Date/Time: Fri, 03 May 2024 11:25:54 +0000
No Data for second acct, it stopped working
View Count: 705
[2019-12-12 18:01:59] |
John M - Posts: 165 |
I have 2 data feeds and my account is current. The second acct is not being allowed data even tho' I had data earlier this morning and yesterday. Please fix this. Thank you. |
Capture.PNG / V - Attached On 2019-12-12 18:01:41 UTC - Size: 20.54 KB - 216 views |
[2019-12-12 21:33:57] |
We apologize for the delay. That screenshot is not sufficient for us. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-12 21:34:09
[2019-12-12 22:17:56] |
I can tell you this : I closed both instances of SC and then reopened the one that was not getting data and it worked receiving the data feed. I then opened the other instance that was getting data and it did not receive data as the second instance open. I then closed both of them and reopened them after waiting a bit and now they are both working. I don't know what to tell you but as you can see from the screenshot it was saying it was not authorized and then it decided it was after all. This is after it had been running fine all morning and for days prior. I have had this setup working for months. There is not much point in doing the test you describe as both instances are receiving data now. However there was most definitely an issue as documented in the screen capture so be advised that something on the SC data/accounting end decided that it wasn't authorized when it clearly was and then decided it was ok again. Thank you. |
[2019-12-13 14:55:18] |
so be advised that something on the SC data/accounting end No, this could not be the case because this is all managed on the Sierra Chart client-side. It is the Sierra Chart side, which determines the routing of market data requests and whether there is an authorized trading account or not.We must see the complete Message Log. Otherwise, we have no idea about the problem. You also need to update to the current version: Software Download: Fast Update Support for the version you are running when using the Sierra Chart data feeds will be coming to an end due to protocol updates. We will be putting out an update notice. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-13 14:56:32
[2020-03-01 20:16:59] |
Software version: 2057 32-bit | 2020-03-01 14:10:57.961 Usage end date: 2020-04-01 | 2020-03-01 14:10:57.961 Enabled for: Advanced Features 2. | 2020-03-01 14:10:57.961 Enabled for: Sierra Chart Historical Data Service. | 2020-03-01 14:10:57.961 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2020-03-01 14:10:57.961 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-03-01 14:10:57.961 Enabled for exchange: INDEXES_DATA_BARCHART | 2020-03-01 14:10:57.961 Enabled for exchange: CME (Trading Account Required) | 2020-03-01 14:10:57.961 Enabled for exchange: CBOT (Trading Account Required) | 2020-03-01 14:10:57.961 Enabled for exchange: COMEX (Trading Account Required) | 2020-03-01 14:10:57.961 Enabled for exchange: NYMEX (Trading Account Required) | 2020-03-01 14:10:57.961 Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX, BATS) | 2020-03-01 14:10:57.961 Enabled for exchange: BATS (NYSE, NASDAQ) | 2020-03-01 14:10:57.961 Received 1 data feed usernames. | 2020-03-01 14:10:57.961 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-03-01 14:10:57.961 Current selected Data/Trading service: Interactive Brokers | 2020-03-01 14:10:57.961 Custom symbol settings values: disabled | 2020-03-01 14:10:57.961 Chart Update Interval: 100 | 2020-03-01 14:10:57.961 Intraday Data Storage Time Unit: 0 | 2020-03-01 14:10:57.961 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-03-01 14:10:57.961 2020-03-01 14:10:57 Local computer time | 2020-03-01 14:10:57.961 2020-03-01 20:10:57 Local computer time in UTC | 2020-03-01 14:10:57.961 2020-03-01 14:10:57 Local computer time in SC Time Zone | 2020-03-01 14:10:57.961 2020-03-01 20:01:07 Server time in UTC | 2020-03-01 14:10:57.961 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-03-01 14:10:57.961 Program path: E:\SierraChart\ | 2020-03-01 14:10:57.961 Data Files path: E:\SierraChart\Data\ | 2020-03-01 14:10:57.961 OS Version Number: 6.1 | 2020-03-01 14:10:57.962 Locale Setting: C | 2020-03-01 14:10:57.962 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-03-01 14:10:57.964 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2020-03-01 14:11:58.218 IB TWS socket (1) | Creating socket. | 2020-03-01 14:11:58.218 IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2020-03-01 14:11:58.218 Starting TWS auto-login thread. | 2020-03-01 14:11:58.218 TWS auto-login thread ending. | 2020-03-01 14:11:58.219 Interactive Brokers | Sending API sign: API | 2020-03-01 14:11:58.719 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2020-03-01 14:11:58.719 Interactive Brokers | TWS server version: 136 | 2020-03-01 14:11:58.721 Interactive Brokers | TWS time: 20200301 14:11:58 Central Standard Time | 2020-03-01 14:11:58.721 Interactive Brokers | Connected. Sending Start API command. | 2020-03-01 14:11:58.971 Interactive Brokers | Waiting for account information. | 2020-03-01 14:11:58.971 IB Account information received. | 2020-03-01 14:11:58.971 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2020-03-01 14:11:58.971 Interactive Brokers | Connected to Live account. | 2020-03-01 14:11:58.971 Interactive Brokers | Year-Month last connected to Live account: 2020-03 | 2020-03-01 14:11:58.971 Interactive Brokers | Connected to data and trading server. | 2020-03-01 14:11:58.971 Triggering next historical data download in queue. | 2020-03-01 14:11:58.972 Triggering next historical data download in queue. | 2020-03-01 14:11:58.972 Triggering next historical data download in queue. | 2020-03-01 14:11:58.972 Triggering next historical data download in queue. | 2020-03-01 14:11:58.972 Next valid order ID: 56221 | 2020-03-01 14:11:59.286 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: Market data farm connection is OK:cashfarm. IB Error Code: 2104. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: Market data farm connection is OK:eufarm. IB Error Code: 2104. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: HMDS data farm connection is OK:euhmds. IB Error Code: 2106. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: HMDS data farm connection is OK:ushmds.nj. IB Error Code: 2106. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: HMDS data farm connection is OK:fundfarm. IB Error Code: 2106. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2020-03-01 14:11:59.286 Message from IB: Sec-def data farm connection is OK:secdefnj. IB Error Code: 2158. Request ID: -1. | 2020-03-01 14:11:59.286 Next valid order ID: 56221 | 2020-03-01 14:11:59.286 Next valid order ID: 56221 | 2020-03-01 14:11:59.287 Mapping ZB-202003-ECBOT to ZBH20. Service code: cbot | 2020-03-01 14:11:59.288 SC Data - All Services | Starting real-time market data updates for: ZB-202003-ECBOT (ZBH20). ID: 1 Service code: cbot | 2020-03-01 14:11:59.288 SC Data - All Services | Using username 0 | 2020-03-01 14:11:59.288 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2020-03-01 14:11:59.288 SC Data - All Services | Requesting security definition data for: ZB-202003-ECBOT (ZBH20). ID: 1 | 2020-03-01 14:11:59.288 DTC Client socket (2) | Creating socket. | 2020-03-01 14:11:59.288 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2020-03-01 14:11:59.288 Added historical Intraday data request for ZB-202003-ECBOT to the queue. | 2020-03-01 14:11:59.288 Intraday data recording state for symbol ZB-202003-ECBOT is set to download 'Pending'. | 2020-03-01 14:11:59.288 Triggering next historical data download in queue. | 2020-03-01 14:11:59.288 Delaying start of download for ZB-202003-ECBOT | 2020-03-01 14:11:59.291 Mapping NQ-202003-GLOBEX to NQH20. Service code: cme | 2020-03-01 14:11:59.291 SC Data - All Services | Starting real-time market data updates for: NQ-202003-GLOBEX (NQH20). ID: 2 Service code: cme | 2020-03-01 14:11:59.291 SC Data - All Services | Requesting security definition data for: NQ-202003-GLOBEX (NQH20). ID: 2 | 2020-03-01 14:11:59.291 Added historical Intraday data request for NQ-202003-GLOBEX to the queue. | 2020-03-01 14:11:59.291 Intraday data recording state for symbol NQ-202003-GLOBEX is set to download 'Pending'. | 2020-03-01 14:11:59.291 Triggering next historical data download in queue. | 2020-03-01 14:11:59.291 Mapping ES-202003-GLOBEX to ESH20. Service code: cme | 2020-03-01 14:11:59.301 SC Data - All Services | Starting real-time market data updates for: ES-202003-GLOBEX (ESH20). ID: 3 Service code: cme | 2020-03-01 14:11:59.301 SC Data - All Services | Requesting security definition data for: ES-202003-GLOBEX (ESH20). ID: 3 | 2020-03-01 14:11:59.301 Added historical Intraday data request for ES-202003-GLOBEX to the queue. | 2020-03-01 14:11:59.302 Intraday data recording state for symbol ES-202003-GLOBEX is set to download 'Pending'. | 2020-03-01 14:11:59.302 Triggering next historical data download in queue. | 2020-03-01 14:11:59.302 SC Data - All Services | Connected to server. | 2020-03-01 14:11:59.333 SC Data - All Services | Starting socket receive thread. | 2020-03-01 14:11:59.334 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-01 14:11:59.334 Mapping ZB-202006-ECBOT to ZBM20. Service code: cbot | 2020-03-01 14:11:59.338 SC Data - All Services | Starting real-time market data updates for: ZB-202006-ECBOT (ZBM20). ID: 4 Service code: cbot | 2020-03-01 14:11:59.338 SC Data - All Services | Requesting security definition data for: ZB-202006-ECBOT (ZBM20). ID: 4 | 2020-03-01 14:11:59.338 Added historical Intraday data request for ZB-202006-ECBOT to the queue. | 2020-03-01 14:11:59.338 Intraday data recording state for symbol ZB-202006-ECBOT is set to download 'Pending'. | 2020-03-01 14:11:59.338 Triggering next historical data download in queue. | 2020-03-01 14:11:59.338 Mapping ZN-202006-ECBOT to ZNM20. Service code: cbot | 2020-03-01 14:11:59.351 SC Data - All Services | Starting real-time market data updates for: ZN-202006-ECBOT (ZNM20). ID: 5 Service code: cbot | 2020-03-01 14:11:59.351 SC Data - All Services | Requesting security definition data for: ZN-202006-ECBOT (ZNM20). ID: 5 | 2020-03-01 14:11:59.351 Added historical Intraday data request for ZN-202006-ECBOT to the queue. | 2020-03-01 14:11:59.351 Intraday data recording state for symbol ZN-202006-ECBOT is set to download 'Pending'. | 2020-03-01 14:11:59.351 Triggering next historical data download in queue. | 2020-03-01 14:11:59.351 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-01 14:11:59.401 SC Data - All Services | Sending logon request message. | 2020-03-01 14:11:59.401 SC Data - All Services | Received logon response. | 2020-03-01 14:11:59.465 SC Data - All Services | Server Name: SC Real-Time Server. | 2020-03-01 14:11:59.465 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-01 14:11:59.465 SC Data - All Services | Logon error received from server: Connection limit exceeded. | 2020-03-01 14:11:59.465 DTC Client socket (2) | CloseSocket call. | 2020-03-01 14:11:59.465 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:11:59.465 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-03-01 14:11:59.465 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:11:59.465 Mapping MES-202003-GLOBEX-USD to MESH20. Service code: cme | 2020-03-01 14:11:59.469 SC Data - All Services | Starting real-time market data updates for: MES-202003-GLOBEX-USD (MESH20). ID: 6 Service code: cme | 2020-03-01 14:11:59.469 SC Data - All Services | Requesting security definition data for: MES-202003-GLOBEX-USD (MESH20). ID: 6 | 2020-03-01 14:11:59.469 Added historical Intraday data request for MES-202003-GLOBEX-USD to the queue. | 2020-03-01 14:11:59.469 Intraday data recording state for symbol MES-202003-GLOBEX-USD is set to download 'Pending'. | 2020-03-01 14:11:59.469 Triggering next historical data download in queue. | 2020-03-01 14:11:59.469 Mapping RTY-202003-GLOBEX-USD to RTYH20. Service code: cme | 2020-03-01 14:11:59.482 SC Data - All Services | Starting real-time market data updates for: RTY-202003-GLOBEX-USD (RTYH20). ID: 7 Service code: cme | 2020-03-01 14:11:59.482 SC Data - All Services | Requesting security definition data for: RTY-202003-GLOBEX-USD (RTYH20). ID: 7 | 2020-03-01 14:11:59.482 Added historical Intraday data request for RTY-202003-GLOBEX-USD to the queue. | 2020-03-01 14:11:59.482 Intraday data recording state for symbol RTY-202003-GLOBEX-USD is set to download 'Pending'. | 2020-03-01 14:11:59.482 Triggering next historical data download in queue. | 2020-03-01 14:11:59.482 Mapping CL-202004-NYMEX to CLJ20. Service code: nymex | 2020-03-01 14:11:59.492 SC Data - All Services | Starting real-time market data updates for: CL-202004-NYMEX (CLJ20). ID: 8 Service code: nymex | 2020-03-01 14:11:59.492 SC Data - All Services | Requesting security definition data for: CL-202004-NYMEX (CLJ20). ID: 8 | 2020-03-01 14:11:59.492 Added historical Intraday data request for CL-202004-NYMEX to the queue. | 2020-03-01 14:11:59.492 Intraday data recording state for symbol CL-202004-NYMEX is set to download 'Pending'. | 2020-03-01 14:11:59.492 Triggering next historical data download in queue. | 2020-03-01 14:11:59.492 Mapping UB-202003-ECBOT-USD to UBH20. Service code: cbot | 2020-03-01 14:11:59.498 SC Data - All Services | Starting real-time market data updates for: UB-202003-ECBOT-USD (UBH20). ID: 9 Service code: cbot | 2020-03-01 14:11:59.498 SC Data - All Services | Requesting security definition data for: UB-202003-ECBOT-USD (UBH20). ID: 9 | 2020-03-01 14:11:59.498 Added historical Intraday data request for UB-202003-ECBOT-USD to the queue. | 2020-03-01 14:11:59.498 Intraday data recording state for symbol UB-202003-ECBOT-USD is set to download 'Pending'. | 2020-03-01 14:11:59.498 Triggering next historical data download in queue. | 2020-03-01 14:11:59.498 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-01 14:11:59.498 DTC Client socket (2) | Closed. | 2020-03-01 14:11:59.498 Mapping MNQ-202003-GLOBEX-USD to MNQH20. Service code: cme | 2020-03-01 14:11:59.518 SC Data - All Services | Starting real-time market data updates for: MNQ-202003-GLOBEX-USD (MNQH20). ID: 10 Service code: cme | 2020-03-01 14:11:59.518 SC Data - All Services | Requesting security definition data for: MNQ-202003-GLOBEX-USD (MNQH20). ID: 10 | 2020-03-01 14:11:59.518 