Date/Time: Thu, 06 Feb 2025 15:17:55 +0000
Transact Account logon error
View Count: 1918
[2019-08-01 16:54:03]
User201847 - Posts: 1
After updating the new version and opening the platform an error message comes up stating "Connection error message from service:TransAct WS\Account Login error-1(-1)\Date-time 2019-08-01." Please advise me on a correction of this problem. Thank you.
[2019-08-01 17:39:32]
conr - Posts: 204
Engineering, this is the exact message I'm getting and I reported this on another thread. Your response: "Ok we are not sure why. We do not observe this ourselves but there may be a problem for some users but that would be something on the Transact authorization side."
I contacted Transact and they said as of today, they have been inundated with calls from Sierra users and that it is nothing on their end. I have wasted half my day between this and trying to figure out the whole Denali feed.
[2019-08-01 18:48:27]
In regards to this, it is not true that it is nothing on their end at least in regards to the first postIn this thread. There is quite a clear express account logon error being given.
However, what we are seeing now in testing is they are closing the orders connection without any proper error message. And that condition is something we did not account for even though the orders connection has no longer been required in recent versions. So we need to accommodate that. We will have a new release in about 20 minutes.
So there is a different behavior on their side.
[2019-08-01 19:31:41]
We have added a patch for this and this is in prerelease 1966. It is fine to use the prerelease.:
Date Time Of Last Edit: 2019-08-01 19:32:03
[2019-08-02 22:17:01]
conr - Posts: 204
Downloaded 1968 and getting the same message.
Software version: 1968 64-bit | 2019-08-02 17:13:05.601
Usage end date: 2019-09-14 | 2019-08-02 17:13:05.601
Enabled for: Advanced Features 2. | 2019-08-02 17:13:05.601
Enabled for: Sierra Chart Historical Data Service. | 2019-08-02 17:13:05.601
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-08-02 17:13:05.601
Enabled for exchange: INDEXES_DATA_BARCHART | 2019-08-02 17:13:05.601
Enabled for exchange: CME with Market Depth for nonprofessional Trading accounts | 2019-08-02 17:13:05.601
Received 1 data feed usernames. | 2019-08-02 17:13:05.601
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-08-02 17:13:05.601
Current selected Data/Trading service: SC Data - All Services | 2019-08-02 17:13:05.601
Custom symbol settings values: disabled | 2019-08-02 17:13:05.601
Chart Update Interval: 900 | 2019-08-02 17:13:05.601
Intraday Data Storage Time Unit: 0 | 2019-08-02 17:13:05.601
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-08-02 17:13:05.601
2019-08-02 17:13:05 Local computer time | 2019-08-02 17:13:05.601
2019-08-02 22:13:05 Local computer time in UTC | 2019-08-02 17:13:05.601
2019-08-02 17:13:05 Local computer time in SC Time Zone | 2019-08-02 17:13:05.601
2019-08-02 18:07:21 Server time in UTC | 2019-08-02 17:13:05.601
Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-08-02 17:13:05.601
Program path: C:\SierraChart\ | 2019-08-02 17:13:05.601
Data Files path: C:\SierraChart\Data\ | 2019-08-02 17:13:05.601
OS Version Number: 10.0 | 2019-08-02 17:13:05.602
Locale Setting: C | 2019-08-02 17:13:05.602
DLLs: AdaptiveVolumeRatio_MAByTick.dll, IOAMT.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-08-02 17:13:05.604
SC Data - All Services | Disconnected. | 2019-08-02 17:13:23.707
SC Data - All Services | Disconnected. | 2019-08-02 17:13:23.740
Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 3. | 2019-08-02 17:13:23.743
Current selected Data/Trading service: TransAct WS | 2019-08-02 17:13:23.743
Symbol settings MD5 received. Request ID: 3. | 2019-08-02 17:13:24.423
Requested symbol settings for service code transact.trading. Request ID: 4. | 2019-08-02 17:13:24.423
Symbol settings received. Request ID: 4. | 2019-08-02 17:13:25.202
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-08-02 17:13:27.064
Auth Websocket | Connecting to WebSocket server. | 2019-08-02 17:13:27.065
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-08-02 17:13:27.065
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-08-02 17:13:27.065
Auth Websocket | Opening WebSocket. | 2019-08-02 17:13:27.096
Auth Websocket | Sending WebSocket handshake. | 2019-08-02 17:13:27.096
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-08-02 17:13:27.197
Auth Websocket | Server header | Upgrade: WebSocket | 2019-08-02 17:13:27.197
Auth Websocket | Server header | Connection: Upgrade | 2019-08-02 17:13:27.197
Auth Websocket | Server header | Sec-WebSocket-Accept: 4XSjXK4aWzUezP1fqh9plYab33I= | 2019-08-02 17:13:27.197
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-08-02 17:13:27.197
Auth Websocket | Server header | | 2019-08-02 17:13:27.197
Auth Websocket | Web socket state is now open. | 2019-08-02 17:13:27.197
TransAct WS | Sending account logon message. Simulated Live | 2019-08-02 17:13:27.197
TransAct WS | Account logon error: -1(-1) | 2019-08-02 17:13:27.227
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-02 17:13:27.227
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:27.227
Auth Websocket | WebSocket closed. | 2019-08-02 17:13:27.328
TransAct WS | Disconnected. | 2019-08-02 17:13:27.328
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:27.328
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-08-02 17:13:27.328
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-08-02 17:13:27.356
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-02 17:13:27.356
Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-08-02 17:13:27.384
Auth Websocket socket (1) | Closed. | 2019-08-02 17:13:27.384
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-08-02 17:13:30.315
Auth Websocket | Connecting to WebSocket server. | 2019-08-02 17:13:30.315
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-08-02 17:13:30.315
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-08-02 17:13:30.315
Auth Websocket | Opening WebSocket. | 2019-08-02 17:13:30.343
Auth Websocket | Sending WebSocket handshake. | 2019-08-02 17:13:30.343
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-08-02 17:13:30.441
Auth Websocket | Server header | Upgrade: WebSocket | 2019-08-02 17:13:30.441
Auth Websocket | Server header | Connection: Upgrade | 2019-08-02 17:13:30.441
Auth Websocket | Server header | Sec-WebSocket-Accept: ufRB05UfrUcT8A4bjF0nJQgolyI= | 2019-08-02 17:13:30.441
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-08-02 17:13:30.441
Auth Websocket | Server header | | 2019-08-02 17:13:30.441
Auth Websocket | Web socket state is now open. | 2019-08-02 17:13:30.441
TransAct WS | Sending account logon message. Simulated Live | 2019-08-02 17:13:30.441
TransAct WS | Account logon error: -1(-1) | 2019-08-02 17:13:30.471
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-02 17:13:30.471
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:30.471
Auth Websocket | WebSocket closed. | 2019-08-02 17:13:30.486
TransAct WS | Disconnected. | 2019-08-02 17:13:30.486
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:30.486
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-08-02 17:13:30.486
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-08-02 17:13:30.514
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-02 17:13:30.514
Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-08-02 17:13:30.542
Auth Websocket socket (1) | Closed. | 2019-08-02 17:13:30.542
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-08-02 17:13:33.486
Auth Websocket | Connecting to WebSocket server. | 2019-08-02 17:13:33.486
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-08-02 17:13:33.486
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-08-02 17:13:33.486
Auth Websocket | Opening WebSocket. | 2019-08-02 17:13:33.515
Auth Websocket | Sending WebSocket handshake. | 2019-08-02 17:13:33.515
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-08-02 17:13:33.616
Auth Websocket | Server header | Upgrade: WebSocket | 2019-08-02 17:13:33.616
Auth Websocket | Server header | Connection: Upgrade | 2019-08-02 17:13:33.616
Auth Websocket | Server header | Sec-WebSocket-Accept: pRpLutYz2kVeWHWUwqpRJ22Q1ds= | 2019-08-02 17:13:33.616
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-08-02 17:13:33.616
Auth Websocket | Server header | | 2019-08-02 17:13:33.616
Auth Websocket | Web socket state is now open. | 2019-08-02 17:13:33.616
TransAct WS | Sending account logon message. Simulated Live | 2019-08-02 17:13:33.616
TransAct WS | Account logon error: -1(-1) | 2019-08-02 17:13:33.645
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-02 17:13:33.645
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:33.645
Auth Websocket | WebSocket closed. | 2019-08-02 17:13:33.658
TransAct WS | Disconnected. | 2019-08-02 17:13:33.658
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:33.658
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-08-02 17:13:33.658
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-08-02 17:13:33.688
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-02 17:13:33.688
Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-08-02 17:13:33.715
Auth Websocket socket (1) | Closed. | 2019-08-02 17:13:33.715
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-08-02 17:13:36.658
Auth Websocket | Connecting to WebSocket server. | 2019-08-02 17:13:36.658
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-08-02 17:13:36.658
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-08-02 17:13:36.658
Auth Websocket | Opening WebSocket. | 2019-08-02 17:13:36.687
Auth Websocket | Sending WebSocket handshake. | 2019-08-02 17:13:36.687
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-08-02 17:13:36.786
Auth Websocket | Server header | Upgrade: WebSocket | 2019-08-02 17:13:36.786
Auth Websocket | Server header | Connection: Upgrade | 2019-08-02 17:13:36.786
Auth Websocket | Server header | Sec-WebSocket-Accept: kiFFHV8WCKyAzt5msZTA3UPB2Tg= | 2019-08-02 17:13:36.786
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-08-02 17:13:36.786
Auth Websocket | Server header | | 2019-08-02 17:13:36.786
Auth Websocket | Web socket state is now open. | 2019-08-02 17:13:36.786
TransAct WS | Sending account logon message. Simulated Live | 2019-08-02 17:13:36.786
TransAct WS | Account logon error: -1(-1) | 2019-08-02 17:13:36.816
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-02 17:13:36.816
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:36.816
Auth Websocket | WebSocket closed. | 2019-08-02 17:13:36.830
TransAct WS | Disconnected. | 2019-08-02 17:13:36.830
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:36.830
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-08-02 17:13:36.830
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-08-02 17:13:36.858
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-02 17:13:36.858
Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-08-02 17:13:36.886
Auth Websocket socket (1) | Closed. | 2019-08-02 17:13:36.886
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-08-02 17:13:39.830
Auth Websocket | Connecting to WebSocket server. | 2019-08-02 17:13:39.830
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-08-02 17:13:39.830
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-08-02 17:13:39.830
Auth Websocket | Opening WebSocket. | 2019-08-02 17:13:39.859
Auth Websocket | Sending WebSocket handshake. | 2019-08-02 17:13:39.859
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-08-02 17:13:39.958
Auth Websocket | Server header | Upgrade: WebSocket | 2019-08-02 17:13:39.958
Auth Websocket | Server header | Connection: Upgrade | 2019-08-02 17:13:39.958
Auth Websocket | Server header | Sec-WebSocket-Accept: +r1uM9ECh59mkOArJhAIe0l+c88= | 2019-08-02 17:13:39.958
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-08-02 17:13:39.958
Auth Websocket | Server header | | 2019-08-02 17:13:39.958
Auth Websocket | Web socket state is now open. | 2019-08-02 17:13:39.958
TransAct WS | Sending account logon message. Simulated Live | 2019-08-02 17:13:39.958
TransAct WS | Account logon error: -1(-1) | 2019-08-02 17:13:39.987
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-02 17:13:39.987
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:39.987
Auth Websocket | WebSocket closed. | 2019-08-02 17:13:40.001
TransAct WS | Disconnected. | 2019-08-02 17:13:40.001
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:40.001
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-08-02 17:13:40.002
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-08-02 17:13:40.030
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-02 17:13:40.030
Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-08-02 17:13:40.058
Auth Websocket socket (1) | Closed. | 2019-08-02 17:13:40.058
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-08-02 17:13:43.017
Auth Websocket | Connecting to WebSocket server. | 2019-08-02 17:13:43.017
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-08-02 17:13:43.017
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-08-02 17:13:43.017
Auth Websocket | Opening WebSocket. | 2019-08-02 17:13:43.046
Auth Websocket | Sending WebSocket handshake. | 2019-08-02 17:13:43.046
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-08-02 17:13:43.145
Auth Websocket | Server header | Upgrade: WebSocket | 2019-08-02 17:13:43.145
Auth Websocket | Server header | Connection: Upgrade | 2019-08-02 17:13:43.145
Auth Websocket | Server header | Sec-WebSocket-Accept: UovLU01FjAtZPHZeHxrq2UaNGuQ= | 2019-08-02 17:13:43.145
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-08-02 17:13:43.145
Auth Websocket | Server header | | 2019-08-02 17:13:43.145
Auth Websocket | Web socket state is now open. | 2019-08-02 17:13:43.145
TransAct WS | Sending account logon message. Simulated Live | 2019-08-02 17:13:43.145
TransAct WS | Account logon error: -1(-1) | 2019-08-02 17:13:43.175
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-02 17:13:43.175
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:43.175
Auth Websocket | WebSocket closed. | 2019-08-02 17:13:43.189
TransAct WS | Disconnected. | 2019-08-02 17:13:43.189
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-02 17:13:43.189
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-08-02 17:13:43.189
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-08-02 17:13:43.218
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-02 17:13:43.218
Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-08-02 17:13:43.246
Auth Websocket socket (1) | Closed. | 2019-08-02 17:13:43.246
[2019-08-03 09:09:20]
Transact support will need to help you with this:
[2019-08-03 14:45:15]
conr - Posts: 204
I'm assuming we need to schedule a phone call?
