Date/Time: Sat, 19 Apr 2025 09:45:11 +0000
Custom chart builder reload behavior
View Count: 440
[2024-03-18 14:52:12] |
User907968 - Posts: 840 |
Hi support, Something strange is happening with custom chart builder on during chart reload, but only when connected to the data feed. It appears as though the builder function is not being called for the most recently added records, which leads to weird behavior on the last few bars. For example, sometimes all the volume for the records that are not processed through the builder function is dumped onto a few bars at the end of the chart. Below is an extract of debug messages printed to the console in visual studio. - There is always at least one message printed per call to the builder function, these are shown bold below. - I assume that the thread exit shown on the italicised line is data downloading or loading. - In the next call to the builder we have inexplicably skipped from bar index 1509 straight to 1517, leaving bars 1510-1516 in an undesriable/unprocessed state. Any idea why this would be? If I reload the chart with the data feed disconnected, it loads correctly and consistently, processing all records. Builder Function Called Time MS: 34702492 Index: 1509 Final Processing: Volume: 39 Index: 1509 Clearing Bar Data: Index 1509 Bar Values at Index: 1509 O: 5231.75 H: 5231.75 L: 5231.75 C: 5231.75 V: 39 Bar Values at Index: 1509 O: 5231.75 H: 5231.75 L: 5231.75 C: 5231.75 V: 3 Current Record Values at Index: 1509 O: 5231.75 H: 5231.75 L: 5231.75 C: 5231.75 V: 3 The thread 5824 has exited with code 0 (0x0). Builder Function Called Time MS: 0 Index: 1517 Is Insert File Records Processing: Index: 1517 Bar Values at Index: 1517 O: 5232 H: 5232 L: 5232 C: 5232 V: 3 Current Record Values at Index: 1517 O: 0 H: 0 L: 0 C: 0 V: 0 Builder Function Called Time MS: 34742604 Index: 1517 Time MS: 34742604 Volume at Index 1517 <= Threshold Bar Values at Index: 1517 O: 5232 H: 5232 L: 5232 C: 5232 V: 3 Current Record Values at Index: 1517 O: 5232 H: 5232 L: 5232 C: 5232 V: 1 Builder Function Called Time MS: 34742604 Index: 1517 Final Processing: Volume: 4 Index: 1517 |
[2024-03-18 15:04:34] |
Sierra_Chart Engineering - Posts: 19276 |
The chart bar indexes are controlled by the custom chart bar function. It is the function which specifies to start a new bar. The concept of a skipped index in this interface does not make sense. The custom bar function will be called for every Intraday record which can be every tick. Not likely there is a problem with that. Maybe there is some unexpected behavior related to splitting data records. We would have to look at how that works with custom chart bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-18 15:05:03
[2024-03-18 15:38:08] |
I agree, it doesn't make sense. The debug info posted above is copied verbatim from the VS output console, so where/how the extra bars are added (if not by a call to the builder function) is beyond me. Data is set to 1-tick granularity, so shouldn't relate to splitting records (should it?) For static chart reloading (and reloading during replay) everything is rock solid, the weird behavior only happens when reloading whilst connected to streaming data. |
[2024-03-20 02:46:12] |
Disable this setting: Chart Settings: Split Data Records (applies to Number of Trades, Volume and Range charts) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Let us know if that changes anything. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-20 08:15:23] |
Hello, Thanks for coming back to me. No change, unfortunately. |
[2024-03-20 22:28:48] |
We will look this over, but we do not know how soon we can get to it. It may not be until months from now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-05 18:20:36
[2024-03-21 10:56:02] |
Ok, understood. Anything you can do would be greatly appreciated. Thanks. |
[2025-03-21 20:15:38] |
We apologize for the long delay. We have been working on this now. There is a lot of complexity to chart data loading functionality. We did identify and correct one problem related to custom chart bars. Not sure it is the cause of what you are seeing, but we will release the change. We were not able to reproduce what you saw, but this is because we were doing some testing in the evening when there was not much trading going on. We then encountered an issue specifically related to custom chart bars and began to work on that. We are not able to reproduce what you are seeing. The test code for the problem is included in the example and it will be identified when it happens. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-21 23:36:42
[2025-03-21 23:35:43] |
What you see is normal if you are tracking chart bar indexes, in the study function and not the bar building function. If the chart is loading data while connected to the data feed, when the loading completes, you may very well see several new bars. (Now that we reread your description, what you are describing is different) The problem that has been solved is a problem that could occur when you re-download the data in the chart completely. In this case the custom bar building function may not go into effect, until after the initial batch of data is read into the chart. This is fixed. Update: the post above has been edited now that we reread, your initial posting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-22 04:17:34
[2025-03-22 10:57:15] |
Yes, the index is being tracked in the bar builder itself. I will check out the update when the market opens on Sunday. Thanks |
