Date/Time: Tue, 26 Nov 2024 07:01:16 +0000
Current status: Inactive - Cannot Connect after entering login info
View Count: 280
[2023-12-19 17:54:10] |
User668772 - Posts: 5 |
Hi SC Support, After logging in, in the upper left corner of the App, in yellow, it constantly cycles back and forth from "Connecting" to "Reconnect Wait". Please advise. Thank You! |
[2023-12-19 19:36:10] |
John - SC Support - Posts: 36286 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-19 19:56:18] |
Software version: 2568 64-bit | 2023-12-19 19:50:50.957 Primary Thread ID: 8596 | 2023-12-19 19:50:50.957 Usage end date: 2024-05-25 | 2023-12-19 19:50:50.957 Enabled for: Advanced Features 2. | 2023-12-19 19:50:50.957 Enabled for: Sierra Chart Historical Data Service. | 2023-12-19 19:50:50.957 Enabled for: Delayed Denali Exchange Data Feed. | 2023-12-19 19:50:50.957 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-12-19 19:50:50.957 Current selected Data/Trading service: DTC - Sub Instance | 2023-12-19 19:50:50.957 Custom symbol settings values: enabled | 2023-12-19 19:50:50.957 Chart Update Interval: 500 | 2023-12-19 19:50:50.957 Intraday Data Storage Time Unit: 1 | 2023-12-19 19:50:50.957 Time Zone: +00:00:00 (UTC+00) | 2023-12-19 19:50:50.957 2023-12-19 19:50:50 Local computer time in UTC | 2023-12-19 19:50:50.957 2023-12-19 19:50:50 Local computer time in SC Time Zone | 2023-12-19 19:50:50.957 2023-12-19 19:46:33 Server time in UTC | 2023-12-19 19:50:50.957 Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-12-19 19:50:50.957 Program path: C:\Users\abc\Documents\G7FX\Sierra Chart Downloader\SierraChartInstance_2\ | 2023-12-19 19:50:50.957 Data Files path: C:\Users\abc\Documents\G7FX\Sierra Chart Downloader\SierraChartInstance_2\Data\ | 2023-12-19 19:50:50.957 OS Version Number: 10.0 | 2023-12-19 19:50:50.958 Locale Setting: C | 2023-12-19 19:50:50.958 DLLs: UserContributedStudies_64.dll | 2023-12-19 19:50:50.958 Allowed protected custom studies: | 2023-12-19 19:50:50.958 Crash reporter started: true | 2023-12-19 19:50:50.958 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:00.563 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:00.564 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:00.564 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:00.565 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:02.594 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:02.594 DTC - Sub Instance | Failed connections: 51 | 2023-12-19 19:52:02.594 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:02.594 DTC Client socket (1) | Closed. | 2023-12-19 19:52:02.594 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:02.594 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:02.610 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:02.610 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:02.610 File >> Reconnect selected. | 2023-12-19 19:52:11.850 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:11.850 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:11.850 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:11.850 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:13.843 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:13.843 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:13.843 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:13.843 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:16.135 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:16.135 DTC - Sub Instance | Failed connections: 52 | 2023-12-19 19:52:16.135 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:16.135 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:16.135 DTC Client socket (1) | Closed. | 2023-12-19 19:52:16.135 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:16.151 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:16.151 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:16.151 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:18.155 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:18.155 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:18.155 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:18.155 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:20.181 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:20.181 DTC - Sub Instance | Failed connections: 53 | 2023-12-19 19:52:20.181 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:20.181 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:20.181 DTC Client socket (1) | Closed. | 2023-12-19 19:52:20.181 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:20.197 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:20.197 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:20.197 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:22.201 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:22.201 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:22.201 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:22.201 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:24.237 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:24.237 DTC - Sub Instance | Failed connections: 54 | 2023-12-19 19:52:24.237 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:24.237 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:24.237 DTC Client socket (1) | Closed. | 2023-12-19 19:52:24.237 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:24.252 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:24.252 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:24.252 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:26.251 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:26.251 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:26.251 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:26.251 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:28.295 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:28.295 DTC - Sub Instance | Failed connections: 55 | 2023-12-19 19:52:28.295 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:28.295 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:28.295 DTC Client socket (1) | Closed. | 2023-12-19 19:52:28.295 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:28.311 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:28.311 