Date/Time: Thu, 28 Nov 2024 08:22:04 +0000
Setting up 2 Instances/Trading Arrangements in Sierra Charts
View Count: 377
[2024-05-15 16:30:16]
bobstone249 - Posts: 28
Hi John, I have successfully set everything up. I have
SierraCharts Installation - Teton/Denali using Dorman Trading as the broker.
SierraCharts2 Installation - Rithmic using TakeProfitTrader as the Prop firm.
I have 2 individual installations of Sierra charts in separate folders on the C drive. Workbooks are unique to each installation.
My accounts with Rithmic/Takeprofittrader and Dorman trading are all working fine.
I just can't get any new data through to Sierra Charts2 workbook for the Rithmic/Takeprofittrader installation. There is no live data coming through. Can you please help?
I do realise that I need to use the Denali data feed. This installation of Sierra Charts (SierraCharts2) is configured as follows;
Global Settings > Data/Trade Service Settings > Current Selected Service (List): Rithmic Direct - DTC (trading)
Global Settings > Data/Trade Service Settings > Server (List): Rithmic Paper Trading-Chicago Area-Aggregated
along with my new Trading username and Trading password - both which are recognised by the Rithmic Trader Pro app
Rob
Original post: Setting up 2 Instances/Trading Arrangements in Sierra Charts
Date Time Of Last Edit: 2024-05-15 16:50:37
[2024-05-15 17:26:21]
John - SC Support - Posts: 36350
In the installation that is not working, make sure the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support For Sierra Chart Data Feeds" is set to "Yes".
If it is set to "No", then change it to "Yes", close that window by selecting OK, then select "File >> Reconnect". That should resolve the issue for you.
Otherwise, if it is already set to "Yes", then we would need to see the Message Log from that installation by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
[2024-05-16 08:30:55]
2024-05-16 08:22:59.648 | Software version: 2639 64-bit
2024-05-16 08:22:59.648 | Primary Thread ID: 16952
2024-05-16 08:22:59.648 | Usage end date: 2024-06-10
2024-05-16 08:22:59.648 | Enabled for: Advanced Features 2.
2024-05-16 08:22:59.648 | Enabled for: Sierra Chart Historical Data Service.
2024-05-16 08:22:59.648 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-05-16 08:22:59.648 | Enabled for: Delayed Denali Exchange Data Feed.
2024-05-16 08:22:59.648 | Enabled for exchange2: CME (Trading Account Required)
2024-05-16 08:22:59.648 | Enabled for exchange2: CBOT (Trading Account Required)
2024-05-16 08:22:59.648 | Enabled for exchange2: COMEX (Trading Account Required)
2024-05-16 08:22:59.648 | Enabled for exchange2: NYMEX (Trading Account Required)
2024-05-16 08:22:59.648 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-05-16 08:22:59.648 | Current selected Data/Trading service: Rithmic Direct - DTC
2024-05-16 08:22:59.648 | Custom symbol settings values: enabled
2024-05-16 08:22:59.648 | Chart Update Interval: 400
2024-05-16 08:22:59.648 | Intraday Data Storage Time Unit: 1
2024-05-16 08:22:59.648 | Time Zone: +00:00:00 (UTC+00)
2024-05-16 08:22:59.648 | 2024-05-16 08:22:59 Local computer time in UTC
2024-05-16 08:22:59.648 | 2024-05-16 08:22:59 Local computer time in SC Time Zone
2024-05-16 08:22:59.648 | 2024-05-16 08:20:17 Server time in UTC
2024-05-16 08:22:59.648 | Local computer UTC time and Server UTC time difference: 1 seconds.
2024-05-16 08:22:59.648 | Program path: C:\SierraChart2\
2024-05-16 08:22:59.648 | Data Files path: C:\SierraChart2\Data\
2024-05-16 08:22:59.648 | OS Version Number: 10.0
2024-05-16 08:22:59.648 | Locale Setting: C
2024-05-16 08:22:59.649 | DLLs: UserContributedStudies_64.dll
2024-05-16 08:22:59.649 | Allowed protected custom studies:
2024-05-16 08:22:59.649 | Crash reporter started: true
2024-05-16 08:24:31.692 | ESM4.CME 1 Min #12 | Reloading chart.
2024-05-16 08:24:31.924 | ESM4.CME 1 Min #12 | Chart data loading complete.
2024-05-16 08:24:32.093 | Mapping ESM4.CME to ESM24. Service code: cme
2024-05-16 08:24:32.094 | Denali Data Feed | Starting real-time market data updates for: ESM4.CME (ESM24). ID: 8 Service code: cme
2024-05-16 08:24:32.096 | Denali Data Feed | Connecting to the server ds27.sierracharts.com. Port 443
2024-05-16 08:24:32.101 | Denali Data Feed | Requesting security definition data for: ESM4.CME (ESM24). ID: 8
2024-05-16 08:24:32.102 | Added historical Intraday data request for ESM4.CME to the queue.
2024-05-16 08:24:32.102 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'.
2024-05-16 08:24:32.102 | Triggering next historical data download in queue.
2024-05-16 08:24:32.112 | Delaying start of download for ESM4.CME.
2024-05-16 08:24:32.129 | DTC Client socket (4) | Creating socket.
2024-05-16 08:24:32.129 | DTC Client socket (4) | New receive buffer size: 0
2024-05-16 08:24:32.129 | DTC Client socket (4) | Connecting to IP: 38.142.127.146.
2024-05-16 08:24:32.227 | Denali Data Feed | Network connection to server complete.
2024-05-16 08:24:32.227 | Denali Data Feed | Starting socket receive thread.
