Date/Time: Tue, 22 Apr 2025 02:18:39 +0000
Why is my data not showing?
View Count: 1082
[2025-01-27 04:24:46] |
User328099 - Posts: 23 |
Not sure why my data stop working? I am already connected to my trading account. it is something to do with my renewals for my data?
[2025-01-27 07:13:14] |
Sierra_Chart Engineering - Posts: 19290 |
The reason you are not getting real-time data from the Denali Data Feed, and historical data from the Denali Data Feed in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported Trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-27 07:13:54
[2025-02-01 23:32:30] |
Yes! but i am using APEX Funding which i used before and i have my login there! so it makes no sense that my data is not showing, it clear i am not its not working! nothing has changed and this started happening last week. before that it was working why is it not letting me? see i cant even make a sim trade 2025-02-01 23:24:50.780 | Trade Order Error - Cannot submit non-simulated order when in Trade Simulation Mode. Internal Order ID: 12603. Service Order ID: (none). Symbol: MNQH5.CME. Account: APEX-75672-50 *
![]() Attachment Deleted. |
[2025-02-01 23:45:07] |
So how do i do this? "However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees" where am i suppose to verify?
[2025-02-02 23:55:50] |
It works for SC Data - All Services, but when i flip it to Rithmic Direct DTC, it does not work! no data is showing, it just freezes the data, what is causing this and how do we fix this? because its really frustrating me and itw as working before the 27th
Date Time Of Last Edit: 2025-02-03 00:08:32
[2025-02-03 00:17:01] |
Do you have any other live funded futures trading account to authorize the CME data that you have activated in your Sierra Chart account? For now in Global Settings >> Data/Trade Service Settings, enter your Rithmic username and password in the Market Data and Historical Data username and password boxes. After this reconnect with File >> Reconnect. Also disable Trade Simulation Mode: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-03 00:18:14
[2025-02-03 01:01:09] |
I am using Apex Trader, i only have 1 account with 3 evaluation in it, so I am not sure how to answer that questions exactly, but all the evaluation accounts are onnected to my main account APEX-75672 and i have already sign in with password, when i do all data stops, and it happened on the 27th which means before that i had no issues trading at all! it was going well. and i know its not APEX because i have been on there case for a week, so its something on Sierra Chart thats not working, what do you need to resolve this, my message logs? what can i do to help you find the problem so we can come up with the solution. already almost 5 days passed and its still not solved? do you need my message log? because its not working and I dont know how to fix this! Also i tried everything you said above it has not worked. Date Time Of Last Edit: 2025-02-03 01:47:54
[2025-02-03 04:10:22] |
Notice: Not connected to Live trading account to receive CME real-time futures data at non-professional fees. why does it say this? can you please check because i am using an account from apex funding trading for an evaluation account so i am a non-pro trader! where are my logs: 2025-02-03 03:54:58.571 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated 2025-02-03 03:54:58.571 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528 2025-02-03 03:54:58.571 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 2025-02-03 03:54:58.619 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-02-03 03:54:58.619 | DTC Client socket (1) | New receive buffer size: 0 2025-02-03 03:54:58.619 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2025-02-03 03:54:58.703 | Rithmic Direct - DTC | Network connection to server complete. 2025-02-03 03:54:58.703 | Rithmic Direct - DTC | Starting socket receive thread. 2025-02-03 03:54:58.703 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2025-02-03 03:54:58.703 | Rithmic Direct - DTC | Sending logon request message. 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | Received logon response. 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | Server Name: . 