Date/Time: Thu, 28 Nov 2024 09:49:50 +0000
Nasdaq - Global Index Data Service
View Count: 1643
[2023-04-04 15:38:01]
User668058 - Posts: 9
I'm having issues with switching from the S&P 500 indices via the old sierrachart exchange data feed to the newest data feed Nasdaq Global NQGI feed (NQGI) with these symbols: https://indexes.nasdaqomx.com/Home/GidsDirectory
In the process of making the switch, I'm unable to get live data from the nasdaq global index data service.
Please see attachment.
https://www.sierrachart.com/image.php?Image=1680622478458.png
Also, the Delayed Header (DD:) does not show on the headers for the NQGI symbols.
Please advise
[2023-04-04 17:43:52]
NQTV symbols are real-time for me, but NQGI symbols are not.
My account does have the NQGI symbols activated - received the message "The 'NASDAQ Global Indexes' exchange has been internally activated..."
https://www.sierrachart.com/image.php?Image=1680630081119.png
When will the GI symbols be in real-time?
[2023-04-04 20:12:46]
Sierra_Chart Engineering - Posts: 17201
Are you available for a call for us to look at this?
Make sure your current telephone number is set here:
https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo
Date Time Of Last Edit: 2023-04-04 20:13:06
[2023-04-05 15:11:17]
Are you still having any issue? You really should not. If there is any issue make sure you are running an up-to-date version of Sierra Chart:
Also refer to help topic 3:
And make sure the correct symbols are being used. You can find them in File >> Find Symbol >> NASDAQ Global Indexes.
[2023-04-06 06:43:47]
Unfortunately, this is still an issue.
I have up-to-date version 2488. I did everything in help topic 3, including disabling custom symbols, updating symbols from server.
I've connected to both "SC Data - All Services" as well as "CQG WebAPI", ussing the "File -> Find Symbol". When I use CQG, I get the orange reading of symbol was not found like here: https://www.sierrachart.com/image.php?Image=1680761165163.png When I use SC Data, I don't get the orange symbol not found. https://www.sierrachart.com/image.php?Image=1680761654425.png
I do have "Allow Support for Sierra Chart Data Feeds" set to "Yes".
In the last screen shot, you can clearly see the NQGI data not coming in. From the log of it, it appears to me that the data should be trickling in.
Attached is a screen shot of the log file. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=78937
Triggering next historical data download in queue. | 2023-04-06 02:31:59.680
HD Request # 5 | Downloading Intraday chart data for NQJPLC-NQGI to the file NQJPLC-NQGI.scid. Service: nasdaq_global_indexes.data | 2023-04-06 02:31:59.680
HD Request # 5 | Download start date-time: 2023-04-06 02:31:39.000000. File last date-time: 2023-04-06 02:31:39.276000 | 2023-04-06 02:31:59.680
HD Request # 5 | Using server: ds3.sierracharts.com port 10150 | 2023-04-06 02:31:59.680
Socket (3) | Creating socket. | 2023-04-06 02:31:59.680
Socket (3) | New receive buffer size: 5242880 | 2023-04-06 02:31:59.680
Socket (3) | Connecting to IP: 142.215.18.104. | 2023-04-06 02:31:59.680
Socket (2) | Socket gracefully closed by remote side. | 2023-04-06 02:31:59.737