[2019-08-04 22:16:51]
We do not see how we can help with this other than to guide you to set the appropriate Transact settings in Global Settings >> Data/Trade Service Settings, in the settings on the left. But we are not going to know what those should be.
We could call and bring Transact into the call but that is about the best we can do. Let us know how you want to proceed.
Date Time Of Last Edit: 2019-08-04 22:17:39
[2019-08-04 22:40:58]
conr - Posts: 204
Truthfully I misread your post. I read it as you would help with this. I will contact them again and provide them with the exact error message.
[2019-08-05 00:11:39]
Ok, just let us know how it goes. If you have trouble we will give them a call on your behalf.
[2019-08-05 01:21:31]
Transact did contact us about this. And we gave them some basic details of parameters being sent to their Authentication websocket server. They will look into it in the morning.
[2019-08-05 09:28:33]
We wonder if the problem has to do with the particular Mode parameter given to the authentication API. It might have to be a single letter but we don't think that matters based on testing.
We set the mode to a single letter in the latest prerelease which is now 1969. Follow the instructions here to update and see if that makes any difference:
But wait about 30 minutes because we still have not yet released it.
[2019-08-05 10:41:00]
User41683 - Posts: 37
I tried version 1969. Still the same error.
Why don't you also implement the TransAct Trading connection you use in version 1941?
[2019-08-05 12:44:29]
conr - Posts: 204
Installed 1969 and same thing.
[2019-08-05 22:05:51]
conr - Posts: 204
Received an email from Transact that I could connect. I was able to connect but not receiving data.
Software version: 1969 32-bit | 2019-08-05 17:00:27.317
Usage end date: 2019-09-14 | 2019-08-05 17:00:27.317
Enabled for: Advanced Features 2. | 2019-08-05 17:00:27.317
Enabled for: Sierra Chart Historical Data Service. | 2019-08-05 17:00:27.317
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-08-05 17:00:27.317
Enabled for exchange: INDEXES_DATA_BARCHART | 2019-08-05 17:00:27.317
Enabled for exchange: CME with Market Depth for nonprofessional Trading accounts | 2019-08-05 17:00:27.317
Received 1 data feed usernames. | 2019-08-05 17:00:27.317
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-08-05 17:00:27.317
Current selected Data/Trading service: SC Data - All Services | 2019-08-05 17:00:27.317
Custom symbol settings values: disabled | 2019-08-05 17:00:27.317
Chart Update Interval: 900 | 2019-08-05 17:00:27.317
Intraday Data Storage Time Unit: 0 | 2019-08-05 17:00:27.317
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-08-05 17:00:27.317
2019-08-05 17:00:27 Local computer time | 2019-08-05 17:00:27.317
2019-08-05 22:00:27 Local computer time in UTC | 2019-08-05 17:00:27.317
2019-08-05 17:00:27 Local computer time in SC Time Zone | 2019-08-05 17:00:27.317
2019-08-05 20:23:46 Server time in UTC | 2019-08-05 17:00:27.317
Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-08-05 17:00:27.317
Program path: C:\SierraChart\ | 2019-08-05 17:00:27.317
Data Files path: C:\SierraChart\Data\ | 2019-08-05 17:00:27.317
OS Version Number: 10.0 | 2019-08-05 17:00:27.317
Locale Setting: C | 2019-08-05 17:00:27.317
DLLs: AdaptiveVolumeRatio_MAByTick.dll, IOAMT.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-08-05 17:00:27.319
SC Data - All Services | Connected to data server. | 2019-08-05 17:00:53.530
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2019-08-05 17:00:53.531
SC Data - All Services | Starting real-time market data updates for: ESU19. ID: 1 | 2019-08-05 17:00:53.977
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESU19 | 2019-08-05 17:00:53.977
SC Data - All Services | Requesting security definition data for: ESU19. ID: 1 | 2019-08-05 17:00:53.977
Added Intraday data request for ESU19 to the queue. | 2019-08-05 17:00:53.977
Intraday data recording state for symbol ESU19 is set to download 'Pending'. | 2019-08-05 17:00:53.977
Delaying start of download for ESU19 | 2019-08-05 17:00:54.056
SC DTC Data with Market Depth | Starting real-time market data updates for: DVOL-SP. ID: 2 Service code: statscalc | 2019-08-05 17:00:54.256
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2019-08-05 17:00:54.256
SC DTC Data with Market Depth | Requesting security definition data for: DVOL-SP. ID: 2 | 2019-08-05 17:00:54.256
DTC Client socket (1) | Creating socket. | 2019-08-05 17:00:54.257
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2019-08-05 17:00:54.257
SC Data - All Services | Starting real-time market data updates for: @ES#c. ID: 3 | 2019-08-05 17:00:54.257
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: @ES#c | 2019-08-05 17:00:54.257
SC Data - All Services | Requesting security definition data for: @ES#c. ID: 3 | 2019-08-05 17:00:54.257
No historical data client is currently set to download historical Intraday data for @ES#c. | 2019-08-05 17:00:54.257
Real-time Intraday chart data file updates started for @ES#c | 2019-08-05 17:00:54.257
Intraday chart data file opened for @ES#c | 2019-08-05 17:00:54.257
SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-SP. ID: 4 Service code: statscalc | 2019-08-05 17:00:54.258
SC DTC Data with Market Depth | Requesting security definition data for: NISS-SP. ID: 4 | 2019-08-05 17:00:54.258
Added Intraday data request for NISS-SP to the queue. | 2019-08-05 17:00:54.258
Intraday data recording state for symbol NISS-SP is set to download 'Pending'. | 2019-08-05 17:00:54.258
SC Data - All Services | Starting real-time market data updates for: ESH19. ID: 5 | 2019-08-05 17:00:54.264
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESH19 | 2019-08-05 17:00:54.264
SC Data - All Services | Requesting security definition data for: ESH19. ID: 5 | 2019-08-05 17:00:54.264
Added Intraday data request for ESH19 to the queue. | 2019-08-05 17:00:54.264
Intraday data recording state for symbol ESH19 is set to download 'Pending'. | 2019-08-05 17:00:54.264
SC Data - All Services | Starting real-time market data updates for: TICKBA-NYSE. ID: 6 | 2019-08-05 17:00:54.266
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: TICKBA-NYSE | 2019-08-05 17:00:54.266
SC Data - All Services | Requesting security definition data for: TICKBA-NYSE. ID: 6 | 2019-08-05 17:00:54.266
No historical data client is currently set to download historical Intraday data for TICKBA-NYSE. | 2019-08-05 17:00:54.266
Real-time Intraday chart data file updates started for TICKBA-NYSE | 2019-08-05 17:00:54.266
Intraday chart data file opened for TICKBA-NYSE | 2019-08-05 17:00:54.266
SC Data - All Services | Starting real-time market data updates for: VI6A.Z. ID: 7 | 2019-08-05 17:00:54.267
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: VI6A.Z | 2019-08-05 17:00:54.267
SC Data - All Services | Requesting security definition data for: VI6A.Z. ID: 7 | 2019-08-05 17:00:54.267
No historical data client is currently set to download historical Intraday data for VI6A.Z. | 2019-08-05 17:00:54.267
Real-time Intraday chart data file updates started for VI6A.Z | 2019-08-05 17:00:54.267
Intraday chart data file opened for VI6A.Z | 2019-08-05 17:00:54.267
SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 8 Service code: statscalc | 2019-08-05 17:00:54.267
SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 8 | 2019-08-05 17:00:54.267
Added Intraday data request for TICK-NYSE to the queue. | 2019-08-05 17:00:54.267
Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2019-08-05 17:00:54.267
SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-SP. ID: 9 Service code: statscalc | 2019-08-05 17:00:54.288
SC DTC Data with Market Depth | Requesting security definition data for: ADR-SP. ID: 9 | 2019-08-05 17:00:54.288
Added Intraday data request for ADR-SP to the queue. | 2019-08-05 17:00:54.288
Intraday data recording state for symbol ADR-SP is set to download 'Pending'. | 2019-08-05 17:00:54.288
SC Data - All Services | Starting real-time market data updates for: JV6T.Z. ID: 10 | 2019-08-05 17:00:54.291
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: JV6T.Z | 2019-08-05 17:00:54.291
SC Data - All Services | Requesting security definition data for: JV6T.Z. ID: 10 | 2019-08-05 17:00:54.291
No historical data client is currently set to download historical Intraday data for JV6T.Z. | 2019-08-05 17:00:54.291
Real-time Intraday chart data file updates started for JV6T.Z | 2019-08-05 17:00:54.291
Intraday chart data file opened for JV6T.Z | 2019-08-05 17:00:54.291
SC DTC Data with Market Depth | Connected to server. | 2019-08-05 17:00:54.329
SC DTC Data with Market Depth | Starting socket receive thread. | 2019-08-05 17:00:54.329
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2019-08-05 17:00:54.329
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2019-08-05 17:00:54.388
SC DTC Data with Market Depth | Sending logon request message. | 2019-08-05 17:00:54.388
SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 11 Service code: statscalc | 2019-08-05 17:00:54.441
SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 11 | 2019-08-05 17:00:54.441
Added Intraday data request for TRIN-NYSE to the queue. | 2019-08-05 17:00:54.441
Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2019-08-05 17:00:54.441
SC Data - All Services | Starting real-time market data updates for: $SPX. ID: 12 Service code: cboe.index | 2019-08-05 17:00:54.446
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: $SPX | 2019-08-05 17:00:54.446
SC Data - All Services | Requesting security definition data for: $SPX. ID: 12 | 2019-08-05 17:00:54.446
SC Data - All Services | Starting real-time market data updates for: VRCT.Z. ID: 13 Service code: equities.us | 2019-08-05 17:00:54.448
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: VRCT.Z | 2019-08-05 17:00:54.448
SC Data - All Services | Requesting security definition data for: VRCT.Z. ID: 13 | 2019-08-05 17:00:54.448
SC Data - All Services | Starting real-time market data updates for: VRET.Z. ID: 14 Service code: equities.us | 2019-08-05 17:00:54.449
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: VRET.Z | 2019-08-05 17:00:54.449
SC Data - All Services | Requesting security definition data for: VRET.Z. ID: 14 | 2019-08-05 17:00:54.449
Requesting market depth updates for: ESU19 if supported. | 2019-08-05 17:00:54.449
Separate subscription for market depth updates not supported. ESU19 | 2019-08-05 17:00:54.449
SC DTC Data with Market Depth | Received logon response. | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Successfully connected. | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Trading is not supported. | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-SP | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DVOL-SP | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-SP | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2019-08-05 17:00:54.912