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:28.311 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:30.307 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:30.307 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:30.308 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:30.308 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:32.349 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:32.349 DTC - Sub Instance | Failed connections: 56 | 2023-12-19 19:52:32.349 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:32.349 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:32.349 DTC Client socket (1) | Closed. | 2023-12-19 19:52:32.349 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:32.365 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:32.365 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:32.365 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:34.363 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:34.363 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:34.363 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:34.363 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:36.387 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:36.387 DTC - Sub Instance | Failed connections: 57 | 2023-12-19 19:52:36.387 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:36.387 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:36.387 DTC Client socket (1) | Closed. | 2023-12-19 19:52:36.387 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:36.402 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:36.403 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:36.403 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:38.411 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:38.411 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:38.411 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:38.411 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:40.445 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:40.446 DTC - Sub Instance | Failed connections: 58 | 2023-12-19 19:52:40.446 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:40.446 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:40.446 DTC Client socket (1) | Closed. | 2023-12-19 19:52:40.446 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:40.461 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:40.461 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:40.461 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:42.468 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:42.570 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:42.570 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:42.570 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:44.605 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:44.605 DTC Client socket (1) | Closed. | 2023-12-19 19:52:44.605 DTC - Sub Instance | Failed connections: 59 | 2023-12-19 19:52:44.605 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:44.605 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:44.605 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:44.621 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:44.621 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:44.621 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:46.633 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:46.633 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:46.633 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:46.633 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:48.661 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:48.661 DTC Client socket (1) | Closed. | 2023-12-19 19:52:48.661 DTC - Sub Instance | Failed connections: 60 | 2023-12-19 19:52:48.661 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:48.661 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:48.661 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:48.677 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:48.677 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:48.677 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:50.665 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:50.665 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:50.665 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:50.665 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:52.704 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:52.704 DTC Client socket (1) | Closed. | 2023-12-19 19:52:52.704 DTC - Sub Instance | Failed connections: 61 | 2023-12-19 19:52:52.704 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:52.704 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:52.704 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:52.719 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:52.719 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:52.719 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:54.725 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:54.725 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:54.725 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:54.725 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:52:56.768 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:52:56.768 DTC - Sub Instance | Failed connections: 62 | 2023-12-19 19:52:56.768 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:52:56.768 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:56.768 DTC Client socket (1) | Closed. | 2023-12-19 19:52:56.768 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:52:56.784 DTC - Sub Instance | Disconnected. | 2023-12-19 19:52:56.784 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:52:56.784 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:52:58.794 DTC Client socket (1) | Creating socket. | 2023-12-19 19:52:58.794 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:52:58.794 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:52:58.794 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:00.837 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:00.837 DTC Client socket (1) | Closed. | 2023-12-19 19:53:00.837 DTC - Sub Instance | Failed connections: 63 | 2023-12-19 19:53:00.837 