2024-05-16 08:24:32.227 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2024-05-16 08:24:32.351 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-05-16 08:24:32.351 | Denali Data Feed | Sending logon request message.
2024-05-16 08:24:32.460 | Denali Data Feed | Received logon response.
2024-05-16 08:24:32.460 | Denali Data Feed | Server Name: RealTimeServer.
2024-05-16 08:24:32.460 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-05-16 08:24:32.460 | Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary.
2024-05-16 08:24:32.460 | Denali Data Feed | Failed connections: 1
2024-05-16 08:24:32.460 | Denali Data Feed | Waiting for socket receive thread to end
2024-05-16 08:24:32.461 | DTC Client socket (4) | CloseSocket call.
2024-05-16 08:24:32.461 | Denali Data Feed | Disconnected from the server.
2024-05-16 08:24:32.461 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds.
2024-05-16 08:24:32.461 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-05-16 08:24:32.558 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-05-16 08:24:32.558 | DTC Client socket (4) | Closed.
2024-05-16 08:24:35.465 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 10048
2024-05-16 08:24:35.497 | DTC Client socket (4) | Creating socket.
2024-05-16 08:24:35.498 | DTC Client socket (4) | New receive buffer size: 0
2024-05-16 08:24:35.498 | DTC Client socket (4) | Connecting to IP: 38.103.85.68.
2024-05-16 08:24:35.590 | Denali Data Feed | Network connection to server complete.
2024-05-16 08:24:35.590 | Denali Data Feed | Starting socket receive thread.
2024-05-16 08:24:35.590 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2024-05-16 08:24:35.689 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-05-16 08:24:35.689 | Denali Data Feed | Sending logon request message.
2024-05-16 08:24:36.340 | Denali Data Feed | Received logon response.
2024-05-16 08:24:36.340 | Denali Data Feed | Server Name: SC Realtime Server.
2024-05-16 08:24:36.340 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-05-16 08:24:36.340 | Denali Data Feed | Successfully connected.
2024-05-16 08:24:36.340 | Denali Data Feed | Trading is not supported.
2024-05-16 08:24:36.340 | Denali Data Feed | MarketDepthIsSupported: 1
2024-05-16 08:24:36.340 | Denali Data Feed | Restarting real-time data updates for symbol: ESM4.CME -> ESM24
2024-05-16 08:24:36.516 | Denali Data Feed | Received security definition for symbol ESM4.CME
2024-05-16 08:24:41.667 | HD Request # 9 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: cme
2024-05-16 08:24:41.667 | HD Request # 9 | Download start date-time: 2024-05-07 18:44:35.000000. File last date-time: 2024-05-07 18:44:35.081000
2024-05-16 08:24:41.668 | HD Request # 9 | Using server: ds28.sierracharts.com port 10150
2024-05-16 08:24:41.702 | Socket (5) | Creating socket.
2024-05-16 08:24:41.702 | Socket (5) | New receive buffer size: 0
2024-05-16 08:24:41.702 | Socket (5) | Connecting to IP: 38.103.112.187.
2024-05-16 08:24:41.899 | HD Request # 9 | Setting DTC encoding to Binary VLS
2024-05-16 08:24:41.899 | HD Request # 9 | Sending historical data logon request message.
2024-05-16 08:24:42.257 | HD Request # 9 | Requesting Intraday data. Start date-time: 2024-05-07 18:44:35. Record interval: 1. Symbol: ESM24
2024-05-16 08:24:42.350 | HD Request # 9 | Decompressing data.
2024-05-16 08:24:42.690 | HD Request # 9 | Receiving Intraday data for ESM4.CME starting at 2024-05-07 18:44:35.081000
2024-05-16 08:24:42.983 | HD Request # 9 | Timestamp of first Intraday data file record written: 2024-05-07 18:44:35.081000.
2024-05-16 08:24:44.362 | Socket (5) | CloseSocket call.
2024-05-16 08:24:44.362 | Historical data download thread signaled to stop.
2024-05-16 08:24:44.362 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-05-16 08:24:44.363 | HD Request # 9 | Received 222052 Intraday data records from 2024-05-07 18:44:35.081000 to 2024-05-16 08:24:34.731000 (8.6 days. Delay: 9.6 seconds) and wrote 222052 records for ESM4.CME
2024-05-16 08:24:44.364 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2024-05-16 08:24:34.731000
2024-05-16 08:24:44.364 | HD Request # 9 | Completion time: 3s.
2024-05-16 08:24:44.364 | HD Request # 9 | Intraday data download complete for ESM4.CME. Unique request ID: 10
2024-05-16 08:24:44.364 | Removing historical data download ID 10.
2024-05-16 08:24:44.364 | Real-time Intraday chart data file updates started for ESM4.CME
2024-05-16 08:24:44.364 | Opened cached Intraday file: C:\SierraChart2\Data\ESM4.CME.scid. Thread ID: 16952
2024-05-16 08:24:44.364 | Intraday chart data file opened for ESM4.CME
2024-05-16 08:24:44.364 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2024-05-16 08:24:44.364 | No download requests in the queue to start downloads for.
2024-05-16 08:24:44.457 | Socket (5) | Socket gracefully closed by remote side.
2024-05-16 08:24:44.457 | Socket (5) | Closed.
2024-05-16 08:28:42.117 | File >> Disconnect selected.
2024-05-16 08:28:42.118 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2024-05-16 08:28:42.118 | DTC Client socket (1) | CloseSocket call.
2024-05-16 08:28:42.118 | DTC Client socket (1) | Max send buffers used during socket life: 3
2024-05-16 08:28:42.118 | DTC Client socket (1) | Max send buffer size during socket life: 406
2024-05-16 08:28:42.119 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2024-05-16 08:28:42.120 | Denali Data Feed | Waiting for socket receive thread to end
2024-05-16 08:28:42.120 | DTC Client socket (4) | CloseSocket call.
