Date/Time: Tue, 22 Apr 2025 10:14:28 +0000
Eurex Data not working on New Instance
View Count: 370
[2025-01-13 09:27:30]
Gabriel Poinsot - Posts: 13
Good morning Support Team,
I recently encountered this issue where when I create a new instance everything would work well within the day until I close and re open it then the Eurex data only would just not work anymore ( see attached chart ) when on my main Sierra everything still works perfectly.
I have tried to delete and redownload the data but nothing and my only solution was to delete all instances and do new ones again until I close them and does not work anymore etc.. loop
Looking forward to hear from you for any solution fix
Kind regards,
Gabriel.
imageSierra Eurex Data new instance not working.png / V - Attached On 2025-01-13 09:22:39 UTC - Size: 8.43 KB - 51 views
[2025-01-13 17:51:18]
John - SC Support - Posts: 39395
When you have this issue, we would need to see the Message Log from that instance. Follow these instructions to get us the log:
[2025-01-13 18:34:08]
2025-01-13 18:22:32.982 | Trade activity files set size: 1
2025-01-13 18:22:33.021 | Created the DTC Protocol server.
2025-01-13 18:22:33.022 | DTC Protocol Server listening on port 11111.
2025-01-13 18:22:33.022 | Reading Internal Order ID file.
2025-01-13 18:22:33.023 | Reading Trade Orders file.
2025-01-13 18:22:33.023 | Reading Trade Positions file.
2025-01-13 18:22:33.023 | Reading Trade Account Data files.
2025-01-13 18:22:33.024 | Software version: 2726 64-bit
2025-01-13 18:22:33.024 | Primary Thread ID: 181096
2025-01-13 18:22:33.024 | Usage end date: 2025-06-17
2025-01-13 18:22:33.024 | Enabled for: Advanced Features 2.
2025-01-13 18:22:33.024 | Enabled for: Sierra Chart Historical Data Service.
2025-01-13 18:22:33.024 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-01-13 18:22:33.024 | Enabled for: Delayed Denali Exchange Data Feed.
2025-01-13 18:22:33.024 | Enabled for exchange2: CME (Trading Account Required)
2025-01-13 18:22:33.024 | Enabled for exchange2: CBOT (Trading Account Required)
2025-01-13 18:22:33.024 | Enabled for exchange2: COMEX (Trading Account Required)
2025-01-13 18:22:33.024 | Enabled for exchange2: NYMEX (Trading Account Required)
2025-01-13 18:22:33.024 | Enabled for exchange2: EUREX EOBI
2025-01-13 18:22:33.024 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-01-13 18:22:33.024 | Current selected Data/Trading service: DTC - Sub Instance
2025-01-13 18:22:33.024 | Custom symbol settings values: enabled
2025-01-13 18:22:33.024 | Chart Update Interval: 400
2025-01-13 18:22:33.024 | Intraday Data Storage Time Unit: 0
2025-01-13 18:22:33.024 | Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00)
2025-01-13 18:22:33.024 | 2025-01-13 18:22:33 Local computer time in UTC
2025-01-13 18:22:33.024 | 2025-01-13 18:22:33 Local computer time in SC Time Zone
2025-01-13 18:22:33.024 | 2025-01-13 18:22:31 Server time in UTC
2025-01-13 18:22:33.024 | Local computer UTC time and Server UTC time difference: 1 seconds.
2025-01-13 18:22:33.024 | Program path: C:\SierraChart\SierraChartInstance_2\
2025-01-13 18:22:33.024 | Data Files path: C:\SierraChart\SierraChartInstance_2\Data\
2025-01-13 18:22:33.024 | OS Version Number: 10.0
2025-01-13 18:22:33.024 | Locale Setting: C
2025-01-13 18:22:33.024 | DLLs: FabTradingStudies_64.dll, sst_FreeBundle_64.dll, UserContributedStudies_64.dll
2025-01-13 18:22:33.024 | Allowed protected custom studies: Fab Trading Studies, SST_FreeBundle
2025-01-13 18:22:33.024 | Crash reporter started: true
2025-01-13 18:22:33.037 | Created the DTC Protocol historical data server.
2025-01-13 18:22:33.037 | HD Server Manager | Listening on port 11110.
2025-01-13 18:22:33.147 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-01-13 18:22:33.286 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-01-13 18:22:33.286 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-01-13 18:22:33.622 | Received 5 login tokens.
2025-01-13 18:22:35.538 | Requested user files to download.
2025-01-13 18:22:36.218 | File to download: sst_FreeBundle_64.dll. Action: 1
2025-01-13 18:22:36.218 | File to download: FabTradingStudies_64.dll. Action: 1
2025-01-13 18:22:36.219 | User files to download complete
2025-01-13 18:22:37.541 |
2025-01-13 18:22:37.543 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2025-01-13 18:22:37.543 | DTC Client socket (1) | Creating socket.
2025-01-13 18:22:37.543 | DTC Client socket (1) | New receive buffer size: 0
2025-01-13 18:22:37.543 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2025-01-13 18:22:37.544 | DTC - Sub Instance | Network connection to server complete.
2025-01-13 18:22:37.544 | DTC - Sub Instance | Starting socket receive thread.
2025-01-13 18:22:37.544 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2025-01-13 18:22:37.544 | DTC - Sub Instance | Setting DTC encoding to Binary VLS
2025-01-13 18:22:37.544 | DTC - Sub Instance | Sending logon request message.
2025-01-13 18:22:37.545 | DTC - Sub Instance | Received logon response.
2025-01-13 18:22:37.545 | DTC - Sub Instance | Server Name: SC DTC Server. Build=52055.
2025-01-13 18:22:37.545 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8
2025-01-13 18:22:37.545 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg.
2025-01-13 18:22:37.545 | DTC - Sub Instance | Trading is supported.
2025-01-13 18:22:37.545 | DTC - Sub Instance | Order cancel and replace is supported.
2025-01-13 18:22:37.545 | DTC - Sub Instance | OCO Orders supported.
2025-01-13 18:22:37.545 | DTC - Sub Instance | Bracket Orders supported.
2025-01-13 18:22:37.545 | DTC - Sub Instance | MarketDepthIsSupported: 1
2025-01-13 18:22:37.545 | DTC - Sub Instance | Connected to server complete.
2025-01-13 18:22:37.545 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-13 18:22:37.545 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1.
2025-01-13 18:22:38.519 | Symbol settings MD5 received. Request ID: 1.
2025-01-13 18:22:38.519 | Symbol settings are up-to-date for cqg.
2025-01-13 18:22:42.120 | Loading DLL: C:\SierraChart\SierraChartInstance_2\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffbe9ef0000
2025-01-13 18:22:42.145 | F.US.EU6H25 [CBV] 200 Volume #1 | Reloading chart.
2025-01-13 18:22:42.147 | Starting DelayedDownloadMonitoringTimer
2025-01-13 18:22:42.147 | Starting HDTimeoutTimer
2025-01-13 18:22:42.147 | Added historical Intraday data request for F.US.EU6H25 to the queue.
2025-01-13 18:27:43.644 | HD Request # 40 | Downloading Intraday chart data for F.US.DDZ24 to the file F.US.DDZ24.scid. Service: eurex
2025-01-13 18:27:43.645 | HD Request # 40 | Download start date-time: 2024-12-20 11:59:32.000000. File last date-time: 2024-12-20 11:59:32.101000
2025-01-13 18:27:43.645 | HD Request # 40 | Using server: ds24.sierracharts.com port 10150
2025-01-13 18:27:43.645 | Socket (2) | Creating socket.
2025-01-13 18:27:43.645 | Socket (2) | New receive buffer size: 0
2025-01-13 18:27:43.645 | Socket (2) | Connecting to IP: 62.209.53.226.
2025-01-13 18:27:43.701 | Socket (3) | Socket gracefully closed by remote side.
2025-01-13 18:27:43.701 | Socket (3) | Closed.
2025-01-13 18:27:43.761 | HD Request # 40 | Setting DTC encoding to Binary VLS
2025-01-13 18:27:43.761 | HD Request # 40 | Sending historical data logon request message.
2025-01-13 18:27:43.806 | F.US.DSXH25 [CBV] 1000 Volume #16 | Reloading chart.
2025-01-13 18:27:43.818 | HD Request # 40 | Requesting Intraday data. Start date-time: 2024-12-20 11:59:32. Record interval: 0. Symbol: FDAX202412_FUT_EUREX
2025-01-13 18:27:43.875 | HD Request # 40 | Decompressing data.
2025-01-13 18:27:43.932 | HD Request # 40 | Receiving Intraday data for F.US.DDZ24 starting at 2024-12-20 11:59:32.101000
2025-01-13 18:27:43.932 | Socket (2) | CloseSocket call.
2025-01-13 18:27:43.932 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-13 18:27:43.932 | Historical data download thread signaled to stop.
2025-01-13 18:27:43.932 | HD Request # 40 | Received 1 Intraday data record from 2024-12-20 11:59:32.101000 to 2024-12-20 11:59:32.101000 (0.0 seconds. Delay: 24.3 days) and wrote 0 records for F.US.DDZ24
2025-01-13 18:27:43.932 | HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2024-12-20 11:59:32.101000
2025-01-13 18:27:43.932 | HD Request # 40 | Completion time: 0s.
2025-01-13 18:27:43.932 | HD Request # 40 | Intraday data download complete for F.US.DDZ24. Unique request ID: 37
2025-01-13 18:27:43.932 | Removing historical data download ID 37.
2025-01-13 18:27:43.932 | Real-time Intraday chart data file updates started for F.US.DDZ24
2025-01-13 18:27:43.932 | Intraday chart data file opened for F.US.DDZ24
2025-01-13 18:27:43.932 | HD Request # 40 | Enabling Intraday chart updating for symbol.
2025-01-13 18:27:43.932 | Triggering next historical data download in queue.
2025-01-13 18:27:43.932 | HD Request # 41 | Downloading Intraday chart data for F.US.DDH25 to the file F.US.DDH25.scid. Service: eurex
2025-01-13 18:27:43.933 | HD Request # 41 | Download start date-time: 2025-01-13 18:17:50.000000. File last date-time: 2025-01-13 18:17:50.579000
2025-01-13 18:27:43.933 | HD Request # 41 | Using server: ds14.sierracharts.com port 10149
2025-01-13 18:27:43.933 | Socket (3) | Creating socket.
2025-01-13 18:27:43.933 | Socket (3) | New receive buffer size: 0
2025-01-13 18:27:43.933 | Socket (3) | Connecting to IP: 176.9.9.252.
2025-01-13 18:27:43.988 | Socket (2) | Socket gracefully closed by remote side.
2025-01-13 18:27:43.988 | Socket (2) | Closed.
2025-01-13 18:27:44.071 | HD Request # 41 | Setting DTC encoding to Binary VLS
2025-01-13 18:27:44.071 | HD Request # 41 | Sending historical data logon request message.
2025-01-13 18:27:44.139 | HD Request # 41 | Requesting Intraday data. Start date-time: 2025-01-13 18:17:50. Record interval: 0. Symbol: FDAX202503_FUT_EUREX
2025-01-13 18:27:44.207 | HD Request # 41 | Decompressing data.
2025-01-13 18:27:44.212 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH25. ID: 23
2025-01-13 18:27:44.212 | Symbol Error | F.US.DSXH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH25. ID: 23
2025-01-13 18:27:44.306 | HD Request # 41 | Receiving Intraday data for F.US.DDH25 starting at 2025-01-13 18:17:50.281000
2025-01-13 18:27:44.306 | Socket (3) | CloseSocket call.
2025-01-13 18:27:44.306 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-13 18:27:44.306 | Historical data download thread signaled to stop.
2025-01-13 18:27:44.307 | HD Request # 41 | Timestamp of first Intraday data file record written: 2025-01-13 18:18:03.718000.
2025-01-13 18:27:44.307 | HD Request # 41 | Received 123 Intraday data records from 2025-01-13 18:17:50.281000 to 2025-01-13 18:27:24.559000 (9.6 minutes. Delay: 19.7 seconds) and wrote 120 records for F.US.DDH25
2025-01-13 18:27:44.307 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2025-01-13 18:27:24.559000
2025-01-13 18:27:44.307 | HD Request # 41 | Completion time: 1s.
2025-01-13 18:27:44.307 | HD Request # 41 | Intraday data download complete for F.US.DDH25. Unique request ID: 38
Date Time Of Last Edit: 2025-01-15 04:17:16
[2025-01-15 18:28:23]
Sierra_Chart Engineering - Posts: 19305
We apologize for the delay.
This is the relevant message:
We want you to disable Custom Symbol Settings and see if that resolves the issue:
Global Symbol Settings: Disabling Custom Symbol Settings
Let us know. Try using that symbol in the main instance of Sierra Chart and let us know if you can get the data there.
Date Time Of Last Edit: 2025-01-15 18:29:08
[2025-01-16 06:19:24]
Thanks for your reply, but unfortunately the issue still persists.
I was and still is working on my main Sierra but on my instance it still doesn't work and still have to delete the instance and download it again to make it work.
[2025-01-16 06:20:41]
2025-01-16 06:09:17.234 | Trade activity files set size: 4
2025-01-16 06:09:17.286 | Created the DTC Protocol server.
2025-01-16 06:09:17.288 | DTC Protocol Server listening on port 11111.
2025-01-16 06:09:17.288 | Reading Internal Order ID file.
2025-01-16 06:09:17.289 | Reading Trade Orders file.
2025-01-16 06:09:17.290 | Reading Trade Positions file.
2025-01-16 06:09:17.290 | Reading Trade Account Data files.
2025-01-16 06:09:17.291 | Software version: 2726 64-bit
2025-01-16 06:09:17.291 | Primary Thread ID: 14440
2025-01-16 06:09:17.291 | Usage end date: 2025-06-17
2025-01-16 06:09:17.291 | Enabled for: Advanced Features 2.
2025-01-16 06:09:17.291 | Enabled for: Sierra Chart Historical Data Service.
2025-01-16 06:09:17.291 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-01-16 06:09:17.291 | Enabled for: Delayed Denali Exchange Data Feed.
2025-01-16 06:09:17.291 | Enabled for exchange2: CME (Trading Account Required)
2025-01-16 06:09:17.291 | Enabled for exchange2: CBOT (Trading Account Required)
2025-01-16 06:09:17.291 | Enabled for exchange2: COMEX (Trading Account Required)
2025-01-16 06:09:17.291 | Enabled for exchange2: NYMEX (Trading Account Required)
2025-01-16 06:09:17.291 | Enabled for exchange2: EUREX EOBI
2025-01-16 06:09:17.291 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-01-16 06:09:17.291 | Current selected Data/Trading service: DTC - Sub Instance
2025-01-16 06:09:17.291 | Custom symbol settings values: disabled
2025-01-16 06:09:17.291 | Chart Update Interval: 400
2025-01-16 06:09:17.291 | Intraday Data Storage Time Unit: 0
2025-01-16 06:09:17.291 | Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00)
2025-01-16 06:09:17.291 | 2025-01-16 06:09:17 Local computer time in UTC
2025-01-16 06:09:17.291 | 2025-01-16 06:09:17 Local computer time in SC Time Zone
2025-01-16 06:09:17.291 | 2025-01-16 06:09:16 Server time in UTC
2025-01-16 06:09:17.291 | Local computer UTC time and Server UTC time difference: 1 seconds.
2025-01-16 06:09:17.291 | Program path: C:\SierraChart\SierraChartInstance_2\
2025-01-16 06:09:17.291 | Data Files path: C:\SierraChart\SierraChartInstance_2\Data\
2025-01-16 06:09:17.291 | OS Version Number: 10.0
2025-01-16 06:09:17.291 | Locale Setting: C
2025-01-16 06:09:17.292 | DLLs: FabTradingStudies_64.dll, sst_FreeBundle_64.dll, UserContributedStudies_64.dll
2025-01-16 06:09:17.292 | Allowed protected custom studies: Fab Trading Studies, SST_FreeBundle
2025-01-16 06:09:17.292 | Crash reporter started: true
2025-01-16 06:09:17.306 | Created the DTC Protocol historical data server.
2025-01-16 06:09:17.307 | HD Server Manager | Listening on port 11110.
2025-01-16 06:09:17.401 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-01-16 06:09:17.541 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-01-16 06:09:17.541 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-01-16 06:09:17.893 | Received 5 login tokens.
2025-01-16 06:09:19.809 | Requested user files to download.
2025-01-16 06:09:20.482 | File to download: sst_FreeBundle_64.dll. Action: 1
2025-01-16 06:09:20.483 | File to download: FabTradingStudies_64.dll. Action: 1
2025-01-16 06:09:20.483 | User files to download complete
2025-01-16 06:09:21.806 |
2025-01-16 06:09:21.808 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2025-01-16 06:09:21.808 | DTC Client socket (1) | Creating socket.
2025-01-16 06:09:21.808 | DTC Client socket (1) | New receive buffer size: 0
2025-01-16 06:09:21.808 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2025-01-16 06:09:21.808 | DTC - Sub Instance | Network connection to server complete.
2025-01-16 06:09:21.808 | DTC - Sub Instance | Starting socket receive thread.
2025-01-16 06:09:21.808 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2025-01-16 06:09:21.808 | DTC - Sub Instance | Setting DTC encoding to Binary VLS
2025-01-16 06:09:21.808 | DTC - Sub Instance | Sending logon request message.
2025-01-16 06:09:21.809 | DTC - Sub Instance | Received logon response.
2025-01-16 06:09:21.809 | DTC - Sub Instance | Server Name: SC DTC Server. Build=52055.
2025-01-16 06:09:21.809 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8
2025-01-16 06:09:21.809 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg.
2025-01-16 06:09:21.809 | DTC - Sub Instance | Trading is supported.
2025-01-16 06:09:21.809 | DTC - Sub Instance | Order cancel and replace is supported.
2025-01-16 06:09:21.809 | DTC - Sub Instance | OCO Orders supported.
2025-01-16 06:09:21.809 | DTC - Sub Instance | Bracket Orders supported.
2025-01-16 06:09:21.809 | DTC - Sub Instance | MarketDepthIsSupported: 1
2025-01-16 06:09:21.809 | DTC - Sub Instance | Connected to server complete.
2025-01-16 06:09:21.809 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-16 06:09:21.809 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1.
2025-01-16 06:09:22.812 | Symbol settings MD5 received. Request ID: 1.
2025-01-16 06:09:22.812 | Symbol settings are up-to-date for cqg.
2025-01-16 06:09:54.728 | Loading DLL: C:\SierraChart\SierraChartInstance_2\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffeec2e0000
2025-01-16 06:09:54.758 | F.US.EU6H25 [CBV] 200 Volume #1 | Reloading chart.
2025-01-16 06:09:54.760 | Starting DelayedDownloadMonitoringTimer
2025-01-16 06:09:54.760 | Starting HDTimeoutTimer
2025-01-16 06:09:54.760 | Added historical Intraday data request for F.US.EU6H25 to the queue.
2025-01-16 06:09:54.762 | Triggering next historical data download in queue.
2025-01-16 06:09:54.778 | F.US.EU6H25 [CBV] 200 Volume #1 | Waiting for historical downloads to complete with the IDs: 1,
2025-01-16 06:09:54.807 | F.US.EPH25 [CBV] 3000 Volume #2 | Reloading chart.
2025-01-16 06:09:54.809 | Added historical Intraday data request for F.US.EPH25 to the queue.
2025-01-16 06:09:54.829 | F.US.EPH25 [CBV] 3000 Volume #2 | Waiting for historical downloads to complete with the IDs: 2,
2025-01-16 06:09:54.861 | F.US.GCEG25 [CBV] 250 Volume #3 | Reloading chart.
2025-01-16 06:09:54.863 | Added historical Intraday data request for F.US.GCEG25 to the queue.
2025-01-16 06:09:54.884 | F.US.GCEG25 [CBV] 250 Volume #3 | Waiting for historical downloads to complete with the IDs: 3,
2025-01-16 06:09:54.913 | F.US.JY6H25 [CBV] 250 Volume #4 | Reloading chart.
2025-01-16 06:09:54.915 | Added historical Intraday data request for F.US.JY6H25 to the queue.
2025-01-16 06:09:54.930 | F.US.JY6H25 [CBV] 250 Volume #4 | Waiting for historical downloads to complete with the IDs: 4,
2025-01-16 06:09:54.961 | F.US.CPEH25 [CBV] 200 Volume #5 | Reloading chart.
2025-01-16 06:09:54.964 | Added historical Intraday data request for F.US.CPEH25 to the queue.
2025-01-16 06:09:54.987 | F.US.CPEH25 [CBV] 200 Volume #5 | Waiting for historical downloads to complete with the IDs: 5,
2025-01-16 06:09:55.018 | F.US.FVAH25 [CBV] 1000 Volume #6 | Reloading chart.
2025-01-16 06:09:55.021 | Added historical Intraday data request for F.US.FVAH25 to the queue.
2025-01-16 06:09:55.041 | F.US.FVAH25 [CBV] 1000 Volume #6 | Waiting for historical downloads to complete with the IDs: 6,
2025-01-16 06:09:55.070 | F.US.TUAH25 [CBV] 1000 Volume #7 | Reloading chart.
2025-01-16 06:09:55.071 | Added historical Intraday data request for F.US.TUAH25 to the queue.
2025-01-16 06:09:55.092 | F.US.TUAH25 [CBV] 1000 Volume #7 | Waiting for historical downloads to complete with the IDs: 7,
2025-01-16 06:09:55.120 | F.US.USAH25 [CBV] 800 Volume #8 | Reloading chart.
2025-01-16 06:09:55.123 | Added historical Intraday data request for F.US.USAH25 to the queue.
2025-01-16 06:09:55.143 | F.US.USAH25 [CBV] 800 Volume #8 | Waiting for historical downloads to complete with the IDs: 8,
2025-01-16 06:09:55.171 | F.US.TYAH25 [CBV] 1000 Volume #9 | Reloading chart.
2025-01-16 06:09:55.173 | Added historical Intraday data request for F.US.TYAH25 to the queue.
2025-01-16 06:09:55.193 | F.US.TYAH25 [CBV] 1000 Volume #9 | Waiting for historical downloads to complete with the IDs: 9,
2025-01-16 06:09:55.222 | F.US.BP6H25 [CBV] 100 Volume #10 | Reloading chart.
2025-01-16 06:09:55.224 | Added historical Intraday data request for F.US.BP6H25 to the queue.
2025-01-16 06:09:55.241 | F.US.BP6H25 [CBV] 100 Volume #10 | Waiting for historical downloads to complete with the IDs: 10,
2025-01-16 06:09:55.270 | F.US.DA6H25 [CBV] 100 Volume #11 | Reloading chart.
2025-01-16 06:09:55.272 | Added historical Intraday data request for F.US.DA6H25 to the queue.
2025-01-16 06:09:55.288 | F.US.DA6H25 [CBV] 100 Volume #11 | Waiting for historical downloads to complete with the IDs: 11,
2025-01-16 06:09:55.317 | F.US.CLEH25 [CBV] 500 Volume #12 | Reloading chart.
2025-01-16 06:09:55.323 | Added historical Intraday data request for F.US.CLEG25 to the queue.
2025-01-16 06:09:55.324 | Added historical Intraday data request for F.US.CLEH25 to the queue.
2025-01-16 06:09:55.346 | F.US.CLEH25 [CBV] 500 Volume #12 | Waiting for historical downloads to complete with the IDs: 12, 13,
2025-01-16 06:09:55.380 | F.US.NGEG25 [CBV] 100 Volume #13 | Reloading chart.
2025-01-16 06:09:55.386 | Added historical Intraday data request for F.US.NGEG25 to the queue.
2025-01-16 06:09:55.410 | F.US.NGEG25 [CBV] 100 Volume #13 | Waiting for historical downloads to complete with the IDs: 14,
2025-01-16 06:09:55.440 | F.US.DBH25 [CBV] 1000 Volume #14 | Reloading chart.
2025-01-16 06:09:55.441 | Added historical Intraday data request for F.US.DBU24 to the queue.
2025-01-16 06:09:55.441 | Added historical Intraday data request for F.US.DBZ24 to the queue.
2025-01-16 06:09:55.442 | Added historical Intraday data request for F.US.DBH25 to the queue.
2025-01-16 06:09:55.460 | F.US.DBH25 [CBV] 1000 Volume #14 | Waiting for historical downloads to complete with the IDs: 15, 16, 17,
2025-01-16 06:09:55.489 | F.US.ENQH25 [CBV] 1500 Volume #15 | Reloading chart.
2025-01-16 06:09:55.491 | Added historical Intraday data request for F.US.ENQH25 to the queue.
2025-01-16 06:09:55.510 | F.US.ENQH25 [CBV] 1500 Volume #15 | Waiting for historical downloads to complete with the IDs: 18,
2025-01-16 06:09:55.541 | F.US.DSXH25 [CBV] 1000 Volume #16 | Reloading chart.
2025-01-16 06:09:55.541 | Added historical Intraday data request for F.US.DSXU24 to the queue.
2025-01-16 06:09:55.542 | Added historical Intraday data request for F.US.DSXZ24 to the queue.
2025-01-16 06:09:55.543 | Added historical Intraday data request for F.US.DSXH25 to the queue.
2025-01-16 06:09:55.561 | F.US.DSXH25 [CBV] 1000 Volume #16 | Waiting for historical downloads to complete with the IDs: 19, 20, 21,
2025-01-16 06:09:55.596 | F.US.DDH25 [CBV] 50 Volume #17 | Reloading chart.
2025-01-16 06:09:55.597 | Added historical Intraday data request for F.US.DDU24 to the queue.
2025-01-16 06:09:55.598 | Added historical Intraday data request for F.US.DDZ24 to the queue.
2025-01-16 06:09:55.599 | Added historical Intraday data request for F.US.DDH25 to the queue.
2025-01-16 06:09:55.619 | F.US.DDH25 [CBV] 50 Volume #17 | Waiting for historical downloads to complete with the IDs: 22, 23, 24,
2025-01-16 06:09:55.648 | F.US.DLH25 [CBV] 1000 Volume #18 | Reloading chart.
2025-01-16 06:09:55.649 | Added historical Intraday data request for F.US.DLU24 to the queue.
2025-01-16 06:09:55.650 | Added historical Intraday data request for F.US.DLZ24 to the queue.
2025-01-16 06:09:55.651 | Added historical Intraday data request for F.US.DLH25 to the queue.
2025-01-16 06:09:55.670 | F.US.DLH25 [CBV] 1000 Volume #18 | Waiting for historical downloads to complete with the IDs: 25, 26, 27,
2025-01-16 06:09:55.700 | F.US.DGH25 [CBV] 1000 Volume #19 | Reloading chart.
2025-01-16 06:09:55.700 | Added historical Intraday data request for F.US.DGU24 to the queue.
2025-01-16 06:09:55.701 | Added historical Intraday data request for F.US.DGZ24 to the queue.
2025-01-16 06:09:55.702 | Added historical Intraday data request for F.US.DGH25 to the queue.
2025-01-16 06:09:55.720 | F.US.DGH25 [CBV] 1000 Volume #19 | Waiting for historical downloads to complete with the IDs: 28, 29, 30,
2025-01-16 06:09:55.756 | F.US.FGBXH25 [CBV] 250 Volume #20 | Reloading chart.
2025-01-16 06:09:55.756 | Added historical Intraday data request for F.US.FGBXU24 to the queue.
2025-01-16 06:09:55.757 | Added historical Intraday data request for F.US.FGBXZ24 to the queue.
2025-01-16 06:09:55.758 | Added historical Intraday data request for F.US.FGBXH25 to the queue.
2025-01-16 06:09:55.776 | F.US.FGBXH25 [CBV] 250 Volume #20 | Waiting for historical downloads to complete with the IDs: 31, 32, 33,
2025-01-16 06:09:55.810 | F.US.SF6H25 [CBV] 100 Volume #21 | Reloading chart.
2025-01-16 06:09:55.811 | Added historical Intraday data request for F.US.SF6H25 to the queue.
2025-01-16 06:09:55.827 | F.US.SF6H25 [CBV] 100 Volume #21 | Waiting for historical downloads to complete with the IDs: 34,
2025-01-16 06:09:55.858 | F.US.FOATH25 [CBV] 250 Volume #22 | Reloading chart.
2025-01-16 06:09:55.859 | Added historical Intraday data request for F.US.FOATU24 to the queue.
2025-01-16 06:09:55.860 | Added historical Intraday data request for F.US.FOATZ24 to the queue.
2025-01-16 06:09:55.861 | Added historical Intraday data request for F.US.FOATH25 to the queue.
2025-01-16 06:09:55.878 | F.US.FOATH25 [CBV] 250 Volume #22 | Waiting for historical downloads to complete with the IDs: 35, 36, 37,
2025-01-16 06:09:55.910 | F.US.FBTPH25 [CBV] 250 Volume #23 | Reloading chart.
2025-01-16 06:09:55.911 | Added historical Intraday data request for F.US.FBTPH25 to the queue.
2025-01-16 06:09:55.930 | F.US.FBTPH25 [CBV] 250 Volume #23 | Waiting for historical downloads to complete with the IDs: 38,
2025-01-16 06:09:55.962 | F.US.BTCF25 [CBV] 1 Min #24 | Reloading chart.
2025-01-16 06:09:55.965 | Added historical Intraday data request for F.US.BTCV24 to the queue.
2025-01-16 06:09:55.967 | Added historical Intraday data request for F.US.BTCF25 to the queue.
2025-01-16 06:09:55.986 | F.US.BTCF25 [CBV] 1 Min #24 | Waiting for historical downloads to complete with the IDs: 39, 40,
2025-01-16 06:09:56.022 | HKG33 [CBV] 1 Min #25 | Reloading chart.
2025-01-16 06:09:56.022 | HKG33 [CBV] 1 Min #25 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-01-16 06:09:56.022 | HKG33 [CBV] 1 Min #25 | There are no continuous futures contract symbols. Loading data normally.
2025-01-16 06:09:56.058 | F.US.MX6H25 [CBV] 100 Volume #26 | Reloading chart.
2025-01-16 06:09:56.060 | Added historical Intraday data request for F.US.MX6H25 to the queue.
2025-01-16 06:09:56.079 | F.US.MX6H25 [CBV] 100 Volume #26 | Waiting for historical downloads to complete with the IDs: 41,
2025-01-16 06:09:56.113 | F.US.CA6H25 [CBV] 100 Volume #27 | Reloading chart.
2025-01-16 06:09:56.115 | Added historical Intraday data request for F.US.CA6H25 to the queue.
2025-01-16 06:09:56.131 | F.US.CA6H25 [CBV] 100 Volume #27 | Waiting for historical downloads to complete with the IDs: 42,
2025-01-16 06:09:56.163 | F.US.RTYH25 [CBV] 200 Volume #28 | Reloading chart.
2025-01-16 06:09:56.165 | Added historical Intraday data request for F.US.RTYH25 to the queue.
2025-01-16 06:09:56.184 | F.US.RTYH25 [CBV] 200 Volume #28 | Waiting for historical downloads to complete with the IDs: 43,
2025-01-16 06:09:56.215 | F.US.YMH25 [CBV] 200 Volume #29 | Reloading chart.
2025-01-16 06:09:56.218 | Added historical Intraday data request for F.US.YMH25 to the queue.
2025-01-16 06:09:56.237 | F.US.YMH25 [CBV] 200 Volume #29 | Waiting for historical downloads to complete with the IDs: 44,
2025-01-16 06:09:56.275 | UK100 [CBV] 1 Min #30 | Reloading chart.
2025-01-16 06:09:56.275 | UK100 [CBV] 1 Min #30 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-01-16 06:09:56.275 | UK100 [CBV] 1 Min #30 | There are no continuous futures contract symbols. Loading data normally.
2025-01-16 06:09:56.310 | FRA40 [CBV] 1 Min #31 | Reloading chart.
2025-01-16 06:09:56.310 | FRA40 [CBV] 1 Min #31 | No contract months found for symbol. Unable to build continuous futures contract chart.
2025-01-16 06:09:56.310 | FRA40 [CBV] 1 Min #31 | There are no continuous futures contract symbols. Loading data normally.
2025-01-16 06:09:56.349 | F.US.NKDH25 [CBV] 25 Volume #32 | Reloading chart.
2025-01-16 06:09:56.351 | Added historical Intraday data request for F.US.NKDH25 to the queue.
2025-01-16 06:09:56.371 | F.US.NKDH25 [CBV] 25 Volume #32 | Waiting for historical downloads to complete with the IDs: 45,
2025-01-16 06:09:56.407 | F.US.BR6G25 [CBV] 100 Volume #33 | Reloading chart.
2025-01-16 06:09:56.407 | Added historical Intraday data request for F.US.BR6N24 to the queue.
2025-01-16 06:09:56.408 | Added historical Intraday data request for F.US.BR6Q24 to the queue.
2025-01-16 06:09:56.409 | Added historical Intraday data request for F.US.BR6U24 to the queue.
2025-01-16 06:09:56.409 | Added historical Intraday data request for F.US.BR6V24 to the queue.
2025-01-16 06:09:56.410 | Added historical Intraday data request for F.US.BR6X24 to the queue.
2025-01-16 06:09:56.411 | Added historical Intraday data request for F.US.BR6Z24 to the queue.
2025-01-16 06:09:56.412 | Added historical Intraday data request for F.US.BR6F25 to the queue.
2025-01-16 06:09:56.413 | Added historical Intraday data request for F.US.BR6G25 to the queue.
2025-01-16 06:09:56.416 | F.US.BR6G25 [CBV] 100 Volume #33 | File F.US.BR6F25.dly has a volume of 0 at 2025-01-09.