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | Successfully connected. 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | Trading is supported. 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | Order cancel and replace is supported. 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | OCO Orders supported. 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2025-02-03 03:54:58.772 | Rithmic Direct - DTC | Connected to server complete. 2025-02-03 03:54:58.774 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-02-03 03:54:58.774 | Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. 2025-02-03 03:54:58.928 | Using symbol data fast lookup vector 2025-02-03 03:54:58.928 | Rithmic Direct - DTC | Starting real-time market data updates for: MNQH5.CME. ID: 1 Service code: rithmic.trading 2025-02-03 03:54:58.928 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: MNQH5.CME. 2025-02-03 03:54:58.928 | Rithmic Direct - DTC | Requesting security definition data for: MNQH5.CME. ID: 1 2025-02-03 03:54:58.928 | Rithmic Direct - DTC | Using primary service for historical data for MNQH5.CME 2025-02-03 03:54:58.928 | Historical data service client indicated that downloads are not enabled. Symbol: MNQH5.CME. Data Type: Intraday data. 2025-02-03 03:54:58.928 | Historical data download ID 236 not found when removing ID from outstanding request set. 2025-02-03 03:54:58.928 | Real-time Intraday chart data file updates started for MNQH5.CME 2025-02-03 03:54:58.928 | Intraday chart data file opened for MNQH5.CME 2025-02-03 03:54:59.090 | Rithmic Direct - DTC | Starting real-time market data updates for: MNQH25-CME. ID: 2 2025-02-03 03:54:59.090 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: MNQH25-CME. 2025-02-03 03:54:59.090 | Rithmic Direct - DTC | Requesting security definition data for: MNQH25-CME. ID: 2 2025-02-03 03:54:59.090 | Rithmic Direct - DTC | Using primary service for historical data for MNQH25-CME 2025-02-03 03:54:59.090 | Historical data service client indicated that downloads are not enabled. Symbol: MNQH25-CME. Data Type: Intraday data. 2025-02-03 03:54:59.091 | Historical data download ID 237 not found when removing ID from outstanding request set. 2025-02-03 03:54:59.091 | Real-time Intraday chart data file updates started for MNQH25-CME 2025-02-03 03:54:59.091 | Intraday chart data file opened for MNQH25-CME 2025-02-03 03:55:03.660 | Rithmic Direct - DTC | Starting real-time market data updates for: CLK20-NYMEX. ID: 3 2025-02-03 03:55:03.660 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: CLK20-NYMEX. 2025-02-03 03:55:03.660 | Rithmic Direct - DTC | Requesting security definition data for: CLK20-NYMEX. ID: 3 2025-02-03 03:55:03.668 | Rithmic Direct - DTC | Starting real-time market data updates for: CLM20-NYMEX. ID: 4 2025-02-03 03:55:03.668 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: CLM20-NYMEX. 2025-02-03 03:55:03.668 | Rithmic Direct - DTC | Requesting security definition data for: CLM20-NYMEX. ID: 4 2025-02-03 03:55:03.670 | Rithmic Direct - DTC | Starting real-time market data updates for: CLN20-NYMEX. ID: 5 2025-02-03 03:55:03.670 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: CLN20-NYMEX. 2025-02-03 03:55:03.670 | Rithmic Direct - DTC | Requesting security definition data for: CLN20-NYMEX. ID: 5 2025-02-03 03:55:03.671 | Rithmic Direct - DTC | Starting real-time market data updates for: ESM20-CME. ID: 6 2025-02-03 03:55:03.671 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESM20-CME. 2025-02-03 03:55:03.671 | Rithmic Direct - DTC | Requesting security definition data for: ESM20-CME. ID: 6 2025-02-03 03:55:03.671 | Rithmic Direct - DTC | Starting real-time market data updates for: ESU20-CME. ID: 7 2025-02-03 03:55:03.671 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESU20-CME. 2025-02-03 03:55:03.671 | Rithmic Direct - DTC | Requesting security definition data for: ESU20-CME. ID: 7 2025-02-03 03:55:03.677 | Rithmic Direct - DTC | Starting real-time market data updates for: ESZ20-CME. ID: 8 2025-02-03 03:55:03.677 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESZ20-CME. 2025-02-03 03:55:03.677 | Rithmic Direct - DTC | Requesting security definition data for: ESZ20-CME. ID: 8 2025-02-03 03:55:03.819 | Requesting market depth updates for: MNQH25-CME if supported. NumLevels=1400 2025-02-03 03:55:03.819 | Separate subscription for market depth updates not supported. MNQH25-CME 2025-02-03 03:55:03.819 | Requesting market depth updates for: MNQH5.CME if supported. NumLevels=100 2025-02-03 03:55:03.819 | Separate subscription for market depth updates not supported. MNQH5.CME 2025-02-03 03:55:09.546 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-02-03 03:55:09.546 | DTC Client socket (3) | Socket gracefully closed by remote side. 2025-02-03 03:55:09.547 | DTC Client socket (3) | Closed. 