Date/Time: Thu, 16 Jan 2025 12:01:40 +0000
connection errors
View Count: 1151
[2017-10-23 12:27:09]
User729700 - Posts: 10
I am able to log in to Sierra Charts but every few minutes my message log says connection to external service has been lost and my charts and data then reload--this has only happened since i logged on this morning and as far as i am aware nothing has changed on my system at my end.Below is a copy of my message log. Thank you for your assistance.
jon harman
Reading Internal Order ID file. | 2017-10-23 12:05:07
Reading Trade Orders file. | 2017-10-23 12:05:07
Reading Trade Positions file. | 2017-10-23 12:05:07
Listening on UDP port 22903. | 2017-10-23 12:05:07
Software version: 1627 | 2017-10-23 12:05:07
Enabled for: Advanced Features. | 2017-10-23 12:05:07
Enabled for: Advanced Features 2. | 2017-10-23 12:05:07
Enabled for: Sierra Chart Historical Data Service. | 2017-10-23 12:05:07
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-10-23 12:05:07
Current selected Data/Trading service: CQG FIX Trading | 2017-10-23 12:05:07
Chart Update Interval: 500 | 2017-10-23 12:05:07
Data/Trade Service Settings automatically set. | 2017-10-23 12:05:07
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2017-10-23 12:05:07
2017-10-23 12:05:13 Local computer time | 2017-10-23 12:05:07
2017-10-23 11:05:13 Local computer time in UTC | 2017-10-23 12:05:07
2017-10-23 12:05:13 Local computer time in SC Time Zone | 2017-10-23 12:05:07
2017-10-23 11:05:10 Server time in UTC | 2017-10-23 12:05:07
Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-10-23 12:05:07
Program path: C:\SierraChart\ | 2017-10-23 12:05:07
Data Files path: C:\SierraChart\Data\ | 2017-10-23 12:05:07
OS Version Number: 6.1 | 2017-10-23 12:05:07
Locale Setting: C | 2017-10-23 12:05:07
Socket (414) | Socket gracefully closed by remote side. | 2017-10-23 13:11:05
Socket (414) | Closed. | 2017-10-23 13:11:05
Opened cached Intraday file: C:\SierraChart\Data\F.US.FDXMZ17.scid | 2017-10-23 13:11:21
CQG WebSocket socket (372) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-10-23 13:11:39
CQG WebSocket socket (372) | Closed. | 2017-10-23 13:11:39
CQG WebSocket socket (372) | Socket gracefully closed by remote side. | 2017-10-23 13:11:39
CQG WebSocket socket (372) | Deleting network socket now after delay. | 2017-10-23 13:12:09
CQG WebSocket socket (397) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-10-23 13:23:26 *
CQG WebSocket socket (397) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2017-10-23 13:23:26
CQG WebSocket socket (397) | Socket gracefully closed by remote side. | 2017-10-23 13:23:26
CQG WebSocket socket (397) | Received socket Close event. | 2017-10-23 13:23:26
CQG WebSocket socket (397) | Initiating close of socket by core. | 2017-10-23 13:23:26
CQG WebSocket | Network socket for WebSocket has been closed by remote side. | 2017-10-23 13:23:26
CQG FIX Trading | WebSocket closed. | 2017-10-23 13:23:26
Connection to the external service has been lost. | 2017-10-23 13:23:26
CQG WebSocket socket (397) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-23 13:23:26
CQG WebSocket socket (397) | Closed. | 2017-10-23 13:23:26
CQG FIX: DisconnectFIX called. | 2017-10-23 13:23:26
CQG FIX: Sending a Logout message. | 2017-10-23 13:23:26
CQG FIX Trading | Disconnected. | 2017-10-23 13:23:26
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-23 13:23:26
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2017-10-23 13:23:26
CQG FIX socket (396) | Initiating close of socket by core. | 2017-10-23 13:23:26
CQG FIX: Disconnected. | 2017-10-23 13:23:26
CQG FIX socket (396) | Shutdown started. Waiting for graceful close. | 2017-10-23 13:23:26
CQG FIX socket (396) | Socket gracefully closed by remote side. | 2017-10-23 13:23:26
CQG FIX socket (396) | Closed. | 2017-10-23 13:23:26
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-10-23 13:23:29
CQG FIX socket (429) | Creating socket. Using TLS 1.2. | 2017-10-23 13:23:29
CQG FIX socket (429) | Connecting to IP: 208.48.16.214. | 2017-10-23 13:23:29
CQG FIX: Sending the Logon message. | 2017-10-23 13:23:29
CQG FIX Trading | Connected to trading server. | 2017-10-23 13:23:30
CQG FIX Trading | Connecting to server api.cqg.com | 2017-10-23 13:23:30
CQG WebSocket | Connecting to WebSocket server. | 2017-10-23 13:23:30
CQG FIX | FCM name: AMP | 2017-10-23 13:23:30
CQG WebSocket socket (430) | Creating socket. Using TLS 1.2. | 2017-10-23 13:23:30
CQG WebSocket socket (430) | Connecting to IP: 195.166.124.165. | 2017-10-23 13:23:30
CQG WebSocket | Opening WebSocket. | 2017-10-23 13:23:30
CQG WebSocket | Sending WebSocket handshake. | 2017-10-23 13:23:30
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-10-23 13:23:30
CQG WebSocket | Web socket state is now open. | 2017-10-23 13:23:30
CQG FIX Trading | WebSocket connected. | 2017-10-23 13:23:30
CQG FIX Trading | Sending market data logon message. | 2017-10-23 13:23:30
CQG FIX Trading | Logon successful. Session Token = XVOCrp+TXMesJWrk8Lp81Ggi7dQT9Gs498L9AZYo9joqhcf5uF1oDYAO1ikMvQFdG6SphzKJAAj | 2017-10-23 13:23:30
CQG FIX Trading | Connected to data and trading server. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.DLM17. ID: 1 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.DLM17. ID: 710826 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.DLM17. ID: 1 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6M17. ID: 2 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.CA6M17. ID: 710827 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.CA6M17. ID: 2 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6M17. ID: 3 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.BP6M17. ID: 710828 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.BP6M17. ID: 3 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6M17. ID: 4 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.EU6M17. ID: 710829 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.EU6M17. ID: 4 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ17. ID: 5 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ17. ID: 710830 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.DDZ17. ID: 5 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.DDZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
Delaying start of download for F.US.DDZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.DLZ17. ID: 6 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.DLZ17. ID: 710831 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.DLZ17. ID: 6 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.DLZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6Z17. ID: 7 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.EU6Z17. ID: 710832 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.EU6Z17. ID: 7 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.EU6Z17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.DDZ7. Search Symbol: F.US.DDZ17. Request ID: 710830. Contract ID: 1. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.DDZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.DLZ7. Search Symbol: F.US.DLZ17. Request ID: 710831. Contract ID: 2. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.DLZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.EU6Z7. Search Symbol: F.US.EU6Z17. Request ID: 710832. Contract ID: 3. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.EU6Z17 | 2017-10-23 13:23:30
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-10-23 13:23:30
Symbol Error - F.US.DLM17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-10-23 13:23:30
Symbol Error - F.US.CA6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-10-23 13:23:30
Symbol Error - F.US.BP6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-10-23 13:23:30
Symbol Error - F.US.EU6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.EPZ17. ID: 8 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.EPZ17. ID: 710833 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.EPZ17. ID: 8 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.EPZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.EPZ7. Search Symbol: F.US.EPZ17. Request ID: 710833. Contract ID: 4. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.EPZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.FBTPZ17. ID: 9 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.FBTPZ17. ID: 710834 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.FBTPZ17. ID: 9 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.FBTPZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
HD Request # 321 | Downloading Intraday chart data for F.US.DDZ17 to the file F.US.DDZ17.scid. Service: cqg | 2017-10-23 13:23:30
HD Request # 321 | Download start date-time: 2017-10-23 13:23:06.000 | 2017-10-23 13:23:30
HD Request # 321 | Using server: ds3.sierracharts.com port 10149 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.JY6Z17. ID: 10 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.JY6Z17. ID: 710835 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.JY6Z17. ID: 10 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.JY6Z17 is set to download 'Pending'. | 2017-10-23 13:23:30
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.EPZ17.2017-10-23.depth | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.FGBXZ17. ID: 11 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.FGBXZ17. ID: 710836 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.FGBXZ17. ID: 11 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.FGBXZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.FBTPZ7. Search Symbol: F.US.FBTPZ17. Request ID: 710834. Contract ID: 5. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.FBTPZ17 | 2017-10-23 13:23:30
Socket (431) | Creating socket. | 2017-10-23 13:23:30
Socket (431) | Connecting to IP: 65.182.172.42. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.DGZ17. ID: 12 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.DGZ17. ID: 710837 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.DGZ17. ID: 12 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.DGZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.DBZ17. ID: 13 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.DBZ17. ID: 710838 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.DBZ17. ID: 13 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.DBZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.JY6Z7. Search Symbol: F.US.JY6Z17. Request ID: 710835. Contract ID: 6. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.JY6Z17 | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.FGBXZ7. Search Symbol: F.US.FGBXZ17. Request ID: 710836. Contract ID: 7. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.FGBXZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.DGZ7. Search Symbol: F.US.DGZ17. Request ID: 710837. Contract ID: 8. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.DGZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.DBZ7. Search Symbol: F.US.DBZ17. Request ID: 710838. Contract ID: 9. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.DBZ17 | 2017-10-23 13:23:30
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DBZ17.2017-10-23.depth | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6Z17. ID: 14 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.BP6Z17. ID: 710839 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.BP6Z17. ID: 14 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.BP6Z17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.FOATZ17. ID: 15 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.FOATZ17. ID: 710840 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.FOATZ17. ID: 15 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.FOATZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.TYAZ17. ID: 16 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.TYAZ17. ID: 710841 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.TYAZ17. ID: 16 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.TYAZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.BP6Z7. Search Symbol: F.US.BP6Z17. Request ID: 710839. Contract ID: 10. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.BP6Z17 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.USAZ17. ID: 17 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.USAZ17. ID: 710842 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.USAZ17. ID: 17 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.USAZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ17. ID: 18 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ17. ID: 710843 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ17. ID: 18 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.DSXZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.FOATZ7. Search Symbol: F.US.FOATZ17. Request ID: 710840. Contract ID: 11. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.FOATZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.TYAZ7. Search Symbol: F.US.TYAZ17. Request ID: 710841. Contract ID: 12. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.TYAZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.CLEZ17. ID: 19 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.CLEZ17. ID: 710844 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.CLEZ17. ID: 19 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.CLEZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.USAZ7. Search Symbol: F.US.USAZ17. Request ID: 710842. Contract ID: 13. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.USAZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.FDXMZ17. ID: 20 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.FDXMZ17. ID: 710845 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.FDXMZ17. ID: 20 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.FDXMZ17 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXZ7. Search Symbol: F.US.DSXZ17. Request ID: 710843. Contract ID: 14. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.DSXZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEZ7. Search Symbol: F.US.CLEZ17. Request ID: 710844. Contract ID: 15. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.CLEZ17 | 2017-10-23 13:23:30
CQG FIX Trading | Received symbol resolution report for symbol F.US.FDXMZ7. Search Symbol: F.US.FDXMZ17. Request ID: 710845. Contract ID: 16. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data for F.US.FDXMZ17 | 2017-10-23 13:23:30
HD Request # 321 | Setting DTC encoding to Binary VLS | 2017-10-23 13:23:30
HD Request # 321 | Sending historical data logon request message. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ16. ID: 21 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ16. ID: 710846 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ16. ID: 21 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.DSXZ16 is set to download 'Pending'. | 2017-10-23 13:23:30
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ16. ID: 22 | 2017-10-23 13:23:30
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ16. ID: 710847 | 2017-10-23 13:23:30
CQG FIX Trading | Requesting security definition data for: F.US.DDZ16. ID: 22 | 2017-10-23 13:23:30
Intraday data recording state for symbol F.US.DDZ16 is set to download 'Pending'. | 2017-10-23 13:23:30
Requesting market depth updates for: F.US.DDZ17 if supported. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data including full depth for F.US.DDZ17 | 2017-10-23 13:23:30
Requesting market depth updates for: F.US.DBZ17 if supported. | 2017-10-23 13:23:30
CQG FIX Trading | Requesting market data including full depth for F.US.DBZ17 | 2017-10-23 13:23:30
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DDZ17.2017-10-23.depth | 2017-10-23 13:23:31
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-10-23 13:23:31
Symbol Error - F.US.DSXZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-10-23 13:23:31
Symbol Error - F.US.DDZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-10-23 13:23:31
CQG FIX Trading | Starting real-time market data updates for: F.US.TUAZ17. ID: 23 | 2017-10-23 13:23:31
CQG FIX Trading | Sending symbol resolution request for F.US.TUAZ17. ID: 710848 | 2017-10-23 13:23:31
CQG FIX Trading | Requesting security definition data for: F.US.TUAZ17. ID: 23 | 2017-10-23 13:23:31
CQG FIX Trading | Starting real-time market data updates for: F.US.FVAZ17. ID: 24 | 2017-10-23 13:23:31
CQG FIX Trading | Sending symbol resolution request for F.US.FVAZ17. ID: 710849 | 2017-10-23 13:23:31
CQG FIX Trading | Requesting security definition data for: F.US.FVAZ17. ID: 24 | 2017-10-23 13:23:31
CQG FIX Trading | Received symbol resolution report for symbol F.US.TUAZ7. Search Symbol: F.US.TUAZ17. Request ID: 710848. Contract ID: 17. | 2017-10-23 13:23:31
CQG FIX Trading | Requesting market data for F.US.TUAZ17 | 2017-10-23 13:23:31
HD Request # 321 | Requesting Intraday data. Start date-time: 2017-10-23 13:23:06. Record interval: 0. Symbol: F.US.DDZ17 | 2017-10-23 13:23:31
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVAZ7. Search Symbol: F.US.FVAZ17. Request ID: 710849. Contract ID: 18. | 2017-10-23 13:23:31
CQG FIX Trading | Requesting market data for F.US.FVAZ17 | 2017-10-23 13:23:31
HD Request # 321 | Decompressing data. | 2017-10-23 13:23:31
HD Request # 321 | Receiving Intraday data for F.US.DDZ17 starting at 2017-10-23 13:23:06 | 2017-10-23 13:23:31
HD Request # 321 | Timestamp of first Intraday data file record written: 2017-10-23 13:23:08 | 2017-10-23 13:23:31
Socket (431) | Initiating close of socket by core. | 2017-10-23 13:23:31
Historical data download thread signaled to stop. | 2017-10-23 13:23:31
Socket (431) | Shutdown started. Waiting for graceful close. | 2017-10-23 13:23:31
HD Request # 321 | Received 17 records from 2017-10-23 13:23:06 to 2017-10-23 13:23:28 (22.0 seconds) and wrote 15 records for F.US.DDZ17 | 2017-10-23 13:23:31
HD Request # 321 | Intraday download COMPLETE for F.US.DDZ17. Completion time: 0s. Unique request ID: 319 | 2017-10-23 13:23:31
Removed historical data download ID 319 | 2017-10-23 13:23:31
Real-time Intraday chart data file updates started for F.US.DDZ17 | 2017-10-23 13:23:31
Intraday chart data file opened for F.US.DDZ17 | 2017-10-23 13:23:31
Delaying start of download for F.US.DLZ17 | 2017-10-23 13:23:31
Socket (431) | Socket gracefully closed by remote side. | 2017-10-23 13:23:31
Socket (431) | Closed. | 2017-10-23 13:23:31
Requesting market depth updates for: F.US.BP6Z17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.BP6Z17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.CLEZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.CLEZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.DGZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.DGZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.DLZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.DLZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.DSXZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.DSXZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.EPZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.EPZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.EU6Z17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.EU6Z17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.FBTPZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.FBTPZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.FDXMZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.FDXMZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.FGBXZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.FGBXZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.FOATZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.FOATZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.JY6Z17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.JY6Z17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.TYAZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.TYAZ17 | 2017-10-23 13:23:35
Requesting market depth updates for: F.US.USAZ17 if supported. | 2017-10-23 13:23:35
CQG FIX Trading | Requesting market data including full depth for F.US.USAZ17 | 2017-10-23 13:23:35
HD Request # 322 | Downloading Intraday chart data for F.US.DLZ17 to the file F.US.DLZ17.scid. Service: cqg | 2017-10-23 13:23:35
HD Request # 322 | Download start date-time: 2017-10-23 13:23:01.000 | 2017-10-23 13:23:35
HD Request # 322 | Using server: ds4.sierracharts.com port 10150 | 2017-10-23 13:23:35
Socket (432) | Creating socket. | 2017-10-23 13:23:35
Socket (432) | Connecting to IP: 192.81.56.146. | 2017-10-23 13:23:35
HD Request # 322 | Setting DTC encoding to Binary VLS | 2017-10-23 13:23:35
HD Request # 322 | Sending historical data logon request message. | 2017-10-23 13:23:35
HD Request # 322 | Requesting Intraday data. Start date-time: 2017-10-23 13:23:01. Record interval: 0. Symbol: F.US.DLZ17 | 2017-10-23 13:23:36
HD Request # 322 | Decompressing data. | 2017-10-23 13:23:36
HD Request # 322 | Receiving Intraday data for F.US.DLZ17 starting at 2017-10-23 13:23:01 | 2017-10-23 13:23:36
HD Request # 322 | Timestamp of first Intraday data file record written: 2017-10-23 13:23:12 | 2017-10-23 13:23:36
Socket (432) | Initiating close of socket by core. | 2017-10-23 13:23:36
Socket (432) | Shutdown started. Waiting for graceful close. | 2017-10-23 13:23:36
Historical data download thread signaled to stop. | 2017-10-23 13:23:36
HD Request # 322 | Received 29 records from 2017-10-23 13:23:01 to 2017-10-23 13:23:28 (27.0 seconds) and wrote 23 records for F.US.DLZ17 | 2017-10-23 13:23:36
HD Request # 322 | Intraday download COMPLETE for F.US.DLZ17. Completion time: 0s. Unique request ID: 320 | 2017-10-23 13:23:36
Removed historical data download ID 320 | 2017-10-23 13:23:36
Real-time Intraday chart data file updates started for F.US.DLZ17 | 2017-10-23 13:23:36
Intraday chart data file opened for F.US.DLZ17 | 2017-10-23 13:23:36
HD Request # 323 | Downloading Intraday chart data for F.US.EU6Z17 to the file F.US.EU6Z17.scid. Service: cqg | 2017-10-23 13:23:36
HD Request # 323 | Download start date-time: 2017-10-23 13:23:06.000 | 2017-10-23 13:23:36
HD Request # 323 | Using server: ds3.sierracharts.com port 10149 | 2017-10-23 13:23:36
Socket (433) | Creating socket. | 2017-10-23 13:23:36
Socket (433) | Connecting to IP: 65.182.172.42. | 2017-10-23 13:23:36
Socket (432) | Socket gracefully closed by remote side. | 2017-10-23 13:23:36
Socket (432) | Closed. | 2017-10-23 13:23:36
HD Request # 323 | Setting DTC encoding to Binary VLS | 2017-10-23 13:23:38
HD Request # 323 | Sending historical data logon request message. | 2017-10-23 13:23:38
HD Request # 323 | Requesting Intraday data. Start date-time: 2017-10-23 13:23:06. Record interval: 0. Symbol: F.US.EU6Z17 | 2017-10-23 13:23:38
HD Request # 323 | Decompressing data. | 2017-10-23 13:23:38
HD Request # 323 | Receiving Intraday data for F.US.EU6Z17 starting at 2017-10-23 13:23:06 | 2017-10-23 13:23:38
HD Request # 323 | Timestamp of first Intraday data file record written: 2017-10-23 13:23:13 | 2017-10-23 13:23:38
Socket (433) | Initiating close of socket by core. | 2017-10-23 13:23:38
Socket (433) | Shutdown started. Waiting for graceful close. | 2017-10-23 13:23:38
Historical data download thread signaled to stop. | 2017-10-23 13:23:38
HD Request # 323 | Received 37 records from 2017-10-23 13:23:06 to 2017-10-23 13:23:36 (30.0 seconds) and wrote 36 records for F.US.EU6Z17 | 2017-10-23 13:23:38
HD Request # 323 | Intraday download COMPLETE for F.US.EU6Z17. Completion time: 2s. Unique request ID: 321 | 2017-10-23 13:23:38
Removed historical data download ID 321 | 2017-10-23 13:23:38
Real-time Intraday chart data file updates started for F.US.EU6Z17 | 2017-10-23 13:23:38
Intraday chart data file opened for F.US.EU6Z17 | 2017-10-23 13:23:38
HD Request # 324 | Downloading Intraday chart data for F.US.EPZ17 to the file F.US.EPZ17.scid. Service: cqg | 2017-10-23 13:23:38
HD Request # 324 | Download start date-time: 2017-10-23 13:23:01.000 | 2017-10-23 13:23:38
HD Request # 324 | Using server: ds4.sierracharts.com port 10150 | 2017-10-23 13:23:38
Socket (434) | Creating socket. | 2017-10-23 13:23:38
Socket (434) | Connecting to IP: 192.81.56.146. | 2017-10-23 13:23:38
Socket (433) | Socket gracefully closed by remote side. | 2017-10-23 13:23:38
Socket (433) | Closed. | 2017-10-23 13:23:38
HD Request # 324 | Setting DTC encoding to Binary VLS | 2017-10-23 13:23:38
HD Request # 324 | Sending historical data logon request message. | 2017-10-23 13:23:38
HD Request # 324 | Requesting Intraday data. Start date-time: 2017-10-23 13:23:01. Record interval: 0. Symbol: F.US.EPZ17 | 2017-10-23 13:23:39
HD Request # 324 | Decompressing data. | 2017-10-23 13:23:39
HD Request # 324 | Receiving Intraday data for F.US.EPZ17 starting at 2017-10-23 13:23:01 | 2017-10-23 13:23:39
HD Request # 324 | Timestamp of first Intraday data file record written: 2017-10-23 13:23:18 | 2017-10-23 13:23:39
Socket (434) | Initiating close of socket by core. | 2017-10-23 13:23:39
Historical data download thread signaled to stop. | 2017-10-23 13:23:39
Socket (434) | Shutdown started. Waiting for graceful close. | 2017-10-23 13:23:39
HD Request # 324 | Received 4 records from 2017-10-23 13:23:01 to 2017-10-23 13:23:18 (17.0 seconds) and wrote 2 records for F.US.EPZ17 | 2017-10-23 13:23:39
HD Request # 324 | Intraday download COMPLETE for F.US.EPZ17. Completion time: 0s. Unique request ID: 322 | 2017-10-23 13:23:39
Removed historical data download ID 322 | 2017-10-23 13:23:39
Real-time Intraday chart data file updates started for F.US.EPZ17 | 2017-10-23 13:23:39
Intraday chart data file opened for F.US.EPZ17 | 2017-10-23 13:23:39
HD Request # 325 | Downloading Intraday chart data for F.US.FBTPZ17 to the file F.US.FBTPZ17.scid. Service: eurex | 2017-10-23 13:23:39
HD Request # 325 | Download start date-time: 2017-10-23 13:23:01.000 | 2017-10-23 13:23:39
HD Request # 325 | Using server: ds1.sierracharts.com port 10149 | 2017-10-23 13:23:39
Socket (435) | Creating socket. | 2017-10-23 13:23:39
Socket (435) | Connecting to IP: 8.18.161.135. | 2017-10-23 13:23:39
Socket (434) | Socket gracefully closed by remote side. | 2017-10-23 13:23:39
Socket (434) | Closed. | 2017-10-23 13:23:39
HD Request # 325 | Setting DTC encoding to Binary VLS | 2017-10-23 13:23:39
HD Request # 325 | Sending historical data logon request message. | 2017-10-23 13:23:39
HD Request # 325 | Requesting Intraday data. Start date-time: 2017-10-23 13:23:01. Record interval: 0. Symbol: IIZ17 | 2017-10-23 13:23:39
HD Request # 325 | Decompressing data. | 2017-10-23 13:23:40
Socket (435) | Initiating close of socket by core. | 2017-10-23 13:23:40
Socket (435) | Shutdown started. Waiting for graceful close. | 2017-10-23 13:23:40
Historical data download thread signaled to stop. | 2017-10-23 13:23:40
HD Request # 325 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FBTPZ17 | 2017-10-23 13:23:40
HD Request # 325 | Intraday download COMPLETE for F.US.FBTPZ17. Completion time: 0s. Unique request ID: 323 | 2017-10-23 13:23:40
Removed historical data download ID 323 | 2017-10-23 13:23:40
Real-time Intraday chart data file updates started for F.US.FBTPZ17 | 2017-10-23 13:23:40
Intraday chart data file opened for F.US.FBTPZ17 | 2017-10-23 13:23:40
HD Request # 326 | Downloading Intraday chart data for F.US.JY6Z17 to the file F.US.JY6Z17.scid. Service: cqg | 2017-10-23 13:23:40
HD Request # 326 | Download start date-time: 2017-10-23 13:23:03.000 | 2017-10-23 13:23:40
HD Request # 326 | Using server: ds3.sierracharts.com port 10150 | 2017-10-23 13:23:40
Socket (436) | Creating socket. | 2017-10-23 13:23:40
Socket (436) | Connecting to IP: 65.182.172.42. | 2017-10-23 13:23:40
Socket (435) | Socket gracefully closed by remote side. | 2017-10-23 13:23:40
Socket (435) | Closed. | 2017-10-23 13:23:40
HD Request # 326 | Setting DTC encoding to Binary VLS | 2017-10-23 13:23:40
HD Request # 326 | Sending historical data logon request message. | 2017-10-23 13:23:40
HD Request # 326 | Requesting Intraday data. Start date-time: 2017-10-23 13:23:03. Record interval: 0. Symbol: F.US.JY6Z17 | 2017-10-23 13:23:40
HD Request # 326 | Decompressing data. | 2017-10-23 13:23:40
HD Request # 326 | Receiving Intraday data for F.US.JY6Z17 starting at 2017-10-23 13:23:03 | 2017-10-23 13:23:40
HD Request # 326 | Timestamp of first Intraday data file record written: 2017-10-23 13:23:08 | 2017-10-23 13:23:40
Socket (436) | Initiating close of socket by core. | 2017-10-23 13:23:40
Socket (436) | Shutdown started. Waiting for graceful close. | 2017-10-23 13:23:40
HD Request # 326 | Received 55 records from 2017-10-23 13:23:03 to 2017-10-23 13:23:37 (34.0 seconds) and wrote 53 records for F.US.JY6Z17 | 2017-10-23 13:23:40
HD Request # 326 | Intraday download COMPLETE for F.US.JY6Z17. Completion time: 1s. Unique request ID: 324 | 2017-10-23 13:23:40
Removed historical data download ID 324 | 2017-10-23 13:23:40
Real-time Intraday chart data file updates started for F.US.JY6Z17 | 2017-10-23 13:23:40
Intraday chart data file opened for F.US.JY6Z17 | 2017-10-23 13:23:40
HD Request # 327 | Downloading Intraday chart data for F.US.FGBXZ17 to the file F.US.FGBXZ17.scid. Service: cqg | 2017-10-23 13:23:40
HD Request # 327 | Download start date-time: 2017-10-23 13:22:52.000 | 2017-10-23 13:23:40
HD Request # 327 | Using server: ds4.sierracharts.com port 10149 | 2017-10-23 13:23:40
Socket (437) | Creating socket. | 2017-10-23 13:23:40
Socket (437) | Connecting to IP: 192.81.56.146. | 2017-10-23 13:23:40
Socket (436) | Socket gracefully closed by remote side. | 2017-10-23 13:23:40
Socket (436) | Closed. | 2017-10-23 13:23:40
HD Request # 327 | Setting DTC encoding to Binary VLS | 2017-10-23 13:23:40
HD Request # 327 | Sending historical data logon request message. | 2017-10-23 13:23:40
HD Request # 327 | Requesting Intraday data. Start date-time: 2017-10-23 13:22:52. Record interval: 0. Symbol: F.US.FGBXZ17 | 2017-10-23 13:23:40
Date Time Of Last Edit: 2017-10-23 17:01:01
[2017-10-23 14:33:49]
HI--the issue detailed above is still ongoing--any idea what the issue is or how to resolve it ?
thanks
Jon
[2017-10-23 17:02:19]
These are the relevant messages:
Refer to:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
There is some connectivity issue between Sierra Chart and the CQG server somewhere. Or a problem with the CQG server.
Date Time Of Last Edit: 2017-10-24 14:40:35
[2017-10-24 07:26:40]
This is continuing to happen at a frequent pace--sometimes every 3 or 4 minutes sometimes 9 or 10 minutes.. Has a fault been reported to CQG? How do i do anything to resolve this issue? I have checked my router/firewall PC settings and can see nothing at my end.I receive CQG data direct from yourselves so am unaware of howe i can contact CQG if the fault lies at their end.
Thanks for your help
Jon
[2017-10-24 14:37:18]
No, we are not optimistic that would help.
The data comes from CQG. Not from Sierra Chart.
We recommend contacting your broker and have them change your account to use CTS instead:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php
For the most reliable connection use the new low-cost connection model for CTS which is documented here:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructionsForAdvancedLowCostConnectionModel
That connection model uses the Sierra Chart data feed.
If you decide to change to CTS, then you need to change the symbols of the charts as explained here:
Changing the Symbol of a Chart
Using the low-cost CTS connection model will give you the very best connectivity assuming the problem is not on your side.
Date Time Of Last Edit: 2017-10-24 14:38:23
[2017-10-24 14:41:29]
We realize we did not give the right link in post #3. This is the correct link:
[2017-10-26 17:41:45]
User97684 - Posts: 136
Hi Jon,
I have exactly the same problem that started around the same time as yours - 3 days or so back. But i am not on CQG, but on Gain. Still happening here, have you sorted yours ?
Thanks,
ves
[2017-10-26 18:18:28]
If you are having a problem connecting to the Gain Capital server, then refer to the instructions here:
https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem
There is no need to ask another user about this. They are not qualified to help with it. Only Sierra Chart engineering can help you.
Date Time Of Last Edit: 2017-10-26 18:19:12
[2017-10-27 12:41:55]
HI Ves
Sadly still got same issues---bizarrely had no problems yesterday at all but back with a vengeance today--makes no sense
Jon
[2017-10-27 17:35:41]
In response to post #9 this is our response:
connection errors | Post: 130133
[2017-10-31 19:42:05]
HI--thank you for your reply. Your suggestion is that i use CTS with your (Sierra charts) data feed. My problem is that i like my current set-up i,e Sierra charts for trading and charting and don't want to change that. Is it not possible to change from a data feed with CQG to a data feed from yourselves but continue with my existing trading and charting visuals? Would this not also be a potential solution to my issue? You seem to be inferring that there are issues for people using CQG data feed with Sierra charts without actually spelling them out---i previously used TT as a data feed supplier and that worked fine until that option was removed. If there are ongoing issues with CQG that you are unable to discuss then obviously i need to change but i would prefer to just change the data feed not the charting and trading package.
thanks
[2017-11-01 09:04:43]
Are you still noticing this problem when using Sierra Chart version 1632?
Since there is what seems to be an apparent bug/issue in Open SSL that we worked around in 1632, that might possibly be leading to this problem.
In your particular case we do not think this is the problem but we just want to be sure.
While we do occasionally hear about connectivity troubles with CQG, nothing severe like in your case. We will follow up with CQG about this once we hear back from you. Because since they are going to start to charge us every month, they really have to do a better job since this appears to be a problem on their side.
Date Time Of Last Edit: 2017-11-01 09:06:28
[2017-11-01 09:26:13]
Hi--thanks for your reply---i have just updated to 1632 this morning so i will run it for today and update you later.
Jon
[2017-11-01 14:52:19]
Hi--after installing version 1632 this morning i had no issues for 3 hours before i got the message CQG WebSocket socket (20) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 10:43:14 *
CQG WebSocket socket (20) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2017-11-01 10:43:14
I logged off my machine, turned off my anti virus and firewall and re logged on. After about 45 minutes i got the message: CQG FIX: No heartbeat messages received from server. Sent Test Request message to server. | 2017-11-01 11:30:33
CQG FIX: Disconnecting due to a loss of activity. No activity for at least 42 seconds. | 2017-11-01 11:31:53 *
it seems to make no difference whether i have my firewall on or off---since about 11-30 i have had more and more frequent log offs with it seeming to alternate between Windows Error Code 10053 and "No heartbeat received from server"
I have no issues with internet connectivity on other machines or programs so i don't believe the issue is my server. I have attached the latest log files for your info
thanks
Jon
Reading Internal Order ID file. | 2017-11-01 11:07:52
Reading Trade Orders file. | 2017-11-01 11:07:52
Reading Trade Positions file. | 2017-11-01 11:07:52
Listening on UDP port 22903. | 2017-11-01 11:07:52
Software version: 1632 | 2017-11-01 11:07:52
Enabled for: Advanced Features. | 2017-11-01 11:07:52
Enabled for: Advanced Features 2. | 2017-11-01 11:07:52
Enabled for: Sierra Chart Historical Data Service. | 2017-11-01 11:07:52
Allow Support for Sierra Chart Data Feeds is enabled. | 2017-11-01 11:07:52
Current selected Data/Trading service: CQG FIX Trading | 2017-11-01 11:07:52
Chart Update Interval: 500 | 2017-11-01 11:07:52
Data/Trade Service Settings automatically set. | 2017-11-01 11:07:52
Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2017-11-01 11:07:52
2017-11-01 11:08:02 Local computer time | 2017-11-01 11:07:52
2017-11-01 11:08:02 Local computer time in UTC | 2017-11-01 11:07:52
2017-11-01 11:08:02 Local computer time in SC Time Zone | 2017-11-01 11:07:52
2017-11-01 11:08:06 Server time in UTC | 2017-11-01 11:07:52
Local computer UTC time and Server UTC time difference: 8 seconds. | 2017-11-01 11:07:52
Program path: C:\SierraChart\ | 2017-11-01 11:07:52
Data Files path: C:\SierraChart\Data\ | 2017-11-01 11:07:52
OS Version Number: 6.1 | 2017-11-01 11:07:52
Locale Setting: C | 2017-11-01 11:07:52
Created the DTC Protocol server. | 2017-11-01 11:07:52
DTC Protocol Server listening on port 11099. | 2017-11-01 11:07:52
Created the DTC Protocol historical data server. | 2017-11-01 11:07:52
HD Server Manager | Listening on port 11098 | 2017-11-01 11:07:52
Checking for new symbol settings for service code cqg | 2017-11-01 11:07:52
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-11-01 11:07:52
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-11-01 11:07:52
Symbol settings are up-to-date for cqg | 2017-11-01 11:07:52
Received 5 login tokens. | 2017-11-01 11:08:04
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-11-01 11:08:05
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-11-01 11:08:05
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-11-01 11:08:08
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-11-01 11:08:10
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-11-01 11:08:10
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-11-01 11:08:10
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 11:08:10
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-11-01 11:08:10
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-01 11:08:13
CQG FIX socket (6) | Creating socket. Using TLS 1.2. | 2017-11-01 11:08:13
CQG FIX socket (6) | Connecting to IP: 208.48.16.214. | 2017-11-01 11:08:13
CQG FIX: Sending the Logon message. | 2017-11-01 11:08:13
CQG FIX Trading | Connected to trading server. | 2017-11-01 11:08:14
CQG FIX Trading | Connecting to server api.cqg.com | 2017-11-01 11:08:14
CQG WebSocket | Connecting to WebSocket server. | 2017-11-01 11:08:14
CQG FIX | FCM name: AMP | 2017-11-01 11:08:14
CQG WebSocket socket (7) | Creating socket. Using TLS 1.2. | 2017-11-01 11:08:14
CQG WebSocket socket (7) | Connecting to IP: 195.166.124.165. | 2017-11-01 11:08:14
CQG WebSocket | Opening WebSocket. | 2017-11-01 11:08:14
CQG WebSocket | Sending WebSocket handshake. | 2017-11-01 11:08:14
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-11-01 11:08:14
CQG WebSocket | Web socket state is now open. | 2017-11-01 11:08:14
CQG FIX Trading | WebSocket connected. | 2017-11-01 11:08:14
CQG FIX Trading | Sending market data logon message. | 2017-11-01 11:08:14
CQG FIX Trading | Logon successful. Session Token = Sn9hJPvILzj97ERIiwyLTjaeFv63thBz8/E/xrWDe4Y0KN7Pf99bkpPJh0wvKkNJKbYK97aiYg7 | 2017-11-01 11:08:14
CQG FIX Trading | Connected to data and trading server. | 2017-11-01 11:08:14
CQG FIX Trading | Starting real-time market data updates for: F.US.DLM17. ID: 1 | 2017-11-01 11:08:14
CQG FIX Trading | Sending symbol resolution request for F.US.DLM17. ID: 593607 | 2017-11-01 11:08:14
CQG FIX Trading | Requesting security definition data for: F.US.DLM17. ID: 1 | 2017-11-01 11:08:14
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6M17. ID: 2 | 2017-11-01 11:08:14
CQG FIX Trading | Sending symbol resolution request for F.US.CA6M17. ID: 593608 | 2017-11-01 11:08:14
CQG FIX Trading | Requesting security definition data for: F.US.CA6M17. ID: 2 | 2017-11-01 11:08:14
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6M17. ID: 3 | 2017-11-01 11:08:14
CQG FIX Trading | Sending symbol resolution request for F.US.BP6M17. ID: 593609 | 2017-11-01 11:08:14
CQG FIX Trading | Requesting security definition data for: F.US.BP6M17. ID: 3 | 2017-11-01 11:08:14
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6M17. ID: 4 | 2017-11-01 11:08:14
CQG FIX Trading | Sending symbol resolution request for F.US.EU6M17. ID: 593610 | 2017-11-01 11:08:14
CQG FIX Trading | Requesting security definition data for: F.US.EU6M17. ID: 4 | 2017-11-01 11:08:14
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6Z17. ID: 5 | 2017-11-01 11:08:14
CQG FIX Trading | Sending symbol resolution request for F.US.CA6Z17. ID: 593611 | 2017-11-01 11:08:14
CQG FIX Trading | Requesting security definition data for: F.US.CA6Z17. ID: 5 | 2017-11-01 11:08:14
CQG FIX Trading | Received symbol resolution report for symbol F.US.CA6Z7. Search Symbol: F.US.CA6Z17. Request ID: 593611. Contract ID: 1. | 2017-11-01 11:08:15
CQG FIX Trading | Requesting market data for F.US.CA6Z17 | 2017-11-01 11:08:15
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 11:08:15
Symbol Error - F.US.DLM17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:08:15
Symbol Error - F.US.CA6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:08:15
Symbol Error - F.US.BP6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:08:15
Symbol Error - F.US.EU6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:08:15
F.US.EPZ17 5 Min #4 | Reloading chart. | 2017-11-01 11:08:42
F.US.DBZ17 1500 Volume #13 | Reloading chart. | 2017-11-01 11:08:42
Chart #13 | Base Graph BarEndIntradayFileIndex: Array is unallocated. | 2017-11-01 11:08:42 *
F.US.DBZ17 #5 | Reloading chart. | 2017-11-01 11:08:42
Array message repeat count limit reached. | 2017-11-01 11:08:42 *
F.US.DSXZ16 2500 Volume #15 | Reloading chart. | 2017-11-01 11:08:42
F.US.TYAZ17 5 Min #17 | Reloading chart. | 2017-11-01 11:08:42
F.US.DBZ17 [CBV] 15 Min #20 | Reloading chart. | 2017-11-01 11:08:42
F.US.DBZ17 [CBV] 60 Min #23 | Reloading chart. | 2017-11-01 11:08:42
+ Loading market depth data. | 2017-11-01 11:08:42
Loaded depth data records for F.US.DBZ17 2017-10-23 from 2017-10-23 07:44:51 to 2017-10-23 20:59:59. | 2017-11-01 11:08:42
Loaded depth data records for F.US.DBZ17 2017-10-24 from 2017-10-24 07:39:33 to 2017-10-24 20:59:59. | 2017-11-01 11:08:42
Loaded depth data records for F.US.DBZ17 2017-10-25 from 2017-10-25 07:41:56 to 2017-10-25 20:59:56. | 2017-11-01 11:08:42
F.US.DBZ17 [CBV] 3 Min #25 | Reloading chart. | 2017-11-01 11:08:42
F.US.DSXZ16 5 Min #26 | Reloading chart. | 2017-11-01 11:08:42
Loaded depth data records for F.US.DBZ17 2017-10-26 from 2017-10-26 08:50:51 to 2017-10-26 18:04:02. | 2017-11-01 11:08:42
Loaded depth data records for F.US.DBZ17 2017-10-27 from 2017-10-27 07:35:47 to 2017-10-27 17:21:26. | 2017-11-01 11:08:42
Loaded depth data records for F.US.DBZ17 2017-10-29 from 2017-10-29 13:06:16 to 2017-10-29 18:06:45. | 2017-11-01 11:08:42
Loaded depth data records for F.US.DBZ17 2017-10-30 from 2017-10-30 07:29:40 to 2017-10-30 18:52:30. | 2017-11-01 11:08:42
F.US.DBZ17 5 Min #28 | Reloading chart. | 2017-11-01 11:08:42
Loaded depth data records for F.US.DBZ17 2017-10-31 from 2017-10-31 07:58:31 to 2017-10-31 20:15:59. | 2017-11-01 11:08:42
Loaded depth data records for F.US.DBZ17 2017-11-01 from 2017-11-01 07:45:48 to 2017-11-01 11:05:33. | 2017-11-01 11:08:42
F.US.DSXZ17 [CBV] #2 | Reloading chart. | 2017-11-01 11:08:42
F.US.DBZ17 Renko 2t #3 | Reloading chart. | 2017-11-01 11:08:42
F.US.DSXZ16 Renko 2t #8 | Reloading chart. | 2017-11-01 11:08:42
F.US.TYAZ17 #11 | Reloading chart. | 2017-11-01 11:08:42
F.US.DDZ16 10 Min #16 | Reloading chart. | 2017-11-01 11:08:42
F.US.EU6Z17 #19 | Reloading chart. | 2017-11-01 11:08:42
F.US.BP6Z17 #12 | Reloading chart. | 2017-11-01 11:08:42
F.US.USAZ17 #30 | Reloading chart. | 2017-11-01 11:08:42
F.US.DGZ17 [CBV] 60 Min #33 | Reloading chart. | 2017-11-01 11:08:42
F.US.DLZ17 #9 | Reloading chart. | 2017-11-01 11:08:42
F.US.DGZ17 #36 | Reloading chart. | 2017-11-01 11:08:42
F.US.FGBXZ17 #38 | Reloading chart. | 2017-11-01 11:08:42
F.US.FBTPZ17 #39 | Reloading chart. | 2017-11-01 11:08:42
F.US.DSXZ17 #41 | Reloading chart. | 2017-11-01 11:08:42
F.US.JY6Z17 [CV] 5 Min #21 | Reloading chart. | 2017-11-01 11:08:42
F.US.DLZ17 [CBV] #34 | Reloading chart. | 2017-11-01 11:08:42
F.US.EPZ17 #37 | Reloading chart. | 2017-11-01 11:08:42
F.US.DBZ17 10 Min #42 | Reloading chart. | 2017-11-01 11:08:42
F.US.FOATZ17 #43 | Reloading chart. | 2017-11-01 11:08:42
F.US.FOATZ17 [CBV] 15 Min #44 | Reloading chart. | 2017-11-01 11:08:42
F.US.JY6Z17 #40 | Reloading chart. | 2017-11-01 11:08:42
F.US.FDXMZ17 #45 | Reloading chart. | 2017-11-01 11:08:42
F.US.CLEZ17 #46 | Reloading chart. | 2017-11-01 11:08:42
F.US.EU6Z17 #47 | Reloading chart. | 2017-11-01 11:08:42
F.US.DBZ17 [CBV] #48 | Reloading chart. | 2017-11-01 11:08:42
F.US.DBZ17 [CBV] 1 Day #14 | Reloading chart. | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DGZ17. ID: 6 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.DGZ17. ID: 593612 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.DGZ17. ID: 6 | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DLZ17. ID: 7 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.DLZ17. ID: 593613 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.DLZ17. ID: 7 | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DBZ17. ID: 8 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.DBZ17. ID: 593614 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.DBZ17. ID: 8 | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FGBXZ17. ID: 9 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.FGBXZ17. ID: 593615 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.FGBXZ17. ID: 9 | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FBTPZ17. ID: 10 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.FBTPZ17. ID: 593616 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.FBTPZ17. ID: 10 | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FOATZ17. ID: 11 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.FOATZ17. ID: 593617 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.FOATZ17. ID: 11 | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.TUAZ17. ID: 12 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.TUAZ17. ID: 593618 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.TUAZ17. ID: 12 | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FVAZ17. ID: 13 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.FVAZ17. ID: 593619 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.FVAZ17. ID: 13 | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.TYAZ17. ID: 14 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.TYAZ17. ID: 593620 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.TYAZ17. ID: 14 | 2017-11-01 11:08:42
CQG FIX Trading | Starting real-time market data updates for: F.US.USAZ17. ID: 15 | 2017-11-01 11:08:42
CQG FIX Trading | Sending symbol resolution request for F.US.USAZ17. ID: 593621 | 2017-11-01 11:08:42
CQG FIX Trading | Requesting security definition data for: F.US.USAZ17. ID: 15 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.DGZ7. Search Symbol: F.US.DGZ17. Request ID: 593612. Contract ID: 2. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.DGZ17 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.DLZ7. Search Symbol: F.US.DLZ17. Request ID: 593613. Contract ID: 3. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.DLZ17 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.DBZ7. Search Symbol: F.US.DBZ17. Request ID: 593614. Contract ID: 4. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.DBZ17 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FGBXZ7. Search Symbol: F.US.FGBXZ17. Request ID: 593615. Contract ID: 5. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.FGBXZ17 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FBTPZ7. Search Symbol: F.US.FBTPZ17. Request ID: 593616. Contract ID: 6. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.FBTPZ17 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FOATZ7. Search Symbol: F.US.FOATZ17. Request ID: 593617. Contract ID: 7. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.FOATZ17 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.TUAZ7. Search Symbol: F.US.TUAZ17. Request ID: 593618. Contract ID: 8. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.TUAZ17 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVAZ7. Search Symbol: F.US.FVAZ17. Request ID: 593619. Contract ID: 9. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.FVAZ17 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.TYAZ7. Search Symbol: F.US.TYAZ17. Request ID: 593620. Contract ID: 10. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.TYAZ17 | 2017-11-01 11:08:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.USAZ7. Search Symbol: F.US.USAZ17. Request ID: 593621. Contract ID: 11. | 2017-11-01 11:08:42
CQG FIX Trading | Requesting market data for F.US.USAZ17 | 2017-11-01 11:08:42
CQG FIX: Received a Logout message. Text = RcvTestRequestHeartbeatTimerExpired | 2017-11-01 11:08:42
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2017-11-01 11:08:42
CQG FIX socket (6) | Adding bytes from final send buffer from buffered socket: 215 | 2017-11-01 11:08:42
CQG FIX socket (6) | Initiating close of socket by core. | 2017-11-01 11:08:42
CQG FIX: Disconnected. | 2017-11-01 11:08:42
Connection to the external service has been lost. | 2017-11-01 11:08:42
CQG FIX socket (6) | Write in progress. Shutdown being delayed. | 2017-11-01 11:08:42
CQG FIX socket (6) | Sending bytes from final send buffer: 215 | 2017-11-01 11:08:42
CQG FIX socket (6) | Socket gracefully closed by remote side. | 2017-11-01 11:08:42
CQG FIX socket (6) | Write has completed. Shutdown being performed. | 2017-11-01 11:08:42
CQG FIX socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 11:08:42
CQG FIX socket (6) | Closed. | 2017-11-01 11:08:42
Intraday data recording state for symbol F.US.EPZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
HD Request # 2 | Downloading Intraday chart data for F.US.EPZ17 to the file F.US.EPZ17.scid. Service: cqg | 2017-11-01 11:09:38
HD Request # 2 | Download start date-time: 2017-11-01 11:05:12.000 | 2017-11-01 11:09:38
HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:09:38
F.US.DBZ17 1500 Volume #13 | Reloading chart. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.DBZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
Socket (8) | Creating socket. | 2017-11-01 11:09:38
Socket (8) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.DSXZ16 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.TYAZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
CQG WebSocket | Timeout waiting for pong message from server. | 2017-11-01 11:09:38
CQG WebSocket socket (7) | Adding bytes from final send buffer from buffered socket: 8 | 2017-11-01 11:09:38
CQG WebSocket socket (7) | Initiating close of socket by core. | 2017-11-01 11:09:38
CQG WebSocket | WebSocket closed. | 2017-11-01 11:09:38
CQG WebSocket socket (7) | Write in progress. Shutdown being delayed. | 2017-11-01 11:09:38
CQG FIX Trading | WebSocket closed. | 2017-11-01 11:09:38
CQG WebSocket socket (7) | Sending bytes from final send buffer: 8 | 2017-11-01 11:09:38
CQG WebSocket socket (7) | Write has completed. Shutdown being performed. | 2017-11-01 11:09:38
CQG WebSocket socket (7) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:38
CQG WebSocket socket (7) | Socket gracefully closed by remote side. | 2017-11-01 11:09:38
CQG WebSocket socket (7) | Closed. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.DSXZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.DDZ16 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.EU6Z17 is set to download 'Pending'. | 2017-11-01 11:09:38
HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:38
HD Request # 2 | Sending historical data logon request message. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.BP6Z17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.USAZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.DGZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.DLZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.FGBXZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.FBTPZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.JY6Z17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.FOATZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.FDXMZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
Intraday data recording state for symbol F.US.CLEZ17 is set to download 'Pending'. | 2017-11-01 11:09:38
CQG FIX Trading | Disconnected. | 2017-11-01 11:09:38
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 11:09:38
HD Request # 2 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:12. Record interval: 0. Symbol: F.US.EPZ17 | 2017-11-01 11:09:38
Socket (8) | Initiating close of socket by core. | 2017-11-01 11:09:39
HD Request # 2 | Historical data for F.US.EPZ17 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-01 11:09:39
Historical data download thread signaled to stop. | 2017-11-01 11:09:39
HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EPZ17 | 2017-11-01 11:09:39
HD Request # 2 | Intraday download COMPLETE for F.US.EPZ17. Completion time: 0s. Unique request ID: 1 | 2017-11-01 11:09:39
Removed historical data download ID 1 | 2017-11-01 11:09:39
HD Request # 3 | Downloading Intraday chart data for F.US.DBZ17 to the file F.US.DBZ17.scid. Service: cqg | 2017-11-01 11:09:39
HD Request # 3 | Download start date-time: 2017-11-01 11:05:34.000 | 2017-11-01 11:09:39
Socket (8) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:39
HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:09:39
Socket (9) | Creating socket. | 2017-11-01 11:09:39
Socket (9) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:39
Socket (8) | Socket gracefully closed by remote side. | 2017-11-01 11:09:39
Socket (8) | Closed. | 2017-11-01 11:09:39
HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:39
HD Request # 3 | Sending historical data logon request message. | 2017-11-01 11:09:39
HD Request # 3 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:34. Record interval: 0. Symbol: F.US.DBZ17 | 2017-11-01 11:09:39
Socket (9) | Initiating close of socket by core. | 2017-11-01 11:09:39
HD Request # 3 | Historical data for F.US.DBZ17 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-01 11:09:39
Socket (9) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:39
HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.DBZ17 | 2017-11-01 11:09:39
HD Request # 3 | Intraday download COMPLETE for F.US.DBZ17. Completion time: 0s. Unique request ID: 2 | 2017-11-01 11:09:39
Removed historical data download ID 2 | 2017-11-01 11:09:39
HD Request # 4 | Downloading Intraday chart data for F.US.DSXZ16 to the file F.US.DSXZ16.scid. Service: eurex | 2017-11-01 11:09:39
HD Request # 4 | Download start date-time: 2016-12-16 10:59:59.000 | 2017-11-01 11:09:39
HD Request # 4 | Using server: ds7.sierracharts.com port 10149 | 2017-11-01 11:09:39
Socket (10) | Creating socket. | 2017-11-01 11:09:39
Socket (10) | Connecting to IP: 8.18.161.133. | 2017-11-01 11:09:39
Socket (9) | Socket gracefully closed by remote side. | 2017-11-01 11:09:39
Socket (9) | Closed. | 2017-11-01 11:09:39
HD Request # 4 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:39
HD Request # 4 | Sending historical data logon request message. | 2017-11-01 11:09:39
HD Request # 4 | Requesting Intraday data. Start date-time: 2016-12-16 10:59:59. Record interval: 0. Symbol: FXZ16 | 2017-11-01 11:09:39
+ Loading market depth data. | 2017-11-01 11:09:39
HD Request # 4 | Decompressing data. | 2017-11-01 11:09:39
HD Request # 4 | Receiving Intraday data for F.US.DSXZ16 starting at 2016-12-16 10:59:59 | 2017-11-01 11:09:39
Socket (10) | Initiating close of socket by core. | 2017-11-01 11:09:39
Socket (10) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:39
HD Request # 4 | Historical data for F.US.DSXZ16 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-01 11:09:39
HD Request # 4 | Received 1 record from 2016-12-16 10:59:59 to 2016-12-16 10:59:59 (0.0 seconds) and wrote 0 records for F.US.DSXZ16 | 2017-11-01 11:09:39
HD Request # 4 | Intraday download COMPLETE for F.US.DSXZ16. Completion time: 0s. Unique request ID: 3 | 2017-11-01 11:09:39
Removed historical data download ID 3 | 2017-11-01 11:09:39
HD Request # 5 | Downloading Intraday chart data for F.US.TYAZ17 to the file F.US.TYAZ17.scid. Service: cqg | 2017-11-01 11:09:39
HD Request # 5 | Download start date-time: 2017-11-01 11:05:16.000 | 2017-11-01 11:09:39
HD Request # 5 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:09:39
Socket (11) | Creating socket. | 2017-11-01 11:09:39
Socket (11) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:39
Socket (10) | Socket gracefully closed by remote side. | 2017-11-01 11:09:40
Socket (10) | Closed. | 2017-11-01 11:09:40
HD Request # 5 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:40
HD Request # 5 | Sending historical data logon request message. | 2017-11-01 11:09:40
HD Request # 5 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:16. Record interval: 0. Symbol: F.US.TYAZ17 | 2017-11-01 11:09:40
Loaded depth data records for F.US.DBZ17 2017-10-23 from 2017-10-23 07:44:51 to 2017-10-23 20:59:59. | 2017-11-01 11:09:40
Socket (11) | Initiating close of socket by core. | 2017-11-01 11:09:40
HD Request # 5 | Historical data for F.US.TYAZ17 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-01 11:09:40
Socket (11) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:40
Historical data download thread signaled to stop. | 2017-11-01 11:09:40
HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.TYAZ17 | 2017-11-01 11:09:40
HD Request # 5 | Intraday download COMPLETE for F.US.TYAZ17. Completion time: 1s. Unique request ID: 4 | 2017-11-01 11:09:40
Removed historical data download ID 4 | 2017-11-01 11:09:40
HD Request # 6 | Downloading Intraday chart data for F.US.DSXZ17 to the file F.US.DSXZ17.scid. Service: cqg | 2017-11-01 11:09:40
HD Request # 6 | Download start date-time: 2017-11-01 11:05:32.000 | 2017-11-01 11:09:40
HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:09:40
Socket (12) | Creating socket. | 2017-11-01 11:09:40
Socket (12) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:40
Socket (11) | Socket gracefully closed by remote side. | 2017-11-01 11:09:40
Socket (11) | Closed. | 2017-11-01 11:09:40
HD Request # 6 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:40
HD Request # 6 | Sending historical data logon request message. | 2017-11-01 11:09:40
Loaded depth data records for F.US.DBZ17 2017-10-24 from 2017-10-24 07:39:33 to 2017-10-24 20:59:59. | 2017-11-01 11:09:40
HD Request # 6 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:32. Record interval: 0. Symbol: F.US.DSXZ17 | 2017-11-01 11:09:40
Socket (12) | Initiating close of socket by core. | 2017-11-01 11:09:40
HD Request # 6 | Historical data for F.US.DSXZ17 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-01 11:09:40
Socket (12) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:40
HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.DSXZ17 | 2017-11-01 11:09:40
HD Request # 6 | Intraday download COMPLETE for F.US.DSXZ17. Completion time: 0s. Unique request ID: 5 | 2017-11-01 11:09:40
Removed historical data download ID 5 | 2017-11-01 11:09:40
HD Request # 7 | Downloading Intraday chart data for F.US.DDZ16 to the file F.US.DDZ16.scid. Service: eurex | 2017-11-01 11:09:40
HD Request # 7 | Download start date-time: 2016-12-16 11:59:55.000 | 2017-11-01 11:09:40
HD Request # 7 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 11:09:40
Socket (13) | Creating socket. | 2017-11-01 11:09:40
Socket (13) | Connecting to IP: 8.18.161.135. | 2017-11-01 11:09:40
Socket (12) | Socket gracefully closed by remote side. | 2017-11-01 11:09:40
Socket (12) | Closed. | 2017-11-01 11:09:40
HD Request # 7 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:41
HD Request # 7 | Sending historical data logon request message. | 2017-11-01 11:09:41
HD Request # 7 | Requesting Intraday data. Start date-time: 2016-12-16 11:59:55. Record interval: 0. Symbol: DYZ16 | 2017-11-01 11:09:41
Loaded depth data records for F.US.DBZ17 2017-10-25 from 2017-10-25 07:41:56 to 2017-10-25 20:59:56. | 2017-11-01 11:09:41
HD Request # 7 | Decompressing data. | 2017-11-01 11:09:41
HD Request # 7 | Receiving Intraday data for F.US.DDZ16 starting at 2016-12-16 11:59:55 | 2017-11-01 11:09:41
HD Request # 7 | Historical data for F.US.DDZ16 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-01 11:09:41
Socket (13) | Initiating close of socket by core. | 2017-11-01 11:09:41
Socket (13) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:41
Historical data download thread signaled to stop. | 2017-11-01 11:09:41
HD Request # 7 | Received 1 record from 2016-12-16 11:59:55 to 2016-12-16 11:59:55 (0.0 seconds) and wrote 0 records for F.US.DDZ16 | 2017-11-01 11:09:41
HD Request # 7 | Intraday download COMPLETE for F.US.DDZ16. Completion time: 1s. Unique request ID: 6 | 2017-11-01 11:09:41
Removed historical data download ID 6 | 2017-11-01 11:09:41
HD Request # 8 | Downloading Intraday chart data for F.US.EU6Z17 to the file F.US.EU6Z17.scid. Service: cqg | 2017-11-01 11:09:41
HD Request # 8 | Download start date-time: 2017-11-01 11:05:14.000 | 2017-11-01 11:09:41
HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:09:41
Socket (14) | Creating socket. | 2017-11-01 11:09:41
Socket (14) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:41
Socket (13) | Socket gracefully closed by remote side. | 2017-11-01 11:09:41
Socket (13) | Closed. | 2017-11-01 11:09:41
HD Request # 8 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:41
HD Request # 8 | Sending historical data logon request message. | 2017-11-01 11:09:41
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-01 11:09:41
CQG FIX socket (15) | Creating socket. Using TLS 1.2. | 2017-11-01 11:09:41
CQG FIX socket (15) | Connecting to IP: 208.48.16.214. | 2017-11-01 11:09:41
HD Request # 8 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:14. Record interval: 0. Symbol: F.US.EU6Z17 | 2017-11-01 11:09:41
Socket (14) | Initiating close of socket by core. | 2017-11-01 11:09:41
Socket (14) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:41
Loaded depth data records for F.US.DBZ17 2017-10-26 from 2017-10-26 08:50:51 to 2017-10-26 18:04:02. | 2017-11-01 11:09:41
HD Request # 8 | Historical data for F.US.EU6Z17 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-01 11:09:41
Socket (14) | Socket gracefully closed by remote side. | 2017-11-01 11:09:41
Socket (14) | Closed. | 2017-11-01 11:09:41
HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.EU6Z17 | 2017-11-01 11:09:41
HD Request # 8 | Intraday download COMPLETE for F.US.EU6Z17. Completion time: 0s. Unique request ID: 7 | 2017-11-01 11:09:41
Removed historical data download ID 7 | 2017-11-01 11:09:41
HD Request # 9 | Downloading Intraday chart data for F.US.BP6Z17 to the file F.US.BP6Z17.scid. Service: cqg | 2017-11-01 11:09:41
HD Request # 9 | Download start date-time: 2017-11-01 11:05:31.000 | 2017-11-01 11:09:41
HD Request # 9 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:09:41
CQG FIX: Sending the Logon message. | 2017-11-01 11:09:42
Socket (16) | Creating socket. | 2017-11-01 11:09:42
Socket (16) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:42
HD Request # 9 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:42
HD Request # 9 | Sending historical data logon request message. | 2017-11-01 11:09:42
CQG FIX Trading | Connected to trading server. | 2017-11-01 11:09:42
CQG FIX Trading | Connecting to server api.cqg.com | 2017-11-01 11:09:42
CQG WebSocket | Connecting to WebSocket server. | 2017-11-01 11:09:42
CQG WebSocket socket (17) | Creating socket. Using TLS 1.2. | 2017-11-01 11:09:42
CQG WebSocket socket (17) | Connecting to IP: 195.166.124.165. | 2017-11-01 11:09:42
HD Request # 9 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:31. Record interval: 0. Symbol: F.US.BP6Z17 | 2017-11-01 11:09:42
Loaded depth data records for F.US.DBZ17 2017-10-27 from 2017-10-27 07:35:47 to 2017-10-27 17:21:26. | 2017-11-01 11:09:42
Loaded depth data records for F.US.DBZ17 2017-10-29 from 2017-10-29 13:06:16 to 2017-10-29 18:06:45. | 2017-11-01 11:09:42
CQG WebSocket | Opening WebSocket. | 2017-11-01 11:09:42
CQG WebSocket | Sending WebSocket handshake. | 2017-11-01 11:09:42
CQG FIX | FCM name: AMP | 2017-11-01 11:09:42
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-11-01 11:09:43
CQG WebSocket | Web socket state is now open. | 2017-11-01 11:09:43
CQG FIX Trading | WebSocket connected. | 2017-11-01 11:09:43
CQG FIX Trading | Sending market data logon message. | 2017-11-01 11:09:43
Socket (16) | Initiating close of socket by core. | 2017-11-01 11:09:43
HD Request # 9 | Historical data for F.US.BP6Z17 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-11-01 11:09:43
Socket (16) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:43
Historical data download thread signaled to stop. | 2017-11-01 11:09:43
HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.BP6Z17 | 2017-11-01 11:09:43
HD Request # 9 | Intraday download COMPLETE for F.US.BP6Z17. Completion time: 0s. Unique request ID: 8 | 2017-11-01 11:09:43
Removed historical data download ID 8 | 2017-11-01 11:09:43
HD Request # 10 | Downloading Intraday chart data for F.US.USAZ17 to the file F.US.USAZ17.scid. Service: cqg | 2017-11-01 11:09:43
HD Request # 10 | Download start date-time: 2017-11-01 11:05:24.000 | 2017-11-01 11:09:43
HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:09:43
Socket (18) | Creating socket. | 2017-11-01 11:09:43
Socket (18) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:43
Socket (16) | Socket gracefully closed by remote side. | 2017-11-01 11:09:43
Socket (16) | Closed. | 2017-11-01 11:09:43
CQG FIX Trading | Logon successful. Session Token = 5OAMxIugNwhXlHVL8XPHt7+Cgg4Yr8i1gA2HP63Qs7M6mS09TAu5ibaTccW6mZh6B5goGzIoEua | 2017-11-01 11:09:43
CQG FIX Trading | Connected to data and trading server. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.DLM17. ID: 1 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.DLM17. ID: 593622 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.DLM17. ID: 1 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6M17. ID: 2 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.CA6M17. ID: 593623 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.CA6M17. ID: 2 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6M17. ID: 3 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.BP6M17. ID: 593624 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.BP6M17. ID: 3 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6M17. ID: 4 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.EU6M17. ID: 593625 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.EU6M17. ID: 4 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6Z17. ID: 5 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.CA6Z17. ID: 593626 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.CA6Z17. ID: 5 | 2017-11-01 11:09:43
HD Request # 10 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:43
HD Request # 10 | Sending historical data logon request message. | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.CA6Z7. Search Symbol: F.US.CA6Z17. Request ID: 593626. Contract ID: 1. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.CA6Z17 | 2017-11-01 11:09:43
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 11:09:43
Symbol Error - F.US.DLM17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:09:43
Symbol Error - F.US.CA6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:09:43
Symbol Error - F.US.BP6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:09:43
Symbol Error - F.US.EU6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:09:43
Loaded depth data records for F.US.DBZ17 2017-10-30 from 2017-10-30 07:29:40 to 2017-10-30 18:52:30. | 2017-11-01 11:09:43
HD Request # 10 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:24. Record interval: 0. Symbol: F.US.USAZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.TYAZ17. ID: 6 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.TYAZ17. ID: 593627 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.TYAZ17. ID: 6 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.TYAZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6Z17. ID: 7 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.EU6Z17. ID: 593628 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.EU6Z17. ID: 7 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.EU6Z17 is set to download 'Pending'. | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.TYAZ7. Search Symbol: F.US.TYAZ17. Request ID: 593627. Contract ID: 2. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.TYAZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.USAZ17. ID: 8 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.USAZ17. ID: 593629 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.USAZ17. ID: 8 | 2017-11-01 11:09:43
Historical Intraday data request for F.US.USAZ17 is discarded because a matching download is in progress and the new one is not for earlier data. | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.USAZ17 has been reset to 'Downloading'. | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.EU6Z7. Search Symbol: F.US.EU6Z17. Request ID: 593628. Contract ID: 3. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.EU6Z17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.USAZ7. Search Symbol: F.US.USAZ17. Request ID: 593629. Contract ID: 4. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.USAZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.DLZ17. ID: 9 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.DLZ17. ID: 593630 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.DLZ17. ID: 9 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.DLZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
Historical Intraday data request for F.US.DLZ17 is discarded because a matching download is already pending and the new one is not for earlier data. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.DGZ17. ID: 10 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.DGZ17. ID: 593631 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.DGZ17. ID: 10 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.DGZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
Historical Intraday data request for F.US.DGZ17 is discarded because a matching download is already pending and the new one is not for earlier data. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.FGBXZ17. ID: 11 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.FGBXZ17. ID: 593632 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.FGBXZ17. ID: 11 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.FGBXZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
Historical Intraday data request for F.US.FGBXZ17 is discarded because a matching download is already pending and the new one is not for earlier data. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.FBTPZ17. ID: 12 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.FBTPZ17. ID: 593633 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.FBTPZ17. ID: 12 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.FBTPZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
Historical Intraday data request for F.US.FBTPZ17 is discarded because a matching download is already pending and the new one is not for earlier data. | 2017-11-01 11:09:43
Socket (18) | Initiating close of socket by core. | 2017-11-01 11:09:43
Socket (18) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:43
HD Request # 10 | Re-requesting historical data for F.US.USAZ17 to get the latest data since the download was started while not connected to primary service. | 2017-11-01 11:09:43
HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.USAZ17 | 2017-11-01 11:09:43
Delaying start of download for F.US.USAZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ17. ID: 13 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ17. ID: 593634 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ17. ID: 13 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.DSXZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.DLZ7. Search Symbol: F.US.DLZ17. Request ID: 593630. Contract ID: 5. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.DLZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.DGZ7. Search Symbol: F.US.DGZ17. Request ID: 593631. Contract ID: 6. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.DGZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.FGBXZ7. Search Symbol: F.US.FGBXZ17. Request ID: 593632. Contract ID: 7. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.FGBXZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.FBTPZ7. Search Symbol: F.US.FBTPZ17. Request ID: 593633. Contract ID: 8. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.FBTPZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.EPZ17. ID: 14 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.EPZ17. ID: 593635 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.EPZ17. ID: 14 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.EPZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.FOATZ17. ID: 15 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.FOATZ17. ID: 593636 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.FOATZ17. ID: 15 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.FOATZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
Historical Intraday data request for F.US.FOATZ17 is discarded because a matching download is already pending and the new one is not for earlier data. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.JY6Z17. ID: 16 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.JY6Z17. ID: 593637 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.JY6Z17. ID: 16 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.JY6Z17 is set to download 'Pending'. | 2017-11-01 11:09:43
Historical Intraday data request for F.US.JY6Z17 is discarded because a matching download is already pending and the new one is not for earlier data. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.FDXMZ17. ID: 17 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.FDXMZ17. ID: 593638 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.FDXMZ17. ID: 17 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.FDXMZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
Historical Intraday data request for F.US.FDXMZ17 is discarded because a matching download is already pending and the new one is not for earlier data. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.CLEZ17. ID: 18 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.CLEZ17. ID: 593639 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.CLEZ17. ID: 18 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.CLEZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
Historical Intraday data request for F.US.CLEZ17 is discarded because a matching download is already pending and the new one is not for earlier data. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.DBZ17. ID: 19 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.DBZ17. ID: 593640 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.DBZ17. ID: 19 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.DBZ17 is set to download 'Pending'. | 2017-11-01 11:09:43
HD Request # 11 | Downloading Intraday chart data for F.US.USAZ17 to the file F.US.USAZ17.scid. Service: cqg | 2017-11-01 11:09:43
HD Request # 11 | Download start date-time: 2017-11-01 11:05:24.000 | 2017-11-01 11:09:43
HD Request # 11 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:09:43
Socket (19) | Creating socket. | 2017-11-01 11:09:43
Socket (19) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6Z17. ID: 20 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.BP6Z17. ID: 593641 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.BP6Z17. ID: 20 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.BP6Z17 is set to download 'Pending'. | 2017-11-01 11:09:43
Requesting market depth updates for: F.US.DBZ17 if supported. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ16. ID: 21 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ16. ID: 593642 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ16. ID: 21 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.DSXZ16 is set to download 'Pending'. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ16. ID: 22 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ16. ID: 593643 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.DDZ16. ID: 22 | 2017-11-01 11:09:43
Intraday data recording state for symbol F.US.DDZ16 is set to download 'Pending'. | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXZ7. Search Symbol: F.US.DSXZ17. Request ID: 593634. Contract ID: 9. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.DSXZ17 | 2017-11-01 11:09:43
Loaded depth data records for F.US.DBZ17 2017-10-31 from 2017-10-31 07:58:31 to 2017-10-31 20:15:59. | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.TUAZ17. ID: 23 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.TUAZ17. ID: 593644 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.TUAZ17. ID: 23 | 2017-11-01 11:09:43
CQG FIX Trading | Starting real-time market data updates for: F.US.FVAZ17. ID: 24 | 2017-11-01 11:09:43
CQG FIX Trading | Sending symbol resolution request for F.US.FVAZ17. ID: 593645 | 2017-11-01 11:09:43
CQG FIX Trading | Requesting security definition data for: F.US.FVAZ17. ID: 24 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.EPZ7. Search Symbol: F.US.EPZ17. Request ID: 593635. Contract ID: 10. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.EPZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.FOATZ7. Search Symbol: F.US.FOATZ17. Request ID: 593636. Contract ID: 11. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.FOATZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.JY6Z7. Search Symbol: F.US.JY6Z17. Request ID: 593637. Contract ID: 12. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.JY6Z17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.FDXMZ7. Search Symbol: F.US.FDXMZ17. Request ID: 593638. Contract ID: 13. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.FDXMZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEZ7. Search Symbol: F.US.CLEZ17. Request ID: 593639. Contract ID: 14. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.CLEZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.DBZ7. Search Symbol: F.US.DBZ17. Request ID: 593640. Contract ID: 15. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data including full depth for F.US.DBZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.BP6Z7. Search Symbol: F.US.BP6Z17. Request ID: 593641. Contract ID: 16. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.BP6Z17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.TUAZ7. Search Symbol: F.US.TUAZ17. Request ID: 593644. Contract ID: 17. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.TUAZ17 | 2017-11-01 11:09:43
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVAZ7. Search Symbol: F.US.FVAZ17. Request ID: 593645. Contract ID: 18. | 2017-11-01 11:09:43
CQG FIX Trading | Requesting market data for F.US.FVAZ17 | 2017-11-01 11:09:43
Socket (18) | Socket gracefully closed by remote side. | 2017-11-01 11:09:43
Socket (18) | Closed. | 2017-11-01 11:09:43
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.EPZ17.2017-11-01.depth | 2017-11-01 11:09:43
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DBZ17.2017-11-01.depth | 2017-11-01 11:09:43
Symbol Error - F.US.DDZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:09:43
Symbol Error - F.US.DSXZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:09:43
Loaded depth data records for F.US.DBZ17 2017-11-01 from 2017-11-01 07:45:48 to 2017-11-01 11:05:33. | 2017-11-01 11:09:43
HD Request # 11 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:46
HD Request # 11 | Sending historical data logon request message. | 2017-11-01 11:09:46
HD Request # 11 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:24. Record interval: 0. Symbol: F.US.USAZ17 | 2017-11-01 11:09:46
HD Request # 11 | Decompressing data. | 2017-11-01 11:09:46
HD Request # 11 | Receiving Intraday data for F.US.USAZ17 starting at 2017-11-01 11:05:24 | 2017-11-01 11:09:46
HD Request # 11 | Timestamp of first Intraday data file record written: 2017-11-01 11:06:00 | 2017-11-01 11:09:46
Socket (19) | Initiating close of socket by core. | 2017-11-01 11:09:46
Socket (19) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:46
Historical data download thread signaled to stop. | 2017-11-01 11:09:46
