Date/Time: Fri, 28 Feb 2025 08:59:42 +0000
Depth data not downloading on chartbooks
View Count: 712
[2021-08-04 16:04:28]
User117347 - Posts: 46
Depth data is not downloading on my chartbooks and continues to be a problem. GC chart depth data is not opening today. At times if I have one chartbook open with depth data working, then I open the chartbook that previously did not download any depth, it will then download the depth and work. I have no idea why this is happening. It's been ongoing. Please advise asap as it a major problem.
[2021-08-04 16:51:17]
John - SC Support - Posts: 38259
The first thing we want to point out is that you are only signed up to get Real-Time data with the Market Depth for the CME and COMEX exchanges. So if you are looking at a symbol that trades on another exchange, then that would be why you are not getting the data.
But, with regards to Gold (GC) you should be getting the data, as that is on the COMEX. Go through the items at this link to see if this resolves your issue:
File Menu: Not Receiving the Full Number of Market Depth Levels
[2021-08-04 20:49:19]
The depth data issue is two-fold:
1. Some chartbooks load the depth data and others do not.
2. A chartbook that is opened on its own does not load the depth data. However, if I open another chartbook that loads the depth data and keep it open, and then I open the same chartbook that previously did not load the depth data, that chartbook will now load the depth data.
Please advise. Using GC and ES symbols
[2021-08-04 21:08:56]
Open a Chartbook that does not load the depth data. Then follow these instructions to get us your Message Log:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-08-05 01:28:36]
Are you referring to historical market depth data when using the Market Depth Historical Graph study? If so, follow the instructions here:
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
[2021-08-06 12:39:54]
Problem: Chart did not load historical depth data upon open. It loaded data only from when Chartbook was opened up.
Symbol: F.US.GCEZ21
Message Log:
Software version: 2292 64-bit | 2021-08-06 08:33:46.969
OpenGL enabled (NVIDIA Corporation/GeForce GTX 1050 Ti/PCIe/SSE2) | 2021-08-06 08:33:46.975
Primary Thread ID: 10708 | 2021-08-06 08:33:46.975
Usage end date: 2021-08-26 | 2021-08-06 08:33:46.975
Enabled for: Advanced Features 2. | 2021-08-06 08:33:46.975
Enabled for: Sierra Chart Historical Data Service. | 2021-08-06 08:33:46.975
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-08-06 08:33:46.975
Enabled for: Delayed Denali Exchange Data Feed. | 2021-08-06 08:33:46.975
Enabled for exchange2: CME | 2021-08-06 08:33:46.975
Enabled for exchange2: COMEX | 2021-08-06 08:33:46.975
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-08-06 08:33:46.975
Current selected Data/Trading service: CQG WebAPI | 2021-08-06 08:33:46.975
Custom symbol settings values: enabled | 2021-08-06 08:33:46.975
Chart Update Interval: 100 | 2021-08-06 08:33:46.975
Intraday Data Storage Time Unit: 0 | 2021-08-06 08:33:46.975
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-08-06 08:33:46.975
2021-08-06 12:33:46 Local computer time in UTC | 2021-08-06 08:33:46.975
2021-08-06 08:33:46 Local computer time in SC Time Zone | 2021-08-06 08:33:46.975
2021-08-05 10:01:24 Server time in UTC | 2021-08-06 08:33:46.975
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-08-06 08:33:46.975
Program path: C:\SierraChart\ | 2021-08-06 08:33:46.975
Data Files path: C:\SierraChart\Data\ | 2021-08-06 08:33:46.975
OS Version Number: 10.0 | 2021-08-06 08:33:46.975
Locale Setting: C | 2021-08-06 08:33:46.975
DLLs: sst_ateam_2151_64.dll, sst_ateam_64.dll, SST_ATEAM_RX_2151_64.dll, SST_ATEAM_RX_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-08-06 08:33:46.976
Allowed protected custom studies: SST_ATEAM, SST_ATEAM_PS | 2021-08-06 08:33:46.976
File >> Disconnect selected. | 2021-08-06 08:34:55.474
CQG WebAPI | Sending Web API Logoff message. | 2021-08-06 08:34:55.498
CQG WebSocket socket (3) | CloseSocket call. | 2021-08-06 08:34:55.498
CQG WebSocket socket (3) | Max send buffers used during socket life: 3 | 2021-08-06 08:34:55.498
CQG WebSocket socket (3) | Max send buffer size during socket life: 309 | 2021-08-06 08:34:55.498
CQG WebSocket | WebSocket closed. | 2021-08-06 08:34:55.498
CQG WebAPI | WebSocket closed. | 2021-08-06 08:34:55.498
CQG WebSocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-08-06 08:34:55.498
SC Data - All Services | Waiting for socket receive thread to end | 2021-08-06 08:34:55.500
DTC Client socket (5) | CloseSocket call. | 2021-08-06 08:34:55.500
DTC Client socket (5) | Max send buffers used during socket life: 3 | 2021-08-06 08:34:55.500
DTC Client socket (5) | Max send buffer size during socket life: 353 | 2021-08-06 08:34:55.500
DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:34:55.500
SC Data - All Services | Disconnected from the server. | 2021-08-06 08:34:55.502
CQG WebAPI | Disconnected. | 2021-08-06 08:34:55.502
CQG WebSocket socket (3) | Write has completed. Shutdown being performed. | 2021-08-06 08:34:55.571
CQG WebSocket socket (3) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:34:55.571
CQG WebAPI | Connecting to server api.cqg.com | 2021-08-06 08:35:47.015
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-08-06 08:35:47.015
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-08-06 08:35:47.153
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-08-06 08:35:47.153
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2021-08-06 08:35:47.153
CQG WebSocket | Opening WebSocket. | 2021-08-06 08:35:47.249
CQG WebSocket | Sending WebSocket handshake. | 2021-08-06 08:35:47.249
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-08-06 08:35:47.468
CQG WebSocket | Server header | Connection: upgrade | 2021-08-06 08:35:47.469
CQG WebSocket | Server header | Sec-WebSocket-Accept: +lIrRZBJ6vnTCRKJjLBs+dg4Tas= | 2021-08-06 08:35:47.469
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-08-06 08:35:47.469
CQG WebSocket | Server header | Upgrade: websocket | 2021-08-06 08:35:47.469
CQG WebSocket | Server header | | 2021-08-06 08:35:47.469
CQG WebSocket | Web socket state is now open. | 2021-08-06 08:35:47.469
CQG WebAPI | WebSocket connected. | 2021-08-06 08:35:47.469
CQG WebAPI | Sending market data logon message. | 2021-08-06 08:35:47.469
CQG WebAPI | Base Time: 2021-07-25T21:21:50. 2021-07-25 21:21:50 | 2021-08-06 08:35:47.658
CQG WebAPI | Logon successful. Session Token = Pp/YG0x2UX0vaK5OILAdbTk2RjMp0HPKz6n8KISbQ2UahI1VX+K1kpctXfadBgbTGrTonhzm1Tm | 2021-08-06 08:35:47.658
CQG WebAPI | Connected to server complete. | 2021-08-06 08:35:47.658
Triggering next historical data download in queue. | 2021-08-06 08:35:47.659
Updated verified funded futures trading account ending date to: 2021-09-05 12:35:47 | 2021-08-06 08:35:47.659
CQG WebAPI | Sending Trade Accounts request message. | 2021-08-06 08:35:47.682
No download requests in the queue to start downloads for. | 2021-08-06 08:35:47.682
Mapping F.US.MGCZ21 to MGCZ21. Service code: comex | 2021-08-06 08:35:47.700
SC Data - All Services | Starting real-time market data updates for: F.US.MGCZ21 (MGCZ21). ID: 1 Service code: comex | 2021-08-06 08:35:47.700
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-08-06 08:35:47.700
CQG WebAPI | Sending symbol resolution request for F.US.MGCZ21. ID: 249187 | 2021-08-06 08:35:47.700
SC Data - All Services | Requesting security definition data for: F.US.MGCZ21 (MGCZ21). ID: 1 | 2021-08-06 08:35:47.700
Requesting market depth updates for: F.US.MGCZ21 if supported. | 2021-08-06 08:35:47.700
Separate subscription for market depth updates not supported. F.US.MGCZ21 | 2021-08-06 08:35:47.700
Mapping F.US.GCEZ21 to GCZ21. Service code: comex | 2021-08-06 08:35:47.700
SC Data - All Services | Starting real-time market data updates for: F.US.GCEZ21 (GCZ21). ID: 2 Service code: comex | 2021-08-06 08:35:47.700
CQG WebAPI | Sending symbol resolution request for F.US.GCEZ21. ID: 249188 | 2021-08-06 08:35:47.700
SC Data - All Services | Requesting security definition data for: F.US.GCEZ21 (GCZ21). ID: 2 | 2021-08-06 08:35:47.700
Added historical Intraday data request for F.US.GCEZ21 to the queue. | 2021-08-06 08:35:47.700
Intraday data recording state for symbol F.US.GCEZ21 is set to download 'Pending'. | 2021-08-06 08:35:47.700
Triggering next historical data download in queue. | 2021-08-06 08:35:47.700
DTC Client socket (2) | Creating socket. | 2021-08-06 08:35:47.701
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-08-06 08:35:47.701
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2021-08-06 08:35:47.701
Delaying start of download for F.US.GCEZ21 | 2021-08-06 08:35:47.736
SC Data - All Services | Network connection to server complete. | 2021-08-06 08:35:47.811
SC Data - All Services | Starting socket receive thread. | 2021-08-06 08:35:47.811
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2021-08-06 08:35:47.811
CQG WebAPI | Received symbol resolution report for symbol F.US.MGCZ21. Search Symbol: F.US.MGCZ21. Request ID: 249187. Contract ID: 1. | 2021-08-06 08:35:47.811
CQG WebAPI | Brokerage name: AMP. Account Name: 93956 | 2021-08-06 08:35:47.811
Updated verified funded futures trading account ending date to: 2021-09-05 12:35:47 | 2021-08-06 08:35:47.811
CQG WebAPI | Sending collateral subscribe request. | 2021-08-06 08:35:47.811
CQG WebAPI | Received symbol resolution report for symbol F.US.GCEZ21. Search Symbol: F.US.GCEZ21. Request ID: 249188. Contract ID: 2. | 2021-08-06 08:35:47.812
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-08-06 08:35:47.906
SC Data - All Services | Sending logon request message. | 2021-08-06 08:35:47.906
Requesting market depth updates for: F.US.GCEZ21 if supported. | 2021-08-06 08:35:48.265
Separate subscription for market depth updates not supported. F.US.GCEZ21 | 2021-08-06 08:35:48.265
SC Data - All Services | Received logon response. | 2021-08-06 08:35:48.716
SC Data - All Services | Server Name: SC Realtime Server. | 2021-08-06 08:35:48.716
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-08-06 08:35:48.716
SC Data - All Services | Successfully connected. | 2021-08-06 08:35:48.716
SC Data - All Services | Trading is not supported. | 2021-08-06 08:35:48.716
Added historical Market depth data request for F.US.GCEZ21 to the queue. | 2021-08-06 08:35:48.716
Market depth data recording state for symbol F.US.GCEZ21 is set to download 'Pending'. | 2021-08-06 08:35:48.716
Triggering next historical data download in queue. | 2021-08-06 08:35:48.716
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEZ21 -> GCZ21. Market Depth data restarted. | 2021-08-06 08:35:48.716
Added historical Market depth data request for F.US.MGCZ21 to the queue. | 2021-08-06 08:35:48.716
Market depth data recording state for symbol F.US.MGCZ21 is set to download 'Pending'. | 2021-08-06 08:35:48.717
SC Data - All Services | Restarting real-time data updates for symbol: F.US.MGCZ21 -> MGCZ21. Market Depth data restarted. | 2021-08-06 08:35:48.717
HD Request # 29 | Downloading market depth chart data for F.US.GCEZ21. Service: comex.marketdepth | 2021-08-06 08:35:48.717
HD Request # 29 | Download start date-time: 2021-08-06 08:34:55.499796. | 2021-08-06 08:35:48.722
HD Request # 29 | Using server: ds23.sierracharts.com port 10149 | 2021-08-06 08:35:48.722
Socket (4) | Creating socket. | 2021-08-06 08:35:48.722
Socket (4) | New receive buffer size: 5242880 | 2021-08-06 08:35:48.722
Socket (4) | Connecting to IP: 216.1.90.130. | 2021-08-06 08:35:48.722
HD Request # 29 | Setting DTC encoding to Binary VLS | 2021-08-06 08:35:48.860
HD Request # 29 | Sending historical data logon request message. | 2021-08-06 08:35:48.860
SC Data - All Services | Clearing market depth for F.US.GCEZ21 | 2021-08-06 08:35:48.932
SC Data - All Services | Clearing market depth for F.US.MGCZ21 | 2021-08-06 08:35:48.933
SC Data - All Services | Received security definition for symbol F.US.GCEZ21 | 2021-08-06 08:35:49.018
SC Data - All Services | Received security definition for symbol F.US.MGCZ21 | 2021-08-06 08:35:49.018
HD Request # 29 | Requesting market depth data. Start date-time: 2021-08-06 08:34:55. Symbol: GCZ21 | 2021-08-06 08:35:49.378
HD Request # 29 | Decompressing data. | 2021-08-06 08:35:49.441
HD Request # 29 | Receiving market depth data for F.US.GCEZ21 starting at 2021-08-06 08:34:55.544000 | 2021-08-06 08:35:49.592
Socket (4) | CloseSocket call. | 2021-08-06 08:35:49.657
Socket (4) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:35:49.658
Historical data download thread signaled to stop. | 2021-08-06 08:35:49.710
HD Request # 29 | Timestamp of first market depth data file record written: 2021-08-06 08:34:55.544000 | 2021-08-06 08:35:49.711
HD Request # 29 | Received 13552 Market depth data records from 2021-08-06 08:34:55.544000 to 2021-08-06 08:35:45.636000 (50.1 seconds) and wrote 13552 records for F.US.GCEZ21 | 2021-08-06 08:35:49.711
HD Request # 29 | Completion time: 1s | 2021-08-06 08:35:49.711
HD Request # 29 | Market depth data download complete for F.US.GCEZ21. Unique request ID: 28 | 2021-08-06 08:35:49.711
Removing historical data download ID 28. | 2021-08-06 08:35:49.711
Real-time market depth file updates started for F.US.GCEZ21 | 2021-08-06 08:35:49.711
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.GCEZ21.2021-08-06.depth | 2021-08-06 08:35:49.717
Triggering next historical data download in queue. | 2021-08-06 08:35:49.717
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.GCEZ21.2021-08-06.depth | 2021-08-06 08:35:49.722
HD Request # 30 | Downloading market depth chart data for F.US.MGCZ21. Service: comex.marketdepth | 2021-08-06 08:35:49.722
Socket (4) | Socket gracefully closed by remote side. | 2021-08-06 08:35:49.727
Socket (4) | Closed. | 2021-08-06 08:35:49.727
HD Request # 30 | Download start date-time: 2021-08-06 08:34:55.499502. | 2021-08-06 08:35:49.727
HD Request # 30 | Using server: ds21.sierracharts.com port 10150 | 2021-08-06 08:35:49.727
Socket (4) | Creating socket. | 2021-08-06 08:35:49.728
Socket (4) | New receive buffer size: 5242880 | 2021-08-06 08:35:49.728
Socket (4) | Connecting to IP: 216.1.90.129. | 2021-08-06 08:35:49.728
HD Request # 30 | Setting DTC encoding to Binary VLS | 2021-08-06 08:35:49.867
HD Request # 30 | Sending historical data logon request message. | 2021-08-06 08:35:49.867
HD Request # 30 | Requesting market depth data. Start date-time: 2021-08-06 08:34:55. Symbol: MGCZ21 | 2021-08-06 08:35:50.384
HD Request # 30 | Decompressing data. | 2021-08-06 08:35:50.447
HD Request # 30 | Receiving market depth data for F.US.MGCZ21 starting at 2021-08-06 08:34:55.544000 | 2021-08-06 08:35:50.591
Socket (4) | CloseSocket call. | 2021-08-06 08:35:50.664
Socket (4) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:35:50.664
Historical data download thread signaled to stop. | 2021-08-06 08:35:50.711
HD Request # 30 | Timestamp of first market depth data file record written: 2021-08-06 08:34:55.544000 | 2021-08-06 08:35:50.712
HD Request # 30 | Received 16033 Market depth data records from 2021-08-06 08:34:55.544000 to 2021-08-06 08:35:47.264000 (51.7 seconds) and wrote 16033 records for F.US.MGCZ21 | 2021-08-06 08:35:50.712
HD Request # 30 | Completion time: 1s | 2021-08-06 08:35:50.712
HD Request # 30 | Market depth data download complete for F.US.MGCZ21. Unique request ID: 29 | 2021-08-06 08:35:50.712
Removing historical data download ID 29. | 2021-08-06 08:35:50.712
Real-time market depth file updates started for F.US.MGCZ21 | 2021-08-06 08:35:50.712
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.MGCZ21.2021-08-06.depth | 2021-08-06 08:35:50.717
Triggering next historical data download in queue. | 2021-08-06 08:35:50.717
No download requests in the queue to start downloads for. | 2021-08-06 08:35:50.717
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.MGCZ21.2021-08-06.depth | 2021-08-06 08:35:50.722
Socket (4) | Socket gracefully closed by remote side. | 2021-08-06 08:35:50.730
Socket (4) | Closed. | 2021-08-06 08:35:50.730
CQG WebAPI | Sending positions subscribe request. RequestID: 249190 | 2021-08-06 08:35:52.993
CQG WebAPI | Sending orders subscribe request. RequestID: 249191 | 2021-08-06 08:35:52.993
HD Request # 31 | Downloading Intraday chart data for F.US.GCEZ21 to the file F.US.GCEZ21.scid. Service: comex | 2021-08-06 08:35:54.112
HD Request # 31 | Download start date-time: 2021-08-06 08:34:55.000000. File last date-time: 2021-08-06 08:34:55.368005 | 2021-08-06 08:35:54.112
HD Request # 31 | Using server: ds23.sierracharts.com port 10150 | 2021-08-06 08:35:54.112
Socket (4) | Creating socket. | 2021-08-06 08:35:54.113
Socket (4) | New receive buffer size: 5242880 | 2021-08-06 08:35:54.113
Socket (4) | Connecting to IP: 216.1.90.130. | 2021-08-06 08:35:54.113
HD Request # 31 | Setting DTC encoding to Binary VLS | 2021-08-06 08:35:54.267
HD Request # 31 | Sending historical data logon request message. | 2021-08-06 08:35:54.267
HD Request # 31 | Requesting Intraday data. Start date-time: 2021-08-06 08:34:55. Record interval: 0. Symbol: GCZ21 | 2021-08-06 08:35:54.788
HD Request # 31 | Decompressing data. | 2021-08-06 08:35:54.851
HD Request # 31 | Receiving Intraday data for F.US.GCEZ21 starting at 2021-08-06 08:34:55.050000 | 2021-08-06 08:35:54.930
Socket (4) | CloseSocket call. | 2021-08-06 08:35:54.931
Socket (4) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:35:54.931
Historical data download thread signaled to stop. | 2021-08-06 08:35:54.969
HD Request # 31 | Timestamp of first Intraday data file record written: 2021-08-06 08:34:55.609000 | 2021-08-06 08:35:54.969
HD Request # 31 | Received 1315 Intraday data records from 2021-08-06 08:34:55.050000 to 2021-08-06 08:35:54.174002 (59.1 seconds) and wrote 1294 records for F.US.GCEZ21 | 2021-08-06 08:35:54.969
HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2021-08-06 12:35:54.174002 | 2021-08-06 08:35:54.974
Added 4 Time and Sales records to Intraday data file for F.US.GCEZ21 after download. | 2021-08-06 08:35:54.974
HD Request # 31 | Completion time: 0s | 2021-08-06 08:35:54.974
HD Request # 31 | Intraday data download complete for F.US.GCEZ21. Unique request ID: 27 | 2021-08-06 08:35:54.974
Removing historical data download ID 27. | 2021-08-06 08:35:54.974
Real-time Intraday chart data file updates started for F.US.GCEZ21 | 2021-08-06 08:35:54.974
Intraday chart data file opened for F.US.GCEZ21 | 2021-08-06 08:35:54.974
HD Request # 31 | Enabling Intraday chart updating for symbol. | 2021-08-06 08:35:54.974
Triggering next historical data download in queue. | 2021-08-06 08:35:54.974
No download requests in the queue to start downloads for. | 2021-08-06 08:35:54.974
Socket (4) | Socket gracefully closed by remote side. | 2021-08-06 08:35:55.000
Socket (4) | Closed. | 2021-08-06 08:35:55.000
Chart #4 has tagged chart #2 for full recalculation. Chartbook: updated__gold_5-26-21.Cht | 2021-08-06 08:35:55.419
Chart #4 has tagged chart #5 for full recalculation. Chartbook: updated__gold_5-26-21.Cht | 2021-08-06 08:35:55.419
Chart #4 has tagged chart #6 for full recalculation. Chartbook: updated__gold_5-26-21.Cht | 2021-08-06 08:35:55.419
F.US.GCEZ21[M]/F.US.MGCZ21[M] 500 Trades #2 | Performing a full recalculation because it has been tagged. Chartbook: updated__gold_5-26-21.Cht | 2021-08-06 08:35:55.469
F.US.GCEZ21[M] 10 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: updated__gold_5-26-21.Cht | 2021-08-06 08:35:55.645
Chart: F.US.GCEZ21[M] 10 Sec #6 | Study: A-Team Trade Management Study V3 | Your Autotrading Global and Chart will need to be enabled for the study to work. | 2021-08-06 08:35:56.215
F.US.GCEZ21[M] 10 Sec #5 | Performing a full recalculation because it has been tagged. Chartbook: updated__gold_5-26-21.Cht | 2021-08-06 08:35:56.330
Chart: F.US.GCEZ21[M] 10 Sec #5 | Study: A-Team Trade Management Study V3 | Your Autotrading Global and Chart will need to be enabled for the study to work. | 2021-08-06 08:35:56.903
Opened cached Intraday file: C:\SierraChart\Data\F.US.GCEZ21.scid. Thread ID: 16024 | 2021-08-06 08:35:58.024
[2021-08-06 12:51:24]
Problem: Depth data did not load when chartbook was opened.
