Date/Time: Tue, 15 Apr 2025 14:03:59 +0000
Level 2 data on Dom not loading
View Count: 78
[2025-04-02 06:23:22] |
User518718 - Posts: 10 |
Hi, I have created new DOMs and my level 2 data is not showing. Cany you kindly advise why this may be? I have done everything on the support board to try and fix. Please see message log below 2025-04-02 07:03:20.554 | Trade activity files set size: 115 2025-04-02 07:03:20.800 | Reading Internal Order ID file. 2025-04-02 07:03:20.822 | Reading Trade Orders file. 2025-04-02 07:03:20.823 | Reading Trade Positions file. 2025-04-02 07:03:20.823 | Reading Trade Account Data files. 2025-04-02 07:03:20.843 | Software version: 2661 64-bit 2025-04-02 07:03:20.843 | Primary Thread ID: 7208 2025-04-02 07:03:20.843 | Usage end date: 2025-04-04 2025-04-02 07:03:20.843 | Enabled for: Advanced Features 2. 2025-04-02 07:03:20.843 | Enabled for: Sierra Chart Historical Data Service. 2025-04-02 07:03:20.843 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-04-02 07:03:20.843 | Enabled for: Delayed Denali Exchange Data Feed. 2025-04-02 07:03:20.843 | Enabled for exchange2: CME (Trading Account Required) 2025-04-02 07:03:20.843 | Enabled for exchange2: CBOT (Trading Account Required) 2025-04-02 07:03:20.843 | Enabled for exchange2: COMEX (Trading Account Required) 2025-04-02 07:03:20.843 | Enabled for exchange2: NYMEX (Trading Account Required) 2025-04-02 07:03:20.843 | Enabled for exchange2: EUREX EOBI 2025-04-02 07:03:20.843 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-04-02 07:03:20.843 | Current selected Data/Trading service: DTC - Sub Instance 2025-04-02 07:03:20.843 | Custom symbol settings values: enabled 2025-04-02 07:03:20.843 | Chart Update Interval: 1000 2025-04-02 07:03:20.843 | Intraday Data Storage Time Unit: 0 2025-04-02 07:03:20.843 | Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) 2025-04-02 07:03:20.843 | 2025-04-02 06:03:20 Local computer time in UTC 2025-04-02 07:03:20.843 | 2025-04-02 07:03:20 Local computer time in SC Time Zone 2025-04-02 07:03:20.843 | 2025-04-02 06:03:18 Server time in UTC 2025-04-02 07:03:20.843 | Local computer UTC time and Server UTC time difference: 1 seconds. 2025-04-02 07:03:20.843 | Program path: E:\SierraChart\SierraChartInstance_5\ 2025-04-02 07:03:20.843 | Data Files path: E:\SierraChart\SierraChartInstance_5\Data\ 2025-04-02 07:03:20.843 | OS Version Number: 10.0 2025-04-02 07:03:20.843 | Locale Setting: C 2025-04-02 07:03:20.843 | DLLs: CustomSwingHighLow2_64 (1).dll, CustomSwingHighLow2_64.dll, CustomSwingHighLow_64.dll, UserContributedStudies_64.dll 2025-04-02 07:03:20.843 | Allowed protected custom studies: 2025-04-02 07:03:20.843 | Crash reporter started: true 2025-04-02 07:03:20.843 | 2025-04-02 07:03:20.903 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2025-04-02 07:03:20.945 | Performing login for updated account information. 2025-04-02 07:03:21.028 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2025-04-02 07:03:21.028 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2025-04-02 07:03:22.026 | Successfully processed Sierra Chart account data. 2025-04-02 07:03:22.026 | Requested user files to download. | Number times message added: 1 2025-04-02 07:03:25.368 | 2025-04-02 07:03:25.378 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2025-04-02 07:03:25.378 | DTC Client socket (1) | Creating socket. 2025-04-02 07:03:25.378 | DTC Client socket (1) | New receive buffer size: 0 2025-04-02 07:03:25.379 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2025-04-02 07:03:25.390 | DTC - Sub Instance | Network connection to server complete. 2025-04-02 07:03:25.390 | DTC - Sub Instance | Starting socket receive thread. 2025-04-02 07:03:25.390 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2025-04-02 07:03:25.391 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2025-04-02 07:03:25.391 | DTC - Sub Instance | Sending logon request message. 2025-04-02 07:03:25.391 | DTC - Sub Instance | Received logon response. 2025-04-02 07:03:25.391 | DTC - Sub Instance | Server Name: SC DTC Server. Build=50860M. 2025-04-02 07:03:25.391 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2025-04-02 07:03:25.391 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg. 2025-04-02 07:03:25.391 | DTC - Sub Instance | Trading is supported. 2025-04-02 07:03:25.391 | DTC - Sub Instance | Order cancel and replace is supported. 2025-04-02 07:03:25.391 | DTC - Sub Instance | OCO Orders supported. 2025-04-02 07:03:25.391 | DTC - Sub Instance | Bracket Orders supported. 2025-04-02 07:03:25.391 | DTC - Sub Instance | MarketDepthIsSupported: 1 2025-04-02 07:03:25.391 | DTC - Sub Instance | Connected to server complete. 2025-04-02 07:03:25.392 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-04-02 07:03:25.392 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. 2025-04-02 07:03:26.671 | Symbol settings MD5 received. Request ID: 1. 2025-04-02 07:03:26.671 | Symbol settings are up-to-date for cqg. 2025-04-02 07:03:28.632 | Files to Open on Startup | File does not exist: E:\SierraChart\SierraChartInstance_5\Data\Spreads & Currencies.Cht 2025-04-02 07:04:33.937 | Loading DLL: E:\SierraChart\SierraChartInstance_5\Data\CustomSwingHighLow.dll (CustomSwingHighLow_64.dll). Handle: 7ff8315d0000 2025-04-02 07:04:33.978 | F.US.GCEM25 [CBV] 60 Min #10 | Reloading chart. 2025-04-02 07:04:34.059 | Starting DelayedDownloadMonitoringTimer 2025-04-02 07:04:34.059 | Starting HDTimeoutTimer 2025-04-02 07:04:34.059 | Added historical Intraday data request for F.US.GCEM25 to the queue. 2025-04-02 07:04:34.068 | Triggering next historical data download in queue. 2025-04-02 07:04:34.080 | F.US.GCEM25 [CBV] 60 Min #10 | Performing continuous chart historical Daily data download for symbol F.US.GCEM25 starting at last date in file. 2025-04-02 07:04:34.080 | Added historical Daily data request for F.US.GCEM25 to the queue. 2025-04-02 07:04:34.125 | F.US.GCEM25 [CBV] 60 Min #10 | Waiting for historical downloads to complete with the IDs: 1, 2, 2025-04-02 07:04:34.177 | F.US.GCEM25 [CBV] 5 Min #11 | Reloading chart. 2025-04-02 07:04:34.189 | F.US.GCEM25 [CBV] 5 Min #11 | Waiting for historical downloads to complete with the IDs: 1, 2, 2025-04-02 07:04:34.234 | F.US.GCEM25 [CB] 1 Min #8 | Reloading chart. 2025-04-02 07:04:34.245 | F.US.GCEM25 [CB] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2, 2025-04-02 07:04:34.289 | F.US.EPM25 [CBV] 60 Min #24 | Reloading chart. 2025-04-02 07:04:34.361 | Added historical Intraday data request for F.US.EPM25 to the queue. 2025-04-02 07:04:34.374 | F.US.EPM25 [CBV] 60 Min #24 | Performing continuous chart historical Daily data download for symbol F.US.EPM25 starting at last date in file. 2025-04-02 07:04:34.374 | Added historical Daily data request for F.US.EPM25 to the queue. 2025-04-02 07:04:34.412 | F.US.EPM25 [CBV] 60 Min #24 | Waiting for historical downloads to complete with the IDs: 3, 4, 2025-04-02 07:04:34.458 | F.US.EPM25 [CBV] 5 Min #23 | Reloading chart. 2025-04-02 07:04:34.474 | F.US.EPM25 [CBV] 5 Min #23 | Waiting for historical downloads to complete with the IDs: 3, 4, 2025-04-02 07:04:34.522 | F.US.EPM25 [CB] 1 Min #22 | Reloading chart. 2025-04-02 07:04:34.526 | F.US.EPM25 [CB] 1 Min #22 | Waiting for historical downloads to complete with the IDs: 3, 4, 2025-04-02 07:04:34.593 | F.US.EU6M25 [CBV] 60 Min #2 | Reloading chart. 2025-04-02 07:04:34.657 | Added historical Intraday data request for F.US.EU6M25 to the queue. 2025-04-02 07:04:34.670 | F.US.EU6M25 [CBV] 60 Min #2 | Performing continuous chart historical Daily data download for symbol F.US.EU6M25 starting at last date in file. 2025-04-02 07:04:34.670 | Added historical Daily data request for F.US.EU6M25 to the queue. 2025-04-02 07:04:34.700 | F.US.EU6M25 [CBV] 60 Min #2 | Waiting for historical downloads to complete with the IDs: 5, 6, 2025-04-02 07:04:34.782 | F.US.EU6M25 [CBV] 5 Min #3 | Reloading chart. 2025-04-02 07:04:34.796 | F.US.EU6M25 [CBV] 5 Min #3 | Waiting for historical downloads to complete with the IDs: 5, 6, 2025-04-02 07:04:34.842 | F.US.EU6M25 [CB] 1 Min #5 | Reloading chart. 2025-04-02 07:04:34.846 | F.US.EU6M25 [CB] 1 Min #5 | Waiting for historical downloads to complete with the IDs: 5, 6, 2025-04-02 07:04:34.906 | F.US.BP6M25 [CBV] 60 Min #6 | Reloading chart. 2025-04-02 07:04:34.969 | Added historical Intraday data request for F.US.BP6M25 to the queue. 2025-04-02 07:04:34.980 | F.US.BP6M25 [CBV] 60 Min #6 | Performing continuous chart historical Daily data download for symbol F.US.BP6M25 starting at last date in file. 2025-04-02 07:04:34.980 | Added historical Daily data request for F.US.BP6M25 to the queue. 2025-04-02 07:04:35.009 | F.US.BP6M25 [CBV] 60 Min #6 | Waiting for historical downloads to complete with the IDs: 7, 8, 2025-04-02 07:04:35.070 | F.US.BP6M25 [CBV] 5 Min #7 | Reloading chart. 2025-04-02 07:04:35.085 | F.US.BP6M25 [CBV] 5 Min #7 | Waiting for historical downloads to complete with the IDs: 7, 8, 2025-04-02 07:04:35.139 | F.US.BP6M25 [CB] 1 Min #16 | Reloading chart. 2025-04-02 07:04:35.142 | F.US.BP6M25 [CB] 1 Min #16 | Waiting for historical downloads to complete with the IDs: 7, 8, 2025-04-02 07:04:35.213 | F.US.ENQM25 [CBV] 60 Min #1 | Reloading chart. 2025-04-02 07:04:35.278 | Added historical Intraday data request for F.US.ENQM25 to the queue. 2025-04-02 07:04:35.290 | F.US.ENQM25 [CBV] 60 Min #1 | Performing continuous chart historical Daily data download for symbol F.US.ENQM25 starting at last date in file. 2025-04-02 07:04:35.290 | Added historical Daily data request for F.US.ENQM25 to the queue. 2025-04-02 07:04:35.328 | F.US.ENQM25 [CBV] 60 Min #1 | Waiting for historical downloads to complete with the IDs: 9, 10, 2025-04-02 07:04:35.383 | F.US.ENQM25 [CBV] 5 Min #9 | Reloading chart. 2025-04-02 07:04:35.400 | F.US.ENQM25 [CBV] 5 Min #9 | Waiting for historical downloads to complete with the IDs: 9, 10, 2025-04-02 07:04:35.456 | F.US.ENQM25 [CB] 1 Min #4 | Reloading chart. 2025-04-02 07:04:35.460 | F.US.ENQM25 [CB] 1 Min #4 | Waiting for historical downloads to complete with the IDs: 9, 10, 2025-04-02 07:04:35.524 | F.US.EPM25 [CBV] 60 Min #21 | Reloading chart. 2025-04-02 07:04:35.565 | F.US.EPM25 [CBV] 60 Min #21 | Waiting for historical downloads to complete with the IDs: 3, 4, 2025-04-02 07:04:35.621 | F.US.EPM25 [CBV] 5 Min #20 | Reloading chart. 2025-04-02 07:04:35.638 | F.US.EPM25 [CBV] 5 Min #20 | Waiting for historical downloads to complete with the IDs: 3, 4, 2025-04-02 07:04:35.695 | F.US.EPM25 [CB] 1 Min #19 | Reloading chart. 2025-04-02 07:04:35.699 | F.US.EPM25 [CB] 1 Min #19 | Waiting for historical downloads to complete with the IDs: 3, 4, 2025-04-02 07:04:35.762 | F.US.MCLEK25 [CBV] 60 Min #14 | Reloading chart. 2025-04-02 07:04:35.970 | Added historical Intraday data request for F.US.MCLEK25 to the queue. 2025-04-02 07:04:35.978 | F.US.MCLEK25 [CBV] 60 Min #14 | Performing continuous chart historical Daily data download for symbol F.US.MCLEK25 starting at last date in file. 2025-04-02 07:04:35.978 | Added historical Daily data request for F.US.MCLEK25 to the queue. 2025-04-02 07:04:36.018 | F.US.MCLEK25 [CBV] 60 Min #14 | Waiting for historical downloads to complete with the IDs: 11, 12, 2025-04-02 07:04:36.068 | F.US.MCLEK25 [CBV] 5 Min #15 | Reloading chart. 2025-04-02 07:04:36.080 | F.US.MCLEK25 [CBV] 5 Min #15 | Waiting for historical downloads to complete with the IDs: 11, 12, 2025-04-02 07:04:36.133 | F.US.MCLEK25 [CB] 1 Min #12 | Reloading chart. 2025-04-02 07:04:36.146 | F.US.MCLEK25 [CB] 1 Min #12 | Waiting for historical downloads to complete with the IDs: 11, 12, 2025-04-02 07:04:36.204 | F.US.MBTJ25 [CBV] 60 Min #18 | Reloading chart. 2025-04-02 07:04:36.268 | Added historical Intraday data request for F.US.MBTV24 to the queue. 2025-04-02 07:04:36.278 | F.US.MBTJ25 [CBV] 60 Min #18 | Performing continuous chart historical Daily data download for symbol F.US.MBTV24 starting at last date in file. 2025-04-02 07:04:36.278 | Added historical Daily data request for F.US.MBTV24 to the queue. 2025-04-02 07:04:36.368 | F.US.MBTJ25 [CBV] 60 Min #18 | Performing continuous chart historical Daily data download for symbol F.US.MBTH25 starting at last date in file. 2025-04-02 07:04:36.368 | Added historical Daily data request for F.US.MBTH25 to the queue. 