Added historical Intraday data request for MNQ-202003-GLOBEX-USD to the queue. | 2020-03-01 14:11:59.518 Intraday data recording state for symbol MNQ-202003-GLOBEX-USD is set to download 'Pending'. | 2020-03-01 14:11:59.518 Triggering next historical data download in queue. | 2020-03-01 14:11:59.518 Mapping GC-202004-NYMEX to GCJ20. Service code: comex | 2020-03-01 14:11:59.530 SC Data - All Services | Starting real-time market data updates for: GC-202004-NYMEX (GCJ20). ID: 11 Service code: comex | 2020-03-01 14:11:59.530 SC Data - All Services | Requesting security definition data for: GC-202004-NYMEX (GCJ20). ID: 11 | 2020-03-01 14:11:59.530 Added historical Intraday data request for GC-202004-NYMEX to the queue. | 2020-03-01 14:11:59.530 Intraday data recording state for symbol GC-202004-NYMEX is set to download 'Pending'. | 2020-03-01 14:11:59.530 Triggering next historical data download in queue. | 2020-03-01 14:11:59.530 Mapping QM-202003-NYMEX to QMH20. Service code: nymex | 2020-03-01 14:11:59.532 SC Data - All Services | Starting real-time market data updates for: QM-202003-NYMEX (QMH20). ID: 12 Service code: nymex | 2020-03-01 14:11:59.532 SC Data - All Services | Requesting security definition data for: QM-202003-NYMEX (QMH20). ID: 12 | 2020-03-01 14:11:59.532 Added historical Intraday data request for QM-202003-NYMEX to the queue. | 2020-03-01 14:11:59.532 Intraday data recording state for symbol QM-202003-NYMEX is set to download 'Pending'. | 2020-03-01 14:11:59.532 Triggering next historical data download in queue. | 2020-03-01 14:11:59.532 Mapping YM-202003-ECBOT to YMH20. Service code: cbot | 2020-03-01 14:11:59.536 SC Data - All Services | Starting real-time market data updates for: YM-202003-ECBOT (YMH20). ID: 13 Service code: cbot | 2020-03-01 14:11:59.536 SC Data - All Services | Requesting security definition data for: YM-202003-ECBOT (YMH20). ID: 13 | 2020-03-01 14:11:59.536 Added historical Intraday data request for YM-202003-ECBOT to the queue. | 2020-03-01 14:11:59.537 Intraday data recording state for symbol YM-202003-ECBOT is set to download 'Pending'. | 2020-03-01 14:11:59.537 Triggering next historical data download in queue. | 2020-03-01 14:11:59.537 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates (6)) for account: U123* | 2020-03-01 14:12:03.975 Requesting market depth updates for: CL-202004-NYMEX if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. CL-202004-NYMEX | 2020-03-01 14:12:03.975 Requesting market depth updates for: ES-202003-GLOBEX if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. ES-202003-GLOBEX | 2020-03-01 14:12:03.975 Requesting market depth updates for: GC-202004-NYMEX if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. GC-202004-NYMEX | 2020-03-01 14:12:03.975 Requesting market depth updates for: MES-202003-GLOBEX-USD if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. MES-202003-GLOBEX-USD | 2020-03-01 14:12:03.975 Requesting market depth updates for: MNQ-202003-GLOBEX-USD if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. MNQ-202003-GLOBEX-USD | 2020-03-01 14:12:03.975 Requesting market depth updates for: NQ-202003-GLOBEX if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. NQ-202003-GLOBEX | 2020-03-01 14:12:03.975 Requesting market depth updates for: QM-202003-NYMEX if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. QM-202003-NYMEX | 2020-03-01 14:12:03.975 Requesting market depth updates for: RTY-202003-GLOBEX-USD if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. RTY-202003-GLOBEX-USD | 2020-03-01 14:12:03.975 Requesting market depth updates for: UB-202003-ECBOT-USD if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. UB-202003-ECBOT-USD | 2020-03-01 14:12:03.975 Requesting market depth updates for: YM-202003-ECBOT if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. YM-202003-ECBOT | 2020-03-01 14:12:03.975 Requesting market depth updates for: ZB-202003-ECBOT if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. ZB-202003-ECBOT | 2020-03-01 14:12:03.975 Requesting market depth updates for: ZB-202006-ECBOT if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. ZB-202006-ECBOT | 2020-03-01 14:12:03.975 Requesting market depth updates for: ZN-202006-ECBOT if supported. | 2020-03-01 14:12:03.975 Separate subscription for market depth updates not supported. ZN-202006-ECBOT | 2020-03-01 14:12:03.975 Interactive Brokers | Begin Trade Positions processing. | 2020-03-01 14:12:04.192 Interactive Brokers | Sending request for contract details for contract ID 32821998 | 2020-03-01 14:12:04.192 Interactive Brokers | Sending request for contract details for contract ID 132629528 | 2020-03-01 14:12:04.192 Interactive Brokers | Sending request for contract details for contract ID 87491440 | 2020-03-01 14:12:04.192 Interactive