Date/Time: Thu, 16 Jan 2025 10:05:11 +0000
TRADING FROM DIFFERENT ACCOUNT WITH INTERACTIVE BROKERS
View Count: 1923
[2017-10-18 20:52:38] |
User41636 - Posts: 35 |
I will be trading from a different account at Interactive Brokers and need to know if any changes in the settings already in force – the ones establishing a connection with Interactive Brokers – will need to be changed. When I originally set up my service with Sierra, I remember that making this connection was not all that easy to do. So if any changes in the settings are required, I would really appreciate your walking me through the necessary steps. I will still be trading in only a single account, just a different one now. Many thanks.
[2017-10-18 21:51:56] |
Based upon what you describe, the answer is no changes are required but if there is a connection problem just let us know.
[2017-10-18 22:42:28] |
There will be a different User Name and different Password with Interactive Brokers because I will be trading in a different account. Hopefully your reply above remains the same.
[2017-10-19 03:56:06] |
Yes, unless you have have entered the username and password into Global Settings >> Data/Trade Service Settings. In which case, you just need to update them there but you do not have to enter them there anyway.
[2017-10-26 21:22:24] |
With the proper authorization from Interactive Brokers, I am now trading in an account in the name of my business colleague. He is directly receiving data on his own computer from Interactive Brokers, and that data is legally being shared by me on my own, separate computer. He is not using Sierra Chart. Only I am using Sierra Chart. Now when I try to access Sierra Chart, the Log states "Error connecting to Data or Trading Service ... Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients?" The only thing I can determine is that there must be a problem with what I understand to be the "target machine," which I gather must be my colleague's computer. I hope this problem can be resolved. I am a loyal customer of Sierra Chart and the arrangement with Interactive Brokers is fully authorized. |
[2017-10-27 04:48:11] |
Refer to step number 26 here to resolve this: https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#IBResolvingConnectionIssue This is purely a technical issue. We do not think it has anything to do with authorizations. Might be something simple related to the port number. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-27 04:48:28
[2017-10-28 00:15:28] |
Since I have access to and am sharing data with another computer where TWS is originally running, I am assuming that TWS is also running (in accordance with the Sierra Chart instructions just below) on my computer – where Sierra Chart is now running. If I understand you correctly, this arrangement is not an issue. So per the following instructions from the link you provided, I changed the Server Address and Port setting to 127.0.1:7496 on both Sierra Chart and Interactive Brokers: “Select the Service Setting >> Server Address and Port setting. It needs to be set to 127.0.0.1:7496. If the TWS software is running on a computer different than Sierra Chart, then the Server Address can be set to the IP address where TWS is running.” Next, per these subsequent instructions from the same link, I was able to change the Socket Port on Interactive Brokers to 7497 (from 7496): “To change the socket port, select Global Settings >> Data/Trade Service Settings. In the Server box enter localhost: 7497 (you can use any number). In Interactive Brokers TWS, select Edit >> Global Configuration >> API >> Settings >> Socket Port and enter 7497 (use the same number you have set in Sierra Chart).” But I could not find anywhere under the “Server” box at Global Settings >> Data/Trade Service Settings in Sierra Chart how to enter 7497, because when I click on the “SC Server Settings” box, all that appears is a drop-down list set presently to “Local computer only,” with no way to enter localhost: 7497. So for this step I did not change anything on Sierra Chart. And I returned to Interactive Brokers and changed the Socket Port there back to its original 7946. I then selected File >> Connect to Data Feed, and the connection seemed to be working. Now, however, another problem. None of the data on my charts is updating. The latest data I have showing on my charts is from October 20. That is where the charts stop. Do I still have a connection problem, or is there something different that must be addressed? The Log is no longer indicating "Error connecting to Data or Trading Service ... Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients?" It is indicating that something else needs to be corrected. Thanks. |
[2017-10-28 02:37:02] |
Now, however, another problem. None of the data on my charts is updating. The latest data I have showing on my charts is from October 20. That is where the charts stop. Software Download: Fast Update If there is some TWS authorization error related to the symbol of the chart, you will see that displayed on the chart after connecting to the data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-28 19:39:16] |
Have successfully updated Sierra Chart to current version. Just as you suggest, per the Message Log it looks as though there is some TWS authorization error. I fully realize that you cannot resolve any problem with Interactive Brokers and do not wish to impose on you. But if you could just explain what the Message Log is stating exactly, I'd be most grateful as I will then be prepared to go to Interactive Brokers with specific instructions. I'm including a copy of the latest Message Log below. Many thanks. Reading Internal Order ID file. | 2017-10-28 13:42:53 Reading Trade Orders file. | 2017-10-28 13:42:53 Reading Trade Positions file. | 2017-10-28 13:42:53 Listening on UDP port 22903. | 2017-10-28 13:42:53 Software version: 1630 | 2017-10-28 13:42:53 Usage end date: 2018-06-03 | 2017-10-28 13:42:53 Enabled for: Advanced Features. | 2017-10-28 13:42:53 Enabled for: Sierra Chart Historical Data Service. | 2017-10-28 13:42:53 Allow Support for Sierra Chart Data Feeds is disabled. | 2017-10-28 13:42:53 Current selected Data/Trading service: Interactive Brokers | 2017-10-28 13:42:53 Chart Update Interval: 500 | 2017-10-28 13:42:53 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-10-28 13:42:53 2017-10-28 13:42:56 Local computer time | 2017-10-28 13:42:53 2017-10-28 18:42:56 Local computer time in UTC | 2017-10-28 13:42:53 2017-10-28 13:42:56 Local computer time in SC Time Zone | 2017-10-28 13:42:53 2017-10-28 18:42:56 Server time in UTC | 2017-10-28 13:42:53 Local computer UTC time and Server UTC time difference: 0 seconds. | 2017-10-28 13:42:53 Program path: C:\SierraChart\ | 2017-10-28 13:42:53 Data Files path: C:\SierraChart\Data\ | 2017-10-28 13:42:53 OS Version Number: 6.1 | 2017-10-28 13:42:53 Locale Setting: C | 2017-10-28 13:42:53 Checking for new symbol settings for service code ib | 2017-10-28 13:42:53 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-10-28 13:42:53 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-10-28 13:42:53 Requesting symbol settings for service code ib. Overwrite = on. | 2017-10-28 13:42:53 Received 5 login tokens. | 2017-10-28 13:42:53 Symbol settings received. | 2017-10-28 13:42:53 Processed 1374 symbol settings. | 2017-10-28 13:42:53 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-10-28 13:42:59 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-10-28 13:42:59 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-10-28 13:43:02 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-10-28 13:43:04 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-10-28 13:43:04 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-10-28 13:43:04 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-28 13:43:04 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-10-28 13:43:04 Files to Open on Start up | Opening file: SQUEEZE PRIMARY.cht | 2017-10-28 13:43:05 QQQ 15 Min #13 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #12 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #4 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #7 | Reloading chart. | 2017-10-28 13:43:05 QQQ 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 SPY 15 Min #2 | Reloading chart. | 2017-10-28 13:43:05 SPY 15 Min #8 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #5 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #9 | Reloading chart. | 2017-10-28 13:43:05 DIA 15 Min #6 | Reloading chart. | 2017-10-28 13:43:05 IWM 15 Min #10 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: HOURLY AS HOURLY RTH FUTURES.