Date/Time: Fri, 10 Jan 2025 16:37:29 +0000
Cannot connect to Gain Capital datafeed
View Count: 828
[2016-09-27 07:50:16]
User163356 - Posts: 5
I've been using SC to connect to my S5/Gain Capital trading account for many months with no problems until yesterday. I still cannot connect to GC today. I noticed they have changed their Server name as my old Server Name was not "prod.gainfutures.com. I've switched it to the current Server name but still cannot connect.
I have sent a copy of my message log to Sierra Chart.
Can you help?
[2016-09-27 07:56:25]
Reading Internal Order ID file. | 2016-09-27 03:40:52
Reading Trade Orders file. | 2016-09-27 03:40:52
Reading Trade Positions file. | 2016-09-27 03:40:52
Software version: 1460 | 2016-09-27 03:40:52
Uses New Spreadsheets | 2016-09-27 03:40:52
Usage end date: 2017-07-11 | 2016-09-27 03:40:52
Enabled for: Advanced Features. | 2016-09-27 03:40:52
Enabled for: Advanced Features 2. | 2016-09-27 03:40:52
Enabled for: Sierra Chart Historical Data Service. | 2016-09-27 03:40:52
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-09-27 03:40:52
Current selected Data/Trading service: GAIN Capital/OEC | 2016-09-27 03:40:52
Chart Update Interval: 500 | 2016-09-27 03:40:52
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-09-27 03:40:52
2016-09-27 15:40:56 Local computer time | 2016-09-27 03:40:52
2016-09-27 07:40:56 Local computer time in UTC | 2016-09-27 03:40:52
2016-09-27 03:40:56 Local computer time in SC Time Zone | 2016-09-27 03:40:52
2016-09-27 07:41:12 Server time in UTC | 2016-09-27 03:40:52
Local computer UTC time and Server UTC time difference: 17 seconds. | 2016-09-27 03:40:52
Program path: C:\SierraChartS5\ | 2016-09-27 03:40:52
Data Files path: D:\OneDrive\SierraChart1\ | 2016-09-27 03:40:52
OS Version Number: 6.2 | 2016-09-27 03:40:52
Locale Setting: C | 2016-09-27 03:40:52
GainCapital FIX Trading: Sent heartbeat to server. | 2016-09-27 03:44:47
Service connection timed out. Will disconnect and retry. | 2016-09-27 03:45:17 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:45:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:45:17
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:45:17
GainCapital FIX Trading: Sending a Logout message. | 2016-09-27 03:45:17
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:45:17
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:45:17
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:45:20
GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-09-27 03:45:20 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:45:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:45:20
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:45:20
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:45:20
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:45:20
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-09-27 03:45:21 *
GainCapital FIX Trading socket (8) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-27 03:45:21
GainCapital FIX Trading socket (8) | SSL has been shut down. | 2016-09-27 03:45:21
GainCapital FIX Trading socket (8) | SSL object has been freed. SSL state is now disconnected. | 2016-09-27 03:45:21
GainCapital FIX Trading socket (8) | Shutdown and closed. | 2016-09-27 03:45:21
GAIN Capital/OEC | Disconnected from the trading server. | 2016-09-27 03:45:21
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:45:23
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-09-27 03:45:23
GainCapital FIX Trading socket (10) | Connected. | 2016-09-27 03:45:23
GainCapital FIX Trading socket (10) | Starting TLS 1.2 connection. | 2016-09-27 03:45:23
GainCapital FIX Trading socket (10) | SSL connection established. | 2016-09-27 03:45:23
GainCapital FIX Trading: Sending the Logon message. | 2016-09-27 03:45:23
GainCapital FIX Trading: Sent heartbeat to server. | 2016-09-27 03:45:53
Service connection timed out. Will disconnect and retry. | 2016-09-27 03:46:23 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:46:23
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:46:23
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:46:23
GainCapital FIX Trading: Sending a Logout message. | 2016-09-27 03:46:23
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:46:23
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:46:23
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:46:26
GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-09-27 03:46:26 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:46:26
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:46:26
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:46:26
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:46:26
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:46:26
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-09-27 03:46:27 *
GainCapital FIX Trading socket (10) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-27 03:46:27
