Date/Time: Thu, 16 Jan 2025 04:40:29 +0000
Data not showing up on charts
View Count: 1499
[2017-10-12 13:16:17] |
nickdubs1 - Posts: 9 |
Good morning, the issue I'm experiencing is that when I load my chartbook one with my studies applied to it, the real time data is not showing up on the charts and its because its saying the "historical download failed". I just recently purchased a one month membership for 24 usd so id like to get this resolved quickly. thank you! account name is **.
Date Time Of Last Edit: 2017-10-12 21:17:06
[2017-10-12 16:28:42] |
What is the symbol of that chart? Go to that chart and select Edit >>Delete All Data and Download. After about a minute, then provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-10-12 16:28:59
[2017-10-12 19:06:38] |
Reading Internal Order ID file. | 2017-10-12 15:03:51 Reading Trade Orders file. | 2017-10-12 15:03:51 Reading Trade Positions file. | 2017-10-12 15:03:51 Listening on UDP port 22903. | 2017-10-12 15:03:51 Software version: 1621 | 2017-10-12 15:03:51 Usage end date: 2017-11-23 | 2017-10-12 15:03:51 Enabled for: Advanced Features. | 2017-10-12 15:03:51 Enabled for: Sierra Chart Historical Data Service. | 2017-10-12 15:03:51 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-10-12 15:03:51 Current selected Data/Trading service: SC Data - All Services | 2017-10-12 15:03:51 Chart Update Interval: 500 | 2017-10-12 15:03:51 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-10-12 15:03:51 2017-10-12 15:03:54 Local computer time | 2017-10-12 15:03:51 2017-10-12 19:03:54 Local computer time in UTC | 2017-10-12 15:03:51 2017-10-12 15:03:54 Local computer time in SC Time Zone | 2017-10-12 15:03:51 2017-10-12 19:03:54 Server time in UTC | 2017-10-12 15:03:51 Local computer UTC time and Server UTC time difference: 0 seconds. | 2017-10-12 15:03:51 Program path: C:\SierraChart\ | 2017-10-12 15:03:51 Data Files path: C:\SierraChart\Data\ | 2017-10-12 15:03:51 OS Version Number: 10.0 | 2017-10-12 15:03:51 Locale Setting: C | 2017-10-12 15:03:51 Created the DTC Protocol server. | 2017-10-12 15:03:51 DTC Protocol Server listening on port 11099. | 2017-10-12 15:03:51 Created the DTC Protocol historical data server. | 2017-10-12 15:03:51 HD Server Manager | Listening on port 11098 | 2017-10-12 15:03:51 Checking for new symbol settings for service code scdataallservices | 2017-10-12 15:03:51 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-10-12 15:03:51 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-10-12 15:03:51 Received 5 login tokens. | 2017-10-12 15:03:51 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-10-12 15:03:57 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-10-12 15:03:57 Symbol settings are up-to-date for scdataallservices | 2017-10-12 15:03:58 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-10-12 15:04:00 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-10-12 15:04:00 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-10-12 15:04:00 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-12 15:04:00 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-10-12 15:04:00 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-10-12 15:04:02 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-10-12 15:04:02 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-10-12 15:04:02 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-12 15:04:02 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-10-12 15:04:02 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-10-12 15:04:03 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-10-12 15:04:03 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-10-12 15:04:03 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-12 15:04:03 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-10-12 15:04:03 Files to Open on Start up | Opening file: Chartbook1.cht | 2017-10-12 15:04:03 NQU7 [CV] Flex Renko 15-10-0 #4 | Reloading chart. | 2017-10-12 15:04:03 NQU7 [CV] Flex Renko 15-10-0 #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 NQU7 [CV] Flex Renko 15-10-0 #4 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 NQU7 [CV] 1 Min #5 | Reloading chart. | 2017-10-12 15:04:03 NQU7 [CV] 1 Min #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 NQU7 [CV] 1 Min #5 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 TICK-NYSE 10 Min #8 | Reloading chart. | 2017-10-12 15:04:03 NQU7 [CV] 1 Min #9 | Reloading chart. | 2017-10-12 15:04:03 NQU7 [CV] 1 Min #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 NQU7 [CV] 1 Min #9 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 NQU7 [CV] Flex Renko 15-10-0 #6 | Reloading chart. | 2017-10-12 15:04:03 NQU7 [CV] Flex Renko 15-10-0 #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 NQU7 [CV] Flex Renko 15-10-0 #6 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 YMU7 [CV] Flex Renko 10-7-0 #16 | Reloading chart. | 2017-10-12 15:04:03 YMU7 [CV] Flex Renko 10-7-0 #16 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 YMU7 [CV] Flex Renko 10-7-0 #16 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 YMU7 [CV] Flex Renko 10-7-0 #17 | Reloading chart. | 2017-10-12 15:04:03 YMU7 [CV] Flex Renko 10-7-0 #17 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 YMU7 [CV] Flex Renko 10-7-0 #17 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 YMU7 [CV] 1 Min #18 | Reloading chart. | 2017-10-12 15:04:03 YMU7 [CV] 1 Min #18 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 YMU7 [CV] 1 Min #18 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 YMU7 [CV] 1 Min #22 | Reloading chart. | 2017-10-12 15:04:03 YMU7 [CV] 1 Min #22 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 YMU7 [CV] 1 Min #22 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 ESU7 [CV] Flex Renko 5-4-0 #12 | Reloading chart. | 2017-10-12 15:04:03 ESU7 [CV] Flex Renko 5-4-0 #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 ESU7 [CV] Flex Renko 5-4-0 #12 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 ESU7 [CV] Flex Renko 5-4-0 #13 | Reloading chart. | 2017-10-12 15:04:03 ESU7 [CV] Flex Renko 5-4-0 #13 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 ESU7 [CV] Flex Renko 5-4-0 #13 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 ESU7 [CV] 1 Min #14 | Reloading chart. | 2017-10-12 15:04:03 ESU7 [CV] 1 Min #14 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 ESU7 [CV] 1 Min #14 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 ESU7 [CV] 1 Min #28 | Reloading chart. | 2017-10-12 15:04:03 ESU7 [CV] 1 Min #28 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 ESU7 [CV] 1 Min #28 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 GCZ7 [CV] Flex Renko 10-7-0 #31 | Reloading chart. | 2017-10-12 15:04:03 GCZ7 [CV] Flex Renko 10-7-0 #31 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 GCZ7 [CV] Flex Renko 10-7-0 #31 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 GCZ7 [CV] Flex Renko 10-7-0 #32 | Reloading chart. | 2017-10-12 15:04:03 GCZ7 [CV] Flex Renko 10-7-0 #32 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 GCZ7 [CV] Flex Renko 10-7-0 #32 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 GCZ7 [CV] 1 Min #33 | Reloading chart. | 2017-10-12 15:04:03 GCZ7 [CV] 1 Min #33 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 GCZ7 [CV] 1 Min #33 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 GCZ7 [CV] 1 Min #37 | Reloading chart. | 2017-10-12 15:04:03 GCZ7 [CV] 1 Min #37 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 GCZ7 [CV] 1 Min #37 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 CLV7 [CV] Flex Renko 10-7-0 #40 | Reloading chart. | 2017-10-12 15:04:03 CLV7 [CV] Flex Renko 10-7-0 #40 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 CLV7 [CV] Flex Renko 10-7-0 #40 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 CLV7 [CV] Flex Renko 10-7-0 #41 | Reloading chart. | 2017-10-12 15:04:03 CLV7 [CV] Flex Renko 10-7-0 #41 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 CLV7 [CV] Flex Renko 10-7-0 #41 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 CLV7 [CV] 1 Min #42 | Reloading chart. | 2017-10-12 15:04:03 CLV7 [CV] 1 Min #42 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 CLV7 [CV] 1 Min #42 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 CLV7 [CV] 1 Min #46 | Reloading chart. | 2017-10-12 15:04:03 CLV7 [CV] 1 Min #46 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 CLV7 [CV] 1 Min #46 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 6EU7 [CV] Flex Renko 10-7-0 #49 | Reloading chart. | 2017-10-12 15:04:03 6EU7 [CV] Flex Renko 10-7-0 #49 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6EU7 [CV] Flex Renko 10-7-0 #49 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 6EU7 [CV] Flex Renko 10-7-0 #50 | Reloading chart. | 2017-10-12 15:04:03 6EU7 [CV] Flex Renko 10-7-0 #50 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6EU7 [CV] Flex Renko 10-7-0 #50 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 6EU7 [CV] 1 Min #51 | Reloading chart. | 2017-10-12 15:04:03 6EU7 [CV] 1 Min #51 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6EU7 [CV] 1 Min #51 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 6EU7 [CV] 1 Min #55 | Reloading chart. | 2017-10-12 15:04:03 6EU7 [CV] 1 Min #55 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6EU7 [CV] 1 Min #55 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 TICK-NASDAQ 5 Min #61 | Reloading chart. | 2017-10-12 15:04:03 6JU7 [CV] Flex Renko 10-7-0 #63 | Reloading chart. | 2017-10-12 15:04:03 6JU7 [CV] Flex Renko 10-7-0 #63 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6JU7 [CV] Flex Renko 10-7-0 #63 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 6JU7 [CV] Flex Renko 10-7-0 #64 | Reloading chart. | 2017-10-12 15:04:03 6JU7 [CV] Flex Renko 10-7-0 #64 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6JU7 [CV] Flex Renko 10-7-0 #64 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 6JU7 [CV] 1 Min #65 | Reloading chart. | 2017-10-12 15:04:03 6JU7 [CV] 1 Min #65 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6JU7 [CV] 1 Min #65 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 6JU7 [CV] 1 Min #69 | Reloading chart. | 2017-10-12 15:04:03 6JU7 [CV] 1 Min #69 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6JU7 [CV] 1 Min #69 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] Flex Renko 10-7-0 #3 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] Flex Renko 10-7-0 #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] Flex Renko 10-7-0 #3 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] Flex Renko 10-7-0 #7 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] Flex Renko 10-7-0 #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] Flex Renko 10-7-0 #7 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #10 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #10 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #11 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #11 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #15 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #15 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #15 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #19 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #19 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #19 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #20 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #20 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #20 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #21 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #21 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #21 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #23 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #23 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #23 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #24 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #24 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #24 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #25 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #25 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #25 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #26 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #26 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #26 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #27 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #27 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #27 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 TICK-TF 15 Min #29 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 5 Min #1 | Reloading chart. | 2017-10-12 15:04:03 RTYU7 [CV] 5 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 RTYU7 [CV] 5 Min #1 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 6JU7 [CV] 5 Min #2 | Reloading chart. | 2017-10-12 15:04:03 6JU7 [CV] 5 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6JU7 [CV] 5 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 6EU7 [CV] 5 Min #30 | Reloading chart. | 2017-10-12 15:04:03 6EU7 [CV] 5 Min #30 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 6EU7 [CV] 5 Min #30 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 GCZ7 [CV] 5 Min #34 | Reloading chart. | 2017-10-12 15:04:03 GCZ7 [CV] 5 Min #34 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 GCZ7 [CV] 5 Min #34 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 CLV7 [CV] 5 Min #35 | Reloading chart. | 2017-10-12 15:04:03 CLV7 [CV] 5 Min #35 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 CLV7 [CV] 5 Min #35 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 ESU7 [CV] 5 Min #36 | Reloading chart. | 2017-10-12 15:04:03 ESU7 [CV] 5 Min #36 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 ESU7 [CV] 5 Min #36 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 YMU7 [CV] 5 Min #38 | Reloading chart. | 2017-10-12 15:04:03 YMU7 [CV] 5 Min #38 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 YMU7 [CV] 5 Min #38 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 NQU7 [CV] 5 Min #39 | Reloading chart. | 2017-10-12 15:04:03 NQU7 [CV] 5 Min #39 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 15:04:03 NQU7 [CV] 5 Min #39 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 15:04:03 NQU7 [CV] Flex Renko 15-10-0 #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 15:04:03 NQU7 [CV] 1 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 15:04:03 NQU7 [CV] 1 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 15:04:03 NQU7 [CV] Flex Renko 15-10-0 #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 15:04:03 YMU7 [CV] Flex Renko 10-7-0 #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 15:04:03 YMU7 [CV] Flex Renko 10-7-0 #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 15:04:03 YMU7 [CV] 1 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 15:04:03 YMU7 [CV] 1 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 15:04:03 ESU7 [CV] Flex Renko 5-4-0 #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 15:04:03 ESU7 [CV] Flex Renko 5-4-0 #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 15:04:03 ESU7 [CV] 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 15:04:03 ESU7 [CV] 1 Min #28 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 15:04:03 GCZ7 [CV] Flex Renko 10-7-0 #31 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 15:04:03 GCZ7 [CV] Flex Renko 10-7-0 #32 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 15:04:03 GCZ7 [CV] 1 Min #33 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 15:04:03 GCZ7 [CV] 1 Min #37 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 15:04:03 CLV7 [CV] Flex Renko 10-7-0 #40 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 15:04:03 CLV7 [CV] Flex Renko 10-7-0 #41 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 15:04:03 CLV7 [CV] 1 Min #42 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 15:04:03 CLV7 [CV] 1 Min #46 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 15:04:03 6EU7 [CV] Flex Renko 10-7-0 #49 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 15:04:03 6EU7 [CV] Flex Renko 10-7-0 #50 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 15:04:03 6EU7 [CV] 1 Min #51 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 15:04:03 6EU7 [CV] 1 Min #55 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 15:04:03 6JU7 [CV] Flex Renko 10-7-0 #63 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 15:04:03 6JU7 [CV] Flex Renko 10-7-0 #64 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 15:04:03 6JU7 [CV] 1 Min #65 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 15:04:03 6JU7 [CV] 1 Min #69 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] Flex Renko 10-7-0 #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] Flex Renko 10-7-0 #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #19 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #20 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #25 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #26 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 1 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 RTYU7 [CV] 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:03 6JU7 [CV] 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 15:04:03 6EU7 [CV] 5 Min #30 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 15:04:03 GCZ7 [CV] 5 Min #34 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 15:04:03 CLV7 [CV] 5 Min #35 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 15:04:03 ESU7 [CV] 5 Min #36 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 15:04:03 YMU7 [CV] 5 Min #38 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 15:04:03 NQU7 [CV] 5 Min #39 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 15:04:03 SC Data - All Services | Connected to data server. | 2017-10-12 15:04:04 SC Data - All Services | Starting real-time market data updates for: NQU7. ID: 1 | 2017-10-12 15:04:04 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: NQU7 | 2017-10-12 15:04:04 SC Data - All Services | Requesting security definition data for: NQU7. ID: 1 | 2017-10-12 15:04:04 Intraday data recording state for symbol NQU7 is set to download 'Pending'. | 2017-10-12 15:04:04 Delaying start of download for