2025-04-02 07:04:36.369 | Added historical Intraday data request for F.US.MBTJ25 to the queue. 2025-04-02 07:04:36.378 | F.US.MBTJ25 [CBV] 60 Min #18 | Performing continuous chart historical Daily data download for symbol F.US.MBTJ25 starting at last date in file. 2025-04-02 07:04:36.378 | Added historical Daily data request for F.US.MBTJ25 to the queue. 2025-04-02 07:04:36.417 | F.US.MBTJ25 [CBV] 60 Min #18 | Waiting for historical downloads to complete with the IDs: 13, 14, 15, 16, 17, 2025-04-02 07:04:36.471 | F.US.MBTJ25 [CBV] 5 Min #17 | Reloading chart. 2025-04-02 07:04:36.476 | F.US.MBTJ25 [CBV] 5 Min #17 | Waiting for historical downloads to complete with the IDs: 15, 16, 17, 2025-04-02 07:04:36.526 | F.US.MBTJ25 [CB] 1 Min #13 | Reloading chart. 2025-04-02 07:04:36.529 | F.US.MBTJ25 [CB] 1 Min #13 | Waiting for historical downloads to complete with the IDs: 16, 17, 2025-04-02 07:04:36.566 | Using symbol data fast lookup vector 2025-04-02 07:04:36.567 | HD Request # 1 | Downloading Intraday chart data for F.US.GCEM25 to the file F.US.GCEM25.scid. Service: comex 2025-04-02 07:04:36.567 | HD Request # 1 | Download start date-time: 2025-04-02 06:56:59.000000. File last date-time: 2025-04-02 06:56:59.524000 2025-04-02 07:04:36.567 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149 2025-04-02 07:04:36.567 | Socket (2) | Creating socket. 2025-04-02 07:04:36.567 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:36.567 | Socket (2) | Connecting to IP: 67.214.125.5. 2025-04-02 07:04:36.774 | HD Request # 1 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:36.774 | HD Request # 1 | Sending historical data logon request message. 2025-04-02 07:04:36.916 | DTC - Sub Instance | Starting real-time market data updates for: F.US.BP6M25. ID: 2 Service code: cqg 2025-04-02 07:04:36.916 | DTC - Sub Instance | Requesting security definition data for: F.US.BP6M25. ID: 2 2025-04-02 07:04:36.916 | Requesting market depth updates for: F.US.BP6M25 if supported. NumLevels=1400 2025-04-02 07:04:36.916 | DTC - Sub Instance | Starting real-time market data updates for: F.US.ENQM25. ID: 3 Service code: cqg 2025-04-02 07:04:36.916 | DTC - Sub Instance | Requesting security definition data for: F.US.ENQM25. ID: 3 2025-04-02 07:04:36.916 | Requesting market depth updates for: F.US.ENQM25 if supported. NumLevels=1400 2025-04-02 07:04:36.916 | DTC - Sub Instance | Starting real-time market data updates for: F.US.EPM25. ID: 4 Service code: cqg 2025-04-02 07:04:36.916 | DTC - Sub Instance | Requesting security definition data for: F.US.EPM25. ID: 4 2025-04-02 07:04:36.916 | Requesting market depth updates for: F.US.EPM25 if supported. NumLevels=1400 2025-04-02 07:04:36.916 | DTC - Sub Instance | Starting real-time market data updates for: F.US.EU6M25. ID: 5 Service code: cqg 2025-04-02 07:04:36.916 | DTC - Sub Instance | Requesting security definition data for: F.US.EU6M25. ID: 5 2025-04-02 07:04:36.916 | Requesting market depth updates for: F.US.EU6M25 if supported. NumLevels=1400 2025-04-02 07:04:36.916 | DTC - Sub Instance | Starting real-time market data updates for: F.US.GCEM25. ID: 1 Service code: cqg 2025-04-02 07:04:36.916 | DTC - Sub Instance | Requesting security definition data for: F.US.GCEM25. ID: 1 2025-04-02 07:04:36.916 | Requesting market depth updates for: F.US.GCEM25 if supported. NumLevels=1400 2025-04-02 07:04:36.916 | DTC - Sub Instance | Starting real-time market data updates for: F.US.MBTJ25. ID: 6 Service code: cqg 2025-04-02 07:04:36.916 | DTC - Sub Instance | Requesting security definition data for: F.US.MBTJ25. ID: 6 2025-04-02 07:04:36.916 | Requesting market depth updates for: F.US.MBTJ25 if supported. NumLevels=1400 2025-04-02 07:04:36.916 | DTC - Sub Instance | Starting real-time market data updates for: F.US.MCLEK25. ID: 7 Service code: cqg 2025-04-02 07:04:36.916 | DTC - Sub Instance | Requesting security definition data for: F.US.MCLEK25. ID: 7 2025-04-02 07:04:36.916 | Requesting market depth updates for: F.US.MCLEK25 if supported. NumLevels=1400 2025-04-02 07:04:36.917 | DTC - Sub Instance | Clearing market depth for F.US.BP6M25 | Number times message added: 1 2025-04-02 07:04:36.917 | DTC - Sub Instance | Clearing market depth for F.US.ENQM25 2025-04-02 07:04:36.917 | DTC - Sub Instance | Clearing market depth for F.US.EPM25 2025-04-02 07:04:36.920 | DTC - Sub Instance | Setting external service identifier for symbol F.US.BP6M25 to 6905 2025-04-02 07:04:36.920 | DTC - Sub Instance | Received security definition for symbol F.US.BP6M25 2025-04-02 07:04:36.920 | DTC - Sub Instance | Setting external service identifier for symbol F.US.ENQM25 to 42005804 2025-04-02 07:04:36.920 | DTC - Sub Instance | Received security definition for symbol F.US.ENQM25 2025-04-02 07:04:36.920 | DTC - Sub Instance | Setting external service identifier for symbol F.US.EPM25 to 4916 2025-04-02 07:04:36.920 | DTC - Sub Instance | Received security definition for symbol F.US.EPM25 2025-04-02 07:04:36.920 | DTC - Sub Instance | Clearing market depth for F.US.EU6M25 | Number times message added: 1 2025-04-02 07:04:36.920 | DTC - Sub Instance | Clearing market depth for F.US.GCEM25 2025-04-02 07:04:36.920 | DTC - Sub Instance | Clearing market depth for F.US.MBTJ25 2025-04-02 07:04:36.920 | DTC - Sub Instance | Clearing market depth for F.US.MCLEK25 | Number times message added: 1 2025-04-02 07:04:36.923 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-04-02 06:56:59. Record interval: 0. Symbol: GCM25 2025-04-02 07:04:36.926 | DTC - Sub Instance | Setting external service identifier for symbol F.US.EU6M25 to 75 2025-04-02 07:04:36.926 | DTC - Sub Instance | Received security definition for symbol F.US.EU6M25 2025-04-02 07:04:36.926 | DTC - Sub Instance | Setting external service identifier for symbol F.US.GCEM25 to 287 2025-04-02 07:04:36.926 | DTC - Sub Instance | Received security definition for symbol F.US.GCEM25 2025-04-02 07:04:36.926 | DTC - Sub Instance | Setting external service identifier for symbol F.US.MBTJ25 to 42007178 2025-04-02 07:04:36.926 | DTC - Sub Instance | Received security definition for symbol F.US.MBTJ25 2025-04-02 07:04:36.926 | DTC - Sub Instance | Setting external service identifier for symbol F.US.MCLEK25 to 76 2025-04-02 07:04:36.926 | DTC - Sub Instance | Received security definition for symbol F.US.MCLEK25 2025-04-02 07:04:36.931 | DTC - Sub Instance | Setting external service identifier for symbol F.US.EU6M25 to 75 2025-04-02 07:04:36.931 | DTC - Sub Instance | Received security definition for symbol F.US.EU6M25 2025-04-02 07:04:36.932 | DTC - Sub Instance | Setting external service identifier for symbol F.US.MCLEK25 to 76 2025-04-02 07:04:36.932 | DTC - Sub Instance | Received security definition for symbol F.US.MCLEK25 2025-04-02 07:04:37.024 | HD Request # 1 | Decompressing data. 2025-04-02 07:04:37.034 | DTC - Sub Instance | Setting external service identifier for symbol F.US.EU6M25 to 12494 2025-04-02 07:04:37.034 | DTC - Sub Instance | Received security definition for symbol F.US.EU6M25 2025-04-02 07:04:37.127 | HD Request # 1 | Receiving Intraday data for F.US.GCEM25 starting at 2025-04-02 06:56:59.524000 2025-04-02 07:04:37.129 | Socket (2) | CloseSocket call. 2025-04-02 07:04:37.129 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:37.129 | Historical data download thread signaled to stop. 2025-04-02 07:04:37.129 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-04-02 06:57:01.892000. 2025-04-02 07:04:37.130 | HD Request # 1 | Received 540 Intraday data records from 2025-04-02 06:56:59.524000 to 2025-04-02 07:04:29.329000 (7.5 minutes. Delay: 7.8 seconds) and wrote 539 records for F.US.GCEM25 2025-04-02 07:04:37.145 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-04-02 06:04:29.329000 2025-04-02 07:04:37.145 | HD Request # 1 | Completion time: 1s. 2025-04-02 07:04:37.145 | HD Request # 1 | Intraday data download complete for F.US.GCEM25. Unique request ID: 1 2025-04-02 07:04:37.145 | Removing historical data download ID 1. 2025-04-02 07:04:37.146 | Real-time Intraday chart data file updates started for F.US.GCEM25 2025-04-02 07:04:37.146 | Intraday chart data file opened for F.US.GCEM25 2025-04-02 07:04:37.146 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2025-04-02 07:04:37.146 | 2025-04-02 07:04:37.146 | Triggering next historical data download in queue. 2025-04-02 07:04:37.148 | HD Request # 2 | Downloading Historical Daily chart data for F.US.GCEM25. Starting date: 2025-03-27. Service: DTCSubInstance 2025-04-02 07:04:37.148 | HD Request # 2 | Using server: 127.0.0.1 port 11098 2025-04-02 07:04:37.148 | Socket (3) | Creating socket. 2025-04-02 07:04:37.148 | Socket (3) | New receive buffer size: 0 2025-04-02 07:04:37.148 | Socket (3) | Connecting to IP: 127.0.0.1. 2025-04-02 07:04:37.199 | HD Request # 2 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:37.199 | HD Request # 2 | Sending historical data logon request message. 2025-04-02 07:04:37.200 | HD Request # 2 | Requesting historical Daily data starting at 2025-03-27. 2025-04-02 07:04:37.201 | DTC - Sub Instance | Setting external service identifier for symbol F.US.MCLEK25 to 42026515 2025-04-02 07:04:37.201 | DTC - Sub Instance | Received security definition for symbol F.US.MCLEK25 2025-04-02 07:04:37.201 | HD Request # 2 | Decompressing data. 2025-04-02 07:04:37.211 | HD Request # 2 | Receiving historical Daily data for F.US.GCEM25 starting at 2025-03-27. 2025-04-02 07:04:37.211 | HD Request # 2 | Writing historical Daily data to the file F.US.GCEM25.dly. 2025-04-02 07:04:37.230 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:37.230 | Socket (2) | Closed. 2025-04-02 07:04:37.231 | Socket (3) | CloseSocket call. 2025-04-02 07:04:37.231 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:37.231 | Historical data download thread signaled to stop. 2025-04-02 07:04:37.231 | HD Request # 2 | Received 4 Daily data records from 2025-03-27 00:00:00 to 2025-04-01 00:00:00 (6.0 days) and wrote 4 records for F.US.GCEM25 2025-04-02 07:04:37.231 | HD Request # 2 | Completion time: 0s. 2025-04-02 07:04:37.231 | HD Request # 2 | Daily data download complete for F.US.GCEM25. Unique request ID: 2 2025-04-02 07:04:37.231 | Removing historical data download ID 2. 2025-04-02 07:04:37.231 | 2025-04-02 07:04:37.231 | Triggering next historical data download in queue. 2025-04-02 07:04:37.231 | Delaying start of download for F.US.EPM25. 2025-04-02 07:04:37.231 | Socket (3) | Socket gracefully closed by remote side. 2025-04-02 07:04:37.232 | Socket (3) | Closed. 2025-04-02 07:04:37.234 | F.US.GCEM25 [CB] 1 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:37.235 | F.US.GCEM25 [CB] 1 Min #8 | Reloading chart. | Number times message added: 1 2025-04-02 07:04:37.286 | Loading market depth data. 2025-04-02 07:04:37.303 | Loaded depth data records for F.US.GCEM25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:58.476000. 2025-04-02 07:04:37.303 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.GCEM25.2025-04-02.depth 2025-04-02 07:04:37.385 | Loaded depth data records for F.US.GCEM25 2025-04-02 from 2025-04-02 01:00:00.038000 to 2025-04-02 06:57:00.556570. 2025-04-02 07:04:37.392 | F.US.GCEM25 [CB] 1 Min #8 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:37.403 | F.US.GCEM25 [CB] 1 Min #8 | Chart data loading complete. 2025-04-02 07:04:37.413 | F.US.GCEM25 [CB] 1 Min #8 | Reloading chart. 2025-04-02 07:04:37.467 | Loading market depth data. 2025-04-02 07:04:37.473 | Loaded depth data records for F.US.GCEM25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:58.476000. 2025-04-02 07:04:37.501 | Loaded depth data records for F.US.GCEM25 2025-04-02 from 2025-04-02 01:00:00.038000 to 2025-04-02 06:57:00.556570. 2025-04-02 07:04:37.505 | F.US.GCEM25 [CB] 1 Min #8 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:37.518 | F.US.GCEM25 [CB] 1 Min #8 | Chart data loading complete. 2025-04-02 07:04:37.970 | F.US.GCEM25 [CBV] 60 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:37.970 | F.US.GCEM25 [CBV] 60 Min #10 | Reloading chart. 