HD Request # 11 | Received 7 records from 2017-11-01 11:05:24 to 2017-11-01 11:09:23 (4.0 minutes) and wrote 5 records for F.US.USAZ17 | 2017-11-01 11:09:46
HD Request # 11 | Intraday download COMPLETE for F.US.USAZ17. Completion time: 3s. Unique request ID: 9 | 2017-11-01 11:09:46
Removed historical data download ID 9 | 2017-11-01 11:09:46
Real-time Intraday chart data file updates started for F.US.USAZ17 | 2017-11-01 11:09:46
Intraday chart data file opened for F.US.USAZ17 | 2017-11-01 11:09:46
Delaying start of download for F.US.DGZ17 | 2017-11-01 11:09:46
Socket (19) | Socket gracefully closed by remote side. | 2017-11-01 11:09:46
Socket (19) | Closed. | 2017-11-01 11:09:46
Requesting market depth updates for: F.US.BP6Z17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.BP6Z17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.CLEZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.CLEZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.DGZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.DGZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.DLZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.DLZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.DSXZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.DSXZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.EPZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.EPZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.EU6Z17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.EU6Z17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.FBTPZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.FBTPZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.FDXMZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.FDXMZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.FGBXZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.FGBXZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.FOATZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.FOATZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.JY6Z17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.JY6Z17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.TYAZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.TYAZ17 | 2017-11-01 11:09:48
Requesting market depth updates for: F.US.USAZ17 if supported. | 2017-11-01 11:09:48
CQG FIX Trading | Requesting market data including full depth for F.US.USAZ17 | 2017-11-01 11:09:48
HD Request # 12 | Downloading Intraday chart data for F.US.DGZ17 to the file F.US.DGZ17.scid. Service: cqg | 2017-11-01 11:09:48
HD Request # 12 | Download start date-time: 2017-11-01 11:05:25.000 | 2017-11-01 11:09:48
HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:09:48
Socket (20) | Creating socket. | 2017-11-01 11:09:48
Socket (20) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:48
HD Request # 12 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:48
HD Request # 12 | Sending historical data logon request message. | 2017-11-01 11:09:48
HD Request # 12 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:25. Record interval: 0. Symbol: F.US.DGZ17 | 2017-11-01 11:09:48
HD Request # 12 | Decompressing data. | 2017-11-01 11:09:48
HD Request # 12 | Receiving Intraday data for F.US.DGZ17 starting at 2017-11-01 11:05:25 | 2017-11-01 11:09:48
HD Request # 12 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:50 | 2017-11-01 11:09:48
Socket (20) | Initiating close of socket by core. | 2017-11-01 11:09:48
Socket (20) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:48
Historical data download thread signaled to stop. | 2017-11-01 11:09:48
HD Request # 12 | Received 18 records from 2017-11-01 11:05:25 to 2017-11-01 11:09:55 (4.5 minutes) and wrote 17 records for F.US.DGZ17 | 2017-11-01 11:09:48
Added 1 Time and Sales records to Intraday data file for F.US.DGZ17 after download. | 2017-11-01 11:09:48
HD Request # 12 | Intraday download COMPLETE for F.US.DGZ17. Completion time: 1s. Unique request ID: 10 | 2017-11-01 11:09:48
Removed historical data download ID 10 | 2017-11-01 11:09:48
Real-time Intraday chart data file updates started for F.US.DGZ17 | 2017-11-01 11:09:48
Intraday chart data file opened for F.US.DGZ17 | 2017-11-01 11:09:48
HD Request # 13 | Downloading Intraday chart data for F.US.DLZ17 to the file F.US.DLZ17.scid. Service: cqg | 2017-11-01 11:09:48
HD Request # 13 | Download start date-time: 2017-11-01 11:05:28.000 | 2017-11-01 11:09:48
HD Request # 13 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:09:48
Socket (21) | Creating socket. | 2017-11-01 11:09:48
Socket (21) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:48
Socket (20) | Socket gracefully closed by remote side. | 2017-11-01 11:09:48
Socket (20) | Closed. | 2017-11-01 11:09:48
HD Request # 13 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:48
HD Request # 13 | Sending historical data logon request message. | 2017-11-01 11:09:48
HD Request # 13 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:28. Record interval: 0. Symbol: F.US.DLZ17 | 2017-11-01 11:09:49
HD Request # 13 | Decompressing data. | 2017-11-01 11:09:49
HD Request # 13 | Receiving Intraday data for F.US.DLZ17 starting at 2017-11-01 11:05:42 | 2017-11-01 11:09:49
HD Request # 13 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:42 | 2017-11-01 11:09:49
Socket (21) | Initiating close of socket by core. | 2017-11-01 11:09:49
Socket (21) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:49
Historical data download thread signaled to stop. | 2017-11-01 11:09:49
HD Request # 13 | Received 106 records from 2017-11-01 11:05:42 to 2017-11-01 11:09:55 (4.2 minutes) and wrote 106 records for F.US.DLZ17 | 2017-11-01 11:09:49
HD Request # 13 | Intraday download COMPLETE for F.US.DLZ17. Completion time: 0s. Unique request ID: 11 | 2017-11-01 11:09:49
Removed historical data download ID 11 | 2017-11-01 11:09:49
Real-time Intraday chart data file updates started for F.US.DLZ17 | 2017-11-01 11:09:49
Intraday chart data file opened for F.US.DLZ17 | 2017-11-01 11:09:49
HD Request # 14 | Downloading Intraday chart data for F.US.FGBXZ17 to the file F.US.FGBXZ17.scid. Service: cqg | 2017-11-01 11:09:49
HD Request # 14 | Download start date-time: 2017-11-01 11:05:25.000 | 2017-11-01 11:09:49
HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:09:49
Socket (22) | Creating socket. | 2017-11-01 11:09:49
Socket (22) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:49
Socket (21) | Socket gracefully closed by remote side. | 2017-11-01 11:09:49
Socket (21) | Closed. | 2017-11-01 11:09:49
HD Request # 14 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:49
HD Request # 14 | Sending historical data logon request message. | 2017-11-01 11:09:49
HD Request # 14 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:25. Record interval: 0. Symbol: F.US.FGBXZ17 | 2017-11-01 11:09:49
HD Request # 14 | Decompressing data. | 2017-11-01 11:09:49
HD Request # 14 | Receiving Intraday data for F.US.FGBXZ17 starting at 2017-11-01 11:05:25 | 2017-11-01 11:09:49
HD Request # 14 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:36 | 2017-11-01 11:09:49
Socket (22) | Initiating close of socket by core. | 2017-11-01 11:09:49
Socket (22) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:49
HD Request # 14 | Received 65 records from 2017-11-01 11:05:25 to 2017-11-01 11:09:46 (4.4 minutes) and wrote 60 records for F.US.FGBXZ17 | 2017-11-01 11:09:49
HD Request # 14 | Intraday download COMPLETE for F.US.FGBXZ17. Completion time: 1s. Unique request ID: 12 | 2017-11-01 11:09:49
Removed historical data download ID 12 | 2017-11-01 11:09:49
Real-time Intraday chart data file updates started for F.US.FGBXZ17 | 2017-11-01 11:09:49
Intraday chart data file opened for F.US.FGBXZ17 | 2017-11-01 11:09:49
HD Request # 15 | Downloading Intraday chart data for F.US.FBTPZ17 to the file F.US.FBTPZ17.scid. Service: eurex | 2017-11-01 11:09:49
HD Request # 15 | Download start date-time: 2017-11-01 11:05:33.000 | 2017-11-01 11:09:49
HD Request # 15 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 11:09:49
Socket (23) | Creating socket. | 2017-11-01 11:09:49
Socket (23) | Connecting to IP: 8.18.161.133. | 2017-11-01 11:09:49
Socket (22) | Socket gracefully closed by remote side. | 2017-11-01 11:09:49
Socket (22) | Closed. | 2017-11-01 11:09:49
HD Request # 15 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:49
HD Request # 15 | Sending historical data logon request message. | 2017-11-01 11:09:49
HD Request # 15 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:33. Record interval: 0. Symbol: IIZ17 | 2017-11-01 11:09:49
HD Request # 15 | Decompressing data. | 2017-11-01 11:09:50
Socket (23) | Initiating close of socket by core. | 2017-11-01 11:09:50
Socket (23) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:50
Historical data download thread signaled to stop. | 2017-11-01 11:09:50
HD Request # 15 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FBTPZ17 | 2017-11-01 11:09:50
HD Request # 15 | Receiving Intraday data for F.US.FBTPZ17 starting at 2017-11-01 11:09:46 | 2017-11-01 11:09:50
HD Request # 15 | Timestamp of first Intraday data file record written: 2017-11-01 11:09:46 | 2017-11-01 11:09:50
Added 6 Time and Sales records to Intraday data file for F.US.FBTPZ17 after download. | 2017-11-01 11:09:50
HD Request # 15 | Intraday download COMPLETE for F.US.FBTPZ17. Completion time: 0s. Unique request ID: 13 | 2017-11-01 11:09:50
Removed historical data download ID 13 | 2017-11-01 11:09:50
Real-time Intraday chart data file updates started for F.US.FBTPZ17 | 2017-11-01 11:09:50
Intraday chart data file opened for F.US.FBTPZ17 | 2017-11-01 11:09:50
HD Request # 16 | Downloading Intraday chart data for F.US.JY6Z17 to the file F.US.JY6Z17.scid. Service: cqg | 2017-11-01 11:09:50
HD Request # 16 | Download start date-time: 2017-11-01 11:05:03.000 | 2017-11-01 11:09:50
HD Request # 16 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:09:50
Socket (24) | Creating socket. | 2017-11-01 11:09:50
Socket (24) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:50
Socket (23) | Socket gracefully closed by remote side. | 2017-11-01 11:09:50
Socket (23) | Closed. | 2017-11-01 11:09:50
HD Request # 16 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:50
HD Request # 16 | Sending historical data logon request message. | 2017-11-01 11:09:50
HD Request # 16 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:03. Record interval: 0. Symbol: F.US.JY6Z17 | 2017-11-01 11:09:50
HD Request # 16 | Decompressing data. | 2017-11-01 11:09:50
HD Request # 16 | Receiving Intraday data for F.US.JY6Z17 starting at 2017-11-01 11:05:03 | 2017-11-01 11:09:50
HD Request # 16 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:10 | 2017-11-01 11:09:50
Socket (24) | Initiating close of socket by core. | 2017-11-01 11:09:50
Socket (24) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:50
HD Request # 16 | Received 167 records from 2017-11-01 11:05:03 to 2017-11-01 11:09:39 (4.6 minutes) and wrote 166 records for F.US.JY6Z17 | 2017-11-01 11:09:50
HD Request # 16 | Intraday download COMPLETE for F.US.JY6Z17. Completion time: 0s. Unique request ID: 14 | 2017-11-01 11:09:50
Removed historical data download ID 14 | 2017-11-01 11:09:50
Real-time Intraday chart data file updates started for F.US.JY6Z17 | 2017-11-01 11:09:50
Intraday chart data file opened for F.US.JY6Z17 | 2017-11-01 11:09:50
HD Request # 17 | Downloading Intraday chart data for F.US.FOATZ17 to the file F.US.FOATZ17.scid. Service: eurex | 2017-11-01 11:09:50
HD Request # 17 | Download start date-time: 2017-11-01 11:05:34.000 | 2017-11-01 11:09:50
HD Request # 17 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 11:09:50
Socket (25) | Creating socket. | 2017-11-01 11:09:50
Socket (25) | Connecting to IP: 8.18.161.135. | 2017-11-01 11:09:50
Socket (24) | Socket gracefully closed by remote side. | 2017-11-01 11:09:50
Socket (24) | Closed. | 2017-11-01 11:09:50
HD Request # 17 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:50
HD Request # 17 | Sending historical data logon request message. | 2017-11-01 11:09:50
HD Request # 17 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:34. Record interval: 0. Symbol: FNZ17 | 2017-11-01 11:09:50
HD Request # 17 | Decompressing data. | 2017-11-01 11:09:50
Socket (25) | Initiating close of socket by core. | 2017-11-01 11:09:50
Socket (25) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:50
HD Request # 17 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FOATZ17 | 2017-11-01 11:09:50
HD Request # 17 | Receiving Intraday data for F.US.FOATZ17 starting at 2017-11-01 11:09:52 | 2017-11-01 11:09:50
HD Request # 17 | Timestamp of first Intraday data file record written: 2017-11-01 11:09:52 | 2017-11-01 11:09:50
Added 2 Time and Sales records to Intraday data file for F.US.FOATZ17 after download. | 2017-11-01 11:09:50
HD Request # 17 | Intraday download COMPLETE for F.US.FOATZ17. Completion time: 0s. Unique request ID: 15 | 2017-11-01 11:09:50
Removed historical data download ID 15 | 2017-11-01 11:09:50
Real-time Intraday chart data file updates started for F.US.FOATZ17 | 2017-11-01 11:09:50
Intraday chart data file opened for F.US.FOATZ17 | 2017-11-01 11:09:50
HD Request # 18 | Downloading Intraday chart data for F.US.FDXMZ17 to the file F.US.FDXMZ17.scid. Service: cqg | 2017-11-01 11:09:50
HD Request # 18 | Download start date-time: 2017-11-01 11:05:25.000 | 2017-11-01 11:09:50
HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:09:50
Socket (26) | Creating socket. | 2017-11-01 11:09:50
Socket (26) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:50
Socket (25) | Socket gracefully closed by remote side. | 2017-11-01 11:09:51
Socket (25) | Closed. | 2017-11-01 11:09:51
HD Request # 18 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:51
HD Request # 18 | Sending historical data logon request message. | 2017-11-01 11:09:51
HD Request # 18 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:25. Record interval: 0. Symbol: F.US.FDXMZ17 | 2017-11-01 11:09:51
HD Request # 18 | Decompressing data. | 2017-11-01 11:09:51
HD Request # 18 | Receiving Intraday data for F.US.FDXMZ17 starting at 2017-11-01 11:05:25 | 2017-11-01 11:09:51
HD Request # 18 | Timestamp of first Intraday data file record written: 2017-11-01 11:06:06 | 2017-11-01 11:09:51
Socket (26) | Initiating close of socket by core. | 2017-11-01 11:09:51
Socket (26) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:51
Historical data download thread signaled to stop. | 2017-11-01 11:09:51
HD Request # 18 | Received 42 records from 2017-11-01 11:05:25 to 2017-11-01 11:09:52 (4.5 minutes) and wrote 41 records for F.US.FDXMZ17 | 2017-11-01 11:09:51
HD Request # 18 | Intraday download COMPLETE for F.US.FDXMZ17. Completion time: 1s. Unique request ID: 16 | 2017-11-01 11:09:51
Removed historical data download ID 16 | 2017-11-01 11:09:51
Real-time Intraday chart data file updates started for F.US.FDXMZ17 | 2017-11-01 11:09:51
Intraday chart data file opened for F.US.FDXMZ17 | 2017-11-01 11:09:51
HD Request # 19 | Downloading Intraday chart data for F.US.CLEZ17 to the file F.US.CLEZ17.scid. Service: cqg | 2017-11-01 11:09:51
HD Request # 19 | Download start date-time: 2017-11-01 11:05:34.000 | 2017-11-01 11:09:51
HD Request # 19 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:09:51
Socket (27) | Creating socket. | 2017-11-01 11:09:51
Socket (27) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:51
Socket (26) | Socket gracefully closed by remote side. | 2017-11-01 11:09:51
Socket (26) | Closed. | 2017-11-01 11:09:51
Opened cached Intraday file: C:\SierraChart\Data\F.US.USAZ17.scid | 2017-11-01 11:09:51
HD Request # 19 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:54
HD Request # 19 | Sending historical data logon request message. | 2017-11-01 11:09:54
HD Request # 19 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:34. Record interval: 0. Symbol: F.US.CLEZ17 | 2017-11-01 11:09:54
HD Request # 19 | Decompressing data. | 2017-11-01 11:09:54
HD Request # 19 | Receiving Intraday data for F.US.CLEZ17 starting at 2017-11-01 11:05:34 | 2017-11-01 11:09:54
HD Request # 19 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:34 | 2017-11-01 11:09:54
Socket (27) | Initiating close of socket by core. | 2017-11-01 11:09:54
Historical data download thread signaled to stop. | 2017-11-01 11:09:54
Socket (27) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:54
HD Request # 19 | Received 588 records from 2017-11-01 11:05:34 to 2017-11-01 11:10:00 (4.4 minutes) and wrote 587 records for F.US.CLEZ17 | 2017-11-01 11:09:54
HD Request # 19 | Intraday download COMPLETE for F.US.CLEZ17. Completion time: 3s. Unique request ID: 17 | 2017-11-01 11:09:54
Removed historical data download ID 17 | 2017-11-01 11:09:54
Real-time Intraday chart data file updates started for F.US.CLEZ17 | 2017-11-01 11:09:54
Intraday chart data file opened for F.US.CLEZ17 | 2017-11-01 11:09:54
HD Request # 20 | Downloading Intraday chart data for F.US.TYAZ17 to the file F.US.TYAZ17.scid. Service: cqg | 2017-11-01 11:09:54
HD Request # 20 | Download start date-time: 2017-11-01 11:05:16.000 | 2017-11-01 11:09:54
HD Request # 20 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:09:54
Socket (28) | Creating socket. | 2017-11-01 11:09:54
Socket (28) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:54
Socket (27) | Socket gracefully closed by remote side. | 2017-11-01 11:09:54
Socket (27) | Closed. | 2017-11-01 11:09:54
HD Request # 20 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:54
HD Request # 20 | Sending historical data logon request message. | 2017-11-01 11:09:54
HD Request # 20 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:16. Record interval: 0. Symbol: F.US.TYAZ17 | 2017-11-01 11:09:54
HD Request # 20 | Decompressing data. | 2017-11-01 11:09:54
HD Request # 20 | Receiving Intraday data for F.US.TYAZ17 starting at 2017-11-01 11:05:16 | 2017-11-01 11:09:54
HD Request # 20 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:37 | 2017-11-01 11:09:54
Socket (28) | Initiating close of socket by core. | 2017-11-01 11:09:54
Socket (28) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:54
HD Request # 20 | Received 58 records from 2017-11-01 11:05:16 to 2017-11-01 11:09:55 (4.7 minutes) and wrote 57 records for F.US.TYAZ17 | 2017-11-01 11:09:54
HD Request # 20 | Intraday download COMPLETE for F.US.TYAZ17. Completion time: 0s. Unique request ID: 18 | 2017-11-01 11:09:54
Removed historical data download ID 18 | 2017-11-01 11:09:54
Real-time Intraday chart data file updates started for F.US.TYAZ17 | 2017-11-01 11:09:54
Intraday chart data file opened for F.US.TYAZ17 | 2017-11-01 11:09:54
HD Request # 21 | Downloading Intraday chart data for F.US.EU6Z17 to the file F.US.EU6Z17.scid. Service: cqg | 2017-11-01 11:09:54
HD Request # 21 | Download start date-time: 2017-11-01 11:05:14.000 | 2017-11-01 11:09:54
HD Request # 21 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:09:54
Socket (29) | Creating socket. | 2017-11-01 11:09:54
Socket (29) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:54
Socket (28) | Socket gracefully closed by remote side. | 2017-11-01 11:09:55
Socket (28) | Closed. | 2017-11-01 11:09:55
HD Request # 21 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:55
HD Request # 21 | Sending historical data logon request message. | 2017-11-01 11:09:55
HD Request # 21 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:14. Record interval: 0. Symbol: F.US.EU6Z17 | 2017-11-01 11:09:55
HD Request # 21 | Decompressing data. | 2017-11-01 11:09:55
HD Request # 21 | Receiving Intraday data for F.US.EU6Z17 starting at 2017-11-01 11:05:14 | 2017-11-01 11:09:55
HD Request # 21 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:41 | 2017-11-01 11:09:55
Socket (29) | Initiating close of socket by core. | 2017-11-01 11:09:55
Socket (29) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:55
Historical data download thread signaled to stop. | 2017-11-01 11:09:55
HD Request # 21 | Received 221 records from 2017-11-01 11:05:14 to 2017-11-01 11:10:02 (4.8 minutes) and wrote 220 records for F.US.EU6Z17 | 2017-11-01 11:09:55
HD Request # 21 | Intraday download COMPLETE for F.US.EU6Z17. Completion time: 0s. Unique request ID: 19 | 2017-11-01 11:09:55
Removed historical data download ID 19 | 2017-11-01 11:09:55
Real-time Intraday chart data file updates started for F.US.EU6Z17 | 2017-11-01 11:09:55
Intraday chart data file opened for F.US.EU6Z17 | 2017-11-01 11:09:55
HD Request # 22 | Downloading Intraday chart data for F.US.DSXZ17 to the file F.US.DSXZ17.scid. Service: cqg | 2017-11-01 11:09:55
HD Request # 22 | Download start date-time: 2017-11-01 11:05:32.000 | 2017-11-01 11:09:55
HD Request # 22 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:09:55
Socket (30) | Creating socket. | 2017-11-01 11:09:55
Socket (30) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:55
Socket (29) | Socket gracefully closed by remote side. | 2017-11-01 11:09:55
Socket (29) | Closed. | 2017-11-01 11:09:55
HD Request # 22 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:55
HD Request # 22 | Sending historical data logon request message. | 2017-11-01 11:09:55
HD Request # 22 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:32. Record interval: 0. Symbol: F.US.DSXZ17 | 2017-11-01 11:09:55
HD Request # 22 | Decompressing data. | 2017-11-01 11:09:56
HD Request # 22 | Receiving Intraday data for F.US.DSXZ17 starting at 2017-11-01 11:05:32 | 2017-11-01 11:09:56
HD Request # 22 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:38 | 2017-11-01 11:09:56
Socket (30) | Initiating close of socket by core. | 2017-11-01 11:09:56
Socket (30) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:56
Historical data download thread signaled to stop. | 2017-11-01 11:09:56
HD Request # 22 | Received 82 records from 2017-11-01 11:05:32 to 2017-11-01 11:09:57 (4.4 minutes) and wrote 81 records for F.US.DSXZ17 | 2017-11-01 11:09:56
HD Request # 22 | Intraday download COMPLETE for F.US.DSXZ17. Completion time: 1s. Unique request ID: 25 | 2017-11-01 11:09:56
Removed historical data download ID 25 | 2017-11-01 11:09:56
Real-time Intraday chart data file updates started for F.US.DSXZ17 | 2017-11-01 11:09:56
Intraday chart data file opened for F.US.DSXZ17 | 2017-11-01 11:09:56
HD Request # 23 | Downloading Intraday chart data for F.US.EPZ17 to the file F.US.EPZ17.scid. Service: cqg | 2017-11-01 11:09:56
HD Request # 23 | Download start date-time: 2017-11-01 11:05:12.000 | 2017-11-01 11:09:56
HD Request # 23 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:09:56
Socket (31) | Creating socket. | 2017-11-01 11:09:56
Socket (31) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:56
Socket (30) | Socket gracefully closed by remote side. | 2017-11-01 11:09:56
Socket (30) | Closed. | 2017-11-01 11:09:56
HD Request # 23 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:56
HD Request # 23 | Sending historical data logon request message. | 2017-11-01 11:09:56
HD Request # 23 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:12. Record interval: 0. Symbol: F.US.EPZ17 | 2017-11-01 11:09:56
HD Request # 23 | Decompressing data. | 2017-11-01 11:09:56
HD Request # 23 | Receiving Intraday data for F.US.EPZ17 starting at 2017-11-01 11:05:12 | 2017-11-01 11:09:56
HD Request # 23 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:35 | 2017-11-01 11:09:56
Socket (31) | Initiating close of socket by core. | 2017-11-01 11:09:56
Socket (31) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:56
HD Request # 23 | Received 459 records from 2017-11-01 11:05:12 to 2017-11-01 11:10:02 (4.8 minutes) and wrote 458 records for F.US.EPZ17 | 2017-11-01 11:09:56
HD Request # 23 | Intraday download COMPLETE for F.US.EPZ17. Completion time: 0s. Unique request ID: 26 | 2017-11-01 11:09:56
Removed historical data download ID 26 | 2017-11-01 11:09:56
Real-time Intraday chart data file updates started for F.US.EPZ17 | 2017-11-01 11:09:56
Intraday chart data file opened for F.US.EPZ17 | 2017-11-01 11:09:56
HD Request # 24 | Downloading Intraday chart data for F.US.DBZ17 to the file F.US.DBZ17.scid. Service: cqg | 2017-11-01 11:09:56
HD Request # 24 | Download start date-time: 2017-11-01 11:05:34.000 | 2017-11-01 11:09:56
HD Request # 24 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:09:56
Socket (32) | Creating socket. | 2017-11-01 11:09:56
Socket (32) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:09:56
Socket (31) | Socket gracefully closed by remote side. | 2017-11-01 11:09:56
Socket (31) | Closed. | 2017-11-01 11:09:56
HD Request # 24 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:56
HD Request # 24 | Sending historical data logon request message. | 2017-11-01 11:09:56
HD Request # 24 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:34. Record interval: 0. Symbol: F.US.DBZ17 | 2017-11-01 11:09:56
HD Request # 24 | Decompressing data. | 2017-11-01 11:09:56
HD Request # 24 | Receiving Intraday data for F.US.DBZ17 starting at 2017-11-01 11:05:35 | 2017-11-01 11:09:56
HD Request # 24 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:35 | 2017-11-01 11:09:56
Socket (32) | Initiating close of socket by core. | 2017-11-01 11:09:56
Socket (32) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:56
HD Request # 24 | Received 221 records from 2017-11-01 11:05:35 to 2017-11-01 11:09:56 (4.4 minutes) and wrote 221 records for F.US.DBZ17 | 2017-11-01 11:09:56
Added 1 Time and Sales records to Intraday data file for F.US.DBZ17 after download. | 2017-11-01 11:09:56
HD Request # 24 | Intraday download COMPLETE for F.US.DBZ17. Completion time: 0s. Unique request ID: 31 | 2017-11-01 11:09:56
Removed historical data download ID 31 | 2017-11-01 11:09:56
Real-time Intraday chart data file updates started for F.US.DBZ17 | 2017-11-01 11:09:56
Intraday chart data file opened for F.US.DBZ17 | 2017-11-01 11:09:56
HD Request # 25 | Downloading Intraday chart data for F.US.BP6Z17 to the file F.US.BP6Z17.scid. Service: cqg | 2017-11-01 11:09:56
HD Request # 25 | Download start date-time: 2017-11-01 11:05:31.000 | 2017-11-01 11:09:56
HD Request # 25 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:09:56
Socket (33) | Creating socket. | 2017-11-01 11:09:56
Socket (33) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:09:56
Socket (32) | Socket gracefully closed by remote side. | 2017-11-01 11:09:56
Socket (32) | Closed. | 2017-11-01 11:09:56
HD Request # 25 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:57
HD Request # 25 | Sending historical data logon request message. | 2017-11-01 11:09:57
HD Request # 25 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:31. Record interval: 0. Symbol: F.US.BP6Z17 | 2017-11-01 11:09:57
HD Request # 25 | Decompressing data. | 2017-11-01 11:09:57
HD Request # 25 | Receiving Intraday data for F.US.BP6Z17 starting at 2017-11-01 11:05:31 | 2017-11-01 11:09:57
HD Request # 25 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:35 | 2017-11-01 11:09:57
Socket (33) | Initiating close of socket by core. | 2017-11-01 11:09:57
Socket (33) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:57
Historical data download thread signaled to stop. | 2017-11-01 11:09:57
HD Request # 25 | Received 303 records from 2017-11-01 11:05:31 to 2017-11-01 11:10:03 (4.5 minutes) and wrote 302 records for F.US.BP6Z17 | 2017-11-01 11:09:57
HD Request # 25 | Intraday download COMPLETE for F.US.BP6Z17. Completion time: 1s. Unique request ID: 32 | 2017-11-01 11:09:57
Removed historical data download ID 32 | 2017-11-01 11:09:57
Real-time Intraday chart data file updates started for F.US.BP6Z17 | 2017-11-01 11:09:57
Intraday chart data file opened for F.US.BP6Z17 | 2017-11-01 11:09:57
HD Request # 26 | Downloading Intraday chart data for F.US.DSXZ16 to the file F.US.DSXZ16.scid. Service: eurex | 2017-11-01 11:09:57
HD Request # 26 | Download start date-time: 2016-12-16 10:59:59.000 | 2017-11-01 11:09:57
HD Request # 26 | Using server: ds7.sierracharts.com port 10149 | 2017-11-01 11:09:57
Socket (34) | Creating socket. | 2017-11-01 11:09:57
Socket (34) | Connecting to IP: 8.18.161.133. | 2017-11-01 11:09:57
Socket (33) | Socket gracefully closed by remote side. | 2017-11-01 11:09:57
Socket (33) | Closed. | 2017-11-01 11:09:57
HD Request # 26 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:57
HD Request # 26 | Sending historical data logon request message. | 2017-11-01 11:09:57
HD Request # 26 | Requesting Intraday data. Start date-time: 2016-12-16 10:59:59. Record interval: 0. Symbol: FXZ16 | 2017-11-01 11:09:57
HD Request # 26 | Decompressing data. | 2017-11-01 11:09:57
HD Request # 26 | Receiving Intraday data for F.US.DSXZ16 starting at 2016-12-16 10:59:59 | 2017-11-01 11:09:57
Socket (34) | Initiating close of socket by core. | 2017-11-01 11:09:57
Socket (34) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:57
HD Request # 26 | Received 1 record from 2016-12-16 10:59:59 to 2016-12-16 10:59:59 (0.0 seconds) and wrote 0 records for F.US.DSXZ16 | 2017-11-01 11:09:57
HD Request # 26 | Intraday download COMPLETE for F.US.DSXZ16. Completion time: 0s. Unique request ID: 33 | 2017-11-01 11:09:57
Removed historical data download ID 33 | 2017-11-01 11:09:57
Real-time Intraday chart data file updates started for F.US.DSXZ16 | 2017-11-01 11:09:57
Intraday chart data file opened for F.US.DSXZ16 | 2017-11-01 11:09:57
HD Request # 27 | Downloading Intraday chart data for F.US.DDZ16 to the file F.US.DDZ16.scid. Service: eurex | 2017-11-01 11:09:57
HD Request # 27 | Download start date-time: 2016-12-16 11:59:55.000 | 2017-11-01 11:09:57
HD Request # 27 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 11:09:57
Socket (35) | Creating socket. | 2017-11-01 11:09:57
Socket (35) | Connecting to IP: 8.18.161.135. | 2017-11-01 11:09:57
Socket (34) | Socket gracefully closed by remote side. | 2017-11-01 11:09:58
Socket (34) | Closed. | 2017-11-01 11:09:58
HD Request # 27 | Setting DTC encoding to Binary VLS | 2017-11-01 11:09:58
HD Request # 27 | Sending historical data logon request message. | 2017-11-01 11:09:58
HD Request # 27 | Requesting Intraday data. Start date-time: 2016-12-16 11:59:55. Record interval: 0. Symbol: DYZ16 | 2017-11-01 11:09:58
HD Request # 27 | Decompressing data. | 2017-11-01 11:09:58
HD Request # 27 | Receiving Intraday data for F.US.DDZ16 starting at 2016-12-16 11:59:55 | 2017-11-01 11:09:58
Socket (35) | Initiating close of socket by core. | 2017-11-01 11:09:58
Socket (35) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:09:58
Historical data download thread signaled to stop. | 2017-11-01 11:09:58
HD Request # 27 | Received 1 record from 2016-12-16 11:59:55 to 2016-12-16 11:59:55 (0.0 seconds) and wrote 0 records for F.US.DDZ16 | 2017-11-01 11:09:58
HD Request # 27 | Intraday download COMPLETE for F.US.DDZ16. Completion time: 0s. Unique request ID: 34 | 2017-11-01 11:09:58
Removed historical data download ID 34 | 2017-11-01 11:09:58
Real-time Intraday chart data file updates started for F.US.DDZ16 | 2017-11-01 11:09:58
Intraday chart data file opened for F.US.DDZ16 | 2017-11-01 11:09:58
Socket (35) | Socket gracefully closed by remote side. | 2017-11-01 11:09:58
Socket (35) | Closed. | 2017-11-01 11:09:58
Opened cached Intraday file: C:\SierraChart\Data\F.US.TYAZ17.scid | 2017-11-01 11:10:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.DSXZ17.scid | 2017-11-01 11:10:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.EPZ17.scid | 2017-11-01 11:10:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.FOATZ17.scid | 2017-11-01 11:10:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.JY6Z17.scid | 2017-11-01 11:10:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.FDXMZ17.scid | 2017-11-01 11:10:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEZ17.scid | 2017-11-01 11:10:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.DBZ17.scid | 2017-11-01 11:10:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.BP6Z17.scid | 2017-11-01 11:10:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.EU6Z17.scid | 2017-11-01 11:10:12
Opened cached Intraday file: C:\SierraChart\Data\F.US.DLZ17.scid | 2017-11-01 11:10:12
Opened cached Intraday file: C:\SierraChart\Data\F.US.DGZ17.scid | 2017-11-01 11:10:12
Opened cached Intraday file: C:\SierraChart\Data\F.US.FGBXZ17.scid | 2017-11-01 11:10:12
Opened cached Intraday file: C:\SierraChart\Data\F.US.FBTPZ17.scid | 2017-11-01 11:10:12
F.US.DSXZ17 [CBV] #1 | Reloading chart. | 2017-11-01 11:10:26
F.US.DSXZ17 2500 Volume #2 | Reloading chart. | 2017-11-01 11:10:26
F.US.DSXZ17 [CBV] 5 Min #3 | Reloading chart. | 2017-11-01 11:10:26
F.US.DSXZ17 Renko 2t #4 | Reloading chart. | 2017-11-01 11:10:26
F.US.DBZ17 [CBV] #5 | Reloading chart. | 2017-11-01 11:10:26
F.US.DSXZ17 [CBV] 60 Min #6 | Reloading chart. | 2017-11-01 11:10:26
F.US.DSXZ17 15 Min #7 | Reloading chart. | 2017-11-01 11:10:26
F.US.DSXZ17 10 Min #8 | Reloading chart. | 2017-11-01 11:10:26
+ Loading market depth data. | 2017-11-01 11:10:26
F.US.DSXZ17 #9 | Reloading chart. | 2017-11-01 11:10:26
F.US.DBZ17 #10 | Reloading chart. | 2017-11-01 11:10:26
Loaded depth data records for F.US.DSXZ17 2017-10-30 from 2017-10-30 07:35:47 to 2017-10-30 18:53:02. | 2017-11-01 11:10:26
Loaded depth data records for F.US.DSXZ17 2017-10-31 from 2017-10-31 08:00:22 to 2017-10-31 20:17:41. | 2017-11-01 11:10:26
Loaded depth data records for F.US.DSXZ17 2017-11-01 from 2017-11-01 07:47:46 to 2017-11-01 11:05:32. | 2017-11-01 11:10:26
F.US.EPZ17 #11 | Reloading chart. | 2017-11-01 11:10:26
F.US.DDZ17 #12 | Reloading chart. | 2017-11-01 11:10:26
F.US.DDZ17 5 Min #13 | Reloading chart. | 2017-11-01 11:10:26
F.US.FDXMZ17 #14 | Reloading chart. | 2017-11-01 11:10:26
F.US.JY6Z17 [CV] 5 Min #15 | Reloading chart. | 2017-11-01 11:10:26
F.US.DSXZ17 [CBV] 1 Day #16 | Reloading chart. | 2017-11-01 11:10:26
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ17. ID: 25 | 2017-11-01 11:10:26
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ17. ID: 593646 | 2017-11-01 11:10:26
CQG FIX Trading | Requesting security definition data for: F.US.DDZ17. ID: 25 | 2017-11-01 11:10:26
CQG FIX Trading | Starting real-time market data updates for: F.US.FVSX17. ID: 26 | 2017-11-01 11:10:26
CQG FIX Trading | Sending symbol resolution request for F.US.FVSX17. ID: 593647 | 2017-11-01 11:10:26
CQG FIX Trading | Requesting security definition data for: F.US.FVSX17. ID: 26 | 2017-11-01 11:10:26
CQG FIX Trading | Starting real-time market data updates for: F.US.SWZ17. ID: 27 | 2017-11-01 11:10:26
CQG FIX Trading | Sending symbol resolution request for F.US.SWZ17. ID: 593648 | 2017-11-01 11:10:26
CQG FIX Trading | Requesting security definition data for: F.US.SWZ17. ID: 27 | 2017-11-01 11:10:26
CQG FIX Trading | Starting real-time market data updates for: F.US.ENQZ17. ID: 28 | 2017-11-01 11:10:26
CQG FIX Trading | Sending symbol resolution request for F.US.ENQZ17. ID: 593649 | 2017-11-01 11:10:26
CQG FIX Trading | Requesting security definition data for: F.US.ENQZ17. ID: 28 | 2017-11-01 11:10:26
CQG FIX Trading | Starting real-time market data updates for: F.US.NKDZ17. ID: 29 | 2017-11-01 11:10:26
CQG FIX Trading | Sending symbol resolution request for F.US.NKDZ17. ID: 593650 | 2017-11-01 11:10:26
CQG FIX Trading | Requesting security definition data for: F.US.NKDZ17. ID: 29 | 2017-11-01 11:10:26
CQG FIX Trading | Starting real-time market data updates for: F.US.YMZ17. ID: 30 | 2017-11-01 11:10:26
CQG FIX Trading | Sending symbol resolution request for F.US.YMZ17. ID: 593651 | 2017-11-01 11:10:26
CQG FIX Trading | Requesting security definition data for: F.US.YMZ17. ID: 30 | 2017-11-01 11:10:26
CQG FIX Trading | Received symbol resolution report for symbol F.US.DDZ7. Search Symbol: F.US.DDZ17. Request ID: 593646. Contract ID: 19. | 2017-11-01 11:10:26
CQG FIX Trading | Requesting market data for F.US.DDZ17 | 2017-11-01 11:10:26
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVSX7. Search Symbol: F.US.FVSX17. Request ID: 593647. Contract ID: 20. | 2017-11-01 11:10:26
CQG FIX Trading | Requesting market data for F.US.FVSX17 | 2017-11-01 11:10:26
CQG FIX Trading | Received symbol resolution report for symbol F.US.SWZ7. Search Symbol: F.US.SWZ17. Request ID: 593648. Contract ID: 21. | 2017-11-01 11:10:26
CQG FIX Trading | Requesting market data for F.US.SWZ17 | 2017-11-01 11:10:26
CQG FIX Trading | Received symbol resolution report for symbol F.US.ENQZ7. Search Symbol: F.US.ENQZ17. Request ID: 593649. Contract ID: 22. | 2017-11-01 11:10:26
CQG FIX Trading | Requesting market data for F.US.ENQZ17 | 2017-11-01 11:10:26
CQG FIX Trading | Received symbol resolution report for symbol F.US.NKDZ7. Search Symbol: F.US.NKDZ17. Request ID: 593650. Contract ID: 23. | 2017-11-01 11:10:26
CQG FIX Trading | Requesting market data for F.US.NKDZ17 | 2017-11-01 11:10:26
CQG FIX Trading | Received symbol resolution report for symbol F.US.YMZ7. Search Symbol: F.US.YMZ17. Request ID: 593651. Contract ID: 24. | 2017-11-01 11:10:26
CQG FIX Trading | Requesting market data for F.US.YMZ17 | 2017-11-01 11:10:26
Requesting market depth updates for: F.US.DDZ17 if supported. | 2017-11-01 11:10:39
CQG FIX Trading | Requesting market data including full depth for F.US.DDZ17 | 2017-11-01 11:10:39
Intraday data recording state for symbol F.US.DDZ17 is set to download 'Pending'. | 2017-11-01 11:10:39
HD Request # 28 | Downloading Intraday chart data for F.US.DDZ17 to the file F.US.DDZ17.scid. Service: cqg | 2017-11-01 11:10:39
HD Request # 28 | Download start date-time: 2017-11-01 11:05:32.000 | 2017-11-01 11:10:39
HD Request # 28 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:10:39
Socket (36) | Creating socket. | 2017-11-01 11:10:39
Socket (36) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:10:39
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DSXZ17.2017-11-01.depth | 2017-11-01 11:10:39
HD Request # 28 | Setting DTC encoding to Binary VLS | 2017-11-01 11:10:39
HD Request # 28 | Sending historical data logon request message. | 2017-11-01 11:10:39
HD Request # 28 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:32. Record interval: 0. Symbol: F.US.DDZ17 | 2017-11-01 11:10:39
HD Request # 28 | Decompressing data. | 2017-11-01 11:10:39
HD Request # 28 | Receiving Intraday data for F.US.DDZ17 starting at 2017-11-01 11:05:32 | 2017-11-01 11:10:39
HD Request # 28 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:35 | 2017-11-01 11:10:39
Socket (36) | Initiating close of socket by core. | 2017-11-01 11:10:39
Historical data download thread signaled to stop. | 2017-11-01 11:10:39
Socket (36) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:10:39
HD Request # 28 | Received 238 records from 2017-11-01 11:05:32 to 2017-11-01 11:10:33 (5.0 minutes) and wrote 237 records for F.US.DDZ17 | 2017-11-01 11:10:39
HD Request # 28 | Intraday download COMPLETE for F.US.DDZ17. Completion time: 1s. Unique request ID: 35 | 2017-11-01 11:10:39
Removed historical data download ID 35 | 2017-11-01 11:10:39
Real-time Intraday chart data file updates started for F.US.DDZ17 | 2017-11-01 11:10:39
Intraday chart data file opened for F.US.DDZ17 | 2017-11-01 11:10:39
Socket (36) | Socket gracefully closed by remote side. | 2017-11-01 11:10:39
Socket (36) | Closed. | 2017-11-01 11:10:39
Opened cached Intraday file: C:\SierraChart\Data\F.US.DDZ17.scid | 2017-11-01 11:10:42
F.US.DDZ17 [CBV] 60 Min #1 | Reloading chart. | 2017-11-01 11:12:32
F.US.DDZ17 1 Min #2 | Reloading chart. | 2017-11-01 11:12:32
F.US.DDZ17 [CBV] #3 | Reloading chart. | 2017-11-01 11:12:32
F.US.DDZ17 Renko 8t #4 | Reloading chart. | 2017-11-01 11:12:32
F.US.FDXMZ17 #5 | Reloading chart. | 2017-11-01 11:12:32
F.US.EPZ17 #7 | Reloading chart. | 2017-11-01 11:12:32
F.US.DSXZ17 #8 | Reloading chart. | 2017-11-01 11:12:32
F.US.DDZ17 [CBV] 1 Day #9 | Reloading chart. | 2017-11-01 11:12:32
+ Loading market depth data. | 2017-11-01 11:12:32
Loaded depth data records for F.US.DDZ17 2017-11-01 from 00:00:00 to 00:00:00. | 2017-11-01 11:12:32
F.US.DDZ17 [CBV] 15 Min #10 | Reloading chart. | 2017-11-01 11:12:32
F.US.DDZ17 #11 | Reloading chart. | 2017-11-01 11:12:32
F.US.EU6Z17 #12 | Reloading chart. | 2017-11-01 11:12:32
F.US.DBZ17 #13 | Reloading chart. | 2017-11-01 11:12:32
F.US.JY6Z17 [CV] 5 Min #14 | Reloading chart. | 2017-11-01 11:12:32
F.US.DDZ17 [CBV] Weekly #15 | Reloading chart. | 2017-11-01 11:12:32
F.US.DDZ17 [CBV] 5 Min #6 | Reloading chart. | 2017-11-01 11:12:32
F.US.DDZ17 1 Min #2 | Reloading chart. | 2017-11-01 11:12:40
HD Request # 29 | Downloading Historical Daily chart data for F.US.DDZ17. Starting date: 2017-10-30. Service: cqg | 2017-11-01 11:12:40
HD Request # 29 | Requesting historical Daily data for DYZ17 starting at 2017-10-29 | 2017-11-01 11:12:40
HTTP connection to ds01.ddfplus.com:80 (38) | Creating socket. | 2017-11-01 11:12:42
HTTP connection to ds01.ddfplus.com:80 (38) | Connecting to IP: 8.18.161.123. | 2017-11-01 11:12:42
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DDZ17.2017-11-01.depth | 2017-11-01 11:12:42
HD Request # 29 | Receiving historical Daily data for F.US.DDZ17 starting at 2017-10-30 | 2017-11-01 11:12:43
HD Request # 29 | Writing historical Daily data to the file F.US.DDZ17.dly | 2017-11-01 11:12:43
HD Request # 29 | Received 2 records from 2017-10-30 00:00:00 to 2017-11-01 00:00:00 (3.0 days) and wrote 2 records for F.US.DDZ17 | 2017-11-01 11:12:43
HD Request # 29 | Daily download COMPLETE for F.US.DDZ17. Completion time: 0s. Unique request ID: 36 | 2017-11-01 11:12:43
Removed historical data download ID 36 | 2017-11-01 11:12:43
F.US.DDZ17 [CBV] Weekly #15 | Reloading chart. | 2017-11-01 11:12:43
+ Loading market depth data. | 2017-11-01 11:12:44
Loaded depth data records for F.US.DDZ17 2017-11-01 from 00:00:00 to 00:00:00. | 2017-11-01 11:12:44
HTTP connection to ds01.ddfplus.com:80 (38) | Socket gracefully closed by remote side. | 2017-11-01 11:13:47
HTTP connection to ds01.ddfplus.com:80 (38) | Received socket Close event. | 2017-11-01 11:13:47
HTTP connection to ds01.ddfplus.com:80 (38) | Initiating close of socket by core. | 2017-11-01 11:13:47
HTTP connection to ds01.ddfplus.com:80 (38) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 11:13:47
HTTP connection to ds01.ddfplus.com:80 (38) | Closed. | 2017-11-01 11:13:47
F.US.BP6Z17 [CV] Daily #1 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 [CBV] Daily #2 | Reloading chart. | 2017-11-01 11:14:45
F.US.BP6Z17 [CV] 5 Min #3 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 [CBV] 5 Min #4 | Reloading chart. | 2017-11-01 11:14:45
F.US.BP6Z17 [CBV] #5 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 #6 | Reloading chart. | 2017-11-01 11:14:45
F.US.BP6Z17 #7 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 #8 | Reloading chart. | 2017-11-01 11:14:45
F.US.JY6Z17 [CV] Daily #9 | Reloading chart. | 2017-11-01 11:14:45
F.US.JY6Z17 #10 | Reloading chart. | 2017-11-01 11:14:45
F.US.MX6M17 #11 | Reloading chart. | 2017-11-01 11:14:45
F.US.JY6Z17 [CV] 5 Min #12 | Reloading chart. | 2017-11-01 11:14:45
F.US.JY6Z17 #13 | Reloading chart. | 2017-11-01 11:14:45
F.US.BP6Z17 [CV] 60 Min #15 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 60 Min #16 | Reloading chart. | 2017-11-01 11:14:45
F.US.JY6Z17 [CV] 60 Min #17 | Reloading chart. | 2017-11-01 11:14:45
F.US.BP6Z17 10 Min #18 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 10 Min #20 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 10 Min #21 | Reloading chart. | 2017-11-01 11:14:45
F.US.JY6Z17 240 Min #22 | Reloading chart. | 2017-11-01 11:14:45
F.US.DBZ17 #14 | Reloading chart. | 2017-11-01 11:14:45
F.US.JY6Z17 [CV] Weekly #23 | Reloading chart. | 2017-11-01 11:14:45
F.US.BP6Z17 [CV] Weekly #24 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 [CBV] Weekly #25 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 Weekly #26 | Reloading chart. | 2017-11-01 11:14:45
F.US.BP6Z17 [CV] 240 Min #27 | Reloading chart. | 2017-11-01 11:14:45
F.US.M6BZ17 #29 | Reloading chart. | 2017-11-01 11:14:45
F.US.M6EZ17 #19 | Reloading chart. | 2017-11-01 11:14:45
F.US.MJYZ17 #28 | Reloading chart. | 2017-11-01 11:14:45
F.US.EU6Z17 [CBV] 240 Min #30 | Reloading chart. | 2017-11-01 11:14:45
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6Z17. ID: 31 | 2017-11-01 11:14:45
CQG FIX Trading | Sending symbol resolution request for F.US.MX6Z17. ID: 593652 | 2017-11-01 11:14:45
CQG FIX Trading | Requesting security definition data for: F.US.MX6Z17. ID: 31 | 2017-11-01 11:14:45
CQG FIX Trading | Starting real-time market data updates for: F.US.DA6Z17. ID: 32 | 2017-11-01 11:14:45
CQG FIX Trading | Sending symbol resolution request for F.US.DA6Z17. ID: 593653 | 2017-11-01 11:14:45
CQG FIX Trading | Requesting security definition data for: F.US.DA6Z17. ID: 32 | 2017-11-01 11:14:45
CQG FIX Trading | Starting real-time market data updates for: F.US.NE6Z17. ID: 33 | 2017-11-01 11:14:45
CQG FIX Trading | Sending symbol resolution request for F.US.NE6Z17. ID: 593654 | 2017-11-01 11:14:45
CQG FIX Trading | Requesting security definition data for: F.US.NE6Z17. ID: 33 | 2017-11-01 11:14:45
CQG FIX Trading | Starting real-time market data updates for: F.US.EADZ17. ID: 34 | 2017-11-01 11:14:45
CQG FIX Trading | Sending symbol resolution request for F.US.EADZ17. ID: 593655 | 2017-11-01 11:14:45
CQG FIX Trading | Requesting security definition data for: F.US.EADZ17. ID: 34 | 2017-11-01 11:14:45
CQG FIX Trading | Starting real-time market data updates for: F.US.ECDZ17. ID: 35 | 2017-11-01 11:14:45
CQG FIX Trading | Sending symbol resolution request for F.US.ECDZ17. ID: 593656 | 2017-11-01 11:14:45
CQG FIX Trading | Requesting security definition data for: F.US.ECDZ17. ID: 35 | 2017-11-01 11:14:45
CQG FIX Trading | Received symbol resolution report for symbol F.US.MX6Z7. Search Symbol: F.US.MX6Z17. Request ID: 593652. Contract ID: 25. | 2017-11-01 11:14:45
CQG FIX Trading | Requesting market data for F.US.MX6Z17 | 2017-11-01 11:14:45
CQG FIX Trading | Received symbol resolution report for symbol F.US.DA6Z7. Search Symbol: F.US.DA6Z17. Request ID: 593653. Contract ID: 26. | 2017-11-01 11:14:45
CQG FIX Trading | Requesting market data for F.US.DA6Z17 | 2017-11-01 11:14:45
CQG FIX Trading | Received symbol resolution report for symbol F.US.NE6Z7. Search Symbol: F.US.NE6Z17. Request ID: 593654. Contract ID: 27. | 2017-11-01 11:14:45
CQG FIX Trading | Requesting market data for F.US.NE6Z17 | 2017-11-01 11:14:45
CQG FIX Trading | Received symbol resolution report for symbol F.US.EADZ7. Search Symbol: F.US.EADZ17. Request ID: 593655. Contract ID: 28. | 2017-11-01 11:14:45
CQG FIX Trading | Requesting market data for F.US.EADZ17 | 2017-11-01 11:14:45
CQG FIX Trading | Received symbol resolution report for symbol F.US.ECDZ7. Search Symbol: F.US.ECDZ17. Request ID: 593656. Contract ID: 29. | 2017-11-01 11:14:45
CQG FIX Trading | Requesting market data for F.US.ECDZ17 | 2017-11-01 11:14:45
HD Request # 30 | Downloading Historical Daily chart data for F.US.BP6Z17. Starting date: 2017-10-31. Service: cqg | 2017-11-01 11:15:03
HD Request # 30 | Requesting historical Daily data for B6Z17 starting at 2017-10-30 | 2017-11-01 11:15:03
HTTP connection to ds01.ddfplus.com:80 (40) | Creating socket. | 2017-11-01 11:15:03
HTTP connection to ds01.ddfplus.com:80 (40) | Connecting to IP: 8.18.161.123. | 2017-11-01 11:15:03
CQG FIX Trading | Starting real-time market data updates for: F.US.M6BZ17. ID: 36 | 2017-11-01 11:15:03
CQG FIX Trading | Sending symbol resolution request for F.US.M6BZ17. ID: 593657 | 2017-11-01 11:15:03
CQG FIX Trading | Requesting security definition data for: F.US.M6BZ17. ID: 36 | 2017-11-01 11:15:03
Requesting market depth updates for: F.US.M6BZ17 if supported. | 2017-11-01 11:15:03
CQG FIX Trading | Starting real-time market data updates for: F.US.M6EZ17. ID: 37 | 2017-11-01 11:15:03
CQG FIX Trading | Sending symbol resolution request for F.US.M6EZ17. ID: 593658 | 2017-11-01 11:15:03
CQG FIX Trading | Requesting security definition data for: F.US.M6EZ17. ID: 37 | 2017-11-01 11:15:03
Requesting market depth updates for: F.US.M6EZ17 if supported. | 2017-11-01 11:15:03
CQG FIX Trading | Starting real-time market data updates for: F.US.MJYZ17. ID: 38 | 2017-11-01 11:15:03
CQG FIX Trading | Sending symbol resolution request for F.US.MJYZ17. ID: 593659 | 2017-11-01 11:15:03
CQG FIX Trading | Requesting security definition data for: F.US.MJYZ17. ID: 38 | 2017-11-01 11:15:03
Requesting market depth updates for: F.US.MJYZ17 if supported. | 2017-11-01 11:15:03
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6M17. ID: 39 | 2017-11-01 11:15:03
CQG FIX Trading | Sending symbol resolution request for F.US.MX6M17. ID: 593660 | 2017-11-01 11:15:03
CQG FIX Trading | Requesting security definition data for: F.US.MX6M17. ID: 39 | 2017-11-01 11:15:03
Requesting market depth updates for: F.US.MX6M17 if supported. | 2017-11-01 11:15:03
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6BZ7. Search Symbol: F.US.M6BZ17. Request ID: 593657. Contract ID: 30. | 2017-11-01 11:15:03
CQG FIX Trading | Requesting market data including full depth for F.US.M6BZ17 | 2017-11-01 11:15:03
Intraday data recording state for symbol F.US.MX6M17 is set to download 'Pending'. | 2017-11-01 11:15:03
Delaying start of download for F.US.MX6M17 | 2017-11-01 11:15:03
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6EZ7. Search Symbol: F.US.M6EZ17. Request ID: 593658. Contract ID: 31. | 2017-11-01 11:15:03
CQG FIX Trading | Requesting market data including full depth for F.US.M6EZ17 | 2017-11-01 11:15:03
CQG FIX Trading | Received symbol resolution report for symbol F.US.MJYZ7. Search Symbol: F.US.MJYZ17. Request ID: 593659. Contract ID: 32. | 2017-11-01 11:15:03
CQG FIX Trading | Requesting market data including full depth for F.US.MJYZ17 | 2017-11-01 11:15:03
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 11:15:03
Symbol Error - F.US.MX6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:15:03
Intraday data recording state for symbol F.US.M6BZ17 is set to download 'Pending'. | 2017-11-01 11:15:03
HD Request # 31 | Downloading Intraday chart data for F.US.MX6M17 to the file F.US.MX6M17.scid. Service: cme | 2017-11-01 11:15:03
HD Request # 31 | Download start date-time: 2017-06-19 14:48:49.000 | 2017-11-01 11:15:03
HD Request # 31 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 11:15:03
Socket (41) | Creating socket. | 2017-11-01 11:15:03
Socket (41) | Connecting to IP: 8.18.161.133. | 2017-11-01 11:15:03
HD Request # 30 | Receiving historical Daily data for F.US.BP6Z17 starting at 2017-10-31 | 2017-11-01 11:15:03
HD Request # 30 | Writing historical Daily data to the file F.US.BP6Z17.dly | 2017-11-01 11:15:03
HD Request # 30 | Received 3 records from 2017-10-31 00:00:00 to 2017-11-01 00:00:00 (2.0 days) and wrote 2 records for F.US.BP6Z17 | 2017-11-01 11:15:03
HD Request # 30 | Daily download COMPLETE for F.US.BP6Z17. Completion time: 0s. Unique request ID: 37 | 2017-11-01 11:15:03
Removed historical data download ID 37 | 2017-11-01 11:15:03
HD Request # 32 | Downloading Historical Daily chart data for F.US.EU6Z17. Starting date: 2017-10-31. Service: cqg | 2017-11-01 11:15:03
HD Request # 32 | Requesting historical Daily data for E6Z17 starting at 2017-10-30 | 2017-11-01 11:15:03
HD Request # 32 | Receiving historical Daily data for F.US.EU6Z17 starting at 2017-10-31 | 2017-11-01 11:15:03
HD Request # 32 | Writing historical Daily data to the file F.US.EU6Z17.dly | 2017-11-01 11:15:03
HD Request # 32 | Received 3 records from 2017-10-31 00:00:00 to 2017-11-01 00:00:00 (2.0 days) and wrote 2 records for F.US.EU6Z17 | 2017-11-01 11:15:03
HD Request # 32 | Daily download COMPLETE for F.US.EU6Z17. Completion time: 0s. Unique request ID: 38 | 2017-11-01 11:15:03
Removed historical data download ID 38 | 2017-11-01 11:15:03
HD Request # 31 | Setting DTC encoding to Binary VLS | 2017-11-01 11:15:03
HD Request # 31 | Sending historical data logon request message. | 2017-11-01 11:15:03
HD Request # 33 | Downloading Historical Daily chart data for F.US.JY6Z17. Starting date: 2017-10-31. Service: cqg | 2017-11-01 11:15:03
HD Request # 33 | Requesting historical Daily data for J6Z17 starting at 2017-10-30 | 2017-11-01 11:15:03
Intraday data recording state for symbol F.US.M6EZ17 is set to download 'Pending'. | 2017-11-01 11:15:03
CQG FIX Trading | Using primary service for historical data for F.US.MJYZ17 | 2017-11-01 11:15:03
Intraday data recording state for symbol F.US.MJYZ17 is set to download 'Pending'. | 2017-11-01 11:15:03
Delaying start of download for F.US.MJYZ17 | 2017-11-01 11:15:03
F.US.BP6Z17 [CV] Daily #1 | Reloading chart. | 2017-11-01 11:15:03
HD Request # 31 | Requesting Intraday data. Start date-time: 2017-06-19 14:48:49. Record interval: 0. Symbol: 6MM17 | 2017-11-01 11:15:03
HD Request # 31 | Decompressing data. | 2017-11-01 11:15:03
HD Request # 31 | Receiving Intraday data for F.US.MX6M17 starting at 2017-06-19 14:48:49 | 2017-11-01 11:15:03
Socket (41) | Initiating close of socket by core. | 2017-11-01 11:15:03
Socket (41) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:15:03
Socket (41) | Socket gracefully closed by remote side. | 2017-11-01 11:15:03
Socket (41) | Closed. | 2017-11-01 11:15:03
HD Request # 33 | Receiving historical Daily data for F.US.JY6Z17 starting at 2017-10-31 | 2017-11-01 11:15:03
HD Request # 33 | Writing historical Daily data to the file F.US.JY6Z17.dly | 2017-11-01 11:15:03
HD Request # 33 | Received 3 records from 2017-10-31 00:00:00 to 2017-11-01 00:00:00 (2.0 days) and wrote 2 records for F.US.JY6Z17 | 2017-11-01 11:15:03
HD Request # 33 | Daily download COMPLETE for F.US.JY6Z17. Completion time: 1s. Unique request ID: 39 | 2017-11-01 11:15:03
Removed historical data download ID 39 | 2017-11-01 11:15:03
Historical data download thread signaled to stop. | 2017-11-01 11:15:03
HD Request # 31 | Received 4 records from 2017-06-19 14:48:49 to 2017-06-19 14:48:49 (0.0 seconds) and wrote 0 records for F.US.MX6M17 | 2017-11-01 11:15:03
HD Request # 31 | Intraday download COMPLETE for F.US.MX6M17. Completion time: 1s. Unique request ID: 40 | 2017-11-01 11:15:03
Removed historical data download ID 40 | 2017-11-01 11:15:03
Real-time Intraday chart data file updates started for F.US.MX6M17 | 2017-11-01 11:15:03
Intraday chart data file opened for F.US.MX6M17 | 2017-11-01 11:15:03
Delaying start of download for F.US.M6BZ17 | 2017-11-01 11:15:03
F.US.EU6Z17 [CBV] Daily #2 | Reloading chart. | 2017-11-01 11:15:04
F.US.JY6Z17 [CV] Daily #9 | Reloading chart. | 2017-11-01 11:15:04
F.US.BP6Z17 [CV] Weekly #24 | Reloading chart. | 2017-11-01 11:15:04
F.US.EU6Z17 [CBV] Weekly #25 | Reloading chart. | 2017-11-01 11:15:04
F.US.EU6Z17 Weekly #26 | Reloading chart. | 2017-11-01 11:15:04
F.US.JY6Z17 [CV] Weekly #23 | Reloading chart. | 2017-11-01 11:15:04
HD Request # 34 | Downloading Intraday chart data for F.US.MJYZ17 to the file F.US.MJYZ17.scid. Service: cqg | 2017-11-01 11:15:08
HD Request # 34 | Download start date-time: 2017-11-01 11:04:32.000 | 2017-11-01 11:15:08
HD Request # 34 | Requesting historical Tick data. | 2017-11-01 11:15:08
HD Request # 35 | Downloading Intraday chart data for F.US.M6BZ17 to the file F.US.M6BZ17.scid. Service: cqg | 2017-11-01 11:15:09
HD Request # 35 | Download start date-time: 2017-11-01 11:02:55.000 | 2017-11-01 11:15:09
HD Request # 35 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:15:09
Socket (42) | Creating socket. | 2017-11-01 11:15:09
Socket (42) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:15:09
HD Request # 35 | Setting DTC encoding to Binary VLS | 2017-11-01 11:15:09
HD Request # 35 | Sending historical data logon request message. | 2017-11-01 11:15:09
HD Request # 35 | Requesting Intraday data. Start date-time: 2017-11-01 11:02:55. Record interval: 0. Symbol: F.US.M6BZ17 | 2017-11-01 11:15:09
HD Request # 35 | Decompressing data. | 2017-11-01 11:15:09
HD Request # 35 | Receiving Intraday data for F.US.M6BZ17 starting at 2017-11-01 11:02:55 | 2017-11-01 11:15:09
HD Request # 35 | Timestamp of first Intraday data file record written: 2017-11-01 11:06:15 | 2017-11-01 11:15:09
Socket (42) | Initiating close of socket by core. | 2017-11-01 11:15:09
Socket (42) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:15:09
Historical data download thread signaled to stop. | 2017-11-01 11:15:09
HD Request # 35 | Received 13 records from 2017-11-01 11:02:55 to 2017-11-01 11:08:11 (5.3 minutes) and wrote 11 records for F.US.M6BZ17 | 2017-11-01 11:15:09
HD Request # 35 | Intraday download COMPLETE for F.US.M6BZ17. Completion time: 0s. Unique request ID: 41 | 2017-11-01 11:15:09
Removed historical data download ID 41 | 2017-11-01 11:15:09
Real-time Intraday chart data file updates started for F.US.M6BZ17 | 2017-11-01 11:15:09
Intraday chart data file opened for F.US.M6BZ17 | 2017-11-01 11:15:09
HD Request # 36 | Downloading Intraday chart data for F.US.M6EZ17 to the file F.US.M6EZ17.scid. Service: cqg | 2017-11-01 11:15:09
HD Request # 36 | Download start date-time: 2017-11-01 11:04:41.000 | 2017-11-01 11:15:09
HD Request # 36 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:15:09
Socket (43) | Creating socket. | 2017-11-01 11:15:09
Socket (43) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:15:09
Socket (42) | Socket gracefully closed by remote side. | 2017-11-01 11:15:09
Socket (42) | Closed. | 2017-11-01 11:15:09
HD Request # 36 | Setting DTC encoding to Binary VLS | 2017-11-01 11:15:09
HD Request # 36 | Sending historical data logon request message. | 2017-11-01 11:15:09
HD Request # 34 | Receiving Intraday data for F.US.MJYZ17 starting at 2017-11-01 11:06:20 | 2017-11-01 11:15:09
HD Request # 34 | Timestamp of first Intraday data file record written: 2017-11-01 11:06:20 | 2017-11-01 11:15:09
HD Request # 34 | Received 1 record from 2017-11-01 11:06:20 to 2017-11-01 11:06:20 (0.0 seconds) and wrote 1 record for F.US.MJYZ17 | 2017-11-01 11:15:09
HD Request # 34 | Intraday download COMPLETE for F.US.MJYZ17. Completion time: 1s. Unique request ID: 43 | 2017-11-01 11:15:09
Removed historical data download ID 43 | 2017-11-01 11:15:09
Real-time Intraday chart data file updates started for F.US.MJYZ17 | 2017-11-01 11:15:09
Intraday chart data file opened for F.US.MJYZ17 | 2017-11-01 11:15:09
HD Request # 36 | Requesting Intraday data. Start date-time: 2017-11-01 11:04:41. Record interval: 0. Symbol: F.US.M6EZ17 | 2017-11-01 11:15:10
HD Request # 36 | Decompressing data. | 2017-11-01 11:15:10
HD Request # 36 | Receiving Intraday data for F.US.M6EZ17 starting at 2017-11-01 11:04:41 | 2017-11-01 11:15:10
HD Request # 36 | Timestamp of first Intraday data file record written: 2017-11-01 11:06:09 | 2017-11-01 11:15:10
Socket (43) | Initiating close of socket by core. | 2017-11-01 11:15:10
Socket (43) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:15:10
Historical data download thread signaled to stop. | 2017-11-01 11:15:10
HD Request # 36 | Received 18 records from 2017-11-01 11:04:41 to 2017-11-01 11:15:02 (10.4 minutes) and wrote 17 records for F.US.M6EZ17 | 2017-11-01 11:15:10
HD Request # 36 | Intraday download COMPLETE for F.US.M6EZ17. Completion time: 0s. Unique request ID: 42 | 2017-11-01 11:15:10
Removed historical data download ID 42 | 2017-11-01 11:15:10
Real-time Intraday chart data file updates started for F.US.M6EZ17 | 2017-11-01 11:15:10
Intraday chart data file opened for F.US.M6EZ17 | 2017-11-01 11:15:10
Socket (43) | Socket gracefully closed by remote side. | 2017-11-01 11:15:10
Socket (43) | Closed. | 2017-11-01 11:15:10
F.US.CA6Z17 [CV] 5 Min #1 | Reloading chart. | 2017-11-01 11:15:15
F.US.CA6Z17 #2 | Reloading chart. | 2017-11-01 11:15:15
F.US.CA6Z17 [CV] 60 Min #3 | Reloading chart. | 2017-11-01 11:15:15
F.US.CA6Z17 [CV] Daily #4 | Reloading chart. | 2017-11-01 11:15:15
F.US.DA6Z17 [CV] 240 Min #5 | Reloading chart. | 2017-11-01 11:15:15
F.US.DA6Z17 #6 | Reloading chart. | 2017-11-01 11:15:15
F.US.DA6Z17 [CV] 60 Min #7 | Reloading chart. | 2017-11-01 11:15:15
F.US.DA6Z17 [CV] Daily #8 | Reloading chart. | 2017-11-01 11:15:15
F.US.NE6Z17 #9 | Reloading chart. | 2017-11-01 11:15:15
F.US.NE6Z17 [CV] Daily #10 | Reloading chart. | 2017-11-01 11:15:15
F.US.NE6Z17 [CV] 60 Min #11 | Reloading chart. | 2017-11-01 11:15:15
F.US.NE6Z17 [CV] 5 Min #12 | Reloading chart. | 2017-11-01 11:15:15
F.US.MX6Z17 #13 | Reloading chart. | 2017-11-01 11:15:15
F.US.MX6Z17 [CV] Daily #14 | Reloading chart. | 2017-11-01 11:15:15
F.US.MX6Z17 [CV] 60 Min #15 | Reloading chart. | 2017-11-01 11:15:15
F.US.MX6Z17 [CV] 5 Min #16 | Reloading chart. | 2017-11-01 11:15:15
F.US.CA6Z17 [CV] 240 Min #17 | Reloading chart. | 2017-11-01 11:15:15
F.US.NE6Z17 [CBV] Weekly #18 | Reloading chart. | 2017-11-01 11:15:15
F.US.DA6Z17 [CV] Weekly #19 | Reloading chart. | 2017-11-01 11:15:15
F.US.GMCDZ17 #20 | Reloading chart. | 2017-11-01 11:15:15
F.US.M6AZ17 #21 | Reloading chart. | 2017-11-01 11:15:15
F.US.NE6Z17 #22 | Reloading chart. | 2017-11-01 11:15:15
Intraday data recording state for symbol F.US.CA6Z17 is set to download 'Pending'. | 2017-11-01 11:15:24
HD Request # 37 | Downloading Intraday chart data for F.US.CA6Z17 to the file F.US.CA6Z17.scid. Service: cqg | 2017-11-01 11:15:24
HD Request # 37 | Download start date-time: 2017-11-01 11:05:18.000 | 2017-11-01 11:15:24
HD Request # 37 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:15:24
Socket (44) | Creating socket. | 2017-11-01 11:15:24
Socket (44) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:15:24
HD Request # 38 | Downloading Historical Daily chart data for F.US.CA6Z17. Starting date: 2017-10-31. Service: cqg | 2017-11-01 11:15:24
HD Request # 38 | Requesting historical Daily data for D6Z17 starting at 2017-10-30 | 2017-11-01 11:15:24
CQG FIX Trading | Starting real-time market data updates for: F.US.GMCDZ17. ID: 40 | 2017-11-01 11:15:24
CQG FIX Trading | Sending symbol resolution request for F.US.GMCDZ17. ID: 593662 | 2017-11-01 11:15:24
CQG FIX Trading | Requesting security definition data for: F.US.GMCDZ17. ID: 40 | 2017-11-01 11:15:24
Requesting market depth updates for: F.US.GMCDZ17 if supported. | 2017-11-01 11:15:24
CQG FIX Trading | Starting real-time market data updates for: F.US.M6AZ17. ID: 41 | 2017-11-01 11:15:24
CQG FIX Trading | Sending symbol resolution request for F.US.M6AZ17. ID: 593663 | 2017-11-01 11:15:24
CQG FIX Trading | Requesting security definition data for: F.US.M6AZ17. ID: 41 | 2017-11-01 11:15:24
Requesting market depth updates for: F.US.M6AZ17 if supported. | 2017-11-01 11:15:24
Requesting market depth updates for: F.US.NE6Z17 if supported. | 2017-11-01 11:15:24
CQG FIX Trading | Requesting market data including full depth for F.US.NE6Z17 | 2017-11-01 11:15:24
Intraday data recording state for symbol F.US.DA6Z17 is set to download 'Pending'. | 2017-11-01 11:15:24
CQG FIX Trading | Received symbol resolution report for symbol F.US.GMCDZ7. Search Symbol: F.US.GMCDZ17. Request ID: 593662. Contract ID: 33. | 2017-11-01 11:15:24
CQG FIX Trading | Requesting market data including full depth for F.US.GMCDZ17 | 2017-11-01 11:15:24
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6AZ7. Search Symbol: F.US.M6AZ17. Request ID: 593663. Contract ID: 34. | 2017-11-01 11:15:24
CQG FIX Trading | Requesting market data including full depth for F.US.M6AZ17 | 2017-11-01 11:15:24
Intraday data recording state for symbol F.US.NE6Z17 is set to download 'Pending'. | 2017-11-01 11:15:24
HD Request # 38 | Receiving historical Daily data for F.US.CA6Z17 starting at 2017-10-31 | 2017-11-01 11:15:24
HD Request # 38 | Writing historical Daily data to the file F.US.CA6Z17.dly | 2017-11-01 11:15:24
HD Request # 38 | Received 3 records from 2017-10-31 00:00:00 to 2017-11-01 00:00:00 (2.0 days) and wrote 2 records for F.US.CA6Z17 | 2017-11-01 11:15:24
HD Request # 38 | Daily download COMPLETE for F.US.CA6Z17. Completion time: 0s. Unique request ID: 45 | 2017-11-01 11:15:24
Removed historical data download ID 45 | 2017-11-01 11:15:24
HD Request # 39 | Downloading Historical Daily chart data for F.US.DA6Z17. Starting date: 2017-10-31. Service: cqg | 2017-11-01 11:15:24
HD Request # 39 | Requesting historical Daily data for A6Z17 starting at 2017-10-30 | 2017-11-01 11:15:24
HD Request # 37 | Setting DTC encoding to Binary VLS | 2017-11-01 11:15:24
HD Request # 37 | Sending historical data logon request message. | 2017-11-01 11:15:24
Intraday data recording state for symbol F.US.MX6Z17 is set to download 'Pending'. | 2017-11-01 11:15:24
Intraday data recording state for symbol F.US.GMCDZ17 is set to download 'Pending'. | 2017-11-01 11:15:24
HD Request # 39 | Receiving historical Daily data for F.US.DA6Z17 starting at 2017-10-31 | 2017-11-01 11:15:24
HD Request # 39 | Writing historical Daily data to the file F.US.DA6Z17.dly | 2017-11-01 11:15:24
HD Request # 39 | Received 3 records from 2017-10-31 00:00:00 to 2017-11-01 00:00:00 (2.0 days) and wrote 2 records for F.US.DA6Z17 | 2017-11-01 11:15:24
HD Request # 39 | Daily download COMPLETE for F.US.DA6Z17. Completion time: 1s. Unique request ID: 47 | 2017-11-01 11:15:24
Removed historical data download ID 47 | 2017-11-01 11:15:24
HD Request # 40 | Downloading Historical Daily chart data for F.US.NE6Z17. Starting date: 2017-10-31. Service: cqg | 2017-11-01 11:15:24
HD Request # 40 | Requesting historical Daily data for N6Z17 starting at 2017-10-30 | 2017-11-01 11:15:24
HD Request # 37 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:18. Record interval: 0. Symbol: F.US.CA6Z17 | 2017-11-01 11:15:24
Intraday data recording state for symbol F.US.M6AZ17 is set to download 'Pending'. | 2017-11-01 11:15:24
F.US.CA6Z17 [CV] Daily #4 | Reloading chart. | 2017-11-01 11:15:24
HD Request # 37 | Decompressing data. | 2017-11-01 11:15:24
HD Request # 37 | Receiving Intraday data for F.US.CA6Z17 starting at 2017-11-01 11:05:18 | 2017-11-01 11:15:24
HD Request # 37 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:23 | 2017-11-01 11:15:24
Socket (44) | Initiating close of socket by core. | 2017-11-01 11:15:24
Socket (44) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:15:24
Socket (44) | Socket gracefully closed by remote side. | 2017-11-01 11:15:24
Socket (44) | Closed. | 2017-11-01 11:15:24
HD Request # 40 | Receiving historical Daily data for F.US.NE6Z17 starting at 2017-10-31 | 2017-11-01 11:15:24
HD Request # 40 | Writing historical Daily data to the file F.US.NE6Z17.dly | 2017-11-01 11:15:24
HD Request # 40 | Received 3 records from 2017-10-31 00:00:00 to 2017-11-01 00:00:00 (2.0 days) and wrote 2 records for F.US.NE6Z17 | 2017-11-01 11:15:24
HD Request # 40 | Daily download COMPLETE for F.US.NE6Z17. Completion time: 0s. Unique request ID: 49 | 2017-11-01 11:15:24
Removed historical data download ID 49 | 2017-11-01 11:15:24
Historical data download thread signaled to stop. | 2017-11-01 11:15:24
HD Request # 37 | Received 217 records from 2017-11-01 11:05:18 to 2017-11-01 11:15:20 (10.0 minutes) and wrote 216 records for F.US.CA6Z17 | 2017-11-01 11:15:24
HD Request # 37 | Intraday download COMPLETE for F.US.CA6Z17. Completion time: 1s. Unique request ID: 44 | 2017-11-01 11:15:24
Removed historical data download ID 44 | 2017-11-01 11:15:24
Real-time Intraday chart data file updates started for F.US.CA6Z17 | 2017-11-01 11:15:24
Intraday chart data file opened for F.US.CA6Z17 | 2017-11-01 11:15:24
HD Request # 41 | Downloading Historical Daily chart data for F.US.MX6Z17. Starting date: 2017-10-31. Service: cqg | 2017-11-01 11:15:24
HD Request # 41 | Requesting historical Daily data for M6Z17 starting at 2017-10-30 | 2017-11-01 11:15:24
HD Request # 42 | Downloading Intraday chart data for F.US.DA6Z17 to the file F.US.DA6Z17.scid. Service: cqg | 2017-11-01 11:15:24
HD Request # 42 | Download start date-time: 2017-11-01 11:05:24.000 | 2017-11-01 11:15:24
HD Request # 42 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:15:24
Socket (45) | Creating socket. | 2017-11-01 11:15:24
Socket (45) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:15:24
F.US.DA6Z17 [CV] Daily #8 | Reloading chart. | 2017-11-01 11:15:25
HD Request # 42 | Setting DTC encoding to Binary VLS | 2017-11-01 11:15:25
HD Request # 42 | Sending historical data logon request message. | 2017-11-01 11:15:25
HD Request # 42 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:24. Record interval: 0. Symbol: F.US.DA6Z17 | 2017-11-01 11:15:25
HD Request # 42 | Decompressing data. | 2017-11-01 11:15:25
HD Request # 42 | Receiving Intraday data for F.US.DA6Z17 starting at 2017-11-01 11:05:24 | 2017-11-01 11:15:25
HD Request # 42 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:37 | 2017-11-01 11:15:25
Socket (45) | Initiating close of socket by core. | 2017-11-01 11:15:25
Socket (45) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:15:25
HD Request # 41 | Receiving historical Daily data for F.US.MX6Z17 starting at 2017-10-31 | 2017-11-01 11:15:25
HD Request # 41 | Writing historical Daily data to the file F.US.MX6Z17.dly | 2017-11-01 11:15:25
HD Request # 41 | Received 3 records from 2017-10-31 00:00:00 to 2017-11-01 00:00:00 (2.0 days) and wrote 2 records for F.US.MX6Z17 | 2017-11-01 11:15:25
HD Request # 41 | Daily download COMPLETE for F.US.MX6Z17. Completion time: 0s. Unique request ID: 51 | 2017-11-01 11:15:25
Removed historical data download ID 51 | 2017-11-01 11:15:25
Historical data download thread signaled to stop. | 2017-11-01 11:15:25
HD Request # 42 | Received 133 records from 2017-11-01 11:05:24 to 2017-11-01 11:14:57 (9.6 minutes) and wrote 129 records for F.US.DA6Z17 | 2017-11-01 11:15:25
HD Request # 42 | Intraday download COMPLETE for F.US.DA6Z17. Completion time: 1s. Unique request ID: 46 | 2017-11-01 11:15:25
Removed historical data download ID 46 | 2017-11-01 11:15:25
Real-time Intraday chart data file updates started for F.US.DA6Z17 | 2017-11-01 11:15:25
Intraday chart data file opened for F.US.DA6Z17 | 2017-11-01 11:15:25
HD Request # 43 | Downloading Intraday chart data for F.US.NE6Z17 to the file F.US.NE6Z17.scid. Service: cqg | 2017-11-01 11:15:25
HD Request # 43 | Download start date-time: 2017-11-01 11:04:32.000 | 2017-11-01 11:15:25
HD Request # 43 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:15:25
Socket (46) | Creating socket. | 2017-11-01 11:15:25
Socket (46) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:15:25
Socket (45) | Socket gracefully closed by remote side. | 2017-11-01 11:15:25
Socket (45) | Closed. | 2017-11-01 11:15:25
F.US.NE6Z17 [CV] Daily #10 | Reloading chart. | 2017-11-01 11:15:25
HD Request # 43 | Setting DTC encoding to Binary VLS | 2017-11-01 11:15:25
HD Request # 43 | Sending historical data logon request message. | 2017-11-01 11:15:25
F.US.DA6Z17 [CV] Weekly #19 | Reloading chart. | 2017-11-01 11:15:25
HD Request # 43 | Requesting Intraday data. Start date-time: 2017-11-01 11:04:32. Record interval: 0. Symbol: F.US.NE6Z17 | 2017-11-01 11:15:25
HD Request # 43 | Decompressing data. | 2017-11-01 11:15:25
HD Request # 43 | Receiving Intraday data for F.US.NE6Z17 starting at 2017-11-01 11:06:20 | 2017-11-01 11:15:25
HD Request # 43 | Timestamp of first Intraday data file record written: 2017-11-01 11:06:20 | 2017-11-01 11:15:25
Socket (46) | Initiating close of socket by core. | 2017-11-01 11:15:25
Socket (46) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:15:25
Socket (46) | Socket gracefully closed by remote side. | 2017-11-01 11:15:25
Socket (46) | Closed. | 2017-11-01 11:15:25
HD Request # 43 | Received 93 records from 2017-11-01 11:06:20 to 2017-11-01 11:15:07 (8.8 minutes) and wrote 93 records for F.US.NE6Z17 | 2017-11-01 11:15:25
HD Request # 43 | Intraday download COMPLETE for F.US.NE6Z17. Completion time: 0s. Unique request ID: 48 | 2017-11-01 11:15:25
Removed historical data download ID 48 | 2017-11-01 11:15:25
Real-time Intraday chart data file updates started for F.US.NE6Z17 | 2017-11-01 11:15:25
Intraday chart data file opened for F.US.NE6Z17 | 2017-11-01 11:15:25
HD Request # 44 | Downloading Intraday chart data for F.US.MX6Z17 to the file F.US.MX6Z17.scid. Service: cqg | 2017-11-01 11:15:25
HD Request # 44 | Download start date-time: 2017-11-01 11:05:23.000 | 2017-11-01 11:15:25
HD Request # 44 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:15:25
Socket (47) | Creating socket. | 2017-11-01 11:15:25
Socket (47) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:15:25
F.US.NE6Z17 [CBV] Weekly #18 | Reloading chart. | 2017-11-01 11:15:25
HD Request # 44 | Setting DTC encoding to Binary VLS | 2017-11-01 11:15:25
HD Request # 44 | Sending historical data logon request message. | 2017-11-01 11:15:25
HD Request # 44 | Requesting Intraday data. Start date-time: 2017-11-01 11:05:23. Record interval: 0. Symbol: F.US.MX6Z17 | 2017-11-01 11:15:25
F.US.MX6Z17 [CV] Daily #14 | Reloading chart. | 2017-11-01 11:15:25
HD Request # 44 | Decompressing data. | 2017-11-01 11:15:25
HD Request # 44 | Receiving Intraday data for F.US.MX6Z17 starting at 2017-11-01 11:05:23 | 2017-11-01 11:15:25
HD Request # 44 | Timestamp of first Intraday data file record written: 2017-11-01 11:05:45 | 2017-11-01 11:15:25
Socket (47) | Initiating close of socket by core. | 2017-11-01 11:15:25
Socket (47) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:15:25
Socket (47) | Socket gracefully closed by remote side. | 2017-11-01 11:15:25
Socket (47) | Closed. | 2017-11-01 11:15:25
HD Request # 44 | Received 32 records from 2017-11-01 11:05:23 to 2017-11-01 11:14:53 (9.5 minutes) and wrote 26 records for F.US.MX6Z17 | 2017-11-01 11:15:25
Added 4 Time and Sales records to Intraday data file for F.US.MX6Z17 after download. | 2017-11-01 11:15:25
HD Request # 44 | Intraday download COMPLETE for F.US.MX6Z17. Completion time: 0s. Unique request ID: 50 | 2017-11-01 11:15:25
Removed historical data download ID 50 | 2017-11-01 11:15:25
Real-time Intraday chart data file updates started for F.US.MX6Z17 | 2017-11-01 11:15:25
Intraday chart data file opened for F.US.MX6Z17 | 2017-11-01 11:15:25
Delaying start of download for F.US.GMCDZ17 | 2017-11-01 11:15:25
HD Request # 45 | Downloading Intraday chart data for F.US.GMCDZ17 to the file F.US.GMCDZ17.scid. Service: cqg | 2017-11-01 11:15:30
HD Request # 45 | Download start date-time: 2017-11-01 11:01:10.000 | 2017-11-01 11:15:30
HD Request # 45 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:15:30
Socket (48) | Creating socket. | 2017-11-01 11:15:30
Socket (48) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:15:30
HD Request # 45 | Setting DTC encoding to Binary VLS | 2017-11-01 11:15:30
HD Request # 45 | Sending historical data logon request message. | 2017-11-01 11:15:30
HD Request # 45 | Requesting Intraday data. Start date-time: 2017-11-01 11:01:10. Record interval: 0. Symbol: F.US.GMCDZ17 | 2017-11-01 11:15:30
HD Request # 45 | Decompressing data. | 2017-11-01 11:15:31
HD Request # 45 | Receiving Intraday data for F.US.GMCDZ17 starting at 2017-11-01 11:01:10 | 2017-11-01 11:15:31
HD Request # 45 | Timestamp of first Intraday data file record written: 2017-11-01 11:09:09 | 2017-11-01 11:15:31
Socket (48) | Initiating close of socket by core. | 2017-11-01 11:15:31
Historical data download thread signaled to stop. | 2017-11-01 11:15:31
Socket (48) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:15:31
HD Request # 45 | Received 2 records from 2017-11-01 11:01:10 to 2017-11-01 11:09:09 (8.0 minutes) and wrote 1 record for F.US.GMCDZ17 | 2017-11-01 11:15:31
HD Request # 45 | Intraday download COMPLETE for F.US.GMCDZ17. Completion time: 0s. Unique request ID: 52 | 2017-11-01 11:15:31
Removed historical data download ID 52 | 2017-11-01 11:15:31
Real-time Intraday chart data file updates started for F.US.GMCDZ17 | 2017-11-01 11:15:31
Intraday chart data file opened for F.US.GMCDZ17 | 2017-11-01 11:15:31
HD Request # 46 | Downloading Intraday chart data for F.US.M6AZ17 to the file F.US.M6AZ17.scid. Service: cme | 2017-11-01 11:15:31
HD Request # 46 | Download start date-time: 2017-11-01 11:02:55.000 | 2017-11-01 11:15:31
HD Request # 46 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 11:15:31
Socket (49) | Creating socket. | 2017-11-01 11:15:31
Socket (49) | Connecting to IP: 8.18.161.135. | 2017-11-01 11:15:31
Socket (48) | Socket gracefully closed by remote side. | 2017-11-01 11:15:31
Socket (48) | Closed. | 2017-11-01 11:15:31
HD Request # 46 | Setting DTC encoding to Binary VLS | 2017-11-01 11:15:31
HD Request # 46 | Sending historical data logon request message. | 2017-11-01 11:15:31
HD Request # 46 | Requesting Intraday data. Start date-time: 2017-11-01 11:02:55. Record interval: 0. Symbol: M6AZ17 | 2017-11-01 11:15:31
HD Request # 46 | Decompressing data. | 2017-11-01 11:15:31
HD Request # 46 | Receiving Intraday data for F.US.M6AZ17 starting at 2017-11-01 11:02:55 | 2017-11-01 11:15:31
HD Request # 46 | Timestamp of first Intraday data file record written: 2017-11-01 11:03:33 | 2017-11-01 11:15:31
Socket (49) | Initiating close of socket by core. | 2017-11-01 11:15:31
Socket (49) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:15:31
HD Request # 46 | Received 2 records from 2017-11-01 11:02:55 to 2017-11-01 11:03:33 (38.0 seconds) and wrote 1 record for F.US.M6AZ17 | 2017-11-01 11:15:31
HD Request # 46 | Intraday download COMPLETE for F.US.M6AZ17. Completion time: 0s. Unique request ID: 53 | 2017-11-01 11:15:31
Removed historical data download ID 53 | 2017-11-01 11:15:31
Real-time Intraday chart data file updates started for F.US.M6AZ17 | 2017-11-01 11:15:31
Intraday chart data file opened for F.US.M6AZ17 | 2017-11-01 11:15:31
Socket (49) | Socket gracefully closed by remote side. | 2017-11-01 11:15:31
Socket (49) | Closed. | 2017-11-01 11:15:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.MX6Z17.scid | 2017-11-01 11:15:38
Opened cached Intraday file: C:\SierraChart\Data\F.US.CA6Z17.scid | 2017-11-01 11:15:58
Opened cached Intraday file: C:\SierraChart\Data\F.US.DA6Z17.scid | 2017-11-01 11:15:58
Opened cached Intraday file: C:\SierraChart\Data\F.US.NE6Z17.scid | 2017-11-01 11:15:58
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6EZ17.scid | 2017-11-01 11:15:58
HTTP connection to ds01.ddfplus.com:80 (40) | Socket gracefully closed by remote side. | 2017-11-01 11:16:31
HTTP connection to ds01.ddfplus.com:80 (40) | Initiating close of socket by core. | 2017-11-01 11:16:31
HTTP connection to ds01.ddfplus.com:80 (40) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 11:16:31
HTTP connection to ds01.ddfplus.com:80 (40) | Closed. | 2017-11-01 11:16:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.GMCDZ17.scid | 2017-11-01 11:17:39
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6AZ17.scid | 2017-11-01 11:18:00
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6BZ17.scid | 2017-11-01 11:20:42
Opened cached Intraday file: C:\SierraChart\Data\F.US.MJYZ17.scid | 2017-11-01 11:29:50
CQG FIX: No heartbeat messages received from server. Sent Test Request message to server. | 2017-11-01 11:30:33
CQG FIX: Disconnecting due to a loss of activity. No activity for at least 42 seconds. | 2017-11-01 11:31:53 *
CQG FIX: Sending a Logout message. Text = No response received after Test Request. | 2017-11-01 11:31:53
CQG FIX socket (15) | Initiating close of socket by core. | 2017-11-01 11:31:53
CQG FIX: Disconnected. | 2017-11-01 11:31:53
Connection to the external service has been lost. | 2017-11-01 11:31:53
CQG FIX socket (15) | Write in progress. Shutdown being delayed. | 2017-11-01 11:31:53
CQG FIX socket (15) | Write has completed. Shutdown being performed. | 2017-11-01 11:31:53
CQG FIX socket (15) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:31:53
CQG FIX Trading | Sending Web API Logoff message. | 2017-11-01 11:31:53
CQG WebSocket socket (17) | Adding bytes from final send buffer from buffered socket: 17 | 2017-11-01 11:31:53
CQG WebSocket socket (17) | Initiating close of socket by core. | 2017-11-01 11:31:53
CQG WebSocket | WebSocket closed. | 2017-11-01 11:31:53
CQG FIX Trading | WebSocket closed. | 2017-11-01 11:31:53
CQG WebSocket socket (17) | Sending bytes from final send buffer: 17 | 2017-11-01 11:31:53
CQG WebSocket socket (17) | Write in progress. Shutdown being delayed. | 2017-11-01 11:31:53
CQG FIX Trading | Disconnected. | 2017-11-01 11:31:53
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 11:31:53
CQG WebSocket socket (17) | Write has completed. Shutdown being performed. | 2017-11-01 11:31:53
CQG WebSocket socket (17) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:31:53
CQG WebSocket socket (17) | Socket gracefully closed by remote side. | 2017-11-01 11:31:53
CQG WebSocket socket (17) | Closed. | 2017-11-01 11:31:53
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-01 11:31:56
CQG FIX socket (55) | Creating socket. Using TLS 1.2. | 2017-11-01 11:31:56
