Date/Time: Wed, 19 Mar 2025 03:22:38 +0000
decalage 10 mn
View Count: 228
[2024-12-03 16:07:59] |
User914407 - Posts: 49 |
Bonjour, Je suis en train de parametrer SC avec Stage5 et après avoir tout entré, j'ai toujours 10mn de retard |
[2024-12-03 18:17:51] |
John - SC Support - Posts: 38782 |
From Google Translate: I am setting up SC with Stage5 and after entering everything I am still 10 minutes behind schedule
Everything on your account looks good. If you are still having an issue, then we would need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-03 18:19:45] |
Je n'ai mis que 100€ pour l'instant sur le compte STAGE 5. Peut-être faut-il mettre plus ?
[2024-12-03 18:27:17] |
2024-12-03 19:22:00.790 | Software version: 2714 64-bit 2024-12-03 19:22:00.790 | Primary Thread ID: 13872 2024-12-03 19:22:00.790 | Usage end date: 2025-11-06 2024-12-03 19:22:00.790 | Enabled for: Advanced Features 2. 2024-12-03 19:22:00.790 | Enabled for: Sierra Chart Historical Data Service. 2024-12-03 19:22:00.790 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-12-03 19:22:00.790 | Enabled for: Delayed Denali Exchange Data Feed. 2024-12-03 19:22:00.790 | Enabled for exchange2: CME 2024-12-03 19:22:00.790 | Allow Support for Sierra Chart Data Feeds is disabled. 2024-12-03 19:22:00.790 | Current selected Data/Trading service: Teton CME Order Routing 2024-12-03 19:22:00.790 | Custom symbol settings values: enabled 2024-12-03 19:22:00.790 | Chart Update Interval: 80 2024-12-03 19:22:00.790 | Intraday Data Storage Time Unit: 0 2024-12-03 19:22:00.790 | Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) 2024-12-03 19:22:00.790 | 2024-12-03 18:22:00 Local computer time in UTC 2024-12-03 19:22:00.790 | 2024-12-03 19:22:00 Local computer time in SC Time Zone 2024-12-03 19:22:00.790 | 2024-12-03 17:33:33 Server time in UTC 2024-12-03 19:22:00.790 | Local computer UTC time and Server UTC time difference: 1 seconds. 2024-12-03 19:22:00.790 | Program path: D:\SierraChart CME\ 2024-12-03 19:22:00.790 | Data Files path: D:\SierraChart CME\Data\ 2024-12-03 19:22:00.790 | OS Version Number: 10.0 2024-12-03 19:22:00.790 | Locale Setting: C 2024-12-03 19:22:00.790 | DLLs: UserContributedStudies_64.dll 2024-12-03 19:22:00.790 | Allowed protected custom studies: 2024-12-03 19:22:00.790 | Crash reporter started: true 2024-12-03 19:22:00.790 | 2024-12-03 19:22:44.522 | Saved Chartbook: LeTradingFr_CB_CME_SP500_Trading_V2.Cht. Time: 0.2078 seconds. 2024-12-03 19:22:45.210 | Unsubscribed from market depth data for ESZ24_FUT_CME 2024-12-03 19:22:45.210 | Unsubscribed from market depth data for MESZ24_FUT_CME 2024-12-03 19:24:20.863 | MESZ24_FUT_CME 1 Min #1 | Reloading chart. 2024-12-03 19:24:21.460 | MESZ24_FUT_CME[M] 1 Min #1 | Chart data loading complete. 2024-12-03 19:24:54.165 | File >> Disconnect selected. 2024-12-03 19:24:54.165 | Teton CME Order Routing | Waiting for socket receive thread to end 2024-12-03 19:24:54.165 | DTC Client socket (1) | CloseSocket call. 2024-12-03 19:24:54.165 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-12-03 19:24:54.165 | Delayed Data Feed | Waiting for socket receive thread to end 2024-12-03 19:24:54.166 | DTC Client socket (5) | CloseSocket call. 2024-12-03 19:24:54.166 | DTC Client socket (5) | Shutdown started. Waiting for graceful close. 2024-12-03 19:24:54.166 | Delayed Data Feed | Disconnected from the server. 2024-12-03 19:24:54.166 | Teton CME Order Routing | Disconnected. 2024-12-03 19:24:54.266 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-12-03 19:24:54.266 | DTC Client socket (1) | Closed. 2024-12-03 19:24:54.348 | DTC Client socket (5) | Socket gracefully closed by remote side. 2024-12-03 19:24:54.348 | DTC Client socket (5) | Closed. 2024-12-03 19:25:04.451 | 2024-12-03 19:25:04.451 | Teton CME Order Routing | Firm: Dorman 2024-12-03 19:25:04.451 | Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 2024-12-03 19:25:04.478 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-12-03 19:25:04.478 | DTC Client socket (1) | New receive buffer size: 0 2024-12-03 19:25:04.478 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2024-12-03 19:25:04.480 | Teton CME Order Routing | Network connection to server complete. 2024-12-03 19:25:04.480 | Teton CME Order Routing | Starting socket receive thread. 2024-12-03 19:25:04.480 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none 2024-12-03 19:25:04.876 | Teton CME Order Routing | Setting DTC encoding to Binary VLS 2024-12-03 19:25:04.876 | Teton CME Order Routing | Sending logon request message. 2024-12-03 19:25:05.457 | Teton CME Order Routing | Received logon response. 2024-12-03 19:25:05.457 | Teton CME Order Routing | Server Name: SC DTC Server. Build=51528. 2024-12-03 19:25:05.457 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 2024-12-03 19:25:05.457 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2024-12-03 19:25:05.457 | Teton CME Order Routing | Trading is supported. 2024-12-03 19:25:05.457 | Teton CME Order Routing | Order cancel and replace is supported. 2024-12-03 19:25:05.457 | Teton CME Order Routing | OCO Orders supported. 2024-12-03 19:25:05.457 | Teton CME Order Routing | Bracket Orders supported. 2024-12-03 19:25:05.457 | Teton CME Order Routing | MarketDepthIsSupported: 1 2024-12-03 19:25:05.457 | Teton CME Order Routing | Connected to server complete. 2024-12-03 19:25:05.458 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-12-03 19:25:05.458 | Updated verified funded futures trading account ending date to: 2025-01-02 18:25:05 2024-12-03 19:25:05.458 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. 2024-12-03 19:25:05.458 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2024-12-03 18:15:18.279079 2024-12-03 19:25:05.542 | Mapping MESZ24_FUT_CME to MESZ24. Service code: cme 2024-12-03 19:25:05.542 | Using symbol data fast lookup vector 2024-12-03 19:25:05.542 | Delayed Data Feed | Starting real-time market data updates for: MESZ24_FUT_CME (MESZ24). ID: 1 Service code: cme 2024-12-03 19:25:05.542 | Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 2024-12-03 19:25:05.542 | Delayed Data Feed | Requesting security definition data for: MESZ24_FUT_CME (MESZ24). ID: 1 2024-12-03 19:25:05.542 | Added historical Intraday data request for MESZ24_FUT_CME to the queue. 2024-12-03 19:25:05.542 | Intraday data recording state for symbol MESZ24_FUT_CME is set to download 'Pending'. 2024-12-03 19:25:05.542 | Triggering next historical data download in queue. 2024-12-03 19:25:05.548 | Delaying start of download for MESZ24_FUT_CME. 2024-12-03 19:25:05.557 | DTC Client socket (2) | Creating socket. 2024-12-03 19:25:05.557 | DTC Client socket (2) | New receive buffer size: 0 2024-12-03 19:25:05.557 | DTC Client socket (2) | Connecting to IP: 67.214.125.6. 2024-12-03 19:25:05.557 | Delayed Data Feed | Network connection to server complete. 2024-12-03 19:25:05.557 | Delayed Data Feed | Starting socket receive thread. 2024-12-03 19:25:05.558 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-12-03 19:25:05.558 | Updated verified funded futures trading account ending date to: 2025-01-02 18:25:05 2024-12-03 19:25:05.640 | Teton CME Order Routing | Received final trade activity snapshot. Count=3. TradeAccount=2067A 2024-12-03 19:25:05.777 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2024-12-03 19:25:05.777 | Delayed Data Feed | Sending logon request message. 2024-12-03 19:25:06.434 | Delayed Data Feed | Received logon response. 2024-12-03 19:25:06.434 | Delayed Data Feed | Server Name: SC Realtime Server. 2024-12-03 19:25:06.434 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2024-12-03 19:25:06.434 | Delayed Data Feed | Successfully connected. 2024-12-03 19:25:06.434 | Delayed Data Feed | Trading is not supported. 2024-12-03 19:25:06.434 | Delayed Data Feed | MarketDepthIsSupported: 1 2024-12-03 19:25:06.434 | Delayed Data Feed | Restarting real-time data updates for symbol: MESZ24_FUT_CME -> MESZ24 2024-12-03 19:25:06.621 | Delayed Data Feed | Setting external service identifier for symbol MESZ24_FUT_CME to 42034014 2024-12-03 19:25:06.621 | Delayed Data Feed | Received security definition for symbol MESZ24_FUT_CME 2024-12-03 19:25:11.775 | HD Request # 5 | Downloading Intraday chart data for MESZ24_FUT_CME to the file MESZ24_FUT_CME.scid. Service: cme 2024-12-03 19:25:11.775 | HD Request # 5 | Download start date-time: 2024-12-03 19:14:43.000000. File last date-time: 2024-12-03 19:14:43.639000 2024-12-03 19:25:11.775 | HD Request # 5 | Using server: ds28.sierracharts.com port 10149 2024-12-03 19:25:11.803 | Socket (3) | Creating socket. 2024-12-03 19:25:11.803 | Socket (3) | New receive buffer size: 0 2024-12-03 19:25:11.803 | Socket (3) | Connecting to IP: 67.214.125.5. 2024-12-03 19:25:12.020 | HD Request # 5 | Setting DTC encoding to Binary VLS 2024-12-03 19:25:12.020 | HD Request # 5 | Sending historical data logon request message. 2024-12-03 19:25:12.605 | HD Request # 5 | Requesting Intraday data. Start date-time: 2024-12-03 19:14:43. Record interval: 0. Symbol: MESZ24 2024-12-03 19:25:12.705 | HD Request # 5 | Decompressing data. 2024-12-03 19:25:12.798 | HD Request # 5 | Receiving Intraday data for MESZ24_FUT_CME starting at 2024-12-03 19:14:43.169000 2024-12-03 19:25:12.799 | Socket (3) | CloseSocket call. 2024-12-03 19:25:12.799 | Socket (3) | Shutdown started. Waiting for graceful close. 2024-12-03 19:25:12.799 | Historical data download thread signaled to stop. 2024-12-03 19:25:12.799 | HD Request # 5 | Timestamp of first Intraday data file record written: 2024-12-03 19:14:48.446000. 2024-12-03 19:25:12.799 | HD Request # 5 | Received 1984 Intraday data records from 2024-12-03 19:14:43.169000 to 2024-12-03 19:25:08.833000 (10.4 minutes. Delay: 4.0 seconds) and wrote 1982 records for MESZ24_FUT_CME 2024-12-03 19:25:12.799 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2024-12-03 18:25:08.833000 2024-12-03 19:25:12.799 | HD Request # 5 | Completion time: 1s. 2024-12-03 19:25:12.799 | HD Request # 5 | Intraday data download complete for MESZ24_FUT_CME. Unique request ID: 5 2024-12-03 19:25:12.799 | Removing historical data download ID 5. 2024-12-03 19:25:12.799 | Real-time Intraday chart data file updates started for MESZ24_FUT_CME 2024-12-03 19:25:12.799 | Intraday chart data file opened for MESZ24_FUT_CME 2024-12-03 19:25:12.799 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2024-12-03 19:25:12.799 | 2024-12-03 19:25:12.799 | No download requests in the queue to start downloads for. 2024-12-03 19:25:12.898 | Socket (3) | Socket gracefully closed by remote side. 2024-12-03 19:25:12.898 | Socket (3) | Closed. 2024-12-03 19:25:12.937 | Opened cached Intraday file: D:\SierraChart CME\Data\MESZ24_FUT_CME.scid. Thread ID: 4876 |
[2024-12-03 19:22:48] |
You do not need to add any funds to your Stage 5 account. You are getting properly verified with them. The issue is the following from your log: Allow Support for Sierra Chart Data Feeds is disabled.
