Date/Time: Tue, 04 Nov 2025 08:13:04 +0000
Sierra Chart package
View Count: 363
|   [2024-05-02 07:53:45]     |
| User177329 - Posts: 35 |
                Hi, Is there a cheaper real-time data for CME and E-mini because the price regarding other platforms is much much more expensive? i dont find it reasonable to pay 140 USD / month if i am getting the same thing for 5 USD / month ?? what is the difference between this real-time data and other platforms ?!  |
|   [2024-05-02 15:13:02]     |
| John - SC Support - Posts: 42737 |
                You are only seeing the exchange options for the Professional exchanges. This is due to the fact that when you filled out the exchange agreements for the CME Group you did not include a Clearing Firm/Brokerage and you stated that you are a Professional. To have access to the non-professional exchanges, you need to redo the agreements and enter a Clearing Firm/Brokerage Name along with the Account Number and then be sure to answer the question about certifying as a Non-Professional as "Yes". You can access the agreements at the following link: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements For more information on the CME Group requirement that you have a live, funded, futures trading account in order to qualify for the non-professional exchange fees, refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2024-05-03 07:33:22]     |
                I do not have a brokerage account
|   [2024-05-03 15:12:00]     |
                Refer to the following for a solution: Easy Solution to CME Funded Trading Account Requirement Otherwise, if you do not have a brokerage account, then you can not get the real-time data for the CME Group at the non-professional rates. On the other hand, if you do not have a brokerage account, then you should use our Delayed Streaming Data to do your testing/learning. The data is delayed by 10 minutes and 10 seconds for the CME Group, but otherwise acts like real-time data. Refer to the following: Delayed Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