2024-05-16 08:28:42.121 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2024-05-16 08:28:42.121 | Denali Data Feed | Disconnected from the server.
2024-05-16 08:28:42.121 | SC Data with Depth | Waiting for socket receive thread to end
2024-05-16 08:28:42.121 | DTC Client socket (2) | CloseSocket call.
2024-05-16 08:28:42.121 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2024-05-16 08:28:42.121 | SC Data with Depth | Disconnected from the server.
2024-05-16 08:28:42.121 | Delayed Data Feed | Waiting for socket receive thread to end
2024-05-16 08:28:42.122 | DTC Client socket (3) | CloseSocket call.
2024-05-16 08:28:42.122 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2024-05-16 08:28:42.122 | Delayed Data Feed | Disconnected from the server.
2024-05-16 08:28:42.122 | Rithmic Direct - DTC | Disconnected.
2024-05-16 08:28:42.213 | DTC Client socket (4) | Socket gracefully closed by remote side.
2024-05-16 08:28:42.214 | DTC Client socket (4) | Closed.
2024-05-16 08:28:42.225 | DTC Client socket (3) | Socket gracefully closed by remote side.
2024-05-16 08:28:42.226 | DTC Client socket (3) | Closed.
2024-05-16 08:28:42.226 | DTC Client socket (1) | Socket gracefully closed by remote side.
2024-05-16 08:28:42.227 | DTC Client socket (1) | Closed.
2024-05-16 08:28:42.290 | DTC Client socket (2) | Socket gracefully closed by remote side.
2024-05-16 08:28:42.290 | DTC Client socket (2) | Closed.
2024-05-16 08:28:49.201 |
2024-05-16 08:28:49.201 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2024-05-16 08:28:49.201 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2024-05-16 08:28:49.209 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2024-05-16 08:28:49.209 | DTC Client socket (1) | New receive buffer size: 0
2024-05-16 08:28:49.209 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2024-05-16 08:28:49.311 | Rithmic Direct - DTC | Network connection to server complete.
2024-05-16 08:28:49.311 | Rithmic Direct - DTC | Starting socket receive thread.
2024-05-16 08:28:49.311 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2024-05-16 08:28:49.311 | Rithmic Direct - DTC | Sending logon request message.
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | Received logon response.
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | Server Name: .
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | Successfully connected.
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | Trading is supported.
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | Order cancel and replace is supported.
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | OCO Orders supported.
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2024-05-16 08:28:49.624 | Rithmic Direct - DTC | Connected to server complete.
2024-05-16 08:28:49.625 | No download requests in the queue to start downloads for. | Number times message added: 3
2024-05-16 08:28:49.689 | Using Bid/Ask average for last trade price for EURUSD
2024-05-16 08:28:49.689 | Using symbol data fast lookup vector
2024-05-16 08:28:49.689 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 1 Service code: fxcm
2024-05-16 08:28:49.689 | SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443
2024-05-16 08:28:49.689 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 1
2024-05-16 08:28:49.689 | Added historical Intraday data request for EURUSD to the queue.
2024-05-16 08:28:49.689 | Intraday data recording state for symbol EURUSD is set to download 'Pending'.
2024-05-16 08:28:49.689 | Triggering next historical data download in queue.
2024-05-16 08:28:49.689 | Delaying start of download for EURUSD.
2024-05-16 08:28:49.689 | Rithmic Direct - DTC | Starting real-time market data updates for: ESM24-CME. ID: 2
2024-05-16 08:28:49.689 | Rithmic Direct - DTC | Server indicated market data is not supported. Not sending market data request. Symbol: ESM24-CME.
2024-05-16 08:28:49.689 | Rithmic Direct - DTC | Requesting security definition data for: ESM24-CME. ID: 2
2024-05-16 08:28:49.689 | Rithmic Direct - DTC | Using primary service for historical data for ESM24-CME
2024-05-16 08:28:49.689 | Historical data service client indicated that downloads are not enabled. Symbol: ESM24-CME. Data Type: Intraday data.
2024-05-16 08:28:49.689 | Historical data download ID 12 not found when removing ID from outstanding request set.
2024-05-16 08:28:49.689 | Real-time Intraday chart data file updates started for ESM24-CME
2024-05-16 08:28:49.690 | Opened cached Intraday file: C:\SierraChart2\Data\ESM24-CME.scid. Thread ID: 16952
2024-05-16 08:28:49.690 | DTC Client socket (2) | Creating socket.
2024-05-16 08:28:49.690 | Intraday chart data file opened for ESM24-CME
2024-05-16 08:28:49.690 | DTC Client socket (2) | New receive buffer size: 0
2024-05-16 08:28:49.690 | DTC Client socket (2) | Connecting to IP: 38.142.170.156.
2024-05-16 08:28:49.690 | Using Bid/Ask average for last trade price for XAUUSD
2024-05-16 08:28:49.690 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 3 Service code: fxcm
2024-05-16 08:28:49.690 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 3
2024-05-16 08:28:49.690 | Added historical Intraday data request for XAUUSD to the queue.
2024-05-16 08:28:49.690 | Intraday data recording state for symbol XAUUSD is set to download 'Pending'.
2024-05-16 08:28:49.690 | Triggering next historical data download in queue.
2024-05-16 08:28:49.690 | Using Bid/Ask average for last trade price for US30
2024-05-16 08:28:49.690 | SC Data with Depth | Starting real-time market data updates for: US30. ID: 4 Service code: fxcm
2024-05-16 08:28:49.690 | SC Data with Depth | Requesting security definition data for: US30. ID: 4
2024-05-16 08:28:49.690 | Added historical Intraday data request for US30 to the queue.
