Date/Time: Thu, 28 Nov 2024 15:55:53 +0000
[Locked] - Rejected
View Count: 551
[2023-04-20 20:35:03]
joew - Posts: 46
I am wondering why my Uniform Subscriber Agreement and CME Non-Professional Certification were rejected.
Private File
[2023-04-20 21:31:30]
John - SC Support - Posts: 36350
The rejection states specifically: "Missing Futures Trading Account Information".
The CME Group requires that you have a live, funded, futures trading account in order to qualify as a Non-Professional. Therefore, when completing the agreement, you need to supply the information for that trading account, or we can not set your account as a Non-Professional.
If you do not have a live, funded, futures trading account that will qualify, then refer to the following solution:
Easy Solution to CME Funded Trading Account Requirement
[2023-04-20 22:12:25]
joew - Posts: 46
I do have two live funded trading accounts. I also had live data. This is a change. I wasn't aware that a change was made. How can I fix it? I have an account with Edge Clear and Interactive Brokers. It also states at the bottom of the agreement that I am certified as a nonprofessional. I am asking for help because the site is a little confusing. I understand you guys are busy and probably overwhelmed. I do not know how to rectify this issue though. I did post this in another section because I gave it some thought and I didn't think I would get a response here being that it's not a programming issue. So sorry for that mistake on my part. I logged into both IB and Teton today hoping that would resolve the issue.
Date Time Of Last Edit: 2023-04-20 22:13:27
[2023-04-20 23:12:32]
joew - Posts: 46
I filled out everything I could find to fill out. I don't know what to do. My data is not correct
Date Time Of Last Edit: 2023-04-20 23:32:28
[2023-04-20 23:47:01]
joew - Posts: 46
When I log into Teton or Rithmic I am getting delayed data. Logging into Teton to trade my live, funded futures trading account, why would it have delayed data? I do not understand but I would like to have this resolved before tomorrow morning.
[2023-04-21 14:07:14]
The first thing is to ensure that you have the right symbols for the particular service you are connected to. After you make a change to the selected service in the "Data/Trade Service Settings" and you select OK, it will ask you if you want to update your symbols. Be sure to select Yes to this. If you forget, or you open another chartbook, then you can update the symbols by selecting "Edit >> Translate Symbols to Current Service".
Next, ensure the option for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" is set to "Yes". If you need to change this, then after you select OK to close that window then select "File >> Disconnect" followed by "File >> Connect to Data Feed". You should start getting your real-time data after this.
And finally, if the above do not solve your issue, then we would need to see your Message Log. Follow these instructions to get us the Message Log:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only.
[2023-04-21 14:12:37]
joew - Posts: 46
The symbol is NQ. I am confident that my data is delayed because I have Trading view and Interactive brokers charts open and also have CME open. Their prices are all the same but Sierra is different from them.
Reading Internal Order ID file. | 2023-04-21 09:33:37.288
Reading Trade Orders file. | 2023-04-21 09:33:37.339
Reading Trade Positions file. | 2023-04-21 09:33:37.339
Reading Trade Account Data files. | 2023-04-21 09:33:37.340
Software version: 2491 64-bit | 2023-04-21 09:33:37.341
Primary Thread ID: 13736 | 2023-04-21 09:33:37.341
Usage end date: 2023-05-02 | 2023-04-21 09:33:37.341
Enabled for: Advanced Features 2. | 2023-04-21 09:33:37.341
Enabled for: Sierra Chart Historical Data Service. | 2023-04-21 09:33:37.341
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-04-21 09:33:37.341
Enabled for: Delayed Denali Exchange Data Feed. | 2023-04-21 09:33:37.341
Enabled for exchange2: CME | 2023-04-21 09:33:37.341
Enabled for exchange2: CBOT (Trading Account Required) | 2023-04-21 09:33:37.341
Enabled for exchange2: COMEX (Trading Account Required) | 2023-04-21 09:33:37.341
Enabled for exchange2: NYMEX (Trading Account Required) | 2023-04-21 09:33:37.341
Enabled for exchange2: fairx_exchange.data | 2023-04-21 09:33:37.341
Enabled for exchange2: NASDAQ Global Indexes | 2023-04-21 09:33:37.341
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-04-21 09:33:37.341
Current selected Data/Trading service: Teton CME Order Routing | 2023-04-21 09:33:37.341
Custom symbol settings values: enabled | 2023-04-21 09:33:37.341
Chart Update Interval: 600 | 2023-04-21 09:33:37.341
Intraday Data Storage Time Unit: 0 | 2023-04-21 09:33:37.341
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-04-21 09:33:37.341
2023-04-21 13:33:37 Local computer time in UTC | 2023-04-21 09:33:37.341
2023-04-21 09:33:37 Local computer time in SC Time Zone | 2023-04-21 09:33:37.341
2023-04-21 13:33:35 Server time in UTC | 2023-04-21 09:33:37.341
Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-04-21 09:33:37.341
Program path: C:\SierraChart rith\ | 2023-04-21 09:33:37.341
Data Files path: C:\SierraChart rith\Data\ | 2023-04-21 09:33:37.341
OS Version Number: 10.0 | 2023-04-21 09:33:37.341
Locale Setting: C | 2023-04-21 09:33:37.341
DLLs: LimitToPrice_64.dll, OrderFlowLabs.com.autoplot_64.dll, OrderFlowLabs.com_64.dll, RW-Bid-Ask_StackPull_Textbox_64.dll, sst_FreeBundle_2273_64.dll, sst_FreeBundle_64.dll, TWFX_FREE_64.dll, TWFX_FREE_SWS_64.dll, TWFX_FREE_ZZS_64.dll, UserContributedStudies_64.dll, Zyp Free by Zyp_64.dll, Zyp OrderFlow by Zdislav_64.dll, Zyp Trade_Your_Plan_64.dll | 2023-04-21 09:33:37.342
Allowed protected custom studies: GomOrderFlowPro, OrderFlowLabs.com, OrderFlowLabs.com AutoPlot, SST_FreeBundle, TWFX_Free, VerrilloTrading - Move Closest OCO To Price, zyp_app | 2023-04-21 09:33:37.342
Crash reporter started: true | 2023-04-21 09:33:37.342
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2023-04-21 09:33:37.352
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-04-21 09:33:37.374
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-04-21 09:33:37.486
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-04-21 09:33:37.486
Received 5 login tokens. | 2023-04-21 09:33:37.756
Symbol settings MD5 received. Request ID: 1. | 2023-04-21 09:33:39.109
Symbol settings are up-to-date for sc_futures_direct.dtc.trading. | 2023-04-21 09:33:39.109
Files to Open on Startup | Opening file: alertsleo_nq.Cht | 2023-04-21 09:33:42.007
Loading DLL: C:\SierraChart rith\Data\OrderFlowLabs.com.dll (OrderFlowLabs.com_64.dll). Handle: 7ff88ce10000 | 2023-04-21 09:33:42.014
NQM23_FUT_CME [CBV] 30 Sec #1 | Reloading chart. | 2023-04-21 09:33:42.019
NQM23_FUT_CME [CBV] 30 Sec #1 | Performing continuous chart historical Daily data download for symbol NQM23_FUT_CME starting at last date in file. | 2023-04-21 09:33:42.022
Starting DelayedDownloadMonitoringTimer | 2023-04-21 09:33:42.022
Starting HDTimeoutTimer | 2023-04-21 09:33:42.022
Added historical Daily data request for NQM23_FUT_CME to the queue. | 2023-04-21 09:33:42.022
Triggering next historical data download in queue. | 2023-04-21 09:33:42.022
NQM23_FUT_CME [CBV] 30 Sec #1 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.034
NQM23_FUT_CME [CBV] 1 Min #7 | Reloading chart. | 2023-04-21 09:33:42.037
NQM23_FUT_CME [CBV] 1 Min #7 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.042
MNQM23_FUT_CME [CBV] 900 Trades #8 | Reloading chart. | 2023-04-21 09:33:42.046
MNQM23_FUT_CME [CBV] 900 Trades #8 | Performing continuous chart historical Daily data download for symbol MNQM23_FUT_CME starting at last date in file. | 2023-04-21 09:33:42.047
Added historical Daily data request for MNQM23_FUT_CME to the queue. | 2023-04-21 09:33:42.047
MNQM23_FUT_CME [CBV] 900 Trades #8 | Waiting for historical downloads to complete with the IDs: 2, | 2023-04-21 09:33:42.051
NQM23_FUT_CME [CBV] 600 Volume #6 | Reloading chart. | 2023-04-21 09:33:42.054
NQM23_FUT_CME [CBV] 600 Volume #6 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.059
NQM23_FUT_CME 15000 Volume #2 | Reloading chart. | 2023-04-21 09:33:42.062
NQM23_FUT_CME [CBV] 1 Day #5 | Reloading chart. | 2023-04-21 09:33:42.070
NQM23_FUT_CME [CBV] 1 Day #5 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.095
Loading DLL: C:\SierraChart rith\Data\RW-Bid-Ask_StackPull_Textbox.dll (RW-Bid-Ask_StackPull_Textbox_64.dll). Handle: 66000000 | 2023-04-21 09:33:42.099
NQM23_FUT_CME [CBV] 240 Min #4 | Reloading chart. | 2023-04-21 09:33:42.119
NQM23_FUT_CME [CBV] 240 Min #4 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.171
Loading DLL: C:\SierraChart rith\Data\sst_FreeBundle.dll (sst_FreeBundle_64.dll). Handle: 9b90000 | 2023-04-21 09:33:42.248
NQM23_FUT_CME [CBV] 60 Min #14 | Reloading chart. | 2023-04-21 09:33:42.274
NQM23_FUT_CME [CBV] 60 Min #14 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.289
NQM23_FUT_CME/MNQM23_FUT_CME [CV] 1 Min #15 | Reloading chart. | 2023-04-21 09:33:42.304
NQM23_FUT_CME/MNQM23_FUT_CME [CV] 1 Min #15 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.318
NQM23_FUT_CME #3 | Reloading chart. | 2023-04-21 09:33:42.347
NQM23_FUT_CME [CBV] 3000 Volume #9 | Reloading chart. | 2023-04-21 09:33:42.372
NQM23_FUT_CME [CBV] 3000 Volume #9 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.396
NQM23_FUT_CME [CBV] 3000 Volume #10 | Reloading chart. | 2023-04-21 09:33:42.414
NQM23_FUT_CME [CBV] 3000 Volume #10 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.419
NQM23_FUT_CME [CBV] 30 Min #11 | Reloading chart. | 2023-04-21 09:33:42.433
NQM23_FUT_CME [CBV] 30 Min #11 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.466
