Date/Time: Fri, 22 Nov 2024 21:25:53 +0000
Data Feed Intermittently Pausing
View Count: 157
[2024-09-24 18:11:32]
User753526 - Posts: 51
During the past week or two I've been noticing that my Data Feed will pause intraday until I force a reconnection to the server. It has just occurred again where I forced a reconnection where it has picked up and running smoothly again. I know I run on a new server routing due to my location, I am wondering if this is having any issues.
Below is my message log file.
2024-09-22 14:41:00.925 | Trade activity files set size: 2497
2024-09-22 14:41:00.956 | Created the DTC Protocol server.
2024-09-22 14:41:00.956 | DTC Protocol Server listening on port 11099.
2024-09-22 14:41:00.957 | Reading Internal Order ID file.
2024-09-22 14:41:00.992 | Reading Trade Orders file.
2024-09-22 14:41:00.993 | Reading Trade Positions file.
2024-09-22 14:41:00.993 | Reading Trade Account Data files.
2024-09-22 14:41:00.994 | NTP | Create NTP Client...
2024-09-22 14:41:00.994 | NTP | Start NTP Client Receive Thread.
2024-09-22 14:41:00.994 | NTP | Client | No privilege to gradual adjust system time. Set time will be used instead to step system time.
2024-09-22 14:41:00.994 | NTP | Client | Create NTP Client Service.
2024-09-22 14:41:00.994 | NTP | Client | Start NTP Client Service.
2024-09-22 14:41:00.994 | NTP | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment.
2024-09-22 14:41:00.994 | NTP | Unable to get permission to adjust the system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2024-09-22 14:41:00.994 | NTP | Client | Cannot adjust System Clock. Cancel NTP Client Service starting.
2024-09-22 14:41:00.994 | NTP | Stop NTP Client...
2024-09-22 14:41:00.994 | NTP | NTP Client Stopped.
2024-09-22 14:41:00.994 | NTP | Unable to get permission to restore the system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2024-09-22 14:41:00.994 | Software version: 2652 64-bit
2024-09-22 14:41:00.994 | Primary Thread ID: 35088
2024-09-22 14:41:00.994 | Usage end date: 2024-10-10
2024-09-22 14:41:00.994 | Enabled for: Advanced Features 2.
2024-09-22 14:41:00.994 | Enabled for: Sierra Chart Historical Data Service.
2024-09-22 14:41:00.994 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-09-22 14:41:00.994 | Enabled for: Delayed Denali Exchange Data Feed.
2024-09-22 14:41:00.994 | Enabled for exchange2: CME
2024-09-22 14:41:00.994 | Enabled for exchange2: COMEX
2024-09-22 14:41:00.994 | Enabled for exchange2: NYMEX
2024-09-22 14:41:00.994 | Enabled for exchange2: NASDAQ Global Indexes
2024-09-22 14:41:00.994 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-09-22 14:41:00.994 | Current selected Data/Trading service: Rithmic Direct - DTC
2024-09-22 14:41:00.994 | Custom symbol settings values: enabled
2024-09-22 14:41:00.994 | Chart Update Interval: 500
2024-09-22 14:41:00.994 | Intraday Data Storage Time Unit: 0
2024-09-22 14:41:00.994 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2024-09-22 14:41:00.994 | 2024-09-22 18:41:00 Local computer time in UTC
2024-09-22 14:41:00.994 | 2024-09-22 14:41:00 Local computer time in SC Time Zone
2024-09-22 14:41:00.994 | 2024-09-22 18:41:01 Server time in UTC
2024-09-22 14:41:00.994 | Local computer UTC time and Server UTC time difference: 2 seconds.
2024-09-22 14:41:00.994 | Program path: C:\SierraChart - TopStep\
2024-09-22 14:41:00.994 | Data Files path: C:\SierraChart - TopStep\Data\
2024-09-22 14:41:00.995 | OS Version Number: 10.0
2024-09-22 14:41:00.995 | Locale Setting: C
2024-09-22 14:41:00.995 | DLLs: ICTMarketOpens_64.dll, UserContributedStudies_64.dll
2024-09-22 14:41:00.995 | Allowed protected custom studies:
2024-09-22 14:41:00.995 | Crash reporter started: true
2024-09-22 14:41:01.006 | Created the DTC Protocol historical data server.
2024-09-22 14:41:01.006 | HD Server Manager | Listening on port 11098.
2024-09-22 14:41:01.006 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2024-09-22 14:41:01.014 | Chat: Chat Window created. Connecting to server.
2024-09-22 14:41:01.014 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-22 14:41:01.057 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:01.212 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2024-09-22 14:41:01.212 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2024-09-22 14:41:01.212 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2024-09-22 14:41:01.267 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2024-09-22 14:41:01.267 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2024-09-22 14:41:01.333 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2024-09-22 14:41:01.333 | DTC Client socket (6) | New receive buffer size: 0
2024-09-22 14:41:01.333 | DTC Client socket (6) | Connecting to IP: 69.39.70.248.
2024-09-22 14:41:01.611 | Chat | Network connection to server complete.
2024-09-22 14:41:01.611 | Chat | Starting socket receive thread.
2024-09-22 14:41:01.611 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-22 14:41:01.684 | Received 5 login tokens.
2024-09-22 14:41:02.444 | Symbol settings MD5 received. Request ID: 1.
2024-09-22 14:41:02.444 | Symbol settings are up-to-date for rithmic_v2.trading.
2024-09-22 14:41:02.444 | Chat | Setting DTC encoding to Binary VLS
2024-09-22 14:41:02.444 | Chat | Sending logon request message.
2024-09-22 14:41:02.968 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2024-09-22 14:41:02.968 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:03.199 | Chat | Received logon response.
2024-09-22 14:41:03.199 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-22 14:41:03.199 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-22 14:41:03.199 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-22 14:41:03.199 | Chat | Trading is not supported.
2024-09-22 14:41:03.199 | Chat | MarketDepthIsSupported: 1
2024-09-22 14:41:03.220 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2024-09-22 14:41:03.220 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2024-09-22 14:41:03.512 | Requested user files to download.
2024-09-22 14:41:05.520 |
2024-09-22 14:41:05.520 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-22 14:41:05.520 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-22 14:41:05.521 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-22 14:41:05.827 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-22 14:41:05.827 | DTC Client socket (1) | New receive buffer size: 0
2024-09-22 14:41:05.827 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-22 14:41:06.092 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-22 14:41:06.092 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-22 14:41:06.093 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-22 14:41:06.093 | Rithmic Direct - DTC | Sending logon request message.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Received logon response.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Server Name: .
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Successfully connected.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Trading is supported.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Connected to server complete.
2024-09-22 14:41:06.859 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-22 14:41:06.859 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-22 14:41:06.860 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-22 14:41:06.860 | Using symbol data fast lookup vector
2024-09-22 14:41:06.860 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-22 14:41:06.860 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-22 14:41:06.861 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-22 14:41:06.861 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-22 14:41:06.861 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-22 14:41:06.861 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-22 14:41:06.861 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-22 14:41:06.861 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-22 14:41:06.979 | DTC Client socket (2) | Creating socket.
2024-09-22 14:41:06.979 | DTC Client socket (2) | New receive buffer size: 0
2024-09-22 14:41:06.979 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-22 14:41:07.133 | Denali Data Feed | Network connection to server complete.
2024-09-22 14:41:07.133 | Denali Data Feed | Starting socket receive thread.
2024-09-22 14:41:07.133 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-22 14:41:07.301 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-22 14:41:07.301 | Denali Data Feed | Sending logon request message.
2024-09-22 14:41:09.489 | Denali Data Feed | Received logon response.
2024-09-22 14:41:09.489 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-22 14:41:09.489 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-22 14:41:09.489 | Denali Data Feed | Successfully connected.
2024-09-22 14:41:09.489 | Denali Data Feed | Trading is not supported.
2024-09-22 14:41:09.489 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-22 14:41:09.489 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24
2024-09-22 14:41:09.489 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-22 14:41:10.146 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-22 14:41:10.146 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-22 14:41:25.526 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2.
2024-09-22 14:41:25.526 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | New receive buffer size: 0
2024-09-22 14:41:25.526 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Connecting to IP: 216.66.0.130.
2024-09-22 14:41:26.188 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:26.191 | Starting DelayedDownloadMonitoringTimer
2024-09-22 14:41:26.191 | Starting HDTimeoutTimer
2024-09-22 14:41:26.191 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-22 14:41:26.191 | Triggering next historical data download in queue.
2024-09-22 14:41:26.192 | ESZ4.CME [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol ESZ4.CME starting at last date in file.
2024-09-22 14:41:26.192 | Starting DelayedDownloadMonitoringTimer
2024-09-22 14:41:26.192 | Starting HDTimeoutTimer
2024-09-22 14:41:26.192 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-22 14:41:26.193 | Triggering next historical data download in queue.
2024-09-22 14:41:26.212 | ESZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:26.219 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 14:41:26.307 | ESZ4.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:26.313 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:26.398 | ESZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:26.403 | ESZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 14:41:26.487 | ESZ4.CME [CBV] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:26.492 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:26.492 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.492 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.685 | ESZ4.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 2,
2024-09-22 14:41:26.691 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:26.691 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.691 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.881 | ESZ4.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 2,
2024-09-22 14:41:26.888 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:26.888 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.888 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:27.070 | ESZ4.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 2,
2024-09-22 14:41:27.088 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:27.168 | ESZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:27.188 | ESZ4.CME 5 Min #12 | Reloading chart.
2024-09-22 14:41:27.197 | ESZ4.CME [CBV] 15 Min #17 | Reloading chart.
2024-09-22 14:41:27.207 | ESZ4.CME [CBV] 15 Min #17 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:27.227 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 14:41:27.266 | ESZ4.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:27.289 | ESZ4.CME 5 Min #11 | Reloading chart.
2024-09-22 14:41:27.313 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 14:41:27.396 | ESZ4.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:27.420 | ESZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 14:41:27.558 | ESZ4.CME #9 | Reloading chart.
2024-09-22 14:41:27.558 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 14:41:27.565 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 14:41:27.571 | MESZ4.CME 30 Min #1 | Reloading chart.
2024-09-22 14:41:27.704 | MESZ4.CME #16 | Reloading chart.
2024-09-22 14:41:27.704 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 14:41:27.711 | MESZ4.CME #16 | Chart data loading complete.
2024-09-22 14:41:27.837 | MESZ4.CME #18 | Reloading chart.
2024-09-22 14:41:27.838 | MESZ4.CME #18 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 14:41:27.845 | MESZ4.CME #18 | Chart data loading complete.
2024-09-22 14:41:27.854 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-22 14:41:27.854 | HD Request # 1 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-22 14:41:27.854 | HD Request # 1 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.918003
2024-09-22 14:41:27.854 | HD Request # 1 | Using server: ds32.sierracharts.com port 10150
2024-09-22 14:41:27.855 | HD Request # 2 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 14:41:27.868 | MESZ4.CME 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 14:41:27.868 | MESZ4.CME 30 Min #1 | Chart data loading complete.
2024-09-22 14:41:27.869 | ESZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:58
2024-09-22 14:41:27.880 | ESZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-22 14:41:27.966 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 3 Service code: cme
2024-09-22 14:41:27.966 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 3
2024-09-22 14:41:27.966 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-22 14:41:27.966 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-22 14:41:27.966 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 4 Service code: cme
2024-09-22 14:41:27.966 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 4
2024-09-22 14:41:27.966 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-22 14:41:27.967 | Socket (4) | Creating socket.
2024-09-22 14:41:27.967 | Socket (4) | New receive buffer size: 0
2024-09-22 14:41:27.967 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 14:41:27.979 | ESZ4.CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-22 14:41:27.985 | ESZ4.CME 5 Min #12 | Chart data loading complete.
2024-09-22 14:41:28.062 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-22 14:41:28.062 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-22 14:41:28.062 | Triggering next historical data download in queue.
2024-09-22 14:41:28.108 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | CloseSocket call.
2024-09-22 14:41:28.108 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:28.248 | ESZ4.CME[M] Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 14:41:28.355 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side.
2024-09-22 14:41:28.355 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Closed.
2024-09-22 14:41:28.537 | HD Request # 1 | Setting DTC encoding to Binary VLS
2024-09-22 14:41:28.537 | HD Request # 1 | Sending historical data logon request message.
2024-09-22 14:41:28.619 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-22 14:41:28.619 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-22 14:41:28.619 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-22 14:41:28.619 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-22 14:41:28.923 | HD Request # 2 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 14:41:29.308 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: ESZ24
2024-09-22 14:41:29.587 | HD Request # 1 | Decompressing data.
2024-09-22 14:41:29.833 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:29.837 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-22 14:41:29.837 | Triggering next historical data download in queue.
2024-09-22 14:41:29.837 | NQZ4.CME [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol NQZ4.CME starting at last date in file.
2024-09-22 14:41:29.837 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-22 14:41:29.856 | NQZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:29.863 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-22 14:41:29.866 | HD Request # 1 | Receiving Intraday data for ESZ4.CME starting at 2024-09-20 16:59:58.001000
2024-09-22 14:41:29.866 | Socket (4) | CloseSocket call.
2024-09-22 14:41:29.866 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:29.894 | NQZ4.CME [CBV] #16 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:29.918 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:30.007 | NQZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:30.014 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-22 14:41:30.100 | NQZ4.CME [CBV] 60 Min #14 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:30.107 | NQZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:30.107 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.107 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.144 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 14:41:30.144 | Socket (4) | Closed.
2024-09-22 14:41:30.301 | NQZ4.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 5,
2024-09-22 14:41:30.308 | NQZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:30.308 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.308 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.492 | NQZ4.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 5,
2024-09-22 14:41:30.499 | NQZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:30.499 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.499 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.681 | NQZ4.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 5,
2024-09-22 14:41:30.706 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-22 14:41:30.743 | NQZ4.CME [CBV] 60 Min #11 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:30.765 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-22 14:41:30.846 | NQZ4.CME [CBV] 15 Min #1 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:30.871 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-22 14:41:30.881 | NQZ4.CME [CBV] 5 Min #15 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:31.007 | MNQZ4.CME #9 | Reloading chart.
2024-09-22 14:41:31.040 | NQZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 14:41:31.080 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:31.170 | NQZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:31.178 | NQZ4.CME 5 Min #12 | Reloading chart.
2024-09-22 14:41:31.187 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-22 14:41:31.198 | NQZ4.CME [CBV] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:31.348 | MNQZ4.CME [CBV] 1 Min #10 | Reloading chart.
2024-09-22 14:41:31.351 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-22 14:41:31.352 | MNQZ4.CME [CBV] 1 Min #10 | Performing continuous chart historical Daily data download for symbol MNQZ4.CME starting at last date in file.
2024-09-22 14:41:31.352 | Added historical Daily data request for MNQZ4.CME to the queue.
2024-09-22 14:41:31.361 | MNQZ4.CME [CBV] 1 Min #10 | Waiting for historical downloads to complete with the IDs: 6, 7,
2024-09-22 14:41:31.393 | Historical data download thread signaled to stop.
2024-09-22 14:41:31.393 | HD Request # 1 | Received 41 Intraday data records from 2024-09-20 16:59:58.001000 to 2024-09-20 16:59:58.918003 (0.9 seconds. Delay: 45.7 hours) and wrote 0 records for ESZ4.CME
2024-09-22 14:41:31.394 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:58.918003
2024-09-22 14:41:31.394 | HD Request # 1 | Completion time: 4s.
2024-09-22 14:41:31.394 | HD Request # 1 | Intraday data download complete for ESZ4.CME. Unique request ID: 1
2024-09-22 14:41:31.394 | Removing historical data download ID 1.
2024-09-22 14:41:31.394 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-22 14:41:31.394 | Intraday chart data file opened for ESZ4.CME
2024-09-22 14:41:31.394 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2024-09-22 14:41:31.394 | Triggering next historical data download in queue.
2024-09-22 14:41:31.394 | HD Request # 2 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-22 14:41:31.394 | HD Request # 2 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-22 14:41:31.397 | HD Request # 2 | Bytes received: 228
2024-09-22 14:41:31.397 | HD Request # 2 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-22 14:41:31.398 | HD Request # 2 | Completion time: 4s.
2024-09-22 14:41:31.398 | HD Request # 2 | Daily data download complete for ESZ4.CME. Unique request ID: 2
2024-09-22 14:41:31.398 | Removing historical data download ID 2.
2024-09-22 14:41:31.398 | Triggering next historical data download in queue.
2024-09-22 14:41:31.406 | MNQZ4.CME #9 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 14:41:31.407 | MNQZ4.CME #9 | Chart data loading complete.
2024-09-22 14:41:31.407 | Delaying start of download for MESZ4.CME.
2024-09-22 14:41:31.407 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-22 14:41:31.408 | HD Request # 3 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 14:41:31.441 | ESZ4.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.441 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 14:41:31.518 | NQZ4.CME Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:22
2024-09-22 14:41:31.556 | NQZ4.CME Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 14:41:31.596 | NQZ4.CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-22 14:41:31.603 | NQZ4.CME 5 Min #12 | Chart data loading complete.
2024-09-22 14:41:31.611 | ESZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.611 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:31.710 | ESZ4.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.710 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:31.872 | ESZ4.CME [CBV] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.872 | ESZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 14:41:31.956 | ESZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 14:41:31.969 | ESZ4.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.970 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:32.146 | ESZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.146 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:32.232 | ESZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 14:41:32.233 | ESZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.233 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:32.257 | ESZ4.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.258 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:32.447 | HD Request # 3 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 14:41:32.447 | ESZ4.CME [CBV] 15 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.447 | ESZ4.CME [CBV] 15 Min #17 | Reloading chart.
2024-09-22 14:41:32.463 | ESZ4.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.463 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 14:41:32.558 | ESZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 14:41:32.558 | ESZ4.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.558 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 14:41:32.609 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-22 14:41:32.609 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 6 Service code: cme
2024-09-22 14:41:32.609 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 6
2024-09-22 14:41:32.610 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 5 Service code: cme
2024-09-22 14:41:32.610 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 5
2024-09-22 14:41:32.638 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-22 14:41:32.642 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 14:41:32.856 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:33.077 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:33.077 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:33.077 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:33.544 | HD Request # 3 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-22 14:41:33.544 | HD Request # 3 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-22 14:41:33.547 | HD Request # 3 | Bytes received: 237
2024-09-22 14:41:33.547 | HD Request # 3 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for NQZ4.CME
2024-09-22 14:41:33.547 | HD Request # 3 | Completion time: 2s.
2024-09-22 14:41:33.547 | HD Request # 3 | Daily data download complete for NQZ4.CME. Unique request ID: 5
2024-09-22 14:41:33.547 | Removing historical data download ID 5.
2024-09-22 14:41:33.547 | Triggering next historical data download in queue.
2024-09-22 14:41:33.547 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-22 14:41:33.548 | HD Request # 4 | Downloading Historical Daily chart data for MNQZ4.CME. Starting date: 2024-09-17. Service: rithmic.trading
2024-09-22 14:41:33.548 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-22 14:41:33.548 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-22 14:41:33.550 | ESZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 14:41:33.772 | ESZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 14:41:33.791 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:33.791 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:33.791 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:34.283 | NQZ4.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:34.284 | NQZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:34.452 | ESZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 14:41:34.530 | NQZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 14:41:34.530 | HD Request # 4 | Requesting historical Daily data for NMZ24 starting at 2024-09-16. SC External HD service.
2024-09-22 14:41:34.566 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:34.790 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:34.849 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:34.849 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:34.849 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:35.297 | NQZ4.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:35.298 | NQZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:35.449 | ESZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 14:41:35.481 | HD Request # 4 | Receiving historical Daily data for MNQZ4.CME starting at 2024-09-17.
2024-09-22 14:41:35.481 | HD Request # 4 | Writing historical Daily data to the file MNQZ4.CME.dly.
2024-09-22 14:41:35.482 | HD Request # 4 | Bytes received: 301
2024-09-22 14:41:35.482 | HD Request # 4 | Received 5 Daily data records from 2024-09-17 00:00:00 to 2024-09-20 00:00:00 (4.0 days) and wrote 4 records for MNQZ4.CME
2024-09-22 14:41:35.483 | HD Request # 4 | Completion time: 2s.
2024-09-22 14:41:35.483 | HD Request # 4 | Daily data download complete for MNQZ4.CME. Unique request ID: 7
2024-09-22 14:41:35.483 | Removing historical data download ID 7.
2024-09-22 14:41:35.483 | No download requests in the queue to start downloads for.
2024-09-22 14:41:35.489 | ESZ4.CME [CBV] 15 Min #17 | Reloading chart.
2024-09-22 14:41:35.518 | NQZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 14:41:35.519 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 14:41:35.718 | ESZ4.CME [CBV] 15 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-21 16:15:00
2024-09-22 14:41:35.720 | ESZ4.CME [CBV] 15 Min #17 | Chart data loading complete.
2024-09-22 14:41:35.721 | NQZ4.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:35.721 | NQZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:35.884 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 14:41:35.982 | NQZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 14:41:35.984 | HD Request # 5 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-22 14:41:35.984 | HD Request # 5 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.769003
2024-09-22 14:41:35.984 | HD Request # 5 | Using server: ds32.sierracharts.com port 10149
2024-09-22 14:41:35.984 | Socket (4) | Creating socket.
2024-09-22 14:41:35.984 | Socket (4) | New receive buffer size: 0
2024-09-22 14:41:35.984 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 14:41:35.993 | NQZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:35.993 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:35.993 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:36.387 | NQZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:36.387 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:36.387 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:36.533 | HD Request # 5 | Setting DTC encoding to Binary VLS
2024-09-22 14:41:36.533 | HD Request # 5 | Sending historical data logon request message.
2024-09-22 14:41:36.775 | NQZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 14:41:36.840 | NQZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 14:41:36.842 | NQZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:36.842 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:36.842 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:37.281 | NQZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 14:41:37.293 | HD Request # 5 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: MESZ24
2024-09-22 14:41:37.564 | HD Request # 5 | Decompressing data.
2024-09-22 14:41:37.833 | HD Request # 5 | Receiving Intraday data for MESZ4.CME starting at 2024-09-20 16:59:58.000000
2024-09-22 14:41:37.833 | Socket (4) | CloseSocket call.
2024-09-22 14:41:37.833 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:37.833 | Historical data download thread signaled to stop.
2024-09-22 14:41:37.833 | HD Request # 5 | Received 14 Intraday data records from 2024-09-20 16:59:58.000000 to 2024-09-20 16:59:58.769003 (0.8 seconds. Delay: 45.7 hours) and wrote 0 records for MESZ4.CME
2024-09-22 14:41:37.833 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:58.769003
2024-09-22 14:41:37.833 | HD Request # 5 | Completion time: 2s.
2024-09-22 14:41:37.833 | HD Request # 5 | Intraday data download complete for MESZ4.CME. Unique request ID: 3
2024-09-22 14:41:37.833 | Removing historical data download ID 3.
2024-09-22 14:41:37.833 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-22 14:41:37.833 | Intraday chart data file opened for MESZ4.CME
2024-09-22 14:41:37.833 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2024-09-22 14:41:37.833 | Triggering next historical data download in queue.
2024-09-22 14:41:37.833 | Delaying start of download for NQZ4.CME.
2024-09-22 14:41:38.103 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 14:41:38.103 | Socket (4) | Closed.
2024-09-22 14:41:38.197 | HD Request # 6 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-22 14:41:38.198 | HD Request # 6 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.313003
2024-09-22 14:41:38.198 | HD Request # 6 | Using server: ds32.sierracharts.com port 10150
2024-09-22 14:41:38.198 | Socket (3) | Creating socket.
2024-09-22 14:41:38.198 | Socket (3) | New receive buffer size: 0
2024-09-22 14:41:38.198 | Socket (3) | Connecting to IP: 67.214.125.3.
2024-09-22 14:41:38.752 | HD Request # 6 | Setting DTC encoding to Binary VLS
2024-09-22 14:41:38.752 | HD Request # 6 | Sending historical data logon request message.
2024-09-22 14:41:39.024 | HD Request # 6 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: NQZ24
2024-09-22 14:41:39.298 | HD Request # 6 | Decompressing data.
2024-09-22 14:41:39.613 | HD Request # 6 | Receiving Intraday data for NQZ4.CME starting at 2024-09-20 16:59:59.313000
2024-09-22 14:41:39.613 | Socket (3) | CloseSocket call.
2024-09-22 14:41:39.613 | Socket (3) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:39.613 | Historical data download thread signaled to stop.
2024-09-22 14:41:39.613 | HD Request # 6 | Received 4 Intraday data records from 2024-09-20 16:59:59.313000 to 2024-09-20 16:59:59.313003 (0.0 seconds. Delay: 45.7 hours) and wrote 0 records for NQZ4.CME
2024-09-22 14:41:39.613 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:59.313003
2024-09-22 14:41:39.613 | HD Request # 6 | Completion time: 1s.
2024-09-22 14:41:39.613 | HD Request # 6 | Intraday data download complete for NQZ4.CME. Unique request ID: 4
2024-09-22 14:41:39.613 | Removing historical data download ID 4.
2024-09-22 14:41:39.613 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-22 14:41:39.613 | Intraday chart data file opened for NQZ4.CME
2024-09-22 14:41:39.613 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2024-09-22 14:41:39.613 | Triggering next historical data download in queue.
2024-09-22 14:41:39.613 | HD Request # 7 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-22 14:41:39.613 | HD Request # 7 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.605000
2024-09-22 14:41:39.613 | HD Request # 7 | Using server: ds32.sierracharts.com port 10149
2024-09-22 14:41:39.613 | Socket (4) | Creating socket.
2024-09-22 14:41:39.613 | Socket (4) | New receive buffer size: 0
2024-09-22 14:41:39.613 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 14:41:39.709 | NQZ4.CME [CBV] 60 Min #11 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.710 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-22 14:41:39.745 | NQZ4.CME [CBV] 1 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.745 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-22 14:41:39.789 | NQZ4.CME [CBV] 15 Min #1 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.790 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-22 14:41:39.876 | NQZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.877 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:39.885 | Socket (3) | Socket gracefully closed by remote side.
2024-09-22 14:41:39.885 | Socket (3) | Closed.
2024-09-22 14:41:39.898 | NQZ4.CME [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.898 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-22 14:41:39.925 | NQZ4.CME [CBV] 5 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.925 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-22 14:41:39.941 | NQZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.942 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:40.033 | NQZ4.CME [CBV] 60 Min #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:40.033 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-22 14:41:40.144 | NQZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:40.145 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:40.168 | HD Request # 7 | Setting DTC encoding to Binary VLS
2024-09-22 14:41:40.168 | HD Request # 7 | Sending historical data logon request message.
2024-09-22 14:41:40.248 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-22 14:41:40.396 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-22 14:41:40.430 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-22 14:41:40.441 | HD Request # 7 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: MNQZ24
2024-09-22 14:41:40.712 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:40.715 | HD Request # 7 | Decompressing data.
2024-09-22 14:41:40.786 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-22 14:41:40.893 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-22 14:41:40.934 | NQZ4.CME [CBV] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 14:41:40.963 | NQZ4.CME [CBV] 5 Min #15 | Chart data loading complete.
2024-09-22 14:41:40.987 | HD Request # 7 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-20 16:59:59.155000
2024-09-22 14:41:40.987 | Socket (4) | CloseSocket call.
2024-09-22 14:41:40.987 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:40.990 | Historical data download thread signaled to stop.
2024-09-22 14:41:40.990 | HD Request # 7 | Received 2 Intraday data records from 2024-09-20 16:59:59.155000 to 2024-09-20 16:59:59.605000 (0.5 seconds. Delay: 45.7 hours) and wrote 0 records for MNQZ4.CME
2024-09-22 14:41:40.990 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:59.605000
2024-09-22 14:41:40.990 | HD Request # 7 | Completion time: 1s.
2024-09-22 14:41:40.990 | HD Request # 7 | Intraday data download complete for MNQZ4.CME. Unique request ID: 6
2024-09-22 14:41:40.990 | Removing historical data download ID 6.
2024-09-22 14:41:40.990 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-22 14:41:40.990 | Intraday chart data file opened for MNQZ4.CME
2024-09-22 14:41:40.990 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2024-09-22 14:41:40.990 | No download requests in the queue to start downloads for.
2024-09-22 14:41:40.990 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:41.246 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-22 14:41:41.259 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 14:41:41.260 | Socket (4) | Closed.
2024-09-22 14:41:41.511 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:41.802 | MNQZ4.CME [CBV] 1 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:41.803 | MNQZ4.CME [CBV] 1 Min #10 | Reloading chart. | Number times message added: 1
2024-09-22 14:41:42.621 | NQZ4.CME [CBV][M] 1 Min #8 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 14:41:42.649 | NQZ4.CME [CBV][M] 1 Min #8 | Chart data loading complete.
2024-09-22 14:41:43.152 | MNQZ4.CME [CBV][M] 1 Min #10 | StartDateTimeForLoadingOrderFills: 2024-09-06 17:38:18
2024-09-22 14:41:43.157 | MNQZ4.CME [CBV][M] 1 Min #10 | Chart data loading complete.
2024-09-22 14:41:49.057 | ESZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-22 14:41:52.108 | NQZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-22 14:41:56.349 | NQZ4.CME [CBV][M] #16 | Chart data loading complete.
2024-09-22 14:42:07.714 | NQZ4.CME [CBV][M] 60 Min #11 | StartDateTimeForLoadingOrderFills: 2023-11-26 18:00:00
2024-09-22 14:42:07.886 | NQZ4.CME [CBV][M] 60 Min #11 | Chart data loading complete.
2024-09-22 14:42:12.315 | ESZ4.CME [CBV][M] 60 Min #8 | Chart data loading complete.
2024-09-22 14:42:13.588 | NQZ4.CME [CBV][M] 60 Min #14 | Chart data loading complete.
2024-09-22 14:42:25.470 | ESZ4.CME [CBV][M] 240 Min #15 | Chart data loading complete.
2024-09-22 14:42:38.999 | NQZ4.CME [CBV][M] 15 Min #1 | Chart data loading complete.
2024-09-22 14:42:41.784 | NQZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 14:42:44.641 | NQZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-22 14:42:55.486 | ESZ4.CME [CBV][M] #14 | Chart data loading complete.
2024-09-22 14:43:05.914 | ESZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 14:43:07.698 | ESZ4.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-13 18:00:00
2024-09-22 14:43:07.801 | ESZ4.CME [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-22 14:43:09.426 | ESZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-22 15:37:59.747 | Saved Chartbook: ES.Cht. Time: 0.0613 seconds.
2024-09-22 15:38:04.148 | Unsubscribed from market depth data for ESZ4.CME
2024-09-22 15:38:04.148 | Unsubscribed from market depth data for MESZ4.CME
2024-09-22 15:38:04.764 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 15:38:04.813 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 15:38:05.000 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 15:38:05.167 | ESZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 15:38:05.340 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 15:38:05.340 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:05.340 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:05.693 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 15:38:05.693 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:05.693 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:06.045 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 15:38:06.045 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:06.045 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:06.404 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 15:38:06.602 | ESZ4.CME 5 Min #12 | Reloading chart.
2024-09-22 15:38:06.613 | ESZ4.CME [CBV] 15 Min #17 | Reloading chart.
2024-09-22 15:38:06.665 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 15:38:06.786 | ESZ4.CME 5 Min #11 | Reloading chart.
2024-09-22 15:38:06.821 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 15:38:07.044 | ESZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 15:38:07.231 | ESZ4.CME #9 | Reloading chart.
2024-09-22 15:38:07.231 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 15:38:07.241 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 15:38:07.250 | MESZ4.CME 30 Min #1 | Reloading chart.
2024-09-22 15:38:07.441 | MESZ4.CME #16 | Reloading chart.
2024-09-22 15:38:07.441 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 15:38:07.452 | MESZ4.CME #16 | Chart data loading complete.
2024-09-22 15:38:07.637 | MESZ4.CME #18 | Reloading chart.
2024-09-22 15:38:07.637 | MESZ4.CME #18 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 15:38:07.648 | MESZ4.CME #18 | Chart data loading complete.
2024-09-22 15:38:07.663 | ESZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 15:38:07.665 | ESZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 15:38:07.669 | ESZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 15:38:07.682 | MESZ4.CME 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 15:38:07.682 | MESZ4.CME 30 Min #1 | Chart data loading complete.
2024-09-22 15:38:07.683 | ESZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:58
2024-09-22 15:38:07.696 | ESZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-22 15:38:07.732 | ESZ4.CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-22 15:38:07.742 | ESZ4.CME 5 Min #12 | Chart data loading complete.
2024-09-22 15:38:08.242 | ESZ4.CME[M] Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 15:38:09.136 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-22 15:38:09.136 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-22 15:38:09.631 | ESZ4.CME [CBV][M] 15 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-21 16:15:00
2024-09-22 15:38:09.632 | ESZ4.CME [CBV][M] 15 Min #17 | Chart data loading complete.
2024-09-22 15:38:09.802 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-22 15:38:09.802 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-22 15:38:16.986 | ESZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-22 15:38:36.832 | ESZ4.CME [CBV][M] 60 Min #8 | Chart data loading complete.
2024-09-22 15:38:46.011 | ESZ4.CME [CBV][M] 240 Min #15 | Chart data loading complete.
2024-09-22 15:39:14.592 | ESZ4.CME [CBV][M] #14 | Chart data loading complete.
2024-09-22 15:39:26.380 | ESZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 15:39:27.851 | ESZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-22 15:39:28.839 | ESZ4.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-13 18:00:00
2024-09-22 15:39:28.926 | ESZ4.CME [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-22 17:00:10.117 | DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-22 17:00:10.117 | DTC Client socket (6) | Socket gracefully closed by remote side.
2024-09-22 17:00:10.117 | DTC Client socket (6) | CloseSocket call.
2024-09-22 17:00:10.117 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-22 17:00:10.118 | DTC Client socket (6) | Closed.
2024-09-22 17:00:10.119 | Chat | Waiting for socket receive thread to end
2024-09-22 17:00:10.119 | DTC Client socket (0) | CloseSocket call.
2024-09-22 17:00:10.119 | Chat | Disconnected from the server.
2024-09-22 17:00:10.119 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2024-09-22 17:00:15.108 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-22 17:00:15.235 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2024-09-22 17:00:15.235 | DTC Client socket (3) | New receive buffer size: 0
2024-09-22 17:00:15.235 | DTC Client socket (3) | Connecting to IP: 69.39.70.248.
2024-09-22 17:00:15.509 | Chat | Network connection to server complete.
2024-09-22 17:00:15.509 | Chat | Starting socket receive thread.
2024-09-22 17:00:15.509 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-22 17:00:16.331 | Chat | Setting DTC encoding to Binary VLS
2024-09-22 17:00:16.331 | Chat | Sending logon request message.
2024-09-22 17:00:21.544 | Chat | Received logon response.
2024-09-22 17:00:21.544 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-22 17:00:21.544 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-22 17:00:21.544 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-22 17:00:21.544 | Chat | Trading is not supported.
2024-09-22 17:00:21.544 | Chat | MarketDepthIsSupported: 1
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol ESZ4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol NQZ4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol MNQZ4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol MESZ4.CME is currently unavailable.
2024-09-22 17:36:46.695 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-22 17:36:46.729 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-22 17:36:46.729 | Denali Data Feed | Real-time data for symbol ESZ4.CME has been restored.
2024-09-22 17:36:46.729 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-22 17:36:46.729 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-22 17:36:46.729 | Triggering next historical data download in queue.
2024-09-22 17:36:46.729 | HD Request # 8 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-22 17:36:46.729 | HD Request # 8 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.918003
2024-09-22 17:36:46.729 | HD Request # 8 | Using server: ds32.sierracharts.com port 10150
2024-09-22 17:36:46.845 | Socket (4) | Creating socket.
2024-09-22 17:36:46.845 | Socket (4) | New receive buffer size: 0
2024-09-22 17:36:46.845 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 17:36:47.397 | HD Request # 8 | Setting DTC encoding to Binary VLS
2024-09-22 17:36:47.397 | HD Request # 8 | Sending historical data logon request message.
2024-09-22 17:36:58.066 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-22 17:36:58.066 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-22 17:36:58.067 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-22 17:36:58.067 | Denali Data Feed | Real-time data for symbol NQZ4.CME has been restored.
2024-09-22 17:36:58.067 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-22 17:36:58.067 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-22 17:36:58.067 | Triggering next historical data download in queue.
2024-09-22 17:36:58.067 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-22 17:36:58.067 | Denali Data Feed | Real-time data for symbol MNQZ4.CME has been restored.
2024-09-22 17:36:58.067 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-22 17:36:58.067 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-22 17:36:58.067 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-22 17:36:58.067 | Denali Data Feed | Real-time data for symbol MESZ4.CME has been restored.
2024-09-22 17:36:58.067 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-22 17:36:58.067 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-22 17:36:58.597 | HD Request # 8 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: ESZ24
2024-09-22 17:36:58.866 | HD Request # 8 | Decompressing data.
2024-09-22 17:36:59.134 | HD Request # 8 | Receiving Intraday data for ESZ4.CME starting at 2024-09-20 16:59:58.001000
2024-09-22 17:36:59.134 | Socket (4) | CloseSocket call.
2024-09-22 17:36:59.134 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 17:36:59.134 | Historical data download thread signaled to stop.
2024-09-22 17:36:59.134 | HD Request # 8 | Received 41 Intraday data records from 2024-09-20 16:59:58.001000 to 2024-09-20 16:59:58.918003 (0.9 seconds. Delay: 2.0 days) and wrote 0 records for ESZ4.CME
2024-09-22 17:36:59.135 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:58.918003
2024-09-22 17:36:59.135 | HD Request # 8 | Completion time: 13s.
2024-09-22 17:36:59.135 | HD Request # 8 | Intraday data download complete for ESZ4.CME. Unique request ID: 8
2024-09-22 17:36:59.135 | Removing historical data download ID 8.
2024-09-22 17:36:59.135 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-22 17:36:59.135 | Intraday chart data file opened for ESZ4.CME
2024-09-22 17:36:59.135 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2024-09-22 17:36:59.135 | Triggering next historical data download in queue.
2024-09-22 17:36:59.135 | HD Request # 9 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-22 17:36:59.135 | HD Request # 9 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.313003
2024-09-22 17:36:59.135 | HD Request # 9 | Using server: ds32.sierracharts.com port 10149
2024-09-22 17:36:59.135 | Socket (5) | Creating socket.
2024-09-22 17:36:59.135 | Socket (5) | New receive buffer size: 0
2024-09-22 17:36:59.135 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 17:36:59.403 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 17:36:59.403 | Socket (4) | Closed.
2024-09-22 17:36:59.693 | HD Request # 9 | Setting DTC encoding to Binary VLS
2024-09-22 17:36:59.693 | HD Request # 9 | Sending historical data logon request message.
2024-09-22 17:37:11.607 | HD Request # 9 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: NQZ24
2024-09-22 17:37:11.882 | HD Request # 9 | Decompressing data.
2024-09-22 17:37:12.157 | HD Request # 9 | Receiving Intraday data for NQZ4.CME starting at 2024-09-20 16:59:59.313000
2024-09-22 17:37:12.157 | Socket (5) | CloseSocket call.
2024-09-22 17:37:12.157 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 17:37:12.157 | Historical data download thread signaled to stop.
2024-09-22 17:37:12.157 | HD Request # 9 | Received 4 Intraday data records from 2024-09-20 16:59:59.313000 to 2024-09-20 16:59:59.313003 (0.0 seconds. Delay: 2.0 days) and wrote 0 records for NQZ4.CME
2024-09-22 17:37:12.157 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:59.313003
2024-09-22 17:37:12.157 | HD Request # 9 | Completion time: 13s.
2024-09-22 17:37:12.157 | HD Request # 9 | Intraday data download complete for NQZ4.CME. Unique request ID: 9
2024-09-22 17:37:12.157 | Removing historical data download ID 9.
2024-09-22 17:37:12.157 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-22 17:37:12.157 | Intraday chart data file opened for NQZ4.CME
2024-09-22 17:37:12.157 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2024-09-22 17:37:12.157 | Triggering next historical data download in queue.
2024-09-22 17:37:12.157 | HD Request # 10 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-22 17:37:12.157 | HD Request # 10 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.605000
2024-09-22 17:37:12.157 | HD Request # 10 | Using server: ds32.sierracharts.com port 10150
2024-09-22 17:37:12.157 | Socket (4) | Creating socket.
2024-09-22 17:37:12.157 | Socket (4) | New receive buffer size: 0
2024-09-22 17:37:12.157 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 17:37:12.431 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 17:37:12.431 | Socket (5) | Closed.
2024-09-22 17:37:12.719 | HD Request # 10 | Setting DTC encoding to Binary VLS
2024-09-22 17:37:12.719 | HD Request # 10 | Sending historical data logon request message.
2024-09-22 17:37:24.605 | HD Request # 10 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: MNQZ24
2024-09-22 17:37:24.879 | HD Request # 10 | Decompressing data.
2024-09-22 17:37:25.151 | HD Request # 10 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-20 16:59:59.155000
2024-09-22 17:37:25.151 | Socket (4) | CloseSocket call.
2024-09-22 17:37:25.151 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 17:37:25.151 | Historical data download thread signaled to stop.
2024-09-22 17:37:25.151 | HD Request # 10 | Received 2 Intraday data records from 2024-09-20 16:59:59.155000 to 2024-09-20 16:59:59.605000 (0.5 seconds. Delay: 2.0 days) and wrote 0 records for MNQZ4.CME
2024-09-22 17:37:25.152 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:59.605000
2024-09-22 17:37:25.152 | HD Request # 10 | Completion time: 13s.
2024-09-22 17:37:25.152 | HD Request # 10 | Intraday data download complete for MNQZ4.CME. Unique request ID: 10
2024-09-22 17:37:25.152 | Removing historical data download ID 10.
2024-09-22 17:37:25.152 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-22 17:37:25.152 | Intraday chart data file opened for MNQZ4.CME
2024-09-22 17:37:25.152 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2024-09-22 17:37:25.152 | Triggering next historical data download in queue.
2024-09-22 17:37:25.152 | HD Request # 11 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-22 17:37:25.152 | HD Request # 11 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.769003
2024-09-22 17:37:25.152 | HD Request # 11 | Using server: ds32.sierracharts.com port 10149
2024-09-22 17:37:25.152 | Socket (5) | Creating socket.
2024-09-22 17:37:25.152 | Socket (5) | New receive buffer size: 0
2024-09-22 17:37:25.152 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 17:37:25.424 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 17:37:25.424 | Socket (4) | Closed.
2024-09-22 17:37:25.711 | HD Request # 11 | Setting DTC encoding to Binary VLS
2024-09-22 17:37:25.711 | HD Request # 11 | Sending historical data logon request message.
2024-09-22 17:37:37.611 | HD Request # 11 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: MESZ24
2024-09-22 17:37:37.888 | HD Request # 11 | Decompressing data.
2024-09-22 17:37:38.161 | HD Request # 11 | Receiving Intraday data for MESZ4.CME starting at 2024-09-20 16:59:58.000000
2024-09-22 17:37:38.161 | Socket (5) | CloseSocket call.
2024-09-22 17:37:38.161 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 17:37:38.161 | Historical data download thread signaled to stop.
2024-09-22 17:37:38.161 | HD Request # 11 | Received 14 Intraday data records from 2024-09-20 16:59:58.000000 to 2024-09-20 16:59:58.769003 (0.8 seconds. Delay: 2.0 days) and wrote 0 records for MESZ4.CME
2024-09-22 17:37:38.162 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:58.769003
2024-09-22 17:37:38.162 | HD Request # 11 | Completion time: 13s.
2024-09-22 17:37:38.162 | HD Request # 11 | Intraday data download complete for MESZ4.CME. Unique request ID: 11
2024-09-22 17:37:38.162 | Removing historical data download ID 11.
2024-09-22 17:37:38.162 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-22 17:37:38.162 | Intraday chart data file opened for MESZ4.CME
2024-09-22 17:37:38.162 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2024-09-22 17:37:38.162 | No download requests in the queue to start downloads for.
2024-09-22 17:37:38.437 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 17:37:38.437 | Socket (5) | Closed.
2024-09-22 17:45:00.086 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-22 17:45:00.086 | Triggering next historical data download in queue.
2024-09-22 17:45:00.087 | HD Request # 12 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 17:45:00.088 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-22 17:45:00.088 | Triggering next historical data download in queue.
2024-09-22 17:45:01.054 | HD Request # 12 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 17:45:01.992 | HD Request # 12 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-22 17:45:01.993 | HD Request # 12 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-22 17:45:01.996 | HD Request # 12 | Bytes received: 234
2024-09-22 17:45:01.996 | HD Request # 12 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-22 17:45:01.996 | HD Request # 12 | Completion time: 1s.
2024-09-22 17:45:01.996 | HD Request # 12 | Daily data download complete for ESZ4.CME. Unique request ID: 12
2024-09-22 17:45:01.996 | Removing historical data download ID 12.
2024-09-22 17:45:01.996 | Triggering next historical data download in queue.
2024-09-22 17:45:01.997 | HD Request # 13 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 17:45:02.133 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 17:45:02.133 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.133 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.529 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 17:45:02.554 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 17:45:02.554 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.554 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.942 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 17:45:02.943 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 17:45:02.943 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.943 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:03.266 | HD Request # 13 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 17:45:03.331 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 17:45:04.038 | HD Request # 13 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-22 17:45:04.038 | HD Request # 13 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-22 17:45:04.040 | HD Request # 13 | Bytes received: 242
2024-09-22 17:45:04.040 | HD Request # 13 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for NQZ4.CME
2024-09-22 17:45:04.040 | HD Request # 13 | Completion time: 3s.
2024-09-22 17:45:04.040 | HD Request # 13 | Daily data download complete for NQZ4.CME. Unique request ID: 13
2024-09-22 17:45:04.040 | Removing historical data download ID 13.
2024-09-22 17:45:04.040 | No download requests in the queue to start downloads for.
2024-09-22 17:45:04.157 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 17:45:04.157 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.157 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.467 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 17:45:04.467 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.467 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.767 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 17:45:04.836 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 17:45:04.838 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 17:45:04.838 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.838 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:05.177 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 18:00:02.149 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-22 18:00:02.150 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 3296
2024-09-22 18:00:02.150 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-22 18:00:02.150 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-22 19:41:03.090 | 6AZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:03.094 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-22 19:41:03.094 | Triggering next historical data download in queue.
2024-09-22 19:41:03.095 | 6AZ4.CME [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol 6AZ4.CME starting at last date in file.
2024-09-22 19:41:03.095 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-22 19:41:03.095 | Triggering next historical data download in queue.
2024-09-22 19:41:03.111 | 6AZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:03.120 | 6AZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:03.205 | 6AZ4.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:03.214 | 6AZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:03.287 | 6AZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:03.296 | 6AZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:03.369 | 6AZ4.CME [CBV] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:03.379 | 6AZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:03.379 | 6AZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.379 | 6AZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.554 | 6AZ4.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 15,
2024-09-22 19:41:03.563 | 6AZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:03.563 | 6AZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.563 | 6AZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.725 | 6AZ4.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 15,
2024-09-22 19:41:03.734 | 6AZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:03.734 | 6AZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.734 | 6AZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.890 | 6AZ4.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 15,
2024-09-22 19:41:03.925 | 6AZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:03.994 | 6AZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:04.027 | 6AZ4.CME 15 Min #12 | Reloading chart.
2024-09-22 19:41:04.057 | 6AZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:04.091 | 6AZ4.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:04.118 | 6AZ4.CME 5 Min #11 | Reloading chart.
2024-09-22 19:41:04.149 | 6AZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:04.219 | 6AZ4.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:04.229 | 6AZ4.CME [CBV] 2 Min #17 | Reloading chart.
2024-09-22 19:41:04.238 | 6AZ4.CME [CBV] 2 Min #17 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:04.266 | 6AZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 19:41:04.409 | ESZ4.CME #9 | Reloading chart.
2024-09-22 19:41:04.409 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:04.409 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 19:41:04.418 | M6AZ4.CME 15 Min #1 | Reloading chart.
2024-09-22 19:41:04.563 | MESZ4.CME #16 | Reloading chart.
2024-09-22 19:41:04.563 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:04.563 | MESZ4.CME #16 | Chart data loading complete.
2024-09-22 19:41:04.706 | 6AZ4.CME #18 | Reloading chart.
2024-09-22 19:41:04.707 | 6AZ4.CME #18 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:04.707 | 6AZ4.CME #18 | Chart data loading complete.
2024-09-22 19:41:04.715 | Mapping 6AZ4.CME to 6AZ24. Service code: cme
2024-09-22 19:41:04.715 | HD Request # 14 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-22 19:41:04.715 | HD Request # 14 | Download start date-time: 2024-09-20 16:58:13.000000. File last date-time: 2024-09-20 16:58:13.494000
2024-09-22 19:41:04.715 | HD Request # 14 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:41:04.716 | HD Request # 15 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 19:41:04.724 | 6AZ4.CME 15 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-28 20:00:00
2024-09-22 19:41:04.726 | 6AZ4.CME 15 Min #12 | Chart data loading complete.
2024-09-22 19:41:04.728 | 6AZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:58:13
2024-09-22 19:41:04.739 | 6AZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-22 19:41:04.742 | 6AZ4.CME Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-28 20:06:36
2024-09-22 19:41:04.752 | 6AZ4.CME Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 19:41:04.774 | M6AZ4.CME 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:30:00
2024-09-22 19:41:04.774 | M6AZ4.CME 15 Min #1 | Chart data loading complete.
2024-09-22 19:41:04.840 | Socket (4) | Creating socket.
2024-09-22 19:41:04.840 | Socket (4) | New receive buffer size: 0
2024-09-22 19:41:04.840 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:05.311 | Denali Data Feed | Starting real-time market data updates for: 6AZ4.CME (6AZ24). ID: 7 Service code: cme
2024-09-22 19:41:05.311 | Denali Data Feed | Requesting security definition data for: 6AZ4.CME (6AZ24). ID: 7
2024-09-22 19:41:05.327 | Mapping M6AZ4.CME to M6AZ24. Service code: cme
2024-09-22 19:41:05.327 | Denali Data Feed | Starting real-time market data updates for: M6AZ4.CME (M6AZ24). ID: 8 Service code: cme
2024-09-22 19:41:05.327 | Denali Data Feed | Requesting security definition data for: M6AZ4.CME (M6AZ24). ID: 8
2024-09-22 19:41:05.327 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-22 19:41:05.327 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-22 19:41:05.327 | Triggering next historical data download in queue.
2024-09-22 19:41:05.396 | HD Request # 14 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:05.396 | HD Request # 14 | Sending historical data logon request message.
2024-09-22 19:41:05.922 | HD Request # 15 | Requesting historical Daily data for A6Z24 starting at 2024-09-17. SC External HD service.
2024-09-22 19:41:05.949 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-22 19:41:05.949 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-22 19:41:06.082 | Requesting market depth updates for: 6AZ4.CME if supported. NumLevels=50
2024-09-22 19:41:06.169 | HD Request # 14 | Requesting Intraday data. Start date-time: 2024-09-20 16:58:13. Record interval: 0. Symbol: 6AZ24
2024-09-22 19:41:06.203 | 6JZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:06.208 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-22 19:41:06.208 | Triggering next historical data download in queue.
2024-09-22 19:41:06.209 | 6JZ4.CME [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol 6JZ4.CME starting at last date in file.
2024-09-22 19:41:06.209 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-22 19:41:06.209 | Triggering next historical data download in queue.
2024-09-22 19:41:06.225 | 6JZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:06.235 | 6JZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:06.314 | 6JZ4.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:06.325 | 6JZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:06.395 | 6JZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:06.404 | 6JZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:06.443 | HD Request # 14 | Decompressing data.
2024-09-22 19:41:06.478 | 6JZ4.CME [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:06.489 | 6JZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:06.489 | 6JZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.489 | 6JZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.659 | 6JZ4.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 18,
2024-09-22 19:41:06.669 | 6JZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:06.669 | 6JZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.669 | 6JZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.719 | HD Request # 14 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-20 16:58:13.494000
2024-09-22 19:41:06.719 | Socket (4) | CloseSocket call.
2024-09-22 19:41:06.719 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:06.825 | 6JZ4.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 18,
2024-09-22 19:41:06.864 | 6JZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:06.864 | 6JZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.864 | 6JZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.950 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-22 19:41:06.991 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 19:41:06.992 | Socket (4) | Closed.
2024-09-22 19:41:07.021 | 6JZ4.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 18,
2024-09-22 19:41:07.031 | 6JZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:07.101 | 6JZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:07.136 | 6JZ4.CME 5 Min #12 | Reloading chart.
2024-09-22 19:41:07.167 | 6JZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:07.205 | 6JZ4.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:07.234 | 6JZ4.CME 5 Min #11 | Reloading chart.
2024-09-22 19:41:07.268 | 6JZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:07.339 | 6JZ4.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:07.351 | 6JZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-22 19:41:07.360 | 6JZ4.CME [CBV] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:07.389 | 6JZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 19:41:07.555 | ESZ4.CME #9 | Reloading chart.
2024-09-22 19:41:07.555 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:07.555 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 19:41:07.578 | MJYZ4.CME 15 Min #1 | Reloading chart.
2024-09-22 19:41:07.590 | USDX 60 Min #16 | Reloading chart.
2024-09-22 19:41:07.610 | Historical data download thread signaled to stop.
2024-09-22 19:41:07.610 | HD Request # 14 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.000000.
2024-09-22 19:41:07.610 | HD Request # 14 | Received 861 Intraday data records from 2024-09-20 16:58:13.494000 to 2024-09-22 19:40:46.245000 (2.1 days. Delay: 21.4 seconds) and wrote 860 records for 6AZ4.CME
2024-09-22 19:41:07.610 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:40:46.245000
2024-09-22 19:41:07.610 | HD Request # 14 | Completion time: 3s.
2024-09-22 19:41:07.610 | HD Request # 14 | Intraday data download complete for 6AZ4.CME. Unique request ID: 14
2024-09-22 19:41:07.610 | Removing historical data download ID 14.
2024-09-22 19:41:07.610 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-22 19:41:07.610 | Intraday chart data file opened for 6AZ4.CME
2024-09-22 19:41:07.610 | HD Request # 14 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:07.611 | Triggering next historical data download in queue.
2024-09-22 19:41:07.617 | 6JZ4.CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-28 20:00:00
2024-09-22 19:41:07.622 | 6JZ4.CME 5 Min #12 | Chart data loading complete.
2024-09-22 19:41:07.623 | 6JZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:57
2024-09-22 19:41:07.631 | 6JZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-22 19:41:07.637 | 6JZ4.CME Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-28 20:04:22
2024-09-22 19:41:07.647 | 6JZ4.CME Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 19:41:07.673 | MJYZ4.CME 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 23:30:00
2024-09-22 19:41:07.673 | MJYZ4.CME 15 Min #1 | Chart data loading complete.
2024-09-22 19:41:07.674 | Delaying start of download for M6AZ4.CME.
2024-09-22 19:41:07.761 | USDX 60 Min #16 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 19:41:07.761 | USDX 60 Min #16 | Chart data loading complete.
2024-09-22 19:41:08.251 | Mapping 6JZ4.CME to 6JZ24. Service code: cme
2024-09-22 19:41:08.251 | Denali Data Feed | Starting real-time market data updates for: 6JZ4.CME (6JZ24). ID: 9 Service code: cme
2024-09-22 19:41:08.251 | Denali Data Feed | Requesting security definition data for: 6JZ4.CME (6JZ24). ID: 9
2024-09-22 19:41:08.265 | Mapping MJYZ4.CME to MJYZ24. Service code: cme
2024-09-22 19:41:08.265 | Denali Data Feed | Starting real-time market data updates for: MJYZ4.CME (MJYZ24). ID: 10 Service code: cme
2024-09-22 19:41:08.265 | Denali Data Feed | Requesting security definition data for: MJYZ4.CME (MJYZ24). ID: 10
2024-09-22 19:41:08.265 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-22 19:41:08.265 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-22 19:41:08.265 | Triggering next historical data download in queue.
2024-09-22 19:41:08.266 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 11 Service code: fxstatscalc
2024-09-22 19:41:08.268 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2024-09-22 19:41:08.270 | SC Data with Depth | Requesting security definition data for: USDX. ID: 11
2024-09-22 19:41:08.270 | Added historical Intraday data request for USDX to the queue.
2024-09-22 19:41:08.270 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2024-09-22 19:41:08.270 | Triggering next historical data download in queue.
2024-09-22 19:41:08.303 | HD Request # 15 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-18.
2024-09-22 19:41:08.303 | HD Request # 15 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-22 19:41:08.308 | HD Request # 15 | Bytes received: 237
2024-09-22 19:41:08.308 | HD Request # 15 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6AZ4.CME
2024-09-22 19:41:08.308 | HD Request # 15 | Completion time: 4s.
2024-09-22 19:41:08.308 | HD Request # 15 | Daily data download complete for 6AZ4.CME. Unique request ID: 15
2024-09-22 19:41:08.308 | Removing historical data download ID 15.
2024-09-22 19:41:08.308 | Triggering next historical data download in queue.
2024-09-22 19:41:08.309 | HD Request # 16 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 19:41:08.387 | DTC Client socket (4) | Creating socket.
2024-09-22 19:41:08.387 | DTC Client socket (4) | New receive buffer size: 0
2024-09-22 19:41:08.387 | DTC Client socket (4) | Connecting to IP: 69.39.70.241.
2024-09-22 19:41:08.614 | 6AZ4.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:08.614 | 6AZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:08.855 | SC Data with Depth | Network connection to server complete.
2024-09-22 19:41:08.855 | SC Data with Depth | Starting socket receive thread.
2024-09-22 19:41:08.855 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2024-09-22 19:41:08.857 | 6AZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:08.857 | 6AZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:09.115 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-22 19:41:09.115 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-22 19:41:09.115 | 6AZ4.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:09.115 | 6AZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:09.747 | HD Request # 16 | Requesting historical Daily data for J6Z24 starting at 2024-09-17. SC External HD service.
2024-09-22 19:41:09.747 | SC Data with Depth | Setting DTC encoding to Binary VLS
2024-09-22 19:41:09.747 | SC Data with Depth | Sending logon request message.
2024-09-22 19:41:09.817 | GCZ4.COMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:09.822 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-22 19:41:09.822 | Triggering next historical data download in queue.
2024-09-22 19:41:09.823 | GCZ4.COMEX [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol GCZ4.COMEX starting at last date in file.
2024-09-22 19:41:09.823 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-22 19:41:09.823 | Triggering next historical data download in queue.
2024-09-22 19:41:09.843 | GCZ4.COMEX [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:09.854 | GCZ4.COMEX [CBV] #14 | Reloading chart.
2024-09-22 19:41:09.974 | GCZ4.COMEX [CBV] #14 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:09.986 | GCZ4.COMEX [CBV] #3 | Reloading chart.
2024-09-22 19:41:10.094 | GCZ4.COMEX [CBV] #3 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:10.106 | GCZ4.COMEX [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:10.205 | GCZ4.COMEX [CBV] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:10.217 | GCZ4.COMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:10.217 | GCZ4.COMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.217 | GCZ4.COMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.460 | GCZ4.COMEX [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 22,
2024-09-22 19:41:10.472 | GCZ4.COMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:10.472 | GCZ4.COMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.472 | GCZ4.COMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.719 | GCZ4.COMEX [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 22,
2024-09-22 19:41:10.764 | GCZ4.COMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:10.764 | GCZ4.COMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.764 | GCZ4.COMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:11.008 | GCZ4.COMEX [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 22,
2024-09-22 19:41:11.022 | GCZ4.COMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:11.117 | GCZ4.COMEX [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:11.157 | GCZ4.COMEX 5 Min #12 | Reloading chart.
2024-09-22 19:41:11.176 | GCZ4.COMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:41:11.190 | GCZ4.COMEX [CBV] 3 Min #17 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:11.224 | GCZ4.COMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:11.283 | GCZ4.COMEX [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:11.319 | GCZ4.COMEX 5 Min #11 | Reloading chart.
2024-09-22 19:41:11.363 | GCZ4.COMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:11.478 | GCZ4.COMEX [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:11.514 | GCZ4.COMEX Rev. 16t-20 #13 | Reloading chart.
2024-09-22 19:41:11.718 | ESU4.CME #9 | Reloading chart.
2024-09-22 19:41:11.719 | ESU4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:11.719 | ESU4.CME #9 | Chart data loading complete.
2024-09-22 19:41:11.730 | MGCZ4.COMEX 15 Min #1 | Reloading chart.
2024-09-22 19:41:11.942 | MESU4.CME #16 | Reloading chart.
2024-09-22 19:41:11.942 | MESU4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:11.943 | MESU4.CME #16 | Chart data loading complete.
2024-09-22 19:41:11.957 | 6AZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:11.962 | SC Data with Depth | Received logon response.
2024-09-22 19:41:11.962 | SC Data with Depth | Server Name: SC Realtime Server.
2024-09-22 19:41:11.962 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2024-09-22 19:41:11.962 | SC Data with Depth | Successfully connected.
2024-09-22 19:41:11.962 | SC Data with Depth | Trading is not supported.
2024-09-22 19:41:11.962 | SC Data with Depth | MarketDepthIsSupported: 1
2024-09-22 19:41:11.962 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2024-09-22 19:41:11.970 | GCZ4.COMEX 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:58
2024-09-22 19:41:11.981 | GCZ4.COMEX 5 Min #11 | Chart data loading complete.
2024-09-22 19:41:11.997 | GCZ4.COMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-21 16:15:00
2024-09-22 19:41:12.006 | GCZ4.COMEX 5 Min #12 | Chart data loading complete.
2024-09-22 19:41:12.007 | MGCZ4.COMEX 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 19:41:12.008 | MGCZ4.COMEX 15 Min #1 | Chart data loading complete.
2024-09-22 19:41:12.103 | 6AZ4.CME [CBV] 2 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:12.104 | 6AZ4.CME [CBV] 2 Min #17 | Reloading chart.
2024-09-22 19:41:12.146 | 6AZ4.CME [CBV] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:12.147 | 6AZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:12.392 | GCZ4.COMEX Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-21 16:15:00
2024-09-22 19:41:12.405 | GCZ4.COMEX Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 19:41:12.406 | 6AZ4.CME [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:12.466 | 6AZ4.CME [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:12.467 | 6AZ4.CME [CBV] 2 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:12.475 | 6AZ4.CME [CBV] 2 Min #17 | Chart data loading complete.
2024-09-22 19:41:12.551 | 6AZ4.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:12.551 | 6AZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:13.132 | HD Request # 16 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-18.
2024-09-22 19:41:13.132 | HD Request # 16 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-22 19:41:13.138 | HD Request # 16 | Bytes received: 274
2024-09-22 19:41:13.138 | HD Request # 16 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6JZ4.CME
2024-09-22 19:41:13.138 | HD Request # 16 | Completion time: 5s.
2024-09-22 19:41:13.138 | HD Request # 16 | Daily data download complete for 6JZ4.CME. Unique request ID: 18
2024-09-22 19:41:13.138 | Removing historical data download ID 18.
2024-09-22 19:41:13.138 | Triggering next historical data download in queue.
2024-09-22 19:41:13.246 | 6AZ4.CME [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:13.246 | SC Data with Depth | Received security definition for symbol USDX
2024-09-22 19:41:13.246 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2024-09-22 19:41:13.247 | HD Request # 17 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 19:41:13.248 | 6AZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:13.263 | 6AZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:13.264 | 6AZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:13.589 | CLX4.NYMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:13.601 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-22 19:41:13.601 | Triggering next historical data download in queue.
2024-09-22 19:41:13.602 | CLX4.NYMEX [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol CLX4.NYMEX starting at last date in file.
2024-09-22 19:41:13.602 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-22 19:41:13.602 | Triggering next historical data download in queue.
2024-09-22 19:41:13.623 | CLX4.NYMEX [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:13.636 | CLX4.NYMEX [CBV] #14 | Reloading chart.
2024-09-22 19:41:13.769 | CLX4.NYMEX [CBV] #14 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:13.781 | CLX4.NYMEX [CBV] #3 | Reloading chart.
2024-09-22 19:41:13.881 | CLX4.NYMEX [CBV] #3 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:13.894 | CLX4.NYMEX [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:13.987 | CLX4.NYMEX [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:14.000 | CLX4.NYMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:14.000 | CLX4.NYMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.000 | CLX4.NYMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.263 | CLX4.NYMEX [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 24,
2024-09-22 19:41:14.308 | CLX4.NYMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:14.308 | CLX4.NYMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.308 | CLX4.NYMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.518 | CLX4.NYMEX [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 24,
2024-09-22 19:41:14.532 | CLX4.NYMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:14.532 | CLX4.NYMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.532 | CLX4.NYMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.749 | CLX4.NYMEX [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 24,
2024-09-22 19:41:14.765 | CLX4.NYMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:14.861 | CLX4.NYMEX [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:14.905 | CLX4.NYMEX 5 Min #12 | Reloading chart.
2024-09-22 19:41:14.941 | CLX4.NYMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:14.993 | CLX4.NYMEX [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:15.030 | CLX4.NYMEX 5 Min #11 | Reloading chart.
2024-09-22 19:41:15.070 | CLX4.NYMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:15.175 | CLX4.NYMEX [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:15.191 | CLX4.NYMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:41:15.203 | CLX4.NYMEX [CBV] 3 Min #17 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:15.238 | CLX4.NYMEX Rev. 16t-20 #13 | Reloading chart.
2024-09-22 19:41:15.445 | ESZ4.CME #9 | Reloading chart.
2024-09-22 19:41:15.445 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:15.446 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 19:41:15.459 | MCLU4.NYMEX 15 Min #1 | Reloading chart.
2024-09-22 19:41:15.668 | MESZ4.CME #16 | Reloading chart.
2024-09-22 19:41:15.668 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:15.669 | MESZ4.CME #16 | Chart data loading complete.
2024-09-22 19:41:15.683 | 6AZ4.CME [CBV] 240 Min #15 | Chart data loading complete.
2024-09-22 19:41:15.688 | HD Request # 17 | Requesting historical Daily data for GCZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 19:41:15.697 | CLX4.NYMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 19:41:15.701 | CLX4.NYMEX 5 Min #12 | Chart data loading complete.
2024-09-22 19:41:15.701 | CLX4.NYMEX 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 19:41:15.709 | CLX4.NYMEX 5 Min #11 | Chart data loading complete.
2024-09-22 19:41:15.713 | CLX4.NYMEX Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 19:41:15.724 | CLX4.NYMEX Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 19:41:15.750 | MCLU4.NYMEX 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-07-21 18:00:00
2024-09-22 19:41:15.751 | MCLU4.NYMEX 15 Min #1 | Chart data loading complete.
2024-09-22 19:41:15.872 | 6JZ4.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:15.873 | 6JZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:16.457 | 6AZ4.CME [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:16.495 | HD Request # 18 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-22 19:41:16.495 | HD Request # 18 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.586001
2024-09-22 19:41:16.495 | HD Request # 18 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:16.495 | Socket (10) | Creating socket.
2024-09-22 19:41:16.495 | Socket (10) | New receive buffer size: 0
2024-09-22 19:41:16.495 | Socket (10) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:16.495 | 6AZ4.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:16.495 | 6AZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:16.605 | 6JZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:16.605 | HD Request # 17 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-18.
2024-09-22 19:41:16.605 | HD Request # 17 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-22 19:41:16.611 | HD Request # 17 | Bytes received: 232
2024-09-22 19:41:16.611 | HD Request # 17 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-22 19:41:16.611 | HD Request # 17 | Completion time: 3s.
2024-09-22 19:41:16.611 | HD Request # 17 | Daily data download complete for GCZ4.COMEX. Unique request ID: 22
2024-09-22 19:41:16.611 | Removing historical data download ID 22.
2024-09-22 19:41:16.611 | Triggering next historical data download in queue.
2024-09-22 19:41:16.611 | Mapping CLX4.NYMEX to CLX24. Service code: nymex
2024-09-22 19:41:16.612 | HD Request # 19 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 19:41:16.616 | 6AZ4.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:16.616 | 6AZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:17.048 | HD Request # 18 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:17.048 | HD Request # 18 | Sending historical data logon request message.
2024-09-22 19:41:17.178 | 6AZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:17.178 | 6AZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:17.236 | 6AZ4.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:17.236 | 6AZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:17.485 | 6AZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:17.594 | 6AZ4.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:17.610 | 6AZ4.CME [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:17.628 | 6AZ4.CME [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:17.824 | HD Request # 18 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: M6AZ24
2024-09-22 19:41:18.008 | HD Request # 19 | Requesting historical Daily data for CLX24 starting at 2024-09-17. SC External HD service.
2024-09-22 19:41:18.024 | 6JZ4.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:18.025 | 6JZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:18.097 | HD Request # 18 | Decompressing data.
2024-09-22 19:41:18.368 | HD Request # 18 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-20 16:59:58.586000
2024-09-22 19:41:18.369 | Socket (10) | CloseSocket call.
2024-09-22 19:41:18.369 | Socket (10) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:18.586 | Historical data download thread signaled to stop.
2024-09-22 19:41:18.586 | HD Request # 18 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.146000.
2024-09-22 19:41:18.586 | HD Request # 18 | Received 235 Intraday data records from 2024-09-20 16:59:58.586000 to 2024-09-22 19:40:37.737000 (2.1 days. Delay: 40.8 seconds) and wrote 233 records for M6AZ4.CME
2024-09-22 19:41:18.586 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:40:37.737000
2024-09-22 19:41:18.586 | HD Request # 18 | Completion time: 2s.
2024-09-22 19:41:18.586 | HD Request # 18 | Intraday data download complete for M6AZ4.CME. Unique request ID: 16
2024-09-22 19:41:18.586 | Removing historical data download ID 16.
2024-09-22 19:41:18.586 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-22 19:41:18.586 | Intraday chart data file opened for M6AZ4.CME
2024-09-22 19:41:18.586 | HD Request # 18 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:18.586 | Triggering next historical data download in queue.
2024-09-22 19:41:18.587 | HD Request # 20 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-22 19:41:18.587 | HD Request # 20 | Download start date-time: 2024-09-20 16:59:57.000000. File last date-time: 2024-09-20 16:59:57.761004
2024-09-22 19:41:18.587 | HD Request # 20 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:41:18.587 | Socket (12) | Creating socket.
2024-09-22 19:41:18.587 | Socket (12) | New receive buffer size: 0
2024-09-22 19:41:18.587 | Socket (12) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:18.594 | 6AZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:18.640 | Socket (10) | Socket gracefully closed by remote side.
2024-09-22 19:41:18.641 | Socket (10) | Closed.
2024-09-22 19:41:18.910 | 6JZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:18.917 | 6AZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:19.140 | HD Request # 20 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:19.140 | HD Request # 20 | Sending historical data logon request message.
2024-09-22 19:41:19.304 | 6AZ4.CME [CBV] #14 | Chart data loading complete.
2024-09-22 19:41:19.304 | HD Request # 19 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-18.
2024-09-22 19:41:19.304 | HD Request # 19 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-22 19:41:19.310 | HD Request # 19 | Bytes received: 217
2024-09-22 19:41:19.310 | HD Request # 19 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-22 19:41:19.310 | HD Request # 19 | Completion time: 3s.
2024-09-22 19:41:19.310 | HD Request # 19 | Daily data download complete for CLX4.NYMEX. Unique request ID: 24
2024-09-22 19:41:19.310 | Removing historical data download ID 24.
2024-09-22 19:41:19.310 | No download requests in the queue to start downloads for.
2024-09-22 19:41:19.334 | 6AZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:19.334 | 6AZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:19.334 | 6AZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:19.411 | HD Request # 20 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:57. Record interval: 0. Symbol: 6JZ24
2024-09-22 19:41:19.685 | HD Request # 20 | Decompressing data.
2024-09-22 19:41:20.068 | GCZ4.COMEX [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:20.068 | GCZ4.COMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:20.235 | HD Request # 20 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-20 16:59:57.760000
2024-09-22 19:41:20.236 | Socket (12) | CloseSocket call.
2024-09-22 19:41:20.236 | Socket (12) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:20.507 | Socket (12) | Socket gracefully closed by remote side.
2024-09-22 19:41:20.507 | Socket (12) | Closed.
2024-09-22 19:41:20.513 | 6AZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:20.513 | Historical data download thread signaled to stop.
2024-09-22 19:41:20.513 | HD Request # 20 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.115000.
2024-09-22 19:41:20.513 | HD Request # 20 | Received 2854 Intraday data records from 2024-09-20 16:59:57.760000 to 2024-09-22 19:40:50.172001 (2.1 days. Delay: 30.3 seconds) and wrote 2848 records for 6JZ4.CME
2024-09-22 19:41:20.514 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:40:50.172001
2024-09-22 19:41:20.514 | HD Request # 20 | Completion time: 2s.
2024-09-22 19:41:20.514 | HD Request # 20 | Intraday data download complete for 6JZ4.CME. Unique request ID: 17
2024-09-22 19:41:20.514 | Removing historical data download ID 17.
2024-09-22 19:41:20.514 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-22 19:41:20.514 | Intraday chart data file opened for 6JZ4.CME
2024-09-22 19:41:20.514 | HD Request # 20 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:20.514 | Triggering next historical data download in queue.
2024-09-22 19:41:20.514 | HD Request # 21 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-22 19:41:20.514 | HD Request # 21 | Download start date-time: 2024-09-20 16:54:47.000000. File last date-time: 2024-09-20 16:54:47.126000
2024-09-22 19:41:20.514 | HD Request # 21 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:20.514 | Socket (5) | Creating socket.
2024-09-22 19:41:20.514 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:20.514 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:20.515 | GCZ4.COMEX [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:20.515 | GCZ4.COMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:20.959 | GCZ4.COMEX [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:20.959 | Requesting market depth updates for: 6JZ4.CME if supported. NumLevels=50
2024-09-22 19:41:20.959 | Denali Data Feed | Starting real-time market data updates for: CLX4.NYMEX (CLX24). ID: 13 Service code: nymex
2024-09-22 19:41:20.959 | Denali Data Feed | Requesting security definition data for: CLX4.NYMEX (CLX24). ID: 13
2024-09-22 19:41:20.959 | Requesting market depth updates for: CLX4.NYMEX if supported. NumLevels=50
2024-09-22 19:41:20.959 | Mapping ESU4.CME to ESU24. Service code: cme
2024-09-22 19:41:20.959 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 14 Service code: cme
2024-09-22 19:41:20.959 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 14
2024-09-22 19:41:20.959 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2024-09-22 19:41:20.959 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 12 Service code: comex
2024-09-22 19:41:20.959 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 12
2024-09-22 19:41:20.959 | Requesting market depth updates for: GCZ4.COMEX if supported. NumLevels=50
2024-09-22 19:41:20.959 | Requesting market depth updates for: MESU4.CME if supported. NumLevels=50
2024-09-22 19:41:20.959 | GCZ4.COMEX [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:20.960 | GCZ4.COMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:21.068 | HD Request # 21 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:21.068 | HD Request # 21 | Sending historical data logon request message.
2024-09-22 19:41:21.340 | HD Request # 21 | Requesting Intraday data. Start date-time: 2024-09-20 16:54:47. Record interval: 0. Symbol: MJYZ24
2024-09-22 19:41:21.403 | GCZ4.COMEX [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:21.419 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-22 19:41:21.419 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-22 19:41:21.419 | Triggering next historical data download in queue.
2024-09-22 19:41:21.419 | Mapping MGCZ4.COMEX to MGCZ24. Service code: comex
2024-09-22 19:41:21.419 | Denali Data Feed | Starting real-time market data updates for: MGCZ4.COMEX (MGCZ24). ID: 15 Service code: comex
2024-09-22 19:41:21.419 | Denali Data Feed | Requesting security definition data for: MGCZ4.COMEX (MGCZ24). ID: 15
2024-09-22 19:41:21.419 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-22 19:41:21.419 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-22 19:41:21.429 | 6JZ4.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:21.429 | 6JZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:21.611 | HD Request # 21 | Decompressing data.
2024-09-22 19:41:21.691 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-22 19:41:21.691 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-22 19:41:21.691 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-22 19:41:21.691 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-22 19:41:21.692 | GCZ4.COMEX [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:21.694 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-22 19:41:21.694 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-22 19:41:21.694 | Triggering next historical data download in queue.
2024-09-22 19:41:21.695 | 6AZ4.CME [CBV] 2 Min #17 | Reloading chart.
2024-09-22 19:41:21.736 | 6AZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:21.882 | HD Request # 21 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-20 16:54:47.126000
2024-09-22 19:41:21.882 | Socket (5) | CloseSocket call.
2024-09-22 19:41:21.882 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:22.090 | 6AZ4.CME [CBV] 2 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:22.103 | 6AZ4.CME [CBV] 2 Min #17 | Chart data loading complete.
2024-09-22 19:41:22.103 | 6AZ4.CME [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:22.153 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:22.153 | Socket (5) | Closed.
2024-09-22 19:41:22.168 | 6AZ4.CME [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:22.168 | Historical data download thread signaled to stop.
2024-09-22 19:41:22.168 | HD Request # 21 | Timestamp of first Intraday data file record written: 2024-09-22 18:07:56.023000.
2024-09-22 19:41:22.169 | HD Request # 21 | Received 19 Intraday data records from 2024-09-20 16:54:47.126000 to 2024-09-22 19:34:49.672000 (2.1 days. Delay: 6.5 minutes) and wrote 18 records for MJYZ4.CME
2024-09-22 19:41:22.169 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:34:49.672000
2024-09-22 19:41:22.169 | HD Request # 21 | Completion time: 2s.
2024-09-22 19:41:22.169 | HD Request # 21 | Intraday data download complete for MJYZ4.CME. Unique request ID: 19
2024-09-22 19:41:22.169 | Removing historical data download ID 19.
2024-09-22 19:41:22.169 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-22 19:41:22.169 | Intraday chart data file opened for MJYZ4.CME
2024-09-22 19:41:22.169 | HD Request # 21 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:22.169 | Triggering next historical data download in queue.
2024-09-22 19:41:22.235 | HD Request # 22 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2024-09-22 19:41:22.235 | HD Request # 22 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.000000
2024-09-22 19:41:22.235 | HD Request # 22 | Using server: ds12.sierracharts.com port 10150
2024-09-22 19:41:22.235 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-22 19:41:22.235 | Socket (5) | Creating socket.
2024-09-22 19:41:22.235 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:22.235 | Socket (5) | Connecting to IP: 69.39.70.241.
2024-09-22 19:41:22.236 | 6JZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:22.236 | 6JZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:22.510 | 6JZ4.CME [CBV] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:22.510 | 6JZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-22 19:41:22.542 | 6JZ4.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:22.543 | 6JZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:22.781 | HD Request # 22 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:22.781 | HD Request # 22 | Sending historical data logon request message.
2024-09-22 19:41:23.314 | 6AZ4.CME [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:23.315 | 6JZ4.CME [CBV] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:23.334 | 6JZ4.CME [CBV] 1 Min #17 | Chart data loading complete.
2024-09-22 19:41:23.335 | 6JZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:23.353 | 6AZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:23.353 | 6AZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:23.353 | 6AZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:23.528 | HD Request # 22 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: USDX
2024-09-22 19:41:23.797 | HD Request # 22 | Decompressing data.
2024-09-22 19:41:24.161 | 6AZ4.CME [CBV] 240 Min #15 | Chart data loading complete.
2024-09-22 19:41:24.173 | 6JZ4.CME [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:24.173 | 6JZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:24.442 | 6AZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:24.443 | 6AZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:24.625 | HD Request # 22 | Receiving Intraday data for USDX starting at 2024-09-20 16:59:59.000000
2024-09-22 19:41:24.803 | CLX4.NYMEX [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:24.803 | CLX4.NYMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:24.893 | Socket (5) | CloseSocket call.
2024-09-22 19:41:24.893 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:25.162 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:25.162 | Socket (5) | Closed.
2024-09-22 19:41:27.105 | Historical data download thread signaled to stop.
2024-09-22 19:41:27.106 | HD Request # 22 | Timestamp of first Intraday data file record written: 2024-09-21 20:14:17.000000.
2024-09-22 19:41:27.106 | HD Request # 22 | Received 4152 Intraday data records from 2024-09-20 16:59:59.000000 to 2024-09-22 19:41:24.000000 (2.1 days. Delay: 3.1 seconds) and wrote 4151 records for USDX
2024-09-22 19:41:27.106 | HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:41:24.000000
2024-09-22 19:41:27.106 | Added 4 Time and Sales records to Intraday data file for USDX after download.
2024-09-22 19:41:27.106 | HD Request # 22 | Completion time: 5s.
2024-09-22 19:41:27.106 | HD Request # 22 | Intraday data download complete for USDX. Unique request ID: 20
2024-09-22 19:41:27.106 | Removing historical data download ID 20.
2024-09-22 19:41:27.106 | Real-time Intraday chart data file updates started for USDX
2024-09-22 19:41:27.106 | Intraday chart data file opened for USDX
2024-09-22 19:41:27.106 | HD Request # 22 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:27.106 | Triggering next historical data download in queue.
2024-09-22 19:41:27.106 | HD Request # 23 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-22 19:41:27.107 | HD Request # 23 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.361000
2024-09-22 19:41:27.107 | HD Request # 23 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:27.107 | Socket (5) | Creating socket.
2024-09-22 19:41:27.107 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:27.107 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:27.244 | CLX4.NYMEX [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:27.245 | CLX4.NYMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:27.660 | HD Request # 23 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:27.660 | HD Request # 23 | Sending historical data logon request message.
2024-09-22 19:41:27.933 | HD Request # 23 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: GCZ24
2024-09-22 19:41:28.205 | HD Request # 23 | Decompressing data.
2024-09-22 19:41:28.755 | HD Request # 23 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-20 16:59:58.171000
2024-09-22 19:41:28.755 | Socket (5) | CloseSocket call.
2024-09-22 19:41:28.755 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:29.028 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:29.028 | Socket (5) | Closed.
2024-09-22 19:41:29.250 | 6JZ4.CME [CBV] 60 Min #15 | Chart data loading complete.
2024-09-22 19:41:29.251 | CLX4.NYMEX [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:29.253 | 6AZ4.CME [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:29.253 | Historical data download thread signaled to stop.
2024-09-22 19:41:29.253 | HD Request # 23 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.000000.
2024-09-22 19:41:29.253 | HD Request # 23 | Received 2368 Intraday data records from 2024-09-20 16:59:58.171000 to 2024-09-22 19:40:50.183001 (2.1 days. Delay: 39.1 seconds) and wrote 2364 records for GCZ4.COMEX
2024-09-22 19:41:29.254 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:40:50.183001
2024-09-22 19:41:29.254 | HD Request # 23 | Completion time: 2s.
2024-09-22 19:41:29.254 | HD Request # 23 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 21
2024-09-22 19:41:29.254 | Removing historical data download ID 21.
2024-09-22 19:41:29.254 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-22 19:41:29.254 | Intraday chart data file opened for GCZ4.COMEX
2024-09-22 19:41:29.254 | HD Request # 23 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:29.254 | Triggering next historical data download in queue.
2024-09-22 19:41:29.254 | HD Request # 24 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-22 19:41:29.254 | HD Request # 24 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.016000
2024-09-22 19:41:29.254 | HD Request # 24 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:41:29.254 | Socket (5) | Creating socket.
2024-09-22 19:41:29.254 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:29.254 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:29.254 | CLX4.NYMEX [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:29.255 | CLX4.NYMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:29.822 | HD Request # 24 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:29.822 | HD Request # 24 | Sending historical data logon request message.
2024-09-22 19:41:30.104 | HD Request # 24 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: CLX24
2024-09-22 19:41:30.394 | HD Request # 24 | Decompressing data.
2024-09-22 19:41:30.707 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 3296
2024-09-22 19:41:30.959 | HD Request # 24 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-20 16:59:59.016000
2024-09-22 19:41:30.959 | Socket (5) | CloseSocket call.
2024-09-22 19:41:30.959 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:31.221 | CLX4.NYMEX [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:31.221 | 6JZ4.CME [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:31.245 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:31.245 | Socket (5) | Closed.
2024-09-22 19:41:31.267 | 6JZ4.CME [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:31.373 | 6JZ4.CME [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:31.373 | Historical data download thread signaled to stop.
2024-09-22 19:41:31.373 | HD Request # 24 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.000000.
2024-09-22 19:41:31.373 | HD Request # 24 | Received 2457 Intraday data records from 2024-09-20 16:59:59.016000 to 2024-09-22 19:41:21.054000 (2.1 days. Delay: 10.3 seconds) and wrote 2456 records for CLX4.NYMEX
2024-09-22 19:41:31.374 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:41:21.054000
2024-09-22 19:41:31.374 | Added 1 Time and Sales records to Intraday data file for CLX4.NYMEX after download.
2024-09-22 19:41:31.374 | HD Request # 24 | Completion time: 2s.
2024-09-22 19:41:31.374 | HD Request # 24 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 23
2024-09-22 19:41:31.374 | Removing historical data download ID 23.
2024-09-22 19:41:31.374 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-22 19:41:31.374 | Intraday chart data file opened for CLX4.NYMEX
2024-09-22 19:41:31.374 | HD Request # 24 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:31.374 | Triggering next historical data download in queue.
2024-09-22 19:41:31.420 | HD Request # 25 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-22 19:41:31.420 | HD Request # 25 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-22 19:41:31.420 | HD Request # 25 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:31.420 | Socket (5) | Creating socket.
2024-09-22 19:41:31.420 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:31.420 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:31.420 | CLX4.NYMEX [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:31.421 | CLX4.NYMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:31.992 | HD Request # 25 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:31.992 | HD Request # 25 | Sending historical data logon request message.
2024-09-22 19:41:32.217 | CLX4.NYMEX [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:32.218 | CLX4.NYMEX [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:32.218 | CLX4.NYMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:32.277 | HD Request # 25 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-22 19:41:32.557 | HD Request # 25 | Decompressing data.
2024-09-22 19:41:32.675 | CLX4.NYMEX [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:32.675 | CLX4.NYMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:32.836 | HD Request # 25 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-22 19:41:32.836 | Socket (5) | CloseSocket call.
2024-09-22 19:41:32.836 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:33.117 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:33.117 | Socket (5) | Closed.
2024-09-22 19:41:33.682 | Historical data download thread signaled to stop.
2024-09-22 19:41:33.682 | HD Request # 25 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 2.4 days) and wrote 0 records for ESU4.CME
2024-09-22 19:41:33.682 | HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-22 19:41:33.682 | HD Request # 25 | Completion time: 2s.
2024-09-22 19:41:33.682 | HD Request # 25 | Intraday data download complete for ESU4.CME. Unique request ID: 25
2024-09-22 19:41:33.682 | Removing historical data download ID 25.
2024-09-22 19:41:33.682 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-22 19:41:33.682 | Intraday chart data file opened for ESU4.CME
2024-09-22 19:41:33.682 | HD Request # 25 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:33.682 | Triggering next historical data download in queue.
2024-09-22 19:41:33.682 | HD Request # 26 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-22 19:41:33.682 | HD Request # 26 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.699000
2024-09-22 19:41:33.682 | HD Request # 26 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:41:33.682 | Socket (5) | Creating socket.
2024-09-22 19:41:33.682 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:33.682 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:33.684 | CLX4.NYMEX [CBV] 3 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:33.684 | CLX4.NYMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:41:33.814 | Mapping MCLU4.NYMEX to MCLU24. Service code: nymex
2024-09-22 19:41:33.815 | Denali Data Feed | Starting real-time market data updates for: MCLU4.NYMEX (MCLU24). ID: 16 Service code: nymex
2024-09-22 19:41:33.815 | Denali Data Feed | Requesting security definition data for: MCLU4.NYMEX (MCLU24). ID: 16
2024-09-22 19:41:33.815 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-22 19:41:33.815 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-22 19:41:33.815 | Triggering next historical data download in queue.
2024-09-22 19:41:33.816 | 6JZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:33.816 | 6JZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:33.816 | 6JZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:34.235 | HD Request # 26 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:34.235 | HD Request # 26 | Sending historical data logon request message.
2024-09-22 19:41:34.516 | HD Request # 26 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: MGCZ24
2024-09-22 19:41:34.716 | CLX4.NYMEX [CBV] 3 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:34.724 | CLX4.NYMEX [CBV] 3 Min #17 | Chart data loading complete.
2024-09-22 19:41:34.724 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-22 19:41:34.724 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-22 19:41:34.768 | 6JZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:34.769 | 6JZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:34.788 | HD Request # 26 | Decompressing data.
2024-09-22 19:41:35.064 | 6JZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:35.065 | 6AZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:35.065 | HD Request # 26 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-20 16:59:59.699000
2024-09-22 19:41:35.066 | Socket (5) | CloseSocket call.
2024-09-22 19:41:35.066 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:35.239 | Historical data download thread signaled to stop.
2024-09-22 19:41:35.239 | HD Request # 26 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.000000.
2024-09-22 19:41:35.240 | HD Request # 26 | Received 1868 Intraday data records from 2024-09-20 16:59:59.699000 to 2024-09-22 19:41:29.189000 (2.1 days. Delay: 6.1 seconds) and wrote 1867 records for MGCZ4.COMEX
2024-09-22 19:41:35.240 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:41:29.189000
2024-09-22 19:41:35.240 | HD Request # 26 | Completion time: 2s.
2024-09-22 19:41:35.240 | HD Request # 26 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 26
2024-09-22 19:41:35.240 | Removing historical data download ID 26.
2024-09-22 19:41:35.240 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-22 19:41:35.240 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-22 19:41:35.240 | HD Request # 26 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:35.240 | Triggering next historical data download in queue.
2024-09-22 19:41:35.240 | HD Request # 27 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-22 19:41:35.240 | HD Request # 27 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-22 19:41:35.241 | HD Request # 27 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:35.241 | Socket (7) | Creating socket.
2024-09-22 19:41:35.241 | Socket (7) | New receive buffer size: 0
2024-09-22 19:41:35.241 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:35.246 | 6AZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:35.247 | 6AZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:35.247 | 6AZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:35.338 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:35.338 | Socket (5) | Closed.
2024-09-22 19:41:35.765 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6JZ4.CME.scid. Thread ID: 3296
2024-09-22 19:41:35.803 | HD Request # 27 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:35.803 | HD Request # 27 | Sending historical data logon request message.
2024-09-22 19:41:36.079 | HD Request # 27 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-22 19:41:36.290 | 6AZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:36.319 | 6AZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:36.355 | HD Request # 27 | Decompressing data.
2024-09-22 19:41:36.470 | 6AZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:36.634 | HD Request # 27 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-22 19:41:36.634 | Socket (7) | CloseSocket call.
2024-09-22 19:41:36.634 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:36.879 | 6AZ4.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:36.900 | 6AZ4.CME [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:36.900 | Historical data download thread signaled to stop.
2024-09-22 19:41:36.900 | HD Request # 27 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 2.4 days) and wrote 0 records for MESU4.CME
2024-09-22 19:41:36.900 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-22 19:41:36.900 | HD Request # 27 | Completion time: 1s.
2024-09-22 19:41:36.900 | HD Request # 27 | Intraday data download complete for MESU4.CME. Unique request ID: 27
2024-09-22 19:41:36.900 | Removing historical data download ID 27.
2024-09-22 19:41:36.900 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-22 19:41:36.900 | Intraday chart data file opened for MESU4.CME
2024-09-22 19:41:36.900 | HD Request # 27 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:36.900 | Triggering next historical data download in queue.
2024-09-22 19:41:36.909 | Socket (7) | Socket gracefully closed by remote side.
2024-09-22 19:41:36.909 | Socket (7) | Closed.
2024-09-22 19:41:36.921 | Delaying start of download for MCLU4.NYMEX.
2024-09-22 19:41:36.938 | 6AZ4.CME [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:37.399 | 6JZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:37.399 | 6JZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:37.399 | 6JZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:38.321 | CLX4.NYMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:38.347 | CLX4.NYMEX [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:38.376 | 6JZ4.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:38.377 | 6JZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:38.514 | 6JZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:38.515 | 6JZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:38.516 | 6JZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:38.582 | 6JZ4.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:38.582 | 6JZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:38.995 | 6AZ4.CME [CBV] #14 | Chart data loading complete.
2024-09-22 19:41:39.031 | GCZ4.COMEX [CBV] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:39.031 | GCZ4.COMEX [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:39.260 | GCZ4.COMEX [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:39.261 | GCZ4.COMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:39.304 | GCZ4.COMEX [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:39.304 | GCZ4.COMEX [CBV] #14 | Reloading chart.
2024-09-22 19:41:39.579 | GCZ4.COMEX [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:39.580 | GCZ4.COMEX [CBV] #3 | Reloading chart.
2024-09-22 19:41:39.897 | GCZ4.COMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:39.897 | GCZ4.COMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:39.897 | GCZ4.COMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:40.811 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCZ4.COMEX.scid. Thread ID: 3296
2024-09-22 19:41:40.811 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\CLX4.NYMEX.scid. Thread ID: 3296
2024-09-22 19:41:41.022 | 6JZ4.CME [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:41.023 | GCZ4.COMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:41.023 | GCZ4.COMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:41.023 | GCZ4.COMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:41.985 | GCZ4.COMEX [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:41.993 | GCZ4.COMEX [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:41.994 | GCZ4.COMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:41.994 | GCZ4.COMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:41.994 | GCZ4.COMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:42.923 | GCZ4.COMEX [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:42.924 | 6JZ4.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:42.951 | 6JZ4.CME [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:42.977 | GCZ4.COMEX [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:42.977 | GCZ4.COMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:43.215 | GCZ4.COMEX [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:43.229 | GCZ4.COMEX [CBV] 3 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:43.230 | GCZ4.COMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:41:43.255 | GCZ4.COMEX [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:43.256 | GCZ4.COMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:43.380 | GCZ4.COMEX [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:43.381 | GCZ4.COMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:43.663 | 6JZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:44.167 | GCZ4.COMEX [CBV] 3 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:44.181 | GCZ4.COMEX [CBV] 3 Min #17 | Chart data loading complete.
2024-09-22 19:41:44.356 | 6JZ4.CME [CBV] #14 | Chart data loading complete.
2024-09-22 19:41:44.384 | 6JZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:44.945 | 6JZ4.CME [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:44.946 | 6JZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-22 19:41:45.013 | 6JZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:45.013 | 6JZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:45.013 | 6JZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:46.180 | 6JZ4.CME [CBV] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:46.206 | 6JZ4.CME [CBV] 1 Min #17 | Chart data loading complete.
2024-09-22 19:41:46.208 | GCZ4.COMEX [CBV] 240 Min #15 | Chart data loading complete.
2024-09-22 19:41:46.248 | 6JZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:46.716 | 6JZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:46.716 | CLX4.NYMEX [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:46.718 | CLX4.NYMEX [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:48.155 | GCZ4.COMEX [CBV] #14 | Chart data loading complete.
2024-09-22 19:41:48.196 | CLX4.NYMEX [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:48.197 | CLX4.NYMEX [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:48.197 | CLX4.NYMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:48.528 | CLX4.NYMEX [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:48.528 | CLX4.NYMEX [CBV] #14 | Reloading chart.
2024-09-22 19:41:49.933 | GCZ4.COMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:49.983 | GCZ4.COMEX [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:50.034 | CLX4.NYMEX [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:50.034 | CLX4.NYMEX [CBV] #3 | Reloading chart.
2024-09-22 19:41:50.886 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AZ4.CME.scid. Thread ID: 3296
2024-09-22 19:41:50.887 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-22 19:41:51.449 | 6JZ4.CME [CBV] 60 Min #15 | Chart data loading complete.
2024-09-22 19:41:51.450 | CLX4.NYMEX [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:51.557 | CLX4.NYMEX [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:51.563 | CLX4.NYMEX [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:51.693 | CLX4.NYMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:51.693 | CLX4.NYMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:51.693 | CLX4.NYMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:55.514 | GCZ4.COMEX [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:55.559 | CLX4.NYMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:55.559 | CLX4.NYMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:55.559 | CLX4.NYMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:58.382 | CLX4.NYMEX [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:58.382 | 6JZ4.CME [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:58.442 | 6JZ4.CME [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:58.470 | GCZ4.COMEX [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:58.473 | CLX4.NYMEX [CBV] 60 Min #15 | Chart data loading complete.
2024-09-22 19:41:58.599 | 6JZ4.CME [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:58.600 | GCZ4.COMEX [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:58.696 | GCZ4.COMEX [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:58.847 | CLX4.NYMEX [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:58.865 | CLX4.NYMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:58.865 | CLX4.NYMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:58.865 | CLX4.NYMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:42:01.446 | CLX4.NYMEX [CBV] #14 | Chart data loading complete.
2024-09-22 19:42:01.448 | CLX4.NYMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:42:02.364 | CLX4.NYMEX [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:42:02.404 | CLX4.NYMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:42:02.935 | CLX4.NYMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:42:04.019 | CLX4.NYMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:42:04.167 | 6JZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:42:04.570 | HD Request # 28 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-22 19:42:04.570 | HD Request # 28 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-22 19:42:04.570 | HD Request # 28 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:42:04.570 | Socket (5) | Creating socket.
2024-09-22 19:42:04.570 | Socket (5) | New receive buffer size: 0
2024-09-22 19:42:04.570 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:42:04.684 | CLX4.NYMEX [CBV] 3 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:42:04.695 | CLX4.NYMEX [CBV] 3 Min #17 | Chart data loading complete.
2024-09-22 19:42:05.134 | HD Request # 28 | Setting DTC encoding to Binary VLS
2024-09-22 19:42:05.134 | HD Request # 28 | Sending historical data logon request message.
2024-09-22 19:42:05.251 | 6JZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:42:05.455 | 6JZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:42:05.562 | 6JZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:42:05.901 | HD Request # 28 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-22 19:42:06.053 | GCZ4.COMEX [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:42:06.179 | HD Request # 28 | Decompressing data.
2024-09-22 19:42:06.413 | GCZ4.COMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:42:06.455 | HD Request # 28 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-22 19:42:06.455 | Socket (5) | CloseSocket call.
2024-09-22 19:42:06.455 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:42:06.483 | Historical data download thread signaled to stop.
2024-09-22 19:42:06.483 | HD Request # 28 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 34.2 days) and wrote 0 records for MCLU4.NYMEX
2024-09-22 19:42:06.483 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-22 19:42:06.483 | HD Request # 28 | Completion time: 2s.
2024-09-22 19:42:06.483 | HD Request # 28 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 28
2024-09-22 19:42:06.483 | Removing historical data download ID 28.
2024-09-22 19:42:06.483 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-22 19:42:06.483 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-22 19:42:06.483 | HD Request # 28 | Enabling Intraday chart updating for symbol.
2024-09-22 19:42:06.483 | No download requests in the queue to start downloads for.
2024-09-22 19:42:06.489 | GCZ4.COMEX [CBV] #14 | Reloading chart.
2024-09-22 19:42:06.730 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:42:06.730 | Socket (5) | Closed.
2024-09-22 19:42:07.268 | CLX4.NYMEX [CBV] #3 | Chart data loading complete.
2024-09-22 19:42:07.362 | GCZ4.COMEX [CBV] #3 | Reloading chart.
2024-09-22 19:42:07.817 | 6JZ4.CME [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:42:07.841 | GCZ4.COMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:42:08.268 | GCZ4.COMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:42:08.320 | GCZ4.COMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:42:08.500 | CLX4.NYMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:42:08.535 | CLX4.NYMEX [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:42:08.599 | GCZ4.COMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:42:09.072 | GCZ4.COMEX [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:42:09.073 | GCZ4.COMEX [CBV] 3 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:42:09.088 | GCZ4.COMEX [CBV] 3 Min #17 | Chart data loading complete.
2024-09-22 19:42:09.355 | CLX4.NYMEX [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:42:10.823 | 6JZ4.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:42:10.852 | 6JZ4.CME [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:42:10.892 | CLX4.NYMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:42:11.448 | 6JZ4.CME [CBV] #14 | Chart data loading complete.
2024-09-22 19:42:11.455 | CLX4.NYMEX [CBV] #14 | Reloading chart.
2024-09-22 19:42:13.227 | CLX4.NYMEX [CBV] #3 | Reloading chart.
2024-09-22 19:42:15.047 | GCZ4.COMEX [CBV] 240 Min #15 | Chart data loading complete.
2024-09-22 19:42:15.053 | CLX4.NYMEX [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:42:15.054 | GCZ4.COMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:42:15.100 | GCZ4.COMEX [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:42:15.788 | GCZ4.COMEX [CBV] #14 | Chart data loading complete.
2024-09-22 19:42:15.827 | 6JZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 19:42:19.283 | CLX4.NYMEX [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 19:42:19.969 | CLX4.NYMEX [CBV][M] 60 Min #15 | Chart data loading complete.
2024-09-22 19:42:21.643 | GCZ4.COMEX [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 19:42:22.155 | CLX4.NYMEX [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:42:22.235 | CLX4.NYMEX [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-22 19:42:22.520 | GCZ4.COMEX [CBV][M] #3 | Chart data loading complete.
2024-09-22 19:42:22.521 | GCZ4.COMEX [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:42:22.610 | GCZ4.COMEX [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-22 19:42:24.168 | CLX4.NYMEX [CBV][M] #14 | Chart data loading complete.
2024-09-22 19:42:29.194 | CLX4.NYMEX [CBV][M] #3 | Chart data loading complete.
2024-09-22 19:42:31.242 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-22 19:43:36.789 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MJYZ4.CME.scid. Thread ID: 3296
2024-09-22 19:44:22.720 | Chat | Message response. Chat ID: 429. Request ID: 1134626463
2024-09-22 19:49:01.820 | Chat | Message response. Chat ID: 429. Request ID: 1134626464
2024-09-22 20:00:00.046 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-22 20:00:00.046 | Triggering next historical data download in queue.
2024-09-22 20:00:00.047 | HD Request # 29 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:00.261 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-22 20:00:00.261 | Triggering next historical data download in queue.
2024-09-22 20:00:00.462 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-22 20:00:00.462 | Triggering next historical data download in queue.
2024-09-22 20:00:00.462 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:00.501 | 6JZ4.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:00.549 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-22 20:00:00.549 | Triggering next historical data download in queue.
2024-09-22 20:00:00.656 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-22 20:00:00.657 | Triggering next historical data download in queue.
2024-09-22 20:00:00.738 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-22 20:00:00.738 | Triggering next historical data download in queue.
2024-09-22 20:00:00.751 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:01.004 | HD Request # 29 | Requesting historical Daily data for J6Z24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:01.057 | NQZ4.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:01.264 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:01.264 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.264 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.472 | GCZ4.COMEX [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 31,
2024-09-22 20:00:01.512 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:01.512 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.512 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.667 | 6JZ4.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 29,
2024-09-22 20:00:01.819 | ESZ4.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:01.913 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:01.913 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.913 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:02.115 | CLX4.NYMEX [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 32,
2024-09-22 20:00:02.115 | HD Request # 29 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-18.
2024-09-22 20:00:02.116 | HD Request # 29 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-22 20:00:02.119 | HD Request # 29 | Bytes received: 274
2024-09-22 20:00:02.119 | HD Request # 29 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6JZ4.CME
2024-09-22 20:00:02.120 | HD Request # 29 | Completion time: 2s.
2024-09-22 20:00:02.120 | HD Request # 29 | Daily data download complete for 6JZ4.CME. Unique request ID: 29
2024-09-22 20:00:02.120 | Removing historical data download ID 29.
2024-09-22 20:00:02.120 | Triggering next historical data download in queue.
2024-09-22 20:00:02.121 | HD Request # 30 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:02.144 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:02.144 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:02.144 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:02.908 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:02.908 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:02.908 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:03.612 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:03.612 | HD Request # 30 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:03.778 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:03.831 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:03.831 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:03.831 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:04.012 | NQZ4.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 30,
2024-09-22 20:00:04.346 | 6JZ4.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:04.347 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:04.894 | HD Request # 30 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-22 20:00:04.894 | HD Request # 30 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-22 20:00:04.896 | HD Request # 30 | Bytes received: 242
2024-09-22 20:00:04.896 | HD Request # 30 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for NQZ4.CME
2024-09-22 20:00:04.897 | HD Request # 30 | Completion time: 2s.
2024-09-22 20:00:04.897 | HD Request # 30 | Daily data download complete for NQZ4.CME. Unique request ID: 30
2024-09-22 20:00:04.897 | Removing historical data download ID 30.
2024-09-22 20:00:04.897 | Triggering next historical data download in queue.
2024-09-22 20:00:04.897 | HD Request # 31 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:04.958 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:04.958 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:04.958 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:05.135 | ESZ4.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 33,
2024-09-22 20:00:05.137 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:05.137 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:05.137 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:05.137 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:05.478 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:05.512 | 6AZ4.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:05.829 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:05.829 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:05.829 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:06.119 | HD Request # 31 | Requesting historical Daily data for GCZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:06.320 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:06.359 | NQZ4.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:06.359 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:06.518 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:06.566 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:06.566 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:06.566 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:07.268 | HD Request # 31 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-18.
2024-09-22 20:00:07.268 | HD Request # 31 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-22 20:00:07.273 | HD Request # 31 | Bytes received: 232
2024-09-22 20:00:07.273 | HD Request # 31 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-22 20:00:07.273 | HD Request # 31 | Completion time: 3s.
2024-09-22 20:00:07.273 | HD Request # 31 | Daily data download complete for GCZ4.COMEX. Unique request ID: 31
2024-09-22 20:00:07.273 | Removing historical data download ID 31.
2024-09-22 20:00:07.273 | Triggering next historical data download in queue.
2024-09-22 20:00:07.274 | HD Request # 32 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:07.368 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:07.417 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:07.417 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:07.417 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:07.572 | 6AZ4.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 34,
2024-09-22 20:00:07.617 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:07.617 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:07.617 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:08.304 | HD Request # 32 | Requesting historical Daily data for CLX24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:08.336 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:08.747 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:08.747 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:08.747 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:09.372 | HD Request # 32 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-18.
2024-09-22 20:00:09.372 | HD Request # 32 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-22 20:00:09.377 | HD Request # 32 | Bytes received: 217
2024-09-22 20:00:09.377 | HD Request # 32 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-22 20:00:09.377 | HD Request # 32 | Completion time: 2s.
2024-09-22 20:00:09.377 | HD Request # 32 | Daily data download complete for CLX4.NYMEX. Unique request ID: 32
2024-09-22 20:00:09.377 | Removing historical data download ID 32.
2024-09-22 20:00:09.377 | Triggering next historical data download in queue.
2024-09-22 20:00:09.378 | HD Request # 33 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:09.387 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:09.387 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:09.387 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:11.486 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:11.534 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:11.534 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:11.534 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:13.649 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:13.649 | HD Request # 33 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:13.696 | GCZ4.COMEX [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:13.697 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:14.116 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:14.117 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:14.117 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:14.117 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:14.408 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:14.471 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:14.748 | HD Request # 33 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-22 20:00:14.749 | HD Request # 33 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-22 20:00:14.752 | HD Request # 33 | Bytes received: 234
2024-09-22 20:00:14.752 | HD Request # 33 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-22 20:00:14.752 | HD Request # 33 | Completion time: 5s.
2024-09-22 20:00:14.752 | HD Request # 33 | Daily data download complete for ESZ4.CME. Unique request ID: 33
2024-09-22 20:00:14.752 | Removing historical data download ID 33.
2024-09-22 20:00:14.752 | Triggering next historical data download in queue.
2024-09-22 20:00:14.753 | HD Request # 34 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:14.887 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:14.887 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:14.887 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:15.413 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:15.444 | CLX4.NYMEX [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:15.445 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:17.341 | HD Request # 34 | Requesting historical Daily data for A6Z24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:17.444 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:17.444 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:17.444 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:18.071 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:18.071 | ESZ4.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:18.072 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:18.221 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:18.282 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:18.284 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:18.284 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:18.284 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:18.655 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:18.674 | HD Request # 34 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-18.
2024-09-22 20:00:18.674 | HD Request # 34 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-22 20:00:18.678 | HD Request # 34 | Bytes received: 237
2024-09-22 20:00:18.678 | HD Request # 34 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6AZ4.CME
2024-09-22 20:00:18.678 | HD Request # 34 | Completion time: 4s.
2024-09-22 20:00:18.678 | HD Request # 34 | Daily data download complete for 6AZ4.CME. Unique request ID: 34
2024-09-22 20:00:18.678 | Removing historical data download ID 34.
2024-09-22 20:00:18.678 | No download requests in the queue to start downloads for.
2024-09-22 20:00:18.694 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:18.694 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:18.694 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:19.482 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:19.482 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:19.482 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:20.183 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:20.287 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:20.287 | 6AZ4.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:20.287 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:20.942 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:21.195 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:21.195 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:21.195 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:23.455 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:23.455 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:23.455 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:23.782 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:23.819 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:24.056 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:24.056 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:24.056 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:24.876 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:30:42.220 | Chat | Message response. Chat ID: 429. Request ID: 1134626465
2024-09-22 21:15:13.971 | Chat | Message response. Chat ID: 429. Request ID: 1134626466
2024-09-22 21:16:03.033 | Chat | Message response. Chat ID: 429. Request ID: 1134626467
2024-09-22 21:35:03.454 | Chat | Message response. Chat ID: 429. Request ID: 1134626468
2024-09-22 21:53:56.745 | Chat | Message response. Chat ID: 429. Request ID: 1134626469
2024-09-22 22:00:44.240 | Chat | Message response. Chat ID: 429. Request ID: 1134626470
2024-09-22 22:27:07.203 | Chat | Message response. Chat ID: 429. Request ID: 1134626471
2024-09-22 22:41:30.527 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Creating socket. Using TLS 1.2.
2024-09-22 22:41:30.527 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | New receive buffer size: 0
2024-09-22 22:41:30.527 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Connecting to IP: 216.66.0.130.
2024-09-22 22:41:32.832 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | CloseSocket call.
2024-09-22 22:41:32.832 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Shutdown started. Waiting for graceful close.
2024-09-22 22:41:33.087 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Socket gracefully closed by remote side.
2024-09-22 22:41:33.087 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Closed.
2024-09-22 22:59:59.960 | Chat | Server has requested a logoff. Reason: Chat server is backing up
2024-09-22 22:59:59.960 | Chat | Waiting for socket receive thread to end
2024-09-22 22:59:59.960 | DTC Client socket (3) | CloseSocket call.
2024-09-22 22:59:59.960 | DTC Client socket (3) | Max send buffers used during socket life: 3
2024-09-22 22:59:59.960 | DTC Client socket (3) | Max send buffer size during socket life: 399
2024-09-22 22:59:59.960 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2024-09-22 22:59:59.960 | Chat | Disconnected from the server.
2024-09-22 22:59:59.960 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2024-09-22 23:00:01.775 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-09-22 23:00:01.775 | DTC Client socket (3) | Closed.
2024-09-22 23:00:04.960 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-22 23:00:05.103 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2024-09-22 23:00:05.103 | DTC Client socket (3) | New receive buffer size: 0
2024-09-22 23:00:05.103 | DTC Client socket (3) | Connecting to IP: 69.39.70.248.
2024-09-22 23:00:05.376 | Chat | Network connection to server complete.
2024-09-22 23:00:05.376 | Chat | Starting socket receive thread.
2024-09-22 23:00:05.376 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-22 23:00:06.196 | Chat | Setting DTC encoding to Binary VLS
2024-09-22 23:00:06.196 | Chat | Sending logon request message.
2024-09-22 23:00:19.951 | Chat | Received logon response.
2024-09-22 23:00:19.951 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-22 23:00:19.951 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-22 23:00:19.951 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-22 23:00:19.951 | Chat | Trading is not supported.
2024-09-22 23:00:19.951 | Chat | MarketDepthIsSupported: 1
2024-09-22 23:20:01.476 | Chat | Message response. Chat ID: 429. Request ID: 1134626477
2024-09-23 00:00:00.054 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-23 00:00:00.054 | Triggering next historical data download in queue.
2024-09-23 00:00:00.055 | HD Request # 35 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:00.055 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-23 00:00:00.055 | Triggering next historical data download in queue.
2024-09-23 00:00:00.056 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-23 00:00:00.056 | Triggering next historical data download in queue.
2024-09-23 00:00:00.487 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 00:00:00.487 | Triggering next historical data download in queue.
2024-09-23 00:00:00.489 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-23 00:00:00.489 | Triggering next historical data download in queue.
2024-09-23 00:00:00.489 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-23 00:00:01.029 | HD Request # 35 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:02.002 | HD Request # 35 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-23 00:00:02.002 | HD Request # 35 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-23 00:00:02.005 | HD Request # 35 | Bytes received: 242
2024-09-23 00:00:02.005 | HD Request # 35 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for NQZ4.CME
2024-09-23 00:00:02.005 | HD Request # 35 | Completion time: 2s.
2024-09-23 00:00:02.005 | HD Request # 35 | Daily data download complete for NQZ4.CME. Unique request ID: 35
2024-09-23 00:00:02.005 | Removing historical data download ID 35.
2024-09-23 00:00:02.005 | Triggering next historical data download in queue.
2024-09-23 00:00:02.006 | HD Request # 36 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:02.216 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:02.216 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:02.216 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:02.557 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:02.768 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:02.768 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:02.768 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:03.062 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:03.062 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:03.062 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:03.357 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:03.357 | HD Request # 36 | Requesting historical Daily data for GCZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:03.401 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:04.152 | HD Request # 36 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-18.
2024-09-23 00:00:04.152 | HD Request # 36 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-23 00:00:04.157 | HD Request # 36 | Bytes received: 232
2024-09-23 00:00:04.157 | HD Request # 36 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-23 00:00:04.157 | HD Request # 36 | Completion time: 2s.
2024-09-23 00:00:04.157 | HD Request # 36 | Daily data download complete for GCZ4.COMEX. Unique request ID: 36
2024-09-23 00:00:04.157 | Removing historical data download ID 36.
2024-09-23 00:00:04.157 | Triggering next historical data download in queue.
2024-09-23 00:00:04.158 | HD Request # 37 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:04.612 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:04.612 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:04.612 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:05.242 | HD Request # 37 | Requesting historical Daily data for J6Z24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:05.502 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:05.504 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:05.504 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:05.504 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:06.135 | HD Request # 37 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-18.
2024-09-23 00:00:06.135 | HD Request # 37 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-23 00:00:06.139 | HD Request # 37 | Bytes received: 274
2024-09-23 00:00:06.139 | HD Request # 37 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6JZ4.CME
2024-09-23 00:00:06.139 | HD Request # 37 | Completion time: 2s.
2024-09-23 00:00:06.139 | HD Request # 37 | Daily data download complete for 6JZ4.CME. Unique request ID: 37
2024-09-23 00:00:06.139 | Removing historical data download ID 37.
2024-09-23 00:00:06.139 | Triggering next historical data download in queue.
2024-09-23 00:00:06.140 | HD Request # 38 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:06.141 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:06.141 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:06.141 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:06.850 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:06.882 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:06.882 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:06.882 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:07.517 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:07.586 | HD Request # 38 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:07.600 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:07.980 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:07.980 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:07.980 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:08.693 | HD Request # 38 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-23 00:00:08.693 | HD Request # 38 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 00:00:08.696 | HD Request # 38 | Bytes received: 234
2024-09-23 00:00:08.696 | HD Request # 38 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-23 00:00:08.696 | HD Request # 38 | Completion time: 2s.
2024-09-23 00:00:08.696 | HD Request # 38 | Daily data download complete for ESZ4.CME. Unique request ID: 38
2024-09-23 00:00:08.696 | Removing historical data download ID 38.
2024-09-23 00:00:08.696 | Triggering next historical data download in queue.
2024-09-23 00:00:08.697 | HD Request # 39 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:08.698 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:08.698 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:08.698 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.030 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:09.031 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:09.031 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.031 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.361 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:09.362 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:09.362 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.362 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.697 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:09.698 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:09.698 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.698 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:10.410 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:10.410 | HD Request # 39 | Requesting historical Daily data for CLX24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:10.667 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:11.305 | HD Request # 39 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-18.
2024-09-23 00:00:11.305 | HD Request # 39 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-23 00:00:11.311 | HD Request # 39 | Bytes received: 217
2024-09-23 00:00:11.311 | HD Request # 39 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-23 00:00:11.311 | HD Request # 39 | Completion time: 3s.
2024-09-23 00:00:11.311 | HD Request # 39 | Daily data download complete for CLX4.NYMEX. Unique request ID: 39
2024-09-23 00:00:11.311 | Removing historical data download ID 39.
2024-09-23 00:00:11.311 | Triggering next historical data download in queue.
2024-09-23 00:00:11.311 | HD Request # 40 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:11.563 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:11.563 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:11.563 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:13.709 | HD Request # 40 | Requesting historical Daily data for A6Z24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:13.710 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:13.710 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:13.710 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:15.834 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:15.866 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:15.866 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:15.866 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:17.987 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:17.987 | HD Request # 40 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-18.
2024-09-23 00:00:17.987 | HD Request # 40 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-23 00:00:17.992 | HD Request # 40 | Bytes received: 237
2024-09-23 00:00:17.992 | HD Request # 40 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6AZ4.CME
2024-09-23 00:00:17.992 | HD Request # 40 | Completion time: 6s.
2024-09-23 00:00:17.992 | HD Request # 40 | Daily data download complete for 6AZ4.CME. Unique request ID: 40
2024-09-23 00:00:17.992 | Removing historical data download ID 40.
2024-09-23 00:00:17.992 | No download requests in the queue to start downloads for.
2024-09-23 00:00:18.319 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:18.749 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:18.749 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:18.749 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:19.457 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:19.457 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:19.457 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:20.170 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:20.202 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:20.202 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:20.202 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:20.911 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:21.136 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 01:44:41.593 | Saved Chartbook: ES.Cht. Time: 0.0584 seconds.
2024-09-23 02:07:31.434 | Chat | Message response. Chat ID: 429. Request ID: 1134626478
2024-09-23 03:15:04.407 | Chat | Message response. Chat ID: 429. Request ID: 1134626479
2024-09-23 03:19:17.660 | Chat | Message response. Chat ID: 429. Request ID: 1134626480
2024-09-23 03:38:10.857 | Chat | Message response. Chat ID: 429. Request ID: 1134626481
2024-09-23 03:46:21.166 | Chat | Message response. Chat ID: 429. Request ID: 1134626482
2024-09-23 04:00:42.762 | Chat | Message response. Chat ID: 429. Request ID: 1134626483
2024-09-23 04:31:08.020 | Chat | Message response. Chat ID: 429. Request ID: 1134626484
2024-09-23 04:34:54.487 | Chat | Message response. Chat ID: 429. Request ID: 1134626485
2024-09-23 04:45:39.613 | Chat | Message response. Chat ID: 429. Request ID: 1134626486
2024-09-23 04:45:40.109 | Chat | Message response. Chat ID: 429. Request ID: 1134626487
2024-09-23 05:10:08.019 | Chat | Message response. Chat ID: 429. Request ID: 1134626488
2024-09-23 05:37:13.686 | Chat | Message response. Chat ID: 429. Request ID: 1134626489
2024-09-23 05:48:12.957 | Chat | Message response. Chat ID: 429. Request ID: 1134626490
2024-09-23 06:41:32.488 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Creating socket. Using TLS 1.2.
2024-09-23 06:41:32.488 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | New receive buffer size: 0
2024-09-23 06:41:32.488 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Connecting to IP: 216.66.0.130.
2024-09-23 06:41:34.273 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | CloseSocket call.
2024-09-23 06:41:34.273 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Shutdown started. Waiting for graceful close.
2024-09-23 06:41:34.527 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Socket gracefully closed by remote side.
2024-09-23 06:41:34.527 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Closed.
2024-09-23 08:25:49.234 | Chat | Message response. Chat ID: 429. Request ID: 1134626491
2024-09-23 08:42:14.769 | Chat | Message response. Chat ID: 429. Request ID: 1134626492
2024-09-23 08:50:52.116 | ESZ4.CME [CBV][M] 1 Min #17 | Reloading chart.
2024-09-23 08:50:52.117 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-23 08:50:52.117 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-23 08:50:52.118 | Triggering next historical data download in queue.
2024-09-23 08:50:52.118 | ESZ4.CME [CBV][M] 1 Min #17 | Performing continuous chart historical Daily data download for symbol ESZ4.CME starting at last date in file.
2024-09-23 08:50:52.118 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 08:50:52.127 | ESZ4.CME [CBV][M] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 41, 42,
2024-09-23 08:50:52.128 | HD Request # 41 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-23 08:50:52.128 | HD Request # 41 | Download start date-time: 2024-09-23 08:50:51.000000. File last date-time: 2024-09-23 08:50:51.963002
2024-09-23 08:50:52.128 | HD Request # 41 | Using server: ds32.sierracharts.com port 10149
2024-09-23 08:50:52.129 | HD Request # 42 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 08:50:52.259 | Socket (5) | Creating socket.
2024-09-23 08:50:52.259 | Socket (5) | New receive buffer size: 0
2024-09-23 08:50:52.259 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 08:50:52.828 | HD Request # 41 | Setting DTC encoding to Binary VLS
2024-09-23 08:50:52.828 | HD Request # 41 | Sending historical data logon request message.
2024-09-23 08:50:53.203 | HD Request # 42 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 08:50:53.613 | HD Request # 41 | Requesting Intraday data. Start date-time: 2024-09-23 08:50:51. Record interval: 0. Symbol: ESZ24
2024-09-23 08:50:53.896 | HD Request # 41 | Decompressing data.
2024-09-23 08:50:54.174 | HD Request # 41 | Receiving Intraday data for ESZ4.CME starting at 2024-09-23 08:50:51.963000
2024-09-23 08:50:54.174 | Socket (5) | CloseSocket call.
2024-09-23 08:50:54.174 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 08:50:54.204 | Historical data download thread signaled to stop.
2024-09-23 08:50:54.204 | HD Request # 41 | Received 3 Intraday data records from 2024-09-23 08:50:51.963000 to 2024-09-23 08:50:51.963002 (0.0 seconds. Delay: 2.2 seconds) and wrote 0 records for ESZ4.CME
2024-09-23 08:50:54.204 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2024-09-23 12:50:51.963002
2024-09-23 08:50:54.204 | HD Request # 41 | Completion time: 2s.
2024-09-23 08:50:54.204 | HD Request # 41 | Intraday data download complete for ESZ4.CME. Unique request ID: 41
2024-09-23 08:50:54.204 | Removing historical data download ID 41.
2024-09-23 08:50:54.204 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-23 08:50:54.204 | Intraday chart data file opened for ESZ4.CME
2024-09-23 08:50:54.204 | HD Request # 41 | Enabling Intraday chart updating for symbol.
2024-09-23 08:50:54.204 | No download requests in the queue to start downloads for.
