Date/Time: Tue, 04 Nov 2025 14:58:09 +0000
Lag/delay in DOM prices after switching from CQG to DENALI (EUREX)
View Count: 1089
[2021-06-17 14:46:55]
User197029 - Posts: 52
I am trading the FESX Futures (FESXU21-EUREX) on an intraday basis and have recently switched from CQG data to the SC Denali data incl EUREX. I have noticed a delay of the bid and offer display in my DOM since then. I have been trading FESX Futures for many years so even though only slightly (maybe 1s) but the delay is clearly visible for the trained eye and annoying. All this happened without me changing any other settings - only the data provider.
So I looked at the video how to improve SC perforamnce that you have posted and I have done those steps but no improvement. Then I started to change the settings "SC Server Settings" to add "Remote Buffer Delay Send Time in Milliseconds" to 20 and this seems to help (I dont know why tbh).
Some background on my usage:
I am running 1 SC instance (version 2270) with 2 sub-instances on my main SSD, in total a number of 15 chartbooks with quite a few DOMs and charts but I guess that should be ok since I have 100mb internet speed, 64GB RAM, 2.4 Ghz Processor. Simultaneously I am also running other 3 SC instances but from another drive so the impact on performance is not that great either.
My 2 questions:
1) Is there anything else I can do to make sure i have no delay on my DOMs? Maybe some other changes in Sierra Chart Server Settings? Real-time data compression?
2) If I change a setting in my main instance will it automatically impact the sub-instances or do I have to manually change the settings there as well?
Please see below also my heartbeat log as of now:
SC DTC Data with Market Depth | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=6, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=0, ActualMessageDelay=-0.7 seconds, DataCompRatio=1.54, UncompressedBytes=6494130, CompressionTime=0.369319(secs), NumCompressions=48044 | 2021-06-17 16:42:56.605
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=11, NumberOfOutstandingSendBuffers=2, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=1238, ActualMessageDelay=-0.7 seconds, DataCompRatio=2.24, UncompressedBytes=325504167, CompressionTime=1.475923(secs), NumCompressions=85186 | 2021-06-17 16:43:06.172
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=18, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=95, ActualMessageDelay=-2.3 seconds, DataCompRatio=1.84, UncompressedBytes=45390898, CompressionTime=0.471785(secs), NumCompressions=88791 | 2021-06-17 16:43:14.264
SC DTC Data with Market Depth | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=6, NumberOfOutstandingSendBuffers=3, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=206, ActualMessageDelay=-0.6 seconds, DataCompRatio=1.54, UncompressedBytes=6511940, CompressionTime=0.370545(secs), NumCompressions=48220 | 2021-06-17 16:43:16.645
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=11, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=4617, ActualMessageDelay=-0.7 seconds, DataCompRatio=2.24, UncompressedBytes=326590998, CompressionTime=1.481853(secs), NumCompressions=85601 | 2021-06-17 16:43:26.171
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=18, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=124, ActualMessageDelay=-2.3 seconds, DataCompRatio=1.84, UncompressedBytes=45475406, CompressionTime=0.473207(secs), NumCompressions=89094 | 2021-06-17 16:43:34.327
SC DTC Data with Market Depth | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=6, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=64, ActualMessageDelay=-0.7 seconds, DataCompRatio=1.54, UncompressedBytes=6526102, CompressionTime=0.371565(secs), NumCompressions=48366 | 2021-06-17 16:43:36.585
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=11, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=0, ActualMessageDelay=-0.6 seconds, DataCompRatio=2.24, UncompressedBytes=327582066, CompressionTime=1.487539(secs), NumCompressions=86016 | 2021-06-17 16:43:46.199
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=18, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=9354, ActualMessageDelay=-2.3 seconds, DataCompRatio=1.84, UncompressedBytes=45557735, CompressionTime=0.474427(secs), NumCompressions=89352 | 2021-06-17 16:43:54.266
SC DTC Data with Market Depth | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=6, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=71, ActualMessageDelay=-0.7 seconds, DataCompRatio=1.54, UncompressedBytes=6547976, CompressionTime=0.372902(secs), NumCompressions=48544 | 2021-06-17 16:43:56.557
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=11, NumberOfOutstandingSendBuffers=2, TransmissionDelayInMilliseconds=20, ServerSendBufferSizeInBytes=1234, ActualMessageDelay=-0.6 seconds, DataCompRatio=2.24, UncompressedBytes=329038423, CompressionTime=1.495005(secs), NumCompressions=86521 | 2021-06-17 16:44:06.197
Thanks!
[2021-06-17 14:58:47]
John - SC Support - Posts: 42750
1. You should have the option for Global Settings >> Sierra Chart Server Settings >> Use Real-Time Data Compression set to Standard Compression. You would most likely not get any benefit from High Compression. Refer to the following information:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#UseRealTimeDataCompression
You would also want to check the Chart >> Advanced Settings >> Chart Update Interval for the Trading DOMs in particular and look at lowering the number in order to get faster updates. Just keep in mind that changing this on a Chart is going to impact how often the studies are recalculated, which could then become counter-productive. Refer to the information here:
Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu)
2. You would have to update any sub-instances for the changes manually.
Date Time Of Last Edit: 2021-06-17 14:59:30
[2021-06-17 15:50:13]
Thanks John. I have set it to Standard Compression. Any recommended value for "Remote Buffer Delay Send Time in Milliseconds" in my case?
I had already before set the Chart Update Interval for the DOMs to a lower number than in the global settings, that didn't help.
Is there a way to see that the feed in the DOM is without delay, such as a confirmation the settings are now fine-tuned in the best way?
thanks again.
[2021-06-17 18:30:38]
There are too many factors that go into what works that we do not have a way to auto-tune or let you know that it is at it's best. You would just have to work with the items that you already know about to determine what works best for you. Your Internet connection, in particular, is going to have a large impact on the various options.
For instance, you can try High Compression, but if you have a good Internet connection, then this will probably just add a few milliseconds rather than shave them off. In addition, if you are getting smaller packets by having a lower "Remote Buffer Delay Send Time", then having higher compression is probably not good, as the amount of compression may not be significant.
[2021-06-18 05:54:23]
For any lagging issues, refer to:
https://www.sierrachart.com/index.php?page=doc/helpdetails4.htm
The log you gave in post #1 is not indicating any delay. So not sure how you are concluding there is a delay.
We want to make sure the data is actually coming from the Denali Exchange Data Feed. Follow the instructions below:
Reconnect to the data feed:
Date Time Of Last Edit: 2021-06-18 05:54:56
[2021-06-18 07:00:05]
Ok here is the log, thanks for taking a closer look.
Software version: 2270 64-bit | 2021-06-18 08:57:52.298
Primary Thread ID: 16364 | 2021-06-18 08:57:52.298
Usage end date: 2021-11-24 | 2021-06-18 08:57:52.298
Enabled for: Advanced Features 2. | 2021-06-18 08:57:52.298
Enabled for: Sierra Chart Historical Data Service. | 2021-06-18 08:57:52.298
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-18 08:57:52.298
Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-18 08:57:52.298
Enabled for exchange2: CME (Trading Account Required) | 2021-06-18 08:57:52.298
Enabled for exchange2: CBOT (Trading Account Required) | 2021-06-18 08:57:52.298
Enabled for exchange2: COMEX (Trading Account Required) | 2021-06-18 08:57:52.298
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-06-18 08:57:52.298
Enabled for exchange2: EUREX EOBI | 2021-06-18 08:57:52.298
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-18 08:57:52.298
Current selected Data/Trading service: CQG WebAPI | 2021-06-18 08:57:52.298
Custom symbol settings values: enabled | 2021-06-18 08:57:52.298
Chart Update Interval: 1000 | 2021-06-18 08:57:52.298
Intraday Data Storage Time Unit: 0 | 2021-06-18 08:57:52.298
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2021-06-18 08:57:52.298
2021-06-18 06:57:52 Local computer time in UTC | 2021-06-18 08:57:52.298
2021-06-18 08:57:52 Local computer time in SC Time Zone | 2021-06-18 08:57:52.298
2021-06-13 15:05:23 Server time in UTC | 2021-06-18 08:57:52.298
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-06-18 08:57:52.298
Program path: C:\SierraChart\ | 2021-06-18 08:57:52.298
Data Files path: C:\SierraChart\Data\ | 2021-06-18 08:57:52.298
OS Version Number: 10.0 | 2021-06-18 08:57:52.298
Locale Setting: C | 2021-06-18 08:57:52.298
DLLs: sst_FreeBundle.dll, sst_FreeBundle_2151.dll, sst_FreeBundle_2151_64.dll, sst_FreeBundle_64.dll, sst_volume_dots.dll, sst_volume_dots_2151.dll, sst_volume_dots_2151_64.dll, sst_volume_dots_64.dll, TicinoMathV2.0.dll, TicinoMathV2.0_64.dll, TicinoMathV3.0.dll, TicinoMathV3.0_2151.dll, TicinoMathV3.0_2151_64.dll, TicinoMathV3.0_64.dll, TicinoMath_Scanner.dll, TicinoMath_Scanner_2151.dll, TicinoMath_Scanner_2151_64.dll, TicinoMath_Scanner_64.dll, TicinoSuite_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-06-18 08:57:52.301
Allowed protected custom studies: SST_FreeBundle, TicinoMathScanner DLL, TicinoMathV2.0.DLL, TicinoMathV3.0.DLL, TicinoSuite | 2021-06-18 08:57:52.301
CQG WebAPI | Connecting to server api.cqg.com | 2021-06-18 08:57:56.946
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-06-18 08:57:56.946
CQG WebSocket socket (10) | Creating socket. Using TLS 1.2. | 2021-06-18 08:57:56.946
CQG WebSocket socket (10) | New receive buffer size: 5242880 | 2021-06-18 08:57:56.947
CQG WebSocket socket (10) | Connecting to IP: 195.166.124.165. | 2021-06-18 08:57:56.947
CQG WebSocket | Opening WebSocket. | 2021-06-18 08:57:56.984
CQG WebSocket | Sending WebSocket handshake. | 2021-06-18 08:57:56.984
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-06-18 08:57:57.104
CQG WebSocket | Server header | Connection: upgrade | 2021-06-18 08:57:57.104
CQG WebSocket | Server header | Sec-WebSocket-Accept: LvPUH7FN12Q4CQ2+s5yGaSz5jW8= | 2021-06-18 08:57:57.104
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-06-18 08:57:57.104
CQG WebSocket | Server header | Upgrade: websocket | 2021-06-18 08:57:57.104
CQG WebSocket | Server header | | 2021-06-18 08:57:57.104
CQG WebSocket | Web socket state is now open. | 2021-06-18 08:57:57.104
CQG WebAPI | WebSocket connected. | 2021-06-18 08:57:57.104
CQG WebAPI | Sending market data logon message. | 2021-06-18 08:57:57.104
CQG WebAPI | Base Time: 2021-06-06T14:36:43. 2021-06-06 14:36:43 | 2021-06-18 08:57:57.693
CQG WebAPI | Logon successful. Session Token = 9utcjZJf1zXyPrKHJMJe+Jfiau6MK5B0vgDI8LwS264QpuRgkLgVznzSZkSzSQEknubBY+pc2in | 2021-06-18 08:57:57.693
CQG WebAPI | Connected to server complete. | 2021-06-18 08:57:57.693
Triggering next historical data download in queue. | 2021-06-18 08:57:57.701
Subscribing to symbol for symbol alert. F.US.DSXH18 | 2021-06-18 08:57:57.701
Mapping F.US.DSXH18 to FESX201803_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.701
SC Data - All Services | Starting real-time market data updates for: F.US.DSXH18 (FESX201803_FUT_EUREX). ID: 1 Service code: eurex | 2021-06-18 08:57:57.701
SC Data - All Services | Connecting to the server ds14.sierracharts.com. Port 10048 | 2021-06-18 08:57:57.701
CQG WebAPI | Sending symbol resolution request for F.US.DSXH18. ID: 74852 | 2021-06-18 08:57:57.701
SC Data - All Services | Requesting security definition data for: F.US.DSXH18 (FESX201803_FUT_EUREX). ID: 1 | 2021-06-18 08:57:57.701
Subscribing to symbol for symbol alert. F.US.DLM18 | 2021-06-18 08:57:57.701
Mapping F.US.DLM18 to FGBM201806_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.701
SC Data - All Services | Starting real-time market data updates for: F.US.DLM18 (FGBM201806_FUT_EUREX). ID: 2 Service code: eurex | 2021-06-18 08:57:57.702
CQG WebAPI | Sending symbol resolution request for F.US.DLM18. ID: 74853 | 2021-06-18 08:57:57.702
SC Data - All Services | Requesting security definition data for: F.US.DLM18 (FGBM201806_FUT_EUREX). ID: 2 | 2021-06-18 08:57:57.702
Subscribing to symbol for symbol alert. F.US.DLM18 | 2021-06-18 08:57:57.702
Subscribing to symbol for symbol alert. F.US.TYAM18 | 2021-06-18 08:57:57.702
Mapping F.US.TYAM18 to ZNM18. Service code: cbot | 2021-06-18 08:57:57.702
SC Data - All Services | Starting real-time market data updates for: F.US.TYAM18 (ZNM18). ID: 3 Service code: cbot | 2021-06-18 08:57:57.702
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2021-06-18 08:57:57.702
DTC Client socket (12) | Creating socket. | 2021-06-18 08:57:57.702
DTC Client socket (12) | New receive buffer size: 5242880 | 2021-06-18 08:57:57.702
DTC Client socket (12) | Connecting to IP: 157.90.1.40. | 2021-06-18 08:57:57.702
CQG WebAPI | Sending symbol resolution request for F.US.TYAM18. ID: 74854 | 2021-06-18 08:57:57.702
SC Data - All Services | Requesting security definition data for: F.US.TYAM18 (ZNM18). ID: 3 | 2021-06-18 08:57:57.702
Subscribing to symbol for symbol alert. F.US.GCEJ18 | 2021-06-18 08:57:57.702
Mapping F.US.GCEJ18 to GCJ18. Service code: comex | 2021-06-18 08:57:57.702
SC Data - All Services | Starting real-time market data updates for: F.US.GCEJ18 (GCJ18). ID: 4 Service code: comex | 2021-06-18 08:57:57.702
CQG WebAPI | Sending symbol resolution request for F.US.GCEJ18. ID: 74855 | 2021-06-18 08:57:57.702
SC Data - All Services | Requesting security definition data for: F.US.GCEJ18 (GCJ18). ID: 4 | 2021-06-18 08:57:57.702
Subscribing to symbol for symbol alert. F.US.DSXH18 | 2021-06-18 08:57:57.702
Subscribing to symbol for symbol alert. F.US.DSXM18 | 2021-06-18 08:57:57.702
Mapping F.US.DSXM18 to FESX201806_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.702
SC Data - All Services | Starting real-time market data updates for: F.US.DSXM18 (FESX201806_FUT_EUREX). ID: 5 Service code: eurex | 2021-06-18 08:57:57.703
CQG WebAPI | Sending symbol resolution request for F.US.DSXM18. ID: 74856 | 2021-06-18 08:57:57.703
DTC Client socket (13) | Creating socket. | 2021-06-18 08:57:57.703
SC Data - All Services | Requesting security definition data for: F.US.DSXM18 (FESX201806_FUT_EUREX). ID: 5 | 2021-06-18 08:57:57.703
Subscribing to symbol for symbol alert. F.US.DSXM18 | 2021-06-18 08:57:57.703
Subscribing to symbol for symbol alert. F.US.DLM18 | 2021-06-18 08:57:57.703
DTC Client socket (13) | New receive buffer size: 5242880 | 2021-06-18 08:57:57.703
DTC Client socket (13) | Connecting to IP: 216.1.90.130. | 2021-06-18 08:57:57.703
Subscribing to symbol for symbol alert. F.US.TYAM18 | 2021-06-18 08:57:57.703
Subscribing to symbol for symbol alert. F.US.DBM18 | 2021-06-18 08:57:57.703
Mapping F.US.DBM18 to FGBL201806_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.703
SC Data - All Services | Starting real-time market data updates for: F.US.DBM18 (FGBL201806_FUT_EUREX). ID: 6 Service code: eurex | 2021-06-18 08:57:57.703
CQG WebAPI | Sending symbol resolution request for F.US.DBM18. ID: 74857 | 2021-06-18 08:57:57.703
SC Data - All Services | Requesting security definition data for: F.US.DBM18 (FGBL201806_FUT_EUREX). ID: 6 | 2021-06-18 08:57:57.703
Subscribing to symbol for symbol alert. F.US.GCEM18 | 2021-06-18 08:57:57.703
Mapping F.US.GCEM18 to GCM18. Service code: comex | 2021-06-18 08:57:57.703
SC Data - All Services | Starting real-time market data updates for: F.US.GCEM18 (GCM18). ID: 7 Service code: comex | 2021-06-18 08:57:57.703
CQG WebAPI | Sending symbol resolution request for F.US.GCEM18. ID: 74858 | 2021-06-18 08:57:57.703
SC Data - All Services | Requesting security definition data for: F.US.GCEM18 (GCM18). ID: 7 | 2021-06-18 08:57:57.703
Subscribing to symbol for symbol alert. F.US.EPM18 | 2021-06-18 08:57:57.703
Mapping F.US.EPM18 to ESM18. Service code: cme | 2021-06-18 08:57:57.703
SC Data - All Services | Starting real-time market data updates for: F.US.EPM18 (ESM18). ID: 8 Service code: cme | 2021-06-18 08:57:57.703
CQG WebAPI | Sending symbol resolution request for F.US.EPM18. ID: 74859 | 2021-06-18 08:57:57.703
SC Data - All Services | Requesting security definition data for: F.US.EPM18 (ESM18). ID: 8 | 2021-06-18 08:57:57.703
Subscribing to symbol for symbol alert. F.US.DBM18 | 2021-06-18 08:57:57.704
Subscribing to symbol for symbol alert. F.US.GCEM18 | 2021-06-18 08:57:57.704
Subscribing to symbol for symbol alert. F.US.DLM18 | 2021-06-18 08:57:57.704
Subscribing to symbol for symbol alert. F.US.EPM18 | 2021-06-18 08:57:57.704
Subscribing to symbol for symbol alert. F.US.DSXM18 | 2021-06-18 08:57:57.704
Subscribing to symbol for symbol alert. F.US.TNAM18 | 2021-06-18 08:57:57.704
Mapping F.US.TNAM18 to TNM18. Service code: cbot | 2021-06-18 08:57:57.704
SC Data - All Services | Starting real-time market data updates for: F.US.TNAM18 (TNM18). ID: 9 Service code: cbot | 2021-06-18 08:57:57.704
CQG WebAPI | Sending symbol resolution request for F.US.TNAM18. ID: 74860 | 2021-06-18 08:57:57.704
SC Data - All Services | Requesting security definition data for: F.US.TNAM18 (TNM18). ID: 9 | 2021-06-18 08:57:57.704
Subscribing to symbol for symbol alert. F.US.TYAM18 | 2021-06-18 08:57:57.704
Subscribing to symbol for symbol alert. F.US.DSXm18 | 2021-06-18 08:57:57.704
Subscribing to symbol for symbol alert. F.US.ZWAN18 | 2021-06-18 08:57:57.704
Mapping F.US.ZWAN18 to ZWN18. Service code: cbot | 2021-06-18 08:57:57.704
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAN18 (ZWN18). ID: 10 Service code: cbot | 2021-06-18 08:57:57.705
CQG WebAPI | Sending symbol resolution request for F.US.ZWAN18. ID: 74861 | 2021-06-18 08:57:57.705
SC Data - All Services | Requesting security definition data for: F.US.ZWAN18 (ZWN18). ID: 10 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.DSXM18 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.DDM18 | 2021-06-18 08:57:57.705
Mapping F.US.DDM18 to FDAX201806_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.705
SC Data - All Services | Starting real-time market data updates for: F.US.DDM18 (FDAX201806_FUT_EUREX). ID: 11 Service code: eurex | 2021-06-18 08:57:57.705
CQG WebAPI | Sending symbol resolution request for F.US.DDM18. ID: 74862 | 2021-06-18 08:57:57.705
SC Data - All Services | Requesting security definition data for: F.US.DDM18 (FDAX201806_FUT_EUREX). ID: 11 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.DLM18 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.EPM18 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.ZWAN18 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.USAM18 | 2021-06-18 08:57:57.705
Mapping F.US.USAM18 to ZBM18. Service code: cbot | 2021-06-18 08:57:57.705
SC Data - All Services | Starting real-time market data updates for: F.US.USAM18 (ZBM18). ID: 12 Service code: cbot | 2021-06-18 08:57:57.705
CQG WebAPI | Sending symbol resolution request for F.US.USAM18. ID: 74863 | 2021-06-18 08:57:57.705
SC Data - All Services | Requesting security definition data for: F.US.USAM18 (ZBM18). ID: 12 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.ZLEN18 | 2021-06-18 08:57:57.705
Mapping F.US.ZLEN18 to ZLN18. Service code: cbot | 2021-06-18 08:57:57.705
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEN18 (ZLN18). ID: 13 Service code: cbot | 2021-06-18 08:57:57.705
CQG WebAPI | Sending symbol resolution request for F.US.ZLEN18. ID: 74864 | 2021-06-18 08:57:57.705
SC Data - All Services | Requesting security definition data for: F.US.ZLEN18 (ZLN18). ID: 13 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.HEV18 | 2021-06-18 08:57:57.705
Mapping F.US.HEV18 to HEV18. Service code: cme | 2021-06-18 08:57:57.705
SC Data - All Services | Starting real-time market data updates for: F.US.HEV18 (HEV18). ID: 14 Service code: cme | 2021-06-18 08:57:57.705
CQG WebAPI | Sending symbol resolution request for F.US.HEV18. ID: 74865 | 2021-06-18 08:57:57.705
SC Data - All Services | Requesting security definition data for: F.US.HEV18 (HEV18). ID: 14 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.DBM18 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.KCEN18 | 2021-06-18 08:57:57.705
CQG WebAPI | Starting real-time market data updates for: F.US.KCEN18. ID: 15 Service code: cqg | 2021-06-18 08:57:57.705
CQG WebAPI | Sending symbol resolution request for F.US.KCEN18. ID: 74866 | 2021-06-18 08:57:57.705
CQG WebAPI | Requesting security definition data for: F.US.KCEN18. ID: 15 | 2021-06-18 08:57:57.705
Subscribing to symbol for symbol alert. F.US.EPM18 | 2021-06-18 08:57:57.706
Subscribing to symbol for symbol alert. F.US.YMM18 | 2021-06-18 08:57:57.706
Mapping F.US.YMM18 to YMM18. Service code: cbot | 2021-06-18 08:57:57.706
SC Data - All Services | Starting real-time market data updates for: F.US.YMM18 (YMM18). ID: 16 Service code: cbot | 2021-06-18 08:57:57.706
CQG WebAPI | Sending symbol resolution request for F.US.YMM18. ID: 74867 | 2021-06-18 08:57:57.706
SC Data - All Services | Requesting security definition data for: F.US.YMM18 (YMM18). ID: 16 | 2021-06-18 08:57:57.706
Subscribing to symbol for symbol alert. F.US.TNAM18 | 2021-06-18 08:57:57.706
Subscribing to symbol for symbol alert. F.US.CLEM18 | 2021-06-18 08:57:57.706
Mapping F.US.CLEM18 to CLM18. Service code: nymex | 2021-06-18 08:57:57.706
SC Data - All Services | Starting real-time market data updates for: F.US.CLEM18 (CLM18). ID: 17 Service code: nymex | 2021-06-18 08:57:57.706
CQG WebAPI | Sending symbol resolution request for F.US.CLEM18. ID: 74868 | 2021-06-18 08:57:57.706
SC Data - All Services | Requesting security definition data for: F.US.CLEM18 (CLM18). ID: 17 | 2021-06-18 08:57:57.706
Subscribing to symbol for symbol alert. F.US.DBM18 | 2021-06-18 08:57:57.706
Subscribing to symbol for symbol alert. F.US.DLM18 | 2021-06-18 08:57:57.706
Subscribing to symbol for symbol alert. F.US.ZMEN18 | 2021-06-18 08:57:57.706
Mapping F.US.ZMEN18 to ZMN18. Service code: cbot | 2021-06-18 08:57:57.706
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEN18 (ZMN18). ID: 18 Service code: cbot | 2021-06-18 08:57:57.707
CQG WebAPI | Sending symbol resolution request for F.US.ZMEN18. ID: 74869 | 2021-06-18 08:57:57.707
SC Data - All Services | Requesting security definition data for: F.US.ZMEN18 (ZMN18). ID: 18 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.GCEM18 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.DLM18 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.EPM18 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.DSXM18 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.CCEN18 | 2021-06-18 08:57:57.707
CQG WebAPI | Starting real-time market data updates for: F.US.CCEN18. ID: 19 Service code: cqg | 2021-06-18 08:57:57.707
CQG WebAPI | Sending symbol resolution request for F.US.CCEN18. ID: 74870 | 2021-06-18 08:57:57.707
CQG WebAPI | Requesting security definition data for: F.US.CCEN18. ID: 19 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.CTEZ18 | 2021-06-18 08:57:57.707
CQG WebAPI | Starting real-time market data updates for: F.US.CTEZ18. ID: 20 Service code: cqg | 2021-06-18 08:57:57.707
CQG WebAPI | Sending symbol resolution request for F.US.CTEZ18. ID: 74871 | 2021-06-18 08:57:57.707
CQG WebAPI | Requesting security definition data for: F.US.CTEZ18. ID: 20 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.GCEQ18 | 2021-06-18 08:57:57.707
Mapping F.US.GCEQ18 to GCQ18. Service code: comex | 2021-06-18 08:57:57.707
SC Data - All Services | Starting real-time market data updates for: F.US.GCEQ18 (GCQ18). ID: 21 Service code: comex | 2021-06-18 08:57:57.707
CQG WebAPI | Sending symbol resolution request for F.US.GCEQ18. ID: 74872 | 2021-06-18 08:57:57.707
SC Data - All Services | Requesting security definition data for: F.US.GCEQ18 (GCQ18). ID: 21 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.ENQM18 | 2021-06-18 08:57:57.707
Mapping F.US.ENQM18 to NQM18. Service code: cme | 2021-06-18 08:57:57.707
SC Data - All Services | Starting real-time market data updates for: F.US.ENQM18 (NQM18). ID: 22 Service code: cme | 2021-06-18 08:57:57.707
CQG WebAPI | Sending symbol resolution request for F.US.ENQM18. ID: 74873 | 2021-06-18 08:57:57.707
SC Data - All Services | Requesting security definition data for: F.US.ENQM18 (NQM18). ID: 22 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.DBM18 | 2021-06-18 08:57:57.707
Subscribing to symbol for symbol alert. F.US.TNAU18 | 2021-06-18 08:57:57.707
Mapping F.US.TNAU18 to TNU18. Service code: cbot | 2021-06-18 08:57:57.707
SC Data - All Services | Starting real-time market data updates for: F.US.TNAU18 (TNU18). ID: 23 Service code: cbot | 2021-06-18 08:57:57.708
CQG WebAPI | Sending symbol resolution request for F.US.TNAU18. ID: 74874 | 2021-06-18 08:57:57.708
SC Data - All Services | Requesting security definition data for: F.US.TNAU18 (TNU18). ID: 23 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.DBM18 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.DSXM18 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.EPM18 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.DLM18 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.YMM18 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.CLEN18 | 2021-06-18 08:57:57.708
Mapping F.US.CLEN18 to CLN18. Service code: nymex | 2021-06-18 08:57:57.708
SC Data - All Services | Starting real-time market data updates for: F.US.CLEN18 (CLN18). ID: 24 Service code: nymex | 2021-06-18 08:57:57.708
CQG WebAPI | Sending symbol resolution request for F.US.CLEN18. ID: 74875 | 2021-06-18 08:57:57.708
SC Data - All Services | Requesting security definition data for: F.US.CLEN18 (CLN18). ID: 24 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.GCEQ18 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.ENQM18 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.TNAU18 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.CCEN18 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.708
Mapping F.US.DBU18 to FGBL201809_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.708
SC Data - All Services | Starting real-time market data updates for: F.US.DBU18 (FGBL201809_FUT_EUREX). ID: 25 Service code: eurex | 2021-06-18 08:57:57.708
CQG WebAPI | Sending symbol resolution request for F.US.DBU18. ID: 74876 | 2021-06-18 08:57:57.708
SC Data - All Services | Requesting security definition data for: F.US.DBU18 (FGBL201809_FUT_EUREX). ID: 25 | 2021-06-18 08:57:57.708
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.708
Mapping F.US.DLU18 to FGBM201809_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.708
SC Data - All Services | Starting real-time market data updates for: F.US.DLU18 (FGBM201809_FUT_EUREX). ID: 26 Service code: eurex | 2021-06-18 08:57:57.709
CQG WebAPI | Sending symbol resolution request for F.US.DLU18. ID: 74877 | 2021-06-18 08:57:57.709
SC Data - All Services | Requesting security definition data for: F.US.DLU18 (FGBM201809_FUT_EUREX). ID: 26 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.DSXM18 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.TNAU18 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.709
Mapping F.US.EPU18 to ESU18. Service code: cme | 2021-06-18 08:57:57.709
SC Data - All Services | Starting real-time market data updates for: F.US.EPU18 (ESU18). ID: 27 Service code: cme | 2021-06-18 08:57:57.709
CQG WebAPI | Sending symbol resolution request for F.US.EPU18. ID: 74878 | 2021-06-18 08:57:57.709
SC Data - All Services | Requesting security definition data for: F.US.EPU18 (ESU18). ID: 27 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.CLEN18 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.CPEN18 | 2021-06-18 08:57:57.709
Mapping F.US.CPEN18 to HGN18. Service code: comex | 2021-06-18 08:57:57.709
SC Data - All Services | Starting real-time market data updates for: F.US.CPEN18 (HGN18). ID: 28 Service code: comex | 2021-06-18 08:57:57.709
CQG WebAPI | Sending symbol resolution request for F.US.CPEN18. ID: 74879 | 2021-06-18 08:57:57.709
SC Data - All Services | Requesting security definition data for: F.US.CPEN18 (HGN18). ID: 28 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.ZLEN18 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.ZSEN18 | 2021-06-18 08:57:57.709
Mapping F.US.ZSEN18 to ZSN18. Service code: cbot | 2021-06-18 08:57:57.709
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEN18 (ZSN18). ID: 29 Service code: cbot | 2021-06-18 08:57:57.709
CQG WebAPI | Sending symbol resolution request for F.US.ZSEN18. ID: 74880 | 2021-06-18 08:57:57.709
SC Data - All Services | Requesting security definition data for: F.US.ZSEN18 (ZSN18). ID: 29 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.ZWAN18 | 2021-06-18 08:57:57.709
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.CCEN18 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.KCEU18 | 2021-06-18 08:57:57.710
CQG WebAPI | Starting real-time market data updates for: F.US.KCEU18. ID: 30 Service code: cqg | 2021-06-18 08:57:57.710
CQG WebAPI | Sending symbol resolution request for F.US.KCEU18. ID: 74881 | 2021-06-18 08:57:57.710
CQG WebAPI | Requesting security definition data for: F.US.KCEU18. ID: 30 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.CLEN18 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.ZCEN18 | 2021-06-18 08:57:57.710
Mapping F.US.ZCEN18 to ZCN18. Service code: cbot | 2021-06-18 08:57:57.710
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEN18 (ZCN18). ID: 31 Service code: cbot | 2021-06-18 08:57:57.710
CQG WebAPI | Sending symbol resolution request for F.US.ZCEN18. ID: 74882 | 2021-06-18 08:57:57.710
SC Data - All Services | Requesting security definition data for: F.US.ZCEN18 (ZCN18). ID: 31 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.ZSEN18 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.DSXM18 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.ZWAN18 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.DDM18 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.SIEN18 | 2021-06-18 08:57:57.710
Mapping F.US.SIEN18 to SIN18. Service code: comex | 2021-06-18 08:57:57.710
SC Data - All Services | Starting real-time market data updates for: F.US.SIEN18 (SIN18). ID: 32 Service code: comex | 2021-06-18 08:57:57.710
CQG WebAPI | Sending symbol resolution request for F.US.SIEN18. ID: 74883 | 2021-06-18 08:57:57.710
SC Data - All Services | Requesting security definition data for: F.US.SIEN18 (SIN18). ID: 32 | 2021-06-18 08:57:57.710
Subscribing to symbol for symbol alert. F.US.SBEN18 | 2021-06-18 08:57:57.710
CQG WebAPI | Starting real-time market data updates for: F.US.SBEN18. ID: 33 Service code: cqg | 2021-06-18 08:57:57.710
CQG WebAPI | Sending symbol resolution request for F.US.SBEN18. ID: 74884 | 2021-06-18 08:57:57.711
CQG WebAPI | Requesting security definition data for: F.US.SBEN18. ID: 33 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.XWN18 | 2021-06-18 08:57:57.711
Mapping F.US.XWN18 to XWN18. Service code: cbot | 2021-06-18 08:57:57.711
SC Data - All Services | Starting real-time market data updates for: F.US.XWN18 (XWN18). ID: 34 Service code: cbot | 2021-06-18 08:57:57.711
CQG WebAPI | Sending symbol resolution request for F.US.XWN18. ID: 74885 | 2021-06-18 08:57:57.711
SC Data - All Services | Requesting security definition data for: F.US.XWN18 (XWN18). ID: 34 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.ZSEN18 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.SIEN18 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.DSXM18 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.DDM18 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.711
Mapping F.US.DSXU18 to FESX201809_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.711
SC Data - All Services | Starting real-time market data updates for: F.US.DSXU18 (FESX201809_FUT_EUREX). ID: 35 Service code: eurex | 2021-06-18 08:57:57.711
CQG WebAPI | Sending symbol resolution request for F.US.DSXU18. ID: 74886 | 2021-06-18 08:57:57.711
SC Data - All Services | Requesting security definition data for: F.US.DSXU18 (FESX201809_FUT_EUREX). ID: 35 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.YMU18 | 2021-06-18 08:57:57.711
Mapping F.US.YMU18 to YMU18. Service code: cbot | 2021-06-18 08:57:57.711
SC Data - All Services | Starting real-time market data updates for: F.US.YMU18 (YMU18). ID: 36 Service code: cbot | 2021-06-18 08:57:57.711
CQG WebAPI | Sending symbol resolution request for F.US.YMU18. ID: 74887 | 2021-06-18 08:57:57.711
SC Data - All Services | Requesting security definition data for: F.US.YMU18 (YMU18). ID: 36 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.ZWAN18 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.HEN18 | 2021-06-18 08:57:57.711
Mapping F.US.HEN18 to HEN18. Service code: cme | 2021-06-18 08:57:57.711
SC Data - All Services | Starting real-time market data updates for: F.US.HEN18 (HEN18). ID: 37 Service code: cme | 2021-06-18 08:57:57.711
CQG WebAPI | Sending symbol resolution request for F.US.HEN18. ID: 74888 | 2021-06-18 08:57:57.711
SC Data - All Services | Requesting security definition data for: F.US.HEN18 (HEN18). ID: 37 | 2021-06-18 08:57:57.711
Subscribing to symbol for symbol alert. F.US.CLEQ18 | 2021-06-18 08:57:57.711
Mapping F.US.CLEQ18 to CLQ18. Service code: nymex | 2021-06-18 08:57:57.711
SC Data - All Services | Starting real-time market data updates for: F.US.CLEQ18 (CLQ18). ID: 38 Service code: nymex | 2021-06-18 08:57:57.712
CQG WebAPI | Sending symbol resolution request for F.US.CLEQ18. ID: 74889 | 2021-06-18 08:57:57.712
SC Data - All Services | Requesting security definition data for: F.US.CLEQ18 (CLQ18). ID: 38 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.CLEQ18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.ZCEN18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.ZSEN18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.CPEN18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.GFQ18 | 2021-06-18 08:57:57.712
Mapping F.US.GFQ18 to GFQ18. Service code: cme | 2021-06-18 08:57:57.712
SC Data - All Services | Starting real-time market data updates for: F.US.GFQ18 (GFQ18). ID: 39 Service code: cme | 2021-06-18 08:57:57.712
CQG WebAPI | Sending symbol resolution request for F.US.GFQ18. ID: 74890 | 2021-06-18 08:57:57.712
SC Data - All Services | Requesting security definition data for: F.US.GFQ18 (GFQ18). ID: 39 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.ZLEN18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.GCEQ18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.SIEN18 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.ZWAU18 | 2021-06-18 08:57:57.712
Mapping F.US.ZWAU18 to ZWU18. Service code: cbot | 2021-06-18 08:57:57.712
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAU18 (ZWU18). ID: 40 Service code: cbot | 2021-06-18 08:57:57.712
CQG WebAPI | Sending symbol resolution request for F.US.ZWAU18. ID: 74891 | 2021-06-18 08:57:57.712
SC Data - All Services | Requesting security definition data for: F.US.ZWAU18 (ZWU18). ID: 40 | 2021-06-18 08:57:57.712
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.GCEQ18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.GFQ18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.CLEQ18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.ZWAU18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.ZSEN18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.CPEN18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.zwau18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.DDU18 | 2021-06-18 08:57:57.713
Mapping F.US.DDU18 to FDAX201809_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.713
SC Data - All Services | Starting real-time market data updates for: F.US.DDU18 (FDAX201809_FUT_EUREX). ID: 41 Service code: eurex | 2021-06-18 08:57:57.713
CQG WebAPI | Sending symbol resolution request for F.US.DDU18. ID: 74892 | 2021-06-18 08:57:57.713
SC Data - All Services | Requesting security definition data for: F.US.DDU18 (FDAX201809_FUT_EUREX). ID: 41 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.HEN18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.ZLEZ18 | 2021-06-18 08:57:57.713
Mapping F.US.ZLEZ18 to ZLZ18. Service code: cbot | 2021-06-18 08:57:57.713
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEZ18 (ZLZ18). ID: 42 Service code: cbot | 2021-06-18 08:57:57.713
CQG WebAPI | Sending symbol resolution request for F.US.ZLEZ18. ID: 74893 | 2021-06-18 08:57:57.713
SC Data - All Services | Requesting security definition data for: F.US.ZLEZ18 (ZLZ18). ID: 42 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.YMU18 | 2021-06-18 08:57:57.713
Subscribing to symbol for symbol alert. F.US.HEQ18 | 2021-06-18 08:57:57.713
Mapping F.US.HEQ18 to HEQ18. Service code: cme | 2021-06-18 08:57:57.714
SC Data - All Services | Starting real-time market data updates for: F.US.HEQ18 (HEQ18). ID: 43 Service code: cme | 2021-06-18 08:57:57.714
CQG WebAPI | Sending symbol resolution request for F.US.HEQ18. ID: 74894 | 2021-06-18 08:57:57.714
SC Data - All Services | Requesting security definition data for: F.US.HEQ18 (HEQ18). ID: 43 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.GFQ18 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.CLEQ18 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.ZWAU18 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.ZSEQ18 | 2021-06-18 08:57:57.714
Mapping F.US.ZSEQ18 to ZSQ18. Service code: cbot | 2021-06-18 08:57:57.714
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEQ18 (ZSQ18). ID: 44 Service code: cbot | 2021-06-18 08:57:57.714
CQG WebAPI | Sending symbol resolution request for F.US.ZSEQ18. ID: 74895 | 2021-06-18 08:57:57.714
SC Data - All Services | Requesting security definition data for: F.US.ZSEQ18 (ZSQ18). ID: 44 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.GCEQ18 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.ZSEX18 | 2021-06-18 08:57:57.714
Mapping F.US.ZSEX18 to ZSX18. Service code: cbot | 2021-06-18 08:57:57.714
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEX18 (ZSX18). ID: 45 Service code: cbot | 2021-06-18 08:57:57.714
CQG WebAPI | Sending symbol resolution request for F.US.ZSEX18. ID: 74896 | 2021-06-18 08:57:57.714
SC Data - All Services | Requesting security definition data for: F.US.ZSEX18 (ZSX18). ID: 45 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.CPEN18 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.714
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.HEQ18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.GFQ18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.CLEQ18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.XCN18 | 2021-06-18 08:57:57.715
Mapping F.US.XCN18 to XCN18. Service code: cbot | 2021-06-18 08:57:57.715
SC Data - All Services | Starting real-time market data updates for: F.US.XCN18 (XCN18). ID: 46 Service code: cbot | 2021-06-18 08:57:57.715
CQG WebAPI | Sending symbol resolution request for F.US.XCN18. ID: 74897 | 2021-06-18 08:57:57.715
SC Data - All Services | Requesting security definition data for: F.US.XCN18 (XCN18). ID: 46 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.ZSEX18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.GCEQ18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.CPEN18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.ENQU18 | 2021-06-18 08:57:57.715
Mapping F.US.ENQU18 to NQU18. Service code: cme | 2021-06-18 08:57:57.715
SC Data - All Services | Starting real-time market data updates for: F.US.ENQU18 (NQU18). ID: 47 Service code: cme | 2021-06-18 08:57:57.715
CQG WebAPI | Sending symbol resolution request for F.US.ENQU18. ID: 74898 | 2021-06-18 08:57:57.715
SC Data - All Services | Requesting security definition data for: F.US.ENQU18 (NQU18). ID: 47 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.TNAU18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.ZWAU18 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.SIEU18 | 2021-06-18 08:57:57.715
Mapping F.US.SIEU18 to SIU18. Service code: comex | 2021-06-18 08:57:57.715
SC Data - All Services | Starting real-time market data updates for: F.US.SIEU18 (SIU18). ID: 48 Service code: comex | 2021-06-18 08:57:57.715
CQG WebAPI | Sending symbol resolution request for F.US.SIEU18. ID: 74899 | 2021-06-18 08:57:57.715
SC Data - All Services | Requesting security definition data for: F.US.SIEU18 (SIU18). ID: 48 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.CPEU18 | 2021-06-18 08:57:57.715
Mapping F.US.CPEU18 to HGU18. Service code: comex | 2021-06-18 08:57:57.715
SC Data - All Services | Starting real-time market data updates for: F.US.CPEU18 (HGU18). ID: 49 Service code: comex | 2021-06-18 08:57:57.715
CQG WebAPI | Sending symbol resolution request for F.US.CPEU18. ID: 74900 | 2021-06-18 08:57:57.715
SC Data - All Services | Requesting security definition data for: F.US.CPEU18 (HGU18). ID: 49 | 2021-06-18 08:57:57.715
Subscribing to symbol for symbol alert. F.US.ZCEU18 | 2021-06-18 08:57:57.715
Mapping F.US.ZCEU18 to ZCU18. Service code: cbot | 2021-06-18 08:57:57.715
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEU18 (ZCU18). ID: 50 Service code: cbot | 2021-06-18 08:57:57.716
CQG WebAPI | Sending symbol resolution request for F.US.ZCEU18. ID: 74901 | 2021-06-18 08:57:57.716
SC Data - All Services | Requesting security definition data for: F.US.ZCEU18 (ZCU18). ID: 50 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.SIEU18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.CPEU18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.CLEQ18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.TYAU18 | 2021-06-18 08:57:57.716
Mapping F.US.TYAU18 to ZNU18. Service code: cbot | 2021-06-18 08:57:57.716
SC Data - All Services | Starting real-time market data updates for: F.US.TYAU18 (ZNU18). ID: 51 Service code: cbot | 2021-06-18 08:57:57.716
CQG WebAPI | Sending symbol resolution request for F.US.TYAU18. ID: 74902 | 2021-06-18 08:57:57.716
SC Data - All Services | Requesting security definition data for: F.US.TYAU18 (ZNU18). ID: 51 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.GFQ18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.ZWAU18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.ZSEX18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.GCEQ18 | 2021-06-18 08:57:57.716
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.GCEQ18 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.ZSEX18 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.SIEU18 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.DDU18 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.KCEZ18 | 2021-06-18 08:57:57.717
CQG WebAPI | Starting real-time market data updates for: F.US.KCEZ18. ID: 52 Service code: cqg | 2021-06-18 08:57:57.717
CQG WebAPI | Sending symbol resolution request for F.US.KCEZ18. ID: 74903 | 2021-06-18 08:57:57.717
CQG WebAPI | Requesting security definition data for: F.US.KCEZ18. ID: 52 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.GCEZ18 | 2021-06-18 08:57:57.717
Mapping F.US.GCEZ18 to GCZ18. Service code: comex | 2021-06-18 08:57:57.717
SC Data - All Services | Starting real-time market data updates for: F.US.GCEZ18 (GCZ18). ID: 53 Service code: comex | 2021-06-18 08:57:57.717
CQG WebAPI | Sending symbol resolution request for F.US.GCEZ18. ID: 74904 | 2021-06-18 08:57:57.717
SC Data - All Services | Requesting security definition data for: F.US.GCEZ18 (GCZ18). ID: 53 | 2021-06-18 08:57:57.717
Subscribing to symbol for symbol alert. F.US.SBEV18 | 2021-06-18 08:57:57.717
CQG WebAPI | Starting real-time market data updates for: F.US.SBEV18. ID: 54 Service code: cqg | 2021-06-18 08:57:57.718
CQG WebAPI | Sending symbol resolution request for F.US.SBEV18. ID: 74905 | 2021-06-18 08:57:57.718
CQG WebAPI | Requesting security definition data for: F.US.SBEV18. ID: 54 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.CTEH19 | 2021-06-18 08:57:57.718
CQG WebAPI | Starting real-time market data updates for: F.US.CTEH19. ID: 55 Service code: cqg | 2021-06-18 08:57:57.718
CQG WebAPI | Sending symbol resolution request for F.US.CTEH19. ID: 74906 | 2021-06-18 08:57:57.718
CQG WebAPI | Requesting security definition data for: F.US.CTEH19. ID: 55 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.GCEZ18 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.CPEU18 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.GFV18 | 2021-06-18 08:57:57.718
Mapping F.US.GFV18 to GFV18. Service code: cme | 2021-06-18 08:57:57.718
SC Data - All Services | Starting real-time market data updates for: F.US.GFV18 (GFV18). ID: 56 Service code: cme | 2021-06-18 08:57:57.718
CQG WebAPI | Sending symbol resolution request for F.US.GFV18. ID: 74907 | 2021-06-18 08:57:57.718
SC Data - All Services | Requesting security definition data for: F.US.GFV18 (GFV18). ID: 56 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.SBEV18 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.KCEZ18 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.RBEU18 | 2021-06-18 08:57:57.718
Mapping F.US.RBEU18 to RBU18. Service code: nymex | 2021-06-18 08:57:57.718
SC Data - All Services | Starting real-time market data updates for: F.US.RBEU18 (RBU18). ID: 57 Service code: nymex | 2021-06-18 08:57:57.718
CQG WebAPI | Sending symbol resolution request for F.US.RBEU18. ID: 74908 | 2021-06-18 08:57:57.718
SC Data - All Services | Requesting security definition data for: F.US.RBEU18 (RBU18). ID: 57 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.ZSEX18 | 2021-06-18 08:57:57.718
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.719
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.719
Subscribing to symbol for symbol alert. F.US.HEV18 | 2021-06-18 08:57:57.719
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.719
Subscribing to symbol for symbol alert. F.US.BP6U18 | 2021-06-18 08:57:57.719
Mapping F.US.BP6U18 to 6BU18. Service code: cme | 2021-06-18 08:57:57.719
SC Data - All Services | Starting real-time market data updates for: F.US.BP6U18 (6BU18). ID: 58 Service code: cme | 2021-06-18 08:57:57.719
CQG WebAPI | Sending symbol resolution request for F.US.BP6U18. ID: 74909 | 2021-06-18 08:57:57.719
SC Data - All Services | Requesting security definition data for: F.US.BP6U18 (6BU18). ID: 58 | 2021-06-18 08:57:57.719
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.719
Subscribing to symbol for symbol alert. F.US.CTEZ18 | 2021-06-18 08:57:57.719
Subscribing to symbol for symbol alert. F.US.YMU18 | 2021-06-18 08:57:57.719
Subscribing to symbol for symbol alert. F.US.FVAU18 | 2021-06-18 08:57:57.719
Mapping F.US.FVAU18 to ZFU18. Service code: cbot | 2021-06-18 08:57:57.719
SC Data - All Services | Starting real-time market data updates for: F.US.FVAU18 (ZFU18). ID: 59 Service code: cbot | 2021-06-18 08:57:57.719
CQG WebAPI | Sending symbol resolution request for F.US.FVAU18. ID: 74910 | 2021-06-18 08:57:57.719
SC Data - All Services | Requesting security definition data for: F.US.FVAU18 (ZFU18). ID: 59 | 2021-06-18 08:57:57.719
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.720
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.720
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.720
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.720
Subscribing to symbol for symbol alert. F.US.SBEH19 | 2021-06-18 08:57:57.720
CQG WebAPI | Starting real-time market data updates for: F.US.SBEH19. ID: 60 Service code: cqg | 2021-06-18 08:57:57.720
CQG WebAPI | Sending symbol resolution request for F.US.SBEH19. ID: 74911 | 2021-06-18 08:57:57.720
CQG WebAPI | Requesting security definition data for: F.US.SBEH19. ID: 60 | 2021-06-18 08:57:57.720
Subscribing to symbol for symbol alert. F.US.ULAU18 | 2021-06-18 08:57:57.720
Mapping F.US.ULAU18 to UBU18. Service code: cbot | 2021-06-18 08:57:57.720
SC Data - All Services | Starting real-time market data updates for: F.US.ULAU18 (UBU18). ID: 61 Service code: cbot | 2021-06-18 08:57:57.720
CQG WebAPI | Sending symbol resolution request for F.US.ULAU18. ID: 74912 | 2021-06-18 08:57:57.720
SC Data - All Services | Requesting security definition data for: F.US.ULAU18 (UBU18). ID: 61 | 2021-06-18 08:57:57.720
Subscribing to symbol for symbol alert. F.US.FVAU18 | 2021-06-18 08:57:57.720
Subscribing to symbol for symbol alert. F.US.HOEV18 | 2021-06-18 08:57:57.720
Mapping F.US.HOEV18 to HOV18. Service code: nymex | 2021-06-18 08:57:57.720
SC Data - All Services | Starting real-time market data updates for: F.US.HOEV18 (HOV18). ID: 62 Service code: nymex | 2021-06-18 08:57:57.720
CQG WebAPI | Sending symbol resolution request for F.US.HOEV18. ID: 74913 | 2021-06-18 08:57:57.720
SC Data - All Services | Requesting security definition data for: F.US.HOEV18 (HOV18). ID: 62 | 2021-06-18 08:57:57.720
Subscribing to symbol for symbol alert. F.US.CLEF19 | 2021-06-18 08:57:57.720
Mapping F.US.CLEF19 to CLF19. Service code: nymex | 2021-06-18 08:57:57.720
SC Data - All Services | Starting real-time market data updates for: F.US.CLEF19 (CLF19). ID: 63 Service code: nymex | 2021-06-18 08:57:57.720
CQG WebAPI | Sending symbol resolution request for F.US.CLEF19. ID: 74914 | 2021-06-18 08:57:57.720
SC Data - All Services | Requesting security definition data for: F.US.CLEF19 (CLF19). ID: 63 | 2021-06-18 08:57:57.720
Subscribing to symbol for symbol alert. F.US.PAEZ18 | 2021-06-18 08:57:57.720
Mapping F.US.PAEZ18 to PAZ18. Service code: nymex | 2021-06-18 08:57:57.720
SC Data - All Services | Starting real-time market data updates for: F.US.PAEZ18 (PAZ18). ID: 64 Service code: nymex | 2021-06-18 08:57:57.721
CQG WebAPI | Sending symbol resolution request for F.US.PAEZ18. ID: 74915 | 2021-06-18 08:57:57.721
SC Data - All Services | Requesting security definition data for: F.US.PAEZ18 (PAZ18). ID: 64 | 2021-06-18 08:57:57.721
Subscribing to symbol for symbol alert. F.US.DBU18 | 2021-06-18 08:57:57.721
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.721
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.721
Subscribing to symbol for symbol alert. F.US.DLU18 | 2021-06-18 08:57:57.721
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.721
Mapping F.US.DBZ18 to FGBL201812_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.721
SC Data - All Services | Starting real-time market data updates for: F.US.DBZ18 (FGBL201812_FUT_EUREX). ID: 65 Service code: eurex | 2021-06-18 08:57:57.721
CQG WebAPI | Sending symbol resolution request for F.US.DBZ18. ID: 74916 | 2021-06-18 08:57:57.721
SC Data - All Services | Requesting security definition data for: F.US.DBZ18 (FGBL201812_FUT_EUREX). ID: 65 | 2021-06-18 08:57:57.721
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.721
Mapping F.US.DLZ18 to FGBM201812_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.721
SC Data - All Services | Starting real-time market data updates for: F.US.DLZ18 (FGBM201812_FUT_EUREX). ID: 66 Service code: eurex | 2021-06-18 08:57:57.721
CQG WebAPI | Sending symbol resolution request for F.US.DLZ18. ID: 74917 | 2021-06-18 08:57:57.721
SC Data - All Services | Requesting security definition data for: F.US.DLZ18 (FGBM201812_FUT_EUREX). ID: 66 | 2021-06-18 08:57:57.721
Subscribing to symbol for symbol alert. F.US.SIEZ18 | 2021-06-18 08:57:57.721
Mapping F.US.SIEZ18 to SIZ18. Service code: comex | 2021-06-18 08:57:57.721
SC Data - All Services | Starting real-time market data updates for: F.US.SIEZ18 (SIZ18). ID: 67 Service code: comex | 2021-06-18 08:57:57.722
CQG WebAPI | Sending symbol resolution request for F.US.SIEZ18. ID: 74918 | 2021-06-18 08:57:57.722
SC Data - All Services | Requesting security definition data for: F.US.SIEZ18 (SIZ18). ID: 67 | 2021-06-18 08:57:57.722
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.722
Mapping F.US.DSXZ18 to FESX201812_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.722
SC Data - All Services | Starting real-time market data updates for: F.US.DSXZ18 (FESX201812_FUT_EUREX). ID: 68 Service code: eurex | 2021-06-18 08:57:57.722
CQG WebAPI | Sending symbol resolution request for F.US.DSXZ18. ID: 74919 | 2021-06-18 08:57:57.722
SC Data - All Services | Requesting security definition data for: F.US.DSXZ18 (FESX201812_FUT_EUREX). ID: 68 | 2021-06-18 08:57:57.722
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.722
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.722
Subscribing to symbol for symbol alert. F.US.CLEX18 | 2021-06-18 08:57:57.722
Mapping F.US.CLEX18 to CLX18. Service code: nymex | 2021-06-18 08:57:57.722
SC Data - All Services | Starting real-time market data updates for: F.US.CLEX18 (CLX18). ID: 69 Service code: nymex | 2021-06-18 08:57:57.722
CQG WebAPI | Sending symbol resolution request for F.US.CLEX18. ID: 74920 | 2021-06-18 08:57:57.722
SC Data - All Services | Requesting security definition data for: F.US.CLEX18 (CLX18). ID: 69 | 2021-06-18 08:57:57.722
Subscribing to symbol for symbol alert. F.US.EPU18 | 2021-06-18 08:57:57.722
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.722
Subscribing to symbol for symbol alert. F.US.HEZ18 | 2021-06-18 08:57:57.722
Mapping F.US.HEZ18 to HEZ18. Service code: cme | 2021-06-18 08:57:57.722
SC Data - All Services | Starting real-time market data updates for: F.US.HEZ18 (HEZ18). ID: 70 Service code: cme | 2021-06-18 08:57:57.722
CQG WebAPI | Sending symbol resolution request for F.US.HEZ18. ID: 74921 | 2021-06-18 08:57:57.722
SC Data - All Services | Requesting security definition data for: F.US.HEZ18 (HEZ18). ID: 70 | 2021-06-18 08:57:57.722
Subscribing to symbol for symbol alert. F.US.DA6U18 | 2021-06-18 08:57:57.722
Mapping F.US.DA6U18 to 6AU18. Service code: cme | 2021-06-18 08:57:57.722
SC Data - All Services | Starting real-time market data updates for: F.US.DA6U18 (6AU18). ID: 71 Service code: cme | 2021-06-18 08:57:57.722
CQG WebAPI | Sending symbol resolution request for F.US.DA6U18. ID: 74922 | 2021-06-18 08:57:57.722
SC Data - All Services | Requesting security definition data for: F.US.DA6U18 (6AU18). ID: 71 | 2021-06-18 08:57:57.722
Subscribing to symbol for symbol alert. F.US.CPEH19 | 2021-06-18 08:57:57.722
Mapping F.US.CPEH19 to HGH19. Service code: comex | 2021-06-18 08:57:57.723
SC Data - All Services | Starting real-time market data updates for: F.US.CPEH19 (HGH19). ID: 72 Service code: comex | 2021-06-18 08:57:57.723
CQG WebAPI | Sending symbol resolution request for F.US.CPEH19. ID: 74923 | 2021-06-18 08:57:57.723
SC Data - All Services | Requesting security definition data for: F.US.CPEH19 (HGH19). ID: 72 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.KWEZ18 | 2021-06-18 08:57:57.723
Mapping F.US.KWEZ18 to KEZ18. Service code: cbot | 2021-06-18 08:57:57.723
SC Data - All Services | Starting real-time market data updates for: F.US.KWEZ18 (KEZ18). ID: 73 Service code: cbot | 2021-06-18 08:57:57.723
CQG WebAPI | Sending symbol resolution request for F.US.KWEZ18. ID: 74924 | 2021-06-18 08:57:57.723
SC Data - All Services | Requesting security definition data for: F.US.KWEZ18 (KEZ18). ID: 73 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.HOEZ18 | 2021-06-18 08:57:57.723
Mapping F.US.HOEZ18 to HOZ18. Service code: nymex | 2021-06-18 08:57:57.723
SC Data - All Services | Starting real-time market data updates for: F.US.HOEZ18 (HOZ18). ID: 74 Service code: nymex | 2021-06-18 08:57:57.723
CQG WebAPI | Sending symbol resolution request for F.US.HOEZ18. ID: 74925 | 2021-06-18 08:57:57.723
SC Data - All Services | Requesting security definition data for: F.US.HOEZ18 (HOZ18). ID: 74 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.DA6Z18 | 2021-06-18 08:57:57.723
Mapping F.US.DA6Z18 to 6AZ18. Service code: cme | 2021-06-18 08:57:57.723
SC Data - All Services | Starting real-time market data updates for: F.US.DA6Z18 (6AZ18). ID: 75 Service code: cme | 2021-06-18 08:57:57.723
CQG WebAPI | Sending symbol resolution request for F.US.DA6Z18. ID: 74926 | 2021-06-18 08:57:57.723
SC Data - All Services | Requesting security definition data for: F.US.DA6Z18 (6AZ18). ID: 75 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.ZLEF19 | 2021-06-18 08:57:57.723
Mapping F.US.ZLEF19 to ZLF19. Service code: cbot | 2021-06-18 08:57:57.723
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEF19 (ZLF19). ID: 76 Service code: cbot | 2021-06-18 08:57:57.723
CQG WebAPI | Sending symbol resolution request for F.US.ZLEF19. ID: 74927 | 2021-06-18 08:57:57.723
SC Data - All Services | Requesting security definition data for: F.US.ZLEF19 (ZLF19). ID: 76 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.SBEV18 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.FVAZ18 | 2021-06-18 08:57:57.723
Mapping F.US.FVAZ18 to ZFZ18. Service code: cbot | 2021-06-18 08:57:57.723
SC Data - All Services | Starting real-time market data updates for: F.US.FVAZ18 (ZFZ18). ID: 77 Service code: cbot | 2021-06-18 08:57:57.723
CQG WebAPI | Sending symbol resolution request for F.US.FVAZ18. ID: 74928 | 2021-06-18 08:57:57.723
SC Data - All Services | Requesting security definition data for: F.US.FVAZ18 (ZFZ18). ID: 77 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.M6AZ18 | 2021-06-18 08:57:57.723
Mapping F.US.M6AZ18 to M6AZ18. Service code: cme | 2021-06-18 08:57:57.723
SC Data - All Services | Starting real-time market data updates for: F.US.M6AZ18 (M6AZ18). ID: 78 Service code: cme | 2021-06-18 08:57:57.723
CQG WebAPI | Sending symbol resolution request for F.US.M6AZ18. ID: 74929 | 2021-06-18 08:57:57.723
SC Data - All Services | Requesting security definition data for: F.US.M6AZ18 (M6AZ18). ID: 78 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.723
Mapping F.US.EPZ18 to ESZ18. Service code: cme | 2021-06-18 08:57:57.723
SC Data - All Services | Starting real-time market data updates for: F.US.EPZ18 (ESZ18). ID: 79 Service code: cme | 2021-06-18 08:57:57.723
CQG WebAPI | Sending symbol resolution request for F.US.EPZ18. ID: 74930 | 2021-06-18 08:57:57.723
SC Data - All Services | Requesting security definition data for: F.US.EPZ18 (ESZ18). ID: 79 | 2021-06-18 08:57:57.723
Subscribing to symbol for symbol alert. F.US.USAZ18 | 2021-06-18 08:57:57.723
Mapping F.US.USAZ18 to ZBZ18. Service code: cbot | 2021-06-18 08:57:57.723
SC Data - All Services | Starting real-time market data updates for: F.US.USAZ18 (ZBZ18). ID: 80 Service code: cbot | 2021-06-18 08:57:57.724
CQG WebAPI | Sending symbol resolution request for F.US.USAZ18. ID: 74931 | 2021-06-18 08:57:57.724
SC Data - All Services | Requesting security definition data for: F.US.USAZ18 (ZBZ18). ID: 80 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.USAZ18 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.DSXU18 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.CLEZ18 | 2021-06-18 08:57:57.724
Mapping F.US.CLEZ18 to CLZ18. Service code: nymex | 2021-06-18 08:57:57.724
SC Data - All Services | Starting real-time market data updates for: F.US.CLEZ18 (CLZ18). ID: 81 Service code: nymex | 2021-06-18 08:57:57.724
CQG WebAPI | Sending symbol resolution request for F.US.CLEZ18. ID: 74932 | 2021-06-18 08:57:57.724
SC Data - All Services | Requesting security definition data for: F.US.CLEZ18 (CLZ18). ID: 81 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.FVAZ18 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.GLEG19 | 2021-06-18 08:57:57.724
Mapping F.US.GLEG19 to LEG19. Service code: cme | 2021-06-18 08:57:57.724
SC Data - All Services | Starting real-time market data updates for: F.US.GLEG19 (LEG19). ID: 82 Service code: cme | 2021-06-18 08:57:57.724
CQG WebAPI | Sending symbol resolution request for F.US.GLEG19. ID: 74933 | 2021-06-18 08:57:57.724
SC Data - All Services | Requesting security definition data for: F.US.GLEG19 (LEG19). ID: 82 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.CLEF19 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.TYAZ18 | 2021-06-18 08:57:57.724
Mapping F.US.TYAZ18 to ZNZ18. Service code: cbot | 2021-06-18 08:57:57.724
SC Data - All Services | Starting real-time market data updates for: F.US.TYAZ18 (ZNZ18). ID: 83 Service code: cbot | 2021-06-18 08:57:57.724
CQG WebAPI | Sending symbol resolution request for F.US.TYAZ18. ID: 74934 | 2021-06-18 08:57:57.724
SC Data - All Services | Requesting security definition data for: F.US.TYAZ18 (ZNZ18). ID: 83 | 2021-06-18 08:57:57.724
Subscribing to symbol for symbol alert. F.US.GCEG19 | 2021-06-18 08:57:57.724
Mapping F.US.GCEG19 to GCG19. Service code: comex | 2021-06-18 08:57:57.724
SC Data - All Services | Starting real-time market data updates for: F.US.GCEG19 (GCG19). ID: 84 Service code: comex | 2021-06-18 08:57:57.724
CQG WebAPI | Sending symbol resolution request for F.US.GCEG19. ID: 74935 | 2021-06-18 08:57:57.725
SC Data - All Services | Requesting security definition data for: F.US.GCEG19 (GCG19). ID: 84 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.GCEG19 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.TYAZ18 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.CTEZ18 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.CPEH19 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.TNAZ18 | 2021-06-18 08:57:57.725
Mapping F.US.TNAZ18 to TNZ18. Service code: cbot | 2021-06-18 08:57:57.725
SC Data - All Services | Starting real-time market data updates for: F.US.TNAZ18 (TNZ18). ID: 85 Service code: cbot | 2021-06-18 08:57:57.725
CQG WebAPI | Sending symbol resolution request for F.US.TNAZ18. ID: 74936 | 2021-06-18 08:57:57.725
SC Data - All Services | Requesting security definition data for: F.US.TNAZ18 (TNZ18). ID: 85 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.ULAZ18 | 2021-06-18 08:57:57.725
Mapping F.US.ULAZ18 to UBZ18. Service code: cbot | 2021-06-18 08:57:57.725
SC Data - All Services | Starting real-time market data updates for: F.US.ULAZ18 (UBZ18). ID: 86 Service code: cbot | 2021-06-18 08:57:57.725
CQG WebAPI | Sending symbol resolution request for F.US.ULAZ18. ID: 74937 | 2021-06-18 08:57:57.725
SC Data - All Services | Requesting security definition data for: F.US.ULAZ18 (UBZ18). ID: 86 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.FVAZ18 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.JY6Z18 | 2021-06-18 08:57:57.725
Mapping F.US.JY6Z18 to 6JZ18. Service code: cme | 2021-06-18 08:57:57.725
SC Data - All Services | Starting real-time market data updates for: F.US.JY6Z18 (6JZ18). ID: 87 Service code: cme | 2021-06-18 08:57:57.725
CQG WebAPI | Sending symbol resolution request for F.US.JY6Z18. ID: 74938 | 2021-06-18 08:57:57.725
SC Data - All Services | Requesting security definition data for: F.US.JY6Z18 (6JZ18). ID: 87 | 2021-06-18 08:57:57.725
Subscribing to symbol for symbol alert. F.US.PLEF19 | 2021-06-18 08:57:57.725
Mapping F.US.PLEF19 to PLF19. Service code: nymex | 2021-06-18 08:57:57.725
SC Data - All Services | Starting real-time market data updates for: F.US.PLEF19 (PLF19). ID: 88 Service code: nymex | 2021-06-18 08:57:57.726
CQG WebAPI | Sending symbol resolution request for F.US.PLEF19. ID: 74939 | 2021-06-18 08:57:57.726
SC Data - All Services | Requesting security definition data for: F.US.PLEF19 (PLF19). ID: 88 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.KCEH19 | 2021-06-18 08:57:57.726
CQG WebAPI | Starting real-time market data updates for: F.US.KCEH19. ID: 89 Service code: cqg | 2021-06-18 08:57:57.726
CQG WebAPI | Sending symbol resolution request for F.US.KCEH19. ID: 74940 | 2021-06-18 08:57:57.726
CQG WebAPI | Requesting security definition data for: F.US.KCEH19. ID: 89 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.ULAZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.USAZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.TYAZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.CTEH19 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.KWEK19 | 2021-06-18 08:57:57.726
Mapping F.US.KWEK19 to KEK19. Service code: cbot | 2021-06-18 08:57:57.726
SC Data - All Services | Starting real-time market data updates for: F.US.KWEK19 (KEK19). ID: 90 Service code: cbot | 2021-06-18 08:57:57.726
CQG WebAPI | Sending symbol resolution request for F.US.KWEK19. ID: 74941 | 2021-06-18 08:57:57.726
SC Data - All Services | Requesting security definition data for: F.US.KWEK19 (KEK19). ID: 90 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.CTEZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.TNAZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.FVAZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.TUAZ18 | 2021-06-18 08:57:57.726
Mapping F.US.TUAZ18 to ZTZ18. Service code: cbot | 2021-06-18 08:57:57.726
SC Data - All Services | Starting real-time market data updates for: F.US.TUAZ18 (ZTZ18). ID: 91 Service code: cbot | 2021-06-18 08:57:57.726
CQG WebAPI | Sending symbol resolution request for F.US.TUAZ18. ID: 74942 | 2021-06-18 08:57:57.726
SC Data - All Services | Requesting security definition data for: F.US.TUAZ18 (ZTZ18). ID: 91 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.ZSEK19 | 2021-06-18 08:57:57.726
Mapping F.US.ZSEK19 to ZSK19. Service code: cbot | 2021-06-18 08:57:57.726
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEK19 (ZSK19). ID: 92 Service code: cbot | 2021-06-18 08:57:57.726
CQG WebAPI | Sending symbol resolution request for F.US.ZSEK19. ID: 74943 | 2021-06-18 08:57:57.726
SC Data - All Services | Requesting security definition data for: F.US.ZSEK19 (ZSK19). ID: 92 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.ZCEK19 | 2021-06-18 08:57:57.726
Mapping F.US.ZCEK19 to ZCK19. Service code: cbot | 2021-06-18 08:57:57.726
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEK19 (ZCK19). ID: 93 Service code: cbot | 2021-06-18 08:57:57.726
CQG WebAPI | Sending symbol resolution request for F.US.ZCEK19. ID: 74944 | 2021-06-18 08:57:57.726
SC Data - All Services | Requesting security definition data for: F.US.ZCEK19 (ZCK19). ID: 93 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.RBEX18 | 2021-06-18 08:57:57.726
Mapping F.US.RBEX18 to RBX18. Service code: nymex | 2021-06-18 08:57:57.726
SC Data - All Services | Starting real-time market data updates for: F.US.RBEX18 (RBX18). ID: 94 Service code: nymex | 2021-06-18 08:57:57.726
CQG WebAPI | Sending symbol resolution request for F.US.RBEX18. ID: 74945 | 2021-06-18 08:57:57.726
SC Data - All Services | Requesting security definition data for: F.US.RBEX18 (RBX18). ID: 94 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.ZLEZ18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.JY6Z18 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.CPEZ18 | 2021-06-18 08:57:57.726
Mapping F.US.CPEZ18 to HGZ18. Service code: comex | 2021-06-18 08:57:57.726
SC Data - All Services | Starting real-time market data updates for: F.US.CPEZ18 (HGZ18). ID: 95 Service code: comex | 2021-06-18 08:57:57.726
CQG WebAPI | Sending symbol resolution request for F.US.CPEZ18. ID: 74946 | 2021-06-18 08:57:57.726
SC Data - All Services | Requesting security definition data for: F.US.CPEZ18 (HGZ18). ID: 95 | 2021-06-18 08:57:57.726
Subscribing to symbol for symbol alert. F.US.M6EZ18 | 2021-06-18 08:57:57.726
Mapping F.US.M6EZ18 to M6EZ18. Service code: cme | 2021-06-18 08:57:57.726
SC Data - All Services | Starting real-time market data updates for: F.US.M6EZ18 (M6EZ18). ID: 96 Service code: cme | 2021-06-18 08:57:57.727
CQG WebAPI | Sending symbol resolution request for F.US.M6EZ18. ID: 74947 | 2021-06-18 08:57:57.727
SC Data - All Services | Requesting security definition data for: F.US.M6EZ18 (M6EZ18). ID: 96 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.TYAZ18 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.FVAZ18 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.ZMEZ18 | 2021-06-18 08:57:57.727
Mapping F.US.ZMEZ18 to ZMZ18. Service code: cbot | 2021-06-18 08:57:57.727
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEZ18 (ZMZ18). ID: 97 Service code: cbot | 2021-06-18 08:57:57.727
CQG WebAPI | Sending symbol resolution request for F.US.ZMEZ18. ID: 74948 | 2021-06-18 08:57:57.727
SC Data - All Services | Requesting security definition data for: F.US.ZMEZ18 (ZMZ18). ID: 97 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.ZCEN19 | 2021-06-18 08:57:57.727
Mapping F.US.ZCEN19 to ZCN19. Service code: cbot | 2021-06-18 08:57:57.727
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEN19 (ZCN19). ID: 98 Service code: cbot | 2021-06-18 08:57:57.727
CQG WebAPI | Sending symbol resolution request for F.US.ZCEN19. ID: 74949 | 2021-06-18 08:57:57.727
SC Data - All Services | Requesting security definition data for: F.US.ZCEN19 (ZCN19). ID: 98 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.DA6Z18 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.EU6Z18 | 2021-06-18 08:57:57.727
Mapping F.US.EU6Z18 to 6EZ18. Service code: cme | 2021-06-18 08:57:57.727
SC Data - All Services | Starting real-time market data updates for: F.US.EU6Z18 (6EZ18). ID: 99 Service code: cme | 2021-06-18 08:57:57.727
CQG WebAPI | Sending symbol resolution request for F.US.EU6Z18. ID: 74950 | 2021-06-18 08:57:57.727
SC Data - All Services | Requesting security definition data for: F.US.EU6Z18 (6EZ18). ID: 99 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.TNAZ18 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.NGEF19 | 2021-06-18 08:57:57.727
Mapping F.US.NGEF19 to NGF19. Service code: nymex | 2021-06-18 08:57:57.727
SC Data - All Services | Starting real-time market data updates for: F.US.NGEF19 (NGF19). ID: 100 Service code: nymex | 2021-06-18 08:57:57.727
CQG WebAPI | Sending symbol resolution request for F.US.NGEF19. ID: 74951 | 2021-06-18 08:57:57.727
SC Data - All Services | Requesting security definition data for: F.US.NGEF19 (NGF19). ID: 100 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.HEZ18 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.GLEG19 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.GFX18 | 2021-06-18 08:57:57.727
Mapping F.US.GFX18 to GFX18. Service code: cme | 2021-06-18 08:57:57.727
SC Data - All Services | Starting real-time market data updates for: F.US.GFX18 (GFX18). ID: 101 Service code: cme | 2021-06-18 08:57:57.727
CQG WebAPI | Sending symbol resolution request for F.US.GFX18. ID: 74952 | 2021-06-18 08:57:57.727
SC Data - All Services | Requesting security definition data for: F.US.GFX18 (GFX18). ID: 101 | 2021-06-18 08:57:57.727
Subscribing to symbol for symbol alert. F.US.GCEZ18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.SF6Z18 | 2021-06-18 08:57:57.728
Mapping F.US.SF6Z18 to 6SZ18. Service code: cme | 2021-06-18 08:57:57.728
SC Data - All Services | Starting real-time market data updates for: F.US.SF6Z18 (6SZ18). ID: 102 Service code: cme | 2021-06-18 08:57:57.728
CQG WebAPI | Sending symbol resolution request for F.US.SF6Z18. ID: 74953 | 2021-06-18 08:57:57.728
SC Data - All Services | Requesting security definition data for: F.US.SF6Z18 (6SZ18). ID: 102 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.GFX18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.TYAZ18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.FVAZ18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.TUAZ18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.FBTPZ18 | 2021-06-18 08:57:57.728
Mapping F.US.FBTPZ18 to FBTP201812_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.728
SC Data - All Services | Starting real-time market data updates for: F.US.FBTPZ18 (FBTP201812_FUT_EUREX). ID: 103 Service code: eurex | 2021-06-18 08:57:57.728
CQG WebAPI | Sending symbol resolution request for F.US.FBTPZ18. ID: 74954 | 2021-06-18 08:57:57.728
SC Data - All Services | Requesting security definition data for: F.US.FBTPZ18 (FBTP201812_FUT_EUREX). ID: 103 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.GLEZ18 | 2021-06-18 08:57:57.728
