Date/Time: Sun, 24 Nov 2024 17:00:07 +0000
Downloadig Historical Data isn't work now
View Count: 206
[2024-05-08 18:44:13] |
janos bardon - Posts: 40 |
My question is, which subfolder in the Sierrachart directory is responsible for downloading Historical Data (RIM, NPP...)? Because my home computer does not download the data, I can't see real time chart, although Chart Dome works perfectly in real time, Sierrachart works perfectly on my office computer, so if I know which folder I need to copy from the office computer to the home computer, my problem is solved. |
[2024-05-08 19:28:03] |
If you are asking where the files are located, then the data is stored in the 'Data' folder under the main Sierra Chart installation folder. The Intraday data is stored in files with the extension of .scid and daily data is stored in files with the extension of .dly. Because my home computer does not download the data, I can't see real time chart, although Chart Dome works perfectly in real time, Sierrachart works perfectly on my office computer, so if I know which folder I need to copy from the office computer to the home computer, my problem is solved.
Our guess is that you are trying to connect to the same Rithmic account from both your office and home computer, and Rithmic does not allow this. But if you get us your Message Log from the computer that is not working we can say for sure. Follow these instructions to get us the Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-09 13:37:52] |
2024-05-09 15:35:04.732 | Trade activity files set size: 3964 2024-05-09 15:35:04.782 | Reading Internal Order ID file. 2024-05-09 15:35:04.795 | Reading Trade Orders file. 2024-05-09 15:35:04.797 | Reading Trade Positions file. 2024-05-09 15:35:04.797 | Reading Trade Account Data files. 2024-05-09 15:35:04.797 | UDPListener (1152). Port 22904 | Listening on UDP port 22904. 2024-05-09 15:35:04.797 | Software version: 2634 64-bit 2024-05-09 15:35:04.797 | Primary Thread ID: 11364 2024-05-09 15:35:04.797 | Usage end date: 2024-07-29 2024-05-09 15:35:04.797 | Enabled for: Sierra Chart Historical Data Service. 2024-05-09 15:35:04.797 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-05-09 15:35:04.797 | Enabled for: Delayed Denali Exchange Data Feed. 2024-05-09 15:35:04.797 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-05-09 15:35:04.797 | Current selected Data/Trading service: Rithmic Direct - DTC 2024-05-09 15:35:04.797 | Custom symbol settings values: enabled 2024-05-09 15:35:04.797 | Chart Update Interval: 500 2024-05-09 15:35:04.797 | Intraday Data Storage Time Unit: 0 2024-05-09 15:35:04.797 | Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) 2024-05-09 15:35:04.797 | 2024-05-09 13:35:04 Local computer time in UTC 2024-05-09 15:35:04.797 | 2024-05-09 15:35:04 Local computer time in SC Time Zone 2024-05-09 15:35:04.797 | 2024-05-09 13:34:57 Server time in UTC 2024-05-09 15:35:04.797 | Local computer UTC time and Server UTC time difference: 6 seconds. 2024-05-09 15:35:04.797 | Notice: Your computer's clock is off by 6 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes' or 'Global Settings -> Set System Date-Time from NTP Servers'. 2024-05-09 15:35:04.797 | Program path: C:\SierraChart\ 2024-05-09 15:35:04.797 | Data Files path: C:\SierraChart\Data\ 2024-05-09 15:35:04.797 | OS Version Number: 6.1 2024-05-09 15:35:04.797 | Locale Setting: C 2024-05-09 15:35:04.800 | DLLs: IOAMT.dll, UserContributedStudies.dll, UserContributedStudies_64.dll 2024-05-09 15:35:04.800 | Allowed protected custom studies: 2024-05-09 15:35:04.800 | Crash reporter started: true 2024-05-09 15:35:04.800 | 2024-05-09 15:35:04.817 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. 2024-05-09 15:35:04.862 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-05-09 15:35:04.868 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. 2024-05-09 15:35:04.869 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0 2024-05-09 15:35:04.869 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. 2024-05-09 15:35:05.035 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-05-09 15:35:05.035 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-05-09 15:35:05.406 | Received 5 login tokens. 2024-05-09 15:35:05.816 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | Number times message added: 1 2024-05-09 15:35:05.816 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call. 2024-05-09 15:35:05.816 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-05-09 15:35:05.816 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed. 2024-05-09 15:35:06.328 | Symbol settings MD5 received. Request ID: 1. 2024-05-09 15:35:06.328 | Symbol settings are up-to-date for rithmic_v2.trading. 2024-05-09 15:35:07.329 | Requested user files to download. 