2024-09-23 08:50:54.204 | HD Request # 42 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-23 08:50:54.204 | HD Request # 42 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 08:50:54.207 | HD Request # 42 | Bytes received: 234
2024-09-23 08:50:54.207 | HD Request # 42 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-23 08:50:54.207 | HD Request # 42 | Completion time: 2s.
2024-09-23 08:50:54.207 | HD Request # 42 | Daily data download complete for ESZ4.CME. Unique request ID: 42
2024-09-23 08:50:54.207 | Removing historical data download ID 42.
2024-09-23 08:50:54.207 | No download requests in the queue to start downloads for.
2024-09-23 08:50:54.288 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 08:50:54.288 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:54.288 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:54.452 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 08:50:54.452 | Socket (5) | Closed.
2024-09-23 08:50:54.672 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 08:50:54.715 | ESZ4.CME [CBV][M] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-23 08:50:54.716 | ESZ4.CME [CBV][M] 1 Min #17 | Reloading chart.
2024-09-23 08:50:55.137 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 08:50:55.137 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:55.137 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:55.518 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 08:50:55.518 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:55.518 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:55.890 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 08:50:55.949 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 08:50:56.750 | ESZ4.CME [CBV][M] 1 Min #17 | Reloading chart.
2024-09-23 08:50:57.137 | ESZ4.CME [CBV][M] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-23 08:50:57.158 | ESZ4.CME [CBV][M] 1 Min #17 | Chart data loading complete.
2024-09-23 08:50:57.416 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-23 09:00:45.538 | Chat | Message response. Chat ID: 429. Request ID: 1134626493
2024-09-23 09:30:17.453 | ESZ4.CME[M] 1 Min #12 | Reloading chart.
2024-09-23 09:30:18.407 | ESZ4.CME[M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:03:00
2024-09-23 09:30:18.441 | ESZ4.CME[M] 1 Min #12 | Chart data loading complete.
2024-09-23 09:46:32.615 | ESZ4.CME [CBV][M] 60 Min #8 | + Error reading record for update Intraday chart. Invalid cache index
2024-09-23 10:01:22.484 | Chat | Message response. Chat ID: 429. Request ID: 1134626494
2024-09-23 10:47:16.592 | 6AZ4.CME [CBV][M] 60 Min #8 | + Error reading record for update Intraday chart. Invalid cache index
2024-09-23 11:00:12.557 | Chat | Message response. Chat ID: 429. Request ID: 1134626495
2024-09-23 11:15:07.935 | Chat | Message response. Chat ID: 429. Request ID: 1134626496
2024-09-23 11:33:38.287 | ESZ4.CME[M] 5 Min #12 | Reloading chart.
2024-09-23 11:33:39.112 | ESZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-23 11:33:39.126 | ESZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-23 12:08:59.935 | Chat | Message response. Chat ID: 429. Request ID: 1134626497
2024-09-23 14:15:55.119 | ESZ4.CME[M] 15 Min #12 | Reloading chart.
2024-09-23 14:15:56.160 | ESZ4.CME[M] 15 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-23 14:15:56.173 | ESZ4.CME[M] 15 Min #12 | Chart data loading complete.
2024-09-23 14:17:07.706 | ESZ4.CME [CBV][M] 60 Min #15 | Reloading chart.
2024-09-23 14:17:07.720 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-23 14:17:07.720 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-23 14:17:07.720 | Triggering next historical data download in queue.
2024-09-23 14:17:07.721 | ESZ4.CME [CBV][M] 60 Min #15 | Performing continuous chart historical Daily data download for symbol ESZ4.CME starting at last date in file.
2024-09-23 14:17:07.721 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 14:17:07.721 | Triggering next historical data download in queue.
2024-09-23 14:17:07.793 | ESZ4.CME [CBV][M] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 43, 44,
2024-09-23 14:17:07.794 | HD Request # 43 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-23 14:17:07.794 | HD Request # 43 | Download start date-time: 2024-09-23 14:17:08.000000. File last date-time: 2024-09-23 14:17:08.507007
2024-09-23 14:17:07.794 | HD Request # 43 | Using server: ds32.sierracharts.com port 10150
2024-09-23 14:17:07.794 | HD Request # 44 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 14:17:07.904 | Socket (5) | Creating socket.
2024-09-23 14:17:07.904 | Socket (5) | New receive buffer size: 0
2024-09-23 14:17:07.904 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 14:17:08.458 | HD Request # 43 | Setting DTC encoding to Binary VLS
2024-09-23 14:17:08.458 | HD Request # 43 | Sending historical data logon request message.
2024-09-23 14:17:08.864 | HD Request # 44 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 14:17:09.226 | HD Request # 43 | Requesting Intraday data. Start date-time: 2024-09-23 14:17:08. Record interval: 0. Symbol: ESZ24
2024-09-23 14:17:09.498 | HD Request # 43 | Decompressing data.
2024-09-23 14:17:09.781 | HD Request # 43 | Receiving Intraday data for ESZ4.CME starting at 2024-09-23 13:17:07.048000
2024-09-23 14:17:09.892 | HD Request # 44 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-23 14:17:09.892 | HD Request # 44 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 14:17:09.895 | HD Request # 44 | Bytes received: 234
2024-09-23 14:17:09.895 | HD Request # 44 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-23 14:17:09.895 | HD Request # 44 | Completion time: 2s.
2024-09-23 14:17:09.895 | HD Request # 44 | Daily data download complete for ESZ4.CME. Unique request ID: 44
2024-09-23 14:17:09.895 | Removing historical data download ID 44.
2024-09-23 14:17:09.895 | No download requests in the queue to start downloads for.
2024-09-23 14:17:10.107 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 14:17:10.107 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:10.107 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:10.476 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 14:17:10.842 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 14:17:10.842 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:10.842 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:10.862 | Socket (5) | CloseSocket call.
2024-09-23 14:17:10.862 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 14:17:11.133 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 14:17:11.133 | Socket (5) | Closed.
2024-09-23 14:17:11.166 | Historical data download thread signaled to stop.
2024-09-23 14:17:11.166 | HD Request # 43 | Timestamp of first Intraday data file record written: 2024-09-23 14:17:09.786000.
2024-09-23 14:17:11.166 | HD Request # 43 | Received 54345 Intraday data records from 2024-09-23 13:17:07.048000 to 2024-09-23 14:17:09.786001 (60.0 minutes. Delay: 1.4 seconds) and wrote 2 records for ESZ4.CME
2024-09-23 14:17:11.167 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2024-09-23 18:17:09.786001
2024-09-23 14:17:11.167 | Added 9 Time and Sales records to Intraday data file for ESZ4.CME after download.
2024-09-23 14:17:11.167 | HD Request # 43 | Completion time: 4s.
2024-09-23 14:17:11.167 | HD Request # 43 | Intraday data download complete for ESZ4.CME. Unique request ID: 43
2024-09-23 14:17:11.167 | Removing historical data download ID 43.
2024-09-23 14:17:11.167 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-23 14:17:11.167 | Intraday chart data file opened for ESZ4.CME
2024-09-23 14:17:11.167 | HD Request # 43 | Enabling Intraday chart updating for symbol.
2024-09-23 14:17:11.167 | No download requests in the queue to start downloads for.
2024-09-23 14:17:11.205 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 14:17:11.221 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 14:17:11.221 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:11.221 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:11.585 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 14:17:11.827 | ESZ4.CME [CBV][M] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-23 14:17:11.828 | ESZ4.CME [CBV][M] 60 Min #15 | Reloading chart. | Number times message added: 1
2024-09-23 14:17:13.976 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-23 14:17:43.112 | ESZ4.CME [CBV][M] 60 Min #15 | Chart data loading complete.
2024-09-23 14:41:13.859 | Denali Data Feed | Message from server: Authorization data verified.
2024-09-23 14:41:35.040 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Creating socket. Using TLS 1.2.
2024-09-23 14:41:35.040 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | New receive buffer size: 0
2024-09-23 14:41:35.040 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Connecting to IP: 216.66.0.130.
2024-09-23 14:41:37.333 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | CloseSocket call.
2024-09-23 14:41:37.333 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Shutdown started. Waiting for graceful close.
2024-09-23 14:41:37.586 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Socket gracefully closed by remote side.
2024-09-23 14:41:37.586 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Closed.
2024-09-23 16:08:37.856 | Saved Chartbook: GC.Cht. Time: 0.0529 seconds.
2024-09-23 17:45:00.006 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-23 17:45:00.006 | Triggering next historical data download in queue.
2024-09-23 17:45:00.007 | HD Request # 45 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:00.007 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-23 17:45:00.007 | Triggering next historical data download in queue.
2024-09-23 17:45:00.007 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-23 17:45:00.007 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-23 17:45:00.023 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-23 17:45:00.023 | Triggering next historical data download in queue.
2024-09-23 17:45:00.062 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 17:45:00.062 | Triggering next historical data download in queue.
2024-09-23 17:45:01.138 | HD Request # 45 | Requesting historical Daily data for GCZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:02.064 | HD Request # 45 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-18.
2024-09-23 17:45:02.064 | HD Request # 45 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-23 17:45:02.069 | HD Request # 45 | Bytes received: 291
2024-09-23 17:45:02.069 | HD Request # 45 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for GCZ4.COMEX
2024-09-23 17:45:02.069 | HD Request # 45 | Completion time: 2s.
2024-09-23 17:45:02.069 | HD Request # 45 | Daily data download complete for GCZ4.COMEX. Unique request ID: 45
2024-09-23 17:45:02.069 | Removing historical data download ID 45.
2024-09-23 17:45:02.069 | Triggering next historical data download in queue.
2024-09-23 17:45:02.070 | HD Request # 46 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:02.165 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:02.165 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:02.165 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:02.949 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:03.097 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:03.097 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:03.097 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:03.734 | HD Request # 46 | Requesting historical Daily data for A6Z24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:03.750 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:03.750 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:03.750 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:04.401 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:04.513 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:05.046 | HD Request # 46 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-18.
2024-09-23 17:45:05.047 | HD Request # 46 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-23 17:45:05.050 | HD Request # 46 | Bytes received: 298
2024-09-23 17:45:05.050 | HD Request # 46 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for 6AZ4.CME
2024-09-23 17:45:05.051 | HD Request # 46 | Completion time: 3s.
2024-09-23 17:45:05.051 | HD Request # 46 | Daily data download complete for 6AZ4.CME. Unique request ID: 46
2024-09-23 17:45:05.051 | Removing historical data download ID 46.
2024-09-23 17:45:05.051 | Triggering next historical data download in queue.
2024-09-23 17:45:05.052 | HD Request # 47 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:05.201 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:05.201 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:05.201 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:05.918 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:05.918 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:05.918 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:06.658 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:06.658 | HD Request # 47 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:06.678 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:06.678 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:06.678 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:07.412 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:07.538 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:08.003 | HD Request # 47 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-23 17:45:08.003 | HD Request # 47 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-23 17:45:08.005 | HD Request # 47 | Bytes received: 300
2024-09-23 17:45:08.005 | HD Request # 47 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for NQZ4.CME
2024-09-23 17:45:08.005 | HD Request # 47 | Completion time: 3s.
2024-09-23 17:45:08.005 | HD Request # 47 | Daily data download complete for NQZ4.CME. Unique request ID: 47
2024-09-23 17:45:08.005 | Removing historical data download ID 47.
2024-09-23 17:45:08.006 |
2024-09-23 17:45:08.006 | Triggering next historical data download in queue.
2024-09-23 17:45:08.006 | HD Request # 48 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:08.258 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:08.258 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.258 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.618 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:08.646 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:08.647 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.647 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.991 | HD Request # 48 | Requesting historical Daily data for CLX24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:08.992 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:08.992 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.992 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:09.284 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:09.358 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:09.878 | HD Request # 48 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-18.
2024-09-23 17:45:09.878 | HD Request # 48 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-23 17:45:09.884 | HD Request # 48 | Bytes received: 272
2024-09-23 17:45:09.884 | HD Request # 48 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for CLX4.NYMEX
2024-09-23 17:45:09.884 | HD Request # 48 | Completion time: 1s.
2024-09-23 17:45:09.884 | HD Request # 48 | Daily data download complete for CLX4.NYMEX. Unique request ID: 48
2024-09-23 17:45:09.884 | Removing historical data download ID 48.
2024-09-23 17:45:09.884 | Triggering next historical data download in queue.
2024-09-23 17:45:09.885 | HD Request # 49 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:10.060 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:10.060 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:10.060 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:12.425 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:12.425 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:12.425 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:14.606 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:14.606 | HD Request # 49 | Requesting historical Daily data for J6Z24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:14.624 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:14.624 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:14.624 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:16.843 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:17.285 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:17.437 | HD Request # 49 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-18.
2024-09-23 17:45:17.437 | HD Request # 49 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-23 17:45:17.441 | HD Request # 49 | Bytes received: 341
2024-09-23 17:45:17.441 | HD Request # 49 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for 6JZ4.CME
2024-09-23 17:45:17.442 | HD Request # 49 | Completion time: 8s.
2024-09-23 17:45:17.442 | HD Request # 49 | Daily data download complete for 6JZ4.CME. Unique request ID: 49
2024-09-23 17:45:17.442 | Removing historical data download ID 49.
2024-09-23 17:45:17.442 | Triggering next historical data download in queue.
2024-09-23 17:45:17.443 | HD Request # 50 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:17.450 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:17.450 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:17.450 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:18.169 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:18.169 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:18.169 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:18.911 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:18.911 | HD Request # 50 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:19.038 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:19.048 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:19.048 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:19.048 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:19.904 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:20.347 | HD Request # 50 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-23 17:45:20.347 | HD Request # 50 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 17:45:20.350 | HD Request # 50 | Bytes received: 295
2024-09-23 17:45:20.350 | HD Request # 50 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for ESZ4.CME
2024-09-23 17:45:20.350 | HD Request # 50 | Completion time: 3s.
2024-09-23 17:45:20.350 | HD Request # 50 | Daily data download complete for ESZ4.CME. Unique request ID: 50
2024-09-23 17:45:20.350 | Removing historical data download ID 50.
2024-09-23 17:45:20.350 | No download requests in the queue to start downloads for.
2024-09-23 17:45:20.496 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:20.496 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:20.496 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:20.832 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:20.833 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:20.833 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:21.178 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:21.231 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:21.232 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:21.232 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:21.232 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:21.613 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:31.293 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 18:00:31.293 | Triggering next historical data download in queue.
2024-09-23 18:00:31.294 | HD Request # 51 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:31.295 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-23 18:00:31.295 | Triggering next historical data download in queue.
2024-09-23 18:00:31.295 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-23 18:00:31.295 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-23 18:00:32.334 | HD Request # 51 | Requesting historical Daily data for ESZ24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:33.227 | HD Request # 51 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-19.
2024-09-23 18:00:33.228 | HD Request # 51 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 18:00:33.230 | HD Request # 51 | Bytes received: 233
2024-09-23 18:00:33.230 | HD Request # 51 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for ESZ4.CME
2024-09-23 18:00:33.230 | HD Request # 51 | Completion time: 2s.
2024-09-23 18:00:33.230 | HD Request # 51 | Daily data download complete for ESZ4.CME. Unique request ID: 51
2024-09-23 18:00:33.231 | Removing historical data download ID 51.
2024-09-23 18:00:33.231 | Triggering next historical data download in queue.
2024-09-23 18:00:33.231 | HD Request # 52 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:33.569 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:33.569 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:33.569 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:33.902 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-23 18:00:33.902 | Triggering next historical data download in queue.
2024-09-23 18:00:33.903 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-23 18:00:33.903 | Triggering next historical data download in queue.
2024-09-23 18:00:33.955 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:33.956 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:33.956 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:33.956 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:34.286 | HD Request # 52 | Requesting historical Daily data for A6Z24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:34.302 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:34.302 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:34.302 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:34.645 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:34.700 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:35.233 | HD Request # 52 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-19.
2024-09-23 18:00:35.234 | HD Request # 52 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-23 18:00:35.238 | HD Request # 52 | Bytes received: 242
2024-09-23 18:00:35.238 | HD Request # 52 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for 6AZ4.CME
2024-09-23 18:00:35.238 | HD Request # 52 | Completion time: 2s.
2024-09-23 18:00:35.238 | HD Request # 52 | Daily data download complete for 6AZ4.CME. Unique request ID: 52
2024-09-23 18:00:35.238 | Removing historical data download ID 52.
2024-09-23 18:00:35.239 |
2024-09-23 18:00:35.239 | Triggering next historical data download in queue.
2024-09-23 18:00:35.239 | HD Request # 53 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:35.379 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:35.379 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:35.379 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:36.088 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:36.088 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:36.088 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:36.834 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:36.834 | HD Request # 53 | Requesting historical Daily data for NQZ24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:36.964 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:37.169 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:37.169 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:37.169 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:37.882 | HD Request # 53 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-19.
2024-09-23 18:00:37.882 | HD Request # 53 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-23 18:00:37.885 | HD Request # 53 | Bytes received: 237
2024-09-23 18:00:37.885 | HD Request # 53 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for NQZ4.CME
2024-09-23 18:00:37.885 | HD Request # 53 | Completion time: 2s.
2024-09-23 18:00:37.885 | HD Request # 53 | Daily data download complete for NQZ4.CME. Unique request ID: 53
2024-09-23 18:00:37.885 | Removing historical data download ID 53.
2024-09-23 18:00:37.885 | Triggering next historical data download in queue.
2024-09-23 18:00:37.886 | HD Request # 54 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:38.019 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:38.402 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:38.402 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:38.402 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:38.701 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:38.701 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:38.701 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:39.013 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:39.013 | HD Request # 54 | Requesting historical Daily data for GCZ24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:39.070 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:39.071 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:39.071 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:39.071 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:39.419 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:39.968 | HD Request # 54 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-19.
2024-09-23 18:00:39.969 | HD Request # 54 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-23 18:00:39.973 | HD Request # 54 | Bytes received: 232
2024-09-23 18:00:39.973 | HD Request # 54 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-23 18:00:39.973 | HD Request # 54 | Completion time: 2s.
2024-09-23 18:00:39.973 | HD Request # 54 | Daily data download complete for GCZ4.COMEX. Unique request ID: 54
2024-09-23 18:00:39.973 | Removing historical data download ID 54.
2024-09-23 18:00:39.973 | Triggering next historical data download in queue.
2024-09-23 18:00:39.974 | HD Request # 55 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:40.113 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:40.113 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:40.113 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:40.753 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:40.753 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:40.753 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:41.421 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:41.422 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:41.422 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:41.422 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:42.085 | HD Request # 55 | Requesting historical Daily data for J6Z24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:42.087 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:42.209 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:43.021 | HD Request # 55 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-19.
2024-09-23 18:00:43.021 | HD Request # 55 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-23 18:00:43.026 | HD Request # 55 | Bytes received: 273
2024-09-23 18:00:43.026 | HD Request # 55 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for 6JZ4.CME
2024-09-23 18:00:43.026 | HD Request # 55 | Completion time: 4s.
2024-09-23 18:00:43.026 | HD Request # 55 | Daily data download complete for 6JZ4.CME. Unique request ID: 55
2024-09-23 18:00:43.026 | Removing historical data download ID 55.
2024-09-23 18:00:43.026 | Triggering next historical data download in queue.
2024-09-23 18:00:43.027 | HD Request # 56 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:43.386 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:43.386 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:43.386 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:44.099 | HD Request # 56 | Requesting historical Daily data for CLX24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:44.100 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:44.100 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:44.100 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:44.842 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:44.895 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:44.895 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:44.895 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:45.625 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:45.625 | HD Request # 56 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-19.
2024-09-23 18:00:45.625 | HD Request # 56 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-23 18:00:45.633 | HD Request # 56 | Bytes received: 217
2024-09-23 18:00:45.633 | HD Request # 56 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-23 18:00:45.633 | HD Request # 56 | Completion time: 2s.
2024-09-23 18:00:45.633 | HD Request # 56 | Daily data download complete for CLX4.NYMEX. Unique request ID: 56
2024-09-23 18:00:45.633 | Removing historical data download ID 56.
2024-09-23 18:00:45.633 | No download requests in the queue to start downloads for.
2024-09-23 18:00:45.923 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:45.924 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:45.924 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:45.924 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:48.492 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:48.657 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:48.657 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:48.657 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:50.785 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:50.785 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:50.785 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:53.022 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:53.477 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:09:15.575 | Chat | Message response. Chat ID: 429. Request ID: 1134626498
2024-09-23 19:25:38.691 | Chat | Message response. Chat ID: 429. Request ID: 1134626499
2024-09-23 19:41:19.295 | SC Data with Depth | Message from server: Authorization data verified.
2024-09-23 20:37:05.538 | Chat | Message response. Chat ID: 429. Request ID: 1134626500
2024-09-23 21:03:57.849 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-23 21:03:57.849 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-23 21:03:57.850 | DTC Client socket (2) | CloseSocket call.
2024-09-23 21:03:57.850 | DTC Client socket (2) | Max send buffers used during socket life: 4
2024-09-23 21:03:57.850 | DTC Client socket (2) | Max send buffer size during socket life: 407
2024-09-23 21:03:57.850 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-23 21:03:57.850 | DTC Client socket (2) | Closed.
2024-09-23 21:03:57.850 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-23 21:03:57.850 | DTC Client socket (0) | CloseSocket call.
2024-09-23 21:03:57.850 | Denali Data Feed | Disconnected from the server.
2024-09-23 21:03:57.850 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-23 21:04:00.837 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-23 21:04:00.960 | DTC Client socket (2) | Creating socket.
2024-09-23 21:04:00.960 | DTC Client socket (2) | New receive buffer size: 0
2024-09-23 21:04:00.960 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-23 21:04:16.147 | Denali Data Feed | Network connection to server complete.
2024-09-23 21:04:16.147 | Denali Data Feed | Starting socket receive thread.
2024-09-23 21:04:16.147 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-23 21:04:16.328 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-23 21:04:16.328 | Denali Data Feed | Sending logon request message.
2024-09-23 21:04:27.658 | Denali Data Feed | Received logon response.
2024-09-23 21:04:27.658 | Denali Data Feed | Server Name: RealTimeServer.
2024-09-23 21:04:27.658 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-23 21:04:27.658 | Denali Data Feed | Logon error received from server: Timed out while checking for maximum connections.
2024-09-23 21:04:27.658 | Denali Data Feed | Failed connections: 1
2024-09-23 21:04:27.658 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-23 21:04:27.658 | DTC Client socket (2) | CloseSocket call.
2024-09-23 21:04:27.658 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:27.658 | Denali Data Feed | Disconnected from the server.
2024-09-23 21:04:27.658 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-23 21:04:27.812 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-23 21:04:27.812 | DTC Client socket (2) | Closed.
2024-09-23 21:04:30.655 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-23 21:04:30.655 | DTC Client socket (2) | Creating socket.
2024-09-23 21:04:30.655 | DTC Client socket (2) | New receive buffer size: 0
2024-09-23 21:04:30.655 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-23 21:04:30.809 | Denali Data Feed | Network connection to server complete.
2024-09-23 21:04:30.809 | Denali Data Feed | Starting socket receive thread.
2024-09-23 21:04:30.809 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-23 21:04:31.005 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-23 21:04:31.005 | Denali Data Feed | Sending logon request message.
2024-09-23 21:04:31.676 | Denali Data Feed | Received logon response.
2024-09-23 21:04:31.676 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-23 21:04:31.676 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-23 21:04:31.676 | Denali Data Feed | Successfully connected.
2024-09-23 21:04:31.676 | Denali Data Feed | Trading is not supported.
2024-09-23 21:04:31.676 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-23 21:04:31.676 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Triggering next historical data download in queue.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: 6AZ4.CME -> 6AZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: 6JZ4.CME -> 6JZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: CLX4.NYMEX -> CLX24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ4.CME -> ESZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: M6AZ4.CME -> M6AZ24
2024-09-23 21:04:31.676 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MCLU4.NYMEX -> MCLU24
2024-09-23 21:04:31.676 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ4.CME -> MESZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MGCZ4.COMEX -> MGCZ24
2024-09-23 21:04:31.676 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MJYZ4.CME -> MJYZ24
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-23 21:04:31.677 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-23 21:04:31.677 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.677 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ4.CME -> MNQZ24. Market Depth data restarted.
2024-09-23 21:04:31.677 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-23 21:04:31.677 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.677 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2024-09-23 21:04:31.677 | HD Request # 57 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-23 21:04:31.677 | HD Request # 57 | Download start date-time: 2024-09-23 21:03:31.000000. File last date-time: 2024-09-23 21:03:31.240004
2024-09-23 21:04:31.677 | HD Request # 57 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:31.819 | Socket (5) | Creating socket.
2024-09-23 21:04:31.819 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:31.819 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-23 21:04:32.385 | HD Request # 57 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:32.385 | HD Request # 57 | Sending historical data logon request message.
2024-09-23 21:04:33.164 | HD Request # 57 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:31. Record interval: 0. Symbol: 6AZ24
2024-09-23 21:04:33.443 | HD Request # 57 | Decompressing data.
2024-09-23 21:04:33.721 | HD Request # 57 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-23 21:03:31.240000
2024-09-23 21:04:33.722 | Socket (5) | CloseSocket call.
2024-09-23 21:04:33.722 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:33.723 | Historical data download thread signaled to stop.
2024-09-23 21:04:33.723 | HD Request # 57 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:45.441000.
2024-09-23 21:04:33.723 | HD Request # 57 | Received 12 Intraday data records from 2024-09-23 21:03:31.240000 to 2024-09-23 21:04:33.084001 (61.8 seconds. Delay: 0.6 seconds) and wrote 7 records for 6AZ4.CME
2024-09-23 21:04:33.723 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:33.084001
2024-09-23 21:04:33.723 | HD Request # 57 | Completion time: 2s.
2024-09-23 21:04:33.723 | HD Request # 57 | Intraday data download complete for 6AZ4.CME. Unique request ID: 57
2024-09-23 21:04:33.723 | Removing historical data download ID 57.
2024-09-23 21:04:33.723 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-23 21:04:33.723 | Intraday chart data file opened for 6AZ4.CME
2024-09-23 21:04:33.723 | HD Request # 57 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:33.723 | Triggering next historical data download in queue.
2024-09-23 21:04:33.723 | HD Request # 58 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-23 21:04:33.724 | HD Request # 58 | Download start date-time: 2024-09-23 21:03:31.000000. File last date-time: 2024-09-23 21:03:31.473000
2024-09-23 21:04:33.724 | HD Request # 58 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:33.724 | Socket (6) | Creating socket.
2024-09-23 21:04:33.724 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:33.724 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:34.001 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:34.001 | Socket (5) | Closed.
2024-09-23 21:04:34.278 | HD Request # 58 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:34.278 | HD Request # 58 | Sending historical data logon request message.
2024-09-23 21:04:35.041 | HD Request # 58 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:31. Record interval: 0. Symbol: 6JZ24
2024-09-23 21:04:35.315 | HD Request # 58 | Decompressing data.
2024-09-23 21:04:35.587 | HD Request # 58 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-23 21:03:31.473000
2024-09-23 21:04:35.588 | Socket (6) | CloseSocket call.
2024-09-23 21:04:35.588 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:35.597 | Historical data download thread signaled to stop.
2024-09-23 21:04:35.597 | HD Request # 58 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:34.091000.
2024-09-23 21:04:35.597 | HD Request # 58 | Received 31 Intraday data records from 2024-09-23 21:03:31.473000 to 2024-09-23 21:04:31.434000 (60.0 seconds. Delay: 4.2 seconds) and wrote 30 records for 6JZ4.CME
2024-09-23 21:04:35.598 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:31.434000
2024-09-23 21:04:35.598 | HD Request # 58 | Completion time: 2s.
2024-09-23 21:04:35.598 | HD Request # 58 | Intraday data download complete for 6JZ4.CME. Unique request ID: 58
2024-09-23 21:04:35.598 | Removing historical data download ID 58.
2024-09-23 21:04:35.598 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-23 21:04:35.598 | Intraday chart data file opened for 6JZ4.CME
2024-09-23 21:04:35.598 | HD Request # 58 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:35.598 | Triggering next historical data download in queue.
2024-09-23 21:04:35.598 | HD Request # 59 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-23 21:04:35.598 | HD Request # 59 | Download start date-time: 2024-09-23 21:03:33.000000. File last date-time: 2024-09-23 21:03:33.303001
2024-09-23 21:04:35.598 | HD Request # 59 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:35.598 | Socket (5) | Creating socket.
2024-09-23 21:04:35.598 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:35.598 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:35.861 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:35.861 | Socket (6) | Closed.
2024-09-23 21:04:36.163 | HD Request # 59 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:36.163 | HD Request # 59 | Sending historical data logon request message.
2024-09-23 21:04:36.441 | HD Request # 59 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:33. Record interval: 0. Symbol: CLX24
2024-09-23 21:04:36.720 | HD Request # 59 | Decompressing data.
2024-09-23 21:04:36.998 | HD Request # 59 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-23 21:03:33.303000
2024-09-23 21:04:36.998 | Socket (5) | CloseSocket call.
2024-09-23 21:04:36.998 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:36.998 | Historical data download thread signaled to stop.
2024-09-23 21:04:36.998 | HD Request # 59 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:33.854000.
2024-09-23 21:04:36.998 | HD Request # 59 | Received 45 Intraday data records from 2024-09-23 21:03:33.303000 to 2024-09-23 21:04:35.184000 (61.9 seconds. Delay: 1.8 seconds) and wrote 43 records for CLX4.NYMEX
2024-09-23 21:04:36.999 | HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:35.184000
2024-09-23 21:04:36.999 | HD Request # 59 | Completion time: 1s.
2024-09-23 21:04:36.999 | HD Request # 59 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 59
2024-09-23 21:04:36.999 | Removing historical data download ID 59.
2024-09-23 21:04:36.999 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-23 21:04:36.999 | Intraday chart data file opened for CLX4.NYMEX
2024-09-23 21:04:36.999 | HD Request # 59 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:36.999 | Triggering next historical data download in queue.
2024-09-23 21:04:36.999 | HD Request # 60 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-23 21:04:37.000 | HD Request # 60 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-23 21:04:37.000 | HD Request # 60 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:37.000 | Socket (6) | Creating socket.
2024-09-23 21:04:37.000 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:37.000 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:37.276 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:37.276 | Socket (5) | Closed.
2024-09-23 21:04:37.571 | HD Request # 60 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:37.571 | HD Request # 60 | Sending historical data logon request message.
2024-09-23 21:04:37.852 | HD Request # 60 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-23 21:04:38.133 | HD Request # 60 | Decompressing data.
2024-09-23 21:04:38.414 | HD Request # 60 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-23 21:04:38.414 | Socket (6) | CloseSocket call.
2024-09-23 21:04:38.414 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:38.430 | Historical data download thread signaled to stop.
2024-09-23 21:04:38.430 | HD Request # 60 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 3.5 days) and wrote 0 records for ESU4.CME
2024-09-23 21:04:38.430 | HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-23 21:04:38.430 | HD Request # 60 | Completion time: 2s.
2024-09-23 21:04:38.430 | HD Request # 60 | Intraday data download complete for ESU4.CME. Unique request ID: 60
2024-09-23 21:04:38.430 | Removing historical data download ID 60.
2024-09-23 21:04:38.430 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-23 21:04:38.430 | Intraday chart data file opened for ESU4.CME
2024-09-23 21:04:38.430 | HD Request # 60 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:38.430 | Triggering next historical data download in queue.
2024-09-23 21:04:38.430 | HD Request # 61 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-23 21:04:38.430 | HD Request # 61 | Download start date-time: 2024-09-23 21:03:32.000000. File last date-time: 2024-09-23 21:03:32.925000
2024-09-23 21:04:38.430 | HD Request # 61 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:38.430 | Socket (5) | Creating socket.
2024-09-23 21:04:38.430 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:38.430 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:38.462 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\CLX4.NYMEX.scid. Thread ID: 3296
2024-09-23 21:04:38.694 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:38.694 | Socket (6) | Closed.
2024-09-23 21:04:38.986 | HD Request # 61 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:38.986 | HD Request # 61 | Sending historical data logon request message.
2024-09-23 21:04:39.257 | HD Request # 61 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:32. Record interval: 0. Symbol: ESZ24
2024-09-23 21:04:39.529 | HD Request # 61 | Decompressing data.
2024-09-23 21:04:39.801 | HD Request # 61 | Receiving Intraday data for ESZ4.CME starting at 2024-09-23 21:03:32.925000
2024-09-23 21:04:39.801 | Socket (5) | CloseSocket call.
2024-09-23 21:04:39.801 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:39.806 | Historical data download thread signaled to stop.
2024-09-23 21:04:39.807 | HD Request # 61 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:37.095000.
2024-09-23 21:04:39.807 | HD Request # 61 | Received 50 Intraday data records from 2024-09-23 21:03:32.925000 to 2024-09-23 21:04:31.857001 (58.9 seconds. Delay: 8.0 seconds) and wrote 49 records for ESZ4.CME
2024-09-23 21:04:39.807 | HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:31.857001
2024-09-23 21:04:39.807 | Added 2 Time and Sales records to Intraday data file for ESZ4.CME after download.
2024-09-23 21:04:39.807 | HD Request # 61 | Completion time: 1s.
2024-09-23 21:04:39.807 | HD Request # 61 | Intraday data download complete for ESZ4.CME. Unique request ID: 61
2024-09-23 21:04:39.807 | Removing historical data download ID 61.
2024-09-23 21:04:39.807 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-23 21:04:39.807 | Intraday chart data file opened for ESZ4.CME
2024-09-23 21:04:39.807 | HD Request # 61 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:39.807 | Triggering next historical data download in queue.
2024-09-23 21:04:39.807 | HD Request # 62 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-23 21:04:39.807 | HD Request # 62 | Download start date-time: 2024-09-23 21:03:30.000000. File last date-time: 2024-09-23 21:03:30.568001
2024-09-23 21:04:39.807 | HD Request # 62 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:39.807 | Socket (6) | Creating socket.
2024-09-23 21:04:39.807 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:39.807 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:40.073 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:40.073 | Socket (5) | Closed.
2024-09-23 21:04:40.363 | HD Request # 62 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:40.363 | HD Request # 62 | Sending historical data logon request message.
2024-09-23 21:04:40.636 | HD Request # 62 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:30. Record interval: 0. Symbol: GCZ24
2024-09-23 21:04:40.909 | HD Request # 62 | Decompressing data.
2024-09-23 21:04:41.182 | HD Request # 62 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-23 21:03:30.568000
2024-09-23 21:04:41.183 | Socket (6) | CloseSocket call.
2024-09-23 21:04:41.183 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:41.246 | Historical data download thread signaled to stop.
2024-09-23 21:04:41.246 | HD Request # 62 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:36.132000.
2024-09-23 21:04:41.246 | HD Request # 62 | Received 46 Intraday data records from 2024-09-23 21:03:30.568000 to 2024-09-23 21:04:31.896000 (61.3 seconds. Delay: 9.4 seconds) and wrote 44 records for GCZ4.COMEX
2024-09-23 21:04:41.247 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:31.896000
2024-09-23 21:04:41.247 | HD Request # 62 | Completion time: 2s.
2024-09-23 21:04:41.247 | HD Request # 62 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 62
2024-09-23 21:04:41.247 | Removing historical data download ID 62.
2024-09-23 21:04:41.247 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-23 21:04:41.247 | Intraday chart data file opened for GCZ4.COMEX
2024-09-23 21:04:41.247 | HD Request # 62 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:41.247 | Triggering next historical data download in queue.
2024-09-23 21:04:41.247 | HD Request # 63 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-23 21:04:41.247 | HD Request # 63 | Download start date-time: 2024-09-23 21:03:10.000000. File last date-time: 2024-09-23 21:03:10.277001
2024-09-23 21:04:41.247 | HD Request # 63 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:41.247 | Socket (5) | Creating socket.
2024-09-23 21:04:41.247 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:41.247 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:41.455 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:41.455 | Socket (6) | Closed.
2024-09-23 21:04:41.804 | HD Request # 63 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:41.804 | HD Request # 63 | Sending historical data logon request message.
2024-09-23 21:04:42.078 | HD Request # 63 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:10. Record interval: 0. Symbol: M6AZ24
2024-09-23 21:04:42.351 | HD Request # 63 | Decompressing data.
2024-09-23 21:04:42.624 | HD Request # 63 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-23 21:03:10.277000
2024-09-23 21:04:42.625 | Socket (5) | CloseSocket call.
2024-09-23 21:04:42.625 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:42.625 | Historical data download thread signaled to stop.
2024-09-23 21:04:42.625 | HD Request # 63 | Timestamp of first Intraday data file record written: 2024-09-23 21:04:19.280000.
2024-09-23 21:04:42.625 | HD Request # 63 | Received 3 Intraday data records from 2024-09-23 21:03:10.277000 to 2024-09-23 21:04:19.280000 (69.0 seconds. Delay: 23.3 seconds) and wrote 1 record for M6AZ4.CME
2024-09-23 21:04:42.626 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:19.280000
2024-09-23 21:04:42.626 | HD Request # 63 | Completion time: 1s.
2024-09-23 21:04:42.626 | HD Request # 63 | Intraday data download complete for M6AZ4.CME. Unique request ID: 63
2024-09-23 21:04:42.626 | Removing historical data download ID 63.
2024-09-23 21:04:42.626 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-23 21:04:42.626 | Intraday chart data file opened for M6AZ4.CME
2024-09-23 21:04:42.626 | HD Request # 63 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:42.626 | Triggering next historical data download in queue.
2024-09-23 21:04:42.626 | HD Request # 64 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-23 21:04:42.626 | HD Request # 64 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-23 21:04:42.626 | HD Request # 64 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:42.626 | Socket (6) | Creating socket.
2024-09-23 21:04:42.626 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:42.626 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:42.898 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:42.898 | Socket (5) | Closed.
2024-09-23 21:04:43.176 | HD Request # 64 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:43.176 | HD Request # 64 | Sending historical data logon request message.
2024-09-23 21:04:43.449 | HD Request # 64 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-23 21:04:43.526 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:43.526 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCZ4.COMEX.scid. Thread ID: 3296
2024-09-23 21:04:43.721 | HD Request # 64 | Decompressing data.
2024-09-23 21:04:43.993 | HD Request # 64 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-23 21:04:43.993 | Socket (6) | CloseSocket call.
2024-09-23 21:04:43.993 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:44.167 | Historical data download thread signaled to stop.
2024-09-23 21:04:44.167 | HD Request # 64 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 35.3 days) and wrote 0 records for MCLU4.NYMEX
2024-09-23 21:04:44.168 | HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-23 21:04:44.168 | HD Request # 64 | Completion time: 2s.
2024-09-23 21:04:44.168 | HD Request # 64 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 64
2024-09-23 21:04:44.168 | Removing historical data download ID 64.
2024-09-23 21:04:44.168 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-23 21:04:44.168 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-23 21:04:44.168 | HD Request # 64 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:44.168 | Triggering next historical data download in queue.
2024-09-23 21:04:44.168 | HD Request # 65 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-23 21:04:44.168 | HD Request # 65 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-23 21:04:44.168 | HD Request # 65 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:44.168 | Socket (5) | Creating socket.
2024-09-23 21:04:44.168 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:44.168 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:44.264 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:44.265 | Socket (6) | Closed.
2024-09-23 21:04:44.725 | HD Request # 65 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:44.725 | HD Request # 65 | Sending historical data logon request message.
2024-09-23 21:04:44.997 | HD Request # 65 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-23 21:04:45.269 | HD Request # 65 | Decompressing data.
2024-09-23 21:04:45.540 | HD Request # 65 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-23 21:04:45.540 | Socket (5) | CloseSocket call.
2024-09-23 21:04:45.541 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:45.557 | Historical data download thread signaled to stop.
2024-09-23 21:04:45.557 | HD Request # 65 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 3.5 days) and wrote 0 records for MESU4.CME
2024-09-23 21:04:45.557 | HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-23 21:04:45.557 | HD Request # 65 | Completion time: 1s.
2024-09-23 21:04:45.557 | HD Request # 65 | Intraday data download complete for MESU4.CME. Unique request ID: 65
2024-09-23 21:04:45.557 | Removing historical data download ID 65.
2024-09-23 21:04:45.557 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-23 21:04:45.557 | Intraday chart data file opened for MESU4.CME
2024-09-23 21:04:45.557 | HD Request # 65 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:45.557 | Triggering next historical data download in queue.
2024-09-23 21:04:45.557 | HD Request # 66 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-23 21:04:45.557 | HD Request # 66 | Download start date-time: 2024-09-23 21:03:31.000000. File last date-time: 2024-09-23 21:03:31.368002
2024-09-23 21:04:45.557 | HD Request # 66 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:45.557 | Socket (6) | Creating socket.
2024-09-23 21:04:45.557 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:45.557 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:45.813 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:45.813 | Socket (5) | Closed.
2024-09-23 21:04:46.110 | HD Request # 66 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:46.110 | HD Request # 66 | Sending historical data logon request message.
2024-09-23 21:04:46.380 | HD Request # 66 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:31. Record interval: 0. Symbol: MESZ24
2024-09-23 21:04:46.652 | HD Request # 66 | Decompressing data.
2024-09-23 21:04:46.922 | HD Request # 66 | Receiving Intraday data for MESZ4.CME starting at 2024-09-23 21:03:31.368000
2024-09-23 21:04:46.923 | Socket (6) | CloseSocket call.
2024-09-23 21:04:46.923 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:46.928 | Historical data download thread signaled to stop.
2024-09-23 21:04:46.928 | HD Request # 66 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:34.258000.
2024-09-23 21:04:46.928 | HD Request # 66 | Received 72 Intraday data records from 2024-09-23 21:03:31.368000 to 2024-09-23 21:04:44.104000 (72.7 seconds. Delay: 2.8 seconds) and wrote 69 records for MESZ4.CME
2024-09-23 21:04:46.928 | HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:44.104000
2024-09-23 21:04:46.928 | Added 1 Time and Sales records to Intraday data file for MESZ4.CME after download.
2024-09-23 21:04:46.928 | HD Request # 66 | Completion time: 1s.
2024-09-23 21:04:46.928 | HD Request # 66 | Intraday data download complete for MESZ4.CME. Unique request ID: 66
2024-09-23 21:04:46.928 | Removing historical data download ID 66.
2024-09-23 21:04:46.928 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-23 21:04:46.928 | Intraday chart data file opened for MESZ4.CME
2024-09-23 21:04:46.928 | HD Request # 66 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:46.928 | Triggering next historical data download in queue.
2024-09-23 21:04:46.928 | HD Request # 67 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-23 21:04:46.929 | HD Request # 67 | Download start date-time: 2024-09-23 21:03:30.000000. File last date-time: 2024-09-23 21:03:30.568004
2024-09-23 21:04:46.929 | HD Request # 67 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:46.929 | Socket (5) | Creating socket.
2024-09-23 21:04:46.929 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:46.929 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:47.195 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:47.195 | Socket (6) | Closed.
2024-09-23 21:04:47.477 | HD Request # 67 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:47.477 | HD Request # 67 | Sending historical data logon request message.
2024-09-23 21:04:47.746 | HD Request # 67 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:30. Record interval: 0. Symbol: MGCZ24
2024-09-23 21:04:48.015 | HD Request # 67 | Decompressing data.
2024-09-23 21:04:48.283 | HD Request # 67 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-23 21:03:30.568000
2024-09-23 21:04:48.284 | Socket (5) | CloseSocket call.
2024-09-23 21:04:48.284 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:48.306 | Historical data download thread signaled to stop.
2024-09-23 21:04:48.306 | HD Request # 67 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:36.132000.
2024-09-23 21:04:48.306 | HD Request # 67 | Received 42 Intraday data records from 2024-09-23 21:03:30.568000 to 2024-09-23 21:04:43.822000 (73.3 seconds. Delay: 4.5 seconds) and wrote 37 records for MGCZ4.COMEX
2024-09-23 21:04:48.307 | HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:43.822000
2024-09-23 21:04:48.307 | Added 1 Time and Sales records to Intraday data file for MGCZ4.COMEX after download.
2024-09-23 21:04:48.307 | HD Request # 67 | Completion time: 2s.
2024-09-23 21:04:48.307 | HD Request # 67 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 67
2024-09-23 21:04:48.307 | Removing historical data download ID 67.
2024-09-23 21:04:48.307 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-23 21:04:48.307 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-23 21:04:48.307 | HD Request # 67 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:48.307 | Triggering next historical data download in queue.
2024-09-23 21:04:48.307 | HD Request # 68 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-23 21:04:48.307 | HD Request # 68 | Download start date-time: 2024-09-23 21:01:51.000000. File last date-time: 2024-09-23 21:01:51.459000
2024-09-23 21:04:48.307 | HD Request # 68 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:48.307 | Socket (6) | Creating socket.
2024-09-23 21:04:48.307 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:48.307 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:48.552 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:48.553 | Socket (5) | Closed.
2024-09-23 21:04:48.574 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:48.574 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:48.574 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:48.575 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6JZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:48.862 | HD Request # 68 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:48.862 | HD Request # 68 | Sending historical data logon request message.
2024-09-23 21:04:49.136 | HD Request # 68 | Requesting Intraday data. Start date-time: 2024-09-23 21:01:51. Record interval: 0. Symbol: MJYZ24
2024-09-23 21:04:49.411 | HD Request # 68 | Decompressing data.
2024-09-23 21:04:49.684 | HD Request # 68 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-23 21:01:51.459000
2024-09-23 21:04:49.685 | Socket (6) | CloseSocket call.
2024-09-23 21:04:49.685 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:49.691 | Historical data download thread signaled to stop.
2024-09-23 21:04:49.692 | HD Request # 68 | Received 1 Intraday data record from 2024-09-23 21:01:51.459000 to 2024-09-23 21:01:51.459000 (0.0 seconds. Delay: 3.0 minutes) and wrote 0 records for MJYZ4.CME
2024-09-23 21:04:49.692 | HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:01:51.459000
2024-09-23 21:04:49.692 | HD Request # 68 | Completion time: 1s.
2024-09-23 21:04:49.692 | HD Request # 68 | Intraday data download complete for MJYZ4.CME. Unique request ID: 68
2024-09-23 21:04:49.692 | Removing historical data download ID 68.
2024-09-23 21:04:49.692 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-23 21:04:49.692 | Intraday chart data file opened for MJYZ4.CME
2024-09-23 21:04:49.692 | HD Request # 68 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:49.692 | Triggering next historical data download in queue.
2024-09-23 21:04:49.692 | HD Request # 69 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-23 21:04:49.692 | HD Request # 69 | Download start date-time: 2024-09-23 21:03:33.000000. File last date-time: 2024-09-23 21:03:33.771000
2024-09-23 21:04:49.692 | HD Request # 69 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:49.692 | Socket (5) | Creating socket.
2024-09-23 21:04:49.692 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:49.692 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:49.959 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:49.959 | Socket (6) | Closed.
2024-09-23 21:04:50.246 | HD Request # 69 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:50.246 | HD Request # 69 | Sending historical data logon request message.
2024-09-23 21:04:50.517 | HD Request # 69 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:33. Record interval: 0. Symbol: MNQZ24
2024-09-23 21:04:50.788 | HD Request # 69 | Decompressing data.
2024-09-23 21:04:51.059 | HD Request # 69 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-23 21:03:33.065000
2024-09-23 21:04:51.060 | Socket (5) | CloseSocket call.
2024-09-23 21:04:51.060 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:51.156 | Historical data download thread signaled to stop.
2024-09-23 21:04:51.156 | HD Request # 69 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:34.958000.
2024-09-23 21:04:51.156 | HD Request # 69 | Received 235 Intraday data records from 2024-09-23 21:03:33.065000 to 2024-09-23 21:04:48.829000 (75.8 seconds. Delay: 2.3 seconds) and wrote 233 records for MNQZ4.CME
2024-09-23 21:04:51.156 | HD Request # 69 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:48.829000
2024-09-23 21:04:51.156 | Added 68 Time and Sales records to Intraday data file for MNQZ4.CME after download.
2024-09-23 21:04:51.157 | HD Request # 69 | Completion time: 2s.
2024-09-23 21:04:51.157 | HD Request # 69 | Intraday data download complete for MNQZ4.CME. Unique request ID: 69
2024-09-23 21:04:51.157 | Removing historical data download ID 69.
2024-09-23 21:04:51.157 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-23 21:04:51.157 | Intraday chart data file opened for MNQZ4.CME
2024-09-23 21:04:51.157 | HD Request # 69 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:51.157 | Triggering next historical data download in queue.
2024-09-23 21:04:51.157 | HD Request # 70 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-23 21:04:51.157 | HD Request # 70 | Download start date-time: 2024-09-23 21:03:32.000000. File last date-time: 2024-09-23 21:03:32.830000
2024-09-23 21:04:51.157 | HD Request # 70 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:51.157 | Socket (6) | Creating socket.
2024-09-23 21:04:51.157 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:51.157 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:51.330 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:51.330 | Socket (5) | Closed.
2024-09-23 21:04:51.706 | HD Request # 70 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:51.706 | HD Request # 70 | Sending historical data logon request message.
2024-09-23 21:04:51.981 | HD Request # 70 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:32. Record interval: 0. Symbol: NQZ24
2024-09-23 21:04:52.250 | HD Request # 70 | Decompressing data.
2024-09-23 21:04:52.520 | HD Request # 70 | Receiving Intraday data for NQZ4.CME starting at 2024-09-23 21:03:32.830000
2024-09-23 21:04:52.520 | Socket (6) | CloseSocket call.
2024-09-23 21:04:52.521 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:52.677 | Historical data download thread signaled to stop.
2024-09-23 21:04:52.677 | HD Request # 70 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:36.051000.
2024-09-23 21:04:52.678 | HD Request # 70 | Received 71 Intraday data records from 2024-09-23 21:03:32.830000 to 2024-09-23 21:04:48.829000 (76.0 seconds. Delay: 3.8 seconds) and wrote 70 records for NQZ4.CME
2024-09-23 21:04:52.678 | HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:48.829000
2024-09-23 21:04:52.678 | Added 14 Time and Sales records to Intraday data file for NQZ4.CME after download.
2024-09-23 21:04:52.678 | HD Request # 70 | Completion time: 1s.
2024-09-23 21:04:52.678 | HD Request # 70 | Intraday data download complete for NQZ4.CME. Unique request ID: 70
2024-09-23 21:04:52.678 | Removing historical data download ID 70.
2024-09-23 21:04:52.678 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-23 21:04:52.678 | Intraday chart data file opened for NQZ4.CME
2024-09-23 21:04:52.678 | HD Request # 70 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:52.678 | No download requests in the queue to start downloads for.
2024-09-23 21:04:52.790 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:52.790 | Socket (6) | Closed.
2024-09-23 21:04:53.619 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:53.619 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:53.620 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-23 21:12:07.367 | Chat | Message response. Chat ID: 429. Request ID: 1134626501
2024-09-23 21:12:38.651 | Chat | Message response. Chat ID: 429. Request ID: 1134626502
2024-09-23 21:16:39.836 | Chat | Message response. Chat ID: 429. Request ID: 1134626503
2024-09-23 21:20:40.943 | Chat | Message response. Chat ID: 429. Request ID: 1134626504
2024-09-23 21:31:05.900 | Chat | Message response. Chat ID: 429. Request ID: 1134626505
2024-09-23 22:00:04.395 | Chat | Message response. Chat ID: 429. Request ID: 1134626506
2024-09-23 22:09:24.949 | Chat | Message response. Chat ID: 429. Request ID: 1134626507
2024-09-23 22:10:29.261 | Chat | Message response. Chat ID: 429. Request ID: 1134626508
2024-09-23 22:22:12.330 | Chat | Message response. Chat ID: 429. Request ID: 1134626509
2024-09-23 22:24:42.410 | Chat | Message response. Chat ID: 429. Request ID: 1134626510
2024-09-23 22:25:01.284 | Chat | Message response. Chat ID: 429. Request ID: 1134626511
2024-09-23 22:25:43.343 | Chat | Message response. Chat ID: 429. Request ID: 1134626512
2024-09-23 22:25:52.168 | Chat | Message response. Chat ID: 429. Request ID: 1134626513
2024-09-23 22:25:54.699 | Chat | Message response. Chat ID: 429. Request ID: 1134626514
2024-09-23 22:38:57.929 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MJYZ4.CME.scid. Thread ID: 3296
2024-09-23 22:41:39.435 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Creating socket. Using TLS 1.2.
2024-09-23 22:41:39.435 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | New receive buffer size: 0
2024-09-23 22:41:39.435 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Connecting to IP: 216.66.0.130.
2024-09-23 22:41:41.304 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | CloseSocket call.
2024-09-23 22:41:41.304 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Shutdown started. Waiting for graceful close.
2024-09-23 22:41:41.557 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Socket gracefully closed by remote side.
2024-09-23 22:41:41.557 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Closed.
2024-09-23 22:48:03.530 | Chat | Message response. Chat ID: 429. Request ID: 1134626515
2024-09-23 23:00:00.045 | Chat | Server has requested a logoff. Reason: Chat server is backing up
2024-09-23 23:00:00.045 | Chat | Waiting for socket receive thread to end
2024-09-23 23:00:00.045 | DTC Client socket (3) | CloseSocket call.
2024-09-23 23:00:00.046 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2024-09-23 23:00:00.046 | Chat | Disconnected from the server.
2024-09-23 23:00:00.046 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2024-09-23 23:00:01.985 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-09-23 23:00:01.985 | DTC Client socket (3) | Closed.
2024-09-23 23:00:05.041 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-23 23:00:05.192 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2024-09-23 23:00:05.192 | DTC Client socket (3) | New receive buffer size: 0
2024-09-23 23:00:05.192 | DTC Client socket (3) | Connecting to IP: 69.39.70.248.
2024-09-23 23:00:05.467 | Chat | Network connection to server complete.
2024-09-23 23:00:05.467 | Chat | Starting socket receive thread.
2024-09-23 23:00:05.467 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-23 23:00:06.294 | Chat | Setting DTC encoding to Binary VLS
2024-09-23 23:00:06.294 | Chat | Sending logon request message.
2024-09-23 23:00:11.445 | Not connected to chat server to send alert messages.
2024-09-23 23:00:22.354 | Chat | Received logon response.
2024-09-23 23:00:22.354 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-23 23:00:22.354 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-23 23:00:22.354 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-23 23:00:22.354 | Chat | Trading is not supported.
2024-09-23 23:00:22.354 | Chat | MarketDepthIsSupported: 1
2024-09-23 23:00:22.629 | Chat | Message response. Chat ID: 429. Request ID: 1134626517
2024-09-24 00:00:00.054 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-24 00:00:00.054 | Triggering next historical data download in queue.
2024-09-24 00:00:00.055 | HD Request # 71 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:00.416 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-24 00:00:00.416 | Triggering next historical data download in queue.
2024-09-24 00:00:00.416 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-24 00:00:00.417 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-24 00:00:00.417 | Triggering next historical data download in queue.
2024-09-24 00:00:00.471 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-24 00:00:00.471 | Triggering next historical data download in queue.
2024-09-24 00:00:00.471 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-24 00:00:01.003 | HD Request # 71 | Requesting historical Daily data for ESZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:02.006 | HD Request # 71 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-19.
2024-09-24 00:00:02.006 | HD Request # 71 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-24 00:00:02.009 | HD Request # 71 | Bytes received: 233
2024-09-24 00:00:02.009 | HD Request # 71 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for ESZ4.CME
2024-09-24 00:00:02.009 | HD Request # 71 | Completion time: 2s.
2024-09-24 00:00:02.009 | HD Request # 71 | Daily data download complete for ESZ4.CME. Unique request ID: 71
2024-09-24 00:00:02.009 | Removing historical data download ID 71.
2024-09-24 00:00:02.009 | Triggering next historical data download in queue.
2024-09-24 00:00:02.010 | HD Request # 72 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:02.168 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:02.168 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:02.168 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:02.568 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:02.577 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:02.577 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:02.577 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:02.967 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:03.068 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:03.068 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:03.068 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:03.403 | HD Request # 72 | Requesting historical Daily data for GCZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:03.457 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:04.182 | HD Request # 72 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-19.
2024-09-24 00:00:04.182 | HD Request # 72 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-24 00:00:04.187 | HD Request # 72 | Bytes received: 232
2024-09-24 00:00:04.187 | HD Request # 72 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-24 00:00:04.187 | HD Request # 72 | Completion time: 2s.
2024-09-24 00:00:04.187 | HD Request # 72 | Daily data download complete for GCZ4.COMEX. Unique request ID: 72
2024-09-24 00:00:04.187 | Removing historical data download ID 72.
2024-09-24 00:00:04.187 | Triggering next historical data download in queue.
2024-09-24 00:00:04.188 | HD Request # 73 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:04.195 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:04.195 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:04.195 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:04.980 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:05.373 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:05.373 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:05.373 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:06.026 | HD Request # 73 | Requesting historical Daily data for NQZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:06.097 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:06.097 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:06.097 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:06.751 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:06.877 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:07.356 | HD Request # 73 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-19.
2024-09-24 00:00:07.356 | HD Request # 73 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-24 00:00:07.358 | HD Request # 73 | Bytes received: 237
2024-09-24 00:00:07.358 | HD Request # 73 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for NQZ4.CME
2024-09-24 00:00:07.358 | HD Request # 73 | Completion time: 3s.
2024-09-24 00:00:07.358 | HD Request # 73 | Daily data download complete for NQZ4.CME. Unique request ID: 73
2024-09-24 00:00:07.358 | Removing historical data download ID 73.
2024-09-24 00:00:07.358 | Triggering next historical data download in queue.
2024-09-24 00:00:07.359 | HD Request # 74 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:07.378 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:07.378 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:07.378 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:07.748 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:07.749 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:07.749 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:07.749 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:08.102 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:08.183 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:08.183 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:08.183 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:08.483 | HD Request # 74 | Requesting historical Daily data for CLX24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:08.546 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:09.274 | HD Request # 74 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-19.
2024-09-24 00:00:09.274 | HD Request # 74 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-24 00:00:09.280 | HD Request # 74 | Bytes received: 217
2024-09-24 00:00:09.280 | HD Request # 74 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-24 00:00:09.280 | HD Request # 74 | Completion time: 2s.
2024-09-24 00:00:09.280 | HD Request # 74 | Daily data download complete for CLX4.NYMEX. Unique request ID: 74
2024-09-24 00:00:09.280 | Removing historical data download ID 74.
2024-09-24 00:00:09.280 | Triggering next historical data download in queue.
2024-09-24 00:00:09.281 | HD Request # 75 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:09.514 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:09.514 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:09.514 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:11.695 | HD Request # 75 | Requesting historical Daily data for J6Z24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:11.878 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:11.879 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:11.879 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:14.098 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:14.098 | HD Request # 75 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-19.
2024-09-24 00:00:14.098 | HD Request # 75 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-24 00:00:14.104 | HD Request # 75 | Bytes received: 273
2024-09-24 00:00:14.104 | HD Request # 75 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for 6JZ4.CME
2024-09-24 00:00:14.104 | HD Request # 75 | Completion time: 5s.
2024-09-24 00:00:14.104 | HD Request # 75 | Daily data download complete for 6JZ4.CME. Unique request ID: 75
2024-09-24 00:00:14.104 | Removing historical data download ID 75.
2024-09-24 00:00:14.104 | Triggering next historical data download in queue.
2024-09-24 00:00:14.105 | HD Request # 76 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:14.189 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:14.189 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:14.189 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:15.003 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:15.057 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:15.057 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:15.057 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:15.806 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:15.806 | HD Request # 76 | Requesting historical Daily data for A6Z24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:16.100 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:16.260 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:16.260 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:16.260 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:18.427 | HD Request # 76 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-19.
2024-09-24 00:00:18.427 | HD Request # 76 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-24 00:00:18.433 | HD Request # 76 | Bytes received: 242
2024-09-24 00:00:18.433 | HD Request # 76 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for 6AZ4.CME
2024-09-24 00:00:18.433 | HD Request # 76 | Completion time: 4s.
2024-09-24 00:00:18.433 | HD Request # 76 | Daily data download complete for 6AZ4.CME. Unique request ID: 76
2024-09-24 00:00:18.433 | Removing historical data download ID 76.
2024-09-24 00:00:18.433 | No download requests in the queue to start downloads for.
2024-09-24 00:00:18.509 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:18.509 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:18.509 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:19.330 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:19.331 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:19.331 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:19.331 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:20.088 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:20.090 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:20.090 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:20.090 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:20.845 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:20.970 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:21.093 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:21.093 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:21.093 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:22.144 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:11:27.352 | Chat | Message response. Chat ID: 429. Request ID: 1134626522
2024-09-24 01:08:10.797 | Chat | Message response. Chat ID: 429. Request ID: 1134626523
2024-09-24 01:09:01.430 | Chat | Message response. Chat ID: 429. Request ID: 1134626524
2024-09-24 01:36:47.040 | Chat | Message response. Chat ID: 429. Request ID: 1134626525
2024-09-24 05:01:27.362 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-24 05:01:27.362 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 05:01:27.363 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:01:27.363 | DTC Client socket (2) | Max send buffers used during socket life: 4
2024-09-24 05:01:27.363 | DTC Client socket (2) | Max send buffer size during socket life: 1401
2024-09-24 05:01:27.363 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 05:01:27.363 | DTC Client socket (2) | Closed.
2024-09-24 05:01:27.363 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 05:01:27.363 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:01:27.363 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:01:27.363 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:01:30.370 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:01:30.478 | DTC Client socket (2) | Creating socket.
2024-09-24 05:01:30.478 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:01:30.478 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:01:51.514 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:01:51.514 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:01:51.514 | Denali Data Feed | Failed connections: 1
2024-09-24 05:01:51.514 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:01:51.514 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:01:51.514 | DTC Client socket (2) | Closed.
2024-09-24 05:01:51.514 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:01:54.510 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:01:54.510 | DTC Client socket (2) | Creating socket.
2024-09-24 05:01:54.510 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:01:54.510 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:02:15.543 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:02:15.543 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:02:15.543 | Denali Data Feed | Failed connections: 2
2024-09-24 05:02:15.543 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:02:15.543 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:02:15.543 | DTC Client socket (2) | Closed.
2024-09-24 05:02:15.543 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:02:18.547 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:02:18.547 | DTC Client socket (2) | Creating socket.
2024-09-24 05:02:18.547 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:02:18.547 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:02:39.577 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:02:39.577 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:02:39.577 | Denali Data Feed | Failed connections: 3
2024-09-24 05:02:39.577 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:02:39.577 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:02:39.577 | DTC Client socket (2) | Closed.
2024-09-24 05:02:39.577 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:02:42.574 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:02:42.575 | DTC Client socket (2) | Creating socket.
2024-09-24 05:02:42.575 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:02:42.575 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:03:03.612 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:03:03.612 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:03:03.612 | Denali Data Feed | Failed connections: 4
2024-09-24 05:03:03.612 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:03:03.612 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:03:03.612 | DTC Client socket (2) | Closed.
2024-09-24 05:03:03.612 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:03:06.604 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:03:06.604 | DTC Client socket (2) | Creating socket.
2024-09-24 05:03:06.604 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:03:06.604 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:03:27.644 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:03:27.644 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:03:27.644 | DTC Client socket (2) | Closed.
2024-09-24 05:03:27.644 | Denali Data Feed | Failed connections: 5
2024-09-24 05:03:27.644 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:03:27.644 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:03:27.644 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:03:30.635 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:03:30.636 | DTC Client socket (2) | Creating socket.
2024-09-24 05:03:30.636 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:03:30.636 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:03:51.679 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:03:51.679 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:03:51.679 | Denali Data Feed | Failed connections: 6
2024-09-24 05:03:51.679 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:03:51.679 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:03:51.679 | DTC Client socket (2) | Closed.
2024-09-24 05:03:51.679 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:03:54.671 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:03:54.672 | DTC Client socket (2) | Creating socket.
2024-09-24 05:03:54.672 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:03:54.672 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:04:15.706 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:04:15.706 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:04:15.707 | DTC Client socket (2) | Closed.
2024-09-24 05:04:15.707 | Denali Data Feed | Failed connections: 7
2024-09-24 05:04:15.707 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:04:15.707 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:04:15.707 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:04:18.697 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:04:18.697 | DTC Client socket (2) | Creating socket.
2024-09-24 05:04:18.697 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:04:18.697 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:04:39.742 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:04:39.742 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:04:39.742 | Denali Data Feed | Failed connections: 8
2024-09-24 05:04:39.742 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:04:39.742 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:04:39.742 | DTC Client socket (2) | Closed.
2024-09-24 05:04:39.742 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:04:42.731 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:04:42.732 | DTC Client socket (2) | Creating socket.
2024-09-24 05:04:42.732 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:04:42.732 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:05:03.757 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:05:03.757 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:05:03.757 | Denali Data Feed | Failed connections: 9
2024-09-24 05:05:03.757 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:05:03.757 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:05:03.757 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:05:03.757 | DTC Client socket (2) | Closed.
2024-09-24 05:05:06.748 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:05:06.748 | DTC Client socket (2) | Creating socket.
2024-09-24 05:05:06.748 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:05:06.748 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:05:27.804 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:05:27.804 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:05:27.804 | Denali Data Feed | Failed connections: 10
2024-09-24 05:05:27.804 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:05:27.804 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:05:27.804 | DTC Client socket (2) | Closed.
2024-09-24 05:05:27.804 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:05:30.797 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:05:30.797 | DTC Client socket (2) | Creating socket.
2024-09-24 05:05:30.797 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:05:30.797 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:05:51.839 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:05:51.839 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:05:51.839 | Denali Data Feed | Failed connections: 11
2024-09-24 05:05:51.839 | DTC Client socket (2) | Closed.
2024-09-24 05:05:51.839 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:05:51.839 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:05:51.839 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:05:54.841 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:05:54.841 | DTC Client socket (2) | Creating socket.
2024-09-24 05:05:54.841 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:05:54.841 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:06:15.862 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:06:15.862 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:06:15.863 | Denali Data Feed | Failed connections: 12
2024-09-24 05:06:15.863 | DTC Client socket (2) | Closed.
2024-09-24 05:06:15.863 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:06:15.863 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:06:15.863 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:06:18.853 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:06:18.853 | DTC Client socket (2) | Creating socket.
2024-09-24 05:06:18.853 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:06:18.853 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:06:39.892 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:06:39.892 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:06:39.892 | Denali Data Feed | Failed connections: 13
2024-09-24 05:06:39.892 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:06:39.892 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:06:39.892 | DTC Client socket (2) | Closed.
2024-09-24 05:06:39.892 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:06:42.887 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:06:42.887 | DTC Client socket (2) | Creating socket.
2024-09-24 05:06:42.888 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:06:42.888 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:07:03.933 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:07:03.933 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:07:03.933 | DTC Client socket (2) | Closed.
2024-09-24 05:07:03.933 | Denali Data Feed | Failed connections: 14
2024-09-24 05:07:03.933 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:07:03.933 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:07:03.933 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:07:06.931 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:07:06.932 | DTC Client socket (2) | Creating socket.
2024-09-24 05:07:06.932 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:07:06.932 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:07:27.973 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:07:27.973 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:07:27.973 | Denali Data Feed | Failed connections: 15
2024-09-24 05:07:27.973 | DTC Client socket (2) | Closed.
2024-09-24 05:07:27.973 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:07:27.973 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:07:27.973 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:07:30.963 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:07:30.964 | DTC Client socket (2) | Creating socket.
2024-09-24 05:07:30.964 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:07:30.964 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:07:52.007 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:07:52.007 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:07:52.007 | DTC Client socket (2) | Closed.
2024-09-24 05:07:52.007 | Denali Data Feed | Failed connections: 16
2024-09-24 05:07:52.007 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:07:52.007 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:07:52.007 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:07:54.998 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:07:54.998 | DTC Client socket (2) | Creating socket.
2024-09-24 05:07:54.998 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:07:54.998 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:08:16.029 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:08:16.029 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:08:16.029 | Denali Data Feed | Failed connections: 17
2024-09-24 05:08:16.029 | DTC Client socket (2) | Closed.
2024-09-24 05:08:16.029 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:08:16.029 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:08:16.029 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:08:19.032 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:08:19.032 | DTC Client socket (2) | Creating socket.
2024-09-24 05:08:19.032 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:08:19.032 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:08:40.078 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:08:40.078 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:08:40.078 | Denali Data Feed | Failed connections: 18
2024-09-24 05:08:40.078 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:08:40.078 | DTC Client socket (2) | Closed.
2024-09-24 05:08:40.078 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:08:40.078 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:08:43.072 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:08:43.072 | DTC Client socket (2) | Creating socket.
2024-09-24 05:08:43.072 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:08:43.072 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:09:04.129 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:09:04.129 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:09:04.129 | DTC Client socket (2) | Closed.
2024-09-24 05:09:04.129 | Denali Data Feed | Failed connections: 19
2024-09-24 05:09:04.129 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:09:04.129 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:09:04.130 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:09:07.137 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:09:07.137 | DTC Client socket (2) | Creating socket.
2024-09-24 05:09:07.137 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:09:07.137 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:09:28.170 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:09:28.176 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:09:28.176 | Denali Data Feed | Failed connections: 20
2024-09-24 05:09:28.176 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:09:28.176 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:09:28.176 | DTC Client socket (2) | Closed.
2024-09-24 05:09:28.176 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:09:31.166 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:09:31.166 | DTC Client socket (2) | Creating socket.
2024-09-24 05:09:31.166 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:09:31.166 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:09:52.228 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:09:52.228 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:09:52.228 | Denali Data Feed | Failed connections: 21
2024-09-24 05:09:52.228 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:09:52.228 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:09:52.228 | DTC Client socket (2) | Closed.
2024-09-24 05:09:52.228 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:09:55.305 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:09:55.305 | DTC Client socket (2) | Creating socket.
2024-09-24 05:09:55.305 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:09:55.305 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:10:16.342 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:10:16.342 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:10:16.342 | Denali Data Feed | Failed connections: 22
2024-09-24 05:10:16.342 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:10:16.342 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:10:16.342 | DTC Client socket (2) | Closed.
2024-09-24 05:10:16.342 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:10:19.344 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:10:19.344 | DTC Client socket (2) | Creating socket.
2024-09-24 05:10:19.344 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:10:19.344 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:10:40.367 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:10:40.371 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:10:40.371 | Denali Data Feed | Failed connections: 23
2024-09-24 05:10:40.371 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:10:40.371 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:10:40.371 | DTC Client socket (2) | Closed.
2024-09-24 05:10:40.371 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:10:43.372 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:10:43.372 | DTC Client socket (2) | Creating socket.
2024-09-24 05:10:43.372 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:10:43.372 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:11:04.403 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:11:04.403 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:11:04.403 | Denali Data Feed | Failed connections: 24
2024-09-24 05:11:04.403 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:11:04.403 | DTC Client socket (2) | Closed.
2024-09-24 05:11:04.403 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:11:04.403 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:11:07.402 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:11:07.402 | DTC Client socket (2) | Creating socket.
2024-09-24 05:11:07.403 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:11:07.403 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:11:28.451 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:11:28.451 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:11:28.451 | Denali Data Feed | Failed connections: 25
2024-09-24 05:11:28.451 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:11:28.451 | DTC Client socket (2) | Closed.
2024-09-24 05:11:28.451 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:11:28.451 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:11:31.449 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:11:31.449 | DTC Client socket (2) | Creating socket.
2024-09-24 05:11:31.449 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:11:31.449 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:11:52.505 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:11:52.505 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:11:52.505 | Denali Data Feed | Failed connections: 26
2024-09-24 05:11:52.505 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:11:52.505 | DTC Client socket (2) | Closed.
2024-09-24 05:11:52.505 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:11:52.505 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:11:55.495 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:11:55.496 | DTC Client socket (2) | Creating socket.
2024-09-24 05:11:55.496 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:11:55.496 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:12:16.538 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:12:16.538 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:12:16.538 | Denali Data Feed | Failed connections: 27
2024-09-24 05:12:16.538 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:12:16.538 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:12:16.538 | DTC Client socket (2) | Closed.
2024-09-24 05:12:16.538 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:12:19.533 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:12:19.533 | DTC Client socket (2) | Creating socket.
2024-09-24 05:12:19.533 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:12:19.533 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:12:40.569 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:12:40.569 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:12:40.569 | Denali Data Feed | Failed connections: 28
2024-09-24 05:12:40.569 | DTC Client socket (2) | Closed.
2024-09-24 05:12:40.569 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:12:40.569 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:12:40.569 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:12:43.563 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:12:43.563 | DTC Client socket (2) | Creating socket.
2024-09-24 05:12:43.563 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:12:43.563 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:13:04.609 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:13:04.609 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:13:04.609 | Denali Data Feed | Failed connections: 29
2024-09-24 05:13:04.609 | DTC Client socket (2) | Closed.
2024-09-24 05:13:04.609 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:13:04.609 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:13:04.609 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:13:07.608 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:13:07.609 | DTC Client socket (2) | Creating socket.
2024-09-24 05:13:07.609 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:13:07.609 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:13:28.650 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:13:28.650 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:13:28.650 | DTC Client socket (2) | Closed.
2024-09-24 05:13:28.650 | Denali Data Feed | Failed connections: 30
2024-09-24 05:13:28.650 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:13:28.650 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:13:28.650 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:13:31.653 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:13:31.653 | DTC Client socket (2) | Creating socket.
2024-09-24 05:13:31.653 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:13:31.653 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:13:52.691 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:13:52.691 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:13:52.691 | Denali Data Feed | Failed connections: 31
2024-09-24 05:13:52.691 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:13:52.691 | DTC Client socket (2) | Closed.
2024-09-24 05:13:52.691 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:13:52.691 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:13:55.683 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:13:55.683 | DTC Client socket (2) | Creating socket.
2024-09-24 05:13:55.684 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:13:55.684 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:14:16.735 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:14:16.735 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:14:16.735 | Denali Data Feed | Failed connections: 32
2024-09-24 05:14:16.735 | DTC Client socket (2) | Closed.
2024-09-24 05:14:16.735 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:14:16.735 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:14:16.735 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:14:19.733 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:14:19.733 | DTC Client socket (2) | Creating socket.
2024-09-24 05:14:19.733 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:14:19.733 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:14:40.767 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:14:40.767 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:14:40.767 | Denali Data Feed | Failed connections: 33
2024-09-24 05:14:40.767 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:14:40.767 | DTC Client socket (2) | Closed.
2024-09-24 05:14:40.767 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:14:40.767 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:14:43.763 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:14:43.763 | DTC Client socket (2) | Creating socket.
2024-09-24 05:14:43.763 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:14:43.763 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:15:04.802 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:15:04.802 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:15:04.802 | DTC Client socket (2) | Closed.
2024-09-24 05:15:04.802 | Denali Data Feed | Failed connections: 34
2024-09-24 05:15:04.802 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:15:04.802 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:15:04.802 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:15:07.792 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:15:07.793 | DTC Client socket (2) | Creating socket.
2024-09-24 05:15:07.793 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:15:07.793 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:15:28.828 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:15:28.828 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:15:28.828 | Denali Data Feed | Failed connections: 35
2024-09-24 05:15:28.828 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:15:28.828 | DTC Client socket (2) | Closed.
2024-09-24 05:15:28.828 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:15:28.828 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:15:31.823 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:15:31.823 | DTC Client socket (2) | Creating socket.
2024-09-24 05:15:31.823 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:15:31.823 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:15:52.863 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:15:52.863 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:15:52.864 | Denali Data Feed | Failed connections: 36
2024-09-24 05:15:52.864 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:15:52.864 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:15:52.864 | DTC Client socket (2) | Closed.
2024-09-24 05:15:52.864 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:15:55.874 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:15:55.874 | DTC Client socket (2) | Creating socket.
2024-09-24 05:15:55.874 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:15:55.874 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:15:56.032 | Denali Data Feed | Network connection to server complete.
2024-09-24 05:15:56.033 | Denali Data Feed | Starting socket receive thread.
2024-09-24 05:15:56.033 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 05:15:56.215 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-24 05:15:56.215 | Denali Data Feed | Sending logon request message.
2024-09-24 05:17:15.871 | Denali Data Feed | There has been no activity on the network socket for 1m 19s. Will reconnect.
2024-09-24 05:17:15.871 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 05:17:15.871 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:17:15.871 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:15.871 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:17:15.871 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:17:18.873 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:17:18.873 | DTC Client socket (5) | Creating socket.
2024-09-24 05:17:18.873 | DTC Client socket (5) | New receive buffer size: 0
2024-09-24 05:17:18.873 | DTC Client socket (5) | Connecting to IP: 202.52.152.130.
2024-09-24 05:17:19.029 | Denali Data Feed | Network connection to server complete.
2024-09-24 05:17:19.029 | Denali Data Feed | Starting socket receive thread.
2024-09-24 05:17:19.029 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 05:17:19.197 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-24 05:17:19.197 | Denali Data Feed | Sending logon request message.
2024-09-24 05:17:19.853 | Denali Data Feed | Received logon response.
2024-09-24 05:17:19.853 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-24 05:17:19.853 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-24 05:17:19.853 | Denali Data Feed | Successfully connected.
2024-09-24 05:17:19.853 | Denali Data Feed | Trading is not supported.
2024-09-24 05:17:19.853 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-24 05:17:19.853 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Triggering next historical data download in queue.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: 6AZ4.CME -> 6AZ24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: 6JZ4.CME -> 6JZ24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: CLX4.NYMEX -> CLX24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ4.CME -> ESZ24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: M6AZ4.CME -> M6AZ24
2024-09-24 05:17:19.853 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: MCLU4.NYMEX -> MCLU24
2024-09-24 05:17:19.853 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24. Market Depth data restarted.
2024-09-24 05:17:19.854 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ4.CME -> MESZ24. Market Depth data restarted.
2024-09-24 05:17:19.854 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MGCZ4.COMEX -> MGCZ24
2024-09-24 05:17:19.854 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MJYZ4.CME -> MJYZ24
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-24 05:17:19.854 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ4.CME -> MNQZ24. Market Depth data restarted.
2024-09-24 05:17:19.854 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2024-09-24 05:17:19.854 | HD Request # 77 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 05:17:19.854 | HD Request # 77 | Download start date-time: 2024-09-24 05:00:54.000000. File last date-time: 2024-09-24 05:00:54.309004
2024-09-24 05:17:19.854 | HD Request # 77 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:19.854 | Socket (6) | Creating socket.
2024-09-24 05:17:19.854 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:19.854 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:20.398 | HD Request # 77 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:20.398 | HD Request # 77 | Sending historical data logon request message.
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-24 05:17:20.510 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-24 05:17:20.510 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-24 05:17:20.663 | HD Request # 77 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:54. Record interval: 0. Symbol: 6AZ24
2024-09-24 05:17:20.930 | HD Request # 77 | Decompressing data.
2024-09-24 05:17:21.199 | HD Request # 77 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 05:00:54.082000
2024-09-24 05:17:21.200 | Socket (6) | CloseSocket call.
2024-09-24 05:17:21.200 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:21.205 | Historical data download thread signaled to stop.
2024-09-24 05:17:21.205 | HD Request # 77 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:32.417000.
2024-09-24 05:17:21.205 | HD Request # 77 | Received 305 Intraday data records from 2024-09-24 05:00:54.082000 to 2024-09-24 05:17:01.892000 (16.1 minutes. Delay: 19.3 seconds) and wrote 287 records for 6AZ4.CME
2024-09-24 05:17:21.206 | HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:01.892000
2024-09-24 05:17:21.206 | HD Request # 77 | Completion time: 2s.
2024-09-24 05:17:21.206 | HD Request # 77 | Intraday data download complete for 6AZ4.CME. Unique request ID: 77
2024-09-24 05:17:21.206 | Removing historical data download ID 77.
2024-09-24 05:17:21.206 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 05:17:21.206 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 05:17:21.206 | HD Request # 77 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:21.206 | Triggering next historical data download in queue.
2024-09-24 05:17:21.206 | HD Request # 78 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 05:17:21.206 | HD Request # 78 | Download start date-time: 2024-09-24 05:00:59.000000. File last date-time: 2024-09-24 05:00:59.469000
2024-09-24 05:17:21.206 | HD Request # 78 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:21.206 | Socket (7) | Creating socket.
2024-09-24 05:17:21.206 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:21.206 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:21.465 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:21.465 | Socket (6) | Closed.
2024-09-24 05:17:21.745 | HD Request # 78 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:21.745 | HD Request # 78 | Sending historical data logon request message.
2024-09-24 05:17:22.008 | HD Request # 78 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:59. Record interval: 0. Symbol: 6JZ24
2024-09-24 05:17:22.272 | HD Request # 78 | Decompressing data.
2024-09-24 05:17:22.539 | HD Request # 78 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 05:00:59.469000
2024-09-24 05:17:22.539 | Socket (7) | CloseSocket call.
2024-09-24 05:17:22.539 | Historical data download thread signaled to stop.
2024-09-24 05:17:22.539 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:22.539 | HD Request # 78 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:04.005000.
2024-09-24 05:17:22.539 | HD Request # 78 | Received 622 Intraday data records from 2024-09-24 05:00:59.469000 to 2024-09-24 05:17:16.251000 (16.3 minutes. Delay: 6.3 seconds) and wrote 621 records for 6JZ4.CME
2024-09-24 05:17:22.539 | HD Request # 78 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:16.251000
2024-09-24 05:17:22.539 | HD Request # 78 | Completion time: 1s.
2024-09-24 05:17:22.539 | HD Request # 78 | Intraday data download complete for 6JZ4.CME. Unique request ID: 78
2024-09-24 05:17:22.539 | Removing historical data download ID 78.
2024-09-24 05:17:22.539 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 05:17:22.540 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 05:17:22.540 | HD Request # 78 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:22.540 | Triggering next historical data download in queue.
2024-09-24 05:17:22.540 | HD Request # 79 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 05:17:22.540 | HD Request # 79 | Download start date-time: 2024-09-24 05:01:02.000000. File last date-time: 2024-09-24 05:01:02.661000
2024-09-24 05:17:22.540 | HD Request # 79 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:22.540 | Socket (6) | Creating socket.
2024-09-24 05:17:22.540 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:22.540 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:22.802 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:22.802 | Socket (7) | Closed.
2024-09-24 05:17:23.094 | HD Request # 79 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:23.094 | HD Request # 79 | Sending historical data logon request message.
2024-09-24 05:17:23.365 | HD Request # 79 | Requesting Intraday data. Start date-time: 2024-09-24 05:01:02. Record interval: 0. Symbol: CLX24
2024-09-24 05:17:23.638 | HD Request # 79 | Decompressing data.
2024-09-24 05:17:24.187 | HD Request # 79 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 05:01:02.136000
2024-09-24 05:17:24.187 | Socket (6) | CloseSocket call.
2024-09-24 05:17:24.187 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:24.189 | Historical data download thread signaled to stop.
2024-09-24 05:17:24.189 | HD Request # 79 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:03.450000.
2024-09-24 05:17:24.189 | HD Request # 79 | Received 2748 Intraday data records from 2024-09-24 05:01:02.136000 to 2024-09-24 05:17:22.204000 (16.3 minutes. Delay: 2.0 seconds) and wrote 2741 records for CLX4.NYMEX
2024-09-24 05:17:24.190 | HD Request # 79 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:22.204000
2024-09-24 05:17:24.190 | Added 9 Time and Sales records to Intraday data file for CLX4.NYMEX after download.
2024-09-24 05:17:24.190 | HD Request # 79 | Completion time: 2s.
2024-09-24 05:17:24.190 | HD Request # 79 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 79
2024-09-24 05:17:24.190 | Removing historical data download ID 79.
2024-09-24 05:17:24.190 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 05:17:24.190 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 05:17:24.190 | HD Request # 79 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:24.190 | Triggering next historical data download in queue.
2024-09-24 05:17:24.190 | HD Request # 80 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 05:17:24.190 | HD Request # 80 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 05:17:24.190 | HD Request # 80 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:24.190 | Socket (7) | Creating socket.
2024-09-24 05:17:24.190 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:24.190 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:24.459 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:24.459 | Socket (6) | Closed.
2024-09-24 05:17:24.744 | HD Request # 80 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:24.744 | HD Request # 80 | Sending historical data logon request message.
2024-09-24 05:17:24.929 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:24.929 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6JZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:25.015 | HD Request # 80 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 05:17:25.288 | HD Request # 80 | Decompressing data.
2024-09-24 05:17:25.560 | HD Request # 80 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 05:17:25.560 | Socket (7) | CloseSocket call.
2024-09-24 05:17:25.560 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:25.563 | Historical data download thread signaled to stop.
2024-09-24 05:17:25.563 | HD Request # 80 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 3.8 days) and wrote 0 records for ESU4.CME
2024-09-24 05:17:25.563 | HD Request # 80 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 05:17:25.563 | HD Request # 80 | Completion time: 1s.
2024-09-24 05:17:25.563 | HD Request # 80 | Intraday data download complete for ESU4.CME. Unique request ID: 80
2024-09-24 05:17:25.563 | Removing historical data download ID 80.
2024-09-24 05:17:25.563 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 05:17:25.563 | Intraday chart data file opened for ESU4.CME
2024-09-24 05:17:25.563 | HD Request # 80 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:25.563 | Triggering next historical data download in queue.
2024-09-24 05:17:25.563 | HD Request # 81 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 05:17:25.563 | HD Request # 81 | Download start date-time: 2024-09-24 05:00:57.000000. File last date-time: 2024-09-24 05:00:57.939005
2024-09-24 05:17:25.563 | HD Request # 81 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:25.563 | Socket (6) | Creating socket.
2024-09-24 05:17:25.563 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:25.563 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:25.831 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:25.831 | Socket (7) | Closed.
2024-09-24 05:17:26.118 | HD Request # 81 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:26.118 | HD Request # 81 | Sending historical data logon request message.
2024-09-24 05:17:26.389 | HD Request # 81 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:57. Record interval: 0. Symbol: ESZ24
2024-09-24 05:17:26.662 | HD Request # 81 | Decompressing data.
2024-09-24 05:17:26.937 | HD Request # 81 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 05:00:57.939000
2024-09-24 05:17:26.938 | Socket (6) | CloseSocket call.
2024-09-24 05:17:26.938 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:26.947 | Historical data download thread signaled to stop.
2024-09-24 05:17:26.947 | HD Request # 81 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:13.979000.
2024-09-24 05:17:26.947 | HD Request # 81 | Received 1412 Intraday data records from 2024-09-24 05:00:57.939000 to 2024-09-24 05:17:19.966000 (16.4 minutes. Delay: 7.0 seconds) and wrote 1406 records for ESZ4.CME
2024-09-24 05:17:26.948 | HD Request # 81 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:19.966000
2024-09-24 05:17:26.948 | HD Request # 81 | Completion time: 1s.
2024-09-24 05:17:26.948 | HD Request # 81 | Intraday data download complete for ESZ4.CME. Unique request ID: 81
2024-09-24 05:17:26.948 | Removing historical data download ID 81.
2024-09-24 05:17:26.948 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 05:17:26.948 | Intraday chart data file opened for ESZ4.CME
2024-09-24 05:17:26.948 | HD Request # 81 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:26.948 | Triggering next historical data download in queue.
2024-09-24 05:17:26.948 | HD Request # 82 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 05:17:26.948 | HD Request # 82 | Download start date-time: 2024-09-24 05:00:50.000000. File last date-time: 2024-09-24 05:00:50.988000
2024-09-24 05:17:26.948 | HD Request # 82 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:26.948 | Socket (7) | Creating socket.
2024-09-24 05:17:26.948 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:26.948 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:27.209 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:27.209 | Socket (6) | Closed.
2024-09-24 05:17:27.498 | HD Request # 82 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:27.498 | HD Request # 82 | Sending historical data logon request message.
2024-09-24 05:17:27.768 | HD Request # 82 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:50. Record interval: 0. Symbol: GCZ24
2024-09-24 05:17:28.041 | HD Request # 82 | Decompressing data.
2024-09-24 05:17:28.317 | HD Request # 82 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 05:00:50.988000
2024-09-24 05:17:28.317 | Socket (7) | CloseSocket call.
2024-09-24 05:17:28.317 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:28.331 | Historical data download thread signaled to stop.
2024-09-24 05:17:28.331 | HD Request # 82 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:05.080000.
2024-09-24 05:17:28.331 | HD Request # 82 | Received 1317 Intraday data records from 2024-09-24 05:00:50.988000 to 2024-09-24 05:17:23.908000 (16.5 minutes. Delay: 4.4 seconds) and wrote 1316 records for GCZ4.COMEX
2024-09-24 05:17:28.331 | HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:23.908000
2024-09-24 05:17:28.331 | Added 1 Time and Sales records to Intraday data file for GCZ4.COMEX after download.
2024-09-24 05:17:28.331 | HD Request # 82 | Completion time: 2s.
2024-09-24 05:17:28.331 | HD Request # 82 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 82
2024-09-24 05:17:28.331 | Removing historical data download ID 82.
2024-09-24 05:17:28.331 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 05:17:28.331 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 05:17:28.331 | HD Request # 82 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:28.331 | Triggering next historical data download in queue.
2024-09-24 05:17:28.331 | HD Request # 83 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 05:17:28.332 | HD Request # 83 | Download start date-time: 2024-09-24 05:00:50.000000. File last date-time: 2024-09-24 05:00:50.471005
2024-09-24 05:17:28.332 | HD Request # 83 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:28.332 | Socket (6) | Creating socket.
2024-09-24 05:17:28.332 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:28.332 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:28.588 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:28.588 | Socket (7) | Closed.
2024-09-24 05:17:28.890 | HD Request # 83 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:28.890 | HD Request # 83 | Sending historical data logon request message.
2024-09-24 05:17:29.162 | HD Request # 83 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:50. Record interval: 0. Symbol: M6AZ24
2024-09-24 05:17:29.435 | HD Request # 83 | Decompressing data.
2024-09-24 05:17:29.707 | HD Request # 83 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 05:00:50.350000
2024-09-24 05:17:29.707 | Socket (6) | CloseSocket call.
2024-09-24 05:17:29.707 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:29.722 | Historical data download thread signaled to stop.
2024-09-24 05:17:29.722 | HD Request # 83 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:32.417000.
2024-09-24 05:17:29.722 | HD Request # 83 | Received 62 Intraday data records from 2024-09-24 05:00:50.350000 to 2024-09-24 05:17:23.947000 (16.6 minutes. Delay: 5.8 seconds) and wrote 55 records for M6AZ4.CME
2024-09-24 05:17:29.723 | HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:23.947000
2024-09-24 05:17:29.723 | HD Request # 83 | Completion time: 1s.
2024-09-24 05:17:29.723 | HD Request # 83 | Intraday data download complete for M6AZ4.CME. Unique request ID: 83
2024-09-24 05:17:29.723 | Removing historical data download ID 83.
2024-09-24 05:17:29.723 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 05:17:29.723 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 05:17:29.723 | HD Request # 83 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:29.723 | Triggering next historical data download in queue.
2024-09-24 05:17:29.723 | HD Request # 84 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 05:17:29.723 | HD Request # 84 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 05:17:29.723 | HD Request # 84 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:29.723 | Socket (7) | Creating socket.
2024-09-24 05:17:29.723 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:29.723 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:29.972 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\CLX4.NYMEX.scid. Thread ID: 3296
2024-09-24 05:17:29.979 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:29.979 | Socket (6) | Closed.
2024-09-24 05:17:30.264 | HD Request # 84 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:30.264 | HD Request # 84 | Sending historical data logon request message.
2024-09-24 05:17:30.528 | HD Request # 84 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 05:17:30.794 | HD Request # 84 | Decompressing data.
2024-09-24 05:17:31.058 | HD Request # 84 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 05:17:31.058 | Socket (7) | CloseSocket call.
2024-09-24 05:17:31.058 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:31.058 | Historical data download thread signaled to stop.
2024-09-24 05:17:31.058 | HD Request # 84 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 35.6 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 05:17:31.058 | HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 05:17:31.058 | HD Request # 84 | Completion time: 2s.
2024-09-24 05:17:31.058 | HD Request # 84 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 84
2024-09-24 05:17:31.058 | Removing historical data download ID 84.
2024-09-24 05:17:31.058 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 05:17:31.058 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 05:17:31.058 | HD Request # 84 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:31.058 | Triggering next historical data download in queue.
2024-09-24 05:17:31.058 | HD Request # 85 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 05:17:31.059 | HD Request # 85 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 05:17:31.059 | HD Request # 85 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:31.059 | Socket (6) | Creating socket.
2024-09-24 05:17:31.059 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:31.059 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:31.322 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:31.322 | Socket (7) | Closed.
2024-09-24 05:17:31.598 | HD Request # 85 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:31.598 | HD Request # 85 | Sending historical data logon request message.
2024-09-24 05:17:31.862 | HD Request # 85 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 05:17:32.127 | HD Request # 85 | Decompressing data.
2024-09-24 05:17:32.391 | HD Request # 85 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 05:17:32.391 | Socket (6) | CloseSocket call.
2024-09-24 05:17:32.391 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:32.393 | Historical data download thread signaled to stop.
2024-09-24 05:17:32.393 | HD Request # 85 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 3.8 days) and wrote 0 records for MESU4.CME
2024-09-24 05:17:32.393 | HD Request # 85 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 05:17:32.393 | HD Request # 85 | Completion time: 1s.
2024-09-24 05:17:32.393 | HD Request # 85 | Intraday data download complete for MESU4.CME. Unique request ID: 85
2024-09-24 05:17:32.393 | Removing historical data download ID 85.
2024-09-24 05:17:32.393 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 05:17:32.393 | Intraday chart data file opened for MESU4.CME
2024-09-24 05:17:32.393 | HD Request # 85 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:32.393 | Triggering next historical data download in queue.
2024-09-24 05:17:32.393 | HD Request # 86 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 05:17:32.393 | HD Request # 86 | Download start date-time: 2024-09-24 05:01:03.000000. File last date-time: 2024-09-24 05:01:03.048000
2024-09-24 05:17:32.394 | HD Request # 86 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:32.394 | Socket (7) | Creating socket.
2024-09-24 05:17:32.394 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:32.394 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:32.656 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:32.656 | Socket (6) | Closed.
2024-09-24 05:17:32.950 | HD Request # 86 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:32.950 | HD Request # 86 | Sending historical data logon request message.
2024-09-24 05:17:33.222 | HD Request # 86 | Requesting Intraday data. Start date-time: 2024-09-24 05:01:03. Record interval: 0. Symbol: MESZ24
2024-09-24 05:17:33.495 | HD Request # 86 | Decompressing data.
2024-09-24 05:17:33.769 | HD Request # 86 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 05:01:03.048000
2024-09-24 05:17:33.770 | Socket (7) | CloseSocket call.
2024-09-24 05:17:33.770 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:33.773 | Historical data download thread signaled to stop.
2024-09-24 05:17:33.773 | HD Request # 86 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:13.979000.
2024-09-24 05:17:33.773 | HD Request # 86 | Received 682 Intraday data records from 2024-09-24 05:01:03.048000 to 2024-09-24 05:17:31.053000 (16.5 minutes. Delay: 2.7 seconds) and wrote 681 records for MESZ4.CME
2024-09-24 05:17:33.773 | HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:31.053000
2024-09-24 05:17:33.773 | Added 2 Time and Sales records to Intraday data file for MESZ4.CME after download.
2024-09-24 05:17:33.773 | HD Request # 86 | Completion time: 1s.
2024-09-24 05:17:33.773 | HD Request # 86 | Intraday data download complete for MESZ4.CME. Unique request ID: 86
2024-09-24 05:17:33.773 | Removing historical data download ID 86.
2024-09-24 05:17:33.773 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 05:17:33.773 | Intraday chart data file opened for MESZ4.CME
2024-09-24 05:17:33.773 | HD Request # 86 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:33.773 | Triggering next historical data download in queue.
2024-09-24 05:17:33.773 | HD Request # 87 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 05:17:33.774 | HD Request # 87 | Download start date-time: 2024-09-24 05:01:00.000000. File last date-time: 2024-09-24 05:01:00.697000
2024-09-24 05:17:33.774 | HD Request # 87 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:33.774 | Socket (6) | Creating socket.
2024-09-24 05:17:33.774 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:33.774 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:34.042 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:34.042 | Socket (7) | Closed.
2024-09-24 05:17:34.332 | HD Request # 87 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:34.332 | HD Request # 87 | Sending historical data logon request message.
2024-09-24 05:17:34.606 | HD Request # 87 | Requesting Intraday data. Start date-time: 2024-09-24 05:01:00. Record interval: 0. Symbol: MGCZ24
2024-09-24 05:17:34.880 | HD Request # 87 | Decompressing data.
2024-09-24 05:17:35.002 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:35.002 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:35.156 | HD Request # 87 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 05:01:00.697000
2024-09-24 05:17:35.156 | Socket (6) | CloseSocket call.
2024-09-24 05:17:35.156 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:35.317 | Historical data download thread signaled to stop.
2024-09-24 05:17:35.317 | HD Request # 87 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:05.075000.
2024-09-24 05:17:35.317 | HD Request # 87 | Received 611 Intraday data records from 2024-09-24 05:01:00.697000 to 2024-09-24 05:17:29.530000 (16.5 minutes. Delay: 5.8 seconds) and wrote 610 records for MGCZ4.COMEX
2024-09-24 05:17:35.318 | HD Request # 87 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:29.530000
2024-09-24 05:17:35.318 | HD Request # 87 | Completion time: 2s.
2024-09-24 05:17:35.318 | HD Request # 87 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 87
2024-09-24 05:17:35.318 | Removing historical data download ID 87.
2024-09-24 05:17:35.318 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 05:17:35.318 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 05:17:35.318 | HD Request # 87 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:35.318 | Triggering next historical data download in queue.
2024-09-24 05:17:35.318 | HD Request # 88 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 05:17:35.318 | HD Request # 88 | Download start date-time: 2024-09-24 04:59:59.000000. File last date-time: 2024-09-24 04:59:59.311000
2024-09-24 05:17:35.318 | HD Request # 88 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:35.318 | Socket (7) | Creating socket.
2024-09-24 05:17:35.318 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:35.318 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:35.428 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:35.428 | Socket (6) | Closed.
2024-09-24 05:17:35.863 | HD Request # 88 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:35.863 | HD Request # 88 | Sending historical data logon request message.
2024-09-24 05:17:36.128 | HD Request # 88 | Requesting Intraday data. Start date-time: 2024-09-24 04:59:59. Record interval: 0. Symbol: MJYZ24
2024-09-24 05:17:36.396 | HD Request # 88 | Decompressing data.
2024-09-24 05:17:36.667 | HD Request # 88 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 04:59:59.311000
2024-09-24 05:17:36.667 | Socket (7) | CloseSocket call.
2024-09-24 05:17:36.667 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:36.685 | Historical data download thread signaled to stop.
2024-09-24 05:17:36.685 | HD Request # 88 | Timestamp of first Intraday data file record written: 2024-09-24 05:12:38.463000.
2024-09-24 05:17:36.685 | HD Request # 88 | Received 3 Intraday data records from 2024-09-24 04:59:59.311000 to 2024-09-24 05:13:50.248000 (13.8 minutes. Delay: 3.8 minutes) and wrote 2 records for MJYZ4.CME
2024-09-24 05:17:36.686 | HD Request # 88 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:13:50.248000
2024-09-24 05:17:36.686 | HD Request # 88 | Completion time: 1s.
2024-09-24 05:17:36.686 | HD Request # 88 | Intraday data download complete for MJYZ4.CME. Unique request ID: 88
2024-09-24 05:17:36.686 | Removing historical data download ID 88.
2024-09-24 05:17:36.686 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 05:17:36.686 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 05:17:36.686 | HD Request # 88 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:36.686 | Triggering next historical data download in queue.
2024-09-24 05:17:36.686 | HD Request # 89 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 05:17:36.686 | HD Request # 89 | Download start date-time: 2024-09-24 05:01:02.000000. File last date-time: 2024-09-24 05:01:02.865000
2024-09-24 05:17:36.686 | HD Request # 89 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:36.686 | Socket (6) | Creating socket.
2024-09-24 05:17:36.686 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:36.686 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:36.933 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:36.934 | Socket (7) | Closed.
2024-09-24 05:17:37.228 | HD Request # 89 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:37.228 | HD Request # 89 | Sending historical data logon request message.
2024-09-24 05:17:37.492 | HD Request # 89 | Requesting Intraday data. Start date-time: 2024-09-24 05:01:02. Record interval: 0. Symbol: MNQZ24
2024-09-24 05:17:37.757 | HD Request # 89 | Decompressing data.
2024-09-24 05:17:38.295 | HD Request # 89 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 05:01:02.223000
2024-09-24 05:17:38.296 | Socket (6) | CloseSocket call.
2024-09-24 05:17:38.296 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:38.296 | Historical data download thread signaled to stop.
2024-09-24 05:17:38.296 | HD Request # 89 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:05.258000.
2024-09-24 05:17:38.297 | HD Request # 89 | Received 3226 Intraday data records from 2024-09-24 05:01:02.223000 to 2024-09-24 05:17:35.646000 (16.6 minutes. Delay: 2.7 seconds) and wrote 3223 records for MNQZ4.CME
2024-09-24 05:17:38.297 | HD Request # 89 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:35.646000
2024-09-24 05:17:38.297 | Added 11 Time and Sales records to Intraday data file for MNQZ4.CME after download.
2024-09-24 05:17:38.297 | HD Request # 89 | Completion time: 2s.
2024-09-24 05:17:38.297 | HD Request # 89 | Intraday data download complete for MNQZ4.CME. Unique request ID: 89
2024-09-24 05:17:38.297 | Removing historical data download ID 89.
2024-09-24 05:17:38.297 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 05:17:38.297 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 05:17:38.297 | HD Request # 89 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:38.297 | Triggering next historical data download in queue.
2024-09-24 05:17:38.297 | HD Request # 90 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 05:17:38.297 | HD Request # 90 | Download start date-time: 2024-09-24 05:00:57.000000. File last date-time: 2024-09-24 05:00:57.657000
2024-09-24 05:17:38.297 | HD Request # 90 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:38.297 | Socket (7) | Creating socket.
2024-09-24 05:17:38.297 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:38.297 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:38.560 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:38.560 | Socket (6) | Closed.
2024-09-24 05:17:38.844 | HD Request # 90 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:38.844 | HD Request # 90 | Sending historical data logon request message.
2024-09-24 05:17:39.110 | HD Request # 90 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:57. Record interval: 0. Symbol: NQZ24
2024-09-24 05:17:39.377 | HD Request # 90 | Decompressing data.
2024-09-24 05:17:39.647 | HD Request # 90 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 05:00:57.657000
2024-09-24 05:17:39.647 | Socket (7) | CloseSocket call.
2024-09-24 05:17:39.647 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:39.761 | Historical data download thread signaled to stop.
2024-09-24 05:17:39.761 | HD Request # 90 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:05.835000.
2024-09-24 05:17:39.761 | HD Request # 90 | Received 984 Intraday data records from 2024-09-24 05:00:57.657000 to 2024-09-24 05:17:37.078000 (16.7 minutes. Delay: 2.7 seconds) and wrote 983 records for NQZ4.CME
2024-09-24 05:17:39.762 | HD Request # 90 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:37.078000
2024-09-24 05:17:39.762 | Added 1 Time and Sales records to Intraday data file for NQZ4.CME after download.
2024-09-24 05:17:39.762 | HD Request # 90 | Completion time: 1s.
2024-09-24 05:17:39.762 | HD Request # 90 | Intraday data download complete for NQZ4.CME. Unique request ID: 90
2024-09-24 05:17:39.762 | Removing historical data download ID 90.
2024-09-24 05:17:39.762 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 05:17:39.762 | Intraday chart data file opened for NQZ4.CME
2024-09-24 05:17:39.762 | HD Request # 90 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:39.762 | No download requests in the queue to start downloads for.
2024-09-24 05:17:39.915 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:39.915 | Socket (7) | Closed.
2024-09-24 05:17:40.026 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:40.026 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 05:17:40.026 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 05:17:41.758 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-24 05:17:41.758 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 05:17:41.758 | DTC Client socket (2) | Closed.
2024-09-24 05:17:45.046 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:50.086 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AZ4.CME.scid. Thread ID: 3296
2024-09-24 05:26:28.763 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MJYZ4.CME.scid. Thread ID: 3296
2024-09-24 06:41:41.320 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Creating socket. Using TLS 1.2.
2024-09-24 06:41:41.321 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | New receive buffer size: 0
2024-09-24 06:41:41.321 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Connecting to IP: 216.66.0.130.
2024-09-24 06:41:43.679 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | CloseSocket call.
2024-09-24 06:41:43.679 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Shutdown started. Waiting for graceful close.
2024-09-24 06:41:43.937 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Socket gracefully closed by remote side.
2024-09-24 06:41:43.937 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Closed.
2024-09-24 07:02:05.609 | Chat | Message response. Chat ID: 429. Request ID: 1134626526
2024-09-24 07:02:37.141 | Chat | Message response. Chat ID: 429. Request ID: 1134626527
2024-09-24 07:28:19.888 | Chat | Message response. Chat ID: 429. Request ID: 1134626528
2024-09-24 08:26:52.552 | ESZ4.CME[M] 5 Min #12 | Reloading chart.
2024-09-24 08:26:53.430 | ESZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 08:26:53.441 | ESZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-24 09:50:06.898 | Chat | Message response. Chat ID: 429. Request ID: 1134626529
2024-09-24 10:00:52.074 | Chat | Message response. Chat ID: 429. Request ID: 1134626530
2024-09-24 10:00:52.925 | Chat | Message response. Chat ID: 429. Request ID: 1134626531
2024-09-24 10:00:52.959 | Chat | Message response. Chat ID: 429. Request ID: 1134626532
2024-09-24 10:01:04.664 | Chat | Message response. Chat ID: 429. Request ID: 1134626533
2024-09-24 10:01:08.397 | Chat | Message response. Chat ID: 429. Request ID: 1134626534
2024-09-24 10:02:19.159 | Chat | Message response. Chat ID: 429. Request ID: 1134626535
2024-09-24 10:02:44.633 | Chat | Message response. Chat ID: 429. Request ID: 1134626536
2024-09-24 10:02:46.204 | Chat | Message response. Chat ID: 429. Request ID: 1134626537
2024-09-24 10:02:47.705 | Chat | Message response. Chat ID: 429. Request ID: 1134626538
2024-09-24 10:02:50.282 | Chat | Message response. Chat ID: 429. Request ID: 1134626539
2024-09-24 10:02:53.444 | Chat | Message response. Chat ID: 429. Request ID: 1134626540
2024-09-24 10:02:59.084 | Chat | Message response. Chat ID: 429. Request ID: 1134626541
2024-09-24 10:03:01.923 | Chat | Message response. Chat ID: 429. Request ID: 1134626542
2024-09-24 10:03:04.572 | Chat | Message response. Chat ID: 429. Request ID: 1134626543
2024-09-24 10:03:06.540 | Chat | Message response. Chat ID: 429. Request ID: 1134626544
2024-09-24 10:18:06.528 | Chat | Message response. Chat ID: 429. Request ID: 1134626545
2024-09-24 11:46:12.354 | DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-24 11:46:12.354 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:46:12.377 | DTC Client socket (5) | CloseSocket call.
2024-09-24 11:46:12.377 | DTC Client socket (5) | Max send buffers used during socket life: 4
2024-09-24 11:46:12.377 | DTC Client socket (5) | Max send buffer size during socket life: 1401
2024-09-24 11:46:12.377 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 11:46:12.377 | DTC Client socket (5) | Closed.
2024-09-24 11:46:12.377 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 11:46:12.378 | DTC Client socket (0) | CloseSocket call.
2024-09-24 11:46:12.378 | Denali Data Feed | Disconnected from the server.
2024-09-24 11:46:12.378 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 11:46:15.395 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 11:46:15.395 | DTC Client socket (5) | Creating socket.
2024-09-24 11:46:15.395 | DTC Client socket (5) | New receive buffer size: 0
2024-09-24 11:46:15.395 | DTC Client socket (5) | Connecting to IP: 202.52.152.130.
2024-09-24 11:46:36.441 | DTC Client socket (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 11:46:36.443 | DTC Client socket (5) | CloseSocket call.
2024-09-24 11:46:36.443 | Denali Data Feed | Failed connections: 1
2024-09-24 11:46:36.443 | DTC Client socket (0) | CloseSocket call.
2024-09-24 11:46:36.443 | Denali Data Feed | Disconnected from the server.
2024-09-24 11:46:36.443 | DTC Client socket (5) | Closed.
2024-09-24 11:46:36.443 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 11:46:38.388 | File >> Reconnect selected.
2024-09-24 11:46:38.658 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 11:46:38.659 | DTC Client socket (1) | CloseSocket call.
2024-09-24 11:46:38.659 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-09-24 11:46:38.659 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-09-24 11:46:38.659 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:38.659 | DTC Client socket (0) | CloseSocket call.
2024-09-24 11:46:38.659 | Denali Data Feed | Disconnected from the server.
2024-09-24 11:46:38.659 | SC Data with Depth | Waiting for socket receive thread to end
2024-09-24 11:46:38.660 | DTC Client socket (4) | CloseSocket call.
2024-09-24 11:46:38.660 | SC Data with Depth | Disconnected from the server.
2024-09-24 11:46:38.660 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:38.660 | Rithmic Direct - DTC | Disconnected.
2024-09-24 11:46:38.660 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 11:46:38.930 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 11:46:38.930 | DTC Client socket (1) | Closed.
2024-09-24 11:46:39.214 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-09-24 11:46:39.215 | DTC Client socket (4) | Closed.
2024-09-24 11:46:42.654 |
2024-09-24 11:46:42.655 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 11:46:42.655 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 11:46:42.655 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 11:46:42.963 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 11:46:42.963 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 11:46:42.963 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 11:46:43.209 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 11:46:43.209 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 11:46:43.209 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 11:46:43.209 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Received logon response.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Server Name: .
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 11:46:43.956 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 11:46:43.956 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 11:46:43.956 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 11:46:43.956 | Using symbol data fast lookup vector
2024-09-24 11:46:43.956 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 11:46:43.956 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 11:46:43.956 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 11:46:43.956 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 11:46:43.956 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 11:46:43.956 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 11:46:43.956 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 11:46:43.956 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 11:46:43.956 | DTC Client socket (2) | Creating socket.
2024-09-24 11:46:43.956 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 11:46:43.956 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 11:46:44.231 | Denali Data Feed | Network connection to server complete.
2024-09-24 11:46:44.231 | Denali Data Feed | Starting socket receive thread.
2024-09-24 11:46:44.231 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 11:46:44.264 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 11:46:44.264 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 3 Service code: cme
2024-09-24 11:46:44.264 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 3
2024-09-24 11:46:44.264 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 11:46:44.264 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.264 | Triggering next historical data download in queue.
2024-09-24 11:46:44.264 | Delaying start of download for MESZ4.CME.
2024-09-24 11:46:44.268 | Mapping MJYZ4.CME to MJYZ24. Service code: cme
2024-09-24 11:46:44.268 | Denali Data Feed | Starting real-time market data updates for: MJYZ4.CME (MJYZ24). ID: 4 Service code: cme
2024-09-24 11:46:44.268 | Denali Data Feed | Requesting security definition data for: MJYZ4.CME (MJYZ24). ID: 4
2024-09-24 11:46:44.268 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 11:46:44.268 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.268 | Triggering next historical data download in queue.
2024-09-24 11:46:44.270 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 11:46:44.270 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 5 Service code: cme
2024-09-24 11:46:44.270 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 5
2024-09-24 11:46:44.270 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 11:46:44.270 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.270 | Triggering next historical data download in queue.
2024-09-24 11:46:44.435 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-24 11:46:44.435 | Denali Data Feed | Sending logon request message.
2024-09-24 11:46:44.435 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 11:46:44.435 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 11:46:44.435 | Triggering next historical data download in queue.
2024-09-24 11:46:44.435 | Mapping 6AZ4.CME to 6AZ24. Service code: cme
2024-09-24 11:46:44.435 | Denali Data Feed | Starting real-time market data updates for: 6AZ4.CME (6AZ24). ID: 6 Service code: cme
2024-09-24 11:46:44.435 | Denali Data Feed | Requesting security definition data for: 6AZ4.CME (6AZ24). ID: 6
2024-09-24 11:46:44.435 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 11:46:44.435 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.436 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 11:46:44.436 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 7 Service code: cme
2024-09-24 11:46:44.436 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 7
2024-09-24 11:46:44.436 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 11:46:44.436 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.436 | Triggering next historical data download in queue.
2024-09-24 11:46:44.499 | Mapping M6AZ4.CME to M6AZ24. Service code: cme
2024-09-24 11:46:44.499 | Denali Data Feed | Starting real-time market data updates for: M6AZ4.CME (M6AZ24). ID: 8 Service code: cme
2024-09-24 11:46:44.499 | Denali Data Feed | Requesting security definition data for: M6AZ4.CME (M6AZ24). ID: 8
2024-09-24 11:46:44.499 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 11:46:44.499 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.499 | Triggering next historical data download in queue.
2024-09-24 11:46:44.499 | Mapping MCLU4.NYMEX to MCLU24. Service code: nymex
2024-09-24 11:46:44.499 | Denali Data Feed | Starting real-time market data updates for: MCLU4.NYMEX (MCLU24). ID: 9 Service code: nymex
2024-09-24 11:46:44.499 | Denali Data Feed | Requesting security definition data for: MCLU4.NYMEX (MCLU24). ID: 9
2024-09-24 11:46:44.499 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 11:46:44.499 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 11:46:44.499 | Mapping CLX4.NYMEX to CLX24. Service code: nymex
2024-09-24 11:46:44.499 | Denali Data Feed | Starting real-time market data updates for: CLX4.NYMEX (CLX24). ID: 10 Service code: nymex
2024-09-24 11:46:44.499 | Denali Data Feed | Requesting security definition data for: CLX4.NYMEX (CLX24). ID: 10
2024-09-24 11:46:44.499 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 11:46:44.499 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 11:46:44.500 | Mapping 6JZ4.CME to 6JZ24. Service code: cme
2024-09-24 11:46:44.500 | Denali Data Feed | Starting real-time market data updates for: 6JZ4.CME (6JZ24). ID: 11 Service code: cme
2024-09-24 11:46:44.500 | Denali Data Feed | Requesting security definition data for: 6JZ4.CME (6JZ24). ID: 11
2024-09-24 11:46:44.500 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 11:46:44.500 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.500 | Triggering next historical data download in queue.
2024-09-24 11:46:44.532 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2024-09-24 11:46:44.532 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 12 Service code: comex
2024-09-24 11:46:44.532 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 12
2024-09-24 11:46:44.532 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 11:46:44.532 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 11:46:44.532 | Triggering next historical data download in queue.
2024-09-24 11:46:44.591 | Mapping ESU4.CME to ESU24. Service code: cme
2024-09-24 11:46:44.591 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 13 Service code: cme
2024-09-24 11:46:44.591 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 13
2024-09-24 11:46:44.591 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 11:46:44.591 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 11:46:44.591 | Triggering next historical data download in queue.
2024-09-24 11:46:44.591 | Mapping MGCZ4.COMEX to MGCZ24. Service code: comex
2024-09-24 11:46:44.591 | Denali Data Feed | Starting real-time market data updates for: MGCZ4.COMEX (MGCZ24). ID: 14 Service code: comex
2024-09-24 11:46:44.591 | Denali Data Feed | Requesting security definition data for: MGCZ4.COMEX (MGCZ24). ID: 14
2024-09-24 11:46:44.591 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 11:46:44.591 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 11:46:44.618 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 11:46:44.618 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 15 Service code: cme
2024-09-24 11:46:44.618 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 15
2024-09-24 11:46:44.618 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 11:46:44.618 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.618 | Triggering next historical data download in queue.
2024-09-24 11:46:44.632 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 16 Service code: fxstatscalc
2024-09-24 11:46:44.632 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443
2024-09-24 11:46:44.632 | SC Data with Depth | Requesting security definition data for: USDX. ID: 16
2024-09-24 11:46:44.632 | Added historical Intraday data request for USDX to the queue.
2024-09-24 11:46:44.632 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2024-09-24 11:46:44.632 | Triggering next historical data download in queue.
2024-09-24 11:46:44.748 | DTC Client socket (4) | Creating socket.
2024-09-24 11:46:44.748 | DTC Client socket (4) | New receive buffer size: 0
2024-09-24 11:46:44.748 | DTC Client socket (4) | Connecting to IP: 67.214.125.7.
2024-09-24 11:46:45.027 | SC Data with Depth | Network connection to server complete.
2024-09-24 11:46:45.027 | SC Data with Depth | Starting socket receive thread.
2024-09-24 11:46:45.027 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 11:46:45.311 | SC Data with Depth | Setting DTC encoding to Binary VLS
2024-09-24 11:46:45.311 | SC Data with Depth | Sending logon request message.
2024-09-24 11:46:46.099 | SC Data with Depth | Received logon response.
2024-09-24 11:46:46.099 | SC Data with Depth | Server Name: SC Realtime Server.
2024-09-24 11:46:46.099 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2024-09-24 11:46:46.099 | SC Data with Depth | Successfully connected.
2024-09-24 11:46:46.099 | SC Data with Depth | Trading is not supported.
2024-09-24 11:46:46.099 | SC Data with Depth | MarketDepthIsSupported: 1
2024-09-24 11:46:46.099 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2024-09-24 11:46:46.674 | Denali Data Feed | Received logon response.
2024-09-24 11:46:46.674 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-24 11:46:46.674 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-24 11:46:46.674 | Denali Data Feed | Successfully connected.
2024-09-24 11:46:46.674 | Denali Data Feed | Trading is not supported.
2024-09-24 11:46:46.674 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: 6AZ4.CME -> 6AZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: 6JZ4.CME -> 6JZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: CLX4.NYMEX -> CLX24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ4.CME -> ESZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: M6AZ4.CME -> M6AZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MCLU4.NYMEX -> MCLU24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ4.CME -> MESZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MGCZ4.COMEX -> MGCZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MJYZ4.CME -> MJYZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ4.CME -> MNQZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2024-09-24 11:46:46.888 | SC Data with Depth | Received security definition for symbol USDX
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-24 11:46:47.370 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-24 11:46:47.370 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-24 11:46:49.597 | Requesting market depth updates for: 6AZ4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: 6JZ4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: CLX4.NYMEX if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: GCZ4.COMEX if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: MESU4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-24 11:46:52.994 | HD Request # 91 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 11:46:52.994 | HD Request # 91 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.178000
2024-09-24 11:46:52.994 | HD Request # 91 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:46:53.106 | Socket (5) | Creating socket.
2024-09-24 11:46:53.106 | Socket (5) | New receive buffer size: 0
2024-09-24 11:46:53.106 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:53.680 | HD Request # 91 | Setting DTC encoding to Binary VLS
2024-09-24 11:46:53.680 | HD Request # 91 | Sending historical data logon request message.
2024-09-24 11:46:54.450 | HD Request # 91 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: MESZ24
2024-09-24 11:46:54.729 | HD Request # 91 | Decompressing data.
2024-09-24 11:46:55.009 | HD Request # 91 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 11:45:40.163000
2024-09-24 11:46:55.009 | Socket (5) | CloseSocket call.
2024-09-24 11:46:55.009 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:55.036 | Historical data download thread signaled to stop.
2024-09-24 11:46:55.036 | HD Request # 91 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.961000.
2024-09-24 11:46:55.036 | HD Request # 91 | Received 1026 Intraday data records from 2024-09-24 11:45:40.163000 to 2024-09-24 11:46:55.527000 (75.4 seconds. Delay: -0.5 seconds) and wrote 1024 records for MESZ4.CME
2024-09-24 11:46:55.036 | HD Request # 91 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:46:55.527000
2024-09-24 11:46:55.036 | Added 9 Time and Sales records to Intraday data file for MESZ4.CME after download.
2024-09-24 11:46:55.036 | HD Request # 91 | Completion time: 3s.
2024-09-24 11:46:55.036 | HD Request # 91 | Intraday data download complete for MESZ4.CME. Unique request ID: 91
2024-09-24 11:46:55.036 | Removing historical data download ID 91.
2024-09-24 11:46:55.036 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 11:46:55.036 | Intraday chart data file opened for MESZ4.CME
2024-09-24 11:46:55.036 | HD Request # 91 | Enabling Intraday chart updating for symbol.
2024-09-24 11:46:55.036 | Triggering next historical data download in queue.
2024-09-24 11:46:55.036 | HD Request # 92 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 11:46:55.037 | HD Request # 92 | Download start date-time: 2024-09-24 11:19:41.000000. File last date-time: 2024-09-24 11:19:41.593000
2024-09-24 11:46:55.037 | HD Request # 92 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:46:55.037 | Socket (6) | Creating socket.
2024-09-24 11:46:55.037 | Socket (6) | New receive buffer size: 0
2024-09-24 11:46:55.037 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:55.288 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:46:55.288 | Socket (5) | Closed.
2024-09-24 11:46:55.590 | HD Request # 92 | Setting DTC encoding to Binary VLS
2024-09-24 11:46:55.590 | HD Request # 92 | Sending historical data logon request message.
2024-09-24 11:46:56.351 | HD Request # 92 | Requesting Intraday data. Start date-time: 2024-09-24 11:19:41. Record interval: 0. Symbol: MJYZ24
2024-09-24 11:46:56.621 | HD Request # 92 | Decompressing data.
2024-09-24 11:46:56.622 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 3296
2024-09-24 11:46:56.890 | HD Request # 92 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 11:19:41.593000
2024-09-24 11:46:56.890 | Socket (6) | CloseSocket call.
2024-09-24 11:46:56.890 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:56.910 | Historical data download thread signaled to stop.
2024-09-24 11:46:56.910 | HD Request # 92 | Received 1 Intraday data record from 2024-09-24 11:19:41.593000 to 2024-09-24 11:19:41.593000 (0.0 seconds. Delay: 27.3 minutes) and wrote 0 records for MJYZ4.CME
2024-09-24 11:46:56.910 | HD Request # 92 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:19:41.593000
2024-09-24 11:46:56.910 | HD Request # 92 | Completion time: 1s.
2024-09-24 11:46:56.910 | HD Request # 92 | Intraday data download complete for MJYZ4.CME. Unique request ID: 92
2024-09-24 11:46:56.910 | Removing historical data download ID 92.
2024-09-24 11:46:56.910 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 11:46:56.910 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 11:46:56.910 | HD Request # 92 | Enabling Intraday chart updating for symbol.
2024-09-24 11:46:56.910 | Triggering next historical data download in queue.
2024-09-24 11:46:56.910 | HD Request # 93 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 11:46:56.910 | HD Request # 93 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.546000
2024-09-24 11:46:56.910 | HD Request # 93 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:46:56.910 | Socket (5) | Creating socket.
2024-09-24 11:46:56.910 | Socket (5) | New receive buffer size: 0
2024-09-24 11:46:56.910 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:57.159 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:46:57.159 | Socket (6) | Closed.
2024-09-24 11:46:57.461 | HD Request # 93 | Setting DTC encoding to Binary VLS
2024-09-24 11:46:57.461 | HD Request # 93 | Sending historical data logon request message.
2024-09-24 11:46:57.730 | HD Request # 93 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: NQZ24
2024-09-24 11:46:58.000 | HD Request # 93 | Decompressing data.