CQG FIX socket (55) | Connecting to IP: 208.48.16.214. | 2017-11-01 11:31:56
CQG FIX: Sending the Logon message. | 2017-11-01 11:31:56
CQG FIX Trading | Connected to trading server. | 2017-11-01 11:31:57
CQG FIX Trading | Connecting to server api.cqg.com | 2017-11-01 11:31:57
CQG WebSocket | Connecting to WebSocket server. | 2017-11-01 11:31:57
CQG FIX | FCM name: AMP | 2017-11-01 11:31:57
CQG WebSocket socket (56) | Creating socket. Using TLS 1.2. | 2017-11-01 11:31:57
CQG WebSocket socket (56) | Connecting to IP: 195.166.124.165. | 2017-11-01 11:31:57
CQG WebSocket | Opening WebSocket. | 2017-11-01 11:31:57
CQG WebSocket | Sending WebSocket handshake. | 2017-11-01 11:31:57
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-11-01 11:31:57
CQG WebSocket | Web socket state is now open. | 2017-11-01 11:31:57
CQG FIX Trading | WebSocket connected. | 2017-11-01 11:31:57
CQG FIX Trading | Sending market data logon message. | 2017-11-01 11:31:57
CQG FIX Trading | Logon successful. Session Token = ep+DP9tlBSHq3B5AXUWYaFey/WugOidp9SNQeJu95NoWbOuTpnk+jFtrOIjhghuoKy05tUg6wzN | 2017-11-01 11:31:57
CQG FIX Trading | Connected to data and trading server. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.DLM17. ID: 1 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.DLM17. ID: 593664 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.DLM17. ID: 1 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6M17. ID: 2 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.CA6M17. ID: 593665 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.CA6M17. ID: 2 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6M17. ID: 3 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.BP6M17. ID: 593666 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.BP6M17. ID: 3 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6M17. ID: 4 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.EU6M17. ID: 593667 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.EU6M17. ID: 4 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6Z17. ID: 5 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.CA6Z17. ID: 593668 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.CA6Z17. ID: 5 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ17. ID: 6 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ17. ID: 593669 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.DDZ17. ID: 6 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ17. ID: 7 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ17. ID: 593670 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ17. ID: 7 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.FVSX17. ID: 8 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.FVSX17. ID: 593671 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.FVSX17. ID: 8 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.SWZ17. ID: 9 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.SWZ17. ID: 593672 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.SWZ17. ID: 9 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.ENQZ17. ID: 10 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.ENQZ17. ID: 593673 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.ENQZ17. ID: 10 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.EPZ17. ID: 11 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.EPZ17. ID: 593674 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.EPZ17. ID: 11 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.NKDZ17. ID: 12 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.NKDZ17. ID: 593675 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.NKDZ17. ID: 12 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.YMZ17. ID: 13 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.YMZ17. ID: 593676 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.YMZ17. ID: 13 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.CA6Z7. Search Symbol: F.US.CA6Z17. Request ID: 593668. Contract ID: 1. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.CA6Z17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.DDZ7. Search Symbol: F.US.DDZ17. Request ID: 593669. Contract ID: 2. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.DDZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXZ7. Search Symbol: F.US.DSXZ17. Request ID: 593670. Contract ID: 3. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.DSXZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVSX7. Search Symbol: F.US.FVSX17. Request ID: 593671. Contract ID: 4. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.FVSX17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.SWZ7. Search Symbol: F.US.SWZ17. Request ID: 593672. Contract ID: 5. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.SWZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.ENQZ7. Search Symbol: F.US.ENQZ17. Request ID: 593673. Contract ID: 6. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.ENQZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.EPZ7. Search Symbol: F.US.EPZ17. Request ID: 593674. Contract ID: 7. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.EPZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.NKDZ7. Search Symbol: F.US.NKDZ17. Request ID: 593675. Contract ID: 8. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.NKDZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.YMZ7. Search Symbol: F.US.YMZ17. Request ID: 593676. Contract ID: 9. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.YMZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 11:31:57
Symbol Error - F.US.DLM17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6Z17. ID: 14 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.BP6Z17. ID: 593677 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.BP6Z17. ID: 14 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6Z17. ID: 15 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.EU6Z17. ID: 593678 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.EU6Z17. ID: 15 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.JY6Z17. ID: 16 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.JY6Z17. ID: 593679 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.JY6Z17. ID: 16 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6Z17. ID: 17 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.MX6Z17. ID: 593680 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.MX6Z17. ID: 17 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.DA6Z17. ID: 18 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.DA6Z17. ID: 593681 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.DA6Z17. ID: 18 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.NE6Z17. ID: 19 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.NE6Z17. ID: 593682 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.NE6Z17. ID: 19 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.EADZ17. ID: 20 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.EADZ17. ID: 593683 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.EADZ17. ID: 20 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.ECDZ17. ID: 21 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.ECDZ17. ID: 593684 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.ECDZ17. ID: 21 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.DDZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
Delaying start of download for F.US.DDZ17 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.DSXZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
HD Request # 47 | Downloading Intraday chart data for F.US.DDZ17 to the file F.US.DDZ17.scid. Service: cqg | 2017-11-01 11:31:57
HD Request # 47 | Download start date-time: 2017-11-01 11:32:01.000 | 2017-11-01 11:31:57
HD Request # 47 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.BP6Z7. Search Symbol: F.US.BP6Z17. Request ID: 593677. Contract ID: 10. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.BP6Z17 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.EPZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
Socket (57) | Creating socket. | 2017-11-01 11:31:57
Socket (57) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.EU6Z7. Search Symbol: F.US.EU6Z17. Request ID: 593678. Contract ID: 11. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.EU6Z17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.JY6Z7. Search Symbol: F.US.JY6Z17. Request ID: 593679. Contract ID: 12. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.JY6Z17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.MX6Z7. Search Symbol: F.US.MX6Z17. Request ID: 593680. Contract ID: 13. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.MX6Z17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.DA6Z7. Search Symbol: F.US.DA6Z17. Request ID: 593681. Contract ID: 14. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.DA6Z17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.NE6Z7. Search Symbol: F.US.NE6Z17. Request ID: 593682. Contract ID: 15. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.NE6Z17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.EADZ7. Search Symbol: F.US.EADZ17. Request ID: 593683. Contract ID: 16. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.EADZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.ECDZ7. Search Symbol: F.US.ECDZ17. Request ID: 593684. Contract ID: 17. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.ECDZ17 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.BP6Z17 is set to download 'Pending'. | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.EU6Z17 is set to download 'Pending'. | 2017-11-01 11:31:57
Symbol Error - F.US.CA6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:31:57
Symbol Error - F.US.EU6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:31:57
Symbol Error - F.US.BP6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:31:57
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.EPZ17.2017-11-01.depth | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.JY6Z17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6M17. ID: 22 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.MX6M17. ID: 593685 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.MX6M17. ID: 22 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.MX6M17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.DBZ17. ID: 23 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.DBZ17. ID: 593686 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.DBZ17. ID: 23 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.DBZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.DBZ7. Search Symbol: F.US.DBZ17. Request ID: 593686. Contract ID: 18. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.DBZ17 | 2017-11-01 11:31:57
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DBZ17.2017-11-01.depth | 2017-11-01 11:31:57
Symbol Error - F.US.MX6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.NE6Z17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.FDXMZ17. ID: 24 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.FDXMZ17. ID: 593687 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.FDXMZ17. ID: 24 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.FDXMZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.FDXMZ7. Search Symbol: F.US.FDXMZ17. Request ID: 593687. Contract ID: 19. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.FDXMZ17 | 2017-11-01 11:31:57
HD Request # 47 | Setting DTC encoding to Binary VLS | 2017-11-01 11:31:57
HD Request # 47 | Sending historical data logon request message. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.CLEZ17. ID: 25 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.CLEZ17. ID: 593688 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.CLEZ17. ID: 25 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.CLEZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.TYAZ17. ID: 26 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.TYAZ17. ID: 593689 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.TYAZ17. ID: 26 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.TYAZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEZ7. Search Symbol: F.US.CLEZ17. Request ID: 593688. Contract ID: 20. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.CLEZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.USAZ17. ID: 27 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.USAZ17. ID: 593690 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.USAZ17. ID: 27 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.USAZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.DLZ17. ID: 28 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.DLZ17. ID: 593691 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.DLZ17. ID: 28 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.DLZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.TYAZ7. Search Symbol: F.US.TYAZ17. Request ID: 593689. Contract ID: 21. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.TYAZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.DGZ17. ID: 29 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.DGZ17. ID: 593692 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.DGZ17. ID: 29 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.DGZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.USAZ7. Search Symbol: F.US.USAZ17. Request ID: 593690. Contract ID: 22. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.USAZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.FGBXZ17. ID: 30 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.FGBXZ17. ID: 593693 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.FGBXZ17. ID: 30 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.FGBXZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.FBTPZ17. ID: 31 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.FBTPZ17. ID: 593694 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.FBTPZ17. ID: 31 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.FBTPZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.DLZ7. Search Symbol: F.US.DLZ17. Request ID: 593691. Contract ID: 23. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.DLZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.DGZ7. Search Symbol: F.US.DGZ17. Request ID: 593692. Contract ID: 24. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.DGZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.FGBXZ7. Search Symbol: F.US.FGBXZ17. Request ID: 593693. Contract ID: 25. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.FGBXZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.FBTPZ7. Search Symbol: F.US.FBTPZ17. Request ID: 593694. Contract ID: 26. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.FBTPZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.FOATZ17. ID: 32 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.FOATZ17. ID: 593695 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.FOATZ17. ID: 32 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.FOATZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.GMCDZ17. ID: 33 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.GMCDZ17. ID: 593696 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.GMCDZ17. ID: 33 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.GMCDZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.M6BZ17. ID: 34 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.M6BZ17. ID: 593697 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.M6BZ17. ID: 34 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.M6BZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.M6EZ17. ID: 35 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.M6EZ17. ID: 593698 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.M6EZ17. ID: 35 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.M6EZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.M6AZ17. ID: 36 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.M6AZ17. ID: 593699 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.M6AZ17. ID: 36 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.M6AZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.FOATZ7. Search Symbol: F.US.FOATZ17. Request ID: 593695. Contract ID: 27. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.FOATZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.MJYZ17. ID: 37 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.MJYZ17. ID: 593700 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.MJYZ17. ID: 37 | 2017-11-01 11:31:57
CQG FIX Trading | Using primary service for historical data for F.US.MJYZ17 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.MJYZ17 is set to download 'Pending'. | 2017-11-01 11:31:57
Delaying start of download for F.US.MJYZ17 | 2017-11-01 11:31:57
Requesting market depth updates for: F.US.DDZ17 if supported. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data including full depth for F.US.DDZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.GMCDZ7. Search Symbol: F.US.GMCDZ17. Request ID: 593696. Contract ID: 28. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.GMCDZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6BZ7. Search Symbol: F.US.M6BZ17. Request ID: 593697. Contract ID: 29. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.M6BZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6EZ7. Search Symbol: F.US.M6EZ17. Request ID: 593698. Contract ID: 30. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.M6EZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6AZ7. Search Symbol: F.US.M6AZ17. Request ID: 593699. Contract ID: 31. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.M6AZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Received symbol resolution report for symbol F.US.MJYZ7. Search Symbol: F.US.MJYZ17. Request ID: 593700. Contract ID: 32. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data for F.US.MJYZ17 | 2017-11-01 11:31:57
HD Request # 47 | Requesting Intraday data. Start date-time: 2017-11-01 11:32:01. Record interval: 0. Symbol: F.US.DDZ17 | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ16. ID: 38 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ16. ID: 593701 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ16. ID: 38 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.DSXZ16 is set to download 'Pending'. | 2017-11-01 11:31:57
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ16. ID: 39 | 2017-11-01 11:31:57
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ16. ID: 593702 | 2017-11-01 11:31:57
CQG FIX Trading | Requesting security definition data for: F.US.DDZ16. ID: 39 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.DDZ16 is set to download 'Pending'. | 2017-11-01 11:31:57
Requesting market depth updates for: F.US.DBZ17 if supported. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data including full depth for F.US.DBZ17 | 2017-11-01 11:31:57
Requesting market depth updates for: F.US.DSXZ17 if supported. | 2017-11-01 11:31:57
CQG FIX Trading | Requesting market data including full depth for F.US.DSXZ17 | 2017-11-01 11:31:57
Intraday data recording state for symbol F.US.DA6Z17 is set to download 'Pending'. | 2017-11-01 11:31:58
Intraday data recording state for symbol F.US.CA6Z17 is set to download 'Pending'. | 2017-11-01 11:31:58
Intraday data recording state for symbol F.US.MX6Z17 is set to download 'Pending'. | 2017-11-01 11:31:58
CQG FIX Trading | Starting real-time market data updates for: F.US.TUAZ17. ID: 40 | 2017-11-01 11:31:58
CQG FIX Trading | Sending symbol resolution request for F.US.TUAZ17. ID: 593703 | 2017-11-01 11:31:58
CQG FIX Trading | Requesting security definition data for: F.US.TUAZ17. ID: 40 | 2017-11-01 11:31:58
CQG FIX Trading | Starting real-time market data updates for: F.US.FVAZ17. ID: 41 | 2017-11-01 11:31:58
CQG FIX Trading | Sending symbol resolution request for F.US.FVAZ17. ID: 593704 | 2017-11-01 11:31:58
CQG FIX Trading | Requesting security definition data for: F.US.FVAZ17. ID: 41 | 2017-11-01 11:31:58
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DDZ17.2017-11-01.depth | 2017-11-01 11:31:58
CQG FIX Trading | Received symbol resolution report for symbol F.US.TUAZ7. Search Symbol: F.US.TUAZ17. Request ID: 593703. Contract ID: 33. | 2017-11-01 11:31:58
CQG FIX Trading | Requesting market data for F.US.TUAZ17 | 2017-11-01 11:31:58
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DSXZ17.2017-11-01.depth | 2017-11-01 11:31:58
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVAZ7. Search Symbol: F.US.FVAZ17. Request ID: 593704. Contract ID: 34. | 2017-11-01 11:31:58
CQG FIX Trading | Requesting market data for F.US.FVAZ17 | 2017-11-01 11:31:58
HD Request # 47 | Decompressing data. | 2017-11-01 11:31:58
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 11:31:58
HD Request # 47 | Receiving Intraday data for F.US.DDZ17 starting at 2017-11-01 11:32:01 | 2017-11-01 11:31:58
Symbol Error - F.US.DSXZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:31:58
Symbol Error - F.US.DDZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 11:31:58
HD Request # 47 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:01 | 2017-11-01 11:31:58
Socket (57) | Initiating close of socket by core. | 2017-11-01 11:31:58
Socket (57) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:31:58
Historical data download thread signaled to stop. | 2017-11-01 11:31:58
HD Request # 47 | Received 4 records from 2017-11-01 11:32:01 to 2017-11-01 11:32:03 (2.0 seconds) and wrote 2 records for F.US.DDZ17 | 2017-11-01 11:31:58
Added 2 Time and Sales records to Intraday data file for F.US.DDZ17 after download. | 2017-11-01 11:31:58
HD Request # 47 | Intraday download COMPLETE for F.US.DDZ17. Completion time: 0s. Unique request ID: 54 | 2017-11-01 11:31:58
Removed historical data download ID 54 | 2017-11-01 11:31:58
Real-time Intraday chart data file updates started for F.US.DDZ17 | 2017-11-01 11:31:58
Intraday chart data file opened for F.US.DDZ17 | 2017-11-01 11:31:58
Delaying start of download for F.US.DSXZ17 | 2017-11-01 11:31:58
Socket (57) | Socket gracefully closed by remote side. | 2017-11-01 11:31:58
Socket (57) | Closed. | 2017-11-01 11:31:58
Delaying start of download for F.US.MJYZ17 | 2017-11-01 11:31:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.DDZ17.scid | 2017-11-01 11:32:01
HD Request # 48 | Downloading Intraday chart data for F.US.MJYZ17 to the file F.US.MJYZ17.scid. Service: cqg | 2017-11-01 11:32:02
HD Request # 48 | Download start date-time: 2017-11-01 11:29:56.000 | 2017-11-01 11:32:02
HD Request # 48 | Requesting historical Tick data. | 2017-11-01 11:32:02
HD Request # 48 | Receiving Intraday data for F.US.MJYZ17 starting at 2017-11-01 11:29:56 | 2017-11-01 11:32:03
HD Request # 48 | Received 1 record from 2017-11-01 11:29:56 to 2017-11-01 11:29:56 (0.0 seconds) and wrote 0 records for F.US.MJYZ17 | 2017-11-01 11:32:03
HD Request # 48 | Intraday download COMPLETE for F.US.MJYZ17. Completion time: 0s. Unique request ID: 76 | 2017-11-01 11:32:03
Removed historical data download ID 76 | 2017-11-01 11:32:03
Real-time Intraday chart data file updates started for F.US.MJYZ17 | 2017-11-01 11:32:03
Intraday chart data file opened for F.US.MJYZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.BP6Z17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.BP6Z17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.CLEZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.CLEZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.DGZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.DGZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.DLZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.DLZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.EPZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.EPZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.EU6Z17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.EU6Z17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.FBTPZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.FBTPZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.FDXMZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.FDXMZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.FGBXZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.FGBXZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.FOATZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.FOATZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.GMCDZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.GMCDZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.JY6Z17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.JY6Z17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.M6AZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.M6AZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.M6BZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.M6BZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.M6EZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.M6EZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.MJYZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.MJYZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.MX6M17 if supported. | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.NE6Z17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.NE6Z17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.TYAZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.TYAZ17 | 2017-11-01 11:32:03
Requesting market depth updates for: F.US.USAZ17 if supported. | 2017-11-01 11:32:03
CQG FIX Trading | Requesting market data including full depth for F.US.USAZ17 | 2017-11-01 11:32:03
HD Request # 49 | Downloading Intraday chart data for F.US.DSXZ17 to the file F.US.DSXZ17.scid. Service: cqg | 2017-11-01 11:32:03
HD Request # 49 | Download start date-time: 2017-11-01 11:31:51.000 | 2017-11-01 11:32:03
HD Request # 49 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:32:03
Socket (59) | Creating socket. | 2017-11-01 11:32:03
Socket (59) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:03
HD Request # 49 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:03
HD Request # 49 | Sending historical data logon request message. | 2017-11-01 11:32:03
HD Request # 49 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:51. Record interval: 0. Symbol: F.US.DSXZ17 | 2017-11-01 11:32:03
HD Request # 49 | Decompressing data. | 2017-11-01 11:32:03
HD Request # 49 | Receiving Intraday data for F.US.DSXZ17 starting at 2017-11-01 11:31:51 | 2017-11-01 11:32:03
HD Request # 49 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:01 | 2017-11-01 11:32:03
Socket (59) | Initiating close of socket by core. | 2017-11-01 11:32:03
Socket (59) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:03
Historical data download thread signaled to stop. | 2017-11-01 11:32:03
HD Request # 49 | Received 25 records from 2017-11-01 11:31:51 to 2017-11-01 11:32:10 (19.0 seconds) and wrote 24 records for F.US.DSXZ17 | 2017-11-01 11:32:03
HD Request # 49 | Intraday download COMPLETE for F.US.DSXZ17. Completion time: 1s. Unique request ID: 55 | 2017-11-01 11:32:03
Removed historical data download ID 55 | 2017-11-01 11:32:03
Real-time Intraday chart data file updates started for F.US.DSXZ17 | 2017-11-01 11:32:03
Intraday chart data file opened for F.US.DSXZ17 | 2017-11-01 11:32:03
HD Request # 50 | Downloading Intraday chart data for F.US.EPZ17 to the file F.US.EPZ17.scid. Service: cqg | 2017-11-01 11:32:03
HD Request # 50 | Download start date-time: 2017-11-01 11:32:00.000 | 2017-11-01 11:32:03
HD Request # 50 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:32:03
Socket (60) | Creating socket. | 2017-11-01 11:32:03
Socket (60) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:03
Socket (59) | Socket gracefully closed by remote side. | 2017-11-01 11:32:03
Socket (59) | Closed. | 2017-11-01 11:32:03
HD Request # 50 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:03
HD Request # 50 | Sending historical data logon request message. | 2017-11-01 11:32:03
HD Request # 50 | Requesting Intraday data. Start date-time: 2017-11-01 11:32:00. Record interval: 0. Symbol: F.US.EPZ17 | 2017-11-01 11:32:04
HD Request # 50 | Decompressing data. | 2017-11-01 11:32:04
HD Request # 50 | Receiving Intraday data for F.US.EPZ17 starting at 2017-11-01 11:32:00 | 2017-11-01 11:32:04
HD Request # 50 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:04 | 2017-11-01 11:32:04
Socket (60) | Initiating close of socket by core. | 2017-11-01 11:32:04
Socket (60) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:04
Historical data download thread signaled to stop. | 2017-11-01 11:32:04
HD Request # 50 | Received 109 records from 2017-11-01 11:32:00 to 2017-11-01 11:32:07 (7.0 seconds) and wrote 106 records for F.US.EPZ17 | 2017-11-01 11:32:04
HD Request # 50 | Intraday download COMPLETE for F.US.EPZ17. Completion time: 0s. Unique request ID: 56 | 2017-11-01 11:32:04
Removed historical data download ID 56 | 2017-11-01 11:32:04
Real-time Intraday chart data file updates started for F.US.EPZ17 | 2017-11-01 11:32:04
Intraday chart data file opened for F.US.EPZ17 | 2017-11-01 11:32:04
HD Request # 51 | Downloading Intraday chart data for F.US.BP6Z17 to the file F.US.BP6Z17.scid. Service: cqg | 2017-11-01 11:32:04
HD Request # 51 | Download start date-time: 2017-11-01 11:32:00.000 | 2017-11-01 11:32:04
HD Request # 51 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:32:04
Socket (61) | Creating socket. | 2017-11-01 11:32:04
Socket (61) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:04
Socket (60) | Socket gracefully closed by remote side. | 2017-11-01 11:32:04
Socket (60) | Closed. | 2017-11-01 11:32:04
HD Request # 51 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:04
HD Request # 51 | Sending historical data logon request message. | 2017-11-01 11:32:04
HD Request # 51 | Requesting Intraday data. Start date-time: 2017-11-01 11:32:00. Record interval: 0. Symbol: F.US.BP6Z17 | 2017-11-01 11:32:04
HD Request # 51 | Decompressing data. | 2017-11-01 11:32:04
HD Request # 51 | Receiving Intraday data for F.US.BP6Z17 starting at 2017-11-01 11:32:00 | 2017-11-01 11:32:04
HD Request # 51 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:02 | 2017-11-01 11:32:04
Socket (61) | Initiating close of socket by core. | 2017-11-01 11:32:04
Socket (61) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:04
HD Request # 51 | Received 4 records from 2017-11-01 11:32:00 to 2017-11-01 11:32:02 (2.0 seconds) and wrote 3 records for F.US.BP6Z17 | 2017-11-01 11:32:04
HD Request # 51 | Intraday download COMPLETE for F.US.BP6Z17. Completion time: 0s. Unique request ID: 57 | 2017-11-01 11:32:04
Removed historical data download ID 57 | 2017-11-01 11:32:04
Real-time Intraday chart data file updates started for F.US.BP6Z17 | 2017-11-01 11:32:04
Intraday chart data file opened for F.US.BP6Z17 | 2017-11-01 11:32:04
HD Request # 52 | Downloading Intraday chart data for F.US.EU6Z17 to the file F.US.EU6Z17.scid. Service: cqg | 2017-11-01 11:32:04
HD Request # 52 | Download start date-time: 2017-11-01 11:31:59.000 | 2017-11-01 11:32:04
HD Request # 52 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:32:04
Socket (62) | Creating socket. | 2017-11-01 11:32:04
Socket (62) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:04
Socket (61) | Socket gracefully closed by remote side. | 2017-11-01 11:32:04
Socket (61) | Closed. | 2017-11-01 11:32:04
HD Request # 52 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:04
HD Request # 52 | Sending historical data logon request message. | 2017-11-01 11:32:04
HD Request # 52 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:59. Record interval: 0. Symbol: F.US.EU6Z17 | 2017-11-01 11:32:04
HD Request # 52 | Decompressing data. | 2017-11-01 11:32:04
HD Request # 52 | Receiving Intraday data for F.US.EU6Z17 starting at 2017-11-01 11:31:59 | 2017-11-01 11:32:04
HD Request # 52 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:02 | 2017-11-01 11:32:04
Socket (62) | Initiating close of socket by core. | 2017-11-01 11:32:04
Socket (62) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:04
HD Request # 52 | Received 63 records from 2017-11-01 11:31:59 to 2017-11-01 11:32:06 (7.0 seconds) and wrote 62 records for F.US.EU6Z17 | 2017-11-01 11:32:04
Added 5 Time and Sales records to Intraday data file for F.US.EU6Z17 after download. | 2017-11-01 11:32:04
HD Request # 52 | Intraday download COMPLETE for F.US.EU6Z17. Completion time: 0s. Unique request ID: 58 | 2017-11-01 11:32:04
Removed historical data download ID 58 | 2017-11-01 11:32:04
Real-time Intraday chart data file updates started for F.US.EU6Z17 | 2017-11-01 11:32:04
Intraday chart data file opened for F.US.EU6Z17 | 2017-11-01 11:32:04
HD Request # 53 | Downloading Intraday chart data for F.US.JY6Z17 to the file F.US.JY6Z17.scid. Service: cqg | 2017-11-01 11:32:04
HD Request # 53 | Download start date-time: 2017-11-01 11:31:51.000 | 2017-11-01 11:32:04
HD Request # 53 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:32:04
Socket (63) | Creating socket. | 2017-11-01 11:32:04
Socket (63) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:04
Socket (62) | Socket gracefully closed by remote side. | 2017-11-01 11:32:04
Socket (62) | Closed. | 2017-11-01 11:32:04
HD Request # 53 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:05
HD Request # 53 | Sending historical data logon request message. | 2017-11-01 11:32:05
HD Request # 53 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:51. Record interval: 0. Symbol: F.US.JY6Z17 | 2017-11-01 11:32:05
HD Request # 53 | Decompressing data. | 2017-11-01 11:32:05
HD Request # 53 | Receiving Intraday data for F.US.JY6Z17 starting at 2017-11-01 11:31:51 | 2017-11-01 11:32:05
HD Request # 53 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:02 | 2017-11-01 11:32:05
Socket (63) | Initiating close of socket by core. | 2017-11-01 11:32:05
Historical data download thread signaled to stop. | 2017-11-01 11:32:05
Socket (63) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:05
HD Request # 53 | Received 48 records from 2017-11-01 11:31:51 to 2017-11-01 11:32:10 (19.0 seconds) and wrote 29 records for F.US.JY6Z17 | 2017-11-01 11:32:05
HD Request # 53 | Intraday download COMPLETE for F.US.JY6Z17. Completion time: 1s. Unique request ID: 59 | 2017-11-01 11:32:05
Removed historical data download ID 59 | 2017-11-01 11:32:05
Real-time Intraday chart data file updates started for F.US.JY6Z17 | 2017-11-01 11:32:05
Intraday chart data file opened for F.US.JY6Z17 | 2017-11-01 11:32:05
HD Request # 54 | Downloading Intraday chart data for F.US.MX6M17 to the file F.US.MX6M17.scid. Service: cme | 2017-11-01 11:32:05
HD Request # 54 | Download start date-time: 2017-06-19 14:48:49.000 | 2017-11-01 11:32:05
HD Request # 54 | Using server: ds7.sierracharts.com port 10149 | 2017-11-01 11:32:05
Socket (64) | Creating socket. | 2017-11-01 11:32:05
Socket (64) | Connecting to IP: 8.18.161.133. | 2017-11-01 11:32:05
Socket (63) | Socket gracefully closed by remote side. | 2017-11-01 11:32:05
Socket (63) | Closed. | 2017-11-01 11:32:05
HD Request # 54 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:05
HD Request # 54 | Sending historical data logon request message. | 2017-11-01 11:32:05
HD Request # 54 | Requesting Intraday data. Start date-time: 2017-06-19 14:48:49. Record interval: 0. Symbol: 6MM17 | 2017-11-01 11:32:05
HD Request # 54 | Decompressing data. | 2017-11-01 11:32:05
HD Request # 54 | Receiving Intraday data for F.US.MX6M17 starting at 2017-06-19 14:48:49 | 2017-11-01 11:32:05
Socket (64) | Initiating close of socket by core. | 2017-11-01 11:32:05
Socket (64) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:05
HD Request # 54 | Received 4 records from 2017-06-19 14:48:49 to 2017-06-19 14:48:49 (0.0 seconds) and wrote 0 records for F.US.MX6M17 | 2017-11-01 11:32:05
HD Request # 54 | Intraday download COMPLETE for F.US.MX6M17. Completion time: 0s. Unique request ID: 60 | 2017-11-01 11:32:05
Removed historical data download ID 60 | 2017-11-01 11:32:05
Real-time Intraday chart data file updates started for F.US.MX6M17 | 2017-11-01 11:32:05
Intraday chart data file opened for F.US.MX6M17 | 2017-11-01 11:32:05
HD Request # 55 | Downloading Intraday chart data for F.US.DBZ17 to the file F.US.DBZ17.scid. Service: cqg | 2017-11-01 11:32:05
HD Request # 55 | Download start date-time: 2017-11-01 11:31:58.000 | 2017-11-01 11:32:05
HD Request # 55 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:32:05
Socket (65) | Creating socket. | 2017-11-01 11:32:05
Socket (65) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:05
Socket (64) | Socket gracefully closed by remote side. | 2017-11-01 11:32:05
Socket (64) | Closed. | 2017-11-01 11:32:05
HD Request # 55 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:05
HD Request # 55 | Sending historical data logon request message. | 2017-11-01 11:32:05
HD Request # 55 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:58. Record interval: 0. Symbol: F.US.DBZ17 | 2017-11-01 11:32:06
HD Request # 55 | Decompressing data. | 2017-11-01 11:32:06
HD Request # 55 | Receiving Intraday data for F.US.DBZ17 starting at 2017-11-01 11:31:58 | 2017-11-01 11:32:06
HD Request # 55 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:01 | 2017-11-01 11:32:06
Socket (65) | Initiating close of socket by core. | 2017-11-01 11:32:06
Socket (65) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:06
Historical data download thread signaled to stop. | 2017-11-01 11:32:06
HD Request # 55 | Received 4 records from 2017-11-01 11:31:58 to 2017-11-01 11:32:07 (9.0 seconds) and wrote 3 records for F.US.DBZ17 | 2017-11-01 11:32:06
HD Request # 55 | Intraday download COMPLETE for F.US.DBZ17. Completion time: 0s. Unique request ID: 61 | 2017-11-01 11:32:06
Removed historical data download ID 61 | 2017-11-01 11:32:06
Real-time Intraday chart data file updates started for F.US.DBZ17 | 2017-11-01 11:32:06
Intraday chart data file opened for F.US.DBZ17 | 2017-11-01 11:32:06
HD Request # 56 | Downloading Intraday chart data for F.US.NE6Z17 to the file F.US.NE6Z17.scid. Service: cqg | 2017-11-01 11:32:06
HD Request # 56 | Download start date-time: 2017-11-01 11:31:44.000 | 2017-11-01 11:32:06
HD Request # 56 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:32:06
Socket (66) | Creating socket. | 2017-11-01 11:32:06
Socket (66) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:06
Socket (65) | Socket gracefully closed by remote side. | 2017-11-01 11:32:06
Socket (65) | Closed. | 2017-11-01 11:32:06
HD Request # 56 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:06
HD Request # 56 | Sending historical data logon request message. | 2017-11-01 11:32:06
HD Request # 56 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:44. Record interval: 0. Symbol: F.US.NE6Z17 | 2017-11-01 11:32:06
HD Request # 56 | Decompressing data. | 2017-11-01 11:32:06
HD Request # 56 | Receiving Intraday data for F.US.NE6Z17 starting at 2017-11-01 11:31:44 | 2017-11-01 11:32:06
HD Request # 56 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:02 | 2017-11-01 11:32:06
Socket (66) | Initiating close of socket by core. | 2017-11-01 11:32:06
Socket (66) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:06
HD Request # 56 | Received 9 records from 2017-11-01 11:31:44 to 2017-11-01 11:32:10 (26.0 seconds) and wrote 8 records for F.US.NE6Z17 | 2017-11-01 11:32:06
HD Request # 56 | Intraday download COMPLETE for F.US.NE6Z17. Completion time: 0s. Unique request ID: 62 | 2017-11-01 11:32:06
Removed historical data download ID 62 | 2017-11-01 11:32:06
Real-time Intraday chart data file updates started for F.US.NE6Z17 | 2017-11-01 11:32:06
Intraday chart data file opened for F.US.NE6Z17 | 2017-11-01 11:32:06
HD Request # 57 | Downloading Intraday chart data for F.US.FDXMZ17 to the file F.US.FDXMZ17.scid. Service: cqg | 2017-11-01 11:32:06
HD Request # 57 | Download start date-time: 2017-11-01 11:31:51.000 | 2017-11-01 11:32:06
HD Request # 57 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:32:06
Socket (67) | Creating socket. | 2017-11-01 11:32:06
Socket (67) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:06
Socket (66) | Socket gracefully closed by remote side. | 2017-11-01 11:32:06
Socket (66) | Closed. | 2017-11-01 11:32:06
HD Request # 57 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:06
HD Request # 57 | Sending historical data logon request message. | 2017-11-01 11:32:06
HD Request # 57 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:51. Record interval: 0. Symbol: F.US.FDXMZ17 | 2017-11-01 11:32:07
HD Request # 57 | Decompressing data. | 2017-11-01 11:32:07
HD Request # 57 | Receiving Intraday data for F.US.FDXMZ17 starting at 2017-11-01 11:31:51 | 2017-11-01 11:32:07
HD Request # 57 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:04 | 2017-11-01 11:32:07
Socket (67) | Initiating close of socket by core. | 2017-11-01 11:32:07
Socket (67) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:07
Historical data download thread signaled to stop. | 2017-11-01 11:32:07
HD Request # 57 | Received 6 records from 2017-11-01 11:31:51 to 2017-11-01 11:32:10 (19.0 seconds) and wrote 5 records for F.US.FDXMZ17 | 2017-11-01 11:32:07
HD Request # 57 | Intraday download COMPLETE for F.US.FDXMZ17. Completion time: 0s. Unique request ID: 63 | 2017-11-01 11:32:07
Removed historical data download ID 63 | 2017-11-01 11:32:07
Real-time Intraday chart data file updates started for F.US.FDXMZ17 | 2017-11-01 11:32:07
Intraday chart data file opened for F.US.FDXMZ17 | 2017-11-01 11:32:07
HD Request # 58 | Downloading Intraday chart data for F.US.CLEZ17 to the file F.US.CLEZ17.scid. Service: cqg | 2017-11-01 11:32:07
HD Request # 58 | Download start date-time: 2017-11-01 11:32:01.000 | 2017-11-01 11:32:07
HD Request # 58 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:32:07
Socket (68) | Creating socket. | 2017-11-01 11:32:07
Socket (68) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:07
Socket (67) | Socket gracefully closed by remote side. | 2017-11-01 11:32:07
Socket (67) | Closed. | 2017-11-01 11:32:07
HD Request # 58 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:07
HD Request # 58 | Sending historical data logon request message. | 2017-11-01 11:32:07
HD Request # 58 | Requesting Intraday data. Start date-time: 2017-11-01 11:32:01. Record interval: 0. Symbol: F.US.CLEZ17 | 2017-11-01 11:32:07
HD Request # 58 | Decompressing data. | 2017-11-01 11:32:07
HD Request # 58 | Receiving Intraday data for F.US.CLEZ17 starting at 2017-11-01 11:32:01 | 2017-11-01 11:32:07
HD Request # 58 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:02 | 2017-11-01 11:32:07
Socket (68) | Initiating close of socket by core. | 2017-11-01 11:32:07
Socket (68) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:07
HD Request # 58 | Received 20 records from 2017-11-01 11:32:01 to 2017-11-01 11:32:13 (12.0 seconds) and wrote 19 records for F.US.CLEZ17 | 2017-11-01 11:32:07
HD Request # 58 | Intraday download COMPLETE for F.US.CLEZ17. Completion time: 1s. Unique request ID: 64 | 2017-11-01 11:32:07
Removed historical data download ID 64 | 2017-11-01 11:32:07
Real-time Intraday chart data file updates started for F.US.CLEZ17 | 2017-11-01 11:32:07
Intraday chart data file opened for F.US.CLEZ17 | 2017-11-01 11:32:07
HD Request # 59 | Downloading Intraday chart data for F.US.TYAZ17 to the file F.US.TYAZ17.scid. Service: cqg | 2017-11-01 11:32:07
HD Request # 59 | Download start date-time: 2017-11-01 11:31:16.000 | 2017-11-01 11:32:07
HD Request # 59 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:32:07
Socket (69) | Creating socket. | 2017-11-01 11:32:07
Socket (69) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:07
Socket (68) | Socket gracefully closed by remote side. | 2017-11-01 11:32:07
Socket (68) | Closed. | 2017-11-01 11:32:07
HD Request # 59 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:08
HD Request # 59 | Sending historical data logon request message. | 2017-11-01 11:32:08
HD Request # 59 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:16. Record interval: 0. Symbol: F.US.TYAZ17 | 2017-11-01 11:32:08
HD Request # 59 | Decompressing data. | 2017-11-01 11:32:08
HD Request # 59 | Receiving Intraday data for F.US.TYAZ17 starting at 2017-11-01 11:31:16 | 2017-11-01 11:32:08
HD Request # 59 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:07 | 2017-11-01 11:32:08
Socket (69) | Initiating close of socket by core. | 2017-11-01 11:32:08
Socket (69) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:08
Historical data download thread signaled to stop. | 2017-11-01 11:32:08
HD Request # 59 | Received 2 records from 2017-11-01 11:31:16 to 2017-11-01 11:32:07 (51.0 seconds) and wrote 1 record for F.US.TYAZ17 | 2017-11-01 11:32:08
HD Request # 59 | Intraday download COMPLETE for F.US.TYAZ17. Completion time: 1s. Unique request ID: 65 | 2017-11-01 11:32:08
Removed historical data download ID 65 | 2017-11-01 11:32:08
Real-time Intraday chart data file updates started for F.US.TYAZ17 | 2017-11-01 11:32:08
Intraday chart data file opened for F.US.TYAZ17 | 2017-11-01 11:32:08
HD Request # 60 | Downloading Intraday chart data for F.US.USAZ17 to the file F.US.USAZ17.scid. Service: cqg | 2017-11-01 11:32:08
HD Request # 60 | Download start date-time: 2017-11-01 11:32:01.000 | 2017-11-01 11:32:08
HD Request # 60 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:32:08
Socket (70) | Creating socket. | 2017-11-01 11:32:08
Socket (70) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:08
Socket (69) | Socket gracefully closed by remote side. | 2017-11-01 11:32:08
Socket (69) | Closed. | 2017-11-01 11:32:08
HD Request # 60 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:08
HD Request # 60 | Sending historical data logon request message. | 2017-11-01 11:32:08
HD Request # 60 | Requesting Intraday data. Start date-time: 2017-11-01 11:32:01. Record interval: 0. Symbol: F.US.USAZ17 | 2017-11-01 11:32:08
HD Request # 60 | Decompressing data. | 2017-11-01 11:32:08
HD Request # 60 | Receiving Intraday data for F.US.USAZ17 starting at 2017-11-01 11:32:01 | 2017-11-01 11:32:08
HD Request # 60 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:07 | 2017-11-01 11:32:08
Socket (70) | Initiating close of socket by core. | 2017-11-01 11:32:08
Socket (70) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:08
HD Request # 60 | Received 4 records from 2017-11-01 11:32:01 to 2017-11-01 11:32:10 (9.0 seconds) and wrote 2 records for F.US.USAZ17 | 2017-11-01 11:32:08
Added 3 Time and Sales records to Intraday data file for F.US.USAZ17 after download. | 2017-11-01 11:32:08
HD Request # 60 | Intraday download COMPLETE for F.US.USAZ17. Completion time: 0s. Unique request ID: 66 | 2017-11-01 11:32:08
Removed historical data download ID 66 | 2017-11-01 11:32:08
Real-time Intraday chart data file updates started for F.US.USAZ17 | 2017-11-01 11:32:08
Intraday chart data file opened for F.US.USAZ17 | 2017-11-01 11:32:08
HD Request # 61 | Downloading Intraday chart data for F.US.DLZ17 to the file F.US.DLZ17.scid. Service: cqg | 2017-11-01 11:32:08
HD Request # 61 | Download start date-time: 2017-11-01 11:31:21.000 | 2017-11-01 11:32:08
HD Request # 61 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:32:08
Socket (71) | Creating socket. | 2017-11-01 11:32:08
Socket (71) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:08
Socket (70) | Socket gracefully closed by remote side. | 2017-11-01 11:32:08
Socket (70) | Closed. | 2017-11-01 11:32:08
HD Request # 61 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:08
HD Request # 61 | Sending historical data logon request message. | 2017-11-01 11:32:08
HD Request # 61 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:21. Record interval: 0. Symbol: F.US.DLZ17 | 2017-11-01 11:32:09
HD Request # 61 | Decompressing data. | 2017-11-01 11:32:09
HD Request # 61 | Receiving Intraday data for F.US.DLZ17 starting at 2017-11-01 11:31:21 | 2017-11-01 11:32:09
Socket (71) | Initiating close of socket by core. | 2017-11-01 11:32:09
Socket (71) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:09
Historical data download thread signaled to stop. | 2017-11-01 11:32:09
HD Request # 61 | Received 1 record from 2017-11-01 11:31:21 to 2017-11-01 11:31:21 (0.0 seconds) and wrote 0 records for F.US.DLZ17 | 2017-11-01 11:32:09
HD Request # 61 | Intraday download COMPLETE for F.US.DLZ17. Completion time: 0s. Unique request ID: 67 | 2017-11-01 11:32:09
Removed historical data download ID 67 | 2017-11-01 11:32:09
Real-time Intraday chart data file updates started for F.US.DLZ17 | 2017-11-01 11:32:09
Intraday chart data file opened for F.US.DLZ17 | 2017-11-01 11:32:09
HD Request # 62 | Downloading Intraday chart data for F.US.DGZ17 to the file F.US.DGZ17.scid. Service: cqg | 2017-11-01 11:32:09
HD Request # 62 | Download start date-time: 2017-11-01 11:30:20.000 | 2017-11-01 11:32:09
HD Request # 62 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:32:09
Socket (72) | Creating socket. | 2017-11-01 11:32:09
Socket (72) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:09
Socket (71) | Socket gracefully closed by remote side. | 2017-11-01 11:32:09
Socket (71) | Closed. | 2017-11-01 11:32:09
HD Request # 62 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:09
HD Request # 62 | Sending historical data logon request message. | 2017-11-01 11:32:09
HD Request # 62 | Requesting Intraday data. Start date-time: 2017-11-01 11:30:20. Record interval: 0. Symbol: F.US.DGZ17 | 2017-11-01 11:32:09
HD Request # 62 | Decompressing data. | 2017-11-01 11:32:09
HD Request # 62 | Receiving Intraday data for F.US.DGZ17 starting at 2017-11-01 11:30:20 | 2017-11-01 11:32:09
Socket (72) | Initiating close of socket by core. | 2017-11-01 11:32:09
Socket (72) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:09
HD Request # 62 | Received 1 record from 2017-11-01 11:30:20 to 2017-11-01 11:30:20 (0.0 seconds) and wrote 0 records for F.US.DGZ17 | 2017-11-01 11:32:09
HD Request # 62 | Intraday download COMPLETE for F.US.DGZ17. Completion time: 0s. Unique request ID: 68 | 2017-11-01 11:32:09
Removed historical data download ID 68 | 2017-11-01 11:32:09
Real-time Intraday chart data file updates started for F.US.DGZ17 | 2017-11-01 11:32:09
Intraday chart data file opened for F.US.DGZ17 | 2017-11-01 11:32:09
HD Request # 63 | Downloading Intraday chart data for F.US.FGBXZ17 to the file F.US.FGBXZ17.scid. Service: cqg | 2017-11-01 11:32:09
HD Request # 63 | Download start date-time: 2017-11-01 11:31:58.000 | 2017-11-01 11:32:09
HD Request # 63 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:32:09
Socket (73) | Creating socket. | 2017-11-01 11:32:09
Socket (73) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:09
Socket (72) | Socket gracefully closed by remote side. | 2017-11-01 11:32:09
Socket (72) | Closed. | 2017-11-01 11:32:09
HD Request # 63 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:09
HD Request # 63 | Sending historical data logon request message. | 2017-11-01 11:32:09
HD Request # 63 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:58. Record interval: 0. Symbol: F.US.FGBXZ17 | 2017-11-01 11:32:09
HD Request # 63 | Decompressing data. | 2017-11-01 11:32:09
HD Request # 63 | Receiving Intraday data for F.US.FGBXZ17 starting at 2017-11-01 11:31:58 | 2017-11-01 11:32:09
Socket (73) | Initiating close of socket by core. | 2017-11-01 11:32:09
Socket (73) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:09
HD Request # 63 | Received 2 records from 2017-11-01 11:31:58 to 2017-11-01 11:31:58 (0.0 seconds) and wrote 0 records for F.US.FGBXZ17 | 2017-11-01 11:32:09
HD Request # 63 | Intraday download COMPLETE for F.US.FGBXZ17. Completion time: 0s. Unique request ID: 69 | 2017-11-01 11:32:09
Removed historical data download ID 69 | 2017-11-01 11:32:09
Real-time Intraday chart data file updates started for F.US.FGBXZ17 | 2017-11-01 11:32:09
Intraday chart data file opened for F.US.FGBXZ17 | 2017-11-01 11:32:09
HD Request # 64 | Downloading Intraday chart data for F.US.FBTPZ17 to the file F.US.FBTPZ17.scid. Service: eurex | 2017-11-01 11:32:09
HD Request # 64 | Download start date-time: 2017-11-01 11:32:00.000 | 2017-11-01 11:32:09
HD Request # 64 | Using server: ds1.sierracharts.com port 10149 | 2017-11-01 11:32:09
Socket (74) | Creating socket. | 2017-11-01 11:32:09
Socket (74) | Connecting to IP: 8.18.161.135. | 2017-11-01 11:32:09
Socket (73) | Socket gracefully closed by remote side. | 2017-11-01 11:32:10
Socket (73) | Closed. | 2017-11-01 11:32:10
HD Request # 64 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:10
HD Request # 64 | Sending historical data logon request message. | 2017-11-01 11:32:10
HD Request # 64 | Requesting Intraday data. Start date-time: 2017-11-01 11:32:00. Record interval: 0. Symbol: IIZ17 | 2017-11-01 11:32:10
HD Request # 64 | Decompressing data. | 2017-11-01 11:32:10
Socket (74) | Initiating close of socket by core. | 2017-11-01 11:32:10
Socket (74) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:10
Historical data download thread signaled to stop. | 2017-11-01 11:32:10
HD Request # 64 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FBTPZ17 | 2017-11-01 11:32:10
HD Request # 64 | Intraday download COMPLETE for F.US.FBTPZ17. Completion time: 1s. Unique request ID: 70 | 2017-11-01 11:32:10
Removed historical data download ID 70 | 2017-11-01 11:32:10
Real-time Intraday chart data file updates started for F.US.FBTPZ17 | 2017-11-01 11:32:10
Intraday chart data file opened for F.US.FBTPZ17 | 2017-11-01 11:32:10
HD Request # 65 | Downloading Intraday chart data for F.US.FOATZ17 to the file F.US.FOATZ17.scid. Service: eurex | 2017-11-01 11:32:10
HD Request # 65 | Download start date-time: 2017-11-01 11:31:48.000 | 2017-11-01 11:32:10
HD Request # 65 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 11:32:10
Socket (75) | Creating socket. | 2017-11-01 11:32:10
Socket (75) | Connecting to IP: 8.18.161.133. | 2017-11-01 11:32:10
Socket (74) | Socket gracefully closed by remote side. | 2017-11-01 11:32:10
Socket (74) | Closed. | 2017-11-01 11:32:10
HD Request # 65 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:10
HD Request # 65 | Sending historical data logon request message. | 2017-11-01 11:32:10
HD Request # 65 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:48. Record interval: 0. Symbol: FNZ17 | 2017-11-01 11:32:10
HD Request # 65 | Decompressing data. | 2017-11-01 11:32:10
Socket (75) | Initiating close of socket by core. | 2017-11-01 11:32:10
Socket (75) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:10
HD Request # 65 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FOATZ17 | 2017-11-01 11:32:10
HD Request # 65 | Intraday download COMPLETE for F.US.FOATZ17. Completion time: 0s. Unique request ID: 71 | 2017-11-01 11:32:10
Removed historical data download ID 71 | 2017-11-01 11:32:10
Real-time Intraday chart data file updates started for F.US.FOATZ17 | 2017-11-01 11:32:10
Intraday chart data file opened for F.US.FOATZ17 | 2017-11-01 11:32:10
HD Request # 66 | Downloading Intraday chart data for F.US.GMCDZ17 to the file F.US.GMCDZ17.scid. Service: cqg | 2017-11-01 11:32:10
HD Request # 66 | Download start date-time: 2017-11-01 11:25:17.000 | 2017-11-01 11:32:10
HD Request # 66 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:32:10
Socket (76) | Creating socket. | 2017-11-01 11:32:10
Socket (76) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:10
Socket (75) | Socket gracefully closed by remote side. | 2017-11-01 11:32:11
Socket (75) | Closed. | 2017-11-01 11:32:11
HD Request # 66 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:11
HD Request # 66 | Sending historical data logon request message. | 2017-11-01 11:32:11
CQG FIX socket (15) | Received socket Close event. | 2017-11-01 11:32:11
CQG FIX socket (15) | Still waiting for graceful close or receive error. | 2017-11-01 11:32:11
CQG FIX socket (15) | Socket gracefully closed by remote side. | 2017-11-01 11:32:11
CQG FIX socket (15) | Closed. | 2017-11-01 11:32:11
HD Request # 66 | Requesting Intraday data. Start date-time: 2017-11-01 11:25:17. Record interval: 0. Symbol: F.US.GMCDZ17 | 2017-11-01 11:32:11
HD Request # 66 | Decompressing data. | 2017-11-01 11:32:11
HD Request # 66 | Receiving Intraday data for F.US.GMCDZ17 starting at 2017-11-01 11:25:17 | 2017-11-01 11:32:11
HD Request # 66 | Timestamp of first Intraday data file record written: 2017-11-01 11:25:58 | 2017-11-01 11:32:11
Socket (76) | Initiating close of socket by core. | 2017-11-01 11:32:11
Socket (76) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:11
Historical data download thread signaled to stop. | 2017-11-01 11:32:11
HD Request # 66 | Received 3 records from 2017-11-01 11:25:17 to 2017-11-01 11:27:53 (2.6 minutes) and wrote 2 records for F.US.GMCDZ17 | 2017-11-01 11:32:11
HD Request # 66 | Intraday download COMPLETE for F.US.GMCDZ17. Completion time: 1s. Unique request ID: 72 | 2017-11-01 11:32:11
Removed historical data download ID 72 | 2017-11-01 11:32:11
Real-time Intraday chart data file updates started for F.US.GMCDZ17 | 2017-11-01 11:32:11
Intraday chart data file opened for F.US.GMCDZ17 | 2017-11-01 11:32:11
HD Request # 67 | Downloading Intraday chart data for F.US.M6BZ17 to the file F.US.M6BZ17.scid. Service: cqg | 2017-11-01 11:32:11
HD Request # 67 | Download start date-time: 2017-11-01 11:30:48.000 | 2017-11-01 11:32:11
HD Request # 67 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 11:32:11
Socket (77) | Creating socket. | 2017-11-01 11:32:11
Socket (77) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:11
Socket (76) | Socket gracefully closed by remote side. | 2017-11-01 11:32:11
Socket (76) | Closed. | 2017-11-01 11:32:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.DSXZ17.scid | 2017-11-01 11:32:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.EU6Z17.scid | 2017-11-01 11:32:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.JY6Z17.scid | 2017-11-01 11:32:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.DBZ17.scid | 2017-11-01 11:32:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.FDXMZ17.scid | 2017-11-01 11:32:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEZ17.scid | 2017-11-01 11:32:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.USAZ17.scid | 2017-11-01 11:32:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.FBTPZ17.scid | 2017-11-01 11:32:11
HD Request # 67 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:14
HD Request # 67 | Sending historical data logon request message. | 2017-11-01 11:32:14
HD Request # 67 | Requesting Intraday data. Start date-time: 2017-11-01 11:30:48. Record interval: 0. Symbol: F.US.M6BZ17 | 2017-11-01 11:32:14
HD Request # 67 | Decompressing data. | 2017-11-01 11:32:14
HD Request # 67 | Receiving Intraday data for F.US.M6BZ17 starting at 2017-11-01 11:30:48 | 2017-11-01 11:32:14
HD Request # 67 | Timestamp of first Intraday data file record written: 2017-11-01 11:30:48 | 2017-11-01 11:32:14
Socket (77) | Initiating close of socket by core. | 2017-11-01 11:32:14
Socket (77) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:14
Historical data download thread signaled to stop. | 2017-11-01 11:32:14
HD Request # 67 | Received 2 records from 2017-11-01 11:30:48 to 2017-11-01 11:30:48 (0.0 seconds) and wrote 1 record for F.US.M6BZ17 | 2017-11-01 11:32:14
HD Request # 67 | Intraday download COMPLETE for F.US.M6BZ17. Completion time: 3s. Unique request ID: 73 | 2017-11-01 11:32:14
Removed historical data download ID 73 | 2017-11-01 11:32:14
Real-time Intraday chart data file updates started for F.US.M6BZ17 | 2017-11-01 11:32:14
Intraday chart data file opened for F.US.M6BZ17 | 2017-11-01 11:32:14
HD Request # 68 | Downloading Intraday chart data for F.US.M6EZ17 to the file F.US.M6EZ17.scid. Service: cqg | 2017-11-01 11:32:14
HD Request # 68 | Download start date-time: 2017-11-01 11:29:53.000 | 2017-11-01 11:32:14
HD Request # 68 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 11:32:14
Socket (78) | Creating socket. | 2017-11-01 11:32:14
Socket (78) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:14
Socket (77) | Socket gracefully closed by remote side. | 2017-11-01 11:32:14
Socket (77) | Closed. | 2017-11-01 11:32:14
HD Request # 68 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:15
HD Request # 68 | Sending historical data logon request message. | 2017-11-01 11:32:15
HD Request # 68 | Requesting Intraday data. Start date-time: 2017-11-01 11:29:53. Record interval: 0. Symbol: F.US.M6EZ17 | 2017-11-01 11:32:15
HD Request # 68 | Decompressing data. | 2017-11-01 11:32:15
HD Request # 68 | Receiving Intraday data for F.US.M6EZ17 starting at 2017-11-01 11:29:53 | 2017-11-01 11:32:15
HD Request # 68 | Timestamp of first Intraday data file record written: 2017-11-01 11:31:49 | 2017-11-01 11:32:15
Socket (78) | Initiating close of socket by core. | 2017-11-01 11:32:15
Socket (78) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:15
Historical data download thread signaled to stop. | 2017-11-01 11:32:15
HD Request # 68 | Received 3 records from 2017-11-01 11:29:53 to 2017-11-01 11:31:49 (116.0 seconds) and wrote 1 record for F.US.M6EZ17 | 2017-11-01 11:32:15
HD Request # 68 | Intraday download COMPLETE for F.US.M6EZ17. Completion time: 0s. Unique request ID: 74 | 2017-11-01 11:32:15
Removed historical data download ID 74 | 2017-11-01 11:32:15
Real-time Intraday chart data file updates started for F.US.M6EZ17 | 2017-11-01 11:32:15
Intraday chart data file opened for F.US.M6EZ17 | 2017-11-01 11:32:15
HD Request # 69 | Downloading Intraday chart data for F.US.M6AZ17 to the file F.US.M6AZ17.scid. Service: cme | 2017-11-01 11:32:15
HD Request # 69 | Download start date-time: 2017-11-01 11:31:01.000 | 2017-11-01 11:32:15
HD Request # 69 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 11:32:15
Socket (79) | Creating socket. | 2017-11-01 11:32:15
Socket (79) | Connecting to IP: 8.18.161.135. | 2017-11-01 11:32:15
Socket (78) | Socket gracefully closed by remote side. | 2017-11-01 11:32:15
Socket (78) | Closed. | 2017-11-01 11:32:15
HD Request # 69 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:15
HD Request # 69 | Sending historical data logon request message. | 2017-11-01 11:32:15
HD Request # 69 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:01. Record interval: 0. Symbol: M6AZ17 | 2017-11-01 11:32:15
HD Request # 69 | Decompressing data. | 2017-11-01 11:32:15
Socket (79) | Initiating close of socket by core. | 2017-11-01 11:32:15
Socket (79) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:15
HD Request # 69 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.M6AZ17 | 2017-11-01 11:32:15
HD Request # 69 | Intraday download COMPLETE for F.US.M6AZ17. Completion time: 0s. Unique request ID: 75 | 2017-11-01 11:32:15
Removed historical data download ID 75 | 2017-11-01 11:32:15
Real-time Intraday chart data file updates started for F.US.M6AZ17 | 2017-11-01 11:32:15
Intraday chart data file opened for F.US.M6AZ17 | 2017-11-01 11:32:15
HD Request # 70 | Downloading Intraday chart data for F.US.DSXZ16 to the file F.US.DSXZ16.scid. Service: eurex | 2017-11-01 11:32:15
HD Request # 70 | Download start date-time: 2016-12-16 10:59:59.000 | 2017-11-01 11:32:15
HD Request # 70 | Using server: ds7.sierracharts.com port 10149 | 2017-11-01 11:32:15
Socket (80) | Creating socket. | 2017-11-01 11:32:15
Socket (80) | Connecting to IP: 8.18.161.133. | 2017-11-01 11:32:15
Socket (79) | Socket gracefully closed by remote side. | 2017-11-01 11:32:15
Socket (79) | Closed. | 2017-11-01 11:32:15
HD Request # 70 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:15
HD Request # 70 | Sending historical data logon request message. | 2017-11-01 11:32:15
HD Request # 70 | Requesting Intraday data. Start date-time: 2016-12-16 10:59:59. Record interval: 0. Symbol: FXZ16 | 2017-11-01 11:32:16
HD Request # 70 | Decompressing data. | 2017-11-01 11:32:16
HD Request # 70 | Receiving Intraday data for F.US.DSXZ16 starting at 2016-12-16 10:59:59 | 2017-11-01 11:32:16
Socket (80) | Initiating close of socket by core. | 2017-11-01 11:32:16
Socket (80) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:16
Historical data download thread signaled to stop. | 2017-11-01 11:32:16
HD Request # 70 | Received 1 record from 2016-12-16 10:59:59 to 2016-12-16 10:59:59 (0.0 seconds) and wrote 0 records for F.US.DSXZ16 | 2017-11-01 11:32:16
HD Request # 70 | Intraday download COMPLETE for F.US.DSXZ16. Completion time: 1s. Unique request ID: 77 | 2017-11-01 11:32:16
Removed historical data download ID 77 | 2017-11-01 11:32:16
Real-time Intraday chart data file updates started for F.US.DSXZ16 | 2017-11-01 11:32:16
Intraday chart data file opened for F.US.DSXZ16 | 2017-11-01 11:32:16
HD Request # 71 | Downloading Intraday chart data for F.US.DDZ16 to the file F.US.DDZ16.scid. Service: eurex | 2017-11-01 11:32:16
HD Request # 71 | Download start date-time: 2016-12-16 11:59:55.000 | 2017-11-01 11:32:16
HD Request # 71 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 11:32:16
Socket (81) | Creating socket. | 2017-11-01 11:32:16
Socket (81) | Connecting to IP: 8.18.161.135. | 2017-11-01 11:32:16
Socket (80) | Socket gracefully closed by remote side. | 2017-11-01 11:32:16
Socket (80) | Closed. | 2017-11-01 11:32:16
HD Request # 71 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:16
HD Request # 71 | Sending historical data logon request message. | 2017-11-01 11:32:16
HD Request # 71 | Requesting Intraday data. Start date-time: 2016-12-16 11:59:55. Record interval: 0. Symbol: DYZ16 | 2017-11-01 11:32:16
HD Request # 71 | Decompressing data. | 2017-11-01 11:32:17
HD Request # 71 | Receiving Intraday data for F.US.DDZ16 starting at 2016-12-16 11:59:55 | 2017-11-01 11:32:17
Socket (81) | Initiating close of socket by core. | 2017-11-01 11:32:17
Historical data download thread signaled to stop. | 2017-11-01 11:32:17
Socket (81) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:17
HD Request # 71 | Received 1 record from 2016-12-16 11:59:55 to 2016-12-16 11:59:55 (0.0 seconds) and wrote 0 records for F.US.DDZ16 | 2017-11-01 11:32:17
HD Request # 71 | Intraday download COMPLETE for F.US.DDZ16. Completion time: 0s. Unique request ID: 78 | 2017-11-01 11:32:17
Removed historical data download ID 78 | 2017-11-01 11:32:17
Real-time Intraday chart data file updates started for F.US.DDZ16 | 2017-11-01 11:32:17
Intraday chart data file opened for F.US.DDZ16 | 2017-11-01 11:32:17
HD Request # 72 | Downloading Intraday chart data for F.US.DA6Z17 to the file F.US.DA6Z17.scid. Service: cqg | 2017-11-01 11:32:17
HD Request # 72 | Download start date-time: 2017-11-01 11:31:42.000 | 2017-11-01 11:32:17
HD Request # 72 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:32:17
Socket (82) | Creating socket. | 2017-11-01 11:32:17
Socket (82) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:17
Socket (81) | Socket gracefully closed by remote side. | 2017-11-01 11:32:17
Socket (81) | Closed. | 2017-11-01 11:32:17
HD Request # 72 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:17
HD Request # 72 | Sending historical data logon request message. | 2017-11-01 11:32:17
HD Request # 72 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:42. Record interval: 0. Symbol: F.US.DA6Z17 | 2017-11-01 11:32:17
HD Request # 72 | Decompressing data. | 2017-11-01 11:32:18
HD Request # 72 | Receiving Intraday data for F.US.DA6Z17 starting at 2017-11-01 11:31:42 | 2017-11-01 11:32:18
Socket (82) | Initiating close of socket by core. | 2017-11-01 11:32:18
Historical data download thread signaled to stop. | 2017-11-01 11:32:18
Socket (82) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:18
HD Request # 72 | Received 1 record from 2017-11-01 11:31:42 to 2017-11-01 11:31:42 (0.0 seconds) and wrote 0 records for F.US.DA6Z17 | 2017-11-01 11:32:18
HD Request # 72 | Intraday download COMPLETE for F.US.DA6Z17. Completion time: 2s. Unique request ID: 79 | 2017-11-01 11:32:18
Removed historical data download ID 79 | 2017-11-01 11:32:18
Real-time Intraday chart data file updates started for F.US.DA6Z17 | 2017-11-01 11:32:18
Intraday chart data file opened for F.US.DA6Z17 | 2017-11-01 11:32:18
HD Request # 73 | Downloading Intraday chart data for F.US.CA6Z17 to the file F.US.CA6Z17.scid. Service: cqg | 2017-11-01 11:32:18
HD Request # 73 | Download start date-time: 2017-11-01 11:31:41.000 | 2017-11-01 11:32:18
HD Request # 73 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 11:32:18
Socket (83) | Creating socket. | 2017-11-01 11:32:18
Socket (83) | Connecting to IP: 65.182.172.42. | 2017-11-01 11:32:18
Socket (82) | Socket gracefully closed by remote side. | 2017-11-01 11:32:18
Socket (82) | Closed. | 2017-11-01 11:32:18
HD Request # 73 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:18
HD Request # 73 | Sending historical data logon request message. | 2017-11-01 11:32:18
HD Request # 73 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:41. Record interval: 0. Symbol: F.US.CA6Z17 | 2017-11-01 11:32:18
HD Request # 73 | Decompressing data. | 2017-11-01 11:32:18
HD Request # 73 | Receiving Intraday data for F.US.CA6Z17 starting at 2017-11-01 11:31:41 | 2017-11-01 11:32:18
HD Request # 73 | Timestamp of first Intraday data file record written: 2017-11-01 11:32:02 | 2017-11-01 11:32:18
Socket (83) | Initiating close of socket by core. | 2017-11-01 11:32:18
Socket (83) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:18
HD Request # 73 | Received 16 records from 2017-11-01 11:31:41 to 2017-11-01 11:32:03 (22.0 seconds) and wrote 15 records for F.US.CA6Z17 | 2017-11-01 11:32:18
HD Request # 73 | Intraday download COMPLETE for F.US.CA6Z17. Completion time: 0s. Unique request ID: 80 | 2017-11-01 11:32:18
Removed historical data download ID 80 | 2017-11-01 11:32:18
Real-time Intraday chart data file updates started for F.US.CA6Z17 | 2017-11-01 11:32:18
Intraday chart data file opened for F.US.CA6Z17 | 2017-11-01 11:32:18
HD Request # 74 | Downloading Intraday chart data for F.US.MX6Z17 to the file F.US.MX6Z17.scid. Service: cqg | 2017-11-01 11:32:18
HD Request # 74 | Download start date-time: 2017-11-01 11:31:23.000 | 2017-11-01 11:32:18
HD Request # 74 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 11:32:18
Socket (84) | Creating socket. | 2017-11-01 11:32:18
Socket (84) | Connecting to IP: 192.81.56.146. | 2017-11-01 11:32:18
Socket (83) | Socket gracefully closed by remote side. | 2017-11-01 11:32:19
Socket (83) | Closed. | 2017-11-01 11:32:19
HD Request # 74 | Setting DTC encoding to Binary VLS | 2017-11-01 11:32:19
HD Request # 74 | Sending historical data logon request message. | 2017-11-01 11:32:19
HD Request # 74 | Requesting Intraday data. Start date-time: 2017-11-01 11:31:23. Record interval: 0. Symbol: F.US.MX6Z17 | 2017-11-01 11:32:19
HD Request # 74 | Decompressing data. | 2017-11-01 11:32:19
HD Request # 74 | Receiving Intraday data for F.US.MX6Z17 starting at 2017-11-01 11:31:23 | 2017-11-01 11:32:19
Socket (84) | Initiating close of socket by core. | 2017-11-01 11:32:19
Historical data download thread signaled to stop. | 2017-11-01 11:32:19
Socket (84) | Shutdown started. Waiting for graceful close. | 2017-11-01 11:32:19
HD Request # 74 | Received 5 records from 2017-11-01 11:31:23 to 2017-11-01 11:31:23 (0.0 seconds) and wrote 0 records for F.US.MX6Z17 | 2017-11-01 11:32:19
HD Request # 74 | Intraday download COMPLETE for F.US.MX6Z17. Completion time: 0s. Unique request ID: 81 | 2017-11-01 11:32:19
Removed historical data download ID 81 | 2017-11-01 11:32:19
Real-time Intraday chart data file updates started for F.US.MX6Z17 | 2017-11-01 11:32:19
Intraday chart data file opened for F.US.MX6Z17 | 2017-11-01 11:32:19
Socket (84) | Socket gracefully closed by remote side. | 2017-11-01 11:32:19
Socket (84) | Closed. | 2017-11-01 11:32:19
Opened cached Intraday file: C:\SierraChart\Data\F.US.EPZ17.scid | 2017-11-01 11:32:22
Opened cached Intraday file: C:\SierraChart\Data\F.US.MX6Z17.scid | 2017-11-01 11:32:22
Opened cached Intraday file: C:\SierraChart\Data\F.US.NE6Z17.scid | 2017-11-01 11:32:22
Opened cached Intraday file: C:\SierraChart\Data\F.US.DGZ17.scid | 2017-11-01 11:32:22
Opened cached Intraday file: C:\SierraChart\Data\F.US.FGBXZ17.scid | 2017-11-01 11:32:22
Opened cached Intraday file: C:\SierraChart\Data\F.US.FOATZ17.scid | 2017-11-01 11:32:22
Opened cached Intraday file: C:\SierraChart\Data\F.US.CA6Z17.scid | 2017-11-01 11:32:32
Opened cached Intraday file: C:\SierraChart\Data\F.US.BP6Z17.scid | 2017-11-01 11:32:32
Opened cached Intraday file: C:\SierraChart\Data\F.US.DLZ17.scid | 2017-11-01 11:32:32
Opened cached Intraday file: C:\SierraChart\Data\F.US.TYAZ17.scid | 2017-11-01 11:32:42
Opened cached Intraday file: C:\SierraChart\Data\F.US.DA6Z17.scid | 2017-11-01 11:32:52
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6AZ17.scid | 2017-11-01 11:32:52
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6EZ17.scid | 2017-11-01 11:33:02
Opened cached Intraday file: C:\SierraChart\Data\F.US.MJYZ17.scid | 2017-11-01 11:34:23
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6BZ17.scid | 2017-11-01 11:35:34
Opened cached Intraday file: C:\SierraChart\Data\F.US.GMCDZ17.scid | 2017-11-01 11:37:56
CQG FIX socket (55) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2017-11-01 12:29:00
CQG FIX socket (55) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 12:29:00 *
CQG FIX socket (55) | Socket gracefully closed by remote side. | 2017-11-01 12:29:00
CQG FIX socket (55) | Received socket Close event. | 2017-11-01 12:29:00
CQG FIX socket (55) | Initiating close of socket by core. | 2017-11-01 12:29:00
CQG FIX: Socket connection was closed without any logout messages sent or received. | 2017-11-01 12:29:00
CQG FIX socket (55) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 12:29:00
CQG FIX socket (55) | Closed. | 2017-11-01 12:29:00
CQG FIX: Disconnected. | 2017-11-01 12:29:00
Connection to the external service has been lost. | 2017-11-01 12:29:00
CQG FIX Trading | Sending Web API Logoff message. | 2017-11-01 12:29:01
CQG WebSocket socket (56) | Adding bytes from final send buffer from buffered socket: 107 | 2017-11-01 12:29:01
CQG WebSocket socket (56) | Initiating close of socket by core. | 2017-11-01 12:29:01
CQG WebSocket | WebSocket closed. | 2017-11-01 12:29:01
CQG FIX Trading | WebSocket closed. | 2017-11-01 12:29:01
CQG WebSocket socket (56) | Write in progress. Shutdown being delayed. | 2017-11-01 12:29:01
CQG FIX Trading | Disconnected. | 2017-11-01 12:29:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 12:29:01
CQG WebSocket socket (56) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 12:29:01 *
CQG WebSocket socket (56) | Sending bytes from final send buffer: 107 | 2017-11-01 12:29:01
CQG WebSocket socket (56) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2017-11-01 12:29:01
CQG WebSocket socket (56) | Write has failed. Shutdown being performed. | 2017-11-01 12:29:01
CQG WebSocket socket (56) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:01
CQG WebSocket socket (56) | Socket gracefully closed by remote side. | 2017-11-01 12:29:01
CQG WebSocket socket (56) | Closed. | 2017-11-01 12:29:01
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-01 12:29:03
Error getting address info for fixapi.cqgtrader.com. Windows error code 11001: No such host is known. | 2017-11-01 12:29:16 *
CQG FIX socket (104) | Initiating close of socket by core. | 2017-11-01 12:29:16
CQG FIX: Socket connection was closed without any logout messages sent or received. | 2017-11-01 12:29:16
CQG FIX: Disconnected. | 2017-11-01 12:29:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-01 12:29:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 12:29:16
CQG FIX Trading | Disconnected. | 2017-11-01 12:29:16
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 12:29:16
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-01 12:29:19
Error getting address info for fixapi.cqgtrader.com. Windows error code 11001: No such host is known. | 2017-11-01 12:29:30 *
CQG FIX socket (105) | Initiating close of socket by core. | 2017-11-01 12:29:30
CQG FIX: Socket connection was closed without any logout messages sent or received. | 2017-11-01 12:29:30
CQG FIX: Disconnected. | 2017-11-01 12:29:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-11-01 12:29:30
Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 12:29:30
CQG FIX Trading | Disconnected. | 2017-11-01 12:29:30
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 12:29:30
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-01 12:29:34
CQG FIX socket (106) | Creating socket. Using TLS 1.2. | 2017-11-01 12:29:34
CQG FIX socket (106) | Connecting to IP: 208.48.16.214. | 2017-11-01 12:29:34
CQG FIX: Sending the Logon message. | 2017-11-01 12:29:34
CQG FIX Trading | Connected to trading server. | 2017-11-01 12:29:35
CQG FIX Trading | Connecting to server api.cqg.com | 2017-11-01 12:29:35
CQG WebSocket | Connecting to WebSocket server. | 2017-11-01 12:29:35
CQG FIX | FCM name: AMP | 2017-11-01 12:29:35
CQG WebSocket socket (107) | Creating socket. Using TLS 1.2. | 2017-11-01 12:29:35
CQG WebSocket socket (107) | Connecting to IP: 195.166.124.165. | 2017-11-01 12:29:35
CQG WebSocket | Opening WebSocket. | 2017-11-01 12:29:35
CQG WebSocket | Sending WebSocket handshake. | 2017-11-01 12:29:35
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-11-01 12:29:35
CQG WebSocket | Web socket state is now open. | 2017-11-01 12:29:35
CQG FIX Trading | WebSocket connected. | 2017-11-01 12:29:35
CQG FIX Trading | Sending market data logon message. | 2017-11-01 12:29:35
CQG FIX Trading | Logon successful. Session Token = MiCrcE7KCwwPLLKNeD+iDJhZMk8/u48B2pG/44rx/Vw2/uU5xfjOIfhEYXAMvoYMVKzNa2N8BBl | 2017-11-01 12:29:35
CQG FIX Trading | Connected to data and trading server. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.DLM17. ID: 1 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.DLM17. ID: 593706 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.DLM17. ID: 1 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6M17. ID: 2 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.CA6M17. ID: 593707 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.CA6M17. ID: 2 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6M17. ID: 3 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.BP6M17. ID: 593708 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.BP6M17. ID: 3 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6M17. ID: 4 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.EU6M17. ID: 593709 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.EU6M17. ID: 4 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6Z17. ID: 5 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.CA6Z17. ID: 593710 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.CA6Z17. ID: 5 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.DBZ17. ID: 6 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.DBZ17. ID: 593711 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.DBZ17. ID: 6 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.DBZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
Delaying start of download for F.US.DBZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.CA6Z7. Search Symbol: F.US.CA6Z17. Request ID: 593710. Contract ID: 1. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.CA6Z17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.DBZ7. Search Symbol: F.US.DBZ17. Request ID: 593711. Contract ID: 2. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.DBZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 12:29:35
Symbol Error - F.US.DLM17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6Z17. ID: 7 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.BP6Z17. ID: 593712 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.BP6Z17. ID: 7 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.BP6Z17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.TYAZ17. ID: 8 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.TYAZ17. ID: 593713 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.TYAZ17. ID: 8 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.TYAZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DBZ17.2017-11-01.depth | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6Z17. ID: 9 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.EU6Z17. ID: 593714 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.EU6Z17. ID: 9 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.EU6Z17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.BP6Z7. Search Symbol: F.US.BP6Z17. Request ID: 593712. Contract ID: 3. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.BP6Z17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.USAZ17. ID: 10 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.USAZ17. ID: 593715 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.USAZ17. ID: 10 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.USAZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