2025-04-02 07:04:38.128 | Opened cached Depth file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.GCEM25.2025-04-02.depth 2025-04-02 07:04:38.187 | F.US.GCEM25 [CBV] 5 Min #11 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:38.188 | F.US.GCEM25 [CBV] 5 Min #11 | Reloading chart. 2025-04-02 07:04:38.974 | F.US.GCEM25 [CBV] 60 Min #10 | Reloading chart. 2025-04-02 07:04:39.200 | F.US.GCEM25 [CBV] 5 Min #11 | Reloading chart. 2025-04-02 07:04:39.425 | Chart #11 has tagged chart #8 for full recalculation. Chartbook: Trading2.Cht 2025-04-02 07:04:39.434 | F.US.GCEM25 [CBV] 5 Min #11 | Chart data loading complete. 2025-04-02 07:04:40.203 | F.US.GCEM25 [CBV] 5 Min #11 | Reloading chart. 2025-04-02 07:04:41.068 | HD Request # 3 | Downloading Intraday chart data for F.US.EPM25 to the file F.US.EPM25.scid. Service: cme 2025-04-02 07:04:41.069 | HD Request # 3 | Download start date-time: 2025-04-02 06:56:44.000000. File last date-time: 2025-04-02 06:56:44.762000 2025-04-02 07:04:41.069 | HD Request # 3 | Using server: ds32.sierracharts.com port 10149 2025-04-02 07:04:41.072 | Socket (2) | Creating socket. 2025-04-02 07:04:41.072 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:41.072 | Socket (2) | Connecting to IP: 67.214.125.3. 2025-04-02 07:04:41.293 | HD Request # 3 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:41.293 | HD Request # 3 | Sending historical data logon request message. 2025-04-02 07:04:41.362 | Opened cached Intraday file: E:\SierraChart\SierraChartInstance_5\Data\F.US.GCEM25.scid. Thread ID: 17944 2025-04-02 07:04:41.385 | F.US.GCEM25 [CBV] 5 Min #11 | Chart data loading complete. 2025-04-02 07:04:41.445 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-04-02 06:56:44. Record interval: 0. Symbol: ESM25 2025-04-02 07:04:41.553 | HD Request # 3 | Decompressing data. 2025-04-02 07:04:41.668 | HD Request # 3 | Receiving Intraday data for F.US.EPM25 starting at 2025-04-02 06:56:44.762000 2025-04-02 07:04:41.669 | Socket (2) | CloseSocket call. 2025-04-02 07:04:41.669 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:41.669 | Historical data download thread signaled to stop. 2025-04-02 07:04:41.670 | HD Request # 3 | Timestamp of first Intraday data file record written: 2025-04-02 06:57:07.060000. 2025-04-02 07:04:41.670 | HD Request # 3 | Received 1504 Intraday data records from 2025-04-02 06:56:44.762000 to 2025-04-02 07:04:34.768005 (7.8 minutes. Delay: 6.9 seconds) and wrote 1503 records for F.US.EPM25 2025-04-02 07:04:41.680 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-04-02 06:04:34.768005 2025-04-02 07:04:41.680 | Added 3 Time and Sales records to Intraday data file for F.US.EPM25 after download. 2025-04-02 07:04:41.680 | HD Request # 3 | Completion time: 0s. 2025-04-02 07:04:41.680 | HD Request # 3 | Intraday data download complete for F.US.EPM25. Unique request ID: 3 2025-04-02 07:04:41.680 | Removing historical data download ID 3. 2025-04-02 07:04:41.680 | Real-time Intraday chart data file updates started for F.US.EPM25 2025-04-02 07:04:41.680 | Intraday chart data file opened for F.US.EPM25 2025-04-02 07:04:41.680 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2025-04-02 07:04:41.680 | 2025-04-02 07:04:41.680 | Triggering next historical data download in queue. 2025-04-02 07:04:41.681 | HD Request # 4 | Downloading Historical Daily chart data for F.US.EPM25. Starting date: 2025-03-27. Service: DTCSubInstance 2025-04-02 07:04:41.681 | HD Request # 4 | Using server: 127.0.0.1 port 11098 2025-04-02 07:04:41.681 | Socket (3) | Creating socket. 2025-04-02 07:04:41.681 | Socket (3) | New receive buffer size: 0 2025-04-02 07:04:41.682 | Socket (3) | Connecting to IP: 127.0.0.1. 2025-04-02 07:04:41.719 | HD Request # 4 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:41.719 | HD Request # 4 | Sending historical data logon request message. 2025-04-02 07:04:41.720 | HD Request # 4 | Requesting historical Daily data starting at 2025-03-27. 2025-04-02 07:04:41.720 | HD Request # 4 | Decompressing data. 2025-04-02 07:04:41.724 | HD Request # 4 | Receiving historical Daily data for F.US.EPM25 starting at 2025-03-27. 2025-04-02 07:04:41.724 | HD Request # 4 | Writing historical Daily data to the file F.US.EPM25.dly. 2025-04-02 07:04:41.728 | Socket (3) | CloseSocket call. 2025-04-02 07:04:41.729 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:41.729 | Historical data download thread signaled to stop. 2025-04-02 07:04:41.729 | HD Request # 4 | Received 4 Daily data records from 2025-03-27 00:00:00 to 2025-04-01 00:00:00 (6.0 days) and wrote 4 records for F.US.EPM25 2025-04-02 07:04:41.729 | HD Request # 4 | Completion time: 0s. 2025-04-02 07:04:41.729 | HD Request # 4 | Daily data download complete for F.US.EPM25. Unique request ID: 4 2025-04-02 07:04:41.729 | Removing historical data download ID 4. 2025-04-02 07:04:41.729 | 2025-04-02 07:04:41.729 | Triggering next historical data download in queue. 2025-04-02 07:04:41.729 | HD Request # 5 | Downloading Intraday chart data for F.US.EU6M25 to the file F.US.EU6M25.scid. Service: cme 2025-04-02 07:04:41.729 | Socket (3) | Socket gracefully closed by remote side. 2025-04-02 07:04:41.729 | Socket (3) | Closed. 2025-04-02 07:04:41.729 | HD Request # 5 | Download start date-time: 2025-04-02 06:56:59.000000. File last date-time: 2025-04-02 06:56:59.582001 2025-04-02 07:04:41.730 | HD Request # 5 | Using server: ds26.sierracharts.com port 10149 2025-04-02 07:04:41.731 | Socket (3) | Creating socket. 2025-04-02 07:04:41.731 | Socket (3) | New receive buffer size: 0 2025-04-02 07:04:41.731 | Socket (3) | Connecting to IP: 64.152.155.17. 2025-04-02 07:04:41.734 | F.US.EPM25 [CB] 1 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:41.734 | F.US.EPM25 [CB] 1 Min #22 | Reloading chart. 2025-04-02 07:04:41.749 | F.US.EPM25 [CB] 1 Min #19 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:41.750 | F.US.EPM25 [CB] 1 Min #19 | Reloading chart. 2025-04-02 07:04:41.764 | F.US.EPM25 [CB] 1 Min #22 | Reloading chart. 2025-04-02 07:04:41.771 | F.US.EPM25 [CB] 1 Min #19 | Reloading chart. 2025-04-02 07:04:41.778 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:41.778 | Socket (2) | Closed. 2025-04-02 07:04:41.782 | Loading market depth data. | Number times message added: 1 2025-04-02 07:04:41.817 | Loaded depth data records for F.US.EPM25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:59.905000. 2025-04-02 07:04:41.818 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.EPM25.2025-04-02.depth 2025-04-02 07:04:41.870 | Loaded depth data records for F.US.EPM25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:59.905000. 2025-04-02 07:04:41.964 | Loaded depth data records for F.US.EPM25 2025-04-02 from 2025-04-02 01:00:00.010000 to 2025-04-02 06:57:00.556372. | Number times message added: 1 2025-04-02 07:04:41.965 | HD Request # 5 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:41.965 | HD Request # 5 | Sending historical data logon request message. 2025-04-02 07:04:41.967 | F.US.EPM25 [CB] 1 Min #19 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:41.981 | F.US.EPM25 [CB] 1 Min #19 | Chart data loading complete. 2025-04-02 07:04:41.982 | F.US.EPM25 [CB] 1 Min #22 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:41.992 | F.US.EPM25 [CB] 1 Min #22 | Chart data loading complete. 2025-04-02 07:04:42.020 | F.US.EPM25 [CB] 1 Min #22 | Reloading chart. 2025-04-02 07:04:42.059 | Loading market depth data. 2025-04-02 07:04:42.074 | Loaded depth data records for F.US.EPM25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:59.905000. 2025-04-02 07:04:42.113 | Loaded depth data records for F.US.EPM25 2025-04-02 from 2025-04-02 01:00:00.010000 to 2025-04-02 06:57:00.556372. 2025-04-02 07:04:42.114 | F.US.EPM25 [CB] 1 Min #22 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:42.120 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-04-02 06:56:59. Record interval: 0. Symbol: 6EM25 2025-04-02 07:04:42.122 | F.US.EPM25 [CB] 1 Min #22 | Chart data loading complete. 2025-04-02 07:04:42.233 | HD Request # 5 | Decompressing data. 2025-04-02 07:04:42.287 | F.US.EPM25 [CBV] 60 Min #24 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:42.288 | F.US.EPM25 [CBV] 60 Min #24 | Reloading chart. 2025-04-02 07:04:42.347 | HD Request # 5 | Receiving Intraday data for F.US.EU6M25 starting at 2025-04-02 06:56:59.582000 2025-04-02 07:04:42.348 | Socket (3) | CloseSocket call. 2025-04-02 07:04:42.348 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:42.376 | Historical data download thread signaled to stop. 2025-04-02 07:04:42.376 | HD Request # 5 | Timestamp of first Intraday data file record written: 2025-04-02 06:57:15.571000. 2025-04-02 07:04:42.376 | HD Request # 5 | Received 322 Intraday data records from 2025-04-02 06:56:59.582000 to 2025-04-02 07:04:23.063000 (7.4 minutes. Delay: 19.3 seconds) and wrote 320 records for F.US.EU6M25 2025-04-02 07:04:42.385 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2025-04-02 06:04:23.063000 2025-04-02 07:04:42.385 | HD Request # 5 | Completion time: 1s. 2025-04-02 07:04:42.385 | HD Request # 5 | Intraday data download complete for F.US.EU6M25. Unique request ID: 5 2025-04-02 07:04:42.385 | Removing historical data download ID 5. 2025-04-02 07:04:42.385 | Real-time Intraday chart data file updates started for F.US.EU6M25 2025-04-02 07:04:42.385 | Intraday chart data file opened for F.US.EU6M25 2025-04-02 07:04:42.385 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2025-04-02 07:04:42.385 | 2025-04-02 07:04:42.385 | Triggering next historical data download in queue. 2025-04-02 07:04:42.387 | HD Request # 6 | Downloading Historical Daily chart data for F.US.EU6M25. Starting date: 2025-03-27. Service: DTCSubInstance 2025-04-02 07:04:42.387 | HD Request # 6 | Using server: 127.0.0.1 port 11098 2025-04-02 07:04:42.387 | Socket (2) | Creating socket. 2025-04-02 07:04:42.387 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:42.387 | Socket (2) | Connecting to IP: 127.0.0.1. 2025-04-02 07:04:42.422 | HD Request # 6 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:42.422 | HD Request # 6 | Sending historical data logon request message. 2025-04-02 07:04:42.422 | HD Request # 6 | Requesting historical Daily data starting at 2025-03-27. 2025-04-02 07:04:42.422 | HD Request # 6 | Data is being downloaded from a remote source. Download will start when this is done. 2025-04-02 07:04:42.457 | F.US.EPM25 [CBV] 5 Min #23 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:42.457 | F.US.EPM25 [CBV] 5 Min #23 | Reloading chart. 2025-04-02 07:04:42.470 | Socket (3) | Socket gracefully closed by remote side. 2025-04-02 07:04:42.470 | Socket (3) | Closed. 2025-04-02 07:04:42.519 | F.US.EPM25 [CBV] 60 Min #21 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:42.519 | F.US.EPM25 [CBV] 60 Min #21 | Reloading chart. 2025-04-02 07:04:42.612 | F.US.EPM25 [CBV] 5 Min #20 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:42.613 | F.US.EPM25 [CBV] 5 Min #20 | Reloading chart. 2025-04-02 07:04:43.037 | Opened cached Depth file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.EPM25.2025-04-02.depth 2025-04-02 07:04:43.285 | F.US.EPM25 [CBV] 60 Min #24 | Reloading chart. 2025-04-02 07:04:43.424 | HD Request # 6 | Decompressing data. 2025-04-02 07:04:43.434 | HD Request # 6 | Receiving historical Daily data for F.US.EU6M25 starting at 2025-03-27. 2025-04-02 07:04:43.434 | HD Request # 6 | Writing historical Daily data to the file F.US.EU6M25.dly. 2025-04-02 07:04:43.446 | Socket (2) | CloseSocket call. 2025-04-02 07:04:43.446 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:43.447 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:43.447 | Socket (2) | Closed. 2025-04-02 07:04:43.457 | Historical data download thread signaled to stop. 2025-04-02 07:04:43.457 | HD Request # 6 | Received 4 Daily data records from 2025-03-27 00:00:00 to 2025-04-01 00:00:00 (6.0 days) and wrote 4 records for F.US.EU6M25 2025-04-02 07:04:43.457 | HD Request # 6 | Completion time: 1s. 2025-04-02 07:04:43.457 | HD Request # 6 | Daily data download complete for F.US.EU6M25. Unique request ID: 6 2025-04-02 07:04:43.457 | Removing historical data download ID 6. 