Date/Time: Fri, 07 Feb 2025 15:23:54 +0000
SC 2111 will not open chartbooks
View Count: 626
[2020-06-04 15:21:43] |
User93464 - Posts: 52 |
On opening SC 2111, it does not load the chartbooks as I have defined in General settings
[2020-06-04 23:16:48] |
There is definitely no problem with this functionality in that version. That has been verified. There are two options on the Login window which can disable automatically opening Chartbooks: General Settings Window: Temporarily Preventing Automatic Opening of Files on Startup Otherwise: Can you open the chartbooks through the process of File >> Open Chartbook? If that also fails, then we need to see your Message Log after you try to open one of the files. Refer to the following instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chartbook you have an issue with. Provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-05 10:26:11] |
All the chartbooks that would normally open on loading of SC failed to do so. All had a reduced file size of 32KB instead of 800 to 900KB I have had to rebuild each chartbook manually in order to begin trading again Enclosed is the message log Reading Internal Order ID file. | 2020-06-05 05:46:57.578 Reading Trade Orders file. | 2020-06-05 05:46:57.654 Reading Trade Positions file. | 2020-06-05 05:46:57.658 Reading Account Balance file. | 2020-06-05 05:46:57.659 UDPListener (1424). Port 22903 | Listening on UDP port 22903. | 2020-06-05 05:46:57.677 Software version: 2111 64-bit | 2020-06-05 05:46:57.678 Primary Thread ID: 2880 | 2020-06-05 05:46:57.678 Usage end date: 2020-07-06 | 2020-06-05 05:46:57.678 Enabled for: Advanced Features 2. | 2020-06-05 05:46:57.678 Enabled for: Sierra Chart Historical Data Service. | 2020-06-05 05:46:57.678 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-05 05:46:57.678 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-06-05 05:46:57.678 Current selected Data/Trading service: SC Data - All Services | 2020-06-05 05:46:57.678 Custom symbol settings values: enabled | 2020-06-05 05:46:57.678 Chart Update Interval: 300 | 2020-06-05 05:46:57.678 Intraday Data Storage Time Unit: 0 | 2020-06-05 05:46:57.678 Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2020-06-05 05:46:57.678 2020-06-05 05:46:57 Local computer time | 2020-06-05 05:46:57.678 2020-06-05 04:46:57 Local computer time in UTC | 2020-06-05 05:46:57.678 2020-06-05 05:46:57 Local computer time in SC Time Zone | 2020-06-05 05:46:57.678 2020-06-05 04:46:56 Server time in UTC | 2020-06-05 05:46:57.678 Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-06-05 05:46:57.678 Program path: C:\SierraChart\ | 2020-06-05 05:46:57.678 Data Files path: C:\SierraChart\Data\ | 2020-06-05 05:46:57.678 OS Version Number: 10.0 | 2020-06-05 05:46:57.678 Locale Setting: C | 2020-06-05 05:46:57.678 Allowed protected custom studies: Trade29 Custom Studies | 2020-06-05 05:46:57.678 Created the DTC Protocol server. | 2020-06-05 05:46:57.679 DTC Protocol Server listening on port 11099. | 2020-06-05 05:46:57.680 Created the DTC Protocol historical data server. | 2020-06-05 05:46:57.680 HD Server Manager | Listening on port 11098 | 2020-06-05 05:46:57.681 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2020-06-05 05:46:57.681 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-06-05 05:46:57.730 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-06-05 05:46:57.753 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-06-05 05:46:57.753 Received 5 login tokens. | 2020-06-05 05:46:57.809 Symbol settings MD5 received. Request ID: 1. | 2020-06-05 05:47:00.578 Symbol settings are up-to-date for scdataallservices. | 2020-06-05 05:47:00.578 Files to Open on Start up | Opening file: DB yields.Cht | 2020-06-05 05:47:00.842 Loading DLL C:\SierraChart\Data\Ysync7C2_64.dll | 2020-06-05 05:47:00.848 EURUSD 1 Min #1 | Reloading chart. | 2020-06-05 05:47:00.876 Files to Open on Start up | Opening file: SEAN GB Sam.Cht | 2020-06-05 05:47:00.888 GBPUSD 15 Min #1 | Reloading chart. | 2020-06-05 05:47:00.921 US02YY1 1 Min #2 | Reloading chart. | 2020-06-05 05:47:01.050 US10YY1 1 Min #3 | Reloading chart. | 2020-06-05 05:47:01.066 GB02YY1 1 Min #4 | Reloading chart. | 2020-06-05 05:47:01.085 GB10YY1 1 Min #5 | Reloading chart. | 2020-06-05 05:47:01.104 GBPUSD 30 Min #6 | Reloading chart. | 2020-06-05 05:47:01.209 