2025-01-16 06:09:56.419 | F.US.BR6G25 [CBV] 100 Volume #33 | File F.US.BR6X24.dly has a volume of 0 at 2024-11-14.
2025-01-16 06:09:56.421 | F.US.BR6G25 [CBV] 100 Volume #33 | File F.US.BR6V24.dly has a volume of 0 at 2024-10-10.
2025-01-16 06:09:56.424 | F.US.BR6G25 [CBV] 100 Volume #33 | File F.US.BR6Q24.dly has a volume of 0 at 2024-08-15.
2025-01-16 06:09:56.425 | F.US.BR6G25 [CBV] 100 Volume #33 | Waiting for historical downloads to complete with the IDs: 46, 47, 48, 49, 50, 51, 52, 53,
2025-01-16 06:09:56.463 | F.US.SIEH25 [CBV] 200 Volume #34 | Reloading chart.
2025-01-16 06:09:56.465 | Added historical Intraday data request for F.US.SIEH25 to the queue.
2025-01-16 06:09:56.491 | F.US.SIEH25 [CBV] 200 Volume #34 | Waiting for historical downloads to complete with the IDs: 54,
2025-01-16 06:09:56.529 | F.US.PAEH25 [CBV] 25 Volume #35 | Reloading chart.
2025-01-16 06:09:56.531 | Added historical Intraday data request for F.US.PAEH25 to the queue.
2025-01-16 06:09:56.555 | F.US.PAEH25 [CBV] 25 Volume #35 | Waiting for historical downloads to complete with the IDs: 55,
2025-01-16 06:09:56.596 | F.US.RBEG25 [CBV] 100 Volume #36 | Reloading chart.
2025-01-16 06:09:56.602 | Added historical Intraday data request for F.US.RBEG25 to the queue.
2025-01-16 06:09:56.631 | F.US.RBEG25 [CBV] 100 Volume #36 | Waiting for historical downloads to complete with the IDs: 56,
2025-01-16 06:09:56.667 | F.US.ULAH25 [CBV] 1000 Volume #37 | Reloading chart.
2025-01-16 06:09:56.669 | Added historical Intraday data request for F.US.ULAH25 to the queue.
2025-01-16 06:09:56.692 | F.US.ULAH25 [CBV] 1000 Volume #37 | Waiting for historical downloads to complete with the IDs: 57,
2025-01-16 06:09:56.732 | F.US.ZSEH25 [CBV] 500 Volume #38 | Reloading chart.
2025-01-16 06:09:56.735 | Added historical Intraday data request for F.US.ZSEH25 to the queue.
2025-01-16 06:09:56.761 | F.US.ZSEH25 [CBV] 500 Volume #38 | Waiting for historical downloads to complete with the IDs: 58,
2025-01-16 06:09:56.800 | F.US.ZCEH25 [CBV] 500 Volume #39 | Reloading chart.
2025-01-16 06:09:56.802 | Added historical Intraday data request for F.US.ZCEH25 to the queue.
2025-01-16 06:09:56.826 | F.US.ZCEH25 [CBV] 500 Volume #39 | Waiting for historical downloads to complete with the IDs: 59,
2025-01-16 06:09:56.866 | F.US.ZWAH25 [CBV] 200 Volume #40 | Reloading chart.
2025-01-16 06:09:56.869 | Added historical Intraday data request for F.US.ZWAH25 to the queue.
2025-01-16 06:09:56.896 | F.US.ZWAH25 [CBV] 200 Volume #40 | Waiting for historical downloads to complete with the IDs: 60,
2025-01-16 06:09:56.901 | Using symbol data fast lookup vector
2025-01-16 06:09:56.901 | HD Request # 1 | Downloading Intraday chart data for F.US.EU6H25 to the file F.US.EU6H25.scid. Service: cme
2025-01-16 06:09:56.901 | HD Request # 1 | Download start date-time: 2025-01-16 06:04:25.000000. File last date-time: 2025-01-16 06:04:25.155000
2025-01-16 06:09:56.901 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149
2025-01-16 06:09:56.903 | Socket (2) | Creating socket.
2025-01-16 06:09:56.903 | Socket (2) | New receive buffer size: 0
2025-01-16 06:09:56.903 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-16 06:09:57.021 | UK100 [CBV-D] 1 Min #30 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:09:57.195 | HD Request # 1 | Setting DTC encoding to Binary VLS
2025-01-16 06:09:57.195 | HD Request # 1 | Sending historical data logon request message.
2025-01-16 06:09:57.382 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:25. Record interval: 0. Symbol: 6EH25
2025-01-16 06:09:57.524 | HD Request # 1 | Decompressing data.
2025-01-16 06:09:57.666 | HD Request # 1 | Receiving Intraday data for F.US.EU6H25 starting at 2025-01-16 06:04:25.076000
2025-01-16 06:09:57.667 | Socket (2) | CloseSocket call.
2025-01-16 06:09:57.667 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:09:57.810 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:09:57.810 | Socket (2) | Closed.
2025-01-16 06:10:19.570 | UK100 [CBV-D] 1 Min #30 | Chart data loading complete.
2025-01-16 06:10:42.089 | FRA40 [CBV-D] 1 Min #31 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:10:53.671 | FRA40 [CBV-D] 1 Min #31 | Chart data loading complete.
2025-01-16 06:10:53.673 | Historical data download thread signaled to stop.
2025-01-16 06:10:53.673 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:52.157000.
2025-01-16 06:10:53.673 | HD Request # 1 | Received 61 Intraday data records from 2025-01-16 06:04:25.076000 to 2025-01-16 06:09:32.738001 (5.1 minutes. Delay: 80.9 seconds) and wrote 59 records for F.US.EU6H25
2025-01-16 06:10:53.674 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:09:32.738001
2025-01-16 06:10:53.674 | HD Request # 1 | Completion time: 57s.
2025-01-16 06:10:53.674 | HD Request # 1 | Intraday data download complete for F.US.EU6H25. Unique request ID: 1
2025-01-16 06:10:53.674 | Removing historical data download ID 1.
2025-01-16 06:10:53.674 | Real-time Intraday chart data file updates started for F.US.EU6H25
2025-01-16 06:10:53.674 | Intraday chart data file opened for F.US.EU6H25
2025-01-16 06:10:53.674 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2025-01-16 06:10:53.674 | Triggering next historical data download in queue.
2025-01-16 06:10:53.683 | HKG33 [CBV-D] 1 Min #25 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:11:07.303 | HKG33 [CBV-D] 1 Min #25 | Chart data loading complete.
2025-01-16 06:11:32.703 | HD Request # 2 | Downloading Intraday chart data for F.US.EPH25 to the file F.US.EPH25.scid. Service: cme
2025-01-16 06:11:32.703 | HD Request # 2 | Download start date-time: 2025-01-16 06:04:44.000000. File last date-time: 2025-01-16 06:04:44.707000
2025-01-16 06:11:32.703 | HD Request # 2 | Using server: ds32.sierracharts.com port 10150
2025-01-16 06:11:32.705 | Socket (2) | Creating socket.
2025-01-16 06:11:32.705 | Socket (2) | New receive buffer size: 0
2025-01-16 06:11:32.705 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-16 06:11:32.914 | Using Bid/Ask average for last trade price for HKG33
2025-01-16 06:11:32.914 | DTC - Sub Instance | Starting real-time market data updates for: HKG33. ID: 3 Service code: fxcm
2025-01-16 06:11:32.914 | DTC - Sub Instance | Requesting security definition data for: HKG33. ID: 3
2025-01-16 06:11:32.914 | Added historical Intraday data request for HKG33 to the queue.
2025-01-16 06:11:32.914 | Intraday data recording state for symbol HKG33 is set to download 'Pending'.
2025-01-16 06:11:32.914 | Triggering next historical data download in queue.
2025-01-16 06:11:32.933 | DTC - Sub Instance | Setting external service identifier for symbol HKG33 to 50
2025-01-16 06:11:32.933 | DTC - Sub Instance | Received security definition for symbol HKG33
2025-01-16 06:11:32.955 | Using Bid/Ask average for last trade price for UK100
2025-01-16 06:11:32.955 | DTC - Sub Instance | Starting real-time market data updates for: UK100. ID: 4 Service code: fxcm
2025-01-16 06:11:32.955 | DTC - Sub Instance | Requesting security definition data for: UK100. ID: 4
2025-01-16 06:11:32.955 | Added historical Intraday data request for UK100 to the queue.
2025-01-16 06:11:32.955 | Intraday data recording state for symbol UK100 is set to download 'Pending'.
2025-01-16 06:11:32.955 | Triggering next historical data download in queue.
2025-01-16 06:11:32.967 | DTC - Sub Instance | Setting external service identifier for symbol UK100 to 56
2025-01-16 06:11:32.967 | DTC - Sub Instance | Received security definition for symbol UK100
2025-01-16 06:11:32.967 | Using Bid/Ask average for last trade price for FRA40
2025-01-16 06:11:32.967 | DTC - Sub Instance | Starting real-time market data updates for: FRA40. ID: 5 Service code: fxcm
2025-01-16 06:11:32.967 | DTC - Sub Instance | Requesting security definition data for: FRA40. ID: 5
2025-01-16 06:11:32.967 | Added historical Intraday data request for FRA40 to the queue.
2025-01-16 06:11:32.967 | Intraday data recording state for symbol FRA40 is set to download 'Pending'.
2025-01-16 06:11:32.967 | Triggering next historical data download in queue.
2025-01-16 06:11:32.985 | DTC - Sub Instance | Setting external service identifier for symbol FRA40 to 48
2025-01-16 06:11:32.985 | DTC - Sub Instance | Received security definition for symbol FRA40
2025-01-16 06:11:32.998 | HD Request # 2 | Setting DTC encoding to Binary VLS
2025-01-16 06:11:32.998 | HD Request # 2 | Sending historical data logon request message.
2025-01-16 06:11:33.039 | F.US.EU6H25 [CBV] 200 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:11:33.039 | F.US.EU6H25 [CBV] 200 Volume #1 | Reloading chart.
2025-01-16 06:11:33.188 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:44. Record interval: 0. Symbol: ESH25
2025-01-16 06:11:33.331 | HD Request # 2 | Decompressing data.
2025-01-16 06:11:33.451 | F.US.EU6H25 [CBV] 200 Volume #1 | Reloading chart.
2025-01-16 06:11:33.478 | HD Request # 2 | Receiving Intraday data for F.US.EPH25 starting at 2025-01-16 06:04:44.707000
2025-01-16 06:11:33.479 | Socket (2) | CloseSocket call.
2025-01-16 06:11:33.479 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:11:33.582 | Historical data download thread signaled to stop.
2025-01-16 06:11:33.583 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:53.867000.
2025-01-16 06:11:33.583 | HD Request # 2 | Received 1391 Intraday data records from 2025-01-16 06:04:44.707000 to 2025-01-16 06:11:28.865001 (6.7 minutes. Delay: 4.7 seconds) and wrote 1390 records for F.US.EPH25
2025-01-16 06:11:33.583 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:11:28.865001
2025-01-16 06:11:33.583 | HD Request # 2 | Completion time: 1s.
2025-01-16 06:11:33.583 | HD Request # 2 | Intraday data download complete for F.US.EPH25. Unique request ID: 2
2025-01-16 06:11:33.583 | Removing historical data download ID 2.
2025-01-16 06:11:33.583 | Real-time Intraday chart data file updates started for F.US.EPH25
2025-01-16 06:11:33.583 | Intraday chart data file opened for F.US.EPH25
2025-01-16 06:11:33.583 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2025-01-16 06:11:33.583 | Triggering next historical data download in queue.
2025-01-16 06:11:33.583 | HD Request # 3 | Downloading Intraday chart data for F.US.GCEG25 to the file F.US.GCEG25.scid. Service: comex
2025-01-16 06:11:33.583 | HD Request # 3 | Download start date-time: 2025-01-16 06:04:43.000000. File last date-time: 2025-01-16 06:04:43.972000
2025-01-16 06:11:33.583 | HD Request # 3 | Using server: ds26.sierracharts.com port 10149
2025-01-16 06:11:33.622 | F.US.EPH25 [CBV] 3000 Volume #2 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:11:33.622 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:11:33.623 | F.US.EPH25 [CBV] 3000 Volume #2 | Reloading chart.
2025-01-16 06:11:33.623 | Socket (2) | Closed.
2025-01-16 06:11:33.667 | Socket (3) | Creating socket.
2025-01-16 06:11:33.667 | Socket (3) | New receive buffer size: 0
2025-01-16 06:11:33.667 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-16 06:11:33.849 | DTC - Sub Instance | Starting real-time market data updates for: F.US.EU6H25. ID: 1 Service code: cqg
2025-01-16 06:11:33.849 | DTC - Sub Instance | Requesting security definition data for: F.US.EU6H25. ID: 1
2025-01-16 06:11:33.849 | DTC - Sub Instance | Setting external service identifier for symbol F.US.EU6H25 to 42272
2025-01-16 06:11:33.849 | DTC - Sub Instance | Received security definition for symbol F.US.EU6H25
2025-01-16 06:11:33.953 | HD Request # 3 | Setting DTC encoding to Binary VLS
2025-01-16 06:11:33.953 | HD Request # 3 | Sending historical data logon request message.
2025-01-16 06:11:34.023 | F.US.EPH25 [CBV] 3000 Volume #2 | Reloading chart.
2025-01-16 06:11:34.137 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:43. Record interval: 0. Symbol: GCG25
2025-01-16 06:11:34.277 | HD Request # 3 | Decompressing data.
2025-01-16 06:11:34.418 | HD Request # 3 | Receiving Intraday data for F.US.GCEG25 starting at 2025-01-16 06:04:43.126000
2025-01-16 06:11:34.418 | Socket (3) | CloseSocket call.
2025-01-16 06:11:34.418 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:11:34.419 | Historical data download thread signaled to stop.
2025-01-16 06:11:34.419 | HD Request # 3 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:52.207000.
2025-01-16 06:11:34.419 | HD Request # 3 | Received 258 Intraday data records from 2025-01-16 06:04:43.126000 to 2025-01-16 06:11:30.080001 (6.8 minutes. Delay: 4.3 seconds) and wrote 256 records for F.US.GCEG25
2025-01-16 06:11:34.419 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:11:30.080001
2025-01-16 06:11:34.419 | HD Request # 3 | Completion time: 1s.
2025-01-16 06:11:34.419 | HD Request # 3 | Intraday data download complete for F.US.GCEG25. Unique request ID: 3
2025-01-16 06:11:34.419 | Removing historical data download ID 3.
2025-01-16 06:11:34.419 | Real-time Intraday chart data file updates started for F.US.GCEG25
2025-01-16 06:11:34.419 | Intraday chart data file opened for F.US.GCEG25
2025-01-16 06:11:34.419 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-01-16 06:11:34.419 | Triggering next historical data download in queue.
2025-01-16 06:11:34.419 | HD Request # 4 | Downloading Intraday chart data for F.US.JY6H25 to the file F.US.JY6H25.scid. Service: cme
2025-01-16 06:11:34.419 | HD Request # 4 | Download start date-time: 2025-01-16 06:04:35.000000. File last date-time: 2025-01-16 06:04:35.077000
2025-01-16 06:11:34.419 | HD Request # 4 | Using server: ds28.sierracharts.com port 10150
2025-01-16 06:11:34.419 | Socket (2) | Creating socket.
2025-01-16 06:11:34.419 | Socket (2) | New receive buffer size: 0
2025-01-16 06:11:34.419 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-16 06:11:34.432 | DTC - Sub Instance | Starting real-time market data updates for: F.US.EPH25. ID: 2 Service code: cqg
2025-01-16 06:11:34.432 | DTC - Sub Instance | Requesting security definition data for: F.US.EPH25. ID: 2
2025-01-16 06:11:34.432 | DTC - Sub Instance | Setting external service identifier for symbol F.US.EPH25 to 5002
2025-01-16 06:11:34.432 | DTC - Sub Instance | Received security definition for symbol F.US.EPH25
2025-01-16 06:11:34.558 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:11:34.558 | Socket (3) | Closed.
2025-01-16 06:11:34.712 | HD Request # 4 | Setting DTC encoding to Binary VLS
2025-01-16 06:11:34.712 | HD Request # 4 | Sending historical data logon request message.
2025-01-16 06:11:34.840 | F.US.GCEG25 [CBV] 250 Volume #3 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:11:34.840 | F.US.GCEG25 [CBV] 250 Volume #3 | Reloading chart.
2025-01-16 06:11:34.900 | HD Request # 4 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:35. Record interval: 0. Symbol: 6JH25
2025-01-16 06:11:35.044 | HD Request # 4 | Decompressing data.
2025-01-16 06:11:35.187 | HD Request # 4 | Receiving Intraday data for F.US.JY6H25 starting at 2025-01-16 06:04:35.077000
2025-01-16 06:11:35.187 | Socket (2) | CloseSocket call.
2025-01-16 06:11:35.187 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:11:35.331 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:11:35.331 | Socket (2) | Closed.
2025-01-16 06:11:38.269 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.EPH25.scid. Thread ID: 24244
2025-01-16 06:11:43.333 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.EU6H25.scid. Thread ID: 24244
2025-01-16 06:11:54.469 | F.US.EU6H25 [CBV] 200 Volume #1 | Chart data loading complete.
2025-01-16 06:11:54.470 | Historical data download thread signaled to stop.
2025-01-16 06:11:54.470 | HD Request # 4 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:57.608000.
2025-01-16 06:11:54.470 | HD Request # 4 | Received 174 Intraday data records from 2025-01-16 06:04:35.077000 to 2025-01-16 06:11:25.771000 (6.8 minutes. Delay: 28.7 seconds) and wrote 173 records for F.US.JY6H25
2025-01-16 06:11:54.470 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:11:25.771000
2025-01-16 06:11:54.470 | HD Request # 4 | Completion time: 20s.
2025-01-16 06:11:54.470 | HD Request # 4 | Intraday data download complete for F.US.JY6H25. Unique request ID: 4
2025-01-16 06:11:54.470 | Removing historical data download ID 4.
2025-01-16 06:11:54.470 | Real-time Intraday chart data file updates started for F.US.JY6H25
2025-01-16 06:11:54.470 | Intraday chart data file opened for F.US.JY6H25
2025-01-16 06:11:54.470 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2025-01-16 06:11:54.470 | Triggering next historical data download in queue.
2025-01-16 06:12:01.399 | F.US.GCEG25 [CBV] 250 Volume #3 | Chart data loading complete.
2025-01-16 06:12:01.439 | F.US.EPH25 [CBV] 3000 Volume #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:12:04.982 | F.US.EPH25 [CBV] 3000 Volume #2 | Chart data loading complete.
2025-01-16 06:12:04.986 | HD Request # 5 | Downloading Intraday chart data for F.US.CPEH25 to the file F.US.CPEH25.scid. Service: comex
2025-01-16 06:12:04.986 | HD Request # 5 | Download start date-time: 2025-01-16 06:04:44.000000. File last date-time: 2025-01-16 06:04:44.613000
2025-01-16 06:12:04.986 | HD Request # 5 | Using server: ds32.sierracharts.com port 10149
2025-01-16 06:12:04.986 | Socket (2) | Creating socket.
2025-01-16 06:12:04.986 | Socket (2) | New receive buffer size: 0
2025-01-16 06:12:04.986 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-16 06:12:05.280 | HD Request # 5 | Setting DTC encoding to Binary VLS
2025-01-16 06:12:05.280 | HD Request # 5 | Sending historical data logon request message.
2025-01-16 06:12:05.468 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:44. Record interval: 0. Symbol: HGH25
2025-01-16 06:12:05.612 | HD Request # 5 | Decompressing data.
2025-01-16 06:12:05.754 | HD Request # 5 | Receiving Intraday data for F.US.CPEH25 starting at 2025-01-16 06:04:44.612000
2025-01-16 06:12:05.755 | Socket (2) | CloseSocket call.
2025-01-16 06:12:05.755 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:12:05.897 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:12:05.897 | Socket (2) | Closed.
2025-01-16 06:12:08.569 | Historical data download thread signaled to stop.
2025-01-16 06:12:08.569 | HD Request # 5 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:56.651000.
2025-01-16 06:12:08.569 | HD Request # 5 | Received 68 Intraday data records from 2025-01-16 06:04:44.612000 to 2025-01-16 06:12:02.178001 (7.3 minutes. Delay: 6.4 seconds) and wrote 66 records for F.US.CPEH25
2025-01-16 06:12:08.569 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:12:02.178001
2025-01-16 06:12:08.569 | HD Request # 5 | Completion time: 4s.
2025-01-16 06:12:08.569 | HD Request # 5 | Intraday data download complete for F.US.CPEH25. Unique request ID: 5
2025-01-16 06:12:08.569 | Removing historical data download ID 5.
2025-01-16 06:12:08.569 | Real-time Intraday chart data file updates started for F.US.CPEH25
2025-01-16 06:12:08.569 | Intraday chart data file opened for F.US.CPEH25
2025-01-16 06:12:08.569 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2025-01-16 06:12:08.569 | Triggering next historical data download in queue.
2025-01-16 06:12:08.572 | HD Request # 6 | Downloading Intraday chart data for F.US.FVAH25 to the file F.US.FVAH25.scid. Service: cbot
2025-01-16 06:12:08.572 | HD Request # 6 | Download start date-time: 2025-01-16 06:04:27.000000. File last date-time: 2025-01-16 06:04:27.887000
2025-01-16 06:12:08.572 | HD Request # 6 | Using server: ds26.sierracharts.com port 10150
2025-01-16 06:12:08.572 | Socket (2) | Creating socket.
2025-01-16 06:12:08.572 | Socket (2) | New receive buffer size: 0
2025-01-16 06:12:08.572 | Socket (2) | Connecting to IP: 64.152.155.17.
2025-01-16 06:12:08.595 | F.US.JY6H25 [CBV] 250 Volume #4 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:12:08.595 | F.US.JY6H25 [CBV] 250 Volume #4 | Reloading chart.
2025-01-16 06:12:08.695 | F.US.CPEH25 [CBV] 200 Volume #5 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:12:08.695 | F.US.CPEH25 [CBV] 200 Volume #5 | Reloading chart.
2025-01-16 06:12:08.848 | F.US.GCEG25 [CBV] 250 Volume #3 | Reloading chart.
2025-01-16 06:12:08.863 | HD Request # 6 | Setting DTC encoding to Binary VLS
2025-01-16 06:12:08.863 | HD Request # 6 | Sending historical data logon request message.
2025-01-16 06:12:08.992 | F.US.JY6H25 [CBV] 250 Volume #4 | Reloading chart.
2025-01-16 06:12:09.049 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:27. Record interval: 0. Symbol: ZFH25
2025-01-16 06:12:09.112 | F.US.CPEH25 [CBV] 200 Volume #5 | Reloading chart.
2025-01-16 06:12:09.190 | HD Request # 6 | Decompressing data.
2025-01-16 06:12:09.276 | DTC - Sub Instance | Starting real-time market data updates for: F.US.GCEG25. ID: 6 Service code: cqg
2025-01-16 06:12:09.276 | DTC - Sub Instance | Requesting security definition data for: F.US.GCEG25. ID: 6
2025-01-16 06:12:09.282 | DTC - Sub Instance | Setting external service identifier for symbol F.US.GCEG25 to 1551
2025-01-16 06:12:09.282 | DTC - Sub Instance | Received security definition for symbol F.US.GCEG25
2025-01-16 06:12:09.331 | HD Request # 6 | Receiving Intraday data for F.US.FVAH25 starting at 2025-01-16 06:04:27.887000
2025-01-16 06:12:09.331 | Socket (2) | CloseSocket call.
2025-01-16 06:12:09.331 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:12:09.331 | Historical data download thread signaled to stop.
2025-01-16 06:12:09.331 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:50.170000.
2025-01-16 06:12:09.331 | HD Request # 6 | Received 219 Intraday data records from 2025-01-16 06:04:27.887000 to 2025-01-16 06:12:03.929003 (7.6 minutes. Delay: 5.4 seconds) and wrote 218 records for F.US.FVAH25
2025-01-16 06:12:09.332 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:12:03.929003
2025-01-16 06:12:09.332 | HD Request # 6 | Completion time: 1s.
2025-01-16 06:12:09.332 | HD Request # 6 | Intraday data download complete for F.US.FVAH25. Unique request ID: 6
2025-01-16 06:12:09.332 | Removing historical data download ID 6.
2025-01-16 06:12:09.332 | Real-time Intraday chart data file updates started for F.US.FVAH25
2025-01-16 06:12:09.332 | Intraday chart data file opened for F.US.FVAH25
2025-01-16 06:12:09.332 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2025-01-16 06:12:09.332 | Triggering next historical data download in queue.
2025-01-16 06:12:09.332 | HD Request # 7 | Downloading Intraday chart data for F.US.TUAH25 to the file F.US.TUAH25.scid. Service: cbot
2025-01-16 06:12:09.332 | HD Request # 7 | Download start date-time: 2025-01-16 06:04:27.000000. File last date-time: 2025-01-16 06:04:27.888000
2025-01-16 06:12:09.332 | HD Request # 7 | Using server: ds28.sierracharts.com port 10149
2025-01-16 06:12:09.332 | Socket (3) | Creating socket.
2025-01-16 06:12:09.332 | Socket (3) | New receive buffer size: 0
2025-01-16 06:12:09.332 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-16 06:12:09.401 | DTC - Sub Instance | Starting real-time market data updates for: F.US.JY6H25. ID: 7 Service code: cqg
2025-01-16 06:12:09.401 | DTC - Sub Instance | Requesting security definition data for: F.US.JY6H25. ID: 7
2025-01-16 06:12:09.401 | DTC - Sub Instance | Setting external service identifier for symbol F.US.JY6H25 to 57969
2025-01-16 06:12:09.401 | DTC - Sub Instance | Received security definition for symbol F.US.JY6H25
2025-01-16 06:12:09.472 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:12:09.472 | Socket (2) | Closed.
2025-01-16 06:12:09.513 | DTC - Sub Instance | Starting real-time market data updates for: F.US.CPEH25. ID: 8 Service code: cqg
2025-01-16 06:12:09.513 | DTC - Sub Instance | Requesting security definition data for: F.US.CPEH25. ID: 8
2025-01-16 06:12:09.513 | DTC - Sub Instance | Setting external service identifier for symbol F.US.CPEH25 to 19222
2025-01-16 06:12:09.513 | DTC - Sub Instance | Received security definition for symbol F.US.CPEH25
2025-01-16 06:12:09.561 | F.US.FVAH25 [CBV] 1000 Volume #6 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:12:09.562 | F.US.FVAH25 [CBV] 1000 Volume #6 | Reloading chart.
2025-01-16 06:12:09.624 | HD Request # 7 | Setting DTC encoding to Binary VLS
2025-01-16 06:12:09.624 | HD Request # 7 | Sending historical data logon request message.
2025-01-16 06:12:09.807 | HD Request # 7 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:27. Record interval: 0. Symbol: ZTH25
2025-01-16 06:12:09.951 | HD Request # 7 | Decompressing data.
2025-01-16 06:12:10.094 | HD Request # 7 | Receiving Intraday data for F.US.TUAH25 starting at 2025-01-16 06:04:27.887000
2025-01-16 06:12:10.094 | Socket (3) | CloseSocket call.
2025-01-16 06:12:10.094 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:12:10.237 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:12:10.237 | Socket (3) | Closed.
2025-01-16 06:12:11.088 | F.US.CPEH25 [CBV] 200 Volume #5 | Chart data loading complete.
2025-01-16 06:12:11.092 | Historical data download thread signaled to stop.
2025-01-16 06:12:11.092 | HD Request # 7 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:50.170000.
2025-01-16 06:12:11.092 | HD Request # 7 | Received 470 Intraday data records from 2025-01-16 06:04:27.887000 to 2025-01-16 06:11:09.336004 (6.7 minutes. Delay: 61.8 seconds) and wrote 468 records for F.US.TUAH25
2025-01-16 06:12:11.092 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:11:09.336004
2025-01-16 06:12:11.092 | HD Request # 7 | Completion time: 2s.
2025-01-16 06:12:11.092 | HD Request # 7 | Intraday data download complete for F.US.TUAH25. Unique request ID: 7
2025-01-16 06:12:11.092 | Removing historical data download ID 7.
2025-01-16 06:12:11.092 | Real-time Intraday chart data file updates started for F.US.TUAH25
2025-01-16 06:12:11.092 | Intraday chart data file opened for F.US.TUAH25
2025-01-16 06:12:11.092 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2025-01-16 06:12:11.092 | Triggering next historical data download in queue.
2025-01-16 06:12:17.760 | F.US.JY6H25 [CBV] 250 Volume #4 | Chart data loading complete.
2025-01-16 06:12:17.761 | HD Request # 8 | Downloading Intraday chart data for F.US.USAH25 to the file F.US.USAH25.scid. Service: cbot
2025-01-16 06:12:17.762 | HD Request # 8 | Download start date-time: 2025-01-16 06:04:44.000000. File last date-time: 2025-01-16 06:04:44.103004
2025-01-16 06:12:17.762 | HD Request # 8 | Using server: ds32.sierracharts.com port 10150
2025-01-16 06:12:17.762 | Socket (2) | Creating socket.
2025-01-16 06:12:17.762 | Socket (2) | New receive buffer size: 0
2025-01-16 06:12:17.762 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-16 06:12:18.055 | HD Request # 8 | Setting DTC encoding to Binary VLS
2025-01-16 06:12:18.055 | HD Request # 8 | Sending historical data logon request message.
2025-01-16 06:12:18.243 | HD Request # 8 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:44. Record interval: 0. Symbol: ZBH25
2025-01-16 06:12:18.386 | HD Request # 8 | Decompressing data.
2025-01-16 06:12:18.529 | HD Request # 8 | Receiving Intraday data for F.US.USAH25 starting at 2025-01-16 06:04:44.059000
2025-01-16 06:12:18.530 | Socket (2) | CloseSocket call.
2025-01-16 06:12:18.530 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:12:18.631 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.GCEG25.scid. Thread ID: 24244
2025-01-16 06:12:18.631 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.JY6H25.scid. Thread ID: 24244
2025-01-16 06:12:18.673 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:12:18.673 | Socket (2) | Closed.
2025-01-16 06:12:24.931 | F.US.GCEG25 [CBV] 250 Volume #3 | Chart data loading complete.
2025-01-16 06:12:38.761 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.CPEH25.scid. Thread ID: 24244
2025-01-16 06:12:47.927 | F.US.FVAH25 [CBV] 1000 Volume #6 | Chart data loading complete.
2025-01-16 06:12:47.932 | Historical data download thread signaled to stop.
2025-01-16 06:12:47.932 | HD Request # 8 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:50.588000.
2025-01-16 06:12:47.932 | HD Request # 8 | Received 258 Intraday data records from 2025-01-16 06:04:44.059000 to 2025-01-16 06:12:06.071002 (7.4 minutes. Delay: 41.9 seconds) and wrote 248 records for F.US.USAH25
2025-01-16 06:12:47.932 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:12:06.071002
2025-01-16 06:12:47.932 | HD Request # 8 | Completion time: 30s.
2025-01-16 06:12:47.932 | HD Request # 8 | Intraday data download complete for F.US.USAH25. Unique request ID: 8
2025-01-16 06:12:47.932 | Removing historical data download ID 8.
2025-01-16 06:12:47.932 | Real-time Intraday chart data file updates started for F.US.USAH25
2025-01-16 06:12:47.932 | Intraday chart data file opened for F.US.USAH25
2025-01-16 06:12:47.932 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2025-01-16 06:12:47.932 | Triggering next historical data download in queue.
2025-01-16 06:12:47.949 | HD Request # 9 | Downloading Intraday chart data for F.US.TYAH25 to the file F.US.TYAH25.scid. Service: cbot
2025-01-16 06:12:47.949 | HD Request # 9 | Download start date-time: 2025-01-16 06:04:36.000000. File last date-time: 2025-01-16 06:04:36.281000
2025-01-16 06:12:47.949 | HD Request # 9 | Using server: ds26.sierracharts.com port 10149
2025-01-16 06:12:47.949 | Socket (3) | Creating socket.
2025-01-16 06:12:47.949 | Socket (3) | New receive buffer size: 0
2025-01-16 06:12:47.949 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-16 06:12:47.976 | F.US.USAH25 [CBV] 800 Volume #8 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:12:47.976 | F.US.USAH25 [CBV] 800 Volume #8 | Reloading chart.
2025-01-16 06:12:48.039 | F.US.FVAH25 [CBV] 1000 Volume #6 | Reloading chart.
2025-01-16 06:12:48.085 | F.US.TUAH25 [CBV] 1000 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:12:48.085 | F.US.TUAH25 [CBV] 1000 Volume #7 | Reloading chart.
2025-01-16 06:12:48.238 | HD Request # 9 | Setting DTC encoding to Binary VLS
2025-01-16 06:12:48.238 | HD Request # 9 | Sending historical data logon request message.
2025-01-16 06:12:48.395 | F.US.USAH25 [CBV] 800 Volume #8 | Reloading chart.
2025-01-16 06:12:48.422 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:36. Record interval: 0. Symbol: ZNH25
2025-01-16 06:12:48.448 | DTC - Sub Instance | Starting real-time market data updates for: F.US.FVAH25. ID: 9 Service code: cqg
2025-01-16 06:12:48.448 | DTC - Sub Instance | Requesting security definition data for: F.US.FVAH25. ID: 9
2025-01-16 06:12:48.462 | DTC - Sub Instance | Setting external service identifier for symbol F.US.FVAH25 to 42072515
2025-01-16 06:12:48.462 | DTC - Sub Instance | Received security definition for symbol F.US.FVAH25
2025-01-16 06:12:48.491 | F.US.TUAH25 [CBV] 1000 Volume #7 | Reloading chart.
