Date/Time: Wed, 14 Oct 2026 08:02:22 +0000
Sudden Not Connected issue
View Count: 970
[2021-04-08 06:21:23]
User774053 - Posts: 3
I have a 6 month account and trade FX and it has been working great, right up to when I added live feeds for the Equities markets. When that was activated it apparently stopped the date feed or created a 'Not Connected' issue with my FX charts. Prior to activating the live feed for the Equities markets, I set up a second Sierra Chart on my computer to handle the Equities symbols and all of that set up just fine. Also, when I set up the live feed, I got an error type message on my FX charts. I followed that advice and closed Sierra Charts, reopened and then updated by down loading the latest up date. This did not resolve the 'Not Connected' issue. Could you look at my account to see what happened? Much thanks
[2021-04-08 13:49:57]
John - SC Support - Posts: 48196
As long as you are not accessing the Equities data from both computers at the same time, we do not know why you would be having an issue.
We need to see the Message Log from the computer on which you are getting the "Not Connected" error by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2021-04-08 14:01:51]
You really should not be having any issues at all. We need to see the Message Log as explained above.
Perfectly fine to be using two installations of Sierra Chart also.
[2021-04-08 16:56:52]
Reading Internal Order ID file. | 2021-04-07 23:19:10.414
Reading Trade Orders file. | 2021-04-07 23:19:10.560
Reading Trade Positions file. | 2021-04-07 23:19:10.560
Reading Trade Account Data files. | 2021-04-07 23:19:10.560
Encountered unknown field code when reading account balance data. | 2021-04-07 23:19:10.561
UDPListener (1572). Port 22904 | Listening on UDP port 22904. | 2021-04-07 23:19:10.595
Software version: 2247 64-bit | 2021-04-07 23:19:10.595
Primary Thread ID: 6040 | 2021-04-07 23:19:10.595
Usage end date: 2021-04-22 | 2021-04-07 23:19:10.595
Usage time has ended. Sierra Chart is in Free mode. Features are restricted. | 2021-04-07 23:19:10.595
To purchase usage time, select 'Help >> Add Usage Credit' on the menu. | 2021-04-07 23:19:10.595 *
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-04-07 23:19:10.595
Current selected Data/Trading service: SC Data - All Services | 2021-04-07 23:19:10.595
Custom symbol settings values: disabled | 2021-04-07 23:19:10.595
Chart Update Interval: 500 | 2021-04-07 23:19:10.595
Intraday Data Storage Time Unit: 1 | 2021-04-07 23:19:10.595
Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-04-07 23:19:10.595
2021-04-08 05:19:10 Local computer time in UTC | 2021-04-07 23:19:10.595
2021-04-07 23:19:10 Local computer time in SC Time Zone | 2021-04-07 23:19:10.595
Program path: C:\SierraChart\ | 2021-04-07 23:19:10.595
Data Files path: C:\SierraChart\Data\ | 2021-04-07 23:19:10.595
OS Version Number: 10.0 | 2021-04-07 23:19:10.596
Locale Setting: C | 2021-04-07 23:19:10.596
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-04-07 23:19:10.596
Allowed protected custom studies: | 2021-04-07 23:19:10.596
DTC Protocol Server feature not enabled for Sierra Chart account. | 2021-04-07 23:19:10.596 *
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2021-04-07 23:19:10.596
Symbol settings MD5 received. Request ID: 1. | 2021-04-07 23:19:41.553
Requested symbol settings for service code scdataallservices. Request ID: 2. | 2021-04-07 23:19:41.554
Received 5 login tokens. | 2021-04-07 23:19:41.565
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-04-07 23:19:41.617
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-04-07 23:19:41.773
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-04-07 23:19:41.773
Files to Open on Startup | Opening file: ENZD.Cht | 2021-04-07 23:19:42.595
EURNZD 30 Min #4 | Reloading chart. | 2021-04-07 23:19:42.654
EURNZD 5 Min #11 | Reloading chart. | 2021-04-07 23:19:42.724
EURNZD 15 Min #12 | Reloading chart. | 2021-04-07 23:19:42.748
EURNZD 30 Min #13 | Reloading chart. | 2021-04-07 23:19:42.780
Enabling compression for file: C:\SierraChart\Data\EURNZD.dly. This may take a while. | 2021-04-07 23:19:42.787
File compression enabled. C:\SierraChart\Data\EURNZD.dly. CompressionState=0 | 2021-04-07 23:19:42.787
EURNZD Daily #14 | Reloading chart. | 2021-04-07 23:19:42.815
EURNZD 240 Min #15 | Reloading chart. | 2021-04-07 23:19:42.847
EURNZD 45 Min #1 | Reloading chart. | 2021-04-07 23:19:42.880
EURNZD 45 Min #2 | Reloading chart. | 2021-04-07 23:19:42.915
EURNZD 120 Min #3 | Reloading chart. | 2021-04-07 23:19:42.948
Files to Open on Startup | Opening file: ECHF.Cht | 2021-04-07 23:19:42.964
EURCHF 5 Min #1 | Reloading chart. | 2021-04-07 23:19:43.076
EURCHF 15 Min #2 | Reloading chart. | 2021-04-07 23:19:43.128
EURCHF 30 Min #4 | Reloading chart. | 2021-04-07 23:19:43.164
Enabling compression for file: C:\SierraChart\Data\EURCHF.dly. This may take a while. | 2021-04-07 23:19:43.172
File compression enabled. C:\SierraChart\Data\EURCHF.dly. CompressionState=0 | 2021-04-07 23:19:43.172
EURCHF Daily #12 | Reloading chart. | 2021-04-07 23:19:43.258
EURCHF 240 Min #13 | Reloading chart. | 2021-04-07 23:19:43.298
EURCHF 120 Min #14 | Reloading chart. | 2021-04-07 23:19:43.331
EURCHF 30 Min #15 | Reloading chart. | 2021-04-07 23:19:43.376
EURCHF 30 Min #3 | Reloading chart. | 2021-04-07 23:19:43.412
EURCHF 45 Min #5 | Reloading chart. | 2021-04-07 23:19:43.452
EURCHF 60 Min #6 | Reloading chart. | 2021-04-07 23:19:43.484
EURCHF 120 Min #7 | Reloading chart. | 2021-04-07 23:19:43.517
Files to Open on Startup | Opening file: EJPY.Cht | 2021-04-07 23:19:43.534
EURJPY 5 Min #1 | Reloading chart. | 2021-04-07 23:19:43.816
EURJPY 15 Min #2 | Reloading chart. | 2021-04-07 23:19:43.852
EURJPY 30 Min #4 | Reloading chart. | 2021-04-07 23:19:44.105
EURJPY 30 Min #11 | Reloading chart. | 2021-04-07 23:19:44.139
Enabling compression for file: C:\SierraChart\Data\EURJPY.dly. This may take a while. | 2021-04-07 23:19:44.150
File compression enabled. C:\SierraChart\Data\EURJPY.dly. CompressionState=0 | 2021-04-07 23:19:44.150
EURJPY Daily #12 | Reloading chart. | 2021-04-07 23:19:44.183
EURJPY 240 Min #13 | Reloading chart. | 2021-04-07 23:19:44.249
EURJPY 45 Min #3 | Reloading chart. | 2021-04-07 23:19:44.284
EURJPY 60 Min #5 | Reloading chart. | 2021-04-07 23:19:44.317
EURJPY 120 Min #6 | Reloading chart. | 2021-04-07 23:19:44.358
Files to Open on Startup | Opening file: EUSD.Cht | 2021-04-07 23:19:44.376
EURUSD 5 Min #1 | Reloading chart. | 2021-04-07 23:19:44.646
EURUSD 15 Min #2 | Reloading chart. | 2021-04-07 23:19:44.788
EURUSD 30 Min #4 | Reloading chart. | 2021-04-07 23:19:44.908
EURUSD 30 Min #11 | Reloading chart. | 2021-04-07 23:19:44.943
Enabling compression for file: C:\SierraChart\Data\EURUSD.dly. This may take a while. | 2021-04-07 23:19:44.953
File compression enabled. C:\SierraChart\Data\EURUSD.dly. CompressionState=0 | 2021-04-07 23:19:44.953
EURUSD Daily #12 | Reloading chart. | 2021-04-07 23:19:45.317
EURUSD 240 Min #13 | Reloading chart. | 2021-04-07 23:19:45.605
EURUSD 45 Min #3 | Reloading chart. | 2021-04-07 23:19:45.642
EURUSD 60 Min #5 | Reloading chart. | 2021-04-07 23:19:46.052
EURUSD 120 Min #6 | Reloading chart. | 2021-04-07 23:19:46.091
Files to Open on Startup | Opening file: ECAD.Cht | 2021-04-07 23:19:46.115
EURCAD 5 Min #1 | Reloading chart. | 2021-04-07 23:19:46.683
EURCAD 15 Min #2 | Reloading chart. | 2021-04-07 23:19:46.716
EURCAD 30 Min #4 | Reloading chart. | 2021-04-07 23:19:46.829
EURCAD 30 Min #11 | Reloading chart. | 2021-04-07 23:19:46.864
Enabling compression for file: C:\SierraChart\Data\EURCAD.dly. This may take a while. | 2021-04-07 23:19:46.872
File compression enabled. C:\SierraChart\Data\EURCAD.dly. CompressionState=0 | 2021-04-07 23:19:46.872
EURCAD Daily #12 | Reloading chart. | 2021-04-07 23:19:46.927