NQU7 | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2017-10-12 15:04:04 DTC Client socket (6) | Creating socket. | 2017-10-12 15:04:04 DTC Client socket (6) | Connecting to IP: 192.81.56.146. | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 2 | 2017-10-12 15:04:04 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2017-10-12 15:04:04 Delaying start of download for TICK-NYSE | 2017-10-12 15:04:04 SC Data - All Services | Starting real-time market data updates for: YMU7. ID: 3 | 2017-10-12 15:04:04 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: YMU7 | 2017-10-12 15:04:04 SC Data - All Services | Requesting security definition data for: YMU7. ID: 3 | 2017-10-12 15:04:04 Intraday data recording state for symbol YMU7 is set to download 'Pending'. | 2017-10-12 15:04:04 HD Request # 2 | Downloading Intraday chart data for NQU7 to the file NQU7.scid. Service: scdataallservices | 2017-10-12 15:04:04 HD Request # 2 | Download start date-time: 2017-04-09 15:04:03.000 | 2017-10-12 15:04:04 HD Request # 2 | Error downloading historical Intraday data for NQU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 15:04:04 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQU7 | 2017-10-12 15:04:04 HD Request # 2 | Intraday download COMPLETE for NQU7. Completion time: 0s. Unique request ID: 1 | 2017-10-12 15:04:04 Removed historical data download ID 1 | 2017-10-12 15:04:04 Real-time Intraday chart data file updates started for NQU7 | 2017-10-12 15:04:04 Opened cached Intraday file: C:\SierraChart\Data\NQU7.scid | 2017-10-12 15:04:04 Intraday chart data file opened for NQU7 | 2017-10-12 15:04:04 Delaying start of download for YMU7 | 2017-10-12 15:04:04 SC Data - All Services | Starting real-time market data updates for: ESU7. ID: 4 | 2017-10-12 15:04:04 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESU7 | 2017-10-12 15:04:04 SC Data - All Services | Requesting security definition data for: ESU7. ID: 4 | 2017-10-12 15:04:04 Intraday data recording state for symbol ESU7 is set to download 'Pending'. | 2017-10-12 15:04:04 HD Request # 3 | Downloading Intraday chart data for YMU7 to the file YMU7.scid. Service: scdataallservices | 2017-10-12 15:04:04 HD Request # 3 | Download start date-time: 2017-04-09 15:04:03.000 | 2017-10-12 15:04:04 HD Request # 3 | Error downloading historical Intraday data for YMU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 15:04:04 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMU7 | 2017-10-12 15:04:04 HD Request # 3 | Intraday download COMPLETE for YMU7. Completion time: 0s. Unique request ID: 3 | 2017-10-12 15:04:04 Removed historical data download ID 3 | 2017-10-12 15:04:04 Real-time Intraday chart data file updates started for YMU7 | 2017-10-12 15:04:04 Opened cached Intraday file: C:\SierraChart\Data\YMU7.scid | 2017-10-12 15:04:04 Intraday chart data file opened for YMU7 | 2017-10-12 15:04:04 Delaying start of download for ESU7 | 2017-10-12 15:04:04 SC Data - All Services | Starting real-time market data updates for: GCZ7. ID: 5 | 2017-10-12 15:04:04 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: GCZ7 | 2017-10-12 15:04:04 SC Data - All Services | Requesting security definition data for: GCZ7. ID: 5 | 2017-10-12 15:04:04 Intraday data recording state for symbol GCZ7 is set to download 'Pending'. | 2017-10-12 15:04:04 HD Request # 4 | Downloading Intraday chart data for ESU7 to the file ESU7.scid. Service: scdataallservices | 2017-10-12 15:04:04 HD Request # 4 | Download start date-time: 2017-04-09 15:04:03.000 | 2017-10-12 15:04:04 HD Request # 4 | Error downloading historical Intraday data for ESU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 15:04:04 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU7 | 2017-10-12 15:04:04 HD Request # 4 | Intraday download COMPLETE for ESU7. Completion time: 0s. Unique request ID: 4 | 2017-10-12 15:04:04 Removed historical data download ID 4 | 2017-10-12 15:04:04 Real-time Intraday chart data file updates started for ESU7 | 2017-10-12 15:04:04 Opened cached Intraday file: C:\SierraChart\Data\ESU7.scid | 2017-10-12 15:04:04 Intraday chart data file opened for ESU7 | 2017-10-12 15:04:04 Delaying start of download for GCZ7 | 2017-10-12 15:04:04 SC Data - All Services | Starting real-time market data updates for: CLV7. ID: 6 | 2017-10-12 15:04:04 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: CLV7 | 2017-10-12 15:04:04 SC Data - All Services | Requesting security definition data for: CLV7. ID: 6 | 2017-10-12 15:04:04 Intraday data recording state for symbol CLV7 is set to download 'Pending'. | 2017-10-12 15:04:04 HD Request # 5 | Downloading Intraday chart data for GCZ7 to the file GCZ7.scid. Service: scdataallservices | 2017-10-12 15:04:04 HD Request # 5 | Download start date-time: 2017-04-09 15:04:03.000 | 2017-10-12 15:04:04 HD Request # 5 | Error downloading historical Intraday data for GCZ7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 15:04:04 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCZ7 | 2017-10-12 15:04:04 HD Request # 5 | Intraday download COMPLETE for GCZ7. Completion time: 0s. Unique request ID: 5 | 2017-10-12 15:04:04 Removed historical data download ID 5 | 2017-10-12 15:04:04 Real-time Intraday chart data file updates started for GCZ7 | 2017-10-12 15:04:04 Opened cached Intraday file: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 15:04:04 Intraday chart data file opened for GCZ7 | 2017-10-12 15:04:04 Delaying start of download for CLV7 | 2017-10-12 15:04:04 SC Data - All Services | Starting real-time market data updates for: 6EU7. ID: 7 | 2017-10-12 15:04:04 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: 6EU7 | 2017-10-12 15:04:04 SC Data - All Services | Requesting security definition data for: 6EU7. ID: 7 | 2017-10-12 15:04:04 Intraday data recording state for symbol 6EU7 is set to download 'Pending'. | 2017-10-12 15:04:04 HD Request # 6 | Downloading Intraday chart data for CLV7 to the file CLV7.scid. Service: scdataallservices | 2017-10-12 15:04:04 HD Request # 6 | Download start date-time: 2017-04-09 15:04:03.000 | 2017-10-12 15:04:04 HD Request # 6 | Error downloading historical Intraday data for CLV7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 15:04:04 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLV7 | 2017-10-12 15:04:04 HD Request # 6 | Intraday download COMPLETE for CLV7. Completion time: 0s. Unique request ID: 6 | 2017-10-12 15:04:04 Removed historical data download ID 6 | 2017-10-12 15:04:04 Real-time Intraday chart data file updates started for CLV7 | 2017-10-12 15:04:04 Opened cached Intraday file: C:\SierraChart\Data\CLV7.scid | 2017-10-12 15:04:04 Intraday chart data file opened for CLV7 | 2017-10-12 15:04:04 Delaying start of download for 6EU7 | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Connected to server. | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Starting socket receive thread. | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NASDAQ. ID: 8 | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NASDAQ. ID: 8 | 2017-10-12 15:04:04 Intraday data recording state for symbol TICK-NASDAQ is set to download 'Pending'. | 2017-10-12 15:04:04 SC Data - All Services | Starting real-time market data updates for: 6JU7. ID: 9 | 2017-10-12 15:04:04 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: 6JU7 | 2017-10-12 15:04:04 SC Data - All Services | Requesting security definition data for: 6JU7. ID: 9 | 2017-10-12 15:04:04 Intraday data recording state for symbol 6JU7 is set to download 'Pending'. | 2017-10-12 15:04:04 HD Request # 7 | Downloading Intraday chart data for 6EU7 to the file 6EU7.scid. Service: scdataallservices | 2017-10-12 15:04:04 HD Request # 7 | Download start date-time: 2017-04-09 15:04:03.000 | 2017-10-12 15:04:04 HD Request # 7 | Error downloading historical Intraday data for 6EU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 15:04:04 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EU7 | 2017-10-12 15:04:04 HD Request # 7 | Intraday download COMPLETE for 6EU7. Completion time: 0s. Unique request ID: 7 | 2017-10-12 15:04:04 Removed historical data download ID 7 | 2017-10-12 15:04:04 Real-time Intraday chart data file updates started for 6EU7 | 2017-10-12 15:04:04 Opened cached Intraday file: C:\SierraChart\Data\6EU7.scid | 2017-10-12 15:04:04 Intraday chart data file opened for 6EU7 | 2017-10-12 15:04:04 Delaying start of download for 6JU7 | 2017-10-12 15:04:04 SC Data - All Services | Starting real-time market data updates for: RTYU7. ID: 10 | 2017-10-12 15:04:04 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: RTYU7 | 2017-10-12 15:04:04 SC Data - All Services | Requesting security definition data for: RTYU7. ID: 10 | 2017-10-12 15:04:04 Intraday data recording state for symbol RTYU7 is set to download 'Pending'. | 2017-10-12 15:04:04 HD Request # 8 | Downloading Intraday chart data for 6JU7 to the file 6JU7.scid. Service: scdataallservices | 2017-10-12 15:04:04 HD Request # 8 | Download start date-time: 2017-04-09 15:04:03.000 | 2017-10-12 15:04:04 HD Request # 8 | Error downloading historical Intraday data for 