2025-01-16 06:12:48.562 | HD Request # 9 | Decompressing data.
2025-01-16 06:12:48.704 | HD Request # 9 | Receiving Intraday data for F.US.TYAH25 starting at 2025-01-16 06:04:36.000000
2025-01-16 06:12:48.704 | Socket (3) | CloseSocket call.
2025-01-16 06:12:48.704 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:12:48.705 | Historical data download thread signaled to stop.
2025-01-16 06:12:48.705 | HD Request # 9 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:56.525000.
2025-01-16 06:12:48.705 | HD Request # 9 | Received 527 Intraday data records from 2025-01-16 06:04:36.000000 to 2025-01-16 06:11:02.125000 (6.4 minutes. Delay: 106.6 seconds) and wrote 516 records for F.US.TYAH25
2025-01-16 06:12:48.705 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:11:02.125000
2025-01-16 06:12:48.705 | HD Request # 9 | Completion time: 1s.
2025-01-16 06:12:48.705 | HD Request # 9 | Intraday data download complete for F.US.TYAH25. Unique request ID: 9
2025-01-16 06:12:48.705 | Removing historical data download ID 9.
2025-01-16 06:12:48.705 | Real-time Intraday chart data file updates started for F.US.TYAH25
2025-01-16 06:12:48.705 | Intraday chart data file opened for F.US.TYAH25
2025-01-16 06:12:48.705 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2025-01-16 06:12:48.705 | Triggering next historical data download in queue.
2025-01-16 06:12:48.705 | HD Request # 10 | Downloading Intraday chart data for F.US.BP6H25 to the file F.US.BP6H25.scid. Service: cme
2025-01-16 06:12:48.705 | HD Request # 10 | Download start date-time: 2025-01-16 06:03:56.000000. File last date-time: 2025-01-16 06:03:56.520000
2025-01-16 06:12:48.706 | HD Request # 10 | Using server: ds28.sierracharts.com port 10150
2025-01-16 06:12:48.706 | Socket (4) | Creating socket.
2025-01-16 06:12:48.706 | Socket (4) | New receive buffer size: 0
2025-01-16 06:12:48.706 | Socket (4) | Connecting to IP: 67.214.125.5.
2025-01-16 06:12:48.794 | DTC - Sub Instance | Starting real-time market data updates for: F.US.USAH25. ID: 11 Service code: cqg
2025-01-16 06:12:48.794 | DTC - Sub Instance | Requesting security definition data for: F.US.USAH25. ID: 11
2025-01-16 06:12:48.794 | F.US.TYAH25 [CBV] 1000 Volume #9 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:12:48.794 | F.US.TYAH25 [CBV] 1000 Volume #9 | Reloading chart.
2025-01-16 06:12:48.810 | DTC - Sub Instance | Setting external service identifier for symbol F.US.USAH25 to 42004096
2025-01-16 06:12:48.810 | DTC - Sub Instance | Received security definition for symbol F.US.USAH25
2025-01-16 06:12:48.845 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:12:48.845 | Socket (3) | Closed.
2025-01-16 06:12:48.906 | DTC - Sub Instance | Starting real-time market data updates for: F.US.TUAH25. ID: 10 Service code: cqg
2025-01-16 06:12:48.906 | DTC - Sub Instance | Requesting security definition data for: F.US.TUAH25. ID: 10
2025-01-16 06:12:48.906 | DTC - Sub Instance | Setting external service identifier for symbol F.US.TUAH25 to 42111442
2025-01-16 06:12:48.906 | DTC - Sub Instance | Received security definition for symbol F.US.TUAH25
2025-01-16 06:12:48.996 | HD Request # 10 | Setting DTC encoding to Binary VLS
2025-01-16 06:12:48.996 | HD Request # 10 | Sending historical data logon request message.
2025-01-16 06:12:49.182 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-01-16 06:03:56. Record interval: 0. Symbol: 6BH25
2025-01-16 06:12:49.207 | F.US.TYAH25 [CBV] 1000 Volume #9 | Reloading chart.
2025-01-16 06:12:49.324 | HD Request # 10 | Decompressing data.
2025-01-16 06:12:49.467 | HD Request # 10 | Receiving Intraday data for F.US.BP6H25 starting at 2025-01-16 06:03:56.520000
2025-01-16 06:12:49.467 | Socket (4) | CloseSocket call.
2025-01-16 06:12:49.467 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-16 06:12:49.468 | Historical data download thread signaled to stop.
2025-01-16 06:12:49.468 | HD Request # 10 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:56.742000.
2025-01-16 06:12:49.468 | HD Request # 10 | Received 45 Intraday data records from 2025-01-16 06:03:56.520000 to 2025-01-16 06:11:39.015001 (7.7 minutes. Delay: 70.5 seconds) and wrote 44 records for F.US.BP6H25
2025-01-16 06:12:49.468 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:11:39.015001
2025-01-16 06:12:49.468 | HD Request # 10 | Completion time: 1s.
2025-01-16 06:12:49.468 | HD Request # 10 | Intraday data download complete for F.US.BP6H25. Unique request ID: 10
2025-01-16 06:12:49.468 | Removing historical data download ID 10.
2025-01-16 06:12:49.468 | Real-time Intraday chart data file updates started for F.US.BP6H25
2025-01-16 06:12:49.468 | Intraday chart data file opened for F.US.BP6H25
2025-01-16 06:12:49.468 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2025-01-16 06:12:49.468 | Triggering next historical data download in queue.
2025-01-16 06:12:49.468 | HD Request # 11 | Downloading Intraday chart data for F.US.DA6H25 to the file F.US.DA6H25.scid. Service: cme
2025-01-16 06:12:49.468 | HD Request # 11 | Download start date-time: 2025-01-16 06:04:43.000000. File last date-time: 2025-01-16 06:04:43.237000
2025-01-16 06:12:49.468 | HD Request # 11 | Using server: ds32.sierracharts.com port 10149
2025-01-16 06:12:49.468 | Socket (2) | Creating socket.
2025-01-16 06:12:49.469 | Socket (2) | New receive buffer size: 0
2025-01-16 06:12:49.469 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-16 06:12:49.604 | DTC - Sub Instance | Starting real-time market data updates for: F.US.TYAH25. ID: 12 Service code: cqg
2025-01-16 06:12:49.604 | DTC - Sub Instance | Requesting security definition data for: F.US.TYAH25. ID: 12
2025-01-16 06:12:49.604 | DTC - Sub Instance | Setting external service identifier for symbol F.US.TYAH25 to 42002219
2025-01-16 06:12:49.604 | DTC - Sub Instance | Received security definition for symbol F.US.TYAH25
2025-01-16 06:12:49.604 | F.US.BP6H25 [CBV] 100 Volume #10 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:12:49.605 | F.US.BP6H25 [CBV] 100 Volume #10 | Reloading chart.
2025-01-16 06:12:49.610 | Socket (4) | Socket gracefully closed by remote side.
2025-01-16 06:12:49.610 | Socket (4) | Closed.
2025-01-16 06:12:49.760 | HD Request # 11 | Setting DTC encoding to Binary VLS
2025-01-16 06:12:49.760 | HD Request # 11 | Sending historical data logon request message.
2025-01-16 06:12:49.967 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:43. Record interval: 0. Symbol: 6AH25
2025-01-16 06:12:50.017 | F.US.BP6H25 [CBV] 100 Volume #10 | Reloading chart.
2025-01-16 06:12:50.110 | HD Request # 11 | Decompressing data.
2025-01-16 06:12:50.253 | HD Request # 11 | Receiving Intraday data for F.US.DA6H25 starting at 2025-01-16 06:04:43.237000
2025-01-16 06:12:50.253 | Socket (2) | CloseSocket call.
2025-01-16 06:12:50.253 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:12:50.254 | Historical data download thread signaled to stop.
2025-01-16 06:12:50.254 | HD Request # 11 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:56.233000.
2025-01-16 06:12:50.254 | HD Request # 11 | Received 94 Intraday data records from 2025-01-16 06:04:43.237000 to 2025-01-16 06:12:45.279000 (8.0 minutes. Delay: 5.0 seconds) and wrote 93 records for F.US.DA6H25
2025-01-16 06:12:50.254 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:12:45.279000
2025-01-16 06:12:50.254 | HD Request # 11 | Completion time: 1s.
2025-01-16 06:12:50.254 | HD Request # 11 | Intraday data download complete for F.US.DA6H25. Unique request ID: 11
2025-01-16 06:12:50.254 | Removing historical data download ID 11.
2025-01-16 06:12:50.254 | Real-time Intraday chart data file updates started for F.US.DA6H25
2025-01-16 06:12:50.254 | Intraday chart data file opened for F.US.DA6H25
2025-01-16 06:12:50.254 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2025-01-16 06:12:50.254 | Triggering next historical data download in queue.
2025-01-16 06:12:50.254 | HD Request # 12 | Downloading Intraday chart data for F.US.CLEG25 to the file F.US.CLEG25.scid. Service: nymex
2025-01-16 06:12:50.255 | HD Request # 12 | Download start date-time: 2025-01-16 05:58:56.000000. File last date-time: 2025-01-16 05:58:56.326000
2025-01-16 06:12:50.255 | HD Request # 12 | Using server: ds26.sierracharts.com port 10150
2025-01-16 06:12:50.255 | Socket (3) | Creating socket.
2025-01-16 06:12:50.255 | Socket (3) | New receive buffer size: 0
2025-01-16 06:12:50.255 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-16 06:12:50.396 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:12:50.396 | Socket (2) | Closed.
2025-01-16 06:12:50.545 | HD Request # 12 | Setting DTC encoding to Binary VLS
2025-01-16 06:12:50.545 | HD Request # 12 | Sending historical data logon request message.
2025-01-16 06:12:50.730 | HD Request # 12 | Requesting Intraday data. Start date-time: 2025-01-16 05:58:56. Record interval: 0. Symbol: CLG25
2025-01-16 06:12:50.870 | HD Request # 12 | Decompressing data.
2025-01-16 06:12:51.010 | HD Request # 12 | Receiving Intraday data for F.US.CLEG25 starting at 2025-01-16 05:58:56.326000
2025-01-16 06:12:51.010 | Socket (3) | CloseSocket call.
2025-01-16 06:12:51.010 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:12:51.151 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:12:51.151 | Socket (3) | Closed.
2025-01-16 06:12:56.582 | F.US.USAH25 [CBV] 800 Volume #8 | Chart data loading complete.
2025-01-16 06:13:11.183 | F.US.BP6H25 [CBV] 100 Volume #10 | Chart data loading complete.
2025-01-16 06:13:14.035 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.TUAH25.scid. Thread ID: 24244
2025-01-16 06:13:19.491 | F.US.TUAH25 [CBV] 1000 Volume #7 | Chart data loading complete.
2025-01-16 06:13:19.491 | Historical data download thread signaled to stop.
2025-01-16 06:13:19.492 | HD Request # 12 | Timestamp of first Intraday data file record written: 2025-01-16 05:59:18.826000.
2025-01-16 06:13:19.492 | HD Request # 12 | Received 74 Intraday data records from 2025-01-16 05:58:56.326000 to 2025-01-16 06:12:19.570000 (13.4 minutes. Delay: 59.9 seconds) and wrote 73 records for F.US.CLEG25
2025-01-16 06:13:19.492 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:12:19.570000
2025-01-16 06:13:19.492 | HD Request # 12 | Completion time: 29s.
2025-01-16 06:13:19.492 | HD Request # 12 | Intraday data download complete for F.US.CLEG25. Unique request ID: 12
2025-01-16 06:13:19.492 | Removing historical data download ID 12.
2025-01-16 06:13:19.492 | Real-time Intraday chart data file updates started for F.US.CLEG25
2025-01-16 06:13:19.492 | Intraday chart data file opened for F.US.CLEG25
2025-01-16 06:13:19.492 | HD Request # 12 | Enabling Intraday chart updating for symbol.
2025-01-16 06:13:19.492 | Triggering next historical data download in queue.
2025-01-16 06:13:34.169 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.USAH25.scid. Thread ID: 24244
2025-01-16 06:13:41.507 | F.US.FVAH25 [CBV] 1000 Volume #6 | Chart data loading complete.
2025-01-16 06:14:04.435 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.FVAH25.scid. Thread ID: 24244
2025-01-16 06:14:04.435 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.TYAH25.scid. Thread ID: 24244
2025-01-16 06:14:36.407 | F.US.TYAH25 [CBV] 1000 Volume #9 | Chart data loading complete.
2025-01-16 06:14:36.424 | HD Request # 13 | Downloading Intraday chart data for F.US.CLEH25 to the file F.US.CLEH25.scid. Service: nymex
2025-01-16 06:14:36.424 | HD Request # 13 | Download start date-time: 2025-01-16 06:04:45.000000. File last date-time: 2025-01-16 06:04:45.591000
2025-01-16 06:14:36.424 | HD Request # 13 | Using server: ds28.sierracharts.com port 10149
2025-01-16 06:14:36.425 | Socket (2) | Creating socket.
2025-01-16 06:14:36.425 | Socket (2) | New receive buffer size: 0
2025-01-16 06:14:36.425 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-16 06:14:36.496 | DTC - Sub Instance | Starting real-time market data updates for: F.US.BP6H25. ID: 13 Service code: cqg
2025-01-16 06:14:36.496 | DTC - Sub Instance | Requesting security definition data for: F.US.BP6H25. ID: 13
2025-01-16 06:14:36.515 | DTC - Sub Instance | Setting external service identifier for symbol F.US.BP6H25 to 29307
2025-01-16 06:14:36.515 | DTC - Sub Instance | Received security definition for symbol F.US.BP6H25
2025-01-16 06:14:36.571 | F.US.DA6H25 [CBV] 100 Volume #11 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:14:36.571 | F.US.DA6H25 [CBV] 100 Volume #11 | Reloading chart.
2025-01-16 06:14:36.716 | HD Request # 13 | Setting DTC encoding to Binary VLS
2025-01-16 06:14:36.716 | HD Request # 13 | Sending historical data logon request message.
2025-01-16 06:14:36.904 | HD Request # 13 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:45. Record interval: 0. Symbol: CLH25
2025-01-16 06:14:36.987 | F.US.DA6H25 [CBV] 100 Volume #11 | Reloading chart.
2025-01-16 06:14:37.047 | HD Request # 13 | Decompressing data.
2025-01-16 06:14:37.190 | HD Request # 13 | Receiving Intraday data for F.US.CLEH25 starting at 2025-01-16 06:04:45.066000
2025-01-16 06:14:37.190 | Socket (2) | CloseSocket call.
2025-01-16 06:14:37.190 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:14:37.191 | Historical data download thread signaled to stop.
2025-01-16 06:14:37.191 | HD Request # 13 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:51.002000.
2025-01-16 06:14:37.191 | HD Request # 13 | Received 213 Intraday data records from 2025-01-16 06:04:45.066000 to 2025-01-16 06:14:25.193000 (9.7 minutes. Delay: 12.0 seconds) and wrote 208 records for F.US.CLEH25
2025-01-16 06:14:37.191 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:14:25.193000
2025-01-16 06:14:37.191 | HD Request # 13 | Completion time: 1s.
2025-01-16 06:14:37.191 | HD Request # 13 | Intraday data download complete for F.US.CLEH25. Unique request ID: 13
2025-01-16 06:14:37.191 | Removing historical data download ID 13.
2025-01-16 06:14:37.191 | Real-time Intraday chart data file updates started for F.US.CLEH25
2025-01-16 06:14:37.191 | Intraday chart data file opened for F.US.CLEH25
2025-01-16 06:14:37.191 | HD Request # 13 | Enabling Intraday chart updating for symbol.
2025-01-16 06:14:37.191 | Triggering next historical data download in queue.
2025-01-16 06:14:37.191 | HD Request # 14 | Downloading Intraday chart data for F.US.NGEG25 to the file F.US.NGEG25.scid. Service: nymex
2025-01-16 06:14:37.191 | HD Request # 14 | Download start date-time: 2025-01-16 06:04:37.000000. File last date-time: 2025-01-16 06:04:37.431001
2025-01-16 06:14:37.191 | HD Request # 14 | Using server: ds32.sierracharts.com port 10150
2025-01-16 06:14:37.191 | Socket (3) | Creating socket.
2025-01-16 06:14:37.191 | Socket (3) | New receive buffer size: 0
2025-01-16 06:14:37.191 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-16 06:14:37.333 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:14:37.333 | Socket (2) | Closed.
2025-01-16 06:14:37.395 | DTC - Sub Instance | Starting real-time market data updates for: F.US.DA6H25. ID: 14 Service code: cqg
2025-01-16 06:14:37.395 | DTC - Sub Instance | Requesting security definition data for: F.US.DA6H25. ID: 14
2025-01-16 06:14:37.397 | DTC - Sub Instance | Setting external service identifier for symbol F.US.DA6H25 to 52126
2025-01-16 06:14:37.397 | DTC - Sub Instance | Received security definition for symbol F.US.DA6H25
2025-01-16 06:14:37.492 | HD Request # 14 | Setting DTC encoding to Binary VLS
2025-01-16 06:14:37.492 | HD Request # 14 | Sending historical data logon request message.
2025-01-16 06:14:37.686 | HD Request # 14 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:37. Record interval: 0. Symbol: NGG25
2025-01-16 06:14:37.834 | HD Request # 14 | Decompressing data.
2025-01-16 06:14:37.983 | HD Request # 14 | Receiving Intraday data for F.US.NGEG25 starting at 2025-01-16 06:04:37.431000
2025-01-16 06:14:37.984 | Socket (3) | CloseSocket call.
2025-01-16 06:14:37.984 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:14:38.131 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:14:38.131 | Socket (3) | Closed.
2025-01-16 06:14:39.720 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.BP6H25.scid. Thread ID: 24244
2025-01-16 06:14:44.767 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.DA6H25.scid. Thread ID: 24244
2025-01-16 06:14:50.614 | F.US.DA6H25 [CBV] 100 Volume #11 | Chart data loading complete.
2025-01-16 06:14:50.615 | Historical data download thread signaled to stop.
2025-01-16 06:14:50.615 | HD Request # 14 | Timestamp of first Intraday data file record written: 2025-01-16 06:05:07.986000.
2025-01-16 06:14:50.615 | HD Request # 14 | Received 487 Intraday data records from 2025-01-16 06:04:37.431000 to 2025-01-16 06:14:33.516000 (9.9 minutes. Delay: 17.1 seconds) and wrote 485 records for F.US.NGEG25
2025-01-16 06:14:50.615 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:14:33.516000
2025-01-16 06:14:50.615 | HD Request # 14 | Completion time: 13s.
2025-01-16 06:14:50.615 | HD Request # 14 | Intraday data download complete for F.US.NGEG25. Unique request ID: 14
2025-01-16 06:14:50.615 | Removing historical data download ID 14.
2025-01-16 06:14:50.615 | Real-time Intraday chart data file updates started for F.US.NGEG25
2025-01-16 06:14:50.615 | Intraday chart data file opened for F.US.NGEG25
2025-01-16 06:14:50.615 | HD Request # 14 | Enabling Intraday chart updating for symbol.
2025-01-16 06:14:50.615 | Triggering next historical data download in queue.
2025-01-16 06:14:50.626 | HD Request # 15 | Downloading Intraday chart data for F.US.DBU24 to the file F.US.DBU24.scid. Service: eurex
2025-01-16 06:14:50.626 | HD Request # 15 | Download start date-time: 2024-09-06 11:29:59.000000. File last date-time: 2024-09-06 11:29:59.003000
2025-01-16 06:14:50.626 | HD Request # 15 | Using server: ds14.sierracharts.com port 10149
2025-01-16 06:14:50.626 | Socket (2) | Creating socket.
2025-01-16 06:14:50.626 | Socket (2) | New receive buffer size: 0
2025-01-16 06:14:50.626 | Socket (2) | Connecting to IP: 176.9.9.252.
2025-01-16 06:14:50.643 | F.US.CLEH25 [CBV] 500 Volume #12 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:14:50.643 | F.US.CLEH25 [CBV] 500 Volume #12 | Reloading chart.
2025-01-16 06:14:50.764 | HD Request # 15 | Setting DTC encoding to Binary VLS
2025-01-16 06:14:50.764 | HD Request # 15 | Sending historical data logon request message.
2025-01-16 06:14:51.047 | F.US.NGEG25 [CBV] 100 Volume #13 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:14:51.047 | F.US.NGEG25 [CBV] 100 Volume #13 | Reloading chart.
2025-01-16 06:14:51.335 | HD Request # 15 | Requesting Intraday data. Start date-time: 2024-09-06 11:29:59. Record interval: 0. Symbol: FGBL202409_FUT_EUREX
2025-01-16 06:14:51.402 | HD Request # 15 | Decompressing data.
2025-01-16 06:14:51.469 | HD Request # 15 | Receiving Intraday data for F.US.DBU24 starting at 2024-09-06 11:29:59.003000
2025-01-16 06:14:51.469 | Socket (2) | CloseSocket call.
2025-01-16 06:14:51.469 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:14:51.537 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:14:51.537 | Socket (2) | Closed.
2025-01-16 06:14:51.922 | Historical data download thread signaled to stop.
2025-01-16 06:14:51.922 | HD Request # 15 | Received 1 Intraday data record from 2024-09-06 11:29:59.003000 to 2024-09-06 11:29:59.003000 (0.0 seconds. Delay: 131.8 days) and wrote 0 records for F.US.DBU24
2025-01-16 06:14:51.923 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2024-09-06 10:29:59.003000
2025-01-16 06:14:51.923 | HD Request # 15 | Completion time: 1s.
2025-01-16 06:14:51.923 | HD Request # 15 | Intraday data download complete for F.US.DBU24. Unique request ID: 15
2025-01-16 06:14:51.923 | Removing historical data download ID 15.
2025-01-16 06:14:51.923 | Real-time Intraday chart data file updates started for F.US.DBU24
2025-01-16 06:14:51.923 | Intraday chart data file opened for F.US.DBU24
2025-01-16 06:14:51.923 | HD Request # 15 | Enabling Intraday chart updating for symbol.
2025-01-16 06:14:51.923 | Triggering next historical data download in queue.
2025-01-16 06:14:51.924 | HD Request # 16 | Downloading Intraday chart data for F.US.DBZ24 to the file F.US.DBZ24.scid. Service: eurex
2025-01-16 06:14:51.925 | HD Request # 16 | Download start date-time: 2024-12-06 11:29:59.000000. File last date-time: 2024-12-06 11:29:59.962001
2025-01-16 06:14:51.925 | HD Request # 16 | Using server: ds50.sierracharts.com port 10150
2025-01-16 06:14:51.925 | Socket (2) | Creating socket.
2025-01-16 06:14:51.925 | Socket (2) | New receive buffer size: 0
2025-01-16 06:14:51.925 | Socket (2) | Connecting to IP: 62.209.53.225.
2025-01-16 06:14:52.042 | HD Request # 16 | Setting DTC encoding to Binary VLS
2025-01-16 06:14:52.042 | HD Request # 16 | Sending historical data logon request message.
2025-01-16 06:14:52.093 | F.US.CLEH25 [CBV] 500 Volume #12 | Reloading chart.
2025-01-16 06:14:52.099 | Socket (2) | CloseSocket call.
2025-01-16 06:14:52.099 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:14:52.156 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:14:52.156 | Socket (2) | Closed.
2025-01-16 06:14:52.613 | HD Request # 16 | Error downloading historical Intraday data for F.US.DBZ24. Historical data logon error: Serving data is disabled
2025-01-16 06:14:52.613 | Added historical Intraday data request for F.US.DBZ24 to the queue.
2025-01-16 06:14:52.613 | Triggering next historical data download in queue.
2025-01-16 06:14:52.613 | Historical data download thread signaled to stop.
2025-01-16 06:14:52.614 | HD Request # 16 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DBZ24
2025-01-16 06:14:52.614 | HD Request # 16 | Completion time: 1s.
2025-01-16 06:14:52.618 | HD Request # 17 | Downloading Intraday chart data for F.US.DBZ24 to the file F.US.DBZ24.scid. Service: eurex
2025-01-16 06:14:52.618 | HD Request # 17 | Download start date-time: 2024-12-06 11:29:59.000000. File last date-time: 2024-12-06 11:29:59.962001
2025-01-16 06:14:52.618 | HD Request # 17 | Using server: ds24.sierracharts.com port 10149
2025-01-16 06:14:52.619 | Socket (2) | Creating socket.
2025-01-16 06:14:52.619 | Socket (2) | New receive buffer size: 0
2025-01-16 06:14:52.619 | Socket (2) | Connecting to IP: 62.209.53.226.
2025-01-16 06:14:52.626 | F.US.NGEG25 [CBV] 100 Volume #13 | Reloading chart.
2025-01-16 06:14:52.735 | HD Request # 17 | Setting DTC encoding to Binary VLS
2025-01-16 06:14:52.735 | HD Request # 17 | Sending historical data logon request message.
2025-01-16 06:14:53.225 | HD Request # 17 | Requesting Intraday data. Start date-time: 2024-12-06 11:29:59. Record interval: 0. Symbol: FGBL202412_FUT_EUREX
2025-01-16 06:14:53.282 | HD Request # 17 | Decompressing data.
2025-01-16 06:14:53.338 | HD Request # 17 | Receiving Intraday data for F.US.DBZ24 starting at 2024-12-06 11:29:59.008000
2025-01-16 06:14:53.339 | Socket (2) | CloseSocket call.
2025-01-16 06:14:53.339 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:14:53.395 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:14:53.395 | Socket (2) | Closed.
2025-01-16 06:14:53.518 | Historical data download thread signaled to stop.
2025-01-16 06:14:53.518 | HD Request # 17 | Received 8 Intraday data records from 2024-12-06 11:29:59.008000 to 2024-12-06 11:29:59.962001 (1.0 seconds. Delay: 40.8 days) and wrote 0 records for F.US.DBZ24
2025-01-16 06:14:53.518 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2024-12-06 11:29:59.962001
2025-01-16 06:14:53.519 | HD Request # 17 | Completion time: 1s.
2025-01-16 06:14:53.519 | HD Request # 17 | Intraday data download complete for F.US.DBZ24. Unique request ID: 16
2025-01-16 06:14:53.519 | Removing historical data download ID 16.
2025-01-16 06:14:53.519 | Real-time Intraday chart data file updates started for F.US.DBZ24
2025-01-16 06:14:53.519 | Intraday chart data file opened for F.US.DBZ24
2025-01-16 06:14:53.519 | HD Request # 17 | Enabling Intraday chart updating for symbol.
2025-01-16 06:14:53.519 | Triggering next historical data download in queue.
2025-01-16 06:14:53.520 | HD Request # 18 | Downloading Intraday chart data for F.US.DBH25 to the file F.US.DBH25.scid. Service: eurex
2025-01-16 06:14:53.520 | HD Request # 18 | Download start date-time: 2025-01-16 06:01:20.000000. File last date-time: 2025-01-16 06:01:20.265000
2025-01-16 06:14:53.520 | HD Request # 18 | Using server: ds14.sierracharts.com port 10150
2025-01-16 06:14:53.520 | Socket (2) | Creating socket.
2025-01-16 06:14:53.520 | Socket (2) | New receive buffer size: 0
2025-01-16 06:14:53.520 | Socket (2) | Connecting to IP: 176.9.9.252.
2025-01-16 06:14:53.618 | DTC - Sub Instance | Starting real-time market data updates for: F.US.CLEH25. ID: 16 Service code: cqg
2025-01-16 06:14:53.618 | DTC - Sub Instance | Requesting security definition data for: F.US.CLEH25. ID: 16
2025-01-16 06:14:53.618 | DTC - Sub Instance | Starting real-time market data updates for: F.US.NGEG25. ID: 17 Service code: cqg
2025-01-16 06:14:53.618 | DTC - Sub Instance | Requesting security definition data for: F.US.NGEG25. ID: 17
2025-01-16 06:14:53.623 | DTC - Sub Instance | Setting external service identifier for symbol F.US.CLEH25 to 37014
2025-01-16 06:14:53.623 | DTC - Sub Instance | Received security definition for symbol F.US.CLEH25
2025-01-16 06:14:53.623 | DTC - Sub Instance | Setting external service identifier for symbol F.US.NGEG25 to 899
2025-01-16 06:14:53.623 | DTC - Sub Instance | Received security definition for symbol F.US.NGEG25
2025-01-16 06:14:53.659 | HD Request # 18 | Setting DTC encoding to Binary VLS
2025-01-16 06:14:53.659 | HD Request # 18 | Sending historical data logon request message.
2025-01-16 06:14:53.727 | HD Request # 18 | Requesting Intraday data. Start date-time: 2025-01-16 06:01:20. Record interval: 0. Symbol: FGBL202503_FUT_EUREX
2025-01-16 06:14:53.795 | HD Request # 18 | Decompressing data.
2025-01-16 06:14:53.863 | HD Request # 18 | Receiving Intraday data for F.US.DBH25 starting at 2025-01-16 06:01:20.264000
2025-01-16 06:14:53.863 | Socket (2) | CloseSocket call.
2025-01-16 06:14:53.863 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:14:53.931 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:14:53.931 | Socket (2) | Closed.
2025-01-16 06:14:59.908 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.CLEH25.scid. Thread ID: 24244
2025-01-16 06:14:59.908 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.NGEG25.scid. Thread ID: 24244
2025-01-16 06:15:16.632 | F.US.NGEG25 [CBV] 100 Volume #13 | Chart data loading complete.
2025-01-16 06:15:16.633 | Historical data download thread signaled to stop.
2025-01-16 06:15:16.633 | HD Request # 18 | Timestamp of first Intraday data file record written: 2025-01-16 06:01:39.537000.
2025-01-16 06:15:16.633 | HD Request # 18 | Received 200 Intraday data records from 2025-01-16 06:01:20.264000 to 2025-01-16 06:14:22.157005 (13.0 minutes. Delay: 54.5 seconds) and wrote 196 records for F.US.DBH25
2025-01-16 06:15:16.634 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:14:22.157005
2025-01-16 06:15:16.634 | HD Request # 18 | Completion time: 23s.
2025-01-16 06:15:16.634 | HD Request # 18 | Intraday data download complete for F.US.DBH25. Unique request ID: 17
2025-01-16 06:15:16.634 | Removing historical data download ID 17.
2025-01-16 06:15:16.634 | Real-time Intraday chart data file updates started for F.US.DBH25
2025-01-16 06:15:16.634 | Intraday chart data file opened for F.US.DBH25
2025-01-16 06:15:16.634 | HD Request # 18 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:16.634 | Triggering next historical data download in queue.
2025-01-16 06:15:19.604 | F.US.CLEH25 [CBV] 500 Volume #12 | Chart data loading complete.
2025-01-16 06:15:19.625 | HD Request # 19 | Downloading Intraday chart data for F.US.ENQH25 to the file F.US.ENQH25.scid. Service: cme
2025-01-16 06:15:19.625 | HD Request # 19 | Download start date-time: 2025-01-16 06:04:37.000000. File last date-time: 2025-01-16 06:04:37.650000
2025-01-16 06:15:19.625 | HD Request # 19 | Using server: ds28.sierracharts.com port 10149
2025-01-16 06:15:19.625 | Socket (2) | Creating socket.
2025-01-16 06:15:19.625 | Socket (2) | New receive buffer size: 0
2025-01-16 06:15:19.625 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-16 06:15:19.695 | F.US.DBH25 [CBV] 1000 Volume #14 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:15:19.695 | F.US.DBH25 [CBV] 1000 Volume #14 | Reloading chart.
2025-01-16 06:15:19.927 | HD Request # 19 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:19.927 | HD Request # 19 | Sending historical data logon request message.
2025-01-16 06:15:20.099 | F.US.DBH25 [CBV] 1000 Volume #14 | Reloading chart.
2025-01-16 06:15:20.120 | HD Request # 19 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:37. Record interval: 0. Symbol: NQH25
2025-01-16 06:15:20.268 | HD Request # 19 | Decompressing data.
2025-01-16 06:15:20.422 | HD Request # 19 | Receiving Intraday data for F.US.ENQH25 starting at 2025-01-16 06:04:37.650000
2025-01-16 06:15:20.510 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBH25. ID: 20
2025-01-16 06:15:20.510 | Symbol Error | F.US.DBH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DBH25. ID: 20
2025-01-16 06:15:20.569 | Socket (2) | CloseSocket call.
2025-01-16 06:15:20.569 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:20.569 | Historical data download thread signaled to stop.
2025-01-16 06:15:20.569 | HD Request # 19 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:49.372000.
2025-01-16 06:15:20.569 | HD Request # 19 | Received 2261 Intraday data records from 2025-01-16 06:04:37.650000 to 2025-01-16 06:15:17.751001 (10.7 minutes. Delay: 2.8 seconds) and wrote 2260 records for F.US.ENQH25
2025-01-16 06:15:20.570 | HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:15:17.751001
2025-01-16 06:15:20.570 | HD Request # 19 | Completion time: 1s.
2025-01-16 06:15:20.570 | HD Request # 19 | Intraday data download complete for F.US.ENQH25. Unique request ID: 18
2025-01-16 06:15:20.570 | Removing historical data download ID 18.
2025-01-16 06:15:20.570 | Real-time Intraday chart data file updates started for F.US.ENQH25
2025-01-16 06:15:20.570 | Intraday chart data file opened for F.US.ENQH25
2025-01-16 06:15:20.570 | HD Request # 19 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:20.570 | Triggering next historical data download in queue.
