Date/Time: Wed, 12 Feb 2025 07:29:53 +0000
Issue logging into sierra chart
View Count: 829
[2020-10-11 22:56:06]
Mila - Posts: 44
I recently joined Sierra charts and working to set it up. I want to set up two Sierra charts for one TWS INTERACTIVE BROKERS DATA FEED ACCOUNT.
Sierra Charts software works well when I am on the same computer with TWS but second Sierra on my laptop, does not connect. I looked at your website for help on the issue, and found that you said to put my user and password into Data/Trade Service Settings but when I input Interactive Brokers(trading) into the Service Setting, I do not see such boxes where I can input my user and password for TWS, these box entries seem to be missing in the service settings scroll down. So I tried to put my user and password in the DTC- Sub Instance as both Username and Password boxes are available in the service specific settings there, still it does not work and second Sierra on my laptop is not connecting. Also I would like to add that I used separate Instance client IDs for each Sierra connection (different numbers) and for my laptop I used and internal IP address. As the button in TWS for allow local is unchecked. Can you please advice on what to do and how to fix so that my second Sierra Charts on my laptop is able to connect.
Thank you
Mila
[2020-10-11 23:21:17]
Where did you see this? The username is no longer used when connecting to Interactive Brokers Trader Workstation. So wherever this is mentioned it needs to be removed but we cannot find where this is.
So you are trying to connect to Trader Workstation which is running on a different computer than where Sierra Chart is installed? Not sure we can help with that. Although in general you will want to make sure that firewalls on the computers and network are just not blocking the connection.
Date Time Of Last Edit: 2020-10-11 23:22:31
[2020-10-12 00:48:30]
Mila - Posts: 44
There was a link in Sierra for user and password that I so, it is still up, I have to look for it but I will post it when I find it again.
Sierra website also states in its connection info for IB TWS which looks to be current info on how to connect to the data feed, that you can run multiple Sierra charts and are Allowed to connect to TWS from separate computer. Is this NOT TRUE any longer?? I am confused. Please Clarify.
[2020-10-12 00:55:28]
Mila - Posts: 44
Also I would like to add that I am using standalone version of TWS 978.2h
[2020-10-12 01:29:54]
Mila - Posts: 44
here is the link on Sierra talking about putting in a User and Passward into IB data feed:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php&CAID=default#ChangingDataTradeServiceSpecificSettings
[2020-10-12 15:33:56]
Yes this is supported, but the connectivity issue is something that you will need to resolve on your side.
We can confirm if it is a connectivity issue if you provide the Message Log after you try to connect. Instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2020-10-12 15:42:11
[2020-10-13 00:53:47]
Mila - Posts: 44
here is the log. please help if possible. thank you.
Reading Internal Order ID file. | 2020-10-12 20:51:14.432
Reading Trade Orders file. | 2020-10-12 20:51:14.535
Reading Trade Positions file. | 2020-10-12 20:51:14.535
Reading Account Balance file. | 2020-10-12 20:51:14.536
UDPListener (1468). Port 22904 | Listening on UDP port 22904. | 2020-10-12 20:51:14.558
Software version: 2177 64-bit | 2020-10-12 20:51:14.558
Primary Thread ID: 10248 | 2020-10-12 20:51:14.558
Usage end date: 2020-10-20 | 2020-10-12 20:51:14.558
Enabled for: Advanced Features 2. | 2020-10-12 20:51:14.559
Enabled for: Sierra Chart Historical Data Service. | 2020-10-12 20:51:14.559
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-12 20:51:14.559
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-12 20:51:14.559
Current selected Data/Trading service: DTC - Sub Instance | 2020-10-12 20:51:14.559
Custom symbol settings values: enabled | 2020-10-12 20:51:14.559
Chart Update Interval: 500 | 2020-10-12 20:51:14.559
Intraday Data Storage Time Unit: 1 | 2020-10-12 20:51:14.559
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-10-12 20:51:14.559
2020-10-12 20:51:14 Local computer time | 2020-10-12 20:51:14.559
2020-10-13 00:51:14 Local computer time in UTC | 2020-10-12 20:51:14.559
2020-10-12 20:51:14 Local computer time in SC Time Zone | 2020-10-12 20:51:14.559
2020-10-13 00:51:07 Server time in UTC | 2020-10-12 20:51:14.559
Local computer UTC time and Server UTC time difference: 7 seconds. | 2020-10-12 20:51:14.559
Notice: Your computer's clock is off by 7 seconds. For help with this, press the 'Send for Analysis' button. | 2020-10-12 20:51:14.559
Program path: C:\SierraChart\ | 2020-10-12 20:51:14.559
Data Files path: C:\SierraChart\Data\ | 2020-10-12 20:51:14.559
OS Version Number: 10.0 | 2020-10-12 20:51:14.559
Locale Setting: C | 2020-10-12 20:51:14.559
DLLs: UserContributedStudies_64.dll | 2020-10-12 20:51:14.559
Allowed protected custom studies: | 2020-10-12 20:51:14.559
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-10-12 20:51:14.624
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-10-12 20:51:14.981
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-10-12 20:51:14.982
Received 5 login tokens. | 2020-10-12 20:51:15.622
Files to Open on Start up | Opening file: ExampleChartbook.cht | 2020-10-12 20:51:18.845
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:51:20.850
DTC Client socket (1) | Creating socket. | 2020-10-12 20:51:20.850
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:51:20.851
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:51:20.851
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:51:22.866 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:51:22.867
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:51:22.867
DTC Client socket (1) | Closed. | 2020-10-12 20:51:22.867
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:51:22.867
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:22.867
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:51:22.876
DTC - Sub Instance | Disconnected. | 2020-10-12 20:51:22.876
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:22.876
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:51:25.898
DTC Client socket (1) | Creating socket. | 2020-10-12 20:51:25.898
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:51:25.898
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:51:25.898
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:51:27.908 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:51:27.908
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:51:27.908
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:51:27.908
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:27.908
DTC Client socket (1) | Closed. | 2020-10-12 20:51:27.908