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:00.837 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:00.837 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:00.853 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:00.853 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:00.853 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:02.863 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:02.863 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:02.863 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:02.863 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:04.909 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:04.909 DTC - Sub Instance | Failed connections: 64 | 2023-12-19 19:53:04.909 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:04.909 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:04.909 DTC Client socket (1) | Closed. | 2023-12-19 19:53:04.909 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:04.925 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:04.925 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:04.925 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:06.917 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:06.917 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:06.917 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:06.917 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:08.957 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:08.957 DTC - Sub Instance | Failed connections: 65 | 2023-12-19 19:53:08.957 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:08.957 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:08.957 DTC Client socket (1) | Closed. | 2023-12-19 19:53:08.958 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:08.974 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:08.974 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:08.974 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:10.972 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:10.973 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:10.973 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:10.973 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:13.001 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:13.001 DTC Client socket (1) | Closed. | 2023-12-19 19:53:13.001 DTC - Sub Instance | Failed connections: 66 | 2023-12-19 19:53:13.001 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:13.001 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:13.001 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:13.017 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:13.017 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:13.017 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:15.028 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:15.028 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:15.029 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:15.029 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:17.047 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:17.047 DTC Client socket (1) | Closed. | 2023-12-19 19:53:17.047 DTC - Sub Instance | Failed connections: 67 | 2023-12-19 19:53:17.047 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:17.047 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:17.047 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:17.063 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:17.063 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:17.063 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:19.059 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:19.059 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:19.060 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:19.060 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:21.081 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:21.081 DTC - Sub Instance | Failed connections: 68 | 2023-12-19 19:53:21.081 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:21.081 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:21.081 DTC Client socket (1) | Closed. | 2023-12-19 19:53:21.081 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:21.097 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:21.097 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:21.097 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:23.085 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:23.085 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:23.086 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:23.086 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:25.109 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:25.109 DTC - Sub Instance | Failed connections: 69 | 2023-12-19 19:53:25.109 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:25.109 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:25.109 DTC Client socket (1) | Closed. | 2023-12-19 19:53:25.109 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:25.125 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:25.125 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:25.125 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:27.117 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:27.117 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:27.118 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:27.118 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:29.159 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:29.159 DTC - Sub Instance | Failed connections: 70 | 2023-12-19 19:53:29.159 DTC Client socket (1) | Closed. | 2023-12-19 19:53:29.159 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:29.159 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:29.159 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:29.175 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:29.175 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:29.175 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:31.177 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:31.177 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:31.178 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:31.178 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:33.219 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:33.219 