Date/Time: Sun, 19 May 2024 00:02:56 +0000
Eurex data
View Count: 217
[2024-03-17 01:13:57] |
WhiteOG - Posts: 11 |
What order routing can i use for eurex, asking this because teton order routing doesnt work? Any recommendations?
[2024-03-17 15:22:03] |
Sierra_Chart Engineering - Posts: 14423 |
You will need to use Interactive Brokers or CQG. Both of these are supported: https://www.sierrachart.com/index.php?page=doc/Contents.php#SupportedDataAndTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-17 16:08:07] |
do i need to open an account with CQG, or just to select as my order routing? ANY INSTRUCTIONS FROM THE STEP 1 HOW TO SET UP LIVE DATA FROM EUREX, FROM A TO Z I MEAN. THANK YOU SIERRA
[2024-03-18 15:20:39] |
Start by asking your current broker if they support trading EUREX with CQG. If they do, then you would need to setup a separate account to trade EUREX (separate from the one you are using to trade The CME Group with the Teton Order Routing Service). Once they have this setup, then you would need to install a second Sierra Chart on the same computer, in order to access that other account and trade it. Refer to the following: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart You would then follow these instructions to connect that installation to CQG: CQG Trading Platform Service: Setup Instructions In order to setup the data for EUREX, follow these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-20 18:53:35] |
User263409 - Posts: 1 |
Dear Sierra Team, I ask my question here cuz I dont want to open another topic. In your page you said this: "The EUREX data feed has the following features. It is recommended to use the Denali Exchange Data Feed for historical and real-time EUREX data within Sierra Chart. EUREX data is not accessible from other sources, unless you are using Service Package 10 or higher. When using Service Package 10 or higher, you just need to pay for the EUREX exchange fee to access the real-time EUREX from the Denali Exchange Data Feed." What does this mean exactly if I want to subscibe Package 12? You say I just need to pay for the EUREX exchange fee. But what is this fee the EUREX subsciption fee (25 USD)? Thanks for your reply! Krisztian |
[2024-04-22 14:11:09] |
With regards to the packages, you just need to be on one of the "Integrated" packages, which are packages 10, 11 and 12. Refer to the following regarding this: Description of Service Packages and Pricing: Integrated Packages Call it what you want - "Subscription Fee", or "Exchange Fee", or something else. This is the fee that gets paid to the exchange themselves (in this case EUREX) for the use of the data. This is a separate item from the Sierra Chart package cost. For EUREX for a non-professional, the cost is $25.00 per month. You can view the exchange fees at the following link: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