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 60 Min #25 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 60 Min #3 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 60 Min #4 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 60 Min #9 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 60 Min #10 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 60 Min #2 | Reloading chart. | 2017-10-28 13:43:05 IWM 60 Min #1 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE SPY.cht | 2017-10-28 13:43:05 SPY 12 Min #4 | Reloading chart. | 2017-10-28 13:43:05 SPY 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 SPY 18 Min #7 | Reloading chart. | 2017-10-28 13:43:05 SPY 1 Min #9 | Reloading chart. | 2017-10-28 13:43:05 SPY 10 Min #3 | Reloading chart. | 2017-10-28 13:43:05 SPY 7 Min #2 | Reloading chart. | 2017-10-28 13:43:05 SPY 5 Min #6 | Reloading chart. | 2017-10-28 13:43:05 SPY 3 Min #5 | Reloading chart. | 2017-10-28 13:43:05 SPY 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 SPY 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE SPY RTH.cht | 2017-10-28 13:43:05 SPY 1 Min #3 | Reloading chart. | 2017-10-28 13:43:05 SPY 10 Min #6 | Reloading chart. | 2017-10-28 13:43:05 SPY 12 Min #5 | Reloading chart. | 2017-10-28 13:43:05 SPY 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 SPY 18 Min #2 | Reloading chart. | 2017-10-28 13:43:05 SPY 7 Min #4 | Reloading chart. | 2017-10-28 13:43:05 SPY 5 Min #8 | Reloading chart. | 2017-10-28 13:43:05 SPY 3 Min #7 | Reloading chart. | 2017-10-28 13:43:05 SPY 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 SPY 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE ES.cht | 2017-10-28 13:43:05 ES-201712-GLOBEX 12 Min #6 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #5 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 18 Min #3 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 1 Min #9 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 10 Min #2 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 7 Min #1 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 5 Min #7 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 3 Min #4 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE ES RTH.cht | 2017-10-28 13:43:05 ES-201712-GLOBEX 1 Min #3 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 10 Min #5 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 12 Min #4 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 18 Min #2 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 7 Min #7 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 5 Min #8 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 3 Min #6 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE DIA.cht | 2017-10-28 13:43:05 DIA 12 Min #4 | Reloading chart. | 2017-10-28 13:43:05 DIA 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 DIA 18 Min #7 | Reloading chart. | 2017-10-28 13:43:05 DIA 1 Min #9 | Reloading chart. | 2017-10-28 13:43:05 DIA 10 Min #3 | Reloading chart. | 2017-10-28 13:43:05 DIA 7 Min #2 | Reloading chart. | 2017-10-28 13:43:05 DIA 15 Min #5 | Reloading chart. | 2017-10-28 13:43:05 DIA 5 Min #6 | Reloading chart. | 2017-10-28 13:43:05 DIA 3 Min #8 | Reloading chart. | 2017-10-28 13:43:05 DIA 25 Min #11 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE YM.cht | 2017-10-28 13:43:05 YM-201712-ECBOT 12 Min #5 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #6 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 18 Min #3 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 1 Min #9 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 10 Min #2 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 7 Min #1 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 5 Min #7 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 3 Min #4 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE YM RTH.cht | 2017-10-28 13:43:05 YM-201712-ECBOT 1 Min #3 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 12 Min #4 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 10 Min #5 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 18 Min #2 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 7 Min #6 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 5 Min #8 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 3 Min #7 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE QQQ.cht | 2017-10-28 13:43:05 QQQ 12 Min #7 | Reloading chart. | 2017-10-28 13:43:05 QQQ 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 QQQ 18 Min #4 | Reloading chart. | 2017-10-28 13:43:05 QQQ 1 Min #9 | Reloading chart. | 2017-10-28 13:43:05 QQQ 10 Min #3 | Reloading chart. | 2017-10-28 13:43:05 QQQ 7 Min #2 | Reloading chart. | 2017-10-28 13:43:05 QQQ 5 Min #6 | Reloading chart. | 2017-10-28 13:43:05 QQQ 3 Min #5 | Reloading chart. | 2017-10-28 13:43:05 QQQ 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 QQQ 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE QQQ RTH.cht | 2017-10-28 13:43:05 QQQ 1 Min #3 | Reloading chart. | 2017-10-28 13:43:05 QQQ 10 Min #7 | Reloading chart. | 2017-10-28 13:43:05 QQQ 12 Min #4 | Reloading chart. | 2017-10-28 13:43:05 QQQ 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 QQQ 18 Min #2 | Reloading chart. | 2017-10-28 13:43:05 QQQ 7 Min #6 | Reloading chart. | 2017-10-28 13:43:05 QQQ 5 Min #8 | Reloading chart. | 2017-10-28 13:43:05 QQQ 3 Min #5 | Reloading chart. | 2017-10-28 13:43:05 QQQ 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 QQQ 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE NQ.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 12 Min #5 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #6 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 18 Min #3 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 1 Min #9 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 10 Min #2 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 7 Min #1 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 5 Min #7 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 3 Min #4 | Reloading chart. | 2017-10-28 13:43:05 NQ-201706-GLOBEX 7 Min #11 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #12 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 25 Min #13 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE NQ RTH.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 1 Min #3 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 12 Min #4 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 10 Min #5 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 18 Min #2 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 7 Min #6 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 5 Min #8 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 3 Min #7 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: VARIOUS 25.cht | 2017-10-28 13:43:05 ES-201712-GLOBEX 25 Min #11 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 25 Min #5 | Reloading chart. | 2017-10-28 13:43:05 SPY 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 SPY 25 Min #2 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 25 Min #3 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 25 Min #1 | Reloading chart. | 2017-10-28 13:43:05 QQQ 25 Min #7 | Reloading chart. | 2017-10-28 13:43:05 QQQ 25 Min #9 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 25 Min #10 | Reloading chart. | 2017-10-28 13:43:05 DIA 25 Min #8 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 25 Min #13 | Reloading chart. | 2017-10-28 13:43:05 IWM 25 Min #4 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: VARIOUS 18.cht | 2017-10-28 13:43:05 SPY 18 Min #7 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 18 Min #6 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 18 Min #9 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 18 Min #8 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 18 Min #12 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 18 Min #10 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 18 Min #11 | Reloading chart. | 2017-10-28 13:43:05 SPY 18 Min #2 | Reloading chart. | 2017-10-28 13:43:05 QQQ 18 Min #3 | Reloading chart. | 