Date/Time: Wed, 05 Feb 2025 16:51:05 +0000
Difference between Bid Ask Volume ratio and Up Down Volume ratio(Ask Bid volume)
View Count: 148
[2024-12-03 19:56:51] |
User763335 - Posts: 97 |
Hello trying to understand the difference between "Bid Ask Volume Ratio" and "Up/Down Volume Ratio" that is based on Ask/Bid Volume. From the documentation Bid Ask Volume Ratio and Up/Down Volume Ratio , it appears they use the same formula, except for conditions of V(ask)+V(Bid) around 0 values. The other difference I noticed is in terms of the EMA calculation for t <n , between the two.For t >=n, they appear to be the same. Can you confirm if my understanding is right? I can see the calculations used, but in layman's terms, how would you characterize the difference between them? It looks the same to me, for the typical conditions and yet I see the Bid/Ask volume ratio , to be a bit more sensitive, for the same moving average length and moving average type(exponential). The up/down volume ratio(ask/Bid volume) seems to be a bit more smoothed out. No issues either way, just trying to understand what/why the difference is.. Thanks |
[2024-12-03 20:29:40] |
John - SC Support - Posts: 37749 |
The "Bid Ask Volume Ratio" and "Up/Down Volume Ratio" will give the exact same results if they have the same parameters and the "Up/Down Volume Ratio" is has the "Calculated Based On" set to "Ask/Bid Volume". If you are seeing differences, then there must be something different in the Length or Moving Average between the two studies. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-03 20:52:20] |
Never mind, my bad..I had a moving avg on top of up/down volume ratio, which I thought I had disabled, but apparently it was still on and the base up/down ratio had it(VR) hidden, causing the difference in sensitivity. Thanks! Date Time Of Last Edit: 2024-12-03 20:53:15