DTC - Sub Instance | Failed connections: 71 | 2023-12-19 19:53:33.219 DTC Client socket (1) | Closed. | 2023-12-19 19:53:33.219 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:33.219 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:33.219 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:33.235 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:33.235 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:33.235 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:35.227 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:35.227 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:35.228 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:35.228 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:37.263 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:37.263 DTC - Sub Instance | Failed connections: 72 | 2023-12-19 19:53:37.263 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:37.263 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:37.263 DTC Client socket (1) | Closed. | 2023-12-19 19:53:37.263 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:37.279 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:37.279 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:37.279 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:39.281 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:39.281 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:39.282 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:39.282 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:41.323 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:41.323 DTC Client socket (1) | Closed. | 2023-12-19 19:53:41.323 DTC - Sub Instance | Failed connections: 73 | 2023-12-19 19:53:41.323 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:41.323 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:41.323 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:41.339 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:41.339 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:41.339 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2023-12-19 19:53:43.349 DTC Client socket (1) | Creating socket. | 2023-12-19 19:53:43.349 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 19:53:43.350 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 19:53:43.350 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 19:53:45.395 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 19:53:45.395 DTC - Sub Instance | Failed connections: 74 | 2023-12-19 19:53:45.395 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 19:53:45.395 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:45.395 DTC Client socket (1) | Closed. | 2023-12-19 19:53:45.395 DTC Client socket (0) | CloseSocket call. | 2023-12-19 19:53:45.411 DTC - Sub Instance | Disconnected. | 2023-12-19 19:53:45.411 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 19:53:45.411 |
[2023-12-19 20:12:01] |
You changed something in the setup for the DTC Server in either the Main Instance or the Sub-Instance, or perhaps both. Such that the sub-instance is not able to connect to the main instance. In particular, the port that the sub-instance is trying to connect to is not the default port, which is why we know something got changed. Please set everything back to the default by setting the following: In the Main Instance: - Global Settings >> Sierra Chart Server Settings >> DTC Protocol Server >> Listening Port: 11098 - Global Settings >> Sierra Chart Server Settings >> DTC Protocol Server >> Historical Data Port: 11099 In the Sub-Instance: - Global Settings >> Data/Trade Service Settings >> Main Settings >> Server Port: 11098 - Global Settings >> Data/Trade Service Settings >> Main Settings >> Historical Data Server Port: 11099 Then exit from all instances of Sierra Chart (including Main Instance) and start Sierra Chart again. Your sub-instance should connect correctly in this case. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-19 20:32:52] |
I believe I did as requested and am now getting this error "Connection error message from service: DTC-Sub Instance | Connection error. Connection to self not allowed|Date-Time:2023-12-19 20:25:00" Created the DTC Protocol server. | 2023-12-19 20:24:55.493 DTC Protocol Server listening on port 11098. | 2023-12-19 20:24:55.494 Reading Internal Order ID file. | 2023-12-19 20:24:55.494 Reading Trade Orders file. | 2023-12-19 20:24:55.598 Reading Trade Positions file. | 2023-12-19 20:24:55.598 Reading Trade Account Data files. | 2023-12-19 20:24:55.599 Software version: 2568 64-bit | 2023-12-19 20:24:55.600 Primary Thread ID: 5792 | 2023-12-19 20:24:55.600 Usage end date: 2024-05-25 | 2023-12-19 20:24:55.600 Enabled for: Advanced Features 2. | 2023-12-19 20:24:55.600 Enabled for: Sierra Chart Historical Data Service. | 2023-12-19 20:24:55.600 Enabled for: Delayed Denali Exchange Data Feed. | 2023-12-19 20:24:55.600 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-12-19 20:24:55.600 Current selected Data/Trading service: DTC - Sub Instance | 2023-12-19 20:24:55.600 Custom symbol settings values: enabled | 2023-12-19 20:24:55.600 Chart Update Interval: 500 | 2023-12-19 20:24:55.600 Intraday Data Storage Time Unit: 1 | 2023-12-19 20:24:55.600 Time Zone: +00:00:00 (UTC+00) | 2023-12-19 20:24:55.600 2023-12-19 20:24:55 Local computer time in UTC | 2023-12-19 20:24:55.600 2023-12-19 20:24:55 Local computer time in SC Time Zone | 2023-12-19 20:24:55.600 2023-12-19 20:24:54 Server time in UTC | 2023-12-19 20:24:55.600 Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-12-19 20:24:55.600 Program path: C:\Users\abc\Documents\G7FX\Sierra Chart Downloader\SierraChartInstance_2\ | 2023-12-19 20:24:55.600 Data Files path: C:\Users\abc\Documents\G7FX\Sierra Chart Downloader\SierraChartInstance_2\Data\ | 2023-12-19 20:24:55.600 OS Version Number: 10.0 | 2023-12-19 20:24:55.601 Locale Setting: C | 2023-12-19 20:24:55.601 DLLs: UserContributedStudies_64.dll | 2023-12-19 20:24:55.601 Allowed protected custom studies: | 2023-12-19 20:24:55.601 Crash reporter started: true | 2023-12-19 20:24:55.601 Created the DTC Protocol historical data server. | 2023-12-19 20:24:55.620 HD Server Manager | Listening on port 11099. | 2023-12-19 20:24:55.621 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-12-19 20:24:55.659 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-12-19 20:24:55.754 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-12-19 20:24:55.754 Received 5 login tokens. | 2023-12-19 20:24:55.955 Requested user files to download. | 2023-12-19 20:24:58.121 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 20:25:00.120 DTC Client socket (1) | Creating socket. | 2023-12-19 20:25:00.120 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 20:25:00.121 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 20:25:00.121 DTC Protocol server | Incoming connection from 127.0.0.1. | 2023-12-19 20:25:00.122 DTC client #1. 