Mapping F.US.GLEZ18 to LEZ18. Service code: cme | 2021-06-18 08:57:57.728
SC Data - All Services | Starting real-time market data updates for: F.US.GLEZ18 (LEZ18). ID: 104 Service code: cme | 2021-06-18 08:57:57.728
CQG WebAPI | Sending symbol resolution request for F.US.GLEZ18. ID: 74955 | 2021-06-18 08:57:57.728
SC Data - All Services | Requesting security definition data for: F.US.GLEZ18 (LEZ18). ID: 104 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.USAZ18 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.GLEG19 | 2021-06-18 08:57:57.728
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.HEZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.GLEZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.FBTPZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.EU6Z18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.BP6Z18 | 2021-06-18 08:57:57.729
Mapping F.US.BP6Z18 to 6BZ18. Service code: cme | 2021-06-18 08:57:57.729
SC Data - All Services | Starting real-time market data updates for: F.US.BP6Z18 (6BZ18). ID: 105 Service code: cme | 2021-06-18 08:57:57.729
CQG WebAPI | Sending symbol resolution request for F.US.BP6Z18. ID: 74956 | 2021-06-18 08:57:57.729
SC Data - All Services | Requesting security definition data for: F.US.BP6Z18 (6BZ18). ID: 105 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.SF6Z18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.USAZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.ULAZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.GLEG19 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.CPEH19 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.ZLEZ18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.JY6Z18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.CA6Z18 | 2021-06-18 08:57:57.729
Mapping F.US.CA6Z18 to 6CZ18. Service code: cme | 2021-06-18 08:57:57.729
SC Data - All Services | Starting real-time market data updates for: F.US.CA6Z18 (6CZ18). ID: 106 Service code: cme | 2021-06-18 08:57:57.729
CQG WebAPI | Sending symbol resolution request for F.US.CA6Z18. ID: 74957 | 2021-06-18 08:57:57.729
SC Data - All Services | Requesting security definition data for: F.US.CA6Z18 (6CZ18). ID: 106 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.GFX18 | 2021-06-18 08:57:57.729
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.ULAZ18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.FBTPZ18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.RBEG19 | 2021-06-18 08:57:57.730
Mapping F.US.RBEG19 to RBG19. Service code: nymex | 2021-06-18 08:57:57.730
SC Data - All Services | Starting real-time market data updates for: F.US.RBEG19 (RBG19). ID: 107 Service code: nymex | 2021-06-18 08:57:57.730
CQG WebAPI | Sending symbol resolution request for F.US.RBEG19. ID: 74958 | 2021-06-18 08:57:57.730
SC Data - All Services | Requesting security definition data for: F.US.RBEG19 (RBG19). ID: 107 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.USAZ18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.BP6Z18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.HEG19 | 2021-06-18 08:57:57.730
Mapping F.US.HEG19 to HEG19. Service code: cme | 2021-06-18 08:57:57.730
SC Data - All Services | Starting real-time market data updates for: F.US.HEG19 (HEG19). ID: 108 Service code: cme | 2021-06-18 08:57:57.730
CQG WebAPI | Sending symbol resolution request for F.US.HEG19. ID: 74959 | 2021-06-18 08:57:57.730
SC Data - All Services | Requesting security definition data for: F.US.HEG19 (HEG19). ID: 108 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.NE6Z18 | 2021-06-18 08:57:57.730
Mapping F.US.NE6Z18 to 6NZ18. Service code: cme | 2021-06-18 08:57:57.730
SC Data - All Services | Starting real-time market data updates for: F.US.NE6Z18 (6NZ18). ID: 109 Service code: cme | 2021-06-18 08:57:57.730
CQG WebAPI | Sending symbol resolution request for F.US.NE6Z18. ID: 74960 | 2021-06-18 08:57:57.730
SC Data - All Services | Requesting security definition data for: F.US.NE6Z18 (6NZ18). ID: 109 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.TNAZ18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.TYAZ18 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.GLEG19 | 2021-06-18 08:57:57.730
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.USAZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.TYAZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.FBTPZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.BP6Z18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.FVAZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.EU6Z18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.JY6Z18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.DA6Z18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.SF6Z18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.ULAZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.CLEZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.TUAZ18 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.YMZ18 | 2021-06-18 08:57:57.731
Mapping F.US.YMZ18 to YMZ18. Service code: cbot | 2021-06-18 08:57:57.731
SC Data - All Services | Starting real-time market data updates for: F.US.YMZ18 (YMZ18). ID: 110 Service code: cbot | 2021-06-18 08:57:57.731
CQG WebAPI | Sending symbol resolution request for F.US.YMZ18. ID: 74961 | 2021-06-18 08:57:57.731
SC Data - All Services | Requesting security definition data for: F.US.YMZ18 (YMZ18). ID: 110 | 2021-06-18 08:57:57.731
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.FBTPZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.TNAZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.DLZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.CPEZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.TYAZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.USAZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.HEG19 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.ZLEH19 | 2021-06-18 08:57:57.732
Mapping F.US.ZLEH19 to ZLH19. Service code: cbot | 2021-06-18 08:57:57.732
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEH19 (ZLH19). ID: 111 Service code: cbot | 2021-06-18 08:57:57.732
CQG WebAPI | Sending symbol resolution request for F.US.ZLEH19. ID: 74962 | 2021-06-18 08:57:57.732
SC Data - All Services | Requesting security definition data for: F.US.ZLEH19 (ZLH19). ID: 111 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.KWEK19 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.ZCEK19 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.ZCEZ18 | 2021-06-18 08:57:57.732
Mapping F.US.ZCEZ18 to ZCZ18. Service code: cbot | 2021-06-18 08:57:57.732
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEZ18 (ZCZ18). ID: 112 Service code: cbot | 2021-06-18 08:57:57.732
CQG WebAPI | Sending symbol resolution request for F.US.ZCEZ18. ID: 74963 | 2021-06-18 08:57:57.732
SC Data - All Services | Requesting security definition data for: F.US.ZCEZ18 (ZCZ18). ID: 112 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.ULAZ18 | 2021-06-18 08:57:57.732
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.DBZ18 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.ULAZ18 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.FBTPZ18 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.TYAZ18 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.USAZ18 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.CA6Z18 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.DA6Z18 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.733
Mapping F.US.USAH19 to ZBH19. Service code: cbot | 2021-06-18 08:57:57.733
SC Data - All Services | Starting real-time market data updates for: F.US.USAH19 (ZBH19). ID: 113 Service code: cbot | 2021-06-18 08:57:57.733
CQG WebAPI | Sending symbol resolution request for F.US.USAH19. ID: 74964 | 2021-06-18 08:57:57.733
SC Data - All Services | Requesting security definition data for: F.US.USAH19 (ZBH19). ID: 113 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.ULAH19 | 2021-06-18 08:57:57.733
Mapping F.US.ULAH19 to UBH19. Service code: cbot | 2021-06-18 08:57:57.733
SC Data - All Services | Starting real-time market data updates for: F.US.ULAH19 (UBH19). ID: 114 Service code: cbot | 2021-06-18 08:57:57.733
CQG WebAPI | Sending symbol resolution request for F.US.ULAH19. ID: 74965 | 2021-06-18 08:57:57.733
SC Data - All Services | Requesting security definition data for: F.US.ULAH19 (UBH19). ID: 114 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.FVAH19 | 2021-06-18 08:57:57.733
Mapping F.US.FVAH19 to ZFH19. Service code: cbot | 2021-06-18 08:57:57.733
SC Data - All Services | Starting real-time market data updates for: F.US.FVAH19 (ZFH19). ID: 115 Service code: cbot | 2021-06-18 08:57:57.733
CQG WebAPI | Sending symbol resolution request for F.US.FVAH19. ID: 74966 | 2021-06-18 08:57:57.733
SC Data - All Services | Requesting security definition data for: F.US.FVAH19 (ZFH19). ID: 115 | 2021-06-18 08:57:57.733
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.733
Mapping F.US.DBH19 to FGBL201903_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.733
SC Data - All Services | Starting real-time market data updates for: F.US.DBH19 (FGBL201903_FUT_EUREX). ID: 116 Service code: eurex | 2021-06-18 08:57:57.734
CQG WebAPI | Sending symbol resolution request for F.US.DBH19. ID: 74967 | 2021-06-18 08:57:57.734
SC Data - All Services | Requesting security definition data for: F.US.DBH19 (FGBL201903_FUT_EUREX). ID: 116 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.FBTPH19 | 2021-06-18 08:57:57.734
Mapping F.US.FBTPH19 to FBTP201903_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.734
SC Data - All Services | Starting real-time market data updates for: F.US.FBTPH19 (FBTP201903_FUT_EUREX). ID: 117 Service code: eurex | 2021-06-18 08:57:57.734
CQG WebAPI | Sending symbol resolution request for F.US.FBTPH19. ID: 74968 | 2021-06-18 08:57:57.734
SC Data - All Services | Requesting security definition data for: F.US.FBTPH19 (FBTP201903_FUT_EUREX). ID: 117 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.734
Mapping F.US.TYAH19 to ZNH19. Service code: cbot | 2021-06-18 08:57:57.734
SC Data - All Services | Starting real-time market data updates for: F.US.TYAH19 (ZNH19). ID: 118 Service code: cbot | 2021-06-18 08:57:57.734
CQG WebAPI | Sending symbol resolution request for F.US.TYAH19. ID: 74969 | 2021-06-18 08:57:57.734
SC Data - All Services | Requesting security definition data for: F.US.TYAH19 (ZNH19). ID: 118 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.ZCEH19 | 2021-06-18 08:57:57.734
Mapping F.US.ZCEH19 to ZCH19. Service code: cbot | 2021-06-18 08:57:57.734
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEH19 (ZCH19). ID: 119 Service code: cbot | 2021-06-18 08:57:57.734
CQG WebAPI | Sending symbol resolution request for F.US.ZCEH19. ID: 74970 | 2021-06-18 08:57:57.734
SC Data - All Services | Requesting security definition data for: F.US.ZCEH19 (ZCH19). ID: 119 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.GLEJ19 | 2021-06-18 08:57:57.734
Mapping F.US.GLEJ19 to LEJ19. Service code: cme | 2021-06-18 08:57:57.734
SC Data - All Services | Starting real-time market data updates for: F.US.GLEJ19 (LEJ19). ID: 120 Service code: cme | 2021-06-18 08:57:57.734
CQG WebAPI | Sending symbol resolution request for F.US.GLEJ19. ID: 74971 | 2021-06-18 08:57:57.734
SC Data - All Services | Requesting security definition data for: F.US.GLEJ19 (LEJ19). ID: 120 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.GFJ19 | 2021-06-18 08:57:57.734
Mapping F.US.GFJ19 to GFJ19. Service code: cme | 2021-06-18 08:57:57.734
SC Data - All Services | Starting real-time market data updates for: F.US.GFJ19 (GFJ19). ID: 121 Service code: cme | 2021-06-18 08:57:57.734
CQG WebAPI | Sending symbol resolution request for F.US.GFJ19. ID: 74972 | 2021-06-18 08:57:57.734
SC Data - All Services | Requesting security definition data for: F.US.GFJ19 (GFJ19). ID: 121 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.734
Mapping F.US.EPH19 to ESH19. Service code: cme | 2021-06-18 08:57:57.734
SC Data - All Services | Starting real-time market data updates for: F.US.EPH19 (ESH19). ID: 122 Service code: cme | 2021-06-18 08:57:57.734
CQG WebAPI | Sending symbol resolution request for F.US.EPH19. ID: 74973 | 2021-06-18 08:57:57.734
SC Data - All Services | Requesting security definition data for: F.US.EPH19 (ESH19). ID: 122 | 2021-06-18 08:57:57.734
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.GLEJ19 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.FVAH19 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.HEJ19 | 2021-06-18 08:57:57.735
Mapping F.US.HEJ19 to HEJ19. Service code: cme | 2021-06-18 08:57:57.735
SC Data - All Services | Starting real-time market data updates for: F.US.HEJ19 (HEJ19). ID: 123 Service code: cme | 2021-06-18 08:57:57.735
CQG WebAPI | Sending symbol resolution request for F.US.HEJ19. ID: 74974 | 2021-06-18 08:57:57.735
SC Data - All Services | Requesting security definition data for: F.US.HEJ19 (HEJ19). ID: 123 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.FBTPH19 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.SF6H19 | 2021-06-18 08:57:57.735
Mapping F.US.SF6H19 to 6SH19. Service code: cme | 2021-06-18 08:57:57.735
SC Data - All Services | Starting real-time market data updates for: F.US.SF6H19 (6SH19). ID: 124 Service code: cme | 2021-06-18 08:57:57.735
CQG WebAPI | Sending symbol resolution request for F.US.SF6H19. ID: 74975 | 2021-06-18 08:57:57.735
SC Data - All Services | Requesting security definition data for: F.US.SF6H19 (6SH19). ID: 124 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.PLEF19 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.DLH19 | 2021-06-18 08:57:57.735
Mapping F.US.DLH19 to FGBM201903_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.735
SC Data - All Services | Starting real-time market data updates for: F.US.DLH19 (FGBM201903_FUT_EUREX). ID: 125 Service code: eurex | 2021-06-18 08:57:57.735
CQG WebAPI | Sending symbol resolution request for F.US.DLH19. ID: 74976 | 2021-06-18 08:57:57.735
SC Data - All Services | Requesting security definition data for: F.US.DLH19 (FGBM201903_FUT_EUREX). ID: 125 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.KWEH19 | 2021-06-18 08:57:57.735
Mapping F.US.KWEH19 to KEH19. Service code: cbot | 2021-06-18 08:57:57.735
SC Data - All Services | Starting real-time market data updates for: F.US.KWEH19 (KEH19). ID: 126 Service code: cbot | 2021-06-18 08:57:57.735
CQG WebAPI | Sending symbol resolution request for F.US.KWEH19. ID: 74977 | 2021-06-18 08:57:57.735
SC Data - All Services | Requesting security definition data for: F.US.KWEH19 (KEH19). ID: 126 | 2021-06-18 08:57:57.735
Subscribing to symbol for symbol alert. F.US.FBTPH19 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.GLEJ19 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.DSXZ18 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.736
Mapping F.US.DSXH19 to FESX201903_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.736
SC Data - All Services | Starting real-time market data updates for: F.US.DSXH19 (FESX201903_FUT_EUREX). ID: 127 Service code: eurex | 2021-06-18 08:57:57.736
CQG WebAPI | Sending symbol resolution request for F.US.DSXH19. ID: 74978 | 2021-06-18 08:57:57.736
SC Data - All Services | Requesting security definition data for: F.US.DSXH19 (FESX201903_FUT_EUREX). ID: 127 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.TUAH19 | 2021-06-18 08:57:57.736
Mapping F.US.TUAH19 to ZTH19. Service code: cbot | 2021-06-18 08:57:57.736
SC Data - All Services | Starting real-time market data updates for: F.US.TUAH19 (ZTH19). ID: 128 Service code: cbot | 2021-06-18 08:57:57.736
CQG WebAPI | Sending symbol resolution request for F.US.TUAH19. ID: 74979 | 2021-06-18 08:57:57.736
SC Data - All Services | Requesting security definition data for: F.US.TUAH19 (ZTH19). ID: 128 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.GLEG19 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.DLH19 | 2021-06-18 08:57:57.736
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.FBTPH19 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.HEJ19 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.TNAH19 | 2021-06-18 08:57:57.737
Mapping F.US.TNAH19 to TNH19. Service code: cbot | 2021-06-18 08:57:57.737
SC Data - All Services | Starting real-time market data updates for: F.US.TNAH19 (TNH19). ID: 129 Service code: cbot | 2021-06-18 08:57:57.737
CQG WebAPI | Sending symbol resolution request for F.US.TNAH19. ID: 74980 | 2021-06-18 08:57:57.737
SC Data - All Services | Requesting security definition data for: F.US.TNAH19 (TNH19). ID: 129 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.CA6H19 | 2021-06-18 08:57:57.737
Mapping F.US.CA6H19 to 6CH19. Service code: cme | 2021-06-18 08:57:57.737
SC Data - All Services | Starting real-time market data updates for: F.US.CA6H19 (6CH19). ID: 130 Service code: cme | 2021-06-18 08:57:57.737
CQG WebAPI | Sending symbol resolution request for F.US.CA6H19. ID: 74981 | 2021-06-18 08:57:57.737
SC Data - All Services | Requesting security definition data for: F.US.CA6H19 (6CH19). ID: 130 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.DLH19 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.TUAH19 | 2021-06-18 08:57:57.737
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.738
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.738
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.738
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.738
Subscribing to symbol for symbol alert. F.US.FBTPH19 | 2021-06-18 08:57:57.738
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.738
Subscribing to symbol for symbol alert. F.US.DLH19 | 2021-06-18 08:57:57.738
Subscribing to symbol for symbol alert. F.US.OJEH19 | 2021-06-18 08:57:57.738
CQG WebAPI | Starting real-time market data updates for: F.US.OJEH19. ID: 131 Service code: cqg | 2021-06-18 08:57:57.738
CQG WebAPI | Sending symbol resolution request for F.US.OJEH19. ID: 74982 | 2021-06-18 08:57:57.738
CQG WebAPI | Requesting security definition data for: F.US.OJEH19. ID: 131 | 2021-06-18 08:57:57.738
Subscribing to symbol for symbol alert. F.US.TNAH19 | 2021-06-18 08:57:57.738
Subscribing to symbol for symbol alert. F.US.FBTSH19 | 2021-06-18 08:57:57.738
Mapping F.US.FBTSH19 to FBTS201903_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.738
SC Data - All Services | Starting real-time market data updates for: F.US.FBTSH19 (FBTS201903_FUT_EUREX). ID: 132 Service code: eurex | 2021-06-18 08:57:57.739
CQG WebAPI | Sending symbol resolution request for F.US.FBTSH19. ID: 74983 | 2021-06-18 08:57:57.739
SC Data - All Services | Requesting security definition data for: F.US.FBTSH19 (FBTS201903_FUT_EUREX). ID: 132 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.FBTSH19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.GFJ19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.ENQH19 | 2021-06-18 08:57:57.739
Mapping F.US.ENQH19 to NQH19. Service code: cme | 2021-06-18 08:57:57.739
SC Data - All Services | Starting real-time market data updates for: F.US.ENQH19 (NQH19). ID: 133 Service code: cme | 2021-06-18 08:57:57.739
CQG WebAPI | Sending symbol resolution request for F.US.ENQH19. ID: 74984 | 2021-06-18 08:57:57.739
SC Data - All Services | Requesting security definition data for: F.US.ENQH19 (NQH19). ID: 133 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.CPEH19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.SF6H19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.FOATH19 | 2021-06-18 08:57:57.739
Mapping F.US.FOATH19 to FOAT201903_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.739
SC Data - All Services | Starting real-time market data updates for: F.US.FOATH19 (FOAT201903_FUT_EUREX). ID: 134 Service code: eurex | 2021-06-18 08:57:57.739
CQG WebAPI | Sending symbol resolution request for F.US.FOATH19. ID: 74985 | 2021-06-18 08:57:57.739
SC Data - All Services | Requesting security definition data for: F.US.FOATH19 (FOAT201903_FUT_EUREX). ID: 134 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.CLEH19 | 2021-06-18 08:57:57.739
Mapping F.US.CLEH19 to CLH19. Service code: nymex | 2021-06-18 08:57:57.739
SC Data - All Services | Starting real-time market data updates for: F.US.CLEH19 (CLH19). ID: 135 Service code: nymex | 2021-06-18 08:57:57.739
CQG WebAPI | Sending symbol resolution request for F.US.CLEH19. ID: 74986 | 2021-06-18 08:57:57.739
SC Data - All Services | Requesting security definition data for: F.US.CLEH19 (CLH19). ID: 135 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.YMH19 | 2021-06-18 08:57:57.739
Mapping F.US.YMH19 to YMH19. Service code: cbot | 2021-06-18 08:57:57.739
SC Data - All Services | Starting real-time market data updates for: F.US.YMH19 (YMH19). ID: 136 Service code: cbot | 2021-06-18 08:57:57.739
CQG WebAPI | Sending symbol resolution request for F.US.YMH19. ID: 74987 | 2021-06-18 08:57:57.739
SC Data - All Services | Requesting security definition data for: F.US.YMH19 (YMH19). ID: 136 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.DDH19 | 2021-06-18 08:57:57.739
Mapping F.US.DDH19 to FDAX201903_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.739
SC Data - All Services | Starting real-time market data updates for: F.US.DDH19 (FDAX201903_FUT_EUREX). ID: 137 Service code: eurex | 2021-06-18 08:57:57.739
CQG WebAPI | Sending symbol resolution request for F.US.DDH19. ID: 74988 | 2021-06-18 08:57:57.739
SC Data - All Services | Requesting security definition data for: F.US.DDH19 (FDAX201903_FUT_EUREX). ID: 137 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.DLH19 | 2021-06-18 08:57:57.739
Subscribing to symbol for symbol alert. F.US.GCEJ19 | 2021-06-18 08:57:57.739
Mapping F.US.GCEJ19 to GCJ19. Service code: comex | 2021-06-18 08:57:57.739
SC Data - All Services | Starting real-time market data updates for: F.US.GCEJ19 (GCJ19). ID: 138 Service code: comex | 2021-06-18 08:57:57.739
CQG WebAPI | Sending symbol resolution request for F.US.GCEJ19. ID: 74989 | 2021-06-18 08:57:57.740
SC Data - All Services | Requesting security definition data for: F.US.GCEJ19 (GCJ19). ID: 138 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.CPEH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.SF6H19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.PLEJ19 | 2021-06-18 08:57:57.740
Mapping F.US.PLEJ19 to PLJ19. Service code: nymex | 2021-06-18 08:57:57.740
SC Data - All Services | Starting real-time market data updates for: F.US.PLEJ19 (PLJ19). ID: 139 Service code: nymex | 2021-06-18 08:57:57.740
CQG WebAPI | Sending symbol resolution request for F.US.PLEJ19. ID: 74990 | 2021-06-18 08:57:57.740
SC Data - All Services | Requesting security definition data for: F.US.PLEJ19 (PLJ19). ID: 139 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.CA6H19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.FBTPH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.ULAH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.HEJ19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.ZCEH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.FVAH19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.ZLEN19 | 2021-06-18 08:57:57.740
Mapping F.US.ZLEN19 to ZLN19. Service code: cbot | 2021-06-18 08:57:57.740
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEN19 (ZLN19). ID: 140 Service code: cbot | 2021-06-18 08:57:57.740
CQG WebAPI | Sending symbol resolution request for F.US.ZLEN19. ID: 74991 | 2021-06-18 08:57:57.740
SC Data - All Services | Requesting security definition data for: F.US.ZLEN19 (ZLN19). ID: 140 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.GFJ19 | 2021-06-18 08:57:57.740
Subscribing to symbol for symbol alert. F.US.CA6H19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.SF6H19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.CLEH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.FVAH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.FBTPH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.GCEJ19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.DA6H19 | 2021-06-18 08:57:57.741
Mapping F.US.DA6H19 to 6AH19. Service code: cme | 2021-06-18 08:57:57.741
SC Data - All Services | Starting real-time market data updates for: F.US.DA6H19 (6AH19). ID: 141 Service code: cme | 2021-06-18 08:57:57.741
CQG WebAPI | Sending symbol resolution request for F.US.DA6H19. ID: 74992 | 2021-06-18 08:57:57.741
SC Data - All Services | Requesting security definition data for: F.US.DA6H19 (6AH19). ID: 141 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.HEM19 | 2021-06-18 08:57:57.741
Mapping F.US.HEM19 to HEM19. Service code: cme | 2021-06-18 08:57:57.741
SC Data - All Services | Starting real-time market data updates for: F.US.HEM19 (HEM19). ID: 142 Service code: cme | 2021-06-18 08:57:57.741
CQG WebAPI | Sending symbol resolution request for F.US.HEM19. ID: 74993 | 2021-06-18 08:57:57.741
SC Data - All Services | Requesting security definition data for: F.US.HEM19 (HEM19). ID: 142 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.DLH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.GLEJ19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.ULAH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.CPEH19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.HOEH19 | 2021-06-18 08:57:57.741
Mapping F.US.HOEH19 to HOH19. Service code: nymex | 2021-06-18 08:57:57.741
SC Data - All Services | Starting real-time market data updates for: F.US.HOEH19 (HOH19). ID: 143 Service code: nymex | 2021-06-18 08:57:57.741
CQG WebAPI | Sending symbol resolution request for F.US.HOEH19. ID: 74994 | 2021-06-18 08:57:57.741
SC Data - All Services | Requesting security definition data for: F.US.HOEH19 (HOH19). ID: 143 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.HOEJ19 | 2021-06-18 08:57:57.741
Mapping F.US.HOEJ19 to HOJ19. Service code: nymex | 2021-06-18 08:57:57.741
SC Data - All Services | Starting real-time market data updates for: F.US.HOEJ19 (HOJ19). ID: 144 Service code: nymex | 2021-06-18 08:57:57.741
CQG WebAPI | Sending symbol resolution request for F.US.HOEJ19. ID: 74995 | 2021-06-18 08:57:57.741
SC Data - All Services | Requesting security definition data for: F.US.HOEJ19 (HOJ19). ID: 144 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.ZCEK19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.GFJ19 | 2021-06-18 08:57:57.741
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.FBTPH19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.CPEK19 | 2021-06-18 08:57:57.742
Mapping F.US.CPEK19 to HGK19. Service code: comex | 2021-06-18 08:57:57.742
SC Data - All Services | Starting real-time market data updates for: F.US.CPEK19 (HGK19). ID: 145 Service code: comex | 2021-06-18 08:57:57.742
CQG WebAPI | Sending symbol resolution request for F.US.CPEK19. ID: 74996 | 2021-06-18 08:57:57.742
SC Data - All Services | Requesting security definition data for: F.US.CPEK19 (HGK19). ID: 145 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.SF6H19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.HEM19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.FVAH19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.SIEH19 | 2021-06-18 08:57:57.742
Mapping F.US.SIEH19 to SIH19. Service code: comex | 2021-06-18 08:57:57.742
SC Data - All Services | Starting real-time market data updates for: F.US.SIEH19 (SIH19). ID: 146 Service code: comex | 2021-06-18 08:57:57.742
CQG WebAPI | Sending symbol resolution request for F.US.SIEH19. ID: 74997 | 2021-06-18 08:57:57.742
SC Data - All Services | Requesting security definition data for: F.US.SIEH19 (SIH19). ID: 146 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.CPEH19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.CA6H19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.EU6H19 | 2021-06-18 08:57:57.742
Mapping F.US.EU6H19 to 6EH19. Service code: cme | 2021-06-18 08:57:57.742
SC Data - All Services | Starting real-time market data updates for: F.US.EU6H19 (6EH19). ID: 147 Service code: cme | 2021-06-18 08:57:57.742
CQG WebAPI | Sending symbol resolution request for F.US.EU6H19. ID: 74998 | 2021-06-18 08:57:57.742
SC Data - All Services | Requesting security definition data for: F.US.EU6H19 (6EH19). ID: 147 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.HEN19 | 2021-06-18 08:57:57.742
Mapping F.US.HEN19 to HEN19. Service code: cme | 2021-06-18 08:57:57.742
SC Data - All Services | Starting real-time market data updates for: F.US.HEN19 (HEN19). ID: 148 Service code: cme | 2021-06-18 08:57:57.742
CQG WebAPI | Sending symbol resolution request for F.US.HEN19. ID: 74999 | 2021-06-18 08:57:57.742
SC Data - All Services | Requesting security definition data for: F.US.HEN19 (HEN19). ID: 148 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.ULAH19 | 2021-06-18 08:57:57.742
Subscribing to symbol for symbol alert. F.US.BP6H19 | 2021-06-18 08:57:57.742
Mapping F.US.BP6H19 to 6BH19. Service code: cme | 2021-06-18 08:57:57.743
SC Data - All Services | Starting real-time market data updates for: F.US.BP6H19 (6BH19). ID: 149 Service code: cme | 2021-06-18 08:57:57.743
CQG WebAPI | Sending symbol resolution request for F.US.BP6H19. ID: 75000 | 2021-06-18 08:57:57.743
SC Data - All Services | Requesting security definition data for: F.US.BP6H19 (6BH19). ID: 149 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.CPEK19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.ULAH19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.USAH19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.CLEM19 | 2021-06-18 08:57:57.743
Mapping F.US.CLEM19 to CLM19. Service code: nymex | 2021-06-18 08:57:57.743
SC Data - All Services | Starting real-time market data updates for: F.US.CLEM19 (CLM19). ID: 150 Service code: nymex | 2021-06-18 08:57:57.743
CQG WebAPI | Sending symbol resolution request for F.US.CLEM19. ID: 75001 | 2021-06-18 08:57:57.743
SC Data - All Services | Requesting security definition data for: F.US.CLEM19 (CLM19). ID: 150 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.HEJ19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.GLEJ19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.DA6H19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.FOATH19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.TYAH19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.743
Mapping F.US.TYAM19 to ZNM19. Service code: cbot | 2021-06-18 08:57:57.743
SC Data - All Services | Starting real-time market data updates for: F.US.TYAM19 (ZNM19). ID: 151 Service code: cbot | 2021-06-18 08:57:57.743
CQG WebAPI | Sending symbol resolution request for F.US.TYAM19. ID: 75002 | 2021-06-18 08:57:57.743
SC Data - All Services | Requesting security definition data for: F.US.TYAM19 (ZNM19). ID: 151 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.ZCEK19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.PLEJ19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.HOEM19 | 2021-06-18 08:57:57.743
Mapping F.US.HOEM19 to HOM19. Service code: nymex | 2021-06-18 08:57:57.743
SC Data - All Services | Starting real-time market data updates for: F.US.HOEM19 (HOM19). ID: 152 Service code: nymex | 2021-06-18 08:57:57.743
CQG WebAPI | Sending symbol resolution request for F.US.HOEM19. ID: 75003 | 2021-06-18 08:57:57.743
SC Data - All Services | Requesting security definition data for: F.US.HOEM19 (HOM19). ID: 152 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.FVAM19 | 2021-06-18 08:57:57.743
Mapping F.US.FVAM19 to ZFM19. Service code: cbot | 2021-06-18 08:57:57.743
SC Data - All Services | Starting real-time market data updates for: F.US.FVAM19 (ZFM19). ID: 153 Service code: cbot | 2021-06-18 08:57:57.743
CQG WebAPI | Sending symbol resolution request for F.US.FVAM19. ID: 75004 | 2021-06-18 08:57:57.743
SC Data - All Services | Requesting security definition data for: F.US.FVAM19 (ZFM19). ID: 153 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.DLH19 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.GLEM19 | 2021-06-18 08:57:57.743
Mapping F.US.GLEM19 to LEM19. Service code: cme | 2021-06-18 08:57:57.743
SC Data - All Services | Starting real-time market data updates for: F.US.GLEM19 (LEM19). ID: 154 Service code: cme | 2021-06-18 08:57:57.743
CQG WebAPI | Sending symbol resolution request for F.US.GLEM19. ID: 75005 | 2021-06-18 08:57:57.743
SC Data - All Services | Requesting security definition data for: F.US.GLEM19 (LEM19). ID: 154 | 2021-06-18 08:57:57.743
Subscribing to symbol for symbol alert. F.US.ULAM19 | 2021-06-18 08:57:57.743
Mapping F.US.ULAM19 to UBM19. Service code: cbot | 2021-06-18 08:57:57.743
SC Data - All Services | Starting real-time market data updates for: F.US.ULAM19 (UBM19). ID: 155 Service code: cbot | 2021-06-18 08:57:57.744
CQG WebAPI | Sending symbol resolution request for F.US.ULAM19. ID: 75006 | 2021-06-18 08:57:57.744
SC Data - All Services | Requesting security definition data for: F.US.ULAM19 (UBM19). ID: 155 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.PLEJ19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.CA6H19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.DBH19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.USAM19 | 2021-06-18 08:57:57.744
Mapping F.US.USAM19 to ZBM19. Service code: cbot | 2021-06-18 08:57:57.744
SC Data - All Services | Starting real-time market data updates for: F.US.USAM19 (ZBM19). ID: 156 Service code: cbot | 2021-06-18 08:57:57.744
CQG WebAPI | Sending symbol resolution request for F.US.USAM19. ID: 75007 | 2021-06-18 08:57:57.744
SC Data - All Services | Requesting security definition data for: F.US.USAM19 (ZBM19). ID: 156 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.EPH19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.DLH19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.ULAM19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.EPM19 | 2021-06-18 08:57:57.744
Mapping F.US.EPM19 to ESM19. Service code: cme | 2021-06-18 08:57:57.744
SC Data - All Services | Starting real-time market data updates for: F.US.EPM19 (ESM19). ID: 157 Service code: cme | 2021-06-18 08:57:57.744
CQG WebAPI | Sending symbol resolution request for F.US.EPM19. ID: 75008 | 2021-06-18 08:57:57.744
SC Data - All Services | Requesting security definition data for: F.US.EPM19 (ESM19). ID: 157 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.FVAM19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.GLEM19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.DBM19 | 2021-06-18 08:57:57.744
Mapping F.US.DBM19 to FGBL201906_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.744
SC Data - All Services | Starting real-time market data updates for: F.US.DBM19 (FGBL201906_FUT_EUREX). ID: 158 Service code: eurex | 2021-06-18 08:57:57.744
CQG WebAPI | Sending symbol resolution request for F.US.DBM19. ID: 75009 | 2021-06-18 08:57:57.744
SC Data - All Services | Requesting security definition data for: F.US.DBM19 (FGBL201906_FUT_EUREX). ID: 158 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.CPEK19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.HEJ19 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.DLM19 | 2021-06-18 08:57:57.744
Mapping F.US.DLM19 to FGBM201906_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.744
SC Data - All Services | Starting real-time market data updates for: F.US.DLM19 (FGBM201906_FUT_EUREX). ID: 159 Service code: eurex | 2021-06-18 08:57:57.744
CQG WebAPI | Sending symbol resolution request for F.US.DLM19. ID: 75010 | 2021-06-18 08:57:57.744
SC Data - All Services | Requesting security definition data for: F.US.DLM19 (FGBM201906_FUT_EUREX). ID: 159 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.TUAM19 | 2021-06-18 08:57:57.744
Mapping F.US.TUAM19 to ZTM19. Service code: cbot | 2021-06-18 08:57:57.744
SC Data - All Services | Starting real-time market data updates for: F.US.TUAM19 (ZTM19). ID: 160 Service code: cbot | 2021-06-18 08:57:57.744
CQG WebAPI | Sending symbol resolution request for F.US.TUAM19. ID: 75011 | 2021-06-18 08:57:57.744
SC Data - All Services | Requesting security definition data for: F.US.TUAM19 (ZTM19). ID: 160 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.ZSEN19 | 2021-06-18 08:57:57.744
Mapping F.US.ZSEN19 to ZSN19. Service code: cbot | 2021-06-18 08:57:57.744
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEN19 (ZSN19). ID: 161 Service code: cbot | 2021-06-18 08:57:57.744
CQG WebAPI | Sending symbol resolution request for F.US.ZSEN19. ID: 75012 | 2021-06-18 08:57:57.744
SC Data - All Services | Requesting security definition data for: F.US.ZSEN19 (ZSN19). ID: 161 | 2021-06-18 08:57:57.744
Subscribing to symbol for symbol alert. F.US.DSXH19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.DBM19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.USAM19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.FVAM19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.ZSEN19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.CA6H19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.SF6H19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.PLEJ19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.CPEK19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.CLEK19 | 2021-06-18 08:57:57.745
Mapping F.US.CLEK19 to CLK19. Service code: nymex | 2021-06-18 08:57:57.745
SC Data - All Services | Starting real-time market data updates for: F.US.CLEK19 (CLK19). ID: 162 Service code: nymex | 2021-06-18 08:57:57.745
CQG WebAPI | Sending symbol resolution request for F.US.CLEK19. ID: 75013 | 2021-06-18 08:57:57.745
SC Data - All Services | Requesting security definition data for: F.US.CLEK19 (CLK19). ID: 162 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.GFJ19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.DSXM19 | 2021-06-18 08:57:57.745
Mapping F.US.DSXM19 to FESX201906_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.745
SC Data - All Services | Starting real-time market data updates for: F.US.DSXM19 (FESX201906_FUT_EUREX). ID: 163 Service code: eurex | 2021-06-18 08:57:57.745
CQG WebAPI | Sending symbol resolution request for F.US.DSXM19. ID: 75014 | 2021-06-18 08:57:57.745
SC Data - All Services | Requesting security definition data for: F.US.DSXM19 (FESX201906_FUT_EUREX). ID: 163 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.EPM19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.ULAM19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.ZCEN19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.EU6M19 | 2021-06-18 08:57:57.745
Mapping F.US.EU6M19 to 6EM19. Service code: cme | 2021-06-18 08:57:57.745
SC Data - All Services | Starting real-time market data updates for: F.US.EU6M19 (6EM19). ID: 164 Service code: cme | 2021-06-18 08:57:57.745
CQG WebAPI | Sending symbol resolution request for F.US.EU6M19. ID: 75015 | 2021-06-18 08:57:57.745
SC Data - All Services | Requesting security definition data for: F.US.EU6M19 (6EM19). ID: 164 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.TUAM19 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.TNAM19 | 2021-06-18 08:57:57.745
Mapping F.US.TNAM19 to TNM19. Service code: cbot | 2021-06-18 08:57:57.745
SC Data - All Services | Starting real-time market data updates for: F.US.TNAM19 (TNM19). ID: 165 Service code: cbot | 2021-06-18 08:57:57.745
CQG WebAPI | Sending symbol resolution request for F.US.TNAM19. ID: 75016 | 2021-06-18 08:57:57.745
SC Data - All Services | Requesting security definition data for: F.US.TNAM19 (TNM19). ID: 165 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.DA6M19 | 2021-06-18 08:57:57.745
Mapping F.US.DA6M19 to 6AM19. Service code: cme | 2021-06-18 08:57:57.745
SC Data - All Services | Starting real-time market data updates for: F.US.DA6M19 (6AM19). ID: 166 Service code: cme | 2021-06-18 08:57:57.745
CQG WebAPI | Sending symbol resolution request for F.US.DA6M19. ID: 75017 | 2021-06-18 08:57:57.745
SC Data - All Services | Requesting security definition data for: F.US.DA6M19 (6AM19). ID: 166 | 2021-06-18 08:57:57.745
Subscribing to symbol for symbol alert. F.US.DSXM19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.EU6M19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.DBM19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.FVAM19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.USAM19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.BP6M19 | 2021-06-18 08:57:57.746
Mapping F.US.BP6M19 to 6BM19. Service code: cme | 2021-06-18 08:57:57.746
SC Data - All Services | Starting real-time market data updates for: F.US.BP6M19 (6BM19). ID: 167 Service code: cme | 2021-06-18 08:57:57.746
CQG WebAPI | Sending symbol resolution request for F.US.BP6M19. ID: 75018 | 2021-06-18 08:57:57.746
SC Data - All Services | Requesting security definition data for: F.US.BP6M19 (6BM19). ID: 167 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.GLEQ19 | 2021-06-18 08:57:57.746
Mapping F.US.GLEQ19 to LEQ19. Service code: cme | 2021-06-18 08:57:57.746
SC Data - All Services | Starting real-time market data updates for: F.US.GLEQ19 (LEQ19). ID: 168 Service code: cme | 2021-06-18 08:57:57.746
CQG WebAPI | Sending symbol resolution request for F.US.GLEQ19. ID: 75019 | 2021-06-18 08:57:57.746
SC Data - All Services | Requesting security definition data for: F.US.GLEQ19 (LEQ19). ID: 168 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.EPM19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.FDXMM19 | 2021-06-18 08:57:57.746
Mapping F.US.FDXMM19 to FDXM201906_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.746
SC Data - All Services | Starting real-time market data updates for: F.US.FDXMM19 (FDXM201906_FUT_EUREX). ID: 169 Service code: eurex | 2021-06-18 08:57:57.746
CQG WebAPI | Sending symbol resolution request for F.US.FDXMM19. ID: 75020 | 2021-06-18 08:57:57.746
SC Data - All Services | Requesting security definition data for: F.US.FDXMM19 (FDXM201906_FUT_EUREX). ID: 169 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.ULAM19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.DLM19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.TUAM19 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.GFU19 | 2021-06-18 08:57:57.746
Mapping F.US.GFU19 to GFU19. Service code: cme | 2021-06-18 08:57:57.746
SC Data - All Services | Starting real-time market data updates for: F.US.GFU19 (GFU19). ID: 170 Service code: cme | 2021-06-18 08:57:57.746
CQG WebAPI | Sending symbol resolution request for F.US.GFU19. ID: 75021 | 2021-06-18 08:57:57.746
SC Data - All Services | Requesting security definition data for: F.US.GFU19 (GFU19). ID: 170 | 2021-06-18 08:57:57.746
Subscribing to symbol for symbol alert. F.US.DSXM19 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.ULAM19 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.FVAM19 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.SF6M19 | 2021-06-18 08:57:57.747
Mapping F.US.SF6M19 to 6SM19. Service code: cme | 2021-06-18 08:57:57.747
SC Data - All Services | Starting real-time market data updates for: F.US.SF6M19 (6SM19). ID: 171 Service code: cme | 2021-06-18 08:57:57.747
CQG WebAPI | Sending symbol resolution request for F.US.SF6M19. ID: 75022 | 2021-06-18 08:57:57.747
SC Data - All Services | Requesting security definition data for: F.US.SF6M19 (6SM19). ID: 171 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.EU6M19 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.SIEK19 | 2021-06-18 08:57:57.747
Mapping F.US.SIEK19 to SIK19. Service code: comex | 2021-06-18 08:57:57.747
SC Data - All Services | Starting real-time market data updates for: F.US.SIEK19 (SIK19). ID: 172 Service code: comex | 2021-06-18 08:57:57.747
CQG WebAPI | Sending symbol resolution request for F.US.SIEK19. ID: 75023 | 2021-06-18 08:57:57.747
SC Data - All Services | Requesting security definition data for: F.US.SIEK19 (SIK19). ID: 172 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.DA6M19 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.USAM19 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.HEV19 | 2021-06-18 08:57:57.747
Mapping F.US.HEV19 to HEV19. Service code: cme | 2021-06-18 08:57:57.747
SC Data - All Services | Starting real-time market data updates for: F.US.HEV19 (HEV19). ID: 173 Service code: cme | 2021-06-18 08:57:57.747
CQG WebAPI | Sending symbol resolution request for F.US.HEV19. ID: 75024 | 2021-06-18 08:57:57.747
SC Data - All Services | Requesting security definition data for: F.US.HEV19 (HEV19). ID: 173 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.PLEN19 | 2021-06-18 08:57:57.747
Mapping F.US.PLEN19 to PLN19. Service code: nymex | 2021-06-18 08:57:57.747
SC Data - All Services | Starting real-time market data updates for: F.US.PLEN19 (PLN19). ID: 174 Service code: nymex | 2021-06-18 08:57:57.747
CQG WebAPI | Sending symbol resolution request for F.US.PLEN19. ID: 75025 | 2021-06-18 08:57:57.747
SC Data - All Services | Requesting security definition data for: F.US.PLEN19 (PLN19). ID: 174 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.CPEN19 | 2021-06-18 08:57:57.747
Mapping F.US.CPEN19 to HGN19. Service code: comex | 2021-06-18 08:57:57.747
SC Data - All Services | Starting real-time market data updates for: F.US.CPEN19 (HGN19). ID: 175 Service code: comex | 2021-06-18 08:57:57.747
CQG WebAPI | Sending symbol resolution request for F.US.CPEN19. ID: 75026 | 2021-06-18 08:57:57.747
SC Data - All Services | Requesting security definition data for: F.US.CPEN19 (HGN19). ID: 175 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.SIEN19 | 2021-06-18 08:57:57.747
Mapping F.US.SIEN19 to SIN19. Service code: comex | 2021-06-18 08:57:57.747
SC Data - All Services | Starting real-time market data updates for: F.US.SIEN19 (SIN19). ID: 176 Service code: comex | 2021-06-18 08:57:57.747
CQG WebAPI | Sending symbol resolution request for F.US.SIEN19. ID: 75027 | 2021-06-18 08:57:57.747
SC Data - All Services | Requesting security definition data for: F.US.SIEN19 (SIN19). ID: 176 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.CA6M19 | 2021-06-18 08:57:57.747
Mapping F.US.CA6M19 to 6CM19. Service code: cme | 2021-06-18 08:57:57.747
SC Data - All Services | Starting real-time market data updates for: F.US.CA6M19 (6CM19). ID: 177 Service code: cme | 2021-06-18 08:57:57.747
CQG WebAPI | Sending symbol resolution request for F.US.CA6M19. ID: 75028 | 2021-06-18 08:57:57.747
SC Data - All Services | Requesting security definition data for: F.US.CA6M19 (6CM19). ID: 177 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.DLM19 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.HEM19 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.NGEM19 | 2021-06-18 08:57:57.747
Mapping F.US.NGEM19 to NGM19. Service code: nymex | 2021-06-18 08:57:57.747
SC Data - All Services | Starting real-time market data updates for: F.US.NGEM19 (NGM19). ID: 178 Service code: nymex | 2021-06-18 08:57:57.747
CQG WebAPI | Sending symbol resolution request for F.US.NGEM19. ID: 75029 | 2021-06-18 08:57:57.747
SC Data - All Services | Requesting security definition data for: F.US.NGEM19 (NGM19). ID: 178 | 2021-06-18 08:57:57.747
Subscribing to symbol for symbol alert. F.US.RBEN19 | 2021-06-18 08:57:57.747
Mapping F.US.RBEN19 to RBN19. Service code: nymex | 2021-06-18 08:57:57.747
SC Data - All Services | Starting real-time market data updates for: F.US.RBEN19 (RBN19). ID: 179 Service code: nymex | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.RBEN19. ID: 75030 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.RBEN19 (RBN19). ID: 179 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.CLEN19 | 2021-06-18 08:57:57.748
Mapping F.US.CLEN19 to CLN19. Service code: nymex | 2021-06-18 08:57:57.748
SC Data - All Services | Starting real-time market data updates for: F.US.CLEN19 (CLN19). ID: 180 Service code: nymex | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.CLEN19. ID: 75031 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.CLEN19 (CLN19). ID: 180 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.EU6M19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.ZMEQ19 | 2021-06-18 08:57:57.748
Mapping F.US.ZMEQ19 to ZMQ19. Service code: cbot | 2021-06-18 08:57:57.748
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEQ19 (ZMQ19). ID: 181 Service code: cbot | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.ZMEQ19. ID: 75032 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.ZMEQ19 (ZMQ19). ID: 181 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.ZCEN19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.CPEN19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.USAM19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.DSXM19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.ULAM19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.TUAM19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.FVAM19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.NE6M19 | 2021-06-18 08:57:57.748
Mapping F.US.NE6M19 to 6NM19. Service code: cme | 2021-06-18 08:57:57.748
SC Data - All Services | Starting real-time market data updates for: F.US.NE6M19 (6NM19). ID: 182 Service code: cme | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.NE6M19. ID: 75033 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.NE6M19 (6NM19). ID: 182 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.SIEN19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.GCEM19 | 2021-06-18 08:57:57.748
Mapping F.US.GCEM19 to GCM19. Service code: comex | 2021-06-18 08:57:57.748
SC Data - All Services | Starting real-time market data updates for: F.US.GCEM19 (GCM19). ID: 183 Service code: comex | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.GCEM19. ID: 75034 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.GCEM19 (GCM19). ID: 183 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.SF6M19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.GFU19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.CA6M19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.ZWAN19 | 2021-06-18 08:57:57.748
Mapping F.US.ZWAN19 to ZWN19. Service code: cbot | 2021-06-18 08:57:57.748
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAN19 (ZWN19). ID: 184 Service code: cbot | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.ZWAN19. ID: 75035 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.ZWAN19 (ZWN19). ID: 184 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.HOEV19 | 2021-06-18 08:57:57.748
Mapping F.US.HOEV19 to HOV19. Service code: nymex | 2021-06-18 08:57:57.748
SC Data - All Services | Starting real-time market data updates for: F.US.HOEV19 (HOV19). ID: 185 Service code: nymex | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.HOEV19. ID: 75036 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.HOEV19 (HOV19). ID: 185 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.DLM19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.BP6M19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.GLEQ19 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.NGEX19 | 2021-06-18 08:57:57.748
Mapping F.US.NGEX19 to NGX19. Service code: nymex | 2021-06-18 08:57:57.748
SC Data - All Services | Starting real-time market data updates for: F.US.NGEX19 (NGX19). ID: 186 Service code: nymex | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.NGEX19. ID: 75037 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.NGEX19 (NGX19). ID: 186 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.ZLEQ19 | 2021-06-18 08:57:57.748
Mapping F.US.ZLEQ19 to ZLQ19. Service code: cbot | 2021-06-18 08:57:57.748
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEQ19 (ZLQ19). ID: 187 Service code: cbot | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.ZLEQ19. ID: 75038 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.ZLEQ19 (ZLQ19). ID: 187 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.KWEN19 | 2021-06-18 08:57:57.748
Mapping F.US.KWEN19 to KEN19. Service code: cbot | 2021-06-18 08:57:57.748
SC Data - All Services | Starting real-time market data updates for: F.US.KWEN19 (KEN19). ID: 188 Service code: cbot | 2021-06-18 08:57:57.748
CQG WebAPI | Sending symbol resolution request for F.US.KWEN19. ID: 75039 | 2021-06-18 08:57:57.748
SC Data - All Services | Requesting security definition data for: F.US.KWEN19 (KEN19). ID: 188 | 2021-06-18 08:57:57.748
Subscribing to symbol for symbol alert. F.US.DSXM19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.GLEQ19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.ZWAU19 | 2021-06-18 08:57:57.749
Mapping F.US.ZWAU19 to ZWU19. Service code: cbot | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAU19 (ZWU19). ID: 189 Service code: cbot | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.ZWAU19. ID: 75040 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.ZWAU19 (ZWU19). ID: 189 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.KWEU19 | 2021-06-18 08:57:57.749
Mapping F.US.KWEU19 to KEU19. Service code: cbot | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.KWEU19 (KEU19). ID: 190 Service code: cbot | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.KWEU19. ID: 75041 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.KWEU19 (KEU19). ID: 190 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.SIEN19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.BP6M19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.SF6M19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.NGEX19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.ZLEQ19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.USAM19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.HEQ19 | 2021-06-18 08:57:57.749
Mapping F.US.HEQ19 to HEQ19. Service code: cme | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.HEQ19 (HEQ19). ID: 191 Service code: cme | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.HEQ19. ID: 75042 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.HEQ19 (HEQ19). ID: 191 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.HEM19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.ZMEU19 | 2021-06-18 08:57:57.749
Mapping F.US.ZMEU19 to ZMU19. Service code: cbot | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEU19 (ZMU19). ID: 192 Service code: cbot | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.ZMEU19. ID: 75043 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.ZMEU19 (ZMU19). ID: 192 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.ZMEQ19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.KWEK20 | 2021-06-18 08:57:57.749
Mapping F.US.KWEK20 to KEK20. Service code: cbot | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.KWEK20 (KEK20). ID: 193 Service code: cbot | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.KWEK20. ID: 75044 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.KWEK20 (KEK20). ID: 193 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.KWEN19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.FBTSM19 | 2021-06-18 08:57:57.749
Mapping F.US.FBTSM19 to FBTS201906_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.FBTSM19 (FBTS201906_FUT_EUREX). ID: 194 Service code: eurex | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.FBTSM19. ID: 75045 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.FBTSM19 (FBTS201906_FUT_EUREX). ID: 194 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.ENQM19 | 2021-06-18 08:57:57.749
Mapping F.US.ENQM19 to NQM19. Service code: cme | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.ENQM19 (NQM19). ID: 195 Service code: cme | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.ENQM19. ID: 75046 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.ENQM19 (NQM19). ID: 195 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.GFU19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.ZWAN19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.CPEU19 | 2021-06-18 08:57:57.749
Mapping F.US.CPEU19 to HGU19. Service code: comex | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.CPEU19 (HGU19). ID: 196 Service code: comex | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.CPEU19. ID: 75047 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.CPEU19 (HGU19). ID: 196 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.CPEN19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.ZLEH20 | 2021-06-18 08:57:57.749
Mapping F.US.ZLEH20 to ZLH20. Service code: cbot | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEH20 (ZLH20). ID: 197 Service code: cbot | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.ZLEH20. ID: 75048 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.ZLEH20 (ZLH20). ID: 197 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.ZMEZ19 | 2021-06-18 08:57:57.749
Mapping F.US.ZMEZ19 to ZMZ19. Service code: cbot | 2021-06-18 08:57:57.749
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEZ19 (ZMZ19). ID: 198 Service code: cbot | 2021-06-18 08:57:57.749
CQG WebAPI | Sending symbol resolution request for F.US.ZMEZ19. ID: 75049 | 2021-06-18 08:57:57.749
SC Data - All Services | Requesting security definition data for: F.US.ZMEZ19 (ZMZ19). ID: 198 | 2021-06-18 08:57:57.749
Subscribing to symbol for symbol alert. F.US.DSXM19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.ZSEN19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.ZMEZ19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.MESM19 | 2021-06-18 08:57:57.750
Mapping F.US.MESM19 to MESM19. Service code: cme | 2021-06-18 08:57:57.750
SC Data - All Services | Starting real-time market data updates for: F.US.MESM19 (MESM19). ID: 199 Service code: cme | 2021-06-18 08:57:57.750
CQG WebAPI | Sending symbol resolution request for F.US.MESM19. ID: 75050 | 2021-06-18 08:57:57.750
SC Data - All Services | Requesting security definition data for: F.US.MESM19 (MESM19). ID: 199 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.JY6M19 | 2021-06-18 08:57:57.750
Mapping F.US.JY6M19 to 6JM19. Service code: cme | 2021-06-18 08:57:57.750
SC Data - All Services | Starting real-time market data updates for: F.US.JY6M19 (6JM19). ID: 200 Service code: cme | 2021-06-18 08:57:57.750
CQG WebAPI | Sending symbol resolution request for F.US.JY6M19. ID: 75051 | 2021-06-18 08:57:57.750
SC Data - All Services | Requesting security definition data for: F.US.JY6M19 (6JM19). ID: 200 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.ZLEQ19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.USAM19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.GLEM19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.ZSEQ19 | 2021-06-18 08:57:57.750
Mapping F.US.ZSEQ19 to ZSQ19. Service code: cbot | 2021-06-18 08:57:57.750
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEQ19 (ZSQ19). ID: 201 Service code: cbot | 2021-06-18 08:57:57.750
CQG WebAPI | Sending symbol resolution request for F.US.ZSEQ19. ID: 75052 | 2021-06-18 08:57:57.750
SC Data - All Services | Requesting security definition data for: F.US.ZSEQ19 (ZSQ19). ID: 201 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.FOATM19 | 2021-06-18 08:57:57.750
Mapping F.US.FOATM19 to FOAT201906_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.750
SC Data - All Services | Starting real-time market data updates for: F.US.FOATM19 (FOAT201906_FUT_EUREX). ID: 202 Service code: eurex | 2021-06-18 08:57:57.750
CQG WebAPI | Sending symbol resolution request for F.US.FOATM19. ID: 75053 | 2021-06-18 08:57:57.750
SC Data - All Services | Requesting security definition data for: F.US.FOATM19 (FOAT201906_FUT_EUREX). ID: 202 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.ZMEV19 | 2021-06-18 08:57:57.750
Mapping F.US.ZMEV19 to ZMV19. Service code: cbot | 2021-06-18 08:57:57.750
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEV19 (ZMV19). ID: 203 Service code: cbot | 2021-06-18 08:57:57.750
CQG WebAPI | Sending symbol resolution request for F.US.ZMEV19. ID: 75054 | 2021-06-18 08:57:57.750
SC Data - All Services | Requesting security definition data for: F.US.ZMEV19 (ZMV19). ID: 203 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.CLEN19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.ZWAZ19 | 2021-06-18 08:57:57.750
Mapping F.US.ZWAZ19 to ZWZ19. Service code: cbot | 2021-06-18 08:57:57.750
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAZ19 (ZWZ19). ID: 204 Service code: cbot | 2021-06-18 08:57:57.750
CQG WebAPI | Sending symbol resolution request for F.US.ZWAZ19. ID: 75055 | 2021-06-18 08:57:57.750
SC Data - All Services | Requesting security definition data for: F.US.ZWAZ19 (ZWZ19). ID: 204 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.SF6M19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.RBEN19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.GLEZ19 | 2021-06-18 08:57:57.750
Mapping F.US.GLEZ19 to LEZ19. Service code: cme | 2021-06-18 08:57:57.750
SC Data - All Services | Starting real-time market data updates for: F.US.GLEZ19 (LEZ19). ID: 205 Service code: cme | 2021-06-18 08:57:57.750
CQG WebAPI | Sending symbol resolution request for F.US.GLEZ19. ID: 75056 | 2021-06-18 08:57:57.750
SC Data - All Services | Requesting security definition data for: F.US.GLEZ19 (LEZ19). ID: 205 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.GFQ19 | 2021-06-18 08:57:57.750
Mapping F.US.GFQ19 to GFQ19. Service code: cme | 2021-06-18 08:57:57.750
SC Data - All Services | Starting real-time market data updates for: F.US.GFQ19 (GFQ19). ID: 206 Service code: cme | 2021-06-18 08:57:57.750
CQG WebAPI | Sending symbol resolution request for F.US.GFQ19. ID: 75057 | 2021-06-18 08:57:57.750
SC Data - All Services | Requesting security definition data for: F.US.GFQ19 (GFQ19). ID: 206 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.PLEN19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.CPEN19 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.GLEV19 | 2021-06-18 08:57:57.750
Mapping F.US.GLEV19 to LEV19. Service code: cme | 2021-06-18 08:57:57.750
SC Data - All Services | Starting real-time market data updates for: F.US.GLEV19 (LEV19). ID: 207 Service code: cme | 2021-06-18 08:57:57.750
CQG WebAPI | Sending symbol resolution request for F.US.GLEV19. ID: 75058 | 2021-06-18 08:57:57.750
SC Data - All Services | Requesting security definition data for: F.US.GLEV19 (LEV19). ID: 207 | 2021-06-18 08:57:57.750
Subscribing to symbol for symbol alert. F.US.SIEU19 | 2021-06-18 08:57:57.750
Mapping F.US.SIEU19 to SIU19. Service code: comex | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.SIEU19 (SIU19). ID: 208 Service code: comex | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.SIEU19. ID: 75059 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.SIEU19 (SIU19). ID: 208 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.SIEU19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.PLEN19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.DSXM19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.DDM19 | 2021-06-18 08:57:57.751
Mapping F.US.DDM19 to FDAX201906_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.DDM19 (FDAX201906_FUT_EUREX). ID: 209 Service code: eurex | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.DDM19. ID: 75060 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.DDM19 (FDAX201906_FUT_EUREX). ID: 209 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.FGBXM19 | 2021-06-18 08:57:57.751
Mapping F.US.FGBXM19 to FGBX201906_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.FGBXM19 (FGBX201906_FUT_EUREX). ID: 210 Service code: eurex | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.FGBXM19. ID: 75061 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.FGBXM19 (FGBX201906_FUT_EUREX). ID: 210 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.BP6M19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.ZCEN19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.ZCEU19 | 2021-06-18 08:57:57.751
Mapping F.US.ZCEU19 to ZCU19. Service code: cbot | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEU19 (ZCU19). ID: 211 Service code: cbot | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.ZCEU19. ID: 75062 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.ZCEU19 (ZCU19). ID: 211 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.ZWAN19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.USAU19 | 2021-06-18 08:57:57.751
Mapping F.US.USAU19 to ZBU19. Service code: cbot | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.USAU19 (ZBU19). ID: 212 Service code: cbot | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.USAU19. ID: 75063 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.USAU19 (ZBU19). ID: 212 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.GCEZ19 | 2021-06-18 08:57:57.751
Mapping F.US.GCEZ19 to GCZ19. Service code: comex | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.GCEZ19 (GCZ19). ID: 213 Service code: comex | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.GCEZ19. ID: 75064 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.GCEZ19 (GCZ19). ID: 213 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.HOEN19 | 2021-06-18 08:57:57.751
Mapping F.US.HOEN19 to HON19. Service code: nymex | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.HOEN19 (HON19). ID: 214 Service code: nymex | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.HOEN19. ID: 75065 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.HOEN19 (HON19). ID: 214 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.EU6M19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.DA6M19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.NGEQ19 | 2021-06-18 08:57:57.751
Mapping F.US.NGEQ19 to NGQ19. Service code: nymex | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.NGEQ19 (NGQ19). ID: 215 Service code: nymex | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.NGEQ19. ID: 75066 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.NGEQ19 (NGQ19). ID: 215 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.FVAM19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.ULAU19 | 2021-06-18 08:57:57.751
Mapping F.US.ULAU19 to UBU19. Service code: cbot | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.ULAU19 (UBU19). ID: 216 Service code: cbot | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.ULAU19. ID: 75067 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.ULAU19 (UBU19). ID: 216 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.USAM19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.GLEQ19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.SF6M19 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.TYAU19 | 2021-06-18 08:57:57.751
Mapping F.US.TYAU19 to ZNU19. Service code: cbot | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.TYAU19 (ZNU19). ID: 217 Service code: cbot | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.TYAU19. ID: 75068 | 2021-06-18 08:57:57.751
SC Data - All Services | Requesting security definition data for: F.US.TYAU19 (ZNU19). ID: 217 | 2021-06-18 08:57:57.751
Subscribing to symbol for symbol alert. F.US.FBTPM19 | 2021-06-18 08:57:57.751
Mapping F.US.FBTPM19 to FBTP201906_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.751
SC Data - All Services | Starting real-time market data updates for: F.US.FBTPM19 (FBTP201906_FUT_EUREX). ID: 218 Service code: eurex | 2021-06-18 08:57:57.751
CQG WebAPI | Sending symbol resolution request for F.US.FBTPM19. ID: 75069 | 2021-06-18 08:57:57.752
SC Data - All Services | Requesting security definition data for: F.US.FBTPM19 (FBTP201906_FUT_EUREX). ID: 218 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.FBTPM19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.USAM19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.DSXM19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.USAU19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.TYAU19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.TYAM19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.ULAU19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.TNAM19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.FVAM19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.RBEU19 | 2021-06-18 08:57:57.752
Mapping F.US.RBEU19 to RBU19. Service code: nymex | 2021-06-18 08:57:57.752
SC Data - All Services | Starting real-time market data updates for: F.US.RBEU19 (RBU19). ID: 219 Service code: nymex | 2021-06-18 08:57:57.752
CQG WebAPI | Sending symbol resolution request for F.US.RBEU19. ID: 75070 | 2021-06-18 08:57:57.752
SC Data - All Services | Requesting security definition data for: F.US.RBEU19 (RBU19). ID: 219 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.ZCEN19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.ULAM19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.FVAU19 | 2021-06-18 08:57:57.752
Mapping F.US.FVAU19 to ZFU19. Service code: cbot | 2021-06-18 08:57:57.752
SC Data - All Services | Starting real-time market data updates for: F.US.FVAU19 (ZFU19). ID: 220 Service code: cbot | 2021-06-18 08:57:57.752
CQG WebAPI | Sending symbol resolution request for F.US.FVAU19. ID: 75071 | 2021-06-18 08:57:57.752
SC Data - All Services | Requesting security definition data for: F.US.FVAU19 (ZFU19). ID: 220 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.NE6M19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.DA6U19 | 2021-06-18 08:57:57.752
Mapping F.US.DA6U19 to 6AU19. Service code: cme | 2021-06-18 08:57:57.752
SC Data - All Services | Starting real-time market data updates for: F.US.DA6U19 (6AU19). ID: 221 Service code: cme | 2021-06-18 08:57:57.752
CQG WebAPI | Sending symbol resolution request for F.US.DA6U19. ID: 75072 | 2021-06-18 08:57:57.752
SC Data - All Services | Requesting security definition data for: F.US.DA6U19 (6AU19). ID: 221 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.SF6U19 | 2021-06-18 08:57:57.752
Mapping F.US.SF6U19 to 6SU19. Service code: cme | 2021-06-18 08:57:57.752
SC Data - All Services | Starting real-time market data updates for: F.US.SF6U19 (6SU19). ID: 222 Service code: cme | 2021-06-18 08:57:57.752
CQG WebAPI | Sending symbol resolution request for F.US.SF6U19. ID: 75073 | 2021-06-18 08:57:57.752
SC Data - All Services | Requesting security definition data for: F.US.SF6U19 (6SU19). ID: 222 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.FBTPU19 | 2021-06-18 08:57:57.752
Mapping F.US.FBTPU19 to FBTP201909_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.752
SC Data - All Services | Starting real-time market data updates for: F.US.FBTPU19 (FBTP201909_FUT_EUREX). ID: 223 Service code: eurex | 2021-06-18 08:57:57.752
CQG WebAPI | Sending symbol resolution request for F.US.FBTPU19. ID: 75074 | 2021-06-18 08:57:57.752
SC Data - All Services | Requesting security definition data for: F.US.FBTPU19 (FBTP201909_FUT_EUREX). ID: 223 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.SF6M19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.DLU19 | 2021-06-18 08:57:57.752
Mapping F.US.DLU19 to FGBM201909_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.752
SC Data - All Services | Starting real-time market data updates for: F.US.DLU19 (FGBM201909_FUT_EUREX). ID: 224 Service code: eurex | 2021-06-18 08:57:57.752
CQG WebAPI | Sending symbol resolution request for F.US.DLU19. ID: 75075 | 2021-06-18 08:57:57.752
SC Data - All Services | Requesting security definition data for: F.US.DLU19 (FGBM201909_FUT_EUREX). ID: 224 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.TUAU19 | 2021-06-18 08:57:57.752
Mapping F.US.TUAU19 to ZTU19. Service code: cbot | 2021-06-18 08:57:57.752
SC Data - All Services | Starting real-time market data updates for: F.US.TUAU19 (ZTU19). ID: 225 Service code: cbot | 2021-06-18 08:57:57.752
CQG WebAPI | Sending symbol resolution request for F.US.TUAU19. ID: 75076 | 2021-06-18 08:57:57.752
SC Data - All Services | Requesting security definition data for: F.US.TUAU19 (ZTU19). ID: 225 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.NGEV19 | 2021-06-18 08:57:57.752
Mapping F.US.NGEV19 to NGV19. Service code: nymex | 2021-06-18 08:57:57.752
SC Data - All Services | Starting real-time market data updates for: F.US.NGEV19 (NGV19). ID: 226 Service code: nymex | 2021-06-18 08:57:57.752