SC DTC Data with Market Depth | Received security definition for symbol ADR-SP | 2019-08-05 17:00:54.976
SC DTC Data with Market Depth | Received security definition for symbol DVOL-SP | 2019-08-05 17:00:54.976
SC DTC Data with Market Depth | Received security definition for symbol NISS-SP | 2019-08-05 17:00:54.976
SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2019-08-05 17:00:54.976
SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2019-08-05 17:00:54.976
HD Request # 24 | Downloading Intraday chart data for ESU19 to the file ESU19.scid. Service: cme | 2019-08-05 17:00:58.111
HD Request # 24 | Download start date-time: 2019-08-05 15:59:59.000 | 2019-08-05 17:00:58.112
HD Request # 24 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2019-08-05 17:00:58.112
Socket (2) | Creating socket. | 2019-08-05 17:00:58.113
Socket (2) | Connecting to IP: 8.18.161.135. | 2019-08-05 17:00:58.113
HD Request # 24 | Setting DTC encoding to Binary VLS | 2019-08-05 17:00:58.177
HD Request # 24 | Sending historical data logon request message. | 2019-08-05 17:00:58.177
HD Request # 24 | Requesting Intraday data. Start date-time: 2019-08-05 15:59:59. Record interval: 0. Symbol: ESU19 | 2019-08-05 17:00:58.205
HD Request # 24 | Decompressing data. | 2019-08-05 17:00:58.234
HD Request # 24 | Receiving Intraday data for ESU19 starting at 2019-08-05 15:59:59 | 2019-08-05 17:00:58.235
Socket (2) | Shutdown started. Waiting for graceful close. | 2019-08-05 17:00:58.235
Historical data download thread signaled to stop. | 2019-08-05 17:00:58.235
HD Request # 24 | Received 6 records from 2019-08-05 15:59:59.000 to 2019-08-05 15:59:59.005 (0.0 seconds) and wrote 0 records for ESU19 | 2019-08-05 17:00:58.235
HD Request # 24 | Completion time: 0s | 2019-08-05 17:00:58.236
HD Request # 24 | Intraday data download complete for ESU19. Unique request ID: 21 | 2019-08-05 17:00:58.236
Removed historical data download ID 21 | 2019-08-05 17:00:58.236
Real-time Intraday chart data file updates started for ESU19 | 2019-08-05 17:00:58.236
Intraday chart data file opened for ESU19 | 2019-08-05 17:00:58.236
Delaying start of download for NISS-SP | 2019-08-05 17:00:58.236
Socket (2) | Socket gracefully closed by remote side. | 2019-08-05 17:00:58.268
Socket (2) | Closed. | 2019-08-05 17:00:58.269
Chart #20 has tagged chart #10 for full recalculation. Chartbook: ES.cht | 2019-08-05 17:00:58.591
Chart #20 has tagged chart #13 for full recalculation. Chartbook: ES.cht | 2019-08-05 17:00:58.591
Chart #20 has tagged chart #23 for full recalculation. Chartbook: ES.cht | 2019-08-05 17:00:58.591
Chart #20 has tagged chart #32 for full recalculation. Chartbook: ES.cht | 2019-08-05 17:00:58.591
Chart #30 has tagged chart #13 for full recalculation. Chartbook: ES.cht | 2019-08-05 17:00:58.773
ESU19 [CB] 2 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 17:00:58.775
ESU19 [CB] 3 Min #32 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 17:01:00.125
HD Request # 25 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2019-08-05 17:01:03.872
HD Request # 25 | Download start date-time: 2019-08-05 17:00:19.000 | 2019-08-05 17:01:03.872
HD Request # 25 | Using server: ds3.sierracharts.com port 10149 | 2019-08-05 17:01:03.872
Socket (2) | Creating socket. | 2019-08-05 17:01:03.873
Socket (2) | Connecting to IP: 65.182.172.42. | 2019-08-05 17:01:03.873
ESU19 [CB] Renko 2t #10 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 17:01:03.878
HD Request # 25 | Setting DTC encoding to Binary VLS | 2019-08-05 17:01:03.963
HD Request # 25 | Sending historical data logon request message. | 2019-08-05 17:01:03.963
HD Request # 25 | Requesting Intraday data. Start date-time: 2019-08-05 17:00:19. Record interval: 0. Symbol: NISS-SP | 2019-08-05 17:01:03.992
HD Request # 25 | Decompressing data. | 2019-08-05 17:01:04.024
HD Request # 25 | Receiving Intraday data for NISS-SP starting at 2019-08-05 17:00:19 | 2019-08-05 17:01:04.025
HD Request # 25 | Timestamp of first Intraday data file record written: 2019-08-05 17:00:20 | 2019-08-05 17:01:04.025
Socket (2) | Shutdown started. Waiting for graceful close. | 2019-08-05 17:01:04.025
Socket (2) | Socket gracefully closed by remote side. | 2019-08-05 17:01:04.055
Socket (2) | Closed. | 2019-08-05 17:01:04.055
Historical data download thread signaled to stop. | 2019-08-05 17:01:18.017
HD Request # 25 | Received 44 records from 2019-08-05 17:00:19.000 to 2019-08-05 17:01:02.000 (43.0 seconds) and wrote 43 records for NISS-SP | 2019-08-05 17:01:18.017
Added 64 Time and Sales records to Intraday data file for NISS-SP after download. | 2019-08-05 17:01:18.018
HD Request # 25 | Completion time: 15s | 2019-08-05 17:01:18.018
HD Request # 25 | Intraday data download complete for NISS-SP. Unique request ID: 22 | 2019-08-05 17:01:18.018
Removed historical data download ID 22 | 2019-08-05 17:01:18.018
Real-time Intraday chart data file updates started for NISS-SP | 2019-08-05 17:01:18.018
Intraday chart data file opened for NISS-SP | 2019-08-05 17:01:18.018
HD Request # 26 | Downloading Intraday chart data for ESH19 to the file ESH19.scid. Service: cme | 2019-08-05 17:01:18.018
HD Request # 26 | Download start date-time: 2019-03-15 08:29:55.000 | 2019-08-05 17:01:18.018
HD Request # 26 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-08-05 17:01:18.019
Socket (2) | Creating socket. | 2019-08-05 17:01:18.019
Socket (2) | Connecting to IP: 8.18.161.133. | 2019-08-05 17:01:18.019
HD Request # 26 | Setting DTC encoding to Binary VLS | 2019-08-05 17:01:18.092
HD Request # 26 | Sending historical data logon request message. | 2019-08-05 17:01:18.092
HD Request # 26 | Requesting Intraday data. Start date-time: 2019-03-15 08:29:55. Record interval: 0. Symbol: ESH19 | 2019-08-05 17:01:18.127
HD Request # 26 | Decompressing data. | 2019-08-05 17:01:18.159
HD Request # 26 | Receiving Intraday data for ESH19 starting at 2019-03-15 08:29:55 | 2019-08-05 17:01:18.160
Socket (2) | Shutdown started. Waiting for graceful close. | 2019-08-05 17:01:18.160
Socket (2) | Socket gracefully closed by remote side. | 2019-08-05 17:01:18.188
Socket (2) | Closed. | 2019-08-05 17:01:18.188
Historical data download thread signaled to stop. | 2019-08-05 17:01:18.191
HD Request # 26 | Received 1 record from 2019-03-15 08:29:55.000 to 2019-03-15 08:29:55.000 (0.0 seconds) and wrote 0 records for ESH19 | 2019-08-05 17:01:18.191
HD Request # 26 | Completion time: 0s | 2019-08-05 17:01:18.191
HD Request # 26 | Intraday data download complete for ESH19. Unique request ID: 23 | 2019-08-05 17:01:18.191
Removed historical data download ID 23 | 2019-08-05 17:01:18.191
Real-time Intraday chart data file updates started for ESH19 | 2019-08-05 17:01:18.191
Intraday chart data file opened for ESH19 | 2019-08-05 17:01:18.191
HD Request # 27 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2019-08-05 17:01:18.191
HD Request # 27 | Download start date-time: 2019-08-05 17:00:19.000 | 2019-08-05 17:01:18.192
HD Request # 27 | Using server: ds4.sierracharts.com port 10149 | 2019-08-05 17:01:18.192
Socket (2) | Creating socket. | 2019-08-05 17:01:18.192
Socket (2) | Connecting to IP: 192.81.56.146. | 2019-08-05 17:01:18.192
ESU19 [CB] 3 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 17:01:18.265
HD Request # 27 | Setting DTC encoding to Binary VLS | 2019-08-05 17:01:18.286
HD Request # 27 | Sending historical data logon request message. | 2019-08-05 17:01:18.286
HD Request # 27 | Requesting Intraday data. Start date-time: 2019-08-05 17:00:19. Record interval: 0. Symbol: TICK-NYSE | 2019-08-05 17:01:18.887
HD Request # 27 | Decompressing data. | 2019-08-05 17:01:18.933
HD Request # 27 | Receiving Intraday data for TICK-NYSE starting at 2019-08-05 17:00:19 | 2019-08-05 17:01:18.934
HD Request # 27 | Timestamp of first Intraday data file record written: 2019-08-05 17:00:20 | 2019-08-05 17:01:18.934
Socket (2) | Shutdown started. Waiting for graceful close. | 2019-08-05 17:01:18.935
Socket (2) | Socket gracefully closed by remote side. | 2019-08-05 17:01:18.975
Socket (2) | Closed. | 2019-08-05 17:01:18.975
Opened cached Intraday file: C:\SierraChart\Data\NISS-SP.scid | 2019-08-05 17:01:20.655
Historical data download thread signaled to stop. | 2019-08-05 17:01:22.137
HD Request # 27 | Received 59 records from 2019-08-05 17:00:19.000 to 2019-08-05 17:01:17.000 (58.0 seconds) and wrote 58 records for TICK-NYSE | 2019-08-05 17:01:22.137
Added 20 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2019-08-05 17:01:22.138
HD Request # 27 | Completion time: 4s | 2019-08-05 17:01:22.138
HD Request # 27 | Intraday data download complete for TICK-NYSE. Unique request ID: 24 | 2019-08-05 17:01:22.138
Removed historical data download ID 24 | 2019-08-05 17:01:22.138
Real-time Intraday chart data file updates started for TICK-NYSE | 2019-08-05 17:01:22.138
Intraday chart data file opened for TICK-NYSE | 2019-08-05 17:01:22.138
HD Request # 28 | Downloading Intraday chart data for ADR-SP to the file ADR-SP.scid. Service: statscalc | 2019-08-05 17:01:22.138
HD Request # 28 | Download start date-time: 2019-08-05 17:00:19.000 | 2019-08-05 17:01:22.138
HD Request # 28 | Using server: ds3.sierracharts.com port 10150 | 2019-08-05 17:01:22.139
Socket (2) | Creating socket. | 2019-08-05 17:01:22.139
Socket (2) | Connecting to IP: 65.182.172.42. | 2019-08-05 17:01:22.139
HD Request # 28 | Setting DTC encoding to Binary VLS | 2019-08-05 17:01:22.222
HD Request # 28 | Sending historical data logon request message. | 2019-08-05 17:01:22.222
HD Request # 28 | Requesting Intraday data. Start date-time: 2019-08-05 17:00:19. Record interval: 0. Symbol: ADR-SP | 2019-08-05 17:01:22.256
HD Request # 28 | Decompressing data. | 2019-08-05 17:01:22.297
HD Request # 28 | Receiving Intraday data for ADR-SP starting at 2019-08-05 17:00:19 | 2019-08-05 17:01:22.297
HD Request # 28 | Timestamp of first Intraday data file record written: 2019-08-05 17:00:20 | 2019-08-05 17:01:22.298
Socket (2) | Shutdown started. Waiting for graceful close. | 2019-08-05 17:01:22.299
Historical data download thread signaled to stop. | 2019-08-05 17:01:22.299
HD Request # 28 | Received 64 records from 2019-08-05 17:00:19.000 to 2019-08-05 17:01:22.000 (63.0 seconds) and wrote 63 records for ADR-SP | 2019-08-05 17:01:22.299
Added 1 Time and Sales records to Intraday data file for ADR-SP after download. | 2019-08-05 17:01:22.300
HD Request # 28 | Completion time: 0s | 2019-08-05 17:01:22.300
HD Request # 28 | Intraday data download complete for ADR-SP. Unique request ID: 25 | 2019-08-05 17:01:22.300
Removed historical data download ID 25 | 2019-08-05 17:01:22.300
Real-time Intraday chart data file updates started for ADR-SP | 2019-08-05 17:01:22.300
Intraday chart data file opened for ADR-SP | 2019-08-05 17:01:22.300