2024-05-16 08:28:49.690 | Intraday data recording state for symbol US30 is set to download 'Pending'.
2024-05-16 08:28:49.691 | Using Bid/Ask average for last trade price for USOil
2024-05-16 08:28:49.691 | SC Data with Depth | Starting real-time market data updates for: USOil. ID: 5 Service code: fxcm
2024-05-16 08:28:49.691 | SC Data with Depth | Requesting security definition data for: USOil. ID: 5
2024-05-16 08:28:49.691 | Added historical Intraday data request for USOil to the queue.
2024-05-16 08:28:49.691 | Intraday data recording state for symbol USOil is set to download 'Pending'.
2024-05-16 08:28:49.691 | Triggering next historical data download in queue.
2024-05-16 08:28:49.691 | Using Bid/Ask average for last trade price for SPX500
2024-05-16 08:28:49.691 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 6 Service code: fxcm
2024-05-16 08:28:49.691 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 6
2024-05-16 08:28:49.691 | Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data
2024-05-16 08:28:49.691 | Delayed Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 7 Service code: nasdaq_exchange.data
2024-05-16 08:28:49.691 | Delayed Data Feed | Connecting to the server ds31.sierracharts.com. Port 10043
2024-05-16 08:28:49.691 | Delayed Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 7
2024-05-16 08:28:49.691 | Added historical Intraday data request for AAPL-NQTV to the queue.
2024-05-16 08:28:49.691 | Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'.
2024-05-16 08:28:49.692 | Mapping ESM4.CME to ESM24. Service code: cme
2024-05-16 08:28:49.692 | Denali Data Feed | Starting real-time market data updates for: ESM4.CME (ESM24). ID: 8 Service code: cme
2024-05-16 08:28:49.692 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 10048
2024-05-16 08:28:49.692 | DTC Client socket (3) | Creating socket.
2024-05-16 08:28:49.692 | DTC Client socket (3) | New receive buffer size: 0
2024-05-16 08:28:49.692 | Denali Data Feed | Requesting security definition data for: ESM4.CME (ESM24). ID: 8
2024-05-16 08:28:49.692 | DTC Client socket (3) | Connecting to IP: 38.103.112.189.
2024-05-16 08:28:49.692 | Added historical Intraday data request for ESM4.CME to the queue.
2024-05-16 08:28:49.692 | Intraday data recording state for symbol ESM4.CME is set to download 'Pending'.
2024-05-16 08:28:49.692 | Triggering next historical data download in queue.
2024-05-16 08:28:49.724 | DTC Client socket (4) | Creating socket.
2024-05-16 08:28:49.724 | DTC Client socket (4) | New receive buffer size: 0
2024-05-16 08:28:49.724 | DTC Client socket (4) | Connecting to IP: 38.103.112.197.
2024-05-16 08:28:49.788 | Delayed Data Feed | Network connection to server complete.
2024-05-16 08:28:49.788 | Delayed Data Feed | Starting socket receive thread.
2024-05-16 08:28:49.788 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2024-05-16 08:28:49.821 | Denali Data Feed | Network connection to server complete.
2024-05-16 08:28:49.821 | Denali Data Feed | Starting socket receive thread.
2024-05-16 08:28:49.821 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2024-05-16 08:28:49.848 | SC Data with Depth | Network connection to server complete.
2024-05-16 08:28:49.848 | SC Data with Depth | Starting socket receive thread.
2024-05-16 08:28:49.848 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard
2024-05-16 08:28:49.908 | Delayed Data Feed | Setting DTC encoding to Binary VLS
2024-05-16 08:28:49.908 | Delayed Data Feed | Sending logon request message.
2024-05-16 08:28:49.951 | Denali Data Feed | Setting DTC encoding to Binary VLS
2024-05-16 08:28:49.951 | Denali Data Feed | Sending logon request message.
2024-05-16 08:28:50.010 | SC Data with Depth | Setting DTC encoding to Binary VLS
2024-05-16 08:28:50.010 | SC Data with Depth | Sending logon request message.
2024-05-16 08:28:50.260 | SC Data with Depth | Received logon response.
2024-05-16 08:28:50.260 | SC Data with Depth | Server Name: SC Realtime Server.
2024-05-16 08:28:50.260 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2024-05-16 08:28:50.260 | SC Data with Depth | Successfully connected.
2024-05-16 08:28:50.260 | SC Data with Depth | Trading is not supported.
2024-05-16 08:28:50.260 | SC Data with Depth | MarketDepthIsSupported: 1
2024-05-16 08:28:50.260 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD
2024-05-16 08:28:50.260 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500
2024-05-16 08:28:50.260 | SC Data with Depth | Restarting real-time data updates for symbol: US30
2024-05-16 08:28:50.260 | SC Data with Depth | Restarting real-time data updates for symbol: USOil
2024-05-16 08:28:50.260 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD
2024-05-16 08:28:50.345 | Delayed Data Feed | Received logon response.
2024-05-16 08:28:50.345 | Delayed Data Feed | Server Name: SC Realtime Server.
2024-05-16 08:28:50.345 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8
2024-05-16 08:28:50.345 | Delayed Data Feed | Successfully connected.
2024-05-16 08:28:50.345 | Delayed Data Feed | Trading is not supported.