You need to do the following: - Select "Global Settings >> Data/Trade Service Settings". - Select the "Common Settings" page at the top if not already selected. - Set the option for "Allow Support for Sierra Chart Data Feeds" to "Yes". - Select OK to close that window. - Select "File >> Reconnect". After this, you will be getting the real-time data from our Denali Exchange Data feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-04 09:07:04] |
çà fonctionne avec le SP mais pas avec le NQ. Voisi les logs : 2024-12-04 09:48:18.261 | Trade activity files set size: 58 2024-12-04 09:48:18.288 | Created the DTC Protocol server. 2024-12-04 09:48:18.288 | DTC Protocol Server listening on port 11099. 2024-12-04 09:48:18.288 | Reading Internal Order ID file. 2024-12-04 09:48:18.303 | Reading Trade Orders file. 2024-12-04 09:48:18.303 | Reading Trade Positions file. 2024-12-04 09:48:18.304 | Reading Trade Account Data files. 2024-12-04 09:48:18.305 | Software version: 2714 64-bit 2024-12-04 09:48:18.305 | Primary Thread ID: 25764 2024-12-04 09:48:18.305 | Usage end date: 2025-11-06 2024-12-04 09:48:18.305 | Enabled for: Advanced Features 2. 2024-12-04 09:48:18.305 | Enabled for: Sierra Chart Historical Data Service. 2024-12-04 09:48:18.305 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-12-04 09:48:18.305 | Enabled for: Delayed Denali Exchange Data Feed. 2024-12-04 09:48:18.305 | Enabled for exchange2: CME 2024-12-04 09:48:18.305 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-12-04 09:48:18.305 | Current selected Data/Trading service: Teton CME Order Routing 2024-12-04 09:48:18.305 | Custom symbol settings values: enabled 2024-12-04 09:48:18.305 | Chart Update Interval: 300 2024-12-04 09:48:18.305 | Intraday Data Storage Time Unit: 0 2024-12-04 09:48:18.305 | Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) 2024-12-04 09:48:18.305 | 2024-12-04 08:48:18 Local computer time in UTC 2024-12-04 09:48:18.305 | 2024-12-04 09:48:18 Local computer time in SC Time Zone 2024-12-04 09:48:18.305 | 2024-12-04 08:48:16 Server time in UTC 2024-12-04 09:48:18.305 | Local computer UTC time and Server UTC time difference: 2 seconds. 2024-12-04 09:48:18.305 | Program path: D:\SierraChart CME\ 2024-12-04 09:48:18.305 | Data Files path: D:\SierraChart CME\Data\ 2024-12-04 09:48:18.305 | OS Version Number: 10.0 2024-12-04 09:48:18.305 | Locale Setting: C 2024-12-04 09:48:18.305 | DLLs: UserContributedStudies_64.dll 2024-12-04 09:48:18.305 | Allowed protected custom studies: 2024-12-04 09:48:18.305 | Crash reporter started: true 2024-12-04 09:48:18.305 | 2024-12-04 09:48:18.333 | Created the DTC Protocol historical data server. 2024-12-04 09:48:18.334 | HD Server Manager | Listening on port 11098. 2024-12-04 09:48:18.334 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2024-12-04 09:48:18.411 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-12-04 09:48:18.489 | Received 5 login tokens. 2024-12-04 09:48:18.490 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-12-04 09:48:18.490 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-12-04 09:48:18.870 | Symbol settings MD5 received. Request ID: 1. 2024-12-04 09:48:18.870 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2024-12-04 09:48:20.831 | Requested user files to download. 2024-12-04 09:48:22.823 | 2024-12-04 09:48:22.823 | Teton CME Order Routing | Firm: Dorman 2024-12-04 09:48:22.824 | Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 2024-12-04 09:48:22.929 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-12-04 09:48:22.929 | DTC Client socket (1) | New receive buffer size: 0 2024-12-04 09:48:22.929 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2024-12-04 09:48:22.929 | Teton CME Order Routing | Network connection to server complete. 2024-12-04 09:48:22.929 | Teton CME Order Routing | Starting socket receive thread. 2024-12-04 09:48:22.930 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none 2024-12-04 09:48:23.352 | Teton CME Order Routing | Setting DTC encoding to Binary VLS 2024-12-04 09:48:23.352 | Teton CME Order Routing | Sending logon request message. 2024-12-04 09:48:23.929 | Teton CME Order Routing | Received logon response. 2024-12-04 09:48:23.929 | Teton CME Order Routing | Server Name: SC DTC Server. Build=51528. 2024-12-04 09:48:23.929 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 2024-12-04 09:48:23.929 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2024-12-04 09:48:23.929 | Teton CME Order Routing | Trading is supported. 2024-12-04 09:48:23.929 | Teton CME Order Routing | Order cancel and replace is supported. 2024-12-04 09:48:23.929 | Teton CME Order Routing | OCO Orders supported. 2024-12-04 09:48:23.929 | Teton CME Order Routing | Bracket Orders supported. 2024-12-04 09:48:23.929 | Teton CME Order Routing | MarketDepthIsSupported: 1 2024-12-04 09:48:23.929 | Teton CME Order Routing | Connected to server complete. 2024-12-04 09:48:23.930 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-12-04 09:48:23.930 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. 2024-12-04 09:48:23.930 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2024-12-03 18:15:18.817814 2024-12-04 09:48:24.030 | Updated verified funded futures trading account ending date to: 2025-01-03 08:48:24 2024-12-04 09:48:24.134 | Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=2067A 2024-12-04 09:48:30.326 | NQZ24_FUT_CME [CBV] 30 Min #3 | Reloading chart. 2024-12-04 09:48:30.326 | Starting DelayedDownloadMonitoringTimer 2024-12-04 09:48:30.326 | Starting HDTimeoutTimer 2024-12-04 09:48:30.326 | Added historical Intraday data request for NQZ24_FUT_CME to the queue. 2024-12-04 09:48:30.326 | Triggering next historical data download in queue. 2024-12-04 09:48:30.327 | NQZ24_FUT_CME [CBV] 30 Min #3 | Performing continuous chart historical Daily data download for symbol NQZ24_FUT_CME starting at last date in file. 2024-12-04 09:48:30.327 | Starting DelayedDownloadMonitoringTimer 2024-12-04 09:48:30.327 | Starting HDTimeoutTimer 2024-12-04 09:48:30.327 | Added historical Daily data request for NQZ24_FUT_CME to the queue. 2024-12-04 09:48:30.328 | Triggering next historical data download in queue. 2024-12-04 09:48:30.331 | NQZ24_FUT_CME [CBV] 30 Min #3 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:30.348 | NQZ24_FUT_CME [CBV] 1 Min #17 | Reloading chart. 2024-12-04 09:48:30.352 | NQZ24_FUT_CME [CBV] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:30.366 | NQZ24_FUT_CME [CBV] Daily #5 | Reloading chart. 2024-12-04 09:48:30.551 | NQZ24_FUT_CME [CBV] Daily #5 | Waiting for historical downloads to complete with the IDs: 2, 2024-12-04 09:48:30.573 | NQZ24_FUT_CME [CBV] 3000 Volume #26 | Reloading chart. 2024-12-04 09:48:30.589 | NQZ24_FUT_CME [CBV] 3000 Volume #26 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:30.600 | Loading DLL: D:\SierraChart CME\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7fffe3c10000 2024-12-04 09:48:30.617 | NQZ24_FUT_CME [CBV] 30000 Volume #21 | Reloading chart. 2024-12-04 09:48:30.626 | NQZ24_FUT_CME [CBV] 30000 Volume #21 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:30.646 | NQZ24_FUT_CME [CBV] 150000 Volume #16 | Reloading chart. 2024-12-04 09:48:30.672 | NQZ24_FUT_CME [CBV] 150000 Volume #16 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:30.690 | NQZ24_FUT_CME [CBV] 500000 Volume #13 | Reloading chart. 2024-12-04 09:48:30.734 | NQZ24_FUT_CME [CBV] 500000 Volume #13 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:30.752 | NQZ24_FUT_CME [CBV] Daily #11 | Reloading chart. 2024-12-04 09:48:30.756 | NQZ24_FUT_CME [CBV] Daily #11 | Performing continuous chart historical Daily data download for symbol NQZ14_FUT_CME starting at 2014-09-14. 2024-12-04 09:48:30.756 | Added historical Daily data request for NQZ14_FUT_CME to the queue. 2024-12-04 09:48:30.929 | NQZ24_FUT_CME [CBV] Daily #11 | Dates not found while checking for invalid data in continuous contract data files. NQZ14_FUT_CME * 2024-12-04 09:48:30.929 | NQZ24_FUT_CME [CBV] Daily #11 | Waiting for historical downloads to complete with the IDs: 2, 3, 2024-12-04 09:48:30.945 | NQZ24_FUT_CME [CBV] #15 | Reloading chart. 2024-12-04 09:48:30.967 | NQZ24_FUT_CME [CBV] #15 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:30.984 | NQZ24_FUT_CME [CBV] #7 | Reloading chart. 2024-12-04 09:48:31.006 | NQZ24_FUT_CME [CBV] #7 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:31.011 | NQZ24_FUT_CME [CBV] #6 | Reloading chart. 2024-12-04 09:48:31.185 | NQZ24_FUT_CME [CBV] #6 | Dates not found while checking for invalid data in continuous contract data files. NQZ14_FUT_CME * 2024-12-04 09:48:31.185 | NQZ24_FUT_CME [CBV] #6 | Waiting for historical downloads to complete with the IDs: 2, 3, 2024-12-04 09:48:31.189 | NQZ24_FUT_CME [CBV] #14 | Reloading chart. 2024-12-04 09:48:31.253 | NQZ24_FUT_CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:31.258 | NQZ24_FUT_CME [CBV] #1 | Reloading chart. 2024-12-04 09:48:31.432 | NQZ24_FUT_CME [CBV] #1 | Dates not found while checking for invalid data in continuous contract data files. NQZ14_FUT_CME * 2024-12-04 09:48:31.432 | NQZ24_FUT_CME [CBV] #1 | Waiting for historical downloads to complete with the IDs: 2, 3, 2024-12-04 09:48:31.447 | NQZ24_FUT_CME [CBV] #24 | Reloading chart. 2024-12-04 09:48:31.469 | NQZ24_FUT_CME [CBV] #24 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:31.489 | NQZ24_FUT_CME [CBV] #22 | Reloading chart. 2024-12-04 09:48:31.511 | NQZ24_FUT_CME [CBV] #22 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:31.626 | NQZ24_FUT_CME [CBV] Rev. 4t #25 | Reloading chart. 2024-12-04 09:48:31.630 | NQZ24_FUT_CME [CBV] Rev. 4t #25 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:31.651 | NQZ24_FUT_CME [CBV] Renko 5t #4 | Reloading chart. 2024-12-04 09:48:31.655 | NQZ24_FUT_CME [CBV] Renko 5t #4 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:31.670 | NQZ24_FUT_CME [CBV] Rev. 4t #12 | Reloading chart. 2024-12-04 09:48:31.674 | NQZ24_FUT_CME [CBV] Rev. 4t #12 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:31.678 | NQZ24_FUT_CME [CBV] 1 Sec #2 | Reloading chart. 2024-12-04 09:48:31.682 | NQZ24_FUT_CME [CBV] 1 Sec #2 | Waiting for historical downloads to complete with the IDs: 1, 2, 2024-12-04 09:48:31.686 | Mapping NQZ24_FUT_CME to NQZ24. Service code: cme 2024-12-04 09:48:31.686 | Using symbol data fast lookup vector 2024-12-04 09:48:31.686 | HD Request # 1 | Downloading Intraday chart data for NQZ24_FUT_CME to the file NQZ24_FUT_CME.scid. Service: cme 2024-12-04 09:48:31.686 | HD Request # 1 | Download start date-time: 2024-12-03 19:45:08.000000. File last date-time: 2024-12-03 19:45:08.735000 2024-12-04 09:48:31.686 | HD Request # 1 | Using server: ds28.sierracharts.com port 10149 2024-12-04 09:48:31.688 | HD Request # 2 | Downloading Historical Daily chart data for NQZ24_FUT_CME. Starting date: 2024-11-27. Service: sc_futures_direct.dtc.trading 2024-12-04 09:48:31.696 | Socket (2) | Creating socket. 2024-12-04 09:48:31.696 | Socket (2) | New receive buffer size: 0 2024-12-04 09:48:31.696 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-12-04 09:48:31.923 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-12-04 09:48:31.923 | HD Request # 1 | Sending historical data logon request message. 2024-12-04 09:48:31.988 | HD Request # 2 | Requesting historical Daily data for NQZ24 starting at 2024-11-26. SC External HD service. 2024-12-04 09:48:32.346 | HD Request # 2 | Receiving historical Daily data for NQZ24_FUT_CME starting at 2024-11-27. 