NQM23_FUT_CME [CBV] 375 Volume #12 | Reloading chart. | 2023-04-21 09:33:42.470
NQM23_FUT_CME [CBV] 375 Volume #12 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.475
NQM23_FUT_CME [CBV] 750 Volume #13 | Reloading chart. | 2023-04-21 09:33:42.600
NQM23_FUT_CME [CBV] 750 Volume #13 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.606
NQM23_FUT_CME [CBV] Flex Renko 40-20-1 #22 | Reloading chart. | 2023-04-21 09:33:42.748
NQM23_FUT_CME [CBV] Flex Renko 40-20-1 #22 | Waiting for historical downloads to complete with the IDs: 1, | 2023-04-21 09:33:42.753
Mapping NQM23_FUT_CME to NQM23. Service code: cme | 2023-04-21 09:33:42.766
Using symbol data fast lookup vector | 2023-04-21 09:33:42.766
HD Request # 1 | Downloading Historical Daily chart data for NQM23_FUT_CME. Starting date: 2023-04-18. Service: sc_futures_direct.dtc.trading | 2023-04-21 09:33:42.767
NQM23_FUT_CME #3 | StartDateTimeForLoadingOrderFills: 2023-04-07 08:33:22 | 2023-04-21 09:33:42.785
Starting DelayedDownloadMonitoringTimer | 2023-04-21 09:33:42.845
Starting HDTimeoutTimer | 2023-04-21 09:33:42.845
Added historical Intraday data request for NQM23_FUT_CME to the queue. | 2023-04-21 09:33:42.845
Intraday data recording state for symbol NQM23_FUT_CME is set to download 'Pending'. | 2023-04-21 09:33:42.845
Triggering next historical data download in queue. | 2023-04-21 09:33:42.845
HD Request # 2 | Downloading Intraday chart data for NQM23_FUT_CME to the file NQM23_FUT_CME.scid. Service: cme | 2023-04-21 09:33:42.850
HD Request # 2 | Download start date-time: 2023-04-21 09:33:22.000000. File last date-time: 2023-04-21 09:33:22.192000 | 2023-04-21 09:33:42.850
HD Request # 2 | Using server: ds26.sierracharts.com port 10150 | 2023-04-21 09:33:42.850
Socket (2) | Creating socket. | 2023-04-21 09:33:42.850
Socket (2) | New receive buffer size: 5242880 | 2023-04-21 09:33:42.850
Socket (2) | Connecting to IP: 142.215.17.188. | 2023-04-21 09:33:42.850
HD Request # 2 | Setting DTC encoding to Binary VLS | 2023-04-21 09:33:42.933
HD Request # 2 | Sending historical data logon request message. | 2023-04-21 09:33:42.933
HD Request # 1 | Requesting historical Daily data for NQM23 starting at 2023-04-17. SC External HD service. | 2023-04-21 09:33:43.358
HD Request # 2 | Requesting Intraday data. Start date-time: 2023-04-21 09:33:22. Record interval: 0. Symbol: NQM23 | 2023-04-21 09:33:43.502
HD Request # 2 | Decompressing data. | 2023-04-21 09:33:43.534
HD Request # 2 | Receiving Intraday data for NQM23_FUT_CME starting at 2023-04-21 09:33:22.088000 | 2023-04-21 09:33:43.534
Socket (2) | CloseSocket call. | 2023-04-21 09:33:43.535
Socket (2) | Shutdown started. Waiting for graceful close. | 2023-04-21 09:33:43.535
Historical data download thread signaled to stop. | 2023-04-21 09:33:43.535
HD Request # 2 | Timestamp of first Intraday data file record written: 2023-04-21 09:33:22.212000. | 2023-04-21 09:33:43.535
HD Request # 2 | Received 494 Intraday data records from 2023-04-21 09:33:22.088000 to 2023-04-21 09:33:41.169001 (19.1 seconds. Delay: 2.4 seconds) and wrote 483 records for NQM23_FUT_CME | 2023-04-21 09:33:43.535
HD Request # 2 | Completion time: 1s. | 2023-04-21 09:33:43.536
HD Request # 2 | Intraday data download complete for NQM23_FUT_CME. Unique request ID: 3 | 2023-04-21 09:33:43.536
Removing historical data download ID 3. | 2023-04-21 09:33:43.536
Real-time Intraday chart data file updates started for NQM23_FUT_CME | 2023-04-21 09:33:43.536
Intraday chart data file opened for NQM23_FUT_CME | 2023-04-21 09:33:43.536
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2023-04-21 09:33:43.536
Triggering next historical data download in queue. | 2023-04-21 09:33:43.536
Historical data for NQM23_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-04-21 09:33:43.536
No download requests in the queue to start downloads for. | 2023-04-21 09:33:43.536
HD Request # 1 | Receiving historical Daily data for NQM23_FUT_CME starting at 2023-04-18. | 2023-04-21 09:33:43.545
HD Request # 1 | Writing historical Daily data to the file NQM23_FUT_CME.dly. | 2023-04-21 09:33:43.545
HD Request # 1 | Bytes received: 241 | 2023-04-21 09:33:43.546
HD Request # 1 | Received 4 Daily data records from 2023-04-18 00:00:00 to 2023-04-20 00:00:00 (3.0 days) and wrote 3 records for NQM23_FUT_CME | 2023-04-21 09:33:43.546
HD Request # 1 | Completion time: 1s. | 2023-04-21 09:33:43.546
HD Request # 1 | Daily data download complete for NQM23_FUT_CME. Unique request ID: 1 | 2023-04-21 09:33:43.546
Removing historical data download ID 1. | 2023-04-21 09:33:43.546
Triggering next historical data download in queue. | 2023-04-21 09:33:43.546
Mapping MNQM23_FUT_CME to MNQM23. Service code: cme | 2023-04-21 09:33:43.547
HD Request # 3 | Downloading Historical Daily chart data for MNQM23_FUT_CME. Starting date: 2023-04-18. Service: sc_futures_direct.dtc.trading | 2023-04-21 09:33:43.548
NQM23_FUT_CME [CBV] Flex Renko 40-20-1 #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.559
NQM23_FUT_CME [CBV] Flex Renko 40-20-1 #22 | Reloading chart. | 2023-04-21 09:33:43.560
Socket (2) | Socket gracefully closed by remote side. | 2023-04-21 09:33:43.574
Socket (2) | Closed. | 2023-04-21 09:33:43.574
NQM23_FUT_CME [CBV] 3000 Volume #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.589
NQM23_FUT_CME [CBV] 3000 Volume #9 | Reloading chart. | 2023-04-21 09:33:43.589
NQM23_FUT_CME [CBV] 750 Volume #13 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.604
NQM23_FUT_CME [CBV] 750 Volume #13 | Reloading chart. | 2023-04-21 09:33:43.604
NQM23_FUT_CME [CBV] Flex Renko 40-20-1 #22 | Reloading chart. | 2023-04-21 09:33:43.621
NQM23_FUT_CME/MNQM23_FUT_CME [CV] 1 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.630
NQM23_FUT_CME/MNQM23_FUT_CME [CV] 1 Min #15 | Reloading chart. | 2023-04-21 09:33:43.630
NQM23_FUT_CME [CBV] 3000 Volume #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.637
NQM23_FUT_CME [CBV] 3000 Volume #10 | Reloading chart. | 2023-04-21 09:33:43.637
NQM23_FUT_CME [CBV] 30 Min #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.653
NQM23_FUT_CME [CBV] 30 Min #11 | Reloading chart. | 2023-04-21 09:33:43.654
NQM23_FUT_CME [CBV] 750 Volume #13 | Reloading chart. | 2023-04-21 09:33:43.677
NQM23_FUT_CME [CBV] 375 Volume #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.685
NQM23_FUT_CME [CBV] 375 Volume #12 | Reloading chart. | 2023-04-21 09:33:43.686
NQM23_FUT_CME/MNQM23_FUT_CME [CV] 1 Min #15 | Reloading chart. | 2023-04-21 09:33:43.736
NQM23_FUT_CME [CBV] 30 Sec #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.846
NQM23_FUT_CME [CBV] 30 Sec #1 | Reloading chart. | 2023-04-21 09:33:43.846
NQM23_FUT_CME [CBV] 1 Min #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.857
NQM23_FUT_CME [CBV] 1 Min #7 | Reloading chart. | 2023-04-21 09:33:43.860
NQM23_FUT_CME [CBV] 600 Volume #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.895
NQM23_FUT_CME [CBV] 600 Volume #6 | Reloading chart. | 2023-04-21 09:33:43.896
NQM23_FUT_CME [CBV] 1 Day #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.900
NQM23_FUT_CME [CBV] 1 Day #5 | Reloading chart. | 2023-04-21 09:33:43.901
NQM23_FUT_CME [CBV] 240 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:43.957
NQM23_FUT_CME [CBV] 240 Min #4 | Reloading chart. | 2023-04-21 09:33:43.958
NQM23_FUT_CME [CBV] 60 Min #14 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:44.102
NQM23_FUT_CME [CBV] 60 Min #14 | Reloading chart. | 2023-04-21 09:33:44.103
HD Request # 3 | Requesting historical Daily data for NMM23 starting at 2023-04-17. SC External HD service. | 2023-04-21 09:33:44.118
NQM23_FUT_CME [CBV] 3000 Volume #9 | Reloading chart. | 2023-04-21 09:33:44.197
HD Request # 3 | Receiving historical Daily data for MNQM23_FUT_CME starting at 2023-04-18. | 2023-04-21 09:33:44.249
HD Request # 3 | Writing historical Daily data to the file MNQM23_FUT_CME.dly. | 2023-04-21 09:33:44.249
HD Request # 3 | Bytes received: 232 | 2023-04-21 09:33:44.251
HD Request # 3 | Received 4 Daily data records from 2023-04-18 00:00:00 to 2023-04-20 00:00:00 (3.0 days) and wrote 3 records for MNQM23_FUT_CME | 2023-04-21 09:33:44.251
HD Request # 3 | Completion time: 1s. | 2023-04-21 09:33:44.251
HD Request # 3 | Daily data download complete for MNQM23_FUT_CME. Unique request ID: 2 | 2023-04-21 09:33:44.251
Removing historical data download ID 2. | 2023-04-21 09:33:44.251
Triggering next historical data download in queue. | 2023-04-21 09:33:44.251
No download requests in the queue to start downloads for. | 2023-04-21 09:33:44.251
NQM23_FUT_CME [CBV] 3000 Volume #10 | Reloading chart. | 2023-04-21 09:33:44.257
NQM23_FUT_CME [CBV] 30 Min #11 | Reloading chart. | 2023-04-21 09:33:44.274
NQM23_FUT_CME [CBV] 375 Volume #12 | Reloading chart. | 2023-04-21 09:33:44.363
NQM23_FUT_CME [CBV] 30 Sec #1 | Reloading chart. | 2023-04-21 09:33:44.453
NQM23_FUT_CME [CBV] 1 Min #7 | Reloading chart. | 2023-04-21 09:33:44.492
MNQM23_FUT_CME [CBV] 900 Trades #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 09:33:44.506
MNQM23_FUT_CME [CBV] 900 Trades #8 | Reloading chart. | 2023-04-21 09:33:44.508
NQM23_FUT_CME [CBV] 1 Day #5 | Reloading chart. | 2023-04-21 09:33:44.531
NQM23_FUT_CME [CBV] 600 Volume #6 | Reloading chart. | 2023-04-21 09:33:44.601
NQM23_FUT_CME [CBV] 240 Min #4 | Reloading chart. | 2023-04-21 09:33:44.619
NQM23_FUT_CME [CBV] 60 Min #14 | Reloading chart. | 2023-04-21 09:33:44.743
Teton CME Order Routing | Firm: Phillip Capital | 2023-04-21 09:33:44.783
Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11089 | 2023-04-21 09:33:44.783
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-04-21 09:33:44.783
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-04-21 09:33:44.783
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2023-04-21 09:33:44.783
Teton CME Order Routing | Network connection to server complete. | 2023-04-21 09:33:44.825
Teton CME Order Routing | Starting socket receive thread. | 2023-04-21 09:33:44.825
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-04-21 09:33:44.825
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-04-21 09:33:44.956
Teton CME Order Routing | Sending logon request message. | 2023-04-21 09:33:44.956
NQM23_FUT_CME [CBV][M] 750 Volume #13 | StartDateTimeForLoadingOrderFills: 2023-04-07 08:33:41 | 2023-04-21 09:33:44.958
MNQM23_FUT_CME [CBV] 900 Trades #8 | Reloading chart. | 2023-04-21 09:33:45.124
Teton CME Order Routing | Received logon response. | 2023-04-21 09:33:45.460
Teton CME Order Routing | Server Name: SC DTC Server. Build=45138. | 2023-04-21 09:33:45.460
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-04-21 09:33:45.460
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2023-04-21 09:33:45.460
Teton CME Order Routing | Trading is supported. | 2023-04-21 09:33:45.460
Teton CME Order Routing | Order cancel and replace is supported. | 2023-04-21 09:33:45.460
Teton CME Order Routing | OCO Orders supported. | 2023-04-21 09:33:45.460
Teton CME Order Routing | Bracket Orders supported. | 2023-04-21 09:33:45.460
Teton CME Order Routing | Connected to server complete. | 2023-04-21 09:33:45.460
Triggering next historical data download in queue. | 2023-04-21 09:33:45.460
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2023-04-21 09:33:45.465
No download requests in the queue to start downloads for. | 2023-04-21 09:33:45.465
Mapping NQM23_FUT_CME to NQM23. Service code: cme | 2023-04-21 09:33:45.466
Using symbol data fast lookup vector | 2023-04-21 09:33:45.466
Denali Data Feed | Starting real-time market data updates for: NQM23_FUT_CME (NQM23). ID: 1 Service code: cme | 2023-04-21 09:33:45.466
Denali Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10048 | 2023-04-21 09:33:45.466
DTC Client socket (2) | Creating socket. | 2023-04-21 09:33:45.467
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-04-21 09:33:45.467
DTC Client socket (2) | Connecting to IP: 142.215.17.187. | 2023-04-21 09:33:45.467
Denali Data Feed | Requesting security definition data for: NQM23_FUT_CME (NQM23). ID: 1 | 2023-04-21 09:33:45.468
Added historical Intraday data request for NQM23_FUT_CME to the queue. | 2023-04-21 09:33:45.468
Intraday data recording state for symbol NQM23_FUT_CME is set to download 'Pending'. | 2023-04-21 09:33:45.468
Triggering next historical data download in queue. | 2023-04-21 09:33:45.468
Delaying start of download for NQM23_FUT_CME. | 2023-04-21 09:33:45.474
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2023-04-20 20:02:45.110632 | 2023-04-21 09:33:45.474
Denali Data Feed | Network connection to server complete. | 2023-04-21 09:33:45.503
Denali Data Feed | Starting socket receive thread. | 2023-04-21 09:33:45.503
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-04-21 09:33:45.503
Mapping MNQM23_FUT_CME to MNQM23. Service code: cme | 2023-04-21 09:33:45.506
Denali Data Feed | Starting real-time market data updates for: MNQM23_FUT_CME (MNQM23). ID: 2 Service code: cme | 2023-04-21 09:33:45.506
Denali Data Feed | Requesting security definition data for: MNQM23_FUT_CME (MNQM23). ID: 2 | 2023-04-21 09:33:45.506
Chart #8 has tagged chart #13 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:45.612
Updated verified funded futures trading account ending date to: 2023-05-21 13:33:45 | 2023-04-21 09:33:45.613
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQM23_FUT_CME | 2023-04-21 09:33:45.613
Teton CME Order Routing | Received security definition for symbol NQM23_FUT_CME | 2023-04-21 09:33:45.613
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-04-21 09:33:45.613
Denali Data Feed | Sending logon request message. | 2023-04-21 09:33:45.613
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=7PV1854 | 2023-04-21 09:33:45.613
Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MNQM23_FUT_CME | 2023-04-21 09:33:45.613
Teton CME Order Routing | Received security definition for symbol MNQM23_FUT_CME | 2023-04-21 09:33:45.613
NQM23_FUT_CME [CBV][M] Flex Renko 40-20-1 #22 | StartDateTimeForLoadingOrderFills: 2023-04-07 08:33:41 | 2023-04-21 09:33:45.700
Added historical Intraday data request for MNQM23_FUT_CME to the queue. | 2023-04-21 09:33:45.911
Intraday data recording state for symbol MNQM23_FUT_CME is set to download 'Pending'. | 2023-04-21 09:33:45.911
Triggering next historical data download in queue. | 2023-04-21 09:33:45.911
Chart #1 has tagged chart #13 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:48.288
Chart #1 has tagged chart #22 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:48.288
Denali Data Feed | Received logon response. | 2023-04-21 09:33:48.288
Denali Data Feed | Server Name: SC Realtime Server. | 2023-04-21 09:33:48.288
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-04-21 09:33:48.288
Denali Data Feed | Successfully connected. | 2023-04-21 09:33:48.288
Denali Data Feed | Trading is not supported. | 2023-04-21 09:33:48.288
Denali Data Feed | Restarting real-time data updates for symbol: MNQM23_FUT_CME -> MNQM23 | 2023-04-21 09:33:48.288
Denali Data Feed | Restarting real-time data updates for symbol: NQM23_FUT_CME -> NQM23 | 2023-04-21 09:33:48.288
Chart #5 has tagged chart #13 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:48.290
Chart #5 has tagged chart #22 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:48.290
Denali Data Feed | Received security definition for symbol MNQM23_FUT_CME | 2023-04-21 09:33:48.452
Denali Data Feed | Received security definition for symbol NQM23_FUT_CME | 2023-04-21 09:33:48.452
Chart #9 has tagged chart #13 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:49.780
Chart #9 has tagged chart #22 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:49.780
NQM23_FUT_CME[M]/MNQM23_FUT_CME [CV][M] 1 Min #15 | StartDateTimeForLoadingOrderFills: 2023-02-20 17:00:00 | 2023-04-21 09:33:50.285
Requesting market depth updates for: NQM23_FUT_CME if supported. | 2023-04-21 09:33:50.837
Denali Data Feed | Clearing market depth for NQM23_FUT_CME | 2023-04-21 09:33:50.933
NQM23_FUT_CME [CBV][M] 60 Min #14 | Study: Display Forex factory calendar news items | Making HTTP request. | 2023-04-21 09:33:51.820
Chart: NQM23_FUT_CME [CBV][M] 60 Min #14 | Study: Display Forex factory calendar news items | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2023-04-21 09:33:51.820 *
HD Request # 4 | Downloading Intraday chart data for NQM23_FUT_CME to the file NQM23_FUT_CME.scid. Service: cme | 2023-04-21 09:33:53.868
HD Request # 4 | Download start date-time: 2023-04-21 09:33:41.000000. File last date-time: 2023-04-21 09:33:41.169001 | 2023-04-21 09:33:53.868
HD Request # 4 | Using server: ds28.sierracharts.com port 10149 | 2023-04-21 09:33:53.868
Socket (3) | Creating socket. | 2023-04-21 09:33:53.869
Socket (3) | New receive buffer size: 5242880 | 2023-04-21 09:33:53.869
Socket (3) | Connecting to IP: 142.215.18.147. | 2023-04-21 09:33:53.869
HD Request # 4 | Setting DTC encoding to Binary VLS | 2023-04-21 09:33:53.941
HD Request # 4 | Sending historical data logon request message. | 2023-04-21 09:33:53.941
HD Request # 4 | Requesting Intraday data. Start date-time: 2023-04-21 09:33:41. Record interval: 0. Symbol: NQM23 | 2023-04-21 09:33:54.521
HD Request # 4 | Decompressing data. | 2023-04-21 09:33:54.556
HD Request # 4 | Receiving Intraday data for NQM23_FUT_CME starting at 2023-04-21 09:33:41.000000 | 2023-04-21 09:33:54.557
Socket (3) | CloseSocket call. | 2023-04-21 09:33:54.557
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-04-21 09:33:54.557
Historical data download thread signaled to stop. | 2023-04-21 09:33:54.568
HD Request # 4 | Timestamp of first Intraday data file record written: 2023-04-21 09:33:41.196000. | 2023-04-21 09:33:54.568
HD Request # 4 | Received 277 Intraday data records from 2023-04-21 09:33:41.000000 to 2023-04-21 09:33:50.881001 (9.9 seconds. Delay: 3.7 seconds) and wrote 266 records for NQM23_FUT_CME | 2023-04-21 09:33:54.568
HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2023-04-21 13:33:50.881001 | 2023-04-21 09:33:54.569
Added 32 Time and Sales records to Intraday data file for NQM23_FUT_CME after download. | 2023-04-21 09:33:54.570
HD Request # 4 | Completion time: 1s. | 2023-04-21 09:33:54.570
HD Request # 4 | Intraday data download complete for NQM23_FUT_CME. Unique request ID: 4 | 2023-04-21 09:33:54.570
Removing historical data download ID 4. | 2023-04-21 09:33:54.570
Real-time Intraday chart data file updates started for NQM23_FUT_CME | 2023-04-21 09:33:54.570
Intraday chart data file opened for NQM23_FUT_CME | 2023-04-21 09:33:54.570
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2023-04-21 09:33:54.570
Triggering next historical data download in queue. | 2023-04-21 09:33:54.570
HD Request # 5 | Downloading Intraday chart data for MNQM23_FUT_CME to the file MNQM23_FUT_CME.scid. Service: cme | 2023-04-21 09:33:54.570
HD Request # 5 | Download start date-time: 2023-04-21 08:45:34.000000. File last date-time: 2023-04-21 08:45:34.201001 | 2023-04-21 09:33:54.570
HD Request # 5 | Using server: ds23.sierracharts.com port 10150 | 2023-04-21 09:33:54.570
Socket (4) | Creating socket. | 2023-04-21 09:33:54.570
Socket (4) | New receive buffer size: 5242880 | 2023-04-21 09:33:54.570
Socket (4) | Connecting to IP: 142.215.17.190. | 2023-04-21 09:33:54.570
Socket (3) | Socket gracefully closed by remote side. | 2023-04-21 09:33:54.592
Socket (3) | Closed. | 2023-04-21 09:33:54.592
HD Request # 5 | Setting DTC encoding to Binary VLS | 2023-04-21 09:33:54.662
HD Request # 5 | Sending historical data logon request message. | 2023-04-21 09:33:54.662
Chart #10 has tagged chart #13 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:54.758
Chart #10 has tagged chart #22 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:54.758
Chart #12 has tagged chart #22 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:54.759
Chart #1 has tagged chart #14 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:54.826
Chart #7 has tagged chart #8 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:54.917
Chart #2 has tagged chart #13 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:54.917
Chart #2 has tagged chart #22 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:54.917
Chart #6 has tagged chart #13 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:55.053
Chart #6 has tagged chart #22 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:55.053
HD Request # 5 | Requesting Intraday data. Start date-time: 2023-04-21 08:45:34. Record interval: 0. Symbol: MNQM23 | 2023-04-21 09:33:55.249
HD Request # 5 | Decompressing data. | 2023-04-21 09:33:55.285
HD Request # 5 | Receiving Intraday data for MNQM23_FUT_CME starting at 2023-04-21 08:45:34.010000 | 2023-04-21 09:33:55.377
HD Request # 5 | Timestamp of first Intraday data file record written: 2023-04-21 08:45:35.754000. | 2023-04-21 09:33:55.541
Socket (4) | CloseSocket call. | 2023-04-21 09:33:55.544
Socket (4) | Shutdown started. Waiting for graceful close. | 2023-04-21 09:33:55.544
Historical data download thread signaled to stop. | 2023-04-21 09:33:55.552
HD Request # 5 | Received 39900 Intraday data records from 2023-04-21 08:45:34.010000 to 2023-04-21 09:33:53.260000 (48.3 minutes. Delay: 2.3 seconds) and wrote 39895 records for MNQM23_FUT_CME | 2023-04-21 09:33:55.552
HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2023-04-21 13:33:53.260000 | 2023-04-21 09:33:55.553
Added 10 Time and Sales records to Intraday data file for MNQM23_FUT_CME after download. | 2023-04-21 09:33:55.553
HD Request # 5 | Completion time: 1s. | 2023-04-21 09:33:55.553
HD Request # 5 | Intraday data download complete for MNQM23_FUT_CME. Unique request ID: 5 | 2023-04-21 09:33:55.553
Removing historical data download ID 5. | 2023-04-21 09:33:55.553
Real-time Intraday chart data file updates started for MNQM23_FUT_CME | 2023-04-21 09:33:55.553
Intraday chart data file opened for MNQM23_FUT_CME | 2023-04-21 09:33:55.553
HD Request # 5 | Enabling Intraday chart updating for symbol. | 2023-04-21 09:33:55.553
Triggering next historical data download in queue. | 2023-04-21 09:33:55.553
No download requests in the queue to start downloads for. | 2023-04-21 09:33:55.553
Socket (4) | Socket gracefully closed by remote side. | 2023-04-21 09:33:55.582
Socket (4) | Closed. | 2023-04-21 09:33:55.582
Chart #8 has tagged chart #22 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:56.146
Opened cached Intraday file: C:\SierraChart rith\Data\NQM23_FUT_CME.scid. Thread ID: 17848 | 2023-04-21 09:33:57.491
Opened cached Intraday file: C:\SierraChart rith\Data\MNQM23_FUT_CME.scid. Thread ID: 17848 | 2023-04-21 09:33:57.491
Chart #11 has tagged chart #14 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:33:59.261
NQM23_FUT_CME 1 Min #1 | Reloading chart. | 2023-04-21 09:33:59.890
NQM23_FUT_CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2023-03-23 00:00:00 | 2023-04-21 09:34:00.591
NQM23_FUT_CME [CBV][M] Flex Renko 40-20-1 #22 | Performing a full recalculation because it has been tagged. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:34:07.094
MNQM23_FUT_CME [CBV][M] 900 Trades #8 | Performing a full recalculation because it has been tagged. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:34:07.148
Chart #8 has tagged chart #22 for full recalculation. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:34:07.212
NQM23_FUT_CME [CBV][M] 750 Volume #13 | Performing a full recalculation because it has been tagged. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:34:07.227
NQM23_FUT_CME [CBV][M] Flex Renko 40-20-1 #22 | Performing a full recalculation because it has been tagged. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:34:07.316
NQM23_FUT_CME [CBV][M] 60 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: alertsleo_nq.Cht | 2023-04-21 09:34:07.407
Unsubscribed from market depth data for NQM23_FUT_CME | 2023-04-21 09:38:15.467
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-04-21 10:02:33.975
DTC Client socket (1) | CloseSocket call. | 2023-04-21 10:02:33.976
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-04-21 10:02:33.976
DTC Client socket (1) | Max send buffer size during socket life: 236 | 2023-04-21 10:02:33.976
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-04-21 10:02:33.976
Denali Data Feed | Waiting for socket receive thread to end | 2023-04-21 10:02:33.976
DTC Client socket (2) | CloseSocket call. | 2023-04-21 10:02:33.976
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2023-04-21 10:02:33.976
Denali Data Feed | Disconnected from the server. | 2023-04-21 10:02:33.976
Teton CME Order Routing | Disconnected. | 2023-04-21 10:02:33.976
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (3) | Creating socket. Using TLS 1.2. | 2023-04-21 10:02:33.983
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (3) | New receive buffer size: 32768 | 2023-04-21 10:02:33.983
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (3) | Connecting to IP: 38.79.0.89. | 2023-04-21 10:02:33.983
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 2. | 2023-04-21 10:02:34.012
Current selected Data/Trading service: Rithmic Direct - DTC | 2023-04-21 10:02:34.012
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-04-21 10:02:34.015
DTC Client socket (1) | Closed. | 2023-04-21 10:02:34.015
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (3) | Socket gracefully closed by remote side. | 2023-04-21 10:02:34.149
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (3) | CloseSocket call. | 2023-04-21 10:02:34.150
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-04-21 10:02:34.150
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (3) | Closed. | 2023-04-21 10:02:34.150
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-04-21 10:02:35.267
NQM3.CME[M] 1 Min #1 | Reloading chart. | 2023-04-21 10:02:35.450
Symbol settings MD5 received. Request ID: 2. | 2023-04-21 10:02:35.749
Requested symbol settings for service code rithmic_v2.trading. Request ID: 3. | 2023-04-21 10:02:35.749
Mapping NQM3.CME to NQM23. Service code: cme | 2023-04-21 10:02:36.056
Added historical Intraday data request for NQM3.CME to the queue. | 2023-04-21 10:02:36.056
Intraday data recording state for symbol NQM3.CME is set to download 'Pending'. | 2023-04-21 10:02:36.056
Triggering next historical data download in queue. | 2023-04-21 10:02:36.056
HD Request # 6 | Downloading Intraday chart data for NQM3.CME to the file NQM3.CME.scid. Service: cme | 2023-04-21 10:02:36.056
HD Request # 6 | Download start date-time: 2023-04-21 09:05:14.000000. File last date-time: 2023-04-21 09:05:14.041002 | 2023-04-21 10:02:36.057
HD Request # 6 | Using server: ds26.sierracharts.com port 10149 | 2023-04-21 10:02:36.057
Socket (3) | Creating socket. | 2023-04-21 10:02:36.057
Socket (3) | New receive buffer size: 5242880 | 2023-04-21 10:02:36.057
Socket (3) | Connecting to IP: 142.215.17.188. | 2023-04-21 10:02:36.057
HD Request # 6 | Setting DTC encoding to Binary VLS | 2023-04-21 10:02:36.142
HD Request # 6 | Sending historical data logon request message. | 2023-04-21 10:02:36.142
NQM3.CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2023-03-23 00:00:00 | 2023-04-21 10:02:36.154
HD Request # 6 | Requesting Intraday data. Start date-time: 2023-04-21 09:05:14. Record interval: 0. Symbol: NQM23 | 2023-04-21 10:02:36.709
HD Request # 6 | Decompressing data. | 2023-04-21 10:02:36.753
HD Request # 6 | Receiving Intraday data for NQM3.CME starting at 2023-04-21 09:05:14.041000 | 2023-04-21 10:02:36.798
HD Request # 6 | Timestamp of first Intraday data file record written: 2023-04-21 09:05:14.554000. | 2023-04-21 10:02:37.005
Socket (3) | CloseSocket call. | 2023-04-21 10:02:37.023
Socket (3) | Shutdown started. Waiting for graceful close. | 2023-04-21 10:02:37.023
Historical data download thread signaled to stop. | 2023-04-21 10:02:37.023
HD Request # 6 | Received 85111 Intraday data records from 2023-04-21 09:05:14.041000 to 2023-04-21 10:02:32.413002 (57.3 minutes. Delay: 4.6 seconds) and wrote 85108 records for NQM3.CME | 2023-04-21 10:02:37.023
HD Request # 6 | Completion time: 1s. | 2023-04-21 10:02:37.023
HD Request # 6 | Intraday data download complete for NQM3.CME. Unique request ID: 6 | 2023-04-21 10:02:37.023
Removing historical data download ID 6. | 2023-04-21 10:02:37.023
Real-time Intraday chart data file updates started for NQM3.CME | 2023-04-21 10:02:37.023
Intraday chart data file opened for NQM3.CME | 2023-04-21 10:02:37.023
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2023-04-21 10:02:37.023
Triggering next historical data download in queue. | 2023-04-21 10:02:37.023
Historical data for NQM3.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2023-04-21 10:02:37.023
No download requests in the queue to start downloads for. | 2023-04-21 10:02:37.023
Socket (3) | Socket gracefully closed by remote side. | 2023-04-21 10:02:37.057
Socket (3) | Closed. | 2023-04-21 10:02:37.057
Symbol settings received. Request ID: 3. | 2023-04-21 10:02:37.920
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated | 2023-04-21 10:02:39.269
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-04-21 10:02:39.269
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-04-21 10:02:39.270
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-04-21 10:02:39.270