6JU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 15:04:04 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6JU7 | 2017-10-12 15:04:04 HD Request # 8 | Intraday download COMPLETE for 6JU7. Completion time: 0s. Unique request ID: 9 | 2017-10-12 15:04:04 Removed historical data download ID 9 | 2017-10-12 15:04:04 Real-time Intraday chart data file updates started for 6JU7 | 2017-10-12 15:04:04 Opened cached Intraday file: C:\SierraChart\Data\6JU7.scid | 2017-10-12 15:04:04 Intraday chart data file opened for 6JU7 | 2017-10-12 15:04:04 Delaying start of download for RTYU7 | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Sending logon request message. | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-TF. ID: 11 | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Requesting security definition data for: TICK-TF. ID: 11 | 2017-10-12 15:04:04 Intraday data recording state for symbol TICK-TF is set to download 'Pending'. | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Received logon response. | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Successfully connected. | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Trading is not supported. | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NASDAQ | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-TF | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Received security definition for symbol TICK-NASDAQ | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2017-10-12 15:04:04 SC DTC Data with Market Depth | Received security definition for symbol TICK-TF | 2017-10-12 15:04:04 Delaying start of download for TICK-NYSE | 2017-10-12 15:04:05 HD Request # 9 | Downloading Intraday chart data for RTYU7 to the file RTYU7.scid. Service: scdataallservices | 2017-10-12 15:04:09 HD Request # 9 | Download start date-time: 2017-04-09 15:04:08.000 | 2017-10-12 15:04:09 HD Request # 9 | Error downloading historical Intraday data for RTYU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 15:04:09 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for RTYU7 | 2017-10-12 15:04:09 HD Request # 9 | Intraday download COMPLETE for RTYU7. Completion time: 0s. Unique request ID: 10 | 2017-10-12 15:04:09 Removed historical data download ID 10 | 2017-10-12 15:04:09 Real-time Intraday chart data file updates started for RTYU7 | 2017-10-12 15:04:09 Opened cached Intraday file: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 15:04:09 Intraday chart data file opened for RTYU7 | 2017-10-12 15:04:09 HD Request # 10 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2017-10-12 15:04:09 HD Request # 10 | Download start date-time: 2017-10-12 14:55:02.000 | 2017-10-12 15:04:09 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2017-10-12 15:04:09 Socket (7) | Creating socket. | 2017-10-12 15:04:09 Socket (7) | Connecting to IP: 192.81.56.146. | 2017-10-12 15:04:09 HD Request # 10 | Setting DTC encoding to Binary VLS | 2017-10-12 15:04:09 HD Request # 10 | Sending historical data logon request message. | 2017-10-12 15:04:09 HD Request # 10 | Requesting Intraday data. Start date-time: 2017-10-12 14:55:02. Record interval: 1. Symbol: TICK-NYSE | 2017-10-12 15:04:09 HD Request # 10 | Decompressing data. | 2017-10-12 15:04:09 HD Request # 10 | Receiving Intraday data for TICK-NYSE starting at 2017-10-12 14:55:02 | 2017-10-12 15:04:09 HD Request # 10 | Timestamp of first Intraday data file record written: 2017-10-12 14:55:02 | 2017-10-12 15:04:09 Socket (7) | Initiating close of socket by core. | 2017-10-12 15:04:09 Socket (7) | Shutdown started. Waiting for graceful close. | 2017-10-12 15:04:09 Historical data download thread signaled to stop. | 2017-10-12 15:04:09 HD Request # 10 | Received 547 records from 2017-10-12 14:55:02 to 2017-10-12 15:04:08 (9.1 minutes) and wrote 547 records for TICK-NYSE | 2017-10-12 15:04:09 Added 3 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2017-10-12 15:04:09 HD Request # 10 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 2 | 2017-10-12 15:04:09 Removed historical data download ID 2 | 2017-10-12 15:04:09 Real-time Intraday chart data file updates started for TICK-NYSE | 2017-10-12 15:04:09 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid | 2017-10-12 15:04:09 Intraday chart data file opened for TICK-NYSE | 2017-10-12 15:04:09 HD Request # 11 | Downloading Intraday chart data for TICK-NASDAQ to the file TICK-NASDAQ.scid. Service: statscalc | 2017-10-12 15:04:09 HD Request # 11 | Download start date-time: 2017-10-12 14:55:02.000 | 2017-10-12 15:04:09 HD Request # 11 | Using server: ds3.sierracharts.com port 10150 | 2017-10-12 15:04:09 Socket (8) | Creating socket. | 2017-10-12 15:04:09 Socket (8) | Connecting to IP: 65.182.172.42. | 2017-10-12 15:04:09 Socket (7) | Socket gracefully closed by remote side. | 2017-10-12 15:04:09 Socket (7) | Closed. | 2017-10-12 15:04:09 HD Request # 11 | Setting DTC encoding to Binary VLS | 2017-10-12 15:04:09 HD Request # 11 | Sending historical data logon request message. | 2017-10-12 15:04:09 HD Request # 11 | Requesting Intraday data. Start date-time: 2017-10-12 14:55:02. Record interval: 1. Symbol: TICK-NASDAQ | 2017-10-12 15:04:09 HD Request # 11 | Decompressing data. | 2017-10-12 15:04:09 HD Request # 11 | Receiving Intraday data for TICK-NASDAQ starting at 2017-10-12 14:55:02 | 2017-10-12 15:04:09 HD Request # 11 | Timestamp of first Intraday data file record written: 2017-10-12 14:55:02 | 2017-10-12 15:04:09 Socket (8) | Initiating close of socket by core. | 2017-10-12 15:04:09 Socket (8) | Shutdown started. Waiting for graceful close. | 2017-10-12 15:04:09 Historical data download thread signaled to stop. | 2017-10-12 15:04:09 HD Request # 11 | Received 547 records from 2017-10-12 14:55:02 to 2017-10-12 15:04:08 (9.1 minutes) and wrote 547 records for TICK-NASDAQ | 2017-10-12 15:04:09 Added 5 Time and Sales records to Intraday data file for TICK-NASDAQ after download. | 2017-10-12 15:04:09 HD Request # 11 | Intraday download COMPLETE for TICK-NASDAQ. Completion time: 0s. Unique request ID: 8 | 2017-10-12 15:04:09 Removed historical data download ID 8 | 2017-10-12 15:04:09 Real-time Intraday chart data file updates started for TICK-NASDAQ | 2017-10-12 15:04:09 Opened cached Intraday file: C:\SierraChart\Data\TICK-NASDAQ.scid | 2017-10-12 15:04:09 Intraday chart data file opened for TICK-NASDAQ | 2017-10-12 15:04:09 HD Request # 12 | Downloading Intraday chart data for TICK-TF to the file TICK-TF.scid. Service: statscalc | 2017-10-12 15:04:09 HD Request # 12 | Download start date-time: 2017-10-12 14:55:02.000 | 2017-10-12 15:04:09 HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2017-10-12 15:04:09 Socket (9) | Creating socket. | 2017-10-12 15:04:09 Socket (9) | Connecting to IP: 192.81.56.146. | 2017-10-12 15:04:09 Socket (8) | Socket gracefully closed by remote side. | 2017-10-12 15:04:09 Socket (8) | Closed. | 2017-10-12 15:04:09 HD Request # 12 | Setting DTC encoding to Binary VLS | 2017-10-12 15:04:10 HD Request # 12 | Sending historical data logon request message. | 2017-10-12 15:04:10 HD Request # 12 | Requesting Intraday data. Start date-time: 2017-10-12 14:55:02. Record interval: 1. Symbol: TICK-TF | 2017-10-12 15:04:10 HD Request # 12 | Decompressing data. | 2017-10-12 15:04:10 HD Request # 12 | Receiving Intraday data for TICK-TF starting at 2017-10-12 14:55:02 | 2017-10-12 15:04:10 HD Request # 12 | Timestamp of first Intraday data file record written: 2017-10-12 14:55:02 | 2017-10-12 15:04:10 Socket (9) | Initiating close of socket by core. | 2017-10-12 15:04:10 Socket (9) | Shutdown started. Waiting for graceful close. | 2017-10-12 15:04:10 Historical data download thread signaled to stop. | 2017-10-12 15:04:10 HD Request # 12 | Received 547 records from 2017-10-12 14:55:02 to 2017-10-12 15:04:08 (9.1 minutes) and wrote 547 records for TICK-TF | 2017-10-12 15:04:10 Added 8 Time and Sales records to Intraday data file for TICK-TF after download. | 2017-10-12 15:04:10 HD Request # 12 | Intraday download COMPLETE for TICK-TF. Completion time: 0s. Unique request ID: 11 | 2017-10-12 15:04:10 Removed historical data download ID 11 | 2017-10-12 15:04:10 Real-time Intraday chart data file updates started for TICK-TF | 2017-10-12 15:04:10 Opened cached Intraday file: C:\SierraChart\Data\TICK-TF.scid | 2017-10-12 15:04:10 Intraday chart data file opened for TICK-TF | 2017-10-12 15:04:10 Socket (9) | Socket gracefully closed by remote side. | 2017-10-12 15:04:10 Socket (9) | Closed. | 2017-10-12 15:04:10 |
[2017-10-12 21:17:41] |
This is the problem: HD Request # 9 | Error downloading historical Intraday data for RTYU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 15:04:09 Based upon this, we think you do not have the Global Settings >> Data/Trade Service Settings >>Service in Sierra Chart set correctly. Who is your futures broker? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-10-12 22:10:24] |
I am currently trading from the platform Tradovate and Andrew Sevin.
[2017-10-12 22:23:26] |
I just updated the data feed to CQG Trading and still am having difficulties getting the charts working.