HD Request # 75 | Downloading Intraday chart data for F.US.DBZ17 to the file F.US.DBZ17.scid. Service: cqg | 2017-11-01 12:29:35
HD Request # 75 | Download start date-time: 2017-11-01 12:28:41.000 | 2017-11-01 12:29:35
HD Request # 75 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.TYAZ7. Search Symbol: F.US.TYAZ17. Request ID: 593713. Contract ID: 4. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.TYAZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.EU6Z7. Search Symbol: F.US.EU6Z17. Request ID: 593714. Contract ID: 5. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.EU6Z17 | 2017-11-01 12:29:35
Socket (108) | Creating socket. | 2017-11-01 12:29:35
Socket (108) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.USAZ7. Search Symbol: F.US.USAZ17. Request ID: 593715. Contract ID: 6. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.USAZ17 | 2017-11-01 12:29:35
Symbol Error - F.US.CA6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 12:29:35
Symbol Error - F.US.BP6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 12:29:35
Symbol Error - F.US.EU6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.DLZ17. ID: 11 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.DLZ17. ID: 593716 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.DLZ17. ID: 11 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.DLZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.DGZ17. ID: 12 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.DGZ17. ID: 593717 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.DGZ17. ID: 12 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.DGZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.DLZ7. Search Symbol: F.US.DLZ17. Request ID: 593716. Contract ID: 7. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.DLZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.FGBXZ17. ID: 13 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.FGBXZ17. ID: 593718 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.FGBXZ17. ID: 13 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.FGBXZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.FBTPZ17. ID: 14 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.FBTPZ17. ID: 593719 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.FBTPZ17. ID: 14 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.FBTPZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.DGZ7. Search Symbol: F.US.DGZ17. Request ID: 593717. Contract ID: 8. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.DGZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ17. ID: 15 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ17. ID: 593720 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ17. ID: 15 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.DSXZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.FGBXZ7. Search Symbol: F.US.FGBXZ17. Request ID: 593718. Contract ID: 9. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.FGBXZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.EPZ17. ID: 16 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.EPZ17. ID: 593721 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.EPZ17. ID: 16 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.EPZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.FBTPZ7. Search Symbol: F.US.FBTPZ17. Request ID: 593719. Contract ID: 10. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.FBTPZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXZ7. Search Symbol: F.US.DSXZ17. Request ID: 593720. Contract ID: 11. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.DSXZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.FOATZ17. ID: 17 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.FOATZ17. ID: 593722 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.FOATZ17. ID: 17 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.FOATZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.EPZ7. Search Symbol: F.US.EPZ17. Request ID: 593721. Contract ID: 12. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.EPZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.FDXMZ17. ID: 18 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.FDXMZ17. ID: 593723 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.FDXMZ17. ID: 18 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.FDXMZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.FOATZ7. Search Symbol: F.US.FOATZ17. Request ID: 593722. Contract ID: 13. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.FOATZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.GMCDZ17. ID: 19 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.GMCDZ17. ID: 593724 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.GMCDZ17. ID: 19 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.GMCDZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.M6BZ17. ID: 20 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.M6BZ17. ID: 593725 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.M6BZ17. ID: 20 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.M6BZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.FDXMZ7. Search Symbol: F.US.FDXMZ17. Request ID: 593723. Contract ID: 14. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.FDXMZ17 | 2017-11-01 12:29:35
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.EPZ17.2017-11-01.depth | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.M6EZ17. ID: 21 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.M6EZ17. ID: 593726 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.M6EZ17. ID: 21 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.M6EZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.M6AZ17. ID: 22 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.M6AZ17. ID: 593727 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.M6AZ17. ID: 22 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.M6AZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.GMCDZ7. Search Symbol: F.US.GMCDZ17. Request ID: 593724. Contract ID: 15. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.GMCDZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6BZ7. Search Symbol: F.US.M6BZ17. Request ID: 593725. Contract ID: 16. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.M6BZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.MJYZ17. ID: 23 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.MJYZ17. ID: 593728 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.MJYZ17. ID: 23 | 2017-11-01 12:29:35
CQG FIX Trading | Using primary service for historical data for F.US.MJYZ17 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.MJYZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
Delaying start of download for F.US.MJYZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ17. ID: 24 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ17. ID: 593729 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.DDZ17. ID: 24 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.DDZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6EZ7. Search Symbol: F.US.M6EZ17. Request ID: 593726. Contract ID: 17. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.M6EZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6AZ7. Search Symbol: F.US.M6AZ17. Request ID: 593727. Contract ID: 18. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.M6AZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.JY6Z17. ID: 25 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.JY6Z17. ID: 593730 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.JY6Z17. ID: 25 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.JY6Z17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.MJYZ7. Search Symbol: F.US.MJYZ17. Request ID: 593728. Contract ID: 19. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.MJYZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.DDZ7. Search Symbol: F.US.DDZ17. Request ID: 593729. Contract ID: 20. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.DDZ17 | 2017-11-01 12:29:35
HD Request # 75 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:35
HD Request # 75 | Sending historical data logon request message. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6M17. ID: 26 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.MX6M17. ID: 593731 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.MX6M17. ID: 26 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.MX6M17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.NE6Z17. ID: 27 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.NE6Z17. ID: 593732 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.NE6Z17. ID: 27 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.NE6Z17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.JY6Z7. Search Symbol: F.US.JY6Z17. Request ID: 593730. Contract ID: 21. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.JY6Z17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.CLEZ17. ID: 28 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.CLEZ17. ID: 593733 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.CLEZ17. ID: 28 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.CLEZ17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.FVSX17. ID: 29 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.FVSX17. ID: 593734 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.FVSX17. ID: 29 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.SWZ17. ID: 30 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.SWZ17. ID: 593735 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.SWZ17. ID: 30 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.ENQZ17. ID: 31 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.ENQZ17. ID: 593736 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.ENQZ17. ID: 31 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.NKDZ17. ID: 32 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.NKDZ17. ID: 593737 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.NKDZ17. ID: 32 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.YMZ17. ID: 33 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.YMZ17. ID: 593738 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.YMZ17. ID: 33 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.NE6Z7. Search Symbol: F.US.NE6Z17. Request ID: 593732. Contract ID: 22. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.NE6Z17 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.DA6Z17. ID: 34 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.DA6Z17. ID: 593739 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.DA6Z17. ID: 34 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.DA6Z17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6Z17. ID: 35 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.MX6Z17. ID: 593740 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.MX6Z17. ID: 35 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.MX6Z17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEZ7. Search Symbol: F.US.CLEZ17. Request ID: 593733. Contract ID: 23. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.CLEZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVSX7. Search Symbol: F.US.FVSX17. Request ID: 593734. Contract ID: 24. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.FVSX17 | 2017-11-01 12:29:35
Requesting market depth updates for: F.US.DDZ17 if supported. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data including full depth for F.US.DDZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.SWZ7. Search Symbol: F.US.SWZ17. Request ID: 593735. Contract ID: 25. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.SWZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.ENQZ7. Search Symbol: F.US.ENQZ17. Request ID: 593736. Contract ID: 26. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.ENQZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.NKDZ7. Search Symbol: F.US.NKDZ17. Request ID: 593737. Contract ID: 27. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.NKDZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.YMZ7. Search Symbol: F.US.YMZ17. Request ID: 593738. Contract ID: 28. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.YMZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.DA6Z7. Search Symbol: F.US.DA6Z17. Request ID: 593739. Contract ID: 29. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.DA6Z17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.MX6Z7. Search Symbol: F.US.MX6Z17. Request ID: 593740. Contract ID: 30. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.MX6Z17 | 2017-11-01 12:29:35
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DDZ17.2017-11-01.depth | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ16. ID: 36 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ16. ID: 593741 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ16. ID: 36 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.DSXZ16 is set to download 'Pending'. | 2017-11-01 12:29:35
Symbol Error - F.US.MX6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ16. ID: 37 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ16. ID: 593742 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.DDZ16. ID: 37 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.DDZ16 is set to download 'Pending'. | 2017-11-01 12:29:35
Requesting market depth updates for: F.US.DBZ17 if supported. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data including full depth for F.US.DBZ17 | 2017-11-01 12:29:35
Requesting market depth updates for: F.US.DSXZ17 if supported. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data including full depth for F.US.DSXZ17 | 2017-11-01 12:29:35
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DSXZ17.2017-11-01.depth | 2017-11-01 12:29:35
Symbol Error - F.US.DSXZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 12:29:35
Symbol Error - F.US.DDZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 12:29:35
HD Request # 75 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:41. Record interval: 0. Symbol: F.US.DBZ17 | 2017-11-01 12:29:35
Intraday data recording state for symbol F.US.CA6Z17 is set to download 'Pending'. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.EADZ17. ID: 38 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.EADZ17. ID: 593743 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.EADZ17. ID: 38 | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.ECDZ17. ID: 39 | 2017-11-01 12:29:35
CQG FIX Trading | Sending symbol resolution request for F.US.ECDZ17. ID: 593744 | 2017-11-01 12:29:35
CQG FIX Trading | Requesting security definition data for: F.US.ECDZ17. ID: 39 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.EADZ7. Search Symbol: F.US.EADZ17. Request ID: 593743. Contract ID: 31. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.EADZ17 | 2017-11-01 12:29:35
CQG FIX Trading | Received symbol resolution report for symbol F.US.ECDZ7. Search Symbol: F.US.ECDZ17. Request ID: 593744. Contract ID: 32. | 2017-11-01 12:29:35
CQG FIX Trading | Requesting market data for F.US.ECDZ17 | 2017-11-01 12:29:35
HD Request # 75 | Decompressing data. | 2017-11-01 12:29:35
HD Request # 75 | Receiving Intraday data for F.US.DBZ17 starting at 2017-11-01 12:28:43 | 2017-11-01 12:29:35
HD Request # 75 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:43 | 2017-11-01 12:29:35
Socket (108) | Initiating close of socket by core. | 2017-11-01 12:29:35
Socket (108) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:35
Historical data download thread signaled to stop. | 2017-11-01 12:29:35
HD Request # 75 | Received 50 records from 2017-11-01 12:28:43 to 2017-11-01 12:29:37 (54.0 seconds) and wrote 50 records for F.US.DBZ17 | 2017-11-01 12:29:35
HD Request # 75 | Intraday download COMPLETE for F.US.DBZ17. Completion time: 0s. Unique request ID: 82 | 2017-11-01 12:29:35
Removed historical data download ID 82 | 2017-11-01 12:29:35
Real-time Intraday chart data file updates started for F.US.DBZ17 | 2017-11-01 12:29:35
Intraday chart data file opened for F.US.DBZ17 | 2017-11-01 12:29:35
Delaying start of download for F.US.BP6Z17 | 2017-11-01 12:29:35
Socket (108) | Socket gracefully closed by remote side. | 2017-11-01 12:29:35
Socket (108) | Closed. | 2017-11-01 12:29:35
CQG FIX Trading | Starting real-time market data updates for: F.US.TUAZ17. ID: 40 | 2017-11-01 12:29:36
CQG FIX Trading | Sending symbol resolution request for F.US.TUAZ17. ID: 593745 | 2017-11-01 12:29:36
CQG FIX Trading | Requesting security definition data for: F.US.TUAZ17. ID: 40 | 2017-11-01 12:29:36
CQG FIX Trading | Starting real-time market data updates for: F.US.FVAZ17. ID: 41 | 2017-11-01 12:29:36
CQG FIX Trading | Sending symbol resolution request for F.US.FVAZ17. ID: 593746 | 2017-11-01 12:29:36
CQG FIX Trading | Requesting security definition data for: F.US.FVAZ17. ID: 41 | 2017-11-01 12:29:36
CQG FIX Trading | Received symbol resolution report for symbol F.US.TUAZ7. Search Symbol: F.US.TUAZ17. Request ID: 593745. Contract ID: 33. | 2017-11-01 12:29:36
CQG FIX Trading | Requesting market data for F.US.TUAZ17 | 2017-11-01 12:29:36
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVAZ7. Search Symbol: F.US.FVAZ17. Request ID: 593746. Contract ID: 34. | 2017-11-01 12:29:36
CQG FIX Trading | Requesting market data for F.US.FVAZ17 | 2017-11-01 12:29:36
Delaying start of download for F.US.MJYZ17 | 2017-11-01 12:29:36
Opened cached Intraday file: C:\SierraChart\Data\F.US.DBZ17.scid | 2017-11-01 12:29:39
HD Request # 76 | Downloading Intraday chart data for F.US.MJYZ17 to the file F.US.MJYZ17.scid. Service: cqg | 2017-11-01 12:29:39
HD Request # 76 | Download start date-time: 2017-11-01 12:28:37.000 | 2017-11-01 12:29:39
HD Request # 76 | Requesting historical Tick data. | 2017-11-01 12:29:39
HD Request # 77 | Downloading Intraday chart data for F.US.BP6Z17 to the file F.US.BP6Z17.scid. Service: cqg | 2017-11-01 12:29:39
HD Request # 77 | Download start date-time: 2017-11-01 12:28:32.000 | 2017-11-01 12:29:39
HD Request # 77 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 12:29:39
Socket (109) | Creating socket. | 2017-11-01 12:29:39
Socket (109) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:39
HD Request # 76 | Receiving Intraday data for F.US.MJYZ17 starting at 2017-11-01 12:28:37 | 2017-11-01 12:29:40
HD Request # 76 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:50 | 2017-11-01 12:29:40
HD Request # 76 | Received 5 records from 2017-11-01 12:28:37 to 2017-11-01 12:28:52 (15.0 seconds) and wrote 3 records for F.US.MJYZ17 | 2017-11-01 12:29:40
HD Request # 76 | Intraday download COMPLETE for F.US.MJYZ17. Completion time: 0s. Unique request ID: 99 | 2017-11-01 12:29:40
Removed historical data download ID 99 | 2017-11-01 12:29:40
Real-time Intraday chart data file updates started for F.US.MJYZ17 | 2017-11-01 12:29:40
Intraday chart data file opened for F.US.MJYZ17 | 2017-11-01 12:29:40
HD Request # 77 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:40
HD Request # 77 | Sending historical data logon request message. | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.BP6Z17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.BP6Z17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.CLEZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.CLEZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.DGZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.DGZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.DLZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.DLZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.EPZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.EPZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.EU6Z17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.EU6Z17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.FBTPZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.FBTPZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.FDXMZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.FDXMZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.FGBXZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.FGBXZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.FOATZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.FOATZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.GMCDZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.GMCDZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.JY6Z17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.JY6Z17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.M6AZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.M6AZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.M6BZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.M6BZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.M6EZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.M6EZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.MJYZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.MJYZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.MX6M17 if supported. | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.NE6Z17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.NE6Z17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.TYAZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.TYAZ17 | 2017-11-01 12:29:40
Requesting market depth updates for: F.US.USAZ17 if supported. | 2017-11-01 12:29:40
CQG FIX Trading | Requesting market data including full depth for F.US.USAZ17 | 2017-11-01 12:29:40
HD Request # 77 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:32. Record interval: 0. Symbol: F.US.BP6Z17 | 2017-11-01 12:29:40
HD Request # 77 | Decompressing data. | 2017-11-01 12:29:40
HD Request # 77 | Receiving Intraday data for F.US.BP6Z17 starting at 2017-11-01 12:28:48 | 2017-11-01 12:29:40
HD Request # 77 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:48 | 2017-11-01 12:29:40
Socket (109) | Initiating close of socket by core. | 2017-11-01 12:29:40
Socket (109) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:40
Historical data download thread signaled to stop. | 2017-11-01 12:29:40
HD Request # 77 | Received 68 records from 2017-11-01 12:28:48 to 2017-11-01 12:29:45 (57.0 seconds) and wrote 68 records for F.US.BP6Z17 | 2017-11-01 12:29:40
Added 19 Time and Sales records to Intraday data file for F.US.BP6Z17 after download. | 2017-11-01 12:29:40
HD Request # 77 | Intraday download COMPLETE for F.US.BP6Z17. Completion time: 1s. Unique request ID: 83 | 2017-11-01 12:29:40
Removed historical data download ID 83 | 2017-11-01 12:29:40
Real-time Intraday chart data file updates started for F.US.BP6Z17 | 2017-11-01 12:29:40
Intraday chart data file opened for F.US.BP6Z17 | 2017-11-01 12:29:40
HD Request # 78 | Downloading Intraday chart data for F.US.TYAZ17 to the file F.US.TYAZ17.scid. Service: cqg | 2017-11-01 12:29:40
HD Request # 78 | Download start date-time: 2017-11-01 12:28:40.000 | 2017-11-01 12:29:40
HD Request # 78 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 12:29:40
Socket (110) | Creating socket. | 2017-11-01 12:29:40
Socket (110) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:40
Socket (109) | Socket gracefully closed by remote side. | 2017-11-01 12:29:40
Socket (109) | Closed. | 2017-11-01 12:29:40
HD Request # 78 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:40
HD Request # 78 | Sending historical data logon request message. | 2017-11-01 12:29:40
HD Request # 78 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:40. Record interval: 0. Symbol: F.US.TYAZ17 | 2017-11-01 12:29:40
HD Request # 78 | Decompressing data. | 2017-11-01 12:29:40
HD Request # 78 | Receiving Intraday data for F.US.TYAZ17 starting at 2017-11-01 12:28:40 | 2017-11-01 12:29:40
HD Request # 78 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:42 | 2017-11-01 12:29:40
Socket (110) | Initiating close of socket by core. | 2017-11-01 12:29:40
Socket (110) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:40
HD Request # 78 | Received 284 records from 2017-11-01 12:28:40 to 2017-11-01 12:29:46 (66.0 seconds) and wrote 272 records for F.US.TYAZ17 | 2017-11-01 12:29:40
HD Request # 78 | Intraday download COMPLETE for F.US.TYAZ17. Completion time: 0s. Unique request ID: 84 | 2017-11-01 12:29:40
Removed historical data download ID 84 | 2017-11-01 12:29:40
Real-time Intraday chart data file updates started for F.US.TYAZ17 | 2017-11-01 12:29:40
Intraday chart data file opened for F.US.TYAZ17 | 2017-11-01 12:29:40
HD Request # 79 | Downloading Intraday chart data for F.US.EU6Z17 to the file F.US.EU6Z17.scid. Service: cqg | 2017-11-01 12:29:40
HD Request # 79 | Download start date-time: 2017-11-01 12:28:41.000 | 2017-11-01 12:29:40
HD Request # 79 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 12:29:40
Socket (111) | Creating socket. | 2017-11-01 12:29:40
Socket (111) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:40
Socket (110) | Socket gracefully closed by remote side. | 2017-11-01 12:29:40
Socket (110) | Closed. | 2017-11-01 12:29:40
HD Request # 79 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:40
HD Request # 79 | Sending historical data logon request message. | 2017-11-01 12:29:40
HD Request # 79 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:41. Record interval: 0. Symbol: F.US.EU6Z17 | 2017-11-01 12:29:41
HD Request # 79 | Decompressing data. | 2017-11-01 12:29:41
HD Request # 79 | Receiving Intraday data for F.US.EU6Z17 starting at 2017-11-01 12:28:41 | 2017-11-01 12:29:41
HD Request # 79 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:42 | 2017-11-01 12:29:41
Socket (111) | Initiating close of socket by core. | 2017-11-01 12:29:41
Socket (111) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:41
Historical data download thread signaled to stop. | 2017-11-01 12:29:41
HD Request # 79 | Received 182 records from 2017-11-01 12:28:41 to 2017-11-01 12:29:47 (66.0 seconds) and wrote 178 records for F.US.EU6Z17 | 2017-11-01 12:29:41
HD Request # 79 | Intraday download COMPLETE for F.US.EU6Z17. Completion time: 1s. Unique request ID: 85 | 2017-11-01 12:29:41
Removed historical data download ID 85 | 2017-11-01 12:29:41
Real-time Intraday chart data file updates started for F.US.EU6Z17 | 2017-11-01 12:29:41
Intraday chart data file opened for F.US.EU6Z17 | 2017-11-01 12:29:41
HD Request # 80 | Downloading Intraday chart data for F.US.USAZ17 to the file F.US.USAZ17.scid. Service: cqg | 2017-11-01 12:29:41
HD Request # 80 | Download start date-time: 2017-11-01 12:28:34.000 | 2017-11-01 12:29:41
HD Request # 80 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 12:29:41
Socket (112) | Creating socket. | 2017-11-01 12:29:41
Socket (112) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:41
Socket (111) | Socket gracefully closed by remote side. | 2017-11-01 12:29:41
Socket (111) | Closed. | 2017-11-01 12:29:41
HD Request # 80 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:41
HD Request # 80 | Sending historical data logon request message. | 2017-11-01 12:29:41
HD Request # 80 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:34. Record interval: 0. Symbol: F.US.USAZ17 | 2017-11-01 12:29:41
HD Request # 80 | Decompressing data. | 2017-11-01 12:29:41
HD Request # 80 | Receiving Intraday data for F.US.USAZ17 starting at 2017-11-01 12:28:34 | 2017-11-01 12:29:41
HD Request # 80 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:41 | 2017-11-01 12:29:41
Socket (112) | Initiating close of socket by core. | 2017-11-01 12:29:41
Socket (112) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:41
HD Request # 80 | Received 123 records from 2017-11-01 12:28:34 to 2017-11-01 12:29:35 (61.0 seconds) and wrote 122 records for F.US.USAZ17 | 2017-11-01 12:29:41
HD Request # 80 | Intraday download COMPLETE for F.US.USAZ17. Completion time: 0s. Unique request ID: 86 | 2017-11-01 12:29:41
Removed historical data download ID 86 | 2017-11-01 12:29:41
Real-time Intraday chart data file updates started for F.US.USAZ17 | 2017-11-01 12:29:41
Intraday chart data file opened for F.US.USAZ17 | 2017-11-01 12:29:41
HD Request # 81 | Downloading Intraday chart data for F.US.DLZ17 to the file F.US.DLZ17.scid. Service: cqg | 2017-11-01 12:29:41
HD Request # 81 | Download start date-time: 2017-11-01 12:28:25.000 | 2017-11-01 12:29:41
HD Request # 81 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 12:29:41
Socket (113) | Creating socket. | 2017-11-01 12:29:41
Socket (113) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:41
Socket (112) | Socket gracefully closed by remote side. | 2017-11-01 12:29:41
Socket (112) | Closed. | 2017-11-01 12:29:41
HD Request # 81 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:42
HD Request # 81 | Sending historical data logon request message. | 2017-11-01 12:29:42
HD Request # 81 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:25. Record interval: 0. Symbol: F.US.DLZ17 | 2017-11-01 12:29:42
HD Request # 81 | Decompressing data. | 2017-11-01 12:29:42
HD Request # 81 | Receiving Intraday data for F.US.DLZ17 starting at 2017-11-01 12:28:25 | 2017-11-01 12:29:42
HD Request # 81 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:26 | 2017-11-01 12:29:42
Socket (113) | Initiating close of socket by core. | 2017-11-01 12:29:42
Socket (113) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:42
Historical data download thread signaled to stop. | 2017-11-01 12:29:42
HD Request # 81 | Received 10 records from 2017-11-01 12:28:25 to 2017-11-01 12:29:36 (71.0 seconds) and wrote 8 records for F.US.DLZ17 | 2017-11-01 12:29:42
HD Request # 81 | Intraday download COMPLETE for F.US.DLZ17. Completion time: 0s. Unique request ID: 87 | 2017-11-01 12:29:42
Removed historical data download ID 87 | 2017-11-01 12:29:42
Real-time Intraday chart data file updates started for F.US.DLZ17 | 2017-11-01 12:29:42
Intraday chart data file opened for F.US.DLZ17 | 2017-11-01 12:29:42
HD Request # 82 | Downloading Intraday chart data for F.US.DGZ17 to the file F.US.DGZ17.scid. Service: cqg | 2017-11-01 12:29:42
HD Request # 82 | Download start date-time: 2017-11-01 12:28:26.000 | 2017-11-01 12:29:42
HD Request # 82 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 12:29:42
Socket (114) | Creating socket. | 2017-11-01 12:29:42
Socket (114) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:42
Socket (113) | Socket gracefully closed by remote side. | 2017-11-01 12:29:42
Socket (113) | Closed. | 2017-11-01 12:29:42
HD Request # 82 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:42
HD Request # 82 | Sending historical data logon request message. | 2017-11-01 12:29:42
HD Request # 82 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:26. Record interval: 0. Symbol: F.US.DGZ17 | 2017-11-01 12:29:42
HD Request # 82 | Decompressing data. | 2017-11-01 12:29:42
HD Request # 82 | Receiving Intraday data for F.US.DGZ17 starting at 2017-11-01 12:28:26 | 2017-11-01 12:29:42
HD Request # 82 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:26 | 2017-11-01 12:29:42
Socket (114) | Initiating close of socket by core. | 2017-11-01 12:29:42
Socket (114) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:42
HD Request # 82 | Received 10 records from 2017-11-01 12:28:26 to 2017-11-01 12:29:31 (65.0 seconds) and wrote 9 records for F.US.DGZ17 | 2017-11-01 12:29:42
HD Request # 82 | Intraday download COMPLETE for F.US.DGZ17. Completion time: 0s. Unique request ID: 88 | 2017-11-01 12:29:42
Removed historical data download ID 88 | 2017-11-01 12:29:42
Real-time Intraday chart data file updates started for F.US.DGZ17 | 2017-11-01 12:29:42
Intraday chart data file opened for F.US.DGZ17 | 2017-11-01 12:29:42
HD Request # 83 | Downloading Intraday chart data for F.US.FGBXZ17 to the file F.US.FGBXZ17.scid. Service: cqg | 2017-11-01 12:29:42
HD Request # 83 | Download start date-time: 2017-11-01 12:28:41.000 | 2017-11-01 12:29:42
HD Request # 83 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 12:29:42
Socket (115) | Creating socket. | 2017-11-01 12:29:42
Socket (115) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:42
Socket (114) | Socket gracefully closed by remote side. | 2017-11-01 12:29:42
Socket (114) | Closed. | 2017-11-01 12:29:42
HD Request # 83 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:42
HD Request # 83 | Sending historical data logon request message. | 2017-11-01 12:29:42
HD Request # 83 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:41. Record interval: 0. Symbol: F.US.FGBXZ17 | 2017-11-01 12:29:43
HD Request # 83 | Decompressing data. | 2017-11-01 12:29:43
HD Request # 83 | Receiving Intraday data for F.US.FGBXZ17 starting at 2017-11-01 12:28:41 | 2017-11-01 12:29:43
HD Request # 83 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:42 | 2017-11-01 12:29:43
Socket (115) | Initiating close of socket by core. | 2017-11-01 12:29:43
Socket (115) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:43
Historical data download thread signaled to stop. | 2017-11-01 12:29:43
HD Request # 83 | Received 24 records from 2017-11-01 12:28:41 to 2017-11-01 12:29:44 (63.0 seconds) and wrote 23 records for F.US.FGBXZ17 | 2017-11-01 12:29:43
HD Request # 83 | Intraday download COMPLETE for F.US.FGBXZ17. Completion time: 0s. Unique request ID: 89 | 2017-11-01 12:29:43
Removed historical data download ID 89 | 2017-11-01 12:29:43
Real-time Intraday chart data file updates started for F.US.FGBXZ17 | 2017-11-01 12:29:43
Intraday chart data file opened for F.US.FGBXZ17 | 2017-11-01 12:29:43
HD Request # 84 | Downloading Intraday chart data for F.US.FBTPZ17 to the file F.US.FBTPZ17.scid. Service: eurex | 2017-11-01 12:29:43
HD Request # 84 | Download start date-time: 2017-11-01 12:28:35.000 | 2017-11-01 12:29:43
HD Request # 84 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 12:29:43
Socket (116) | Creating socket. | 2017-11-01 12:29:43
Socket (116) | Connecting to IP: 8.18.161.133. | 2017-11-01 12:29:43
Socket (115) | Socket gracefully closed by remote side. | 2017-11-01 12:29:43
Socket (115) | Closed. | 2017-11-01 12:29:43
HD Request # 84 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:43
HD Request # 84 | Sending historical data logon request message. | 2017-11-01 12:29:43
HD Request # 84 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:35. Record interval: 0. Symbol: IIZ17 | 2017-11-01 12:29:43
HD Request # 84 | Decompressing data. | 2017-11-01 12:29:43
Socket (116) | Initiating close of socket by core. | 2017-11-01 12:29:43
Socket (116) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:43
HD Request # 84 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FBTPZ17 | 2017-11-01 12:29:43
HD Request # 84 | Intraday download COMPLETE for F.US.FBTPZ17. Completion time: 1s. Unique request ID: 90 | 2017-11-01 12:29:43
Removed historical data download ID 90 | 2017-11-01 12:29:43
Real-time Intraday chart data file updates started for F.US.FBTPZ17 | 2017-11-01 12:29:43
Intraday chart data file opened for F.US.FBTPZ17 | 2017-11-01 12:29:43
HD Request # 85 | Downloading Intraday chart data for F.US.DSXZ17 to the file F.US.DSXZ17.scid. Service: cqg | 2017-11-01 12:29:43
HD Request # 85 | Download start date-time: 2017-11-01 12:28:39.000 | 2017-11-01 12:29:43
HD Request # 85 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 12:29:43
Socket (117) | Creating socket. | 2017-11-01 12:29:43
Socket (117) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:43
Socket (116) | Socket gracefully closed by remote side. | 2017-11-01 12:29:43
Socket (116) | Closed. | 2017-11-01 12:29:43
HD Request # 85 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:43
HD Request # 85 | Sending historical data logon request message. | 2017-11-01 12:29:43
HD Request # 85 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:39. Record interval: 0. Symbol: F.US.DSXZ17 | 2017-11-01 12:29:44
HD Request # 85 | Decompressing data. | 2017-11-01 12:29:44
HD Request # 85 | Receiving Intraday data for F.US.DSXZ17 starting at 2017-11-01 12:28:39 | 2017-11-01 12:29:44
HD Request # 85 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:44 | 2017-11-01 12:29:44
Socket (117) | Initiating close of socket by core. | 2017-11-01 12:29:44
Socket (117) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:44
Historical data download thread signaled to stop. | 2017-11-01 12:29:44
HD Request # 85 | Received 68 records from 2017-11-01 12:28:39 to 2017-11-01 12:29:49 (70.0 seconds) and wrote 66 records for F.US.DSXZ17 | 2017-11-01 12:29:44
HD Request # 85 | Intraday download COMPLETE for F.US.DSXZ17. Completion time: 0s. Unique request ID: 91 | 2017-11-01 12:29:44
Removed historical data download ID 91 | 2017-11-01 12:29:44
Real-time Intraday chart data file updates started for F.US.DSXZ17 | 2017-11-01 12:29:44
Intraday chart data file opened for F.US.DSXZ17 | 2017-11-01 12:29:44
HD Request # 86 | Downloading Intraday chart data for F.US.EPZ17 to the file F.US.EPZ17.scid. Service: cqg | 2017-11-01 12:29:44
HD Request # 86 | Download start date-time: 2017-11-01 12:28:38.000 | 2017-11-01 12:29:44
HD Request # 86 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 12:29:44
Socket (118) | Creating socket. | 2017-11-01 12:29:44
Socket (118) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:44
Socket (117) | Socket gracefully closed by remote side. | 2017-11-01 12:29:44
Socket (117) | Closed. | 2017-11-01 12:29:44
HD Request # 86 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:47
HD Request # 86 | Sending historical data logon request message. | 2017-11-01 12:29:47
HD Request # 86 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:38. Record interval: 0. Symbol: F.US.EPZ17 | 2017-11-01 12:29:47
HD Request # 86 | Decompressing data. | 2017-11-01 12:29:47
HD Request # 86 | Receiving Intraday data for F.US.EPZ17 starting at 2017-11-01 12:28:38 | 2017-11-01 12:29:47
HD Request # 86 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:50 | 2017-11-01 12:29:47
Socket (118) | Initiating close of socket by core. | 2017-11-01 12:29:47
Socket (118) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:47
Historical data download thread signaled to stop. | 2017-11-01 12:29:47
HD Request # 86 | Received 268 records from 2017-11-01 12:28:38 to 2017-11-01 12:29:54 (76.0 seconds) and wrote 266 records for F.US.EPZ17 | 2017-11-01 12:29:47
Added 1 Time and Sales records to Intraday data file for F.US.EPZ17 after download. | 2017-11-01 12:29:47
HD Request # 86 | Intraday download COMPLETE for F.US.EPZ17. Completion time: 4s. Unique request ID: 92 | 2017-11-01 12:29:47
Removed historical data download ID 92 | 2017-11-01 12:29:47
Real-time Intraday chart data file updates started for F.US.EPZ17 | 2017-11-01 12:29:47
Intraday chart data file opened for F.US.EPZ17 | 2017-11-01 12:29:47
HD Request # 87 | Downloading Intraday chart data for F.US.FOATZ17 to the file F.US.FOATZ17.scid. Service: eurex | 2017-11-01 12:29:47
HD Request # 87 | Download start date-time: 2017-11-01 12:28:18.000 | 2017-11-01 12:29:47
HD Request # 87 | Using server: ds1.sierracharts.com port 10149 | 2017-11-01 12:29:47
Socket (119) | Creating socket. | 2017-11-01 12:29:47
Socket (119) | Connecting to IP: 8.18.161.135. | 2017-11-01 12:29:47
Socket (118) | Socket gracefully closed by remote side. | 2017-11-01 12:29:47
Socket (118) | Closed. | 2017-11-01 12:29:47
HD Request # 87 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:47
HD Request # 87 | Sending historical data logon request message. | 2017-11-01 12:29:47
HD Request # 87 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:18. Record interval: 0. Symbol: FNZ17 | 2017-11-01 12:29:47
HD Request # 87 | Decompressing data. | 2017-11-01 12:29:47
Socket (119) | Initiating close of socket by core. | 2017-11-01 12:29:47
Socket (119) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:47
HD Request # 87 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FOATZ17 | 2017-11-01 12:29:47
HD Request # 87 | Receiving Intraday data for F.US.FOATZ17 starting at 2017-11-01 12:29:49 | 2017-11-01 12:29:47
HD Request # 87 | Timestamp of first Intraday data file record written: 2017-11-01 12:29:49 | 2017-11-01 12:29:47
Added 3 Time and Sales records to Intraday data file for F.US.FOATZ17 after download. | 2017-11-01 12:29:47
HD Request # 87 | Intraday download COMPLETE for F.US.FOATZ17. Completion time: 0s. Unique request ID: 93 | 2017-11-01 12:29:47
Removed historical data download ID 93 | 2017-11-01 12:29:47
Real-time Intraday chart data file updates started for F.US.FOATZ17 | 2017-11-01 12:29:47
Intraday chart data file opened for F.US.FOATZ17 | 2017-11-01 12:29:47
HD Request # 88 | Downloading Intraday chart data for F.US.FDXMZ17 to the file F.US.FDXMZ17.scid. Service: cqg | 2017-11-01 12:29:47
HD Request # 88 | Download start date-time: 2017-11-01 12:28:27.000 | 2017-11-01 12:29:47
HD Request # 88 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 12:29:47
Socket (120) | Creating socket. | 2017-11-01 12:29:47
Socket (120) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:47
Socket (119) | Socket gracefully closed by remote side. | 2017-11-01 12:29:48
Socket (119) | Closed. | 2017-11-01 12:29:48
HD Request # 88 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:48
HD Request # 88 | Sending historical data logon request message. | 2017-11-01 12:29:48
HD Request # 88 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:27. Record interval: 0. Symbol: F.US.FDXMZ17 | 2017-11-01 12:29:48
HD Request # 88 | Decompressing data. | 2017-11-01 12:29:48
HD Request # 88 | Receiving Intraday data for F.US.FDXMZ17 starting at 2017-11-01 12:28:27 | 2017-11-01 12:29:48
HD Request # 88 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:42 | 2017-11-01 12:29:48
Socket (120) | Initiating close of socket by core. | 2017-11-01 12:29:48
Socket (120) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:48
Historical data download thread signaled to stop. | 2017-11-01 12:29:48
HD Request # 88 | Received 14 records from 2017-11-01 12:28:27 to 2017-11-01 12:29:48 (81.0 seconds) and wrote 13 records for F.US.FDXMZ17 | 2017-11-01 12:29:48
HD Request # 88 | Intraday download COMPLETE for F.US.FDXMZ17. Completion time: 0s. Unique request ID: 94 | 2017-11-01 12:29:48
Removed historical data download ID 94 | 2017-11-01 12:29:48
Real-time Intraday chart data file updates started for F.US.FDXMZ17 | 2017-11-01 12:29:48
Intraday chart data file opened for F.US.FDXMZ17 | 2017-11-01 12:29:48
HD Request # 89 | Downloading Intraday chart data for F.US.GMCDZ17 to the file F.US.GMCDZ17.scid. Service: cqg | 2017-11-01 12:29:48
HD Request # 89 | Download start date-time: 2017-11-01 12:26:39.000 | 2017-11-01 12:29:48
HD Request # 89 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 12:29:48
Socket (121) | Creating socket. | 2017-11-01 12:29:48
Socket (121) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:48
Socket (120) | Socket gracefully closed by remote side. | 2017-11-01 12:29:48
Socket (120) | Closed. | 2017-11-01 12:29:48
HD Request # 89 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:48
HD Request # 89 | Sending historical data logon request message. | 2017-11-01 12:29:48
HD Request # 89 | Requesting Intraday data. Start date-time: 2017-11-01 12:26:39. Record interval: 0. Symbol: F.US.GMCDZ17 | 2017-11-01 12:29:48
HD Request # 89 | Decompressing data. | 2017-11-01 12:29:48
HD Request # 89 | Receiving Intraday data for F.US.GMCDZ17 starting at 2017-11-01 12:26:39 | 2017-11-01 12:29:48
HD Request # 89 | Timestamp of first Intraday data file record written: 2017-11-01 12:29:40 | 2017-11-01 12:29:48
Socket (121) | Initiating close of socket by core. | 2017-11-01 12:29:48
Socket (121) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:48
HD Request # 89 | Received 2 records from 2017-11-01 12:26:39 to 2017-11-01 12:29:40 (3.0 minutes) and wrote 1 record for F.US.GMCDZ17 | 2017-11-01 12:29:48
HD Request # 89 | Intraday download COMPLETE for F.US.GMCDZ17. Completion time: 0s. Unique request ID: 95 | 2017-11-01 12:29:48
Removed historical data download ID 95 | 2017-11-01 12:29:48
Real-time Intraday chart data file updates started for F.US.GMCDZ17 | 2017-11-01 12:29:48
Intraday chart data file opened for F.US.GMCDZ17 | 2017-11-01 12:29:48
HD Request # 90 | Downloading Intraday chart data for F.US.M6BZ17 to the file F.US.M6BZ17.scid. Service: cqg | 2017-11-01 12:29:48
HD Request # 90 | Download start date-time: 2017-11-01 12:26:57.000 | 2017-11-01 12:29:48
HD Request # 90 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 12:29:48
Socket (122) | Creating socket. | 2017-11-01 12:29:48
Socket (122) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:48
Socket (121) | Socket gracefully closed by remote side. | 2017-11-01 12:29:48
Socket (121) | Closed. | 2017-11-01 12:29:48
HD Request # 90 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:49
HD Request # 90 | Sending historical data logon request message. | 2017-11-01 12:29:49
HD Request # 90 | Requesting Intraday data. Start date-time: 2017-11-01 12:26:57. Record interval: 0. Symbol: F.US.M6BZ17 | 2017-11-01 12:29:49
HD Request # 90 | Decompressing data. | 2017-11-01 12:29:49
HD Request # 90 | Receiving Intraday data for F.US.M6BZ17 starting at 2017-11-01 12:28:43 | 2017-11-01 12:29:49
HD Request # 90 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:43 | 2017-11-01 12:29:49
Socket (122) | Initiating close of socket by core. | 2017-11-01 12:29:49
Socket (122) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:49
Historical data download thread signaled to stop. | 2017-11-01 12:29:49
HD Request # 90 | Received 3 records from 2017-11-01 12:28:43 to 2017-11-01 12:29:45 (62.0 seconds) and wrote 3 records for F.US.M6BZ17 | 2017-11-01 12:29:49
HD Request # 90 | Intraday download COMPLETE for F.US.M6BZ17. Completion time: 1s. Unique request ID: 96 | 2017-11-01 12:29:49
Removed historical data download ID 96 | 2017-11-01 12:29:49
Real-time Intraday chart data file updates started for F.US.M6BZ17 | 2017-11-01 12:29:49
Intraday chart data file opened for F.US.M6BZ17 | 2017-11-01 12:29:49
HD Request # 91 | Downloading Intraday chart data for F.US.M6EZ17 to the file F.US.M6EZ17.scid. Service: cqg | 2017-11-01 12:29:49
HD Request # 91 | Download start date-time: 2017-11-01 12:28:38.000 | 2017-11-01 12:29:49
HD Request # 91 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 12:29:49
Socket (123) | Creating socket. | 2017-11-01 12:29:49
Socket (123) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:49
Socket (122) | Socket gracefully closed by remote side. | 2017-11-01 12:29:49
Socket (122) | Closed. | 2017-11-01 12:29:49
HD Request # 91 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:49
HD Request # 91 | Sending historical data logon request message. | 2017-11-01 12:29:49
Opened cached Intraday file: C:\SierraChart\Data\F.US.BP6Z17.scid | 2017-11-01 12:29:49
Opened cached Intraday file: C:\SierraChart\Data\F.US.TYAZ17.scid | 2017-11-01 12:29:49
Opened cached Intraday file: C:\SierraChart\Data\F.US.EU6Z17.scid | 2017-11-01 12:29:49
Opened cached Intraday file: C:\SierraChart\Data\F.US.USAZ17.scid | 2017-11-01 12:29:49
Opened cached Intraday file: C:\SierraChart\Data\F.US.DLZ17.scid | 2017-11-01 12:29:49
Opened cached Intraday file: C:\SierraChart\Data\F.US.FGBXZ17.scid | 2017-11-01 12:29:49
Opened cached Intraday file: C:\SierraChart\Data\F.US.DSXZ17.scid | 2017-11-01 12:29:49
HD Request # 91 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:38. Record interval: 0. Symbol: F.US.M6EZ17 | 2017-11-01 12:29:49
HD Request # 91 | Decompressing data. | 2017-11-01 12:29:49
HD Request # 91 | Receiving Intraday data for F.US.M6EZ17 starting at 2017-11-01 12:28:38 | 2017-11-01 12:29:49
HD Request # 91 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:43 | 2017-11-01 12:29:49
Socket (123) | Initiating close of socket by core. | 2017-11-01 12:29:49
Socket (123) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:49
HD Request # 91 | Received 15 records from 2017-11-01 12:28:38 to 2017-11-01 12:29:29 (51.0 seconds) and wrote 14 records for F.US.M6EZ17 | 2017-11-01 12:29:49
HD Request # 91 | Intraday download COMPLETE for F.US.M6EZ17. Completion time: 0s. Unique request ID: 97 | 2017-11-01 12:29:49
Removed historical data download ID 97 | 2017-11-01 12:29:49
Real-time Intraday chart data file updates started for F.US.M6EZ17 | 2017-11-01 12:29:49
Intraday chart data file opened for F.US.M6EZ17 | 2017-11-01 12:29:49
HD Request # 92 | Downloading Intraday chart data for F.US.M6AZ17 to the file F.US.M6AZ17.scid. Service: cme | 2017-11-01 12:29:49
HD Request # 92 | Download start date-time: 2017-11-01 12:27:58.000 | 2017-11-01 12:29:49
HD Request # 92 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 12:29:49
Socket (124) | Creating socket. | 2017-11-01 12:29:49
Socket (124) | Connecting to IP: 8.18.161.133. | 2017-11-01 12:29:49
Socket (123) | Socket gracefully closed by remote side. | 2017-11-01 12:29:49
Socket (123) | Closed. | 2017-11-01 12:29:49
HD Request # 92 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:49
HD Request # 92 | Sending historical data logon request message. | 2017-11-01 12:29:49
HD Request # 92 | Requesting Intraday data. Start date-time: 2017-11-01 12:27:58. Record interval: 0. Symbol: M6AZ17 | 2017-11-01 12:29:50
HD Request # 92 | Decompressing data. | 2017-11-01 12:29:50
Socket (124) | Initiating close of socket by core. | 2017-11-01 12:29:50
Historical data download thread signaled to stop. | 2017-11-01 12:29:50
Socket (124) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:50
HD Request # 92 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.M6AZ17 | 2017-11-01 12:29:50
HD Request # 92 | Intraday download COMPLETE for F.US.M6AZ17. Completion time: 0s. Unique request ID: 98 | 2017-11-01 12:29:50
Removed historical data download ID 98 | 2017-11-01 12:29:50
Real-time Intraday chart data file updates started for F.US.M6AZ17 | 2017-11-01 12:29:50
Intraday chart data file opened for F.US.M6AZ17 | 2017-11-01 12:29:50
HD Request # 93 | Downloading Intraday chart data for F.US.DDZ17 to the file F.US.DDZ17.scid. Service: cqg | 2017-11-01 12:29:50
HD Request # 93 | Download start date-time: 2017-11-01 12:28:41.000 | 2017-11-01 12:29:50
HD Request # 93 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 12:29:50
Socket (125) | Creating socket. | 2017-11-01 12:29:50
Socket (125) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:50
Socket (124) | Socket gracefully closed by remote side. | 2017-11-01 12:29:50
Socket (124) | Closed. | 2017-11-01 12:29:50
HD Request # 93 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:50
HD Request # 93 | Sending historical data logon request message. | 2017-11-01 12:29:50
HD Request # 93 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:41. Record interval: 0. Symbol: F.US.DDZ17 | 2017-11-01 12:29:50
HD Request # 93 | Decompressing data. | 2017-11-01 12:29:50
HD Request # 93 | Receiving Intraday data for F.US.DDZ17 starting at 2017-11-01 12:28:41 | 2017-11-01 12:29:50
HD Request # 93 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:42 | 2017-11-01 12:29:50
Socket (125) | Initiating close of socket by core. | 2017-11-01 12:29:50
Socket (125) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:50
HD Request # 93 | Received 78 records from 2017-11-01 12:28:41 to 2017-11-01 12:29:51 (70.0 seconds) and wrote 76 records for F.US.DDZ17 | 2017-11-01 12:29:50
Added 1 Time and Sales records to Intraday data file for F.US.DDZ17 after download. | 2017-11-01 12:29:50
HD Request # 93 | Intraday download COMPLETE for F.US.DDZ17. Completion time: 0s. Unique request ID: 100 | 2017-11-01 12:29:50
Removed historical data download ID 100 | 2017-11-01 12:29:50
Real-time Intraday chart data file updates started for F.US.DDZ17 | 2017-11-01 12:29:50
Intraday chart data file opened for F.US.DDZ17 | 2017-11-01 12:29:50
HD Request # 94 | Downloading Intraday chart data for F.US.JY6Z17 to the file F.US.JY6Z17.scid. Service: cqg | 2017-11-01 12:29:50
HD Request # 94 | Download start date-time: 2017-11-01 12:28:41.000 | 2017-11-01 12:29:50
HD Request # 94 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 12:29:50
Socket (126) | Creating socket. | 2017-11-01 12:29:50
Socket (126) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:50
Socket (125) | Socket gracefully closed by remote side. | 2017-11-01 12:29:51
Socket (125) | Closed. | 2017-11-01 12:29:51
HD Request # 94 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:51
HD Request # 94 | Sending historical data logon request message. | 2017-11-01 12:29:51
HD Request # 94 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:41. Record interval: 0. Symbol: F.US.JY6Z17 | 2017-11-01 12:29:51
HD Request # 94 | Decompressing data. | 2017-11-01 12:29:51
HD Request # 94 | Receiving Intraday data for F.US.JY6Z17 starting at 2017-11-01 12:28:41 | 2017-11-01 12:29:51
HD Request # 94 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:42 | 2017-11-01 12:29:51
Socket (126) | Initiating close of socket by core. | 2017-11-01 12:29:51
Socket (126) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:51
Historical data download thread signaled to stop. | 2017-11-01 12:29:51
HD Request # 94 | Received 139 records from 2017-11-01 12:28:41 to 2017-11-01 12:29:52 (71.0 seconds) and wrote 133 records for F.US.JY6Z17 | 2017-11-01 12:29:51
Added 3 Time and Sales records to Intraday data file for F.US.JY6Z17 after download. | 2017-11-01 12:29:51
HD Request # 94 | Intraday download COMPLETE for F.US.JY6Z17. Completion time: 1s. Unique request ID: 101 | 2017-11-01 12:29:51
Removed historical data download ID 101 | 2017-11-01 12:29:51
Real-time Intraday chart data file updates started for F.US.JY6Z17 | 2017-11-01 12:29:51
Intraday chart data file opened for F.US.JY6Z17 | 2017-11-01 12:29:51
HD Request # 95 | Downloading Intraday chart data for F.US.MX6M17 to the file F.US.MX6M17.scid. Service: cme | 2017-11-01 12:29:51
HD Request # 95 | Download start date-time: 2017-06-19 14:48:49.000 | 2017-11-01 12:29:51
HD Request # 95 | Using server: ds1.sierracharts.com port 10149 | 2017-11-01 12:29:51
Socket (127) | Creating socket. | 2017-11-01 12:29:51
Socket (127) | Connecting to IP: 8.18.161.135. | 2017-11-01 12:29:51
Socket (126) | Socket gracefully closed by remote side. | 2017-11-01 12:29:51
Socket (126) | Closed. | 2017-11-01 12:29:51
HD Request # 95 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:51
HD Request # 95 | Sending historical data logon request message. | 2017-11-01 12:29:51
HD Request # 95 | Requesting Intraday data. Start date-time: 2017-06-19 14:48:49. Record interval: 0. Symbol: 6MM17 | 2017-11-01 12:29:51
HD Request # 95 | Decompressing data. | 2017-11-01 12:29:52
HD Request # 95 | Receiving Intraday data for F.US.MX6M17 starting at 2017-06-19 14:48:49 | 2017-11-01 12:29:52
Socket (127) | Initiating close of socket by core. | 2017-11-01 12:29:52
Socket (127) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:52
Historical data download thread signaled to stop. | 2017-11-01 12:29:52
HD Request # 95 | Received 4 records from 2017-06-19 14:48:49 to 2017-06-19 14:48:49 (0.0 seconds) and wrote 0 records for F.US.MX6M17 | 2017-11-01 12:29:52
HD Request # 95 | Intraday download COMPLETE for F.US.MX6M17. Completion time: 0s. Unique request ID: 102 | 2017-11-01 12:29:52
Removed historical data download ID 102 | 2017-11-01 12:29:52
Real-time Intraday chart data file updates started for F.US.MX6M17 | 2017-11-01 12:29:52
Intraday chart data file opened for F.US.MX6M17 | 2017-11-01 12:29:52
HD Request # 96 | Downloading Intraday chart data for F.US.NE6Z17 to the file F.US.NE6Z17.scid. Service: cqg | 2017-11-01 12:29:52
HD Request # 96 | Download start date-time: 2017-11-01 12:28:33.000 | 2017-11-01 12:29:52
HD Request # 96 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 12:29:52
Socket (128) | Creating socket. | 2017-11-01 12:29:52
Socket (128) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:52
Socket (127) | Socket gracefully closed by remote side. | 2017-11-01 12:29:52
Socket (127) | Closed. | 2017-11-01 12:29:52
HD Request # 96 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:52
HD Request # 96 | Sending historical data logon request message. | 2017-11-01 12:29:52
HD Request # 96 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:33. Record interval: 0. Symbol: F.US.NE6Z17 | 2017-11-01 12:29:52
HD Request # 96 | Decompressing data. | 2017-11-01 12:29:52
HD Request # 96 | Receiving Intraday data for F.US.NE6Z17 starting at 2017-11-01 12:28:47 | 2017-11-01 12:29:52
HD Request # 96 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:47 | 2017-11-01 12:29:52
Socket (128) | Initiating close of socket by core. | 2017-11-01 12:29:52
Socket (128) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:52
HD Request # 96 | Received 14 records from 2017-11-01 12:28:47 to 2017-11-01 12:29:47 (60.0 seconds) and wrote 14 records for F.US.NE6Z17 | 2017-11-01 12:29:52
HD Request # 96 | Intraday download COMPLETE for F.US.NE6Z17. Completion time: 1s. Unique request ID: 103 | 2017-11-01 12:29:52
Removed historical data download ID 103 | 2017-11-01 12:29:52
Real-time Intraday chart data file updates started for F.US.NE6Z17 | 2017-11-01 12:29:52
Intraday chart data file opened for F.US.NE6Z17 | 2017-11-01 12:29:52
HD Request # 97 | Downloading Intraday chart data for F.US.CLEZ17 to the file F.US.CLEZ17.scid. Service: cqg | 2017-11-01 12:29:52
HD Request # 97 | Download start date-time: 2017-11-01 12:28:37.000 | 2017-11-01 12:29:52
HD Request # 97 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 12:29:52
Socket (129) | Creating socket. | 2017-11-01 12:29:52
Socket (129) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:52
Socket (128) | Socket gracefully closed by remote side. | 2017-11-01 12:29:52
Socket (128) | Closed. | 2017-11-01 12:29:52
HD Request # 97 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:52
HD Request # 97 | Sending historical data logon request message. | 2017-11-01 12:29:52
HD Request # 97 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:37. Record interval: 0. Symbol: F.US.CLEZ17 | 2017-11-01 12:29:53
HD Request # 97 | Decompressing data. | 2017-11-01 12:29:53
HD Request # 97 | Receiving Intraday data for F.US.CLEZ17 starting at 2017-11-01 12:28:37 | 2017-11-01 12:29:53
HD Request # 97 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:42 | 2017-11-01 12:29:53
Socket (129) | Initiating close of socket by core. | 2017-11-01 12:29:53
Socket (129) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:53
Historical data download thread signaled to stop. | 2017-11-01 12:29:53
HD Request # 97 | Received 181 records from 2017-11-01 12:28:37 to 2017-11-01 12:29:57 (80.0 seconds) and wrote 176 records for F.US.CLEZ17 | 2017-11-01 12:29:53
HD Request # 97 | Intraday download COMPLETE for F.US.CLEZ17. Completion time: 0s. Unique request ID: 104 | 2017-11-01 12:29:53
Removed historical data download ID 104 | 2017-11-01 12:29:53
Real-time Intraday chart data file updates started for F.US.CLEZ17 | 2017-11-01 12:29:53
Intraday chart data file opened for F.US.CLEZ17 | 2017-11-01 12:29:53
HD Request # 98 | Downloading Intraday chart data for F.US.DA6Z17 to the file F.US.DA6Z17.scid. Service: cqg | 2017-11-01 12:29:53
HD Request # 98 | Download start date-time: 2017-11-01 12:28:39.000 | 2017-11-01 12:29:53
HD Request # 98 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 12:29:53
Socket (130) | Creating socket. | 2017-11-01 12:29:53
Socket (130) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:53
Socket (129) | Socket gracefully closed by remote side. | 2017-11-01 12:29:53
Socket (129) | Closed. | 2017-11-01 12:29:53
HD Request # 98 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:53
HD Request # 98 | Sending historical data logon request message. | 2017-11-01 12:29:53
HD Request # 98 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:39. Record interval: 0. Symbol: F.US.DA6Z17 | 2017-11-01 12:29:53
HD Request # 98 | Decompressing data. | 2017-11-01 12:29:53
HD Request # 98 | Receiving Intraday data for F.US.DA6Z17 starting at 2017-11-01 12:28:39 | 2017-11-01 12:29:53
HD Request # 98 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:46 | 2017-11-01 12:29:53
Socket (130) | Initiating close of socket by core. | 2017-11-01 12:29:53
Socket (130) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:53
HD Request # 98 | Received 143 records from 2017-11-01 12:28:39 to 2017-11-01 12:29:56 (77.0 seconds) and wrote 138 records for F.US.DA6Z17 | 2017-11-01 12:29:53
Added 3 Time and Sales records to Intraday data file for F.US.DA6Z17 after download. | 2017-11-01 12:29:53
HD Request # 98 | Intraday download COMPLETE for F.US.DA6Z17. Completion time: 0s. Unique request ID: 105 | 2017-11-01 12:29:53
Removed historical data download ID 105 | 2017-11-01 12:29:53
Real-time Intraday chart data file updates started for F.US.DA6Z17 | 2017-11-01 12:29:53
Intraday chart data file opened for F.US.DA6Z17 | 2017-11-01 12:29:53
HD Request # 99 | Downloading Intraday chart data for F.US.MX6Z17 to the file F.US.MX6Z17.scid. Service: cqg | 2017-11-01 12:29:53
HD Request # 99 | Download start date-time: 2017-11-01 12:28:39.000 | 2017-11-01 12:29:53
HD Request # 99 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 12:29:53
Socket (131) | Creating socket. | 2017-11-01 12:29:53
Socket (131) | Connecting to IP: 192.81.56.146. | 2017-11-01 12:29:53
Socket (130) | Socket gracefully closed by remote side. | 2017-11-01 12:29:53
Socket (130) | Closed. | 2017-11-01 12:29:53
HD Request # 99 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:53
HD Request # 99 | Sending historical data logon request message. | 2017-11-01 12:29:53
HD Request # 99 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:39. Record interval: 0. Symbol: F.US.MX6Z17 | 2017-11-01 12:29:53
HD Request # 99 | Decompressing data. | 2017-11-01 12:29:54
HD Request # 99 | Receiving Intraday data for F.US.MX6Z17 starting at 2017-11-01 12:28:39 | 2017-11-01 12:29:54
HD Request # 99 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:51 | 2017-11-01 12:29:54
Socket (131) | Initiating close of socket by core. | 2017-11-01 12:29:54
Socket (131) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:54
Historical data download thread signaled to stop. | 2017-11-01 12:29:54
HD Request # 99 | Received 19 records from 2017-11-01 12:28:39 to 2017-11-01 12:29:48 (69.0 seconds) and wrote 16 records for F.US.MX6Z17 | 2017-11-01 12:29:54
HD Request # 99 | Intraday download COMPLETE for F.US.MX6Z17. Completion time: 0s. Unique request ID: 106 | 2017-11-01 12:29:54
Removed historical data download ID 106 | 2017-11-01 12:29:54
Real-time Intraday chart data file updates started for F.US.MX6Z17 | 2017-11-01 12:29:54
Intraday chart data file opened for F.US.MX6Z17 | 2017-11-01 12:29:54
HD Request # 100 | Downloading Intraday chart data for F.US.DSXZ16 to the file F.US.DSXZ16.scid. Service: eurex | 2017-11-01 12:29:54
HD Request # 100 | Download start date-time: 2016-12-16 10:59:59.000 | 2017-11-01 12:29:54
HD Request # 100 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 12:29:54
Socket (132) | Creating socket. | 2017-11-01 12:29:54
Socket (132) | Connecting to IP: 8.18.161.133. | 2017-11-01 12:29:54
Socket (131) | Socket gracefully closed by remote side. | 2017-11-01 12:29:54
Socket (131) | Closed. | 2017-11-01 12:29:54
HD Request # 100 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:54
HD Request # 100 | Sending historical data logon request message. | 2017-11-01 12:29:54
HD Request # 100 | Requesting Intraday data. Start date-time: 2016-12-16 10:59:59. Record interval: 0. Symbol: FXZ16 | 2017-11-01 12:29:54
HD Request # 100 | Decompressing data. | 2017-11-01 12:29:54
HD Request # 100 | Receiving Intraday data for F.US.DSXZ16 starting at 2016-12-16 10:59:59 | 2017-11-01 12:29:54
Socket (132) | Initiating close of socket by core. | 2017-11-01 12:29:54
Socket (132) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:54
HD Request # 100 | Received 1 record from 2016-12-16 10:59:59 to 2016-12-16 10:59:59 (0.0 seconds) and wrote 0 records for F.US.DSXZ16 | 2017-11-01 12:29:54
HD Request # 100 | Intraday download COMPLETE for F.US.DSXZ16. Completion time: 1s. Unique request ID: 107 | 2017-11-01 12:29:54
Removed historical data download ID 107 | 2017-11-01 12:29:54
Real-time Intraday chart data file updates started for F.US.DSXZ16 | 2017-11-01 12:29:54
Intraday chart data file opened for F.US.DSXZ16 | 2017-11-01 12:29:54
HD Request # 101 | Downloading Intraday chart data for F.US.DDZ16 to the file F.US.DDZ16.scid. Service: eurex | 2017-11-01 12:29:54
HD Request # 101 | Download start date-time: 2016-12-16 11:59:55.000 | 2017-11-01 12:29:54
HD Request # 101 | Using server: ds1.sierracharts.com port 10149 | 2017-11-01 12:29:54
Socket (133) | Creating socket. | 2017-11-01 12:29:54
Socket (133) | Connecting to IP: 8.18.161.135. | 2017-11-01 12:29:54
Socket (132) | Socket gracefully closed by remote side. | 2017-11-01 12:29:54
Socket (132) | Closed. | 2017-11-01 12:29:54
HD Request # 101 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:55
HD Request # 101 | Sending historical data logon request message. | 2017-11-01 12:29:55
HD Request # 101 | Requesting Intraday data. Start date-time: 2016-12-16 11:59:55. Record interval: 0. Symbol: DYZ16 | 2017-11-01 12:29:55
HD Request # 101 | Decompressing data. | 2017-11-01 12:29:55
HD Request # 101 | Receiving Intraday data for F.US.DDZ16 starting at 2016-12-16 11:59:55 | 2017-11-01 12:29:55
Socket (133) | Initiating close of socket by core. | 2017-11-01 12:29:55
Socket (133) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:55
Historical data download thread signaled to stop. | 2017-11-01 12:29:55
HD Request # 101 | Received 1 record from 2016-12-16 11:59:55 to 2016-12-16 11:59:55 (0.0 seconds) and wrote 0 records for F.US.DDZ16 | 2017-11-01 12:29:55
HD Request # 101 | Intraday download COMPLETE for F.US.DDZ16. Completion time: 1s. Unique request ID: 108 | 2017-11-01 12:29:55
Removed historical data download ID 108 | 2017-11-01 12:29:55
Real-time Intraday chart data file updates started for F.US.DDZ16 | 2017-11-01 12:29:55
Intraday chart data file opened for F.US.DDZ16 | 2017-11-01 12:29:55
HD Request # 102 | Downloading Intraday chart data for F.US.CA6Z17 to the file F.US.CA6Z17.scid. Service: cqg | 2017-11-01 12:29:55
HD Request # 102 | Download start date-time: 2017-11-01 12:28:37.000 | 2017-11-01 12:29:55
HD Request # 102 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 12:29:55
Socket (134) | Creating socket. | 2017-11-01 12:29:55
Socket (134) | Connecting to IP: 65.182.172.42. | 2017-11-01 12:29:55
Socket (133) | Socket gracefully closed by remote side. | 2017-11-01 12:29:55
Socket (133) | Closed. | 2017-11-01 12:29:55
HD Request # 102 | Setting DTC encoding to Binary VLS | 2017-11-01 12:29:55
HD Request # 102 | Sending historical data logon request message. | 2017-11-01 12:29:55
HD Request # 102 | Requesting Intraday data. Start date-time: 2017-11-01 12:28:37. Record interval: 0. Symbol: F.US.CA6Z17 | 2017-11-01 12:29:55
HD Request # 102 | Decompressing data. | 2017-11-01 12:29:56
HD Request # 102 | Receiving Intraday data for F.US.CA6Z17 starting at 2017-11-01 12:28:37 | 2017-11-01 12:29:56
HD Request # 102 | Timestamp of first Intraday data file record written: 2017-11-01 12:28:37 | 2017-11-01 12:29:56
Socket (134) | Initiating close of socket by core. | 2017-11-01 12:29:56
Socket (134) | Shutdown started. Waiting for graceful close. | 2017-11-01 12:29:56
Historical data download thread signaled to stop. | 2017-11-01 12:29:56
HD Request # 102 | Received 67 records from 2017-11-01 12:28:37 to 2017-11-01 12:29:45 (68.0 seconds) and wrote 63 records for F.US.CA6Z17 | 2017-11-01 12:29:56
Added 6 Time and Sales records to Intraday data file for F.US.CA6Z17 after download. | 2017-11-01 12:29:56
HD Request # 102 | Intraday download COMPLETE for F.US.CA6Z17. Completion time: 0s. Unique request ID: 109 | 2017-11-01 12:29:56
Removed historical data download ID 109 | 2017-11-01 12:29:56
Real-time Intraday chart data file updates started for F.US.CA6Z17 | 2017-11-01 12:29:56
Intraday chart data file opened for F.US.CA6Z17 | 2017-11-01 12:29:56
Socket (134) | Socket gracefully closed by remote side. | 2017-11-01 12:29:56
Socket (134) | Closed. | 2017-11-01 12:29:56
Opened cached Intraday file: C:\SierraChart\Data\F.US.FBTPZ17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.EPZ17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.FOATZ17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6EZ17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.MJYZ17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.DDZ17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.JY6Z17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.NE6Z17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEZ17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.DA6Z17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.MX6Z17.scid | 2017-11-01 12:29:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.CA6Z17.scid | 2017-11-01 12:30:10
Opened cached Intraday file: C:\SierraChart\Data\F.US.FDXMZ17.scid | 2017-11-01 12:30:10
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6BZ17.scid | 2017-11-01 12:30:10
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6AZ17.scid | 2017-11-01 12:30:10
Opened cached Intraday file: C:\SierraChart\Data\F.US.GMCDZ17.scid | 2017-11-01 12:30:30
Opened cached Intraday file: C:\SierraChart\Data\F.US.DGZ17.scid | 2017-11-01 12:32:11
F.US.EPZ17 [CBV] 2500 Volume #2 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 [CBV] 2500 Volume #2 | Performing historical Daily data download for symbol ESZ17 starting at last date in file. | 2017-11-01 13:30:15
F.US.EPZ17 [CBV] 2500 Volume #2 | Waiting for historical downloads to complete with the IDs: 110, | 2017-11-01 13:30:15
F.US.EPZ17 #3 | Reloading chart. | 2017-11-01 13:30:15
NISS-NYSE 30 Sec #5 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 [CBV] #9 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 [CBV] #9 | Waiting for historical downloads to complete with the IDs: 110, | 2017-11-01 13:30:15
F.US.TYAZ17 #10 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 #11 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 [CV] Daily #13 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 [CV] Daily #13 | Performing historical Daily data download for symbol F.US.EPZ17 starting at last date in file. | 2017-11-01 13:30:15
F.US.EPZ17 [CV] Daily #13 | Waiting for historical downloads to complete with the IDs: 111, | 2017-11-01 13:30:15
F.US.DBZ17 #14 | Reloading chart. | 2017-11-01 13:30:15
F.US.DSXZ17 #16 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 10 Min #17 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 5 Min #18 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 Renko 2t #19 | Reloading chart. | 2017-11-01 13:30:15
F.US.EU6Z17 #20 | Reloading chart. | 2017-11-01 13:30:15
F.US.TYAZ17 #22 | Reloading chart. | 2017-11-01 13:30:15
F.US.BP6Z17 #23 | Reloading chart. | 2017-11-01 13:30:15
F.US.USAZ17 #24 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 [CBV] 60 Min #25 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 [CBV] 60 Min #25 | Waiting for historical downloads to complete with the IDs: 110, | 2017-11-01 13:30:15
F.US.JY6Z17 #27 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 15 Min #1 | Reloading chart. | 2017-11-01 13:30:15
+ Loading market depth data. | 2017-11-01 13:30:15
Loaded depth data records for F.US.EPZ17 2017-10-27 from 00:00:00 to 00:00:00. | 2017-11-01 13:30:15
Loaded depth data records for F.US.EPZ17 2017-10-29 from 2017-10-29 13:06:16 to 2017-10-29 18:06:44. | 2017-11-01 13:30:15
Loaded depth data records for F.US.EPZ17 2017-10-30 from 2017-10-30 07:29:39 to 2017-10-30 18:53:06. | 2017-11-01 13:30:15
F.US.JY6Z17 [CV] 5 Min #21 | Reloading chart. | 2017-11-01 13:30:15
Loaded depth data records for F.US.EPZ17 2017-10-31 from 2017-10-31 07:58:31 to 2017-10-31 20:17:52. | 2017-11-01 13:30:15
F.US.CLEZ17 #28 | Reloading chart. | 2017-11-01 13:30:15
Loaded depth data records for F.US.EPZ17 2017-11-01 from 2017-11-01 07:45:46 to 2017-11-01 13:30:08. | 2017-11-01 13:30:15
F.US.YMZ17 [CBV] 15 Min #30 | Reloading chart. | 2017-11-01 13:30:15
F.US.YMZ17 [CBV] 15 Min #30 | Performing historical Daily data download for symbol YMZ17 starting at last date in file. | 2017-11-01 13:30:15
F.US.YMZ17 [CBV] 15 Min #30 | Waiting for historical downloads to complete with the IDs: 112, | 2017-11-01 13:30:15
F.US.YMZ17 #31 | Reloading chart. | 2017-11-01 13:30:15
F.US.ENQZ17 #32 | Reloading chart. | 2017-11-01 13:30:15
F.US.FDXMZ17 #33 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 [CB] 1 Day #29 | Reloading chart. | 2017-11-01 13:30:15
F.US.EPZ17 [CB] 1 Day #29 | Waiting for historical downloads to complete with the IDs: 110, | 2017-11-01 13:30:15
HD Request # 103 | Downloading Historical Daily chart data for ESZ17. Starting date: 2017-10-30. Service: cqg | 2017-11-01 13:30:15
HD Request # 103 | Requesting historical Daily data for ESZ17 starting at 2017-10-29 | 2017-11-01 13:30:15
Requesting market depth updates for: F.US.ENQZ17 if supported. | 2017-11-01 13:30:28
CQG FIX Trading | Requesting market data including full depth for F.US.ENQZ17 | 2017-11-01 13:30:28
Requesting market depth updates for: F.US.YMZ17 if supported. | 2017-11-01 13:30:28
CQG FIX Trading | Requesting market data including full depth for F.US.YMZ17 | 2017-11-01 13:30:28
SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-NYSE. ID: 43 | 2017-11-01 13:30:28
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2017-11-01 13:30:28
SC DTC Data with Market Depth | Requesting security definition data for: NISS-NYSE. ID: 43 | 2017-11-01 13:30:28
Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2017-11-01 13:30:28
Delaying start of download for NISS-NYSE | 2017-11-01 13:30:28
Intraday data recording state for symbol F.US.YMZ17 is set to download 'Pending'. | 2017-11-01 13:30:28
Intraday data recording state for symbol F.US.ENQZ17 is set to download 'Pending'. | 2017-11-01 13:30:28
HTTP connection to ds01.ddfplus.com:80 (156) | Creating socket. | 2017-11-01 13:30:28
HTTP connection to ds01.ddfplus.com:80 (156) | Connecting to IP: 8.18.161.123. | 2017-11-01 13:30:28
DTC Client socket (157) | Creating socket. | 2017-11-01 13:30:28
DTC Client socket (157) | Connecting to IP: 192.81.56.146. | 2017-11-01 13:30:28
SC DTC Data with Market Depth | Connected to server. | 2017-11-01 13:30:28
SC DTC Data with Market Depth | Starting socket receive thread. | 2017-11-01 13:30:28
SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-11-01 13:30:28
HD Request # 103 | Receiving historical Daily data for ESZ17 starting at 2017-10-30 | 2017-11-01 13:30:28
HD Request # 103 | Writing historical Daily data to the file ESZ17.dly | 2017-11-01 13:30:28
HD Request # 103 | Received 3 records from 2017-10-30 00:00:00 to 2017-11-01 00:00:00 (3.0 days) and wrote 3 records for ESZ17 | 2017-11-01 13:30:28
HD Request # 103 | Daily download COMPLETE for ESZ17. Completion time: 1s. Unique request ID: 110 | 2017-11-01 13:30:28
Removed historical data download ID 110 | 2017-11-01 13:30:28
HD Request # 104 | Downloading Historical Daily chart data for F.US.EPZ17. Starting date: 2017-10-30. Service: cqg | 2017-11-01 13:30:28
HD Request # 104 | Requesting historical Daily data for ESZ17 starting at 2017-10-29 | 2017-11-01 13:30:28
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-11-01 13:30:28
SC DTC Data with Market Depth | Sending logon request message. | 2017-11-01 13:30:28
F.US.EPZ17 [CBV] 2500 Volume #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 13:30:29
F.US.EPZ17 [CBV] 2500 Volume #2 | Reloading chart. | 2017-11-01 13:30:29
HD Request # 104 | Receiving historical Daily data for F.US.EPZ17 starting at 2017-10-30 | 2017-11-01 13:30:29
HD Request # 104 | Writing historical Daily data to the file F.US.EPZ17.dly | 2017-11-01 13:30:29
HD Request # 104 | Received 3 records from 2017-10-30 00:00:00 to 2017-11-01 00:00:00 (3.0 days) and wrote 3 records for F.US.EPZ17 | 2017-11-01 13:30:29
HD Request # 104 | Daily download COMPLETE for F.US.EPZ17. Completion time: 0s. Unique request ID: 111 | 2017-11-01 13:30:29
Removed historical data download ID 111 | 2017-11-01 13:30:29
HD Request # 105 | Downloading Historical Daily chart data for YMZ17. Starting date: 2017-10-30. Service: cqg | 2017-11-01 13:30:29
HD Request # 105 | Requesting historical Daily data for YMZ17 starting at 2017-10-29 | 2017-11-01 13:30:29
SC DTC Data with Market Depth | Received logon response. | 2017-11-01 13:30:29
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-11-01 13:30:29
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-11-01 13:30:29
SC DTC Data with Market Depth | Successfully connected. | 2017-11-01 13:30:29
SC DTC Data with Market Depth | Trading is not supported. | 2017-11-01 13:30:29
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2017-11-01 13:30:29
F.US.EPZ17 [CBV] 60 Min #25 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 13:30:29
F.US.EPZ17 [CBV] 60 Min #25 | Reloading chart. | 2017-11-01 13:30:29
HD Request # 105 | Receiving historical Daily data for YMZ17 starting at 2017-10-30 | 2017-11-01 13:30:29
HD Request # 105 | Writing historical Daily data to the file YMZ17.dly | 2017-11-01 13:30:29
HD Request # 105 | Received 3 records from 2017-10-30 00:00:00 to 2017-11-01 00:00:00 (3.0 days) and wrote 3 records for YMZ17 | 2017-11-01 13:30:29
HD Request # 105 | Daily download COMPLETE for YMZ17. Completion time: 0s. Unique request ID: 112 | 2017-11-01 13:30:29
Removed historical data download ID 112 | 2017-11-01 13:30:29
SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2017-11-01 13:30:29
F.US.EPZ17 [CBV] #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 13:30:29
F.US.EPZ17 [CBV] #9 | Reloading chart. | 2017-11-01 13:30:29
F.US.EPZ17 [CV] Daily #13 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 13:30:29
F.US.EPZ17 [CV] Daily #13 | Reloading chart. | 2017-11-01 13:30:29
Delaying start of download for NISS-NYSE | 2017-11-01 13:30:29
F.US.EPZ17 [CB] 1 Day #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 13:30:29
F.US.EPZ17 [CB] 1 Day #29 | Reloading chart. | 2017-11-01 13:30:29
+ Loading market depth data. | 2017-11-01 13:30:29
Loaded depth data records for F.US.EPZ17 2017-10-29 from 2017-10-29 13:06:16 to 2017-10-29 18:06:44. | 2017-11-01 13:30:29
F.US.YMZ17 [CBV] 15 Min #30 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 13:30:30
F.US.YMZ17 [CBV] 15 Min #30 | Reloading chart. | 2017-11-01 13:30:30
F.US.EPZ17 [CBV] 60 Min #25 | Reloading chart. | 2017-11-01 13:30:30
F.US.EPZ17 [CBV] #9 | Reloading chart. | 2017-11-01 13:30:30
F.US.EPZ17 [CV] Daily #13 | Reloading chart. | 2017-11-01 13:30:30
Loaded depth data records for F.US.EPZ17 2017-10-30 from 2017-10-30 07:29:39 to 2017-10-30 18:53:06. | 2017-11-01 13:30:30
Loaded depth data records for F.US.EPZ17 2017-10-31 from 2017-10-31 07:58:31 to 2017-10-31 20:17:52. | 2017-11-01 13:30:30
Loaded depth data records for F.US.EPZ17 2017-11-01 from 2017-11-01 07:45:46 to 2017-11-01 13:30:08. | 2017-11-01 13:30:30
F.US.EPZ17 [CB] 1 Day #29 | Reloading chart. | 2017-11-01 13:30:30
F.US.YMZ17 [CBV] 15 Min #30 | Reloading chart. | 2017-11-01 13:30:34
HD Request # 106 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2017-11-01 13:30:37
HD Request # 106 | Download start date-time: 2017-10-31 20:17:59.000 | 2017-11-01 13:30:37
HD Request # 106 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 13:30:37
Socket (158) | Creating socket. | 2017-11-01 13:30:37
Socket (158) | Connecting to IP: 192.81.56.146. | 2017-11-01 13:30:37
HD Request # 106 | Setting DTC encoding to Binary VLS | 2017-11-01 13:30:37
HD Request # 106 | Sending historical data logon request message. | 2017-11-01 13:30:37
HD Request # 106 | Requesting Intraday data. Start date-time: 2017-10-31 20:17:59. Record interval: 0. Symbol: NISS-NYSE | 2017-11-01 13:30:37
HD Request # 106 | Decompressing data. | 2017-11-01 13:30:37
HD Request # 106 | Receiving Intraday data for NISS-NYSE starting at 2017-10-31 20:17:59 | 2017-11-01 13:30:37
HD Request # 106 | Timestamp of first Intraday data file record written: 2017-10-31 20:18:00 | 2017-11-01 13:30:37
Socket (158) | Initiating close of socket by core. | 2017-11-01 13:30:37
Socket (158) | Shutdown started. Waiting for graceful close. | 2017-11-01 13:30:37
Historical data download thread signaled to stop. | 2017-11-01 13:30:37
Socket (158) | Socket gracefully closed by remote side. | 2017-11-01 13:30:37
Socket (158) | Closed. | 2017-11-01 13:30:37