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-04-21 10:02:39.270
Rithmic Direct - DTC | Network connection to server complete. | 2023-04-21 10:02:39.309
Rithmic Direct - DTC | Starting socket receive thread. | 2023-04-21 10:02:39.309
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-04-21 10:02:39.309
Rithmic Direct - DTC | Sending logon request message. | 2023-04-21 10:02:39.309
Rithmic Direct - DTC | Received logon response. | 2023-04-21 10:02:39.442
Rithmic Direct - DTC | Server Name: . | 2023-04-21 10:02:39.442
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-04-21 10:02:39.442
Rithmic Direct - DTC | Successfully connected. | 2023-04-21 10:02:39.442
Rithmic Direct - DTC | Trading is supported. | 2023-04-21 10:02:39.442
Rithmic Direct - DTC | Order cancel and replace is supported. | 2023-04-21 10:02:39.442
Rithmic Direct - DTC | OCO Orders supported. | 2023-04-21 10:02:39.442
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-04-21 10:02:39.442
Rithmic Direct - DTC | Connected to server complete. | 2023-04-21 10:02:39.442
Triggering next historical data download in queue. | 2023-04-21 10:02:39.443
No download requests in the queue to start downloads for. | 2023-04-21 10:02:39.443
NQM3.CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 2023-03-23 00:00:00 | 2023-04-21 10:02:39.718
Mapping NQM3.CME to NQM23. Service code: cme | 2023-04-21 10:02:39.718
Using symbol data fast lookup vector | 2023-04-21 10:02:39.718
Denali Data Feed | Starting real-time market data updates for: NQM3.CME (NQM23). ID: 1 Service code: cme | 2023-04-21 10:02:39.718
Denali Data Feed | Connecting to the server ds21.sierracharts.com. Port 443 | 2023-04-21 10:02:39.718
Denali Data Feed | Requesting security definition data for: NQM3.CME (NQM23). ID: 1 | 2023-04-21 10:02:39.718
Added historical Intraday data request for NQM3.CME to the queue. | 2023-04-21 10:02:39.718
Intraday data recording state for symbol NQM3.CME is set to download 'Pending'. | 2023-04-21 10:02:39.718
Triggering next historical data download in queue. | 2023-04-21 10:02:39.718
DTC Client socket (3) | Creating socket. | 2023-04-21 10:02:39.719
DTC Client socket (3) | New receive buffer size: 5242880 | 2023-04-21 10:02:39.719
DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2023-04-21 10:02:39.719
Delaying start of download for NQM3.CME. | 2023-04-21 10:02:39.727
Denali Data Feed | Network connection to server complete. | 2023-04-21 10:02:39.755
Denali Data Feed | Starting socket receive thread. | 2023-04-21 10:02:39.755
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-04-21 10:02:39.756
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-04-21 10:02:39.826
Denali Data Feed | Sending logon request message. | 2023-04-21 10:02:39.826
Denali Data Feed | Received logon response. | 2023-04-21 10:02:39.872
Denali Data Feed | Server Name: RealTime Server. | 2023-04-21 10:02:39.872
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-04-21 10:02:39.872
Denali Data Feed | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2023-04-21 10:02:39.872
Denali Data Feed | Waiting for socket receive thread to end | 2023-04-21 10:02:39.872
DTC Client socket (3) | CloseSocket call. | 2023-04-21 10:02:39.872
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-04-21 10:02:39.872
Denali Data Feed | Disconnected from the server. | 2023-04-21 10:02:39.872
Denali Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-04-21 10:02:39.872
DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-04-21 10:02:39.909
DTC Client socket (3) | Closed. | 2023-04-21 10:02:39.909
Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 | 2023-04-21 10:02:41.873
DTC Client socket (3) | Creating socket. | 2023-04-21 10:02:41.873
DTC Client socket (3) | New receive buffer size: 5242880 | 2023-04-21 10:02:41.873
DTC Client socket (3) | Connecting to IP: 142.215.18.148. | 2023-04-21 10:02:41.873
Denali Data Feed | Network connection to server complete. | 2023-04-21 10:02:41.919
Denali Data Feed | Starting socket receive thread. | 2023-04-21 10:02:41.919
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-04-21 10:02:41.919
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-04-21 10:02:41.960
Denali Data Feed | Sending logon request message. | 2023-04-21 10:02:41.960
Denali Data Feed | Received logon response. | 2023-04-21 10:02:42.776
Denali Data Feed | Server Name: SC Realtime Server. | 2023-04-21 10:02:42.776
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-04-21 10:02:42.776
Denali Data Feed | Successfully connected. | 2023-04-21 10:02:42.776
Denali Data Feed | Trading is not supported. | 2023-04-21 10:02:42.776
Denali Data Feed | Restarting real-time data updates for symbol: NQM3.CME -> NQM23 | 2023-04-21 10:02:42.776
Opened cached Depth file: C:\SierraChart rith\Data\MarketDepthData\NQM3.CME.2023-04-21.depth | 2023-04-21 10:02:42.903
Denali Data Feed | Received security definition for symbol NQM3.CME | 2023-04-21 10:02:42.903
Requesting market depth updates for: NQM3.CME if supported. | 2023-04-21 10:02:44.429
Denali Data Feed | Clearing market depth for NQM3.CME | 2023-04-21 10:02:44.547
HD Request # 7 | Downloading Intraday chart data for NQM3.CME to the file NQM3.CME.scid. Service: cme | 2023-04-21 10:02:47.273
HD Request # 7 | Download start date-time: 2023-04-21 10:02:32.000000. File last date-time: 2023-04-21 10:02:32.413002 | 2023-04-21 10:02:47.273
HD Request # 7 | Using server: ds28.sierracharts.com port 10150 | 2023-04-21 10:02:47.273
Socket (4) | Creating socket. | 2023-04-21 10:02:47.274
Socket (4) | New receive buffer size: 5242880 | 2023-04-21 10:02:47.274
Socket (4) | Connecting to IP: 142.215.18.147. | 2023-04-21 10:02:47.274
HD Request # 7 | Setting DTC encoding to Binary VLS | 2023-04-21 10:02:47.360
HD Request # 7 | Sending historical data logon request message. | 2023-04-21 10:02:47.360
HD Request # 7 | Requesting Intraday data. Start date-time: 2023-04-21 10:02:32. Record interval: 0. Symbol: NQM23 | 2023-04-21 10:02:47.921
HD Request # 7 | Decompressing data. | 2023-04-21 10:02:47.956
HD Request # 7 | Receiving Intraday data for NQM3.CME starting at 2023-04-21 10:02:32.085000 | 2023-04-21 10:02:47.956
Socket (4) | CloseSocket call. | 2023-04-21 10:02:47.956
Historical data download thread signaled to stop. | 2023-04-21 10:02:47.957
Socket (4) | Shutdown started. Waiting for graceful close. | 2023-04-21 10:02:47.957
HD Request # 7 | Timestamp of first Intraday data file record written: 2023-04-21 10:02:32.482000. | 2023-04-21 10:02:47.957
HD Request # 7 | Received 547 Intraday data records from 2023-04-21 10:02:32.085000 to 2023-04-21 10:02:46.296000 (14.2 seconds. Delay: 1.7 seconds) and wrote 525 records for NQM3.CME | 2023-04-21 10:02:47.957
HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2023-04-21 14:02:46.296000 | 2023-04-21 10:02:47.957
Added 18 Time and Sales records to Intraday data file for NQM3.CME after download. | 2023-04-21 10:02:47.957
HD Request # 7 | Completion time: 0s. | 2023-04-21 10:02:47.957
HD Request # 7 | Intraday data download complete for NQM3.CME. Unique request ID: 7 | 2023-04-21 10:02:47.957
Removing historical data download ID 7. | 2023-04-21 10:02:47.957
Real-time Intraday chart data file updates started for NQM3.CME | 2023-04-21 10:02:47.957
Intraday chart data file opened for NQM3.CME | 2023-04-21 10:02:47.957
HD Request # 7 | Enabling Intraday chart updating for symbol. | 2023-04-21 10:02:47.957
Triggering next historical data download in queue. | 2023-04-21 10:02:47.957
No download requests in the queue to start downloads for. | 2023-04-21 10:02:47.957
Socket (4) | Socket gracefully closed by remote side. | 2023-04-21 10:02:47.994
Socket (4) | Closed. | 2023-04-21 10:02:47.994
Opened cached Intraday file: C:\SierraChart rith\Data\NQM3.CME.scid. Thread ID: 17848 | 2023-04-21 10:02:50.757
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (4) | Creating socket. Using TLS 1.2. | 2023-04-21 10:02:59.279
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (4) | New receive buffer size: 32768 | 2023-04-21 10:02:59.279
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (4) | Connecting to IP: 38.79.0.89. | 2023-04-21 10:02:59.279
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (4) | Socket gracefully closed by remote side. | 2023-04-21 10:02:59.417
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (4) | CloseSocket call. | 2023-04-21 10:02:59.418
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-04-21 10:02:59.418
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (4) | Closed. | 2023-04-21 10:02:59.418
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2023-04-21 10:05:01.367
DTC Client socket (2) | Closed. | 2023-04-21 10:05:01.367
NQM3.CME [CBV] 750 Volume #1 | Reloading chart. | 2023-04-21 10:05:12.462
NQM3.CME [CBV] 750 Volume #1 | Performing continuous chart historical Daily data download for symbol NQM3.CME starting at last date in file. | 2023-04-21 10:05:12.467
Added historical Daily data request for NQM3.CME to the queue. | 2023-04-21 10:05:12.467
Triggering next historical data download in queue. | 2023-04-21 10:05:12.467
NQM3.CME [CBV] 750 Volume #1 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.478
NQM3.CME [CBV] 5 Min #6 | Reloading chart. | 2023-04-21 10:05:12.483
NQM3.CME [CBV] 5 Min #6 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.487
NQM3.CME [CBV] 750 Volume #26 | Reloading chart. | 2023-04-21 10:05:12.492
NQM3.CME [CBV] 750 Volume #26 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.506
NQM3.CME [CBV] 1 Day #3 | Reloading chart. | 2023-04-21 10:05:12.510
NQM3.CME [CBV] 1 Day #3 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.554
NQM3.CME 30 Sec #13 | Reloading chart. | 2023-04-21 10:05:12.558
NQM3.CME [CBV] 500 Volume #28 | Reloading chart. | 2023-04-21 10:05:12.567