2024-09-24 11:46:58.279 | HD Request # 93 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 11:45:40.005000
2024-09-24 11:46:58.279 | Socket (5) | CloseSocket call.
2024-09-24 11:46:58.279 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:58.280 | Historical data download thread signaled to stop.
2024-09-24 11:46:58.280 | HD Request # 93 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.767000.
2024-09-24 11:46:58.281 | HD Request # 93 | Received 1559 Intraday data records from 2024-09-24 11:45:40.005000 to 2024-09-24 11:46:59.453002 (79.4 seconds. Delay: -1.2 seconds) and wrote 1543 records for NQZ4.CME
2024-09-24 11:46:58.281 | HD Request # 93 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:46:59.453002
2024-09-24 11:46:58.281 | Added 2 Time and Sales records to Intraday data file for NQZ4.CME after download.
2024-09-24 11:46:58.281 | HD Request # 93 | Completion time: 2s.
2024-09-24 11:46:58.281 | HD Request # 93 | Intraday data download complete for NQZ4.CME. Unique request ID: 93
2024-09-24 11:46:58.281 | Removing historical data download ID 93.
2024-09-24 11:46:58.281 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 11:46:58.281 | Intraday chart data file opened for NQZ4.CME
2024-09-24 11:46:58.281 | HD Request # 93 | Enabling Intraday chart updating for symbol.
2024-09-24 11:46:58.281 | Triggering next historical data download in queue.
2024-09-24 11:46:58.281 | HD Request # 94 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 11:46:58.282 | HD Request # 94 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 11:46:58.282 | HD Request # 94 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:46:58.282 | Socket (6) | Creating socket.
2024-09-24 11:46:58.282 | Socket (6) | New receive buffer size: 0
2024-09-24 11:46:58.282 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:58.548 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:46:58.548 | Socket (5) | Closed.
2024-09-24 11:46:58.841 | HD Request # 94 | Setting DTC encoding to Binary VLS
2024-09-24 11:46:58.841 | HD Request # 94 | Sending historical data logon request message.
2024-09-24 11:46:59.110 | HD Request # 94 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 11:46:59.390 | HD Request # 94 | Decompressing data.
2024-09-24 11:46:59.660 | HD Request # 94 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 11:46:59.660 | Socket (6) | CloseSocket call.
2024-09-24 11:46:59.660 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:59.661 | Historical data download thread signaled to stop.
2024-09-24 11:46:59.661 | HD Request # 94 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 4.1 days) and wrote 0 records for MESU4.CME
2024-09-24 11:46:59.661 | HD Request # 94 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 11:46:59.661 | HD Request # 94 | Completion time: 1s.
2024-09-24 11:46:59.661 | HD Request # 94 | Intraday data download complete for MESU4.CME. Unique request ID: 94
2024-09-24 11:46:59.661 | Removing historical data download ID 94.
2024-09-24 11:46:59.661 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 11:46:59.661 | Intraday chart data file opened for MESU4.CME
2024-09-24 11:46:59.661 | HD Request # 94 | Enabling Intraday chart updating for symbol.
2024-09-24 11:46:59.661 | Triggering next historical data download in queue.
2024-09-24 11:46:59.661 | HD Request # 95 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 11:46:59.661 | HD Request # 95 | Download start date-time: 2024-09-24 11:45:17.000000. File last date-time: 2024-09-24 11:45:17.821000
2024-09-24 11:46:59.661 | HD Request # 95 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:46:59.661 | Socket (5) | Creating socket.
2024-09-24 11:46:59.661 | Socket (5) | New receive buffer size: 0
2024-09-24 11:46:59.661 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:59.931 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:46:59.931 | Socket (6) | Closed.
2024-09-24 11:47:00.232 | HD Request # 95 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:00.232 | HD Request # 95 | Sending historical data logon request message.
2024-09-24 11:47:00.512 | HD Request # 95 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:17. Record interval: 0. Symbol: 6AZ24
2024-09-24 11:47:00.791 | HD Request # 95 | Decompressing data.
2024-09-24 11:47:01.069 | HD Request # 95 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 11:45:17.821000
2024-09-24 11:47:01.070 | Socket (5) | CloseSocket call.
2024-09-24 11:47:01.070 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:01.070 | Historical data download thread signaled to stop.
2024-09-24 11:47:01.070 | HD Request # 95 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:49.371000.
2024-09-24 11:47:01.070 | HD Request # 95 | Received 47 Intraday data records from 2024-09-24 11:45:17.821000 to 2024-09-24 11:46:54.612001 (96.8 seconds. Delay: 6.5 seconds) and wrote 46 records for 6AZ4.CME
2024-09-24 11:47:01.070 | HD Request # 95 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:46:54.612001
2024-09-24 11:47:01.070 | Added 9 Time and Sales records to Intraday data file for 6AZ4.CME after download.
2024-09-24 11:47:01.070 | HD Request # 95 | Completion time: 2s.
2024-09-24 11:47:01.070 | HD Request # 95 | Intraday data download complete for 6AZ4.CME. Unique request ID: 95
2024-09-24 11:47:01.070 | Removing historical data download ID 95.
2024-09-24 11:47:01.070 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 11:47:01.070 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 11:47:01.070 | HD Request # 95 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:01.070 | Triggering next historical data download in queue.
2024-09-24 11:47:01.070 | HD Request # 96 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 11:47:01.071 | HD Request # 96 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.526000
2024-09-24 11:47:01.071 | HD Request # 96 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:01.071 | Socket (6) | Creating socket.
2024-09-24 11:47:01.071 | Socket (6) | New receive buffer size: 0
2024-09-24 11:47:01.071 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:01.350 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:01.350 | Socket (5) | Closed.
2024-09-24 11:47:01.618 | HD Request # 96 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:01.618 | HD Request # 96 | Sending historical data logon request message.
2024-09-24 11:47:01.657 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:01.887 | HD Request # 96 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: ESZ24
2024-09-24 11:47:02.156 | HD Request # 96 | Decompressing data.
2024-09-24 11:47:02.428 | HD Request # 96 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 11:45:40.525000
2024-09-24 11:47:02.428 | Socket (6) | CloseSocket call.
2024-09-24 11:47:02.428 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:02.453 | Historical data download thread signaled to stop.
2024-09-24 11:47:02.453 | HD Request # 96 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.986000.
2024-09-24 11:47:02.453 | HD Request # 96 | Received 1954 Intraday data records from 2024-09-24 11:45:40.525000 to 2024-09-24 11:47:03.398000 (82.9 seconds. Delay: -0.9 seconds) and wrote 1944 records for ESZ4.CME
2024-09-24 11:47:02.453 | HD Request # 96 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:03.398000
2024-09-24 11:47:02.453 | HD Request # 96 | Completion time: 1s.
2024-09-24 11:47:02.453 | HD Request # 96 | Intraday data download complete for ESZ4.CME. Unique request ID: 96
2024-09-24 11:47:02.453 | Removing historical data download ID 96.
2024-09-24 11:47:02.453 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 11:47:02.453 | Intraday chart data file opened for ESZ4.CME
2024-09-24 11:47:02.453 | HD Request # 96 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:02.453 | Triggering next historical data download in queue.
2024-09-24 11:47:02.453 | HD Request # 97 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 11:47:02.453 | HD Request # 97 | Download start date-time: 2024-09-24 11:42:50.000000. File last date-time: 2024-09-24 11:42:50.872000
2024-09-24 11:47:02.454 | HD Request # 97 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:47:02.454 | Socket (5) | Creating socket.
2024-09-24 11:47:02.454 | Socket (5) | New receive buffer size: 0
2024-09-24 11:47:02.454 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:02.697 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:02.697 | Socket (6) | Closed.
2024-09-24 11:47:03.024 | HD Request # 97 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:03.024 | HD Request # 97 | Sending historical data logon request message.
2024-09-24 11:47:03.303 | HD Request # 97 | Requesting Intraday data. Start date-time: 2024-09-24 11:42:50. Record interval: 0. Symbol: M6AZ24
2024-09-24 11:47:03.321 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Creating socket. Using TLS 1.2.
2024-09-24 11:47:03.321 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | New receive buffer size: 0
2024-09-24 11:47:03.321 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Connecting to IP: 216.66.0.130.
2024-09-24 11:47:03.582 | HD Request # 97 | Decompressing data.
2024-09-24 11:47:03.860 | HD Request # 97 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 11:42:50.872000
2024-09-24 11:47:03.860 | Socket (5) | CloseSocket call.
2024-09-24 11:47:03.860 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:03.871 | Historical data download thread signaled to stop.
2024-09-24 11:47:03.871 | HD Request # 97 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:49.372000.
2024-09-24 11:47:03.871 | HD Request # 97 | Received 5 Intraday data records from 2024-09-24 11:42:50.872000 to 2024-09-24 11:46:12.835000 (3.4 minutes. Delay: 51.0 seconds) and wrote 4 records for M6AZ4.CME
2024-09-24 11:47:03.871 | HD Request # 97 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:46:12.835000
2024-09-24 11:47:03.871 | HD Request # 97 | Completion time: 1s.
2024-09-24 11:47:03.871 | HD Request # 97 | Intraday data download complete for M6AZ4.CME. Unique request ID: 97
2024-09-24 11:47:03.871 | Removing historical data download ID 97.
2024-09-24 11:47:03.871 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 11:47:03.871 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 11:47:03.871 | HD Request # 97 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:03.871 | Triggering next historical data download in queue.
2024-09-24 11:47:03.871 | HD Request # 98 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 11:47:03.872 | HD Request # 98 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 11:47:03.872 | HD Request # 98 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:03.872 | Socket (7) | Creating socket.
2024-09-24 11:47:03.872 | Socket (7) | New receive buffer size: 0
2024-09-24 11:47:03.872 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:04.139 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:04.139 | Socket (5) | Closed.
2024-09-24 11:47:04.434 | HD Request # 98 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:04.434 | HD Request # 98 | Sending historical data logon request message.
2024-09-24 11:47:04.711 | HD Request # 98 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 11:47:04.990 | HD Request # 98 | Decompressing data.
2024-09-24 11:47:05.267 | HD Request # 98 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 11:47:05.267 | Socket (7) | CloseSocket call.
2024-09-24 11:47:05.267 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:05.286 | Historical data download thread signaled to stop.
2024-09-24 11:47:05.286 | HD Request # 98 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 35.9 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 11:47:05.287 | HD Request # 98 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 11:47:05.287 | HD Request # 98 | Completion time: 2s.
2024-09-24 11:47:05.287 | HD Request # 98 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 98
2024-09-24 11:47:05.287 | Removing historical data download ID 98.
2024-09-24 11:47:05.287 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 11:47:05.287 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 11:47:05.287 | HD Request # 98 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:05.287 | Triggering next historical data download in queue.
2024-09-24 11:47:05.287 | HD Request # 99 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 11:47:05.287 | HD Request # 99 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.177004
2024-09-24 11:47:05.287 | HD Request # 99 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:47:05.287 | Socket (8) | Creating socket.
2024-09-24 11:47:05.287 | Socket (8) | New receive buffer size: 0
2024-09-24 11:47:05.287 | Socket (8) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:05.435 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | CloseSocket call.
2024-09-24 11:47:05.435 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:05.544 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 11:47:05.544 | Socket (7) | Closed.
2024-09-24 11:47:05.689 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:05.689 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Closed.
2024-09-24 11:47:05.858 | HD Request # 99 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:05.858 | HD Request # 99 | Sending historical data logon request message.
2024-09-24 11:47:06.139 | HD Request # 99 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: CLX24
2024-09-24 11:47:06.419 | HD Request # 99 | Decompressing data.
2024-09-24 11:47:06.699 | HD Request # 99 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 11:45:40.177000
2024-09-24 11:47:06.699 | Socket (8) | CloseSocket call.
2024-09-24 11:47:06.699 | Socket (8) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:06.702 | Historical data download thread signaled to stop.
2024-09-24 11:47:06.702 | HD Request # 99 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:41.162000.
2024-09-24 11:47:06.702 | HD Request # 99 | Received 257 Intraday data records from 2024-09-24 11:45:40.177000 to 2024-09-24 11:47:05.117007 (84.9 seconds. Delay: 1.6 seconds) and wrote 252 records for CLX4.NYMEX
2024-09-24 11:47:06.702 | HD Request # 99 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:05.117007
2024-09-24 11:47:06.702 | Added 2 Time and Sales records to Intraday data file for CLX4.NYMEX after download.
2024-09-24 11:47:06.702 | HD Request # 99 | Completion time: 1s.
2024-09-24 11:47:06.702 | HD Request # 99 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 99
2024-09-24 11:47:06.702 | Removing historical data download ID 99.
2024-09-24 11:47:06.702 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 11:47:06.702 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 11:47:06.702 | HD Request # 99 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:06.702 | Triggering next historical data download in queue.
2024-09-24 11:47:06.702 | HD Request # 100 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 11:47:06.702 | HD Request # 100 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.439000
2024-09-24 11:47:06.702 | HD Request # 100 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:06.702 | Socket (5) | Creating socket.
2024-09-24 11:47:06.702 | Socket (5) | New receive buffer size: 0
2024-09-24 11:47:06.702 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:06.705 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:06.706 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:06.979 | Socket (8) | Socket gracefully closed by remote side.
2024-09-24 11:47:06.979 | Socket (8) | Closed.
2024-09-24 11:47:07.267 | HD Request # 100 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:07.267 | HD Request # 100 | Sending historical data logon request message.
2024-09-24 11:47:07.542 | HD Request # 100 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: 6JZ24
2024-09-24 11:47:07.819 | HD Request # 100 | Decompressing data.
2024-09-24 11:47:08.094 | HD Request # 100 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 11:45:40.439000
2024-09-24 11:47:08.094 | Socket (5) | CloseSocket call.
2024-09-24 11:47:08.094 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:08.103 | Historical data download thread signaled to stop.
2024-09-24 11:47:08.103 | HD Request # 100 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:44.453000.
2024-09-24 11:47:08.103 | HD Request # 100 | Received 82 Intraday data records from 2024-09-24 11:45:40.439000 to 2024-09-24 11:47:02.393000 (82.0 seconds. Delay: 5.7 seconds) and wrote 81 records for 6JZ4.CME
2024-09-24 11:47:08.103 | HD Request # 100 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:02.393000
2024-09-24 11:47:08.103 | HD Request # 100 | Completion time: 2s.
2024-09-24 11:47:08.103 | HD Request # 100 | Intraday data download complete for 6JZ4.CME. Unique request ID: 100
2024-09-24 11:47:08.103 | Removing historical data download ID 100.
2024-09-24 11:47:08.103 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 11:47:08.103 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 11:47:08.103 | HD Request # 100 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:08.103 | Triggering next historical data download in queue.
2024-09-24 11:47:08.103 | HD Request # 101 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 11:47:08.103 | HD Request # 101 | Download start date-time: 2024-09-24 11:45:39.000000. File last date-time: 2024-09-24 11:45:39.150001
2024-09-24 11:47:08.103 | HD Request # 101 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:47:08.104 | Socket (6) | Creating socket.
2024-09-24 11:47:08.104 | Socket (6) | New receive buffer size: 0
2024-09-24 11:47:08.104 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:08.369 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:08.369 | Socket (5) | Closed.
2024-09-24 11:47:08.669 | HD Request # 101 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:08.669 | HD Request # 101 | Sending historical data logon request message.
2024-09-24 11:47:08.945 | HD Request # 101 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:39. Record interval: 0. Symbol: GCZ24
2024-09-24 11:47:09.222 | HD Request # 101 | Decompressing data.
2024-09-24 11:47:09.499 | HD Request # 101 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 11:45:39.150000
2024-09-24 11:47:09.499 | Socket (6) | CloseSocket call.
2024-09-24 11:47:09.499 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:09.522 | Historical data download thread signaled to stop.
2024-09-24 11:47:09.522 | HD Request # 101 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.994000.
2024-09-24 11:47:09.523 | HD Request # 101 | Received 378 Intraday data records from 2024-09-24 11:45:39.150000 to 2024-09-24 11:47:08.675000 (89.5 seconds. Delay: 0.8 seconds) and wrote 376 records for GCZ4.COMEX
2024-09-24 11:47:09.523 | HD Request # 101 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:08.675000
2024-09-24 11:47:09.523 | Added 1 Time and Sales records to Intraday data file for GCZ4.COMEX after download.
2024-09-24 11:47:09.523 | HD Request # 101 | Completion time: 1s.
2024-09-24 11:47:09.523 | HD Request # 101 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 101
2024-09-24 11:47:09.523 | Removing historical data download ID 101.
2024-09-24 11:47:09.523 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 11:47:09.523 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 11:47:09.523 | HD Request # 101 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:09.523 | Triggering next historical data download in queue.
2024-09-24 11:47:09.523 | HD Request # 102 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 11:47:09.524 | HD Request # 102 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 11:47:09.524 | HD Request # 102 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:09.524 | Socket (5) | Creating socket.
2024-09-24 11:47:09.524 | Socket (5) | New receive buffer size: 0
2024-09-24 11:47:09.524 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:09.775 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:09.775 | Socket (6) | Closed.
2024-09-24 11:47:10.102 | HD Request # 102 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:10.102 | HD Request # 102 | Sending historical data logon request message.
2024-09-24 11:47:10.383 | HD Request # 102 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 11:47:10.665 | HD Request # 102 | Decompressing data.
2024-09-24 11:47:10.946 | HD Request # 102 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 11:47:10.946 | Socket (5) | CloseSocket call.
2024-09-24 11:47:10.946 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:10.956 | Historical data download thread signaled to stop.
2024-09-24 11:47:10.956 | HD Request # 102 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 4.1 days) and wrote 0 records for ESU4.CME
2024-09-24 11:47:10.956 | HD Request # 102 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 11:47:10.956 | HD Request # 102 | Completion time: 1s.
2024-09-24 11:47:10.956 | HD Request # 102 | Intraday data download complete for ESU4.CME. Unique request ID: 102
2024-09-24 11:47:10.956 | Removing historical data download ID 102.
2024-09-24 11:47:10.957 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 11:47:10.957 | Intraday chart data file opened for ESU4.CME
2024-09-24 11:47:10.957 | HD Request # 102 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:10.957 | Triggering next historical data download in queue.
2024-09-24 11:47:10.957 | HD Request # 103 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 11:47:10.957 | HD Request # 103 | Download start date-time: 2024-09-24 11:45:38.000000. File last date-time: 2024-09-24 11:45:38.778001
2024-09-24 11:47:10.957 | HD Request # 103 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:47:10.957 | Socket (6) | Creating socket.
2024-09-24 11:47:10.957 | Socket (6) | New receive buffer size: 0
2024-09-24 11:47:10.957 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:11.228 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:11.228 | Socket (5) | Closed.
2024-09-24 11:47:11.506 | HD Request # 103 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:11.506 | HD Request # 103 | Sending historical data logon request message.
2024-09-24 11:47:11.750 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\CLX4.NYMEX.scid. Thread ID: 3296
2024-09-24 11:47:11.750 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 11:47:11.775 | HD Request # 103 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:38. Record interval: 0. Symbol: MGCZ24
2024-09-24 11:47:12.045 | HD Request # 103 | Decompressing data.
2024-09-24 11:47:12.314 | HD Request # 103 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 11:45:38.778000
2024-09-24 11:47:12.315 | Socket (6) | CloseSocket call.
2024-09-24 11:47:12.315 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:12.320 | Historical data download thread signaled to stop.
2024-09-24 11:47:12.320 | HD Request # 103 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:41.541000.
2024-09-24 11:47:12.320 | HD Request # 103 | Received 213 Intraday data records from 2024-09-24 11:45:38.778000 to 2024-09-24 11:47:12.202001 (93.4 seconds. Delay: 0.1 seconds) and wrote 211 records for MGCZ4.COMEX
2024-09-24 11:47:12.320 | HD Request # 103 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:12.202001
2024-09-24 11:47:12.320 | HD Request # 103 | Completion time: 2s.
2024-09-24 11:47:12.320 | HD Request # 103 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 103
2024-09-24 11:47:12.320 | Removing historical data download ID 103.
2024-09-24 11:47:12.320 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 11:47:12.320 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 11:47:12.320 | HD Request # 103 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:12.320 | Triggering next historical data download in queue.
2024-09-24 11:47:12.320 | HD Request # 104 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 11:47:12.321 | HD Request # 104 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.586000
2024-09-24 11:47:12.321 | HD Request # 104 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:12.321 | Socket (5) | Creating socket.
2024-09-24 11:47:12.321 | Socket (5) | New receive buffer size: 0
2024-09-24 11:47:12.321 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:12.583 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:12.584 | Socket (6) | Closed.
2024-09-24 11:47:12.877 | HD Request # 104 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:12.877 | HD Request # 104 | Sending historical data logon request message.
2024-09-24 11:47:13.147 | HD Request # 104 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: MNQZ24
2024-09-24 11:47:13.419 | HD Request # 104 | Decompressing data.
2024-09-24 11:47:13.971 | HD Request # 104 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 11:45:40.005000
2024-09-24 11:47:13.972 | Socket (5) | CloseSocket call.
2024-09-24 11:47:13.972 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:13.985 | Historical data download thread signaled to stop.
2024-09-24 11:47:13.985 | HD Request # 104 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.692000.
2024-09-24 11:47:13.985 | HD Request # 104 | Received 4065 Intraday data records from 2024-09-24 11:45:40.005000 to 2024-09-24 11:47:11.548006 (91.5 seconds. Delay: 2.4 seconds) and wrote 4024 records for MNQZ4.CME
2024-09-24 11:47:13.985 | HD Request # 104 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:11.548006
2024-09-24 11:47:13.986 | Added 115 Time and Sales records to Intraday data file for MNQZ4.CME after download.
2024-09-24 11:47:13.986 | HD Request # 104 | Completion time: 1s.
2024-09-24 11:47:13.986 | HD Request # 104 | Intraday data download complete for MNQZ4.CME. Unique request ID: 104
2024-09-24 11:47:13.986 | Removing historical data download ID 104.
2024-09-24 11:47:13.986 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 11:47:13.986 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 11:47:13.986 | HD Request # 104 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:13.986 | Triggering next historical data download in queue.
2024-09-24 11:47:13.986 | HD Request # 105 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2024-09-24 11:47:13.986 | HD Request # 105 | Download start date-time: 2024-09-24 11:46:39.000000. File last date-time: 2024-09-24 11:46:39.000000
2024-09-24 11:47:13.986 | HD Request # 105 | Using server: ds4.sierracharts.com port 10149
2024-09-24 11:47:13.986 | Socket (6) | Creating socket.
2024-09-24 11:47:13.986 | Socket (6) | New receive buffer size: 0
2024-09-24 11:47:13.986 | Socket (6) | Connecting to IP: 67.214.125.7.
2024-09-24 11:47:14.244 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:14.244 | Socket (5) | Closed.
2024-09-24 11:47:14.550 | HD Request # 105 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:14.550 | HD Request # 105 | Sending historical data logon request message.
2024-09-24 11:47:15.304 | HD Request # 105 | Requesting Intraday data. Start date-time: 2024-09-24 11:46:39. Record interval: 0. Symbol: USDX
2024-09-24 11:47:15.582 | HD Request # 105 | Decompressing data.
2024-09-24 11:47:15.860 | HD Request # 105 | Receiving Intraday data for USDX starting at 2024-09-24 11:46:39.000000
2024-09-24 11:47:15.860 | Socket (6) | CloseSocket call.
2024-09-24 11:47:15.860 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:15.870 | Historical data download thread signaled to stop.
2024-09-24 11:47:15.870 | HD Request # 105 | Timestamp of first Intraday data file record written: 2024-09-24 11:46:40.000000.
2024-09-24 11:47:15.870 | HD Request # 105 | Received 39 Intraday data records from 2024-09-24 11:46:39.000000 to 2024-09-24 11:47:17.000000 (38.0 seconds. Delay: -1.1 seconds) and wrote 38 records for USDX
2024-09-24 11:47:15.871 | HD Request # 105 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:17.000000
2024-09-24 11:47:15.871 | HD Request # 105 | Completion time: 2s.
2024-09-24 11:47:15.871 | HD Request # 105 | Intraday data download complete for USDX. Unique request ID: 105
2024-09-24 11:47:15.871 | Removing historical data download ID 105.
2024-09-24 11:47:15.871 | Real-time Intraday chart data file updates started for USDX
2024-09-24 11:47:15.871 | Intraday chart data file opened for USDX
2024-09-24 11:47:15.871 | HD Request # 105 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:15.871 | No download requests in the queue to start downloads for.
2024-09-24 11:47:16.138 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:16.139 | Socket (6) | Closed.
2024-09-24 11:47:16.768 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6JZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:16.769 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 11:47:16.769 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:16.769 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 3296
2024-09-24 11:47:46.945 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AZ4.CME.scid. Thread ID: 3296
2024-09-24 11:53:39.263 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MJYZ4.CME.scid. Thread ID: 3296
2024-09-24 12:17:06.655 | File >> Reconnect selected.
2024-09-24 12:17:06.920 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 12:17:06.920 | DTC Client socket (1) | CloseSocket call.
2024-09-24 12:17:06.920 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-09-24 12:17:06.920 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-09-24 12:17:06.920 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:06.921 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 12:17:06.921 | DTC Client socket (2) | CloseSocket call.
2024-09-24 12:17:06.921 | DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0
2024-09-24 12:17:06.921 | Denali Data Feed | Disconnected from the server.
2024-09-24 12:17:06.921 | SC Data with Depth | Waiting for socket receive thread to end
2024-09-24 12:17:06.921 | DTC Client socket (4) | CloseSocket call.
2024-09-24 12:17:06.921 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:06.921 | SC Data with Depth | Disconnected from the server.
2024-09-24 12:17:06.921 | Rithmic Direct - DTC | Disconnected.
2024-09-24 12:17:06.921 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 12:17:07.168 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 12:17:07.168 | DTC Client socket (1) | Closed.
2024-09-24 12:17:07.506 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-09-24 12:17:07.506 | DTC Client socket (4) | Closed.
2024-09-24 12:17:10.918 |
2024-09-24 12:17:10.918 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 12:17:10.918 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 12:17:10.918 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 12:17:11.250 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 12:17:11.250 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 12:17:11.250 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 12:17:11.519 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 12:17:11.519 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 12:17:11.519 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 12:17:11.519 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Write has completed. Shutdown being performed.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Closed.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Received logon response.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Server Name: .
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 12:17:12.340 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 12:17:12.340 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 12:17:12.340 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 12:17:12.340 | Using symbol data fast lookup vector
2024-09-24 12:17:12.340 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 12:17:12.340 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 12:17:12.340 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 12:17:12.340 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 12:17:12.340 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 12:17:12.340 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 12:17:12.340 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 12:17:12.340 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 12:17:12.340 | DTC Client socket (2) | Creating socket.
2024-09-24 12:17:12.340 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 12:17:12.340 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 12:17:12.637 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2024-09-24 12:17:12.638 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 3 Service code: comex
2024-09-24 12:17:12.638 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 3
2024-09-24 12:17:12.638 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 12:17:12.638 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 12:17:12.638 | Triggering next historical data download in queue.
2024-09-24 12:17:12.662 | Delaying start of download for GCZ4.COMEX.
2024-09-24 12:17:12.663 | Mapping 6AZ4.CME to 6AZ24. Service code: cme
2024-09-24 12:17:12.663 | Denali Data Feed | Starting real-time market data updates for: 6AZ4.CME (6AZ24). ID: 4 Service code: cme
2024-09-24 12:17:12.663 | Denali Data Feed | Requesting security definition data for: 6AZ4.CME (6AZ24). ID: 4
2024-09-24 12:17:12.663 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 12:17:12.663 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.663 | Triggering next historical data download in queue.
2024-09-24 12:17:12.696 | Mapping CLX4.NYMEX to CLX24. Service code: nymex
2024-09-24 12:17:12.696 | Denali Data Feed | Starting real-time market data updates for: CLX4.NYMEX (CLX24). ID: 5 Service code: nymex
2024-09-24 12:17:12.696 | Denali Data Feed | Requesting security definition data for: CLX4.NYMEX (CLX24). ID: 5
2024-09-24 12:17:12.696 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 12:17:12.696 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 12:17:12.696 | Triggering next historical data download in queue.
2024-09-24 12:17:12.697 | Mapping 6JZ4.CME to 6JZ24. Service code: cme
2024-09-24 12:17:12.697 | Denali Data Feed | Starting real-time market data updates for: 6JZ4.CME (6JZ24). ID: 6 Service code: cme
2024-09-24 12:17:12.697 | Denali Data Feed | Requesting security definition data for: 6JZ4.CME (6JZ24). ID: 6
2024-09-24 12:17:12.697 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 12:17:12.697 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.697 | Triggering next historical data download in queue.
2024-09-24 12:17:12.747 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 12:17:12.747 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 7 Service code: cme
2024-09-24 12:17:12.747 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 7
2024-09-24 12:17:12.747 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 12:17:12.747 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.747 | Triggering next historical data download in queue.
2024-09-24 12:17:12.840 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 12:17:12.840 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 8 Service code: cme
2024-09-24 12:17:12.840 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 8
2024-09-24 12:17:12.840 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 12:17:12.840 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.840 | Triggering next historical data download in queue.
2024-09-24 12:17:12.913 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 12:17:12.913 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 9 Service code: cme
2024-09-24 12:17:12.913 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 9
2024-09-24 12:17:12.944 | Mapping MJYZ4.CME to MJYZ24. Service code: cme
2024-09-24 12:17:12.944 | Denali Data Feed | Starting real-time market data updates for: MJYZ4.CME (MJYZ24). ID: 10 Service code: cme
2024-09-24 12:17:12.944 | Denali Data Feed | Requesting security definition data for: MJYZ4.CME (MJYZ24). ID: 10
2024-09-24 12:17:12.944 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 12:17:12.944 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.944 | Triggering next historical data download in queue.
2024-09-24 12:17:12.944 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 12:17:12.944 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 12:17:13.310 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 12:17:13.310 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 12:17:13.310 | Triggering next historical data download in queue.
2024-09-24 12:17:13.311 | Mapping M6AZ4.CME to M6AZ24. Service code: cme
2024-09-24 12:17:13.311 | Denali Data Feed | Starting real-time market data updates for: M6AZ4.CME (M6AZ24). ID: 11 Service code: cme
2024-09-24 12:17:13.311 | Denali Data Feed | Requesting security definition data for: M6AZ4.CME (M6AZ24). ID: 11
2024-09-24 12:17:13.311 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 12:17:13.311 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 12:17:13.311 | Triggering next historical data download in queue.
2024-09-24 12:17:13.312 | Mapping MCLU4.NYMEX to MCLU24. Service code: nymex
2024-09-24 12:17:13.312 | Denali Data Feed | Starting real-time market data updates for: MCLU4.NYMEX (MCLU24). ID: 12 Service code: nymex
2024-09-24 12:17:13.312 | Denali Data Feed | Requesting security definition data for: MCLU4.NYMEX (MCLU24). ID: 12
2024-09-24 12:17:13.312 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 12:17:13.312 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 12:17:13.312 | Triggering next historical data download in queue.
2024-09-24 12:17:13.408 | Mapping ESU4.CME to ESU24. Service code: cme
2024-09-24 12:17:13.408 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 13 Service code: cme
2024-09-24 12:17:13.408 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 13
2024-09-24 12:17:13.408 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 12:17:13.408 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 12:17:13.408 | Triggering next historical data download in queue.
2024-09-24 12:17:13.409 | Mapping MGCZ4.COMEX to MGCZ24. Service code: comex
2024-09-24 12:17:13.409 | Denali Data Feed | Starting real-time market data updates for: MGCZ4.COMEX (MGCZ24). ID: 14 Service code: comex
2024-09-24 12:17:13.409 | Denali Data Feed | Requesting security definition data for: MGCZ4.COMEX (MGCZ24). ID: 14
2024-09-24 12:17:13.409 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 12:17:13.409 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 12:17:13.409 | Triggering next historical data download in queue.
2024-09-24 12:17:13.450 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 12:17:13.450 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 15 Service code: cme
2024-09-24 12:17:13.450 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 15
2024-09-24 12:17:13.450 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 12:17:13.450 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 12:17:13.450 | Triggering next historical data download in queue.
2024-09-24 12:17:13.469 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 16 Service code: fxstatscalc
2024-09-24 12:17:13.469 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2024-09-24 12:17:13.469 | SC Data with Depth | Requesting security definition data for: USDX. ID: 16
2024-09-24 12:17:13.469 | Added historical Intraday data request for USDX to the queue.
2024-09-24 12:17:13.469 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2024-09-24 12:17:13.470 | Triggering next historical data download in queue.
2024-09-24 12:17:13.590 | DTC Client socket (4) | Creating socket.
2024-09-24 12:17:13.590 | DTC Client socket (4) | New receive buffer size: 0
2024-09-24 12:17:13.590 | DTC Client socket (4) | Connecting to IP: 69.39.70.241.
2024-09-24 12:17:13.869 | SC Data with Depth | Network connection to server complete.
2024-09-24 12:17:13.869 | SC Data with Depth | Starting socket receive thread.
2024-09-24 12:17:13.870 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 12:17:14.194 | SC Data with Depth | Setting DTC encoding to Binary VLS
2024-09-24 12:17:14.194 | SC Data with Depth | Sending logon request message.
2024-09-24 12:17:15.500 | SC Data with Depth | Received logon response.
2024-09-24 12:17:15.500 | SC Data with Depth | Server Name: SC Realtime Server.
2024-09-24 12:17:15.500 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2024-09-24 12:17:15.500 | SC Data with Depth | Successfully connected.
2024-09-24 12:17:15.500 | SC Data with Depth | Trading is not supported.
2024-09-24 12:17:15.500 | SC Data with Depth | MarketDepthIsSupported: 1
2024-09-24 12:17:15.500 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2024-09-24 12:17:16.282 | SC Data with Depth | Received security definition for symbol USDX
2024-09-24 12:17:17.341 | Requesting market depth updates for: 6AZ4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: 6JZ4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: CLX4.NYMEX if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: GCZ4.COMEX if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: MESU4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 12:17:31.531 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Creating socket. Using TLS 1.2.
2024-09-24 12:17:31.531 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | New receive buffer size: 0
2024-09-24 12:17:31.531 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Connecting to IP: 216.66.0.130.
2024-09-24 12:17:33.277 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | CloseSocket call.
2024-09-24 12:17:33.278 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:33.355 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 12:17:33.355 | DTC Client socket (2) | CloseSocket call.
2024-09-24 12:17:33.355 | DTC Client socket (2) | Closed.
2024-09-24 12:17:33.355 | Denali Data Feed | Failed connections: 1
2024-09-24 12:17:33.355 | DTC Client socket (0) | CloseSocket call.
2024-09-24 12:17:33.355 | Denali Data Feed | Disconnected from the server.
2024-09-24 12:17:33.355 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 12:17:33.526 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:33.526 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Closed.
2024-09-24 12:17:36.358 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 12:17:36.359 | DTC Client socket (2) | Creating socket.
2024-09-24 12:17:36.359 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 12:17:36.359 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 12:17:43.011 | HD Request # 106 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 12:17:43.011 | HD Request # 106 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.775001
2024-09-24 12:17:43.011 | HD Request # 106 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:43.011 | Socket (5) | Creating socket.
2024-09-24 12:17:43.011 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:43.011 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:43.574 | HD Request # 106 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:43.574 | HD Request # 106 | Sending historical data logon request message.
2024-09-24 12:17:44.344 | HD Request # 106 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: GCZ24
2024-09-24 12:17:44.619 | HD Request # 106 | Decompressing data.
2024-09-24 12:17:44.893 | HD Request # 106 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 12:16:48.015000
2024-09-24 12:17:44.893 | Socket (5) | CloseSocket call.
2024-09-24 12:17:44.893 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:44.893 | Historical data download thread signaled to stop.
2024-09-24 12:17:44.894 | HD Request # 106 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:50.680000.
2024-09-24 12:17:44.894 | HD Request # 106 | Received 208 Intraday data records from 2024-09-24 12:16:48.015000 to 2024-09-24 12:17:43.222000 (55.2 seconds. Delay: 1.7 seconds) and wrote 200 records for GCZ4.COMEX
2024-09-24 12:17:44.894 | HD Request # 106 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:43.222000
2024-09-24 12:17:44.894 | HD Request # 106 | Completion time: 1s.
2024-09-24 12:17:44.894 | HD Request # 106 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 106
2024-09-24 12:17:44.894 | Removing historical data download ID 106.
2024-09-24 12:17:44.894 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 12:17:44.894 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 12:17:44.894 | HD Request # 106 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:44.894 | Triggering next historical data download in queue.
2024-09-24 12:17:44.894 | Historical data for GCZ4.COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:44.894 | HD Request # 107 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 12:17:44.894 | HD Request # 107 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.092001
2024-09-24 12:17:44.894 | HD Request # 107 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:44.894 | Socket (6) | Creating socket.
2024-09-24 12:17:44.894 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:44.894 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:45.169 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:45.169 | Socket (5) | Closed.
2024-09-24 12:17:45.471 | HD Request # 107 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:45.471 | HD Request # 107 | Sending historical data logon request message.
2024-09-24 12:17:46.242 | HD Request # 107 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: 6AZ24
2024-09-24 12:17:46.520 | HD Request # 107 | Decompressing data.
2024-09-24 12:17:46.797 | HD Request # 107 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 12:16:48.091000
2024-09-24 12:17:46.797 | Socket (6) | CloseSocket call.
2024-09-24 12:17:46.797 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:46.797 | Historical data download thread signaled to stop.
2024-09-24 12:17:46.797 | HD Request # 107 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:52.039000.
2024-09-24 12:17:46.797 | HD Request # 107 | Received 42 Intraday data records from 2024-09-24 12:16:48.091000 to 2024-09-24 12:17:44.032000 (55.9 seconds. Delay: 2.8 seconds) and wrote 38 records for 6AZ4.CME
2024-09-24 12:17:46.798 | HD Request # 107 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:44.032000
2024-09-24 12:17:46.798 | HD Request # 107 | Completion time: 2s.
2024-09-24 12:17:46.798 | HD Request # 107 | Intraday data download complete for 6AZ4.CME. Unique request ID: 107
2024-09-24 12:17:46.798 | Removing historical data download ID 107.
2024-09-24 12:17:46.798 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 12:17:46.798 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 12:17:46.798 | HD Request # 107 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:46.798 | Triggering next historical data download in queue.
2024-09-24 12:17:46.798 | Historical data for 6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:46.798 | HD Request # 108 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 12:17:46.798 | HD Request # 108 | Download start date-time: 2024-09-24 12:16:47.000000. File last date-time: 2024-09-24 12:16:47.527001
2024-09-24 12:17:46.798 | HD Request # 108 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:46.798 | Socket (5) | Creating socket.
2024-09-24 12:17:46.798 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:46.798 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:47.074 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:47.075 | Socket (6) | Closed.
2024-09-24 12:17:47.348 | HD Request # 108 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:47.348 | HD Request # 108 | Sending historical data logon request message.
2024-09-24 12:17:47.617 | HD Request # 108 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:47. Record interval: 0. Symbol: CLX24
2024-09-24 12:17:47.888 | HD Request # 108 | Decompressing data.
2024-09-24 12:17:48.157 | HD Request # 108 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 12:16:47.527000
2024-09-24 12:17:48.157 | Socket (5) | CloseSocket call.
2024-09-24 12:17:48.157 | Historical data download thread signaled to stop.
2024-09-24 12:17:48.157 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:48.157 | HD Request # 108 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:51.554000.
2024-09-24 12:17:48.157 | HD Request # 108 | Received 155 Intraday data records from 2024-09-24 12:16:47.527000 to 2024-09-24 12:17:46.212001 (58.7 seconds. Delay: 1.9 seconds) and wrote 153 records for CLX4.NYMEX
2024-09-24 12:17:48.158 | HD Request # 108 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:46.212001
2024-09-24 12:17:48.158 | HD Request # 108 | Completion time: 2s.
2024-09-24 12:17:48.158 | HD Request # 108 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 108
2024-09-24 12:17:48.158 | Removing historical data download ID 108.
2024-09-24 12:17:48.158 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 12:17:48.158 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 12:17:48.158 | HD Request # 108 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:48.158 | Triggering next historical data download in queue.
2024-09-24 12:17:48.158 | Historical data for CLX4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:48.158 | HD Request # 109 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 12:17:48.158 | HD Request # 109 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.062000
2024-09-24 12:17:48.158 | HD Request # 109 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:48.158 | Socket (6) | Creating socket.
2024-09-24 12:17:48.158 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:48.158 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:48.427 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:48.427 | Socket (5) | Closed.
2024-09-24 12:17:48.725 | HD Request # 109 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:48.725 | HD Request # 109 | Sending historical data logon request message.
2024-09-24 12:17:49.003 | HD Request # 109 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: 6JZ24
2024-09-24 12:17:49.282 | HD Request # 109 | Decompressing data.
2024-09-24 12:17:49.559 | HD Request # 109 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 12:16:48.062000
2024-09-24 12:17:49.560 | Socket (6) | CloseSocket call.
2024-09-24 12:17:49.560 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:49.560 | Historical data download thread signaled to stop.
2024-09-24 12:17:49.560 | HD Request # 109 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:56.020000.
2024-09-24 12:17:49.560 | HD Request # 109 | Received 54 Intraday data records from 2024-09-24 12:16:48.062000 to 2024-09-24 12:17:50.111000 (62.0 seconds. Delay: -0.6 seconds) and wrote 53 records for 6JZ4.CME
2024-09-24 12:17:49.560 | HD Request # 109 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:50.111000
2024-09-24 12:17:49.560 | HD Request # 109 | Completion time: 1s.
2024-09-24 12:17:49.560 | HD Request # 109 | Intraday data download complete for 6JZ4.CME. Unique request ID: 109
2024-09-24 12:17:49.560 | Removing historical data download ID 109.
2024-09-24 12:17:49.560 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 12:17:49.560 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 12:17:49.560 | HD Request # 109 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:49.560 | Triggering next historical data download in queue.
2024-09-24 12:17:49.560 | Historical data for 6JZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:49.560 | HD Request # 110 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 12:17:49.560 | HD Request # 110 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.359000
2024-09-24 12:17:49.560 | HD Request # 110 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:49.560 | Socket (5) | Creating socket.
2024-09-24 12:17:49.560 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:49.561 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:49.837 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:49.837 | Socket (6) | Closed.
2024-09-24 12:17:50.116 | HD Request # 110 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:50.116 | HD Request # 110 | Sending historical data logon request message.
2024-09-24 12:17:50.386 | HD Request # 110 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: ESZ24
2024-09-24 12:17:50.655 | HD Request # 110 | Decompressing data.
2024-09-24 12:17:50.927 | HD Request # 110 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 12:16:48.093000
2024-09-24 12:17:50.927 | Socket (5) | CloseSocket call.
2024-09-24 12:17:50.927 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:50.927 | Historical data download thread signaled to stop.
2024-09-24 12:17:50.927 | HD Request # 110 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:51.165000.
2024-09-24 12:17:50.928 | HD Request # 110 | Received 864 Intraday data records from 2024-09-24 12:16:48.093000 to 2024-09-24 12:17:50.110001 (62.0 seconds. Delay: 0.8 seconds) and wrote 856 records for ESZ4.CME
2024-09-24 12:17:50.928 | HD Request # 110 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:50.110001
2024-09-24 12:17:50.928 | HD Request # 110 | Completion time: 1s.
2024-09-24 12:17:50.928 | HD Request # 110 | Intraday data download complete for ESZ4.CME. Unique request ID: 110
2024-09-24 12:17:50.928 | Removing historical data download ID 110.
2024-09-24 12:17:50.928 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 12:17:50.928 | Intraday chart data file opened for ESZ4.CME
2024-09-24 12:17:50.928 | HD Request # 110 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:50.928 | Triggering next historical data download in queue.
2024-09-24 12:17:50.928 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:50.928 | HD Request # 111 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 12:17:50.928 | HD Request # 111 | Download start date-time: 2024-09-24 12:16:49.000000. File last date-time: 2024-09-24 12:16:49.333002
2024-09-24 12:17:50.928 | HD Request # 111 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:50.928 | Socket (6) | Creating socket.
2024-09-24 12:17:50.928 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:50.928 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:51.196 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:51.197 | Socket (5) | Closed.
2024-09-24 12:17:51.499 | HD Request # 111 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:51.499 | HD Request # 111 | Sending historical data logon request message.
2024-09-24 12:17:51.778 | HD Request # 111 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:49. Record interval: 0. Symbol: MESZ24
2024-09-24 12:17:52.058 | HD Request # 111 | Decompressing data.
2024-09-24 12:17:52.337 | HD Request # 111 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 12:16:49.333000
2024-09-24 12:17:52.338 | Socket (6) | CloseSocket call.
2024-09-24 12:17:52.338 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:52.338 | Historical data download thread signaled to stop.
2024-09-24 12:17:52.338 | HD Request # 111 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:50.046000.
2024-09-24 12:17:52.338 | HD Request # 111 | Received 287 Intraday data records from 2024-09-24 12:16:49.333000 to 2024-09-24 12:17:49.822000 (60.5 seconds. Delay: 2.5 seconds) and wrote 284 records for MESZ4.CME
2024-09-24 12:17:52.339 | HD Request # 111 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:49.822000
2024-09-24 12:17:52.339 | HD Request # 111 | Completion time: 2s.
2024-09-24 12:17:52.339 | HD Request # 111 | Intraday data download complete for MESZ4.CME. Unique request ID: 111
2024-09-24 12:17:52.339 | Removing historical data download ID 111.
2024-09-24 12:17:52.339 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 12:17:52.339 | Intraday chart data file opened for MESZ4.CME
2024-09-24 12:17:52.339 | HD Request # 111 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:52.339 | Triggering next historical data download in queue.
2024-09-24 12:17:52.339 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:52.339 | HD Request # 112 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 12:17:52.339 | HD Request # 112 | Download start date-time: 2024-09-24 11:59:22.000000. File last date-time: 2024-09-24 11:59:22.084001
2024-09-24 12:17:52.339 | HD Request # 112 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:52.339 | Socket (5) | Creating socket.
2024-09-24 12:17:52.339 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:52.339 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:52.617 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:52.617 | Socket (6) | Closed.
2024-09-24 12:17:52.898 | HD Request # 112 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:52.898 | HD Request # 112 | Sending historical data logon request message.
2024-09-24 12:17:53.171 | HD Request # 112 | Requesting Intraday data. Start date-time: 2024-09-24 11:59:22. Record interval: 0. Symbol: MJYZ24
2024-09-24 12:17:53.444 | HD Request # 112 | Decompressing data.
2024-09-24 12:17:53.716 | HD Request # 112 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 11:59:22.084000
2024-09-24 12:17:53.716 | Socket (5) | CloseSocket call.
2024-09-24 12:17:53.716 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:53.724 | Historical data download thread signaled to stop.
2024-09-24 12:17:53.724 | HD Request # 112 | Received 2 Intraday data records from 2024-09-24 11:59:22.084000 to 2024-09-24 11:59:22.084001 (0.0 seconds. Delay: 18.5 minutes) and wrote 0 records for MJYZ4.CME
2024-09-24 12:17:53.724 | HD Request # 112 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:59:22.084001
2024-09-24 12:17:53.724 | HD Request # 112 | Completion time: 1s.
2024-09-24 12:17:53.724 | HD Request # 112 | Intraday data download complete for MJYZ4.CME. Unique request ID: 112
2024-09-24 12:17:53.724 | Removing historical data download ID 112.
2024-09-24 12:17:53.724 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 12:17:53.724 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 12:17:53.724 | HD Request # 112 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:53.724 | Triggering next historical data download in queue.
2024-09-24 12:17:53.724 | Historical data for MJYZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:53.724 | HD Request # 113 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 12:17:53.724 | HD Request # 113 | Download start date-time: 2024-09-24 12:16:49.000000. File last date-time: 2024-09-24 12:16:49.348001
2024-09-24 12:17:53.724 | HD Request # 113 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:53.724 | Socket (6) | Creating socket.
2024-09-24 12:17:53.724 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:53.724 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:53.989 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:53.990 | Socket (5) | Closed.
2024-09-24 12:17:54.278 | HD Request # 113 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:54.278 | HD Request # 113 | Sending historical data logon request message.
2024-09-24 12:17:54.550 | HD Request # 113 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:49. Record interval: 0. Symbol: NQZ24
2024-09-24 12:17:54.826 | HD Request # 113 | Decompressing data.
2024-09-24 12:17:55.097 | HD Request # 113 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 12:16:49.348000
2024-09-24 12:17:55.097 | Socket (6) | CloseSocket call.
2024-09-24 12:17:55.097 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:55.097 | Historical data download thread signaled to stop.
2024-09-24 12:17:55.097 | HD Request # 113 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:50.040000.
2024-09-24 12:17:55.097 | HD Request # 113 | Received 502 Intraday data records from 2024-09-24 12:16:49.348000 to 2024-09-24 12:17:53.966000 (64.6 seconds. Delay: 1.1 seconds) and wrote 500 records for NQZ4.CME
2024-09-24 12:17:55.098 | HD Request # 113 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:53.966000
2024-09-24 12:17:55.098 | HD Request # 113 | Completion time: 2s.
2024-09-24 12:17:55.098 | HD Request # 113 | Intraday data download complete for NQZ4.CME. Unique request ID: 113
2024-09-24 12:17:55.098 | Removing historical data download ID 113.
2024-09-24 12:17:55.098 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 12:17:55.098 | Intraday chart data file opened for NQZ4.CME
2024-09-24 12:17:55.098 | HD Request # 113 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:55.098 | Triggering next historical data download in queue.
2024-09-24 12:17:55.098 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:55.098 | HD Request # 114 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 12:17:55.098 | HD Request # 114 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 12:17:55.098 | HD Request # 114 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:55.098 | Socket (5) | Creating socket.
2024-09-24 12:17:55.098 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:55.098 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:55.372 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:55.372 | Socket (6) | Closed.
2024-09-24 12:17:55.662 | HD Request # 114 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:55.662 | HD Request # 114 | Sending historical data logon request message.
2024-09-24 12:17:55.939 | HD Request # 114 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 12:17:56.227 | HD Request # 114 | Decompressing data.
2024-09-24 12:17:56.505 | HD Request # 114 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 12:17:56.505 | Socket (5) | CloseSocket call.
2024-09-24 12:17:56.505 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:56.505 | Historical data download thread signaled to stop.
2024-09-24 12:17:56.505 | HD Request # 114 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 4.1 days) and wrote 0 records for MESU4.CME
2024-09-24 12:17:56.505 | HD Request # 114 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 12:17:56.505 | HD Request # 114 | Completion time: 1s.
2024-09-24 12:17:56.505 | HD Request # 114 | Intraday data download complete for MESU4.CME. Unique request ID: 114
2024-09-24 12:17:56.505 | Removing historical data download ID 114.
2024-09-24 12:17:56.505 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 12:17:56.505 | Intraday chart data file opened for MESU4.CME
2024-09-24 12:17:56.505 | HD Request # 114 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:56.505 | Triggering next historical data download in queue.
2024-09-24 12:17:56.505 | Historical data for MESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:56.505 | HD Request # 115 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 12:17:56.505 | HD Request # 115 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.076000
2024-09-24 12:17:56.505 | HD Request # 115 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:56.505 | Socket (6) | Creating socket.
2024-09-24 12:17:56.505 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:56.505 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:56.786 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:56.786 | Socket (5) | Closed.
2024-09-24 12:17:57.082 | HD Request # 115 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:57.082 | HD Request # 115 | Sending historical data logon request message.
2024-09-24 12:17:57.362 | HD Request # 115 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: M6AZ24
2024-09-24 12:17:57.417 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 12:17:57.417 | DTC Client socket (2) | CloseSocket call.
2024-09-24 12:17:57.417 | Denali Data Feed | Failed connections: 2
2024-09-24 12:17:57.417 | DTC Client socket (0) | CloseSocket call.
2024-09-24 12:17:57.417 | Denali Data Feed | Disconnected from the server.
2024-09-24 12:17:57.417 | DTC Client socket (2) | Closed.
2024-09-24 12:17:57.417 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 12:17:57.644 | HD Request # 115 | Decompressing data.
2024-09-24 12:17:57.925 | HD Request # 115 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 12:16:48.076000
2024-09-24 12:17:57.925 | Socket (6) | CloseSocket call.
2024-09-24 12:17:57.925 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:57.925 | Historical data download thread signaled to stop.
2024-09-24 12:17:57.925 | HD Request # 115 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:31.653000.
2024-09-24 12:17:57.925 | HD Request # 115 | Received 4 Intraday data records from 2024-09-24 12:16:48.076000 to 2024-09-24 12:17:31.653002 (43.6 seconds. Delay: 26.3 seconds) and wrote 3 records for M6AZ4.CME
2024-09-24 12:17:57.926 | HD Request # 115 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:31.653002
2024-09-24 12:17:57.926 | HD Request # 115 | Completion time: 1s.
2024-09-24 12:17:57.926 | HD Request # 115 | Intraday data download complete for M6AZ4.CME. Unique request ID: 115
2024-09-24 12:17:57.926 | Removing historical data download ID 115.
2024-09-24 12:17:57.926 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 12:17:57.926 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 12:17:57.926 | HD Request # 115 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:57.926 | Triggering next historical data download in queue.
2024-09-24 12:17:57.926 | Historical data for M6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:57.926 | HD Request # 116 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 12:17:57.926 | HD Request # 116 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 12:17:57.926 | HD Request # 116 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:57.926 | Socket (2) | Creating socket.
2024-09-24 12:17:57.926 | Socket (2) | New receive buffer size: 0
2024-09-24 12:17:57.926 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:58.206 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:58.206 | Socket (6) | Closed.
2024-09-24 12:17:58.484 | HD Request # 116 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:58.484 | HD Request # 116 | Sending historical data logon request message.
2024-09-24 12:17:58.755 | HD Request # 116 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 12:17:59.028 | HD Request # 116 | Decompressing data.
2024-09-24 12:17:59.299 | HD Request # 116 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 12:17:59.299 | Socket (2) | CloseSocket call.
2024-09-24 12:17:59.299 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:59.299 | Historical data download thread signaled to stop.
2024-09-24 12:17:59.299 | HD Request # 116 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 35.9 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 12:17:59.299 | HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 12:17:59.300 | HD Request # 116 | Completion time: 2s.
2024-09-24 12:17:59.300 | HD Request # 116 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 116
2024-09-24 12:17:59.300 | Removing historical data download ID 116.
2024-09-24 12:17:59.300 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 12:17:59.300 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 12:17:59.300 | HD Request # 116 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:59.300 | Triggering next historical data download in queue.
2024-09-24 12:17:59.300 | Historical data for MCLU4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:59.300 | HD Request # 117 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 12:17:59.300 | HD Request # 117 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 12:17:59.300 | HD Request # 117 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:59.300 | Socket (5) | Creating socket.
2024-09-24 12:17:59.300 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:59.300 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:59.571 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 12:17:59.571 | Socket (2) | Closed.
2024-09-24 12:17:59.866 | HD Request # 117 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:59.866 | HD Request # 117 | Sending historical data logon request message.
2024-09-24 12:18:00.144 | HD Request # 117 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 12:18:00.424 | HD Request # 117 | Decompressing data.
2024-09-24 12:18:00.581 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 12:18:00.581 | DTC Client socket (2) | Creating socket.
2024-09-24 12:18:00.582 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 12:18:00.582 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 12:18:00.702 | HD Request # 117 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 12:18:00.702 | Socket (5) | CloseSocket call.
2024-09-24 12:18:00.702 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:00.706 | Historical data download thread signaled to stop.
2024-09-24 12:18:00.706 | HD Request # 117 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 4.1 days) and wrote 0 records for ESU4.CME
2024-09-24 12:18:00.706 | HD Request # 117 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 12:18:00.706 | HD Request # 117 | Completion time: 1s.
2024-09-24 12:18:00.706 | HD Request # 117 | Intraday data download complete for ESU4.CME. Unique request ID: 117
2024-09-24 12:18:00.706 | Removing historical data download ID 117.
2024-09-24 12:18:00.706 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 12:18:00.706 | Intraday chart data file opened for ESU4.CME
2024-09-24 12:18:00.706 | HD Request # 117 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:00.706 | Triggering next historical data download in queue.
2024-09-24 12:18:00.706 | Historical data for ESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:18:00.706 | HD Request # 118 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 12:18:00.706 | HD Request # 118 | Download start date-time: 2024-09-24 12:16:47.000000. File last date-time: 2024-09-24 12:16:47.039003
2024-09-24 12:18:00.706 | HD Request # 118 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:00.706 | Socket (6) | Creating socket.
2024-09-24 12:18:00.706 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:00.706 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:00.779 | Denali Data Feed | Network connection to server complete.
2024-09-24 12:18:00.779 | Denali Data Feed | Starting socket receive thread.
2024-09-24 12:18:00.779 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 12:18:00.981 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:00.981 | Socket (5) | Closed.
2024-09-24 12:18:00.988 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-24 12:18:00.988 | Denali Data Feed | Sending logon request message.
2024-09-24 12:18:01.280 | HD Request # 118 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:01.280 | HD Request # 118 | Sending historical data logon request message.
2024-09-24 12:18:01.558 | HD Request # 118 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:47. Record interval: 0. Symbol: MGCZ24
2024-09-24 12:18:01.676 | Denali Data Feed | Received logon response.
2024-09-24 12:18:01.676 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-24 12:18:01.676 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-24 12:18:01.676 | Denali Data Feed | Successfully connected.
2024-09-24 12:18:01.676 | Denali Data Feed | Trading is not supported.
2024-09-24 12:18:01.676 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-24 12:18:01.676 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Triggering next historical data download in queue.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: 6AZ4.CME -> 6AZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: 6JZ4.CME -> 6JZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: CLX4.NYMEX -> CLX24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ4.CME -> ESZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: M6AZ4.CME -> M6AZ24
2024-09-24 12:18:01.676 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MCLU4.NYMEX -> MCLU24
2024-09-24 12:18:01.676 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ4.CME -> MESZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MGCZ4.COMEX -> MGCZ24
2024-09-24 12:18:01.676 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MJYZ4.CME -> MJYZ24
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ4.CME -> MNQZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2024-09-24 12:18:01.848 | HD Request # 118 | Decompressing data.
2024-09-24 12:18:02.126 | HD Request # 118 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 12:16:47.039000
2024-09-24 12:18:02.126 | Socket (6) | CloseSocket call.
2024-09-24 12:18:02.126 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:02.126 | Historical data download thread signaled to stop.
2024-09-24 12:18:02.126 | HD Request # 118 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:53.075000.
2024-09-24 12:18:02.126 | HD Request # 118 | Received 107 Intraday data records from 2024-09-24 12:16:47.039000 to 2024-09-24 12:17:59.058000 (72.0 seconds. Delay: 3.1 seconds) and wrote 103 records for MGCZ4.COMEX
2024-09-24 12:18:02.127 | HD Request # 118 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:59.058000
2024-09-24 12:18:02.127 | HD Request # 118 | Completion time: 2s.
2024-09-24 12:18:02.127 | HD Request # 118 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 118
2024-09-24 12:18:02.127 | Removing historical data download ID 118.
2024-09-24 12:18:02.127 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 12:18:02.127 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 12:18:02.127 | HD Request # 118 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:02.127 | Triggering next historical data download in queue.
2024-09-24 12:18:02.127 | Initiating new historical data download for MGCZ4.COMEX to get the latest data since the download was started while not connected to primary service.
2024-09-24 12:18:02.127 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 12:18:02.127 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 12:18:02.127 | HD Request # 119 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 12:18:02.127 | HD Request # 119 | Download start date-time: 2024-09-24 12:17:59.000000. File last date-time: 2024-09-24 12:17:59.058000
2024-09-24 12:18:02.127 | HD Request # 119 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:02.127 | Socket (5) | Creating socket.
2024-09-24 12:18:02.127 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:02.127 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:02.404 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:02.404 | Socket (6) | Closed.
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-24 12:18:02.686 | HD Request # 119 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:02.686 | HD Request # 119 | Sending historical data logon request message.
2024-09-24 12:18:02.959 | HD Request # 119 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:59. Record interval: 0. Symbol: MGCZ24
2024-09-24 12:18:03.234 | HD Request # 119 | Decompressing data.
2024-09-24 12:18:03.510 | HD Request # 119 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 12:17:59.058000
2024-09-24 12:18:03.510 | Socket (5) | CloseSocket call.
2024-09-24 12:18:03.510 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:03.613 | Historical data download thread signaled to stop.
2024-09-24 12:18:03.613 | HD Request # 119 | Timestamp of first Intraday data file record written: 2024-09-24 12:18:00.994000.
2024-09-24 12:18:03.613 | HD Request # 119 | Received 11 Intraday data records from 2024-09-24 12:17:59.058000 to 2024-09-24 12:18:03.670004 (4.6 seconds. Delay: -0.1 seconds) and wrote 10 records for MGCZ4.COMEX
2024-09-24 12:18:03.613 | HD Request # 119 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:03.670004
2024-09-24 12:18:03.613 | HD Request # 119 | Completion time: 1s.
2024-09-24 12:18:03.613 | HD Request # 119 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 133
2024-09-24 12:18:03.613 | Removing historical data download ID 133.
2024-09-24 12:18:03.613 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 12:18:03.613 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 12:18:03.613 | HD Request # 119 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:03.613 | Triggering next historical data download in queue.
2024-09-24 12:18:03.613 | HD Request # 120 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 12:18:03.614 | HD Request # 120 | Download start date-time: 2024-09-24 12:16:49.000000. File last date-time: 2024-09-24 12:16:49.724000
2024-09-24 12:18:03.614 | HD Request # 120 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:03.614 | Socket (6) | Creating socket.
2024-09-24 12:18:03.614 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:03.614 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:03.783 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:03.784 | Socket (5) | Closed.
2024-09-24 12:18:04.192 | HD Request # 120 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:04.192 | HD Request # 120 | Sending historical data logon request message.
2024-09-24 12:18:04.473 | HD Request # 120 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:49. Record interval: 0. Symbol: MNQZ24
2024-09-24 12:18:04.756 | HD Request # 120 | Decompressing data.
2024-09-24 12:18:05.043 | HD Request # 120 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 12:16:49.348000
2024-09-24 12:18:05.044 | Socket (6) | CloseSocket call.
2024-09-24 12:18:05.044 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:05.044 | Historical data download thread signaled to stop.
2024-09-24 12:18:05.044 | HD Request # 120 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:50.040000.
2024-09-24 12:18:05.044 | HD Request # 120 | Received 1261 Intraday data records from 2024-09-24 12:16:49.348000 to 2024-09-24 12:18:06.451000 (77.1 seconds. Delay: -1.4 seconds) and wrote 1251 records for MNQZ4.CME
2024-09-24 12:18:05.044 | HD Request # 120 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:06.451000
2024-09-24 12:18:05.044 | HD Request # 120 | Completion time: 2s.
2024-09-24 12:18:05.044 | HD Request # 120 | Intraday data download complete for MNQZ4.CME. Unique request ID: 119
2024-09-24 12:18:05.044 | Removing historical data download ID 119.
2024-09-24 12:18:05.044 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 12:18:05.044 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 12:18:05.044 | HD Request # 120 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:05.044 | Triggering next historical data download in queue.
2024-09-24 12:18:05.044 | HD Request # 121 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2024-09-24 12:18:05.045 | HD Request # 121 | Download start date-time: 2024-09-24 12:17:08.000000. File last date-time: 2024-09-24 12:17:08.000000
2024-09-24 12:18:05.045 | HD Request # 121 | Using server: ds12.sierracharts.com port 10149
2024-09-24 12:18:05.045 | Socket (5) | Creating socket.
2024-09-24 12:18:05.045 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:05.045 | Socket (5) | Connecting to IP: 69.39.70.241.
2024-09-24 12:18:05.326 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:05.326 | Socket (6) | Closed.
2024-09-24 12:18:05.639 | HD Request # 121 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:05.639 | HD Request # 121 | Sending historical data logon request message.
2024-09-24 12:18:06.394 | HD Request # 121 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:08. Record interval: 0. Symbol: USDX
2024-09-24 12:18:06.672 | HD Request # 121 | Decompressing data.
2024-09-24 12:18:06.952 | HD Request # 121 | Receiving Intraday data for USDX starting at 2024-09-24 12:17:08.000000
2024-09-24 12:18:06.952 | Socket (5) | CloseSocket call.
2024-09-24 12:18:06.952 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:06.960 | Historical data download thread signaled to stop.
2024-09-24 12:18:06.960 | HD Request # 121 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:09.000000.
2024-09-24 12:18:06.960 | HD Request # 121 | Received 59 Intraday data records from 2024-09-24 12:17:08.000000 to 2024-09-24 12:18:07.000000 (59.0 seconds. Delay: -0.0 seconds) and wrote 58 records for USDX
2024-09-24 12:18:06.960 | HD Request # 121 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:07.000000
2024-09-24 12:18:06.960 | Added 2 Time and Sales records to Intraday data file for USDX after download.
2024-09-24 12:18:06.960 | HD Request # 121 | Completion time: 1s.
2024-09-24 12:18:06.960 | HD Request # 121 | Intraday data download complete for USDX. Unique request ID: 120
2024-09-24 12:18:06.960 | Removing historical data download ID 120.
2024-09-24 12:18:06.960 | Real-time Intraday chart data file updates started for USDX
2024-09-24 12:18:06.960 | Intraday chart data file opened for USDX
2024-09-24 12:18:06.960 | HD Request # 121 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:06.960 | Triggering next historical data download in queue.
2024-09-24 12:18:06.960 | HD Request # 122 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 12:18:06.961 | HD Request # 122 | Download start date-time: 2024-09-24 12:17:44.000000. File last date-time: 2024-09-24 12:17:44.032000
2024-09-24 12:18:06.961 | HD Request # 122 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:06.961 | Socket (6) | Creating socket.
2024-09-24 12:18:06.961 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:06.961 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:07.232 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:07.232 | Socket (5) | Closed.
2024-09-24 12:18:07.523 | HD Request # 122 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:07.523 | HD Request # 122 | Sending historical data logon request message.
2024-09-24 12:18:07.803 | HD Request # 122 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:44. Record interval: 0. Symbol: 6AZ24
2024-09-24 12:18:08.077 | HD Request # 122 | Decompressing data.
2024-09-24 12:18:08.353 | HD Request # 122 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 12:17:44.032000
2024-09-24 12:18:08.353 | Socket (6) | CloseSocket call.
2024-09-24 12:18:08.353 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:08.353 | Historical data download thread signaled to stop.
2024-09-24 12:18:08.353 | HD Request # 122 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:47.488000.
2024-09-24 12:18:08.353 | HD Request # 122 | Received 29 Intraday data records from 2024-09-24 12:17:44.032000 to 2024-09-24 12:18:05.400002 (21.4 seconds. Delay: 3.0 seconds) and wrote 28 records for 6AZ4.CME
2024-09-24 12:18:08.354 | HD Request # 122 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:05.400002
2024-09-24 12:18:08.354 | HD Request # 122 | Completion time: 2s.
2024-09-24 12:18:08.354 | HD Request # 122 | Intraday data download complete for 6AZ4.CME. Unique request ID: 121
2024-09-24 12:18:08.354 | Removing historical data download ID 121.
2024-09-24 12:18:08.354 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 12:18:08.354 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 12:18:08.354 | HD Request # 122 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:08.354 | Triggering next historical data download in queue.
2024-09-24 12:18:08.354 | HD Request # 123 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 12:18:08.354 | HD Request # 123 | Download start date-time: 2024-09-24 12:17:50.000000. File last date-time: 2024-09-24 12:17:50.111000
2024-09-24 12:18:08.354 | HD Request # 123 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:08.354 | Socket (5) | Creating socket.
2024-09-24 12:18:08.354 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:08.354 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:08.637 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:08.637 | Socket (6) | Closed.
2024-09-24 12:18:08.931 | HD Request # 123 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:08.931 | HD Request # 123 | Sending historical data logon request message.
2024-09-24 12:18:09.163 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 12:18:09.163 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-24 12:18:09.164 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 3296
2024-09-24 12:18:09.209 | HD Request # 123 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:50. Record interval: 0. Symbol: 6JZ24
2024-09-24 12:18:09.482 | HD Request # 123 | Decompressing data.
2024-09-24 12:18:09.753 | HD Request # 123 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 12:17:50.111000
2024-09-24 12:18:09.754 | Socket (5) | CloseSocket call.
2024-09-24 12:18:09.754 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:09.765 | Historical data download thread signaled to stop.
2024-09-24 12:18:09.765 | HD Request # 123 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:55.100000.
2024-09-24 12:18:09.765 | HD Request # 123 | Received 62 Intraday data records from 2024-09-24 12:17:50.111000 to 2024-09-24 12:18:08.926000 (18.8 seconds. Delay: 0.8 seconds) and wrote 61 records for 6JZ4.CME
2024-09-24 12:18:09.766 | HD Request # 123 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:08.926000
2024-09-24 12:18:09.766 | HD Request # 123 | Completion time: 1s.
2024-09-24 12:18:09.766 | HD Request # 123 | Intraday data download complete for 6JZ4.CME. Unique request ID: 122
2024-09-24 12:18:09.766 | Removing historical data download ID 122.
2024-09-24 12:18:09.766 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 12:18:09.766 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 12:18:09.766 | HD Request # 123 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:09.766 | Triggering next historical data download in queue.
2024-09-24 12:18:09.766 | HD Request # 124 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 12:18:09.766 | HD Request # 124 | Download start date-time: 2024-09-24 12:17:46.000000. File last date-time: 2024-09-24 12:17:46.212001
2024-09-24 12:18:09.766 | HD Request # 124 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:09.766 | Socket (6) | Creating socket.
2024-09-24 12:18:09.766 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:09.766 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:10.026 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:10.026 | Socket (5) | Closed.
2024-09-24 12:18:10.327 | HD Request # 124 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:10.327 | HD Request # 124 | Sending historical data logon request message.
2024-09-24 12:18:10.600 | HD Request # 124 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:46. Record interval: 0. Symbol: CLX24
2024-09-24 12:18:10.873 | HD Request # 124 | Decompressing data.
2024-09-24 12:18:11.146 | HD Request # 124 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 12:17:46.212000
2024-09-24 12:18:11.146 | Socket (6) | CloseSocket call.
2024-09-24 12:18:11.146 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:11.166 | Historical data download thread signaled to stop.
2024-09-24 12:18:11.166 | HD Request # 124 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:50.219000.
2024-09-24 12:18:11.166 | HD Request # 124 | Received 48 Intraday data records from 2024-09-24 12:17:46.212000 to 2024-09-24 12:18:11.848000 (25.6 seconds. Delay: -0.7 seconds) and wrote 46 records for CLX4.NYMEX
2024-09-24 12:18:11.167 | HD Request # 124 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:11.848000
2024-09-24 12:18:11.167 | HD Request # 124 | Completion time: 2s.
2024-09-24 12:18:11.167 | HD Request # 124 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 123
2024-09-24 12:18:11.167 | Removing historical data download ID 123.
2024-09-24 12:18:11.167 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 12:18:11.167 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 12:18:11.167 | HD Request # 124 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:11.167 | Triggering next historical data download in queue.
2024-09-24 12:18:11.167 | HD Request # 125 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 12:18:11.167 | HD Request # 125 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 12:18:11.167 | HD Request # 125 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:11.167 | Socket (5) | Creating socket.
2024-09-24 12:18:11.167 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:11.167 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:11.419 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:11.419 | Socket (6) | Closed.
2024-09-24 12:18:11.738 | HD Request # 125 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:11.738 | HD Request # 125 | Sending historical data logon request message.
2024-09-24 12:18:12.015 | HD Request # 125 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 12:18:12.295 | HD Request # 125 | Decompressing data.
2024-09-24 12:18:12.573 | HD Request # 125 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 12:18:12.573 | Socket (5) | CloseSocket call.
2024-09-24 12:18:12.573 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:12.576 | Historical data download thread signaled to stop.
2024-09-24 12:18:12.576 | HD Request # 125 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 4.1 days) and wrote 0 records for ESU4.CME
2024-09-24 12:18:12.576 | HD Request # 125 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 12:18:12.576 | HD Request # 125 | Completion time: 1s.
2024-09-24 12:18:12.576 | HD Request # 125 | Intraday data download complete for ESU4.CME. Unique request ID: 124
2024-09-24 12:18:12.576 | Removing historical data download ID 124.
2024-09-24 12:18:12.576 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 12:18:12.576 | Intraday chart data file opened for ESU4.CME
2024-09-24 12:18:12.576 | HD Request # 125 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:12.576 | Triggering next historical data download in queue.
2024-09-24 12:18:12.576 | HD Request # 126 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 12:18:12.576 | HD Request # 126 | Download start date-time: 2024-09-24 12:17:50.000000. File last date-time: 2024-09-24 12:17:50.110001
2024-09-24 12:18:12.576 | HD Request # 126 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:12.576 | Socket (6) | Creating socket.
2024-09-24 12:18:12.576 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:12.576 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:12.851 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:12.851 | Socket (5) | Closed.
2024-09-24 12:18:13.138 | HD Request # 126 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:13.138 | HD Request # 126 | Sending historical data logon request message.
[2024-09-24 19:55:53]
User753526 - Posts: 51
Just an update, its happened again into the last 30 minutes of session today and has been out for over 10 minutes now.
Updated Message Log.. seems to continually be unable to connect to the SierraCharts server.
2024-09-22 14:41:00.925 | Trade activity files set size: 2497
2024-09-22 14:41:00.956 | Created the DTC Protocol server.
2024-09-22 14:41:00.956 | DTC Protocol Server listening on port 11099.
2024-09-22 14:41:00.957 | Reading Internal Order ID file.
2024-09-22 14:41:00.992 | Reading Trade Orders file.
2024-09-22 14:41:00.993 | Reading Trade Positions file.
2024-09-22 14:41:00.993 | Reading Trade Account Data files.
2024-09-22 14:41:00.994 | NTP | Create NTP Client...
2024-09-22 14:41:00.994 | NTP | Start NTP Client Receive Thread.
2024-09-22 14:41:00.994 | NTP | Client | No privilege to gradual adjust system time. Set time will be used instead to step system time.
2024-09-22 14:41:00.994 | NTP | Client | Create NTP Client Service.
2024-09-22 14:41:00.994 | NTP | Client | Start NTP Client Service.
2024-09-22 14:41:00.994 | NTP | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment.
2024-09-22 14:41:00.994 | NTP | Unable to get permission to adjust the system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2024-09-22 14:41:00.994 | NTP | Client | Cannot adjust System Clock. Cancel NTP Client Service starting.
2024-09-22 14:41:00.994 | NTP | Stop NTP Client...
2024-09-22 14:41:00.994 | NTP | NTP Client Stopped.
2024-09-22 14:41:00.994 | NTP | Unable to get permission to restore the system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2024-09-22 14:41:00.994 | Software version: 2652 64-bit
2024-09-22 14:41:00.994 | Primary Thread ID: 35088
2024-09-22 14:41:00.994 | Usage end date: 2024-10-10
2024-09-22 14:41:00.994 | Enabled for: Advanced Features 2.
2024-09-22 14:41:00.994 | Enabled for: Sierra Chart Historical Data Service.
2024-09-22 14:41:00.994 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-09-22 14:41:00.994 | Enabled for: Delayed Denali Exchange Data Feed.
2024-09-22 14:41:00.994 | Enabled for exchange2: CME
2024-09-22 14:41:00.994 | Enabled for exchange2: COMEX
2024-09-22 14:41:00.994 | Enabled for exchange2: NYMEX
2024-09-22 14:41:00.994 | Enabled for exchange2: NASDAQ Global Indexes
2024-09-22 14:41:00.994 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-09-22 14:41:00.994 | Current selected Data/Trading service: Rithmic Direct - DTC
2024-09-22 14:41:00.994 | Custom symbol settings values: enabled
2024-09-22 14:41:00.994 | Chart Update Interval: 500
2024-09-22 14:41:00.994 | Intraday Data Storage Time Unit: 0
2024-09-22 14:41:00.994 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2024-09-22 14:41:00.994 | 2024-09-22 18:41:00 Local computer time in UTC
2024-09-22 14:41:00.994 | 2024-09-22 14:41:00 Local computer time in SC Time Zone
2024-09-22 14:41:00.994 | 2024-09-22 18:41:01 Server time in UTC
2024-09-22 14:41:00.994 | Local computer UTC time and Server UTC time difference: 2 seconds.
2024-09-22 14:41:00.994 | Program path: C:\SierraChart - TopStep\
2024-09-22 14:41:00.994 | Data Files path: C:\SierraChart - TopStep\Data\
2024-09-22 14:41:00.995 | OS Version Number: 10.0
2024-09-22 14:41:00.995 | Locale Setting: C
2024-09-22 14:41:00.995 | DLLs: ICTMarketOpens_64.dll, UserContributedStudies_64.dll
2024-09-22 14:41:00.995 | Allowed protected custom studies:
2024-09-22 14:41:00.995 | Crash reporter started: true
2024-09-22 14:41:01.006 | Created the DTC Protocol historical data server.
2024-09-22 14:41:01.006 | HD Server Manager | Listening on port 11098.
2024-09-22 14:41:01.006 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2024-09-22 14:41:01.014 | Chat: Chat Window created. Connecting to server.
2024-09-22 14:41:01.014 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-22 14:41:01.057 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:01.212 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2024-09-22 14:41:01.212 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2024-09-22 14:41:01.212 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2024-09-22 14:41:01.267 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2024-09-22 14:41:01.267 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2024-09-22 14:41:01.333 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2024-09-22 14:41:01.333 | DTC Client socket (6) | New receive buffer size: 0
2024-09-22 14:41:01.333 | DTC Client socket (6) | Connecting to IP: 69.39.70.248.
2024-09-22 14:41:01.611 | Chat | Network connection to server complete.
2024-09-22 14:41:01.611 | Chat | Starting socket receive thread.
2024-09-22 14:41:01.611 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-22 14:41:01.684 | Received 5 login tokens.
2024-09-22 14:41:02.444 | Symbol settings MD5 received. Request ID: 1.
2024-09-22 14:41:02.444 | Symbol settings are up-to-date for rithmic_v2.trading.
2024-09-22 14:41:02.444 | Chat | Setting DTC encoding to Binary VLS
2024-09-22 14:41:02.444 | Chat | Sending logon request message.
2024-09-22 14:41:02.968 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2024-09-22 14:41:02.968 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:03.199 | Chat | Received logon response.
2024-09-22 14:41:03.199 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-22 14:41:03.199 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-22 14:41:03.199 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-22 14:41:03.199 | Chat | Trading is not supported.
2024-09-22 14:41:03.199 | Chat | MarketDepthIsSupported: 1
2024-09-22 14:41:03.220 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2024-09-22 14:41:03.220 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2024-09-22 14:41:03.512 | Requested user files to download.
2024-09-22 14:41:05.520 |
2024-09-22 14:41:05.520 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-22 14:41:05.520 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-22 14:41:05.521 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-22 14:41:05.827 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-22 14:41:05.827 | DTC Client socket (1) | New receive buffer size: 0
2024-09-22 14:41:05.827 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-22 14:41:06.092 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-22 14:41:06.092 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-22 14:41:06.093 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-22 14:41:06.093 | Rithmic Direct - DTC | Sending logon request message.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Received logon response.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Server Name: .
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Successfully connected.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Trading is supported.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-22 14:41:06.859 | Rithmic Direct - DTC | Connected to server complete.
2024-09-22 14:41:06.859 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-22 14:41:06.859 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-22 14:41:06.860 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-22 14:41:06.860 | Using symbol data fast lookup vector
2024-09-22 14:41:06.860 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-22 14:41:06.860 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-22 14:41:06.861 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-22 14:41:06.861 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-22 14:41:06.861 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-22 14:41:06.861 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-22 14:41:06.861 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-22 14:41:06.861 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-22 14:41:06.979 | DTC Client socket (2) | Creating socket.
2024-09-22 14:41:06.979 | DTC Client socket (2) | New receive buffer size: 0
2024-09-22 14:41:06.979 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-22 14:41:07.133 | Denali Data Feed | Network connection to server complete.
2024-09-22 14:41:07.133 | Denali Data Feed | Starting socket receive thread.
2024-09-22 14:41:07.133 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-22 14:41:07.301 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-22 14:41:07.301 | Denali Data Feed | Sending logon request message.
2024-09-22 14:41:09.489 | Denali Data Feed | Received logon response.
2024-09-22 14:41:09.489 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-22 14:41:09.489 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-22 14:41:09.489 | Denali Data Feed | Successfully connected.
2024-09-22 14:41:09.489 | Denali Data Feed | Trading is not supported.
2024-09-22 14:41:09.489 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-22 14:41:09.489 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24
2024-09-22 14:41:09.489 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-22 14:41:10.146 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-22 14:41:10.146 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-22 14:41:25.526 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2.
2024-09-22 14:41:25.526 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | New receive buffer size: 0
2024-09-22 14:41:25.526 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Connecting to IP: 216.66.0.130.
2024-09-22 14:41:26.188 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:26.191 | Starting DelayedDownloadMonitoringTimer
2024-09-22 14:41:26.191 | Starting HDTimeoutTimer
2024-09-22 14:41:26.191 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-22 14:41:26.191 | Triggering next historical data download in queue.
2024-09-22 14:41:26.192 | ESZ4.CME [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol ESZ4.CME starting at last date in file.
2024-09-22 14:41:26.192 | Starting DelayedDownloadMonitoringTimer
2024-09-22 14:41:26.192 | Starting HDTimeoutTimer
2024-09-22 14:41:26.192 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-22 14:41:26.193 | Triggering next historical data download in queue.
2024-09-22 14:41:26.212 | ESZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:26.219 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 14:41:26.307 | ESZ4.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:26.313 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:26.398 | ESZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:26.403 | ESZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 14:41:26.487 | ESZ4.CME [CBV] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:26.492 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:26.492 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.492 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.685 | ESZ4.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 2,
2024-09-22 14:41:26.691 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:26.691 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.691 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.881 | ESZ4.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 2,
2024-09-22 14:41:26.888 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:26.888 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:26.888 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:27.070 | ESZ4.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 2,
2024-09-22 14:41:27.088 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:27.168 | ESZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:27.188 | ESZ4.CME 5 Min #12 | Reloading chart.
2024-09-22 14:41:27.197 | ESZ4.CME [CBV] 15 Min #17 | Reloading chart.
2024-09-22 14:41:27.207 | ESZ4.CME [CBV] 15 Min #17 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:27.227 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 14:41:27.266 | ESZ4.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:27.289 | ESZ4.CME 5 Min #11 | Reloading chart.
2024-09-22 14:41:27.313 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 14:41:27.396 | ESZ4.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-22 14:41:27.420 | ESZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 14:41:27.558 | ESZ4.CME #9 | Reloading chart.
2024-09-22 14:41:27.558 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 14:41:27.565 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 14:41:27.571 | MESZ4.CME 30 Min #1 | Reloading chart.
2024-09-22 14:41:27.704 | MESZ4.CME #16 | Reloading chart.
2024-09-22 14:41:27.704 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 14:41:27.711 | MESZ4.CME #16 | Chart data loading complete.
2024-09-22 14:41:27.837 | MESZ4.CME #18 | Reloading chart.
2024-09-22 14:41:27.838 | MESZ4.CME #18 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 14:41:27.845 | MESZ4.CME #18 | Chart data loading complete.
2024-09-22 14:41:27.854 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-22 14:41:27.854 | HD Request # 1 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-22 14:41:27.854 | HD Request # 1 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.918003
2024-09-22 14:41:27.854 | HD Request # 1 | Using server: ds32.sierracharts.com port 10150
2024-09-22 14:41:27.855 | HD Request # 2 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 14:41:27.868 | MESZ4.CME 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 14:41:27.868 | MESZ4.CME 30 Min #1 | Chart data loading complete.
2024-09-22 14:41:27.869 | ESZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:58
2024-09-22 14:41:27.880 | ESZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-22 14:41:27.966 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 3 Service code: cme
2024-09-22 14:41:27.966 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 3
2024-09-22 14:41:27.966 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-22 14:41:27.966 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-22 14:41:27.966 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 4 Service code: cme
2024-09-22 14:41:27.966 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 4
2024-09-22 14:41:27.966 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-22 14:41:27.967 | Socket (4) | Creating socket.
2024-09-22 14:41:27.967 | Socket (4) | New receive buffer size: 0
2024-09-22 14:41:27.967 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 14:41:27.979 | ESZ4.CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-22 14:41:27.985 | ESZ4.CME 5 Min #12 | Chart data loading complete.
2024-09-22 14:41:28.062 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-22 14:41:28.062 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-22 14:41:28.062 | Triggering next historical data download in queue.
2024-09-22 14:41:28.108 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | CloseSocket call.
2024-09-22 14:41:28.108 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:28.248 | ESZ4.CME[M] Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 14:41:28.355 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side.
2024-09-22 14:41:28.355 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Closed.
2024-09-22 14:41:28.537 | HD Request # 1 | Setting DTC encoding to Binary VLS
2024-09-22 14:41:28.537 | HD Request # 1 | Sending historical data logon request message.
2024-09-22 14:41:28.619 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-22 14:41:28.619 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-22 14:41:28.619 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-22 14:41:28.619 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-22 14:41:28.923 | HD Request # 2 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 14:41:29.308 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: ESZ24
2024-09-22 14:41:29.587 | HD Request # 1 | Decompressing data.
2024-09-22 14:41:29.833 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:29.837 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-22 14:41:29.837 | Triggering next historical data download in queue.
2024-09-22 14:41:29.837 | NQZ4.CME [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol NQZ4.CME starting at last date in file.
2024-09-22 14:41:29.837 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-22 14:41:29.856 | NQZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:29.863 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-22 14:41:29.866 | HD Request # 1 | Receiving Intraday data for ESZ4.CME starting at 2024-09-20 16:59:58.001000
2024-09-22 14:41:29.866 | Socket (4) | CloseSocket call.
2024-09-22 14:41:29.866 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:29.894 | NQZ4.CME [CBV] #16 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:29.918 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:30.007 | NQZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:30.014 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-22 14:41:30.100 | NQZ4.CME [CBV] 60 Min #14 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:30.107 | NQZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:30.107 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.107 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.144 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 14:41:30.144 | Socket (4) | Closed.
2024-09-22 14:41:30.301 | NQZ4.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 5,
2024-09-22 14:41:30.308 | NQZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:30.308 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.308 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.492 | NQZ4.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 5,
2024-09-22 14:41:30.499 | NQZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:30.499 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.499 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:30.681 | NQZ4.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 5,
2024-09-22 14:41:30.706 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-22 14:41:30.743 | NQZ4.CME [CBV] 60 Min #11 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:30.765 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-22 14:41:30.846 | NQZ4.CME [CBV] 15 Min #1 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:30.871 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-22 14:41:30.881 | NQZ4.CME [CBV] 5 Min #15 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:31.007 | MNQZ4.CME #9 | Reloading chart.
2024-09-22 14:41:31.040 | NQZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 14:41:31.080 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:31.170 | NQZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:31.178 | NQZ4.CME 5 Min #12 | Reloading chart.
2024-09-22 14:41:31.187 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-22 14:41:31.198 | NQZ4.CME [CBV] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 4, 5,
2024-09-22 14:41:31.348 | MNQZ4.CME [CBV] 1 Min #10 | Reloading chart.
2024-09-22 14:41:31.351 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-22 14:41:31.352 | MNQZ4.CME [CBV] 1 Min #10 | Performing continuous chart historical Daily data download for symbol MNQZ4.CME starting at last date in file.
2024-09-22 14:41:31.352 | Added historical Daily data request for MNQZ4.CME to the queue.
2024-09-22 14:41:31.361 | MNQZ4.CME [CBV] 1 Min #10 | Waiting for historical downloads to complete with the IDs: 6, 7,
2024-09-22 14:41:31.393 | Historical data download thread signaled to stop.
2024-09-22 14:41:31.393 | HD Request # 1 | Received 41 Intraday data records from 2024-09-20 16:59:58.001000 to 2024-09-20 16:59:58.918003 (0.9 seconds. Delay: 45.7 hours) and wrote 0 records for ESZ4.CME
2024-09-22 14:41:31.394 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:58.918003
2024-09-22 14:41:31.394 | HD Request # 1 | Completion time: 4s.
2024-09-22 14:41:31.394 | HD Request # 1 | Intraday data download complete for ESZ4.CME. Unique request ID: 1
2024-09-22 14:41:31.394 | Removing historical data download ID 1.
2024-09-22 14:41:31.394 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-22 14:41:31.394 | Intraday chart data file opened for ESZ4.CME
2024-09-22 14:41:31.394 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2024-09-22 14:41:31.394 | Triggering next historical data download in queue.
2024-09-22 14:41:31.394 | HD Request # 2 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-22 14:41:31.394 | HD Request # 2 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-22 14:41:31.397 | HD Request # 2 | Bytes received: 228
2024-09-22 14:41:31.397 | HD Request # 2 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-22 14:41:31.398 | HD Request # 2 | Completion time: 4s.
2024-09-22 14:41:31.398 | HD Request # 2 | Daily data download complete for ESZ4.CME. Unique request ID: 2
2024-09-22 14:41:31.398 | Removing historical data download ID 2.
2024-09-22 14:41:31.398 | Triggering next historical data download in queue.
2024-09-22 14:41:31.406 | MNQZ4.CME #9 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 14:41:31.407 | MNQZ4.CME #9 | Chart data loading complete.
2024-09-22 14:41:31.407 | Delaying start of download for MESZ4.CME.
2024-09-22 14:41:31.407 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-22 14:41:31.408 | HD Request # 3 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 14:41:31.441 | ESZ4.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.441 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 14:41:31.518 | NQZ4.CME Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:22
2024-09-22 14:41:31.556 | NQZ4.CME Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 14:41:31.596 | NQZ4.CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-22 14:41:31.603 | NQZ4.CME 5 Min #12 | Chart data loading complete.
2024-09-22 14:41:31.611 | ESZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.611 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:31.710 | ESZ4.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.710 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:31.872 | ESZ4.CME [CBV] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.872 | ESZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 14:41:31.956 | ESZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 14:41:31.969 | ESZ4.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:31.970 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:32.146 | ESZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.146 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:32.232 | ESZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 14:41:32.233 | ESZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.233 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:32.257 | ESZ4.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.258 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:32.447 | HD Request # 3 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 14:41:32.447 | ESZ4.CME [CBV] 15 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.447 | ESZ4.CME [CBV] 15 Min #17 | Reloading chart.
2024-09-22 14:41:32.463 | ESZ4.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.463 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 14:41:32.558 | ESZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 14:41:32.558 | ESZ4.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:32.558 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 14:41:32.609 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-22 14:41:32.609 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 6 Service code: cme
2024-09-22 14:41:32.609 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 6
2024-09-22 14:41:32.610 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 5 Service code: cme
2024-09-22 14:41:32.610 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 5
2024-09-22 14:41:32.638 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-22 14:41:32.642 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 14:41:32.856 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:33.077 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:33.077 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:33.077 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:33.544 | HD Request # 3 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-22 14:41:33.544 | HD Request # 3 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-22 14:41:33.547 | HD Request # 3 | Bytes received: 237
2024-09-22 14:41:33.547 | HD Request # 3 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for NQZ4.CME
2024-09-22 14:41:33.547 | HD Request # 3 | Completion time: 2s.
2024-09-22 14:41:33.547 | HD Request # 3 | Daily data download complete for NQZ4.CME. Unique request ID: 5
2024-09-22 14:41:33.547 | Removing historical data download ID 5.
2024-09-22 14:41:33.547 | Triggering next historical data download in queue.
2024-09-22 14:41:33.547 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-22 14:41:33.548 | HD Request # 4 | Downloading Historical Daily chart data for MNQZ4.CME. Starting date: 2024-09-17. Service: rithmic.trading
2024-09-22 14:41:33.548 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-22 14:41:33.548 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-22 14:41:33.550 | ESZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 14:41:33.772 | ESZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 14:41:33.791 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:33.791 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:33.791 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:34.283 | NQZ4.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:34.284 | NQZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:34.452 | ESZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 14:41:34.530 | NQZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 14:41:34.530 | HD Request # 4 | Requesting historical Daily data for NMZ24 starting at 2024-09-16. SC External HD service.
2024-09-22 14:41:34.566 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:34.790 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:34.849 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:34.849 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:34.849 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:35.297 | NQZ4.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:35.298 | NQZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:35.449 | ESZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 14:41:35.481 | HD Request # 4 | Receiving historical Daily data for MNQZ4.CME starting at 2024-09-17.
2024-09-22 14:41:35.481 | HD Request # 4 | Writing historical Daily data to the file MNQZ4.CME.dly.
2024-09-22 14:41:35.482 | HD Request # 4 | Bytes received: 301
2024-09-22 14:41:35.482 | HD Request # 4 | Received 5 Daily data records from 2024-09-17 00:00:00 to 2024-09-20 00:00:00 (4.0 days) and wrote 4 records for MNQZ4.CME
2024-09-22 14:41:35.483 | HD Request # 4 | Completion time: 2s.
2024-09-22 14:41:35.483 | HD Request # 4 | Daily data download complete for MNQZ4.CME. Unique request ID: 7
2024-09-22 14:41:35.483 | Removing historical data download ID 7.
2024-09-22 14:41:35.483 | No download requests in the queue to start downloads for.
2024-09-22 14:41:35.489 | ESZ4.CME [CBV] 15 Min #17 | Reloading chart.
2024-09-22 14:41:35.518 | NQZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 14:41:35.519 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 14:41:35.718 | ESZ4.CME [CBV] 15 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-21 16:15:00
2024-09-22 14:41:35.720 | ESZ4.CME [CBV] 15 Min #17 | Chart data loading complete.
2024-09-22 14:41:35.721 | NQZ4.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:35.721 | NQZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:35.884 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 14:41:35.982 | NQZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 14:41:35.984 | HD Request # 5 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-22 14:41:35.984 | HD Request # 5 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.769003
2024-09-22 14:41:35.984 | HD Request # 5 | Using server: ds32.sierracharts.com port 10149
2024-09-22 14:41:35.984 | Socket (4) | Creating socket.
2024-09-22 14:41:35.984 | Socket (4) | New receive buffer size: 0
2024-09-22 14:41:35.984 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 14:41:35.993 | NQZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 14:41:35.993 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:35.993 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:36.387 | NQZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 14:41:36.387 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:36.387 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:36.533 | HD Request # 5 | Setting DTC encoding to Binary VLS
2024-09-22 14:41:36.533 | HD Request # 5 | Sending historical data logon request message.
2024-09-22 14:41:36.775 | NQZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 14:41:36.840 | NQZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 14:41:36.842 | NQZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 14:41:36.842 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:36.842 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 14:41:37.281 | NQZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 14:41:37.293 | HD Request # 5 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: MESZ24
2024-09-22 14:41:37.564 | HD Request # 5 | Decompressing data.
2024-09-22 14:41:37.833 | HD Request # 5 | Receiving Intraday data for MESZ4.CME starting at 2024-09-20 16:59:58.000000
2024-09-22 14:41:37.833 | Socket (4) | CloseSocket call.
2024-09-22 14:41:37.833 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:37.833 | Historical data download thread signaled to stop.
2024-09-22 14:41:37.833 | HD Request # 5 | Received 14 Intraday data records from 2024-09-20 16:59:58.000000 to 2024-09-20 16:59:58.769003 (0.8 seconds. Delay: 45.7 hours) and wrote 0 records for MESZ4.CME
2024-09-22 14:41:37.833 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:58.769003
2024-09-22 14:41:37.833 | HD Request # 5 | Completion time: 2s.
2024-09-22 14:41:37.833 | HD Request # 5 | Intraday data download complete for MESZ4.CME. Unique request ID: 3
2024-09-22 14:41:37.833 | Removing historical data download ID 3.
2024-09-22 14:41:37.833 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-22 14:41:37.833 | Intraday chart data file opened for MESZ4.CME
2024-09-22 14:41:37.833 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2024-09-22 14:41:37.833 | Triggering next historical data download in queue.
2024-09-22 14:41:37.833 | Delaying start of download for NQZ4.CME.
2024-09-22 14:41:38.103 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 14:41:38.103 | Socket (4) | Closed.
2024-09-22 14:41:38.197 | HD Request # 6 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-22 14:41:38.198 | HD Request # 6 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.313003
2024-09-22 14:41:38.198 | HD Request # 6 | Using server: ds32.sierracharts.com port 10150
2024-09-22 14:41:38.198 | Socket (3) | Creating socket.
2024-09-22 14:41:38.198 | Socket (3) | New receive buffer size: 0
2024-09-22 14:41:38.198 | Socket (3) | Connecting to IP: 67.214.125.3.
2024-09-22 14:41:38.752 | HD Request # 6 | Setting DTC encoding to Binary VLS
2024-09-22 14:41:38.752 | HD Request # 6 | Sending historical data logon request message.
2024-09-22 14:41:39.024 | HD Request # 6 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: NQZ24
2024-09-22 14:41:39.298 | HD Request # 6 | Decompressing data.
2024-09-22 14:41:39.613 | HD Request # 6 | Receiving Intraday data for NQZ4.CME starting at 2024-09-20 16:59:59.313000
2024-09-22 14:41:39.613 | Socket (3) | CloseSocket call.
2024-09-22 14:41:39.613 | Socket (3) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:39.613 | Historical data download thread signaled to stop.
2024-09-22 14:41:39.613 | HD Request # 6 | Received 4 Intraday data records from 2024-09-20 16:59:59.313000 to 2024-09-20 16:59:59.313003 (0.0 seconds. Delay: 45.7 hours) and wrote 0 records for NQZ4.CME
2024-09-22 14:41:39.613 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:59.313003
2024-09-22 14:41:39.613 | HD Request # 6 | Completion time: 1s.
2024-09-22 14:41:39.613 | HD Request # 6 | Intraday data download complete for NQZ4.CME. Unique request ID: 4
2024-09-22 14:41:39.613 | Removing historical data download ID 4.
2024-09-22 14:41:39.613 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-22 14:41:39.613 | Intraday chart data file opened for NQZ4.CME
2024-09-22 14:41:39.613 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2024-09-22 14:41:39.613 | Triggering next historical data download in queue.
2024-09-22 14:41:39.613 | HD Request # 7 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-22 14:41:39.613 | HD Request # 7 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.605000
2024-09-22 14:41:39.613 | HD Request # 7 | Using server: ds32.sierracharts.com port 10149
2024-09-22 14:41:39.613 | Socket (4) | Creating socket.
2024-09-22 14:41:39.613 | Socket (4) | New receive buffer size: 0
2024-09-22 14:41:39.613 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 14:41:39.709 | NQZ4.CME [CBV] 60 Min #11 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.710 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-22 14:41:39.745 | NQZ4.CME [CBV] 1 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.745 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-22 14:41:39.789 | NQZ4.CME [CBV] 15 Min #1 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.790 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-22 14:41:39.876 | NQZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.877 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:39.885 | Socket (3) | Socket gracefully closed by remote side.
2024-09-22 14:41:39.885 | Socket (3) | Closed.
2024-09-22 14:41:39.898 | NQZ4.CME [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.898 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-22 14:41:39.925 | NQZ4.CME [CBV] 5 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.925 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-22 14:41:39.941 | NQZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:39.942 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:40.033 | NQZ4.CME [CBV] 60 Min #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:40.033 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-22 14:41:40.144 | NQZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:40.145 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:40.168 | HD Request # 7 | Setting DTC encoding to Binary VLS
2024-09-22 14:41:40.168 | HD Request # 7 | Sending historical data logon request message.
2024-09-22 14:41:40.248 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-22 14:41:40.396 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-22 14:41:40.430 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-22 14:41:40.441 | HD Request # 7 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: MNQZ24
2024-09-22 14:41:40.712 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 14:41:40.715 | HD Request # 7 | Decompressing data.
2024-09-22 14:41:40.786 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-22 14:41:40.893 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-22 14:41:40.934 | NQZ4.CME [CBV] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 14:41:40.963 | NQZ4.CME [CBV] 5 Min #15 | Chart data loading complete.
2024-09-22 14:41:40.987 | HD Request # 7 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-20 16:59:59.155000
2024-09-22 14:41:40.987 | Socket (4) | CloseSocket call.
2024-09-22 14:41:40.987 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 14:41:40.990 | Historical data download thread signaled to stop.
2024-09-22 14:41:40.990 | HD Request # 7 | Received 2 Intraday data records from 2024-09-20 16:59:59.155000 to 2024-09-20 16:59:59.605000 (0.5 seconds. Delay: 45.7 hours) and wrote 0 records for MNQZ4.CME
2024-09-22 14:41:40.990 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:59.605000
2024-09-22 14:41:40.990 | HD Request # 7 | Completion time: 1s.
2024-09-22 14:41:40.990 | HD Request # 7 | Intraday data download complete for MNQZ4.CME. Unique request ID: 6
2024-09-22 14:41:40.990 | Removing historical data download ID 6.
2024-09-22 14:41:40.990 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-22 14:41:40.990 | Intraday chart data file opened for MNQZ4.CME
2024-09-22 14:41:40.990 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2024-09-22 14:41:40.990 | No download requests in the queue to start downloads for.
2024-09-22 14:41:40.990 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 14:41:41.246 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-22 14:41:41.259 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 14:41:41.260 | Socket (4) | Closed.
2024-09-22 14:41:41.511 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 14:41:41.802 | MNQZ4.CME [CBV] 1 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 14:41:41.803 | MNQZ4.CME [CBV] 1 Min #10 | Reloading chart. | Number times message added: 1
2024-09-22 14:41:42.621 | NQZ4.CME [CBV][M] 1 Min #8 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 14:41:42.649 | NQZ4.CME [CBV][M] 1 Min #8 | Chart data loading complete.
2024-09-22 14:41:43.152 | MNQZ4.CME [CBV][M] 1 Min #10 | StartDateTimeForLoadingOrderFills: 2024-09-06 17:38:18
2024-09-22 14:41:43.157 | MNQZ4.CME [CBV][M] 1 Min #10 | Chart data loading complete.
2024-09-22 14:41:49.057 | ESZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-22 14:41:52.108 | NQZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-22 14:41:56.349 | NQZ4.CME [CBV][M] #16 | Chart data loading complete.
2024-09-22 14:42:07.714 | NQZ4.CME [CBV][M] 60 Min #11 | StartDateTimeForLoadingOrderFills: 2023-11-26 18:00:00
2024-09-22 14:42:07.886 | NQZ4.CME [CBV][M] 60 Min #11 | Chart data loading complete.
2024-09-22 14:42:12.315 | ESZ4.CME [CBV][M] 60 Min #8 | Chart data loading complete.
2024-09-22 14:42:13.588 | NQZ4.CME [CBV][M] 60 Min #14 | Chart data loading complete.
2024-09-22 14:42:25.470 | ESZ4.CME [CBV][M] 240 Min #15 | Chart data loading complete.
2024-09-22 14:42:38.999 | NQZ4.CME [CBV][M] 15 Min #1 | Chart data loading complete.
2024-09-22 14:42:41.784 | NQZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 14:42:44.641 | NQZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-22 14:42:55.486 | ESZ4.CME [CBV][M] #14 | Chart data loading complete.
2024-09-22 14:43:05.914 | ESZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 14:43:07.698 | ESZ4.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-13 18:00:00
2024-09-22 14:43:07.801 | ESZ4.CME [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-22 14:43:09.426 | ESZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-22 15:37:59.747 | Saved Chartbook: ES.Cht. Time: 0.0613 seconds.
2024-09-22 15:38:04.148 | Unsubscribed from market depth data for ESZ4.CME
2024-09-22 15:38:04.148 | Unsubscribed from market depth data for MESZ4.CME
2024-09-22 15:38:04.764 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 15:38:04.813 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 15:38:05.000 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 15:38:05.167 | ESZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 15:38:05.340 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 15:38:05.340 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:05.340 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:05.693 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 15:38:05.693 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:05.693 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:06.045 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 15:38:06.045 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:06.045 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 15:38:06.404 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 15:38:06.602 | ESZ4.CME 5 Min #12 | Reloading chart.
2024-09-22 15:38:06.613 | ESZ4.CME [CBV] 15 Min #17 | Reloading chart.
2024-09-22 15:38:06.665 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 15:38:06.786 | ESZ4.CME 5 Min #11 | Reloading chart.
2024-09-22 15:38:06.821 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 15:38:07.044 | ESZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 15:38:07.231 | ESZ4.CME #9 | Reloading chart.
2024-09-22 15:38:07.231 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 15:38:07.241 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 15:38:07.250 | MESZ4.CME 30 Min #1 | Reloading chart.
2024-09-22 15:38:07.441 | MESZ4.CME #16 | Reloading chart.
2024-09-22 15:38:07.441 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 15:38:07.452 | MESZ4.CME #16 | Chart data loading complete.
2024-09-22 15:38:07.637 | MESZ4.CME #18 | Reloading chart.
2024-09-22 15:38:07.637 | MESZ4.CME #18 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 15:38:07.648 | MESZ4.CME #18 | Chart data loading complete.
2024-09-22 15:38:07.663 | ESZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 15:38:07.665 | ESZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 15:38:07.669 | ESZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 15:38:07.682 | MESZ4.CME 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 15:38:07.682 | MESZ4.CME 30 Min #1 | Chart data loading complete.
2024-09-22 15:38:07.683 | ESZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:58
2024-09-22 15:38:07.696 | ESZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-22 15:38:07.732 | ESZ4.CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-22 15:38:07.742 | ESZ4.CME 5 Min #12 | Chart data loading complete.
2024-09-22 15:38:08.242 | ESZ4.CME[M] Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 15:38:09.136 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-22 15:38:09.136 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-22 15:38:09.631 | ESZ4.CME [CBV][M] 15 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-21 16:15:00
2024-09-22 15:38:09.632 | ESZ4.CME [CBV][M] 15 Min #17 | Chart data loading complete.
2024-09-22 15:38:09.802 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-22 15:38:09.802 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-22 15:38:16.986 | ESZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-22 15:38:36.832 | ESZ4.CME [CBV][M] 60 Min #8 | Chart data loading complete.
2024-09-22 15:38:46.011 | ESZ4.CME [CBV][M] 240 Min #15 | Chart data loading complete.
2024-09-22 15:39:14.592 | ESZ4.CME [CBV][M] #14 | Chart data loading complete.
2024-09-22 15:39:26.380 | ESZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 15:39:27.851 | ESZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-22 15:39:28.839 | ESZ4.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-13 18:00:00
2024-09-22 15:39:28.926 | ESZ4.CME [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-22 17:00:10.117 | DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-22 17:00:10.117 | DTC Client socket (6) | Socket gracefully closed by remote side.
2024-09-22 17:00:10.117 | DTC Client socket (6) | CloseSocket call.
2024-09-22 17:00:10.117 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-22 17:00:10.118 | DTC Client socket (6) | Closed.
2024-09-22 17:00:10.119 | Chat | Waiting for socket receive thread to end
2024-09-22 17:00:10.119 | DTC Client socket (0) | CloseSocket call.
2024-09-22 17:00:10.119 | Chat | Disconnected from the server.
2024-09-22 17:00:10.119 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2024-09-22 17:00:15.108 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-22 17:00:15.235 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2024-09-22 17:00:15.235 | DTC Client socket (3) | New receive buffer size: 0
2024-09-22 17:00:15.235 | DTC Client socket (3) | Connecting to IP: 69.39.70.248.
2024-09-22 17:00:15.509 | Chat | Network connection to server complete.
2024-09-22 17:00:15.509 | Chat | Starting socket receive thread.
2024-09-22 17:00:15.509 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-22 17:00:16.331 | Chat | Setting DTC encoding to Binary VLS
2024-09-22 17:00:16.331 | Chat | Sending logon request message.
2024-09-22 17:00:21.544 | Chat | Received logon response.
2024-09-22 17:00:21.544 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-22 17:00:21.544 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-22 17:00:21.544 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-22 17:00:21.544 | Chat | Trading is not supported.
2024-09-22 17:00:21.544 | Chat | MarketDepthIsSupported: 1
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol ESZ4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol NQZ4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol MNQZ4.CME is currently unavailable.
2024-09-22 17:36:23.838 | Denali Data Feed | Real-time data for symbol MESZ4.CME is currently unavailable.
2024-09-22 17:36:46.695 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-22 17:36:46.729 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-22 17:36:46.729 | Denali Data Feed | Real-time data for symbol ESZ4.CME has been restored.
2024-09-22 17:36:46.729 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-22 17:36:46.729 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-22 17:36:46.729 | Triggering next historical data download in queue.
2024-09-22 17:36:46.729 | HD Request # 8 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-22 17:36:46.729 | HD Request # 8 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.918003
2024-09-22 17:36:46.729 | HD Request # 8 | Using server: ds32.sierracharts.com port 10150
2024-09-22 17:36:46.845 | Socket (4) | Creating socket.
2024-09-22 17:36:46.845 | Socket (4) | New receive buffer size: 0
2024-09-22 17:36:46.845 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 17:36:47.397 | HD Request # 8 | Setting DTC encoding to Binary VLS
2024-09-22 17:36:47.397 | HD Request # 8 | Sending historical data logon request message.
2024-09-22 17:36:58.066 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-22 17:36:58.066 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-22 17:36:58.067 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-22 17:36:58.067 | Denali Data Feed | Real-time data for symbol NQZ4.CME has been restored.
2024-09-22 17:36:58.067 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-22 17:36:58.067 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-22 17:36:58.067 | Triggering next historical data download in queue.
2024-09-22 17:36:58.067 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-22 17:36:58.067 | Denali Data Feed | Real-time data for symbol MNQZ4.CME has been restored.
2024-09-22 17:36:58.067 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-22 17:36:58.067 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-22 17:36:58.067 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-22 17:36:58.067 | Denali Data Feed | Real-time data for symbol MESZ4.CME has been restored.
2024-09-22 17:36:58.067 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-22 17:36:58.067 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-22 17:36:58.597 | HD Request # 8 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: ESZ24
2024-09-22 17:36:58.866 | HD Request # 8 | Decompressing data.
2024-09-22 17:36:59.134 | HD Request # 8 | Receiving Intraday data for ESZ4.CME starting at 2024-09-20 16:59:58.001000
2024-09-22 17:36:59.134 | Socket (4) | CloseSocket call.
2024-09-22 17:36:59.134 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 17:36:59.134 | Historical data download thread signaled to stop.
2024-09-22 17:36:59.134 | HD Request # 8 | Received 41 Intraday data records from 2024-09-20 16:59:58.001000 to 2024-09-20 16:59:58.918003 (0.9 seconds. Delay: 2.0 days) and wrote 0 records for ESZ4.CME
2024-09-22 17:36:59.135 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:58.918003
2024-09-22 17:36:59.135 | HD Request # 8 | Completion time: 13s.
2024-09-22 17:36:59.135 | HD Request # 8 | Intraday data download complete for ESZ4.CME. Unique request ID: 8
2024-09-22 17:36:59.135 | Removing historical data download ID 8.
2024-09-22 17:36:59.135 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-22 17:36:59.135 | Intraday chart data file opened for ESZ4.CME
2024-09-22 17:36:59.135 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2024-09-22 17:36:59.135 | Triggering next historical data download in queue.
2024-09-22 17:36:59.135 | HD Request # 9 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-22 17:36:59.135 | HD Request # 9 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.313003
2024-09-22 17:36:59.135 | HD Request # 9 | Using server: ds32.sierracharts.com port 10149
2024-09-22 17:36:59.135 | Socket (5) | Creating socket.
2024-09-22 17:36:59.135 | Socket (5) | New receive buffer size: 0
2024-09-22 17:36:59.135 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 17:36:59.403 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 17:36:59.403 | Socket (4) | Closed.
2024-09-22 17:36:59.693 | HD Request # 9 | Setting DTC encoding to Binary VLS
2024-09-22 17:36:59.693 | HD Request # 9 | Sending historical data logon request message.
2024-09-22 17:37:11.607 | HD Request # 9 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: NQZ24
2024-09-22 17:37:11.882 | HD Request # 9 | Decompressing data.
2024-09-22 17:37:12.157 | HD Request # 9 | Receiving Intraday data for NQZ4.CME starting at 2024-09-20 16:59:59.313000
2024-09-22 17:37:12.157 | Socket (5) | CloseSocket call.
2024-09-22 17:37:12.157 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 17:37:12.157 | Historical data download thread signaled to stop.
2024-09-22 17:37:12.157 | HD Request # 9 | Received 4 Intraday data records from 2024-09-20 16:59:59.313000 to 2024-09-20 16:59:59.313003 (0.0 seconds. Delay: 2.0 days) and wrote 0 records for NQZ4.CME
2024-09-22 17:37:12.157 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:59.313003
2024-09-22 17:37:12.157 | HD Request # 9 | Completion time: 13s.
2024-09-22 17:37:12.157 | HD Request # 9 | Intraday data download complete for NQZ4.CME. Unique request ID: 9
2024-09-22 17:37:12.157 | Removing historical data download ID 9.
2024-09-22 17:37:12.157 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-22 17:37:12.157 | Intraday chart data file opened for NQZ4.CME
2024-09-22 17:37:12.157 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2024-09-22 17:37:12.157 | Triggering next historical data download in queue.
2024-09-22 17:37:12.157 | HD Request # 10 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-22 17:37:12.157 | HD Request # 10 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.605000
2024-09-22 17:37:12.157 | HD Request # 10 | Using server: ds32.sierracharts.com port 10150
2024-09-22 17:37:12.157 | Socket (4) | Creating socket.
2024-09-22 17:37:12.157 | Socket (4) | New receive buffer size: 0
2024-09-22 17:37:12.157 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 17:37:12.431 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 17:37:12.431 | Socket (5) | Closed.
2024-09-22 17:37:12.719 | HD Request # 10 | Setting DTC encoding to Binary VLS
2024-09-22 17:37:12.719 | HD Request # 10 | Sending historical data logon request message.
2024-09-22 17:37:24.605 | HD Request # 10 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: MNQZ24
2024-09-22 17:37:24.879 | HD Request # 10 | Decompressing data.
2024-09-22 17:37:25.151 | HD Request # 10 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-20 16:59:59.155000
2024-09-22 17:37:25.151 | Socket (4) | CloseSocket call.
2024-09-22 17:37:25.151 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 17:37:25.151 | Historical data download thread signaled to stop.
2024-09-22 17:37:25.151 | HD Request # 10 | Received 2 Intraday data records from 2024-09-20 16:59:59.155000 to 2024-09-20 16:59:59.605000 (0.5 seconds. Delay: 2.0 days) and wrote 0 records for MNQZ4.CME
2024-09-22 17:37:25.152 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:59.605000
2024-09-22 17:37:25.152 | HD Request # 10 | Completion time: 13s.
2024-09-22 17:37:25.152 | HD Request # 10 | Intraday data download complete for MNQZ4.CME. Unique request ID: 10
2024-09-22 17:37:25.152 | Removing historical data download ID 10.
2024-09-22 17:37:25.152 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-22 17:37:25.152 | Intraday chart data file opened for MNQZ4.CME
2024-09-22 17:37:25.152 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2024-09-22 17:37:25.152 | Triggering next historical data download in queue.
2024-09-22 17:37:25.152 | HD Request # 11 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-22 17:37:25.152 | HD Request # 11 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.769003
2024-09-22 17:37:25.152 | HD Request # 11 | Using server: ds32.sierracharts.com port 10149
2024-09-22 17:37:25.152 | Socket (5) | Creating socket.
2024-09-22 17:37:25.152 | Socket (5) | New receive buffer size: 0
2024-09-22 17:37:25.152 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 17:37:25.424 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 17:37:25.424 | Socket (4) | Closed.
2024-09-22 17:37:25.711 | HD Request # 11 | Setting DTC encoding to Binary VLS
2024-09-22 17:37:25.711 | HD Request # 11 | Sending historical data logon request message.
2024-09-22 17:37:37.611 | HD Request # 11 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: MESZ24
2024-09-22 17:37:37.888 | HD Request # 11 | Decompressing data.
2024-09-22 17:37:38.161 | HD Request # 11 | Receiving Intraday data for MESZ4.CME starting at 2024-09-20 16:59:58.000000
2024-09-22 17:37:38.161 | Socket (5) | CloseSocket call.
2024-09-22 17:37:38.161 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 17:37:38.161 | Historical data download thread signaled to stop.
2024-09-22 17:37:38.161 | HD Request # 11 | Received 14 Intraday data records from 2024-09-20 16:59:58.000000 to 2024-09-20 16:59:58.769003 (0.8 seconds. Delay: 2.0 days) and wrote 0 records for MESZ4.CME
2024-09-22 17:37:38.162 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2024-09-20 20:59:58.769003
2024-09-22 17:37:38.162 | HD Request # 11 | Completion time: 13s.
2024-09-22 17:37:38.162 | HD Request # 11 | Intraday data download complete for MESZ4.CME. Unique request ID: 11
2024-09-22 17:37:38.162 | Removing historical data download ID 11.
2024-09-22 17:37:38.162 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-22 17:37:38.162 | Intraday chart data file opened for MESZ4.CME
2024-09-22 17:37:38.162 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2024-09-22 17:37:38.162 | No download requests in the queue to start downloads for.
2024-09-22 17:37:38.437 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 17:37:38.437 | Socket (5) | Closed.
2024-09-22 17:45:00.086 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-22 17:45:00.086 | Triggering next historical data download in queue.
2024-09-22 17:45:00.087 | HD Request # 12 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 17:45:00.088 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-22 17:45:00.088 | Triggering next historical data download in queue.
2024-09-22 17:45:01.054 | HD Request # 12 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 17:45:01.992 | HD Request # 12 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-22 17:45:01.993 | HD Request # 12 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-22 17:45:01.996 | HD Request # 12 | Bytes received: 234
2024-09-22 17:45:01.996 | HD Request # 12 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-22 17:45:01.996 | HD Request # 12 | Completion time: 1s.
2024-09-22 17:45:01.996 | HD Request # 12 | Daily data download complete for ESZ4.CME. Unique request ID: 12
2024-09-22 17:45:01.996 | Removing historical data download ID 12.
2024-09-22 17:45:01.996 | Triggering next historical data download in queue.
2024-09-22 17:45:01.997 | HD Request # 13 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 17:45:02.133 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 17:45:02.133 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.133 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.529 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 17:45:02.554 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 17:45:02.554 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.554 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.942 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 17:45:02.943 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 17:45:02.943 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:02.943 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:03.266 | HD Request # 13 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 17:45:03.331 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 17:45:04.038 | HD Request # 13 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-22 17:45:04.038 | HD Request # 13 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-22 17:45:04.040 | HD Request # 13 | Bytes received: 242
2024-09-22 17:45:04.040 | HD Request # 13 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for NQZ4.CME
2024-09-22 17:45:04.040 | HD Request # 13 | Completion time: 3s.
2024-09-22 17:45:04.040 | HD Request # 13 | Daily data download complete for NQZ4.CME. Unique request ID: 13
2024-09-22 17:45:04.040 | Removing historical data download ID 13.
2024-09-22 17:45:04.040 | No download requests in the queue to start downloads for.
2024-09-22 17:45:04.157 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 17:45:04.157 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.157 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.467 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 17:45:04.467 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.467 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.767 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 17:45:04.836 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 17:45:04.838 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 17:45:04.838 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:04.838 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 17:45:05.177 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 18:00:02.149 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-22 18:00:02.150 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 3296
2024-09-22 18:00:02.150 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-22 18:00:02.150 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-22 19:41:03.090 | 6AZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:03.094 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-22 19:41:03.094 | Triggering next historical data download in queue.
2024-09-22 19:41:03.095 | 6AZ4.CME [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol 6AZ4.CME starting at last date in file.
2024-09-22 19:41:03.095 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-22 19:41:03.095 | Triggering next historical data download in queue.
2024-09-22 19:41:03.111 | 6AZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:03.120 | 6AZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:03.205 | 6AZ4.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:03.214 | 6AZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:03.287 | 6AZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:03.296 | 6AZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:03.369 | 6AZ4.CME [CBV] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:03.379 | 6AZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:03.379 | 6AZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.379 | 6AZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.554 | 6AZ4.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 15,
2024-09-22 19:41:03.563 | 6AZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:03.563 | 6AZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.563 | 6AZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.725 | 6AZ4.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 15,
2024-09-22 19:41:03.734 | 6AZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:03.734 | 6AZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.734 | 6AZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:03.890 | 6AZ4.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 15,
2024-09-22 19:41:03.925 | 6AZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:03.994 | 6AZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:04.027 | 6AZ4.CME 15 Min #12 | Reloading chart.
2024-09-22 19:41:04.057 | 6AZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:04.091 | 6AZ4.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:04.118 | 6AZ4.CME 5 Min #11 | Reloading chart.
2024-09-22 19:41:04.149 | 6AZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:04.219 | 6AZ4.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:04.229 | 6AZ4.CME [CBV] 2 Min #17 | Reloading chart.
2024-09-22 19:41:04.238 | 6AZ4.CME [CBV] 2 Min #17 | Waiting for historical downloads to complete with the IDs: 14, 15,
2024-09-22 19:41:04.266 | 6AZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 19:41:04.409 | ESZ4.CME #9 | Reloading chart.
2024-09-22 19:41:04.409 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:04.409 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 19:41:04.418 | M6AZ4.CME 15 Min #1 | Reloading chart.
2024-09-22 19:41:04.563 | MESZ4.CME #16 | Reloading chart.
2024-09-22 19:41:04.563 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:04.563 | MESZ4.CME #16 | Chart data loading complete.
2024-09-22 19:41:04.706 | 6AZ4.CME #18 | Reloading chart.
2024-09-22 19:41:04.707 | 6AZ4.CME #18 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:04.707 | 6AZ4.CME #18 | Chart data loading complete.
2024-09-22 19:41:04.715 | Mapping 6AZ4.CME to 6AZ24. Service code: cme
2024-09-22 19:41:04.715 | HD Request # 14 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-22 19:41:04.715 | HD Request # 14 | Download start date-time: 2024-09-20 16:58:13.000000. File last date-time: 2024-09-20 16:58:13.494000
2024-09-22 19:41:04.715 | HD Request # 14 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:41:04.716 | HD Request # 15 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 19:41:04.724 | 6AZ4.CME 15 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-28 20:00:00
2024-09-22 19:41:04.726 | 6AZ4.CME 15 Min #12 | Chart data loading complete.
2024-09-22 19:41:04.728 | 6AZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:58:13
2024-09-22 19:41:04.739 | 6AZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-22 19:41:04.742 | 6AZ4.CME Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-28 20:06:36
2024-09-22 19:41:04.752 | 6AZ4.CME Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 19:41:04.774 | M6AZ4.CME 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:30:00
2024-09-22 19:41:04.774 | M6AZ4.CME 15 Min #1 | Chart data loading complete.
2024-09-22 19:41:04.840 | Socket (4) | Creating socket.