HD Request # 29 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2019-08-05 17:01:22.300
HD Request # 29 | Download start date-time: 2019-08-05 17:00:19.000 | 2019-08-05 17:01:22.301
HD Request # 29 | Using server: ds4.sierracharts.com port 10149 | 2019-08-05 17:01:22.302
Socket (3) | Creating socket. | 2019-08-05 17:01:22.302
Socket (3) | Connecting to IP: 192.81.56.146. | 2019-08-05 17:01:22.302
Socket (2) | Socket gracefully closed by remote side. | 2019-08-05 17:01:22.335
Socket (2) | Closed. | 2019-08-05 17:01:22.335
HD Request # 29 | Setting DTC encoding to Binary VLS | 2019-08-05 17:01:22.407
HD Request # 29 | Sending historical data logon request message. | 2019-08-05 17:01:22.407
HD Request # 29 | Requesting Intraday data. Start date-time: 2019-08-05 17:00:19. Record interval: 0. Symbol: TRIN-NYSE | 2019-08-05 17:01:22.459
HD Request # 29 | Decompressing data. | 2019-08-05 17:01:22.502
HD Request # 29 | Receiving Intraday data for TRIN-NYSE starting at 2019-08-05 17:00:19 | 2019-08-05 17:01:22.503
HD Request # 29 | Timestamp of first Intraday data file record written: 2019-08-05 17:00:20 | 2019-08-05 17:01:22.504
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-08-05 17:01:22.504
Historical data download thread signaled to stop. | 2019-08-05 17:01:22.504
HD Request # 29 | Received 63 records from 2019-08-05 17:00:19.000 to 2019-08-05 17:01:21.000 (62.0 seconds) and wrote 62 records for TRIN-NYSE | 2019-08-05 17:01:22.505
Added 6 Time and Sales records to Intraday data file for TRIN-NYSE after download. | 2019-08-05 17:01:22.506
HD Request # 29 | Completion time: 0s | 2019-08-05 17:01:22.506
HD Request # 29 | Intraday data download complete for TRIN-NYSE. Unique request ID: 26 | 2019-08-05 17:01:22.506
Removed historical data download ID 26 | 2019-08-05 17:01:22.506
Real-time Intraday chart data file updates started for TRIN-NYSE | 2019-08-05 17:01:22.506
Intraday chart data file opened for TRIN-NYSE | 2019-08-05 17:01:22.506
Socket (3) | Socket gracefully closed by remote side. | 2019-08-05 17:01:22.548
Socket (3) | Closed. | 2019-08-05 17:01:22.548
Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid | 2019-08-05 17:01:25.733
Opened cached Intraday file: C:\SierraChart\Data\ADR-SP.scid | 2019-08-05 17:01:25.734
Opened cached Intraday file: C:\SierraChart\Data\TRIN-NYSE.scid | 2019-08-05 17:01:25.734
[2019-08-06 01:41:37]
This log does not show any connection to Transact. Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions
And then to ensure you are using the correct symbols, after you open your Chartbook when connected to Transact, use this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
Date Time Of Last Edit: 2019-08-06 01:42:10
[2019-08-06 02:00:27]
conr - Posts: 204
I did that. Here is the log when I connect to Transact. It's when I switch back to SC Data-All Services I get no data.
Software version: 1969 32-bit | 2019-08-05 20:53:26.390
Usage end date: 2019-09-14 | 2019-08-05 20:53:26.390
Enabled for: Advanced Features 2. | 2019-08-05 20:53:26.390
Enabled for: Sierra Chart Historical Data Service. | 2019-08-05 20:53:26.390
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-08-05 20:53:26.390
Enabled for exchange: INDEXES_DATA_BARCHART | 2019-08-05 20:53:26.390
Enabled for exchange: CME with Market Depth for nonprofessional Trading accounts | 2019-08-05 20:53:26.390
Received 1 data feed usernames. | 2019-08-05 20:53:26.390
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-08-05 20:53:26.390
Current selected Data/Trading service: SC Data - All Services | 2019-08-05 20:53:26.390
Custom symbol settings values: disabled | 2019-08-05 20:53:26.390
Chart Update Interval: 900 | 2019-08-05 20:53:26.390
Intraday Data Storage Time Unit: 0 | 2019-08-05 20:53:26.390
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-08-05 20:53:26.390
2019-08-05 20:53:26 Local computer time | 2019-08-05 20:53:26.390
2019-08-06 01:53:26 Local computer time in UTC | 2019-08-05 20:53:26.390
2019-08-05 20:53:26 Local computer time in SC Time Zone | 2019-08-05 20:53:26.390
2019-08-05 20:23:46 Server time in UTC | 2019-08-05 20:53:26.390
Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-08-05 20:53:26.390
Program path: C:\SierraChart\ | 2019-08-05 20:53:26.390
Data Files path: C:\SierraChart\Data\ | 2019-08-05 20:53:26.390
OS Version Number: 10.0 | 2019-08-05 20:53:26.390
Locale Setting: C | 2019-08-05 20:53:26.390
DLLs: AdaptiveVolumeRatio_MAByTick.dll, IOAMT.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-08-05 20:53:26.392
SC Data - All Services | Disconnected. | 2019-08-05 20:53:47.128
SC Data - All Services | Disconnected. | 2019-08-05 20:53:47.146
Checking for new symbol settings. Requested symbol settings MD5 for service code transact.trading. Request ID: 11. | 2019-08-05 20:53:47.149
Current selected Data/Trading service: TransAct WS | 2019-08-05 20:53:47.149
Symbol settings MD5 received. Request ID: 11. | 2019-08-05 20:53:48.260
Requested symbol settings for service code transact.trading. Request ID: 12. | 2019-08-05 20:53:48.260
Symbol settings received. Request ID: 12. | 2019-08-05 20:53:49.613
TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-08-05 20:53:52.611
Auth Websocket | Connecting to WebSocket server. | 2019-08-05 20:53:52.611
Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-08-05 20:53:52.611
Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-08-05 20:53:52.612
Auth Websocket | Opening WebSocket. | 2019-08-05 20:53:52.640
Auth Websocket | Sending WebSocket handshake. | 2019-08-05 20:53:52.640
Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-08-05 20:53:52.737
Auth Websocket | Server header | Upgrade: WebSocket | 2019-08-05 20:53:52.737
Auth Websocket | Server header | Connection: Upgrade | 2019-08-05 20:53:52.737
Auth Websocket | Server header | Sec-WebSocket-Accept: Dkhe8RWeWiT0lWCd0oFqOWiZzgQ= | 2019-08-05 20:53:52.737
Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-08-05 20:53:52.737
Auth Websocket | Server header | | 2019-08-05 20:53:52.737
Auth Websocket | Web socket state is now open. | 2019-08-05 20:53:52.737
TransAct WS | Sending account logon message. Simulated Live | 2019-08-05 20:53:52.737
Price Websocket | Connecting to WebSocket server. | 2019-08-05 20:53:52.880
Auth Websocket | WebSocket closed. | 2019-08-05 20:53:52.880
Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-08-05 20:53:52.880
Price Websocket socket (2) | Creating socket. Using TLS 1.2. | 2019-08-05 20:53:52.881
Price Websocket socket (2) | Connecting to IP: 208.97.219.197. | 2019-08-05 20:53:52.881
Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-08-05 20:53:52.908
Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:53:52.908
Price Websocket | Opening WebSocket. | 2019-08-05 20:53:52.910
Price Websocket | Sending WebSocket handshake. | 2019-08-05 20:53:52.910
Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-08-05 20:53:52.936
Auth Websocket socket (1) | Closed. | 2019-08-05 20:53:52.936
Price Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-08-05 20:53:53.008
Price Websocket | Server header | Upgrade: WebSocket | 2019-08-05 20:53:53.008
Price Websocket | Server header | Connection: Upgrade | 2019-08-05 20:53:53.008
Price Websocket | Server header | Sec-WebSocket-Accept: 77nIpHFLEOAxmKP9O8PoDhdXbnw= | 2019-08-05 20:53:53.008
Price Websocket | Server header | Sec-WebSocket-Protocol: priceapi | 2019-08-05 20:53:53.008
Price Websocket | Server header | | 2019-08-05 20:53:53.008
Price Websocket | Web socket state is now open. | 2019-08-05 20:53:53.008
Orders Websocket | Connecting to WebSocket server. | 2019-08-05 20:53:53.090
Orders Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-08-05 20:53:53.091
Orders Websocket socket (1) | Connecting to IP: 208.97.219.123. | 2019-08-05 20:53:53.091
Orders Websocket | Opening WebSocket. | 2019-08-05 20:53:53.120
Orders Websocket | Sending WebSocket handshake. | 2019-08-05 20:53:53.120
Orders Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-08-05 20:53:53.216
Orders Websocket | Server header | Upgrade: WebSocket | 2019-08-05 20:53:53.216
Orders Websocket | Server header | Connection: Upgrade | 2019-08-05 20:53:53.216
Orders Websocket | Server header | Sec-WebSocket-Accept: XrsJDcb9gWKAvlzS9Js8PSIvWC0= | 2019-08-05 20:53:53.216
Orders Websocket | Server header | Sec-WebSocket-Protocol: order | 2019-08-05 20:53:53.216
Orders Websocket | Server header | | 2019-08-05 20:53:53.216
Orders Websocket | Web socket state is now open. | 2019-08-05 20:53:53.216
TransAct WS | Sending orders connection logon message. | 2019-08-05 20:53:53.216
TransAct WS | Connected to data and trading server. | 2019-08-05 20:53:53.355
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2019-08-05 20:53:53.359
TransAct WS | Starting real-time market data updates for: ESU19. ID: 1 | 2019-08-05 20:53:53.816
Symbol Error - ESU19 is unknown, unavailable, or improperly formatted. Unsupported symbol | 2019-08-05 20:53:53.816
TransAct WS | Requesting security definition data for: ESU19. ID: 1 | 2019-08-05 20:53:53.816
Added Intraday data request for ESU19 to the queue. | 2019-08-05 20:53:53.816
Intraday data recording state for symbol ESU19 is set to download 'Pending'. | 2019-08-05 20:53:53.816
HD Request # 60 | Downloading Intraday chart data for ESU19 to the file ESU19.scid. Service: transact.trading | 2019-08-05 20:53:53.879
HD Request # 60 | Download start date-time: 2019-08-05 20:41:21.000 | 2019-08-05 20:53:53.880
TransAct WS | Subscribe response. Status: -8. Topics: No topics found | 2019-08-05 20:53:53.880
HD Request # 60 | Using server: ds3.sierracharts.com port 10150 | 2019-08-05 20:53:53.880
Socket (3) | Creating socket. | 2019-08-05 20:53:53.880
Socket (3) | Connecting to IP: 65.182.172.42. | 2019-08-05 20:53:53.880
TransAct WS | Subscribe response. Status: -8. Topics: No topics found | 2019-08-05 20:53:53.942
HD Request # 60 | Setting DTC encoding to Binary VLS | 2019-08-05 20:53:53.953
HD Request # 60 | Sending historical data logon request message. | 2019-08-05 20:53:53.953
HD Request # 60 | Requesting Intraday data. Start date-time: 2019-08-05 20:41:21. Record interval: 0. Symbol: ESU19 | 2019-08-05 20:53:53.982
Socket (3) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:53:54.012
HD Request # 60 | Error downloading historical Intraday data for ESU19. Historical data file not available for symbol. | 2019-08-05 20:53:54.020
Historical data download thread signaled to stop. | 2019-08-05 20:53:54.021
HD Request # 60 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESU19 | 2019-08-05 20:53:54.021
HD Request # 60 | Completion time: 0s | 2019-08-05 20:53:54.021
HD Request # 60 | Intraday data download complete for ESU19. Unique request ID: 57 | 2019-08-05 20:53:54.021
Removed historical data download ID 57 | 2019-08-05 20:53:54.021
Real-time Intraday chart data file updates started for ESU19 | 2019-08-05 20:53:54.021