NQM3.CME [CBV] 500 Volume #28 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.571
NQM3.CME [CBV] 3072 Trades #4 | Reloading chart. | 2023-04-21 10:05:12.575
NQM3.CME [CBV] 3072 Trades #4 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.580
NQM3.CME [CBV] 3072 Trades #11 | Reloading chart. | 2023-04-21 10:05:12.584
NQM3.CME [CBV] 3072 Trades #11 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.589
NQM3.CME [CBV] 512 Trades #5 | Reloading chart. | 2023-04-21 10:05:12.593
NQM3.CME [CBV] 512 Trades #5 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.598
NQM3.CME [CBV] 512 Trades #17 | Reloading chart. | 2023-04-21 10:05:12.602
NQM3.CME [CBV] 512 Trades #17 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.607
NQM3.CME [CBV] 375 Volume #19 | Reloading chart. | 2023-04-21 10:05:12.611
NQM3.CME [CBV] 375 Volume #19 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.617
NQM3.CME [CBV] 1 Min #27 | Reloading chart. | 2023-04-21 10:05:12.622
NQM3.CME [CBV] 1 Min #27 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.626
NQM3.CME [CBV] 14500 Volume #23 | Reloading chart. | 2023-04-21 10:05:12.631
NQM3.CME [CBV] 14500 Volume #23 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.635
NQM3.CME [CBV] 5 Min #25 | Reloading chart. | 2023-04-21 10:05:12.640
NQM3.CME [CBV] 5 Min #25 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.653
NQM3.CME [CBV] 7 Day #9 | Reloading chart. | 2023-04-21 10:05:12.670
NQM3.CME [CBV] 7 Day #9 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.843
NQM3.CME [CBV] 60 Min #22 | Reloading chart. | 2023-04-21 10:05:12.857
NQM3.CME [CBV] 60 Min #22 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.881
NQM3.CME [CBV] 30 Min #2 | Reloading chart. | 2023-04-21 10:05:12.887
NQM3.CME [CBV] 30 Min #2 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.901
NQM3.CME [CBV] 60 Min #15 | Reloading chart. | 2023-04-21 10:05:12.915
NQM3.CME [CBV] 60 Min #15 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.957
NQM3.CME [CBV] 60 Min #12 | Reloading chart. | 2023-04-21 10:05:12.962
NQM3.CME [CBV] 60 Min #12 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.975
NQM3.CME [CBV] 15 Min #10 | Reloading chart. | 2023-04-21 10:05:12.980
NQM3.CME [CBV] 15 Min #10 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:12.993
NQM3.CME [CBV] 7500 Volume #20 | Reloading chart. | 2023-04-21 10:05:12.998
NQM3.CME [CBV] 7500 Volume #20 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.003
NQM3.CME [CBV] 7500 Volume #7 | Reloading chart. | 2023-04-21 10:05:13.037
NQM3.CME [CBV] 7500 Volume #7 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.041
NQM3.CME [CBV] 60 Min #8 | Reloading chart. | 2023-04-21 10:05:13.075
NQM3.CME [CBV] 60 Min #8 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.089
NQM3.CME 1 Trades #21 | Reloading chart. | 2023-04-21 10:05:13.095
NQM3.CME [CBV] Daily #35 | Reloading chart. | 2023-04-21 10:05:13.116
NQM3.CME [CBV] Daily #35 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.172
NQM3.CME [CBV] 240 Min #34 | Reloading chart. | 2023-04-21 10:05:13.189
NQM3.CME [CBV] 240 Min #34 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.237
NQM3.CME [CBV] 7500 Volume #29 | Reloading chart. | 2023-04-21 10:05:13.242
NQM3.CME [CBV] 7500 Volume #29 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.256
NQM3.CME/NQM3.CME 512 Trades #14 | Reloading chart. | 2023-04-21 10:05:13.298
NQM3.CME [CBV] 512 Trades #31 | Reloading chart. | 2023-04-21 10:05:13.307
NQM3.CME [CBV] 512 Trades #31 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.311
NQM3.CME/MNQM3.CME 750 Volume #18 | Reloading chart. | 2023-04-21 10:05:13.342
NQM3.CME [CBV] 15 Min #24 | Reloading chart. | 2023-04-21 10:05:13.367
NQM3.CME [CBV] 15 Min #24 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.381
NQM3.CME/MNQM3.CME 7500 Volume #40 | Reloading chart. | 2023-04-21 10:05:13.400
NQM3.CME #16 | Reloading chart. | 2023-04-21 10:05:13.408
NQM3.CME [CBV] 375 Volume #39 | Reloading chart. | 2023-04-21 10:05:13.418
NQM3.CME [CBV] 375 Volume #39 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.422
Loading market depth data. | 2023-04-21 10:05:13.520
Loaded depth data records for NQM3.CME 2023-04-14 from 00:00:00.000000 to 00:00:00.000000. | 2023-04-21 10:05:13.525
Loaded depth data records for NQM3.CME 2023-04-16 from 2023-04-16 19:45:09.591000 to 2023-04-16 19:59:59.909000. | 2023-04-21 10:05:13.526
NQM3.CME/MNQM3.CME 5.00 Range #30 | Reloading chart. | 2023-04-21 10:05:13.643
NQM3.CME/NQM3.CME 5.00 Range #33 | Reloading chart. | 2023-04-21 10:05:13.872
NQM3.CME/MNQM3.CME [CV] 1 Min #37 | Reloading chart. | 2023-04-21 10:05:13.925
NQM3.CME/MNQM3.CME [CV] 1 Min #37 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.932
NQM3.CME/NQM3.CME [CBV] 1 Min #32 | Reloading chart. | 2023-04-21 10:05:13.980
NQM3.CME/NQM3.CME [CBV] 1 Min #32 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:13.987
NQM3.CME [CBV] #36 | Reloading chart. | 2023-04-21 10:05:14.034
NQM3.CME [CBV] #36 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:14.051
Loading DLL: C:\SierraChart rith\Data\TWFX_FREE.dll (TWFX_FREE_64.dll). Handle: 7ff88f6b0000 | 2023-04-21 10:05:14.068
Loading DLL: C:\SierraChart rith\Data\Zyp Free by Zyp.dll (Zyp Free by Zyp_64.dll). Handle: 7ff88f600000 | 2023-04-21 10:05:14.085
Loading DLL: C:\SierraChart rith\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ff88e680000 | 2023-04-21 10:05:14.091
NQM3.CME [CBV] 5.00 Range #38 | Reloading chart. | 2023-04-21 10:05:14.127
NQM3.CME [CBV] 5.00 Range #38 | Waiting for historical downloads to complete with the IDs: 8, | 2023-04-21 10:05:14.134
HD Request # 8 | Downloading Historical Daily chart data for NQM3.CME. Starting date: 2023-04-18. Service: rithmic.trading | 2023-04-21 10:05:14.150
Loaded depth data records for NQM3.CME 2023-04-17 from 2023-04-16 20:00:00.055000 to 2023-04-17 19:42:44.202000. | 2023-04-21 10:05:14.165
NQM3.CME 1 Trades #21 | StartDateTimeForLoadingOrderFills: 2023-04-07 09:05:11 | 2023-04-21 10:05:14.233
Loaded depth data records for NQM3.CME 2023-04-18 from 2023-04-17 20:21:28.705000 to 2023-04-18 19:42:36.927000. | 2023-04-21 10:05:14.757
NQM3.CME #16 | StartDateTimeForLoadingOrderFills: 2023-04-07 09:05:11 | 2023-04-21 10:05:14.923
NQM3.CME/MNQM3.CME 5.00 Range #30 | StartDateTimeForLoadingOrderFills: 2023-04-07 09:05:12 | 2023-04-21 10:05:15.016
Loaded depth data records for NQM3.CME 2023-04-19 from 2023-04-19 08:00:43.964000 to 2023-04-19 19:13:38.065000. | 2023-04-21 10:05:15.231
NQM3.CME/NQM3.CME 5.00 Range #33 | StartDateTimeForLoadingOrderFills: 2023-04-07 09:05:12 | 2023-04-21 10:05:15.682
HD Request # 8 | Requesting historical Daily data for NQM23 starting at 2023-04-17. SC External HD service. | 2023-04-21 10:05:15.789
HD Request # 8 | Receiving historical Daily data for NQM3.CME starting at 2023-04-18. | 2023-04-21 10:05:15.964
HD Request # 8 | Writing historical Daily data to the file NQM3.CME.dly. | 2023-04-21 10:05:15.964
HD Request # 8 | Bytes received: 241 | 2023-04-21 10:05:15.966
HD Request # 8 | Received 4 Daily data records from 2023-04-18 00:00:00 to 2023-04-20 00:00:00 (3.0 days) and wrote 3 records for NQM3.CME | 2023-04-21 10:05:15.966
HD Request # 8 | Completion time: 1s. | 2023-04-21 10:05:15.966
HD Request # 8 | Daily data download complete for NQM3.CME. Unique request ID: 8 | 2023-04-21 10:05:15.966
Removing historical data download ID 8. | 2023-04-21 10:05:15.966
Triggering next historical data download in queue. | 2023-04-21 10:05:15.966
No download requests in the queue to start downloads for. | 2023-04-21 10:05:15.966
NQM3.CME [CBV] 750 Volume #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:15.974
NQM3.CME [CBV] 750 Volume #1 | Reloading chart. | 2023-04-21 10:05:15.974
NQM3.CME [CBV] 5 Min #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:15.985
NQM3.CME [CBV] 5 Min #6 | Reloading chart. | 2023-04-21 10:05:15.986
NQM3.CME [CBV] 750 Volume #26 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.000
NQM3.CME [CBV] 750 Volume #26 | Reloading chart. | 2023-04-21 10:05:16.001
NQM3.CME [CBV] 1 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.012
NQM3.CME [CBV] 1 Day #3 | Reloading chart. | 2023-04-21 10:05:16.013
NQM3.CME [CBV] 500 Volume #28 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.059
NQM3.CME [CBV] 500 Volume #28 | Reloading chart. | 2023-04-21 10:05:16.060
NQM3.CME [CBV] 3072 Trades #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.091
NQM3.CME [CBV] 3072 Trades #4 | Reloading chart. | 2023-04-21 10:05:16.092
NQM3.CME [CBV] 512 Trades #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.097
NQM3.CME [CBV] 512 Trades #5 | Reloading chart. | 2023-04-21 10:05:16.097
NQM3.CME [CBV] 3072 Trades #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.102
NQM3.CME [CBV] 3072 Trades #11 | Reloading chart. | 2023-04-21 10:05:16.104
NQM3.CME [CBV] 375 Volume #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.109
NQM3.CME [CBV] 375 Volume #19 | Reloading chart. | 2023-04-21 10:05:16.109
NQM3.CME [CBV] 512 Trades #17 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.114
NQM3.CME [CBV] 512 Trades #17 | Reloading chart. | 2023-04-21 10:05:16.117
NQM3.CME [CBV] 14500 Volume #23 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.123
NQM3.CME [CBV] 14500 Volume #23 | Reloading chart. | 2023-04-21 10:05:16.124
NQM3.CME [CBV] 1 Min #27 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.131
NQM3.CME [CBV] 1 Min #27 | Reloading chart. | 2023-04-21 10:05:16.137
NQM3.CME [CBV] 5 Min #25 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.141
NQM3.CME [CBV] 5 Min #25 | Reloading chart. | 2023-04-21 10:05:16.142
NQM3.CME [CBV] 7 Day #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.185