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:51:27.923
DTC - Sub Instance | Disconnected. | 2020-10-12 20:51:27.923
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:27.924
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:51:30.926
DTC Client socket (1) | Creating socket. | 2020-10-12 20:51:30.926
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:51:30.926
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:51:30.926
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:51:32.950 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:51:32.951
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:51:32.951
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:51:32.951
DTC Client socket (1) | Closed. | 2020-10-12 20:51:32.951
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:32.951
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:51:32.966
DTC - Sub Instance | Disconnected. | 2020-10-12 20:51:32.966
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:32.966
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:51:35.981
DTC Client socket (1) | Creating socket. | 2020-10-12 20:51:35.981
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:51:35.982
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:51:35.982
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:51:37.999 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:51:38.000
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:51:38.000
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:51:38.000
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:38.000
DTC Client socket (1) | Closed. | 2020-10-12 20:51:38.000
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:51:38.015
DTC - Sub Instance | Disconnected. | 2020-10-12 20:51:38.015
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:38.015
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:51:41.013
DTC Client socket (1) | Creating socket. | 2020-10-12 20:51:41.013
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:51:41.013
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:51:41.013
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:51:43.052 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:51:43.052
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:51:43.052
DTC Client socket (1) | Closed. | 2020-10-12 20:51:43.052
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:51:43.053
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:43.053
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:51:43.068
DTC - Sub Instance | Disconnected. | 2020-10-12 20:51:43.068
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:43.068
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:51:46.091
DTC Client socket (1) | Creating socket. | 2020-10-12 20:51:46.091
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:51:46.092
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:51:46.092
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:51:48.097 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:51:48.097
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:51:48.097
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:51:48.097
DTC Client socket (1) | Closed. | 2020-10-12 20:51:48.097
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:48.097
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:51:48.112
DTC - Sub Instance | Disconnected. | 2020-10-12 20:51:48.113
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:48.113
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:51:51.138
DTC Client socket (1) | Creating socket. | 2020-10-12 20:51:51.138
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:51:51.138
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:51:51.138
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:51:53.162 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:51:53.162
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:51:53.162
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:51:53.163
DTC Client socket (1) | Closed. | 2020-10-12 20:51:53.163
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:53.163
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:51:53.178
DTC - Sub Instance | Disconnected. | 2020-10-12 20:51:53.178
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:53.178
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:51:56.182
DTC Client socket (1) | Creating socket. | 2020-10-12 20:51:56.182
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:51:56.182
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:51:56.182
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:51:58.214 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:51:58.214
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:51:58.214
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:51:58.214
DTC Client socket (1) | Closed. | 2020-10-12 20:51:58.214
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:58.214
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:51:58.229
DTC - Sub Instance | Disconnected. | 2020-10-12 20:51:58.230
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:51:58.230
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:01.221
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:01.221
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:01.221
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:01.221
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:03.260 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:03.260
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:03.260
DTC Client socket (1) | Closed. | 2020-10-12 20:52:03.260
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:03.260
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:03.260
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:03.277
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:03.277
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:03.278
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:06.281
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:06.281
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:06.281
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:06.281
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:08.319 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:08.320
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:08.320
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:08.320
DTC Client socket (1) | Closed. | 2020-10-12 20:52:08.320
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:08.320
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:08.336
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:08.336
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:08.336
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:11.333
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:11.333
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:11.334