2024-05-16 08:28:50.345 | Delayed Data Feed | MarketDepthIsSupported: 1
2024-05-16 08:28:50.345 | Delayed Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV
2024-05-16 08:28:50.511 | SC Data with Depth | Received security definition for symbol EURUSD
2024-05-16 08:28:50.511 | SC Data with Depth | Received security definition for symbol SPX500
2024-05-16 08:28:50.511 | SC Data with Depth | Received security definition for symbol US30
2024-05-16 08:28:50.511 | SC Data with Depth | Received security definition for symbol USOil
2024-05-16 08:28:50.511 | SC Data with Depth | Received security definition for symbol XAUUSD
2024-05-16 08:28:50.533 | Delayed Data Feed | Received security definition for symbol AAPL-NQTV
2024-05-16 08:28:50.576 | Denali Data Feed | Received logon response.
2024-05-16 08:28:50.576 | Denali Data Feed | Server Name: SC Realtime Server.
2024-05-16 08:28:50.576 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2024-05-16 08:28:50.576 | Denali Data Feed | Successfully connected.
2024-05-16 08:28:50.576 | Denali Data Feed | Trading is not supported.
2024-05-16 08:28:50.576 | Denali Data Feed | MarketDepthIsSupported: 1
2024-05-16 08:28:50.576 | Denali Data Feed | Restarting real-time data updates for symbol: ESM4.CME -> ESM24
2024-05-16 08:28:50.763 | Denali Data Feed | Received security definition for symbol ESM4.CME
2024-05-16 08:28:55.375 | HD Request # 10 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm
2024-05-16 08:28:55.375 | HD Request # 10 | Download start date-time: 2024-05-16 08:28:39.000000. File last date-time: 2024-05-16 08:28:39.000000
2024-05-16 08:28:55.375 | HD Request # 10 | Using server: ds13-2.sierracharts.com port 10149
2024-05-16 08:28:55.375 | Socket (5) | Creating socket.
2024-05-16 08:28:55.375 | Socket (5) | New receive buffer size: 0
2024-05-16 08:28:55.375 | Socket (5) | Connecting to IP: 38.142.170.156.
2024-05-16 08:28:55.719 | HD Request # 10 | Setting DTC encoding to Binary VLS
2024-05-16 08:28:55.719 | HD Request # 10 | Sending historical data logon request message.
2024-05-16 08:28:55.919 | HD Request # 10 | Requesting Intraday data. Start date-time: 2024-05-16 08:28:39. Record interval: 1. Symbol: EURUSD
2024-05-16 08:28:56.076 | HD Request # 10 | Decompressing data.
2024-05-16 08:28:56.232 | HD Request # 10 | Receiving Intraday data for EURUSD starting at 2024-05-16 08:28:39.450000
2024-05-16 08:28:56.233 | Socket (5) | CloseSocket call.
2024-05-16 08:28:56.233 | Historical data download thread signaled to stop.
2024-05-16 08:28:56.233 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-05-16 08:28:56.233 | HD Request # 10 | Timestamp of first Intraday data file record written: 2024-05-16 08:28:39.450000.
2024-05-16 08:28:56.233 | HD Request # 10 | Received 9 Intraday data records from 2024-05-16 08:28:39.450000 to 2024-05-16 08:28:53.369000 (13.9 seconds. Delay: 2.9 seconds) and wrote 9 records for EURUSD
2024-05-16 08:28:56.234 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2024-05-16 08:28:53.369000
2024-05-16 08:28:56.234 | Added 2 Time and Sales records to Intraday data file for EURUSD after download.
2024-05-16 08:28:56.234 | HD Request # 10 | Completion time: 1s.
2024-05-16 08:28:56.234 | HD Request # 10 | Intraday data download complete for EURUSD. Unique request ID: 11
2024-05-16 08:28:56.234 | Removing historical data download ID 11.
2024-05-16 08:28:56.234 | Real-time Intraday chart data file updates started for EURUSD
2024-05-16 08:28:56.234 | Opened cached Intraday file: C:\SierraChart2\Data\EURUSD.scid. Thread ID: 16952
2024-05-16 08:28:56.234 | Intraday chart data file opened for EURUSD
2024-05-16 08:28:56.234 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2024-05-16 08:28:56.234 | Triggering next historical data download in queue.
2024-05-16 08:28:56.234 | HD Request # 11 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm
2024-05-16 08:28:56.234 | HD Request # 11 | Download start date-time: 2024-05-16 08:28:41.000000. File last date-time: 2024-05-16 08:28:41.000000
2024-05-16 08:28:56.234 | HD Request # 11 | Using server: ds4.sierracharts.com port 10150
2024-05-16 08:28:56.235 | Socket (6) | Creating socket.
2024-05-16 08:28:56.235 | Socket (6) | New receive buffer size: 0
2024-05-16 08:28:56.235 | Socket (6) | Connecting to IP: 38.103.112.200.
2024-05-16 08:28:56.391 | Socket (5) | Socket gracefully closed by remote side.
2024-05-16 08:28:56.391 | Socket (5) | Closed.
2024-05-16 08:28:56.468 | HD Request # 11 | Setting DTC encoding to Binary VLS
2024-05-16 08:28:56.468 | HD Request # 11 | Sending historical data logon request message.
2024-05-16 08:28:56.810 | HD Request # 11 | Requesting Intraday data. Start date-time: 2024-05-16 08:28:41. Record interval: 1. Symbol: XAUUSD
2024-05-16 08:28:56.908 | HD Request # 11 | Decompressing data.
2024-05-16 08:28:57.004 | HD Request # 11 | Receiving Intraday data for XAUUSD starting at 2024-05-16 08:28:41.002000
2024-05-16 08:28:57.005 | Socket (6) | CloseSocket call.
2024-05-16 08:28:57.005 | Historical data download thread signaled to stop.
2024-05-16 08:28:57.005 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-05-16 08:28:57.005 | HD Request # 11 | Timestamp of first Intraday data file record written: 2024-05-16 08:28:41.002000.