EURCAD 240 Min #13 | Reloading chart. | 2021-04-07 23:19:46.964
EURCAD 45 Min #3 | Reloading chart. | 2021-04-07 23:19:47.277
EURCAD 60 Min #5 | Reloading chart. | 2021-04-07 23:19:47.590
EURCAD 120 Min #6 | Reloading chart. | 2021-04-07 23:19:47.822
Files to Open on Startup | Opening file: EGBP.Cht | 2021-04-07 23:19:47.852
EURGBP 5 Min #1 | Reloading chart. | 2021-04-07 23:19:48.179
EURGBP 15 Min #2 | Reloading chart. | 2021-04-07 23:19:48.240
EURGBP 30 Min #4 | Reloading chart. | 2021-04-07 23:19:48.843
EURGBP 30 Min #11 | Reloading chart. | 2021-04-07 23:19:49.403
EURGBP 240 Min #12 | Reloading chart. | 2021-04-07 23:19:49.763
Enabling compression for file: C:\SierraChart\Data\EURGBP.dly. This may take a while. | 2021-04-07 23:19:49.772
File compression enabled. C:\SierraChart\Data\EURGBP.dly. CompressionState=0 | 2021-04-07 23:19:49.772
EURGBP Daily #13 | Reloading chart. | 2021-04-07 23:19:49.987
EURGBP 45 Min #3 | Reloading chart. | 2021-04-07 23:19:50.021
EURGBP 60 Min #5 | Reloading chart. | 2021-04-07 23:19:50.057
EURGBP 120 Min #6 | Reloading chart. | 2021-04-07 23:19:50.094
Files to Open on Startup | Opening file: GAUD.Cht | 2021-04-07 23:19:50.118
GBPAUD 5 Min #1 | Reloading chart. | 2021-04-07 23:19:50.544
GBPAUD 15 Min #2 | Reloading chart. | 2021-04-07 23:19:50.578
GBPAUD 30 Min #4 | Reloading chart. | 2021-04-07 23:19:50.612
GBPAUD 30 Min #11 | Reloading chart. | 2021-04-07 23:19:50.654
GBPAUD 240 Min #12 | Reloading chart. | 2021-04-07 23:19:52.352
Enabling compression for file: C:\SierraChart\Data\GBPAUD.dly. This may take a while. | 2021-04-07 23:19:52.361
File compression enabled. C:\SierraChart\Data\GBPAUD.dly. CompressionState=2 | 2021-04-07 23:19:52.361
GBPAUD Daily #13 | Reloading chart. | 2021-04-07 23:19:52.700
GBPAUD 45 Min #3 | Reloading chart. | 2021-04-07 23:19:52.745
GBPAUD 60 Min #5 | Reloading chart. | 2021-04-07 23:19:53.061
GBPAUD 120 Min #6 | Reloading chart. | 2021-04-07 23:19:53.101
Files to Open on Startup | Opening file: GUSD.Cht | 2021-04-07 23:19:53.129
GBPUSD 5 Min #1 | Reloading chart. | 2021-04-07 23:19:53.449
GBPUSD 15 Min #2 | Reloading chart. | 2021-04-07 23:19:53.482
GBPUSD 30 Min #4 | Reloading chart. | 2021-04-07 23:19:53.886
GBPUSD 30 Min #11 | Reloading chart. | 2021-04-07 23:19:53.921
GBPUSD 240 Min #12 | Reloading chart. | 2021-04-07 23:19:53.960
Enabling compression for file: C:\SierraChart\Data\GBPUSD.dly. This may take a while. | 2021-04-07 23:19:53.970
File compression enabled. C:\SierraChart\Data\GBPUSD.dly. CompressionState=0 | 2021-04-07 23:19:53.970
GBPUSD Daily #13 | Reloading chart. | 2021-04-07 23:19:54.004
GBPUSD 45 Min #3 | Reloading chart. | 2021-04-07 23:19:54.040
GBPUSD 60 Min #5 | Reloading chart. | 2021-04-07 23:19:54.079
GBPUSD 120 Min #6 | Reloading chart. | 2021-04-07 23:19:54.116
Files to Open on Startup | Opening file: GNZD.Cht | 2021-04-07 23:19:54.147
GBPNZD 5 Min #1 | Reloading chart. | 2021-04-07 23:19:54.618
GBPNZD 15 Min #2 | Reloading chart. | 2021-04-07 23:19:54.711
GBPNZD 30 Min #4 | Reloading chart. | 2021-04-07 23:19:54.749
GBPNZD 30 Min #11 | Reloading chart. | 2021-04-07 23:19:54.804
GBPNZD 240 Min #12 | Reloading chart. | 2021-04-07 23:19:54.839
Enabling compression for file: C:\SierraChart\Data\GBPNZD.dly. This may take a while. | 2021-04-07 23:19:54.854
File compression enabled. C:\SierraChart\Data\GBPNZD.dly. CompressionState=0 | 2021-04-07 23:19:54.854
GBPNZD Daily #13 | Reloading chart. | 2021-04-07 23:19:55.615
GBPNZD 45 Min #3 | Reloading chart. | 2021-04-07 23:19:55.824
GBPNZD 60 Min #5 | Reloading chart. | 2021-04-07 23:19:55.972
GBPNZD 120 Min #6 | Reloading chart. | 2021-04-07 23:19:56.013
Files to Open on Startup | Opening file: GCAD.Cht | 2021-04-07 23:19:56.044
GBPCAD 5 Min #1 | Reloading chart. | 2021-04-07 23:20:00.183
GBPCAD 15 Min #2 | Reloading chart. | 2021-04-07 23:20:00.219
GBPCAD 30 Min #4 | Reloading chart. | 2021-04-07 23:20:00.255
GBPCAD 30 Min #11 | Reloading chart. | 2021-04-07 23:20:00.343
GBPCAD 240 Min #12 | Reloading chart. | 2021-04-07 23:20:00.386
Enabling compression for file: C:\SierraChart\Data\GBPCAD.dly. This may take a while. | 2021-04-07 23:20:00.396
File compression enabled. C:\SierraChart\Data\GBPCAD.dly. CompressionState=2 | 2021-04-07 23:20:00.400
GBPCAD Daily #13 | Reloading chart. | 2021-04-07 23:20:00.529
GBPCAD 45 Min #3 | Reloading chart. | 2021-04-07 23:20:00.573
GBPCAD 60 Min #5 | Reloading chart. | 2021-04-07 23:20:00.609
GBPCAD 120 Min #6 | Reloading chart. | 2021-04-07 23:20:00.801
Files to Open on Startup | Opening file: GCHF.Cht | 2021-04-07 23:20:00.846
GBPCHF 5 Min #1 | Reloading chart. | 2021-04-07 23:20:01.036
GBPCHF 15 Min #2 | Reloading chart. | 2021-04-07 23:20:01.086
GBPCHF 30 Min #4 | Reloading chart. | 2021-04-07 23:20:01.142
GBPCHF 30 Min #11 | Reloading chart. | 2021-04-07 23:20:01.192
GBPCHF 240 Min #12 | Reloading chart. | 2021-04-07 23:20:01.405
Enabling compression for file: C:\SierraChart\Data\GBPCHF.dly. This may take a while. | 2021-04-07 23:20:01.441
File compression enabled. C:\SierraChart\Data\GBPCHF.dly. CompressionState=0 | 2021-04-07 23:20:01.441
GBPCHF Daily #13 | Reloading chart. | 2021-04-07 23:20:01.605
GBPCHF 45 Min #3 | Reloading chart. | 2021-04-07 23:20:01.646
GBPCHF 60 Min #5 | Reloading chart. | 2021-04-07 23:20:01.830
GBPCHF 120 Min #6 | Reloading chart. | 2021-04-07 23:20:01.879
Files to Open on Startup | Opening file: GJPY.Cht | 2021-04-07 23:20:01.958
GBPJPY 5 Min #1 | Reloading chart. | 2021-04-07 23:20:02.078
GBPJPY 15 Min #2 | Reloading chart. | 2021-04-07 23:20:02.115
GBPJPY 30 Min #4 | Reloading chart. | 2021-04-07 23:20:02.306
GBPJPY 30 Min #11 | Reloading chart. | 2021-04-07 23:20:02.346
GBPJPY 240 Min #12 | Reloading chart. | 2021-04-07 23:20:02.413
Enabling compression for file: C:\SierraChart\Data\GBPJPY.dly. This may take a while. | 2021-04-07 23:20:02.423
File compression enabled. C:\SierraChart\Data\GBPJPY.dly. CompressionState=0 | 2021-04-07 23:20:02.423
GBPJPY Daily #13 | Reloading chart. | 2021-04-07 23:20:02.831
GBPJPY 45 Min #3 | Reloading chart. | 2021-04-07 23:20:02.913
GBPJPY 60 Min #5 | Reloading chart. | 2021-04-07 23:20:02.964
GBPJPY 120 Min #6 | Reloading chart. | 2021-04-07 23:20:03.003
Files to Open on Startup | Opening file: xxxx.Cht | 2021-04-07 23:20:03.052
AUDUSD 30 Min #1 | Reloading chart. | 2021-04-07 23:20:03.355
AUDCAD 30 Min #2 | Reloading chart. | 2021-04-07 23:20:04.650
AUDJPY 30 Min #3 | Reloading chart. | 2021-04-07 23:20:05.047
AUDCHF 30 Min #4 | Reloading chart. | 2021-04-07 23:20:05.382
AUDNZD 30 Min #5 | Reloading chart. | 2021-04-07 23:20:06.244
NZDUSD 30 Min #6 | Reloading chart. | 2021-04-07 23:20:06.325
NZDCHF 30 Min #7 | Reloading chart. | 2021-04-07 23:20:06.848
NZDJPY 30 Min #8 | Reloading chart. | 2021-04-07 23:20:07.291
NZDCAD 30 Min #9 | Reloading chart. | 2021-04-07 23:20:07.544
USDCHF 30 Min #10 | Reloading chart. | 2021-04-07 23:20:07.939
EURCHF 30 Min #11 | Reloading chart. | 2021-04-07 23:20:08.447
USDJPY 30 Min #12 | Reloading chart. | 2021-04-07 23:20:08.904
USDCAD 30 Min #13 | Reloading chart. | 2021-04-07 23:20:09.399
CHFJPY 30 Min #14 | Reloading chart. | 2021-04-07 23:20:09.716
CADJPY 30 Min #15 | Reloading chart. | 2021-04-07 23:20:10.017
CADCHF 30 Min #16 | Reloading chart. | 2021-04-07 23:20:10.485
EURNZD 30 Min #17 | Reloading chart. | 2021-04-07 23:20:10.714
EURJPY 30 Min #18 | Reloading chart. | 2021-04-07 23:20:11.060
EURUSD 30 Min #19 | Reloading chart. | 2021-04-07 23:20:11.298
EURCAD 30 Min #20 | Reloading chart. | 2021-04-07 23:20:11.621
EURGBP 30 Min #21 | Reloading chart. | 2021-04-07 23:20:11.943
GBPJPY 30 Min #22 | Reloading chart. | 2021-04-07 23:20:12.322
GBPUSD 30 Min #23 | Reloading chart. | 2021-04-07 23:20:13.954
GBPCHF 30 Min #24 | Reloading chart. | 2021-04-07 23:20:14.163