2024-05-09 15:35:09.342 | 2024-05-09 15:35:09.342 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Europe-Aggregated 2024-05-09 15:35:09.342 | Rithmic Direct - DTC | Connecting to the server rsc-ie.rithmic.com. Port 40809 2024-05-09 15:35:09.479 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-05-09 15:35:09.479 | DTC Client socket (1) | New receive buffer size: 0 2024-05-09 15:35:09.479 | DTC Client socket (1) | Connecting to IP: 54.216.199.59. 2024-05-09 15:35:09.529 | Rithmic Direct - DTC | Network connection to server complete. 2024-05-09 15:35:09.529 | Rithmic Direct - DTC | Starting socket receive thread. 2024-05-09 15:35:09.529 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-05-09 15:35:09.529 | Rithmic Direct - DTC | Sending logon request message. 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | Received logon response. 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | Server Name: . 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | Successfully connected. 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | Trading is supported. 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | OCO Orders supported. 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2024-05-09 15:35:09.787 | Rithmic Direct - DTC | Connected to server complete. 2024-05-09 15:35:09.787 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-05-09 15:35:09.787 | Updated verified funded futures trading account ending date to: 2024-06-08 13:35:09 | Number times message added: 1 2024-05-09 15:35:14.768 | MNQM4.CME 1 Min #1 | Reloading chart. 2024-05-09 15:35:15.271 | Using symbol data fast lookup vector 2024-05-09 15:35:15.271 | Rithmic Direct - DTC | Starting real-time market data updates for: MNQM4.CME. ID: 1 Service code: rithmic.trading 2024-05-09 15:35:15.271 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-ie.rithmic.com. Port 40812 2024-05-09 15:35:15.271 | DTC Client socket (3) | Creating socket. Using TLS 1.2. 2024-05-09 15:35:15.271 | DTC Client socket (3) | New receive buffer size: 0 2024-05-09 15:35:15.271 | DTC Client socket (3) | Connecting to IP: 54.216.199.59. 2024-05-09 15:35:15.271 | Rithmic Direct - DTC | Requesting security definition data for: MNQM4.CME. ID: 1 2024-05-09 15:35:15.271 | Starting DelayedDownloadMonitoringTimer 2024-05-09 15:35:15.271 | Starting HDTimeoutTimer 2024-05-09 15:35:15.271 | Added historical Intraday data request for MNQM4.CME to the queue. 2024-05-09 15:35:15.271 | Intraday data recording state for symbol MNQM4.CME is set to download 'Pending'. 2024-05-09 15:35:15.271 | Triggering next historical data download in queue. 2024-05-09 15:35:15.271 | Delaying start of download for MNQM4.CME. 2024-05-09 15:35:15.321 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-05-09 15:35:15.321 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-05-09 15:35:15.321 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-05-09 15:35:15.321 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-05-09 15:35:15.590 | Rithmic Direct - DTC (Data) | Received logon response. 2024-05-09 15:35:15.590 | Rithmic Direct - DTC (Data) | Server Name: . 2024-05-09 15:35:15.590 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-05-09 15:35:15.590 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-05-09 15:35:15.590 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-05-09 15:35:15.590 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-05-09 15:35:15.590 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-05-09 15:35:15.590 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MNQM4.CME 2024-05-09 15:35:15.883 | Rithmic Direct - DTC (Data) | Received security definition for symbol MNQM4.CME 2024-05-09 15:35:20.340 | HD Request # 1 | Downloading Intraday chart data for MNQM4.CME to the file MNQM4.CME.scid. Service: rithmic.trading 2024-05-09 15:35:20.340 | HD Request # 1 | Download start date-time: 2024-05-08 17:53:07.000000. File last date-time: 2024-05-08 17:53:07.935000 2024-05-09 15:35:20.340 | HD Request # 1 | Using server: rsc-ie.rithmic.com port 40811. Use encryption. 2024-05-09 15:35:20.340 | Socket (2) | Creating socket. Using TLS 1.2. 2024-05-09 15:35:20.340 | Socket (2) | New receive buffer size: 0 2024-05-09 15:35:20.340 | Socket (2) | Connecting to IP: 54.216.199.59. 2024-05-09 15:35:20.390 | HD Request # 1 | Sending historical data logon request message. 2024-05-09 15:35:20.637 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-05-08 17:53:07. Record interval: 0. Symbol: MNQM4.CME 2024-05-09 15:35:22.502 | MNQM4.CME 1 Min #1 | Chart data loading complete. 2024-05-09 15:35:22.724 | HD Request # 1 | Receiving Intraday data for MNQM4.CME starting at 2024-05-08 17:53:07.570000 2024-05-09 15:35:23.354 | HD Request # 1 | Timestamp of first Intraday data file record written: 2024-05-08 17:53:07.966000. 2024-05-09 15:35:29.358 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Creating socket. Using TLS 1.2. 2024-05-09 15:35:29.358 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | New receive buffer size: 0 2024-05-09 15:35:29.358 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Connecting to IP: 38.79.0.89. 2024-05-09 15:35:29.950 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2024-05-09 15:35:30.200 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Socket gracefully closed by remote side. | Number times message added: 1 2024-05-09 15:35:30.200 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | CloseSocket call. 2024-05-09 15:35:30.200 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-05-09 15:35:30.200 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (4) | Closed. 2024-05-09 15:35:30.760 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2024-06-04"}. Success=true 2024-05-09 15:36:44.926 | File >> Disconnect selected. 2024-05-09 15:36:44.926 | Rithmic Direct - DTC (Data) | Waiting for socket receive thread to end 2024-05-09 15:36:44.926 | DTC Client socket (3) | CloseSocket call. 2024-05-09 15:36:44.927 | DTC Client socket (3) | Shutdown started. Waiting for graceful close. 2024-05-09 15:36:44.927 | Rithmic Direct - DTC (Data) | Disconnected from the server. 2024-05-09 15:36:44.927 | Rithmic Direct - DTC | Waiting for socket receive thread to end 2024-05-09 15:36:44.927 | DTC Client socket (1) | CloseSocket call. 2024-05-09 15:36:44.927 | Rithmic Direct - DTC | Disconnected. 2024-05-09 15:36:44.927 | HD Request # 1 | Active download canceled. 2024-05-09 15:36:44.927 | Historical data download thread signaled to stop. 2024-05-09 15:36:44.927 | Socket (2) | CloseSocket call. 2024-05-09 15:36:44.928 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-05-09 15:36:44.928 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-05-09 15:36:44.928 | HD Request # 1 | Received 494076 Intraday data records from 2024-05-08 17:53:07.570000 to 2024-05-09 15:35:09.458001 (21.7 hours. Delay: 95.5 seconds) and wrote 494068 records for MNQM4.CME 2024-05-09 15:36:44.928 | HD Request # 1 | Completion time: 1m 24s. 2024-05-09 15:36:44.928 | HD Request # 1 | Intraday data download complete for MNQM4.CME. Unique request ID: 1 2024-05-09 15:36:44.928 | Removing historical data download ID 1. 2024-05-09 15:36:44.928 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-05-09 15:36:44.928 | 2024-05-09 15:36:44.928 | No download requests in the queue to start downloads for. 2024-05-09 15:36:44.977 | Socket (2) | Socket gracefully closed by remote side. 2024-05-09 15:36:44.977 | Socket (2) | Closed. 2024-05-09 15:36:44.980 | DTC Client socket (3) | Socket gracefully closed by remote side. 2024-05-09 15:36:44.980 | DTC Client socket (3) | Closed. 2024-05-09 15:36:44.981 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-05-09 15:36:44.981 | DTC Client socket (1) | Closed. 2024-05-09 15:36:51.605 | 2024-05-09 15:36:51.605 | Rithmic Direct - DTC | Using server connection: Rithmic 01-Europe-Aggregated 2024-05-09 15:36:51.605 | Rithmic Direct - DTC | Connecting to the server rsc-ie.rithmic.com. Port 40809 2024-05-09 15:36:51.605 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2024-05-09 15:36:51.605 | DTC Client socket (1) | New receive buffer size: 0 2024-05-09 15:36:51.605 | DTC Client socket (1) | Connecting to IP: 54.216.199.59. 2024-05-09 15:36:51.655 | Rithmic Direct - DTC | Network connection to server complete. 2024-05-09 15:36:51.655 | Rithmic Direct - DTC | Starting socket receive thread. 2024-05-09 15:36:51.655 | Rithmic Direct - DTC | Setting DTC encoding to Binary 2024-05-09 15:36:51.655 | Rithmic Direct - DTC | Sending logon request message. 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | Received logon response. 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | Server Name: . 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | Successfully connected. 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | Trading is supported. 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | Order cancel and replace is supported. 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | OCO Orders supported. 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: . 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | MarketDepthIsSupported: 0 2024-05-09 15:36:51.910 | Rithmic Direct - DTC | Connected to server complete. 2024-05-09 15:36:51.910 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-05-09 15:36:51.910 | Updated verified funded futures trading account ending date to: 2024-06-08 13:36:51 2024-05-09 15:36:52.060 | Updated verified funded futures trading account ending date to: 2024-06-08 13:36:52 2024-05-09 15:36:52.148 | Using symbol data fast lookup vector 2024-05-09 15:36:52.148 | Rithmic Direct - DTC | Starting real-time market data updates for: MNQM4.CME. ID: 1 Service code: rithmic.trading 2024-05-09 15:36:52.148 | Rithmic Direct - DTC (Data) | Connecting to the server rsc-ie.rithmic.com. Port 40812 2024-05-09 15:36:52.148 | DTC Client socket (2) | Creating socket. Using TLS 1.2. 