2025-01-16 06:15:20.570 | HD Request # 20 | Downloading Intraday chart data for F.US.DSXU24 to the file F.US.DSXU24.scid. Service: eurex
2025-01-16 06:15:20.570 | HD Request # 20 | Download start date-time: 2024-09-20 10:59:33.000000. File last date-time: 2024-09-20 10:59:33.750000
2025-01-16 06:15:20.570 | HD Request # 20 | Using server: ds24.sierracharts.com port 10150
2025-01-16 06:15:20.570 | Socket (4) | Creating socket.
2025-01-16 06:15:20.570 | Socket (4) | New receive buffer size: 0
2025-01-16 06:15:20.570 | Socket (4) | Connecting to IP: 62.209.53.226.
2025-01-16 06:15:20.685 | HD Request # 20 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:20.685 | HD Request # 20 | Sending historical data logon request message.
2025-01-16 06:15:20.701 | F.US.ENQH25 [CBV] 1500 Volume #15 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:15:20.701 | F.US.ENQH25 [CBV] 1500 Volume #15 | Reloading chart.
2025-01-16 06:15:20.716 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:15:20.716 | Socket (2) | Closed.
2025-01-16 06:15:21.114 | F.US.ENQH25 [CBV] 1500 Volume #15 | Reloading chart.
2025-01-16 06:15:21.175 | HD Request # 20 | Requesting Intraday data. Start date-time: 2024-09-20 10:59:33. Record interval: 0. Symbol: FESX202409_FUT_EUREX
2025-01-16 06:15:21.232 | HD Request # 20 | Decompressing data.
2025-01-16 06:15:21.288 | HD Request # 20 | Receiving Intraday data for F.US.DSXU24 starting at 2024-09-20 10:59:33.750000
2025-01-16 06:15:21.288 | Socket (4) | CloseSocket call.
2025-01-16 06:15:21.288 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:21.288 | Historical data download thread signaled to stop.
2025-01-16 06:15:21.288 | HD Request # 20 | Received 1 Intraday data record from 2024-09-20 10:59:33.750000 to 2024-09-20 10:59:33.750000 (0.0 seconds. Delay: 117.8 days) and wrote 0 records for F.US.DSXU24
2025-01-16 06:15:21.288 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2024-09-20 09:59:33.750000
2025-01-16 06:15:21.288 | HD Request # 20 | Completion time: 1s.
2025-01-16 06:15:21.288 | HD Request # 20 | Intraday data download complete for F.US.DSXU24. Unique request ID: 19
2025-01-16 06:15:21.288 | Removing historical data download ID 19.
2025-01-16 06:15:21.288 | Real-time Intraday chart data file updates started for F.US.DSXU24
2025-01-16 06:15:21.288 | Intraday chart data file opened for F.US.DSXU24
2025-01-16 06:15:21.288 | HD Request # 20 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:21.288 | Triggering next historical data download in queue.
2025-01-16 06:15:21.288 | HD Request # 21 | Downloading Intraday chart data for F.US.DSXZ24 to the file F.US.DSXZ24.scid. Service: eurex
2025-01-16 06:15:21.289 | HD Request # 21 | Download start date-time: 2024-12-20 10:59:59.000000. File last date-time: 2024-12-20 10:59:59.987000
2025-01-16 06:15:21.289 | HD Request # 21 | Using server: ds14.sierracharts.com port 10149
2025-01-16 06:15:21.289 | Socket (2) | Creating socket.
2025-01-16 06:15:21.289 | Socket (2) | New receive buffer size: 0
2025-01-16 06:15:21.289 | Socket (2) | Connecting to IP: 176.9.9.252.
2025-01-16 06:15:21.346 | Socket (4) | Socket gracefully closed by remote side.
2025-01-16 06:15:21.346 | Socket (4) | Closed.
2025-01-16 06:15:21.438 | HD Request # 21 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:21.438 | HD Request # 21 | Sending historical data logon request message.
2025-01-16 06:15:21.510 | DTC - Sub Instance | Starting real-time market data updates for: F.US.ENQH25. ID: 21 Service code: cqg
2025-01-16 06:15:21.510 | DTC - Sub Instance | Requesting security definition data for: F.US.ENQH25. ID: 21
2025-01-16 06:15:21.510 | DTC - Sub Instance | Setting external service identifier for symbol F.US.ENQH25 to 42288528
2025-01-16 06:15:21.510 | DTC - Sub Instance | Received security definition for symbol F.US.ENQH25
2025-01-16 06:15:22.005 | HD Request # 21 | Requesting Intraday data. Start date-time: 2024-12-20 10:59:59. Record interval: 0. Symbol: FESX202412_FUT_EUREX
2025-01-16 06:15:22.073 | HD Request # 21 | Decompressing data.
2025-01-16 06:15:22.139 | HD Request # 21 | Receiving Intraday data for F.US.DSXZ24 starting at 2024-12-20 10:59:59.987000
2025-01-16 06:15:22.139 | Socket (2) | CloseSocket call.
2025-01-16 06:15:22.139 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:22.145 | Historical data download thread signaled to stop.
2025-01-16 06:15:22.145 | HD Request # 21 | Received 1 Intraday data record from 2024-12-20 10:59:59.987000 to 2024-12-20 10:59:59.987000 (0.0 seconds. Delay: 26.8 days) and wrote 0 records for F.US.DSXZ24
2025-01-16 06:15:22.145 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2024-12-20 10:59:59.987000
2025-01-16 06:15:22.145 | HD Request # 21 | Completion time: 1s.
2025-01-16 06:15:22.145 | HD Request # 21 | Intraday data download complete for F.US.DSXZ24. Unique request ID: 20
2025-01-16 06:15:22.145 | Removing historical data download ID 20.
2025-01-16 06:15:22.145 | Real-time Intraday chart data file updates started for F.US.DSXZ24
2025-01-16 06:15:22.145 | Intraday chart data file opened for F.US.DSXZ24
2025-01-16 06:15:22.145 | HD Request # 21 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:22.145 | Triggering next historical data download in queue.
2025-01-16 06:15:22.145 | HD Request # 22 | Downloading Intraday chart data for F.US.DSXH25 to the file F.US.DSXH25.scid. Service: eurex
2025-01-16 06:15:22.145 | HD Request # 22 | Download start date-time: 2025-01-16 06:01:25.000000. File last date-time: 2025-01-16 06:01:25.225002
2025-01-16 06:15:22.145 | HD Request # 22 | Using server: ds50.sierracharts.com port 10150
2025-01-16 06:15:22.145 | Socket (3) | Creating socket.
2025-01-16 06:15:22.145 | Socket (3) | New receive buffer size: 0
2025-01-16 06:15:22.145 | Socket (3) | Connecting to IP: 62.209.53.225.
2025-01-16 06:15:22.207 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:15:22.207 | Socket (2) | Closed.
2025-01-16 06:15:22.262 | HD Request # 22 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:22.262 | HD Request # 22 | Sending historical data logon request message.
2025-01-16 06:15:22.319 | Socket (3) | CloseSocket call.
2025-01-16 06:15:22.319 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:22.320 | HD Request # 22 | Error downloading historical Intraday data for F.US.DSXH25. Historical data logon error: Serving data is disabled
2025-01-16 06:15:22.320 | Added historical Intraday data request for F.US.DSXH25 to the queue.
2025-01-16 06:15:22.320 | Triggering next historical data download in queue.
2025-01-16 06:15:22.320 | Historical data download thread signaled to stop.
2025-01-16 06:15:22.320 | HD Request # 22 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DSXH25
2025-01-16 06:15:22.320 | HD Request # 22 | Completion time: 0s.
2025-01-16 06:15:22.320 | HD Request # 23 | Downloading Intraday chart data for F.US.DSXH25 to the file F.US.DSXH25.scid. Service: eurex
2025-01-16 06:15:22.320 | HD Request # 23 | Download start date-time: 2025-01-16 06:01:25.000000. File last date-time: 2025-01-16 06:01:25.225002
2025-01-16 06:15:22.320 | HD Request # 23 | Using server: ds24.sierracharts.com port 10149
2025-01-16 06:15:22.320 | Socket (2) | Creating socket.
2025-01-16 06:15:22.320 | Socket (2) | New receive buffer size: 0
2025-01-16 06:15:22.320 | Socket (2) | Connecting to IP: 62.209.53.226.
2025-01-16 06:15:22.377 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:15:22.377 | Socket (3) | Closed.
2025-01-16 06:15:22.436 | HD Request # 23 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:22.436 | HD Request # 23 | Sending historical data logon request message.
2025-01-16 06:15:22.493 | HD Request # 23 | Requesting Intraday data. Start date-time: 2025-01-16 06:01:25. Record interval: 0. Symbol: FESX202503_FUT_EUREX
2025-01-16 06:15:22.550 | HD Request # 23 | Decompressing data.
2025-01-16 06:15:22.608 | HD Request # 23 | Receiving Intraday data for F.US.DSXH25 starting at 2025-01-16 06:01:25.225000
2025-01-16 06:15:22.609 | Socket (2) | CloseSocket call.
2025-01-16 06:15:22.609 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:22.609 | Historical data download thread signaled to stop.
2025-01-16 06:15:22.609 | HD Request # 23 | Timestamp of first Intraday data file record written: 2025-01-16 06:01:48.081000.
2025-01-16 06:15:22.609 | HD Request # 23 | Received 792 Intraday data records from 2025-01-16 06:01:25.225000 to 2025-01-16 06:15:20.889000 (13.9 minutes. Delay: 1.7 seconds) and wrote 789 records for F.US.DSXH25
2025-01-16 06:15:22.610 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:15:20.889000
2025-01-16 06:15:22.610 | HD Request # 23 | Completion time: 0s.
2025-01-16 06:15:22.610 | HD Request # 23 | Intraday data download complete for F.US.DSXH25. Unique request ID: 21
2025-01-16 06:15:22.610 | Removing historical data download ID 21.
2025-01-16 06:15:22.610 | Real-time Intraday chart data file updates started for F.US.DSXH25
2025-01-16 06:15:22.610 | Intraday chart data file opened for F.US.DSXH25
2025-01-16 06:15:22.610 | HD Request # 23 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:22.610 | Triggering next historical data download in queue.
2025-01-16 06:15:22.610 | HD Request # 24 | Downloading Intraday chart data for F.US.DDU24 to the file F.US.DDU24.scid. Service: eurex
2025-01-16 06:15:22.610 | HD Request # 24 | Download start date-time: 2024-09-20 11:58:52.000000. File last date-time: 2024-09-20 11:58:52.338000
2025-01-16 06:15:22.610 | HD Request # 24 | Using server: ds14.sierracharts.com port 10150
2025-01-16 06:15:22.610 | Socket (3) | Creating socket.
2025-01-16 06:15:22.610 | Socket (3) | New receive buffer size: 0
2025-01-16 06:15:22.610 | Socket (3) | Connecting to IP: 176.9.9.252.
2025-01-16 06:15:22.666 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:15:22.666 | Socket (2) | Closed.
2025-01-16 06:15:22.749 | HD Request # 24 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:22.749 | HD Request # 24 | Sending historical data logon request message.
2025-01-16 06:15:22.817 | HD Request # 24 | Requesting Intraday data. Start date-time: 2024-09-20 11:58:52. Record interval: 0. Symbol: FDAX202409_FUT_EUREX
2025-01-16 06:15:22.885 | HD Request # 24 | Decompressing data.
2025-01-16 06:15:22.952 | HD Request # 24 | Receiving Intraday data for F.US.DDU24 starting at 2024-09-20 11:58:52.338000
2025-01-16 06:15:22.952 | Socket (3) | CloseSocket call.
2025-01-16 06:15:22.952 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:23.020 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:15:23.020 | Socket (3) | Closed.
2025-01-16 06:15:25.092 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.ENQH25.scid. Thread ID: 24244
2025-01-16 06:15:38.867 | F.US.DBH25 [CBV] 1000 Volume #14 | Chart data loading complete.
2025-01-16 06:15:38.867 | Historical data download thread signaled to stop.
2025-01-16 06:15:38.867 | HD Request # 24 | Received 1 Intraday data record from 2024-09-20 11:58:52.338000 to 2024-09-20 11:58:52.338000 (0.0 seconds. Delay: 117.8 days) and wrote 0 records for F.US.DDU24
2025-01-16 06:15:38.867 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2024-09-20 10:58:52.338000
2025-01-16 06:15:38.867 | HD Request # 24 | Completion time: 16s.
2025-01-16 06:15:38.867 | HD Request # 24 | Intraday data download complete for F.US.DDU24. Unique request ID: 22
2025-01-16 06:15:38.867 | Removing historical data download ID 22.
2025-01-16 06:15:38.867 | Real-time Intraday chart data file updates started for F.US.DDU24
2025-01-16 06:15:38.867 | Intraday chart data file opened for F.US.DDU24
2025-01-16 06:15:38.867 | HD Request # 24 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:38.867 | Triggering next historical data download in queue.
2025-01-16 06:15:38.896 | F.US.ENQH25 [CBV] 1500 Volume #15 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:15:40.955 | F.US.ENQH25 [CBV] 1500 Volume #15 | Chart data loading complete.
2025-01-16 06:15:40.963 | HD Request # 25 | Downloading Intraday chart data for F.US.DDZ24 to the file F.US.DDZ24.scid. Service: eurex
2025-01-16 06:15:40.963 | HD Request # 25 | Download start date-time: 2024-12-20 11:59:32.000000. File last date-time: 2024-12-20 11:59:32.101000
2025-01-16 06:15:40.963 | HD Request # 25 | Using server: ds50.sierracharts.com port 10149
2025-01-16 06:15:40.963 | Socket (2) | Creating socket.
2025-01-16 06:15:40.963 | Socket (2) | New receive buffer size: 0
2025-01-16 06:15:40.963 | Socket (2) | Connecting to IP: 62.209.53.225.
2025-01-16 06:15:41.080 | HD Request # 25 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:41.080 | HD Request # 25 | Sending historical data logon request message.
2025-01-16 06:15:41.137 | Socket (2) | CloseSocket call.
2025-01-16 06:15:41.137 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:41.195 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:15:41.195 | Socket (2) | Closed.
2025-01-16 06:15:43.083 | HD Request # 25 | Error downloading historical Intraday data for F.US.DDZ24. Historical data logon error: Serving data is disabled
2025-01-16 06:15:43.083 | Added historical Intraday data request for F.US.DDZ24 to the queue.
2025-01-16 06:15:43.083 | Triggering next historical data download in queue.
2025-01-16 06:15:43.083 | Historical data download thread signaled to stop.
2025-01-16 06:15:43.083 | HD Request # 25 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DDZ24
2025-01-16 06:15:43.083 | HD Request # 25 | Completion time: 3s.
2025-01-16 06:15:43.084 | HD Request # 26 | Downloading Intraday chart data for F.US.DDZ24 to the file F.US.DDZ24.scid. Service: eurex
2025-01-16 06:15:43.085 | HD Request # 26 | Download start date-time: 2024-12-20 11:59:32.000000. File last date-time: 2024-12-20 11:59:32.101000
2025-01-16 06:15:43.085 | HD Request # 26 | Using server: ds24.sierracharts.com port 10150
2025-01-16 06:15:43.085 | Socket (2) | Creating socket.
2025-01-16 06:15:43.085 | Socket (2) | New receive buffer size: 0
2025-01-16 06:15:43.085 | Socket (2) | Connecting to IP: 62.209.53.226.
2025-01-16 06:15:43.122 | F.US.DSXH25 [CBV] 1000 Volume #16 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:15:43.122 | F.US.DSXH25 [CBV] 1000 Volume #16 | Reloading chart.
2025-01-16 06:15:43.200 | HD Request # 26 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:43.200 | HD Request # 26 | Sending historical data logon request message.
2025-01-16 06:15:43.257 | HD Request # 26 | Requesting Intraday data. Start date-time: 2024-12-20 11:59:32. Record interval: 0. Symbol: FDAX202412_FUT_EUREX
2025-01-16 06:15:43.314 | HD Request # 26 | Decompressing data.
2025-01-16 06:15:43.370 | HD Request # 26 | Receiving Intraday data for F.US.DDZ24 starting at 2024-12-20 11:59:32.101000
2025-01-16 06:15:43.370 | Socket (2) | CloseSocket call.
2025-01-16 06:15:43.370 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:43.371 | Historical data download thread signaled to stop.
2025-01-16 06:15:43.371 | HD Request # 26 | Received 1 Intraday data record from 2024-12-20 11:59:32.101000 to 2024-12-20 11:59:32.101000 (0.0 seconds. Delay: 26.8 days) and wrote 0 records for F.US.DDZ24
2025-01-16 06:15:43.371 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2024-12-20 11:59:32.101000
2025-01-16 06:15:43.371 | HD Request # 26 | Completion time: 0s.
2025-01-16 06:15:43.371 | HD Request # 26 | Intraday data download complete for F.US.DDZ24. Unique request ID: 23
2025-01-16 06:15:43.371 | Removing historical data download ID 23.
2025-01-16 06:15:43.371 | Real-time Intraday chart data file updates started for F.US.DDZ24
2025-01-16 06:15:43.371 | Intraday chart data file opened for F.US.DDZ24
2025-01-16 06:15:43.371 | HD Request # 26 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:43.371 | Triggering next historical data download in queue.
2025-01-16 06:15:43.371 | HD Request # 27 | Downloading Intraday chart data for F.US.DDH25 to the file F.US.DDH25.scid. Service: eurex
2025-01-16 06:15:43.371 | HD Request # 27 | Download start date-time: 2025-01-16 06:01:25.000000. File last date-time: 2025-01-16 06:01:25.840000
2025-01-16 06:15:43.371 | HD Request # 27 | Using server: ds14.sierracharts.com port 10149
2025-01-16 06:15:43.371 | Socket (3) | Creating socket.
2025-01-16 06:15:43.371 | Socket (3) | New receive buffer size: 0
2025-01-16 06:15:43.371 | Socket (3) | Connecting to IP: 176.9.9.252.
2025-01-16 06:15:43.426 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:15:43.426 | Socket (2) | Closed.
2025-01-16 06:15:43.509 | HD Request # 27 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:43.509 | HD Request # 27 | Sending historical data logon request message.
2025-01-16 06:15:43.536 | F.US.DSXH25 [CBV] 1000 Volume #16 | Reloading chart.
2025-01-16 06:15:43.577 | HD Request # 27 | Requesting Intraday data. Start date-time: 2025-01-16 06:01:25. Record interval: 0. Symbol: FDAX202503_FUT_EUREX
2025-01-16 06:15:43.645 | HD Request # 27 | Decompressing data.
2025-01-16 06:15:43.713 | HD Request # 27 | Receiving Intraday data for F.US.DDH25 starting at 2025-01-16 06:01:25.227000
2025-01-16 06:15:43.713 | Socket (3) | CloseSocket call.
2025-01-16 06:15:43.713 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:43.714 | Historical data download thread signaled to stop.
2025-01-16 06:15:43.714 | HD Request # 27 | Timestamp of first Intraday data file record written: 2025-01-16 06:02:15.504000.
2025-01-16 06:15:43.714 | HD Request # 27 | Received 331 Intraday data records from 2025-01-16 06:01:25.227000 to 2025-01-16 06:15:32.852000 (14.1 minutes. Delay: 10.9 seconds) and wrote 328 records for F.US.DDH25
2025-01-16 06:15:43.714 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:15:32.852000
2025-01-16 06:15:43.714 | HD Request # 27 | Completion time: 0s.
2025-01-16 06:15:43.714 | HD Request # 27 | Intraday data download complete for F.US.DDH25. Unique request ID: 24
2025-01-16 06:15:43.714 | Removing historical data download ID 24.
2025-01-16 06:15:43.714 | Real-time Intraday chart data file updates started for F.US.DDH25
2025-01-16 06:15:43.714 | Intraday chart data file opened for F.US.DDH25
2025-01-16 06:15:43.714 | HD Request # 27 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:43.714 | Triggering next historical data download in queue.
2025-01-16 06:15:43.714 | HD Request # 28 | Downloading Intraday chart data for F.US.DLU24 to the file F.US.DLU24.scid. Service: eurex
2025-01-16 06:15:43.714 | HD Request # 28 | Download start date-time: 2024-09-06 11:29:59.000000. File last date-time: 2024-09-06 11:29:59.003004
2025-01-16 06:15:43.714 | HD Request # 28 | Using server: ds50.sierracharts.com port 10150
2025-01-16 06:15:43.714 | Socket (2) | Creating socket.
2025-01-16 06:15:43.714 | Socket (2) | New receive buffer size: 0
2025-01-16 06:15:43.714 | Socket (2) | Connecting to IP: 62.209.53.225.
2025-01-16 06:15:43.780 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:15:43.781 | Socket (3) | Closed.
2025-01-16 06:15:43.830 | HD Request # 28 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:43.830 | HD Request # 28 | Sending historical data logon request message.
2025-01-16 06:15:43.887 | Socket (2) | CloseSocket call.
2025-01-16 06:15:43.887 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:43.898 | HD Request # 28 | Error downloading historical Intraday data for F.US.DLU24. Historical data logon error: Serving data is disabled
2025-01-16 06:15:43.898 | Added historical Intraday data request for F.US.DLU24 to the queue.
2025-01-16 06:15:43.898 | Triggering next historical data download in queue.
2025-01-16 06:15:43.898 | Historical data download thread signaled to stop.
2025-01-16 06:15:43.898 | HD Request # 28 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DLU24
2025-01-16 06:15:43.898 | HD Request # 28 | Completion time: 0s.
2025-01-16 06:15:43.898 | HD Request # 29 | Downloading Intraday chart data for F.US.DLU24 to the file F.US.DLU24.scid. Service: eurex
2025-01-16 06:15:43.898 | HD Request # 29 | Download start date-time: 2024-09-06 11:29:59.000000. File last date-time: 2024-09-06 11:29:59.003004
2025-01-16 06:15:43.898 | HD Request # 29 | Using server: ds24.sierracharts.com port 10149
2025-01-16 06:15:43.898 | Socket (3) | Creating socket.
2025-01-16 06:15:43.898 | Socket (3) | New receive buffer size: 0
2025-01-16 06:15:43.898 | Socket (3) | Connecting to IP: 62.209.53.226.
2025-01-16 06:15:43.932 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH25. ID: 24
2025-01-16 06:15:43.932 | Symbol Error | F.US.DSXH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH25. ID: 24
2025-01-16 06:15:43.944 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:15:43.944 | Socket (2) | Closed.
2025-01-16 06:15:44.015 | HD Request # 29 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:44.015 | HD Request # 29 | Sending historical data logon request message.
2025-01-16 06:15:44.061 | F.US.DDH25 [CBV] 50 Volume #17 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:15:44.061 | F.US.DDH25 [CBV] 50 Volume #17 | Reloading chart. | Number times message added: 1
2025-01-16 06:15:44.507 | HD Request # 29 | Requesting Intraday data. Start date-time: 2024-09-06 11:29:59. Record interval: 0. Symbol: FGBM202409_FUT_EUREX
2025-01-16 06:15:44.564 | HD Request # 29 | Decompressing data.
2025-01-16 06:15:44.621 | HD Request # 29 | Receiving Intraday data for F.US.DLU24 starting at 2024-09-06 11:29:59.003000
2025-01-16 06:15:44.621 | Socket (3) | CloseSocket call.
2025-01-16 06:15:44.621 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:44.621 | Historical data download thread signaled to stop.
2025-01-16 06:15:44.621 | HD Request # 29 | Received 5 Intraday data records from 2024-09-06 11:29:59.003000 to 2024-09-06 11:29:59.003004 (0.0 seconds. Delay: 131.8 days) and wrote 0 records for F.US.DLU24
2025-01-16 06:15:44.621 | HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2024-09-06 10:29:59.003004
2025-01-16 06:15:44.621 | HD Request # 29 | Completion time: 1s.
2025-01-16 06:15:44.621 | HD Request # 29 | Intraday data download complete for F.US.DLU24. Unique request ID: 25
2025-01-16 06:15:44.621 | Removing historical data download ID 25.
2025-01-16 06:15:44.621 | Real-time Intraday chart data file updates started for F.US.DLU24
2025-01-16 06:15:44.621 | Intraday chart data file opened for F.US.DLU24
2025-01-16 06:15:44.621 | HD Request # 29 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:44.621 | Triggering next historical data download in queue.
2025-01-16 06:15:44.621 | HD Request # 30 | Downloading Intraday chart data for F.US.DLZ24 to the file F.US.DLZ24.scid. Service: eurex
2025-01-16 06:15:44.621 | HD Request # 30 | Download start date-time: 2024-12-06 07:25:04.000000. File last date-time: 2024-12-06 07:25:04.591000
2025-01-16 06:15:44.621 | HD Request # 30 | Using server: ds14.sierracharts.com port 10150
2025-01-16 06:15:44.621 | Socket (2) | Creating socket.
2025-01-16 06:15:44.622 | Socket (2) | New receive buffer size: 0
2025-01-16 06:15:44.622 | Socket (2) | Connecting to IP: 176.9.9.252.
2025-01-16 06:15:44.677 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:15:44.677 | Socket (3) | Closed.
2025-01-16 06:15:44.758 | HD Request # 30 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:44.758 | HD Request # 30 | Sending historical data logon request message.
2025-01-16 06:15:44.826 | HD Request # 30 | Requesting Intraday data. Start date-time: 2024-12-06 07:25:04. Record interval: 0. Symbol: FGBM202412_FUT_EUREX
2025-01-16 06:15:44.894 | HD Request # 30 | Decompressing data.
2025-01-16 06:15:44.961 | HD Request # 30 | Receiving Intraday data for F.US.DLZ24 starting at 2024-12-06 07:25:04.580000
2025-01-16 06:15:44.961 | Socket (2) | CloseSocket call.
2025-01-16 06:15:44.961 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:45.028 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:15:45.028 | Socket (2) | Closed.
2025-01-16 06:15:54.841 | F.US.DDH25 [CBV] 50 Volume #17 | Chart data loading complete.
2025-01-16 06:15:54.841 | Historical data download thread signaled to stop.
2025-01-16 06:15:54.841 | HD Request # 30 | Received 3 Intraday data records from 2024-12-06 07:25:04.580000 to 2024-12-06 07:25:04.591000 (0.0 seconds. Delay: 41.0 days) and wrote 0 records for F.US.DLZ24
2025-01-16 06:15:54.841 | HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2024-12-06 07:25:04.591000
2025-01-16 06:15:54.841 | HD Request # 30 | Completion time: 10s.
2025-01-16 06:15:54.841 | HD Request # 30 | Intraday data download complete for F.US.DLZ24. Unique request ID: 26
2025-01-16 06:15:54.841 | Removing historical data download ID 26.
2025-01-16 06:15:54.841 | Real-time Intraday chart data file updates started for F.US.DLZ24
2025-01-16 06:15:54.841 | Intraday chart data file opened for F.US.DLZ24
2025-01-16 06:15:54.841 | HD Request # 30 | Enabling Intraday chart updating for symbol.
2025-01-16 06:15:54.841 | Triggering next historical data download in queue.
2025-01-16 06:15:59.493 | F.US.DSXH25 [CBV] 1000 Volume #16 | Chart data loading complete.
2025-01-16 06:15:59.500 | HD Request # 31 | Downloading Intraday chart data for F.US.DLH25 to the file F.US.DLH25.scid. Service: eurex
2025-01-16 06:15:59.500 | HD Request # 31 | Download start date-time: 2025-01-16 06:00:04.000000. File last date-time: 2025-01-16 06:00:04.102010
2025-01-16 06:15:59.500 | HD Request # 31 | Using server: ds50.sierracharts.com port 10149
2025-01-16 06:15:59.500 | Socket (2) | Creating socket.
2025-01-16 06:15:59.500 | Socket (2) | New receive buffer size: 0
2025-01-16 06:15:59.500 | Socket (2) | Connecting to IP: 62.209.53.225.
2025-01-16 06:15:59.584 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DDH25. ID: 27
2025-01-16 06:15:59.584 | Symbol Error | F.US.DDH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DDH25. ID: 27
2025-01-16 06:15:59.617 | HD Request # 31 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:59.617 | HD Request # 31 | Sending historical data logon request message.
2025-01-16 06:15:59.674 | Socket (2) | CloseSocket call.
2025-01-16 06:15:59.674 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:15:59.674 | HD Request # 31 | Error downloading historical Intraday data for F.US.DLH25. Historical data logon error: Serving data is disabled
2025-01-16 06:15:59.674 | Added historical Intraday data request for F.US.DLH25 to the queue.
2025-01-16 06:15:59.674 | Triggering next historical data download in queue.
2025-01-16 06:15:59.674 | Historical data download thread signaled to stop.
2025-01-16 06:15:59.674 | HD Request # 31 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DLH25
2025-01-16 06:15:59.674 | HD Request # 31 | Completion time: 0s.
2025-01-16 06:15:59.674 | HD Request # 32 | Downloading Intraday chart data for F.US.DLH25 to the file F.US.DLH25.scid. Service: eurex
2025-01-16 06:15:59.674 | HD Request # 32 | Download start date-time: 2025-01-16 06:00:04.000000. File last date-time: 2025-01-16 06:00:04.102010
2025-01-16 06:15:59.674 | HD Request # 32 | Using server: ds24.sierracharts.com port 10150
2025-01-16 06:15:59.674 | Socket (3) | Creating socket.
2025-01-16 06:15:59.675 | Socket (3) | New receive buffer size: 0
2025-01-16 06:15:59.675 | Socket (3) | Connecting to IP: 62.209.53.226.
2025-01-16 06:15:59.731 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:15:59.731 | Socket (2) | Closed.
2025-01-16 06:15:59.790 | HD Request # 32 | Setting DTC encoding to Binary VLS
2025-01-16 06:15:59.790 | HD Request # 32 | Sending historical data logon request message.
2025-01-16 06:16:00.283 | HD Request # 32 | Requesting Intraday data. Start date-time: 2025-01-16 06:00:04. Record interval: 0. Symbol: FGBM202503_FUT_EUREX
2025-01-16 06:16:00.341 | HD Request # 32 | Decompressing data.
2025-01-16 06:16:00.397 | HD Request # 32 | Receiving Intraday data for F.US.DLH25 starting at 2025-01-16 06:00:04.102000
2025-01-16 06:16:00.398 | Socket (3) | CloseSocket call.
2025-01-16 06:16:00.398 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:00.398 | Historical data download thread signaled to stop.
2025-01-16 06:16:00.398 | HD Request # 32 | Timestamp of first Intraday data file record written: 2025-01-16 06:06:22.586000.
2025-01-16 06:16:00.398 | HD Request # 32 | Received 56 Intraday data records from 2025-01-16 06:00:04.102000 to 2025-01-16 06:15:08.480001 (15.1 minutes. Delay: 51.9 seconds) and wrote 45 records for F.US.DLH25
2025-01-16 06:16:00.398 | HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:15:08.480001
2025-01-16 06:16:00.398 | HD Request # 32 | Completion time: 1s.
2025-01-16 06:16:00.398 | HD Request # 32 | Intraday data download complete for F.US.DLH25. Unique request ID: 27
2025-01-16 06:16:00.398 | Removing historical data download ID 27.
2025-01-16 06:16:00.398 | Real-time Intraday chart data file updates started for F.US.DLH25
2025-01-16 06:16:00.398 | Intraday chart data file opened for F.US.DLH25
2025-01-16 06:16:00.398 | HD Request # 32 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:00.398 | Triggering next historical data download in queue.
2025-01-16 06:16:00.399 | HD Request # 33 | Downloading Intraday chart data for F.US.DGU24 to the file F.US.DGU24.scid. Service: eurex
2025-01-16 06:16:00.399 | HD Request # 33 | Download start date-time: 2024-09-06 11:29:54.000000. File last date-time: 2024-09-06 11:29:54.392000
2025-01-16 06:16:00.399 | HD Request # 33 | Using server: ds14.sierracharts.com port 10149
2025-01-16 06:16:00.399 | Socket (2) | Creating socket.
2025-01-16 06:16:00.399 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:00.399 | Socket (2) | Connecting to IP: 176.9.9.252.
2025-01-16 06:16:00.455 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:00.455 | Socket (3) | Closed.
2025-01-16 06:16:00.538 | HD Request # 33 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:00.538 | HD Request # 33 | Sending historical data logon request message.
2025-01-16 06:16:00.714 | F.US.DLH25 [CBV] 1000 Volume #18 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:16:00.714 | F.US.DLH25 [CBV] 1000 Volume #18 | Reloading chart.
2025-01-16 06:16:01.110 | HD Request # 33 | Requesting Intraday data. Start date-time: 2024-09-06 11:29:54. Record interval: 0. Symbol: FGBS202409_FUT_EUREX
2025-01-16 06:16:01.169 | F.US.DLH25 [CBV] 1000 Volume #18 | Reloading chart.
2025-01-16 06:16:01.178 | HD Request # 33 | Decompressing data.
2025-01-16 06:16:01.245 | HD Request # 33 | Receiving Intraday data for F.US.DGU24 starting at 2024-09-06 11:29:54.350000
2025-01-16 06:16:01.245 | Socket (2) | CloseSocket call.
2025-01-16 06:16:01.245 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:01.258 | Historical data download thread signaled to stop.
2025-01-16 06:16:01.258 | HD Request # 33 | Received 2 Intraday data records from 2024-09-06 11:29:54.350000 to 2024-09-06 11:29:54.392000 (0.0 seconds. Delay: 131.8 days) and wrote 0 records for F.US.DGU24
2025-01-16 06:16:01.258 | HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2024-09-06 10:29:54.392000
2025-01-16 06:16:01.258 | HD Request # 33 | Completion time: 1s.
2025-01-16 06:16:01.258 | HD Request # 33 | Intraday data download complete for F.US.DGU24. Unique request ID: 28
2025-01-16 06:16:01.258 | Removing historical data download ID 28.