CQG WebAPI | Sending symbol resolution request for F.US.NGEV19. ID: 75077 | 2021-06-18 08:57:57.752
SC Data - All Services | Requesting security definition data for: F.US.NGEV19 (NGV19). ID: 226 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.EU6M19 | 2021-06-18 08:57:57.752
Subscribing to symbol for symbol alert. F.US.PLEV19 | 2021-06-18 08:57:57.752
Mapping F.US.PLEV19 to PLV19. Service code: nymex | 2021-06-18 08:57:57.752
SC Data - All Services | Starting real-time market data updates for: F.US.PLEV19 (PLV19). ID: 227 Service code: nymex | 2021-06-18 08:57:57.753
CQG WebAPI | Sending symbol resolution request for F.US.PLEV19. ID: 75078 | 2021-06-18 08:57:57.753
SC Data - All Services | Requesting security definition data for: F.US.PLEV19 (PLV19). ID: 227 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.TYAU19 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.DSXM19 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.HEV19 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.DA6U19 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.GLEG20 | 2021-06-18 08:57:57.753
Mapping F.US.GLEG20 to LEG20. Service code: cme | 2021-06-18 08:57:57.753
SC Data - All Services | Starting real-time market data updates for: F.US.GLEG20 (LEG20). ID: 228 Service code: cme | 2021-06-18 08:57:57.753
CQG WebAPI | Sending symbol resolution request for F.US.GLEG20. ID: 75079 | 2021-06-18 08:57:57.753
SC Data - All Services | Requesting security definition data for: F.US.GLEG20 (LEG20). ID: 228 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.USAU19 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.TNAU19 | 2021-06-18 08:57:57.753
Mapping F.US.TNAU19 to TNU19. Service code: cbot | 2021-06-18 08:57:57.753
SC Data - All Services | Starting real-time market data updates for: F.US.TNAU19 (TNU19). ID: 229 Service code: cbot | 2021-06-18 08:57:57.753
CQG WebAPI | Sending symbol resolution request for F.US.TNAU19. ID: 75080 | 2021-06-18 08:57:57.753
SC Data - All Services | Requesting security definition data for: F.US.TNAU19 (TNU19). ID: 229 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.BP6U19 | 2021-06-18 08:57:57.753
Mapping F.US.BP6U19 to 6BU19. Service code: cme | 2021-06-18 08:57:57.753
SC Data - All Services | Starting real-time market data updates for: F.US.BP6U19 (6BU19). ID: 230 Service code: cme | 2021-06-18 08:57:57.753
CQG WebAPI | Sending symbol resolution request for F.US.BP6U19. ID: 75081 | 2021-06-18 08:57:57.753
SC Data - All Services | Requesting security definition data for: F.US.BP6U19 (6BU19). ID: 230 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.PLEN19 | 2021-06-18 08:57:57.753
Subscribing to symbol for symbol alert. F.US.DSXU19 | 2021-06-18 08:57:57.753
Mapping F.US.DSXU19 to FESX201909_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.753
SC Data - All Services | Starting real-time market data updates for: F.US.DSXU19 (FESX201909_FUT_EUREX). ID: 231 Service code: eurex | 2021-06-18 08:57:57.754
CQG WebAPI | Sending symbol resolution request for F.US.DSXU19. ID: 75082 | 2021-06-18 08:57:57.754
SC Data - All Services | Requesting security definition data for: F.US.DSXU19 (FESX201909_FUT_EUREX). ID: 231 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.TYAU19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.DSXU19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.FVAU19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.TNAU19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.CPEN19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.GFQ19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.ZWAU19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.USAU19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.HEG20 | 2021-06-18 08:57:57.754
Mapping F.US.HEG20 to HEG20. Service code: cme | 2021-06-18 08:57:57.754
SC Data - All Services | Starting real-time market data updates for: F.US.HEG20 (HEG20). ID: 232 Service code: cme | 2021-06-18 08:57:57.754
CQG WebAPI | Sending symbol resolution request for F.US.HEG20. ID: 75083 | 2021-06-18 08:57:57.754
SC Data - All Services | Requesting security definition data for: F.US.HEG20 (HEG20). ID: 232 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.PLEV19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.EU6U19 | 2021-06-18 08:57:57.754
Mapping F.US.EU6U19 to 6EU19. Service code: cme | 2021-06-18 08:57:57.754
SC Data - All Services | Starting real-time market data updates for: F.US.EU6U19 (6EU19). ID: 233 Service code: cme | 2021-06-18 08:57:57.754
CQG WebAPI | Sending symbol resolution request for F.US.EU6U19. ID: 75084 | 2021-06-18 08:57:57.754
SC Data - All Services | Requesting security definition data for: F.US.EU6U19 (6EU19). ID: 233 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.RBEU19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.BP6U19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.CA6U19 | 2021-06-18 08:57:57.754
Mapping F.US.CA6U19 to 6CU19. Service code: cme | 2021-06-18 08:57:57.754
SC Data - All Services | Starting real-time market data updates for: F.US.CA6U19 (6CU19). ID: 234 Service code: cme | 2021-06-18 08:57:57.754
CQG WebAPI | Sending symbol resolution request for F.US.CA6U19. ID: 75085 | 2021-06-18 08:57:57.754
SC Data - All Services | Requesting security definition data for: F.US.CA6U19 (6CU19). ID: 234 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.GLEV19 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.ZSEF20 | 2021-06-18 08:57:57.754
Mapping F.US.ZSEF20 to ZSF20. Service code: cbot | 2021-06-18 08:57:57.754
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEF20 (ZSF20). ID: 235 Service code: cbot | 2021-06-18 08:57:57.754
CQG WebAPI | Sending symbol resolution request for F.US.ZSEF20. ID: 75086 | 2021-06-18 08:57:57.754
SC Data - All Services | Requesting security definition data for: F.US.ZSEF20 (ZSF20). ID: 235 | 2021-06-18 08:57:57.754
Subscribing to symbol for symbol alert. F.US.DSXU19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.PLEV19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.USAU19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.DLU19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.TYAU19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.EU6U19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.ZLEF20 | 2021-06-18 08:57:57.755
Mapping F.US.ZLEF20 to ZLF20. Service code: cbot | 2021-06-18 08:57:57.755
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEF20 (ZLF20). ID: 236 Service code: cbot | 2021-06-18 08:57:57.755
CQG WebAPI | Sending symbol resolution request for F.US.ZLEF20. ID: 75087 | 2021-06-18 08:57:57.755
SC Data - All Services | Requesting security definition data for: F.US.ZLEF20 (ZLF20). ID: 236 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.CPEU19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.DBU19 | 2021-06-18 08:57:57.755
Mapping F.US.DBU19 to FGBL201909_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.755
SC Data - All Services | Starting real-time market data updates for: F.US.DBU19 (FGBL201909_FUT_EUREX). ID: 237 Service code: eurex | 2021-06-18 08:57:57.755
CQG WebAPI | Sending symbol resolution request for F.US.DBU19. ID: 75088 | 2021-06-18 08:57:57.755
SC Data - All Services | Requesting security definition data for: F.US.DBU19 (FGBL201909_FUT_EUREX). ID: 237 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.TUAU19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.BP6U19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.RBEZ19 | 2021-06-18 08:57:57.755
Mapping F.US.RBEZ19 to RBZ19. Service code: nymex | 2021-06-18 08:57:57.755
SC Data - All Services | Starting real-time market data updates for: F.US.RBEZ19 (RBZ19). ID: 238 Service code: nymex | 2021-06-18 08:57:57.755
CQG WebAPI | Sending symbol resolution request for F.US.RBEZ19. ID: 75089 | 2021-06-18 08:57:57.755
SC Data - All Services | Requesting security definition data for: F.US.RBEZ19 (RBZ19). ID: 238 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.FOATU19 | 2021-06-18 08:57:57.755
Mapping F.US.FOATU19 to FOAT201909_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.755
SC Data - All Services | Starting real-time market data updates for: F.US.FOATU19 (FOAT201909_FUT_EUREX). ID: 239 Service code: eurex | 2021-06-18 08:57:57.755
CQG WebAPI | Sending symbol resolution request for F.US.FOATU19. ID: 75090 | 2021-06-18 08:57:57.755
SC Data - All Services | Requesting security definition data for: F.US.FOATU19 (FOAT201909_FUT_EUREX). ID: 239 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.GCEZ19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.JY6U19 | 2021-06-18 08:57:57.755
Mapping F.US.JY6U19 to 6JU19. Service code: cme | 2021-06-18 08:57:57.755
SC Data - All Services | Starting real-time market data updates for: F.US.JY6U19 (6JU19). ID: 240 Service code: cme | 2021-06-18 08:57:57.755
CQG WebAPI | Sending symbol resolution request for F.US.JY6U19. ID: 75091 | 2021-06-18 08:57:57.755
SC Data - All Services | Requesting security definition data for: F.US.JY6U19 (6JU19). ID: 240 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.ZWAU19 | 2021-06-18 08:57:57.755
Subscribing to symbol for symbol alert. F.US.HEZ19 | 2021-06-18 08:57:57.755
Mapping F.US.HEZ19 to HEZ19. Service code: cme | 2021-06-18 08:57:57.756
SC Data - All Services | Starting real-time market data updates for: F.US.HEZ19 (HEZ19). ID: 241 Service code: cme | 2021-06-18 08:57:57.756
CQG WebAPI | Sending symbol resolution request for F.US.HEZ19. ID: 75092 | 2021-06-18 08:57:57.756
SC Data - All Services | Requesting security definition data for: F.US.HEZ19 (HEZ19). ID: 241 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.TYAU19 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.FOATU19 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.DSXU19 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.DLU19 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.GLEV19 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.KWEZ19 | 2021-06-18 08:57:57.756
Mapping F.US.KWEZ19 to KEZ19. Service code: cbot | 2021-06-18 08:57:57.756
SC Data - All Services | Starting real-time market data updates for: F.US.KWEZ19 (KEZ19). ID: 242 Service code: cbot | 2021-06-18 08:57:57.756
CQG WebAPI | Sending symbol resolution request for F.US.KWEZ19. ID: 75093 | 2021-06-18 08:57:57.756
SC Data - All Services | Requesting security definition data for: F.US.KWEZ19 (KEZ19). ID: 242 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.EPU19 | 2021-06-18 08:57:57.756
Mapping F.US.EPU19 to ESU19. Service code: cme | 2021-06-18 08:57:57.756
SC Data - All Services | Starting real-time market data updates for: F.US.EPU19 (ESU19). ID: 243 Service code: cme | 2021-06-18 08:57:57.756
CQG WebAPI | Sending symbol resolution request for F.US.EPU19. ID: 75094 | 2021-06-18 08:57:57.756
SC Data - All Services | Requesting security definition data for: F.US.EPU19 (ESU19). ID: 243 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.TNAU19 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.HEZ19 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.NE6U19 | 2021-06-18 08:57:57.756
Mapping F.US.NE6U19 to 6NU19. Service code: cme | 2021-06-18 08:57:57.756
SC Data - All Services | Starting real-time market data updates for: F.US.NE6U19 (6NU19). ID: 244 Service code: cme | 2021-06-18 08:57:57.756
CQG WebAPI | Sending symbol resolution request for F.US.NE6U19. ID: 75095 | 2021-06-18 08:57:57.756
SC Data - All Services | Requesting security definition data for: F.US.NE6U19 (6NU19). ID: 244 | 2021-06-18 08:57:57.756
Subscribing to symbol for symbol alert. F.US.TYAU19 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.DSXU19 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.TYAZ19 | 2021-06-18 08:57:57.757
Mapping F.US.TYAZ19 to ZNZ19. Service code: cbot | 2021-06-18 08:57:57.757
SC Data - All Services | Starting real-time market data updates for: F.US.TYAZ19 (ZNZ19). ID: 245 Service code: cbot | 2021-06-18 08:57:57.757
CQG WebAPI | Sending symbol resolution request for F.US.TYAZ19. ID: 75096 | 2021-06-18 08:57:57.757
SC Data - All Services | Requesting security definition data for: F.US.TYAZ19 (ZNZ19). ID: 245 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.ZLEF20 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.FBTSU19 | 2021-06-18 08:57:57.757
Mapping F.US.FBTSU19 to FBTS201909_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.757
SC Data - All Services | Starting real-time market data updates for: F.US.FBTSU19 (FBTS201909_FUT_EUREX). ID: 246 Service code: eurex | 2021-06-18 08:57:57.757
CQG WebAPI | Sending symbol resolution request for F.US.FBTSU19. ID: 75097 | 2021-06-18 08:57:57.757
SC Data - All Services | Requesting security definition data for: F.US.FBTSU19 (FBTS201909_FUT_EUREX). ID: 246 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.DA6U19 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.SF6U19 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.ZWAH20 | 2021-06-18 08:57:57.757
Mapping F.US.ZWAH20 to ZWH20. Service code: cbot | 2021-06-18 08:57:57.757
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAH20 (ZWH20). ID: 247 Service code: cbot | 2021-06-18 08:57:57.757
CQG WebAPI | Sending symbol resolution request for F.US.ZWAH20. ID: 75098 | 2021-06-18 08:57:57.757
SC Data - All Services | Requesting security definition data for: F.US.ZWAH20 (ZWH20). ID: 247 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.TNAZ19 | 2021-06-18 08:57:57.757
Mapping F.US.TNAZ19 to TNZ19. Service code: cbot | 2021-06-18 08:57:57.757
SC Data - All Services | Starting real-time market data updates for: F.US.TNAZ19 (TNZ19). ID: 248 Service code: cbot | 2021-06-18 08:57:57.757
CQG WebAPI | Sending symbol resolution request for F.US.TNAZ19. ID: 75099 | 2021-06-18 08:57:57.757
SC Data - All Services | Requesting security definition data for: F.US.TNAZ19 (TNZ19). ID: 248 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.DLZ19 | 2021-06-18 08:57:57.757
Mapping F.US.DLZ19 to FGBM201912_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.757
SC Data - All Services | Starting real-time market data updates for: F.US.DLZ19 (FGBM201912_FUT_EUREX). ID: 249 Service code: eurex | 2021-06-18 08:57:57.757
CQG WebAPI | Sending symbol resolution request for F.US.DLZ19. ID: 75100 | 2021-06-18 08:57:57.757
SC Data - All Services | Requesting security definition data for: F.US.DLZ19 (FGBM201912_FUT_EUREX). ID: 249 | 2021-06-18 08:57:57.757
Subscribing to symbol for symbol alert. F.US.ULAZ19 | 2021-06-18 08:57:57.757
Mapping F.US.ULAZ19 to UBZ19. Service code: cbot | 2021-06-18 08:57:57.758
SC Data - All Services | Starting real-time market data updates for: F.US.ULAZ19 (UBZ19). ID: 250 Service code: cbot | 2021-06-18 08:57:57.758
CQG WebAPI | Sending symbol resolution request for F.US.ULAZ19. ID: 75101 | 2021-06-18 08:57:57.758
SC Data - All Services | Requesting security definition data for: F.US.ULAZ19 (UBZ19). ID: 250 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.TYAZ19 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.PLEV19 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.DLZ19 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.ZCEZ19 | 2021-06-18 08:57:57.758
Mapping F.US.ZCEZ19 to ZCZ19. Service code: cbot | 2021-06-18 08:57:57.758
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEZ19 (ZCZ19). ID: 251 Service code: cbot | 2021-06-18 08:57:57.758
CQG WebAPI | Sending symbol resolution request for F.US.ZCEZ19. ID: 75102 | 2021-06-18 08:57:57.758
SC Data - All Services | Requesting security definition data for: F.US.ZCEZ19 (ZCZ19). ID: 251 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.CPEZ19 | 2021-06-18 08:57:57.758
Mapping F.US.CPEZ19 to HGZ19. Service code: comex | 2021-06-18 08:57:57.758
SC Data - All Services | Starting real-time market data updates for: F.US.CPEZ19 (HGZ19). ID: 252 Service code: comex | 2021-06-18 08:57:57.758
CQG WebAPI | Sending symbol resolution request for F.US.CPEZ19. ID: 75103 | 2021-06-18 08:57:57.758
SC Data - All Services | Requesting security definition data for: F.US.CPEZ19 (HGZ19). ID: 252 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.DSXU19 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.DA6U19 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.EPZ19 | 2021-06-18 08:57:57.758
Mapping F.US.EPZ19 to ESZ19. Service code: cme | 2021-06-18 08:57:57.758
SC Data - All Services | Starting real-time market data updates for: F.US.EPZ19 (ESZ19). ID: 253 Service code: cme | 2021-06-18 08:57:57.758
CQG WebAPI | Sending symbol resolution request for F.US.EPZ19. ID: 75104 | 2021-06-18 08:57:57.758
SC Data - All Services | Requesting security definition data for: F.US.EPZ19 (ESZ19). ID: 253 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.JY6U19 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.CA6Z19 | 2021-06-18 08:57:57.758
Mapping F.US.CA6Z19 to 6CZ19. Service code: cme | 2021-06-18 08:57:57.758
SC Data - All Services | Starting real-time market data updates for: F.US.CA6Z19 (6CZ19). ID: 254 Service code: cme | 2021-06-18 08:57:57.758
CQG WebAPI | Sending symbol resolution request for F.US.CA6Z19. ID: 75105 | 2021-06-18 08:57:57.758
SC Data - All Services | Requesting security definition data for: F.US.CA6Z19 (6CZ19). ID: 254 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.GLEG20 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.EU6U19 | 2021-06-18 08:57:57.758
Subscribing to symbol for symbol alert. F.US.BP6Z19 | 2021-06-18 08:57:57.758
Mapping F.US.BP6Z19 to 6BZ19. Service code: cme | 2021-06-18 08:57:57.758
SC Data - All Services | Starting real-time market data updates for: F.US.BP6Z19 (6BZ19). ID: 255 Service code: cme | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.BP6Z19. ID: 75106 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.BP6Z19 (6BZ19). ID: 255 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.CPEZ19 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.DSXU19 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.TYAZ19 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.USAZ19 | 2021-06-18 08:57:57.759
Mapping F.US.USAZ19 to ZBZ19. Service code: cbot | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.USAZ19 (ZBZ19). ID: 256 Service code: cbot | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.USAZ19. ID: 75107 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.USAZ19 (ZBZ19). ID: 256 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.GCEZ19 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.GFV19 | 2021-06-18 08:57:57.759
Mapping F.US.GFV19 to GFV19. Service code: cme | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.GFV19 (GFV19). ID: 257 Service code: cme | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.GFV19. ID: 75108 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.GFV19 (GFV19). ID: 257 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.DBZ19 | 2021-06-18 08:57:57.759
Mapping F.US.DBZ19 to FGBL201912_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.DBZ19 (FGBL201912_FUT_EUREX). ID: 258 Service code: eurex | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.DBZ19. ID: 75109 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.DBZ19 (FGBL201912_FUT_EUREX). ID: 258 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.DLZ19 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.HOEX19 | 2021-06-18 08:57:57.759
Mapping F.US.HOEX19 to HOX19. Service code: nymex | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.HOEX19 (HOX19). ID: 259 Service code: nymex | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.HOEX19. ID: 75110 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.HOEX19 (HOX19). ID: 259 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.NGEV19 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.DSXZ19 | 2021-06-18 08:57:57.759
Mapping F.US.DSXZ19 to FESX201912_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.DSXZ19 (FESX201912_FUT_EUREX). ID: 260 Service code: eurex | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.DSXZ19. ID: 75111 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.DSXZ19 (FESX201912_FUT_EUREX). ID: 260 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.FOATZ19 | 2021-06-18 08:57:57.759
Mapping F.US.FOATZ19 to FOAT201912_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.FOATZ19 (FOAT201912_FUT_EUREX). ID: 261 Service code: eurex | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.FOATZ19. ID: 75112 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.FOATZ19 (FOAT201912_FUT_EUREX). ID: 261 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.NGEX19 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.NE6Z19 | 2021-06-18 08:57:57.759
Mapping F.US.NE6Z19 to 6NZ19. Service code: cme | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.NE6Z19 (6NZ19). ID: 262 Service code: cme | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.NE6Z19. ID: 75113 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.NE6Z19 (6NZ19). ID: 262 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.FVAZ19 | 2021-06-18 08:57:57.759
Mapping F.US.FVAZ19 to ZFZ19. Service code: cbot | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.FVAZ19 (ZFZ19). ID: 263 Service code: cbot | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.FVAZ19. ID: 75114 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.FVAZ19 (ZFZ19). ID: 263 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.YMZ19 | 2021-06-18 08:57:57.759
Mapping F.US.YMZ19 to YMZ19. Service code: cbot | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.YMZ19 (YMZ19). ID: 264 Service code: cbot | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.YMZ19. ID: 75115 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.YMZ19 (YMZ19). ID: 264 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.ULAZ19 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.DA6Z19 | 2021-06-18 08:57:57.759
Mapping F.US.DA6Z19 to 6AZ19. Service code: cme | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.DA6Z19 (6AZ19). ID: 265 Service code: cme | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.DA6Z19. ID: 75116 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.DA6Z19 (6AZ19). ID: 265 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.GFX19 | 2021-06-18 08:57:57.759
Mapping F.US.GFX19 to GFX19. Service code: cme | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.GFX19 (GFX19). ID: 266 Service code: cme | 2021-06-18 08:57:57.759
CQG WebAPI | Sending symbol resolution request for F.US.GFX19. ID: 75117 | 2021-06-18 08:57:57.759
SC Data - All Services | Requesting security definition data for: F.US.GFX19 (GFX19). ID: 266 | 2021-06-18 08:57:57.759
Subscribing to symbol for symbol alert. F.US.KWEH20 | 2021-06-18 08:57:57.759
Mapping F.US.KWEH20 to KEH20. Service code: cbot | 2021-06-18 08:57:57.759
SC Data - All Services | Starting real-time market data updates for: F.US.KWEH20 (KEH20). ID: 267 Service code: cbot | 2021-06-18 08:57:57.760
CQG WebAPI | Sending symbol resolution request for F.US.KWEH20. ID: 75118 | 2021-06-18 08:57:57.760
SC Data - All Services | Requesting security definition data for: F.US.KWEH20 (KEH20). ID: 267 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.TYAZ19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.EPZ19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.BP6Z19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.ZREX19 | 2021-06-18 08:57:57.760
Mapping F.US.ZREX19 to ZRX19. Service code: cbot | 2021-06-18 08:57:57.760
SC Data - All Services | Starting real-time market data updates for: F.US.ZREX19 (ZRX19). ID: 268 Service code: cbot | 2021-06-18 08:57:57.760
CQG WebAPI | Sending symbol resolution request for F.US.ZREX19. ID: 75119 | 2021-06-18 08:57:57.760
SC Data - All Services | Requesting security definition data for: F.US.ZREX19 (ZRX19). ID: 268 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.DSXZ19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.SF6Z19 | 2021-06-18 08:57:57.760
Mapping F.US.SF6Z19 to 6SZ19. Service code: cme | 2021-06-18 08:57:57.760
SC Data - All Services | Starting real-time market data updates for: F.US.SF6Z19 (6SZ19). ID: 269 Service code: cme | 2021-06-18 08:57:57.760
CQG WebAPI | Sending symbol resolution request for F.US.SF6Z19. ID: 75120 | 2021-06-18 08:57:57.760
SC Data - All Services | Requesting security definition data for: F.US.SF6Z19 (6SZ19). ID: 269 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.EU6Z19 | 2021-06-18 08:57:57.760
Mapping F.US.EU6Z19 to 6EZ19. Service code: cme | 2021-06-18 08:57:57.760
SC Data - All Services | Starting real-time market data updates for: F.US.EU6Z19 (6EZ19). ID: 270 Service code: cme | 2021-06-18 08:57:57.760
CQG WebAPI | Sending symbol resolution request for F.US.EU6Z19. ID: 75121 | 2021-06-18 08:57:57.760
SC Data - All Services | Requesting security definition data for: F.US.EU6Z19 (6EZ19). ID: 270 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.DLZ19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.GCEZ19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.ZSEX19 | 2021-06-18 08:57:57.760
Mapping F.US.ZSEX19 to ZSX19. Service code: cbot | 2021-06-18 08:57:57.760
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEX19 (ZSX19). ID: 271 Service code: cbot | 2021-06-18 08:57:57.760
CQG WebAPI | Sending symbol resolution request for F.US.ZSEX19. ID: 75122 | 2021-06-18 08:57:57.760
SC Data - All Services | Requesting security definition data for: F.US.ZSEX19 (ZSX19). ID: 271 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.FGBXZ19 | 2021-06-18 08:57:57.760
Mapping F.US.FGBXZ19 to FGBX201912_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.760
SC Data - All Services | Starting real-time market data updates for: F.US.FGBXZ19 (FGBX201912_FUT_EUREX). ID: 272 Service code: eurex | 2021-06-18 08:57:57.760
CQG WebAPI | Sending symbol resolution request for F.US.FGBXZ19. ID: 75123 | 2021-06-18 08:57:57.760
SC Data - All Services | Requesting security definition data for: F.US.FGBXZ19 (FGBX201912_FUT_EUREX). ID: 272 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.FVAZ19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.PLEF20 | 2021-06-18 08:57:57.760
Mapping F.US.PLEF20 to PLF20. Service code: nymex | 2021-06-18 08:57:57.760
SC Data - All Services | Starting real-time market data updates for: F.US.PLEF20 (PLF20). ID: 273 Service code: nymex | 2021-06-18 08:57:57.760
CQG WebAPI | Sending symbol resolution request for F.US.PLEF20. ID: 75124 | 2021-06-18 08:57:57.760
SC Data - All Services | Requesting security definition data for: F.US.PLEF20 (PLF20). ID: 273 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.CPEZ19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.ZCEZ19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.ZCEH20 | 2021-06-18 08:57:57.760
Mapping F.US.ZCEH20 to ZCH20. Service code: cbot | 2021-06-18 08:57:57.760
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEH20 (ZCH20). ID: 274 Service code: cbot | 2021-06-18 08:57:57.760
CQG WebAPI | Sending symbol resolution request for F.US.ZCEH20. ID: 75125 | 2021-06-18 08:57:57.760
SC Data - All Services | Requesting security definition data for: F.US.ZCEH20 (ZCH20). ID: 274 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.USAZ19 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.NGEZ19 | 2021-06-18 08:57:57.760
Mapping F.US.NGEZ19 to NGZ19. Service code: nymex | 2021-06-18 08:57:57.760
SC Data - All Services | Starting real-time market data updates for: F.US.NGEZ19 (NGZ19). ID: 275 Service code: nymex | 2021-06-18 08:57:57.760
CQG WebAPI | Sending symbol resolution request for F.US.NGEZ19. ID: 75126 | 2021-06-18 08:57:57.760
SC Data - All Services | Requesting security definition data for: F.US.NGEZ19 (NGZ19). ID: 275 | 2021-06-18 08:57:57.760
Subscribing to symbol for symbol alert. F.US.CLEZ19 | 2021-06-18 08:57:57.760
Mapping F.US.CLEZ19 to CLZ19. Service code: nymex | 2021-06-18 08:57:57.760
SC Data - All Services | Starting real-time market data updates for: F.US.CLEZ19 (CLZ19). ID: 276 Service code: nymex | 2021-06-18 08:57:57.761
CQG WebAPI | Sending symbol resolution request for F.US.CLEZ19. ID: 75127 | 2021-06-18 08:57:57.761
SC Data - All Services | Requesting security definition data for: F.US.CLEZ19 (CLZ19). ID: 276 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.NGEZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.TYAZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.GCEZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.DSXZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.EU6Z19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.NGEX19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.CLEZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.ZMEZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.ZSEF20 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.CPEZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.PLEF20 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.ZSEX19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.HOEF20 | 2021-06-18 08:57:57.761
Mapping F.US.HOEF20 to HOF20. Service code: nymex | 2021-06-18 08:57:57.761
SC Data - All Services | Starting real-time market data updates for: F.US.HOEF20 (HOF20). ID: 277 Service code: nymex | 2021-06-18 08:57:57.761
CQG WebAPI | Sending symbol resolution request for F.US.HOEF20. ID: 75128 | 2021-06-18 08:57:57.761
SC Data - All Services | Requesting security definition data for: F.US.HOEF20 (HOF20). ID: 277 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.DA6Z19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.GLEJ20 | 2021-06-18 08:57:57.761
Mapping F.US.GLEJ20 to LEJ20. Service code: cme | 2021-06-18 08:57:57.761
SC Data - All Services | Starting real-time market data updates for: F.US.GLEJ20 (LEJ20). ID: 278 Service code: cme | 2021-06-18 08:57:57.761
CQG WebAPI | Sending symbol resolution request for F.US.GLEJ20. ID: 75129 | 2021-06-18 08:57:57.761
SC Data - All Services | Requesting security definition data for: F.US.GLEJ20 (LEJ20). ID: 278 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.BP6Z19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.FVAZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.ZSEH20 | 2021-06-18 08:57:57.761
Mapping F.US.ZSEH20 to ZSH20. Service code: cbot | 2021-06-18 08:57:57.761
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEH20 (ZSH20). ID: 279 Service code: cbot | 2021-06-18 08:57:57.761
CQG WebAPI | Sending symbol resolution request for F.US.ZSEH20. ID: 75130 | 2021-06-18 08:57:57.761
SC Data - All Services | Requesting security definition data for: F.US.ZSEH20 (ZSH20). ID: 279 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.HOEH20 | 2021-06-18 08:57:57.761
Mapping F.US.HOEH20 to HOH20. Service code: nymex | 2021-06-18 08:57:57.761
SC Data - All Services | Starting real-time market data updates for: F.US.HOEH20 (HOH20). ID: 280 Service code: nymex | 2021-06-18 08:57:57.761
CQG WebAPI | Sending symbol resolution request for F.US.HOEH20. ID: 75131 | 2021-06-18 08:57:57.761
SC Data - All Services | Requesting security definition data for: F.US.HOEH20 (HOH20). ID: 280 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.CLEG20 | 2021-06-18 08:57:57.761
Mapping F.US.CLEG20 to CLG20. Service code: nymex | 2021-06-18 08:57:57.761
SC Data - All Services | Starting real-time market data updates for: F.US.CLEG20 (CLG20). ID: 281 Service code: nymex | 2021-06-18 08:57:57.761
CQG WebAPI | Sending symbol resolution request for F.US.CLEG20. ID: 75132 | 2021-06-18 08:57:57.761
SC Data - All Services | Requesting security definition data for: F.US.CLEG20 (CLG20). ID: 281 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.USAZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.TUAZ19 | 2021-06-18 08:57:57.761
Mapping F.US.TUAZ19 to ZTZ19. Service code: cbot | 2021-06-18 08:57:57.761
SC Data - All Services | Starting real-time market data updates for: F.US.TUAZ19 (ZTZ19). ID: 282 Service code: cbot | 2021-06-18 08:57:57.761
CQG WebAPI | Sending symbol resolution request for F.US.TUAZ19. ID: 75133 | 2021-06-18 08:57:57.761
SC Data - All Services | Requesting security definition data for: F.US.TUAZ19 (ZTZ19). ID: 282 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.DBZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.GCEG20 | 2021-06-18 08:57:57.761
Mapping F.US.GCEG20 to GCG20. Service code: comex | 2021-06-18 08:57:57.761
SC Data - All Services | Starting real-time market data updates for: F.US.GCEG20 (GCG20). ID: 283 Service code: comex | 2021-06-18 08:57:57.761
CQG WebAPI | Sending symbol resolution request for F.US.GCEG20. ID: 75134 | 2021-06-18 08:57:57.761
SC Data - All Services | Requesting security definition data for: F.US.GCEG20 (GCG20). ID: 283 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.EPZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.DLZ19 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.ZCEH20 | 2021-06-18 08:57:57.761
Subscribing to symbol for symbol alert. F.US.ZSEF20 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.ZMEZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.KWEH20 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.ZCEH20 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.GFF20 | 2021-06-18 08:57:57.762
Mapping F.US.GFF20 to GFF20. Service code: cme | 2021-06-18 08:57:57.762
SC Data - All Services | Starting real-time market data updates for: F.US.GFF20 (GFF20). ID: 284 Service code: cme | 2021-06-18 08:57:57.762
CQG WebAPI | Sending symbol resolution request for F.US.GFF20. ID: 75135 | 2021-06-18 08:57:57.762
SC Data - All Services | Requesting security definition data for: F.US.GFF20 (GFF20). ID: 284 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.TYAZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.CPEH20 | 2021-06-18 08:57:57.762
Mapping F.US.CPEH20 to HGH20. Service code: comex | 2021-06-18 08:57:57.762
SC Data - All Services | Starting real-time market data updates for: F.US.CPEH20 (HGH20). ID: 285 Service code: comex | 2021-06-18 08:57:57.762
CQG WebAPI | Sending symbol resolution request for F.US.CPEH20. ID: 75136 | 2021-06-18 08:57:57.762
SC Data - All Services | Requesting security definition data for: F.US.CPEH20 (HGH20). ID: 285 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.NGEH20 | 2021-06-18 08:57:57.762
Mapping F.US.NGEH20 to NGH20. Service code: nymex | 2021-06-18 08:57:57.762
SC Data - All Services | Starting real-time market data updates for: F.US.NGEH20 (NGH20). ID: 286 Service code: nymex | 2021-06-18 08:57:57.762
CQG WebAPI | Sending symbol resolution request for F.US.NGEH20. ID: 75137 | 2021-06-18 08:57:57.762
SC Data - All Services | Requesting security definition data for: F.US.NGEH20 (NGH20). ID: 286 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.ZSEH20 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.EU6Z19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.ZSEX19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.CPEZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.BP6Z19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.USAZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.DSXZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.ZCEZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.DBZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.ULAZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.SF6Z19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.ZLEZ19 | 2021-06-18 08:57:57.762
Mapping F.US.ZLEZ19 to ZLZ19. Service code: cbot | 2021-06-18 08:57:57.762
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEZ19 (ZLZ19). ID: 287 Service code: cbot | 2021-06-18 08:57:57.762
CQG WebAPI | Sending symbol resolution request for F.US.ZLEZ19. ID: 75138 | 2021-06-18 08:57:57.762
SC Data - All Services | Requesting security definition data for: F.US.ZLEZ19 (ZLZ19). ID: 287 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.TNAZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.ZLEF20 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.ZLEK20 | 2021-06-18 08:57:57.762
Mapping F.US.ZLEK20 to ZLK20. Service code: cbot | 2021-06-18 08:57:57.762
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEK20 (ZLK20). ID: 288 Service code: cbot | 2021-06-18 08:57:57.762
CQG WebAPI | Sending symbol resolution request for F.US.ZLEK20. ID: 75139 | 2021-06-18 08:57:57.762
SC Data - All Services | Requesting security definition data for: F.US.ZLEK20 (ZLK20). ID: 288 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.FVAZ19 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.NGEF20 | 2021-06-18 08:57:57.762
Mapping F.US.NGEF20 to NGF20. Service code: nymex | 2021-06-18 08:57:57.762
SC Data - All Services | Starting real-time market data updates for: F.US.NGEF20 (NGF20). ID: 289 Service code: nymex | 2021-06-18 08:57:57.762
CQG WebAPI | Sending symbol resolution request for F.US.NGEF20. ID: 75140 | 2021-06-18 08:57:57.762
SC Data - All Services | Requesting security definition data for: F.US.NGEF20 (NGF20). ID: 289 | 2021-06-18 08:57:57.762
Subscribing to symbol for symbol alert. F.US.LBSX19 | 2021-06-18 08:57:57.762
Mapping F.US.LBSX19 to LBSX19. Service code: cme | 2021-06-18 08:57:57.762
SC Data - All Services | Starting real-time market data updates for: F.US.LBSX19 (LBSX19). ID: 290 Service code: cme | 2021-06-18 08:57:57.762
CQG WebAPI | Sending symbol resolution request for F.US.LBSX19. ID: 75141 | 2021-06-18 08:57:57.763
SC Data - All Services | Requesting security definition data for: F.US.LBSX19 (LBSX19). ID: 290 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.LBSX19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.TYAZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.ZLEH20 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.ZLEZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.DSXZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.DLZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.HOEH20 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.CLEF20 | 2021-06-18 08:57:57.763
Mapping F.US.CLEF20 to CLF20. Service code: nymex | 2021-06-18 08:57:57.763
SC Data - All Services | Starting real-time market data updates for: F.US.CLEF20 (CLF20). ID: 291 Service code: nymex | 2021-06-18 08:57:57.763
CQG WebAPI | Sending symbol resolution request for F.US.CLEF20. ID: 75142 | 2021-06-18 08:57:57.763
SC Data - All Services | Requesting security definition data for: F.US.CLEF20 (CLF20). ID: 291 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.NGEZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.CA6Z19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.GLEG20 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.USAZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.TNAZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.CPEZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.ZCEN20 | 2021-06-18 08:57:57.763
Mapping F.US.ZCEN20 to ZCN20. Service code: cbot | 2021-06-18 08:57:57.763
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEN20 (ZCN20). ID: 292 Service code: cbot | 2021-06-18 08:57:57.763
CQG WebAPI | Sending symbol resolution request for F.US.ZCEN20. ID: 75143 | 2021-06-18 08:57:57.763
SC Data - All Services | Requesting security definition data for: F.US.ZCEN20 (ZCN20). ID: 292 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.ZSEF20 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.NGEF20 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.RBEF20 | 2021-06-18 08:57:57.763
Mapping F.US.RBEF20 to RBF20. Service code: nymex | 2021-06-18 08:57:57.763
SC Data - All Services | Starting real-time market data updates for: F.US.RBEF20 (RBF20). ID: 293 Service code: nymex | 2021-06-18 08:57:57.763
CQG WebAPI | Sending symbol resolution request for F.US.RBEF20. ID: 75144 | 2021-06-18 08:57:57.763
SC Data - All Services | Requesting security definition data for: F.US.RBEF20 (RBF20). ID: 293 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.NGEG20 | 2021-06-18 08:57:57.763
Mapping F.US.NGEG20 to NGG20. Service code: nymex | 2021-06-18 08:57:57.763
SC Data - All Services | Starting real-time market data updates for: F.US.NGEG20 (NGG20). ID: 294 Service code: nymex | 2021-06-18 08:57:57.763
CQG WebAPI | Sending symbol resolution request for F.US.NGEG20. ID: 75145 | 2021-06-18 08:57:57.763
SC Data - All Services | Requesting security definition data for: F.US.NGEG20 (NGG20). ID: 294 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.ULAZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.EU6Z19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.ZWAK20 | 2021-06-18 08:57:57.763
Mapping F.US.ZWAK20 to ZWK20. Service code: cbot | 2021-06-18 08:57:57.763
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAK20 (ZWK20). ID: 295 Service code: cbot | 2021-06-18 08:57:57.763
CQG WebAPI | Sending symbol resolution request for F.US.ZWAK20. ID: 75146 | 2021-06-18 08:57:57.763
SC Data - All Services | Requesting security definition data for: F.US.ZWAK20 (ZWK20). ID: 295 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.CLEH20 | 2021-06-18 08:57:57.763
Mapping F.US.CLEH20 to CLH20. Service code: nymex | 2021-06-18 08:57:57.763
SC Data - All Services | Starting real-time market data updates for: F.US.CLEH20 (CLH20). ID: 296 Service code: nymex | 2021-06-18 08:57:57.763
CQG WebAPI | Sending symbol resolution request for F.US.CLEH20. ID: 75147 | 2021-06-18 08:57:57.763
SC Data - All Services | Requesting security definition data for: F.US.CLEH20 (CLH20). ID: 296 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.NE6Z19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.GCEJ20 | 2021-06-18 08:57:57.763
Mapping F.US.GCEJ20 to GCJ20. Service code: comex | 2021-06-18 08:57:57.763
SC Data - All Services | Starting real-time market data updates for: F.US.GCEJ20 (GCJ20). ID: 297 Service code: comex | 2021-06-18 08:57:57.763
CQG WebAPI | Sending symbol resolution request for F.US.GCEJ20. ID: 75148 | 2021-06-18 08:57:57.763
SC Data - All Services | Requesting security definition data for: F.US.GCEJ20 (GCJ20). ID: 297 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.ZLEN20 | 2021-06-18 08:57:57.763
Mapping F.US.ZLEN20 to ZLN20. Service code: cbot | 2021-06-18 08:57:57.763
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEN20 (ZLN20). ID: 298 Service code: cbot | 2021-06-18 08:57:57.763
CQG WebAPI | Sending symbol resolution request for F.US.ZLEN20. ID: 75149 | 2021-06-18 08:57:57.763
SC Data - All Services | Requesting security definition data for: F.US.ZLEN20 (ZLN20). ID: 298 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.DBZ19 | 2021-06-18 08:57:57.763
Subscribing to symbol for symbol alert. F.US.DBZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.DSXZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.TYAZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.CLEJ20 | 2021-06-18 08:57:57.764
Mapping F.US.CLEJ20 to CLJ20. Service code: nymex | 2021-06-18 08:57:57.764
SC Data - All Services | Starting real-time market data updates for: F.US.CLEJ20 (CLJ20). ID: 299 Service code: nymex | 2021-06-18 08:57:57.764
CQG WebAPI | Sending symbol resolution request for F.US.CLEJ20. ID: 75150 | 2021-06-18 08:57:57.764
SC Data - All Services | Requesting security definition data for: F.US.CLEJ20 (CLJ20). ID: 299 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.NE6Z19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.NGEH20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.KWEZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.CPEZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.USAZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.CPEH20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.DLZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.BP6Z19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.FXXPZ19 | 2021-06-18 08:57:57.764
Mapping F.US.FXXPZ19 to FXXP201912_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.764
SC Data - All Services | Starting real-time market data updates for: F.US.FXXPZ19 (FXXP201912_FUT_EUREX). ID: 300 Service code: eurex | 2021-06-18 08:57:57.764
CQG WebAPI | Sending symbol resolution request for F.US.FXXPZ19. ID: 75151 | 2021-06-18 08:57:57.764
SC Data - All Services | Requesting security definition data for: F.US.FXXPZ19 (FXXP201912_FUT_EUREX). ID: 300 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.ZLEK20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.JY6Z19 | 2021-06-18 08:57:57.764
Mapping F.US.JY6Z19 to 6JZ19. Service code: cme | 2021-06-18 08:57:57.764
SC Data - All Services | Starting real-time market data updates for: F.US.JY6Z19 (6JZ19). ID: 301 Service code: cme | 2021-06-18 08:57:57.764
CQG WebAPI | Sending symbol resolution request for F.US.JY6Z19. ID: 75152 | 2021-06-18 08:57:57.764
SC Data - All Services | Requesting security definition data for: F.US.JY6Z19 (6JZ19). ID: 301 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.SF6Z19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.CLEF20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.PLEF20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.EU6Z19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.ZSEH20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.DA6Z19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.ZLEZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.GCEZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.ZCEZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.FVAZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.TUAZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.GLEG20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.CLEK20 | 2021-06-18 08:57:57.764
Mapping F.US.CLEK20 to CLK20. Service code: nymex | 2021-06-18 08:57:57.764
SC Data - All Services | Starting real-time market data updates for: F.US.CLEK20 (CLK20). ID: 302 Service code: nymex | 2021-06-18 08:57:57.764
CQG WebAPI | Sending symbol resolution request for F.US.CLEK20. ID: 75153 | 2021-06-18 08:57:57.764
SC Data - All Services | Requesting security definition data for: F.US.CLEK20 (CLK20). ID: 302 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.ZWAK20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.ZSEK20 | 2021-06-18 08:57:57.764
Mapping F.US.ZSEK20 to ZSK20. Service code: cbot | 2021-06-18 08:57:57.764
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEK20 (ZSK20). ID: 303 Service code: cbot | 2021-06-18 08:57:57.764
CQG WebAPI | Sending symbol resolution request for F.US.ZSEK20. ID: 75154 | 2021-06-18 08:57:57.764
SC Data - All Services | Requesting security definition data for: F.US.ZSEK20 (ZSK20). ID: 303 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.KWEK20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.NGEF20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.CA6Z19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.NGEZ19 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.ZCEN20 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.SIEH20 | 2021-06-18 08:57:57.764
Mapping F.US.SIEH20 to SIH20. Service code: comex | 2021-06-18 08:57:57.764
SC Data - All Services | Starting real-time market data updates for: F.US.SIEH20 (SIH20). ID: 304 Service code: comex | 2021-06-18 08:57:57.764
CQG WebAPI | Sending symbol resolution request for F.US.SIEH20. ID: 75155 | 2021-06-18 08:57:57.764
SC Data - All Services | Requesting security definition data for: F.US.SIEH20 (SIH20). ID: 304 | 2021-06-18 08:57:57.764
Subscribing to symbol for symbol alert. F.US.GLEM20 | 2021-06-18 08:57:57.764
Mapping F.US.GLEM20 to LEM20. Service code: cme | 2021-06-18 08:57:57.764
SC Data - All Services | Starting real-time market data updates for: F.US.GLEM20 (LEM20). ID: 305 Service code: cme | 2021-06-18 08:57:57.765
CQG WebAPI | Sending symbol resolution request for F.US.GLEM20. ID: 75156 | 2021-06-18 08:57:57.765
SC Data - All Services | Requesting security definition data for: F.US.GLEM20 (LEM20). ID: 305 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.DSXZ19 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.FXXPZ19 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.TYAZ19 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.USAZ19 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.ZCEN20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.GLEM20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.ZCEH20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.ZSEH20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.ZSEK20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.NGEG20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.PLEF20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.CLEH20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.ZSEF20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.GLEG20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.ZLEF20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.NGEH20 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.ZMEK20 | 2021-06-18 08:57:57.765
Mapping F.US.ZMEK20 to ZMK20. Service code: cbot | 2021-06-18 08:57:57.765
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEK20 (ZMK20). ID: 306 Service code: cbot | 2021-06-18 08:57:57.765
CQG WebAPI | Sending symbol resolution request for F.US.ZMEK20. ID: 75157 | 2021-06-18 08:57:57.765
SC Data - All Services | Requesting security definition data for: F.US.ZMEK20 (ZMK20). ID: 306 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.HOEJ20 | 2021-06-18 08:57:57.765
Mapping F.US.HOEJ20 to HOJ20. Service code: nymex | 2021-06-18 08:57:57.765
SC Data - All Services | Starting real-time market data updates for: F.US.HOEJ20 (HOJ20). ID: 307 Service code: nymex | 2021-06-18 08:57:57.765
CQG WebAPI | Sending symbol resolution request for F.US.HOEJ20. ID: 75158 | 2021-06-18 08:57:57.765
SC Data - All Services | Requesting security definition data for: F.US.HOEJ20 (HOJ20). ID: 307 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.TYAH20 | 2021-06-18 08:57:57.765
Mapping F.US.TYAH20 to ZNH20. Service code: cbot | 2021-06-18 08:57:57.765
SC Data - All Services | Starting real-time market data updates for: F.US.TYAH20 (ZNH20). ID: 308 Service code: cbot | 2021-06-18 08:57:57.765
CQG WebAPI | Sending symbol resolution request for F.US.TYAH20. ID: 75159 | 2021-06-18 08:57:57.765
SC Data - All Services | Requesting security definition data for: F.US.TYAH20 (ZNH20). ID: 308 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.DBZ19 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.SF6Z19 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.EU6Z19 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.BP6Z19 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.NE6Z19 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.USAH20 | 2021-06-18 08:57:57.765
Mapping F.US.USAH20 to ZBH20. Service code: cbot | 2021-06-18 08:57:57.765
SC Data - All Services | Starting real-time market data updates for: F.US.USAH20 (ZBH20). ID: 309 Service code: cbot | 2021-06-18 08:57:57.765
CQG WebAPI | Sending symbol resolution request for F.US.USAH20. ID: 75160 | 2021-06-18 08:57:57.765
SC Data - All Services | Requesting security definition data for: F.US.USAH20 (ZBH20). ID: 309 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.GLEV20 | 2021-06-18 08:57:57.765
Mapping F.US.GLEV20 to LEV20. Service code: cme | 2021-06-18 08:57:57.765
SC Data - All Services | Starting real-time market data updates for: F.US.GLEV20 (LEV20). ID: 310 Service code: cme | 2021-06-18 08:57:57.765
CQG WebAPI | Sending symbol resolution request for F.US.GLEV20. ID: 75161 | 2021-06-18 08:57:57.765
SC Data - All Services | Requesting security definition data for: F.US.GLEV20 (LEV20). ID: 310 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.TNAH20 | 2021-06-18 08:57:57.765
Mapping F.US.TNAH20 to TNH20. Service code: cbot | 2021-06-18 08:57:57.765
SC Data - All Services | Starting real-time market data updates for: F.US.TNAH20 (TNH20). ID: 311 Service code: cbot | 2021-06-18 08:57:57.765
CQG WebAPI | Sending symbol resolution request for F.US.TNAH20. ID: 75162 | 2021-06-18 08:57:57.765
SC Data - All Services | Requesting security definition data for: F.US.TNAH20 (TNH20). ID: 311 | 2021-06-18 08:57:57.765
Subscribing to symbol for symbol alert. F.US.ZMEH20 | 2021-06-18 08:57:57.765
Mapping F.US.ZMEH20 to ZMH20. Service code: cbot | 2021-06-18 08:57:57.765
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEH20 (ZMH20). ID: 312 Service code: cbot | 2021-06-18 08:57:57.766
CQG WebAPI | Sending symbol resolution request for F.US.ZMEH20. ID: 75163 | 2021-06-18 08:57:57.766
SC Data - All Services | Requesting security definition data for: F.US.ZMEH20 (ZMH20). ID: 312 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.EU6Z19 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.ZCEK20 | 2021-06-18 08:57:57.766
Mapping F.US.ZCEK20 to ZCK20. Service code: cbot | 2021-06-18 08:57:57.766
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEK20 (ZCK20). ID: 313 Service code: cbot | 2021-06-18 08:57:57.766
CQG WebAPI | Sending symbol resolution request for F.US.ZCEK20. ID: 75164 | 2021-06-18 08:57:57.766
SC Data - All Services | Requesting security definition data for: F.US.ZCEK20 (ZCK20). ID: 313 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.ZCEH20 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.TYAH20 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.DSXZ19 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.NE6H20 | 2021-06-18 08:57:57.766
Mapping F.US.NE6H20 to 6NH20. Service code: cme | 2021-06-18 08:57:57.766
SC Data - All Services | Starting real-time market data updates for: F.US.NE6H20 (6NH20). ID: 314 Service code: cme | 2021-06-18 08:57:57.766
CQG WebAPI | Sending symbol resolution request for F.US.NE6H20. ID: 75165 | 2021-06-18 08:57:57.766
SC Data - All Services | Requesting security definition data for: F.US.NE6H20 (6NH20). ID: 314 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.USAH20 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.ZLEN20 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.CPEH20 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.EU6H20 | 2021-06-18 08:57:57.766
Mapping F.US.EU6H20 to 6EH20. Service code: cme | 2021-06-18 08:57:57.766
SC Data - All Services | Starting real-time market data updates for: F.US.EU6H20 (6EH20). ID: 315 Service code: cme | 2021-06-18 08:57:57.766
CQG WebAPI | Sending symbol resolution request for F.US.EU6H20. ID: 75166 | 2021-06-18 08:57:57.766
SC Data - All Services | Requesting security definition data for: F.US.EU6H20 (6EH20). ID: 315 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.ZSEF20 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.ZMEQ20 | 2021-06-18 08:57:57.766
Mapping F.US.ZMEQ20 to ZMQ20. Service code: cbot | 2021-06-18 08:57:57.766
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEQ20 (ZMQ20). ID: 316 Service code: cbot | 2021-06-18 08:57:57.766
CQG WebAPI | Sending symbol resolution request for F.US.ZMEQ20. ID: 75167 | 2021-06-18 08:57:57.766
SC Data - All Services | Requesting security definition data for: F.US.ZMEQ20 (ZMQ20). ID: 316 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.NGEK20 | 2021-06-18 08:57:57.766
Mapping F.US.NGEK20 to NGK20. Service code: nymex | 2021-06-18 08:57:57.766
SC Data - All Services | Starting real-time market data updates for: F.US.NGEK20 (NGK20). ID: 317 Service code: nymex | 2021-06-18 08:57:57.766
CQG WebAPI | Sending symbol resolution request for F.US.NGEK20. ID: 75168 | 2021-06-18 08:57:57.766
SC Data - All Services | Requesting security definition data for: F.US.NGEK20 (NGK20). ID: 317 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.ZSEK20 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.SF6H20 | 2021-06-18 08:57:57.766
Mapping F.US.SF6H20 to 6SH20. Service code: cme | 2021-06-18 08:57:57.766
SC Data - All Services | Starting real-time market data updates for: F.US.SF6H20 (6SH20). ID: 318 Service code: cme | 2021-06-18 08:57:57.766
CQG WebAPI | Sending symbol resolution request for F.US.SF6H20. ID: 75169 | 2021-06-18 08:57:57.766
SC Data - All Services | Requesting security definition data for: F.US.SF6H20 (6SH20). ID: 318 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.ZLEH20 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.RBEJ20 | 2021-06-18 08:57:57.766
Mapping F.US.RBEJ20 to RBJ20. Service code: nymex | 2021-06-18 08:57:57.766
SC Data - All Services | Starting real-time market data updates for: F.US.RBEJ20 (RBJ20). ID: 319 Service code: nymex | 2021-06-18 08:57:57.766
CQG WebAPI | Sending symbol resolution request for F.US.RBEJ20. ID: 75170 | 2021-06-18 08:57:57.766
SC Data - All Services | Requesting security definition data for: F.US.RBEJ20 (RBJ20). ID: 319 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.SIEH20 | 2021-06-18 08:57:57.766
Subscribing to symbol for symbol alert. F.US.BP6H20 | 2021-06-18 08:57:57.766
Mapping F.US.BP6H20 to 6BH20. Service code: cme | 2021-06-18 08:57:57.766
SC Data - All Services | Starting real-time market data updates for: F.US.BP6H20 (6BH20). ID: 320 Service code: cme | 2021-06-18 08:57:57.766
CQG WebAPI | Sending symbol resolution request for F.US.BP6H20. ID: 75171 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.BP6H20 (6BH20). ID: 320 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.SF6H20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.TYAH20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.USAH20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.EU6H20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.DSXH20 | 2021-06-18 08:57:57.767
Mapping F.US.DSXH20 to FESX202003_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.DSXH20 (FESX202003_FUT_EUREX). ID: 321 Service code: eurex | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.DSXH20. ID: 75172 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.DSXH20 (FESX202003_FUT_EUREX). ID: 321 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.NGEF20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.SIEK20 | 2021-06-18 08:57:57.767
Mapping F.US.SIEK20 to SIK20. Service code: comex | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.SIEK20 (SIK20). ID: 322 Service code: comex | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.SIEK20. ID: 75173 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.SIEK20 (SIK20). ID: 322 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.ZLEH20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.ZCEH20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.ZSEN20 | 2021-06-18 08:57:57.767
Mapping F.US.ZSEN20 to ZSN20. Service code: cbot | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEN20 (ZSN20). ID: 323 Service code: cbot | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.ZSEN20. ID: 75174 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.ZSEN20 (ZSN20). ID: 323 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.NE6H20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.HOEG20 | 2021-06-18 08:57:57.767
Mapping F.US.HOEG20 to HOG20. Service code: nymex | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.HOEG20 (HOG20). ID: 324 Service code: nymex | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.HOEG20. ID: 75175 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.HOEG20 (HOG20). ID: 324 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.GFQ20 | 2021-06-18 08:57:57.767
Mapping F.US.GFQ20 to GFQ20. Service code: cme | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.GFQ20 (GFQ20). ID: 325 Service code: cme | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.GFQ20. ID: 75176 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.GFQ20 (GFQ20). ID: 325 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.CPEH20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.DA6H20 | 2021-06-18 08:57:57.767
Mapping F.US.DA6H20 to 6AH20. Service code: cme | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.DA6H20 (6AH20). ID: 326 Service code: cme | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.DA6H20. ID: 75177 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.DA6H20 (6AH20). ID: 326 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.ZWAK20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.GCEJ20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.PLEJ20 | 2021-06-18 08:57:57.767
Mapping F.US.PLEJ20 to PLJ20. Service code: nymex | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.PLEJ20 (PLJ20). ID: 327 Service code: nymex | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.PLEJ20. ID: 75178 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.PLEJ20 (PLJ20). ID: 327 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.EU6M20 | 2021-06-18 08:57:57.767
Mapping F.US.EU6M20 to 6EM20. Service code: cme | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.EU6M20 (6EM20). ID: 328 Service code: cme | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.EU6M20. ID: 75179 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.EU6M20 (6EM20). ID: 328 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.KWEK20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.NGEG20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.CA6H20 | 2021-06-18 08:57:57.767
Mapping F.US.CA6H20 to 6CH20. Service code: cme | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.CA6H20 (6CH20). ID: 329 Service code: cme | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.CA6H20. ID: 75180 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.CA6H20 (6CH20). ID: 329 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.GCEG20 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.NGEJ20 | 2021-06-18 08:57:57.767
Mapping F.US.NGEJ20 to NGJ20. Service code: nymex | 2021-06-18 08:57:57.767
SC Data - All Services | Starting real-time market data updates for: F.US.NGEJ20 (NGJ20). ID: 330 Service code: nymex | 2021-06-18 08:57:57.767
CQG WebAPI | Sending symbol resolution request for F.US.NGEJ20. ID: 75181 | 2021-06-18 08:57:57.767
SC Data - All Services | Requesting security definition data for: F.US.NGEJ20 (NGJ20). ID: 330 | 2021-06-18 08:57:57.767
Subscribing to symbol for symbol alert. F.US.ZWAK20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.TYAH20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.PLEN20 | 2021-06-18 08:57:57.768
Mapping F.US.PLEN20 to PLN20. Service code: nymex | 2021-06-18 08:57:57.768
SC Data - All Services | Starting real-time market data updates for: F.US.PLEN20 (PLN20). ID: 331 Service code: nymex | 2021-06-18 08:57:57.768
CQG WebAPI | Sending symbol resolution request for F.US.PLEN20. ID: 75182 | 2021-06-18 08:57:57.768
SC Data - All Services | Requesting security definition data for: F.US.PLEN20 (PLN20). ID: 331 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.USAH20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.CLEK20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.TNAH20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.KWEK20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.CA6H20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.YMH20 | 2021-06-18 08:57:57.768
Mapping F.US.YMH20 to YMH20. Service code: cbot | 2021-06-18 08:57:57.768
SC Data - All Services | Starting real-time market data updates for: F.US.YMH20 (YMH20). ID: 332 Service code: cbot | 2021-06-18 08:57:57.768
CQG WebAPI | Sending symbol resolution request for F.US.YMH20. ID: 75183 | 2021-06-18 08:57:57.768
SC Data - All Services | Requesting security definition data for: F.US.YMH20 (YMH20). ID: 332 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.NE6H20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.JY6H20 | 2021-06-18 08:57:57.768
Mapping F.US.JY6H20 to 6JH20. Service code: cme | 2021-06-18 08:57:57.768
SC Data - All Services | Starting real-time market data updates for: F.US.JY6H20 (6JH20). ID: 333 Service code: cme | 2021-06-18 08:57:57.768
CQG WebAPI | Sending symbol resolution request for F.US.JY6H20. ID: 75184 | 2021-06-18 08:57:57.768
SC Data - All Services | Requesting security definition data for: F.US.JY6H20 (6JH20). ID: 333 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.GFU20 | 2021-06-18 08:57:57.768
Mapping F.US.GFU20 to GFU20. Service code: cme | 2021-06-18 08:57:57.768
SC Data - All Services | Starting real-time market data updates for: F.US.GFU20 (GFU20). ID: 334 Service code: cme | 2021-06-18 08:57:57.768
CQG WebAPI | Sending symbol resolution request for F.US.GFU20. ID: 75185 | 2021-06-18 08:57:57.768
SC Data - All Services | Requesting security definition data for: F.US.GFU20 (GFU20). ID: 334 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.BP6H20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.PLEJ20 | 2021-06-18 08:57:57.768
Subscribing to symbol for symbol alert. F.US.TYAH20 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.USAH20 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.ZSEK20 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.SF6H20 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.CPEK20 | 2021-06-18 08:57:57.769
Mapping F.US.CPEK20 to HGK20. Service code: comex | 2021-06-18 08:57:57.769
SC Data - All Services | Starting real-time market data updates for: F.US.CPEK20 (HGK20). ID: 335 Service code: comex | 2021-06-18 08:57:57.769
CQG WebAPI | Sending symbol resolution request for F.US.CPEK20. ID: 75186 | 2021-06-18 08:57:57.769
SC Data - All Services | Requesting security definition data for: F.US.CPEK20 (HGK20). ID: 335 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.CPEH20 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.ZCEH20 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.PAEH20 | 2021-06-18 08:57:57.769
Mapping F.US.PAEH20 to PAH20. Service code: nymex | 2021-06-18 08:57:57.769
SC Data - All Services | Starting real-time market data updates for: F.US.PAEH20 (PAH20). ID: 336 Service code: nymex | 2021-06-18 08:57:57.769
CQG WebAPI | Sending symbol resolution request for F.US.PAEH20. ID: 75187 | 2021-06-18 08:57:57.769
SC Data - All Services | Requesting security definition data for: F.US.PAEH20 (PAH20). ID: 336 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.ZCEK20 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.ZWAN20 | 2021-06-18 08:57:57.769
Mapping F.US.ZWAN20 to ZWN20. Service code: cbot | 2021-06-18 08:57:57.769
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAN20 (ZWN20). ID: 337 Service code: cbot | 2021-06-18 08:57:57.769
CQG WebAPI | Sending symbol resolution request for F.US.ZWAN20. ID: 75188 | 2021-06-18 08:57:57.769
SC Data - All Services | Requesting security definition data for: F.US.ZWAN20 (ZWN20). ID: 337 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.KWEH20 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.ZWAZ20 | 2021-06-18 08:57:57.769
Mapping F.US.ZWAZ20 to ZWZ20. Service code: cbot | 2021-06-18 08:57:57.769
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAZ20 (ZWZ20). ID: 338 Service code: cbot | 2021-06-18 08:57:57.769
CQG WebAPI | Sending symbol resolution request for F.US.ZWAZ20. ID: 75189 | 2021-06-18 08:57:57.769
SC Data - All Services | Requesting security definition data for: F.US.ZWAZ20 (ZWZ20). ID: 338 | 2021-06-18 08:57:57.769
Subscribing to symbol for symbol alert. F.US.TYAH20 | 2021-06-18 08:57:57.770
Subscribing to symbol for symbol alert. F.US.DLH20 | 2021-06-18 08:57:57.770
Mapping F.US.DLH20 to FGBM202003_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.770
SC Data - All Services | Starting real-time market data updates for: F.US.DLH20 (FGBM202003_FUT_EUREX). ID: 339 Service code: eurex | 2021-06-18 08:57:57.770
CQG WebAPI | Sending symbol resolution request for F.US.DLH20. ID: 75190 | 2021-06-18 08:57:57.770
SC Data - All Services | Requesting security definition data for: F.US.DLH20 (FGBM202003_FUT_EUREX). ID: 339 | 2021-06-18 08:57:57.770
Subscribing to symbol for symbol alert. F.US.ZMEH20 | 2021-06-18 08:57:57.770
Subscribing to symbol for symbol alert. F.US.ZCEK20 | 2021-06-18 08:57:57.770
Subscribing to symbol for symbol alert. F.US.USAH20 | 2021-06-18 08:57:57.770
Subscribing to symbol for symbol alert. F.US.SIEK20 | 2021-06-18 08:57:57.770
Subscribing to symbol for symbol alert. F.US.DBH20 | 2021-06-18 08:57:57.770
Mapping F.US.DBH20 to FGBL202003_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.770
SC Data - All Services | Starting real-time market data updates for: F.US.DBH20 (FGBL202003_FUT_EUREX). ID: 340 Service code: eurex | 2021-06-18 08:57:57.770
CQG WebAPI | Sending symbol resolution request for F.US.DBH20. ID: 75191 | 2021-06-18 08:57:57.770
SC Data - All Services | Requesting security definition data for: F.US.DBH20 (FGBL202003_FUT_EUREX). ID: 340 | 2021-06-18 08:57:57.770
Subscribing to symbol for symbol alert. F.US.CPEK20 | 2021-06-18 08:57:57.770
Subscribing to symbol for symbol alert. F.US.KWEK20 | 2021-06-18 08:57:57.770
Subscribing to symbol for symbol alert. F.US.TYAH20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.KWEH20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.GFJ20 | 2021-06-18 08:57:57.771
Mapping F.US.GFJ20 to GFJ20. Service code: cme | 2021-06-18 08:57:57.771
SC Data - All Services | Starting real-time market data updates for: F.US.GFJ20 (GFJ20). ID: 341 Service code: cme | 2021-06-18 08:57:57.771
CQG WebAPI | Sending symbol resolution request for F.US.GFJ20. ID: 75192 | 2021-06-18 08:57:57.771
SC Data - All Services | Requesting security definition data for: F.US.GFJ20 (GFJ20). ID: 341 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.ZCEK20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.EU6H20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.NGEM20 | 2021-06-18 08:57:57.771
Mapping F.US.NGEM20 to NGM20. Service code: nymex | 2021-06-18 08:57:57.771
SC Data - All Services | Starting real-time market data updates for: F.US.NGEM20 (NGM20). ID: 342 Service code: nymex | 2021-06-18 08:57:57.771
CQG WebAPI | Sending symbol resolution request for F.US.NGEM20. ID: 75193 | 2021-06-18 08:57:57.771
SC Data - All Services | Requesting security definition data for: F.US.NGEM20 (NGM20). ID: 342 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.ZSEH20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.NE6H20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.DBH20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.TNAH20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.ZWAH20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.BP6H20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.ZLEN20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.ZLEZ20 | 2021-06-18 08:57:57.771
Mapping F.US.ZLEZ20 to ZLZ20. Service code: cbot | 2021-06-18 08:57:57.771
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEZ20 (ZLZ20). ID: 343 Service code: cbot | 2021-06-18 08:57:57.771
CQG WebAPI | Sending symbol resolution request for F.US.ZLEZ20. ID: 75194 | 2021-06-18 08:57:57.771
SC Data - All Services | Requesting security definition data for: F.US.ZLEZ20 (ZLZ20). ID: 343 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.NGEN20 | 2021-06-18 08:57:57.771
Mapping F.US.NGEN20 to NGN20. Service code: nymex | 2021-06-18 08:57:57.771
SC Data - All Services | Starting real-time market data updates for: F.US.NGEN20 (NGN20). ID: 344 Service code: nymex | 2021-06-18 08:57:57.771
CQG WebAPI | Sending symbol resolution request for F.US.NGEN20. ID: 75195 | 2021-06-18 08:57:57.771
SC Data - All Services | Requesting security definition data for: F.US.NGEN20 (NGN20). ID: 344 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.GLEJ20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.NGEJ20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.ZSEK20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.CPEK20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.SIEK20 | 2021-06-18 08:57:57.771
Subscribing to symbol for symbol alert. F.US.TYAH20 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.DA6H20 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.DBH20 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.ZSEN20 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.NGEM20 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.ZWAN20 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.NGEK20 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.TYAM20 | 2021-06-18 08:57:57.772