[2017-10-12 22:24:46] |
Reading Internal Order ID file. | 2017-10-12 18:12:43 Reading Trade Orders file. | 2017-10-12 18:12:43 Reading Trade Positions file. | 2017-10-12 18:12:43 Listening on UDP port 22903. | 2017-10-12 18:12:43 Software version: 1621 | 2017-10-12 18:12:43 Usage end date: 2017-11-23 | 2017-10-12 18:12:43 Enabled for: Advanced Features. | 2017-10-12 18:12:43 Enabled for: Sierra Chart Historical Data Service. | 2017-10-12 18:12:43 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-10-12 18:12:43 Current selected Data/Trading service: SC Data - All Services | 2017-10-12 18:12:43 Chart Update Interval: 500 | 2017-10-12 18:12:43 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-10-12 18:12:43 2017-10-12 18:12:47 Local computer time | 2017-10-12 18:12:43 2017-10-12 22:12:47 Local computer time in UTC | 2017-10-12 18:12:43 2017-10-12 18:12:47 Local computer time in SC Time Zone | 2017-10-12 18:12:43 2017-10-12 22:12:47 Server time in UTC | 2017-10-12 18:12:43 Local computer UTC time and Server UTC time difference: 1 seconds. | 2017-10-12 18:12:43 Program path: C:\SierraChart\ | 2017-10-12 18:12:43 Data Files path: C:\SierraChart\Data\ | 2017-10-12 18:12:43 OS Version Number: 10.0 | 2017-10-12 18:12:43 Locale Setting: C | 2017-10-12 18:12:43 Created the DTC Protocol server. | 2017-10-12 18:12:43 DTC Protocol Server listening on port 11099. | 2017-10-12 18:12:43 Created the DTC Protocol historical data server. | 2017-10-12 18:12:43 HD Server Manager | Listening on port 11098 | 2017-10-12 18:12:43 Checking for new symbol settings for service code scdataallservices | 2017-10-12 18:12:43 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2017-10-12 18:12:43 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2017-10-12 18:12:43 Received 5 login tokens. | 2017-10-12 18:12:43 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2017-10-12 18:12:49 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2017-10-12 18:12:49 Symbol settings are up-to-date for scdataallservices | 2017-10-12 18:12:50 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2017-10-12 18:12:52 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2017-10-12 18:12:52 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2017-10-12 18:12:52 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-12 18:12:52 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2017-10-12 18:12:52 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2017-10-12 18:12:54 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2017-10-12 18:12:54 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2017-10-12 18:12:54 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-12 18:12:54 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2017-10-12 18:12:54 Files to Open on Start up | Opening file: Chartbook1.cht | 2017-10-12 18:12:55 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2017-10-12 18:12:55 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2017-10-12 18:12:55 NQU7 [CV] Flex Renko 15-10-0 #4 | Reloading chart. | 2017-10-12 18:12:55 NQU7 [CV] Flex Renko 15-10-0 #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 NQU7 [CV] Flex Renko 15-10-0 #4 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 NQU7 [CV] 1 Min #5 | Reloading chart. | 2017-10-12 18:12:55 NQU7 [CV] 1 Min #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 NQU7 [CV] 1 Min #5 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 TICK-NYSE 10 Min #8 | Reloading chart. | 2017-10-12 18:12:55 NQU7 [CV] 1 Min #9 | Reloading chart. | 2017-10-12 18:12:55 NQU7 [CV] 1 Min #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 NQU7 [CV] 1 Min #9 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 NQU7 [CV] Flex Renko 15-10-0 #6 | Reloading chart. | 2017-10-12 18:12:55 NQU7 [CV] Flex Renko 15-10-0 #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 NQU7 [CV] Flex Renko 15-10-0 #6 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 YMU7 [CV] Flex Renko 10-7-0 #16 | Reloading chart. | 2017-10-12 18:12:55 YMU7 [CV] Flex Renko 10-7-0 #16 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 YMU7 [CV] Flex Renko 10-7-0 #16 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 YMU7 [CV] Flex Renko 10-7-0 #17 | Reloading chart. | 2017-10-12 18:12:55 YMU7 [CV] Flex Renko 10-7-0 #17 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 YMU7 [CV] Flex Renko 10-7-0 #17 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 YMU7 [CV] 1 Min #18 | Reloading chart. | 2017-10-12 18:12:55 YMU7 [CV] 1 Min #18 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 YMU7 [CV] 1 Min #18 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 YMU7 [CV] 1 Min #22 | Reloading chart. | 2017-10-12 18:12:55 YMU7 [CV] 1 Min #22 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 YMU7 [CV] 1 Min #22 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 ESU7 [CV] Flex Renko 5-4-0 #12 | Reloading chart. | 2017-10-12 18:12:55 ESU7 [CV] Flex Renko 5-4-0 #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 ESU7 [CV] Flex Renko 5-4-0 #12 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 ESU7 [CV] Flex Renko 5-4-0 #13 | Reloading chart. | 2017-10-12 18:12:55 ESU7 [CV] Flex Renko 5-4-0 #13 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 ESU7 [CV] Flex Renko 5-4-0 #13 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 ESU7 [CV] 1 Min #14 | Reloading chart. | 2017-10-12 18:12:55 ESU7 [CV] 1 Min #14 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 ESU7 [CV] 1 Min #14 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 ESU7 [CV] 1 Min #28 | Reloading chart. | 2017-10-12 18:12:55 ESU7 [CV] 1 Min #28 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 ESU7 [CV] 1 Min #28 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 GCZ7 [CV] Flex Renko 10-7-0 #31 | Reloading chart. | 2017-10-12 18:12:55 GCZ7 [CV] Flex Renko 10-7-0 #31 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 GCZ7 [CV] Flex Renko 10-7-0 #31 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 GCZ7 [CV] Flex Renko 10-7-0 #32 | Reloading chart. | 2017-10-12 18:12:55 GCZ7 [CV] Flex Renko 10-7-0 #32 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 GCZ7 [CV] Flex Renko 10-7-0 #32 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 GCZ7 [CV] 1 Min #33 | Reloading chart. | 2017-10-12 18:12:55 GCZ7 [CV] 1 Min #33 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 GCZ7 [CV] 1 Min #33 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 GCZ7 [CV] 1 Min #37 | Reloading chart. | 2017-10-12 18:12:55 GCZ7 [CV] 1 Min #37 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 GCZ7 [CV] 1 Min #37 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 CLV7 [CV] Flex Renko 10-7-0 #40 | Reloading chart. | 2017-10-12 18:12:55 CLV7 [CV] Flex Renko 10-7-0 #40 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 CLV7 [CV] Flex Renko 10-7-0 #40 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 CLV7 [CV] Flex Renko 10-7-0 #41 | Reloading chart. | 2017-10-12 18:12:55 CLV7 [CV] Flex Renko 10-7-0 #41 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 CLV7 [CV] Flex Renko 10-7-0 #41 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 CLV7 [CV] 1 Min #42 | Reloading chart. | 2017-10-12 18:12:55 CLV7 [CV] 1 Min #42 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 CLV7 [CV] 1 Min #42 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 CLV7 [CV] 1 Min #46 | Reloading chart. | 2017-10-12 18:12:55 CLV7 [CV] 1 Min #46 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 CLV7 [CV] 1 Min #46 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 6EU7 [CV] Flex Renko 10-7-0 #49 | Reloading chart. | 2017-10-12 18:12:55 6EU7 [CV] Flex Renko 10-7-0 #49 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6EU7 [CV] Flex Renko 10-7-0 #49 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 6EU7 [CV] Flex Renko 10-7-0 #50 | Reloading chart. | 2017-10-12 18:12:55 6EU7 [CV] Flex Renko 10-7-0 #50 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6EU7 [CV] Flex Renko 10-7-0 #50 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 6EU7 [CV] 1 Min #51 | Reloading chart. | 2017-10-12 18:12:55 6EU7 [CV] 1 Min #51 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6EU7 [CV] 1 Min #51 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 6EU7 [CV] 1 Min #55 | Reloading chart. | 2017-10-12 18:12:55 6EU7 [CV] 1 Min #55 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6EU7 [CV] 1 Min #55 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 TICK-NASDAQ 5 Min #61 | Reloading chart. | 2017-10-12 18:12:55 6JU7 [CV] Flex Renko 10-7-0 #63 | Reloading chart. | 2017-10-12 18:12:55 6JU7 [CV] Flex Renko 10-7-0 #63 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6JU7 [CV] Flex Renko 10-7-0 #63 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 6JU7 [CV] Flex Renko 10-7-0 #64 | Reloading chart. | 2017-10-12 18:12:55 6JU7 [CV] Flex Renko 10-7-0 #64 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6JU7 [CV] Flex Renko 10-7-0 #64 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 6JU7 [CV] 1 Min #65 | Reloading chart. | 2017-10-12 18:12:55 6JU7 [CV] 1 Min #65 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6JU7 [CV] 1 Min #65 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 6JU7 [CV] 1 Min #69 | Reloading chart. | 2017-10-12 18:12:55 6JU7 [CV] 1 Min #69 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6JU7 [CV] 1 Min #69 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] Flex Renko 10-7-0 #3 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] Flex Renko 10-7-0 #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] Flex Renko 10-7-0 #3 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] Flex Renko 10-7-0 #7 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] Flex Renko 10-7-0 #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] Flex Renko 10-7-0 #7 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #10 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #10 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #11 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #11 