HD Request # 106 | Received 30976 records from 2017-10-31 20:17:59 to 2017-11-01 13:30:43 (17.2 hours) and wrote 30975 records for NISS-NYSE | 2017-11-01 13:30:37
Added 18 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2017-11-01 13:30:37
HD Request # 106 | Intraday download COMPLETE for NISS-NYSE. Completion time: 1s. Unique request ID: 113 | 2017-11-01 13:30:37
Removed historical data download ID 113 | 2017-11-01 13:30:37
Real-time Intraday chart data file updates started for NISS-NYSE | 2017-11-01 13:30:37
Intraday chart data file opened for NISS-NYSE | 2017-11-01 13:30:37
HD Request # 107 | Downloading Intraday chart data for F.US.YMZ17 to the file F.US.YMZ17.scid. Service: cqg | 2017-11-01 13:30:37
HD Request # 107 | Download start date-time: 2017-10-31 20:14:59.000 | 2017-11-01 13:30:37
HD Request # 107 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 13:30:37
Socket (159) | Creating socket. | 2017-11-01 13:30:37
Socket (159) | Connecting to IP: 65.182.172.42. | 2017-11-01 13:30:37
HD Request # 107 | Setting DTC encoding to Binary VLS | 2017-11-01 13:30:38
HD Request # 107 | Sending historical data logon request message. | 2017-11-01 13:30:38
HD Request # 107 | Requesting Intraday data. Start date-time: 2017-10-31 20:14:59. Record interval: 0. Symbol: F.US.YMZ17 | 2017-11-01 13:30:38
HD Request # 107 | Decompressing data. | 2017-11-01 13:30:38
HD Request # 107 | Receiving Intraday data for F.US.YMZ17 starting at 2017-10-31 20:14:59 | 2017-11-01 13:30:38
HD Request # 107 | Timestamp of first Intraday data file record written: 2017-10-31 20:30:00 | 2017-11-01 13:30:40
Socket (159) | Initiating close of socket by core. | 2017-11-01 13:30:40
Historical data download thread signaled to stop. | 2017-11-01 13:30:40
Socket (159) | Shutdown started. Waiting for graceful close. | 2017-11-01 13:30:40
Socket (159) | Socket gracefully closed by remote side. | 2017-11-01 13:30:40
Socket (159) | Closed. | 2017-11-01 13:30:40
HD Request # 107 | Received 31783 records from 2017-10-31 20:14:59 to 2017-11-01 13:30:46 (17.3 hours) and wrote 31777 records for F.US.YMZ17 | 2017-11-01 13:30:40
Added 69 Time and Sales records to Intraday data file for F.US.YMZ17 after download. | 2017-11-01 13:30:40
HD Request # 107 | Intraday download COMPLETE for F.US.YMZ17. Completion time: 3s. Unique request ID: 114 | 2017-11-01 13:30:40
Removed historical data download ID 114 | 2017-11-01 13:30:40
Real-time Intraday chart data file updates started for F.US.YMZ17 | 2017-11-01 13:30:40
Intraday chart data file opened for F.US.YMZ17 | 2017-11-01 13:30:40
HD Request # 108 | Downloading Intraday chart data for F.US.ENQZ17 to the file F.US.ENQZ17.scid. Service: cqg | 2017-11-01 13:30:40
HD Request # 108 | Download start date-time: 2017-10-31 20:14:59.000 | 2017-11-01 13:30:40
HD Request # 108 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 13:30:40
Socket (160) | Creating socket. | 2017-11-01 13:30:40
Socket (160) | Connecting to IP: 192.81.56.146. | 2017-11-01 13:30:40
Opened cached Intraday file: C:\SierraChart\Data\F.US.YMZ17.scid | 2017-11-01 13:30:40
Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2017-11-01 13:30:40
HD Request # 108 | Setting DTC encoding to Binary VLS | 2017-11-01 13:30:42
HD Request # 108 | Sending historical data logon request message. | 2017-11-01 13:30:42
HD Request # 108 | Requesting Intraday data. Start date-time: 2017-10-31 20:14:59. Record interval: 0. Symbol: F.US.ENQZ17 | 2017-11-01 13:30:42
HD Request # 108 | Decompressing data. | 2017-11-01 13:30:42
HD Request # 108 | Receiving Intraday data for F.US.ENQZ17 starting at 2017-10-31 20:14:59 | 2017-11-01 13:30:42
HD Request # 108 | Timestamp of first Intraday data file record written: 2017-10-31 20:30:00 | 2017-11-01 13:30:44
Socket (160) | Initiating close of socket by core. | 2017-11-01 13:30:44
Socket (160) | Shutdown started. Waiting for graceful close. | 2017-11-01 13:30:44
Socket (160) | Socket gracefully closed by remote side. | 2017-11-01 13:30:44
Socket (160) | Closed. | 2017-11-01 13:30:44
Historical data download thread signaled to stop. | 2017-11-01 13:30:44
HD Request # 108 | Received 34076 records from 2017-10-31 20:14:59 to 2017-11-01 13:30:49 (17.3 hours) and wrote 34069 records for F.US.ENQZ17 | 2017-11-01 13:30:44
Added 44 Time and Sales records to Intraday data file for F.US.ENQZ17 after download. | 2017-11-01 13:30:44
HD Request # 108 | Intraday download COMPLETE for F.US.ENQZ17. Completion time: 3s. Unique request ID: 115 | 2017-11-01 13:30:44
Removed historical data download ID 115 | 2017-11-01 13:30:44
Real-time Intraday chart data file updates started for F.US.ENQZ17 | 2017-11-01 13:30:44
Intraday chart data file opened for F.US.ENQZ17 | 2017-11-01 13:30:44
Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQZ17.scid | 2017-11-01 13:30:51
HTTP connection to ds01.ddfplus.com:80 (156) | Socket gracefully closed by remote side. | 2017-11-01 13:31:34
HTTP connection to ds01.ddfplus.com:80 (156) | Received socket Close event. | 2017-11-01 13:31:34
HTTP connection to ds01.ddfplus.com:80 (156) | Initiating close of socket by core. | 2017-11-01 13:31:34
HTTP connection to ds01.ddfplus.com:80 (156) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 13:31:34
HTTP connection to ds01.ddfplus.com:80 (156) | Closed. | 2017-11-01 13:31:34
SC DTC Data with Market Depth | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2017-11-01 13:59:48
DTC Client socket (157) | Initiating close of socket by core. | 2017-11-01 13:59:48
DTC Client socket (157) | Write in progress. Shutdown being delayed. | 2017-11-01 13:59:48
SC DTC Data with Market Depth | Disconnected from the server. | 2017-11-01 13:59:48
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2017-11-01 13:59:48
SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 10048 | 2017-11-01 13:59:50
DTC Client socket (171) | Creating socket. | 2017-11-01 13:59:50
DTC Client socket (171) | Connecting to IP: 65.182.172.42. | 2017-11-01 13:59:50
SC DTC Data with Market Depth | Connected to server. | 2017-11-01 13:59:50
SC DTC Data with Market Depth | Starting socket receive thread. | 2017-11-01 13:59:50
SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-11-01 13:59:50
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-11-01 13:59:51
SC DTC Data with Market Depth | Sending logon request message. | 2017-11-01 13:59:51
SC DTC Data with Market Depth | Received logon response. | 2017-11-01 13:59:51
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-11-01 13:59:51
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-11-01 13:59:51
SC DTC Data with Market Depth | Successfully connected. | 2017-11-01 13:59:51
SC DTC Data with Market Depth | Trading is not supported. | 2017-11-01 13:59:51
Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2017-11-01 13:59:51
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2017-11-01 13:59:51
Delaying start of download for NISS-NYSE | 2017-11-01 13:59:51
SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2017-11-01 13:59:51
HD Request # 109 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2017-11-01 13:59:56
HD Request # 109 | Download start date-time: 2017-11-01 13:58:53.000 | 2017-11-01 13:59:56
HD Request # 109 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 13:59:56
Socket (172) | Creating socket. | 2017-11-01 13:59:56
Socket (172) | Connecting to IP: 65.182.172.42. | 2017-11-01 13:59:56
HD Request # 109 | Setting DTC encoding to Binary VLS | 2017-11-01 13:59:56
HD Request # 109 | Sending historical data logon request message. | 2017-11-01 13:59:56
HD Request # 109 | Requesting Intraday data. Start date-time: 2017-11-01 13:58:53. Record interval: 0. Symbol: NISS-NYSE | 2017-11-01 13:59:57
HD Request # 109 | Decompressing data. | 2017-11-01 13:59:57
HD Request # 109 | Receiving Intraday data for NISS-NYSE starting at 2017-11-01 13:58:53 | 2017-11-01 13:59:57
HD Request # 109 | Timestamp of first Intraday data file record written: 2017-11-01 13:58:54 | 2017-11-01 13:59:57
Socket (172) | Initiating close of socket by core. | 2017-11-01 13:59:57
Socket (172) | Shutdown started. Waiting for graceful close. | 2017-11-01 13:59:57
Historical data download thread signaled to stop. | 2017-11-01 13:59:57
HD Request # 109 | Received 70 records from 2017-11-01 13:58:53 to 2017-11-01 14:00:02 (69.0 seconds) and wrote 69 records for NISS-NYSE | 2017-11-01 13:59:57
Added 8 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2017-11-01 13:59:57
HD Request # 109 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 116 | 2017-11-01 13:59:57
Removed historical data download ID 116 | 2017-11-01 13:59:57
Real-time Intraday chart data file updates started for NISS-NYSE | 2017-11-01 13:59:57
Intraday chart data file opened for NISS-NYSE | 2017-11-01 13:59:57
Socket (172) | Socket gracefully closed by remote side. | 2017-11-01 13:59:57
Socket (172) | Closed. | 2017-11-01 13:59:57
Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2017-11-01 14:00:07
DTC Client socket (157) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 14:00:28 *
DTC Client socket (157) | Write has completed. Shutdown being performed. | 2017-11-01 14:00:28
DTC Client socket (157) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:00:28
DTC Client socket (157) | Socket gracefully closed by remote side. | 2017-11-01 14:00:28
DTC Client socket (157) | Closed. | 2017-11-01 14:00:28
CQG WebSocket socket (107) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 14:07:37 *
CQG WebSocket socket (107) | Socket gracefully closed by remote side. | 2017-11-01 14:07:37
CQG WebSocket socket (107) | Received socket Close event. | 2017-11-01 14:07:37
CQG WebSocket socket (107) | Initiating close of socket by core. | 2017-11-01 14:07:37
CQG WebSocket | Network socket for WebSocket has been closed by remote side. | 2017-11-01 14:07:37
CQG FIX Trading | WebSocket closed. | 2017-11-01 14:07:37
Connection to the external service has been lost. | 2017-11-01 14:07:37
CQG WebSocket socket (107) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 14:07:37
CQG WebSocket socket (107) | Closed. | 2017-11-01 14:07:37
CQG FIX: DisconnectFIX called. | 2017-11-01 14:07:37
CQG FIX: Sending a Logout message. | 2017-11-01 14:07:37
CQG FIX Trading | Disconnected. | 2017-11-01 14:07:37
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 14:07:37
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2017-11-01 14:07:38
CQG FIX socket (106) | Initiating close of socket by core. | 2017-11-01 14:07:38
CQG FIX: Disconnected. | 2017-11-01 14:07:38
CQG FIX socket (106) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:38
CQG FIX socket (106) | Socket gracefully closed by remote side. | 2017-11-01 14:07:38
CQG FIX socket (106) | Closed. | 2017-11-01 14:07:38
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-01 14:07:41
CQG FIX socket (175) | Creating socket. Using TLS 1.2. | 2017-11-01 14:07:41
CQG FIX socket (175) | Connecting to IP: 208.48.16.214. | 2017-11-01 14:07:41
CQG FIX: Sending the Logon message. | 2017-11-01 14:07:41
CQG FIX Trading | Connected to trading server. | 2017-11-01 14:07:42
CQG FIX Trading | Connecting to server api.cqg.com | 2017-11-01 14:07:42
CQG WebSocket | Connecting to WebSocket server. | 2017-11-01 14:07:42
CQG FIX | FCM name: AMP | 2017-11-01 14:07:42
CQG WebSocket socket (176) | Creating socket. Using TLS 1.2. | 2017-11-01 14:07:42
CQG WebSocket socket (176) | Connecting to IP: 195.166.124.165. | 2017-11-01 14:07:42
CQG WebSocket | Opening WebSocket. | 2017-11-01 14:07:42
CQG WebSocket | Sending WebSocket handshake. | 2017-11-01 14:07:42
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-11-01 14:07:42
CQG WebSocket | Web socket state is now open. | 2017-11-01 14:07:42
CQG FIX Trading | WebSocket connected. | 2017-11-01 14:07:42
CQG FIX Trading | Sending market data logon message. | 2017-11-01 14:07:42
CQG FIX Trading | Logon successful. Session Token = Q/2EgTmllp5wcVg+3Giifnbjx/gzx6fNZP+uDD+yLMwV/2GyTV1FD3XeXFR8ad7/3ODperv4xlL | 2017-11-01 14:07:42
CQG FIX Trading | Connected to data and trading server. | 2017-11-01 14:07:42
DTC Client socket (171) | Initiating close of socket by core. | 2017-11-01 14:07:42
DTC Client socket (171) | Write in progress. Shutdown being delayed. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Disconnected from the server. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DLM17. ID: 1 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.DLM17. ID: 593748 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.DLM17. ID: 1 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6M17. ID: 2 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.CA6M17. ID: 593749 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.CA6M17. ID: 2 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6M17. ID: 3 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.BP6M17. ID: 593750 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.BP6M17. ID: 3 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6M17. ID: 4 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.EU6M17. ID: 593751 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.EU6M17. ID: 4 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6Z17. ID: 5 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.CA6Z17. ID: 593752 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.CA6Z17. ID: 5 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ17. ID: 6 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ17. ID: 593753 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ17. ID: 6 | 2017-11-01 14:07:42
Requesting market depth updates for: F.US.DSXZ17 if supported. | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.DSXZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
Delaying start of download for F.US.DSXZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.JY6Z17. ID: 7 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.JY6Z17. ID: 593754 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.JY6Z17. ID: 7 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.JY6Z17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DBZ17. ID: 8 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.DBZ17. ID: 593755 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.DBZ17. ID: 8 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.DBZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.CA6Z7. Search Symbol: F.US.CA6Z17. Request ID: 593752. Contract ID: 1. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.CA6Z17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXZ7. Search Symbol: F.US.DSXZ17. Request ID: 593753. Contract ID: 2. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data including full depth for F.US.DSXZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.JY6Z7. Search Symbol: F.US.JY6Z17. Request ID: 593754. Contract ID: 3. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.JY6Z17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.DBZ7. Search Symbol: F.US.DBZ17. Request ID: 593755. Contract ID: 4. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.DBZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 14:07:42
Symbol Error - F.US.DLM17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:07:42
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DSXZ17.2017-11-01.depth | 2017-11-01 14:07:42
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DBZ17.2017-11-01.depth | 2017-11-01 14:07:42
Symbol Error - F.US.CA6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:07:42
Symbol Error - F.US.BP6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:07:42
Symbol Error - F.US.EU6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.EPZ17. ID: 9 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.EPZ17. ID: 593756 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.EPZ17. ID: 9 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.EPZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.EPZ7. Search Symbol: F.US.EPZ17. Request ID: 593756. Contract ID: 5. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.EPZ17 | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-NYSE. ID: 10 | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Requesting security definition data for: NISS-NYSE. ID: 10 | 2017-11-01 14:07:42
Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2017-11-01 14:07:42
HD Request # 110 | Downloading Intraday chart data for F.US.DSXZ17 to the file F.US.DSXZ17.scid. Service: cqg | 2017-11-01 14:07:42
HD Request # 110 | Download start date-time: 2017-11-01 14:07:26.000 | 2017-11-01 14:07:42
HD Request # 110 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:07:42
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.EPZ17.2017-11-01.depth | 2017-11-01 14:07:42
Requesting market depth updates for: F.US.EPZ17 if supported. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data including full depth for F.US.EPZ17 | 2017-11-01 14:07:42
DTC Client socket (177) | Creating socket. | 2017-11-01 14:07:42
DTC Client socket (177) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:07:42
Socket (178) | Creating socket. | 2017-11-01 14:07:42
Socket (178) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:07:42
Requesting market depth updates for: F.US.DBZ17 if supported. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data including full depth for F.US.DBZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FOATZ17. ID: 11 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.FOATZ17. ID: 593757 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.FOATZ17. ID: 11 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.FOATZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ16. ID: 12 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ16. ID: 593758 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ16. ID: 12 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.DSXZ16 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FOATZ7. Search Symbol: F.US.FOATZ17. Request ID: 593757. Contract ID: 6. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.FOATZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.TYAZ17. ID: 13 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.TYAZ17. ID: 593759 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.TYAZ17. ID: 13 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.TYAZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ17. ID: 14 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ17. ID: 593760 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.DDZ17. ID: 14 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.DDZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6Z17. ID: 15 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.EU6Z17. ID: 593761 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.EU6Z17. ID: 15 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6Z17. ID: 16 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.BP6Z17. ID: 593762 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.BP6Z17. ID: 16 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.BP6Z17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.YMZ17. ID: 17 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.YMZ17. ID: 593763 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.YMZ17. ID: 17 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.YMZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.TYAZ7. Search Symbol: F.US.TYAZ17. Request ID: 593759. Contract ID: 7. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.TYAZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.DDZ7. Search Symbol: F.US.DDZ17. Request ID: 593760. Contract ID: 8. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.DDZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.EU6Z7. Search Symbol: F.US.EU6Z17. Request ID: 593761. Contract ID: 9. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.EU6Z17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DA6Z17. ID: 18 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.DA6Z17. ID: 593764 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.DA6Z17. ID: 18 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.DA6Z17 is set to download 'Pending'. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Connected to server. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Starting socket receive thread. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.BP6Z7. Search Symbol: F.US.BP6Z17. Request ID: 593762. Contract ID: 10. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.BP6Z17 | 2017-11-01 14:07:42
Symbol Error - F.US.DSXZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.NE6Z17. ID: 19 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.NE6Z17. ID: 593765 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.NE6Z17. ID: 19 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.NE6Z17 is set to download 'Pending'. | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.CA6Z17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.YMZ7. Search Symbol: F.US.YMZ17. Request ID: 593763. Contract ID: 11. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.YMZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.DA6Z7. Search Symbol: F.US.DA6Z17. Request ID: 593764. Contract ID: 12. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.DA6Z17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6Z17. ID: 20 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.MX6Z17. ID: 593766 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.MX6Z17. ID: 20 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.MX6Z17 is set to download 'Pending'. | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.EU6Z17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.NE6Z7. Search Symbol: F.US.NE6Z17. Request ID: 593765. Contract ID: 13. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.NE6Z17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.MX6Z7. Search Symbol: F.US.MX6Z17. Request ID: 593766. Contract ID: 14. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.MX6Z17 | 2017-11-01 14:07:42
Requesting market depth updates for: F.US.DDZ17 if supported. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data including full depth for F.US.DDZ17 | 2017-11-01 14:07:42
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DDZ17.2017-11-01.depth | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ16. ID: 21 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ16. ID: 593767 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.DDZ16. ID: 21 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.DDZ16 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DGZ17. ID: 22 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.DGZ17. ID: 593768 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.DGZ17. ID: 22 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.DGZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.DLZ17. ID: 23 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.DLZ17. ID: 593769 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.DLZ17. ID: 23 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.DLZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Sending logon request message. | 2017-11-01 14:07:42
HD Request # 110 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:42
HD Request # 110 | Sending historical data logon request message. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.EADZ17. ID: 24 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.EADZ17. ID: 593770 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.EADZ17. ID: 24 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.ECDZ17. ID: 25 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.ECDZ17. ID: 593771 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.ECDZ17. ID: 25 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FGBXZ17. ID: 26 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.FGBXZ17. ID: 593772 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.FGBXZ17. ID: 26 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FBTPZ17. ID: 27 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.FBTPZ17. ID: 593773 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.FBTPZ17. ID: 27 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.TUAZ17. ID: 28 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.TUAZ17. ID: 593774 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.TUAZ17. ID: 28 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FVAZ17. ID: 29 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.FVAZ17. ID: 593775 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.FVAZ17. ID: 29 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.USAZ17. ID: 30 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.USAZ17. ID: 593776 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.USAZ17. ID: 30 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FDXMZ17. ID: 31 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.FDXMZ17. ID: 593777 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.FDXMZ17. ID: 31 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.FDXMZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.DGZ7. Search Symbol: F.US.DGZ17. Request ID: 593768. Contract ID: 15. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.DGZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.DLZ7. Search Symbol: F.US.DLZ17. Request ID: 593769. Contract ID: 16. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.DLZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.EADZ7. Search Symbol: F.US.EADZ17. Request ID: 593770. Contract ID: 17. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.EADZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.ECDZ7. Search Symbol: F.US.ECDZ17. Request ID: 593771. Contract ID: 18. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.ECDZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FGBXZ7. Search Symbol: F.US.FGBXZ17. Request ID: 593772. Contract ID: 19. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.FGBXZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FBTPZ7. Search Symbol: F.US.FBTPZ17. Request ID: 593773. Contract ID: 20. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.FBTPZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.TUAZ7. Search Symbol: F.US.TUAZ17. Request ID: 593774. Contract ID: 21. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.TUAZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVAZ7. Search Symbol: F.US.FVAZ17. Request ID: 593775. Contract ID: 22. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.FVAZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.USAZ7. Search Symbol: F.US.USAZ17. Request ID: 593776. Contract ID: 23. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.USAZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.GMCDZ17. ID: 32 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.GMCDZ17. ID: 593778 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.GMCDZ17. ID: 32 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.GMCDZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FDXMZ7. Search Symbol: F.US.FDXMZ17. Request ID: 593777. Contract ID: 24. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.FDXMZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.M6BZ17. ID: 33 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.M6BZ17. ID: 593779 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.M6BZ17. ID: 33 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.M6BZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.M6EZ17. ID: 34 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.M6EZ17. ID: 593780 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.M6EZ17. ID: 34 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.M6EZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.M6AZ17. ID: 35 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.M6AZ17. ID: 593781 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.M6AZ17. ID: 35 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.M6AZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.GMCDZ7. Search Symbol: F.US.GMCDZ17. Request ID: 593778. Contract ID: 25. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.GMCDZ17 | 2017-11-01 14:07:42
Symbol Error - F.US.DDZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.MJYZ17. ID: 36 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.MJYZ17. ID: 593782 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.MJYZ17. ID: 36 | 2017-11-01 14:07:42
CQG FIX Trading | Using primary service for historical data for F.US.MJYZ17 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.MJYZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
Delaying start of download for F.US.MJYZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6BZ7. Search Symbol: F.US.M6BZ17. Request ID: 593779. Contract ID: 26. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.M6BZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6EZ7. Search Symbol: F.US.M6EZ17. Request ID: 593780. Contract ID: 27. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.M6EZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6M17. ID: 37 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.MX6M17. ID: 593783 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.MX6M17. ID: 37 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.MX6M17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6AZ7. Search Symbol: F.US.M6AZ17. Request ID: 593781. Contract ID: 28. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.M6AZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.MJYZ7. Search Symbol: F.US.MJYZ17. Request ID: 593782. Contract ID: 29. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.MJYZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.CLEZ17. ID: 38 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.CLEZ17. ID: 593784 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.CLEZ17. ID: 38 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.CLEZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.USAZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.ENQZ17. ID: 39 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.ENQZ17. ID: 593785 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.ENQZ17. ID: 39 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.ENQZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEZ7. Search Symbol: F.US.CLEZ17. Request ID: 593784. Contract ID: 30. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.CLEZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.ENQZ7. Search Symbol: F.US.ENQZ17. Request ID: 593785. Contract ID: 31. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.ENQZ17 | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.FGBXZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Received logon response. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Successfully connected. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Trading is not supported. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2017-11-01 14:07:42
Intraday data recording state for symbol F.US.FBTPZ17 is set to download 'Pending'. | 2017-11-01 14:07:42
HD Request # 110 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:26. Record interval: 0. Symbol: F.US.DSXZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.FVSX17. ID: 40 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.FVSX17. ID: 593786 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.FVSX17. ID: 40 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.SWZ17. ID: 41 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.SWZ17. ID: 593787 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.SWZ17. ID: 41 | 2017-11-01 14:07:42
CQG FIX Trading | Starting real-time market data updates for: F.US.NKDZ17. ID: 42 | 2017-11-01 14:07:42
CQG FIX Trading | Sending symbol resolution request for F.US.NKDZ17. ID: 593788 | 2017-11-01 14:07:42
CQG FIX Trading | Requesting security definition data for: F.US.NKDZ17. ID: 42 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVSX7. Search Symbol: F.US.FVSX17. Request ID: 593786. Contract ID: 32. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.FVSX17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.SWZ7. Search Symbol: F.US.SWZ17. Request ID: 593787. Contract ID: 33. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.SWZ17 | 2017-11-01 14:07:42
CQG FIX Trading | Received symbol resolution report for symbol F.US.NKDZ7. Search Symbol: F.US.NKDZ17. Request ID: 593788. Contract ID: 34. | 2017-11-01 14:07:42
CQG FIX Trading | Requesting market data for F.US.NKDZ17 | 2017-11-01 14:07:42
Symbol Error - F.US.MX6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:07:42
SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2017-11-01 14:07:43
HD Request # 110 | Decompressing data. | 2017-11-01 14:07:43
HD Request # 110 | Receiving Intraday data for F.US.DSXZ17 starting at 2017-11-01 14:07:26 | 2017-11-01 14:07:43
HD Request # 110 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:29 | 2017-11-01 14:07:43
Socket (178) | Initiating close of socket by core. | 2017-11-01 14:07:43
Socket (178) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:43
Historical data download thread signaled to stop. | 2017-11-01 14:07:43
HD Request # 110 | Received 6 records from 2017-11-01 14:07:26 to 2017-11-01 14:07:45 (19.0 seconds) and wrote 5 records for F.US.DSXZ17 | 2017-11-01 14:07:43
HD Request # 110 | Intraday download COMPLETE for F.US.DSXZ17. Completion time: 0s. Unique request ID: 117 | 2017-11-01 14:07:43
Removed historical data download ID 117 | 2017-11-01 14:07:43
Real-time Intraday chart data file updates started for F.US.DSXZ17 | 2017-11-01 14:07:43
Intraday chart data file opened for F.US.DSXZ17 | 2017-11-01 14:07:43
Delaying start of download for F.US.JY6Z17 | 2017-11-01 14:07:43
Socket (178) | Socket gracefully closed by remote side. | 2017-11-01 14:07:43
Socket (178) | Closed. | 2017-11-01 14:07:43
Delaying start of download for F.US.MJYZ17 | 2017-11-01 14:07:43
HD Request # 111 | Downloading Intraday chart data for F.US.JY6Z17 to the file F.US.JY6Z17.scid. Service: cqg | 2017-11-01 14:07:46
HD Request # 111 | Download start date-time: 2017-11-01 14:07:22.000 | 2017-11-01 14:07:46
HD Request # 111 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:07:46
Socket (179) | Creating socket. | 2017-11-01 14:07:46
Socket (179) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:07:46
HD Request # 111 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:47
HD Request # 111 | Sending historical data logon request message. | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.BP6Z17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.BP6Z17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.CLEZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.CLEZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.DGZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.DGZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.DLZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.DLZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.ENQZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.ENQZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.EU6Z17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.EU6Z17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.FBTPZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.FBTPZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.FDXMZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.FDXMZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.FGBXZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.FGBXZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.FOATZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.FOATZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.GMCDZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.GMCDZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.JY6Z17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.JY6Z17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.M6AZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.M6AZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.M6BZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.M6BZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.M6EZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.M6EZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.MJYZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.MJYZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.MX6M17 if supported. | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.NE6Z17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.NE6Z17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.TYAZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.TYAZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.USAZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.USAZ17 | 2017-11-01 14:07:47
Requesting market depth updates for: F.US.YMZ17 if supported. | 2017-11-01 14:07:47
CQG FIX Trading | Requesting market data including full depth for F.US.YMZ17 | 2017-11-01 14:07:47
HD Request # 111 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:22. Record interval: 0. Symbol: F.US.JY6Z17 | 2017-11-01 14:07:47
HD Request # 111 | Decompressing data. | 2017-11-01 14:07:47
HD Request # 111 | Receiving Intraday data for F.US.JY6Z17 starting at 2017-11-01 14:07:22 | 2017-11-01 14:07:47
HD Request # 111 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:28 | 2017-11-01 14:07:47
Socket (179) | Initiating close of socket by core. | 2017-11-01 14:07:47
Socket (179) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:47
Historical data download thread signaled to stop. | 2017-11-01 14:07:47
HD Request # 111 | Received 42 records from 2017-11-01 14:07:22 to 2017-11-01 14:07:43 (21.0 seconds) and wrote 38 records for F.US.JY6Z17 | 2017-11-01 14:07:47
HD Request # 111 | Intraday download COMPLETE for F.US.JY6Z17. Completion time: 1s. Unique request ID: 118 | 2017-11-01 14:07:47
Removed historical data download ID 118 | 2017-11-01 14:07:47
Real-time Intraday chart data file updates started for F.US.JY6Z17 | 2017-11-01 14:07:47
Intraday chart data file opened for F.US.JY6Z17 | 2017-11-01 14:07:47
HD Request # 112 | Downloading Intraday chart data for F.US.DBZ17 to the file F.US.DBZ17.scid. Service: cqg | 2017-11-01 14:07:47
HD Request # 112 | Download start date-time: 2017-11-01 14:07:15.000 | 2017-11-01 14:07:47
HD Request # 112 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:07:47
Socket (180) | Creating socket. | 2017-11-01 14:07:47
Socket (180) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:07:47
Socket (179) | Socket gracefully closed by remote side. | 2017-11-01 14:07:47
Socket (179) | Closed. | 2017-11-01 14:07:47
HD Request # 112 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:47
HD Request # 112 | Sending historical data logon request message. | 2017-11-01 14:07:47
HD Request # 112 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:15. Record interval: 0. Symbol: F.US.DBZ17 | 2017-11-01 14:07:47
HD Request # 112 | Decompressing data. | 2017-11-01 14:07:47
HD Request # 112 | Receiving Intraday data for F.US.DBZ17 starting at 2017-11-01 14:07:15 | 2017-11-01 14:07:47
HD Request # 112 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:27 | 2017-11-01 14:07:47
Socket (180) | Initiating close of socket by core. | 2017-11-01 14:07:47
Socket (180) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:47
HD Request # 112 | Received 75 records from 2017-11-01 14:07:15 to 2017-11-01 14:07:51 (36.0 seconds) and wrote 73 records for F.US.DBZ17 | 2017-11-01 14:07:47
HD Request # 112 | Intraday download COMPLETE for F.US.DBZ17. Completion time: 0s. Unique request ID: 119 | 2017-11-01 14:07:47
Removed historical data download ID 119 | 2017-11-01 14:07:47
Real-time Intraday chart data file updates started for F.US.DBZ17 | 2017-11-01 14:07:47
Intraday chart data file opened for F.US.DBZ17 | 2017-11-01 14:07:47
HD Request # 113 | Downloading Intraday chart data for F.US.EPZ17 to the file F.US.EPZ17.scid. Service: cqg | 2017-11-01 14:07:47
HD Request # 113 | Download start date-time: 2017-11-01 14:07:24.000 | 2017-11-01 14:07:47
HD Request # 113 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:07:47
Socket (181) | Creating socket. | 2017-11-01 14:07:47
Socket (181) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:07:47
Socket (180) | Socket gracefully closed by remote side. | 2017-11-01 14:07:47
Socket (180) | Closed. | 2017-11-01 14:07:47
HD Request # 114 | Downloading Intraday chart data for F.US.MJYZ17 to the file F.US.MJYZ17.scid. Service: cqg | 2017-11-01 14:07:47
HD Request # 114 | Download start date-time: 2017-11-01 14:06:40.000 | 2017-11-01 14:07:47
HD Request # 114 | Requesting historical Tick data. | 2017-11-01 14:07:47
HD Request # 113 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:48
HD Request # 113 | Sending historical data logon request message. | 2017-11-01 14:07:48
HD Request # 113 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:24. Record interval: 0. Symbol: F.US.EPZ17 | 2017-11-01 14:07:48
HD Request # 114 | Receiving Intraday data for F.US.MJYZ17 starting at 2017-11-01 14:06:40 | 2017-11-01 14:07:48
HD Request # 114 | Timestamp of first Intraday data file record written: 2017-11-01 14:06:58 | 2017-11-01 14:07:48
HD Request # 114 | Received 5 records from 2017-11-01 14:06:40 to 2017-11-01 14:07:46 (66.0 seconds) and wrote 4 records for F.US.MJYZ17 | 2017-11-01 14:07:48
HD Request # 114 | Intraday download COMPLETE for F.US.MJYZ17. Completion time: 1s. Unique request ID: 141 | 2017-11-01 14:07:48
Removed historical data download ID 141 | 2017-11-01 14:07:48
Real-time Intraday chart data file updates started for F.US.MJYZ17 | 2017-11-01 14:07:48
Intraday chart data file opened for F.US.MJYZ17 | 2017-11-01 14:07:48
HD Request # 113 | Decompressing data. | 2017-11-01 14:07:48
HD Request # 113 | Receiving Intraday data for F.US.EPZ17 starting at 2017-11-01 14:07:24 | 2017-11-01 14:07:48
HD Request # 113 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:24 | 2017-11-01 14:07:48
Socket (181) | Initiating close of socket by core. | 2017-11-01 14:07:48
Historical data download thread signaled to stop. | 2017-11-01 14:07:48
Socket (181) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:48
HD Request # 113 | Received 196 records from 2017-11-01 14:07:24 to 2017-11-01 14:07:54 (30.0 seconds) and wrote 195 records for F.US.EPZ17 | 2017-11-01 14:07:48
Added 1 Time and Sales records to Intraday data file for F.US.EPZ17 after download. | 2017-11-01 14:07:48
HD Request # 113 | Intraday download COMPLETE for F.US.EPZ17. Completion time: 1s. Unique request ID: 120 | 2017-11-01 14:07:48
Removed historical data download ID 120 | 2017-11-01 14:07:48
Real-time Intraday chart data file updates started for F.US.EPZ17 | 2017-11-01 14:07:48
Intraday chart data file opened for F.US.EPZ17 | 2017-11-01 14:07:48
HD Request # 115 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2017-11-01 14:07:48
HD Request # 115 | Download start date-time: 2017-11-01 14:07:09.000 | 2017-11-01 14:07:48
HD Request # 115 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:07:48
Socket (182) | Creating socket. | 2017-11-01 14:07:48
Socket (182) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:07:48
Socket (181) | Socket gracefully closed by remote side. | 2017-11-01 14:07:48
Socket (181) | Closed. | 2017-11-01 14:07:48
HD Request # 115 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:48
HD Request # 115 | Sending historical data logon request message. | 2017-11-01 14:07:48
HD Request # 115 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:09. Record interval: 0. Symbol: NISS-NYSE | 2017-11-01 14:07:48
HD Request # 115 | Decompressing data. | 2017-11-01 14:07:48
HD Request # 115 | Receiving Intraday data for NISS-NYSE starting at 2017-11-01 14:07:09 | 2017-11-01 14:07:48
HD Request # 115 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:10 | 2017-11-01 14:07:48
Socket (182) | Initiating close of socket by core. | 2017-11-01 14:07:48
Socket (182) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:48
HD Request # 115 | Received 46 records from 2017-11-01 14:07:09 to 2017-11-01 14:07:54 (45.0 seconds) and wrote 45 records for NISS-NYSE | 2017-11-01 14:07:48
Added 5 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2017-11-01 14:07:48
HD Request # 115 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 121 | 2017-11-01 14:07:48
Removed historical data download ID 121 | 2017-11-01 14:07:48
Real-time Intraday chart data file updates started for NISS-NYSE | 2017-11-01 14:07:48
Intraday chart data file opened for NISS-NYSE | 2017-11-01 14:07:48
HD Request # 116 | Downloading Intraday chart data for F.US.FOATZ17 to the file F.US.FOATZ17.scid. Service: eurex | 2017-11-01 14:07:48
HD Request # 116 | Download start date-time: 2017-11-01 14:07:03.000 | 2017-11-01 14:07:48
HD Request # 116 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 14:07:48
Socket (183) | Creating socket. | 2017-11-01 14:07:48
Socket (183) | Connecting to IP: 8.18.161.133. | 2017-11-01 14:07:48
Socket (182) | Socket gracefully closed by remote side. | 2017-11-01 14:07:48
Socket (182) | Closed. | 2017-11-01 14:07:48
HD Request # 116 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:49
HD Request # 116 | Sending historical data logon request message. | 2017-11-01 14:07:49
HD Request # 116 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:03. Record interval: 0. Symbol: FNZ17 | 2017-11-01 14:07:49
HD Request # 116 | Decompressing data. | 2017-11-01 14:07:50
Socket (183) | Initiating close of socket by core. | 2017-11-01 14:07:50
Socket (183) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:50
Historical data download thread signaled to stop. | 2017-11-01 14:07:50
HD Request # 116 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FOATZ17 | 2017-11-01 14:07:50
HD Request # 116 | Receiving Intraday data for F.US.FOATZ17 starting at 2017-11-01 14:07:51 | 2017-11-01 14:07:50
HD Request # 116 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:51 | 2017-11-01 14:07:50
Added 11 Time and Sales records to Intraday data file for F.US.FOATZ17 after download. | 2017-11-01 14:07:50
HD Request # 116 | Intraday download COMPLETE for F.US.FOATZ17. Completion time: 2s. Unique request ID: 122 | 2017-11-01 14:07:50
Removed historical data download ID 122 | 2017-11-01 14:07:50
Real-time Intraday chart data file updates started for F.US.FOATZ17 | 2017-11-01 14:07:50
Intraday chart data file opened for F.US.FOATZ17 | 2017-11-01 14:07:50
HD Request # 117 | Downloading Intraday chart data for F.US.DSXZ16 to the file F.US.DSXZ16.scid. Service: eurex | 2017-11-01 14:07:50
HD Request # 117 | Download start date-time: 2016-12-16 10:59:59.000 | 2017-11-01 14:07:50
HD Request # 117 | Using server: ds1.sierracharts.com port 10149 | 2017-11-01 14:07:50
Socket (184) | Creating socket. | 2017-11-01 14:07:50
Socket (184) | Connecting to IP: 8.18.161.135. | 2017-11-01 14:07:50
Socket (183) | Socket gracefully closed by remote side. | 2017-11-01 14:07:50
Socket (183) | Closed. | 2017-11-01 14:07:50
HD Request # 117 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:50
HD Request # 117 | Sending historical data logon request message. | 2017-11-01 14:07:50
HD Request # 117 | Requesting Intraday data. Start date-time: 2016-12-16 10:59:59. Record interval: 0. Symbol: FXZ16 | 2017-11-01 14:07:50
HD Request # 117 | Decompressing data. | 2017-11-01 14:07:50
HD Request # 117 | Receiving Intraday data for F.US.DSXZ16 starting at 2016-12-16 10:59:59 | 2017-11-01 14:07:50
Socket (184) | Initiating close of socket by core. | 2017-11-01 14:07:50
Socket (184) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:50
HD Request # 117 | Received 1 record from 2016-12-16 10:59:59 to 2016-12-16 10:59:59 (0.0 seconds) and wrote 0 records for F.US.DSXZ16 | 2017-11-01 14:07:50
HD Request # 117 | Intraday download COMPLETE for F.US.DSXZ16. Completion time: 0s. Unique request ID: 123 | 2017-11-01 14:07:50
Removed historical data download ID 123 | 2017-11-01 14:07:50
Real-time Intraday chart data file updates started for F.US.DSXZ16 | 2017-11-01 14:07:50
Intraday chart data file opened for F.US.DSXZ16 | 2017-11-01 14:07:50
HD Request # 118 | Downloading Intraday chart data for F.US.TYAZ17 to the file F.US.TYAZ17.scid. Service: cqg | 2017-11-01 14:07:50
HD Request # 118 | Download start date-time: 2017-11-01 14:07:20.000 | 2017-11-01 14:07:50
HD Request # 118 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:07:50
Socket (185) | Creating socket. | 2017-11-01 14:07:50
Socket (185) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:07:50
Socket (184) | Socket gracefully closed by remote side. | 2017-11-01 14:07:51
Socket (184) | Closed. | 2017-11-01 14:07:51
HD Request # 118 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:51
HD Request # 118 | Sending historical data logon request message. | 2017-11-01 14:07:51
HD Request # 118 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:20. Record interval: 0. Symbol: F.US.TYAZ17 | 2017-11-01 14:07:51
HD Request # 118 | Decompressing data. | 2017-11-01 14:07:51
HD Request # 118 | Receiving Intraday data for F.US.TYAZ17 starting at 2017-11-01 14:07:20 | 2017-11-01 14:07:51
HD Request # 118 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:20 | 2017-11-01 14:07:51
Socket (185) | Initiating close of socket by core. | 2017-11-01 14:07:51
Socket (185) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:51
Historical data download thread signaled to stop. | 2017-11-01 14:07:51
HD Request # 118 | Received 55 records from 2017-11-01 14:07:20 to 2017-11-01 14:07:42 (22.0 seconds) and wrote 54 records for F.US.TYAZ17 | 2017-11-01 14:07:51
HD Request # 118 | Intraday download COMPLETE for F.US.TYAZ17. Completion time: 1s. Unique request ID: 124 | 2017-11-01 14:07:51
Removed historical data download ID 124 | 2017-11-01 14:07:51
Real-time Intraday chart data file updates started for F.US.TYAZ17 | 2017-11-01 14:07:51
Intraday chart data file opened for F.US.TYAZ17 | 2017-11-01 14:07:51
HD Request # 119 | Downloading Intraday chart data for F.US.DDZ17 to the file F.US.DDZ17.scid. Service: cqg | 2017-11-01 14:07:51
HD Request # 119 | Download start date-time: 2017-11-01 14:07:22.000 | 2017-11-01 14:07:51
HD Request # 119 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:07:51
Socket (186) | Creating socket. | 2017-11-01 14:07:51
Socket (186) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:07:51
Socket (185) | Socket gracefully closed by remote side. | 2017-11-01 14:07:51
Socket (185) | Closed. | 2017-11-01 14:07:51
HD Request # 119 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:51
HD Request # 119 | Sending historical data logon request message. | 2017-11-01 14:07:51
HD Request # 119 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:22. Record interval: 0. Symbol: F.US.DDZ17 | 2017-11-01 14:07:51
HD Request # 119 | Decompressing data. | 2017-11-01 14:07:51
HD Request # 119 | Receiving Intraday data for F.US.DDZ17 starting at 2017-11-01 14:07:28 | 2017-11-01 14:07:51
HD Request # 119 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:28 | 2017-11-01 14:07:51
Socket (186) | Initiating close of socket by core. | 2017-11-01 14:07:51
Socket (186) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:51
HD Request # 119 | Received 18 records from 2017-11-01 14:07:28 to 2017-11-01 14:07:57 (29.0 seconds) and wrote 18 records for F.US.DDZ17 | 2017-11-01 14:07:51
Added 2 Time and Sales records to Intraday data file for F.US.DDZ17 after download. | 2017-11-01 14:07:51
HD Request # 119 | Intraday download COMPLETE for F.US.DDZ17. Completion time: 0s. Unique request ID: 125 | 2017-11-01 14:07:51
Removed historical data download ID 125 | 2017-11-01 14:07:51
Real-time Intraday chart data file updates started for F.US.DDZ17 | 2017-11-01 14:07:51
Intraday chart data file opened for F.US.DDZ17 | 2017-11-01 14:07:51
HD Request # 120 | Downloading Intraday chart data for F.US.BP6Z17 to the file F.US.BP6Z17.scid. Service: cqg | 2017-11-01 14:07:51
HD Request # 120 | Download start date-time: 2017-11-01 14:07:24.000 | 2017-11-01 14:07:51
HD Request # 120 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:07:51
Socket (187) | Creating socket. | 2017-11-01 14:07:51
Socket (187) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:07:51
Socket (186) | Socket gracefully closed by remote side. | 2017-11-01 14:07:51
Socket (186) | Closed. | 2017-11-01 14:07:51
HD Request # 120 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:52
HD Request # 120 | Sending historical data logon request message. | 2017-11-01 14:07:52
HD Request # 120 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:24. Record interval: 0. Symbol: F.US.BP6Z17 | 2017-11-01 14:07:52
HD Request # 120 | Decompressing data. | 2017-11-01 14:07:52
HD Request # 120 | Receiving Intraday data for F.US.BP6Z17 starting at 2017-11-01 14:07:24 | 2017-11-01 14:07:52
HD Request # 120 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:28 | 2017-11-01 14:07:52
Socket (187) | Initiating close of socket by core. | 2017-11-01 14:07:52
Socket (187) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:52
Historical data download thread signaled to stop. | 2017-11-01 14:07:52
HD Request # 120 | Received 50 records from 2017-11-01 14:07:24 to 2017-11-01 14:07:58 (34.0 seconds) and wrote 47 records for F.US.BP6Z17 | 2017-11-01 14:07:52
HD Request # 120 | Intraday download COMPLETE for F.US.BP6Z17. Completion time: 0s. Unique request ID: 126 | 2017-11-01 14:07:52
Removed historical data download ID 126 | 2017-11-01 14:07:52
Real-time Intraday chart data file updates started for F.US.BP6Z17 | 2017-11-01 14:07:52
Intraday chart data file opened for F.US.BP6Z17 | 2017-11-01 14:07:52
HD Request # 121 | Downloading Intraday chart data for F.US.YMZ17 to the file F.US.YMZ17.scid. Service: cqg | 2017-11-01 14:07:52
HD Request # 121 | Download start date-time: 2017-11-01 14:07:24.000 | 2017-11-01 14:07:52
HD Request # 121 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:07:52
Socket (188) | Creating socket. | 2017-11-01 14:07:52
Socket (188) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:07:52
Socket (187) | Socket gracefully closed by remote side. | 2017-11-01 14:07:52
Socket (187) | Closed. | 2017-11-01 14:07:52
HD Request # 121 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:52
HD Request # 121 | Sending historical data logon request message. | 2017-11-01 14:07:52
DTC Client socket (171) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 14:07:52 *
DTC Client socket (171) | Write has completed. Shutdown being performed. | 2017-11-01 14:07:52
DTC Client socket (171) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:52
DTC Client socket (171) | Socket gracefully closed by remote side. | 2017-11-01 14:07:52
DTC Client socket (171) | Closed. | 2017-11-01 14:07:52
HD Request # 121 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:24. Record interval: 0. Symbol: F.US.YMZ17 | 2017-11-01 14:07:52
HD Request # 121 | Decompressing data. | 2017-11-01 14:07:52
HD Request # 121 | Receiving Intraday data for F.US.YMZ17 starting at 2017-11-01 14:07:24 | 2017-11-01 14:07:52
HD Request # 121 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:27 | 2017-11-01 14:07:52
Socket (188) | Initiating close of socket by core. | 2017-11-01 14:07:52
Socket (188) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:52
HD Request # 121 | Received 162 records from 2017-11-01 14:07:24 to 2017-11-01 14:07:59 (35.0 seconds) and wrote 159 records for F.US.YMZ17 | 2017-11-01 14:07:52
HD Request # 121 | Intraday download COMPLETE for F.US.YMZ17. Completion time: 0s. Unique request ID: 127 | 2017-11-01 14:07:52
Removed historical data download ID 127 | 2017-11-01 14:07:52
Real-time Intraday chart data file updates started for F.US.YMZ17 | 2017-11-01 14:07:52
Intraday chart data file opened for F.US.YMZ17 | 2017-11-01 14:07:52
HD Request # 122 | Downloading Intraday chart data for F.US.DA6Z17 to the file F.US.DA6Z17.scid. Service: cqg | 2017-11-01 14:07:52
HD Request # 122 | Download start date-time: 2017-11-01 14:07:24.000 | 2017-11-01 14:07:52
HD Request # 122 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:07:52
Socket (189) | Creating socket. | 2017-11-01 14:07:52
Socket (189) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:07:52
Socket (188) | Socket gracefully closed by remote side. | 2017-11-01 14:07:52
Socket (188) | Closed. | 2017-11-01 14:07:52
HD Request # 122 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:53
HD Request # 122 | Sending historical data logon request message. | 2017-11-01 14:07:53
HD Request # 122 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:24. Record interval: 0. Symbol: F.US.DA6Z17 | 2017-11-01 14:07:53
HD Request # 122 | Decompressing data. | 2017-11-01 14:07:53
HD Request # 122 | Receiving Intraday data for F.US.DA6Z17 starting at 2017-11-01 14:07:24 | 2017-11-01 14:07:53
HD Request # 122 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:28 | 2017-11-01 14:07:53
Socket (189) | Initiating close of socket by core. | 2017-11-01 14:07:53
Socket (189) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:53
Historical data download thread signaled to stop. | 2017-11-01 14:07:53
HD Request # 122 | Received 49 records from 2017-11-01 14:07:24 to 2017-11-01 14:07:59 (35.0 seconds) and wrote 46 records for F.US.DA6Z17 | 2017-11-01 14:07:53
Added 1 Time and Sales records to Intraday data file for F.US.DA6Z17 after download. | 2017-11-01 14:07:53
HD Request # 122 | Intraday download COMPLETE for F.US.DA6Z17. Completion time: 1s. Unique request ID: 128 | 2017-11-01 14:07:53
Removed historical data download ID 128 | 2017-11-01 14:07:53
Real-time Intraday chart data file updates started for F.US.DA6Z17 | 2017-11-01 14:07:53
Intraday chart data file opened for F.US.DA6Z17 | 2017-11-01 14:07:53
HD Request # 123 | Downloading Intraday chart data for F.US.NE6Z17 to the file F.US.NE6Z17.scid. Service: cqg | 2017-11-01 14:07:53
HD Request # 123 | Download start date-time: 2017-11-01 14:07:11.000 | 2017-11-01 14:07:53
HD Request # 123 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:07:53
Socket (190) | Creating socket. | 2017-11-01 14:07:53
Socket (190) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:07:53
Opened cached Intraday file: C:\SierraChart\Data\F.US.DSXZ17.scid | 2017-11-01 14:07:53
Opened cached Intraday file: C:\SierraChart\Data\F.US.JY6Z17.scid | 2017-11-01 14:07:53
Opened cached Intraday file: C:\SierraChart\Data\F.US.DBZ17.scid | 2017-11-01 14:07:53
Opened cached Intraday file: C:\SierraChart\Data\F.US.EPZ17.scid | 2017-11-01 14:07:53
Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2017-11-01 14:07:53
Opened cached Intraday file: C:\SierraChart\Data\F.US.FOATZ17.scid | 2017-11-01 14:07:53
Opened cached Intraday file: C:\SierraChart\Data\F.US.DDZ17.scid | 2017-11-01 14:07:53
Opened cached Intraday file: C:\SierraChart\Data\F.US.BP6Z17.scid | 2017-11-01 14:07:53
Opened cached Intraday file: C:\SierraChart\Data\F.US.YMZ17.scid | 2017-11-01 14:07:53
Socket (189) | Socket gracefully closed by remote side. | 2017-11-01 14:07:53
Socket (189) | Closed. | 2017-11-01 14:07:53
HD Request # 123 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:53
HD Request # 123 | Sending historical data logon request message. | 2017-11-01 14:07:53
HD Request # 123 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:11. Record interval: 0. Symbol: F.US.NE6Z17 | 2017-11-01 14:07:53
HD Request # 123 | Decompressing data. | 2017-11-01 14:07:54
HD Request # 123 | Receiving Intraday data for F.US.NE6Z17 starting at 2017-11-01 14:07:11 | 2017-11-01 14:07:54
HD Request # 123 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:16 | 2017-11-01 14:07:54
Socket (190) | Initiating close of socket by core. | 2017-11-01 14:07:54
Socket (190) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:54
Historical data download thread signaled to stop. | 2017-11-01 14:07:54
HD Request # 123 | Received 6 records from 2017-11-01 14:07:11 to 2017-11-01 14:07:51 (40.0 seconds) and wrote 2 records for F.US.NE6Z17 | 2017-11-01 14:07:54
HD Request # 123 | Intraday download COMPLETE for F.US.NE6Z17. Completion time: 0s. Unique request ID: 129 | 2017-11-01 14:07:54
Removed historical data download ID 129 | 2017-11-01 14:07:54
Real-time Intraday chart data file updates started for F.US.NE6Z17 | 2017-11-01 14:07:54
Intraday chart data file opened for F.US.NE6Z17 | 2017-11-01 14:07:54
HD Request # 124 | Downloading Intraday chart data for F.US.CA6Z17 to the file F.US.CA6Z17.scid. Service: cqg | 2017-11-01 14:07:54
HD Request # 124 | Download start date-time: 2017-11-01 14:07:23.000 | 2017-11-01 14:07:54
HD Request # 124 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:07:54
Socket (191) | Creating socket. | 2017-11-01 14:07:54
Socket (191) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:07:54
Socket (190) | Socket gracefully closed by remote side. | 2017-11-01 14:07:54
Socket (190) | Closed. | 2017-11-01 14:07:54
HD Request # 124 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:54
HD Request # 124 | Sending historical data logon request message. | 2017-11-01 14:07:54
HD Request # 124 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:23. Record interval: 0. Symbol: F.US.CA6Z17 | 2017-11-01 14:07:54
HD Request # 124 | Decompressing data. | 2017-11-01 14:07:54
HD Request # 124 | Receiving Intraday data for F.US.CA6Z17 starting at 2017-11-01 14:07:23 | 2017-11-01 14:07:54
HD Request # 124 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:32 | 2017-11-01 14:07:54
Socket (191) | Initiating close of socket by core. | 2017-11-01 14:07:54
Socket (191) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:54
HD Request # 124 | Received 26 records from 2017-11-01 14:07:23 to 2017-11-01 14:07:58 (35.0 seconds) and wrote 25 records for F.US.CA6Z17 | 2017-11-01 14:07:54
Added 11 Time and Sales records to Intraday data file for F.US.CA6Z17 after download. | 2017-11-01 14:07:54
HD Request # 124 | Intraday download COMPLETE for F.US.CA6Z17. Completion time: 0s. Unique request ID: 130 | 2017-11-01 14:07:54
Removed historical data download ID 130 | 2017-11-01 14:07:54
Real-time Intraday chart data file updates started for F.US.CA6Z17 | 2017-11-01 14:07:54
Intraday chart data file opened for F.US.CA6Z17 | 2017-11-01 14:07:54
HD Request # 125 | Downloading Intraday chart data for F.US.MX6Z17 to the file F.US.MX6Z17.scid. Service: cqg | 2017-11-01 14:07:54
HD Request # 125 | Download start date-time: 2017-11-01 14:07:23.000 | 2017-11-01 14:07:54
HD Request # 125 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:07:54
Socket (192) | Creating socket. | 2017-11-01 14:07:54
Socket (192) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:07:54
Socket (191) | Socket gracefully closed by remote side. | 2017-11-01 14:07:54
Socket (191) | Closed. | 2017-11-01 14:07:54
HD Request # 125 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:54
HD Request # 125 | Sending historical data logon request message. | 2017-11-01 14:07:54
HD Request # 125 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:23. Record interval: 0. Symbol: F.US.MX6Z17 | 2017-11-01 14:07:54
HD Request # 125 | Decompressing data. | 2017-11-01 14:07:54
HD Request # 125 | Receiving Intraday data for F.US.MX6Z17 starting at 2017-11-01 14:07:23 | 2017-11-01 14:07:54
HD Request # 125 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:23 | 2017-11-01 14:07:54
Socket (192) | Initiating close of socket by core. | 2017-11-01 14:07:54
Socket (192) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:54
HD Request # 125 | Received 59 records from 2017-11-01 14:07:23 to 2017-11-01 14:08:01 (38.0 seconds) and wrote 30 records for F.US.MX6Z17 | 2017-11-01 14:07:54
HD Request # 125 | Intraday download COMPLETE for F.US.MX6Z17. Completion time: 0s. Unique request ID: 131 | 2017-11-01 14:07:54
Removed historical data download ID 131 | 2017-11-01 14:07:54
Real-time Intraday chart data file updates started for F.US.MX6Z17 | 2017-11-01 14:07:54
Intraday chart data file opened for F.US.MX6Z17 | 2017-11-01 14:07:54
HD Request # 126 | Downloading Intraday chart data for F.US.EU6Z17 to the file F.US.EU6Z17.scid. Service: cqg | 2017-11-01 14:07:54
HD Request # 126 | Download start date-time: 2017-11-01 14:07:26.000 | 2017-11-01 14:07:54
HD Request # 126 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:07:54
Socket (193) | Creating socket. | 2017-11-01 14:07:54
Socket (193) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:07:54
Socket (192) | Socket gracefully closed by remote side. | 2017-11-01 14:07:55
Socket (192) | Closed. | 2017-11-01 14:07:55
HD Request # 126 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:55
HD Request # 126 | Sending historical data logon request message. | 2017-11-01 14:07:55
HD Request # 126 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:26. Record interval: 0. Symbol: F.US.EU6Z17 | 2017-11-01 14:07:55
HD Request # 126 | Decompressing data. | 2017-11-01 14:07:55
HD Request # 126 | Receiving Intraday data for F.US.EU6Z17 starting at 2017-11-01 14:07:26 | 2017-11-01 14:07:55
HD Request # 126 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:26 | 2017-11-01 14:07:55
Socket (193) | Initiating close of socket by core. | 2017-11-01 14:07:55
Socket (193) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:55
Historical data download thread signaled to stop. | 2017-11-01 14:07:55
HD Request # 126 | Received 175 records from 2017-11-01 14:07:26 to 2017-11-01 14:08:01 (35.0 seconds) and wrote 174 records for F.US.EU6Z17 | 2017-11-01 14:07:55
HD Request # 126 | Intraday download COMPLETE for F.US.EU6Z17. Completion time: 1s. Unique request ID: 132 | 2017-11-01 14:07:55
Removed historical data download ID 132 | 2017-11-01 14:07:55
Real-time Intraday chart data file updates started for F.US.EU6Z17 | 2017-11-01 14:07:55
Intraday chart data file opened for F.US.EU6Z17 | 2017-11-01 14:07:55
HD Request # 127 | Downloading Intraday chart data for F.US.DDZ16 to the file F.US.DDZ16.scid. Service: eurex | 2017-11-01 14:07:55
HD Request # 127 | Download start date-time: 2016-12-16 11:59:55.000 | 2017-11-01 14:07:55
HD Request # 127 | Using server: ds7.sierracharts.com port 10149 | 2017-11-01 14:07:55
Socket (194) | Creating socket. | 2017-11-01 14:07:55
Socket (194) | Connecting to IP: 8.18.161.133. | 2017-11-01 14:07:55
Socket (193) | Socket gracefully closed by remote side. | 2017-11-01 14:07:55
Socket (193) | Closed. | 2017-11-01 14:07:55
HD Request # 127 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:58
HD Request # 127 | Sending historical data logon request message. | 2017-11-01 14:07:58
HD Request # 127 | Requesting Intraday data. Start date-time: 2016-12-16 11:59:55. Record interval: 0. Symbol: DYZ16 | 2017-11-01 14:07:59
HD Request # 127 | Decompressing data. | 2017-11-01 14:07:59
HD Request # 127 | Receiving Intraday data for F.US.DDZ16 starting at 2016-12-16 11:59:55 | 2017-11-01 14:07:59
Socket (194) | Initiating close of socket by core. | 2017-11-01 14:07:59
Socket (194) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:59
Historical data download thread signaled to stop. | 2017-11-01 14:07:59
HD Request # 127 | Received 1 record from 2016-12-16 11:59:55 to 2016-12-16 11:59:55 (0.0 seconds) and wrote 0 records for F.US.DDZ16 | 2017-11-01 14:07:59
HD Request # 127 | Intraday download COMPLETE for F.US.DDZ16. Completion time: 3s. Unique request ID: 133 | 2017-11-01 14:07:59
Removed historical data download ID 133 | 2017-11-01 14:07:59
Real-time Intraday chart data file updates started for F.US.DDZ16 | 2017-11-01 14:07:59
Intraday chart data file opened for F.US.DDZ16 | 2017-11-01 14:07:59
HD Request # 128 | Downloading Intraday chart data for F.US.DGZ17 to the file F.US.DGZ17.scid. Service: cqg | 2017-11-01 14:07:59
HD Request # 128 | Download start date-time: 2017-11-01 14:07:22.000 | 2017-11-01 14:07:59
HD Request # 128 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:07:59
Socket (196) | Creating socket. | 2017-11-01 14:07:59
Socket (196) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:07:59
Socket (194) | Socket gracefully closed by remote side. | 2017-11-01 14:07:59
Socket (194) | Closed. | 2017-11-01 14:07:59
HD Request # 128 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:59
HD Request # 128 | Sending historical data logon request message. | 2017-11-01 14:07:59
HD Request # 128 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:22. Record interval: 0. Symbol: F.US.DGZ17 | 2017-11-01 14:07:59
HD Request # 128 | Decompressing data. | 2017-11-01 14:07:59
HD Request # 128 | Receiving Intraday data for F.US.DGZ17 starting at 2017-11-01 14:07:22 | 2017-11-01 14:07:59
HD Request # 128 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:29 | 2017-11-01 14:07:59
Socket (196) | Initiating close of socket by core. | 2017-11-01 14:07:59
Socket (196) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:07:59
HD Request # 128 | Received 5 records from 2017-11-01 14:07:22 to 2017-11-01 14:08:04 (42.0 seconds) and wrote 4 records for F.US.DGZ17 | 2017-11-01 14:07:59
HD Request # 128 | Intraday download COMPLETE for F.US.DGZ17. Completion time: 1s. Unique request ID: 134 | 2017-11-01 14:07:59
Removed historical data download ID 134 | 2017-11-01 14:07:59
Real-time Intraday chart data file updates started for F.US.DGZ17 | 2017-11-01 14:07:59
Intraday chart data file opened for F.US.DGZ17 | 2017-11-01 14:07:59
HD Request # 129 | Downloading Intraday chart data for F.US.DLZ17 to the file F.US.DLZ17.scid. Service: cqg | 2017-11-01 14:07:59
HD Request # 129 | Download start date-time: 2017-11-01 14:07:21.000 | 2017-11-01 14:07:59
HD Request # 129 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:07:59
Socket (197) | Creating socket. | 2017-11-01 14:07:59
Socket (197) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:07:59
Socket (196) | Socket gracefully closed by remote side. | 2017-11-01 14:07:59
Socket (196) | Closed. | 2017-11-01 14:07:59
HD Request # 129 | Setting DTC encoding to Binary VLS | 2017-11-01 14:07:59
HD Request # 129 | Sending historical data logon request message. | 2017-11-01 14:07:59
HD Request # 129 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:21. Record interval: 0. Symbol: F.US.DLZ17 | 2017-11-01 14:08:00
HD Request # 129 | Decompressing data. | 2017-11-01 14:08:01
HD Request # 129 | Receiving Intraday data for F.US.DLZ17 starting at 2017-11-01 14:07:21 | 2017-11-01 14:08:01
HD Request # 129 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:29 | 2017-11-01 14:08:01
Socket (197) | Initiating close of socket by core. | 2017-11-01 14:08:01
Historical data download thread signaled to stop. | 2017-11-01 14:08:01
Socket (197) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:01
HD Request # 129 | Received 17 records from 2017-11-01 14:07:21 to 2017-11-01 14:08:04 (43.0 seconds) and wrote 16 records for F.US.DLZ17 | 2017-11-01 14:08:01
HD Request # 129 | Intraday download COMPLETE for F.US.DLZ17. Completion time: 0s. Unique request ID: 135 | 2017-11-01 14:08:01
Removed historical data download ID 135 | 2017-11-01 14:08:01
Real-time Intraday chart data file updates started for F.US.DLZ17 | 2017-11-01 14:08:01
Intraday chart data file opened for F.US.DLZ17 | 2017-11-01 14:08:01
HD Request # 130 | Downloading Intraday chart data for F.US.FDXMZ17 to the file F.US.FDXMZ17.scid. Service: cqg | 2017-11-01 14:08:01
HD Request # 130 | Download start date-time: 2017-11-01 14:07:16.000 | 2017-11-01 14:08:01
HD Request # 130 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:08:01
Socket (199) | Creating socket. | 2017-11-01 14:08:01
Socket (199) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:08:01
Socket (197) | Socket gracefully closed by remote side. | 2017-11-01 14:08:01
Socket (197) | Closed. | 2017-11-01 14:08:01
HD Request # 130 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:01
HD Request # 130 | Sending historical data logon request message. | 2017-11-01 14:08:01
HD Request # 130 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:16. Record interval: 0. Symbol: F.US.FDXMZ17 | 2017-11-01 14:08:01
HD Request # 130 | Decompressing data. | 2017-11-01 14:08:02
HD Request # 130 | Receiving Intraday data for F.US.FDXMZ17 starting at 2017-11-01 14:07:16 | 2017-11-01 14:08:02
HD Request # 130 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:29 | 2017-11-01 14:08:02
Socket (199) | Initiating close of socket by core. | 2017-11-01 14:08:02
Socket (199) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:02
Historical data download thread signaled to stop. | 2017-11-01 14:08:02
HD Request # 130 | Received 20 records from 2017-11-01 14:07:16 to 2017-11-01 14:08:04 (48.0 seconds) and wrote 16 records for F.US.FDXMZ17 | 2017-11-01 14:08:02
HD Request # 130 | Intraday download COMPLETE for F.US.FDXMZ17. Completion time: 1s. Unique request ID: 136 | 2017-11-01 14:08:02
Removed historical data download ID 136 | 2017-11-01 14:08:02
Real-time Intraday chart data file updates started for F.US.FDXMZ17 | 2017-11-01 14:08:02
Intraday chart data file opened for F.US.FDXMZ17 | 2017-11-01 14:08:02
HD Request # 131 | Downloading Intraday chart data for F.US.GMCDZ17 to the file F.US.GMCDZ17.scid. Service: cqg | 2017-11-01 14:08:02
HD Request # 131 | Download start date-time: 2017-11-01 14:05:56.000 | 2017-11-01 14:08:02
HD Request # 131 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:08:02
Socket (200) | Creating socket. | 2017-11-01 14:08:02
Socket (200) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:08:02
Socket (199) | Socket gracefully closed by remote side. | 2017-11-01 14:08:02
Socket (199) | Closed. | 2017-11-01 14:08:02
HD Request # 131 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:02
HD Request # 131 | Sending historical data logon request message. | 2017-11-01 14:08:02
HD Request # 131 | Requesting Intraday data. Start date-time: 2017-11-01 14:05:56. Record interval: 0. Symbol: F.US.GMCDZ17 | 2017-11-01 14:08:02
HD Request # 131 | Decompressing data. | 2017-11-01 14:08:02
HD Request # 131 | Receiving Intraday data for F.US.GMCDZ17 starting at 2017-11-01 14:05:56 | 2017-11-01 14:08:02
HD Request # 131 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:39 | 2017-11-01 14:08:02
Socket (200) | Initiating close of socket by core. | 2017-11-01 14:08:02
Socket (200) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:02
HD Request # 131 | Received 4 records from 2017-11-01 14:05:56 to 2017-11-01 14:08:00 (2.1 minutes) and wrote 2 records for F.US.GMCDZ17 | 2017-11-01 14:08:02
HD Request # 131 | Intraday download COMPLETE for F.US.GMCDZ17. Completion time: 0s. Unique request ID: 137 | 2017-11-01 14:08:02
Removed historical data download ID 137 | 2017-11-01 14:08:02
Real-time Intraday chart data file updates started for F.US.GMCDZ17 | 2017-11-01 14:08:02
Intraday chart data file opened for F.US.GMCDZ17 | 2017-11-01 14:08:02
HD Request # 132 | Downloading Intraday chart data for F.US.M6BZ17 to the file F.US.M6BZ17.scid. Service: cqg | 2017-11-01 14:08:02
HD Request # 132 | Download start date-time: 2017-11-01 14:05:23.000 | 2017-11-01 14:08:02
HD Request # 132 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:08:02
Socket (201) | Creating socket. | 2017-11-01 14:08:02
Socket (201) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:08:02
Socket (200) | Socket gracefully closed by remote side. | 2017-11-01 14:08:02
Socket (200) | Closed. | 2017-11-01 14:08:02
HD Request # 132 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:02
HD Request # 132 | Sending historical data logon request message. | 2017-11-01 14:08:02
HD Request # 132 | Requesting Intraday data. Start date-time: 2017-11-01 14:05:23. Record interval: 0. Symbol: F.US.M6BZ17 | 2017-11-01 14:08:02
HD Request # 132 | Decompressing data. | 2017-11-01 14:08:02
HD Request # 132 | Receiving Intraday data for F.US.M6BZ17 starting at 2017-11-01 14:05:23 | 2017-11-01 14:08:02
HD Request # 132 | Timestamp of first Intraday data file record written: 2017-11-01 14:05:57 | 2017-11-01 14:08:02
Socket (201) | Initiating close of socket by core. | 2017-11-01 14:08:02
Socket (201) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:02
HD Request # 132 | Received 10 records from 2017-11-01 14:05:23 to 2017-11-01 14:07:16 (113.0 seconds) and wrote 9 records for F.US.M6BZ17 | 2017-11-01 14:08:02
HD Request # 132 | Intraday download COMPLETE for F.US.M6BZ17. Completion time: 0s. Unique request ID: 138 | 2017-11-01 14:08:02
Removed historical data download ID 138 | 2017-11-01 14:08:02
Real-time Intraday chart data file updates started for F.US.M6BZ17 | 2017-11-01 14:08:02
Intraday chart data file opened for F.US.M6BZ17 | 2017-11-01 14:08:02
HD Request # 133 | Downloading Intraday chart data for F.US.M6EZ17 to the file F.US.M6EZ17.scid. Service: cqg | 2017-11-01 14:08:02
HD Request # 133 | Download start date-time: 2017-11-01 14:07:26.000 | 2017-11-01 14:08:02
HD Request # 133 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:08:02
Socket (202) | Creating socket. | 2017-11-01 14:08:02
Socket (202) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:08:02
Socket (201) | Socket gracefully closed by remote side. | 2017-11-01 14:08:02
Socket (201) | Closed. | 2017-11-01 14:08:02
HD Request # 133 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:02
HD Request # 133 | Sending historical data logon request message. | 2017-11-01 14:08:02
HD Request # 133 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:26. Record interval: 0. Symbol: F.US.M6EZ17 | 2017-11-01 14:08:02
HD Request # 133 | Decompressing data. | 2017-11-01 14:08:03
HD Request # 133 | Receiving Intraday data for F.US.M6EZ17 starting at 2017-11-01 14:07:26 | 2017-11-01 14:08:03
HD Request # 133 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:30 | 2017-11-01 14:08:03
Socket (202) | Initiating close of socket by core. | 2017-11-01 14:08:03
Socket (202) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:03
Historical data download thread signaled to stop. | 2017-11-01 14:08:03
HD Request # 133 | Received 20 records from 2017-11-01 14:07:26 to 2017-11-01 14:08:10 (44.0 seconds) and wrote 16 records for F.US.M6EZ17 | 2017-11-01 14:08:03
HD Request # 133 | Intraday download COMPLETE for F.US.M6EZ17. Completion time: 0s. Unique request ID: 139 | 2017-11-01 14:08:03
Removed historical data download ID 139 | 2017-11-01 14:08:03
Real-time Intraday chart data file updates started for F.US.M6EZ17 | 2017-11-01 14:08:03
Intraday chart data file opened for F.US.M6EZ17 | 2017-11-01 14:08:03
HD Request # 134 | Downloading Intraday chart data for F.US.M6AZ17 to the file F.US.M6AZ17.scid. Service: cme | 2017-11-01 14:08:03
HD Request # 134 | Download start date-time: 2017-11-01 14:07:23.000 | 2017-11-01 14:08:03
HD Request # 134 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 14:08:03
Socket (203) | Creating socket. | 2017-11-01 14:08:03
Socket (203) | Connecting to IP: 8.18.161.135. | 2017-11-01 14:08:03
Socket (202) | Socket gracefully closed by remote side. | 2017-11-01 14:08:03
Socket (202) | Closed. | 2017-11-01 14:08:03
HD Request # 134 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:03
HD Request # 134 | Sending historical data logon request message. | 2017-11-01 14:08:03
HD Request # 134 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:23. Record interval: 0. Symbol: M6AZ17 | 2017-11-01 14:08:03
HD Request # 134 | Decompressing data. | 2017-11-01 14:08:03
Socket (203) | Initiating close of socket by core. | 2017-11-01 14:08:03
Socket (203) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:03
HD Request # 134 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.M6AZ17 | 2017-11-01 14:08:03
HD Request # 134 | Intraday download COMPLETE for F.US.M6AZ17. Completion time: 1s. Unique request ID: 140 | 2017-11-01 14:08:03
Removed historical data download ID 140 | 2017-11-01 14:08:03
Real-time Intraday chart data file updates started for F.US.M6AZ17 | 2017-11-01 14:08:03
Intraday chart data file opened for F.US.M6AZ17 | 2017-11-01 14:08:03
HD Request # 135 | Downloading Intraday chart data for F.US.MX6M17 to the file F.US.MX6M17.scid. Service: cme | 2017-11-01 14:08:03
HD Request # 135 | Download start date-time: 2017-06-19 14:48:49.000 | 2017-11-01 14:08:03
HD Request # 135 | Using server: ds7.sierracharts.com port 10149 | 2017-11-01 14:08:03
Socket (204) | Creating socket. | 2017-11-01 14:08:03
Socket (204) | Connecting to IP: 8.18.161.133. | 2017-11-01 14:08:03
Opened cached Intraday file: C:\SierraChart\Data\F.US.CA6Z17.scid | 2017-11-01 14:08:03
Opened cached Intraday file: C:\SierraChart\Data\F.US.TYAZ17.scid | 2017-11-01 14:08:03
Opened cached Intraday file: C:\SierraChart\Data\F.US.EU6Z17.scid | 2017-11-01 14:08:03