Intraday chart data file opened for ESU19 | 2019-08-05 20:53:54.021
Socket (3) | Socket gracefully closed by remote side. | 2019-08-05 20:53:54.043
Socket (3) | Closed. | 2019-08-05 20:53:54.043
SC DTC Data with Market Depth | Starting real-time market data updates for: DVOL-SP. ID: 2 Service code: statscalc | 2019-08-05 20:53:54.225
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2019-08-05 20:53:54.225
SC DTC Data with Market Depth | Requesting security definition data for: DVOL-SP. ID: 2 | 2019-08-05 20:53:54.225
DTC Client socket (3) | Creating socket. | 2019-08-05 20:53:54.225
DTC Client socket (3) | Connecting to IP: 192.81.56.146. | 2019-08-05 20:53:54.225
TransAct WS | Starting real-time market data updates for: @ES#c. ID: 3 | 2019-08-05 20:53:54.226
Symbol Error - @ES#c is unknown, unavailable, or improperly formatted. Unsupported symbol | 2019-08-05 20:53:54.226
TransAct WS | Requesting security definition data for: @ES#c. ID: 3 | 2019-08-05 20:53:54.226
Added Intraday data request for @ES#c to the queue. | 2019-08-05 20:53:54.226
Intraday data recording state for symbol @ES#c is set to download 'Pending'. | 2019-08-05 20:53:54.226
HD Request # 61 | Downloading Intraday chart data for @ES#c to the file @ES#c.scid. Service: transact.trading | 2019-08-05 20:53:54.226
HD Request # 61 | Download start date-time: 2019-01-31 19:53:54.000 | 2019-08-05 20:53:54.227
HD Request # 61 | Using server: ds4.sierracharts.com port 10149 | 2019-08-05 20:53:54.227
Socket (4) | Creating socket. | 2019-08-05 20:53:54.227
Socket (4) | Connecting to IP: 192.81.56.146. | 2019-08-05 20:53:54.227
SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-SP. ID: 4 Service code: statscalc | 2019-08-05 20:53:54.227
SC DTC Data with Market Depth | Requesting security definition data for: NISS-SP. ID: 4 | 2019-08-05 20:53:54.227
Added Intraday data request for NISS-SP to the queue. | 2019-08-05 20:53:54.227
Intraday data recording state for symbol NISS-SP is set to download 'Pending'. | 2019-08-05 20:53:54.227
TransAct WS | Starting real-time market data updates for: ESH19. ID: 5 | 2019-08-05 20:53:54.233
Symbol Error - ESH19 is unknown, unavailable, or improperly formatted. Unsupported symbol | 2019-08-05 20:53:54.233
TransAct WS | Requesting security definition data for: ESH19. ID: 5 | 2019-08-05 20:53:54.233
Added Intraday data request for ESH19 to the queue. | 2019-08-05 20:53:54.233
Intraday data recording state for symbol ESH19 is set to download 'Pending'. | 2019-08-05 20:53:54.233
TransAct WS | Starting real-time market data updates for: TICKBA-NYSE. ID: 6 | 2019-08-05 20:53:54.235
Symbol Error - TICKBA-NYSE is unknown, unavailable, or improperly formatted. Unsupported symbol | 2019-08-05 20:53:54.235
TransAct WS | Requesting security definition data for: TICKBA-NYSE. ID: 6 | 2019-08-05 20:53:54.235
Added Intraday data request for TICKBA-NYSE to the queue. | 2019-08-05 20:53:54.235
Intraday data recording state for symbol TICKBA-NYSE is set to download 'Pending'. | 2019-08-05 20:53:54.235
TransAct WS | Starting real-time market data updates for: VI6A.Z. ID: 7 | 2019-08-05 20:53:54.236
Symbol Error - VI6A.Z is unknown, unavailable, or improperly formatted. Unsupported symbol | 2019-08-05 20:53:54.236
TransAct WS | Requesting security definition data for: VI6A.Z. ID: 7 | 2019-08-05 20:53:54.236
Added Intraday data request for VI6A.Z to the queue. | 2019-08-05 20:53:54.236
Intraday data recording state for symbol VI6A.Z is set to download 'Pending'. | 2019-08-05 20:53:54.236
SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 8 Service code: statscalc | 2019-08-05 20:53:54.236
SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 8 | 2019-08-05 20:53:54.236
Added Intraday data request for TICK-NYSE to the queue. | 2019-08-05 20:53:54.236
Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2019-08-05 20:53:54.236
Chart #20 has tagged chart #10 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:53:54.237
Chart #20 has tagged chart #13 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:53:54.237
Chart #20 has tagged chart #23 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:53:54.237
Chart #20 has tagged chart #32 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:53:54.237
SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-SP. ID: 9 Service code: statscalc | 2019-08-05 20:53:54.262
SC DTC Data with Market Depth | Requesting security definition data for: ADR-SP. ID: 9 | 2019-08-05 20:53:54.262
Added Intraday data request for ADR-SP to the queue. | 2019-08-05 20:53:54.262
Intraday data recording state for symbol ADR-SP is set to download 'Pending'. | 2019-08-05 20:53:54.262
TransAct WS | Starting real-time market data updates for: JV6T.Z. ID: 10 | 2019-08-05 20:53:54.265
Symbol Error - JV6T.Z is unknown, unavailable, or improperly formatted. Unsupported symbol | 2019-08-05 20:53:54.265
TransAct WS | Requesting security definition data for: JV6T.Z. ID: 10 | 2019-08-05 20:53:54.265
Added Intraday data request for JV6T.Z to the queue. | 2019-08-05 20:53:54.265
Intraday data recording state for symbol JV6T.Z is set to download 'Pending'. | 2019-08-05 20:53:54.265
SC DTC Data with Market Depth | Connected to server. | 2019-08-05 20:53:54.304
SC DTC Data with Market Depth | Starting socket receive thread. | 2019-08-05 20:53:54.304
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2019-08-05 20:53:54.304
HD Request # 61 | Setting DTC encoding to Binary VLS | 2019-08-05 20:53:54.319
HD Request # 61 | Sending historical data logon request message. | 2019-08-05 20:53:54.319
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2019-08-05 20:53:54.416
SC DTC Data with Market Depth | Sending logon request message. | 2019-08-05 20:53:54.416
SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 11 Service code: statscalc | 2019-08-05 20:53:54.416
SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 11 | 2019-08-05 20:53:54.416
Added Intraday data request for TRIN-NYSE to the queue. | 2019-08-05 20:53:54.416
Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2019-08-05 20:53:54.416
Chart #30 has tagged chart #13 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:53:54.417
TransAct WS | Starting real-time market data updates for: $SPX. ID: 12 Service code: cboe.index | 2019-08-05 20:53:54.420
Symbol Error - $SPX is unknown, unavailable, or improperly formatted. Unsupported symbol | 2019-08-05 20:53:54.420
TransAct WS | Requesting security definition data for: $SPX. ID: 12 | 2019-08-05 20:53:54.421
TransAct WS | Starting real-time market data updates for: VRCT.Z. ID: 13 Service code: equities.us | 2019-08-05 20:53:54.422
Symbol Error - VRCT.Z is unknown, unavailable, or improperly formatted. Unsupported symbol | 2019-08-05 20:53:54.422
TransAct WS | Requesting security definition data for: VRCT.Z. ID: 13 | 2019-08-05 20:53:54.422
TransAct WS | Starting real-time market data updates for: VRET.Z. ID: 14 Service code: equities.us | 2019-08-05 20:53:54.423
Symbol Error - VRET.Z is unknown, unavailable, or improperly formatted. Unsupported symbol | 2019-08-05 20:53:54.423
TransAct WS | Requesting security definition data for: VRET.Z. ID: 14 | 2019-08-05 20:53:54.423
Requesting market depth updates for: ESU19 if supported. | 2019-08-05 20:53:54.423
Separate subscription for market depth updates not supported. ESU19 | 2019-08-05 20:53:54.423
ESU19 [CB] 2 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 20:53:54.423
HD Request # 61 | Requesting Intraday data. Start date-time: 2019-01-31 19:53:54. Record interval: 0. Symbol: @ES#c | 2019-08-05 20:53:55.237
Socket (4) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:53:55.278
Socket (4) | Socket gracefully closed by remote side. | 2019-08-05 20:53:55.318
Socket (4) | Closed. | 2019-08-05 20:53:55.318
HD Request # 61 | Error downloading historical Intraday data for @ES#c. Historical data file not available for symbol. | 2019-08-05 20:53:55.778
Historical data download thread signaled to stop. | 2019-08-05 20:53:55.778
HD Request # 61 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for @ES#c | 2019-08-05 20:53:55.778
HD Request # 61 | Completion time: 1s | 2019-08-05 20:53:55.778
HD Request # 61 | Intraday data download complete for @ES#c. Unique request ID: 58 | 2019-08-05 20:53:55.778
Removed historical data download ID 58 | 2019-08-05 20:53:55.778
Real-time Intraday chart data file updates started for @ES#c | 2019-08-05 20:53:55.778
Intraday chart data file opened for @ES#c | 2019-08-05 20:53:55.778
SC DTC Data with Market Depth | Received logon response. | 2019-08-05 20:53:55.778
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2019-08-05 20:53:55.778
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2019-08-05 20:53:55.778
SC DTC Data with Market Depth | Successfully connected. | 2019-08-05 20:53:55.778
SC DTC Data with Market Depth | Trading is not supported. | 2019-08-05 20:53:55.778
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-SP | 2019-08-05 20:53:55.778
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DVOL-SP | 2019-08-05 20:53:55.779
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-SP | 2019-08-05 20:53:55.779
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2019-08-05 20:53:55.779
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2019-08-05 20:53:55.779
Delaying start of download for NISS-SP | 2019-08-05 20:53:55.779
ESU19 [CB] 3 Min #32 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 20:53:55.785
SC DTC Data with Market Depth | Received security definition for symbol ADR-SP | 2019-08-05 20:53:59.468
SC DTC Data with Market Depth | Received security definition for symbol DVOL-SP | 2019-08-05 20:53:59.468
SC DTC Data with Market Depth | Received security definition for symbol NISS-SP | 2019-08-05 20:53:59.468
SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2019-08-05 20:53:59.468
SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2019-08-05 20:53:59.468
ESU19 [CB] Renko 2t #10 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 20:53:59.470
ESU19 [CB] 3 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 20:54:13.466
HD Request # 62 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2019-08-05 20:54:17.282
HD Request # 62 | Download start date-time: 2019-08-05 19:05:00.000 | 2019-08-05 20:54:17.283
HD Request # 62 | Using server: ds3.sierracharts.com port 10150 | 2019-08-05 20:54:17.283
Socket (4) | Creating socket. | 2019-08-05 20:54:17.283
Socket (4) | Connecting to IP: 65.182.172.42. | 2019-08-05 20:54:17.283
TransAct WS | Trading information positions response: API not available | 2019-08-05 20:54:17.354
TransAct WS | Trading information request response: API not available | 2019-08-05 20:54:17.354
HD Request # 62 | Setting DTC encoding to Binary VLS | 2019-08-05 20:54:17.356
HD Request # 62 | Sending historical data logon request message. | 2019-08-05 20:54:17.356