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #15 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #15 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #15 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #19 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #19 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #19 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #20 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #20 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #20 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #21 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #21 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #21 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #23 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #23 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #23 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #24 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #24 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #24 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #25 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #25 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #25 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #26 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #26 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #26 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #27 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #27 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #27 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 TICK-TF 15 Min #29 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 5 Min #1 | Reloading chart. | 2017-10-12 18:12:55 RTYU7 [CV] 5 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 RTYU7 [CV] 5 Min #1 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 6JU7 [CV] 5 Min #2 | Reloading chart. | 2017-10-12 18:12:55 6JU7 [CV] 5 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6JU7 [CV] 5 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 6EU7 [CV] 5 Min #30 | Reloading chart. | 2017-10-12 18:12:55 6EU7 [CV] 5 Min #30 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 6EU7 [CV] 5 Min #30 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 GCZ7 [CV] 5 Min #34 | Reloading chart. | 2017-10-12 18:12:55 GCZ7 [CV] 5 Min #34 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 GCZ7 [CV] 5 Min #34 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 CLV7 [CV] 5 Min #35 | Reloading chart. | 2017-10-12 18:12:55 CLV7 [CV] 5 Min #35 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 CLV7 [CV] 5 Min #35 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 ESU7 [CV] 5 Min #36 | Reloading chart. | 2017-10-12 18:12:55 ESU7 [CV] 5 Min #36 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 ESU7 [CV] 5 Min #36 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 YMU7 [CV] 5 Min #38 | Reloading chart. | 2017-10-12 18:12:55 YMU7 [CV] 5 Min #38 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 YMU7 [CV] 5 Min #38 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 NQU7 [CV] 5 Min #39 | Reloading chart. | 2017-10-12 18:12:55 NQU7 [CV] 5 Min #39 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2017-10-12 18:12:55 NQU7 [CV] 5 Min #39 | There are no continuous futures contract symbols. Loading data normally. | 2017-10-12 18:12:55 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2017-10-12 18:12:55 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-12 18:12:55 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2017-10-12 18:12:55 NQU7 [CV] Flex Renko 15-10-0 #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 18:12:55 NQU7 [CV] 1 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 18:12:55 NQU7 [CV] 1 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 18:12:55 NQU7 [CV] Flex Renko 15-10-0 #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 18:12:55 YMU7 [CV] Flex Renko 10-7-0 #16 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 18:12:55 YMU7 [CV] Flex Renko 10-7-0 #17 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 18:12:55 YMU7 [CV] 1 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 18:12:55 YMU7 [CV] 1 Min #22 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 18:12:55 ESU7 [CV] Flex Renko 5-4-0 #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 18:12:55 ESU7 [CV] Flex Renko 5-4-0 #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 18:12:55 ESU7 [CV] 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 18:12:55 ESU7 [CV] 1 Min #28 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 18:12:55 GCZ7 [CV] Flex Renko 10-7-0 #31 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 18:12:55 GCZ7 [CV] Flex Renko 10-7-0 #32 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 18:12:55 GCZ7 [CV] 1 Min #33 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 18:12:55 GCZ7 [CV] 1 Min #37 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 18:12:55 CLV7 [CV] Flex Renko 10-7-0 #40 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 18:12:55 CLV7 [CV] Flex Renko 10-7-0 #41 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 18:12:55 CLV7 [CV] 1 Min #42 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 18:12:55 CLV7 [CV] 1 Min #46 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 18:12:55 6EU7 [CV] Flex Renko 10-7-0 #49 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 18:12:55 6EU7 [CV] Flex Renko 10-7-0 #50 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 18:12:55 6EU7 [CV] 1 Min #51 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 18:12:55 6EU7 [CV] 1 Min #55 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 18:12:55 6JU7 [CV] Flex Renko 10-7-0 #63 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 18:12:55 6JU7 [CV] Flex Renko 10-7-0 #64 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 18:12:55 6JU7 [CV] 1 Min #65 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 18:12:55 6JU7 [CV] 1 Min #69 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] Flex Renko 10-7-0 #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] Flex Renko 10-7-0 #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #15 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #19 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #20 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #21 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #23 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #24 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #25 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #26 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 1 Min #27 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 RTYU7 [CV] 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:12:55 6JU7 [CV] 5 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6JU7.scid | 2017-10-12 18:12:55 6EU7 [CV] 5 Min #30 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6EU7.scid | 2017-10-12 18:12:55 GCZ7 [CV] 5 Min #34 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 18:12:55 CLV7 [CV] 5 Min #35 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLV7.scid | 2017-10-12 18:12:55 ESU7 [CV] 5 Min #36 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU7.scid | 2017-10-12 18:12:55 YMU7 [CV] 5 Min #38 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\YMU7.scid | 2017-10-12 18:12:55 NQU7 [CV] 5 Min #39 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU7.scid | 2017-10-12 18:12:55 SC Data - All Services | Connected to data server. | 2017-10-12 18:12:57 SC Data - All Services | Starting real-time market data updates for: NQU7. ID: 1 | 2017-10-12 18:12:57 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: NQU7 | 2017-10-12 18:12:57 SC Data - All Services | Requesting security definition data for: NQU7. ID: 1 | 2017-10-12 18:12:57 Intraday data recording state for symbol NQU7 is set to download 'Pending'. | 2017-10-12 18:12:57 Delaying start of download for NQU7 | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 2 | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2017-10-12 18:12:57 DTC Client socket (6) | Creating socket. | 2017-10-12 18:12:57 DTC Client socket (6) | Connecting to IP: 192.81.56.146. | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 2 | 2017-10-12 18:12:57 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2017-10-12 18:12:57 Delaying start of download for TICK-NYSE | 2017-10-12 18:12:57 SC Data - All Services | Starting real-time market data updates for: YMU7. ID: 3 | 2017-10-12 18:12:57 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: YMU7 | 2017-10-12 18:12:57 SC Data - All Services | Requesting security definition data for: YMU7. ID: 3 | 2017-10-12 18:12:57 Intraday data recording state for symbol YMU7 is set to download 'Pending'. | 2017-10-12 18:12:57 HD Request # 2 | Downloading Intraday chart data for NQU7 to the file NQU7.scid. Service: scdataallservices | 2017-10-12 18:12:57 HD Request # 2 | Download start date-time: 2017-04-09 18:12:56.000 | 2017-10-12 18:12:57 HD Request # 2 | Error downloading historical Intraday data for NQU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 18:12:57 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQU7 | 2017-10-12 18:12:57 HD Request # 2 | Intraday download COMPLETE for NQU7. Completion time: 0s. Unique request ID: 1 | 2017-10-12 18:12:57 Removed historical data download ID 1 | 2017-10-12 18:12:57 Real-time Intraday chart data file updates started for NQU7 | 2017-10-12 18:12:57 Opened cached Intraday file: C:\SierraChart\Data\NQU7.scid | 2017-10-12 18:12:57 Intraday chart data file opened for NQU7 | 2017-10-12 18:12:57 Delaying start of download for YMU7 | 2017-10-12 18:12:57 SC Data - All Services | Starting real-time market data updates for: ESU7. ID: 4 | 2017-10-12 18:12:57 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESU7 | 2017-10-12 18:12:57 SC Data - All Services | Requesting security definition data for: ESU7. ID: 4 | 2017-10-12 18:12:57 Intraday data recording state for