2024-09-22 19:41:04.840 | Socket (4) | New receive buffer size: 0
2024-09-22 19:41:04.840 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:05.311 | Denali Data Feed | Starting real-time market data updates for: 6AZ4.CME (6AZ24). ID: 7 Service code: cme
2024-09-22 19:41:05.311 | Denali Data Feed | Requesting security definition data for: 6AZ4.CME (6AZ24). ID: 7
2024-09-22 19:41:05.327 | Mapping M6AZ4.CME to M6AZ24. Service code: cme
2024-09-22 19:41:05.327 | Denali Data Feed | Starting real-time market data updates for: M6AZ4.CME (M6AZ24). ID: 8 Service code: cme
2024-09-22 19:41:05.327 | Denali Data Feed | Requesting security definition data for: M6AZ4.CME (M6AZ24). ID: 8
2024-09-22 19:41:05.327 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-22 19:41:05.327 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-22 19:41:05.327 | Triggering next historical data download in queue.
2024-09-22 19:41:05.396 | HD Request # 14 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:05.396 | HD Request # 14 | Sending historical data logon request message.
2024-09-22 19:41:05.922 | HD Request # 15 | Requesting historical Daily data for A6Z24 starting at 2024-09-17. SC External HD service.
2024-09-22 19:41:05.949 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-22 19:41:05.949 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-22 19:41:06.082 | Requesting market depth updates for: 6AZ4.CME if supported. NumLevels=50
2024-09-22 19:41:06.169 | HD Request # 14 | Requesting Intraday data. Start date-time: 2024-09-20 16:58:13. Record interval: 0. Symbol: 6AZ24
2024-09-22 19:41:06.203 | 6JZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:06.208 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-22 19:41:06.208 | Triggering next historical data download in queue.
2024-09-22 19:41:06.209 | 6JZ4.CME [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol 6JZ4.CME starting at last date in file.
2024-09-22 19:41:06.209 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-22 19:41:06.209 | Triggering next historical data download in queue.
2024-09-22 19:41:06.225 | 6JZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:06.235 | 6JZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:06.314 | 6JZ4.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:06.325 | 6JZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:06.395 | 6JZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:06.404 | 6JZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:06.443 | HD Request # 14 | Decompressing data.
2024-09-22 19:41:06.478 | 6JZ4.CME [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:06.489 | 6JZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:06.489 | 6JZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.489 | 6JZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.659 | 6JZ4.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 18,
2024-09-22 19:41:06.669 | 6JZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:06.669 | 6JZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.669 | 6JZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.719 | HD Request # 14 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-20 16:58:13.494000
2024-09-22 19:41:06.719 | Socket (4) | CloseSocket call.
2024-09-22 19:41:06.719 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:06.825 | 6JZ4.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 18,
2024-09-22 19:41:06.864 | 6JZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:06.864 | 6JZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.864 | 6JZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:06.950 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-22 19:41:06.991 | Socket (4) | Socket gracefully closed by remote side.
2024-09-22 19:41:06.992 | Socket (4) | Closed.
2024-09-22 19:41:07.021 | 6JZ4.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 18,
2024-09-22 19:41:07.031 | 6JZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:07.101 | 6JZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:07.136 | 6JZ4.CME 5 Min #12 | Reloading chart.
2024-09-22 19:41:07.167 | 6JZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:07.205 | 6JZ4.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:07.234 | 6JZ4.CME 5 Min #11 | Reloading chart.
2024-09-22 19:41:07.268 | 6JZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:07.339 | 6JZ4.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:07.351 | 6JZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-22 19:41:07.360 | 6JZ4.CME [CBV] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 17, 18,
2024-09-22 19:41:07.389 | 6JZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-22 19:41:07.555 | ESZ4.CME #9 | Reloading chart.
2024-09-22 19:41:07.555 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:07.555 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 19:41:07.578 | MJYZ4.CME 15 Min #1 | Reloading chart.
2024-09-22 19:41:07.590 | USDX 60 Min #16 | Reloading chart.
2024-09-22 19:41:07.610 | Historical data download thread signaled to stop.
2024-09-22 19:41:07.610 | HD Request # 14 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.000000.
2024-09-22 19:41:07.610 | HD Request # 14 | Received 861 Intraday data records from 2024-09-20 16:58:13.494000 to 2024-09-22 19:40:46.245000 (2.1 days. Delay: 21.4 seconds) and wrote 860 records for 6AZ4.CME
2024-09-22 19:41:07.610 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:40:46.245000
2024-09-22 19:41:07.610 | HD Request # 14 | Completion time: 3s.
2024-09-22 19:41:07.610 | HD Request # 14 | Intraday data download complete for 6AZ4.CME. Unique request ID: 14
2024-09-22 19:41:07.610 | Removing historical data download ID 14.
2024-09-22 19:41:07.610 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-22 19:41:07.610 | Intraday chart data file opened for 6AZ4.CME
2024-09-22 19:41:07.610 | HD Request # 14 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:07.611 | Triggering next historical data download in queue.
2024-09-22 19:41:07.617 | 6JZ4.CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-28 20:00:00
2024-09-22 19:41:07.622 | 6JZ4.CME 5 Min #12 | Chart data loading complete.
2024-09-22 19:41:07.623 | 6JZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:57
2024-09-22 19:41:07.631 | 6JZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-22 19:41:07.637 | 6JZ4.CME Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-28 20:04:22
2024-09-22 19:41:07.647 | 6JZ4.CME Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 19:41:07.673 | MJYZ4.CME 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 23:30:00
2024-09-22 19:41:07.673 | MJYZ4.CME 15 Min #1 | Chart data loading complete.
2024-09-22 19:41:07.674 | Delaying start of download for M6AZ4.CME.
2024-09-22 19:41:07.761 | USDX 60 Min #16 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 19:41:07.761 | USDX 60 Min #16 | Chart data loading complete.
2024-09-22 19:41:08.251 | Mapping 6JZ4.CME to 6JZ24. Service code: cme
2024-09-22 19:41:08.251 | Denali Data Feed | Starting real-time market data updates for: 6JZ4.CME (6JZ24). ID: 9 Service code: cme
2024-09-22 19:41:08.251 | Denali Data Feed | Requesting security definition data for: 6JZ4.CME (6JZ24). ID: 9
2024-09-22 19:41:08.265 | Mapping MJYZ4.CME to MJYZ24. Service code: cme
2024-09-22 19:41:08.265 | Denali Data Feed | Starting real-time market data updates for: MJYZ4.CME (MJYZ24). ID: 10 Service code: cme
2024-09-22 19:41:08.265 | Denali Data Feed | Requesting security definition data for: MJYZ4.CME (MJYZ24). ID: 10
2024-09-22 19:41:08.265 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-22 19:41:08.265 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-22 19:41:08.265 | Triggering next historical data download in queue.
2024-09-22 19:41:08.266 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 11 Service code: fxstatscalc
2024-09-22 19:41:08.268 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2024-09-22 19:41:08.270 | SC Data with Depth | Requesting security definition data for: USDX. ID: 11
2024-09-22 19:41:08.270 | Added historical Intraday data request for USDX to the queue.
2024-09-22 19:41:08.270 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2024-09-22 19:41:08.270 | Triggering next historical data download in queue.
2024-09-22 19:41:08.303 | HD Request # 15 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-18.
2024-09-22 19:41:08.303 | HD Request # 15 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-22 19:41:08.308 | HD Request # 15 | Bytes received: 237
2024-09-22 19:41:08.308 | HD Request # 15 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6AZ4.CME
2024-09-22 19:41:08.308 | HD Request # 15 | Completion time: 4s.
2024-09-22 19:41:08.308 | HD Request # 15 | Daily data download complete for 6AZ4.CME. Unique request ID: 15
2024-09-22 19:41:08.308 | Removing historical data download ID 15.
2024-09-22 19:41:08.308 | Triggering next historical data download in queue.
2024-09-22 19:41:08.309 | HD Request # 16 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 19:41:08.387 | DTC Client socket (4) | Creating socket.
2024-09-22 19:41:08.387 | DTC Client socket (4) | New receive buffer size: 0
2024-09-22 19:41:08.387 | DTC Client socket (4) | Connecting to IP: 69.39.70.241.
2024-09-22 19:41:08.614 | 6AZ4.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:08.614 | 6AZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:08.855 | SC Data with Depth | Network connection to server complete.
2024-09-22 19:41:08.855 | SC Data with Depth | Starting socket receive thread.
2024-09-22 19:41:08.855 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2024-09-22 19:41:08.857 | 6AZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:08.857 | 6AZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:09.115 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-22 19:41:09.115 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-22 19:41:09.115 | 6AZ4.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:09.115 | 6AZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:09.747 | HD Request # 16 | Requesting historical Daily data for J6Z24 starting at 2024-09-17. SC External HD service.
2024-09-22 19:41:09.747 | SC Data with Depth | Setting DTC encoding to Binary VLS
2024-09-22 19:41:09.747 | SC Data with Depth | Sending logon request message.
2024-09-22 19:41:09.817 | GCZ4.COMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:09.822 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-22 19:41:09.822 | Triggering next historical data download in queue.
2024-09-22 19:41:09.823 | GCZ4.COMEX [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol GCZ4.COMEX starting at last date in file.
2024-09-22 19:41:09.823 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-22 19:41:09.823 | Triggering next historical data download in queue.
2024-09-22 19:41:09.843 | GCZ4.COMEX [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:09.854 | GCZ4.COMEX [CBV] #14 | Reloading chart.
2024-09-22 19:41:09.974 | GCZ4.COMEX [CBV] #14 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:09.986 | GCZ4.COMEX [CBV] #3 | Reloading chart.
2024-09-22 19:41:10.094 | GCZ4.COMEX [CBV] #3 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:10.106 | GCZ4.COMEX [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:10.205 | GCZ4.COMEX [CBV] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:10.217 | GCZ4.COMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:10.217 | GCZ4.COMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.217 | GCZ4.COMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.460 | GCZ4.COMEX [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 22,
2024-09-22 19:41:10.472 | GCZ4.COMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:10.472 | GCZ4.COMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.472 | GCZ4.COMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.719 | GCZ4.COMEX [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 22,
2024-09-22 19:41:10.764 | GCZ4.COMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:10.764 | GCZ4.COMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:10.764 | GCZ4.COMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:11.008 | GCZ4.COMEX [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 22,
2024-09-22 19:41:11.022 | GCZ4.COMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:11.117 | GCZ4.COMEX [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:11.157 | GCZ4.COMEX 5 Min #12 | Reloading chart.
2024-09-22 19:41:11.176 | GCZ4.COMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:41:11.190 | GCZ4.COMEX [CBV] 3 Min #17 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:11.224 | GCZ4.COMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:11.283 | GCZ4.COMEX [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:11.319 | GCZ4.COMEX 5 Min #11 | Reloading chart.
2024-09-22 19:41:11.363 | GCZ4.COMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:11.478 | GCZ4.COMEX [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 21, 22,
2024-09-22 19:41:11.514 | GCZ4.COMEX Rev. 16t-20 #13 | Reloading chart.
2024-09-22 19:41:11.718 | ESU4.CME #9 | Reloading chart.
2024-09-22 19:41:11.719 | ESU4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:11.719 | ESU4.CME #9 | Chart data loading complete.
2024-09-22 19:41:11.730 | MGCZ4.COMEX 15 Min #1 | Reloading chart.
2024-09-22 19:41:11.942 | MESU4.CME #16 | Reloading chart.
2024-09-22 19:41:11.942 | MESU4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:11.943 | MESU4.CME #16 | Chart data loading complete.
2024-09-22 19:41:11.957 | 6AZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:11.962 | SC Data with Depth | Received logon response.
2024-09-22 19:41:11.962 | SC Data with Depth | Server Name: SC Realtime Server.
2024-09-22 19:41:11.962 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2024-09-22 19:41:11.962 | SC Data with Depth | Successfully connected.
2024-09-22 19:41:11.962 | SC Data with Depth | Trading is not supported.
2024-09-22 19:41:11.962 | SC Data with Depth | MarketDepthIsSupported: 1
2024-09-22 19:41:11.962 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2024-09-22 19:41:11.970 | GCZ4.COMEX 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:58
2024-09-22 19:41:11.981 | GCZ4.COMEX 5 Min #11 | Chart data loading complete.
2024-09-22 19:41:11.997 | GCZ4.COMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-21 16:15:00
2024-09-22 19:41:12.006 | GCZ4.COMEX 5 Min #12 | Chart data loading complete.
2024-09-22 19:41:12.007 | MGCZ4.COMEX 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-21 18:00:00
2024-09-22 19:41:12.008 | MGCZ4.COMEX 15 Min #1 | Chart data loading complete.
2024-09-22 19:41:12.103 | 6AZ4.CME [CBV] 2 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:12.104 | 6AZ4.CME [CBV] 2 Min #17 | Reloading chart.
2024-09-22 19:41:12.146 | 6AZ4.CME [CBV] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:12.147 | 6AZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:12.392 | GCZ4.COMEX Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-21 16:15:00
2024-09-22 19:41:12.405 | GCZ4.COMEX Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 19:41:12.406 | 6AZ4.CME [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:12.466 | 6AZ4.CME [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:12.467 | 6AZ4.CME [CBV] 2 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:12.475 | 6AZ4.CME [CBV] 2 Min #17 | Chart data loading complete.
2024-09-22 19:41:12.551 | 6AZ4.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:12.551 | 6AZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:13.132 | HD Request # 16 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-18.
2024-09-22 19:41:13.132 | HD Request # 16 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-22 19:41:13.138 | HD Request # 16 | Bytes received: 274
2024-09-22 19:41:13.138 | HD Request # 16 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6JZ4.CME
2024-09-22 19:41:13.138 | HD Request # 16 | Completion time: 5s.
2024-09-22 19:41:13.138 | HD Request # 16 | Daily data download complete for 6JZ4.CME. Unique request ID: 18
2024-09-22 19:41:13.138 | Removing historical data download ID 18.
2024-09-22 19:41:13.138 | Triggering next historical data download in queue.
2024-09-22 19:41:13.246 | 6AZ4.CME [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:13.246 | SC Data with Depth | Received security definition for symbol USDX
2024-09-22 19:41:13.246 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2024-09-22 19:41:13.247 | HD Request # 17 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 19:41:13.248 | 6AZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:13.263 | 6AZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:13.264 | 6AZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:13.589 | CLX4.NYMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:13.601 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-22 19:41:13.601 | Triggering next historical data download in queue.
2024-09-22 19:41:13.602 | CLX4.NYMEX [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol CLX4.NYMEX starting at last date in file.
2024-09-22 19:41:13.602 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-22 19:41:13.602 | Triggering next historical data download in queue.
2024-09-22 19:41:13.623 | CLX4.NYMEX [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:13.636 | CLX4.NYMEX [CBV] #14 | Reloading chart.
2024-09-22 19:41:13.769 | CLX4.NYMEX [CBV] #14 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:13.781 | CLX4.NYMEX [CBV] #3 | Reloading chart.
2024-09-22 19:41:13.881 | CLX4.NYMEX [CBV] #3 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:13.894 | CLX4.NYMEX [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:13.987 | CLX4.NYMEX [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:14.000 | CLX4.NYMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:14.000 | CLX4.NYMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.000 | CLX4.NYMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.263 | CLX4.NYMEX [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 24,
2024-09-22 19:41:14.308 | CLX4.NYMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:14.308 | CLX4.NYMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.308 | CLX4.NYMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.518 | CLX4.NYMEX [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 24,
2024-09-22 19:41:14.532 | CLX4.NYMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:14.532 | CLX4.NYMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.532 | CLX4.NYMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:14.749 | CLX4.NYMEX [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 24,
2024-09-22 19:41:14.765 | CLX4.NYMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:14.861 | CLX4.NYMEX [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:14.905 | CLX4.NYMEX 5 Min #12 | Reloading chart.
2024-09-22 19:41:14.941 | CLX4.NYMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:14.993 | CLX4.NYMEX [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:15.030 | CLX4.NYMEX 5 Min #11 | Reloading chart.
2024-09-22 19:41:15.070 | CLX4.NYMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:15.175 | CLX4.NYMEX [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:15.191 | CLX4.NYMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:41:15.203 | CLX4.NYMEX [CBV] 3 Min #17 | Waiting for historical downloads to complete with the IDs: 23, 24,
2024-09-22 19:41:15.238 | CLX4.NYMEX Rev. 16t-20 #13 | Reloading chart.
2024-09-22 19:41:15.445 | ESZ4.CME #9 | Reloading chart.
2024-09-22 19:41:15.445 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:15.446 | ESZ4.CME #9 | Chart data loading complete.
2024-09-22 19:41:15.459 | MCLU4.NYMEX 15 Min #1 | Reloading chart.
2024-09-22 19:41:15.668 | MESZ4.CME #16 | Reloading chart.
2024-09-22 19:41:15.668 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-22 19:41:15.669 | MESZ4.CME #16 | Chart data loading complete.
2024-09-22 19:41:15.683 | 6AZ4.CME [CBV] 240 Min #15 | Chart data loading complete.
2024-09-22 19:41:15.688 | HD Request # 17 | Requesting historical Daily data for GCZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 19:41:15.697 | CLX4.NYMEX 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 19:41:15.701 | CLX4.NYMEX 5 Min #12 | Chart data loading complete.
2024-09-22 19:41:15.701 | CLX4.NYMEX 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 19:41:15.709 | CLX4.NYMEX 5 Min #11 | Chart data loading complete.
2024-09-22 19:41:15.713 | CLX4.NYMEX Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-09-06 16:59:59
2024-09-22 19:41:15.724 | CLX4.NYMEX Rev. 16t-20 #13 | Chart data loading complete.
2024-09-22 19:41:15.750 | MCLU4.NYMEX 15 Min #1 | StartDateTimeForLoadingOrderFills: 2024-07-21 18:00:00
2024-09-22 19:41:15.751 | MCLU4.NYMEX 15 Min #1 | Chart data loading complete.
2024-09-22 19:41:15.872 | 6JZ4.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:15.873 | 6JZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:16.457 | 6AZ4.CME [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:16.495 | HD Request # 18 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-22 19:41:16.495 | HD Request # 18 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.586001
2024-09-22 19:41:16.495 | HD Request # 18 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:16.495 | Socket (10) | Creating socket.
2024-09-22 19:41:16.495 | Socket (10) | New receive buffer size: 0
2024-09-22 19:41:16.495 | Socket (10) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:16.495 | 6AZ4.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:16.495 | 6AZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:16.605 | 6JZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:16.605 | HD Request # 17 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-18.
2024-09-22 19:41:16.605 | HD Request # 17 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-22 19:41:16.611 | HD Request # 17 | Bytes received: 232
2024-09-22 19:41:16.611 | HD Request # 17 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-22 19:41:16.611 | HD Request # 17 | Completion time: 3s.
2024-09-22 19:41:16.611 | HD Request # 17 | Daily data download complete for GCZ4.COMEX. Unique request ID: 22
2024-09-22 19:41:16.611 | Removing historical data download ID 22.
2024-09-22 19:41:16.611 | Triggering next historical data download in queue.
2024-09-22 19:41:16.611 | Mapping CLX4.NYMEX to CLX24. Service code: nymex
2024-09-22 19:41:16.612 | HD Request # 19 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 19:41:16.616 | 6AZ4.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:16.616 | 6AZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:17.048 | HD Request # 18 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:17.048 | HD Request # 18 | Sending historical data logon request message.
2024-09-22 19:41:17.178 | 6AZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:17.178 | 6AZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:17.236 | 6AZ4.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:17.236 | 6AZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:17.485 | 6AZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:17.594 | 6AZ4.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:17.610 | 6AZ4.CME [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:17.628 | 6AZ4.CME [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:17.824 | HD Request # 18 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: M6AZ24
2024-09-22 19:41:18.008 | HD Request # 19 | Requesting historical Daily data for CLX24 starting at 2024-09-17. SC External HD service.
2024-09-22 19:41:18.024 | 6JZ4.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:18.025 | 6JZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:18.097 | HD Request # 18 | Decompressing data.
2024-09-22 19:41:18.368 | HD Request # 18 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-20 16:59:58.586000
2024-09-22 19:41:18.369 | Socket (10) | CloseSocket call.
2024-09-22 19:41:18.369 | Socket (10) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:18.586 | Historical data download thread signaled to stop.
2024-09-22 19:41:18.586 | HD Request # 18 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.146000.
2024-09-22 19:41:18.586 | HD Request # 18 | Received 235 Intraday data records from 2024-09-20 16:59:58.586000 to 2024-09-22 19:40:37.737000 (2.1 days. Delay: 40.8 seconds) and wrote 233 records for M6AZ4.CME
2024-09-22 19:41:18.586 | HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:40:37.737000
2024-09-22 19:41:18.586 | HD Request # 18 | Completion time: 2s.
2024-09-22 19:41:18.586 | HD Request # 18 | Intraday data download complete for M6AZ4.CME. Unique request ID: 16
2024-09-22 19:41:18.586 | Removing historical data download ID 16.
2024-09-22 19:41:18.586 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-22 19:41:18.586 | Intraday chart data file opened for M6AZ4.CME
2024-09-22 19:41:18.586 | HD Request # 18 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:18.586 | Triggering next historical data download in queue.
2024-09-22 19:41:18.587 | HD Request # 20 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-22 19:41:18.587 | HD Request # 20 | Download start date-time: 2024-09-20 16:59:57.000000. File last date-time: 2024-09-20 16:59:57.761004
2024-09-22 19:41:18.587 | HD Request # 20 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:41:18.587 | Socket (12) | Creating socket.
2024-09-22 19:41:18.587 | Socket (12) | New receive buffer size: 0
2024-09-22 19:41:18.587 | Socket (12) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:18.594 | 6AZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:18.640 | Socket (10) | Socket gracefully closed by remote side.
2024-09-22 19:41:18.641 | Socket (10) | Closed.
2024-09-22 19:41:18.910 | 6JZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:18.917 | 6AZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:19.140 | HD Request # 20 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:19.140 | HD Request # 20 | Sending historical data logon request message.
2024-09-22 19:41:19.304 | 6AZ4.CME [CBV] #14 | Chart data loading complete.
2024-09-22 19:41:19.304 | HD Request # 19 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-18.
2024-09-22 19:41:19.304 | HD Request # 19 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-22 19:41:19.310 | HD Request # 19 | Bytes received: 217
2024-09-22 19:41:19.310 | HD Request # 19 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-22 19:41:19.310 | HD Request # 19 | Completion time: 3s.
2024-09-22 19:41:19.310 | HD Request # 19 | Daily data download complete for CLX4.NYMEX. Unique request ID: 24
2024-09-22 19:41:19.310 | Removing historical data download ID 24.
2024-09-22 19:41:19.310 | No download requests in the queue to start downloads for.
2024-09-22 19:41:19.334 | 6AZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:19.334 | 6AZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:19.334 | 6AZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:19.411 | HD Request # 20 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:57. Record interval: 0. Symbol: 6JZ24
2024-09-22 19:41:19.685 | HD Request # 20 | Decompressing data.
2024-09-22 19:41:20.068 | GCZ4.COMEX [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:20.068 | GCZ4.COMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:20.235 | HD Request # 20 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-20 16:59:57.760000
2024-09-22 19:41:20.236 | Socket (12) | CloseSocket call.
2024-09-22 19:41:20.236 | Socket (12) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:20.507 | Socket (12) | Socket gracefully closed by remote side.
2024-09-22 19:41:20.507 | Socket (12) | Closed.
2024-09-22 19:41:20.513 | 6AZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:20.513 | Historical data download thread signaled to stop.
2024-09-22 19:41:20.513 | HD Request # 20 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.115000.
2024-09-22 19:41:20.513 | HD Request # 20 | Received 2854 Intraday data records from 2024-09-20 16:59:57.760000 to 2024-09-22 19:40:50.172001 (2.1 days. Delay: 30.3 seconds) and wrote 2848 records for 6JZ4.CME
2024-09-22 19:41:20.514 | HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:40:50.172001
2024-09-22 19:41:20.514 | HD Request # 20 | Completion time: 2s.
2024-09-22 19:41:20.514 | HD Request # 20 | Intraday data download complete for 6JZ4.CME. Unique request ID: 17
2024-09-22 19:41:20.514 | Removing historical data download ID 17.
2024-09-22 19:41:20.514 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-22 19:41:20.514 | Intraday chart data file opened for 6JZ4.CME
2024-09-22 19:41:20.514 | HD Request # 20 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:20.514 | Triggering next historical data download in queue.
2024-09-22 19:41:20.514 | HD Request # 21 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-22 19:41:20.514 | HD Request # 21 | Download start date-time: 2024-09-20 16:54:47.000000. File last date-time: 2024-09-20 16:54:47.126000
2024-09-22 19:41:20.514 | HD Request # 21 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:20.514 | Socket (5) | Creating socket.
2024-09-22 19:41:20.514 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:20.514 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:20.515 | GCZ4.COMEX [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:20.515 | GCZ4.COMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:20.959 | GCZ4.COMEX [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:20.959 | Requesting market depth updates for: 6JZ4.CME if supported. NumLevels=50
2024-09-22 19:41:20.959 | Denali Data Feed | Starting real-time market data updates for: CLX4.NYMEX (CLX24). ID: 13 Service code: nymex
2024-09-22 19:41:20.959 | Denali Data Feed | Requesting security definition data for: CLX4.NYMEX (CLX24). ID: 13
2024-09-22 19:41:20.959 | Requesting market depth updates for: CLX4.NYMEX if supported. NumLevels=50
2024-09-22 19:41:20.959 | Mapping ESU4.CME to ESU24. Service code: cme
2024-09-22 19:41:20.959 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 14 Service code: cme
2024-09-22 19:41:20.959 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 14
2024-09-22 19:41:20.959 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2024-09-22 19:41:20.959 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 12 Service code: comex
2024-09-22 19:41:20.959 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 12
2024-09-22 19:41:20.959 | Requesting market depth updates for: GCZ4.COMEX if supported. NumLevels=50
2024-09-22 19:41:20.959 | Requesting market depth updates for: MESU4.CME if supported. NumLevels=50
2024-09-22 19:41:20.959 | GCZ4.COMEX [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:20.960 | GCZ4.COMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:21.068 | HD Request # 21 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:21.068 | HD Request # 21 | Sending historical data logon request message.
2024-09-22 19:41:21.340 | HD Request # 21 | Requesting Intraday data. Start date-time: 2024-09-20 16:54:47. Record interval: 0. Symbol: MJYZ24
2024-09-22 19:41:21.403 | GCZ4.COMEX [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:21.419 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-22 19:41:21.419 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-22 19:41:21.419 | Triggering next historical data download in queue.
2024-09-22 19:41:21.419 | Mapping MGCZ4.COMEX to MGCZ24. Service code: comex
2024-09-22 19:41:21.419 | Denali Data Feed | Starting real-time market data updates for: MGCZ4.COMEX (MGCZ24). ID: 15 Service code: comex
2024-09-22 19:41:21.419 | Denali Data Feed | Requesting security definition data for: MGCZ4.COMEX (MGCZ24). ID: 15
2024-09-22 19:41:21.419 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-22 19:41:21.419 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-22 19:41:21.429 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-22 19:41:21.429 | 6JZ4.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:21.429 | 6JZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:21.611 | HD Request # 21 | Decompressing data.
2024-09-22 19:41:21.691 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-22 19:41:21.691 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-22 19:41:21.691 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-22 19:41:21.691 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-22 19:41:21.692 | GCZ4.COMEX [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:21.694 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-22 19:41:21.694 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-22 19:41:21.694 | Triggering next historical data download in queue.
2024-09-22 19:41:21.695 | 6AZ4.CME [CBV] 2 Min #17 | Reloading chart.
2024-09-22 19:41:21.736 | 6AZ4.CME [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:21.882 | HD Request # 21 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-20 16:54:47.126000
2024-09-22 19:41:21.882 | Socket (5) | CloseSocket call.
2024-09-22 19:41:21.882 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:22.090 | 6AZ4.CME [CBV] 2 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:22.103 | 6AZ4.CME [CBV] 2 Min #17 | Chart data loading complete.
2024-09-22 19:41:22.103 | 6AZ4.CME [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:22.153 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:22.153 | Socket (5) | Closed.
2024-09-22 19:41:22.168 | 6AZ4.CME [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:22.168 | Historical data download thread signaled to stop.
2024-09-22 19:41:22.168 | HD Request # 21 | Timestamp of first Intraday data file record written: 2024-09-22 18:07:56.023000.
2024-09-22 19:41:22.169 | HD Request # 21 | Received 19 Intraday data records from 2024-09-20 16:54:47.126000 to 2024-09-22 19:34:49.672000 (2.1 days. Delay: 6.5 minutes) and wrote 18 records for MJYZ4.CME
2024-09-22 19:41:22.169 | HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:34:49.672000
2024-09-22 19:41:22.169 | HD Request # 21 | Completion time: 2s.
2024-09-22 19:41:22.169 | HD Request # 21 | Intraday data download complete for MJYZ4.CME. Unique request ID: 19
2024-09-22 19:41:22.169 | Removing historical data download ID 19.
2024-09-22 19:41:22.169 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-22 19:41:22.169 | Intraday chart data file opened for MJYZ4.CME
2024-09-22 19:41:22.169 | HD Request # 21 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:22.169 | Triggering next historical data download in queue.
2024-09-22 19:41:22.235 | HD Request # 22 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2024-09-22 19:41:22.235 | HD Request # 22 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.000000
2024-09-22 19:41:22.235 | HD Request # 22 | Using server: ds12.sierracharts.com port 10150
2024-09-22 19:41:22.235 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-22 19:41:22.235 | Socket (5) | Creating socket.
2024-09-22 19:41:22.235 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:22.235 | Socket (5) | Connecting to IP: 69.39.70.241.
2024-09-22 19:41:22.236 | 6JZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:22.236 | 6JZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:22.510 | 6JZ4.CME [CBV] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:22.510 | 6JZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-22 19:41:22.542 | 6JZ4.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:22.543 | 6JZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:22.781 | HD Request # 22 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:22.781 | HD Request # 22 | Sending historical data logon request message.
2024-09-22 19:41:23.314 | 6AZ4.CME [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:23.315 | 6JZ4.CME [CBV] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:23.334 | 6JZ4.CME [CBV] 1 Min #17 | Chart data loading complete.
2024-09-22 19:41:23.335 | 6JZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:23.353 | 6AZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:23.353 | 6AZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:23.353 | 6AZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:23.528 | HD Request # 22 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: USDX
2024-09-22 19:41:23.797 | HD Request # 22 | Decompressing data.
2024-09-22 19:41:24.161 | 6AZ4.CME [CBV] 240 Min #15 | Chart data loading complete.
2024-09-22 19:41:24.173 | 6JZ4.CME [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:24.173 | 6JZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:24.442 | 6AZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:24.443 | 6AZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:24.625 | HD Request # 22 | Receiving Intraday data for USDX starting at 2024-09-20 16:59:59.000000
2024-09-22 19:41:24.803 | CLX4.NYMEX [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:24.803 | CLX4.NYMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:24.893 | Socket (5) | CloseSocket call.
2024-09-22 19:41:24.893 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:25.162 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:25.162 | Socket (5) | Closed.
2024-09-22 19:41:27.105 | Historical data download thread signaled to stop.
2024-09-22 19:41:27.106 | HD Request # 22 | Timestamp of first Intraday data file record written: 2024-09-21 20:14:17.000000.
2024-09-22 19:41:27.106 | HD Request # 22 | Received 4152 Intraday data records from 2024-09-20 16:59:59.000000 to 2024-09-22 19:41:24.000000 (2.1 days. Delay: 3.1 seconds) and wrote 4151 records for USDX
2024-09-22 19:41:27.106 | HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:41:24.000000
2024-09-22 19:41:27.106 | Added 4 Time and Sales records to Intraday data file for USDX after download.
2024-09-22 19:41:27.106 | HD Request # 22 | Completion time: 5s.
2024-09-22 19:41:27.106 | HD Request # 22 | Intraday data download complete for USDX. Unique request ID: 20
2024-09-22 19:41:27.106 | Removing historical data download ID 20.
2024-09-22 19:41:27.106 | Real-time Intraday chart data file updates started for USDX
2024-09-22 19:41:27.106 | Intraday chart data file opened for USDX
2024-09-22 19:41:27.106 | HD Request # 22 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:27.106 | Triggering next historical data download in queue.
2024-09-22 19:41:27.106 | HD Request # 23 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-22 19:41:27.107 | HD Request # 23 | Download start date-time: 2024-09-20 16:59:58.000000. File last date-time: 2024-09-20 16:59:58.361000
2024-09-22 19:41:27.107 | HD Request # 23 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:27.107 | Socket (5) | Creating socket.
2024-09-22 19:41:27.107 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:27.107 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:27.244 | CLX4.NYMEX [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:27.245 | CLX4.NYMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:27.660 | HD Request # 23 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:27.660 | HD Request # 23 | Sending historical data logon request message.
2024-09-22 19:41:27.933 | HD Request # 23 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:58. Record interval: 0. Symbol: GCZ24
2024-09-22 19:41:28.205 | HD Request # 23 | Decompressing data.
2024-09-22 19:41:28.755 | HD Request # 23 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-20 16:59:58.171000
2024-09-22 19:41:28.755 | Socket (5) | CloseSocket call.
2024-09-22 19:41:28.755 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:29.028 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:29.028 | Socket (5) | Closed.
2024-09-22 19:41:29.250 | 6JZ4.CME [CBV] 60 Min #15 | Chart data loading complete.
2024-09-22 19:41:29.251 | CLX4.NYMEX [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:29.253 | 6AZ4.CME [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:29.253 | Historical data download thread signaled to stop.
2024-09-22 19:41:29.253 | HD Request # 23 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.000000.
2024-09-22 19:41:29.253 | HD Request # 23 | Received 2368 Intraday data records from 2024-09-20 16:59:58.171000 to 2024-09-22 19:40:50.183001 (2.1 days. Delay: 39.1 seconds) and wrote 2364 records for GCZ4.COMEX
2024-09-22 19:41:29.254 | HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:40:50.183001
2024-09-22 19:41:29.254 | HD Request # 23 | Completion time: 2s.
2024-09-22 19:41:29.254 | HD Request # 23 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 21
2024-09-22 19:41:29.254 | Removing historical data download ID 21.
2024-09-22 19:41:29.254 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-22 19:41:29.254 | Intraday chart data file opened for GCZ4.COMEX
2024-09-22 19:41:29.254 | HD Request # 23 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:29.254 | Triggering next historical data download in queue.
2024-09-22 19:41:29.254 | HD Request # 24 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-22 19:41:29.254 | HD Request # 24 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.016000
2024-09-22 19:41:29.254 | HD Request # 24 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:41:29.254 | Socket (5) | Creating socket.
2024-09-22 19:41:29.254 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:29.254 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:29.254 | CLX4.NYMEX [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:29.255 | CLX4.NYMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:29.822 | HD Request # 24 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:29.822 | HD Request # 24 | Sending historical data logon request message.
2024-09-22 19:41:30.104 | HD Request # 24 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: CLX24
2024-09-22 19:41:30.394 | HD Request # 24 | Decompressing data.
2024-09-22 19:41:30.707 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 3296
2024-09-22 19:41:30.959 | HD Request # 24 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-20 16:59:59.016000
2024-09-22 19:41:30.959 | Socket (5) | CloseSocket call.
2024-09-22 19:41:30.959 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:31.221 | CLX4.NYMEX [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:31.221 | 6JZ4.CME [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:31.245 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:31.245 | Socket (5) | Closed.
2024-09-22 19:41:31.267 | 6JZ4.CME [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:31.373 | 6JZ4.CME [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:31.373 | Historical data download thread signaled to stop.
2024-09-22 19:41:31.373 | HD Request # 24 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.000000.
2024-09-22 19:41:31.373 | HD Request # 24 | Received 2457 Intraday data records from 2024-09-20 16:59:59.016000 to 2024-09-22 19:41:21.054000 (2.1 days. Delay: 10.3 seconds) and wrote 2456 records for CLX4.NYMEX
2024-09-22 19:41:31.374 | HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:41:21.054000
2024-09-22 19:41:31.374 | Added 1 Time and Sales records to Intraday data file for CLX4.NYMEX after download.
2024-09-22 19:41:31.374 | HD Request # 24 | Completion time: 2s.
2024-09-22 19:41:31.374 | HD Request # 24 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 23
2024-09-22 19:41:31.374 | Removing historical data download ID 23.
2024-09-22 19:41:31.374 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-22 19:41:31.374 | Intraday chart data file opened for CLX4.NYMEX
2024-09-22 19:41:31.374 | HD Request # 24 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:31.374 | Triggering next historical data download in queue.
2024-09-22 19:41:31.420 | HD Request # 25 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-22 19:41:31.420 | HD Request # 25 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-22 19:41:31.420 | HD Request # 25 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:31.420 | Socket (5) | Creating socket.
2024-09-22 19:41:31.420 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:31.420 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:31.420 | CLX4.NYMEX [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:31.421 | CLX4.NYMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:31.992 | HD Request # 25 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:31.992 | HD Request # 25 | Sending historical data logon request message.
2024-09-22 19:41:32.217 | CLX4.NYMEX [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:32.218 | CLX4.NYMEX [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:32.218 | CLX4.NYMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:32.277 | HD Request # 25 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-22 19:41:32.557 | HD Request # 25 | Decompressing data.
2024-09-22 19:41:32.675 | CLX4.NYMEX [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:32.675 | CLX4.NYMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:32.836 | HD Request # 25 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-22 19:41:32.836 | Socket (5) | CloseSocket call.
2024-09-22 19:41:32.836 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:33.117 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:33.117 | Socket (5) | Closed.
2024-09-22 19:41:33.682 | Historical data download thread signaled to stop.
2024-09-22 19:41:33.682 | HD Request # 25 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 2.4 days) and wrote 0 records for ESU4.CME
2024-09-22 19:41:33.682 | HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-22 19:41:33.682 | HD Request # 25 | Completion time: 2s.
2024-09-22 19:41:33.682 | HD Request # 25 | Intraday data download complete for ESU4.CME. Unique request ID: 25
2024-09-22 19:41:33.682 | Removing historical data download ID 25.
2024-09-22 19:41:33.682 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-22 19:41:33.682 | Intraday chart data file opened for ESU4.CME
2024-09-22 19:41:33.682 | HD Request # 25 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:33.682 | Triggering next historical data download in queue.
2024-09-22 19:41:33.682 | HD Request # 26 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-22 19:41:33.682 | HD Request # 26 | Download start date-time: 2024-09-20 16:59:59.000000. File last date-time: 2024-09-20 16:59:59.699000
2024-09-22 19:41:33.682 | HD Request # 26 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:41:33.682 | Socket (5) | Creating socket.
2024-09-22 19:41:33.682 | Socket (5) | New receive buffer size: 0
2024-09-22 19:41:33.682 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:33.684 | CLX4.NYMEX [CBV] 3 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:33.684 | CLX4.NYMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:41:33.814 | Mapping MCLU4.NYMEX to MCLU24. Service code: nymex
2024-09-22 19:41:33.815 | Denali Data Feed | Starting real-time market data updates for: MCLU4.NYMEX (MCLU24). ID: 16 Service code: nymex
2024-09-22 19:41:33.815 | Denali Data Feed | Requesting security definition data for: MCLU4.NYMEX (MCLU24). ID: 16
2024-09-22 19:41:33.815 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-22 19:41:33.815 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-22 19:41:33.815 | Triggering next historical data download in queue.
2024-09-22 19:41:33.816 | 6JZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:33.816 | 6JZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:33.816 | 6JZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:34.235 | HD Request # 26 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:34.235 | HD Request # 26 | Sending historical data logon request message.
2024-09-22 19:41:34.516 | HD Request # 26 | Requesting Intraday data. Start date-time: 2024-09-20 16:59:59. Record interval: 0. Symbol: MGCZ24
2024-09-22 19:41:34.716 | CLX4.NYMEX [CBV] 3 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:34.724 | CLX4.NYMEX [CBV] 3 Min #17 | Chart data loading complete.
2024-09-22 19:41:34.724 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-22 19:41:34.724 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-22 19:41:34.768 | 6JZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:34.769 | 6JZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:34.788 | HD Request # 26 | Decompressing data.
2024-09-22 19:41:35.064 | 6JZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:35.065 | 6AZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:35.065 | HD Request # 26 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-20 16:59:59.699000
2024-09-22 19:41:35.066 | Socket (5) | CloseSocket call.
2024-09-22 19:41:35.066 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:35.239 | Historical data download thread signaled to stop.
2024-09-22 19:41:35.239 | HD Request # 26 | Timestamp of first Intraday data file record written: 2024-09-22 18:00:00.000000.
2024-09-22 19:41:35.240 | HD Request # 26 | Received 1868 Intraday data records from 2024-09-20 16:59:59.699000 to 2024-09-22 19:41:29.189000 (2.1 days. Delay: 6.1 seconds) and wrote 1867 records for MGCZ4.COMEX
2024-09-22 19:41:35.240 | HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2024-09-22 23:41:29.189000
2024-09-22 19:41:35.240 | HD Request # 26 | Completion time: 2s.
2024-09-22 19:41:35.240 | HD Request # 26 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 26
2024-09-22 19:41:35.240 | Removing historical data download ID 26.
2024-09-22 19:41:35.240 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-22 19:41:35.240 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-22 19:41:35.240 | HD Request # 26 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:35.240 | Triggering next historical data download in queue.
2024-09-22 19:41:35.240 | HD Request # 27 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-22 19:41:35.240 | HD Request # 27 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-22 19:41:35.241 | HD Request # 27 | Using server: ds32.sierracharts.com port 10149
2024-09-22 19:41:35.241 | Socket (7) | Creating socket.
2024-09-22 19:41:35.241 | Socket (7) | New receive buffer size: 0
2024-09-22 19:41:35.241 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-22 19:41:35.246 | 6AZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:35.247 | 6AZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:35.247 | 6AZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:35.338 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:41:35.338 | Socket (5) | Closed.
2024-09-22 19:41:35.765 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6JZ4.CME.scid. Thread ID: 3296
2024-09-22 19:41:35.803 | HD Request # 27 | Setting DTC encoding to Binary VLS
2024-09-22 19:41:35.803 | HD Request # 27 | Sending historical data logon request message.
2024-09-22 19:41:36.079 | HD Request # 27 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-22 19:41:36.290 | 6AZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:36.319 | 6AZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:36.355 | HD Request # 27 | Decompressing data.
2024-09-22 19:41:36.470 | 6AZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:36.634 | HD Request # 27 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-22 19:41:36.634 | Socket (7) | CloseSocket call.
2024-09-22 19:41:36.634 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-22 19:41:36.879 | 6AZ4.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:36.900 | 6AZ4.CME [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:36.900 | Historical data download thread signaled to stop.
2024-09-22 19:41:36.900 | HD Request # 27 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 2.4 days) and wrote 0 records for MESU4.CME
2024-09-22 19:41:36.900 | HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-22 19:41:36.900 | HD Request # 27 | Completion time: 1s.
2024-09-22 19:41:36.900 | HD Request # 27 | Intraday data download complete for MESU4.CME. Unique request ID: 27
2024-09-22 19:41:36.900 | Removing historical data download ID 27.
2024-09-22 19:41:36.900 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-22 19:41:36.900 | Intraday chart data file opened for MESU4.CME
2024-09-22 19:41:36.900 | HD Request # 27 | Enabling Intraday chart updating for symbol.
2024-09-22 19:41:36.900 | Triggering next historical data download in queue.
2024-09-22 19:41:36.909 | Socket (7) | Socket gracefully closed by remote side.
2024-09-22 19:41:36.909 | Socket (7) | Closed.
2024-09-22 19:41:36.921 | Delaying start of download for MCLU4.NYMEX.
2024-09-22 19:41:36.938 | 6AZ4.CME [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:37.399 | 6JZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:37.399 | 6JZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:37.399 | 6JZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:38.321 | CLX4.NYMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:38.347 | CLX4.NYMEX [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:38.376 | 6JZ4.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:38.377 | 6JZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:38.514 | 6JZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:38.515 | 6JZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:38.516 | 6JZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:38.582 | 6JZ4.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:38.582 | 6JZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:41:38.995 | 6AZ4.CME [CBV] #14 | Chart data loading complete.
2024-09-22 19:41:39.031 | GCZ4.COMEX [CBV] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:39.031 | GCZ4.COMEX [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:41:39.260 | GCZ4.COMEX [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:39.261 | GCZ4.COMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:39.304 | GCZ4.COMEX [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:39.304 | GCZ4.COMEX [CBV] #14 | Reloading chart.
2024-09-22 19:41:39.579 | GCZ4.COMEX [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:39.580 | GCZ4.COMEX [CBV] #3 | Reloading chart.
2024-09-22 19:41:39.897 | GCZ4.COMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:39.897 | GCZ4.COMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:39.897 | GCZ4.COMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:40.811 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCZ4.COMEX.scid. Thread ID: 3296
2024-09-22 19:41:40.811 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\CLX4.NYMEX.scid. Thread ID: 3296
2024-09-22 19:41:41.022 | 6JZ4.CME [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:41.023 | GCZ4.COMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:41.023 | GCZ4.COMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:41.023 | GCZ4.COMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:41.985 | GCZ4.COMEX [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:41.993 | GCZ4.COMEX [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:41.994 | GCZ4.COMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:41.994 | GCZ4.COMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:41.994 | GCZ4.COMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:42.923 | GCZ4.COMEX [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:42.924 | 6JZ4.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:42.951 | 6JZ4.CME [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:42.977 | GCZ4.COMEX [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:42.977 | GCZ4.COMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:41:43.215 | GCZ4.COMEX [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:43.229 | GCZ4.COMEX [CBV] 3 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:43.230 | GCZ4.COMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:41:43.255 | GCZ4.COMEX [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:43.256 | GCZ4.COMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:41:43.380 | GCZ4.COMEX [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:43.381 | GCZ4.COMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:43.663 | 6JZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:41:44.167 | GCZ4.COMEX [CBV] 3 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:44.181 | GCZ4.COMEX [CBV] 3 Min #17 | Chart data loading complete.
2024-09-22 19:41:44.356 | 6JZ4.CME [CBV] #14 | Chart data loading complete.
2024-09-22 19:41:44.384 | 6JZ4.CME [CBV] #3 | Reloading chart.
2024-09-22 19:41:44.945 | 6JZ4.CME [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:44.946 | 6JZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-22 19:41:45.013 | 6JZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:45.013 | 6JZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:45.013 | 6JZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:46.180 | 6JZ4.CME [CBV] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:41:46.206 | 6JZ4.CME [CBV] 1 Min #17 | Chart data loading complete.
2024-09-22 19:41:46.208 | GCZ4.COMEX [CBV] 240 Min #15 | Chart data loading complete.
2024-09-22 19:41:46.248 | 6JZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:46.716 | 6JZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:41:46.716 | CLX4.NYMEX [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:46.718 | CLX4.NYMEX [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:41:48.155 | GCZ4.COMEX [CBV] #14 | Chart data loading complete.
2024-09-22 19:41:48.196 | CLX4.NYMEX [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:48.197 | CLX4.NYMEX [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:48.197 | CLX4.NYMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:41:48.528 | CLX4.NYMEX [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:48.528 | CLX4.NYMEX [CBV] #14 | Reloading chart.
2024-09-22 19:41:49.933 | GCZ4.COMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:41:49.983 | GCZ4.COMEX [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:41:50.034 | CLX4.NYMEX [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 19:41:50.034 | CLX4.NYMEX [CBV] #3 | Reloading chart.
2024-09-22 19:41:50.886 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AZ4.CME.scid. Thread ID: 3296
2024-09-22 19:41:50.887 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-22 19:41:51.449 | 6JZ4.CME [CBV] 60 Min #15 | Chart data loading complete.
2024-09-22 19:41:51.450 | CLX4.NYMEX [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:51.557 | CLX4.NYMEX [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:51.563 | CLX4.NYMEX [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:41:51.693 | CLX4.NYMEX [CBV] Monthly #4 | Reloading chart.
2024-09-22 19:41:51.693 | CLX4.NYMEX [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:51.693 | CLX4.NYMEX [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:55.514 | GCZ4.COMEX [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:55.559 | CLX4.NYMEX [CBV] Weekly #5 | Reloading chart.
2024-09-22 19:41:55.559 | CLX4.NYMEX [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:55.559 | CLX4.NYMEX [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:58.382 | CLX4.NYMEX [CBV] Monthly #4 | Chart data loading complete.
2024-09-22 19:41:58.382 | 6JZ4.CME [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:58.442 | 6JZ4.CME [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:58.470 | GCZ4.COMEX [CBV] 240 Min #7 | Chart data loading complete.
2024-09-22 19:41:58.473 | CLX4.NYMEX [CBV] 60 Min #15 | Chart data loading complete.
2024-09-22 19:41:58.599 | 6JZ4.CME [CBV] #3 | Chart data loading complete.
2024-09-22 19:41:58.600 | GCZ4.COMEX [CBV] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:41:58.696 | GCZ4.COMEX [CBV] 15 Min #10 | Chart data loading complete.
2024-09-22 19:41:58.847 | CLX4.NYMEX [CBV] Weekly #5 | Chart data loading complete.
2024-09-22 19:41:58.865 | CLX4.NYMEX [CBV] Daily #6 | Reloading chart.
2024-09-22 19:41:58.865 | CLX4.NYMEX [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:41:58.865 | CLX4.NYMEX [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 19:42:01.446 | CLX4.NYMEX [CBV] #14 | Chart data loading complete.
2024-09-22 19:42:01.448 | CLX4.NYMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:42:02.364 | CLX4.NYMEX [CBV] Daily #6 | Chart data loading complete.
2024-09-22 19:42:02.404 | CLX4.NYMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:42:02.935 | CLX4.NYMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:42:04.019 | CLX4.NYMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:42:04.167 | 6JZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:42:04.570 | HD Request # 28 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-22 19:42:04.570 | HD Request # 28 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-22 19:42:04.570 | HD Request # 28 | Using server: ds32.sierracharts.com port 10150
2024-09-22 19:42:04.570 | Socket (5) | Creating socket.
2024-09-22 19:42:04.570 | Socket (5) | New receive buffer size: 0
2024-09-22 19:42:04.570 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-22 19:42:04.684 | CLX4.NYMEX [CBV] 3 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:42:04.695 | CLX4.NYMEX [CBV] 3 Min #17 | Chart data loading complete.
2024-09-22 19:42:05.134 | HD Request # 28 | Setting DTC encoding to Binary VLS
2024-09-22 19:42:05.134 | HD Request # 28 | Sending historical data logon request message.
2024-09-22 19:42:05.251 | 6JZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:42:05.455 | 6JZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:42:05.562 | 6JZ4.CME [CBV] #14 | Reloading chart.
2024-09-22 19:42:05.901 | HD Request # 28 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-22 19:42:06.053 | GCZ4.COMEX [CBV] 240 Min #15 | Reloading chart.
2024-09-22 19:42:06.179 | HD Request # 28 | Decompressing data.
2024-09-22 19:42:06.413 | GCZ4.COMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:42:06.455 | HD Request # 28 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-22 19:42:06.455 | Socket (5) | CloseSocket call.
2024-09-22 19:42:06.455 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-22 19:42:06.483 | Historical data download thread signaled to stop.
2024-09-22 19:42:06.483 | HD Request # 28 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 34.2 days) and wrote 0 records for MCLU4.NYMEX
2024-09-22 19:42:06.483 | HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-22 19:42:06.483 | HD Request # 28 | Completion time: 2s.
2024-09-22 19:42:06.483 | HD Request # 28 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 28
2024-09-22 19:42:06.483 | Removing historical data download ID 28.
2024-09-22 19:42:06.483 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-22 19:42:06.483 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-22 19:42:06.483 | HD Request # 28 | Enabling Intraday chart updating for symbol.
2024-09-22 19:42:06.483 | No download requests in the queue to start downloads for.
2024-09-22 19:42:06.489 | GCZ4.COMEX [CBV] #14 | Reloading chart.
2024-09-22 19:42:06.730 | Socket (5) | Socket gracefully closed by remote side.
2024-09-22 19:42:06.730 | Socket (5) | Closed.
2024-09-22 19:42:07.268 | CLX4.NYMEX [CBV] #3 | Chart data loading complete.
2024-09-22 19:42:07.362 | GCZ4.COMEX [CBV] #3 | Reloading chart.
2024-09-22 19:42:07.817 | 6JZ4.CME [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:42:07.841 | GCZ4.COMEX [CBV] 240 Min #7 | Reloading chart.
2024-09-22 19:42:08.268 | GCZ4.COMEX [CBV] 3 Min #17 | Reloading chart.
2024-09-22 19:42:08.320 | GCZ4.COMEX [CBV] 60 Min #8 | Reloading chart.
2024-09-22 19:42:08.500 | CLX4.NYMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:42:08.535 | CLX4.NYMEX [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:42:08.599 | GCZ4.COMEX [CBV] 15 Min #10 | Reloading chart.
2024-09-22 19:42:09.072 | GCZ4.COMEX [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:42:09.073 | GCZ4.COMEX [CBV] 3 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-23 16:15:00
2024-09-22 19:42:09.088 | GCZ4.COMEX [CBV] 3 Min #17 | Chart data loading complete.
2024-09-22 19:42:09.355 | CLX4.NYMEX [CBV] 60 Min #15 | Reloading chart.
2024-09-22 19:42:10.823 | 6JZ4.CME [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:42:10.852 | 6JZ4.CME [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:42:10.892 | CLX4.NYMEX [CBV] 240 Min #2 | Reloading chart.
2024-09-22 19:42:11.448 | 6JZ4.CME [CBV] #14 | Chart data loading complete.
2024-09-22 19:42:11.455 | CLX4.NYMEX [CBV] #14 | Reloading chart.
2024-09-22 19:42:13.227 | CLX4.NYMEX [CBV] #3 | Reloading chart.
2024-09-22 19:42:15.047 | GCZ4.COMEX [CBV] 240 Min #15 | Chart data loading complete.
2024-09-22 19:42:15.053 | CLX4.NYMEX [CBV] 240 Min #2 | Chart data loading complete.
2024-09-22 19:42:15.054 | GCZ4.COMEX [CBV] 60 Min #8 | StartDateTimeForLoadingOrderFills: 2023-11-27 18:00:00
2024-09-22 19:42:15.100 | GCZ4.COMEX [CBV] 60 Min #8 | Chart data loading complete.
2024-09-22 19:42:15.788 | GCZ4.COMEX [CBV] #14 | Chart data loading complete.
2024-09-22 19:42:15.827 | 6JZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 19:42:19.283 | CLX4.NYMEX [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 19:42:19.969 | CLX4.NYMEX [CBV][M] 60 Min #15 | Chart data loading complete.
2024-09-22 19:42:21.643 | GCZ4.COMEX [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-22 19:42:22.155 | CLX4.NYMEX [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:42:22.235 | CLX4.NYMEX [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-22 19:42:22.520 | GCZ4.COMEX [CBV][M] #3 | Chart data loading complete.
2024-09-22 19:42:22.521 | GCZ4.COMEX [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-22 19:42:22.610 | GCZ4.COMEX [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-22 19:42:24.168 | CLX4.NYMEX [CBV][M] #14 | Chart data loading complete.
2024-09-22 19:42:29.194 | CLX4.NYMEX [CBV][M] #3 | Chart data loading complete.
2024-09-22 19:42:31.242 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-22 19:43:36.789 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MJYZ4.CME.scid. Thread ID: 3296
2024-09-22 19:44:22.720 | Chat | Message response. Chat ID: 429. Request ID: 1134626463
2024-09-22 19:49:01.820 | Chat | Message response. Chat ID: 429. Request ID: 1134626464
2024-09-22 20:00:00.046 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-22 20:00:00.046 | Triggering next historical data download in queue.
2024-09-22 20:00:00.047 | HD Request # 29 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:00.261 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-22 20:00:00.261 | Triggering next historical data download in queue.
2024-09-22 20:00:00.462 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-22 20:00:00.462 | Triggering next historical data download in queue.
2024-09-22 20:00:00.462 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:00.501 | 6JZ4.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:00.549 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-22 20:00:00.549 | Triggering next historical data download in queue.
2024-09-22 20:00:00.656 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-22 20:00:00.657 | Triggering next historical data download in queue.
2024-09-22 20:00:00.738 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-22 20:00:00.738 | Triggering next historical data download in queue.
2024-09-22 20:00:00.751 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:01.004 | HD Request # 29 | Requesting historical Daily data for J6Z24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:01.057 | NQZ4.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:01.264 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:01.264 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.264 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.472 | GCZ4.COMEX [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 31,
2024-09-22 20:00:01.512 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:01.512 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.512 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.667 | 6JZ4.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 29,
2024-09-22 20:00:01.819 | ESZ4.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:01.913 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:01.913 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:01.913 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:02.115 | CLX4.NYMEX [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 32,
2024-09-22 20:00:02.115 | HD Request # 29 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-18.
2024-09-22 20:00:02.116 | HD Request # 29 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-22 20:00:02.119 | HD Request # 29 | Bytes received: 274
2024-09-22 20:00:02.119 | HD Request # 29 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6JZ4.CME
2024-09-22 20:00:02.120 | HD Request # 29 | Completion time: 2s.
2024-09-22 20:00:02.120 | HD Request # 29 | Daily data download complete for 6JZ4.CME. Unique request ID: 29
2024-09-22 20:00:02.120 | Removing historical data download ID 29.
2024-09-22 20:00:02.120 | Triggering next historical data download in queue.
2024-09-22 20:00:02.121 | HD Request # 30 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:02.144 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:02.144 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:02.144 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:02.908 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:02.908 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:02.908 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:03.612 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:03.612 | HD Request # 30 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:03.778 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:03.831 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:03.831 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:03.831 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:04.012 | NQZ4.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 30,
2024-09-22 20:00:04.346 | 6JZ4.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:04.347 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:04.894 | HD Request # 30 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-22 20:00:04.894 | HD Request # 30 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-22 20:00:04.896 | HD Request # 30 | Bytes received: 242
2024-09-22 20:00:04.896 | HD Request # 30 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for NQZ4.CME
2024-09-22 20:00:04.897 | HD Request # 30 | Completion time: 2s.
2024-09-22 20:00:04.897 | HD Request # 30 | Daily data download complete for NQZ4.CME. Unique request ID: 30
2024-09-22 20:00:04.897 | Removing historical data download ID 30.
2024-09-22 20:00:04.897 | Triggering next historical data download in queue.
2024-09-22 20:00:04.897 | HD Request # 31 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:04.958 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:04.958 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:04.958 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:05.135 | ESZ4.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 33,
2024-09-22 20:00:05.137 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:05.137 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:05.137 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:05.137 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:05.478 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:05.512 | 6AZ4.CME [CBV][M] Daily #6 | Reloading Historical Daily chart due to current quote data for new date received.
2024-09-22 20:00:05.829 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:05.829 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:05.829 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:06.119 | HD Request # 31 | Requesting historical Daily data for GCZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:06.320 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:06.359 | NQZ4.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:06.359 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:06.518 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:06.566 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:06.566 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:06.566 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:07.268 | HD Request # 31 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-18.
2024-09-22 20:00:07.268 | HD Request # 31 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-22 20:00:07.273 | HD Request # 31 | Bytes received: 232
2024-09-22 20:00:07.273 | HD Request # 31 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-22 20:00:07.273 | HD Request # 31 | Completion time: 3s.
2024-09-22 20:00:07.273 | HD Request # 31 | Daily data download complete for GCZ4.COMEX. Unique request ID: 31
2024-09-22 20:00:07.273 | Removing historical data download ID 31.
2024-09-22 20:00:07.273 | Triggering next historical data download in queue.
2024-09-22 20:00:07.274 | HD Request # 32 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:07.368 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:07.417 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:07.417 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:07.417 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:07.572 | 6AZ4.CME [CBV][M] Daily #6 | Waiting for historical downloads to complete with the IDs: 34,
2024-09-22 20:00:07.617 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:07.617 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:07.617 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:08.304 | HD Request # 32 | Requesting historical Daily data for CLX24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:08.336 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:08.747 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:08.747 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:08.747 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:09.372 | HD Request # 32 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-18.
2024-09-22 20:00:09.372 | HD Request # 32 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-22 20:00:09.377 | HD Request # 32 | Bytes received: 217
2024-09-22 20:00:09.377 | HD Request # 32 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-22 20:00:09.377 | HD Request # 32 | Completion time: 2s.
2024-09-22 20:00:09.377 | HD Request # 32 | Daily data download complete for CLX4.NYMEX. Unique request ID: 32
2024-09-22 20:00:09.377 | Removing historical data download ID 32.
2024-09-22 20:00:09.377 | Triggering next historical data download in queue.
2024-09-22 20:00:09.378 | HD Request # 33 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:09.387 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:09.387 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:09.387 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:11.486 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:11.534 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:11.534 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:11.534 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:13.649 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:13.649 | HD Request # 33 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:13.696 | GCZ4.COMEX [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:13.697 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:14.116 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:14.117 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:14.117 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:14.117 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:14.408 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:14.471 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:14.748 | HD Request # 33 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-22 20:00:14.749 | HD Request # 33 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-22 20:00:14.752 | HD Request # 33 | Bytes received: 234
2024-09-22 20:00:14.752 | HD Request # 33 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-22 20:00:14.752 | HD Request # 33 | Completion time: 5s.
2024-09-22 20:00:14.752 | HD Request # 33 | Daily data download complete for ESZ4.CME. Unique request ID: 33
2024-09-22 20:00:14.752 | Removing historical data download ID 33.
2024-09-22 20:00:14.752 | Triggering next historical data download in queue.
2024-09-22 20:00:14.753 | HD Request # 34 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-22 20:00:14.887 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:14.887 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:14.887 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:15.413 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:15.444 | CLX4.NYMEX [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:15.445 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:17.341 | HD Request # 34 | Requesting historical Daily data for A6Z24 starting at 2024-09-17. SC External HD service.
2024-09-22 20:00:17.444 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:17.444 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:17.444 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:18.071 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:18.071 | ESZ4.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:18.072 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:18.221 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:18.282 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:18.284 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:18.284 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:18.284 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:18.655 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:18.674 | HD Request # 34 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-18.
2024-09-22 20:00:18.674 | HD Request # 34 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-22 20:00:18.678 | HD Request # 34 | Bytes received: 237
2024-09-22 20:00:18.678 | HD Request # 34 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6AZ4.CME
2024-09-22 20:00:18.678 | HD Request # 34 | Completion time: 4s.
2024-09-22 20:00:18.678 | HD Request # 34 | Daily data download complete for 6AZ4.CME. Unique request ID: 34
2024-09-22 20:00:18.678 | Removing historical data download ID 34.
2024-09-22 20:00:18.678 | No download requests in the queue to start downloads for.
2024-09-22 20:00:18.694 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-22 20:00:18.694 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:18.694 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:19.482 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-22 20:00:19.482 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:19.482 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:20.183 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-22 20:00:20.287 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-22 20:00:20.287 | 6AZ4.CME [CBV][M] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-22 20:00:20.287 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:20.942 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:21.195 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:21.195 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:21.195 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:23.455 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:23.455 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:23.455 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:23.782 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:23.819 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:00:24.056 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-22 20:00:24.056 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:24.056 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-22 20:00:24.876 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-22 20:30:42.220 | Chat | Message response. Chat ID: 429. Request ID: 1134626465
2024-09-22 21:15:13.971 | Chat | Message response. Chat ID: 429. Request ID: 1134626466
2024-09-22 21:16:03.033 | Chat | Message response. Chat ID: 429. Request ID: 1134626467
2024-09-22 21:35:03.454 | Chat | Message response. Chat ID: 429. Request ID: 1134626468
2024-09-22 21:53:56.745 | Chat | Message response. Chat ID: 429. Request ID: 1134626469
2024-09-22 22:00:44.240 | Chat | Message response. Chat ID: 429. Request ID: 1134626470
2024-09-22 22:27:07.203 | Chat | Message response. Chat ID: 429. Request ID: 1134626471
2024-09-22 22:41:30.527 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Creating socket. Using TLS 1.2.
2024-09-22 22:41:30.527 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | New receive buffer size: 0
2024-09-22 22:41:30.527 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Connecting to IP: 216.66.0.130.
2024-09-22 22:41:32.832 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | CloseSocket call.
2024-09-22 22:41:32.832 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Shutdown started. Waiting for graceful close.
2024-09-22 22:41:33.087 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Socket gracefully closed by remote side.
2024-09-22 22:41:33.087 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Closed.
2024-09-22 22:59:59.960 | Chat | Server has requested a logoff. Reason: Chat server is backing up
2024-09-22 22:59:59.960 | Chat | Waiting for socket receive thread to end
2024-09-22 22:59:59.960 | DTC Client socket (3) | CloseSocket call.
2024-09-22 22:59:59.960 | DTC Client socket (3) | Max send buffers used during socket life: 3
2024-09-22 22:59:59.960 | DTC Client socket (3) | Max send buffer size during socket life: 399
2024-09-22 22:59:59.960 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2024-09-22 22:59:59.960 | Chat | Disconnected from the server.
2024-09-22 22:59:59.960 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2024-09-22 23:00:01.775 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-09-22 23:00:01.775 | DTC Client socket (3) | Closed.
2024-09-22 23:00:04.960 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-22 23:00:05.103 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2024-09-22 23:00:05.103 | DTC Client socket (3) | New receive buffer size: 0
2024-09-22 23:00:05.103 | DTC Client socket (3) | Connecting to IP: 69.39.70.248.
2024-09-22 23:00:05.376 | Chat | Network connection to server complete.
2024-09-22 23:00:05.376 | Chat | Starting socket receive thread.
2024-09-22 23:00:05.376 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-22 23:00:06.196 | Chat | Setting DTC encoding to Binary VLS
2024-09-22 23:00:06.196 | Chat | Sending logon request message.
2024-09-22 23:00:19.951 | Chat | Received logon response.
2024-09-22 23:00:19.951 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-22 23:00:19.951 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-22 23:00:19.951 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-22 23:00:19.951 | Chat | Trading is not supported.
2024-09-22 23:00:19.951 | Chat | MarketDepthIsSupported: 1
2024-09-22 23:20:01.476 | Chat | Message response. Chat ID: 429. Request ID: 1134626477
2024-09-23 00:00:00.054 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-23 00:00:00.054 | Triggering next historical data download in queue.
2024-09-23 00:00:00.055 | HD Request # 35 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:00.055 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-23 00:00:00.055 | Triggering next historical data download in queue.
2024-09-23 00:00:00.056 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-23 00:00:00.056 | Triggering next historical data download in queue.
2024-09-23 00:00:00.487 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 00:00:00.487 | Triggering next historical data download in queue.
2024-09-23 00:00:00.489 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-23 00:00:00.489 | Triggering next historical data download in queue.
2024-09-23 00:00:00.489 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-23 00:00:01.029 | HD Request # 35 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:02.002 | HD Request # 35 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-23 00:00:02.002 | HD Request # 35 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-23 00:00:02.005 | HD Request # 35 | Bytes received: 242
2024-09-23 00:00:02.005 | HD Request # 35 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for NQZ4.CME
2024-09-23 00:00:02.005 | HD Request # 35 | Completion time: 2s.
2024-09-23 00:00:02.005 | HD Request # 35 | Daily data download complete for NQZ4.CME. Unique request ID: 35
2024-09-23 00:00:02.005 | Removing historical data download ID 35.
2024-09-23 00:00:02.005 | Triggering next historical data download in queue.
2024-09-23 00:00:02.006 | HD Request # 36 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:02.216 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:02.216 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:02.216 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:02.557 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:02.768 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:02.768 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:02.768 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:03.062 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:03.062 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:03.062 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:03.357 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:03.357 | HD Request # 36 | Requesting historical Daily data for GCZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:03.401 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:04.152 | HD Request # 36 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-18.
2024-09-23 00:00:04.152 | HD Request # 36 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-23 00:00:04.157 | HD Request # 36 | Bytes received: 232
2024-09-23 00:00:04.157 | HD Request # 36 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-23 00:00:04.157 | HD Request # 36 | Completion time: 2s.
2024-09-23 00:00:04.157 | HD Request # 36 | Daily data download complete for GCZ4.COMEX. Unique request ID: 36
2024-09-23 00:00:04.157 | Removing historical data download ID 36.
2024-09-23 00:00:04.157 | Triggering next historical data download in queue.
2024-09-23 00:00:04.158 | HD Request # 37 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:04.612 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:04.612 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:04.612 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:05.242 | HD Request # 37 | Requesting historical Daily data for J6Z24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:05.502 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:05.504 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:05.504 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:05.504 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:06.135 | HD Request # 37 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-18.
2024-09-23 00:00:06.135 | HD Request # 37 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-23 00:00:06.139 | HD Request # 37 | Bytes received: 274
2024-09-23 00:00:06.139 | HD Request # 37 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6JZ4.CME
2024-09-23 00:00:06.139 | HD Request # 37 | Completion time: 2s.
2024-09-23 00:00:06.139 | HD Request # 37 | Daily data download complete for 6JZ4.CME. Unique request ID: 37
2024-09-23 00:00:06.139 | Removing historical data download ID 37.
2024-09-23 00:00:06.139 | Triggering next historical data download in queue.
2024-09-23 00:00:06.140 | HD Request # 38 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:06.141 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:06.141 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:06.141 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:06.850 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:06.882 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:06.882 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:06.882 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:07.517 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:07.586 | HD Request # 38 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:07.600 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:07.980 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:07.980 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:07.980 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:08.693 | HD Request # 38 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-23 00:00:08.693 | HD Request # 38 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 00:00:08.696 | HD Request # 38 | Bytes received: 234
2024-09-23 00:00:08.696 | HD Request # 38 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-23 00:00:08.696 | HD Request # 38 | Completion time: 2s.
2024-09-23 00:00:08.696 | HD Request # 38 | Daily data download complete for ESZ4.CME. Unique request ID: 38
2024-09-23 00:00:08.696 | Removing historical data download ID 38.
2024-09-23 00:00:08.696 | Triggering next historical data download in queue.
2024-09-23 00:00:08.697 | HD Request # 39 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:08.698 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:08.698 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:08.698 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.030 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:09.031 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:09.031 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.031 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.361 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:09.362 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:09.362 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.362 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.697 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:09.698 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:09.698 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:09.698 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:10.410 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:10.410 | HD Request # 39 | Requesting historical Daily data for CLX24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:10.667 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:11.305 | HD Request # 39 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-18.
2024-09-23 00:00:11.305 | HD Request # 39 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-23 00:00:11.311 | HD Request # 39 | Bytes received: 217
2024-09-23 00:00:11.311 | HD Request # 39 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-23 00:00:11.311 | HD Request # 39 | Completion time: 3s.
2024-09-23 00:00:11.311 | HD Request # 39 | Daily data download complete for CLX4.NYMEX. Unique request ID: 39
2024-09-23 00:00:11.311 | Removing historical data download ID 39.
2024-09-23 00:00:11.311 | Triggering next historical data download in queue.
2024-09-23 00:00:11.311 | HD Request # 40 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 00:00:11.563 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:11.563 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:11.563 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:13.709 | HD Request # 40 | Requesting historical Daily data for A6Z24 starting at 2024-09-17. SC External HD service.
2024-09-23 00:00:13.710 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:13.710 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:13.710 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:15.834 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:15.866 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:15.866 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:15.866 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:17.987 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 00:00:17.987 | HD Request # 40 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-18.
2024-09-23 00:00:17.987 | HD Request # 40 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-23 00:00:17.992 | HD Request # 40 | Bytes received: 237
2024-09-23 00:00:17.992 | HD Request # 40 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for 6AZ4.CME
2024-09-23 00:00:17.992 | HD Request # 40 | Completion time: 6s.
2024-09-23 00:00:17.992 | HD Request # 40 | Daily data download complete for 6AZ4.CME. Unique request ID: 40
2024-09-23 00:00:17.992 | Removing historical data download ID 40.
2024-09-23 00:00:17.992 | No download requests in the queue to start downloads for.
2024-09-23 00:00:18.319 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:18.749 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 00:00:18.749 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:18.749 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:19.457 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 00:00:19.457 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:19.457 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:20.170 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 00:00:20.202 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 00:00:20.202 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:20.202 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 00:00:20.911 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 00:00:21.136 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 01:44:41.593 | Saved Chartbook: ES.Cht. Time: 0.0584 seconds.
2024-09-23 02:07:31.434 | Chat | Message response. Chat ID: 429. Request ID: 1134626478
2024-09-23 03:15:04.407 | Chat | Message response. Chat ID: 429. Request ID: 1134626479
2024-09-23 03:19:17.660 | Chat | Message response. Chat ID: 429. Request ID: 1134626480
2024-09-23 03:38:10.857 | Chat | Message response. Chat ID: 429. Request ID: 1134626481
2024-09-23 03:46:21.166 | Chat | Message response. Chat ID: 429. Request ID: 1134626482
2024-09-23 04:00:42.762 | Chat | Message response. Chat ID: 429. Request ID: 1134626483
2024-09-23 04:31:08.020 | Chat | Message response. Chat ID: 429. Request ID: 1134626484
2024-09-23 04:34:54.487 | Chat | Message response. Chat ID: 429. Request ID: 1134626485
2024-09-23 04:45:39.613 | Chat | Message response. Chat ID: 429. Request ID: 1134626486
2024-09-23 04:45:40.109 | Chat | Message response. Chat ID: 429. Request ID: 1134626487
2024-09-23 05:10:08.019 | Chat | Message response. Chat ID: 429. Request ID: 1134626488
2024-09-23 05:37:13.686 | Chat | Message response. Chat ID: 429. Request ID: 1134626489
2024-09-23 05:48:12.957 | Chat | Message response. Chat ID: 429. Request ID: 1134626490
2024-09-23 06:41:32.488 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Creating socket. Using TLS 1.2.
2024-09-23 06:41:32.488 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | New receive buffer size: 0
2024-09-23 06:41:32.488 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Connecting to IP: 216.66.0.130.
2024-09-23 06:41:34.273 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | CloseSocket call.
2024-09-23 06:41:34.273 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Shutdown started. Waiting for graceful close.
2024-09-23 06:41:34.527 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Socket gracefully closed by remote side.
2024-09-23 06:41:34.527 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (5) | Closed.
2024-09-23 08:25:49.234 | Chat | Message response. Chat ID: 429. Request ID: 1134626491
2024-09-23 08:42:14.769 | Chat | Message response. Chat ID: 429. Request ID: 1134626492
2024-09-23 08:50:52.116 | ESZ4.CME [CBV][M] 1 Min #17 | Reloading chart.
2024-09-23 08:50:52.117 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-23 08:50:52.117 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-23 08:50:52.118 | Triggering next historical data download in queue.
2024-09-23 08:50:52.118 | ESZ4.CME [CBV][M] 1 Min #17 | Performing continuous chart historical Daily data download for symbol ESZ4.CME starting at last date in file.
2024-09-23 08:50:52.118 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 08:50:52.127 | ESZ4.CME [CBV][M] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 41, 42,
2024-09-23 08:50:52.128 | HD Request # 41 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-23 08:50:52.128 | HD Request # 41 | Download start date-time: 2024-09-23 08:50:51.000000. File last date-time: 2024-09-23 08:50:51.963002
2024-09-23 08:50:52.128 | HD Request # 41 | Using server: ds32.sierracharts.com port 10149
2024-09-23 08:50:52.129 | HD Request # 42 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 08:50:52.259 | Socket (5) | Creating socket.
2024-09-23 08:50:52.259 | Socket (5) | New receive buffer size: 0
2024-09-23 08:50:52.259 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 08:50:52.828 | HD Request # 41 | Setting DTC encoding to Binary VLS
2024-09-23 08:50:52.828 | HD Request # 41 | Sending historical data logon request message.
2024-09-23 08:50:53.203 | HD Request # 42 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 08:50:53.613 | HD Request # 41 | Requesting Intraday data. Start date-time: 2024-09-23 08:50:51. Record interval: 0. Symbol: ESZ24
2024-09-23 08:50:53.896 | HD Request # 41 | Decompressing data.
2024-09-23 08:50:54.174 | HD Request # 41 | Receiving Intraday data for ESZ4.CME starting at 2024-09-23 08:50:51.963000
2024-09-23 08:50:54.174 | Socket (5) | CloseSocket call.
2024-09-23 08:50:54.174 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 08:50:54.204 | Historical data download thread signaled to stop.
2024-09-23 08:50:54.204 | HD Request # 41 | Received 3 Intraday data records from 2024-09-23 08:50:51.963000 to 2024-09-23 08:50:51.963002 (0.0 seconds. Delay: 2.2 seconds) and wrote 0 records for ESZ4.CME
2024-09-23 08:50:54.204 | HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2024-09-23 12:50:51.963002
2024-09-23 08:50:54.204 | HD Request # 41 | Completion time: 2s.
2024-09-23 08:50:54.204 | HD Request # 41 | Intraday data download complete for ESZ4.CME. Unique request ID: 41
2024-09-23 08:50:54.204 | Removing historical data download ID 41.
2024-09-23 08:50:54.204 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-23 08:50:54.204 | Intraday chart data file opened for ESZ4.CME
2024-09-23 08:50:54.204 | HD Request # 41 | Enabling Intraday chart updating for symbol.
2024-09-23 08:50:54.204 | No download requests in the queue to start downloads for.
2024-09-23 08:50:54.204 | HD Request # 42 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-23 08:50:54.204 | HD Request # 42 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 08:50:54.207 | HD Request # 42 | Bytes received: 234
2024-09-23 08:50:54.207 | HD Request # 42 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-23 08:50:54.207 | HD Request # 42 | Completion time: 2s.
2024-09-23 08:50:54.207 | HD Request # 42 | Daily data download complete for ESZ4.CME. Unique request ID: 42
2024-09-23 08:50:54.207 | Removing historical data download ID 42.
2024-09-23 08:50:54.207 | No download requests in the queue to start downloads for.
2024-09-23 08:50:54.288 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 08:50:54.288 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:54.288 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:54.452 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 08:50:54.452 | Socket (5) | Closed.
2024-09-23 08:50:54.672 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 08:50:54.715 | ESZ4.CME [CBV][M] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-23 08:50:54.716 | ESZ4.CME [CBV][M] 1 Min #17 | Reloading chart.
2024-09-23 08:50:55.137 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 08:50:55.137 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:55.137 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:55.518 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 08:50:55.518 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:55.518 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 08:50:55.890 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 08:50:55.949 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 08:50:56.750 | ESZ4.CME [CBV][M] 1 Min #17 | Reloading chart.
2024-09-23 08:50:57.137 | ESZ4.CME [CBV][M] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-23 08:50:57.158 | ESZ4.CME [CBV][M] 1 Min #17 | Chart data loading complete.
2024-09-23 08:50:57.416 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-23 09:00:45.538 | Chat | Message response. Chat ID: 429. Request ID: 1134626493
2024-09-23 09:30:17.453 | ESZ4.CME[M] 1 Min #12 | Reloading chart.
2024-09-23 09:30:18.407 | ESZ4.CME[M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:03:00
2024-09-23 09:30:18.441 | ESZ4.CME[M] 1 Min #12 | Chart data loading complete.
2024-09-23 09:46:32.615 | ESZ4.CME [CBV][M] 60 Min #8 | + Error reading record for update Intraday chart. Invalid cache index
2024-09-23 10:01:22.484 | Chat | Message response. Chat ID: 429. Request ID: 1134626494
2024-09-23 10:47:16.592 | 6AZ4.CME [CBV][M] 60 Min #8 | + Error reading record for update Intraday chart. Invalid cache index
2024-09-23 11:00:12.557 | Chat | Message response. Chat ID: 429. Request ID: 1134626495
2024-09-23 11:15:07.935 | Chat | Message response. Chat ID: 429. Request ID: 1134626496
2024-09-23 11:33:38.287 | ESZ4.CME[M] 5 Min #12 | Reloading chart.
2024-09-23 11:33:39.112 | ESZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-23 11:33:39.126 | ESZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-23 12:08:59.935 | Chat | Message response. Chat ID: 429. Request ID: 1134626497
2024-09-23 14:15:55.119 | ESZ4.CME[M] 15 Min #12 | Reloading chart.
2024-09-23 14:15:56.160 | ESZ4.CME[M] 15 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-23 14:15:56.173 | ESZ4.CME[M] 15 Min #12 | Chart data loading complete.
2024-09-23 14:17:07.706 | ESZ4.CME [CBV][M] 60 Min #15 | Reloading chart.
2024-09-23 14:17:07.720 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-23 14:17:07.720 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-23 14:17:07.720 | Triggering next historical data download in queue.
2024-09-23 14:17:07.721 | ESZ4.CME [CBV][M] 60 Min #15 | Performing continuous chart historical Daily data download for symbol ESZ4.CME starting at last date in file.
2024-09-23 14:17:07.721 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 14:17:07.721 | Triggering next historical data download in queue.
2024-09-23 14:17:07.793 | ESZ4.CME [CBV][M] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 43, 44,
2024-09-23 14:17:07.794 | HD Request # 43 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-23 14:17:07.794 | HD Request # 43 | Download start date-time: 2024-09-23 14:17:08.000000. File last date-time: 2024-09-23 14:17:08.507007
2024-09-23 14:17:07.794 | HD Request # 43 | Using server: ds32.sierracharts.com port 10150
2024-09-23 14:17:07.794 | HD Request # 44 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 14:17:07.904 | Socket (5) | Creating socket.
2024-09-23 14:17:07.904 | Socket (5) | New receive buffer size: 0
2024-09-23 14:17:07.904 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 14:17:08.458 | HD Request # 43 | Setting DTC encoding to Binary VLS
2024-09-23 14:17:08.458 | HD Request # 43 | Sending historical data logon request message.
2024-09-23 14:17:08.864 | HD Request # 44 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 14:17:09.226 | HD Request # 43 | Requesting Intraday data. Start date-time: 2024-09-23 14:17:08. Record interval: 0. Symbol: ESZ24
2024-09-23 14:17:09.498 | HD Request # 43 | Decompressing data.
2024-09-23 14:17:09.781 | HD Request # 43 | Receiving Intraday data for ESZ4.CME starting at 2024-09-23 13:17:07.048000
2024-09-23 14:17:09.892 | HD Request # 44 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-23 14:17:09.892 | HD Request # 44 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 14:17:09.895 | HD Request # 44 | Bytes received: 234
2024-09-23 14:17:09.895 | HD Request # 44 | Received 4 Daily data records from 2024-09-18 00:00:00 to 2024-09-20 00:00:00 (3.0 days) and wrote 3 records for ESZ4.CME
2024-09-23 14:17:09.895 | HD Request # 44 | Completion time: 2s.
2024-09-23 14:17:09.895 | HD Request # 44 | Daily data download complete for ESZ4.CME. Unique request ID: 44
2024-09-23 14:17:09.895 | Removing historical data download ID 44.
2024-09-23 14:17:09.895 | No download requests in the queue to start downloads for.
2024-09-23 14:17:10.107 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 14:17:10.107 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:10.107 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:10.476 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 14:17:10.842 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 14:17:10.842 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:10.842 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:10.862 | Socket (5) | CloseSocket call.
2024-09-23 14:17:10.862 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 14:17:11.133 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 14:17:11.133 | Socket (5) | Closed.
2024-09-23 14:17:11.166 | Historical data download thread signaled to stop.
2024-09-23 14:17:11.166 | HD Request # 43 | Timestamp of first Intraday data file record written: 2024-09-23 14:17:09.786000.
2024-09-23 14:17:11.166 | HD Request # 43 | Received 54345 Intraday data records from 2024-09-23 13:17:07.048000 to 2024-09-23 14:17:09.786001 (60.0 minutes. Delay: 1.4 seconds) and wrote 2 records for ESZ4.CME
2024-09-23 14:17:11.167 | HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2024-09-23 18:17:09.786001
2024-09-23 14:17:11.167 | Added 9 Time and Sales records to Intraday data file for ESZ4.CME after download.
2024-09-23 14:17:11.167 | HD Request # 43 | Completion time: 4s.
2024-09-23 14:17:11.167 | HD Request # 43 | Intraday data download complete for ESZ4.CME. Unique request ID: 43
2024-09-23 14:17:11.167 | Removing historical data download ID 43.
2024-09-23 14:17:11.167 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-23 14:17:11.167 | Intraday chart data file opened for ESZ4.CME
2024-09-23 14:17:11.167 | HD Request # 43 | Enabling Intraday chart updating for symbol.
2024-09-23 14:17:11.167 | No download requests in the queue to start downloads for.
2024-09-23 14:17:11.205 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 14:17:11.221 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 14:17:11.221 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:11.221 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 14:17:11.585 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 14:17:11.827 | ESZ4.CME [CBV][M] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-23 14:17:11.828 | ESZ4.CME [CBV][M] 60 Min #15 | Reloading chart. | Number times message added: 1
2024-09-23 14:17:13.976 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-23 14:17:43.112 | ESZ4.CME [CBV][M] 60 Min #15 | Chart data loading complete.
2024-09-23 14:41:13.859 | Denali Data Feed | Message from server: Authorization data verified.
2024-09-23 14:41:35.040 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Creating socket. Using TLS 1.2.
2024-09-23 14:41:35.040 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | New receive buffer size: 0
2024-09-23 14:41:35.040 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Connecting to IP: 216.66.0.130.
2024-09-23 14:41:37.333 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | CloseSocket call.
2024-09-23 14:41:37.333 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Shutdown started. Waiting for graceful close.
2024-09-23 14:41:37.586 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Socket gracefully closed by remote side.
2024-09-23 14:41:37.586 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (5) | Closed.
2024-09-23 16:08:37.856 | Saved Chartbook: GC.Cht. Time: 0.0529 seconds.
2024-09-23 17:45:00.006 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-23 17:45:00.006 | Triggering next historical data download in queue.
2024-09-23 17:45:00.007 | HD Request # 45 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:00.007 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-23 17:45:00.007 | Triggering next historical data download in queue.
2024-09-23 17:45:00.007 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-23 17:45:00.007 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-23 17:45:00.023 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-23 17:45:00.023 | Triggering next historical data download in queue.
2024-09-23 17:45:00.062 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 17:45:00.062 | Triggering next historical data download in queue.
2024-09-23 17:45:01.138 | HD Request # 45 | Requesting historical Daily data for GCZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:02.064 | HD Request # 45 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-18.
2024-09-23 17:45:02.064 | HD Request # 45 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-23 17:45:02.069 | HD Request # 45 | Bytes received: 291
2024-09-23 17:45:02.069 | HD Request # 45 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for GCZ4.COMEX
2024-09-23 17:45:02.069 | HD Request # 45 | Completion time: 2s.
2024-09-23 17:45:02.069 | HD Request # 45 | Daily data download complete for GCZ4.COMEX. Unique request ID: 45
2024-09-23 17:45:02.069 | Removing historical data download ID 45.
2024-09-23 17:45:02.069 | Triggering next historical data download in queue.
2024-09-23 17:45:02.070 | HD Request # 46 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:02.165 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:02.165 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:02.165 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:02.949 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:03.097 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:03.097 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:03.097 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:03.734 | HD Request # 46 | Requesting historical Daily data for A6Z24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:03.750 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:03.750 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:03.750 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:04.401 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:04.513 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:05.046 | HD Request # 46 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-18.
2024-09-23 17:45:05.047 | HD Request # 46 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-23 17:45:05.050 | HD Request # 46 | Bytes received: 298
2024-09-23 17:45:05.050 | HD Request # 46 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for 6AZ4.CME
2024-09-23 17:45:05.051 | HD Request # 46 | Completion time: 3s.
2024-09-23 17:45:05.051 | HD Request # 46 | Daily data download complete for 6AZ4.CME. Unique request ID: 46
2024-09-23 17:45:05.051 | Removing historical data download ID 46.
2024-09-23 17:45:05.051 | Triggering next historical data download in queue.
2024-09-23 17:45:05.052 | HD Request # 47 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:05.201 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:05.201 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:05.201 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:05.918 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:05.918 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:05.918 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:06.658 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:06.658 | HD Request # 47 | Requesting historical Daily data for NQZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:06.678 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:06.678 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:06.678 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:07.412 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:07.538 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:08.003 | HD Request # 47 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-18.
2024-09-23 17:45:08.003 | HD Request # 47 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-23 17:45:08.005 | HD Request # 47 | Bytes received: 300
2024-09-23 17:45:08.005 | HD Request # 47 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for NQZ4.CME
2024-09-23 17:45:08.005 | HD Request # 47 | Completion time: 3s.
2024-09-23 17:45:08.005 | HD Request # 47 | Daily data download complete for NQZ4.CME. Unique request ID: 47
2024-09-23 17:45:08.005 | Removing historical data download ID 47.
2024-09-23 17:45:08.006 |
2024-09-23 17:45:08.006 | Triggering next historical data download in queue.
2024-09-23 17:45:08.006 | HD Request # 48 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:08.258 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:08.258 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.258 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.618 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:08.646 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:08.647 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.647 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.991 | HD Request # 48 | Requesting historical Daily data for CLX24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:08.992 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:08.992 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:08.992 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:09.284 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:09.358 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:09.878 | HD Request # 48 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-18.
2024-09-23 17:45:09.878 | HD Request # 48 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-23 17:45:09.884 | HD Request # 48 | Bytes received: 272
2024-09-23 17:45:09.884 | HD Request # 48 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for CLX4.NYMEX
2024-09-23 17:45:09.884 | HD Request # 48 | Completion time: 1s.
2024-09-23 17:45:09.884 | HD Request # 48 | Daily data download complete for CLX4.NYMEX. Unique request ID: 48
2024-09-23 17:45:09.884 | Removing historical data download ID 48.
2024-09-23 17:45:09.884 | Triggering next historical data download in queue.
2024-09-23 17:45:09.885 | HD Request # 49 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:10.060 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:10.060 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:10.060 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:12.425 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:12.425 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:12.425 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:14.606 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:14.606 | HD Request # 49 | Requesting historical Daily data for J6Z24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:14.624 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:14.624 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:14.624 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:16.843 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:17.285 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:17.437 | HD Request # 49 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-18.
2024-09-23 17:45:17.437 | HD Request # 49 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-23 17:45:17.441 | HD Request # 49 | Bytes received: 341
2024-09-23 17:45:17.441 | HD Request # 49 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for 6JZ4.CME
2024-09-23 17:45:17.442 | HD Request # 49 | Completion time: 8s.
2024-09-23 17:45:17.442 | HD Request # 49 | Daily data download complete for 6JZ4.CME. Unique request ID: 49
2024-09-23 17:45:17.442 | Removing historical data download ID 49.
2024-09-23 17:45:17.442 | Triggering next historical data download in queue.
2024-09-23 17:45:17.443 | HD Request # 50 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-23 17:45:17.450 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:17.450 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:17.450 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:18.169 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:18.169 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:18.169 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:18.911 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:18.911 | HD Request # 50 | Requesting historical Daily data for ESZ24 starting at 2024-09-17. SC External HD service.
2024-09-23 17:45:19.038 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:19.048 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:19.048 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:19.048 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:19.904 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 17:45:20.347 | HD Request # 50 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-18.
2024-09-23 17:45:20.347 | HD Request # 50 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 17:45:20.350 | HD Request # 50 | Bytes received: 295
2024-09-23 17:45:20.350 | HD Request # 50 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for ESZ4.CME
2024-09-23 17:45:20.350 | HD Request # 50 | Completion time: 3s.
2024-09-23 17:45:20.350 | HD Request # 50 | Daily data download complete for ESZ4.CME. Unique request ID: 50
2024-09-23 17:45:20.350 | Removing historical data download ID 50.
2024-09-23 17:45:20.350 | No download requests in the queue to start downloads for.
2024-09-23 17:45:20.496 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 17:45:20.496 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:20.496 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:20.832 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 17:45:20.833 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:20.833 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:21.178 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 17:45:21.231 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 17:45:21.232 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 17:45:21.232 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:21.232 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 17:45:21.613 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:31.293 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-23 18:00:31.293 | Triggering next historical data download in queue.
2024-09-23 18:00:31.294 | HD Request # 51 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:31.295 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-23 18:00:31.295 | Triggering next historical data download in queue.
2024-09-23 18:00:31.295 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-23 18:00:31.295 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-23 18:00:32.334 | HD Request # 51 | Requesting historical Daily data for ESZ24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:33.227 | HD Request # 51 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-19.
2024-09-23 18:00:33.228 | HD Request # 51 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-23 18:00:33.230 | HD Request # 51 | Bytes received: 233
2024-09-23 18:00:33.230 | HD Request # 51 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for ESZ4.CME
2024-09-23 18:00:33.230 | HD Request # 51 | Completion time: 2s.
2024-09-23 18:00:33.230 | HD Request # 51 | Daily data download complete for ESZ4.CME. Unique request ID: 51
2024-09-23 18:00:33.231 | Removing historical data download ID 51.
2024-09-23 18:00:33.231 | Triggering next historical data download in queue.
2024-09-23 18:00:33.231 | HD Request # 52 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:33.569 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:33.569 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:33.569 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:33.902 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-23 18:00:33.902 | Triggering next historical data download in queue.
2024-09-23 18:00:33.903 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-23 18:00:33.903 | Triggering next historical data download in queue.
2024-09-23 18:00:33.955 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:33.956 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:33.956 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:33.956 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:34.286 | HD Request # 52 | Requesting historical Daily data for A6Z24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:34.302 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:34.302 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:34.302 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:34.645 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:34.700 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:35.233 | HD Request # 52 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-19.
2024-09-23 18:00:35.234 | HD Request # 52 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-23 18:00:35.238 | HD Request # 52 | Bytes received: 242
2024-09-23 18:00:35.238 | HD Request # 52 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for 6AZ4.CME
2024-09-23 18:00:35.238 | HD Request # 52 | Completion time: 2s.
2024-09-23 18:00:35.238 | HD Request # 52 | Daily data download complete for 6AZ4.CME. Unique request ID: 52
2024-09-23 18:00:35.238 | Removing historical data download ID 52.
2024-09-23 18:00:35.239 |
2024-09-23 18:00:35.239 | Triggering next historical data download in queue.
2024-09-23 18:00:35.239 | HD Request # 53 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:35.379 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:35.379 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:35.379 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:36.088 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:36.088 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:36.088 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:36.834 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:36.834 | HD Request # 53 | Requesting historical Daily data for NQZ24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:36.964 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:37.169 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:37.169 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:37.169 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:37.882 | HD Request # 53 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-19.
2024-09-23 18:00:37.882 | HD Request # 53 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-23 18:00:37.885 | HD Request # 53 | Bytes received: 237
2024-09-23 18:00:37.885 | HD Request # 53 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for NQZ4.CME
2024-09-23 18:00:37.885 | HD Request # 53 | Completion time: 2s.
2024-09-23 18:00:37.885 | HD Request # 53 | Daily data download complete for NQZ4.CME. Unique request ID: 53
2024-09-23 18:00:37.885 | Removing historical data download ID 53.
2024-09-23 18:00:37.885 | Triggering next historical data download in queue.
2024-09-23 18:00:37.886 | HD Request # 54 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:38.019 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:38.402 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:38.402 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:38.402 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:38.701 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:38.701 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:38.701 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:39.013 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:39.013 | HD Request # 54 | Requesting historical Daily data for GCZ24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:39.070 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:39.071 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:39.071 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:39.071 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:39.419 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:39.968 | HD Request # 54 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-19.
2024-09-23 18:00:39.969 | HD Request # 54 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-23 18:00:39.973 | HD Request # 54 | Bytes received: 232
2024-09-23 18:00:39.973 | HD Request # 54 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-23 18:00:39.973 | HD Request # 54 | Completion time: 2s.
2024-09-23 18:00:39.973 | HD Request # 54 | Daily data download complete for GCZ4.COMEX. Unique request ID: 54
2024-09-23 18:00:39.973 | Removing historical data download ID 54.
2024-09-23 18:00:39.973 | Triggering next historical data download in queue.
2024-09-23 18:00:39.974 | HD Request # 55 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:40.113 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:40.113 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:40.113 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:40.753 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:40.753 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:40.753 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:41.421 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:41.422 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:41.422 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:41.422 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:42.085 | HD Request # 55 | Requesting historical Daily data for J6Z24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:42.087 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:42.209 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:43.021 | HD Request # 55 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-19.
2024-09-23 18:00:43.021 | HD Request # 55 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-23 18:00:43.026 | HD Request # 55 | Bytes received: 273
2024-09-23 18:00:43.026 | HD Request # 55 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for 6JZ4.CME
2024-09-23 18:00:43.026 | HD Request # 55 | Completion time: 4s.
2024-09-23 18:00:43.026 | HD Request # 55 | Daily data download complete for 6JZ4.CME. Unique request ID: 55
2024-09-23 18:00:43.026 | Removing historical data download ID 55.
2024-09-23 18:00:43.026 | Triggering next historical data download in queue.
2024-09-23 18:00:43.027 | HD Request # 56 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-23 18:00:43.386 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:43.386 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:43.386 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:44.099 | HD Request # 56 | Requesting historical Daily data for CLX24 starting at 2024-09-18. SC External HD service.
2024-09-23 18:00:44.100 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:44.100 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:44.100 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:44.842 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:00:44.895 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:44.895 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:44.895 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:45.625 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:45.625 | HD Request # 56 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-19.
2024-09-23 18:00:45.625 | HD Request # 56 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-23 18:00:45.633 | HD Request # 56 | Bytes received: 217
2024-09-23 18:00:45.633 | HD Request # 56 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-23 18:00:45.633 | HD Request # 56 | Completion time: 2s.
2024-09-23 18:00:45.633 | HD Request # 56 | Daily data download complete for CLX4.NYMEX. Unique request ID: 56
2024-09-23 18:00:45.633 | Removing historical data download ID 56.
2024-09-23 18:00:45.633 | No download requests in the queue to start downloads for.
2024-09-23 18:00:45.923 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:45.924 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-23 18:00:45.924 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:45.924 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:48.492 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-23 18:00:48.657 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-23 18:00:48.657 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:48.657 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:50.785 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-23 18:00:50.785 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:50.785 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-23 18:00:53.022 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-23 18:00:53.477 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-23 18:09:15.575 | Chat | Message response. Chat ID: 429. Request ID: 1134626498
2024-09-23 19:25:38.691 | Chat | Message response. Chat ID: 429. Request ID: 1134626499
2024-09-23 19:41:19.295 | SC Data with Depth | Message from server: Authorization data verified.
2024-09-23 20:37:05.538 | Chat | Message response. Chat ID: 429. Request ID: 1134626500
2024-09-23 21:03:57.849 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-23 21:03:57.849 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-23 21:03:57.850 | DTC Client socket (2) | CloseSocket call.
2024-09-23 21:03:57.850 | DTC Client socket (2) | Max send buffers used during socket life: 4
2024-09-23 21:03:57.850 | DTC Client socket (2) | Max send buffer size during socket life: 407
2024-09-23 21:03:57.850 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-23 21:03:57.850 | DTC Client socket (2) | Closed.
2024-09-23 21:03:57.850 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-23 21:03:57.850 | DTC Client socket (0) | CloseSocket call.
2024-09-23 21:03:57.850 | Denali Data Feed | Disconnected from the server.
2024-09-23 21:03:57.850 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-23 21:04:00.837 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-23 21:04:00.960 | DTC Client socket (2) | Creating socket.
2024-09-23 21:04:00.960 | DTC Client socket (2) | New receive buffer size: 0
2024-09-23 21:04:00.960 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-23 21:04:16.147 | Denali Data Feed | Network connection to server complete.
2024-09-23 21:04:16.147 | Denali Data Feed | Starting socket receive thread.
2024-09-23 21:04:16.147 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-23 21:04:16.328 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-23 21:04:16.328 | Denali Data Feed | Sending logon request message.
2024-09-23 21:04:27.658 | Denali Data Feed | Received logon response.
2024-09-23 21:04:27.658 | Denali Data Feed | Server Name: RealTimeServer.
2024-09-23 21:04:27.658 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-23 21:04:27.658 | Denali Data Feed | Logon error received from server: Timed out while checking for maximum connections.
2024-09-23 21:04:27.658 | Denali Data Feed | Failed connections: 1
2024-09-23 21:04:27.658 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-23 21:04:27.658 | DTC Client socket (2) | CloseSocket call.
2024-09-23 21:04:27.658 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:27.658 | Denali Data Feed | Disconnected from the server.
2024-09-23 21:04:27.658 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-23 21:04:27.812 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-23 21:04:27.812 | DTC Client socket (2) | Closed.
2024-09-23 21:04:30.655 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-23 21:04:30.655 | DTC Client socket (2) | Creating socket.
2024-09-23 21:04:30.655 | DTC Client socket (2) | New receive buffer size: 0
2024-09-23 21:04:30.655 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-23 21:04:30.809 | Denali Data Feed | Network connection to server complete.
2024-09-23 21:04:30.809 | Denali Data Feed | Starting socket receive thread.
2024-09-23 21:04:30.809 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-23 21:04:31.005 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-23 21:04:31.005 | Denali Data Feed | Sending logon request message.
2024-09-23 21:04:31.676 | Denali Data Feed | Received logon response.
2024-09-23 21:04:31.676 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-23 21:04:31.676 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-23 21:04:31.676 | Denali Data Feed | Successfully connected.
2024-09-23 21:04:31.676 | Denali Data Feed | Trading is not supported.
2024-09-23 21:04:31.676 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-23 21:04:31.676 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Triggering next historical data download in queue.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: 6AZ4.CME -> 6AZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: 6JZ4.CME -> 6JZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: CLX4.NYMEX -> CLX24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ4.CME -> ESZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: M6AZ4.CME -> M6AZ24
2024-09-23 21:04:31.676 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MCLU4.NYMEX -> MCLU24
2024-09-23 21:04:31.676 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ4.CME -> MESZ24. Market Depth data restarted.
2024-09-23 21:04:31.676 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MGCZ4.COMEX -> MGCZ24
2024-09-23 21:04:31.676 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-23 21:04:31.676 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MJYZ4.CME -> MJYZ24
2024-09-23 21:04:31.676 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-23 21:04:31.677 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-23 21:04:31.677 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.677 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ4.CME -> MNQZ24. Market Depth data restarted.
2024-09-23 21:04:31.677 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-23 21:04:31.677 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-23 21:04:31.677 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2024-09-23 21:04:31.677 | HD Request # 57 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-23 21:04:31.677 | HD Request # 57 | Download start date-time: 2024-09-23 21:03:31.000000. File last date-time: 2024-09-23 21:03:31.240004
2024-09-23 21:04:31.677 | HD Request # 57 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:31.819 | Socket (5) | Creating socket.
2024-09-23 21:04:31.819 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:31.819 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-23 21:04:32.331 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-23 21:04:32.332 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-23 21:04:32.385 | HD Request # 57 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:32.385 | HD Request # 57 | Sending historical data logon request message.
2024-09-23 21:04:33.164 | HD Request # 57 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:31. Record interval: 0. Symbol: 6AZ24
2024-09-23 21:04:33.443 | HD Request # 57 | Decompressing data.
2024-09-23 21:04:33.721 | HD Request # 57 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-23 21:03:31.240000
2024-09-23 21:04:33.722 | Socket (5) | CloseSocket call.
2024-09-23 21:04:33.722 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:33.723 | Historical data download thread signaled to stop.
2024-09-23 21:04:33.723 | HD Request # 57 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:45.441000.
2024-09-23 21:04:33.723 | HD Request # 57 | Received 12 Intraday data records from 2024-09-23 21:03:31.240000 to 2024-09-23 21:04:33.084001 (61.8 seconds. Delay: 0.6 seconds) and wrote 7 records for 6AZ4.CME
2024-09-23 21:04:33.723 | HD Request # 57 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:33.084001
2024-09-23 21:04:33.723 | HD Request # 57 | Completion time: 2s.
2024-09-23 21:04:33.723 | HD Request # 57 | Intraday data download complete for 6AZ4.CME. Unique request ID: 57
2024-09-23 21:04:33.723 | Removing historical data download ID 57.
2024-09-23 21:04:33.723 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-23 21:04:33.723 | Intraday chart data file opened for 6AZ4.CME
2024-09-23 21:04:33.723 | HD Request # 57 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:33.723 | Triggering next historical data download in queue.
2024-09-23 21:04:33.723 | HD Request # 58 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-23 21:04:33.724 | HD Request # 58 | Download start date-time: 2024-09-23 21:03:31.000000. File last date-time: 2024-09-23 21:03:31.473000
2024-09-23 21:04:33.724 | HD Request # 58 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:33.724 | Socket (6) | Creating socket.
2024-09-23 21:04:33.724 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:33.724 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:34.001 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:34.001 | Socket (5) | Closed.
2024-09-23 21:04:34.278 | HD Request # 58 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:34.278 | HD Request # 58 | Sending historical data logon request message.
2024-09-23 21:04:35.041 | HD Request # 58 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:31. Record interval: 0. Symbol: 6JZ24
2024-09-23 21:04:35.315 | HD Request # 58 | Decompressing data.
2024-09-23 21:04:35.587 | HD Request # 58 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-23 21:03:31.473000
2024-09-23 21:04:35.588 | Socket (6) | CloseSocket call.
2024-09-23 21:04:35.588 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:35.597 | Historical data download thread signaled to stop.
2024-09-23 21:04:35.597 | HD Request # 58 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:34.091000.
2024-09-23 21:04:35.597 | HD Request # 58 | Received 31 Intraday data records from 2024-09-23 21:03:31.473000 to 2024-09-23 21:04:31.434000 (60.0 seconds. Delay: 4.2 seconds) and wrote 30 records for 6JZ4.CME
2024-09-23 21:04:35.598 | HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:31.434000
2024-09-23 21:04:35.598 | HD Request # 58 | Completion time: 2s.
2024-09-23 21:04:35.598 | HD Request # 58 | Intraday data download complete for 6JZ4.CME. Unique request ID: 58
2024-09-23 21:04:35.598 | Removing historical data download ID 58.
2024-09-23 21:04:35.598 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-23 21:04:35.598 | Intraday chart data file opened for 6JZ4.CME
2024-09-23 21:04:35.598 | HD Request # 58 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:35.598 | Triggering next historical data download in queue.
2024-09-23 21:04:35.598 | HD Request # 59 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-23 21:04:35.598 | HD Request # 59 | Download start date-time: 2024-09-23 21:03:33.000000. File last date-time: 2024-09-23 21:03:33.303001
2024-09-23 21:04:35.598 | HD Request # 59 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:35.598 | Socket (5) | Creating socket.
2024-09-23 21:04:35.598 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:35.598 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:35.861 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:35.861 | Socket (6) | Closed.
2024-09-23 21:04:36.163 | HD Request # 59 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:36.163 | HD Request # 59 | Sending historical data logon request message.
2024-09-23 21:04:36.441 | HD Request # 59 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:33. Record interval: 0. Symbol: CLX24
2024-09-23 21:04:36.720 | HD Request # 59 | Decompressing data.
2024-09-23 21:04:36.998 | HD Request # 59 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-23 21:03:33.303000
2024-09-23 21:04:36.998 | Socket (5) | CloseSocket call.
2024-09-23 21:04:36.998 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:36.998 | Historical data download thread signaled to stop.
2024-09-23 21:04:36.998 | HD Request # 59 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:33.854000.
2024-09-23 21:04:36.998 | HD Request # 59 | Received 45 Intraday data records from 2024-09-23 21:03:33.303000 to 2024-09-23 21:04:35.184000 (61.9 seconds. Delay: 1.8 seconds) and wrote 43 records for CLX4.NYMEX
2024-09-23 21:04:36.999 | HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:35.184000
2024-09-23 21:04:36.999 | HD Request # 59 | Completion time: 1s.
2024-09-23 21:04:36.999 | HD Request # 59 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 59
2024-09-23 21:04:36.999 | Removing historical data download ID 59.
2024-09-23 21:04:36.999 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-23 21:04:36.999 | Intraday chart data file opened for CLX4.NYMEX
2024-09-23 21:04:36.999 | HD Request # 59 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:36.999 | Triggering next historical data download in queue.
2024-09-23 21:04:36.999 | HD Request # 60 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-23 21:04:37.000 | HD Request # 60 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-23 21:04:37.000 | HD Request # 60 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:37.000 | Socket (6) | Creating socket.
2024-09-23 21:04:37.000 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:37.000 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:37.276 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:37.276 | Socket (5) | Closed.
2024-09-23 21:04:37.571 | HD Request # 60 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:37.571 | HD Request # 60 | Sending historical data logon request message.
2024-09-23 21:04:37.852 | HD Request # 60 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-23 21:04:38.133 | HD Request # 60 | Decompressing data.
2024-09-23 21:04:38.414 | HD Request # 60 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-23 21:04:38.414 | Socket (6) | CloseSocket call.
2024-09-23 21:04:38.414 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:38.430 | Historical data download thread signaled to stop.
2024-09-23 21:04:38.430 | HD Request # 60 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 3.5 days) and wrote 0 records for ESU4.CME
2024-09-23 21:04:38.430 | HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-23 21:04:38.430 | HD Request # 60 | Completion time: 2s.
2024-09-23 21:04:38.430 | HD Request # 60 | Intraday data download complete for ESU4.CME. Unique request ID: 60
2024-09-23 21:04:38.430 | Removing historical data download ID 60.
2024-09-23 21:04:38.430 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-23 21:04:38.430 | Intraday chart data file opened for ESU4.CME
2024-09-23 21:04:38.430 | HD Request # 60 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:38.430 | Triggering next historical data download in queue.
2024-09-23 21:04:38.430 | HD Request # 61 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-23 21:04:38.430 | HD Request # 61 | Download start date-time: 2024-09-23 21:03:32.000000. File last date-time: 2024-09-23 21:03:32.925000
2024-09-23 21:04:38.430 | HD Request # 61 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:38.430 | Socket (5) | Creating socket.
2024-09-23 21:04:38.430 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:38.430 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:38.462 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\CLX4.NYMEX.scid. Thread ID: 3296
2024-09-23 21:04:38.694 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:38.694 | Socket (6) | Closed.
2024-09-23 21:04:38.986 | HD Request # 61 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:38.986 | HD Request # 61 | Sending historical data logon request message.
2024-09-23 21:04:39.257 | HD Request # 61 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:32. Record interval: 0. Symbol: ESZ24
2024-09-23 21:04:39.529 | HD Request # 61 | Decompressing data.
2024-09-23 21:04:39.801 | HD Request # 61 | Receiving Intraday data for ESZ4.CME starting at 2024-09-23 21:03:32.925000
2024-09-23 21:04:39.801 | Socket (5) | CloseSocket call.
2024-09-23 21:04:39.801 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:39.806 | Historical data download thread signaled to stop.
2024-09-23 21:04:39.807 | HD Request # 61 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:37.095000.
2024-09-23 21:04:39.807 | HD Request # 61 | Received 50 Intraday data records from 2024-09-23 21:03:32.925000 to 2024-09-23 21:04:31.857001 (58.9 seconds. Delay: 8.0 seconds) and wrote 49 records for ESZ4.CME
2024-09-23 21:04:39.807 | HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:31.857001
2024-09-23 21:04:39.807 | Added 2 Time and Sales records to Intraday data file for ESZ4.CME after download.
2024-09-23 21:04:39.807 | HD Request # 61 | Completion time: 1s.
2024-09-23 21:04:39.807 | HD Request # 61 | Intraday data download complete for ESZ4.CME. Unique request ID: 61
2024-09-23 21:04:39.807 | Removing historical data download ID 61.
2024-09-23 21:04:39.807 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-23 21:04:39.807 | Intraday chart data file opened for ESZ4.CME
2024-09-23 21:04:39.807 | HD Request # 61 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:39.807 | Triggering next historical data download in queue.
2024-09-23 21:04:39.807 | HD Request # 62 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-23 21:04:39.807 | HD Request # 62 | Download start date-time: 2024-09-23 21:03:30.000000. File last date-time: 2024-09-23 21:03:30.568001
2024-09-23 21:04:39.807 | HD Request # 62 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:39.807 | Socket (6) | Creating socket.
2024-09-23 21:04:39.807 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:39.807 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:40.073 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:40.073 | Socket (5) | Closed.
2024-09-23 21:04:40.363 | HD Request # 62 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:40.363 | HD Request # 62 | Sending historical data logon request message.
2024-09-23 21:04:40.636 | HD Request # 62 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:30. Record interval: 0. Symbol: GCZ24
2024-09-23 21:04:40.909 | HD Request # 62 | Decompressing data.
2024-09-23 21:04:41.182 | HD Request # 62 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-23 21:03:30.568000
2024-09-23 21:04:41.183 | Socket (6) | CloseSocket call.
2024-09-23 21:04:41.183 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:41.246 | Historical data download thread signaled to stop.
2024-09-23 21:04:41.246 | HD Request # 62 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:36.132000.
2024-09-23 21:04:41.246 | HD Request # 62 | Received 46 Intraday data records from 2024-09-23 21:03:30.568000 to 2024-09-23 21:04:31.896000 (61.3 seconds. Delay: 9.4 seconds) and wrote 44 records for GCZ4.COMEX
2024-09-23 21:04:41.247 | HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:31.896000
2024-09-23 21:04:41.247 | HD Request # 62 | Completion time: 2s.
2024-09-23 21:04:41.247 | HD Request # 62 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 62
2024-09-23 21:04:41.247 | Removing historical data download ID 62.
2024-09-23 21:04:41.247 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-23 21:04:41.247 | Intraday chart data file opened for GCZ4.COMEX
2024-09-23 21:04:41.247 | HD Request # 62 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:41.247 | Triggering next historical data download in queue.
2024-09-23 21:04:41.247 | HD Request # 63 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-23 21:04:41.247 | HD Request # 63 | Download start date-time: 2024-09-23 21:03:10.000000. File last date-time: 2024-09-23 21:03:10.277001
2024-09-23 21:04:41.247 | HD Request # 63 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:41.247 | Socket (5) | Creating socket.
2024-09-23 21:04:41.247 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:41.247 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:41.455 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:41.455 | Socket (6) | Closed.
2024-09-23 21:04:41.804 | HD Request # 63 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:41.804 | HD Request # 63 | Sending historical data logon request message.
2024-09-23 21:04:42.078 | HD Request # 63 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:10. Record interval: 0. Symbol: M6AZ24
2024-09-23 21:04:42.351 | HD Request # 63 | Decompressing data.
2024-09-23 21:04:42.624 | HD Request # 63 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-23 21:03:10.277000
2024-09-23 21:04:42.625 | Socket (5) | CloseSocket call.
2024-09-23 21:04:42.625 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:42.625 | Historical data download thread signaled to stop.
2024-09-23 21:04:42.625 | HD Request # 63 | Timestamp of first Intraday data file record written: 2024-09-23 21:04:19.280000.
2024-09-23 21:04:42.625 | HD Request # 63 | Received 3 Intraday data records from 2024-09-23 21:03:10.277000 to 2024-09-23 21:04:19.280000 (69.0 seconds. Delay: 23.3 seconds) and wrote 1 record for M6AZ4.CME
2024-09-23 21:04:42.626 | HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:19.280000
2024-09-23 21:04:42.626 | HD Request # 63 | Completion time: 1s.
2024-09-23 21:04:42.626 | HD Request # 63 | Intraday data download complete for M6AZ4.CME. Unique request ID: 63
2024-09-23 21:04:42.626 | Removing historical data download ID 63.
2024-09-23 21:04:42.626 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-23 21:04:42.626 | Intraday chart data file opened for M6AZ4.CME
2024-09-23 21:04:42.626 | HD Request # 63 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:42.626 | Triggering next historical data download in queue.
2024-09-23 21:04:42.626 | HD Request # 64 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-23 21:04:42.626 | HD Request # 64 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-23 21:04:42.626 | HD Request # 64 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:42.626 | Socket (6) | Creating socket.
2024-09-23 21:04:42.626 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:42.626 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:42.898 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:42.898 | Socket (5) | Closed.
2024-09-23 21:04:43.176 | HD Request # 64 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:43.176 | HD Request # 64 | Sending historical data logon request message.
2024-09-23 21:04:43.449 | HD Request # 64 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-23 21:04:43.526 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:43.526 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCZ4.COMEX.scid. Thread ID: 3296
2024-09-23 21:04:43.721 | HD Request # 64 | Decompressing data.
2024-09-23 21:04:43.993 | HD Request # 64 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-23 21:04:43.993 | Socket (6) | CloseSocket call.
2024-09-23 21:04:43.993 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:44.167 | Historical data download thread signaled to stop.
2024-09-23 21:04:44.167 | HD Request # 64 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 35.3 days) and wrote 0 records for MCLU4.NYMEX
2024-09-23 21:04:44.168 | HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-23 21:04:44.168 | HD Request # 64 | Completion time: 2s.
2024-09-23 21:04:44.168 | HD Request # 64 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 64
2024-09-23 21:04:44.168 | Removing historical data download ID 64.
2024-09-23 21:04:44.168 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-23 21:04:44.168 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-23 21:04:44.168 | HD Request # 64 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:44.168 | Triggering next historical data download in queue.
2024-09-23 21:04:44.168 | HD Request # 65 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-23 21:04:44.168 | HD Request # 65 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-23 21:04:44.168 | HD Request # 65 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:44.168 | Socket (5) | Creating socket.
2024-09-23 21:04:44.168 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:44.168 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:44.264 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:44.265 | Socket (6) | Closed.
2024-09-23 21:04:44.725 | HD Request # 65 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:44.725 | HD Request # 65 | Sending historical data logon request message.
2024-09-23 21:04:44.997 | HD Request # 65 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-23 21:04:45.269 | HD Request # 65 | Decompressing data.
2024-09-23 21:04:45.540 | HD Request # 65 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-23 21:04:45.540 | Socket (5) | CloseSocket call.
2024-09-23 21:04:45.541 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:45.557 | Historical data download thread signaled to stop.
2024-09-23 21:04:45.557 | HD Request # 65 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 3.5 days) and wrote 0 records for MESU4.CME
2024-09-23 21:04:45.557 | HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-23 21:04:45.557 | HD Request # 65 | Completion time: 1s.
2024-09-23 21:04:45.557 | HD Request # 65 | Intraday data download complete for MESU4.CME. Unique request ID: 65
2024-09-23 21:04:45.557 | Removing historical data download ID 65.
2024-09-23 21:04:45.557 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-23 21:04:45.557 | Intraday chart data file opened for MESU4.CME
2024-09-23 21:04:45.557 | HD Request # 65 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:45.557 | Triggering next historical data download in queue.
2024-09-23 21:04:45.557 | HD Request # 66 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-23 21:04:45.557 | HD Request # 66 | Download start date-time: 2024-09-23 21:03:31.000000. File last date-time: 2024-09-23 21:03:31.368002
2024-09-23 21:04:45.557 | HD Request # 66 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:45.557 | Socket (6) | Creating socket.
2024-09-23 21:04:45.557 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:45.557 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:45.813 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:45.813 | Socket (5) | Closed.
2024-09-23 21:04:46.110 | HD Request # 66 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:46.110 | HD Request # 66 | Sending historical data logon request message.
2024-09-23 21:04:46.380 | HD Request # 66 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:31. Record interval: 0. Symbol: MESZ24
2024-09-23 21:04:46.652 | HD Request # 66 | Decompressing data.
2024-09-23 21:04:46.922 | HD Request # 66 | Receiving Intraday data for MESZ4.CME starting at 2024-09-23 21:03:31.368000
2024-09-23 21:04:46.923 | Socket (6) | CloseSocket call.
2024-09-23 21:04:46.923 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:46.928 | Historical data download thread signaled to stop.
2024-09-23 21:04:46.928 | HD Request # 66 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:34.258000.
2024-09-23 21:04:46.928 | HD Request # 66 | Received 72 Intraday data records from 2024-09-23 21:03:31.368000 to 2024-09-23 21:04:44.104000 (72.7 seconds. Delay: 2.8 seconds) and wrote 69 records for MESZ4.CME
2024-09-23 21:04:46.928 | HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:44.104000
2024-09-23 21:04:46.928 | Added 1 Time and Sales records to Intraday data file for MESZ4.CME after download.
2024-09-23 21:04:46.928 | HD Request # 66 | Completion time: 1s.
2024-09-23 21:04:46.928 | HD Request # 66 | Intraday data download complete for MESZ4.CME. Unique request ID: 66
2024-09-23 21:04:46.928 | Removing historical data download ID 66.
2024-09-23 21:04:46.928 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-23 21:04:46.928 | Intraday chart data file opened for MESZ4.CME
2024-09-23 21:04:46.928 | HD Request # 66 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:46.928 | Triggering next historical data download in queue.
2024-09-23 21:04:46.928 | HD Request # 67 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-23 21:04:46.929 | HD Request # 67 | Download start date-time: 2024-09-23 21:03:30.000000. File last date-time: 2024-09-23 21:03:30.568004
2024-09-23 21:04:46.929 | HD Request # 67 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:46.929 | Socket (5) | Creating socket.
2024-09-23 21:04:46.929 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:46.929 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:47.195 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:47.195 | Socket (6) | Closed.
2024-09-23 21:04:47.477 | HD Request # 67 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:47.477 | HD Request # 67 | Sending historical data logon request message.
2024-09-23 21:04:47.746 | HD Request # 67 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:30. Record interval: 0. Symbol: MGCZ24
2024-09-23 21:04:48.015 | HD Request # 67 | Decompressing data.
2024-09-23 21:04:48.283 | HD Request # 67 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-23 21:03:30.568000
2024-09-23 21:04:48.284 | Socket (5) | CloseSocket call.
2024-09-23 21:04:48.284 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:48.306 | Historical data download thread signaled to stop.
2024-09-23 21:04:48.306 | HD Request # 67 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:36.132000.
2024-09-23 21:04:48.306 | HD Request # 67 | Received 42 Intraday data records from 2024-09-23 21:03:30.568000 to 2024-09-23 21:04:43.822000 (73.3 seconds. Delay: 4.5 seconds) and wrote 37 records for MGCZ4.COMEX
2024-09-23 21:04:48.307 | HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:43.822000
2024-09-23 21:04:48.307 | Added 1 Time and Sales records to Intraday data file for MGCZ4.COMEX after download.
2024-09-23 21:04:48.307 | HD Request # 67 | Completion time: 2s.
2024-09-23 21:04:48.307 | HD Request # 67 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 67
2024-09-23 21:04:48.307 | Removing historical data download ID 67.
2024-09-23 21:04:48.307 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-23 21:04:48.307 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-23 21:04:48.307 | HD Request # 67 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:48.307 | Triggering next historical data download in queue.
2024-09-23 21:04:48.307 | HD Request # 68 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-23 21:04:48.307 | HD Request # 68 | Download start date-time: 2024-09-23 21:01:51.000000. File last date-time: 2024-09-23 21:01:51.459000
2024-09-23 21:04:48.307 | HD Request # 68 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:48.307 | Socket (6) | Creating socket.
2024-09-23 21:04:48.307 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:48.307 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:48.552 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:48.553 | Socket (5) | Closed.
2024-09-23 21:04:48.574 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:48.574 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:48.574 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:48.575 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6JZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:48.862 | HD Request # 68 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:48.862 | HD Request # 68 | Sending historical data logon request message.
2024-09-23 21:04:49.136 | HD Request # 68 | Requesting Intraday data. Start date-time: 2024-09-23 21:01:51. Record interval: 0. Symbol: MJYZ24
2024-09-23 21:04:49.411 | HD Request # 68 | Decompressing data.