Brokers | Sending request for contract details for contract ID 169688387 | 2020-03-01 14:12:04.193 Interactive Brokers | Received contract details for symbol FMO-STK-SMART-USD | 2020-03-01 14:12:04.198 Interactive Brokers | Received contract details for symbol IRT-STK-SMART-USD | 2020-03-01 14:12:04.198 Interactive Brokers | Received Trade Positions download end message for account U123* | 2020-03-01 14:12:04.199 Interactive Brokers | Received Trade Positions for all accounts. Performing final processing. | 2020-03-01 14:12:04.199 Interactive Brokers | Received contract details for symbol MITT-STK-SMART-USD | 2020-03-01 14:12:04.199 Interactive Brokers | Received contract details for symbol NRZ-STK-SMART-USD | 2020-03-01 14:12:04.200 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2020-03-01 14:12:04.200 SC Data - All Services | Using username 0 | 2020-03-01 14:12:04.458 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2020-03-01 14:12:04.458 DTC Client socket (2) | Creating socket. | 2020-03-01 14:12:04.458 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2020-03-01 14:12:04.458 SC Data - All Services | Connected to server. | 2020-03-01 14:12:04.503 SC Data - All Services | Starting socket receive thread. | 2020-03-01 14:12:04.503 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-01 14:12:04.503 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-01 14:12:04.555 SC Data - All Services | Sending logon request message. | 2020-03-01 14:12:04.555 SC Data - All Services | Received logon response. | 2020-03-01 14:12:04.619 SC Data - All Services | Server Name: SC Real-Time Server. | 2020-03-01 14:12:04.620 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-01 14:12:04.620 SC Data - All Services | Logon error received from server: Connection limit exceeded. | 2020-03-01 14:12:04.620 DTC Client socket (2) | CloseSocket call. | 2020-03-01 14:12:04.620 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:12:04.620 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-03-01 14:12:04.620 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:04.620 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-01 14:12:04.652 DTC Client socket (2) | Closed. | 2020-03-01 14:12:04.652 SC Data - All Services | Using username 0 | 2020-03-01 14:12:09.621 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2020-03-01 14:12:09.621 DTC Client socket (2) | Creating socket. | 2020-03-01 14:12:09.622 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2020-03-01 14:12:09.622 SC Data - All Services | Connected to server. | 2020-03-01 14:12:09.661 SC Data - All Services | Starting socket receive thread. | 2020-03-01 14:12:09.661 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-01 14:12:09.661 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-01 14:12:09.726 SC Data - All Services | Sending logon request message. | 2020-03-01 14:12:09.726 SC Data - All Services | Received logon response. | 2020-03-01 14:12:09.789 SC Data - All Services | Server Name: SC Real-Time Server. | 2020-03-01 14:12:09.789 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-01 14:12:09.789 SC Data - All Services | Logon error received from server: Connection limit exceeded. | 2020-03-01 14:12:09.789 DTC Client socket (2) | CloseSocket call. | 2020-03-01 14:12:09.790 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:12:09.790 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-03-01 14:12:09.790 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:09.790 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-01 14:12:09.825 DTC Client socket (2) | Closed. | 2020-03-01 14:12:09.825 Interactive Brokers | All contract details received for symbols used for trading. Re-requesting trading data. | 2020-03-01 14:12:14.194 Interactive Brokers | Stopping automatic Trade Position updates for account: U123* | 2020-03-01 14:12:14.194 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates (6)) for account: U123* | 2020-03-01 14:12:14.194 Message from IB: API client has been unsubscribed from account data. IB Error Code: 2100. Request ID: -1. | 2020-03-01 14:12:14.195 Interactive Brokers | Begin Trade Positions processing. | 2020-03-01 14:12:14.466 Interactive Brokers | Received Trade Positions download end message for account U123* | 2020-03-01 14:12:14.471 Interactive Brokers | Received Trade Positions for all accounts. Performing final processing. | 2020-03-01 14:12:14.471 SC Data - All Services | Using username 0 | 2020-03-01 14:12:14.788 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2020-03-01 14:12:14.788 DTC Client socket (2) | Creating socket. | 2020-03-01 14:12:14.788 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2020-03-01 14:12:14.788 SC Data - All Services | Connected to server. | 2020-03-01 14:12:14.827 SC Data - All Services | Starting