Date/Time: Mon, 27 Jan 2025 16:49:10 +0000
All charts went missing
View Count: 1239
[2019-02-26 19:02:20]
Vitwat - Posts: 19
Last month, I loaded 1600 days with the option of 'Continuous Futures Contract - Volume Based Rollover, Back Adjusted' for ES 201903 contract but the data did not load way back to year 2015 when it is supposed to.
So reading the 'Downloading/Viewing More Historical Intraday Data' guide, I follow the "Necessary Step" of Go to the chart. Select Edit >> Delete All Data And Download but it ends up not only did it not load ES data I wanted way back to 2015, my existing data from 29 November 2018 to data was also gone resulting in a blank chart in all my chartbook from my 1k trade volume to my TPO chart to my weekly chart.
Now can I know how do I:
1) Load all my ES data all the way back from year January 2015 up to date
Thank you very much.
Below appended my message log:-
Reading Internal Order ID file. | 2019-02-26 13:42:24
Reading Trade Orders file. | 2019-02-26 13:42:25
Reading Trade Positions file. | 2019-02-26 13:42:25
Account Balance file. | 2019-02-26 13:42:25
Listening on UDP port 22904. | 2019-02-26 13:42:25
Software version: 1863 32-bit | 2019-02-26 13:42:25
Usage end date: 2020-02-26 | 2019-02-26 13:42:25
Enabled for: Advanced Features. | 2019-02-26 13:42:25
Enabled for: Advanced Features 2. | 2019-02-26 13:42:25
Enabled for: Sierra Chart Historical Data Service. | 2019-02-26 13:42:25
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-02-26 13:42:25
Current selected Data/Trading service: SC Data - All Services | 2019-02-26 13:42:25
Chart Update Interval: 500 | 2019-02-26 13:42:25
Intraday Data Storage Time Unit: 0 | 2019-02-26 13:42:25
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-02-26 13:42:25
2019-02-26 13:42:24 Local computer time | 2019-02-26 13:42:25
2019-02-26 18:42:24 Local computer time in UTC | 2019-02-26 13:42:25
2019-02-26 13:42:24 Local computer time in SC Time Zone | 2019-02-26 13:42:25
2019-02-26 18:42:23 Server time in UTC | 2019-02-26 13:42:25
Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-02-26 13:42:25
Program path: C:\SierraChart\ | 2019-02-26 13:42:25
Data Files path: C:\SierraChart\Data\ | 2019-02-26 13:42:25
OS Version Number: 10.0 | 2019-02-26 13:42:25
Locale Setting: C | 2019-02-26 13:42:25
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-02-26 13:42:25
HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2019-02-26 13:42:25
HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 46.4.97.203. | 2019-02-26 13:42:25
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2019-02-26 13:42:25
HTTPS login.sierrachart.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-02-26 13:42:25
HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-02-26 13:42:25
HTTPS login.sierrachart.com:443 (1) | Closed. | 2019-02-26 13:42:25
Received 5 login tokens. | 2019-02-26 13:42:26
HTTPS www.sierrachart.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-02-26 13:42:26
HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-02-26 13:42:26
HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-02-26 13:42:26
HTTPS www.sierrachart.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-02-26 13:42:27
HTTPS www.sierrachart.com:443 (1) | Connecting to IP: 46.4.97.203. | 2019-02-26 13:42:27
HTTPS www.sierrachart.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-02-26 13:42:28
HTTPS www.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-02-26 13:42:28
HTTPS www.sierrachart.com:443 (1) | Closed. | 2019-02-26 13:42:28
Symbol settings MD5 received. Request ID: 1. | 2019-02-26 13:42:29
Symbol settings are up-to-date for scdataallservices. | 2019-02-26 13:42:29
HTTPS www.sierrachart.com:443 (4) | Shutdown started. Waiting for graceful close. | 2019-02-26 13:42:29
HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2019-02-26 13:42:29
HTTPS www.sierrachart.com:443 (4) | Closed. | 2019-02-26 13:42:29
SC Data - All Services | Connected to data server. | 2019-02-26 13:42:31
