Date/Time: Mon, 05 Oct 2026 02:07:29 +0000
TRANSACT client using denali data
View Count: 1095
| [2019-09-01 21:53:13] |
| User82032 - Posts: 35 |
When I log on to my Transact account once per month to keep from paying duplicate exchange fees I am still getting connection error with the Transact websocket. I am using Sierra Chart package 5 (version 1983) directly from Sierra. Do I have to download a earlier version such as 1941 to make this connection with Transact. Thanks |
| [2019-09-02 00:24:29] |
Transact did say they did properly authorize your account to connect. We will get this sorted for you. Can you please follow the instructions below when you try to connect to Transact: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed with File >> Connect to Data Feed. After about 15 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-09-02 01:04:54] |
For some reason I am not getting any real time data now even though the tab on top is green suggesting I am connected.
| [2019-09-02 01:42:06] |
I sent a message log as requested by using the send for analysis button. Also, I am not getting any live data from the denali feed even though my connection tab is green |
| [2019-09-02 04:54:52] |
Yes you will not receive the real time CME data due to CME requirements until you confirm you have an authorized trading account through a technical method. This is why you need to connect to your trading account once a month. It is not to remove duplicate exchange fees. It is to authorize CME data. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Here are the specific instructions: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees And here are the instructions you need to follow to connect to Transact: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions You just need to follow through these Transact instructions now, and if you have trouble connecting, provide the message log. Also the log you submitted does not show any connection attempt to Transact. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-02 04:55:27
| [2019-09-02 05:34:33] |
Socket (2) | Creating socket. | 2019-09-01 23:24:52.655 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-09-01 23:59:49.596 Auth Websocket | Connecting to WebSocket server. | 2019-09-01 23:59:49.596 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-01 23:59:49.596 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-09-01 23:59:49.596 Auth Websocket | Opening WebSocket. | 2019-09-01 23:59:49.611 Auth Websocket | Sending WebSocket handshake. | 2019-09-01 23:59:49.611 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-09-01 23:59:49.752 Auth Websocket | Server header | Upgrade: WebSocket | 2019-09-01 23:59:49.752 Auth Websocket | Server header | Connection: Upgrade | 2019-09-01 23:59:49.752 Auth Websocket | Server header | Sec-WebSocket-Accept: gviHqtutTr1O2uqL+k3m+4FpBvc= | 2019-09-01 23:59:49.752 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-09-01 23:59:49.752 Auth Websocket | Server header | | 2019-09-01 23:59:49.752 Auth Websocket | Web socket state is now open. | 2019-09-01 23:59:49.752 TransAct WS | Sending account logon message. Live | 2019-09-01 23:59:49.752 TransAct WS | Account logon error: -1(-1) | 2019-09-01 23:59:49.814 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-01 23:59:49.814 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-01 23:59:49.814 Auth Websocket | WebSocket closed. | 2019-09-01 23:59:50.110 TransAct WS | Disconnected. | 2019-09-01 23:59:50.110 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-01 23:59:50.110 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-09-01 23:59:50.110 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-09-01 23:59:50.142 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-01 23:59:50.142 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-09-01 23:59:50.157 Auth Websocket socket (1) | Closed. | 2019-09-01 23:59:50.157 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-09-01 23:59:53.839 Auth Websocket | Connecting to WebSocket server. | 2019-09-01 23:59:53.839 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-01 23:59:53.839 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-09-01 23:59:53.839 Auth Websocket | Opening WebSocket. | 2019-09-01 23:59:53.854 Auth Websocket | Sending WebSocket handshake. | 2019-09-01 23:59:53.854 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-09-01 23:59:53.995 Auth Websocket | Server header | Upgrade: WebSocket | 2019-09-01 