127.0.0.1 (2) | Creating socket. | 2023-12-19 20:25:00.123 DTC client #1. 127.0.0.1 (2) | New receive buffer size: 262144 | 2023-12-19 20:25:00.123 DTC client #1. 127.0.0.1 (2) | Allocated send buffers: 32 of 131072 bytes. | 2023-12-19 20:25:00.123 DTC - Sub Instance | Network connection to server complete. | 2023-12-19 20:25:00.124 DTC - Sub Instance | Starting socket receive thread. | 2023-12-19 20:25:00.124 DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none | 2023-12-19 20:25:00.124 DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS | 2023-12-19 20:25:00.125 DTC - Sub Instance | Setting DTC encoding to Binary VLS | 2023-12-19 20:25:00.125 DTC - Sub Instance | Sending logon request message. | 2023-12-19 20:25:00.125 DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20 | 2023-12-19 20:25:00.125 DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request. | 2023-12-19 20:25:00.125 DTC client #1. Sierra Chart. 127.0.0.1 | Sent Logon response with error to Sierra Chart client. Username: Rmdt-23. Result text: Connection to self not allowed | 2023-12-19 20:25:00.125 DTC - Sub Instance | Received logon response. | 2023-12-19 20:25:00.126 DTC - Sub Instance | Server Name: SC DTC Server. | 2023-12-19 20:25:00.126 DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 | 2023-12-19 20:25:00.126 DTC - Sub Instance | Connection error: Connection to self not allowed | 2023-12-19 20:25:00.126 * DTC - Sub Instance | Failed connections: 1 | 2023-12-19 20:25:00.126 DTC - Sub Instance | Waiting for socket receive thread to end | 2023-12-19 20:25:00.147 DTC Client socket (1) | CloseSocket call. | 2023-12-19 20:25:00.147 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-12-19 20:25:00.147 DTC client #1. 127.0.0.1 (2) | Socket gracefully closed by remote side. | 2023-12-19 20:25:00.147 DTC - Sub Instance | Disconnected. | 2023-12-19 20:25:00.147 DTC client #1. 127.0.0.1 (2) | CloseSocket call. | 2023-12-19 20:25:00.148 DTC client #1. 127.0.0.1 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-19 20:25:00.148 DTC client #1. 127.0.0.1 (2) | Closed. | 2023-12-19 20:25:00.148 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-19 20:25:00.148 DTC Client socket (1) | Closed. | 2023-12-19 20:25:00.148 Deleting individual DTC server: DTC client #1. Sierra Chart. 127.0.0.1 | 2023-12-19 20:25:01.153 DTC server: DTC client #1. Sierra Chart. 127.0.0.1 successfully deleted. | 2023-12-19 20:25:01.153 |
[2023-12-19 21:22:16] |
Please also change the following in the Sub-Instance: - Global Settings >> Sierra Chart Server Settings >> DTC Protocol Server >> Listening Port: 11110 - Global Settings >> Sierra Chart Server Settings >> DTC Protocol Server >> Historical Data Port: 11111 Then exit from the sub-instance and start it again and it should be fine. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-19 21:54:38] |
I am back to the "Connecting" - "Reconnect Wait" errors Created the DTC Protocol server. | 2023-12-19 21:51:26.319 DTC Protocol Server listening on port 11110. | 2023-12-19 21:51:26.320 Reading Internal Order ID file. | 2023-12-19 21:51:26.320 Reading Trade Orders file. | 2023-12-19 21:51:26.422 Reading Trade Positions file. | 2023-12-19 21:51:26.423 Reading Trade Account Data files. | 2023-12-19 21:51:26.423 Software version: 2568 64-bit | 2023-12-19 21:51:26.424 Primary Thread ID: 6324 | 2023-12-19 21:51:26.424 Usage end date: 2024-05-25 | 2023-12-19 21:51:26.424 Enabled for: Advanced Features 2. | 2023-12-19 21:51:26.424 Enabled for: Sierra Chart Historical Data Service. | 2023-12-19 21:51:26.424 Enabled for: Delayed Denali Exchange Data Feed. | 2023-12-19 21:51:26.424 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-12-19 21:51:26.424 Current selected Data/Trading service: DTC - Sub Instance | 2023-12-19 21:51:26.424 Custom symbol settings values: enabled | 2023-12-19 21:51:26.424 Chart Update Interval: 500 | 2023-12-19 21:51:26.424 Intraday Data Storage Time Unit: 1 | 2023-12-19 21:51:26.424 Time Zone: +00:00:00 (UTC+00) | 2023-12-19 21:51:26.424 2023-12-19 21:51:26 Local computer time in UTC | 2023-12-19 21:51:26.424 2023-12-19 21:51:26 Local computer time in SC Time Zone | 2023-12-19 21:51:26.424 2023-12-19 21:51:25 Server time in UTC | 2023-12-19 21:51:26.424 Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-12-19 21:51:26.424 Program path: C:\Users\abc\Documents\G7FX\Sierra Chart Downloader\SierraChartInstance_2\ | 2023-12-19 21:51:26.424 Data Files path: C:\Users\abc\Documents\G7FX\Sierra Chart Downloader\SierraChartInstance_2\Data\ | 2023-12-19 21:51:26.424 OS Version Number: 10.0 | 2023-12-19 21:51:26.425 Locale Setting: C | 2023-12-19 21:51:26.425 DLLs: UserContributedStudies_64.dll | 2023-12-19 21:51:26.425 Allowed protected custom studies: | 2023-12-19 21:51:26.425 Crash reporter started: true | 2023-12-19 21:51:26.425 Created the DTC Protocol historical data server. | 2023-12-19 21:51:26.446 HD Server Manager | Listening on port 11111. | 2023-12-19 21:51:26.448 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-12-19 21:51:26.488 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-12-19 21:51:26.585 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-12-19 21:51:26.585 Received 5 login tokens. | 2023-12-19 21:51:26.772 Requested user files to download. | 2023-12-19 21:51:29.034 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:51:31.050 DTC Client socket (1) | Creating socket. | 2023-12-19 21:51:31.051 