2024-12-04 09:48:32.346 | HD Request # 2 | Writing historical Daily data to the file NQZ24_FUT_CME.dly. 2024-12-04 09:48:32.347 | HD Request # 2 | Bytes received: 303 2024-12-04 09:48:32.347 | HD Request # 2 | Received 5 Daily data records from 2024-11-27 00:00:00 to 2024-12-03 00:00:00 (7.0 days) and wrote 4 records for NQZ24_FUT_CME 2024-12-04 09:48:32.347 | HD Request # 2 | Completion time: 1s. 2024-12-04 09:48:32.347 | HD Request # 2 | Daily data download complete for NQZ24_FUT_CME. Unique request ID: 2 2024-12-04 09:48:32.347 | Removing historical data download ID 2. 2024-12-04 09:48:32.348 | 2024-12-04 09:48:32.348 | Triggering next historical data download in queue. 2024-12-04 09:48:32.348 | Mapping NQZ14_FUT_CME to NQZ14. Service code: cme 2024-12-04 09:48:32.348 | HD Request # 3 | Downloading Historical Daily chart data for NQZ14_FUT_CME. Starting date: 2014-12-07. Service: sc_futures_direct.dtc.trading 2024-12-04 09:48:32.504 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-12-03 19:45:08. Record interval: 0. Symbol: NQZ24 2024-12-04 09:48:32.544 | NQZ24_FUT_CME [CBV] Daily #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:32.545 | NQZ24_FUT_CME [CBV] Daily #5 | Reloading chart. 2024-12-04 09:48:32.603 | HD Request # 1 | Decompressing data. 2024-12-04 09:48:32.614 | HD Request # 1 | Receiving Intraday data for NQZ24_FUT_CME starting at 2024-12-03 19:45:08.023000 2024-12-04 09:48:32.678 | HD Request # 3 | Requesting historical Daily data for NQZ14 starting at 2014-12-06. SC External HD service. 2024-12-04 09:48:32.829 | NQZ24_FUT_CME [CBV] Daily #5 | Chart data loading complete. 2024-12-04 09:48:32.857 | NQZ24_FUT_CME [CBV] Daily #5 | Reloading chart. 2024-12-04 09:48:32.975 | HD Request # 1 | Timestamp of first Intraday data file record written: 2024-12-03 19:45:09.162000. 2024-12-04 09:48:33.162 | HD Request # 3 | Receiving historical Daily data for NQZ14_FUT_CME starting at 2014-12-08. 2024-12-04 09:48:33.163 | HD Request # 3 | Writing historical Daily data to the file NQZ14_FUT_CME.dly. 2024-12-04 09:48:33.163 | HD Request # 3 | Bytes received: 571 2024-12-04 09:48:33.163 | HD Request # 3 | Received 10 Daily data records from 2014-12-08 00:00:00 to 2014-12-19 00:00:00 (12.0 days) and wrote 10 records for NQZ14_FUT_CME 2024-12-04 09:48:33.163 | HD Request # 3 | Completion time: 1s. 2024-12-04 09:48:33.163 | HD Request # 3 | Daily data download complete for NQZ14_FUT_CME. Unique request ID: 3 2024-12-04 09:48:33.163 | Removing historical data download ID 3. 2024-12-04 09:48:33.163 | 2024-12-04 09:48:33.163 | No download requests in the queue to start downloads for. 2024-12-04 09:48:33.163 | NQZ24_FUT_CME [CBV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:33.163 | NQZ24_FUT_CME [CBV] #1 | Reloading chart. 2024-12-04 09:48:33.163 | Unable to determine transition date based on volume from files: NQZ12_FUT_CME.dly, NQH13_FUT_CME.dly 2024-12-04 09:48:33.163 | The NQH13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.163 | Unable to determine transition date based on volume from files: NQH13_FUT_CME.dly, NQM13_FUT_CME.dly 2024-12-04 09:48:33.163 | The NQM13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.163 | Unable to determine transition date based on volume from files: NQM13_FUT_CME.dly, NQU13_FUT_CME.dly 2024-12-04 09:48:33.163 | The NQU13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.163 | Unable to determine transition date based on volume from files: NQU13_FUT_CME.dly, NQZ13_FUT_CME.dly 2024-12-04 09:48:33.163 | The NQZ13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.163 | Unable to determine transition date based on volume from files: NQZ13_FUT_CME.dly, NQH14_FUT_CME.dly 2024-12-04 09:48:33.163 | The NQH14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.163 | Unable to determine transition date based on volume from files: NQH14_FUT_CME.dly, NQM14_FUT_CME.dly 2024-12-04 09:48:33.163 | The NQM14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.163 | Unable to determine transition date based on volume from files: NQM14_FUT_CME.dly, NQU14_FUT_CME.dly 2024-12-04 09:48:33.163 | The NQU14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.210 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2012-12-21 from file. D:\SierraChart CME\Data\NQZ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.210 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.211 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2013-03-15 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.211 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.211 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2013-06-21 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.211 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.211 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2013-09-20 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.211 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.212 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2013-12-20 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.212 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.212 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2014-03-21 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.212 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.212 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2014-06-20 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.212 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.212 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2014-09-19 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.212 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.368 | Socket (2) | CloseSocket call. 2024-12-04 09:48:33.368 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-12-04 09:48:33.411 | NQZ24_FUT_CME [CBV] Daily #5 | Chart data loading complete. 2024-12-04 09:48:33.465 | Socket (2) | Socket gracefully closed by remote side. 2024-12-04 09:48:33.465 | Socket (2) | Closed. 2024-12-04 09:48:33.484 | NQZ24_FUT_CME [CBV] #1 | Chart data loading complete. 2024-12-04 09:48:33.484 | Historical data download thread signaled to stop. 2024-12-04 09:48:33.484 | HD Request # 1 | Received 126739 Intraday data records from 2024-12-03 19:45:08.023000 to 2024-12-04 09:48:28.054000 (14.1 hours. Delay: 5.4 seconds) and wrote 126733 records for NQZ24_FUT_CME 2024-12-04 09:48:33.484 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-12-04 08:48:28.054000 2024-12-04 09:48:33.484 | HD Request # 1 | Completion time: 2s. 2024-12-04 09:48:33.484 | HD Request # 1 | Intraday data download complete for NQZ24_FUT_CME. Unique request ID: 1 2024-12-04 09:48:33.484 | Removing historical data download ID 1. 2024-12-04 09:48:33.484 | Real-time Intraday chart data file updates started for NQZ24_FUT_CME 2024-12-04 09:48:33.484 | Intraday chart data file opened for NQZ24_FUT_CME 2024-12-04 09:48:33.484 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-12-04 09:48:33.484 | 2024-12-04 09:48:33.484 | No download requests in the queue to start downloads for. 2024-12-04 09:48:33.484 | Historical data for NQZ24_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-12-04 09:48:33.484 | NQZ24_FUT_CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:33.484 | NQZ24_FUT_CME [CBV] #14 | Reloading chart. 2024-12-04 09:48:33.520 | NQZ24_FUT_CME [CBV] 3000 Volume #26 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:33.520 | NQZ24_FUT_CME [CBV] 3000 Volume #26 | Reloading chart. 2024-12-04 09:48:33.526 | NQZ24_FUT_CME [CBV] 30000 Volume #21 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:33.526 | NQZ24_FUT_CME [CBV] 30000 Volume #21 | Reloading chart. 2024-12-04 09:48:33.532 | NQZ24_FUT_CME [CBV] #15 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:33.532 | NQZ24_FUT_CME [CBV] #15 | Reloading chart. 2024-12-04 09:48:33.548 | NQZ24_FUT_CME [CBV] #1 | Reloading chart. 2024-12-04 09:48:33.724 | NQZ24_FUT_CME [CBV] #1 | Dates not found while checking for invalid data in continuous contract data files. NQZ14_FUT_CME * 2024-12-04 09:48:33.724 | Unable to determine transition date based on volume from files: NQZ12_FUT_CME.dly, NQH13_FUT_CME.dly 2024-12-04 09:48:33.724 | The NQH13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.724 | Unable to determine transition date based on volume from files: NQH13_FUT_CME.dly, NQM13_FUT_CME.dly 2024-12-04 09:48:33.724 | The NQM13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.724 | Unable to determine transition date based on volume from files: NQM13_FUT_CME.dly, NQU13_FUT_CME.dly 2024-12-04 09:48:33.724 | The NQU13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.724 | Unable to determine transition date based on volume from files: NQU13_FUT_CME.dly, NQZ13_FUT_CME.dly 2024-12-04 09:48:33.724 | The NQZ13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.724 | Unable to determine transition date based on volume from files: NQZ13_FUT_CME.dly, NQH14_FUT_CME.dly 2024-12-04 09:48:33.724 | The NQH14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.724 | Unable to determine transition date based on volume from files: NQH14_FUT_CME.dly, NQM14_FUT_CME.dly 2024-12-04 09:48:33.724 | The NQM14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.724 | Unable to determine transition date based on volume from files: NQM14_FUT_CME.dly, NQU14_FUT_CME.dly 2024-12-04 09:48:33.724 | The NQU14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.770 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2012-12-21 from file. D:\SierraChart CME\Data\NQZ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.770 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.770 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2013-03-15 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.770 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.771 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2013-06-21 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.771 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.771 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2013-09-20 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.771 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.771 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2013-12-20 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.771 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.772 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2014-03-21 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.772 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.772 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2014-06-20 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.772 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.772 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 2014-09-19 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.772 | NQZ24_FUT_CME [CBV] #1 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.861 | NQZ24_FUT_CME [CBV] #7 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:33.861 | NQZ24_FUT_CME [CBV] #7 | Reloading chart. 2024-12-04 09:48:33.877 | Denali Data Feed | Starting real-time market data updates for: NQZ24_FUT_CME (NQZ24). ID: 1 Service code: cme 2024-12-04 09:48:33.878 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2024-12-04 09:48:33.878 | Denali Data Feed | Requesting security definition data for: NQZ24_FUT_CME (NQZ24). ID: 1 2024-12-04 09:48:33.892 | NQZ24_FUT_CME [CBV] 500000 Volume #13 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:33.892 | NQZ24_FUT_CME [CBV] 500000 Volume #13 | Reloading chart. 2024-12-04 09:48:33.913 | DTC Client socket (2) | Creating socket. 2024-12-04 09:48:33.913 | DTC Client socket (2) | New receive buffer size: 0 2024-12-04 09:48:33.913 | DTC Client socket (2) | Connecting to IP: 67.214.125.6. 