2025-01-16 06:16:01.258 | Real-time Intraday chart data file updates started for F.US.DGU24
2025-01-16 06:16:01.258 | Intraday chart data file opened for F.US.DGU24
2025-01-16 06:16:01.258 | HD Request # 33 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:01.258 | Triggering next historical data download in queue.
2025-01-16 06:16:01.258 | HD Request # 34 | Downloading Intraday chart data for F.US.DGZ24 to the file F.US.DGZ24.scid. Service: eurex
2025-01-16 06:16:01.259 | HD Request # 34 | Download start date-time: 2024-12-06 11:29:57.000000. File last date-time: 2024-12-06 11:29:57.465003
2025-01-16 06:16:01.259 | HD Request # 34 | Using server: ds50.sierracharts.com port 10150
2025-01-16 06:16:01.259 | Socket (3) | Creating socket.
2025-01-16 06:16:01.259 | Socket (3) | New receive buffer size: 0
2025-01-16 06:16:01.259 | Socket (3) | Connecting to IP: 62.209.53.225.
2025-01-16 06:16:01.312 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:01.312 | Socket (2) | Closed.
2025-01-16 06:16:01.375 | HD Request # 34 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:01.375 | HD Request # 34 | Sending historical data logon request message.
2025-01-16 06:16:01.432 | Socket (3) | CloseSocket call.
2025-01-16 06:16:01.432 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:01.439 | HD Request # 34 | Error downloading historical Intraday data for F.US.DGZ24. Historical data logon error: Serving data is disabled
2025-01-16 06:16:01.439 | Added historical Intraday data request for F.US.DGZ24 to the queue.
2025-01-16 06:16:01.439 | Triggering next historical data download in queue.
2025-01-16 06:16:01.439 | Historical data download thread signaled to stop.
2025-01-16 06:16:01.439 | HD Request # 34 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DGZ24
2025-01-16 06:16:01.439 | HD Request # 34 | Completion time: 0s.
2025-01-16 06:16:01.439 | HD Request # 35 | Downloading Intraday chart data for F.US.DGZ24 to the file F.US.DGZ24.scid. Service: eurex
2025-01-16 06:16:01.439 | HD Request # 35 | Download start date-time: 2024-12-06 11:29:57.000000. File last date-time: 2024-12-06 11:29:57.465003
2025-01-16 06:16:01.439 | HD Request # 35 | Using server: ds24.sierracharts.com port 10149
2025-01-16 06:16:01.439 | Socket (2) | Creating socket.
2025-01-16 06:16:01.439 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:01.439 | Socket (2) | Connecting to IP: 62.209.53.226.
2025-01-16 06:16:01.490 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:01.490 | Socket (3) | Closed.
2025-01-16 06:16:01.555 | HD Request # 35 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:01.555 | HD Request # 35 | Sending historical data logon request message.
2025-01-16 06:16:01.595 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DLH25. ID: 30
2025-01-16 06:16:01.595 | Symbol Error | F.US.DLH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DLH25. ID: 30
2025-01-16 06:16:01.612 | HD Request # 35 | Requesting Intraday data. Start date-time: 2024-12-06 11:29:57. Record interval: 0. Symbol: FGBS202412_FUT_EUREX
2025-01-16 06:16:01.669 | HD Request # 35 | Decompressing data.
2025-01-16 06:16:01.726 | HD Request # 35 | Receiving Intraday data for F.US.DGZ24 starting at 2024-12-06 11:29:57.231000
2025-01-16 06:16:01.726 | Socket (2) | CloseSocket call.
2025-01-16 06:16:01.726 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:01.726 | Historical data download thread signaled to stop.
2025-01-16 06:16:01.726 | HD Request # 35 | Received 6 Intraday data records from 2024-12-06 11:29:57.231000 to 2024-12-06 11:29:57.465003 (0.2 seconds. Delay: 40.8 days) and wrote 0 records for F.US.DGZ24
2025-01-16 06:16:01.727 | HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2024-12-06 11:29:57.465003
2025-01-16 06:16:01.727 | HD Request # 35 | Completion time: 0s.
2025-01-16 06:16:01.727 | HD Request # 35 | Intraday data download complete for F.US.DGZ24. Unique request ID: 29
2025-01-16 06:16:01.727 | Removing historical data download ID 29.
2025-01-16 06:16:01.727 | Real-time Intraday chart data file updates started for F.US.DGZ24
2025-01-16 06:16:01.727 | Intraday chart data file opened for F.US.DGZ24
2025-01-16 06:16:01.727 | HD Request # 35 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:01.727 | Triggering next historical data download in queue.
2025-01-16 06:16:01.727 | HD Request # 36 | Downloading Intraday chart data for F.US.DGH25 to the file F.US.DGH25.scid. Service: eurex
2025-01-16 06:16:01.727 | HD Request # 36 | Download start date-time: 2025-01-16 06:01:21.000000. File last date-time: 2025-01-16 06:01:21.852000
2025-01-16 06:16:01.727 | HD Request # 36 | Using server: ds14.sierracharts.com port 10150
2025-01-16 06:16:01.727 | Socket (3) | Creating socket.
2025-01-16 06:16:01.727 | Socket (3) | New receive buffer size: 0
2025-01-16 06:16:01.727 | Socket (3) | Connecting to IP: 176.9.9.252.
2025-01-16 06:16:01.783 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:01.783 | Socket (2) | Closed.
2025-01-16 06:16:01.865 | HD Request # 36 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:01.865 | HD Request # 36 | Sending historical data logon request message.
2025-01-16 06:16:01.933 | HD Request # 36 | Requesting Intraday data. Start date-time: 2025-01-16 06:01:21. Record interval: 0. Symbol: FGBS202503_FUT_EUREX
2025-01-16 06:16:02.002 | HD Request # 36 | Decompressing data.
2025-01-16 06:16:02.069 | HD Request # 36 | Receiving Intraday data for F.US.DGH25 starting at 2025-01-16 06:01:21.852000
2025-01-16 06:16:02.069 | Socket (3) | CloseSocket call.
2025-01-16 06:16:02.069 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:02.137 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:02.138 | Socket (3) | Closed.
2025-01-16 06:16:07.992 | F.US.DLH25 [CBV] 1000 Volume #18 | Chart data loading complete.
2025-01-16 06:16:07.992 | Historical data download thread signaled to stop.
2025-01-16 06:16:07.992 | HD Request # 36 | Timestamp of first Intraday data file record written: 2025-01-16 06:09:43.770000.
2025-01-16 06:16:07.992 | HD Request # 36 | Received 46 Intraday data records from 2025-01-16 06:01:21.852000 to 2025-01-16 06:15:23.940006 (14.0 minutes. Delay: 44.1 seconds) and wrote 45 records for F.US.DGH25
2025-01-16 06:16:07.993 | HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:15:23.940006
2025-01-16 06:16:07.993 | HD Request # 36 | Completion time: 6s.
2025-01-16 06:16:07.993 | HD Request # 36 | Intraday data download complete for F.US.DGH25. Unique request ID: 30
2025-01-16 06:16:07.993 | Removing historical data download ID 30.
2025-01-16 06:16:07.993 | Real-time Intraday chart data file updates started for F.US.DGH25
2025-01-16 06:16:07.993 | Intraday chart data file opened for F.US.DGH25
2025-01-16 06:16:07.993 | HD Request # 36 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:07.993 | Triggering next historical data download in queue.
2025-01-16 06:16:07.997 | HD Request # 37 | Downloading Intraday chart data for F.US.FGBXU24 to the file F.US.FGBXU24.scid. Service: eurex
2025-01-16 06:16:07.997 | HD Request # 37 | Download start date-time: 2024-09-06 11:29:56.000000. File last date-time: 2024-09-06 11:29:56.704000
2025-01-16 06:16:07.997 | HD Request # 37 | Using server: ds50.sierracharts.com port 10149
2025-01-16 06:16:07.997 | Socket (2) | Creating socket.
2025-01-16 06:16:07.997 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:07.997 | Socket (2) | Connecting to IP: 62.209.53.225.
2025-01-16 06:16:08.112 | HD Request # 37 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:08.112 | HD Request # 37 | Sending historical data logon request message.
2025-01-16 06:16:08.169 | Socket (2) | CloseSocket call.
2025-01-16 06:16:08.169 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:08.179 | HD Request # 37 | Error downloading historical Intraday data for F.US.FGBXU24. Historical data logon error: Serving data is disabled
2025-01-16 06:16:08.179 | Added historical Intraday data request for F.US.FGBXU24 to the queue.
2025-01-16 06:16:08.179 | Triggering next historical data download in queue.
2025-01-16 06:16:08.179 | Historical data download thread signaled to stop.
2025-01-16 06:16:08.179 | HD Request # 37 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FGBXU24
2025-01-16 06:16:08.179 | HD Request # 37 | Completion time: 1s.
2025-01-16 06:16:08.179 | HD Request # 38 | Downloading Intraday chart data for F.US.FGBXU24 to the file F.US.FGBXU24.scid. Service: eurex
2025-01-16 06:16:08.179 | HD Request # 38 | Download start date-time: 2024-09-06 11:29:56.000000. File last date-time: 2024-09-06 11:29:56.704000
2025-01-16 06:16:08.179 | HD Request # 38 | Using server: ds24.sierracharts.com port 10150
2025-01-16 06:16:08.179 | Socket (3) | Creating socket.
2025-01-16 06:16:08.179 | Socket (3) | New receive buffer size: 0
2025-01-16 06:16:08.179 | Socket (3) | Connecting to IP: 62.209.53.226.
2025-01-16 06:16:08.209 | F.US.DGH25 [CBV] 1000 Volume #19 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:16:08.210 | F.US.DGH25 [CBV] 1000 Volume #19 | Reloading chart.
2025-01-16 06:16:08.226 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:08.227 | Socket (2) | Closed.
2025-01-16 06:16:08.294 | HD Request # 38 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:08.294 | HD Request # 38 | Sending historical data logon request message.
2025-01-16 06:16:08.351 | HD Request # 38 | Requesting Intraday data. Start date-time: 2024-09-06 11:29:56. Record interval: 0. Symbol: FGBX202409_FUT_EUREX
2025-01-16 06:16:08.408 | HD Request # 38 | Decompressing data.
2025-01-16 06:16:08.464 | HD Request # 38 | Receiving Intraday data for F.US.FGBXU24 starting at 2024-09-06 11:29:56.407000
2025-01-16 06:16:08.464 | Socket (3) | CloseSocket call.
2025-01-16 06:16:08.464 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:08.466 | Historical data download thread signaled to stop.
2025-01-16 06:16:08.466 | HD Request # 38 | Received 3 Intraday data records from 2024-09-06 11:29:56.407000 to 2024-09-06 11:29:56.704000 (0.3 seconds. Delay: 131.8 days) and wrote 0 records for F.US.FGBXU24
2025-01-16 06:16:08.466 | HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2024-09-06 10:29:56.704000
2025-01-16 06:16:08.466 | HD Request # 38 | Completion time: 0s.
2025-01-16 06:16:08.466 | HD Request # 38 | Intraday data download complete for F.US.FGBXU24. Unique request ID: 31
2025-01-16 06:16:08.466 | Removing historical data download ID 31.
2025-01-16 06:16:08.466 | Real-time Intraday chart data file updates started for F.US.FGBXU24
2025-01-16 06:16:08.466 | Intraday chart data file opened for F.US.FGBXU24
2025-01-16 06:16:08.466 | HD Request # 38 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:08.466 | Triggering next historical data download in queue.
2025-01-16 06:16:08.466 | HD Request # 39 | Downloading Intraday chart data for F.US.FGBXZ24 to the file F.US.FGBXZ24.scid. Service: eurex
2025-01-16 06:16:08.466 | HD Request # 39 | Download start date-time: 2024-12-06 08:44:12.000000. File last date-time: 2024-12-06 08:44:12.818000
2025-01-16 06:16:08.466 | HD Request # 39 | Using server: ds14.sierracharts.com port 10149
2025-01-16 06:16:08.466 | Socket (2) | Creating socket.
2025-01-16 06:16:08.466 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:08.466 | Socket (2) | Connecting to IP: 176.9.9.252.
2025-01-16 06:16:08.521 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:08.521 | Socket (3) | Closed.
2025-01-16 06:16:08.606 | HD Request # 39 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:08.606 | HD Request # 39 | Sending historical data logon request message.
2025-01-16 06:16:08.625 | F.US.DGH25 [CBV] 1000 Volume #19 | Reloading chart.
2025-01-16 06:16:08.673 | HD Request # 39 | Requesting Intraday data. Start date-time: 2024-12-06 08:44:12. Record interval: 0. Symbol: FGBX202412_FUT_EUREX
2025-01-16 06:16:08.741 | HD Request # 39 | Decompressing data.
2025-01-16 06:16:08.808 | HD Request # 39 | Receiving Intraday data for F.US.FGBXZ24 starting at 2024-12-06 08:44:12.818000
2025-01-16 06:16:08.808 | Socket (2) | CloseSocket call.
2025-01-16 06:16:08.809 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:08.876 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:08.876 | Socket (2) | Closed.
2025-01-16 06:16:13.380 | F.US.DGH25 [CBV] 1000 Volume #19 | Chart data loading complete.
2025-01-16 06:16:13.380 | Historical data download thread signaled to stop.
2025-01-16 06:16:13.380 | HD Request # 39 | Received 1 Intraday data record from 2024-12-06 08:44:12.818000 to 2024-12-06 08:44:12.818000 (0.0 seconds. Delay: 40.9 days) and wrote 0 records for F.US.FGBXZ24
2025-01-16 06:16:13.380 | HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2024-12-06 08:44:12.818000
2025-01-16 06:16:13.380 | HD Request # 39 | Completion time: 5s.
2025-01-16 06:16:13.380 | HD Request # 39 | Intraday data download complete for F.US.FGBXZ24. Unique request ID: 32
2025-01-16 06:16:13.380 | Removing historical data download ID 32.
2025-01-16 06:16:13.380 | Real-time Intraday chart data file updates started for F.US.FGBXZ24
2025-01-16 06:16:13.380 | Intraday chart data file opened for F.US.FGBXZ24
2025-01-16 06:16:13.380 | HD Request # 39 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:13.380 | Triggering next historical data download in queue.
2025-01-16 06:16:13.383 | HD Request # 40 | Downloading Intraday chart data for F.US.FGBXH25 to the file F.US.FGBXH25.scid. Service: eurex
2025-01-16 06:16:13.383 | HD Request # 40 | Download start date-time: 2025-01-16 06:02:03.000000. File last date-time: 2025-01-16 06:02:03.070000
2025-01-16 06:16:13.383 | HD Request # 40 | Using server: ds50.sierracharts.com port 10150
2025-01-16 06:16:13.383 | Socket (2) | Creating socket.
2025-01-16 06:16:13.383 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:13.383 | Socket (2) | Connecting to IP: 62.209.53.225.
2025-01-16 06:16:13.499 | HD Request # 40 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:13.499 | HD Request # 40 | Sending historical data logon request message.
2025-01-16 06:16:13.522 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DGH25. ID: 33
2025-01-16 06:16:13.522 | Symbol Error | F.US.DGH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DGH25. ID: 33
2025-01-16 06:16:13.556 | Socket (2) | CloseSocket call.
2025-01-16 06:16:13.556 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:13.565 | HD Request # 40 | Error downloading historical Intraday data for F.US.FGBXH25. Historical data logon error: Serving data is disabled
2025-01-16 06:16:13.565 | Added historical Intraday data request for F.US.FGBXH25 to the queue.
2025-01-16 06:16:13.565 | Triggering next historical data download in queue.
2025-01-16 06:16:13.565 | Historical data download thread signaled to stop.
2025-01-16 06:16:13.565 | HD Request # 40 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FGBXH25
2025-01-16 06:16:13.565 | HD Request # 40 | Completion time: 0s.
2025-01-16 06:16:13.565 | HD Request # 41 | Downloading Intraday chart data for F.US.FGBXH25 to the file F.US.FGBXH25.scid. Service: eurex
2025-01-16 06:16:13.565 | HD Request # 41 | Download start date-time: 2025-01-16 06:02:03.000000. File last date-time: 2025-01-16 06:02:03.070000
2025-01-16 06:16:13.565 | HD Request # 41 | Using server: ds24.sierracharts.com port 10149
2025-01-16 06:16:13.565 | Socket (3) | Creating socket.
2025-01-16 06:16:13.565 | Socket (3) | New receive buffer size: 0
2025-01-16 06:16:13.565 | Socket (3) | Connecting to IP: 62.209.53.226.
2025-01-16 06:16:13.613 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:13.613 | Socket (2) | Closed.
2025-01-16 06:16:13.681 | HD Request # 41 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:13.681 | HD Request # 41 | Sending historical data logon request message.
2025-01-16 06:16:14.169 | HD Request # 41 | Requesting Intraday data. Start date-time: 2025-01-16 06:02:03. Record interval: 0. Symbol: FGBX202503_FUT_EUREX
2025-01-16 06:16:14.226 | HD Request # 41 | Decompressing data.
2025-01-16 06:16:14.283 | HD Request # 41 | Receiving Intraday data for F.US.FGBXH25 starting at 2025-01-16 06:02:03.070000
2025-01-16 06:16:14.283 | Socket (3) | CloseSocket call.
2025-01-16 06:16:14.283 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:14.283 | Historical data download thread signaled to stop.
2025-01-16 06:16:14.283 | HD Request # 41 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:44.006000.
2025-01-16 06:16:14.284 | HD Request # 41 | Received 20 Intraday data records from 2025-01-16 06:02:03.070000 to 2025-01-16 06:11:24.550000 (9.4 minutes. Delay: 4.8 minutes) and wrote 19 records for F.US.FGBXH25
2025-01-16 06:16:14.284 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:11:24.550000
2025-01-16 06:16:14.284 | HD Request # 41 | Completion time: 1s.
2025-01-16 06:16:14.284 | HD Request # 41 | Intraday data download complete for F.US.FGBXH25. Unique request ID: 33
2025-01-16 06:16:14.284 | Removing historical data download ID 33.
2025-01-16 06:16:14.284 | Real-time Intraday chart data file updates started for F.US.FGBXH25
2025-01-16 06:16:14.284 | Intraday chart data file opened for F.US.FGBXH25
2025-01-16 06:16:14.284 | HD Request # 41 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:14.284 | Triggering next historical data download in queue.
2025-01-16 06:16:14.284 | HD Request # 42 | Downloading Intraday chart data for F.US.SF6H25 to the file F.US.SF6H25.scid. Service: cme
2025-01-16 06:16:14.284 | HD Request # 42 | Download start date-time: 2025-01-16 06:04:31.000000. File last date-time: 2025-01-16 06:04:31.438001
2025-01-16 06:16:14.284 | HD Request # 42 | Using server: ds26.sierracharts.com port 10150
2025-01-16 06:16:14.284 | Socket (2) | Creating socket.
2025-01-16 06:16:14.284 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:14.284 | Socket (2) | Connecting to IP: 64.152.155.17.
2025-01-16 06:16:14.340 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:14.340 | Socket (3) | Closed.
2025-01-16 06:16:14.341 | F.US.FGBXH25 [CBV] 250 Volume #20 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:16:14.341 | F.US.FGBXH25 [CBV] 250 Volume #20 | Reloading chart.
2025-01-16 06:16:14.572 | HD Request # 42 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:14.572 | HD Request # 42 | Sending historical data logon request message.
2025-01-16 06:16:14.754 | F.US.FGBXH25 [CBV] 250 Volume #20 | Reloading chart.
2025-01-16 06:16:14.760 | HD Request # 42 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:31. Record interval: 0. Symbol: 6SH25
2025-01-16 06:16:14.900 | HD Request # 42 | Decompressing data.
2025-01-16 06:16:15.039 | HD Request # 42 | Receiving Intraday data for F.US.SF6H25 starting at 2025-01-16 06:04:31.438000
2025-01-16 06:16:15.040 | Socket (2) | CloseSocket call.
2025-01-16 06:16:15.040 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:15.040 | Historical data download thread signaled to stop.
2025-01-16 06:16:15.040 | HD Request # 42 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:52.157000.
2025-01-16 06:16:15.040 | HD Request # 42 | Received 29 Intraday data records from 2025-01-16 06:04:31.438000 to 2025-01-16 06:15:32.629000 (11.0 minutes. Delay: 42.4 seconds) and wrote 27 records for F.US.SF6H25
2025-01-16 06:16:15.040 | HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:15:32.629000
2025-01-16 06:16:15.040 | HD Request # 42 | Completion time: 1s.
2025-01-16 06:16:15.040 | HD Request # 42 | Intraday data download complete for F.US.SF6H25. Unique request ID: 34
2025-01-16 06:16:15.040 | Removing historical data download ID 34.
2025-01-16 06:16:15.040 | Real-time Intraday chart data file updates started for F.US.SF6H25
2025-01-16 06:16:15.040 | Intraday chart data file opened for F.US.SF6H25
2025-01-16 06:16:15.040 | HD Request # 42 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:15.040 | Triggering next historical data download in queue.
2025-01-16 06:16:15.041 | HD Request # 43 | Downloading Intraday chart data for F.US.FOATU24 to the file F.US.FOATU24.scid. Service: eurex
2025-01-16 06:16:15.041 | HD Request # 43 | Download start date-time: 2024-09-06 11:29:59.000000. File last date-time: 2024-09-06 11:29:59.003001
2025-01-16 06:16:15.041 | HD Request # 43 | Using server: ds50.sierracharts.com port 10149
2025-01-16 06:16:15.041 | Socket (3) | Creating socket.
2025-01-16 06:16:15.041 | Socket (3) | New receive buffer size: 0
2025-01-16 06:16:15.041 | Socket (3) | Connecting to IP: 62.209.53.225.
2025-01-16 06:16:15.157 | HD Request # 43 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:15.157 | HD Request # 43 | Sending historical data logon request message.
2025-01-16 06:16:15.180 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:15.180 | Socket (2) | Closed.
2025-01-16 06:16:15.213 | Socket (3) | CloseSocket call.
2025-01-16 06:16:15.213 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:15.270 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:15.270 | Socket (3) | Closed.
2025-01-16 06:16:17.817 | F.US.FGBXH25 [CBV] 250 Volume #20 | Chart data loading complete.
2025-01-16 06:16:17.817 | HD Request # 43 | Error downloading historical Intraday data for F.US.FOATU24. Historical data logon error: Serving data is disabled
2025-01-16 06:16:17.817 | Added historical Intraday data request for F.US.FOATU24 to the queue.
2025-01-16 06:16:17.817 | Triggering next historical data download in queue.
2025-01-16 06:16:17.817 | Historical data download thread signaled to stop.
2025-01-16 06:16:17.817 | HD Request # 43 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FOATU24
2025-01-16 06:16:17.817 | HD Request # 43 | Completion time: 2s.
2025-01-16 06:16:17.820 | HD Request # 44 | Downloading Intraday chart data for F.US.FOATU24 to the file F.US.FOATU24.scid. Service: eurex
2025-01-16 06:16:17.820 | HD Request # 44 | Download start date-time: 2024-09-06 11:29:59.000000. File last date-time: 2024-09-06 11:29:59.003001
2025-01-16 06:16:17.820 | HD Request # 44 | Using server: ds24.sierracharts.com port 10150
2025-01-16 06:16:17.820 | Socket (2) | Creating socket.
2025-01-16 06:16:17.820 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:17.820 | Socket (2) | Connecting to IP: 62.209.53.226.
2025-01-16 06:16:17.823 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FGBXH25. ID: 36
2025-01-16 06:16:17.823 | Symbol Error | F.US.FGBXH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FGBXH25. ID: 36
2025-01-16 06:16:17.835 | F.US.SF6H25 [CBV] 100 Volume #21 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:16:17.835 | F.US.SF6H25 [CBV] 100 Volume #21 | Reloading chart.
2025-01-16 06:16:17.935 | HD Request # 44 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:17.935 | HD Request # 44 | Sending historical data logon request message.
2025-01-16 06:16:17.992 | HD Request # 44 | Requesting Intraday data. Start date-time: 2024-09-06 11:29:59. Record interval: 0. Symbol: FOAT202409_FUT_EUREX
2025-01-16 06:16:18.049 | HD Request # 44 | Decompressing data.
2025-01-16 06:16:18.105 | HD Request # 44 | Receiving Intraday data for F.US.FOATU24 starting at 2024-09-06 11:29:59.003000
2025-01-16 06:16:18.105 | Socket (2) | CloseSocket call.
2025-01-16 06:16:18.105 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:18.116 | Historical data download thread signaled to stop.
2025-01-16 06:16:18.116 | HD Request # 44 | Received 2 Intraday data records from 2024-09-06 11:29:59.003000 to 2024-09-06 11:29:59.003001 (0.0 seconds. Delay: 131.8 days) and wrote 0 records for F.US.FOATU24
2025-01-16 06:16:18.116 | HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2024-09-06 10:29:59.003001
2025-01-16 06:16:18.116 | HD Request # 44 | Completion time: 1s.
2025-01-16 06:16:18.116 | HD Request # 44 | Intraday data download complete for F.US.FOATU24. Unique request ID: 35
2025-01-16 06:16:18.116 | Removing historical data download ID 35.
2025-01-16 06:16:18.116 | Real-time Intraday chart data file updates started for F.US.FOATU24
2025-01-16 06:16:18.116 | Intraday chart data file opened for F.US.FOATU24
2025-01-16 06:16:18.116 | HD Request # 44 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:18.116 | Triggering next historical data download in queue.
2025-01-16 06:16:18.116 | HD Request # 45 | Downloading Intraday chart data for F.US.FOATZ24 to the file F.US.FOATZ24.scid. Service: eurex
2025-01-16 06:16:18.117 | HD Request # 45 | Download start date-time: 2024-12-06 11:29:56.000000. File last date-time: 2024-12-06 11:29:56.778000
2025-01-16 06:16:18.117 | HD Request # 45 | Using server: ds14.sierracharts.com port 10149
2025-01-16 06:16:18.117 | Socket (3) | Creating socket.
2025-01-16 06:16:18.117 | Socket (3) | New receive buffer size: 0
2025-01-16 06:16:18.117 | Socket (3) | Connecting to IP: 176.9.9.252.
2025-01-16 06:16:18.162 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:18.162 | Socket (2) | Closed.
2025-01-16 06:16:18.249 | F.US.SF6H25 [CBV] 100 Volume #21 | Reloading chart.
2025-01-16 06:16:18.255 | HD Request # 45 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:18.255 | HD Request # 45 | Sending historical data logon request message.
2025-01-16 06:16:18.323 | HD Request # 45 | Requesting Intraday data. Start date-time: 2024-12-06 11:29:56. Record interval: 0. Symbol: FOAT202412_FUT_EUREX
2025-01-16 06:16:18.391 | HD Request # 45 | Decompressing data.
2025-01-16 06:16:18.458 | HD Request # 45 | Receiving Intraday data for F.US.FOATZ24 starting at 2024-12-06 11:29:56.642000
2025-01-16 06:16:18.458 | Socket (3) | CloseSocket call.
2025-01-16 06:16:18.458 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:18.526 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:18.526 | Socket (3) | Closed.
2025-01-16 06:16:19.554 | F.US.SF6H25 [CBV] 100 Volume #21 | Chart data loading complete.
2025-01-16 06:16:19.554 | Historical data download thread signaled to stop.
2025-01-16 06:16:19.554 | HD Request # 45 | Received 6 Intraday data records from 2024-12-06 11:29:56.642000 to 2024-12-06 11:29:56.778000 (0.1 seconds. Delay: 40.8 days) and wrote 0 records for F.US.FOATZ24
2025-01-16 06:16:19.554 | HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2024-12-06 11:29:56.778000
2025-01-16 06:16:19.554 | HD Request # 45 | Completion time: 1s.
2025-01-16 06:16:19.554 | HD Request # 45 | Intraday data download complete for F.US.FOATZ24. Unique request ID: 36
2025-01-16 06:16:19.554 | Removing historical data download ID 36.
2025-01-16 06:16:19.554 | Real-time Intraday chart data file updates started for F.US.FOATZ24
2025-01-16 06:16:19.554 | Intraday chart data file opened for F.US.FOATZ24
2025-01-16 06:16:19.554 | HD Request # 45 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:19.554 | Triggering next historical data download in queue.
2025-01-16 06:16:19.556 | HD Request # 46 | Downloading Intraday chart data for F.US.FOATH25 to the file F.US.FOATH25.scid. Service: eurex
2025-01-16 06:16:19.556 | HD Request # 46 | Download start date-time: 2025-01-16 06:00:10.000000. File last date-time: 2025-01-16 06:00:10.039001
2025-01-16 06:16:19.556 | HD Request # 46 | Using server: ds50.sierracharts.com port 10150
2025-01-16 06:16:19.556 | Socket (2) | Creating socket.
2025-01-16 06:16:19.556 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:19.556 | Socket (2) | Connecting to IP: 62.209.53.225.
2025-01-16 06:16:19.672 | HD Request # 46 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:19.672 | HD Request # 46 | Sending historical data logon request message.
2025-01-16 06:16:19.729 | Socket (2) | CloseSocket call.
2025-01-16 06:16:19.729 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:19.736 | HD Request # 46 | Error downloading historical Intraday data for F.US.FOATH25. Historical data logon error: Serving data is disabled
2025-01-16 06:16:19.736 | Added historical Intraday data request for F.US.FOATH25 to the queue.
2025-01-16 06:16:19.736 | Triggering next historical data download in queue.
2025-01-16 06:16:19.736 | Historical data download thread signaled to stop.
2025-01-16 06:16:19.736 | HD Request # 46 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.FOATH25
2025-01-16 06:16:19.736 | HD Request # 46 | Completion time: 0s.
2025-01-16 06:16:19.736 | HD Request # 47 | Downloading Intraday chart data for F.US.FOATH25 to the file F.US.FOATH25.scid. Service: eurex
2025-01-16 06:16:19.736 | HD Request # 47 | Download start date-time: 2025-01-16 06:00:10.000000. File last date-time: 2025-01-16 06:00:10.039001
2025-01-16 06:16:19.736 | HD Request # 47 | Using server: ds24.sierracharts.com port 10149
2025-01-16 06:16:19.736 | Socket (3) | Creating socket.
2025-01-16 06:16:19.736 | Socket (3) | New receive buffer size: 0
2025-01-16 06:16:19.736 | Socket (3) | Connecting to IP: 62.209.53.226.
2025-01-16 06:16:19.786 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:19.786 | Socket (2) | Closed.
2025-01-16 06:16:19.799 | DTC - Sub Instance | Starting real-time market data updates for: F.US.SF6H25. ID: 37 Service code: cqg
2025-01-16 06:16:19.799 | DTC - Sub Instance | Requesting security definition data for: F.US.SF6H25. ID: 37
2025-01-16 06:16:19.810 | DTC - Sub Instance | Setting external service identifier for symbol F.US.SF6H25 to 33558
2025-01-16 06:16:19.810 | DTC - Sub Instance | Received security definition for symbol F.US.SF6H25
2025-01-16 06:16:19.851 | HD Request # 47 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:19.851 | HD Request # 47 | Sending historical data logon request message.
2025-01-16 06:16:19.908 | HD Request # 47 | Requesting Intraday data. Start date-time: 2025-01-16 06:00:10. Record interval: 0. Symbol: FOAT202503_FUT_EUREX
2025-01-16 06:16:19.965 | HD Request # 47 | Decompressing data.
2025-01-16 06:16:20.021 | HD Request # 47 | Receiving Intraday data for F.US.FOATH25 starting at 2025-01-16 06:00:10.039000
2025-01-16 06:16:20.021 | Socket (3) | CloseSocket call.
2025-01-16 06:16:20.022 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:20.022 | Historical data download thread signaled to stop.
2025-01-16 06:16:20.022 | HD Request # 47 | Timestamp of first Intraday data file record written: 2025-01-16 06:03:02.078000.
2025-01-16 06:16:20.022 | HD Request # 47 | Received 37 Intraday data records from 2025-01-16 06:00:10.039000 to 2025-01-16 06:13:08.826000 (13.0 minutes. Delay: 3.2 minutes) and wrote 35 records for F.US.FOATH25
2025-01-16 06:16:20.022 | HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:13:08.826000
2025-01-16 06:16:20.022 | HD Request # 47 | Completion time: 1s.
2025-01-16 06:16:20.022 | HD Request # 47 | Intraday data download complete for F.US.FOATH25. Unique request ID: 37
2025-01-16 06:16:20.022 | Removing historical data download ID 37.
2025-01-16 06:16:20.022 | Real-time Intraday chart data file updates started for F.US.FOATH25
2025-01-16 06:16:20.022 | Intraday chart data file opened for F.US.FOATH25
2025-01-16 06:16:20.022 | HD Request # 47 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:20.022 | Triggering next historical data download in queue.
2025-01-16 06:16:20.023 | HD Request # 48 | Downloading Intraday chart data for F.US.FBTPH25 to the file F.US.FBTPH25.scid. Service: eurex
2025-01-16 06:16:20.023 | HD Request # 48 | Download start date-time: 2025-01-15 17:59:58.000000. File last date-time: 2025-01-15 17:59:58.999000
2025-01-16 06:16:20.023 | HD Request # 48 | Using server: ds14.sierracharts.com port 10150
2025-01-16 06:16:20.023 | Socket (2) | Creating socket.
2025-01-16 06:16:20.023 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:20.023 | Socket (2) | Connecting to IP: 176.9.9.252.
2025-01-16 06:16:20.069 | F.US.FOATH25 [CBV] 250 Volume #22 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:16:20.069 | F.US.FOATH25 [CBV] 250 Volume #22 | Reloading chart.
2025-01-16 06:16:20.078 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:20.078 | Socket (3) | Closed.
2025-01-16 06:16:20.161 | HD Request # 48 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:20.161 | HD Request # 48 | Sending historical data logon request message.