Files to Open on Startup | Opening file: AUSD.Cht | 2021-04-07 23:20:14.251
AUDUSD 5 Min #1 | Reloading chart. | 2021-04-07 23:20:14.602
AUDUSD 15 Min #4 | Reloading chart. | 2021-04-07 23:20:14.654
AUDUSD 30 Min #5 | Reloading chart. | 2021-04-07 23:20:14.942
AUDUSD 30 Min #11 | Reloading chart. | 2021-04-07 23:20:14.986
AUDUSD 240 Min #12 | Reloading chart. | 2021-04-07 23:20:15.036
Enabling compression for file: C:\SierraChart\Data\AUDUSD.dly. This may take a while. | 2021-04-07 23:20:15.058
File compression enabled. C:\SierraChart\Data\AUDUSD.dly. CompressionState=2 | 2021-04-07 23:20:15.058
AUDUSD Daily #13 | Reloading chart. | 2021-04-07 23:20:15.180
AUDUSD 45 Min #2 | Reloading chart. | 2021-04-07 23:20:15.234
AUDUSD 60 Min #3 | Reloading chart. | 2021-04-07 23:20:15.280
AUDUSD 120 Min #6 | Reloading chart. | 2021-04-07 23:20:15.323
Files to Open on Startup | Opening file: ACAD.Cht | 2021-04-07 23:20:15.374
AUDCAD 5 Min #1 | Reloading chart. | 2021-04-07 23:20:15.915
AUDCAD 15 Min #2 | Reloading chart. | 2021-04-07 23:20:15.977
AUDCAD 30 Min #4 | Reloading chart. | 2021-04-07 23:20:16.544
AUDCAD 30 Min #11 | Reloading chart. | 2021-04-07 23:20:16.590
AUDCAD 240 Min #12 | Reloading chart. | 2021-04-07 23:20:16.642
Enabling compression for file: C:\SierraChart\Data\AUDCAD.dly. This may take a while. | 2021-04-07 23:20:16.656
File compression enabled. C:\SierraChart\Data\AUDCAD.dly. CompressionState=0 | 2021-04-07 23:20:16.656
AUDCAD Daily #13 | Reloading chart. | 2021-04-07 23:20:16.739
AUDCAD 45 Min #3 | Reloading chart. | 2021-04-07 23:20:16.895
AUDCAD 60 Min #5 | Reloading chart. | 2021-04-07 23:20:17.104
AUDCAD 120 Min #6 | Reloading chart. | 2021-04-07 23:20:17.254
Files to Open on Startup | Opening file: AJPY.Cht | 2021-04-07 23:20:17.423
AUDJPY 5 Min #1 | Reloading chart. | 2021-04-07 23:20:17.656
AUDJPY 15 Min #2 | Reloading chart. | 2021-04-07 23:20:17.703
AUDJPY 30 Min #4 | Reloading chart. | 2021-04-07 23:20:17.984
AUDJPY 30 Min #11 | Reloading chart. | 2021-04-07 23:20:18.031
AUDJPY 240 Min #12 | Reloading chart. | 2021-04-07 23:20:18.078
Enabling compression for file: C:\SierraChart\Data\AUDJPY.dly. This may take a while. | 2021-04-07 23:20:18.092
File compression enabled. C:\SierraChart\Data\AUDJPY.dly. CompressionState=2 | 2021-04-07 23:20:18.092
AUDJPY Daily #3 | Reloading chart. | 2021-04-07 23:20:18.138
AUDJPY 45 Min #5 | Reloading chart. | 2021-04-07 23:20:18.705
AUDJPY 60 Min #6 | Reloading chart. | 2021-04-07 23:20:18.770
AUDJPY 120 Min #7 | Reloading chart. | 2021-04-07 23:20:18.823
Files to Open on Startup | Opening file: ACHF.Cht | 2021-04-07 23:20:18.977
AUDCHF 5 Min #1 | Reloading chart. | 2021-04-07 23:20:19.362
AUDCHF 15 Min #2 | Reloading chart. | 2021-04-07 23:20:19.405
AUDCHF 30 Min #4 | Reloading chart. | 2021-04-07 23:20:19.868
AUDCHF 30 Min #11 | Reloading chart. | 2021-04-07 23:20:19.913
AUDCHF 240 Min #12 | Reloading chart. | 2021-04-07 23:20:20.913
Enabling compression for file: C:\SierraChart\Data\AUDCHF.dly. This may take a while. | 2021-04-07 23:20:21.180
File compression enabled. C:\SierraChart\Data\AUDCHF.dly. CompressionState=2 | 2021-04-07 23:20:21.185
AUDCHF Daily #13 | Reloading chart. | 2021-04-07 23:20:21.693
AUDCHF 45 Min #3 | Reloading chart. | 2021-04-07 23:20:22.623
AUDCHF 60 Min #5 | Reloading chart. | 2021-04-07 23:20:24.954
AUDCHF 120 Min #6 | Reloading chart. | 2021-04-07 23:20:25.108
Files to Open on Startup | Opening file: ANZD.Cht | 2021-04-07 23:20:25.204
AUDNZD 5 Min #1 | Reloading chart. | 2021-04-07 23:20:25.322
AUDNZD 15 Min #2 | Reloading chart. | 2021-04-07 23:20:25.372
AUDNZD 30 Min #4 | Reloading chart. | 2021-04-07 23:20:25.752
AUDNZD 30 Min #11 | Reloading chart. | 2021-04-07 23:20:25.867
AUDNZD 240 Min #12 | Reloading chart. | 2021-04-07 23:20:26.018
Enabling compression for file: C:\SierraChart\Data\AUDNZD.dly. This may take a while. | 2021-04-07 23:20:26.040
File compression enabled. C:\SierraChart\Data\AUDNZD.dly. CompressionState=0 | 2021-04-07 23:20:26.040
AUDNZD Daily #13 | Reloading chart. | 2021-04-07 23:20:26.120
AUDNZD 45 Min #3 | Reloading chart. | 2021-04-07 23:20:26.210
AUDNZD 60 Min #5 | Reloading chart. | 2021-04-07 23:20:26.633
AUDNZD 120 Min #6 | Reloading chart. | 2021-04-07 23:20:26.793
Files to Open on Startup | Opening file: NUSD.Cht | 2021-04-07 23:20:27.649
NZDUSD 5 Min #1 | Reloading chart. | 2021-04-07 23:20:27.799
NZDUSD 15 Min #2 | Reloading chart. | 2021-04-07 23:20:27.937
NZDUSD 30 Min #4 | Reloading chart. | 2021-04-07 23:20:28.765
NZDUSD 30 Min #11 | Reloading chart. | 2021-04-07 23:20:28.813
NZDUSD 240 Min #12 | Reloading chart. | 2021-04-07 23:20:28.857
Enabling compression for file: C:\SierraChart\Data\NZDUSD.dly. This may take a while. | 2021-04-07 23:20:28.873
File compression enabled. C:\SierraChart\Data\NZDUSD.dly. CompressionState=2 | 2021-04-07 23:20:28.874
NZDUSD Daily #13 | Reloading chart. | 2021-04-07 23:20:28.917
NZDUSD 45 Min #3 | Reloading chart. | 2021-04-07 23:20:29.082
NZDUSD 60 Min #5 | Reloading chart. | 2021-04-07 23:20:29.201
NZDUSD 120 Min #6 | Reloading chart. | 2021-04-07 23:20:29.345
Files to Open on Startup | Opening file: NCHF.Cht | 2021-04-07 23:20:29.502
NZDCHF 5 Min #1 | Reloading chart. | 2021-04-07 23:20:29.721
NZDCHF 15 Min #2 | Reloading chart. | 2021-04-07 23:20:29.882
NZDCHF 30 Min #4 | Reloading chart. | 2021-04-07 23:20:31.023
NZDCHF 30 Min #11 | Reloading chart. | 2021-04-07 23:20:31.062
NZDCHF 240 Min #12 | Reloading chart. | 2021-04-07 23:20:31.122
Enabling compression for file: C:\SierraChart\Data\NZDCHF.dly. This may take a while. | 2021-04-07 23:20:31.135
File compression enabled. C:\SierraChart\Data\NZDCHF.dly. CompressionState=0 | 2021-04-07 23:20:31.135
NZDCHF Daily #13 | Reloading chart. | 2021-04-07 23:20:31.182
NZDCHF 45 Min #3 | Reloading chart. | 2021-04-07 23:20:31.232
NZDCHF 60 Min #5 | Reloading chart. | 2021-04-07 23:20:31.281
NZDCHF 120 Min #6 | Reloading chart. | 2021-04-07 23:20:31.331
Files to Open on Startup | Opening file: NJPY.Cht | 2021-04-07 23:20:31.425
NZDJPY 5 Min #1 | Reloading chart. | 2021-04-07 23:20:31.602
NZDJPY 15 Min #2 | Reloading chart. | 2021-04-07 23:20:31.706
NZDJPY 30 Min #4 | Reloading chart. | 2021-04-07 23:20:33.157
NZDJPY 30 Min #11 | Reloading chart. | 2021-04-07 23:20:33.200
NZDJPY 240 Min #12 | Reloading chart. | 2021-04-07 23:20:33.240
Enabling compression for file: C:\SierraChart\Data\NZDJPY.dly. This may take a while. | 2021-04-07 23:20:33.253
File compression enabled. C:\SierraChart\Data\NZDJPY.dly. CompressionState=0 | 2021-04-07 23:20:33.253
NZDJPY Daily #13 | Reloading chart. | 2021-04-07 23:20:33.286
NZDJPY 45 Min #3 | Reloading chart. | 2021-04-07 23:20:33.329
NZDJPY 60 Min #5 | Reloading chart. | 2021-04-07 23:20:33.378
NZDJPY 120 Min #6 | Reloading chart. | 2021-04-07 23:20:33.429
Files to Open on Startup | Opening file: NCAD.Cht | 2021-04-07 23:20:33.554
NZDCAD 30 Min #1 | Reloading chart. | 2021-04-07 23:20:34.128
NZDCAD 15 Min #3 | Reloading chart. | 2021-04-07 23:20:34.192
NZDCAD 5 Min #4 | Reloading chart. | 2021-04-07 23:20:34.337
NZDCAD 30 Min #11 | Reloading chart. | 2021-04-07 23:20:34.477
NZDCAD 240 Min #12 | Reloading chart. | 2021-04-07 23:20:34.709
Enabling compression for file: C:\SierraChart\Data\NZDCAD.dly. This may take a while. | 2021-04-07 23:20:34.741
File compression enabled. C:\SierraChart\Data\NZDCAD.dly. CompressionState=2 | 2021-04-07 23:20:34.747
NZDCAD Daily #2 | Reloading chart. | 2021-04-07 23:20:34.864
NZDCAD 45 Min #5 | Reloading chart. | 2021-04-07 23:20:35.604
NZDCAD 60 Min #6 | Reloading chart. | 2021-04-07 23:20:35.668
NZDCAD 120 Min #7 | Reloading chart. | 2021-04-07 23:20:35.786
Files to Open on Startup | Opening file: UCHF.Cht | 2021-04-07 23:20:36.643
USDCHF 5 Min #1 | Reloading chart. | 2021-04-07 23:20:36.744
USDCHF 15 Min #2 | Reloading chart. | 2021-04-07 23:20:36.802