Socket (2) | Closed. | 2023-04-06 02:31:59.737
Denali Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 443 | 2023-04-06 02:31:59.770
DTC Client socket (2) | Creating socket. | 2023-04-06 02:31:59.771
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-04-06 02:31:59.771
DTC Client socket (2) | Connecting to IP: 142.215.17.187. | 2023-04-06 02:31:59.771
HD Request # 5 | Setting DTC encoding to Binary VLS | 2023-04-06 02:31:59.807
HD Request # 5 | Sending historical data logon request message. | 2023-04-06 02:31:59.807
Denali Data Feed | Network connection to server complete. | 2023-04-06 02:31:59.833
Denali Data Feed | Starting socket receive thread. | 2023-04-06 02:31:59.833
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-04-06 02:31:59.833
HD Request # 5 | Requesting Intraday data. Start date-time: 2023-04-06 02:31:39. Record interval: 1. Symbol: NQJPLC-NQGI | 2023-04-06 02:31:59.868
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-04-06 02:31:59.903
Denali Data Feed | Sending logon request message. | 2023-04-06 02:31:59.903
HD Request # 5 | Decompressing data. | 2023-04-06 02:31:59.928
HD Request # 5 | Receiving Intraday data for NQJPLC-NQGI starting at 2023-04-06 02:31:39.276000 | 2023-04-06 02:31:59.929
Socket (3) | CloseSocket call. | 2023-04-06 02:31:59.929
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-04-06 02:31:59.929
Historical data download thread signaled to stop. | 2023-04-06 02:31:59.929
HD Request # 5 | Timestamp of first Intraday data file record written: 2023-04-06 02:31:39.276000. | 2023-04-06 02:31:59.929
HD Request # 5 | Received 21 Intraday data records from 2023-04-06 02:31:39.276000 to 2023-04-06 02:31:59.275000 (20.0 seconds. Delay: 0.7 seconds) and wrote 21 records for NQJPLC-NQGI | 2023-04-06 02:31:59.929
HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2023-04-06 06:31:59.275000 | 2023-04-06 02:31:59.933
HD Request # 5 | Completion time: 0s. | 2023-04-06 02:31:59.933
HD Request # 5 | Intraday data download complete for NQJPLC-NQGI. Unique request ID: 5 | 2023-04-06 02:31:59.933
Removing historical data download ID 5. | 2023-04-06 02:31:59.933
Real-time Intraday chart data file updates started for NQJPLC-NQGI | 2023-04-06 02:31:59.933
Opened cached Intraday file: S:\Sierrachart_20230402\Data\NQJPLC-NQGI.scid. Thread ID: 12528 | 2023-04-06 02:31:59.933
Intraday chart data file opened for NQJPLC-NQGI | 2023-04-06 02:31:59.933
HD Request # 5 | Enabling Intraday chart updating for symbol. | 2023-04-06 02:31:59.933
ESM23-CME[M] 5 Sec #1 | Historical data download for additional symbol NQJPLC-NQGI with ID 5 has completed. | 2023-04-06 02:31:59.933
Yes, I'm available for a phone call to discuss. My phone number on the SC account is up to date.
Date Time Of Last Edit: 2023-04-06 13:19:37
imageNQJPLC-NQGI.png / V - Attached On 2023-04-06 06:41:48 UTC - Size: 90.21 KB - 102 views
[2023-04-06 13:35:35]
I'm using EST time on my SC, 15min before the US open. I tried NQDEL-NQGI as a Germany index should be having data coming in at this time, and it does load data up to the current moment. However, no streaming live data after that.