2024-12-04 09:48:33.920 | NQZ24_FUT_CME [CBV] Rev. 4t #25 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:33.920 | NQZ24_FUT_CME [CBV] Rev. 4t #25 | Reloading chart. 2024-12-04 09:48:33.922 | NQZ24_FUT_CME [CBV] #6 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:33.922 | NQZ24_FUT_CME [CBV] #6 | Reloading chart. 2024-12-04 09:48:33.922 | Unable to determine transition date based on volume from files: NQZ12_FUT_CME.dly, NQH13_FUT_CME.dly 2024-12-04 09:48:33.922 | The NQH13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.923 | Unable to determine transition date based on volume from files: NQH13_FUT_CME.dly, NQM13_FUT_CME.dly 2024-12-04 09:48:33.923 | The NQM13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.923 | Unable to determine transition date based on volume from files: NQM13_FUT_CME.dly, NQU13_FUT_CME.dly 2024-12-04 09:48:33.923 | The NQU13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.923 | Unable to determine transition date based on volume from files: NQU13_FUT_CME.dly, NQZ13_FUT_CME.dly 2024-12-04 09:48:33.923 | The NQZ13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.923 | Unable to determine transition date based on volume from files: NQZ13_FUT_CME.dly, NQH14_FUT_CME.dly 2024-12-04 09:48:33.923 | The NQH14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.923 | Unable to determine transition date based on volume from files: NQH14_FUT_CME.dly, NQM14_FUT_CME.dly 2024-12-04 09:48:33.923 | The NQM14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.923 | Unable to determine transition date based on volume from files: NQM14_FUT_CME.dly, NQU14_FUT_CME.dly 2024-12-04 09:48:33.923 | The NQU14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:33.969 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-12-21 from file. D:\SierraChart CME\Data\NQZ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.969 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.969 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2013-03-15 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.969 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.969 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2013-06-21 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.969 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.970 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2013-09-20 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.970 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.970 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2013-12-20 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.970 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.970 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2014-03-21 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.970 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.970 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2014-06-20 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.970 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.971 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2014-09-19 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:33.971 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.060 | NQZ24_FUT_CME [CBV] Renko 5t #4 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:34.060 | NQZ24_FUT_CME [CBV] Renko 5t #4 | Reloading chart. 2024-12-04 09:48:34.062 | NQZ24_FUT_CME [CBV] 1 Sec #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:34.062 | NQZ24_FUT_CME [CBV] 1 Sec #2 | Reloading chart. 2024-12-04 09:48:34.070 | NQZ24_FUT_CME [CBV] Rev. 4t #12 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:34.071 | NQZ24_FUT_CME [CBV] Rev. 4t #12 | Reloading chart. 2024-12-04 09:48:34.081 | NQZ24_FUT_CME [CBV] Daily #11 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:34.082 | NQZ24_FUT_CME [CBV] Daily #11 | Reloading chart. 2024-12-04 09:48:34.082 | Unable to determine transition date based on volume from files: NQZ12_FUT_CME.dly, NQH13_FUT_CME.dly 2024-12-04 09:48:34.082 | The NQH13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:34.082 | Unable to determine transition date based on volume from files: NQH13_FUT_CME.dly, NQM13_FUT_CME.dly 2024-12-04 09:48:34.082 | The NQM13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:34.082 | Unable to determine transition date based on volume from files: NQM13_FUT_CME.dly, NQU13_FUT_CME.dly 2024-12-04 09:48:34.082 | The NQU13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:34.082 | Unable to determine transition date based on volume from files: NQU13_FUT_CME.dly, NQZ13_FUT_CME.dly 2024-12-04 09:48:34.082 | The NQZ13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:34.082 | Unable to determine transition date based on volume from files: NQZ13_FUT_CME.dly, NQH14_FUT_CME.dly 2024-12-04 09:48:34.082 | The NQH14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:34.082 | Unable to determine transition date based on volume from files: NQH14_FUT_CME.dly, NQM14_FUT_CME.dly 2024-12-04 09:48:34.082 | The NQM14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:34.082 | Unable to determine transition date based on volume from files: NQM14_FUT_CME.dly, NQU14_FUT_CME.dly 2024-12-04 09:48:34.082 | The NQU14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:34.129 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2012-12-21 from file. D:\SierraChart CME\Data\NQZ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.129 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.130 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2013-03-15 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.130 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.130 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2013-06-21 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.130 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.130 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2013-09-20 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.130 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.131 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2013-12-20 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.131 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.131 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2014-03-21 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.131 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.131 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2014-06-20 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.131 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.132 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2014-09-19 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.132 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:34.221 | NQZ24_FUT_CME [CBV] #24 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:34.232 | NQZ24_FUT_CME [CBV] #24 | Reloading chart. 2024-12-04 09:48:34.263 | NQZ24_FUT_CME [CBV] #22 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:34.263 | NQZ24_FUT_CME [CBV] #22 | Reloading chart. 2024-12-04 09:48:34.282 | NQZ24_FUT_CME [CBV] 30 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:34.287 | NQZ24_FUT_CME [CBV] 30 Min #3 | Reloading chart. 2024-12-04 09:48:34.289 | NQZ24_FUT_CME [CBV] 150000 Volume #16 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:34.289 | NQZ24_FUT_CME [CBV] 150000 Volume #16 | Reloading chart. 2024-12-04 09:48:34.306 | NQZ24_FUT_CME [CBV] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-04 09:48:34.306 | NQZ24_FUT_CME [CBV] 1 Min #17 | Reloading chart. 2024-12-04 09:48:34.308 | NQZ24_FUT_CME [CBV] #14 | Reloading chart. 2024-12-04 09:48:34.412 | NQZ24_FUT_CME [CBV] 3000 Volume #26 | Reloading chart. 2024-12-04 09:48:34.441 | NQZ24_FUT_CME [CBV] 30000 Volume #21 | Reloading chart. 2024-12-04 09:48:34.453 | NQZ24_FUT_CME [CBV] #15 | Reloading chart. 2024-12-04 09:48:34.578 | NQZ24_FUT_CME [CBV] #1 | Chart data loading complete. 2024-12-04 09:48:34.578 | Denali Data Feed | Network connection to server complete. 2024-12-04 09:48:34.578 | Denali Data Feed | Starting socket receive thread. 2024-12-04 09:48:34.579 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-12-04 09:48:34.579 | Requesting market depth updates for: NQZ24_FUT_CME if supported. NumLevels=100 2024-12-04 09:48:34.996 | NQZ24_FUT_CME [CBV] #6 | Chart data loading complete. 2024-12-04 09:48:35.000 | NQZ24_FUT_CME [CBV] #7 | Reloading chart. 2024-12-04 09:48:35.042 | NQZ24_FUT_CME [CBV] 500000 Volume #13 | Reloading chart. 2024-12-04 09:48:35.132 | NQZ24_FUT_CME [CBV] Rev. 4t #25 | Reloading chart. 2024-12-04 09:48:35.137 | NQZ24_FUT_CME [CBV] #6 | Reloading chart. 2024-12-04 09:48:35.315 | NQZ24_FUT_CME [CBV] #6 | Dates not found while checking for invalid data in continuous contract data files. NQZ14_FUT_CME * 2024-12-04 09:48:35.315 | Unable to determine transition date based on volume from files: NQZ12_FUT_CME.dly, NQH13_FUT_CME.dly 2024-12-04 09:48:35.315 | The NQH13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.315 | Unable to determine transition date based on volume from files: NQH13_FUT_CME.dly, NQM13_FUT_CME.dly 2024-12-04 09:48:35.315 | The NQM13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.315 | Unable to determine transition date based on volume from files: NQM13_FUT_CME.dly, NQU13_FUT_CME.dly 2024-12-04 09:48:35.315 | The NQU13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.315 | Unable to determine transition date based on volume from files: NQU13_FUT_CME.dly, NQZ13_FUT_CME.dly 2024-12-04 09:48:35.315 | The NQZ13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.315 | Unable to determine transition date based on volume from files: NQZ13_FUT_CME.dly, NQH14_FUT_CME.dly 2024-12-04 09:48:35.315 | The NQH14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.315 | Unable to determine transition date based on volume from files: NQH14_FUT_CME.dly, NQM14_FUT_CME.dly 2024-12-04 09:48:35.315 | The NQM14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.315 | Unable to determine transition date based on volume from files: NQM14_FUT_CME.dly, NQU14_FUT_CME.dly 2024-12-04 09:48:35.315 | The NQU14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.361 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-12-21 from file. D:\SierraChart CME\Data\NQZ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.361 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.362 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2013-03-15 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.362 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.362 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2013-06-21 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.362 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.362 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2013-09-20 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.362 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.362 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2013-12-20 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.362 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.363 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2014-03-21 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.363 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.363 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2014-06-20 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.363 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.363 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2014-09-19 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.363 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.468 | NQZ24_FUT_CME [CBV] Daily #11 | Chart data loading complete. 