2025-01-16 06:16:20.228 | HD Request # 48 | Requesting Intraday data. Start date-time: 2025-01-15 17:59:58. Record interval: 0. Symbol: FBTP202503_FUT_EUREX
2025-01-16 06:16:20.296 | HD Request # 48 | Decompressing data.
2025-01-16 06:16:20.363 | HD Request # 48 | Receiving Intraday data for F.US.FBTPH25 starting at 2025-01-15 17:59:58.999000
2025-01-16 06:16:20.363 | Socket (2) | CloseSocket call.
2025-01-16 06:16:20.363 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:20.363 | Historical data download thread signaled to stop.
2025-01-16 06:16:20.363 | HD Request # 48 | Received 1 Intraday data record from 2025-01-15 17:59:58.999000 to 2025-01-15 17:59:58.999000 (0.0 seconds. Delay: 12.3 hours) and wrote 0 records for F.US.FBTPH25
2025-01-16 06:16:20.363 | HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2025-01-15 17:59:58.999000
2025-01-16 06:16:20.363 | HD Request # 48 | Completion time: 0s.
2025-01-16 06:16:20.363 | HD Request # 48 | Intraday data download complete for F.US.FBTPH25. Unique request ID: 38
2025-01-16 06:16:20.363 | Removing historical data download ID 38.
2025-01-16 06:16:20.363 | Real-time Intraday chart data file updates started for F.US.FBTPH25
2025-01-16 06:16:20.363 | Intraday chart data file opened for F.US.FBTPH25
2025-01-16 06:16:20.363 | HD Request # 48 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:20.363 | Triggering next historical data download in queue.
2025-01-16 06:16:20.364 | HD Request # 49 | Downloading Intraday chart data for F.US.BTCV24 to the file F.US.BTCV24.scid. Service: cme
2025-01-16 06:16:20.364 | HD Request # 49 | Download start date-time: 2024-10-25 15:59:16.000000. File last date-time: 2024-10-25 15:59:16.184000
2025-01-16 06:16:20.364 | HD Request # 49 | Using server: ds28.sierracharts.com port 10149
2025-01-16 06:16:20.364 | Socket (3) | Creating socket.
2025-01-16 06:16:20.364 | Socket (3) | New receive buffer size: 0
2025-01-16 06:16:20.364 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-16 06:16:20.430 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:20.430 | Socket (2) | Closed.
2025-01-16 06:16:20.480 | F.US.FOATH25 [CBV] 250 Volume #22 | Reloading chart.
2025-01-16 06:16:20.636 | F.US.FBTPH25 [CBV] 250 Volume #23 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:16:20.637 | F.US.FBTPH25 [CBV] 250 Volume #23 | Reloading chart.
2025-01-16 06:16:20.655 | HD Request # 49 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:20.655 | HD Request # 49 | Sending historical data logon request message.
2025-01-16 06:16:20.840 | HD Request # 49 | Requesting Intraday data. Start date-time: 2024-10-25 15:59:16. Record interval: 0. Symbol: BTCV24
2025-01-16 06:16:20.894 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FOATH25. ID: 40
2025-01-16 06:16:20.894 | Symbol Error | F.US.FOATH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FOATH25. ID: 40
2025-01-16 06:16:20.983 | HD Request # 49 | Decompressing data.
2025-01-16 06:16:21.038 | F.US.FBTPH25 [CBV] 250 Volume #23 | Reloading chart.
2025-01-16 06:16:21.125 | HD Request # 49 | Receiving Intraday data for F.US.BTCV24 starting at 2024-10-25 15:59:16.184000
2025-01-16 06:16:21.125 | Socket (3) | CloseSocket call.
2025-01-16 06:16:21.125 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:21.267 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:21.267 | Socket (3) | Closed.
2025-01-16 06:16:25.590 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.SF6H25.scid. Thread ID: 24244
2025-01-16 06:16:29.913 | F.US.FOATH25 [CBV] 250 Volume #22 | Chart data loading complete.
2025-01-16 06:16:29.913 | Historical data download thread signaled to stop.
2025-01-16 06:16:29.913 | HD Request # 49 | Received 1 Intraday data record from 2024-10-25 15:59:16.184000 to 2024-10-25 15:59:16.184000 (0.0 seconds. Delay: 82.6 days) and wrote 0 records for F.US.BTCV24
2025-01-16 06:16:29.914 | HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2024-10-25 14:59:16.184000
2025-01-16 06:16:29.914 | HD Request # 49 | Completion time: 9s.
2025-01-16 06:16:29.914 | HD Request # 49 | Intraday data download complete for F.US.BTCV24. Unique request ID: 39
2025-01-16 06:16:29.914 | Removing historical data download ID 39.
2025-01-16 06:16:29.914 | Real-time Intraday chart data file updates started for F.US.BTCV24
2025-01-16 06:16:29.914 | Intraday chart data file opened for F.US.BTCV24
2025-01-16 06:16:29.914 | HD Request # 49 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:29.914 | Triggering next historical data download in queue.
2025-01-16 06:16:47.173 | F.US.FBTPH25 [CBV] 250 Volume #23 | Chart data loading complete.
2025-01-16 06:16:47.180 | HD Request # 50 | Downloading Intraday chart data for F.US.BTCF25 to the file F.US.BTCF25.scid. Service: cme
2025-01-16 06:16:47.180 | HD Request # 50 | Download start date-time: 2025-01-16 06:02:30.000000. File last date-time: 2025-01-16 06:02:30.154000
2025-01-16 06:16:47.180 | HD Request # 50 | Using server: ds32.sierracharts.com port 10150
2025-01-16 06:16:47.180 | Socket (2) | Creating socket.
2025-01-16 06:16:47.180 | Socket (2) | New receive buffer size: 0
2025-01-16 06:16:47.180 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-16 06:16:47.450 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FBTPH25. ID: 41
2025-01-16 06:16:47.450 | Symbol Error | F.US.FBTPH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.FBTPH25. ID: 41
2025-01-16 06:16:47.474 | HD Request # 50 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:47.474 | HD Request # 50 | Sending historical data logon request message.
2025-01-16 06:16:47.665 | HD Request # 50 | Requesting Intraday data. Start date-time: 2025-01-16 06:02:30. Record interval: 0. Symbol: BTCF25
2025-01-16 06:16:47.809 | HD Request # 50 | Decompressing data.
2025-01-16 06:16:47.950 | HD Request # 50 | Receiving Intraday data for F.US.BTCF25 starting at 2025-01-16 06:02:30.153000
2025-01-16 06:16:47.951 | Socket (2) | CloseSocket call.
2025-01-16 06:16:47.951 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:47.951 | Historical data download thread signaled to stop.
2025-01-16 06:16:47.951 | HD Request # 50 | Timestamp of first Intraday data file record written: 2025-01-16 06:02:54.326000.
2025-01-16 06:16:47.951 | HD Request # 50 | Received 6 Intraday data records from 2025-01-16 06:02:30.153000 to 2025-01-16 06:13:50.599000 (11.3 minutes. Delay: 3.0 minutes) and wrote 4 records for F.US.BTCF25
2025-01-16 06:16:47.951 | HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:13:50.599000
2025-01-16 06:16:47.951 | HD Request # 50 | Completion time: 0s.
2025-01-16 06:16:47.951 | HD Request # 50 | Intraday data download complete for F.US.BTCF25. Unique request ID: 40
2025-01-16 06:16:47.951 | Removing historical data download ID 40.
2025-01-16 06:16:47.951 | Real-time Intraday chart data file updates started for F.US.BTCF25
2025-01-16 06:16:47.951 | Intraday chart data file opened for F.US.BTCF25
2025-01-16 06:16:47.951 | HD Request # 50 | Enabling Intraday chart updating for symbol.
2025-01-16 06:16:47.951 | Triggering next historical data download in queue.
2025-01-16 06:16:47.951 | HD Request # 51 | Downloading Intraday chart data for F.US.MX6H25 to the file F.US.MX6H25.scid. Service: cme
2025-01-16 06:16:47.952 | HD Request # 51 | Download start date-time: 2025-01-16 06:01:57.000000. File last date-time: 2025-01-16 06:01:57.200003
2025-01-16 06:16:47.952 | HD Request # 51 | Using server: ds26.sierracharts.com port 10149
2025-01-16 06:16:47.952 | Socket (3) | Creating socket.
2025-01-16 06:16:47.952 | Socket (3) | New receive buffer size: 0
2025-01-16 06:16:47.952 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-16 06:16:48.093 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:16:48.093 | Socket (2) | Closed.
2025-01-16 06:16:48.237 | HD Request # 51 | Setting DTC encoding to Binary VLS
2025-01-16 06:16:48.237 | HD Request # 51 | Sending historical data logon request message.
2025-01-16 06:16:48.286 | F.US.BTCF25 [CBV] 1 Min #24 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:16:48.286 | F.US.BTCF25 [CBV] 1 Min #24 | Reloading chart.
2025-01-16 06:16:48.423 | HD Request # 51 | Requesting Intraday data. Start date-time: 2025-01-16 06:01:57. Record interval: 0. Symbol: 6MH25
2025-01-16 06:16:48.563 | HD Request # 51 | Decompressing data.
2025-01-16 06:16:48.701 | HD Request # 51 | Receiving Intraday data for F.US.MX6H25 starting at 2025-01-16 06:01:57.200000
2025-01-16 06:16:48.702 | Socket (3) | CloseSocket call.
2025-01-16 06:16:48.702 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:16:48.842 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:16:48.842 | Socket (3) | Closed.
2025-01-16 06:17:04.943 | F.US.BTCF25 [CBV] 1 Min #24 | Chart data loading complete.
2025-01-16 06:17:04.943 | Historical data download thread signaled to stop.
2025-01-16 06:17:04.943 | HD Request # 51 | Timestamp of first Intraday data file record written: 2025-01-16 06:06:02.748000.
2025-01-16 06:17:04.943 | HD Request # 51 | Received 12 Intraday data records from 2025-01-16 06:01:57.200000 to 2025-01-16 06:13:55.541006 (12.0 minutes. Delay: 3.2 minutes) and wrote 8 records for F.US.MX6H25
2025-01-16 06:17:04.943 | HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:13:55.541006
2025-01-16 06:17:04.943 | HD Request # 51 | Completion time: 17s.
2025-01-16 06:17:04.943 | HD Request # 51 | Intraday data download complete for F.US.MX6H25. Unique request ID: 41
2025-01-16 06:17:04.943 | Removing historical data download ID 41.
2025-01-16 06:17:04.943 | Real-time Intraday chart data file updates started for F.US.MX6H25
2025-01-16 06:17:04.943 | Intraday chart data file opened for F.US.MX6H25
2025-01-16 06:17:04.943 | HD Request # 51 | Enabling Intraday chart updating for symbol.
2025-01-16 06:17:04.943 | Triggering next historical data download in queue.
2025-01-16 06:17:04.957 | HD Request # 52 | Downloading Intraday chart data for F.US.CA6H25 to the file F.US.CA6H25.scid. Service: cme
2025-01-16 06:17:04.957 | HD Request # 52 | Download start date-time: 2025-01-16 06:03:12.000000. File last date-time: 2025-01-16 06:03:12.495001
2025-01-16 06:17:04.957 | HD Request # 52 | Using server: ds28.sierracharts.com port 10150
2025-01-16 06:17:04.957 | Socket (2) | Creating socket.
2025-01-16 06:17:04.957 | Socket (2) | New receive buffer size: 0
2025-01-16 06:17:04.957 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-16 06:17:05.069 | F.US.MX6H25 [CBV] 100 Volume #26 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:17:05.069 | F.US.MX6H25 [CBV] 100 Volume #26 | Reloading chart.
2025-01-16 06:17:05.129 | F.US.BTCF25 [CBV] 1 Min #24 | Reloading chart.
2025-01-16 06:17:05.249 | HD Request # 52 | Setting DTC encoding to Binary VLS
2025-01-16 06:17:05.249 | HD Request # 52 | Sending historical data logon request message.
2025-01-16 06:17:05.439 | HD Request # 52 | Requesting Intraday data. Start date-time: 2025-01-16 06:03:12. Record interval: 0. Symbol: 6CH25
2025-01-16 06:17:05.581 | HD Request # 52 | Decompressing data.
2025-01-16 06:17:05.724 | HD Request # 52 | Receiving Intraday data for F.US.CA6H25 starting at 2025-01-16 06:03:12.495000
2025-01-16 06:17:05.724 | Socket (2) | CloseSocket call.
2025-01-16 06:17:05.724 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:17:05.867 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:17:05.867 | Socket (2) | Closed.
2025-01-16 06:17:10.037 | F.US.MX6H25 [CBV] 100 Volume #26 | Chart data loading complete.
2025-01-16 06:17:26.234 | F.US.BTCF25 [CBV] 1 Min #24 | Chart data loading complete.
2025-01-16 06:17:26.234 | Historical data download thread signaled to stop.
2025-01-16 06:17:26.234 | HD Request # 52 | Timestamp of first Intraday data file record written: 2025-01-16 06:03:40.061000.
2025-01-16 06:17:26.234 | HD Request # 52 | Received 77 Intraday data records from 2025-01-16 06:03:12.495000 to 2025-01-16 06:16:15.410000 (13.0 minutes. Delay: 70.8 seconds) and wrote 75 records for F.US.CA6H25
2025-01-16 06:17:26.234 | HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:16:15.410000
2025-01-16 06:17:26.234 | HD Request # 52 | Completion time: 22s.
2025-01-16 06:17:26.234 | HD Request # 52 | Intraday data download complete for F.US.CA6H25. Unique request ID: 42
2025-01-16 06:17:26.234 | Removing historical data download ID 42.
2025-01-16 06:17:26.234 | Real-time Intraday chart data file updates started for F.US.CA6H25
2025-01-16 06:17:26.234 | Intraday chart data file opened for F.US.CA6H25
2025-01-16 06:17:26.234 | HD Request # 52 | Enabling Intraday chart updating for symbol.
2025-01-16 06:17:26.234 | Triggering next historical data download in queue.
2025-01-16 06:17:26.247 | HD Request # 53 | Downloading Intraday chart data for F.US.RTYH25 to the file F.US.RTYH25.scid. Service: cme
2025-01-16 06:17:26.247 | HD Request # 53 | Download start date-time: 2025-01-16 06:04:27.000000. File last date-time: 2025-01-16 06:04:27.876000
2025-01-16 06:17:26.247 | HD Request # 53 | Using server: ds32.sierracharts.com port 10149
2025-01-16 06:17:26.247 | Socket (2) | Creating socket.
2025-01-16 06:17:26.247 | Socket (2) | New receive buffer size: 0
2025-01-16 06:17:26.247 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-16 06:17:26.285 | F.US.MX6H25 [CBV] 100 Volume #26 | Reloading chart.
2025-01-16 06:17:26.344 | DTC - Sub Instance | Starting real-time market data updates for: F.US.BTCF25. ID: 43 Service code: cqg
2025-01-16 06:17:26.344 | DTC - Sub Instance | Requesting security definition data for: F.US.BTCF25. ID: 43
2025-01-16 06:17:26.357 | DTC - Sub Instance | Setting external service identifier for symbol F.US.BTCF25 to 42004339
2025-01-16 06:17:26.357 | DTC - Sub Instance | Received security definition for symbol F.US.BTCF25
2025-01-16 06:17:26.357 | F.US.CA6H25 [CBV] 100 Volume #27 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:17:26.358 | F.US.CA6H25 [CBV] 100 Volume #27 | Reloading chart.
2025-01-16 06:17:26.551 | HD Request # 53 | Setting DTC encoding to Binary VLS
2025-01-16 06:17:26.551 | HD Request # 53 | Sending historical data logon request message.
2025-01-16 06:17:26.694 | DTC - Sub Instance | Starting real-time market data updates for: F.US.MX6H25. ID: 44 Service code: cqg
2025-01-16 06:17:26.694 | DTC - Sub Instance | Requesting security definition data for: F.US.MX6H25. ID: 44
2025-01-16 06:17:26.699 | DTC - Sub Instance | Setting external service identifier for symbol F.US.MX6H25 to 42007011
2025-01-16 06:17:26.699 | DTC - Sub Instance | Received security definition for symbol F.US.MX6H25
2025-01-16 06:17:26.739 | HD Request # 53 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:27. Record interval: 0. Symbol: RTYH25
2025-01-16 06:17:26.887 | HD Request # 53 | Decompressing data.
2025-01-16 06:17:27.034 | HD Request # 53 | Receiving Intraday data for F.US.RTYH25 starting at 2025-01-16 06:04:27.876000
2025-01-16 06:17:27.034 | Socket (2) | CloseSocket call.
2025-01-16 06:17:27.034 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:17:27.182 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:17:27.182 | Socket (2) | Closed.
2025-01-16 06:17:31.312 | F.US.MX6H25 [CBV] 100 Volume #26 | Chart data loading complete.
2025-01-16 06:17:31.314 | Historical data download thread signaled to stop.
2025-01-16 06:17:31.314 | HD Request # 53 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:56.643000.
2025-01-16 06:17:31.314 | HD Request # 53 | Received 186 Intraday data records from 2025-01-16 06:04:27.876000 to 2025-01-16 06:16:54.071000 (12.4 minutes. Delay: 37.2 seconds) and wrote 185 records for F.US.RTYH25
2025-01-16 06:17:31.315 | HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:16:54.071000
2025-01-16 06:17:31.315 | HD Request # 53 | Completion time: 5s.
2025-01-16 06:17:31.315 | HD Request # 53 | Intraday data download complete for F.US.RTYH25. Unique request ID: 43
2025-01-16 06:17:31.315 | Removing historical data download ID 43.
2025-01-16 06:17:31.315 | Real-time Intraday chart data file updates started for F.US.RTYH25
2025-01-16 06:17:31.315 | Intraday chart data file opened for F.US.RTYH25
2025-01-16 06:17:31.315 | HD Request # 53 | Enabling Intraday chart updating for symbol.
2025-01-16 06:17:31.315 | Triggering next historical data download in queue.
2025-01-16 06:17:41.523 | F.US.CA6H25 [CBV] 100 Volume #27 | Chart data loading complete.
2025-01-16 06:17:41.526 | HD Request # 54 | Downloading Intraday chart data for F.US.YMH25 to the file F.US.YMH25.scid. Service: cbot
2025-01-16 06:17:41.526 | HD Request # 54 | Download start date-time: 2025-01-16 06:04:01.000000. File last date-time: 2025-01-16 06:04:01.349000
2025-01-16 06:17:41.526 | HD Request # 54 | Using server: ds26.sierracharts.com port 10150
2025-01-16 06:17:41.526 | Socket (2) | Creating socket.
2025-01-16 06:17:41.526 | Socket (2) | New receive buffer size: 0
2025-01-16 06:17:41.526 | Socket (2) | Connecting to IP: 64.152.155.17.
2025-01-16 06:17:41.585 | F.US.CA6H25 [CBV] 100 Volume #27 | Reloading chart.
2025-01-16 06:17:41.816 | HD Request # 54 | Setting DTC encoding to Binary VLS
2025-01-16 06:17:41.816 | HD Request # 54 | Sending historical data logon request message.
2025-01-16 06:17:41.873 | F.US.RTYH25 [CBV] 200 Volume #28 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:17:41.873 | F.US.RTYH25 [CBV] 200 Volume #28 | Reloading chart.
2025-01-16 06:17:41.993 | DTC - Sub Instance | Starting real-time market data updates for: F.US.CA6H25. ID: 45 Service code: cqg
2025-01-16 06:17:41.993 | DTC - Sub Instance | Requesting security definition data for: F.US.CA6H25. ID: 45
2025-01-16 06:17:41.994 | DTC - Sub Instance | Setting external service identifier for symbol F.US.CA6H25 to 45908
2025-01-16 06:17:41.994 | DTC - Sub Instance | Received security definition for symbol F.US.CA6H25
2025-01-16 06:17:42.000 | HD Request # 54 | Requesting Intraday data. Start date-time: 2025-01-16 06:04:01. Record interval: 0. Symbol: YMH25
2025-01-16 06:17:42.141 | HD Request # 54 | Decompressing data.
2025-01-16 06:17:42.283 | HD Request # 54 | Receiving Intraday data for F.US.YMH25 starting at 2025-01-16 06:04:01.349000
2025-01-16 06:17:42.283 | Socket (2) | CloseSocket call.
2025-01-16 06:17:42.283 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:17:42.423 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:17:42.423 | Socket (2) | Closed.
2025-01-16 06:17:52.998 | F.US.CA6H25 [CBV] 100 Volume #27 | Chart data loading complete.
2025-01-16 06:17:52.998 | Historical data download thread signaled to stop.
2025-01-16 06:17:52.998 | HD Request # 54 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:05.485000.
2025-01-16 06:17:52.998 | HD Request # 54 | Received 347 Intraday data records from 2025-01-16 06:04:01.349000 to 2025-01-16 06:17:38.253001 (13.6 minutes. Delay: 14.7 seconds) and wrote 346 records for F.US.YMH25
2025-01-16 06:17:52.999 | HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:17:38.253001
2025-01-16 06:17:52.999 | HD Request # 54 | Completion time: 11s.
2025-01-16 06:17:52.999 | HD Request # 54 | Intraday data download complete for F.US.YMH25. Unique request ID: 44
2025-01-16 06:17:52.999 | Removing historical data download ID 44.
2025-01-16 06:17:52.999 | Real-time Intraday chart data file updates started for F.US.YMH25
2025-01-16 06:17:52.999 | Intraday chart data file opened for F.US.YMH25
2025-01-16 06:17:52.999 | HD Request # 54 | Enabling Intraday chart updating for symbol.
2025-01-16 06:17:52.999 | Triggering next historical data download in queue.
2025-01-16 06:17:53.006 | F.US.RTYH25 [CBV] 200 Volume #28 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:18:03.708 | F.US.RTYH25 [CBV] 200 Volume #28 | Chart data loading complete.
2025-01-16 06:18:03.715 | HD Request # 55 | Downloading Intraday chart data for F.US.NKDH25 to the file F.US.NKDH25.scid. Service: cme
2025-01-16 06:18:03.715 | HD Request # 55 | Download start date-time: 2025-01-16 06:03:33.000000. File last date-time: 2025-01-16 06:03:33.179000
2025-01-16 06:18:03.715 | HD Request # 55 | Using server: ds28.sierracharts.com port 10149
2025-01-16 06:18:03.715 | Socket (2) | Creating socket.
2025-01-16 06:18:03.715 | Socket (2) | New receive buffer size: 0
2025-01-16 06:18:03.715 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-16 06:18:04.008 | HD Request # 55 | Setting DTC encoding to Binary VLS
2025-01-16 06:18:04.008 | HD Request # 55 | Sending historical data logon request message.
2025-01-16 06:18:04.193 | HD Request # 55 | Requesting Intraday data. Start date-time: 2025-01-16 06:03:33. Record interval: 0. Symbol: NKDH25
2025-01-16 06:18:04.336 | HD Request # 55 | Decompressing data.
2025-01-16 06:18:04.479 | HD Request # 55 | Receiving Intraday data for F.US.NKDH25 starting at 2025-01-16 06:03:33.179000
2025-01-16 06:18:04.479 | Socket (2) | CloseSocket call.
2025-01-16 06:18:04.479 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:18:04.622 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:18:04.622 | Socket (2) | Closed.
2025-01-16 06:18:14.351 | Historical data download thread signaled to stop.
2025-01-16 06:18:14.351 | HD Request # 55 | Timestamp of first Intraday data file record written: 2025-01-16 06:04:05.481000.
2025-01-16 06:18:14.351 | HD Request # 55 | Received 166 Intraday data records from 2025-01-16 06:03:33.179000 to 2025-01-16 06:17:56.186000 (14.4 minutes. Delay: 18.2 seconds) and wrote 165 records for F.US.NKDH25
2025-01-16 06:18:14.351 | HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:17:56.186000
2025-01-16 06:18:14.351 | HD Request # 55 | Completion time: 11s.
2025-01-16 06:18:14.351 | HD Request # 55 | Intraday data download complete for F.US.NKDH25. Unique request ID: 45
2025-01-16 06:18:14.351 | Removing historical data download ID 45.
2025-01-16 06:18:14.351 | Real-time Intraday chart data file updates started for F.US.NKDH25
2025-01-16 06:18:14.351 | Intraday chart data file opened for F.US.NKDH25
2025-01-16 06:18:14.351 | HD Request # 55 | Enabling Intraday chart updating for symbol.
2025-01-16 06:18:14.351 | Triggering next historical data download in queue.
2025-01-16 06:18:14.359 | HD Request # 56 | Downloading Intraday chart data for F.US.BR6N24 to the file F.US.BR6N24.scid. Service: cme
2025-01-16 06:18:14.359 | HD Request # 56 | Download start date-time: 2024-06-28 15:06:59.000000. File last date-time: 2024-06-28 15:06:59.844000
2025-01-16 06:18:14.359 | HD Request # 56 | Using server: ds32.sierracharts.com port 10150
2025-01-16 06:18:14.359 | Socket (2) | Creating socket.
2025-01-16 06:18:14.359 | Socket (2) | New receive buffer size: 0
2025-01-16 06:18:14.359 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-16 06:18:14.368 | F.US.RTYH25 [CBV] 200 Volume #28 | Reloading chart.
2025-01-16 06:18:14.457 | F.US.NKDH25 [CBV] 25 Volume #32 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:18:14.457 | F.US.NKDH25 [CBV] 25 Volume #32 | Reloading chart.
2025-01-16 06:18:14.652 | HD Request # 56 | Setting DTC encoding to Binary VLS
2025-01-16 06:18:14.652 | HD Request # 56 | Sending historical data logon request message.
2025-01-16 06:18:14.700 | F.US.YMH25 [CBV] 200 Volume #29 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:18:14.700 | F.US.YMH25 [CBV] 200 Volume #29 | Reloading chart.
2025-01-16 06:18:14.716 | F.US.NKDH25 [CBV] 25 Volume #32 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:18:14.843 | HD Request # 56 | Requesting Intraday data. Start date-time: 2024-06-28 15:06:59. Record interval: 0. Symbol: 6LN24
2025-01-16 06:18:14.987 | HD Request # 56 | Decompressing data.
2025-01-16 06:18:15.129 | HD Request # 56 | Receiving Intraday data for F.US.BR6N24 starting at 2024-06-28 15:06:59.842000
2025-01-16 06:18:15.130 | Socket (2) | CloseSocket call.
2025-01-16 06:18:15.130 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:18:15.273 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:18:15.273 | Socket (2) | Closed.
2025-01-16 06:18:17.110 | F.US.NKDH25 [CBV] 25 Volume #32 | Chart data loading complete.
2025-01-16 06:18:19.053 | Historical data download thread signaled to stop.
2025-01-16 06:18:19.053 | HD Request # 56 | Received 5 Intraday data records from 2024-06-28 15:06:59.842000 to 2024-06-28 15:06:59.844000 (0.0 seconds. Delay: 201.7 days) and wrote 0 records for F.US.BR6N24
2025-01-16 06:18:19.053 | HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2024-06-28 14:06:59.844000
2025-01-16 06:18:19.053 | HD Request # 56 | Completion time: 5s.
2025-01-16 06:18:19.053 | HD Request # 56 | Intraday data download complete for F.US.BR6N24. Unique request ID: 46
2025-01-16 06:18:19.053 | Removing historical data download ID 46.
2025-01-16 06:18:19.053 | Real-time Intraday chart data file updates started for F.US.BR6N24
2025-01-16 06:18:19.053 | Intraday chart data file opened for F.US.BR6N24
2025-01-16 06:18:19.053 | HD Request # 56 | Enabling Intraday chart updating for symbol.
2025-01-16 06:18:19.053 | Triggering next historical data download in queue.
2025-01-16 06:18:19.070 | F.US.YMH25 [CBV] 200 Volume #29 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:18:24.601 | F.US.YMH25 [CBV] 200 Volume #29 | Chart data loading complete.
2025-01-16 06:18:24.613 | F.US.RTYH25 [CBV] 200 Volume #28 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:18:31.536 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.CA6H25.scid. Thread ID: 24244
2025-01-16 06:18:34.860 | F.US.RTYH25 [CBV] 200 Volume #28 | Chart data loading complete.
2025-01-16 06:18:34.863 | HD Request # 57 | Downloading Intraday chart data for F.US.BR6Q24 to the file F.US.BR6Q24.scid. Service: cme
2025-01-16 06:18:34.863 | HD Request # 57 | Download start date-time: 2024-07-31 14:59:34.000000. File last date-time: 2024-07-31 14:59:34.351000
2025-01-16 06:18:34.863 | HD Request # 57 | Using server: ds26.sierracharts.com port 10149
2025-01-16 06:18:34.864 | Socket (3) | Creating socket.
2025-01-16 06:18:34.864 | Socket (3) | New receive buffer size: 0
2025-01-16 06:18:34.864 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-16 06:18:35.151 | HD Request # 57 | Setting DTC encoding to Binary VLS
2025-01-16 06:18:35.151 | HD Request # 57 | Sending historical data logon request message.
2025-01-16 06:18:35.336 | HD Request # 57 | Requesting Intraday data. Start date-time: 2024-07-31 14:59:34. Record interval: 0. Symbol: 6LQ24
2025-01-16 06:18:35.477 | HD Request # 57 | Decompressing data.
2025-01-16 06:18:35.616 | HD Request # 57 | Receiving Intraday data for F.US.BR6Q24 starting at 2024-07-31 14:59:34.351000
2025-01-16 06:18:35.616 | Socket (3) | CloseSocket call.
2025-01-16 06:18:35.616 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:18:35.757 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:18:35.757 | Socket (3) | Closed.
2025-01-16 06:18:50.747 | Historical data download thread signaled to stop.
2025-01-16 06:18:50.748 | HD Request # 57 | Received 1 Intraday data record from 2024-07-31 14:59:34.351000 to 2024-07-31 14:59:34.351000 (0.0 seconds. Delay: 168.7 days) and wrote 0 records for F.US.BR6Q24
2025-01-16 06:18:50.748 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2024-07-31 13:59:34.351000
2025-01-16 06:18:50.748 | HD Request # 57 | Completion time: 16s.
2025-01-16 06:18:50.748 | HD Request # 57 | Intraday data download complete for F.US.BR6Q24. Unique request ID: 47
2025-01-16 06:18:50.748 | Removing historical data download ID 47.
2025-01-16 06:18:50.748 | Real-time Intraday chart data file updates started for F.US.BR6Q24
2025-01-16 06:18:50.748 | Intraday chart data file opened for F.US.BR6Q24
2025-01-16 06:18:50.748 | HD Request # 57 | Enabling Intraday chart updating for symbol.
2025-01-16 06:18:50.748 | Triggering next historical data download in queue.
2025-01-16 06:18:50.760 | HD Request # 58 | Downloading Intraday chart data for F.US.BR6U24 to the file F.US.BR6U24.scid. Service: cme
2025-01-16 06:18:50.760 | HD Request # 58 | Download start date-time: 2024-08-30 15:11:14.000000. File last date-time: 2024-08-30 15:11:14.508000
2025-01-16 06:18:50.760 | HD Request # 58 | Using server: ds28.sierracharts.com port 10150
2025-01-16 06:18:50.760 | Socket (3) | Creating socket.
2025-01-16 06:18:50.760 | Socket (3) | New receive buffer size: 0
2025-01-16 06:18:50.760 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-16 06:18:50.894 | DTC - Sub Instance | Starting real-time market data updates for: F.US.RTYH25. ID: 46 Service code: cqg
2025-01-16 06:18:50.894 | DTC - Sub Instance | Requesting security definition data for: F.US.RTYH25. ID: 46
2025-01-16 06:18:50.905 | F.US.NKDH25 [CBV] 25 Volume #32 | Reloading chart.
2025-01-16 06:18:50.998 | DTC - Sub Instance | Setting external service identifier for symbol F.US.RTYH25 to 42001620
2025-01-16 06:18:50.998 | DTC - Sub Instance | Received security definition for symbol F.US.RTYH25
2025-01-16 06:18:51.050 | HD Request # 58 | Setting DTC encoding to Binary VLS
2025-01-16 06:18:51.050 | HD Request # 58 | Sending historical data logon request message.
2025-01-16 06:18:51.149 | F.US.YMH25 [CBV] 200 Volume #29 | Reloading chart.
2025-01-16 06:18:51.187 | F.US.NKDH25 [CBV] 25 Volume #32 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:18:51.241 | HD Request # 58 | Requesting Intraday data. Start date-time: 2024-08-30 15:11:14. Record interval: 0. Symbol: 6LU24
2025-01-16 06:18:51.384 | HD Request # 58 | Decompressing data.
2025-01-16 06:18:51.526 | HD Request # 58 | Receiving Intraday data for F.US.BR6U24 starting at 2024-08-30 15:11:14.508000
2025-01-16 06:18:51.526 | Socket (3) | CloseSocket call.
2025-01-16 06:18:51.526 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:18:51.669 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:18:51.669 | Socket (3) | Closed.
2025-01-16 06:18:53.506 | F.US.NKDH25 [CBV] 25 Volume #32 | Chart data loading complete.
2025-01-16 06:18:55.371 | Historical data download thread signaled to stop.
2025-01-16 06:18:55.371 | HD Request # 58 | Received 1 Intraday data record from 2024-08-30 15:11:14.508000 to 2024-08-30 15:11:14.508000 (0.0 seconds. Delay: 138.7 days) and wrote 0 records for F.US.BR6U24
2025-01-16 06:18:55.371 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2024-08-30 14:11:14.508000
2025-01-16 06:18:55.371 | HD Request # 58 | Completion time: 5s.