symbol ESU7 is set to download 'Pending'. | 2017-10-12 18:12:57 HD Request # 3 | Downloading Intraday chart data for YMU7 to the file YMU7.scid. Service: scdataallservices | 2017-10-12 18:12:57 HD Request # 3 | Download start date-time: 2017-04-09 18:12:56.000 | 2017-10-12 18:12:57 HD Request # 3 | Error downloading historical Intraday data for YMU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 18:12:57 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMU7 | 2017-10-12 18:12:57 HD Request # 3 | Intraday download COMPLETE for YMU7. Completion time: 0s. Unique request ID: 3 | 2017-10-12 18:12:57 Removed historical data download ID 3 | 2017-10-12 18:12:57 Real-time Intraday chart data file updates started for YMU7 | 2017-10-12 18:12:57 Opened cached Intraday file: C:\SierraChart\Data\YMU7.scid | 2017-10-12 18:12:57 Intraday chart data file opened for YMU7 | 2017-10-12 18:12:57 Delaying start of download for ESU7 | 2017-10-12 18:12:57 SC Data - All Services | Starting real-time market data updates for: GCZ7. ID: 5 | 2017-10-12 18:12:57 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: GCZ7 | 2017-10-12 18:12:57 SC Data - All Services | Requesting security definition data for: GCZ7. ID: 5 | 2017-10-12 18:12:57 Intraday data recording state for symbol GCZ7 is set to download 'Pending'. | 2017-10-12 18:12:57 HD Request # 4 | Downloading Intraday chart data for ESU7 to the file ESU7.scid. Service: scdataallservices | 2017-10-12 18:12:57 HD Request # 4 | Download start date-time: 2017-04-09 18:12:56.000 | 2017-10-12 18:12:57 HD Request # 4 | Error downloading historical Intraday data for ESU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 18:12:57 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESU7 | 2017-10-12 18:12:57 HD Request # 4 | Intraday download COMPLETE for ESU7. Completion time: 0s. Unique request ID: 4 | 2017-10-12 18:12:57 Removed historical data download ID 4 | 2017-10-12 18:12:57 Real-time Intraday chart data file updates started for ESU7 | 2017-10-12 18:12:57 Opened cached Intraday file: C:\SierraChart\Data\ESU7.scid | 2017-10-12 18:12:57 Intraday chart data file opened for ESU7 | 2017-10-12 18:12:57 Delaying start of download for GCZ7 | 2017-10-12 18:12:57 SC Data - All Services | Starting real-time market data updates for: CLV7. ID: 6 | 2017-10-12 18:12:57 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: CLV7 | 2017-10-12 18:12:57 SC Data - All Services | Requesting security definition data for: CLV7. ID: 6 | 2017-10-12 18:12:57 Intraday data recording state for symbol CLV7 is set to download 'Pending'. | 2017-10-12 18:12:57 HD Request # 5 | Downloading Intraday chart data for GCZ7 to the file GCZ7.scid. Service: scdataallservices | 2017-10-12 18:12:57 HD Request # 5 | Download start date-time: 2017-04-09 18:12:56.000 | 2017-10-12 18:12:57 HD Request # 5 | Error downloading historical Intraday data for GCZ7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 18:12:57 HD Request # 5 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCZ7 | 2017-10-12 18:12:57 HD Request # 5 | Intraday download COMPLETE for GCZ7. Completion time: 0s. Unique request ID: 5 | 2017-10-12 18:12:57 Removed historical data download ID 5 | 2017-10-12 18:12:57 Real-time Intraday chart data file updates started for GCZ7 | 2017-10-12 18:12:57 Opened cached Intraday file: C:\SierraChart\Data\GCZ7.scid | 2017-10-12 18:12:57 Intraday chart data file opened for GCZ7 | 2017-10-12 18:12:57 Delaying start of download for CLV7 | 2017-10-12 18:12:57 SC Data - All Services | Starting real-time market data updates for: 6EU7. ID: 7 | 2017-10-12 18:12:57 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: 6EU7 | 2017-10-12 18:12:57 SC Data - All Services | Requesting security definition data for: 6EU7. ID: 7 | 2017-10-12 18:12:57 Intraday data recording state for symbol 6EU7 is set to download 'Pending'. | 2017-10-12 18:12:57 HD Request # 6 | Downloading Intraday chart data for CLV7 to the file CLV7.scid. Service: scdataallservices | 2017-10-12 18:12:57 HD Request # 6 | Download start date-time: 2017-04-09 18:12:56.000 | 2017-10-12 18:12:57 HD Request # 6 | Error downloading historical Intraday data for CLV7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 18:12:57 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLV7 | 2017-10-12 18:12:57 HD Request # 6 | Intraday download COMPLETE for CLV7. Completion time: 0s. Unique request ID: 6 | 2017-10-12 18:12:57 Removed historical data download ID 6 | 2017-10-12 18:12:57 Real-time Intraday chart data file updates started for CLV7 | 2017-10-12 18:12:57 Opened cached Intraday file: C:\SierraChart\Data\CLV7.scid | 2017-10-12 18:12:57 Intraday chart data file opened for CLV7 | 2017-10-12 18:12:57 Delaying start of download for 6EU7 | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NASDAQ. ID: 8 | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NASDAQ. ID: 8 | 2017-10-12 18:12:57 Intraday data recording state for symbol TICK-NASDAQ is set to download 'Pending'. | 2017-10-12 18:12:57 SC Data - All Services | Starting real-time market data updates for: 6JU7. ID: 9 | 2017-10-12 18:12:57 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: 6JU7 | 2017-10-12 18:12:57 SC Data - All Services | Requesting security definition data for: 6JU7. ID: 9 | 2017-10-12 18:12:57 Intraday data recording state for symbol 6JU7 is set to download 'Pending'. | 2017-10-12 18:12:57 HD Request # 7 | Downloading Intraday chart data for 6EU7 to the file 6EU7.scid. Service: scdataallservices | 2017-10-12 18:12:57 HD Request # 7 | Download start date-time: 2017-04-09 18:12:56.000 | 2017-10-12 18:12:57 HD Request # 7 | Error downloading historical Intraday data for 6EU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 18:12:57 HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EU7 | 2017-10-12 18:12:57 HD Request # 7 | Intraday download COMPLETE for 6EU7. Completion time: 0s. Unique request ID: 7 | 2017-10-12 18:12:57 Removed historical data download ID 7 | 2017-10-12 18:12:57 Real-time Intraday chart data file updates started for 6EU7 | 2017-10-12 18:12:57 Opened cached Intraday file: C:\SierraChart\Data\6EU7.scid | 2017-10-12 18:12:57 Intraday chart data file opened for 6EU7 | 2017-10-12 18:12:57 Delaying start of download for 6JU7 | 2017-10-12 18:12:57 SC Data - All Services | Starting real-time market data updates for: RTYU7. ID: 10 | 2017-10-12 18:12:57 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: RTYU7 | 2017-10-12 18:12:57 SC Data - All Services | Requesting security definition data for: RTYU7. ID: 10 | 2017-10-12 18:12:57 Intraday data recording state for symbol RTYU7 is set to download 'Pending'. | 2017-10-12 18:12:57 HD Request # 8 | Downloading Intraday chart data for 6JU7 to the file 6JU7.scid. Service: scdataallservices | 2017-10-12 18:12:57 HD Request # 8 | Download start date-time: 2017-04-09 18:12:56.000 | 2017-10-12 18:12:57 HD Request # 8 | Error downloading historical Intraday data for 6JU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 18:12:57 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6JU7 | 2017-10-12 18:12:57 HD Request # 8 | Intraday download COMPLETE for 6JU7. Completion time: 0s. Unique request ID: 9 | 2017-10-12 18:12:57 Removed historical data download ID 9 | 2017-10-12 18:12:57 Real-time Intraday chart data file updates started for 6JU7 | 2017-10-12 18:12:57 Opened cached Intraday file: C:\SierraChart\Data\6JU7.scid | 2017-10-12 18:12:57 Intraday chart data file opened for 6JU7 | 2017-10-12 18:12:57 Delaying start of download for RTYU7 | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Connected to server. | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Starting socket receive thread. | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Sending Encoding Request to server | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Sending logon request message. | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-TF. ID: 11 | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Requesting security definition data for: TICK-TF. ID: 11 | 2017-10-12 18:12:57 Intraday data recording state for symbol TICK-TF is set to download 'Pending'. | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Received logon response. | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Successfully connected. | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Trading is not supported. | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NASDAQ | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-TF | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Received security definition for symbol TICK-NASDAQ | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2017-10-12 18:12:57 SC DTC Data with Market Depth | Received security definition for symbol TICK-TF | 2017-10-12 18:12:57 Delaying start of download for TICK-NYSE | 2017-10-12 18:12:58 HD Request # 9 | Downloading Intraday chart data for RTYU7 to the file RTYU7.scid. Service: scdataallservices | 2017-10-12 18:13:01 HD Request # 9 | Download start date-time: 2017-04-09 18:13:01.000 | 2017-10-12 18:13:01 HD Request # 9 | Error downloading historical Intraday data for RTYU7. The futures symbol format is invalid. The year must be 2 digits. | 2017-10-12 18:13:01 HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for RTYU7 | 2017-10-12 18:13:01 HD Request # 9 | Intraday download COMPLETE for RTYU7. Completion time: 0s. Unique request ID: 10 | 2017-10-12 18:13:01 Removed historical data download ID 10 | 2017-10-12 18:13:01 Real-time Intraday chart data file updates started for RTYU7 | 2017-10-12 18:13:01 Opened cached Intraday file: C:\SierraChart\Data\RTYU7.scid | 2017-10-12 18:13:01 Intraday chart data file opened for RTYU7 | 2017-10-12 18:13:01 HD Request # 10 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2017-10-12 18:13:02 HD Request # 10 | Download start date-time: 2017-10-12 18:11:13.000 | 2017-10-12 18:13:02 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2017-10-12 18:13:02 Socket (7) | Creating socket. | 