2024-12-04 09:48:35.470 | NQZ24_FUT_CME [CBV] Daily #11 | Reloading chart. 2024-12-04 09:48:35.650 | NQZ24_FUT_CME [CBV] Daily #11 | Dates not found while checking for invalid data in continuous contract data files. NQZ14_FUT_CME * 2024-12-04 09:48:35.650 | Unable to determine transition date based on volume from files: NQZ12_FUT_CME.dly, NQH13_FUT_CME.dly 2024-12-04 09:48:35.650 | The NQH13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.650 | Unable to determine transition date based on volume from files: NQH13_FUT_CME.dly, NQM13_FUT_CME.dly 2024-12-04 09:48:35.650 | The NQM13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.650 | Unable to determine transition date based on volume from files: NQM13_FUT_CME.dly, NQU13_FUT_CME.dly 2024-12-04 09:48:35.650 | The NQU13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.650 | Unable to determine transition date based on volume from files: NQU13_FUT_CME.dly, NQZ13_FUT_CME.dly 2024-12-04 09:48:35.650 | The NQZ13_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.650 | Unable to determine transition date based on volume from files: NQZ13_FUT_CME.dly, NQH14_FUT_CME.dly 2024-12-04 09:48:35.650 | The NQH14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.650 | Unable to determine transition date based on volume from files: NQH14_FUT_CME.dly, NQM14_FUT_CME.dly 2024-12-04 09:48:35.650 | The NQM14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.650 | Unable to determine transition date based on volume from files: NQM14_FUT_CME.dly, NQU14_FUT_CME.dly 2024-12-04 09:48:35.650 | The NQU14_FUT_CME.dly symbol may not be the active contract month. 2024-12-04 09:48:35.696 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2012-12-21 from file. D:\SierraChart CME\Data\NQZ12_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.696 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.696 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2013-03-15 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.696 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.697 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2013-06-21 from file. D:\SierraChart CME\Data\NQM13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.697 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.697 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2013-09-20 from file. D:\SierraChart CME\Data\NQU13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.697 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.697 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2013-12-20 from file. D:\SierraChart CME\Data\NQZ13_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.697 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.697 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2014-03-21 from file. D:\SierraChart CME\Data\NQH14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.697 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.698 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2014-06-20 from file. D:\SierraChart CME\Data\NQM14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.698 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.698 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 2014-09-19 from file. D:\SierraChart CME\Data\NQU14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.698 | NQZ24_FUT_CME [CBV] Daily #11 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQZ14_FUT_CME.dly. Error: No Data for read. End of file. 2024-12-04 09:48:35.789 | NQZ24_FUT_CME [CBV] 1 Sec #2 | Reloading chart. 2024-12-04 09:48:35.795 | NQZ24_FUT_CME [CBV] Renko 5t #4 | Reloading chart. 2024-12-04 09:48:35.805 | NQZ24_FUT_CME [CBV] Rev. 4t #12 | Reloading chart. 2024-12-04 09:48:35.814 | NQZ24_FUT_CME [CBV] #24 | Reloading chart. 2024-12-04 09:48:35.860 | NQZ24_FUT_CME [CBV] #22 | Reloading chart. 2024-12-04 09:48:35.896 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQZ24_FUT_CME 2024-12-04 09:48:35.896 | Teton CME Order Routing | Setting external service identifier for symbol NQZ24_FUT_CME to 106364 2024-12-04 09:48:35.896 | Teton CME Order Routing | Received security definition for symbol NQZ24_FUT_CME 2024-12-04 09:48:37.079 | NQZ24_FUT_CME [CBV] 30 Min #3 | Chart data loading complete. 2024-12-04 09:48:37.079 | NQZ24_FUT_CME [CBV] 150000 Volume #16 | Reloading chart. 2024-12-04 09:48:37.143 | NQZ24_FUT_CME [CBV] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2023-11-28 00:00:00 2024-12-04 09:48:40.639 | NQZ24_FUT_CME [CBV] 1 Min #17 | Chart data loading complete. 2024-12-04 09:48:40.687 | NQZ24_FUT_CME [CBV] 30000 Volume #21 | Chart data loading complete. 2024-12-04 09:48:40.704 | NQZ24_FUT_CME [CBV] Rev. 4t #25 | StartDateTimeForLoadingOrderFills: 2023-11-28 00:00:00 2024-12-04 09:48:44.541 | DTC Client socket (2) | Socket gracefully closed by remote side. | Number times message added: 1 2024-12-04 09:50:19.301 | NQZ24_FUT_CME [CBV] Rev. 4t #25 | Chart data loading complete. 2024-12-04 09:50:19.717 | NQZ24_FUT_CME [CBV] #6 | Chart data loading complete. 2024-12-04 09:50:19.719 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-12-04 09:50:19.719 | Denali Data Feed | Sending logon request message. 2024-12-04 09:50:19.719 | Denali Data Feed | Server has requested a logoff. Reason: No Logon message received. 2024-12-04 09:50:19.719 | Denali Data Feed | Failed connections: 1 2024-12-04 09:50:19.719 | Denali Data Feed | Waiting for socket receive thread to end 2024-12-04 09:50:19.719 | DTC Client socket (2) | CloseSocket call. 2024-12-04 09:50:19.719 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-04 09:50:19.719 | DTC Client socket (2) | Closed. 2024-12-04 09:50:19.719 | Denali Data Feed | Disconnected from the server. 2024-12-04 09:50:19.719 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2024-12-04 09:50:19.735 | NQZ24_FUT_CME [CBV] Daily #11 | Chart data loading complete. 2024-12-04 09:50:20.082 | Chart #2 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 09:50:20.082 | Chart #2 has tagged chart #3 for full recalculation. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 09:50:20.082 | NQZ24_FUT_CME [CBV] 1 Sec #2 | Chart data loading complete. 2024-12-04 09:50:20.087 | NQZ24_FUT_CME [CBV] Renko 5t #4 | StartDateTimeForLoadingOrderFills: 2023-11-28 00:00:00 2024-12-04 09:50:20.296 | NQZ24_FUT_CME [CBV] Renko 5t #4 | Chart data loading complete. 2024-12-04 09:50:25.533 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:50:35.521 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:50:45.524 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:50:55.530 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:51:05.532 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:51:15.533 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:51:25.443 | Chart #12 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 09:51:25.443 | NQZ24_FUT_CME [CBV] Rev. 4t #12 | Chart data loading complete. 2024-12-04 09:51:25.526 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:51:25.790 | NQZ24_FUT_CME [CBV] #24 | Chart data loading complete. 2024-12-04 09:51:26.348 | NQZ24_FUT_CME [CBV] #22 | Chart data loading complete. 2024-12-04 09:51:26.355 | NQZ24_FUT_CME [CBV] 30 Min #3 | Reloading chart. 2024-12-04 09:51:35.536 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:51:45.538 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:51:55.531 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:52:05.527 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:52:15.538 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:52:25.534 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:52:35.537 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:52:45.528 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:52:55.541 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:53:05.539 | BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. * 2024-12-04 09:53:08.690 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 09:53:08.954 | NQZ24_FUT_CME [CBV] 150000 Volume #16 | Chart data loading complete. 2024-12-04 09:53:08.975 | NQZ24_FUT_CME [CBV][M] 3000 Volume #26 | StartDateTimeForLoadingOrderFills: 2023-11-28 00:00:00 2024-12-04 09:53:09.051 | NQZ24_FUT_CME [CBV][M] 3000 Volume #26 | Chart data loading complete. 2024-12-04 09:53:09.658 | NQZ24_FUT_CME [CBV][M] #15 | Chart data loading complete. 2024-12-04 09:53:10.478 | NQZ24_FUT_CME [CBV][M] #7 | Chart data loading complete. 2024-12-04 09:53:10.630 | NQZ24_FUT_CME [CBV][M] 500000 Volume #13 | Chart data loading complete. 2024-12-04 09:53:10.635 | NQZ24_FUT_CME [CBV] 1 Min #17 | Reloading chart. 2024-12-04 09:53:11.543 | NQZ24_FUT_CME [CBV][M] #14 | Chart data loading complete. 2024-12-04 09:53:11.545 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2024-12-04 09:53:11.619 | : Array is unallocated. | Number times message added: 10 2024-12-04 09:53:13.209 | Chart #3 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 09:53:13.209 | Chart #3 has tagged chart #17 for full recalculation. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 09:53:13.209 | Chart #3 has tagged chart #25 for full recalculation. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 09:53:13.209 | NQZ24_FUT_CME [CBV] 30 Min #3 | Chart data loading complete. 2024-12-04 09:53:13.728 | NQZ24_FUT_CME [CBV] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2023-11-28 00:00:00 2024-12-04 09:53:17.235 | NQZ24_FUT_CME [CBV] 1 Min #17 | Chart data loading complete. 2024-12-04 09:53:17.237 | NQZ24_FUT_CME [CBV][M] Rev. 4t #25 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 09:54:56.491 | : Array is unallocated. | Number times message added: 10 2024-12-04 09:54:56.503 | NQZ24_FUT_CME [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 09:55:46.829 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht. 2024-12-04 09:55:50.326 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-01-02"}. Success=true 2024-12-04 09:55:50.402 | : Array is unallocated. | Number times message added: 2 2024-12-04 09:55:50.402 | Array message repeat count limit reached. 2024-12-04 09:59:02.633 | NQZ24_FUT_CME [CBV][M] 3000 Volume #26 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-04 09:59:03.095 | NQZ24_FUT_CME [CBV][M] Rev. 4t #25 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-04 09:59:03.205 | NQZ24_FUT_CME [CBV][M] Renko 5t #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-04 10:00:44.595 | Chart #25 has tagged chart #12 for full recalculation. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 10:00:44.866 | NQZ24_FUT_CME [CBV][M] 1 Min #17 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-04 10:00:44.962 | NQZ24_FUT_CME [CBV][M] Rev. 4t #12 | Performing a full recalculation because it has been tagged. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht 2024-12-04 10:01:35.308 | Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht. |
[2024-12-04 18:06:16] |
John - SC Support - Posts: 38782 |
First, you are getting a message about a circular reference: Circular chart reference detected. Charts: 25, 12. Chartbook: LeTradingFr_CB_CME_NQ_Trading_V3_Lourd.Cht.
You need to resolve this circular reference. Refer to the following: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.9 References to Other Charts / Continuous Full Recalculation of Charts Second, you are requesting data going very far back for your continuous futures contract and there is some daily data that is not available causing the back-adjustment to not work correctly. This is shown in messages like the following: 2024-12-04 09:48:33.969 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 2012-12-21 from file. D:\SierraChart CME\Data\NQZ12_FUT_CME.dly. Error: No Data for read. End of file.