GainCapital FIX Trading socket (10) | SSL has been shut down. | 2016-09-27 03:46:27
GainCapital FIX Trading socket (10) | SSL object has been freed. SSL state is now disconnected. | 2016-09-27 03:46:27
GainCapital FIX Trading socket (10) | Shutdown and closed. | 2016-09-27 03:46:27
GAIN Capital/OEC | Disconnected from the trading server. | 2016-09-27 03:46:27
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:46:29
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-09-27 03:46:29
GainCapital FIX Trading socket (11) | Connected. | 2016-09-27 03:46:29
GainCapital FIX Trading socket (11) | Starting TLS 1.2 connection. | 2016-09-27 03:46:29
GainCapital FIX Trading socket (11) | SSL connection established. | 2016-09-27 03:46:29
GainCapital FIX Trading: Sending the Logon message. | 2016-09-27 03:46:29
GainCapital FIX Trading: Sent heartbeat to server. | 2016-09-27 03:46:59
Service connection timed out. Will disconnect and retry. | 2016-09-27 03:47:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:47:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:47:29
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:47:29
GainCapital FIX Trading: Sending a Logout message. | 2016-09-27 03:47:29
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:47:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:47:29
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:47:32
GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-09-27 03:47:32 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:47:32
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:47:32
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:47:32
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:47:32
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:47:32
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-09-27 03:47:33 *
GainCapital FIX Trading socket (11) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-27 03:47:33
GainCapital FIX Trading socket (11) | SSL has been shut down. | 2016-09-27 03:47:33
GainCapital FIX Trading socket (11) | SSL object has been freed. SSL state is now disconnected. | 2016-09-27 03:47:33
GainCapital FIX Trading socket (11) | Shutdown and closed. | 2016-09-27 03:47:33
GAIN Capital/OEC | Disconnected from the trading server. | 2016-09-27 03:47:33
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:47:35
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-09-27 03:47:35
GainCapital FIX Trading socket (13) | Connected. | 2016-09-27 03:47:35
GainCapital FIX Trading socket (13) | Starting TLS 1.2 connection. | 2016-09-27 03:47:35
GainCapital FIX Trading socket (13) | SSL connection established. | 2016-09-27 03:47:35
GainCapital FIX Trading: Sending the Logon message. | 2016-09-27 03:47:36
GainCapital FIX Trading: Sent heartbeat to server. | 2016-09-27 03:48:06
Service connection timed out. Will disconnect and retry. | 2016-09-27 03:48:35 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:48:35
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:48:35
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:48:35
GainCapital FIX Trading: Sending a Logout message. | 2016-09-27 03:48:35
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:48:35
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:48:35
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:48:38
GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-09-27 03:48:38 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:48:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:48:38
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:48:38
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:48:38
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:48:38
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-09-27 03:48:39 *
GainCapital FIX Trading socket (13) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-27 03:48:39
GainCapital FIX Trading socket (13) | SSL has been shut down. | 2016-09-27 03:48:39
GainCapital FIX Trading socket (13) | SSL object has been freed. SSL state is now disconnected. | 2016-09-27 03:48:39
GainCapital FIX Trading socket (13) | Shutdown and closed. | 2016-09-27 03:48:39
GAIN Capital/OEC | Disconnected from the trading server. | 2016-09-27 03:48:39
The above has been sent to support. | 2016-09-27 03:48:39 *
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-09-27 03:48:39
HTTP connection to www.sierrachart.com:80 (14) | Connected. | 2016-09-27 03:48:40
Sending of the message log was completed. Please read the response that was received. The response was saved to D:\OneDrive\SierraChart1\MessageLogAnalysis.htm | 2016-09-27 03:48:41
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:48:41
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-09-27 03:48:41
GainCapital FIX Trading socket (15) | Connected. | 2016-09-27 03:48:41