https://www.sierrachart.com/image.php?Image=1680787725222.png
Here's some of the log file:
Reading Internal Order ID file. | 2023-04-06 09:15:27.409
Reading Trade Orders file. | 2023-04-06 09:15:27.447
Reading Trade Positions file. | 2023-04-06 09:15:27.447
Reading Trade Account Data files. | 2023-04-06 09:15:27.447
Software version: 2488 64-bit | 2023-04-06 09:15:27.448
Primary Thread ID: 8024 | 2023-04-06 09:15:27.448
Usage end date: 2023-04-22 | 2023-04-06 09:15:27.448
Enabled for: Advanced Features 2. | 2023-04-06 09:15:27.448
Enabled for: Sierra Chart Historical Data Service. | 2023-04-06 09:15:27.448
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-04-06 09:15:27.448
Enabled for: Delayed Denali Exchange Data Feed. | 2023-04-06 09:15:27.448
Enabled for exchange2: CME (Trading Account Required) | 2023-04-06 09:15:27.448
Enabled for exchange2: CBOT (Trading Account Required) | 2023-04-06 09:15:27.448
Enabled for exchange2: COMEX (Trading Account Required) | 2023-04-06 09:15:27.448
Enabled for exchange2: NYMEX (Trading Account Required) | 2023-04-06 09:15:27.448
Enabled for exchange2: fairx_exchange.data | 2023-04-06 09:15:27.448
Enabled for exchange2: NASDAQ US stock data | 2023-04-06 09:15:27.448
Enabled for exchange2: NASDAQ Global Indexes | 2023-04-06 09:15:27.448
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-04-06 09:15:27.448
Current selected Data/Trading service: SC Data - All Services | 2023-04-06 09:15:27.448
Custom symbol settings values: disabled | 2023-04-06 09:15:27.448
Chart Update Interval: 500 | 2023-04-06 09:15:27.448
Intraday Data Storage Time Unit: 1 | 2023-04-06 09:15:27.448
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-04-06 09:15:27.448
2023-04-06 13:15:27 Local computer time in UTC | 2023-04-06 09:15:27.448
2023-04-06 09:15:27 Local computer time in SC Time Zone | 2023-04-06 09:15:27.448
2023-04-06 13:15:28 Server time in UTC | 2023-04-06 09:15:27.448
Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-04-06 09:15:27.448
Program path: S:\Sierrachart_20230402\ | 2023-04-06 09:15:27.448
Data Files path: S:\Sierrachart_20230402\Data\ | 2023-04-06 09:15:27.448
OS Version Number: 6.3 | 2023-04-06 09:15:27.448
Locale Setting: C | 2023-04-06 09:15:27.448
Crash reporter started: true | 2023-04-06 09:15:27.448
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2023-04-06 09:15:27.459
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-04-06 09:15:27.474
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-04-06 09:15:27.665
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-04-06 09:15:27.665
Received 5 login tokens. | 2023-04-06 09:15:28.054
Symbol settings MD5 received. Request ID: 1. | 2023-04-06 09:15:29.830
Symbol settings are up-to-date for scdataallservices. | 2023-04-06 09:15:29.830
SC Data - All Services | Connected to server complete. | 2023-04-06 09:15:34.352
Triggering next historical data download in queue. | 2023-04-06 09:15:34.352
Triggering next historical data download in queue. | 2023-04-06 09:15:48.825
No download requests in the queue to start downloads for. | 2023-04-06 09:15:48.825
Socket (2) | Socket gracefully closed by remote side. | 2023-04-06 09:15:48.879
Socket (2) | Closed. | 2023-04-06 09:15:48.879
Enabling compression for file: S:\Sierrachart_20230402\Data\NQDELC-NQGI.scid. This may take a while. | 2023-04-06 09:16:25.260
File compression enabled. S:\Sierrachart_20230402\Data\NQDELC-NQGI.scid. CompressionState=0 | 2023-04-06 09:16:25.260
NQDELC-NQGI 1 Min #4 | Reloading chart. | 2023-04-06 09:16:25.261
NQDELC-NQGI 1 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: S:\Sierrachart_20230402\Data\NQDELC-NQGI.scid | 2023-04-06 09:16:25.265
SC Data - All Services | Starting real-time market data updates for: NQDELC-NQGI. ID: 4 Service code: nasdaq_global_indexes.data | 2023-04-06 09:16:25.761
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: NQDELC-NQGI | 2023-04-06 09:16:25.761
SC Data - All Services | Requesting security definition data for: NQDELC-NQGI. ID: 4 | 2023-04-06 09:16:25.761
Added historical Intraday data request for NQDELC-NQGI to the queue. | 2023-04-06 09:16:25.761