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:11.334
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:13.359 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:13.359
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:13.359
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:13.359
DTC Client socket (1) | Closed. | 2020-10-12 20:52:13.359
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:13.359
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:13.374
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:13.375
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:13.375
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:16.382
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:16.382
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:16.382
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:16.382
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:18.412 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:18.412
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:18.412
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:18.412
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:18.412
DTC Client socket (1) | Closed. | 2020-10-12 20:52:18.412
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:18.427
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:18.427
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:18.427
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:21.424
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:21.424
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:21.424
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:21.425
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:23.450 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:23.450
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:23.450
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:23.451
DTC Client socket (1) | Closed. | 2020-10-12 20:52:23.451
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:23.451
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:23.467
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:23.467
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:23.467
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:26.465
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:26.465
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:26.466
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:26.466
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:28.487 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:28.487
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:28.487
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:28.487
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:28.487
DTC Client socket (1) | Closed. | 2020-10-12 20:52:28.487
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:28.503
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:28.503
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:28.503
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:31.516
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:31.516
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:31.516
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:31.516
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:33.552 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:33.552
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:33.552
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:33.552
DTC Client socket (1) | Closed. | 2020-10-12 20:52:33.552
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:33.552
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:33.567
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:33.567
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:33.567
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:36.586
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:36.586
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:36.586
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:36.586
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:38.601 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:38.601
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:38.601
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:38.601
DTC Client socket (1) | Closed. | 2020-10-12 20:52:38.601
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:38.601
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:38.616
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:38.617
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:38.617
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:41.621
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:41.621
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:41.622
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:41.622
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:43.657 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:43.657
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:43.657
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:43.657
DTC Client socket (1) | Closed. | 2020-10-12 20:52:43.657
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:43.658
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:43.673
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:43.673
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:43.673
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:46.676
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:46.676
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:46.676
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:46.676
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 20:52:48.695 *
DTC Client socket (1) | CloseSocket call. | 2020-10-12 20:52:48.695
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 20:52:48.695
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 20:52:48.695
DTC Client socket (1) | Closed. | 2020-10-12 20:52:48.695
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:48.695
DTC Client socket (0) | CloseSocket call. | 2020-10-12 20:52:48.711
DTC - Sub Instance | Disconnected. | 2020-10-12 20:52:48.711
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 20:52:48.711
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 80 | 2020-10-12 20:52:51.729
DTC Client socket (1) | Creating socket. | 2020-10-12 20:52:51.729
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-12 20:52:51.729
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 20:52:51.729
[2020-10-13 02:20:24]
You need to follow the Interactive Brokers set up instructions here:
Interactive Brokers Trading Service: Setup Instructions
You have the wrong service set in Sierra Chart. You do not need to use a username or password. This is just not relevant when connecting to TWS.
[2020-10-13 03:39:17]
Mila - Posts: 44
I am sorry i sent you the wrong log. I was trying different setting ext and didn't reset it back to IB.