2025-02-03 03:55:10.601 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-02-03 03:55:10.601 | DTC Client socket (4) | Socket gracefully closed by remote side. 2025-02-03 03:55:10.601 | DTC Client socket (4) | Closed. 2025-02-03 03:55:10.665 | Rithmic Direct - DTC | Starting real-time market data updates for: YMZ24-CBOT. ID: 9 2025-02-03 03:55:10.665 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: YMZ24-CBOT. 2025-02-03 03:55:10.665 | Rithmic Direct - DTC | Requesting security definition data for: YMZ24-CBOT. ID: 9 2025-02-03 03:55:10.665 | Rithmic Direct - DTC | Using primary service for historical data for YMZ24-CBOT 2025-02-03 03:55:10.665 | Historical data service client indicated that downloads are not enabled. Symbol: YMZ24-CBOT. Data Type: Intraday data. 2025-02-03 03:55:10.665 | Historical data download ID 238 not found when removing ID from outstanding request set. 2025-02-03 03:55:10.665 | Real-time Intraday chart data file updates started for YMZ24-CBOT 2025-02-03 03:55:10.665 | Intraday chart data file opened for YMZ24-CBOT 2025-02-03 03:55:12.552 | Rithmic Direct - DTC | Starting real-time market data updates for: BTCUSD_PERP_BINANCE. ID: 10 2025-02-03 03:55:12.552 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: BTCUSD_PERP_BINANCE. 2025-02-03 03:55:12.552 | Rithmic Direct - DTC | Requesting security definition data for: BTCUSD_PERP_BINANCE. ID: 10 2025-02-03 03:55:12.552 | Rithmic Direct - DTC | Using primary service for historical data for BTCUSD_PERP_BINANCE 2025-02-03 03:55:12.552 | Historical data service client indicated that downloads are not enabled. Symbol: BTCUSD_PERP_BINANCE. Data Type: Intraday data. 2025-02-03 03:55:12.552 | Historical data download ID 239 not found when removing ID from outstanding request set. 2025-02-03 03:55:12.552 | Real-time Intraday chart data file updates started for BTCUSD_PERP_BINANCE 2025-02-03 03:55:12.552 | Intraday chart data file opened for BTCUSD_PERP_BINANCE 2025-02-03 03:55:12.553 | Mapping AAPL to AAPL. Service code: us_equities_utp_cta_exchange.data 2025-02-03 03:55:12.553 | Delayed Data Feed | Starting real-time market data updates for: AAPL (AAPL). ID: 11 Service code: us_equities_utp_cta_exchange.data 2025-02-03 03:55:12.553 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043 2025-02-03 03:55:12.553 | Delayed Data Feed | Requesting security definition data for: AAPL (AAPL). ID: 11 2025-02-03 03:55:12.553 | Added historical Intraday data request for AAPL to the queue. 2025-02-03 03:55:12.553 | Intraday data recording state for symbol AAPL is set to download 'Pending'. 2025-02-03 03:55:12.553 | Triggering next historical data download in queue. 2025-02-03 03:55:12.553 | DTC Client socket (2) | Creating socket. 2025-02-03 03:55:12.554 | DTC Client socket (2) | New receive buffer size: 0 2025-02-03 03:55:12.554 | DTC Client socket (2) | Connecting to IP: 69.39.70.247. 2025-02-03 03:55:12.554 | Delaying start of download for AAPL. 2025-02-03 03:55:12.554 | Using Bid/Ask average for last trade price for EURUSD 2025-02-03 03:55:12.554 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 12 Service code: fxcm 2025-02-03 03:55:12.554 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 2025-02-03 03:55:12.554 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 12 2025-02-03 03:55:12.554 | Added historical Intraday data request for EURUSD to the queue. 2025-02-03 03:55:12.554 | Intraday data recording state for symbol EURUSD is set to download 'Pending'. 2025-02-03 03:55:12.554 | Triggering next historical data download in queue. 2025-02-03 03:55:12.554 | DTC Client socket (3) | Creating socket. 