Intraday data recording state for symbol NQDELC-NQGI is set to download 'Pending'. | 2023-04-06 09:16:25.761
Triggering next historical data download in queue. | 2023-04-06 09:16:25.761
Delaying start of download for NQDELC-NQGI. | 2023-04-06 09:16:25.761
HD Request # 4 | Downloading Intraday chart data for NQDELC-NQGI to the file NQDELC-NQGI.scid. Service: nasdaq_global_indexes.data | 2023-04-06 09:16:30.837
HD Request # 4 | Download start date-time: 2022-10-02 09:16:30.000000. File last date-time: 00:00:00.000000 | 2023-04-06 09:16:30.837
HD Request # 4 | Using server: ds3.sierracharts.com port 10150 | 2023-04-06 09:16:30.837
Socket (2) | Creating socket. | 2023-04-06 09:16:30.837
Socket (2) | New receive buffer size: 5242880 | 2023-04-06 09:16:30.837
Socket (2) | Connecting to IP: 142.215.18.104. | 2023-04-06 09:16:30.837
HD Request # 4 | Setting DTC encoding to Binary VLS | 2023-04-06 09:16:30.962
HD Request # 4 | Sending historical data logon request message. | 2023-04-06 09:16:30.962
HD Request # 4 | Requesting Intraday data. Start date-time: 2022-10-02 09:16:30. Record interval: 1. Symbol: NQDELC-NQGI | 2023-04-06 09:16:31.560
HD Request # 4 | Decompressing data. | 2023-04-06 09:16:31.621
HD Request # 4 | Receiving Intraday data for NQDELC-NQGI starting at 2023-03-29 04:45:54.748000 | 2023-04-06 09:16:31.828
HD Request # 4 | Timestamp of first Intraday data file record written: 2023-03-29 04:45:54.748000. | 2023-04-06 09:16:32.176
Socket (2) | CloseSocket call. | 2023-04-06 09:16:32.703
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-04-06 09:16:32.703
Historical data download thread signaled to stop. | 2023-04-06 09:16:32.707
HD Request # 4 | Received 210637 Intraday data records from 2023-03-29 04:45:54.748000 to 2023-04-06 09:16:32.749000 (8.2 days. Delay: -0.0 seconds) and wrote 210637 records for NQDELC-NQGI | 2023-04-06 09:16:32.708
HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2023-04-06 13:16:32.749000 | 2023-04-06 09:16:32.711
HD Request # 4 | Completion time: 2s. | 2023-04-06 09:16:32.711
HD Request # 4 | Intraday data download complete for NQDELC-NQGI. Unique request ID: 4 | 2023-04-06 09:16:32.711
Removing historical data download ID 4. | 2023-04-06 09:16:32.711
Real-time Intraday chart data file updates started for NQDELC-NQGI | 2023-04-06 09:16:32.711
Opened cached Intraday file: S:\Sierrachart_20230402\Data\NQDELC-NQGI.scid. Thread ID: 8024 | 2023-04-06 09:16:32.711
Intraday chart data file opened for NQDELC-NQGI | 2023-04-06 09:16:32.711
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2023-04-06 09:16:32.711
[2023-04-07 14:02:30]
Please update the community and I on the status of this.
I have spoken to and have done screen shares with two other sierrachart users, and they also are unable to get true live-streaming data from the NQGI symbols.
Not being able to get NQGI live streaming data, and no longer being able to get an activation of the Sierrachart Exchange Datafeed with S&P 500 indicies, is a major, major issue.
Others in the community that have had this issue, please add to this thread as I don't believe I'm the only one. Of course, with the markets closed for the holiday weekend, testing live-streaming isn't possible.
Date Time Of Last Edit: 2023-04-07 14:02:50
[2023-04-07 18:38:02]
We tried calling but it says your voicemail box is not set up and there was no other answer.
There definitively should not be any problem. The issue is not reproducible when using CQG.
If anyone else has a problem they need to contact us directly. We do not know what the issue would be in their case. They need to be told to contact us. It does not help to make reference to what they are saying. Each user needs to contact us.
While following the above steps, disable Custom Symbol Settings.
Date Time Of Last Edit: 2023-04-07 18:38:55
[2023-04-10 05:25:41]
Thank you for trying to call me. I will be available for a call after 12:30am EST Monday.
I've completed all recommendations with no avail.
[2023-05-07 11:07:44]
We see no follow-up posting here. We assume the issue is now resolved. As long as Sierra Chart is up-to-date you should be fine.
Date Time Of Last Edit: 2023-05-07 11:07:52
