Date/Time: Wed, 23 Apr 2025 03:19:18 +0000
Chart Selected Tab Color and Chart Tab Color will not change.
View Count: 299
[2024-11-24 18:43:12]
TradeHax - Posts: 9
Hello, I have referred to the Global Graphic Settings Documentation and changed the colors for Chart Selected Tab Color, Text Color, and Border Color, as well as Chart Tab Color and Chart Tab Text Color. The Chart Selected Tab Text and Tab Border colors function properly. The Chart Selected Tab Color and the Chart Tab Color will not change. They are set to the same color as Chart Tab Control Background Color but do not reflect it and are still an off white. Is there a solution to this? My other question is Where can I change the compact tool value window colors to match the control bar background as well? Thank you for your time.
https://www.sierrachart.com/image.php?Image=1732473021496.png
[2024-11-25 17:08:48]
John - SC Support - Posts: 39428
We are not seeing any issues with changing the "Chart Selected Tab Color" or the "Chart Tab Color". When we change these, the tabs update appropriately.
What are the colors you are trying to change to?
[2024-11-25 18:49:37]
TradeHax - Posts: 9
I am trying to change the Chart Tab Background color to match the darker blue surrounding it. I can change the text color fine, but the chart tab background refuses to be visibly change even though in the Global Graphic Settings it shows the bark blue as being selected.
[2024-11-25 18:51:37]
TradeHax - Posts: 9
I am also trying to make the compact Tool Value window background dark blue as well I just cannot find the setting.
[2024-11-25 20:15:49]
Attached is an image of the "Chart Tab Color" changed to pink and then selecting Apply to apply it to the non-selected tabs. Let us know if you are changing this item and the non-selected tabs are not updating after you select Apply.
The background for the Compact Tool Values Window is controlled through the "Chart Values Window Background Color". Refer to the following:
Graphics Settings: Chart Values Window Background Color
imageScreenshot 2024-11-25 141223.png / V - Attached On 2024-11-25 20:15:46 UTC - Size: 257.63 KB - 62 views
[2024-11-26 18:29:42]
TradeHax - Posts: 9
Yes, I have changed the "Chart Tab Color" to different colors and select apply but it remains the same off white color.
[2024-11-26 19:55:31]
Please get us your "Sierra4.config" file. It is located in the main Sierra Chart installation folder. Follow these instructions to get us the file:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2024-11-27 04:45:10]
TradeHax - Posts: 9
Here is the requested file.
Private File
[2024-12-07 20:06:34]
TradeHax - Posts: 9
Hi, just checking if you've had any luck locating the issue? Thanks
[2024-12-09 19:44:12]
TradeHax - Posts: 9
Hello, any chance you have looked at the Sierra4.config file?
[2024-12-09 22:17:53]
Sierra_Chart Engineering - Posts: 19307
We apologize for the delay. We will look into this today.
[2024-12-09 23:00:49]
In the configuration file you gave, all three of these colors are set to 21, 27, 53 (RGB color values). So they are all the same color. So they are all going to look the same. You need to change them:
Graphics Settings
[2024-12-10 15:47:37]
TradeHax - Posts: 9
Yes those are the RGB values I have chosen. It should be a navy blue color. It is an off white instead. I have the Chart Tab Control Background Color also set to 21, 27, 53 RGB and it displays as a Navy Blue. I can change the Chart Tab Text color to any color. I cannot change the Chart Tab Color or the Chart Selected Tab Color to any color. It stays white.