2024-05-16 08:28:57.006 | HD Request # 11 | Received 12 Intraday data records from 2024-05-16 08:28:41.002000 to 2024-05-16 08:28:54.192000 (13.2 seconds. Delay: 2.8 seconds) and wrote 12 records for XAUUSD
2024-05-16 08:28:57.006 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2024-05-16 08:28:54.192000
2024-05-16 08:28:57.006 | Added 2 Time and Sales records to Intraday data file for XAUUSD after download.
2024-05-16 08:28:57.006 | HD Request # 11 | Completion time: 1s.
2024-05-16 08:28:57.006 | HD Request # 11 | Intraday data download complete for XAUUSD. Unique request ID: 13
2024-05-16 08:28:57.006 | Removing historical data download ID 13.
2024-05-16 08:28:57.006 | Real-time Intraday chart data file updates started for XAUUSD
2024-05-16 08:28:57.007 | Opened cached Intraday file: C:\SierraChart2\Data\XAUUSD.scid. Thread ID: 16952
2024-05-16 08:28:57.007 | Intraday chart data file opened for XAUUSD
2024-05-16 08:28:57.007 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2024-05-16 08:28:57.007 | Triggering next historical data download in queue.
2024-05-16 08:28:57.007 | HD Request # 12 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm
2024-05-16 08:28:57.007 | HD Request # 12 | Download start date-time: 2024-05-16 08:28:41.000000. File last date-time: 2024-05-16 08:28:41.000000
2024-05-16 08:28:57.007 | HD Request # 12 | Using server: ds12.sierracharts.com port 10149
2024-05-16 08:28:57.007 | Socket (5) | Creating socket.
2024-05-16 08:28:57.007 | Socket (5) | New receive buffer size: 0
2024-05-16 08:28:57.007 | Socket (5) | Connecting to IP: 38.103.112.181.
2024-05-16 08:28:57.102 | Socket (6) | Socket gracefully closed by remote side.
2024-05-16 08:28:57.102 | Socket (6) | Closed.
2024-05-16 08:28:57.215 | HD Request # 12 | Setting DTC encoding to Binary VLS
2024-05-16 08:28:57.215 | HD Request # 12 | Sending historical data logon request message.
2024-05-16 08:28:57.559 | HD Request # 12 | Requesting Intraday data. Start date-time: 2024-05-16 08:28:41. Record interval: 1. Symbol: US30
2024-05-16 08:28:57.655 | HD Request # 12 | Decompressing data.
2024-05-16 08:28:57.750 | HD Request # 12 | Receiving Intraday data for US30 starting at 2024-05-16 08:28:41.154000
2024-05-16 08:28:57.750 | Socket (5) | CloseSocket call.
2024-05-16 08:28:57.750 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-05-16 08:28:57.751 | Historical data download thread signaled to stop.
2024-05-16 08:28:57.751 | HD Request # 12 | Timestamp of first Intraday data file record written: 2024-05-16 08:28:41.154000.
2024-05-16 08:28:57.751 | HD Request # 12 | Received 6 Intraday data records from 2024-05-16 08:28:41.154000 to 2024-05-16 08:28:54.503000 (13.3 seconds. Delay: 3.2 seconds) and wrote 6 records for US30
2024-05-16 08:28:57.751 | HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2024-05-16 08:28:54.503000
2024-05-16 08:28:57.751 | HD Request # 12 | Completion time: 0s.
2024-05-16 08:28:57.751 | HD Request # 12 | Intraday data download complete for US30. Unique request ID: 14
2024-05-16 08:28:57.751 | Removing historical data download ID 14.
2024-05-16 08:28:57.751 | Real-time Intraday chart data file updates started for US30
2024-05-16 08:28:57.751 | Opened cached Intraday file: C:\SierraChart2\Data\US30.scid. Thread ID: 16952
2024-05-16 08:28:57.751 | Intraday chart data file opened for US30
2024-05-16 08:28:57.751 | HD Request # 12 | Enabling Intraday chart updating for symbol.
2024-05-16 08:28:57.751 | Triggering next historical data download in queue.
2024-05-16 08:28:57.752 | HD Request # 13 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm
2024-05-16 08:28:57.752 | HD Request # 13 | Download start date-time: 2024-05-16 08:28:41.000000. File last date-time: 2024-05-16 08:28:41.000000
2024-05-16 08:28:57.752 | HD Request # 13 | Using server: ds13-2.sierracharts.com port 10150
2024-05-16 08:28:57.752 | Socket (6) | Creating socket.
2024-05-16 08:28:57.752 | Socket (6) | New receive buffer size: 0
2024-05-16 08:28:57.752 | Socket (6) | Connecting to IP: 38.142.170.156.
2024-05-16 08:28:57.847 | Socket (5) | Socket gracefully closed by remote side.
2024-05-16 08:28:57.847 | Socket (5) | Closed.
2024-05-16 08:28:58.089 | HD Request # 13 | Setting DTC encoding to Binary VLS
2024-05-16 08:28:58.089 | HD Request # 13 | Sending historical data logon request message.
2024-05-16 08:28:58.295 | HD Request # 13 | Requesting Intraday data. Start date-time: 2024-05-16 08:28:41. Record interval: 1. Symbol: USOil
2024-05-16 08:28:58.457 | HD Request # 13 | Decompressing data.
2024-05-16 08:28:58.619 | HD Request # 13 | Receiving Intraday data for USOil starting at 2024-05-16 08:28:41.132000
2024-05-16 08:28:58.619 | Socket (6) | CloseSocket call.
2024-05-16 08:28:58.619 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-05-16 08:28:58.620 | Historical data download thread signaled to stop.
2024-05-16 08:28:58.620 | HD Request # 13 | Timestamp of first Intraday data file record written: 2024-05-16 08:28:41.132000.
2024-05-16 08:28:58.620 | HD Request # 13 | Received 9 Intraday data records from 2024-05-16 08:28:41.132000 to 2024-05-16 08:28:55.343000 (14.2 seconds. Delay: 3.3 seconds) and wrote 9 records for USOil
2024-05-16 08:28:58.621 | HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2024-05-16 08:28:55.343000
2024-05-16 08:28:58.621 | Added 2 Time and Sales records to Intraday data file for USOil after download.
2024-05-16 08:28:58.621 | HD Request # 13 | Completion time: 1s.
2024-05-16 08:28:58.621 | HD Request # 13 | Intraday data download complete for USOil. Unique request ID: 15
2024-05-16 08:28:58.621 | Removing historical data download ID 15.
2024-05-16 08:28:58.621 | Real-time Intraday chart data file updates started for USOil
2024-05-16 08:28:58.621 | Opened cached Intraday file: C:\SierraChart2\Data\USOil.scid. Thread ID: 16952
2024-05-16 08:28:58.621 | Intraday chart data file opened for USOil
2024-05-16 08:28:58.621 | HD Request # 13 | Enabling Intraday chart updating for symbol.
2024-05-16 08:28:58.621 | Triggering next historical data download in queue.
2024-05-16 08:28:58.621 | HD Request # 14 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data
2024-05-16 08:28:58.621 | HD Request # 14 | Download start date-time: 2024-05-16 08:13:28.000000. File last date-time: 2024-05-16 08:13:28.000000
2024-05-16 08:28:58.621 | HD Request # 14 | Using server: ds30.sierracharts.com port 10149
2024-05-16 08:28:58.621 | Socket (5) | Creating socket.
2024-05-16 08:28:58.622 | Socket (5) | New receive buffer size: 0
2024-05-16 08:28:58.622 | Socket (5) | Connecting to IP: 38.103.112.195.
2024-05-16 08:28:58.782 | Socket (6) | Socket gracefully closed by remote side.
2024-05-16 08:28:58.782 | Socket (6) | Closed.
2024-05-16 08:28:58.820 | HD Request # 14 | Setting DTC encoding to Binary VLS
2024-05-16 08:28:58.820 | HD Request # 14 | Sending historical data logon request message.
2024-05-16 08:28:59.177 | HD Request # 14 | Requesting Intraday data. Start date-time: 2024-05-16 08:13:28. Record interval: 1. Symbol: AAPL-NQTV
2024-05-16 08:28:59.275 | HD Request # 14 | Decompressing data.
2024-05-16 08:28:59.369 | HD Request # 14 | Receiving Intraday data for AAPL-NQTV starting at 2024-05-16 08:13:28.392000
2024-05-16 08:28:59.370 | Socket (5) | CloseSocket call.
2024-05-16 08:28:59.370 | Socket (5) | Shutdown started. Waiting for graceful close.
2024-05-16 08:28:59.370 | Historical data download thread signaled to stop.
2024-05-16 08:28:59.370 | HD Request # 14 | Timestamp of first Intraday data file record written: 2024-05-16 08:13:28.392000.
2024-05-16 08:28:59.370 | HD Request # 14 | Received 2 Intraday data records from 2024-05-16 08:13:28.392000 to 2024-05-16 08:13:46.716000 (18.3 seconds. Delay: 15.2 minutes) and wrote 2 records for AAPL-NQTV
2024-05-16 08:28:59.370 | HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2024-05-16 08:13:46.716000
2024-05-16 08:28:59.370 | HD Request # 14 | Completion time: 1s.
2024-05-16 08:28:59.370 | HD Request # 14 | Intraday data download complete for AAPL-NQTV. Unique request ID: 16
2024-05-16 08:28:59.370 | Removing historical data download ID 16.
2024-05-16 08:28:59.370 | Real-time Intraday chart data file updates started for AAPL-NQTV
2024-05-16 08:28:59.371 | Opened cached Intraday file: C:\SierraChart2\Data\AAPL-NQTV.scid. Thread ID: 16952
2024-05-16 08:28:59.371 | Intraday chart data file opened for AAPL-NQTV
2024-05-16 08:28:59.371 | HD Request # 14 | Enabling Intraday chart updating for symbol.
2024-05-16 08:28:59.371 | Triggering next historical data download in queue.
2024-05-16 08:28:59.371 | HD Request # 15 | Downloading Intraday chart data for ESM4.CME to the file ESM4.CME.scid. Service: cme
2024-05-16 08:28:59.371 | HD Request # 15 | Download start date-time: 2024-05-16 08:28:38.000000. File last date-time: 2024-05-16 08:28:38.000000
2024-05-16 08:28:59.371 | HD Request # 15 | Using server: ds26.sierracharts.com port 10150
2024-05-16 08:28:59.371 | Socket (6) | Creating socket.
2024-05-16 08:28:59.371 | Socket (6) | New receive buffer size: 0
2024-05-16 08:28:59.371 | Socket (6) | Connecting to IP: 38.103.112.197.
2024-05-16 08:28:59.467 | Socket (5) | Socket gracefully closed by remote side.
2024-05-16 08:28:59.467 | Socket (5) | Closed.
2024-05-16 08:28:59.571 | HD Request # 15 | Setting DTC encoding to Binary VLS
2024-05-16 08:28:59.571 | HD Request # 15 | Sending historical data logon request message.
2024-05-16 08:28:59.931 | HD Request # 15 | Requesting Intraday data. Start date-time: 2024-05-16 08:28:38. Record interval: 1. Symbol: ESM24
2024-05-16 08:29:00.029 | HD Request # 15 | Decompressing data.