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:51:31.053 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:51:31.053 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:51:33.093 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:51:33.093 DTC Client socket (1) | Closed. | 2023-12-19 21:51:33.093 DTC - Sub Instance | Failed connections: 1 | 2023-12-19 21:51:33.093 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:51:33.093 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:33.093 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:51:33.107 DTC - Sub Instance | Disconnected. | 2023-12-19 21:51:33.107 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:33.107 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:51:35.108 DTC Client socket (1) | Creating socket. | 2023-12-19 21:51:35.108 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:51:35.109 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:51:35.109 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:51:37.146 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:51:37.146 DTC - Sub Instance | Failed connections: 2 | 2023-12-19 21:51:37.146 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:51:37.146 DTC Client socket (1) | Closed. | 2023-12-19 21:51:37.146 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:37.146 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:51:37.162 DTC - Sub Instance | Disconnected. | 2023-12-19 21:51:37.162 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:37.162 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:51:39.172 DTC Client socket (1) | Creating socket. | 2023-12-19 21:51:39.172 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:51:39.172 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:51:39.172 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:51:41.214 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:51:41.214 DTC - Sub Instance | Failed connections: 3 | 2023-12-19 21:51:41.214 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:51:41.214 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:41.214 DTC Client socket (1) | Closed. | 2023-12-19 21:51:41.214 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:51:41.230 DTC - Sub Instance | Disconnected. | 2023-12-19 21:51:41.230 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:41.230 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:51:43.226 DTC Client socket (1) | Creating socket. | 2023-12-19 21:51:43.226 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:51:43.226 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:51:43.226 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:51:45.270 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:51:45.270 DTC - Sub Instance | Failed connections: 4 | 2023-12-19 21:51:45.270 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:51:45.270 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:45.270 DTC Client socket (1) | Closed. | 2023-12-19 21:51:45.270 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:51:45.286 DTC - Sub Instance | Disconnected. | 2023-12-19 21:51:45.286 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:45.286 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:51:47.277 DTC Client socket (1) | Creating socket. | 2023-12-19 21:51:47.277 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:51:47.277 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:51:47.277 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:51:49.314 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:51:49.314 DTC - Sub Instance | Failed connections: 5 | 2023-12-19 21:51:49.314 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:51:49.314 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:49.314 DTC Client socket (1) | Closed. | 2023-12-19 21:51:49.314 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:51:49.330 DTC - Sub Instance | Disconnected. | 2023-12-19 21:51:49.330 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:49.330 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:51:51.333 DTC Client socket (1) | Creating socket. | 2023-12-19 21:51:51.333 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:51:51.333 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:51:51.333 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:51:53.373 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:51:53.373 DTC - Sub Instance | Failed connections: 6 | 2023-12-19 21:51:53.373 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:51:53.373 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:53.373 DTC Client socket (1) | Closed. | 2023-12-19 21:51:53.373 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:51:53.389 DTC - Sub Instance | Disconnected. | 2023-12-19 21:51:53.389 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:53.389 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:51:55.393 DTC Client socket (1) | Creating socket. | 2023-12-19 21:51:55.393 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:51:55.393 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:51:55.393 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:51:57.427 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:51:57.428 DTC - Sub Instance | Failed connections: 7 | 2023-12-19 21:51:57.428 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:51:57.428 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:57.428 DTC Client socket (1) | Closed. | 2023-12-19 21:51:57.428 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:51:57.443 DTC - Sub Instance | Disconnected. | 2023-12-19 21:51:57.443 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:51:57.443 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:51:59.453 DTC Client socket (1) | Creating socket. | 2023-12-19 21:51:59.454 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:51:59.454 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:51:59.454 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:01.485 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:01.490 DTC - Sub Instance | Failed connections: 8 | 2023-12-19 21:52:01.490 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:01.490 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:01.490 