23:59:53.995 Auth Websocket | Server header | Connection: Upgrade | 2019-09-01 23:59:53.995 Auth Websocket | Server header | Sec-WebSocket-Accept: p4KJVevNlSRZ/PWfXIgkvNB8bk0= | 2019-09-01 23:59:53.995 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-09-01 23:59:53.995 Auth Websocket | Server header | | 2019-09-01 23:59:53.995 Auth Websocket | Web socket state is now open. | 2019-09-01 23:59:53.995 TransAct WS | Sending account logon message. Live | 2019-09-01 23:59:53.995 TransAct WS | Account logon error: -1(-1) | 2019-09-01 23:59:54.057 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-01 23:59:54.057 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-01 23:59:54.057 Auth Websocket | WebSocket closed. | 2019-09-01 23:59:54.541 TransAct WS | Disconnected. | 2019-09-01 23:59:54.541 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-01 23:59:54.541 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-09-01 23:59:54.541 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-09-01 23:59:54.572 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-01 23:59:54.572 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-09-01 23:59:54.588 Auth Websocket socket (1) | Closed. | 2019-09-01 23:59:54.588 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-09-01 23:59:57.552 Auth Websocket | Connecting to WebSocket server. | 2019-09-01 23:59:57.552 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-01 23:59:57.552 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-09-01 23:59:57.552 Auth Websocket | Opening WebSocket. | 2019-09-01 23:59:57.583 Auth Websocket | Sending WebSocket handshake. | 2019-09-01 23:59:57.583 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-09-01 23:59:57.723 Auth Websocket | Server header | Upgrade: WebSocket | 2019-09-01 23:59:57.723 Auth Websocket | Server header | Connection: Upgrade | 2019-09-01 23:59:57.723 Auth Websocket | Server header | Sec-WebSocket-Accept: YLZ5pn+Wz8DzJtz9DfwW13HSFXo= | 2019-09-01 23:59:57.723 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-09-01 23:59:57.723 Auth Websocket | Server header | | 2019-09-01 23:59:57.723 Auth Websocket | Web socket state is now open. | 2019-09-01 23:59:57.723 TransAct WS | Sending account logon message. Live | 2019-09-01 23:59:57.723 TransAct WS | Account logon error: -1(-1) | 2019-09-01 23:59:58.004 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-01 23:59:58.004 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-01 23:59:58.004 Auth Websocket | WebSocket closed. | 2019-09-01 23:59:58.066 TransAct WS | Disconnected. | 2019-09-01 23:59:58.066 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-09-01 23:59:58.066 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-01 23:59:58.066 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-09-01 23:59:58.082 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-01 23:59:58.082 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-09-01 23:59:58.113 Auth Websocket socket (1) | Closed. | 2019-09-01 23:59:58.113 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-09-02 00:00:01.218 Auth Websocket | Connecting to WebSocket server. | 2019-09-02 00:00:01.218 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-02 00:00:01.218 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-09-02 00:00:01.218 Auth Websocket | Opening WebSocket. | 2019-09-02 00:00:01.249 Auth Websocket | Sending WebSocket handshake. | 2019-09-02 00:00:01.249 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-09-02 00:00:01.342 Auth Websocket | Server header | Upgrade: WebSocket | 2019-09-02 00:00:01.342 Auth Websocket | Server header | Connection: Upgrade | 2019-09-02 00:00:01.342 Auth Websocket | Server header | Sec-WebSocket-Accept: ZNNiIWSqWpgwLD8GMywDOM8LtR4= | 2019-09-02 00:00:01.342 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-09-02 00:00:01.342 Auth Websocket | Server header | | 2019-09-02 00:00:01.342 Auth Websocket | Web socket state is now open. | 2019-09-02 00:00:01.342 TransAct WS | Sending account logon message. Live | 2019-09-02 00:00:01.342 TransAct WS | Account logon error: -1(-1) | 2019-09-02 00:00:01.405 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-02 00:00:01.405 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:01.405 Auth Websocket | WebSocket closed. | 2019-09-02 00:00:01.764 TransAct WS | Disconnected. | 2019-09-02 00:00:01.764 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-09-02 00:00:01.764 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:01.764 