HD Request # 62 | Requesting Intraday data. Start date-time: 2019-08-05 19:05:00. Record interval: 0. Symbol: NISS-SP | 2019-08-05 20:54:17.385
HD Request # 62 | Decompressing data. | 2019-08-05 20:54:17.415
HD Request # 62 | Receiving Intraday data for NISS-SP starting at 2019-08-05 19:05:00 | 2019-08-05 20:54:17.415
Historical data download thread signaled to stop. | 2019-08-05 20:54:17.416
Socket (4) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:54:17.416
HD Request # 62 | Received 1 record from 2019-08-05 19:05:00.000 to 2019-08-05 19:05:00.000 (0.0 seconds) and wrote 0 records for NISS-SP | 2019-08-05 20:54:17.416
HD Request # 62 | Completion time: 0s | 2019-08-05 20:54:17.416
HD Request # 62 | Intraday data download complete for NISS-SP. Unique request ID: 59 | 2019-08-05 20:54:17.416
Removed historical data download ID 59 | 2019-08-05 20:54:17.416
Real-time Intraday chart data file updates started for NISS-SP | 2019-08-05 20:54:17.416
Intraday chart data file opened for NISS-SP | 2019-08-05 20:54:17.416
HD Request # 63 | Downloading Intraday chart data for ESH19 to the file ESH19.scid. Service: transact.trading | 2019-08-05 20:54:17.417
HD Request # 63 | Download start date-time: 2019-03-15 08:29:55.000 | 2019-08-05 20:54:17.417
HD Request # 63 | Using server: ds4.sierracharts.com port 10149 | 2019-08-05 20:54:17.417
Socket (5) | Creating socket. | 2019-08-05 20:54:17.417
Socket (5) | Connecting to IP: 192.81.56.146. | 2019-08-05 20:54:17.417
Socket (4) | Socket gracefully closed by remote side. | 2019-08-05 20:54:17.444
Socket (4) | Closed. | 2019-08-05 20:54:17.445
HD Request # 63 | Setting DTC encoding to Binary VLS | 2019-08-05 20:54:17.512
HD Request # 63 | Sending historical data logon request message. | 2019-08-05 20:54:17.512
HD Request # 63 | Requesting Intraday data. Start date-time: 2019-03-15 08:29:55. Record interval: 0. Symbol: ESH19 | 2019-08-05 20:54:17.564
Socket (5) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:54:17.605
HD Request # 63 | Error downloading historical Intraday data for ESH19. Historical data file not available for symbol. | 2019-08-05 20:54:17.611
Historical data download thread signaled to stop. | 2019-08-05 20:54:17.611
HD Request # 63 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESH19 | 2019-08-05 20:54:17.611
HD Request # 63 | Completion time: 0s | 2019-08-05 20:54:17.612
HD Request # 63 | Intraday data download complete for ESH19. Unique request ID: 60 | 2019-08-05 20:54:17.612
Removed historical data download ID 60 | 2019-08-05 20:54:17.612
Real-time Intraday chart data file updates started for ESH19 | 2019-08-05 20:54:17.612
Intraday chart data file opened for ESH19 | 2019-08-05 20:54:17.612
HD Request # 64 | Downloading Intraday chart data for TICKBA-NYSE to the file TICKBA-NYSE.scid. Service: transact.trading | 2019-08-05 20:54:17.612
HD Request # 64 | Download start date-time: 2019-05-31 19:00:13.000 | 2019-08-05 20:54:17.613
HD Request # 64 | Using server: ds3.sierracharts.com port 10150 | 2019-08-05 20:54:17.613
Socket (4) | Creating socket. | 2019-08-05 20:54:17.613
Socket (4) | Connecting to IP: 65.182.172.42. | 2019-08-05 20:54:17.613
Socket (5) | Socket gracefully closed by remote side. | 2019-08-05 20:54:17.644
Socket (5) | Closed. | 2019-08-05 20:54:17.645
HD Request # 64 | Setting DTC encoding to Binary VLS | 2019-08-05 20:54:17.684
HD Request # 64 | Sending historical data logon request message. | 2019-08-05 20:54:17.684
HD Request # 64 | Requesting Intraday data. Start date-time: 2019-05-31 19:00:13. Record interval: 0. Symbol: TICKBA-NYSE | 2019-08-05 20:54:17.714
Socket (4) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:54:17.743
HD Request # 64 | Error downloading historical Intraday data for TICKBA-NYSE. Historical data file not available for symbol. | 2019-08-05 20:54:17.743
Historical data download thread signaled to stop. | 2019-08-05 20:54:17.744
HD Request # 64 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for TICKBA-NYSE | 2019-08-05 20:54:17.744
HD Request # 64 | Completion time: 0s | 2019-08-05 20:54:17.744
HD Request # 64 | Intraday data download complete for TICKBA-NYSE. Unique request ID: 61 | 2019-08-05 20:54:17.744
Removed historical data download ID 61 | 2019-08-05 20:54:17.744
Real-time Intraday chart data file updates started for TICKBA-NYSE | 2019-08-05 20:54:17.744
Intraday chart data file opened for TICKBA-NYSE | 2019-08-05 20:54:17.744
HD Request # 65 | Downloading Intraday chart data for VI6A.Z to the file VI6A.Z.scid. Service: transact.trading | 2019-08-05 20:54:17.744
HD Request # 65 | Download start date-time: 2019-01-31 19:54:17.000 | 2019-08-05 20:54:17.745
HD Request # 65 | Using server: ds4.sierracharts.com port 10149 | 2019-08-05 20:54:17.745
Socket (5) | Creating socket. | 2019-08-05 20:54:17.745
Socket (5) | Connecting to IP: 192.81.56.146. | 2019-08-05 20:54:17.746
Socket (4) | Socket gracefully closed by remote side. | 2019-08-05 20:54:17.773
Socket (4) | Closed. | 2019-08-05 20:54:17.773
HD Request # 65 | Setting DTC encoding to Binary VLS | 2019-08-05 20:54:17.838
HD Request # 65 | Sending historical data logon request message. | 2019-08-05 20:54:17.838
HD Request # 65 | Requesting Intraday data. Start date-time: 2019-01-31 19:54:17. Record interval: 0. Symbol: VI6A.Z | 2019-08-05 20:54:17.891
HD Request # 65 | Error downloading historical Intraday data for VI6A.Z. Historical data file not available for symbol. | 2019-08-05 20:54:17.932
Socket (5) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:54:17.932
Historical data download thread signaled to stop. | 2019-08-05 20:54:17.932
HD Request # 65 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for VI6A.Z | 2019-08-05 20:54:17.932
HD Request # 65 | Completion time: 0s | 2019-08-05 20:54:17.933
HD Request # 65 | Intraday data download complete for VI6A.Z. Unique request ID: 62 | 2019-08-05 20:54:17.933
Removed historical data download ID 62 | 2019-08-05 20:54:17.933
Real-time Intraday chart data file updates started for VI6A.Z | 2019-08-05 20:54:17.933
Intraday chart data file opened for VI6A.Z | 2019-08-05 20:54:17.933
HD Request # 66 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2019-08-05 20:54:17.933
HD Request # 66 | Download start date-time: 2019-08-05 19:05:00.000 | 2019-08-05 20:54:17.934
HD Request # 66 | Using server: ds3.sierracharts.com port 10150 | 2019-08-05 20:54:17.934
Socket (4) | Creating socket. | 2019-08-05 20:54:17.934
Socket (4) | Connecting to IP: 65.182.172.42. | 2019-08-05 20:54:17.934
Socket (5) | Socket gracefully closed by remote side. | 2019-08-05 20:54:17.972
Socket (5) | Closed. | 2019-08-05 20:54:17.972
HD Request # 66 | Setting DTC encoding to Binary VLS | 2019-08-05 20:54:18.004
HD Request # 66 | Sending historical data logon request message. | 2019-08-05 20:54:18.004
HD Request # 66 | Requesting Intraday data. Start date-time: 2019-08-05 19:05:00. Record interval: 0. Symbol: TICK-NYSE | 2019-08-05 20:54:18.033
HD Request # 66 | Decompressing data. | 2019-08-05 20:54:18.063
HD Request # 66 | Receiving Intraday data for TICK-NYSE starting at 2019-08-05 19:05:00 | 2019-08-05 20:54:18.063
Socket (4) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:54:18.064
Historical data download thread signaled to stop. | 2019-08-05 20:54:18.064
HD Request # 66 | Received 1 record from 2019-08-05 19:05:00.000 to 2019-08-05 19:05:00.000 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2019-08-05 20:54:18.064
HD Request # 66 | Completion time: 1s | 2019-08-05 20:54:18.065
HD Request # 66 | Intraday data download complete for TICK-NYSE. Unique request ID: 63 | 2019-08-05 20:54:18.065
Removed historical data download ID 63 | 2019-08-05 20:54:18.065
Real-time Intraday chart data file updates started for TICK-NYSE | 2019-08-05 20:54:18.065
Intraday chart data file opened for TICK-NYSE | 2019-08-05 20:54:18.065
HD Request # 67 | Downloading Intraday chart data for ADR-SP to the file ADR-SP.scid. Service: statscalc | 2019-08-05 20:54:18.066
HD Request # 67 | Download start date-time: 2019-08-05 19:05:00.000 | 2019-08-05 20:54:18.066
HD Request # 67 | Using server: ds4.sierracharts.com port 10149 | 2019-08-05 20:54:18.067
Socket (5) | Creating socket. | 2019-08-05 20:54:18.067
Socket (5) | Connecting to IP: 192.81.56.146. | 2019-08-05 20:54:18.067
Socket (4) | Socket gracefully closed by remote side. | 2019-08-05 20:54:18.093
Socket (4) | Closed. | 2019-08-05 20:54:18.093
HD Request # 67 | Setting DTC encoding to Binary VLS | 2019-08-05 20:54:18.160
HD Request # 67 | Sending historical data logon request message. | 2019-08-05 20:54:18.160
HD Request # 67 | Requesting Intraday data. Start date-time: 2019-08-05 19:05:00. Record interval: 0. Symbol: ADR-SP | 2019-08-05 20:54:18.213
HD Request # 67 | Decompressing data. | 2019-08-05 20:54:18.254
HD Request # 67 | Receiving Intraday data for ADR-SP starting at 2019-08-05 19:05:00 | 2019-08-05 20:54:18.254
Socket (5) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:54:18.254
Historical data download thread signaled to stop. | 2019-08-05 20:54:18.254
HD Request # 67 | Received 1 record from 2019-08-05 19:05:00.000 to 2019-08-05 19:05:00.000 (0.0 seconds) and wrote 0 records for ADR-SP | 2019-08-05 20:54:18.254
HD Request # 67 | Completion time: 0s | 2019-08-05 20:54:18.256
HD Request # 67 | Intraday data download complete for ADR-SP. Unique request ID: 64 | 2019-08-05 20:54:18.256
Removed historical data download ID 64 | 2019-08-05 20:54:18.256
Real-time Intraday chart data file updates started for ADR-SP | 2019-08-05 20:54:18.256
Intraday chart data file opened for ADR-SP | 2019-08-05 20:54:18.256
HD Request # 68 | Downloading Intraday chart data for JV6T.Z to the file JV6T.Z.scid. Service: transact.trading | 2019-08-05 20:54:18.256
HD Request # 68 | Download start date-time: 2019-01-31 19:54:18.000 | 2019-08-05 20:54:18.257
HD Request # 68 | Using server: ds3.sierracharts.com port 10150 | 2019-08-05 20:54:18.257
Socket (4) | Creating socket. | 2019-08-05 20:54:18.257
Socket (4) | Connecting to IP: 65.182.172.42. | 2019-08-05 20:54:18.258
Socket (5) | Socket gracefully closed by remote side. | 2019-08-05 20:54:18.294
Socket (5) | Closed. | 2019-08-05 20:54:18.294
HD Request # 68 | Setting DTC encoding to Binary VLS | 2019-08-05 20:54:18.332
HD Request # 68 | Sending historical data logon request message. | 2019-08-05 20:54:18.332
HD Request # 68 | Requesting Intraday data. Start date-time: 2019-01-31 19:54:18. Record interval: 0. Symbol: JV6T.Z | 2019-08-05 20:54:18.362
HD Request # 68 | Error downloading historical Intraday data for JV6T.Z. Historical data file not available for symbol. | 2019-08-05 20:54:18.393
Socket (4) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:54:18.393
Historical data download thread signaled to stop. | 2019-08-05 20:54:18.393
HD Request # 68 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for JV6T.Z | 2019-08-05 20:54:18.393