socket receive thread. | 2020-03-01 14:12:14.827 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-01 14:12:14.827 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-01 14:12:14.880 SC Data - All Services | Sending logon request message. | 2020-03-01 14:12:14.880 SC Data - All Services | Received logon response. | 2020-03-01 14:12:14.957 SC Data - All Services | Server Name: SC Real-Time Server. | 2020-03-01 14:12:14.957 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-01 14:12:14.957 SC Data - All Services | Logon error received from server: Connection limit exceeded. | 2020-03-01 14:12:14.957 DTC Client socket (2) | CloseSocket call. | 2020-03-01 14:12:14.958 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:12:14.958 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-03-01 14:12:14.958 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:14.958 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-01 14:12:14.993 DTC Client socket (2) | Closed. | 2020-03-01 14:12:14.993 SC Data - All Services | Using username 0 | 2020-03-01 14:12:19.965 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2020-03-01 14:12:19.965 DTC Client socket (2) | Creating socket. | 2020-03-01 14:12:19.966 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2020-03-01 14:12:19.966 SC Data - All Services | Connected to server. | 2020-03-01 14:12:20.005 SC Data - All Services | Starting socket receive thread. | 2020-03-01 14:12:20.005 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-01 14:12:20.005 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-01 14:12:20.049 SC Data - All Services | Sending logon request message. | 2020-03-01 14:12:20.049 SC Data - All Services | Received logon response. | 2020-03-01 14:12:20.112 SC Data - All Services | Server Name: SC Real-Time Server. | 2020-03-01 14:12:20.112 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-01 14:12:20.112 SC Data - All Services | Logon error received from server: Connection limit exceeded. | 2020-03-01 14:12:20.112 DTC Client socket (2) | CloseSocket call. | 2020-03-01 14:12:20.112 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:12:20.112 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-03-01 14:12:20.112 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:20.112 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-01 14:12:20.147 DTC Client socket (2) | Closed. | 2020-03-01 14:12:20.147 SC Data - All Services | Using username 0 | 2020-03-01 14:12:25.113 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2020-03-01 14:12:25.113 DTC Client socket (2) | Creating socket. | 2020-03-01 14:12:25.114 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2020-03-01 14:12:25.114 SC Data - All Services | Connected to server. | 2020-03-01 14:12:25.154 SC Data - All Services | Starting socket receive thread. | 2020-03-01 14:12:25.154 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-01 14:12:25.154 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-01 14:12:25.206 SC Data - All Services | Sending logon request message. | 2020-03-01 14:12:25.206 SC Data - All Services | Received logon response. | 2020-03-01 14:12:25.287 SC Data - All Services | Server Name: SC Real-Time Server. | 2020-03-01 14:12:25.287 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-01 14:12:25.287 SC Data - All Services | Logon error received from server: Connection limit exceeded. | 2020-03-01 14:12:25.287 DTC Client socket (2) | CloseSocket call. | 2020-03-01 14:12:25.287 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:12:25.288 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-03-01 14:12:25.288 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:25.288 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-01 14:12:25.323 DTC Client socket (2) | Closed. | 2020-03-01 14:12:25.323 SC Data - All Services | Using username 0 | 2020-03-01 14:12:30.292 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2020-03-01 14:12:30.292 DTC Client socket (2) | Creating socket. | 2020-03-01 14:12:30.293 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2020-03-01 14:12:30.293 SC Data - All Services | Connected to server. | 2020-03-01 14:12:30.331 SC Data - All Services | Starting socket receive thread. | 2020-03-01 14:12:30.331 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-01 14:12:30.331 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-01 14:12:30.369 SC Data - All Services | Sending logon request message. | 2020-03-01 14:12:30.369 SC Data - All Services | Received logon response. | 2020-03-01 14:12:30.417 SC Data - All Services | Server Name: SC Real-Time Server. | 2020-03-01 14:12:30.417 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-01 14:12:30.417 SC Data - All Services | Logon error received from server: Connection limit exceeded. | 2020-03-01 14:12:30.417 