DTC Client socket (1) | Closed. | 2023-12-19 21:52:01.491 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:01.502 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:01.502 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:01.502 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:03.503 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:03.503 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:03.503 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:03.504 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:05.545 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:05.545 DTC - Sub Instance | Failed connections: 9 | 2023-12-19 21:52:05.545 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:05.545 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:05.545 DTC Client socket (1) | Closed. | 2023-12-19 21:52:05.545 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:05.561 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:05.561 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:05.561 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:07.559 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:07.559 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:07.559 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:07.559 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:09.595 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:09.595 DTC - Sub Instance | Failed connections: 10 | 2023-12-19 21:52:09.595 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:09.595 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:09.595 DTC Client socket (1) | Closed. | 2023-12-19 21:52:09.595 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:09.611 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:09.611 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:09.611 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:11.603 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:11.603 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:11.603 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:11.603 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:13.635 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:13.635 DTC - Sub Instance | Failed connections: 11 | 2023-12-19 21:52:13.635 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:13.635 DTC Client socket (1) | Closed. | 2023-12-19 21:52:13.635 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:13.635 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:13.651 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:13.651 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:13.651 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:15.664 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:15.664 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:15.664 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:15.664 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:17.712 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:17.712 DTC - Sub Instance | Failed connections: 12 | 2023-12-19 21:52:17.712 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:17.712 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:17.712 DTC Client socket (1) | Closed. | 2023-12-19 21:52:17.712 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:17.728 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:17.728 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:17.728 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:19.726 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:19.727 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:19.727 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:19.727 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:21.755 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:21.755 DTC - Sub Instance | Failed connections: 13 | 2023-12-19 21:52:21.755 DTC Client socket (1) | Closed. | 2023-12-19 21:52:21.755 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:21.755 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:21.755 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:21.771 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:21.771 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:21.771 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:23.759 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:23.759 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:23.759 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:23.759 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:25.801 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:25.801 DTC - Sub Instance | Failed connections: 14 | 2023-12-19 21:52:25.801 DTC Client socket (1) | Closed. | 2023-12-19 21:52:25.801 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:25.801 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:25.801 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:25.817 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:25.817 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:25.817 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:27.834 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:27.834 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:27.834 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:27.834 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:29.877 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:29.877 DTC - Sub Instance | Failed connections: 15 | 2023-12-19 21:52:29.877 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:29.877 DTC Client socket (1) | Closed. | 2023-12-19 21:52:29.877 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:29.877 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:29.893 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:29.893 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:29.893 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:31.897 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:31.898 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:31.898 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:31.898 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:33.920 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:33.920 DTC