Mapping F.US.TYAM20 to ZNM20. Service code: cbot | 2021-06-18 08:57:57.772
SC Data - All Services | Starting real-time market data updates for: F.US.TYAM20 (ZNM20). ID: 345 Service code: cbot | 2021-06-18 08:57:57.772
CQG WebAPI | Sending symbol resolution request for F.US.TYAM20. ID: 75196 | 2021-06-18 08:57:57.772
SC Data - All Services | Requesting security definition data for: F.US.TYAM20 (ZNM20). ID: 345 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.USAM20 | 2021-06-18 08:57:57.772
Mapping F.US.USAM20 to ZBM20. Service code: cbot | 2021-06-18 08:57:57.772
SC Data - All Services | Starting real-time market data updates for: F.US.USAM20 (ZBM20). ID: 346 Service code: cbot | 2021-06-18 08:57:57.772
CQG WebAPI | Sending symbol resolution request for F.US.USAM20. ID: 75197 | 2021-06-18 08:57:57.772
SC Data - All Services | Requesting security definition data for: F.US.USAM20 (ZBM20). ID: 346 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.EU6M20 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.SF6H20 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.DLM20 | 2021-06-18 08:57:57.772
Mapping F.US.DLM20 to FGBM202006_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.772
SC Data - All Services | Starting real-time market data updates for: F.US.DLM20 (FGBM202006_FUT_EUREX). ID: 347 Service code: eurex | 2021-06-18 08:57:57.772
CQG WebAPI | Sending symbol resolution request for F.US.DLM20. ID: 75198 | 2021-06-18 08:57:57.772
SC Data - All Services | Requesting security definition data for: F.US.DLM20 (FGBM202006_FUT_EUREX). ID: 347 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.KWEU20 | 2021-06-18 08:57:57.772
Mapping F.US.KWEU20 to KEU20. Service code: cbot | 2021-06-18 08:57:57.772
SC Data - All Services | Starting real-time market data updates for: F.US.KWEU20 (KEU20). ID: 348 Service code: cbot | 2021-06-18 08:57:57.772
CQG WebAPI | Sending symbol resolution request for F.US.KWEU20. ID: 75199 | 2021-06-18 08:57:57.772
SC Data - All Services | Requesting security definition data for: F.US.KWEU20 (KEU20). ID: 348 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.FVAM20 | 2021-06-18 08:57:57.772
Mapping F.US.FVAM20 to ZFM20. Service code: cbot | 2021-06-18 08:57:57.772
SC Data - All Services | Starting real-time market data updates for: F.US.FVAM20 (ZFM20). ID: 349 Service code: cbot | 2021-06-18 08:57:57.772
CQG WebAPI | Sending symbol resolution request for F.US.FVAM20. ID: 75200 | 2021-06-18 08:57:57.772
SC Data - All Services | Requesting security definition data for: F.US.FVAM20 (ZFM20). ID: 349 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.KWEN20 | 2021-06-18 08:57:57.772
Mapping F.US.KWEN20 to KEN20. Service code: cbot | 2021-06-18 08:57:57.772
SC Data - All Services | Starting real-time market data updates for: F.US.KWEN20 (KEN20). ID: 350 Service code: cbot | 2021-06-18 08:57:57.772
CQG WebAPI | Sending symbol resolution request for F.US.KWEN20. ID: 75201 | 2021-06-18 08:57:57.772
SC Data - All Services | Requesting security definition data for: F.US.KWEN20 (KEN20). ID: 350 | 2021-06-18 08:57:57.772
Subscribing to symbol for symbol alert. F.US.SIEN20 | 2021-06-18 08:57:57.772
Mapping F.US.SIEN20 to SIN20. Service code: comex | 2021-06-18 08:57:57.772
SC Data - All Services | Starting real-time market data updates for: F.US.SIEN20 (SIN20). ID: 351 Service code: comex | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.SIEN20. ID: 75202 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.SIEN20 (SIN20). ID: 351 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.CPEN20 | 2021-06-18 08:57:57.773
Mapping F.US.CPEN20 to HGN20. Service code: comex | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.CPEN20 (HGN20). ID: 352 Service code: comex | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.CPEN20. ID: 75203 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.CPEN20 (HGN20). ID: 352 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.PLEJ20 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.TYAM20 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.PLEN20 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.DA6M20 | 2021-06-18 08:57:57.773
Mapping F.US.DA6M20 to 6AM20. Service code: cme | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.DA6M20 (6AM20). ID: 353 Service code: cme | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.DA6M20. ID: 75204 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.DA6M20 (6AM20). ID: 353 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.KWEZ20 | 2021-06-18 08:57:57.773
Mapping F.US.KWEZ20 to KEZ20. Service code: cbot | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.KWEZ20 (KEZ20). ID: 354 Service code: cbot | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.KWEZ20. ID: 75205 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.KWEZ20 (KEZ20). ID: 354 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.DLM20 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.BP6M20 | 2021-06-18 08:57:57.773
Mapping F.US.BP6M20 to 6BM20. Service code: cme | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.BP6M20 (6BM20). ID: 355 Service code: cme | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.BP6M20. ID: 75206 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.BP6M20 (6BM20). ID: 355 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.CA6M20 | 2021-06-18 08:57:57.773
Mapping F.US.CA6M20 to 6CM20. Service code: cme | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.CA6M20 (6CM20). ID: 356 Service code: cme | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.CA6M20. ID: 75207 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.CA6M20 (6CM20). ID: 356 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.SF6M20 | 2021-06-18 08:57:57.773
Mapping F.US.SF6M20 to 6SM20. Service code: cme | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.SF6M20 (6SM20). ID: 357 Service code: cme | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.SF6M20. ID: 75208 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.SF6M20 (6SM20). ID: 357 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.JY6M20 | 2021-06-18 08:57:57.773
Mapping F.US.JY6M20 to 6JM20. Service code: cme | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.JY6M20 (6JM20). ID: 358 Service code: cme | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.JY6M20. ID: 75209 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.JY6M20 (6JM20). ID: 358 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.USAM20 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.KWEU20 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.ZWAK20 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.ZMEU20 | 2021-06-18 08:57:57.773
Mapping F.US.ZMEU20 to ZMU20. Service code: cbot | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEU20 (ZMU20). ID: 359 Service code: cbot | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.ZMEU20. ID: 75210 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.ZMEU20 (ZMU20). ID: 359 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.ZMEN20 | 2021-06-18 08:57:57.773
Mapping F.US.ZMEN20 to ZMN20. Service code: cbot | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEN20 (ZMN20). ID: 360 Service code: cbot | 2021-06-18 08:57:57.773
CQG WebAPI | Sending symbol resolution request for F.US.ZMEN20. ID: 75211 | 2021-06-18 08:57:57.773
SC Data - All Services | Requesting security definition data for: F.US.ZMEN20 (ZMN20). ID: 360 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.ZLEN20 | 2021-06-18 08:57:57.773
Subscribing to symbol for symbol alert. F.US.NE6M20 | 2021-06-18 08:57:57.773
Mapping F.US.NE6M20 to 6NM20. Service code: cme | 2021-06-18 08:57:57.773
SC Data - All Services | Starting real-time market data updates for: F.US.NE6M20 (6NM20). ID: 361 Service code: cme | 2021-06-18 08:57:57.774
CQG WebAPI | Sending symbol resolution request for F.US.NE6M20. ID: 75212 | 2021-06-18 08:57:57.774
SC Data - All Services | Requesting security definition data for: F.US.NE6M20 (6NM20). ID: 361 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.CA6M20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.SF6M20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.TYAM20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.DSXM20 | 2021-06-18 08:57:57.774
Mapping F.US.DSXM20 to FESX202006_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.774
SC Data - All Services | Starting real-time market data updates for: F.US.DSXM20 (FESX202006_FUT_EUREX). ID: 362 Service code: eurex | 2021-06-18 08:57:57.774
CQG WebAPI | Sending symbol resolution request for F.US.DSXM20. ID: 75213 | 2021-06-18 08:57:57.774
SC Data - All Services | Requesting security definition data for: F.US.DSXM20 (FESX202006_FUT_EUREX). ID: 362 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.ZMEN20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.PLEN20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.FBTSM20 | 2021-06-18 08:57:57.774
Mapping F.US.FBTSM20 to FBTS202006_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.774
SC Data - All Services | Starting real-time market data updates for: F.US.FBTSM20 (FBTS202006_FUT_EUREX). ID: 363 Service code: eurex | 2021-06-18 08:57:57.774
CQG WebAPI | Sending symbol resolution request for F.US.FBTSM20. ID: 75214 | 2021-06-18 08:57:57.774
SC Data - All Services | Requesting security definition data for: F.US.FBTSM20 (FBTS202006_FUT_EUREX). ID: 363 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.ZCEN20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.EU6M20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.NE6M20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.DLM20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.HEQ20 | 2021-06-18 08:57:57.774
Mapping F.US.HEQ20 to HEQ20. Service code: cme | 2021-06-18 08:57:57.774
SC Data - All Services | Starting real-time market data updates for: F.US.HEQ20 (HEQ20). ID: 364 Service code: cme | 2021-06-18 08:57:57.774
CQG WebAPI | Sending symbol resolution request for F.US.HEQ20. ID: 75215 | 2021-06-18 08:57:57.774
SC Data - All Services | Requesting security definition data for: F.US.HEQ20 (HEQ20). ID: 364 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.ZWAN20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.ZWAZ20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.ZSEK20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.USAM20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.TNAM20 | 2021-06-18 08:57:57.774
Mapping F.US.TNAM20 to TNM20. Service code: cbot | 2021-06-18 08:57:57.774
SC Data - All Services | Starting real-time market data updates for: F.US.TNAM20 (TNM20). ID: 365 Service code: cbot | 2021-06-18 08:57:57.774
CQG WebAPI | Sending symbol resolution request for F.US.TNAM20. ID: 75216 | 2021-06-18 08:57:57.774
SC Data - All Services | Requesting security definition data for: F.US.TNAM20 (TNM20). ID: 365 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.NGEM20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.ZSEN20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.BP6M20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.DBM20 | 2021-06-18 08:57:57.774
Mapping F.US.DBM20 to FGBL202006_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.774
SC Data - All Services | Starting real-time market data updates for: F.US.DBM20 (FGBL202006_FUT_EUREX). ID: 366 Service code: eurex | 2021-06-18 08:57:57.774
CQG WebAPI | Sending symbol resolution request for F.US.DBM20. ID: 75217 | 2021-06-18 08:57:57.774
SC Data - All Services | Requesting security definition data for: F.US.DBM20 (FGBL202006_FUT_EUREX). ID: 366 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.KWEU20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.ZCEK20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.CPEK20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.ZLEK20 | 2021-06-18 08:57:57.774
Subscribing to symbol for symbol alert. F.US.ZCEK20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.SF6M20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.TYAM20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.ZMEN20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.CPEN20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.EU6M20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.DSXM20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.ZCEN20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.NGEN20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.CPEK20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.NE6M20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.ZSEK20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.HEV20 | 2021-06-18 08:57:57.775
Mapping F.US.HEV20 to HEV20. Service code: cme | 2021-06-18 08:57:57.775
SC Data - All Services | Starting real-time market data updates for: F.US.HEV20 (HEV20). ID: 367 Service code: cme | 2021-06-18 08:57:57.775
CQG WebAPI | Sending symbol resolution request for F.US.HEV20. ID: 75218 | 2021-06-18 08:57:57.775
SC Data - All Services | Requesting security definition data for: F.US.HEV20 (HEV20). ID: 367 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.SIEN20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.DDM20 | 2021-06-18 08:57:57.775
Mapping F.US.DDM20 to FDAX202006_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.775
SC Data - All Services | Starting real-time market data updates for: F.US.DDM20 (FDAX202006_FUT_EUREX). ID: 368 Service code: eurex | 2021-06-18 08:57:57.775
CQG WebAPI | Sending symbol resolution request for F.US.DDM20. ID: 75219 | 2021-06-18 08:57:57.775
SC Data - All Services | Requesting security definition data for: F.US.DDM20 (FDAX202006_FUT_EUREX). ID: 368 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.DBM20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.HEM20 | 2021-06-18 08:57:57.775
Mapping F.US.HEM20 to HEM20. Service code: cme | 2021-06-18 08:57:57.775
SC Data - All Services | Starting real-time market data updates for: F.US.HEM20 (HEM20). ID: 369 Service code: cme | 2021-06-18 08:57:57.775
CQG WebAPI | Sending symbol resolution request for F.US.HEM20. ID: 75220 | 2021-06-18 08:57:57.775
SC Data - All Services | Requesting security definition data for: F.US.HEM20 (HEM20). ID: 369 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.ZCEU20 | 2021-06-18 08:57:57.775
Mapping F.US.ZCEU20 to ZCU20. Service code: cbot | 2021-06-18 08:57:57.775
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEU20 (ZCU20). ID: 370 Service code: cbot | 2021-06-18 08:57:57.775
CQG WebAPI | Sending symbol resolution request for F.US.ZCEU20. ID: 75221 | 2021-06-18 08:57:57.775
SC Data - All Services | Requesting security definition data for: F.US.ZCEU20 (ZCU20). ID: 370 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.ZMEK20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.NGEK20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.ZSEN20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.FVAM20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.NGEM20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.KWEN20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.BP6M20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.ZLEN20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.FXXPM20 | 2021-06-18 08:57:57.775
Mapping F.US.FXXPM20 to FXXP202006_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.775
SC Data - All Services | Starting real-time market data updates for: F.US.FXXPM20 (FXXP202006_FUT_EUREX). ID: 371 Service code: eurex | 2021-06-18 08:57:57.775
CQG WebAPI | Sending symbol resolution request for F.US.FXXPM20. ID: 75222 | 2021-06-18 08:57:57.775
SC Data - All Services | Requesting security definition data for: F.US.FXXPM20 (FXXP202006_FUT_EUREX). ID: 371 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.TNAM20 | 2021-06-18 08:57:57.775
Subscribing to symbol for symbol alert. F.US.EU6M20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.TNAM20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.TYAM20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.ZLEN20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.SF6M20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.DLM20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.DBM20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.GLEM20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.ZCEN20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.CA6M20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.KWEN20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.PLEN20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.USAM20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.BP6M20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.ZMEQ20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.SIEN20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.ZWAN20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.ZWAU20 | 2021-06-18 08:57:57.776
Mapping F.US.ZWAU20 to ZWU20. Service code: cbot | 2021-06-18 08:57:57.776
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAU20 (ZWU20). ID: 372 Service code: cbot | 2021-06-18 08:57:57.776
CQG WebAPI | Sending symbol resolution request for F.US.ZWAU20. ID: 75223 | 2021-06-18 08:57:57.776
SC Data - All Services | Requesting security definition data for: F.US.ZWAU20 (ZWU20). ID: 372 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.NGEM20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.JY6M20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.FVAM20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.ZMEN20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.ZSEN20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.CPEN20 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.FGBXM20 | 2021-06-18 08:57:57.776
Mapping F.US.FGBXM20 to FGBX202006_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.776
SC Data - All Services | Starting real-time market data updates for: F.US.FGBXM20 (FGBX202006_FUT_EUREX). ID: 373 Service code: eurex | 2021-06-18 08:57:57.776
CQG WebAPI | Sending symbol resolution request for F.US.FGBXM20. ID: 75224 | 2021-06-18 08:57:57.776
SC Data - All Services | Requesting security definition data for: F.US.FGBXM20 (FGBX202006_FUT_EUREX). ID: 373 | 2021-06-18 08:57:57.776
Subscribing to symbol for symbol alert. F.US.ZLEN20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.TYAM20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.HEZ20 | 2021-06-18 08:57:57.777
Mapping F.US.HEZ20 to HEZ20. Service code: cme | 2021-06-18 08:57:57.777
SC Data - All Services | Starting real-time market data updates for: F.US.HEZ20 (HEZ20). ID: 374 Service code: cme | 2021-06-18 08:57:57.777
CQG WebAPI | Sending symbol resolution request for F.US.HEZ20. ID: 75225 | 2021-06-18 08:57:57.777
SC Data - All Services | Requesting security definition data for: F.US.HEZ20 (HEZ20). ID: 374 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.NE6M20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.TNAM20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.FVAM20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.KWEN20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.ZWAN20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.BP6M20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.DLM20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.FGBXM20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.PLEN20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.USAM20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.ULAM20 | 2021-06-18 08:57:57.777
Mapping F.US.ULAM20 to UBM20. Service code: cbot | 2021-06-18 08:57:57.777
SC Data - All Services | Starting real-time market data updates for: F.US.ULAM20 (UBM20). ID: 375 Service code: cbot | 2021-06-18 08:57:57.777
CQG WebAPI | Sending symbol resolution request for F.US.ULAM20. ID: 75226 | 2021-06-18 08:57:57.777
SC Data - All Services | Requesting security definition data for: F.US.ULAM20 (UBM20). ID: 375 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.SF6M20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.FXXPM20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.CPEN20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.CA6M20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.DA6M20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.EU6M20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.ZMEN20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.ZWAU20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.DSXM20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.DBM20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.TYAU20 | 2021-06-18 08:57:57.777
Mapping F.US.TYAU20 to ZNU20. Service code: cbot | 2021-06-18 08:57:57.777
SC Data - All Services | Starting real-time market data updates for: F.US.TYAU20 (ZNU20). ID: 376 Service code: cbot | 2021-06-18 08:57:57.777
CQG WebAPI | Sending symbol resolution request for F.US.TYAU20. ID: 75227 | 2021-06-18 08:57:57.777
SC Data - All Services | Requesting security definition data for: F.US.TYAU20 (ZNU20). ID: 376 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.ZMEQ20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.ZCEN20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.SIEN20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.NGEU20 | 2021-06-18 08:57:57.777
Mapping F.US.NGEU20 to NGU20. Service code: nymex | 2021-06-18 08:57:57.777
SC Data - All Services | Starting real-time market data updates for: F.US.NGEU20 (NGU20). ID: 377 Service code: nymex | 2021-06-18 08:57:57.777
CQG WebAPI | Sending symbol resolution request for F.US.NGEU20. ID: 75228 | 2021-06-18 08:57:57.777
SC Data - All Services | Requesting security definition data for: F.US.NGEU20 (NGU20). ID: 377 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.NGEN20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.HEV20 | 2021-06-18 08:57:57.777
Subscribing to symbol for symbol alert. F.US.SF6U20 | 2021-06-18 08:57:57.777
Mapping F.US.SF6U20 to 6SU20. Service code: cme | 2021-06-18 08:57:57.777
SC Data - All Services | Starting real-time market data updates for: F.US.SF6U20 (6SU20). ID: 378 Service code: cme | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.SF6U20. ID: 75229 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.SF6U20 (6SU20). ID: 378 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.ZSEN20 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.TYAU20 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.NGEU20 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.HEV20 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.HEZ20 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.USAU20 | 2021-06-18 08:57:57.778
Mapping F.US.USAU20 to ZBU20. Service code: cbot | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.USAU20 (ZBU20). ID: 379 Service code: cbot | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.USAU20. ID: 75230 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.USAU20 (ZBU20). ID: 379 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.SIEU20 | 2021-06-18 08:57:57.778
Mapping F.US.SIEU20 to SIU20. Service code: comex | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.SIEU20 (SIU20). ID: 380 Service code: comex | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.SIEU20. ID: 75231 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.SIEU20 (SIU20). ID: 380 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.CPEU20 | 2021-06-18 08:57:57.778
Mapping F.US.CPEU20 to HGU20. Service code: comex | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.CPEU20 (HGU20). ID: 381 Service code: comex | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.CPEU20. ID: 75232 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.CPEU20 (HGU20). ID: 381 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.PLEV20 | 2021-06-18 08:57:57.778
Mapping F.US.PLEV20 to PLV20. Service code: nymex | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.PLEV20 (PLV20). ID: 382 Service code: nymex | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.PLEV20. ID: 75233 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.PLEV20 (PLV20). ID: 382 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.ZLEN20 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.CPEN20 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.RBEV20 | 2021-06-18 08:57:57.778
Mapping F.US.RBEV20 to RBV20. Service code: nymex | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.RBEV20 (RBV20). ID: 383 Service code: nymex | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.RBEV20. ID: 75234 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.RBEV20 (RBV20). ID: 383 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.RBEQ20 | 2021-06-18 08:57:57.778
Mapping F.US.RBEQ20 to RBQ20. Service code: nymex | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.RBEQ20 (RBQ20). ID: 384 Service code: nymex | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.RBEQ20. ID: 75235 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.RBEQ20 (RBQ20). ID: 384 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.DLU20 | 2021-06-18 08:57:57.778
Mapping F.US.DLU20 to FGBM202009_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.DLU20 (FGBM202009_FUT_EUREX). ID: 385 Service code: eurex | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.DLU20. ID: 75236 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.DLU20 (FGBM202009_FUT_EUREX). ID: 385 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.ZMEQ20 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.KWEU20 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.BP6U20 | 2021-06-18 08:57:57.778
Mapping F.US.BP6U20 to 6BU20. Service code: cme | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.BP6U20 (6BU20). ID: 386 Service code: cme | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.BP6U20. ID: 75237 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.BP6U20 (6BU20). ID: 386 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.CPEZ20 | 2021-06-18 08:57:57.778
Mapping F.US.CPEZ20 to HGZ20. Service code: comex | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.CPEZ20 (HGZ20). ID: 387 Service code: comex | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.CPEZ20. ID: 75238 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.CPEZ20 (HGZ20). ID: 387 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.DA6U20 | 2021-06-18 08:57:57.778
Mapping F.US.DA6U20 to 6AU20. Service code: cme | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.DA6U20 (6AU20). ID: 388 Service code: cme | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.DA6U20. ID: 75239 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.DA6U20 (6AU20). ID: 388 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.DBU20 | 2021-06-18 08:57:57.778
Mapping F.US.DBU20 to FGBL202009_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.DBU20 (FGBL202009_FUT_EUREX). ID: 389 Service code: eurex | 2021-06-18 08:57:57.778
CQG WebAPI | Sending symbol resolution request for F.US.DBU20. ID: 75240 | 2021-06-18 08:57:57.778
SC Data - All Services | Requesting security definition data for: F.US.DBU20 (FGBL202009_FUT_EUREX). ID: 389 | 2021-06-18 08:57:57.778
Subscribing to symbol for symbol alert. F.US.FVAU20 | 2021-06-18 08:57:57.778
Mapping F.US.FVAU20 to ZFU20. Service code: cbot | 2021-06-18 08:57:57.778
SC Data - All Services | Starting real-time market data updates for: F.US.FVAU20 (ZFU20). ID: 390 Service code: cbot | 2021-06-18 08:57:57.779
CQG WebAPI | Sending symbol resolution request for F.US.FVAU20. ID: 75241 | 2021-06-18 08:57:57.779
SC Data - All Services | Requesting security definition data for: F.US.FVAU20 (ZFU20). ID: 390 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.DBU20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.CA6U20 | 2021-06-18 08:57:57.779
Mapping F.US.CA6U20 to 6CU20. Service code: cme | 2021-06-18 08:57:57.779
SC Data - All Services | Starting real-time market data updates for: F.US.CA6U20 (6CU20). ID: 391 Service code: cme | 2021-06-18 08:57:57.779
CQG WebAPI | Sending symbol resolution request for F.US.CA6U20. ID: 75242 | 2021-06-18 08:57:57.779
SC Data - All Services | Requesting security definition data for: F.US.CA6U20 (6CU20). ID: 391 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.EU6U20 | 2021-06-18 08:57:57.779
Mapping F.US.EU6U20 to 6EU20. Service code: cme | 2021-06-18 08:57:57.779
SC Data - All Services | Starting real-time market data updates for: F.US.EU6U20 (6EU20). ID: 392 Service code: cme | 2021-06-18 08:57:57.779
CQG WebAPI | Sending symbol resolution request for F.US.EU6U20. ID: 75243 | 2021-06-18 08:57:57.779
SC Data - All Services | Requesting security definition data for: F.US.EU6U20 (6EU20). ID: 392 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.TYAU20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.USAU20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.CPEU20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.CPEZ20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.BP6U20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.HEV20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.ZSEX20 | 2021-06-18 08:57:57.779
Mapping F.US.ZSEX20 to ZSX20. Service code: cbot | 2021-06-18 08:57:57.779
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEX20 (ZSX20). ID: 393 Service code: cbot | 2021-06-18 08:57:57.779
CQG WebAPI | Sending symbol resolution request for F.US.ZSEX20. ID: 75244 | 2021-06-18 08:57:57.779
SC Data - All Services | Requesting security definition data for: F.US.ZSEX20 (ZSX20). ID: 393 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.FVAU20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.JY6U20 | 2021-06-18 08:57:57.779
Mapping F.US.JY6U20 to 6JU20. Service code: cme | 2021-06-18 08:57:57.779
SC Data - All Services | Starting real-time market data updates for: F.US.JY6U20 (6JU20). ID: 394 Service code: cme | 2021-06-18 08:57:57.779
CQG WebAPI | Sending symbol resolution request for F.US.JY6U20. ID: 75245 | 2021-06-18 08:57:57.779
SC Data - All Services | Requesting security definition data for: F.US.JY6U20 (6JU20). ID: 394 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.SF6U20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.ZMEQ20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.DSXU20 | 2021-06-18 08:57:57.779
Mapping F.US.DSXU20 to FESX202009_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.779
SC Data - All Services | Starting real-time market data updates for: F.US.DSXU20 (FESX202009_FUT_EUREX). ID: 395 Service code: eurex | 2021-06-18 08:57:57.779
CQG WebAPI | Sending symbol resolution request for F.US.DSXU20. ID: 75246 | 2021-06-18 08:57:57.779
SC Data - All Services | Requesting security definition data for: F.US.DSXU20 (FESX202009_FUT_EUREX). ID: 395 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.ZSEQ20 | 2021-06-18 08:57:57.779
Mapping F.US.ZSEQ20 to ZSQ20. Service code: cbot | 2021-06-18 08:57:57.779
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEQ20 (ZSQ20). ID: 396 Service code: cbot | 2021-06-18 08:57:57.779
CQG WebAPI | Sending symbol resolution request for F.US.ZSEQ20. ID: 75247 | 2021-06-18 08:57:57.779
SC Data - All Services | Requesting security definition data for: F.US.ZSEQ20 (ZSQ20). ID: 396 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.PLEV20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.RBEV20 | 2021-06-18 08:57:57.779
Subscribing to symbol for symbol alert. F.US.NE6U20 | 2021-06-18 08:57:57.779
Mapping F.US.NE6U20 to 6NU20. Service code: cme | 2021-06-18 08:57:57.779
SC Data - All Services | Starting real-time market data updates for: F.US.NE6U20 (6NU20). ID: 397 Service code: cme | 2021-06-18 08:57:57.779
CQG WebAPI | Sending symbol resolution request for F.US.NE6U20. ID: 75248 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.NE6U20 (6NU20). ID: 397 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.NE6U20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.ZMEF21 | 2021-06-18 08:57:57.780
Mapping F.US.ZMEF21 to ZMF21. Service code: cbot | 2021-06-18 08:57:57.780
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEF21 (ZMF21). ID: 398 Service code: cbot | 2021-06-18 08:57:57.780
CQG WebAPI | Sending symbol resolution request for F.US.ZMEF21. ID: 75249 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.ZMEF21 (ZMF21). ID: 398 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.TYAU20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.USAU20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.RBEV20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.NGEQ20 | 2021-06-18 08:57:57.780
Mapping F.US.NGEQ20 to NGQ20. Service code: nymex | 2021-06-18 08:57:57.780
SC Data - All Services | Starting real-time market data updates for: F.US.NGEQ20 (NGQ20). ID: 399 Service code: nymex | 2021-06-18 08:57:57.780
CQG WebAPI | Sending symbol resolution request for F.US.NGEQ20. ID: 75250 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.NGEQ20 (NGQ20). ID: 399 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.CPEU20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.SF6U20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.DSXU20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.TUAU20 | 2021-06-18 08:57:57.780
Mapping F.US.TUAU20 to ZTU20. Service code: cbot | 2021-06-18 08:57:57.780
SC Data - All Services | Starting real-time market data updates for: F.US.TUAU20 (ZTU20). ID: 400 Service code: cbot | 2021-06-18 08:57:57.780
CQG WebAPI | Sending symbol resolution request for F.US.TUAU20. ID: 75251 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.TUAU20 (ZTU20). ID: 400 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.FVAU20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.FOATU20 | 2021-06-18 08:57:57.780
Mapping F.US.FOATU20 to FOAT202009_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.780
SC Data - All Services | Starting real-time market data updates for: F.US.FOATU20 (FOAT202009_FUT_EUREX). ID: 401 Service code: eurex | 2021-06-18 08:57:57.780
CQG WebAPI | Sending symbol resolution request for F.US.FOATU20. ID: 75252 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.FOATU20 (FOAT202009_FUT_EUREX). ID: 401 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.GLEV20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.SIEU20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.DBU20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.PLEV20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.EU6U20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.ZLEU20 | 2021-06-18 08:57:57.780
Mapping F.US.ZLEU20 to ZLU20. Service code: cbot | 2021-06-18 08:57:57.780
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEU20 (ZLU20). ID: 402 Service code: cbot | 2021-06-18 08:57:57.780
CQG WebAPI | Sending symbol resolution request for F.US.ZLEU20. ID: 75253 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.ZLEU20 (ZLU20). ID: 402 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.ZMEV20 | 2021-06-18 08:57:57.780
Mapping F.US.ZMEV20 to ZMV20. Service code: cbot | 2021-06-18 08:57:57.780
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEV20 (ZMV20). ID: 403 Service code: cbot | 2021-06-18 08:57:57.780
CQG WebAPI | Sending symbol resolution request for F.US.ZMEV20. ID: 75254 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.ZMEV20 (ZMV20). ID: 403 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.KWEU20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.NGEU20 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.ZLEH21 | 2021-06-18 08:57:57.780
Mapping F.US.ZLEH21 to ZLH21. Service code: cbot | 2021-06-18 08:57:57.780
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEH21 (ZLH21). ID: 404 Service code: cbot | 2021-06-18 08:57:57.780
CQG WebAPI | Sending symbol resolution request for F.US.ZLEH21. ID: 75255 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.ZLEH21 (ZLH21). ID: 404 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.RBEU20 | 2021-06-18 08:57:57.780
Mapping F.US.RBEU20 to RBU20. Service code: nymex | 2021-06-18 08:57:57.780
SC Data - All Services | Starting real-time market data updates for: F.US.RBEU20 (RBU20). ID: 405 Service code: nymex | 2021-06-18 08:57:57.780
CQG WebAPI | Sending symbol resolution request for F.US.RBEU20. ID: 75256 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.RBEU20 (RBU20). ID: 405 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.EPU20 | 2021-06-18 08:57:57.780
Mapping F.US.EPU20 to ESU20. Service code: cme | 2021-06-18 08:57:57.780
SC Data - All Services | Starting real-time market data updates for: F.US.EPU20 (ESU20). ID: 406 Service code: cme | 2021-06-18 08:57:57.780
CQG WebAPI | Sending symbol resolution request for F.US.EPU20. ID: 75257 | 2021-06-18 08:57:57.780
SC Data - All Services | Requesting security definition data for: F.US.EPU20 (ESU20). ID: 406 | 2021-06-18 08:57:57.780
Subscribing to symbol for symbol alert. F.US.NGEV20 | 2021-06-18 08:57:57.780
Mapping F.US.NGEV20 to NGV20. Service code: nymex | 2021-06-18 08:57:57.781
SC Data - All Services | Starting real-time market data updates for: F.US.NGEV20 (NGV20). ID: 407 Service code: nymex | 2021-06-18 08:57:57.781
CQG WebAPI | Sending symbol resolution request for F.US.NGEV20. ID: 75258 | 2021-06-18 08:57:57.781
SC Data - All Services | Requesting security definition data for: F.US.NGEV20 (NGV20). ID: 407 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.ZLEH21 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.TYAU20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.USAU20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.DSXU20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.NE6U20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.FVAU20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.GFU20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.DBU20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.ZSEX20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.PLEV20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.JY6U20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.DA6U20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.DLU20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.TNAU20 | 2021-06-18 08:57:57.781
Mapping F.US.TNAU20 to TNU20. Service code: cbot | 2021-06-18 08:57:57.781
SC Data - All Services | Starting real-time market data updates for: F.US.TNAU20 (TNU20). ID: 408 Service code: cbot | 2021-06-18 08:57:57.781
CQG WebAPI | Sending symbol resolution request for F.US.TNAU20. ID: 75259 | 2021-06-18 08:57:57.781
SC Data - All Services | Requesting security definition data for: F.US.TNAU20 (TNU20). ID: 408 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.SF6U20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.RBEV20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.NGEX20 | 2021-06-18 08:57:57.781
Mapping F.US.NGEX20 to NGX20. Service code: nymex | 2021-06-18 08:57:57.781
SC Data - All Services | Starting real-time market data updates for: F.US.NGEX20 (NGX20). ID: 409 Service code: nymex | 2021-06-18 08:57:57.781
CQG WebAPI | Sending symbol resolution request for F.US.NGEX20. ID: 75260 | 2021-06-18 08:57:57.781
SC Data - All Services | Requesting security definition data for: F.US.NGEX20 (NGX20). ID: 409 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.ZLEV20 | 2021-06-18 08:57:57.781
Mapping F.US.ZLEV20 to ZLV20. Service code: cbot | 2021-06-18 08:57:57.781
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEV20 (ZLV20). ID: 410 Service code: cbot | 2021-06-18 08:57:57.781
CQG WebAPI | Sending symbol resolution request for F.US.ZLEV20. ID: 75261 | 2021-06-18 08:57:57.781
SC Data - All Services | Requesting security definition data for: F.US.ZLEV20 (ZLV20). ID: 410 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.ZCEN21 | 2021-06-18 08:57:57.781
Mapping F.US.ZCEN21 to ZCN21. Service code: cbot | 2021-06-18 08:57:57.781
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEN21 (ZCN21). ID: 411 Service code: cbot | 2021-06-18 08:57:57.781
CQG WebAPI | Sending symbol resolution request for F.US.ZCEN21. ID: 75262 | 2021-06-18 08:57:57.781
SC Data - All Services | Requesting security definition data for: F.US.ZCEN21 (ZCN21). ID: 411 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.ZMEV20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.ZSEU20 | 2021-06-18 08:57:57.781
Mapping F.US.ZSEU20 to ZSU20. Service code: cbot | 2021-06-18 08:57:57.781
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEU20 (ZSU20). ID: 412 Service code: cbot | 2021-06-18 08:57:57.781
CQG WebAPI | Sending symbol resolution request for F.US.ZSEU20. ID: 75263 | 2021-06-18 08:57:57.781
SC Data - All Services | Requesting security definition data for: F.US.ZSEU20 (ZSU20). ID: 412 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.ZLEU20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.EU6U20 | 2021-06-18 08:57:57.781
Subscribing to symbol for symbol alert. F.US.KWEK21 | 2021-06-18 08:57:57.782
Mapping F.US.KWEK21 to KEK21. Service code: cbot | 2021-06-18 08:57:57.782
SC Data - All Services | Starting real-time market data updates for: F.US.KWEK21 (KEK21). ID: 413 Service code: cbot | 2021-06-18 08:57:57.782
CQG WebAPI | Sending symbol resolution request for F.US.KWEK21. ID: 75264 | 2021-06-18 08:57:57.782
SC Data - All Services | Requesting security definition data for: F.US.KWEK21 (KEK21). ID: 413 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.DSXU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.NGEV20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.RBEU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.BP6U20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.ZLEU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.TYAU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.GFU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.SIEU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.ZWAU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.MGCZ20 | 2021-06-18 08:57:57.782
Mapping F.US.MGCZ20 to MGCZ20. Service code: comex | 2021-06-18 08:57:57.782
SC Data - All Services | Starting real-time market data updates for: F.US.MGCZ20 (MGCZ20). ID: 414 Service code: comex | 2021-06-18 08:57:57.782
CQG WebAPI | Sending symbol resolution request for F.US.MGCZ20. ID: 75265 | 2021-06-18 08:57:57.782
SC Data - All Services | Requesting security definition data for: F.US.MGCZ20 (MGCZ20). ID: 414 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.DBU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.DLU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.USAU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.NGEU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.ZMEV20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.SF6U20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.CA6U20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.ZSEU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.KWEZ20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.EPU20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.PLEV20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.ZWAZ20 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.ULAU20 | 2021-06-18 08:57:57.782
Mapping F.US.ULAU20 to UBU20. Service code: cbot | 2021-06-18 08:57:57.782
SC Data - All Services | Starting real-time market data updates for: F.US.ULAU20 (UBU20). ID: 415 Service code: cbot | 2021-06-18 08:57:57.782
CQG WebAPI | Sending symbol resolution request for F.US.ULAU20. ID: 75266 | 2021-06-18 08:57:57.782
SC Data - All Services | Requesting security definition data for: F.US.ULAU20 (UBU20). ID: 415 | 2021-06-18 08:57:57.782
Subscribing to symbol for symbol alert. F.US.TYAU20 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.DSXU20 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.CLEX20 | 2021-06-18 08:57:57.783
Mapping F.US.CLEX20 to CLX20. Service code: nymex | 2021-06-18 08:57:57.783
SC Data - All Services | Starting real-time market data updates for: F.US.CLEX20 (CLX20). ID: 416 Service code: nymex | 2021-06-18 08:57:57.783
CQG WebAPI | Sending symbol resolution request for F.US.CLEX20. ID: 75267 | 2021-06-18 08:57:57.783
SC Data - All Services | Requesting security definition data for: F.US.CLEX20 (CLX20). ID: 416 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.USAU20 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.CA6U20 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.ZLEV20 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.DBU20 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.HOEV20 | 2021-06-18 08:57:57.783
Mapping F.US.HOEV20 to HOV20. Service code: nymex | 2021-06-18 08:57:57.783
SC Data - All Services | Starting real-time market data updates for: F.US.HOEV20 (HOV20). ID: 417 Service code: nymex | 2021-06-18 08:57:57.783
CQG WebAPI | Sending symbol resolution request for F.US.HOEV20. ID: 75268 | 2021-06-18 08:57:57.783
SC Data - All Services | Requesting security definition data for: F.US.HOEV20 (HOV20). ID: 417 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.NGEV20 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-18 08:57:57.783
Mapping F.US.TYAZ20 to ZNZ20. Service code: cbot | 2021-06-18 08:57:57.783
SC Data - All Services | Starting real-time market data updates for: F.US.TYAZ20 (ZNZ20). ID: 418 Service code: cbot | 2021-06-18 08:57:57.783
CQG WebAPI | Sending symbol resolution request for F.US.TYAZ20. ID: 75269 | 2021-06-18 08:57:57.783
SC Data - All Services | Requesting security definition data for: F.US.TYAZ20 (ZNZ20). ID: 418 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.ZLEK21 | 2021-06-18 08:57:57.783
Mapping F.US.ZLEK21 to ZLK21. Service code: cbot | 2021-06-18 08:57:57.783
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEK21 (ZLK21). ID: 419 Service code: cbot | 2021-06-18 08:57:57.783
CQG WebAPI | Sending symbol resolution request for F.US.ZLEK21. ID: 75270 | 2021-06-18 08:57:57.783
SC Data - All Services | Requesting security definition data for: F.US.ZLEK21 (ZLK21). ID: 419 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.RBEV20 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.DBZ20 | 2021-06-18 08:57:57.783
Mapping F.US.DBZ20 to FGBL202012_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.783
SC Data - All Services | Starting real-time market data updates for: F.US.DBZ20 (FGBL202012_FUT_EUREX). ID: 420 Service code: eurex | 2021-06-18 08:57:57.783
CQG WebAPI | Sending symbol resolution request for F.US.DBZ20. ID: 75271 | 2021-06-18 08:57:57.783
SC Data - All Services | Requesting security definition data for: F.US.DBZ20 (FGBL202012_FUT_EUREX). ID: 420 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.NGEZ20 | 2021-06-18 08:57:57.783
Mapping F.US.NGEZ20 to NGZ20. Service code: nymex | 2021-06-18 08:57:57.783
SC Data - All Services | Starting real-time market data updates for: F.US.NGEZ20 (NGZ20). ID: 421 Service code: nymex | 2021-06-18 08:57:57.783
CQG WebAPI | Sending symbol resolution request for F.US.NGEZ20. ID: 75272 | 2021-06-18 08:57:57.783
SC Data - All Services | Requesting security definition data for: F.US.NGEZ20 (NGZ20). ID: 421 | 2021-06-18 08:57:57.783
Subscribing to symbol for symbol alert. F.US.GFF21 | 2021-06-18 08:57:57.783
Mapping F.US.GFF21 to GFF21. Service code: cme | 2021-06-18 08:57:57.783
SC Data - All Services | Starting real-time market data updates for: F.US.GFF21 (GFF21). ID: 422 Service code: cme | 2021-06-18 08:57:57.784
CQG WebAPI | Sending symbol resolution request for F.US.GFF21. ID: 75273 | 2021-06-18 08:57:57.784
SC Data - All Services | Requesting security definition data for: F.US.GFF21 (GFF21). ID: 422 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.GFF21 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.DSXU20 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.GFX20 | 2021-06-18 08:57:57.784
Mapping F.US.GFX20 to GFX20. Service code: cme | 2021-06-18 08:57:57.784
SC Data - All Services | Starting real-time market data updates for: F.US.GFX20 (GFX20). ID: 423 Service code: cme | 2021-06-18 08:57:57.784
CQG WebAPI | Sending symbol resolution request for F.US.GFX20. ID: 75274 | 2021-06-18 08:57:57.784
SC Data - All Services | Requesting security definition data for: F.US.GFX20 (GFX20). ID: 423 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.ZCEZ20 | 2021-06-18 08:57:57.784
Mapping F.US.ZCEZ20 to ZCZ20. Service code: cbot | 2021-06-18 08:57:57.784
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEZ20 (ZCZ20). ID: 424 Service code: cbot | 2021-06-18 08:57:57.784
CQG WebAPI | Sending symbol resolution request for F.US.ZCEZ20. ID: 75275 | 2021-06-18 08:57:57.784
SC Data - All Services | Requesting security definition data for: F.US.ZCEZ20 (ZCZ20). ID: 424 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.ZMEZ20 | 2021-06-18 08:57:57.784
Mapping F.US.ZMEZ20 to ZMZ20. Service code: cbot | 2021-06-18 08:57:57.784
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEZ20 (ZMZ20). ID: 425 Service code: cbot | 2021-06-18 08:57:57.784
CQG WebAPI | Sending symbol resolution request for F.US.ZMEZ20. ID: 75276 | 2021-06-18 08:57:57.784
SC Data - All Services | Requesting security definition data for: F.US.ZMEZ20 (ZMZ20). ID: 425 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.RBEX20 | 2021-06-18 08:57:57.784
Mapping F.US.RBEX20 to RBX20. Service code: nymex | 2021-06-18 08:57:57.784
SC Data - All Services | Starting real-time market data updates for: F.US.RBEX20 (RBX20). ID: 426 Service code: nymex | 2021-06-18 08:57:57.784
CQG WebAPI | Sending symbol resolution request for F.US.RBEX20. ID: 75277 | 2021-06-18 08:57:57.784
SC Data - All Services | Requesting security definition data for: F.US.RBEX20 (RBX20). ID: 426 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.CLEX20 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.ZSEF21 | 2021-06-18 08:57:57.784
Mapping F.US.ZSEF21 to ZSF21. Service code: cbot | 2021-06-18 08:57:57.784
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEF21 (ZSF21). ID: 427 Service code: cbot | 2021-06-18 08:57:57.784
CQG WebAPI | Sending symbol resolution request for F.US.ZSEF21. ID: 75278 | 2021-06-18 08:57:57.784
SC Data - All Services | Requesting security definition data for: F.US.ZSEF21 (ZSF21). ID: 427 | 2021-06-18 08:57:57.784
Subscribing to symbol for symbol alert. F.US.BP6Z20 | 2021-06-18 08:57:57.784
Mapping F.US.BP6Z20 to 6BZ20. Service code: cme | 2021-06-18 08:57:57.784
SC Data - All Services | Starting real-time market data updates for: F.US.BP6Z20 (6BZ20). ID: 428 Service code: cme | 2021-06-18 08:57:57.785
CQG WebAPI | Sending symbol resolution request for F.US.BP6Z20. ID: 75279 | 2021-06-18 08:57:57.785
SC Data - All Services | Requesting security definition data for: F.US.BP6Z20 (6BZ20). ID: 428 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.DSXU20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.CTEZ20 | 2021-06-18 08:57:57.785
CQG WebAPI | Starting real-time market data updates for: F.US.CTEZ20. ID: 429 Service code: cqg | 2021-06-18 08:57:57.785
CQG WebAPI | Sending symbol resolution request for F.US.CTEZ20. ID: 75280 | 2021-06-18 08:57:57.785
CQG WebAPI | Requesting security definition data for: F.US.CTEZ20. ID: 429 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.ZLEV20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.ZMEN21 | 2021-06-18 08:57:57.785
Mapping F.US.ZMEN21 to ZMN21. Service code: cbot | 2021-06-18 08:57:57.785
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEN21 (ZMN21). ID: 430 Service code: cbot | 2021-06-18 08:57:57.785
CQG WebAPI | Sending symbol resolution request for F.US.ZMEN21. ID: 75281 | 2021-06-18 08:57:57.785
SC Data - All Services | Requesting security definition data for: F.US.ZMEN21 (ZMN21). ID: 430 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.ZMEZ20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.ZCEZ20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.ZWAZ20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.NGEZ20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.CPEZ20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.ZLEZ20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.DSXZ20 | 2021-06-18 08:57:57.785
Mapping F.US.DSXZ20 to FESX202012_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.785
SC Data - All Services | Starting real-time market data updates for: F.US.DSXZ20 (FESX202012_FUT_EUREX). ID: 431 Service code: eurex | 2021-06-18 08:57:57.785
CQG WebAPI | Sending symbol resolution request for F.US.DSXZ20. ID: 75282 | 2021-06-18 08:57:57.785
SC Data - All Services | Requesting security definition data for: F.US.DSXZ20 (FESX202012_FUT_EUREX). ID: 431 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.DBZ20 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.DLZ20 | 2021-06-18 08:57:57.785
Mapping F.US.DLZ20 to FGBM202012_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.785
SC Data - All Services | Starting real-time market data updates for: F.US.DLZ20 (FGBM202012_FUT_EUREX). ID: 432 Service code: eurex | 2021-06-18 08:57:57.785
CQG WebAPI | Sending symbol resolution request for F.US.DLZ20. ID: 75283 | 2021-06-18 08:57:57.785
SC Data - All Services | Requesting security definition data for: F.US.DLZ20 (FGBM202012_FUT_EUREX). ID: 432 | 2021-06-18 08:57:57.785
Subscribing to symbol for symbol alert. F.US.EU6Z20 | 2021-06-18 08:57:57.785
Mapping F.US.EU6Z20 to 6EZ20. Service code: cme | 2021-06-18 08:57:57.785
SC Data - All Services | Starting real-time market data updates for: F.US.EU6Z20 (6EZ20). ID: 433 Service code: cme | 2021-06-18 08:57:57.786
CQG WebAPI | Sending symbol resolution request for F.US.EU6Z20. ID: 75284 | 2021-06-18 08:57:57.786
SC Data - All Services | Requesting security definition data for: F.US.EU6Z20 (6EZ20). ID: 433 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.JY6Z20 | 2021-06-18 08:57:57.786
Mapping F.US.JY6Z20 to 6JZ20. Service code: cme | 2021-06-18 08:57:57.786
SC Data - All Services | Starting real-time market data updates for: F.US.JY6Z20 (6JZ20). ID: 434 Service code: cme | 2021-06-18 08:57:57.786
CQG WebAPI | Sending symbol resolution request for F.US.JY6Z20. ID: 75285 | 2021-06-18 08:57:57.786
SC Data - All Services | Requesting security definition data for: F.US.JY6Z20 (6JZ20). ID: 434 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.TNAZ20 | 2021-06-18 08:57:57.786
Mapping F.US.TNAZ20 to TNZ20. Service code: cbot | 2021-06-18 08:57:57.786
SC Data - All Services | Starting real-time market data updates for: F.US.TNAZ20 (TNZ20). ID: 435 Service code: cbot | 2021-06-18 08:57:57.786
CQG WebAPI | Sending symbol resolution request for F.US.TNAZ20. ID: 75286 | 2021-06-18 08:57:57.786
SC Data - All Services | Requesting security definition data for: F.US.TNAZ20 (TNZ20). ID: 435 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.NGEX20 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.DSXZ20 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.ZSEK21 | 2021-06-18 08:57:57.786
Mapping F.US.ZSEK21 to ZSK21. Service code: cbot | 2021-06-18 08:57:57.786
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEK21 (ZSK21). ID: 436 Service code: cbot | 2021-06-18 08:57:57.786
CQG WebAPI | Sending symbol resolution request for F.US.ZSEK21. ID: 75287 | 2021-06-18 08:57:57.786
SC Data - All Services | Requesting security definition data for: F.US.ZSEK21 (ZSK21). ID: 436 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.GFF21 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.BP6Z20 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.USAZ20 | 2021-06-18 08:57:57.786
Mapping F.US.USAZ20 to ZBZ20. Service code: cbot | 2021-06-18 08:57:57.786
SC Data - All Services | Starting real-time market data updates for: F.US.USAZ20 (ZBZ20). ID: 437 Service code: cbot | 2021-06-18 08:57:57.786
CQG WebAPI | Sending symbol resolution request for F.US.USAZ20. ID: 75288 | 2021-06-18 08:57:57.786
SC Data - All Services | Requesting security definition data for: F.US.USAZ20 (ZBZ20). ID: 437 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.HEQ21 | 2021-06-18 08:57:57.786
Mapping F.US.HEQ21 to HEQ21. Service code: cme | 2021-06-18 08:57:57.786
SC Data - All Services | Starting real-time market data updates for: F.US.HEQ21 (HEQ21). ID: 438 Service code: cme | 2021-06-18 08:57:57.786
CQG WebAPI | Sending symbol resolution request for F.US.HEQ21. ID: 75289 | 2021-06-18 08:57:57.786
SC Data - All Services | Requesting security definition data for: F.US.HEQ21 (HEQ21). ID: 438 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.ZWAZ20 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.EU6Z20 | 2021-06-18 08:57:57.786
Subscribing to symbol for symbol alert. F.US.EU6Z20 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.PLEF21 | 2021-06-18 08:57:57.787
Mapping F.US.PLEF21 to PLF21. Service code: nymex | 2021-06-18 08:57:57.787
SC Data - All Services | Starting real-time market data updates for: F.US.PLEF21 (PLF21). ID: 439 Service code: nymex | 2021-06-18 08:57:57.787
CQG WebAPI | Sending symbol resolution request for F.US.PLEF21. ID: 75290 | 2021-06-18 08:57:57.787
SC Data - All Services | Requesting security definition data for: F.US.PLEF21 (PLF21). ID: 439 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.ZWAZ20 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.DSXZ20 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.JY6Z20 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.CA6Z20 | 2021-06-18 08:57:57.787
Mapping F.US.CA6Z20 to 6CZ20. Service code: cme | 2021-06-18 08:57:57.787
SC Data - All Services | Starting real-time market data updates for: F.US.CA6Z20 (6CZ20). ID: 440 Service code: cme | 2021-06-18 08:57:57.787
CQG WebAPI | Sending symbol resolution request for F.US.CA6Z20. ID: 75291 | 2021-06-18 08:57:57.787
SC Data - All Services | Requesting security definition data for: F.US.CA6Z20 (6CZ20). ID: 440 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.TNAZ20 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.ZMEN21 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.SF6Z20 | 2021-06-18 08:57:57.787
Mapping F.US.SF6Z20 to 6SZ20. Service code: cme | 2021-06-18 08:57:57.787
SC Data - All Services | Starting real-time market data updates for: F.US.SF6Z20 (6SZ20). ID: 441 Service code: cme | 2021-06-18 08:57:57.787
CQG WebAPI | Sending symbol resolution request for F.US.SF6Z20. ID: 75292 | 2021-06-18 08:57:57.787
SC Data - All Services | Requesting security definition data for: F.US.SF6Z20 (6SZ20). ID: 441 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.USAZ20 | 2021-06-18 08:57:57.787
Subscribing to symbol for symbol alert. F.US.USAZ20 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.DSXZ20 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.ZCEZ20 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.HEJ21 | 2021-06-18 08:57:57.788
Mapping F.US.HEJ21 to HEJ21. Service code: cme | 2021-06-18 08:57:57.788
SC Data - All Services | Starting real-time market data updates for: F.US.HEJ21 (HEJ21). ID: 442 Service code: cme | 2021-06-18 08:57:57.788
CQG WebAPI | Sending symbol resolution request for F.US.HEJ21. ID: 75293 | 2021-06-18 08:57:57.788
SC Data - All Services | Requesting security definition data for: F.US.HEJ21 (HEJ21). ID: 442 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.ZWAZ20 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.ZMEK21 | 2021-06-18 08:57:57.788
Mapping F.US.ZMEK21 to ZMK21. Service code: cbot | 2021-06-18 08:57:57.788
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEK21 (ZMK21). ID: 443 Service code: cbot | 2021-06-18 08:57:57.788
CQG WebAPI | Sending symbol resolution request for F.US.ZMEK21. ID: 75294 | 2021-06-18 08:57:57.788
SC Data - All Services | Requesting security definition data for: F.US.ZMEK21 (ZMK21). ID: 443 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.JY6Z20 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.KWEN21 | 2021-06-18 08:57:57.788
Mapping F.US.KWEN21 to KEN21. Service code: cbot | 2021-06-18 08:57:57.788
SC Data - All Services | Starting real-time market data updates for: F.US.KWEN21 (KEN21). ID: 444 Service code: cbot | 2021-06-18 08:57:57.788
CQG WebAPI | Sending symbol resolution request for F.US.KWEN21. ID: 75295 | 2021-06-18 08:57:57.788
SC Data - All Services | Requesting security definition data for: F.US.KWEN21 (KEN21). ID: 444 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.KWEZ20 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.KWEK21 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.DBZ20 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.NGEF21 | 2021-06-18 08:57:57.788
Mapping F.US.NGEF21 to NGF21. Service code: nymex | 2021-06-18 08:57:57.788
SC Data - All Services | Starting real-time market data updates for: F.US.NGEF21 (NGF21). ID: 445 Service code: nymex | 2021-06-18 08:57:57.788
CQG WebAPI | Sending symbol resolution request for F.US.NGEF21. ID: 75296 | 2021-06-18 08:57:57.788
SC Data - All Services | Requesting security definition data for: F.US.NGEF21 (NGF21). ID: 445 | 2021-06-18 08:57:57.788
Subscribing to symbol for symbol alert. F.US.DSXZ20 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.ZMEZ20 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.HEJ21 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.ZMEF21 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.KWEU21 | 2021-06-18 08:57:57.789
Mapping F.US.KWEU21 to KEU21. Service code: cbot | 2021-06-18 08:57:57.789
SC Data - All Services | Starting real-time market data updates for: F.US.KWEU21 (KEU21). ID: 446 Service code: cbot | 2021-06-18 08:57:57.789
CQG WebAPI | Sending symbol resolution request for F.US.KWEU21. ID: 75297 | 2021-06-18 08:57:57.789
SC Data - All Services | Requesting security definition data for: F.US.KWEU21 (KEU21). ID: 446 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.ZMEH21 | 2021-06-18 08:57:57.789
Mapping F.US.ZMEH21 to ZMH21. Service code: cbot | 2021-06-18 08:57:57.789
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEH21 (ZMH21). ID: 447 Service code: cbot | 2021-06-18 08:57:57.789
CQG WebAPI | Sending symbol resolution request for F.US.ZMEH21. ID: 75298 | 2021-06-18 08:57:57.789
SC Data - All Services | Requesting security definition data for: F.US.ZMEH21 (ZMH21). ID: 447 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.ZMEK21 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.USAZ20 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.GLEG21 | 2021-06-18 08:57:57.789
Mapping F.US.GLEG21 to LEG21. Service code: cme | 2021-06-18 08:57:57.789
SC Data - All Services | Starting real-time market data updates for: F.US.GLEG21 (LEG21). ID: 448 Service code: cme | 2021-06-18 08:57:57.789
CQG WebAPI | Sending symbol resolution request for F.US.GLEG21. ID: 75299 | 2021-06-18 08:57:57.789
SC Data - All Services | Requesting security definition data for: F.US.GLEG21 (LEG21). ID: 448 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.DA6Z20 | 2021-06-18 08:57:57.789
Mapping F.US.DA6Z20 to 6AZ20. Service code: cme | 2021-06-18 08:57:57.789
SC Data - All Services | Starting real-time market data updates for: F.US.DA6Z20 (6AZ20). ID: 449 Service code: cme | 2021-06-18 08:57:57.789
CQG WebAPI | Sending symbol resolution request for F.US.DA6Z20. ID: 75300 | 2021-06-18 08:57:57.789
SC Data - All Services | Requesting security definition data for: F.US.DA6Z20 (6AZ20). ID: 449 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.CLEF21 | 2021-06-18 08:57:57.789
Mapping F.US.CLEF21 to CLF21. Service code: nymex | 2021-06-18 08:57:57.789
SC Data - All Services | Starting real-time market data updates for: F.US.CLEF21 (CLF21). ID: 450 Service code: nymex | 2021-06-18 08:57:57.789
CQG WebAPI | Sending symbol resolution request for F.US.CLEF21. ID: 75301 | 2021-06-18 08:57:57.789
SC Data - All Services | Requesting security definition data for: F.US.CLEF21 (CLF21). ID: 450 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.ZWAZ20 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.ZCEK21 | 2021-06-18 08:57:57.789
Mapping F.US.ZCEK21 to ZCK21. Service code: cbot | 2021-06-18 08:57:57.789
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEK21 (ZCK21). ID: 451 Service code: cbot | 2021-06-18 08:57:57.789
CQG WebAPI | Sending symbol resolution request for F.US.ZCEK21. ID: 75302 | 2021-06-18 08:57:57.789
SC Data - All Services | Requesting security definition data for: F.US.ZCEK21 (ZCK21). ID: 451 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.DLZ20 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.CPEZ20 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.PLEF21 | 2021-06-18 08:57:57.789
Subscribing to symbol for symbol alert. F.US.ZLEF21 | 2021-06-18 08:57:57.789
Mapping F.US.ZLEF21 to ZLF21. Service code: cbot | 2021-06-18 08:57:57.789
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEF21 (ZLF21). ID: 452 Service code: cbot | 2021-06-18 08:57:57.789
CQG WebAPI | Sending symbol resolution request for F.US.ZLEF21. ID: 75303 | 2021-06-18 08:57:57.790
SC Data - All Services | Requesting security definition data for: F.US.ZLEF21 (ZLF21). ID: 452 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.USAZ20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.DSXZ20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.NE6Z20 | 2021-06-18 08:57:57.790
Mapping F.US.NE6Z20 to 6NZ20. Service code: cme | 2021-06-18 08:57:57.790
SC Data - All Services | Starting real-time market data updates for: F.US.NE6Z20 (6NZ20). ID: 453 Service code: cme | 2021-06-18 08:57:57.790
CQG WebAPI | Sending symbol resolution request for F.US.NE6Z20. ID: 75304 | 2021-06-18 08:57:57.790
SC Data - All Services | Requesting security definition data for: F.US.NE6Z20 (6NZ20). ID: 453 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.NGEZ20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.ZSEK21 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.BP6Z20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.ZMEF21 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.ZMEZ20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.RBEH21 | 2021-06-18 08:57:57.790
Mapping F.US.RBEH21 to RBH21. Service code: nymex | 2021-06-18 08:57:57.790
SC Data - All Services | Starting real-time market data updates for: F.US.RBEH21 (RBH21). ID: 454 Service code: nymex | 2021-06-18 08:57:57.790
CQG WebAPI | Sending symbol resolution request for F.US.RBEH21. ID: 75305 | 2021-06-18 08:57:57.790
SC Data - All Services | Requesting security definition data for: F.US.RBEH21 (RBH21). ID: 454 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.HOEJ21 | 2021-06-18 08:57:57.790
Mapping F.US.HOEJ21 to HOJ21. Service code: nymex | 2021-06-18 08:57:57.790
SC Data - All Services | Starting real-time market data updates for: F.US.HOEJ21 (HOJ21). ID: 455 Service code: nymex | 2021-06-18 08:57:57.790
CQG WebAPI | Sending symbol resolution request for F.US.HOEJ21. ID: 75306 | 2021-06-18 08:57:57.790
SC Data - All Services | Requesting security definition data for: F.US.HOEJ21 (HOJ21). ID: 455 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.GCEZ20 | 2021-06-18 08:57:57.790
Mapping F.US.GCEZ20 to GCZ20. Service code: comex | 2021-06-18 08:57:57.790
SC Data - All Services | Starting real-time market data updates for: F.US.GCEZ20 (GCZ20). ID: 456 Service code: comex | 2021-06-18 08:57:57.790
CQG WebAPI | Sending symbol resolution request for F.US.GCEZ20. ID: 75307 | 2021-06-18 08:57:57.790
SC Data - All Services | Requesting security definition data for: F.US.GCEZ20 (GCZ20). ID: 456 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.CLEZ20 | 2021-06-18 08:57:57.790
Mapping F.US.CLEZ20 to CLZ20. Service code: nymex | 2021-06-18 08:57:57.790
SC Data - All Services | Starting real-time market data updates for: F.US.CLEZ20 (CLZ20). ID: 457 Service code: nymex | 2021-06-18 08:57:57.790
CQG WebAPI | Sending symbol resolution request for F.US.CLEZ20. ID: 75308 | 2021-06-18 08:57:57.790
SC Data - All Services | Requesting security definition data for: F.US.CLEZ20 (CLZ20). ID: 457 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.DLZ20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.NGEM21 | 2021-06-18 08:57:57.790
Mapping F.US.NGEM21 to NGM21. Service code: nymex | 2021-06-18 08:57:57.790
SC Data - All Services | Starting real-time market data updates for: F.US.NGEM21 (NGM21). ID: 458 Service code: nymex | 2021-06-18 08:57:57.790
CQG WebAPI | Sending symbol resolution request for F.US.NGEM21. ID: 75309 | 2021-06-18 08:57:57.790
SC Data - All Services | Requesting security definition data for: F.US.NGEM21 (NGM21). ID: 458 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.ZLEZ20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.ZMEH21 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.ZSEF21 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.DA6Z20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.CA6Z20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.PLEF21 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.NGEF21 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.JY6Z20 | 2021-06-18 08:57:57.790
Subscribing to symbol for symbol alert. F.US.ZCEZ20 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.NE6Z20 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.DA6Z20 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.ZLEH21 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.ZCEU21 | 2021-06-18 08:57:57.791
Mapping F.US.ZCEU21 to ZCU21. Service code: cbot | 2021-06-18 08:57:57.791
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEU21 (ZCU21). ID: 459 Service code: cbot | 2021-06-18 08:57:57.791
CQG WebAPI | Sending symbol resolution request for F.US.ZCEU21. ID: 75310 | 2021-06-18 08:57:57.791
SC Data - All Services | Requesting security definition data for: F.US.ZCEU21 (ZCU21). ID: 459 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.DSXZ20 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.ZSEN21 | 2021-06-18 08:57:57.791
Mapping F.US.ZSEN21 to ZSN21. Service code: cbot | 2021-06-18 08:57:57.791
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEN21 (ZSN21). ID: 460 Service code: cbot | 2021-06-18 08:57:57.791
CQG WebAPI | Sending symbol resolution request for F.US.ZSEN21. ID: 75311 | 2021-06-18 08:57:57.791
SC Data - All Services | Requesting security definition data for: F.US.ZSEN21 (ZSN21). ID: 460 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.USAH21 | 2021-06-18 08:57:57.791
Mapping F.US.USAH21 to ZBH21. Service code: cbot | 2021-06-18 08:57:57.791
SC Data - All Services | Starting real-time market data updates for: F.US.USAH21 (ZBH21). ID: 461 Service code: cbot | 2021-06-18 08:57:57.791
CQG WebAPI | Sending symbol resolution request for F.US.USAH21. ID: 75312 | 2021-06-18 08:57:57.791
SC Data - All Services | Requesting security definition data for: F.US.USAH21 (ZBH21). ID: 461 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.TYAH21 | 2021-06-18 08:57:57.791
Mapping F.US.TYAH21 to ZNH21. Service code: cbot | 2021-06-18 08:57:57.791
SC Data - All Services | Starting real-time market data updates for: F.US.TYAH21 (ZNH21). ID: 462 Service code: cbot | 2021-06-18 08:57:57.791
CQG WebAPI | Sending symbol resolution request for F.US.TYAH21. ID: 75313 | 2021-06-18 08:57:57.791
SC Data - All Services | Requesting security definition data for: F.US.TYAH21 (ZNH21). ID: 462 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.ZMEN21 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.HEJ21 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.CLEH21 | 2021-06-18 08:57:57.791
Mapping F.US.CLEH21 to CLH21. Service code: nymex | 2021-06-18 08:57:57.791
SC Data - All Services | Starting real-time market data updates for: F.US.CLEH21 (CLH21). ID: 463 Service code: nymex | 2021-06-18 08:57:57.791
CQG WebAPI | Sending symbol resolution request for F.US.CLEH21. ID: 75314 | 2021-06-18 08:57:57.791
SC Data - All Services | Requesting security definition data for: F.US.CLEH21 (CLH21). ID: 463 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.ZLEK21 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.HOEF21 | 2021-06-18 08:57:57.791
Mapping F.US.HOEF21 to HOF21. Service code: nymex | 2021-06-18 08:57:57.791