NQM3.CME [CBV] 7 Day #9 | Reloading chart. | 2023-04-21 10:05:16.192
Loaded depth data records for NQM3.CME 2023-04-20 from 2023-04-20 08:10:20.345000 to 2023-04-20 19:59:59.985000. | 2023-04-21 10:05:16.300
Loaded depth data records for NQM3.CME 2023-04-21 from 2023-04-20 20:00:00.023000 to 2023-04-21 10:05:10.343000. | 2023-04-21 10:05:16.341
Chart #4 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.511
Chart #4 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.511
Chart #4 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.511
NQM3.CME [CBV] 7500 Volume #29 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.511
NQM3.CME [CBV] 7500 Volume #29 | Reloading chart. | 2023-04-21 10:05:16.512
Chart #5 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.592
Chart #5 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.592
Chart #5 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.592
Chart #19 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.596
Chart #19 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.596
Chart #19 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.596
Chart #23 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.597
Chart #23 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.597
Chart #23 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.597
Chart #11 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.599
Chart #11 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.599
Chart #11 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.599
Chart #17 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.636
Chart #17 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.636
Chart #17 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.636
Chart #6 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.721
Chart #6 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.721
Chart #6 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.721
Chart #28 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.832
Chart #28 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.832
Chart #28 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.832
NQM3.CME/MNQM3.CME 750 Volume #18 | Reloading chart. | 2023-04-21 10:05:16.848
Mapping MNQM3.CME to MNQM23. Service code: cme | 2023-04-21 10:05:16.856
Denali Data Feed | Starting real-time market data updates for: MNQM3.CME (MNQM23). ID: 2 Service code: cme | 2023-04-21 10:05:16.856
Denali Data Feed | Requesting security definition data for: MNQM3.CME (MNQM23). ID: 2 | 2023-04-21 10:05:16.856
NQM3.CME [CBV] 60 Min #22 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.857
NQM3.CME [CBV] 60 Min #22 | Reloading chart. | 2023-04-21 10:05:16.858
Chart #27 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.892
Chart #27 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.892
Chart #27 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:16.892
NQM3.CME [CBV] 30 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.892
NQM3.CME [CBV] 30 Min #2 | Reloading chart. | 2023-04-21 10:05:16.911
NQM3.CME [CBV] 60 Min #15 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.932
NQM3.CME [CBV] 60 Min #15 | Reloading chart. | 2023-04-21 10:05:16.932
Denali Data Feed | Received security definition for symbol MNQM3.CME | 2023-04-21 10:05:16.998
NQM3.CME [CBV] 60 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:16.998
NQM3.CME [CBV] 60 Min #12 | Reloading chart. | 2023-04-21 10:05:17.000
NQM3.CME [CBV] 15 Min #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.027
NQM3.CME [CBV] 15 Min #10 | Reloading chart. | 2023-04-21 10:05:17.041
NQM3.CME [CBV] 7500 Volume #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.075
NQM3.CME [CBV] 7500 Volume #20 | Reloading chart. | 2023-04-21 10:05:17.081
NQM3.CME [CBV] 7500 Volume #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.095
NQM3.CME [CBV] 7500 Volume #7 | Reloading chart. | 2023-04-21 10:05:17.096
NQM3.CME/MNQM3.CME 5.00 Range #30 | Reloading chart. | 2023-04-21 10:05:17.120
NQM3.CME [CBV] 60 Min #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.131
NQM3.CME [CBV] 60 Min #8 | Reloading chart. | 2023-04-21 10:05:17.132
NQM3.CME [CBV] Daily #35 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.181
NQM3.CME [CBV] Daily #35 | Reloading chart. | 2023-04-21 10:05:17.193
NQM3.CME [CBV] 240 Min #34 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.287
NQM3.CME [CBV] 240 Min #34 | Reloading chart. | 2023-04-21 10:05:17.294
Loading market depth data. | 2023-04-21 10:05:17.319
Loaded depth data records for NQM3.CME 2023-04-14 from 00:00:00.000000 to 00:00:00.000000. | 2023-04-21 10:05:17.320
Loaded depth data records for NQM3.CME 2023-04-16 from 2023-04-16 19:45:09.591000 to 2023-04-16 19:59:59.909000. | 2023-04-21 10:05:17.322
NQM3.CME/NQM3.CME 5.00 Range #33 | Reloading chart. | 2023-04-21 10:05:17.396
NQM3.CME [CBV] 512 Trades #31 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.443
NQM3.CME [CBV] 512 Trades #31 | Reloading chart. | 2023-04-21 10:05:17.450
NQM3.CME [CBV] 15 Min #24 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.463
NQM3.CME [CBV] 15 Min #24 | Reloading chart. | 2023-04-21 10:05:17.466
NQM3.CME/MNQM3.CME [CV] 1 Min #37 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.490
NQM3.CME/MNQM3.CME [CV] 1 Min #37 | Reloading chart. | 2023-04-21 10:05:17.494
NQM3.CME [CBV] 375 Volume #39 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.549
NQM3.CME [CBV] 375 Volume #39 | Reloading chart. | 2023-04-21 10:05:17.581
NQM3.CME [CBV] 5.00 Range #38 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.591
NQM3.CME [CBV] 5.00 Range #38 | Reloading chart. | 2023-04-21 10:05:17.595
Requesting market depth updates for: MNQM3.CME if supported. | 2023-04-21 10:05:17.651
NQM3.CME/NQM3.CME [CBV] 1 Min #32 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.679
NQM3.CME/NQM3.CME [CBV] 1 Min #32 | Reloading chart. | 2023-04-21 10:05:17.681
NQM3.CME [CBV] #36 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-04-21 10:05:17.693
NQM3.CME [CBV] #36 | Reloading chart. | 2023-04-21 10:05:17.706
Denali Data Feed | Clearing market depth for MNQM3.CME | 2023-04-21 10:05:17.783
NQM3.CME [CBV] 7500 Volume #29 | Reloading chart. | 2023-04-21 10:05:17.837
Chart #20 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:17.999
Chart #20 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:17.999
Chart #20 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:17.999
NQM3.CME [CBV] 750 Volume #1 | Reloading chart. | 2023-04-21 10:05:18.000
NQM3.CME [CBV] 5 Min #6 | Reloading chart. | 2023-04-21 10:05:18.117
NQM3.CME [CBV] 750 Volume #26 | Reloading chart. | 2023-04-21 10:05:18.217
Chart #25 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:18.438
Chart #25 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:18.438
Chart #25 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:18.438
NQM3.CME [CBV] 1 Day #3 | Reloading chart. | 2023-04-21 10:05:18.502
Loaded depth data records for NQM3.CME 2023-04-17 from 2023-04-16 20:00:00.055000 to 2023-04-17 19:42:44.202000. | 2023-04-21 10:05:18.632
NQM3.CME/MNQM3.CME 5.00 Range #30 | StartDateTimeForLoadingOrderFills: 2023-04-07 09:05:17 | 2023-04-21 10:05:18.916
NQM3.CME/NQM3.CME 5.00 Range #33 | StartDateTimeForLoadingOrderFills: 2023-04-07 09:05:17 | 2023-04-21 10:05:19.136
Chart #32 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:19.678
Loaded depth data records for NQM3.CME 2023-04-18 from 2023-04-17 20:21:28.705000 to 2023-04-18 19:42:36.927000. | 2023-04-21 10:05:19.691
NQM3.CME/MNQM3.CME [CV] 1 Min #37 | Study: Display Forex factory calendar news items | Making HTTP request. | 2023-04-21 10:05:19.713
Chart: NQM3.CME/MNQM3.CME [CV] 1 Min #37 | Study: Display Forex factory calendar news items | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2023-04-21 10:05:19.713 *
Chart #6 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:19.926
Chart #6 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:19.926
Loaded depth data records for NQM3.CME 2023-04-19 from 2023-04-19 08:00:43.964000 to 2023-04-19 19:13:38.065000. | 2023-04-21 10:05:20.622
NQM3.CME [CBV] 500 Volume #28 | Reloading chart. | 2023-04-21 10:05:20.669
NQM3.CME [CBV] 512 Trades #5 | Reloading chart. | 2023-04-21 10:05:20.686
NQM3.CME [CBV] 3072 Trades #4 | Reloading chart. | 2023-04-21 10:05:20.707
NQM3.CME [CBV] 375 Volume #19 | Reloading chart. | 2023-04-21 10:05:20.725
NQM3.CME [CBV] 3072 Trades #11 | Reloading chart. | 2023-04-21 10:05:20.741
NQM3.CME [CBV] 14500 Volume #23 | Reloading chart. | 2023-04-21 10:05:20.763
NQM3.CME [CBV] 512 Trades #17 | Reloading chart. | 2023-04-21 10:05:20.782
NQM3.CME [CBV] 5 Min #25 | Reloading chart. | 2023-04-21 10:05:20.852
NQM3.CME [CBV] 1 Min #27 | Reloading chart. | 2023-04-21 10:05:20.936
NQM3.CME [CBV] 7 Day #9 | Reloading chart. | 2023-04-21 10:05:20.966
Loaded depth data records for NQM3.CME 2023-04-20 from 2023-04-20 08:10:20.345000 to 2023-04-20 19:59:59.985000. | 2023-04-21 10:05:21.923
Loaded depth data records for NQM3.CME 2023-04-21 from 2023-04-20 20:00:00.023000 to 2023-04-21 10:05:15.407000. | 2023-04-21 10:05:21.969
Chart #5 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.976
Chart #5 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.976
Chart #19 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.982
Chart #19 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.982
Chart #4 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.983
Chart #4 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.983
Chart #23 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.984
Chart #23 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.984
Chart #11 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.985
Chart #11 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.985