2025-01-16 06:18:55.371 | HD Request # 58 | Intraday data download complete for F.US.BR6U24. Unique request ID: 48
2025-01-16 06:18:55.371 | Removing historical data download ID 48.
2025-01-16 06:18:55.371 | Real-time Intraday chart data file updates started for F.US.BR6U24
2025-01-16 06:18:55.371 | Intraday chart data file opened for F.US.BR6U24
2025-01-16 06:18:55.371 | HD Request # 58 | Enabling Intraday chart updating for symbol.
2025-01-16 06:18:55.371 | Triggering next historical data download in queue.
2025-01-16 06:18:55.384 | F.US.YMH25 [CBV] 200 Volume #29 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:19:00.942 | F.US.YMH25 [CBV] 200 Volume #29 | Chart data loading complete.
2025-01-16 06:19:00.946 | HD Request # 59 | Downloading Intraday chart data for F.US.BR6V24 to the file F.US.BR6V24.scid. Service: cme
2025-01-16 06:19:00.947 | HD Request # 59 | Download start date-time: 2024-09-30 15:06:58.000000. File last date-time: 2024-09-30 15:06:58.758000
2025-01-16 06:19:00.947 | HD Request # 59 | Using server: ds32.sierracharts.com port 10149
2025-01-16 06:19:00.947 | Socket (3) | Creating socket.
2025-01-16 06:19:00.947 | Socket (3) | New receive buffer size: 0
2025-01-16 06:19:00.947 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-16 06:19:01.239 | HD Request # 59 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:01.239 | HD Request # 59 | Sending historical data logon request message.
2025-01-16 06:19:01.429 | HD Request # 59 | Requesting Intraday data. Start date-time: 2024-09-30 15:06:58. Record interval: 0. Symbol: 6LV24
2025-01-16 06:19:01.572 | HD Request # 59 | Decompressing data.
2025-01-16 06:19:01.714 | HD Request # 59 | Receiving Intraday data for F.US.BR6V24 starting at 2024-09-30 15:06:58.758000
2025-01-16 06:19:01.714 | Socket (3) | CloseSocket call.
2025-01-16 06:19:01.714 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:01.765 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.RTYH25.scid. Thread ID: 24244
2025-01-16 06:19:01.856 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:19:01.856 | Socket (3) | Closed.
2025-01-16 06:19:06.722 | Historical data download thread signaled to stop.
2025-01-16 06:19:06.722 | HD Request # 59 | Received 1 Intraday data record from 2024-09-30 15:06:58.758000 to 2024-09-30 15:06:58.758000 (0.0 seconds. Delay: 107.7 days) and wrote 0 records for F.US.BR6V24
2025-01-16 06:19:06.722 | HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2024-09-30 14:06:58.758000
2025-01-16 06:19:06.722 | HD Request # 59 | Completion time: 6s.
2025-01-16 06:19:06.722 | HD Request # 59 | Intraday data download complete for F.US.BR6V24. Unique request ID: 49
2025-01-16 06:19:06.722 | Removing historical data download ID 49.
2025-01-16 06:19:06.722 | Real-time Intraday chart data file updates started for F.US.BR6V24
2025-01-16 06:19:06.722 | Intraday chart data file opened for F.US.BR6V24
2025-01-16 06:19:06.722 | HD Request # 59 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:06.722 | Triggering next historical data download in queue.
2025-01-16 06:19:06.727 | HD Request # 60 | Downloading Intraday chart data for F.US.BR6X24 to the file F.US.BR6X24.scid. Service: cme
2025-01-16 06:19:06.727 | HD Request # 60 | Download start date-time: 2024-10-31 14:14:15.000000. File last date-time: 2024-10-31 14:14:15.624000
2025-01-16 06:19:06.727 | HD Request # 60 | Using server: ds26.sierracharts.com port 10150
2025-01-16 06:19:06.727 | Socket (3) | Creating socket.
2025-01-16 06:19:06.727 | Socket (3) | New receive buffer size: 0
2025-01-16 06:19:06.727 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-16 06:19:06.962 | DTC - Sub Instance | Starting real-time market data updates for: F.US.NKDH25. ID: 48 Service code: cqg
2025-01-16 06:19:06.962 | DTC - Sub Instance | Requesting security definition data for: F.US.NKDH25. ID: 48
2025-01-16 06:19:06.973 | DTC - Sub Instance | Setting external service identifier for symbol F.US.NKDH25 to 65
2025-01-16 06:19:06.973 | DTC - Sub Instance | Received security definition for symbol F.US.NKDH25
2025-01-16 06:19:06.992 | DTC - Sub Instance | Starting real-time market data updates for: F.US.YMH25. ID: 47 Service code: cqg
2025-01-16 06:19:06.992 | DTC - Sub Instance | Requesting security definition data for: F.US.YMH25. ID: 47
2025-01-16 06:19:07.002 | DTC - Sub Instance | Setting external service identifier for symbol F.US.YMH25 to 42002868
2025-01-16 06:19:07.002 | DTC - Sub Instance | Received security definition for symbol F.US.YMH25
2025-01-16 06:19:07.015 | HD Request # 60 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:07.015 | HD Request # 60 | Sending historical data logon request message.
2025-01-16 06:19:07.197 | HD Request # 60 | Requesting Intraday data. Start date-time: 2024-10-31 14:14:15. Record interval: 0. Symbol: 6LX24
2025-01-16 06:19:07.337 | HD Request # 60 | Decompressing data.
2025-01-16 06:19:07.476 | HD Request # 60 | Receiving Intraday data for F.US.BR6X24 starting at 2024-10-31 14:14:15.624000
2025-01-16 06:19:07.476 | Socket (3) | CloseSocket call.
2025-01-16 06:19:07.476 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:07.476 | Historical data download thread signaled to stop.
2025-01-16 06:19:07.476 | HD Request # 60 | Received 1 Intraday data record from 2024-10-31 14:14:15.624000 to 2024-10-31 14:14:15.624000 (0.0 seconds. Delay: 76.7 days) and wrote 0 records for F.US.BR6X24
2025-01-16 06:19:07.476 | HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2024-10-31 14:14:15.624000
2025-01-16 06:19:07.476 | HD Request # 60 | Completion time: 1s.
2025-01-16 06:19:07.476 | HD Request # 60 | Intraday data download complete for F.US.BR6X24. Unique request ID: 50
2025-01-16 06:19:07.476 | Removing historical data download ID 50.
2025-01-16 06:19:07.476 | Real-time Intraday chart data file updates started for F.US.BR6X24
2025-01-16 06:19:07.476 | Intraday chart data file opened for F.US.BR6X24
2025-01-16 06:19:07.476 | HD Request # 60 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:07.476 | Triggering next historical data download in queue.
2025-01-16 06:19:07.476 | HD Request # 61 | Downloading Intraday chart data for F.US.BR6Z24 to the file F.US.BR6Z24.scid. Service: cme
2025-01-16 06:19:07.476 | HD Request # 61 | Download start date-time: 2024-11-29 15:11:51.000000. File last date-time: 2024-11-29 15:11:51.877001
2025-01-16 06:19:07.476 | HD Request # 61 | Using server: ds28.sierracharts.com port 10149
2025-01-16 06:19:07.477 | Socket (2) | Creating socket.
2025-01-16 06:19:07.477 | Socket (2) | New receive buffer size: 0
2025-01-16 06:19:07.477 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-16 06:19:07.615 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:19:07.615 | Socket (3) | Closed.
2025-01-16 06:19:07.776 | HD Request # 61 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:07.776 | HD Request # 61 | Sending historical data logon request message.
2025-01-16 06:19:07.966 | HD Request # 61 | Requesting Intraday data. Start date-time: 2024-11-29 15:11:51. Record interval: 0. Symbol: 6LZ24
2025-01-16 06:19:08.113 | HD Request # 61 | Decompressing data.
2025-01-16 06:19:08.260 | HD Request # 61 | Receiving Intraday data for F.US.BR6Z24 starting at 2024-11-29 15:11:51.877000
2025-01-16 06:19:08.260 | Socket (2) | CloseSocket call.
2025-01-16 06:19:08.260 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:08.260 | Historical data download thread signaled to stop.
2025-01-16 06:19:08.260 | HD Request # 61 | Received 2 Intraday data records from 2024-11-29 15:11:51.877000 to 2024-11-29 15:11:51.877001 (0.0 seconds. Delay: 47.6 days) and wrote 0 records for F.US.BR6Z24
2025-01-16 06:19:08.260 | HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2024-11-29 15:11:51.877001
2025-01-16 06:19:08.260 | HD Request # 61 | Completion time: 1s.
2025-01-16 06:19:08.260 | HD Request # 61 | Intraday data download complete for F.US.BR6Z24. Unique request ID: 51
2025-01-16 06:19:08.260 | Removing historical data download ID 51.
2025-01-16 06:19:08.260 | Real-time Intraday chart data file updates started for F.US.BR6Z24
2025-01-16 06:19:08.260 | Intraday chart data file opened for F.US.BR6Z24
2025-01-16 06:19:08.260 | HD Request # 61 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:08.260 | Triggering next historical data download in queue.
2025-01-16 06:19:08.261 | HD Request # 62 | Downloading Intraday chart data for F.US.BR6F25 to the file F.US.BR6F25.scid. Service: cme
2025-01-16 06:19:08.261 | HD Request # 62 | Download start date-time: 2024-12-30 15:12:45.000000. File last date-time: 2024-12-30 15:12:45.808000
2025-01-16 06:19:08.261 | HD Request # 62 | Using server: ds32.sierracharts.com port 10150
2025-01-16 06:19:08.261 | Socket (3) | Creating socket.
2025-01-16 06:19:08.261 | Socket (3) | New receive buffer size: 0
2025-01-16 06:19:08.261 | Socket (3) | Connecting to IP: 67.214.125.3.
2025-01-16 06:19:08.407 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:19:08.407 | Socket (2) | Closed.
2025-01-16 06:19:08.550 | HD Request # 62 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:08.550 | HD Request # 62 | Sending historical data logon request message.
2025-01-16 06:19:08.738 | HD Request # 62 | Requesting Intraday data. Start date-time: 2024-12-30 15:12:45. Record interval: 0. Symbol: 6LF25
2025-01-16 06:19:08.881 | HD Request # 62 | Decompressing data.
2025-01-16 06:19:09.023 | HD Request # 62 | Receiving Intraday data for F.US.BR6F25 starting at 2024-12-30 15:12:45.808000
2025-01-16 06:19:09.023 | Socket (3) | CloseSocket call.
2025-01-16 06:19:09.023 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:09.023 | Historical data download thread signaled to stop.
2025-01-16 06:19:09.023 | HD Request # 62 | Received 1 Intraday data record from 2024-12-30 15:12:45.808000 to 2024-12-30 15:12:45.808000 (0.0 seconds. Delay: 16.6 days) and wrote 0 records for F.US.BR6F25
2025-01-16 06:19:09.023 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2024-12-30 15:12:45.808000
2025-01-16 06:19:09.023 | HD Request # 62 | Completion time: 1s.
2025-01-16 06:19:09.023 | HD Request # 62 | Intraday data download complete for F.US.BR6F25. Unique request ID: 52
2025-01-16 06:19:09.023 | Removing historical data download ID 52.
2025-01-16 06:19:09.023 | Real-time Intraday chart data file updates started for F.US.BR6F25
2025-01-16 06:19:09.023 | Intraday chart data file opened for F.US.BR6F25
2025-01-16 06:19:09.023 | HD Request # 62 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:09.023 | Triggering next historical data download in queue.
2025-01-16 06:19:09.023 | HD Request # 63 | Downloading Intraday chart data for F.US.BR6G25 to the file F.US.BR6G25.scid. Service: cme
2025-01-16 06:19:09.023 | HD Request # 63 | Download start date-time: 2025-01-16 05:19:58.000000. File last date-time: 2025-01-16 05:19:58.980002
2025-01-16 06:19:09.024 | HD Request # 63 | Using server: ds26.sierracharts.com port 10149
2025-01-16 06:19:09.024 | Socket (2) | Creating socket.
2025-01-16 06:19:09.024 | Socket (2) | New receive buffer size: 0
2025-01-16 06:19:09.024 | Socket (2) | Connecting to IP: 64.152.155.17.
2025-01-16 06:19:09.170 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:19:09.170 | Socket (3) | Closed.
2025-01-16 06:19:09.315 | HD Request # 63 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:09.315 | HD Request # 63 | Sending historical data logon request message.
2025-01-16 06:19:09.500 | HD Request # 63 | Requesting Intraday data. Start date-time: 2025-01-16 05:19:58. Record interval: 0. Symbol: 6LG25
2025-01-16 06:19:09.640 | HD Request # 63 | Decompressing data.
2025-01-16 06:19:09.780 | HD Request # 63 | Receiving Intraday data for F.US.BR6G25 starting at 2025-01-16 05:19:58.046000
2025-01-16 06:19:09.780 | Socket (2) | CloseSocket call.
2025-01-16 06:19:09.780 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:09.780 | Historical data download thread signaled to stop.
2025-01-16 06:19:09.780 | HD Request # 63 | Received 7 Intraday data records from 2025-01-16 05:19:58.046000 to 2025-01-16 05:19:58.980002 (0.9 seconds. Delay: 59.2 minutes) and wrote 0 records for F.US.BR6G25
2025-01-16 06:19:09.780 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2025-01-16 05:19:58.980002
2025-01-16 06:19:09.780 | HD Request # 63 | Completion time: 0s.
2025-01-16 06:19:09.780 | HD Request # 63 | Intraday data download complete for F.US.BR6G25. Unique request ID: 53
2025-01-16 06:19:09.780 | Removing historical data download ID 53.
2025-01-16 06:19:09.780 | Real-time Intraday chart data file updates started for F.US.BR6G25
2025-01-16 06:19:09.780 | Intraday chart data file opened for F.US.BR6G25
2025-01-16 06:19:09.780 | HD Request # 63 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:09.780 | Triggering next historical data download in queue.
2025-01-16 06:19:09.780 | HD Request # 64 | Downloading Intraday chart data for F.US.SIEH25 to the file F.US.SIEH25.scid. Service: comex
2025-01-16 06:19:09.781 | HD Request # 64 | Download start date-time: 2025-01-16 05:52:00.000000. File last date-time: 2025-01-16 05:52:00.293001
2025-01-16 06:19:09.781 | HD Request # 64 | Using server: ds28.sierracharts.com port 10150
2025-01-16 06:19:09.781 | Socket (3) | Creating socket.
2025-01-16 06:19:09.781 | Socket (3) | New receive buffer size: 0
2025-01-16 06:19:09.781 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-01-16 06:19:09.920 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:19:09.920 | Socket (2) | Closed.
2025-01-16 06:19:10.071 | HD Request # 64 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:10.071 | HD Request # 64 | Sending historical data logon request message.
2025-01-16 06:19:10.117 | F.US.BR6G25 [CBV] 100 Volume #33 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:19:10.118 | F.US.BR6G25 [CBV] 100 Volume #33 | Reloading chart.
2025-01-16 06:19:10.213 | HD Request # 64 | Requesting Intraday data. Start date-time: 2025-01-16 05:52:00. Record interval: 0. Symbol: SIH25
2025-01-16 06:19:10.310 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 2024-07-16 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6N24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:10.310 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6Q24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:10.356 | HD Request # 64 | Decompressing data.
2025-01-16 06:19:10.417 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 2024-09-17 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6U24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:10.417 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6V24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:10.499 | HD Request # 64 | Receiving Intraday data for F.US.SIEH25 starting at 2025-01-16 05:52:00.293000
2025-01-16 06:19:10.500 | Socket (3) | CloseSocket call.
2025-01-16 06:19:10.500 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:10.538 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 2024-12-17 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6Z24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:10.538 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6F25.dly. Error: No Data for read. End of file.
2025-01-16 06:19:10.599 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 2025-01-14 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6F25.dly. Error: No Data for read. End of file.
2025-01-16 06:19:10.599 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6G25.dly. Error: No Data for read. End of file.
2025-01-16 06:19:10.602 | Historical data download thread signaled to stop.
2025-01-16 06:19:10.602 | HD Request # 64 | Timestamp of first Intraday data file record written: 2025-01-16 05:52:14.585000.
2025-01-16 06:19:10.603 | HD Request # 64 | Received 541 Intraday data records from 2025-01-16 05:52:00.293000 to 2025-01-16 06:19:03.310001 (27.1 minutes. Delay: 7.3 seconds) and wrote 539 records for F.US.SIEH25
2025-01-16 06:19:10.603 | HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:19:03.310001
2025-01-16 06:19:10.603 | HD Request # 64 | Completion time: 1s.
2025-01-16 06:19:10.603 | HD Request # 64 | Intraday data download complete for F.US.SIEH25. Unique request ID: 54
2025-01-16 06:19:10.603 | Removing historical data download ID 54.
2025-01-16 06:19:10.603 | Real-time Intraday chart data file updates started for F.US.SIEH25
2025-01-16 06:19:10.603 | Intraday chart data file opened for F.US.SIEH25
2025-01-16 06:19:10.603 | HD Request # 64 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:10.603 | Triggering next historical data download in queue.
2025-01-16 06:19:10.603 | HD Request # 65 | Downloading Intraday chart data for F.US.PAEH25 to the file F.US.PAEH25.scid. Service: nymex
2025-01-16 06:19:10.603 | HD Request # 65 | Download start date-time: 2025-01-16 05:48:51.000000. File last date-time: 2025-01-16 05:48:51.388000
2025-01-16 06:19:10.603 | HD Request # 65 | Using server: ds32.sierracharts.com port 10149
2025-01-16 06:19:10.603 | Socket (2) | Creating socket.
2025-01-16 06:19:10.604 | Socket (2) | New receive buffer size: 0
2025-01-16 06:19:10.604 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-16 06:19:10.625 | F.US.SIEH25 [CBV] 200 Volume #34 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:19:10.625 | F.US.SIEH25 [CBV] 200 Volume #34 | Reloading chart.
2025-01-16 06:19:10.642 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:19:10.642 | Socket (3) | Closed.
2025-01-16 06:19:10.893 | HD Request # 65 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:10.893 | HD Request # 65 | Sending historical data logon request message.
2025-01-16 06:19:11.036 | HD Request # 65 | Requesting Intraday data. Start date-time: 2025-01-16 05:48:51. Record interval: 0. Symbol: PAH25
2025-01-16 06:19:11.179 | HD Request # 65 | Decompressing data.
2025-01-16 06:19:11.291 | F.US.BR6G25 [CBV] 100 Volume #33 | Chart data loading complete.
2025-01-16 06:19:11.321 | HD Request # 65 | Receiving Intraday data for F.US.PAEH25 starting at 2025-01-16 05:48:51.388000
2025-01-16 06:19:11.321 | Socket (2) | CloseSocket call.
2025-01-16 06:19:11.321 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:11.330 | Historical data download thread signaled to stop.
2025-01-16 06:19:11.330 | HD Request # 65 | Timestamp of first Intraday data file record written: 2025-01-16 05:58:38.947000.
2025-01-16 06:19:11.330 | HD Request # 65 | Received 12 Intraday data records from 2025-01-16 05:48:51.388000 to 2025-01-16 06:16:50.371000 (28.0 minutes. Delay: 2.3 minutes) and wrote 11 records for F.US.PAEH25
2025-01-16 06:19:11.330 | HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:16:50.371000
2025-01-16 06:19:11.330 | HD Request # 65 | Completion time: 1s.
2025-01-16 06:19:11.330 | HD Request # 65 | Intraday data download complete for F.US.PAEH25. Unique request ID: 55
2025-01-16 06:19:11.330 | Removing historical data download ID 55.
2025-01-16 06:19:11.330 | Real-time Intraday chart data file updates started for F.US.PAEH25
2025-01-16 06:19:11.330 | Intraday chart data file opened for F.US.PAEH25
2025-01-16 06:19:11.330 | HD Request # 65 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:11.330 | Triggering next historical data download in queue.
2025-01-16 06:19:11.330 | HD Request # 66 | Downloading Intraday chart data for F.US.RBEG25 to the file F.US.RBEG25.scid. Service: nymex
2025-01-16 06:19:11.330 | HD Request # 66 | Download start date-time: 2025-01-16 05:50:07.000000. File last date-time: 2025-01-16 05:50:07.851000
2025-01-16 06:19:11.330 | HD Request # 66 | Using server: ds26.sierracharts.com port 10150
2025-01-16 06:19:11.330 | Socket (3) | Creating socket.
2025-01-16 06:19:11.330 | Socket (3) | New receive buffer size: 0
2025-01-16 06:19:11.330 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-16 06:19:11.405 | F.US.PAEH25 [CBV] 25 Volume #35 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:19:11.405 | F.US.PAEH25 [CBV] 25 Volume #35 | Reloading chart.
2025-01-16 06:19:11.464 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:19:11.464 | Socket (2) | Closed.
2025-01-16 06:19:11.472 | F.US.BR6G25 [CBV] 100 Volume #33 | Reloading chart.
2025-01-16 06:19:11.481 | F.US.BR6G25 [CBV] 100 Volume #33 | File F.US.BR6F25.dly has a volume of 0 at 2025-01-09.
2025-01-16 06:19:11.484 | F.US.BR6G25 [CBV] 100 Volume #33 | File F.US.BR6X24.dly has a volume of 0 at 2024-11-14.
2025-01-16 06:19:11.486 | F.US.BR6G25 [CBV] 100 Volume #33 | File F.US.BR6V24.dly has a volume of 0 at 2024-10-10.
2025-01-16 06:19:11.489 | F.US.BR6G25 [CBV] 100 Volume #33 | File F.US.BR6Q24.dly has a volume of 0 at 2024-08-15.
2025-01-16 06:19:11.617 | HD Request # 66 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:11.617 | HD Request # 66 | Sending historical data logon request message.
2025-01-16 06:19:11.709 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 2024-07-16 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6N24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:11.709 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6Q24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:11.759 | HD Request # 66 | Requesting Intraday data. Start date-time: 2025-01-16 05:50:07. Record interval: 0. Symbol: RBG25
2025-01-16 06:19:11.810 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 2024-09-17 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6U24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:11.810 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6V24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:11.847 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.BTCF25.scid. Thread ID: 24244
2025-01-16 06:19:11.847 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.YMH25.scid. Thread ID: 24244
2025-01-16 06:19:11.899 | HD Request # 66 | Decompressing data.
2025-01-16 06:19:11.933 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 2024-12-17 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6Z24.dly. Error: No Data for read. End of file.
2025-01-16 06:19:11.933 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6F25.dly. Error: No Data for read. End of file.
2025-01-16 06:19:11.992 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 2025-01-14 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6F25.dly. Error: No Data for read. End of file.
2025-01-16 06:19:11.992 | F.US.BR6G25 [CBV] 100 Volume #33 | Error while getting daily settlement price with date 0 from file. C:\SierraChart\SierraChartInstance_2\Data\F.US.BR6G25.dly. Error: No Data for read. End of file.
2025-01-16 06:19:12.038 | HD Request # 66 | Receiving Intraday data for F.US.RBEG25 starting at 2025-01-16 05:50:07.851000
2025-01-16 06:19:12.039 | Socket (3) | CloseSocket call.
2025-01-16 06:19:12.039 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:12.179 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:19:12.179 | Socket (3) | Closed.
2025-01-16 06:19:12.538 | F.US.PAEH25 [CBV] 25 Volume #35 | Chart data loading complete.
2025-01-16 06:19:13.988 | F.US.SIEH25 [CBV] 200 Volume #34 | Chart data loading complete.
2025-01-16 06:19:13.988 | Historical data download thread signaled to stop.
2025-01-16 06:19:13.988 | HD Request # 66 | Timestamp of first Intraday data file record written: 2025-01-16 05:56:40.080000.
2025-01-16 06:19:13.988 | HD Request # 66 | Received 16 Intraday data records from 2025-01-16 05:50:07.851000 to 2025-01-16 06:19:09.068000 (29.0 minutes. Delay: 4.9 seconds) and wrote 15 records for F.US.RBEG25
2025-01-16 06:19:13.988 | HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:19:09.068000
2025-01-16 06:19:13.988 | HD Request # 66 | Completion time: 2s.
2025-01-16 06:19:13.988 | HD Request # 66 | Intraday data download complete for F.US.RBEG25. Unique request ID: 56
2025-01-16 06:19:13.988 | Removing historical data download ID 56.
2025-01-16 06:19:13.988 | Real-time Intraday chart data file updates started for F.US.RBEG25
2025-01-16 06:19:13.988 | Intraday chart data file opened for F.US.RBEG25
2025-01-16 06:19:13.988 | HD Request # 66 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:13.988 | Triggering next historical data download in queue.
2025-01-16 06:19:14.350 | F.US.BR6G25 [CBV] 100 Volume #33 | Chart data loading complete.
2025-01-16 06:19:14.352 | HD Request # 67 | Downloading Intraday chart data for F.US.ULAH25 to the file F.US.ULAH25.scid. Service: cbot
2025-01-16 06:19:14.352 | HD Request # 67 | Download start date-time: 2025-01-16 05:50:32.000000. File last date-time: 2025-01-16 05:50:32.483001
2025-01-16 06:19:14.352 | HD Request # 67 | Using server: ds28.sierracharts.com port 10149
2025-01-16 06:19:14.352 | Socket (2) | Creating socket.
2025-01-16 06:19:14.352 | Socket (2) | New receive buffer size: 0
2025-01-16 06:19:14.352 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-16 06:19:14.388 | F.US.SIEH25 [CBV] 200 Volume #34 | Reloading chart.
2025-01-16 06:19:14.608 | F.US.RBEG25 [CBV] 100 Volume #36 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:19:14.608 | F.US.RBEG25 [CBV] 100 Volume #36 | Reloading chart.
2025-01-16 06:19:14.651 | HD Request # 67 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:14.651 | HD Request # 67 | Sending historical data logon request message.
2025-01-16 06:19:14.799 | HD Request # 67 | Requesting Intraday data. Start date-time: 2025-01-16 05:50:32. Record interval: 0. Symbol: UBH25
2025-01-16 06:19:14.910 | F.US.PAEH25 [CBV] 25 Volume #35 | Reloading chart.
2025-01-16 06:19:14.947 | HD Request # 67 | Decompressing data.
2025-01-16 06:19:14.961 | DTC - Sub Instance | Starting real-time market data updates for: F.US.BR6G25. ID: 56 Service code: cqg
2025-01-16 06:19:14.961 | DTC - Sub Instance | Requesting security definition data for: F.US.BR6G25. ID: 56
2025-01-16 06:19:14.974 | DTC - Sub Instance | Setting external service identifier for symbol F.US.BR6G25 to 10312
2025-01-16 06:19:14.974 | DTC - Sub Instance | Received security definition for symbol F.US.BR6G25
2025-01-16 06:19:15.026 | DTC - Sub Instance | Starting real-time market data updates for: F.US.SIEH25. ID: 57 Service code: cqg
2025-01-16 06:19:15.026 | DTC - Sub Instance | Requesting security definition data for: F.US.SIEH25. ID: 57
2025-01-16 06:19:15.026 | DTC - Sub Instance | Setting external service identifier for symbol F.US.SIEH25 to 5556
2025-01-16 06:19:15.026 | DTC - Sub Instance | Received security definition for symbol F.US.SIEH25
2025-01-16 06:19:15.027 | F.US.RBEG25 [CBV] 100 Volume #36 | Reloading chart.
2025-01-16 06:19:15.094 | HD Request # 67 | Receiving Intraday data for F.US.ULAH25 starting at 2025-01-16 05:50:32.483000
2025-01-16 06:19:15.095 | Socket (2) | CloseSocket call.
2025-01-16 06:19:15.095 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:15.242 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:19:15.242 | Socket (2) | Closed.
2025-01-16 06:19:15.779 | F.US.PAEH25 [CBV] 25 Volume #35 | Chart data loading complete.
2025-01-16 06:19:15.780 | Historical data download thread signaled to stop.
2025-01-16 06:19:15.780 | HD Request # 67 | Timestamp of first Intraday data file record written: 2025-01-16 05:52:41.304000.
2025-01-16 06:19:15.780 | HD Request # 67 | Received 331 Intraday data records from 2025-01-16 05:50:32.483000 to 2025-01-16 06:19:00.359002 (28.5 minutes. Delay: 15.4 seconds) and wrote 329 records for F.US.ULAH25
2025-01-16 06:19:15.780 | HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:19:00.359002
2025-01-16 06:19:15.780 | HD Request # 67 | Completion time: 1s.
2025-01-16 06:19:15.780 | HD Request # 67 | Intraday data download complete for F.US.ULAH25. Unique request ID: 57
2025-01-16 06:19:15.780 | Removing historical data download ID 57.
2025-01-16 06:19:15.780 | Real-time Intraday chart data file updates started for F.US.ULAH25
2025-01-16 06:19:15.780 | Intraday chart data file opened for F.US.ULAH25
2025-01-16 06:19:15.780 | HD Request # 67 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:15.780 | Triggering next historical data download in queue.
2025-01-16 06:19:16.767 | F.US.RBEG25 [CBV] 100 Volume #36 | Chart data loading complete.
2025-01-16 06:19:18.230 | F.US.SIEH25 [CBV] 200 Volume #34 | Chart data loading complete.
2025-01-16 06:19:18.230 | HD Request # 68 | Downloading Intraday chart data for F.US.ZSEH25 to the file F.US.ZSEH25.scid. Service: cbot
2025-01-16 06:19:18.230 | HD Request # 68 | Download start date-time: 2025-01-16 05:52:02.000000. File last date-time: 2025-01-16 05:52:02.781001
2025-01-16 06:19:18.230 | HD Request # 68 | Using server: ds32.sierracharts.com port 10150
2025-01-16 06:19:18.230 | Socket (2) | Creating socket.
2025-01-16 06:19:18.230 | Socket (2) | New receive buffer size: 0
2025-01-16 06:19:18.230 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-01-16 06:19:18.401 | F.US.ULAH25 [CBV] 1000 Volume #37 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:19:18.401 | F.US.ULAH25 [CBV] 1000 Volume #37 | Reloading chart.
2025-01-16 06:19:18.438 | DTC - Sub Instance | Starting real-time market data updates for: F.US.PAEH25. ID: 58 Service code: cqg
2025-01-16 06:19:18.438 | DTC - Sub Instance | Requesting security definition data for: F.US.PAEH25. ID: 58
2025-01-16 06:19:18.465 | DTC - Sub Instance | Setting external service identifier for symbol F.US.PAEH25 to 4127894
2025-01-16 06:19:18.465 | DTC - Sub Instance | Received security definition for symbol F.US.PAEH25
2025-01-16 06:19:18.523 | HD Request # 68 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:18.523 | HD Request # 68 | Sending historical data logon request message.
2025-01-16 06:19:18.541 | DTC - Sub Instance | Starting real-time market data updates for: F.US.RBEG25. ID: 59 Service code: cqg
2025-01-16 06:19:18.541 | DTC - Sub Instance | Requesting security definition data for: F.US.RBEG25. ID: 59
2025-01-16 06:19:18.562 | DTC - Sub Instance | Setting external service identifier for symbol F.US.RBEG25 to 254801
2025-01-16 06:19:18.562 | DTC - Sub Instance | Received security definition for symbol F.US.RBEG25
2025-01-16 06:19:18.666 | HD Request # 68 | Requesting Intraday data. Start date-time: 2025-01-16 05:52:02. Record interval: 0. Symbol: ZSH25
2025-01-16 06:19:18.810 | F.US.ULAH25 [CBV] 1000 Volume #37 | Reloading chart.
2025-01-16 06:19:18.810 | HD Request # 68 | Decompressing data.
2025-01-16 06:19:18.953 | HD Request # 68 | Receiving Intraday data for F.US.ZSEH25 starting at 2025-01-16 05:52:02.109000
2025-01-16 06:19:18.954 | Socket (2) | CloseSocket call.
2025-01-16 06:19:18.954 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:18.960 | Historical data download thread signaled to stop.
2025-01-16 06:19:18.960 | HD Request # 68 | Timestamp of first Intraday data file record written: 2025-01-16 05:52:22.443000.
2025-01-16 06:19:18.960 | HD Request # 68 | Received 371 Intraday data records from 2025-01-16 05:52:02.109000 to 2025-01-16 06:19:11.203006 (27.2 minutes. Delay: 7.8 seconds) and wrote 368 records for F.US.ZSEH25
2025-01-16 06:19:18.961 | HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:19:11.203006
2025-01-16 06:19:18.961 | HD Request # 68 | Completion time: 0s.
2025-01-16 06:19:18.961 | HD Request # 68 | Intraday data download complete for F.US.ZSEH25. Unique request ID: 58
2025-01-16 06:19:18.961 | Removing historical data download ID 58.
2025-01-16 06:19:18.961 | Real-time Intraday chart data file updates started for F.US.ZSEH25
2025-01-16 06:19:18.961 | Intraday chart data file opened for F.US.ZSEH25
2025-01-16 06:19:18.961 | HD Request # 68 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:18.961 | Triggering next historical data download in queue.
2025-01-16 06:19:18.961 | HD Request # 69 | Downloading Intraday chart data for F.US.ZCEH25 to the file F.US.ZCEH25.scid. Service: cbot
2025-01-16 06:19:18.961 | HD Request # 69 | Download start date-time: 2025-01-16 05:52:02.000000. File last date-time: 2025-01-16 05:52:02.791000
2025-01-16 06:19:18.961 | HD Request # 69 | Using server: ds26.sierracharts.com port 10149
2025-01-16 06:19:18.961 | Socket (3) | Creating socket.
2025-01-16 06:19:18.961 | Socket (3) | New receive buffer size: 0
2025-01-16 06:19:18.961 | Socket (3) | Connecting to IP: 64.152.155.17.