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-09-02 00:00:01.795 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-02 00:00:01.795 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-09-02 00:00:01.826 Auth Websocket socket (1) | Closed. | 2019-09-02 00:00:01.826 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-09-02 00:00:05.445 Auth Websocket | Connecting to WebSocket server. | 2019-09-02 00:00:05.445 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-02 00:00:05.445 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-09-02 00:00:05.445 Auth Websocket | Opening WebSocket. | 2019-09-02 00:00:05.476 Auth Websocket | Sending WebSocket handshake. | 2019-09-02 00:00:05.476 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-09-02 00:00:05.601 Auth Websocket | Server header | Upgrade: WebSocket | 2019-09-02 00:00:05.601 Auth Websocket | Server header | Connection: Upgrade | 2019-09-02 00:00:05.601 Auth Websocket | Server header | Sec-WebSocket-Accept: T/aO++TXc9EjG9EpNL/9fRlfWFw= | 2019-09-02 00:00:05.601 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-09-02 00:00:05.601 Auth Websocket | Server header | | 2019-09-02 00:00:05.601 Auth Websocket | Web socket state is now open. | 2019-09-02 00:00:05.601 TransAct WS | Sending account logon message. Live | 2019-09-02 00:00:05.601 TransAct WS | Account logon error: -1(-1) | 2019-09-02 00:00:05.679 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-02 00:00:05.679 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:05.679 Auth Websocket | WebSocket closed. | 2019-09-02 00:00:06.194 TransAct WS | Disconnected. | 2019-09-02 00:00:06.194 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-09-02 00:00:06.194 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:06.194 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-09-02 00:00:06.225 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-02 00:00:06.225 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-09-02 00:00:06.256 Auth Websocket socket (1) | Closed. | 2019-09-02 00:00:06.256 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-09-02 00:00:09.236 Auth Websocket | Connecting to WebSocket server. | 2019-09-02 00:00:09.236 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-02 00:00:09.236 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-09-02 00:00:09.236 Auth Websocket | Opening WebSocket. | 2019-09-02 00:00:09.283 Auth Websocket | Sending WebSocket handshake. | 2019-09-02 00:00:09.283 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-09-02 00:00:09.470 Auth Websocket | Server header | Upgrade: WebSocket | 2019-09-02 00:00:09.470 Auth Websocket | Server header | Connection: Upgrade | 2019-09-02 00:00:09.470 Auth Websocket | Server header | Sec-WebSocket-Accept: s2A+7kMEA2nH0SnD1v6fes2t6js= | 2019-09-02 00:00:09.470 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-09-02 00:00:09.470 Auth Websocket | Server header | | 2019-09-02 00:00:09.470 Auth Websocket | Web socket state is now open. | 2019-09-02 00:00:09.470 TransAct WS | Sending account logon message. Live | 2019-09-02 00:00:09.470 TransAct WS | Account logon error: -1(-1) | 2019-09-02 00:00:09.517 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-02 00:00:09.517 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:09.517 Auth Websocket | WebSocket closed. | 2019-09-02 00:00:10.125 TransAct WS | Disconnected. | 2019-09-02 00:00:10.125 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:10.125 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-09-02 00:00:10.125 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-09-02 00:00:10.156 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-02 00:00:10.156 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-09-02 00:00:10.188 Auth Websocket socket (1) | Closed. | 2019-09-02 00:00:10.188 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-09-02 00:00:13.136 Auth Websocket | Connecting to WebSocket server. | 2019-09-02 00:00:13.136 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-02 00:00:13.136 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-09-02 00:00:13.136 Auth Websocket | Opening WebSocket. | 2019-09-02 00:00:13.152 Auth Websocket | Sending WebSocket handshake. | 2019-09-02 00:00:13.152 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-09-02 00:00:13.245 Auth Websocket | Server header | Upgrade: WebSocket | 2019-09-02 00:00:13.245 Auth Websocket | Server header | Connection: Upgrade | 2019-09-02 