2024-05-09 15:36:52.148 | DTC Client socket (2) | New receive buffer size: 0 2024-05-09 15:36:52.148 | DTC Client socket (2) | Connecting to IP: 54.216.199.59. 2024-05-09 15:36:52.148 | Rithmic Direct - DTC | Requesting security definition data for: MNQM4.CME. ID: 1 2024-05-09 15:36:52.148 | Added historical Intraday data request for MNQM4.CME to the queue. 2024-05-09 15:36:52.148 | Intraday data recording state for symbol MNQM4.CME is set to download 'Pending'. 2024-05-09 15:36:52.148 | Triggering next historical data download in queue. 2024-05-09 15:36:52.163 | Delaying start of download for MNQM4.CME. 2024-05-09 15:36:52.198 | Rithmic Direct - DTC (Data) | Network connection to server complete. 2024-05-09 15:36:52.198 | Rithmic Direct - DTC (Data) | Starting socket receive thread. 2024-05-09 15:36:52.198 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary 2024-05-09 15:36:52.198 | Rithmic Direct - DTC (Data) | Sending logon request message. 2024-05-09 15:36:52.445 | Rithmic Direct - DTC (Data) | Received logon response. 2024-05-09 15:36:52.445 | Rithmic Direct - DTC (Data) | Server Name: . 2024-05-09 15:36:52.445 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8 2024-05-09 15:36:52.445 | Rithmic Direct - DTC (Data) | Successfully connected. 2024-05-09 15:36:52.445 | Rithmic Direct - DTC (Data) | Trading is not supported. 2024-05-09 15:36:52.445 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: . 2024-05-09 15:36:52.445 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1 2024-05-09 15:36:52.445 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: MNQM4.CME 2024-05-09 15:36:52.703 | Rithmic Direct - DTC (Data) | Received security definition for symbol MNQM4.CME 2024-05-09 15:36:57.686 | HD Request # 2 | Downloading Intraday chart data for MNQM4.CME to the file MNQM4.CME.scid. Service: rithmic.trading 2024-05-09 15:36:57.686 | HD Request # 2 | Download start date-time: 2024-05-09 15:35:09.000000. File last date-time: 2024-05-09 15:35:09.458001 2024-05-09 15:36:57.686 | HD Request # 2 | Using server: rsc-ie.rithmic.com port 40811. Use encryption. 2024-05-09 15:36:57.686 | Socket (3) | Creating socket. Using TLS 1.2. 2024-05-09 15:36:57.686 | Socket (3) | New receive buffer size: 0 2024-05-09 15:36:57.686 | Socket (3) | Connecting to IP: 54.216.199.59. 2024-05-09 15:36:57.736 | HD Request # 2 | Sending historical data logon request message. 2024-05-09 15:36:57.982 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-05-09 15:35:09. Record interval: 0. Symbol: MNQM4.CME 2024-05-09 15:36:58.230 | HD Request # 2 | Receiving Intraday data for MNQM4.CME starting at 2024-05-09 15:35:09.036000 2024-05-09 15:37:11.615 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Creating socket. Using TLS 1.2. 2024-05-09 15:37:11.615 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | New receive buffer size: 0 2024-05-09 15:37:11.615 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Connecting to IP: 38.79.0.89. 2024-05-09 15:37:12.455 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Socket gracefully closed by remote side. 2024-05-09 15:37:12.455 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | CloseSocket call. 2024-05-09 15:37:12.455 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2024-05-09 15:37:12.455 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Closed. 2024-05-09 15:37:12.455 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (4) | Socket gracefully closed by remote side. |
[2024-05-09 13:56:23] |
Sierra_Chart Engineering - Posts: 17156 |
We see you are using Rithmic data: 2024-05-09 15:35:04.797 | Current selected Data/Trading service: Rithmic Direct - DTC Refer to: Rithmic Trading Platform Service: Rithmic Market Data and Support Policy In your case there is no reason to be using Rithmic data. You just need to activate the exchange that you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed After activating the exchange, wait a few minutes and: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-05-09 13:57:13
[2024-05-09 17:11:15] |
"You just need to activate the exchange that you need here:..."...must I cancel the Rithmic Data Service? Global Settings..---> Data/Trade Service Settings---> Current Selected Service (List)...what must I do here? Date Time Of Last Edit: 2024-05-09 17:36:20
[2024-05-09 18:10:02] |
After you setup the data from our Denali Exchange Data Feed, then you can cancel the data you are receiving from Rithmic. You would need to ask your broker to do this for you. Global Settings..---> Data/Trade Service Settings---> Current Selected Service (List)...what must I do here?
Leave this alone. You are still going to use Rithmic for your order routing, just not for data. Refer to the information at the following link: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