USDCHF 30 Min #4 | Reloading chart. | 2021-04-07 23:20:37.401
USDCHF 30 Min #11 | Reloading chart. | 2021-04-07 23:20:37.456
USDCHF 240 Min #12 | Reloading chart. | 2021-04-07 23:20:37.552
Enabling compression for file: C:\SierraChart\Data\USDCHF.dly. This may take a while. | 2021-04-07 23:20:37.585
File compression enabled. C:\SierraChart\Data\USDCHF.dly. CompressionState=0 | 2021-04-07 23:20:37.585
USDCHF Daily #13 | Reloading chart. | 2021-04-07 23:20:37.664
USDCHF 45 Min #3 | Reloading chart. | 2021-04-07 23:20:37.899
USDCHF 60 Min #5 | Reloading chart. | 2021-04-07 23:20:38.089
USDCHF 120 Min #6 | Reloading chart. | 2021-04-07 23:20:38.154
Files to Open on Startup | Opening file: UJPY.Cht | 2021-04-07 23:20:38.528
USDJPY 5 Min #1 | Reloading chart. | 2021-04-07 23:20:38.660
USDJPY 15 Min #2 | Reloading chart. | 2021-04-07 23:20:38.718
USDJPY 30 Min #4 | Reloading chart. | 2021-04-07 23:20:39.446
USDJPY 60 Min #11 | Reloading chart. | 2021-04-07 23:20:39.518
USDJPY 120 Min #12 | Reloading chart. | 2021-04-07 23:20:39.623
USDJPY 240 Min #13 | Reloading chart. | 2021-04-07 23:20:39.767
USDJPY 45 Min #3 | Reloading chart. | 2021-04-07 23:20:39.901
USDJPY 30 Min #6 | Reloading chart. | 2021-04-07 23:20:39.955
Enabling compression for file: C:\SierraChart\Data\USDJPY.dly. This may take a while. | 2021-04-07 23:20:39.977
File compression enabled. C:\SierraChart\Data\USDJPY.dly. CompressionState=2 | 2021-04-07 23:20:39.978
USDJPY Daily #5 | Reloading chart. | 2021-04-07 23:20:40.204
Files to Open on Startup | Opening file: UCAD.Cht | 2021-04-07 23:20:40.480
USDCAD 5 Min #1 | Reloading chart. | 2021-04-07 23:20:40.631
USDCAD 15 Min #2 | Reloading chart. | 2021-04-07 23:20:40.707
USDCAD 30 Min #4 | Reloading chart. | 2021-04-07 23:20:41.770
USDCAD 30 Min #11 | Reloading chart. | 2021-04-07 23:20:41.817
USDCAD 120 Min #12 | Reloading chart. | 2021-04-07 23:20:41.872
USDCAD 240 Min #13 | Reloading chart. | 2021-04-07 23:20:41.983
USDCAD 60 Min #3 | Reloading chart. | 2021-04-07 23:20:42.053
USDCAD 45 Min #6 | Reloading chart. | 2021-04-07 23:20:42.143
Enabling compression for file: C:\SierraChart\Data\USDCAD.dly. This may take a while. | 2021-04-07 23:20:42.171
File compression enabled. C:\SierraChart\Data\USDCAD.dly. CompressionState=2 | 2021-04-07 23:20:42.173
USDCAD Daily #8 | Reloading chart. | 2021-04-07 23:20:42.241
Files to Open on Startup | Opening file: CHJPY.Cht | 2021-04-07 23:20:42.370
CHFJPY 5 Min #1 | Reloading chart. | 2021-04-07 23:20:42.602
CHFJPY 15 Min #2 | Reloading chart. | 2021-04-07 23:20:42.711
CHFJPY 30 Min #4 | Reloading chart. | 2021-04-07 23:20:43.995
CHFJPY 60 Min #11 | Reloading chart. | 2021-04-07 23:20:44.091
CHFJPY 240 Min #12 | Reloading chart. | 2021-04-07 23:20:44.154
Enabling compression for file: C:\SierraChart\Data\CHFJPY.dly. This may take a while. | 2021-04-07 23:20:44.258
File compression enabled. C:\SierraChart\Data\CHFJPY.dly. CompressionState=0 | 2021-04-07 23:20:44.258
CHFJPY Daily #13 | Reloading chart. | 2021-04-07 23:20:44.337
CHFJPY 30 Min #3 | Reloading chart. | 2021-04-07 23:20:44.408
CHFJPY 45 Min #5 | Reloading chart. | 2021-04-07 23:20:44.464
CHFJPY 120 Min #6 | Reloading chart. | 2021-04-07 23:20:44.518
Files to Open on Startup | Opening file: CAJPY.Cht | 2021-04-07 23:20:44.649
CADJPY 5 Min #1 | Reloading chart. | 2021-04-07 23:20:44.846
CADJPY 15 Min #2 | Reloading chart. | 2021-04-07 23:20:44.904
CADJPY 30 Min #4 | Reloading chart. | 2021-04-07 23:20:46.273
CADJPY 30 Min #11 | Reloading chart. | 2021-04-07 23:20:46.324
CADJPY 240 Min #12 | Reloading chart. | 2021-04-07 23:20:46.376
Enabling compression for file: C:\SierraChart\Data\CADJPY.dly. This may take a while. | 2021-04-07 23:20:46.390
File compression enabled. C:\SierraChart\Data\CADJPY.dly. CompressionState=2 | 2021-04-07 23:20:46.391
CADJPY Daily #13 | Reloading chart. | 2021-04-07 23:20:46.439
CADJPY 45 Min #3 | Reloading chart. | 2021-04-07 23:20:46.505
CADJPY 60 Min #5 | Reloading chart. | 2021-04-07 23:20:46.593
CADJPY 120 Min #6 | Reloading chart. | 2021-04-07 23:20:46.730
Files to Open on Startup | Opening file: CACHF.Cht | 2021-04-07 23:20:46.863
CADCHF 30 Min #1 | Reloading chart. | 2021-04-07 23:20:47.380
CADCHF 15 Min #3 | Reloading chart. | 2021-04-07 23:20:47.449
CADCHF 5 Min #4 | Reloading chart. | 2021-04-07 23:20:47.615
CADCHF 30 Min #11 | Reloading chart. | 2021-04-07 23:20:47.884
CADCHF 240 Min #12 | Reloading chart. | 2021-04-07 23:20:48.413
Enabling compression for file: C:\SierraChart\Data\CADCHF.dly. This may take a while. | 2021-04-07 23:20:48.429
File compression enabled. C:\SierraChart\Data\CADCHF.dly. CompressionState=0 | 2021-04-07 23:20:48.429
CADCHF Daily #13 | Reloading chart. | 2021-04-07 23:20:48.490
CADCHF 45 Min #2 | Reloading chart. | 2021-04-07 23:20:48.554
CADCHF 60 Min #5 | Reloading chart. | 2021-04-07 23:20:48.640
CADCHF 120 Min #6 | Reloading chart. | 2021-04-07 23:20:48.800
Files to Open on Startup | Opening file: cs.cht | 2021-04-07 23:20:48.938
EURUSD 120 Min #1 | Reloading chart. | 2021-04-07 23:20:49.178
GBPUSD 120 Min #2 | Reloading chart. | 2021-04-07 23:20:49.351
AUDUSD 120 Min #3 | Reloading chart. | 2021-04-07 23:20:49.545
NZDUSD 120 Min #4 | Reloading chart. | 2021-04-07 23:20:49.772
USDJPY 120 Min #5 | Reloading chart. | 2021-04-07 23:20:49.972
USDCAD 120 Min #6 | Reloading chart. | 2021-04-07 23:20:50.164
EURUSD 120 Min #7 | Reloading chart. | 2021-04-07 23:20:51.963
EURGBP 120 Min #8 | Reloading chart. | 2021-04-07 23:20:52.151
EURAUD 120 Min #9 | Reloading chart. | 2021-04-07 23:20:52.316
EURNZD 120 Min #10 | Reloading chart. | 2021-04-07 23:20:52.517
EURJPY 120 Min #11 | Reloading chart. | 2021-04-07 23:20:52.789
EURCAD 120 Min #12 | Reloading chart. | 2021-04-07 23:20:53.075
GBPUSD 120 Min #13 | Reloading chart. | 2021-04-07 23:20:53.319
EURGBP 120 Min #14 | Reloading chart. | 2021-04-07 23:20:53.717
GBPAUD 120 Min #15 | Reloading chart. | 2021-04-07 23:20:54.268
GBPNZD 120 Min #16 | Reloading chart. | 2021-04-07 23:20:55.065
GBPJPY 120 Min #17 | Reloading chart. | 2021-04-07 23:20:55.448
GBPCAD 120 Min #18 | Reloading chart. | 2021-04-07 23:20:56.395
AUDUSD 120 Min #19 | Reloading chart. | 2021-04-07 23:20:56.860
EURAUD 120 Min #20 | Reloading chart. | 2021-04-07 23:20:57.381
GBPAUD 120 Min #21 | Reloading chart. | 2021-04-07 23:20:57.762
AUDNZD 120 Min #22 | Reloading chart. | 2021-04-07 23:20:58.464
AUDJPY 120 Min #23 | Reloading chart. | 2021-04-07 23:20:59.083
AUDCAD 120 Min #24 | Reloading chart. | 2021-04-07 23:21:00.570
NZDUSD 120 Min #25 | Reloading chart. | 2021-04-07 23:21:01.053
EURNZD 120 Min #26 | Reloading chart. | 2021-04-07 23:21:01.534
GBPNZD 120 Min #27 | Reloading chart. | 2021-04-07 23:21:02.170
AUDNZD 120 Min #28 | Reloading chart. | 2021-04-07 23:21:02.800
NZDJPY 120 Min #29 | Reloading chart. | 2021-04-07 23:21:03.643
NZDCAD 120 Min #30 | Reloading chart. | 2021-04-07 23:21:04.746
USDJPY 120 Min #31 | Reloading chart. | 2021-04-07 23:21:06.659
EURJPY 120 Min #32 | Reloading chart. | 2021-04-07 23:21:07.727
GBPJPY 120 Min #33 | Reloading chart. | 2021-04-07 23:21:08.716
AUDJPY 120 Min #34 | Reloading chart. | 2021-04-07 23:21:10.363
NZDJPY 120 Min #35 | Reloading chart. | 2021-04-07 23:21:11.182
CADJPY 120 Min #36 | Reloading chart. | 2021-04-07 23:21:13.177
USDCAD 120 Min #37 | Reloading chart. | 2021-04-07 23:21:14.263
EURCAD 120 Min #38 | Reloading chart. | 2021-04-07 23:21:14.965
GBPCAD 120 Min #39 | Reloading chart. | 2021-04-07 23:21:15.616
AUDCAD 120 Min #40 | Reloading chart. | 2021-04-07 23:21:16.971
NZDCAD 120 Min #41 | Reloading chart. | 2021-04-07 23:21:18.450
CADJPY 120 Min #42 | Reloading chart. | 2021-04-07 23:21:19.327
USDCHF 120 Min #44 | Reloading chart. | 2021-04-07 23:21:21.065
EURCHF 120 Min #45 | Reloading chart. | 2021-04-07 23:21:22.616