Symbol: F.US.EPU21
Message Log:
Software version: 2292 64-bit | 2021-08-06 08:46:57.972
OpenGL enabled (NVIDIA Corporation/GeForce GTX 1050 Ti/PCIe/SSE2) | 2021-08-06 08:46:57.977
Primary Thread ID: 10708 | 2021-08-06 08:46:57.977
Usage end date: 2021-08-26 | 2021-08-06 08:46:57.977
Enabled for: Advanced Features 2. | 2021-08-06 08:46:57.977
Enabled for: Sierra Chart Historical Data Service. | 2021-08-06 08:46:57.977
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-08-06 08:46:57.977
Enabled for: Delayed Denali Exchange Data Feed. | 2021-08-06 08:46:57.977
Enabled for exchange2: CME | 2021-08-06 08:46:57.977
Enabled for exchange2: COMEX | 2021-08-06 08:46:57.977
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-08-06 08:46:57.977
Current selected Data/Trading service: CQG WebAPI | 2021-08-06 08:46:57.977
Custom symbol settings values: enabled | 2021-08-06 08:46:57.977
Chart Update Interval: 100 | 2021-08-06 08:46:57.977
Intraday Data Storage Time Unit: 0 | 2021-08-06 08:46:57.977
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-08-06 08:46:57.977
2021-08-06 12:46:57 Local computer time in UTC | 2021-08-06 08:46:57.977
2021-08-06 08:46:57 Local computer time in SC Time Zone | 2021-08-06 08:46:57.977
2021-08-05 10:01:24 Server time in UTC | 2021-08-06 08:46:57.977
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-08-06 08:46:57.977
Program path: C:\SierraChart\ | 2021-08-06 08:46:57.977
Data Files path: C:\SierraChart\Data\ | 2021-08-06 08:46:57.977
OS Version Number: 10.0 | 2021-08-06 08:46:57.978
Locale Setting: C | 2021-08-06 08:46:57.978
DLLs: sst_ateam_2151_64.dll, sst_ateam_64.dll, SST_ATEAM_RX_2151_64.dll, SST_ATEAM_RX_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-08-06 08:46:57.978
Allowed protected custom studies: SST_ATEAM, SST_ATEAM_PS | 2021-08-06 08:46:57.978
File >> Disconnect selected. | 2021-08-06 08:48:11.639
CQG WebAPI | Sending Web API Logoff message. | 2021-08-06 08:48:11.685
CQG WebSocket socket (3) | CloseSocket call. | 2021-08-06 08:48:11.685
CQG WebSocket | WebSocket closed. | 2021-08-06 08:48:11.685
CQG WebAPI | WebSocket closed. | 2021-08-06 08:48:11.685
CQG WebSocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-08-06 08:48:11.685
SC Data - All Services | Waiting for socket receive thread to end | 2021-08-06 08:48:11.686
DTC Client socket (4) | CloseSocket call. | 2021-08-06 08:48:11.686
DTC Client socket (4) | Max send buffers used during socket life: 3 | 2021-08-06 08:48:11.686
DTC Client socket (4) | Max send buffer size during socket life: 315 | 2021-08-06 08:48:11.686
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:48:11.686
SC Data - All Services | Disconnected from the server. | 2021-08-06 08:48:11.686
CQG WebAPI | Disconnected. | 2021-08-06 08:48:11.686
CQG WebSocket socket (3) | Write has completed. Shutdown being performed. | 2021-08-06 08:48:11.756
CQG WebSocket socket (3) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:48:11.756
CQG WebAPI | Connecting to server api.cqg.com | 2021-08-06 08:49:00.474
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-08-06 08:49:00.474
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-08-06 08:49:00.497
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-08-06 08:49:00.497
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2021-08-06 08:49:00.497
CQG WebSocket | Opening WebSocket. | 2021-08-06 08:49:00.659
CQG WebSocket | Sending WebSocket handshake. | 2021-08-06 08:49:00.659
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-08-06 08:49:00.893
CQG WebSocket | Server header | Connection: upgrade | 2021-08-06 08:49:00.893
CQG WebSocket | Server header | Sec-WebSocket-Accept: /I1nPGLYo1scwZ5dM7Mklv23XNs= | 2021-08-06 08:49:00.893
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-08-06 08:49:00.893
CQG WebSocket | Server header | Upgrade: websocket | 2021-08-06 08:49:00.893
CQG WebSocket | Server header | | 2021-08-06 08:49:00.893
CQG WebSocket | Web socket state is now open. | 2021-08-06 08:49:00.893
CQG WebAPI | WebSocket connected. | 2021-08-06 08:49:00.893
CQG WebAPI | Sending market data logon message. | 2021-08-06 08:49:00.893
CQG WebAPI | Base Time: 2021-07-25T21:21:50. 2021-07-25 21:21:50 | 2021-08-06 08:49:01.192
CQG WebAPI | Logon successful. Session Token = ofdFRHSwrxmXgTJ8Tfa+5PHB9H9IpoltHtOUqzSzwbsOfpqzKu+jCbhsCRh1Pxr3n/EqVWLUyE5 | 2021-08-06 08:49:01.192
CQG WebAPI | Connected to server complete. | 2021-08-06 08:49:01.192
Triggering next historical data download in queue. | 2021-08-06 08:49:01.193
Updated verified funded futures trading account ending date to: 2021-09-05 12:49:01 | 2021-08-06 08:49:01.193
CQG WebAPI | Sending Trade Accounts request message. | 2021-08-06 08:49:01.239
No download requests in the queue to start downloads for. | 2021-08-06 08:49:01.239
Mapping F.US.MESU21 to MESU21. Service code: cme | 2021-08-06 08:49:01.240
SC Data - All Services | Starting real-time market data updates for: F.US.MESU21 (MESU21). ID: 1 Service code: cme | 2021-08-06 08:49:01.240
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2021-08-06 08:49:01.240
CQG WebAPI | Sending symbol resolution request for F.US.MESU21. ID: 249201 | 2021-08-06 08:49:01.241
SC Data - All Services | Requesting security definition data for: F.US.MESU21 (MESU21). ID: 1 | 2021-08-06 08:49:01.241
Requesting market depth updates for: F.US.MESU21 if supported. | 2021-08-06 08:49:01.241
Separate subscription for market depth updates not supported. F.US.MESU21 | 2021-08-06 08:49:01.241
Mapping F.US.EPU21 to ESU21. Service code: cme | 2021-08-06 08:49:01.241
SC Data - All Services | Starting real-time market data updates for: F.US.EPU21 (ESU21). ID: 2 Service code: cme | 2021-08-06 08:49:01.241
CQG WebAPI | Sending symbol resolution request for F.US.EPU21. ID: 249202 | 2021-08-06 08:49:01.241
SC Data - All Services | Requesting security definition data for: F.US.EPU21 (ESU21). ID: 2 | 2021-08-06 08:49:01.241
Added historical Intraday data request for F.US.EPU21 to the queue. | 2021-08-06 08:49:01.241
Intraday data recording state for symbol F.US.EPU21 is set to download 'Pending'. | 2021-08-06 08:49:01.241
Triggering next historical data download in queue. | 2021-08-06 08:49:01.241
DTC Client socket (2) | Creating socket. | 2021-08-06 08:49:01.270
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-08-06 08:49:01.270
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2021-08-06 08:49:01.270
Delaying start of download for F.US.EPU21 | 2021-08-06 08:49:01.294
CQG WebAPI | Received symbol resolution report for symbol F.US.MESU21. Search Symbol: F.US.MESU21. Request ID: 249201. Contract ID: 1. | 2021-08-06 08:49:01.391