2024-09-23 21:04:49.684 | HD Request # 68 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-23 21:01:51.459000
2024-09-23 21:04:49.685 | Socket (6) | CloseSocket call.
2024-09-23 21:04:49.685 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:49.691 | Historical data download thread signaled to stop.
2024-09-23 21:04:49.692 | HD Request # 68 | Received 1 Intraday data record from 2024-09-23 21:01:51.459000 to 2024-09-23 21:01:51.459000 (0.0 seconds. Delay: 3.0 minutes) and wrote 0 records for MJYZ4.CME
2024-09-23 21:04:49.692 | HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:01:51.459000
2024-09-23 21:04:49.692 | HD Request # 68 | Completion time: 1s.
2024-09-23 21:04:49.692 | HD Request # 68 | Intraday data download complete for MJYZ4.CME. Unique request ID: 68
2024-09-23 21:04:49.692 | Removing historical data download ID 68.
2024-09-23 21:04:49.692 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-23 21:04:49.692 | Intraday chart data file opened for MJYZ4.CME
2024-09-23 21:04:49.692 | HD Request # 68 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:49.692 | Triggering next historical data download in queue.
2024-09-23 21:04:49.692 | HD Request # 69 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-23 21:04:49.692 | HD Request # 69 | Download start date-time: 2024-09-23 21:03:33.000000. File last date-time: 2024-09-23 21:03:33.771000
2024-09-23 21:04:49.692 | HD Request # 69 | Using server: ds32.sierracharts.com port 10149
2024-09-23 21:04:49.692 | Socket (5) | Creating socket.
2024-09-23 21:04:49.692 | Socket (5) | New receive buffer size: 0
2024-09-23 21:04:49.692 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:49.959 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:49.959 | Socket (6) | Closed.
2024-09-23 21:04:50.246 | HD Request # 69 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:50.246 | HD Request # 69 | Sending historical data logon request message.
2024-09-23 21:04:50.517 | HD Request # 69 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:33. Record interval: 0. Symbol: MNQZ24
2024-09-23 21:04:50.788 | HD Request # 69 | Decompressing data.
2024-09-23 21:04:51.059 | HD Request # 69 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-23 21:03:33.065000
2024-09-23 21:04:51.060 | Socket (5) | CloseSocket call.
2024-09-23 21:04:51.060 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:51.156 | Historical data download thread signaled to stop.
2024-09-23 21:04:51.156 | HD Request # 69 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:34.958000.
2024-09-23 21:04:51.156 | HD Request # 69 | Received 235 Intraday data records from 2024-09-23 21:03:33.065000 to 2024-09-23 21:04:48.829000 (75.8 seconds. Delay: 2.3 seconds) and wrote 233 records for MNQZ4.CME
2024-09-23 21:04:51.156 | HD Request # 69 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:48.829000
2024-09-23 21:04:51.156 | Added 68 Time and Sales records to Intraday data file for MNQZ4.CME after download.
2024-09-23 21:04:51.157 | HD Request # 69 | Completion time: 2s.
2024-09-23 21:04:51.157 | HD Request # 69 | Intraday data download complete for MNQZ4.CME. Unique request ID: 69
2024-09-23 21:04:51.157 | Removing historical data download ID 69.
2024-09-23 21:04:51.157 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-23 21:04:51.157 | Intraday chart data file opened for MNQZ4.CME
2024-09-23 21:04:51.157 | HD Request # 69 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:51.157 | Triggering next historical data download in queue.
2024-09-23 21:04:51.157 | HD Request # 70 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-23 21:04:51.157 | HD Request # 70 | Download start date-time: 2024-09-23 21:03:32.000000. File last date-time: 2024-09-23 21:03:32.830000
2024-09-23 21:04:51.157 | HD Request # 70 | Using server: ds32.sierracharts.com port 10150
2024-09-23 21:04:51.157 | Socket (6) | Creating socket.
2024-09-23 21:04:51.157 | Socket (6) | New receive buffer size: 0
2024-09-23 21:04:51.157 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-23 21:04:51.330 | Socket (5) | Socket gracefully closed by remote side.
2024-09-23 21:04:51.330 | Socket (5) | Closed.
2024-09-23 21:04:51.706 | HD Request # 70 | Setting DTC encoding to Binary VLS
2024-09-23 21:04:51.706 | HD Request # 70 | Sending historical data logon request message.
2024-09-23 21:04:51.981 | HD Request # 70 | Requesting Intraday data. Start date-time: 2024-09-23 21:03:32. Record interval: 0. Symbol: NQZ24
2024-09-23 21:04:52.250 | HD Request # 70 | Decompressing data.
2024-09-23 21:04:52.520 | HD Request # 70 | Receiving Intraday data for NQZ4.CME starting at 2024-09-23 21:03:32.830000
2024-09-23 21:04:52.520 | Socket (6) | CloseSocket call.
2024-09-23 21:04:52.521 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-23 21:04:52.677 | Historical data download thread signaled to stop.
2024-09-23 21:04:52.677 | HD Request # 70 | Timestamp of first Intraday data file record written: 2024-09-23 21:03:36.051000.
2024-09-23 21:04:52.678 | HD Request # 70 | Received 71 Intraday data records from 2024-09-23 21:03:32.830000 to 2024-09-23 21:04:48.829000 (76.0 seconds. Delay: 3.8 seconds) and wrote 70 records for NQZ4.CME
2024-09-23 21:04:52.678 | HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2024-09-24 01:04:48.829000
2024-09-23 21:04:52.678 | Added 14 Time and Sales records to Intraday data file for NQZ4.CME after download.
2024-09-23 21:04:52.678 | HD Request # 70 | Completion time: 1s.
2024-09-23 21:04:52.678 | HD Request # 70 | Intraday data download complete for NQZ4.CME. Unique request ID: 70
2024-09-23 21:04:52.678 | Removing historical data download ID 70.
2024-09-23 21:04:52.678 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-23 21:04:52.678 | Intraday chart data file opened for NQZ4.CME
2024-09-23 21:04:52.678 | HD Request # 70 | Enabling Intraday chart updating for symbol.
2024-09-23 21:04:52.678 | No download requests in the queue to start downloads for.
2024-09-23 21:04:52.790 | Socket (6) | Socket gracefully closed by remote side.
2024-09-23 21:04:52.790 | Socket (6) | Closed.
2024-09-23 21:04:53.619 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:53.619 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-23 21:04:53.620 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-23 21:12:07.367 | Chat | Message response. Chat ID: 429. Request ID: 1134626501
2024-09-23 21:12:38.651 | Chat | Message response. Chat ID: 429. Request ID: 1134626502
2024-09-23 21:16:39.836 | Chat | Message response. Chat ID: 429. Request ID: 1134626503
2024-09-23 21:20:40.943 | Chat | Message response. Chat ID: 429. Request ID: 1134626504
2024-09-23 21:31:05.900 | Chat | Message response. Chat ID: 429. Request ID: 1134626505
2024-09-23 22:00:04.395 | Chat | Message response. Chat ID: 429. Request ID: 1134626506
2024-09-23 22:09:24.949 | Chat | Message response. Chat ID: 429. Request ID: 1134626507
2024-09-23 22:10:29.261 | Chat | Message response. Chat ID: 429. Request ID: 1134626508
2024-09-23 22:22:12.330 | Chat | Message response. Chat ID: 429. Request ID: 1134626509
2024-09-23 22:24:42.410 | Chat | Message response. Chat ID: 429. Request ID: 1134626510
2024-09-23 22:25:01.284 | Chat | Message response. Chat ID: 429. Request ID: 1134626511
2024-09-23 22:25:43.343 | Chat | Message response. Chat ID: 429. Request ID: 1134626512
2024-09-23 22:25:52.168 | Chat | Message response. Chat ID: 429. Request ID: 1134626513
2024-09-23 22:25:54.699 | Chat | Message response. Chat ID: 429. Request ID: 1134626514
2024-09-23 22:38:57.929 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MJYZ4.CME.scid. Thread ID: 3296
2024-09-23 22:41:39.435 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Creating socket. Using TLS 1.2.
2024-09-23 22:41:39.435 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | New receive buffer size: 0
2024-09-23 22:41:39.435 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Connecting to IP: 216.66.0.130.
2024-09-23 22:41:41.304 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | CloseSocket call.
2024-09-23 22:41:41.304 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Shutdown started. Waiting for graceful close.
2024-09-23 22:41:41.557 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Socket gracefully closed by remote side.
2024-09-23 22:41:41.557 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (5) | Closed.
2024-09-23 22:48:03.530 | Chat | Message response. Chat ID: 429. Request ID: 1134626515
2024-09-23 23:00:00.045 | Chat | Server has requested a logoff. Reason: Chat server is backing up
2024-09-23 23:00:00.045 | Chat | Waiting for socket receive thread to end
2024-09-23 23:00:00.045 | DTC Client socket (3) | CloseSocket call.
2024-09-23 23:00:00.046 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2024-09-23 23:00:00.046 | Chat | Disconnected from the server.
2024-09-23 23:00:00.046 | Chat | Data feed disconnected. Will reconnect in 5 seconds.
2024-09-23 23:00:01.985 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-09-23 23:00:01.985 | DTC Client socket (3) | Closed.
2024-09-23 23:00:05.041 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-23 23:00:05.192 | DTC Client socket (3) | Creating socket. Using TLS 1.2.
2024-09-23 23:00:05.192 | DTC Client socket (3) | New receive buffer size: 0
2024-09-23 23:00:05.192 | DTC Client socket (3) | Connecting to IP: 69.39.70.248.
2024-09-23 23:00:05.467 | Chat | Network connection to server complete.
2024-09-23 23:00:05.467 | Chat | Starting socket receive thread.
2024-09-23 23:00:05.467 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-23 23:00:06.294 | Chat | Setting DTC encoding to Binary VLS
2024-09-23 23:00:06.294 | Chat | Sending logon request message.
2024-09-23 23:00:11.445 | Not connected to chat server to send alert messages.
2024-09-23 23:00:22.354 | Chat | Received logon response.
2024-09-23 23:00:22.354 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-23 23:00:22.354 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-23 23:00:22.354 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-23 23:00:22.354 | Chat | Trading is not supported.
2024-09-23 23:00:22.354 | Chat | MarketDepthIsSupported: 1
2024-09-23 23:00:22.629 | Chat | Message response. Chat ID: 429. Request ID: 1134626517
2024-09-24 00:00:00.054 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-24 00:00:00.054 | Triggering next historical data download in queue.
2024-09-24 00:00:00.055 | HD Request # 71 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:00.416 | Added historical Daily data request for GCZ4.COMEX to the queue.
2024-09-24 00:00:00.416 | Triggering next historical data download in queue.
2024-09-24 00:00:00.416 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-24 00:00:00.417 | Added historical Daily data request for CLX4.NYMEX to the queue.
2024-09-24 00:00:00.417 | Triggering next historical data download in queue.
2024-09-24 00:00:00.471 | Added historical Daily data request for 6JZ4.CME to the queue.
2024-09-24 00:00:00.471 | Triggering next historical data download in queue.
2024-09-24 00:00:00.471 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-24 00:00:01.003 | HD Request # 71 | Requesting historical Daily data for ESZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:02.006 | HD Request # 71 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-19.
2024-09-24 00:00:02.006 | HD Request # 71 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-24 00:00:02.009 | HD Request # 71 | Bytes received: 233
2024-09-24 00:00:02.009 | HD Request # 71 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for ESZ4.CME
2024-09-24 00:00:02.009 | HD Request # 71 | Completion time: 2s.
2024-09-24 00:00:02.009 | HD Request # 71 | Daily data download complete for ESZ4.CME. Unique request ID: 71
2024-09-24 00:00:02.009 | Removing historical data download ID 71.
2024-09-24 00:00:02.009 | Triggering next historical data download in queue.
2024-09-24 00:00:02.010 | HD Request # 72 | Downloading Historical Daily chart data for GCZ4.COMEX. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:02.168 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:02.168 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:02.168 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:02.568 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:02.577 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:02.577 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:02.577 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:02.967 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:03.068 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:03.068 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:03.068 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:03.403 | HD Request # 72 | Requesting historical Daily data for GCZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:03.457 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:04.182 | HD Request # 72 | Receiving historical Daily data for GCZ4.COMEX starting at 2024-09-19.
2024-09-24 00:00:04.182 | HD Request # 72 | Writing historical Daily data to the file GCZ4.COMEX.dly.
2024-09-24 00:00:04.187 | HD Request # 72 | Bytes received: 232
2024-09-24 00:00:04.187 | HD Request # 72 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for GCZ4.COMEX
2024-09-24 00:00:04.187 | HD Request # 72 | Completion time: 2s.
2024-09-24 00:00:04.187 | HD Request # 72 | Daily data download complete for GCZ4.COMEX. Unique request ID: 72
2024-09-24 00:00:04.187 | Removing historical data download ID 72.
2024-09-24 00:00:04.187 | Triggering next historical data download in queue.
2024-09-24 00:00:04.188 | HD Request # 73 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:04.195 | GCZ4.COMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:04.195 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:04.195 | GCZ4.COMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:04.980 | GCZ4.COMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:05.373 | GCZ4.COMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:05.373 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:05.373 | GCZ4.COMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:06.026 | HD Request # 73 | Requesting historical Daily data for NQZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:06.097 | GCZ4.COMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:06.097 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:06.097 | GCZ4.COMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:06.751 | GCZ4.COMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:06.877 | GCZ4.COMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:07.356 | HD Request # 73 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-19.
2024-09-24 00:00:07.356 | HD Request # 73 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-24 00:00:07.358 | HD Request # 73 | Bytes received: 237
2024-09-24 00:00:07.358 | HD Request # 73 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for NQZ4.CME
2024-09-24 00:00:07.358 | HD Request # 73 | Completion time: 3s.
2024-09-24 00:00:07.358 | HD Request # 73 | Daily data download complete for NQZ4.CME. Unique request ID: 73
2024-09-24 00:00:07.358 | Removing historical data download ID 73.
2024-09-24 00:00:07.358 | Triggering next historical data download in queue.
2024-09-24 00:00:07.359 | HD Request # 74 | Downloading Historical Daily chart data for CLX4.NYMEX. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:07.378 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:07.378 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:07.378 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:07.748 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:07.749 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:07.749 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:07.749 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:08.102 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:08.183 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:08.183 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:08.183 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:08.483 | HD Request # 74 | Requesting historical Daily data for CLX24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:08.546 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:09.274 | HD Request # 74 | Receiving historical Daily data for CLX4.NYMEX starting at 2024-09-19.
2024-09-24 00:00:09.274 | HD Request # 74 | Writing historical Daily data to the file CLX4.NYMEX.dly.
2024-09-24 00:00:09.280 | HD Request # 74 | Bytes received: 217
2024-09-24 00:00:09.280 | HD Request # 74 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for CLX4.NYMEX
2024-09-24 00:00:09.280 | HD Request # 74 | Completion time: 2s.
2024-09-24 00:00:09.280 | HD Request # 74 | Daily data download complete for CLX4.NYMEX. Unique request ID: 74
2024-09-24 00:00:09.280 | Removing historical data download ID 74.
2024-09-24 00:00:09.280 | Triggering next historical data download in queue.
2024-09-24 00:00:09.281 | HD Request # 75 | Downloading Historical Daily chart data for 6JZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:09.514 | CLX4.NYMEX [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:09.514 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:09.514 | CLX4.NYMEX [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:11.695 | HD Request # 75 | Requesting historical Daily data for J6Z24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:11.878 | CLX4.NYMEX [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:11.879 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:11.879 | CLX4.NYMEX [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:14.098 | CLX4.NYMEX [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:14.098 | HD Request # 75 | Receiving historical Daily data for 6JZ4.CME starting at 2024-09-19.
2024-09-24 00:00:14.098 | HD Request # 75 | Writing historical Daily data to the file 6JZ4.CME.dly.
2024-09-24 00:00:14.104 | HD Request # 75 | Bytes received: 273
2024-09-24 00:00:14.104 | HD Request # 75 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for 6JZ4.CME
2024-09-24 00:00:14.104 | HD Request # 75 | Completion time: 5s.
2024-09-24 00:00:14.104 | HD Request # 75 | Daily data download complete for 6JZ4.CME. Unique request ID: 75
2024-09-24 00:00:14.104 | Removing historical data download ID 75.
2024-09-24 00:00:14.104 | Triggering next historical data download in queue.
2024-09-24 00:00:14.105 | HD Request # 76 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 00:00:14.189 | 6JZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:14.189 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:14.189 | 6JZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:15.003 | CLX4.NYMEX [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:15.057 | 6JZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:15.057 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:15.057 | 6JZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:15.806 | 6JZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:15.806 | HD Request # 76 | Requesting historical Daily data for A6Z24 starting at 2024-09-18. SC External HD service.
2024-09-24 00:00:16.100 | 6JZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:16.260 | CLX4.NYMEX [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:16.260 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:16.260 | CLX4.NYMEX [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:18.427 | HD Request # 76 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-19.
2024-09-24 00:00:18.427 | HD Request # 76 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-24 00:00:18.433 | HD Request # 76 | Bytes received: 242
2024-09-24 00:00:18.433 | HD Request # 76 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for 6AZ4.CME
2024-09-24 00:00:18.433 | HD Request # 76 | Completion time: 4s.
2024-09-24 00:00:18.433 | HD Request # 76 | Daily data download complete for 6AZ4.CME. Unique request ID: 76
2024-09-24 00:00:18.433 | Removing historical data download ID 76.
2024-09-24 00:00:18.433 | No download requests in the queue to start downloads for.
2024-09-24 00:00:18.509 | 6JZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:18.509 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:18.509 | 6JZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:19.330 | CLX4.NYMEX [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:00:19.331 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 00:00:19.331 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:19.331 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:20.088 | 6JZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:20.090 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 00:00:20.090 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:20.090 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:20.845 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 00:00:20.970 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 00:00:21.093 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 00:00:21.093 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:21.093 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 00:00:22.144 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 00:11:27.352 | Chat | Message response. Chat ID: 429. Request ID: 1134626522
2024-09-24 01:08:10.797 | Chat | Message response. Chat ID: 429. Request ID: 1134626523
2024-09-24 01:09:01.430 | Chat | Message response. Chat ID: 429. Request ID: 1134626524
2024-09-24 01:36:47.040 | Chat | Message response. Chat ID: 429. Request ID: 1134626525
2024-09-24 05:01:27.362 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-24 05:01:27.362 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 05:01:27.363 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:01:27.363 | DTC Client socket (2) | Max send buffers used during socket life: 4
2024-09-24 05:01:27.363 | DTC Client socket (2) | Max send buffer size during socket life: 1401
2024-09-24 05:01:27.363 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 05:01:27.363 | DTC Client socket (2) | Closed.
2024-09-24 05:01:27.363 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 05:01:27.363 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:01:27.363 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:01:27.363 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:01:30.370 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:01:30.478 | DTC Client socket (2) | Creating socket.
2024-09-24 05:01:30.478 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:01:30.478 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:01:51.514 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:01:51.514 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:01:51.514 | Denali Data Feed | Failed connections: 1
2024-09-24 05:01:51.514 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:01:51.514 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:01:51.514 | DTC Client socket (2) | Closed.
2024-09-24 05:01:51.514 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:01:54.510 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:01:54.510 | DTC Client socket (2) | Creating socket.
2024-09-24 05:01:54.510 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:01:54.510 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:02:15.543 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:02:15.543 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:02:15.543 | Denali Data Feed | Failed connections: 2
2024-09-24 05:02:15.543 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:02:15.543 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:02:15.543 | DTC Client socket (2) | Closed.
2024-09-24 05:02:15.543 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:02:18.547 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:02:18.547 | DTC Client socket (2) | Creating socket.
2024-09-24 05:02:18.547 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:02:18.547 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:02:39.577 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:02:39.577 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:02:39.577 | Denali Data Feed | Failed connections: 3
2024-09-24 05:02:39.577 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:02:39.577 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:02:39.577 | DTC Client socket (2) | Closed.
2024-09-24 05:02:39.577 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:02:42.574 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:02:42.575 | DTC Client socket (2) | Creating socket.
2024-09-24 05:02:42.575 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:02:42.575 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:03:03.612 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:03:03.612 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:03:03.612 | Denali Data Feed | Failed connections: 4
2024-09-24 05:03:03.612 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:03:03.612 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:03:03.612 | DTC Client socket (2) | Closed.
2024-09-24 05:03:03.612 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:03:06.604 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:03:06.604 | DTC Client socket (2) | Creating socket.
2024-09-24 05:03:06.604 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:03:06.604 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:03:27.644 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:03:27.644 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:03:27.644 | DTC Client socket (2) | Closed.
2024-09-24 05:03:27.644 | Denali Data Feed | Failed connections: 5
2024-09-24 05:03:27.644 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:03:27.644 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:03:27.644 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:03:30.635 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:03:30.636 | DTC Client socket (2) | Creating socket.
2024-09-24 05:03:30.636 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:03:30.636 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:03:51.679 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:03:51.679 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:03:51.679 | Denali Data Feed | Failed connections: 6
2024-09-24 05:03:51.679 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:03:51.679 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:03:51.679 | DTC Client socket (2) | Closed.
2024-09-24 05:03:51.679 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:03:54.671 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:03:54.672 | DTC Client socket (2) | Creating socket.
2024-09-24 05:03:54.672 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:03:54.672 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:04:15.706 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:04:15.706 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:04:15.707 | DTC Client socket (2) | Closed.
2024-09-24 05:04:15.707 | Denali Data Feed | Failed connections: 7
2024-09-24 05:04:15.707 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:04:15.707 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:04:15.707 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:04:18.697 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:04:18.697 | DTC Client socket (2) | Creating socket.
2024-09-24 05:04:18.697 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:04:18.697 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:04:39.742 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:04:39.742 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:04:39.742 | Denali Data Feed | Failed connections: 8
2024-09-24 05:04:39.742 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:04:39.742 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:04:39.742 | DTC Client socket (2) | Closed.
2024-09-24 05:04:39.742 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:04:42.731 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:04:42.732 | DTC Client socket (2) | Creating socket.
2024-09-24 05:04:42.732 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:04:42.732 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:05:03.757 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:05:03.757 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:05:03.757 | Denali Data Feed | Failed connections: 9
2024-09-24 05:05:03.757 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:05:03.757 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:05:03.757 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:05:03.757 | DTC Client socket (2) | Closed.
2024-09-24 05:05:06.748 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:05:06.748 | DTC Client socket (2) | Creating socket.
2024-09-24 05:05:06.748 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:05:06.748 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:05:27.804 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:05:27.804 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:05:27.804 | Denali Data Feed | Failed connections: 10
2024-09-24 05:05:27.804 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:05:27.804 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:05:27.804 | DTC Client socket (2) | Closed.
2024-09-24 05:05:27.804 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:05:30.797 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:05:30.797 | DTC Client socket (2) | Creating socket.
2024-09-24 05:05:30.797 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:05:30.797 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:05:51.839 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:05:51.839 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:05:51.839 | Denali Data Feed | Failed connections: 11
2024-09-24 05:05:51.839 | DTC Client socket (2) | Closed.
2024-09-24 05:05:51.839 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:05:51.839 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:05:51.839 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:05:54.841 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:05:54.841 | DTC Client socket (2) | Creating socket.
2024-09-24 05:05:54.841 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:05:54.841 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:06:15.862 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:06:15.862 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:06:15.863 | Denali Data Feed | Failed connections: 12
2024-09-24 05:06:15.863 | DTC Client socket (2) | Closed.
2024-09-24 05:06:15.863 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:06:15.863 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:06:15.863 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:06:18.853 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:06:18.853 | DTC Client socket (2) | Creating socket.
2024-09-24 05:06:18.853 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:06:18.853 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:06:39.892 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:06:39.892 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:06:39.892 | Denali Data Feed | Failed connections: 13
2024-09-24 05:06:39.892 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:06:39.892 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:06:39.892 | DTC Client socket (2) | Closed.
2024-09-24 05:06:39.892 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:06:42.887 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:06:42.887 | DTC Client socket (2) | Creating socket.
2024-09-24 05:06:42.888 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:06:42.888 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:07:03.933 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:07:03.933 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:07:03.933 | DTC Client socket (2) | Closed.
2024-09-24 05:07:03.933 | Denali Data Feed | Failed connections: 14
2024-09-24 05:07:03.933 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:07:03.933 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:07:03.933 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:07:06.931 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:07:06.932 | DTC Client socket (2) | Creating socket.
2024-09-24 05:07:06.932 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:07:06.932 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:07:27.973 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:07:27.973 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:07:27.973 | Denali Data Feed | Failed connections: 15
2024-09-24 05:07:27.973 | DTC Client socket (2) | Closed.
2024-09-24 05:07:27.973 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:07:27.973 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:07:27.973 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:07:30.963 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:07:30.964 | DTC Client socket (2) | Creating socket.
2024-09-24 05:07:30.964 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:07:30.964 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:07:52.007 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:07:52.007 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:07:52.007 | DTC Client socket (2) | Closed.
2024-09-24 05:07:52.007 | Denali Data Feed | Failed connections: 16
2024-09-24 05:07:52.007 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:07:52.007 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:07:52.007 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:07:54.998 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:07:54.998 | DTC Client socket (2) | Creating socket.
2024-09-24 05:07:54.998 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:07:54.998 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:08:16.029 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:08:16.029 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:08:16.029 | Denali Data Feed | Failed connections: 17
2024-09-24 05:08:16.029 | DTC Client socket (2) | Closed.
2024-09-24 05:08:16.029 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:08:16.029 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:08:16.029 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:08:19.032 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:08:19.032 | DTC Client socket (2) | Creating socket.
2024-09-24 05:08:19.032 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:08:19.032 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:08:40.078 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:08:40.078 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:08:40.078 | Denali Data Feed | Failed connections: 18
2024-09-24 05:08:40.078 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:08:40.078 | DTC Client socket (2) | Closed.
2024-09-24 05:08:40.078 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:08:40.078 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:08:43.072 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:08:43.072 | DTC Client socket (2) | Creating socket.
2024-09-24 05:08:43.072 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:08:43.072 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:09:04.129 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:09:04.129 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:09:04.129 | DTC Client socket (2) | Closed.
2024-09-24 05:09:04.129 | Denali Data Feed | Failed connections: 19
2024-09-24 05:09:04.129 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:09:04.129 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:09:04.130 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:09:07.137 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:09:07.137 | DTC Client socket (2) | Creating socket.
2024-09-24 05:09:07.137 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:09:07.137 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:09:28.170 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:09:28.176 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:09:28.176 | Denali Data Feed | Failed connections: 20
2024-09-24 05:09:28.176 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:09:28.176 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:09:28.176 | DTC Client socket (2) | Closed.
2024-09-24 05:09:28.176 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:09:31.166 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:09:31.166 | DTC Client socket (2) | Creating socket.
2024-09-24 05:09:31.166 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:09:31.166 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:09:52.228 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:09:52.228 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:09:52.228 | Denali Data Feed | Failed connections: 21
2024-09-24 05:09:52.228 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:09:52.228 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:09:52.228 | DTC Client socket (2) | Closed.
2024-09-24 05:09:52.228 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:09:55.305 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:09:55.305 | DTC Client socket (2) | Creating socket.
2024-09-24 05:09:55.305 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:09:55.305 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:10:16.342 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:10:16.342 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:10:16.342 | Denali Data Feed | Failed connections: 22
2024-09-24 05:10:16.342 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:10:16.342 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:10:16.342 | DTC Client socket (2) | Closed.
2024-09-24 05:10:16.342 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:10:19.344 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:10:19.344 | DTC Client socket (2) | Creating socket.
2024-09-24 05:10:19.344 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:10:19.344 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:10:40.367 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:10:40.371 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:10:40.371 | Denali Data Feed | Failed connections: 23
2024-09-24 05:10:40.371 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:10:40.371 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:10:40.371 | DTC Client socket (2) | Closed.
2024-09-24 05:10:40.371 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:10:43.372 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:10:43.372 | DTC Client socket (2) | Creating socket.
2024-09-24 05:10:43.372 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:10:43.372 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:11:04.403 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:11:04.403 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:11:04.403 | Denali Data Feed | Failed connections: 24
2024-09-24 05:11:04.403 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:11:04.403 | DTC Client socket (2) | Closed.
2024-09-24 05:11:04.403 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:11:04.403 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:11:07.402 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:11:07.402 | DTC Client socket (2) | Creating socket.
2024-09-24 05:11:07.403 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:11:07.403 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:11:28.451 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:11:28.451 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:11:28.451 | Denali Data Feed | Failed connections: 25
2024-09-24 05:11:28.451 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:11:28.451 | DTC Client socket (2) | Closed.
2024-09-24 05:11:28.451 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:11:28.451 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:11:31.449 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:11:31.449 | DTC Client socket (2) | Creating socket.
2024-09-24 05:11:31.449 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:11:31.449 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:11:52.505 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:11:52.505 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:11:52.505 | Denali Data Feed | Failed connections: 26
2024-09-24 05:11:52.505 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:11:52.505 | DTC Client socket (2) | Closed.
2024-09-24 05:11:52.505 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:11:52.505 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:11:55.495 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:11:55.496 | DTC Client socket (2) | Creating socket.
2024-09-24 05:11:55.496 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:11:55.496 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:12:16.538 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:12:16.538 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:12:16.538 | Denali Data Feed | Failed connections: 27
2024-09-24 05:12:16.538 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:12:16.538 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:12:16.538 | DTC Client socket (2) | Closed.
2024-09-24 05:12:16.538 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:12:19.533 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:12:19.533 | DTC Client socket (2) | Creating socket.
2024-09-24 05:12:19.533 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:12:19.533 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:12:40.569 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:12:40.569 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:12:40.569 | Denali Data Feed | Failed connections: 28
2024-09-24 05:12:40.569 | DTC Client socket (2) | Closed.
2024-09-24 05:12:40.569 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:12:40.569 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:12:40.569 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:12:43.563 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:12:43.563 | DTC Client socket (2) | Creating socket.
2024-09-24 05:12:43.563 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:12:43.563 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:13:04.609 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:13:04.609 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:13:04.609 | Denali Data Feed | Failed connections: 29
2024-09-24 05:13:04.609 | DTC Client socket (2) | Closed.
2024-09-24 05:13:04.609 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:13:04.609 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:13:04.609 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:13:07.608 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:13:07.609 | DTC Client socket (2) | Creating socket.
2024-09-24 05:13:07.609 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:13:07.609 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:13:28.650 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:13:28.650 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:13:28.650 | DTC Client socket (2) | Closed.
2024-09-24 05:13:28.650 | Denali Data Feed | Failed connections: 30
2024-09-24 05:13:28.650 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:13:28.650 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:13:28.650 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:13:31.653 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:13:31.653 | DTC Client socket (2) | Creating socket.
2024-09-24 05:13:31.653 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:13:31.653 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:13:52.691 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:13:52.691 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:13:52.691 | Denali Data Feed | Failed connections: 31
2024-09-24 05:13:52.691 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:13:52.691 | DTC Client socket (2) | Closed.
2024-09-24 05:13:52.691 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:13:52.691 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:13:55.683 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:13:55.683 | DTC Client socket (2) | Creating socket.
2024-09-24 05:13:55.684 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:13:55.684 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:14:16.735 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:14:16.735 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:14:16.735 | Denali Data Feed | Failed connections: 32
2024-09-24 05:14:16.735 | DTC Client socket (2) | Closed.
2024-09-24 05:14:16.735 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:14:16.735 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:14:16.735 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:14:19.733 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:14:19.733 | DTC Client socket (2) | Creating socket.
2024-09-24 05:14:19.733 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:14:19.733 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:14:40.767 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:14:40.767 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:14:40.767 | Denali Data Feed | Failed connections: 33
2024-09-24 05:14:40.767 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:14:40.767 | DTC Client socket (2) | Closed.
2024-09-24 05:14:40.767 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:14:40.767 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:14:43.763 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:14:43.763 | DTC Client socket (2) | Creating socket.
2024-09-24 05:14:43.763 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:14:43.763 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:15:04.802 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:15:04.802 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:15:04.802 | DTC Client socket (2) | Closed.
2024-09-24 05:15:04.802 | Denali Data Feed | Failed connections: 34
2024-09-24 05:15:04.802 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:15:04.802 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:15:04.802 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:15:07.792 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:15:07.793 | DTC Client socket (2) | Creating socket.
2024-09-24 05:15:07.793 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:15:07.793 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:15:28.828 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:15:28.828 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:15:28.828 | Denali Data Feed | Failed connections: 35
2024-09-24 05:15:28.828 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:15:28.828 | DTC Client socket (2) | Closed.
2024-09-24 05:15:28.828 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:15:28.828 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:15:31.823 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:15:31.823 | DTC Client socket (2) | Creating socket.
2024-09-24 05:15:31.823 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:15:31.823 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:15:52.863 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 05:15:52.863 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:15:52.864 | Denali Data Feed | Failed connections: 36
2024-09-24 05:15:52.864 | DTC Client socket (0) | CloseSocket call.
2024-09-24 05:15:52.864 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:15:52.864 | DTC Client socket (2) | Closed.
2024-09-24 05:15:52.864 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:15:55.874 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:15:55.874 | DTC Client socket (2) | Creating socket.
2024-09-24 05:15:55.874 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 05:15:55.874 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 05:15:56.032 | Denali Data Feed | Network connection to server complete.
2024-09-24 05:15:56.033 | Denali Data Feed | Starting socket receive thread.
2024-09-24 05:15:56.033 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 05:15:56.215 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-24 05:15:56.215 | Denali Data Feed | Sending logon request message.
2024-09-24 05:17:15.871 | Denali Data Feed | There has been no activity on the network socket for 1m 19s. Will reconnect.
2024-09-24 05:17:15.871 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 05:17:15.871 | DTC Client socket (2) | CloseSocket call.
2024-09-24 05:17:15.871 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:15.871 | Denali Data Feed | Disconnected from the server.
2024-09-24 05:17:15.871 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 05:17:18.873 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 05:17:18.873 | DTC Client socket (5) | Creating socket.
2024-09-24 05:17:18.873 | DTC Client socket (5) | New receive buffer size: 0
2024-09-24 05:17:18.873 | DTC Client socket (5) | Connecting to IP: 202.52.152.130.
2024-09-24 05:17:19.029 | Denali Data Feed | Network connection to server complete.
2024-09-24 05:17:19.029 | Denali Data Feed | Starting socket receive thread.
2024-09-24 05:17:19.029 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 05:17:19.197 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-24 05:17:19.197 | Denali Data Feed | Sending logon request message.
2024-09-24 05:17:19.853 | Denali Data Feed | Received logon response.
2024-09-24 05:17:19.853 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-24 05:17:19.853 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-24 05:17:19.853 | Denali Data Feed | Successfully connected.
2024-09-24 05:17:19.853 | Denali Data Feed | Trading is not supported.
2024-09-24 05:17:19.853 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-24 05:17:19.853 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Triggering next historical data download in queue.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: 6AZ4.CME -> 6AZ24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: 6JZ4.CME -> 6JZ24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: CLX4.NYMEX -> CLX24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ4.CME -> ESZ24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24. Market Depth data restarted.
2024-09-24 05:17:19.853 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: M6AZ4.CME -> M6AZ24
2024-09-24 05:17:19.853 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: MCLU4.NYMEX -> MCLU24
2024-09-24 05:17:19.853 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 05:17:19.853 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 05:17:19.853 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24. Market Depth data restarted.
2024-09-24 05:17:19.854 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ4.CME -> MESZ24. Market Depth data restarted.
2024-09-24 05:17:19.854 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MGCZ4.COMEX -> MGCZ24
2024-09-24 05:17:19.854 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MJYZ4.CME -> MJYZ24
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-24 05:17:19.854 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ4.CME -> MNQZ24. Market Depth data restarted.
2024-09-24 05:17:19.854 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 05:17:19.854 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 05:17:19.854 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2024-09-24 05:17:19.854 | HD Request # 77 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 05:17:19.854 | HD Request # 77 | Download start date-time: 2024-09-24 05:00:54.000000. File last date-time: 2024-09-24 05:00:54.309004
2024-09-24 05:17:19.854 | HD Request # 77 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:19.854 | Socket (6) | Creating socket.
2024-09-24 05:17:19.854 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:19.854 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:20.398 | HD Request # 77 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:20.398 | HD Request # 77 | Sending historical data logon request message.
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-24 05:17:20.509 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-24 05:17:20.510 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-24 05:17:20.510 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-24 05:17:20.510 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-24 05:17:20.663 | HD Request # 77 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:54. Record interval: 0. Symbol: 6AZ24
2024-09-24 05:17:20.930 | HD Request # 77 | Decompressing data.
2024-09-24 05:17:21.199 | HD Request # 77 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 05:00:54.082000
2024-09-24 05:17:21.200 | Socket (6) | CloseSocket call.
2024-09-24 05:17:21.200 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:21.205 | Historical data download thread signaled to stop.
2024-09-24 05:17:21.205 | HD Request # 77 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:32.417000.
2024-09-24 05:17:21.205 | HD Request # 77 | Received 305 Intraday data records from 2024-09-24 05:00:54.082000 to 2024-09-24 05:17:01.892000 (16.1 minutes. Delay: 19.3 seconds) and wrote 287 records for 6AZ4.CME
2024-09-24 05:17:21.206 | HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:01.892000
2024-09-24 05:17:21.206 | HD Request # 77 | Completion time: 2s.
2024-09-24 05:17:21.206 | HD Request # 77 | Intraday data download complete for 6AZ4.CME. Unique request ID: 77
2024-09-24 05:17:21.206 | Removing historical data download ID 77.
2024-09-24 05:17:21.206 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 05:17:21.206 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 05:17:21.206 | HD Request # 77 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:21.206 | Triggering next historical data download in queue.
2024-09-24 05:17:21.206 | HD Request # 78 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 05:17:21.206 | HD Request # 78 | Download start date-time: 2024-09-24 05:00:59.000000. File last date-time: 2024-09-24 05:00:59.469000
2024-09-24 05:17:21.206 | HD Request # 78 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:21.206 | Socket (7) | Creating socket.
2024-09-24 05:17:21.206 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:21.206 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:21.465 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:21.465 | Socket (6) | Closed.
2024-09-24 05:17:21.745 | HD Request # 78 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:21.745 | HD Request # 78 | Sending historical data logon request message.
2024-09-24 05:17:22.008 | HD Request # 78 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:59. Record interval: 0. Symbol: 6JZ24
2024-09-24 05:17:22.272 | HD Request # 78 | Decompressing data.
2024-09-24 05:17:22.539 | HD Request # 78 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 05:00:59.469000
2024-09-24 05:17:22.539 | Socket (7) | CloseSocket call.
2024-09-24 05:17:22.539 | Historical data download thread signaled to stop.
2024-09-24 05:17:22.539 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:22.539 | HD Request # 78 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:04.005000.
2024-09-24 05:17:22.539 | HD Request # 78 | Received 622 Intraday data records from 2024-09-24 05:00:59.469000 to 2024-09-24 05:17:16.251000 (16.3 minutes. Delay: 6.3 seconds) and wrote 621 records for 6JZ4.CME
2024-09-24 05:17:22.539 | HD Request # 78 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:16.251000
2024-09-24 05:17:22.539 | HD Request # 78 | Completion time: 1s.
2024-09-24 05:17:22.539 | HD Request # 78 | Intraday data download complete for 6JZ4.CME. Unique request ID: 78
2024-09-24 05:17:22.539 | Removing historical data download ID 78.
2024-09-24 05:17:22.539 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 05:17:22.540 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 05:17:22.540 | HD Request # 78 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:22.540 | Triggering next historical data download in queue.
2024-09-24 05:17:22.540 | HD Request # 79 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 05:17:22.540 | HD Request # 79 | Download start date-time: 2024-09-24 05:01:02.000000. File last date-time: 2024-09-24 05:01:02.661000
2024-09-24 05:17:22.540 | HD Request # 79 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:22.540 | Socket (6) | Creating socket.
2024-09-24 05:17:22.540 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:22.540 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:22.802 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:22.802 | Socket (7) | Closed.
2024-09-24 05:17:23.094 | HD Request # 79 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:23.094 | HD Request # 79 | Sending historical data logon request message.
2024-09-24 05:17:23.365 | HD Request # 79 | Requesting Intraday data. Start date-time: 2024-09-24 05:01:02. Record interval: 0. Symbol: CLX24
2024-09-24 05:17:23.638 | HD Request # 79 | Decompressing data.
2024-09-24 05:17:24.187 | HD Request # 79 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 05:01:02.136000
2024-09-24 05:17:24.187 | Socket (6) | CloseSocket call.
2024-09-24 05:17:24.187 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:24.189 | Historical data download thread signaled to stop.
2024-09-24 05:17:24.189 | HD Request # 79 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:03.450000.
2024-09-24 05:17:24.189 | HD Request # 79 | Received 2748 Intraday data records from 2024-09-24 05:01:02.136000 to 2024-09-24 05:17:22.204000 (16.3 minutes. Delay: 2.0 seconds) and wrote 2741 records for CLX4.NYMEX
2024-09-24 05:17:24.190 | HD Request # 79 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:22.204000
2024-09-24 05:17:24.190 | Added 9 Time and Sales records to Intraday data file for CLX4.NYMEX after download.
2024-09-24 05:17:24.190 | HD Request # 79 | Completion time: 2s.
2024-09-24 05:17:24.190 | HD Request # 79 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 79
2024-09-24 05:17:24.190 | Removing historical data download ID 79.
2024-09-24 05:17:24.190 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 05:17:24.190 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 05:17:24.190 | HD Request # 79 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:24.190 | Triggering next historical data download in queue.
2024-09-24 05:17:24.190 | HD Request # 80 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 05:17:24.190 | HD Request # 80 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 05:17:24.190 | HD Request # 80 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:24.190 | Socket (7) | Creating socket.
2024-09-24 05:17:24.190 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:24.190 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:24.459 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:24.459 | Socket (6) | Closed.
2024-09-24 05:17:24.744 | HD Request # 80 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:24.744 | HD Request # 80 | Sending historical data logon request message.
2024-09-24 05:17:24.929 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:24.929 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6JZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:25.015 | HD Request # 80 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 05:17:25.288 | HD Request # 80 | Decompressing data.
2024-09-24 05:17:25.560 | HD Request # 80 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 05:17:25.560 | Socket (7) | CloseSocket call.
2024-09-24 05:17:25.560 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:25.563 | Historical data download thread signaled to stop.
2024-09-24 05:17:25.563 | HD Request # 80 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 3.8 days) and wrote 0 records for ESU4.CME
2024-09-24 05:17:25.563 | HD Request # 80 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 05:17:25.563 | HD Request # 80 | Completion time: 1s.
2024-09-24 05:17:25.563 | HD Request # 80 | Intraday data download complete for ESU4.CME. Unique request ID: 80
2024-09-24 05:17:25.563 | Removing historical data download ID 80.
2024-09-24 05:17:25.563 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 05:17:25.563 | Intraday chart data file opened for ESU4.CME
2024-09-24 05:17:25.563 | HD Request # 80 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:25.563 | Triggering next historical data download in queue.
2024-09-24 05:17:25.563 | HD Request # 81 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 05:17:25.563 | HD Request # 81 | Download start date-time: 2024-09-24 05:00:57.000000. File last date-time: 2024-09-24 05:00:57.939005
2024-09-24 05:17:25.563 | HD Request # 81 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:25.563 | Socket (6) | Creating socket.
2024-09-24 05:17:25.563 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:25.563 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:25.831 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:25.831 | Socket (7) | Closed.
2024-09-24 05:17:26.118 | HD Request # 81 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:26.118 | HD Request # 81 | Sending historical data logon request message.
2024-09-24 05:17:26.389 | HD Request # 81 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:57. Record interval: 0. Symbol: ESZ24
2024-09-24 05:17:26.662 | HD Request # 81 | Decompressing data.
2024-09-24 05:17:26.937 | HD Request # 81 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 05:00:57.939000
2024-09-24 05:17:26.938 | Socket (6) | CloseSocket call.
2024-09-24 05:17:26.938 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:26.947 | Historical data download thread signaled to stop.
2024-09-24 05:17:26.947 | HD Request # 81 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:13.979000.
2024-09-24 05:17:26.947 | HD Request # 81 | Received 1412 Intraday data records from 2024-09-24 05:00:57.939000 to 2024-09-24 05:17:19.966000 (16.4 minutes. Delay: 7.0 seconds) and wrote 1406 records for ESZ4.CME
2024-09-24 05:17:26.948 | HD Request # 81 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:19.966000
2024-09-24 05:17:26.948 | HD Request # 81 | Completion time: 1s.
2024-09-24 05:17:26.948 | HD Request # 81 | Intraday data download complete for ESZ4.CME. Unique request ID: 81
2024-09-24 05:17:26.948 | Removing historical data download ID 81.
2024-09-24 05:17:26.948 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 05:17:26.948 | Intraday chart data file opened for ESZ4.CME
2024-09-24 05:17:26.948 | HD Request # 81 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:26.948 | Triggering next historical data download in queue.
2024-09-24 05:17:26.948 | HD Request # 82 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 05:17:26.948 | HD Request # 82 | Download start date-time: 2024-09-24 05:00:50.000000. File last date-time: 2024-09-24 05:00:50.988000
2024-09-24 05:17:26.948 | HD Request # 82 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:26.948 | Socket (7) | Creating socket.
2024-09-24 05:17:26.948 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:26.948 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:27.209 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:27.209 | Socket (6) | Closed.
2024-09-24 05:17:27.498 | HD Request # 82 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:27.498 | HD Request # 82 | Sending historical data logon request message.
2024-09-24 05:17:27.768 | HD Request # 82 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:50. Record interval: 0. Symbol: GCZ24
2024-09-24 05:17:28.041 | HD Request # 82 | Decompressing data.
2024-09-24 05:17:28.317 | HD Request # 82 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 05:00:50.988000
2024-09-24 05:17:28.317 | Socket (7) | CloseSocket call.
2024-09-24 05:17:28.317 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:28.331 | Historical data download thread signaled to stop.
2024-09-24 05:17:28.331 | HD Request # 82 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:05.080000.
2024-09-24 05:17:28.331 | HD Request # 82 | Received 1317 Intraday data records from 2024-09-24 05:00:50.988000 to 2024-09-24 05:17:23.908000 (16.5 minutes. Delay: 4.4 seconds) and wrote 1316 records for GCZ4.COMEX
2024-09-24 05:17:28.331 | HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:23.908000
2024-09-24 05:17:28.331 | Added 1 Time and Sales records to Intraday data file for GCZ4.COMEX after download.
2024-09-24 05:17:28.331 | HD Request # 82 | Completion time: 2s.
2024-09-24 05:17:28.331 | HD Request # 82 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 82
2024-09-24 05:17:28.331 | Removing historical data download ID 82.
2024-09-24 05:17:28.331 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 05:17:28.331 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 05:17:28.331 | HD Request # 82 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:28.331 | Triggering next historical data download in queue.
2024-09-24 05:17:28.331 | HD Request # 83 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 05:17:28.332 | HD Request # 83 | Download start date-time: 2024-09-24 05:00:50.000000. File last date-time: 2024-09-24 05:00:50.471005
2024-09-24 05:17:28.332 | HD Request # 83 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:28.332 | Socket (6) | Creating socket.
2024-09-24 05:17:28.332 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:28.332 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:28.588 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:28.588 | Socket (7) | Closed.
2024-09-24 05:17:28.890 | HD Request # 83 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:28.890 | HD Request # 83 | Sending historical data logon request message.
2024-09-24 05:17:29.162 | HD Request # 83 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:50. Record interval: 0. Symbol: M6AZ24
2024-09-24 05:17:29.435 | HD Request # 83 | Decompressing data.
2024-09-24 05:17:29.707 | HD Request # 83 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 05:00:50.350000
2024-09-24 05:17:29.707 | Socket (6) | CloseSocket call.
2024-09-24 05:17:29.707 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:29.722 | Historical data download thread signaled to stop.
2024-09-24 05:17:29.722 | HD Request # 83 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:32.417000.
2024-09-24 05:17:29.722 | HD Request # 83 | Received 62 Intraday data records from 2024-09-24 05:00:50.350000 to 2024-09-24 05:17:23.947000 (16.6 minutes. Delay: 5.8 seconds) and wrote 55 records for M6AZ4.CME
2024-09-24 05:17:29.723 | HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:23.947000
2024-09-24 05:17:29.723 | HD Request # 83 | Completion time: 1s.
2024-09-24 05:17:29.723 | HD Request # 83 | Intraday data download complete for M6AZ4.CME. Unique request ID: 83
2024-09-24 05:17:29.723 | Removing historical data download ID 83.
2024-09-24 05:17:29.723 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 05:17:29.723 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 05:17:29.723 | HD Request # 83 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:29.723 | Triggering next historical data download in queue.
2024-09-24 05:17:29.723 | HD Request # 84 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 05:17:29.723 | HD Request # 84 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 05:17:29.723 | HD Request # 84 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:29.723 | Socket (7) | Creating socket.
2024-09-24 05:17:29.723 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:29.723 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:29.972 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\CLX4.NYMEX.scid. Thread ID: 3296
2024-09-24 05:17:29.979 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:29.979 | Socket (6) | Closed.
2024-09-24 05:17:30.264 | HD Request # 84 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:30.264 | HD Request # 84 | Sending historical data logon request message.
2024-09-24 05:17:30.528 | HD Request # 84 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 05:17:30.794 | HD Request # 84 | Decompressing data.
2024-09-24 05:17:31.058 | HD Request # 84 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 05:17:31.058 | Socket (7) | CloseSocket call.
2024-09-24 05:17:31.058 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:31.058 | Historical data download thread signaled to stop.
2024-09-24 05:17:31.058 | HD Request # 84 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 35.6 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 05:17:31.058 | HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 05:17:31.058 | HD Request # 84 | Completion time: 2s.
2024-09-24 05:17:31.058 | HD Request # 84 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 84
2024-09-24 05:17:31.058 | Removing historical data download ID 84.
2024-09-24 05:17:31.058 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 05:17:31.058 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 05:17:31.058 | HD Request # 84 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:31.058 | Triggering next historical data download in queue.
2024-09-24 05:17:31.058 | HD Request # 85 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 05:17:31.059 | HD Request # 85 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 05:17:31.059 | HD Request # 85 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:31.059 | Socket (6) | Creating socket.
2024-09-24 05:17:31.059 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:31.059 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:31.322 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:31.322 | Socket (7) | Closed.
2024-09-24 05:17:31.598 | HD Request # 85 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:31.598 | HD Request # 85 | Sending historical data logon request message.
2024-09-24 05:17:31.862 | HD Request # 85 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 05:17:32.127 | HD Request # 85 | Decompressing data.
2024-09-24 05:17:32.391 | HD Request # 85 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 05:17:32.391 | Socket (6) | CloseSocket call.
2024-09-24 05:17:32.391 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:32.393 | Historical data download thread signaled to stop.
2024-09-24 05:17:32.393 | HD Request # 85 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 3.8 days) and wrote 0 records for MESU4.CME
2024-09-24 05:17:32.393 | HD Request # 85 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 05:17:32.393 | HD Request # 85 | Completion time: 1s.
2024-09-24 05:17:32.393 | HD Request # 85 | Intraday data download complete for MESU4.CME. Unique request ID: 85
2024-09-24 05:17:32.393 | Removing historical data download ID 85.
2024-09-24 05:17:32.393 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 05:17:32.393 | Intraday chart data file opened for MESU4.CME
2024-09-24 05:17:32.393 | HD Request # 85 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:32.393 | Triggering next historical data download in queue.
2024-09-24 05:17:32.393 | HD Request # 86 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 05:17:32.393 | HD Request # 86 | Download start date-time: 2024-09-24 05:01:03.000000. File last date-time: 2024-09-24 05:01:03.048000
2024-09-24 05:17:32.394 | HD Request # 86 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:32.394 | Socket (7) | Creating socket.
2024-09-24 05:17:32.394 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:32.394 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:32.656 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:32.656 | Socket (6) | Closed.
2024-09-24 05:17:32.950 | HD Request # 86 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:32.950 | HD Request # 86 | Sending historical data logon request message.
2024-09-24 05:17:33.222 | HD Request # 86 | Requesting Intraday data. Start date-time: 2024-09-24 05:01:03. Record interval: 0. Symbol: MESZ24
2024-09-24 05:17:33.495 | HD Request # 86 | Decompressing data.
2024-09-24 05:17:33.769 | HD Request # 86 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 05:01:03.048000
2024-09-24 05:17:33.770 | Socket (7) | CloseSocket call.
2024-09-24 05:17:33.770 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:33.773 | Historical data download thread signaled to stop.
2024-09-24 05:17:33.773 | HD Request # 86 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:13.979000.
2024-09-24 05:17:33.773 | HD Request # 86 | Received 682 Intraday data records from 2024-09-24 05:01:03.048000 to 2024-09-24 05:17:31.053000 (16.5 minutes. Delay: 2.7 seconds) and wrote 681 records for MESZ4.CME
2024-09-24 05:17:33.773 | HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:31.053000
2024-09-24 05:17:33.773 | Added 2 Time and Sales records to Intraday data file for MESZ4.CME after download.
2024-09-24 05:17:33.773 | HD Request # 86 | Completion time: 1s.
2024-09-24 05:17:33.773 | HD Request # 86 | Intraday data download complete for MESZ4.CME. Unique request ID: 86
2024-09-24 05:17:33.773 | Removing historical data download ID 86.
2024-09-24 05:17:33.773 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 05:17:33.773 | Intraday chart data file opened for MESZ4.CME
2024-09-24 05:17:33.773 | HD Request # 86 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:33.773 | Triggering next historical data download in queue.
2024-09-24 05:17:33.773 | HD Request # 87 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 05:17:33.774 | HD Request # 87 | Download start date-time: 2024-09-24 05:01:00.000000. File last date-time: 2024-09-24 05:01:00.697000
2024-09-24 05:17:33.774 | HD Request # 87 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:33.774 | Socket (6) | Creating socket.
2024-09-24 05:17:33.774 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:33.774 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:34.042 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:34.042 | Socket (7) | Closed.
2024-09-24 05:17:34.332 | HD Request # 87 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:34.332 | HD Request # 87 | Sending historical data logon request message.
2024-09-24 05:17:34.606 | HD Request # 87 | Requesting Intraday data. Start date-time: 2024-09-24 05:01:00. Record interval: 0. Symbol: MGCZ24
2024-09-24 05:17:34.880 | HD Request # 87 | Decompressing data.
2024-09-24 05:17:35.002 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:35.002 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:35.156 | HD Request # 87 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 05:01:00.697000
2024-09-24 05:17:35.156 | Socket (6) | CloseSocket call.
2024-09-24 05:17:35.156 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:35.317 | Historical data download thread signaled to stop.
2024-09-24 05:17:35.317 | HD Request # 87 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:05.075000.
2024-09-24 05:17:35.317 | HD Request # 87 | Received 611 Intraday data records from 2024-09-24 05:01:00.697000 to 2024-09-24 05:17:29.530000 (16.5 minutes. Delay: 5.8 seconds) and wrote 610 records for MGCZ4.COMEX
2024-09-24 05:17:35.318 | HD Request # 87 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:29.530000
2024-09-24 05:17:35.318 | HD Request # 87 | Completion time: 2s.
2024-09-24 05:17:35.318 | HD Request # 87 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 87
2024-09-24 05:17:35.318 | Removing historical data download ID 87.
2024-09-24 05:17:35.318 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 05:17:35.318 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 05:17:35.318 | HD Request # 87 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:35.318 | Triggering next historical data download in queue.
2024-09-24 05:17:35.318 | HD Request # 88 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 05:17:35.318 | HD Request # 88 | Download start date-time: 2024-09-24 04:59:59.000000. File last date-time: 2024-09-24 04:59:59.311000
2024-09-24 05:17:35.318 | HD Request # 88 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:35.318 | Socket (7) | Creating socket.
2024-09-24 05:17:35.318 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:35.318 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:35.428 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:35.428 | Socket (6) | Closed.
2024-09-24 05:17:35.863 | HD Request # 88 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:35.863 | HD Request # 88 | Sending historical data logon request message.
2024-09-24 05:17:36.128 | HD Request # 88 | Requesting Intraday data. Start date-time: 2024-09-24 04:59:59. Record interval: 0. Symbol: MJYZ24
2024-09-24 05:17:36.396 | HD Request # 88 | Decompressing data.
2024-09-24 05:17:36.667 | HD Request # 88 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 04:59:59.311000
2024-09-24 05:17:36.667 | Socket (7) | CloseSocket call.
2024-09-24 05:17:36.667 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:36.685 | Historical data download thread signaled to stop.
2024-09-24 05:17:36.685 | HD Request # 88 | Timestamp of first Intraday data file record written: 2024-09-24 05:12:38.463000.
2024-09-24 05:17:36.685 | HD Request # 88 | Received 3 Intraday data records from 2024-09-24 04:59:59.311000 to 2024-09-24 05:13:50.248000 (13.8 minutes. Delay: 3.8 minutes) and wrote 2 records for MJYZ4.CME
2024-09-24 05:17:36.686 | HD Request # 88 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:13:50.248000
2024-09-24 05:17:36.686 | HD Request # 88 | Completion time: 1s.
2024-09-24 05:17:36.686 | HD Request # 88 | Intraday data download complete for MJYZ4.CME. Unique request ID: 88
2024-09-24 05:17:36.686 | Removing historical data download ID 88.
2024-09-24 05:17:36.686 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 05:17:36.686 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 05:17:36.686 | HD Request # 88 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:36.686 | Triggering next historical data download in queue.
2024-09-24 05:17:36.686 | HD Request # 89 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 05:17:36.686 | HD Request # 89 | Download start date-time: 2024-09-24 05:01:02.000000. File last date-time: 2024-09-24 05:01:02.865000
2024-09-24 05:17:36.686 | HD Request # 89 | Using server: ds32.sierracharts.com port 10149
2024-09-24 05:17:36.686 | Socket (6) | Creating socket.
2024-09-24 05:17:36.686 | Socket (6) | New receive buffer size: 0
2024-09-24 05:17:36.686 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:36.933 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:36.934 | Socket (7) | Closed.
2024-09-24 05:17:37.228 | HD Request # 89 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:37.228 | HD Request # 89 | Sending historical data logon request message.
2024-09-24 05:17:37.492 | HD Request # 89 | Requesting Intraday data. Start date-time: 2024-09-24 05:01:02. Record interval: 0. Symbol: MNQZ24
2024-09-24 05:17:37.757 | HD Request # 89 | Decompressing data.
2024-09-24 05:17:38.295 | HD Request # 89 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 05:01:02.223000
2024-09-24 05:17:38.296 | Socket (6) | CloseSocket call.
2024-09-24 05:17:38.296 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:38.296 | Historical data download thread signaled to stop.
2024-09-24 05:17:38.296 | HD Request # 89 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:05.258000.
2024-09-24 05:17:38.297 | HD Request # 89 | Received 3226 Intraday data records from 2024-09-24 05:01:02.223000 to 2024-09-24 05:17:35.646000 (16.6 minutes. Delay: 2.7 seconds) and wrote 3223 records for MNQZ4.CME
2024-09-24 05:17:38.297 | HD Request # 89 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:35.646000
2024-09-24 05:17:38.297 | Added 11 Time and Sales records to Intraday data file for MNQZ4.CME after download.
2024-09-24 05:17:38.297 | HD Request # 89 | Completion time: 2s.
2024-09-24 05:17:38.297 | HD Request # 89 | Intraday data download complete for MNQZ4.CME. Unique request ID: 89
2024-09-24 05:17:38.297 | Removing historical data download ID 89.
2024-09-24 05:17:38.297 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 05:17:38.297 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 05:17:38.297 | HD Request # 89 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:38.297 | Triggering next historical data download in queue.
2024-09-24 05:17:38.297 | HD Request # 90 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 05:17:38.297 | HD Request # 90 | Download start date-time: 2024-09-24 05:00:57.000000. File last date-time: 2024-09-24 05:00:57.657000
2024-09-24 05:17:38.297 | HD Request # 90 | Using server: ds32.sierracharts.com port 10150
2024-09-24 05:17:38.297 | Socket (7) | Creating socket.
2024-09-24 05:17:38.297 | Socket (7) | New receive buffer size: 0
2024-09-24 05:17:38.297 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 05:17:38.560 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 05:17:38.560 | Socket (6) | Closed.
2024-09-24 05:17:38.844 | HD Request # 90 | Setting DTC encoding to Binary VLS
2024-09-24 05:17:38.844 | HD Request # 90 | Sending historical data logon request message.
2024-09-24 05:17:39.110 | HD Request # 90 | Requesting Intraday data. Start date-time: 2024-09-24 05:00:57. Record interval: 0. Symbol: NQZ24
2024-09-24 05:17:39.377 | HD Request # 90 | Decompressing data.
2024-09-24 05:17:39.647 | HD Request # 90 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 05:00:57.657000
2024-09-24 05:17:39.647 | Socket (7) | CloseSocket call.
2024-09-24 05:17:39.647 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 05:17:39.761 | Historical data download thread signaled to stop.
2024-09-24 05:17:39.761 | HD Request # 90 | Timestamp of first Intraday data file record written: 2024-09-24 05:01:05.835000.
2024-09-24 05:17:39.761 | HD Request # 90 | Received 984 Intraday data records from 2024-09-24 05:00:57.657000 to 2024-09-24 05:17:37.078000 (16.7 minutes. Delay: 2.7 seconds) and wrote 983 records for NQZ4.CME
2024-09-24 05:17:39.762 | HD Request # 90 | Add time&sales data | Remembered last file record date-time: 2024-09-24 09:17:37.078000
2024-09-24 05:17:39.762 | Added 1 Time and Sales records to Intraday data file for NQZ4.CME after download.
2024-09-24 05:17:39.762 | HD Request # 90 | Completion time: 1s.
2024-09-24 05:17:39.762 | HD Request # 90 | Intraday data download complete for NQZ4.CME. Unique request ID: 90
2024-09-24 05:17:39.762 | Removing historical data download ID 90.
2024-09-24 05:17:39.762 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 05:17:39.762 | Intraday chart data file opened for NQZ4.CME
2024-09-24 05:17:39.762 | HD Request # 90 | Enabling Intraday chart updating for symbol.
2024-09-24 05:17:39.762 | No download requests in the queue to start downloads for.
2024-09-24 05:17:39.915 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 05:17:39.915 | Socket (7) | Closed.
2024-09-24 05:17:40.026 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:40.026 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 05:17:40.026 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 05:17:41.758 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-24 05:17:41.758 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 05:17:41.758 | DTC Client socket (2) | Closed.
2024-09-24 05:17:45.046 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-24 05:17:50.086 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AZ4.CME.scid. Thread ID: 3296
2024-09-24 05:26:28.763 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MJYZ4.CME.scid. Thread ID: 3296
2024-09-24 06:41:41.320 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Creating socket. Using TLS 1.2.
2024-09-24 06:41:41.321 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | New receive buffer size: 0
2024-09-24 06:41:41.321 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Connecting to IP: 216.66.0.130.
2024-09-24 06:41:43.679 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | CloseSocket call.
2024-09-24 06:41:43.679 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Shutdown started. Waiting for graceful close.
2024-09-24 06:41:43.937 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Socket gracefully closed by remote side.
2024-09-24 06:41:43.937 | HTTPS connection ID:7 to downloads.rithmic.com:443 for request ID:7 (2) | Closed.
2024-09-24 07:02:05.609 | Chat | Message response. Chat ID: 429. Request ID: 1134626526
2024-09-24 07:02:37.141 | Chat | Message response. Chat ID: 429. Request ID: 1134626527
2024-09-24 07:28:19.888 | Chat | Message response. Chat ID: 429. Request ID: 1134626528
2024-09-24 08:26:52.552 | ESZ4.CME[M] 5 Min #12 | Reloading chart.
2024-09-24 08:26:53.430 | ESZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 08:26:53.441 | ESZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-24 09:50:06.898 | Chat | Message response. Chat ID: 429. Request ID: 1134626529
2024-09-24 10:00:52.074 | Chat | Message response. Chat ID: 429. Request ID: 1134626530
2024-09-24 10:00:52.925 | Chat | Message response. Chat ID: 429. Request ID: 1134626531
2024-09-24 10:00:52.959 | Chat | Message response. Chat ID: 429. Request ID: 1134626532
2024-09-24 10:01:04.664 | Chat | Message response. Chat ID: 429. Request ID: 1134626533
2024-09-24 10:01:08.397 | Chat | Message response. Chat ID: 429. Request ID: 1134626534
2024-09-24 10:02:19.159 | Chat | Message response. Chat ID: 429. Request ID: 1134626535
2024-09-24 10:02:44.633 | Chat | Message response. Chat ID: 429. Request ID: 1134626536
2024-09-24 10:02:46.204 | Chat | Message response. Chat ID: 429. Request ID: 1134626537
2024-09-24 10:02:47.705 | Chat | Message response. Chat ID: 429. Request ID: 1134626538
2024-09-24 10:02:50.282 | Chat | Message response. Chat ID: 429. Request ID: 1134626539
2024-09-24 10:02:53.444 | Chat | Message response. Chat ID: 429. Request ID: 1134626540
2024-09-24 10:02:59.084 | Chat | Message response. Chat ID: 429. Request ID: 1134626541
2024-09-24 10:03:01.923 | Chat | Message response. Chat ID: 429. Request ID: 1134626542
2024-09-24 10:03:04.572 | Chat | Message response. Chat ID: 429. Request ID: 1134626543
2024-09-24 10:03:06.540 | Chat | Message response. Chat ID: 429. Request ID: 1134626544
2024-09-24 10:18:06.528 | Chat | Message response. Chat ID: 429. Request ID: 1134626545
2024-09-24 11:46:12.354 | DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-24 11:46:12.354 | DTC Client socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:46:12.377 | DTC Client socket (5) | CloseSocket call.
2024-09-24 11:46:12.377 | DTC Client socket (5) | Max send buffers used during socket life: 4
2024-09-24 11:46:12.377 | DTC Client socket (5) | Max send buffer size during socket life: 1401
2024-09-24 11:46:12.377 | DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 11:46:12.377 | DTC Client socket (5) | Closed.
2024-09-24 11:46:12.377 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 11:46:12.378 | DTC Client socket (0) | CloseSocket call.
2024-09-24 11:46:12.378 | Denali Data Feed | Disconnected from the server.
2024-09-24 11:46:12.378 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 11:46:15.395 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 11:46:15.395 | DTC Client socket (5) | Creating socket.
2024-09-24 11:46:15.395 | DTC Client socket (5) | New receive buffer size: 0
2024-09-24 11:46:15.395 | DTC Client socket (5) | Connecting to IP: 202.52.152.130.
2024-09-24 11:46:36.441 | DTC Client socket (5) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 11:46:36.443 | DTC Client socket (5) | CloseSocket call.
2024-09-24 11:46:36.443 | Denali Data Feed | Failed connections: 1
2024-09-24 11:46:36.443 | DTC Client socket (0) | CloseSocket call.
2024-09-24 11:46:36.443 | Denali Data Feed | Disconnected from the server.
2024-09-24 11:46:36.443 | DTC Client socket (5) | Closed.
2024-09-24 11:46:36.443 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 11:46:38.388 | File >> Reconnect selected.
2024-09-24 11:46:38.658 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 11:46:38.659 | DTC Client socket (1) | CloseSocket call.
2024-09-24 11:46:38.659 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-09-24 11:46:38.659 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-09-24 11:46:38.659 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:38.659 | DTC Client socket (0) | CloseSocket call.
2024-09-24 11:46:38.659 | Denali Data Feed | Disconnected from the server.
2024-09-24 11:46:38.659 | SC Data with Depth | Waiting for socket receive thread to end
2024-09-24 11:46:38.660 | DTC Client socket (4) | CloseSocket call.
2024-09-24 11:46:38.660 | SC Data with Depth | Disconnected from the server.
2024-09-24 11:46:38.660 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:38.660 | Rithmic Direct - DTC | Disconnected.
2024-09-24 11:46:38.660 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 11:46:38.930 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 11:46:38.930 | DTC Client socket (1) | Closed.
2024-09-24 11:46:39.214 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-09-24 11:46:39.215 | DTC Client socket (4) | Closed.
2024-09-24 11:46:42.654 |
2024-09-24 11:46:42.655 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 11:46:42.655 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 11:46:42.655 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 11:46:42.963 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 11:46:42.963 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 11:46:42.963 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 11:46:43.209 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 11:46:43.209 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 11:46:43.209 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 11:46:43.209 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Received logon response.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Server Name: .
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 11:46:43.954 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 11:46:43.956 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 11:46:43.956 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 11:46:43.956 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 11:46:43.956 | Using symbol data fast lookup vector
2024-09-24 11:46:43.956 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 11:46:43.956 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 11:46:43.956 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 11:46:43.956 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 11:46:43.956 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 11:46:43.956 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 11:46:43.956 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 11:46:43.956 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 11:46:43.956 | DTC Client socket (2) | Creating socket.
2024-09-24 11:46:43.956 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 11:46:43.956 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 11:46:44.231 | Denali Data Feed | Network connection to server complete.
2024-09-24 11:46:44.231 | Denali Data Feed | Starting socket receive thread.
2024-09-24 11:46:44.231 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 11:46:44.264 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 11:46:44.264 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 3 Service code: cme
2024-09-24 11:46:44.264 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 3
2024-09-24 11:46:44.264 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 11:46:44.264 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.264 | Triggering next historical data download in queue.
2024-09-24 11:46:44.264 | Delaying start of download for MESZ4.CME.
2024-09-24 11:46:44.268 | Mapping MJYZ4.CME to MJYZ24. Service code: cme
2024-09-24 11:46:44.268 | Denali Data Feed | Starting real-time market data updates for: MJYZ4.CME (MJYZ24). ID: 4 Service code: cme
2024-09-24 11:46:44.268 | Denali Data Feed | Requesting security definition data for: MJYZ4.CME (MJYZ24). ID: 4
2024-09-24 11:46:44.268 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 11:46:44.268 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.268 | Triggering next historical data download in queue.
2024-09-24 11:46:44.270 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 11:46:44.270 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 5 Service code: cme
2024-09-24 11:46:44.270 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 5
2024-09-24 11:46:44.270 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 11:46:44.270 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.270 | Triggering next historical data download in queue.
2024-09-24 11:46:44.435 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-24 11:46:44.435 | Denali Data Feed | Sending logon request message.
2024-09-24 11:46:44.435 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 11:46:44.435 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 11:46:44.435 | Triggering next historical data download in queue.
2024-09-24 11:46:44.435 | Mapping 6AZ4.CME to 6AZ24. Service code: cme
2024-09-24 11:46:44.435 | Denali Data Feed | Starting real-time market data updates for: 6AZ4.CME (6AZ24). ID: 6 Service code: cme
2024-09-24 11:46:44.435 | Denali Data Feed | Requesting security definition data for: 6AZ4.CME (6AZ24). ID: 6
2024-09-24 11:46:44.435 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 11:46:44.435 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.436 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 11:46:44.436 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 7 Service code: cme
2024-09-24 11:46:44.436 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 7
2024-09-24 11:46:44.436 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 11:46:44.436 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.436 | Triggering next historical data download in queue.
2024-09-24 11:46:44.499 | Mapping M6AZ4.CME to M6AZ24. Service code: cme
2024-09-24 11:46:44.499 | Denali Data Feed | Starting real-time market data updates for: M6AZ4.CME (M6AZ24). ID: 8 Service code: cme
2024-09-24 11:46:44.499 | Denali Data Feed | Requesting security definition data for: M6AZ4.CME (M6AZ24). ID: 8
2024-09-24 11:46:44.499 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 11:46:44.499 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.499 | Triggering next historical data download in queue.
2024-09-24 11:46:44.499 | Mapping MCLU4.NYMEX to MCLU24. Service code: nymex
2024-09-24 11:46:44.499 | Denali Data Feed | Starting real-time market data updates for: MCLU4.NYMEX (MCLU24). ID: 9 Service code: nymex
2024-09-24 11:46:44.499 | Denali Data Feed | Requesting security definition data for: MCLU4.NYMEX (MCLU24). ID: 9
2024-09-24 11:46:44.499 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 11:46:44.499 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 11:46:44.499 | Mapping CLX4.NYMEX to CLX24. Service code: nymex
2024-09-24 11:46:44.499 | Denali Data Feed | Starting real-time market data updates for: CLX4.NYMEX (CLX24). ID: 10 Service code: nymex
2024-09-24 11:46:44.499 | Denali Data Feed | Requesting security definition data for: CLX4.NYMEX (CLX24). ID: 10
2024-09-24 11:46:44.499 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 11:46:44.499 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 11:46:44.500 | Mapping 6JZ4.CME to 6JZ24. Service code: cme
2024-09-24 11:46:44.500 | Denali Data Feed | Starting real-time market data updates for: 6JZ4.CME (6JZ24). ID: 11 Service code: cme
2024-09-24 11:46:44.500 | Denali Data Feed | Requesting security definition data for: 6JZ4.CME (6JZ24). ID: 11
2024-09-24 11:46:44.500 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 11:46:44.500 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.500 | Triggering next historical data download in queue.
2024-09-24 11:46:44.532 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2024-09-24 11:46:44.532 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 12 Service code: comex
2024-09-24 11:46:44.532 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 12
2024-09-24 11:46:44.532 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 11:46:44.532 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 11:46:44.532 | Triggering next historical data download in queue.
2024-09-24 11:46:44.591 | Mapping ESU4.CME to ESU24. Service code: cme
2024-09-24 11:46:44.591 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 13 Service code: cme
2024-09-24 11:46:44.591 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 13
2024-09-24 11:46:44.591 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 11:46:44.591 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 11:46:44.591 | Triggering next historical data download in queue.
2024-09-24 11:46:44.591 | Mapping MGCZ4.COMEX to MGCZ24. Service code: comex
2024-09-24 11:46:44.591 | Denali Data Feed | Starting real-time market data updates for: MGCZ4.COMEX (MGCZ24). ID: 14 Service code: comex
2024-09-24 11:46:44.591 | Denali Data Feed | Requesting security definition data for: MGCZ4.COMEX (MGCZ24). ID: 14
2024-09-24 11:46:44.591 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 11:46:44.591 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 11:46:44.618 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 11:46:44.618 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 15 Service code: cme
2024-09-24 11:46:44.618 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 15
2024-09-24 11:46:44.618 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 11:46:44.618 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 11:46:44.618 | Triggering next historical data download in queue.
2024-09-24 11:46:44.632 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 16 Service code: fxstatscalc
2024-09-24 11:46:44.632 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443
2024-09-24 11:46:44.632 | SC Data with Depth | Requesting security definition data for: USDX. ID: 16
2024-09-24 11:46:44.632 | Added historical Intraday data request for USDX to the queue.
2024-09-24 11:46:44.632 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2024-09-24 11:46:44.632 | Triggering next historical data download in queue.
2024-09-24 11:46:44.748 | DTC Client socket (4) | Creating socket.
2024-09-24 11:46:44.748 | DTC Client socket (4) | New receive buffer size: 0
2024-09-24 11:46:44.748 | DTC Client socket (4) | Connecting to IP: 67.214.125.7.
2024-09-24 11:46:45.027 | SC Data with Depth | Network connection to server complete.
2024-09-24 11:46:45.027 | SC Data with Depth | Starting socket receive thread.
2024-09-24 11:46:45.027 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 11:46:45.311 | SC Data with Depth | Setting DTC encoding to Binary VLS
2024-09-24 11:46:45.311 | SC Data with Depth | Sending logon request message.
2024-09-24 11:46:46.099 | SC Data with Depth | Received logon response.
2024-09-24 11:46:46.099 | SC Data with Depth | Server Name: SC Realtime Server.
2024-09-24 11:46:46.099 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2024-09-24 11:46:46.099 | SC Data with Depth | Successfully connected.
2024-09-24 11:46:46.099 | SC Data with Depth | Trading is not supported.
2024-09-24 11:46:46.099 | SC Data with Depth | MarketDepthIsSupported: 1
2024-09-24 11:46:46.099 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2024-09-24 11:46:46.674 | Denali Data Feed | Received logon response.
2024-09-24 11:46:46.674 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-24 11:46:46.674 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-24 11:46:46.674 | Denali Data Feed | Successfully connected.
2024-09-24 11:46:46.674 | Denali Data Feed | Trading is not supported.
2024-09-24 11:46:46.674 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: 6AZ4.CME -> 6AZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: 6JZ4.CME -> 6JZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: CLX4.NYMEX -> CLX24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ4.CME -> ESZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: M6AZ4.CME -> M6AZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MCLU4.NYMEX -> MCLU24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ4.CME -> MESZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MGCZ4.COMEX -> MGCZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MJYZ4.CME -> MJYZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ4.CME -> MNQZ24
2024-09-24 11:46:46.674 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2024-09-24 11:46:46.888 | SC Data with Depth | Received security definition for symbol USDX
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-24 11:46:47.370 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-24 11:46:47.370 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-24 11:46:47.370 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-24 11:46:49.597 | Requesting market depth updates for: 6AZ4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: 6JZ4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: CLX4.NYMEX if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: GCZ4.COMEX if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: MESU4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 11:46:49.597 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-24 11:46:50.032 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-24 11:46:52.994 | HD Request # 91 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 11:46:52.994 | HD Request # 91 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.178000
2024-09-24 11:46:52.994 | HD Request # 91 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:46:53.106 | Socket (5) | Creating socket.
2024-09-24 11:46:53.106 | Socket (5) | New receive buffer size: 0
2024-09-24 11:46:53.106 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:53.680 | HD Request # 91 | Setting DTC encoding to Binary VLS
2024-09-24 11:46:53.680 | HD Request # 91 | Sending historical data logon request message.
2024-09-24 11:46:54.450 | HD Request # 91 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: MESZ24
2024-09-24 11:46:54.729 | HD Request # 91 | Decompressing data.
2024-09-24 11:46:55.009 | HD Request # 91 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 11:45:40.163000
2024-09-24 11:46:55.009 | Socket (5) | CloseSocket call.
2024-09-24 11:46:55.009 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:55.036 | Historical data download thread signaled to stop.
2024-09-24 11:46:55.036 | HD Request # 91 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.961000.
2024-09-24 11:46:55.036 | HD Request # 91 | Received 1026 Intraday data records from 2024-09-24 11:45:40.163000 to 2024-09-24 11:46:55.527000 (75.4 seconds. Delay: -0.5 seconds) and wrote 1024 records for MESZ4.CME
2024-09-24 11:46:55.036 | HD Request # 91 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:46:55.527000
2024-09-24 11:46:55.036 | Added 9 Time and Sales records to Intraday data file for MESZ4.CME after download.
2024-09-24 11:46:55.036 | HD Request # 91 | Completion time: 3s.
2024-09-24 11:46:55.036 | HD Request # 91 | Intraday data download complete for MESZ4.CME. Unique request ID: 91
2024-09-24 11:46:55.036 | Removing historical data download ID 91.
2024-09-24 11:46:55.036 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 11:46:55.036 | Intraday chart data file opened for MESZ4.CME
2024-09-24 11:46:55.036 | HD Request # 91 | Enabling Intraday chart updating for symbol.
2024-09-24 11:46:55.036 | Triggering next historical data download in queue.
2024-09-24 11:46:55.036 | HD Request # 92 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 11:46:55.037 | HD Request # 92 | Download start date-time: 2024-09-24 11:19:41.000000. File last date-time: 2024-09-24 11:19:41.593000
2024-09-24 11:46:55.037 | HD Request # 92 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:46:55.037 | Socket (6) | Creating socket.
2024-09-24 11:46:55.037 | Socket (6) | New receive buffer size: 0
2024-09-24 11:46:55.037 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:55.288 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:46:55.288 | Socket (5) | Closed.
2024-09-24 11:46:55.590 | HD Request # 92 | Setting DTC encoding to Binary VLS
2024-09-24 11:46:55.590 | HD Request # 92 | Sending historical data logon request message.
2024-09-24 11:46:56.351 | HD Request # 92 | Requesting Intraday data. Start date-time: 2024-09-24 11:19:41. Record interval: 0. Symbol: MJYZ24
2024-09-24 11:46:56.621 | HD Request # 92 | Decompressing data.
2024-09-24 11:46:56.622 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 3296
2024-09-24 11:46:56.890 | HD Request # 92 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 11:19:41.593000
2024-09-24 11:46:56.890 | Socket (6) | CloseSocket call.
2024-09-24 11:46:56.890 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:56.910 | Historical data download thread signaled to stop.
2024-09-24 11:46:56.910 | HD Request # 92 | Received 1 Intraday data record from 2024-09-24 11:19:41.593000 to 2024-09-24 11:19:41.593000 (0.0 seconds. Delay: 27.3 minutes) and wrote 0 records for MJYZ4.CME
2024-09-24 11:46:56.910 | HD Request # 92 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:19:41.593000
2024-09-24 11:46:56.910 | HD Request # 92 | Completion time: 1s.
2024-09-24 11:46:56.910 | HD Request # 92 | Intraday data download complete for MJYZ4.CME. Unique request ID: 92
2024-09-24 11:46:56.910 | Removing historical data download ID 92.
2024-09-24 11:46:56.910 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 11:46:56.910 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 11:46:56.910 | HD Request # 92 | Enabling Intraday chart updating for symbol.
2024-09-24 11:46:56.910 | Triggering next historical data download in queue.
2024-09-24 11:46:56.910 | HD Request # 93 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 11:46:56.910 | HD Request # 93 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.546000
2024-09-24 11:46:56.910 | HD Request # 93 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:46:56.910 | Socket (5) | Creating socket.
2024-09-24 11:46:56.910 | Socket (5) | New receive buffer size: 0
2024-09-24 11:46:56.910 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:57.159 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:46:57.159 | Socket (6) | Closed.
2024-09-24 11:46:57.461 | HD Request # 93 | Setting DTC encoding to Binary VLS
2024-09-24 11:46:57.461 | HD Request # 93 | Sending historical data logon request message.
2024-09-24 11:46:57.730 | HD Request # 93 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: NQZ24
2024-09-24 11:46:58.000 | HD Request # 93 | Decompressing data.
2024-09-24 11:46:58.279 | HD Request # 93 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 11:45:40.005000
2024-09-24 11:46:58.279 | Socket (5) | CloseSocket call.
2024-09-24 11:46:58.279 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:58.280 | Historical data download thread signaled to stop.
2024-09-24 11:46:58.280 | HD Request # 93 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.767000.
2024-09-24 11:46:58.281 | HD Request # 93 | Received 1559 Intraday data records from 2024-09-24 11:45:40.005000 to 2024-09-24 11:46:59.453002 (79.4 seconds. Delay: -1.2 seconds) and wrote 1543 records for NQZ4.CME
2024-09-24 11:46:58.281 | HD Request # 93 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:46:59.453002
2024-09-24 11:46:58.281 | Added 2 Time and Sales records to Intraday data file for NQZ4.CME after download.
2024-09-24 11:46:58.281 | HD Request # 93 | Completion time: 2s.
2024-09-24 11:46:58.281 | HD Request # 93 | Intraday data download complete for NQZ4.CME. Unique request ID: 93
2024-09-24 11:46:58.281 | Removing historical data download ID 93.
2024-09-24 11:46:58.281 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 11:46:58.281 | Intraday chart data file opened for NQZ4.CME
2024-09-24 11:46:58.281 | HD Request # 93 | Enabling Intraday chart updating for symbol.
2024-09-24 11:46:58.281 | Triggering next historical data download in queue.
2024-09-24 11:46:58.281 | HD Request # 94 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 11:46:58.282 | HD Request # 94 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 11:46:58.282 | HD Request # 94 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:46:58.282 | Socket (6) | Creating socket.
2024-09-24 11:46:58.282 | Socket (6) | New receive buffer size: 0
2024-09-24 11:46:58.282 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:58.548 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:46:58.548 | Socket (5) | Closed.
2024-09-24 11:46:58.841 | HD Request # 94 | Setting DTC encoding to Binary VLS
2024-09-24 11:46:58.841 | HD Request # 94 | Sending historical data logon request message.
2024-09-24 11:46:59.110 | HD Request # 94 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 11:46:59.390 | HD Request # 94 | Decompressing data.
2024-09-24 11:46:59.660 | HD Request # 94 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 11:46:59.660 | Socket (6) | CloseSocket call.
2024-09-24 11:46:59.660 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:46:59.661 | Historical data download thread signaled to stop.
2024-09-24 11:46:59.661 | HD Request # 94 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 4.1 days) and wrote 0 records for MESU4.CME
2024-09-24 11:46:59.661 | HD Request # 94 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 11:46:59.661 | HD Request # 94 | Completion time: 1s.
2024-09-24 11:46:59.661 | HD Request # 94 | Intraday data download complete for MESU4.CME. Unique request ID: 94
2024-09-24 11:46:59.661 | Removing historical data download ID 94.
2024-09-24 11:46:59.661 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 11:46:59.661 | Intraday chart data file opened for MESU4.CME
2024-09-24 11:46:59.661 | HD Request # 94 | Enabling Intraday chart updating for symbol.
2024-09-24 11:46:59.661 | Triggering next historical data download in queue.
2024-09-24 11:46:59.661 | HD Request # 95 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 11:46:59.661 | HD Request # 95 | Download start date-time: 2024-09-24 11:45:17.000000. File last date-time: 2024-09-24 11:45:17.821000
2024-09-24 11:46:59.661 | HD Request # 95 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:46:59.661 | Socket (5) | Creating socket.
2024-09-24 11:46:59.661 | Socket (5) | New receive buffer size: 0
2024-09-24 11:46:59.661 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:46:59.931 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:46:59.931 | Socket (6) | Closed.
2024-09-24 11:47:00.232 | HD Request # 95 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:00.232 | HD Request # 95 | Sending historical data logon request message.
2024-09-24 11:47:00.512 | HD Request # 95 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:17. Record interval: 0. Symbol: 6AZ24
2024-09-24 11:47:00.791 | HD Request # 95 | Decompressing data.
2024-09-24 11:47:01.069 | HD Request # 95 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 11:45:17.821000
2024-09-24 11:47:01.070 | Socket (5) | CloseSocket call.
2024-09-24 11:47:01.070 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:01.070 | Historical data download thread signaled to stop.
2024-09-24 11:47:01.070 | HD Request # 95 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:49.371000.
2024-09-24 11:47:01.070 | HD Request # 95 | Received 47 Intraday data records from 2024-09-24 11:45:17.821000 to 2024-09-24 11:46:54.612001 (96.8 seconds. Delay: 6.5 seconds) and wrote 46 records for 6AZ4.CME
2024-09-24 11:47:01.070 | HD Request # 95 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:46:54.612001
2024-09-24 11:47:01.070 | Added 9 Time and Sales records to Intraday data file for 6AZ4.CME after download.
2024-09-24 11:47:01.070 | HD Request # 95 | Completion time: 2s.
2024-09-24 11:47:01.070 | HD Request # 95 | Intraday data download complete for 6AZ4.CME. Unique request ID: 95
2024-09-24 11:47:01.070 | Removing historical data download ID 95.
2024-09-24 11:47:01.070 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 11:47:01.070 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 11:47:01.070 | HD Request # 95 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:01.070 | Triggering next historical data download in queue.
2024-09-24 11:47:01.070 | HD Request # 96 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 11:47:01.071 | HD Request # 96 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.526000
2024-09-24 11:47:01.071 | HD Request # 96 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:01.071 | Socket (6) | Creating socket.
2024-09-24 11:47:01.071 | Socket (6) | New receive buffer size: 0
2024-09-24 11:47:01.071 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:01.350 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:01.350 | Socket (5) | Closed.
2024-09-24 11:47:01.618 | HD Request # 96 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:01.618 | HD Request # 96 | Sending historical data logon request message.
2024-09-24 11:47:01.657 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:01.887 | HD Request # 96 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: ESZ24
2024-09-24 11:47:02.156 | HD Request # 96 | Decompressing data.
2024-09-24 11:47:02.428 | HD Request # 96 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 11:45:40.525000
2024-09-24 11:47:02.428 | Socket (6) | CloseSocket call.
2024-09-24 11:47:02.428 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:02.453 | Historical data download thread signaled to stop.
2024-09-24 11:47:02.453 | HD Request # 96 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.986000.
2024-09-24 11:47:02.453 | HD Request # 96 | Received 1954 Intraday data records from 2024-09-24 11:45:40.525000 to 2024-09-24 11:47:03.398000 (82.9 seconds. Delay: -0.9 seconds) and wrote 1944 records for ESZ4.CME
2024-09-24 11:47:02.453 | HD Request # 96 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:03.398000
2024-09-24 11:47:02.453 | HD Request # 96 | Completion time: 1s.
2024-09-24 11:47:02.453 | HD Request # 96 | Intraday data download complete for ESZ4.CME. Unique request ID: 96
2024-09-24 11:47:02.453 | Removing historical data download ID 96.
2024-09-24 11:47:02.453 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 11:47:02.453 | Intraday chart data file opened for ESZ4.CME
2024-09-24 11:47:02.453 | HD Request # 96 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:02.453 | Triggering next historical data download in queue.
2024-09-24 11:47:02.453 | HD Request # 97 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 11:47:02.453 | HD Request # 97 | Download start date-time: 2024-09-24 11:42:50.000000. File last date-time: 2024-09-24 11:42:50.872000
2024-09-24 11:47:02.454 | HD Request # 97 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:47:02.454 | Socket (5) | Creating socket.
2024-09-24 11:47:02.454 | Socket (5) | New receive buffer size: 0
2024-09-24 11:47:02.454 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:02.697 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:02.697 | Socket (6) | Closed.
2024-09-24 11:47:03.024 | HD Request # 97 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:03.024 | HD Request # 97 | Sending historical data logon request message.
2024-09-24 11:47:03.303 | HD Request # 97 | Requesting Intraday data. Start date-time: 2024-09-24 11:42:50. Record interval: 0. Symbol: M6AZ24
2024-09-24 11:47:03.321 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Creating socket. Using TLS 1.2.
2024-09-24 11:47:03.321 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | New receive buffer size: 0
2024-09-24 11:47:03.321 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Connecting to IP: 216.66.0.130.
2024-09-24 11:47:03.582 | HD Request # 97 | Decompressing data.
2024-09-24 11:47:03.860 | HD Request # 97 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 11:42:50.872000
2024-09-24 11:47:03.860 | Socket (5) | CloseSocket call.
2024-09-24 11:47:03.860 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:03.871 | Historical data download thread signaled to stop.
2024-09-24 11:47:03.871 | HD Request # 97 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:49.372000.
2024-09-24 11:47:03.871 | HD Request # 97 | Received 5 Intraday data records from 2024-09-24 11:42:50.872000 to 2024-09-24 11:46:12.835000 (3.4 minutes. Delay: 51.0 seconds) and wrote 4 records for M6AZ4.CME
2024-09-24 11:47:03.871 | HD Request # 97 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:46:12.835000
2024-09-24 11:47:03.871 | HD Request # 97 | Completion time: 1s.
2024-09-24 11:47:03.871 | HD Request # 97 | Intraday data download complete for M6AZ4.CME. Unique request ID: 97
2024-09-24 11:47:03.871 | Removing historical data download ID 97.
2024-09-24 11:47:03.871 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 11:47:03.871 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 11:47:03.871 | HD Request # 97 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:03.871 | Triggering next historical data download in queue.
2024-09-24 11:47:03.871 | HD Request # 98 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 11:47:03.872 | HD Request # 98 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 11:47:03.872 | HD Request # 98 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:03.872 | Socket (7) | Creating socket.
2024-09-24 11:47:03.872 | Socket (7) | New receive buffer size: 0
2024-09-24 11:47:03.872 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:04.139 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:04.139 | Socket (5) | Closed.
2024-09-24 11:47:04.434 | HD Request # 98 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:04.434 | HD Request # 98 | Sending historical data logon request message.
2024-09-24 11:47:04.711 | HD Request # 98 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 11:47:04.990 | HD Request # 98 | Decompressing data.
2024-09-24 11:47:05.267 | HD Request # 98 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 11:47:05.267 | Socket (7) | CloseSocket call.
2024-09-24 11:47:05.267 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:05.286 | Historical data download thread signaled to stop.
2024-09-24 11:47:05.286 | HD Request # 98 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 35.9 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 11:47:05.287 | HD Request # 98 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 11:47:05.287 | HD Request # 98 | Completion time: 2s.
2024-09-24 11:47:05.287 | HD Request # 98 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 98
2024-09-24 11:47:05.287 | Removing historical data download ID 98.
2024-09-24 11:47:05.287 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 11:47:05.287 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 11:47:05.287 | HD Request # 98 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:05.287 | Triggering next historical data download in queue.
2024-09-24 11:47:05.287 | HD Request # 99 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 11:47:05.287 | HD Request # 99 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.177004
2024-09-24 11:47:05.287 | HD Request # 99 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:47:05.287 | Socket (8) | Creating socket.
2024-09-24 11:47:05.287 | Socket (8) | New receive buffer size: 0
2024-09-24 11:47:05.287 | Socket (8) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:05.435 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | CloseSocket call.
2024-09-24 11:47:05.435 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:05.544 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 11:47:05.544 | Socket (7) | Closed.
2024-09-24 11:47:05.689 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:05.689 | HTTPS connection ID:8 to downloads.rithmic.com:443 for request ID:8 (6) | Closed.
2024-09-24 11:47:05.858 | HD Request # 99 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:05.858 | HD Request # 99 | Sending historical data logon request message.
2024-09-24 11:47:06.139 | HD Request # 99 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: CLX24
2024-09-24 11:47:06.419 | HD Request # 99 | Decompressing data.
2024-09-24 11:47:06.699 | HD Request # 99 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 11:45:40.177000
2024-09-24 11:47:06.699 | Socket (8) | CloseSocket call.
2024-09-24 11:47:06.699 | Socket (8) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:06.702 | Historical data download thread signaled to stop.
2024-09-24 11:47:06.702 | HD Request # 99 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:41.162000.
2024-09-24 11:47:06.702 | HD Request # 99 | Received 257 Intraday data records from 2024-09-24 11:45:40.177000 to 2024-09-24 11:47:05.117007 (84.9 seconds. Delay: 1.6 seconds) and wrote 252 records for CLX4.NYMEX
2024-09-24 11:47:06.702 | HD Request # 99 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:05.117007
2024-09-24 11:47:06.702 | Added 2 Time and Sales records to Intraday data file for CLX4.NYMEX after download.
2024-09-24 11:47:06.702 | HD Request # 99 | Completion time: 1s.
2024-09-24 11:47:06.702 | HD Request # 99 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 99
2024-09-24 11:47:06.702 | Removing historical data download ID 99.
2024-09-24 11:47:06.702 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 11:47:06.702 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 11:47:06.702 | HD Request # 99 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:06.702 | Triggering next historical data download in queue.
2024-09-24 11:47:06.702 | HD Request # 100 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 11:47:06.702 | HD Request # 100 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.439000
2024-09-24 11:47:06.702 | HD Request # 100 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:06.702 | Socket (5) | Creating socket.
2024-09-24 11:47:06.702 | Socket (5) | New receive buffer size: 0
2024-09-24 11:47:06.702 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:06.705 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:06.706 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:06.979 | Socket (8) | Socket gracefully closed by remote side.
2024-09-24 11:47:06.979 | Socket (8) | Closed.
2024-09-24 11:47:07.267 | HD Request # 100 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:07.267 | HD Request # 100 | Sending historical data logon request message.
2024-09-24 11:47:07.542 | HD Request # 100 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: 6JZ24
2024-09-24 11:47:07.819 | HD Request # 100 | Decompressing data.
2024-09-24 11:47:08.094 | HD Request # 100 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 11:45:40.439000
2024-09-24 11:47:08.094 | Socket (5) | CloseSocket call.
2024-09-24 11:47:08.094 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:08.103 | Historical data download thread signaled to stop.
2024-09-24 11:47:08.103 | HD Request # 100 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:44.453000.
2024-09-24 11:47:08.103 | HD Request # 100 | Received 82 Intraday data records from 2024-09-24 11:45:40.439000 to 2024-09-24 11:47:02.393000 (82.0 seconds. Delay: 5.7 seconds) and wrote 81 records for 6JZ4.CME
2024-09-24 11:47:08.103 | HD Request # 100 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:02.393000
2024-09-24 11:47:08.103 | HD Request # 100 | Completion time: 2s.
2024-09-24 11:47:08.103 | HD Request # 100 | Intraday data download complete for 6JZ4.CME. Unique request ID: 100
2024-09-24 11:47:08.103 | Removing historical data download ID 100.
2024-09-24 11:47:08.103 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 11:47:08.103 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 11:47:08.103 | HD Request # 100 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:08.103 | Triggering next historical data download in queue.
2024-09-24 11:47:08.103 | HD Request # 101 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 11:47:08.103 | HD Request # 101 | Download start date-time: 2024-09-24 11:45:39.000000. File last date-time: 2024-09-24 11:45:39.150001
2024-09-24 11:47:08.103 | HD Request # 101 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:47:08.104 | Socket (6) | Creating socket.
2024-09-24 11:47:08.104 | Socket (6) | New receive buffer size: 0
2024-09-24 11:47:08.104 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:08.369 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:08.369 | Socket (5) | Closed.
2024-09-24 11:47:08.669 | HD Request # 101 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:08.669 | HD Request # 101 | Sending historical data logon request message.
2024-09-24 11:47:08.945 | HD Request # 101 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:39. Record interval: 0. Symbol: GCZ24
2024-09-24 11:47:09.222 | HD Request # 101 | Decompressing data.
2024-09-24 11:47:09.499 | HD Request # 101 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 11:45:39.150000
2024-09-24 11:47:09.499 | Socket (6) | CloseSocket call.
2024-09-24 11:47:09.499 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:09.522 | Historical data download thread signaled to stop.
2024-09-24 11:47:09.522 | HD Request # 101 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.994000.
2024-09-24 11:47:09.523 | HD Request # 101 | Received 378 Intraday data records from 2024-09-24 11:45:39.150000 to 2024-09-24 11:47:08.675000 (89.5 seconds. Delay: 0.8 seconds) and wrote 376 records for GCZ4.COMEX
2024-09-24 11:47:09.523 | HD Request # 101 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:08.675000
2024-09-24 11:47:09.523 | Added 1 Time and Sales records to Intraday data file for GCZ4.COMEX after download.
2024-09-24 11:47:09.523 | HD Request # 101 | Completion time: 1s.
2024-09-24 11:47:09.523 | HD Request # 101 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 101
2024-09-24 11:47:09.523 | Removing historical data download ID 101.
2024-09-24 11:47:09.523 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 11:47:09.523 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 11:47:09.523 | HD Request # 101 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:09.523 | Triggering next historical data download in queue.
2024-09-24 11:47:09.523 | HD Request # 102 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 11:47:09.524 | HD Request # 102 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 11:47:09.524 | HD Request # 102 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:09.524 | Socket (5) | Creating socket.
2024-09-24 11:47:09.524 | Socket (5) | New receive buffer size: 0
2024-09-24 11:47:09.524 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:09.775 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:09.775 | Socket (6) | Closed.
2024-09-24 11:47:10.102 | HD Request # 102 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:10.102 | HD Request # 102 | Sending historical data logon request message.
2024-09-24 11:47:10.383 | HD Request # 102 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 11:47:10.665 | HD Request # 102 | Decompressing data.
2024-09-24 11:47:10.946 | HD Request # 102 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 11:47:10.946 | Socket (5) | CloseSocket call.
2024-09-24 11:47:10.946 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:10.956 | Historical data download thread signaled to stop.
2024-09-24 11:47:10.956 | HD Request # 102 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 4.1 days) and wrote 0 records for ESU4.CME
2024-09-24 11:47:10.956 | HD Request # 102 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 11:47:10.956 | HD Request # 102 | Completion time: 1s.
2024-09-24 11:47:10.956 | HD Request # 102 | Intraday data download complete for ESU4.CME. Unique request ID: 102
2024-09-24 11:47:10.956 | Removing historical data download ID 102.
2024-09-24 11:47:10.957 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 11:47:10.957 | Intraday chart data file opened for ESU4.CME
2024-09-24 11:47:10.957 | HD Request # 102 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:10.957 | Triggering next historical data download in queue.
2024-09-24 11:47:10.957 | HD Request # 103 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 11:47:10.957 | HD Request # 103 | Download start date-time: 2024-09-24 11:45:38.000000. File last date-time: 2024-09-24 11:45:38.778001
2024-09-24 11:47:10.957 | HD Request # 103 | Using server: ds32.sierracharts.com port 10149
2024-09-24 11:47:10.957 | Socket (6) | Creating socket.
2024-09-24 11:47:10.957 | Socket (6) | New receive buffer size: 0
2024-09-24 11:47:10.957 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:11.228 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:11.228 | Socket (5) | Closed.
2024-09-24 11:47:11.506 | HD Request # 103 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:11.506 | HD Request # 103 | Sending historical data logon request message.
2024-09-24 11:47:11.750 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\CLX4.NYMEX.scid. Thread ID: 3296
2024-09-24 11:47:11.750 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 11:47:11.775 | HD Request # 103 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:38. Record interval: 0. Symbol: MGCZ24
2024-09-24 11:47:12.045 | HD Request # 103 | Decompressing data.
2024-09-24 11:47:12.314 | HD Request # 103 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 11:45:38.778000
2024-09-24 11:47:12.315 | Socket (6) | CloseSocket call.
2024-09-24 11:47:12.315 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:12.320 | Historical data download thread signaled to stop.
2024-09-24 11:47:12.320 | HD Request # 103 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:41.541000.
2024-09-24 11:47:12.320 | HD Request # 103 | Received 213 Intraday data records from 2024-09-24 11:45:38.778000 to 2024-09-24 11:47:12.202001 (93.4 seconds. Delay: 0.1 seconds) and wrote 211 records for MGCZ4.COMEX
2024-09-24 11:47:12.320 | HD Request # 103 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:12.202001
2024-09-24 11:47:12.320 | HD Request # 103 | Completion time: 2s.
2024-09-24 11:47:12.320 | HD Request # 103 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 103
2024-09-24 11:47:12.320 | Removing historical data download ID 103.
2024-09-24 11:47:12.320 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 11:47:12.320 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 11:47:12.320 | HD Request # 103 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:12.320 | Triggering next historical data download in queue.
2024-09-24 11:47:12.320 | HD Request # 104 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 11:47:12.321 | HD Request # 104 | Download start date-time: 2024-09-24 11:45:40.000000. File last date-time: 2024-09-24 11:45:40.586000
2024-09-24 11:47:12.321 | HD Request # 104 | Using server: ds32.sierracharts.com port 10150
2024-09-24 11:47:12.321 | Socket (5) | Creating socket.
2024-09-24 11:47:12.321 | Socket (5) | New receive buffer size: 0
2024-09-24 11:47:12.321 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 11:47:12.583 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:12.584 | Socket (6) | Closed.
2024-09-24 11:47:12.877 | HD Request # 104 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:12.877 | HD Request # 104 | Sending historical data logon request message.
2024-09-24 11:47:13.147 | HD Request # 104 | Requesting Intraday data. Start date-time: 2024-09-24 11:45:40. Record interval: 0. Symbol: MNQZ24
2024-09-24 11:47:13.419 | HD Request # 104 | Decompressing data.
2024-09-24 11:47:13.971 | HD Request # 104 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 11:45:40.005000
2024-09-24 11:47:13.972 | Socket (5) | CloseSocket call.
2024-09-24 11:47:13.972 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:13.985 | Historical data download thread signaled to stop.
2024-09-24 11:47:13.985 | HD Request # 104 | Timestamp of first Intraday data file record written: 2024-09-24 11:45:40.692000.
2024-09-24 11:47:13.985 | HD Request # 104 | Received 4065 Intraday data records from 2024-09-24 11:45:40.005000 to 2024-09-24 11:47:11.548006 (91.5 seconds. Delay: 2.4 seconds) and wrote 4024 records for MNQZ4.CME
2024-09-24 11:47:13.985 | HD Request # 104 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:11.548006
2024-09-24 11:47:13.986 | Added 115 Time and Sales records to Intraday data file for MNQZ4.CME after download.
2024-09-24 11:47:13.986 | HD Request # 104 | Completion time: 1s.
2024-09-24 11:47:13.986 | HD Request # 104 | Intraday data download complete for MNQZ4.CME. Unique request ID: 104
2024-09-24 11:47:13.986 | Removing historical data download ID 104.
2024-09-24 11:47:13.986 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 11:47:13.986 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 11:47:13.986 | HD Request # 104 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:13.986 | Triggering next historical data download in queue.
2024-09-24 11:47:13.986 | HD Request # 105 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2024-09-24 11:47:13.986 | HD Request # 105 | Download start date-time: 2024-09-24 11:46:39.000000. File last date-time: 2024-09-24 11:46:39.000000
2024-09-24 11:47:13.986 | HD Request # 105 | Using server: ds4.sierracharts.com port 10149
2024-09-24 11:47:13.986 | Socket (6) | Creating socket.
2024-09-24 11:47:13.986 | Socket (6) | New receive buffer size: 0
2024-09-24 11:47:13.986 | Socket (6) | Connecting to IP: 67.214.125.7.
2024-09-24 11:47:14.244 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 11:47:14.244 | Socket (5) | Closed.
2024-09-24 11:47:14.550 | HD Request # 105 | Setting DTC encoding to Binary VLS
2024-09-24 11:47:14.550 | HD Request # 105 | Sending historical data logon request message.
2024-09-24 11:47:15.304 | HD Request # 105 | Requesting Intraday data. Start date-time: 2024-09-24 11:46:39. Record interval: 0. Symbol: USDX
2024-09-24 11:47:15.582 | HD Request # 105 | Decompressing data.
2024-09-24 11:47:15.860 | HD Request # 105 | Receiving Intraday data for USDX starting at 2024-09-24 11:46:39.000000
2024-09-24 11:47:15.860 | Socket (6) | CloseSocket call.
2024-09-24 11:47:15.860 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 11:47:15.870 | Historical data download thread signaled to stop.
2024-09-24 11:47:15.870 | HD Request # 105 | Timestamp of first Intraday data file record written: 2024-09-24 11:46:40.000000.
2024-09-24 11:47:15.870 | HD Request # 105 | Received 39 Intraday data records from 2024-09-24 11:46:39.000000 to 2024-09-24 11:47:17.000000 (38.0 seconds. Delay: -1.1 seconds) and wrote 38 records for USDX
2024-09-24 11:47:15.871 | HD Request # 105 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:47:17.000000
2024-09-24 11:47:15.871 | HD Request # 105 | Completion time: 2s.
2024-09-24 11:47:15.871 | HD Request # 105 | Intraday data download complete for USDX. Unique request ID: 105
2024-09-24 11:47:15.871 | Removing historical data download ID 105.
2024-09-24 11:47:15.871 | Real-time Intraday chart data file updates started for USDX
2024-09-24 11:47:15.871 | Intraday chart data file opened for USDX
2024-09-24 11:47:15.871 | HD Request # 105 | Enabling Intraday chart updating for symbol.
2024-09-24 11:47:15.871 | No download requests in the queue to start downloads for.
2024-09-24 11:47:16.138 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 11:47:16.139 | Socket (6) | Closed.
2024-09-24 11:47:16.768 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6JZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:16.769 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 11:47:16.769 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-24 11:47:16.769 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 3296
2024-09-24 11:47:46.945 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AZ4.CME.scid. Thread ID: 3296
2024-09-24 11:53:39.263 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MJYZ4.CME.scid. Thread ID: 3296
2024-09-24 12:17:06.655 | File >> Reconnect selected.
2024-09-24 12:17:06.920 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 12:17:06.920 | DTC Client socket (1) | CloseSocket call.
2024-09-24 12:17:06.920 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-09-24 12:17:06.920 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-09-24 12:17:06.920 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:06.921 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 12:17:06.921 | DTC Client socket (2) | CloseSocket call.
2024-09-24 12:17:06.921 | DTC Client socket (2) | Write in progress. Shutdown being delayed. PendingSize=0
2024-09-24 12:17:06.921 | Denali Data Feed | Disconnected from the server.
2024-09-24 12:17:06.921 | SC Data with Depth | Waiting for socket receive thread to end
2024-09-24 12:17:06.921 | DTC Client socket (4) | CloseSocket call.
2024-09-24 12:17:06.921 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:06.921 | SC Data with Depth | Disconnected from the server.
2024-09-24 12:17:06.921 | Rithmic Direct - DTC | Disconnected.
2024-09-24 12:17:06.921 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 12:17:07.168 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 12:17:07.168 | DTC Client socket (1) | Closed.
2024-09-24 12:17:07.506 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-09-24 12:17:07.506 | DTC Client socket (4) | Closed.
2024-09-24 12:17:10.918 |
2024-09-24 12:17:10.918 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 12:17:10.918 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 12:17:10.918 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 12:17:11.250 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 12:17:11.250 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 12:17:11.250 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 12:17:11.519 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 12:17:11.519 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 12:17:11.519 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 12:17:11.519 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Write has completed. Shutdown being performed.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 12:17:11.537 | DTC Client socket (2) | Closed.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Received logon response.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Server Name: .
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 12:17:12.339 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 12:17:12.340 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 12:17:12.340 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 12:17:12.340 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 12:17:12.340 | Using symbol data fast lookup vector
2024-09-24 12:17:12.340 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 12:17:12.340 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 12:17:12.340 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 12:17:12.340 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 12:17:12.340 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 12:17:12.340 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 12:17:12.340 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 12:17:12.340 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 12:17:12.340 | DTC Client socket (2) | Creating socket.
2024-09-24 12:17:12.340 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 12:17:12.340 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 12:17:12.637 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2024-09-24 12:17:12.638 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 3 Service code: comex
2024-09-24 12:17:12.638 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 3
2024-09-24 12:17:12.638 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 12:17:12.638 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 12:17:12.638 | Triggering next historical data download in queue.
2024-09-24 12:17:12.662 | Delaying start of download for GCZ4.COMEX.
2024-09-24 12:17:12.663 | Mapping 6AZ4.CME to 6AZ24. Service code: cme
2024-09-24 12:17:12.663 | Denali Data Feed | Starting real-time market data updates for: 6AZ4.CME (6AZ24). ID: 4 Service code: cme
2024-09-24 12:17:12.663 | Denali Data Feed | Requesting security definition data for: 6AZ4.CME (6AZ24). ID: 4
2024-09-24 12:17:12.663 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 12:17:12.663 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.663 | Triggering next historical data download in queue.
2024-09-24 12:17:12.696 | Mapping CLX4.NYMEX to CLX24. Service code: nymex
2024-09-24 12:17:12.696 | Denali Data Feed | Starting real-time market data updates for: CLX4.NYMEX (CLX24). ID: 5 Service code: nymex
2024-09-24 12:17:12.696 | Denali Data Feed | Requesting security definition data for: CLX4.NYMEX (CLX24). ID: 5
2024-09-24 12:17:12.696 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 12:17:12.696 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 12:17:12.696 | Triggering next historical data download in queue.
2024-09-24 12:17:12.697 | Mapping 6JZ4.CME to 6JZ24. Service code: cme
2024-09-24 12:17:12.697 | Denali Data Feed | Starting real-time market data updates for: 6JZ4.CME (6JZ24). ID: 6 Service code: cme
2024-09-24 12:17:12.697 | Denali Data Feed | Requesting security definition data for: 6JZ4.CME (6JZ24). ID: 6
2024-09-24 12:17:12.697 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 12:17:12.697 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.697 | Triggering next historical data download in queue.
2024-09-24 12:17:12.747 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 12:17:12.747 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 7 Service code: cme
2024-09-24 12:17:12.747 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 7
2024-09-24 12:17:12.747 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 12:17:12.747 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.747 | Triggering next historical data download in queue.
2024-09-24 12:17:12.840 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 12:17:12.840 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 8 Service code: cme
2024-09-24 12:17:12.840 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 8
2024-09-24 12:17:12.840 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 12:17:12.840 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.840 | Triggering next historical data download in queue.
2024-09-24 12:17:12.913 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 12:17:12.913 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 9 Service code: cme
2024-09-24 12:17:12.913 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 9
2024-09-24 12:17:12.944 | Mapping MJYZ4.CME to MJYZ24. Service code: cme
2024-09-24 12:17:12.944 | Denali Data Feed | Starting real-time market data updates for: MJYZ4.CME (MJYZ24). ID: 10 Service code: cme
2024-09-24 12:17:12.944 | Denali Data Feed | Requesting security definition data for: MJYZ4.CME (MJYZ24). ID: 10
2024-09-24 12:17:12.944 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 12:17:12.944 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 12:17:12.944 | Triggering next historical data download in queue.
2024-09-24 12:17:12.944 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 12:17:12.944 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 12:17:13.310 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 12:17:13.310 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 12:17:13.310 | Triggering next historical data download in queue.
2024-09-24 12:17:13.311 | Mapping M6AZ4.CME to M6AZ24. Service code: cme
2024-09-24 12:17:13.311 | Denali Data Feed | Starting real-time market data updates for: M6AZ4.CME (M6AZ24). ID: 11 Service code: cme
2024-09-24 12:17:13.311 | Denali Data Feed | Requesting security definition data for: M6AZ4.CME (M6AZ24). ID: 11
2024-09-24 12:17:13.311 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 12:17:13.311 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 12:17:13.311 | Triggering next historical data download in queue.
2024-09-24 12:17:13.312 | Mapping MCLU4.NYMEX to MCLU24. Service code: nymex
2024-09-24 12:17:13.312 | Denali Data Feed | Starting real-time market data updates for: MCLU4.NYMEX (MCLU24). ID: 12 Service code: nymex
2024-09-24 12:17:13.312 | Denali Data Feed | Requesting security definition data for: MCLU4.NYMEX (MCLU24). ID: 12
2024-09-24 12:17:13.312 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 12:17:13.312 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 12:17:13.312 | Triggering next historical data download in queue.
2024-09-24 12:17:13.408 | Mapping ESU4.CME to ESU24. Service code: cme
2024-09-24 12:17:13.408 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 13 Service code: cme
2024-09-24 12:17:13.408 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 13
2024-09-24 12:17:13.408 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 12:17:13.408 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 12:17:13.408 | Triggering next historical data download in queue.
2024-09-24 12:17:13.409 | Mapping MGCZ4.COMEX to MGCZ24. Service code: comex
2024-09-24 12:17:13.409 | Denali Data Feed | Starting real-time market data updates for: MGCZ4.COMEX (MGCZ24). ID: 14 Service code: comex
2024-09-24 12:17:13.409 | Denali Data Feed | Requesting security definition data for: MGCZ4.COMEX (MGCZ24). ID: 14
2024-09-24 12:17:13.409 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 12:17:13.409 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 12:17:13.409 | Triggering next historical data download in queue.
2024-09-24 12:17:13.450 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 12:17:13.450 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 15 Service code: cme
2024-09-24 12:17:13.450 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 15
2024-09-24 12:17:13.450 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 12:17:13.450 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 12:17:13.450 | Triggering next historical data download in queue.
2024-09-24 12:17:13.469 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 16 Service code: fxstatscalc
2024-09-24 12:17:13.469 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2024-09-24 12:17:13.469 | SC Data with Depth | Requesting security definition data for: USDX. ID: 16
2024-09-24 12:17:13.469 | Added historical Intraday data request for USDX to the queue.
2024-09-24 12:17:13.469 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2024-09-24 12:17:13.470 | Triggering next historical data download in queue.
2024-09-24 12:17:13.590 | DTC Client socket (4) | Creating socket.
2024-09-24 12:17:13.590 | DTC Client socket (4) | New receive buffer size: 0
2024-09-24 12:17:13.590 | DTC Client socket (4) | Connecting to IP: 69.39.70.241.
2024-09-24 12:17:13.869 | SC Data with Depth | Network connection to server complete.
2024-09-24 12:17:13.869 | SC Data with Depth | Starting socket receive thread.
2024-09-24 12:17:13.870 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 12:17:14.194 | SC Data with Depth | Setting DTC encoding to Binary VLS
2024-09-24 12:17:14.194 | SC Data with Depth | Sending logon request message.
2024-09-24 12:17:15.500 | SC Data with Depth | Received logon response.
2024-09-24 12:17:15.500 | SC Data with Depth | Server Name: SC Realtime Server.
2024-09-24 12:17:15.500 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2024-09-24 12:17:15.500 | SC Data with Depth | Successfully connected.
2024-09-24 12:17:15.500 | SC Data with Depth | Trading is not supported.
2024-09-24 12:17:15.500 | SC Data with Depth | MarketDepthIsSupported: 1
2024-09-24 12:17:15.500 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2024-09-24 12:17:16.282 | SC Data with Depth | Received security definition for symbol USDX
2024-09-24 12:17:17.341 | Requesting market depth updates for: 6AZ4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: 6JZ4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: CLX4.NYMEX if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: GCZ4.COMEX if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: MESU4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 12:17:17.341 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 12:17:31.531 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Creating socket. Using TLS 1.2.
2024-09-24 12:17:31.531 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | New receive buffer size: 0
2024-09-24 12:17:31.531 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Connecting to IP: 216.66.0.130.
2024-09-24 12:17:33.277 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | CloseSocket call.
2024-09-24 12:17:33.278 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:33.355 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 12:17:33.355 | DTC Client socket (2) | CloseSocket call.
2024-09-24 12:17:33.355 | DTC Client socket (2) | Closed.
2024-09-24 12:17:33.355 | Denali Data Feed | Failed connections: 1
2024-09-24 12:17:33.355 | DTC Client socket (0) | CloseSocket call.
2024-09-24 12:17:33.355 | Denali Data Feed | Disconnected from the server.
2024-09-24 12:17:33.355 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 12:17:33.526 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:33.526 | HTTPS connection ID:9 to downloads.rithmic.com:443 for request ID:9 (5) | Closed.
2024-09-24 12:17:36.358 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 12:17:36.359 | DTC Client socket (2) | Creating socket.
2024-09-24 12:17:36.359 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 12:17:36.359 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 12:17:43.011 | HD Request # 106 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 12:17:43.011 | HD Request # 106 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.775001
2024-09-24 12:17:43.011 | HD Request # 106 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:43.011 | Socket (5) | Creating socket.
2024-09-24 12:17:43.011 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:43.011 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:43.574 | HD Request # 106 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:43.574 | HD Request # 106 | Sending historical data logon request message.
2024-09-24 12:17:44.344 | HD Request # 106 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: GCZ24
2024-09-24 12:17:44.619 | HD Request # 106 | Decompressing data.
2024-09-24 12:17:44.893 | HD Request # 106 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 12:16:48.015000
2024-09-24 12:17:44.893 | Socket (5) | CloseSocket call.
2024-09-24 12:17:44.893 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:44.893 | Historical data download thread signaled to stop.
2024-09-24 12:17:44.894 | HD Request # 106 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:50.680000.
2024-09-24 12:17:44.894 | HD Request # 106 | Received 208 Intraday data records from 2024-09-24 12:16:48.015000 to 2024-09-24 12:17:43.222000 (55.2 seconds. Delay: 1.7 seconds) and wrote 200 records for GCZ4.COMEX
2024-09-24 12:17:44.894 | HD Request # 106 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:43.222000
2024-09-24 12:17:44.894 | HD Request # 106 | Completion time: 1s.
2024-09-24 12:17:44.894 | HD Request # 106 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 106
2024-09-24 12:17:44.894 | Removing historical data download ID 106.
2024-09-24 12:17:44.894 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 12:17:44.894 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 12:17:44.894 | HD Request # 106 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:44.894 | Triggering next historical data download in queue.
2024-09-24 12:17:44.894 | Historical data for GCZ4.COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:44.894 | HD Request # 107 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 12:17:44.894 | HD Request # 107 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.092001
2024-09-24 12:17:44.894 | HD Request # 107 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:44.894 | Socket (6) | Creating socket.
2024-09-24 12:17:44.894 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:44.894 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:45.169 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:45.169 | Socket (5) | Closed.
2024-09-24 12:17:45.471 | HD Request # 107 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:45.471 | HD Request # 107 | Sending historical data logon request message.
2024-09-24 12:17:46.242 | HD Request # 107 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: 6AZ24
2024-09-24 12:17:46.520 | HD Request # 107 | Decompressing data.
2024-09-24 12:17:46.797 | HD Request # 107 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 12:16:48.091000
2024-09-24 12:17:46.797 | Socket (6) | CloseSocket call.
2024-09-24 12:17:46.797 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:46.797 | Historical data download thread signaled to stop.
2024-09-24 12:17:46.797 | HD Request # 107 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:52.039000.
2024-09-24 12:17:46.797 | HD Request # 107 | Received 42 Intraday data records from 2024-09-24 12:16:48.091000 to 2024-09-24 12:17:44.032000 (55.9 seconds. Delay: 2.8 seconds) and wrote 38 records for 6AZ4.CME
2024-09-24 12:17:46.798 | HD Request # 107 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:44.032000
2024-09-24 12:17:46.798 | HD Request # 107 | Completion time: 2s.
2024-09-24 12:17:46.798 | HD Request # 107 | Intraday data download complete for 6AZ4.CME. Unique request ID: 107
2024-09-24 12:17:46.798 | Removing historical data download ID 107.
2024-09-24 12:17:46.798 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 12:17:46.798 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 12:17:46.798 | HD Request # 107 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:46.798 | Triggering next historical data download in queue.
2024-09-24 12:17:46.798 | Historical data for 6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:46.798 | HD Request # 108 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 12:17:46.798 | HD Request # 108 | Download start date-time: 2024-09-24 12:16:47.000000. File last date-time: 2024-09-24 12:16:47.527001
2024-09-24 12:17:46.798 | HD Request # 108 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:46.798 | Socket (5) | Creating socket.
2024-09-24 12:17:46.798 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:46.798 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:47.074 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:47.075 | Socket (6) | Closed.
2024-09-24 12:17:47.348 | HD Request # 108 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:47.348 | HD Request # 108 | Sending historical data logon request message.
2024-09-24 12:17:47.617 | HD Request # 108 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:47. Record interval: 0. Symbol: CLX24
2024-09-24 12:17:47.888 | HD Request # 108 | Decompressing data.
2024-09-24 12:17:48.157 | HD Request # 108 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 12:16:47.527000
2024-09-24 12:17:48.157 | Socket (5) | CloseSocket call.
2024-09-24 12:17:48.157 | Historical data download thread signaled to stop.
2024-09-24 12:17:48.157 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:48.157 | HD Request # 108 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:51.554000.
2024-09-24 12:17:48.157 | HD Request # 108 | Received 155 Intraday data records from 2024-09-24 12:16:47.527000 to 2024-09-24 12:17:46.212001 (58.7 seconds. Delay: 1.9 seconds) and wrote 153 records for CLX4.NYMEX
2024-09-24 12:17:48.158 | HD Request # 108 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:46.212001
2024-09-24 12:17:48.158 | HD Request # 108 | Completion time: 2s.
2024-09-24 12:17:48.158 | HD Request # 108 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 108
2024-09-24 12:17:48.158 | Removing historical data download ID 108.
2024-09-24 12:17:48.158 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 12:17:48.158 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 12:17:48.158 | HD Request # 108 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:48.158 | Triggering next historical data download in queue.