2025-04-02 07:04:43.457 | 2025-04-02 07:04:43.457 | Triggering next historical data download in queue. 2025-04-02 07:04:43.457 | HD Request # 7 | Downloading Intraday chart data for F.US.BP6M25 to the file F.US.BP6M25.scid. Service: cme 2025-04-02 07:04:43.457 | HD Request # 7 | Download start date-time: 2025-04-02 06:56:50.000000. File last date-time: 2025-04-02 06:56:50.317001 2025-04-02 07:04:43.457 | HD Request # 7 | Using server: ds28.sierracharts.com port 10149 2025-04-02 07:04:43.457 | Socket (2) | Creating socket. 2025-04-02 07:04:43.457 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:43.457 | Socket (2) | Connecting to IP: 67.214.125.5. 2025-04-02 07:04:43.463 | F.US.EU6M25 [CB] 1 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:43.464 | F.US.EU6M25 [CB] 1 Min #5 | Reloading chart. 2025-04-02 07:04:43.496 | F.US.EPM25 [CBV] 5 Min #23 | Reloading chart. 2025-04-02 07:04:43.500 | Loading market depth data. 2025-04-02 07:04:43.511 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.EU6M25.2025-04-01.depth 2025-04-02 07:04:43.670 | F.US.EU6M25 [CB] 1 Min #5 | Reloading chart. 2025-04-02 07:04:43.672 | HD Request # 7 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:43.672 | HD Request # 7 | Sending historical data logon request message. 2025-04-02 07:04:43.674 | Loaded depth data records for F.US.EU6M25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:55.198000. 2025-04-02 07:04:43.674 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.EU6M25.2025-04-02.depth 2025-04-02 07:04:43.719 | F.US.EPM25 [CBV] 60 Min #21 | Reloading chart. 2025-04-02 07:04:43.740 | Loaded depth data records for F.US.EU6M25 2025-04-02 from 2025-04-02 01:00:00.738000 to 2025-04-02 06:57:00.556471. 2025-04-02 07:04:43.779 | HD Request # 7 | Requesting Intraday data. Start date-time: 2025-04-02 06:56:50. Record interval: 0. Symbol: 6BM25 2025-04-02 07:04:43.883 | HD Request # 7 | Decompressing data. 2025-04-02 07:04:43.887 | F.US.EU6M25 [CB] 1 Min #5 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:43.901 | F.US.EU6M25 [CB] 1 Min #5 | Chart data loading complete. 2025-04-02 07:04:43.918 | F.US.EU6M25 [CBV] 60 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:43.918 | F.US.EU6M25 [CBV] 60 Min #2 | Reloading chart. 2025-04-02 07:04:43.988 | HD Request # 7 | Receiving Intraday data for F.US.BP6M25 starting at 2025-04-02 06:56:50.317000 2025-04-02 07:04:43.989 | Socket (2) | CloseSocket call. 2025-04-02 07:04:43.989 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:44.092 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:44.092 | Socket (2) | Closed. 2025-04-02 07:04:44.192 | Historical data download thread signaled to stop. 2025-04-02 07:04:44.192 | HD Request # 7 | Timestamp of first Intraday data file record written: 2025-04-02 06:57:01.635000. 2025-04-02 07:04:44.192 | HD Request # 7 | Received 192 Intraday data records from 2025-04-02 06:56:50.317000 to 2025-04-02 07:04:21.303001 (7.5 minutes. Delay: 22.9 seconds) and wrote 190 records for F.US.BP6M25 2025-04-02 07:04:44.204 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2025-04-02 06:04:21.303001 2025-04-02 07:04:44.204 | HD Request # 7 | Completion time: 1s. 2025-04-02 07:04:44.204 | HD Request # 7 | Intraday data download complete for F.US.BP6M25. Unique request ID: 7 2025-04-02 07:04:44.204 | Removing historical data download ID 7. 2025-04-02 07:04:44.204 | Real-time Intraday chart data file updates started for F.US.BP6M25 2025-04-02 07:04:44.204 | Intraday chart data file opened for F.US.BP6M25 2025-04-02 07:04:44.204 | HD Request # 7 | Enabling Intraday chart updating for symbol. 2025-04-02 07:04:44.204 | 2025-04-02 07:04:44.204 | Triggering next historical data download in queue. 2025-04-02 07:04:44.206 | HD Request # 8 | Downloading Historical Daily chart data for F.US.BP6M25. Starting date: 2025-03-27. Service: DTCSubInstance 2025-04-02 07:04:44.206 | HD Request # 8 | Using server: 127.0.0.1 port 11098 2025-04-02 07:04:44.206 | Socket (2) | Creating socket. 2025-04-02 07:04:44.207 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:44.207 | Socket (2) | Connecting to IP: 127.0.0.1. 2025-04-02 07:04:44.264 | HD Request # 8 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:44.264 | HD Request # 8 | Sending historical data logon request message. 2025-04-02 07:04:44.264 | HD Request # 8 | Requesting historical Daily data starting at 2025-03-27. 2025-04-02 07:04:44.265 | HD Request # 8 | Decompressing data. 2025-04-02 07:04:44.266 | F.US.EPM25 [CBV] 5 Min #20 | Reloading chart. 2025-04-02 07:04:44.277 | HD Request # 8 | Receiving historical Daily data for F.US.BP6M25 starting at 2025-03-27. 2025-04-02 07:04:44.277 | HD Request # 8 | Writing historical Daily data to the file F.US.BP6M25.dly. 2025-04-02 07:04:44.288 | Socket (2) | CloseSocket call. 2025-04-02 07:04:44.289 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:44.289 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:44.289 | Socket (2) | Closed. 2025-04-02 07:04:44.334 | Historical data download thread signaled to stop. 2025-04-02 07:04:44.334 | HD Request # 8 | Received 4 Daily data records from 2025-03-27 00:00:00 to 2025-04-01 00:00:00 (6.0 days) and wrote 4 records for F.US.BP6M25 2025-04-02 07:04:44.334 | HD Request # 8 | Completion time: 0s. 2025-04-02 07:04:44.334 | HD Request # 8 | Daily data download complete for F.US.BP6M25. Unique request ID: 8 2025-04-02 07:04:44.334 | Removing historical data download ID 8. 2025-04-02 07:04:44.334 | 2025-04-02 07:04:44.334 | Triggering next historical data download in queue. 2025-04-02 07:04:44.334 | HD Request # 9 | Downloading Intraday chart data for F.US.ENQM25 to the file F.US.ENQM25.scid. Service: cme 2025-04-02 07:04:44.334 | HD Request # 9 | Download start date-time: 2025-04-02 06:56:41.000000. File last date-time: 2025-04-02 06:56:41.254000 2025-04-02 07:04:44.334 | HD Request # 9 | Using server: ds32.sierracharts.com port 10149 2025-04-02 07:04:44.334 | Socket (2) | Creating socket. 2025-04-02 07:04:44.334 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:44.334 | Socket (2) | Connecting to IP: 67.214.125.3. 2025-04-02 07:04:44.394 | F.US.BP6M25 [CB] 1 Min #16 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:44.394 | F.US.BP6M25 [CB] 1 Min #16 | Reloading chart. 2025-04-02 07:04:44.418 | Loading market depth data. 2025-04-02 07:04:44.424 | F.US.EU6M25 [CBV] 5 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:44.429 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.BP6M25.2025-04-01.depth 2025-04-02 07:04:44.527 | F.US.EU6M25 [CBV] 5 Min #3 | Reloading chart. 2025-04-02 07:04:44.530 | Loaded depth data records for F.US.BP6M25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:45.108000. 2025-04-02 07:04:44.530 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.BP6M25.2025-04-02.depth 2025-04-02 07:04:44.554 | HD Request # 9 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:44.554 | HD Request # 9 | Sending historical data logon request message. 2025-04-02 07:04:44.572 | Loaded depth data records for F.US.BP6M25 2025-04-02 from 2025-04-02 01:00:00.871000 to 2025-04-02 06:57:00.556208. 2025-04-02 07:04:44.636 | F.US.BP6M25 [CB] 1 Min #16 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:44.650 | F.US.BP6M25 [CB] 1 Min #16 | Chart data loading complete. 2025-04-02 07:04:44.664 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-04-02 06:56:41. Record interval: 0. Symbol: NQM25 2025-04-02 07:04:44.695 | F.US.BP6M25 [CBV] 60 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:44.696 | F.US.BP6M25 [CBV] 60 Min #6 | Reloading chart. 2025-04-02 07:04:44.782 | HD Request # 9 | Decompressing data. 2025-04-02 07:04:44.889 | HD Request # 9 | Receiving Intraday data for F.US.ENQM25 starting at 2025-04-02 06:56:41.250000 2025-04-02 07:04:44.897 | Socket (2) | CloseSocket call. 2025-04-02 07:04:44.897 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:45.008 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:45.008 | Socket (2) | Closed. 2025-04-02 07:04:45.041 | Historical data download thread signaled to stop. 2025-04-02 07:04:45.041 | HD Request # 9 | Timestamp of first Intraday data file record written: 2025-04-02 06:57:03.930000. 2025-04-02 07:04:45.042 | HD Request # 9 | Received 900 Intraday data records from 2025-04-02 06:56:41.250000 to 2025-04-02 07:04:42.957000 (8.0 minutes. Delay: 2.1 seconds) and wrote 894 records for F.US.ENQM25 2025-04-02 07:04:45.053 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-04-02 06:04:42.957000 2025-04-02 07:04:45.053 | HD Request # 9 | Completion time: 1s. 2025-04-02 07:04:45.053 | HD Request # 9 | Intraday data download complete for F.US.ENQM25. Unique request ID: 9 2025-04-02 07:04:45.053 | Removing historical data download ID 9. 2025-04-02 07:04:45.053 | Real-time Intraday chart data file updates started for F.US.ENQM25 2025-04-02 07:04:45.053 | Intraday chart data file opened for F.US.ENQM25 2025-04-02 07:04:45.053 | HD Request # 9 | Enabling Intraday chart updating for symbol. 2025-04-02 07:04:45.053 | 2025-04-02 07:04:45.053 | Triggering next historical data download in queue. 2025-04-02 07:04:45.056 | HD Request # 10 | Downloading Historical Daily chart data for F.US.ENQM25. Starting date: 2025-03-27. Service: DTCSubInstance 2025-04-02 07:04:45.056 | HD Request # 10 | Using server: 127.0.0.1 port 11098 2025-04-02 07:04:45.056 | Socket (2) | Creating socket. 2025-04-02 07:04:45.056 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:45.056 | Socket (2) | Connecting to IP: 127.0.0.1. 2025-04-02 07:04:45.065 | F.US.BP6M25 [CBV] 5 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:45.066 | F.US.BP6M25 [CBV] 5 Min #7 | Reloading chart. 2025-04-02 07:04:45.289 | HD Request # 10 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:45.289 | HD Request # 10 | Sending historical data logon request message. 2025-04-02 07:04:45.290 | HD Request # 10 | Requesting historical Daily data starting at 2025-03-27. 2025-04-02 07:04:45.290 | HD Request # 10 | Decompressing data. 2025-04-02 07:04:45.290 | Opened cached Depth file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.EU6M25.2025-04-02.depth 2025-04-02 07:04:45.293 | HD Request # 10 | Receiving historical Daily data for F.US.ENQM25 starting at 2025-03-27. 2025-04-02 07:04:45.293 | HD Request # 10 | Writing historical Daily data to the file F.US.ENQM25.dly. 2025-04-02 07:04:45.296 | Socket (2) | CloseSocket call. 2025-04-02 07:04:45.297 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:45.297 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:45.297 | Socket (2) | Closed. 2025-04-02 07:04:45.367 | Historical data download thread signaled to stop. 2025-04-02 07:04:45.367 | HD Request # 10 | Received 4 Daily data records from 2025-03-27 00:00:00 to 2025-04-01 00:00:00 (6.0 days) and wrote 4 records for F.US.ENQM25 2025-04-02 07:04:45.367 | HD Request # 10 | Completion time: 0s. 2025-04-02 07:04:45.367 | HD Request # 10 | Daily data download complete for F.US.ENQM25. Unique request ID: 10 2025-04-02 07:04:45.367 | Removing historical data download ID 10. 2025-04-02 07:04:45.367 | 2025-04-02 07:04:45.367 | Triggering next historical data download in queue. 2025-04-02 07:04:45.367 | HD Request # 11 | Downloading Intraday chart data for F.US.MCLEK25 to the file F.US.MCLEK25.scid. Service: nymex 2025-04-02 07:04:45.367 | HD Request # 11 | Download start date-time: 2025-04-02 06:56:51.000000. File last date-time: 2025-04-02 06:56:51.242001 2025-04-02 07:04:45.367 | HD Request # 11 | Using server: ds26.sierracharts.com port 10149 2025-04-02 07:04:45.367 | Socket (2) | Creating socket. 2025-04-02 07:04:45.367 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:45.367 | Socket (2) | Connecting to IP: 64.152.155.17. 2025-04-02 07:04:45.371 | F.US.ENQM25 [CBV] 60 Min #1 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:45.372 | F.US.ENQM25 [CBV] 60 Min #1 | Reloading chart. 2025-04-02 07:04:45.587 | F.US.ENQM25 [CBV] 5 Min #9 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:45.587 | F.US.ENQM25 [CBV] 5 Min #9 | Reloading chart. 2025-04-02 07:04:45.646 | HD Request # 11 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:45.646 | HD Request # 11 | Sending historical data logon request message. 