CQG WebAPI | Brokerage name: AMP. Account Name: 93956 | 2021-08-06 08:49:01.391
Updated verified funded futures trading account ending date to: 2021-09-05 12:49:01 | 2021-08-06 08:49:01.391
CQG WebAPI | Sending collateral subscribe request. | 2021-08-06 08:49:01.391
SC Data - All Services | Network connection to server complete. | 2021-08-06 08:49:01.391
SC Data - All Services | Starting socket receive thread. | 2021-08-06 08:49:01.391
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2021-08-06 08:49:01.392
CQG WebAPI | Received symbol resolution report for symbol F.US.EPU21. Search Symbol: F.US.EPU21. Request ID: 249202. Contract ID: 2. | 2021-08-06 08:49:01.392
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-08-06 08:49:01.720
SC Data - All Services | Sending logon request message. | 2021-08-06 08:49:01.720
Mapping F.US.EPZ20 to ESZ20. Service code: cme | 2021-08-06 08:49:01.774
SC Data - All Services | Starting real-time market data updates for: F.US.EPZ20 (ESZ20). ID: 3 Service code: cme | 2021-08-06 08:49:01.774
CQG WebAPI | Sending symbol resolution request for F.US.EPZ20. ID: 249204 | 2021-08-06 08:49:01.774
SC Data - All Services | Requesting security definition data for: F.US.EPZ20 (ESZ20). ID: 3 | 2021-08-06 08:49:01.774
Requesting market depth updates for: F.US.EPZ20 if supported. | 2021-08-06 08:49:01.774
Separate subscription for market depth updates not supported. F.US.EPZ20 | 2021-08-06 08:49:01.774
Added historical Intraday data request for F.US.EPZ20 to the queue. | 2021-08-06 08:49:01.774
Intraday data recording state for symbol F.US.EPZ20 is set to download 'Pending'. | 2021-08-06 08:49:01.774
Triggering next historical data download in queue. | 2021-08-06 08:49:01.774
Mapping F.US.MSFU21 to MSFU21. Service code: cme | 2021-08-06 08:49:01.780
SC Data - All Services | Starting real-time market data updates for: F.US.MSFU21 (MSFU21). ID: 4 Service code: cme | 2021-08-06 08:49:01.780
CQG WebAPI | Sending symbol resolution request for F.US.MSFU21. ID: 249205 | 2021-08-06 08:49:01.780
SC Data - All Services | Requesting security definition data for: F.US.MSFU21 (MSFU21). ID: 4 | 2021-08-06 08:49:01.780
CQG WebAPI | Received symbol resolution report for symbol F.US.MSFU21. Search Symbol: F.US.MSFU21. Request ID: 249205. Contract ID: 3. | 2021-08-06 08:49:01.868
CQG WebAPI | Received message: Requested symbol was not found. | 2021-08-06 08:49:01.868
Symbol Error - F.US.EPZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-08-06 08:49:01.868
SC Data - All Services | Received logon response. | 2021-08-06 08:49:02.649
SC Data - All Services | Server Name: SC Realtime Server. | 2021-08-06 08:49:02.649
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-08-06 08:49:02.649
SC Data - All Services | Successfully connected. | 2021-08-06 08:49:02.649
SC Data - All Services | Trading is not supported. | 2021-08-06 08:49:02.649
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPU21 -> ESU21 | 2021-08-06 08:49:02.649
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPZ20 -> ESZ20 | 2021-08-06 08:49:02.649
Added historical Market depth data request for F.US.MESU21 to the queue. | 2021-08-06 08:49:02.649
Market depth data recording state for symbol F.US.MESU21 is set to download 'Pending'. | 2021-08-06 08:49:02.649
Triggering next historical data download in queue. | 2021-08-06 08:49:02.649
SC Data - All Services | Restarting real-time data updates for symbol: F.US.MESU21 -> MESU21. Market Depth data restarted. | 2021-08-06 08:49:02.649
SC Data - All Services | Restarting real-time data updates for symbol: F.US.MSFU21 -> MSFU21 | 2021-08-06 08:49:02.649
HD Request # 36 | Downloading market depth chart data for F.US.MESU21. Service: cme.marketdepth | 2021-08-06 08:49:02.649
HD Request # 36 | Download start date-time: 2021-08-06 08:48:11.685626. | 2021-08-06 08:49:02.655
HD Request # 36 | Using server: ds23.sierracharts.com port 10149 | 2021-08-06 08:49:02.655
Socket (5) | Creating socket. | 2021-08-06 08:49:02.655
Socket (5) | New receive buffer size: 5242880 | 2021-08-06 08:49:02.655
Socket (5) | Connecting to IP: 216.1.90.130. | 2021-08-06 08:49:02.655
HD Request # 36 | Setting DTC encoding to Binary VLS | 2021-08-06 08:49:02.799
HD Request # 36 | Sending historical data logon request message. | 2021-08-06 08:49:02.799
Added historical Market depth data request for F.US.EPZ20 to the queue. | 2021-08-06 08:49:02.992
Market depth data recording state for symbol F.US.EPZ20 is set to download 'Pending'. | 2021-08-06 08:49:02.992
Triggering next historical data download in queue. | 2021-08-06 08:49:02.992
SC Data - All Services | Clearing market depth for F.US.MESU21 | 2021-08-06 08:49:02.992
SC Data - All Services | Received security definition for symbol F.US.EPU21 | 2021-08-06 08:49:03.091
SC Data - All Services | Real-time data for symbol F.US.EPZ20 is currently unavailable. | 2021-08-06 08:49:03.091
SC Data - All Services | Received security definition for symbol F.US.EPZ20 | 2021-08-06 08:49:03.091
SC Data - All Services | Received security definition for symbol F.US.MESU21 | 2021-08-06 08:49:03.091
SC Data - All Services | Received security definition for symbol F.US.MSFU21 | 2021-08-06 08:49:03.091
HD Request # 36 | Requesting market depth data. Start date-time: 2021-08-06 08:48:11. Symbol: MESU21 | 2021-08-06 08:49:03.318
HD Request # 36 | Decompressing data. | 2021-08-06 08:49:03.379
HD Request # 36 | Receiving market depth data for F.US.MESU21 starting at 2021-08-06 08:48:11.745000 | 2021-08-06 08:49:03.518
Socket (5) | CloseSocket call. | 2021-08-06 08:49:03.522
Socket (5) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:49:03.522
Historical data download thread signaled to stop. | 2021-08-06 08:49:03.577
HD Request # 36 | Timestamp of first market depth data file record written: 2021-08-06 08:48:11.745000 | 2021-08-06 08:49:03.577
HD Request # 36 | Received 5798 Market depth data records from 2021-08-06 08:48:11.745000 to 2021-08-06 08:49:01.956000 (50.2 seconds) and wrote 5798 records for F.US.MESU21 | 2021-08-06 08:49:03.577
HD Request # 36 | Completion time: 1s | 2021-08-06 08:49:03.577
HD Request # 36 | Market depth data download complete for F.US.MESU21. Unique request ID: 36 | 2021-08-06 08:49:03.577
Removing historical data download ID 36. | 2021-08-06 08:49:03.577
Real-time market depth file updates started for F.US.MESU21 | 2021-08-06 08:49:03.577
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.MESU21.2021-08-06.depth | 2021-08-06 08:49:03.584
Triggering next historical data download in queue. | 2021-08-06 08:49:03.585
HD Request # 37 | Downloading market depth chart data for F.US.EPZ20. Service: cme.marketdepth | 2021-08-06 08:49:03.585