SC Data - All Services | Starting real-time market data updates for: F.US.HOEF21 (HOF21). ID: 464 Service code: nymex | 2021-06-18 08:57:57.791
CQG WebAPI | Sending symbol resolution request for F.US.HOEF21. ID: 75315 | 2021-06-18 08:57:57.791
SC Data - All Services | Requesting security definition data for: F.US.HOEF21 (HOF21). ID: 464 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.DBH21 | 2021-06-18 08:57:57.791
Mapping F.US.DBH21 to FGBL202103_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.791
SC Data - All Services | Starting real-time market data updates for: F.US.DBH21 (FGBL202103_FUT_EUREX). ID: 465 Service code: eurex | 2021-06-18 08:57:57.791
CQG WebAPI | Sending symbol resolution request for F.US.DBH21. ID: 75316 | 2021-06-18 08:57:57.791
SC Data - All Services | Requesting security definition data for: F.US.DBH21 (FGBL202103_FUT_EUREX). ID: 465 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.NGEH21 | 2021-06-18 08:57:57.791
Mapping F.US.NGEH21 to NGH21. Service code: nymex | 2021-06-18 08:57:57.791
SC Data - All Services | Starting real-time market data updates for: F.US.NGEH21 (NGH21). ID: 466 Service code: nymex | 2021-06-18 08:57:57.791
CQG WebAPI | Sending symbol resolution request for F.US.NGEH21. ID: 75317 | 2021-06-18 08:57:57.791
SC Data - All Services | Requesting security definition data for: F.US.NGEH21 (NGH21). ID: 466 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.NGEM21 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.TNAH21 | 2021-06-18 08:57:57.791
Mapping F.US.TNAH21 to TNH21. Service code: cbot | 2021-06-18 08:57:57.791
SC Data - All Services | Starting real-time market data updates for: F.US.TNAH21 (TNH21). ID: 467 Service code: cbot | 2021-06-18 08:57:57.791
CQG WebAPI | Sending symbol resolution request for F.US.TNAH21. ID: 75318 | 2021-06-18 08:57:57.791
SC Data - All Services | Requesting security definition data for: F.US.TNAH21 (TNH21). ID: 467 | 2021-06-18 08:57:57.791
Subscribing to symbol for symbol alert. F.US.YMZ20 | 2021-06-18 08:57:57.791
Mapping F.US.YMZ20 to YMZ20. Service code: cbot | 2021-06-18 08:57:57.792
SC Data - All Services | Starting real-time market data updates for: F.US.YMZ20 (YMZ20). ID: 468 Service code: cbot | 2021-06-18 08:57:57.792
CQG WebAPI | Sending symbol resolution request for F.US.YMZ20. ID: 75319 | 2021-06-18 08:57:57.792
SC Data - All Services | Requesting security definition data for: F.US.YMZ20 (YMZ20). ID: 468 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.DSXZ20 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.CA6H21 | 2021-06-18 08:57:57.792
Mapping F.US.CA6H21 to 6CH21. Service code: cme | 2021-06-18 08:57:57.792
SC Data - All Services | Starting real-time market data updates for: F.US.CA6H21 (6CH21). ID: 469 Service code: cme | 2021-06-18 08:57:57.792
CQG WebAPI | Sending symbol resolution request for F.US.CA6H21. ID: 75320 | 2021-06-18 08:57:57.792
SC Data - All Services | Requesting security definition data for: F.US.CA6H21 (6CH21). ID: 469 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.ZSEN21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.HOEF21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.SF6H21 | 2021-06-18 08:57:57.792
Mapping F.US.SF6H21 to 6SH21. Service code: cme | 2021-06-18 08:57:57.792
SC Data - All Services | Starting real-time market data updates for: F.US.SF6H21 (6SH21). ID: 470 Service code: cme | 2021-06-18 08:57:57.792
CQG WebAPI | Sending symbol resolution request for F.US.SF6H21. ID: 75321 | 2021-06-18 08:57:57.792
SC Data - All Services | Requesting security definition data for: F.US.SF6H21 (6SH21). ID: 470 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.JY6Z20 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.TYAH21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.HOEH21 | 2021-06-18 08:57:57.792
Mapping F.US.HOEH21 to HOH21. Service code: nymex | 2021-06-18 08:57:57.792
SC Data - All Services | Starting real-time market data updates for: F.US.HOEH21 (HOH21). ID: 471 Service code: nymex | 2021-06-18 08:57:57.792
CQG WebAPI | Sending symbol resolution request for F.US.HOEH21. ID: 75322 | 2021-06-18 08:57:57.792
SC Data - All Services | Requesting security definition data for: F.US.HOEH21 (HOH21). ID: 471 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.ZMEN21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.RBEH21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.GFQ21 | 2021-06-18 08:57:57.792
Mapping F.US.GFQ21 to GFQ21. Service code: cme | 2021-06-18 08:57:57.792
SC Data - All Services | Starting real-time market data updates for: F.US.GFQ21 (GFQ21). ID: 472 Service code: cme | 2021-06-18 08:57:57.792
CQG WebAPI | Sending symbol resolution request for F.US.GFQ21. ID: 75323 | 2021-06-18 08:57:57.792
SC Data - All Services | Requesting security definition data for: F.US.GFQ21 (GFQ21). ID: 472 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.DSXH21 | 2021-06-18 08:57:57.792
Mapping F.US.DSXH21 to FESX202103_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.792
SC Data - All Services | Starting real-time market data updates for: F.US.DSXH21 (FESX202103_FUT_EUREX). ID: 473 Service code: eurex | 2021-06-18 08:57:57.792
CQG WebAPI | Sending symbol resolution request for F.US.DSXH21. ID: 75324 | 2021-06-18 08:57:57.792
SC Data - All Services | Requesting security definition data for: F.US.DSXH21 (FESX202103_FUT_EUREX). ID: 473 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.ZCEK21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.DA6H21 | 2021-06-18 08:57:57.792
Mapping F.US.DA6H21 to 6AH21. Service code: cme | 2021-06-18 08:57:57.792
SC Data - All Services | Starting real-time market data updates for: F.US.DA6H21 (6AH21). ID: 474 Service code: cme | 2021-06-18 08:57:57.792
CQG WebAPI | Sending symbol resolution request for F.US.DA6H21. ID: 75325 | 2021-06-18 08:57:57.792
SC Data - All Services | Requesting security definition data for: F.US.DA6H21 (6AH21). ID: 474 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.GFF21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.ZSEF21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.USAH21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.ULAH21 | 2021-06-18 08:57:57.792
Mapping F.US.ULAH21 to UBH21. Service code: cbot | 2021-06-18 08:57:57.792
SC Data - All Services | Starting real-time market data updates for: F.US.ULAH21 (UBH21). ID: 475 Service code: cbot | 2021-06-18 08:57:57.792
CQG WebAPI | Sending symbol resolution request for F.US.ULAH21. ID: 75326 | 2021-06-18 08:57:57.792
SC Data - All Services | Requesting security definition data for: F.US.ULAH21 (UBH21). ID: 475 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.NGEH21 | 2021-06-18 08:57:57.792
Subscribing to symbol for symbol alert. F.US.DLH21 | 2021-06-18 08:57:57.792
Mapping F.US.DLH21 to FGBM202103_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.DLH21 (FGBM202103_FUT_EUREX). ID: 476 Service code: eurex | 2021-06-18 08:57:57.793
CQG WebAPI | Sending symbol resolution request for F.US.DLH21. ID: 75327 | 2021-06-18 08:57:57.793
SC Data - All Services | Requesting security definition data for: F.US.DLH21 (FGBM202103_FUT_EUREX). ID: 476 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.DSXH21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.KWEK21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.TYAH21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.TNAH21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.NE6H21 | 2021-06-18 08:57:57.793
Mapping F.US.NE6H21 to 6NH21. Service code: cme | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.NE6H21 (6NH21). ID: 477 Service code: cme | 2021-06-18 08:57:57.793
CQG WebAPI | Sending symbol resolution request for F.US.NE6H21. ID: 75328 | 2021-06-18 08:57:57.793
SC Data - All Services | Requesting security definition data for: F.US.NE6H21 (6NH21). ID: 477 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.RBEH21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.KWEH21 | 2021-06-18 08:57:57.793
Mapping F.US.KWEH21 to KEH21. Service code: cbot | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.KWEH21 (KEH21). ID: 478 Service code: cbot | 2021-06-18 08:57:57.793
CQG WebAPI | Sending symbol resolution request for F.US.KWEH21. ID: 75329 | 2021-06-18 08:57:57.793
SC Data - All Services | Requesting security definition data for: F.US.KWEH21 (KEH21). ID: 478 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.ZCEN21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.ZLEK21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.CA6H21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.ZCEH21 | 2021-06-18 08:57:57.793
Mapping F.US.ZCEH21 to ZCH21. Service code: cbot | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEH21 (ZCH21). ID: 479 Service code: cbot | 2021-06-18 08:57:57.793
CQG WebAPI | Sending symbol resolution request for F.US.ZCEH21. ID: 75330 | 2021-06-18 08:57:57.793
SC Data - All Services | Requesting security definition data for: F.US.ZCEH21 (ZCH21). ID: 479 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.ZMEK21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.ZSEH21 | 2021-06-18 08:57:57.793
Mapping F.US.ZSEH21 to ZSH21. Service code: cbot | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEH21 (ZSH21). ID: 480 Service code: cbot | 2021-06-18 08:57:57.793
CQG WebAPI | Sending symbol resolution request for F.US.ZSEH21. ID: 75331 | 2021-06-18 08:57:57.793
SC Data - All Services | Requesting security definition data for: F.US.ZSEH21 (ZSH21). ID: 480 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.HOEG21 | 2021-06-18 08:57:57.793
Mapping F.US.HOEG21 to HOG21. Service code: nymex | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.HOEG21 (HOG21). ID: 481 Service code: nymex | 2021-06-18 08:57:57.793
CQG WebAPI | Sending symbol resolution request for F.US.HOEG21. ID: 75332 | 2021-06-18 08:57:57.793
SC Data - All Services | Requesting security definition data for: F.US.HOEG21 (HOG21). ID: 481 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.RBEG21 | 2021-06-18 08:57:57.793
Mapping F.US.RBEG21 to RBG21. Service code: nymex | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.RBEG21 (RBG21). ID: 482 Service code: nymex | 2021-06-18 08:57:57.793
CQG WebAPI | Sending symbol resolution request for F.US.RBEG21. ID: 75333 | 2021-06-18 08:57:57.793
SC Data - All Services | Requesting security definition data for: F.US.RBEG21 (RBG21). ID: 482 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.HEM21 | 2021-06-18 08:57:57.793
Mapping F.US.HEM21 to HEM21. Service code: cme | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.HEM21 (HEM21). ID: 483 Service code: cme | 2021-06-18 08:57:57.793
CQG WebAPI | Sending symbol resolution request for F.US.HEM21. ID: 75334 | 2021-06-18 08:57:57.793
SC Data - All Services | Requesting security definition data for: F.US.HEM21 (HEM21). ID: 483 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.DA6H21 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.EPH21 | 2021-06-18 08:57:57.793
Mapping F.US.EPH21 to ESH21. Service code: cme | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.EPH21 (ESH21). ID: 484 Service code: cme | 2021-06-18 08:57:57.793
CQG WebAPI | Sending symbol resolution request for F.US.EPH21. ID: 75335 | 2021-06-18 08:57:57.793
SC Data - All Services | Requesting security definition data for: F.US.EPH21 (ESH21). ID: 484 | 2021-06-18 08:57:57.793
Subscribing to symbol for symbol alert. F.US.FVAH21 | 2021-06-18 08:57:57.793
Mapping F.US.FVAH21 to ZFH21. Service code: cbot | 2021-06-18 08:57:57.793
SC Data - All Services | Starting real-time market data updates for: F.US.FVAH21 (ZFH21). ID: 485 Service code: cbot | 2021-06-18 08:57:57.794
CQG WebAPI | Sending symbol resolution request for F.US.FVAH21. ID: 75336 | 2021-06-18 08:57:57.794
SC Data - All Services | Requesting security definition data for: F.US.FVAH21 (ZFH21). ID: 485 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.DSXH21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.ZCEH21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.TYAH21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.ZMEH21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.TNAH21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.CLEK21 | 2021-06-18 08:57:57.794
Mapping F.US.CLEK21 to CLK21. Service code: nymex | 2021-06-18 08:57:57.794
SC Data - All Services | Starting real-time market data updates for: F.US.CLEK21 (CLK21). ID: 486 Service code: nymex | 2021-06-18 08:57:57.794
CQG WebAPI | Sending symbol resolution request for F.US.CLEK21. ID: 75337 | 2021-06-18 08:57:57.794
SC Data - All Services | Requesting security definition data for: F.US.CLEK21 (CLK21). ID: 486 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.CLEH21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.USAH21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.GLEQ21 | 2021-06-18 08:57:57.794
Mapping F.US.GLEQ21 to LEQ21. Service code: cme | 2021-06-18 08:57:57.794
SC Data - All Services | Starting real-time market data updates for: F.US.GLEQ21 (LEQ21). ID: 487 Service code: cme | 2021-06-18 08:57:57.794
CQG WebAPI | Sending symbol resolution request for F.US.GLEQ21. ID: 75338 | 2021-06-18 08:57:57.794
SC Data - All Services | Requesting security definition data for: F.US.GLEQ21 (LEQ21). ID: 487 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.CA6H21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.DBH21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.RBEH21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.HEQ21 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.GLEM21 | 2021-06-18 08:57:57.794
Mapping F.US.GLEM21 to LEM21. Service code: cme | 2021-06-18 08:57:57.794
SC Data - All Services | Starting real-time market data updates for: F.US.GLEM21 (LEM21). ID: 488 Service code: cme | 2021-06-18 08:57:57.794
CQG WebAPI | Sending symbol resolution request for F.US.GLEM21. ID: 75339 | 2021-06-18 08:57:57.794
SC Data - All Services | Requesting security definition data for: F.US.GLEM21 (LEM21). ID: 488 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.GCEJ21 | 2021-06-18 08:57:57.794
Mapping F.US.GCEJ21 to GCJ21. Service code: comex | 2021-06-18 08:57:57.794
SC Data - All Services | Starting real-time market data updates for: F.US.GCEJ21 (GCJ21). ID: 489 Service code: comex | 2021-06-18 08:57:57.794
CQG WebAPI | Sending symbol resolution request for F.US.GCEJ21. ID: 75340 | 2021-06-18 08:57:57.794
SC Data - All Services | Requesting security definition data for: F.US.GCEJ21 (GCJ21). ID: 489 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.JY6H21 | 2021-06-18 08:57:57.794
Mapping F.US.JY6H21 to 6JH21. Service code: cme | 2021-06-18 08:57:57.794
SC Data - All Services | Starting real-time market data updates for: F.US.JY6H21 (6JH21). ID: 490 Service code: cme | 2021-06-18 08:57:57.794
CQG WebAPI | Sending symbol resolution request for F.US.JY6H21. ID: 75341 | 2021-06-18 08:57:57.794
SC Data - All Services | Requesting security definition data for: F.US.JY6H21 (6JH21). ID: 490 | 2021-06-18 08:57:57.794
Subscribing to symbol for symbol alert. F.US.CPEH21 | 2021-06-18 08:57:57.794
Mapping F.US.CPEH21 to HGH21. Service code: comex | 2021-06-18 08:57:57.794
SC Data - All Services | Starting real-time market data updates for: F.US.CPEH21 (HGH21). ID: 491 Service code: comex | 2021-06-18 08:57:57.795
CQG WebAPI | Sending symbol resolution request for F.US.CPEH21. ID: 75342 | 2021-06-18 08:57:57.795
SC Data - All Services | Requesting security definition data for: F.US.CPEH21 (HGH21). ID: 491 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.DSXH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.TNAH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.CPEH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.GLEM21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.CLEH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.SF6H21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.CLEJ21 | 2021-06-18 08:57:57.795
Mapping F.US.CLEJ21 to CLJ21. Service code: nymex | 2021-06-18 08:57:57.795
SC Data - All Services | Starting real-time market data updates for: F.US.CLEJ21 (CLJ21). ID: 492 Service code: nymex | 2021-06-18 08:57:57.795
CQG WebAPI | Sending symbol resolution request for F.US.CLEJ21. ID: 75343 | 2021-06-18 08:57:57.795
SC Data - All Services | Requesting security definition data for: F.US.CLEJ21 (CLJ21). ID: 492 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.TYAH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.ULAH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.RBEH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.HOEH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.ZCEH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.ZCEU21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.NGEH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.PLEJ21 | 2021-06-18 08:57:57.795
Mapping F.US.PLEJ21 to PLJ21. Service code: nymex | 2021-06-18 08:57:57.795
SC Data - All Services | Starting real-time market data updates for: F.US.PLEJ21 (PLJ21). ID: 493 Service code: nymex | 2021-06-18 08:57:57.795
CQG WebAPI | Sending symbol resolution request for F.US.PLEJ21. ID: 75344 | 2021-06-18 08:57:57.795
SC Data - All Services | Requesting security definition data for: F.US.PLEJ21 (PLJ21). ID: 493 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.NGEK21 | 2021-06-18 08:57:57.795
Mapping F.US.NGEK21 to NGK21. Service code: nymex | 2021-06-18 08:57:57.795
SC Data - All Services | Starting real-time market data updates for: F.US.NGEK21 (NGK21). ID: 494 Service code: nymex | 2021-06-18 08:57:57.795
CQG WebAPI | Sending symbol resolution request for F.US.NGEK21. ID: 75345 | 2021-06-18 08:57:57.795
SC Data - All Services | Requesting security definition data for: F.US.NGEK21 (NGK21). ID: 494 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.ZSEN21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.RBEN21 | 2021-06-18 08:57:57.795
Mapping F.US.RBEN21 to RBN21. Service code: nymex | 2021-06-18 08:57:57.795
Mapping F.US.RBEQ21 to RBQ21. Service code: nymex | 2021-06-18 08:57:57.795
SC Data - All Services | Starting real-time market data updates for: F.US.RBEQ21 (RBQ21). ID: 496 Service code: nymex | 2021-06-18 08:57:57.795
CQG WebAPI | Sending symbol resolution request for F.US.RBEQ21. ID: 75346 | 2021-06-18 08:57:57.795
SC Data - All Services | Requesting security definition data for: F.US.RBEQ21 (RBQ21). ID: 496 | 2021-06-18 08:57:57.795
SC Data - All Services | Starting real-time market data updates for: F.US.RBEN21 (RBN21). ID: 495 Service code: nymex | 2021-06-18 08:57:57.795
CQG WebAPI | Sending symbol resolution request for F.US.RBEN21. ID: 75347 | 2021-06-18 08:57:57.795
SC Data - All Services | Requesting security definition data for: F.US.RBEN21 (RBN21). ID: 495 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.ZSEX21 | 2021-06-18 08:57:57.795
Mapping F.US.ZSEX21 to ZSX21. Service code: cbot | 2021-06-18 08:57:57.795
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEX21 (ZSX21). ID: 497 Service code: cbot | 2021-06-18 08:57:57.795
CQG WebAPI | Sending symbol resolution request for F.US.ZSEX21. ID: 75348 | 2021-06-18 08:57:57.795
SC Data - All Services | Requesting security definition data for: F.US.ZSEX21 (ZSX21). ID: 497 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.KWEK21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.DBH21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.NE6H21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.ZMEK21 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.RBEJ21 | 2021-06-18 08:57:57.795
Mapping F.US.RBEJ21 to RBJ21. Service code: nymex | 2021-06-18 08:57:57.795
SC Data - All Services | Starting real-time market data updates for: F.US.RBEJ21 (RBJ21). ID: 498 Service code: nymex | 2021-06-18 08:57:57.795
CQG WebAPI | Sending symbol resolution request for F.US.RBEJ21. ID: 75349 | 2021-06-18 08:57:57.795
SC Data - All Services | Requesting security definition data for: F.US.RBEJ21 (RBJ21). ID: 498 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.RBEK21 | 2021-06-18 08:57:57.795
Mapping F.US.RBEK21 to RBK21. Service code: nymex | 2021-06-18 08:57:57.795
SC Data - All Services | Starting real-time market data updates for: F.US.RBEK21 (RBK21). ID: 499 Service code: nymex | 2021-06-18 08:57:57.795
CQG WebAPI | Sending symbol resolution request for F.US.RBEK21. ID: 75350 | 2021-06-18 08:57:57.795
SC Data - All Services | Requesting security definition data for: F.US.RBEK21 (RBK21). ID: 499 | 2021-06-18 08:57:57.795
Subscribing to symbol for symbol alert. F.US.DSXH21 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.RBEJ21 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.CLEJ21 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.ZSEK21 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.ZLEK21 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.CPEK21 | 2021-06-18 08:57:57.796
Mapping F.US.CPEK21 to HGK21. Service code: comex | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.CPEK21 (HGK21). ID: 500 Service code: comex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.CPEK21. ID: 75351 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.CPEK21 (HGK21). ID: 500 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.TYAM21 | 2021-06-18 08:57:57.796
Mapping F.US.TYAM21 to ZNM21. Service code: cbot | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.TYAM21 (ZNM21). ID: 501 Service code: cbot | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.TYAM21. ID: 75352 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.TYAM21 (ZNM21). ID: 501 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.HOEK21 | 2021-06-18 08:57:57.796
Mapping F.US.HOEK21 to HOK21. Service code: nymex | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.HOEK21 (HOK21). ID: 502 Service code: nymex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.HOEK21. ID: 75353 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.HOEK21 (HOK21). ID: 502 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.RBEM21 | 2021-06-18 08:57:57.796
Mapping F.US.RBEM21 to RBM21. Service code: nymex | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.RBEM21 (RBM21). ID: 503 Service code: nymex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.RBEM21. ID: 75354 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.RBEM21 (RBM21). ID: 503 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.ZSEQ21 | 2021-06-18 08:57:57.796
Mapping F.US.ZSEQ21 to ZSQ21. Service code: cbot | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEQ21 (ZSQ21). ID: 504 Service code: cbot | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.ZSEQ21. ID: 75355 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.ZSEQ21 (ZSQ21). ID: 504 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.CPEN21 | 2021-06-18 08:57:57.796
Mapping F.US.CPEN21 to HGN21. Service code: comex | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.CPEN21 (HGN21). ID: 505 Service code: comex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.CPEN21. ID: 75356 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.CPEN21 (HGN21). ID: 505 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.ZWAN21 | 2021-06-18 08:57:57.796
Mapping F.US.ZWAN21 to ZWN21. Service code: cbot | 2021-06-18 08:57:57.796
Mapping F.US.ZWAU21 to ZWU21. Service code: cbot | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAU21 (ZWU21). ID: 507 Service code: cbot | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.ZWAU21. ID: 75357 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.ZWAU21 (ZWU21). ID: 507 | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAN21 (ZWN21). ID: 506 Service code: cbot | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.ZWAN21. ID: 75358 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.ZWAN21 (ZWN21). ID: 506 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.KWEN21 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.DLH21 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.NGEJ21 | 2021-06-18 08:57:57.796
Mapping F.US.NGEJ21 to NGJ21. Service code: nymex | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.NGEJ21 (NGJ21). ID: 508 Service code: nymex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.NGEJ21. ID: 75359 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.NGEJ21 (NGJ21). ID: 508 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.SF6H21 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.MGCJ21 | 2021-06-18 08:57:57.796
Mapping F.US.MGCJ21 to MGCJ21. Service code: comex | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.MGCJ21 (MGCJ21). ID: 509 Service code: comex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.MGCJ21. ID: 75360 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.MGCJ21 (MGCJ21). ID: 509 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.TNAM21 | 2021-06-18 08:57:57.796
Mapping F.US.TNAM21 to TNM21. Service code: cbot | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.TNAM21 (TNM21). ID: 510 Service code: cbot | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.TNAM21. ID: 75361 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.TNAM21 (TNM21). ID: 510 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.PLEN21 | 2021-06-18 08:57:57.796
Mapping F.US.PLEN21 to PLN21. Service code: nymex | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.PLEN21 (PLN21). ID: 511 Service code: nymex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.PLEN21. ID: 75362 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.PLEN21 (PLN21). ID: 511 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.GCEM21 | 2021-06-18 08:57:57.796
Mapping F.US.GCEM21 to GCM21. Service code: comex | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.GCEM21 (GCM21). ID: 512 Service code: comex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.GCEM21. ID: 75363 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.GCEM21 (GCM21). ID: 512 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.PLEJ21 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.NGEN21 | 2021-06-18 08:57:57.796
Mapping F.US.NGEN21 to NGN21. Service code: nymex | 2021-06-18 08:57:57.796
Mapping F.US.NGEQ21 to NGQ21. Service code: nymex | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.NGEQ21 (NGQ21). ID: 514 Service code: nymex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.NGEQ21. ID: 75364 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.NGEQ21 (NGQ21). ID: 514 | 2021-06-18 08:57:57.796
SC Data - All Services | Starting real-time market data updates for: F.US.NGEN21 (NGN21). ID: 513 Service code: nymex | 2021-06-18 08:57:57.796
CQG WebAPI | Sending symbol resolution request for F.US.NGEN21. ID: 75365 | 2021-06-18 08:57:57.796
SC Data - All Services | Requesting security definition data for: F.US.NGEN21 (NGN21). ID: 513 | 2021-06-18 08:57:57.796
Subscribing to symbol for symbol alert. F.US.NGEM21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.ZCEN21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.DSXH21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.NE6H21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.SF6M21 | 2021-06-18 08:57:57.797
Mapping F.US.SF6M21 to 6SM21. Service code: cme | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.SF6M21 (6SM21). ID: 515 Service code: cme | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.SF6M21. ID: 75366 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.SF6M21 (6SM21). ID: 515 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.ZMEN21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.DLM21 | 2021-06-18 08:57:57.797
Mapping F.US.DLM21 to FGBM202106_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.DLM21 (FGBM202106_FUT_EUREX). ID: 516 Service code: eurex | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.DLM21. ID: 75367 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.DLM21 (FGBM202106_FUT_EUREX). ID: 516 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.KWEK21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.ZCEU21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.ZSEK21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.CLEM21 | 2021-06-18 08:57:57.797
Mapping F.US.CLEM21 to CLM21. Service code: nymex | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.CLEM21 (CLM21). ID: 517 Service code: nymex | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.CLEM21. ID: 75368 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.CLEM21 (CLM21). ID: 517 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.TYAM21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.DA6M21 | 2021-06-18 08:57:57.797
Mapping F.US.DA6M21 to 6AM21. Service code: cme | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.DA6M21 (6AM21). ID: 518 Service code: cme | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.DA6M21. ID: 75369 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.DA6M21 (6AM21). ID: 518 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.ZWAN21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.DBM21 | 2021-06-18 08:57:57.797
Mapping F.US.DBM21 to FGBL202106_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.DBM21 (FGBL202106_FUT_EUREX). ID: 519 Service code: eurex | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.DBM21. ID: 75370 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.DBM21 (FGBL202106_FUT_EUREX). ID: 519 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.ZLEK21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.ZCEK21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.USAM21 | 2021-06-18 08:57:57.797
Mapping F.US.USAM21 to ZBM21. Service code: cbot | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.USAM21 (ZBM21). ID: 520 Service code: cbot | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.USAM21. ID: 75371 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.USAM21 (ZBM21). ID: 520 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.YMM21 | 2021-06-18 08:57:57.797
Mapping F.US.YMM21 to YMM21. Service code: cbot | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.YMM21 (YMM21). ID: 521 Service code: cbot | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.YMM21. ID: 75372 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.YMM21 (YMM21). ID: 521 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.TNAM21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.DSXM21 | 2021-06-18 08:57:57.797
Mapping F.US.DSXM21 to FESX202106_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.797
Mapping F.US.DSXU21 to FESX202109_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.DSXU21 (FESX202109_FUT_EUREX). ID: 523 Service code: eurex | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.DSXU21. ID: 75373 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.DSXU21 (FESX202109_FUT_EUREX). ID: 523 | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.DSXM21 (FESX202106_FUT_EUREX). ID: 522 Service code: eurex | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.DSXM21. ID: 75374 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.DSXM21 (FESX202106_FUT_EUREX). ID: 522 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.FVAM21 | 2021-06-18 08:57:57.797
Mapping F.US.FVAM21 to ZFM21. Service code: cbot | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.FVAM21 (ZFM21). ID: 524 Service code: cbot | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.FVAM21. ID: 75375 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.FVAM21 (ZFM21). ID: 524 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.HOEK21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.KWEU21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.HEQ21 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.ZWAK21 | 2021-06-18 08:57:57.797
Mapping F.US.ZWAK21 to ZWK21. Service code: cbot | 2021-06-18 08:57:57.797
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAK21 (ZWK21). ID: 525 Service code: cbot | 2021-06-18 08:57:57.797
CQG WebAPI | Sending symbol resolution request for F.US.ZWAK21. ID: 75376 | 2021-06-18 08:57:57.797
SC Data - All Services | Requesting security definition data for: F.US.ZWAK21 (ZWK21). ID: 525 | 2021-06-18 08:57:57.797
Subscribing to symbol for symbol alert. F.US.DSXM21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.SF6M21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.TYAM21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.KWEK21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.TNAM21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.FVAM21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ZCEN21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ZWAK21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ZSEQ21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.EU6M21 | 2021-06-18 08:57:57.798
Mapping F.US.EU6M21 to 6EM21. Service code: cme | 2021-06-18 08:57:57.798
SC Data - All Services | Starting real-time market data updates for: F.US.EU6M21 (6EM21). ID: 526 Service code: cme | 2021-06-18 08:57:57.798
CQG WebAPI | Sending symbol resolution request for F.US.EU6M21. ID: 75377 | 2021-06-18 08:57:57.798
SC Data - All Services | Requesting security definition data for: F.US.EU6M21 (6EM21). ID: 526 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.KWEN21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.DDM21 | 2021-06-18 08:57:57.798
Mapping F.US.DDM21 to FDAX202106_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.798
Mapping F.US.DDU21 to FDAX202109_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.798
SC Data - All Services | Starting real-time market data updates for: F.US.DDU21 (FDAX202109_FUT_EUREX). ID: 528 Service code: eurex | 2021-06-18 08:57:57.798
CQG WebAPI | Sending symbol resolution request for F.US.DDU21. ID: 75378 | 2021-06-18 08:57:57.798
SC Data - All Services | Requesting security definition data for: F.US.DDU21 (FDAX202109_FUT_EUREX). ID: 528 | 2021-06-18 08:57:57.798
SC Data - All Services | Starting real-time market data updates for: F.US.DDM21 (FDAX202106_FUT_EUREX). ID: 527 Service code: eurex | 2021-06-18 08:57:57.798
CQG WebAPI | Sending symbol resolution request for F.US.DDM21. ID: 75379 | 2021-06-18 08:57:57.798
SC Data - All Services | Requesting security definition data for: F.US.DDM21 (FDAX202106_FUT_EUREX). ID: 527 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.NGEK21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.HOEK21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ZCEZ21 | 2021-06-18 08:57:57.798
Mapping F.US.ZCEZ21 to ZCZ21. Service code: cbot | 2021-06-18 08:57:57.798
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEZ21 (ZCZ21). ID: 529 Service code: cbot | 2021-06-18 08:57:57.798
CQG WebAPI | Sending symbol resolution request for F.US.ZCEZ21. ID: 75380 | 2021-06-18 08:57:57.798
SC Data - All Services | Requesting security definition data for: F.US.ZCEZ21 (ZCZ21). ID: 529 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ZSEU21 | 2021-06-18 08:57:57.798
Mapping F.US.ZSEU21 to ZSU21. Service code: cbot | 2021-06-18 08:57:57.798
SC Data - All Services | Starting real-time market data updates for: F.US.ZSEU21 (ZSU21). ID: 530 Service code: cbot | 2021-06-18 08:57:57.798
CQG WebAPI | Sending symbol resolution request for F.US.ZSEU21. ID: 75381 | 2021-06-18 08:57:57.798
SC Data - All Services | Requesting security definition data for: F.US.ZSEU21 (ZSU21). ID: 530 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ZSEK21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.DLM21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.DBM21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ZSEN21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.PLEN21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ZLEN21 | 2021-06-18 08:57:57.798
Mapping F.US.ZLEN21 to ZLN21. Service code: cbot | 2021-06-18 08:57:57.798
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEN21 (ZLN21). ID: 531 Service code: cbot | 2021-06-18 08:57:57.798
CQG WebAPI | Sending symbol resolution request for F.US.ZLEN21. ID: 75382 | 2021-06-18 08:57:57.798
SC Data - All Services | Requesting security definition data for: F.US.ZLEN21 (ZLN21). ID: 531 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ULAM21 | 2021-06-18 08:57:57.798
Mapping F.US.ULAM21 to UBM21. Service code: cbot | 2021-06-18 08:57:57.798
SC Data - All Services | Starting real-time market data updates for: F.US.ULAM21 (UBM21). ID: 532 Service code: cbot | 2021-06-18 08:57:57.798
CQG WebAPI | Sending symbol resolution request for F.US.ULAM21. ID: 75383 | 2021-06-18 08:57:57.798
SC Data - All Services | Requesting security definition data for: F.US.ULAM21 (UBM21). ID: 532 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.HEQ21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.ZCEK21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.KWEU21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.BP6M21 | 2021-06-18 08:57:57.798
Mapping F.US.BP6M21 to 6BM21. Service code: cme | 2021-06-18 08:57:57.798
SC Data - All Services | Starting real-time market data updates for: F.US.BP6M21 (6BM21). ID: 533 Service code: cme | 2021-06-18 08:57:57.798
CQG WebAPI | Sending symbol resolution request for F.US.BP6M21. ID: 75384 | 2021-06-18 08:57:57.798
SC Data - All Services | Requesting security definition data for: F.US.BP6M21 (6BM21). ID: 533 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.RBEK21 | 2021-06-18 08:57:57.798
Subscribing to symbol for symbol alert. F.US.GCEM21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.SIEK21 | 2021-06-18 08:57:57.799
Mapping F.US.SIEK21 to SIK21. Service code: comex | 2021-06-18 08:57:57.799
SC Data - All Services | Starting real-time market data updates for: F.US.SIEK21 (SIK21). ID: 534 Service code: comex | 2021-06-18 08:57:57.799
CQG WebAPI | Sending symbol resolution request for F.US.SIEK21. ID: 75385 | 2021-06-18 08:57:57.799
SC Data - All Services | Requesting security definition data for: F.US.SIEK21 (SIK21). ID: 534 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.ZCEU21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.NGEQ21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.RBEK21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.ZCEZ21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.BP6M21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.TYAM21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.DSXM21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.TNAM21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.DDM21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.EU6M21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.HOEM21 | 2021-06-18 08:57:57.799
Mapping F.US.HOEM21 to HOM21. Service code: nymex | 2021-06-18 08:57:57.799
SC Data - All Services | Starting real-time market data updates for: F.US.HOEM21 (HOM21). ID: 535 Service code: nymex | 2021-06-18 08:57:57.799
CQG WebAPI | Sending symbol resolution request for F.US.HOEM21. ID: 75386 | 2021-06-18 08:57:57.799
SC Data - All Services | Requesting security definition data for: F.US.HOEM21 (HOM21). ID: 535 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.CA6M21 | 2021-06-18 08:57:57.799
Mapping F.US.CA6M21 to 6CM21. Service code: cme | 2021-06-18 08:57:57.799
SC Data - All Services | Starting real-time market data updates for: F.US.CA6M21 (6CM21). ID: 536 Service code: cme | 2021-06-18 08:57:57.799
CQG WebAPI | Sending symbol resolution request for F.US.CA6M21. ID: 75387 | 2021-06-18 08:57:57.799
SC Data - All Services | Requesting security definition data for: F.US.CA6M21 (6CM21). ID: 536 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.DBM21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.CLEM21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.ZWAK21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.ZWAN21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.NE6M21 | 2021-06-18 08:57:57.799
Mapping F.US.NE6M21 to 6NM21. Service code: cme | 2021-06-18 08:57:57.799
SC Data - All Services | Starting real-time market data updates for: F.US.NE6M21 (6NM21). ID: 537 Service code: cme | 2021-06-18 08:57:57.799
CQG WebAPI | Sending symbol resolution request for F.US.NE6M21. ID: 75388 | 2021-06-18 08:57:57.799
SC Data - All Services | Requesting security definition data for: F.US.NE6M21 (6NM21). ID: 537 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.ZCEK21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.ZWAU21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.FVAM21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.KWEN21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.CPEN21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.ZLEU21 | 2021-06-18 08:57:57.799
Mapping F.US.ZLEU21 to ZLU21. Service code: cbot | 2021-06-18 08:57:57.799
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEU21 (ZLU21). ID: 538 Service code: cbot | 2021-06-18 08:57:57.799
CQG WebAPI | Sending symbol resolution request for F.US.ZLEU21. ID: 75389 | 2021-06-18 08:57:57.799
SC Data - All Services | Requesting security definition data for: F.US.ZLEU21 (ZLU21). ID: 538 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.RBEM21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.SIEN21 | 2021-06-18 08:57:57.799
Mapping F.US.SIEN21 to SIN21. Service code: comex | 2021-06-18 08:57:57.799
SC Data - All Services | Starting real-time market data updates for: F.US.SIEN21 (SIN21). ID: 539 Service code: comex | 2021-06-18 08:57:57.799
CQG WebAPI | Sending symbol resolution request for F.US.SIEN21. ID: 75390 | 2021-06-18 08:57:57.799
SC Data - All Services | Requesting security definition data for: F.US.SIEN21 (SIN21). ID: 539 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.PLEN21 | 2021-06-18 08:57:57.799
Subscribing to symbol for symbol alert. F.US.DDM21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.ZWAN21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.DSXM21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.ZWAU21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.NGEU21 | 2021-06-18 08:57:57.800
Mapping F.US.NGEU21 to NGU21. Service code: nymex | 2021-06-18 08:57:57.800
SC Data - All Services | Starting real-time market data updates for: F.US.NGEU21 (NGU21). ID: 540 Service code: nymex | 2021-06-18 08:57:57.800
CQG WebAPI | Sending symbol resolution request for F.US.NGEU21. ID: 75391 | 2021-06-18 08:57:57.800
SC Data - All Services | Requesting security definition data for: F.US.NGEU21 (NGU21). ID: 540 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.ZSEX21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.TNAM21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.TYAM21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.PLEN21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.ZMEN21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.HOEN21 | 2021-06-18 08:57:57.800
Mapping F.US.HOEN21 to HON21. Service code: nymex | 2021-06-18 08:57:57.800
Mapping F.US.HOEQ21 to HOQ21. Service code: nymex | 2021-06-18 08:57:57.800
SC Data - All Services | Starting real-time market data updates for: F.US.HOEQ21 (HOQ21). ID: 542 Service code: nymex | 2021-06-18 08:57:57.800
CQG WebAPI | Sending symbol resolution request for F.US.HOEQ21. ID: 75392 | 2021-06-18 08:57:57.800
SC Data - All Services | Requesting security definition data for: F.US.HOEQ21 (HOQ21). ID: 542 | 2021-06-18 08:57:57.800
SC Data - All Services | Starting real-time market data updates for: F.US.HOEN21 (HON21). ID: 541 Service code: nymex | 2021-06-18 08:57:57.800
CQG WebAPI | Sending symbol resolution request for F.US.HOEN21. ID: 75393 | 2021-06-18 08:57:57.800
SC Data - All Services | Requesting security definition data for: F.US.HOEN21 (HON21). ID: 541 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.NGEN21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.DLM21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.RBEN21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.EU6M21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.CPEN21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.ZSEQ21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.CA6M21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.ZCEN21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.YMM21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.ZLEQ21 | 2021-06-18 08:57:57.800
Mapping F.US.ZLEQ21 to ZLQ21. Service code: cbot | 2021-06-18 08:57:57.800
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEQ21 (ZLQ21). ID: 543 Service code: cbot | 2021-06-18 08:57:57.800
CQG WebAPI | Sending symbol resolution request for F.US.ZLEQ21. ID: 75394 | 2021-06-18 08:57:57.800
SC Data - All Services | Requesting security definition data for: F.US.ZLEQ21 (ZLQ21). ID: 543 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.ZMEQ21 | 2021-06-18 08:57:57.800
Mapping F.US.ZMEQ21 to ZMQ21. Service code: cbot | 2021-06-18 08:57:57.800
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEQ21 (ZMQ21). ID: 544 Service code: cbot | 2021-06-18 08:57:57.800
CQG WebAPI | Sending symbol resolution request for F.US.ZMEQ21. ID: 75395 | 2021-06-18 08:57:57.800
SC Data - All Services | Requesting security definition data for: F.US.ZMEQ21 (ZMQ21). ID: 544 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.GCEM21 | 2021-06-18 08:57:57.800
Subscribing to symbol for symbol alert. F.US.DSXM21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.DDM21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.TYAM21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.DLM21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.DA6M21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.NGEM21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.RBEN21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.GCEM21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.ZSEU21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.BP6M21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.CA6M21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.CPEN21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.ZLEU21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.ZSEN21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.SF6M21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.USAM21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.ZCEN21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.PLEN21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.YMM21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.TNAM21 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. GBPCAD | 2021-06-18 08:57:57.801
Using Bid/Ask average for last trade price for GBPCAD | 2021-06-18 08:57:57.801
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPCAD. ID: 545 Service code: fxcm | 2021-06-18 08:57:57.801
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2021-06-18 08:57:57.801
SC DTC Data with Market Depth | Requesting security definition data for: GBPCAD. ID: 545 | 2021-06-18 08:57:57.801
Subscribing to symbol for symbol alert. F.US.FBTPM21 | 2021-06-18 08:57:57.801
Mapping F.US.FBTPM21 to FBTP202106_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:57.801
SC Data - All Services | Starting real-time market data updates for: F.US.FBTPM21 (FBTP202106_FUT_EUREX). ID: 546 Service code: eurex | 2021-06-18 08:57:57.802
CQG WebAPI | Sending symbol resolution request for F.US.FBTPM21. ID: 75396 | 2021-06-18 08:57:57.802
SC Data - All Services | Requesting security definition data for: F.US.FBTPM21 (FBTP202106_FUT_EUREX). ID: 546 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.CA6M21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.BP6M21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.NGEN21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.DLM21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.ZLEN21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.USAM21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.KWEU21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.SF6M21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.CPEN21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.EPM21 | 2021-06-18 08:57:57.802
Mapping F.US.EPM21 to ESM21. Service code: cme | 2021-06-18 08:57:57.802
DTC Client socket (14) | Creating socket. | 2021-06-18 08:57:57.802
SC Data - All Services | Starting real-time market data updates for: F.US.EPM21 (ESM21). ID: 547 Service code: cme | 2021-06-18 08:57:57.802
CQG WebAPI | Sending symbol resolution request for F.US.EPM21. ID: 75397 | 2021-06-18 08:57:57.802
SC Data - All Services | Requesting security definition data for: F.US.EPM21 (ESM21). ID: 547 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.DSXM21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.ZMEN21 | 2021-06-18 08:57:57.802
DTC Client socket (14) | New receive buffer size: 5242880 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.DDM21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.TNAM21 | 2021-06-18 08:57:57.802
DTC Client socket (14) | Connecting to IP: 192.81.56.146. | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.TYAM21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.ZCEN21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.CLEN21 | 2021-06-18 08:57:57.802
Mapping F.US.CLEN21 to CLN21. Service code: nymex | 2021-06-18 08:57:57.802
Mapping F.US.CLEQ21 to CLQ21. Service code: nymex | 2021-06-18 08:57:57.802
SC Data - All Services | Starting real-time market data updates for: F.US.CLEQ21 (CLQ21). ID: 549 Service code: nymex | 2021-06-18 08:57:57.802
CQG WebAPI | Sending symbol resolution request for F.US.CLEQ21. ID: 75398 | 2021-06-18 08:57:57.802
SC Data - All Services | Requesting security definition data for: F.US.CLEQ21 (CLQ21). ID: 549 | 2021-06-18 08:57:57.802
SC Data - All Services | Starting real-time market data updates for: F.US.CLEN21 (CLN21). ID: 548 Service code: nymex | 2021-06-18 08:57:57.802
CQG WebAPI | Sending symbol resolution request for F.US.CLEN21. ID: 75399 | 2021-06-18 08:57:57.802
SC Data - All Services | Requesting security definition data for: F.US.CLEN21 (CLN21). ID: 548 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.NE6M21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.TYAU21 | 2021-06-18 08:57:57.802
Mapping F.US.TYAU21 to ZNU21. Service code: cbot | 2021-06-18 08:57:57.802
SC Data - All Services | Starting real-time market data updates for: F.US.TYAU21 (ZNU21). ID: 550 Service code: cbot | 2021-06-18 08:57:57.802
CQG WebAPI | Sending symbol resolution request for F.US.TYAU21. ID: 75400 | 2021-06-18 08:57:57.802
SC Data - All Services | Requesting security definition data for: F.US.TYAU21 (ZNU21). ID: 550 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.HOEV21 | 2021-06-18 08:57:57.802
Mapping F.US.HOEV21 to HOV21. Service code: nymex | 2021-06-18 08:57:57.802
SC Data - All Services | Starting real-time market data updates for: F.US.HOEV21 (HOV21). ID: 551 Service code: nymex | 2021-06-18 08:57:57.802
CQG WebAPI | Sending symbol resolution request for F.US.HOEV21. ID: 75401 | 2021-06-18 08:57:57.802
SC Data - All Services | Requesting security definition data for: F.US.HOEV21 (HOV21). ID: 551 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.ZSEU21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.SF6U21 | 2021-06-18 08:57:57.802
Mapping F.US.SF6U21 to 6SU21. Service code: cme | 2021-06-18 08:57:57.802
SC Data - All Services | Starting real-time market data updates for: F.US.SF6U21 (6SU21). ID: 552 Service code: cme | 2021-06-18 08:57:57.802
CQG WebAPI | Sending symbol resolution request for F.US.SF6U21. ID: 75402 | 2021-06-18 08:57:57.802
SC Data - All Services | Requesting security definition data for: F.US.SF6U21 (6SU21). ID: 552 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.ZLEQ21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.HEQ21 | 2021-06-18 08:57:57.802
Subscribing to symbol for symbol alert. F.US.BP6U21 | 2021-06-18 08:57:57.802
Mapping F.US.BP6U21 to 6BU21. Service code: cme | 2021-06-18 08:57:57.802
SC Data - All Services | Starting real-time market data updates for: F.US.BP6U21 (6BU21). ID: 553 Service code: cme | 2021-06-18 08:57:57.803
CQG WebAPI | Sending symbol resolution request for F.US.BP6U21. ID: 75403 | 2021-06-18 08:57:57.803
SC Data - All Services | Requesting security definition data for: F.US.BP6U21 (6BU21). ID: 553 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.DSXM21 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.DDM21 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.TNAU21 | 2021-06-18 08:57:57.803
Mapping F.US.TNAU21 to TNU21. Service code: cbot | 2021-06-18 08:57:57.803
SC Data - All Services | Starting real-time market data updates for: F.US.TNAU21 (TNU21). ID: 554 Service code: cbot | 2021-06-18 08:57:57.803
CQG WebAPI | Sending symbol resolution request for F.US.TNAU21. ID: 75404 | 2021-06-18 08:57:57.803
SC Data - All Services | Requesting security definition data for: F.US.TNAU21 (TNU21). ID: 554 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.TYAU21 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.DSXU21 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.CPEN21 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.FVAU21 | 2021-06-18 08:57:57.803
Mapping F.US.FVAU21 to ZFU21. Service code: cbot | 2021-06-18 08:57:57.803
SC Data - All Services | Starting real-time market data updates for: F.US.FVAU21 (ZFU21). ID: 555 Service code: cbot | 2021-06-18 08:57:57.803
CQG WebAPI | Sending symbol resolution request for F.US.FVAU21. ID: 75405 | 2021-06-18 08:57:57.803
SC Data - All Services | Requesting security definition data for: F.US.FVAU21 (ZFU21). ID: 555 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.ZSEU21 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.CA6U21 | 2021-06-18 08:57:57.803
Mapping F.US.CA6U21 to 6CU21. Service code: cme | 2021-06-18 08:57:57.803
SC Data - All Services | Starting real-time market data updates for: F.US.CA6U21 (6CU21). ID: 556 Service code: cme | 2021-06-18 08:57:57.803
CQG WebAPI | Sending symbol resolution request for F.US.CA6U21. ID: 75406 | 2021-06-18 08:57:57.803
SC Data - All Services | Requesting security definition data for: F.US.CA6U21 (6CU21). ID: 556 | 2021-06-18 08:57:57.803
Subscribing to symbol for symbol alert. F.US.DDU21 | 2021-06-18 08:57:57.803
Updated verified funded futures trading account ending date to: 2021-07-18 06:57:57 | 2021-06-18 08:57:57.803
CQG WebAPI | Sending Trade Accounts request message. | 2021-06-18 08:57:57.836
No download requests in the queue to start downloads for. | 2021-06-18 08:57:57.836
SC Data - All Services | Network connection to server complete. | 2021-06-18 08:57:57.836
SC Data - All Services | Starting socket receive thread. | 2021-06-18 08:57:57.836
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-18 08:57:57.836
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.837
Symbol Error - F.US.DSXH18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.837
SC Data - All Services | Network connection to server complete. | 2021-06-18 08:57:57.837
SC Data - All Services | Starting socket receive thread. | 2021-06-18 08:57:57.837
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-18 08:57:57.837
Symbol Error - F.US.DLM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.837
Symbol Error - F.US.TYAM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.837
Added historical Intraday data request for F.US.CA6U21 to the queue. | 2021-06-18 08:57:57.838
Intraday data recording state for symbol F.US.CA6U21 is set to download 'Pending'. | 2021-06-18 08:57:57.838
Triggering next historical data download in queue. | 2021-06-18 08:57:57.839
Delaying start of download for F.US.CA6U21 | 2021-06-18 08:57:57.839
Mapping F.US.RBEV21 to RBV21. Service code: nymex | 2021-06-18 08:57:57.839
SC Data - All Services | Starting real-time market data updates for: F.US.RBEV21 (RBV21). ID: 557 Service code: nymex | 2021-06-18 08:57:57.839
CQG WebAPI | Sending symbol resolution request for F.US.RBEV21. ID: 75408 | 2021-06-18 08:57:57.839
SC Data - All Services | Requesting security definition data for: F.US.RBEV21 (RBV21). ID: 557 | 2021-06-18 08:57:57.839
Requesting market depth updates for: F.US.TNAU21 if supported. | 2021-06-18 08:57:57.840
Separate subscription for market depth updates not supported. F.US.TNAU21 | 2021-06-18 08:57:57.840
Added historical Intraday data request for F.US.TNAU21 to the queue. | 2021-06-18 08:57:57.840
Intraday data recording state for symbol F.US.TNAU21 is set to download 'Pending'. | 2021-06-18 08:57:57.840
Triggering next historical data download in queue. | 2021-06-18 08:57:57.840
Requesting market depth updates for: F.US.DSXU21 if supported. | 2021-06-18 08:57:57.842
Separate subscription for market depth updates not supported. F.US.DSXU21 | 2021-06-18 08:57:57.842
Added historical Intraday data request for F.US.DSXU21 to the queue. | 2021-06-18 08:57:57.842
Intraday data recording state for symbol F.US.DSXU21 is set to download 'Pending'. | 2021-06-18 08:57:57.842
Triggering next historical data download in queue. | 2021-06-18 08:57:57.842
CQG WebAPI | Received symbol resolution report for symbol F.US.ZCEN21. Search Symbol: F.US.ZCEN21. Request ID: 75262. Contract ID: 1. | 2021-06-18 08:57:57.879
CQG WebAPI | Brokerage name: AMP. Account Name: 112374 | 2021-06-18 08:57:57.879
CQG WebAPI | Sending collateral subscribe request. | 2021-06-18 08:57:57.879
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-18 08:57:57.879
SC Data - All Services | Sending logon request message. | 2021-06-18 08:57:57.879
CQG WebAPI | Received symbol resolution report for symbol F.US.ZMEN21. Search Symbol: F.US.ZMEN21. Request ID: 75281. Contract ID: 2. | 2021-06-18 08:57:57.880
CQG WebAPI | Received symbol resolution report for symbol F.US.HEQ21. Search Symbol: F.US.HEQ21. Request ID: 75289. Contract ID: 3. | 2021-06-18 08:57:57.898
CQG WebAPI | Received symbol resolution report for symbol F.US.KWEN21. Search Symbol: F.US.KWEN21. Request ID: 75295. Contract ID: 4. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.KWEU21. Search Symbol: F.US.KWEU21. Request ID: 75297. Contract ID: 5. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.ZCEU21. Search Symbol: F.US.ZCEU21. Request ID: 75310. Contract ID: 6. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.ZSEN21. Search Symbol: F.US.ZSEN21. Request ID: 75311. Contract ID: 7. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.GFQ21. Search Symbol: F.US.GFQ21. Request ID: 75323. Contract ID: 8. | 2021-06-18 08:57:57.925
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.925
Symbol Error - F.US.GCEJ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.925
Symbol Error - F.US.DSXM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.925
Symbol Error - F.US.DBM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.925
Symbol Error - F.US.GCEM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.GLEQ21. Search Symbol: F.US.GLEQ21. Request ID: 75338. Contract ID: 9. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.GLEM21. Search Symbol: F.US.GLEM21. Request ID: 75339. Contract ID: 10. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.RBEQ21. Search Symbol: F.US.RBEQ21. Request ID: 75346. Contract ID: 11. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.RBEN21. Search Symbol: F.US.RBEN21. Request ID: 75347. Contract ID: 12. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.ZSEX21. Search Symbol: F.US.ZSEX21. Request ID: 75348. Contract ID: 13. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.TYAM21. Search Symbol: F.US.TYAM21. Request ID: 75352. Contract ID: 14. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.ZSEQ21. Search Symbol: F.US.ZSEQ21. Request ID: 75355. Contract ID: 15. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.CPEN21. Search Symbol: F.US.CPEN21. Request ID: 75356. Contract ID: 16. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.ZWAU21. Search Symbol: F.US.ZWAU21. Request ID: 75357. Contract ID: 17. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.ZWAN21. Search Symbol: F.US.ZWAN21. Request ID: 75358. Contract ID: 18. | 2021-06-18 08:57:57.925
Symbol Error - F.US.EPM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.925
Symbol Error - F.US.TNAM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.925
Symbol Error - F.US.ZWAN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.TNAM21. Search Symbol: F.US.TNAM21. Request ID: 75361. Contract ID: 19. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.PLEN21. Search Symbol: F.US.PLEN21. Request ID: 75362. Contract ID: 20. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.GCEM21. Search Symbol: F.US.GCEM21. Request ID: 75363. Contract ID: 21. | 2021-06-18 08:57:57.925
CQG WebAPI | Received symbol resolution report for symbol F.US.NGEQ21. Search Symbol: F.US.NGEQ21. Request ID: 75364. Contract ID: 22. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.NGEN21. Search Symbol: F.US.NGEN21. Request ID: 75365. Contract ID: 23. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.USAM21. Search Symbol: F.US.USAM21. Request ID: 75371. Contract ID: 24. | 2021-06-18 08:57:57.926
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.926
Symbol Error - F.US.DDM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.YMM21. Search Symbol: F.US.YMM21. Request ID: 75372. Contract ID: 25. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.DSXU21. Search Symbol: F.US.DSXU21. Request ID: 75373. Contract ID: 26. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.DSXM21. Search Symbol: F.US.DSXM21. Request ID: 75374. Contract ID: 27. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.FVAM21. Search Symbol: F.US.FVAM21. Request ID: 75375. Contract ID: 28. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.DDU21. Search Symbol: F.US.DDU21. Request ID: 75378. Contract ID: 29. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.DDM21. Search Symbol: F.US.DDM21. Request ID: 75379. Contract ID: 30. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.ZCEZ21. Search Symbol: F.US.ZCEZ21. Request ID: 75380. Contract ID: 31. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.ZSEU21. Search Symbol: F.US.ZSEU21. Request ID: 75381. Contract ID: 32. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.ZLEN21. Search Symbol: F.US.ZLEN21. Request ID: 75382. Contract ID: 33. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.ULAM21. Search Symbol: F.US.ULAM21. Request ID: 75383. Contract ID: 34. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.ZLEU21. Search Symbol: F.US.ZLEU21. Request ID: 75389. Contract ID: 35. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.SIEN21. Search Symbol: F.US.SIEN21. Request ID: 75390. Contract ID: 36. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.NGEU21. Search Symbol: F.US.NGEU21. Request ID: 75391. Contract ID: 37. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.HOEQ21. Search Symbol: F.US.HOEQ21. Request ID: 75392. Contract ID: 38. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.HOEN21. Search Symbol: F.US.HOEN21. Request ID: 75393. Contract ID: 39. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.ZLEQ21. Search Symbol: F.US.ZLEQ21. Request ID: 75394. Contract ID: 40. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.ZMEQ21. Search Symbol: F.US.ZMEQ21. Request ID: 75395. Contract ID: 41. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.EPM21. Search Symbol: F.US.EPM21. Request ID: 75397. Contract ID: 42. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.CLEQ21. Search Symbol: F.US.CLEQ21. Request ID: 75398. Contract ID: 43. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.CLEN21. Search Symbol: F.US.CLEN21. Request ID: 75399. Contract ID: 44. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.TYAU21. Search Symbol: F.US.TYAU21. Request ID: 75400. Contract ID: 45. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.HOEV21. Search Symbol: F.US.HOEV21. Request ID: 75401. Contract ID: 46. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.SF6U21. Search Symbol: F.US.SF6U21. Request ID: 75402. Contract ID: 47. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.BP6U21. Search Symbol: F.US.BP6U21. Request ID: 75403. Contract ID: 48. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.TNAU21. Search Symbol: F.US.TNAU21. Request ID: 75404. Contract ID: 49. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.FVAU21. Search Symbol: F.US.FVAU21. Request ID: 75405. Contract ID: 50. | 2021-06-18 08:57:57.926
CQG WebAPI | Received symbol resolution report for symbol F.US.CA6U21. Search Symbol: F.US.CA6U21. Request ID: 75406. Contract ID: 51. | 2021-06-18 08:57:57.926
Symbol Error - F.US.ZLEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.926
Symbol Error - F.US.USAM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.926
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.HEV18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.KCEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.YMM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.CLEM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.ZMEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.CCEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.ENQM18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.CTEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.GCEQ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.TNAU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.CLEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
CQG WebAPI | Received symbol resolution report for symbol F.US.RBEV21. Search Symbol: F.US.RBEV21. Request ID: 75408. Contract ID: 52. | 2021-06-18 08:57:57.931
Symbol Error - F.US.CPEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.DLU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.931
Symbol Error - F.US.DBU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.EPU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.KCEU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZSEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZCEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.SIEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.SBEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.XWN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.DSXU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.YMU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.HEN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.CLEQ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.GFQ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZWAU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZLEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.DDU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.HEQ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZSEQ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZSEX18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.XCN18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.CPEU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ENQU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.SIEU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.TYAU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZCEU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.KCEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.GCEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.SBEV18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.CTEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.RBEU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.GFV18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.BP6U18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.FVAU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ULAU18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.SBEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.PAEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.SIEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.CLEF19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.HOEV18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.DLZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.DBZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.DSXZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.CLEX18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.HEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.DA6U18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.KWEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.CPEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.HOEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.DA6Z18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZLEF19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.FVAZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.EPZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.USAZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.M6AZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.CLEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.GLEG19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.TYAZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.TNAZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.GCEG19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ULAZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.PLEF19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.JY6Z18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.KCEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.TUAZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.KWEK19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZCEK19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZSEK19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.RBEX18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.M6EZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.CPEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZMEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.EU6Z18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.ZCEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.NGEF19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.GFX18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.SF6Z18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.GLEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.FBTPZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.BP6Z18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.CA6Z18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
Symbol Error - F.US.RBEG19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.932