Client socket (1) | Closed. | 2023-12-19 21:52:33.920 DTC - Sub Instance | Failed connections: 16 | 2023-12-19 21:52:33.920 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:33.920 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:33.920 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:33.935 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:33.935 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:33.935 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:35.941 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:35.941 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:35.941 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:35.941 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:37.985 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:37.985 DTC - Sub Instance | Failed connections: 17 | 2023-12-19 21:52:37.985 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:37.985 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:37.985 DTC Client socket (1) | Closed. | 2023-12-19 21:52:37.985 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:38.001 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:38.001 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:38.001 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:40.012 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:40.013 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:40.013 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:40.013 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:42.053 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:42.053 DTC - Sub Instance | Failed connections: 18 | 2023-12-19 21:52:42.053 DTC Client socket (1) | Closed. | 2023-12-19 21:52:42.053 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:42.053 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:42.053 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:42.059 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:42.059 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:42.059 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:44.059 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:44.060 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:44.060 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:44.060 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:46.099 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:46.099 DTC - Sub Instance | Failed connections: 19 | 2023-12-19 21:52:46.099 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:46.099 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:46.099 DTC Client socket (1) | Closed. | 2023-12-19 21:52:46.099 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:46.115 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:46.115 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:46.115 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:48.107 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:48.108 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:48.108 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:48.108 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:50.149 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:50.150 DTC - Sub Instance | Failed connections: 20 | 2023-12-19 21:52:50.150 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:50.150 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:50.150 DTC Client socket (1) | Closed. | 2023-12-19 21:52:50.150 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:50.165 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:50.165 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:50.165 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:52.173 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:52.175 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:52.175 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:52.175 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:54.211 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:54.212 DTC - Sub Instance | Failed connections: 21 | 2023-12-19 21:52:54.212 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:54.212 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:54.212 DTC Client socket (1) | Closed. | 2023-12-19 21:52:54.212 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:54.227 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:54.227 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:54.227 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:52:56.252 DTC Client socket (1) | Creating socket. | 2023-12-19 21:52:56.252 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:52:56.252 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:52:56.252 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2023-12-19 21:52:58.289 * DTC Client socket (1) | CloseSocket call. | 2023-12-19 21:52:58.289 DTC - Sub Instance | Failed connections: 22 | 2023-12-19 21:52:58.289 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-12-19 21:52:58.289 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:58.289 DTC Client socket (1) | Closed. | 2023-12-19 21:52:58.289 DTC Client socket (0) | CloseSocket call. | 2023-12-19 21:52:58.305 DTC - Sub Instance | Disconnected. | 2023-12-19 21:52:58.305 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-19 21:52:58.305 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11098 | 2023-12-19 21:53:00.309 DTC Client socket (1) | Creating socket. | 2023-12-19 21:53:00.309 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-19 21:53:00.309 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2023-12-19 21:53:00.309 |
[2023-12-20 07:04:15] |
Sierra_Chart Engineering - Posts: 17179 |
You do not have Sierra Chart installed in the correct folder on your system. Exit all installations of Sierra Chart. Install Sierra Chart again: Software Download And let it install itself into the standard default location and do not change it. And then follow the instructions here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Updating Existing Installation of Sierra Chart with Files and Settings from Another Installation And copy the files from this folder: C:\Users\abc\Desktop\ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-20 07:05:24