2024-12-04 09:48:33.969 | NQZ24_FUT_CME [CBV] #6 | Error while getting daily settlement price with date 0 from file. D:\SierraChart CME\Data\NQH13_FUT_CME.dly. Error: No Data for read. End of file. Refer to the following regarding this: Continuous Futures Contract Charts: Preventing Error Messages by Reducing Days to Load in Chart There is also the following error: BufferedSocket | Error posting message in c_AsyncWindow::PostMessage. Windows error code 1816: Le quota disponible est insuffisant pour traiter cette commande. *
We are not sure why you are getting this error. Although it seems to be in regards to a message, so it could be related to alerts and having too many at one time. But check your drive space and make sure you are not out of space on your drive, just to be certain. After you fix the above, then let us know if you are still having a problem. If you are, then we need to know exactly what it is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-09 14:19:29] |
User914407 - Posts: 49 |
Bonjour, J'ai aussi des lenteurs sur ce compte : 2024-12-09 15:00:58.545 | Trade activity files set size: 64 2024-12-09 15:00:58.550 | Rithmic Direct - DTC | Processed connection points. Count: 347 2024-12-09 15:00:58.566 | Created the DTC Protocol server. 2024-12-09 15:00:58.567 | DTC Protocol Server listening on port 11099. 2024-12-09 15:00:58.567 | Reading Internal Order ID file. 2024-12-09 15:00:58.580 | Reading Trade Orders file. 2024-12-09 15:00:58.580 | Reading Trade Positions file. 2024-12-09 15:00:58.580 | Reading Trade Account Data files. 2024-12-09 15:00:58.582 | Software version: 2714 64-bit 2024-12-09 15:00:58.582 | Primary Thread ID: 10652 2024-12-09 15:00:58.582 | Usage end date: 2025-11-06 2024-12-09 15:00:58.582 | Enabled for: Advanced Features 2. 2024-12-09 15:00:58.582 | Enabled for: Sierra Chart Historical Data Service. 2024-12-09 15:00:58.582 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-12-09 15:00:58.582 | Enabled for: Delayed Denali Exchange Data Feed. 2024-12-09 15:00:58.582 | Enabled for exchange2: CME 2024-12-09 15:00:58.582 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-12-09 15:00:58.582 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-12-09 15:00:58.582 | Custom symbol settings values: enabled 2024-12-09 15:00:58.582 | Chart Update Interval: 300 2024-12-09 15:00:58.582 | Intraday Data Storage Time Unit: 0 2024-12-09 15:00:58.582 | Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) 2024-12-09 15:00:58.582 | 2024-12-09 14:00:58 Local computer time in UTC 2024-12-09 15:00:58.582 | 2024-12-09 15:00:58 Local computer time in SC Time Zone 2024-12-09 15:00:58.582 | 2024-12-09 14:00:57 Server time in UTC 2024-12-09 15:00:58.582 | Local computer UTC time and Server UTC time difference: 1 seconds. 2024-12-09 15:00:58.582 | Program path: D:\SierraChart CME\ 2024-12-09 15:00:58.582 | Data Files path: D:\SierraChart CME\Data\ 2024-12-09 15:00:58.582 | OS Version Number: 10.0 2024-12-09 15:00:58.582 | Locale Setting: C 2024-12-09 15:00:58.582 | DLLs: UserContributedStudies_64.dll 2024-12-09 15:00:58.582 | Allowed protected custom studies: 2024-12-09 15:00:58.582 | Crash reporter started: true 2024-12-09 15:00:58.582 | 2024-12-09 15:00:58.585 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2024-12-09 15:00:58.585 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2024-12-09 15:00:58.585 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130. 2024-12-09 15:00:58.607 | Created the DTC Protocol historical data server. 2024-12-09 15:00:58.608 | HD Server Manager | Listening on port 11098. 2024-12-09 15:00:58.608 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2024-12-09 15:00:58.730 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-12-09 15:00:58.870 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-12-09 15:00:58.870 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-12-09 15:00:59.005 | Received 5 login tokens. 2024-12-09 15:00:59.093 | Rithmic Direct - DTC | Wrote file: D:\SierraChart CME\RithmicConnections.json. Size: 81131 2024-12-09 15:00:59.093 | Rithmic Direct - DTC | Processed connection points. Count: 347 2024-12-09 15:00:59.342 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2024-12-09 15:00:59.342 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. 2024-12-09 15:00:59.344 | Symbol settings MD5 received. Request ID: 1. 2024-12-09 15:00:59.344 | Symbol settings are up-to-date for rithmic_v2.trading. 2024-12-09 15:00:59.467 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. 2024-12-09 15:00:59.467 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2024-12-09 15:01:01.095 | Requested user files to download. 2024-12-09 15:01:03.108 | 2024-12-09 15:01:03.108 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated 2024-12-09 15:01:03.108 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500 2024-12-09 15:01:03.109 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 2024-12-09 15:01:03.146 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-12-09 15:01:03.146 | DTC Client socket (1) | New receive buffer size: 0 2024-12-09 15:01:03.146 | DTC Client socket (1) | Connecting to IP: 216.57.156.163. 2024-12-09 15:01:03.146 | Rithmic Direct - DTC | Network connection to server complete. 2024-12-09 15:01:03.146 | Rithmic Direct - DTC | Starting socket receive thread. 2024-12-09 15:01:03.146 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-12-09 15:01:03.146 | Rithmic Direct - DTC | Sending logon request message. 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | Received logon response. 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | Server Name: . 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | Successfully connected. 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | Trading is supported. 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | OCO Orders supported. 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2024-12-09 15:01:03.582 | Rithmic Direct - DTC | Connected to server complete. 2024-12-09 15:01:03.582 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-12-09 15:01:08.497 | NQZ4.CME [CV] #1 | Reloading chart. 2024-12-09 15:01:08.497 | Starting DelayedDownloadMonitoringTimer 2024-12-09 15:01:08.497 | Starting HDTimeoutTimer 2024-12-09 15:01:08.497 | Added historical Intraday data request for NQZ4.CME to the queue. 2024-12-09 15:01:08.498 | Triggering next historical data download in queue. 2024-12-09 15:01:08.507 | NQZ4.CME [CV] #1 | Waiting for historical downloads to complete with the IDs: 1, 2024-12-09 15:01:08.521 | NQZ4.CME [CBV] #5 | Reloading chart. 2024-12-09 15:01:08.530 | NQZ4.CME [CBV] #5 | Waiting for historical downloads to complete with the IDs: 1, 2024-12-09 15:01:08.651 | NQZ4.CME [CBV] 1 Min #4 | Reloading chart. 2024-12-09 15:01:08.660 | NQZ4.CME [CBV] 1 Min #4 | Waiting for historical downloads to complete with the IDs: 1, 2024-12-09 15:01:08.788 | NQZ4.CME [CBV] 5 Min #7 | Reloading chart. 2024-12-09 15:01:08.797 | NQZ4.CME [CBV] 5 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2024-12-09 15:01:08.886 | NQZ4.CME [CBV] 1 Min #3 | Reloading chart. 2024-12-09 15:01:08.895 | NQZ4.CME [CBV] 1 Min #3 | Waiting for historical downloads to complete with the IDs: 1, 2024-12-09 15:01:08.909 | NQZ4.CME [CBV] #9 | Reloading chart. 2024-12-09 15:01:08.918 | NQZ4.CME [CBV] #9 | Waiting for historical downloads to complete with the IDs: 1, 2024-12-09 15:01:08.921 | NQZ4.CME 30 Min #10 | Reloading chart. 2024-12-09 15:01:09.012 | NQZ4.CME [CBV] 1 Min #2 | Reloading chart. 2024-12-09 15:01:09.021 | NQZ4.CME [CBV] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2024-12-09 15:01:09.029 | Mapping NQZ4.CME to NQZ24. Service code: cme 2024-12-09 15:01:09.029 | Using symbol data fast lookup vector 2024-12-09 15:01:09.029 | HD Request # 1 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme 2024-12-09 15:01:09.029 | HD Request # 1 | Download start date-time: 2024-12-09 15:00:14.000000. File last date-time: 2024-12-09 15:00:14.160000 2024-12-09 15:01:09.029 | HD Request # 1 | Using server: ds28.sierracharts.com port 10150 2024-12-09 15:01:09.046 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 1 Service code: cme 2024-12-09 15:01:09.047 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443 2024-12-09 15:01:09.047 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 1 2024-12-09 15:01:09.047 | Requesting market depth updates for: NQZ4.CME if supported. NumLevels=100 2024-12-09 15:01:09.063 | Socket (2) | Creating socket. 2024-12-09 15:01:09.063 | Socket (2) | New receive buffer size: 0 2024-12-09 15:01:09.063 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-12-09 15:01:09.093 | DTC Client socket (4) | Creating socket. 2024-12-09 15:01:09.093 | DTC Client socket (4) | New receive buffer size: 0 2024-12-09 15:01:09.093 | DTC Client socket (4) | Connecting to IP: 67.214.125.6. 2024-12-09 15:01:09.093 | Denali Data Feed | Network connection to server complete. 2024-12-09 15:01:09.093 | Denali Data Feed | Starting socket receive thread. 2024-12-09 15:01:09.094 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2024-12-09 15:01:09.284 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-12-09 15:01:09.284 | HD Request # 1 | Sending historical data logon request message. 2024-12-09 15:01:09.341 | Denali Data Feed | Setting DTC encoding to Binary VLS 2024-12-09 15:01:09.341 | Denali Data Feed | Sending logon request message. 2024-12-09 15:01:09.430 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-12-09 15:00:14. Record interval: 0. Symbol: NQZ24 2024-12-09 15:01:09.530 | HD Request # 1 | Decompressing data. 2024-12-09 15:01:09.621 | HD Request # 1 | Receiving Intraday data for NQZ4.CME starting at 2024-12-09 15:00:14.160000 2024-12-09 15:01:09.621 | Socket (2) | CloseSocket call. 2024-12-09 15:01:09.621 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-12-09 15:01:09.621 | Historical data download thread signaled to stop. 2024-12-09 15:01:09.621 | HD Request # 1 | Timestamp of first Intraday data file record written: 2024-12-09 15:00:15.068000. 2024-12-09 15:01:09.621 | HD Request # 1 | Received 124 Intraday data records from 2024-12-09 15:00:14.160000 to 2024-12-09 15:01:05.653001 (51.5 seconds. Delay: 4.0 seconds) and wrote 123 records for NQZ4.CME 2024-12-09 15:01:09.622 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-12-09 14:01:05.653001 2024-12-09 15:01:09.622 | HD Request # 1 | Completion time: 0s. 2024-12-09 15:01:09.622 | HD Request # 1 | Intraday data download complete for NQZ4.CME. Unique request ID: 1 2024-12-09 15:01:09.622 | Removing historical data download ID 1. 2024-12-09 15:01:09.622 | Real-time Intraday chart data file updates started for NQZ4.CME 2024-12-09 15:01:09.622 | Intraday chart data file opened for NQZ4.CME 2024-12-09 15:01:09.622 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-12-09 15:01:09.622 | 2024-12-09 15:01:09.622 | No download requests in the queue to start downloads for. 2024-12-09 15:01:09.622 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. 2024-12-09 15:01:09.641 | NQZ4.CME [CBV] 1 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:01:09.641 | NQZ4.CME [CBV] 1 Min #2 | Reloading chart. 2024-12-09 15:01:09.719 | Socket (2) | Socket gracefully closed by remote side. 2024-12-09 15:01:09.719 | Socket (2) | Closed. 2024-12-09 15:01:09.733 | NQZ4.CME [CBV] 5 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:01:09.733 | NQZ4.CME [CBV] 5 Min #7 | Reloading chart. 2024-12-09 15:01:09.749 | NQZ4.CME [CV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:01:09.749 | NQZ4.CME [CV] #1 | Reloading chart. 2024-12-09 15:01:09.780 | NQZ4.CME [CBV] #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:01:09.780 | NQZ4.CME [CBV] #5 | Reloading chart. 2024-12-09 15:01:09.827 | NQZ4.CME [CBV] 1 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:01:09.827 | NQZ4.CME [CBV] 1 Min #3 | Reloading chart. 2024-12-09 15:01:09.843 | Denali Data Feed | Received logon response. 2024-12-09 15:01:09.843 | Denali Data Feed | Server Name: SC Realtime Server. 2024-12-09 15:01:09.843 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2024-12-09 15:01:09.843 | Denali Data Feed | Successfully connected. 2024-12-09 15:01:09.843 | Denali Data Feed | Trading is not supported. 2024-12-09 15:01:09.843 | Denali Data Feed | MarketDepthIsSupported: 1 2024-12-09 15:01:09.843 | Added historical Intraday data request for NQZ4.CME to the queue. 2024-12-09 15:01:09.843 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'. 2024-12-09 15:01:09.843 | Triggering next historical data download in queue. 2024-12-09 15:01:09.843 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24. Market Depth data restarted. 2024-12-09 15:01:09.843 | Delaying start of download for NQZ4.CME. 2024-12-09 15:01:09.858 | NQZ4.CME [CBV] #9 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:01:09.858 | NQZ4.CME [CBV] #9 | Reloading chart. 2024-12-09 15:01:09.904 | NQZ4.CME [CBV] 1 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:01:09.904 | NQZ4.CME [CBV] 1 Min #4 | Reloading chart. 2024-12-09 15:01:09.968 | NQZ4.CME [CBV] 1 Min #2 | Reloading chart. 2024-12-09 15:01:09.983 | NQZ4.CME [CBV] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 2, 2024-12-09 15:01:10.029 | Denali Data Feed | Clearing market depth for NQZ4.CME 2024-12-09 15:01:10.029 | Denali Data Feed | Setting external service identifier for symbol NQZ4.CME to 106364 2024-12-09 15:01:10.029 | Denali Data Feed | Received security definition for symbol NQZ4.CME 2024-12-09 15:01:10.046 | NQZ4.CME [CBV] 5 Min #7 | Reloading chart. 2024-12-09 15:01:10.055 | NQZ4.CME [CBV] 5 Min #7 | Waiting for historical downloads to complete with the IDs: 2, 2024-12-09 15:01:10.067 | NQZ4.CME [CV] #1 | Reloading chart. 2024-12-09 15:01:10.078 | NQZ4.CME [CV] #1 | Waiting for historical downloads to complete with the IDs: 2, 2024-12-09 15:01:10.094 | NQZ4.CME [CBV] #5 | Reloading chart. 2024-12-09 15:01:10.104 | NQZ4.CME [CBV] #5 | Waiting for historical downloads to complete with the IDs: 2, 2024-12-09 15:01:10.141 | NQZ4.CME [CBV] 1 Min #3 | Reloading chart. 2024-12-09 15:01:10.150 | NQZ4.CME [CBV] 1 Min #3 | Waiting for historical downloads to complete with the IDs: 2, 2024-12-09 15:01:10.157 | NQZ4.CME [CBV] #9 | Reloading chart. 2024-12-09 15:01:10.168 | NQZ4.CME [CBV] #9 | Waiting for historical downloads to complete with the IDs: 2, 2024-12-09 15:01:10.205 | NQZ4.CME [CBV] 1 Min #4 | Reloading chart. 2024-12-09 15:01:10.217 | NQZ4.CME [CBV] 1 Min #4 | Waiting for historical downloads to complete with the IDs: 2, 2024-12-09 15:01:10.275 | NQZ4.CME[M] 30 Min #10 | Chart data loading complete. 2024-12-09 15:01:12.864 | NQZ4.CME [CBV] 5 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:01:12.875 | NQZ4.CME [CBV] 5 Min #7 | Chart data loading complete. 2024-12-09 15:01:13.775 | NQZ4.CME [CBV] #5 | Chart data loading complete. 