Opened cached Intraday file: C:\SierraChart\Data\F.US.DA6Z17.scid | 2017-11-01 14:08:03
Opened cached Intraday file: C:\SierraChart\Data\F.US.NE6Z17.scid | 2017-11-01 14:08:03
Opened cached Intraday file: C:\SierraChart\Data\F.US.MX6Z17.scid | 2017-11-01 14:08:03
Opened cached Intraday file: C:\SierraChart\Data\F.US.FDXMZ17.scid | 2017-11-01 14:08:03
Socket (203) | Socket gracefully closed by remote side. | 2017-11-01 14:08:04
Socket (203) | Closed. | 2017-11-01 14:08:04
HD Request # 135 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:07
HD Request # 135 | Sending historical data logon request message. | 2017-11-01 14:08:07
HD Request # 135 | Requesting Intraday data. Start date-time: 2017-06-19 14:48:49. Record interval: 0. Symbol: 6MM17 | 2017-11-01 14:08:07
HD Request # 135 | Decompressing data. | 2017-11-01 14:08:07
HD Request # 135 | Receiving Intraday data for F.US.MX6M17 starting at 2017-06-19 14:48:49 | 2017-11-01 14:08:07
Socket (204) | Initiating close of socket by core. | 2017-11-01 14:08:07
Socket (204) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:07
Historical data download thread signaled to stop. | 2017-11-01 14:08:07
HD Request # 135 | Received 4 records from 2017-06-19 14:48:49 to 2017-06-19 14:48:49 (0.0 seconds) and wrote 0 records for F.US.MX6M17 | 2017-11-01 14:08:07
HD Request # 135 | Intraday download COMPLETE for F.US.MX6M17. Completion time: 3s. Unique request ID: 142 | 2017-11-01 14:08:07
Removed historical data download ID 142 | 2017-11-01 14:08:07
Real-time Intraday chart data file updates started for F.US.MX6M17 | 2017-11-01 14:08:07
Intraday chart data file opened for F.US.MX6M17 | 2017-11-01 14:08:07
HD Request # 136 | Downloading Intraday chart data for F.US.CLEZ17 to the file F.US.CLEZ17.scid. Service: cqg | 2017-11-01 14:08:07
HD Request # 136 | Download start date-time: 2017-11-01 14:07:26.000 | 2017-11-01 14:08:07
HD Request # 136 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:08:07
Socket (205) | Creating socket. | 2017-11-01 14:08:07
Socket (205) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:08:07
Socket (204) | Socket gracefully closed by remote side. | 2017-11-01 14:08:07
Socket (204) | Closed. | 2017-11-01 14:08:07
HD Request # 136 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:07
HD Request # 136 | Sending historical data logon request message. | 2017-11-01 14:08:07
HD Request # 136 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:26. Record interval: 0. Symbol: F.US.CLEZ17 | 2017-11-01 14:08:07
HD Request # 136 | Decompressing data. | 2017-11-01 14:08:07
HD Request # 136 | Receiving Intraday data for F.US.CLEZ17 starting at 2017-11-01 14:07:26 | 2017-11-01 14:08:07
HD Request # 136 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:27 | 2017-11-01 14:08:07
Socket (205) | Initiating close of socket by core. | 2017-11-01 14:08:07
Socket (205) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:07
HD Request # 136 | Received 513 records from 2017-11-01 14:07:26 to 2017-11-01 14:08:13 (47.0 seconds) and wrote 512 records for F.US.CLEZ17 | 2017-11-01 14:08:07
Added 2 Time and Sales records to Intraday data file for F.US.CLEZ17 after download. | 2017-11-01 14:08:07
HD Request # 136 | Intraday download COMPLETE for F.US.CLEZ17. Completion time: 1s. Unique request ID: 143 | 2017-11-01 14:08:07
Removed historical data download ID 143 | 2017-11-01 14:08:07
Real-time Intraday chart data file updates started for F.US.CLEZ17 | 2017-11-01 14:08:07
Intraday chart data file opened for F.US.CLEZ17 | 2017-11-01 14:08:07
HD Request # 137 | Downloading Intraday chart data for F.US.USAZ17 to the file F.US.USAZ17.scid. Service: cqg | 2017-11-01 14:08:07
HD Request # 137 | Download start date-time: 2017-11-01 14:07:24.000 | 2017-11-01 14:08:07
HD Request # 137 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:08:07
Socket (206) | Creating socket. | 2017-11-01 14:08:07
Socket (206) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:08:07
Socket (205) | Socket gracefully closed by remote side. | 2017-11-01 14:08:07
Socket (205) | Closed. | 2017-11-01 14:08:07
HD Request # 137 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:08
HD Request # 137 | Sending historical data logon request message. | 2017-11-01 14:08:08
HD Request # 137 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:24. Record interval: 0. Symbol: F.US.USAZ17 | 2017-11-01 14:08:08
HD Request # 137 | Decompressing data. | 2017-11-01 14:08:08
HD Request # 137 | Receiving Intraday data for F.US.USAZ17 starting at 2017-11-01 14:07:24 | 2017-11-01 14:08:08
HD Request # 137 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:24 | 2017-11-01 14:08:08
Socket (206) | Initiating close of socket by core. | 2017-11-01 14:08:08
Socket (206) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:08
Historical data download thread signaled to stop. | 2017-11-01 14:08:08
HD Request # 137 | Received 253 records from 2017-11-01 14:07:24 to 2017-11-01 14:08:12 (48.0 seconds) and wrote 232 records for F.US.USAZ17 | 2017-11-01 14:08:08
HD Request # 137 | Intraday download COMPLETE for F.US.USAZ17. Completion time: 0s. Unique request ID: 144 | 2017-11-01 14:08:08
Removed historical data download ID 144 | 2017-11-01 14:08:08
Real-time Intraday chart data file updates started for F.US.USAZ17 | 2017-11-01 14:08:08
Intraday chart data file opened for F.US.USAZ17 | 2017-11-01 14:08:08
HD Request # 138 | Downloading Intraday chart data for F.US.ENQZ17 to the file F.US.ENQZ17.scid. Service: cqg | 2017-11-01 14:08:08
HD Request # 138 | Download start date-time: 2017-11-01 14:07:20.000 | 2017-11-01 14:08:08
HD Request # 138 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:08:08
Socket (207) | Creating socket. | 2017-11-01 14:08:08
Socket (207) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:08:08
Socket (206) | Socket gracefully closed by remote side. | 2017-11-01 14:08:08
Socket (206) | Closed. | 2017-11-01 14:08:08
HD Request # 138 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:08
HD Request # 138 | Sending historical data logon request message. | 2017-11-01 14:08:08
HD Request # 138 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:20. Record interval: 0. Symbol: F.US.ENQZ17 | 2017-11-01 14:08:09
HD Request # 138 | Decompressing data. | 2017-11-01 14:08:09
HD Request # 138 | Receiving Intraday data for F.US.ENQZ17 starting at 2017-11-01 14:07:20 | 2017-11-01 14:08:09
HD Request # 138 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:26 | 2017-11-01 14:08:09
Socket (207) | Initiating close of socket by core. | 2017-11-01 14:08:09
Socket (207) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:09
Historical data download thread signaled to stop. | 2017-11-01 14:08:09
HD Request # 138 | Received 813 records from 2017-11-01 14:07:20 to 2017-11-01 14:08:15 (55.0 seconds) and wrote 799 records for F.US.ENQZ17 | 2017-11-01 14:08:09
Added 12 Time and Sales records to Intraday data file for F.US.ENQZ17 after download. | 2017-11-01 14:08:09
HD Request # 138 | Intraday download COMPLETE for F.US.ENQZ17. Completion time: 2s. Unique request ID: 145 | 2017-11-01 14:08:09
Removed historical data download ID 145 | 2017-11-01 14:08:09
Real-time Intraday chart data file updates started for F.US.ENQZ17 | 2017-11-01 14:08:09
Intraday chart data file opened for F.US.ENQZ17 | 2017-11-01 14:08:09
HD Request # 139 | Downloading Intraday chart data for F.US.FGBXZ17 to the file F.US.FGBXZ17.scid. Service: cqg | 2017-11-01 14:08:09
HD Request # 139 | Download start date-time: 2017-11-01 14:07:16.000 | 2017-11-01 14:08:09
HD Request # 139 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:08:09
Socket (208) | Creating socket. | 2017-11-01 14:08:09
Socket (208) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:08:09
Socket (207) | Socket gracefully closed by remote side. | 2017-11-01 14:08:09
Socket (207) | Closed. | 2017-11-01 14:08:09
HD Request # 139 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:09
HD Request # 139 | Sending historical data logon request message. | 2017-11-01 14:08:09
HD Request # 139 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:16. Record interval: 0. Symbol: F.US.FGBXZ17 | 2017-11-01 14:08:10
HD Request # 139 | Decompressing data. | 2017-11-01 14:08:10
HD Request # 139 | Receiving Intraday data for F.US.FGBXZ17 starting at 2017-11-01 14:07:44 | 2017-11-01 14:08:10
HD Request # 139 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:44 | 2017-11-01 14:08:10
Socket (208) | Initiating close of socket by core. | 2017-11-01 14:08:10
Socket (208) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:10
Historical data download thread signaled to stop. | 2017-11-01 14:08:10
HD Request # 139 | Received 18 records from 2017-11-01 14:07:44 to 2017-11-01 14:08:13 (29.0 seconds) and wrote 18 records for F.US.FGBXZ17 | 2017-11-01 14:08:10
HD Request # 139 | Intraday download COMPLETE for F.US.FGBXZ17. Completion time: 0s. Unique request ID: 146 | 2017-11-01 14:08:10
Removed historical data download ID 146 | 2017-11-01 14:08:10
Real-time Intraday chart data file updates started for F.US.FGBXZ17 | 2017-11-01 14:08:10
Intraday chart data file opened for F.US.FGBXZ17 | 2017-11-01 14:08:10
HD Request # 140 | Downloading Intraday chart data for F.US.FBTPZ17 to the file F.US.FBTPZ17.scid. Service: eurex | 2017-11-01 14:08:10
HD Request # 140 | Download start date-time: 2017-11-01 14:07:07.000 | 2017-11-01 14:08:10
HD Request # 140 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 14:08:10
Socket (209) | Creating socket. | 2017-11-01 14:08:10
Socket (209) | Connecting to IP: 8.18.161.135. | 2017-11-01 14:08:10
Socket (208) | Socket gracefully closed by remote side. | 2017-11-01 14:08:10
Socket (208) | Closed. | 2017-11-01 14:08:10
HD Request # 140 | Setting DTC encoding to Binary VLS | 2017-11-01 14:08:10
HD Request # 140 | Sending historical data logon request message. | 2017-11-01 14:08:10
HD Request # 140 | Requesting Intraday data. Start date-time: 2017-11-01 14:07:07. Record interval: 0. Symbol: IIZ17 | 2017-11-01 14:08:10
HD Request # 140 | Decompressing data. | 2017-11-01 14:08:10
Socket (209) | Initiating close of socket by core. | 2017-11-01 14:08:10
Socket (209) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:08:10
HD Request # 140 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FBTPZ17 | 2017-11-01 14:08:10
HD Request # 140 | Receiving Intraday data for F.US.FBTPZ17 starting at 2017-11-01 14:07:54 | 2017-11-01 14:08:10
HD Request # 140 | Timestamp of first Intraday data file record written: 2017-11-01 14:07:54 | 2017-11-01 14:08:10
Added 21 Time and Sales records to Intraday data file for F.US.FBTPZ17 after download. | 2017-11-01 14:08:10
HD Request # 140 | Intraday download COMPLETE for F.US.FBTPZ17. Completion time: 0s. Unique request ID: 147 | 2017-11-01 14:08:10
Removed historical data download ID 147 | 2017-11-01 14:08:10
Real-time Intraday chart data file updates started for F.US.FBTPZ17 | 2017-11-01 14:08:10
Intraday chart data file opened for F.US.FBTPZ17 | 2017-11-01 14:08:10
Socket (209) | Socket gracefully closed by remote side. | 2017-11-01 14:08:11
Socket (209) | Closed. | 2017-11-01 14:08:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.DGZ17.scid | 2017-11-01 14:08:13
Opened cached Intraday file: C:\SierraChart\Data\F.US.DLZ17.scid | 2017-11-01 14:08:13
Opened cached Intraday file: C:\SierraChart\Data\F.US.FGBXZ17.scid | 2017-11-01 14:08:13
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6EZ17.scid | 2017-11-01 14:08:13
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6AZ17.scid | 2017-11-01 14:08:13
Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEZ17.scid | 2017-11-01 14:08:13
Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQZ17.scid | 2017-11-01 14:08:13
Opened cached Intraday file: C:\SierraChart\Data\F.US.USAZ17.scid | 2017-11-01 14:08:23
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6BZ17.scid | 2017-11-01 14:08:34
Opened cached Intraday file: C:\SierraChart\Data\F.US.FBTPZ17.scid | 2017-11-01 14:08:44
Opened cached Intraday file: C:\SierraChart\Data\F.US.MJYZ17.scid | 2017-11-01 14:10:05
Opened cached Intraday file: C:\SierraChart\Data\F.US.GMCDZ17.scid | 2017-11-01 14:11:37
F.US.CLEZ17 [CBV] Daily #1 | Reloading chart. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] Daily #1 | Performing historical Daily data download for symbol F.US.CLEZ17 starting at last date in file. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] Daily #1 | Waiting for historical downloads to complete with the IDs: 148, | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] 1 Min #2 | Reloading chart. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] 1 Min #2 | Performing historical Daily data download for symbol CLZ17 starting at last date in file. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 149, | 2017-11-01 14:16:52
F.US.CLEZ17 #3 | Reloading chart. | 2017-11-01 14:16:52
F.US.CPEZ17 [CBV] Daily #5 | Reloading chart. | 2017-11-01 14:16:52
F.US.CPEZ17 [CBV] Daily #5 | Performing historical Daily data download for symbol F.US.CPEZ17 starting at last date in file. | 2017-11-01 14:16:52
F.US.CPEZ17 [CBV] Daily #5 | Waiting for historical downloads to complete with the IDs: 150, | 2017-11-01 14:16:52
F.US.CPEZ17 10 Min #6 | Reloading chart. | 2017-11-01 14:16:52
F.US.GCEZ17 [CBV] Daily #7 | Reloading chart. | 2017-11-01 14:16:52
F.US.GCEZ17 [CBV] Daily #7 | Performing historical Daily data download for symbol F.US.GCEZ17 starting at last date in file. | 2017-11-01 14:16:52
F.US.GCEZ17 [CBV] Daily #7 | Waiting for historical downloads to complete with the IDs: 151, | 2017-11-01 14:16:52
F.US.GCEZ17 15 Min #8 | Reloading chart. | 2017-11-01 14:16:52
F.US.GCEZ17 #9 | Reloading chart. | 2017-11-01 14:16:52
F.US.CPEZ17 #4 | Reloading chart. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] 60 Min #10 | Reloading chart. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] 60 Min #10 | Waiting for historical downloads to complete with the IDs: 149, | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] 1000 Volume #11 | Reloading chart. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] 1000 Volume #11 | Waiting for historical downloads to complete with the IDs: 149, | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] #12 | Reloading chart. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] #12 | Waiting for historical downloads to complete with the IDs: 149, | 2017-11-01 14:16:52
F.US.CLEZ17 Renko 4t #13 | Reloading chart. | 2017-11-01 14:16:52
F.US.CLEZ17 10 Min #14 | Reloading chart. | 2017-11-01 14:16:52
F.US.EU6Z17 #15 | Reloading chart. | 2017-11-01 14:16:52
F.US.EPZ17 #16 | Reloading chart. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] 15 Min #17 | Reloading chart. | 2017-11-01 14:16:52
F.US.CLEZ17 [CBV] 15 Min #17 | Waiting for historical downloads to complete with the IDs: 149, | 2017-11-01 14:16:52
F.US.NQMZ17 #18 | Reloading chart. | 2017-11-01 14:16:52
F.US.MGCZ17 #19 | Reloading chart. | 2017-11-01 14:16:52
+ Loading market depth data. | 2017-11-01 14:16:52
CQG FIX Trading | Starting real-time market data updates for: F.US.RBEZ17. ID: 43 | 2017-11-01 14:16:52
CQG FIX Trading | Sending symbol resolution request for F.US.RBEZ17. ID: 593790 | 2017-11-01 14:16:52
CQG FIX Trading | Requesting security definition data for: F.US.RBEZ17. ID: 43 | 2017-11-01 14:16:52
CQG FIX Trading | Starting real-time market data updates for: F.US.CPEZ17. ID: 44 | 2017-11-01 14:16:52
CQG FIX Trading | Sending symbol resolution request for F.US.CPEZ17. ID: 593791 | 2017-11-01 14:16:52
CQG FIX Trading | Requesting security definition data for: F.US.CPEZ17. ID: 44 | 2017-11-01 14:16:52
CQG FIX Trading | Starting real-time market data updates for: F.US.GCEZ17. ID: 45 | 2017-11-01 14:16:52
CQG FIX Trading | Sending symbol resolution request for F.US.GCEZ17. ID: 593792 | 2017-11-01 14:16:52
CQG FIX Trading | Requesting security definition data for: F.US.GCEZ17. ID: 45 | 2017-11-01 14:16:52
CQG FIX Trading | Starting real-time market data updates for: F.US.SIEZ17. ID: 46 | 2017-11-01 14:16:52
CQG FIX Trading | Sending symbol resolution request for F.US.SIEZ17. ID: 593793 | 2017-11-01 14:16:52
CQG FIX Trading | Requesting security definition data for: F.US.SIEZ17. ID: 46 | 2017-11-01 14:16:52
CQG FIX Trading | Starting real-time market data updates for: F.US.PAEZ17. ID: 47 | 2017-11-01 14:16:52
CQG FIX Trading | Sending symbol resolution request for F.US.PAEZ17. ID: 593794 | 2017-11-01 14:16:52
CQG FIX Trading | Requesting security definition data for: F.US.PAEZ17. ID: 47 | 2017-11-01 14:16:52
CQG FIX Trading | Starting real-time market data updates for: F.US.PLEF18. ID: 48 | 2017-11-01 14:16:52
CQG FIX Trading | Sending symbol resolution request for F.US.PLEF18. ID: 593795 | 2017-11-01 14:16:52
CQG FIX Trading | Requesting security definition data for: F.US.PLEF18. ID: 48 | 2017-11-01 14:16:52
HD Request # 141 | Downloading Historical Daily chart data for F.US.CLEZ17. Starting date: 2017-10-26. Service: cqg | 2017-11-01 14:16:52
HD Request # 141 | Requesting historical Daily data for CLZ17 starting at 2017-10-25 | 2017-11-01 14:16:52
HTTP connection to ds01.ddfplus.com:80 (212) | Creating socket. | 2017-11-01 14:16:52
HTTP connection to ds01.ddfplus.com:80 (212) | Connecting to IP: 8.18.161.123. | 2017-11-01 14:16:52
Loaded depth data records for F.US.CLEZ17 2017-10-27 from 00:00:00 to 00:00:00. | 2017-11-01 14:16:52
CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEZ7. Search Symbol: F.US.RBEZ17. Request ID: 593790. Contract ID: 35. | 2017-11-01 14:16:52
CQG FIX Trading | Requesting market data for F.US.RBEZ17 | 2017-11-01 14:16:52
CQG FIX Trading | Received symbol resolution report for symbol F.US.CPEZ7. Search Symbol: F.US.CPEZ17. Request ID: 593791. Contract ID: 36. | 2017-11-01 14:16:52
CQG FIX Trading | Requesting market data for F.US.CPEZ17 | 2017-11-01 14:16:52
CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEZ7. Search Symbol: F.US.GCEZ17. Request ID: 593792. Contract ID: 37. | 2017-11-01 14:16:52
CQG FIX Trading | Requesting market data for F.US.GCEZ17 | 2017-11-01 14:16:52
CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEZ7. Search Symbol: F.US.SIEZ17. Request ID: 593793. Contract ID: 38. | 2017-11-01 14:16:52
CQG FIX Trading | Requesting market data for F.US.SIEZ17 | 2017-11-01 14:16:52
CQG FIX Trading | Received symbol resolution report for symbol F.US.PAEZ7. Search Symbol: F.US.PAEZ17. Request ID: 593794. Contract ID: 39. | 2017-11-01 14:16:52
CQG FIX Trading | Requesting market data for F.US.PAEZ17 | 2017-11-01 14:16:52
CQG FIX Trading | Received symbol resolution report for symbol F.US.PLEF8. Search Symbol: F.US.PLEF18. Request ID: 593795. Contract ID: 40. | 2017-11-01 14:16:52
CQG FIX Trading | Requesting market data for F.US.PLEF18 | 2017-11-01 14:16:52
Requesting market depth updates for: F.US.CPEZ17 if supported. | 2017-11-01 14:16:59
CQG FIX Trading | Requesting market data including full depth for F.US.CPEZ17 | 2017-11-01 14:16:59
Requesting market depth updates for: F.US.GCEZ17 if supported. | 2017-11-01 14:16:59
CQG FIX Trading | Requesting market data including full depth for F.US.GCEZ17 | 2017-11-01 14:16:59
CQG FIX Trading | Starting real-time market data updates for: F.US.MGCZ17. ID: 49 | 2017-11-01 14:16:59
CQG FIX Trading | Sending symbol resolution request for F.US.MGCZ17. ID: 593796 | 2017-11-01 14:16:59
CQG FIX Trading | Requesting security definition data for: F.US.MGCZ17. ID: 49 | 2017-11-01 14:16:59
Requesting market depth updates for: F.US.MGCZ17 if supported. | 2017-11-01 14:16:59
CQG FIX Trading | Starting real-time market data updates for: F.US.NQMZ17. ID: 50 | 2017-11-01 14:16:59
CQG FIX Trading | Sending symbol resolution request for F.US.NQMZ17. ID: 593797 | 2017-11-01 14:16:59
CQG FIX Trading | Requesting security definition data for: F.US.NQMZ17. ID: 50 | 2017-11-01 14:16:59
Requesting market depth updates for: F.US.NQMZ17 if supported. | 2017-11-01 14:16:59
CQG FIX Trading | Received symbol resolution report for symbol F.US.MGCZ7. Search Symbol: F.US.MGCZ17. Request ID: 593796. Contract ID: 41. | 2017-11-01 14:16:59
CQG FIX Trading | Requesting market data including full depth for F.US.MGCZ17 | 2017-11-01 14:16:59
CQG FIX Trading | Received symbol resolution report for symbol F.US.NQMZ7. Search Symbol: F.US.NQMZ17. Request ID: 593797. Contract ID: 42. | 2017-11-01 14:16:59
CQG FIX Trading | Requesting market data including full depth for F.US.NQMZ17 | 2017-11-01 14:16:59
HD Request # 141 | Receiving historical Daily data for F.US.CLEZ17 starting at 2017-10-26 | 2017-11-01 14:16:59
HD Request # 141 | Writing historical Daily data to the file F.US.CLEZ17.dly | 2017-11-01 14:16:59
HD Request # 141 | Received 6 records from 2017-10-26 00:00:00 to 2017-11-01 00:00:00 (7.0 days) and wrote 5 records for F.US.CLEZ17 | 2017-11-01 14:16:59
HD Request # 141 | Daily download COMPLETE for F.US.CLEZ17. Completion time: 0s. Unique request ID: 148 | 2017-11-01 14:16:59
Removed historical data download ID 148 | 2017-11-01 14:16:59
HD Request # 142 | Downloading Historical Daily chart data for CLZ17. Starting date: 2017-10-26. Service: cqg | 2017-11-01 14:16:59
HD Request # 142 | Requesting historical Daily data for CLZ17 starting at 2017-10-25 | 2017-11-01 14:16:59
Intraday data recording state for symbol F.US.CPEZ17 is set to download 'Pending'. | 2017-11-01 14:16:59
HD Request # 143 | Downloading Intraday chart data for F.US.CPEZ17 to the file F.US.CPEZ17.scid. Service: cqg | 2017-11-01 14:16:59
HD Request # 143 | Download start date-time: 2017-10-27 08:39:00.000 | 2017-11-01 14:16:59
HD Request # 143 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:16:59
Socket (213) | Creating socket. | 2017-11-01 14:16:59
Socket (213) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:16:59
Intraday data recording state for symbol F.US.GCEZ17 is set to download 'Pending'. | 2017-11-01 14:16:59
Intraday data recording state for symbol F.US.NQMZ17 is set to download 'Pending'. | 2017-11-01 14:16:59
Intraday data recording state for symbol F.US.MGCZ17 is set to download 'Pending'. | 2017-11-01 14:16:59
F.US.CLEZ17 [CBV] Daily #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 14:16:59
F.US.CLEZ17 [CBV] Daily #1 | Reloading chart. | 2017-11-01 14:16:59
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.CLEZ17.2017-11-01.depth | 2017-11-01 14:16:59
HD Request # 142 | Receiving historical Daily data for CLZ17 starting at 2017-10-26 | 2017-11-01 14:16:59
HD Request # 142 | Writing historical Daily data to the file CLZ17.dly | 2017-11-01 14:16:59
HD Request # 142 | Received 6 records from 2017-10-26 00:00:00 to 2017-11-01 00:00:00 (7.0 days) and wrote 5 records for CLZ17 | 2017-11-01 14:16:59
HD Request # 142 | Daily download COMPLETE for CLZ17. Completion time: 3s. Unique request ID: 149 | 2017-11-01 14:16:59
Removed historical data download ID 149 | 2017-11-01 14:16:59
HD Request # 144 | Downloading Historical Daily chart data for F.US.CPEZ17. Starting date: 2017-10-26. Service: cqg | 2017-11-01 14:16:59
HD Request # 144 | Requesting historical Daily data for HGZ17 starting at 2017-10-25 | 2017-11-01 14:16:59
F.US.CLEZ17 [CBV] #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] #12 | Reloading chart. | 2017-11-01 14:17:01
HD Request # 144 | Receiving historical Daily data for F.US.CPEZ17 starting at 2017-10-26 | 2017-11-01 14:17:01
HD Request # 144 | Writing historical Daily data to the file F.US.CPEZ17.dly | 2017-11-01 14:17:01
HD Request # 144 | Received 6 records from 2017-10-26 00:00:00 to 2017-11-01 00:00:00 (7.0 days) and wrote 5 records for F.US.CPEZ17 | 2017-11-01 14:17:01
HD Request # 144 | Daily download COMPLETE for F.US.CPEZ17. Completion time: 0s. Unique request ID: 150 | 2017-11-01 14:17:01
Removed historical data download ID 150 | 2017-11-01 14:17:01
HD Request # 145 | Downloading Historical Daily chart data for F.US.GCEZ17. Starting date: 2017-10-26. Service: cqg | 2017-11-01 14:17:01
HD Request # 145 | Requesting historical Daily data for GCZ17 starting at 2017-10-25 | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] 1 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] 1 Min #2 | Reloading chart. | 2017-11-01 14:17:01
HD Request # 145 | Receiving historical Daily data for F.US.GCEZ17 starting at 2017-10-26 | 2017-11-01 14:17:01
HD Request # 145 | Writing historical Daily data to the file F.US.GCEZ17.dly | 2017-11-01 14:17:01
HD Request # 145 | Received 6 records from 2017-10-26 00:00:00 to 2017-11-01 00:00:00 (7.0 days) and wrote 5 records for F.US.GCEZ17 | 2017-11-01 14:17:01
HD Request # 145 | Daily download COMPLETE for F.US.GCEZ17. Completion time: 1s. Unique request ID: 151 | 2017-11-01 14:17:01
Removed historical data download ID 151 | 2017-11-01 14:17:01
HD Request # 143 | Setting DTC encoding to Binary VLS | 2017-11-01 14:17:01
HD Request # 143 | Sending historical data logon request message. | 2017-11-01 14:17:01
F.US.CPEZ17 [CBV] Daily #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 14:17:01
F.US.CPEZ17 [CBV] Daily #5 | Reloading chart. | 2017-11-01 14:17:01
HD Request # 143 | Requesting Intraday data. Start date-time: 2017-10-27 08:39:00. Record interval: 0. Symbol: F.US.CPEZ17 | 2017-11-01 14:17:01
HD Request # 143 | Decompressing data. | 2017-11-01 14:17:01
HD Request # 143 | Receiving Intraday data for F.US.CPEZ17 starting at 2017-10-27 08:39:00 | 2017-11-01 14:17:01
HD Request # 143 | Timestamp of first Intraday data file record written: 2017-10-27 08:39:36 | 2017-11-01 14:17:01
F.US.GCEZ17 [CBV] Daily #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 14:17:01
F.US.GCEZ17 [CBV] Daily #7 | Reloading chart. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] 60 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] 60 Min #10 | Reloading chart. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] 1000 Volume #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] 1000 Volume #11 | Reloading chart. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] 15 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] 15 Min #17 | Reloading chart. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] Daily #1 | Reloading chart. | 2017-11-01 14:17:01
F.US.CLEZ17 [CBV] #12 | Reloading chart. | 2017-11-01 14:17:09
F.US.CLEZ17 [CBV] 1 Min #2 | Reloading chart. | 2017-11-01 14:17:09
F.US.CPEZ17 [CBV] Daily #5 | Reloading chart. | 2017-11-01 14:17:09
Socket (213) | Initiating close of socket by core. | 2017-11-01 14:17:09
Socket (213) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:17:09
Socket (213) | Socket gracefully closed by remote side. | 2017-11-01 14:17:09
Socket (213) | Closed. | 2017-11-01 14:17:09
Historical data download thread signaled to stop. | 2017-11-01 14:17:09
HD Request # 143 | Received 295536 records from 2017-10-27 08:39:00 to 2017-11-01 14:17:09 (5.3 days) and wrote 295533 records for F.US.CPEZ17 | 2017-11-01 14:17:09
Added 8 Time and Sales records to Intraday data file for F.US.CPEZ17 after download. | 2017-11-01 14:17:09
HD Request # 143 | Intraday download COMPLETE for F.US.CPEZ17. Completion time: 13s. Unique request ID: 152 | 2017-11-01 14:17:09
Removed historical data download ID 152 | 2017-11-01 14:17:09
Real-time Intraday chart data file updates started for F.US.CPEZ17 | 2017-11-01 14:17:09
Intraday chart data file opened for F.US.CPEZ17 | 2017-11-01 14:17:09
HD Request # 146 | Downloading Intraday chart data for F.US.GCEZ17 to the file F.US.GCEZ17.scid. Service: cqg | 2017-11-01 14:17:09
HD Request # 146 | Download start date-time: 2017-10-27 08:39:17.000 | 2017-11-01 14:17:09
HD Request # 146 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:17:09
Socket (215) | Creating socket. | 2017-11-01 14:17:09
Socket (215) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:17:09
F.US.GCEZ17 [CBV] Daily #7 | Reloading chart. | 2017-11-01 14:17:09
HD Request # 146 | Setting DTC encoding to Binary VLS | 2017-11-01 14:17:09
HD Request # 146 | Sending historical data logon request message. | 2017-11-01 14:17:09
HD Request # 146 | Requesting Intraday data. Start date-time: 2017-10-27 08:39:17. Record interval: 0. Symbol: F.US.GCEZ17 | 2017-11-01 14:17:09
HD Request # 146 | Decompressing data. | 2017-11-01 14:17:09
F.US.CLEZ17 [CBV] 60 Min #10 | Reloading chart. | 2017-11-01 14:17:09
HD Request # 146 | Receiving Intraday data for F.US.GCEZ17 starting at 2017-10-27 08:39:17 | 2017-11-01 14:17:09
HD Request # 146 | Timestamp of first Intraday data file record written: 2017-10-27 08:39:17 | 2017-11-01 14:17:09
F.US.CLEZ17 [CBV] 1000 Volume #11 | Reloading chart. | 2017-11-01 14:17:09
F.US.CLEZ17 [CBV] 15 Min #17 | Reloading chart. | 2017-11-01 14:17:09
Socket (215) | Initiating close of socket by core. | 2017-11-01 14:17:14
Socket (215) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:17:14
Historical data download thread signaled to stop. | 2017-11-01 14:17:14
HD Request # 146 | Received 694228 records from 2017-10-27 08:39:17 to 2017-11-01 14:17:21 (5.3 days) and wrote 694227 records for F.US.GCEZ17 | 2017-11-01 14:17:14
Added 8 Time and Sales records to Intraday data file for F.US.GCEZ17 after download. | 2017-11-01 14:17:14
HD Request # 146 | Intraday download COMPLETE for F.US.GCEZ17. Completion time: 2s. Unique request ID: 153 | 2017-11-01 14:17:14
Removed historical data download ID 153 | 2017-11-01 14:17:14
Real-time Intraday chart data file updates started for F.US.GCEZ17 | 2017-11-01 14:17:14
Intraday chart data file opened for F.US.GCEZ17 | 2017-11-01 14:17:14
HD Request # 147 | Downloading Intraday chart data for F.US.NQMZ17 to the file F.US.NQMZ17.scid. Service: cqg | 2017-11-01 14:17:14
HD Request # 147 | Download start date-time: 2017-10-27 08:37:05.000 | 2017-11-01 14:17:14
HD Request # 147 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:17:14
Socket (216) | Creating socket. | 2017-11-01 14:17:14
Socket (216) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:17:14
Socket (215) | Socket gracefully closed by remote side. | 2017-11-01 14:17:14
Socket (215) | Closed. | 2017-11-01 14:17:14
HD Request # 147 | Setting DTC encoding to Binary VLS | 2017-11-01 14:17:14
HD Request # 147 | Sending historical data logon request message. | 2017-11-01 14:17:14
HD Request # 147 | Requesting Intraday data. Start date-time: 2017-10-27 08:37:05. Record interval: 0. Symbol: F.US.NQMZ17 | 2017-11-01 14:17:14
HD Request # 147 | Decompressing data. | 2017-11-01 14:17:14
HD Request # 147 | Receiving Intraday data for F.US.NQMZ17 starting at 2017-10-27 08:37:05 | 2017-11-01 14:17:14
HD Request # 147 | Timestamp of first Intraday data file record written: 2017-10-27 08:37:57 | 2017-11-01 14:17:14
Socket (216) | Initiating close of socket by core. | 2017-11-01 14:17:16
Historical data download thread signaled to stop. | 2017-11-01 14:17:16
HD Request # 147 | Received 30011 records from 2017-10-27 08:37:05 to 2017-11-01 14:17:20 (5.3 days) and wrote 30009 records for F.US.NQMZ17 | 2017-11-01 14:17:16
HD Request # 147 | Intraday download COMPLETE for F.US.NQMZ17. Completion time: 2s. Unique request ID: 154 | 2017-11-01 14:17:16
Removed historical data download ID 154 | 2017-11-01 14:17:16
Real-time Intraday chart data file updates started for F.US.NQMZ17 | 2017-11-01 14:17:16
Intraday chart data file opened for F.US.NQMZ17 | 2017-11-01 14:17:16
HD Request # 148 | Downloading Intraday chart data for F.US.MGCZ17 to the file F.US.MGCZ17.scid. Service: cqg | 2017-11-01 14:17:16
HD Request # 148 | Download start date-time: 2017-10-27 08:36:55.000 | 2017-11-01 14:17:16
Socket (216) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:17:16
HD Request # 148 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:17:16
Socket (217) | Creating socket. | 2017-11-01 14:17:16
Socket (217) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:17:16
Socket (216) | Socket gracefully closed by remote side. | 2017-11-01 14:17:16
Socket (216) | Closed. | 2017-11-01 14:17:16
HD Request # 148 | Setting DTC encoding to Binary VLS | 2017-11-01 14:17:16
HD Request # 148 | Sending historical data logon request message. | 2017-11-01 14:17:16
HD Request # 148 | Requesting Intraday data. Start date-time: 2017-10-27 08:36:55. Record interval: 0. Symbol: F.US.MGCZ17 | 2017-11-01 14:17:16
HD Request # 148 | Decompressing data. | 2017-11-01 14:17:16
HD Request # 148 | Receiving Intraday data for F.US.MGCZ17 starting at 2017-10-27 08:36:55 | 2017-11-01 14:17:16
HD Request # 148 | Timestamp of first Intraday data file record written: 2017-10-27 08:38:05 | 2017-11-01 14:17:16
Opened cached Intraday file: C:\SierraChart\Data\F.US.CPEZ17.scid | 2017-11-01 14:17:21
Opened cached Intraday file: C:\SierraChart\Data\F.US.GCEZ17.scid | 2017-11-01 14:17:21
Socket (217) | Initiating close of socket by core. | 2017-11-01 14:17:22
Socket (217) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:17:22
Historical data download thread signaled to stop. | 2017-11-01 14:17:22
HD Request # 148 | Received 11898 records from 2017-10-27 08:36:55 to 2017-11-01 14:17:23 (5.3 days) and wrote 11896 records for F.US.MGCZ17 | 2017-11-01 14:17:22
Added 2 Time and Sales records to Intraday data file for F.US.MGCZ17 after download. | 2017-11-01 14:17:22
HD Request # 148 | Intraday download COMPLETE for F.US.MGCZ17. Completion time: 7s. Unique request ID: 155 | 2017-11-01 14:17:22
Removed historical data download ID 155 | 2017-11-01 14:17:22
Real-time Intraday chart data file updates started for F.US.MGCZ17 | 2017-11-01 14:17:22
Intraday chart data file opened for F.US.MGCZ17 | 2017-11-01 14:17:22
Socket (217) | Socket gracefully closed by remote side. | 2017-11-01 14:17:22
Socket (217) | Closed. | 2017-11-01 14:17:22
Opened cached Intraday file: C:\SierraChart\Data\F.US.MGCZ17.scid | 2017-11-01 14:17:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.NQMZ17.scid | 2017-11-01 14:17:41
HTTP connection to ds01.ddfplus.com:80 (212) | Socket gracefully closed by remote side. | 2017-11-01 14:18:07
HTTP connection to ds01.ddfplus.com:80 (212) | Received socket Close event. | 2017-11-01 14:18:07
HTTP connection to ds01.ddfplus.com:80 (212) | Initiating close of socket by core. | 2017-11-01 14:18:07
HTTP connection to ds01.ddfplus.com:80 (212) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 14:18:07
HTTP connection to ds01.ddfplus.com:80 (212) | Closed. | 2017-11-01 14:18:07
SC DTC Data with Market Depth | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2017-11-01 14:18:22
DTC Client socket (177) | Initiating close of socket by core. | 2017-11-01 14:18:22
DTC Client socket (177) | Write in progress. Shutdown being delayed. | 2017-11-01 14:18:22
SC DTC Data with Market Depth | Disconnected from the server. | 2017-11-01 14:18:22
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2017-11-01 14:18:22
SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2017-11-01 14:18:24
DTC Client socket (218) | Creating socket. | 2017-11-01 14:18:24
DTC Client socket (218) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:18:24
SC DTC Data with Market Depth | Connected to server. | 2017-11-01 14:18:24
SC DTC Data with Market Depth | Starting socket receive thread. | 2017-11-01 14:18:24
SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-11-01 14:18:24
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-11-01 14:18:24
SC DTC Data with Market Depth | Sending logon request message. | 2017-11-01 14:18:24
SC DTC Data with Market Depth | Received logon response. | 2017-11-01 14:18:26
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-11-01 14:18:26
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-11-01 14:18:26
SC DTC Data with Market Depth | Successfully connected. | 2017-11-01 14:18:26
SC DTC Data with Market Depth | Trading is not supported. | 2017-11-01 14:18:26
Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2017-11-01 14:18:26
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2017-11-01 14:18:26
Delaying start of download for NISS-NYSE | 2017-11-01 14:18:26
SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2017-11-01 14:18:26
HD Request # 149 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2017-11-01 14:18:31
HD Request # 149 | Download start date-time: 2017-11-01 14:17:23.000 | 2017-11-01 14:18:31
HD Request # 149 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:18:31
Socket (219) | Creating socket. | 2017-11-01 14:18:31
Socket (219) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:18:31
HD Request # 149 | Setting DTC encoding to Binary VLS | 2017-11-01 14:18:31
HD Request # 149 | Sending historical data logon request message. | 2017-11-01 14:18:31
HD Request # 149 | Requesting Intraday data. Start date-time: 2017-11-01 14:17:23. Record interval: 0. Symbol: NISS-NYSE | 2017-11-01 14:18:31
HD Request # 149 | Decompressing data. | 2017-11-01 14:18:31
HD Request # 149 | Receiving Intraday data for NISS-NYSE starting at 2017-11-01 14:17:23 | 2017-11-01 14:18:31
HD Request # 149 | Timestamp of first Intraday data file record written: 2017-11-01 14:17:24 | 2017-11-01 14:18:31
Socket (219) | Initiating close of socket by core. | 2017-11-01 14:18:31
Socket (219) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:18:31
Historical data download thread signaled to stop. | 2017-11-01 14:18:31
HD Request # 149 | Received 75 records from 2017-11-01 14:17:23 to 2017-11-01 14:18:37 (74.0 seconds) and wrote 74 records for NISS-NYSE | 2017-11-01 14:18:31
HD Request # 149 | Intraday download COMPLETE for NISS-NYSE. Completion time: 1s. Unique request ID: 156 | 2017-11-01 14:18:31
Removed historical data download ID 156 | 2017-11-01 14:18:31
Real-time Intraday chart data file updates started for NISS-NYSE | 2017-11-01 14:18:31
Intraday chart data file opened for NISS-NYSE | 2017-11-01 14:18:31
Socket (219) | Socket gracefully closed by remote side. | 2017-11-01 14:18:31
Socket (219) | Closed. | 2017-11-01 14:18:31
Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2017-11-01 14:18:32
DTC Client socket (177) | Write has completed. Shutdown being performed. | 2017-11-01 14:18:41
DTC Client socket (177) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:18:41
DTC Client socket (177) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 14:18:41 *
DTC Client socket (177) | Socket gracefully closed by remote side. | 2017-11-01 14:18:41
DTC Client socket (177) | Closed. | 2017-11-01 14:18:41
CQG WebSocket socket (176) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 14:26:46 *
CQG WebSocket socket (176) | Socket gracefully closed by remote side. | 2017-11-01 14:26:46
CQG WebSocket socket (176) | Received socket Close event. | 2017-11-01 14:26:46
CQG WebSocket socket (176) | Initiating close of socket by core. | 2017-11-01 14:26:46
CQG WebSocket | Network socket for WebSocket has been closed by remote side. | 2017-11-01 14:26:46
CQG FIX Trading | WebSocket closed. | 2017-11-01 14:26:46
Connection to the external service has been lost. | 2017-11-01 14:26:46
CQG WebSocket socket (176) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 14:26:46
CQG WebSocket socket (176) | Closed. | 2017-11-01 14:26:46
CQG FIX: DisconnectFIX called. | 2017-11-01 14:26:46
CQG FIX: Sending a Logout message. | 2017-11-01 14:26:46
CQG FIX Trading | Disconnected. | 2017-11-01 14:26:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 14:26:46
CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2017-11-01 14:26:46
CQG FIX socket (175) | Initiating close of socket by core. | 2017-11-01 14:26:46
CQG FIX: Disconnected. | 2017-11-01 14:26:46
CQG FIX socket (175) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:46
CQG FIX socket (175) | Socket gracefully closed by remote side. | 2017-11-01 14:26:46
CQG FIX socket (175) | Closed. | 2017-11-01 14:26:46
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-01 14:26:49
CQG FIX socket (223) | Creating socket. Using TLS 1.2. | 2017-11-01 14:26:49
CQG FIX socket (223) | Connecting to IP: 208.48.16.214. | 2017-11-01 14:26:49
CQG FIX: Sending the Logon message. | 2017-11-01 14:26:49
CQG FIX Trading | Connected to trading server. | 2017-11-01 14:26:50
CQG FIX Trading | Connecting to server api.cqg.com | 2017-11-01 14:26:50
CQG WebSocket | Connecting to WebSocket server. | 2017-11-01 14:26:50
CQG FIX | FCM name: AMP | 2017-11-01 14:26:50
CQG WebSocket socket (224) | Creating socket. Using TLS 1.2. | 2017-11-01 14:26:50
CQG WebSocket socket (224) | Connecting to IP: 195.166.124.165. | 2017-11-01 14:26:50
CQG WebSocket | Opening WebSocket. | 2017-11-01 14:26:50
CQG WebSocket | Sending WebSocket handshake. | 2017-11-01 14:26:50
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-11-01 14:26:50
CQG WebSocket | Web socket state is now open. | 2017-11-01 14:26:50
CQG FIX Trading | WebSocket connected. | 2017-11-01 14:26:50
CQG FIX Trading | Sending market data logon message. | 2017-11-01 14:26:50
CQG FIX Trading | Logon successful. Session Token = Ls6zc+Hm3/deOyFs/cXmxWNUhTpMMExeDU5m67wufWMs5/apQBvaI+M6gcU84FpaNDpVmDpWAkA | 2017-11-01 14:26:50
CQG FIX Trading | Connected to data and trading server. | 2017-11-01 14:26:50
DTC Client socket (218) | Initiating close of socket by core. | 2017-11-01 14:26:50
DTC Client socket (218) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:50
SC DTC Data with Market Depth | Disconnected from the server. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.DLM17. ID: 1 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.DLM17. ID: 593798 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.DLM17. ID: 1 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6M17. ID: 2 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.CA6M17. ID: 593799 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.CA6M17. ID: 2 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6M17. ID: 3 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.BP6M17. ID: 593800 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.BP6M17. ID: 3 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6M17. ID: 4 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.EU6M17. ID: 593801 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.EU6M17. ID: 4 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6Z17. ID: 5 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.CA6Z17. ID: 593802 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.CA6Z17. ID: 5 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.CA6Z7. Search Symbol: F.US.CA6Z17. Request ID: 593802. Contract ID: 1. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.CA6Z17 | 2017-11-01 14:26:50
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 14:26:50
Symbol Error - F.US.DLM17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:26:50
DTC Client socket (218) | Socket gracefully closed by remote side. | 2017-11-01 14:26:50
DTC Client socket (218) | Closed. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.CLEZ17. ID: 6 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.CLEZ17. ID: 593803 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.CLEZ17. ID: 6 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.RBEZ17. ID: 7 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.RBEZ17. ID: 593804 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.RBEZ17. ID: 7 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.CPEZ17. ID: 8 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.CPEZ17. ID: 593805 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.CPEZ17. ID: 8 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.GCEZ17. ID: 9 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.GCEZ17. ID: 593806 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.GCEZ17. ID: 9 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.SIEZ17. ID: 10 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.SIEZ17. ID: 593807 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.SIEZ17. ID: 10 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.PAEZ17. ID: 11 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.PAEZ17. ID: 593808 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.PAEZ17. ID: 11 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.PLEF18. ID: 12 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.PLEF18. ID: 593809 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.PLEF18. ID: 12 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.DBZ17. ID: 13 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.DBZ17. ID: 593810 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.DBZ17. ID: 13 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEZ7. Search Symbol: F.US.CLEZ17. Request ID: 593803. Contract ID: 2. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.CLEZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEZ7. Search Symbol: F.US.RBEZ17. Request ID: 593804. Contract ID: 3. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.RBEZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.CPEZ7. Search Symbol: F.US.CPEZ17. Request ID: 593805. Contract ID: 4. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.CPEZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEZ7. Search Symbol: F.US.GCEZ17. Request ID: 593806. Contract ID: 5. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.GCEZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEZ7. Search Symbol: F.US.SIEZ17. Request ID: 593807. Contract ID: 6. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.SIEZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.PAEZ7. Search Symbol: F.US.PAEZ17. Request ID: 593808. Contract ID: 7. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.PAEZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.PLEF8. Search Symbol: F.US.PLEF18. Request ID: 593809. Contract ID: 8. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.PLEF18 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.DBZ7. Search Symbol: F.US.DBZ17. Request ID: 593810. Contract ID: 9. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.DBZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.FDXMZ17. ID: 14 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.FDXMZ17. ID: 593811 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.FDXMZ17. ID: 14 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.FDXMZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
Delaying start of download for F.US.FDXMZ17 | 2017-11-01 14:26:50
Symbol Error - F.US.CA6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:26:50
Symbol Error - F.US.BP6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:26:50
Symbol Error - F.US.EU6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6Z17. ID: 15 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.EU6Z17. ID: 593812 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.EU6Z17. ID: 15 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.EU6Z17 is set to download 'Pending'. | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.DBZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.FDXMZ7. Search Symbol: F.US.FDXMZ17. Request ID: 593811. Contract ID: 10. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.FDXMZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.EU6Z7. Search Symbol: F.US.EU6Z17. Request ID: 593812. Contract ID: 11. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.EU6Z17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.GMCDZ17. ID: 16 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.GMCDZ17. ID: 593813 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.GMCDZ17. ID: 16 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.GMCDZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.M6BZ17. ID: 17 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.M6BZ17. ID: 593814 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.M6BZ17. ID: 17 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.M6BZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
HD Request # 150 | Downloading Intraday chart data for F.US.FDXMZ17 to the file F.US.FDXMZ17.scid. Service: cqg | 2017-11-01 14:26:50
HD Request # 150 | Download start date-time: 2017-11-01 14:26:34.000 | 2017-11-01 14:26:50
HD Request # 150 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:26:50
Socket (225) | Creating socket. | 2017-11-01 14:26:50
Socket (225) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.M6EZ17. ID: 18 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.M6EZ17. ID: 593815 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.M6EZ17. ID: 18 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.M6EZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.GMCDZ7. Search Symbol: F.US.GMCDZ17. Request ID: 593813. Contract ID: 12. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.GMCDZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.M6AZ17. ID: 19 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.M6AZ17. ID: 593816 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.M6AZ17. ID: 19 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.M6AZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.MJYZ17. ID: 20 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.MJYZ17. ID: 593817 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.MJYZ17. ID: 20 | 2017-11-01 14:26:50
CQG FIX Trading | Using primary service for historical data for F.US.MJYZ17 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.MJYZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
Delaying start of download for F.US.MJYZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6BZ7. Search Symbol: F.US.M6BZ17. Request ID: 593814. Contract ID: 13. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.M6BZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ17. ID: 21 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ17. ID: 593818 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.DDZ17. ID: 21 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.DDZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ17. ID: 22 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ17. ID: 593819 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ17. ID: 22 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.DSXZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6EZ7. Search Symbol: F.US.M6EZ17. Request ID: 593815. Contract ID: 14. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.M6EZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6AZ7. Search Symbol: F.US.M6AZ17. Request ID: 593816. Contract ID: 15. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.M6AZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.MJYZ7. Search Symbol: F.US.MJYZ17. Request ID: 593817. Contract ID: 16. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.MJYZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.DDZ7. Search Symbol: F.US.DDZ17. Request ID: 593818. Contract ID: 17. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.DDZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXZ7. Search Symbol: F.US.DSXZ17. Request ID: 593819. Contract ID: 18. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.DSXZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.EPZ17. ID: 23 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.EPZ17. ID: 593820 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.EPZ17. ID: 23 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.EPZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6Z17. ID: 24 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.BP6Z17. ID: 593821 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.BP6Z17. ID: 24 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.BP6Z17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.JY6Z17. ID: 25 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.JY6Z17. ID: 593822 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.JY6Z17. ID: 25 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.JY6Z17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.EPZ7. Search Symbol: F.US.EPZ17. Request ID: 593820. Contract ID: 19. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.EPZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6M17. ID: 26 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.MX6M17. ID: 593823 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.MX6M17. ID: 26 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.MX6M17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.NE6Z17. ID: 27 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.NE6Z17. ID: 593824 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.NE6Z17. ID: 27 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.NE6Z17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.BP6Z7. Search Symbol: F.US.BP6Z17. Request ID: 593821. Contract ID: 20. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.BP6Z17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.JY6Z7. Search Symbol: F.US.JY6Z17. Request ID: 593822. Contract ID: 21. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.JY6Z17 | 2017-11-01 14:26:50
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.EPZ17.2017-11-01.depth | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.CLEZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.USAZ17. ID: 28 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.USAZ17. ID: 593825 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.USAZ17. ID: 28 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.USAZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.NE6Z7. Search Symbol: F.US.NE6Z17. Request ID: 593824. Contract ID: 22. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.NE6Z17 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.GCEZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.MGCZ17. ID: 29 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.MGCZ17. ID: 593826 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.MGCZ17. ID: 29 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.MGCZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.USAZ7. Search Symbol: F.US.USAZ17. Request ID: 593825. Contract ID: 23. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.USAZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.NQMZ17. ID: 30 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.NQMZ17. ID: 593827 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.NQMZ17. ID: 30 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.NQMZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.CPEZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.TYAZ17. ID: 31 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.TYAZ17. ID: 593828 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.TYAZ17. ID: 31 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.TYAZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.MGCZ7. Search Symbol: F.US.MGCZ17. Request ID: 593826. Contract ID: 24. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.MGCZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.ENQZ17. ID: 32 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.ENQZ17. ID: 593829 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.ENQZ17. ID: 32 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.ENQZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.NQMZ7. Search Symbol: F.US.NQMZ17. Request ID: 593827. Contract ID: 25. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.NQMZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.TYAZ7. Search Symbol: F.US.TYAZ17. Request ID: 593828. Contract ID: 26. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.TYAZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.YMZ17. ID: 33 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.YMZ17. ID: 593830 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.YMZ17. ID: 33 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.YMZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.ENQZ7. Search Symbol: F.US.ENQZ17. Request ID: 593829. Contract ID: 27. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.ENQZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.DLZ17. ID: 34 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.DLZ17. ID: 593831 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.DLZ17. ID: 34 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.DLZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.YMZ7. Search Symbol: F.US.YMZ17. Request ID: 593830. Contract ID: 28. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.YMZ17 | 2017-11-01 14:26:50
Symbol Error - F.US.MX6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.DGZ17. ID: 35 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.DGZ17. ID: 593832 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.DGZ17. ID: 35 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.DGZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.FGBXZ17. ID: 36 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.FGBXZ17. ID: 593833 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.FGBXZ17. ID: 36 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.FGBXZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.FBTPZ17. ID: 37 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.FBTPZ17. ID: 593834 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.FBTPZ17. ID: 37 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.FBTPZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.DLZ7. Search Symbol: F.US.DLZ17. Request ID: 593831. Contract ID: 29. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.DLZ17 | 2017-11-01 14:26:50
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DBZ17.2017-11-01.depth | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.DGZ7. Search Symbol: F.US.DGZ17. Request ID: 593832. Contract ID: 30. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.DGZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.FOATZ17. ID: 38 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.FOATZ17. ID: 593835 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.FOATZ17. ID: 38 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.FOATZ17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.FGBXZ7. Search Symbol: F.US.FGBXZ17. Request ID: 593833. Contract ID: 31. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.FGBXZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.FBTPZ7. Search Symbol: F.US.FBTPZ17. Request ID: 593834. Contract ID: 32. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.FBTPZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.FOATZ7. Search Symbol: F.US.FOATZ17. Request ID: 593835. Contract ID: 33. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.FOATZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ16. ID: 39 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ16. ID: 593836 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ16. ID: 39 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.DSXZ16 is set to download 'Pending'. | 2017-11-01 14:26:50
Requesting market depth updates for: F.US.DBZ17 if supported. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data including full depth for F.US.DBZ17 | 2017-11-01 14:26:50
Requesting market depth updates for: F.US.CLEZ17 if supported. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data including full depth for F.US.CLEZ17 | 2017-11-01 14:26:50
HD Request # 150 | Setting DTC encoding to Binary VLS | 2017-11-01 14:26:50
HD Request # 150 | Sending historical data logon request message. | 2017-11-01 14:26:50
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.CLEZ17.2017-11-01.depth | 2017-11-01 14:26:50
Requesting market depth updates for: F.US.EPZ17 if supported. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data including full depth for F.US.EPZ17 | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.DA6Z17. ID: 40 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.DA6Z17. ID: 593837 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.DA6Z17. ID: 40 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.DA6Z17 is set to download 'Pending'. | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.CA6Z17 is set to download 'Pending'. | 2017-11-01 14:26:50
Symbol Error - F.US.DSXZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6Z17. ID: 41 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.MX6Z17. ID: 593838 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.MX6Z17. ID: 41 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.MX6Z17 is set to download 'Pending'. | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.DA6Z7. Search Symbol: F.US.DA6Z17. Request ID: 593837. Contract ID: 34. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.DA6Z17 | 2017-11-01 14:26:50
CQG FIX Trading | Received symbol resolution report for symbol F.US.MX6Z7. Search Symbol: F.US.MX6Z17. Request ID: 593838. Contract ID: 35. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data for F.US.MX6Z17 | 2017-11-01 14:26:50
Requesting market depth updates for: F.US.DDZ17 if supported. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data including full depth for F.US.DDZ17 | 2017-11-01 14:26:50
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DDZ17.2017-11-01.depth | 2017-11-01 14:26:50
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ16. ID: 42 | 2017-11-01 14:26:50
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ16. ID: 593839 | 2017-11-01 14:26:50
CQG FIX Trading | Requesting security definition data for: F.US.DDZ16. ID: 42 | 2017-11-01 14:26:50
Intraday data recording state for symbol F.US.DDZ16 is set to download 'Pending'. | 2017-11-01 14:26:50
Requesting market depth updates for: F.US.DSXZ17 if supported. | 2017-11-01 14:26:50
CQG FIX Trading | Requesting market data including full depth for F.US.DSXZ17 | 2017-11-01 14:26:50
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DSXZ17.2017-11-01.depth | 2017-11-01 14:26:50
SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-NYSE. ID: 43 | 2017-11-01 14:26:51
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-11-01 14:26:51
SC DTC Data with Market Depth | Requesting security definition data for: NISS-NYSE. ID: 43 | 2017-11-01 14:26:51
Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2017-11-01 14:26:51
DTC Client socket (226) | Creating socket. | 2017-11-01 14:26:51
DTC Client socket (226) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:26:51
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 14:26:51
Symbol Error - F.US.DDZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:26:51
HD Request # 150 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:34. Record interval: 0. Symbol: F.US.FDXMZ17 | 2017-11-01 14:26:51
CQG FIX Trading | Starting real-time market data updates for: F.US.EADZ17. ID: 44 | 2017-11-01 14:26:51
CQG FIX Trading | Sending symbol resolution request for F.US.EADZ17. ID: 593840 | 2017-11-01 14:26:51
CQG FIX Trading | Requesting security definition data for: F.US.EADZ17. ID: 44 | 2017-11-01 14:26:51
CQG FIX Trading | Starting real-time market data updates for: F.US.ECDZ17. ID: 45 | 2017-11-01 14:26:51
CQG FIX Trading | Sending symbol resolution request for F.US.ECDZ17. ID: 593841 | 2017-11-01 14:26:51
CQG FIX Trading | Requesting security definition data for: F.US.ECDZ17. ID: 45 | 2017-11-01 14:26:51
CQG FIX Trading | Starting real-time market data updates for: F.US.TUAZ17. ID: 46 | 2017-11-01 14:26:51
CQG FIX Trading | Sending symbol resolution request for F.US.TUAZ17. ID: 593842 | 2017-11-01 14:26:51
CQG FIX Trading | Requesting security definition data for: F.US.TUAZ17. ID: 46 | 2017-11-01 14:26:51
CQG FIX Trading | Starting real-time market data updates for: F.US.FVAZ17. ID: 47 | 2017-11-01 14:26:51
CQG FIX Trading | Sending symbol resolution request for F.US.FVAZ17. ID: 593843 | 2017-11-01 14:26:51
CQG FIX Trading | Requesting security definition data for: F.US.FVAZ17. ID: 47 | 2017-11-01 14:26:51
CQG FIX Trading | Received symbol resolution report for symbol F.US.EADZ7. Search Symbol: F.US.EADZ17. Request ID: 593840. Contract ID: 36. | 2017-11-01 14:26:51
CQG FIX Trading | Requesting market data for F.US.EADZ17 | 2017-11-01 14:26:51
CQG FIX Trading | Starting real-time market data updates for: F.US.FVSX17. ID: 48 | 2017-11-01 14:26:51
CQG FIX Trading | Sending symbol resolution request for F.US.FVSX17. ID: 593844 | 2017-11-01 14:26:51
CQG FIX Trading | Requesting security definition data for: F.US.FVSX17. ID: 48 | 2017-11-01 14:26:51
CQG FIX Trading | Starting real-time market data updates for: F.US.SWZ17. ID: 49 | 2017-11-01 14:26:51
CQG FIX Trading | Sending symbol resolution request for F.US.SWZ17. ID: 593845 | 2017-11-01 14:26:51
CQG FIX Trading | Requesting security definition data for: F.US.SWZ17. ID: 49 | 2017-11-01 14:26:51
CQG FIX Trading | Starting real-time market data updates for: F.US.NKDZ17. ID: 50 | 2017-11-01 14:26:51
CQG FIX Trading | Sending symbol resolution request for F.US.NKDZ17. ID: 593846 | 2017-11-01 14:26:51
CQG FIX Trading | Requesting security definition data for: F.US.NKDZ17. ID: 50 | 2017-11-01 14:26:51
CQG FIX Trading | Received symbol resolution report for symbol F.US.ECDZ7. Search Symbol: F.US.ECDZ17. Request ID: 593841. Contract ID: 37. | 2017-11-01 14:26:51
CQG FIX Trading | Requesting market data for F.US.ECDZ17 | 2017-11-01 14:26:51
CQG FIX Trading | Received symbol resolution report for symbol F.US.TUAZ7. Search Symbol: F.US.TUAZ17. Request ID: 593842. Contract ID: 38. | 2017-11-01 14:26:51
CQG FIX Trading | Requesting market data for F.US.TUAZ17 | 2017-11-01 14:26:51
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVAZ7. Search Symbol: F.US.FVAZ17. Request ID: 593843. Contract ID: 39. | 2017-11-01 14:26:51
CQG FIX Trading | Requesting market data for F.US.FVAZ17 | 2017-11-01 14:26:51
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVSX7. Search Symbol: F.US.FVSX17. Request ID: 593844. Contract ID: 40. | 2017-11-01 14:26:51
CQG FIX Trading | Requesting market data for F.US.FVSX17 | 2017-11-01 14:26:51
CQG FIX Trading | Received symbol resolution report for symbol F.US.SWZ7. Search Symbol: F.US.SWZ17. Request ID: 593845. Contract ID: 41. | 2017-11-01 14:26:51
CQG FIX Trading | Requesting market data for F.US.SWZ17 | 2017-11-01 14:26:51
CQG FIX Trading | Received symbol resolution report for symbol F.US.NKDZ7. Search Symbol: F.US.NKDZ17. Request ID: 593846. Contract ID: 42. | 2017-11-01 14:26:51
CQG FIX Trading | Requesting market data for F.US.NKDZ17 | 2017-11-01 14:26:51
SC DTC Data with Market Depth | Connected to server. | 2017-11-01 14:26:51
SC DTC Data with Market Depth | Starting socket receive thread. | 2017-11-01 14:26:51
SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-11-01 14:26:51
HD Request # 150 | Decompressing data. | 2017-11-01 14:26:51
HD Request # 150 | Receiving Intraday data for F.US.FDXMZ17 starting at 2017-11-01 14:26:34 | 2017-11-01 14:26:51
HD Request # 150 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:41 | 2017-11-01 14:26:51
Socket (225) | Initiating close of socket by core. | 2017-11-01 14:26:51
Socket (225) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:51
Historical data download thread signaled to stop. | 2017-11-01 14:26:51
HD Request # 150 | Received 4 records from 2017-11-01 14:26:34 to 2017-11-01 14:26:55 (21.0 seconds) and wrote 3 records for F.US.FDXMZ17 | 2017-11-01 14:26:51
HD Request # 150 | Intraday download COMPLETE for F.US.FDXMZ17. Completion time: 1s. Unique request ID: 157 | 2017-11-01 14:26:51
Removed historical data download ID 157 | 2017-11-01 14:26:51
Real-time Intraday chart data file updates started for F.US.FDXMZ17 | 2017-11-01 14:26:51
Intraday chart data file opened for F.US.FDXMZ17 | 2017-11-01 14:26:51
Delaying start of download for F.US.EU6Z17 | 2017-11-01 14:26:51
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-11-01 14:26:51
SC DTC Data with Market Depth | Sending logon request message. | 2017-11-01 14:26:51
Socket (225) | Socket gracefully closed by remote side. | 2017-11-01 14:26:51
Socket (225) | Closed. | 2017-11-01 14:26:51
SC DTC Data with Market Depth | Received logon response. | 2017-11-01 14:26:52
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-11-01 14:26:52
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-11-01 14:26:52
SC DTC Data with Market Depth | Successfully connected. | 2017-11-01 14:26:52
SC DTC Data with Market Depth | Trading is not supported. | 2017-11-01 14:26:52
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2017-11-01 14:26:52
SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2017-11-01 14:26:52
Delaying start of download for F.US.MJYZ17 | 2017-11-01 14:26:52
Requesting market depth updates for: F.US.BP6Z17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.BP6Z17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.CPEZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.CPEZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.DGZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.DGZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.DLZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.DLZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.ENQZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.ENQZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.EU6Z17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.EU6Z17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.FBTPZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.FBTPZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.FDXMZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.FDXMZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.FGBXZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.FGBXZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.FOATZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.FOATZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.GCEZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.GCEZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.GMCDZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.GMCDZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.JY6Z17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.JY6Z17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.M6AZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.M6AZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.M6BZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.M6BZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.M6EZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.M6EZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.MGCZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.MGCZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.MJYZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.MJYZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.MX6M17 if supported. | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.NE6Z17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.NE6Z17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.NQMZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.NQMZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.TYAZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.TYAZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.USAZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.USAZ17 | 2017-11-01 14:26:55
Requesting market depth updates for: F.US.YMZ17 if supported. | 2017-11-01 14:26:55
CQG FIX Trading | Requesting market data including full depth for F.US.YMZ17 | 2017-11-01 14:26:55
HD Request # 151 | Downloading Intraday chart data for F.US.EU6Z17 to the file F.US.EU6Z17.scid. Service: cqg | 2017-11-01 14:26:55
HD Request # 151 | Download start date-time: 2017-11-01 14:26:34.000 | 2017-11-01 14:26:55
HD Request # 151 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:26:55
Socket (227) | Creating socket. | 2017-11-01 14:26:55
Socket (227) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:26:55
HD Request # 152 | Downloading Intraday chart data for F.US.MJYZ17 to the file F.US.MJYZ17.scid. Service: cqg | 2017-11-01 14:26:55
HD Request # 152 | Download start date-time: 2017-11-01 14:25:58.000 | 2017-11-01 14:26:55
HD Request # 152 | Requesting historical Tick data. | 2017-11-01 14:26:55
HD Request # 151 | Setting DTC encoding to Binary VLS | 2017-11-01 14:26:55
HD Request # 151 | Sending historical data logon request message. | 2017-11-01 14:26:55
HD Request # 151 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:34. Record interval: 0. Symbol: F.US.EU6Z17 | 2017-11-01 14:26:55
HD Request # 151 | Decompressing data. | 2017-11-01 14:26:55
HD Request # 151 | Receiving Intraday data for F.US.EU6Z17 starting at 2017-11-01 14:26:34 | 2017-11-01 14:26:55
HD Request # 151 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:37 | 2017-11-01 14:26:55
Socket (227) | Initiating close of socket by core. | 2017-11-01 14:26:55
Socket (227) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:55
Historical data download thread signaled to stop. | 2017-11-01 14:26:55
HD Request # 151 | Received 60 records from 2017-11-01 14:26:34 to 2017-11-01 14:27:02 (28.0 seconds) and wrote 59 records for F.US.EU6Z17 | 2017-11-01 14:26:55
HD Request # 151 | Intraday download COMPLETE for F.US.EU6Z17. Completion time: 0s. Unique request ID: 158 | 2017-11-01 14:26:55
Removed historical data download ID 158 | 2017-11-01 14:26:55
Real-time Intraday chart data file updates started for F.US.EU6Z17 | 2017-11-01 14:26:55
Intraday chart data file opened for F.US.EU6Z17 | 2017-11-01 14:26:55
HD Request # 153 | Downloading Intraday chart data for F.US.DBZ17 to the file F.US.DBZ17.scid. Service: cqg | 2017-11-01 14:26:55
HD Request # 153 | Download start date-time: 2017-11-01 14:26:20.000 | 2017-11-01 14:26:55
HD Request # 153 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:26:55
Socket (228) | Creating socket. | 2017-11-01 14:26:55
Socket (228) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:26:55
Socket (227) | Socket gracefully closed by remote side. | 2017-11-01 14:26:55
Socket (227) | Closed. | 2017-11-01 14:26:55
HD Request # 153 | Setting DTC encoding to Binary VLS | 2017-11-01 14:26:55
HD Request # 153 | Sending historical data logon request message. | 2017-11-01 14:26:55
HD Request # 153 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:20. Record interval: 0. Symbol: F.US.DBZ17 | 2017-11-01 14:26:56
HD Request # 153 | Decompressing data. | 2017-11-01 14:26:56
HD Request # 153 | Receiving Intraday data for F.US.DBZ17 starting at 2017-11-01 14:26:20 | 2017-11-01 14:26:56
HD Request # 153 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:20 | 2017-11-01 14:26:56
Socket (228) | Initiating close of socket by core. | 2017-11-01 14:26:56
Socket (228) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:56
Historical data download thread signaled to stop. | 2017-11-01 14:26:56
HD Request # 153 | Received 73 records from 2017-11-01 14:26:20 to 2017-11-01 14:27:01 (41.0 seconds) and wrote 62 records for F.US.DBZ17 | 2017-11-01 14:26:56
HD Request # 153 | Intraday download COMPLETE for F.US.DBZ17. Completion time: 1s. Unique request ID: 159 | 2017-11-01 14:26:56
Removed historical data download ID 159 | 2017-11-01 14:26:56
Real-time Intraday chart data file updates started for F.US.DBZ17 | 2017-11-01 14:26:56
Intraday chart data file opened for F.US.DBZ17 | 2017-11-01 14:26:56
HD Request # 154 | Downloading Intraday chart data for F.US.GMCDZ17 to the file F.US.GMCDZ17.scid. Service: cqg | 2017-11-01 14:26:56
HD Request # 154 | Download start date-time: 2017-11-01 14:26:15.000 | 2017-11-01 14:26:56
HD Request # 154 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:26:56
Socket (229) | Creating socket. | 2017-11-01 14:26:56
Socket (229) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:26:56
Socket (228) | Socket gracefully closed by remote side. | 2017-11-01 14:26:56
Socket (228) | Closed. | 2017-11-01 14:26:56
HD Request # 154 | Setting DTC encoding to Binary VLS | 2017-11-01 14:26:56
HD Request # 154 | Sending historical data logon request message. | 2017-11-01 14:26:56
HD Request # 154 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:15. Record interval: 0. Symbol: F.US.GMCDZ17 | 2017-11-01 14:26:57
HD Request # 154 | Decompressing data. | 2017-11-01 14:26:57
HD Request # 154 | Receiving Intraday data for F.US.GMCDZ17 starting at 2017-11-01 14:26:15 | 2017-11-01 14:26:57
Socket (229) | Initiating close of socket by core. | 2017-11-01 14:26:57
Socket (229) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:57
Historical data download thread signaled to stop. | 2017-11-01 14:26:57
HD Request # 154 | Received 1 record from 2017-11-01 14:26:15 to 2017-11-01 14:26:15 (0.0 seconds) and wrote 0 records for F.US.GMCDZ17 | 2017-11-01 14:26:57
HD Request # 154 | Intraday download COMPLETE for F.US.GMCDZ17. Completion time: 0s. Unique request ID: 160 | 2017-11-01 14:26:57
Removed historical data download ID 160 | 2017-11-01 14:26:57
Real-time Intraday chart data file updates started for F.US.GMCDZ17 | 2017-11-01 14:26:57
Intraday chart data file opened for F.US.GMCDZ17 | 2017-11-01 14:26:57
HD Request # 155 | Downloading Intraday chart data for F.US.M6BZ17 to the file F.US.M6BZ17.scid. Service: cqg | 2017-11-01 14:26:57
HD Request # 155 | Download start date-time: 2017-11-01 14:23:57.000 | 2017-11-01 14:26:57
HD Request # 155 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:26:57
Socket (230) | Creating socket. | 2017-11-01 14:26:57
Socket (230) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:26:57
HD Request # 152 | Receiving Intraday data for F.US.MJYZ17 starting at 2017-11-01 14:25:58 | 2017-11-01 14:26:57
HD Request # 152 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:50 | 2017-11-01 14:26:57
HD Request # 152 | Received 2 records from 2017-11-01 14:25:58 to 2017-11-01 14:26:50 (52.0 seconds) and wrote 1 record for F.US.MJYZ17 | 2017-11-01 14:26:57
HD Request # 152 | Intraday download COMPLETE for F.US.MJYZ17. Completion time: 1s. Unique request ID: 164 | 2017-11-01 14:26:57
Removed historical data download ID 164 | 2017-11-01 14:26:57
Real-time Intraday chart data file updates started for F.US.MJYZ17 | 2017-11-01 14:26:57
Intraday chart data file opened for F.US.MJYZ17 | 2017-11-01 14:26:57
Socket (229) | Socket gracefully closed by remote side. | 2017-11-01 14:26:57
Socket (229) | Closed. | 2017-11-01 14:26:57
HD Request # 155 | Setting DTC encoding to Binary VLS | 2017-11-01 14:26:57
HD Request # 155 | Sending historical data logon request message. | 2017-11-01 14:26:57
HD Request # 155 | Requesting Intraday data. Start date-time: 2017-11-01 14:23:57. Record interval: 0. Symbol: F.US.M6BZ17 | 2017-11-01 14:26:57
HD Request # 155 | Decompressing data. | 2017-11-01 14:26:57
HD Request # 155 | Receiving Intraday data for F.US.M6BZ17 starting at 2017-11-01 14:23:57 | 2017-11-01 14:26:57
HD Request # 155 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:47 | 2017-11-01 14:26:57
Socket (230) | Initiating close of socket by core. | 2017-11-01 14:26:57
Socket (230) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:57
HD Request # 155 | Received 6 records from 2017-11-01 14:23:57 to 2017-11-01 14:26:54 (2.9 minutes) and wrote 4 records for F.US.M6BZ17 | 2017-11-01 14:26:57
HD Request # 155 | Intraday download COMPLETE for F.US.M6BZ17. Completion time: 0s. Unique request ID: 161 | 2017-11-01 14:26:57
Removed historical data download ID 161 | 2017-11-01 14:26:57
Real-time Intraday chart data file updates started for F.US.M6BZ17 | 2017-11-01 14:26:57
Intraday chart data file opened for F.US.M6BZ17 | 2017-11-01 14:26:57
HD Request # 156 | Downloading Intraday chart data for F.US.M6EZ17 to the file F.US.M6EZ17.scid. Service: cqg | 2017-11-01 14:26:57
HD Request # 156 | Download start date-time: 2017-11-01 14:26:00.000 | 2017-11-01 14:26:57
HD Request # 156 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:26:57
Socket (231) | Creating socket. | 2017-11-01 14:26:57
Socket (231) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:26:57
Socket (230) | Socket gracefully closed by remote side. | 2017-11-01 14:26:57
Socket (230) | Closed. | 2017-11-01 14:26:57
HD Request # 156 | Setting DTC encoding to Binary VLS | 2017-11-01 14:26:57
HD Request # 156 | Sending historical data logon request message. | 2017-11-01 14:26:57
HD Request # 156 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:00. Record interval: 0. Symbol: F.US.M6EZ17 | 2017-11-01 14:26:57
HD Request # 156 | Decompressing data. | 2017-11-01 14:26:58
HD Request # 156 | Receiving Intraday data for F.US.M6EZ17 starting at 2017-11-01 14:26:00 | 2017-11-01 14:26:58
HD Request # 156 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:25 | 2017-11-01 14:26:58
Socket (231) | Initiating close of socket by core. | 2017-11-01 14:26:58
Socket (231) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:58
Historical data download thread signaled to stop. | 2017-11-01 14:26:58
HD Request # 156 | Received 3 records from 2017-11-01 14:26:00 to 2017-11-01 14:26:26 (26.0 seconds) and wrote 2 records for F.US.M6EZ17 | 2017-11-01 14:26:58