2025-04-02 07:04:45.772 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-04-02 06:56:51. Record interval: 0. Symbol: MCLK25 2025-04-02 07:04:45.874 | F.US.BP6M25 [CB] 1 Min #16 | Reloading chart. 2025-04-02 07:04:45.889 | HD Request # 11 | Decompressing data. 2025-04-02 07:04:45.925 | F.US.ENQM25 [CB] 1 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:45.926 | F.US.ENQM25 [CB] 1 Min #4 | Reloading chart. 2025-04-02 07:04:45.953 | Loading market depth data. 2025-04-02 07:04:45.956 | Loaded depth data records for F.US.BP6M25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:45.108000. 2025-04-02 07:04:45.972 | Loaded depth data records for F.US.BP6M25 2025-04-02 from 2025-04-02 01:00:00.871000 to 2025-04-02 06:57:00.556208. 2025-04-02 07:04:46.018 | HD Request # 11 | Receiving Intraday data for F.US.MCLEK25 starting at 2025-04-02 06:56:51.242000 2025-04-02 07:04:46.018 | F.US.BP6M25 [CB] 1 Min #16 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:46.018 | Socket (2) | CloseSocket call. 2025-04-02 07:04:46.028 | Loading market depth data. 2025-04-02 07:04:46.030 | F.US.BP6M25 [CB] 1 Min #16 | Chart data loading complete. 2025-04-02 07:04:46.050 | Historical data download thread signaled to stop. 2025-04-02 07:04:46.050 | HD Request # 11 | Timestamp of first Intraday data file record written: 2025-04-02 06:57:09.941000. 2025-04-02 07:04:46.050 | HD Request # 11 | Received 147 Intraday data records from 2025-04-02 06:56:51.242000 to 2025-04-02 07:04:36.928004 (7.8 minutes. Delay: 9.1 seconds) and wrote 145 records for F.US.MCLEK25 2025-04-02 07:04:46.063 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2025-04-02 06:04:36.928004 2025-04-02 07:04:46.063 | HD Request # 11 | Completion time: 1s. 2025-04-02 07:04:46.063 | HD Request # 11 | Intraday data download complete for F.US.MCLEK25. Unique request ID: 11 2025-04-02 07:04:46.063 | Removing historical data download ID 11. 2025-04-02 07:04:46.063 | Real-time Intraday chart data file updates started for F.US.MCLEK25 2025-04-02 07:04:46.063 | Intraday chart data file opened for F.US.MCLEK25 2025-04-02 07:04:46.063 | HD Request # 11 | Enabling Intraday chart updating for symbol. 2025-04-02 07:04:46.063 | 2025-04-02 07:04:46.063 | Triggering next historical data download in queue. 2025-04-02 07:04:46.078 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:46.149 | Loaded depth data records for F.US.ENQM25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:59.906000. 2025-04-02 07:04:46.149 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.ENQM25.2025-04-02.depth 2025-04-02 07:04:46.242 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:46.242 | Socket (2) | Closed. 2025-04-02 07:04:46.249 | HD Request # 12 | Downloading Historical Daily chart data for F.US.MCLEK25. Starting date: 2025-03-27. Service: nymex 2025-04-02 07:04:46.252 | HD Request # 12 | Using server: ds28.sierracharts.com port 10150 2025-04-02 07:04:46.255 | F.US.BP6M25 [CBV] 5 Min #7 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:04:46.326 | Socket (2) | Creating socket. 2025-04-02 07:04:46.326 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:46.326 | Socket (2) | Connecting to IP: 67.214.125.5. 2025-04-02 07:04:46.483 | Loaded depth data records for F.US.ENQM25 2025-04-02 from 2025-04-02 01:00:00.011000 to 2025-04-02 06:57:00.556296. 2025-04-02 07:04:46.491 | Chart #7 has tagged chart #16 for full recalculation. Chartbook: Trading2.Cht 2025-04-02 07:04:46.536 | F.US.BP6M25 [CBV] 5 Min #7 | Chart data loading complete. 2025-04-02 07:04:46.634 | HD Request # 12 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:46.634 | HD Request # 12 | Sending historical data logon request message. 2025-04-02 07:04:46.786 | HD Request # 12 | Requesting historical Daily data starting at 2025-03-27. 2025-04-02 07:04:46.912 | HD Request # 12 | Decompressing data. 2025-04-02 07:04:46.912 | HD Request # 12 | Receiving historical Daily data for F.US.MCLEK25 starting at 2025-03-27. 2025-04-02 07:04:46.912 | HD Request # 12 | Writing historical Daily data to the file F.US.MCLEK25.dly. 2025-04-02 07:04:46.916 | Socket (2) | CloseSocket call. 2025-04-02 07:04:46.916 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:46.995 | F.US.ENQM25 [CB] 1 Min #4 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:47.062 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:47.063 | Socket (2) | Closed. 2025-04-02 07:04:47.190 | F.US.ENQM25 [CB] 1 Min #4 | Chart data loading complete. 2025-04-02 07:04:47.191 | Historical data download thread signaled to stop. 2025-04-02 07:04:47.191 | HD Request # 12 | Received 5 Daily data records from 2025-03-27 00:00:00 to 2025-04-02 00:00:00 (7.0 days) and wrote 5 records for F.US.MCLEK25 2025-04-02 07:04:47.191 | HD Request # 12 | Completion time: 1s. 2025-04-02 07:04:47.191 | HD Request # 12 | Daily data download complete for F.US.MCLEK25. Unique request ID: 12 2025-04-02 07:04:47.191 | Removing historical data download ID 12. 2025-04-02 07:04:47.191 | 2025-04-02 07:04:47.191 | Triggering next historical data download in queue. 2025-04-02 07:04:47.415 | HD Request # 13 | Downloading Intraday chart data for F.US.MBTV24 to the file F.US.MBTV24.scid. Service: cme 2025-04-02 07:04:47.416 | HD Request # 13 | Download start date-time: 2024-10-25 15:58:44.000000. File last date-time: 2024-10-25 15:58:44.743000 2025-04-02 07:04:47.416 | HD Request # 13 | Using server: ds32.sierracharts.com port 10149 2025-04-02 07:04:47.417 | F.US.EU6M25 [CBV] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:04:47.464 | Socket (2) | Creating socket. 2025-04-02 07:04:47.464 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:47.464 | Socket (2) | Connecting to IP: 67.214.125.3. 2025-04-02 07:04:47.684 | Chart #3 has tagged chart #5 for full recalculation. Chartbook: Trading2.Cht 2025-04-02 07:04:47.703 | HD Request # 13 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:47.703 | HD Request # 13 | Sending historical data logon request message. 2025-04-02 07:04:47.892 | HD Request # 13 | Requesting Intraday data. Start date-time: 2024-10-25 15:58:44. Record interval: 0. Symbol: MBTV24 2025-04-02 07:04:48.045 | F.US.EU6M25 [CBV] 5 Min #3 | Chart data loading complete. 2025-04-02 07:04:48.095 | HD Request # 13 | Decompressing data. 2025-04-02 07:04:48.176 | HD Request # 13 | Receiving Intraday data for F.US.MBTV24 starting at 2024-10-25 15:58:44.743000 2025-04-02 07:04:48.176 | Socket (2) | CloseSocket call. 2025-04-02 07:04:48.210 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:48.376 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:48.376 | Socket (2) | Closed. 2025-04-02 07:04:48.450 | Historical data download thread signaled to stop. 2025-04-02 07:04:48.450 | HD Request # 13 | Received 1 Intraday data record from 2024-10-25 15:58:44.743000 to 2024-10-25 15:58:44.743000 (0.0 seconds. Delay: 158.6 days) and wrote 0 records for F.US.MBTV24 2025-04-02 07:04:48.450 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2024-10-25 14:58:44.743000 2025-04-02 07:04:48.450 | HD Request # 13 | Completion time: 1s. 2025-04-02 07:04:48.450 | HD Request # 13 | Intraday data download complete for F.US.MBTV24. Unique request ID: 13 2025-04-02 07:04:48.450 | Removing historical data download ID 13. 2025-04-02 07:04:48.450 | Real-time Intraday chart data file updates started for F.US.MBTV24 2025-04-02 07:04:48.450 | Intraday chart data file opened for F.US.MBTV24 2025-04-02 07:04:48.450 | HD Request # 13 | Enabling Intraday chart updating for symbol. 2025-04-02 07:04:48.450 | 2025-04-02 07:04:48.450 | Triggering next historical data download in queue. 2025-04-02 07:04:48.454 | HD Request # 14 | Downloading Historical Daily chart data for F.US.MBTV24. Starting date: 2024-10-23. Service: DTCSubInstance 2025-04-02 07:04:48.454 | HD Request # 14 | Using server: 127.0.0.1 port 11098 2025-04-02 07:04:48.458 | Socket (2) | Creating socket. 2025-04-02 07:04:48.458 | Socket (2) | New receive buffer size: 0 2025-04-02 07:04:48.458 | Socket (2) | Connecting to IP: 127.0.0.1. 2025-04-02 07:04:48.855 | Opened cached Intraday file: E:\SierraChart\SierraChartInstance_5\Data\F.US.BP6M25.scid. Thread ID: 17944 2025-04-02 07:04:48.856 | Opened cached Intraday file: E:\SierraChart\SierraChartInstance_5\Data\F.US.EPM25.scid. Thread ID: 17944 2025-04-02 07:04:48.856 | Opened cached Intraday file: E:\SierraChart\SierraChartInstance_5\Data\F.US.EU6M25.scid. Thread ID: 17944 2025-04-02 07:04:48.987 | F.US.MCLEK25 [CBV] 60 Min #14 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:48.988 | F.US.MCLEK25 [CBV] 60 Min #14 | Reloading chart. 2025-04-02 07:04:49.732 | F.US.EU6M25 [CBV] 60 Min #2 | Reloading chart. 2025-04-02 07:04:50.369 | F.US.MCLEK25 [CBV] 5 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:50.371 | F.US.MCLEK25 [CBV] 5 Min #15 | Reloading chart. 2025-04-02 07:04:50.552 | F.US.EU6M25 [CBV] 5 Min #3 | Reloading chart. 2025-04-02 07:04:50.946 | F.US.BP6M25 [CBV] 60 Min #6 | Reloading chart. 2025-04-02 07:04:51.899 | F.US.MCLEK25 [CBV] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:04:52.195 | F.US.MCLEK25 [CBV] 5 Min #15 | Chart data loading complete. 2025-04-02 07:04:52.568 | F.US.MCLEK25 [CB] 1 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:04:52.568 | F.US.MCLEK25 [CB] 1 Min #12 | Reloading chart. 2025-04-02 07:04:52.735 | Loading market depth data. 2025-04-02 07:04:52.748 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.MCLEK25.2025-04-01.depth 2025-04-02 07:04:52.897 | F.US.ENQM25 [CB] 1 Min #4 | Reloading chart. 2025-04-02 07:04:52.904 | Loaded depth data records for F.US.MCLEK25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:39.206000. 2025-04-02 07:04:52.904 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.MCLEK25.2025-04-02.depth 2025-04-02 07:04:52.947 | Loaded depth data records for F.US.MCLEK25 2025-04-02 from 2025-04-02 01:00:00.066000 to 2025-04-02 06:57:00.556733. 2025-04-02 07:04:53.016 | Opened cached Depth file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.BP6M25.2025-04-02.depth 2025-04-02 07:04:53.017 | F.US.MCLEK25 [CB] 1 Min #12 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:53.085 | F.US.MCLEK25 [CB] 1 Min #12 | Chart data loading complete. 2025-04-02 07:04:53.090 | Loading market depth data. 2025-04-02 07:04:53.210 | Loaded depth data records for F.US.ENQM25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:59.906000. 2025-04-02 07:04:53.213 | F.US.BP6M25 [CBV] 5 Min #7 | Reloading chart. 2025-04-02 07:04:53.482 | Loaded depth data records for F.US.ENQM25 2025-04-02 from 2025-04-02 01:00:00.011000 to 2025-04-02 06:57:00.556296. 2025-04-02 07:04:53.657 | F.US.ENQM25 [CB] 1 Min #4 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:53.810 | F.US.ENQM25 [CB] 1 Min #4 | Chart data loading complete. 2025-04-02 07:04:54.001 | F.US.ENQM25 [CBV] 60 Min #1 | Reloading chart. 2025-04-02 07:04:54.834 | F.US.BP6M25 [CBV] 5 Min #7 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:04:55.186 | F.US.BP6M25 [CBV] 5 Min #7 | Chart data loading complete. 2025-04-02 07:04:55.187 | F.US.EU6M25 [CBV] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:04:55.478 | F.US.EU6M25 [CBV] 5 Min #3 | Chart data loading complete. 2025-04-02 07:04:55.895 | F.US.ENQM25 [CBV] 5 Min #9 | Reloading chart. 2025-04-02 07:04:56.123 | F.US.MCLEK25 [CBV] 60 Min #14 | Reloading chart. 2025-04-02 07:04:56.643 | F.US.MCLEK25 [CBV] 5 Min #15 | Reloading chart. 2025-04-02 07:04:56.946 | F.US.MCLEK25 [CB] 1 Min #12 | Reloading chart. 2025-04-02 07:04:57.098 | Loading market depth data. 2025-04-02 07:04:57.110 | Loaded depth data records for F.US.MCLEK25 2025-04-01 from 2025-04-01 23:00:00.000000 to 2025-04-02 00:59:39.206000. 2025-04-02 07:04:57.145 | Loaded depth data records for F.US.MCLEK25 2025-04-02 from 2025-04-02 01:00:00.066000 to 2025-04-02 06:57:00.556733. 2025-04-02 07:04:57.209 | F.US.MCLEK25 [CB] 1 Min #12 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:04:57.241 | F.US.MCLEK25 [CB] 1 Min #12 | Chart data loading complete. 2025-04-02 07:04:57.830 | F.US.MCLEK25 [CBV] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:04:58.062 | F.US.MCLEK25 [CBV] 5 Min #15 | Chart data loading complete. 