2024-05-16 08:29:00.124 | HD Request # 15 | Receiving Intraday data for ESM4.CME starting at 2024-05-16 08:28:38.269000
2024-05-16 08:29:00.124 | Socket (6) | CloseSocket call.
2024-05-16 08:29:00.125 | Socket (6) | Shutdown started. Waiting for graceful close.
2024-05-16 08:29:00.125 | Historical data download thread signaled to stop.
2024-05-16 08:29:00.125 | HD Request # 15 | Timestamp of first Intraday data file record written: 2024-05-16 08:28:38.269000.
2024-05-16 08:29:00.125 | HD Request # 15 | Received 6 Intraday data records from 2024-05-16 08:28:38.269000 to 2024-05-16 08:28:54.162000 (15.9 seconds. Delay: 6.0 seconds) and wrote 6 records for ESM4.CME
2024-05-16 08:29:00.125 | HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2024-05-16 08:28:54.162000
2024-05-16 08:29:00.125 | HD Request # 15 | Completion time: 1s.
2024-05-16 08:29:00.125 | HD Request # 15 | Intraday data download complete for ESM4.CME. Unique request ID: 17
2024-05-16 08:29:00.125 | Removing historical data download ID 17.
2024-05-16 08:29:00.125 | Real-time Intraday chart data file updates started for ESM4.CME
2024-05-16 08:29:00.126 | Opened cached Intraday file: C:\SierraChart2\Data\ESM4.CME.scid. Thread ID: 16952
2024-05-16 08:29:00.126 | Intraday chart data file opened for ESM4.CME
2024-05-16 08:29:00.126 | HD Request # 15 | Enabling Intraday chart updating for symbol.
2024-05-16 08:29:00.126 | No download requests in the queue to start downloads for.
2024-05-16 08:29:00.222 | Socket (6) | Socket gracefully closed by remote side.
2024-05-16 08:29:00.222 | Socket (6) | Closed.
2024-05-16 08:29:09.207 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Creating socket. Using TLS 1.2.
2024-05-16 08:29:09.208 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | New receive buffer size: 0
2024-05-16 08:29:09.208 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Connecting to IP: 38.79.0.89.
2024-05-16 08:29:09.784 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Socket gracefully closed by remote side. | Number times message added: 1
2024-05-16 08:29:09.786 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | CloseSocket call.
2024-05-16 08:29:09.786 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2024-05-16 08:29:09.786 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (5) | Closed.
[2024-05-16 08:32:45]
John, the code is ESM4.CME.
I have followed your instructions and opened a standard graph within SC. From my observation, this graph appears to be live and is updating. My chartbook isn't. I have uploaded a screenshot to show the last data update May 7th, hope this helps.
John, whilst you are dealing with this, could I also ask - is it possible to have live data feed for the SIM in Sierra charts?
Regards
Rob
Date Time Of Last Edit: 2024-05-16 10:07:03
imageScreenshot 2024-05-16 093830.png / V - Attached On 2024-05-16 08:40:54 UTC - Size: 338.48 KB - 50 views
[2024-05-16 15:09:07]
We see a few symbols that are not correct for Rithmic in your log. In particular we see at least one chart that is trying to get data for "ESM24-CME". That symbol needs to be changed to "ESM4.CME".
To update the symbols, open the chartbook and select "Edit >> Translate Symbols to Current Service". This will take care of the above.
But, there are also other symbols for CFDs and FOREX that we recommend removing from that chartbook as well, as Rithmic tends to have trouble with any symbol they do not recognize. So items like "USOIL", "XAUUSD", "AAPL-NQTV" should be removed. If you want to chart these symbols, then we would recommend doing so in the installation that is connected to Teton, as that one can handle these. Or, you could install a 3rd Sierra Chart just for those items.
We are not sure what you mean by "is it possible to have live data feed for the SIM in Sierra charts?". What exactly are you wanting to do?
[2024-05-16 16:26:50]
Hi John, thank you for your response.
Please ignore my question about the live data feed for SIM, I have resolved that one.
a) Your comment - "But, there are also other symbols for CFDs and FOREX that we recommend removing from that chartbook as well, as Rithmic tends to have trouble with any symbol they do not recognize. So items like "USOIL", "XAUUSD", "AAPL-NQTV" should be removed. If you want to chart these symbols, then we would recommend doing so in the installation that is connected to Teton, as that one can handle these. Or, you could install a 3rd Sierra Chart just for those items."
How do I remove these, didn't know they were in the chartbook?
Sorry to be painful, but I have one more question.
b) For the Denali/Teton SC installation I am running. When changing from the Micro version of Crude Oil (MCLN24_FUT_CME) to the Mini version (CLN24_FUT_CME) I am only receiving market profile data for the last 11 days. When I simply change back to the Mini, without changing any settings, I receive 12 months.
The other chart in the chartbook is ES S&P500 (ESM24_FUT_CME & MESM24_FUT_CME). When I carry out the same process of moving from micro to mini it works fine, I get 12 months on each symbol.
The settings are almost identical as the market profile for CL is a copy of the ES market profile chart with some amendments like the symbol. There has been a new contract rollover on CL today but I've never experienced this before.
Load data limiting method (List): "Use Days To Load"
Days to load for intraday chart data type: "365"
Any ideas what this could be?
Date Time Of Last Edit: 2024-05-16 17:02:37
[2024-05-16 17:49:41]
a) Most likely they are charts, but the list of everywhere to check for these symbols is at the following link:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
b) Is the chart setup as a Continuous Futures Contract chart?
Also, refer to the following:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