HD Request # 68 | Completion time: 0s | 2019-08-05 20:54:18.394
HD Request # 68 | Intraday data download complete for JV6T.Z. Unique request ID: 65 | 2019-08-05 20:54:18.394
Removed historical data download ID 65 | 2019-08-05 20:54:18.394
Real-time Intraday chart data file updates started for JV6T.Z | 2019-08-05 20:54:18.394
Intraday chart data file opened for JV6T.Z | 2019-08-05 20:54:18.394
HD Request # 69 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2019-08-05 20:54:18.394
HD Request # 69 | Download start date-time: 2019-08-05 19:05:00.000 | 2019-08-05 20:54:18.395
HD Request # 69 | Using server: ds4.sierracharts.com port 10149 | 2019-08-05 20:54:18.395
Socket (5) | Creating socket. | 2019-08-05 20:54:18.395
Socket (5) | Connecting to IP: 192.81.56.146. | 2019-08-05 20:54:18.395
Socket (4) | Socket gracefully closed by remote side. | 2019-08-05 20:54:18.423
Socket (4) | Closed. | 2019-08-05 20:54:18.423
HD Request # 69 | Setting DTC encoding to Binary VLS | 2019-08-05 20:54:18.498
HD Request # 69 | Sending historical data logon request message. | 2019-08-05 20:54:18.498
Chart #24 has tagged chart #23 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:54:18.518
Chart #24 has tagged chart #32 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:54:18.518
HD Request # 69 | Requesting Intraday data. Start date-time: 2019-08-05 19:05:00. Record interval: 0. Symbol: TRIN-NYSE | 2019-08-05 20:54:18.549
HD Request # 69 | Decompressing data. | 2019-08-05 20:54:18.590
HD Request # 69 | Receiving Intraday data for TRIN-NYSE starting at 2019-08-05 19:05:00 | 2019-08-05 20:54:18.590
Socket (5) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:54:18.590
Historical data download thread signaled to stop. | 2019-08-05 20:54:18.590
HD Request # 69 | Received 1 record from 2019-08-05 19:05:00.000 to 2019-08-05 19:05:00.000 (0.0 seconds) and wrote 0 records for TRIN-NYSE | 2019-08-05 20:54:18.590
HD Request # 69 | Completion time: 0s | 2019-08-05 20:54:18.592
HD Request # 69 | Intraday data download complete for TRIN-NYSE. Unique request ID: 66 | 2019-08-05 20:54:18.592
Removed historical data download ID 66 | 2019-08-05 20:54:18.592
Real-time Intraday chart data file updates started for TRIN-NYSE | 2019-08-05 20:54:18.592
Intraday chart data file opened for TRIN-NYSE | 2019-08-05 20:54:18.592
Socket (5) | Socket gracefully closed by remote side. | 2019-08-05 20:54:18.632
Socket (5) | Closed. | 2019-08-05 20:54:18.632
ESU19 [CB] 3 Min #32 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 20:54:18.756
ESU19 [CB] 3 Min #23 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 20:54:22.475
Here is the log when I connect over to SC Data - All Services
Software version: 1969 32-bit | 2019-08-05 20:58:06.556
Usage end date: 2019-09-14 | 2019-08-05 20:58:06.556
Enabled for: Advanced Features 2. | 2019-08-05 20:58:06.556
Enabled for: Sierra Chart Historical Data Service. | 2019-08-05 20:58:06.556
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-08-05 20:58:06.556
Enabled for exchange: INDEXES_DATA_BARCHART | 2019-08-05 20:58:06.556
Enabled for exchange: CME with Market Depth for nonprofessional Trading accounts | 2019-08-05 20:58:06.556
Received 1 data feed usernames. | 2019-08-05 20:58:06.556
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-08-05 20:58:06.556
Current selected Data/Trading service: TransAct WS | 2019-08-05 20:58:06.556
Custom symbol settings values: disabled | 2019-08-05 20:58:06.556
Chart Update Interval: 900 | 2019-08-05 20:58:06.556
Intraday Data Storage Time Unit: 0 | 2019-08-05 20:58:06.556
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-08-05 20:58:06.556
2019-08-05 20:58:06 Local computer time | 2019-08-05 20:58:06.556
2019-08-06 01:58:06 Local computer time in UTC | 2019-08-05 20:58:06.556
2019-08-05 20:58:06 Local computer time in SC Time Zone | 2019-08-05 20:58:06.556
2019-08-05 20:23:46 Server time in UTC | 2019-08-05 20:58:06.556
Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-08-05 20:58:06.556
Program path: C:\SierraChart\ | 2019-08-05 20:58:06.556
Data Files path: C:\SierraChart\Data\ | 2019-08-05 20:58:06.556
OS Version Number: 10.0 | 2019-08-05 20:58:06.556
Locale Setting: C | 2019-08-05 20:58:06.556
DLLs: AdaptiveVolumeRatio_MAByTick.dll, IOAMT.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-08-05 20:58:06.558
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 13. | 2019-08-05 20:58:23.710
Current selected Data/Trading service: SC Data - All Services | 2019-08-05 20:58:23.710
SC Data - All Services | Connected to data server. | 2019-08-05 20:58:27.338
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2019-08-05 20:58:27.340
Symbol settings MD5 received. Request ID: 13. | 2019-08-05 20:58:27.784
Requested symbol settings for service code scdataallservices. Request ID: 14. | 2019-08-05 20:58:27.784
SC Data - All Services | Starting real-time market data updates for: ESU19. ID: 1 | 2019-08-05 20:58:27.787
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESU19 | 2019-08-05 20:58:27.787
SC Data - All Services | Requesting security definition data for: ESU19. ID: 1 | 2019-08-05 20:58:27.787
Added Intraday data request for ESU19 to the queue. | 2019-08-05 20:58:27.787
Intraday data recording state for symbol ESU19 is set to download 'Pending'. | 2019-08-05 20:58:27.787
Delaying start of download for ESU19 | 2019-08-05 20:58:27.851
SC DTC Data with Market Depth | Starting real-time market data updates for: DVOL-SP. ID: 2 Service code: statscalc | 2019-08-05 20:58:28.141
SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2019-08-05 20:58:28.141
SC DTC Data with Market Depth | Requesting security definition data for: DVOL-SP. ID: 2 | 2019-08-05 20:58:28.141
DTC Client socket (3) | Creating socket. | 2019-08-05 20:58:28.142
DTC Client socket (3) | Connecting to IP: 65.182.172.42. | 2019-08-05 20:58:28.142
SC Data - All Services | Starting real-time market data updates for: @ES#c. ID: 3 | 2019-08-05 20:58:28.143
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: @ES#c | 2019-08-05 20:58:28.143
SC Data - All Services | Requesting security definition data for: @ES#c. ID: 3 | 2019-08-05 20:58:28.143
No historical data client is currently set to download historical Intraday data for @ES#c. | 2019-08-05 20:58:28.143
Real-time Intraday chart data file updates started for @ES#c | 2019-08-05 20:58:28.143
Intraday chart data file opened for @ES#c | 2019-08-05 20:58:28.143
SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-SP. ID: 4 Service code: statscalc | 2019-08-05 20:58:28.143
SC DTC Data with Market Depth | Requesting security definition data for: NISS-SP. ID: 4 | 2019-08-05 20:58:28.143
Added Intraday data request for NISS-SP to the queue. | 2019-08-05 20:58:28.143
Intraday data recording state for symbol NISS-SP is set to download 'Pending'. | 2019-08-05 20:58:28.143
SC Data - All Services | Starting real-time market data updates for: ESH19. ID: 5 | 2019-08-05 20:58:28.150
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESH19 | 2019-08-05 20:58:28.150
SC Data - All Services | Requesting security definition data for: ESH19. ID: 5 | 2019-08-05 20:58:28.150
Added Intraday data request for ESH19 to the queue. | 2019-08-05 20:58:28.150
Intraday data recording state for symbol ESH19 is set to download 'Pending'. | 2019-08-05 20:58:28.150
SC Data - All Services | Starting real-time market data updates for: TICKBA-NYSE. ID: 6 | 2019-08-05 20:58:28.151
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: TICKBA-NYSE | 2019-08-05 20:58:28.151
SC Data - All Services | Requesting security definition data for: TICKBA-NYSE. ID: 6 | 2019-08-05 20:58:28.151
No historical data client is currently set to download historical Intraday data for TICKBA-NYSE. | 2019-08-05 20:58:28.151
Real-time Intraday chart data file updates started for TICKBA-NYSE | 2019-08-05 20:58:28.151
Intraday chart data file opened for TICKBA-NYSE | 2019-08-05 20:58:28.151
SC Data - All Services | Starting real-time market data updates for: VI6A.Z. ID: 7 | 2019-08-05 20:58:28.153
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: VI6A.Z | 2019-08-05 20:58:28.153
SC Data - All Services | Requesting security definition data for: VI6A.Z. ID: 7 | 2019-08-05 20:58:28.153
No historical data client is currently set to download historical Intraday data for VI6A.Z. | 2019-08-05 20:58:28.153
Real-time Intraday chart data file updates started for VI6A.Z | 2019-08-05 20:58:28.153
Intraday chart data file opened for VI6A.Z | 2019-08-05 20:58:28.153
SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 8 Service code: statscalc | 2019-08-05 20:58:28.153
SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 8 | 2019-08-05 20:58:28.153
Added Intraday data request for TICK-NYSE to the queue. | 2019-08-05 20:58:28.153
Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2019-08-05 20:58:28.153
SC DTC Data with Market Depth | Connected to server. | 2019-08-05 20:58:28.179
SC DTC Data with Market Depth | Starting socket receive thread. | 2019-08-05 20:58:28.179
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2019-08-05 20:58:28.179
SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-SP. ID: 9 Service code: statscalc | 2019-08-05 20:58:28.179
SC DTC Data with Market Depth | Requesting security definition data for: ADR-SP. ID: 9 | 2019-08-05 20:58:28.179
Added Intraday data request for ADR-SP to the queue. | 2019-08-05 20:58:28.179
Intraday data recording state for symbol ADR-SP is set to download 'Pending'. | 2019-08-05 20:58:28.179
SC Data - All Services | Starting real-time market data updates for: JV6T.Z. ID: 10 | 2019-08-05 20:58:28.182
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: JV6T.Z | 2019-08-05 20:58:28.182
SC Data - All Services | Requesting security definition data for: JV6T.Z. ID: 10 | 2019-08-05 20:58:28.182
No historical data client is currently set to download historical Intraday data for JV6T.Z. | 2019-08-05 20:58:28.183
Real-time Intraday chart data file updates started for JV6T.Z | 2019-08-05 20:58:28.183
Intraday chart data file opened for JV6T.Z | 2019-08-05 20:58:28.183
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2019-08-05 20:58:28.280
SC DTC Data with Market Depth | Sending logon request message. | 2019-08-05 20:58:28.280
SC DTC Data with Market Depth | Received logon response. | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Successfully connected. | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Trading is not supported. | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-SP | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DVOL-SP | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-SP | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 11 Service code: statscalc | 2019-08-05 20:58:28.334
SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 11 | 2019-08-05 20:58:28.334