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.HEG19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.NE6Z18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.YMZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.ZLEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.ZCEZ18 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.USAH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.ULAH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.FVAH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.DBH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.FBTPH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.TYAH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.ZCEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.GFJ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.GLEJ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.HEJ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.DLH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.SF6H19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.EPH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.KWEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.DSXH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.TUAH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.TNAH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.OJEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.CA6H19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.FBTSH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.ENQH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.CLEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.FOATH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.YMH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.DDH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.GCEJ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.PLEJ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.ZLEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.DA6H19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.HEM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.HOEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.CPEK19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.SIEH19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.EU6H19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.HOEJ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.CLEM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.HEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.BP6H19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.TYAM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.HOEM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.FVAM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.USAM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.ULAM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.GLEM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.EPM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.DBM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.DLM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.TUAM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.ZSEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.DSXM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.CLEK19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.EU6M19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.TNAM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
Symbol Error - F.US.DA6M19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.933
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.944
Symbol Error - F.US.BP6M19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.944
Symbol Error - F.US.FDXMM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.944
SC DTC Data with Market Depth | Network connection to server complete. | 2021-06-18 08:57:57.944
SC DTC Data with Market Depth | Starting socket receive thread. | 2021-06-18 08:57:57.944
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-18 08:57:57.945
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.945
Symbol Error - F.US.GLEQ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.945
Symbol Error - F.US.GFU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.945
Symbol Error - F.US.SF6M19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.945
Symbol Error - F.US.HEV19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.945
Symbol Error - F.US.SIEK19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.945
Symbol Error - F.US.PLEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.945
Symbol Error - F.US.CPEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.945
Symbol Error - F.US.CA6M19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.945
Symbol Error - F.US.SIEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.945
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.NGEM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.RBEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.CLEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.ZMEQ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
CQG WebAPI | Received symbol resolution report for symbol F.US.ZWAU19. Search Symbol: F.US.ZWAU19. Request ID: 75040. Contract ID: 53. | 2021-06-18 08:57:57.949
Symbol Error - F.US.GCEM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.NE6M19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.HOEV19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.ZWAN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.NGEX19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.ZLEQ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.KWEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
Symbol Error - F.US.HEQ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.949
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.KWEU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.KWEK20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.ZMEU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.ENQM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.FBTSM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.CPEU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.ZLEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.MESM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.ZSEQ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.JY6M19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.ZMEZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.FOATM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.GLEZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.ZWAZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
CQG WebAPI | Received symbol resolution report for symbol F.US.ZCEU19. Search Symbol: F.US.ZCEU19. Request ID: 75062. Contract ID: 54. | 2021-06-18 08:57:57.950
Symbol Error - F.US.ZMEV19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.SIEU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.GFQ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.GLEV19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.DDM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.FGBXM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.USAU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.GCEZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.HOEN19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.FBTPM19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.TYAU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.RBEU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.NGEQ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.ULAU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.DA6U19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.FVAU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.SF6U19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.FBTPU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.DLU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.TUAU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.NGEV19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.PLEV19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
Symbol Error - F.US.GLEG20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.950
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.951
Symbol Error - F.US.BP6U19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.951
Symbol Error - F.US.TNAU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.951
Added historical Intraday data request for F.US.DDU21 to the queue. | 2021-06-18 08:57:57.953
Intraday data recording state for symbol F.US.DDU21 is set to download 'Pending'. | 2021-06-18 08:57:57.953
Triggering next historical data download in queue. | 2021-06-18 08:57:57.953
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.953
Symbol Error - F.US.DSXU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.953
Symbol Error - F.US.HEG20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.953
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.EU6U19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.ZSEF20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
CQG WebAPI | Received symbol resolution report for symbol F.US.KWEZ19. Search Symbol: F.US.KWEZ19. Request ID: 75093. Contract ID: 55. | 2021-06-18 08:57:57.968
Symbol Error - F.US.ZLEF20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.CA6U19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.RBEZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.DBU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.HEZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.JY6U19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.FOATU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.NE6U19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.EPU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.FBTSU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.TYAZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.ZWAH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.TNAZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
CQG WebAPI | Received symbol resolution report for symbol F.US.ZCEZ19. Search Symbol: F.US.ZCEZ19. Request ID: 75102. Contract ID: 56. | 2021-06-18 08:57:57.968
Symbol Error - F.US.DLZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.CA6Z19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.EPZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.USAZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.CPEZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.ULAZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.BP6Z19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.GFV19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.HOEX19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.DBZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.FOATZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.DSXZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.NE6Z19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.FVAZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.YMZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.DA6Z19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.968
Symbol Error - F.US.GFX19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.KWEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.ZREX19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.SF6Z19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.EU6Z19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.ZSEX19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.FGBXZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.PLEF20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.NGEZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.ZCEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.CLEZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.HOEF20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.GLEJ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.ZSEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.HOEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.CLEG20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.TUAZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.GCEG20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.GFF20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.CPEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.NGEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.ZLEZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.ZLEK20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
Symbol Error - F.US.NGEF20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.969
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.975
Symbol Error - F.US.LBSX19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.975
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.CLEF20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.ZCEN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.RBEF20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.NGEG20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.ZWAK20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
CQG WebAPI | Received symbol resolution report for symbol F.US.ZSEK20. Search Symbol: F.US.ZSEK20. Request ID: 75154. Contract ID: 57. | 2021-06-18 08:57:57.976
Symbol Error - F.US.CLEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.GCEJ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.ZLEN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.CLEJ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.FXXPZ19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.JY6Z19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.CLEK20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.SIEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.GLEM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
CQG WebAPI | Received symbol resolution report for symbol F.US.ZCEK20. Search Symbol: F.US.ZCEK20. Request ID: 75164. Contract ID: 58. | 2021-06-18 08:57:57.976
Symbol Error - F.US.ZMEK20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.TYAH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.HOEJ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.USAH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.GLEV20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.TNAH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.ZMEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.NE6H20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
Symbol Error - F.US.EU6H20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.976
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.SF6H20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.ZMEQ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.NGEK20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.RBEJ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.BP6H20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.DSXH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.SIEK20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.ZSEN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.HOEG20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.DA6H20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.GFQ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.PLEJ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Symbol Error - F.US.EU6M20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.978
Added historical Intraday data request for F.US.TYAU21 to the queue. | 2021-06-18 08:57:57.978
Intraday data recording state for symbol F.US.TYAU21 is set to download 'Pending'. | 2021-06-18 08:57:57.978
Triggering next historical data download in queue. | 2021-06-18 08:57:57.978
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.979
Symbol Error - F.US.CA6H20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.979
Symbol Error - F.US.NGEJ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.979
Symbol Error - F.US.PLEN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.979
Added historical Intraday data request for F.US.RBEV21 to the queue. | 2021-06-18 08:57:57.979
Intraday data recording state for symbol F.US.RBEV21 is set to download 'Pending'. | 2021-06-18 08:57:57.979
Triggering next historical data download in queue. | 2021-06-18 08:57:57.979
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.YMH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.JY6H20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.GFU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.PAEH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.ZWAN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.DLH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.ZWAZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.CPEK20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.DBH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.GFJ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.ZLEZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.NGEM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.NGEN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.USAM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.TYAM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.DLM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.FVAM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.KWEU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.KWEN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.SIEN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.CPEN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.DA6M20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
Symbol Error - F.US.KWEZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.988
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.BP6M20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.SF6M20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.CA6M20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.ZMEU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.ZMEN20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.JY6M20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.NE6M20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.DSXM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.FBTSM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.HEQ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
Symbol Error - F.US.TNAM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.992
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.995
Symbol Error - F.US.DBM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.995
Symbol Error - F.US.HEV20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.995
Symbol Error - F.US.DDM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.995
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.HEM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.FXXPM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.ZCEU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.ZWAU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.FGBXM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.HEZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.TYAU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.ULAM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.NGEU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.SF6U20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.USAU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.SIEU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.RBEV20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.PLEV20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.RBEQ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
Symbol Error - F.US.CPEU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.996
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.998
Symbol Error - F.US.DLU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.998
Symbol Error - F.US.BP6U20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.998
Symbol Error - F.US.CPEZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.998
CQG WebAPI | Received symbol resolution report for symbol F.US.ZSEX20. Search Symbol: F.US.ZSEX20. Request ID: 75244. Contract ID: 59. | 2021-06-18 08:57:57.998
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:57.999
Symbol Error - F.US.DBU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:57.999
Symbol Error - F.US.DA6U20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.000
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.000
Symbol Error - F.US.FVAU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.000
Symbol Error - F.US.CA6U20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.000
Symbol Error - F.US.EU6U20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.000
Requesting market depth updates for: F.US.TYAU21 if supported. | 2021-06-18 08:57:58.000
Separate subscription for market depth updates not supported. F.US.TYAU21 | 2021-06-18 08:57:58.000
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=0, ActualMessageDelay=-0.0 seconds, DataCompRatio=0.89, UncompressedBytes=16, CompressionTime=0.000007(secs), NumCompressions=1 | 2021-06-18 08:57:58.002
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.002
Symbol Error - F.US.JY6U20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.002
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-18 08:57:58.002
SC Data - All Services | Sending logon request message. | 2021-06-18 08:57:58.002
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.ZSEQ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.DSXU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.NE6U20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.ZMEF21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.NGEQ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.TUAU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.FOATU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.ZMEV20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.ZLEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.ZLEU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
CQG WebAPI | Received symbol resolution report for symbol F.US.KWEK21. Search Symbol: F.US.KWEK21. Request ID: 75264. Contract ID: 60. | 2021-06-18 08:57:58.004
Symbol Error - F.US.EPU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.RBEU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.NGEV20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.TNAU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.NGEX20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.ZLEV20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
Symbol Error - F.US.ZSEU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.004
CQG WebAPI | Received symbol resolution report for symbol F.US.ZLEK21. Search Symbol: F.US.ZLEK21. Request ID: 75270. Contract ID: 61. | 2021-06-18 08:57:58.005
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.006
Symbol Error - F.US.ULAU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.006
Symbol Error - F.US.MGCZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.006
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.016
Symbol Error - F.US.CLEX20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.016
CQG WebAPI | Received symbol resolution report for symbol F.US.ZCEZ20. Search Symbol: F.US.ZCEZ20. Request ID: 75275. Contract ID: 62. | 2021-06-18 08:57:58.035
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.HOEV20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.TYAZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.DBZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.NGEZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.GFX20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.GFF21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.ZSEF21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.ZMEZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.CTEZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.RBEX20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
CQG WebAPI | Received symbol resolution report for symbol F.US.ZSEK21. Search Symbol: F.US.ZSEK21. Request ID: 75287. Contract ID: 63. | 2021-06-18 08:57:58.035
Symbol Error - F.US.DSXZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.DLZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.EU6Z20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.BP6Z20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
CQG WebAPI | Received symbol resolution report for symbol F.US.ZMEK21. Search Symbol: F.US.ZMEK21. Request ID: 75294. Contract ID: 64. | 2021-06-18 08:57:58.035
Symbol Error - F.US.CA6Z20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.SF6Z20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.HEJ21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.JY6Z20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.PLEF21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.TNAZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.USAZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
CQG WebAPI | Received symbol resolution report for symbol F.US.ZCEK21. Search Symbol: F.US.ZCEK21. Request ID: 75302. Contract ID: 65. | 2021-06-18 08:57:58.035
Symbol Error - F.US.CLEF21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.NE6Z20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.ZLEF21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.NGEF21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.ZMEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.GLEG21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.RBEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.HOEJ21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
CQG WebAPI | Received symbol resolution report for symbol F.US.NGEM21. Search Symbol: F.US.NGEM21. Request ID: 75309. Contract ID: 66. | 2021-06-18 08:57:58.035
Symbol Error - F.US.DA6Z20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.GCEZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.CLEZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.USAH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.TYAH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.HOEF21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.CLEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.NGEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.DBH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.TNAH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.YMZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.CA6H21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.SF6H21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.DSXH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.HOEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.DA6H21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.ULAH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
CQG WebAPI | Received symbol resolution report for symbol F.US.HEM21. Search Symbol: F.US.HEM21. Request ID: 75334. Contract ID: 67. | 2021-06-18 08:57:58.035
Symbol Error - F.US.DLH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.NE6H21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.ZSEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.KWEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.RBEG21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.ZCEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.HOEG21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.EPH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.FVAH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.CLEK21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.CPEH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.JY6H21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.GCEJ21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.CLEJ21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.035
Symbol Error - F.US.PLEJ21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.036
CQG WebAPI | Received symbol resolution report for symbol F.US.CPEK21. Search Symbol: F.US.CPEK21. Request ID: 75351. Contract ID: 68. | 2021-06-18 08:57:58.036
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.036
Symbol Error - F.US.NGEK21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.036
CQG WebAPI | Received symbol resolution report for symbol F.US.RBEM21. Search Symbol: F.US.RBEM21. Request ID: 75354. Contract ID: 69. | 2021-06-18 08:57:58.036
CQG WebAPI | Received symbol resolution report for symbol F.US.SF6M21. Search Symbol: F.US.SF6M21. Request ID: 75366. Contract ID: 70. | 2021-06-18 08:57:58.036
CQG WebAPI | Received symbol resolution report for symbol F.US.DLM21. Search Symbol: F.US.DLM21. Request ID: 75367. Contract ID: 71. | 2021-06-18 08:57:58.037
CQG WebAPI | Received symbol resolution report for symbol F.US.CLEM21. Search Symbol: F.US.CLEM21. Request ID: 75368. Contract ID: 72. | 2021-06-18 08:57:58.038
CQG WebAPI | Received symbol resolution report for symbol F.US.DA6M21. Search Symbol: F.US.DA6M21. Request ID: 75369. Contract ID: 73. | 2021-06-18 08:57:58.038
CQG WebAPI | Received symbol resolution report for symbol F.US.DBM21. Search Symbol: F.US.DBM21. Request ID: 75370. Contract ID: 74. | 2021-06-18 08:57:58.038
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.038
Symbol Error - F.US.RBEJ21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.038
Symbol Error - F.US.RBEK21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.038
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.040
Symbol Error - F.US.HOEK21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.040
Symbol Error - F.US.NGEJ21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.040
Symbol Error - F.US.MGCJ21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.040
CQG WebAPI | Received symbol resolution report for symbol F.US.ZWAK21. Search Symbol: F.US.ZWAK21. Request ID: 75376. Contract ID: 75. | 2021-06-18 08:57:58.041
CQG WebAPI | Received symbol resolution report for symbol F.US.EU6M21. Search Symbol: F.US.EU6M21. Request ID: 75377. Contract ID: 76. | 2021-06-18 08:57:58.041
CQG WebAPI | Received symbol resolution report for symbol F.US.BP6M21. Search Symbol: F.US.BP6M21. Request ID: 75384. Contract ID: 77. | 2021-06-18 08:57:58.041
CQG WebAPI | Received symbol resolution report for symbol F.US.SIEK21. Search Symbol: F.US.SIEK21. Request ID: 75385. Contract ID: 78. | 2021-06-18 08:57:58.042
CQG WebAPI | Received symbol resolution report for symbol F.US.HOEM21. Search Symbol: F.US.HOEM21. Request ID: 75386. Contract ID: 79. | 2021-06-18 08:57:58.043
CQG WebAPI | Received symbol resolution report for symbol F.US.CA6M21. Search Symbol: F.US.CA6M21. Request ID: 75387. Contract ID: 80. | 2021-06-18 08:57:58.043
CQG WebAPI | Received symbol resolution report for symbol F.US.NE6M21. Search Symbol: F.US.NE6M21. Request ID: 75388. Contract ID: 81. | 2021-06-18 08:57:58.043
CQG WebAPI | Received symbol resolution report for symbol F.US.FBTPM21. Search Symbol: F.US.FBTPM21. Request ID: 75396. Contract ID: 82. | 2021-06-18 08:57:58.073
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-06-18 08:57:58.101
SC DTC Data with Market Depth | Sending logon request message. | 2021-06-18 08:57:58.101
Mapping F.US.YMU19 to YMU19. Service code: cbot | 2021-06-18 08:57:58.120
SC Data - All Services | Starting real-time market data updates for: F.US.YMU19 (YMU19). ID: 558 Service code: cbot | 2021-06-18 08:57:58.120
CQG WebAPI | Sending symbol resolution request for F.US.YMU19. ID: 75410 | 2021-06-18 08:57:58.120
SC Data - All Services | Requesting security definition data for: F.US.YMU19 (YMU19). ID: 558 | 2021-06-18 08:57:58.120
Mapping F.US.DDU19 to FDAX201909_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:58.120
SC Data - All Services | Starting real-time market data updates for: F.US.DDU19 (FDAX201909_FUT_EUREX). ID: 559 Service code: eurex | 2021-06-18 08:57:58.120
CQG WebAPI | Sending symbol resolution request for F.US.DDU19. ID: 75411 | 2021-06-18 08:57:58.120
SC Data - All Services | Requesting security definition data for: F.US.DDU19 (FDAX201909_FUT_EUREX). ID: 559 | 2021-06-18 08:57:58.120
Mapping F.US.USAU21 to ZBU21. Service code: cbot | 2021-06-18 08:57:58.121
SC Data - All Services | Starting real-time market data updates for: F.US.USAU21 (ZBU21). ID: 560 Service code: cbot | 2021-06-18 08:57:58.121
CQG WebAPI | Sending symbol resolution request for F.US.USAU21. ID: 75412 | 2021-06-18 08:57:58.121
SC Data - All Services | Requesting security definition data for: F.US.USAU21 (ZBU21). ID: 560 | 2021-06-18 08:57:58.121
Mapping F.US.DBU21 to FGBL202109_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:58.121
SC Data - All Services | Starting real-time market data updates for: F.US.DBU21 (FGBL202109_FUT_EUREX). ID: 561 Service code: eurex | 2021-06-18 08:57:58.121
CQG WebAPI | Sending symbol resolution request for F.US.DBU21. ID: 75413 | 2021-06-18 08:57:58.121
SC Data - All Services | Requesting security definition data for: F.US.DBU21 (FGBL202109_FUT_EUREX). ID: 561 | 2021-06-18 08:57:58.121
Mapping F.US.DLU21 to FGBM202109_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:58.121
SC Data - All Services | Starting real-time market data updates for: F.US.DLU21 (FGBM202109_FUT_EUREX). ID: 562 Service code: eurex | 2021-06-18 08:57:58.121
CQG WebAPI | Sending symbol resolution request for F.US.DLU21. ID: 75414 | 2021-06-18 08:57:58.121
SC Data - All Services | Requesting security definition data for: F.US.DLU21 (FGBM202109_FUT_EUREX). ID: 562 | 2021-06-18 08:57:58.121
Requesting market depth updates for: F.US.USAU21 if supported. | 2021-06-18 08:57:58.121
Separate subscription for market depth updates not supported. F.US.USAU21 | 2021-06-18 08:57:58.121
Requesting market depth updates for: F.US.DBU21 if supported. | 2021-06-18 08:57:58.121
Separate subscription for market depth updates not supported. F.US.DBU21 | 2021-06-18 08:57:58.121
Requesting market depth updates for: F.US.DLU21 if supported. | 2021-06-18 08:57:58.121
Separate subscription for market depth updates not supported. F.US.DLU21 | 2021-06-18 08:57:58.121
Mapping F.US.EPH20 to ESH20. Service code: cme | 2021-06-18 08:57:58.123
SC Data - All Services | Starting real-time market data updates for: F.US.EPH20 (ESH20). ID: 563 Service code: cme | 2021-06-18 08:57:58.123
CQG WebAPI | Sending symbol resolution request for F.US.EPH20. ID: 75415 | 2021-06-18 08:57:58.123
SC Data - All Services | Requesting security definition data for: F.US.EPH20 (ESH20). ID: 563 | 2021-06-18 08:57:58.123
Mapping F.US.GFH20 to GFH20. Service code: cme | 2021-06-18 08:57:58.123
SC Data - All Services | Starting real-time market data updates for: F.US.GFH20 (GFH20). ID: 564 Service code: cme | 2021-06-18 08:57:58.123
CQG WebAPI | Sending symbol resolution request for F.US.GFH20. ID: 75416 | 2021-06-18 08:57:58.123
SC Data - All Services | Requesting security definition data for: F.US.GFH20 (GFH20). ID: 564 | 2021-06-18 08:57:58.123
Mapping F.US.EPM20 to ESM20. Service code: cme | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.EPM20 (ESM20). ID: 565 Service code: cme | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.EPM20. ID: 75417 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.EPM20 (ESM20). ID: 565 | 2021-06-18 08:57:58.124
Mapping F.US.YMU20 to YMU20. Service code: cbot | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.YMU20 (YMU20). ID: 566 Service code: cbot | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.YMU20. ID: 75418 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.YMU20 (YMU20). ID: 566 | 2021-06-18 08:57:58.124
Mapping F.US.EPZ20 to ESZ20. Service code: cme | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.EPZ20 (ESZ20). ID: 567 Service code: cme | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.EPZ20. ID: 75419 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.EPZ20 (ESZ20). ID: 567 | 2021-06-18 08:57:58.124
Mapping F.US.YMH21 to YMH21. Service code: cbot | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.YMH21 (YMH21). ID: 568 Service code: cbot | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.YMH21. ID: 75420 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.YMH21 (YMH21). ID: 568 | 2021-06-18 08:57:58.124
Mapping F.US.EPU21 to ESU21. Service code: cme | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.EPU21 (ESU21). ID: 569 Service code: cme | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.EPU21. ID: 75421 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.EPU21 (ESU21). ID: 569 | 2021-06-18 08:57:58.124
Mapping F.US.YMU21 to YMU21. Service code: cbot | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.YMU21 (YMU21). ID: 570 Service code: cbot | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.YMU21. ID: 75422 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.YMU21 (YMU21). ID: 570 | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Starting real-time market data updates for: EUR-X. ID: 571 Service code: fxstatscalc | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Requesting security definition data for: EUR-X. ID: 571 | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Starting real-time market data updates for: GBP-X. ID: 572 Service code: fxstatscalc | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Requesting security definition data for: GBP-X. ID: 572 | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Starting real-time market data updates for: AUD-X. ID: 573 Service code: fxstatscalc | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Requesting security definition data for: AUD-X. ID: 573 | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Starting real-time market data updates for: NZD-X. ID: 574 Service code: fxstatscalc | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Requesting security definition data for: NZD-X. ID: 574 | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Starting real-time market data updates for: CHF-X. ID: 575 Service code: fxstatscalc | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Requesting security definition data for: CHF-X. ID: 575 | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Starting real-time market data updates for: CAD-X. ID: 576 Service code: fxstatscalc | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Requesting security definition data for: CAD-X. ID: 576 | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Starting real-time market data updates for: JPY-X. ID: 577 Service code: fxstatscalc | 2021-06-18 08:57:58.124
SC DTC Data with Market Depth | Requesting security definition data for: JPY-X. ID: 577 | 2021-06-18 08:57:58.124
Mapping F.US.ULAU21 to UBU21. Service code: cbot | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.ULAU21 (UBU21). ID: 578 Service code: cbot | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.ULAU21. ID: 75423 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.ULAU21 (UBU21). ID: 578 | 2021-06-18 08:57:58.124
Mapping F.US.TUAU21 to ZTU21. Service code: cbot | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.TUAU21 (ZTU21). ID: 579 Service code: cbot | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.TUAU21. ID: 75424 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.TUAU21 (ZTU21). ID: 579 | 2021-06-18 08:57:58.124
Mapping F.US.DA6U21 to 6AU21. Service code: cme | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.DA6U21 (6AU21). ID: 580 Service code: cme | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.DA6U21. ID: 75425 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.DA6U21 (6AU21). ID: 580 | 2021-06-18 08:57:58.124
Mapping F.US.EU6U21 to 6EU21. Service code: cme | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.EU6U21 (6EU21). ID: 581 Service code: cme | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.EU6U21. ID: 75426 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.EU6U21 (6EU21). ID: 581 | 2021-06-18 08:57:58.124
Mapping F.US.NE6U21 to 6NU21. Service code: cme | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.NE6U21 (6NU21). ID: 582 Service code: cme | 2021-06-18 08:57:58.124
CQG WebAPI | Sending symbol resolution request for F.US.NE6U21. ID: 75427 | 2021-06-18 08:57:58.124
SC Data - All Services | Requesting security definition data for: F.US.NE6U21 (6NU21). ID: 582 | 2021-06-18 08:57:58.124
Mapping F.US.JY6U21 to 6JU21. Service code: cme | 2021-06-18 08:57:58.124
SC Data - All Services | Starting real-time market data updates for: F.US.JY6U21 (6JU21). ID: 583 Service code: cme | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.JY6U21. ID: 75428 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.JY6U21 (6JU21). ID: 583 | 2021-06-18 08:57:58.125
Mapping F.US.GCEQ21 to GCQ21. Service code: comex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.GCEQ21 (GCQ21). ID: 584 Service code: comex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.GCEQ21. ID: 75429 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.GCEQ21 (GCQ21). ID: 584 | 2021-06-18 08:57:58.125
Mapping F.US.HEN21 to HEN21. Service code: cme | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.HEN21 (HEN21). ID: 585 Service code: cme | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.HEN21. ID: 75430 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.HEN21 (HEN21). ID: 585 | 2021-06-18 08:57:58.125
Mapping F.US.BTCM21 to BTCM21. Service code: cme | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.BTCM21 (BTCM21). ID: 586 Service code: cme | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.BTCM21. ID: 75431 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.BTCM21 (BTCM21). ID: 586 | 2021-06-18 08:57:58.125
CQG WebAPI | Starting real-time market data updates for: XAU.EUR. ID: 587 | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for XAU.EUR. ID: 75432 | 2021-06-18 08:57:58.125
CQG WebAPI | Requesting security definition data for: XAU.EUR. ID: 587 | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Starting real-time market data updates for: USD-X. ID: 588 Service code: fxstatscalc | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Requesting security definition data for: USD-X. ID: 588 | 2021-06-18 08:57:58.125
Mapping F.US.GCEZ21 to GCZ21. Service code: comex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.GCEZ21 (GCZ21). ID: 589 Service code: comex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.GCEZ21. ID: 75433 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.GCEZ21 (GCZ21). ID: 589 | 2021-06-18 08:57:58.125
Mapping F.US.NGEV21 to NGV21. Service code: nymex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.NGEV21 (NGV21). ID: 590 Service code: nymex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.NGEV21. ID: 75434 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.NGEV21 (NGV21). ID: 590 | 2021-06-18 08:57:58.125
Mapping F.US.KWEZ21 to KEZ21. Service code: cbot | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.KWEZ21 (KEZ21). ID: 591 Service code: cbot | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.KWEZ21. ID: 75435 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.KWEZ21 (KEZ21). ID: 591 | 2021-06-18 08:57:58.125
Mapping F.US.CLEU21 to CLU21. Service code: nymex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.CLEU21 (CLU21). ID: 592 Service code: nymex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.CLEU21. ID: 75436 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.CLEU21 (CLU21). ID: 592 | 2021-06-18 08:57:58.125
Mapping F.US.ZCEH22 to ZCH22. Service code: cbot | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.ZCEH22 (ZCH22). ID: 593 Service code: cbot | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.ZCEH22. ID: 75437 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.ZCEH22 (ZCH22). ID: 593 | 2021-06-18 08:57:58.125
Mapping F.US.HOEU21 to HOU21. Service code: nymex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.HOEU21 (HOU21). ID: 594 Service code: nymex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.HOEU21. ID: 75438 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.HOEU21 (HOU21). ID: 594 | 2021-06-18 08:57:58.125
Mapping F.US.CPEU21 to HGU21. Service code: comex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.CPEU21 (HGU21). ID: 595 Service code: comex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.CPEU21. ID: 75439 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.CPEU21 (HGU21). ID: 595 | 2021-06-18 08:57:58.125
Mapping F.US.CLEV21 to CLV21. Service code: nymex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.CLEV21 (CLV21). ID: 596 Service code: nymex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.CLEV21. ID: 75440 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.CLEV21 (CLV21). ID: 596 | 2021-06-18 08:57:58.125
Mapping F.US.NGEX21 to NGX21. Service code: nymex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.NGEX21 (NGX21). ID: 597 Service code: nymex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.NGEX21. ID: 75441 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.NGEX21 (NGX21). ID: 597 | 2021-06-18 08:57:58.125
Mapping F.US.SIEU21 to SIU21. Service code: comex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.SIEU21 (SIU21). ID: 598 Service code: comex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.SIEU21. ID: 75442 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.SIEU21 (SIU21). ID: 598 | 2021-06-18 08:57:58.125
Mapping F.US.ZWAZ21 to ZWZ21. Service code: cbot | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.ZWAZ21 (ZWZ21). ID: 599 Service code: cbot | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.ZWAZ21. ID: 75443 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.ZWAZ21 (ZWZ21). ID: 599 | 2021-06-18 08:57:58.125
Mapping F.US.ZLEZ21 to ZLZ21. Service code: cbot | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEZ21 (ZLZ21). ID: 600 Service code: cbot | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.ZLEZ21. ID: 75444 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.ZLEZ21 (ZLZ21). ID: 600 | 2021-06-18 08:57:58.125
Mapping F.US.ZMEZ21 to ZMZ21. Service code: cbot | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEZ21 (ZMZ21). ID: 601 Service code: cbot | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.ZMEZ21. ID: 75445 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.ZMEZ21 (ZMZ21). ID: 601 | 2021-06-18 08:57:58.125
Mapping F.US.PLEV21 to PLV21. Service code: nymex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.PLEV21 (PLV21). ID: 602 Service code: nymex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.PLEV21. ID: 75446 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.PLEV21 (PLV21). ID: 602 | 2021-06-18 08:57:58.125
Mapping F.US.BTCN21 to BTCN21. Service code: cme | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.BTCN21 (BTCN21). ID: 603 Service code: cme | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.BTCN21. ID: 75447 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.BTCN21 (BTCN21). ID: 603 | 2021-06-18 08:57:58.125
Mapping F.US.RBEU21 to RBU21. Service code: nymex | 2021-06-18 08:57:58.125
SC Data - All Services | Starting real-time market data updates for: F.US.RBEU21 (RBU21). ID: 604 Service code: nymex | 2021-06-18 08:57:58.125
CQG WebAPI | Sending symbol resolution request for F.US.RBEU21. ID: 75448 | 2021-06-18 08:57:58.125
SC Data - All Services | Requesting security definition data for: F.US.RBEU21 (RBU21). ID: 604 | 2021-06-18 08:57:58.125
Using Bid/Ask average for last trade price for EURUSD | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 605 Service code: fxcm | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 605 | 2021-06-18 08:57:58.125
Using Bid/Ask average for last trade price for USDJPY | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Starting real-time market data updates for: USDJPY. ID: 606 Service code: fxcm | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Requesting security definition data for: USDJPY. ID: 606 | 2021-06-18 08:57:58.125
Using Bid/Ask average for last trade price for GBPUSD | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Starting real-time market data updates for: GBPUSD. ID: 607 Service code: fxcm | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Requesting security definition data for: GBPUSD. ID: 607 | 2021-06-18 08:57:58.125
Using Bid/Ask average for last trade price for AUDUSD | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Starting real-time market data updates for: AUDUSD. ID: 608 Service code: fxcm | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Requesting security definition data for: AUDUSD. ID: 608 | 2021-06-18 08:57:58.125
Using Bid/Ask average for last trade price for USDCAD | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Starting real-time market data updates for: USDCAD. ID: 609 Service code: fxcm | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Requesting security definition data for: USDCAD. ID: 609 | 2021-06-18 08:57:58.125
Using Bid/Ask average for last trade price for USDCHF | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Starting real-time market data updates for: USDCHF. ID: 610 Service code: fxcm | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Requesting security definition data for: USDCHF. ID: 610 | 2021-06-18 08:57:58.125
Using Bid/Ask average for last trade price for EURGBP | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Starting real-time market data updates for: EURGBP. ID: 611 Service code: fxcm | 2021-06-18 08:57:58.125
SC DTC Data with Market Depth | Requesting security definition data for: EURGBP. ID: 611 | 2021-06-18 08:57:58.125
Mapping F.US.BR6N21 to 6LN21. Service code: cme | 2021-06-18 08:57:58.142
SC Data - All Services | Starting real-time market data updates for: F.US.BR6N21 (6LN21). ID: 612 Service code: cme | 2021-06-18 08:57:58.142
CQG WebAPI | Sending symbol resolution request for F.US.BR6N21. ID: 75449 | 2021-06-18 08:57:58.142
SC Data - All Services | Requesting security definition data for: F.US.BR6N21 (6LN21). ID: 612 | 2021-06-18 08:57:58.142
Mapping F.US.FGBXU21 to FGBX202109_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:58.142
SC Data - All Services | Starting real-time market data updates for: F.US.FGBXU21 (FGBX202109_FUT_EUREX). ID: 613 Service code: eurex | 2021-06-18 08:57:58.142
CQG WebAPI | Sending symbol resolution request for F.US.FGBXU21. ID: 75450 | 2021-06-18 08:57:58.142
SC Data - All Services | Requesting security definition data for: F.US.FGBXU21 (FGBX202109_FUT_EUREX). ID: 613 | 2021-06-18 08:57:58.142
Mapping F.US.FBTPU21 to FBTP202109_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:58.142
SC Data - All Services | Starting real-time market data updates for: F.US.FBTPU21 (FBTP202109_FUT_EUREX). ID: 614 Service code: eurex | 2021-06-18 08:57:58.142
CQG WebAPI | Sending symbol resolution request for F.US.FBTPU21. ID: 75451 | 2021-06-18 08:57:58.142
SC Data - All Services | Requesting security definition data for: F.US.FBTPU21 (FBTP202109_FUT_EUREX). ID: 614 | 2021-06-18 08:57:58.142
Mapping F.US.FBTSU21 to FBTS202109_FUT_EUREX. Service code: eurex | 2021-06-18 08:57:58.142
SC Data - All Services | Starting real-time market data updates for: F.US.FBTSU21 (FBTS202109_FUT_EUREX). ID: 615 Service code: eurex | 2021-06-18 08:57:58.142
CQG WebAPI | Sending symbol resolution request for F.US.FBTSU21. ID: 75452 | 2021-06-18 08:57:58.142
SC Data - All Services | Requesting security definition data for: F.US.FBTSU21 (FBTS202109_FUT_EUREX). ID: 615 | 2021-06-18 08:57:58.142
Mapping F.US.GLEV21 to LEV21. Service code: cme | 2021-06-18 08:57:58.142
SC Data - All Services | Starting real-time market data updates for: F.US.GLEV21 (LEV21). ID: 616 Service code: cme | 2021-06-18 08:57:58.142
CQG WebAPI | Sending symbol resolution request for F.US.GLEV21. ID: 75453 | 2021-06-18 08:57:58.142
SC Data - All Services | Requesting security definition data for: F.US.GLEV21 (LEV21). ID: 616 | 2021-06-18 08:57:58.142
Mapping F.US.ZLEF22 to ZLF22. Service code: cbot | 2021-06-18 08:57:58.143
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEF22 (ZLF22). ID: 617 Service code: cbot | 2021-06-18 08:57:58.143
CQG WebAPI | Sending symbol resolution request for F.US.ZLEF22. ID: 75454 | 2021-06-18 08:57:58.143
SC Data - All Services | Requesting security definition data for: F.US.ZLEF22 (ZLF22). ID: 617 | 2021-06-18 08:57:58.143
Mapping F.US.ZLEH22 to ZLH22. Service code: cbot | 2021-06-18 08:57:58.143
SC Data - All Services | Starting real-time market data updates for: F.US.ZLEH22 (ZLH22). ID: 618 Service code: cbot | 2021-06-18 08:57:58.143
CQG WebAPI | Sending symbol resolution request for F.US.ZLEH22. ID: 75455 | 2021-06-18 08:57:58.143
SC Data - All Services | Requesting security definition data for: F.US.ZLEH22 (ZLH22). ID: 618 | 2021-06-18 08:57:58.143
Mapping F.US.ZMEU21 to ZMU21. Service code: cbot | 2021-06-18 08:57:58.143
SC Data - All Services | Starting real-time market data updates for: F.US.ZMEU21 (ZMU21). ID: 619 Service code: cbot | 2021-06-18 08:57:58.143
CQG WebAPI | Sending symbol resolution request for F.US.ZMEU21. ID: 75456 | 2021-06-18 08:57:58.143
SC Data - All Services | Requesting security definition data for: F.US.ZMEU21 (ZMU21). ID: 619 | 2021-06-18 08:57:58.143
Mapping F.US.MQOM21 to QOM21. Service code: comex | 2021-06-18 08:57:58.143
SC Data - All Services | Starting real-time market data updates for: F.US.MQOM21 (QOM21). ID: 620 Service code: comex | 2021-06-18 08:57:58.143
CQG WebAPI | Sending symbol resolution request for F.US.MQOM21. ID: 75457 | 2021-06-18 08:57:58.143
SC Data - All Services | Requesting security definition data for: F.US.MQOM21 (QOM21). ID: 620 | 2021-06-18 08:57:58.143
Mapping F.US.MGCQ21 to MGCQ21. Service code: comex | 2021-06-18 08:57:58.143
SC Data - All Services | Starting real-time market data updates for: F.US.MGCQ21 (MGCQ21). ID: 621 Service code: comex | 2021-06-18 08:57:58.143
CQG WebAPI | Sending symbol resolution request for F.US.MGCQ21. ID: 75458 | 2021-06-18 08:57:58.143
SC Data - All Services | Requesting security definition data for: F.US.MGCQ21 (MGCQ21). ID: 621 | 2021-06-18 08:57:58.143
Mapping F.US.MQIN21 to QIN21. Service code: comex | 2021-06-18 08:57:58.144
SC Data - All Services | Starting real-time market data updates for: F.US.MQIN21 (QIN21). ID: 622 Service code: comex | 2021-06-18 08:57:58.144
CQG WebAPI | Sending symbol resolution request for F.US.MQIN21. ID: 75459 | 2021-06-18 08:57:58.144
SC Data - All Services | Requesting security definition data for: F.US.MQIN21 (QIN21). ID: 622 | 2021-06-18 08:57:58.144
Mapping F.US.PAEU21 to PAU21. Service code: nymex | 2021-06-18 08:57:58.144
SC Data - All Services | Starting real-time market data updates for: F.US.PAEU21 (PAU21). ID: 623 Service code: nymex | 2021-06-18 08:57:58.144
CQG WebAPI | Sending symbol resolution request for F.US.PAEU21. ID: 75460 | 2021-06-18 08:57:58.144
SC Data - All Services | Requesting security definition data for: F.US.PAEU21 (PAU21). ID: 623 | 2021-06-18 08:57:58.144
CQG WebAPI | Received symbol resolution report for symbol F.US.USAU21. Search Symbol: F.US.USAU21. Request ID: 75412. Contract ID: 83. | 2021-06-18 08:57:58.156
CQG WebAPI | Received symbol resolution report for symbol F.US.DBU21. Search Symbol: F.US.DBU21. Request ID: 75413. Contract ID: 84. | 2021-06-18 08:57:58.157
CQG WebAPI | Received symbol resolution report for symbol F.US.DLU21. Search Symbol: F.US.DLU21. Request ID: 75414. Contract ID: 85. | 2021-06-18 08:57:58.157
CQG WebAPI | Received symbol resolution report for symbol F.US.EPU21. Search Symbol: F.US.EPU21. Request ID: 75421. Contract ID: 86. | 2021-06-18 08:57:58.193
CQG WebAPI | Received symbol resolution report for symbol F.US.YMU21. Search Symbol: F.US.YMU21. Request ID: 75422. Contract ID: 87. | 2021-06-18 08:57:58.193
CQG WebAPI | Received symbol resolution report for symbol F.US.ULAU21. Search Symbol: F.US.ULAU21. Request ID: 75423. Contract ID: 88. | 2021-06-18 08:57:58.194
CQG WebAPI | Received symbol resolution report for symbol F.US.TUAU21. Search Symbol: F.US.TUAU21. Request ID: 75424. Contract ID: 89. | 2021-06-18 08:57:58.194
CQG WebAPI | Received symbol resolution report for symbol F.US.DA6U21. Search Symbol: F.US.DA6U21. Request ID: 75425. Contract ID: 90. | 2021-06-18 08:57:58.194
CQG WebAPI | Received symbol resolution report for symbol F.US.EU6U21. Search Symbol: F.US.EU6U21. Request ID: 75426. Contract ID: 91. | 2021-06-18 08:57:58.195
CQG WebAPI | Received symbol resolution report for symbol F.US.NE6U21. Search Symbol: F.US.NE6U21. Request ID: 75427. Contract ID: 92. | 2021-06-18 08:57:58.195
CQG WebAPI | Received symbol resolution report for symbol F.US.JY6U21. Search Symbol: F.US.JY6U21. Request ID: 75428. Contract ID: 93. | 2021-06-18 08:57:58.195
CQG WebAPI | Received symbol resolution report for symbol F.US.GCEQ21. Search Symbol: F.US.GCEQ21. Request ID: 75429. Contract ID: 94. | 2021-06-18 08:57:58.196
CQG WebAPI | Received symbol resolution report for symbol F.US.HEN21. Search Symbol: F.US.HEN21. Request ID: 75430. Contract ID: 95. | 2021-06-18 08:57:58.196
CQG WebAPI | Received symbol resolution report for symbol F.US.BTCM21. Search Symbol: F.US.BTCM21. Request ID: 75431. Contract ID: 96. | 2021-06-18 08:57:58.196
CQG WebAPI | Received symbol resolution report for symbol F.US.GCEZ21. Search Symbol: F.US.GCEZ21. Request ID: 75433. Contract ID: 97. | 2021-06-18 08:57:58.196
CQG WebAPI | Received symbol resolution report for symbol F.US.NGEV21. Search Symbol: F.US.NGEV21. Request ID: 75434. Contract ID: 98. | 2021-06-18 08:57:58.196
CQG WebAPI | Received symbol resolution report for symbol F.US.KWEZ21. Search Symbol: F.US.KWEZ21. Request ID: 75435. Contract ID: 99. | 2021-06-18 08:57:58.196
CQG WebAPI | Received symbol resolution report for symbol F.US.CLEU21. Search Symbol: F.US.CLEU21. Request ID: 75436. Contract ID: 100. | 2021-06-18 08:57:58.196
CQG WebAPI | Received symbol resolution report for symbol F.US.ZCEH22. Search Symbol: F.US.ZCEH22. Request ID: 75437. Contract ID: 101. | 2021-06-18 08:57:58.196
CQG WebAPI | Received symbol resolution report for symbol F.US.HOEU21. Search Symbol: F.US.HOEU21. Request ID: 75438. Contract ID: 102. | 2021-06-18 08:57:58.196
CQG WebAPI | Received symbol resolution report for symbol F.US.CPEU21. Search Symbol: F.US.CPEU21. Request ID: 75439. Contract ID: 103. | 2021-06-18 08:57:58.197
CQG WebAPI | Received symbol resolution report for symbol F.US.CLEV21. Search Symbol: F.US.CLEV21. Request ID: 75440. Contract ID: 104. | 2021-06-18 08:57:58.197
CQG WebAPI | Received symbol resolution report for symbol F.US.NGEX21. Search Symbol: F.US.NGEX21. Request ID: 75441. Contract ID: 105. | 2021-06-18 08:57:58.198
CQG WebAPI | Received symbol resolution report for symbol F.US.SIEU21. Search Symbol: F.US.SIEU21. Request ID: 75442. Contract ID: 106. | 2021-06-18 08:57:58.198
CQG WebAPI | Received symbol resolution report for symbol F.US.ZWAZ21. Search Symbol: F.US.ZWAZ21. Request ID: 75443. Contract ID: 107. | 2021-06-18 08:57:58.198
CQG WebAPI | Received symbol resolution report for symbol F.US.ZLEZ21. Search Symbol: F.US.ZLEZ21. Request ID: 75444. Contract ID: 108. | 2021-06-18 08:57:58.199
CQG WebAPI | Received symbol resolution report for symbol F.US.ZMEZ21. Search Symbol: F.US.ZMEZ21. Request ID: 75445. Contract ID: 109. | 2021-06-18 08:57:58.199
CQG WebAPI | Received symbol resolution report for symbol F.US.PLEV21. Search Symbol: F.US.PLEV21. Request ID: 75446. Contract ID: 110. | 2021-06-18 08:57:58.199
CQG WebAPI | Received symbol resolution report for symbol F.US.BTCN21. Search Symbol: F.US.BTCN21. Request ID: 75447. Contract ID: 111. | 2021-06-18 08:57:58.199
CQG WebAPI | Received symbol resolution report for symbol F.US.RBEU21. Search Symbol: F.US.RBEU21. Request ID: 75448. Contract ID: 112. | 2021-06-18 08:57:58.199
CQG WebAPI | Received symbol resolution report for symbol F.US.BR6N21. Search Symbol: F.US.BR6N21. Request ID: 75449. Contract ID: 113. | 2021-06-18 08:57:58.199
CQG WebAPI | Received symbol resolution report for symbol F.US.FGBXU21. Search Symbol: F.US.FGBXU21. Request ID: 75450. Contract ID: 114. | 2021-06-18 08:57:58.200
CQG WebAPI | Received symbol resolution report for symbol F.US.FBTPU21. Search Symbol: F.US.FBTPU21. Request ID: 75451. Contract ID: 115. | 2021-06-18 08:57:58.200
CQG WebAPI | Received symbol resolution report for symbol F.US.FBTSU21. Search Symbol: F.US.FBTSU21. Request ID: 75452. Contract ID: 116. | 2021-06-18 08:57:58.200
CQG WebAPI | Received symbol resolution report for symbol F.US.GLEV21. Search Symbol: F.US.GLEV21. Request ID: 75453. Contract ID: 117. | 2021-06-18 08:57:58.200
CQG WebAPI | Received symbol resolution report for symbol F.US.ZLEF22. Search Symbol: F.US.ZLEF22. Request ID: 75454. Contract ID: 118. | 2021-06-18 08:57:58.200
CQG WebAPI | Received symbol resolution report for symbol F.US.ZLEH22. Search Symbol: F.US.ZLEH22. Request ID: 75455. Contract ID: 119. | 2021-06-18 08:57:58.200
CQG WebAPI | Received symbol resolution report for symbol F.US.ZMEU21. Search Symbol: F.US.ZMEU21. Request ID: 75456. Contract ID: 120. | 2021-06-18 08:57:58.200
CQG WebAPI | Received symbol resolution report for symbol F.US.MGCQ21. Search Symbol: F.US.MGCQ21. Request ID: 75458. Contract ID: 121. | 2021-06-18 08:57:58.202
CQG WebAPI | Received symbol resolution report for symbol F.US.MQIN21. Search Symbol: F.US.MQIN21. Request ID: 75459. Contract ID: 122. | 2021-06-18 08:57:58.202
CQG WebAPI | Received symbol resolution report for symbol F.US.PAEU21. Search Symbol: F.US.PAEU21. Request ID: 75460. Contract ID: 123. | 2021-06-18 08:57:58.204
SC Data - All Services | Received logon response. | 2021-06-18 08:57:58.219
SC Data - All Services | Server Name: SC Realtime Server. | 2021-06-18 08:57:58.219
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-18 08:57:58.219
SC Data - All Services | Successfully connected. | 2021-06-18 08:57:58.219
SC Data - All Services | Trading is not supported. | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBH19 -> FGBL201903_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBH20 -> FGBL202003_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBH21 -> FGBL202103_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBM18 -> FGBL201806_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBM19 -> FGBL201906_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBM20 -> FGBL202006_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBM21 -> FGBL202106_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBU18 -> FGBL201809_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBU19 -> FGBL201909_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBU20 -> FGBL202009_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBU21 -> FGBL202109_FUT_EUREX. Market Depth data restarted. | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBZ18 -> FGBL201812_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBZ19 -> FGBL201912_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DBZ20 -> FGBL202012_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DDH19 -> FDAX201903_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DDM18 -> FDAX201806_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DDM19 -> FDAX201906_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DDM20 -> FDAX202006_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DDM21 -> FDAX202106_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DDU18 -> FDAX201809_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DDU19 -> FDAX201909_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DDU21 -> FDAX202109_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLH19 -> FGBM201903_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLH20 -> FGBM202003_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLH21 -> FGBM202103_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLM18 -> FGBM201806_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLM19 -> FGBM201906_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLM20 -> FGBM202006_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLM21 -> FGBM202106_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLU18 -> FGBM201809_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLU19 -> FGBM201909_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLU20 -> FGBM202009_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLU21 -> FGBM202109_FUT_EUREX. Market Depth data restarted. | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLZ18 -> FGBM201812_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLZ19 -> FGBM201912_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DLZ20 -> FGBM202012_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXH18 -> FESX201803_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXH19 -> FESX201903_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXH20 -> FESX202003_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXH21 -> FESX202103_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXM18 -> FESX201806_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXM19 -> FESX201906_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXM20 -> FESX202006_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXM21 -> FESX202106_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXU18 -> FESX201809_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXU19 -> FESX201909_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXU20 -> FESX202009_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXU21 -> FESX202109_FUT_EUREX. Market Depth data restarted. | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXZ18 -> FESX201812_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXZ19 -> FESX201912_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DSXZ20 -> FESX202012_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTPH19 -> FBTP201903_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTPM19 -> FBTP201906_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTPM21 -> FBTP202106_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTPU19 -> FBTP201909_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTPU21 -> FBTP202109_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTPZ18 -> FBTP201812_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTSH19 -> FBTS201903_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTSM19 -> FBTS201906_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTSM20 -> FBTS202006_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTSU19 -> FBTS201909_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FBTSU21 -> FBTS202109_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FDXMM19 -> FDXM201906_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FGBXM19 -> FGBX201906_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FGBXM20 -> FGBX202006_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FGBXU21 -> FGBX202109_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FGBXZ19 -> FGBX201912_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FOATH19 -> FOAT201903_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FOATM19 -> FOAT201906_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FOATU19 -> FOAT201909_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FOATU20 -> FOAT202009_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FOATZ19 -> FOAT201912_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FXXPM20 -> FXXP202006_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FXXPZ19 -> FXXP201912_FUT_EUREX | 2021-06-18 08:57:58.219
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=0, ActualMessageDelay=-0.1 seconds, DataCompRatio=0.89, UncompressedBytes=16, CompressionTime=0.000009(secs), NumCompressions=1 | 2021-06-18 08:57:58.221
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.229
Symbol Error - F.US.DDU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.229
Symbol Error - F.US.YMU19 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.229
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.230
Symbol Error - F.US.EPH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.230
CQG WebAPI | Received symbol resolution report for symbol F.US.YMH21. Search Symbol: F.US.YMH21. Request ID: 75420. Contract ID: 124. | 2021-06-18 08:57:58.266
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.267
Symbol Error - F.US.GFH20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.267
Symbol Error - F.US.EPM20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.268
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-18 08:57:58.268
Symbol Error - F.US.EPZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.268
Symbol Error - F.US.YMU20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.268
Symbol Error - XAU.EUR is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-18 08:57:58.268
CQG WebAPI | Received symbol resolution report for symbol F.US.MQOM21. Search Symbol: F.US.MQOM21. Request ID: 75457. Contract ID: 125. | 2021-06-18 08:57:58.272
SC DTC Data with Market Depth | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=0, ActualMessageDelay=-0.8 seconds, DataCompRatio=0.89, UncompressedBytes=16, CompressionTime=0.000004(secs), NumCompressions=1 | 2021-06-18 08:57:58.337
SC Data - All Services | Clearing market depth for F.US.DBU21 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBH19 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBH19 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBH20 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBH20 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBH21 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBH21 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBM18 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBM18 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBM19 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBM19 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBM20 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBM20 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBM21 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBM21 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBU18 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBU18 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBU19 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBU19 | 2021-06-18 08:57:58.347
SC Data - All Services | Real-time data for symbol F.US.DBU20 is currently unavailable. | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBU20 | 2021-06-18 08:57:58.347
SC Data - All Services | Received security definition for symbol F.US.DBU21 | 2021-06-18 08:57:58.347
SC Data - All Services | Clearing market depth for F.US.DLU21 | 2021-06-18 08:57:58.347
SC Data - All Services | Clearing market depth for F.US.DSXU21 | 2021-06-18 08:57:58.348
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.DSXU21.2021-06-18.depth | 2021-06-18 08:57:58.348
SC Data - All Services | Real-time data for symbol F.US.DBZ18 is currently unavailable. | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DBZ18 | 2021-06-18 08:57:58.348
SC Data - All Services | Real-time data for symbol F.US.DBZ19 is currently unavailable. | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DBZ19 | 2021-06-18 08:57:58.348
SC Data - All Services | Real-time data for symbol F.US.DBZ20 is currently unavailable. | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DBZ20 | 2021-06-18 08:57:58.348
SC Data - All Services | Real-time data for symbol F.US.DDH19 is currently unavailable. | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DDH19 | 2021-06-18 08:57:58.348
SC Data - All Services | Real-time data for symbol F.US.DDM18 is currently unavailable. | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DDM18 | 2021-06-18 08:57:58.348
SC Data - All Services | Real-time data for symbol F.US.DDM19 is currently unavailable. | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DDM19 | 2021-06-18 08:57:58.348
SC Data - All Services | Real-time data for symbol F.US.DDM20 is currently unavailable. | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DDM20 | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DDM21 | 2021-06-18 08:57:58.348
SC Data - All Services | Real-time data for symbol F.US.DDU18 is currently unavailable. | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DDU18 | 2021-06-18 08:57:58.348
SC Data - All Services | Real-time data for symbol F.US.DDU19 is currently unavailable. | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DDU19 | 2021-06-18 08:57:58.348