2025-04-02 07:04:58.282 | Opened cached Depth file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.ENQM25.2025-04-02.depth 2025-04-02 07:04:58.282 | Opened cached Depth file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.MCLEK25.2025-04-02.depth 2025-04-02 07:04:58.454 | HD Request # 14 | Sending historical data logon request message. 2025-04-02 07:04:59.022 | F.US.BP6M25 [CBV] 60 Min #6 | Chart data loading complete. 2025-04-02 07:04:59.757 | HD Request # 14 | Setting DTC encoding to Binary VLS 2025-04-02 07:04:59.757 | HD Request # 14 | Sending historical data logon request message. 2025-04-02 07:04:59.757 | Socket (2) | CloseSocket call. 2025-04-02 07:04:59.757 | HD Request # 14 | Error downloading historical Daily data for F.US.MBTV24. Historical data logon error: Unsupported protocol version 2025-04-02 07:04:59.757 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:04:59.757 | Historical data download thread signaled to stop. 2025-04-02 07:04:59.757 | HD Request # 14 | Received 0 Daily data records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for F.US.MBTV24 2025-04-02 07:04:59.757 | HD Request # 14 | Completion time: 11s. 2025-04-02 07:04:59.757 | HD Request # 14 | Daily data download complete for F.US.MBTV24. Unique request ID: 14 2025-04-02 07:04:59.757 | Removing historical data download ID 14. 2025-04-02 07:04:59.757 | 2025-04-02 07:04:59.757 | Triggering next historical data download in queue. 2025-04-02 07:04:59.759 | HD Request # 15 | Downloading Historical Daily chart data for F.US.MBTH25. Starting date: 2025-03-11. Service: DTCSubInstance 2025-04-02 07:04:59.759 | HD Request # 15 | Using server: 127.0.0.1 port 11098 2025-04-02 07:04:59.759 | Socket (3) | Creating socket. 2025-04-02 07:04:59.759 | Socket (3) | New receive buffer size: 0 2025-04-02 07:04:59.759 | Socket (3) | Connecting to IP: 127.0.0.1. 2025-04-02 07:04:59.761 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:04:59.761 | Socket (2) | Closed. 2025-04-02 07:05:02.118 | F.US.GCEM25 [CBV] 60 Min #10 | Chart data loading complete. 2025-04-02 07:05:02.304 | F.US.MCLEK25 [CBV] 60 Min #14 | Chart data loading complete. 2025-04-02 07:05:02.741 | HD Request # 15 | Setting DTC encoding to Binary VLS 2025-04-02 07:05:02.741 | HD Request # 15 | Sending historical data logon request message. 2025-04-02 07:05:02.741 | HD Request # 15 | Requesting historical Daily data starting at 2025-03-11. 2025-04-02 07:05:02.742 | HD Request # 15 | Decompressing data. 2025-04-02 07:05:02.746 | HD Request # 15 | Receiving historical Daily data for F.US.MBTH25 starting at 2025-03-11. 2025-04-02 07:05:02.746 | HD Request # 15 | Writing historical Daily data to the file F.US.MBTH25.dly. 2025-04-02 07:05:02.750 | Socket (3) | CloseSocket call. 2025-04-02 07:05:02.750 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-04-02 07:05:02.750 | Historical data download thread signaled to stop. 2025-04-02 07:05:02.750 | HD Request # 15 | Received 3 Daily data records from 2025-03-11 00:00:00 to 2025-03-13 00:00:00 (3.0 days) and wrote 3 records for F.US.MBTH25 2025-04-02 07:05:02.750 | HD Request # 15 | Completion time: 3s. 2025-04-02 07:05:02.750 | HD Request # 15 | Daily data download complete for F.US.MBTH25. Unique request ID: 15 2025-04-02 07:05:02.750 | Removing historical data download ID 15. 2025-04-02 07:05:02.750 | 2025-04-02 07:05:02.750 | Triggering next historical data download in queue. 2025-04-02 07:05:02.751 | Socket (3) | Socket gracefully closed by remote side. 2025-04-02 07:05:02.751 | Socket (3) | Closed. 2025-04-02 07:05:02.751 | HD Request # 16 | Downloading Intraday chart data for F.US.MBTJ25 to the file F.US.MBTJ25.scid. Service: cme 2025-04-02 07:05:02.751 | HD Request # 16 | Download start date-time: 2025-04-02 06:56:42.000000. File last date-time: 2025-04-02 06:56:42.786001 2025-04-02 07:05:02.752 | HD Request # 16 | Using server: ds26.sierracharts.com port 10150 2025-04-02 07:05:02.752 | Socket (2) | Creating socket. 2025-04-02 07:05:02.752 | Socket (2) | New receive buffer size: 0 2025-04-02 07:05:02.752 | Socket (2) | Connecting to IP: 64.152.155.17. 2025-04-02 07:05:03.011 | HD Request # 16 | Setting DTC encoding to Binary VLS 2025-04-02 07:05:03.011 | HD Request # 16 | Sending historical data logon request message. 2025-04-02 07:05:03.110 | Opened cached Intraday file: E:\SierraChart\SierraChartInstance_5\Data\F.US.ENQM25.scid. Thread ID: 17944 2025-04-02 07:05:03.169 | Opened cached Intraday file: E:\SierraChart\SierraChartInstance_5\Data\F.US.MCLEK25.scid. Thread ID: 17944 2025-04-02 07:05:03.178 | HD Request # 16 | Requesting Intraday data. Start date-time: 2025-04-02 06:56:42. Record interval: 0. Symbol: MBTJ25 2025-04-02 07:05:03.216 | F.US.ENQM25 [CBV] 5 Min #9 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:05:03.297 | HD Request # 16 | Decompressing data. 2025-04-02 07:05:03.418 | HD Request # 16 | Receiving Intraday data for F.US.MBTJ25 starting at 2025-04-02 06:56:42.691000 2025-04-02 07:05:03.418 | Socket (2) | CloseSocket call. 2025-04-02 07:05:03.418 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:05:03.538 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:05:03.538 | Socket (2) | Closed. 2025-04-02 07:05:03.554 | Chart #9 has tagged chart #4 for full recalculation. Chartbook: Trading2.Cht 2025-04-02 07:05:03.577 | F.US.ENQM25 [CBV] 5 Min #9 | Chart data loading complete. 2025-04-02 07:05:03.814 | Historical data download thread signaled to stop. 2025-04-02 07:05:03.814 | HD Request # 16 | Timestamp of first Intraday data file record written: 2025-04-02 06:57:06.751000. 2025-04-02 07:05:03.815 | HD Request # 16 | Received 130 Intraday data records from 2025-04-02 06:56:42.691000 to 2025-04-02 07:05:00.640000 (8.3 minutes. Delay: 3.2 seconds) and wrote 123 records for F.US.MBTJ25 2025-04-02 07:05:03.837 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2025-04-02 06:05:00.640000 2025-04-02 07:05:03.837 | HD Request # 16 | Completion time: 1s. 2025-04-02 07:05:03.837 | HD Request # 16 | Intraday data download complete for F.US.MBTJ25. Unique request ID: 16 2025-04-02 07:05:03.837 | Removing historical data download ID 16. 2025-04-02 07:05:03.837 | Real-time Intraday chart data file updates started for F.US.MBTJ25 2025-04-02 07:05:03.837 | Intraday chart data file opened for F.US.MBTJ25 2025-04-02 07:05:03.837 | HD Request # 16 | Enabling Intraday chart updating for symbol. 2025-04-02 07:05:03.837 | 2025-04-02 07:05:03.837 | Triggering next historical data download in queue. 2025-04-02 07:05:03.839 | HD Request # 17 | Downloading Historical Daily chart data for F.US.MBTJ25. Starting date: 2025-03-27. Service: DTCSubInstance 2025-04-02 07:05:03.839 | HD Request # 17 | Using server: 127.0.0.1 port 11098 2025-04-02 07:05:03.839 | Socket (2) | Creating socket. 2025-04-02 07:05:03.839 | Socket (2) | New receive buffer size: 0 2025-04-02 07:05:03.840 | Socket (2) | Connecting to IP: 127.0.0.1. 2025-04-02 07:05:03.949 | F.US.ENQM25 [CBV] 5 Min #9 | Reloading chart. 2025-04-02 07:05:04.304 | HD Request # 17 | Setting DTC encoding to Binary VLS 2025-04-02 07:05:04.304 | HD Request # 17 | Sending historical data logon request message. 2025-04-02 07:05:04.304 | HD Request # 17 | Requesting historical Daily data starting at 2025-03-27. 2025-04-02 07:05:04.304 | HD Request # 17 | Decompressing data. 2025-04-02 07:05:04.305 | HD Request # 17 | Receiving historical Daily data for F.US.MBTJ25 starting at 2025-03-27. 2025-04-02 07:05:04.305 | HD Request # 17 | Writing historical Daily data to the file F.US.MBTJ25.dly. 2025-04-02 07:05:04.307 | Socket (2) | CloseSocket call. 2025-04-02 07:05:04.307 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:05:04.307 | Historical data download thread signaled to stop. 2025-04-02 07:05:04.307 | HD Request # 17 | Received 4 Daily data records from 2025-03-27 00:00:00 to 2025-04-01 00:00:00 (6.0 days) and wrote 4 records for F.US.MBTJ25 2025-04-02 07:05:04.307 | HD Request # 17 | Completion time: 1s. 2025-04-02 07:05:04.307 | HD Request # 17 | Daily data download complete for F.US.MBTJ25. Unique request ID: 17 2025-04-02 07:05:04.307 | Removing historical data download ID 17. 2025-04-02 07:05:04.307 | 2025-04-02 07:05:04.307 | No download requests in the queue to start downloads for. 2025-04-02 07:05:04.307 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:05:04.307 | Socket (2) | Closed. 2025-04-02 07:05:04.341 | F.US.MBTJ25 [CB] 1 Min #13 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:05:04.341 | F.US.MBTJ25 [CB] 1 Min #13 | Reloading chart. 2025-04-02 07:05:04.376 | Loading market depth data. 2025-04-02 07:05:04.402 | F.US.MBTJ25 [CB] 1 Min #13 | Reloading chart. 2025-04-02 07:05:04.416 | Loaded depth data records for F.US.MBTJ25 2025-04-01 from 2025-04-01 23:00:00.074000 to 2025-04-02 00:59:55.470000. 2025-04-02 07:05:04.416 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.MBTJ25.2025-04-02.depth 2025-04-02 07:05:04.663 | Loaded depth data records for F.US.MBTJ25 2025-04-02 from 2025-04-02 01:00:00.072000 to 2025-04-02 06:57:00.556650. 2025-04-02 07:05:04.683 | F.US.MBTJ25 [CB] 1 Min #13 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:05:04.708 | F.US.MBTJ25 [CB] 1 Min #13 | Chart data loading complete. 2025-04-02 07:05:04.884 | F.US.MBTJ25 [CBV] 60 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:05:04.885 | F.US.MBTJ25 [CBV] 60 Min #18 | Reloading chart. 2025-04-02 07:05:05.114 | F.US.MBTJ25 [CBV] 5 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:05:05.116 | F.US.MBTJ25 [CBV] 5 Min #17 | Reloading chart. 2025-04-02 07:05:05.637 | F.US.MBTJ25 [CBV] 5 Min #17 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:05:05.806 | Chart #17 has tagged chart #13 for full recalculation. Chartbook: Trading2.Cht 2025-04-02 07:05:05.806 | Chart #17 has tagged chart #19 for full recalculation. Chartbook: Trading2.Cht 2025-04-02 07:05:05.822 | F.US.MBTJ25 [CBV] 5 Min #17 | Chart data loading complete. 2025-04-02 07:05:06.026 | Opened cached Depth file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.MBTJ25.2025-04-02.depth 2025-04-02 07:05:06.180 | F.US.EPM25 [CBV] 5 Min #23 | Chart data loading complete. 2025-04-02 07:05:06.411 | F.US.EU6M25 [CBV] 60 Min #2 | Chart data loading complete. 2025-04-02 07:05:06.530 | F.US.EPM25 [CBV] 5 Min #23 | Reloading chart. 2025-04-02 07:05:06.637 | F.US.MBTJ25 [CBV] 60 Min #18 | Reloading chart. 2025-04-02 07:05:07.247 | F.US.MBTJ25 [CBV] 5 Min #17 | Reloading chart. 2025-04-02 07:05:07.747 | F.US.MBTJ25 [CBV] 5 Min #17 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:05:07.971 | F.US.MBTJ25 [CBV] 5 Min #17 | Chart data loading complete. 2025-04-02 07:05:09.605 | Opened cached Intraday file: E:\SierraChart\SierraChartInstance_5\Data\F.US.MBTJ25.scid. Thread ID: 17944 2025-04-02 07:05:10.571 | F.US.EPM25 [CBV] 5 Min #20 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:05:10.684 | F.US.EPM25 [CBV] 5 Min #20 | Chart data loading complete. 2025-04-02 07:05:10.912 | F.US.EPM25 [CBV] 5 Min #20 | Reloading chart. 2025-04-02 07:05:12.258 | F.US.MBTJ25 [CBV] 60 Min #18 | Chart data loading complete. 2025-04-02 07:05:13.305 | F.US.ENQM25 [CBV] 5 Min #9 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:05:13.487 | F.US.ENQM25 [CBV] 5 Min #9 | Chart data loading complete. 2025-04-02 07:05:21.778 | F.US.EPM25 [CBV] 5 Min #23 | Chart data loading complete. 2025-04-02 07:05:24.926 | F.US.EPM25 [CBV] 5 Min #20 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:05:25.023 | F.US.EPM25 [CBV] 5 Min #20 | Chart data loading complete. 2025-04-02 07:06:09.474 | F.US.ENQM25 [CBV] 60 Min #1 | Chart data loading complete. 2025-04-02 07:07:02.967 | F.US.EPM25 [CBV] 60 Min #21 | Chart data loading complete. 2025-04-02 07:07:10.896 | F.US.EPM25 [CBV] 60 Min #24 | Chart data loading complete. 2025-04-02 07:07:10.896 | F.US.GCEM25 [CB] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Trading2.Cht 2025-04-02 07:07:10.909 | F.US.BP6M25 [CB] 1 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: Trading2.Cht 2025-04-02 07:07:10.921 | F.US.ENQM25 [CB] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: Trading2.Cht 2025-04-02 07:07:10.933 | F.US.EPM25 [CB] 1 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: Trading2.Cht 2025-04-02 07:07:10.942 | F.US.EU6M25 [CB] 1 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: Trading2.Cht 2025-04-02 07:07:10.958 | F.US.MBTJ25 [CB] 1 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Trading2.Cht 2025-04-02 07:13:51.959 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\F.US.EEUM25.scid 2025-04-02 07:13:51.959 | F.US.EEUM25 [CB] 1 Min #5 | Reloading chart. 