GBPCHF 120 Min #46 | Reloading chart. | 2021-04-07 23:21:24.256
AUDCHF 120 Min #47 | Reloading chart. | 2021-04-07 23:21:26.420
NZDCHF 120 Min #48 | Reloading chart. | 2021-04-07 23:21:27.714
CADCHF 120 Min #49 | Reloading chart. | 2021-04-07 23:21:28.705
Files to Open on Startup | Opening file: s NJPY.Cht | 2021-04-07 23:21:29.074
NZDJPY 60 Min #1 | Reloading chart. | 2021-04-07 23:21:29.567
NZDJPY Weekly #2 | Reloading chart. | 2021-04-07 23:21:30.204
NZDJPY Daily #3 | Reloading chart. | 2021-04-07 23:21:32.370
NZDJPY 120 Min #4 | Reloading chart. | 2021-04-07 23:21:35.757
NZDJPY Daily #5 | Reloading chart. | 2021-04-07 23:21:39.856
NZDJPY 15 Min #6 | Reloading chart. | 2021-04-07 23:21:40.896
Files to Open on Startup | Opening file: s UCHF.Cht | 2021-04-07 23:21:42.302
USDCHF 60 Min #1 | Reloading chart. | 2021-04-07 23:21:43.895
USDCHF Daily #6 | Reloading chart. | 2021-04-07 23:21:46.897
USDCHF Weekly #7 | Reloading chart. | 2021-04-07 23:21:47.694
USDCHF 120 Min #2 | Reloading chart. | 2021-04-07 23:21:48.297
USDCHF Daily #3 | Reloading chart. | 2021-04-07 23:21:51.589
USDCHF 15 Min #4 | Reloading chart. | 2021-04-07 23:21:52.322
Files to Open on Startup | Opening file: s UJPY.Cht | 2021-04-07 23:21:52.484
USDJPY Weekly #3 | Reloading chart. | 2021-04-07 23:21:53.112
USDJPY Daily #4 | Reloading chart. | 2021-04-07 23:21:55.816
USDJPY 120 Min #2 | Reloading chart. | 2021-04-07 23:21:58.833
USDJPY 15 Min #6 | Reloading chart. | 2021-04-07 23:21:58.959
USDJPY Daily #7 | Reloading chart. | 2021-04-07 23:22:05.121
USDJPY 60 Min #5 | Reloading chart. | 2021-04-07 23:22:05.964
Files to Open on Startup | Opening file: s CAJPY.Cht | 2021-04-07 23:22:06.632
CADJPY 60 Min #1 | Reloading chart. | 2021-04-07 23:22:07.317
CADJPY Weekly #2 | Reloading chart. | 2021-04-07 23:22:08.655
CADJPY Daily #3 | Reloading chart. | 2021-04-07 23:22:09.204
CADJPY 120 Min #4 | Reloading chart. | 2021-04-07 23:22:09.363
CADJPY Daily #7 | Reloading chart. | 2021-04-07 23:22:14.108
CADJPY 15 Min #8 | Reloading chart. | 2021-04-07 23:22:14.889
Files to Open on Startup | Opening file: s CACHF.Cht | 2021-04-07 23:22:15.039
CADCHF 60 Min #1 | Reloading chart. | 2021-04-07 23:22:16.388
CADCHF Weekly #3 | Reloading chart. | 2021-04-07 23:22:17.990
CADCHF Daily #4 | Reloading chart. | 2021-04-07 23:22:19.237
CADCHF 120 Min #2 | Reloading chart. | 2021-04-07 23:22:20.123
CADCHF Daily #5 | Reloading chart. | 2021-04-07 23:22:25.961
CADCHF 15 Min #7 | Reloading chart. | 2021-04-07 23:22:28.460
Files to Open on Startup | Opening file: s GCHF.Cht | 2021-04-07 23:22:29.811
GBPCHF 60 Min #1 | Reloading chart. | 2021-04-07 23:22:31.111
GBPCHF Weekly #2 | Reloading chart. | 2021-04-07 23:22:32.536
GBPCHF Daily #3 | Reloading chart. | 2021-04-07 23:22:34.488
GBPCHF 120 Min #4 | Reloading chart. | 2021-04-07 23:22:35.207
GBPCHF Daily #5 | Reloading chart. | 2021-04-07 23:22:39.170
GBPCHF 15 Min #6 | Reloading chart. | 2021-04-07 23:22:41.638
Files to Open on Startup | Opening file: s ENZD.Cht | 2021-04-07 23:22:42.067
EURNZD 60 Min #1 | Reloading chart. | 2021-04-07 23:22:44.429
EURNZD Weekly #3 | Reloading chart. | 2021-04-07 23:22:48.699
EURNZD Daily #4 | Reloading chart. | 2021-04-07 23:22:49.630
EURNZD 120 Min #2 | Reloading chart. | 2021-04-07 23:22:50.324
EURNZD Daily #5 | Reloading chart. | 2021-04-07 23:22:52.458
EURNZD 15 Min #6 | Reloading chart. | 2021-04-07 23:22:53.554
Files to Open on Startup | Opening file: s EUSD.Cht | 2021-04-07 23:22:53.899
EURUSD 60 Min #1 | Reloading chart. | 2021-04-07 23:22:54.253
EURUSD Weekly #2 | Reloading chart. | 2021-04-07 23:22:54.996
EURUSD Daily #3 | Reloading chart. | 2021-04-07 23:22:55.464
EURUSD 120 Min #4 | Reloading chart. | 2021-04-07 23:22:56.310
EURUSD 15 Min #5 | Reloading chart. | 2021-04-07 23:22:56.635
EURUSD Daily #6 | Reloading chart. | 2021-04-07 23:23:00.771
Files to Open on Startup | Opening file: s ECAD.Cht | 2021-04-07 23:23:01.395
EURCAD 60 Min #1 | Reloading chart. | 2021-04-07 23:23:02.234
EURCAD Weekly #2 | Reloading chart. | 2021-04-07 23:23:02.728
EURCAD Daily #3 | Reloading chart. | 2021-04-07 23:23:03.083
EURCAD 120 Min #4 | Reloading chart. | 2021-04-07 23:23:21.628
EURCAD 15 Min #5 | Reloading chart. | 2021-04-07 23:23:22.033
EURCAD Daily #6 | Reloading chart. | 2021-04-07 23:23:22.539
Files to Open on Startup | Opening file: ats .Cht | 2021-04-07 23:23:23.253
GBPCHF 15 Min #1 | Reloading chart. | 2021-04-07 23:23:23.692
GBPCHF Daily #4 | Reloading chart. | 2021-04-07 23:23:24.373
GBPCHF 60 Min #5 | Reloading chart. | 2021-04-07 23:23:24.601
GBPCHF Daily #9 | Reloading chart. | 2021-04-07 23:23:38.317
GBPCHF 120 Min #10 | Reloading chart. | 2021-04-07 23:23:38.540
Files to Open on Startup | Opening file: s AUSD.Cht | 2021-04-07 23:23:39.686
AUDUSD 60 Min #1 | Reloading chart. | 2021-04-07 23:23:40.103
AUDUSD 120 Min #2 | Reloading chart. | 2021-04-07 23:23:40.231
AUDUSD Daily #3 | Reloading chart. | 2021-04-07 23:23:40.944
AUDUSD Weekly #4 | Reloading chart. | 2021-04-07 23:23:41.647
AUDUSD Daily #5 | Reloading chart. | 2021-04-07 23:23:54.901
AUDUSD 15 Min #6 | Reloading chart. | 2021-04-07 23:23:55.032
Files to Open on Startup | Opening file: s ACAD.Cht | 2021-04-07 23:23:55.595
AUDCAD 60 Min #1 | Reloading chart. | 2021-04-07 23:23:55.857
AUDCAD 120 Min #2 | Reloading chart. | 2021-04-07 23:23:55.952
AUDCAD Daily #3 | Reloading chart. | 2021-04-07 23:23:56.692
AUDCAD Weekly #4 | Reloading chart. | 2021-04-07 23:23:56.988
AUDUSD 15 Min #6 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2019-02-05 19:30:00. Next Bar Date Time: 2019-02-05 19:15:00. Filename: AUDUSD.scid | 2021-04-07 23:23:58.631
AUDCAD Daily #5 | Reloading chart. | 2021-04-07 23:24:01.693
AUDCAD 15 Min #6 | Reloading chart. | 2021-04-07 23:24:01.793
Files to Open on Startup | Opening file: s AJPY.Cht | 2021-04-07 23:24:02.428
AUDJPY 60 Min #1 | Reloading chart. | 2021-04-07 23:24:02.511
AUDJPY 120 Min #2 | Reloading chart. | 2021-04-07 23:24:02.775
AUDJPY Daily #3 | Reloading chart. | 2021-04-07 23:24:03.040
AUDJPY Weekly #4 | Reloading chart. | 2021-04-07 23:24:03.212
AUDJPY Daily #5 | Reloading chart. | 2021-04-07 23:24:04.442
AUDJPY 15 Min #6 | Reloading chart. | 2021-04-07 23:24:07.907
Files to Open on Startup | Opening file: s ACHF.Cht | 2021-04-07 23:24:08.077
AUDCHF 60 Min #1 | Reloading chart. | 2021-04-07 23:24:08.182
AUDCHF 120 Min #2 | Reloading chart. | 2021-04-07 23:24:13.410
AUDCHF Daily #3 | Reloading chart. | 2021-04-07 23:24:13.603
AUDCHF Weekly #4 | Reloading chart. | 2021-04-07 23:24:13.811
AUDCHF Daily #5 | Reloading chart. | 2021-04-07 23:24:14.446
AUDCHF 15 Min #6 | Reloading chart. | 2021-04-07 23:24:14.692
Files to Open on Startup | Opening file: s ANZD.Cht | 2021-04-07 23:24:16.673
AUDNZD 60 Min #1 | Reloading chart. | 2021-04-07 23:24:16.883
AUDNZD 120 Min #2 | Reloading chart. | 2021-04-07 23:24:17.069
AUDNZD Daily #3 | Reloading chart. | 2021-04-07 23:24:17.603
AUDNZD Weekly #4 | Reloading chart. | 2021-04-07 23:24:18.735
AUDNZD 15 Min #5 | Reloading chart. | 2021-04-07 23:24:18.836
AUDNZD Daily #6 | Reloading chart. | 2021-04-07 23:24:28.547
Files to Open on Startup | Opening file: s NUSD.Cht | 2021-04-07 23:24:29.072
NZDUSD 60 Min #1 | Reloading chart. | 2021-04-07 23:24:29.182
NZDUSD 120 Min #2 | Reloading chart. | 2021-04-07 23:24:29.329
NZDUSD Daily #3 | Reloading chart. | 2021-04-07 23:24:30.104
NZDUSD Weekly #4 | Reloading chart. | 2021-04-07 23:24:30.348
NZDUSD Daily #5 | Reloading chart. | 2021-04-07 23:24:34.191
NZDUSD 15 Min #6 | Reloading chart. | 2021-04-07 23:24:34.277
Files to Open on Startup | Opening file: s NCHF.Cht | 2021-04-07 23:24:34.471
NZDCHF 60 Min #1 | Reloading chart. | 2021-04-07 23:24:34.646
NZDCHF 120 Min #2 | Reloading chart. | 2021-04-07 23:24:34.949
NZDCHF Daily #3 | Reloading chart. | 2021-04-07 23:24:35.459