HD Request # 156 | Intraday download COMPLETE for F.US.M6EZ17. Completion time: 0s. Unique request ID: 162 | 2017-11-01 14:26:58
Removed historical data download ID 162 | 2017-11-01 14:26:58
Real-time Intraday chart data file updates started for F.US.M6EZ17 | 2017-11-01 14:26:58
Intraday chart data file opened for F.US.M6EZ17 | 2017-11-01 14:26:58
HD Request # 157 | Downloading Intraday chart data for F.US.M6AZ17 to the file F.US.M6AZ17.scid. Service: cme | 2017-11-01 14:26:58
HD Request # 157 | Download start date-time: 2017-11-01 14:25:29.000 | 2017-11-01 14:26:58
HD Request # 157 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 14:26:58
Socket (232) | Creating socket. | 2017-11-01 14:26:58
Socket (232) | Connecting to IP: 8.18.161.133. | 2017-11-01 14:26:58
Socket (231) | Socket gracefully closed by remote side. | 2017-11-01 14:26:58
Socket (231) | Closed. | 2017-11-01 14:26:58
HD Request # 157 | Setting DTC encoding to Binary VLS | 2017-11-01 14:26:58
HD Request # 157 | Sending historical data logon request message. | 2017-11-01 14:26:58
HD Request # 157 | Requesting Intraday data. Start date-time: 2017-11-01 14:25:29. Record interval: 0. Symbol: M6AZ17 | 2017-11-01 14:26:58
HD Request # 157 | Decompressing data. | 2017-11-01 14:26:58
Socket (232) | Initiating close of socket by core. | 2017-11-01 14:26:58
Socket (232) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:58
HD Request # 157 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.M6AZ17 | 2017-11-01 14:26:58
HD Request # 157 | Receiving Intraday data for F.US.M6AZ17 starting at 2017-11-01 14:27:03 | 2017-11-01 14:26:58
HD Request # 157 | Timestamp of first Intraday data file record written: 2017-11-01 14:27:03 | 2017-11-01 14:26:58
Added 2 Time and Sales records to Intraday data file for F.US.M6AZ17 after download. | 2017-11-01 14:26:58
HD Request # 157 | Intraday download COMPLETE for F.US.M6AZ17. Completion time: 1s. Unique request ID: 163 | 2017-11-01 14:26:58
Removed historical data download ID 163 | 2017-11-01 14:26:58
Real-time Intraday chart data file updates started for F.US.M6AZ17 | 2017-11-01 14:26:58
Intraday chart data file opened for F.US.M6AZ17 | 2017-11-01 14:26:58
HD Request # 158 | Downloading Intraday chart data for F.US.DDZ17 to the file F.US.DDZ17.scid. Service: cqg | 2017-11-01 14:26:58
HD Request # 158 | Download start date-time: 2017-11-01 14:26:34.000 | 2017-11-01 14:26:58
HD Request # 158 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:26:58
Socket (233) | Creating socket. | 2017-11-01 14:26:58
Socket (233) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:26:58
Socket (232) | Socket gracefully closed by remote side. | 2017-11-01 14:26:58
Socket (232) | Closed. | 2017-11-01 14:26:58
HD Request # 158 | Setting DTC encoding to Binary VLS | 2017-11-01 14:26:58
HD Request # 158 | Sending historical data logon request message. | 2017-11-01 14:26:58
HD Request # 158 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:34. Record interval: 0. Symbol: F.US.DDZ17 | 2017-11-01 14:26:58
HD Request # 158 | Decompressing data. | 2017-11-01 14:26:59
HD Request # 158 | Receiving Intraday data for F.US.DDZ17 starting at 2017-11-01 14:26:34 | 2017-11-01 14:26:59
HD Request # 158 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:40 | 2017-11-01 14:26:59
Socket (233) | Initiating close of socket by core. | 2017-11-01 14:26:59
Socket (233) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:26:59
Historical data download thread signaled to stop. | 2017-11-01 14:26:59
HD Request # 158 | Received 18 records from 2017-11-01 14:26:34 to 2017-11-01 14:27:00 (26.0 seconds) and wrote 17 records for F.US.DDZ17 | 2017-11-01 14:26:59
HD Request # 158 | Intraday download COMPLETE for F.US.DDZ17. Completion time: 0s. Unique request ID: 165 | 2017-11-01 14:26:59
Removed historical data download ID 165 | 2017-11-01 14:26:59
Real-time Intraday chart data file updates started for F.US.DDZ17 | 2017-11-01 14:26:59
Intraday chart data file opened for F.US.DDZ17 | 2017-11-01 14:26:59
HD Request # 159 | Downloading Intraday chart data for F.US.DSXZ17 to the file F.US.DSXZ17.scid. Service: cqg | 2017-11-01 14:26:59
HD Request # 159 | Download start date-time: 2017-11-01 14:26:25.000 | 2017-11-01 14:26:59
HD Request # 159 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:26:59
Socket (234) | Creating socket. | 2017-11-01 14:26:59
Socket (234) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:26:59
Socket (233) | Socket gracefully closed by remote side. | 2017-11-01 14:26:59
Socket (233) | Closed. | 2017-11-01 14:26:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.DBZ17.scid | 2017-11-01 14:26:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.FDXMZ17.scid | 2017-11-01 14:26:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.EU6Z17.scid | 2017-11-01 14:26:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6BZ17.scid | 2017-11-01 14:26:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.MJYZ17.scid | 2017-11-01 14:26:59
HD Request # 159 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:02
HD Request # 159 | Sending historical data logon request message. | 2017-11-01 14:27:02
HD Request # 159 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:25. Record interval: 0. Symbol: F.US.DSXZ17 | 2017-11-01 14:27:02
HD Request # 159 | Decompressing data. | 2017-11-01 14:27:02
HD Request # 159 | Receiving Intraday data for F.US.DSXZ17 starting at 2017-11-01 14:26:25 | 2017-11-01 14:27:02
HD Request # 159 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:39 | 2017-11-01 14:27:02
Socket (234) | Initiating close of socket by core. | 2017-11-01 14:27:02
Socket (234) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:02
Historical data download thread signaled to stop. | 2017-11-01 14:27:02
HD Request # 159 | Received 10 records from 2017-11-01 14:26:25 to 2017-11-01 14:26:59 (34.0 seconds) and wrote 9 records for F.US.DSXZ17 | 2017-11-01 14:27:02
HD Request # 159 | Intraday download COMPLETE for F.US.DSXZ17. Completion time: 4s. Unique request ID: 166 | 2017-11-01 14:27:02
Removed historical data download ID 166 | 2017-11-01 14:27:02
Real-time Intraday chart data file updates started for F.US.DSXZ17 | 2017-11-01 14:27:02
Intraday chart data file opened for F.US.DSXZ17 | 2017-11-01 14:27:02
HD Request # 160 | Downloading Intraday chart data for F.US.EPZ17 to the file F.US.EPZ17.scid. Service: cqg | 2017-11-01 14:27:02
HD Request # 160 | Download start date-time: 2017-11-01 14:26:33.000 | 2017-11-01 14:27:02
HD Request # 160 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:27:02
Socket (235) | Creating socket. | 2017-11-01 14:27:02
Socket (235) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:02
Socket (234) | Socket gracefully closed by remote side. | 2017-11-01 14:27:02
Socket (234) | Closed. | 2017-11-01 14:27:02
HD Request # 160 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:02
HD Request # 160 | Sending historical data logon request message. | 2017-11-01 14:27:02
HD Request # 160 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:33. Record interval: 0. Symbol: F.US.EPZ17 | 2017-11-01 14:27:02
HD Request # 160 | Decompressing data. | 2017-11-01 14:27:02
HD Request # 160 | Receiving Intraday data for F.US.EPZ17 starting at 2017-11-01 14:26:33 | 2017-11-01 14:27:02
HD Request # 160 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:35 | 2017-11-01 14:27:02
Socket (235) | Initiating close of socket by core. | 2017-11-01 14:27:02
Socket (235) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:02
HD Request # 160 | Received 197 records from 2017-11-01 14:26:33 to 2017-11-01 14:27:05 (32.0 seconds) and wrote 194 records for F.US.EPZ17 | 2017-11-01 14:27:02
Added 2 Time and Sales records to Intraday data file for F.US.EPZ17 after download. | 2017-11-01 14:27:02
HD Request # 160 | Intraday download COMPLETE for F.US.EPZ17. Completion time: 0s. Unique request ID: 167 | 2017-11-01 14:27:02
Removed historical data download ID 167 | 2017-11-01 14:27:02
Real-time Intraday chart data file updates started for F.US.EPZ17 | 2017-11-01 14:27:02
Intraday chart data file opened for F.US.EPZ17 | 2017-11-01 14:27:02
HD Request # 161 | Downloading Intraday chart data for F.US.BP6Z17 to the file F.US.BP6Z17.scid. Service: cqg | 2017-11-01 14:27:02
HD Request # 161 | Download start date-time: 2017-11-01 14:26:30.000 | 2017-11-01 14:27:02
HD Request # 161 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:27:02
Socket (236) | Creating socket. | 2017-11-01 14:27:02
Socket (236) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:02
Socket (235) | Socket gracefully closed by remote side. | 2017-11-01 14:27:02
Socket (235) | Closed. | 2017-11-01 14:27:02
HD Request # 161 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:03
HD Request # 161 | Sending historical data logon request message. | 2017-11-01 14:27:03
HD Request # 161 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:30. Record interval: 0. Symbol: F.US.BP6Z17 | 2017-11-01 14:27:03
HD Request # 161 | Decompressing data. | 2017-11-01 14:27:03
HD Request # 161 | Receiving Intraday data for F.US.BP6Z17 starting at 2017-11-01 14:26:30 | 2017-11-01 14:27:03
HD Request # 161 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:37 | 2017-11-01 14:27:03
Socket (236) | Initiating close of socket by core. | 2017-11-01 14:27:03
Socket (236) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:03
Historical data download thread signaled to stop. | 2017-11-01 14:27:03
HD Request # 161 | Received 120 records from 2017-11-01 14:26:30 to 2017-11-01 14:27:09 (39.0 seconds) and wrote 114 records for F.US.BP6Z17 | 2017-11-01 14:27:03
HD Request # 161 | Intraday download COMPLETE for F.US.BP6Z17. Completion time: 0s. Unique request ID: 168 | 2017-11-01 14:27:03
Removed historical data download ID 168 | 2017-11-01 14:27:03
Real-time Intraday chart data file updates started for F.US.BP6Z17 | 2017-11-01 14:27:03
Intraday chart data file opened for F.US.BP6Z17 | 2017-11-01 14:27:03
HD Request # 162 | Downloading Intraday chart data for F.US.JY6Z17 to the file F.US.JY6Z17.scid. Service: cqg | 2017-11-01 14:27:03
HD Request # 162 | Download start date-time: 2017-11-01 14:26:31.000 | 2017-11-01 14:27:03
HD Request # 162 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:27:03
Socket (237) | Creating socket. | 2017-11-01 14:27:03
Socket (237) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:03
Socket (236) | Socket gracefully closed by remote side. | 2017-11-01 14:27:03
Socket (236) | Closed. | 2017-11-01 14:27:03
HD Request # 162 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:03
HD Request # 162 | Sending historical data logon request message. | 2017-11-01 14:27:03
HD Request # 162 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:31. Record interval: 0. Symbol: F.US.JY6Z17 | 2017-11-01 14:27:03
HD Request # 162 | Decompressing data. | 2017-11-01 14:27:03
HD Request # 162 | Receiving Intraday data for F.US.JY6Z17 starting at 2017-11-01 14:26:31 | 2017-11-01 14:27:03
HD Request # 162 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:39 | 2017-11-01 14:27:03
Socket (237) | Initiating close of socket by core. | 2017-11-01 14:27:03
Socket (237) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:03
HD Request # 162 | Received 64 records from 2017-11-01 14:26:31 to 2017-11-01 14:27:09 (38.0 seconds) and wrote 63 records for F.US.JY6Z17 | 2017-11-01 14:27:03
Added 2 Time and Sales records to Intraday data file for F.US.JY6Z17 after download. | 2017-11-01 14:27:03
HD Request # 162 | Intraday download COMPLETE for F.US.JY6Z17. Completion time: 0s. Unique request ID: 169 | 2017-11-01 14:27:03
Removed historical data download ID 169 | 2017-11-01 14:27:03
Real-time Intraday chart data file updates started for F.US.JY6Z17 | 2017-11-01 14:27:03
Intraday chart data file opened for F.US.JY6Z17 | 2017-11-01 14:27:03
HD Request # 163 | Downloading Intraday chart data for F.US.MX6M17 to the file F.US.MX6M17.scid. Service: cme | 2017-11-01 14:27:03
HD Request # 163 | Download start date-time: 2017-06-19 14:48:49.000 | 2017-11-01 14:27:03
HD Request # 163 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 14:27:03
Socket (238) | Creating socket. | 2017-11-01 14:27:03
Socket (238) | Connecting to IP: 8.18.161.135. | 2017-11-01 14:27:03
Socket (237) | Socket gracefully closed by remote side. | 2017-11-01 14:27:03
Socket (237) | Closed. | 2017-11-01 14:27:03
HD Request # 163 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:04
HD Request # 163 | Sending historical data logon request message. | 2017-11-01 14:27:04
HD Request # 163 | Requesting Intraday data. Start date-time: 2017-06-19 14:48:49. Record interval: 0. Symbol: 6MM17 | 2017-11-01 14:27:04
HD Request # 163 | Decompressing data. | 2017-11-01 14:27:04
HD Request # 163 | Receiving Intraday data for F.US.MX6M17 starting at 2017-06-19 14:48:49 | 2017-11-01 14:27:04
Socket (238) | Initiating close of socket by core. | 2017-11-01 14:27:04
Socket (238) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:04
Historical data download thread signaled to stop. | 2017-11-01 14:27:04
HD Request # 163 | Received 4 records from 2017-06-19 14:48:49 to 2017-06-19 14:48:49 (0.0 seconds) and wrote 0 records for F.US.MX6M17 | 2017-11-01 14:27:04
HD Request # 163 | Intraday download COMPLETE for F.US.MX6M17. Completion time: 1s. Unique request ID: 170 | 2017-11-01 14:27:04
Removed historical data download ID 170 | 2017-11-01 14:27:04
Real-time Intraday chart data file updates started for F.US.MX6M17 | 2017-11-01 14:27:04
Intraday chart data file opened for F.US.MX6M17 | 2017-11-01 14:27:04
HD Request # 164 | Downloading Intraday chart data for F.US.NE6Z17 to the file F.US.NE6Z17.scid. Service: cqg | 2017-11-01 14:27:04
HD Request # 164 | Download start date-time: 2017-11-01 14:26:13.000 | 2017-11-01 14:27:04
HD Request # 164 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:27:04
Socket (239) | Creating socket. | 2017-11-01 14:27:04
Socket (239) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:04
Socket (238) | Socket gracefully closed by remote side. | 2017-11-01 14:27:04
Socket (238) | Closed. | 2017-11-01 14:27:04
HD Request # 164 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:04
HD Request # 164 | Sending historical data logon request message. | 2017-11-01 14:27:04
HD Request # 164 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:13. Record interval: 0. Symbol: F.US.NE6Z17 | 2017-11-01 14:27:04
HD Request # 164 | Decompressing data. | 2017-11-01 14:27:04
HD Request # 164 | Receiving Intraday data for F.US.NE6Z17 starting at 2017-11-01 14:26:13 | 2017-11-01 14:27:04
HD Request # 164 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:13 | 2017-11-01 14:27:04
Socket (239) | Initiating close of socket by core. | 2017-11-01 14:27:04
Socket (239) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:04
HD Request # 164 | Received 6 records from 2017-11-01 14:26:13 to 2017-11-01 14:26:13 (0.0 seconds) and wrote 3 records for F.US.NE6Z17 | 2017-11-01 14:27:04
Added 3 Time and Sales records to Intraday data file for F.US.NE6Z17 after download. | 2017-11-01 14:27:04
HD Request # 164 | Intraday download COMPLETE for F.US.NE6Z17. Completion time: 0s. Unique request ID: 171 | 2017-11-01 14:27:04
Removed historical data download ID 171 | 2017-11-01 14:27:04
Real-time Intraday chart data file updates started for F.US.NE6Z17 | 2017-11-01 14:27:04
Intraday chart data file opened for F.US.NE6Z17 | 2017-11-01 14:27:04
HD Request # 165 | Downloading Intraday chart data for F.US.CLEZ17 to the file F.US.CLEZ17.scid. Service: cqg | 2017-11-01 14:27:04
HD Request # 165 | Download start date-time: 2017-11-01 14:26:34.000 | 2017-11-01 14:27:04
HD Request # 165 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:27:04
Socket (240) | Creating socket. | 2017-11-01 14:27:04
Socket (240) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:04
Socket (239) | Socket gracefully closed by remote side. | 2017-11-01 14:27:05
Socket (239) | Closed. | 2017-11-01 14:27:05
HD Request # 165 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:05
HD Request # 165 | Sending historical data logon request message. | 2017-11-01 14:27:05
HD Request # 165 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:34. Record interval: 0. Symbol: F.US.CLEZ17 | 2017-11-01 14:27:05
HD Request # 165 | Decompressing data. | 2017-11-01 14:27:05
HD Request # 165 | Receiving Intraday data for F.US.CLEZ17 starting at 2017-11-01 14:26:34 | 2017-11-01 14:27:05
HD Request # 165 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:34 | 2017-11-01 14:27:05
Socket (240) | Initiating close of socket by core. | 2017-11-01 14:27:05
Socket (240) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:05
Historical data download thread signaled to stop. | 2017-11-01 14:27:05
HD Request # 165 | Received 227 records from 2017-11-01 14:26:34 to 2017-11-01 14:27:09 (35.0 seconds) and wrote 196 records for F.US.CLEZ17 | 2017-11-01 14:27:05
Added 10 Time and Sales records to Intraday data file for F.US.CLEZ17 after download. | 2017-11-01 14:27:05
HD Request # 165 | Intraday download COMPLETE for F.US.CLEZ17. Completion time: 0s. Unique request ID: 172 | 2017-11-01 14:27:05
Removed historical data download ID 172 | 2017-11-01 14:27:05
Real-time Intraday chart data file updates started for F.US.CLEZ17 | 2017-11-01 14:27:05
Intraday chart data file opened for F.US.CLEZ17 | 2017-11-01 14:27:05
HD Request # 166 | Downloading Intraday chart data for F.US.USAZ17 to the file F.US.USAZ17.scid. Service: cqg | 2017-11-01 14:27:05
HD Request # 166 | Download start date-time: 2017-11-01 14:26:16.000 | 2017-11-01 14:27:05
HD Request # 166 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:27:05
Socket (241) | Creating socket. | 2017-11-01 14:27:05
Socket (241) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:05
Socket (240) | Socket gracefully closed by remote side. | 2017-11-01 14:27:05
Socket (240) | Closed. | 2017-11-01 14:27:05
HD Request # 166 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:05
HD Request # 166 | Sending historical data logon request message. | 2017-11-01 14:27:05
HD Request # 166 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:16. Record interval: 0. Symbol: F.US.USAZ17 | 2017-11-01 14:27:05
HD Request # 166 | Decompressing data. | 2017-11-01 14:27:05
HD Request # 166 | Receiving Intraday data for F.US.USAZ17 starting at 2017-11-01 14:26:35 | 2017-11-01 14:27:05
HD Request # 166 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:35 | 2017-11-01 14:27:05
Socket (241) | Initiating close of socket by core. | 2017-11-01 14:27:05
Socket (241) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:05
HD Request # 166 | Received 228 records from 2017-11-01 14:26:35 to 2017-11-01 14:27:11 (36.0 seconds) and wrote 228 records for F.US.USAZ17 | 2017-11-01 14:27:05
HD Request # 166 | Intraday download COMPLETE for F.US.USAZ17. Completion time: 0s. Unique request ID: 173 | 2017-11-01 14:27:05
Removed historical data download ID 173 | 2017-11-01 14:27:05
Real-time Intraday chart data file updates started for F.US.USAZ17 | 2017-11-01 14:27:05
Intraday chart data file opened for F.US.USAZ17 | 2017-11-01 14:27:05
HD Request # 167 | Downloading Intraday chart data for F.US.GCEZ17 to the file F.US.GCEZ17.scid. Service: cqg | 2017-11-01 14:27:05
HD Request # 167 | Download start date-time: 2017-11-01 14:26:32.000 | 2017-11-01 14:27:05
HD Request # 167 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:27:05
Socket (242) | Creating socket. | 2017-11-01 14:27:05
Socket (242) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:05
Socket (241) | Socket gracefully closed by remote side. | 2017-11-01 14:27:05
Socket (241) | Closed. | 2017-11-01 14:27:05
HD Request # 167 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:06
HD Request # 167 | Sending historical data logon request message. | 2017-11-01 14:27:06
HD Request # 167 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:32. Record interval: 0. Symbol: F.US.GCEZ17 | 2017-11-01 14:27:06
HD Request # 167 | Decompressing data. | 2017-11-01 14:27:06
HD Request # 167 | Receiving Intraday data for F.US.GCEZ17 starting at 2017-11-01 14:26:32 | 2017-11-01 14:27:06
HD Request # 167 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:36 | 2017-11-01 14:27:06
Socket (242) | Initiating close of socket by core. | 2017-11-01 14:27:06
Socket (242) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:06
Historical data download thread signaled to stop. | 2017-11-01 14:27:06
HD Request # 167 | Received 641 records from 2017-11-01 14:26:32 to 2017-11-01 14:27:12 (40.0 seconds) and wrote 621 records for F.US.GCEZ17 | 2017-11-01 14:27:06
Added 16 Time and Sales records to Intraday data file for F.US.GCEZ17 after download. | 2017-11-01 14:27:06
HD Request # 167 | Intraday download COMPLETE for F.US.GCEZ17. Completion time: 1s. Unique request ID: 174 | 2017-11-01 14:27:06
Removed historical data download ID 174 | 2017-11-01 14:27:06
Real-time Intraday chart data file updates started for F.US.GCEZ17 | 2017-11-01 14:27:06
Intraday chart data file opened for F.US.GCEZ17 | 2017-11-01 14:27:06
HD Request # 168 | Downloading Intraday chart data for F.US.MGCZ17 to the file F.US.MGCZ17.scid. Service: cqg | 2017-11-01 14:27:06
HD Request # 168 | Download start date-time: 2017-11-01 14:26:26.000 | 2017-11-01 14:27:06
HD Request # 168 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:27:06
Socket (243) | Creating socket. | 2017-11-01 14:27:06
Socket (243) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:06
Socket (242) | Socket gracefully closed by remote side. | 2017-11-01 14:27:06
Socket (242) | Closed. | 2017-11-01 14:27:06
HD Request # 168 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:06
HD Request # 168 | Sending historical data logon request message. | 2017-11-01 14:27:06
HD Request # 168 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:26. Record interval: 0. Symbol: F.US.MGCZ17 | 2017-11-01 14:27:07
HD Request # 168 | Decompressing data. | 2017-11-01 14:27:07
HD Request # 168 | Receiving Intraday data for F.US.MGCZ17 starting at 2017-11-01 14:26:26 | 2017-11-01 14:27:07
HD Request # 168 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:26 | 2017-11-01 14:27:07
Socket (243) | Initiating close of socket by core. | 2017-11-01 14:27:07
Socket (243) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:07
Historical data download thread signaled to stop. | 2017-11-01 14:27:07
HD Request # 168 | Received 13 records from 2017-11-01 14:26:26 to 2017-11-01 14:27:06 (40.0 seconds) and wrote 12 records for F.US.MGCZ17 | 2017-11-01 14:27:07
HD Request # 168 | Intraday download COMPLETE for F.US.MGCZ17. Completion time: 0s. Unique request ID: 175 | 2017-11-01 14:27:07
Removed historical data download ID 175 | 2017-11-01 14:27:07
Real-time Intraday chart data file updates started for F.US.MGCZ17 | 2017-11-01 14:27:07
Intraday chart data file opened for F.US.MGCZ17 | 2017-11-01 14:27:07
HD Request # 169 | Downloading Intraday chart data for F.US.NQMZ17 to the file F.US.NQMZ17.scid. Service: cqg | 2017-11-01 14:27:07
HD Request # 169 | Download start date-time: 2017-11-01 14:26:22.000 | 2017-11-01 14:27:07
HD Request # 169 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:27:07
Socket (244) | Creating socket. | 2017-11-01 14:27:07
Socket (244) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:07
Socket (243) | Socket gracefully closed by remote side. | 2017-11-01 14:27:07
Socket (243) | Closed. | 2017-11-01 14:27:07
HD Request # 169 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:07
HD Request # 169 | Sending historical data logon request message. | 2017-11-01 14:27:07
HD Request # 169 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:22. Record interval: 0. Symbol: F.US.NQMZ17 | 2017-11-01 14:27:07
HD Request # 169 | Decompressing data. | 2017-11-01 14:27:07
HD Request # 169 | Receiving Intraday data for F.US.NQMZ17 starting at 2017-11-01 14:26:22 | 2017-11-01 14:27:07
Socket (244) | Initiating close of socket by core. | 2017-11-01 14:27:07
Socket (244) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:07
HD Request # 169 | Received 1 record from 2017-11-01 14:26:22 to 2017-11-01 14:26:22 (0.0 seconds) and wrote 0 records for F.US.NQMZ17 | 2017-11-01 14:27:07
HD Request # 169 | Intraday download COMPLETE for F.US.NQMZ17. Completion time: 1s. Unique request ID: 176 | 2017-11-01 14:27:07
Removed historical data download ID 176 | 2017-11-01 14:27:07
Real-time Intraday chart data file updates started for F.US.NQMZ17 | 2017-11-01 14:27:07
Intraday chart data file opened for F.US.NQMZ17 | 2017-11-01 14:27:07
HD Request # 170 | Downloading Intraday chart data for F.US.CPEZ17 to the file F.US.CPEZ17.scid. Service: cqg | 2017-11-01 14:27:07
HD Request # 170 | Download start date-time: 2017-11-01 14:26:31.000 | 2017-11-01 14:27:07
HD Request # 170 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:27:07
Socket (245) | Creating socket. | 2017-11-01 14:27:07
Socket (245) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:07
Socket (244) | Socket gracefully closed by remote side. | 2017-11-01 14:27:07
Socket (244) | Closed. | 2017-11-01 14:27:07
HD Request # 170 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:07
HD Request # 170 | Sending historical data logon request message. | 2017-11-01 14:27:07
HD Request # 170 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:31. Record interval: 0. Symbol: F.US.CPEZ17 | 2017-11-01 14:27:07
HD Request # 170 | Decompressing data. | 2017-11-01 14:27:07
HD Request # 170 | Receiving Intraday data for F.US.CPEZ17 starting at 2017-11-01 14:26:31 | 2017-11-01 14:27:07
HD Request # 170 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:37 | 2017-11-01 14:27:07
Socket (245) | Initiating close of socket by core. | 2017-11-01 14:27:07
Socket (245) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:07
HD Request # 170 | Received 79 records from 2017-11-01 14:26:31 to 2017-11-01 14:27:14 (43.0 seconds) and wrote 78 records for F.US.CPEZ17 | 2017-11-01 14:27:07
Added 1 Time and Sales records to Intraday data file for F.US.CPEZ17 after download. | 2017-11-01 14:27:07
HD Request # 170 | Intraday download COMPLETE for F.US.CPEZ17. Completion time: 0s. Unique request ID: 177 | 2017-11-01 14:27:07
Removed historical data download ID 177 | 2017-11-01 14:27:07
Real-time Intraday chart data file updates started for F.US.CPEZ17 | 2017-11-01 14:27:07
Intraday chart data file opened for F.US.CPEZ17 | 2017-11-01 14:27:07
HD Request # 171 | Downloading Intraday chart data for F.US.TYAZ17 to the file F.US.TYAZ17.scid. Service: cqg | 2017-11-01 14:27:07
HD Request # 171 | Download start date-time: 2017-11-01 14:26:33.000 | 2017-11-01 14:27:07
HD Request # 171 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:27:07
Socket (246) | Creating socket. | 2017-11-01 14:27:07
Socket (246) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:07
Socket (245) | Socket gracefully closed by remote side. | 2017-11-01 14:27:08
Socket (245) | Closed. | 2017-11-01 14:27:08
HD Request # 171 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:08
HD Request # 171 | Sending historical data logon request message. | 2017-11-01 14:27:08
HD Request # 171 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:33. Record interval: 0. Symbol: F.US.TYAZ17 | 2017-11-01 14:27:08
HD Request # 171 | Decompressing data. | 2017-11-01 14:27:08
HD Request # 171 | Receiving Intraday data for F.US.TYAZ17 starting at 2017-11-01 14:26:33 | 2017-11-01 14:27:08
HD Request # 171 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:47 | 2017-11-01 14:27:08
Socket (246) | Initiating close of socket by core. | 2017-11-01 14:27:08
Socket (246) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:08
Historical data download thread signaled to stop. | 2017-11-01 14:27:08
HD Request # 171 | Received 268 records from 2017-11-01 14:26:33 to 2017-11-01 14:27:11 (38.0 seconds) and wrote 248 records for F.US.TYAZ17 | 2017-11-01 14:27:08
HD Request # 171 | Intraday download COMPLETE for F.US.TYAZ17. Completion time: 0s. Unique request ID: 178 | 2017-11-01 14:27:08
Removed historical data download ID 178 | 2017-11-01 14:27:08
Real-time Intraday chart data file updates started for F.US.TYAZ17 | 2017-11-01 14:27:08
Intraday chart data file opened for F.US.TYAZ17 | 2017-11-01 14:27:08
HD Request # 172 | Downloading Intraday chart data for F.US.ENQZ17 to the file F.US.ENQZ17.scid. Service: cqg | 2017-11-01 14:27:08
HD Request # 172 | Download start date-time: 2017-11-01 14:26:34.000 | 2017-11-01 14:27:08
HD Request # 172 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:27:08
Socket (247) | Creating socket. | 2017-11-01 14:27:08
Socket (247) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:08
Socket (246) | Socket gracefully closed by remote side. | 2017-11-01 14:27:08
Socket (246) | Closed. | 2017-11-01 14:27:08
HD Request # 172 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:08
HD Request # 172 | Sending historical data logon request message. | 2017-11-01 14:27:08
Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEZ17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.CPEZ17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.GCEZ17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6EZ17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6AZ17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.DDZ17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.DSXZ17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.EPZ17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.BP6Z17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.JY6Z17.scid | 2017-11-01 14:27:09
Opened cached Intraday file: C:\SierraChart\Data\F.US.NQMZ17.scid | 2017-11-01 14:27:09
HD Request # 172 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:34. Record interval: 0. Symbol: F.US.ENQZ17 | 2017-11-01 14:27:09
HD Request # 172 | Decompressing data. | 2017-11-01 14:27:09
HD Request # 172 | Receiving Intraday data for F.US.ENQZ17 starting at 2017-11-01 14:26:34 | 2017-11-01 14:27:09
HD Request # 172 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:35 | 2017-11-01 14:27:09
Socket (247) | Initiating close of socket by core. | 2017-11-01 14:27:09
Socket (247) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:09
Historical data download thread signaled to stop. | 2017-11-01 14:27:09
HD Request # 172 | Received 745 records from 2017-11-01 14:26:34 to 2017-11-01 14:27:16 (42.0 seconds) and wrote 634 records for F.US.ENQZ17 | 2017-11-01 14:27:09
Added 4 Time and Sales records to Intraday data file for F.US.ENQZ17 after download. | 2017-11-01 14:27:09
HD Request # 172 | Intraday download COMPLETE for F.US.ENQZ17. Completion time: 1s. Unique request ID: 179 | 2017-11-01 14:27:09
Removed historical data download ID 179 | 2017-11-01 14:27:09
Real-time Intraday chart data file updates started for F.US.ENQZ17 | 2017-11-01 14:27:09
Intraday chart data file opened for F.US.ENQZ17 | 2017-11-01 14:27:09
HD Request # 173 | Downloading Intraday chart data for F.US.YMZ17 to the file F.US.YMZ17.scid. Service: cqg | 2017-11-01 14:27:09
HD Request # 173 | Download start date-time: 2017-11-01 14:26:23.000 | 2017-11-01 14:27:09
HD Request # 173 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:27:09
Socket (248) | Creating socket. | 2017-11-01 14:27:09
Socket (248) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:09
Socket (247) | Socket gracefully closed by remote side. | 2017-11-01 14:27:10
Socket (247) | Closed. | 2017-11-01 14:27:10
HD Request # 173 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:10
HD Request # 173 | Sending historical data logon request message. | 2017-11-01 14:27:10
HD Request # 173 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:23. Record interval: 0. Symbol: F.US.YMZ17 | 2017-11-01 14:27:10
HD Request # 173 | Decompressing data. | 2017-11-01 14:27:10
HD Request # 173 | Receiving Intraday data for F.US.YMZ17 starting at 2017-11-01 14:26:23 | 2017-11-01 14:27:10
HD Request # 173 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:32 | 2017-11-01 14:27:10
Socket (248) | Initiating close of socket by core. | 2017-11-01 14:27:10
Socket (248) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:10
Historical data download thread signaled to stop. | 2017-11-01 14:27:10
HD Request # 173 | Received 69 records from 2017-11-01 14:26:23 to 2017-11-01 14:27:05 (42.0 seconds) and wrote 60 records for F.US.YMZ17 | 2017-11-01 14:27:10
Added 1 Time and Sales records to Intraday data file for F.US.YMZ17 after download. | 2017-11-01 14:27:10
HD Request # 173 | Intraday download COMPLETE for F.US.YMZ17. Completion time: 1s. Unique request ID: 180 | 2017-11-01 14:27:10
Removed historical data download ID 180 | 2017-11-01 14:27:10
Real-time Intraday chart data file updates started for F.US.YMZ17 | 2017-11-01 14:27:10
Intraday chart data file opened for F.US.YMZ17 | 2017-11-01 14:27:10
HD Request # 174 | Downloading Intraday chart data for F.US.DLZ17 to the file F.US.DLZ17.scid. Service: cqg | 2017-11-01 14:27:10
HD Request # 174 | Download start date-time: 2017-11-01 14:26:15.000 | 2017-11-01 14:27:10
HD Request # 174 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:27:10
Socket (249) | Creating socket. | 2017-11-01 14:27:10
Socket (249) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:10
Socket (248) | Socket gracefully closed by remote side. | 2017-11-01 14:27:10
Socket (248) | Closed. | 2017-11-01 14:27:10
HD Request # 174 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:10
HD Request # 174 | Sending historical data logon request message. | 2017-11-01 14:27:10
HD Request # 174 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:15. Record interval: 0. Symbol: F.US.DLZ17 | 2017-11-01 14:27:10
HD Request # 174 | Decompressing data. | 2017-11-01 14:27:10
HD Request # 174 | Receiving Intraday data for F.US.DLZ17 starting at 2017-11-01 14:26:16 | 2017-11-01 14:27:10
HD Request # 174 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:16 | 2017-11-01 14:27:10
Socket (249) | Initiating close of socket by core. | 2017-11-01 14:27:10
Socket (249) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:10
HD Request # 174 | Received 18 records from 2017-11-01 14:26:16 to 2017-11-01 14:27:17 (61.0 seconds) and wrote 18 records for F.US.DLZ17 | 2017-11-01 14:27:10
HD Request # 174 | Intraday download COMPLETE for F.US.DLZ17. Completion time: 0s. Unique request ID: 181 | 2017-11-01 14:27:10
Removed historical data download ID 181 | 2017-11-01 14:27:10
Real-time Intraday chart data file updates started for F.US.DLZ17 | 2017-11-01 14:27:10
Intraday chart data file opened for F.US.DLZ17 | 2017-11-01 14:27:10
HD Request # 175 | Downloading Intraday chart data for F.US.DGZ17 to the file F.US.DGZ17.scid. Service: cqg | 2017-11-01 14:27:10
HD Request # 175 | Download start date-time: 2017-11-01 14:26:25.000 | 2017-11-01 14:27:10
HD Request # 175 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:27:10
Socket (250) | Creating socket. | 2017-11-01 14:27:10
Socket (250) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:10
Socket (249) | Socket gracefully closed by remote side. | 2017-11-01 14:27:10
Socket (249) | Closed. | 2017-11-01 14:27:10
HD Request # 175 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:11
HD Request # 175 | Sending historical data logon request message. | 2017-11-01 14:27:11
HD Request # 175 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:25. Record interval: 0. Symbol: F.US.DGZ17 | 2017-11-01 14:27:11
HD Request # 175 | Decompressing data. | 2017-11-01 14:27:11
HD Request # 175 | Receiving Intraday data for F.US.DGZ17 starting at 2017-11-01 14:26:25 | 2017-11-01 14:27:11
HD Request # 175 | Timestamp of first Intraday data file record written: 2017-11-01 14:27:04 | 2017-11-01 14:27:11
Socket (250) | Initiating close of socket by core. | 2017-11-01 14:27:11
Socket (250) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:11
Historical data download thread signaled to stop. | 2017-11-01 14:27:11
HD Request # 175 | Received 7 records from 2017-11-01 14:26:25 to 2017-11-01 14:27:13 (48.0 seconds) and wrote 6 records for F.US.DGZ17 | 2017-11-01 14:27:11
HD Request # 175 | Intraday download COMPLETE for F.US.DGZ17. Completion time: 0s. Unique request ID: 182 | 2017-11-01 14:27:11
Removed historical data download ID 182 | 2017-11-01 14:27:11
Real-time Intraday chart data file updates started for F.US.DGZ17 | 2017-11-01 14:27:11
Intraday chart data file opened for F.US.DGZ17 | 2017-11-01 14:27:11
HD Request # 176 | Downloading Intraday chart data for F.US.FGBXZ17 to the file F.US.FGBXZ17.scid. Service: cqg | 2017-11-01 14:27:11
HD Request # 176 | Download start date-time: 2017-11-01 14:26:21.000 | 2017-11-01 14:27:11
HD Request # 176 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:27:11
Socket (251) | Creating socket. | 2017-11-01 14:27:11
Socket (251) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:11
Socket (250) | Socket gracefully closed by remote side. | 2017-11-01 14:27:11
Socket (250) | Closed. | 2017-11-01 14:27:11
HD Request # 176 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:12
HD Request # 176 | Sending historical data logon request message. | 2017-11-01 14:27:12
HD Request # 176 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:21. Record interval: 0. Symbol: F.US.FGBXZ17 | 2017-11-01 14:27:12
HD Request # 176 | Decompressing data. | 2017-11-01 14:27:13
HD Request # 176 | Receiving Intraday data for F.US.FGBXZ17 starting at 2017-11-01 14:26:22 | 2017-11-01 14:27:13
HD Request # 176 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:22 | 2017-11-01 14:27:13
Socket (251) | Initiating close of socket by core. | 2017-11-01 14:27:13
Socket (251) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:13
Historical data download thread signaled to stop. | 2017-11-01 14:27:13
HD Request # 176 | Received 12 records from 2017-11-01 14:26:22 to 2017-11-01 14:26:55 (33.0 seconds) and wrote 12 records for F.US.FGBXZ17 | 2017-11-01 14:27:13
Added 4 Time and Sales records to Intraday data file for F.US.FGBXZ17 after download. | 2017-11-01 14:27:13
HD Request # 176 | Intraday download COMPLETE for F.US.FGBXZ17. Completion time: 2s. Unique request ID: 183 | 2017-11-01 14:27:13
Removed historical data download ID 183 | 2017-11-01 14:27:13
Real-time Intraday chart data file updates started for F.US.FGBXZ17 | 2017-11-01 14:27:13
Intraday chart data file opened for F.US.FGBXZ17 | 2017-11-01 14:27:13
HD Request # 177 | Downloading Intraday chart data for F.US.FBTPZ17 to the file F.US.FBTPZ17.scid. Service: eurex | 2017-11-01 14:27:13
HD Request # 177 | Download start date-time: 2017-11-01 14:26:29.000 | 2017-11-01 14:27:13
HD Request # 177 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 14:27:13
Socket (252) | Creating socket. | 2017-11-01 14:27:13
Socket (252) | Connecting to IP: 8.18.161.133. | 2017-11-01 14:27:13
Socket (251) | Socket gracefully closed by remote side. | 2017-11-01 14:27:13
Socket (251) | Closed. | 2017-11-01 14:27:13
HD Request # 177 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:13
HD Request # 177 | Sending historical data logon request message. | 2017-11-01 14:27:13
HD Request # 177 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:29. Record interval: 0. Symbol: IIZ17 | 2017-11-01 14:27:13
HD Request # 177 | Decompressing data. | 2017-11-01 14:27:14
Socket (252) | Initiating close of socket by core. | 2017-11-01 14:27:14
Socket (252) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:14
Historical data download thread signaled to stop. | 2017-11-01 14:27:14
HD Request # 177 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FBTPZ17 | 2017-11-01 14:27:14
HD Request # 177 | Intraday download COMPLETE for F.US.FBTPZ17. Completion time: 0s. Unique request ID: 184 | 2017-11-01 14:27:14
Removed historical data download ID 184 | 2017-11-01 14:27:14
Real-time Intraday chart data file updates started for F.US.FBTPZ17 | 2017-11-01 14:27:14
Intraday chart data file opened for F.US.FBTPZ17 | 2017-11-01 14:27:14
HD Request # 178 | Downloading Intraday chart data for F.US.FOATZ17 to the file F.US.FOATZ17.scid. Service: eurex | 2017-11-01 14:27:14
HD Request # 178 | Download start date-time: 2017-11-01 14:26:32.000 | 2017-11-01 14:27:14
HD Request # 178 | Using server: ds1.sierracharts.com port 10149 | 2017-11-01 14:27:14
Socket (253) | Creating socket. | 2017-11-01 14:27:14
Socket (253) | Connecting to IP: 8.18.161.135. | 2017-11-01 14:27:14
Socket (252) | Socket gracefully closed by remote side. | 2017-11-01 14:27:14
Socket (252) | Closed. | 2017-11-01 14:27:14
HD Request # 178 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:14
HD Request # 178 | Sending historical data logon request message. | 2017-11-01 14:27:14
HD Request # 178 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:32. Record interval: 0. Symbol: FNZ17 | 2017-11-01 14:27:14
HD Request # 178 | Decompressing data. | 2017-11-01 14:27:14
Socket (253) | Initiating close of socket by core. | 2017-11-01 14:27:14
Socket (253) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:14
HD Request # 178 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FOATZ17 | 2017-11-01 14:27:14
HD Request # 178 | Receiving Intraday data for F.US.FOATZ17 starting at 2017-11-01 14:26:58 | 2017-11-01 14:27:14
HD Request # 178 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:58 | 2017-11-01 14:27:14
Added 15 Time and Sales records to Intraday data file for F.US.FOATZ17 after download. | 2017-11-01 14:27:14
HD Request # 178 | Intraday download COMPLETE for F.US.FOATZ17. Completion time: 1s. Unique request ID: 185 | 2017-11-01 14:27:14
Removed historical data download ID 185 | 2017-11-01 14:27:14
Real-time Intraday chart data file updates started for F.US.FOATZ17 | 2017-11-01 14:27:14
Intraday chart data file opened for F.US.FOATZ17 | 2017-11-01 14:27:14
HD Request # 179 | Downloading Intraday chart data for F.US.DSXZ16 to the file F.US.DSXZ16.scid. Service: eurex | 2017-11-01 14:27:14
HD Request # 179 | Download start date-time: 2016-12-16 10:59:59.000 | 2017-11-01 14:27:14
HD Request # 179 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 14:27:14
Socket (254) | Creating socket. | 2017-11-01 14:27:14
Socket (254) | Connecting to IP: 8.18.161.133. | 2017-11-01 14:27:14
Socket (253) | Socket gracefully closed by remote side. | 2017-11-01 14:27:14
Socket (253) | Closed. | 2017-11-01 14:27:14
HD Request # 179 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:14
HD Request # 179 | Sending historical data logon request message. | 2017-11-01 14:27:14
HD Request # 179 | Requesting Intraday data. Start date-time: 2016-12-16 10:59:59. Record interval: 0. Symbol: FXZ16 | 2017-11-01 14:27:14
HD Request # 179 | Decompressing data. | 2017-11-01 14:27:14
HD Request # 179 | Receiving Intraday data for F.US.DSXZ16 starting at 2016-12-16 10:59:59 | 2017-11-01 14:27:14
Socket (254) | Initiating close of socket by core. | 2017-11-01 14:27:14
Socket (254) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:14
HD Request # 179 | Received 1 record from 2016-12-16 10:59:59 to 2016-12-16 10:59:59 (0.0 seconds) and wrote 0 records for F.US.DSXZ16 | 2017-11-01 14:27:14
HD Request # 179 | Intraday download COMPLETE for F.US.DSXZ16. Completion time: 0s. Unique request ID: 186 | 2017-11-01 14:27:14
Removed historical data download ID 186 | 2017-11-01 14:27:14
Real-time Intraday chart data file updates started for F.US.DSXZ16 | 2017-11-01 14:27:14
Intraday chart data file opened for F.US.DSXZ16 | 2017-11-01 14:27:14
HD Request # 180 | Downloading Intraday chart data for F.US.DA6Z17 to the file F.US.DA6Z17.scid. Service: cqg | 2017-11-01 14:27:14
HD Request # 180 | Download start date-time: 2017-11-01 14:26:33.000 | 2017-11-01 14:27:14
HD Request # 180 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:27:14
Socket (255) | Creating socket. | 2017-11-01 14:27:15
Socket (255) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:15
Socket (254) | Socket gracefully closed by remote side. | 2017-11-01 14:27:15
Socket (254) | Closed. | 2017-11-01 14:27:15
HD Request # 180 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:15
HD Request # 180 | Sending historical data logon request message. | 2017-11-01 14:27:15
HD Request # 180 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:33. Record interval: 0. Symbol: F.US.DA6Z17 | 2017-11-01 14:27:15
HD Request # 180 | Decompressing data. | 2017-11-01 14:27:15
HD Request # 180 | Receiving Intraday data for F.US.DA6Z17 starting at 2017-11-01 14:26:33 | 2017-11-01 14:27:15
HD Request # 180 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:41 | 2017-11-01 14:27:15
Socket (255) | Initiating close of socket by core. | 2017-11-01 14:27:15
Socket (255) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:15
Historical data download thread signaled to stop. | 2017-11-01 14:27:15
HD Request # 180 | Received 112 records from 2017-11-01 14:26:33 to 2017-11-01 14:27:19 (46.0 seconds) and wrote 97 records for F.US.DA6Z17 | 2017-11-01 14:27:15
Added 2 Time and Sales records to Intraday data file for F.US.DA6Z17 after download. | 2017-11-01 14:27:15
HD Request # 180 | Intraday download COMPLETE for F.US.DA6Z17. Completion time: 1s. Unique request ID: 187 | 2017-11-01 14:27:15
Removed historical data download ID 187 | 2017-11-01 14:27:15
Real-time Intraday chart data file updates started for F.US.DA6Z17 | 2017-11-01 14:27:15
Intraday chart data file opened for F.US.DA6Z17 | 2017-11-01 14:27:15
HD Request # 181 | Downloading Intraday chart data for F.US.CA6Z17 to the file F.US.CA6Z17.scid. Service: cqg | 2017-11-01 14:27:15
HD Request # 181 | Download start date-time: 2017-11-01 14:26:34.000 | 2017-11-01 14:27:15
HD Request # 181 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:27:15
Socket (256) | Creating socket. | 2017-11-01 14:27:15
Socket (256) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:15
Socket (255) | Socket gracefully closed by remote side. | 2017-11-01 14:27:15
Socket (255) | Closed. | 2017-11-01 14:27:15
HD Request # 181 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:18
HD Request # 181 | Sending historical data logon request message. | 2017-11-01 14:27:18
HD Request # 181 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:34. Record interval: 0. Symbol: F.US.CA6Z17 | 2017-11-01 14:27:18
HD Request # 181 | Decompressing data. | 2017-11-01 14:27:19
HD Request # 181 | Receiving Intraday data for F.US.CA6Z17 starting at 2017-11-01 14:26:34 | 2017-11-01 14:27:19
HD Request # 181 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:34 | 2017-11-01 14:27:19
Socket (256) | Initiating close of socket by core. | 2017-11-01 14:27:19
Socket (256) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:19
Historical data download thread signaled to stop. | 2017-11-01 14:27:19
HD Request # 181 | Received 111 records from 2017-11-01 14:26:34 to 2017-11-01 14:27:24 (50.0 seconds) and wrote 110 records for F.US.CA6Z17 | 2017-11-01 14:27:19
Added 2 Time and Sales records to Intraday data file for F.US.CA6Z17 after download. | 2017-11-01 14:27:19
HD Request # 181 | Intraday download COMPLETE for F.US.CA6Z17. Completion time: 3s. Unique request ID: 188 | 2017-11-01 14:27:19
Removed historical data download ID 188 | 2017-11-01 14:27:19
Real-time Intraday chart data file updates started for F.US.CA6Z17 | 2017-11-01 14:27:19
Intraday chart data file opened for F.US.CA6Z17 | 2017-11-01 14:27:19
HD Request # 182 | Downloading Intraday chart data for F.US.MX6Z17 to the file F.US.MX6Z17.scid. Service: cqg | 2017-11-01 14:27:19
HD Request # 182 | Download start date-time: 2017-11-01 14:26:27.000 | 2017-11-01 14:27:19
HD Request # 182 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:27:19
Socket (257) | Creating socket. | 2017-11-01 14:27:19
Socket (257) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:27:19
Socket (256) | Socket gracefully closed by remote side. | 2017-11-01 14:27:19
Socket (256) | Closed. | 2017-11-01 14:27:19
HD Request # 182 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:19
HD Request # 182 | Sending historical data logon request message. | 2017-11-01 14:27:19
HD Request # 182 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:27. Record interval: 0. Symbol: F.US.MX6Z17 | 2017-11-01 14:27:19
HD Request # 182 | Decompressing data. | 2017-11-01 14:27:19
HD Request # 182 | Receiving Intraday data for F.US.MX6Z17 starting at 2017-11-01 14:26:27 | 2017-11-01 14:27:19
HD Request # 182 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:51 | 2017-11-01 14:27:19
Socket (257) | Initiating close of socket by core. | 2017-11-01 14:27:19
Socket (257) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:19
HD Request # 182 | Received 62 records from 2017-11-01 14:26:27 to 2017-11-01 14:27:24 (57.0 seconds) and wrote 61 records for F.US.MX6Z17 | 2017-11-01 14:27:19
HD Request # 182 | Intraday download COMPLETE for F.US.MX6Z17. Completion time: 0s. Unique request ID: 189 | 2017-11-01 14:27:19
Removed historical data download ID 189 | 2017-11-01 14:27:19
Real-time Intraday chart data file updates started for F.US.MX6Z17 | 2017-11-01 14:27:19
Intraday chart data file opened for F.US.MX6Z17 | 2017-11-01 14:27:19
HD Request # 183 | Downloading Intraday chart data for F.US.DDZ16 to the file F.US.DDZ16.scid. Service: eurex | 2017-11-01 14:27:19
HD Request # 183 | Download start date-time: 2016-12-16 11:59:55.000 | 2017-11-01 14:27:19
HD Request # 183 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 14:27:19
Socket (258) | Creating socket. | 2017-11-01 14:27:19
Socket (258) | Connecting to IP: 8.18.161.135. | 2017-11-01 14:27:19
Socket (257) | Socket gracefully closed by remote side. | 2017-11-01 14:27:19
Socket (257) | Closed. | 2017-11-01 14:27:19
HD Request # 183 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:19
HD Request # 183 | Sending historical data logon request message. | 2017-11-01 14:27:19
HD Request # 183 | Requesting Intraday data. Start date-time: 2016-12-16 11:59:55. Record interval: 0. Symbol: DYZ16 | 2017-11-01 14:27:19
Opened cached Intraday file: C:\SierraChart\Data\F.US.NE6Z17.scid | 2017-11-01 14:27:19
Opened cached Intraday file: C:\SierraChart\Data\F.US.USAZ17.scid | 2017-11-01 14:27:19
Opened cached Intraday file: C:\SierraChart\Data\F.US.TYAZ17.scid | 2017-11-01 14:27:19
Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQZ17.scid | 2017-11-01 14:27:19
Opened cached Intraday file: C:\SierraChart\Data\F.US.YMZ17.scid | 2017-11-01 14:27:19
Opened cached Intraday file: C:\SierraChart\Data\F.US.DGZ17.scid | 2017-11-01 14:27:19
Opened cached Intraday file: C:\SierraChart\Data\F.US.FBTPZ17.scid | 2017-11-01 14:27:19
Opened cached Intraday file: C:\SierraChart\Data\F.US.DA6Z17.scid | 2017-11-01 14:27:19
HD Request # 183 | Decompressing data. | 2017-11-01 14:27:20
HD Request # 183 | Receiving Intraday data for F.US.DDZ16 starting at 2016-12-16 11:59:55 | 2017-11-01 14:27:20
Socket (258) | Initiating close of socket by core. | 2017-11-01 14:27:20
Socket (258) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:20
Historical data download thread signaled to stop. | 2017-11-01 14:27:20
HD Request # 183 | Received 1 record from 2016-12-16 11:59:55 to 2016-12-16 11:59:55 (0.0 seconds) and wrote 0 records for F.US.DDZ16 | 2017-11-01 14:27:20
HD Request # 183 | Intraday download COMPLETE for F.US.DDZ16. Completion time: 0s. Unique request ID: 190 | 2017-11-01 14:27:20
Removed historical data download ID 190 | 2017-11-01 14:27:20
Real-time Intraday chart data file updates started for F.US.DDZ16 | 2017-11-01 14:27:20
Intraday chart data file opened for F.US.DDZ16 | 2017-11-01 14:27:20
HD Request # 184 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2017-11-01 14:27:20
HD Request # 184 | Download start date-time: 2017-11-01 14:26:58.000 | 2017-11-01 14:27:20
HD Request # 184 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:27:20
Socket (259) | Creating socket. | 2017-11-01 14:27:20
Socket (259) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:27:20
Socket (258) | Socket gracefully closed by remote side. | 2017-11-01 14:27:20
Socket (258) | Closed. | 2017-11-01 14:27:20
HD Request # 184 | Setting DTC encoding to Binary VLS | 2017-11-01 14:27:20
HD Request # 184 | Sending historical data logon request message. | 2017-11-01 14:27:20
HD Request # 184 | Requesting Intraday data. Start date-time: 2017-11-01 14:26:58. Record interval: 0. Symbol: NISS-NYSE | 2017-11-01 14:27:20
HD Request # 184 | Decompressing data. | 2017-11-01 14:27:20
HD Request # 184 | Receiving Intraday data for NISS-NYSE starting at 2017-11-01 14:26:58 | 2017-11-01 14:27:20
HD Request # 184 | Timestamp of first Intraday data file record written: 2017-11-01 14:26:59 | 2017-11-01 14:27:20
Socket (259) | Initiating close of socket by core. | 2017-11-01 14:27:20
Socket (259) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:27:20
HD Request # 184 | Received 29 records from 2017-11-01 14:26:58 to 2017-11-01 14:27:26 (28.0 seconds) and wrote 28 records for NISS-NYSE | 2017-11-01 14:27:20
Added 3 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2017-11-01 14:27:20
HD Request # 184 | Intraday download COMPLETE for NISS-NYSE. Completion time: 1s. Unique request ID: 191 | 2017-11-01 14:27:20
Removed historical data download ID 191 | 2017-11-01 14:27:20
Real-time Intraday chart data file updates started for NISS-NYSE | 2017-11-01 14:27:20
Intraday chart data file opened for NISS-NYSE | 2017-11-01 14:27:20
Socket (259) | Socket gracefully closed by remote side. | 2017-11-01 14:27:20
Socket (259) | Closed. | 2017-11-01 14:27:20
Opened cached Intraday file: C:\SierraChart\Data\F.US.CA6Z17.scid | 2017-11-01 14:27:29
Opened cached Intraday file: C:\SierraChart\Data\F.US.FGBXZ17.scid | 2017-11-01 14:27:29
Opened cached Intraday file: C:\SierraChart\Data\F.US.FOATZ17.scid | 2017-11-01 14:27:29
Opened cached Intraday file: C:\SierraChart\Data\F.US.MX6Z17.scid | 2017-11-01 14:27:29
Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2017-11-01 14:27:29
F.US.TYAZ17 #11 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.EU6Z17 #19 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.USAZ17 #30 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DLZ17 #9 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DGZ17 #36 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.FGBXZ17 #38 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.FBTPZ17 #39 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DSXZ17 #41 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.EPZ17 #37 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.FOATZ17 #43 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.JY6Z17 #40 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.FDXMZ17 #45 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.CLEZ17 #46 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.EU6Z17 #47 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DBZ17 #5 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.BP6Z17 #12 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.JY6Z17 [CV] 5 Min #21 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.FOATZ17 [CBV] 15 Min #44 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DBZ17 1500 Volume #13 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DBZ17 [CBV] 15 Min #20 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DBZ17 [CBV] 3 Min #25 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DSXZ17 [CBV] #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DBZ17 Renko 2t #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DLZ17 [CBV] #34 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DBZ17 10 Min #42 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DBZ17 [CBV] #48 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DBZ17 [CBV] 1 Day #14 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:48
F.US.DBZ17 [CBV] 60 Min #23 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 5 Min #28 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.TYAZ17 #11 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.EU6Z17 #19 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.USAZ17 #30 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DLZ17 #9 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DGZ17 #36 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.FGBXZ17 #38 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.FBTPZ17 #39 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DSXZ17 #41 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.EPZ17 #37 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.FOATZ17 #43 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.JY6Z17 #40 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.FDXMZ17 #45 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.CLEZ17 #46 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.EU6Z17 #47 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 #5 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.BP6Z17 #12 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.JY6Z17 [CV] 5 Min #21 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.FOATZ17 [CBV] 15 Min #44 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 1500 Volume #13 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 [CBV] 15 Min #20 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 [CBV] 3 Min #25 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DSXZ17 [CBV] #2 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 Renko 2t #3 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DLZ17 [CBV] #34 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 10 Min #42 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 [CBV] #48 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 [CBV] 1 Day #14 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:49
F.US.DBZ17 [CBV] 60 Min #23 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:50
Opened cached Intraday file: C:\SierraChart\Data\F.US.DLZ17.scid | 2017-11-01 14:27:50
F.US.DBZ17 5 Min #28 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:50
F.US.TYAZ17 #11 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:50
F.US.EU6Z17 #19 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:50
F.US.USAZ17 #30 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:50
F.US.DLZ17 #9 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:50
F.US.FGBXZ17 #38 | BitBlt error. Windows error code 6: The handle is invalid. | 2017-11-01 14:27:50
Opened cached Intraday file: C:\SierraChart\Data\F.US.MGCZ17.scid | 2017-11-01 14:28:00
Opened cached Intraday file: C:\SierraChart\Data\F.US.GMCDZ17.scid | 2017-11-01 14:29:21
SC DTC Data with Market Depth | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2017-11-01 14:34:11
DTC Client socket (226) | Initiating close of socket by core. | 2017-11-01 14:34:11
DTC Client socket (226) | Write in progress. Shutdown being delayed. | 2017-11-01 14:34:11
SC DTC Data with Market Depth | Disconnected from the server. | 2017-11-01 14:34:11
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2017-11-01 14:34:11
DTC Client socket (226) | Write has completed. Shutdown being performed. | 2017-11-01 14:34:13
DTC Client socket (226) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:34:13
DTC Client socket (226) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 14:34:13 *
DTC Client socket (226) | Socket gracefully closed by remote side. | 2017-11-01 14:34:13
DTC Client socket (226) | Closed. | 2017-11-01 14:34:13
SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2017-11-01 14:34:13
DTC Client socket (262) | Creating socket. | 2017-11-01 14:34:13
DTC Client socket (262) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:34:13
SC DTC Data with Market Depth | Connected to server. | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Starting socket receive thread. | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Sending logon request message. | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Received logon response. | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Successfully connected. | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Trading is not supported. | 2017-11-01 14:34:14
Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2017-11-01 14:34:14
Delaying start of download for NISS-NYSE | 2017-11-01 14:34:14
SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2017-11-01 14:34:14
HD Request # 185 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2017-11-01 14:34:19
HD Request # 185 | Download start date-time: 2017-11-01 14:33:31.000 | 2017-11-01 14:34:19
HD Request # 185 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:34:19
Socket (263) | Creating socket. | 2017-11-01 14:34:19
Socket (263) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:34:19
HD Request # 185 | Setting DTC encoding to Binary VLS | 2017-11-01 14:34:19
HD Request # 185 | Sending historical data logon request message. | 2017-11-01 14:34:19
HD Request # 185 | Requesting Intraday data. Start date-time: 2017-11-01 14:33:31. Record interval: 0. Symbol: NISS-NYSE | 2017-11-01 14:34:19
HD Request # 185 | Decompressing data. | 2017-11-01 14:34:19
HD Request # 185 | Receiving Intraday data for NISS-NYSE starting at 2017-11-01 14:33:31 | 2017-11-01 14:34:19
HD Request # 185 | Timestamp of first Intraday data file record written: 2017-11-01 14:33:32 | 2017-11-01 14:34:19
Socket (263) | Initiating close of socket by core. | 2017-11-01 14:34:19
Socket (263) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:34:19
Historical data download thread signaled to stop. | 2017-11-01 14:34:19
HD Request # 185 | Received 56 records from 2017-11-01 14:33:31 to 2017-11-01 14:34:26 (55.0 seconds) and wrote 55 records for NISS-NYSE | 2017-11-01 14:34:19
Added 2 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2017-11-01 14:34:19
HD Request # 185 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 192 | 2017-11-01 14:34:19
Removed historical data download ID 192 | 2017-11-01 14:34:19
Real-time Intraday chart data file updates started for NISS-NYSE | 2017-11-01 14:34:19
Intraday chart data file opened for NISS-NYSE | 2017-11-01 14:34:19
Socket (263) | Socket gracefully closed by remote side. | 2017-11-01 14:34:19
Socket (263) | Closed. | 2017-11-01 14:34:19
Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2017-11-01 14:34:25
CQG FIX: No heartbeat messages received from server. Sent Test Request message to server. | 2017-11-01 14:40:00
CQG FIX: Disconnecting due to a loss of activity. No activity for at least 42 seconds. | 2017-11-01 14:40:50 *
CQG FIX: Sending a Logout message. Text = No response received after Test Request. | 2017-11-01 14:40:50
CQG FIX socket (223) | Initiating close of socket by core. | 2017-11-01 14:40:50
CQG FIX: Disconnected. | 2017-11-01 14:40:50
Connection to the external service has been lost. | 2017-11-01 14:40:50
CQG FIX socket (223) | Write in progress. Shutdown being delayed. | 2017-11-01 14:40:50
CQG FIX Trading | Sending Web API Logoff message. | 2017-11-01 14:40:50
CQG WebSocket socket (224) | Adding bytes from final send buffer from buffered socket: 17 | 2017-11-01 14:40:50
CQG WebSocket socket (224) | Initiating close of socket by core. | 2017-11-01 14:40:50
CQG WebSocket | WebSocket closed. | 2017-11-01 14:40:50
CQG FIX Trading | WebSocket closed. | 2017-11-01 14:40:50
CQG FIX Trading | Disconnected. | 2017-11-01 14:40:50
CQG WebSocket socket (224) | Sending bytes from final send buffer: 17 | 2017-11-01 14:40:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-11-01 14:40:50
CQG WebSocket socket (224) | Write in progress. Shutdown being delayed. | 2017-11-01 14:40:50
CQG FIX socket (223) | Write has completed. Shutdown being performed. | 2017-11-01 14:40:50
CQG FIX socket (223) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:40:50
CQG WebSocket socket (224) | Write has completed. Shutdown being performed. | 2017-11-01 14:40:50
CQG WebSocket socket (224) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:40:50
CQG WebSocket socket (224) | Received socket Close event. | 2017-11-01 14:40:51
CQG WebSocket socket (224) | Still waiting for graceful close or receive error. | 2017-11-01 14:40:51
CQG WebSocket socket (224) | Socket gracefully closed by remote side. | 2017-11-01 14:40:51
CQG WebSocket socket (224) | Closed. | 2017-11-01 14:40:51
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-11-01 14:40:53
CQG FIX socket (266) | Creating socket. Using TLS 1.2. | 2017-11-01 14:40:53
CQG FIX socket (266) | Connecting to IP: 208.48.16.214. | 2017-11-01 14:40:53
CQG FIX: Sending the Logon message. | 2017-11-01 14:40:54
CQG FIX Trading | Connected to trading server. | 2017-11-01 14:40:54
CQG FIX Trading | Connecting to server api.cqg.com | 2017-11-01 14:40:54
CQG WebSocket | Connecting to WebSocket server. | 2017-11-01 14:40:54
CQG FIX | FCM name: AMP | 2017-11-01 14:40:54
CQG WebSocket socket (267) | Creating socket. Using TLS 1.2. | 2017-11-01 14:40:54
CQG WebSocket socket (267) | Connecting to IP: 195.166.124.165. | 2017-11-01 14:40:54
CQG WebSocket | Opening WebSocket. | 2017-11-01 14:40:54
CQG WebSocket | Sending WebSocket handshake. | 2017-11-01 14:40:54
CQG WebSocket | Received WebSocket handshake acknowledgment. | 2017-11-01 14:40:54
CQG WebSocket | Web socket state is now open. | 2017-11-01 14:40:54
CQG FIX Trading | WebSocket connected. | 2017-11-01 14:40:54
CQG FIX Trading | Sending market data logon message. | 2017-11-01 14:40:54
CQG FIX Trading | Logon successful. Session Token = RnpYBIOmPkBNax33FPGWUESO9mUiwSpBZxO3wxmrqy4JzQqy7oToUhcuMV7Aq1EpAXlQwNju6t3 | 2017-11-01 14:40:54
CQG FIX Trading | Connected to data and trading server. | 2017-11-01 14:40:54
DTC Client socket (262) | Initiating close of socket by core. | 2017-11-01 14:40:54
DTC Client socket (262) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:40:54
SC DTC Data with Market Depth | Disconnected from the server. | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.DLM17. ID: 1 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.DLM17. ID: 593848 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.DLM17. ID: 1 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6M17. ID: 2 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.CA6M17. ID: 593849 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.CA6M17. ID: 2 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6M17. ID: 3 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.BP6M17. ID: 593850 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.BP6M17. ID: 3 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6M17. ID: 4 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.EU6M17. ID: 593851 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.EU6M17. ID: 4 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.CA6Z17. ID: 5 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.CA6Z17. ID: 593852 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.CA6Z17. ID: 5 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.TYAZ17. ID: 6 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.TYAZ17. ID: 593853 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.TYAZ17. ID: 6 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.TYAZ17 is set to download 'Pending'. | 2017-11-01 14:40:54
Delaying start of download for F.US.TYAZ17 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ17. ID: 7 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ17. ID: 593854 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ17. ID: 7 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.DSXZ17 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.DBZ17. ID: 8 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.DBZ17. ID: 593855 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.DBZ17. ID: 8 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.DBZ17 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.CA6Z7. Search Symbol: F.US.CA6Z17. Request ID: 593852. Contract ID: 1. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.CA6Z17 | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.TYAZ7. Search Symbol: F.US.TYAZ17. Request ID: 593853. Contract ID: 2. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.TYAZ17 | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.DSXZ7. Search Symbol: F.US.DSXZ17. Request ID: 593854. Contract ID: 3. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.DSXZ17 | 2017-11-01 14:40:54
DTC Client socket (262) | Socket gracefully closed by remote side. | 2017-11-01 14:40:54
DTC Client socket (262) | Closed. | 2017-11-01 14:40:54
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 14:40:54
Symbol Error - F.US.DLM17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.DBZ7. Search Symbol: F.US.DBZ17. Request ID: 593855. Contract ID: 4. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.DBZ17 | 2017-11-01 14:40:54
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DBZ17.2017-11-01.depth | 2017-11-01 14:40:54
Symbol Error - F.US.CA6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:40:54
Symbol Error - F.US.EU6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:40:54
Symbol Error - F.US.BP6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ17. ID: 9 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ17. ID: 593856 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.DDZ17. ID: 9 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.DDZ17 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.EU6Z17. ID: 10 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.EU6Z17. ID: 593857 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.EU6Z17. ID: 10 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.BP6Z17. ID: 11 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.BP6Z17. ID: 593858 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.BP6Z17. ID: 11 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.BP6Z17 is set to download 'Pending'. | 2017-11-01 14:40:54
HD Request # 186 | Downloading Intraday chart data for F.US.TYAZ17 to the file F.US.TYAZ17.scid. Service: cqg | 2017-11-01 14:40:54
HD Request # 186 | Download start date-time: 2017-11-01 14:40:54.000 | 2017-11-01 14:40:54
HD Request # 186 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.DDZ7. Search Symbol: F.US.DDZ17. Request ID: 593856. Contract ID: 5. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.DDZ17 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.JY6Z17. ID: 12 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.JY6Z17. ID: 593859 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.JY6Z17. ID: 12 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.JY6Z17 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.EU6Z7. Search Symbol: F.US.EU6Z17. Request ID: 593857. Contract ID: 6. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.EU6Z17 | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.BP6Z7. Search Symbol: F.US.BP6Z17. Request ID: 593858. Contract ID: 7. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.BP6Z17 | 2017-11-01 14:40:54
Socket (268) | Creating socket. | 2017-11-01 14:40:54
Socket (268) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.EPZ17. ID: 13 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.EPZ17. ID: 593860 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.EPZ17. ID: 13 | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.JY6Z7. Search Symbol: F.US.JY6Z17. Request ID: 593859. Contract ID: 8. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.JY6Z17 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.YMZ17. ID: 14 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.YMZ17. ID: 593861 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.YMZ17. ID: 14 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.YMZ17 is set to download 'Pending'. | 2017-11-01 14:40:54
Requesting market depth updates for: F.US.EPZ17 if supported. | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.EPZ17 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.EPZ7. Search Symbol: F.US.EPZ17. Request ID: 593860. Contract ID: 9. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data including full depth for F.US.EPZ17 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.DA6Z17. ID: 15 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.DA6Z17. ID: 593862 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.DA6Z17. ID: 15 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.DA6Z17 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.YMZ7. Search Symbol: F.US.YMZ17. Request ID: 593861. Contract ID: 10. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.YMZ17 | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.NE6Z17. ID: 16 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.NE6Z17. ID: 593863 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.NE6Z17. ID: 16 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.NE6Z17 is set to download 'Pending'. | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.CA6Z17 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.DA6Z7. Search Symbol: F.US.DA6Z17. Request ID: 593862. Contract ID: 11. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.DA6Z17 | 2017-11-01 14:40:54
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.EPZ17.2017-11-01.depth | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6Z17. ID: 17 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.MX6Z17. ID: 593864 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.MX6Z17. ID: 17 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.MX6Z17 is set to download 'Pending'. | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.EU6Z17 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.NE6Z7. Search Symbol: F.US.NE6Z17. Request ID: 593863. Contract ID: 12. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.NE6Z17 | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.MX6Z7. Search Symbol: F.US.MX6Z17. Request ID: 593864. Contract ID: 13. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.MX6Z17 | 2017-11-01 14:40:54
Requesting market depth updates for: F.US.DDZ17 if supported. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data including full depth for F.US.DDZ17 | 2017-11-01 14:40:54
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DDZ17.2017-11-01.depth | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.DSXZ16. ID: 18 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.DSXZ16. ID: 593865 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.DSXZ16. ID: 18 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.DSXZ16 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.DDZ16. ID: 19 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.DDZ16. ID: 593866 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.DDZ16. ID: 19 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.DDZ16 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.DGZ17. ID: 20 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.DGZ17. ID: 593867 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.DGZ17. ID: 20 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.DGZ17 is set to download 'Pending'. | 2017-11-01 14:40:54
CQG FIX Trading | Starting real-time market data updates for: F.US.DLZ17. ID: 21 | 2017-11-01 14:40:54
CQG FIX Trading | Sending symbol resolution request for F.US.DLZ17. ID: 593868 | 2017-11-01 14:40:54
CQG FIX Trading | Requesting security definition data for: F.US.DLZ17. ID: 21 | 2017-11-01 14:40:54
Intraday data recording state for symbol F.US.DLZ17 is set to download 'Pending'. | 2017-11-01 14:40:54
Requesting market depth updates for: F.US.DBZ17 if supported. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data including full depth for F.US.DBZ17 | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.DGZ7. Search Symbol: F.US.DGZ17. Request ID: 593867. Contract ID: 14. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.DGZ17 | 2017-11-01 14:40:54
CQG FIX Trading | Received symbol resolution report for symbol F.US.DLZ7. Search Symbol: F.US.DLZ17. Request ID: 593868. Contract ID: 15. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data for F.US.DLZ17 | 2017-11-01 14:40:54
Requesting market depth updates for: F.US.DSXZ17 if supported. | 2017-11-01 14:40:54
CQG FIX Trading | Requesting market data including full depth for F.US.DSXZ17 | 2017-11-01 14:40:54
Symbol Error - F.US.DSXZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:40:54
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DSXZ17.2017-11-01.depth | 2017-11-01 14:40:55
CQG FIX Trading | Received message: Requested symbol was not found. | 2017-11-01 14:40:55
Symbol Error - F.US.DDZ16 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-NYSE. ID: 22 | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Requesting security definition data for: NISS-NYSE. ID: 22 | 2017-11-01 14:40:55
Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2017-11-01 14:40:55
DTC Client socket (269) | Creating socket. | 2017-11-01 14:40:55
DTC Client socket (269) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:40:55
HD Request # 186 | Setting DTC encoding to Binary VLS | 2017-11-01 14:40:55
HD Request # 186 | Sending historical data logon request message. | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.FOATZ17. ID: 23 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.FOATZ17. ID: 593869 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.FOATZ17. ID: 23 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.FOATZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.FOATZ7. Search Symbol: F.US.FOATZ17. Request ID: 593869. Contract ID: 16. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.FOATZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.CLEZ17. ID: 24 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.CLEZ17. ID: 593870 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.CLEZ17. ID: 24 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.CLEZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.GCEZ17. ID: 25 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.GCEZ17. ID: 593871 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.GCEZ17. ID: 25 | 2017-11-01 14:40:55
Requesting market depth updates for: F.US.CLEZ17 if supported. | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.CPEZ17. ID: 26 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.CPEZ17. ID: 593872 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.CPEZ17. ID: 26 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.CPEZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.CLEZ7. Search Symbol: F.US.CLEZ17. Request ID: 593870. Contract ID: 17. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data including full depth for F.US.CLEZ17 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.GCEZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.EADZ17. ID: 27 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.EADZ17. ID: 593873 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.EADZ17. ID: 27 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.ECDZ17. ID: 28 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.ECDZ17. ID: 593874 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.ECDZ17. ID: 28 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.GCEZ7. Search Symbol: F.US.GCEZ17. Request ID: 593871. Contract ID: 18. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.GCEZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.CPEZ7. Search Symbol: F.US.CPEZ17. Request ID: 593872. Contract ID: 19. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.CPEZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.FGBXZ17. ID: 29 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.FGBXZ17. ID: 593875 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.FGBXZ17. ID: 29 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.FBTPZ17. ID: 30 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.FBTPZ17. ID: 593876 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.FBTPZ17. ID: 30 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.TUAZ17. ID: 31 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.TUAZ17. ID: 593877 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.TUAZ17. ID: 31 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.FVAZ17. ID: 32 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.FVAZ17. ID: 593878 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.FVAZ17. ID: 32 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.USAZ17. ID: 33 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.USAZ17. ID: 593879 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.USAZ17. ID: 33 | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Connected to server. | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Starting socket receive thread. | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.EADZ7. Search Symbol: F.US.EADZ17. Request ID: 593873. Contract ID: 20. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.EADZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.FVSX17. ID: 34 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.FVSX17. ID: 593880 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.FVSX17. ID: 34 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.SWZ17. ID: 35 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.SWZ17. ID: 593881 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.SWZ17. ID: 35 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.ENQZ17. ID: 36 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.ENQZ17. ID: 593882 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.ENQZ17. ID: 36 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.NKDZ17. ID: 37 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.NKDZ17. ID: 593883 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.NKDZ17. ID: 37 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.ECDZ7. Search Symbol: F.US.ECDZ17. Request ID: 593874. Contract ID: 21. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.ECDZ17 | 2017-11-01 14:40:55