I went through Ib set up, its all exactly how the instructions show.
below is the IB log, its still not connecting.
Reading Internal Order ID file. | 2020-10-12 23:38:33.961
Reading Trade Orders file. | 2020-10-12 23:38:34.061
Reading Trade Positions file. | 2020-10-12 23:38:34.061
Reading Account Balance file. | 2020-10-12 23:38:34.061
UDPListener (1456). Port 22904 | Listening on UDP port 22904. | 2020-10-12 23:38:34.089
Software version: 2177 64-bit | 2020-10-12 23:38:34.089
Primary Thread ID: 12848 | 2020-10-12 23:38:34.089
Usage end date: 2020-10-20 | 2020-10-12 23:38:34.089
Enabled for: Advanced Features 2. | 2020-10-12 23:38:34.089
Enabled for: Sierra Chart Historical Data Service. | 2020-10-12 23:38:34.089
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-12 23:38:34.089
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-12 23:38:34.089
Current selected Data/Trading service: Interactive Brokers | 2020-10-12 23:38:34.089
Custom symbol settings values: enabled | 2020-10-12 23:38:34.089
Chart Update Interval: 500 | 2020-10-12 23:38:34.089
Intraday Data Storage Time Unit: 1 | 2020-10-12 23:38:34.089
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-10-12 23:38:34.089
2020-10-12 23:38:34 Local computer time | 2020-10-12 23:38:34.089
2020-10-13 03:38:34 Local computer time in UTC | 2020-10-12 23:38:34.089
2020-10-12 23:38:34 Local computer time in SC Time Zone | 2020-10-12 23:38:34.089
2020-10-13 03:38:26 Server time in UTC | 2020-10-12 23:38:34.089
Local computer UTC time and Server UTC time difference: 7 seconds. | 2020-10-12 23:38:34.089
Notice: Your computer's clock is off by 7 seconds. For help with this, press the 'Send for Analysis' button. | 2020-10-12 23:38:34.089
Program path: C:\SierraChart\ | 2020-10-12 23:38:34.089
Data Files path: C:\SierraChart\Data\ | 2020-10-12 23:38:34.089
OS Version Number: 10.0 | 2020-10-12 23:38:34.089
Locale Setting: C | 2020-10-12 23:38:34.089
DLLs: UserContributedStudies_64.dll | 2020-10-12 23:38:34.089
Allowed protected custom studies: | 2020-10-12 23:38:34.090
Checking for new symbol settings. Requested symbol settings MD5 for service code interactive_brokers.trading. Request ID: 1. | 2020-10-12 23:38:34.123
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-10-12 23:38:34.166
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-10-12 23:38:34.429
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-10-12 23:38:34.429
Received 5 login tokens. | 2020-10-12 23:38:35.080
Symbol settings MD5 received. Request ID: 1. | 2020-10-12 23:38:35.662
Symbol settings are up-to-date for interactive_brokers.trading. | 2020-10-12 23:38:35.662
Files to Open on Start up | Opening file: ExampleChartbook.cht | 2020-10-12 23:38:38.194
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2020-10-12 23:38:40.220
IB TWS socket (1) | Creating socket. | 2020-10-12 23:38:40.220
IB TWS socket (1) | New receive buffer size: 5242880 | 2020-10-12 23:38:40.220
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 23:38:40.220
IB TWS socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 23:38:42.251 *
IB TWS socket (1) | CloseSocket call. | 2020-10-12 23:38:42.251
IB TWS socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 23:38:42.251
Interactive Brokers | Failed to connect to the data and trade server. | 2020-10-12 23:38:42.252 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2020-10-12 23:38:42.252 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 23:38:42.252
IB TWS socket (1) | Closed. | 2020-10-12 23:38:42.252
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 23:38:42.252
IB TWS socket (0) | CloseSocket call. | 2020-10-12 23:38:42.297
Interactive Brokers | Disconnected. | 2020-10-12 23:38:42.297
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 23:38:42.297
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2020-10-12 23:38:45.287
IB TWS socket (1) | Creating socket. | 2020-10-12 23:38:45.287
IB TWS socket (1) | New receive buffer size: 5242880 | 2020-10-12 23:38:45.287
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2020-10-12 23:38:45.287
IB TWS socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-10-12 23:38:47.296 *
IB TWS socket (1) | CloseSocket call. | 2020-10-12 23:38:47.296
IB TWS socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-12 23:38:47.296
Interactive Brokers | Failed to connect to the data and trade server. | 2020-10-12 23:38:47.296 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2020-10-12 23:38:47.296 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-12 23:38:47.296
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 23:38:47.296
IB TWS socket (1) | Closed. | 2020-10-12 23:38:47.296
IB TWS socket (0) | CloseSocket call. | 2020-10-12 23:38:47.303
Interactive Brokers | Disconnected. | 2020-10-12 23:38:47.303
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-12 23:38:47.304
[2020-10-13 03:48:44]
Is Trader Workstation running on the computer you are trying to connect from?