GainCapital FIX Trading socket (15) | Starting TLS 1.2 connection. | 2016-09-27 03:48:41
GainCapital FIX Trading socket (15) | SSL connection established. | 2016-09-27 03:48:41
GainCapital FIX Trading: Sending the Logon message. | 2016-09-27 03:48:42
HTTP connection to www.sierrachart.com:80 (14) | Closed. No error. | 2016-09-27 03:48:46
HTTP connection to www.sierrachart.com:80 (14) | Shutdown and closed. | 2016-09-27 03:48:46
GainCapital FIX Trading: Sent heartbeat to server. | 2016-09-27 03:49:12
Service connection timed out. Will disconnect and retry. | 2016-09-27 03:49:41 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:49:41
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:49:41
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:49:41
GainCapital FIX Trading: Sending a Logout message. | 2016-09-27 03:49:41
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:49:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:49:41
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:49:44
GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-09-27 03:49:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:49:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:49:44
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:49:44
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:49:44
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:49:44
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-09-27 03:49:45 *
GainCapital FIX Trading socket (15) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-27 03:49:45
GainCapital FIX Trading socket (15) | SSL has been shut down. | 2016-09-27 03:49:45
GainCapital FIX Trading socket (15) | SSL object has been freed. SSL state is now disconnected. | 2016-09-27 03:49:45
GainCapital FIX Trading socket (15) | Shutdown and closed. | 2016-09-27 03:49:45
GAIN Capital/OEC | Disconnected from the trading server. | 2016-09-27 03:49:45
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:49:47
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-09-27 03:49:47
GainCapital FIX Trading socket (17) | Connected. | 2016-09-27 03:49:47
GainCapital FIX Trading socket (17) | Starting TLS 1.2 connection. | 2016-09-27 03:49:47
GainCapital FIX Trading socket (17) | SSL connection established. | 2016-09-27 03:49:47
GainCapital FIX Trading: Sending the Logon message. | 2016-09-27 03:49:48
GainCapital FIX Trading: Sent heartbeat to server. | 2016-09-27 03:50:18
Service connection timed out. Will disconnect and retry. | 2016-09-27 03:50:47 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:50:47
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:50:47
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:50:47
GainCapital FIX Trading: Sending a Logout message. | 2016-09-27 03:50:47
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:50:47
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:50:47
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:50:50
GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-09-27 03:50:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:50:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:50:50
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:50:50
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:50:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:50:50
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-09-27 03:50:51 *
GainCapital FIX Trading socket (17) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-27 03:50:51
GainCapital FIX Trading socket (17) | SSL has been shut down. | 2016-09-27 03:50:51
GainCapital FIX Trading socket (17) | SSL object has been freed. SSL state is now disconnected. | 2016-09-27 03:50:51
GainCapital FIX Trading socket (17) | Shutdown and closed. | 2016-09-27 03:50:51
GAIN Capital/OEC | Disconnected from the trading server. | 2016-09-27 03:50:51
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:50:53
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-09-27 03:50:53
GainCapital FIX Trading socket (18) | Connected. | 2016-09-27 03:50:53
GainCapital FIX Trading socket (18) | Starting TLS 1.2 connection. | 2016-09-27 03:50:53
GainCapital FIX Trading socket (18) | SSL connection established. | 2016-09-27 03:50:53
GainCapital FIX Trading: Sending the Logon message. | 2016-09-27 03:50:54
GainCapital FIX Trading: Sent heartbeat to server. | 2016-09-27 03:51:24
Service connection timed out. Will disconnect and retry. | 2016-09-27 03:51:53 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:51:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:51:53
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:51:53
GainCapital FIX Trading: Sending a Logout message. | 2016-09-27 03:51:53
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:51:53
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:51:53
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:51:56
GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-09-27 03:51:56 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:51:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:51:56
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:51:56
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:51:56
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:51:56
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-09-27 03:51:57 *
GainCapital FIX Trading socket (18) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-27 03:51:57
GainCapital FIX Trading socket (18) | SSL has been shut down. | 2016-09-27 03:51:57
GainCapital FIX Trading socket (18) | SSL object has been freed. SSL state is now disconnected. | 2016-09-27 03:51:57
GainCapital FIX Trading socket (18) | Shutdown and closed. | 2016-09-27 03:51:57
GAIN Capital/OEC | Disconnected from the trading server. | 2016-09-27 03:51:57
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:51:59
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-09-27 03:51:59
GainCapital FIX Trading socket (20) | Connected. | 2016-09-27 03:51:59
GainCapital FIX Trading socket (20) | Starting TLS 1.2 connection. | 2016-09-27 03:51:59
GainCapital FIX Trading socket (20) | SSL connection established. | 2016-09-27 03:51:59
GainCapital FIX Trading: Sending the Logon message. | 2016-09-27 03:52:00
GainCapital FIX Trading: Sent heartbeat to server. | 2016-09-27 03:52:30
Service connection timed out. Will disconnect and retry. | 2016-09-27 03:52:59 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:52:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:52:59
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:52:59
GainCapital FIX Trading: Sending a Logout message. | 2016-09-27 03:52:59
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:52:59
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:52:59
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:53:02
GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-09-27 03:53:02 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-27 03:53:02
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-27 03:53:02
GainCapital FIX Trading: DisconnectFIX called. | 2016-09-27 03:53:02
GAIN Capital/OEC | Disconnected. | 2016-09-27 03:53:02
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-27 03:53:02
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-09-27 03:53:03 *
GainCapital FIX Trading socket (20) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-27 03:53:03
GainCapital FIX Trading socket (20) | SSL has been shut down. | 2016-09-27 03:53:03
GainCapital FIX Trading socket (20) | SSL object has been freed. SSL state is now disconnected. | 2016-09-27 03:53:03
GainCapital FIX Trading socket (20) | Shutdown and closed. | 2016-09-27 03:53:03
GAIN Capital/OEC | Disconnected from the trading server. | 2016-09-27 03:53:03
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-09-27 03:53:05
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-09-27 03:53:05
GainCapital FIX Trading socket (22) | Connected. | 2016-09-27 03:53:05
GainCapital FIX Trading socket (22) | Starting TLS 1.2 connection. | 2016-09-27 03:53:05
GainCapital FIX Trading socket (22) | SSL connection established. | 2016-09-27 03:53:05
GainCapital FIX Trading: Sending the Logon message. | 2016-09-27 03:53:06
[2016-09-27 08:07:02]
These are the relevant messages:
Another one of our users had the same problem last week. This is the correct address: prod.gainfutures.com.
Contact us through an Account Support Ticket:
https://www.sierrachart.com/usercp.php?page=SupportTickets
Give us your Gain Capital username and we will contact them about this.
Date Time Of Last Edit: 2016-09-27 08:07:29
[2016-09-27 16:51:46]
This is what we received from Gain Capital:
Thank you for your email. We are aware of the issue and have rolled out a fix to SIM. If client needs market data and does not need to trade, we can have the user connect to SIM until a fix to PROD is released. If the customer needs to trade, but cannot connect to PROD with Sierra and the server does not respond to the user, they can connect in OEC Trader.
Unfortunately, the user cannot connect to PROD unless we restart the FIX Order Server. This would drop all other FIX users who may not be having a problem at all. We would prefer not to affect all other users for one person.
So if you require a simulation account with Gain Capital, contact them and explain the problem you are having. Let us know if you need more help.
[2016-09-28 10:31:41]
Can you let me the name of the person in Gain Capital you got that email from so that I can ask my broker, S5, to contact him/her.
When did he/she say that the fix to their PROD will be released? I would need to trade.
[2016-09-28 10:53:38]
They did not give a date about the release to their production server.
The name is:
Mark Nixon
GAIN Capital Futures