2025-02-03 03:55:12.554 | DTC Client socket (3) | New receive buffer size: 0 2025-02-03 03:55:12.554 | DTC Client socket (3) | Connecting to IP: 67.214.125.7. 2025-02-03 03:55:12.754 | Delayed Data Feed | Network connection to server complete. 2025-02-03 03:55:12.754 | Delayed Data Feed | Starting socket receive thread. 2025-02-03 03:55:12.755 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-02-03 03:55:12.756 | SC Data with Depth | Network connection to server complete. 2025-02-03 03:55:12.756 | SC Data with Depth | Starting socket receive thread. 2025-02-03 03:55:12.756 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard 2025-02-03 03:55:12.810 | SC Data with Depth | Setting DTC encoding to Binary VLS 2025-02-03 03:55:12.810 | SC Data with Depth | Sending logon request message. 2025-02-03 03:55:12.810 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2025-02-03 03:55:12.810 | Delayed Data Feed | Sending logon request message. 2025-02-03 03:55:13.631 | Delayed Data Feed | Received logon response. 2025-02-03 03:55:13.631 | Delayed Data Feed | Server Name: SC Realtime Server. 2025-02-03 03:55:13.631 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2025-02-03 03:55:13.631 | Delayed Data Feed | Successfully connected. 2025-02-03 03:55:13.631 | Delayed Data Feed | Trading is not supported. 2025-02-03 03:55:13.631 | Delayed Data Feed | MarketDepthIsSupported: 1 2025-02-03 03:55:13.631 | Delayed Data Feed | Restarting real-time data updates for symbol: AAPL -> AAPL 2025-02-03 03:55:13.632 | SC Data with Depth | Received logon response. 2025-02-03 03:55:13.632 | SC Data with Depth | Server Name: SC Realtime Server. 2025-02-03 03:55:13.632 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8 2025-02-03 03:55:13.632 | SC Data with Depth | Successfully connected. 2025-02-03 03:55:13.632 | SC Data with Depth | Trading is not supported. 2025-02-03 03:55:13.632 | SC Data with Depth | MarketDepthIsSupported: 1 2025-02-03 03:55:13.632 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD 2025-02-03 03:55:13.709 | SC Data with Depth | Setting external service identifier for symbol EURUSD to 18 2025-02-03 03:55:13.709 | SC Data with Depth | Received security definition for symbol EURUSD 2025-02-03 03:55:13.710 | Delayed Data Feed | Real-time data for symbol AAPL is currently unavailable. 2025-02-03 03:55:13.710 | Delayed Data Feed | Setting external service identifier for symbol AAPL to 12 2025-02-03 03:55:13.710 | Delayed Data Feed | Received security definition for symbol AAPL 2025-02-03 03:55:18.151 | HD Request # 115 | Downloading Intraday chart data for AAPL to the file AAPL.scid. Service: us_equities_utp_cta_exchange.data 2025-02-03 03:55:18.151 | HD Request # 115 | Download start date-time: 2025-01-31 23:59:30.000000. File last date-time: 2025-01-31 23:59:30.308000 2025-02-03 03:55:18.152 | HD Request # 115 | Using server: ds33.sierracharts.com port 10149 2025-02-03 03:55:18.152 | Socket (4) | Creating socket. 2025-02-03 03:55:18.152 | Socket (4) | New receive buffer size: 0 2025-02-03 03:55:18.152 | Socket (4) | Connecting to IP: 69.39.70.245. 2025-02-03 03:55:18.204 | HD Request # 115 | Setting DTC encoding to Binary VLS 2025-02-03 03:55:18.204 | HD Request # 115 | Sending historical data logon request message. 2025-02-03 03:55:18.272 | HD Request # 115 | Requesting Intraday data. Start date-time: 2025-01-31 23:59:30. Record interval: 0. Symbol: AAPL 2025-02-03 03:55:18.294 | HD Request # 115 | Decompressing data. 2025-02-03 03:55:18.316 | HD Request # 115 | Receiving Intraday data for AAPL starting at 2025-01-31 23:59:30.308000 2025-02-03 03:55:18.316 | Socket (4) | CloseSocket call. 2025-02-03 03:55:18.316 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-02-03 03:55:18.317 | Historical data download thread signaled to stop. 2025-02-03 03:55:18.317 | HD Request # 115 | Received 12 Intraday data records from 2025-01-31 23:59:30.308000 to 2025-01-31 23:59:56.596000 (26.3 seconds. Delay: 2.2 days) and wrote 0 records for AAPL 2025-02-03 03:55:18.317 | HD Request # 115 | Add time&sales data | Remembered last file record date-time: 2025-01-31 23:59:30.308000 2025-02-03 03:55:18.317 | HD Request # 115 | Completion time: 0s. 2025-02-03 03:55:18.317 | HD Request # 115 | Intraday data download complete for AAPL. Unique request ID: 240 2025-02-03 03:55:18.317 | Removing historical data download ID 240. 