Date Time Of Last Edit: 2020-10-13 03:48:57
[2020-10-13 06:38:43]
Mila - Posts: 44
No it is not. I have Trader Workstation on one computer with Sierra working very well and I am trying to hook up second Sierra to the same Trader Workstation on separate computer, and that Sierra is not connecting, the one on separate computer.
Allow connection from localhost only is Uchecked on TWS and i have put in my internal IP address for the Trusted IPs in TWS, its still not connecting.
[2020-10-13 10:09:11]
You need to change the Global Settings >> Data/Trade Service Settings >> Server Address in Sierra Chart for TWS. You are currently using the local system IP:
The port number should be left the same.
Date Time Of Last Edit: 2020-10-13 18:55:09
[2020-10-13 21:06:14]
Mila - Posts: 44
In the Global settings> Data/Trade Service Settings>> Server Address I have changed the Server Address and Port to TWS and Sierra is not connecting. I have also tried to input into Server Address and Port TWS 127.0.0.1:7496 because you said to leave port number the same, its still not connecting. I must not be understanding you clearly.
So currently my settings are: Global Settings> Data/Trade Service Settings>> Service is set to Interactive Brokers(trading) and in the scroll down, Server Address and Port is set to TWS and Sierra is not connecting. I am not sure what to do with the port number or where to input it? Please clarify for me.
Below it the log.
Reading Internal Order ID file. | 2020-10-13 17:04:44.632
Reading Trade Orders file. | 2020-10-13 17:04:44.738
Reading Trade Positions file. | 2020-10-13 17:04:44.739
Reading Account Balance file. | 2020-10-13 17:04:44.739
UDPListener (1456). Port 22904 | Listening on UDP port 22904. | 2020-10-13 17:04:44.763
Software version: 2177 64-bit | 2020-10-13 17:04:44.763
Primary Thread ID: 1348 | 2020-10-13 17:04:44.763
Usage end date: 2020-10-20 | 2020-10-13 17:04:44.763
Enabled for: Advanced Features 2. | 2020-10-13 17:04:44.763
Enabled for: Sierra Chart Historical Data Service. | 2020-10-13 17:04:44.763
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-13 17:04:44.763
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-13 17:04:44.763
Current selected Data/Trading service: Interactive Brokers | 2020-10-13 17:04:44.763
Custom symbol settings values: enabled | 2020-10-13 17:04:44.763
Chart Update Interval: 500 | 2020-10-13 17:04:44.763
Intraday Data Storage Time Unit: 1 | 2020-10-13 17:04:44.763
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-10-13 17:04:44.763
2020-10-13 17:04:44 Local computer time | 2020-10-13 17:04:44.763
2020-10-13 21:04:44 Local computer time in UTC | 2020-10-13 17:04:44.763
2020-10-13 17:04:44 Local computer time in SC Time Zone | 2020-10-13 17:04:44.763
2020-10-13 21:04:36 Server time in UTC | 2020-10-13 17:04:44.763
Local computer UTC time and Server UTC time difference: 8 seconds. | 2020-10-13 17:04:44.763
Notice: Your computer's clock is off by 8 seconds. For help with this, press the 'Send for Analysis' button. | 2020-10-13 17:04:44.763
Program path: C:\SierraChart\ | 2020-10-13 17:04:44.763
Data Files path: C:\SierraChart\Data\ | 2020-10-13 17:04:44.763
OS Version Number: 10.0 | 2020-10-13 17:04:44.763
Locale Setting: C | 2020-10-13 17:04:44.763
DLLs: UserContributedStudies_64.dll | 2020-10-13 17:04:44.763
Allowed protected custom studies: | 2020-10-13 17:04:44.763
Checking for new symbol settings. Requested symbol settings MD5 for service code interactive_brokers.trading. Request ID: 1. | 2020-10-13 17:04:44.764
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-10-13 17:04:44.806