DTC Client socket (2) | CloseSocket call. | 2020-03-01 14:12:30.417 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:12:30.417 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-03-01 14:12:30.417 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:30.417 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-01 14:12:30.456 DTC Client socket (2) | Closed. | 2020-03-01 14:12:30.456 SC Data - All Services | Using username 0 | 2020-03-01 14:12:35.425 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 443 | 2020-03-01 14:12:35.425 DTC Client socket (2) | Creating socket. | 2020-03-01 14:12:35.425 DTC Client socket (2) | Connecting to IP: 8.18.161.133. | 2020-03-01 14:12:35.425 SC Data - All Services | Connected to server. | 2020-03-01 14:12:35.465 SC Data - All Services | Starting socket receive thread. | 2020-03-01 14:12:35.465 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-01 14:12:35.465 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-01 14:12:35.518 SC Data - All Services | Sending logon request message. | 2020-03-01 14:12:35.518 SC Data - All Services | Received logon response. | 2020-03-01 14:12:35.594 SC Data - All Services | Server Name: SC Real-Time Server. | 2020-03-01 14:12:35.594 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-01 14:12:35.594 SC Data - All Services | Logon error received from server: Connection limit exceeded. | 2020-03-01 14:12:35.594 DTC Client socket (2) | CloseSocket call. | 2020-03-01 14:12:35.595 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:12:35.595 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-03-01 14:12:35.595 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:35.595 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-01 14:12:35.631 DTC Client socket (2) | Closed. | 2020-03-01 14:12:35.631 SC Data - All Services | Using username 0 | 2020-03-01 14:12:40.608 SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2020-03-01 14:12:40.608 DTC Client socket (2) | Creating socket. | 2020-03-01 14:12:40.608 DTC Client socket (2) | Connecting to IP: 8.18.161.135. | 2020-03-01 14:12:40.608 SC Data - All Services | Connected to server. | 2020-03-01 14:12:40.647 SC Data - All Services | Starting socket receive thread. | 2020-03-01 14:12:40.647 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-03-01 14:12:40.647 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-03-01 14:12:40.710 SC Data - All Services | Sending logon request message. | 2020-03-01 14:12:40.710 SC Data - All Services | Received logon response. | 2020-03-01 14:12:40.773 SC Data - All Services | Server Name: SC Real-Time Server. | 2020-03-01 14:12:40.773 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-03-01 14:12:40.773 SC Data - All Services | Logon error received from server: Connection limit exceeded. | 2020-03-01 14:12:40.773 DTC Client socket (2) | CloseSocket call. | 2020-03-01 14:12:40.773 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:12:40.773 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-03-01 14:12:40.774 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:40.774 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-03-01 14:12:40.808 DTC Client socket (2) | Closed. | 2020-03-01 14:12:40.808 File >> Disconnect selected. | 2020-03-01 14:12:41.990 Canceling historical data download request for NQ-202003-GLOBEX Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 37. | 2020-03-01 14:12:41.990 Canceling historical data download request for ES-202003-GLOBEX Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 38. | 2020-03-01 14:12:41.990 Canceling historical data download request for ZB-202006-ECBOT Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 39. | 2020-03-01 14:12:41.990 Canceling historical data download request for ZN-202006-ECBOT Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 40. | 2020-03-01 14:12:41.990 Canceling historical data download request for MES-202003-GLOBEX-USD Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 41. | 2020-03-01 14:12:41.990 Canceling historical data download request for RTY-202003-GLOBEX-USD Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 42. | 2020-03-01 14:12:41.990 Canceling historical data download request for CL-202004-NYMEX Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 43. | 2020-03-01 14:12:41.990 Canceling historical data download request for UB-202003-ECBOT-USD Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 44. | 2020-03-01 14:12:41.990 Canceling historical data download request for MNQ-202003-GLOBEX-USD Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 45. | 2020-03-01 14:12:41.990 Canceling historical data download request for GC-202004-NYMEX Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 46. | 2020-03-01 14:12:41.990 Canceling historical data download request for