SC Data - All Services | Received security definition for symbol F.US.DDU21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLH19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLH19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLH20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLH20 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLH21 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLH21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLM18 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLM18 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLM19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLM19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLM20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLM20 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLM21 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLM21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLU18 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLU18 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLU19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLU19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLU20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLU20 | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLU21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLZ18 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLZ18 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLZ19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLZ19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DLZ20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DLZ20 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXH18 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXH18 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXH19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXH19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXH20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXH20 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXH21 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXH21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXM18 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXM18 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXM19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXM19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXM20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXM20 | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXM21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXU18 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXU18 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXU19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXU19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXU20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXU20 | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXU21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXZ18 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXZ18 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXZ19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXZ19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.DSXZ20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.DSXZ20 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FBTPH19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTPH19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FBTPM19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTPM19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FBTPM21 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTPM21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FBTPU19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTPU19 | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTPU21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FBTPZ18 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTPZ18 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FBTSH19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTSH19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FBTSM19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTSM19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FBTSM20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTSM20 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FBTSU19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTSU19 | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FBTSU21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FDXMM19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FDXMM19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FGBXM19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FGBXM19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FGBXM20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FGBXM20 | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FGBXU21 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FGBXZ19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FGBXZ19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FOATH19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FOATH19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FOATM19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FOATM19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FOATU19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FOATU19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FOATU20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FOATU20 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FOATZ19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FOATZ19 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FXXPM20 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FXXPM20 | 2021-06-18 08:57:58.349
SC Data - All Services | Real-time data for symbol F.US.FXXPZ19 is currently unavailable. | 2021-06-18 08:57:58.349
SC Data - All Services | Received security definition for symbol F.US.FXXPZ19 | 2021-06-18 08:57:58.349
SC DTC Data with Market Depth | Received logon response. | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Successfully connected. | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Trading is not supported. | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUD-X | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUDUSD | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CAD-X | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHF-X | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EUR-X | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURGBP | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBP-X | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPCAD | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBPUSD | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: JPY-X | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZD-X | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USD-X | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCAD | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDCHF | 2021-06-18 08:57:58.883
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDJPY | 2021-06-18 08:57:58.883
SC Data - All Services | Received logon response. | 2021-06-18 08:57:58.883
SC Data - All Services | Server Name: SC Realtime Server. | 2021-06-18 08:57:58.883
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-18 08:57:58.883
SC Data - All Services | Successfully connected. | 2021-06-18 08:57:58.883
SC Data - All Services | Trading is not supported. | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6H19 -> 6BH19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6H20 -> 6BH20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6M19 -> 6BM19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6M20 -> 6BM20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6M21 -> 6BM21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6U18 -> 6BU18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6U19 -> 6BU19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6U20 -> 6BU20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6U21 -> 6BU21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6Z18 -> 6BZ18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6Z19 -> 6BZ19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6Z20 -> 6BZ20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BR6N21 -> 6LN21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BTCM21 -> BTCM21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.BTCN21 -> BTCN21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6H19 -> 6CH19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6H20 -> 6CH20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6H21 -> 6CH21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6M19 -> 6CM19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6M20 -> 6CM20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6M21 -> 6CM21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6U19 -> 6CU19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6U20 -> 6CU20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6U21 -> 6CU21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6Z18 -> 6CZ18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6Z19 -> 6CZ19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6Z20 -> 6CZ20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEF19 -> CLF19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEF20 -> CLF20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEF21 -> CLF21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEG20 -> CLG20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEH19 -> CLH19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEH20 -> CLH20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEH21 -> CLH21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEJ20 -> CLJ20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEJ21 -> CLJ21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEK19 -> CLK19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEK20 -> CLK20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEK21 -> CLK21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEM18 -> CLM18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEM19 -> CLM19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEM21 -> CLM21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEN18 -> CLN18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEN19 -> CLN19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEN21 -> CLN21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEQ18 -> CLQ18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEQ21 -> CLQ21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEU21 -> CLU21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEV21 -> CLV21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEX18 -> CLX18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEX20 -> CLX20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEZ18 -> CLZ18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEZ19 -> CLZ19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEZ20 -> CLZ20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEH19 -> HGH19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEH20 -> HGH20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEH21 -> HGH21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEK19 -> HGK19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEK20 -> HGK20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEK21 -> HGK21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEN18 -> HGN18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEN19 -> HGN19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEN20 -> HGN20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEN21 -> HGN21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEU18 -> HGU18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEU19 -> HGU19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEU20 -> HGU20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEU21 -> HGU21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEZ18 -> HGZ18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEZ19 -> HGZ19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.CPEZ20 -> HGZ20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6H19 -> 6AH19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6H20 -> 6AH20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6H21 -> 6AH21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6M19 -> 6AM19 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6M20 -> 6AM20 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6M21 -> 6AM21 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6U18 -> 6AU18 | 2021-06-18 08:57:58.883
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6U19 -> 6AU19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6U20 -> 6AU20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6U21 -> 6AU21 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6Z18 -> 6AZ18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6Z19 -> 6AZ19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6Z20 -> 6AZ20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ENQH19 -> NQH19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ENQM18 -> NQM18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ENQM19 -> NQM19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ENQU18 -> NQU18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPH19 -> ESH19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPH20 -> ESH20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPH21 -> ESH21 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPM18 -> ESM18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPM19 -> ESM19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPM20 -> ESM20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPM21 -> ESM21 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPU18 -> ESU18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPU19 -> ESU19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPU20 -> ESU20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPU21 -> ESU21 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPZ18 -> ESZ18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPZ19 -> ESZ19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPZ20 -> ESZ20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6H19 -> 6EH19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6H20 -> 6EH20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6M19 -> 6EM19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6M20 -> 6EM20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6M21 -> 6EM21 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6U19 -> 6EU19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6U20 -> 6EU20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6U21 -> 6EU21 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6Z18 -> 6EZ18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6Z19 -> 6EZ19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6Z20 -> 6EZ20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAH19 -> ZFH19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAH21 -> ZFH21 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAM19 -> ZFM19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAM20 -> ZFM20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAM21 -> ZFM21 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAU18 -> ZFU18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAU19 -> ZFU19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAU20 -> ZFU20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAU21 -> ZFU21 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAZ18 -> ZFZ18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAZ19 -> ZFZ19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEG19 -> GCG19 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEG20 -> GCG20 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEJ18 -> GCJ18 | 2021-06-18 08:57:58.884
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEJ19 -> GCJ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEJ20 -> GCJ20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEJ21 -> GCJ21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEM18 -> GCM18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEM19 -> GCM19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEM21 -> GCM21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEQ18 -> GCQ18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEQ21 -> GCQ21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEZ18 -> GCZ18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEZ19 -> GCZ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEZ20 -> GCZ20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEZ21 -> GCZ21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFF20 -> GFF20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFF21 -> GFF21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFH20 -> GFH20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFJ19 -> GFJ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFJ20 -> GFJ20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFQ18 -> GFQ18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFQ19 -> GFQ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFQ20 -> GFQ20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFQ21 -> GFQ21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFU19 -> GFU19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFU20 -> GFU20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFV18 -> GFV18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFV19 -> GFV19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFX18 -> GFX18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFX19 -> GFX19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GFX20 -> GFX20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEG19 -> LEG19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEG20 -> LEG20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEG21 -> LEG21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEJ19 -> LEJ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEJ20 -> LEJ20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEM19 -> LEM19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEM20 -> LEM20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEM21 -> LEM21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEQ19 -> LEQ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEQ21 -> LEQ21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEV19 -> LEV19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEV20 -> LEV20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEV21 -> LEV21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEZ18 -> LEZ18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.GLEZ19 -> LEZ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEG19 -> HEG19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEG20 -> HEG20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEJ19 -> HEJ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEJ21 -> HEJ21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEM19 -> HEM19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEM20 -> HEM20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEM21 -> HEM21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEN18 -> HEN18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEN19 -> HEN19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEN21 -> HEN21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEQ18 -> HEQ18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEQ19 -> HEQ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEQ20 -> HEQ20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEQ21 -> HEQ21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEV18 -> HEV18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEV19 -> HEV19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEV20 -> HEV20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEZ18 -> HEZ18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEZ19 -> HEZ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HEZ20 -> HEZ20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEF20 -> HOF20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEF21 -> HOF21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEG20 -> HOG20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEG21 -> HOG21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEH19 -> HOH19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEH20 -> HOH20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEH21 -> HOH21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEJ19 -> HOJ19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEJ20 -> HOJ20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEJ21 -> HOJ21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEK21 -> HOK21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEM19 -> HOM19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEM21 -> HOM21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEN19 -> HON19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEN21 -> HON21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEQ21 -> HOQ21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEU21 -> HOU21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEV18 -> HOV18 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEV19 -> HOV19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEV20 -> HOV20 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEV21 -> HOV21 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEX19 -> HOX19 | 2021-06-18 08:57:58.885
SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEZ18 -> HOZ18 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6H20 -> 6JH20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6H21 -> 6JH21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6M19 -> 6JM19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6M20 -> 6JM20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6U19 -> 6JU19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6U20 -> 6JU20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6U21 -> 6JU21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6Z18 -> 6JZ18 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6Z19 -> 6JZ19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6Z20 -> 6JZ20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEH19 -> KEH19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEH20 -> KEH20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEH21 -> KEH21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEK19 -> KEK19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEK20 -> KEK20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEK21 -> KEK21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEN19 -> KEN19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEN20 -> KEN20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEN21 -> KEN21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEU19 -> KEU19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEU20 -> KEU20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEU21 -> KEU21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEZ18 -> KEZ18 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEZ19 -> KEZ19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEZ20 -> KEZ20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.KWEZ21 -> KEZ21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.LBSX19 -> LBSX19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.M6AZ18 -> M6AZ18 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.M6EZ18 -> M6EZ18 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.MESM19 -> MESM19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.MGCJ21 -> MGCJ21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.MGCQ21 -> MGCQ21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.MGCZ20 -> MGCZ20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.MQIN21 -> QIN21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.MQOM21 -> QOM21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6H20 -> 6NH20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6H21 -> 6NH21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6M19 -> 6NM19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6M20 -> 6NM20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6M21 -> 6NM21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6U19 -> 6NU19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6U20 -> 6NU20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6U21 -> 6NU21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6Z18 -> 6NZ18 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6Z19 -> 6NZ19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NE6Z20 -> 6NZ20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEF19 -> NGF19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEF20 -> NGF20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEF21 -> NGF21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEG20 -> NGG20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEH20 -> NGH20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEH21 -> NGH21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEJ20 -> NGJ20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEJ21 -> NGJ21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEK20 -> NGK20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEK21 -> NGK21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEM19 -> NGM19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEM20 -> NGM20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEM21 -> NGM21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEN20 -> NGN20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEN21 -> NGN21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEQ19 -> NGQ19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEQ20 -> NGQ20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEQ21 -> NGQ21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEU20 -> NGU20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEU21 -> NGU21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEV19 -> NGV19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEV20 -> NGV20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEV21 -> NGV21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEX19 -> NGX19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEX20 -> NGX20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEX21 -> NGX21 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEZ19 -> NGZ19 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEZ20 -> NGZ20 | 2021-06-18 08:57:58.886
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PAEH20 -> PAH20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PAEU21 -> PAU21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PAEZ18 -> PAZ18 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEF19 -> PLF19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEF20 -> PLF20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEF21 -> PLF21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEJ19 -> PLJ19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEJ20 -> PLJ20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEJ21 -> PLJ21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEN19 -> PLN19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEN20 -> PLN20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEN21 -> PLN21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEV19 -> PLV19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEV20 -> PLV20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.PLEV21 -> PLV21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEF20 -> RBF20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEG19 -> RBG19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEG21 -> RBG21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEH21 -> RBH21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEJ20 -> RBJ20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEJ21 -> RBJ21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEK21 -> RBK21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEM21 -> RBM21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEN19 -> RBN19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEN21 -> RBN21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEQ20 -> RBQ20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEQ21 -> RBQ21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEU18 -> RBU18 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEU19 -> RBU19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEU20 -> RBU20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEU21 -> RBU21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEV20 -> RBV20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEV21 -> RBV21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEX18 -> RBX18 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEX20 -> RBX20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEZ19 -> RBZ19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6H19 -> 6SH19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6H20 -> 6SH20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6H21 -> 6SH21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6M19 -> 6SM19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6M20 -> 6SM20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6M21 -> 6SM21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6U19 -> 6SU19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6U20 -> 6SU20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6U21 -> 6SU21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6Z18 -> 6SZ18 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6Z19 -> 6SZ19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6Z20 -> 6SZ20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEH19 -> SIH19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEH20 -> SIH20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEK19 -> SIK19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEK20 -> SIK20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEK21 -> SIK21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEN18 -> SIN18 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEN19 -> SIN19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEN20 -> SIN20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEN21 -> SIN21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEU18 -> SIU18 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEU19 -> SIU19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEU20 -> SIU20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEU21 -> SIU21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEZ18 -> SIZ18 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAH19 -> TNH19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAH20 -> TNH20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAH21 -> TNH21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAM18 -> TNM18 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAM19 -> TNM19 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAM20 -> TNM20 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAM21 -> TNM21 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAU18 -> TNU18 | 2021-06-18 08:57:58.887
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAU19 -> TNU19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAU20 -> TNU20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAU21 -> TNU21. Market Depth data restarted. | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAZ18 -> TNZ18 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAZ19 -> TNZ19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAZ20 -> TNZ20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TUAH19 -> ZTH19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TUAM19 -> ZTM19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TUAU19 -> ZTU19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TUAU20 -> ZTU20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TUAU21 -> ZTU21 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TUAZ18 -> ZTZ18 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TUAZ19 -> ZTZ19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAH19 -> ZNH19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAH20 -> ZNH20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAH21 -> ZNH21 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAM18 -> ZNM18 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAM19 -> ZNM19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAM20 -> ZNM20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAM21 -> ZNM21 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAU18 -> ZNU18 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAU19 -> ZNU19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAU20 -> ZNU20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAU21 -> ZNU21. Market Depth data restarted. | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAZ18 -> ZNZ18 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAZ19 -> ZNZ19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAZ20 -> ZNZ20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAH19 -> UBH19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAH21 -> UBH21 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAM19 -> UBM19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAM20 -> UBM20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAM21 -> UBM21 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAU18 -> UBU18 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAU19 -> UBU19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAU20 -> UBU20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAU21 -> UBU21 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAZ18 -> UBZ18 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ULAZ19 -> UBZ19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAH19 -> ZBH19 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAH20 -> ZBH20 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAH21 -> ZBH21 | 2021-06-18 08:57:58.888
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAM18 -> ZBM18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAM19 -> ZBM19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAM20 -> ZBM20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAM21 -> ZBM21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAU19 -> ZBU19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAU20 -> ZBU20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAU21 -> ZBU21. Market Depth data restarted. | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAZ18 -> ZBZ18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAZ19 -> ZBZ19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAZ20 -> ZBZ20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.XCN18 -> XCN18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.XWN18 -> XWN18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMH19 -> YMH19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMH20 -> YMH20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMH21 -> YMH21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMM18 -> YMM18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMM21 -> YMM21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMU18 -> YMU18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMU19 -> YMU19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMU20 -> YMU20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMU21 -> YMU21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMZ18 -> YMZ18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMZ19 -> YMZ19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMZ20 -> YMZ20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEH19 -> ZCH19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEH20 -> ZCH20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEH21 -> ZCH21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEH22 -> ZCH22 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEK19 -> ZCK19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEK20 -> ZCK20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEK21 -> ZCK21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEN18 -> ZCN18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEN19 -> ZCN19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEN20 -> ZCN20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEN21 -> ZCN21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEU18 -> ZCU18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEU19 -> ZCU19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEU20 -> ZCU20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEU21 -> ZCU21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEZ18 -> ZCZ18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEZ19 -> ZCZ19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEZ20 -> ZCZ20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZCEZ21 -> ZCZ21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEF19 -> ZLF19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEF20 -> ZLF20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEF21 -> ZLF21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEF22 -> ZLF22 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEH19 -> ZLH19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEH20 -> ZLH20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEH21 -> ZLH21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEH22 -> ZLH22 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEK20 -> ZLK20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEK21 -> ZLK21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEN18 -> ZLN18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEN19 -> ZLN19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEN20 -> ZLN20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEN21 -> ZLN21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEQ19 -> ZLQ19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEQ21 -> ZLQ21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEU20 -> ZLU20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEU21 -> ZLU21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEV20 -> ZLV20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEZ18 -> ZLZ18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEZ19 -> ZLZ19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEZ20 -> ZLZ20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZLEZ21 -> ZLZ21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEF21 -> ZMF21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEH20 -> ZMH20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEH21 -> ZMH21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEK20 -> ZMK20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEK21 -> ZMK21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEN18 -> ZMN18 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEN20 -> ZMN20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEN21 -> ZMN21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEQ19 -> ZMQ19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEQ20 -> ZMQ20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEQ21 -> ZMQ21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEU19 -> ZMU19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEU20 -> ZMU20 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEU21 -> ZMU21 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEV19 -> ZMV19 | 2021-06-18 08:57:58.889
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEV20 -> ZMV20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEZ18 -> ZMZ18 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEZ19 -> ZMZ19 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEZ20 -> ZMZ20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZMEZ21 -> ZMZ21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZREX19 -> ZRX19 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEF20 -> ZSF20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEF21 -> ZSF21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEH20 -> ZSH20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEH21 -> ZSH21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEK19 -> ZSK19 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEK20 -> ZSK20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEK21 -> ZSK21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEN18 -> ZSN18 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEN19 -> ZSN19 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEN20 -> ZSN20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEN21 -> ZSN21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEQ18 -> ZSQ18 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEQ19 -> ZSQ19 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEQ20 -> ZSQ20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEQ21 -> ZSQ21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEU20 -> ZSU20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEU21 -> ZSU21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEX18 -> ZSX18 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEX19 -> ZSX19 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEX20 -> ZSX20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZSEX21 -> ZSX21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAH20 -> ZWH20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAK20 -> ZWK20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAK21 -> ZWK21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAN18 -> ZWN18 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAN19 -> ZWN19 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAN20 -> ZWN20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAN21 -> ZWN21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAU18 -> ZWU18 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAU19 -> ZWU19 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAU20 -> ZWU20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAU21 -> ZWU21 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAZ19 -> ZWZ19 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAZ20 -> ZWZ20 | 2021-06-18 08:57:58.890
SC Data - All Services | Restarting real-time data updates for symbol: F.US.ZWAZ21 -> ZWZ21 | 2021-06-18 08:57:58.890
SC Data - All Services | Real-time data for symbol F.US.BP6H19 is currently unavailable. | 2021-06-18 08:57:59.097
SC Data - All Services | Received security definition for symbol F.US.BP6H19 | 2021-06-18 08:57:59.097
SC Data - All Services | Real-time data for symbol F.US.BP6H20 is currently unavailable. | 2021-06-18 08:57:59.097
SC Data - All Services | Received security definition for symbol F.US.BP6H20 | 2021-06-18 08:57:59.097
SC Data - All Services | Real-time data for symbol F.US.BP6M19 is currently unavailable. | 2021-06-18 08:57:59.097
SC Data - All Services | Received security definition for symbol F.US.BP6M19 | 2021-06-18 08:57:59.097
SC Data - All Services | Real-time data for symbol F.US.BP6M20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BP6M20 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BP6M21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.BP6U18 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BP6U18 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.BP6U19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BP6U19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.BP6U20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BP6U20 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BP6U21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.BP6Z18 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BP6Z18 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.BP6Z19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BP6Z19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.BP6Z20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BP6Z20 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BR6N21 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BTCM21 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.BTCN21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6H19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6H19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6H20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6H20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6H21 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6H21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6M19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6M19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6M20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6M20 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6M21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6U19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6U19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6U20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6U20 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6U21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6Z18 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6Z18 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6Z19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6Z19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CA6Z20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CA6Z20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEF19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEF19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEF20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEF20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEF21 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEF21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEG20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEG20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEH19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEH19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEH20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEH20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEH21 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEH21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEJ20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEJ20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEJ21 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEJ21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEK19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEK19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEK20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEK20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEK21 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEK21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEM18 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEM18 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEM19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEM19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEM21 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEM21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEN18 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEN18 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEN19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEN19 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEN21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEQ18 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEQ18 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEQ21 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEU21 | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEV21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEX18 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEX18 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEX20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEX20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEZ18 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEZ18 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEZ19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEZ19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CLEZ20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CLEZ20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CPEH19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CPEH19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CPEH20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CPEH20 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CPEH21 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CPEH21 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CPEK19 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CPEK19 | 2021-06-18 08:57:59.098
SC Data - All Services | Real-time data for symbol F.US.CPEK20 is currently unavailable. | 2021-06-18 08:57:59.098
SC Data - All Services | Received security definition for symbol F.US.CPEK20 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEK21 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEK21 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEN18 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEN18 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEN19 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEN19 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEN20 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEN20 | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEN21 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEU18 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEU18 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEU19 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEU19 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEU20 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEU20 | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEU21 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEZ18 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEZ18 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEZ19 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEZ19 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.CPEZ20 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.CPEZ20 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.DA6H19 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6H19 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.DA6H20 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6H20 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.DA6H21 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6H21 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.DA6M19 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6M19 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.DA6M20 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6M20 | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6M21 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.DA6U18 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6U18 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.DA6U19 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6U19 | 2021-06-18 08:57:59.099
SC Data - All Services | Real-time data for symbol F.US.DA6U20 is currently unavailable. | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6U20 | 2021-06-18 08:57:59.099
SC Data - All Services | Received security definition for symbol F.US.DA6U21 | 2021-06-18 08:57:59.100
SC Data - All Services | Real-time data for symbol F.US.DA6Z18 is currently unavailable. | 2021-06-18 08:57:59.100
SC Data - All Services | Received security definition for symbol F.US.DA6Z18 | 2021-06-18 08:57:59.100
SC DTC Data with Market Depth | Received security definition for symbol AUD-X | 2021-06-18 08:57:59.123
SC DTC Data with Market Depth | Received security definition for symbol AUDUSD | 2021-06-18 08:57:59.123
SC DTC Data with Market Depth | Received security definition for symbol CAD-X | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol CHF-X | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol EUR-X | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol EURGBP | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol GBP-X | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol GBPCAD | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol GBPUSD | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol JPY-X | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol NZD-X | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol USD-X | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol USDCAD | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol USDCHF | 2021-06-18 08:57:59.124
SC DTC Data with Market Depth | Received security definition for symbol USDJPY | 2021-06-18 08:57:59.124
SC Data - All Services | Real-time data for symbol F.US.DA6Z19 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.DA6Z19 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.DA6Z20 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.DA6Z20 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.ENQH19 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.ENQH19 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.ENQM18 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.ENQM18 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.ENQM19 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.ENQM19 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.ENQU18 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.ENQU18 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPH19 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPH19 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPH20 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPH20 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPH21 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPH21 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPM18 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPM18 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPM19 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPM19 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPM20 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPM20 | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPM21 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPU18 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPU18 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPU19 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPU19 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPU20 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPU20 | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPU21 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPZ18 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPZ18 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPZ19 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPZ19 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EPZ20 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EPZ20 | 2021-06-18 08:57:59.357
SC Data - All Services | Real-time data for symbol F.US.EU6H19 is currently unavailable. | 2021-06-18 08:57:59.357
SC Data - All Services | Received security definition for symbol F.US.EU6H19 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.EU6H20 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6H20 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.EU6M19 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6M19 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.EU6M20 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6M20 | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6M21 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.EU6U19 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6U19 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.EU6U20 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6U20 | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6U21 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.EU6Z18 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6Z18 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.EU6Z19 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6Z19 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.EU6Z20 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.EU6Z20 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.FVAH19 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAH19 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.FVAH21 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAH21 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.FVAM19 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAM19 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.FVAM20 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAM20 | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAM21 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.FVAU18 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAU18 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.FVAU19 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAU19 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.FVAU20 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAU20 | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAU21 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.FVAZ18 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAZ18 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.FVAZ19 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.FVAZ19 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.GCEG19 is currently unavailable. | 2021-06-18 08:57:59.358
SC Data - All Services | Received security definition for symbol F.US.GCEG19 | 2021-06-18 08:57:59.358
SC Data - All Services | Real-time data for symbol F.US.GCEG20 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEG20 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEJ18 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEJ18 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEJ19 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEJ19 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEJ20 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEJ20 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEJ21 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEJ21 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEM18 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEM18 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEM19 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEM19 | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEM21 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEQ18 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEQ18 | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEQ21 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEZ18 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEZ18 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEZ19 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEZ19 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GCEZ20 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEZ20 | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GCEZ21 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFF20 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFF20 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFF21 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFF21 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFH20 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFH20 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFJ19 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFJ19 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFJ20 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFJ20 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFQ18 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFQ18 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFQ19 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFQ19 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFQ20 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFQ20 | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFQ21 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFU19 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFU19 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFU20 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFU20 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFV18 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFV18 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFV19 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFV19 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFX18 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFX18 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFX19 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFX19 | 2021-06-18 08:57:59.359
SC Data - All Services | Real-time data for symbol F.US.GFX20 is currently unavailable. | 2021-06-18 08:57:59.359
SC Data - All Services | Received security definition for symbol F.US.GFX20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEG19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEG19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEG20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEG20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEG21 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEG21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEJ19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEJ19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEJ20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEJ20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEM19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEM19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEM20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEM20 | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEM21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEQ19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEQ19 | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEQ21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEV19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEV19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEV20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEV20 | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEV21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEZ18 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEZ18 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.GLEZ19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.GLEZ19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEG19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEG19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEG20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEG20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEJ19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEJ19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEJ21 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEJ21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEM19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEM19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEM20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEM20 | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEM21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEN18 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEN18 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEN19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEN19 | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEN21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEQ18 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEQ18 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEQ19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEQ19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEQ20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEQ20 | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEQ21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEV18 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEV18 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEV19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEV19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEV20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEV20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEZ18 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEZ18 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEZ19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEZ19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HEZ20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HEZ20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEF20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEF20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEF21 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEF21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEG20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEG20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEG21 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEG21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEH19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEH19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEH20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEH20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEH21 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEH21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEJ19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEJ19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEJ20 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEJ20 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEJ21 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEJ21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEK21 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEK21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEM19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEM19 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEM21 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEM21 | 2021-06-18 08:57:59.360
SC Data - All Services | Real-time data for symbol F.US.HOEN19 is currently unavailable. | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEN19 | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEN21 | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEQ21 | 2021-06-18 08:57:59.360
SC Data - All Services | Received security definition for symbol F.US.HOEU21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.HOEV18 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.HOEV18 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.HOEV19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.HOEV19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.HOEV20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.HOEV20 | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.HOEV21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.HOEX19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.HOEX19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.HOEZ18 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.HOEZ18 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.JY6H20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6H20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.JY6H21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6H21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.JY6M19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6M19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.JY6M20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6M20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.JY6U19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6U19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.JY6U20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6U20 | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6U21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.JY6Z18 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6Z18 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.JY6Z19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6Z19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.JY6Z20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.JY6Z20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEH19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEH19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEH20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEH20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEH21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEH21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEK19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEK19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEK20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEK20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEK21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEK21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEN19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEN19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEN20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEN20 | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEN21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEU19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEU19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEU20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEU20 | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEU21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEZ18 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEZ18 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEZ19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEZ19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.KWEZ20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEZ20 | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.KWEZ21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.LBSX19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.LBSX19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.M6AZ18 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.M6AZ18 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.M6EZ18 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.M6EZ18 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.MESM19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.MESM19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.MGCJ21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.MGCJ21 | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.MGCQ21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.MGCZ20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.MGCZ20 | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.MQIN21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.MQOM21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.MQOM21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NE6H20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6H20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NE6H21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6H21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NE6M19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6M19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NE6M20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6M20 | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6M21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NE6U19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6U19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NE6U20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6U20 | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6U21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NE6Z18 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6Z18 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NE6Z19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6Z19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NE6Z20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NE6Z20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEF19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEF19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEF20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEF20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEF21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEF21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEG20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEG20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEH20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEH20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEH21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEH21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEJ20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEJ20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEJ21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEJ21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEK20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEK20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEK21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEK21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEM19 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEM19 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEM20 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEM20 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEM21 is currently unavailable. | 2021-06-18 08:57:59.361
SC Data - All Services | Received security definition for symbol F.US.NGEM21 | 2021-06-18 08:57:59.361