NZDCHF Weekly #4 | Reloading chart. | 2021-04-07 23:24:36.130
NZDCHF Daily #5 | Reloading chart. | 2021-04-07 23:24:40.955
NZDCHF 15 Min #6 | Reloading chart. | 2021-04-07 23:24:41.066
Files to Open on Startup | Opening file: s NCAD.Cht | 2021-04-07 23:24:41.279
NZDCAD 60 Min #1 | Reloading chart. | 2021-04-07 23:24:41.370
NZDCAD 120 Min #2 | Reloading chart. | 2021-04-07 23:24:41.467
NZDCAD Daily #3 | Reloading chart. | 2021-04-07 23:24:41.811
NZDCAD Weekly #4 | Reloading chart. | 2021-04-07 23:24:42.429
NZDCAD Daily #5 | Reloading chart. | 2021-04-07 23:24:47.952
NZDCAD 15 Min #6 | Reloading chart. | 2021-04-07 23:24:48.050
Files to Open on Startup | Opening file: s UCAD.Cht | 2021-04-07 23:24:48.423
USDCAD 60 Min #1 | Reloading chart. | 2021-04-07 23:24:48.497
USDCAD 120 Min #2 | Reloading chart. | 2021-04-07 23:24:48.630
USDCAD Daily #3 | Reloading chart. | 2021-04-07 23:24:49.398
USDCAD Weekly #4 | Reloading chart. | 2021-04-07 23:24:49.671
USDCAD Daily #5 | Reloading chart. | 2021-04-07 23:24:55.909
USDCAD 15 Min #6 | Reloading chart. | 2021-04-07 23:24:55.999
Files to Open on Startup | Opening file: s CHJPY.Cht | 2021-04-07 23:24:56.428
CHFJPY 60 Min #1 | Reloading chart. | 2021-04-07 23:24:56.578
CHFJPY 120 Min #2 | Reloading chart. | 2021-04-07 23:24:56.988
CHFJPY Daily #3 | Reloading chart. | 2021-04-07 23:24:57.325
CHFJPY Weekly #4 | Reloading chart. | 2021-04-07 23:24:57.900
CHFJPY Daily #5 | Reloading chart. | 2021-04-07 23:25:04.910
CHFJPY 15 Min #6 | Reloading chart. | 2021-04-07 23:25:04.998
Files to Open on Startup | Opening file: s ECHF.Cht | 2021-04-07 23:25:05.290
EURCHF 60 Min #1 | Reloading chart. | 2021-04-07 23:25:05.380
EURCHF 120 Min #2 | Reloading chart. | 2021-04-07 23:25:05.679
EURCHF Daily #3 | Reloading chart. | 2021-04-07 23:25:07.017
EURCHF Weekly #4 | Reloading chart. | 2021-04-07 23:25:07.805
EURCHF Daily #5 | Reloading chart. | 2021-04-07 23:25:11.600
EURCHF 15 Min #6 | Reloading chart. | 2021-04-07 23:25:11.685
Files to Open on Startup | Opening file: s EJPY.Cht | 2021-04-07 23:25:11.899
EURJPY 60 Min #1 | Reloading chart. | 2021-04-07 23:25:12.015
EURJPY 120 Min #2 | Reloading chart. | 2021-04-07 23:25:12.151
EURJPY Daily #3 | Reloading chart. | 2021-04-07 23:25:12.392
EURJPY Weekly #4 | Reloading chart. | 2021-04-07 23:25:13.020
EURJPY Daily #5 | Reloading chart. | 2021-04-07 23:25:21.886
EURJPY 15 Min #6 | Reloading chart. | 2021-04-07 23:25:21.980
Files to Open on Startup | Opening file: s EGBP.Cht | 2021-04-07 23:25:22.553
EURGBP 60 Min #1 | Reloading chart. | 2021-04-07 23:25:22.633
EURGBP 120 Min #2 | Reloading chart. | 2021-04-07 23:25:22.968
EURGBP Daily #3 | Reloading chart. | 2021-04-07 23:25:29.168
EURGBP Weekly #4 | Reloading chart. | 2021-04-07 23:25:29.406
EURGBP Daily #5 | Reloading chart. | 2021-04-07 23:25:29.538
EURGBP 15 Min #6 | Reloading chart. | 2021-04-07 23:25:29.646
Files to Open on Startup | Opening file: s GAUD.Cht | 2021-04-07 23:25:30.083
GBPAUD 60 Min #1 | Reloading chart. | 2021-04-07 23:25:30.196
GBPAUD 120 Min #2 | Reloading chart. | 2021-04-07 23:25:30.316
GBPAUD Daily #3 | Reloading chart. | 2021-04-07 23:25:30.583
GBPAUD Weekly #4 | Reloading chart. | 2021-04-07 23:25:30.813
GBPAUD Daily #5 | Reloading chart. | 2021-04-07 23:25:35.097
GBPAUD 15 Min #6 | Reloading chart. | 2021-04-07 23:25:35.210
Files to Open on Startup | Opening file: s GUSD.Cht | 2021-04-07 23:25:35.484
GBPUSD 60 Min #1 | Reloading chart. | 2021-04-07 23:25:35.588
GBPUSD 120 Min #2 | Reloading chart. | 2021-04-07 23:25:35.815
GBPUSD Daily #3 | Reloading chart. | 2021-04-07 23:25:36.136
GBPUSD Weekly #4 | Reloading chart. | 2021-04-07 23:25:36.820
GBPUSD Daily #5 | Reloading chart. | 2021-04-07 23:25:46.295
GBPUSD 15 Min #6 | Reloading chart. | 2021-04-07 23:25:46.416
Files to Open on Startup | Opening file: s GNZD.Cht | 2021-04-07 23:25:47.551
GBPNZD 60 Min #1 | Reloading chart. | 2021-04-07 23:25:47.660
GBPNZD 120 Min #2 | Reloading chart. | 2021-04-07 23:25:47.786
GBPNZD Daily #3 | Reloading chart. | 2021-04-07 23:25:48.045
GBPNZD Weekly #4 | Reloading chart. | 2021-04-07 23:25:48.352
GBPNZD Daily #5 | Reloading chart. | 2021-04-07 23:26:04.091
GBPNZD 15 Min #6 | Reloading chart. | 2021-04-07 23:26:04.193
Files to Open on Startup | Opening file: s GCAD.Cht | 2021-04-07 23:26:04.446
GBPCAD 60 Min #1 | Reloading chart. | 2021-04-07 23:26:04.575
GBPCAD 120 Min #2 | Reloading chart. | 2021-04-07 23:26:04.892
GBPCAD Daily #3 | Reloading chart. | 2021-04-07 23:26:05.877
GBPCAD Weekly #4 | Reloading chart. | 2021-04-07 23:26:06.489
GBPCAD Daily #5 | Reloading chart. | 2021-04-07 23:26:11.371
GBPCAD 15 Min #6 | Reloading chart. | 2021-04-07 23:26:11.508
Files to Open on Startup | Opening file: s GJPY.Cht | 2021-04-07 23:26:11.837
GBPJPY 60 Min #1 | Reloading chart. | 2021-04-07 23:26:12.040
GBPJPY 120 Min #2 | Reloading chart. | 2021-04-07 23:26:12.346
GBPJPY Daily #3 | Reloading chart. | 2021-04-07 23:26:27.641
GBPJPY Weekly #4 | Reloading chart. | 2021-04-07 23:26:28.150
GBPJPY Daily #5 | Reloading chart. | 2021-04-07 23:26:28.424
GBPJPY 15 Min #6 | Reloading chart. | 2021-04-07 23:26:29.016
Symbol settings received. Request ID: 2. | 2021-04-07 23:26:54.323
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-04-07 23:26:54.414 *
Using Bid/Ask average for last trade price for EURNZD | 2021-04-07 23:26:54.592
Starting DelayedDownloadMonitoringTimer | 2021-04-07 23:26:54.594
Starting HDTimeoutTimer | 2021-04-07 23:26:54.594
Historical data service client indicated that downloads are not enabled. Symbol: EURNZD. Data Type: Intraday data | 2021-04-07 23:26:54.594
Historical data download ID 1 not found when removing ID from outstanding request set. | 2021-04-07 23:26:54.594
Starting DelayedDownloadMonitoringTimer | 2021-04-07 23:26:54.613
Starting HDTimeoutTimer | 2021-04-07 23:26:54.614
Historical data service client indicated that downloads are not enabled. Symbol: EURNZD. Data Type: Daily data | 2021-04-07 23:26:54.614
Historical data download ID 2 not found when removing ID from outstanding request set. | 2021-04-07 23:26:54.614
Using Bid/Ask average for last trade price for EURCHF | 2021-04-07 23:26:54.626
Historical data service client indicated that downloads are not enabled. Symbol: EURCHF. Data Type: Intraday data | 2021-04-07 23:26:54.626
Historical data download ID 3 not found when removing ID from outstanding request set. | 2021-04-07 23:26:54.626
Historical data service client indicated that downloads are not enabled. Symbol: EURCHF. Data Type: Daily data | 2021-04-07 23:26:54.907
Historical data download ID 4 not found when removing ID from outstanding request set. | 2021-04-07 23:26:54.907
Using Bid/Ask average for last trade price for EURJPY | 2021-04-07 23:26:54.929
Historical data service client indicated that downloads are not enabled. Symbol: EURJPY. Data Type: Intraday data | 2021-04-07 23:26:54.930
Historical data download ID 5 not found when removing ID from outstanding request set. | 2021-04-07 23:26:54.930
Historical data service client indicated that downloads are not enabled. Symbol: EURJPY. Data Type: Daily data | 2021-04-07 23:26:54.950
Historical data download ID 6 not found when removing ID from outstanding request set. | 2021-04-07 23:26:54.950
Using Bid/Ask average for last trade price for EURUSD | 2021-04-07 23:26:54.964
Historical data service client indicated that downloads are not enabled. Symbol: EURUSD. Data Type: Intraday data | 2021-04-07 23:26:54.964
Historical data download ID 7 not found when removing ID from outstanding request set. | 2021-04-07 23:26:54.964
Historical data service client indicated that downloads are not enabled. Symbol: EURUSD. Data Type: Daily data | 2021-04-07 23:26:54.983
Historical data download ID 8 not found when removing ID from outstanding request set. | 2021-04-07 23:26:54.983
Using Bid/Ask average for last trade price for EURCAD | 2021-04-07 23:26:54.999
Historical data service client indicated that downloads are not enabled. Symbol: EURCAD. Data Type: Intraday data | 2021-04-07 23:26:54.999
Historical data download ID 9 not found when removing ID from outstanding request set. | 2021-04-07 23:26:54.999
Historical data service client indicated that downloads are not enabled. Symbol: EURCAD. Data Type: Daily data | 2021-04-07 23:26:55.024
Historical data download ID 10 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.024
Using Bid/Ask average for last trade price for EURGBP | 2021-04-07 23:26:55.042
Historical data service client indicated that downloads are not enabled. Symbol: EURGBP. Data Type: Intraday data | 2021-04-07 23:26:55.043
Historical data download ID 11 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.043
Historical data service client indicated that downloads are not enabled. Symbol: EURGBP. Data Type: Daily data | 2021-04-07 23:26:55.068
Historical data download ID 12 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.068
Using Bid/Ask average for last trade price for GBPAUD | 2021-04-07 23:26:55.074
Historical data service client indicated that downloads are not enabled. Symbol: GBPAUD. Data Type: Intraday data | 2021-04-07 23:26:55.075
Historical data download ID 13 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.075
Historical data service client indicated that downloads are not enabled. Symbol: GBPAUD. Data Type: Daily data | 2021-04-07 23:26:55.083
Historical data download ID 14 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.083
Using Bid/Ask average for last trade price for GBPUSD | 2021-04-07 23:26:55.088
Historical data service client indicated that downloads are not enabled. Symbol: GBPUSD. Data Type: Intraday data | 2021-04-07 23:26:55.088
Historical data download ID 15 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.088
Historical data service client indicated that downloads are not enabled. Symbol: GBPUSD. Data Type: Daily data | 2021-04-07 23:26:55.095
Historical data download ID 16 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.095
Using Bid/Ask average for last trade price for GBPNZD | 2021-04-07 23:26:55.100
Historical data service client indicated that downloads are not enabled. Symbol: GBPNZD. Data Type: Intraday data | 2021-04-07 23:26:55.100
Historical data download ID 17 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.100
Historical data service client indicated that downloads are not enabled. Symbol: GBPNZD. Data Type: Daily data | 2021-04-07 23:26:55.107
Historical data download ID 18 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.107
Using Bid/Ask average for last trade price for GBPCAD | 2021-04-07 23:26:55.114
Historical data service client indicated that downloads are not enabled. Symbol: GBPCAD. Data Type: Intraday data | 2021-04-07 23:26:55.114
Historical data download ID 19 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.114
Historical data service client indicated that downloads are not enabled. Symbol: GBPCAD. Data Type: Daily data | 2021-04-07 23:26:55.119
Historical data download ID 20 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.119
Using Bid/Ask average for last trade price for GBPCHF | 2021-04-07 23:26:55.124
Historical data service client indicated that downloads are not enabled. Symbol: GBPCHF. Data Type: Intraday data | 2021-04-07 23:26:55.124
Historical data download ID 21 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.124
Historical data service client indicated that downloads are not enabled. Symbol: GBPCHF. Data Type: Daily data | 2021-04-07 23:26:55.130
Historical data download ID 22 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.130
Using Bid/Ask average for last trade price for GBPJPY | 2021-04-07 23:26:55.134
Historical data service client indicated that downloads are not enabled. Symbol: GBPJPY. Data Type: Intraday data | 2021-04-07 23:26:55.134
Historical data download ID 23 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.134
Historical data service client indicated that downloads are not enabled. Symbol: GBPJPY. Data Type: Daily data | 2021-04-07 23:26:55.165
Historical data download ID 24 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.165
Using Bid/Ask average for last trade price for AUDUSD | 2021-04-07 23:26:55.192
Historical data service client indicated that downloads are not enabled. Symbol: AUDUSD. Data Type: Intraday data | 2021-04-07 23:26:55.192
Historical data download ID 25 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.192
Using Bid/Ask average for last trade price for AUDCAD | 2021-04-07 23:26:55.195
Historical data service client indicated that downloads are not enabled. Symbol: AUDCAD. Data Type: Intraday data | 2021-04-07 23:26:55.195
Historical data download ID 26 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.195
Using Bid/Ask average for last trade price for AUDJPY | 2021-04-07 23:26:55.196
Historical data service client indicated that downloads are not enabled. Symbol: AUDJPY. Data Type: Intraday data | 2021-04-07 23:26:55.196
Historical data download ID 27 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.196
Using Bid/Ask average for last trade price for AUDCHF | 2021-04-07 23:26:55.197
Historical data service client indicated that downloads are not enabled. Symbol: AUDCHF. Data Type: Intraday data | 2021-04-07 23:26:55.197
Historical data download ID 28 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.197
Using Bid/Ask average for last trade price for AUDNZD | 2021-04-07 23:26:55.198
Historical data service client indicated that downloads are not enabled. Symbol: AUDNZD. Data Type: Intraday data | 2021-04-07 23:26:55.198
Historical data download ID 29 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.198
Using Bid/Ask average for last trade price for NZDUSD | 2021-04-07 23:26:55.198
Historical data service client indicated that downloads are not enabled. Symbol: NZDUSD. Data Type: Intraday data | 2021-04-07 23:26:55.199
Historical data download ID 30 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.199
Using Bid/Ask average for last trade price for NZDCHF | 2021-04-07 23:26:55.199
Historical data service client indicated that downloads are not enabled. Symbol: NZDCHF. Data Type: Intraday data | 2021-04-07 23:26:55.199
Historical data download ID 31 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.199
Using Bid/Ask average for last trade price for NZDJPY | 2021-04-07 23:26:55.200
Historical data service client indicated that downloads are not enabled. Symbol: NZDJPY. Data Type: Intraday data | 2021-04-07 23:26:55.200
Historical data download ID 32 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.200
Using Bid/Ask average for last trade price for NZDCAD | 2021-04-07 23:26:55.201
Historical data service client indicated that downloads are not enabled. Symbol: NZDCAD. Data Type: Intraday data | 2021-04-07 23:26:55.201
Historical data download ID 33 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.201
Using Bid/Ask average for last trade price for USDCHF | 2021-04-07 23:26:55.202
Historical data service client indicated that downloads are not enabled. Symbol: USDCHF. Data Type: Intraday data | 2021-04-07 23:26:55.202
Historical data download ID 34 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.202
Using Bid/Ask average for last trade price for USDJPY | 2021-04-07 23:26:55.204
Historical data service client indicated that downloads are not enabled. Symbol: USDJPY. Data Type: Intraday data | 2021-04-07 23:26:55.204
Historical data download ID 35 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.204
Using Bid/Ask average for last trade price for USDCAD | 2021-04-07 23:26:55.205
Historical data service client indicated that downloads are not enabled. Symbol: USDCAD. Data Type: Intraday data | 2021-04-07 23:26:55.205
Historical data download ID 36 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.205
Using Bid/Ask average for last trade price for CHFJPY | 2021-04-07 23:26:55.206
Historical data service client indicated that downloads are not enabled. Symbol: CHFJPY. Data Type: Intraday data | 2021-04-07 23:26:55.206
Historical data download ID 37 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.206
Using Bid/Ask average for last trade price for CADJPY | 2021-04-07 23:26:55.216
Historical data service client indicated that downloads are not enabled. Symbol: CADJPY. Data Type: Intraday data | 2021-04-07 23:26:55.216
Historical data download ID 38 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.216
Using Bid/Ask average for last trade price for CADCHF | 2021-04-07 23:26:55.217
Historical data service client indicated that downloads are not enabled. Symbol: CADCHF. Data Type: Intraday data | 2021-04-07 23:26:55.217
Historical data download ID 39 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.217
Historical data service client indicated that downloads are not enabled. Symbol: AUDUSD. Data Type: Daily data | 2021-04-07 23:26:55.229
Historical data download ID 40 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.229
Historical data service client indicated that downloads are not enabled. Symbol: AUDCAD. Data Type: Daily data | 2021-04-07 23:26:55.235
Historical data download ID 41 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.235
Historical data service client indicated that downloads are not enabled. Symbol: AUDJPY. Data Type: Daily data | 2021-04-07 23:26:55.241
Historical data download ID 42 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.241
Historical data service client indicated that downloads are not enabled. Symbol: AUDCHF. Data Type: Daily data | 2021-04-07 23:26:55.248
Historical data download ID 43 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.248
Historical data service client indicated that downloads are not enabled. Symbol: AUDNZD. Data Type: Daily data | 2021-04-07 23:26:55.255
Historical data download ID 44 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.255
Historical data service client indicated that downloads are not enabled. Symbol: NZDUSD. Data Type: Daily data | 2021-04-07 23:26:55.261
Historical data download ID 45 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.261
Historical data service client indicated that downloads are not enabled. Symbol: NZDCHF. Data Type: Daily data | 2021-04-07 23:26:55.267
Historical data download ID 46 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.267
Historical data service client indicated that downloads are not enabled. Symbol: NZDJPY. Data Type: Daily data | 2021-04-07 23:26:55.272
Historical data download ID 47 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.272
Historical data service client indicated that downloads are not enabled. Symbol: NZDCAD. Data Type: Daily data | 2021-04-07 23:26:55.277
Historical data download ID 48 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.277
Historical data service client indicated that downloads are not enabled. Symbol: USDCHF. Data Type: Daily data | 2021-04-07 23:26:55.284
Historical data download ID 49 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.284
Historical data service client indicated that downloads are not enabled. Symbol: USDJPY. Data Type: Daily data | 2021-04-07 23:26:55.293
Historical data download ID 50 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.293
Historical data service client indicated that downloads are not enabled. Symbol: USDCAD. Data Type: Daily data | 2021-04-07 23:26:55.298
Historical data download ID 51 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.298
Historical data service client indicated that downloads are not enabled. Symbol: CHFJPY. Data Type: Daily data | 2021-04-07 23:26:55.302
Historical data download ID 52 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.302
Historical data service client indicated that downloads are not enabled. Symbol: CADJPY. Data Type: Daily data | 2021-04-07 23:26:55.307
Historical data download ID 53 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.307
Historical data service client indicated that downloads are not enabled. Symbol: CADCHF. Data Type: Daily data | 2021-04-07 23:26:55.313
Historical data download ID 54 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.313
Using Bid/Ask average for last trade price for EURAUD | 2021-04-07 23:26:55.320
Historical data service client indicated that downloads are not enabled. Symbol: EURAUD. Data Type: Intraday data | 2021-04-07 23:26:55.320
Historical data download ID 55 not found when removing ID from outstanding request set. | 2021-04-07 23:26:55.320
Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2021-04-07 23:26:55.458 *
EURNZD Daily #14 | Reloading chart. | 2021-04-07 23:26:55.472
EURCHF Daily #12 | Reloading chart. | 2021-04-07 23:26:55.501
EURJPY Daily #12 | Reloading chart. | 2021-04-07 23:26:55.534
EURUSD Daily #12 | Reloading chart. | 2021-04-07 23:26:55.572
EURCAD Daily #12 | Reloading chart. | 2021-04-07 23:26:55.637
EURGBP Daily #13 | Reloading chart. | 2021-04-07 23:26:55.692
GBPAUD Daily #13 | Reloading chart. | 2021-04-07 23:26:55.767
GBPUSD Daily #13 | Reloading chart. | 2021-04-07 23:26:55.826
GBPNZD Daily #13 | Reloading chart. | 2021-04-07 23:26:55.866
GBPCAD Daily #13 | Reloading chart. | 2021-04-07 23:26:55.929
GBPCHF Daily #13 | Reloading chart. | 2021-04-07 23:26:55.995
GBPJPY Daily #13 | Reloading chart. | 2021-04-07 23:26:56.026
AUDUSD Daily #13 | Reloading chart. | 2021-04-07 23:26:56.096
AUDCAD Daily #13 | Reloading chart. | 2021-04-07 23:26:56.148
AUDJPY Daily #3 | Reloading chart. | 2021-04-07 23:26:56.186
AUDCHF Daily #13 | Reloading chart. | 2021-04-07 23:26:56.236
AUDNZD Daily #13 | Reloading chart. | 2021-04-07 23:26:56.270
NZDUSD Daily #13 | Reloading chart. | 2021-04-07 23:26:56.325
NZDCHF Daily #13 | Reloading chart. | 2021-04-07 23:26:56.479
NZDJPY Daily #13 | Reloading chart. | 2021-04-07 23:26:56.511
NZDCAD Daily #2 | Reloading chart. | 2021-04-07 23:26:56.535
USDCHF Daily #13 | Reloading chart. | 2021-04-07 23:26:56.581
USDJPY Daily #5 | Reloading chart. | 2021-04-07 23:26:56.607
USDCAD Daily #8 | Reloading chart. | 2021-04-07 23:26:56.649
CHFJPY Daily #13 | Reloading chart. | 2021-04-07 23:26:56.674
CADJPY Daily #13 | Reloading chart. | 2021-04-07 23:26:56.709
CADCHF Daily #13 | Reloading chart. | 2021-04-07 23:26:56.740
Source file does not exist when saving backup of C:\SierraChart\TradePositions.data. No backup made. | 2021-04-08 07:26:41.767
Notice: Detected that the system has resumed from a low-power state. | 2021-04-08 07:26:45.187
Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2021-04-08 10:10:05.068 *
Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2021-04-08 10:10:09.792 *
[2021-04-08 18:57:49]
John - SC Support - Posts: 48196
This is the problem:
Usage time has ended. Sierra Chart is in Free mode. Features are restricted.
The first thing to check is that the Account Name that is being used when you log into the Sierra Chart software matches the Account Name that you used to post to this Support Board. If it is not, then change it and log in to your Sierra Chart software using the account you posted from, as it is a valid account.
If you do have the correct account, then use the Forced Login option to ensure that your account information is properly updated. Refer to the following:
Sierra Chart - Software Login Instructions: Forced Login
Finally, if none of the above work, then check your Internet connection, as you must be offline.
[2021-04-09 13:53:47]
User774053 - Posts: 3
The forced login corrected the problem, thank you!