QM-202003-NYMEX Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 47. | 2020-03-01 14:12:41.990 Canceling historical data download request for YM-202003-ECBOT Intraday data. | 2020-03-01 14:12:41.990 Removing historical data download ID 48. | 2020-03-01 14:12:41.990 IB TWS socket (1) | CloseSocket call. | 2020-03-01 14:12:42.243 DTC Client socket (0) | CloseSocket call. | 2020-03-01 14:12:42.243 SC Data - All Services | Disconnected from the server. | 2020-03-01 14:12:42.243 Interactive Brokers | Disconnected. | 2020-03-01 14:12:42.243 IB TWS socket (1) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:42.243 IB TWS socket (1) | Socket gracefully closed by remote side. | 2020-03-01 14:12:42.243 IB TWS socket (1) | Closed. | 2020-03-01 14:12:42.243 HD Request # 36 | Downloading Intraday chart data for ZB-202003-ECBOT to the file ZB-202003-ECBOT.scid. Service: cbot | 2020-03-01 14:12:42.492 HD Request # 36 | Download start date-time: 2020-02-28 15:59:25.000 | 2020-03-01 14:12:42.493 HD Request # 36 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2020-03-01 14:12:42.493 Socket (1) | Creating socket. | 2020-03-01 14:12:42.493 Socket (1) | Connecting to IP: 8.18.161.135. | 2020-03-01 14:12:42.493 HD Request # 36 | Setting DTC encoding to Binary VLS | 2020-03-01 14:12:42.576 HD Request # 36 | Sending historical data logon request message. | 2020-03-01 14:12:42.576 HD Request # 36 | Requesting Intraday data. Start date-time: 2020-02-28 15:59:25. Record interval: 0. Symbol: ZBH20 | 2020-03-01 14:12:42.616 HD Request # 36 | Decompressing data. | 2020-03-01 14:12:42.654 HD Request # 36 | Receiving Intraday data for ZB-202003-ECBOT starting at 2020-02-28 15:59:25 | 2020-03-01 14:12:42.654 Socket (1) | CloseSocket call. | 2020-03-01 14:12:42.654 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-03-01 14:12:42.654 HD Request # 36 | Historical data for ZB-202003-ECBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-03-01 14:12:42.654 Historical data download thread signaled to stop. | 2020-03-01 14:12:42.654 HD Request # 36 | Received 2 records from 2020-02-28 15:59:25.000 to 2020-02-28 15:59:25.001 (0.0 seconds) and wrote 0 records for ZB-202003-ECBOT | 2020-03-01 14:12:42.655 HD Request # 36 | Completion time: 0s | 2020-03-01 14:12:42.655 HD Request # 36 | Intraday data download complete for ZB-202003-ECBOT. Unique request ID: 36 | 2020-03-01 14:12:42.655 Removing historical data download ID 36. | 2020-03-01 14:12:42.655 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2020-03-01 14:12:42.655 Triggering next historical data download in queue. | 2020-03-01 14:12:42.655 Socket (1) | Socket gracefully closed by remote side. | 2020-03-01 14:12:42.692 Socket (1) | Closed. | 2020-03-01 14:12:42.692 Chart #1 has tagged chart #10 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #11 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #12 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #2 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #3 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #4 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #5 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #6 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #7 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #8 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 Chart #1 has tagged chart #9 for full recalculation. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 ZB-202003-ECBOT[M] #6 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.707 ZB-202003-ECBOT [CBV][M] 5 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.708 ZB-202003-ECBOT [CBV][M] 1 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.723 ZB-202003-ECBOT [CBV][M] Weekly #11 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.786 ZB-202003-ECBOT [CBV][M] Flex Renko 3-2-1 #12 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.788 ZB-202003-ECBOT [CBV][M] #2 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.835 ZB-202003-ECBOT [CBV][M] #8 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.841 ZB-202003-ECBOT [CBV][M] 600 Volume #10 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.850 ZB-202003-ECBOT [CBV][M] 60 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.899 ZB-202003-ECBOT [CBV][M] Daily #7 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.901 ZB-202003-ECBOT [CBV][M] Flex Renko 3-2-1 #9 | Performing a full recalculation because it has been tagged. Chartbook: ZB Pax v2 charts.Cht | 2020-03-01 14:12:42.908 |
[2020-03-01 21:17:07] |
So I'm having connectivity issues again for the second data feed. Both instances of SC are v2057 64 bit. I posted the message log above. Suggestions? |
[2020-03-01 21:59:18] |
Regarding this, refer to: Notice: Sierra Chart/Barchart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