Socket (5) | Socket gracefully closed by remote side. | 2021-08-06 08:49:03.589
Socket (5) | Closed. | 2021-08-06 08:49:03.589
HD Request # 37 | Download start date-time: 2021-08-06 08:48:11.686014. | 2021-08-06 08:49:03.590
HD Request # 37 | Using server: ds21.sierracharts.com port 10150 | 2021-08-06 08:49:03.590
Socket (5) | Creating socket. | 2021-08-06 08:49:03.590
Socket (5) | New receive buffer size: 5242880 | 2021-08-06 08:49:03.590
Socket (5) | Connecting to IP: 216.1.90.129. | 2021-08-06 08:49:03.590
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.MESU21.2021-08-06.depth | 2021-08-06 08:49:03.596
HD Request # 37 | Setting DTC encoding to Binary VLS | 2021-08-06 08:49:03.726
HD Request # 37 | Sending historical data logon request message. | 2021-08-06 08:49:03.726
HD Request # 37 | Requesting market depth data. Start date-time: 2021-08-06 08:48:11. Symbol: ESZ20 | 2021-08-06 08:49:04.245
Socket (5) | CloseSocket call. | 2021-08-06 08:49:04.309
Socket (5) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:49:04.309
HD Request # 37 | Error downloading historical Market Depth data for F.US.EPZ20. No market depth data files found. Path: I:\CME_Data\MarketDepthData/ | 2021-08-06 08:49:04.319
Historical data download thread signaled to stop. | 2021-08-06 08:49:04.319
HD Request # 37 | Received 0 Market depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.EPZ20 | 2021-08-06 08:49:04.319
HD Request # 37 | Completion time: 1s | 2021-08-06 08:49:04.319
HD Request # 37 | Market depth data download complete for F.US.EPZ20. Unique request ID: 37 | 2021-08-06 08:49:04.319
Removing historical data download ID 37. | 2021-08-06 08:49:04.319
Real-time market depth file updates started for F.US.EPZ20 | 2021-08-06 08:49:04.319
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.EPZ20.2021-08-06.depth | 2021-08-06 08:49:04.320
Triggering next historical data download in queue. | 2021-08-06 08:49:04.320
No download requests in the queue to start downloads for. | 2021-08-06 08:49:04.320
Socket (5) | Socket gracefully closed by remote side. | 2021-08-06 08:49:04.370
Socket (5) | Closed. | 2021-08-06 08:49:04.370
CQG WebAPI | Sending positions subscribe request. RequestID: 249206 | 2021-08-06 08:49:06.816
CQG WebAPI | Sending orders subscribe request. RequestID: 249207 | 2021-08-06 08:49:06.816
Requesting market depth updates for: F.US.MSFU21 if supported. | 2021-08-06 08:49:06.816
SC Data - All Services | Clearing market depth for F.US.MSFU21 | 2021-08-06 08:49:07.047
HD Request # 38 | Downloading Intraday chart data for F.US.EPU21 to the file F.US.EPU21.scid. Service: cme | 2021-08-06 08:49:07.333
HD Request # 38 | Download start date-time: 2021-08-06 08:48:10.000000. File last date-time: 2021-08-06 08:48:10.268000 | 2021-08-06 08:49:07.333
HD Request # 38 | Using server: ds21.sierracharts.com port 10149 | 2021-08-06 08:49:07.333
Socket (5) | Creating socket. | 2021-08-06 08:49:07.333
Socket (5) | New receive buffer size: 5242880 | 2021-08-06 08:49:07.333
Socket (5) | Connecting to IP: 216.1.90.129. | 2021-08-06 08:49:07.333
HD Request # 38 | Setting DTC encoding to Binary VLS | 2021-08-06 08:49:07.469
HD Request # 38 | Sending historical data logon request message. | 2021-08-06 08:49:07.469
HD Request # 38 | Requesting Intraday data. Start date-time: 2021-08-06 08:48:10. Record interval: 0. Symbol: ESU21 | 2021-08-06 08:49:07.987
HD Request # 38 | Decompressing data. | 2021-08-06 08:49:08.051
HD Request # 38 | Receiving Intraday data for F.US.EPU21 starting at 2021-08-06 08:48:10.268000 | 2021-08-06 08:49:08.052
Socket (5) | CloseSocket call. | 2021-08-06 08:49:08.053
Socket (5) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:49:08.054
Historical data download thread signaled to stop. | 2021-08-06 08:49:08.056
HD Request # 38 | Timestamp of first Intraday data file record written: 2021-08-06 08:48:12.569000 | 2021-08-06 08:49:08.056
HD Request # 38 | Received 823 Intraday data records from 2021-08-06 08:48:10.268000 to 2021-08-06 08:49:07.036007 (56.8 seconds) and wrote 822 records for F.US.EPU21 | 2021-08-06 08:49:08.057
HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2021-08-06 12:49:07.036007 | 2021-08-06 08:49:08.062
Added 9 Time and Sales records to Intraday data file for F.US.EPU21 after download. | 2021-08-06 08:49:08.062
HD Request # 38 | Completion time: 1s | 2021-08-06 08:49:08.062
HD Request # 38 | Intraday data download complete for F.US.EPU21. Unique request ID: 34 | 2021-08-06 08:49:08.062
Removing historical data download ID 34. | 2021-08-06 08:49:08.062
Real-time Intraday chart data file updates started for F.US.EPU21 | 2021-08-06 08:49:08.062
Intraday chart data file opened for F.US.EPU21 | 2021-08-06 08:49:08.062
HD Request # 38 | Enabling Intraday chart updating for symbol. | 2021-08-06 08:49:08.062
Triggering next historical data download in queue. | 2021-08-06 08:49:08.062
HD Request # 39 | Downloading Intraday chart data for F.US.EPZ20 to the file F.US.EPZ20.scid. Service: cme | 2021-08-06 08:49:08.062
HD Request # 39 | Download start date-time: 2020-12-18 09:29:59.000000. File last date-time: 2020-12-18 09:29:59.953003 | 2021-08-06 08:49:08.062
HD Request # 39 | Using server: ds23.sierracharts.com port 10150 | 2021-08-06 08:49:08.062
Socket (6) | Creating socket. | 2021-08-06 08:49:08.062
Socket (6) | New receive buffer size: 5242880 | 2021-08-06 08:49:08.063
Socket (6) | Connecting to IP: 216.1.90.130. | 2021-08-06 08:49:08.063
Socket (5) | Socket gracefully closed by remote side. | 2021-08-06 08:49:08.126
Socket (5) | Closed. | 2021-08-06 08:49:08.126
HD Request # 39 | Setting DTC encoding to Binary VLS | 2021-08-06 08:49:08.210
HD Request # 39 | Sending historical data logon request message. | 2021-08-06 08:49:08.210
HD Request # 39 | Requesting Intraday data. Start date-time: 2020-12-18 09:29:59. Record interval: 0. Symbol: ESZ20 | 2021-08-06 08:49:08.729
HD Request # 39 | Decompressing data. | 2021-08-06 08:49:08.790
HD Request # 39 | Receiving Intraday data for F.US.EPZ20 starting at 2020-12-18 09:29:59.324000 | 2021-08-06 08:49:08.791
Socket (6) | CloseSocket call. | 2021-08-06 08:49:08.791
Socket (6) | Shutdown started. Waiting for graceful close. | 2021-08-06 08:49:08.791
Historical data download thread signaled to stop. | 2021-08-06 08:49:08.830
HD Request # 39 | Received 5 Intraday data records from 2020-12-18 09:29:59.324000 to 2020-12-18 09:29:59.953003 (0.6 seconds) and wrote 0 records for F.US.EPZ20 | 2021-08-06 08:49:08.830
HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2020-12-18 14:29:59.953003 | 2021-08-06 08:49:08.831