Loading DLL C:\SierraChart\Data\UserContributedStudies_64.dll | 2020-06-05 05:47:01.323 Loading DLL C:\SierraChart\Data\BetterMomentum2_1_64.dll | 2020-06-05 05:47:01.369 GBPUSD 5 Min #7 | Reloading chart. | 2020-06-05 05:47:01.505 GBPUSD 1 Min #8 | Reloading chart. | 2020-06-05 05:47:01.761 SPX500 5 Min #9 | Reloading chart. | 2020-06-05 05:47:01.845 UK100 5 Min #10 | Reloading chart. | 2020-06-05 05:47:01.891 USDOLLAR 5 Min #11 | Reloading chart. | 2020-06-05 05:47:02.064 Files to Open on Start up | Opening file: SEAN CY Sam.Cht | 2020-06-05 05:47:02.109 CADJPY 15 Min #1 | Reloading chart. | 2020-06-05 05:47:02.346 JP02YY1 1 Min #2 | Reloading chart. | 2020-06-05 05:47:02.596 JP10YY1 1 Min #3 | Reloading chart. | 2020-06-05 05:47:02.954 CA02YY1 1 Min #4 | Reloading chart. | 2020-06-05 05:47:03.236 CA10YY1 1 Min #5 | Reloading chart. | 2020-06-05 05:47:03.352 CADJPY 30 Min #6 | Reloading chart. | 2020-06-05 05:47:03.677 CADJPY 5 Min #7 | Reloading chart. | 2020-06-05 05:47:03.961 CADJPY 1 Min #8 | Reloading chart. | 2020-06-05 05:47:04.474 GER30 1 Min #9 | Reloading chart. | 2020-06-05 05:47:04.961 JPN225 1 Min #10 | Reloading chart. | 2020-06-05 05:47:05.282 Files to Open on Start up | Opening file: SEAN EU Sam.Cht | 2020-06-05 05:47:05.293 EURUSD 15 Min #1 | Reloading chart. | 2020-06-05 05:47:05.649 US02YY1 1 Min #2 | Reloading chart. | 2020-06-05 05:47:05.847 US10YY1 1 Min #3 | Reloading chart. | 2020-06-05 05:47:05.861 DE02YY1 1 Min #4 | Reloading chart. | 2020-06-05 05:47:06.087 DE10YY1 1 Min #5 | Reloading chart. | 2020-06-05 05:47:06.311 EURUSD 30 Min #6 | Reloading chart. | 2020-06-05 05:47:06.653 EURUSD 5 Min #7 | Reloading chart. | 2020-06-05 05:47:07.117 EURUSD 1 Min #8 | Reloading chart. | 2020-06-05 05:47:07.269 SPX500 1 Min #9 | Reloading chart. | 2020-06-05 05:47:07.383 GER30 1 Min #10 | Reloading chart. | 2020-06-05 05:47:07.543 USDOLLAR 5 Min #11 | Reloading chart. | 2020-06-05 05:47:07.946 USDJPY 1 Min #12 | Reloading chart. | 2020-06-05 05:47:08.180 EURJPY 1 Min #13 | Reloading chart. | 2020-06-05 05:47:08.513 Files to Open on Start up | Opening file: SEAN UJ Sam.Cht | 2020-06-05 05:47:08.544 USDJPY 15 Min #1 | Reloading chart. | 2020-06-05 05:47:08.718 JP02YY1 1 Min #2 | Reloading chart. | 2020-06-05 05:47:09.385 JP10YY1 1 Min #3 | Reloading chart. | 2020-06-05 05:47:09.748 US02YY1 1 Min #4 | Reloading chart. | 2020-06-05 05:47:09.769 US10YY1 1 Min #5 | Reloading chart. | 2020-06-05 05:47:10.353 USDJPY 30 Min #6 | Reloading chart. | 2020-06-05 05:47:11.352 USDJPY 5 Min #7 | Reloading chart. | 2020-06-05 05:47:11.478 USDJPY 1 Min #8 | Reloading chart. | 2020-06-05 05:47:11.515 JPN225 1 Min #9 | Reloading chart. | 2020-06-05 05:47:11.868 SPX500 1 Min #10 | Reloading chart. | 2020-06-05 05:47:12.217 TED1 1 Min #11 | Reloading chart. | 2020-06-05 05:47:12.859 USOil 5 Min #12 | Reloading chart. | 2020-06-05 05:47:14.044 USDOLLAR 5 Min #13 | Reloading chart. | 2020-06-05 05:47:14.464 Files to Open on Start up | Opening file: SEAN EJ Sam.Cht | 2020-06-05 05:47:14.620 Date Time Of Last Edit: 2020-06-05 10:37:51
[2020-06-05 10:35:45] |
You had a newer version of Sierra Chart installed that supported compression of Chartbooks and then you went back to an earlier version that did not support the compression. So you just need to use the backup Chartbook files: Chartbooks (Workspaces): Accessing a Backup Chartbook File Or install the current version: Software Download: Fast Update I have had to rebuild each chartbook manually in order to begin trading again Please ask us first before doing this. There is no need for this because there are full backups available.
[2020-06-05 13:38:05] |
The problem first occurred on 2111, I moved to a newer version to try and cure the problem, that was no help and I reverted back to 2111
[2020-06-05 18:20:07] |
Well there definitely is no issue with the automatic opening of files on 2111 or any version. That is with certainty. Other than of failure to open a Chartbook due to a compatibility issue due to the version that it was saved in. Since we do not know the precise details of what you are doing and the state of the files, whether compressed or compressed, at each version, we cannot say exactly what happened. But there are backup Chartbook's available: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-05 18:20:48
