Date/Time: Tue, 15 Apr 2025 14:31:37 +0000
Latest update not connecting to Gain CAPITAL
View Count: 578
[2024-02-26 02:00:49]
User305536 - Posts: 60
I have been running Sierra Chartys for quite some time and my broker is GAIN Capital. Normally, I use the Gain Capital as my trade data and Denali as my data feed. I just updated to the latest version of Sierra charts, however, now my connection to GAIN Capital is lost and its not even in the drop down lost, and my data feed is generic and only displays a limited number of records. Please, I need to get this back in order ASAP.
Thank You
Allan
[2024-02-26 02:29:15]
Sierra_Chart Engineering - Posts: 19226
Gain Capital support has been discontinued for at least two or three years. We have not had anyone ask about this for a long time now.
We cannot provide any further help with Gain Capital.
We can help you with market data. We see that you have the CBOT exchange activated and you can receive real-time CBOT data now.
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
For trading use the gain capital software.
Date Time Of Last Edit: 2024-02-26 02:29:35
[2024-02-26 05:01:09]
well, i have been running the older version ofsierra chart and it has been working great with gain capital as trade provider (i trade on sierra chart) and denalli as the data. even now after the update the trade window has my account number in it, but of course none of the balance data or anything works because its not connected. I want/need to continue using sierra chart and tading orders on the screen, but Gain Capital is my broker and i'm not changing that either. please offer a better solution.
[2024-02-26 05:28:59]
found the problem. On the Gain Capital site, they offer the following in the Sierra Chart install configuration.
GETTING STARTED
Go to the Software Download page and follow the instructions to download Sierra Chart.
NOTE: Version 2416 or earlier must be used. Newer versions do not support trading capabilities, due to a decision made by Sierra Chart.
Sierra Change Log:
2417 Release Date: 2022-07-20
Removed support for the Gain Capital trading service. You can continue to use Gain Capital in older versions.
If you have a newer version installed, go to Help > Install Previous Version
Then, choose the option “Specific Version” and enter version number 2416.
I was able to install the older version and everything is fine now.
HOWEVER, I wish I know how to receive latest version and still use Gain Capital as the broker.
Please help me understand that.
[2024-02-26 06:53:20]
You cannot:
Switch to Teton:
Date Time Of Last Edit: 2024-02-26 06:56:02
[2024-02-26 13:49:02]
I am considering because Gain Capital (Cannon Trading) is level 5 and on your list. The major question is this..
1. Can I still trade off of the Sierra Chart screens (trades on the charts)?
2. Will I still be able to see my Gain Capital trading account balance and trade history inside Sierra Chart trading tab?
[2024-02-26 14:08:19]
Where is this list you are referring to:
1, 2. Not in newer versions of Sierra Chart with Gain Capital but if your account is through Cannon Trading they can set you up on Teton order routing.
[2024-02-26 14:16:15]
Setup Instructions
[Link] - [Top]
This service supports live trading only. For simulated trading you can enable Trade >> Trade Simulation Mode On within Sierra Chart, or use the Simulated Futures Trading Service. However, for simulated trading, in order to take advantage of the lower-priced CME exchange fees, requires that you still have a live trading account anyway.
To be able to use this service, you need to have a live trading account with one of the following clearing firms or one of their Introducing Brokers:
Stage 5 Trading (Broker)
Edge Clear (Broker)
Ironbeam (Clearing firm)
Trade Pro Futures (Broker)
AGN Futures (Broker)
Canon Trading (Broker) <---------------------------HERE
Sweet Futures (Broker)
DeepDiscountTrading (Broker)
Optimus Futures (Broker)
Cunningham LLC (Broker)
Advantage Futures (Clearing firm)
Dorman Trading (Clearing firm)
Phillip Capital (Clearing firm)
AMP Futures (Broker)
If your broker or clearing firm is not listed, then contact your broker, clearing firm or Sierra Chart and make an inquiry about supporting the Teton Order Routing Service.
[2024-02-26 14:17:05]
Then with teton routing, where will my account balance and trades be listed?
[2024-02-26 14:18:21]
Yes and can I trade on the screen?
[2024-02-26 15:33:31]
SC Support - Posts: 1954
Yes,
[2024-02-26 15:39:15]
I just dont see the part where it says you can trade off of the chart screen rather than using the web trading platform. Also it does not say where the account balances ect are being displayed. Please help.
[2024-02-28 17:12:16]
Would you please answer this?
[2024-02-28 17:30:04]
Hi there, regarding "I just dont see the part where it says you can trade off of the chart screen rather than using the web trading platform. Also it does not say where the account balances ect are being displayed. Please help."
Yes you can trade directly from the charts and just use the Web-based trading panel as back-up, when you are traveling. Correct Balances would always be available for display.
Do you have an existing relationship with any of the Brokers or Clearing Firms that support Teton Order Routing, see #2 here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
[2024-02-28 18:32:05]
Will the trade account monitor balances be populated and updated with the data from Canon Trading (Broker)?
[2024-02-28 20:00:03]
Regarding "Will the trade account monitor balances be populated and updated with the data from Canon Trading (Broker)?"
>> Yes it can be, Cannon Trading can put you on the Teton Order Routing Service without Sierra Chart's intervention; when Cannon Trading has added you to the Teton Order Routing Service, your set-up instructions begin with step #5 here:
[2025-04-08 04:28:17]
User325260 - Posts: 3
Hi. I have the same situation and want to switch to tenton. Cannon told me I have been set up but at step 9, I can't find anything that seems to match the available clearing firms. Which clearing firm should be used?
[2025-04-08 13:54:12]
Hi User325260, if Cannon Trading is your Broker, who are you Clearing through?
Are you also getting this error message?
[Connection error message from service: Teton CME Order Routing | Connection error: No trade accounts assigned | Date-Time]
[2025-04-09 03:56:49]
Hi. I'm clearing through stone x/gain capital.
When I try using "Test" as the clearing firm I get that message.
[2025-04-09 13:32:14]
Hi User325260 at this time "stoneX/gain capital" does not support Teton Order Routing. I think that Cannon Trading have a relationship with Ironbeam which do support Teton, you might ask them about that.
Anyway I see that you have connected your Sierra Chart Account to your Futures Trading Account, so you are verified as a Non-Professional for Real-time CME Group Futures Data:
[Verified trading account ending date: 2025-05-09]
For more information on why you need to connect your Sierra Chart Account to your Futures Trading Account at least once a month (in order to verify your Non-Professional status) please see:
