Date/Time: Wed, 27 Nov 2024 22:42:45 +0000
Charts stopped working - this happened once before
View Count: 419
[2023-04-02 22:54:39]
ErikT - Posts: 121
All my futures charts stopped updating last Thursday. I see a red error message saying historical chart download failed because of an invalid symbol, but the error message disappears from the screen before I can get a screen grab.
This happened once recently, where my charts stopped working because of some internal glitch. You were able to fix it promptly last time soon as I reported it.
I vaguely remember the solution had to do with my market data settings. I have it set to "SC Data - All Services". It used to be set for SC Order Routing service but I think you changed it for some reason.
The format of the symbols that are failing are GCM23_FUT_COMEX and CLK23_FUT_NYMEX. These normally work fine with my Denali data feed. But if I try Find Symbol now it shows me a different format like CLK23-NYMEX.
I think I am supposed to choose something other than "SC Data - All Services" in Global Settings but I'm not sure what.
Thanks in advance for your help.
[2023-04-03 01:56:47]
Sierra_Chart Engineering - Posts: 17198
Translate the symbols with Edit >> Translate Symbols to Current Service.
[2023-06-08 22:23:12]
ErikT - Posts: 121
Hi Guys,
I'd like to re-open this ticket.
Edit>>Translate Symbols to Current Service doesn't solve my problem because I make extensive use of ADD_SYMBOL studies in my charts, and the translate to current service function does not appear to update symbols stored in ADD_SYMBOL studies. Specifically, I make extensive use of "Symbol Studies" where the symbol is for an exchange-traded futures spread, such as CLZ23-CLM24.CL.FUT_SPREAD.NYMEX. Manually updating all the symbols by hand would literally take over a week, as I have many charts with dozens of studies on them.
So what I need from SC is EITHER:
1) A way to switch my entire environment back to the old symbol format so my symbol studies work; or
2) An upgrade to Translate Symbols to Current Service so that it updates symbols stored inside Add Symbol studies when it updates everything else; or
3) Some other workaround so I can get my charts working without having to spend days manually updating all the add symbol studies.
THANKS in advance!!!
Erik
[2023-06-12 08:11:40]
1.
Symbols like these are related to TT-based order routing and are no longer supported:
You need to change to the new format used by SC Data-All Services which would be:
CLZ23-CLM24.FUT_SPREAD.NYMEX
2. This is already supported but the issue relates to no translation patterns for spreads but we can give it a try to set this up for CL.
There are still manual changes you may need to make.
[2023-06-12 15:37:43]
ErikT - Posts: 121
Ok, great! Just to be clear we're on the same page, I interpret the above to mean that you will be upgrading Edit>>Translate Symbols to Current Service so that a future version at least partially translates symbols stored in additional symbol studies, but I should expect to still need to make a few manual changes to clean things up.
Please let me know when I should take another stab at this with Edit>>Translate Symbols, after downloading and installing the latest SC.
Thanks again!!!
Erik
[2023-06-20 22:53:20]
ErikT - Posts: 121
SANITY CHECK - My understanding from your last post 8 days ago is that you will be upgrading Edit>>Translate Symbols to Current Service so that it correctly updates CL spread symbols that are contained inside AddAdditionalSymbol studies, and I am waiting for you to reply when that new version is available. My charts are still not working and won't be until I find a solution to the symbol format problem.
I just wanted to make sure we're on the same page because I never thought to ask what the timeframe would be for this upgrade. If it's going to be multiple weeks, I should probably start manually updating the few charts I most urgently need to use. That will be a big job but I need the charts working in a reasonable timeframe. In the week this is pending I could have manually updated a couple of charts, but I haven't started because my understanding is you are about to give me a new version that automates this. Please let me know whether this is close to ready, and if not I'll start tackling it manually in my primary charts.
Thanks guys!
[2023-06-21 18:31:11]
We really recommend that you manually change the symbols. We are not sure when we can get to this.
[2023-06-21 18:39:23]
ErikT - Posts: 121
Ok, thanks. I understand that I'm probably the only user with this particular need.
If you do get to this at some point, it will make my life a lot easier. There's no way I can manually update all my charts. They took years to create. But I'll start manually updating my most important charts.
Thanks again guys!
[2023-06-22 10:19:25]
We were able to successfully support this for CL spreads from TT formatted spreads.
After that translate the symbols with this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service
Date Time Of Last Edit: 2023-06-23 10:05:46
[2023-06-22 17:20:34]
ErikT - Posts: 121
THANK YOU THANK YOU THANK YOU!!!
This upgrade saved me countless HOURS of work updating dozens of .CHTs. THANKS AGAIN GUYS!!!
[2023-06-23 10:05:17]
So did it actually work for you? We did a test and it does.
Date Time Of Last Edit: 2023-06-23 10:05:29
[2023-06-23 20:15:07]
ErikT - Posts: 121
YES, it worked beautifully on the first try. All my charts have updated symbol formats now. THANKS AGAIN!!!