2025-04-02 07:13:51.960 | Added historical Intraday data request for F.US.EEUM25 to the queue. 2025-04-02 07:13:51.960 | Triggering next historical data download in queue. 2025-04-02 07:13:51.962 | F.US.EEUM25 [CB] 1 Min #5 | Performing continuous chart historical Daily data download for symbol F.US.EEUM25 starting at last date in file. 2025-04-02 07:13:51.962 | Added historical Daily data request for F.US.EEUM25 to the queue. 2025-04-02 07:13:51.962 | F.US.EEUM25 [CB] 1 Min #5 | Waiting for historical downloads to complete with the IDs: 18, 19, 2025-04-02 07:13:51.963 | HD Request # 18 | Downloading Intraday chart data for F.US.EEUM25 to the file F.US.EEUM25.scid. Service: cme 2025-04-02 07:13:51.963 | HD Request # 18 | Download start date-time: 2025-02-27 00:00:00.000000. File last date-time: 00:00:00.000000 2025-04-02 07:13:51.964 | HD Request # 18 | Using server: ds28.sierracharts.com port 10150 2025-04-02 07:13:51.964 | Socket (2) | Creating socket. 2025-04-02 07:13:51.964 | Socket (2) | New receive buffer size: 0 2025-04-02 07:13:51.964 | Socket (2) | Connecting to IP: 67.214.125.5. 2025-04-02 07:13:52.179 | HD Request # 18 | Setting DTC encoding to Binary VLS 2025-04-02 07:13:52.179 | HD Request # 18 | Sending historical data logon request message. 2025-04-02 07:13:52.330 | HD Request # 18 | Requesting Intraday data. Start date-time: 2025-02-27 00:00:00. Record interval: 0. Symbol: E7M25 2025-04-02 07:13:52.433 | HD Request # 18 | Decompressing data. 2025-04-02 07:13:52.661 | HD Request # 18 | Receiving Intraday data for F.US.EEUM25 starting at 2025-02-27 00:04:44.287000 2025-04-02 07:13:52.891 | HD Request # 18 | Timestamp of first Intraday data file record written: 2025-02-27 00:04:44.287000. 2025-04-02 07:13:52.997 | Socket (2) | CloseSocket call. 2025-04-02 07:13:52.997 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:13:53.010 | Historical data download thread signaled to stop. 2025-04-02 07:13:53.010 | HD Request # 18 | Received 44760 Intraday data records from 2025-02-27 00:04:44.287000 to 2025-04-02 07:12:17.793000 (34.3 days. Delay: 95.2 seconds) and wrote 44760 records for F.US.EEUM25 2025-04-02 07:13:53.026 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2025-04-02 06:12:17.793000 2025-04-02 07:13:53.026 | HD Request # 18 | Completion time: 2s. 2025-04-02 07:13:53.026 | HD Request # 18 | Intraday data download complete for F.US.EEUM25. Unique request ID: 18 2025-04-02 07:13:53.026 | Removing historical data download ID 18. 2025-04-02 07:13:53.026 | Real-time Intraday chart data file updates started for F.US.EEUM25 2025-04-02 07:13:53.026 | Intraday chart data file opened for F.US.EEUM25 2025-04-02 07:13:53.026 | HD Request # 18 | Enabling Intraday chart updating for symbol. 2025-04-02 07:13:53.026 | 2025-04-02 07:13:53.026 | Triggering next historical data download in queue. 2025-04-02 07:13:53.027 | HD Request # 19 | Downloading Historical Daily chart data for F.US.EEUM25. Starting date: 1975-04-15. Service: DTCSubInstance 2025-04-02 07:13:53.028 | HD Request # 19 | Using server: 127.0.0.1 port 11098 2025-04-02 07:13:53.028 | Socket (3) | Creating socket. 2025-04-02 07:13:53.028 | Socket (3) | New receive buffer size: 0 2025-04-02 07:13:53.028 | Socket (3) | Connecting to IP: 127.0.0.1. 2025-04-02 07:13:53.097 | HD Request # 19 | Setting DTC encoding to Binary VLS 2025-04-02 07:13:53.097 | HD Request # 19 | Sending historical data logon request message. 2025-04-02 07:13:53.098 | HD Request # 19 | Requesting historical Daily data starting at 1975-04-15. 2025-04-02 07:13:53.098 | HD Request # 19 | Decompressing data. 2025-04-02 07:13:53.100 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:13:53.100 | Socket (2) | Closed. 2025-04-02 07:13:53.100 | HD Request # 19 | Receiving historical Daily data for F.US.EEUM25 starting at 2024-12-02. 2025-04-02 07:13:53.101 | HD Request # 19 | Writing historical Daily data to the file F.US.EEUM25.dly. 2025-04-02 07:13:53.102 | Socket (3) | CloseSocket call. 2025-04-02 07:13:53.102 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-04-02 07:13:53.103 | Socket (3) | Socket gracefully closed by remote side. 2025-04-02 07:13:53.103 | Socket (3) | Closed. 2025-04-02 07:13:53.109 | Historical data download thread signaled to stop. 2025-04-02 07:13:53.109 | HD Request # 19 | Received 83 Daily data records from 2024-12-02 00:00:00 to 2025-04-01 00:00:00 (121.0 days) and wrote 83 records for F.US.EEUM25 2025-04-02 07:13:53.109 | HD Request # 19 | Completion time: 0s. 2025-04-02 07:13:53.109 | HD Request # 19 | Daily data download complete for F.US.EEUM25. Unique request ID: 19 2025-04-02 07:13:53.109 | Removing historical data download ID 19. 2025-04-02 07:13:53.109 | 2025-04-02 07:13:53.109 | No download requests in the queue to start downloads for. 2025-04-02 07:13:53.117 | F.US.EEUM25 [CB] 1 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:13:53.117 | F.US.EEUM25 [CB] 1 Min #5 | Reloading chart. 2025-04-02 07:13:53.131 | Loading market depth data. 2025-04-02 07:13:53.133 | F.US.EEUM25 [CB] 1 Min #5 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:13:53.138 | F.US.EEUM25 [CB] 1 Min #5 | Chart data loading complete. 2025-04-02 07:13:53.159 | F.US.EEUM25 [CB] 1 Min #5 | Reloading chart. 2025-04-02 07:13:53.160 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\F.US.EEUM25.dly 2025-04-02 07:13:53.177 | Loading market depth data. 2025-04-02 07:13:53.179 | F.US.EEUM25 [CB] 1 Min #5 | StartDateTimeForLoadingOrderFills: 23:00:00 2025-04-02 07:13:53.184 | F.US.EEUM25 [CB] 1 Min #5 | Chart data loading complete. 2025-04-02 07:13:53.188 | DTC - Sub Instance | Starting real-time market data updates for: F.US.EEUM25. ID: 10 Service code: cqg 2025-04-02 07:13:53.188 | DTC - Sub Instance | Requesting security definition data for: F.US.EEUM25. ID: 10 2025-04-02 07:13:53.188 | Requesting market depth updates for: F.US.EEUM25 if supported. NumLevels=1400 2025-04-02 07:13:53.193 | DTC - Sub Instance | Clearing market depth for F.US.EEUM25 2025-04-02 07:13:53.193 | Opened cached Depth file: E:\SierraChart\SierraChartInstance_5\Data\MarketDepthData\F.US.EEUM25.2025-04-02.depth 2025-04-02 07:13:53.193 | DTC - Sub Instance | Clearing market depth for F.US.EEUM25 2025-04-02 07:13:53.193 | DTC - Sub Instance | Setting external service identifier for symbol F.US.EEUM25 to 42046875 2025-04-02 07:13:53.193 | DTC - Sub Instance | Received security definition for symbol F.US.EEUM25 2025-04-02 07:14:03.625 | F.US.EEUM25 [CBV] 5 Min #3 | Reloading chart. 2025-04-02 07:14:03.626 | Added historical Intraday data request for F.US.EEUH25 to the queue. 2025-04-02 07:14:03.626 | Triggering next historical data download in queue. 2025-04-02 07:14:03.627 | F.US.EEUM25 [CBV] 5 Min #3 | Performing continuous chart historical Daily data download for symbol F.US.EEUH25 starting at last date in file. 2025-04-02 07:14:03.627 | Added historical Daily data request for F.US.EEUH25 to the queue. 2025-04-02 07:14:03.631 | F.US.EEUM25 [CBV] 5 Min #3 | Waiting for historical downloads to complete with the IDs: 20, 21, 2025-04-02 07:14:03.631 | HD Request # 20 | Downloading Intraday chart data for F.US.EEUH25 to the file F.US.EEUH25.scid. Service: cme 2025-04-02 07:14:03.632 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\F.US.EEUH25.scid 2025-04-02 07:14:03.632 | HD Request # 20 | Download start date-time: 2024-11-28 00:00:00.000000. File last date-time: 00:00:00.000000 2025-04-02 07:14:03.632 | HD Request # 20 | Using server: ds32.sierracharts.com port 10150 2025-04-02 07:14:03.632 | Socket (2) | Creating socket. 2025-04-02 07:14:03.632 | Socket (2) | New receive buffer size: 0 2025-04-02 07:14:03.632 | Socket (2) | Connecting to IP: 67.214.125.3. 2025-04-02 07:14:03.853 | HD Request # 20 | Setting DTC encoding to Binary VLS 2025-04-02 07:14:03.853 | HD Request # 20 | Sending historical data logon request message. 2025-04-02 07:14:04.013 | HD Request # 20 | Requesting Intraday data. Start date-time: 2024-11-28 00:00:00. Record interval: 0. Symbol: E7H25 2025-04-02 07:14:04.118 | HD Request # 20 | Decompressing data. 2025-04-02 07:14:04.352 | HD Request # 20 | Receiving Intraday data for F.US.EEUH25 starting at 2024-11-28 00:50:24.720000 2025-04-02 07:14:04.595 | HD Request # 20 | Timestamp of first Intraday data file record written: 2024-11-28 00:50:24.720000. 2025-04-02 07:14:07.929 | Socket (2) | CloseSocket call. 2025-04-02 07:14:07.929 | Historical data download thread signaled to stop. 2025-04-02 07:14:07.929 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-02 07:14:07.930 | HD Request # 20 | Received 289654 Intraday data records from 2024-11-28 00:50:24.720000 to 2025-03-17 14:09:25.686000 (109.6 days. Delay: 15.7 days) and wrote 289654 records for F.US.EEUH25 2025-04-02 07:14:07.941 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2025-03-17 14:09:25.686000 2025-04-02 07:14:07.941 | HD Request # 20 | Completion time: 4s. 2025-04-02 07:14:07.941 | HD Request # 20 | Intraday data download complete for F.US.EEUH25. Unique request ID: 20 2025-04-02 07:14:07.941 | Removing historical data download ID 20. 2025-04-02 07:14:07.941 | Real-time Intraday chart data file updates started for F.US.EEUH25 2025-04-02 07:14:07.941 | Intraday chart data file opened for F.US.EEUH25 2025-04-02 07:14:07.941 | HD Request # 20 | Enabling Intraday chart updating for symbol. 2025-04-02 07:14:07.941 | 2025-04-02 07:14:07.941 | Triggering next historical data download in queue. 2025-04-02 07:14:07.941 | HD Request # 21 | Downloading Historical Daily chart data for F.US.EEUH25. Starting date: 1975-04-15. Service: DTCSubInstance 2025-04-02 07:14:07.941 | HD Request # 21 | Using server: 127.0.0.1 port 11098 2025-04-02 07:14:07.941 | Socket (3) | Creating socket. 2025-04-02 07:14:07.942 | Socket (3) | New receive buffer size: 0 2025-04-02 07:14:07.942 | Socket (3) | Connecting to IP: 127.0.0.1. 2025-04-02 07:14:07.986 | HD Request # 21 | Setting DTC encoding to Binary VLS 2025-04-02 07:14:07.986 | HD Request # 21 | Sending historical data logon request message. 2025-04-02 07:14:07.986 | HD Request # 21 | Requesting historical Daily data starting at 1975-04-15. 2025-04-02 07:14:07.987 | HD Request # 21 | Decompressing data. 2025-04-02 07:14:07.988 | HD Request # 21 | Receiving historical Daily data for F.US.EEUH25 starting at 2024-07-24. 2025-04-02 07:14:07.988 | HD Request # 21 | Writing historical Daily data to the file F.US.EEUH25.dly. 2025-04-02 07:14:07.989 | Socket (3) | CloseSocket call. 2025-04-02 07:14:07.989 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-04-02 07:14:07.989 | Historical data download thread signaled to stop. 2025-04-02 07:14:07.989 | HD Request # 21 | Received 140 Daily data records from 2024-07-24 00:00:00 to 2025-03-17 00:00:00 (237.0 days) and wrote 140 records for F.US.EEUH25 2025-04-02 07:14:07.989 | HD Request # 21 | Completion time: 0s. 2025-04-02 07:14:07.989 | HD Request # 21 | Daily data download complete for F.US.EEUH25. Unique request ID: 21 2025-04-02 07:14:07.989 | Removing historical data download ID 21. 2025-04-02 07:14:07.989 | 2025-04-02 07:14:07.989 | No download requests in the queue to start downloads for. 2025-04-02 07:14:07.990 | Socket (3) | Socket gracefully closed by remote side. 2025-04-02 07:14:07.990 | Socket (3) | Closed. 2025-04-02 07:14:08.040 | Socket (2) | Socket gracefully closed by remote side. 2025-04-02 07:14:08.040 | Socket (2) | Closed. 2025-04-02 07:14:08.631 | F.US.EEUM25 [CBV] 5 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2025-04-02 07:14:08.632 | F.US.EEUM25 [CBV] 5 Min #3 | Reloading chart. 2025-04-02 07:14:08.636 | Enabling compression for file: E:\SierraChart\SierraChartInstance_5\Data\F.US.EEUH25.dly 2025-04-02 07:14:08.686 | F.US.EEUM25 [CBV] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:14:08.754 | Chart #3 has tagged chart #5 for full recalculation. Chartbook: Trading2.Cht 2025-04-02 07:14:08.761 | F.US.EEUM25 [CBV] 5 Min #3 | Chart data loading complete. 2025-04-02 07:14:08.841 | F.US.EEUM25 [CB] 1 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: Trading2.Cht 2025-04-02 07:14:09.638 | F.US.EEUM25 [CBV] 5 Min #3 | Reloading chart. 2025-04-02 07:14:09.699 | F.US.EEUM25 [CBV] 5 Min #3 | StartDateTimeForLoadingOrderFills: 2024-03-26 00:00:00 2025-04-02 07:14:09.753 | Chart #3 has tagged chart #5 for full recalculation. Chartbook: Trading2.Cht 2025-04-02 07:14:09.759 | F.US.EEUM25 [CBV] 5 Min #3 | Chart data loading complete. 2025-04-02 07:14:09.826 | F.US.EEUM25 [CB] 1 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: Trading2.Cht 2025-04-02 07:14:21.300 | Opened cached Intraday file: E:\SierraChart\SierraChartInstance_5\Data\F.US.EEUM25.scid. Thread ID: 17944 |