ES.20190300.CME_Eq [CBV] 1000 Volume #1 | Reloading chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 1000 Volume #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 1000 Volume #1 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 60 Min #3 | Reloading chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 60 Min #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 60 Min #3 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 60 Min #4 | Reloading chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 60 Min #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 60 Min #4 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] #5 | Reloading chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] #5 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 100000 Volume #6 | Reloading chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 100000 Volume #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV] 100000 Volume #6 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV-D] 1000 Volume #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ES.20190300.CME_Eq.scid | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV-D] 60 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ES.20190300.CME_Eq.scid | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV-D] 60 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ES.20190300.CME_Eq.scid | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV-D] #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ES.20190300.CME_Eq.scid | 2019-02-26 13:43:24
ES.20190300.CME_Eq [CBV-D] 100000 Volume #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ES.20190300.CME_Eq.scid | 2019-02-26 13:43:24
SC Data - All Services | Starting real-time market data updates for: ES.20190300.CME_Eq. ID: 1 | 2019-02-26 13:43:25
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ES.20190300.CME_Eq | 2019-02-26 13:43:25
SC Data - All Services | Requesting security definition data for: ES.20190300.CME_Eq. ID: 1 | 2019-02-26 13:43:25
No historical data client is currently set to download historical Intraday data for ES.20190300.CME_Eq. | 2019-02-26 13:43:25
Real-time Intraday chart data file updates started for ES.20190300.CME_Eq | 2019-02-26 13:43:25
Intraday chart data file opened for ES.20190300.CME_Eq | 2019-02-26 13:43:25
imagesierra_2019-02-26_1357.png / V - Attached On 2019-02-26 18:58:43 UTC - Size: 27.41 KB - 246 views
[2019-02-26 19:16:57]
The symbols you are using are CTS symbols. So you need to set Global Settings >> Data/Trade Service Settings >> Service to CTS T4 FIX and connect to the data feed with File >> Connect to Data Feed.
After that is done if there is any missing data in the charts after the data downloading is complete, then re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
Date Time Of Last Edit: 2019-02-26 19:17:55
[2019-02-27 02:51:05]
Vitwat - Posts: 19
Thank you for your prompt reply.
I have set the settings to Global Settings >> Data/Trade Service Settings >> Service to CTS T4 FIX and attempt to connect to the data feed with File >> Connect to Data Feed.
But it does not connect. It shows a 'waiting to reconnect' sign on the connection status box.
I earlier used Global Settings >> Data/Trade Service Settings >> Service to SC Data- All Services and the chart could be connected and show a green box on the connection status box.
But now after switching it and waited over a night, it is still waiting to reconnect.
How can I connect it after switching to CTS T4 FIX please?
Thank you.
imagesierra_2.png / V - Attached On 2019-02-27 02:50:51 UTC - Size: 27.8 KB - 273 views
[2019-02-27 04:59:46]
Through your broker do you have a CTS account set up? We just want to be sure.
[2019-02-27 05:28:11]
Vitwat - Posts: 19
At the present I don't have a broker as I have only started to learn trading and am currently using the platform for back testing. For now I can only rely on the Service to SC Data- All Services for connection. Thank you.
Date Time Of Last Edit: 2019-02-27 05:28:31
[2019-02-27 06:05:17]
Ok we got it. So just keep the Service set to SC Data- All Services and update the symbol of the charts to match what that service uses. Refer to the instructions here:
Data/Trading Service Connection and Symbol Issues: 1.3. Symbols
The symbol can be changed through Chart >> Chart Settings.
Date Time Of Last Edit: 2019-02-27 06:05:34
[2019-03-01 09:21:32]
Vitwat - Posts: 19
Greetings, the matter had been resolved and all my charts are back. Thank you so much and hope you have a great weekend ahead.
Thank you.