2025-01-16 06:19:19.062 | F.US.ZSEH25 [CBV] 500 Volume #38 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:19:19.063 | F.US.ZSEH25 [CBV] 500 Volume #38 | Reloading chart.
2025-01-16 06:19:19.096 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:19:19.097 | Socket (2) | Closed.
2025-01-16 06:19:19.259 | HD Request # 69 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:19.259 | HD Request # 69 | Sending historical data logon request message.
2025-01-16 06:19:19.296 | DTC - Sub Instance | Starting real-time market data updates for: F.US.ULAH25. ID: 60 Service code: cqg
2025-01-16 06:19:19.296 | DTC - Sub Instance | Requesting security definition data for: F.US.ULAH25. ID: 60
2025-01-16 06:19:19.313 | DTC - Sub Instance | Setting external service identifier for symbol F.US.ULAH25 to 42002512
2025-01-16 06:19:19.313 | DTC - Sub Instance | Received security definition for symbol F.US.ULAH25
2025-01-16 06:19:19.399 | HD Request # 69 | Requesting Intraday data. Start date-time: 2025-01-16 05:52:02. Record interval: 0. Symbol: ZCH25
2025-01-16 06:19:19.459 | F.US.ZSEH25 [CBV] 500 Volume #38 | Reloading chart.
2025-01-16 06:19:19.539 | HD Request # 69 | Decompressing data.
2025-01-16 06:19:19.680 | HD Request # 69 | Receiving Intraday data for F.US.ZCEH25 starting at 2025-01-16 05:52:02.791000
2025-01-16 06:19:19.680 | Socket (3) | CloseSocket call.
2025-01-16 06:19:19.680 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:19.680 | Historical data download thread signaled to stop.
2025-01-16 06:19:19.681 | HD Request # 69 | Timestamp of first Intraday data file record written: 2025-01-16 05:52:24.626000.
2025-01-16 06:19:19.681 | HD Request # 69 | Received 126 Intraday data records from 2025-01-16 05:52:02.791000 to 2025-01-16 06:19:11.250000 (27.1 minutes. Delay: 8.4 seconds) and wrote 125 records for F.US.ZCEH25
2025-01-16 06:19:19.681 | HD Request # 69 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:19:11.250000
2025-01-16 06:19:19.681 | HD Request # 69 | Completion time: 1s.
2025-01-16 06:19:19.681 | HD Request # 69 | Intraday data download complete for F.US.ZCEH25. Unique request ID: 59
2025-01-16 06:19:19.681 | Removing historical data download ID 59.
2025-01-16 06:19:19.681 | Real-time Intraday chart data file updates started for F.US.ZCEH25
2025-01-16 06:19:19.681 | Intraday chart data file opened for F.US.ZCEH25
2025-01-16 06:19:19.681 | HD Request # 69 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:19.681 | Triggering next historical data download in queue.
2025-01-16 06:19:19.681 | HD Request # 70 | Downloading Intraday chart data for F.US.ZWAH25 to the file F.US.ZWAH25.scid. Service: cbot
2025-01-16 06:19:19.681 | HD Request # 70 | Download start date-time: 2025-01-16 05:51:01.000000. File last date-time: 2025-01-16 05:51:01.663000
2025-01-16 06:19:19.681 | HD Request # 70 | Using server: ds28.sierracharts.com port 10150
2025-01-16 06:19:19.681 | Socket (2) | Creating socket.
2025-01-16 06:19:19.681 | Socket (2) | New receive buffer size: 0
2025-01-16 06:19:19.681 | Socket (2) | Connecting to IP: 67.214.125.5.
2025-01-16 06:19:19.821 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:19:19.821 | Socket (3) | Closed.
2025-01-16 06:19:19.871 | DTC - Sub Instance | Starting real-time market data updates for: F.US.ZSEH25. ID: 61 Service code: cqg
2025-01-16 06:19:19.871 | DTC - Sub Instance | Requesting security definition data for: F.US.ZSEH25. ID: 61
2025-01-16 06:19:19.871 | DTC - Sub Instance | Setting external service identifier for symbol F.US.ZSEH25 to 760184
2025-01-16 06:19:19.871 | DTC - Sub Instance | Received security definition for symbol F.US.ZSEH25
2025-01-16 06:19:19.872 | F.US.ZCEH25 [CBV] 500 Volume #39 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:19:19.872 | F.US.ZCEH25 [CBV] 500 Volume #39 | Reloading chart.
2025-01-16 06:19:19.972 | HD Request # 70 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:19.972 | HD Request # 70 | Sending historical data logon request message.
2025-01-16 06:19:20.115 | HD Request # 70 | Requesting Intraday data. Start date-time: 2025-01-16 05:51:01. Record interval: 0. Symbol: ZWH25
2025-01-16 06:19:20.258 | HD Request # 70 | Decompressing data.
2025-01-16 06:19:20.400 | HD Request # 70 | Receiving Intraday data for F.US.ZWAH25 starting at 2025-01-16 05:51:01.653000
2025-01-16 06:19:20.400 | Socket (2) | CloseSocket call.
2025-01-16 06:19:20.400 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:20.544 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:19:20.544 | Socket (2) | Closed.
2025-01-16 06:19:21.879 | F.US.ULAH25 [CBV] 1000 Volume #37 | Chart data loading complete.
2025-01-16 06:19:21.880 | F.US.ZSEH25 [CBV] 500 Volume #38 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:19:21.940 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.SIEH25.scid. Thread ID: 24244
2025-01-16 06:19:22.481 | F.US.ZSEH25 [CBV] 500 Volume #38 | Chart data loading complete.
2025-01-16 06:19:22.483 | Historical data download thread signaled to stop.
2025-01-16 06:19:22.483 | HD Request # 70 | Timestamp of first Intraday data file record written: 2025-01-16 05:52:35.289000.
2025-01-16 06:19:22.483 | HD Request # 70 | Received 66 Intraday data records from 2025-01-16 05:51:01.653000 to 2025-01-16 06:17:56.613000 (26.9 minutes. Delay: 85.9 seconds) and wrote 64 records for F.US.ZWAH25
2025-01-16 06:19:22.483 | HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:17:56.613000
2025-01-16 06:19:22.483 | HD Request # 70 | Completion time: 3s.
2025-01-16 06:19:22.483 | HD Request # 70 | Intraday data download complete for F.US.ZWAH25. Unique request ID: 60
2025-01-16 06:19:22.483 | Removing historical data download ID 60.
2025-01-16 06:19:22.483 | Real-time Intraday chart data file updates started for F.US.ZWAH25
2025-01-16 06:19:22.483 | Intraday chart data file opened for F.US.ZWAH25
2025-01-16 06:19:22.483 | HD Request # 70 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:22.483 | Triggering next historical data download in queue.
2025-01-16 06:19:22.485 | F.US.ZCEH25 [CBV] 500 Volume #39 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:19:23.730 | F.US.ZCEH25 [CBV] 500 Volume #39 | Chart data loading complete.
2025-01-16 06:19:25.498 | HD Request # 71 | Downloading Intraday chart data for HKG33 to the file HKG33.scid. Service: fxcm
2025-01-16 06:19:25.499 | HD Request # 71 | Download start date-time: 2025-01-16 05:52:09.000000. File last date-time: 2025-01-16 05:52:09.105000
2025-01-16 06:19:25.499 | HD Request # 71 | Using server: ds12.sierracharts.com port 10149
2025-01-16 06:19:25.579 | Socket (2) | Creating socket.
2025-01-16 06:19:25.579 | Socket (2) | New receive buffer size: 0
2025-01-16 06:19:25.579 | Socket (2) | Connecting to IP: 69.39.70.241.
2025-01-16 06:19:25.676 | F.US.ZCEH25 [CBV] 500 Volume #39 | Reloading chart.
2025-01-16 06:19:25.792 | F.US.ZWAH25 [CBV] 200 Volume #40 | Download is complete for all contract months in chart. Proceeding with data load.
2025-01-16 06:19:25.793 | F.US.ZWAH25 [CBV] 200 Volume #40 | Reloading chart.
2025-01-16 06:19:25.877 | HD Request # 71 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:25.877 | HD Request # 71 | Sending historical data logon request message.
2025-01-16 06:19:26.059 | HD Request # 71 | Requesting Intraday data. Start date-time: 2025-01-16 05:52:09. Record interval: 0. Symbol: HKG33
2025-01-16 06:19:26.077 | DTC - Sub Instance | Starting real-time market data updates for: F.US.ZCEH25. ID: 62 Service code: cqg
2025-01-16 06:19:26.077 | DTC - Sub Instance | Requesting security definition data for: F.US.ZCEH25. ID: 62
2025-01-16 06:19:26.077 | DTC - Sub Instance | Setting external service identifier for symbol F.US.ZCEH25 to 626930
2025-01-16 06:19:26.077 | DTC - Sub Instance | Received security definition for symbol F.US.ZCEH25
2025-01-16 06:19:26.202 | HD Request # 71 | Decompressing data.
2025-01-16 06:19:26.214 | F.US.ZWAH25 [CBV] 200 Volume #40 | Reloading chart.
2025-01-16 06:19:26.220 | HD Request # 71 | Receiving Intraday data for HKG33 starting at 2025-01-16 05:52:09.105000
2025-01-16 06:19:26.359 | F.US.ZWAH25 [CBV] 200 Volume #40 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:19:26.648 | Socket (2) | CloseSocket call.
2025-01-16 06:19:26.648 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:26.791 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:19:26.791 | Socket (2) | Closed.
2025-01-16 06:19:26.970 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.NKDH25.scid. Thread ID: 24244
2025-01-16 06:19:27.323 | F.US.ZWAH25 [CBV] 200 Volume #40 | Chart data loading complete.
2025-01-16 06:19:28.117 | Historical data download thread signaled to stop.
2025-01-16 06:19:28.118 | HD Request # 71 | Timestamp of first Intraday data file record written: 2025-01-16 05:52:09.604000.
2025-01-16 06:19:28.118 | HD Request # 71 | Received 5384 Intraday data records from 2025-01-16 05:52:09.105000 to 2025-01-16 06:19:23.542000 (27.2 minutes. Delay: 4.6 seconds) and wrote 5383 records for HKG33
2025-01-16 06:19:28.118 | HD Request # 71 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:19:23.542000
2025-01-16 06:19:28.118 | Added 9 Time and Sales records to Intraday data file for HKG33 after download.
2025-01-16 06:19:28.118 | HD Request # 71 | Completion time: 3s.
2025-01-16 06:19:28.118 | HD Request # 71 | Intraday data download complete for HKG33. Unique request ID: 61
2025-01-16 06:19:28.118 | Removing historical data download ID 61.
2025-01-16 06:19:28.118 | Real-time Intraday chart data file updates started for HKG33
2025-01-16 06:19:28.118 | Intraday chart data file opened for HKG33
2025-01-16 06:19:28.118 | HD Request # 71 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:28.118 | Triggering next historical data download in queue.
2025-01-16 06:19:28.127 | F.US.ZCEH25 [CBV] 500 Volume #39 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-01-16 06:19:29.318 | F.US.ZCEH25 [CBV] 500 Volume #39 | Chart data loading complete.
2025-01-16 06:19:29.319 | HD Request # 72 | Downloading Intraday chart data for UK100 to the file UK100.scid. Service: fxcm
2025-01-16 06:19:29.319 | HD Request # 72 | Download start date-time: 2025-01-16 05:52:06.000000. File last date-time: 2025-01-16 05:52:06.838000
2025-01-16 06:19:29.319 | HD Request # 72 | Using server: ds4.sierracharts.com port 10150
2025-01-16 06:19:29.320 | Socket (3) | Creating socket.
2025-01-16 06:19:29.320 | Socket (3) | New receive buffer size: 0
2025-01-16 06:19:29.320 | Socket (3) | Connecting to IP: 67.214.125.7.
2025-01-16 06:19:29.622 | HD Request # 72 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:29.622 | HD Request # 72 | Sending historical data logon request message.
2025-01-16 06:19:29.797 | HD Request # 72 | Requesting Intraday data. Start date-time: 2025-01-16 05:52:06. Record interval: 0. Symbol: UK100
2025-01-16 06:19:29.941 | HD Request # 72 | Decompressing data.
2025-01-16 06:19:30.086 | HD Request # 72 | Receiving Intraday data for UK100 starting at 2025-01-16 05:52:06.773000
2025-01-16 06:19:30.087 | Socket (3) | CloseSocket call.
2025-01-16 06:19:30.087 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:30.229 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:19:30.229 | Socket (3) | Closed.
2025-01-16 06:19:30.500 | Historical data download thread signaled to stop.
2025-01-16 06:19:30.500 | HD Request # 72 | Timestamp of first Intraday data file record written: 2025-01-16 05:52:50.444000.
2025-01-16 06:19:30.500 | HD Request # 72 | Received 697 Intraday data records from 2025-01-16 05:52:06.773000 to 2025-01-16 06:19:20.960000 (27.2 minutes. Delay: 9.5 seconds) and wrote 695 records for UK100
2025-01-16 06:19:30.500 | HD Request # 72 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:19:20.960000
2025-01-16 06:19:30.500 | HD Request # 72 | Completion time: 1s.
2025-01-16 06:19:30.500 | HD Request # 72 | Intraday data download complete for UK100. Unique request ID: 62
2025-01-16 06:19:30.500 | Removing historical data download ID 62.
2025-01-16 06:19:30.500 | Real-time Intraday chart data file updates started for UK100
2025-01-16 06:19:30.500 | Intraday chart data file opened for UK100
2025-01-16 06:19:30.500 | HD Request # 72 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:30.500 | Triggering next historical data download in queue.
2025-01-16 06:19:30.501 | HD Request # 73 | Downloading Intraday chart data for FRA40 to the file FRA40.scid. Service: fxcm
2025-01-16 06:19:30.501 | HD Request # 73 | Download start date-time: 2025-01-15 20:59:57.000000. File last date-time: 2025-01-15 20:59:57.001000
2025-01-16 06:19:30.501 | HD Request # 73 | Using server: ds12.sierracharts.com port 10149
2025-01-16 06:19:30.501 | Socket (3) | Creating socket.
2025-01-16 06:19:30.501 | Socket (3) | New receive buffer size: 0
2025-01-16 06:19:30.501 | Socket (3) | Connecting to IP: 69.39.70.241.
2025-01-16 06:19:30.763 | DTC - Sub Instance | Starting real-time market data updates for: F.US.ZWAH25. ID: 63 Service code: cqg
2025-01-16 06:19:30.763 | DTC - Sub Instance | Requesting security definition data for: F.US.ZWAH25. ID: 63
2025-01-16 06:19:30.788 | DTC - Sub Instance | Setting external service identifier for symbol F.US.ZWAH25 to 466991
2025-01-16 06:19:30.788 | DTC - Sub Instance | Received security definition for symbol F.US.ZWAH25
2025-01-16 06:19:30.796 | HD Request # 73 | Setting DTC encoding to Binary VLS
2025-01-16 06:19:30.796 | HD Request # 73 | Sending historical data logon request message.
2025-01-16 06:19:30.939 | HD Request # 73 | Requesting Intraday data. Start date-time: 2025-01-15 20:59:57. Record interval: 0. Symbol: FRA40
2025-01-16 06:19:31.082 | HD Request # 73 | Decompressing data.
2025-01-16 06:19:31.224 | HD Request # 73 | Receiving Intraday data for FRA40 starting at 2025-01-15 20:59:57.001000
2025-01-16 06:19:31.224 | Socket (3) | CloseSocket call.
2025-01-16 06:19:31.224 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:19:31.225 | Historical data download thread signaled to stop.
2025-01-16 06:19:31.225 | HD Request # 73 | Received 1 Intraday data record from 2025-01-15 20:59:57.001000 to 2025-01-15 20:59:57.001000 (0.0 seconds. Delay: 9.3 hours) and wrote 0 records for FRA40
2025-01-16 06:19:31.225 | HD Request # 73 | Add time&sales data | Remembered last file record date-time: 2025-01-15 20:59:57.001000
2025-01-16 06:19:31.225 | HD Request # 73 | Completion time: 1s.
2025-01-16 06:19:31.225 | HD Request # 73 | Intraday data download complete for FRA40. Unique request ID: 63
2025-01-16 06:19:31.225 | Removing historical data download ID 63.
2025-01-16 06:19:31.225 | Real-time Intraday chart data file updates started for FRA40
2025-01-16 06:19:31.225 | Intraday chart data file opened for FRA40
2025-01-16 06:19:31.225 | HD Request # 73 | Enabling Intraday chart updating for symbol.
2025-01-16 06:19:31.225 | No download requests in the queue to start downloads for.
2025-01-16 06:19:31.368 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:19:31.368 | Socket (3) | Closed.
2025-01-16 06:19:32.028 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\HKG33.scid. Thread ID: 24244
2025-01-16 06:19:37.050 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\UK100.scid. Thread ID: 24244
2025-01-16 06:19:37.050 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.ZSEH25.scid. Thread ID: 24244
2025-01-16 06:19:42.094 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.PAEH25.scid. Thread ID: 24244
2025-01-16 06:20:02.219 | Opened cached Intraday file: C:\SierraChart\SierraChartInstance_2\Data\F.US.ULAH25.scid. Thread ID: 24244
[2025-01-16 06:41:51]
Sierra_Chart Engineering - Posts: 19305
This log is too complex. In the sub instance:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2025-01-16 06:50:41]
Gabriel Poinsot - Posts: 13
No worries, so the symbol are all the Eurex Markets but for this example I will be using EuroStoxx = F.US.DSXH25
[2025-01-16 06:50:49]
2025-01-16 06:46:54.476 | Software version: 2726 64-bit
2025-01-16 06:46:54.476 | Primary Thread ID: 25932
2025-01-16 06:46:54.476 | Usage end date: 2025-06-17
2025-01-16 06:46:54.476 | Enabled for: Advanced Features 2.
2025-01-16 06:46:54.476 | Enabled for: Sierra Chart Historical Data Service.
2025-01-16 06:46:54.476 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-01-16 06:46:54.476 | Enabled for: Delayed Denali Exchange Data Feed.
2025-01-16 06:46:54.476 | Enabled for exchange2: CME (Trading Account Required)
2025-01-16 06:46:54.476 | Enabled for exchange2: CBOT (Trading Account Required)
2025-01-16 06:46:54.476 | Enabled for exchange2: COMEX (Trading Account Required)
2025-01-16 06:46:54.476 | Enabled for exchange2: NYMEX (Trading Account Required)
2025-01-16 06:46:54.476 | Enabled for exchange2: EUREX EOBI
2025-01-16 06:46:54.476 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-01-16 06:46:54.476 | Current selected Data/Trading service: DTC - Sub Instance
2025-01-16 06:46:54.476 | Custom symbol settings values: disabled
2025-01-16 06:46:54.476 | Chart Update Interval: 400
2025-01-16 06:46:54.476 | Intraday Data Storage Time Unit: 0
2025-01-16 06:46:54.476 | Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00)
2025-01-16 06:46:54.476 | 2025-01-16 06:46:54 Local computer time in UTC
2025-01-16 06:46:54.476 | 2025-01-16 06:46:54 Local computer time in SC Time Zone
2025-01-16 06:46:54.476 | 2025-01-16 06:46:36 Server time in UTC
2025-01-16 06:46:54.476 | Local computer UTC time and Server UTC time difference: 1 seconds.
2025-01-16 06:46:54.476 | Program path: C:\SierraChart\SierraChartInstance_2\
2025-01-16 06:46:54.476 | Data Files path: C:\SierraChart\SierraChartInstance_2\Data\
2025-01-16 06:46:54.476 | OS Version Number: 10.0
2025-01-16 06:46:54.476 | Locale Setting: C
2025-01-16 06:46:54.476 | DLLs: FabTradingStudies_64.dll, sst_FreeBundle_64.dll, UserContributedStudies_64.dll
2025-01-16 06:46:54.476 | Allowed protected custom studies: Fab Trading Studies, SST_FreeBundle
2025-01-16 06:46:54.476 | Crash reporter started: true
2025-01-16 06:47:15.453 | F.US.DSXH25 1 Min #1 | Reloading chart.
2025-01-16 06:47:15.552 | F.US.DSXH25 1 Min #1 | Chart data loading complete.
2025-01-16 06:47:15.849 | Using symbol data fast lookup vector
2025-01-16 06:47:15.849 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH25. ID: 1
2025-01-16 06:47:15.849 | Symbol Error | F.US.DSXH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH25. ID: 1
2025-01-16 06:47:15.849 | Starting DelayedDownloadMonitoringTimer
2025-01-16 06:47:15.849 | Starting HDTimeoutTimer
2025-01-16 06:47:15.850 | Added historical Intraday data request for F.US.DSXH25 to the queue.
2025-01-16 06:47:15.850 | Intraday data recording state for symbol F.US.DSXH25 is set to download 'Pending'.
2025-01-16 06:47:15.851 | Triggering next historical data download in queue.
2025-01-16 06:47:15.852 | HD Request # 1 | Downloading Intraday chart data for F.US.DSXH25 to the file F.US.DSXH25.scid. Service: eurex
2025-01-16 06:47:15.852 | HD Request # 1 | Download start date-time: 2025-01-16 06:44:15.000000. File last date-time: 2025-01-16 06:44:15.443000
2025-01-16 06:47:15.852 | HD Request # 1 | Using server: ds50.sierracharts.com port 10149
2025-01-16 06:47:15.942 | Socket (2) | Creating socket.
2025-01-16 06:47:15.942 | Socket (2) | New receive buffer size: 0
2025-01-16 06:47:15.942 | Socket (2) | Connecting to IP: 62.209.53.225.
2025-01-16 06:47:16.059 | HD Request # 1 | Setting DTC encoding to Binary VLS
2025-01-16 06:47:16.059 | HD Request # 1 | Sending historical data logon request message.
2025-01-16 06:47:16.117 | Socket (2) | CloseSocket call.
2025-01-16 06:47:16.117 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-01-16 06:47:16.117 | HD Request # 1 | Error downloading historical Intraday data for F.US.DSXH25. Historical data logon error: Serving data is disabled
2025-01-16 06:47:16.117 | Added historical Intraday data request for F.US.DSXH25 to the queue.
2025-01-16 06:47:16.117 | Triggering next historical data download in queue.
2025-01-16 06:47:16.117 | Historical data download thread signaled to stop.
2025-01-16 06:47:16.117 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for F.US.DSXH25
2025-01-16 06:47:16.117 | HD Request # 1 | Completion time: 1s.
2025-01-16 06:47:16.117 | HD Request # 2 | Downloading Intraday chart data for F.US.DSXH25 to the file F.US.DSXH25.scid. Service: eurex
2025-01-16 06:47:16.117 | HD Request # 2 | Download start date-time: 2025-01-16 06:44:15.000000. File last date-time: 2025-01-16 06:44:15.443000
2025-01-16 06:47:16.117 | HD Request # 2 | Using server: ds14.sierracharts.com port 10150
2025-01-16 06:47:16.118 | Socket (3) | Creating socket.
2025-01-16 06:47:16.118 | Socket (3) | New receive buffer size: 0
2025-01-16 06:47:16.118 | Socket (3) | Connecting to IP: 176.9.9.252.
2025-01-16 06:47:16.174 | Socket (2) | Socket gracefully closed by remote side.
2025-01-16 06:47:16.174 | Socket (2) | Closed.
2025-01-16 06:47:16.256 | HD Request # 2 | Setting DTC encoding to Binary VLS
2025-01-16 06:47:16.256 | HD Request # 2 | Sending historical data logon request message.
2025-01-16 06:47:16.819 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-01-16 06:44:15. Record interval: 0. Symbol: FESX202503_FUT_EUREX
2025-01-16 06:47:16.888 | HD Request # 2 | Decompressing data.
2025-01-16 06:47:16.981 | HD Request # 2 | Receiving Intraday data for F.US.DSXH25 starting at 2025-01-16 06:44:15.434000
2025-01-16 06:47:16.982 | Socket (3) | CloseSocket call.
2025-01-16 06:47:16.982 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:47:16.982 | Historical data download thread signaled to stop.
2025-01-16 06:47:16.982 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-01-16 06:44:50.449000.
2025-01-16 06:47:16.982 | HD Request # 2 | Received 104 Intraday data records from 2025-01-16 06:44:15.434000 to 2025-01-16 06:47:12.554002 (3.0 minutes. Delay: 4.4 seconds) and wrote 99 records for F.US.DSXH25
2025-01-16 06:47:16.982 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:47:12.554002
2025-01-16 06:47:16.982 | HD Request # 2 | Completion time: 0s.
2025-01-16 06:47:16.982 | HD Request # 2 | Intraday data download complete for F.US.DSXH25. Unique request ID: 1
2025-01-16 06:47:16.982 | Removing historical data download ID 1.
2025-01-16 06:47:16.982 | Real-time Intraday chart data file updates started for F.US.DSXH25
2025-01-16 06:47:16.982 | Intraday chart data file opened for F.US.DSXH25
2025-01-16 06:47:16.982 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2025-01-16 06:47:16.982 | No download requests in the queue to start downloads for.
2025-01-16 06:47:17.049 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:47:17.049 | Socket (3) | Closed.
2025-01-16 06:48:43.619 | File >> Disconnect selected.
2025-01-16 06:48:43.619 | DTC - Sub Instance | Waiting for socket receive thread to end
2025-01-16 06:48:43.619 | DTC Client socket (1) | CloseSocket call.
2025-01-16 06:48:43.619 | DTC - Sub Instance | Disconnected.
2025-01-16 06:48:43.619 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-01-16 06:48:43.619 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-01-16 06:48:43.619 | DTC Client socket (1) | Closed.
2025-01-16 06:48:52.955 |
2025-01-16 06:48:52.955 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2025-01-16 06:48:52.955 | DTC Client socket (1) | Creating socket.
2025-01-16 06:48:52.955 | DTC Client socket (1) | New receive buffer size: 0
2025-01-16 06:48:52.955 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2025-01-16 06:48:52.955 | DTC - Sub Instance | Network connection to server complete.
2025-01-16 06:48:52.955 | DTC - Sub Instance | Starting socket receive thread.
2025-01-16 06:48:52.955 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2025-01-16 06:48:52.955 | DTC - Sub Instance | Setting DTC encoding to Binary VLS
2025-01-16 06:48:52.955 | DTC - Sub Instance | Sending logon request message.
2025-01-16 06:48:52.955 | DTC - Sub Instance | Received logon response.
2025-01-16 06:48:52.955 | DTC - Sub Instance | Server Name: SC DTC Server. Build=52055.
2025-01-16 06:48:52.955 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8
2025-01-16 06:48:52.955 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg.
2025-01-16 06:48:52.955 | DTC - Sub Instance | Trading is supported.
2025-01-16 06:48:52.955 | DTC - Sub Instance | Order cancel and replace is supported.
2025-01-16 06:48:52.955 | DTC - Sub Instance | OCO Orders supported.
2025-01-16 06:48:52.955 | DTC - Sub Instance | Bracket Orders supported.
2025-01-16 06:48:52.955 | DTC - Sub Instance | MarketDepthIsSupported: 1
2025-01-16 06:48:52.955 | DTC - Sub Instance | Connected to server complete.
2025-01-16 06:48:52.956 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-01-16 06:48:52.956 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 2.
2025-01-16 06:48:52.974 | Using symbol data fast lookup vector
2025-01-16 06:48:52.974 | DTC - Sub Instance | Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH25. ID: 1
2025-01-16 06:48:52.974 | Symbol Error | F.US.DSXH25 is unknown, unavailable, or improperly formatted. Real-time market data only supported with Sierra Chart data feed for symbol: F.US.DSXH25. ID: 1
2025-01-16 06:48:52.974 | Added historical Intraday data request for F.US.DSXH25 to the queue.
2025-01-16 06:48:52.974 | Intraday data recording state for symbol F.US.DSXH25 is set to download 'Pending'.
2025-01-16 06:48:52.974 | Triggering next historical data download in queue.
2025-01-16 06:48:52.976 | HD Request # 3 | Downloading Intraday chart data for F.US.DSXH25 to the file F.US.DSXH25.scid. Service: eurex
2025-01-16 06:48:52.976 | HD Request # 3 | Download start date-time: 2025-01-16 06:47:12.000000. File last date-time: 2025-01-16 06:47:12.554002
2025-01-16 06:48:52.976 | HD Request # 3 | Using server: ds24.sierracharts.com port 10149
2025-01-16 06:48:52.976 | Socket (3) | Creating socket.
2025-01-16 06:48:52.976 | Socket (3) | New receive buffer size: 0
2025-01-16 06:48:52.976 | Socket (3) | Connecting to IP: 62.209.53.226.
2025-01-16 06:48:53.092 | HD Request # 3 | Setting DTC encoding to Binary VLS
2025-01-16 06:48:53.092 | HD Request # 3 | Sending historical data logon request message.
2025-01-16 06:48:53.583 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-01-16 06:47:12. Record interval: 0. Symbol: FESX202503_FUT_EUREX
2025-01-16 06:48:53.639 | HD Request # 3 | Decompressing data.
2025-01-16 06:48:53.740 | HD Request # 3 | Receiving Intraday data for F.US.DSXH25 starting at 2025-01-16 06:47:12.554000
2025-01-16 06:48:53.740 | Socket (3) | CloseSocket call.
2025-01-16 06:48:53.740 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-01-16 06:48:53.740 | Historical data download thread signaled to stop.
2025-01-16 06:48:53.740 | HD Request # 3 | Timestamp of first Intraday data file record written: 2025-01-16 06:47:14.952000.
2025-01-16 06:48:53.740 | HD Request # 3 | Received 76 Intraday data records from 2025-01-16 06:47:12.554000 to 2025-01-16 06:48:48.241002 (95.7 seconds. Delay: 5.5 seconds) and wrote 73 records for F.US.DSXH25
2025-01-16 06:48:53.741 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-01-16 06:48:48.241002
2025-01-16 06:48:53.741 | HD Request # 3 | Completion time: 1s.
2025-01-16 06:48:53.741 | HD Request # 3 | Intraday data download complete for F.US.DSXH25. Unique request ID: 2
2025-01-16 06:48:53.741 | Removing historical data download ID 2.
2025-01-16 06:48:53.741 | Real-time Intraday chart data file updates started for F.US.DSXH25
2025-01-16 06:48:53.741 | Intraday chart data file opened for F.US.DSXH25
2025-01-16 06:48:53.741 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-01-16 06:48:53.741 | No download requests in the queue to start downloads for.
2025-01-16 06:48:53.797 | Socket (3) | Socket gracefully closed by remote side.
2025-01-16 06:48:53.797 | Socket (3) | Closed.
2025-01-16 06:48:53.948 | Symbol settings MD5 received. Request ID: 2.
2025-01-16 06:48:53.948 | Symbol settings are up-to-date for cqg.
[2025-01-16 07:27:17]
Thank you. We have enough information now. We will work on a solution for this.
[2025-01-16 07:33:56]
Thank you for working on it, looking forward the answer, have a great day.
[2025-01-17 01:05:08]
How are you starting this new instance? It must be started with File >> New Instance. We are unable to reproduce this problem. We see no issue at all.
[2025-01-17 06:43:44]
Yes for sure I did File >> New Instance every time.
Never had an issue with anything before but that's indeed weird that only on an new instance only Eurex isn't working while all exchanges are, and on top of that when Eurex and all other exchanges are working perfectly on my main Sierra/Instance.
You can see on the screenshot attached I have the instance.
imageSierra instance.png / V - Attached On 2025-01-17 06:40:58 UTC - Size: 46.18 KB - 37 views
[2025-01-17 07:35:11]
At this point in time we do not understand the reason for the issue. The issue is not reproducible at all and we see no reason for the problem.
It would seem to be related to Symbol Settings. However, you have disabled custom symbol settings.
We apologize, but at this point we have no resolution for the problem.
Date Time Of Last Edit: 2025-01-17 07:35:21
[2025-01-17 07:39:28]
It is actually 100% clear after a code review, that if you are starting the instance with File >> New Instance that you should never be receiving this message:
Make sure you are not actually running the executable directly from that subfolder for the instance.
Date Time Of Last Edit: 2025-01-17 07:39:48
[2025-01-17 08:22:11]
Thanks for the answer, so where should I be expected to open the instance after creating that new one if not from subfolder ?
[2025-01-17 08:32:59]
It can only ever be started with File >> New Instance. You never run the executable directly from the folder. You must always start it with File >> New Instance. It needs to be done this way every time.
Date Time Of Last Edit: 2025-01-17 08:45:02
[2025-01-17 08:40:54]
Yes sure, that is what I've always been doing. So meaning that when I wanted a second instance of Sierra I did File >> New Instance and pinned to task bar the second instance to open it.
But the issue does not come from that because when I start from scratch so :
1. File >> New Instance from main Sierra ( everything works perfectly on Main Sierra )
2. Data is loading and Eurex works perfectly on the second Instance ( still no Issues )
3. But then only once I close that instance and re open it then that's when Eurex is not working anymore after all the steps of removing Custom Symbols etc...
So basically my Eurex data is only working on that new instance the first time its downloaded UNTIL I close that instance and re open it then Eurex only is Dead and I have to delete that instance and redo the same steps all over again
[2025-01-17 16:33:14]
John - SC Support - Posts: 39395
Do NOT pin the instance to the taskbar and start it from there. That is your problem.
You need to start sub-instances from the main instance by selecting "File >> New Instance" or by setting up the sub-instances to start automatically - refer to the following:
General Settings Window: Instances to Run on Startup (Global Settings >> General Settings >> General >> New Instances)
[2025-01-17 17:16:27]
Oh I see now ! that's not how I used to make it work in the past.
That fixed the issues, thank you so much for devoting so much time to find the solution.
I wish you an amazing day, take care.