HD Request # 39 | Completion time: 0s | 2021-08-06 08:49:08.831
HD Request # 39 | Intraday data download complete for F.US.EPZ20. Unique request ID: 35 | 2021-08-06 08:49:08.831
Removing historical data download ID 35. | 2021-08-06 08:49:08.831
Real-time Intraday chart data file updates started for F.US.EPZ20 | 2021-08-06 08:49:08.831
Intraday chart data file opened for F.US.EPZ20 | 2021-08-06 08:49:08.831
HD Request # 39 | Enabling Intraday chart updating for symbol. | 2021-08-06 08:49:08.831
Triggering next historical data download in queue. | 2021-08-06 08:49:08.831
No download requests in the queue to start downloads for. | 2021-08-06 08:49:08.831
Socket (6) | Socket gracefully closed by remote side. | 2021-08-06 08:49:08.855
Socket (6) | Closed. | 2021-08-06 08:49:08.855
Chart #8 has tagged chart #2 for full recalculation. Chartbook: NEW_ES_LIGHT_12-9-20_V2204.Cht | 2021-08-06 08:49:09.148
F.US.EPU21[M]/F.US.MESU21[M] 500 Trades #2 | Performing a full recalculation because it has been tagged. Chartbook: NEW_ES_LIGHT_12-9-20_V2204.Cht | 2021-08-06 08:49:09.190
Opened cached Intraday file: C:\SierraChart\Data\F.US.EPU21.scid. Thread ID: 16024 | 2021-08-06 08:49:09.764
[2021-08-06 14:55:25]
Go through these instructions and ensure that everything is setup properly to receive the historical depth data:
Note in the above instructions is information for how to force the download if it does not occur automatically. Once you have everything setup, then if you are not getting the historical data automatically, then use that option to force the download. If that does not work, then let us know and get us your Message Log after you have performed the request.
Just note, it can take several minutes to download the historical depth data and while it is downloading, you can continue to work on the system. Your chart will then automatically reload once all the data is downloaded. So make sure you give it enough time to be sure you get the data.
[2021-08-15 22:15:51]
Went through the instruction and they are all setup properly. I opened the chartbook and still no depth. Please advise. Thank you
Software version: 2292 64-bit | 2021-08-15 18:10:52.625
OpenGL enabled (NVIDIA Corporation/GeForce GTX 1050 Ti/PCIe/SSE2) | 2021-08-15 18:10:52.629
Primary Thread ID: 4796 | 2021-08-15 18:10:52.629
Usage end date: 2021-08-26 | 2021-08-15 18:10:52.629
Enabled for: Advanced Features 2. | 2021-08-15 18:10:52.629
Enabled for: Sierra Chart Historical Data Service. | 2021-08-15 18:10:52.629
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-08-15 18:10:52.629
Enabled for: Delayed Denali Exchange Data Feed. | 2021-08-15 18:10:52.629
Enabled for exchange2: CME | 2021-08-15 18:10:52.629
Enabled for exchange2: COMEX | 2021-08-15 18:10:52.629
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-08-15 18:10:52.629
Current selected Data/Trading service: CQG WebAPI | 2021-08-15 18:10:52.629
Custom symbol settings values: enabled | 2021-08-15 18:10:52.629
Chart Update Interval: 100 | 2021-08-15 18:10:52.629
Intraday Data Storage Time Unit: 0 | 2021-08-15 18:10:52.629
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-08-15 18:10:52.629
2021-08-15 22:10:52 Local computer time in UTC | 2021-08-15 18:10:52.629
2021-08-15 18:10:52 Local computer time in SC Time Zone | 2021-08-15 18:10:52.629
2021-08-13 17:47:33 Server time in UTC | 2021-08-15 18:10:52.629
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-08-15 18:10:52.629
Program path: C:\SierraChart\ | 2021-08-15 18:10:52.629
Data Files path: C:\SierraChart\Data\ | 2021-08-15 18:10:52.629
OS Version Number: 10.0 | 2021-08-15 18:10:52.629
Locale Setting: C | 2021-08-15 18:10:52.629
DLLs: sst_ateam_2151_64.dll, sst_ateam_64.dll, SST_ATEAM_RX_2151_64.dll, SST_ATEAM_RX_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-08-15 18:10:52.630
Allowed protected custom studies: SST_ATEAM, SST_ATEAM_PS | 2021-08-15 18:10:52.630
F.US.EPU21/F.US.MESU21 [C] Rev. 25t #11 | Reloading chart. | 2021-08-15 18:11:07.521
F.US.EPU21/F.US.MESU21 500 Trades #2 | Reloading chart. | 2021-08-15 18:11:07.753
F.US.EPU21/F.US.MESU21 10 Sec #10 | Reloading chart. | 2021-08-15 18:11:08.210
F.US.EPU21/F.US.MESU21 10 Sec #6 | Reloading chart. | 2021-08-15 18:11:08.674
Loading market depth data. | 2021-08-15 18:11:08.914
Loading market depth data. | 2021-08-15 18:11:08.985
Loaded depth data records for F.US.EPU21 2021-08-10 from 2021-08-10 18:00:00.000000 to 2021-08-10 19:59:59.962000. | 2021-08-15 18:11:09.127
F.US.EPU21/F.US.MESU21 Rev. 2t #1 | Reloading chart. | 2021-08-15 18:11:09.137
Loading market depth data. | 2021-08-15 18:11:09.145
Loaded depth data records for F.US.EPU21 2021-08-11 from 2021-08-11 18:00:00.000000 to 2021-08-11 19:59:59.682000. | 2021-08-15 18:11:09.243
F.US.EPU21/F.US.MESU21 10 Sec #8 | Reloading chart. | 2021-08-15 18:11:09.265
F.US.EPU21/F.US.MESU21 [C] 1 Min #9 | Reloading chart. | 2021-08-15 18:11:09.342
F.US.EPU21/F.US.MSFU21 10 Sec #5 | Reloading chart. | 2021-08-15 18:11:09.442
Loading market depth data. | 2021-08-15 18:11:09.512
F.US.EPU21/F.US.MESU21 [C] 10 Sec #12 | Reloading chart. | 2021-08-15 18:11:09.596
Loaded depth data records for F.US.EPU21 2021-08-11 from 2021-08-11 18:00:00.000000 to 2021-08-11 19:59:59.682000. | 2021-08-15 18:11:09.738
F.US.EPU21/F.US.MESU21 10 Sec #3 | Reloading chart. | 2021-08-15 18:11:09.781
Loading market depth data. | 2021-08-15 18:11:09.792
F.US.EPU21/F.US.MESU21 Rev. 2t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-08-15 18:11:09.904
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:09.911
F.US.EPU21/F.US.MESU21 [C] 10 Sec #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-08-15 18:11:09.997
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:10.497
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:10.639
Requesting market depth updates for: F.US.MSFU21 if supported. | 2021-08-15 18:11:10.972
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:10.978
Loading market depth data. | 2021-08-15 18:11:11.002
SC Data - All Services | Clearing market depth for F.US.MSFU21 | 2021-08-15 18:11:11.069
Loaded depth data records for F.US.EPU21 2021-08-09 from 2021-08-09 18:00:00.000000 to 2021-08-09 19:59:59.847000. | 2021-08-15 18:11:11.160
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:12.526
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:13.084
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:13.217
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:13.373
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:13.826
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:14.206
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:14.493