2025-02-03 03:55:18.317 | Real-time Intraday chart data file updates started for AAPL 2025-02-03 03:55:18.317 | Intraday chart data file opened for AAPL 2025-02-03 03:55:18.317 | HD Request # 115 | Enabling Intraday chart updating for symbol. 2025-02-03 03:55:18.317 | 2025-02-03 03:55:18.317 | Triggering next historical data download in queue. 2025-02-03 03:55:18.317 | HD Request # 116 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm 2025-02-03 03:55:18.317 | HD Request # 116 | Download start date-time: 2025-02-03 03:28:55.000000. File last date-time: 2025-02-03 03:28:55.237000 2025-02-03 03:55:18.317 | HD Request # 116 | Using server: ds4.sierracharts.com port 10150 2025-02-03 03:55:18.318 | Socket (5) | Creating socket. 2025-02-03 03:55:18.318 | Socket (5) | New receive buffer size: 0 2025-02-03 03:55:18.318 | Socket (5) | Connecting to IP: 67.214.125.7. 2025-02-03 03:55:18.341 | Socket (4) | Socket gracefully closed by remote side. 2025-02-03 03:55:18.341 | Socket (4) | Closed. 2025-02-03 03:55:18.379 | HD Request # 116 | Setting DTC encoding to Binary VLS 2025-02-03 03:55:18.379 | HD Request # 116 | Sending historical data logon request message. 2025-02-03 03:55:18.432 | HD Request # 116 | Requesting Intraday data. Start date-time: 2025-02-03 03:28:55. Record interval: 0. Symbol: EURUSD 2025-02-03 03:55:18.457 | HD Request # 116 | Decompressing data. 2025-02-03 03:55:18.496 | HD Request # 116 | Receiving Intraday data for EURUSD starting at 2025-02-03 03:28:55.120000 2025-02-03 03:55:18.517 | Socket (5) | CloseSocket call. 2025-02-03 03:55:18.517 | Socket (5) | Shutdown started. Waiting for graceful close. 2025-02-03 03:55:18.518 | Historical data download thread signaled to stop. 2025-02-03 03:55:18.518 | HD Request # 116 | Timestamp of first Intraday data file record written: 2025-02-03 03:28:57.740000. 2025-02-03 03:55:18.518 | HD Request # 116 | Received 4507 Intraday data records from 2025-02-03 03:28:55.120000 to 2025-02-03 03:55:16.166000 (26.4 minutes. Delay: 2.4 seconds) and wrote 4505 records for EURUSD 2025-02-03 03:55:18.518 | HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2025-02-03 03:55:16.166000 2025-02-03 03:55:18.518 | Added 12 Time and Sales records to Intraday data file for EURUSD after download. 2025-02-03 03:55:18.519 | HD Request # 116 | Completion time: 0s. 2025-02-03 03:55:18.519 | HD Request # 116 | Intraday data download complete for EURUSD. Unique request ID: 241 2025-02-03 03:55:18.519 | Removing historical data download ID 241. 2025-02-03 03:55:18.519 | Real-time Intraday chart data file updates started for EURUSD 2025-02-03 03:55:18.519 | Intraday chart data file opened for EURUSD 2025-02-03 03:55:18.519 | HD Request # 116 | Enabling Intraday chart updating for symbol. 2025-02-03 03:55:18.519 | 2025-02-03 03:55:18.519 | No download requests in the queue to start downloads for. 2025-02-03 03:55:18.540 | Socket (5) | Socket gracefully closed by remote side. 2025-02-03 03:55:18.540 | Socket (5) | Closed. 2025-02-03 03:55:18.615 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Creating socket. Using TLS 1.2. 2025-02-03 03:55:18.615 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | New receive buffer size: 0 2025-02-03 03:55:18.615 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Connecting to IP: 216.66.0.130. 2025-02-03 03:55:18.690 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 81131 2025-02-03 03:55:18.691 | Rithmic Direct - DTC | Processed connection points. Count: 347 2025-02-03 03:55:18.934 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | CloseSocket call. 2025-02-03 03:55:18.934 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Shutdown started. Waiting for graceful close. 2025-02-03 03:55:18.946 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Socket gracefully closed by remote side. 2025-02-03 03:55:18.946 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (4) | Closed. 2025-02-03 03:55:21.633 | Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 24304" Date Time Of Last Edit: 2025-02-03 04:12:21
[2025-02-03 04:46:29] |
I have resolved this issue on my end, thank you for your time.