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.CLEZ17.2017-11-01.depth | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.FDXMZ17. ID: 38 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.FDXMZ17. ID: 593884 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.FDXMZ17. ID: 38 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.FDXMZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.FGBXZ7. Search Symbol: F.US.FGBXZ17. Request ID: 593875. Contract ID: 22. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.FGBXZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.FBTPZ7. Search Symbol: F.US.FBTPZ17. Request ID: 593876. Contract ID: 23. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.FBTPZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.TUAZ7. Search Symbol: F.US.TUAZ17. Request ID: 593877. Contract ID: 24. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.TUAZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVAZ7. Search Symbol: F.US.FVAZ17. Request ID: 593878. Contract ID: 25. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.FVAZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.USAZ7. Search Symbol: F.US.USAZ17. Request ID: 593879. Contract ID: 26. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.USAZ17 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.USAZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.FGBXZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.FVSX7. Search Symbol: F.US.FVSX17. Request ID: 593880. Contract ID: 27. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.FVSX17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.SWZ7. Search Symbol: F.US.SWZ17. Request ID: 593881. Contract ID: 28. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.SWZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.ENQZ7. Search Symbol: F.US.ENQZ17. Request ID: 593882. Contract ID: 29. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.ENQZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.NKDZ7. Search Symbol: F.US.NKDZ17. Request ID: 593883. Contract ID: 30. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.NKDZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.FDXMZ7. Search Symbol: F.US.FDXMZ17. Request ID: 593884. Contract ID: 31. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.FDXMZ17 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.FBTPZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
HD Request # 186 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:54. Record interval: 0. Symbol: F.US.TYAZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.GMCDZ17. ID: 39 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.GMCDZ17. ID: 593885 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.GMCDZ17. ID: 39 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.GMCDZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.M6BZ17. ID: 40 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.M6BZ17. ID: 593886 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.M6BZ17. ID: 40 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.M6BZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.M6EZ17. ID: 41 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.M6EZ17. ID: 593887 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.M6EZ17. ID: 41 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.M6EZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.M6AZ17. ID: 42 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.M6AZ17. ID: 593888 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.M6AZ17. ID: 42 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.M6AZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.MJYZ17. ID: 43 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.MJYZ17. ID: 593889 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.MJYZ17. ID: 43 | 2017-11-01 14:40:55
CQG FIX Trading | Using primary service for historical data for F.US.MJYZ17 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.MJYZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
Delaying start of download for F.US.MJYZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.GMCDZ7. Search Symbol: F.US.GMCDZ17. Request ID: 593885. Contract ID: 32. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.GMCDZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.MX6M17. ID: 44 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.MX6M17. ID: 593890 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.MX6M17. ID: 44 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.MX6M17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6BZ7. Search Symbol: F.US.M6BZ17. Request ID: 593886. Contract ID: 33. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.M6BZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6EZ7. Search Symbol: F.US.M6EZ17. Request ID: 593887. Contract ID: 34. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.M6EZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.M6AZ7. Search Symbol: F.US.M6AZ17. Request ID: 593888. Contract ID: 35. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.M6AZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.MJYZ7. Search Symbol: F.US.MJYZ17. Request ID: 593889. Contract ID: 36. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.MJYZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.MGCZ17. ID: 45 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.MGCZ17. ID: 593891 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.MGCZ17. ID: 45 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.MGCZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Starting real-time market data updates for: F.US.NQMZ17. ID: 46 | 2017-11-01 14:40:55
CQG FIX Trading | Sending symbol resolution request for F.US.NQMZ17. ID: 593892 | 2017-11-01 14:40:55
CQG FIX Trading | Requesting security definition data for: F.US.NQMZ17. ID: 46 | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.NQMZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
Intraday data recording state for symbol F.US.ENQZ17 is set to download 'Pending'. | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.MGCZ7. Search Symbol: F.US.MGCZ17. Request ID: 593891. Contract ID: 37. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.MGCZ17 | 2017-11-01 14:40:55
CQG FIX Trading | Received symbol resolution report for symbol F.US.NQMZ7. Search Symbol: F.US.NQMZ17. Request ID: 593892. Contract ID: 38. | 2017-11-01 14:40:55
CQG FIX Trading | Requesting market data for F.US.NQMZ17 | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Sending logon request message. | 2017-11-01 14:40:55
HD Request # 186 | Decompressing data. | 2017-11-01 14:40:55
HD Request # 186 | Receiving Intraday data for F.US.TYAZ17 starting at 2017-11-01 14:40:54 | 2017-11-01 14:40:55
HD Request # 186 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:54 | 2017-11-01 14:40:55
Socket (268) | Initiating close of socket by core. | 2017-11-01 14:40:55
Socket (268) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:40:55
Historical data download thread signaled to stop. | 2017-11-01 14:40:55
HD Request # 186 | Received 3 records from 2017-11-01 14:40:54 to 2017-11-01 14:41:01 (7.0 seconds) and wrote 2 records for F.US.TYAZ17 | 2017-11-01 14:40:55
HD Request # 186 | Intraday download COMPLETE for F.US.TYAZ17. Completion time: 0s. Unique request ID: 193 | 2017-11-01 14:40:55
Removed historical data download ID 193 | 2017-11-01 14:40:55
Real-time Intraday chart data file updates started for F.US.TYAZ17 | 2017-11-01 14:40:55
Intraday chart data file opened for F.US.TYAZ17 | 2017-11-01 14:40:55
Delaying start of download for F.US.DSXZ17 | 2017-11-01 14:40:55
Symbol Error - F.US.MX6M17 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Received logon response. | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Successfully connected. | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Trading is not supported. | 2017-11-01 14:40:55
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2017-11-01 14:40:55
Socket (268) | Socket gracefully closed by remote side. | 2017-11-01 14:40:56
Socket (268) | Closed. | 2017-11-01 14:40:56
SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2017-11-01 14:40:56
CQG FIX Trading | Starting real-time market data updates for: F.US.RBEZ17. ID: 47 | 2017-11-01 14:40:56
CQG FIX Trading | Sending symbol resolution request for F.US.RBEZ17. ID: 593893 | 2017-11-01 14:40:56
CQG FIX Trading | Requesting security definition data for: F.US.RBEZ17. ID: 47 | 2017-11-01 14:40:56
CQG FIX Trading | Starting real-time market data updates for: F.US.SIEZ17. ID: 48 | 2017-11-01 14:40:56
CQG FIX Trading | Sending symbol resolution request for F.US.SIEZ17. ID: 593894 | 2017-11-01 14:40:56
CQG FIX Trading | Requesting security definition data for: F.US.SIEZ17. ID: 48 | 2017-11-01 14:40:56
CQG FIX Trading | Starting real-time market data updates for: F.US.PAEZ17. ID: 49 | 2017-11-01 14:40:56
CQG FIX Trading | Sending symbol resolution request for F.US.PAEZ17. ID: 593895 | 2017-11-01 14:40:56
CQG FIX Trading | Requesting security definition data for: F.US.PAEZ17. ID: 49 | 2017-11-01 14:40:56
CQG FIX Trading | Starting real-time market data updates for: F.US.PLEF18. ID: 50 | 2017-11-01 14:40:56
CQG FIX Trading | Sending symbol resolution request for F.US.PLEF18. ID: 593896 | 2017-11-01 14:40:56
CQG FIX Trading | Requesting security definition data for: F.US.PLEF18. ID: 50 | 2017-11-01 14:40:56
CQG FIX Trading | Received symbol resolution report for symbol F.US.RBEZ7. Search Symbol: F.US.RBEZ17. Request ID: 593893. Contract ID: 39. | 2017-11-01 14:40:56
CQG FIX Trading | Requesting market data for F.US.RBEZ17 | 2017-11-01 14:40:56
CQG FIX Trading | Received symbol resolution report for symbol F.US.SIEZ7. Search Symbol: F.US.SIEZ17. Request ID: 593894. Contract ID: 40. | 2017-11-01 14:40:56
CQG FIX Trading | Requesting market data for F.US.SIEZ17 | 2017-11-01 14:40:56
CQG FIX Trading | Received symbol resolution report for symbol F.US.PAEZ7. Search Symbol: F.US.PAEZ17. Request ID: 593895. Contract ID: 41. | 2017-11-01 14:40:56
CQG FIX Trading | Requesting market data for F.US.PAEZ17 | 2017-11-01 14:40:56
CQG FIX Trading | Received symbol resolution report for symbol F.US.PLEF8. Search Symbol: F.US.PLEF18. Request ID: 593896. Contract ID: 42. | 2017-11-01 14:40:56
CQG FIX Trading | Requesting market data for F.US.PLEF18 | 2017-11-01 14:40:56
Delaying start of download for F.US.MJYZ17 | 2017-11-01 14:40:56
HD Request # 187 | Downloading Intraday chart data for F.US.DSXZ17 to the file F.US.DSXZ17.scid. Service: cqg | 2017-11-01 14:41:00
HD Request # 187 | Download start date-time: 2017-11-01 14:40:57.000 | 2017-11-01 14:41:00
HD Request # 187 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:00
Socket (271) | Creating socket. | 2017-11-01 14:41:00
Socket (271) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.BP6Z17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.BP6Z17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.CPEZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.CPEZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.DGZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.DGZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.DLZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.DLZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.ENQZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.ENQZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.EU6Z17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.EU6Z17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.FBTPZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.FBTPZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.FDXMZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.FDXMZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.FGBXZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.FGBXZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.FOATZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.FOATZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.GCEZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.GCEZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.GMCDZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.GMCDZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.JY6Z17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.JY6Z17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.M6AZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.M6AZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.M6BZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.M6BZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.M6EZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.M6EZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.MGCZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.MGCZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.MJYZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.MJYZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.MX6M17 if supported. | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.NE6Z17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.NE6Z17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.NQMZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.NQMZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.TYAZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.TYAZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.USAZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.USAZ17 | 2017-11-01 14:41:00
Requesting market depth updates for: F.US.YMZ17 if supported. | 2017-11-01 14:41:00
CQG FIX Trading | Requesting market data including full depth for F.US.YMZ17 | 2017-11-01 14:41:00
HD Request # 187 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:00
HD Request # 187 | Sending historical data logon request message. | 2017-11-01 14:41:00
HD Request # 187 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:57. Record interval: 0. Symbol: F.US.DSXZ17 | 2017-11-01 14:41:00
HD Request # 188 | Downloading Intraday chart data for F.US.MJYZ17 to the file F.US.MJYZ17.scid. Service: cqg | 2017-11-01 14:41:00
HD Request # 188 | Download start date-time: 2017-11-01 14:37:58.000 | 2017-11-01 14:41:00
HD Request # 188 | Requesting historical Tick data. | 2017-11-01 14:41:00
HD Request # 187 | Decompressing data. | 2017-11-01 14:41:00
HD Request # 187 | Receiving Intraday data for F.US.DSXZ17 starting at 2017-11-01 14:40:57 | 2017-11-01 14:41:00
HD Request # 187 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:00 | 2017-11-01 14:41:00
Socket (271) | Initiating close of socket by core. | 2017-11-01 14:41:00
Socket (271) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:00
Historical data download thread signaled to stop. | 2017-11-01 14:41:00
HD Request # 187 | Received 14 records from 2017-11-01 14:40:57 to 2017-11-01 14:41:03 (6.0 seconds) and wrote 13 records for F.US.DSXZ17 | 2017-11-01 14:41:00
Added 6 Time and Sales records to Intraday data file for F.US.DSXZ17 after download. | 2017-11-01 14:41:00
HD Request # 187 | Intraday download COMPLETE for F.US.DSXZ17. Completion time: 1s. Unique request ID: 194 | 2017-11-01 14:41:00
Removed historical data download ID 194 | 2017-11-01 14:41:00
Real-time Intraday chart data file updates started for F.US.DSXZ17 | 2017-11-01 14:41:00
Intraday chart data file opened for F.US.DSXZ17 | 2017-11-01 14:41:00
HD Request # 189 | Downloading Intraday chart data for F.US.DBZ17 to the file F.US.DBZ17.scid. Service: cqg | 2017-11-01 14:41:00
HD Request # 189 | Download start date-time: 2017-11-01 14:40:55.000 | 2017-11-01 14:41:00
HD Request # 189 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:00
Socket (272) | Creating socket. | 2017-11-01 14:41:00
Socket (272) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:00
Socket (271) | Socket gracefully closed by remote side. | 2017-11-01 14:41:00
Socket (271) | Closed. | 2017-11-01 14:41:00
HD Request # 188 | Receiving Intraday data for F.US.MJYZ17 starting at 2017-11-01 14:37:58 | 2017-11-01 14:41:00
HD Request # 188 | Timestamp of first Intraday data file record written: 2017-11-01 14:38:00 | 2017-11-01 14:41:00
HD Request # 188 | Received 2 records from 2017-11-01 14:37:58 to 2017-11-01 14:38:00 (2.0 seconds) and wrote 1 record for F.US.MJYZ17 | 2017-11-01 14:41:00
HD Request # 188 | Intraday download COMPLETE for F.US.MJYZ17. Completion time: 0s. Unique request ID: 223 | 2017-11-01 14:41:00
Removed historical data download ID 223 | 2017-11-01 14:41:00
Real-time Intraday chart data file updates started for F.US.MJYZ17 | 2017-11-01 14:41:00
Intraday chart data file opened for F.US.MJYZ17 | 2017-11-01 14:41:00
HD Request # 189 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:00
HD Request # 189 | Sending historical data logon request message. | 2017-11-01 14:41:00
HD Request # 189 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:55. Record interval: 0. Symbol: F.US.DBZ17 | 2017-11-01 14:41:01
HD Request # 189 | Decompressing data. | 2017-11-01 14:41:01
HD Request # 189 | Receiving Intraday data for F.US.DBZ17 starting at 2017-11-01 14:40:55 | 2017-11-01 14:41:01
HD Request # 189 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:00 | 2017-11-01 14:41:01
Socket (272) | Initiating close of socket by core. | 2017-11-01 14:41:01
Socket (272) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:01
Historical data download thread signaled to stop. | 2017-11-01 14:41:01
HD Request # 189 | Received 7 records from 2017-11-01 14:40:55 to 2017-11-01 14:41:06 (11.0 seconds) and wrote 6 records for F.US.DBZ17 | 2017-11-01 14:41:01
Added 1 Time and Sales records to Intraday data file for F.US.DBZ17 after download. | 2017-11-01 14:41:01
HD Request # 189 | Intraday download COMPLETE for F.US.DBZ17. Completion time: 0s. Unique request ID: 195 | 2017-11-01 14:41:01
Removed historical data download ID 195 | 2017-11-01 14:41:01
Real-time Intraday chart data file updates started for F.US.DBZ17 | 2017-11-01 14:41:01
Intraday chart data file opened for F.US.DBZ17 | 2017-11-01 14:41:01
HD Request # 190 | Downloading Intraday chart data for F.US.DDZ17 to the file F.US.DDZ17.scid. Service: cqg | 2017-11-01 14:41:01
HD Request # 190 | Download start date-time: 2017-11-01 14:40:55.000 | 2017-11-01 14:41:01
HD Request # 190 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:01
Socket (273) | Creating socket. | 2017-11-01 14:41:01
Socket (273) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.TYAZ17.scid | 2017-11-01 14:41:01
Socket (272) | Socket gracefully closed by remote side. | 2017-11-01 14:41:01
Socket (272) | Closed. | 2017-11-01 14:41:01
HD Request # 190 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:01
HD Request # 190 | Sending historical data logon request message. | 2017-11-01 14:41:01
HD Request # 190 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:55. Record interval: 0. Symbol: F.US.DDZ17 | 2017-11-01 14:41:02
HD Request # 190 | Decompressing data. | 2017-11-01 14:41:02
HD Request # 190 | Receiving Intraday data for F.US.DDZ17 starting at 2017-11-01 14:40:55 | 2017-11-01 14:41:02
HD Request # 190 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:55 | 2017-11-01 14:41:02
Socket (273) | Initiating close of socket by core. | 2017-11-01 14:41:02
Socket (273) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:02
Historical data download thread signaled to stop. | 2017-11-01 14:41:02
HD Request # 190 | Received 11 records from 2017-11-01 14:40:55 to 2017-11-01 14:41:02 (7.0 seconds) and wrote 10 records for F.US.DDZ17 | 2017-11-01 14:41:02
HD Request # 190 | Intraday download COMPLETE for F.US.DDZ17. Completion time: 1s. Unique request ID: 196 | 2017-11-01 14:41:02
Removed historical data download ID 196 | 2017-11-01 14:41:02
Real-time Intraday chart data file updates started for F.US.DDZ17 | 2017-11-01 14:41:02
Intraday chart data file opened for F.US.DDZ17 | 2017-11-01 14:41:02
HD Request # 191 | Downloading Intraday chart data for F.US.BP6Z17 to the file F.US.BP6Z17.scid. Service: cqg | 2017-11-01 14:41:02
HD Request # 191 | Download start date-time: 2017-11-01 14:40:53.000 | 2017-11-01 14:41:02
HD Request # 191 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:02
Socket (274) | Creating socket. | 2017-11-01 14:41:02
Socket (274) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:02
Socket (273) | Socket gracefully closed by remote side. | 2017-11-01 14:41:02
Socket (273) | Closed. | 2017-11-01 14:41:02
HD Request # 191 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:02
HD Request # 191 | Sending historical data logon request message. | 2017-11-01 14:41:02
HD Request # 191 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:53. Record interval: 0. Symbol: F.US.BP6Z17 | 2017-11-01 14:41:02
HD Request # 191 | Decompressing data. | 2017-11-01 14:41:02
HD Request # 191 | Receiving Intraday data for F.US.BP6Z17 starting at 2017-11-01 14:40:53 | 2017-11-01 14:41:02
HD Request # 191 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:57 | 2017-11-01 14:41:02
Socket (274) | Initiating close of socket by core. | 2017-11-01 14:41:02
Socket (274) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:02
HD Request # 191 | Received 28 records from 2017-11-01 14:40:53 to 2017-11-01 14:41:03 (10.0 seconds) and wrote 10 records for F.US.BP6Z17 | 2017-11-01 14:41:02
Added 2 Time and Sales records to Intraday data file for F.US.BP6Z17 after download. | 2017-11-01 14:41:02
HD Request # 191 | Intraday download COMPLETE for F.US.BP6Z17. Completion time: 0s. Unique request ID: 197 | 2017-11-01 14:41:02
Removed historical data download ID 197 | 2017-11-01 14:41:02
Real-time Intraday chart data file updates started for F.US.BP6Z17 | 2017-11-01 14:41:02
Intraday chart data file opened for F.US.BP6Z17 | 2017-11-01 14:41:02
HD Request # 192 | Downloading Intraday chart data for F.US.JY6Z17 to the file F.US.JY6Z17.scid. Service: cqg | 2017-11-01 14:41:02
HD Request # 192 | Download start date-time: 2017-11-01 14:40:56.000 | 2017-11-01 14:41:02
HD Request # 192 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:02
Socket (275) | Creating socket. | 2017-11-01 14:41:02
Socket (275) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:02
Socket (274) | Socket gracefully closed by remote side. | 2017-11-01 14:41:02
Socket (274) | Closed. | 2017-11-01 14:41:02
HD Request # 192 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:02
HD Request # 192 | Sending historical data logon request message. | 2017-11-01 14:41:02
HD Request # 192 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:56. Record interval: 0. Symbol: F.US.JY6Z17 | 2017-11-01 14:41:02
HD Request # 192 | Decompressing data. | 2017-11-01 14:41:02
HD Request # 192 | Receiving Intraday data for F.US.JY6Z17 starting at 2017-11-01 14:40:56 | 2017-11-01 14:41:02
HD Request # 192 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:59 | 2017-11-01 14:41:02
Socket (275) | Initiating close of socket by core. | 2017-11-01 14:41:02
Socket (275) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:02
HD Request # 192 | Received 74 records from 2017-11-01 14:40:56 to 2017-11-01 14:41:08 (12.0 seconds) and wrote 59 records for F.US.JY6Z17 | 2017-11-01 14:41:02
Added 1 Time and Sales records to Intraday data file for F.US.JY6Z17 after download. | 2017-11-01 14:41:02
HD Request # 192 | Intraday download COMPLETE for F.US.JY6Z17. Completion time: 0s. Unique request ID: 198 | 2017-11-01 14:41:02
Removed historical data download ID 198 | 2017-11-01 14:41:02
Real-time Intraday chart data file updates started for F.US.JY6Z17 | 2017-11-01 14:41:02
Intraday chart data file opened for F.US.JY6Z17 | 2017-11-01 14:41:02
HD Request # 193 | Downloading Intraday chart data for F.US.YMZ17 to the file F.US.YMZ17.scid. Service: cqg | 2017-11-01 14:41:02
HD Request # 193 | Download start date-time: 2017-11-01 14:40:53.000 | 2017-11-01 14:41:02
HD Request # 193 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:02
Socket (276) | Creating socket. | 2017-11-01 14:41:02
Socket (276) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:02
Socket (275) | Socket gracefully closed by remote side. | 2017-11-01 14:41:03
Socket (275) | Closed. | 2017-11-01 14:41:03
HD Request # 193 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:03
HD Request # 193 | Sending historical data logon request message. | 2017-11-01 14:41:03
HD Request # 193 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:53. Record interval: 0. Symbol: F.US.YMZ17 | 2017-11-01 14:41:03
HD Request # 193 | Decompressing data. | 2017-11-01 14:41:03
HD Request # 193 | Receiving Intraday data for F.US.YMZ17 starting at 2017-11-01 14:40:53 | 2017-11-01 14:41:03
HD Request # 193 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:53 | 2017-11-01 14:41:03
Socket (276) | Initiating close of socket by core. | 2017-11-01 14:41:03
Socket (276) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:03
Historical data download thread signaled to stop. | 2017-11-01 14:41:03
HD Request # 193 | Received 47 records from 2017-11-01 14:40:53 to 2017-11-01 14:41:10 (17.0 seconds) and wrote 27 records for F.US.YMZ17 | 2017-11-01 14:41:03
Added 1 Time and Sales records to Intraday data file for F.US.YMZ17 after download. | 2017-11-01 14:41:03
HD Request # 193 | Intraday download COMPLETE for F.US.YMZ17. Completion time: 1s. Unique request ID: 199 | 2017-11-01 14:41:03
Removed historical data download ID 199 | 2017-11-01 14:41:03
Real-time Intraday chart data file updates started for F.US.YMZ17 | 2017-11-01 14:41:03
Intraday chart data file opened for F.US.YMZ17 | 2017-11-01 14:41:03
HD Request # 194 | Downloading Intraday chart data for F.US.EPZ17 to the file F.US.EPZ17.scid. Service: cqg | 2017-11-01 14:41:03
HD Request # 194 | Download start date-time: 2017-11-01 14:40:57.000 | 2017-11-01 14:41:03
HD Request # 194 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:03
Socket (277) | Creating socket. | 2017-11-01 14:41:03
Socket (277) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:03
Socket (276) | Socket gracefully closed by remote side. | 2017-11-01 14:41:03
Socket (276) | Closed. | 2017-11-01 14:41:03
HD Request # 194 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:03
HD Request # 194 | Sending historical data logon request message. | 2017-11-01 14:41:03
HD Request # 194 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:57. Record interval: 0. Symbol: F.US.EPZ17 | 2017-11-01 14:41:03
HD Request # 194 | Decompressing data. | 2017-11-01 14:41:03
HD Request # 194 | Receiving Intraday data for F.US.EPZ17 starting at 2017-11-01 14:40:57 | 2017-11-01 14:41:03
HD Request # 194 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:57 | 2017-11-01 14:41:03
Socket (277) | Initiating close of socket by core. | 2017-11-01 14:41:03
Socket (277) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:03
HD Request # 194 | Received 183 records from 2017-11-01 14:40:57 to 2017-11-01 14:41:06 (9.0 seconds) and wrote 182 records for F.US.EPZ17 | 2017-11-01 14:41:03
Added 2 Time and Sales records to Intraday data file for F.US.EPZ17 after download. | 2017-11-01 14:41:03
HD Request # 194 | Intraday download COMPLETE for F.US.EPZ17. Completion time: 0s. Unique request ID: 200 | 2017-11-01 14:41:03
Removed historical data download ID 200 | 2017-11-01 14:41:03
Real-time Intraday chart data file updates started for F.US.EPZ17 | 2017-11-01 14:41:03
Intraday chart data file opened for F.US.EPZ17 | 2017-11-01 14:41:03
HD Request # 195 | Downloading Intraday chart data for F.US.DA6Z17 to the file F.US.DA6Z17.scid. Service: cqg | 2017-11-01 14:41:03
HD Request # 195 | Download start date-time: 2017-11-01 14:40:45.000 | 2017-11-01 14:41:03
HD Request # 195 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:03
Socket (278) | Creating socket. | 2017-11-01 14:41:03
Socket (278) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:03
Socket (277) | Socket gracefully closed by remote side. | 2017-11-01 14:41:03
Socket (277) | Closed. | 2017-11-01 14:41:03
HD Request # 195 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:04
HD Request # 195 | Sending historical data logon request message. | 2017-11-01 14:41:04
HD Request # 195 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:45. Record interval: 0. Symbol: F.US.DA6Z17 | 2017-11-01 14:41:05
HD Request # 195 | Decompressing data. | 2017-11-01 14:41:05
HD Request # 195 | Receiving Intraday data for F.US.DA6Z17 starting at 2017-11-01 14:40:45 | 2017-11-01 14:41:05
HD Request # 195 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:02 | 2017-11-01 14:41:05
Socket (278) | Initiating close of socket by core. | 2017-11-01 14:41:05
Socket (278) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:05
Historical data download thread signaled to stop. | 2017-11-01 14:41:05
HD Request # 195 | Received 13 records from 2017-11-01 14:40:45 to 2017-11-01 14:41:10 (25.0 seconds) and wrote 12 records for F.US.DA6Z17 | 2017-11-01 14:41:05
HD Request # 195 | Intraday download COMPLETE for F.US.DA6Z17. Completion time: 0s. Unique request ID: 201 | 2017-11-01 14:41:05
Removed historical data download ID 201 | 2017-11-01 14:41:05
Real-time Intraday chart data file updates started for F.US.DA6Z17 | 2017-11-01 14:41:05
Intraday chart data file opened for F.US.DA6Z17 | 2017-11-01 14:41:05
HD Request # 196 | Downloading Intraday chart data for F.US.NE6Z17 to the file F.US.NE6Z17.scid. Service: cqg | 2017-11-01 14:41:05
HD Request # 196 | Download start date-time: 2017-11-01 14:40:45.000 | 2017-11-01 14:41:05
HD Request # 196 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:05
Socket (279) | Creating socket. | 2017-11-01 14:41:05
Socket (279) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:05
Socket (278) | Socket gracefully closed by remote side. | 2017-11-01 14:41:05
Socket (278) | Closed. | 2017-11-01 14:41:05
HD Request # 196 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:05
HD Request # 196 | Sending historical data logon request message. | 2017-11-01 14:41:05
HD Request # 196 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:45. Record interval: 0. Symbol: F.US.NE6Z17 | 2017-11-01 14:41:05
HD Request # 196 | Decompressing data. | 2017-11-01 14:41:05
HD Request # 196 | Receiving Intraday data for F.US.NE6Z17 starting at 2017-11-01 14:40:45 | 2017-11-01 14:41:05
Socket (279) | Initiating close of socket by core. | 2017-11-01 14:41:05
Socket (279) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:05
HD Request # 196 | Received 1 record from 2017-11-01 14:40:45 to 2017-11-01 14:40:45 (0.0 seconds) and wrote 0 records for F.US.NE6Z17 | 2017-11-01 14:41:05
HD Request # 196 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:07 | 2017-11-01 14:41:05
Added 2 Time and Sales records to Intraday data file for F.US.NE6Z17 after download. | 2017-11-01 14:41:05
HD Request # 196 | Intraday download COMPLETE for F.US.NE6Z17. Completion time: 1s. Unique request ID: 202 | 2017-11-01 14:41:05
Removed historical data download ID 202 | 2017-11-01 14:41:05
Real-time Intraday chart data file updates started for F.US.NE6Z17 | 2017-11-01 14:41:05
Intraday chart data file opened for F.US.NE6Z17 | 2017-11-01 14:41:05
HD Request # 197 | Downloading Intraday chart data for F.US.CA6Z17 to the file F.US.CA6Z17.scid. Service: cqg | 2017-11-01 14:41:05
HD Request # 197 | Download start date-time: 2017-11-01 14:40:37.000 | 2017-11-01 14:41:05
HD Request # 197 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:05
Socket (280) | Creating socket. | 2017-11-01 14:41:05
Socket (280) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:05
Socket (279) | Socket gracefully closed by remote side. | 2017-11-01 14:41:05
Socket (279) | Closed. | 2017-11-01 14:41:05
HD Request # 197 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:05
HD Request # 197 | Sending historical data logon request message. | 2017-11-01 14:41:05
HD Request # 197 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:37. Record interval: 0. Symbol: F.US.CA6Z17 | 2017-11-01 14:41:06
HD Request # 197 | Decompressing data. | 2017-11-01 14:41:06
HD Request # 197 | Receiving Intraday data for F.US.CA6Z17 starting at 2017-11-01 14:40:37 | 2017-11-01 14:41:06
HD Request # 197 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:45 | 2017-11-01 14:41:06
Socket (280) | Initiating close of socket by core. | 2017-11-01 14:41:06
Socket (280) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:06
Historical data download thread signaled to stop. | 2017-11-01 14:41:06
HD Request # 197 | Received 20 records from 2017-11-01 14:40:37 to 2017-11-01 14:41:11 (34.0 seconds) and wrote 19 records for F.US.CA6Z17 | 2017-11-01 14:41:06
HD Request # 197 | Intraday download COMPLETE for F.US.CA6Z17. Completion time: 0s. Unique request ID: 203 | 2017-11-01 14:41:06
Removed historical data download ID 203 | 2017-11-01 14:41:06
Real-time Intraday chart data file updates started for F.US.CA6Z17 | 2017-11-01 14:41:06
Intraday chart data file opened for F.US.CA6Z17 | 2017-11-01 14:41:06
HD Request # 198 | Downloading Intraday chart data for F.US.MX6Z17 to the file F.US.MX6Z17.scid. Service: cqg | 2017-11-01 14:41:06
HD Request # 198 | Download start date-time: 2017-11-01 14:40:27.000 | 2017-11-01 14:41:06
HD Request # 198 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:06
Socket (281) | Creating socket. | 2017-11-01 14:41:06
Socket (281) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:06
Socket (280) | Socket gracefully closed by remote side. | 2017-11-01 14:41:06
Socket (280) | Closed. | 2017-11-01 14:41:06
HD Request # 198 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:06
HD Request # 198 | Sending historical data logon request message. | 2017-11-01 14:41:06
HD Request # 198 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:27. Record interval: 0. Symbol: F.US.MX6Z17 | 2017-11-01 14:41:06
HD Request # 198 | Decompressing data. | 2017-11-01 14:41:06
HD Request # 198 | Receiving Intraday data for F.US.MX6Z17 starting at 2017-11-01 14:40:27 | 2017-11-01 14:41:06
Socket (281) | Initiating close of socket by core. | 2017-11-01 14:41:06
Socket (281) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:06
HD Request # 198 | Received 1 record from 2017-11-01 14:40:27 to 2017-11-01 14:40:27 (0.0 seconds) and wrote 0 records for F.US.MX6Z17 | 2017-11-01 14:41:06
HD Request # 198 | Intraday download COMPLETE for F.US.MX6Z17. Completion time: 1s. Unique request ID: 204 | 2017-11-01 14:41:06
Removed historical data download ID 204 | 2017-11-01 14:41:06
Real-time Intraday chart data file updates started for F.US.MX6Z17 | 2017-11-01 14:41:06
Intraday chart data file opened for F.US.MX6Z17 | 2017-11-01 14:41:06
HD Request # 199 | Downloading Intraday chart data for F.US.EU6Z17 to the file F.US.EU6Z17.scid. Service: cqg | 2017-11-01 14:41:06
HD Request # 199 | Download start date-time: 2017-11-01 14:40:47.000 | 2017-11-01 14:41:06
HD Request # 199 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:06
Socket (282) | Creating socket. | 2017-11-01 14:41:06
Socket (282) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:06
Socket (281) | Socket gracefully closed by remote side. | 2017-11-01 14:41:06
Socket (281) | Closed. | 2017-11-01 14:41:06
HD Request # 199 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:06
HD Request # 199 | Sending historical data logon request message. | 2017-11-01 14:41:06
HD Request # 199 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:47. Record interval: 0. Symbol: F.US.EU6Z17 | 2017-11-01 14:41:07
HD Request # 199 | Decompressing data. | 2017-11-01 14:41:07
HD Request # 199 | Receiving Intraday data for F.US.EU6Z17 starting at 2017-11-01 14:40:47 | 2017-11-01 14:41:07
HD Request # 199 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:55 | 2017-11-01 14:41:07
Socket (282) | Initiating close of socket by core. | 2017-11-01 14:41:07
Socket (282) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:07
Historical data download thread signaled to stop. | 2017-11-01 14:41:07
HD Request # 199 | Received 43 records from 2017-11-01 14:40:47 to 2017-11-01 14:41:12 (25.0 seconds) and wrote 38 records for F.US.EU6Z17 | 2017-11-01 14:41:07
HD Request # 199 | Intraday download COMPLETE for F.US.EU6Z17. Completion time: 0s. Unique request ID: 205 | 2017-11-01 14:41:07
Removed historical data download ID 205 | 2017-11-01 14:41:07
Real-time Intraday chart data file updates started for F.US.EU6Z17 | 2017-11-01 14:41:07
Intraday chart data file opened for F.US.EU6Z17 | 2017-11-01 14:41:07
HD Request # 200 | Downloading Intraday chart data for F.US.DSXZ16 to the file F.US.DSXZ16.scid. Service: eurex | 2017-11-01 14:41:07
HD Request # 200 | Download start date-time: 2016-12-16 10:59:59.000 | 2017-11-01 14:41:07
HD Request # 200 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 14:41:07
Socket (283) | Creating socket. | 2017-11-01 14:41:07
Socket (283) | Connecting to IP: 8.18.161.133. | 2017-11-01 14:41:07
Socket (282) | Socket gracefully closed by remote side. | 2017-11-01 14:41:08
Socket (282) | Closed. | 2017-11-01 14:41:08
HD Request # 200 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:10
HD Request # 200 | Sending historical data logon request message. | 2017-11-01 14:41:10
HD Request # 200 | Requesting Intraday data. Start date-time: 2016-12-16 10:59:59. Record interval: 0. Symbol: FXZ16 | 2017-11-01 14:41:10
HD Request # 200 | Decompressing data. | 2017-11-01 14:41:10
HD Request # 200 | Receiving Intraday data for F.US.DSXZ16 starting at 2016-12-16 10:59:59 | 2017-11-01 14:41:10
Socket (283) | Initiating close of socket by core. | 2017-11-01 14:41:10
Socket (283) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:10
Historical data download thread signaled to stop. | 2017-11-01 14:41:10
HD Request # 200 | Received 1 record from 2016-12-16 10:59:59 to 2016-12-16 10:59:59 (0.0 seconds) and wrote 0 records for F.US.DSXZ16 | 2017-11-01 14:41:10
HD Request # 200 | Intraday download COMPLETE for F.US.DSXZ16. Completion time: 4s. Unique request ID: 206 | 2017-11-01 14:41:10
Removed historical data download ID 206 | 2017-11-01 14:41:10
Real-time Intraday chart data file updates started for F.US.DSXZ16 | 2017-11-01 14:41:10
Intraday chart data file opened for F.US.DSXZ16 | 2017-11-01 14:41:10
HD Request # 201 | Downloading Intraday chart data for F.US.DDZ16 to the file F.US.DDZ16.scid. Service: eurex | 2017-11-01 14:41:10
HD Request # 201 | Download start date-time: 2016-12-16 11:59:55.000 | 2017-11-01 14:41:10
HD Request # 201 | Using server: ds1.sierracharts.com port 10149 | 2017-11-01 14:41:10
Socket (284) | Creating socket. | 2017-11-01 14:41:10
Socket (284) | Connecting to IP: 8.18.161.135. | 2017-11-01 14:41:10
Socket (283) | Socket gracefully closed by remote side. | 2017-11-01 14:41:10
Socket (283) | Closed. | 2017-11-01 14:41:10
HD Request # 201 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:10
HD Request # 201 | Sending historical data logon request message. | 2017-11-01 14:41:10
HD Request # 201 | Requesting Intraday data. Start date-time: 2016-12-16 11:59:55. Record interval: 0. Symbol: DYZ16 | 2017-11-01 14:41:10
Opened cached Intraday file: C:\SierraChart\Data\F.US.CA6Z17.scid | 2017-11-01 14:41:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.DSXZ17.scid | 2017-11-01 14:41:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.DBZ17.scid | 2017-11-01 14:41:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.DDZ17.scid | 2017-11-01 14:41:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.EU6Z17.scid | 2017-11-01 14:41:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.BP6Z17.scid | 2017-11-01 14:41:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.JY6Z17.scid | 2017-11-01 14:41:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.EPZ17.scid | 2017-11-01 14:41:11
Opened cached Intraday file: C:\SierraChart\Data\F.US.YMZ17.scid | 2017-11-01 14:41:11
HD Request # 201 | Decompressing data. | 2017-11-01 14:41:11
HD Request # 201 | Receiving Intraday data for F.US.DDZ16 starting at 2016-12-16 11:59:55 | 2017-11-01 14:41:11
Socket (284) | Initiating close of socket by core. | 2017-11-01 14:41:11
Socket (284) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:11
Historical data download thread signaled to stop. | 2017-11-01 14:41:11
HD Request # 201 | Received 1 record from 2016-12-16 11:59:55 to 2016-12-16 11:59:55 (0.0 seconds) and wrote 0 records for F.US.DDZ16 | 2017-11-01 14:41:11
HD Request # 201 | Intraday download COMPLETE for F.US.DDZ16. Completion time: 1s. Unique request ID: 207 | 2017-11-01 14:41:11
Removed historical data download ID 207 | 2017-11-01 14:41:11
Real-time Intraday chart data file updates started for F.US.DDZ16 | 2017-11-01 14:41:11
Intraday chart data file opened for F.US.DDZ16 | 2017-11-01 14:41:11
HD Request # 202 | Downloading Intraday chart data for F.US.DGZ17 to the file F.US.DGZ17.scid. Service: cqg | 2017-11-01 14:41:11
HD Request # 202 | Download start date-time: 2017-11-01 14:40:52.000 | 2017-11-01 14:41:11
HD Request # 202 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:11
Socket (285) | Creating socket. | 2017-11-01 14:41:11
Socket (285) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:11
Socket (284) | Socket gracefully closed by remote side. | 2017-11-01 14:41:12
Socket (284) | Closed. | 2017-11-01 14:41:12
HD Request # 202 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:14
HD Request # 202 | Sending historical data logon request message. | 2017-11-01 14:41:14
HD Request # 202 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:52. Record interval: 0. Symbol: F.US.DGZ17 | 2017-11-01 14:41:14
HD Request # 202 | Decompressing data. | 2017-11-01 14:41:14
HD Request # 202 | Receiving Intraday data for F.US.DGZ17 starting at 2017-11-01 14:40:52 | 2017-11-01 14:41:14
HD Request # 202 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:08 | 2017-11-01 14:41:14
Socket (285) | Initiating close of socket by core. | 2017-11-01 14:41:14
Socket (285) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:14
Historical data download thread signaled to stop. | 2017-11-01 14:41:14
HD Request # 202 | Received 7 records from 2017-11-01 14:40:52 to 2017-11-01 14:41:08 (16.0 seconds) and wrote 1 record for F.US.DGZ17 | 2017-11-01 14:41:14
HD Request # 202 | Intraday download COMPLETE for F.US.DGZ17. Completion time: 3s. Unique request ID: 208 | 2017-11-01 14:41:14
Removed historical data download ID 208 | 2017-11-01 14:41:14
Real-time Intraday chart data file updates started for F.US.DGZ17 | 2017-11-01 14:41:14
Intraday chart data file opened for F.US.DGZ17 | 2017-11-01 14:41:14
HD Request # 203 | Downloading Intraday chart data for F.US.DLZ17 to the file F.US.DLZ17.scid. Service: cqg | 2017-11-01 14:41:14
HD Request # 203 | Download start date-time: 2017-11-01 14:40:55.000 | 2017-11-01 14:41:14
HD Request # 203 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:14
Socket (286) | Creating socket. | 2017-11-01 14:41:14
Socket (286) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:14
Socket (285) | Socket gracefully closed by remote side. | 2017-11-01 14:41:14
Socket (285) | Closed. | 2017-11-01 14:41:14
HD Request # 203 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:14
HD Request # 203 | Sending historical data logon request message. | 2017-11-01 14:41:14
HD Request # 203 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:55. Record interval: 0. Symbol: F.US.DLZ17 | 2017-11-01 14:41:15
HD Request # 203 | Decompressing data. | 2017-11-01 14:41:15
HD Request # 203 | Receiving Intraday data for F.US.DLZ17 starting at 2017-11-01 14:40:55 | 2017-11-01 14:41:15
HD Request # 203 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:00 | 2017-11-01 14:41:15
Socket (286) | Initiating close of socket by core. | 2017-11-01 14:41:15
Historical data download thread signaled to stop. | 2017-11-01 14:41:15
Socket (286) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:15
HD Request # 203 | Received 10 records from 2017-11-01 14:40:55 to 2017-11-01 14:41:15 (20.0 seconds) and wrote 9 records for F.US.DLZ17 | 2017-11-01 14:41:15
HD Request # 203 | Intraday download COMPLETE for F.US.DLZ17. Completion time: 0s. Unique request ID: 209 | 2017-11-01 14:41:15
Removed historical data download ID 209 | 2017-11-01 14:41:15
Real-time Intraday chart data file updates started for F.US.DLZ17 | 2017-11-01 14:41:15
Intraday chart data file opened for F.US.DLZ17 | 2017-11-01 14:41:15
HD Request # 204 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2017-11-01 14:41:15
HD Request # 204 | Download start date-time: 2017-11-01 14:41:02.000 | 2017-11-01 14:41:15
HD Request # 204 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:15
Socket (287) | Creating socket. | 2017-11-01 14:41:15
Socket (287) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:15
Socket (286) | Socket gracefully closed by remote side. | 2017-11-01 14:41:15
Socket (286) | Closed. | 2017-11-01 14:41:15
HD Request # 204 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:15
HD Request # 204 | Sending historical data logon request message. | 2017-11-01 14:41:15
HD Request # 204 | Requesting Intraday data. Start date-time: 2017-11-01 14:41:02. Record interval: 0. Symbol: NISS-NYSE | 2017-11-01 14:41:15
HD Request # 204 | Decompressing data. | 2017-11-01 14:41:15
HD Request # 204 | Receiving Intraday data for NISS-NYSE starting at 2017-11-01 14:41:02 | 2017-11-01 14:41:15
HD Request # 204 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:03 | 2017-11-01 14:41:15
Socket (287) | Initiating close of socket by core. | 2017-11-01 14:41:15
Socket (287) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:15
HD Request # 204 | Received 21 records from 2017-11-01 14:41:02 to 2017-11-01 14:41:22 (20.0 seconds) and wrote 20 records for NISS-NYSE | 2017-11-01 14:41:15
Added 3 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2017-11-01 14:41:15
HD Request # 204 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 210 | 2017-11-01 14:41:15
Removed historical data download ID 210 | 2017-11-01 14:41:15
Real-time Intraday chart data file updates started for NISS-NYSE | 2017-11-01 14:41:15
Intraday chart data file opened for NISS-NYSE | 2017-11-01 14:41:15
HD Request # 205 | Downloading Intraday chart data for F.US.FOATZ17 to the file F.US.FOATZ17.scid. Service: eurex | 2017-11-01 14:41:15
HD Request # 205 | Download start date-time: 2017-11-01 14:40:56.000 | 2017-11-01 14:41:15
HD Request # 205 | Using server: ds7.sierracharts.com port 10149 | 2017-11-01 14:41:15
Socket (288) | Creating socket. | 2017-11-01 14:41:15
Socket (288) | Connecting to IP: 8.18.161.133. | 2017-11-01 14:41:15
Socket (287) | Socket gracefully closed by remote side. | 2017-11-01 14:41:15
Socket (287) | Closed. | 2017-11-01 14:41:15
HD Request # 205 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:16
HD Request # 205 | Sending historical data logon request message. | 2017-11-01 14:41:16
HD Request # 205 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:56. Record interval: 0. Symbol: FNZ17 | 2017-11-01 14:41:16
HD Request # 205 | Decompressing data. | 2017-11-01 14:41:16
Socket (288) | Initiating close of socket by core. | 2017-11-01 14:41:16
Socket (288) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:16
Historical data download thread signaled to stop. | 2017-11-01 14:41:16
HD Request # 205 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FOATZ17 | 2017-11-01 14:41:16
HD Request # 205 | Receiving Intraday data for F.US.FOATZ17 starting at 2017-11-01 14:41:08 | 2017-11-01 14:41:16
HD Request # 205 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:08 | 2017-11-01 14:41:16
Added 24 Time and Sales records to Intraday data file for F.US.FOATZ17 after download. | 2017-11-01 14:41:16
HD Request # 205 | Intraday download COMPLETE for F.US.FOATZ17. Completion time: 1s. Unique request ID: 211 | 2017-11-01 14:41:16
Removed historical data download ID 211 | 2017-11-01 14:41:16
Real-time Intraday chart data file updates started for F.US.FOATZ17 | 2017-11-01 14:41:16
Intraday chart data file opened for F.US.FOATZ17 | 2017-11-01 14:41:16
HD Request # 206 | Downloading Intraday chart data for F.US.CLEZ17 to the file F.US.CLEZ17.scid. Service: cqg | 2017-11-01 14:41:16
HD Request # 206 | Download start date-time: 2017-11-01 14:40:56.000 | 2017-11-01 14:41:16
HD Request # 206 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:41:16
Socket (289) | Creating socket. | 2017-11-01 14:41:16
Socket (289) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:16
Socket (288) | Socket gracefully closed by remote side. | 2017-11-01 14:41:16
Socket (288) | Closed. | 2017-11-01 14:41:16
HD Request # 206 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:16
HD Request # 206 | Sending historical data logon request message. | 2017-11-01 14:41:16
HD Request # 206 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:56. Record interval: 0. Symbol: F.US.CLEZ17 | 2017-11-01 14:41:17
HD Request # 206 | Decompressing data. | 2017-11-01 14:41:17
HD Request # 206 | Receiving Intraday data for F.US.CLEZ17 starting at 2017-11-01 14:40:56 | 2017-11-01 14:41:17
HD Request # 206 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:58 | 2017-11-01 14:41:17
Socket (289) | Initiating close of socket by core. | 2017-11-01 14:41:17
Socket (289) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:17
Historical data download thread signaled to stop. | 2017-11-01 14:41:17
HD Request # 206 | Received 334 records from 2017-11-01 14:40:56 to 2017-11-01 14:41:24 (28.0 seconds) and wrote 332 records for F.US.CLEZ17 | 2017-11-01 14:41:17
Added 14 Time and Sales records to Intraday data file for F.US.CLEZ17 after download. | 2017-11-01 14:41:17
HD Request # 206 | Intraday download COMPLETE for F.US.CLEZ17. Completion time: 1s. Unique request ID: 212 | 2017-11-01 14:41:17
Removed historical data download ID 212 | 2017-11-01 14:41:17
Real-time Intraday chart data file updates started for F.US.CLEZ17 | 2017-11-01 14:41:17
Intraday chart data file opened for F.US.CLEZ17 | 2017-11-01 14:41:17
HD Request # 207 | Downloading Intraday chart data for F.US.CPEZ17 to the file F.US.CPEZ17.scid. Service: cqg | 2017-11-01 14:41:17
HD Request # 207 | Download start date-time: 2017-11-01 14:40:48.000 | 2017-11-01 14:41:17
HD Request # 207 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:41:17
Socket (290) | Creating socket. | 2017-11-01 14:41:17
Socket (290) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:17
Socket (289) | Socket gracefully closed by remote side. | 2017-11-01 14:41:17
Socket (289) | Closed. | 2017-11-01 14:41:17
HD Request # 207 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:17
HD Request # 207 | Sending historical data logon request message. | 2017-11-01 14:41:17
HD Request # 207 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:48. Record interval: 0. Symbol: F.US.CPEZ17 | 2017-11-01 14:41:18
HD Request # 207 | Decompressing data. | 2017-11-01 14:41:18
HD Request # 207 | Receiving Intraday data for F.US.CPEZ17 starting at 2017-11-01 14:40:48 | 2017-11-01 14:41:18
HD Request # 207 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:59 | 2017-11-01 14:41:18
Socket (290) | Initiating close of socket by core. | 2017-11-01 14:41:18
Socket (290) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:18
Historical data download thread signaled to stop. | 2017-11-01 14:41:18
HD Request # 207 | Received 133 records from 2017-11-01 14:40:48 to 2017-11-01 14:41:22 (34.0 seconds) and wrote 71 records for F.US.CPEZ17 | 2017-11-01 14:41:18
HD Request # 207 | Intraday download COMPLETE for F.US.CPEZ17. Completion time: 0s. Unique request ID: 213 | 2017-11-01 14:41:18
Removed historical data download ID 213 | 2017-11-01 14:41:18
Real-time Intraday chart data file updates started for F.US.CPEZ17 | 2017-11-01 14:41:18
Intraday chart data file opened for F.US.CPEZ17 | 2017-11-01 14:41:18
HD Request # 208 | Downloading Intraday chart data for F.US.GCEZ17 to the file F.US.GCEZ17.scid. Service: cqg | 2017-11-01 14:41:18
HD Request # 208 | Download start date-time: 2017-11-01 14:40:56.000 | 2017-11-01 14:41:18
HD Request # 208 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:41:18
Socket (291) | Creating socket. | 2017-11-01 14:41:18
Socket (291) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:18
Socket (290) | Socket gracefully closed by remote side. | 2017-11-01 14:41:18
Socket (290) | Closed. | 2017-11-01 14:41:18
HD Request # 208 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:18
HD Request # 208 | Sending historical data logon request message. | 2017-11-01 14:41:18
HD Request # 208 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:56. Record interval: 0. Symbol: F.US.GCEZ17 | 2017-11-01 14:41:18
HD Request # 208 | Decompressing data. | 2017-11-01 14:41:18
HD Request # 208 | Receiving Intraday data for F.US.GCEZ17 starting at 2017-11-01 14:40:56 | 2017-11-01 14:41:18
HD Request # 208 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:58 | 2017-11-01 14:41:18
Socket (291) | Initiating close of socket by core. | 2017-11-01 14:41:18
Socket (291) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:18
HD Request # 208 | Received 229 records from 2017-11-01 14:40:56 to 2017-11-01 14:41:26 (30.0 seconds) and wrote 196 records for F.US.GCEZ17 | 2017-11-01 14:41:18
HD Request # 208 | Intraday download COMPLETE for F.US.GCEZ17. Completion time: 0s. Unique request ID: 214 | 2017-11-01 14:41:18
Removed historical data download ID 214 | 2017-11-01 14:41:18
Real-time Intraday chart data file updates started for F.US.GCEZ17 | 2017-11-01 14:41:18
Intraday chart data file opened for F.US.GCEZ17 | 2017-11-01 14:41:18
HD Request # 209 | Downloading Intraday chart data for F.US.FDXMZ17 to the file F.US.FDXMZ17.scid. Service: cqg | 2017-11-01 14:41:18
HD Request # 209 | Download start date-time: 2017-11-01 14:40:50.000 | 2017-11-01 14:41:18
HD Request # 209 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:41:18
Socket (292) | Creating socket. | 2017-11-01 14:41:18
Socket (292) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:18
Socket (291) | Socket gracefully closed by remote side. | 2017-11-01 14:41:18
Socket (291) | Closed. | 2017-11-01 14:41:18
HD Request # 209 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:18
HD Request # 209 | Sending historical data logon request message. | 2017-11-01 14:41:18
HD Request # 209 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:50. Record interval: 0. Symbol: F.US.FDXMZ17 | 2017-11-01 14:41:18
HD Request # 209 | Decompressing data. | 2017-11-01 14:41:18
HD Request # 209 | Receiving Intraday data for F.US.FDXMZ17 starting at 2017-11-01 14:40:50 | 2017-11-01 14:41:18
HD Request # 209 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:50 | 2017-11-01 14:41:18
Socket (292) | Initiating close of socket by core. | 2017-11-01 14:41:18
Socket (292) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:18
HD Request # 209 | Received 12 records from 2017-11-01 14:40:50 to 2017-11-01 14:41:23 (33.0 seconds) and wrote 9 records for F.US.FDXMZ17 | 2017-11-01 14:41:18
HD Request # 209 | Intraday download COMPLETE for F.US.FDXMZ17. Completion time: 0s. Unique request ID: 215 | 2017-11-01 14:41:18
Removed historical data download ID 215 | 2017-11-01 14:41:18
Real-time Intraday chart data file updates started for F.US.FDXMZ17 | 2017-11-01 14:41:18
Intraday chart data file opened for F.US.FDXMZ17 | 2017-11-01 14:41:18
HD Request # 210 | Downloading Intraday chart data for F.US.USAZ17 to the file F.US.USAZ17.scid. Service: cqg | 2017-11-01 14:41:18
HD Request # 210 | Download start date-time: 2017-11-01 14:40:57.000 | 2017-11-01 14:41:18
HD Request # 210 | Using server: ds4.sierracharts.com port 10150 | 2017-11-01 14:41:18
Socket (293) | Creating socket. | 2017-11-01 14:41:18
Socket (293) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:18
Socket (292) | Socket gracefully closed by remote side. | 2017-11-01 14:41:19
Socket (292) | Closed. | 2017-11-01 14:41:19
HD Request # 210 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:19
HD Request # 210 | Sending historical data logon request message. | 2017-11-01 14:41:19
HD Request # 210 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:57. Record interval: 0. Symbol: F.US.USAZ17 | 2017-11-01 14:41:19
HD Request # 210 | Decompressing data. | 2017-11-01 14:41:19
HD Request # 210 | Receiving Intraday data for F.US.USAZ17 starting at 2017-11-01 14:40:57 | 2017-11-01 14:41:19
HD Request # 210 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:58 | 2017-11-01 14:41:19
Socket (293) | Initiating close of socket by core. | 2017-11-01 14:41:19
Socket (293) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:19
Historical data download thread signaled to stop. | 2017-11-01 14:41:19
HD Request # 210 | Received 762 records from 2017-11-01 14:40:57 to 2017-11-01 14:41:24 (27.1 seconds) and wrote 753 records for F.US.USAZ17 | 2017-11-01 14:41:19
Added 106 Time and Sales records to Intraday data file for F.US.USAZ17 after download. | 2017-11-01 14:41:19
HD Request # 210 | Intraday download COMPLETE for F.US.USAZ17. Completion time: 1s. Unique request ID: 216 | 2017-11-01 14:41:19
Removed historical data download ID 216 | 2017-11-01 14:41:19
Real-time Intraday chart data file updates started for F.US.USAZ17 | 2017-11-01 14:41:19
Intraday chart data file opened for F.US.USAZ17 | 2017-11-01 14:41:19
HD Request # 211 | Downloading Intraday chart data for F.US.FGBXZ17 to the file F.US.FGBXZ17.scid. Service: cqg | 2017-11-01 14:41:19
HD Request # 211 | Download start date-time: 2017-11-01 14:40:55.000 | 2017-11-01 14:41:19
HD Request # 211 | Using server: ds3.sierracharts.com port 10149 | 2017-11-01 14:41:19
Socket (294) | Creating socket. | 2017-11-01 14:41:19
Socket (294) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:19
Socket (293) | Socket gracefully closed by remote side. | 2017-11-01 14:41:19
Socket (293) | Closed. | 2017-11-01 14:41:19
HD Request # 211 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:20
HD Request # 211 | Sending historical data logon request message. | 2017-11-01 14:41:20
HD Request # 211 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:55. Record interval: 0. Symbol: F.US.FGBXZ17 | 2017-11-01 14:41:20
HD Request # 211 | Decompressing data. | 2017-11-01 14:41:20
HD Request # 211 | Receiving Intraday data for F.US.FGBXZ17 starting at 2017-11-01 14:40:55 | 2017-11-01 14:41:20
HD Request # 211 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:02 | 2017-11-01 14:41:20
Socket (294) | Initiating close of socket by core. | 2017-11-01 14:41:20
Socket (294) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:20
Historical data download thread signaled to stop. | 2017-11-01 14:41:20
HD Request # 211 | Received 48 records from 2017-11-01 14:40:55 to 2017-11-01 14:41:26 (31.0 seconds) and wrote 46 records for F.US.FGBXZ17 | 2017-11-01 14:41:20
HD Request # 211 | Intraday download COMPLETE for F.US.FGBXZ17. Completion time: 0s. Unique request ID: 217 | 2017-11-01 14:41:20
Removed historical data download ID 217 | 2017-11-01 14:41:20
Real-time Intraday chart data file updates started for F.US.FGBXZ17 | 2017-11-01 14:41:20
Intraday chart data file opened for F.US.FGBXZ17 | 2017-11-01 14:41:20
HD Request # 212 | Downloading Intraday chart data for F.US.FBTPZ17 to the file F.US.FBTPZ17.scid. Service: eurex | 2017-11-01 14:41:20
HD Request # 212 | Download start date-time: 2017-11-01 14:40:56.000 | 2017-11-01 14:41:20
HD Request # 212 | Using server: ds1.sierracharts.com port 10150 | 2017-11-01 14:41:20
Socket (295) | Creating socket. | 2017-11-01 14:41:20
Socket (295) | Connecting to IP: 8.18.161.135. | 2017-11-01 14:41:20
Socket (294) | Socket gracefully closed by remote side. | 2017-11-01 14:41:20
Socket (294) | Closed. | 2017-11-01 14:41:20
HD Request # 212 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:20
HD Request # 212 | Sending historical data logon request message. | 2017-11-01 14:41:20
HD Request # 212 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:56. Record interval: 0. Symbol: IIZ17 | 2017-11-01 14:41:20
HD Request # 212 | Decompressing data. | 2017-11-01 14:41:21
Socket (295) | Initiating close of socket by core. | 2017-11-01 14:41:21
Socket (295) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:21
Historical data download thread signaled to stop. | 2017-11-01 14:41:21
HD Request # 212 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.FBTPZ17 | 2017-11-01 14:41:21
HD Request # 212 | Receiving Intraday data for F.US.FBTPZ17 starting at 2017-11-01 14:41:04 | 2017-11-01 14:41:21
HD Request # 212 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:04 | 2017-11-01 14:41:21
Added 13 Time and Sales records to Intraday data file for F.US.FBTPZ17 after download. | 2017-11-01 14:41:21
HD Request # 212 | Intraday download COMPLETE for F.US.FBTPZ17. Completion time: 0s. Unique request ID: 218 | 2017-11-01 14:41:21
Removed historical data download ID 218 | 2017-11-01 14:41:21
Real-time Intraday chart data file updates started for F.US.FBTPZ17 | 2017-11-01 14:41:21
Intraday chart data file opened for F.US.FBTPZ17 | 2017-11-01 14:41:21
HD Request # 213 | Downloading Intraday chart data for F.US.GMCDZ17 to the file F.US.GMCDZ17.scid. Service: cqg | 2017-11-01 14:41:21
HD Request # 213 | Download start date-time: 2017-11-01 14:36:49.000 | 2017-11-01 14:41:21
HD Request # 213 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:21
Socket (296) | Creating socket. | 2017-11-01 14:41:21
Socket (296) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:21
Socket (295) | Socket gracefully closed by remote side. | 2017-11-01 14:41:21
Socket (295) | Closed. | 2017-11-01 14:41:21
HD Request # 213 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:21
HD Request # 213 | Sending historical data logon request message. | 2017-11-01 14:41:21
HD Request # 213 | Requesting Intraday data. Start date-time: 2017-11-01 14:36:49. Record interval: 0. Symbol: F.US.GMCDZ17 | 2017-11-01 14:41:21
Opened cached Intraday file: C:\SierraChart\Data\F.US.DA6Z17.scid | 2017-11-01 14:41:21
Opened cached Intraday file: C:\SierraChart\Data\F.US.NE6Z17.scid | 2017-11-01 14:41:21
Opened cached Intraday file: C:\SierraChart\Data\F.US.MX6Z17.scid | 2017-11-01 14:41:21
Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2017-11-01 14:41:21
Opened cached Intraday file: C:\SierraChart\Data\F.US.CLEZ17.scid | 2017-11-01 14:41:21
Opened cached Intraday file: C:\SierraChart\Data\F.US.GCEZ17.scid | 2017-11-01 14:41:21
Opened cached Intraday file: C:\SierraChart\Data\F.US.CPEZ17.scid | 2017-11-01 14:41:21
Opened cached Intraday file: C:\SierraChart\Data\F.US.USAZ17.scid | 2017-11-01 14:41:21
HD Request # 213 | Decompressing data. | 2017-11-01 14:41:21
HD Request # 213 | Receiving Intraday data for F.US.GMCDZ17 starting at 2017-10-31 14:49:36 | 2017-11-01 14:41:21
Socket (296) | Initiating close of socket by core. | 2017-11-01 14:41:21
Socket (296) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:21
HD Request # 213 | Received 404 records from 2017-10-31 14:49:36 to 2017-11-01 14:36:48 (23.8 hours) and wrote 0 records for F.US.GMCDZ17 | 2017-11-01 14:41:21
HD Request # 213 | Intraday download COMPLETE for F.US.GMCDZ17. Completion time: 1s. Unique request ID: 219 | 2017-11-01 14:41:21
Removed historical data download ID 219 | 2017-11-01 14:41:21
Real-time Intraday chart data file updates started for F.US.GMCDZ17 | 2017-11-01 14:41:21
Intraday chart data file opened for F.US.GMCDZ17 | 2017-11-01 14:41:21
HD Request # 214 | Downloading Intraday chart data for F.US.M6BZ17 to the file F.US.M6BZ17.scid. Service: cqg | 2017-11-01 14:41:21
HD Request # 214 | Download start date-time: 2017-11-01 14:35:37.000 | 2017-11-01 14:41:21
HD Request # 214 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:21
Socket (297) | Creating socket. | 2017-11-01 14:41:21
Socket (297) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:21
Socket (296) | Socket gracefully closed by remote side. | 2017-11-01 14:41:21
Socket (296) | Closed. | 2017-11-01 14:41:21
HD Request # 214 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:21
HD Request # 214 | Sending historical data logon request message. | 2017-11-01 14:41:21
HD Request # 214 | Requesting Intraday data. Start date-time: 2017-11-01 14:35:37. Record interval: 0. Symbol: F.US.M6BZ17 | 2017-11-01 14:41:22
HD Request # 214 | Decompressing data. | 2017-11-01 14:41:22
HD Request # 214 | Receiving Intraday data for F.US.M6BZ17 starting at 2017-11-01 14:35:37 | 2017-11-01 14:41:22
HD Request # 214 | Timestamp of first Intraday data file record written: 2017-11-01 14:37:12 | 2017-11-01 14:41:22
Socket (297) | Initiating close of socket by core. | 2017-11-01 14:41:22
Socket (297) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:22
Historical data download thread signaled to stop. | 2017-11-01 14:41:22
HD Request # 214 | Received 8 records from 2017-11-01 14:35:37 to 2017-11-01 14:40:03 (4.4 minutes) and wrote 4 records for F.US.M6BZ17 | 2017-11-01 14:41:22
HD Request # 214 | Intraday download COMPLETE for F.US.M6BZ17. Completion time: 0s. Unique request ID: 220 | 2017-11-01 14:41:22
Removed historical data download ID 220 | 2017-11-01 14:41:22
Real-time Intraday chart data file updates started for F.US.M6BZ17 | 2017-11-01 14:41:22
Intraday chart data file opened for F.US.M6BZ17 | 2017-11-01 14:41:22
HD Request # 215 | Downloading Intraday chart data for F.US.M6EZ17 to the file F.US.M6EZ17.scid. Service: cqg | 2017-11-01 14:41:22
HD Request # 215 | Download start date-time: 2017-11-01 14:40:47.000 | 2017-11-01 14:41:22
HD Request # 215 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:22
Socket (298) | Creating socket. | 2017-11-01 14:41:22
Socket (298) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:22
Socket (297) | Socket gracefully closed by remote side. | 2017-11-01 14:41:22
Socket (297) | Closed. | 2017-11-01 14:41:22
HD Request # 215 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:22
HD Request # 215 | Sending historical data logon request message. | 2017-11-01 14:41:22
HD Request # 215 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:47. Record interval: 0. Symbol: F.US.M6EZ17 | 2017-11-01 14:41:22
HD Request # 215 | Decompressing data. | 2017-11-01 14:41:22
HD Request # 215 | Receiving Intraday data for F.US.M6EZ17 starting at 2017-11-01 14:40:47 | 2017-11-01 14:41:22
Socket (298) | Initiating close of socket by core. | 2017-11-01 14:41:22
Socket (298) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:22
HD Request # 215 | Received 2 records from 2017-11-01 14:40:47 to 2017-11-01 14:40:47 (0.0 seconds) and wrote 0 records for F.US.M6EZ17 | 2017-11-01 14:41:22
HD Request # 215 | Intraday download COMPLETE for F.US.M6EZ17. Completion time: 1s. Unique request ID: 221 | 2017-11-01 14:41:22
Removed historical data download ID 221 | 2017-11-01 14:41:22
Real-time Intraday chart data file updates started for F.US.M6EZ17 | 2017-11-01 14:41:22
Intraday chart data file opened for F.US.M6EZ17 | 2017-11-01 14:41:22
HD Request # 216 | Downloading Intraday chart data for F.US.M6AZ17 to the file F.US.M6AZ17.scid. Service: cme | 2017-11-01 14:41:22
HD Request # 216 | Download start date-time: 2017-11-01 14:40:02.000 | 2017-11-01 14:41:22
HD Request # 216 | Using server: ds7.sierracharts.com port 10150 | 2017-11-01 14:41:22
Socket (299) | Creating socket. | 2017-11-01 14:41:22
Socket (299) | Connecting to IP: 8.18.161.133. | 2017-11-01 14:41:22
Socket (298) | Socket gracefully closed by remote side. | 2017-11-01 14:41:22
Socket (298) | Closed. | 2017-11-01 14:41:22
HD Request # 216 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:23
HD Request # 216 | Sending historical data logon request message. | 2017-11-01 14:41:23
HD Request # 216 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:02. Record interval: 0. Symbol: M6AZ17 | 2017-11-01 14:41:23
HD Request # 216 | Decompressing data. | 2017-11-01 14:41:23
Socket (299) | Initiating close of socket by core. | 2017-11-01 14:41:23
Socket (299) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:23
Historical data download thread signaled to stop. | 2017-11-01 14:41:23
HD Request # 216 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.M6AZ17 | 2017-11-01 14:41:23
HD Request # 216 | Receiving Intraday data for F.US.M6AZ17 starting at 2017-11-01 14:41:03 | 2017-11-01 14:41:23
HD Request # 216 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:03 | 2017-11-01 14:41:23
Added 4 Time and Sales records to Intraday data file for F.US.M6AZ17 after download. | 2017-11-01 14:41:23
HD Request # 216 | Intraday download COMPLETE for F.US.M6AZ17. Completion time: 0s. Unique request ID: 222 | 2017-11-01 14:41:23
Removed historical data download ID 222 | 2017-11-01 14:41:23
Real-time Intraday chart data file updates started for F.US.M6AZ17 | 2017-11-01 14:41:23
Intraday chart data file opened for F.US.M6AZ17 | 2017-11-01 14:41:23
HD Request # 217 | Downloading Intraday chart data for F.US.MX6M17 to the file F.US.MX6M17.scid. Service: cme | 2017-11-01 14:41:23
HD Request # 217 | Download start date-time: 2017-06-19 14:48:49.000 | 2017-11-01 14:41:23
HD Request # 217 | Using server: ds1.sierracharts.com port 10149 | 2017-11-01 14:41:23
Socket (300) | Creating socket. | 2017-11-01 14:41:23
Socket (300) | Connecting to IP: 8.18.161.135. | 2017-11-01 14:41:23
Socket (299) | Socket gracefully closed by remote side. | 2017-11-01 14:41:23
Socket (299) | Closed. | 2017-11-01 14:41:23
HD Request # 217 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:23
HD Request # 217 | Sending historical data logon request message. | 2017-11-01 14:41:23
HD Request # 217 | Requesting Intraday data. Start date-time: 2017-06-19 14:48:49. Record interval: 0. Symbol: 6MM17 | 2017-11-01 14:41:23
HD Request # 217 | Decompressing data. | 2017-11-01 14:41:24
HD Request # 217 | Receiving Intraday data for F.US.MX6M17 starting at 2017-06-19 14:48:49 | 2017-11-01 14:41:24
Socket (300) | Initiating close of socket by core. | 2017-11-01 14:41:24
Socket (300) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:24
Historical data download thread signaled to stop. | 2017-11-01 14:41:24
HD Request # 217 | Received 4 records from 2017-06-19 14:48:49 to 2017-06-19 14:48:49 (0.0 seconds) and wrote 0 records for F.US.MX6M17 | 2017-11-01 14:41:24
HD Request # 217 | Intraday download COMPLETE for F.US.MX6M17. Completion time: 0s. Unique request ID: 224 | 2017-11-01 14:41:24
Removed historical data download ID 224 | 2017-11-01 14:41:24
Real-time Intraday chart data file updates started for F.US.MX6M17 | 2017-11-01 14:41:24
Intraday chart data file opened for F.US.MX6M17 | 2017-11-01 14:41:24
HD Request # 218 | Downloading Intraday chart data for F.US.MGCZ17 to the file F.US.MGCZ17.scid. Service: cqg | 2017-11-01 14:41:24
HD Request # 218 | Download start date-time: 2017-11-01 14:40:36.000 | 2017-11-01 14:41:24
HD Request # 218 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:24
Socket (301) | Creating socket. | 2017-11-01 14:41:24
Socket (301) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:24
Socket (300) | Socket gracefully closed by remote side. | 2017-11-01 14:41:24
Socket (300) | Closed. | 2017-11-01 14:41:24
HD Request # 218 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:24
HD Request # 218 | Sending historical data logon request message. | 2017-11-01 14:41:24
HD Request # 218 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:36. Record interval: 0. Symbol: F.US.MGCZ17 | 2017-11-01 14:41:24
HD Request # 218 | Decompressing data. | 2017-11-01 14:41:24
HD Request # 218 | Receiving Intraday data for F.US.MGCZ17 starting at 2017-11-01 14:40:36 | 2017-11-01 14:41:24
HD Request # 218 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:56 | 2017-11-01 14:41:24
Socket (301) | Initiating close of socket by core. | 2017-11-01 14:41:24
Socket (301) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:24
HD Request # 218 | Received 11 records from 2017-11-01 14:40:36 to 2017-11-01 14:41:21 (45.0 seconds) and wrote 9 records for F.US.MGCZ17 | 2017-11-01 14:41:24
HD Request # 218 | Intraday download COMPLETE for F.US.MGCZ17. Completion time: 1s. Unique request ID: 225 | 2017-11-01 14:41:24
Removed historical data download ID 225 | 2017-11-01 14:41:24
Real-time Intraday chart data file updates started for F.US.MGCZ17 | 2017-11-01 14:41:24
Intraday chart data file opened for F.US.MGCZ17 | 2017-11-01 14:41:24
HD Request # 219 | Downloading Intraday chart data for F.US.NQMZ17 to the file F.US.NQMZ17.scid. Service: cqg | 2017-11-01 14:41:24
HD Request # 219 | Download start date-time: 2017-11-01 14:40:50.000 | 2017-11-01 14:41:24
HD Request # 219 | Using server: ds4.sierracharts.com port 10149 | 2017-11-01 14:41:24
Socket (302) | Creating socket. | 2017-11-01 14:41:24
Socket (302) | Connecting to IP: 192.81.56.146. | 2017-11-01 14:41:24
Socket (301) | Socket gracefully closed by remote side. | 2017-11-01 14:41:24
Socket (301) | Closed. | 2017-11-01 14:41:24
HD Request # 219 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:24
HD Request # 219 | Sending historical data logon request message. | 2017-11-01 14:41:24
HD Request # 219 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:50. Record interval: 0. Symbol: F.US.NQMZ17 | 2017-11-01 14:41:25
HD Request # 219 | Decompressing data. | 2017-11-01 14:41:25
HD Request # 219 | Receiving Intraday data for F.US.NQMZ17 starting at 2017-11-01 14:40:50 | 2017-11-01 14:41:25
HD Request # 219 | Timestamp of first Intraday data file record written: 2017-11-01 14:41:08 | 2017-11-01 14:41:25
Socket (302) | Initiating close of socket by core. | 2017-11-01 14:41:25
Socket (302) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:25
Historical data download thread signaled to stop. | 2017-11-01 14:41:25
HD Request # 219 | Received 16 records from 2017-11-01 14:40:50 to 2017-11-01 14:41:30 (40.0 seconds) and wrote 11 records for F.US.NQMZ17 | 2017-11-01 14:41:25
HD Request # 219 | Intraday download COMPLETE for F.US.NQMZ17. Completion time: 0s. Unique request ID: 226 | 2017-11-01 14:41:25
Removed historical data download ID 226 | 2017-11-01 14:41:25
Real-time Intraday chart data file updates started for F.US.NQMZ17 | 2017-11-01 14:41:25
Intraday chart data file opened for F.US.NQMZ17 | 2017-11-01 14:41:25
HD Request # 220 | Downloading Intraday chart data for F.US.ENQZ17 to the file F.US.ENQZ17.scid. Service: cqg | 2017-11-01 14:41:25
HD Request # 220 | Download start date-time: 2017-11-01 14:40:56.000 | 2017-11-01 14:41:25
HD Request # 220 | Using server: ds3.sierracharts.com port 10150 | 2017-11-01 14:41:25
Socket (303) | Creating socket. | 2017-11-01 14:41:25
Socket (303) | Connecting to IP: 65.182.172.42. | 2017-11-01 14:41:25
Socket (302) | Socket gracefully closed by remote side. | 2017-11-01 14:41:25
Socket (302) | Closed. | 2017-11-01 14:41:25
HD Request # 220 | Setting DTC encoding to Binary VLS | 2017-11-01 14:41:25
HD Request # 220 | Sending historical data logon request message. | 2017-11-01 14:41:25
HD Request # 220 | Requesting Intraday data. Start date-time: 2017-11-01 14:40:56. Record interval: 0. Symbol: F.US.ENQZ17 | 2017-11-01 14:41:25
HD Request # 220 | Decompressing data. | 2017-11-01 14:41:25
HD Request # 220 | Receiving Intraday data for F.US.ENQZ17 starting at 2017-11-01 14:40:56 | 2017-11-01 14:41:25
HD Request # 220 | Timestamp of first Intraday data file record written: 2017-11-01 14:40:56 | 2017-11-01 14:41:25
Socket (303) | Initiating close of socket by core. | 2017-11-01 14:41:25
Socket (303) | Shutdown started. Waiting for graceful close. | 2017-11-01 14:41:25
HD Request # 220 | Received 595 records from 2017-11-01 14:40:56 to 2017-11-01 14:41:30 (34.0 seconds) and wrote 591 records for F.US.ENQZ17 | 2017-11-01 14:41:25
Added 16 Time and Sales records to Intraday data file for F.US.ENQZ17 after download. | 2017-11-01 14:41:25
HD Request # 220 | Intraday download COMPLETE for F.US.ENQZ17. Completion time: 1s. Unique request ID: 227 | 2017-11-01 14:41:25
Removed historical data download ID 227 | 2017-11-01 14:41:25
Real-time Intraday chart data file updates started for F.US.ENQZ17 | 2017-11-01 14:41:25
Intraday chart data file opened for F.US.ENQZ17 | 2017-11-01 14:41:25
Socket (303) | Socket gracefully closed by remote side. | 2017-11-01 14:41:25
Socket (303) | Closed. | 2017-11-01 14:41:25
Opened cached Intraday file: C:\SierraChart\Data\F.US.DLZ17.scid | 2017-11-01 14:41:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.FOATZ17.scid | 2017-11-01 14:41:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.FGBXZ17.scid | 2017-11-01 14:41:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.FBTPZ17.scid | 2017-11-01 14:41:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.ENQZ17.scid | 2017-11-01 14:41:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.NQMZ17.scid | 2017-11-01 14:41:31
Opened cached Intraday file: C:\SierraChart\Data\F.US.FDXMZ17.scid | 2017-11-01 14:41:41
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6BZ17.scid | 2017-11-01 14:41:41
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6EZ17.scid | 2017-11-01 14:41:41
Opened cached Intraday file: C:\SierraChart\Data\F.US.MGCZ17.scid | 2017-11-01 14:41:41
Opened cached Intraday file: C:\SierraChart\Data\F.US.M6AZ17.scid | 2017-11-01 14:41:51
CQG FIX socket (223) | Timed out waiting for shutdown. Performing an immediate socket close. | 2017-11-01 14:41:59
CQG FIX socket (223) | Closed. | 2017-11-01 14:41:59
CQG FIX socket (223) | Socket gracefully closed by remote side. | 2017-11-01 14:41:59
Opened cached Intraday file: C:\SierraChart\Data\F.US.DGZ17.scid | 2017-11-01 14:42:01
Opened cached Intraday file: C:\SierraChart\Data\F.US.MJYZ17.scid | 2017-11-01 14:42:12
CQG FIX socket (223) | Deleting network socket now after delay. | 2017-11-01 14:42:29
Opened cached Intraday file: C:\SierraChart\Data\F.US.GMCDZ17.scid | 2017-11-01 14:46:15
[2017-11-01 17:43:07]
At this point reviewing this log, you are losing connection to two different CQG servers and also to the Sierra Chart server.
Refer to:
SC DTC Data with Market Depth | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2017-11-01 14:18:22
DTC Client socket (177) | Initiating close of socket by core. | 2017-11-01 14:18:22
DTC Client socket (177) | Write in progress. Shutdown being delayed. | 2017-11-01 14:18:22
SC DTC Data with Market Depth | Disconnected from the server. | 2017-11-01 14:18:22
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2017-11-01 14:18:22
SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2017-11-01 14:18:24
CQG WebSocket socket (176) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2017-11-01 14:26:46 *
CQG WebSocket socket (176) | Socket gracefully closed by remote side. | 2017-11-01 14:26:46
CQG WebSocket socket (176) | Received socket Close event. | 2017-11-01 14:26:46
CQG WebSocket socket (176) | Initiating close of socket by core. | 2017-11-01 14:26:46
CQG WebSocket | Network socket for WebSocket has been closed by remote side. | 2017-11-01 14:26:46
CQG FIX Trading | WebSocket closed. | 2017-11-01 14:26:46
Connection to the external service has been lost. | 2017-11-01 14:26:46
CQG WebSocket socket (176) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-11-01 14:26:46
There is absolutely no doubt you have a problem with your Internet connection. That is where you need to start. There is no point in us contacting CQG. There is nothing they can do. Our recommendation is to use a different Internet service provider or contact them. And do not use a wireless connection.
[2017-11-02 17:23:47]
User729700 - Posts: 10
thanks for the info--i will look into it