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-10-13 17:04:45.053
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-10-13 17:04:45.053
Received 5 login tokens. | 2020-10-13 17:04:45.560
Symbol settings MD5 received. Request ID: 1. | 2020-10-13 17:04:46.206
Symbol settings are up-to-date for interactive_brokers.trading. | 2020-10-13 17:04:46.206
Files to Open on Start up | Opening file: ExampleChartbook.cht | 2020-10-13 17:04:49.071
Interactive Brokers | Connecting to TWS:7496 | 2020-10-13 17:04:51.085
Error getting address info for TWS. Windows error code 11001: No such host is known. | 2020-10-13 17:04:53.355 *
IB TWS socket (1) | CloseSocket call. | 2020-10-13 17:04:53.355
IB TWS socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-13 17:04:53.355
Interactive Brokers | Failed to connect to the data and trade server. | 2020-10-13 17:04:53.355 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2020-10-13 17:04:53.355 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-13 17:04:53.355
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-13 17:04:53.356
IB TWS socket (0) | CloseSocket call. | 2020-10-13 17:04:53.398
Interactive Brokers | Disconnected. | 2020-10-13 17:04:53.398
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-13 17:04:53.398
Interactive Brokers | Connecting to TWS:7496 | 2020-10-13 17:04:56.416
Error getting address info for TWS. Windows error code 11001: No such host is known. | 2020-10-13 17:04:58.718 *
IB TWS socket (1) | CloseSocket call. | 2020-10-13 17:04:58.718
IB TWS socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-13 17:04:58.718
Interactive Brokers | Failed to connect to the data and trade server. | 2020-10-13 17:04:58.718 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2020-10-13 17:04:58.718 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-13 17:04:58.718
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-13 17:04:58.719
IB TWS socket (0) | CloseSocket call. | 2020-10-13 17:04:58.734
Interactive Brokers | Disconnected. | 2020-10-13 17:04:58.734
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-13 17:04:58.734
Interactive Brokers | Connecting to TWS:7496 | 2020-10-13 17:05:01.722
Error getting address info for TWS. Windows error code 11001: No such host is known. | 2020-10-13 17:05:03.983 *
IB TWS socket (1) | CloseSocket call. | 2020-10-13 17:05:03.983
IB TWS socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-13 17:05:03.983
Interactive Brokers | Failed to connect to the data and trade server. | 2020-10-13 17:05:03.983 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2020-10-13 17:05:03.983 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-10-13 17:05:03.983
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-13 17:05:03.983
IB TWS socket (0) | CloseSocket call. | 2020-10-13 17:05:04.023
Interactive Brokers | Disconnected. | 2020-10-13 17:05:04.023
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-10-13 17:05:04.023
[2020-10-14 01:29:52]
You do have to specify the IP address. What is your local area network IP where TWS is running?
[2020-10-14 01:34:37]
Mila - Posts: 44
TWS is running on computer with IPv4 address: 192.168.200.252
where do i need to input this number? thank you
[2020-10-14 03:02:53]
Mila - Posts: 44
I got it, THANK YOU! I INPUTED THE INTERNAL IP ON THE COMPUTER TWS IS RUNNING ON INTO SERVER ADDRESS AND PORT AND IT WORKED, SECOND SIERRA IS UP AND RUNNING. THANK YOU VERY MUCH FOR ALL THE HELP!
[2020-10-14 03:04:07]
Yes that is correct.
[2020-10-14 03:09:54]
Mila - Posts: 44
BIG THANK YOU! :)