2017-10-12 18:13:02 Socket (7) | Connecting to IP: 192.81.56.146. | 2017-10-12 18:13:02 HD Request # 10 | Setting DTC encoding to Binary VLS | 2017-10-12 18:13:02 HD Request # 10 | Sending historical data logon request message. | 2017-10-12 18:13:02 HD Request # 10 | Requesting Intraday data. Start date-time: 2017-10-12 18:11:13. Record interval: 1. Symbol: TICK-NYSE | 2017-10-12 18:13:02 HD Request # 10 | Decompressing data. | 2017-10-12 18:13:02 HD Request # 10 | Receiving Intraday data for TICK-NYSE starting at 2017-10-12 18:11:13 | 2017-10-12 18:13:02 HD Request # 10 | Timestamp of first Intraday data file record written: 2017-10-12 18:11:13 | 2017-10-12 18:13:02 Socket (7) | Initiating close of socket by core. | 2017-10-12 18:13:02 Socket (7) | Shutdown started. Waiting for graceful close. | 2017-10-12 18:13:02 Historical data download thread signaled to stop. | 2017-10-12 18:13:02 HD Request # 10 | Received 110 records from 2017-10-12 18:11:13 to 2017-10-12 18:13:02 (109.0 seconds) and wrote 110 records for TICK-NYSE | 2017-10-12 18:13:02 Added 2 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2017-10-12 18:13:02 HD Request # 10 | Intraday download COMPLETE for TICK-NYSE. Completion time: 1s. Unique request ID: 2 | 2017-10-12 18:13:02 Removed historical data download ID 2 | 2017-10-12 18:13:02 Real-time Intraday chart data file updates started for TICK-NYSE | 2017-10-12 18:13:02 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid | 2017-10-12 18:13:02 Intraday chart data file opened for TICK-NYSE | 2017-10-12 18:13:02 HD Request # 11 | Downloading Intraday chart data for TICK-NASDAQ to the file TICK-NASDAQ.scid. Service: statscalc | 2017-10-12 18:13:02 HD Request # 11 | Download start date-time: 2017-10-12 18:11:13.000 | 2017-10-12 18:13:02 HD Request # 11 | Using server: ds3.sierracharts.com port 10150 | 2017-10-12 18:13:02 Socket (8) | Creating socket. | 2017-10-12 18:13:02 Socket (8) | Connecting to IP: 65.182.172.42. | 2017-10-12 18:13:02 Socket (7) | Socket gracefully closed by remote side. | 2017-10-12 18:13:02 Socket (7) | Closed. | 2017-10-12 18:13:02 HD Request # 11 | Setting DTC encoding to Binary VLS | 2017-10-12 18:13:02 HD Request # 11 | Sending historical data logon request message. | 2017-10-12 18:13:02 HD Request # 11 | Requesting Intraday data. Start date-time: 2017-10-12 18:11:13. Record interval: 1. Symbol: TICK-NASDAQ | 2017-10-12 18:13:02 HD Request # 11 | Decompressing data. | 2017-10-12 18:13:02 HD Request # 11 | Receiving Intraday data for TICK-NASDAQ starting at 2017-10-12 18:11:13 | 2017-10-12 18:13:02 HD Request # 11 | Timestamp of first Intraday data file record written: 2017-10-12 18:11:13 | 2017-10-12 18:13:02 Socket (8) | Initiating close of socket by core. | 2017-10-12 18:13:02 Socket (8) | Shutdown started. Waiting for graceful close. | 2017-10-12 18:13:02 Historical data download thread signaled to stop. | 2017-10-12 18:13:02 HD Request # 11 | Received 110 records from 2017-10-12 18:11:13 to 2017-10-12 18:13:02 (109.0 seconds) and wrote 110 records for TICK-NASDAQ | 2017-10-12 18:13:02 Added 1 Time and Sales records to Intraday data file for TICK-NASDAQ after download. | 2017-10-12 18:13:02 HD Request # 11 | Intraday download COMPLETE for TICK-NASDAQ. Completion time: 0s. Unique request ID: 8 | 2017-10-12 18:13:02 Removed historical data download ID 8 | 2017-10-12 18:13:02 Real-time Intraday chart data file updates started for TICK-NASDAQ | 2017-10-12 18:13:02 Opened cached Intraday file: C:\SierraChart\Data\TICK-NASDAQ.scid | 2017-10-12 18:13:02 Intraday chart data file opened for TICK-NASDAQ | 2017-10-12 18:13:02 HD Request # 12 | Downloading Intraday chart data for TICK-TF to the file TICK-TF.scid. Service: statscalc | 2017-10-12 18:13:02 HD Request # 12 | Download start date-time: 2017-10-12 18:11:13.000 | 2017-10-12 18:13:02 HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2017-10-12 18:13:02 Socket (9) | Creating socket. | 2017-10-12 18:13:02 Socket (9) | Connecting to IP: 192.81.56.146. | 2017-10-12 18:13:02 Socket (8) | Socket gracefully closed by remote side. | 2017-10-12 18:13:02 Socket (8) | Closed. | 2017-10-12 18:13:02 HD Request # 12 | Setting DTC encoding to Binary VLS | 2017-10-12 18:13:02 HD Request # 12 | Sending historical data logon request message. | 2017-10-12 18:13:02 HD Request # 12 | Requesting Intraday data. Start date-time: 2017-10-12 18:11:13. Record interval: 1. Symbol: TICK-TF | 2017-10-12 18:13:02 HD Request # 12 | Decompressing data. | 2017-10-12 18:13:02 HD Request # 12 | Receiving Intraday data for TICK-TF starting at 2017-10-12 18:11:13 | 2017-10-12 18:13:02 HD Request # 12 | Timestamp of first Intraday data file record written: 2017-10-12 18:11:13 | 2017-10-12 18:13:02 Socket (9) | Initiating close of socket by core. | 2017-10-12 18:13:02 Socket (9) | Shutdown started. Waiting for graceful close. | 2017-10-12 18:13:02 Historical data download thread signaled to stop. | 2017-10-12 18:13:02 HD Request # 12 | Received 110 records from 2017-10-12 18:11:13 to 2017-10-12 18:13:02 (109.0 seconds) and wrote 110 records for TICK-TF | 2017-10-12 18:13:02 Added 1 Time and Sales records to Intraday data file for TICK-TF after download. | 2017-10-12 18:13:02 HD Request # 12 | Intraday download COMPLETE for TICK-TF. Completion time: 0s. Unique request ID: 11 | 2017-10-12 18:13:02 Removed historical data download ID 11 | 2017-10-12 18:13:02 Real-time Intraday chart data file updates started for TICK-TF | 2017-10-12 18:13:02 Opened cached Intraday file: C:\SierraChart\Data\TICK-TF.scid | 2017-10-12 18:13:02 Intraday chart data file opened for TICK-TF | 2017-10-12 18:13:02 Socket (9) | Socket gracefully closed by remote side. | 2017-10-12 18:13:03 Socket (9) | Closed. | 2017-10-12 18:13:03 DTC Client socket (6) | Initiating close of socket by core. | 2017-10-12 18:17:56 SC DTC Data with Market Depth | Disconnected from the server. | 2017-10-12 18:17:56 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2017-10-12 18:17:56 SC Data - All Services | Disconnected. | 2017-10-12 18:17:56 SC Data - All Services | Disconnected. | 2017-10-12 18:17:56 Checking for new symbol settings for service code cqg | 2017-10-12 18:17:56 Current selected Data/Trading service: CQG FIX Trading | 2017-10-12 18:17:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-10-12 18:17:56 HTTPS connection to www.sierrachart.com:443 (11) | Creating socket. Using TLS 1.2. | 2017-10-12 18:17:56 HTTPS connection to www.sierrachart.com:443 (11) | Connecting to IP: 204.15.192.108. | 2017-10-12 18:17:56 DTC Client socket (6) | Socket gracefully closed by remote side. | 2017-10-12 18:17:56 DTC Client socket (6) | Closed. | 2017-10-12 18:17:56 Requesting symbol settings for service code cqg. Overwrite = on. | 2017-10-12 18:17:57 Symbol settings received. | 2017-10-12 18:17:57 Processed 1194 symbol settings. | 2017-10-12 18:17:57 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-10-12 18:17:59 CQG FIX socket (12) | Creating socket. Using TLS 1.2. | 2017-10-12 18:17:59 CQG FIX socket (12) | Connecting to IP: 208.48.16.214. | 2017-10-12 18:17:59 CQG FIX: Sending the Logon message. | 2017-10-12 18:17:59 CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2017-10-12 18:17:59 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2017-10-12 18:17:59 CQG FIX socket (12) | Initiating close of socket by core. | 2017-10-12 18:17:59 CQG FIX: Disconnected. | 2017-10-12 18:17:59 CQG FIX socket (12) | Write in progress. Shutdown being delayed. | 2017-10-12 18:17:59 CQG FIX Trading | Disconnected. | 2017-10-12 18:17:59 CQG FIX socket (12) | Write has completed. Shutdown being performed. | 2017-10-12 18:17:59 CQG FIX socket (12) | Shutdown started. Waiting for graceful close. | 2017-10-12 18:17:59 CQG FIX socket (12) | Socket gracefully closed by remote side. | 2017-10-12 18:18:00 CQG FIX socket (12) | Closed. | 2017-10-12 18:18:00 HTTPS connection to www.sierrachart.com:443 (11) | Socket gracefully closed by remote side. | 2017-10-12 18:18:02 HTTPS connection to www.sierrachart.com:443 (11) | Received socket Close event. | 2017-10-12 18:18:02 HTTPS connection to www.sierrachart.com:443 (11) | Initiating close of socket by core. | 2017-10-12 18:18:02 HTTPS connection to www.sierrachart.com:443 (11) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2017-10-12 18:18:02 HTTPS connection to www.sierrachart.com:443 (11) | Closed. | 2017-10-12 18:18:02 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2017-10-12 18:21:02 CQG FIX socket (14) | Creating socket. Using TLS 1.2. | 2017-10-12 18:21:02 CQG FIX socket (14) | Connecting to IP: 208.48.16.214. | 2017-10-12 18:21:02 CQG FIX: Sending the Logon message. | 2017-10-12 18:21:02 CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2017-10-12 18:21:02 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2017-10-12 18:21:02 CQG FIX socket (14) | Initiating close of socket by core. | 2017-10-12 18:21:02 CQG FIX: Disconnected. | 2017-10-12 18:21:02 CQG FIX socket (14) | Write in progress. Shutdown being delayed. | 2017-10-12 18:21:02 CQG FIX Trading | Disconnected. | 2017-10-12 18:21:02 CQG FIX socket (14) | Write has completed. Shutdown being performed. | 2017-10-12 18:21:02 CQG FIX socket (14) | Shutdown started. Waiting for graceful close. | 2017-10-12 18:21:02 CQG FIX socket (14) | Socket gracefully closed by remote side. | 2017-10-12 18:21:02 CQG FIX socket (14) | Closed. | 2017-10-12 18:21:02 |
[2017-10-13 02:52:39] |
In the case of CQG, the symbols are different. You need to follow through the instructions here to change the symbols of the charts to CQG symbols: Data/Trading Service Connection and Symbol Issues: 1.3. Symbols The other problem is this: CQG FIX: Received a Logout message. Text = UserName does not exist. Contact Customer Support for assistance. | 2017-10-12 18:17:59 Refer to this section here about this: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#CommonErrorMessage_UserNameDoesNotExist Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