2024-09-24 12:17:48.158 | Historical data for CLX4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:48.158 | HD Request # 109 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 12:17:48.158 | HD Request # 109 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.062000
2024-09-24 12:17:48.158 | HD Request # 109 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:48.158 | Socket (6) | Creating socket.
2024-09-24 12:17:48.158 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:48.158 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:48.427 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:48.427 | Socket (5) | Closed.
2024-09-24 12:17:48.725 | HD Request # 109 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:48.725 | HD Request # 109 | Sending historical data logon request message.
2024-09-24 12:17:49.003 | HD Request # 109 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: 6JZ24
2024-09-24 12:17:49.282 | HD Request # 109 | Decompressing data.
2024-09-24 12:17:49.559 | HD Request # 109 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 12:16:48.062000
2024-09-24 12:17:49.560 | Socket (6) | CloseSocket call.
2024-09-24 12:17:49.560 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:49.560 | Historical data download thread signaled to stop.
2024-09-24 12:17:49.560 | HD Request # 109 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:56.020000.
2024-09-24 12:17:49.560 | HD Request # 109 | Received 54 Intraday data records from 2024-09-24 12:16:48.062000 to 2024-09-24 12:17:50.111000 (62.0 seconds. Delay: -0.6 seconds) and wrote 53 records for 6JZ4.CME
2024-09-24 12:17:49.560 | HD Request # 109 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:50.111000
2024-09-24 12:17:49.560 | HD Request # 109 | Completion time: 1s.
2024-09-24 12:17:49.560 | HD Request # 109 | Intraday data download complete for 6JZ4.CME. Unique request ID: 109
2024-09-24 12:17:49.560 | Removing historical data download ID 109.
2024-09-24 12:17:49.560 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 12:17:49.560 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 12:17:49.560 | HD Request # 109 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:49.560 | Triggering next historical data download in queue.
2024-09-24 12:17:49.560 | Historical data for 6JZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:49.560 | HD Request # 110 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 12:17:49.560 | HD Request # 110 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.359000
2024-09-24 12:17:49.560 | HD Request # 110 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:49.560 | Socket (5) | Creating socket.
2024-09-24 12:17:49.560 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:49.561 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:49.837 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:49.837 | Socket (6) | Closed.
2024-09-24 12:17:50.116 | HD Request # 110 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:50.116 | HD Request # 110 | Sending historical data logon request message.
2024-09-24 12:17:50.386 | HD Request # 110 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: ESZ24
2024-09-24 12:17:50.655 | HD Request # 110 | Decompressing data.
2024-09-24 12:17:50.927 | HD Request # 110 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 12:16:48.093000
2024-09-24 12:17:50.927 | Socket (5) | CloseSocket call.
2024-09-24 12:17:50.927 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:50.927 | Historical data download thread signaled to stop.
2024-09-24 12:17:50.927 | HD Request # 110 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:51.165000.
2024-09-24 12:17:50.928 | HD Request # 110 | Received 864 Intraday data records from 2024-09-24 12:16:48.093000 to 2024-09-24 12:17:50.110001 (62.0 seconds. Delay: 0.8 seconds) and wrote 856 records for ESZ4.CME
2024-09-24 12:17:50.928 | HD Request # 110 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:50.110001
2024-09-24 12:17:50.928 | HD Request # 110 | Completion time: 1s.
2024-09-24 12:17:50.928 | HD Request # 110 | Intraday data download complete for ESZ4.CME. Unique request ID: 110
2024-09-24 12:17:50.928 | Removing historical data download ID 110.
2024-09-24 12:17:50.928 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 12:17:50.928 | Intraday chart data file opened for ESZ4.CME
2024-09-24 12:17:50.928 | HD Request # 110 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:50.928 | Triggering next historical data download in queue.
2024-09-24 12:17:50.928 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:50.928 | HD Request # 111 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 12:17:50.928 | HD Request # 111 | Download start date-time: 2024-09-24 12:16:49.000000. File last date-time: 2024-09-24 12:16:49.333002
2024-09-24 12:17:50.928 | HD Request # 111 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:50.928 | Socket (6) | Creating socket.
2024-09-24 12:17:50.928 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:50.928 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:51.196 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:51.197 | Socket (5) | Closed.
2024-09-24 12:17:51.499 | HD Request # 111 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:51.499 | HD Request # 111 | Sending historical data logon request message.
2024-09-24 12:17:51.778 | HD Request # 111 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:49. Record interval: 0. Symbol: MESZ24
2024-09-24 12:17:52.058 | HD Request # 111 | Decompressing data.
2024-09-24 12:17:52.337 | HD Request # 111 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 12:16:49.333000
2024-09-24 12:17:52.338 | Socket (6) | CloseSocket call.
2024-09-24 12:17:52.338 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:52.338 | Historical data download thread signaled to stop.
2024-09-24 12:17:52.338 | HD Request # 111 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:50.046000.
2024-09-24 12:17:52.338 | HD Request # 111 | Received 287 Intraday data records from 2024-09-24 12:16:49.333000 to 2024-09-24 12:17:49.822000 (60.5 seconds. Delay: 2.5 seconds) and wrote 284 records for MESZ4.CME
2024-09-24 12:17:52.339 | HD Request # 111 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:49.822000
2024-09-24 12:17:52.339 | HD Request # 111 | Completion time: 2s.
2024-09-24 12:17:52.339 | HD Request # 111 | Intraday data download complete for MESZ4.CME. Unique request ID: 111
2024-09-24 12:17:52.339 | Removing historical data download ID 111.
2024-09-24 12:17:52.339 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 12:17:52.339 | Intraday chart data file opened for MESZ4.CME
2024-09-24 12:17:52.339 | HD Request # 111 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:52.339 | Triggering next historical data download in queue.
2024-09-24 12:17:52.339 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:52.339 | HD Request # 112 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 12:17:52.339 | HD Request # 112 | Download start date-time: 2024-09-24 11:59:22.000000. File last date-time: 2024-09-24 11:59:22.084001
2024-09-24 12:17:52.339 | HD Request # 112 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:52.339 | Socket (5) | Creating socket.
2024-09-24 12:17:52.339 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:52.339 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:52.617 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:52.617 | Socket (6) | Closed.
2024-09-24 12:17:52.898 | HD Request # 112 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:52.898 | HD Request # 112 | Sending historical data logon request message.
2024-09-24 12:17:53.171 | HD Request # 112 | Requesting Intraday data. Start date-time: 2024-09-24 11:59:22. Record interval: 0. Symbol: MJYZ24
2024-09-24 12:17:53.444 | HD Request # 112 | Decompressing data.
2024-09-24 12:17:53.716 | HD Request # 112 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 11:59:22.084000
2024-09-24 12:17:53.716 | Socket (5) | CloseSocket call.
2024-09-24 12:17:53.716 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:53.724 | Historical data download thread signaled to stop.
2024-09-24 12:17:53.724 | HD Request # 112 | Received 2 Intraday data records from 2024-09-24 11:59:22.084000 to 2024-09-24 11:59:22.084001 (0.0 seconds. Delay: 18.5 minutes) and wrote 0 records for MJYZ4.CME
2024-09-24 12:17:53.724 | HD Request # 112 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:59:22.084001
2024-09-24 12:17:53.724 | HD Request # 112 | Completion time: 1s.
2024-09-24 12:17:53.724 | HD Request # 112 | Intraday data download complete for MJYZ4.CME. Unique request ID: 112
2024-09-24 12:17:53.724 | Removing historical data download ID 112.
2024-09-24 12:17:53.724 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 12:17:53.724 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 12:17:53.724 | HD Request # 112 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:53.724 | Triggering next historical data download in queue.
2024-09-24 12:17:53.724 | Historical data for MJYZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:53.724 | HD Request # 113 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 12:17:53.724 | HD Request # 113 | Download start date-time: 2024-09-24 12:16:49.000000. File last date-time: 2024-09-24 12:16:49.348001
2024-09-24 12:17:53.724 | HD Request # 113 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:53.724 | Socket (6) | Creating socket.
2024-09-24 12:17:53.724 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:53.724 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:53.989 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:53.990 | Socket (5) | Closed.
2024-09-24 12:17:54.278 | HD Request # 113 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:54.278 | HD Request # 113 | Sending historical data logon request message.
2024-09-24 12:17:54.550 | HD Request # 113 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:49. Record interval: 0. Symbol: NQZ24
2024-09-24 12:17:54.826 | HD Request # 113 | Decompressing data.
2024-09-24 12:17:55.097 | HD Request # 113 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 12:16:49.348000
2024-09-24 12:17:55.097 | Socket (6) | CloseSocket call.
2024-09-24 12:17:55.097 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:55.097 | Historical data download thread signaled to stop.
2024-09-24 12:17:55.097 | HD Request # 113 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:50.040000.
2024-09-24 12:17:55.097 | HD Request # 113 | Received 502 Intraday data records from 2024-09-24 12:16:49.348000 to 2024-09-24 12:17:53.966000 (64.6 seconds. Delay: 1.1 seconds) and wrote 500 records for NQZ4.CME
2024-09-24 12:17:55.098 | HD Request # 113 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:53.966000
2024-09-24 12:17:55.098 | HD Request # 113 | Completion time: 2s.
2024-09-24 12:17:55.098 | HD Request # 113 | Intraday data download complete for NQZ4.CME. Unique request ID: 113
2024-09-24 12:17:55.098 | Removing historical data download ID 113.
2024-09-24 12:17:55.098 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 12:17:55.098 | Intraday chart data file opened for NQZ4.CME
2024-09-24 12:17:55.098 | HD Request # 113 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:55.098 | Triggering next historical data download in queue.
2024-09-24 12:17:55.098 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:55.098 | HD Request # 114 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 12:17:55.098 | HD Request # 114 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 12:17:55.098 | HD Request # 114 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:55.098 | Socket (5) | Creating socket.
2024-09-24 12:17:55.098 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:55.098 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:55.372 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:55.372 | Socket (6) | Closed.
2024-09-24 12:17:55.662 | HD Request # 114 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:55.662 | HD Request # 114 | Sending historical data logon request message.
2024-09-24 12:17:55.939 | HD Request # 114 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 12:17:56.227 | HD Request # 114 | Decompressing data.
2024-09-24 12:17:56.505 | HD Request # 114 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 12:17:56.505 | Socket (5) | CloseSocket call.
2024-09-24 12:17:56.505 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:56.505 | Historical data download thread signaled to stop.
2024-09-24 12:17:56.505 | HD Request # 114 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 4.1 days) and wrote 0 records for MESU4.CME
2024-09-24 12:17:56.505 | HD Request # 114 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 12:17:56.505 | HD Request # 114 | Completion time: 1s.
2024-09-24 12:17:56.505 | HD Request # 114 | Intraday data download complete for MESU4.CME. Unique request ID: 114
2024-09-24 12:17:56.505 | Removing historical data download ID 114.
2024-09-24 12:17:56.505 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 12:17:56.505 | Intraday chart data file opened for MESU4.CME
2024-09-24 12:17:56.505 | HD Request # 114 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:56.505 | Triggering next historical data download in queue.
2024-09-24 12:17:56.505 | Historical data for MESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:56.505 | HD Request # 115 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 12:17:56.505 | HD Request # 115 | Download start date-time: 2024-09-24 12:16:48.000000. File last date-time: 2024-09-24 12:16:48.076000
2024-09-24 12:17:56.505 | HD Request # 115 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:56.505 | Socket (6) | Creating socket.
2024-09-24 12:17:56.505 | Socket (6) | New receive buffer size: 0
2024-09-24 12:17:56.505 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:56.786 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:17:56.786 | Socket (5) | Closed.
2024-09-24 12:17:57.082 | HD Request # 115 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:57.082 | HD Request # 115 | Sending historical data logon request message.
2024-09-24 12:17:57.362 | HD Request # 115 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:48. Record interval: 0. Symbol: M6AZ24
2024-09-24 12:17:57.417 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 12:17:57.417 | DTC Client socket (2) | CloseSocket call.
2024-09-24 12:17:57.417 | Denali Data Feed | Failed connections: 2
2024-09-24 12:17:57.417 | DTC Client socket (0) | CloseSocket call.
2024-09-24 12:17:57.417 | Denali Data Feed | Disconnected from the server.
2024-09-24 12:17:57.417 | DTC Client socket (2) | Closed.
2024-09-24 12:17:57.417 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 12:17:57.644 | HD Request # 115 | Decompressing data.
2024-09-24 12:17:57.925 | HD Request # 115 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 12:16:48.076000
2024-09-24 12:17:57.925 | Socket (6) | CloseSocket call.
2024-09-24 12:17:57.925 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:57.925 | Historical data download thread signaled to stop.
2024-09-24 12:17:57.925 | HD Request # 115 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:31.653000.
2024-09-24 12:17:57.925 | HD Request # 115 | Received 4 Intraday data records from 2024-09-24 12:16:48.076000 to 2024-09-24 12:17:31.653002 (43.6 seconds. Delay: 26.3 seconds) and wrote 3 records for M6AZ4.CME
2024-09-24 12:17:57.926 | HD Request # 115 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:31.653002
2024-09-24 12:17:57.926 | HD Request # 115 | Completion time: 1s.
2024-09-24 12:17:57.926 | HD Request # 115 | Intraday data download complete for M6AZ4.CME. Unique request ID: 115
2024-09-24 12:17:57.926 | Removing historical data download ID 115.
2024-09-24 12:17:57.926 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 12:17:57.926 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 12:17:57.926 | HD Request # 115 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:57.926 | Triggering next historical data download in queue.
2024-09-24 12:17:57.926 | Historical data for M6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:57.926 | HD Request # 116 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 12:17:57.926 | HD Request # 116 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 12:17:57.926 | HD Request # 116 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:17:57.926 | Socket (2) | Creating socket.
2024-09-24 12:17:57.926 | Socket (2) | New receive buffer size: 0
2024-09-24 12:17:57.926 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:58.206 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:17:58.206 | Socket (6) | Closed.
2024-09-24 12:17:58.484 | HD Request # 116 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:58.484 | HD Request # 116 | Sending historical data logon request message.
2024-09-24 12:17:58.755 | HD Request # 116 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 12:17:59.028 | HD Request # 116 | Decompressing data.
2024-09-24 12:17:59.299 | HD Request # 116 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 12:17:59.299 | Socket (2) | CloseSocket call.
2024-09-24 12:17:59.299 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 12:17:59.299 | Historical data download thread signaled to stop.
2024-09-24 12:17:59.299 | HD Request # 116 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 35.9 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 12:17:59.299 | HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 12:17:59.300 | HD Request # 116 | Completion time: 2s.
2024-09-24 12:17:59.300 | HD Request # 116 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 116
2024-09-24 12:17:59.300 | Removing historical data download ID 116.
2024-09-24 12:17:59.300 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 12:17:59.300 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 12:17:59.300 | HD Request # 116 | Enabling Intraday chart updating for symbol.
2024-09-24 12:17:59.300 | Triggering next historical data download in queue.
2024-09-24 12:17:59.300 | Historical data for MCLU4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:17:59.300 | HD Request # 117 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 12:17:59.300 | HD Request # 117 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 12:17:59.300 | HD Request # 117 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:17:59.300 | Socket (5) | Creating socket.
2024-09-24 12:17:59.300 | Socket (5) | New receive buffer size: 0
2024-09-24 12:17:59.300 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:17:59.571 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 12:17:59.571 | Socket (2) | Closed.
2024-09-24 12:17:59.866 | HD Request # 117 | Setting DTC encoding to Binary VLS
2024-09-24 12:17:59.866 | HD Request # 117 | Sending historical data logon request message.
2024-09-24 12:18:00.144 | HD Request # 117 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 12:18:00.424 | HD Request # 117 | Decompressing data.
2024-09-24 12:18:00.581 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 12:18:00.581 | DTC Client socket (2) | Creating socket.
2024-09-24 12:18:00.582 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 12:18:00.582 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 12:18:00.702 | HD Request # 117 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 12:18:00.702 | Socket (5) | CloseSocket call.
2024-09-24 12:18:00.702 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:00.706 | Historical data download thread signaled to stop.
2024-09-24 12:18:00.706 | HD Request # 117 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 4.1 days) and wrote 0 records for ESU4.CME
2024-09-24 12:18:00.706 | HD Request # 117 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 12:18:00.706 | HD Request # 117 | Completion time: 1s.
2024-09-24 12:18:00.706 | HD Request # 117 | Intraday data download complete for ESU4.CME. Unique request ID: 117
2024-09-24 12:18:00.706 | Removing historical data download ID 117.
2024-09-24 12:18:00.706 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 12:18:00.706 | Intraday chart data file opened for ESU4.CME
2024-09-24 12:18:00.706 | HD Request # 117 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:00.706 | Triggering next historical data download in queue.
2024-09-24 12:18:00.706 | Historical data for ESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 12:18:00.706 | HD Request # 118 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 12:18:00.706 | HD Request # 118 | Download start date-time: 2024-09-24 12:16:47.000000. File last date-time: 2024-09-24 12:16:47.039003
2024-09-24 12:18:00.706 | HD Request # 118 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:00.706 | Socket (6) | Creating socket.
2024-09-24 12:18:00.706 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:00.706 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:00.779 | Denali Data Feed | Network connection to server complete.
2024-09-24 12:18:00.779 | Denali Data Feed | Starting socket receive thread.
2024-09-24 12:18:00.779 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 12:18:00.981 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:00.981 | Socket (5) | Closed.
2024-09-24 12:18:00.988 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-24 12:18:00.988 | Denali Data Feed | Sending logon request message.
2024-09-24 12:18:01.280 | HD Request # 118 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:01.280 | HD Request # 118 | Sending historical data logon request message.
2024-09-24 12:18:01.558 | HD Request # 118 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:47. Record interval: 0. Symbol: MGCZ24
2024-09-24 12:18:01.676 | Denali Data Feed | Received logon response.
2024-09-24 12:18:01.676 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-24 12:18:01.676 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-24 12:18:01.676 | Denali Data Feed | Successfully connected.
2024-09-24 12:18:01.676 | Denali Data Feed | Trading is not supported.
2024-09-24 12:18:01.676 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-24 12:18:01.676 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Triggering next historical data download in queue.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: 6AZ4.CME -> 6AZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: 6JZ4.CME -> 6JZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: CLX4.NYMEX -> CLX24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: ESU4.CME -> ESU24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ4.CME -> ESZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: GCZ4.COMEX -> GCZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: M6AZ4.CME -> M6AZ24
2024-09-24 12:18:01.676 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MCLU4.NYMEX -> MCLU24
2024-09-24 12:18:01.676 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ4.CME -> MESZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MGCZ4.COMEX -> MGCZ24
2024-09-24 12:18:01.676 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MJYZ4.CME -> MJYZ24
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ4.CME -> MNQZ24. Market Depth data restarted.
2024-09-24 12:18:01.676 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 12:18:01.676 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 12:18:01.676 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2024-09-24 12:18:01.848 | HD Request # 118 | Decompressing data.
2024-09-24 12:18:02.126 | HD Request # 118 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 12:16:47.039000
2024-09-24 12:18:02.126 | Socket (6) | CloseSocket call.
2024-09-24 12:18:02.126 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:02.126 | Historical data download thread signaled to stop.
2024-09-24 12:18:02.126 | HD Request # 118 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:53.075000.
2024-09-24 12:18:02.126 | HD Request # 118 | Received 107 Intraday data records from 2024-09-24 12:16:47.039000 to 2024-09-24 12:17:59.058000 (72.0 seconds. Delay: 3.1 seconds) and wrote 103 records for MGCZ4.COMEX
2024-09-24 12:18:02.127 | HD Request # 118 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:59.058000
2024-09-24 12:18:02.127 | HD Request # 118 | Completion time: 2s.
2024-09-24 12:18:02.127 | HD Request # 118 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 118
2024-09-24 12:18:02.127 | Removing historical data download ID 118.
2024-09-24 12:18:02.127 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 12:18:02.127 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 12:18:02.127 | HD Request # 118 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:02.127 | Triggering next historical data download in queue.
2024-09-24 12:18:02.127 | Initiating new historical data download for MGCZ4.COMEX to get the latest data since the download was started while not connected to primary service.
2024-09-24 12:18:02.127 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 12:18:02.127 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 12:18:02.127 | HD Request # 119 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 12:18:02.127 | HD Request # 119 | Download start date-time: 2024-09-24 12:17:59.000000. File last date-time: 2024-09-24 12:17:59.058000
2024-09-24 12:18:02.127 | HD Request # 119 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:02.127 | Socket (5) | Creating socket.
2024-09-24 12:18:02.127 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:02.127 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:02.404 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:02.404 | Socket (6) | Closed.
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for 6AZ4.CME
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for 6JZ4.CME
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for CLX4.NYMEX
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for ESU4.CME
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-24 12:18:02.553 | Denali Data Feed | Clearing market depth for GCZ4.COMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Clearing market depth for MESU4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol 6AZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol 6JZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol CLX4.NYMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Real-time data for symbol ESU4.CME is currently unavailable.
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol ESU4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol GCZ4.COMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol M6AZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Real-time data for symbol MCLU4.NYMEX is currently unavailable.
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MCLU4.NYMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MGCZ4.COMEX
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MJYZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-24 12:18:02.554 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-24 12:18:02.686 | HD Request # 119 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:02.686 | HD Request # 119 | Sending historical data logon request message.
2024-09-24 12:18:02.959 | HD Request # 119 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:59. Record interval: 0. Symbol: MGCZ24
2024-09-24 12:18:03.234 | HD Request # 119 | Decompressing data.
2024-09-24 12:18:03.510 | HD Request # 119 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 12:17:59.058000
2024-09-24 12:18:03.510 | Socket (5) | CloseSocket call.
2024-09-24 12:18:03.510 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:03.613 | Historical data download thread signaled to stop.
2024-09-24 12:18:03.613 | HD Request # 119 | Timestamp of first Intraday data file record written: 2024-09-24 12:18:00.994000.
2024-09-24 12:18:03.613 | HD Request # 119 | Received 11 Intraday data records from 2024-09-24 12:17:59.058000 to 2024-09-24 12:18:03.670004 (4.6 seconds. Delay: -0.1 seconds) and wrote 10 records for MGCZ4.COMEX
2024-09-24 12:18:03.613 | HD Request # 119 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:03.670004
2024-09-24 12:18:03.613 | HD Request # 119 | Completion time: 1s.
2024-09-24 12:18:03.613 | HD Request # 119 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 133
2024-09-24 12:18:03.613 | Removing historical data download ID 133.
2024-09-24 12:18:03.613 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 12:18:03.613 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 12:18:03.613 | HD Request # 119 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:03.613 | Triggering next historical data download in queue.
2024-09-24 12:18:03.613 | HD Request # 120 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 12:18:03.614 | HD Request # 120 | Download start date-time: 2024-09-24 12:16:49.000000. File last date-time: 2024-09-24 12:16:49.724000
2024-09-24 12:18:03.614 | HD Request # 120 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:03.614 | Socket (6) | Creating socket.
2024-09-24 12:18:03.614 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:03.614 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:03.783 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:03.784 | Socket (5) | Closed.
2024-09-24 12:18:04.192 | HD Request # 120 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:04.192 | HD Request # 120 | Sending historical data logon request message.
2024-09-24 12:18:04.473 | HD Request # 120 | Requesting Intraday data. Start date-time: 2024-09-24 12:16:49. Record interval: 0. Symbol: MNQZ24
2024-09-24 12:18:04.756 | HD Request # 120 | Decompressing data.
2024-09-24 12:18:05.043 | HD Request # 120 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 12:16:49.348000
2024-09-24 12:18:05.044 | Socket (6) | CloseSocket call.
2024-09-24 12:18:05.044 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:05.044 | Historical data download thread signaled to stop.
2024-09-24 12:18:05.044 | HD Request # 120 | Timestamp of first Intraday data file record written: 2024-09-24 12:16:50.040000.
2024-09-24 12:18:05.044 | HD Request # 120 | Received 1261 Intraday data records from 2024-09-24 12:16:49.348000 to 2024-09-24 12:18:06.451000 (77.1 seconds. Delay: -1.4 seconds) and wrote 1251 records for MNQZ4.CME
2024-09-24 12:18:05.044 | HD Request # 120 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:06.451000
2024-09-24 12:18:05.044 | HD Request # 120 | Completion time: 2s.
2024-09-24 12:18:05.044 | HD Request # 120 | Intraday data download complete for MNQZ4.CME. Unique request ID: 119
2024-09-24 12:18:05.044 | Removing historical data download ID 119.
2024-09-24 12:18:05.044 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 12:18:05.044 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 12:18:05.044 | HD Request # 120 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:05.044 | Triggering next historical data download in queue.
2024-09-24 12:18:05.044 | HD Request # 121 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2024-09-24 12:18:05.045 | HD Request # 121 | Download start date-time: 2024-09-24 12:17:08.000000. File last date-time: 2024-09-24 12:17:08.000000
2024-09-24 12:18:05.045 | HD Request # 121 | Using server: ds12.sierracharts.com port 10149
2024-09-24 12:18:05.045 | Socket (5) | Creating socket.
2024-09-24 12:18:05.045 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:05.045 | Socket (5) | Connecting to IP: 69.39.70.241.
2024-09-24 12:18:05.326 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:05.326 | Socket (6) | Closed.
2024-09-24 12:18:05.639 | HD Request # 121 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:05.639 | HD Request # 121 | Sending historical data logon request message.
2024-09-24 12:18:06.394 | HD Request # 121 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:08. Record interval: 0. Symbol: USDX
2024-09-24 12:18:06.672 | HD Request # 121 | Decompressing data.
2024-09-24 12:18:06.952 | HD Request # 121 | Receiving Intraday data for USDX starting at 2024-09-24 12:17:08.000000
2024-09-24 12:18:06.952 | Socket (5) | CloseSocket call.
2024-09-24 12:18:06.952 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:06.960 | Historical data download thread signaled to stop.
2024-09-24 12:18:06.960 | HD Request # 121 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:09.000000.
2024-09-24 12:18:06.960 | HD Request # 121 | Received 59 Intraday data records from 2024-09-24 12:17:08.000000 to 2024-09-24 12:18:07.000000 (59.0 seconds. Delay: -0.0 seconds) and wrote 58 records for USDX
2024-09-24 12:18:06.960 | HD Request # 121 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:07.000000
2024-09-24 12:18:06.960 | Added 2 Time and Sales records to Intraday data file for USDX after download.
2024-09-24 12:18:06.960 | HD Request # 121 | Completion time: 1s.
2024-09-24 12:18:06.960 | HD Request # 121 | Intraday data download complete for USDX. Unique request ID: 120
2024-09-24 12:18:06.960 | Removing historical data download ID 120.
2024-09-24 12:18:06.960 | Real-time Intraday chart data file updates started for USDX
2024-09-24 12:18:06.960 | Intraday chart data file opened for USDX
2024-09-24 12:18:06.960 | HD Request # 121 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:06.960 | Triggering next historical data download in queue.
2024-09-24 12:18:06.960 | HD Request # 122 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 12:18:06.961 | HD Request # 122 | Download start date-time: 2024-09-24 12:17:44.000000. File last date-time: 2024-09-24 12:17:44.032000
2024-09-24 12:18:06.961 | HD Request # 122 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:06.961 | Socket (6) | Creating socket.
2024-09-24 12:18:06.961 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:06.961 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:07.232 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:07.232 | Socket (5) | Closed.
2024-09-24 12:18:07.523 | HD Request # 122 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:07.523 | HD Request # 122 | Sending historical data logon request message.
2024-09-24 12:18:07.803 | HD Request # 122 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:44. Record interval: 0. Symbol: 6AZ24
2024-09-24 12:18:08.077 | HD Request # 122 | Decompressing data.
2024-09-24 12:18:08.353 | HD Request # 122 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 12:17:44.032000
2024-09-24 12:18:08.353 | Socket (6) | CloseSocket call.
2024-09-24 12:18:08.353 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:08.353 | Historical data download thread signaled to stop.
2024-09-24 12:18:08.353 | HD Request # 122 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:47.488000.
2024-09-24 12:18:08.353 | HD Request # 122 | Received 29 Intraday data records from 2024-09-24 12:17:44.032000 to 2024-09-24 12:18:05.400002 (21.4 seconds. Delay: 3.0 seconds) and wrote 28 records for 6AZ4.CME
2024-09-24 12:18:08.354 | HD Request # 122 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:05.400002
2024-09-24 12:18:08.354 | HD Request # 122 | Completion time: 2s.
2024-09-24 12:18:08.354 | HD Request # 122 | Intraday data download complete for 6AZ4.CME. Unique request ID: 121
2024-09-24 12:18:08.354 | Removing historical data download ID 121.
2024-09-24 12:18:08.354 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 12:18:08.354 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 12:18:08.354 | HD Request # 122 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:08.354 | Triggering next historical data download in queue.
2024-09-24 12:18:08.354 | HD Request # 123 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 12:18:08.354 | HD Request # 123 | Download start date-time: 2024-09-24 12:17:50.000000. File last date-time: 2024-09-24 12:17:50.111000
2024-09-24 12:18:08.354 | HD Request # 123 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:08.354 | Socket (5) | Creating socket.
2024-09-24 12:18:08.354 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:08.354 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:08.637 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:08.637 | Socket (6) | Closed.
2024-09-24 12:18:08.931 | HD Request # 123 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:08.931 | HD Request # 123 | Sending historical data logon request message.
2024-09-24 12:18:09.163 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MGCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 12:18:09.163 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 3296
2024-09-24 12:18:09.164 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 3296
2024-09-24 12:18:09.209 | HD Request # 123 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:50. Record interval: 0. Symbol: 6JZ24
2024-09-24 12:18:09.482 | HD Request # 123 | Decompressing data.
2024-09-24 12:18:09.753 | HD Request # 123 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 12:17:50.111000
2024-09-24 12:18:09.754 | Socket (5) | CloseSocket call.
2024-09-24 12:18:09.754 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:09.765 | Historical data download thread signaled to stop.
2024-09-24 12:18:09.765 | HD Request # 123 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:55.100000.
2024-09-24 12:18:09.765 | HD Request # 123 | Received 62 Intraday data records from 2024-09-24 12:17:50.111000 to 2024-09-24 12:18:08.926000 (18.8 seconds. Delay: 0.8 seconds) and wrote 61 records for 6JZ4.CME
2024-09-24 12:18:09.766 | HD Request # 123 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:08.926000
2024-09-24 12:18:09.766 | HD Request # 123 | Completion time: 1s.
2024-09-24 12:18:09.766 | HD Request # 123 | Intraday data download complete for 6JZ4.CME. Unique request ID: 122
2024-09-24 12:18:09.766 | Removing historical data download ID 122.
2024-09-24 12:18:09.766 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 12:18:09.766 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 12:18:09.766 | HD Request # 123 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:09.766 | Triggering next historical data download in queue.
2024-09-24 12:18:09.766 | HD Request # 124 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 12:18:09.766 | HD Request # 124 | Download start date-time: 2024-09-24 12:17:46.000000. File last date-time: 2024-09-24 12:17:46.212001
2024-09-24 12:18:09.766 | HD Request # 124 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:09.766 | Socket (6) | Creating socket.
2024-09-24 12:18:09.766 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:09.766 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:10.026 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:10.026 | Socket (5) | Closed.
2024-09-24 12:18:10.327 | HD Request # 124 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:10.327 | HD Request # 124 | Sending historical data logon request message.
2024-09-24 12:18:10.600 | HD Request # 124 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:46. Record interval: 0. Symbol: CLX24
2024-09-24 12:18:10.873 | HD Request # 124 | Decompressing data.
2024-09-24 12:18:11.146 | HD Request # 124 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 12:17:46.212000
2024-09-24 12:18:11.146 | Socket (6) | CloseSocket call.
2024-09-24 12:18:11.146 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:11.166 | Historical data download thread signaled to stop.
2024-09-24 12:18:11.166 | HD Request # 124 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:50.219000.
2024-09-24 12:18:11.166 | HD Request # 124 | Received 48 Intraday data records from 2024-09-24 12:17:46.212000 to 2024-09-24 12:18:11.848000 (25.6 seconds. Delay: -0.7 seconds) and wrote 46 records for CLX4.NYMEX
2024-09-24 12:18:11.167 | HD Request # 124 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:11.848000
2024-09-24 12:18:11.167 | HD Request # 124 | Completion time: 2s.
2024-09-24 12:18:11.167 | HD Request # 124 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 123
2024-09-24 12:18:11.167 | Removing historical data download ID 123.
2024-09-24 12:18:11.167 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 12:18:11.167 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 12:18:11.167 | HD Request # 124 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:11.167 | Triggering next historical data download in queue.
2024-09-24 12:18:11.167 | HD Request # 125 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 12:18:11.167 | HD Request # 125 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 12:18:11.167 | HD Request # 125 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:11.167 | Socket (5) | Creating socket.
2024-09-24 12:18:11.167 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:11.167 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:11.419 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:11.419 | Socket (6) | Closed.
2024-09-24 12:18:11.738 | HD Request # 125 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:11.738 | HD Request # 125 | Sending historical data logon request message.
2024-09-24 12:18:12.015 | HD Request # 125 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 12:18:12.295 | HD Request # 125 | Decompressing data.
2024-09-24 12:18:12.573 | HD Request # 125 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 12:18:12.573 | Socket (5) | CloseSocket call.
2024-09-24 12:18:12.573 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:12.576 | Historical data download thread signaled to stop.
2024-09-24 12:18:12.576 | HD Request # 125 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 4.1 days) and wrote 0 records for ESU4.CME
2024-09-24 12:18:12.576 | HD Request # 125 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 12:18:12.576 | HD Request # 125 | Completion time: 1s.
2024-09-24 12:18:12.576 | HD Request # 125 | Intraday data download complete for ESU4.CME. Unique request ID: 124
2024-09-24 12:18:12.576 | Removing historical data download ID 124.
2024-09-24 12:18:12.576 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 12:18:12.576 | Intraday chart data file opened for ESU4.CME
2024-09-24 12:18:12.576 | HD Request # 125 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:12.576 | Triggering next historical data download in queue.
2024-09-24 12:18:12.576 | HD Request # 126 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 12:18:12.576 | HD Request # 126 | Download start date-time: 2024-09-24 12:17:50.000000. File last date-time: 2024-09-24 12:17:50.110001
2024-09-24 12:18:12.576 | HD Request # 126 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:12.576 | Socket (6) | Creating socket.
2024-09-24 12:18:12.576 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:12.576 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:12.851 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:12.851 | Socket (5) | Closed.
2024-09-24 12:18:13.138 | HD Request # 126 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:13.138 | HD Request # 126 | Sending historical data logon request message.
2024-09-24 12:18:13.412 | HD Request # 126 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:50. Record interval: 0. Symbol: ESZ24
2024-09-24 12:18:13.687 | HD Request # 126 | Decompressing data.
2024-09-24 12:18:13.961 | HD Request # 126 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 12:17:50.110000
2024-09-24 12:18:13.961 | Socket (6) | CloseSocket call.
2024-09-24 12:18:13.961 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:13.971 | Historical data download thread signaled to stop.
2024-09-24 12:18:13.971 | HD Request # 126 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:50.941000.
2024-09-24 12:18:13.971 | HD Request # 126 | Received 166 Intraday data records from 2024-09-24 12:17:50.110000 to 2024-09-24 12:18:14.586000 (24.5 seconds. Delay: -0.6 seconds) and wrote 164 records for ESZ4.CME
2024-09-24 12:18:13.972 | HD Request # 126 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:14.586000
2024-09-24 12:18:13.972 | Added 2 Time and Sales records to Intraday data file for ESZ4.CME after download.
2024-09-24 12:18:13.972 | HD Request # 126 | Completion time: 1s.
2024-09-24 12:18:13.972 | HD Request # 126 | Intraday data download complete for ESZ4.CME. Unique request ID: 125
2024-09-24 12:18:13.972 | Removing historical data download ID 125.
2024-09-24 12:18:13.972 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 12:18:13.972 | Intraday chart data file opened for ESZ4.CME
2024-09-24 12:18:13.972 | HD Request # 126 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:13.972 | Triggering next historical data download in queue.
2024-09-24 12:18:13.972 | HD Request # 127 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 12:18:13.972 | HD Request # 127 | Download start date-time: 2024-09-24 12:17:43.000000. File last date-time: 2024-09-24 12:17:43.222000
2024-09-24 12:18:13.972 | HD Request # 127 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:13.972 | Socket (5) | Creating socket.
2024-09-24 12:18:13.972 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:13.972 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:14.194 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-24 12:18:14.194 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\CLX4.NYMEX.scid. Thread ID: 3296
2024-09-24 12:18:14.194 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6JZ4.CME.scid. Thread ID: 3296
2024-09-24 12:18:14.235 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:14.235 | Socket (6) | Closed.
2024-09-24 12:18:14.530 | HD Request # 127 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:14.530 | HD Request # 127 | Sending historical data logon request message.
2024-09-24 12:18:14.802 | HD Request # 127 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:43. Record interval: 0. Symbol: GCZ24
2024-09-24 12:18:15.076 | HD Request # 127 | Decompressing data.
2024-09-24 12:18:15.349 | HD Request # 127 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 12:17:43.222000
2024-09-24 12:18:15.349 | Socket (5) | CloseSocket call.
2024-09-24 12:18:15.349 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:15.363 | Historical data download thread signaled to stop.
2024-09-24 12:18:15.363 | HD Request # 127 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:44.168000.
2024-09-24 12:18:15.363 | HD Request # 127 | Received 116 Intraday data records from 2024-09-24 12:17:43.222000 to 2024-09-24 12:18:15.683000 (32.5 seconds. Delay: -0.3 seconds) and wrote 115 records for GCZ4.COMEX
2024-09-24 12:18:15.364 | HD Request # 127 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:15.683000
2024-09-24 12:18:15.364 | Added 4 Time and Sales records to Intraday data file for GCZ4.COMEX after download.
2024-09-24 12:18:15.364 | HD Request # 127 | Completion time: 2s.
2024-09-24 12:18:15.364 | HD Request # 127 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 126
2024-09-24 12:18:15.364 | Removing historical data download ID 126.
2024-09-24 12:18:15.364 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 12:18:15.364 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 12:18:15.364 | HD Request # 127 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:15.364 | Triggering next historical data download in queue.
2024-09-24 12:18:15.364 | HD Request # 128 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 12:18:15.364 | HD Request # 128 | Download start date-time: 2024-09-24 12:17:31.000000. File last date-time: 2024-09-24 12:17:31.653002
2024-09-24 12:18:15.364 | HD Request # 128 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:15.364 | Socket (6) | Creating socket.
2024-09-24 12:18:15.364 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:15.364 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:15.622 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:15.622 | Socket (5) | Closed.
2024-09-24 12:18:15.932 | HD Request # 128 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:15.932 | HD Request # 128 | Sending historical data logon request message.
2024-09-24 12:18:16.698 | HD Request # 128 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:31. Record interval: 0. Symbol: M6AZ24
2024-09-24 12:18:16.975 | HD Request # 128 | Decompressing data.
2024-09-24 12:18:17.251 | HD Request # 128 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 12:17:31.653000
2024-09-24 12:18:17.251 | Socket (6) | CloseSocket call.
2024-09-24 12:18:17.251 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:17.265 | Historical data download thread signaled to stop.
2024-09-24 12:18:17.265 | HD Request # 128 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:59.058000.
2024-09-24 12:18:17.265 | HD Request # 128 | Received 5 Intraday data records from 2024-09-24 12:17:31.653000 to 2024-09-24 12:17:59.058001 (27.4 seconds. Delay: 18.2 seconds) and wrote 2 records for M6AZ4.CME
2024-09-24 12:18:17.265 | HD Request # 128 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:17:59.058001
2024-09-24 12:18:17.265 | HD Request # 128 | Completion time: 2s.
2024-09-24 12:18:17.265 | HD Request # 128 | Intraday data download complete for M6AZ4.CME. Unique request ID: 127
2024-09-24 12:18:17.265 | Removing historical data download ID 127.
2024-09-24 12:18:17.265 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 12:18:17.265 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 12:18:17.265 | HD Request # 128 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:17.265 | Triggering next historical data download in queue.
2024-09-24 12:18:17.265 | HD Request # 129 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 12:18:17.265 | HD Request # 129 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 12:18:17.265 | HD Request # 129 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:17.265 | Socket (5) | Creating socket.
2024-09-24 12:18:17.265 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:17.265 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:17.527 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:17.527 | Socket (6) | Closed.
2024-09-24 12:18:17.833 | HD Request # 129 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:17.833 | HD Request # 129 | Sending historical data logon request message.
2024-09-24 12:18:18.601 | HD Request # 129 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 12:18:18.879 | HD Request # 129 | Decompressing data.
2024-09-24 12:18:19.156 | HD Request # 129 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 12:18:19.157 | Socket (5) | CloseSocket call.
2024-09-24 12:18:19.157 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:19.160 | Historical data download thread signaled to stop.
2024-09-24 12:18:19.160 | HD Request # 129 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 35.9 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 12:18:19.160 | HD Request # 129 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 12:18:19.160 | HD Request # 129 | Completion time: 2s.
2024-09-24 12:18:19.160 | HD Request # 129 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 128
2024-09-24 12:18:19.160 | Removing historical data download ID 128.
2024-09-24 12:18:19.160 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 12:18:19.160 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 12:18:19.160 | HD Request # 129 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:19.160 | Triggering next historical data download in queue.
2024-09-24 12:18:19.160 | HD Request # 130 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 12:18:19.160 | HD Request # 130 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 12:18:19.160 | HD Request # 130 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:19.160 | Socket (6) | Creating socket.
2024-09-24 12:18:19.160 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:19.160 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:19.222 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\GCZ4.COMEX.scid. Thread ID: 3296
2024-09-24 12:18:19.223 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 3296
2024-09-24 12:18:19.439 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:19.439 | Socket (5) | Closed.
2024-09-24 12:18:19.736 | HD Request # 130 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:19.736 | HD Request # 130 | Sending historical data logon request message.
2024-09-24 12:18:20.015 | HD Request # 130 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 12:18:20.294 | HD Request # 130 | Decompressing data.
2024-09-24 12:18:20.572 | HD Request # 130 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 12:18:20.572 | Socket (6) | CloseSocket call.
2024-09-24 12:18:20.573 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:20.591 | Historical data download thread signaled to stop.
2024-09-24 12:18:20.591 | HD Request # 130 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 4.1 days) and wrote 0 records for MESU4.CME
2024-09-24 12:18:20.592 | HD Request # 130 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 12:18:20.592 | HD Request # 130 | Completion time: 1s.
2024-09-24 12:18:20.592 | HD Request # 130 | Intraday data download complete for MESU4.CME. Unique request ID: 129
2024-09-24 12:18:20.592 | Removing historical data download ID 129.
2024-09-24 12:18:20.592 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 12:18:20.592 | Intraday chart data file opened for MESU4.CME
2024-09-24 12:18:20.592 | HD Request # 130 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:20.592 | Triggering next historical data download in queue.
2024-09-24 12:18:20.592 | HD Request # 131 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 12:18:20.592 | HD Request # 131 | Download start date-time: 2024-09-24 12:17:49.000000. File last date-time: 2024-09-24 12:17:49.822000
2024-09-24 12:18:20.592 | HD Request # 131 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:20.592 | Socket (5) | Creating socket.
2024-09-24 12:18:20.592 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:20.592 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:20.851 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:20.851 | Socket (6) | Closed.
2024-09-24 12:18:21.148 | HD Request # 131 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:21.148 | HD Request # 131 | Sending historical data logon request message.
2024-09-24 12:18:21.419 | HD Request # 131 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:49. Record interval: 0. Symbol: MESZ24
2024-09-24 12:18:21.692 | HD Request # 131 | Decompressing data.
2024-09-24 12:18:21.963 | HD Request # 131 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 12:17:49.547000
2024-09-24 12:18:21.963 | Socket (5) | CloseSocket call.
2024-09-24 12:18:21.963 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:21.973 | Historical data download thread signaled to stop.
2024-09-24 12:18:21.973 | HD Request # 131 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:53.050000.
2024-09-24 12:18:21.973 | HD Request # 131 | Received 87 Intraday data records from 2024-09-24 12:17:49.547000 to 2024-09-24 12:18:22.354000 (32.8 seconds. Delay: -0.4 seconds) and wrote 85 records for MESZ4.CME
2024-09-24 12:18:21.973 | HD Request # 131 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:22.354000
2024-09-24 12:18:21.973 | HD Request # 131 | Completion time: 1s.
2024-09-24 12:18:21.973 | HD Request # 131 | Intraday data download complete for MESZ4.CME. Unique request ID: 130
2024-09-24 12:18:21.973 | Removing historical data download ID 130.
2024-09-24 12:18:21.973 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 12:18:21.973 | Intraday chart data file opened for MESZ4.CME
2024-09-24 12:18:21.973 | HD Request # 131 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:21.973 | Triggering next historical data download in queue.
2024-09-24 12:18:21.973 | HD Request # 132 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 12:18:21.974 | HD Request # 132 | Download start date-time: 2024-09-24 11:59:22.000000. File last date-time: 2024-09-24 11:59:22.084001
2024-09-24 12:18:21.974 | HD Request # 132 | Using server: ds32.sierracharts.com port 10150
2024-09-24 12:18:21.974 | Socket (6) | Creating socket.
2024-09-24 12:18:21.974 | Socket (6) | New receive buffer size: 0
2024-09-24 12:18:21.974 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:22.234 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:22.234 | Socket (5) | Closed.
2024-09-24 12:18:22.536 | HD Request # 132 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:22.536 | HD Request # 132 | Sending historical data logon request message.
2024-09-24 12:18:22.812 | HD Request # 132 | Requesting Intraday data. Start date-time: 2024-09-24 11:59:22. Record interval: 0. Symbol: MJYZ24
2024-09-24 12:18:23.089 | HD Request # 132 | Decompressing data.
2024-09-24 12:18:23.365 | HD Request # 132 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 11:59:22.084000
2024-09-24 12:18:23.365 | Socket (6) | CloseSocket call.
2024-09-24 12:18:23.365 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:23.365 | Historical data download thread signaled to stop.
2024-09-24 12:18:23.365 | HD Request # 132 | Received 2 Intraday data records from 2024-09-24 11:59:22.084000 to 2024-09-24 11:59:22.084001 (0.0 seconds. Delay: 19.0 minutes) and wrote 0 records for MJYZ4.CME
2024-09-24 12:18:23.365 | HD Request # 132 | Add time&sales data | Remembered last file record date-time: 2024-09-24 15:59:22.084001
2024-09-24 12:18:23.365 | HD Request # 132 | Completion time: 2s.
2024-09-24 12:18:23.365 | HD Request # 132 | Intraday data download complete for MJYZ4.CME. Unique request ID: 131
2024-09-24 12:18:23.365 | Removing historical data download ID 131.
2024-09-24 12:18:23.365 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 12:18:23.365 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 12:18:23.365 | HD Request # 132 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:23.365 | Triggering next historical data download in queue.
2024-09-24 12:18:23.365 | HD Request # 133 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 12:18:23.365 | HD Request # 133 | Download start date-time: 2024-09-24 12:17:53.000000. File last date-time: 2024-09-24 12:17:53.966000
2024-09-24 12:18:23.365 | HD Request # 133 | Using server: ds32.sierracharts.com port 10149
2024-09-24 12:18:23.365 | Socket (5) | Creating socket.
2024-09-24 12:18:23.365 | Socket (5) | New receive buffer size: 0
2024-09-24 12:18:23.365 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 12:18:23.642 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 12:18:23.642 | Socket (6) | Closed.
2024-09-24 12:18:23.936 | HD Request # 133 | Setting DTC encoding to Binary VLS
2024-09-24 12:18:23.936 | HD Request # 133 | Sending historical data logon request message.
2024-09-24 12:18:24.215 | HD Request # 133 | Requesting Intraday data. Start date-time: 2024-09-24 12:17:53. Record interval: 0. Symbol: NQZ24
2024-09-24 12:18:24.265 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 3296
2024-09-24 12:18:24.495 | HD Request # 133 | Decompressing data.
2024-09-24 12:18:24.775 | HD Request # 133 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 12:17:53.142000
2024-09-24 12:18:24.775 | Socket (5) | CloseSocket call.
2024-09-24 12:18:24.775 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 12:18:24.843 | Historical data download thread signaled to stop.
2024-09-24 12:18:24.843 | HD Request # 133 | Timestamp of first Intraday data file record written: 2024-09-24 12:17:55.379000.
2024-09-24 12:18:24.843 | HD Request # 133 | Received 218 Intraday data records from 2024-09-24 12:17:53.142000 to 2024-09-24 12:18:22.337000 (29.2 seconds. Delay: 2.5 seconds) and wrote 191 records for NQZ4.CME
2024-09-24 12:18:24.843 | HD Request # 133 | Add time&sales data | Remembered last file record date-time: 2024-09-24 16:18:22.337000
2024-09-24 12:18:24.843 | Added 14 Time and Sales records to Intraday data file for NQZ4.CME after download.
2024-09-24 12:18:24.843 | HD Request # 133 | Completion time: 1s.
2024-09-24 12:18:24.843 | HD Request # 133 | Intraday data download complete for NQZ4.CME. Unique request ID: 132
2024-09-24 12:18:24.843 | Removing historical data download ID 132.
2024-09-24 12:18:24.843 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 12:18:24.843 | Intraday chart data file opened for NQZ4.CME
2024-09-24 12:18:24.843 | HD Request # 133 | Enabling Intraday chart updating for symbol.
2024-09-24 12:18:24.843 | No download requests in the queue to start downloads for.
2024-09-24 12:18:25.054 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 12:18:25.054 | Socket (5) | Closed.
2024-09-24 12:18:29.303 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-24 12:18:29.303 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\M6AZ4.CME.scid. Thread ID: 3296
2024-09-24 12:32:43.344 | NQZ4.CME[M] 5 Min #12 | Reloading chart.
2024-09-24 12:32:43.875 | NQZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 12:32:43.893 | NQZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-24 12:32:44.162 | NQZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 12:43:37.483 | NQZ4.CME[M] 30 Min #12 | Reloading chart.
2024-09-24 12:43:38.001 | NQZ4.CME[M] 30 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 19:45:00
2024-09-24 12:43:38.024 | NQZ4.CME[M] 30 Min #12 | Chart data loading complete.
2024-09-24 12:43:47.910 | NQZ4.CME[M] 120 Min #12 | Reloading chart.
2024-09-24 12:43:48.426 | NQZ4.CME[M] 120 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 18:15:00
2024-09-24 12:43:48.453 | NQZ4.CME[M] 120 Min #12 | Chart data loading complete.
2024-09-24 12:43:57.027 | NQZ4.CME[M] 5 Min #12 | Reloading chart.
2024-09-24 12:43:57.525 | NQZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 12:43:57.543 | NQZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-24 12:58:12.158 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MJYZ4.CME.scid. Thread ID: 3296
2024-09-24 13:30:21.577 | NQZ4.CME[M] 30 Min #12 | Reloading chart.
2024-09-24 13:30:22.095 | NQZ4.CME[M] 30 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 19:45:00
2024-09-24 13:30:22.117 | NQZ4.CME[M] 30 Min #12 | Chart data loading complete.
2024-09-24 13:50:39.711 | NQZ4.CME[M] 30 Min #12 | Reloading chart.
2024-09-24 13:50:40.318 | NQZ4.CME[M] 30 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 19:45:00
2024-09-24 13:50:40.342 | NQZ4.CME[M] 30 Min #12 | Chart data loading complete.
2024-09-24 13:50:43.833 | NQZ4.CME[M] 240 Min #12 | Reloading chart.
2024-09-24 13:50:44.350 | NQZ4.CME[M] 240 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 16:15:00
2024-09-24 13:50:44.377 | NQZ4.CME[M] 240 Min #12 | Chart data loading complete.
2024-09-24 13:50:44.404 | NQZ4.CME[M] 120 Min #12 | Reloading chart.
2024-09-24 13:50:44.962 | NQZ4.CME[M] 120 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 18:15:00
2024-09-24 13:50:44.987 | NQZ4.CME[M] 120 Min #12 | Chart data loading complete.
2024-09-24 13:50:51.386 | NQZ4.CME[M] 240 Min #12 | Reloading chart.
2024-09-24 13:50:51.918 | NQZ4.CME[M] 240 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 16:15:00
2024-09-24 13:50:51.946 | NQZ4.CME[M] 240 Min #12 | Chart data loading complete.
2024-09-24 13:51:00.629 | NQZ4.CME[M] 5 Min #12 | Reloading chart.
2024-09-24 13:51:01.240 | NQZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 13:51:01.255 | NQZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-24 13:55:23.603 | NQZ4.CME[M] 15 Min #12 | Reloading chart.
2024-09-24 13:55:24.113 | NQZ4.CME[M] 15 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 13:55:24.129 | NQZ4.CME[M] 15 Min #12 | Chart data loading complete.
2024-09-24 15:09:16.346 | NQZ4.CME [CBV][M] 15 Min #8 | Reloading chart.
2024-09-24 15:09:16.349 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 15:09:16.349 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 15:09:16.349 | Triggering next historical data download in queue.
2024-09-24 15:09:16.350 | NQZ4.CME [CBV][M] 15 Min #8 | Performing continuous chart historical Daily data download for symbol NQZ4.CME starting at last date in file.
2024-09-24 15:09:16.350 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-24 15:09:16.350 | Triggering next historical data download in queue.
2024-09-24 15:09:16.359 | NQZ4.CME [CBV][M] 15 Min #8 | Waiting for historical downloads to complete with the IDs: 134, 135,
2024-09-24 15:09:16.360 | HD Request # 134 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 15:09:16.360 | HD Request # 134 | Download start date-time: 2024-09-24 15:09:17.000000. File last date-time: 2024-09-24 15:09:17.801002
2024-09-24 15:09:16.360 | HD Request # 134 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:09:16.361 | HD Request # 135 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 15:09:16.480 | Socket (5) | Creating socket.
2024-09-24 15:09:16.480 | Socket (5) | New receive buffer size: 0
2024-09-24 15:09:16.480 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:09:17.057 | HD Request # 134 | Setting DTC encoding to Binary VLS
2024-09-24 15:09:17.057 | HD Request # 134 | Sending historical data logon request message.
2024-09-24 15:09:17.469 | HD Request # 135 | Requesting historical Daily data for NQZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 15:09:17.834 | HD Request # 134 | Requesting Intraday data. Start date-time: 2024-09-24 15:09:17. Record interval: 0. Symbol: NQZ24
2024-09-24 15:09:18.116 | HD Request # 134 | Decompressing data.
2024-09-24 15:09:18.497 | HD Request # 135 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-19.
2024-09-24 15:09:18.497 | HD Request # 135 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-24 15:09:18.499 | HD Request # 135 | Bytes received: 237
2024-09-24 15:09:18.499 | HD Request # 135 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for NQZ4.CME
2024-09-24 15:09:18.499 | HD Request # 135 | Completion time: 2s.
2024-09-24 15:09:18.499 | HD Request # 135 | Daily data download complete for NQZ4.CME. Unique request ID: 135
2024-09-24 15:09:18.499 | Removing historical data download ID 135.
2024-09-24 15:09:18.499 | No download requests in the queue to start downloads for.
2024-09-24 15:09:18.690 | HD Request # 134 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 14:09:14.580000
2024-09-24 15:09:18.712 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 15:09:18.712 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:09:18.712 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:09:19.031 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 15:09:19.031 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:09:19.031 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:09:19.298 | Socket (5) | CloseSocket call.
2024-09-24 15:09:19.298 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:09:19.335 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 15:09:19.335 | Historical data download thread signaled to stop.
2024-09-24 15:09:19.335 | HD Request # 134 | Timestamp of first Intraday data file record written: 2024-09-24 15:09:18.067000.
2024-09-24 15:09:19.335 | HD Request # 134 | Received 32371 Intraday data records from 2024-09-24 14:09:14.580000 to 2024-09-24 15:09:20.253000 (60.1 minutes. Delay: -0.9 seconds) and wrote 12 records for NQZ4.CME
2024-09-24 15:09:19.335 | HD Request # 134 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:09:20.253000
2024-09-24 15:09:19.335 | Added 1 Time and Sales records to Intraday data file for NQZ4.CME after download.
2024-09-24 15:09:19.335 | HD Request # 134 | Completion time: 3s.
2024-09-24 15:09:19.335 | HD Request # 134 | Intraday data download complete for NQZ4.CME. Unique request ID: 134
2024-09-24 15:09:19.335 | Removing historical data download ID 134.
2024-09-24 15:09:19.335 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 15:09:19.335 | Intraday chart data file opened for NQZ4.CME
2024-09-24 15:09:19.335 | HD Request # 134 | Enabling Intraday chart updating for symbol.
2024-09-24 15:09:19.335 | No download requests in the queue to start downloads for.
2024-09-24 15:09:19.374 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 15:09:19.530 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 15:09:19.530 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:09:19.530 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:09:19.578 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:09:19.578 | Socket (5) | Closed.
2024-09-24 15:09:19.876 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 15:09:20.187 | NQZ4.CME [CBV][M] 15 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:09:20.187 | NQZ4.CME [CBV][M] 15 Min #8 | Reloading chart. | Number times message added: 1
2024-09-24 15:09:21.479 | NQZ4.CME [CBV][M] 15 Min #8 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-24 15:09:21.495 | NQZ4.CME [CBV][M] 15 Min #8 | Chart data loading complete.
2024-09-24 15:09:24.609 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 3296
2024-09-24 15:09:38.436 | NQZ4.CME [CBV][M] Rev. 16t-20 #8 | Reloading chart.
2024-09-24 15:09:39.942 | NQZ4.CME [CBV][M] Rev. 16t-20 #8 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-24 15:09:39.984 | NQZ4.CME [CBV][M] Rev. 16t-20 #8 | Chart data loading complete.
2024-09-24 15:11:48.267 | NQZ4.CME [CBV][M] 1 Min #8 | Reloading chart.
2024-09-24 15:11:49.467 | NQZ4.CME [CBV][M] 1 Min #8 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-24 15:11:49.497 | NQZ4.CME [CBV][M] 1 Min #8 | Chart data loading complete.
2024-09-24 15:24:44.293 | 6AZ4.CME [CBV][M] 240 Min #15 | Reloading chart.
2024-09-24 15:24:44.307 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 15:24:44.308 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 15:24:44.308 | Triggering next historical data download in queue.
2024-09-24 15:24:44.308 | 6AZ4.CME [CBV][M] 240 Min #15 | Performing continuous chart historical Daily data download for symbol 6AZ4.CME starting at last date in file.
2024-09-24 15:24:44.308 | Added historical Daily data request for 6AZ4.CME to the queue.
2024-09-24 15:24:44.372 | 6AZ4.CME [CBV][M] 240 Min #15 | Waiting for historical downloads to complete with the IDs: 136, 137,
2024-09-24 15:24:44.373 | HD Request # 136 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 15:24:44.373 | HD Request # 136 | Download start date-time: 2024-09-24 15:24:41.000000. File last date-time: 2024-09-24 15:24:41.916000
2024-09-24 15:24:44.373 | HD Request # 136 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:24:44.373 | Socket (5) | Creating socket.
2024-09-24 15:24:44.373 | Socket (5) | New receive buffer size: 0
2024-09-24 15:24:44.373 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:24:44.374 | HD Request # 137 | Downloading Historical Daily chart data for 6AZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 15:24:44.928 | HD Request # 136 | Setting DTC encoding to Binary VLS
2024-09-24 15:24:44.928 | HD Request # 136 | Sending historical data logon request message.
2024-09-24 15:24:45.368 | HD Request # 137 | Requesting historical Daily data for A6Z24 starting at 2024-09-18. SC External HD service.
2024-09-24 15:24:45.711 | HD Request # 136 | Requesting Intraday data. Start date-time: 2024-09-24 15:24:41. Record interval: 0. Symbol: 6AZ24
2024-09-24 15:24:45.993 | HD Request # 136 | Decompressing data.
2024-09-24 15:24:46.264 | HD Request # 136 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 15:24:41.916000
2024-09-24 15:24:46.264 | Socket (5) | CloseSocket call.
2024-09-24 15:24:46.264 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:24:46.306 | Historical data download thread signaled to stop.
2024-09-24 15:24:46.306 | HD Request # 136 | Received 1 Intraday data record from 2024-09-24 15:24:41.916000 to 2024-09-24 15:24:41.916000 (0.0 seconds. Delay: 4.4 seconds) and wrote 0 records for 6AZ4.CME
2024-09-24 15:24:46.306 | HD Request # 136 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:24:41.916000
2024-09-24 15:24:46.306 | HD Request # 136 | Completion time: 2s.
2024-09-24 15:24:46.306 | HD Request # 136 | Intraday data download complete for 6AZ4.CME. Unique request ID: 136
2024-09-24 15:24:46.306 | Removing historical data download ID 136.
2024-09-24 15:24:46.306 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 15:24:46.306 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 15:24:46.306 | HD Request # 136 | Enabling Intraday chart updating for symbol.
2024-09-24 15:24:46.306 | No download requests in the queue to start downloads for.
2024-09-24 15:24:46.306 | HD Request # 137 | Receiving historical Daily data for 6AZ4.CME starting at 2024-09-19.
2024-09-24 15:24:46.306 | HD Request # 137 | Writing historical Daily data to the file 6AZ4.CME.dly.
2024-09-24 15:24:46.310 | HD Request # 137 | Bytes received: 242
2024-09-24 15:24:46.310 | HD Request # 137 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for 6AZ4.CME
2024-09-24 15:24:46.310 | HD Request # 137 | Completion time: 2s.
2024-09-24 15:24:46.310 | HD Request # 137 | Daily data download complete for 6AZ4.CME. Unique request ID: 137
2024-09-24 15:24:46.310 | Removing historical data download ID 137.
2024-09-24 15:24:46.310 | No download requests in the queue to start downloads for.
2024-09-24 15:24:46.425 | 6AZ4.CME [CBV][M] 240 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:24:46.425 | 6AZ4.CME [CBV][M] 240 Min #15 | Reloading chart.
2024-09-24 15:24:46.545 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:24:46.545 | Socket (5) | Closed.
2024-09-24 15:24:47.121 | 6AZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 15:24:47.121 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:24:47.121 | 6AZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:24:47.959 | 6AZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 15:24:47.959 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:24:47.959 | 6AZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:24:48.739 | 6AZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 15:24:48.746 | 6AZ4.CME [CBV][M] 240 Min #15 | Chart data loading complete.
2024-09-24 15:24:48.749 | 6AZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 15:24:48.749 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:24:48.749 | 6AZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:24:49.487 | 6AZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 15:24:49.683 | 6AZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 15:24:49.783 | 6AZ4.CME [CBV][M] 240 Min #15 | Reloading chart.
2024-09-24 15:24:51.802 | 6AZ4.CME [CBV][M] 240 Min #15 | Chart data loading complete.
2024-09-24 15:24:52.235 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\6AZ4.CME.scid. Thread ID: 3296
2024-09-24 15:25:23.423 | 6AZ4.CME [CBV][M] 60 Min #15 | Reloading chart.
2024-09-24 15:25:25.193 | 6AZ4.CME [CBV][M] 60 Min #15 | Chart data loading complete.
2024-09-24 15:32:14.033 | NQZ4.CME[M] 5 Min #12 | Reloading chart.
2024-09-24 15:32:14.629 | NQZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 15:32:14.645 | NQZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-24 15:45:11.212 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
2024-09-24 15:45:11.212 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 15:45:11.212 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:45:11.212 | DTC Client socket (2) | Max send buffers used during socket life: 4
2024-09-24 15:45:11.212 | DTC Client socket (2) | Max send buffer size during socket life: 1401
2024-09-24 15:45:11.212 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 15:45:11.212 | DTC Client socket (2) | Closed.
2024-09-24 15:45:11.213 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 15:45:11.213 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:45:11.213 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:45:11.215 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:45:14.219 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:45:14.335 | DTC Client socket (2) | Creating socket.
2024-09-24 15:45:14.335 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:45:14.335 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:45:26.761 | File >> Reconnect selected.
2024-09-24 15:45:27.032 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 15:45:27.033 | DTC Client socket (1) | CloseSocket call.
2024-09-24 15:45:27.033 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-09-24 15:45:27.033 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-09-24 15:45:27.033 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 15:45:27.033 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:45:27.033 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:45:27.033 | SC Data with Depth | Waiting for socket receive thread to end
2024-09-24 15:45:27.033 | DTC Client socket (2) | Closed.
2024-09-24 15:45:27.034 | DTC Client socket (4) | CloseSocket call.
2024-09-24 15:45:27.034 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:45:27.034 | SC Data with Depth | Disconnected from the server.
2024-09-24 15:45:27.034 | Rithmic Direct - DTC | Disconnected.
2024-09-24 15:45:27.034 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 15:45:27.278 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 15:45:27.278 | DTC Client socket (1) | Closed.
2024-09-24 15:45:27.432 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:45:27.432 | DTC Client socket (4) | Closed.
2024-09-24 15:45:31.163 |
2024-09-24 15:45:31.163 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 15:45:31.163 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 15:45:31.163 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 15:45:31.505 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 15:45:31.505 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 15:45:31.505 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 15:45:31.749 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 15:45:31.749 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 15:45:31.749 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 15:45:31.749 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | Received logon response.
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | Server Name: .
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 15:45:32.488 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 15:45:32.489 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 15:45:32.489 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 15:45:32.489 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 15:45:32.489 | Using symbol data fast lookup vector
2024-09-24 15:45:32.490 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 15:45:32.490 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:45:32.490 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 15:45:32.490 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 15:45:32.490 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 15:45:32.490 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 15:45:32.490 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 15:45:32.490 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 15:45:32.490 | DTC Client socket (2) | Creating socket.
2024-09-24 15:45:32.490 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:45:32.490 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:45:32.813 | Mapping 6AZ4.CME to 6AZ24. Service code: cme
2024-09-24 15:45:32.813 | Denali Data Feed | Starting real-time market data updates for: 6AZ4.CME (6AZ24). ID: 3 Service code: cme
2024-09-24 15:45:32.813 | Denali Data Feed | Requesting security definition data for: 6AZ4.CME (6AZ24). ID: 3
2024-09-24 15:45:32.813 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 15:45:32.813 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 4 Service code: cme
2024-09-24 15:45:32.813 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 4
2024-09-24 15:45:32.813 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 15:45:32.813 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 15:45:32.813 | Triggering next historical data download in queue.
2024-09-24 15:45:32.833 | Delaying start of download for NQZ4.CME.
2024-09-24 15:45:33.042 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 15:45:33.042 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 15:45:33.042 | Triggering next historical data download in queue.
2024-09-24 15:45:33.042 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 15:45:33.042 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 15:45:33.043 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 15:45:33.043 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 5 Service code: cme
2024-09-24 15:45:33.043 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 5
2024-09-24 15:45:33.043 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 15:45:33.043 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 15:45:33.043 | Triggering next historical data download in queue.
2024-09-24 15:45:33.043 | Mapping M6AZ4.CME to M6AZ24. Service code: cme
2024-09-24 15:45:33.043 | Denali Data Feed | Starting real-time market data updates for: M6AZ4.CME (M6AZ24). ID: 6 Service code: cme
2024-09-24 15:45:33.043 | Denali Data Feed | Requesting security definition data for: M6AZ4.CME (M6AZ24). ID: 6
2024-09-24 15:45:33.043 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 15:45:33.043 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 15:45:33.044 | Mapping MCLU4.NYMEX to MCLU24. Service code: nymex
2024-09-24 15:45:33.044 | Denali Data Feed | Starting real-time market data updates for: MCLU4.NYMEX (MCLU24). ID: 7 Service code: nymex
2024-09-24 15:45:33.044 | Denali Data Feed | Requesting security definition data for: MCLU4.NYMEX (MCLU24). ID: 7
2024-09-24 15:45:33.044 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 15:45:33.044 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 15:45:33.044 | Triggering next historical data download in queue.
2024-09-24 15:45:33.044 | Mapping CLX4.NYMEX to CLX24. Service code: nymex
2024-09-24 15:45:33.044 | Denali Data Feed | Starting real-time market data updates for: CLX4.NYMEX (CLX24). ID: 8 Service code: nymex
2024-09-24 15:45:33.044 | Denali Data Feed | Requesting security definition data for: CLX4.NYMEX (CLX24). ID: 8
2024-09-24 15:45:33.044 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 15:45:33.044 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 15:45:33.045 | Mapping 6JZ4.CME to 6JZ24. Service code: cme
2024-09-24 15:45:33.045 | Denali Data Feed | Starting real-time market data updates for: 6JZ4.CME (6JZ24). ID: 9 Service code: cme
2024-09-24 15:45:33.045 | Denali Data Feed | Requesting security definition data for: 6JZ4.CME (6JZ24). ID: 9
2024-09-24 15:45:33.045 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 15:45:33.045 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 15:45:33.045 | Triggering next historical data download in queue.
2024-09-24 15:45:33.083 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2024-09-24 15:45:33.083 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 10 Service code: comex
2024-09-24 15:45:33.083 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 10
2024-09-24 15:45:33.083 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 15:45:33.083 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 15:45:33.083 | Triggering next historical data download in queue.
2024-09-24 15:45:33.159 | Mapping ESU4.CME to ESU24. Service code: cme
2024-09-24 15:45:33.160 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 11 Service code: cme
2024-09-24 15:45:33.160 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 11
2024-09-24 15:45:33.160 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 15:45:33.160 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 15:45:33.160 | Triggering next historical data download in queue.
2024-09-24 15:45:33.160 | Mapping MGCZ4.COMEX to MGCZ24. Service code: comex
2024-09-24 15:45:33.160 | Denali Data Feed | Starting real-time market data updates for: MGCZ4.COMEX (MGCZ24). ID: 12 Service code: comex
2024-09-24 15:45:33.160 | Denali Data Feed | Requesting security definition data for: MGCZ4.COMEX (MGCZ24). ID: 12
2024-09-24 15:45:33.160 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 15:45:33.160 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 15:45:33.196 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 15:45:33.196 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 13 Service code: cme
2024-09-24 15:45:33.196 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 13
2024-09-24 15:45:33.196 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 15:45:33.196 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 15:45:33.196 | Triggering next historical data download in queue.
2024-09-24 15:45:33.213 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 14 Service code: fxstatscalc
2024-09-24 15:45:33.213 | SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443
2024-09-24 15:45:33.213 | SC Data with Depth | Requesting security definition data for: USDX. ID: 14
2024-09-24 15:45:33.213 | Added historical Intraday data request for USDX to the queue.
2024-09-24 15:45:33.213 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2024-09-24 15:45:33.214 | Triggering next historical data download in queue.
2024-09-24 15:45:33.324 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 15:45:33.324 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 15 Service code: cme
2024-09-24 15:45:33.324 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 15
2024-09-24 15:45:33.324 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 15:45:33.324 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 15:45:33.324 | Triggering next historical data download in queue.
2024-09-24 15:45:33.328 | DTC Client socket (4) | Creating socket.
2024-09-24 15:45:33.328 | DTC Client socket (4) | New receive buffer size: 0
2024-09-24 15:45:33.328 | DTC Client socket (4) | Connecting to IP: 67.214.125.7.
2024-09-24 15:45:33.608 | SC Data with Depth | Network connection to server complete.
2024-09-24 15:45:33.608 | SC Data with Depth | Starting socket receive thread.
2024-09-24 15:45:33.608 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 15:45:33.707 | Mapping MJYZ4.CME to MJYZ24. Service code: cme
2024-09-24 15:45:33.707 | Denali Data Feed | Starting real-time market data updates for: MJYZ4.CME (MJYZ24). ID: 16 Service code: cme
2024-09-24 15:45:33.707 | Denali Data Feed | Requesting security definition data for: MJYZ4.CME (MJYZ24). ID: 16
2024-09-24 15:45:33.707 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 15:45:33.707 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 15:45:33.707 | Triggering next historical data download in queue.
2024-09-24 15:45:33.903 | SC Data with Depth | Setting DTC encoding to Binary VLS
2024-09-24 15:45:33.903 | SC Data with Depth | Sending logon request message.
2024-09-24 15:45:34.674 | SC Data with Depth | Received logon response.
2024-09-24 15:45:34.674 | SC Data with Depth | Server Name: SC Realtime Server.
2024-09-24 15:45:34.674 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:45:34.674 | SC Data with Depth | Successfully connected.
2024-09-24 15:45:34.674 | SC Data with Depth | Trading is not supported.
2024-09-24 15:45:34.674 | SC Data with Depth | MarketDepthIsSupported: 1
2024-09-24 15:45:34.674 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2024-09-24 15:45:35.454 | SC Data with Depth | Received security definition for symbol USDX
2024-09-24 15:45:37.481 | Requesting market depth updates for: 6AZ4.CME if supported. NumLevels=50
2024-09-24 15:45:37.481 | Requesting market depth updates for: 6JZ4.CME if supported. NumLevels=50
2024-09-24 15:45:37.481 | Requesting market depth updates for: CLX4.NYMEX if supported. NumLevels=50
2024-09-24 15:45:37.481 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2024-09-24 15:45:37.481 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 15:45:37.481 | Requesting market depth updates for: GCZ4.COMEX if supported. NumLevels=50
2024-09-24 15:45:37.481 | Requesting market depth updates for: MESU4.CME if supported. NumLevels=50
2024-09-24 15:45:37.481 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 15:45:37.481 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 15:45:51.422 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Creating socket. Using TLS 1.2.
2024-09-24 15:45:51.423 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | New receive buffer size: 0
2024-09-24 15:45:51.423 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Connecting to IP: 216.66.0.130.
2024-09-24 15:45:53.158 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | CloseSocket call.
2024-09-24 15:45:53.158 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:45:53.405 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Socket gracefully closed by remote side.
2024-09-24 15:45:53.405 | HTTPS connection ID:10 to downloads.rithmic.com:443 for request ID:10 (5) | Closed.
2024-09-24 15:45:53.531 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:45:53.536 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:45:53.536 | Denali Data Feed | Failed connections: 1
2024-09-24 15:45:53.536 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:45:53.536 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:45:53.536 | DTC Client socket (2) | Closed.
2024-09-24 15:45:53.536 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:45:56.662 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:45:56.663 | DTC Client socket (2) | Creating socket.
2024-09-24 15:45:56.663 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:45:56.663 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:46:03.688 | HD Request # 138 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 15:46:03.688 | HD Request # 138 | Download start date-time: 2024-09-24 15:44:52.000000. File last date-time: 2024-09-24 15:44:52.009000
2024-09-24 15:46:03.688 | HD Request # 138 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:46:03.688 | Socket (5) | Creating socket.
2024-09-24 15:46:03.689 | Socket (5) | New receive buffer size: 0
2024-09-24 15:46:03.689 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:04.246 | HD Request # 138 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:04.246 | HD Request # 138 | Sending historical data logon request message.
2024-09-24 15:46:05.007 | HD Request # 138 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:52. Record interval: 0. Symbol: NQZ24
2024-09-24 15:46:05.280 | HD Request # 138 | Decompressing data.
2024-09-24 15:46:05.554 | HD Request # 138 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 15:44:52.009000
2024-09-24 15:46:05.554 | Socket (5) | CloseSocket call.
2024-09-24 15:46:05.554 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:05.564 | Historical data download thread signaled to stop.
2024-09-24 15:46:05.564 | HD Request # 138 | Timestamp of first Intraday data file record written: 2024-09-24 15:44:52.125000.
2024-09-24 15:46:05.564 | HD Request # 138 | Received 850 Intraday data records from 2024-09-24 15:44:52.009000 to 2024-09-24 15:46:06.359000 (74.3 seconds. Delay: -0.8 seconds) and wrote 849 records for NQZ4.CME
2024-09-24 15:46:05.565 | HD Request # 138 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:06.359000
2024-09-24 15:46:05.565 | HD Request # 138 | Completion time: 2s.
2024-09-24 15:46:05.565 | HD Request # 138 | Intraday data download complete for NQZ4.CME. Unique request ID: 138
2024-09-24 15:46:05.565 | Removing historical data download ID 138.
2024-09-24 15:46:05.565 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 15:46:05.565 | Intraday chart data file opened for NQZ4.CME
2024-09-24 15:46:05.565 | HD Request # 138 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:05.565 | Triggering next historical data download in queue.
2024-09-24 15:46:05.565 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:05.565 | HD Request # 139 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 15:46:05.565 | HD Request # 139 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 15:46:05.565 | HD Request # 139 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:46:05.565 | Socket (6) | Creating socket.
2024-09-24 15:46:05.565 | Socket (6) | New receive buffer size: 0
2024-09-24 15:46:05.565 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:05.827 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:46:05.827 | Socket (5) | Closed.
2024-09-24 15:46:06.125 | HD Request # 139 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:06.125 | HD Request # 139 | Sending historical data logon request message.
2024-09-24 15:46:06.888 | HD Request # 139 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 15:46:07.161 | HD Request # 139 | Decompressing data.
2024-09-24 15:46:07.434 | HD Request # 139 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 15:46:07.434 | Socket (6) | CloseSocket call.
2024-09-24 15:46:07.434 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:07.434 | Historical data download thread signaled to stop.
2024-09-24 15:46:07.434 | HD Request # 139 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 4.3 days) and wrote 0 records for MESU4.CME
2024-09-24 15:46:07.434 | HD Request # 139 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 15:46:07.434 | HD Request # 139 | Completion time: 2s.
2024-09-24 15:46:07.434 | HD Request # 139 | Intraday data download complete for MESU4.CME. Unique request ID: 139
2024-09-24 15:46:07.434 | Removing historical data download ID 139.
2024-09-24 15:46:07.434 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 15:46:07.434 | Intraday chart data file opened for MESU4.CME
2024-09-24 15:46:07.434 | HD Request # 139 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:07.434 | Triggering next historical data download in queue.
2024-09-24 15:46:07.434 | Historical data for MESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:07.434 | HD Request # 140 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 15:46:07.435 | HD Request # 140 | Download start date-time: 2024-09-24 15:44:51.000000. File last date-time: 2024-09-24 15:44:51.166000
2024-09-24 15:46:07.435 | HD Request # 140 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:46:07.435 | Socket (5) | Creating socket.
2024-09-24 15:46:07.435 | Socket (5) | New receive buffer size: 0
2024-09-24 15:46:07.435 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:07.708 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:46:07.708 | Socket (6) | Closed.
2024-09-24 15:46:07.998 | HD Request # 140 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:07.998 | HD Request # 140 | Sending historical data logon request message.
2024-09-24 15:46:08.275 | HD Request # 140 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:51. Record interval: 0. Symbol: 6AZ24
2024-09-24 15:46:08.552 | HD Request # 140 | Decompressing data.
2024-09-24 15:46:08.828 | HD Request # 140 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 15:44:51.166000
2024-09-24 15:46:08.829 | Socket (5) | CloseSocket call.
2024-09-24 15:46:08.829 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:08.829 | Historical data download thread signaled to stop.
2024-09-24 15:46:08.829 | HD Request # 140 | Timestamp of first Intraday data file record written: 2024-09-24 15:44:58.041000.
2024-09-24 15:46:08.829 | HD Request # 140 | Received 83 Intraday data records from 2024-09-24 15:44:51.166000 to 2024-09-24 15:46:09.626000 (78.5 seconds. Delay: -0.8 seconds) and wrote 82 records for 6AZ4.CME
2024-09-24 15:46:08.829 | HD Request # 140 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:09.626000
2024-09-24 15:46:08.829 | HD Request # 140 | Completion time: 1s.
2024-09-24 15:46:08.829 | HD Request # 140 | Intraday data download complete for 6AZ4.CME. Unique request ID: 140
2024-09-24 15:46:08.829 | Removing historical data download ID 140.
2024-09-24 15:46:08.829 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 15:46:08.829 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 15:46:08.829 | HD Request # 140 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:08.829 | Triggering next historical data download in queue.
2024-09-24 15:46:08.829 | Historical data for 6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:08.829 | HD Request # 141 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 15:46:08.830 | HD Request # 141 | Download start date-time: 2024-09-24 15:44:51.000000. File last date-time: 2024-09-24 15:44:51.977036
2024-09-24 15:46:08.830 | HD Request # 141 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:46:08.830 | Socket (6) | Creating socket.
2024-09-24 15:46:08.830 | Socket (6) | New receive buffer size: 0
2024-09-24 15:46:08.830 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:09.105 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:46:09.105 | Socket (5) | Closed.
2024-09-24 15:46:09.383 | HD Request # 141 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:09.383 | HD Request # 141 | Sending historical data logon request message.
2024-09-24 15:46:09.653 | HD Request # 141 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:51. Record interval: 0. Symbol: ESZ24
2024-09-24 15:46:09.926 | HD Request # 141 | Decompressing data.
2024-09-24 15:46:10.200 | HD Request # 141 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 15:44:51.375000
2024-09-24 15:46:10.201 | Socket (6) | CloseSocket call.
2024-09-24 15:46:10.201 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:10.201 | Historical data download thread signaled to stop.
2024-09-24 15:46:10.201 | HD Request # 141 | Timestamp of first Intraday data file record written: 2024-09-24 15:44:52.150000.
2024-09-24 15:46:10.201 | HD Request # 141 | Received 1423 Intraday data records from 2024-09-24 15:44:51.375000 to 2024-09-24 15:46:09.623009 (78.2 seconds. Delay: 0.6 seconds) and wrote 1384 records for ESZ4.CME
2024-09-24 15:46:10.202 | HD Request # 141 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:09.623009
2024-09-24 15:46:10.202 | HD Request # 141 | Completion time: 2s.
2024-09-24 15:46:10.202 | HD Request # 141 | Intraday data download complete for ESZ4.CME. Unique request ID: 141
2024-09-24 15:46:10.202 | Removing historical data download ID 141.
2024-09-24 15:46:10.202 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 15:46:10.202 | Intraday chart data file opened for ESZ4.CME
2024-09-24 15:46:10.202 | HD Request # 141 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:10.202 | Triggering next historical data download in queue.
2024-09-24 15:46:10.202 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:10.202 | HD Request # 142 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 15:46:10.202 | HD Request # 142 | Download start date-time: 2024-09-24 15:44:46.000000. File last date-time: 2024-09-24 15:44:46.653001
2024-09-24 15:46:10.202 | HD Request # 142 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:46:10.202 | Socket (5) | Creating socket.
2024-09-24 15:46:10.202 | Socket (5) | New receive buffer size: 0
2024-09-24 15:46:10.202 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:10.472 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:46:10.472 | Socket (6) | Closed.
2024-09-24 15:46:10.771 | HD Request # 142 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:10.771 | HD Request # 142 | Sending historical data logon request message.
2024-09-24 15:46:11.049 | HD Request # 142 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:46. Record interval: 0. Symbol: M6AZ24
2024-09-24 15:46:11.328 | HD Request # 142 | Decompressing data.
2024-09-24 15:46:11.605 | HD Request # 142 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 15:44:46.653000
2024-09-24 15:46:11.605 | Socket (5) | CloseSocket call.
2024-09-24 15:46:11.605 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:11.619 | Historical data download thread signaled to stop.
2024-09-24 15:46:11.619 | HD Request # 142 | Timestamp of first Intraday data file record written: 2024-09-24 15:45:25.121000.
2024-09-24 15:46:11.619 | HD Request # 142 | Received 19 Intraday data records from 2024-09-24 15:44:46.653000 to 2024-09-24 15:46:05.461000 (78.8 seconds. Delay: 6.2 seconds) and wrote 17 records for M6AZ4.CME
2024-09-24 15:46:11.619 | HD Request # 142 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:05.461000
2024-09-24 15:46:11.619 | HD Request # 142 | Completion time: 1s.
2024-09-24 15:46:11.619 | HD Request # 142 | Intraday data download complete for M6AZ4.CME. Unique request ID: 142
2024-09-24 15:46:11.619 | Removing historical data download ID 142.
2024-09-24 15:46:11.619 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 15:46:11.619 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 15:46:11.619 | HD Request # 142 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:11.619 | Triggering next historical data download in queue.
2024-09-24 15:46:11.619 | Historical data for M6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:11.619 | HD Request # 143 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 15:46:11.620 | HD Request # 143 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 15:46:11.620 | HD Request # 143 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:46:11.620 | Socket (6) | Creating socket.
2024-09-24 15:46:11.620 | Socket (6) | New receive buffer size: 0
2024-09-24 15:46:11.620 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:11.883 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:46:11.883 | Socket (5) | Closed.
2024-09-24 15:46:12.176 | HD Request # 143 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:12.176 | HD Request # 143 | Sending historical data logon request message.
2024-09-24 15:46:12.447 | HD Request # 143 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 15:46:12.720 | HD Request # 143 | Decompressing data.
2024-09-24 15:46:12.991 | HD Request # 143 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 15:46:12.991 | Socket (6) | CloseSocket call.
2024-09-24 15:46:12.991 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:12.991 | Historical data download thread signaled to stop.
2024-09-24 15:46:12.991 | HD Request # 143 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 36.1 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 15:46:12.991 | HD Request # 143 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 15:46:12.991 | HD Request # 143 | Completion time: 1s.
2024-09-24 15:46:12.991 | HD Request # 143 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 143
2024-09-24 15:46:12.991 | Removing historical data download ID 143.
2024-09-24 15:46:12.991 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 15:46:12.991 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 15:46:12.991 | HD Request # 143 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:12.991 | Triggering next historical data download in queue.
2024-09-24 15:46:12.991 | Historical data for MCLU4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:12.991 | HD Request # 144 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 15:46:12.991 | HD Request # 144 | Download start date-time: 2024-09-24 15:44:45.000000. File last date-time: 2024-09-24 15:44:45.991001
2024-09-24 15:46:12.991 | HD Request # 144 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:46:12.991 | Socket (5) | Creating socket.
2024-09-24 15:46:12.991 | Socket (5) | New receive buffer size: 0
2024-09-24 15:46:12.991 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:13.263 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:46:13.263 | Socket (6) | Closed.
2024-09-24 15:46:13.542 | HD Request # 144 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:13.542 | HD Request # 144 | Sending historical data logon request message.
2024-09-24 15:46:13.811 | HD Request # 144 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:45. Record interval: 0. Symbol: CLX24
2024-09-24 15:46:14.081 | HD Request # 144 | Decompressing data.
2024-09-24 15:46:14.350 | HD Request # 144 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 15:44:45.981000
2024-09-24 15:46:14.351 | Socket (5) | CloseSocket call.
2024-09-24 15:46:14.351 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:14.351 | Historical data download thread signaled to stop.
2024-09-24 15:46:14.351 | HD Request # 144 | Timestamp of first Intraday data file record written: 2024-09-24 15:44:55.389000.
2024-09-24 15:46:14.351 | HD Request # 144 | Received 102 Intraday data records from 2024-09-24 15:44:45.981000 to 2024-09-24 15:46:02.861001 (76.9 seconds. Delay: 11.5 seconds) and wrote 95 records for CLX4.NYMEX
2024-09-24 15:46:14.351 | HD Request # 144 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:02.861001
2024-09-24 15:46:14.351 | HD Request # 144 | Completion time: 2s.
2024-09-24 15:46:14.351 | HD Request # 144 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 144
2024-09-24 15:46:14.351 | Removing historical data download ID 144.
2024-09-24 15:46:14.351 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 15:46:14.351 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 15:46:14.351 | HD Request # 144 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:14.351 | Triggering next historical data download in queue.
2024-09-24 15:46:14.351 | Historical data for CLX4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:14.351 | HD Request # 145 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 15:46:14.352 | HD Request # 145 | Download start date-time: 2024-09-24 15:44:48.000000. File last date-time: 2024-09-24 15:44:48.812000
2024-09-24 15:46:14.352 | HD Request # 145 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:46:14.352 | Socket (6) | Creating socket.
2024-09-24 15:46:14.352 | Socket (6) | New receive buffer size: 0
2024-09-24 15:46:14.352 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:14.620 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:46:14.620 | Socket (5) | Closed.
2024-09-24 15:46:14.910 | HD Request # 145 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:14.910 | HD Request # 145 | Sending historical data logon request message.
2024-09-24 15:46:15.182 | HD Request # 145 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:48. Record interval: 0. Symbol: 6JZ24
2024-09-24 15:46:15.455 | HD Request # 145 | Decompressing data.
2024-09-24 15:46:15.727 | HD Request # 145 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 15:44:48.729000
2024-09-24 15:46:15.727 | Socket (6) | CloseSocket call.
2024-09-24 15:46:15.728 | Historical data download thread signaled to stop.
2024-09-24 15:46:15.728 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:15.728 | HD Request # 145 | Timestamp of first Intraday data file record written: 2024-09-24 15:44:53.160000.
2024-09-24 15:46:15.728 | HD Request # 145 | Received 67 Intraday data records from 2024-09-24 15:44:48.729000 to 2024-09-24 15:46:13.582000 (84.9 seconds. Delay: 2.1 seconds) and wrote 61 records for 6JZ4.CME
2024-09-24 15:46:15.728 | HD Request # 145 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:13.582000
2024-09-24 15:46:15.728 | HD Request # 145 | Completion time: 1s.
2024-09-24 15:46:15.728 | HD Request # 145 | Intraday data download complete for 6JZ4.CME. Unique request ID: 145
2024-09-24 15:46:15.728 | Removing historical data download ID 145.
2024-09-24 15:46:15.728 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 15:46:15.728 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 15:46:15.728 | HD Request # 145 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:15.728 | Triggering next historical data download in queue.
2024-09-24 15:46:15.728 | Historical data for 6JZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:15.728 | HD Request # 146 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 15:46:15.728 | HD Request # 146 | Download start date-time: 2024-09-24 15:44:51.000000. File last date-time: 2024-09-24 15:44:51.985000
2024-09-24 15:46:15.728 | HD Request # 146 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:46:15.728 | Socket (7) | Creating socket.
2024-09-24 15:46:15.729 | Socket (7) | New receive buffer size: 0
2024-09-24 15:46:15.729 | Socket (7) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:15.999 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:46:16.000 | Socket (6) | Closed.
2024-09-24 15:46:16.285 | HD Request # 146 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:16.285 | HD Request # 146 | Sending historical data logon request message.
2024-09-24 15:46:16.556 | HD Request # 146 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:51. Record interval: 0. Symbol: GCZ24
2024-09-24 15:46:16.828 | HD Request # 146 | Decompressing data.
2024-09-24 15:46:17.101 | HD Request # 146 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 15:44:51.104000
2024-09-24 15:46:17.101 | Socket (7) | CloseSocket call.
2024-09-24 15:46:17.101 | Socket (7) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:17.105 | Historical data download thread signaled to stop.
2024-09-24 15:46:17.105 | HD Request # 146 | Timestamp of first Intraday data file record written: 2024-09-24 15:44:55.230000.
2024-09-24 15:46:17.105 | HD Request # 146 | Received 407 Intraday data records from 2024-09-24 15:44:51.104000 to 2024-09-24 15:46:17.167002 (86.1 seconds. Delay: -0.1 seconds) and wrote 401 records for GCZ4.COMEX
2024-09-24 15:46:17.106 | HD Request # 146 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:17.167002
2024-09-24 15:46:17.106 | HD Request # 146 | Completion time: 2s.
2024-09-24 15:46:17.106 | HD Request # 146 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 146
2024-09-24 15:46:17.106 | Removing historical data download ID 146.
2024-09-24 15:46:17.106 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 15:46:17.106 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 15:46:17.106 | HD Request # 146 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:17.106 | Triggering next historical data download in queue.
2024-09-24 15:46:17.106 | Historical data for GCZ4.COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:17.106 | HD Request # 147 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 15:46:17.106 | HD Request # 147 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 15:46:17.106 | HD Request # 147 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:46:17.106 | Socket (5) | Creating socket.
2024-09-24 15:46:17.106 | Socket (5) | New receive buffer size: 0
2024-09-24 15:46:17.106 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:17.373 | Socket (7) | Socket gracefully closed by remote side.
2024-09-24 15:46:17.373 | Socket (7) | Closed.
2024-09-24 15:46:17.655 | HD Request # 147 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:17.655 | HD Request # 147 | Sending historical data logon request message.
2024-09-24 15:46:17.708 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:46:17.708 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:46:17.708 | Denali Data Feed | Failed connections: 2
2024-09-24 15:46:17.708 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:46:17.708 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:46:17.708 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:46:17.708 | DTC Client socket (2) | Closed.
2024-09-24 15:46:17.924 | HD Request # 147 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 15:46:18.195 | HD Request # 147 | Decompressing data.
2024-09-24 15:46:18.464 | HD Request # 147 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 15:46:18.464 | Socket (5) | CloseSocket call.
2024-09-24 15:46:18.464 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:18.464 | Historical data download thread signaled to stop.
2024-09-24 15:46:18.464 | HD Request # 147 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 4.3 days) and wrote 0 records for ESU4.CME
2024-09-24 15:46:18.464 | HD Request # 147 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 15:46:18.464 | HD Request # 147 | Completion time: 1s.
2024-09-24 15:46:18.464 | HD Request # 147 | Intraday data download complete for ESU4.CME. Unique request ID: 147
2024-09-24 15:46:18.464 | Removing historical data download ID 147.
2024-09-24 15:46:18.464 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 15:46:18.464 | Intraday chart data file opened for ESU4.CME
2024-09-24 15:46:18.464 | HD Request # 147 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:18.464 | Triggering next historical data download in queue.
2024-09-24 15:46:18.464 | Historical data for ESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:18.464 | HD Request # 148 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 15:46:18.465 | HD Request # 148 | Download start date-time: 2024-09-24 15:44:50.000000. File last date-time: 2024-09-24 15:44:50.898001
2024-09-24 15:46:18.465 | HD Request # 148 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:46:18.465 | Socket (2) | Creating socket.
2024-09-24 15:46:18.465 | Socket (2) | New receive buffer size: 0
2024-09-24 15:46:18.465 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:18.734 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:46:18.734 | Socket (5) | Closed.
2024-09-24 15:46:19.034 | HD Request # 148 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:19.034 | HD Request # 148 | Sending historical data logon request message.
2024-09-24 15:46:19.312 | HD Request # 148 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:50. Record interval: 0. Symbol: MGCZ24
2024-09-24 15:46:19.592 | HD Request # 148 | Decompressing data.
2024-09-24 15:46:19.871 | HD Request # 148 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 15:44:50.395000
2024-09-24 15:46:19.871 | Socket (2) | CloseSocket call.
2024-09-24 15:46:19.871 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:19.871 | Historical data download thread signaled to stop.
2024-09-24 15:46:19.871 | HD Request # 148 | Timestamp of first Intraday data file record written: 2024-09-24 15:44:53.144000.
2024-09-24 15:46:19.871 | HD Request # 148 | Received 189 Intraday data records from 2024-09-24 15:44:50.395000 to 2024-09-24 15:46:16.957000 (86.6 seconds. Delay: 2.9 seconds) and wrote 186 records for MGCZ4.COMEX
2024-09-24 15:46:19.872 | HD Request # 148 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:16.957000
2024-09-24 15:46:19.872 | HD Request # 148 | Completion time: 1s.
2024-09-24 15:46:19.872 | HD Request # 148 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 148
2024-09-24 15:46:19.872 | Removing historical data download ID 148.
2024-09-24 15:46:19.872 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 15:46:19.872 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 15:46:19.872 | HD Request # 148 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:19.872 | Triggering next historical data download in queue.
2024-09-24 15:46:19.872 | Historical data for MGCZ4.COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:19.872 | HD Request # 149 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 15:46:19.872 | HD Request # 149 | Download start date-time: 2024-09-24 15:44:52.000000. File last date-time: 2024-09-24 15:44:52.009000
2024-09-24 15:46:19.872 | HD Request # 149 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:46:19.872 | Socket (5) | Creating socket.
2024-09-24 15:46:19.872 | Socket (5) | New receive buffer size: 0
2024-09-24 15:46:19.872 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:20.150 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 15:46:20.151 | Socket (2) | Closed.
2024-09-24 15:46:20.439 | HD Request # 149 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:20.439 | HD Request # 149 | Sending historical data logon request message.
2024-09-24 15:46:20.699 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:46:20.699 | DTC Client socket (2) | Creating socket.
2024-09-24 15:46:20.699 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:46:20.699 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:46:20.715 | HD Request # 149 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:52. Record interval: 0. Symbol: MNQZ24
2024-09-24 15:46:20.993 | HD Request # 149 | Decompressing data.
2024-09-24 15:46:21.272 | HD Request # 149 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 15:44:52.005000
2024-09-24 15:46:21.273 | Socket (5) | CloseSocket call.
2024-09-24 15:46:21.273 | Historical data download thread signaled to stop.
2024-09-24 15:46:21.273 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:21.273 | HD Request # 149 | Timestamp of first Intraday data file record written: 2024-09-24 15:44:52.129000.
2024-09-24 15:46:21.273 | HD Request # 149 | Received 1686 Intraday data records from 2024-09-24 15:44:52.005000 to 2024-09-24 15:46:22.688000 (90.7 seconds. Delay: -1.4 seconds) and wrote 1681 records for MNQZ4.CME
2024-09-24 15:46:21.273 | HD Request # 149 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:22.688000
2024-09-24 15:46:21.274 | HD Request # 149 | Completion time: 2s.
2024-09-24 15:46:21.274 | HD Request # 149 | Intraday data download complete for MNQZ4.CME. Unique request ID: 149
2024-09-24 15:46:21.274 | Removing historical data download ID 149.
2024-09-24 15:46:21.274 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 15:46:21.274 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 15:46:21.274 | HD Request # 149 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:21.274 | Triggering next historical data download in queue.
2024-09-24 15:46:21.274 | Historical data for MNQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:21.274 | HD Request # 150 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2024-09-24 15:46:21.274 | HD Request # 150 | Download start date-time: 2024-09-24 15:45:28.000000. File last date-time: 2024-09-24 15:45:28.000000
2024-09-24 15:46:21.274 | HD Request # 150 | Using server: ds4.sierracharts.com port 10150
2024-09-24 15:46:21.274 | Socket (6) | Creating socket.
2024-09-24 15:46:21.274 | Socket (6) | New receive buffer size: 0
2024-09-24 15:46:21.274 | Socket (6) | Connecting to IP: 67.214.125.7.
2024-09-24 15:46:21.549 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:46:21.549 | Socket (5) | Closed.
2024-09-24 15:46:21.821 | HD Request # 150 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:21.821 | HD Request # 150 | Sending historical data logon request message.
2024-09-24 15:46:22.571 | HD Request # 150 | Requesting Intraday data. Start date-time: 2024-09-24 15:45:28. Record interval: 0. Symbol: USDX
2024-09-24 15:46:22.843 | HD Request # 150 | Decompressing data.
2024-09-24 15:46:23.114 | HD Request # 150 | Receiving Intraday data for USDX starting at 2024-09-24 15:45:28.000000
2024-09-24 15:46:23.114 | Socket (6) | CloseSocket call.
2024-09-24 15:46:23.114 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:23.120 | Historical data download thread signaled to stop.
2024-09-24 15:46:23.120 | HD Request # 150 | Timestamp of first Intraday data file record written: 2024-09-24 15:45:30.000000.
2024-09-24 15:46:23.120 | HD Request # 150 | Received 55 Intraday data records from 2024-09-24 15:45:28.000000 to 2024-09-24 15:46:24.000000 (56.0 seconds. Delay: -0.9 seconds) and wrote 54 records for USDX
2024-09-24 15:46:23.121 | HD Request # 150 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:24.000000
2024-09-24 15:46:23.121 | Added 2 Time and Sales records to Intraday data file for USDX after download.
2024-09-24 15:46:23.121 | HD Request # 150 | Completion time: 2s.
2024-09-24 15:46:23.121 | HD Request # 150 | Intraday data download complete for USDX. Unique request ID: 150
2024-09-24 15:46:23.121 | Removing historical data download ID 150.
2024-09-24 15:46:23.121 | Real-time Intraday chart data file updates started for USDX
2024-09-24 15:46:23.121 | Intraday chart data file opened for USDX
2024-09-24 15:46:23.121 | HD Request # 150 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:23.121 | Triggering next historical data download in queue.
2024-09-24 15:46:23.121 | HD Request # 151 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 15:46:23.121 | HD Request # 151 | Download start date-time: 2024-09-24 15:44:51.000000. File last date-time: 2024-09-24 15:44:51.977011
2024-09-24 15:46:23.121 | HD Request # 151 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:46:23.121 | Socket (5) | Creating socket.
2024-09-24 15:46:23.121 | Socket (5) | New receive buffer size: 0
2024-09-24 15:46:23.121 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:23.384 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:46:23.384 | Socket (6) | Closed.
2024-09-24 15:46:23.671 | HD Request # 151 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:23.671 | HD Request # 151 | Sending historical data logon request message.
2024-09-24 15:46:23.941 | HD Request # 151 | Requesting Intraday data. Start date-time: 2024-09-24 15:44:51. Record interval: 0. Symbol: MESZ24
2024-09-24 15:46:24.210 | HD Request # 151 | Decompressing data.
2024-09-24 15:46:24.480 | HD Request # 151 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 15:44:51.648000
2024-09-24 15:46:24.480 | Socket (5) | CloseSocket call.
2024-09-24 15:46:24.480 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:24.480 | Historical data download thread signaled to stop.
2024-09-24 15:46:24.480 | HD Request # 151 | Timestamp of first Intraday data file record written: 2024-09-24 15:44:52.151000.
2024-09-24 15:46:24.480 | HD Request # 151 | Received 528 Intraday data records from 2024-09-24 15:44:51.648000 to 2024-09-24 15:46:18.206000 (86.6 seconds. Delay: 6.3 seconds) and wrote 515 records for MESZ4.CME
2024-09-24 15:46:24.481 | HD Request # 151 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:46:18.206000
2024-09-24 15:46:24.481 | HD Request # 151 | Completion time: 1s.
2024-09-24 15:46:24.481 | HD Request # 151 | Intraday data download complete for MESZ4.CME. Unique request ID: 151
2024-09-24 15:46:24.481 | Removing historical data download ID 151.
2024-09-24 15:46:24.481 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 15:46:24.481 | Intraday chart data file opened for MESZ4.CME
2024-09-24 15:46:24.481 | HD Request # 151 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:24.481 | Triggering next historical data download in queue.
2024-09-24 15:46:24.481 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:24.481 | HD Request # 152 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 15:46:24.481 | HD Request # 152 | Download start date-time: 2024-09-24 15:35:01.000000. File last date-time: 2024-09-24 15:35:01.988000
2024-09-24 15:46:24.481 | HD Request # 152 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:46:24.481 | Socket (6) | Creating socket.
2024-09-24 15:46:24.481 | Socket (6) | New receive buffer size: 0
2024-09-24 15:46:24.481 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:46:24.749 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:46:24.750 | Socket (5) | Closed.
2024-09-24 15:46:25.050 | HD Request # 152 | Setting DTC encoding to Binary VLS
2024-09-24 15:46:25.050 | HD Request # 152 | Sending historical data logon request message.
2024-09-24 15:46:25.327 | HD Request # 152 | Requesting Intraday data. Start date-time: 2024-09-24 15:35:01. Record interval: 0. Symbol: MJYZ24
2024-09-24 15:46:25.605 | HD Request # 152 | Decompressing data.
2024-09-24 15:46:25.883 | HD Request # 152 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 15:35:01.916000
2024-09-24 15:46:25.883 | Socket (6) | CloseSocket call.
2024-09-24 15:46:25.883 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:46:25.883 | Historical data download thread signaled to stop.
2024-09-24 15:46:25.883 | HD Request # 152 | Received 2 Intraday data records from 2024-09-24 15:35:01.916000 to 2024-09-24 15:35:01.988000 (0.1 seconds. Delay: 11.4 minutes) and wrote 0 records for MJYZ4.CME
2024-09-24 15:46:25.883 | HD Request # 152 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:35:01.988000
2024-09-24 15:46:25.883 | HD Request # 152 | Completion time: 1s.
2024-09-24 15:46:25.883 | HD Request # 152 | Intraday data download complete for MJYZ4.CME. Unique request ID: 152
2024-09-24 15:46:25.883 | Removing historical data download ID 152.
2024-09-24 15:46:25.883 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 15:46:25.883 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 15:46:25.883 | HD Request # 152 | Enabling Intraday chart updating for symbol.
2024-09-24 15:46:25.883 | No download requests in the queue to start downloads for.
2024-09-24 15:46:25.883 | Historical data for MJYZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:46:26.160 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:46:26.160 | Socket (6) | Closed.
2024-09-24 15:46:27.711 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 3296
2024-09-24 15:46:41.757 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:46:41.757 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:46:41.757 | Denali Data Feed | Failed connections: 3
2024-09-24 15:46:41.757 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:46:41.757 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:46:41.757 | DTC Client socket (2) | Closed.
2024-09-24 15:46:41.757 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:46:44.744 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:46:44.744 | DTC Client socket (2) | Creating socket.
2024-09-24 15:46:44.744 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:46:44.744 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:47:05.773 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:47:05.773 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:47:05.773 | Denali Data Feed | Failed connections: 4
2024-09-24 15:47:05.773 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:47:05.773 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:47:05.773 | DTC Client socket (2) | Closed.
2024-09-24 15:47:05.773 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:47:07.432 | File >> Reconnect selected.
2024-09-24 15:47:07.714 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 15:47:07.715 | DTC Client socket (1) | CloseSocket call.
2024-09-24 15:47:07.715 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:07.715 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:47:07.715 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:47:07.715 | SC Data with Depth | Waiting for socket receive thread to end
2024-09-24 15:47:07.715 | DTC Client socket (4) | CloseSocket call.
2024-09-24 15:47:07.715 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:07.715 | SC Data with Depth | Disconnected from the server.
2024-09-24 15:47:07.715 | Rithmic Direct - DTC | Disconnected.
2024-09-24 15:47:07.715 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 15:47:07.959 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 15:47:07.959 | DTC Client socket (1) | Closed.
2024-09-24 15:47:07.984 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:47:07.984 | DTC Client socket (4) | Closed.
2024-09-24 15:47:11.714 |
2024-09-24 15:47:11.714 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 15:47:11.714 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 15:47:11.714 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 15:47:11.714 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 15:47:11.714 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 15:47:11.714 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 15:47:11.956 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 15:47:11.956 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 15:47:11.956 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 15:47:11.956 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | Received logon response.
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | Server Name: .
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 15:47:12.689 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 15:47:12.689 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 15:47:12.689 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 15:47:12.689 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 15:47:12.689 | Using symbol data fast lookup vector
2024-09-24 15:47:12.689 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 15:47:12.689 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:47:12.689 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 15:47:12.689 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 15:47:12.689 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 15:47:12.689 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 15:47:12.689 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 15:47:12.689 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 15:47:12.690 | DTC Client socket (2) | Creating socket.
2024-09-24 15:47:12.690 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:47:12.690 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:47:13.013 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 15:47:13.013 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 3 Service code: cme
2024-09-24 15:47:13.013 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 3
2024-09-24 15:47:13.013 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 15:47:13.013 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 15:47:13.013 | Triggering next historical data download in queue.
2024-09-24 15:47:13.014 | Delaying start of download for NQZ4.CME.
2024-09-24 15:47:13.243 | Mapping CLX4.NYMEX to CLX24. Service code: nymex
2024-09-24 15:47:13.243 | Denali Data Feed | Starting real-time market data updates for: CLX4.NYMEX (CLX24). ID: 4 Service code: nymex
2024-09-24 15:47:13.243 | Denali Data Feed | Requesting security definition data for: CLX4.NYMEX (CLX24). ID: 4
2024-09-24 15:47:13.244 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 15:47:13.244 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 5 Service code: cme
2024-09-24 15:47:13.244 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 5
2024-09-24 15:47:13.244 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 15:47:13.244 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 15:47:13.244 | Triggering next historical data download in queue.
2024-09-24 15:47:13.245 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 15:47:13.245 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 6 Service code: cme
2024-09-24 15:47:13.245 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 6
2024-09-24 15:47:13.245 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 15:47:13.245 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 15:47:13.246 | Triggering next historical data download in queue.
2024-09-24 15:47:13.267 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 15:47:13.267 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 7 Service code: cme
2024-09-24 15:47:13.267 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 7
2024-09-24 15:47:13.267 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 15:47:13.267 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 15:47:13.267 | Triggering next historical data download in queue.
2024-09-24 15:47:13.296 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2024-09-24 15:47:13.296 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 8 Service code: comex
2024-09-24 15:47:13.296 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 8
2024-09-24 15:47:13.296 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 15:47:13.296 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 15:47:13.296 | Triggering next historical data download in queue.
2024-09-24 15:47:13.319 | Mapping 6AZ4.CME to 6AZ24. Service code: cme
2024-09-24 15:47:13.319 | Denali Data Feed | Starting real-time market data updates for: 6AZ4.CME (6AZ24). ID: 9 Service code: cme
2024-09-24 15:47:13.319 | Denali Data Feed | Requesting security definition data for: 6AZ4.CME (6AZ24). ID: 9
2024-09-24 15:47:13.319 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 15:47:13.319 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 15:47:13.319 | Triggering next historical data download in queue.
2024-09-24 15:47:13.349 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 15:47:13.349 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 15:47:13.349 | Triggering next historical data download in queue.
2024-09-24 15:47:13.350 | Mapping 6JZ4.CME to 6JZ24. Service code: cme
2024-09-24 15:47:13.350 | Denali Data Feed | Starting real-time market data updates for: 6JZ4.CME (6JZ24). ID: 10 Service code: cme
2024-09-24 15:47:13.350 | Denali Data Feed | Requesting security definition data for: 6JZ4.CME (6JZ24). ID: 10
2024-09-24 15:47:13.350 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 15:47:13.350 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 15:47:13.350 | Triggering next historical data download in queue.
2024-09-24 15:47:13.577 | Mapping MJYZ4.CME to MJYZ24. Service code: cme
2024-09-24 15:47:13.577 | Denali Data Feed | Starting real-time market data updates for: MJYZ4.CME (MJYZ24). ID: 11 Service code: cme
2024-09-24 15:47:13.577 | Denali Data Feed | Requesting security definition data for: MJYZ4.CME (MJYZ24). ID: 11
2024-09-24 15:47:13.577 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 15:47:13.577 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 15:47:13.577 | Triggering next historical data download in queue.
2024-09-24 15:47:13.757 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 15:47:13.757 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 15:47:13.757 | Triggering next historical data download in queue.
2024-09-24 15:47:13.758 | Mapping M6AZ4.CME to M6AZ24. Service code: cme
2024-09-24 15:47:13.758 | Denali Data Feed | Starting real-time market data updates for: M6AZ4.CME (M6AZ24). ID: 12 Service code: cme
2024-09-24 15:47:13.758 | Denali Data Feed | Requesting security definition data for: M6AZ4.CME (M6AZ24). ID: 12
2024-09-24 15:47:13.758 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 15:47:13.758 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 15:47:13.758 | Triggering next historical data download in queue.
2024-09-24 15:47:13.758 | Mapping MCLU4.NYMEX to MCLU24. Service code: nymex
2024-09-24 15:47:13.758 | Denali Data Feed | Starting real-time market data updates for: MCLU4.NYMEX (MCLU24). ID: 13 Service code: nymex
2024-09-24 15:47:13.758 | Denali Data Feed | Requesting security definition data for: MCLU4.NYMEX (MCLU24). ID: 13
2024-09-24 15:47:13.758 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 15:47:13.758 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 15:47:13.847 | Mapping ESU4.CME to ESU24. Service code: cme
2024-09-24 15:47:13.847 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 14 Service code: cme
2024-09-24 15:47:13.847 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 14
2024-09-24 15:47:13.847 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 15:47:13.847 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 15:47:13.847 | Triggering next historical data download in queue.
2024-09-24 15:47:13.847 | Mapping MGCZ4.COMEX to MGCZ24. Service code: comex
2024-09-24 15:47:13.847 | Denali Data Feed | Starting real-time market data updates for: MGCZ4.COMEX (MGCZ24). ID: 15 Service code: comex
2024-09-24 15:47:13.847 | Denali Data Feed | Requesting security definition data for: MGCZ4.COMEX (MGCZ24). ID: 15
2024-09-24 15:47:13.847 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 15:47:13.847 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 15:47:13.888 | SC Data with Depth | Starting real-time market data updates for: USDX. ID: 16 Service code: fxstatscalc
2024-09-24 15:47:13.888 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2024-09-24 15:47:13.888 | SC Data with Depth | Requesting security definition data for: USDX. ID: 16
2024-09-24 15:47:13.888 | Added historical Intraday data request for USDX to the queue.
2024-09-24 15:47:13.888 | Intraday data recording state for symbol USDX is set to download 'Pending'.
2024-09-24 15:47:13.888 | Triggering next historical data download in queue.
2024-09-24 15:47:14.017 | DTC Client socket (4) | Creating socket.
2024-09-24 15:47:14.017 | DTC Client socket (4) | New receive buffer size: 0
2024-09-24 15:47:14.017 | DTC Client socket (4) | Connecting to IP: 69.39.70.241.
2024-09-24 15:47:14.296 | SC Data with Depth | Network connection to server complete.
2024-09-24 15:47:14.296 | SC Data with Depth | Starting socket receive thread.
2024-09-24 15:47:14.296 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 15:47:14.627 | SC Data with Depth | Setting DTC encoding to Binary VLS
2024-09-24 15:47:14.627 | SC Data with Depth | Sending logon request message.
2024-09-24 15:47:15.894 | SC Data with Depth | Received logon response.
2024-09-24 15:47:15.894 | SC Data with Depth | Server Name: SC Realtime Server.
2024-09-24 15:47:15.894 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:47:15.894 | SC Data with Depth | Successfully connected.
2024-09-24 15:47:15.894 | SC Data with Depth | Trading is not supported.
2024-09-24 15:47:15.894 | SC Data with Depth | MarketDepthIsSupported: 1
2024-09-24 15:47:15.895 | SC Data with Depth | Restarting real-time data updates for symbol: USDX
2024-09-24 15:47:16.672 | SC Data with Depth | Received security definition for symbol USDX
2024-09-24 15:47:17.682 | Requesting market depth updates for: 6AZ4.CME if supported. NumLevels=50
2024-09-24 15:47:17.682 | Requesting market depth updates for: 6JZ4.CME if supported. NumLevels=50
2024-09-24 15:47:17.682 | Requesting market depth updates for: CLX4.NYMEX if supported. NumLevels=50
2024-09-24 15:47:17.682 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2024-09-24 15:47:17.682 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 15:47:17.682 | Requesting market depth updates for: GCZ4.COMEX if supported. NumLevels=50
2024-09-24 15:47:17.682 | Requesting market depth updates for: MESU4.CME if supported. NumLevels=50
2024-09-24 15:47:17.682 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 15:47:17.682 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 15:47:31.714 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Creating socket. Using TLS 1.2.
2024-09-24 15:47:31.714 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | New receive buffer size: 0
2024-09-24 15:47:31.714 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Connecting to IP: 216.66.0.130.
2024-09-24 15:47:33.498 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | CloseSocket call.
2024-09-24 15:47:33.498 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:33.717 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:47:33.717 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:47:33.717 | Denali Data Feed | Failed connections: 5
2024-09-24 15:47:33.717 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:47:33.717 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:47:33.717 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:47:33.717 | DTC Client socket (2) | Closed.
2024-09-24 15:47:33.753 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Socket gracefully closed by remote side.
2024-09-24 15:47:33.753 | HTTPS connection ID:11 to downloads.rithmic.com:443 for request ID:11 (5) | Closed.
2024-09-24 15:47:36.714 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:47:36.714 | DTC Client socket (2) | Creating socket.
2024-09-24 15:47:36.714 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:47:36.714 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:47:44.688 | HD Request # 153 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 15:47:44.688 | HD Request # 153 | Download start date-time: 2024-09-24 15:46:06.000000. File last date-time: 2024-09-24 15:46:06.359000
2024-09-24 15:47:44.688 | HD Request # 153 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:47:44.688 | Socket (5) | Creating socket.
2024-09-24 15:47:44.688 | Socket (5) | New receive buffer size: 0
2024-09-24 15:47:44.688 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:45.259 | HD Request # 153 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:45.259 | HD Request # 153 | Sending historical data logon request message.
2024-09-24 15:47:46.025 | HD Request # 153 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:06. Record interval: 0. Symbol: NQZ24
2024-09-24 15:47:46.310 | HD Request # 153 | Decompressing data.
2024-09-24 15:47:46.588 | HD Request # 153 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 15:46:06.171000
2024-09-24 15:47:46.589 | Socket (5) | CloseSocket call.
2024-09-24 15:47:46.589 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:46.596 | Historical data download thread signaled to stop.
2024-09-24 15:47:46.596 | HD Request # 153 | Timestamp of first Intraday data file record written: 2024-09-24 15:46:06.947000.
2024-09-24 15:47:46.596 | HD Request # 153 | Received 545 Intraday data records from 2024-09-24 15:46:06.171000 to 2024-09-24 15:47:46.635000 (100.5 seconds. Delay: -0.0 seconds) and wrote 543 records for NQZ4.CME
2024-09-24 15:47:46.596 | HD Request # 153 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:47:46.635000
2024-09-24 15:47:46.597 | HD Request # 153 | Completion time: 2s.
2024-09-24 15:47:46.597 | HD Request # 153 | Intraday data download complete for NQZ4.CME. Unique request ID: 153
2024-09-24 15:47:46.597 | Removing historical data download ID 153.
2024-09-24 15:47:46.597 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 15:47:46.597 | Intraday chart data file opened for NQZ4.CME
2024-09-24 15:47:46.597 | HD Request # 153 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:46.597 | Triggering next historical data download in queue.
2024-09-24 15:47:46.597 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:46.597 | HD Request # 154 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 15:47:46.597 | HD Request # 154 | Download start date-time: 2024-09-24 15:46:22.000000. File last date-time: 2024-09-24 15:46:22.688000
2024-09-24 15:47:46.597 | HD Request # 154 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:47:46.597 | Socket (6) | Creating socket.
2024-09-24 15:47:46.597 | Socket (6) | New receive buffer size: 0
2024-09-24 15:47:46.597 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:46.867 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:47:46.867 | Socket (5) | Closed.
2024-09-24 15:47:47.161 | HD Request # 154 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:47.161 | HD Request # 154 | Sending historical data logon request message.
2024-09-24 15:47:47.931 | HD Request # 154 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:22. Record interval: 0. Symbol: MNQZ24
2024-09-24 15:47:48.211 | HD Request # 154 | Decompressing data.
2024-09-24 15:47:48.488 | HD Request # 154 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 15:46:22.059000
2024-09-24 15:47:48.488 | Socket (6) | CloseSocket call.
2024-09-24 15:47:48.488 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:48.488 | Historical data download thread signaled to stop.
2024-09-24 15:47:48.488 | HD Request # 154 | Timestamp of first Intraday data file record written: 2024-09-24 15:46:22.856000.
2024-09-24 15:47:48.488 | HD Request # 154 | Received 1012 Intraday data records from 2024-09-24 15:46:22.059000 to 2024-09-24 15:47:47.178002 (85.1 seconds. Delay: 1.3 seconds) and wrote 1007 records for MNQZ4.CME
2024-09-24 15:47:48.489 | HD Request # 154 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:47:47.178002
2024-09-24 15:47:48.489 | HD Request # 154 | Completion time: 2s.
2024-09-24 15:47:48.489 | HD Request # 154 | Intraday data download complete for MNQZ4.CME. Unique request ID: 154
2024-09-24 15:47:48.489 | Removing historical data download ID 154.
2024-09-24 15:47:48.489 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 15:47:48.489 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 15:47:48.489 | HD Request # 154 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:48.489 | Triggering next historical data download in queue.
2024-09-24 15:47:48.489 | Historical data for MNQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:48.489 | HD Request # 155 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 15:47:48.489 | HD Request # 155 | Download start date-time: 2024-09-24 15:46:09.000000. File last date-time: 2024-09-24 15:46:09.623009
2024-09-24 15:47:48.489 | HD Request # 155 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:47:48.489 | Socket (5) | Creating socket.
2024-09-24 15:47:48.489 | Socket (5) | New receive buffer size: 0
2024-09-24 15:47:48.489 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:48.765 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:47:48.765 | Socket (6) | Closed.
2024-09-24 15:47:49.047 | HD Request # 155 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:49.047 | HD Request # 155 | Sending historical data logon request message.
2024-09-24 15:47:49.319 | HD Request # 155 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:09. Record interval: 0. Symbol: ESZ24
2024-09-24 15:47:49.592 | HD Request # 155 | Decompressing data.
2024-09-24 15:47:49.867 | HD Request # 155 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 15:46:09.328000
2024-09-24 15:47:49.867 | Socket (5) | CloseSocket call.
2024-09-24 15:47:49.867 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:49.867 | Historical data download thread signaled to stop.
2024-09-24 15:47:49.867 | HD Request # 155 | Timestamp of first Intraday data file record written: 2024-09-24 15:46:11.393000.
2024-09-24 15:47:49.867 | HD Request # 155 | Received 1206 Intraday data records from 2024-09-24 15:46:09.328000 to 2024-09-24 15:47:51.478006 (102.2 seconds. Delay: -1.6 seconds) and wrote 1175 records for ESZ4.CME
2024-09-24 15:47:49.868 | HD Request # 155 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:47:51.478006
2024-09-24 15:47:49.868 | HD Request # 155 | Completion time: 1s.
2024-09-24 15:47:49.868 | HD Request # 155 | Intraday data download complete for ESZ4.CME. Unique request ID: 155
2024-09-24 15:47:49.868 | Removing historical data download ID 155.
2024-09-24 15:47:49.868 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 15:47:49.868 | Intraday chart data file opened for ESZ4.CME
2024-09-24 15:47:49.868 | HD Request # 155 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:49.868 | Triggering next historical data download in queue.
2024-09-24 15:47:49.868 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:49.868 | HD Request # 156 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 15:47:49.868 | HD Request # 156 | Download start date-time: 2024-09-24 15:46:18.000000. File last date-time: 2024-09-24 15:46:18.206000
2024-09-24 15:47:49.868 | HD Request # 156 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:47:49.868 | Socket (6) | Creating socket.
2024-09-24 15:47:49.868 | Socket (6) | New receive buffer size: 0
2024-09-24 15:47:49.868 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:50.139 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:47:50.139 | Socket (5) | Closed.
2024-09-24 15:47:50.424 | HD Request # 156 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:50.424 | HD Request # 156 | Sending historical data logon request message.
2024-09-24 15:47:50.700 | HD Request # 156 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:18. Record interval: 0. Symbol: MESZ24
2024-09-24 15:47:50.972 | HD Request # 156 | Decompressing data.
2024-09-24 15:47:51.244 | HD Request # 156 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 15:46:18.206000
2024-09-24 15:47:51.244 | Socket (6) | CloseSocket call.
2024-09-24 15:47:51.244 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:51.244 | Historical data download thread signaled to stop.
2024-09-24 15:47:51.244 | HD Request # 156 | Timestamp of first Intraday data file record written: 2024-09-24 15:46:23.827000.
2024-09-24 15:47:51.244 | HD Request # 156 | Received 311 Intraday data records from 2024-09-24 15:46:18.206000 to 2024-09-24 15:47:51.479002 (93.3 seconds. Delay: -0.2 seconds) and wrote 310 records for MESZ4.CME
2024-09-24 15:47:51.245 | HD Request # 156 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:47:51.479002
2024-09-24 15:47:51.245 | HD Request # 156 | Completion time: 2s.