SC Data - All Services | Real-time data for symbol F.US.NGEN20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEN20 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEN21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.NGEQ19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEQ19 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.NGEQ20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEQ20 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEQ21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.NGEU20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEU20 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEU21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.NGEV19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEV19 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.NGEV20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEV20 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEV21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.NGEX19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEX19 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.NGEX20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEX20 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEX21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.NGEZ19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEZ19 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.NGEZ20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.NGEZ20 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PAEH20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PAEH20 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PAEU21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PAEZ18 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PAEZ18 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEF19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEF19 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEF20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEF20 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEF21 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEF21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEJ19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEJ19 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEJ20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEJ20 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEJ21 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEJ21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEN19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEN19 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEN20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEN20 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEN21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEV19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEV19 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.PLEV20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEV20 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.PLEV21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEF20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEF20 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEG19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEG19 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEG21 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEG21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEH21 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEH21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEJ20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEJ20 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEJ21 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEJ21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEK21 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEK21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEM21 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEM21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEN19 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEN19 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEN21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEQ20 is currently unavailable. | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEQ20 | 2021-06-18 08:57:59.362
SC Data - All Services | Received security definition for symbol F.US.RBEQ21 | 2021-06-18 08:57:59.362
SC Data - All Services | Real-time data for symbol F.US.RBEU18 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.RBEU18 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.RBEU19 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.RBEU19 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.RBEU20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.RBEU20 | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.RBEU21 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.RBEV20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.RBEV20 | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.RBEV21 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.RBEX18 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.RBEX18 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.RBEX20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.RBEX20 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.RBEZ19 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.RBEZ19 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6H19 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6H19 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6H20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6H20 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6H21 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6H21 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6M19 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6M19 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6M20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6M20 | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6M21 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6U19 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6U19 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6U20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6U20 | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6U21 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6Z18 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6Z18 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6Z19 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6Z19 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SF6Z20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SF6Z20 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SIEH19 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEH19 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SIEH20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEH20 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SIEK19 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEK19 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SIEK20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEK20 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SIEK21 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEK21 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SIEN18 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEN18 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SIEN19 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEN19 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SIEN20 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEN20 | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEN21 | 2021-06-18 08:57:59.363
SC Data - All Services | Real-time data for symbol F.US.SIEU18 is currently unavailable. | 2021-06-18 08:57:59.363
SC Data - All Services | Received security definition for symbol F.US.SIEU18 | 2021-06-18 08:57:59.363
SC Data - All Services | Clearing market depth for F.US.TNAU21 | 2021-06-18 08:57:59.363
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TNAU21.2021-06-18.depth | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.SIEU19 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.SIEU19 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.SIEU20 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.SIEU20 | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.SIEU21 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.SIEZ18 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.SIEZ18 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAH19 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAH19 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAH20 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAH20 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAH21 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAH21 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAM18 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAM18 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAM19 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAM19 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAM20 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAM20 | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAM21 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAU18 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAU18 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAU19 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAU19 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAU20 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAU20 | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAU21 | 2021-06-18 08:57:59.364
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAH19.2021-06-18.depth | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAZ18 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAZ18 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAZ19 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAZ19 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TNAZ20 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TNAZ20 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TUAH19 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TUAH19 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TUAM19 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TUAM19 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TUAU19 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TUAU19 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TUAU20 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TUAU20 | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TUAU21 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TUAZ18 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TUAZ18 | 2021-06-18 08:57:59.364
SC Data - All Services | Real-time data for symbol F.US.TUAZ19 is currently unavailable. | 2021-06-18 08:57:59.364
SC Data - All Services | Received security definition for symbol F.US.TUAZ19 | 2021-06-18 08:57:59.364
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAH20.2021-06-18.depth | 2021-06-18 08:57:59.365
SC Data - All Services | Real-time data for symbol F.US.TYAH19 is currently unavailable. | 2021-06-18 08:57:59.365
SC Data - All Services | Received security definition for symbol F.US.TYAH19 | 2021-06-18 08:57:59.365
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAH21.2021-06-18.depth | 2021-06-18 08:57:59.365
SC Data - All Services | Real-time data for symbol F.US.TYAH20 is currently unavailable. | 2021-06-18 08:57:59.365
SC Data - All Services | Received security definition for symbol F.US.TYAH20 | 2021-06-18 08:57:59.365
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAM18.2021-06-18.depth | 2021-06-18 08:57:59.366
SC Data - All Services | Real-time data for symbol F.US.TYAH21 is currently unavailable. | 2021-06-18 08:57:59.366
SC Data - All Services | Received security definition for symbol F.US.TYAH21 | 2021-06-18 08:57:59.366
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAM19.2021-06-18.depth | 2021-06-18 08:57:59.366
SC Data - All Services | Real-time data for symbol F.US.TYAM18 is currently unavailable. | 2021-06-18 08:57:59.366
SC Data - All Services | Received security definition for symbol F.US.TYAM18 | 2021-06-18 08:57:59.366
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAM20.2021-06-18.depth | 2021-06-18 08:57:59.367
SC Data - All Services | Real-time data for symbol F.US.TYAM19 is currently unavailable. | 2021-06-18 08:57:59.367
SC Data - All Services | Received security definition for symbol F.US.TYAM19 | 2021-06-18 08:57:59.367
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAM21.2021-06-18.depth | 2021-06-18 08:57:59.367
SC Data - All Services | Real-time data for symbol F.US.TYAM20 is currently unavailable. | 2021-06-18 08:57:59.367
SC Data - All Services | Received security definition for symbol F.US.TYAM20 | 2021-06-18 08:57:59.367
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAU18.2021-06-18.depth | 2021-06-18 08:57:59.368
SC Data - All Services | Received security definition for symbol F.US.TYAM21 | 2021-06-18 08:57:59.368
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAU19.2021-06-18.depth | 2021-06-18 08:57:59.368
SC Data - All Services | Real-time data for symbol F.US.TYAU18 is currently unavailable. | 2021-06-18 08:57:59.368
SC Data - All Services | Received security definition for symbol F.US.TYAU18 | 2021-06-18 08:57:59.368
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAU20.2021-06-18.depth | 2021-06-18 08:57:59.369
SC Data - All Services | Real-time data for symbol F.US.TYAU19 is currently unavailable. | 2021-06-18 08:57:59.369
SC Data - All Services | Received security definition for symbol F.US.TYAU19 | 2021-06-18 08:57:59.369
SC Data - All Services | Clearing market depth for F.US.TYAU21 | 2021-06-18 08:57:59.369
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAU21.2021-06-18.depth | 2021-06-18 08:57:59.369
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAZ18.2021-06-18.depth | 2021-06-18 08:57:59.370
SC Data - All Services | Real-time data for symbol F.US.TYAU20 is currently unavailable. | 2021-06-18 08:57:59.370
SC Data - All Services | Received security definition for symbol F.US.TYAU20 | 2021-06-18 08:57:59.370
SC Data - All Services | Received security definition for symbol F.US.TYAU21 | 2021-06-18 08:57:59.370
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAZ19.2021-06-18.depth | 2021-06-18 08:57:59.370
SC Data - All Services | Real-time data for symbol F.US.TYAZ18 is currently unavailable. | 2021-06-18 08:57:59.370
SC Data - All Services | Received security definition for symbol F.US.TYAZ18 | 2021-06-18 08:57:59.370
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\F.US.TYAZ20.2021-06-18.depth | 2021-06-18 08:57:59.371
SC Data - All Services | Clearing market depth for F.US.USAU21 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.TYAZ19 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.TYAZ19 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.TYAZ20 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.TYAZ20 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.ULAH19 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAH19 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.ULAH21 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAH21 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.ULAM19 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAM19 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.ULAM20 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAM20 | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAM21 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.ULAU18 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAU18 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.ULAU19 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAU19 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.ULAU20 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAU20 | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAU21 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.ULAZ18 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAZ18 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.ULAZ19 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.ULAZ19 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.USAH19 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAH19 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.USAH20 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAH20 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.USAH21 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAH21 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.USAM18 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAM18 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.USAM19 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAM19 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.USAM20 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAM20 | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAM21 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.USAU19 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAU19 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.USAU20 is currently unavailable. | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAU20 | 2021-06-18 08:57:59.371
SC Data - All Services | Received security definition for symbol F.US.USAU21 | 2021-06-18 08:57:59.371
SC Data - All Services | Real-time data for symbol F.US.USAZ18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.USAZ18 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.USAZ19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.USAZ19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.USAZ20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.USAZ20 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.XCN18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.XCN18 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.XWN18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.XWN18 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMH19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMH19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMH20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMH20 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMH21 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMH21 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMM18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMM18 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMM21 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMU18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMU18 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMU19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMU19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMU20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMU20 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMU21 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMZ18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMZ18 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMZ19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMZ19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.YMZ20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.YMZ20 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEH19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEH19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEH20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEH20 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEH21 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEH21 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEH22 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEK19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEK19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEK20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEK20 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEK21 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEK21 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEN18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEN18 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEN19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEN19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEN20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEN20 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEN21 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEU18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEU18 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEU19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEU19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEU20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEU20 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEU21 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEZ18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEZ18 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEZ19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEZ19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZCEZ20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEZ20 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZCEZ21 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEF19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEF19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEF20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEF20 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEF21 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEF21 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEF22 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEH19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEH19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEH20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEH20 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEH21 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEH21 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEH22 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEK20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEK20 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEK21 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEK21 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEN18 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEN18 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEN19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEN19 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEN20 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEN20 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEN21 | 2021-06-18 08:57:59.372
SC Data - All Services | Real-time data for symbol F.US.ZLEQ19 is currently unavailable. | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEQ19 | 2021-06-18 08:57:59.372
SC Data - All Services | Received security definition for symbol F.US.ZLEQ21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZLEU20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZLEU20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZLEU21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZLEV20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZLEV20 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZLEZ18 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZLEZ18 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZLEZ19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZLEZ19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZLEZ20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZLEZ20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZLEZ21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEF21 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEF21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEH20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEH20 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEH21 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEH21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEK20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEK20 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEK21 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEK21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEN18 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEN18 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEN20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEN20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEN21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEQ19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEQ19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEQ20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEQ20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEQ21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEU19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEU19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEU20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEU20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEU21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEV19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEV19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEV20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEV20 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEZ18 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEZ18 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEZ19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEZ19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZMEZ20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEZ20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZMEZ21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZREX19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZREX19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEF20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEF20 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEF21 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEF21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEH20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEH20 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEH21 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEH21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEK19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEK19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEK20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEK20 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEK21 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEK21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEN18 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEN18 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEN19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEN19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEN20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEN20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEN21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEQ18 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEQ18 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEQ19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEQ19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEQ20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEQ20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEQ21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEU20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEU20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEU21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEX18 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEX18 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEX19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEX19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZSEX20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEX20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZSEX21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZWAH20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAH20 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZWAK20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAK20 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZWAK21 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAK21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZWAN18 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAN18 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZWAN19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAN19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZWAN20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAN20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAN21 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZWAU18 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAU18 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZWAU19 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAU19 | 2021-06-18 08:57:59.373
SC Data - All Services | Real-time data for symbol F.US.ZWAU20 is currently unavailable. | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAU20 | 2021-06-18 08:57:59.373
SC Data - All Services | Received security definition for symbol F.US.ZWAU21 | 2021-06-18 08:57:59.374
SC Data - All Services | Real-time data for symbol F.US.ZWAZ19 is currently unavailable. | 2021-06-18 08:57:59.374
SC Data - All Services | Received security definition for symbol F.US.ZWAZ19 | 2021-06-18 08:57:59.374
SC Data - All Services | Real-time data for symbol F.US.ZWAZ20 is currently unavailable. | 2021-06-18 08:57:59.374
SC Data - All Services | Received security definition for symbol F.US.ZWAZ20 | 2021-06-18 08:57:59.374
SC Data - All Services | Received security definition for symbol F.US.ZWAZ21 | 2021-06-18 08:57:59.374
Requesting market depth updates for: F.US.CA6U21 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.DDU21 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAH19 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAH20 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAH21 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAM18 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAM19 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAM20 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAM21 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAU18 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAU19 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAU20 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAZ18 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAZ19 if supported. | 2021-06-18 08:58:02.699
Requesting market depth updates for: F.US.TYAZ20 if supported. | 2021-06-18 08:58:02.699
SC Data - All Services | Clearing market depth for F.US.DDU21 | 2021-06-18 08:58:02.827
SC Data - All Services | Clearing market depth for F.US.CA6U21 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAH19 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAH20 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAH21 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAM18 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAM19 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAM20 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAM21 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAU18 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAU19 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAU20 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAZ18 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAZ19 | 2021-06-18 08:58:02.852
SC Data - All Services | Clearing market depth for F.US.TYAZ20 | 2021-06-18 08:58:02.852
CQG WebAPI | Sending positions subscribe request. RequestID: 75461 | 2021-06-18 08:58:02.866
CQG WebAPI | Sending orders subscribe request. RequestID: 75462 | 2021-06-18 08:58:02.866
HD Request # 1139 | Downloading Intraday chart data for F.US.CA6U21 to the file F.US.CA6U21.scid. Service: cme | 2021-06-18 08:58:04.835
HD Request # 1139 | Download start date-time: 2021-06-18 08:56:52.000000. File last date-time: 2021-06-18 08:56:52.124000 | 2021-06-18 08:58:04.836
HD Request # 1139 | Using server: ds23.sierracharts.com port 10149 | 2021-06-18 08:58:04.836
Socket (11) | Creating socket. | 2021-06-18 08:58:04.836
Socket (11) | New receive buffer size: 5242880 | 2021-06-18 08:58:04.836
Socket (11) | Connecting to IP: 216.1.90.130. | 2021-06-18 08:58:04.836
HD Request # 1139 | Setting DTC encoding to Binary VLS | 2021-06-18 08:58:05.108
HD Request # 1139 | Sending historical data logon request message. | 2021-06-18 08:58:05.108
HD Request # 1139 | Requesting Intraday data. Start date-time: 2021-06-18 08:56:52. Record interval: 0. Symbol: 6CU21 | 2021-06-18 08:58:05.237
HD Request # 1139 | Decompressing data. | 2021-06-18 08:58:05.368
HD Request # 1139 | Receiving Intraday data for F.US.CA6U21 starting at 2021-06-18 08:56:52.124000 | 2021-06-18 08:58:05.369
Socket (11) | CloseSocket call. | 2021-06-18 08:58:05.370
Socket (11) | Shutdown started. Waiting for graceful close. | 2021-06-18 08:58:05.370
Historical data download thread signaled to stop. | 2021-06-18 08:58:05.370
HD Request # 1139 | Timestamp of first Intraday data file record written: 2021-06-18 08:57:00.322000 | 2021-06-18 08:58:05.370
HD Request # 1139 | Received 88 records from 2021-06-18 08:56:52.124000 to 2021-06-18 08:58:01.007000 (68.9 seconds) and wrote 87 records for F.US.CA6U21 | 2021-06-18 08:58:05.371
HD Request # 1139 | Add time&sales data | Remembered last file record date-time: 2021-06-18 06:58:01.007000 | 2021-06-18 08:58:05.371
Added 3 Time and Sales records to Intraday data file for F.US.CA6U21 after download. | 2021-06-18 08:58:05.371
HD Request # 1139 | Completion time: 1s | 2021-06-18 08:58:05.371
HD Request # 1139 | Intraday data download complete for F.US.CA6U21. Unique request ID: 996 | 2021-06-18 08:58:05.371
Removing historical data download ID 996. | 2021-06-18 08:58:05.371
Real-time Intraday chart data file updates started for F.US.CA6U21 | 2021-06-18 08:58:05.371
Intraday chart data file opened for F.US.CA6U21 | 2021-06-18 08:58:05.371
HD Request # 1139 | Enabling Intraday chart updating for symbol. | 2021-06-18 08:58:05.371
Triggering next historical data download in queue. | 2021-06-18 08:58:05.371
HD Request # 1140 | Downloading Intraday chart data for F.US.TNAU21 to the file F.US.TNAU21.scid. Service: cbot | 2021-06-18 08:58:05.372
HD Request # 1140 | Download start date-time: 2021-06-18 08:55:48.000000. File last date-time: 2021-06-18 08:55:48.506000 | 2021-06-18 08:58:05.372
HD Request # 1140 | Using server: ds21.sierracharts.com port 10150 | 2021-06-18 08:58:05.372
Socket (15) | Creating socket. | 2021-06-18 08:58:05.372
Socket (15) | New receive buffer size: 5242880 | 2021-06-18 08:58:05.373
Socket (15) | Connecting to IP: 216.1.90.129. | 2021-06-18 08:58:05.373
DTC client #28. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.CA6U21 | 2021-06-18 08:58:05.373
DTC client #27. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.CA6U21 | 2021-06-18 08:58:05.388
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=7, NumberOfOutstandingSendBuffers=2, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=5542, ActualMessageDelay=-0.1 seconds, DataCompRatio=3.18, UncompressedBytes=439778, CompressionTime=0.002878(secs), NumCompressions=60 | 2021-06-18 08:58:05.446
Socket (11) | Socket gracefully closed by remote side. | 2021-06-18 08:58:05.499
Socket (11) | Closed. | 2021-06-18 08:58:05.499
HD Request # 1140 | Setting DTC encoding to Binary VLS | 2021-06-18 08:58:05.642
HD Request # 1140 | Sending historical data logon request message. | 2021-06-18 08:58:05.642
Chart #2 has tagged chart #8 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.710
Chart #4 has tagged chart #13 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.854
Chart #4 has tagged chart #3 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.854
Chart #4 has tagged chart #6 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.854
Chart #4 has tagged chart #7 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.854
F.US.CA6U21[M] 240 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.896
Chart #6 has tagged chart #12 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.896
Chart #6 has tagged chart #7 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.896
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.897
Chart #2 has tagged chart #6 for full recalculation. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.897
Chart #5 has tagged chart #10 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.900
Chart #5 has tagged chart #11 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.900
Chart #8 has tagged chart #5 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.900
Chart #3 has tagged chart #1 for full recalculation. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.900
Chart #3 has tagged chart #2 for full recalculation. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.900
Chart #3 has tagged chart #6 for full recalculation. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.900
F.US.CA6U21[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.901
Chart #10 has tagged chart #2 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.902
Chart #10 has tagged chart #4 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.902
Chart #10 has tagged chart #5 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.902
Chart #10 has tagged chart #6 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.902
Chart #10 has tagged chart #7 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.902
F.US.CA6U21[M] 1 Day #7 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.902
Chart #7 has tagged chart #1 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.903
Chart #7 has tagged chart #12 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.903
Chart #7 has tagged chart #4 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.903
Chart #7 has tagged chart #9 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.903
F.US.CA6U21[M] #3 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:05.903
F.US.CA6U21[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:05.925
HD Request # 1140 | Requesting Intraday data. Start date-time: 2021-06-18 08:55:48. Record interval: 0. Symbol: TNU21 | 2021-06-18 08:58:06.229
F.US.CA6U21[M] 240 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.269
F.US.CA6U21[M] 1 Day #8 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.271
F.US.CA6U21[M] #12 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:06.271
F.US.CA6U21[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.278
F.US.CA6U21[M] 1 Day #4 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:06.284
F.US.CA6U21[M] 240 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:06.285
F.US.CA6U21[M] #11 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:06.285
Chart #10 has tagged chart #12 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.287
Chart #10 has tagged chart #13 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.287
Chart #10 has tagged chart #3 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.287
Chart #10 has tagged chart #4 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.287
Chart #10 has tagged chart #5 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.287
Chart #10 has tagged chart #6 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.287
Chart #10 has tagged chart #7 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.287
Chart #10 has tagged chart #8 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.287
Chart #10 has tagged chart #9 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.287
F.US.CA6U21[M] 240 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.288
Chart: F.US.CA6U21[M] 240 Min #12 | Study: ASK Circles | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2021-06-18 08:58:06.289 *
Chart: F.US.CA6U21[M] 240 Min #12 | Study: BID Circles | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2021-06-18 08:58:06.289 *
Chart #12 has tagged chart #13 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.289
F.US.CA6U21[M] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.289
F.US.CA6U21[M] 1 Day #6 | Performing a full recalculation because it has been tagged. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.292
HD Request # 1140 | Decompressing data. | 2021-06-18 08:58:06.361
HD Request # 1140 | Receiving Intraday data for F.US.TNAU21 starting at 2021-06-18 08:55:48.501000 | 2021-06-18 08:58:06.362
Socket (15) | CloseSocket call. | 2021-06-18 08:58:06.363
Socket (15) | Shutdown started. Waiting for graceful close. | 2021-06-18 08:58:06.363
Historical data download thread signaled to stop. | 2021-06-18 08:58:06.363
HD Request # 1140 | Timestamp of first Intraday data file record written: 2021-06-18 08:57:01.943000 | 2021-06-18 08:58:06.363
HD Request # 1140 | Received 163 records from 2021-06-18 08:55:48.501000 to 2021-06-18 08:58:00.901002 (2.2 minutes) and wrote 154 records for F.US.TNAU21 | 2021-06-18 08:58:06.363
HD Request # 1140 | Add time&sales data | Remembered last file record date-time: 2021-06-18 06:58:00.901002 | 2021-06-18 08:58:06.364
HD Request # 1140 | Completion time: 1s | 2021-06-18 08:58:06.364
HD Request # 1140 | Intraday data download complete for F.US.TNAU21. Unique request ID: 997 | 2021-06-18 08:58:06.364
Removing historical data download ID 997. | 2021-06-18 08:58:06.364
Real-time Intraday chart data file updates started for F.US.TNAU21 | 2021-06-18 08:58:06.364
Intraday chart data file opened for F.US.TNAU21 | 2021-06-18 08:58:06.364
HD Request # 1140 | Enabling Intraday chart updating for symbol. | 2021-06-18 08:58:06.364
Triggering next historical data download in queue. | 2021-06-18 08:58:06.364
HD Request # 1141 | Downloading Intraday chart data for F.US.DSXU21 to the file F.US.DSXU21.scid. Service: eurex | 2021-06-18 08:58:06.364
HD Request # 1141 | Download start date-time: 2021-06-18 08:56:48.000000. File last date-time: 2021-06-18 08:56:48.560000 | 2021-06-18 08:58:06.365
HD Request # 1141 | Using server: ds24.sierracharts.com port 10149 | 2021-06-18 08:58:06.365
Socket (11) | Creating socket. | 2021-06-18 08:58:06.365
Socket (11) | New receive buffer size: 5242880 | 2021-06-18 08:58:06.365
Socket (11) | Connecting to IP: 80.81.77.132. | 2021-06-18 08:58:06.365
DTC client #27. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.TNAU21 | 2021-06-18 08:58:06.366
DTC client #28. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.TNAU21 | 2021-06-18 08:58:06.366
HD Request # 1141 | Setting DTC encoding to Binary VLS | 2021-06-18 08:58:06.424
HD Request # 1141 | Sending historical data logon request message. | 2021-06-18 08:58:06.424
HD Request # 1141 | Requesting Intraday data. Start date-time: 2021-06-18 08:56:48. Record interval: 0. Symbol: FESX202109_FUT_EUREX | 2021-06-18 08:58:06.452
HD Request # 1141 | Decompressing data. | 2021-06-18 08:58:06.486
HD Request # 1141 | Receiving Intraday data for F.US.DSXU21 starting at 2021-06-18 08:56:48.560000 | 2021-06-18 08:58:06.486
Socket (11) | CloseSocket call. | 2021-06-18 08:58:06.487
Socket (11) | Shutdown started. Waiting for graceful close. | 2021-06-18 08:58:06.487
Chart #5 has tagged chart #10 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.487
Historical data download thread signaled to stop. | 2021-06-18 08:58:06.487
HD Request # 1141 | Timestamp of first Intraday data file record written: 2021-06-18 08:57:00.240000 | 2021-06-18 08:58:06.488
HD Request # 1141 | Received 20 records from 2021-06-18 08:56:48.560000 to 2021-06-18 08:58:05.024000 (76.5 seconds) and wrote 19 records for F.US.DSXU21 | 2021-06-18 08:58:06.488
HD Request # 1141 | Add time&sales data | Remembered last file record date-time: 2021-06-18 06:58:05.024000 | 2021-06-18 08:58:06.488
Added 2 Time and Sales records to Intraday data file for F.US.DSXU21 after download. | 2021-06-18 08:58:06.488
HD Request # 1141 | Completion time: 0s | 2021-06-18 08:58:06.489
HD Request # 1141 | Intraday data download complete for F.US.DSXU21. Unique request ID: 998 | 2021-06-18 08:58:06.489
Removing historical data download ID 998. | 2021-06-18 08:58:06.489
Real-time Intraday chart data file updates started for F.US.DSXU21 | 2021-06-18 08:58:06.489
Intraday chart data file opened for F.US.DSXU21 | 2021-06-18 08:58:06.489
HD Request # 1141 | Enabling Intraday chart updating for symbol. | 2021-06-18 08:58:06.489
Triggering next historical data download in queue. | 2021-06-18 08:58:06.489
HD Request # 1142 | Downloading Intraday chart data for F.US.DDU21 to the file F.US.DDU21.scid. Service: eurex | 2021-06-18 08:58:06.489
HD Request # 1142 | Download start date-time: 2021-06-18 08:56:55.000000. File last date-time: 2021-06-18 08:56:55.361000 | 2021-06-18 08:58:06.489
HD Request # 1142 | Using server: ds14.sierracharts.com port 10150 | 2021-06-18 08:58:06.489
Socket (16) | Creating socket. | 2021-06-18 08:58:06.490
Socket (16) | New receive buffer size: 5242880 | 2021-06-18 08:58:06.490
Socket (16) | Connecting to IP: 157.90.1.40. | 2021-06-18 08:58:06.490
Socket (15) | Socket gracefully closed by remote side. | 2021-06-18 08:58:06.494
Socket (15) | Closed. | 2021-06-18 08:58:06.494
DTC client #27. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.DSXU21 | 2021-06-18 08:58:06.499
DTC client #28. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.DSXU21 | 2021-06-18 08:58:06.508
Socket (11) | Socket gracefully closed by remote side. | 2021-06-18 08:58:06.515
Socket (11) | Closed. | 2021-06-18 08:58:06.515
HD Request # 1142 | Setting DTC encoding to Binary VLS | 2021-06-18 08:58:06.558
HD Request # 1142 | Sending historical data logon request message. | 2021-06-18 08:58:06.558
HD Request # 1142 | Requesting Intraday data. Start date-time: 2021-06-18 08:56:55. Record interval: 0. Symbol: FDAX202109_FUT_EUREX | 2021-06-18 08:58:06.710
Chart #7 has tagged chart #1 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.725
Chart #7 has tagged chart #11 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.725
Chart #7 has tagged chart #12 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.725
Chart #7 has tagged chart #4 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.725
Chart #3 has tagged chart #1 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.743
Chart #3 has tagged chart #11 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.743
Chart #3 has tagged chart #16 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.743
Chart #3 has tagged chart #9 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.743
HD Request # 1142 | Decompressing data. | 2021-06-18 08:58:06.748
HD Request # 1142 | Receiving Intraday data for F.US.DDU21 starting at 2021-06-18 08:56:55.361000 | 2021-06-18 08:58:06.748
Socket (16) | CloseSocket call. | 2021-06-18 08:58:06.749
Socket (16) | Shutdown started. Waiting for graceful close. | 2021-06-18 08:58:06.749
Chart #12 has tagged chart #14 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.749
Chart #12 has tagged chart #2 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.749
Historical data download thread signaled to stop. | 2021-06-18 08:58:06.749
HD Request # 1142 | Timestamp of first Intraday data file record written: 2021-06-18 08:57:05.644000 | 2021-06-18 08:58:06.749
HD Request # 1142 | Received 42 records from 2021-06-18 08:56:55.361000 to 2021-06-18 08:58:03.104000 (67.7 seconds) and wrote 41 records for F.US.DDU21 | 2021-06-18 08:58:06.749
HD Request # 1142 | Add time&sales data | Remembered last file record date-time: 2021-06-18 06:58:03.104000 | 2021-06-18 08:58:06.750
HD Request # 1142 | Completion time: 0s | 2021-06-18 08:58:06.750
HD Request # 1142 | Intraday data download complete for F.US.DDU21. Unique request ID: 999 | 2021-06-18 08:58:06.750
Removing historical data download ID 999. | 2021-06-18 08:58:06.750
Real-time Intraday chart data file updates started for F.US.DDU21 | 2021-06-18 08:58:06.750
Intraday chart data file opened for F.US.DDU21 | 2021-06-18 08:58:06.750
HD Request # 1142 | Enabling Intraday chart updating for symbol. | 2021-06-18 08:58:06.750
Triggering next historical data download in queue. | 2021-06-18 08:58:06.750
HD Request # 1143 | Downloading Intraday chart data for F.US.TYAU21 to the file F.US.TYAU21.scid. Service: cbot | 2021-06-18 08:58:06.750
HD Request # 1143 | Download start date-time: 2021-06-18 08:56:55.000000. File last date-time: 2021-06-18 08:56:55.049003 | 2021-06-18 08:58:06.751
HD Request # 1143 | Using server: ds23.sierracharts.com port 10149 | 2021-06-18 08:58:06.752
Socket (11) | Creating socket. | 2021-06-18 08:58:06.752
Socket (11) | New receive buffer size: 5242880 | 2021-06-18 08:58:06.752
Socket (11) | Connecting to IP: 216.1.90.130. | 2021-06-18 08:58:06.752
DTC client #28. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.DDU21 | 2021-06-18 08:58:06.753
F.US.TNAU21[M] 240 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.754
DTC client #27. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.DDU21 | 2021-06-18 08:58:06.755
Chart #8 has tagged chart #13 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.756
Chart #8 has tagged chart #5 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.756
Chart #10 has tagged chart #6 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.764
F.US.TNAU21[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.765
Chart #10 has tagged chart #6 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.765
F.US.DSXU21[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.771
Socket (16) | Socket gracefully closed by remote side. | 2021-06-18 08:58:06.782
Socket (16) | Closed. | 2021-06-18 08:58:06.782
Chart #12 has tagged chart #2 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.801
Chart #3 has tagged chart #11 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.802
Chart #3 has tagged chart #9 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.802
F.US.DDU21[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.802
Chart #2 has tagged chart #7 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.804
Chart #10 has tagged chart #6 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.804
Chart #8 has tagged chart #13 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.804
Chart #8 has tagged chart #5 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.804
F.US.DSXU21[M] #11 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.805
Chart #4 has tagged chart #1 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
Chart #4 has tagged chart #10 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
Chart #4 has tagged chart #11 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
Chart #4 has tagged chart #13 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
Chart #4 has tagged chart #14 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
Chart #4 has tagged chart #16 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
Chart #4 has tagged chart #2 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
Chart #4 has tagged chart #3 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
Chart #4 has tagged chart #5 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
Chart #4 has tagged chart #6 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.839
F.US.DSXU21[M] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.840
Chart #13 has tagged chart #7 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.841
Chart #8 has tagged chart #5 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.842
F.US.TNAU21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.845
F.US.TNAU21[M] #12 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.852
Chart #3 has tagged chart #12 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.864
Chart #3 has tagged chart #2 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.864
Chart #3 has tagged chart #5 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.864
Chart #3 has tagged chart #6 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.864
Chart #3 has tagged chart #7 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.864
F.US.DDU21[M] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.864
Chart #5 has tagged chart #10 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
Chart #5 has tagged chart #14 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
Chart #5 has tagged chart #2 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
Chart #5 has tagged chart #9 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
Chart #4 has tagged chart #10 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
Chart #4 has tagged chart #11 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
Chart #4 has tagged chart #13 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
Chart #4 has tagged chart #2 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
Chart #4 has tagged chart #5 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
Chart #4 has tagged chart #6 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
F.US.DSXU21[M] 240 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.865
F.US.DSXU21[M] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.871
Chart #5 has tagged chart #10 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.873
Chart #5 has tagged chart #14 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.873
Chart #5 has tagged chart #2 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.873
Chart #5 has tagged chart #9 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.873
F.US.CA6U21[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:06.885
F.US.CA6U21[M] 1 Day #4 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.886
Chart #4 has tagged chart #13 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.886
Chart #4 has tagged chart #3 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.886
Chart #4 has tagged chart #6 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.886
Chart #4 has tagged chart #7 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.886
F.US.DSXU21[M] #16 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.886
F.US.DSXU21[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:06.887
F.US.TNAU21[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.895
F.US.TNAU21[M] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.895
Chart #5 has tagged chart #10 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:06.897
F.US.CA6U21[M] 1 Day #5 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.908
F.US.CA6U21[M] 240 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.909
Chart #6 has tagged chart #12 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.909
Chart #6 has tagged chart #7 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.909
F.US.CA6U21[M] 1 Day #2 | Performing a full recalculation because it has been tagged. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.910
Chart #2 has tagged chart #1 for full recalculation. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.910
Chart #2 has tagged chart #6 for full recalculation. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.910
F.US.CA6U21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:06.911
F.US.CA6U21[M] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:06.918
Chart #5 has tagged chart #11 for full recalculation. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:06.920
F.US.CA6U21[M] #3 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:06.923
HD Request # 1143 | Setting DTC encoding to Binary VLS | 2021-06-18 08:58:07.032
HD Request # 1143 | Sending historical data logon request message. | 2021-06-18 08:58:07.032
HD Request # 1143 | Requesting Intraday data. Start date-time: 2021-06-18 08:56:55. Record interval: 0. Symbol: ZNU21 | 2021-06-18 08:58:07.167
F.US.CA6U21[M] 240 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:07.267
F.US.CA6U21[M] 1 Day #8 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:07.269
F.US.CA6U21[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:07.269
F.US.CA6U21[M] #11 | Performing a full recalculation because it has been tagged. Chartbook: INTRADAY Tracker V4 02-21.Cht | 2021-06-18 08:58:07.277
F.US.CA6U21[M] 240 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:07.278
F.US.CA6U21[M] 240 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:07.279
Chart: F.US.CA6U21[M] 240 Min #12 | Study: ASK Circles | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2021-06-18 08:58:07.280 *
Chart: F.US.CA6U21[M] 240 Min #12 | Study: BID Circles | You are not allowed to use this study. Contact frederik@simplesystemtrading.com to discuss authorization | 2021-06-18 08:58:07.280 *
Chart #12 has tagged chart #13 for full recalculation. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:07.280
F.US.CA6U21[M] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: ToD Weekly-3T-FUTS V4 02-21.Cht | 2021-06-18 08:58:07.280
F.US.CA6U21[M] 1 Day #6 | Performing a full recalculation because it has been tagged. Chartbook: Delta-Profile-FUTS V4 02-21.Cht | 2021-06-18 08:58:07.286
HD Request # 1143 | Decompressing data. | 2021-06-18 08:58:07.303
HD Request # 1143 | Receiving Intraday data for F.US.TYAU21 starting at 2021-06-18 08:56:55.049000 | 2021-06-18 08:58:07.305
Socket (11) | CloseSocket call. | 2021-06-18 08:58:07.306
Historical data download thread signaled to stop. | 2021-06-18 08:58:07.306
Socket (11) | Shutdown started. Waiting for graceful close. | 2021-06-18 08:58:07.306
HD Request # 1143 | Timestamp of first Intraday data file record written: 2021-06-18 08:57:00.528000 | 2021-06-18 08:58:07.306
HD Request # 1143 | Received 369 records from 2021-06-18 08:56:55.049000 to 2021-06-18 08:58:00.848007 (65.8 seconds) and wrote 365 records for F.US.TYAU21 | 2021-06-18 08:58:07.306
HD Request # 1143 | Add time&sales data | Remembered last file record date-time: 2021-06-18 06:58:00.848007 | 2021-06-18 08:58:07.307
HD Request # 1143 | Completion time: 1s | 2021-06-18 08:58:07.307
HD Request # 1143 | Intraday data download complete for F.US.TYAU21. Unique request ID: 1000 | 2021-06-18 08:58:07.307
Removing historical data download ID 1000. | 2021-06-18 08:58:07.307
Real-time Intraday chart data file updates started for F.US.TYAU21 | 2021-06-18 08:58:07.307
Intraday chart data file opened for F.US.TYAU21 | 2021-06-18 08:58:07.307
HD Request # 1143 | Enabling Intraday chart updating for symbol. | 2021-06-18 08:58:07.307
Triggering next historical data download in queue. | 2021-06-18 08:58:07.307
HD Request # 1144 | Downloading Intraday chart data for F.US.RBEV21 to the file F.US.RBEV21.scid. Service: nymex | 2021-06-18 08:58:07.307
HD Request # 1144 | Download start date-time: 2021-06-17 22:50:05.000000. File last date-time: 2021-06-17 22:50:05.508000 | 2021-06-18 08:58:07.307
HD Request # 1144 | Using server: ds21.sierracharts.com port 10150 | 2021-06-18 08:58:07.307
Socket (15) | Creating socket. | 2021-06-18 08:58:07.308
Socket (15) | New receive buffer size: 5242880 | 2021-06-18 08:58:07.308
Socket (15) | Connecting to IP: 216.1.90.129. | 2021-06-18 08:58:07.308
DTC client #27. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.TYAU21 | 2021-06-18 08:58:07.309
DTC client #28. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.TYAU21 | 2021-06-18 08:58:07.310
Chart #5 has tagged chart #10 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.424
Socket (11) | Socket gracefully closed by remote side. | 2021-06-18 08:58:07.441
Socket (11) | Closed. | 2021-06-18 08:58:07.441
HD Request # 1144 | Setting DTC encoding to Binary VLS | 2021-06-18 08:58:07.564
HD Request # 1144 | Sending historical data logon request message. | 2021-06-18 08:58:07.564
HD Request # 1144 | Requesting Intraday data. Start date-time: 2021-06-17 22:50:05. Record interval: 0. Symbol: RBV21 | 2021-06-18 08:58:07.690
F.US.TNAU21[M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.724
F.US.TNAU21[M] 1 Day #7 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.737
Chart #7 has tagged chart #1 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.738
Chart #7 has tagged chart #11 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.738
Chart #7 has tagged chart #12 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.738
Chart #7 has tagged chart #4 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.738
F.US.DSXU21[M] 1 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.738
F.US.TNAU21[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.748
F.US.DDU21[M] #11 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.751
F.US.DDU21[M] #14 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.757
F.US.DSXU21[M] 30 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.757
F.US.DSXU21[M] 1 Day #3 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.772
Chart #3 has tagged chart #1 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.773
Chart #3 has tagged chart #11 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.773
Chart #3 has tagged chart #16 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.773
Chart #3 has tagged chart #9 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.773
Chart #8 has tagged chart #5 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.778
F.US.TNAU21[M] 240 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.778
F.US.DSXU21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.781
F.US.DSXU21[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.791
Chart #10 has tagged chart #6 for full recalculation. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.793
F.US.TNAU21[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.794
Chart #10 has tagged chart #6 for full recalculation. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.794
F.US.DDU21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.795
F.US.DDU21[M] 240 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.798
F.US.DDU21[M] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.799
F.US.TYAU21[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.802
Chart #10 has tagged chart #6 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.803
Chart #3 has tagged chart #12 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.803
Chart #3 has tagged chart #2 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.803
Chart #3 has tagged chart #5 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.803
Chart #3 has tagged chart #6 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.803
Chart #3 has tagged chart #7 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.803
F.US.DSXU21[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.804
F.US.DSXU21[M] 1 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.812
HD Request # 1144 | Decompressing data. | 2021-06-18 08:58:07.815
HD Request # 1144 | Receiving Intraday data for F.US.RBEV21 starting at 2021-06-17 22:50:05.508000 | 2021-06-18 08:58:07.816
Socket (15) | CloseSocket call. | 2021-06-18 08:58:07.816
Socket (15) | Shutdown started. Waiting for graceful close. | 2021-06-18 08:58:07.816
Historical data download thread signaled to stop. | 2021-06-18 08:58:07.840
HD Request # 1144 | Received 1 record from 2021-06-17 22:50:05.508000 to 2021-06-17 22:50:05.508000 (0.0 seconds) and wrote 0 records for F.US.RBEV21 | 2021-06-18 08:58:07.840
HD Request # 1144 | Add time&sales data | Remembered last file record date-time: 2021-06-17 20:50:05.508000 | 2021-06-18 08:58:07.841
HD Request # 1144 | Completion time: 0s | 2021-06-18 08:58:07.841
HD Request # 1144 | Intraday data download complete for F.US.RBEV21. Unique request ID: 1001 | 2021-06-18 08:58:07.841
Removing historical data download ID 1001. | 2021-06-18 08:58:07.841
Real-time Intraday chart data file updates started for F.US.RBEV21 | 2021-06-18 08:58:07.841
Intraday chart data file opened for F.US.RBEV21 | 2021-06-18 08:58:07.841
HD Request # 1144 | Enabling Intraday chart updating for symbol. | 2021-06-18 08:58:07.841
Triggering next historical data download in queue. | 2021-06-18 08:58:07.841
No download requests in the queue to start downloads for. | 2021-06-18 08:58:07.841
F.US.TYAU21[M] 1 Day #7 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.842
Chart #7 has tagged chart #1 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.842
Chart #7 has tagged chart #11 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.842
Chart #7 has tagged chart #12 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.842
Chart #7 has tagged chart #4 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.842
DTC client #28. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.RBEV21 | 2021-06-18 08:58:07.842
Requesting market depth updates for: F.US.RBEV21 if supported. | 2021-06-18 08:58:07.843
F.US.DDU21[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.844
Chart #2 has tagged chart #7 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.846
DTC client #27. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol F.US.RBEV21 | 2021-06-18 08:58:07.846
F.US.DDU21[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.847
Chart #10 has tagged chart #6 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.850
F.US.DSXU21[M] #11 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.850
F.US.TYAU21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.891
F.US.TNAU21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.898
F.US.TNAU21[M] #12 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.902
F.US.DDU21[M] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.914
Chart #5 has tagged chart #10 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.915
Chart #5 has tagged chart #14 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.915
Chart #5 has tagged chart #2 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.915
Chart #5 has tagged chart #9 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:07.915
F.US.DSXU21[M] 240 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.915
F.US.DSXU21[M] #16 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.936
F.US.DSXU21[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:07.936
Socket (15) | Socket gracefully closed by remote side. | 2021-06-18 08:58:07.940
Socket (15) | Closed. | 2021-06-18 08:58:07.940
F.US.TYAU21[M] 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.944
Chart #5 has tagged chart #10 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.945
F.US.TYAU21[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:07.945
F.US.TNAU21[M] #1 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:07.946
SC Data - All Services | Clearing market depth for F.US.RBEV21 | 2021-06-18 08:58:08.042
SC DTC Data with Market Depth | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=9, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=786, ActualMessageDelay=-0.9 seconds, DataCompRatio=1.92, UncompressedBytes=11452, CompressionTime=0.000192(secs), NumCompressions=48 | 2021-06-18 08:58:08.089
F.US.TNAU21[M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: TN intra V4 02-21.cht | 2021-06-18 08:58:08.721
F.US.DSXU21[M] 1 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:08.732
F.US.DDU21[M] #14 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:08.744
Chart #9 has tagged chart #10 for full recalculation. Chartbook: ToW-ToM-Quad-3T-VERTICAL-Hist-FUTS V4 02-21.Cht | 2021-06-18 08:58:08.766
Chart #9 has tagged chart #11 for full recalculation. Chartbook: ToW-ToM-Quad-3T-VERTICAL-Hist-FUTS V4 02-21.Cht | 2021-06-18 08:58:08.766
F.US.TYAU21[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:08.766
F.US.DSXU21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: FESX intra V4 02-21.Cht | 2021-06-18 08:58:08.769
F.US.TYAU21[M] 240 Min #11 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:08.778
F.US.DDU21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:08.779
F.US.DDU21[M] 240 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:08.784
F.US.TYAU21[M] #12 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:08.785
F.US.TYAU21[M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:08.798
F.US.TYAU21[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:08.809
Chart #10 has tagged chart #6 for full recalculation. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:08.809
F.US.DDU21[M] 30 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:08.847
Chart #2 has tagged chart #7 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:08.849
F.US.DDU21[M] 5 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:08.849
Chart #10 has tagged chart #6 for full recalculation. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:08.851
F.US.RBEV21[M] 1 Day #11 | Performing a full recalculation because it has been tagged. Chartbook: ToW-ToM-Quad-3T-VERTICAL-Hist-FUTS V4 02-21.Cht | 2021-06-18 08:58:08.851
F.US.TYAU21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: ZN intra V4 02-21.cht | 2021-06-18 08:58:08.883
F.US.RBEV21[M] Daily #10 | Performing a full recalculation because it has been tagged. Chartbook: ToW-ToM-Quad-3T-VERTICAL-Hist-FUTS V4 02-21.Cht | 2021-06-18 08:58:08.911
Chart #10 has tagged chart #11 for full recalculation. Chartbook: ToW-ToM-Quad-3T-VERTICAL-Hist-FUTS V4 02-21.Cht | 2021-06-18 08:58:08.912
F.US.DSXU21[M] 1 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:09.718
F.US.DDU21[M] 5 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: DAX intra V4 02-21.Cht | 2021-06-18 08:58:09.763
F.US.RBEV21[M] 1 Day #11 | Performing a full recalculation because it has been tagged. Chartbook: ToW-ToM-Quad-3T-VERTICAL-Hist-FUTS V4 02-21.Cht | 2021-06-18 08:58:09.800
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=12, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=376, ActualMessageDelay=-0.1 seconds, DataCompRatio=2.86, UncompressedBytes=110104, CompressionTime=0.000362(secs), NumCompressions=58 | 2021-06-18 08:58:10.512
Opened cached Intraday file: C:\SierraChart\Data\F.US.DSXU21.scid. Thread ID: 14488 | 2021-06-18 08:58:11.402
Opened cached Intraday file: C:\SierraChart\Data\F.US.CA6U21.scid. Thread ID: 14488 | 2021-06-18 08:58:11.402
Unsubscribed from market depth data for F.US.RBEV21 | 2021-06-18 08:58:12.704
Opened cached Intraday file: C:\SierraChart\Data\F.US.DDU21.scid. Thread ID: 14488 | 2021-06-18 08:58:16.443
DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-06-18 08:58:19.466
DTC Client socket (4) | Closed. | 2021-06-18 08:58:19.466
DTC Client socket (6) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-06-18 08:58:19.466
DTC Client socket (6) | Closed. | 2021-06-18 08:58:19.466
CQG WebSocket socket (9) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-06-18 08:58:19.466
CQG WebSocket socket (9) | Closed. | 2021-06-18 08:58:19.466
Opened cached Intraday file: C:\SierraChart\Data\F.US.TYAU21.scid. Thread ID: 14488 | 2021-06-18 08:58:21.500
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=6, NumberOfOutstandingSendBuffers=1, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=1206, ActualMessageDelay=-0.1 seconds, DataCompRatio=2.65, UncompressedBytes=756839, CompressionTime=0.006310(secs), NumCompressions=228 | 2021-06-18 08:58:25.370
SC DTC Data with Market Depth | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=8, NumberOfOutstandingSendBuffers=2, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=331, ActualMessageDelay=-0.8 seconds, DataCompRatio=1.69, UncompressedBytes=25566, CompressionTime=0.000537(secs), NumCompressions=146 | 2021-06-18 08:58:28.144
SC Data - All Services | Heartbeat from server | ServerReceivedClientHeartbeatSecondsAgo=11, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=80, ServerSendBufferSizeInBytes=29, ActualMessageDelay=-0.1 seconds, DataCompRatio=2.44, UncompressedBytes=152568, CompressionTime=0.000647(secs), NumCompressions=146 | 2021-06-18 08:58:30.463
[2021-06-22 19:33:39]
Sierra_Chart Engineering - Posts: 21301
There are a very large number of messages like these in the log:
Subscribing to symbol for symbol alert. F.US.EPZ18 | 2021-06-18 08:57:57.728
Go to Window >> Alert Manager >> Symbol Alerts and remove all of the old alerts for expired symbols and symbols you do not need.
For lagging issues refer to help topic 4:
Prices / Data Falling Behind
You can also disable the detailed heartbeat logging.
Date Time Of Last Edit: 2021-06-22 19:33:51
