Date/Time: Thu, 17 Sep 2026 19:31:10 +0000
Sierra Chart suddenly crashing, also in Safe mode, V: 2646
View Count: 595
[2024-06-16 19:35:14]
fabse - Posts: 10
I am running my instance and it suddenly crashes
- It is a sub instance
- I have started it in safe mode
- I have disabled OpenGL
- I have restarted my computer multiple times (windows 11, latest, amd64)
- Version: 2646, Rev: 50448M
It happens when I either click the button "Folder" in the "Trade Acitivity Log" > "Trades" > "Save Log As" screen or when recompiling an ASCIL file.
It does create a .dmp file in the Crashes folder.
I get when pressing the "Folder" button:
Unhandled exception at 0x00007FFCDC4E2583 (explorerframe.dll) in SierraChart.23464.dmp: 0xC0000005: Access violation reading location 0x00007FFCDDDA7C88.
And I get when it happens during "Compile Visual C++ Release":
Unhandled exception at 0x00007FFCFC734470 in SierraChart.2984.dmp: 0xC0000005: Access violation executing location 0x00007FFCFC734470.
From the stracktrace: (it is the Main Thread(
00007FFD096E9D56 mov qword ptr [rsp+50h],rax
What can I do here please? I can not really use it anymore.
Date Time Of Last Edit: 2024-06-16 20:13:44
[2024-06-16 22:42:34]
fabse - Posts: 10
Update:
I was able to narrow it done. There seem to be two things going on:
1: The exception which came up when I was compiling an ASCIL was my mistake as I am using external resources which seems to be problematic when they change and the DLL is unloaded, it works when I manually release the DLLs and recompile.
2: The second exception:
comes only up if OpenGL is enabled. I have the latest nvidia drivers installed but i keep getting the error.
[2024-06-17 21:59:56]
Sierra_Chart Engineering - Posts: 24883
In this case just do not use OpenGL. We do not believe this is a problem within Sierra Chart.