[2025-04-02 15:32:44] |
John - SC Support - Posts: 39274 |
You are not setup to get the Level 2 data for the CME Group, but you should be getting it for EUREX. You have the "Full CME Group (CME, CBOT, COMEX, NYMEX) for Non-Professional Trading Accounts" active. This does not include the Market Depth data. If you want the Market Depth data for the full CME Group, then you would need the "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for Non-Professional Trading Accounts". Or, if you only need Market Depth for some instruments, then you could just also activate the individual exchange, such as the "CME with Market Depth for Non-Professional Trading Accounts", which would give you Market Depth for the CME exchange, while you continue to get data without Market Depth for the CBOT, COMEX, and NYMEX from the "Full CME Group" option you already have activated. Refer to the following for how to change exchange selections: Denali Exchange Data Feed: Changing Denali Exchange Data Feed Exchange Selections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-04-02 16:32:55] |
User518718 - Posts: 10 |
thanks for the prompt response John I appreciate it. Im not getting any level 2 data on the EUREX side? I will make sure both market depth packages are paid for. But im curious to why the EUREX products arent giving me any depth in the book? Ive tried all the other steps I can find on support board. |
[2025-04-02 17:18:50] |
Please get us your Message Log by following these instructions for a EUREX symbol: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-04-03 06:15:32] |
Hi John, Please see below It appears my doms market depth are working now if I navigate to - Find Symbol > Open Trading DOM But if I try to use a dom thats saved to my chartbook It doese not display market depth. Is this down to maybe not having it correctly saved on my main sierra instance? 2025-04-03 07:05:58.897 | Software version: 2661 64-bit 2025-04-03 07:05:58.897 | Primary Thread ID: 8544 2025-04-03 07:05:58.897 | Usage end date: 2025-04-04 2025-04-03 07:05:58.897 | Enabled for: Advanced Features 2. 2025-04-03 07:05:58.897 | Enabled for: Sierra Chart Historical Data Service. 2025-04-03 07:05:58.897 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-04-03 07:05:58.897 | Enabled for: Delayed Denali Exchange Data Feed. 2025-04-03 07:05:58.897 | Enabled for exchange2: CME (Trading Account Required) 2025-04-03 07:05:58.897 | Enabled for exchange2: CBOT (Trading Account Required) 2025-04-03 07:05:58.897 | Enabled for exchange2: COMEX (Trading Account Required) 2025-04-03 07:05:58.897 | Enabled for exchange2: NYMEX (Trading Account Required) 2025-04-03 07:05:58.897 | Enabled for exchange2: EUREX EOBI 2025-04-03 07:05:58.897 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-04-03 07:05:58.897 | Current selected Data/Trading service: DTC - Sub Instance 2025-04-03 07:05:58.897 | Custom symbol settings values: enabled 2025-04-03 07:05:58.897 | Chart Update Interval: 500 2025-04-03 07:05:58.897 | Intraday Data Storage Time Unit: 0 2025-04-03 07:05:58.897 | Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) 2025-04-03 07:05:58.897 | 2025-04-03 06:05:58 Local computer time in UTC 2025-04-03 07:05:58.897 | 2025-04-03 07:05:58 Local computer time in SC Time Zone 2025-04-03 07:05:58.897 | 2025-04-03 06:04:39 Server time in UTC 2025-04-03 07:05:58.897 | Local computer UTC time and Server UTC time difference: 1 seconds. 2025-04-03 07:05:58.897 | Program path: E:\SierraChart\SierraChartInstance_6\ 2025-04-03 07:05:58.897 | Data Files path: E:\SierraChart\SierraChartInstance_6\Data\ 2025-04-03 07:05:58.897 | OS Version Number: 10.0 2025-04-03 07:05:58.897 | Locale Setting: C 2025-04-03 07:05:58.897 | DLLs: CustomSwingHighLow_64.dll, UserContributedStudies_64.dll 2025-04-03 07:05:58.897 | Allowed protected custom studies: 2025-04-03 07:05:58.897 | Crash reporter started: true 2025-04-03 07:05:58.897 | 2025-04-03 07:05:59.106 | Performing login for updated account information. 2025-04-03 07:06:00.254 | Successfully processed Sierra Chart account data. 2025-04-03 07:06:00.254 | Requested user files to download. 2025-04-03 07:06:10.100 | Saved Chartbook: Trading1.Cht. Time: 0.0423 seconds. 2025-04-03 07:06:34.770 | F.US.DBM25 #1 | Reloading chart. 2025-04-03 07:06:34.771 | F.US.DBM25 #1 | StartDateTimeForLoadingOrderFills: 2025-03-20 00:00:00 2025-04-03 07:06:34.823 | F.US.DBM25 #1 | Chart data loading complete. 2025-04-03 07:06:55.735 | F.US.DBM25 #2 | Reloading chart. 2025-04-03 07:06:55.736 | F.US.DBM25 #2 | StartDateTimeForLoadingOrderFills: 2025-03-20 00:00:00 2025-04-03 07:06:55.788 | F.US.DBM25 #2 | Chart data loading complete. 2025-04-03 07:12:27.553 | F.US.DBM25 1 Min #3 | Reloading chart. 2025-04-03 07:12:28.742 | F.US.DBM25 1 Min #3 | Chart data loading complete. 2025-04-03 07:12:37.720 | File >> Disconnect selected. 2025-04-03 07:12:37.720 | DTC - Sub Instance | Waiting for socket receive thread to end 2025-04-03 07:12:37.721 | DTC Client socket (1) | CloseSocket call. 2025-04-03 07:12:37.721 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2025-04-03 07:12:37.723 | DTC - Sub Instance | Disconnected. 2025-04-03 07:12:37.835 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-04-03 07:12:37.835 | DTC Client socket (1) | Closed. 2025-04-03 07:12:43.240 | 2025-04-03 07:12:43.240 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2025-04-03 07:12:43.240 | DTC Client socket (1) | Creating socket. 2025-04-03 07:12:43.240 | DTC Client socket (1) | New receive buffer size: 0 2025-04-03 07:12:43.240 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2025-04-03 07:12:43.241 | DTC - Sub Instance | Network connection to server complete. 2025-04-03 07:12:43.241 | DTC - Sub Instance | Starting socket receive thread. 2025-04-03 07:12:43.241 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2025-04-03 07:12:43.242 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2025-04-03 07:12:43.242 | DTC - Sub Instance | Sending logon request message. 2025-04-03 07:12:43.242 | DTC - Sub Instance | Received logon response. 2025-04-03 07:12:43.242 | DTC - Sub Instance | Server Name: SC DTC Server. Build=50860M. 2025-04-03 07:12:43.242 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2025-04-03 07:12:43.242 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg. 2025-04-03 07:12:43.242 | DTC - Sub Instance | Trading is supported. 2025-04-03 07:12:43.242 | DTC - Sub Instance | Order cancel and replace is supported. 2025-04-03 07:12:43.242 | DTC - Sub Instance | OCO Orders supported. 2025-04-03 07:12:43.242 | DTC - Sub Instance | Bracket Orders supported. 2025-04-03 07:12:43.242 | DTC - Sub Instance | MarketDepthIsSupported: 1 2025-04-03 07:12:43.242 | DTC - Sub Instance | Connected to server complete. 2025-04-03 07:12:43.245 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-04-03 07:12:43.247 | Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 2. 2025-04-03 07:12:43.415 | Using symbol data fast lookup vector 2025-04-03 07:12:43.415 | DTC - Sub Instance | Starting real-time market data updates for: F.US.DBM25. ID: 1 Service code: cqg 2025-04-03 07:12:43.415 | DTC - Sub Instance | Requesting security definition data for: F.US.DBM25. ID: 1 2025-04-03 07:12:43.415 | Added historical Intraday data request for F.US.DBM25 to the queue. 2025-04-03 07:12:43.415 | Intraday data recording state for symbol F.US.DBM25 is set to download 'Pending'. 2025-04-03 07:12:43.415 | Triggering next historical data download in queue. 2025-04-03 07:12:43.419 | Delaying start of download for F.US.DBM25. 2025-04-03 07:12:43.425 | DTC - Sub Instance | Setting external service identifier for symbol F.US.DBM25 to 11820389 2025-04-03 07:12:43.425 | DTC - Sub Instance | Received security definition for symbol F.US.DBM25 2025-04-03 07:12:45.141 | Symbol settings MD5 received. Request ID: 2. 2025-04-03 07:12:45.141 | Symbol settings are up-to-date for cqg. 2025-04-03 07:12:48.245 | Requesting market depth updates for: F.US.DBM25 if supported. NumLevels=1400 2025-04-03 07:12:48.245 | DTC - Sub Instance | Starting market orders updates for: F.US.DBM25. MinimumMarketByOrderQuantity: 100. Service code: cqg 2025-04-03 07:12:48.247 | HD Request # 84 | Downloading Intraday chart data for F.US.DBM25 to the file F.US.DBM25.scid. Service: eurex 2025-04-03 07:12:48.247 | HD Request # 84 | Download start date-time: 2025-04-03 07:12:37.000000. File last date-time: 2025-04-03 07:12:37.557000 2025-04-03 07:12:48.247 | HD Request # 84 | Using server: ds14.sierracharts.com port 10150 2025-04-03 07:12:48.247 | DTC - Sub Instance | Clearing market depth for F.US.DBM25 2025-04-03 07:12:48.259 | Socket (2) | Creating socket. 2025-04-03 07:12:48.259 | Socket (2) | New receive buffer size: 0 2025-04-03 07:12:48.260 | Socket (2) | Connecting to IP: 176.9.9.252. 2025-04-03 07:12:48.338 | HD Request # 84 | Setting DTC encoding to Binary VLS 2025-04-03 07:12:48.338 | HD Request # 84 | Sending historical data logon request message. 2025-04-03 07:12:48.852 | HD Request # 84 | Requesting Intraday data. Start date-time: 2025-04-03 07:12:37. Record interval: 0. Symbol: FGBL202506_FUT_EUREX 2025-04-03 07:12:48.889 | HD Request # 84 | Decompressing data. 2025-04-03 07:12:48.925 | HD Request # 84 | Receiving Intraday data for F.US.DBM25 starting at 2025-04-03 07:12:37.464000 2025-04-03 07:12:48.926 | Socket (2) | CloseSocket call. 2025-04-03 07:12:48.926 | Socket (2) | Shutdown started. Waiting for graceful close. 2025-04-03 07:12:48.927 | Historical data download thread signaled to stop. 2025-04-03 07:12:48.927 | HD Request # 84 | Timestamp of first Intraday data file record written: 2025-04-03 07:12:38.047000. 2025-04-03 07:12:48.927 | HD Request # 84 | Received 119 Intraday data records from 2025-04-03 07:12:37.464000 to 2025-04-03 07:12:46.638005 (9.2 seconds. Delay: 2.3 seconds) and wrote 98 records for F.US.DBM25 2025-04-03 07:12:48.936 | HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2025-04-03 06:12:46.638005 2025-04-03 07:12:48.936 | Added 4 Time and Sales records to Intraday data file for F.US.DBM25 after download. 2025-04-03 07:12:48.937 | HD Request # 84 | Completion time: 0s. 2025-04-03 07:12:48.937 | HD Request # 84 | Intraday data download complete for F.US.DBM25. Unique request ID: 85 2025-04-03 07:12:48.937 | Removing historical data download ID 85. 2025-04-03 07:12:48.937 | Real-time Intraday chart data file updates started for F.US.DBM25 2025-04-03 07:12:48.937 | Intraday chart data file opened for F.US.DBM25 2025-04-03 07:12:48.937 | HD Request # 84 | Enabling Intraday chart updating for symbol. 2025-04-03 07:12:48.937 | 2025-04-03 07:12:48.937 | No download requests in the queue to start downloads for. 2025-04-03 07:12:48.968 | Socket (2) | Socket gracefully closed by remote side. 2025-04-03 07:12:48.968 | Socket (2) | Closed. 2025-04-03 07:12:56.145 | Opened cached Intraday file: E:\SierraChart\SierraChartInstance_6\Data\F.US.DBM25.scid. Thread ID: 10884 |
[2025-04-03 13:42:24] |
We do see that the request for Market Depth data is being made, so there is no issue there. With regards to seeing the depth in one DOM and not another, refer to the following: Global Trade Settings Windows: Troubleshooting Market Depth Data Not Displaying in Chart/Trade DOM Columns For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