Added Intraday data request for TRIN-NYSE to the queue. | 2019-08-05 20:58:28.334
Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2019-08-05 20:58:28.334
SC Data - All Services | Starting real-time market data updates for: $SPX. ID: 12 Service code: cboe.index | 2019-08-05 20:58:28.339
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: $SPX | 2019-08-05 20:58:28.339
SC Data - All Services | Requesting security definition data for: $SPX. ID: 12 | 2019-08-05 20:58:28.339
SC Data - All Services | Starting real-time market data updates for: VRCT.Z. ID: 13 Service code: equities.us | 2019-08-05 20:58:28.341
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: VRCT.Z | 2019-08-05 20:58:28.341
SC Data - All Services | Requesting security definition data for: VRCT.Z. ID: 13 | 2019-08-05 20:58:28.341
SC Data - All Services | Starting real-time market data updates for: VRET.Z. ID: 14 Service code: equities.us | 2019-08-05 20:58:28.342
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: VRET.Z | 2019-08-05 20:58:28.342
SC Data - All Services | Requesting security definition data for: VRET.Z. ID: 14 | 2019-08-05 20:58:28.342
Requesting market depth updates for: ESU19 if supported. | 2019-08-05 20:58:28.342
Separate subscription for market depth updates not supported. ESU19 | 2019-08-05 20:58:28.342
SC DTC Data with Market Depth | Received security definition for symbol ADR-SP | 2019-08-05 20:58:28.382
SC DTC Data with Market Depth | Received security definition for symbol DVOL-SP | 2019-08-05 20:58:28.382
SC DTC Data with Market Depth | Received security definition for symbol NISS-SP | 2019-08-05 20:58:28.382
SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2019-08-05 20:58:28.382
SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2019-08-05 20:58:28.382
HD Request # 70 | Downloading Intraday chart data for ESU19 to the file ESU19.scid. Service: cme | 2019-08-05 20:58:32.974
HD Request # 70 | Download start date-time: 2019-08-05 20:41:21.000 | 2019-08-05 20:58:32.975
HD Request # 70 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2019-08-05 20:58:32.975
Socket (1) | Creating socket. | 2019-08-05 20:58:32.975
Socket (1) | Connecting to IP: 8.18.161.135. | 2019-08-05 20:58:32.975
HD Request # 70 | Setting DTC encoding to Binary VLS | 2019-08-05 20:58:33.039
HD Request # 70 | Sending historical data logon request message. | 2019-08-05 20:58:33.039
HD Request # 70 | Requesting Intraday data. Start date-time: 2019-08-05 20:41:21. Record interval: 0. Symbol: ESU19 | 2019-08-05 20:58:33.068
HD Request # 70 | Decompressing data. | 2019-08-05 20:58:33.100
HD Request # 70 | Receiving Intraday data for ESU19 starting at 2019-08-05 20:41:21 | 2019-08-05 20:58:33.193
HD Request # 70 | Timestamp of first Intraday data file record written: 2019-08-05 20:41:22 | 2019-08-05 20:58:33.194
Historical data download thread signaled to stop. | 2019-08-05 20:58:33.196
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:58:33.196
HD Request # 70 | Received 5095 records from 2019-08-05 20:41:21.000 to 2019-08-05 20:48:34.000 (7.2 minutes) and wrote 5092 records for ESU19 | 2019-08-05 20:58:33.197
HD Request # 70 | Completion time: 1s | 2019-08-05 20:58:33.198
HD Request # 70 | Intraday data download complete for ESU19. Unique request ID: 67 | 2019-08-05 20:58:33.198
Removed historical data download ID 67 | 2019-08-05 20:58:33.198
Real-time Intraday chart data file updates started for ESU19 | 2019-08-05 20:58:33.198
Intraday chart data file opened for ESU19 | 2019-08-05 20:58:33.198
HD Request # 71 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2019-08-05 20:58:33.198
HD Request # 71 | Download start date-time: 2019-08-05 19:05:00.000 | 2019-08-05 20:58:33.199
HD Request # 71 | Using server: ds3.sierracharts.com port 10149 | 2019-08-05 20:58:33.199
Socket (4) | Creating socket. | 2019-08-05 20:58:33.200
Socket (4) | Connecting to IP: 65.182.172.42. | 2019-08-05 20:58:33.200
Socket (1) | Socket gracefully closed by remote side. | 2019-08-05 20:58:33.225
Socket (1) | Closed. | 2019-08-05 20:58:33.225
HD Request # 71 | Setting DTC encoding to Binary VLS | 2019-08-05 20:58:33.269
HD Request # 71 | Sending historical data logon request message. | 2019-08-05 20:58:33.269
HD Request # 71 | Requesting Intraday data. Start date-time: 2019-08-05 19:05:00. Record interval: 0. Symbol: NISS-SP | 2019-08-05 20:58:33.298
HD Request # 71 | Decompressing data. | 2019-08-05 20:58:33.328
HD Request # 71 | Receiving Intraday data for NISS-SP starting at 2019-08-05 19:05:00 | 2019-08-05 20:58:33.328
Socket (4) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:58:33.328
Historical data download thread signaled to stop. | 2019-08-05 20:58:33.328
HD Request # 71 | Received 1 record from 2019-08-05 19:05:00.000 to 2019-08-05 19:05:00.000 (0.0 seconds) and wrote 0 records for NISS-SP | 2019-08-05 20:58:33.328
HD Request # 71 | Completion time: 0s | 2019-08-05 20:58:33.330
HD Request # 71 | Intraday data download complete for NISS-SP. Unique request ID: 68 | 2019-08-05 20:58:33.330
Removed historical data download ID 68 | 2019-08-05 20:58:33.330
Real-time Intraday chart data file updates started for NISS-SP | 2019-08-05 20:58:33.330
Intraday chart data file opened for NISS-SP | 2019-08-05 20:58:33.330
HD Request # 72 | Downloading Intraday chart data for ESH19 to the file ESH19.scid. Service: cme | 2019-08-05 20:58:33.330
HD Request # 72 | Download start date-time: 2019-03-15 08:29:55.000 | 2019-08-05 20:58:33.331
HD Request # 72 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-08-05 20:58:33.331
Socket (1) | Creating socket. | 2019-08-05 20:58:33.332
Socket (1) | Connecting to IP: 8.18.161.133. | 2019-08-05 20:58:33.332
Socket (4) | Socket gracefully closed by remote side. | 2019-08-05 20:58:33.358
Socket (4) | Closed. | 2019-08-05 20:58:33.358
HD Request # 72 | Setting DTC encoding to Binary VLS | 2019-08-05 20:58:33.401
HD Request # 72 | Sending historical data logon request message. | 2019-08-05 20:58:33.401
Symbol settings received. Request ID: 14. | 2019-08-05 20:58:33.438
HD Request # 72 | Requesting Intraday data. Start date-time: 2019-03-15 08:29:55. Record interval: 0. Symbol: ESH19 | 2019-08-05 20:58:33.439
HD Request # 72 | Decompressing data. | 2019-08-05 20:58:33.472
HD Request # 72 | Receiving Intraday data for ESH19 starting at 2019-03-15 08:29:55 | 2019-08-05 20:58:33.473
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:58:33.473
Socket (1) | Socket gracefully closed by remote side. | 2019-08-05 20:58:33.500
Socket (1) | Closed. | 2019-08-05 20:58:33.500
Historical data download thread signaled to stop. | 2019-08-05 20:58:33.516
HD Request # 72 | Received 1 record from 2019-03-15 08:29:55.000 to 2019-03-15 08:29:55.000 (0.0 seconds) and wrote 0 records for ESH19 | 2019-08-05 20:58:33.516
HD Request # 72 | Completion time: 0s | 2019-08-05 20:58:33.517
HD Request # 72 | Intraday data download complete for ESH19. Unique request ID: 69 | 2019-08-05 20:58:33.517
Removed historical data download ID 69 | 2019-08-05 20:58:33.517
Real-time Intraday chart data file updates started for ESH19 | 2019-08-05 20:58:33.517
Intraday chart data file opened for ESH19 | 2019-08-05 20:58:33.517
HD Request # 73 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2019-08-05 20:58:33.517
HD Request # 73 | Download start date-time: 2019-08-05 19:05:00.000 | 2019-08-05 20:58:33.517
HD Request # 73 | Using server: ds4.sierracharts.com port 10149 | 2019-08-05 20:58:33.517
Socket (1) | Creating socket. | 2019-08-05 20:58:33.517
Socket (1) | Connecting to IP: 192.81.56.146. | 2019-08-05 20:58:33.518
Chart #20 has tagged chart #10 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:58:33.527
Chart #20 has tagged chart #13 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:58:33.527
Chart #20 has tagged chart #23 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:58:33.527
Chart #20 has tagged chart #32 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:58:33.527
HD Request # 73 | Setting DTC encoding to Binary VLS | 2019-08-05 20:58:33.610
HD Request # 73 | Sending historical data logon request message. | 2019-08-05 20:58:33.610
Chart #30 has tagged chart #13 for full recalculation. Chartbook: ES.cht | 2019-08-05 20:58:33.714
ESU19 [CB] 2 Sec #13 | Performing a full recalculation because it has been tagged. Chartbook: ES.cht | 2019-08-05 20:58:33.723
HD Request # 73 | Requesting Intraday data. Start date-time: 2019-08-05 19:05:00. Record interval: 0. Symbol: TICK-NYSE | 2019-08-05 20:58:34.642
HD Request # 73 | Decompressing data. | 2019-08-05 20:58:34.682
HD Request # 73 | Receiving Intraday data for TICK-NYSE starting at 2019-08-05 19:05:00 | 2019-08-05 20:58:34.683
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-05 20:58:34.683
Socket (1) | Socket gracefully closed by remote side. | 2019-08-05 20:58:34.723
Socket (1) | Closed. | 2019-08-05 20:58:34.723
Historical data download thread signaled to stop. | 2019-08-05 20:58:35.071
HD Request # 73 | Received 1 record from 2019-08-05 19:05:00.000 to 2019-08-05 19:05:00.000 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2019-08-05 20:58:35.071
HD Request # 73 | Completion time: 2s | 2019-08-05 20:58:35.071
HD Request # 73 | Intraday data download complete for TICK-NYSE. Unique request ID: 70 | 2019-08-05 20:58:35.071
Removed historical data download ID 70 | 2019-08-05 20:58:35.071
Real-time Intraday chart data file updates started for TICK-NYSE | 2019-08-05 20:58:35.071
Intraday chart data file opened for TICK-NYSE | 2019-08-05 20:58:35.071
HD Request # 74 | Downloading Intraday chart data for ADR-SP to the file ADR-SP.scid. Service: statscalc | 2019-08-05 20:58:35.072
HD Request # 74 | Download start date-time: 2019-08-05 19:05:00.000 | 2019-08-05 20:58:35.072
HD Request # 74 | Using server: ds3.sierracharts.com port 10150 | 2019-08-05 20:58:35.072
Socket (1) | Creating socket. | 2019-08-05 20:58:35.072
Socket (1) | Connecting to IP: 65.182.172.42. | 2019-08-05 20:58:35.072
Date Time Of Last Edit: 2019-08-06 06:49:07
[2019-08-06 06:49:26]
We see the problem:
We will have this resolved in 1970 which will be out before morning.
[2020-05-02 19:43:25]
j4ytr4der_ - Posts: 946
I'm running version 2098 (prerelease) and also getting this message. Is there something I need to do on my side? Settings all look correct to me. I have an email in to TransACT support as well but doubt I'll hear back until Monday.
[2020-05-03 23:48:13]
Refer to this particular section:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError
[2020-05-04 02:22:33]
Thanks, I've already contacted them so am just waiting to hear back, probably tomorrow I'm guessing.
But if I choose one of their options to use SC, won't that mean I'll be paying them monthly for it also? I've already paid directly to you, so I'm a bit confused regarding the suggestion at that link. Thanks.