2024-09-24 15:47:51.245 | HD Request # 156 | Intraday data download complete for MESZ4.CME. Unique request ID: 156
2024-09-24 15:47:51.245 | Removing historical data download ID 156.
2024-09-24 15:47:51.245 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 15:47:51.245 | Intraday chart data file opened for MESZ4.CME
2024-09-24 15:47:51.245 | HD Request # 156 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:51.245 | Triggering next historical data download in queue.
2024-09-24 15:47:51.245 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:51.245 | HD Request # 157 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 15:47:51.245 | HD Request # 157 | Download start date-time: 2024-09-24 15:46:17.000000. File last date-time: 2024-09-24 15:46:17.167002
2024-09-24 15:47:51.245 | HD Request # 157 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:47:51.245 | Socket (5) | Creating socket.
2024-09-24 15:47:51.245 | Socket (5) | New receive buffer size: 0
2024-09-24 15:47:51.245 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:51.515 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:47:51.515 | Socket (6) | Closed.
2024-09-24 15:47:51.804 | HD Request # 157 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:51.804 | HD Request # 157 | Sending historical data logon request message.
2024-09-24 15:47:52.076 | HD Request # 157 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:17. Record interval: 0. Symbol: GCZ24
2024-09-24 15:47:52.350 | HD Request # 157 | Decompressing data.
2024-09-24 15:47:52.623 | HD Request # 157 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 15:46:17.167000
2024-09-24 15:47:52.623 | Socket (5) | CloseSocket call.
2024-09-24 15:47:52.623 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:52.629 | Historical data download thread signaled to stop.
2024-09-24 15:47:52.629 | HD Request # 157 | Timestamp of first Intraday data file record written: 2024-09-24 15:46:19.790000.
2024-09-24 15:47:52.629 | HD Request # 157 | Received 282 Intraday data records from 2024-09-24 15:46:17.167000 to 2024-09-24 15:47:51.561000 (94.4 seconds. Delay: 1.1 seconds) and wrote 279 records for GCZ4.COMEX
2024-09-24 15:47:52.629 | HD Request # 157 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:47:51.561000
2024-09-24 15:47:52.629 | HD Request # 157 | Completion time: 1s.
2024-09-24 15:47:52.629 | HD Request # 157 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 157
2024-09-24 15:47:52.629 | Removing historical data download ID 157.
2024-09-24 15:47:52.629 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 15:47:52.629 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 15:47:52.629 | HD Request # 157 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:52.629 | Triggering next historical data download in queue.
2024-09-24 15:47:52.629 | Historical data for GCZ4.COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:52.629 | HD Request # 158 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 15:47:52.629 | HD Request # 158 | Download start date-time: 2024-09-24 15:46:09.000000. File last date-time: 2024-09-24 15:46:09.626000
2024-09-24 15:47:52.629 | HD Request # 158 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:47:52.629 | Socket (6) | Creating socket.
2024-09-24 15:47:52.630 | Socket (6) | New receive buffer size: 0
2024-09-24 15:47:52.630 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:52.896 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:47:52.896 | Socket (5) | Closed.
2024-09-24 15:47:53.196 | HD Request # 158 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:53.196 | HD Request # 158 | Sending historical data logon request message.
2024-09-24 15:47:53.472 | HD Request # 158 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:09. Record interval: 0. Symbol: 6AZ24
2024-09-24 15:47:53.749 | HD Request # 158 | Decompressing data.
2024-09-24 15:47:54.026 | HD Request # 158 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 15:46:09.625000
2024-09-24 15:47:54.026 | Socket (6) | CloseSocket call.
2024-09-24 15:47:54.026 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:54.026 | Historical data download thread signaled to stop.
2024-09-24 15:47:54.026 | HD Request # 158 | Timestamp of first Intraday data file record written: 2024-09-24 15:46:20.240000.
2024-09-24 15:47:54.026 | HD Request # 158 | Received 56 Intraday data records from 2024-09-24 15:46:09.625000 to 2024-09-24 15:47:52.008001 (102.4 seconds. Delay: 2.0 seconds) and wrote 47 records for 6AZ4.CME
2024-09-24 15:47:54.026 | HD Request # 158 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:47:52.008001
2024-09-24 15:47:54.026 | HD Request # 158 | Completion time: 2s.
2024-09-24 15:47:54.026 | HD Request # 158 | Intraday data download complete for 6AZ4.CME. Unique request ID: 158
2024-09-24 15:47:54.026 | Removing historical data download ID 158.
2024-09-24 15:47:54.026 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 15:47:54.026 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 15:47:54.026 | HD Request # 158 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:54.026 | Triggering next historical data download in queue.
2024-09-24 15:47:54.026 | Historical data for 6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:54.026 | HD Request # 159 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 15:47:54.027 | HD Request # 159 | Download start date-time: 2024-09-24 15:46:02.000000. File last date-time: 2024-09-24 15:46:02.861001
2024-09-24 15:47:54.027 | HD Request # 159 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:47:54.027 | Socket (5) | Creating socket.
2024-09-24 15:47:54.027 | Socket (5) | New receive buffer size: 0
2024-09-24 15:47:54.027 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:54.302 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:47:54.302 | Socket (6) | Closed.
2024-09-24 15:47:54.586 | HD Request # 159 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:54.586 | HD Request # 159 | Sending historical data logon request message.
2024-09-24 15:47:54.858 | HD Request # 159 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:02. Record interval: 0. Symbol: CLX24
2024-09-24 15:47:55.132 | HD Request # 159 | Decompressing data.
2024-09-24 15:47:55.404 | HD Request # 159 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 15:46:02.852000
2024-09-24 15:47:55.404 | Socket (5) | CloseSocket call.
2024-09-24 15:47:55.404 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:55.404 | Historical data download thread signaled to stop.
2024-09-24 15:47:55.404 | HD Request # 159 | Timestamp of first Intraday data file record written: 2024-09-24 15:46:31.844000.
2024-09-24 15:47:55.405 | HD Request # 159 | Received 51 Intraday data records from 2024-09-24 15:46:02.852000 to 2024-09-24 15:47:54.657002 (111.8 seconds. Delay: 0.7 seconds) and wrote 48 records for CLX4.NYMEX
2024-09-24 15:47:55.405 | HD Request # 159 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:47:54.657002
2024-09-24 15:47:55.405 | HD Request # 159 | Completion time: 1s.
2024-09-24 15:47:55.405 | HD Request # 159 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 159
2024-09-24 15:47:55.405 | Removing historical data download ID 159.
2024-09-24 15:47:55.405 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 15:47:55.405 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 15:47:55.405 | HD Request # 159 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:55.405 | Triggering next historical data download in queue.
2024-09-24 15:47:55.405 | Historical data for CLX4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:55.405 | HD Request # 160 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 15:47:55.405 | HD Request # 160 | Download start date-time: 2024-09-24 15:46:13.000000. File last date-time: 2024-09-24 15:46:13.582000
2024-09-24 15:47:55.405 | HD Request # 160 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:47:55.405 | Socket (6) | Creating socket.
2024-09-24 15:47:55.405 | Socket (6) | New receive buffer size: 0
2024-09-24 15:47:55.405 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:55.677 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:47:55.677 | Socket (5) | Closed.
2024-09-24 15:47:55.963 | HD Request # 160 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:55.963 | HD Request # 160 | Sending historical data logon request message.
2024-09-24 15:47:56.235 | HD Request # 160 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:13. Record interval: 0. Symbol: 6JZ24
2024-09-24 15:47:56.508 | HD Request # 160 | Decompressing data.
2024-09-24 15:47:56.779 | HD Request # 160 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 15:46:13.557000
2024-09-24 15:47:56.779 | Socket (6) | CloseSocket call.
2024-09-24 15:47:56.779 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:56.780 | Historical data download thread signaled to stop.
2024-09-24 15:47:56.780 | HD Request # 160 | Timestamp of first Intraday data file record written: 2024-09-24 15:46:22.267000.
2024-09-24 15:47:56.780 | HD Request # 160 | Received 37 Intraday data records from 2024-09-24 15:46:13.557000 to 2024-09-24 15:47:49.258000 (95.7 seconds. Delay: 7.5 seconds) and wrote 28 records for 6JZ4.CME
2024-09-24 15:47:56.780 | HD Request # 160 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:47:49.258000
2024-09-24 15:47:56.780 | HD Request # 160 | Completion time: 1s.
2024-09-24 15:47:56.780 | HD Request # 160 | Intraday data download complete for 6JZ4.CME. Unique request ID: 160
2024-09-24 15:47:56.780 | Removing historical data download ID 160.
2024-09-24 15:47:56.780 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 15:47:56.780 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 15:47:56.780 | HD Request # 160 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:56.780 | Triggering next historical data download in queue.
2024-09-24 15:47:56.780 | Historical data for 6JZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:56.780 | HD Request # 161 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 15:47:56.780 | HD Request # 161 | Download start date-time: 2024-09-24 15:35:01.000000. File last date-time: 2024-09-24 15:35:01.988000
2024-09-24 15:47:56.780 | HD Request # 161 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:47:56.780 | Socket (5) | Creating socket.
2024-09-24 15:47:56.780 | Socket (5) | New receive buffer size: 0
2024-09-24 15:47:56.780 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:57.052 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:47:57.052 | Socket (6) | Closed.
2024-09-24 15:47:57.344 | HD Request # 161 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:57.344 | HD Request # 161 | Sending historical data logon request message.
2024-09-24 15:47:57.620 | HD Request # 161 | Requesting Intraday data. Start date-time: 2024-09-24 15:35:01. Record interval: 0. Symbol: MJYZ24
2024-09-24 15:47:57.751 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:47:57.751 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:47:57.751 | Denali Data Feed | Failed connections: 6
2024-09-24 15:47:57.751 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:47:57.751 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:47:57.751 | DTC Client socket (2) | Closed.
2024-09-24 15:47:57.751 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:47:57.897 | HD Request # 161 | Decompressing data.
2024-09-24 15:47:58.173 | HD Request # 161 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 15:35:01.916000
2024-09-24 15:47:58.173 | Socket (5) | CloseSocket call.
2024-09-24 15:47:58.173 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:58.181 | Historical data download thread signaled to stop.
2024-09-24 15:47:58.181 | HD Request # 161 | Received 2 Intraday data records from 2024-09-24 15:35:01.916000 to 2024-09-24 15:35:01.988000 (0.1 seconds. Delay: 12.9 minutes) and wrote 0 records for MJYZ4.CME
2024-09-24 15:47:58.181 | HD Request # 161 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:35:01.988000
2024-09-24 15:47:58.181 | HD Request # 161 | Completion time: 2s.
2024-09-24 15:47:58.181 | HD Request # 161 | Intraday data download complete for MJYZ4.CME. Unique request ID: 161
2024-09-24 15:47:58.181 | Removing historical data download ID 161.
2024-09-24 15:47:58.181 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 15:47:58.181 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 15:47:58.181 | HD Request # 161 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:58.181 | Triggering next historical data download in queue.
2024-09-24 15:47:58.181 | Historical data for MJYZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:58.181 | HD Request # 162 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 15:47:58.181 | HD Request # 162 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 15:47:58.181 | HD Request # 162 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:47:58.182 | Socket (2) | Creating socket.
2024-09-24 15:47:58.182 | Socket (2) | New receive buffer size: 0
2024-09-24 15:47:58.182 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:58.450 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:47:58.450 | Socket (5) | Closed.
2024-09-24 15:47:58.747 | HD Request # 162 | Setting DTC encoding to Binary VLS
2024-09-24 15:47:58.747 | HD Request # 162 | Sending historical data logon request message.
2024-09-24 15:47:59.021 | HD Request # 162 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 15:47:59.296 | HD Request # 162 | Decompressing data.
2024-09-24 15:47:59.570 | HD Request # 162 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 15:47:59.570 | Socket (2) | CloseSocket call.
2024-09-24 15:47:59.570 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 15:47:59.579 | Historical data download thread signaled to stop.
2024-09-24 15:47:59.579 | HD Request # 162 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 4.3 days) and wrote 0 records for MESU4.CME
2024-09-24 15:47:59.579 | HD Request # 162 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 15:47:59.579 | HD Request # 162 | Completion time: 1s.
2024-09-24 15:47:59.579 | HD Request # 162 | Intraday data download complete for MESU4.CME. Unique request ID: 162
2024-09-24 15:47:59.579 | Removing historical data download ID 162.
2024-09-24 15:47:59.579 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 15:47:59.579 | Intraday chart data file opened for MESU4.CME
2024-09-24 15:47:59.579 | HD Request # 162 | Enabling Intraday chart updating for symbol.
2024-09-24 15:47:59.579 | Triggering next historical data download in queue.
2024-09-24 15:47:59.579 | Historical data for MESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:47:59.579 | HD Request # 163 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 15:47:59.579 | HD Request # 163 | Download start date-time: 2024-09-24 15:46:05.000000. File last date-time: 2024-09-24 15:46:05.461000
2024-09-24 15:47:59.579 | HD Request # 163 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:47:59.579 | Socket (5) | Creating socket.
2024-09-24 15:47:59.580 | Socket (5) | New receive buffer size: 0
2024-09-24 15:47:59.580 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:47:59.846 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 15:47:59.846 | Socket (2) | Closed.
2024-09-24 15:48:00.155 | HD Request # 163 | Setting DTC encoding to Binary VLS
2024-09-24 15:48:00.155 | HD Request # 163 | Sending historical data logon request message.
2024-09-24 15:48:00.436 | HD Request # 163 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:05. Record interval: 0. Symbol: M6AZ24
2024-09-24 15:48:00.718 | HD Request # 163 | Decompressing data.
2024-09-24 15:48:00.750 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:48:00.750 | DTC Client socket (2) | Creating socket.
2024-09-24 15:48:00.750 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:48:00.750 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:48:00.999 | HD Request # 163 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 15:46:05.461000
2024-09-24 15:48:00.999 | Socket (5) | CloseSocket call.
2024-09-24 15:48:00.999 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:48:01.000 | Historical data download thread signaled to stop.
2024-09-24 15:48:01.000 | HD Request # 163 | Timestamp of first Intraday data file record written: 2024-09-24 15:47:05.320000.
2024-09-24 15:48:01.000 | HD Request # 163 | Received 5 Intraday data records from 2024-09-24 15:46:05.461000 to 2024-09-24 15:47:35.500000 (90.0 seconds. Delay: 25.5 seconds) and wrote 4 records for M6AZ4.CME
2024-09-24 15:48:01.000 | HD Request # 163 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:47:35.500000
2024-09-24 15:48:01.000 | HD Request # 163 | Completion time: 2s.
2024-09-24 15:48:01.000 | HD Request # 163 | Intraday data download complete for M6AZ4.CME. Unique request ID: 163
2024-09-24 15:48:01.000 | Removing historical data download ID 163.
2024-09-24 15:48:01.001 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 15:48:01.001 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 15:48:01.001 | HD Request # 163 | Enabling Intraday chart updating for symbol.
2024-09-24 15:48:01.001 | Triggering next historical data download in queue.
2024-09-24 15:48:01.001 | Historical data for M6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:48:01.001 | HD Request # 164 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 15:48:01.001 | HD Request # 164 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 15:48:01.001 | HD Request # 164 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:48:01.001 | Socket (6) | Creating socket.
2024-09-24 15:48:01.001 | Socket (6) | New receive buffer size: 0
2024-09-24 15:48:01.001 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:48:01.281 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:48:01.281 | Socket (5) | Closed.
2024-09-24 15:48:01.577 | HD Request # 164 | Setting DTC encoding to Binary VLS
2024-09-24 15:48:01.577 | HD Request # 164 | Sending historical data logon request message.
2024-09-24 15:48:01.858 | HD Request # 164 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 15:48:02.141 | HD Request # 164 | Decompressing data.
2024-09-24 15:48:02.422 | HD Request # 164 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 15:48:02.422 | Socket (6) | CloseSocket call.
2024-09-24 15:48:02.422 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:48:02.422 | Historical data download thread signaled to stop.
2024-09-24 15:48:02.422 | HD Request # 164 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 36.1 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 15:48:02.422 | HD Request # 164 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 15:48:02.422 | HD Request # 164 | Completion time: 1s.
2024-09-24 15:48:02.422 | HD Request # 164 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 164
2024-09-24 15:48:02.422 | Removing historical data download ID 164.
2024-09-24 15:48:02.422 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 15:48:02.422 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 15:48:02.422 | HD Request # 164 | Enabling Intraday chart updating for symbol.
2024-09-24 15:48:02.422 | Triggering next historical data download in queue.
2024-09-24 15:48:02.422 | Historical data for MCLU4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:48:02.422 | HD Request # 165 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 15:48:02.422 | HD Request # 165 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 15:48:02.422 | HD Request # 165 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:48:02.422 | Socket (5) | Creating socket.
2024-09-24 15:48:02.422 | Socket (5) | New receive buffer size: 0
2024-09-24 15:48:02.422 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:48:02.703 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:48:02.703 | Socket (6) | Closed.
2024-09-24 15:48:02.983 | HD Request # 165 | Setting DTC encoding to Binary VLS
2024-09-24 15:48:02.983 | HD Request # 165 | Sending historical data logon request message.
2024-09-24 15:48:03.256 | HD Request # 165 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 15:48:03.530 | HD Request # 165 | Decompressing data.
2024-09-24 15:48:03.804 | HD Request # 165 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 15:48:03.804 | Socket (5) | CloseSocket call.
2024-09-24 15:48:03.804 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:48:03.804 | Historical data download thread signaled to stop.
2024-09-24 15:48:03.804 | HD Request # 165 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 4.3 days) and wrote 0 records for ESU4.CME
2024-09-24 15:48:03.804 | HD Request # 165 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 15:48:03.804 | HD Request # 165 | Completion time: 1s.
2024-09-24 15:48:03.804 | HD Request # 165 | Intraday data download complete for ESU4.CME. Unique request ID: 165
2024-09-24 15:48:03.804 | Removing historical data download ID 165.
2024-09-24 15:48:03.804 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 15:48:03.804 | Intraday chart data file opened for ESU4.CME
2024-09-24 15:48:03.804 | HD Request # 165 | Enabling Intraday chart updating for symbol.
2024-09-24 15:48:03.804 | Triggering next historical data download in queue.
2024-09-24 15:48:03.804 | Historical data for ESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:48:03.804 | HD Request # 166 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 15:48:03.804 | HD Request # 166 | Download start date-time: 2024-09-24 15:46:16.000000. File last date-time: 2024-09-24 15:46:16.957000
2024-09-24 15:48:03.804 | HD Request # 166 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:48:03.804 | Socket (6) | Creating socket.
2024-09-24 15:48:03.804 | Socket (6) | New receive buffer size: 0
2024-09-24 15:48:03.804 | Socket (6) | Connecting to IP: 67.214.125.3.
2024-09-24 15:48:04.082 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:48:04.082 | Socket (5) | Closed.
2024-09-24 15:48:04.365 | HD Request # 166 | Setting DTC encoding to Binary VLS
2024-09-24 15:48:04.365 | HD Request # 166 | Sending historical data logon request message.
2024-09-24 15:48:04.638 | HD Request # 166 | Requesting Intraday data. Start date-time: 2024-09-24 15:46:16. Record interval: 0. Symbol: MGCZ24
2024-09-24 15:48:04.911 | HD Request # 166 | Decompressing data.
2024-09-24 15:48:05.186 | HD Request # 166 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 15:46:16.352000
2024-09-24 15:48:05.186 | Socket (6) | CloseSocket call.
2024-09-24 15:48:05.186 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-09-24 15:48:05.192 | Historical data download thread signaled to stop.
2024-09-24 15:48:05.192 | HD Request # 166 | Timestamp of first Intraday data file record written: 2024-09-24 15:46:19.045000.
2024-09-24 15:48:05.192 | HD Request # 166 | Received 166 Intraday data records from 2024-09-24 15:46:16.352000 to 2024-09-24 15:48:03.380000 (107.0 seconds. Delay: 1.8 seconds) and wrote 164 records for MGCZ4.COMEX
2024-09-24 15:48:05.193 | HD Request # 166 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:48:03.380000
2024-09-24 15:48:05.193 | HD Request # 166 | Completion time: 2s.
2024-09-24 15:48:05.193 | HD Request # 166 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 166
2024-09-24 15:48:05.193 | Removing historical data download ID 166.
2024-09-24 15:48:05.193 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 15:48:05.193 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 15:48:05.193 | HD Request # 166 | Enabling Intraday chart updating for symbol.
2024-09-24 15:48:05.193 | Triggering next historical data download in queue.
2024-09-24 15:48:05.193 | Historical data for MGCZ4.COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:48:05.193 | HD Request # 167 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc
2024-09-24 15:48:05.193 | HD Request # 167 | Download start date-time: 2024-09-24 15:47:09.000000. File last date-time: 2024-09-24 15:47:09.000001
2024-09-24 15:48:05.193 | HD Request # 167 | Using server: ds12.sierracharts.com port 10149
2024-09-24 15:48:05.193 | Socket (5) | Creating socket.
2024-09-24 15:48:05.193 | Socket (5) | New receive buffer size: 0
2024-09-24 15:48:05.193 | Socket (5) | Connecting to IP: 69.39.70.241.
2024-09-24 15:48:05.458 | Socket (6) | Socket gracefully closed by remote side.
2024-09-24 15:48:05.458 | Socket (6) | Closed.
2024-09-24 15:48:05.744 | HD Request # 167 | Setting DTC encoding to Binary VLS
2024-09-24 15:48:05.744 | HD Request # 167 | Sending historical data logon request message.
2024-09-24 15:48:06.498 | HD Request # 167 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:09. Record interval: 0. Symbol: USDX
2024-09-24 15:48:06.768 | HD Request # 167 | Decompressing data.
2024-09-24 15:48:07.038 | HD Request # 167 | Receiving Intraday data for USDX starting at 2024-09-24 15:47:09.000000
2024-09-24 15:48:07.038 | Socket (5) | CloseSocket call.
2024-09-24 15:48:07.038 | Historical data download thread signaled to stop.
2024-09-24 15:48:07.038 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:48:07.038 | HD Request # 167 | Timestamp of first Intraday data file record written: 2024-09-24 15:47:10.000000.
2024-09-24 15:48:07.038 | HD Request # 167 | Received 58 Intraday data records from 2024-09-24 15:47:09.000000 to 2024-09-24 15:48:06.000000 (57.0 seconds. Delay: 1.0 seconds) and wrote 57 records for USDX
2024-09-24 15:48:07.039 | HD Request # 167 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:48:06.000000
2024-09-24 15:48:07.039 | Added 3 Time and Sales records to Intraday data file for USDX after download.
2024-09-24 15:48:07.039 | HD Request # 167 | Completion time: 2s.
2024-09-24 15:48:07.039 | HD Request # 167 | Intraday data download complete for USDX. Unique request ID: 167
2024-09-24 15:48:07.039 | Removing historical data download ID 167.
2024-09-24 15:48:07.039 | Real-time Intraday chart data file updates started for USDX
2024-09-24 15:48:07.039 | Intraday chart data file opened for USDX
2024-09-24 15:48:07.039 | HD Request # 167 | Enabling Intraday chart updating for symbol.
2024-09-24 15:48:07.039 | No download requests in the queue to start downloads for.
2024-09-24 15:48:07.309 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:48:07.309 | Socket (5) | Closed.
2024-09-24 15:48:08.419 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\USDX.scid. Thread ID: 3296
2024-09-24 15:48:21.803 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:48:21.803 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:48:21.803 | Denali Data Feed | Failed connections: 7
2024-09-24 15:48:21.803 | DTC Client socket (2) | Closed.
2024-09-24 15:48:21.803 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:48:21.803 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:48:21.803 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:48:24.791 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:48:24.791 | DTC Client socket (2) | Creating socket.
2024-09-24 15:48:24.791 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:48:24.791 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:48:37.525 | File >> Reconnect selected.
2024-09-24 15:48:37.800 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 15:48:37.801 | DTC Client socket (1) | CloseSocket call.
2024-09-24 15:48:37.801 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-09-24 15:48:37.801 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-09-24 15:48:37.801 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 15:48:37.801 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:48:37.801 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:48:37.801 | SC Data with Depth | Waiting for socket receive thread to end
2024-09-24 15:48:37.801 | DTC Client socket (2) | Closed.
2024-09-24 15:48:37.801 | DTC Client socket (4) | CloseSocket call.
2024-09-24 15:48:37.801 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:48:37.801 | SC Data with Depth | Disconnected from the server.
2024-09-24 15:48:37.801 | Rithmic Direct - DTC | Disconnected.
2024-09-24 15:48:37.801 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 15:48:38.043 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 15:48:38.043 | DTC Client socket (1) | Closed.
2024-09-24 15:48:38.377 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:48:38.377 | DTC Client socket (4) | Closed.
2024-09-24 15:48:41.790 |
2024-09-24 15:48:41.790 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 15:48:41.790 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 15:48:41.790 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 15:48:41.790 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 15:48:41.790 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 15:48:41.790 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 15:48:42.039 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 15:48:42.039 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 15:48:42.039 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 15:48:42.039 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | Received logon response.
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | Server Name: .
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 15:48:42.789 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 15:48:42.790 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 15:48:42.790 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 15:48:42.790 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 15:48:42.790 | Using symbol data fast lookup vector
2024-09-24 15:48:42.790 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 15:48:42.790 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:48:42.790 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 15:48:42.790 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 15:48:42.790 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 15:48:42.790 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 15:48:42.790 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 15:48:42.790 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 15:48:42.790 | DTC Client socket (2) | Creating socket.
2024-09-24 15:48:42.790 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:48:42.790 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:48:43.066 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 15:48:43.066 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 3 Service code: cme
2024-09-24 15:48:43.066 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 3
2024-09-24 15:48:43.066 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 15:48:43.066 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 15:48:43.066 | Triggering next historical data download in queue.
2024-09-24 15:48:43.066 | Delaying start of download for MESZ4.CME.
2024-09-24 15:48:43.069 | Mapping 6JZ4.CME to 6JZ24. Service code: cme
2024-09-24 15:48:43.069 | Denali Data Feed | Starting real-time market data updates for: 6JZ4.CME (6JZ24). ID: 4 Service code: cme
2024-09-24 15:48:43.069 | Denali Data Feed | Requesting security definition data for: 6JZ4.CME (6JZ24). ID: 4
2024-09-24 15:48:43.069 | Added historical Intraday data request for 6JZ4.CME to the queue.
2024-09-24 15:48:43.069 | Intraday data recording state for symbol 6JZ4.CME is set to download 'Pending'.
2024-09-24 15:48:43.069 | Triggering next historical data download in queue.
2024-09-24 15:48:43.070 | Mapping GCZ4.COMEX to GCZ24. Service code: comex
2024-09-24 15:48:43.070 | Denali Data Feed | Starting real-time market data updates for: GCZ4.COMEX (GCZ24). ID: 5 Service code: comex
2024-09-24 15:48:43.070 | Denali Data Feed | Requesting security definition data for: GCZ4.COMEX (GCZ24). ID: 5
2024-09-24 15:48:43.070 | Added historical Intraday data request for GCZ4.COMEX to the queue.
2024-09-24 15:48:43.070 | Intraday data recording state for symbol GCZ4.COMEX is set to download 'Pending'.
2024-09-24 15:48:43.070 | Triggering next historical data download in queue.
2024-09-24 15:48:43.096 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 15:48:43.097 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 6 Service code: cme
2024-09-24 15:48:43.097 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 6
2024-09-24 15:48:43.098 | Mapping CLX4.NYMEX to CLX24. Service code: nymex
2024-09-24 15:48:43.098 | Denali Data Feed | Starting real-time market data updates for: CLX4.NYMEX (CLX24). ID: 7 Service code: nymex
2024-09-24 15:48:43.098 | Denali Data Feed | Requesting security definition data for: CLX4.NYMEX (CLX24). ID: 7
2024-09-24 15:48:43.099 | Mapping 6AZ4.CME to 6AZ24. Service code: cme
2024-09-24 15:48:43.099 | Denali Data Feed | Starting real-time market data updates for: 6AZ4.CME (6AZ24). ID: 8 Service code: cme
2024-09-24 15:48:43.099 | Denali Data Feed | Requesting security definition data for: 6AZ4.CME (6AZ24). ID: 8
2024-09-24 15:48:43.099 | Added historical Intraday data request for 6AZ4.CME to the queue.
2024-09-24 15:48:43.099 | Intraday data recording state for symbol 6AZ4.CME is set to download 'Pending'.
2024-09-24 15:48:43.099 | Triggering next historical data download in queue.
2024-09-24 15:48:43.113 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 15:48:43.113 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 9 Service code: cme
2024-09-24 15:48:43.113 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 9
2024-09-24 15:48:43.125 | Mapping MJYZ4.CME to MJYZ24. Service code: cme
2024-09-24 15:48:43.125 | Denali Data Feed | Starting real-time market data updates for: MJYZ4.CME (MJYZ24). ID: 10 Service code: cme
2024-09-24 15:48:43.125 | Denali Data Feed | Requesting security definition data for: MJYZ4.CME (MJYZ24). ID: 10
2024-09-24 15:48:43.125 | Added historical Intraday data request for MJYZ4.CME to the queue.
2024-09-24 15:48:43.125 | Intraday data recording state for symbol MJYZ4.CME is set to download 'Pending'.
2024-09-24 15:48:43.125 | Triggering next historical data download in queue.
2024-09-24 15:48:43.127 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 15:48:43.127 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 15:48:43.127 | Triggering next historical data download in queue.
2024-09-24 15:48:43.288 | Added historical Intraday data request for MESU4.CME to the queue.
2024-09-24 15:48:43.288 | Intraday data recording state for symbol MESU4.CME is set to download 'Pending'.
2024-09-24 15:48:43.288 | Triggering next historical data download in queue.
2024-09-24 15:48:43.288 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 15:48:43.288 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 15:48:43.353 | Mapping M6AZ4.CME to M6AZ24. Service code: cme
2024-09-24 15:48:43.353 | Denali Data Feed | Starting real-time market data updates for: M6AZ4.CME (M6AZ24). ID: 11 Service code: cme
2024-09-24 15:48:43.353 | Denali Data Feed | Requesting security definition data for: M6AZ4.CME (M6AZ24). ID: 11
2024-09-24 15:48:43.353 | Added historical Intraday data request for M6AZ4.CME to the queue.
2024-09-24 15:48:43.353 | Intraday data recording state for symbol M6AZ4.CME is set to download 'Pending'.
2024-09-24 15:48:43.353 | Triggering next historical data download in queue.
2024-09-24 15:48:43.353 | Mapping MCLU4.NYMEX to MCLU24. Service code: nymex
2024-09-24 15:48:43.353 | Denali Data Feed | Starting real-time market data updates for: MCLU4.NYMEX (MCLU24). ID: 12 Service code: nymex
2024-09-24 15:48:43.353 | Denali Data Feed | Requesting security definition data for: MCLU4.NYMEX (MCLU24). ID: 12
2024-09-24 15:48:43.353 | Added historical Intraday data request for MCLU4.NYMEX to the queue.
2024-09-24 15:48:43.353 | Intraday data recording state for symbol MCLU4.NYMEX is set to download 'Pending'.
2024-09-24 15:48:43.353 | Added historical Intraday data request for CLX4.NYMEX to the queue.
2024-09-24 15:48:43.353 | Intraday data recording state for symbol CLX4.NYMEX is set to download 'Pending'.
2024-09-24 15:48:43.440 | Mapping ESU4.CME to ESU24. Service code: cme
2024-09-24 15:48:43.440 | Denali Data Feed | Starting real-time market data updates for: ESU4.CME (ESU24). ID: 13 Service code: cme
2024-09-24 15:48:43.440 | Denali Data Feed | Requesting security definition data for: ESU4.CME (ESU24). ID: 13
2024-09-24 15:48:43.440 | Added historical Intraday data request for ESU4.CME to the queue.
2024-09-24 15:48:43.440 | Intraday data recording state for symbol ESU4.CME is set to download 'Pending'.
2024-09-24 15:48:43.440 | Triggering next historical data download in queue.
2024-09-24 15:48:43.440 | Mapping MGCZ4.COMEX to MGCZ24. Service code: comex
2024-09-24 15:48:43.440 | Denali Data Feed | Starting real-time market data updates for: MGCZ4.COMEX (MGCZ24). ID: 14 Service code: comex
2024-09-24 15:48:43.440 | Denali Data Feed | Requesting security definition data for: MGCZ4.COMEX (MGCZ24). ID: 14
2024-09-24 15:48:43.440 | Added historical Intraday data request for MGCZ4.COMEX to the queue.
2024-09-24 15:48:43.440 | Intraday data recording state for symbol MGCZ4.COMEX is set to download 'Pending'.
2024-09-24 15:48:43.466 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 15:48:43.466 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 15 Service code: cme
2024-09-24 15:48:43.466 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 15
2024-09-24 15:48:43.466 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 15:48:43.466 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 15:48:43.466 | Triggering next historical data download in queue.
2024-09-24 15:48:47.781 | Requesting market depth updates for: 6AZ4.CME if supported. NumLevels=50
2024-09-24 15:48:47.781 | Requesting market depth updates for: 6JZ4.CME if supported. NumLevels=50
2024-09-24 15:48:47.781 | Requesting market depth updates for: CLX4.NYMEX if supported. NumLevels=50
2024-09-24 15:48:47.781 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=50
2024-09-24 15:48:47.781 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 15:48:47.781 | Requesting market depth updates for: GCZ4.COMEX if supported. NumLevels=50
2024-09-24 15:48:47.781 | Requesting market depth updates for: MESU4.CME if supported. NumLevels=50
2024-09-24 15:48:47.781 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 15:48:47.781 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 15:49:01.791 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (4) | Creating socket. Using TLS 1.2.
2024-09-24 15:49:01.791 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (4) | New receive buffer size: 0
2024-09-24 15:49:01.791 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (4) | Connecting to IP: 216.66.0.130.
2024-09-24 15:49:03.540 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (4) | CloseSocket call.
2024-09-24 15:49:03.540 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:03.791 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (4) | Socket gracefully closed by remote side.
2024-09-24 15:49:03.791 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (4) | Closed.
2024-09-24 15:49:03.847 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:49:03.847 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:49:03.848 | Denali Data Feed | Failed connections: 8
2024-09-24 15:49:03.848 | DTC Client socket (2) | Closed.
2024-09-24 15:49:03.848 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:49:03.848 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:49:03.848 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:49:06.840 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:49:06.840 | DTC Client socket (2) | Creating socket.
2024-09-24 15:49:06.840 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:49:06.840 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:49:14.724 | HD Request # 168 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 15:49:14.724 | HD Request # 168 | Download start date-time: 2024-09-24 15:47:51.000000. File last date-time: 2024-09-24 15:47:51.479002
2024-09-24 15:49:14.724 | HD Request # 168 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:49:14.724 | Socket (4) | Creating socket.
2024-09-24 15:49:14.724 | Socket (4) | New receive buffer size: 0
2024-09-24 15:49:14.724 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:15.294 | HD Request # 168 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:15.294 | HD Request # 168 | Sending historical data logon request message.
2024-09-24 15:49:16.061 | HD Request # 168 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:51. Record interval: 0. Symbol: MESZ24
2024-09-24 15:49:16.341 | HD Request # 168 | Decompressing data.
2024-09-24 15:49:16.622 | HD Request # 168 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 15:47:51.479000
2024-09-24 15:49:16.622 | Socket (4) | CloseSocket call.
2024-09-24 15:49:16.622 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:16.625 | Historical data download thread signaled to stop.
2024-09-24 15:49:16.625 | HD Request # 168 | Timestamp of first Intraday data file record written: 2024-09-24 15:47:52.614000.
2024-09-24 15:49:16.625 | HD Request # 168 | Received 717 Intraday data records from 2024-09-24 15:47:51.479000 to 2024-09-24 15:49:15.852001 (84.4 seconds. Delay: 0.8 seconds) and wrote 714 records for MESZ4.CME
2024-09-24 15:49:16.625 | HD Request # 168 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:15.852001
2024-09-24 15:49:16.625 | HD Request # 168 | Completion time: 2s.
2024-09-24 15:49:16.625 | HD Request # 168 | Intraday data download complete for MESZ4.CME. Unique request ID: 168
2024-09-24 15:49:16.625 | Removing historical data download ID 168.
2024-09-24 15:49:16.625 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 15:49:16.625 | Intraday chart data file opened for MESZ4.CME
2024-09-24 15:49:16.625 | HD Request # 168 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:16.625 | Triggering next historical data download in queue.
2024-09-24 15:49:16.625 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:16.625 | HD Request # 169 | Downloading Intraday chart data for 6JZ4.CME to the file 6JZ4.CME.scid. Service: cme
2024-09-24 15:49:16.626 | HD Request # 169 | Download start date-time: 2024-09-24 15:47:49.000000. File last date-time: 2024-09-24 15:47:49.258000
2024-09-24 15:49:16.626 | HD Request # 169 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:49:16.626 | Socket (5) | Creating socket.
2024-09-24 15:49:16.626 | Socket (5) | New receive buffer size: 0
2024-09-24 15:49:16.626 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:16.901 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:49:16.901 | Socket (4) | Closed.
2024-09-24 15:49:17.196 | HD Request # 169 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:17.196 | HD Request # 169 | Sending historical data logon request message.
2024-09-24 15:49:17.966 | HD Request # 169 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:49. Record interval: 0. Symbol: 6JZ24
2024-09-24 15:49:18.246 | HD Request # 169 | Decompressing data.
2024-09-24 15:49:18.524 | HD Request # 169 | Receiving Intraday data for 6JZ4.CME starting at 2024-09-24 15:47:49.257000
2024-09-24 15:49:18.524 | Socket (5) | CloseSocket call.
2024-09-24 15:49:18.524 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:18.524 | Historical data download thread signaled to stop.
2024-09-24 15:49:18.524 | HD Request # 169 | Timestamp of first Intraday data file record written: 2024-09-24 15:47:57.360000.
2024-09-24 15:49:18.525 | HD Request # 169 | Received 32 Intraday data records from 2024-09-24 15:47:49.257000 to 2024-09-24 15:49:05.614000 (76.4 seconds. Delay: 12.9 seconds) and wrote 28 records for 6JZ4.CME
2024-09-24 15:49:18.525 | HD Request # 169 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:05.614000
2024-09-24 15:49:18.525 | HD Request # 169 | Completion time: 2s.
2024-09-24 15:49:18.525 | HD Request # 169 | Intraday data download complete for 6JZ4.CME. Unique request ID: 169
2024-09-24 15:49:18.525 | Removing historical data download ID 169.
2024-09-24 15:49:18.525 | Real-time Intraday chart data file updates started for 6JZ4.CME
2024-09-24 15:49:18.525 | Intraday chart data file opened for 6JZ4.CME
2024-09-24 15:49:18.525 | HD Request # 169 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:18.525 | Triggering next historical data download in queue.
2024-09-24 15:49:18.525 | Historical data for 6JZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:18.525 | HD Request # 170 | Downloading Intraday chart data for GCZ4.COMEX to the file GCZ4.COMEX.scid. Service: comex
2024-09-24 15:49:18.525 | HD Request # 170 | Download start date-time: 2024-09-24 15:47:51.000000. File last date-time: 2024-09-24 15:47:51.561000
2024-09-24 15:49:18.525 | HD Request # 170 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:49:18.525 | Socket (4) | Creating socket.
2024-09-24 15:49:18.525 | Socket (4) | New receive buffer size: 0
2024-09-24 15:49:18.525 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:18.803 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:49:18.804 | Socket (5) | Closed.
2024-09-24 15:49:19.074 | HD Request # 170 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:19.074 | HD Request # 170 | Sending historical data logon request message.
2024-09-24 15:49:19.342 | HD Request # 170 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:51. Record interval: 0. Symbol: GCZ24
2024-09-24 15:49:19.611 | HD Request # 170 | Decompressing data.
2024-09-24 15:49:19.880 | HD Request # 170 | Receiving Intraday data for GCZ4.COMEX starting at 2024-09-24 15:47:51.561000
2024-09-24 15:49:19.881 | Socket (4) | CloseSocket call.
2024-09-24 15:49:19.881 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:19.881 | Historical data download thread signaled to stop.
2024-09-24 15:49:19.881 | HD Request # 170 | Timestamp of first Intraday data file record written: 2024-09-24 15:47:52.539000.
2024-09-24 15:49:19.881 | HD Request # 170 | Received 234 Intraday data records from 2024-09-24 15:47:51.561000 to 2024-09-24 15:49:20.295001 (88.7 seconds. Delay: -0.4 seconds) and wrote 233 records for GCZ4.COMEX
2024-09-24 15:49:19.881 | HD Request # 170 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:20.295001
2024-09-24 15:49:19.881 | HD Request # 170 | Completion time: 1s.
2024-09-24 15:49:19.881 | HD Request # 170 | Intraday data download complete for GCZ4.COMEX. Unique request ID: 170
2024-09-24 15:49:19.881 | Removing historical data download ID 170.
2024-09-24 15:49:19.881 | Real-time Intraday chart data file updates started for GCZ4.COMEX
2024-09-24 15:49:19.881 | Intraday chart data file opened for GCZ4.COMEX
2024-09-24 15:49:19.881 | HD Request # 170 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:19.881 | Triggering next historical data download in queue.
2024-09-24 15:49:19.881 | Historical data for GCZ4.COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:19.881 | HD Request # 171 | Downloading Intraday chart data for 6AZ4.CME to the file 6AZ4.CME.scid. Service: cme
2024-09-24 15:49:19.881 | HD Request # 171 | Download start date-time: 2024-09-24 15:47:52.000000. File last date-time: 2024-09-24 15:47:52.008001
2024-09-24 15:49:19.881 | HD Request # 171 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:49:19.881 | Socket (5) | Creating socket.
2024-09-24 15:49:19.882 | Socket (5) | New receive buffer size: 0
2024-09-24 15:49:19.882 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:20.150 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:49:20.150 | Socket (4) | Closed.
2024-09-24 15:49:20.449 | HD Request # 171 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:20.449 | HD Request # 171 | Sending historical data logon request message.
2024-09-24 15:49:20.725 | HD Request # 171 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:52. Record interval: 0. Symbol: 6AZ24
2024-09-24 15:49:21.002 | HD Request # 171 | Decompressing data.
2024-09-24 15:49:21.279 | HD Request # 171 | Receiving Intraday data for 6AZ4.CME starting at 2024-09-24 15:47:52.008000
2024-09-24 15:49:21.279 | Socket (5) | CloseSocket call.
2024-09-24 15:49:21.279 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:21.279 | Historical data download thread signaled to stop.
2024-09-24 15:49:21.279 | HD Request # 171 | Timestamp of first Intraday data file record written: 2024-09-24 15:48:02.814000.
2024-09-24 15:49:21.279 | HD Request # 171 | Received 53 Intraday data records from 2024-09-24 15:47:52.008000 to 2024-09-24 15:49:03.792000 (71.8 seconds. Delay: 17.5 seconds) and wrote 51 records for 6AZ4.CME
2024-09-24 15:49:21.279 | HD Request # 171 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:03.792000
2024-09-24 15:49:21.279 | HD Request # 171 | Completion time: 2s.
2024-09-24 15:49:21.279 | HD Request # 171 | Intraday data download complete for 6AZ4.CME. Unique request ID: 171
2024-09-24 15:49:21.279 | Removing historical data download ID 171.
2024-09-24 15:49:21.279 | Real-time Intraday chart data file updates started for 6AZ4.CME
2024-09-24 15:49:21.279 | Intraday chart data file opened for 6AZ4.CME
2024-09-24 15:49:21.279 | HD Request # 171 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:21.279 | Triggering next historical data download in queue.
2024-09-24 15:49:21.279 | Historical data for 6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:21.279 | HD Request # 172 | Downloading Intraday chart data for MJYZ4.CME to the file MJYZ4.CME.scid. Service: cme
2024-09-24 15:49:21.280 | HD Request # 172 | Download start date-time: 2024-09-24 15:35:01.000000. File last date-time: 2024-09-24 15:35:01.988000
2024-09-24 15:49:21.280 | HD Request # 172 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:49:21.280 | Socket (4) | Creating socket.
2024-09-24 15:49:21.280 | Socket (4) | New receive buffer size: 0
2024-09-24 15:49:21.280 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:21.555 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:49:21.555 | Socket (5) | Closed.
2024-09-24 15:49:21.844 | HD Request # 172 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:21.844 | HD Request # 172 | Sending historical data logon request message.
2024-09-24 15:49:22.120 | HD Request # 172 | Requesting Intraday data. Start date-time: 2024-09-24 15:35:01. Record interval: 0. Symbol: MJYZ24
2024-09-24 15:49:22.397 | HD Request # 172 | Decompressing data.
2024-09-24 15:49:22.672 | HD Request # 172 | Receiving Intraday data for MJYZ4.CME starting at 2024-09-24 15:35:01.916000
2024-09-24 15:49:22.673 | Socket (4) | CloseSocket call.
2024-09-24 15:49:22.673 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:22.691 | Historical data download thread signaled to stop.
2024-09-24 15:49:22.691 | HD Request # 172 | Received 2 Intraday data records from 2024-09-24 15:35:01.916000 to 2024-09-24 15:35:01.988000 (0.1 seconds. Delay: 14.3 minutes) and wrote 0 records for MJYZ4.CME
2024-09-24 15:49:22.691 | HD Request # 172 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:35:01.988000
2024-09-24 15:49:22.691 | HD Request # 172 | Completion time: 1s.
2024-09-24 15:49:22.691 | HD Request # 172 | Intraday data download complete for MJYZ4.CME. Unique request ID: 172
2024-09-24 15:49:22.691 | Removing historical data download ID 172.
2024-09-24 15:49:22.691 | Real-time Intraday chart data file updates started for MJYZ4.CME
2024-09-24 15:49:22.691 | Intraday chart data file opened for MJYZ4.CME
2024-09-24 15:49:22.691 | HD Request # 172 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:22.691 | Triggering next historical data download in queue.
2024-09-24 15:49:22.691 | Historical data for MJYZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:22.691 | HD Request # 173 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 15:49:22.692 | HD Request # 173 | Download start date-time: 2024-09-24 15:47:46.000000. File last date-time: 2024-09-24 15:47:46.635000
2024-09-24 15:49:22.692 | HD Request # 173 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:49:22.692 | Socket (5) | Creating socket.
2024-09-24 15:49:22.692 | Socket (5) | New receive buffer size: 0
2024-09-24 15:49:22.692 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:22.949 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:49:22.949 | Socket (4) | Closed.
2024-09-24 15:49:23.245 | HD Request # 173 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:23.245 | HD Request # 173 | Sending historical data logon request message.
2024-09-24 15:49:23.515 | HD Request # 173 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:46. Record interval: 0. Symbol: NQZ24
2024-09-24 15:49:23.786 | HD Request # 173 | Decompressing data.
2024-09-24 15:49:24.058 | HD Request # 173 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 15:47:46.625000
2024-09-24 15:49:24.058 | Socket (5) | CloseSocket call.
2024-09-24 15:49:24.058 | Historical data download thread signaled to stop.
2024-09-24 15:49:24.058 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:24.058 | HD Request # 173 | Timestamp of first Intraday data file record written: 2024-09-24 15:47:47.505000.
2024-09-24 15:49:24.058 | HD Request # 173 | Received 823 Intraday data records from 2024-09-24 15:47:46.625000 to 2024-09-24 15:49:23.900000 (97.3 seconds. Delay: 0.2 seconds) and wrote 821 records for NQZ4.CME
2024-09-24 15:49:24.059 | HD Request # 173 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:23.900000
2024-09-24 15:49:24.059 | HD Request # 173 | Completion time: 2s.
2024-09-24 15:49:24.059 | HD Request # 173 | Intraday data download complete for NQZ4.CME. Unique request ID: 173
2024-09-24 15:49:24.059 | Removing historical data download ID 173.
2024-09-24 15:49:24.059 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 15:49:24.059 | Intraday chart data file opened for NQZ4.CME
2024-09-24 15:49:24.059 | HD Request # 173 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:24.059 | Triggering next historical data download in queue.
2024-09-24 15:49:24.059 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:24.059 | HD Request # 174 | Downloading Intraday chart data for MESU4.CME to the file MESU4.CME.scid. Service: cme
2024-09-24 15:49:24.059 | HD Request # 174 | Download start date-time: 2024-09-20 09:29:58.000000. File last date-time: 2024-09-20 09:29:58.972001
2024-09-24 15:49:24.059 | HD Request # 174 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:49:24.059 | Socket (4) | Creating socket.
2024-09-24 15:49:24.059 | Socket (4) | New receive buffer size: 0
2024-09-24 15:49:24.059 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:24.328 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:49:24.328 | Socket (5) | Closed.
2024-09-24 15:49:24.627 | HD Request # 174 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:24.627 | HD Request # 174 | Sending historical data logon request message.
2024-09-24 15:49:24.905 | HD Request # 174 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:58. Record interval: 0. Symbol: MESU24
2024-09-24 15:49:25.183 | HD Request # 174 | Decompressing data.
2024-09-24 15:49:25.460 | HD Request # 174 | Receiving Intraday data for MESU4.CME starting at 2024-09-20 09:29:58.972000
2024-09-24 15:49:25.460 | Socket (4) | CloseSocket call.
2024-09-24 15:49:25.460 | Historical data download thread signaled to stop.
2024-09-24 15:49:25.460 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:25.460 | HD Request # 174 | Received 2 Intraday data records from 2024-09-20 09:29:58.972000 to 2024-09-20 09:29:58.972001 (0.0 seconds. Delay: 4.3 days) and wrote 0 records for MESU4.CME
2024-09-24 15:49:25.460 | HD Request # 174 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:58.972001
2024-09-24 15:49:25.460 | HD Request # 174 | Completion time: 1s.
2024-09-24 15:49:25.460 | HD Request # 174 | Intraday data download complete for MESU4.CME. Unique request ID: 174
2024-09-24 15:49:25.460 | Removing historical data download ID 174.
2024-09-24 15:49:25.460 | Real-time Intraday chart data file updates started for MESU4.CME
2024-09-24 15:49:25.460 | Intraday chart data file opened for MESU4.CME
2024-09-24 15:49:25.460 | HD Request # 174 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:25.460 | Triggering next historical data download in queue.
2024-09-24 15:49:25.460 | Historical data for MESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:25.460 | HD Request # 175 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 15:49:25.460 | HD Request # 175 | Download start date-time: 2024-09-24 15:47:51.000000. File last date-time: 2024-09-24 15:47:51.478006
2024-09-24 15:49:25.460 | HD Request # 175 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:49:25.460 | Socket (5) | Creating socket.
2024-09-24 15:49:25.460 | Socket (5) | New receive buffer size: 0
2024-09-24 15:49:25.461 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:25.738 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:49:25.738 | Socket (4) | Closed.
2024-09-24 15:49:26.032 | HD Request # 175 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:26.032 | HD Request # 175 | Sending historical data logon request message.
2024-09-24 15:49:26.310 | HD Request # 175 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:51. Record interval: 0. Symbol: ESZ24
2024-09-24 15:49:26.589 | HD Request # 175 | Decompressing data.
2024-09-24 15:49:26.871 | HD Request # 175 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 15:47:51.465000
2024-09-24 15:49:26.872 | Socket (5) | CloseSocket call.
2024-09-24 15:49:26.872 | Historical data download thread signaled to stop.
2024-09-24 15:49:26.872 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:26.872 | HD Request # 175 | Timestamp of first Intraday data file record written: 2024-09-24 15:47:52.613000.
2024-09-24 15:49:26.872 | HD Request # 175 | Received 2189 Intraday data records from 2024-09-24 15:47:51.465000 to 2024-09-24 15:49:27.505000 (96.0 seconds. Delay: -0.6 seconds) and wrote 2180 records for ESZ4.CME
2024-09-24 15:49:26.873 | HD Request # 175 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:27.505000
2024-09-24 15:49:26.873 | HD Request # 175 | Completion time: 1s.
2024-09-24 15:49:26.873 | HD Request # 175 | Intraday data download complete for ESZ4.CME. Unique request ID: 175
2024-09-24 15:49:26.873 | Removing historical data download ID 175.
2024-09-24 15:49:26.873 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 15:49:26.873 | Intraday chart data file opened for ESZ4.CME
2024-09-24 15:49:26.873 | HD Request # 175 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:26.873 | Triggering next historical data download in queue.
2024-09-24 15:49:26.873 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:26.873 | HD Request # 176 | Downloading Intraday chart data for M6AZ4.CME to the file M6AZ4.CME.scid. Service: cme
2024-09-24 15:49:26.873 | HD Request # 176 | Download start date-time: 2024-09-24 15:47:35.000000. File last date-time: 2024-09-24 15:47:35.500000
2024-09-24 15:49:26.873 | HD Request # 176 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:49:26.873 | Socket (4) | Creating socket.
2024-09-24 15:49:26.873 | Socket (4) | New receive buffer size: 0
2024-09-24 15:49:26.873 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:27.150 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:49:27.150 | Socket (5) | Closed.
2024-09-24 15:49:27.442 | HD Request # 176 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:27.442 | HD Request # 176 | Sending historical data logon request message.
2024-09-24 15:49:27.720 | HD Request # 176 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:35. Record interval: 0. Symbol: M6AZ24
2024-09-24 15:49:27.867 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:49:27.867 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:49:27.867 | Denali Data Feed | Failed connections: 9
2024-09-24 15:49:27.867 | DTC Client socket (2) | Closed.
2024-09-24 15:49:27.867 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:49:27.867 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:49:27.867 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:49:28.000 | HD Request # 176 | Decompressing data.
2024-09-24 15:49:28.278 | HD Request # 176 | Receiving Intraday data for M6AZ4.CME starting at 2024-09-24 15:47:35.500000
2024-09-24 15:49:28.278 | Socket (4) | CloseSocket call.
2024-09-24 15:49:28.278 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:28.278 | Historical data download thread signaled to stop.
2024-09-24 15:49:28.278 | HD Request # 176 | Timestamp of first Intraday data file record written: 2024-09-24 15:48:24.338000.
2024-09-24 15:49:28.278 | HD Request # 176 | Received 9 Intraday data records from 2024-09-24 15:47:35.500000 to 2024-09-24 15:49:23.714000 (108.2 seconds. Delay: 4.6 seconds) and wrote 8 records for M6AZ4.CME
2024-09-24 15:49:28.279 | HD Request # 176 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:23.714000
2024-09-24 15:49:28.279 | HD Request # 176 | Completion time: 2s.
2024-09-24 15:49:28.279 | HD Request # 176 | Intraday data download complete for M6AZ4.CME. Unique request ID: 176
2024-09-24 15:49:28.279 | Removing historical data download ID 176.
2024-09-24 15:49:28.279 | Real-time Intraday chart data file updates started for M6AZ4.CME
2024-09-24 15:49:28.279 | Intraday chart data file opened for M6AZ4.CME
2024-09-24 15:49:28.279 | HD Request # 176 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:28.279 | Triggering next historical data download in queue.
2024-09-24 15:49:28.279 | Historical data for M6AZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:28.279 | HD Request # 177 | Downloading Intraday chart data for MCLU4.NYMEX to the file MCLU4.NYMEX.scid. Service: nymex
2024-09-24 15:49:28.279 | HD Request # 177 | Download start date-time: 2024-08-19 14:29:49.000000. File last date-time: 2024-08-19 14:29:49.591000
2024-09-24 15:49:28.279 | HD Request # 177 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:49:28.279 | Socket (2) | Creating socket.
2024-09-24 15:49:28.279 | Socket (2) | New receive buffer size: 0
2024-09-24 15:49:28.279 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:28.556 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:49:28.556 | Socket (4) | Closed.
2024-09-24 15:49:28.835 | HD Request # 177 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:28.835 | HD Request # 177 | Sending historical data logon request message.
2024-09-24 15:49:29.106 | HD Request # 177 | Requesting Intraday data. Start date-time: 2024-08-19 14:29:49. Record interval: 0. Symbol: MCLU24
2024-09-24 15:49:29.379 | HD Request # 177 | Decompressing data.
2024-09-24 15:49:29.651 | HD Request # 177 | Receiving Intraday data for MCLU4.NYMEX starting at 2024-08-19 14:29:49.119000
2024-09-24 15:49:29.651 | Socket (2) | CloseSocket call.
2024-09-24 15:49:29.651 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:29.659 | Historical data download thread signaled to stop.
2024-09-24 15:49:29.659 | HD Request # 177 | Received 4 Intraday data records from 2024-08-19 14:29:49.119000 to 2024-08-19 14:29:49.591000 (0.5 seconds. Delay: 36.1 days) and wrote 0 records for MCLU4.NYMEX
2024-09-24 15:49:29.660 | HD Request # 177 | Add time&sales data | Remembered last file record date-time: 2024-08-19 18:29:49.591000
2024-09-24 15:49:29.660 | HD Request # 177 | Completion time: 1s.
2024-09-24 15:49:29.660 | HD Request # 177 | Intraday data download complete for MCLU4.NYMEX. Unique request ID: 177
2024-09-24 15:49:29.660 | Removing historical data download ID 177.
2024-09-24 15:49:29.660 | Real-time Intraday chart data file updates started for MCLU4.NYMEX
2024-09-24 15:49:29.660 | Intraday chart data file opened for MCLU4.NYMEX
2024-09-24 15:49:29.660 | HD Request # 177 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:29.660 | Triggering next historical data download in queue.
2024-09-24 15:49:29.660 | Historical data for MCLU4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:29.660 | HD Request # 178 | Downloading Intraday chart data for CLX4.NYMEX to the file CLX4.NYMEX.scid. Service: nymex
2024-09-24 15:49:29.660 | HD Request # 178 | Download start date-time: 2024-09-24 15:47:54.000000. File last date-time: 2024-09-24 15:47:54.657002
2024-09-24 15:49:29.660 | HD Request # 178 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:49:29.660 | Socket (4) | Creating socket.
2024-09-24 15:49:29.660 | Socket (4) | New receive buffer size: 0
2024-09-24 15:49:29.660 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:29.922 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 15:49:29.923 | Socket (2) | Closed.
2024-09-24 15:49:30.228 | HD Request # 178 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:30.228 | HD Request # 178 | Sending historical data logon request message.
2024-09-24 15:49:30.505 | HD Request # 178 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:54. Record interval: 0. Symbol: CLX24
2024-09-24 15:49:30.784 | HD Request # 178 | Decompressing data.
2024-09-24 15:49:30.872 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:49:30.872 | DTC Client socket (2) | Creating socket.
2024-09-24 15:49:30.872 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:49:30.872 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:49:31.061 | HD Request # 178 | Receiving Intraday data for CLX4.NYMEX starting at 2024-09-24 15:47:54.657000
2024-09-24 15:49:31.061 | Socket (4) | CloseSocket call.
2024-09-24 15:49:31.061 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:31.062 | Historical data download thread signaled to stop.
2024-09-24 15:49:31.062 | HD Request # 178 | Timestamp of first Intraday data file record written: 2024-09-24 15:48:13.475000.
2024-09-24 15:49:31.062 | HD Request # 178 | Received 79 Intraday data records from 2024-09-24 15:47:54.657000 to 2024-09-24 15:49:27.427000 (92.8 seconds. Delay: 3.6 seconds) and wrote 76 records for CLX4.NYMEX
2024-09-24 15:49:31.062 | HD Request # 178 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:27.427000
2024-09-24 15:49:31.062 | HD Request # 178 | Completion time: 2s.
2024-09-24 15:49:31.062 | HD Request # 178 | Intraday data download complete for CLX4.NYMEX. Unique request ID: 178
2024-09-24 15:49:31.062 | Removing historical data download ID 178.
2024-09-24 15:49:31.062 | Real-time Intraday chart data file updates started for CLX4.NYMEX
2024-09-24 15:49:31.062 | Intraday chart data file opened for CLX4.NYMEX
2024-09-24 15:49:31.062 | HD Request # 178 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:31.062 | Triggering next historical data download in queue.
2024-09-24 15:49:31.062 | Historical data for CLX4.NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:31.062 | HD Request # 179 | Downloading Intraday chart data for ESU4.CME to the file ESU4.CME.scid. Service: cme
2024-09-24 15:49:31.062 | HD Request # 179 | Download start date-time: 2024-09-20 09:29:59.000000. File last date-time: 2024-09-20 09:29:59.856000
2024-09-24 15:49:31.062 | HD Request # 179 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:49:31.063 | Socket (5) | Creating socket.
2024-09-24 15:49:31.063 | Socket (5) | New receive buffer size: 0
2024-09-24 15:49:31.063 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:31.338 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:49:31.338 | Socket (4) | Closed.
2024-09-24 15:49:31.619 | HD Request # 179 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:31.619 | HD Request # 179 | Sending historical data logon request message.
2024-09-24 15:49:31.890 | HD Request # 179 | Requesting Intraday data. Start date-time: 2024-09-20 09:29:59. Record interval: 0. Symbol: ESU24
2024-09-24 15:49:32.162 | HD Request # 179 | Decompressing data.
2024-09-24 15:49:32.432 | HD Request # 179 | Receiving Intraday data for ESU4.CME starting at 2024-09-20 09:29:59.011000
2024-09-24 15:49:32.432 | Socket (5) | CloseSocket call.
2024-09-24 15:49:32.432 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:32.432 | Historical data download thread signaled to stop.
2024-09-24 15:49:32.432 | HD Request # 179 | Received 12 Intraday data records from 2024-09-20 09:29:59.011000 to 2024-09-20 09:29:59.856000 (0.8 seconds. Delay: 4.3 days) and wrote 0 records for ESU4.CME
2024-09-24 15:49:32.433 | HD Request # 179 | Add time&sales data | Remembered last file record date-time: 2024-09-20 13:29:59.856000
2024-09-24 15:49:32.433 | HD Request # 179 | Completion time: 1s.
2024-09-24 15:49:32.433 | HD Request # 179 | Intraday data download complete for ESU4.CME. Unique request ID: 179
2024-09-24 15:49:32.433 | Removing historical data download ID 179.
2024-09-24 15:49:32.433 | Real-time Intraday chart data file updates started for ESU4.CME
2024-09-24 15:49:32.433 | Intraday chart data file opened for ESU4.CME
2024-09-24 15:49:32.433 | HD Request # 179 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:32.433 | Triggering next historical data download in queue.
2024-09-24 15:49:32.433 | Historical data for ESU4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:32.433 | HD Request # 180 | Downloading Intraday chart data for MGCZ4.COMEX to the file MGCZ4.COMEX.scid. Service: comex
2024-09-24 15:49:32.433 | HD Request # 180 | Download start date-time: 2024-09-24 15:48:03.000000. File last date-time: 2024-09-24 15:48:03.380000
2024-09-24 15:49:32.433 | HD Request # 180 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:49:32.433 | Socket (4) | Creating socket.
2024-09-24 15:49:32.433 | Socket (4) | New receive buffer size: 0
2024-09-24 15:49:32.433 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:32.703 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:49:32.703 | Socket (5) | Closed.
2024-09-24 15:49:32.993 | HD Request # 180 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:32.993 | HD Request # 180 | Sending historical data logon request message.
2024-09-24 15:49:33.266 | HD Request # 180 | Requesting Intraday data. Start date-time: 2024-09-24 15:48:03. Record interval: 0. Symbol: MGCZ24
2024-09-24 15:49:33.541 | HD Request # 180 | Decompressing data.
2024-09-24 15:49:33.815 | HD Request # 180 | Receiving Intraday data for MGCZ4.COMEX starting at 2024-09-24 15:48:03.376000
2024-09-24 15:49:33.815 | Socket (4) | CloseSocket call.
2024-09-24 15:49:33.816 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:33.816 | Historical data download thread signaled to stop.
2024-09-24 15:49:33.816 | HD Request # 180 | Timestamp of first Intraday data file record written: 2024-09-24 15:48:05.638000.
2024-09-24 15:49:33.816 | HD Request # 180 | Received 112 Intraday data records from 2024-09-24 15:48:03.376000 to 2024-09-24 15:49:28.767003 (85.4 seconds. Delay: 5.0 seconds) and wrote 110 records for MGCZ4.COMEX
2024-09-24 15:49:33.816 | HD Request # 180 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:28.767003
2024-09-24 15:49:33.816 | HD Request # 180 | Completion time: 1s.
2024-09-24 15:49:33.816 | HD Request # 180 | Intraday data download complete for MGCZ4.COMEX. Unique request ID: 180
2024-09-24 15:49:33.816 | Removing historical data download ID 180.
2024-09-24 15:49:33.816 | Real-time Intraday chart data file updates started for MGCZ4.COMEX
2024-09-24 15:49:33.816 | Intraday chart data file opened for MGCZ4.COMEX
2024-09-24 15:49:33.816 | HD Request # 180 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:33.816 | Triggering next historical data download in queue.
2024-09-24 15:49:33.816 | Historical data for MGCZ4.COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:33.816 | HD Request # 181 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 15:49:33.816 | HD Request # 181 | Download start date-time: 2024-09-24 15:47:47.000000. File last date-time: 2024-09-24 15:47:47.178002
2024-09-24 15:49:33.816 | HD Request # 181 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:49:33.816 | Socket (5) | Creating socket.
2024-09-24 15:49:33.816 | Socket (5) | New receive buffer size: 0
2024-09-24 15:49:33.816 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:49:34.090 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:49:34.090 | Socket (4) | Closed.
2024-09-24 15:49:34.388 | HD Request # 181 | Setting DTC encoding to Binary VLS
2024-09-24 15:49:34.388 | HD Request # 181 | Sending historical data logon request message.
2024-09-24 15:49:34.669 | HD Request # 181 | Requesting Intraday data. Start date-time: 2024-09-24 15:47:47. Record interval: 0. Symbol: MNQZ24
2024-09-24 15:49:34.951 | HD Request # 181 | Decompressing data.
2024-09-24 15:49:35.234 | HD Request # 181 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 15:47:47.178000
2024-09-24 15:49:35.234 | Socket (5) | CloseSocket call.
2024-09-24 15:49:35.234 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:35.243 | Historical data download thread signaled to stop.
2024-09-24 15:49:35.243 | HD Request # 181 | Timestamp of first Intraday data file record written: 2024-09-24 15:47:47.504000.
2024-09-24 15:49:35.243 | HD Request # 181 | Received 1460 Intraday data records from 2024-09-24 15:47:47.178000 to 2024-09-24 15:49:36.012002 (108.8 seconds. Delay: -0.8 seconds) and wrote 1457 records for MNQZ4.CME
2024-09-24 15:49:35.244 | HD Request # 181 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:49:36.012002
2024-09-24 15:49:35.244 | HD Request # 181 | Completion time: 2s.
2024-09-24 15:49:35.244 | HD Request # 181 | Intraday data download complete for MNQZ4.CME. Unique request ID: 181
2024-09-24 15:49:35.244 | Removing historical data download ID 181.
2024-09-24 15:49:35.244 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 15:49:35.244 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 15:49:35.244 | HD Request # 181 | Enabling Intraday chart updating for symbol.
2024-09-24 15:49:35.244 | No download requests in the queue to start downloads for.
2024-09-24 15:49:35.244 | Historical data for MNQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:49:35.514 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:49:35.514 | Socket (5) | Closed.
2024-09-24 15:49:42.819 | Saved Chartbook: 6A.Cht. Time: 0.0404 seconds.
2024-09-24 15:49:43.268 | Unsubscribed from market depth data for 6AZ4.CME
2024-09-24 15:49:45.852 | Saved Chartbook: GC.Cht. Time: 0.0554 seconds.
2024-09-24 15:49:47.781 | Unsubscribed from market depth data for MESU4.CME
2024-09-24 15:49:47.781 | Unsubscribed from market depth data for GCZ4.COMEX
2024-09-24 15:49:47.781 | Unsubscribed from market depth data for ESU4.CME
2024-09-24 15:49:48.844 | Saved Chartbook: CL.Cht. Time: 0.0620 seconds.
2024-09-24 15:49:51.904 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:49:51.904 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:49:51.904 | Denali Data Feed | Failed connections: 10
2024-09-24 15:49:51.904 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:49:51.904 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:49:51.904 | DTC Client socket (2) | Closed.
2024-09-24 15:49:51.904 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:49:52.491 | Saved Chartbook: 6J.Cht. Time: 0.0333 seconds.
2024-09-24 15:49:52.785 | Unsubscribed from market depth data for 6JZ4.CME
2024-09-24 15:49:52.785 | Unsubscribed from market depth data for CLX4.NYMEX
2024-09-24 15:49:54.900 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:49:54.900 | DTC Client socket (2) | Creating socket.
2024-09-24 15:49:54.900 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:49:54.900 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:49:55.698 | File >> Reconnect selected.
2024-09-24 15:49:55.815 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 15:49:55.815 | DTC Client socket (1) | CloseSocket call.
2024-09-24 15:49:55.815 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-09-24 15:49:55.815 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-09-24 15:49:55.815 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 15:49:55.815 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:49:55.815 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:49:55.815 | Rithmic Direct - DTC | Disconnected.
2024-09-24 15:49:55.815 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 15:49:55.815 | DTC Client socket (2) | Closed.
2024-09-24 15:49:56.064 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 15:49:56.064 | DTC Client socket (1) | Closed.
2024-09-24 15:49:59.810 |
2024-09-24 15:49:59.810 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 15:49:59.810 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 15:49:59.810 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 15:49:59.810 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 15:49:59.810 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 15:49:59.810 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 15:50:00.058 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 15:50:00.058 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 15:50:00.058 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 15:50:00.058 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | Received logon response.
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | Server Name: .
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 15:50:01.215 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 15:50:01.216 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 15:50:01.216 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 15:50:01.216 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 15:50:01.216 | Using symbol data fast lookup vector
2024-09-24 15:50:01.216 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 15:50:01.216 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:50:01.216 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 15:50:01.216 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 15:50:01.216 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 15:50:01.216 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 15:50:01.216 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 15:50:01.216 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 15:50:01.216 | DTC Client socket (2) | Creating socket.
2024-09-24 15:50:01.216 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:50:01.216 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:50:01.667 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 15:50:01.667 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 3 Service code: cme
2024-09-24 15:50:01.667 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 3
2024-09-24 15:50:01.667 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 15:50:01.667 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 15:50:01.667 | Triggering next historical data download in queue.
2024-09-24 15:50:01.668 | Delaying start of download for NQZ4.CME.
2024-09-24 15:50:01.668 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 15:50:01.668 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 4 Service code: cme
2024-09-24 15:50:01.668 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 4
2024-09-24 15:50:01.668 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 15:50:01.668 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 15:50:01.668 | Triggering next historical data download in queue.
2024-09-24 15:50:01.669 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 15:50:01.669 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 5 Service code: cme
2024-09-24 15:50:01.669 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 5
2024-09-24 15:50:01.669 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 15:50:01.669 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 15:50:01.669 | Triggering next historical data download in queue.
2024-09-24 15:50:01.738 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 15:50:01.738 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 6 Service code: cme
2024-09-24 15:50:01.738 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 6
2024-09-24 15:50:01.738 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 15:50:01.738 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 15:50:01.738 | Triggering next historical data download in queue.
2024-09-24 15:50:06.223 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 15:50:06.223 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 15:50:06.223 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 15:50:19.812 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | Creating socket. Using TLS 1.2.
2024-09-24 15:50:19.812 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | New receive buffer size: 0
2024-09-24 15:50:19.812 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | Connecting to IP: 216.66.0.130.
2024-09-24 15:50:21.560 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | CloseSocket call.
2024-09-24 15:50:21.560 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:50:21.809 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | Socket gracefully closed by remote side.
2024-09-24 15:50:21.809 | HTTPS connection ID:13 to downloads.rithmic.com:443 for request ID:13 (4) | Closed.
2024-09-24 15:50:22.255 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:50:22.255 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:50:22.255 | Denali Data Feed | Failed connections: 11
2024-09-24 15:50:22.255 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:50:22.255 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:50:22.255 | DTC Client socket (2) | Closed.
2024-09-24 15:50:22.255 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:50:25.248 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:50:25.248 | DTC Client socket (2) | Creating socket.
2024-09-24 15:50:25.248 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:50:25.248 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:50:32.695 | HD Request # 182 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 15:50:32.695 | HD Request # 182 | Download start date-time: 2024-09-24 15:49:23.000000. File last date-time: 2024-09-24 15:49:23.900000
2024-09-24 15:50:32.695 | HD Request # 182 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:50:32.695 | Socket (4) | Creating socket.
2024-09-24 15:50:32.695 | Socket (4) | New receive buffer size: 0
2024-09-24 15:50:32.695 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:50:33.255 | HD Request # 182 | Setting DTC encoding to Binary VLS
2024-09-24 15:50:33.255 | HD Request # 182 | Sending historical data logon request message.
2024-09-24 15:50:34.012 | HD Request # 182 | Requesting Intraday data. Start date-time: 2024-09-24 15:49:23. Record interval: 0. Symbol: NQZ24
2024-09-24 15:50:34.287 | HD Request # 182 | Decompressing data.
2024-09-24 15:50:34.556 | HD Request # 182 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 15:49:23.385000
2024-09-24 15:50:34.556 | Socket (4) | CloseSocket call.
2024-09-24 15:50:34.556 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:50:34.556 | Historical data download thread signaled to stop.
2024-09-24 15:50:34.556 | HD Request # 182 | Timestamp of first Intraday data file record written: 2024-09-24 15:49:25.289000.
2024-09-24 15:50:34.557 | HD Request # 182 | Received 926 Intraday data records from 2024-09-24 15:49:23.385000 to 2024-09-24 15:50:32.461002 (69.1 seconds. Delay: 2.1 seconds) and wrote 895 records for NQZ4.CME
2024-09-24 15:50:34.557 | HD Request # 182 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:50:32.461002
2024-09-24 15:50:34.557 | HD Request # 182 | Completion time: 2s.
2024-09-24 15:50:34.557 | HD Request # 182 | Intraday data download complete for NQZ4.CME. Unique request ID: 182
2024-09-24 15:50:34.557 | Removing historical data download ID 182.
2024-09-24 15:50:34.557 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 15:50:34.557 | Intraday chart data file opened for NQZ4.CME
2024-09-24 15:50:34.557 | HD Request # 182 | Enabling Intraday chart updating for symbol.
2024-09-24 15:50:34.557 | Triggering next historical data download in queue.
2024-09-24 15:50:34.557 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:50:34.557 | HD Request # 183 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 15:50:34.557 | HD Request # 183 | Download start date-time: 2024-09-24 15:49:36.000000. File last date-time: 2024-09-24 15:49:36.012002
2024-09-24 15:50:34.557 | HD Request # 183 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:50:34.557 | Socket (5) | Creating socket.
2024-09-24 15:50:34.557 | Socket (5) | New receive buffer size: 0
2024-09-24 15:50:34.557 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:50:34.827 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:50:34.827 | Socket (4) | Closed.
2024-09-24 15:50:35.114 | HD Request # 183 | Setting DTC encoding to Binary VLS
2024-09-24 15:50:35.114 | HD Request # 183 | Sending historical data logon request message.
2024-09-24 15:50:35.883 | HD Request # 183 | Requesting Intraday data. Start date-time: 2024-09-24 15:49:36. Record interval: 0. Symbol: MNQZ24
2024-09-24 15:50:36.157 | HD Request # 183 | Decompressing data.
2024-09-24 15:50:36.437 | HD Request # 183 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 15:49:36.012000
2024-09-24 15:50:36.438 | Socket (5) | CloseSocket call.
2024-09-24 15:50:36.438 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:50:36.438 | Historical data download thread signaled to stop.
2024-09-24 15:50:36.438 | HD Request # 183 | Timestamp of first Intraday data file record written: 2024-09-24 15:49:36.326000.
2024-09-24 15:50:36.438 | HD Request # 183 | Received 1424 Intraday data records from 2024-09-24 15:49:36.012000 to 2024-09-24 15:50:36.445004 (60.4 seconds. Delay: -0.0 seconds) and wrote 1421 records for MNQZ4.CME
2024-09-24 15:50:36.439 | HD Request # 183 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:50:36.445004
2024-09-24 15:50:36.439 | HD Request # 183 | Completion time: 2s.
2024-09-24 15:50:36.439 | HD Request # 183 | Intraday data download complete for MNQZ4.CME. Unique request ID: 183
2024-09-24 15:50:36.439 | Removing historical data download ID 183.
2024-09-24 15:50:36.439 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 15:50:36.439 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 15:50:36.439 | HD Request # 183 | Enabling Intraday chart updating for symbol.
2024-09-24 15:50:36.439 | Triggering next historical data download in queue.
2024-09-24 15:50:36.439 | Historical data for MNQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:50:36.439 | HD Request # 184 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 15:50:36.439 | HD Request # 184 | Download start date-time: 2024-09-24 15:49:27.000000. File last date-time: 2024-09-24 15:49:27.505000
2024-09-24 15:50:36.439 | HD Request # 184 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:50:36.439 | Socket (4) | Creating socket.
2024-09-24 15:50:36.439 | Socket (4) | New receive buffer size: 0
2024-09-24 15:50:36.439 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:50:36.711 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:50:36.711 | Socket (5) | Closed.
2024-09-24 15:50:37.008 | HD Request # 184 | Setting DTC encoding to Binary VLS
2024-09-24 15:50:37.008 | HD Request # 184 | Sending historical data logon request message.
2024-09-24 15:50:37.285 | HD Request # 184 | Requesting Intraday data. Start date-time: 2024-09-24 15:49:27. Record interval: 0. Symbol: ESZ24
2024-09-24 15:50:37.563 | HD Request # 184 | Decompressing data.
2024-09-24 15:50:37.847 | HD Request # 184 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 15:49:27.505000
2024-09-24 15:50:37.848 | Socket (4) | CloseSocket call.
2024-09-24 15:50:37.848 | Historical data download thread signaled to stop.
2024-09-24 15:50:37.848 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:50:37.848 | HD Request # 184 | Timestamp of first Intraday data file record written: 2024-09-24 15:49:29.535000.
2024-09-24 15:50:37.848 | HD Request # 184 | Received 2174 Intraday data records from 2024-09-24 15:49:27.505000 to 2024-09-24 15:50:36.239001 (68.7 seconds. Delay: 1.6 seconds) and wrote 2173 records for ESZ4.CME
2024-09-24 15:50:37.848 | HD Request # 184 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:50:36.239001
2024-09-24 15:50:37.848 | HD Request # 184 | Completion time: 1s.
2024-09-24 15:50:37.848 | HD Request # 184 | Intraday data download complete for ESZ4.CME. Unique request ID: 184
2024-09-24 15:50:37.848 | Removing historical data download ID 184.
2024-09-24 15:50:37.848 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 15:50:37.848 | Intraday chart data file opened for ESZ4.CME
2024-09-24 15:50:37.848 | HD Request # 184 | Enabling Intraday chart updating for symbol.
2024-09-24 15:50:37.849 |
2024-09-24 15:50:37.849 | Triggering next historical data download in queue.
2024-09-24 15:50:37.849 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:50:37.849 | HD Request # 185 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 15:50:37.849 | HD Request # 185 | Download start date-time: 2024-09-24 15:49:15.000000. File last date-time: 2024-09-24 15:49:15.852001
2024-09-24 15:50:37.849 | HD Request # 185 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:50:37.849 | Socket (5) | Creating socket.
2024-09-24 15:50:37.849 | Socket (5) | New receive buffer size: 0
2024-09-24 15:50:37.849 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:50:38.126 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:50:38.126 | Socket (4) | Closed.
2024-09-24 15:50:38.406 | HD Request # 185 | Setting DTC encoding to Binary VLS
2024-09-24 15:50:38.406 | HD Request # 185 | Sending historical data logon request message.
2024-09-24 15:50:38.682 | HD Request # 185 | Requesting Intraday data. Start date-time: 2024-09-24 15:49:15. Record interval: 0. Symbol: MESZ24
2024-09-24 15:50:38.954 | HD Request # 185 | Decompressing data.
2024-09-24 15:50:39.228 | HD Request # 185 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 15:49:15.240000
2024-09-24 15:50:39.228 | Socket (5) | CloseSocket call.
2024-09-24 15:50:39.228 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:50:39.228 | Historical data download thread signaled to stop.
2024-09-24 15:50:39.228 | HD Request # 185 | Timestamp of first Intraday data file record written: 2024-09-24 15:49:16.418000.
2024-09-24 15:50:39.228 | HD Request # 185 | Received 854 Intraday data records from 2024-09-24 15:49:15.240000 to 2024-09-24 15:50:40.463000 (85.2 seconds. Delay: -1.2 seconds) and wrote 836 records for MESZ4.CME
2024-09-24 15:50:39.229 | HD Request # 185 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:50:40.463000
2024-09-24 15:50:39.229 | HD Request # 185 | Completion time: 2s.
2024-09-24 15:50:39.229 | HD Request # 185 | Intraday data download complete for MESZ4.CME. Unique request ID: 185
2024-09-24 15:50:39.229 | Removing historical data download ID 185.
2024-09-24 15:50:39.229 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 15:50:39.229 | Intraday chart data file opened for MESZ4.CME
2024-09-24 15:50:39.229 | HD Request # 185 | Enabling Intraday chart updating for symbol.
2024-09-24 15:50:39.229 | No download requests in the queue to start downloads for.
2024-09-24 15:50:39.229 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:50:39.499 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:50:39.500 | Socket (5) | Closed.
2024-09-24 15:50:46.285 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:50:46.292 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:50:46.292 | Denali Data Feed | Failed connections: 12
2024-09-24 15:50:46.292 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:50:46.292 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:50:46.292 | DTC Client socket (2) | Closed.
2024-09-24 15:50:46.292 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:50:49.322 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:50:49.323 | DTC Client socket (2) | Creating socket.
2024-09-24 15:50:49.323 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:50:49.323 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:51:10.358 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:51:10.358 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:51:10.358 | Denali Data Feed | Failed connections: 13
2024-09-24 15:51:10.358 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:51:10.358 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:51:10.358 | DTC Client socket (2) | Closed.
2024-09-24 15:51:10.358 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:51:13.367 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:51:13.367 | DTC Client socket (2) | Creating socket.
2024-09-24 15:51:13.367 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:51:13.367 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:51:34.384 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:51:34.398 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:51:34.398 | Denali Data Feed | Failed connections: 14
2024-09-24 15:51:34.398 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:51:34.398 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:51:34.398 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:51:34.398 | DTC Client socket (2) | Closed.
2024-09-24 15:51:37.415 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:51:37.415 | DTC Client socket (2) | Creating socket.
2024-09-24 15:51:37.415 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:51:37.415 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:51:47.364 | File >> Reconnect selected.
2024-09-24 15:51:47.481 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 15:51:47.481 | DTC Client socket (1) | CloseSocket call.
2024-09-24 15:51:47.481 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-09-24 15:51:47.481 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-09-24 15:51:47.482 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:51:47.482 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:51:47.482 | Rithmic Direct - DTC | Disconnected.
2024-09-24 15:51:47.482 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 15:51:47.482 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 15:51:47.482 | DTC Client socket (2) | Closed.
2024-09-24 15:51:47.729 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 15:51:47.729 | DTC Client socket (1) | Closed.
2024-09-24 15:51:51.480 |
2024-09-24 15:51:51.480 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 15:51:51.480 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 15:51:51.480 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 15:51:52.612 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 15:51:52.612 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 15:51:52.613 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 15:51:52.855 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 15:51:52.855 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 15:51:52.855 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 15:51:52.855 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | Received logon response.
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | Server Name: .
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 15:51:53.586 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 15:51:53.586 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 15:51:53.586 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 15:51:53.586 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 15:51:53.586 | Using symbol data fast lookup vector
2024-09-24 15:51:53.586 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 15:51:53.586 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:51:53.586 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 15:51:53.586 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 15:51:53.586 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 15:51:53.586 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 15:51:53.586 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 15:51:53.586 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 15:51:53.587 | DTC Client socket (2) | Creating socket.
2024-09-24 15:51:53.587 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:51:53.587 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:51:53.886 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 15:51:53.886 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 3 Service code: cme
2024-09-24 15:51:53.886 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 3
2024-09-24 15:51:53.886 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 15:51:53.886 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 15:51:53.886 | Triggering next historical data download in queue.
2024-09-24 15:51:53.887 | Delaying start of download for NQZ4.CME.
2024-09-24 15:51:54.087 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 15:51:54.087 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 4 Service code: cme
2024-09-24 15:51:54.087 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 4
2024-09-24 15:51:54.087 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 15:51:54.087 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 15:51:54.087 | Triggering next historical data download in queue.
2024-09-24 15:51:54.088 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 15:51:54.088 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 5 Service code: cme
2024-09-24 15:51:54.088 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 5
2024-09-24 15:51:54.088 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 15:51:54.088 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 15:51:54.088 | Triggering next historical data download in queue.
2024-09-24 15:51:54.110 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 15:51:54.110 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 6 Service code: cme
2024-09-24 15:51:54.110 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 6
2024-09-24 15:51:54.110 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 15:51:54.110 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 15:51:54.110 | Triggering next historical data download in queue.
2024-09-24 15:51:58.575 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 15:51:58.575 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 15:51:58.575 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 15:52:11.815 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (4) | Creating socket. Using TLS 1.2.
2024-09-24 15:52:11.816 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (4) | New receive buffer size: 0
2024-09-24 15:52:11.816 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (4) | Connecting to IP: 216.66.0.130.
2024-09-24 15:52:13.590 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (4) | CloseSocket call.
2024-09-24 15:52:13.590 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:52:13.844 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (4) | Socket gracefully closed by remote side.
2024-09-24 15:52:13.844 | HTTPS connection ID:14 to downloads.rithmic.com:443 for request ID:14 (4) | Closed.
2024-09-24 15:52:14.632 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:52:14.632 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:52:14.632 | Denali Data Feed | Failed connections: 15
2024-09-24 15:52:14.632 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:52:14.632 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:52:14.632 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:52:14.632 | DTC Client socket (2) | Closed.
2024-09-24 15:52:17.626 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:52:17.626 | DTC Client socket (2) | Creating socket.
2024-09-24 15:52:17.626 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:52:17.626 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:52:24.765 | HD Request # 186 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 15:52:24.765 | HD Request # 186 | Download start date-time: 2024-09-24 15:50:32.000000. File last date-time: 2024-09-24 15:50:32.461002
2024-09-24 15:52:24.765 | HD Request # 186 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:52:24.765 | Socket (4) | Creating socket.
2024-09-24 15:52:24.765 | Socket (4) | New receive buffer size: 0
2024-09-24 15:52:24.765 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:52:25.337 | HD Request # 186 | Setting DTC encoding to Binary VLS
2024-09-24 15:52:25.337 | HD Request # 186 | Sending historical data logon request message.
2024-09-24 15:52:26.110 | HD Request # 186 | Requesting Intraday data. Start date-time: 2024-09-24 15:50:32. Record interval: 0. Symbol: NQZ24
2024-09-24 15:52:26.390 | HD Request # 186 | Decompressing data.
2024-09-24 15:52:26.673 | HD Request # 186 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 15:50:32.461000
2024-09-24 15:52:26.674 | Socket (4) | CloseSocket call.
2024-09-24 15:52:26.674 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:52:26.674 | Historical data download thread signaled to stop.
2024-09-24 15:52:26.674 | HD Request # 186 | Timestamp of first Intraday data file record written: 2024-09-24 15:50:32.672000.
2024-09-24 15:52:26.674 | HD Request # 186 | Received 1466 Intraday data records from 2024-09-24 15:50:32.461000 to 2024-09-24 15:52:25.230000 (112.8 seconds. Delay: 1.4 seconds) and wrote 1463 records for NQZ4.CME
2024-09-24 15:52:26.675 | HD Request # 186 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:52:25.230000
2024-09-24 15:52:26.675 | HD Request # 186 | Completion time: 2s.
2024-09-24 15:52:26.675 | HD Request # 186 | Intraday data download complete for NQZ4.CME. Unique request ID: 186
2024-09-24 15:52:26.675 | Removing historical data download ID 186.
2024-09-24 15:52:26.675 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 15:52:26.675 | Intraday chart data file opened for NQZ4.CME
2024-09-24 15:52:26.675 | HD Request # 186 | Enabling Intraday chart updating for symbol.
2024-09-24 15:52:26.675 | Triggering next historical data download in queue.
2024-09-24 15:52:26.675 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:52:26.675 | HD Request # 187 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 15:52:26.675 | HD Request # 187 | Download start date-time: 2024-09-24 15:50:36.000000. File last date-time: 2024-09-24 15:50:36.445004
2024-09-24 15:52:26.675 | HD Request # 187 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:52:26.675 | Socket (5) | Creating socket.
2024-09-24 15:52:26.675 | Socket (5) | New receive buffer size: 0
2024-09-24 15:52:26.675 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:52:26.955 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:52:26.955 | Socket (4) | Closed.
2024-09-24 15:52:27.236 | HD Request # 187 | Setting DTC encoding to Binary VLS
2024-09-24 15:52:27.236 | HD Request # 187 | Sending historical data logon request message.
2024-09-24 15:52:28.002 | HD Request # 187 | Requesting Intraday data. Start date-time: 2024-09-24 15:50:36. Record interval: 0. Symbol: MNQZ24
2024-09-24 15:52:28.277 | HD Request # 187 | Decompressing data.
2024-09-24 15:52:28.557 | HD Request # 187 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 15:50:36.083000
2024-09-24 15:52:28.557 | Socket (5) | CloseSocket call.
2024-09-24 15:52:28.557 | Historical data download thread signaled to stop.
2024-09-24 15:52:28.557 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:52:28.557 | HD Request # 187 | Timestamp of first Intraday data file record written: 2024-09-24 15:50:36.986000.
2024-09-24 15:52:28.557 | HD Request # 187 | Received 2132 Intraday data records from 2024-09-24 15:50:36.083000 to 2024-09-24 15:52:29.467003 (113.4 seconds. Delay: -0.9 seconds) and wrote 2113 records for MNQZ4.CME
2024-09-24 15:52:28.558 | HD Request # 187 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:52:29.467003
2024-09-24 15:52:28.558 | HD Request # 187 | Completion time: 2s.
2024-09-24 15:52:28.558 | HD Request # 187 | Intraday data download complete for MNQZ4.CME. Unique request ID: 187
2024-09-24 15:52:28.558 | Removing historical data download ID 187.
2024-09-24 15:52:28.558 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 15:52:28.558 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 15:52:28.558 | HD Request # 187 | Enabling Intraday chart updating for symbol.
2024-09-24 15:52:28.558 | Triggering next historical data download in queue.
2024-09-24 15:52:28.558 | Historical data for MNQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:52:28.558 | HD Request # 188 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 15:52:28.558 | HD Request # 188 | Download start date-time: 2024-09-24 15:50:36.000000. File last date-time: 2024-09-24 15:50:36.239001
2024-09-24 15:52:28.558 | HD Request # 188 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:52:28.558 | Socket (4) | Creating socket.
2024-09-24 15:52:28.558 | Socket (4) | New receive buffer size: 0
2024-09-24 15:52:28.558 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:52:28.831 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:52:28.831 | Socket (5) | Closed.
2024-09-24 15:52:29.128 | HD Request # 188 | Setting DTC encoding to Binary VLS
2024-09-24 15:52:29.128 | HD Request # 188 | Sending historical data logon request message.
2024-09-24 15:52:29.408 | HD Request # 188 | Requesting Intraday data. Start date-time: 2024-09-24 15:50:36. Record interval: 0. Symbol: ESZ24
2024-09-24 15:52:29.688 | HD Request # 188 | Decompressing data.
2024-09-24 15:52:30.255 | HD Request # 188 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 15:50:36.017000
2024-09-24 15:52:30.257 | Socket (4) | CloseSocket call.
2024-09-24 15:52:30.257 | Historical data download thread signaled to stop.
2024-09-24 15:52:30.257 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:52:30.257 | HD Request # 188 | Timestamp of first Intraday data file record written: 2024-09-24 15:50:37.455000.
2024-09-24 15:52:30.257 | HD Request # 188 | Received 3848 Intraday data records from 2024-09-24 15:50:36.017000 to 2024-09-24 15:52:29.220001 (113.2 seconds. Delay: 1.0 seconds) and wrote 3809 records for ESZ4.CME
2024-09-24 15:52:30.257 | HD Request # 188 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:52:29.220001
2024-09-24 15:52:30.257 | HD Request # 188 | Completion time: 2s.
2024-09-24 15:52:30.257 | HD Request # 188 | Intraday data download complete for ESZ4.CME. Unique request ID: 188
2024-09-24 15:52:30.257 | Removing historical data download ID 188.
2024-09-24 15:52:30.257 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 15:52:30.257 | Intraday chart data file opened for ESZ4.CME
2024-09-24 15:52:30.257 | HD Request # 188 | Enabling Intraday chart updating for symbol.
2024-09-24 15:52:30.257 | Triggering next historical data download in queue.
2024-09-24 15:52:30.257 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:52:30.257 | HD Request # 189 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 15:52:30.257 | HD Request # 189 | Download start date-time: 2024-09-24 15:50:40.000000. File last date-time: 2024-09-24 15:50:40.463000
2024-09-24 15:52:30.257 | HD Request # 189 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:52:30.257 | Socket (5) | Creating socket.
2024-09-24 15:52:30.257 | Socket (5) | New receive buffer size: 0
2024-09-24 15:52:30.258 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:52:30.536 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:52:30.536 | Socket (4) | Closed.
2024-09-24 15:52:30.816 | HD Request # 189 | Setting DTC encoding to Binary VLS
2024-09-24 15:52:30.816 | HD Request # 189 | Sending historical data logon request message.
2024-09-24 15:52:31.091 | HD Request # 189 | Requesting Intraday data. Start date-time: 2024-09-24 15:50:40. Record interval: 0. Symbol: MESZ24
2024-09-24 15:52:31.365 | HD Request # 189 | Decompressing data.
2024-09-24 15:52:31.640 | HD Request # 189 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 15:50:40.014000
2024-09-24 15:52:31.641 | Socket (5) | CloseSocket call.
2024-09-24 15:52:31.641 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:52:31.641 | Historical data download thread signaled to stop.
2024-09-24 15:52:31.641 | HD Request # 189 | Timestamp of first Intraday data file record written: 2024-09-24 15:50:40.793000.
2024-09-24 15:52:31.641 | HD Request # 189 | Received 1126 Intraday data records from 2024-09-24 15:50:40.014000 to 2024-09-24 15:52:32.907000 (112.9 seconds. Delay: -1.3 seconds) and wrote 1117 records for MESZ4.CME
2024-09-24 15:52:31.641 | HD Request # 189 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:52:32.907000
2024-09-24 15:52:31.641 | HD Request # 189 | Completion time: 1s.
2024-09-24 15:52:31.641 | HD Request # 189 | Intraday data download complete for MESZ4.CME. Unique request ID: 189
2024-09-24 15:52:31.641 | Removing historical data download ID 189.
2024-09-24 15:52:31.641 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 15:52:31.641 | Intraday chart data file opened for MESZ4.CME
2024-09-24 15:52:31.641 | HD Request # 189 | Enabling Intraday chart updating for symbol.
2024-09-24 15:52:31.641 | No download requests in the queue to start downloads for.
2024-09-24 15:52:31.641 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:52:31.914 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:52:31.914 | Socket (5) | Closed.
2024-09-24 15:52:38.664 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:52:38.664 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:52:38.664 | Denali Data Feed | Failed connections: 16
2024-09-24 15:52:38.664 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:52:38.664 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:52:38.664 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:52:38.664 | DTC Client socket (2) | Closed.
2024-09-24 15:52:41.654 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:52:41.654 | DTC Client socket (2) | Creating socket.
2024-09-24 15:52:41.654 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:52:41.654 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:52:45.801 | File >> Reconnect selected.
2024-09-24 15:52:45.925 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 15:52:45.926 | DTC Client socket (1) | CloseSocket call.
2024-09-24 15:52:45.926 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-09-24 15:52:45.926 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-09-24 15:52:45.926 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:52:45.926 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:52:45.926 | Rithmic Direct - DTC | Disconnected.
2024-09-24 15:52:45.926 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 15:52:45.926 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 15:52:45.926 | DTC Client socket (2) | Closed.
2024-09-24 15:52:46.169 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 15:52:46.169 | DTC Client socket (1) | Closed.
2024-09-24 15:52:49.915 |
2024-09-24 15:52:49.915 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 15:52:49.915 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 15:52:49.915 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 15:52:49.915 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 15:52:49.915 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 15:52:49.915 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 15:52:50.161 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 15:52:50.161 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 15:52:50.161 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 15:52:50.161 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | Received logon response.
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | Server Name: .
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 15:52:50.901 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 15:52:50.901 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 15:52:50.901 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 15:52:50.901 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 15:52:50.901 | Using symbol data fast lookup vector
2024-09-24 15:52:50.901 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 15:52:50.901 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:52:50.901 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 15:52:50.901 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 15:52:50.901 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 15:52:50.901 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 15:52:50.901 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 15:52:50.901 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 15:52:50.902 | DTC Client socket (2) | Creating socket.
2024-09-24 15:52:50.902 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:52:50.902 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:52:51.019 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 15:52:51.019 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 3 Service code: cme
2024-09-24 15:52:51.019 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 3
2024-09-24 15:52:51.019 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 15:52:51.019 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 15:52:51.019 | Triggering next historical data download in queue.
2024-09-24 15:52:51.045 | Delaying start of download for NQZ4.CME.
2024-09-24 15:52:51.255 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 15:52:51.255 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 4 Service code: cme
2024-09-24 15:52:51.255 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 4
2024-09-24 15:52:51.255 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 15:52:51.255 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 15:52:51.255 | Triggering next historical data download in queue.
2024-09-24 15:52:51.256 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 15:52:51.256 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 5 Service code: cme
2024-09-24 15:52:51.256 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 5
2024-09-24 15:52:51.256 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 15:52:51.256 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 15:52:51.256 | Triggering next historical data download in queue.
2024-09-24 15:52:51.276 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 15:52:51.276 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 6 Service code: cme
2024-09-24 15:52:51.276 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 6
2024-09-24 15:52:51.276 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 15:52:51.276 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 15:52:51.276 | Triggering next historical data download in queue.
2024-09-24 15:52:55.904 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 15:52:55.904 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 15:52:55.904 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 15:53:09.918 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (4) | Creating socket. Using TLS 1.2.
2024-09-24 15:53:09.918 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (4) | New receive buffer size: 0
2024-09-24 15:53:09.918 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (4) | Connecting to IP: 216.66.0.130.
2024-09-24 15:53:11.718 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (4) | CloseSocket call.
2024-09-24 15:53:11.718 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:53:11.934 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:53:11.934 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:53:11.934 | Denali Data Feed | Failed connections: 17
2024-09-24 15:53:11.934 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:53:11.934 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:53:11.934 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:53:11.934 | DTC Client socket (2) | Closed.
2024-09-24 15:53:11.976 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (4) | Socket gracefully closed by remote side.
2024-09-24 15:53:11.976 | HTTPS connection ID:15 to downloads.rithmic.com:443 for request ID:15 (4) | Closed.
2024-09-24 15:53:14.931 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:53:14.931 | DTC Client socket (2) | Creating socket.
2024-09-24 15:53:14.931 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:53:14.931 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:53:22.779 | HD Request # 190 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 15:53:22.780 | HD Request # 190 | Download start date-time: 2024-09-24 15:52:25.000000. File last date-time: 2024-09-24 15:52:25.230000
2024-09-24 15:53:22.780 | HD Request # 190 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:53:22.780 | Socket (4) | Creating socket.
2024-09-24 15:53:22.780 | Socket (4) | New receive buffer size: 0
2024-09-24 15:53:22.780 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:53:23.333 | HD Request # 190 | Setting DTC encoding to Binary VLS
2024-09-24 15:53:23.333 | HD Request # 190 | Sending historical data logon request message.
2024-09-24 15:53:24.091 | HD Request # 190 | Requesting Intraday data. Start date-time: 2024-09-24 15:52:25. Record interval: 0. Symbol: NQZ24
2024-09-24 15:53:24.363 | HD Request # 190 | Decompressing data.
2024-09-24 15:53:24.635 | HD Request # 190 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 15:52:25.230000
2024-09-24 15:53:24.635 | Socket (4) | CloseSocket call.
2024-09-24 15:53:24.635 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:53:24.635 | Historical data download thread signaled to stop.
2024-09-24 15:53:24.635 | HD Request # 190 | Timestamp of first Intraday data file record written: 2024-09-24 15:52:25.479000.
2024-09-24 15:53:24.635 | HD Request # 190 | Received 508 Intraday data records from 2024-09-24 15:52:25.230000 to 2024-09-24 15:53:25.383001 (60.2 seconds. Delay: -0.7 seconds) and wrote 507 records for NQZ4.CME
2024-09-24 15:53:24.636 | HD Request # 190 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:53:25.383001
2024-09-24 15:53:24.636 | HD Request # 190 | Completion time: 2s.
2024-09-24 15:53:24.636 | HD Request # 190 | Intraday data download complete for NQZ4.CME. Unique request ID: 190
2024-09-24 15:53:24.636 | Removing historical data download ID 190.
2024-09-24 15:53:24.636 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 15:53:24.636 | Intraday chart data file opened for NQZ4.CME
2024-09-24 15:53:24.636 | HD Request # 190 | Enabling Intraday chart updating for symbol.
2024-09-24 15:53:24.636 | Triggering next historical data download in queue.
2024-09-24 15:53:24.636 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:53:24.636 | HD Request # 191 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 15:53:24.636 | HD Request # 191 | Download start date-time: 2024-09-24 15:52:29.000000. File last date-time: 2024-09-24 15:52:29.467003
2024-09-24 15:53:24.636 | HD Request # 191 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:53:24.636 | Socket (5) | Creating socket.
2024-09-24 15:53:24.636 | Socket (5) | New receive buffer size: 0
2024-09-24 15:53:24.636 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:53:24.907 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:53:24.907 | Socket (4) | Closed.
2024-09-24 15:53:25.200 | HD Request # 191 | Setting DTC encoding to Binary VLS
2024-09-24 15:53:25.200 | HD Request # 191 | Sending historical data logon request message.
2024-09-24 15:53:25.966 | HD Request # 191 | Requesting Intraday data. Start date-time: 2024-09-24 15:52:29. Record interval: 0. Symbol: MNQZ24
2024-09-24 15:53:26.243 | HD Request # 191 | Decompressing data.
2024-09-24 15:53:26.519 | HD Request # 191 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 15:52:29.112000
2024-09-24 15:53:26.519 | Socket (5) | CloseSocket call.
2024-09-24 15:53:26.519 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:53:26.525 | Historical data download thread signaled to stop.
2024-09-24 15:53:26.525 | HD Request # 191 | Timestamp of first Intraday data file record written: 2024-09-24 15:52:29.559000.
2024-09-24 15:53:26.525 | HD Request # 191 | Received 704 Intraday data records from 2024-09-24 15:52:29.112000 to 2024-09-24 15:53:25.839000 (56.7 seconds. Delay: 0.7 seconds) and wrote 696 records for MNQZ4.CME
2024-09-24 15:53:26.526 | HD Request # 191 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:53:25.839000
2024-09-24 15:53:26.526 | HD Request # 191 | Completion time: 2s.
2024-09-24 15:53:26.526 | HD Request # 191 | Intraday data download complete for MNQZ4.CME. Unique request ID: 191
2024-09-24 15:53:26.526 | Removing historical data download ID 191.
2024-09-24 15:53:26.526 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 15:53:26.526 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 15:53:26.526 | HD Request # 191 | Enabling Intraday chart updating for symbol.
2024-09-24 15:53:26.526 | Triggering next historical data download in queue.
2024-09-24 15:53:26.526 | Historical data for MNQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:53:26.526 | HD Request # 192 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 15:53:26.526 | HD Request # 192 | Download start date-time: 2024-09-24 15:52:29.000000. File last date-time: 2024-09-24 15:52:29.220001
2024-09-24 15:53:26.526 | HD Request # 192 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:53:26.526 | Socket (4) | Creating socket.
2024-09-24 15:53:26.526 | Socket (4) | New receive buffer size: 0
2024-09-24 15:53:26.526 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 15:53:26.795 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:53:26.795 | Socket (5) | Closed.
2024-09-24 15:53:27.103 | HD Request # 192 | Setting DTC encoding to Binary VLS
2024-09-24 15:53:27.103 | HD Request # 192 | Sending historical data logon request message.
2024-09-24 15:53:27.385 | HD Request # 192 | Requesting Intraday data. Start date-time: 2024-09-24 15:52:29. Record interval: 0. Symbol: ESZ24
2024-09-24 15:53:27.667 | HD Request # 192 | Decompressing data.
2024-09-24 15:53:27.953 | HD Request # 192 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 15:52:29.028000
2024-09-24 15:53:27.953 | Socket (4) | CloseSocket call.
2024-09-24 15:53:27.953 | Historical data download thread signaled to stop.
2024-09-24 15:53:27.953 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:53:27.953 | HD Request # 192 | Timestamp of first Intraday data file record written: 2024-09-24 15:52:29.841000.
2024-09-24 15:53:27.953 | HD Request # 192 | Received 1766 Intraday data records from 2024-09-24 15:52:29.028000 to 2024-09-24 15:53:29.908000 (60.9 seconds. Delay: -2.0 seconds) and wrote 1754 records for ESZ4.CME
2024-09-24 15:53:27.954 | HD Request # 192 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:53:29.908000
2024-09-24 15:53:27.954 | HD Request # 192 | Completion time: 1s.
2024-09-24 15:53:27.954 | HD Request # 192 | Intraday data download complete for ESZ4.CME. Unique request ID: 192
2024-09-24 15:53:27.954 | Removing historical data download ID 192.
2024-09-24 15:53:27.954 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 15:53:27.954 | Intraday chart data file opened for ESZ4.CME
2024-09-24 15:53:27.954 | HD Request # 192 | Enabling Intraday chart updating for symbol.
2024-09-24 15:53:27.954 | Triggering next historical data download in queue.
2024-09-24 15:53:27.954 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:53:27.954 | HD Request # 193 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 15:53:27.954 | HD Request # 193 | Download start date-time: 2024-09-24 15:52:32.000000. File last date-time: 2024-09-24 15:52:32.907000
2024-09-24 15:53:27.954 | HD Request # 193 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:53:27.954 | Socket (5) | Creating socket.
2024-09-24 15:53:27.954 | Socket (5) | New receive buffer size: 0
2024-09-24 15:53:27.954 | Socket (5) | Connecting to IP: 67.214.125.3.
2024-09-24 15:53:28.236 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 15:53:28.236 | Socket (4) | Closed.
2024-09-24 15:53:28.521 | HD Request # 193 | Setting DTC encoding to Binary VLS
2024-09-24 15:53:28.521 | HD Request # 193 | Sending historical data logon request message.
2024-09-24 15:53:28.798 | HD Request # 193 | Requesting Intraday data. Start date-time: 2024-09-24 15:52:32. Record interval: 0. Symbol: MESZ24
2024-09-24 15:53:29.077 | HD Request # 193 | Decompressing data.
2024-09-24 15:53:29.361 | HD Request # 193 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 15:52:32.125000
2024-09-24 15:53:29.361 | Socket (5) | CloseSocket call.
2024-09-24 15:53:29.362 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-09-24 15:53:29.362 | Historical data download thread signaled to stop.
2024-09-24 15:53:29.362 | HD Request # 193 | Timestamp of first Intraday data file record written: 2024-09-24 15:52:35.551000.
2024-09-24 15:53:29.362 | HD Request # 193 | Received 412 Intraday data records from 2024-09-24 15:52:32.125000 to 2024-09-24 15:53:29.800000 (57.7 seconds. Delay: -0.4 seconds) and wrote 402 records for MESZ4.CME
2024-09-24 15:53:29.362 | HD Request # 193 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:53:29.800000
2024-09-24 15:53:29.362 | HD Request # 193 | Completion time: 2s.
2024-09-24 15:53:29.362 | HD Request # 193 | Intraday data download complete for MESZ4.CME. Unique request ID: 193
2024-09-24 15:53:29.362 | Removing historical data download ID 193.
2024-09-24 15:53:29.362 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 15:53:29.362 | Intraday chart data file opened for MESZ4.CME
2024-09-24 15:53:29.362 | HD Request # 193 | Enabling Intraday chart updating for symbol.
2024-09-24 15:53:29.362 | No download requests in the queue to start downloads for.
2024-09-24 15:53:29.362 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:53:29.638 | Socket (5) | Socket gracefully closed by remote side.
2024-09-24 15:53:29.639 | Socket (5) | Closed.
2024-09-24 15:53:35.953 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:53:35.953 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:53:35.953 | DTC Client socket (2) | Closed.
2024-09-24 15:53:35.953 | Denali Data Feed | Failed connections: 18
2024-09-24 15:53:35.953 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:53:35.953 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:53:35.953 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:53:38.947 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:53:38.947 | DTC Client socket (2) | Creating socket.
2024-09-24 15:53:38.947 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:53:38.947 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:53:59.985 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:53:59.985 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:53:59.985 | Denali Data Feed | Failed connections: 19
2024-09-24 15:53:59.985 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:53:59.985 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:53:59.985 | DTC Client socket (2) | Closed.
2024-09-24 15:53:59.985 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:54:02.985 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:54:02.985 | DTC Client socket (2) | Creating socket.
2024-09-24 15:54:02.985 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:54:02.985 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:54:24.006 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:54:24.006 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:54:24.006 | Denali Data Feed | Failed connections: 20
2024-09-24 15:54:24.006 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:54:24.006 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:54:24.006 | DTC Client socket (2) | Closed.
2024-09-24 15:54:24.006 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:54:26.999 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:54:26.999 | DTC Client socket (2) | Creating socket.
2024-09-24 15:54:26.999 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:54:26.999 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
[2024-09-24 20:03:13]
User753526 - Posts: 51
Another update. I just restarted Sierra Charts and I get updated charts which then stop and no time & sales data or DOM price data appearing. I see the lines talking about Windows Error 10060 however I've made no updates or changes today, these issues simply appeared reoccurent over the past 2 wks and today coming to a complete stop.
Updated Message Log
2024-09-24 15:58:39.660 | Trade activity files set size: 2501
2024-09-24 15:58:39.692 | Created the DTC Protocol server.
2024-09-24 15:58:39.694 | DTC Protocol Server listening on port 11099.
2024-09-24 15:58:39.694 | Reading Internal Order ID file.
2024-09-24 15:58:39.728 | Reading Trade Orders file.
2024-09-24 15:58:39.728 | Reading Trade Positions file.
2024-09-24 15:58:39.728 | Reading Trade Account Data files.
2024-09-24 15:58:39.730 | NTP | Create NTP Client...
2024-09-24 15:58:39.730 | NTP | Start NTP Client Receive Thread.
2024-09-24 15:58:39.730 | NTP | Client | No privilege to gradual adjust system time. Set time will be used instead to step system time.
2024-09-24 15:58:39.730 | NTP | Client | Create NTP Client Service.
2024-09-24 15:58:39.730 | NTP | Client | Start NTP Client Service.
2024-09-24 15:58:39.730 | NTP | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment.
2024-09-24 15:58:39.730 | NTP | Unable to get permission to adjust the system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2024-09-24 15:58:39.730 | NTP | Client | Cannot adjust System Clock. Cancel NTP Client Service starting.
2024-09-24 15:58:39.730 | NTP | Stop NTP Client...
2024-09-24 15:58:39.730 | NTP | NTP Client Stopped.
2024-09-24 15:58:39.730 | NTP | Unable to get permission to restore the system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2024-09-24 15:58:39.730 | Software version: 2652 64-bit
2024-09-24 15:58:39.730 | Primary Thread ID: 39664
2024-09-24 15:58:39.730 | Usage end date: 2024-10-10
2024-09-24 15:58:39.730 | Enabled for: Advanced Features 2.
2024-09-24 15:58:39.730 | Enabled for: Sierra Chart Historical Data Service.
2024-09-24 15:58:39.730 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-09-24 15:58:39.730 | Enabled for: Delayed Denali Exchange Data Feed.
2024-09-24 15:58:39.730 | Enabled for exchange2: CME
2024-09-24 15:58:39.730 | Enabled for exchange2: COMEX
2024-09-24 15:58:39.730 | Enabled for exchange2: NYMEX
2024-09-24 15:58:39.730 | Enabled for exchange2: NASDAQ Global Indexes
2024-09-24 15:58:39.730 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-09-24 15:58:39.730 | Current selected Data/Trading service: Rithmic Direct - DTC
2024-09-24 15:58:39.730 | Custom symbol settings values: enabled
2024-09-24 15:58:39.730 | Chart Update Interval: 500
2024-09-24 15:58:39.730 | Intraday Data Storage Time Unit: 0
2024-09-24 15:58:39.730 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2024-09-24 15:58:39.730 | 2024-09-24 19:58:39 Local computer time in UTC
2024-09-24 15:58:39.730 | 2024-09-24 15:58:39 Local computer time in SC Time Zone
2024-09-24 15:58:39.730 | 2024-09-24 19:58:40 Server time in UTC
2024-09-24 15:58:39.730 | Local computer UTC time and Server UTC time difference: 2 seconds.
2024-09-24 15:58:39.730 | Program path: C:\SierraChart - TopStep\
2024-09-24 15:58:39.730 | Data Files path: C:\SierraChart - TopStep\Data\
2024-09-24 15:58:39.731 | OS Version Number: 10.0
2024-09-24 15:58:39.731 | Locale Setting: C
2024-09-24 15:58:39.731 | DLLs: ICTMarketOpens_64.dll, UserContributedStudies_64.dll
2024-09-24 15:58:39.731 | Allowed protected custom studies:
2024-09-24 15:58:39.731 | Crash reporter started: true
2024-09-24 15:58:39.742 | Created the DTC Protocol historical data server.
2024-09-24 15:58:39.743 | HD Server Manager | Listening on port 11098.
2024-09-24 15:58:39.743 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2024-09-24 15:58:39.753 | Chat: Chat Window created. Connecting to server.
2024-09-24 15:58:39.754 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-24 15:58:39.786 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2024-09-24 15:58:39.998 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2024-09-24 15:58:39.998 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2024-09-24 15:58:40.423 | Received 5 login tokens.
2024-09-24 15:58:40.795 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2024-09-24 15:58:40.795 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2024-09-24 15:58:40.795 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2024-09-24 15:58:40.795 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2024-09-24 15:58:40.795 | DTC Client socket (6) | New receive buffer size: 0
2024-09-24 15:58:40.795 | DTC Client socket (6) | Connecting to IP: 69.39.70.248.
2024-09-24 15:58:41.071 | Chat | Network connection to server complete.
2024-09-24 15:58:41.071 | Chat | Starting socket receive thread.
2024-09-24 15:58:41.071 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-24 15:58:41.899 | Chat | Setting DTC encoding to Binary VLS
2024-09-24 15:58:41.899 | Chat | Sending logon request message.
2024-09-24 15:58:42.008 | Symbol settings MD5 received. Request ID: 1.
2024-09-24 15:58:42.008 | Symbol settings are up-to-date for rithmic_v2.trading.
2024-09-24 15:58:42.247 | Requested user files to download.
2024-09-24 15:58:42.541 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2024-09-24 15:58:42.541 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2024-09-24 15:58:42.652 | Chat | Received logon response.
2024-09-24 15:58:42.652 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-24 15:58:42.652 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:58:42.652 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-24 15:58:42.652 | Chat | Trading is not supported.
2024-09-24 15:58:42.652 | Chat | MarketDepthIsSupported: 1
2024-09-24 15:58:42.792 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2024-09-24 15:58:42.792 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2024-09-24 15:58:44.244 |
2024-09-24 15:58:44.244 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 15:58:44.244 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 15:58:44.245 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 15:58:44.560 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 15:58:44.561 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 15:58:44.561 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 15:58:44.800 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 15:58:44.800 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 15:58:44.800 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 15:58:44.800 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | Received logon response.
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | Server Name: .
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 15:58:45.529 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 15:58:45.529 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 15:58:45.529 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 15:58:45.529 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 15:58:45.529 | Using symbol data fast lookup vector
2024-09-24 15:58:45.529 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 15:58:45.530 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:58:45.531 | DTC Client socket (2) | Creating socket.
2024-09-24 15:58:45.531 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:58:45.531 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:58:45.532 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 15:58:45.532 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 15:58:45.532 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 15:58:45.532 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 15:58:45.532 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 15:58:45.532 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 15:59:04.244 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2.
2024-09-24 15:59:04.244 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | New receive buffer size: 0
2024-09-24 15:59:04.244 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Connecting to IP: 216.66.0.130.
2024-09-24 15:59:06.014 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | CloseSocket call.
2024-09-24 15:59:06.014 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Shutdown started. Waiting for graceful close.
2024-09-24 15:59:06.267 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side.
2024-09-24 15:59:06.268 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Closed.
2024-09-24 15:59:06.588 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:59:06.588 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:59:06.588 | Denali Data Feed | Failed connections: 1
2024-09-24 15:59:06.588 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:59:06.588 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:59:06.588 | DTC Client socket (2) | Closed.
2024-09-24 15:59:06.588 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:59:09.591 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:59:09.591 | DTC Client socket (2) | Creating socket.
2024-09-24 15:59:09.591 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:59:09.591 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:59:22.963 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 15:59:22.965 | Starting DelayedDownloadMonitoringTimer
2024-09-24 15:59:22.965 | Starting HDTimeoutTimer
2024-09-24 15:59:22.965 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 15:59:22.966 | Triggering next historical data download in queue.
2024-09-24 15:59:22.967 | ESZ4.CME [CBV] 240 Min #2 | Performing continuous chart historical Daily data download for symbol ESZ4.CME starting at last date in file.
2024-09-24 15:59:22.967 | Starting DelayedDownloadMonitoringTimer
2024-09-24 15:59:22.967 | Starting HDTimeoutTimer
2024-09-24 15:59:22.967 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-24 15:59:22.968 | Triggering next historical data download in queue.
2024-09-24 15:59:22.987 | ESZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-24 15:59:22.996 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-24 15:59:23.086 | ESZ4.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-24 15:59:23.094 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 15:59:23.181 | ESZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-24 15:59:23.189 | ESZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-24 15:59:23.274 | ESZ4.CME [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-24 15:59:23.281 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-24 15:59:23.281 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:23.281 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:23.476 | ESZ4.CME [CBV] Monthly #4 | Waiting for historical downloads to complete with the IDs: 2,
2024-09-24 15:59:23.483 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-24 15:59:23.483 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:23.483 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:23.668 | ESZ4.CME [CBV] Weekly #5 | Waiting for historical downloads to complete with the IDs: 2,
2024-09-24 15:59:23.676 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-24 15:59:23.676 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:23.676 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:23.858 | ESZ4.CME [CBV] Daily #6 | Waiting for historical downloads to complete with the IDs: 2,
2024-09-24 15:59:23.866 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 15:59:23.947 | ESZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-24 15:59:23.977 | ESZ4.CME 5 Min #12 | Reloading chart.
2024-09-24 15:59:23.988 | ESZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-24 15:59:23.999 | ESZ4.CME [CBV] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-24 15:59:24.023 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-24 15:59:24.062 | ESZ4.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-24 15:59:24.088 | ESZ4.CME 5 Min #11 | Reloading chart.
2024-09-24 15:59:24.116 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-24 15:59:24.198 | ESZ4.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 1, 2,
2024-09-24 15:59:24.226 | ESZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-24 15:59:24.356 | ESZ4.CME #9 | Reloading chart.
2024-09-24 15:59:24.357 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-24 15:59:24.366 | ESZ4.CME #9 | Chart data loading complete.
2024-09-24 15:59:24.381 | MESZ4.CME 30 Min #1 | Reloading chart.
2024-09-24 15:59:24.525 | MESZ4.CME #16 | Reloading chart.
2024-09-24 15:59:24.525 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-24 15:59:24.534 | MESZ4.CME #16 | Chart data loading complete.
2024-09-24 15:59:24.667 | MESZ4.CME #18 | Reloading chart.
2024-09-24 15:59:24.667 | MESZ4.CME #18 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-24 15:59:24.676 | MESZ4.CME #18 | Chart data loading complete.
2024-09-24 15:59:24.685 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 15:59:24.685 | HD Request # 1 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 15:59:24.685 | HD Request # 1 | Download start date-time: 2024-09-24 15:57:15.000000. File last date-time: 2024-09-24 15:57:15.044000
2024-09-24 15:59:24.685 | HD Request # 1 | Using server: ds32.sierracharts.com port 10150
2024-09-24 15:59:24.685 | Socket (3) | Creating socket.
2024-09-24 15:59:24.685 | Socket (3) | New receive buffer size: 0
2024-09-24 15:59:24.685 | Socket (3) | Connecting to IP: 67.214.125.3.
2024-09-24 15:59:24.686 | HD Request # 2 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 15:59:24.700 | ESZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-10 15:57:15
2024-09-24 15:59:24.710 | ESZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-24 15:59:24.711 | MESZ4.CME 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-24 15:59:24.712 | MESZ4.CME 30 Min #1 | Chart data loading complete.
2024-09-24 15:59:24.822 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 3 Service code: cme
2024-09-24 15:59:24.822 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 3
2024-09-24 15:59:24.869 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 15:59:24.869 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 4 Service code: cme
2024-09-24 15:59:24.869 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 4
2024-09-24 15:59:24.869 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 15:59:24.869 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 15:59:24.869 | Triggering next historical data download in queue.
2024-09-24 15:59:24.980 | ESZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 15:59:25.000 | ESZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-24 15:59:25.248 | HD Request # 1 | Setting DTC encoding to Binary VLS
2024-09-24 15:59:25.248 | HD Request # 1 | Sending historical data logon request message.
2024-09-24 15:59:25.288 | ESZ4.CME[M] Rev. 16t-20 #13 | Chart data loading complete.
2024-09-24 15:59:25.525 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 15:59:25.525 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 15:59:25.642 | HD Request # 2 | Requesting historical Daily data for ESZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 15:59:26.016 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-09-24 15:57:15. Record interval: 0. Symbol: ESZ24
2024-09-24 15:59:26.287 | HD Request # 1 | Decompressing data.
2024-09-24 15:59:26.525 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 15:59:26.528 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 15:59:26.528 | Triggering next historical data download in queue.
2024-09-24 15:59:26.547 | NQZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 15:59:26.555 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-24 15:59:26.572 | HD Request # 1 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 15:57:15.044000
2024-09-24 15:59:26.586 | NQZ4.CME [CBV] #16 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 15:59:26.611 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 15:59:26.704 | NQZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 15:59:26.712 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-24 15:59:26.798 | NQZ4.CME [CBV] 60 Min #14 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 15:59:26.807 | NQZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-24 15:59:26.807 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:26.807 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:26.843 | Socket (3) | CloseSocket call.
2024-09-24 15:59:26.843 | Socket (3) | Shutdown started. Waiting for graceful close.
2024-09-24 15:59:27.109 | NQZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-24 15:59:27.109 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:27.109 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:27.114 | Socket (3) | Socket gracefully closed by remote side.
2024-09-24 15:59:27.114 | Socket (3) | Closed.