2017-10-28 13:43:05 QQQ 18 Min #1 | Reloading chart. | 2017-10-28 13:43:05 DIA 18 Min #4 | Reloading chart. | 2017-10-28 13:43:05 IWM 18 Min #13 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: VARIOUS 15.cht | 2017-10-28 13:43:05 SPY 15 Min #3 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #9 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #8 | Reloading chart. | 2017-10-28 13:43:05 QQQ 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 QQQ 15 Min #5 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #10 | Reloading chart. | 2017-10-28 13:43:05 SPY 15 Min #7 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #2 | Reloading chart. | 2017-10-28 13:43:05 DIA 15 Min #17 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #13 | Reloading chart. | 2017-10-28 13:43:05 IWM 15 Min #6 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: VARIOUS 12.cht | 2017-10-28 13:43:05 SPY 12 Min #3 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 12 Min #9 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 12 Min #8 | Reloading chart. | 2017-10-28 13:43:05 QQQ 12 Min #1 | Reloading chart. | 2017-10-28 13:43:05 QQQ 12 Min #5 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 12 Min #11 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 12 Min #10 | Reloading chart. | 2017-10-28 13:43:05 SPY 12 Min #7 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 12 Min #2 | Reloading chart. | 2017-10-28 13:43:05 DIA 12 Min #13 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 12 Min #12 | Reloading chart. | 2017-10-28 13:43:05 IWM 12 Min #4 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: VARIOUS 10.cht | 2017-10-28 13:43:05 SPY 10 Min #3 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 10 Min #9 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 10 Min #8 | Reloading chart. | 2017-10-28 13:43:05 QQQ 10 Min #1 | Reloading chart. | 2017-10-28 13:43:05 QQQ 10 Min #5 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 10 Min #11 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 10 Min #10 | Reloading chart. | 2017-10-28 13:43:05 SPY 10 Min #7 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 10 Min #2 | Reloading chart. | 2017-10-28 13:43:05 DIA 10 Min #13 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 10 Min #12 | Reloading chart. | 2017-10-28 13:43:05 IWM 10 Min #6 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: VARIOUS 7.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 7 Min #11 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 7 Min #4 | Reloading chart. | 2017-10-28 13:43:05 QQQ 7 Min #8 | Reloading chart. | 2017-10-28 13:43:05 QQQ 7 Min #9 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 7 Min #1 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 7 Min #2 | Reloading chart. | 2017-10-28 13:43:05 SPY 7 Min #3 | Reloading chart. | 2017-10-28 13:43:05 SPY 7 Min #5 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 7 Min #10 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 7 Min #12 | Reloading chart. | 2017-10-28 13:43:05 DIA 7 Min #6 | Reloading chart. | 2017-10-28 13:43:05 IWM 7 Min #7 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: VARIOUS 5.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 5 Min #2 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 5 Min #4 | Reloading chart. | 2017-10-28 13:43:05 QQQ 5 Min #8 | Reloading chart. | 2017-10-28 13:43:05 QQQ 5 Min #9 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 5 Min #3 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 5 Min #12 | Reloading chart. | 2017-10-28 13:43:05 SPY 5 Min #10 | Reloading chart. | 2017-10-28 13:43:05 SPY 5 Min #7 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 5 Min #6 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 5 Min #11 | Reloading chart. | 2017-10-28 13:43:05 DIA 5 Min #1 | Reloading chart. | 2017-10-28 13:43:05 IWM 5 Min #5 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: VARIOUS 3.cht | 2017-10-28 13:43:05 ES-201712-GLOBEX 3 Min #14 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 3 Min #11 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 3 Min #10 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 3 Min #1 | Reloading chart. | 2017-10-28 13:43:05 QQQ 3 Min #12 | Reloading chart. | 2017-10-28 13:43:05 SPY 3 Min #7 | Reloading chart. | 2017-10-28 13:43:05 DIA 3 Min #13 | Reloading chart. | 2017-10-28 13:43:05 SPY 3 Min #6 | Reloading chart. | 2017-10-28 13:43:05 IWM 3 Min #5 | Reloading chart. | 2017-10-28 13:43:05 QQQ 3 Min #3 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 3 Min #8 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 3 Min #2 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: VARIOUS ONE.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 1 Min #13 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 1 Min #11 | Reloading chart. | 2017-10-28 13:43:05 QQQ 1 Min #4 | Reloading chart. | 2017-10-28 13:43:05 QQQ 1 Min #8 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 1 Min #9 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 1 Min #1 | Reloading chart. | 2017-10-28 13:43:05 SPY 1 Min #2 | Reloading chart. | 2017-10-28 13:43:05 SPY 1 Min #3 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 1 Min #5 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 1 Min #10 | Reloading chart. | 2017-10-28 13:43:05 DIA 1 Min #12 | Reloading chart. | 2017-10-28 13:43:05 IWM 1 Min #6 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: ONE WIDE.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 1 Min #1 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 1 Min #2 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 1 Min #3 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 1 Min #5 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 1 Min #4 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 1 Min #6 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: SEVEN WIDE ETF.cht | 2017-10-28 13:43:05 QQQ 7 Min #3 | Reloading chart. | 2017-10-28 13:43:05 QQQ 7 Min #4 | Reloading chart. | 2017-10-28 13:43:05 SPY 7 Min #5 | Reloading chart. | 2017-10-28 13:43:05 SPY 7 Min #1 | Reloading chart. | 2017-10-28 13:43:05 DIA 7 Min #6 | Reloading chart. | 2017-10-28 13:43:05 DIA 7 Min #2 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: SEVEN WIDE.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 7 Min #2 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 7 Min #3 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 7 Min #4 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 7 Min #5 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 7 Min #1 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 7 Min #6 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: FIVE WIDE.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 5 Min #1 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 5 Min #5 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 5 Min #6 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 5 Min #7 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 5 Min #3 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 5 Min #2 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: THREE WIDE.cht | 2017-10-28 13:43:05 NQ-201712-GLOBEX 3 Min #3 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 3 Min #4 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 3 Min #5 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 3 Min #1 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 3 Min #6 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 3 Min #7 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: 12 15 18 WIDE IWM.cht | 2017-10-28 13:43:05 IWM 1 Min #3 | Reloading chart. | 2017-10-28 13:43:05 IWM 10 Min #7 | Reloading chart. | 2017-10-28 13:43:05 IWM 12 Min #4 | Reloading chart. | 2017-10-28 13:43:05 IWM 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 IWM 18 Min #2 | Reloading chart. | 2017-10-28 13:43:05 IWM 7 Min #6 | Reloading chart. | 2017-10-28 13:43:05 IWM 5 Min #5 | Reloading chart. | 2017-10-28 13:43:05 IWM 3 Min #9 | Reloading chart. | 2017-10-28 13:43:05 IWM 15 Min #11 | Reloading chart. | 2017-10-28 13:43:05 IWM 25 Min #12 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: MAPPING QQQ SPY DIA.cht | 2017-10-28 13:43:05 DIA 15 Min #1 | Reloading chart. | 2017-10-28 13:43:05 IWM 15 Min #2 | Reloading chart. | 2017-10-28 13:43:05 SPY 15 Min #4 | Reloading chart. | 2017-10-28 13:43:05 SPY 15 Min #3 | Reloading chart. | 2017-10-28 13:43:05 QQQ 15 Min #5 | Reloading chart. | 2017-10-28 13:43:05 QQQ 15 Min #6 | Reloading chart. | 2017-10-28 13:43:05 SPY 1 Min #7 | Reloading chart. | 2017-10-28 13:43:05 QQQ 1 Min #8 | Reloading chart. | 2017-10-28 13:43:05 DIA 1 Min #9 | Reloading chart. | 2017-10-28 13:43:05 IWM 1 Min #10 | Reloading chart. | 2017-10-28 13:43:05 Files to Open on Start up | Opening file: MAPPING NQ ES YM.cht | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #2 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #4 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #6 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 15 Min #8 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 15 Min #9 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 15 Min #3 | Reloading chart. | 2017-10-28 13:43:05 ES-201712-GLOBEX 1 Min #1 | Reloading chart. | 2017-10-28 13:43:05 NQ-201712-GLOBEX 1 Min #5 | Reloading chart. | 2017-10-28 13:43:05 YM-201712-ECBOT 1 Min #7 | Reloading chart. | 2017-10-28 13:43:05 'Allow Support for Sierra Chart Data Feeds' is disabled. The ??? pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:31 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ-######-GLOBEX pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:31 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES-######-GLOBEX pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:31 'Allow Support for Sierra Chart Data Feeds' is disabled. The ??? pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:31 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM-######-ECBOT pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:31 'Allow Support for Sierra Chart Data Feeds' is disabled. The ??? pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:31 'Allow Support for Sierra Chart Data Feeds' is disabled. The ??? pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:31 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ-######-GLOBEX pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:31 Intraday data recording state for symbol NQ-201706-GLOBEX is set to download 'Pending'. | 2017-10-28 13:43:31 HD Request # 2 | Downloading Intraday chart data for NQ-201706-GLOBEX to the file NQ-201706-GLOBEX.scid. Service: cme | 2017-10-28 13:43:31 HD Request # 2 | Download start date-time: 2017-06-16 16:26:20.000 | 2017-10-28 13:43:31 HD Request # 2 | Using server: ds7.sierracharts.com port 10149 | 2017-10-28 13:43:31 Socket (6) | Creating socket. | 2017-10-28 13:43:31 Socket (6) | Connecting to IP: 8.18.161.133. | 2017-10-28 13:43:31 HD Request # 2 | Setting DTC encoding to Binary VLS | 2017-10-28 13:43:31 HD Request # 2 | Sending historical data logon request message. | 2017-10-28 13:43:31 HD Request # 2 | Requesting Intraday data. Start date-time: 2017-06-16 16:26:20. Record interval: 1. Symbol: NQM17 | 2017-10-28 13:43:31 HD Request # 2 | Decompressing data. | 2017-10-28 13:43:31 HD Request # 2 | Receiving Intraday data for NQ-201706-GLOBEX starting at 2017-06-15 08:29:52 | 2017-10-28 13:43:31 HD Request # 2 | Historical data for NQ-201706-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2017-10-28 13:43:31 Socket (6) | Initiating close of socket by core. | 2017-10-28 13:43:31 Historical data download thread signaled to stop. | 2017-10-28 13:43:31 Socket (6) | Shutdown started. Waiting for graceful close. | 2017-10-28 13:43:31 HD Request # 2 | Received 8308 records from 2017-06-15 08:29:52 to 2017-06-16 08:29:52 (24.0 hours) and wrote 0 records for NQ-201706-GLOBEX | 2017-10-28 13:43:31 HD Request # 2 | Intraday download COMPLETE for NQ-201706-GLOBEX. Completion time: 0s. Unique request ID: 1 | 2017-10-28 13:43:31 Removed historical data download ID 1 | 2017-10-28 13:43:31 Socket (6) | Socket gracefully closed by remote side. | 2017-10-28 13:43:31 Socket (6) | Closed. | 2017-10-28 13:43:31 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2017-10-28 13:43:31 Socket (7) | Creating socket. | 2017-10-28 13:43:31 Socket (7) | Connecting to IP: 127.0.0.1. | 2017-10-28 13:43:31 Socket connected to TWS. Sending client version: 62. Waiting for acceptance. | 2017-10-28 13:43:31 Interactive Brokers | TWS server version: 76 | 2017-10-28 13:43:55 Interactive Brokers | Connected. Waiting for account information. | 2017-10-28 13:43:55 IB Account information received. | 2017-10-28 13:43:55 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2017-10-28 13:43:55 Interactive Brokers | Connected to Live account. | 2017-10-28 13:43:55 Interactive Brokers | Year-Month last connected to Live account: 2017-10 | 2017-10-28 13:43:55 Interactive Brokers | Connected to data and trading server. | 2017-10-28 13:43:55 Next valid order ID: 1 | 2017-10-28 13:43:55 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: Market data farm connection is OK:usfarm.us. IB Error Code: 2104. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2017-10-28 13:43:55 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2017-10-28 13:43:55 Next valid order ID: 1 | 2017-10-28 13:43:55 IB Account information received. | 2017-10-28 13:43:55 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2017-10-28 13:43:55 Interactive Brokers | Connected to Live account. | 2017-10-28 13:43:55 Interactive Brokers | Year-Month last connected to Live account: 2017-10 | 2017-10-28 13:43:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The ??? pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:55 Interactive Brokers | Starting real-time market data updates for: SPY. ID: 1 | 2017-10-28 13:43:55 Interactive Brokers | Subscribing to Symbol: SPY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: | 2017-10-28 13:43:55 Interactive Brokers | Requesting security definition data for: SPY. ID: 1 | 2017-10-28 13:43:55 Interactive Brokers | Using primary service for historical data for SPY | 2017-10-28 13:43:55 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2017-10-28 13:43:55 Delaying start of download for SPY | 2017-10-28 13:43:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ-######-GLOBEX pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:55 Interactive Brokers | Starting real-time market data updates for: NQ-201712-GLOBEX. ID: 2 | 2017-10-28 13:43:55 Interactive Brokers | Subscribing to Symbol: NQ, SecurityType: FUT, Expiration: 201712, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: | 2017-10-28 13:43:55 Interactive Brokers | Requesting security definition data for: NQ-201712-GLOBEX. ID: 2 | 2017-10-28 13:43:55 Interactive Brokers | Using primary service for historical data for NQ-201712-GLOBEX | 2017-10-28 13:43:55 Intraday data recording state for symbol NQ-201712-GLOBEX is set to download 'Pending'. | 2017-10-28 13:43:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The ??? pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:55 Interactive Brokers | Starting real-time market data updates for: QQQ. ID: 3 | 2017-10-28 13:43:55 Interactive Brokers | Subscribing to Symbol: QQQ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: | 2017-10-28 13:43:55 Interactive Brokers | Requesting security definition data for: QQQ. ID: 3 | 2017-10-28 13:43:55 Interactive Brokers | Using primary service for historical data for QQQ | 2017-10-28 13:43:55 Intraday data recording state for symbol QQQ is set to download 'Pending'. | 2017-10-28 13:43:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM-######-ECBOT pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:55 Interactive Brokers | Starting real-time market data updates for: YM-201712-ECBOT. ID: 4 | 2017-10-28 13:43:55 Interactive Brokers | Subscribing to Symbol: YM, SecurityType: FUT, Expiration: 201712, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: | 2017-10-28 13:43:55 Interactive Brokers | Requesting security definition data for: YM-201712-ECBOT. ID: 4 | 2017-10-28 13:43:55 Interactive Brokers | Using primary service for historical data for YM-201712-ECBOT | 2017-10-28 13:43:55 Intraday data recording state for symbol YM-201712-ECBOT is set to download 'Pending'. | 2017-10-28 13:43:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The ??? pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:55 Interactive Brokers | Starting real-time market data updates for: IWM. ID: 5 | 2017-10-28 13:43:55 Interactive Brokers | Subscribing to Symbol: IWM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: | 2017-10-28 13:43:55 Interactive Brokers | Requesting security definition data for: IWM. ID: 5 | 2017-10-28 13:43:55 Interactive Brokers | Using primary service for historical data for IWM | 2017-10-28 13:43:55 Intraday data recording state for symbol IWM is set to download 'Pending'. | 2017-10-28 13:43:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The ??? pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:55 Interactive Brokers | Starting real-time market data updates for: DIA. ID: 6 | 2017-10-28 13:43:55 Interactive Brokers | Subscribing to Symbol: DIA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: | 2017-10-28 13:43:55 Interactive Brokers | Requesting security definition data for: DIA. ID: 6 | 2017-10-28 13:43:55 Interactive Brokers | Using primary service for historical data for DIA | 2017-10-28 13:43:55 Intraday data recording state for symbol DIA is set to download 'Pending'. | 2017-10-28 13:43:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES-######-GLOBEX pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:55 Interactive Brokers | Starting real-time market data updates for: ES-201712-GLOBEX. ID: 7 | 2017-10-28 13:43:55 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201712, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: | 2017-10-28 13:43:55 Interactive Brokers | Requesting security definition data for: ES-201712-GLOBEX. ID: 7 | 2017-10-28 13:43:55 Interactive Brokers | Using primary service for historical data for ES-201712-GLOBEX | 2017-10-28 13:43:55 Intraday data recording state for symbol ES-201712-GLOBEX is set to download 'Pending'. | 2017-10-28 13:43:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ-######-GLOBEX pattern/symbol will not use the SC Exchange Data Feed. | 2017-10-28 13:43:56 Interactive Brokers | Starting real-time market data updates for: NQ-201706-GLOBEX. ID: 8 | 2017-10-28 13:43:56 Interactive Brokers | Subscribing to Symbol: NQ, SecurityType: FUT, Expiration: 201706, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: | 2017-10-28 13:43:56 Interactive Brokers | Requesting security definition data for: NQ-201706-GLOBEX. ID: 8 | 2017-10-28 13:43:56 Intraday data recording state for symbol NQ-201706-GLOBEX is set to download 'Pending'. | 2017-10-28 13:43:56 Delaying start of download for NQ-201706-GLOBEX | 2017-10-28 13:43:56 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 1. Symbol: SPY. | 2017-10-28 13:43:56 Symbol Error - NQ-201706-GLOBEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2017-10-28 13:43:56 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 3. Symbol: QQQ. | 2017-10-28 13:43:56 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 5. Symbol: IWM. | 2017-10-28 13:43:56 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 6. Symbol: DIA. | 2017-10-28 13:43:56 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 4. Symbol: YM-201712-ECBOT. | 2017-10-28 13:43:56 Delaying start of download for SPY | 2017-10-28 13:43:56 HD Request # 3 | Downloading Intraday chart data for NQ-201706-GLOBEX to the file NQ-201706-GLOBEX.scid. Service: cme | 2017-10-28 13:43:57 HD Request # 3 | Download start date-time: 2017-06-16 16:26:20.000 | 2017-10-28 13:43:57 HD Request # 3 | Using server: ds1.sierracharts.com port 10150 | 2017-10-28 13:43:57 Socket (8) | Creating socket. | 2017-10-28 13:43:57 Socket (8) | Connecting to IP: 8.18.161.135. | 2017-10-28 13:43:57 HD Request # 3 | Setting DTC encoding to Binary VLS | 2017-10-28 13:43:57 HD Request # 3 | Sending historical data logon request message. | 2017-10-28 13:43:57 HD Request # 3 | Requesting Intraday data. Start date-time: 2017-06-16 16:26:20. Record interval: 1. Symbol: NQM17 | 2017-10-28 13:43:57 HD Request # 3 | Decompressing data. | 2017-10-28 13:43:57 HD Request # 3 | Receiving Intraday data for NQ-201706-GLOBEX starting at 2017-06-15 08:29:52 | 2017-10-28 13:43:57 Socket (8) | Initiating close of socket by core. | 2017-10-28 13:43:57 Historical data download thread signaled to stop. | 2017-10-28 13:43:57 Socket (8) | Shutdown started. Waiting for graceful close. | 2017-10-28 13:43:57 HD Request # 3 | Received 8308 records from 2017-06-15 08:29:52 to 2017-06-16 08:29:52 (24.0 hours) and wrote 0 records for NQ-201706-GLOBEX | 2017-10-28 13:43:57 HD Request # 3 | Intraday download COMPLETE for NQ-201706-GLOBEX. Completion time: 0s. Unique request ID: 9 | 2017-10-28 13:43:57 Removed historical data download ID 9 | 2017-10-28 13:43:57 Real-time Intraday chart data file updates started for NQ-201706-GLOBEX | 2017-10-28 13:43:57 Opened cached Intraday file: C:\SierraChart\Data\NQ-201706-GLOBEX.scid | 2017-10-28 13:43:57 Intraday chart data file opened for NQ-201706-GLOBEX | 2017-10-28 13:43:57 Socket (8) | Socket gracefully closed by remote side. | 2017-10-28 13:43:57 Socket (8) | Closed. | 2017-10-28 13:43:57 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: U934* | 2017-10-28 13:44:00 Interactive Brokers | Received Trade Positions download end message for account U934* | 2017-10-28 13:44:00 HD Request # 4 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: equities.us | 2017-10-28 13:44:00 HD Request # 4 | Download start date-time: 2017-10-20 15:38:29.000 | 2017-10-28 13:44:00 HD Request # 4 | Requesting a total of 7 days and 84331 seconds. | 2017-10-28 13:44:00 HD Request # 4 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 602731. | 2017-10-28 13:44:00 HD Request # 4 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-21 15:28:29 for SPY. PriceType: TRADES | 2017-10-28 13:44:00 HD Request # 4 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 9. | 2017-10-28 13:44:00 HD Request # 4 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 516331. | 2017-10-28 13:44:00 HD Request # 4 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-22 15:28:29 for SPY. PriceType: TRADES | 2017-10-28 13:44:00 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 9. | 2017-10-28 13:44:00 HD Request # 4 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 10. | 2017-10-28 13:44:00 HD Request # 4 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 429931. | 2017-10-28 13:44:00 HD Request # 4 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-23 15:28:29 for SPY. PriceType: TRADES | 2017-10-28 13:44:00 HD Request # 4 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 11. | 2017-10-28 13:44:00 HD Request # 4 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 343531. | 2017-10-28 13:44:00 HD Request # 4 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-24 15:28:29 for SPY. PriceType: TRADES | 2017-10-28 13:44:00 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 10. | 2017-10-28 13:44:00 HD Request # 4 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 12. | 2017-10-28 13:44:00 HD Request # 4 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 257131. | 2017-10-28 13:44:00 HD Request # 4 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-25 15:28:29 for SPY. PriceType: TRADES | 2017-10-28 13:44:00 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 11. | 2017-10-28 13:44:00 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 12. | 2017-10-28 13:44:01 HD Request # 4 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 13. | 2017-10-28 13:44:01 HD Request # 4 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 170731. | 2017-10-28 13:44:01 HD Request # 4 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-26 15:28:29 for SPY. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 13. | 2017-10-28 13:44:01 HD Request # 4 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 14. | 2017-10-28 13:44:01 HD Request # 4 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 84331. | 2017-10-28 13:44:01 HD Request # 4 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-27 15:28:29 for SPY. PriceType: TRADES | 2017-10-28 13:44:01 HD Request # 4 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 15. | 2017-10-28 13:44:01 HD Request # 4 | IB Backfill - Seconds requested: 84331. Seconds Remaining: 0. | 2017-10-28 13:44:01 HD Request # 4 | Requesting 84331 Seconds of data at 30 secs with ending date-time at 2017-10-28 14:54:00 for SPY. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 14. | 2017-10-28 13:44:01 HD Request # 4 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 16. | 2017-10-28 13:44:01 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for SPY | 2017-10-28 13:44:01 HD Request # 4 | Intraday download COMPLETE for SPY. Completion time: 1s. Unique request ID: 2 | 2017-10-28 13:44:01 Removed historical data download ID 2 | 2017-10-28 13:44:01 Real-time Intraday chart data file updates started for SPY | 2017-10-28 13:44:01 Opened cached Intraday file: C:\SierraChart\Data\SPY.scid | 2017-10-28 13:44:01 Intraday chart data file opened for SPY | 2017-10-28 13:44:01 HD Request # 5 | Downloading Intraday chart data for NQ-201712-GLOBEX to the file NQ-201712-GLOBEX.scid. Service: ib | 2017-10-28 13:44:01 HD Request # 5 | Download start date-time: 2017-10-20 15:38:30.000 | 2017-10-28 13:44:01 HD Request # 5 | Requesting a total of 7 days and 84331 seconds. | 2017-10-28 13:44:01 HD Request # 5 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 602731. | 2017-10-28 13:44:01 HD Request # 5 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-21 15:28:30 for NQ-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 15. | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 16. | 2017-10-28 13:44:01 HD Request # 5 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 17. | 2017-10-28 13:44:01 HD Request # 5 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 516331. | 2017-10-28 13:44:01 HD Request # 5 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-22 15:28:30 for NQ-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 17. | 2017-10-28 13:44:01 HD Request # 5 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 18. | 2017-10-28 13:44:01 HD Request # 5 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 429931. | 2017-10-28 13:44:01 HD Request # 5 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-23 15:28:30 for NQ-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 18. | 2017-10-28 13:44:01 HD Request # 5 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 19. | 2017-10-28 13:44:01 HD Request # 5 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 343531. | 2017-10-28 13:44:01 HD Request # 5 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-24 15:28:30 for NQ-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 19. | 2017-10-28 13:44:01 HD Request # 5 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 20. | 2017-10-28 13:44:01 HD Request # 5 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 257131. | 2017-10-28 13:44:01 HD Request # 5 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-25 15:28:30 for NQ-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 20. | 2017-10-28 13:44:01 HD Request # 5 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 21. | 2017-10-28 13:44:01 HD Request # 5 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 170731. | 2017-10-28 13:44:01 HD Request # 5 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-26 15:28:30 for NQ-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 21. | 2017-10-28 13:44:01 HD Request # 5 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 22. | 2017-10-28 13:44:01 HD Request # 5 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 84331. | 2017-10-28 13:44:01 HD Request # 5 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-27 15:28:30 for NQ-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 22. | 2017-10-28 13:44:01 HD Request # 5 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 23. | 2017-10-28 13:44:01 HD Request # 5 | IB Backfill - Seconds requested: 84331. Seconds Remaining: 0. | 2017-10-28 13:44:01 HD Request # 5 | Requesting 84331 Seconds of data at 30 secs with ending date-time at 2017-10-28 14:54:01 for NQ-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 23. | 2017-10-28 13:44:01 HD Request # 5 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 24. | 2017-10-28 13:44:01 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201712-GLOBEX | 2017-10-28 13:44:01 HD Request # 5 | Intraday download COMPLETE for NQ-201712-GLOBEX. Completion time: 0s. Unique request ID: 3 | 2017-10-28 13:44:01 Removed historical data download ID 3 | 2017-10-28 13:44:01 Real-time Intraday chart data file updates started for NQ-201712-GLOBEX | 2017-10-28 13:44:01 Opened cached Intraday file: C:\SierraChart\Data\NQ-201712-GLOBEX.scid | 2017-10-28 13:44:01 Intraday chart data file opened for NQ-201712-GLOBEX | 2017-10-28 13:44:01 HD Request # 6 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: equities.us | 2017-10-28 13:44:01 HD Request # 6 | Download start date-time: 2017-10-20 15:38:00.000 | 2017-10-28 13:44:01 HD Request # 6 | Requesting a total of 7 days and 84361 seconds. | 2017-10-28 13:44:01 HD Request # 6 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 602761. | 2017-10-28 13:44:01 HD Request # 6 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-21 15:28:00 for QQQ. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 24. | 2017-10-28 13:44:01 HD Request # 6 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 25. | 2017-10-28 13:44:01 HD Request # 6 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 516361. | 2017-10-28 13:44:01 HD Request # 6 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-22 15:28:00 for QQQ. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ISLAND STK. IB Error Code: 162. Request ID: 25. | 2017-10-28 13:44:01 HD Request # 6 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 26. | 2017-10-28 13:44:01 HD Request # 6 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 429961. | 2017-10-28 13:44:01 HD Request # 6 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-23 15:28:00 for QQQ. PriceType: TRADES | 2017-10-28 13:44:01 HD Request # 6 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 27. | 2017-10-28 13:44:01 HD Request # 6 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 343561. | 2017-10-28 13:44:01 HD Request # 6 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-24 15:28:00 for QQQ. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ISLAND STK. IB Error Code: 162. Request ID: 26. | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ISLAND STK. IB Error Code: 162. Request ID: 27. | 2017-10-28 13:44:01 HD Request # 6 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 28. | 2017-10-28 13:44:01 HD Request # 6 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 257161. | 2017-10-28 13:44:01 HD Request # 6 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-25 15:28:00 for QQQ. PriceType: TRADES | 2017-10-28 13:44:01 HD Request # 6 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 29. | 2017-10-28 13:44:01 HD Request # 6 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 170761. | 2017-10-28 13:44:01 HD Request # 6 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-26 15:28:00 for QQQ. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ISLAND STK. IB Error Code: 162. Request ID: 28. | 2017-10-28 13:44:01 HD Request # 6 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 30. | 2017-10-28 13:44:01 HD Request # 6 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 84361. | 2017-10-28 13:44:01 HD Request # 6 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-27 15:28:00 for QQQ. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ISLAND STK. IB Error Code: 162. Request ID: 29. | 2017-10-28 13:44:01 HD Request # 6 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 31. | 2017-10-28 13:44:01 HD Request # 6 | IB Backfill - Seconds requested: 84361. Seconds Remaining: 0. | 2017-10-28 13:44:01 HD Request # 6 | Requesting 84361 Seconds of data at 30 secs with ending date-time at 2017-10-28 14:54:01 for QQQ. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ISLAND STK. IB Error Code: 162. Request ID: 30. | 2017-10-28 13:44:01 HD Request # 6 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 32. | 2017-10-28 13:44:01 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for QQQ | 2017-10-28 13:44:01 HD Request # 6 | Intraday download COMPLETE for QQQ. Completion time: 0s. Unique request ID: 4 | 2017-10-28 13:44:01 Removed historical data download ID 4 | 2017-10-28 13:44:01 Real-time Intraday chart data file updates started for QQQ | 2017-10-28 13:44:01 Opened cached Intraday file: C:\SierraChart\Data\QQQ.scid | 2017-10-28 13:44:01 Intraday chart data file opened for QQQ | 2017-10-28 13:44:01 HD Request # 7 | Downloading Intraday chart data for YM-201712-ECBOT to the file YM-201712-ECBOT.scid. Service: ib | 2017-10-28 13:44:01 HD Request # 7 | Download start date-time: 2017-10-20 15:38:03.000 | 2017-10-28 13:44:01 HD Request # 7 | Requesting a total of 7 days and 84358 seconds. | 2017-10-28 13:44:01 HD Request # 7 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 602758. | 2017-10-28 13:44:01 HD Request # 7 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-21 15:28:03 for YM-201712-ECBOT. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ISLAND STK. IB Error Code: 162. Request ID: 31. | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ISLAND STK. IB Error Code: 162. Request ID: 32. | 2017-10-28 13:44:01 HD Request # 7 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 33. | 2017-10-28 13:44:01 HD Request # 7 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 516358. | 2017-10-28 13:44:01 HD Request # 7 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-22 15:28:03 for YM-201712-ECBOT. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 33. | 2017-10-28 13:44:01 HD Request # 7 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 34. | 2017-10-28 13:44:01 HD Request # 7 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 429958. | 2017-10-28 13:44:01 HD Request # 7 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-23 15:28:03 for YM-201712-ECBOT. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 34. | 2017-10-28 13:44:01 HD Request # 7 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 35. | 2017-10-28 13:44:01 HD Request # 7 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 343558. | 2017-10-28 13:44:01 HD Request # 7 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-24 15:28:03 for YM-201712-ECBOT. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 35. | 2017-10-28 13:44:01 HD Request # 7 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 36. | 2017-10-28 13:44:01 HD Request # 7 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 257158. | 2017-10-28 13:44:01 HD Request # 7 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-25 15:28:03 for YM-201712-ECBOT. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 36. | 2017-10-28 13:44:01 HD Request # 7 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 37. | 2017-10-28 13:44:01 HD Request # 7 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 170758. | 2017-10-28 13:44:01 HD Request # 7 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-26 15:28:03 for YM-201712-ECBOT. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 37. | 2017-10-28 13:44:01 HD Request # 7 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 38. | 2017-10-28 13:44:01 HD Request # 7 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 84358. | 2017-10-28 13:44:01 HD Request # 7 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-27 15:28:03 for YM-201712-ECBOT. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 38. | 2017-10-28 13:44:01 HD Request # 7 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 39. | 2017-10-28 13:44:01 HD Request # 7 | IB Backfill - Seconds requested: 84358. Seconds Remaining: 0. | 2017-10-28 13:44:01 HD Request # 7 | Requesting 84358 Seconds of data at 30 secs with ending date-time at 2017-10-28 14:54:01 for YM-201712-ECBOT. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 39. | 2017-10-28 13:44:01 HD Request # 7 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 40. | 2017-10-28 13:44:01 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YM-201712-ECBOT | 2017-10-28 13:44:01 HD Request # 7 | Intraday download COMPLETE for YM-201712-ECBOT. Completion time: 0s. Unique request ID: 5 | 2017-10-28 13:44:01 Removed historical data download ID 5 | 2017-10-28 13:44:01 Real-time Intraday chart data file updates started for YM-201712-ECBOT | 2017-10-28 13:44:01 Opened cached Intraday file: C:\SierraChart\Data\YM-201712-ECBOT.scid | 2017-10-28 13:44:01 Intraday chart data file opened for YM-201712-ECBOT | 2017-10-28 13:44:01 HD Request # 8 | Downloading Intraday chart data for IWM to the file IWM.scid. Service: equities.us | 2017-10-28 13:44:01 HD Request # 8 | Download start date-time: 2017-10-20 15:38:18.000 | 2017-10-28 13:44:01 HD Request # 8 | Requesting a total of 7 days and 84343 seconds. | 2017-10-28 13:44:01 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 602743. | 2017-10-28 13:44:01 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-21 15:28:18 for IWM. PriceType: TRADES | 2017-10-28 13:44:01 Message from IB: Historical Market Data Service error message:No market data permissions for ECBOT FUT. IB Error Code: 162. Request ID: 40. | 2017-10-28 13:44:01 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 41. | 2017-10-28 13:44:01 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 516343. | 2017-10-28 13:44:01 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-22 15:28:18 for IWM. PriceType: TRADES | 2017-10-28 13:44:01 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 42. | 2017-10-28 13:44:02 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 429943. | 2017-10-28 13:44:02 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-23 15:28:18 for IWM. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 41. | 2017-10-28 13:44:02 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 43. | 2017-10-28 13:44:02 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 343543. | 2017-10-28 13:44:02 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-24 15:28:18 for IWM. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 42. | 2017-10-28 13:44:02 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 44. | 2017-10-28 13:44:02 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 257143. | 2017-10-28 13:44:02 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-25 15:28:18 for IWM. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 43. | 2017-10-28 13:44:02 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 45. | 2017-10-28 13:44:02 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 170743. | 2017-10-28 13:44:02 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-26 15:28:18 for IWM. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 44. | 2017-10-28 13:44:02 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 46. | 2017-10-28 13:44:02 HD Request # 8 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 84343. | 2017-10-28 13:44:02 HD Request # 8 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-27 15:28:18 for IWM. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 45. | 2017-10-28 13:44:02 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 47. | 2017-10-28 13:44:02 HD Request # 8 | IB Backfill - Seconds requested: 84343. Seconds Remaining: 0. | 2017-10-28 13:44:02 HD Request # 8 | Requesting 84343 Seconds of data at 30 secs with ending date-time at 2017-10-28 14:54:01 for IWM. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 46. | 2017-10-28 13:44:02 HD Request # 8 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 48. | 2017-10-28 13:44:02 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for IWM | 2017-10-28 13:44:02 HD Request # 8 | Intraday download COMPLETE for IWM. Completion time: 1s. Unique request ID: 6 | 2017-10-28 13:44:02 Removed historical data download ID 6 | 2017-10-28 13:44:02 Real-time Intraday chart data file updates started for IWM | 2017-10-28 13:44:02 Opened cached Intraday file: C:\SierraChart\Data\IWM.scid | 2017-10-28 13:44:02 Intraday chart data file opened for IWM | 2017-10-28 13:44:02 HD Request # 9 | Downloading Intraday chart data for DIA to the file DIA.scid. Service: equities.us | 2017-10-28 13:44:02 HD Request # 9 | Download start date-time: 2017-10-20 15:30:15.000 | 2017-10-28 13:44:02 HD Request # 9 | Requesting a total of 7 days and 84827 seconds. | 2017-10-28 13:44:02 HD Request # 9 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 603227. | 2017-10-28 13:44:02 HD Request # 9 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-21 15:20:15 for DIA. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 47. | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 48. | 2017-10-28 13:44:02 HD Request # 9 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 49. | 2017-10-28 13:44:02 HD Request # 9 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 516827. | 2017-10-28 13:44:02 HD Request # 9 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-22 15:20:15 for DIA. PriceType: TRADES | 2017-10-28 13:44:02 HD Request # 9 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 50. | 2017-10-28 13:44:02 HD Request # 9 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 430427. | 2017-10-28 13:44:02 HD Request # 9 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-23 15:20:15 for DIA. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 49. | 2017-10-28 13:44:02 HD Request # 9 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 51. | 2017-10-28 13:44:02 HD Request # 9 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 344027. | 2017-10-28 13:44:02 HD Request # 9 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-24 15:20:15 for DIA. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 50. | 2017-10-28 13:44:02 HD Request # 9 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 52. | 2017-10-28 13:44:02 HD Request # 9 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 257627. | 2017-10-28 13:44:02 HD Request # 9 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-25 15:20:15 for DIA. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 51. | 2017-10-28 13:44:02 HD Request # 9 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 53. | 2017-10-28 13:44:02 HD Request # 9 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 171227. | 2017-10-28 13:44:02 HD Request # 9 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-26 15:20:15 for DIA. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 52. | 2017-10-28 13:44:02 HD Request # 9 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 54. | 2017-10-28 13:44:02 HD Request # 9 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 84827. | 2017-10-28 13:44:02 HD Request # 9 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-27 15:20:15 for DIA. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 53. | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 54. | 2017-10-28 13:44:02 HD Request # 9 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 55. | 2017-10-28 13:44:02 HD Request # 9 | IB Backfill - Seconds requested: 84827. Seconds Remaining: 0. | 2017-10-28 13:44:02 HD Request # 9 | Requesting 84827 Seconds of data at 30 secs with ending date-time at 2017-10-28 14:54:02 for DIA. PriceType: TRADES | 2017-10-28 13:44:02 HD Request # 9 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 56. | 2017-10-28 13:44:02 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for DIA | 2017-10-28 13:44:02 HD Request # 9 | Intraday download COMPLETE for DIA. Completion time: 0s. Unique request ID: 7 | 2017-10-28 13:44:02 Removed historical data download ID 7 | 2017-10-28 13:44:02 Real-time Intraday chart data file updates started for DIA | 2017-10-28 13:44:02 Opened cached Intraday file: C:\SierraChart\Data\DIA.scid | 2017-10-28 13:44:02 Intraday chart data file opened for DIA | 2017-10-28 13:44:02 HD Request # 10 | Downloading Intraday chart data for ES-201712-GLOBEX to the file ES-201712-GLOBEX.scid. Service: ib | 2017-10-28 13:44:02 HD Request # 10 | Download start date-time: 2017-10-20 15:38:29.000 | 2017-10-28 13:44:02 HD Request # 10 | Requesting a total of 7 days and 84333 seconds. | 2017-10-28 13:44:02 HD Request # 10 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 602733. | 2017-10-28 13:44:02 HD Request # 10 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-21 15:28:29 for ES-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 55. | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for AMEX STK. IB Error Code: 162. Request ID: 56. | 2017-10-28 13:44:02 HD Request # 10 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 57. | 2017-10-28 13:44:02 HD Request # 10 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 516333. | 2017-10-28 13:44:02 HD Request # 10 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-22 15:28:29 for ES-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:02 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 57. | 2017-10-28 13:44:02 HD Request # 10 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 58. | 2017-10-28 13:44:03 HD Request # 10 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 429933. | 2017-10-28 13:44:03 HD Request # 10 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-23 15:28:29 for ES-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:03 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 58. | 2017-10-28 13:44:03 HD Request # 10 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 59. | 2017-10-28 13:44:03 HD Request # 10 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 343533. | 2017-10-28 13:44:03 HD Request # 10 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-24 15:28:29 for ES-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:03 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 59. | 2017-10-28 13:44:03 HD Request # 10 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 60. | 2017-10-28 13:44:03 HD Request # 10 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 257133. | 2017-10-28 13:44:03 HD Request # 10 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-25 15:28:29 for ES-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:03 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 60. | 2017-10-28 13:44:03 HD Request # 10 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 61. | 2017-10-28 13:44:03 HD Request # 10 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 170733. | 2017-10-28 13:44:03 HD Request # 10 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-26 15:28:29 for ES-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:03 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 61. | 2017-10-28 13:44:03 HD Request # 10 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 62. | 2017-10-28 13:44:03 HD Request # 10 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 84333. | 2017-10-28 13:44:03 HD Request # 10 | Requesting 1 Day of data at 30 secs with ending date-time at 2017-10-27 15:28:29 for ES-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:03 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 62. | 2017-10-28 13:44:03 HD Request # 10 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 63. | 2017-10-28 13:44:03 HD Request # 10 | IB Backfill - Seconds requested: 84333. Seconds Remaining: 0. | 2017-10-28 13:44:03 HD Request # 10 | Requesting 84333 Seconds of data at 30 secs with ending date-time at 2017-10-28 14:54:02 for ES-201712-GLOBEX. PriceType: TRADES | 2017-10-28 13:44:03 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 63. | 2017-10-28 13:44:03 HD Request # 10 | Message from IB: Requested market data is not subscribed. IB Error Code: 354. Request ID: 64. | 2017-10-28 13:44:03 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ES-201712-GLOBEX | 2017-10-28 13:44:03 HD Request # 10 | Intraday download COMPLETE for ES-201712-GLOBEX. Completion time: 0s. Unique request ID: 8 | 2017-10-28 13:44:03 Removed historical data download ID 8 | 2017-10-28 13:44:03 Real-time Intraday chart data file updates started for ES-201712-GLOBEX | 2017-10-28 13:44:03 Opened cached Intraday file: C:\SierraChart\Data\ES-201712-GLOBEX.scid | 2017-10-28 13:44:03 Intraday chart data file opened for ES-201712-GLOBEX | 2017-10-28 13:44:03 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 64. | 2017-10-28 13:44:03 |
[2017-10-28 20:34:30] |
User41636 - Posts: 35 |
I should add to post just submitted that nothing is displayed on any of my charts regarding "some TWS authorization error related to the symbol of the chart" after connecting to the data feed. Yet as before, none of the data on my charts is updating. The latest data I have showing on my charts is from October 20. That is where the charts stop. Could there still be a connection problem? Thanks again.
[2017-10-30 16:09:50] |
You definitely should be seeing on the chart, for 30 seconds after connecting to the data feed or after opening the chart and when connected to the data feed, a message indicating the symbol is unknown, and the error message text from Interactive Brokers. That is with certainty. These are the relevant messages: Symbol Error - NQ-201706-GLOBEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2017-10-28 13:43:56 Message from IB: Historical Market Data Service error message:No market data permissions for GLOBEX FUT. IB Error Code: 162. Request ID: 61. | 2017-10-28 13:44:03 There are other similar messages as well like this. Refer to: Interactive Brokers Trading Service: Market Data Not Subscribed Through Interactive Brokers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-30 16:10:03
