Date/Time: Sun, 19 Jan 2025 21:49:02 +0000
Why does the VxP chart show the same bid size X ask size for a few price levels in a row
View Count: 1414
[2018-05-08 01:11:16] |
User432504 - Posts: 73 |
SC and anyone else who may know: Why does the VxP chart show the same Bid Size x Ask Size for a few price levels in a row, from time to time? I have seen this for many different symbols and intermittently though out a trading day. For example: 2 x 15 2 x 15 2 x 15 2 x 15 2 x 15 2 x 15 2 x 15 I have attached a copy of the SC that I am speaking about below. http://www.sierrachart.com/image.php?Image=1525741351811.png Thanks in advance. Sierra Charts are really nice. |
[2018-05-08 03:20:46] |
We will prepare some documentation for this, but you need to set Sierra Chart for a tick by tick data configuration. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-08 13:22:50] |
I have done the steps listed in your post above...ie. make sure to set the Intraday Data Storage Time Unit to 1 Tick and allow the support for SC data feed. Those were set already and I still get the results listed above in my original question. I am using Rithmic to feed SC, so that should be tick by tick data. Let me know what your new documentation steps will be to correct this. Date Time Of Last Edit: 2018-05-08 13:28:20
[2018-05-08 18:24:51] |
I am using Rithmic to feed SC, so that should be tick by tick data. http://www.sierrachart.com/index.php?page=doc/Rithmic.php#Included To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-09 01:35:36] |
I thought Rithmic sent tick for tick data? What does this mean..... Streaming Real-Time Data: Yes. Does that mean that streaming real time data is tick for tick; and, only the historical data is on a 1 second basis for service package 3? The below is from your website.... Standard Sierra Chart (Service Package 3) Price: 24 USD/month The Standard Service Package includes all functionality of the software except what is listed in the Sierra Chart with Advanced Features section. It includes the Included Data Services listed below and support for External Services. Sierra Chart with Advanced Features (Service Package 5) Price: 33 USD/month Sierra Chart with Advanced Features includes all of the Standard Service Package features and these additional advanced features: TPO Chart Study Numbers Bars Numbers Bars Calculated Values Market Depth Historical Graph Volume Profile Interactive Drawing Tool Increased number of historical data queries with the Sierra Chart Historical Data Service. From your webpage --- Description of Service Packages and Pricing: Packages It sounds like package 3 has everything except what you list in package 5 and package 5 makes no mention of tick for tick not being included in package 3? Please explain? Also, i just now loaded up SC on a second computer that was getting the quotes in real time but pulling it from historical data and sure enough the data shows completely different sizes on the VxP chart at the same time and the same price. Is this because I need to have the service package 5 to get real time tick for tick historical data when i load up a chart that hasn't been streaming already and building slowly but instead pulling data from the historical database? Let me know if I am understanding correctly. I have no need for TPO or Number Bars charts. Also, let me guess....if i sign up now for Service Package 5, i will need to edit the prior charts since they don't seem to be on a tick by tick basis? Is that correct also? I just updated to service package 5 and I received the following message.... -Notice: Your Services Balance of 0.00 USD is too low to renew the Services activated on your account when they expire. You need a balance of at least 33 USD. You can activate and deactivate the Service Package on your account. (Current Usage Time Ending Date: 2018-05-25). You will need to make a payment of 33 USD. - If your custom studies are no longer displaying and you are using the 64-bit version, then refer to Custom Studies Not Displaying on Chart. ========================================================= You posted the following.... There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. So why did i get the message about needing to make a payment of 33 USD? Date Time Of Last Edit: 2018-05-09 02:45:03
[2018-05-21 21:01:02] |
Does that mean that streaming real time data is tick for tick; and, only the historical data is on a 1 second basis for service package 3? Is this because I need to have the service package 5 to get real time tick for tick historical data when i load up a chart that hasn't been streaming already and building slowly but instead pulling data from the historical database? Yes. And make sure you re-download the data in the Intraday chart after changing to service package 5:"Edit >> Delete All Data and Download". This only needs to be done once for each symbol. So why did i get the message about needing to make a payment of 33 USD? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-21 21:01:48