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:14.764
Loaded depth data records for F.US.EPU21 2021-08-10 from 2021-08-09 20:00:00.004000 to 2021-08-10 19:59:59.962000. | 2021-08-15 18:11:14.830
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:15.057
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:15.256
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:15.641
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:15.868
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:16.699
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:17.376
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:17.855
Loaded depth data records for F.US.EPU21 2021-08-11 from 2021-08-10 20:00:00.004000 to 2021-08-11 19:59:59.682000. | 2021-08-15 18:11:18.463
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:18.502
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:18.719
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:19.345
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:19.594
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:19.830
Chart #1 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2021-08-15 18:11:20.073
Array message repeat count limit reached. | 2021-08-15 18:11:20.073
Loaded depth data records for F.US.EPU21 2021-08-12 from 2021-08-11 20:00:00.000000 to 2021-08-12 19:59:59.996000. | 2021-08-15 18:11:20.756
Loaded depth data records for F.US.EPU21 2021-08-12 from 2021-08-11 20:00:00.000000 to 2021-08-12 19:59:59.996000. | 2021-08-15 18:11:20.837
Loaded depth data records for F.US.EPU21 2021-08-12 from 2021-08-11 20:00:00.000000 to 2021-08-12 19:59:59.996000. | 2021-08-15 18:11:21.121
Loaded depth data records for F.US.EPU21 2021-08-13 from 2021-08-12 20:00:00.002000 to 2021-08-13 13:24:07.974273. | 2021-08-15 18:11:23.278
F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-08-15 18:11:23.280
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #8 | Study: ATEAM - Signal Receiver Plot Study - Rectangles | This plot study is connected to the Signal Receiver Connection Study. | 2021-08-15 18:11:23.284 *
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #8 | Study: ATEAM - Signal Receiver Plot Study - Alert Condition Study SG | This plot study is connected to the Signal Receiver Connection Study. | 2021-08-15 18:11:23.443 *
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #8 | Study: ATEAM - Signal Receiver Plot Study - Click Marker | This plot study is connected to the Signal Receiver Connection Study. | 2021-08-15 18:11:23.446 *
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #8 | Study: ATEAM - Signal Receiver Plot Study - Manual Signals | This plot study is connected to the Connection Study. | 2021-08-15 18:11:23.452 *
Loaded depth data records for F.US.EPU21 2021-08-11 from 2021-08-10 20:00:00.004000 to 2021-08-11 19:59:59.682000. | 2021-08-15 18:11:24.561
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #8 | Study: ATEAM - Signal Receiver Connection Study | Receiver Connection Study ID#3: Starting Connection to SST BackEnd. | 2021-08-15 18:11:26.062 *
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #8 | Study: ATEAM - Signal Receiver Connection Study | Receiver Connection Study ID#3: Connection Established. | 2021-08-15 18:11:26.736 *
Loaded depth data records for F.US.EPU21 2021-08-13 from 2021-08-12 20:00:00.002000 to 2021-08-13 13:24:07.974273. | 2021-08-15 18:11:28.420
F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-08-15 18:11:28.433
Loaded depth data records for F.US.EPU21 2021-08-13 from 2021-08-12 20:00:00.002000 to 2021-08-13 13:24:07.974273. | 2021-08-15 18:11:28.523
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #6 | Study: A-Team Trade Management Study V3 | Your Autotrading Global and Chart will need to be enabled for the study to work. | 2021-08-15 18:11:28.872
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #6 | Study: A-Team Trade Management Study V3 | Your Autotrading Global and Chart will need to be enabled for the study to work. | 2021-08-15 18:11:29.287
F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-08-15 18:11:29.365
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #10 | Study: A-Team Trade Management Study V3 | Your Autotrading Global and Chart will need to be enabled for the study to work. | 2021-08-15 18:11:29.780
Chart: F.US.EPU21[M]/F.US.MESU21[M] 10 Sec #10 | Study: A-Team Trade Management Study V3 | Your Autotrading Global and Chart will need to be enabled for the study to work. | 2021-08-15 18:11:31.643
Loaded depth data records for F.US.EPU21 2021-08-12 from 2021-08-11 20:00:00.000000 to 2021-08-12 19:59:59.996000. | 2021-08-15 18:11:33.355
Loaded depth data records for F.US.EPU21 2021-08-13 from 2021-08-12 20:00:00.002000 to 2021-08-13 13:24:07.974273. | 2021-08-15 18:11:39.455
Chart: F.US.EPU21[M]/F.US.MESU21[M] 500 Trades #2 | Study: ATEAM - Signal Receiver Plot Study - Rectangles | This plot study is connected to the Signal Receiver Connection Study. | 2021-08-15 18:11:39.526 *
Chart: F.US.EPU21[M]/F.US.MESU21[M] 500 Trades #2 | Study: ATEAM - Signal Receiver Plot Study - Alert Condition Study SG | This plot study is connected to the Signal Receiver Connection Study. | 2021-08-15 18:11:39.540 *
Chart: F.US.EPU21[M]/F.US.MESU21[M] 500 Trades #2 | Study: ATEAM - Signal Receiver Plot Study - Click Marker | This plot study is connected to the Signal Receiver Connection Study. | 2021-08-15 18:11:39.540 *
Chart: F.US.EPU21[M]/F.US.MESU21[M] 500 Trades #2 | Study: ATEAM - Signal Receiver Plot Study - Manual Signals | This plot study is connected to the Connection Study. | 2021-08-15 18:11:39.541 *
Chart: F.US.EPU21[M]/F.US.MESU21 [C][M] Rev. 25t #11 | Study: ATEAM - Signal Receiver Plot Study - Rectangles | This plot study is connected to the Signal Receiver Connection Study. | 2021-08-15 18:12:31.183 *
Chart: F.US.EPU21[M]/F.US.MESU21 [C][M] Rev. 25t #11 | Study: ATEAM - Signal Receiver Plot Study - Click Marker | This plot study is connected to the Signal Receiver Connection Study. | 2021-08-15 18:12:31.232 *
[2021-08-16 08:38:21]
We may need to look at this using remote assistance to get a better idea of what is going on in your case.
For now, scroll the chart back to the point where you want to see market depth data, and right click and select Download Depth Data from Date-Time.
The data should download without any problems. We do not observe an issue with this in the Message Log.
[2021-08-16 13:20:54]
What time can you do a remote? Data still doesn't come in using "download depth data from date-time"
[2021-08-18 16:41:10]
We apologize for the delay. We can do this today. Please confirm if that is all right.