2024-12-09 15:01:13.776 | NQZ4.CME [CBV] 1 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:02:02.769 | NQZ4.CME [CBV] 1 Min #2 | Chart data loading complete. 2024-12-09 15:02:52.088 | NQZ4.CME [CV] #1 | Chart data loading complete. 2024-12-09 15:02:52.090 | NQZ4.CME [CBV] 1 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:03:40.961 | NQZ4.CME [CBV] 1 Min #3 | Chart data loading complete. 2024-12-09 15:03:41.010 | NQZ4.CME [CBV] 1 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:04:30.000 | NQZ4.CME [CBV] 1 Min #4 | Chart data loading complete. 2024-12-09 15:04:30.441 | NQZ4.CME [CBV] #9 | Chart data loading complete. 2024-12-09 15:04:30.442 | Historical data timed out while delaying download. * 2024-12-09 15:04:30.442 | Removing historical data download ID 2. 2024-12-09 15:04:30.442 | Real-time Intraday chart data file updates started for NQZ4.CME 2024-12-09 15:04:30.442 | Intraday chart data file opened for NQZ4.CME 2024-12-09 15:04:30.442 | No download requests in the queue to start downloads for. 2024-12-09 15:04:30.453 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. 2024-12-09 15:04:30.453 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0 2024-12-09 15:04:30.453 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 216.66.0.130. 2024-12-09 15:04:30.457 | NQZ4.CME [CBV] 1 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:04:30.462 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2. 2024-12-09 15:04:30.463 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 0 2024-12-09 15:04:30.463 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 216.66.0.130. 2024-12-09 15:04:30.464 | NQZ4.CME [CBV] 1 Min #2 | Reloading chart. 2024-12-09 15:04:30.479 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Creating socket. Using TLS 1.2. 2024-12-09 15:04:30.479 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | New receive buffer size: 0 2024-12-09 15:04:30.479 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Connecting to IP: 216.66.0.130. 2024-12-09 15:04:30.483 | NQZ4.CME [CBV] 5 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:04:30.484 | NQZ4.CME [CBV] 5 Min #7 | Reloading chart. 2024-12-09 15:04:30.487 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (6) | Creating socket. Using TLS 1.2. 2024-12-09 15:04:30.487 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (6) | New receive buffer size: 0 2024-12-09 15:04:30.487 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (6) | Connecting to IP: 216.66.0.130. 2024-12-09 15:04:30.496 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | Creating socket. Using TLS 1.2. 2024-12-09 15:04:30.496 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | New receive buffer size: 0 2024-12-09 15:04:30.496 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | Connecting to IP: 216.66.0.130. 2024-12-09 15:04:35.648 | Opened cached Intraday file: D:\SierraChart CME\Data\NQZ4.CME.scid. Thread ID: 19600 2024-12-09 15:05:36.146 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. 2024-12-09 15:05:36.146 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (6) | Socket gracefully closed by remote side. 2024-12-09 15:05:36.146 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. 2024-12-09 15:05:36.146 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Socket gracefully closed by remote side. 2024-12-09 15:05:36.146 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | Socket gracefully closed by remote side. 2024-12-09 15:06:37.147 | NQZ4.CME [CBV] #5 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:06:37.149 | NQZ4.CME [CBV] #5 | Reloading chart. 2024-12-09 15:06:37.156 | NQZ4.CME [CV] #1 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:06:37.159 | NQZ4.CME [CV] #1 | Reloading chart. 2024-12-09 15:06:37.176 | NQZ4.CME [CBV] 1 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:06:37.184 | NQZ4.CME [CBV] 1 Min #3 | Reloading chart. 2024-12-09 15:06:37.196 | NQZ4.CME [CBV] #9 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:06:37.202 | NQZ4.CME [CBV] #9 | Reloading chart. 2024-12-09 15:06:37.212 | NQZ4.CME [CBV] 1 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. 2024-12-09 15:06:37.219 | NQZ4.CME [CBV] 1 Min #4 | Reloading chart. 2024-12-09 15:06:37.231 | NQZ4.CME [CBV] 1 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:07:30.690 | NQZ4.CME [CBV] 1 Min #2 | Chart data loading complete. 2024-12-09 15:07:30.726 | NQZ4.CME [CBV] 5 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:07:30.737 | NQZ4.CME [CBV] 5 Min #7 | Chart data loading complete. 2024-12-09 15:07:30.755 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call. 2024-12-09 15:07:30.755 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:07:30.755 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed. 2024-12-09 15:07:30.755 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (6) | CloseSocket call. 2024-12-09 15:07:30.755 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:07:30.756 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (6) | Closed. 2024-12-09 15:07:30.756 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | CloseSocket call. 2024-12-09 15:07:30.756 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:07:30.756 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Closed. 2024-12-09 15:07:30.756 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | CloseSocket call. 2024-12-09 15:07:30.756 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | CloseSocket call. 2024-12-09 15:07:30.756 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:07:30.756 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Closed. 2024-12-09 15:07:30.756 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:07:30.756 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (7) | Closed. 2024-12-09 15:07:30.794 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (8) | Creating socket. Using TLS 1.2. 2024-12-09 15:07:30.794 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (8) | New receive buffer size: 0 2024-12-09 15:07:30.794 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (8) | Connecting to IP: 216.66.0.130. 2024-12-09 15:07:30.805 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Creating socket. Using TLS 1.2. 2024-12-09 15:07:30.805 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | New receive buffer size: 0 2024-12-09 15:07:30.805 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Connecting to IP: 216.66.0.130. 2024-12-09 15:07:30.820 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (6) | Creating socket. Using TLS 1.2. 2024-12-09 15:07:30.820 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (6) | New receive buffer size: 0 2024-12-09 15:07:30.820 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (6) | Connecting to IP: 216.66.0.130. 2024-12-09 15:07:30.832 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (3) | Creating socket. Using TLS 1.2. 2024-12-09 15:07:30.832 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (3) | New receive buffer size: 0 2024-12-09 15:07:30.832 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (3) | Connecting to IP: 216.66.0.130. 2024-12-09 15:07:30.842 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Creating socket. Using TLS 1.2. 2024-12-09 15:07:30.842 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | New receive buffer size: 0 2024-12-09 15:07:30.842 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Connecting to IP: 216.66.0.130. 2024-12-09 15:08:23.115 | NQZ4.CME [CBV] #5 | Chart data loading complete. 2024-12-09 15:08:23.460 | NQZ4.CME [CV] #1 | Chart data loading complete. 2024-12-09 15:08:23.461 | NQZ4.CME [CBV] 1 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:08:36.149 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (8) | Socket gracefully closed by remote side. 2024-12-09 15:08:36.149 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (6) | Socket gracefully closed by remote side. 2024-12-09 15:08:36.149 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (3) | Socket gracefully closed by remote side. 2024-12-09 15:08:36.149 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Socket gracefully closed by remote side. 2024-12-09 15:08:36.150 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Socket gracefully closed by remote side. 2024-12-09 15:09:15.193 | NQZ4.CME [CBV] 1 Min #3 | Chart data loading complete. 2024-12-09 15:09:15.792 | NQZ4.CME [CBV] #9 | Chart data loading complete. 2024-12-09 15:09:15.793 | NQZ4.CME [CBV] 1 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:10:20.072 | NQZ4.CME [CBV] 1 Min #4 | Chart data loading complete. 2024-12-09 15:10:20.229 | NQZ4.CME [CBV] 1 Min #2 | Reloading chart. 2024-12-09 15:10:20.245 | NQZ4.CME [CBV] 5 Min #7 | Reloading chart. 2024-12-09 15:10:20.276 | NQZ4.CME [CBV] #5 | Reloading chart. 2024-12-09 15:12:08.826 | NQZ4.CME [CV] #1 | Reloading chart. 2024-12-09 15:12:08.842 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (8) | CloseSocket call. 2024-12-09 15:12:08.842 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:12:08.842 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (8) | Closed. 2024-12-09 15:12:08.842 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (6) | CloseSocket call. 2024-12-09 15:12:08.842 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:12:08.842 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (6) | Closed. 2024-12-09 15:12:08.842 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (3) | CloseSocket call. 2024-12-09 15:12:08.842 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:12:08.842 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (3) | Closed. 2024-12-09 15:12:08.842 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | CloseSocket call. 2024-12-09 15:12:08.842 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:12:08.842 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Closed. 2024-12-09 15:12:08.842 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | CloseSocket call. 2024-12-09 15:12:08.842 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:12:08.842 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (2) | Closed. 2024-12-09 15:12:08.851 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (9) | Creating socket. Using TLS 1.2. 2024-12-09 15:12:08.851 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (9) | New receive buffer size: 0 2024-12-09 15:12:08.851 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (9) | Connecting to IP: 216.66.0.130. 2024-12-09 15:12:08.858 | NQZ4.CME [CBV] 1 Min #3 | Reloading chart. 2024-12-09 15:12:08.860 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (8) | Creating socket. Using TLS 1.2. 2024-12-09 15:12:08.860 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (8) | New receive buffer size: 0 2024-12-09 15:12:08.860 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (8) | Connecting to IP: 216.66.0.130. 2024-12-09 15:12:08.868 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (6) | Creating socket. Using TLS 1.2. 2024-12-09 15:12:08.868 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (6) | New receive buffer size: 0 2024-12-09 15:12:08.868 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (6) | Connecting to IP: 216.66.0.130. 2024-12-09 15:12:08.876 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (3) | Creating socket. Using TLS 1.2. 2024-12-09 15:12:08.876 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (3) | New receive buffer size: 0 2024-12-09 15:12:08.876 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (3) | Connecting to IP: 216.66.0.130. 2024-12-09 15:12:08.878 | NQZ4.CME [CBV] #9 | Reloading chart. 2024-12-09 15:12:08.885 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Creating socket. Using TLS 1.2. 2024-12-09 15:12:08.885 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | New receive buffer size: 0 2024-12-09 15:12:08.885 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Connecting to IP: 216.66.0.130. 2024-12-09 15:12:08.897 | NQZ4.CME [CBV] 1 Min #4 | Reloading chart. 2024-12-09 15:12:08.912 | NQZ4.CME [CBV] 1 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:12:57.990 | NQZ4.CME [CBV] 1 Min #2 | Chart data loading complete. 2024-12-09 15:12:57.992 | NQZ4.CME [CBV] 5 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:12:58.002 | NQZ4.CME [CBV] 5 Min #7 | Chart data loading complete. 2024-12-09 15:12:58.145 | NQZ4.CME [CBV] #5 | Chart data loading complete. 2024-12-09 15:13:03.465 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (6) | Socket gracefully closed by remote side. 2024-12-09 15:13:03.465 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (9) | Socket gracefully closed by remote side. 2024-12-09 15:13:03.465 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Socket gracefully closed by remote side. 2024-12-09 15:13:03.465 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (8) | Socket gracefully closed by remote side. 2024-12-09 15:13:03.465 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (3) | Socket gracefully closed by remote side. 2024-12-09 15:13:47.635 | NQZ4.CME [CV] #1 | Chart data loading complete. 2024-12-09 15:13:47.637 | NQZ4.CME [CBV] 1 Min #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:14:36.548 | NQZ4.CME [CBV] 1 Min #3 | Chart data loading complete. 2024-12-09 15:14:36.996 | NQZ4.CME [CBV] #9 | Chart data loading complete. 2024-12-09 15:14:37.000 | NQZ4.CME [CBV] 1 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2024-12-09 15:15:29.471 | NQZ4.CME [CBV] 1 Min #4 | Chart data loading complete. 2024-12-09 15:15:29.532 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (6) | Socket gracefully closed by remote side. 2024-12-09 15:15:29.532 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (9) | Socket gracefully closed by remote side. 2024-12-09 15:15:29.532 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (3) | Socket gracefully closed by remote side. 2024-12-09 15:15:29.532 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (8) | Socket gracefully closed by remote side. 2024-12-09 15:15:29.532 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Socket gracefully closed by remote side. 2024-12-09 15:15:29.534 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (6) | CloseSocket call. 2024-12-09 15:15:29.534 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:15:29.534 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (6) | Closed. 2024-12-09 15:15:29.534 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (9) | CloseSocket call. 2024-12-09 15:15:29.534 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:15:29.534 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (9) | Closed. 2024-12-09 15:15:29.534 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | CloseSocket call. 2024-12-09 15:15:29.534 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:15:29.534 | HTTPS connection ID:16 to downloads.rithmic.com:443 for request ID:16 (5) | Closed. 