2024-09-24 15:59:27.414 | NQZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-24 15:59:27.414 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:27.414 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:27.736 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-24 15:59:27.774 | NQZ4.CME [CBV] 60 Min #11 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 15:59:27.800 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-24 15:59:27.881 | NQZ4.CME [CBV] 15 Min #1 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 15:59:27.910 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-24 15:59:27.922 | NQZ4.CME [CBV] 5 Min #15 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 15:59:28.050 | MNQZ4.CME #9 | Reloading chart.
2024-09-24 15:59:28.086 | NQZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-24 15:59:28.097 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 15:59:28.181 | NQZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 15:59:28.191 | NQZ4.CME 5 Min #12 | Reloading chart.
2024-09-24 15:59:28.236 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-24 15:59:28.247 | NQZ4.CME [CBV] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 15:59:28.405 | MNQZ4.CME [CBV] 1 Min #10 | Reloading chart.
2024-09-24 15:59:28.408 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 15:59:28.409 | MNQZ4.CME [CBV] 1 Min #10 | Performing continuous chart historical Daily data download for symbol MNQZ4.CME starting at last date in file.
2024-09-24 15:59:28.409 | Added historical Daily data request for MNQZ4.CME to the queue.
2024-09-24 15:59:28.409 | Triggering next historical data download in queue.
2024-09-24 15:59:28.418 | MNQZ4.CME [CBV] 1 Min #10 | Waiting for historical downloads to complete with the IDs: 5, 6,
2024-09-24 15:59:28.451 | HD Request # 2 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-19.
2024-09-24 15:59:28.451 | HD Request # 2 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-24 15:59:28.454 | HD Request # 2 | Bytes received: 233
2024-09-24 15:59:28.454 | HD Request # 2 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for ESZ4.CME
2024-09-24 15:59:28.454 | HD Request # 2 | Completion time: 4s.
2024-09-24 15:59:28.454 | HD Request # 2 | Daily data download complete for ESZ4.CME. Unique request ID: 2
2024-09-24 15:59:28.454 | Removing historical data download ID 2.
2024-09-24 15:59:28.456 | Historical data download thread signaled to stop.
2024-09-24 15:59:28.457 | HD Request # 1 | Timestamp of first Intraday data file record written: 2024-09-24 15:57:15.394000.
2024-09-24 15:59:28.457 | HD Request # 1 | Received 9352 Intraday data records from 2024-09-24 15:57:15.044000 to 2024-09-24 15:59:28.239000 (2.2 minutes. Delay: 0.2 seconds) and wrote 9351 records for ESZ4.CME
2024-09-24 15:59:28.457 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:59:28.239000
2024-09-24 15:59:28.457 | HD Request # 1 | Completion time: 4s.
2024-09-24 15:59:28.457 | HD Request # 1 | Intraday data download complete for ESZ4.CME. Unique request ID: 1
2024-09-24 15:59:28.457 | Removing historical data download ID 1.
2024-09-24 15:59:28.457 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 15:59:28.457 | Intraday chart data file opened for ESZ4.CME
2024-09-24 15:59:28.457 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2024-09-24 15:59:28.457 | Triggering next historical data download in queue.
2024-09-24 15:59:28.457 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:59:28.460 | NQZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-24 15:59:28.463 | NQZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-24 15:59:28.467 | NQZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-24 15:59:28.473 | MNQZ4.CME #9 | StartDateTimeForLoadingOrderFills: 2024-09-10 15:57:15
2024-09-24 15:59:28.473 | MNQZ4.CME #9 | Chart data loading complete.
2024-09-24 15:59:28.474 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 15:59:28.475 | HD Request # 3 | Downloading Historical Daily chart data for MNQZ4.CME. Starting date: 2024-09-18. Service: rithmic.trading
2024-09-24 15:59:28.475 | Delaying start of download for MESZ4.CME.
2024-09-24 15:59:28.508 | ESZ4.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:28.509 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-24 15:59:28.586 | ESZ4.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:28.586 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-24 15:59:28.629 | ESZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:28.630 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 15:59:28.715 | NQZ4.CME Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:22
2024-09-24 15:59:28.761 | NQZ4.CME Rev. 16t-20 #13 | Chart data loading complete.
2024-09-24 15:59:28.808 | NQZ4.CME 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 15:59:28.817 | NQZ4.CME 5 Min #12 | Chart data loading complete.
2024-09-24 15:59:28.840 | ESZ4.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:28.841 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-24 15:59:28.941 | ESZ4.CME [CBV] Daily #6 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:28.942 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-24 15:59:29.120 | ESZ4.CME [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:29.121 | ESZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-24 15:59:29.219 | ESZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-24 15:59:29.261 | ESZ4.CME [CBV] Monthly #4 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:29.262 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-24 15:59:29.466 | ESZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:29.467 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 15:59:29.566 | HD Request # 3 | Requesting historical Daily data for NMZ24 starting at 2024-09-17. SC External HD service.
2024-09-24 15:59:29.567 | ESZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-24 15:59:29.569 | ESZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:29.569 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 15:59:29.603 | ESZ4.CME [CBV] Weekly #5 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:29.603 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-24 15:59:29.817 | ESZ4.CME [CBV] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 15:59:29.817 | ESZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-24 15:59:29.835 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 15:59:29.835 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 6 Service code: cme
2024-09-24 15:59:29.835 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 6
2024-09-24 15:59:29.840 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 5 Service code: cme
2024-09-24 15:59:29.840 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 5
2024-09-24 15:59:29.863 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-24 15:59:30.089 | ESZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-24 15:59:30.092 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-24 15:59:30.209 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 15:59:30.433 | HD Request # 3 | Receiving historical Daily data for MNQZ4.CME starting at 2024-09-18.
2024-09-24 15:59:30.433 | HD Request # 3 | Writing historical Daily data to the file MNQZ4.CME.dly.
2024-09-24 15:59:30.435 | HD Request # 3 | Bytes received: 297
2024-09-24 15:59:30.435 | HD Request # 3 | Received 5 Daily data records from 2024-09-18 00:00:00 to 2024-09-23 00:00:00 (6.0 days) and wrote 4 records for MNQZ4.CME
2024-09-24 15:59:30.435 | HD Request # 3 | Completion time: 2s.
2024-09-24 15:59:30.435 | HD Request # 3 | Daily data download complete for MNQZ4.CME. Unique request ID: 6
2024-09-24 15:59:30.435 | Removing historical data download ID 6.
2024-09-24 15:59:30.435 | No download requests in the queue to start downloads for.
2024-09-24 15:59:30.438 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-24 15:59:30.629 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:59:30.666 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:59:30.666 | Denali Data Feed | Failed connections: 2
2024-09-24 15:59:30.666 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:59:30.666 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:59:30.666 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:59:30.666 | DTC Client socket (2) | Closed.
2024-09-24 15:59:30.670 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-24 15:59:30.670 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:30.671 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:31.177 | ESZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-24 15:59:31.413 | ESZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-24 15:59:31.432 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-24 15:59:31.432 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:31.432 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:31.916 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 15:59:32.143 | ESZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-24 15:59:32.144 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 15:59:32.202 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-24 15:59:32.202 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:32.202 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 15:59:32.662 | ESZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-24 15:59:32.696 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 15:59:32.726 | ESZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-24 15:59:33.142 | ESZ4.CME [CBV] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-24 15:59:33.156 | ESZ4.CME [CBV] 1 Min #17 | Chart data loading complete.
2024-09-24 15:59:33.672 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:59:33.672 | DTC Client socket (2) | Creating socket.
2024-09-24 15:59:33.672 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 15:59:33.672 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 15:59:42.951 | ESZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-24 15:59:54.703 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 15:59:54.703 | DTC Client socket (2) | CloseSocket call.
2024-09-24 15:59:54.703 | Denali Data Feed | Failed connections: 3
2024-09-24 15:59:54.703 | DTC Client socket (0) | CloseSocket call.
2024-09-24 15:59:54.703 | Denali Data Feed | Disconnected from the server.
2024-09-24 15:59:54.703 | DTC Client socket (2) | Closed.
2024-09-24 15:59:54.703 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 15:59:55.982 | HD Request # 4 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 15:59:55.982 | HD Request # 4 | Download start date-time: 2024-09-24 15:57:14.000000. File last date-time: 2024-09-24 15:57:14.928003
2024-09-24 15:59:55.982 | HD Request # 4 | Using server: ds32.sierracharts.com port 10149
2024-09-24 15:59:55.982 | Socket (2) | Creating socket.
2024-09-24 15:59:55.983 | Socket (2) | New receive buffer size: 0
2024-09-24 15:59:55.983 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 15:59:56.536 | HD Request # 4 | Setting DTC encoding to Binary VLS
2024-09-24 15:59:56.536 | HD Request # 4 | Sending historical data logon request message.
2024-09-24 15:59:57.300 | HD Request # 4 | Requesting Intraday data. Start date-time: 2024-09-24 15:57:14. Record interval: 0. Symbol: MESZ24
2024-09-24 15:59:57.572 | HD Request # 4 | Decompressing data.
2024-09-24 15:59:57.697 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 15:59:57.698 | DTC Client socket (3) | Creating socket.
2024-09-24 15:59:57.698 | DTC Client socket (3) | New receive buffer size: 0
2024-09-24 15:59:57.698 | DTC Client socket (3) | Connecting to IP: 202.52.152.130.
2024-09-24 15:59:57.853 | HD Request # 4 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 15:57:14.048000
2024-09-24 15:59:58.166 | Socket (2) | CloseSocket call.
2024-09-24 15:59:58.166 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 15:59:58.166 | Historical data download thread signaled to stop.
2024-09-24 15:59:58.166 | HD Request # 4 | Timestamp of first Intraday data file record written: 2024-09-24 15:57:15.431000.
2024-09-24 15:59:58.166 | HD Request # 4 | Received 5346 Intraday data records from 2024-09-24 15:57:14.048000 to 2024-09-24 15:59:56.417000 (2.7 minutes. Delay: 1.7 seconds) and wrote 5330 records for MESZ4.CME
2024-09-24 15:59:58.166 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2024-09-24 19:59:56.417000
2024-09-24 15:59:58.166 | HD Request # 4 | Completion time: 3s.
2024-09-24 15:59:58.166 | HD Request # 4 | Intraday data download complete for MESZ4.CME. Unique request ID: 3
2024-09-24 15:59:58.166 | Removing historical data download ID 3.
2024-09-24 15:59:58.166 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 15:59:58.166 | Intraday chart data file opened for MESZ4.CME
2024-09-24 15:59:58.166 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2024-09-24 15:59:58.166 | Triggering next historical data download in queue.
2024-09-24 15:59:58.166 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 15:59:58.166 | Delaying start of download for NQZ4.CME.
2024-09-24 15:59:58.437 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 15:59:58.437 | Socket (2) | Closed.
2024-09-24 15:59:58.870 | ESZ4.CME [CBV][M] 60 Min #8 | Chart data loading complete.
2024-09-24 16:00:00.979 | HD Request # 5 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 16:00:00.980 | HD Request # 5 | Download start date-time: 2024-09-24 15:57:11.000000. File last date-time: 2024-09-24 15:57:11.243000
2024-09-24 16:00:00.980 | HD Request # 5 | Using server: ds32.sierracharts.com port 10150
2024-09-24 16:00:00.980 | Socket (2) | Creating socket.
2024-09-24 16:00:00.980 | Socket (2) | New receive buffer size: 0
2024-09-24 16:00:00.980 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 16:00:01.532 | HD Request # 5 | Setting DTC encoding to Binary VLS
2024-09-24 16:00:01.532 | HD Request # 5 | Sending historical data logon request message.
2024-09-24 16:00:02.284 | HD Request # 5 | Requesting Intraday data. Start date-time: 2024-09-24 15:57:11. Record interval: 0. Symbol: NQZ24
2024-09-24 16:00:02.553 | HD Request # 5 | Decompressing data.
2024-09-24 16:00:02.833 | HD Request # 5 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 15:57:11.014000
2024-09-24 16:00:03.104 | Socket (2) | CloseSocket call.
2024-09-24 16:00:03.104 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 16:00:03.129 | Historical data download thread signaled to stop.
2024-09-24 16:00:03.129 | HD Request # 5 | Timestamp of first Intraday data file record written: 2024-09-24 15:57:11.360000.
2024-09-24 16:00:03.129 | HD Request # 5 | Received 7763 Intraday data records from 2024-09-24 15:57:11.014000 to 2024-09-24 16:00:04.455007 (2.9 minutes. Delay: -1.3 seconds) and wrote 7756 records for NQZ4.CME
2024-09-24 16:00:03.130 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:00:04.455007
2024-09-24 16:00:03.130 | HD Request # 5 | Completion time: 3s.
2024-09-24 16:00:03.130 | HD Request # 5 | Intraday data download complete for NQZ4.CME. Unique request ID: 4
2024-09-24 16:00:03.130 | Removing historical data download ID 4.
2024-09-24 16:00:03.130 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 16:00:03.130 | Intraday chart data file opened for NQZ4.CME
2024-09-24 16:00:03.130 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2024-09-24 16:00:03.130 | Triggering next historical data download in queue.
2024-09-24 16:00:03.130 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:00:03.130 | HD Request # 6 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 16:00:03.130 | HD Request # 6 | Download start date-time: 2024-09-24 15:57:15.000000. File last date-time: 2024-09-24 15:57:15.310003
2024-09-24 16:00:03.130 | HD Request # 6 | Using server: ds32.sierracharts.com port 10149
2024-09-24 16:00:03.130 | Socket (4) | Creating socket.
2024-09-24 16:00:03.130 | Socket (4) | New receive buffer size: 0
2024-09-24 16:00:03.130 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 16:00:03.130 | NQZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:03.130 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 16:00:03.200 | NQZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:03.202 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 16:00:03.293 | NQZ4.CME [CBV] 60 Min #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:03.294 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-24 16:00:03.373 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 16:00:03.373 | Socket (2) | Closed.
2024-09-24 16:00:03.378 | NQZ4.CME [CBV] 60 Min #11 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:03.378 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-24 16:00:03.424 | NQZ4.CME [CBV] 1 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:03.425 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-24 16:00:03.441 | NQZ4.CME [CBV] 15 Min #1 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:03.442 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-24 16:00:03.539 | NQZ4.CME [CBV] 5 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:03.539 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-24 16:00:03.570 | NQZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:03.571 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 16:00:03.601 | NQZ4.CME [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:03.604 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-24 16:00:03.693 | HD Request # 6 | Setting DTC encoding to Binary VLS
2024-09-24 16:00:03.693 | HD Request # 6 | Sending historical data logon request message.
2024-09-24 16:00:03.766 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 16:00:03.971 | HD Request # 6 | Requesting Intraday data. Start date-time: 2024-09-24 15:57:15. Record interval: 0. Symbol: MNQZ24
2024-09-24 16:00:04.088 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 16:00:04.248 | HD Request # 6 | Decompressing data.
2024-09-24 16:00:04.437 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-24 16:00:04.535 | HD Request # 6 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 15:57:15.047000
2024-09-24 16:00:04.744 | NQZ4.CME [CBV] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2024-09-10 16:00:04
2024-09-24 16:00:04.806 | NQZ4.CME [CBV] 5 Min #15 | Chart data loading complete.
2024-09-24 16:00:04.815 | Socket (4) | CloseSocket call.
2024-09-24 16:00:04.815 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 16:00:04.867 | Historical data download thread signaled to stop.
2024-09-24 16:00:04.868 | HD Request # 6 | Timestamp of first Intraday data file record written: 2024-09-24 15:57:15.472000.
2024-09-24 16:00:04.868 | HD Request # 6 | Received 7167 Intraday data records from 2024-09-24 15:57:15.047000 to 2024-09-24 16:00:04.429000 (2.8 minutes. Delay: 0.4 seconds) and wrote 7158 records for MNQZ4.CME
2024-09-24 16:00:04.869 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:00:04.429000
2024-09-24 16:00:04.869 | HD Request # 6 | Completion time: 1s.
2024-09-24 16:00:04.869 | HD Request # 6 | Intraday data download complete for MNQZ4.CME. Unique request ID: 5
2024-09-24 16:00:04.869 | Removing historical data download ID 5.
2024-09-24 16:00:04.869 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 16:00:04.869 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 16:00:04.869 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2024-09-24 16:00:04.869 | No download requests in the queue to start downloads for.
2024-09-24 16:00:04.869 | Historical data for MNQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:00:04.872 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-24 16:00:05.027 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-24 16:00:05.075 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-24 16:00:05.089 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 16:00:05.089 | Socket (4) | Closed.
2024-09-24 16:00:05.357 | MNQZ4.CME [CBV] 1 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:00:05.358 | MNQZ4.CME [CBV] 1 Min #10 | Reloading chart.
2024-09-24 16:00:05.373 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-24 16:00:05.423 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 16:00:05.493 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-24 16:00:05.859 | MNQZ4.CME [CBV] 1 Min #10 | Reloading chart.
2024-09-24 16:00:06.207 | NQZ4.CME [CBV][M] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2024-09-10 16:00:04
2024-09-24 16:00:06.238 | NQZ4.CME [CBV][M] 5 Min #15 | Chart data loading complete.
2024-09-24 16:00:06.336 | NQZ4.CME [CBV][M] 1 Min #8 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-24 16:00:06.366 | NQZ4.CME [CBV][M] 1 Min #8 | Chart data loading complete.
2024-09-24 16:00:06.847 | MNQZ4.CME [CBV][M] 1 Min #10 | StartDateTimeForLoadingOrderFills: 2024-09-10 16:00:04
2024-09-24 16:00:06.852 | MNQZ4.CME [CBV][M] 1 Min #10 | Chart data loading complete.
2024-09-24 16:00:15.300 | NQZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-24 16:00:15.498 | ESZ4.CME [CBV][M] 60 Min #15 | Chart data loading complete.
2024-09-24 16:00:18.831 | NQZ4.CME [CBV][M] #16 | Chart data loading complete.
2024-09-24 16:00:18.873 | DTC Client socket (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 16:00:18.895 | DTC Client socket (3) | CloseSocket call.
2024-09-24 16:00:18.895 | Denali Data Feed | Failed connections: 4
2024-09-24 16:00:18.895 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:00:18.895 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:00:18.895 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:00:18.895 | DTC Client socket (3) | Closed.
2024-09-24 16:00:21.900 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:00:21.901 | DTC Client socket (2) | Creating socket.
2024-09-24 16:00:21.901 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 16:00:21.901 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 16:00:29.261 | NQZ4.CME [CBV][M] 60 Min #11 | StartDateTimeForLoadingOrderFills: 2023-11-29 16:00:00
2024-09-24 16:00:29.413 | NQZ4.CME [CBV][M] 60 Min #11 | Chart data loading complete.
2024-09-24 16:00:34.193 | NQZ4.CME [CBV][M] 60 Min #14 | Chart data loading complete.
2024-09-24 16:00:43.432 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 16:00:43.432 | DTC Client socket (2) | CloseSocket call.
2024-09-24 16:00:43.432 | Denali Data Feed | Failed connections: 5
2024-09-24 16:00:43.432 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:00:43.432 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:00:43.432 | DTC Client socket (2) | Closed.
2024-09-24 16:00:43.432 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:00:46.431 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:00:46.432 | DTC Client socket (2) | Creating socket.
2024-09-24 16:00:46.432 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 16:00:46.432 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 16:00:47.784 | ESZ4.CME [CBV][M] #14 | Chart data loading complete.
2024-09-24 16:01:00.728 | NQZ4.CME [CBV][M] 15 Min #1 | Chart data loading complete.
2024-09-24 16:01:00.755 | ESZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-24 16:01:02.694 | NQZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-24 16:01:04.124 | ESZ4.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-24 16:01:04.241 | ESZ4.CME [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-24 16:01:04.805 | ESZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-24 16:01:05.682 | NQZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-24 16:01:07.470 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 16:01:07.479 | DTC Client socket (2) | CloseSocket call.
2024-09-24 16:01:07.479 | Denali Data Feed | Failed connections: 6
2024-09-24 16:01:07.479 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:01:07.479 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:01:07.479 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:01:07.479 | DTC Client socket (2) | Closed.
2024-09-24 16:01:10.480 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:01:10.480 | DTC Client socket (2) | Creating socket.
2024-09-24 16:01:10.480 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 16:01:10.480 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 16:01:31.505 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 16:01:31.505 | DTC Client socket (2) | CloseSocket call.
2024-09-24 16:01:31.505 | DTC Client socket (2) | Closed.
2024-09-24 16:01:31.505 | Denali Data Feed | Failed connections: 7
2024-09-24 16:01:31.505 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:01:31.505 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:01:31.505 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:01:34.501 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:01:34.501 | DTC Client socket (2) | Creating socket.
2024-09-24 16:01:34.501 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 16:01:34.501 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
2024-09-24 16:01:55.540 | DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2024-09-24 16:01:55.540 | DTC Client socket (2) | CloseSocket call.
2024-09-24 16:01:55.540 | Denali Data Feed | Failed connections: 8
2024-09-24 16:01:55.540 | DTC Client socket (2) | Closed.
2024-09-24 16:01:55.540 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:01:55.540 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:01:55.540 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:01:58.531 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:01:58.531 | DTC Client socket (2) | Creating socket.
2024-09-24 16:01:58.531 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 16:01:58.531 | DTC Client socket (2) | Connecting to IP: 202.52.152.130.
[2024-09-24 20:24:21]
4th Update.
Checked firewall off, any other security issues that could hinder the data and all clear. I have been instructed in the past to use ds40.SierraCharts.com for my data feed. When I changed this back to ds13.SierraCharts.com the data on the DOM and time & sales appeared. I have changed this back to ds40.SierraCharts.com again and data is continuing to flow. I dont understand why this would stop or why me alternating back to ds13 then to ds40 again would allow the data to continue flowing.
Is there an issue along the server network somewhere?
2024-09-24 16:11:37.020 | Trade activity files set size: 2501
2024-09-24 16:11:37.045 | Created the DTC Protocol server.
2024-09-24 16:11:37.046 | DTC Protocol Server listening on port 11099.
2024-09-24 16:11:37.046 | Reading Internal Order ID file.
2024-09-24 16:11:37.079 | Reading Trade Orders file.
2024-09-24 16:11:37.080 | Reading Trade Positions file.
2024-09-24 16:11:37.080 | Reading Trade Account Data files.
2024-09-24 16:11:37.082 | NTP | Create NTP Client...
2024-09-24 16:11:37.082 | NTP | Start NTP Client Receive Thread.
2024-09-24 16:11:37.082 | NTP | Client | No privilege to gradual adjust system time. Set time will be used instead to step system time.
2024-09-24 16:11:37.082 | NTP | Client | Create NTP Client Service.
2024-09-24 16:11:37.082 | NTP | Client | Start NTP Client Service.
2024-09-24 16:11:37.082 | NTP | System Clock Adjustment is ENABLED! Disable it and switch to own Clock Adjustment.
2024-09-24 16:11:37.082 | NTP | Unable to get permission to adjust the system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2024-09-24 16:11:37.082 | NTP | Client | Cannot adjust System Clock. Cancel NTP Client Service starting.
2024-09-24 16:11:37.082 | NTP | Stop NTP Client...
2024-09-24 16:11:37.082 | NTP | NTP Client Stopped.
2024-09-24 16:11:37.082 | NTP | Unable to get permission to restore the system time: Failed to adjust privileges. Windows error code 1300: Not all privileges or groups referenced are assigned to the caller.
2024-09-24 16:11:37.082 | Software version: 2652 64-bit
2024-09-24 16:11:37.082 | Primary Thread ID: 11044
2024-09-24 16:11:37.082 | Usage end date: 2024-10-10
2024-09-24 16:11:37.082 | Enabled for: Advanced Features 2.
2024-09-24 16:11:37.082 | Enabled for: Sierra Chart Historical Data Service.
2024-09-24 16:11:37.082 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-09-24 16:11:37.082 | Enabled for: Delayed Denali Exchange Data Feed.
2024-09-24 16:11:37.082 | Enabled for exchange2: CME
2024-09-24 16:11:37.082 | Enabled for exchange2: COMEX
2024-09-24 16:11:37.082 | Enabled for exchange2: NYMEX
2024-09-24 16:11:37.082 | Enabled for exchange2: NASDAQ Global Indexes
2024-09-24 16:11:37.082 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-09-24 16:11:37.082 | Current selected Data/Trading service: Rithmic Direct - DTC
2024-09-24 16:11:37.082 | Custom symbol settings values: enabled
2024-09-24 16:11:37.082 | Chart Update Interval: 500
2024-09-24 16:11:37.082 | Intraday Data Storage Time Unit: 0
2024-09-24 16:11:37.082 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00)
2024-09-24 16:11:37.082 | 2024-09-24 20:11:37 Local computer time in UTC
2024-09-24 16:11:37.082 | 2024-09-24 16:11:37 Local computer time in SC Time Zone
2024-09-24 16:11:37.082 | 2024-09-24 20:11:37 Server time in UTC
2024-09-24 16:11:37.082 | Local computer UTC time and Server UTC time difference: 2 seconds.
2024-09-24 16:11:37.082 | Program path: C:\SierraChart - TopStep\
2024-09-24 16:11:37.082 | Data Files path: C:\SierraChart - TopStep\Data\
2024-09-24 16:11:37.082 | OS Version Number: 10.0
2024-09-24 16:11:37.082 | Locale Setting: C
2024-09-24 16:11:37.089 | DLLs: ICTMarketOpens_64.dll, UserContributedStudies_64.dll
2024-09-24 16:11:37.089 | Allowed protected custom studies:
2024-09-24 16:11:37.089 | Crash reporter started: true
2024-09-24 16:11:37.100 | Created the DTC Protocol historical data server.
2024-09-24 16:11:37.100 | HD Server Manager | Listening on port 11098.
2024-09-24 16:11:37.100 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2024-09-24 16:11:37.107 | Chat: Chat Window created. Connecting to server.
2024-09-24 16:11:37.108 | Chat | Connecting to the server chat2.sierracharts.com. Port 10065
2024-09-24 16:11:37.143 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2024-09-24 16:11:37.417 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2024-09-24 16:11:37.417 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2024-09-24 16:11:37.417 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2024-09-24 16:11:37.417 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2024-09-24 16:11:37.417 | DTC Client socket (6) | New receive buffer size: 0
2024-09-24 16:11:37.417 | DTC Client socket (6) | Connecting to IP: 69.39.70.248.
2024-09-24 16:11:37.570 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2024-09-24 16:11:37.570 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2024-09-24 16:11:37.741 | Chat | Network connection to server complete.
2024-09-24 16:11:37.741 | Chat | Starting socket receive thread.
2024-09-24 16:11:37.741 | Chat | Sending encoding request to server: Binary VLS. Compression: none
2024-09-24 16:11:38.402 | Received 5 login tokens.
2024-09-24 16:11:38.714 | Chat | Setting DTC encoding to Binary VLS
2024-09-24 16:11:38.714 | Chat | Sending logon request message.
2024-09-24 16:11:39.483 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2024-09-24 16:11:39.483 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2024-09-24 16:11:39.511 | Chat | Received logon response.
2024-09-24 16:11:39.511 | Chat | Server Name: SC DTC Server. Build=51186:51187.
2024-09-24 16:11:39.511 | Chat | Server protocol version: 8. Client protocol version: 8
2024-09-24 16:11:39.511 | Chat | Successfully connected. Connected to SC DTC Protocol server. Service=chat_server.data|SymbolSettings=chat_server.data.
2024-09-24 16:11:39.511 | Chat | Trading is not supported.
2024-09-24 16:11:39.511 | Chat | MarketDepthIsSupported: 1
2024-09-24 16:11:39.535 | Symbol settings MD5 received. Request ID: 1.
2024-09-24 16:11:39.535 | Symbol settings are up-to-date for rithmic_v2.trading.
2024-09-24 16:11:39.592 | Requested user files to download.
2024-09-24 16:11:39.814 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2024-09-24 16:11:39.814 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2024-09-24 16:11:41.599 |
2024-09-24 16:11:41.599 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 16:11:41.599 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 16:11:41.600 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 16:11:41.934 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2024-09-24 16:11:41.934 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 16:11:41.934 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2024-09-24 16:11:42.173 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 16:11:42.203 | Starting DelayedDownloadMonitoringTimer
2024-09-24 16:11:42.203 | Starting HDTimeoutTimer
2024-09-24 16:11:42.203 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 16:11:42.204 | Triggering next historical data download in queue.
2024-09-24 16:11:42.223 | ESZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 1,
2024-09-24 16:11:42.230 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-24 16:11:42.400 | ESZ4.CME [CBV] #14 | Waiting for historical downloads to complete with the IDs: 1,
2024-09-24 16:11:42.407 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 16:11:42.502 | ESZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 1,
2024-09-24 16:11:42.508 | ESZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-24 16:11:42.588 | ESZ4.CME [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 1,
2024-09-24 16:11:42.593 | ESZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-24 16:11:42.593 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:42.593 | ESZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:42.934 | ESZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-24 16:11:42.934 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:42.934 | ESZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:43.272 | ESZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-24 16:11:43.272 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:43.272 | ESZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:43.606 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 16:11:43.686 | ESZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 1,
2024-09-24 16:11:43.712 | ESZ4.CME 5 Min #12 | Reloading chart.
2024-09-24 16:11:43.728 | ESZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-24 16:11:43.738 | ESZ4.CME [CBV] 1 Min #17 | Waiting for historical downloads to complete with the IDs: 1,
2024-09-24 16:11:43.759 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-24 16:11:43.800 | ESZ4.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 1,
2024-09-24 16:11:43.823 | ESZ4.CME 5 Min #11 | Reloading chart.
2024-09-24 16:11:43.846 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-24 16:11:43.935 | ESZ4.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 1,
2024-09-24 16:11:43.959 | ESZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-24 16:11:44.086 | ESZ4.CME #9 | Reloading chart.
2024-09-24 16:11:44.086 | ESZ4.CME #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-24 16:11:44.093 | ESZ4.CME #9 | Chart data loading complete.
2024-09-24 16:11:44.107 | MESZ4.CME 30 Min #1 | Reloading chart.
2024-09-24 16:11:44.220 | MESZ4.CME #16 | Reloading chart.
2024-09-24 16:11:44.220 | MESZ4.CME #16 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-24 16:11:44.226 | MESZ4.CME #16 | Chart data loading complete.
2024-09-24 16:11:44.347 | MESZ4.CME #18 | Reloading chart.
2024-09-24 16:11:44.347 | MESZ4.CME #18 | StartDateTimeForLoadingOrderFills: 00:00:00
2024-09-24 16:11:44.353 | MESZ4.CME #18 | Chart data loading complete.
2024-09-24 16:11:44.363 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 16:11:44.363 | Using symbol data fast lookup vector
2024-09-24 16:11:44.363 | HD Request # 1 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 16:11:44.365 | HD Request # 1 | Download start date-time: 2024-09-24 16:08:07.000000. File last date-time: 2024-09-24 16:08:07.341000
2024-09-24 16:11:44.365 | HD Request # 1 | Using server: ds32.sierracharts.com port 10150
2024-09-24 16:11:44.366 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 16:11:44.366 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 16:11:44.366 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 16:11:44.366 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 16:11:44.371 | ESZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-24 16:11:44.373 | ESZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-24 16:11:44.375 | ESZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-24 16:11:44.408 | MESZ4.CME 30 Min #1 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-24 16:11:44.408 | MESZ4.CME 30 Min #1 | Chart data loading complete.
2024-09-24 16:11:44.428 | ESZ4.CME 5 Min #11 | StartDateTimeForLoadingOrderFills: 2024-09-10 16:08:07
2024-09-24 16:11:44.440 | ESZ4.CME 5 Min #11 | Chart data loading complete.
2024-09-24 16:11:44.487 | Socket (1) | Creating socket.
2024-09-24 16:11:44.487 | Socket (1) | New receive buffer size: 0
2024-09-24 16:11:44.487 | Socket (1) | Connecting to IP: 67.214.125.3.
2024-09-24 16:11:44.616 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 16:11:44.616 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 16:11:44.616 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 16:11:44.616 | Triggering next historical data download in queue.
2024-09-24 16:11:44.858 | ESZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 16:11:44.872 | ESZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-24 16:11:45.091 | ESZ4.CME[M] Rev. 16t-20 #13 | Chart data loading complete.
2024-09-24 16:11:45.188 | HD Request # 1 | Setting DTC encoding to Binary VLS
2024-09-24 16:11:45.188 | HD Request # 1 | Sending historical data logon request message.
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | Received logon response.
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | Server Name: .
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 16:11:45.503 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 16:11:45.503 | No download requests in the queue to start downloads for.
2024-09-24 16:11:45.503 | Triggering next historical data download in queue.
2024-09-24 16:11:45.503 | No download requests in the queue to start downloads for. | Number times message added: 1
2024-09-24 16:11:45.503 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 16:11:45.503 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 16:11:45.503 | Using symbol data fast lookup vector
2024-09-24 16:11:45.503 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 16:11:45.504 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:11:45.505 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 16:11:45.505 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 16:11:45.505 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 16:11:45.505 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 16:11:45.505 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 16:11:45.505 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 16:11:45.593 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 16:11:45.593 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 3 Service code: cme
2024-09-24 16:11:45.593 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 3
2024-09-24 16:11:45.608 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 16:11:45.608 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 4 Service code: cme
2024-09-24 16:11:45.608 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 4
2024-09-24 16:11:45.625 | DTC Client socket (3) | Creating socket.
2024-09-24 16:11:45.625 | DTC Client socket (3) | New receive buffer size: 0
2024-09-24 16:11:45.625 | DTC Client socket (3) | Connecting to IP: 202.52.152.130.
2024-09-24 16:11:45.746 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:11:45.746 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:11:45.746 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:11:45.999 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-09-24 16:08:07. Record interval: 0. Symbol: ESZ24
2024-09-24 16:11:46.325 | HD Request # 1 | Decompressing data.
2024-09-24 16:11:46.654 | HD Request # 1 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 16:08:07.337000
2024-09-24 16:11:46.654 | Socket (1) | CloseSocket call.
2024-09-24 16:11:46.654 | Socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 16:11:46.654 | Historical data download thread signaled to stop.
2024-09-24 16:11:46.655 | HD Request # 1 | Timestamp of first Intraday data file record written: 2024-09-24 16:08:07.747000.
2024-09-24 16:11:46.655 | HD Request # 1 | Received 1457 Intraday data records from 2024-09-24 16:08:07.337000 to 2024-09-24 16:11:45.016000 (3.6 minutes. Delay: 1.6 seconds) and wrote 1455 records for ESZ4.CME
2024-09-24 16:11:46.655 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:11:45.016000
2024-09-24 16:11:46.655 | HD Request # 1 | Completion time: 2s.
2024-09-24 16:11:46.655 | HD Request # 1 | Intraday data download complete for ESZ4.CME. Unique request ID: 1
2024-09-24 16:11:46.655 | Removing historical data download ID 1.
2024-09-24 16:11:46.655 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 16:11:46.655 | Intraday chart data file opened for ESZ4.CME
2024-09-24 16:11:46.655 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2024-09-24 16:11:46.655 | Triggering next historical data download in queue.
2024-09-24 16:11:46.655 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:11:46.655 | Delaying start of download for MESZ4.CME.
2024-09-24 16:11:46.684 | ESZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:11:46.684 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 16:11:46.740 | ESZ4.CME [CBV] #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:11:46.740 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-24 16:11:46.817 | ESZ4.CME [CBV] 1 Min #17 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:11:46.817 | ESZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-24 16:11:46.830 | ESZ4.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:11:46.830 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-24 16:11:46.885 | ESZ4.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:11:46.885 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-24 16:11:46.971 | ESZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:11:46.971 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 16:11:46.986 | Socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:11:46.986 | Socket (1) | Closed.
2024-09-24 16:11:47.077 | ESZ4.CME [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:11:47.077 | ESZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-24 16:11:47.178 | ESZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:11:47.179 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 16:11:47.282 | ESZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 16:11:47.340 | ESZ4.CME [CBV] #14 | Reloading chart.
2024-09-24 16:11:47.585 | ESZ4.CME [CBV] 1 Min #17 | Reloading chart.
2024-09-24 16:11:47.617 | ESZ4.CME [CBV] 60 Min #8 | Reloading chart.
2024-09-24 16:11:47.736 | ESZ4.CME [CBV] 15 Min #10 | Reloading chart.
2024-09-24 16:11:47.965 | ESZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 16:11:48.200 | ESZ4.CME [CBV] 60 Min #15 | Reloading chart.
2024-09-24 16:11:48.684 | ESZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 16:11:49.929 | ESZ4.CME [CBV][M] 1 Min #17 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-24 16:11:49.944 | ESZ4.CME [CBV][M] 1 Min #17 | Chart data loading complete.
2024-09-24 16:11:50.532 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 16:11:50.532 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 16:11:52.579 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 16:11:52.596 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 16:11:52.596 | Triggering next historical data download in queue.
2024-09-24 16:11:52.621 | NQZ4.CME [CBV] 240 Min #2 | Waiting for historical downloads to complete with the IDs: 3,
2024-09-24 16:11:52.629 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-24 16:11:52.671 | NQZ4.CME [CBV] #16 | Waiting for historical downloads to complete with the IDs: 3,
2024-09-24 16:11:52.700 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 16:11:52.860 | NQZ4.CME [CBV] #3 | Waiting for historical downloads to complete with the IDs: 3,
2024-09-24 16:11:52.868 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-24 16:11:52.977 | NQZ4.CME [CBV] 60 Min #14 | Waiting for historical downloads to complete with the IDs: 3,
2024-09-24 16:11:52.985 | NQZ4.CME [CBV] Monthly #4 | Reloading chart.
2024-09-24 16:11:52.985 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:52.985 | NQZ4.CME [CBV] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:53.402 | NQZ4.CME [CBV] Weekly #5 | Reloading chart.
2024-09-24 16:11:53.402 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:53.402 | NQZ4.CME [CBV] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:53.820 | NQZ4.CME [CBV] Daily #6 | Reloading chart.
2024-09-24 16:11:53.820 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:53.820 | NQZ4.CME [CBV] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:11:54.259 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-24 16:11:54.311 | NQZ4.CME [CBV] 60 Min #11 | Waiting for historical downloads to complete with the IDs: 3,
2024-09-24 16:11:54.340 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-24 16:11:54.454 | NQZ4.CME [CBV] 15 Min #1 | Waiting for historical downloads to complete with the IDs: 3,
2024-09-24 16:11:54.485 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-24 16:11:54.499 | NQZ4.CME [CBV] 5 Min #15 | Waiting for historical downloads to complete with the IDs: 3,
2024-09-24 16:11:54.627 | MNQZ4.CME #9 | Reloading chart.
2024-09-24 16:11:54.665 | NQZ4.CME Rev. 16t-20 #13 | Reloading chart.
2024-09-24 16:11:54.685 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 16:11:54.813 | NQZ4.CME [CBV] 240 Min #7 | Waiting for historical downloads to complete with the IDs: 3,
2024-09-24 16:11:54.823 | NQZ4.CME 5 Min #12 | Reloading chart.
2024-09-24 16:11:54.873 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-24 16:11:54.890 | NQZ4.CME [CBV] 1 Min #8 | Waiting for historical downloads to complete with the IDs: 3,
2024-09-24 16:11:55.064 | MNQZ4.CME [CBV] 1 Min #10 | Reloading chart.
2024-09-24 16:11:55.104 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 16:11:55.118 | MNQZ4.CME [CBV] 1 Min #10 | Waiting for historical downloads to complete with the IDs: 4,
2024-09-24 16:11:55.163 | NQZ4.CME [CBV] Monthly #4 | Chart data loading complete.
2024-09-24 16:11:55.167 | NQZ4.CME [CBV] Weekly #5 | Chart data loading complete.
2024-09-24 16:11:55.172 | NQZ4.CME [CBV] Daily #6 | Chart data loading complete.
2024-09-24 16:11:55.180 | MNQZ4.CME #9 | StartDateTimeForLoadingOrderFills: 2024-09-10 16:08:11
2024-09-24 16:11:55.181 | MNQZ4.CME #9 | Chart data loading complete.
2024-09-24 16:11:55.260 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 16:11:55.260 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 5 Service code: cme
2024-09-24 16:11:55.260 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 5
2024-09-24 16:11:55.264 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 16:11:55.264 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 6 Service code: cme
2024-09-24 16:11:55.264 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 6
2024-09-24 16:11:55.493 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 16:11:55.595 | NQZ4.CME[M] Rev. 16t-20 #13 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:22
2024-09-24 16:11:55.655 | NQZ4.CME[M] Rev. 16t-20 #13 | Chart data loading complete.
2024-09-24 16:11:55.718 | NQZ4.CME[M] 5 Min #12 | StartDateTimeForLoadingOrderFills: 2024-08-29 20:00:00
2024-09-24 16:11:55.729 | NQZ4.CME[M] 5 Min #12 | Chart data loading complete.
2024-09-24 16:11:57.412 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-09-24 16:11:57.412 | DTC Client socket (3) | CloseSocket call.
2024-09-24 16:11:57.412 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:11:57.412 | DTC Client socket (3) | Closed.
2024-09-24 16:11:57.412 | Denali Data Feed | Failed connections: 1
2024-09-24 16:11:57.412 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:11:57.412 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:11:57.412 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:11:57.412 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:12:00.155 | ESZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-24 16:12:00.535 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:12:00.536 | DTC Client socket (1) | Creating socket.
2024-09-24 16:12:00.536 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:12:00.536 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:12:00.657 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:12:00.657 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:12:00.657 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:12:01.587 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2.
2024-09-24 16:12:01.587 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | New receive buffer size: 0
2024-09-24 16:12:01.587 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Connecting to IP: 216.66.0.130.
2024-09-24 16:12:03.634 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | CloseSocket call.
2024-09-24 16:12:03.634 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Shutdown started. Waiting for graceful close.
2024-09-24 16:12:03.967 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side.
2024-09-24 16:12:03.967 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Closed.
2024-09-24 16:12:10.453 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:12:10.453 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:12:10.453 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:12:10.453 | DTC Client socket (1) | Closed.
2024-09-24 16:12:10.453 | Denali Data Feed | Failed connections: 2
2024-09-24 16:12:10.453 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:12:10.453 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:12:10.453 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:12:10.453 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:12:13.449 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:12:13.449 | DTC Client socket (1) | Creating socket.
2024-09-24 16:12:13.449 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:12:13.449 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:12:13.570 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:12:13.570 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:12:13.570 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:12:14.775 | ESZ4.CME [CBV][M] 60 Min #8 | Chart data loading complete.
2024-09-24 16:12:16.237 | HD Request # 2 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 16:12:16.238 | HD Request # 2 | Download start date-time: 2024-09-24 16:08:08.000000. File last date-time: 2024-09-24 16:08:08.663000
2024-09-24 16:12:16.238 | HD Request # 2 | Using server: ds32.sierracharts.com port 10149
2024-09-24 16:12:16.238 | Socket (3) | Creating socket.
2024-09-24 16:12:16.238 | Socket (3) | New receive buffer size: 0
2024-09-24 16:12:16.238 | Socket (3) | Connecting to IP: 67.214.125.3.
2024-09-24 16:12:16.899 | HD Request # 2 | Setting DTC encoding to Binary VLS
2024-09-24 16:12:16.899 | HD Request # 2 | Sending historical data logon request message.
2024-09-24 16:12:17.717 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-09-24 16:08:08. Record interval: 0. Symbol: MESZ24
2024-09-24 16:12:18.042 | HD Request # 2 | Decompressing data.
2024-09-24 16:12:18.368 | HD Request # 2 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 16:08:08.415000
2024-09-24 16:12:18.369 | Socket (3) | CloseSocket call.
2024-09-24 16:12:18.369 | Socket (3) | Shutdown started. Waiting for graceful close.
2024-09-24 16:12:18.369 | Historical data download thread signaled to stop.
2024-09-24 16:12:18.369 | HD Request # 2 | Timestamp of first Intraday data file record written: 2024-09-24 16:08:12.957000.
2024-09-24 16:12:18.369 | HD Request # 2 | Received 443 Intraday data records from 2024-09-24 16:08:08.415000 to 2024-09-24 16:12:16.086001 (4.1 minutes. Delay: 2.3 seconds) and wrote 435 records for MESZ4.CME
2024-09-24 16:12:18.369 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:12:16.086001
2024-09-24 16:12:18.369 | HD Request # 2 | Completion time: 2s.
2024-09-24 16:12:18.369 | HD Request # 2 | Intraday data download complete for MESZ4.CME. Unique request ID: 2
2024-09-24 16:12:18.369 | Removing historical data download ID 2.
2024-09-24 16:12:18.369 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 16:12:18.369 | Intraday chart data file opened for MESZ4.CME
2024-09-24 16:12:18.369 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2024-09-24 16:12:18.369 | Triggering next historical data download in queue.
2024-09-24 16:12:18.369 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:12:18.369 | Delaying start of download for NQZ4.CME.
2024-09-24 16:12:18.692 | Socket (3) | Socket gracefully closed by remote side.
2024-09-24 16:12:18.692 | Socket (3) | Closed.
2024-09-24 16:12:23.341 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:12:23.341 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:12:23.341 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:12:23.341 | DTC Client socket (1) | Closed.
2024-09-24 16:12:23.341 | Denali Data Feed | Failed connections: 3
2024-09-24 16:12:23.342 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:12:23.342 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:12:23.342 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:12:23.342 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:12:25.330 | ESZ4.CME [CBV][M] 60 Min #15 | Chart data loading complete.
2024-09-24 16:12:26.278 | HD Request # 3 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 16:12:26.278 | HD Request # 3 | Download start date-time: 2024-09-24 16:08:06.000000. File last date-time: 2024-09-24 16:08:06.596001
2024-09-24 16:12:26.278 | HD Request # 3 | Using server: ds32.sierracharts.com port 10150
2024-09-24 16:12:26.278 | Socket (1) | Creating socket.
2024-09-24 16:12:26.278 | Socket (1) | New receive buffer size: 0
2024-09-24 16:12:26.278 | Socket (1) | Connecting to IP: 67.214.125.3.
2024-09-24 16:12:26.342 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:12:26.342 | DTC Client socket (3) | Creating socket.
2024-09-24 16:12:26.342 | DTC Client socket (3) | New receive buffer size: 0
2024-09-24 16:12:26.342 | DTC Client socket (3) | Connecting to IP: 202.52.152.130.
2024-09-24 16:12:26.463 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:12:26.463 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:12:26.463 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:12:26.952 | HD Request # 3 | Setting DTC encoding to Binary VLS
2024-09-24 16:12:26.952 | HD Request # 3 | Sending historical data logon request message.
2024-09-24 16:12:27.765 | HD Request # 3 | Requesting Intraday data. Start date-time: 2024-09-24 16:08:06. Record interval: 0. Symbol: NQZ24
2024-09-24 16:12:28.111 | HD Request # 3 | Decompressing data.
2024-09-24 16:12:28.437 | HD Request # 3 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 16:08:06.596000
2024-09-24 16:12:28.438 | Socket (1) | CloseSocket call.
2024-09-24 16:12:28.438 | Historical data download thread signaled to stop.
2024-09-24 16:12:28.438 | Socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 16:12:28.438 | HD Request # 3 | Timestamp of first Intraday data file record written: 2024-09-24 16:08:08.088000.
2024-09-24 16:12:28.438 | HD Request # 3 | Received 837 Intraday data records from 2024-09-24 16:08:06.596000 to 2024-09-24 16:12:28.917000 (4.4 minutes. Delay: -0.5 seconds) and wrote 835 records for NQZ4.CME
2024-09-24 16:12:28.438 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:12:28.917000
2024-09-24 16:12:28.438 | HD Request # 3 | Completion time: 2s.
2024-09-24 16:12:28.438 | HD Request # 3 | Intraday data download complete for NQZ4.CME. Unique request ID: 3
2024-09-24 16:12:28.438 | Removing historical data download ID 3.
2024-09-24 16:12:28.438 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 16:12:28.438 | Intraday chart data file opened for NQZ4.CME
2024-09-24 16:12:28.438 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2024-09-24 16:12:28.438 | Triggering next historical data download in queue.
2024-09-24 16:12:28.438 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:12:28.438 | HD Request # 4 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 16:12:28.439 | HD Request # 4 | Download start date-time: 2024-09-24 16:08:11.000000. File last date-time: 2024-09-24 16:08:11.563000
2024-09-24 16:12:28.439 | HD Request # 4 | Using server: ds32.sierracharts.com port 10149
2024-09-24 16:12:28.439 | Socket (4) | Creating socket.
2024-09-24 16:12:28.439 | Socket (4) | New receive buffer size: 0
2024-09-24 16:12:28.439 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 16:12:28.541 | NQZ4.CME [CBV] 5 Min #15 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:28.541 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-24 16:12:28.573 | NQZ4.CME [CBV] 240 Min #2 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:28.573 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 16:12:28.668 | NQZ4.CME [CBV] #16 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:28.669 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-24 16:12:28.706 | NQZ4.CME [CBV] 240 Min #7 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:28.706 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 16:12:28.763 | Socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:12:28.763 | Socket (1) | Closed.
2024-09-24 16:12:28.779 | NQZ4.CME [CBV] #3 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:28.779 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 16:12:28.844 | NQZ4.CME [CBV] 60 Min #11 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:28.845 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-24 16:12:28.891 | NQZ4.CME [CBV] 15 Min #1 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:28.891 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-24 16:12:28.961 | NQZ4.CME [CBV] 1 Min #8 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:28.961 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-24 16:12:28.975 | NQZ4.CME [CBV] 60 Min #14 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:28.975 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-24 16:12:29.053 | NQZ4.CME [CBV] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2024-09-10 16:12:28
2024-09-24 16:12:29.078 | NQZ4.CME [CBV] 5 Min #15 | Chart data loading complete.
2024-09-24 16:12:29.103 | HD Request # 4 | Setting DTC encoding to Binary VLS
2024-09-24 16:12:29.103 | HD Request # 4 | Sending historical data logon request message.
2024-09-24 16:12:29.110 | NQZ4.CME [CBV] 5 Min #15 | Reloading chart.
2024-09-24 16:12:29.141 | NQZ4.CME [CBV] 240 Min #2 | Reloading chart.
2024-09-24 16:12:29.193 | NQZ4.CME [CBV] #16 | Reloading chart.
2024-09-24 16:12:29.273 | NQZ4.CME [CBV] 240 Min #7 | Reloading chart.
2024-09-24 16:12:29.429 | HD Request # 4 | Requesting Intraday data. Start date-time: 2024-09-24 16:08:11. Record interval: 0. Symbol: MNQZ24
2024-09-24 16:12:29.512 | NQZ4.CME [CBV] #3 | Reloading chart.
2024-09-24 16:12:29.740 | NQZ4.CME [CBV] 60 Min #11 | Reloading chart.
2024-09-24 16:12:29.754 | HD Request # 4 | Decompressing data.
2024-09-24 16:12:29.855 | NQZ4.CME [CBV] 5 Min #15 | StartDateTimeForLoadingOrderFills: 2024-09-10 16:12:28
2024-09-24 16:12:29.885 | NQZ4.CME [CBV] 5 Min #15 | Chart data loading complete.
2024-09-24 16:12:29.925 | NQZ4.CME [CBV] 15 Min #1 | Reloading chart.
2024-09-24 16:12:30.082 | HD Request # 4 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 16:08:11.199000
2024-09-24 16:12:30.082 | Socket (4) | CloseSocket call.
2024-09-24 16:12:30.082 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 16:12:30.148 | Historical data download thread signaled to stop.
2024-09-24 16:12:30.148 | HD Request # 4 | Timestamp of first Intraday data file record written: 2024-09-24 16:08:12.867000.
2024-09-24 16:12:30.148 | HD Request # 4 | Received 1150 Intraday data records from 2024-09-24 16:08:11.199000 to 2024-09-24 16:12:28.855001 (4.3 minutes. Delay: 1.3 seconds) and wrote 1143 records for MNQZ4.CME
2024-09-24 16:12:30.149 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:12:28.855001
2024-09-24 16:12:30.149 | HD Request # 4 | Completion time: 2s.
2024-09-24 16:12:30.149 | HD Request # 4 | Intraday data download complete for MNQZ4.CME. Unique request ID: 4
2024-09-24 16:12:30.149 | Removing historical data download ID 4.
2024-09-24 16:12:30.149 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 16:12:30.149 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 16:12:30.149 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2024-09-24 16:12:30.149 | No download requests in the queue to start downloads for.
2024-09-24 16:12:30.149 | Historical data for MNQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:12:30.151 | NQZ4.CME [CBV] 60 Min #14 | Reloading chart.
2024-09-24 16:12:30.378 | NQZ4.CME [CBV] 1 Min #8 | Reloading chart.
2024-09-24 16:12:30.407 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 16:12:30.407 | Socket (4) | Closed.
2024-09-24 16:12:30.415 | MNQZ4.CME [CBV] 1 Min #10 | Download is complete for all contract months in chart. Proceeding with data load.
2024-09-24 16:12:30.416 | MNQZ4.CME [CBV] 1 Min #10 | Reloading chart. | Number times message added: 1
2024-09-24 16:12:31.208 | NQZ4.CME [CBV][M] 1 Min #8 | StartDateTimeForLoadingOrderFills: 2024-08-25 18:00:00
2024-09-24 16:12:31.264 | NQZ4.CME [CBV][M] 1 Min #8 | Chart data loading complete.
2024-09-24 16:12:31.598 | MNQZ4.CME [CBV][M] 1 Min #10 | StartDateTimeForLoadingOrderFills: 2024-09-10 16:12:28
2024-09-24 16:12:31.603 | MNQZ4.CME [CBV][M] 1 Min #10 | Chart data loading complete.
2024-09-24 16:12:38.001 | NQZ4.CME [CBV][M] 240 Min #2 | Chart data loading complete.
2024-09-24 16:12:38.931 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-09-24 16:12:38.931 | DTC Client socket (3) | CloseSocket call.
2024-09-24 16:12:38.931 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:12:38.931 | DTC Client socket (3) | Closed.
2024-09-24 16:12:38.931 | Denali Data Feed | Failed connections: 4
2024-09-24 16:12:38.931 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:12:38.931 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:12:38.931 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:12:38.931 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:12:41.133 | NQZ4.CME [CBV][M] #16 | Chart data loading complete.
2024-09-24 16:12:41.944 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:12:41.944 | DTC Client socket (1) | Creating socket.
2024-09-24 16:12:41.944 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:12:41.944 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:12:42.066 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:12:42.066 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:12:42.066 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:12:50.676 | NQZ4.CME [CBV][M] 60 Min #11 | StartDateTimeForLoadingOrderFills: 2023-11-29 16:00:00
2024-09-24 16:12:50.807 | NQZ4.CME [CBV][M] 60 Min #11 | Chart data loading complete.
2024-09-24 16:12:52.697 | ESZ4.CME [CBV][M] #14 | Chart data loading complete.
2024-09-24 16:12:54.544 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:12:54.544 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:12:54.544 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:12:54.544 | DTC Client socket (1) | Closed.
2024-09-24 16:12:54.544 | Denali Data Feed | Failed connections: 5
2024-09-24 16:12:54.544 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:12:54.544 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:12:54.544 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:12:54.544 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:12:55.685 | NQZ4.CME [CBV][M] 60 Min #14 | Chart data loading complete.
2024-09-24 16:12:57.541 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:12:57.542 | DTC Client socket (1) | Creating socket.
2024-09-24 16:12:57.542 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:12:57.542 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:12:57.663 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:12:57.663 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:12:57.663 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:13:02.517 | ESZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-24 16:13:05.011 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:13:05.011 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:13:05.011 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:13:05.011 | DTC Client socket (1) | Closed.
2024-09-24 16:13:05.011 | Denali Data Feed | Failed connections: 6
2024-09-24 16:13:05.011 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:13:05.011 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:13:05.011 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:13:05.011 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:13:05.213 | ESZ4.CME [CBV][M] 15 Min #10 | StartDateTimeForLoadingOrderFills: 2022-07-17 18:00:00
2024-09-24 16:13:05.301 | ESZ4.CME [CBV][M] 15 Min #10 | Chart data loading complete.
2024-09-24 16:13:06.188 | ESZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-24 16:13:08.006 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:13:08.006 | DTC Client socket (1) | Creating socket.
2024-09-24 16:13:08.006 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:13:08.006 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:13:08.139 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:13:08.139 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:13:08.139 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:13:14.165 | NQZ4.CME [CBV][M] 15 Min #1 | Chart data loading complete.
2024-09-24 16:13:14.478 | NQZ4.CME [CBV][M] 240 Min #7 | Chart data loading complete.
2024-09-24 16:13:17.013 | NQZ4.CME [CBV][M] #3 | Chart data loading complete.
2024-09-24 16:13:17.901 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:13:17.911 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:13:17.911 | Denali Data Feed | Failed connections: 7
2024-09-24 16:13:17.911 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:13:17.911 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:13:17.911 | DTC Client socket (1) | Closed.
2024-09-24 16:13:17.911 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:13:17.911 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:13:17.911 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:13:20.914 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:13:20.914 | DTC Client socket (1) | Creating socket.
2024-09-24 16:13:20.914 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:13:20.914 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:13:21.035 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:13:21.035 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:13:21.035 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:13:30.700 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:13:30.700 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:13:30.701 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:13:30.701 | DTC Client socket (1) | Closed.
2024-09-24 16:13:30.701 | Denali Data Feed | Failed connections: 8
2024-09-24 16:13:30.701 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:13:30.701 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:13:30.701 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:13:30.701 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:13:33.702 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:13:33.702 | DTC Client socket (1) | Creating socket.
2024-09-24 16:13:33.702 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:13:33.702 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:13:33.823 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:13:33.823 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:13:33.823 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:13:43.420 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:13:43.422 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:13:43.422 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:13:43.422 | DTC Client socket (1) | Closed.
2024-09-24 16:13:43.422 | Denali Data Feed | Failed connections: 9
2024-09-24 16:13:43.422 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:13:43.422 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:13:43.422 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:13:43.422 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:13:46.425 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:13:46.425 | DTC Client socket (1) | Creating socket.
2024-09-24 16:13:46.425 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:13:46.425 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:13:46.546 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:13:46.546 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:13:46.546 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:13:56.130 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:13:56.131 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:13:56.131 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:13:56.131 | DTC Client socket (1) | Closed.
2024-09-24 16:13:56.131 | Denali Data Feed | Failed connections: 10
2024-09-24 16:13:56.131 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:13:56.131 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:13:56.131 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:13:56.131 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:13:59.119 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:13:59.119 | DTC Client socket (1) | Creating socket.
2024-09-24 16:13:59.119 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:13:59.119 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:13:59.240 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:13:59.240 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:13:59.240 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:14:08.861 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:14:08.861 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:14:08.861 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:14:08.861 | DTC Client socket (1) | Closed.
2024-09-24 16:14:08.861 | Denali Data Feed | Failed connections: 11
2024-09-24 16:14:08.861 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:14:08.861 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:14:08.861 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:14:08.861 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:14:11.852 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:14:11.852 | DTC Client socket (1) | Creating socket.
2024-09-24 16:14:11.852 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:14:11.852 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:14:11.972 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:14:11.972 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:14:11.972 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:14:24.460 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:14:24.460 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:14:24.460 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:14:24.460 | DTC Client socket (1) | Closed.
2024-09-24 16:14:24.460 | Denali Data Feed | Failed connections: 12
2024-09-24 16:14:24.460 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:14:24.460 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:14:24.460 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:14:24.460 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:14:27.460 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:14:27.461 | DTC Client socket (1) | Creating socket.
2024-09-24 16:14:27.461 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:14:27.461 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:14:27.581 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:14:27.581 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:14:27.581 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:14:37.969 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:14:37.979 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:14:37.979 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:14:37.979 | DTC Client socket (1) | Closed.
2024-09-24 16:14:37.979 | Denali Data Feed | Failed connections: 13
2024-09-24 16:14:37.979 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:14:37.979 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:14:37.979 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:14:37.979 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:14:40.990 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:14:40.990 | DTC Client socket (1) | Creating socket.
2024-09-24 16:14:40.990 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:14:40.990 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:14:41.113 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:14:41.113 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:14:41.113 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:14:50.780 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:14:50.780 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:14:50.780 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:14:50.780 | DTC Client socket (1) | Closed.
2024-09-24 16:14:50.780 | Denali Data Feed | Failed connections: 14
2024-09-24 16:14:50.780 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:14:50.780 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:14:50.780 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:14:50.780 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:14:53.779 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:14:53.779 | DTC Client socket (1) | Creating socket.
2024-09-24 16:14:53.779 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:14:53.779 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:14:53.900 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:14:53.900 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:14:53.900 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:15:03.409 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:15:03.409 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:15:03.409 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:15:03.409 | DTC Client socket (1) | Closed.
2024-09-24 16:15:03.409 | Denali Data Feed | Failed connections: 15
2024-09-24 16:15:03.409 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:15:03.409 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:15:03.409 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:15:03.409 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:15:06.411 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:15:06.411 | DTC Client socket (1) | Creating socket.
2024-09-24 16:15:06.411 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:15:06.411 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:15:06.533 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:15:06.533 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:15:06.533 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:15:16.129 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:15:16.129 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:15:16.129 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:15:16.129 | DTC Client socket (1) | Closed.
2024-09-24 16:15:16.129 | Denali Data Feed | Failed connections: 16
2024-09-24 16:15:16.129 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:15:16.129 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:15:16.129 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:15:16.129 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:15:19.119 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:15:19.119 | DTC Client socket (1) | Creating socket.
2024-09-24 16:15:19.119 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:15:19.119 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:15:19.239 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:15:19.239 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:15:19.239 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:15:29.089 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:15:29.089 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:15:29.089 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:15:29.089 | DTC Client socket (1) | Closed.
2024-09-24 16:15:29.089 | Denali Data Feed | Failed connections: 17
2024-09-24 16:15:29.089 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:15:29.089 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:15:29.089 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:15:29.089 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:15:32.093 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:15:32.093 | DTC Client socket (1) | Creating socket.
2024-09-24 16:15:32.093 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:15:32.093 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:15:32.216 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:15:32.216 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:15:32.216 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:15:41.729 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:15:41.729 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:15:41.729 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:15:41.729 | DTC Client socket (1) | Closed.
2024-09-24 16:15:41.730 | Denali Data Feed | Failed connections: 18
2024-09-24 16:15:41.730 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:15:41.730 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:15:41.730 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:15:41.730 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:15:44.735 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:15:44.735 | DTC Client socket (1) | Creating socket.
2024-09-24 16:15:44.735 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:15:44.735 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:15:44.856 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:15:44.856 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:15:44.856 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:15:54.859 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:15:54.859 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:15:54.859 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:15:54.859 | DTC Client socket (1) | Closed.
2024-09-24 16:15:54.859 | Denali Data Feed | Failed connections: 19
2024-09-24 16:15:54.859 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:15:54.859 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:15:54.859 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:15:54.859 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:15:57.852 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:15:57.852 | DTC Client socket (1) | Creating socket.
2024-09-24 16:15:57.852 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:15:57.852 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:15:57.973 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:15:57.973 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:15:57.973 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:16:07.979 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:16:07.979 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:16:07.979 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:16:07.979 | DTC Client socket (1) | Closed.
2024-09-24 16:16:07.979 | Denali Data Feed | Failed connections: 20
2024-09-24 16:16:07.979 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:16:07.979 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:16:07.979 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:16:07.979 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:16:10.988 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:16:10.988 | DTC Client socket (1) | Creating socket.
2024-09-24 16:16:10.988 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:16:10.988 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:16:11.109 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:16:11.109 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:16:11.109 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:16:20.768 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:16:20.768 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:16:20.768 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:16:20.768 | DTC Client socket (1) | Closed.
2024-09-24 16:16:20.768 | Denali Data Feed | Failed connections: 21
2024-09-24 16:16:20.768 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:16:20.768 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:16:20.768 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:16:20.768 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:16:23.768 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:16:23.769 | DTC Client socket (1) | Creating socket.
2024-09-24 16:16:23.769 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:16:23.769 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:16:23.903 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:16:23.903 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:16:23.903 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:16:33.408 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:16:33.411 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:16:33.411 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:16:33.411 | DTC Client socket (1) | Closed.
2024-09-24 16:16:33.411 | Denali Data Feed | Failed connections: 22
2024-09-24 16:16:33.411 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:16:33.411 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:16:33.411 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:16:33.411 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:16:36.401 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:16:36.401 | DTC Client socket (1) | Creating socket.
2024-09-24 16:16:36.401 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:16:36.401 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:16:36.522 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:16:36.522 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:16:36.522 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:16:46.128 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:16:46.129 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:16:46.129 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:16:46.129 | DTC Client socket (1) | Closed.
2024-09-24 16:16:46.129 | Denali Data Feed | Failed connections: 23
2024-09-24 16:16:46.129 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:16:46.129 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:16:46.129 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:16:46.129 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:16:49.116 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:16:49.117 | DTC Client socket (3) | Creating socket.
2024-09-24 16:16:49.117 | DTC Client socket (3) | New receive buffer size: 0
2024-09-24 16:16:49.117 | DTC Client socket (3) | Connecting to IP: 202.52.152.130.
2024-09-24 16:16:49.238 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:16:49.238 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:16:49.238 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:16:59.088 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-09-24 16:16:59.088 | DTC Client socket (3) | CloseSocket call.
2024-09-24 16:16:59.088 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:16:59.088 | DTC Client socket (3) | Closed.
2024-09-24 16:16:59.088 | Denali Data Feed | Failed connections: 24
2024-09-24 16:16:59.088 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:16:59.088 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:16:59.088 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:16:59.088 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:17:02.096 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:17:02.097 | DTC Client socket (1) | Creating socket.
2024-09-24 16:17:02.097 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:17:02.097 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:17:02.218 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:17:02.218 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:17:02.218 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:17:11.728 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:17:11.728 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:17:11.728 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:17:11.728 | DTC Client socket (1) | Closed.
2024-09-24 16:17:11.728 | Denali Data Feed | Failed connections: 25
2024-09-24 16:17:11.728 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:17:11.728 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:17:11.728 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:17:11.728 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:17:14.736 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:17:14.736 | DTC Client socket (1) | Creating socket.
2024-09-24 16:17:14.736 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:17:14.736 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:17:14.857 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:17:14.857 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:17:14.857 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:17:24.777 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:17:24.777 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:17:24.778 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:17:24.778 | DTC Client socket (1) | Closed.
2024-09-24 16:17:24.778 | Denali Data Feed | Failed connections: 26
2024-09-24 16:17:24.778 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:17:24.778 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:17:24.778 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:17:24.778 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:17:27.784 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:17:27.784 | DTC Client socket (1) | Creating socket.
2024-09-24 16:17:27.784 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:17:27.784 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:17:27.907 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:17:27.907 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:17:27.907 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:17:37.567 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:17:37.567 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:17:37.567 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:17:37.567 | DTC Client socket (1) | Closed.
2024-09-24 16:17:37.567 | Denali Data Feed | Failed connections: 27
2024-09-24 16:17:37.567 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:17:37.567 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:17:37.567 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:17:37.567 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:17:40.563 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:17:40.563 | DTC Client socket (1) | Creating socket.
2024-09-24 16:17:40.563 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:17:40.563 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:17:40.684 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:17:40.684 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:17:40.684 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:17:50.457 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:17:50.457 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:17:50.457 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:17:50.457 | DTC Client socket (1) | Closed.
2024-09-24 16:17:50.457 | Denali Data Feed | Failed connections: 28
2024-09-24 16:17:50.457 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:17:50.457 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:17:50.457 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:17:50.457 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:17:53.450 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:17:53.450 | DTC Client socket (1) | Creating socket.
2024-09-24 16:17:53.450 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:17:53.450 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:17:53.571 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:17:53.571 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:17:53.571 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:18:03.177 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:18:03.177 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:18:03.177 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:18:03.177 | DTC Client socket (1) | Closed.
2024-09-24 16:18:03.177 | Denali Data Feed | Failed connections: 29
2024-09-24 16:18:03.177 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:18:03.177 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:18:03.177 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:18:03.177 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:18:06.175 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:18:06.176 | DTC Client socket (1) | Creating socket.
2024-09-24 16:18:06.176 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:18:06.176 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:18:06.296 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:18:06.296 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:18:06.296 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:18:15.977 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:18:15.977 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:18:15.977 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:18:15.977 | DTC Client socket (1) | Closed.
2024-09-24 16:18:15.977 | Denali Data Feed | Failed connections: 30
2024-09-24 16:18:15.977 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:18:15.977 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:18:15.977 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:18:15.977 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:18:18.987 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:18:18.988 | DTC Client socket (1) | Creating socket.
2024-09-24 16:18:18.988 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:18:18.988 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:18:19.108 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:18:19.108 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:18:19.108 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:18:31.566 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:18:31.566 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:18:31.567 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:18:31.567 | DTC Client socket (1) | Closed.
2024-09-24 16:18:31.567 | Denali Data Feed | Failed connections: 31
2024-09-24 16:18:31.567 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:18:31.567 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:18:31.567 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:18:31.567 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:18:34.563 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:18:34.563 | DTC Client socket (1) | Creating socket.
2024-09-24 16:18:34.563 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:18:34.563 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:18:34.683 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:18:34.683 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:18:34.683 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:18:44.766 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:18:44.767 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:18:44.767 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:18:44.767 | DTC Client socket (1) | Closed.
2024-09-24 16:18:44.767 | Denali Data Feed | Failed connections: 32
2024-09-24 16:18:44.767 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:18:44.767 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:18:44.767 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:18:44.767 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:18:47.768 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:18:47.769 | DTC Client socket (1) | Creating socket.
2024-09-24 16:18:47.769 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:18:47.769 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:18:47.889 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:18:47.889 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:18:47.889 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:18:51.781 | File >> Reconnect selected.
2024-09-24 16:18:51.898 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 16:18:51.898 | DTC Client socket (2) | CloseSocket call.
2024-09-24 16:18:51.898 | DTC Client socket (2) | Max send buffers used during socket life: 3
2024-09-24 16:18:51.898 | DTC Client socket (2) | Max send buffer size during socket life: 406
2024-09-24 16:18:51.898 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 16:18:51.899 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:18:51.899 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:18:51.899 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 16:18:51.899 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:18:51.899 | Rithmic Direct - DTC | Disconnected.
2024-09-24 16:18:51.899 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 16:18:52.277 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 16:18:52.277 | DTC Client socket (2) | Closed.
2024-09-24 16:18:55.897 |
2024-09-24 16:18:55.897 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 16:18:55.897 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 16:18:55.897 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 16:18:56.296 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2024-09-24 16:18:56.296 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 16:18:56.296 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2024-09-24 16:18:56.673 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 16:18:56.673 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 16:18:56.673 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 16:18:56.673 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 16:18:57.486 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:18:57.486 | DTC Client socket (1) | Closed.
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | Received logon response.
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | Server Name: .
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 16:18:57.810 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 16:18:57.810 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 16:18:57.810 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 16:18:57.810 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 16:18:57.810 | Using symbol data fast lookup vector
2024-09-24 16:18:57.810 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 16:18:57.810 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:18:57.810 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 16:18:57.810 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 16:18:57.810 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 16:18:57.810 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 16:18:57.810 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 16:18:57.810 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 16:18:57.811 | DTC Client socket (1) | Creating socket.
2024-09-24 16:18:57.811 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:18:57.811 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:18:57.926 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 16:18:57.926 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 3 Service code: cme
2024-09-24 16:18:57.926 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 3
2024-09-24 16:18:57.926 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 16:18:57.926 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 16:18:57.926 | Triggering next historical data download in queue.
2024-09-24 16:18:57.940 | Delaying start of download for ESZ4.CME.
2024-09-24 16:18:57.940 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:18:57.940 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:18:57.941 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:18:57.958 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 16:18:57.958 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 4 Service code: cme
2024-09-24 16:18:57.958 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 4
2024-09-24 16:18:57.958 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 16:18:57.958 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 16:18:57.958 | Triggering next historical data download in queue.
2024-09-24 16:18:58.283 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 16:18:58.284 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 5 Service code: cme
2024-09-24 16:18:58.284 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 5
2024-09-24 16:18:58.284 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 16:18:58.284 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 16:18:58.284 | Triggering next historical data download in queue.
2024-09-24 16:18:58.303 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 16:18:58.303 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 6 Service code: cme
2024-09-24 16:18:58.303 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 6
2024-09-24 16:18:58.303 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 16:18:58.303 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 16:18:58.303 | Triggering next historical data download in queue.
2024-09-24 16:19:03.054 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 16:19:03.054 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 16:19:03.054 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 16:19:09.976 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:19:09.980 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:19:09.980 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:19:09.980 | DTC Client socket (1) | Closed.
2024-09-24 16:19:09.980 | Denali Data Feed | Failed connections: 33
2024-09-24 16:19:09.980 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:19:09.980 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:19:09.980 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:19:09.981 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:19:13.002 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:19:13.003 | DTC Client socket (1) | Creating socket.
2024-09-24 16:19:13.003 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:19:13.003 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:19:13.124 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:19:13.124 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:19:13.124 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:19:16.225 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2.
2024-09-24 16:19:16.225 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | New receive buffer size: 0
2024-09-24 16:19:16.225 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Connecting to IP: 216.66.0.130.
2024-09-24 16:19:18.293 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | CloseSocket call.
2024-09-24 16:19:18.293 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close.
2024-09-24 16:19:18.625 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Socket gracefully closed by remote side.
2024-09-24 16:19:18.625 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (3) | Closed.
2024-09-24 16:19:23.006 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:19:23.006 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:19:23.006 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:19:23.006 | DTC Client socket (1) | Closed.
2024-09-24 16:19:23.006 | Denali Data Feed | Failed connections: 34
2024-09-24 16:19:23.006 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:19:23.006 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:19:23.006 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:19:23.006 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:19:25.996 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:19:25.997 | DTC Client socket (1) | Creating socket.
2024-09-24 16:19:25.997 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:19:25.997 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:19:26.118 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:19:26.118 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:19:26.118 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:19:28.379 | HD Request # 5 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 16:19:28.379 | HD Request # 5 | Download start date-time: 2024-09-24 16:11:45.000000. File last date-time: 2024-09-24 16:11:45.016000
2024-09-24 16:19:28.380 | HD Request # 5 | Using server: ds32.sierracharts.com port 10150
2024-09-24 16:19:28.380 | Socket (3) | Creating socket.
2024-09-24 16:19:28.380 | Socket (3) | New receive buffer size: 0
2024-09-24 16:19:28.380 | Socket (3) | Connecting to IP: 67.214.125.3.
2024-09-24 16:19:29.039 | HD Request # 5 | Setting DTC encoding to Binary VLS
2024-09-24 16:19:29.039 | HD Request # 5 | Sending historical data logon request message.
2024-09-24 16:19:29.858 | HD Request # 5 | Requesting Intraday data. Start date-time: 2024-09-24 16:11:45. Record interval: 0. Symbol: ESZ24
2024-09-24 16:19:30.189 | HD Request # 5 | Decompressing data.
2024-09-24 16:19:30.513 | HD Request # 5 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 16:11:45.016000
2024-09-24 16:19:30.514 | Socket (3) | CloseSocket call.
2024-09-24 16:19:30.514 | Socket (3) | Shutdown started. Waiting for graceful close.
2024-09-24 16:19:30.514 | Historical data download thread signaled to stop.
2024-09-24 16:19:30.514 | HD Request # 5 | Timestamp of first Intraday data file record written: 2024-09-24 16:11:45.618000.
2024-09-24 16:19:30.514 | HD Request # 5 | Received 2208 Intraday data records from 2024-09-24 16:11:45.016000 to 2024-09-24 16:19:30.529000 (7.8 minutes. Delay: -0.0 seconds) and wrote 2207 records for ESZ4.CME
2024-09-24 16:19:30.515 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:19:30.529000
2024-09-24 16:19:30.515 | HD Request # 5 | Completion time: 2s.
2024-09-24 16:19:30.515 | HD Request # 5 | Intraday data download complete for ESZ4.CME. Unique request ID: 5
2024-09-24 16:19:30.515 | Removing historical data download ID 5.
2024-09-24 16:19:30.515 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 16:19:30.515 | Intraday chart data file opened for ESZ4.CME
2024-09-24 16:19:30.515 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2024-09-24 16:19:30.515 | Triggering next historical data download in queue.
2024-09-24 16:19:30.515 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:19:30.515 | HD Request # 6 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 16:19:30.515 | HD Request # 6 | Download start date-time: 2024-09-24 16:12:28.000000. File last date-time: 2024-09-24 16:12:28.917000
2024-09-24 16:19:30.515 | HD Request # 6 | Using server: ds32.sierracharts.com port 10149
2024-09-24 16:19:30.515 | Socket (4) | Creating socket.
2024-09-24 16:19:30.515 | Socket (4) | New receive buffer size: 0
2024-09-24 16:19:30.515 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 16:19:30.838 | Socket (3) | Socket gracefully closed by remote side.
2024-09-24 16:19:30.838 | Socket (3) | Closed.
2024-09-24 16:19:31.179 | HD Request # 6 | Setting DTC encoding to Binary VLS
2024-09-24 16:19:31.179 | HD Request # 6 | Sending historical data logon request message.
2024-09-24 16:19:31.990 | HD Request # 6 | Requesting Intraday data. Start date-time: 2024-09-24 16:12:28. Record interval: 0. Symbol: NQZ24
2024-09-24 16:19:32.315 | HD Request # 6 | Decompressing data.
2024-09-24 16:19:32.644 | HD Request # 6 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 16:12:28.854000
2024-09-24 16:19:32.644 | Socket (4) | CloseSocket call.
2024-09-24 16:19:32.645 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 16:19:32.645 | Historical data download thread signaled to stop.
2024-09-24 16:19:32.645 | HD Request # 6 | Timestamp of first Intraday data file record written: 2024-09-24 16:12:29.962000.
2024-09-24 16:19:32.645 | HD Request # 6 | Received 1503 Intraday data records from 2024-09-24 16:12:28.854000 to 2024-09-24 16:19:30.767000 (7.0 minutes. Delay: 1.9 seconds) and wrote 1500 records for NQZ4.CME
2024-09-24 16:19:32.645 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:19:30.767000
2024-09-24 16:19:32.645 | HD Request # 6 | Completion time: 2s.
2024-09-24 16:19:32.645 | HD Request # 6 | Intraday data download complete for NQZ4.CME. Unique request ID: 6
2024-09-24 16:19:32.645 | Removing historical data download ID 6.
2024-09-24 16:19:32.645 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 16:19:32.645 | Intraday chart data file opened for NQZ4.CME
2024-09-24 16:19:32.645 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2024-09-24 16:19:32.645 | Triggering next historical data download in queue.
2024-09-24 16:19:32.645 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:19:32.645 | HD Request # 7 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 16:19:32.645 | HD Request # 7 | Download start date-time: 2024-09-24 16:12:16.000000. File last date-time: 2024-09-24 16:12:16.086001
2024-09-24 16:19:32.645 | HD Request # 7 | Using server: ds32.sierracharts.com port 10150
2024-09-24 16:19:32.645 | Socket (3) | Creating socket.
2024-09-24 16:19:32.645 | Socket (3) | New receive buffer size: 0
2024-09-24 16:19:32.646 | Socket (3) | Connecting to IP: 67.214.125.3.
2024-09-24 16:19:32.968 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 16:19:32.968 | Socket (4) | Closed.
2024-09-24 16:19:33.303 | HD Request # 7 | Setting DTC encoding to Binary VLS
2024-09-24 16:19:33.303 | HD Request # 7 | Sending historical data logon request message.
2024-09-24 16:19:33.626 | HD Request # 7 | Requesting Intraday data. Start date-time: 2024-09-24 16:12:16. Record interval: 0. Symbol: MESZ24
2024-09-24 16:19:33.952 | HD Request # 7 | Decompressing data.
2024-09-24 16:19:34.277 | HD Request # 7 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 16:12:16.080000
2024-09-24 16:19:34.278 | Socket (3) | CloseSocket call.
2024-09-24 16:19:34.278 | Socket (3) | Shutdown started. Waiting for graceful close.
2024-09-24 16:19:34.278 | Historical data download thread signaled to stop.
2024-09-24 16:19:34.278 | HD Request # 7 | Timestamp of first Intraday data file record written: 2024-09-24 16:12:17.886000.
2024-09-24 16:19:34.278 | HD Request # 7 | Received 681 Intraday data records from 2024-09-24 16:12:16.080000 to 2024-09-24 16:19:33.593002 (7.3 minutes. Delay: 0.7 seconds) and wrote 674 records for MESZ4.CME
2024-09-24 16:19:34.278 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:19:33.593002
2024-09-24 16:19:34.278 | HD Request # 7 | Completion time: 2s.
2024-09-24 16:19:34.278 | HD Request # 7 | Intraday data download complete for MESZ4.CME. Unique request ID: 7
2024-09-24 16:19:34.278 | Removing historical data download ID 7.
2024-09-24 16:19:34.278 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 16:19:34.278 | Intraday chart data file opened for MESZ4.CME
2024-09-24 16:19:34.278 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2024-09-24 16:19:34.278 | Triggering next historical data download in queue.
2024-09-24 16:19:34.278 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:19:34.278 | HD Request # 8 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 16:19:34.279 | HD Request # 8 | Download start date-time: 2024-09-24 16:12:28.000000. File last date-time: 2024-09-24 16:12:28.855001
2024-09-24 16:19:34.279 | HD Request # 8 | Using server: ds32.sierracharts.com port 10149
2024-09-24 16:19:34.279 | Socket (4) | Creating socket.
2024-09-24 16:19:34.279 | Socket (4) | New receive buffer size: 0
2024-09-24 16:19:34.279 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 16:19:34.601 | Socket (3) | Socket gracefully closed by remote side.
2024-09-24 16:19:34.601 | Socket (3) | Closed.
2024-09-24 16:19:34.941 | HD Request # 8 | Setting DTC encoding to Binary VLS
2024-09-24 16:19:34.941 | HD Request # 8 | Sending historical data logon request message.
2024-09-24 16:19:35.265 | HD Request # 8 | Requesting Intraday data. Start date-time: 2024-09-24 16:12:28. Record interval: 0. Symbol: MNQZ24
2024-09-24 16:19:35.590 | HD Request # 8 | Decompressing data.
2024-09-24 16:19:35.736 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:19:35.736 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:19:35.736 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:19:35.736 | DTC Client socket (1) | Closed.
2024-09-24 16:19:35.736 | Denali Data Feed | Failed connections: 35
2024-09-24 16:19:35.736 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:19:35.736 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:19:35.736 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:19:35.736 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:19:36.246 | HD Request # 8 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 16:12:28.855000
2024-09-24 16:19:36.246 | Socket (4) | CloseSocket call.
2024-09-24 16:19:36.246 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 16:19:36.246 | Historical data download thread signaled to stop.
2024-09-24 16:19:36.247 | HD Request # 8 | Timestamp of first Intraday data file record written: 2024-09-24 16:12:29.739000.
2024-09-24 16:19:36.247 | HD Request # 8 | Received 2471 Intraday data records from 2024-09-24 16:12:28.855000 to 2024-09-24 16:19:36.027000 (7.1 minutes. Delay: 0.2 seconds) and wrote 2469 records for MNQZ4.CME
2024-09-24 16:19:36.247 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:19:36.027000
2024-09-24 16:19:36.247 | HD Request # 8 | Completion time: 2s.
2024-09-24 16:19:36.247 | HD Request # 8 | Intraday data download complete for MNQZ4.CME. Unique request ID: 8
2024-09-24 16:19:36.247 | Removing historical data download ID 8.
2024-09-24 16:19:36.247 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 16:19:36.247 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 16:19:36.247 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2024-09-24 16:19:36.247 | No download requests in the queue to start downloads for.
2024-09-24 16:19:36.247 | Historical data for MNQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:19:36.570 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 16:19:36.570 | Socket (4) | Closed.
2024-09-24 16:19:38.730 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:19:38.730 | DTC Client socket (1) | Creating socket.
2024-09-24 16:19:38.730 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:19:38.730 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:19:38.851 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:19:38.851 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:19:38.851 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:19:48.445 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:19:48.445 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:19:48.445 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:19:48.445 | DTC Client socket (1) | Closed.
2024-09-24 16:19:48.445 | Denali Data Feed | Failed connections: 36
2024-09-24 16:19:48.445 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:19:48.446 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:19:48.446 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:19:48.446 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:19:51.459 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:19:51.459 | DTC Client socket (1) | Creating socket.
2024-09-24 16:19:51.459 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:19:51.459 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:19:51.580 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:19:51.580 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:19:51.580 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:20:01.095 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:20:01.095 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:20:01.095 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:20:01.095 | DTC Client socket (1) | Closed.
2024-09-24 16:20:01.095 | Denali Data Feed | Failed connections: 37
2024-09-24 16:20:01.095 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:20:01.095 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:20:01.095 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:20:01.096 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:20:04.084 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:20:04.085 | DTC Client socket (1) | Creating socket.
2024-09-24 16:20:04.085 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:20:04.085 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:20:04.205 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:20:04.205 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:20:04.205 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:20:07.174 | File >> Reconnect selected.
2024-09-24 16:20:07.289 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 16:20:07.289 | DTC Client socket (2) | CloseSocket call.
2024-09-24 16:20:07.289 | DTC Client socket (2) | Max send buffers used during socket life: 3
2024-09-24 16:20:07.289 | DTC Client socket (2) | Max send buffer size during socket life: 406
2024-09-24 16:20:07.289 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:07.289 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:20:07.289 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:20:07.289 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:07.289 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:20:07.289 | Rithmic Direct - DTC | Disconnected.
2024-09-24 16:20:07.289 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 16:20:07.667 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 16:20:07.667 | DTC Client socket (2) | Closed.
2024-09-24 16:20:11.300 |
2024-09-24 16:20:11.300 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 16:20:11.300 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 16:20:11.300 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 16:20:11.300 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2024-09-24 16:20:11.300 | DTC Client socket (2) | New receive buffer size: 0
2024-09-24 16:20:11.300 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2024-09-24 16:20:11.677 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 16:20:11.677 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 16:20:11.677 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 16:20:11.677 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | Received logon response.
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | Server Name: .
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 16:20:12.812 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 16:20:12.812 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-09-24 16:20:12.812 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 16:20:12.812 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 16:20:12.812 | Using symbol data fast lookup vector
2024-09-24 16:20:12.812 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 16:20:12.812 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:20:12.812 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 16:20:12.812 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 16:20:12.812 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 16:20:12.812 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 16:20:12.812 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 16:20:12.812 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 16:20:12.812 | DTC Client socket (3) | Creating socket.
2024-09-24 16:20:12.812 | DTC Client socket (3) | New receive buffer size: 0
2024-09-24 16:20:12.812 | DTC Client socket (3) | Connecting to IP: 202.52.152.130.
2024-09-24 16:20:12.933 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:20:12.933 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:20:12.933 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:20:12.934 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 16:20:12.934 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 3 Service code: cme
2024-09-24 16:20:12.934 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 3
2024-09-24 16:20:12.934 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 16:20:12.934 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 16:20:12.934 | Triggering next historical data download in queue.
2024-09-24 16:20:12.946 | Delaying start of download for ESZ4.CME.
2024-09-24 16:20:12.963 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 16:20:12.963 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 4 Service code: cme
2024-09-24 16:20:12.963 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 4
2024-09-24 16:20:12.964 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 16:20:12.964 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 16:20:12.964 | Triggering next historical data download in queue.
2024-09-24 16:20:13.278 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 16:20:13.278 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 5 Service code: cme
2024-09-24 16:20:13.278 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 5
2024-09-24 16:20:13.278 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 16:20:13.278 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 16:20:13.278 | Triggering next historical data download in queue.
2024-09-24 16:20:13.297 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 16:20:13.297 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 6 Service code: cme
2024-09-24 16:20:13.297 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 6
2024-09-24 16:20:13.297 | Added historical Intraday data request for MNQZ4.CME to the queue.
2024-09-24 16:20:13.297 | Intraday data recording state for symbol MNQZ4.CME is set to download 'Pending'.
2024-09-24 16:20:13.297 | Triggering next historical data download in queue.
2024-09-24 16:20:13.815 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:20:13.815 | DTC Client socket (1) | Closed.
2024-09-24 16:20:17.815 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 16:20:17.815 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 16:20:17.815 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 16:20:23.165 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-09-24 16:20:23.165 | DTC Client socket (3) | CloseSocket call.
2024-09-24 16:20:23.165 | DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-09-24 16:20:23.165 | DTC Client socket (3) | Closed.
2024-09-24 16:20:23.165 | Denali Data Feed | Failed connections: 38
2024-09-24 16:20:23.165 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:20:23.166 | DTC Client socket (0) | CloseSocket call.
2024-09-24 16:20:23.166 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:20:23.166 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-09-24 16:20:26.163 | Denali Data Feed | Connecting to the server ds40.SierraCharts.com. Port 443
2024-09-24 16:20:26.163 | DTC Client socket (1) | Creating socket.
2024-09-24 16:20:26.163 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:20:26.163 | DTC Client socket (1) | Connecting to IP: 202.52.152.130.
2024-09-24 16:20:26.284 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:20:26.284 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:20:26.284 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:20:31.290 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Creating socket. Using TLS 1.2.
2024-09-24 16:20:31.290 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | New receive buffer size: 0
2024-09-24 16:20:31.290 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Connecting to IP: 216.66.0.130.
2024-09-24 16:20:32.713 | File >> Reconnect selected.
2024-09-24 16:20:32.826 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-09-24 16:20:32.826 | DTC Client socket (2) | CloseSocket call.
2024-09-24 16:20:32.826 | Denali Data Feed | Waiting for socket receive thread to end
2024-09-24 16:20:32.826 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:32.826 | DTC Client socket (1) | CloseSocket call.
2024-09-24 16:20:32.826 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:32.826 | Denali Data Feed | Disconnected from the server.
2024-09-24 16:20:32.826 | Rithmic Direct - DTC | Disconnected.
2024-09-24 16:20:32.826 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2024-09-24 16:20:33.204 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-09-24 16:20:33.204 | DTC Client socket (2) | Closed.
2024-09-24 16:20:33.364 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | CloseSocket call.
2024-09-24 16:20:33.364 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:33.395 | HD Request # 9 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 16:20:33.395 | HD Request # 9 | Download start date-time: 2024-09-24 16:19:30.000000. File last date-time: 2024-09-24 16:19:30.529000
2024-09-24 16:20:33.395 | HD Request # 9 | Using server: ds32.sierracharts.com port 10150
2024-09-24 16:20:33.395 | Socket (2) | Creating socket.
2024-09-24 16:20:33.395 | Socket (2) | New receive buffer size: 0
2024-09-24 16:20:33.395 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 16:20:33.695 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Socket gracefully closed by remote side.
2024-09-24 16:20:33.695 | HTTPS connection ID:4 to downloads.rithmic.com:443 for request ID:4 (3) | Closed.
2024-09-24 16:20:34.056 | HD Request # 9 | Setting DTC encoding to Binary VLS
2024-09-24 16:20:34.056 | HD Request # 9 | Sending historical data logon request message.
2024-09-24 16:20:34.872 | HD Request # 9 | Requesting Intraday data. Start date-time: 2024-09-24 16:19:30. Record interval: 0. Symbol: ESZ24
2024-09-24 16:20:35.198 | HD Request # 9 | Decompressing data.
2024-09-24 16:20:35.522 | HD Request # 9 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 16:19:30.384000
2024-09-24 16:20:35.523 | Socket (2) | CloseSocket call.
2024-09-24 16:20:35.523 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:35.523 | Historical data download thread signaled to stop.
2024-09-24 16:20:35.523 | HD Request # 9 | Timestamp of first Intraday data file record written: 2024-09-24 16:19:33.593000.
2024-09-24 16:20:35.523 | HD Request # 9 | Received 163 Intraday data records from 2024-09-24 16:19:30.384000 to 2024-09-24 16:20:31.140000 (60.8 seconds. Delay: 4.4 seconds) and wrote 120 records for ESZ4.CME
2024-09-24 16:20:35.523 | HD Request # 9 | Completion time: 2s.
2024-09-24 16:20:35.523 | HD Request # 9 | Intraday data download complete for ESZ4.CME. Unique request ID: 9
2024-09-24 16:20:35.523 | Removing historical data download ID 9.
2024-09-24 16:20:35.523 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 16:20:35.523 | Intraday chart data file opened for ESZ4.CME
2024-09-24 16:20:35.523 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2024-09-24 16:20:35.523 | Triggering next historical data download in queue.
2024-09-24 16:20:35.523 | Historical data for ESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:20:35.523 | HD Request # 10 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 16:20:35.523 | HD Request # 10 | Download start date-time: 2024-09-24 16:19:30.000000. File last date-time: 2024-09-24 16:19:30.767000
2024-09-24 16:20:35.523 | HD Request # 10 | Using server: ds32.sierracharts.com port 10149
2024-09-24 16:20:35.523 | Socket (3) | Creating socket.
2024-09-24 16:20:35.523 | Socket (3) | New receive buffer size: 0
2024-09-24 16:20:35.523 | Socket (3) | Connecting to IP: 67.214.125.3.
2024-09-24 16:20:35.846 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 16:20:35.847 | Socket (2) | Closed.
2024-09-24 16:20:35.975 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-09-24 16:20:35.975 | DTC Client socket (1) | Closed.
2024-09-24 16:20:36.182 | HD Request # 10 | Setting DTC encoding to Binary VLS
2024-09-24 16:20:36.182 | HD Request # 10 | Sending historical data logon request message.
2024-09-24 16:20:36.830 |
2024-09-24 16:20:36.830 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2024-09-24 16:20:36.830 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2024-09-24 16:20:36.830 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2024-09-24 16:20:36.831 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-09-24 16:20:36.831 | DTC Client socket (1) | New receive buffer size: 0
2024-09-24 16:20:36.831 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-09-24 16:20:36.999 | HD Request # 10 | Requesting Intraday data. Start date-time: 2024-09-24 16:19:30. Record interval: 0. Symbol: NQZ24
2024-09-24 16:20:37.207 | Rithmic Direct - DTC | Network connection to server complete.
2024-09-24 16:20:37.207 | Rithmic Direct - DTC | Starting socket receive thread.
2024-09-24 16:20:37.208 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-09-24 16:20:37.208 | Rithmic Direct - DTC | Sending logon request message.
2024-09-24 16:20:37.325 | HD Request # 10 | Decompressing data.
2024-09-24 16:20:37.649 | HD Request # 10 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 16:19:30.385000
2024-09-24 16:20:37.650 | Socket (3) | CloseSocket call.
2024-09-24 16:20:37.650 | Socket (3) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:37.650 | Historical data download thread signaled to stop.
2024-09-24 16:20:37.650 | HD Request # 10 | Timestamp of first Intraday data file record written: 2024-09-24 16:19:33.593000.
2024-09-24 16:20:37.650 | HD Request # 10 | Received 114 Intraday data records from 2024-09-24 16:19:30.385000 to 2024-09-24 16:20:29.605003 (59.2 seconds. Delay: 8.0 seconds) and wrote 95 records for NQZ4.CME
2024-09-24 16:20:37.650 | HD Request # 10 | Completion time: 2s.
2024-09-24 16:20:37.650 | HD Request # 10 | Intraday data download complete for NQZ4.CME. Unique request ID: 10
2024-09-24 16:20:37.650 | Removing historical data download ID 10.
2024-09-24 16:20:37.650 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 16:20:37.650 | Intraday chart data file opened for NQZ4.CME
2024-09-24 16:20:37.650 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2024-09-24 16:20:37.650 | Triggering next historical data download in queue.
2024-09-24 16:20:37.650 | Historical data for NQZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:20:37.650 | HD Request # 11 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 16:20:37.650 | HD Request # 11 | Download start date-time: 2024-09-24 16:19:33.000000. File last date-time: 2024-09-24 16:19:33.593002
2024-09-24 16:20:37.650 | HD Request # 11 | Using server: ds32.sierracharts.com port 10150
2024-09-24 16:20:37.650 | Socket (4) | Creating socket.
2024-09-24 16:20:37.650 | Socket (4) | New receive buffer size: 0
2024-09-24 16:20:37.650 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 16:20:37.974 | Socket (3) | Socket gracefully closed by remote side.
2024-09-24 16:20:37.974 | Socket (3) | Closed.
2024-09-24 16:20:38.310 | HD Request # 11 | Setting DTC encoding to Binary VLS
2024-09-24 16:20:38.310 | HD Request # 11 | Sending historical data logon request message.
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | Received logon response.
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | Server Name: .
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | Successfully connected.
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | Trading is supported.
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | OCO Orders supported.
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-09-24 16:20:38.342 | Rithmic Direct - DTC | Connected to server complete.
2024-09-24 16:20:38.342 | No download requests in the queue to start downloads for.
2024-09-24 16:20:38.342 | Triggering next historical data download in queue.
2024-09-24 16:20:38.342 | No download requests in the queue to start downloads for. | Number times message added: 1
2024-09-24 16:20:38.342 | Subscribing to symbol for symbol alert. MESU4.CME
2024-09-24 16:20:38.342 | Mapping MESU4.CME to MESU24. Service code: cme
2024-09-24 16:20:38.342 | Using symbol data fast lookup vector
2024-09-24 16:20:38.342 | Denali Data Feed | Starting real-time market data updates for: MESU4.CME (MESU24). ID: 1 Service code: cme
2024-09-24 16:20:38.342 | Denali Data Feed | Connecting to the server ds13.SierraCharts.com. Port 443
2024-09-24 16:20:38.342 | Denali Data Feed | Requesting security definition data for: MESU4.CME (MESU24). ID: 1
2024-09-24 16:20:38.342 | Subscribing to symbol for symbol alert. MESU4.CME | Number times message added: 2
2024-09-24 16:20:38.342 | Subscribing to symbol for symbol alert. MNQU4.CME
2024-09-24 16:20:38.342 | Mapping MNQU4.CME to MNQU24. Service code: cme
2024-09-24 16:20:38.342 | Denali Data Feed | Starting real-time market data updates for: MNQU4.CME (MNQU24). ID: 2 Service code: cme
2024-09-24 16:20:38.342 | Denali Data Feed | Requesting security definition data for: MNQU4.CME (MNQU24). ID: 2
2024-09-24 16:20:38.450 | Mapping ESZ4.CME to ESZ24. Service code: cme
2024-09-24 16:20:38.450 | Denali Data Feed | Starting real-time market data updates for: ESZ4.CME (ESZ24). ID: 3 Service code: cme
2024-09-24 16:20:38.450 | Denali Data Feed | Requesting security definition data for: ESZ4.CME (ESZ24). ID: 3
2024-09-24 16:20:38.451 | Added historical Intraday data request for ESZ4.CME to the queue.
2024-09-24 16:20:38.451 | Intraday data recording state for symbol ESZ4.CME is set to download 'Pending'.
2024-09-24 16:20:38.451 | Triggering next historical data download in queue.
2024-09-24 16:20:38.478 | Mapping NQZ4.CME to NQZ24. Service code: cme
2024-09-24 16:20:38.478 | Denali Data Feed | Starting real-time market data updates for: NQZ4.CME (NQZ24). ID: 4 Service code: cme
2024-09-24 16:20:38.478 | Denali Data Feed | Requesting security definition data for: NQZ4.CME (NQZ24). ID: 4
2024-09-24 16:20:38.478 | Added historical Intraday data request for NQZ4.CME to the queue.
2024-09-24 16:20:38.478 | Intraday data recording state for symbol NQZ4.CME is set to download 'Pending'.
2024-09-24 16:20:38.478 | Triggering next historical data download in queue.
2024-09-24 16:20:38.554 | DTC Client socket (3) | Creating socket.
2024-09-24 16:20:38.554 | DTC Client socket (3) | New receive buffer size: 0
2024-09-24 16:20:38.554 | DTC Client socket (3) | Connecting to IP: 69.39.70.246.
2024-09-24 16:20:38.634 | HD Request # 11 | Requesting Intraday data. Start date-time: 2024-09-24 16:19:33. Record interval: 0. Symbol: MESZ24
2024-09-24 16:20:38.719 | Denali Data Feed | Network connection to server complete.
2024-09-24 16:20:38.719 | Denali Data Feed | Starting socket receive thread.
2024-09-24 16:20:38.719 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high
2024-09-24 16:20:38.781 | Mapping MESZ4.CME to MESZ24. Service code: cme
2024-09-24 16:20:38.781 | Denali Data Feed | Starting real-time market data updates for: MESZ4.CME (MESZ24). ID: 5 Service code: cme
2024-09-24 16:20:38.781 | Denali Data Feed | Requesting security definition data for: MESZ4.CME (MESZ24). ID: 5
2024-09-24 16:20:38.799 | Mapping MNQZ4.CME to MNQZ24. Service code: cme
2024-09-24 16:20:38.799 | Denali Data Feed | Starting real-time market data updates for: MNQZ4.CME (MNQZ24). ID: 6 Service code: cme
2024-09-24 16:20:38.799 | Denali Data Feed | Requesting security definition data for: MNQZ4.CME (MNQZ24). ID: 6
2024-09-24 16:20:38.960 | HD Request # 11 | Decompressing data.
2024-09-24 16:20:39.268 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-09-24 16:20:39.268 | Denali Data Feed | Sending logon request message.
2024-09-24 16:20:39.284 | HD Request # 11 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 16:19:33.593000
2024-09-24 16:20:39.284 | Socket (4) | CloseSocket call.
2024-09-24 16:20:39.284 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:39.284 | Historical data download thread signaled to stop.
2024-09-24 16:20:39.284 | HD Request # 11 | Timestamp of first Intraday data file record written: 2024-09-24 16:19:39.968000.
2024-09-24 16:20:39.284 | HD Request # 11 | Received 69 Intraday data records from 2024-09-24 16:19:33.593000 to 2024-09-24 16:20:38.864004 (65.3 seconds. Delay: 0.4 seconds) and wrote 66 records for MESZ4.CME
2024-09-24 16:20:39.285 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:20:38.864004
2024-09-24 16:20:39.285 | HD Request # 11 | Completion time: 2s.
2024-09-24 16:20:39.285 | HD Request # 11 | Intraday data download complete for MESZ4.CME. Unique request ID: 11
2024-09-24 16:20:39.285 | Removing historical data download ID 11.
2024-09-24 16:20:39.285 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 16:20:39.285 | Intraday chart data file opened for MESZ4.CME
2024-09-24 16:20:39.285 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2024-09-24 16:20:39.285 | Triggering next historical data download in queue.
2024-09-24 16:20:39.285 | Historical data for MESZ4.CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2024-09-24 16:20:39.285 | Delaying start of download for MNQZ4.CME.
2024-09-24 16:20:39.608 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 16:20:39.608 | Socket (4) | Closed.
2024-09-24 16:20:40.772 | Denali Data Feed | Received logon response.
2024-09-24 16:20:40.772 | Denali Data Feed | Server Name: SC Realtime Server.
2024-09-24 16:20:40.772 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-09-24 16:20:40.772 | Denali Data Feed | Successfully connected.
2024-09-24 16:20:40.772 | Denali Data Feed | Trading is not supported.
2024-09-24 16:20:40.772 | Denali Data Feed | MarketDepthIsSupported: 1
2024-09-24 16:20:40.773 | Denali Data Feed | Restarting real-time data updates for symbol: ESZ4.CME -> ESZ24
2024-09-24 16:20:40.773 | Denali Data Feed | Restarting real-time data updates for symbol: MESU4.CME -> MESU24
2024-09-24 16:20:40.773 | Added historical Intraday data request for MESZ4.CME to the queue.
2024-09-24 16:20:40.773 | Intraday data recording state for symbol MESZ4.CME is set to download 'Pending'.
2024-09-24 16:20:40.773 | Triggering next historical data download in queue.
2024-09-24 16:20:40.773 | Denali Data Feed | Restarting real-time data updates for symbol: MESZ4.CME -> MESZ24
2024-09-24 16:20:40.773 | Denali Data Feed | Restarting real-time data updates for symbol: MNQU4.CME -> MNQU24
2024-09-24 16:20:40.773 | Denali Data Feed | Restarting real-time data updates for symbol: MNQZ4.CME -> MNQZ24
2024-09-24 16:20:40.773 | Denali Data Feed | Restarting real-time data updates for symbol: NQZ4.CME -> NQZ24
2024-09-24 16:20:41.590 | Denali Data Feed | Received security definition for symbol ESZ4.CME
2024-09-24 16:20:41.590 | Denali Data Feed | Real-time data for symbol MESU4.CME is currently unavailable.
2024-09-24 16:20:41.590 | Denali Data Feed | Received security definition for symbol MESU4.CME
2024-09-24 16:20:41.590 | Denali Data Feed | Received security definition for symbol MESZ4.CME
2024-09-24 16:20:41.590 | Denali Data Feed | Real-time data for symbol MNQU4.CME is currently unavailable.
2024-09-24 16:20:41.590 | Denali Data Feed | Received security definition for symbol MNQU4.CME
2024-09-24 16:20:41.590 | Denali Data Feed | Received security definition for symbol MNQZ4.CME
2024-09-24 16:20:41.590 | Denali Data Feed | Received security definition for symbol NQZ4.CME
2024-09-24 16:20:41.856 | Starting DelayedDownloadMonitoringTimer
2024-09-24 16:20:41.856 | Starting HDTimeoutTimer
2024-09-24 16:20:41.857 | Added historical Daily data request for NQZ4.CME to the queue.
2024-09-24 16:20:41.858 | Triggering next historical data download in queue.
2024-09-24 16:20:41.860 | HD Request # 12 | Downloading Historical Daily chart data for NQZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 16:20:42.234 | Added historical Daily data request for ESZ4.CME to the queue.
2024-09-24 16:20:42.234 | Triggering next historical data download in queue.
2024-09-24 16:20:43.349 | Requesting market depth updates for: ESZ4.CME if supported. NumLevels=50
2024-09-24 16:20:43.349 | Requesting market depth updates for: MESZ4.CME if supported. NumLevels=50
2024-09-24 16:20:43.349 | Requesting market depth updates for: MNQZ4.CME if supported. NumLevels=50
2024-09-24 16:20:43.724 | HD Request # 12 | Requesting historical Daily data for NQZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 16:20:43.854 | Denali Data Feed | Clearing market depth for ESZ4.CME
2024-09-24 16:20:43.854 | Denali Data Feed | Clearing market depth for MESZ4.CME
2024-09-24 16:20:43.854 | Denali Data Feed | Clearing market depth for MNQZ4.CME
2024-09-24 16:20:45.225 | HD Request # 12 | Receiving historical Daily data for NQZ4.CME starting at 2024-09-19.
2024-09-24 16:20:45.225 | HD Request # 12 | Writing historical Daily data to the file NQZ4.CME.dly.
2024-09-24 16:20:45.227 | HD Request # 12 | Bytes received: 237
2024-09-24 16:20:45.227 | HD Request # 12 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for NQZ4.CME
2024-09-24 16:20:45.227 | HD Request # 12 | Completion time: 4s.
2024-09-24 16:20:45.227 | HD Request # 12 | Daily data download complete for NQZ4.CME. Unique request ID: 16
2024-09-24 16:20:45.227 | Removing historical data download ID 16.
2024-09-24 16:20:45.227 | Triggering next historical data download in queue.
2024-09-24 16:20:45.228 | HD Request # 13 | Downloading Historical Daily chart data for ESZ4.CME. Starting date: 2024-09-19. Service: rithmic.trading
2024-09-24 16:20:45.338 | NQZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 16:20:45.338 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:45.338 | NQZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:45.681 | NQZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 16:20:45.705 | NQZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 16:20:45.705 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:45.705 | NQZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:46.029 | NQZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 16:20:46.029 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:46.029 | NQZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:46.333 | NQZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 16:20:46.532 | NQZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 16:20:46.712 | HD Request # 14 | Downloading Intraday chart data for MNQZ4.CME to the file MNQZ4.CME.scid. Service: cme
2024-09-24 16:20:46.712 | HD Request # 14 | Download start date-time: 2024-09-24 16:19:36.000000. File last date-time: 2024-09-24 16:19:36.027000
2024-09-24 16:20:46.712 | HD Request # 14 | Using server: ds32.sierracharts.com port 10149
2024-09-24 16:20:46.712 | Socket (4) | Creating socket.
2024-09-24 16:20:46.712 | Socket (4) | New receive buffer size: 0
2024-09-24 16:20:46.712 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 16:20:47.242 | HD Request # 13 | Requesting historical Daily data for ESZ24 starting at 2024-09-18. SC External HD service.
2024-09-24 16:20:47.372 | HD Request # 14 | Setting DTC encoding to Binary VLS
2024-09-24 16:20:47.372 | HD Request # 14 | Sending historical data logon request message.
2024-09-24 16:20:47.696 | HD Request # 14 | Requesting Intraday data. Start date-time: 2024-09-24 16:19:36. Record interval: 0. Symbol: MNQZ24
2024-09-24 16:20:48.022 | HD Request # 14 | Decompressing data.
2024-09-24 16:20:48.343 | HD Request # 13 | Receiving historical Daily data for ESZ4.CME starting at 2024-09-19.
2024-09-24 16:20:48.343 | HD Request # 13 | Writing historical Daily data to the file ESZ4.CME.dly.
2024-09-24 16:20:48.346 | HD Request # 13 | Bytes received: 233
2024-09-24 16:20:48.346 | HD Request # 13 | Received 4 Daily data records from 2024-09-19 00:00:00 to 2024-09-23 00:00:00 (5.0 days) and wrote 3 records for ESZ4.CME
2024-09-24 16:20:48.346 | HD Request # 14 | Receiving Intraday data for MNQZ4.CME starting at 2024-09-24 16:19:36.016000
2024-09-24 16:20:48.346 | HD Request # 13 | Completion time: 3s.
2024-09-24 16:20:48.346 | HD Request # 13 | Daily data download complete for ESZ4.CME. Unique request ID: 17
2024-09-24 16:20:48.346 | Removing historical data download ID 17.
2024-09-24 16:20:48.346 | No download requests in the queue to start downloads for.
2024-09-24 16:20:48.346 | Socket (4) | CloseSocket call.
2024-09-24 16:20:48.346 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:48.346 | Historical data download thread signaled to stop.
2024-09-24 16:20:48.347 | HD Request # 14 | Timestamp of first Intraday data file record written: 2024-09-24 16:19:38.778000.
2024-09-24 16:20:48.347 | HD Request # 14 | Received 152 Intraday data records from 2024-09-24 16:19:36.016000 to 2024-09-24 16:20:47.963004 (71.9 seconds. Delay: 0.4 seconds) and wrote 147 records for MNQZ4.CME
2024-09-24 16:20:48.347 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:20:47.963004
2024-09-24 16:20:48.347 | Added 7 Time and Sales records to Intraday data file for MNQZ4.CME after download.
2024-09-24 16:20:48.347 | HD Request # 14 | Completion time: 2s.
2024-09-24 16:20:48.347 | HD Request # 14 | Intraday data download complete for MNQZ4.CME. Unique request ID: 12
2024-09-24 16:20:48.347 | Removing historical data download ID 12.
2024-09-24 16:20:48.347 | Real-time Intraday chart data file updates started for MNQZ4.CME
2024-09-24 16:20:48.347 | Intraday chart data file opened for MNQZ4.CME
2024-09-24 16:20:48.347 | HD Request # 14 | Enabling Intraday chart updating for symbol.
2024-09-24 16:20:48.347 | Triggering next historical data download in queue.
2024-09-24 16:20:48.347 | HD Request # 15 | Downloading Intraday chart data for ESZ4.CME to the file ESZ4.CME.scid. Service: cme
2024-09-24 16:20:48.347 | HD Request # 15 | Download start date-time: 2024-09-24 16:20:31.000000. File last date-time: 2024-09-24 16:20:31.140000
2024-09-24 16:20:48.347 | HD Request # 15 | Using server: ds32.sierracharts.com port 10150
2024-09-24 16:20:48.347 | Socket (2) | Creating socket.
2024-09-24 16:20:48.347 | Socket (2) | New receive buffer size: 0
2024-09-24 16:20:48.347 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 16:20:48.515 | ESZ4.CME [CBV][M] Weekly #5 | Reloading chart.
2024-09-24 16:20:48.515 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:48.515 | ESZ4.CME [CBV][M] Weekly #5 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:48.670 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 16:20:48.670 | Socket (4) | Closed.
2024-09-24 16:20:48.893 | ESZ4.CME [CBV][M] Monthly #4 | Reloading chart.
2024-09-24 16:20:48.893 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:48.893 | ESZ4.CME [CBV][M] Monthly #4 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:49.021 | HD Request # 15 | Setting DTC encoding to Binary VLS
2024-09-24 16:20:49.021 | HD Request # 15 | Sending historical data logon request message.
2024-09-24 16:20:49.234 | ESZ4.CME [CBV][M] Weekly #5 | Chart data loading complete.
2024-09-24 16:20:49.270 | ESZ4.CME [CBV][M] Monthly #4 | Chart data loading complete.
2024-09-24 16:20:49.319 | ESZ4.CME [CBV][M] Daily #6 | Reloading chart.
2024-09-24 16:20:49.319 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to 5 years to load data for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:49.319 | ESZ4.CME [CBV][M] Daily #6 | Limiting the number of years to download historical data to 5 years for the continuous futures chart. Reason: Single-digit year in symbol.
2024-09-24 16:20:49.345 | HD Request # 15 | Requesting Intraday data. Start date-time: 2024-09-24 16:20:31. Record interval: 0. Symbol: ESZ24
2024-09-24 16:20:49.671 | HD Request # 15 | Decompressing data.
2024-09-24 16:20:49.703 | ESZ4.CME [CBV][M] Daily #6 | Chart data loading complete.
2024-09-24 16:20:49.994 | HD Request # 15 | Receiving Intraday data for ESZ4.CME starting at 2024-09-24 16:20:31.140000
2024-09-24 16:20:49.995 | Socket (2) | CloseSocket call.
2024-09-24 16:20:49.995 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:49.995 | Historical data download thread signaled to stop.
2024-09-24 16:20:49.995 | HD Request # 15 | Timestamp of first Intraday data file record written: 2024-09-24 16:20:39.429000.
2024-09-24 16:20:49.995 | HD Request # 15 | Received 10 Intraday data records from 2024-09-24 16:20:31.140000 to 2024-09-24 16:20:47.304006 (16.2 seconds. Delay: 2.7 seconds) and wrote 9 records for ESZ4.CME
2024-09-24 16:20:49.995 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:20:47.304006
2024-09-24 16:20:49.995 | Added 14 Time and Sales records to Intraday data file for ESZ4.CME after download.
2024-09-24 16:20:49.995 | HD Request # 15 | Completion time: 1s.
2024-09-24 16:20:49.995 | HD Request # 15 | Intraday data download complete for ESZ4.CME. Unique request ID: 13
2024-09-24 16:20:49.995 | Removing historical data download ID 13.
2024-09-24 16:20:49.995 | Real-time Intraday chart data file updates started for ESZ4.CME
2024-09-24 16:20:49.995 | Intraday chart data file opened for ESZ4.CME
2024-09-24 16:20:49.995 | HD Request # 15 | Enabling Intraday chart updating for symbol.
2024-09-24 16:20:49.995 | Triggering next historical data download in queue.
2024-09-24 16:20:49.995 | HD Request # 16 | Downloading Intraday chart data for NQZ4.CME to the file NQZ4.CME.scid. Service: cme
2024-09-24 16:20:49.996 | HD Request # 16 | Download start date-time: 2024-09-24 16:20:29.000000. File last date-time: 2024-09-24 16:20:29.605003
2024-09-24 16:20:49.996 | HD Request # 16 | Using server: ds32.sierracharts.com port 10149
2024-09-24 16:20:49.996 | Socket (4) | Creating socket.
2024-09-24 16:20:49.996 | Socket (4) | New receive buffer size: 0
2024-09-24 16:20:49.996 | Socket (4) | Connecting to IP: 67.214.125.3.
2024-09-24 16:20:50.319 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 16:20:50.319 | Socket (2) | Closed.
2024-09-24 16:20:50.654 | HD Request # 16 | Setting DTC encoding to Binary VLS
2024-09-24 16:20:50.654 | HD Request # 16 | Sending historical data logon request message.
2024-09-24 16:20:50.978 | HD Request # 16 | Requesting Intraday data. Start date-time: 2024-09-24 16:20:29. Record interval: 0. Symbol: NQZ24
2024-09-24 16:20:51.238 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MNQZ4.CME.scid. Thread ID: 7560
2024-09-24 16:20:51.303 | HD Request # 16 | Decompressing data.
2024-09-24 16:20:51.627 | HD Request # 16 | Receiving Intraday data for NQZ4.CME starting at 2024-09-24 16:20:29.605000
2024-09-24 16:20:51.627 | Socket (4) | CloseSocket call.
2024-09-24 16:20:51.627 | Socket (4) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:51.633 | Historical data download thread signaled to stop.
2024-09-24 16:20:51.633 | HD Request # 16 | Timestamp of first Intraday data file record written: 2024-09-24 16:20:40.267000.
2024-09-24 16:20:51.633 | HD Request # 16 | Received 12 Intraday data records from 2024-09-24 16:20:29.605000 to 2024-09-24 16:20:48.632002 (19.0 seconds. Delay: 3.0 seconds) and wrote 8 records for NQZ4.CME
2024-09-24 16:20:51.634 | HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:20:48.632002
2024-09-24 16:20:51.634 | HD Request # 16 | Completion time: 2s.
2024-09-24 16:20:51.634 | HD Request # 16 | Intraday data download complete for NQZ4.CME. Unique request ID: 14
2024-09-24 16:20:51.634 | Removing historical data download ID 14.
2024-09-24 16:20:51.634 | Real-time Intraday chart data file updates started for NQZ4.CME
2024-09-24 16:20:51.634 | Intraday chart data file opened for NQZ4.CME
2024-09-24 16:20:51.634 | HD Request # 16 | Enabling Intraday chart updating for symbol.
2024-09-24 16:20:51.634 | Triggering next historical data download in queue.
2024-09-24 16:20:51.634 | HD Request # 17 | Downloading Intraday chart data for MESZ4.CME to the file MESZ4.CME.scid. Service: cme
2024-09-24 16:20:51.634 | HD Request # 17 | Download start date-time: 2024-09-24 16:20:38.000000. File last date-time: 2024-09-24 16:20:38.864004
2024-09-24 16:20:51.634 | HD Request # 17 | Using server: ds32.sierracharts.com port 10150
2024-09-24 16:20:51.634 | Socket (2) | Creating socket.
2024-09-24 16:20:51.634 | Socket (2) | New receive buffer size: 0
2024-09-24 16:20:51.634 | Socket (2) | Connecting to IP: 67.214.125.3.
2024-09-24 16:20:51.951 | Socket (4) | Socket gracefully closed by remote side.
2024-09-24 16:20:51.952 | Socket (4) | Closed.
2024-09-24 16:20:52.298 | HD Request # 17 | Setting DTC encoding to Binary VLS
2024-09-24 16:20:52.298 | HD Request # 17 | Sending historical data logon request message.
2024-09-24 16:20:52.622 | HD Request # 17 | Requesting Intraday data. Start date-time: 2024-09-24 16:20:38. Record interval: 0. Symbol: MESZ24
2024-09-24 16:20:52.948 | HD Request # 17 | Decompressing data.
2024-09-24 16:20:53.272 | HD Request # 17 | Receiving Intraday data for MESZ4.CME starting at 2024-09-24 16:20:38.864000
2024-09-24 16:20:53.272 | Socket (2) | CloseSocket call.
2024-09-24 16:20:53.272 | Socket (2) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:53.274 | Historical data download thread signaled to stop.
2024-09-24 16:20:53.274 | HD Request # 17 | Timestamp of first Intraday data file record written: 2024-09-24 16:20:46.395000.
2024-09-24 16:20:53.274 | HD Request # 17 | Received 8 Intraday data records from 2024-09-24 16:20:38.864000 to 2024-09-24 16:20:52.776001 (13.9 seconds. Delay: 0.5 seconds) and wrote 3 records for MESZ4.CME
2024-09-24 16:20:53.274 | HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2024-09-24 20:20:52.776001
2024-09-24 16:20:53.274 | Added 4 Time and Sales records to Intraday data file for MESZ4.CME after download.
2024-09-24 16:20:53.274 | HD Request # 17 | Completion time: 2s.
2024-09-24 16:20:53.274 | HD Request # 17 | Intraday data download complete for MESZ4.CME. Unique request ID: 15
2024-09-24 16:20:53.274 | Removing historical data download ID 15.
2024-09-24 16:20:53.274 | Real-time Intraday chart data file updates started for MESZ4.CME
2024-09-24 16:20:53.274 | Intraday chart data file opened for MESZ4.CME
2024-09-24 16:20:53.274 | HD Request # 17 | Enabling Intraday chart updating for symbol.
2024-09-24 16:20:53.274 | No download requests in the queue to start downloads for.
2024-09-24 16:20:53.597 | Socket (2) | Socket gracefully closed by remote side.
2024-09-24 16:20:53.597 | Socket (2) | Closed.
2024-09-24 16:20:56.285 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\ESZ4.CME.scid. Thread ID: 7560
2024-09-24 16:20:56.285 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\NQZ4.CME.scid. Thread ID: 7560
2024-09-24 16:20:56.285 | Opened cached Intraday file: C:\SierraChart - TopStep\Data\MESZ4.CME.scid. Thread ID: 7560
2024-09-24 16:20:57.205 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.2.
2024-09-24 16:20:57.205 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | New receive buffer size: 0
2024-09-24 16:20:57.205 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Connecting to IP: 216.66.0.130.
2024-09-24 16:20:59.270 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | CloseSocket call.
2024-09-24 16:20:59.270 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Shutdown started. Waiting for graceful close.
2024-09-24 16:20:59.603 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Socket gracefully closed by remote side.
2024-09-24 16:20:59.603 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Closed.
[2024-09-24 21:13:48]
John - SC Support - Posts: 36237
You are having network connectivity issues as noted by these messages:
DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Refer to the following regarding the above:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
There is no issue with our data feed today or lately.
The one thing we want you to do is to NOT use a specific server at this time. The issues related to why you needed to use a specific server have been resolved, and there have been changes to our infrastructure such that ds13 is no longer a valid data server.
But, given the specificity of the drop outs, this appears to be an issue with your Internet provider.
[2024-09-24 21:18:28]
User753526 - Posts: 51
Regarding the link to the list of things to check. I did check these and found all settings to be in order. The only time the data feed became active again was when switching to ds13, and it remained active when changing back to ds40 again. No other changes were made. So please let me know if I am to remove the ds40 server which was avoiding the Singapore server issues in the past.
Regarding my internet service provider, I also run tradingview which saw no interruption to data feed during any of the time today as well as any webpage etc. that was open. So to clarify, do you believe my ISP was down or only down for the specific Sierra Server connection?
Date Time Of Last Edit: 2024-09-24 21:20:19
[2024-09-24 21:35:25]
Given your issues, we would prefer to not use a specific server in order to allow the system to change to a different server if there is a problem with the one you are connected to.
With regards to the connectivity, the problem could be anywhere along the line in the public Internet between your location and the location of our server. Given that you are seeing a specific outage for a specific amount of time, and we are not getting other reports of issues in general, we do believe that this is not an issue with our servers or with our Internet Providers.