00:00:13.245 Auth Websocket | Server header | Sec-WebSocket-Accept: R+nzHSZT5G0UXLdD8a/hdNMkId8= | 2019-09-02 00:00:13.245 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-09-02 00:00:13.245 Auth Websocket | Server header | | 2019-09-02 00:00:13.245 Auth Websocket | Web socket state is now open. | 2019-09-02 00:00:13.245 TransAct WS | Sending account logon message. Live | 2019-09-02 00:00:13.245 TransAct WS | Account logon error: -1(-1) | 2019-09-02 00:00:13.276 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-02 00:00:13.276 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:13.276 Auth Websocket | WebSocket closed. | 2019-09-02 00:00:13.666 TransAct WS | Disconnected. | 2019-09-02 00:00:13.666 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:13.666 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-09-02 00:00:13.666 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-09-02 00:00:13.682 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-02 00:00:13.682 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-09-02 00:00:13.713 Auth Websocket socket (1) | Closed. | 2019-09-02 00:00:13.713 TransAct WS | Connecting to Authorization server 208.97.219.30:1869 | 2019-09-02 00:00:16.677 Auth Websocket | Connecting to WebSocket server. | 2019-09-02 00:00:16.677 Auth Websocket socket (1) | Creating socket. Using TLS 1.2. | 2019-09-02 00:00:16.677 Auth Websocket socket (1) | Connecting to IP: 208.97.219.30. | 2019-09-02 00:00:16.677 Auth Websocket | Opening WebSocket. | 2019-09-02 00:00:16.693 Auth Websocket | Sending WebSocket handshake. | 2019-09-02 00:00:16.693 Auth Websocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-09-02 00:00:16.786 Auth Websocket | Server header | Upgrade: WebSocket | 2019-09-02 00:00:16.786 Auth Websocket | Server header | Connection: Upgrade | 2019-09-02 00:00:16.786 Auth Websocket | Server header | Sec-WebSocket-Accept: g11hAWRIhfAUV2xUZ0IbBx/T3XA= | 2019-09-02 00:00:16.786 Auth Websocket | Server header | Sec-WebSocket-Protocol: authenticateapi | 2019-09-02 00:00:16.786 Auth Websocket | Server header | | 2019-09-02 00:00:16.786 Auth Websocket | Web socket state is now open. | 2019-09-02 00:00:16.786 TransAct WS | Sending account logon message. Live | 2019-09-02 00:00:16.786 TransAct WS | Account logon error: -1(-1) | 2019-09-02 00:00:16.833 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-02 00:00:16.833 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:16.833 Auth Websocket | WebSocket closed. | 2019-09-02 00:00:17.176 TransAct WS | Disconnected. | 2019-09-02 00:00:17.176 Auth Websocket socket (1) | Write in progress. Shutdown being delayed. | 2019-09-02 00:00:17.176 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-02 00:00:17.176 Auth Websocket socket (1) | Write has completed. Shutdown being performed. | 2019-09-02 00:00:17.208 Auth Websocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-02 00:00:17.208 Auth Websocket socket (1) | Socket gracefully closed by remote side. | 2019-09-02 00:00:17.239 Auth Websocket socket (1) | Closed. | 2019-09-02 00:00:17.239 File >> Disconnect selected. | 2019-09-02 00:00:17.566 TransAct WS | Disconnected. | 2019-09-02 00:00:17.566 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 8. | 2019-09-02 00:25:14.083 Current selected Data/Trading service: SC Data - All Services | 2019-09-02 00:25:14.083 |
| [2019-09-02 06:35:00] |
We will contact Transact about this. We have temporarily authorized your Sierra Chart account to receive the CME data for the next week. You can set the Service back to SC Data-All Services.
| [2019-09-02 07:13:26] |
During my conversations with Transact tonight I was informed by them that Sierra chart had me authorized for package 3 and not package 5. I informed them I was paying for my charting and data directly from Sierra. They told me it did not matter and that sierra only authorized me for package 3. He said he would opt me in to package 5. Why do they having to authorize my use of sierra charts if I pay directly to sierra. Anyhow he sent me a end user agreement saying the fee is 29.95 per month plus a risk liquidation fee. What is all this? It appears like Transact will be deducting these fees from my account. Am I right to question this stuff? I do not to be billed by both Transact and Sierra for charting and exchange fees.
| [2019-09-02 11:17:21] |
We will send an email to Transact now to get this all straightened out for you. You do not have to pay Transact anything.