2024-12-09 15:15:29.534 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (8) | CloseSocket call. 2024-12-09 15:15:29.534 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:15:29.534 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (8) | Closed. 2024-12-09 15:15:29.534 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (3) | CloseSocket call. 2024-12-09 15:15:29.534 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:15:29.534 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (3) | Closed. 2024-12-09 15:15:29.570 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (10) | Creating socket. Using TLS 1.2. 2024-12-09 15:15:29.570 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (10) | New receive buffer size: 0 2024-12-09 15:15:29.570 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (10) | Connecting to IP: 216.66.0.130. 2024-12-09 15:15:29.578 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (6) | Creating socket. Using TLS 1.2. 2024-12-09 15:15:29.578 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (6) | New receive buffer size: 0 2024-12-09 15:15:29.578 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (6) | Connecting to IP: 216.66.0.130. 2024-12-09 15:15:29.587 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (9) | Creating socket. Using TLS 1.2. 2024-12-09 15:15:29.587 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (9) | New receive buffer size: 0 2024-12-09 15:15:29.587 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (9) | Connecting to IP: 216.66.0.130. 2024-12-09 15:15:29.595 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (5) | Creating socket. Using TLS 1.2. 2024-12-09 15:15:29.595 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (5) | New receive buffer size: 0 2024-12-09 15:15:29.595 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (5) | Connecting to IP: 216.66.0.130. 2024-12-09 15:15:29.604 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (8) | Creating socket. Using TLS 1.2. 2024-12-09 15:15:29.604 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (8) | New receive buffer size: 0 2024-12-09 15:15:29.604 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (8) | Connecting to IP: 216.66.0.130. 2024-12-09 15:16:36.115 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (10) | Socket gracefully closed by remote side. 2024-12-09 15:16:36.115 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (6) | Socket gracefully closed by remote side. 2024-12-09 15:16:36.115 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (5) | Socket gracefully closed by remote side. 2024-12-09 15:16:36.115 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (9) | Socket gracefully closed by remote side. 2024-12-09 15:16:36.115 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (8) | Socket gracefully closed by remote side. 2024-12-09 15:17:29.166 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (10) | CloseSocket call. 2024-12-09 15:17:29.166 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:17:29.166 | HTTPS connection ID:17 to downloads.rithmic.com:443 for request ID:17 (10) | Closed. 2024-12-09 15:17:29.166 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (6) | CloseSocket call. 2024-12-09 15:17:29.166 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:17:29.166 | HTTPS connection ID:18 to downloads.rithmic.com:443 for request ID:18 (6) | Closed. 2024-12-09 15:17:29.166 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (5) | CloseSocket call. 2024-12-09 15:17:29.166 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:17:29.166 | HTTPS connection ID:20 to downloads.rithmic.com:443 for request ID:20 (5) | Closed. 2024-12-09 15:17:29.166 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (9) | CloseSocket call. 2024-12-09 15:17:29.166 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:17:29.166 | HTTPS connection ID:19 to downloads.rithmic.com:443 for request ID:19 (9) | Closed. 2024-12-09 15:17:29.166 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (8) | CloseSocket call. 2024-12-09 15:17:29.166 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-12-09 15:17:29.166 | HTTPS connection ID:21 to downloads.rithmic.com:443 for request ID:21 (8) | Closed. 2024-12-09 15:17:29.189 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (11) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:29.189 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (11) | New receive buffer size: 0 2024-12-09 15:17:29.189 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (11) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:29.198 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (6) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:29.198 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (6) | New receive buffer size: 0 2024-12-09 15:17:29.198 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (6) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:29.207 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (7) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:29.207 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (7) | New receive buffer size: 0 2024-12-09 15:17:29.207 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (7) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:29.215 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (5) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:29.215 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (5) | New receive buffer size: 0 2024-12-09 15:17:29.215 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (5) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:29.224 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (9) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:29.224 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (9) | New receive buffer size: 0 2024-12-09 15:17:29.224 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (9) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:30.190 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (11) | CloseSocket call. 2024-12-09 15:17:30.190 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (7) | CloseSocket call. 2024-12-09 15:17:30.190 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (5) | CloseSocket call. 2024-12-09 15:17:30.190 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (6) | CloseSocket call. 2024-12-09 15:17:30.190 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (11) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:30.190 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (9) | CloseSocket call. 2024-12-09 15:17:30.190 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (7) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:30.190 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (5) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:30.190 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (6) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:30.190 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (9) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:30.200 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (8) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:30.200 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (8) | New receive buffer size: 0 2024-12-09 15:17:30.200 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (8) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:30.209 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (10) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:30.209 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (10) | New receive buffer size: 0 2024-12-09 15:17:30.209 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (10) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:30.218 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (12) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:30.218 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (12) | New receive buffer size: 0 2024-12-09 15:17:30.218 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (12) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:30.228 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (13) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:30.228 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (13) | New receive buffer size: 0 2024-12-09 15:17:30.228 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (13) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:30.237 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (14) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:30.237 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (14) | New receive buffer size: 0 2024-12-09 15:17:30.237 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (14) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:30.311 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (11) | Socket gracefully closed by remote side. 2024-12-09 15:17:30.311 | HTTPS connection ID:22 to downloads.rithmic.com:443 for request ID:22 (11) | Closed. 2024-12-09 15:17:30.311 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (7) | Socket gracefully closed by remote side. 2024-12-09 15:17:30.311 | HTTPS connection ID:24 to downloads.rithmic.com:443 for request ID:24 (7) | Closed. 2024-12-09 15:17:30.311 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (6) | Socket gracefully closed by remote side. 2024-12-09 15:17:30.312 | HTTPS connection ID:23 to downloads.rithmic.com:443 for request ID:23 (6) | Closed. 2024-12-09 15:17:30.312 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (9) | Socket gracefully closed by remote side. 2024-12-09 15:17:30.312 | HTTPS connection ID:26 to downloads.rithmic.com:443 for request ID:26 (9) | Closed. 2024-12-09 15:17:30.313 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (5) | Socket gracefully closed by remote side. 2024-12-09 15:17:30.313 | HTTPS connection ID:25 to downloads.rithmic.com:443 for request ID:25 (5) | Closed. 2024-12-09 15:17:31.215 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (14) | CloseSocket call. 2024-12-09 15:17:31.215 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (14) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:31.215 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (12) | CloseSocket call. 2024-12-09 15:17:31.215 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (12) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:31.215 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (10) | CloseSocket call. 2024-12-09 15:17:31.215 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (10) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:31.224 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:31.224 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | New receive buffer size: 0 2024-12-09 15:17:31.224 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:31.233 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (5) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:31.233 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (5) | New receive buffer size: 0 2024-12-09 15:17:31.233 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (5) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:31.241 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (6) | Creating socket. Using TLS 1.2. 2024-12-09 15:17:31.241 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (6) | New receive buffer size: 0 2024-12-09 15:17:31.241 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (6) | Connecting to IP: 216.66.0.130. 2024-12-09 15:17:31.348 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (12) | Socket gracefully closed by remote side. 2024-12-09 15:17:31.348 | HTTPS connection ID:29 to downloads.rithmic.com:443 for request ID:29 (12) | Closed. 2024-12-09 15:17:31.348 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (14) | Socket gracefully closed by remote side. 2024-12-09 15:17:31.348 | HTTPS connection ID:31 to downloads.rithmic.com:443 for request ID:31 (14) | Closed. 2024-12-09 15:17:31.348 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (10) | Socket gracefully closed by remote side. 2024-12-09 15:17:31.348 | HTTPS connection ID:28 to downloads.rithmic.com:443 for request ID:28 (10) | Closed. 2024-12-09 15:17:31.769 | Rithmic Direct - DTC | Wrote file: D:\SierraChart CME\RithmicConnections.json. Size: 81131 2024-12-09 15:17:31.769 | Rithmic Direct - DTC | Processed connection points. Count: 347 2024-12-09 15:17:32.108 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (6) | CloseSocket call. 2024-12-09 15:17:32.108 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (5) | CloseSocket call. 2024-12-09 15:17:32.108 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | CloseSocket call. 2024-12-09 15:17:32.109 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (6) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:32.109 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (5) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:32.109 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:32.241 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (5) | Socket gracefully closed by remote side. 2024-12-09 15:17:32.241 | HTTPS connection ID:33 to downloads.rithmic.com:443 for request ID:33 (5) | Closed. 2024-12-09 15:17:32.242 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Socket gracefully closed by remote side. 2024-12-09 15:17:32.242 | HTTPS connection ID:32 to downloads.rithmic.com:443 for request ID:32 (2) | Closed. 2024-12-09 15:17:32.242 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (6) | Socket gracefully closed by remote side. 2024-12-09 15:17:32.242 | HTTPS connection ID:34 to downloads.rithmic.com:443 for request ID:34 (6) | Closed. 2024-12-09 15:17:35.498 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (8) | CloseSocket call. 2024-12-09 15:17:35.498 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (8) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:35.625 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (8) | Socket gracefully closed by remote side. 2024-12-09 15:17:35.625 | HTTPS connection ID:27 to downloads.rithmic.com:443 for request ID:27 (8) | Closed. 2024-12-09 15:17:35.847 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (13) | CloseSocket call. 2024-12-09 15:17:35.848 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (13) | Shutdown started. Waiting for graceful close. 2024-12-09 15:17:35.973 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (13) | Socket gracefully closed by remote side. 2024-12-09 15:17:35.973 | HTTPS connection ID:30 to downloads.rithmic.com:443 for request ID:30 (13) | Closed. |
[2024-12-09 18:02:55] |
Sierra_Chart Engineering - Posts: 18836 |
We want you to update Sierra Chart to the current version. Follow these instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