Chart #17 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.989
Chart #17 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:21.989
Chart #28 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:22.012
Chart #28 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:22.012
Chart #27 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:22.021
Chart #27 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:22.021
NQM3.CME [CBV] 60 Min #22 | Reloading chart. | 2023-04-21 10:05:22.228
NQM3.CME [CBV] 30 Min #2 | Reloading chart. | 2023-04-21 10:05:22.322
NQM3.CME [CBV] 60 Min #15 | Reloading chart. | 2023-04-21 10:05:22.379
Chart #8 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:22.534
Chart #8 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:22.534
Chart #8 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:22.534
NQM3.CME [CBV] 5.00 Range #38 | Reloading chart. | 2023-04-21 10:05:22.559
NQM3.CME/MNQM3.CME [CV] 1 Min #37 | Reloading chart. | 2023-04-21 10:05:22.580
NQM3.CME [CBV] 60 Min #12 | Reloading chart. | 2023-04-21 10:05:22.608
NQM3.CME [CBV] 15 Min #10 | Reloading chart. | 2023-04-21 10:05:22.659
NQM3.CME [CBV] 7500 Volume #20 | Reloading chart. | 2023-04-21 10:05:22.708
NQM3.CME [CBV] 7500 Volume #7 | Reloading chart. | 2023-04-21 10:05:22.730
NQM3.CME [CBV] 60 Min #8 | Reloading chart. | 2023-04-21 10:05:22.757
NQM3.CME [CBV] Daily #35 | Reloading chart. | 2023-04-21 10:05:22.815
NQM3.CME [CBV] 240 Min #34 | Reloading chart. | 2023-04-21 10:05:22.965
Chart #25 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:23.133
Chart #25 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:23.133
NQM3.CME [CBV] 512 Trades #31 | Reloading chart. | 2023-04-21 10:05:23.193
NQM3.CME [CBV] 15 Min #24 | Reloading chart. | 2023-04-21 10:05:23.217
NQM3.CME [CBV] 375 Volume #39 | Reloading chart. | 2023-04-21 10:05:23.295
NQM3.CME/NQM3.CME [CBV] 1 Min #32 | Reloading chart. | 2023-04-21 10:05:23.314
NQM3.CME [CBV] #36 | Reloading chart. | 2023-04-21 10:05:23.336
Chart #20 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:23.405
Chart #20 has tagged chart #32 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:23.405
Chart #20 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:23.405
NQM3.CME [CBV][M] 7500 Volume #29 | StartDateTimeForLoadingOrderFills: 2023-03-07 17:00:00 | 2023-04-21 10:05:24.933
Chart #29 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:24.939
Chart #29 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:24.939
Chart #29 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:24.939
Chart #1 has tagged chart #12 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:29.555
Chart #1 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:29.555
Chart #1 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:29.555
Chart #1 has tagged chart #32 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:29.555
Chart #1 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:29.555
Chart #1 has tagged chart #8 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:29.555
Chart #2 has tagged chart #32 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:30.480
Chart #2 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:30.480
DTC Client socket (2) | Deleting network socket now after delay. | 2023-04-21 10:05:31.368
Chart #3 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:38.517
Chart #3 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:38.517
Chart #3 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:05:38.517
Chart #34 has tagged chart #38 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:04.850
NQM3.CME/NQM3.CME[M] 5.00 Range #33 | StartDateTimeForLoadingOrderFills: 2023-04-07 09:06:28 | 2023-04-21 10:06:30.359
NQM3.CME[M] #16 | StartDateTimeForLoadingOrderFills: 2023-04-07 09:06:31 | 2023-04-21 10:06:32.968
NQM3.CME [CBV][M] 5.00 Range #38 | Performing a full recalculation because it has been tagged. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.170
NQM3.CME[M]/MNQM3.CME[M] 5.00 Range #30 | Performing a full recalculation because it has been tagged. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.188
NQM3.CME [CBV][M] 60 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.282
NQM3.CME/NQM3.CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.329
NQM3.CME/NQM3.CME [CBV][M] 1 Min #32 | Performing a full recalculation because it has been tagged. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.398
Chart #32 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.428
NQM3.CME [CBV][M] 60 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.466
Chart #8 has tagged chart #14 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.471
Chart #8 has tagged chart #30 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.471
Chart #8 has tagged chart #33 for full recalculation. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.471
NQM3.CME[M]/MNQM3.CME[M] 5.00 Range #30 | Performing a full recalculation because it has been tagged. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.488
NQM3.CME/NQM3.CME[M] 5.00 Range #33 | Performing a full recalculation because it has been tagged. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.561
NQM3.CME/NQM3.CME[M] 512 Trades #14 | Performing a full recalculation because it has been tagged. Chartbook: OFL NQ.Cht | 2023-04-21 10:06:37.911
File >> Disconnect selected. | 2023-04-21 10:10:34.092
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2023-04-21 10:10:34.093
DTC Client socket (1) | CloseSocket call. | 2023-04-21 10:10:34.093
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-04-21 10:10:34.093
DTC Client socket (1) | Max send buffer size during socket life: 406 | 2023-04-21 10:10:34.093
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-04-21 10:10:34.093
Denali Data Feed | Waiting for socket receive thread to end | 2023-04-21 10:10:34.093
DTC Client socket (3) | CloseSocket call. | 2023-04-21 10:10:34.093
Denali Data Feed | Disconnected from the server. | 2023-04-21 10:10:34.093
Rithmic Direct - DTC | Disconnected. | 2023-04-21 10:10:34.093
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2023-04-21 10:10:34.093
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-04-21 10:10:34.141
DTC Client socket (1) | Closed. | 2023-04-21 10:10:34.141
Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Aggregated | 2023-04-21 10:10:44.245
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2023-04-21 10:10:44.245
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-04-21 10:10:44.247
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-04-21 10:10:44.247
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2023-04-21 10:10:44.247
Rithmic Direct - DTC | Network connection to server complete. | 2023-04-21 10:10:44.287
Rithmic Direct - DTC | Starting socket receive thread. | 2023-04-21 10:10:44.287
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2023-04-21 10:10:44.287
Rithmic Direct - DTC | Sending logon request message. | 2023-04-21 10:10:44.287
Rithmic Direct - DTC | Received logon response. | 2023-04-21 10:10:44.423
Rithmic Direct - DTC | Server Name: . | 2023-04-21 10:10:44.423
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2023-04-21 10:10:44.423
Rithmic Direct - DTC | Successfully connected. | 2023-04-21 10:10:44.423
Rithmic Direct - DTC | Trading is supported. | 2023-04-21 10:10:44.423
Rithmic Direct - DTC | Order cancel and replace is supported. | 2023-04-21 10:10:44.423
Rithmic Direct - DTC | OCO Orders supported. | 2023-04-21 10:10:44.423
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2023-04-21 10:10:44.423
Rithmic Direct - DTC | Connected to server complete. | 2023-04-21 10:10:44.423
Triggering next historical data download in queue. | 2023-04-21 10:10:44.424
No download requests in the queue to start downloads for. | 2023-04-21 10:10:44.424
Mapping NQM3.CME to NQM23. Service code: cme | 2023-04-21 10:10:44.946
Using symbol data fast lookup vector | 2023-04-21 10:10:44.946
Denali Data Feed | Starting real-time market data updates for: NQM3.CME (NQM23). ID: 1 Service code: cme | 2023-04-21 10:10:44.946
Denali Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 443 | 2023-04-21 10:10:44.946
Denali Data Feed | Requesting security definition data for: NQM3.CME (NQM23). ID: 1 | 2023-04-21 10:10:44.946
Added historical Intraday data request for NQM3.CME to the queue. | 2023-04-21 10:10:44.946
Intraday data recording state for symbol NQM3.CME is set to download 'Pending'. | 2023-04-21 10:10:44.946
Triggering next historical data download in queue. | 2023-04-21 10:10:44.946
DTC Client socket (2) | Creating socket. | 2023-04-21 10:10:44.946
DTC Client socket (2) | New receive buffer size: 5242880 | 2023-04-21 10:10:44.946
DTC Client socket (2) | Connecting to IP: 142.215.17.189. | 2023-04-21 10:10:44.946
Delaying start of download for NQM3.CME. | 2023-04-21 10:10:44.955
Denali Data Feed | Network connection to server complete. | 2023-04-21 10:10:44.982
Denali Data Feed | Starting socket receive thread. | 2023-04-21 10:10:44.982
Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-04-21 10:10:44.982
Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-04-21 10:10:45.055
Denali Data Feed | Sending logon request message. | 2023-04-21 10:10:45.055
Denali Data Feed | Received logon response. | 2023-04-21 10:10:45.865
Denali Data Feed | Server Name: SC Realtime Server. | 2023-04-21 10:10:45.865
Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-04-21 10:10:45.865
Denali Data Feed | Successfully connected. | 2023-04-21 10:10:45.865
Denali Data Feed | Trading is not supported. | 2023-04-21 10:10:45.865
Denali Data Feed | Restarting real-time data updates for symbol: NQM3.CME -> NQM23 | 2023-04-21 10:10:45.865
Opened cached Depth file: C:\SierraChart rith\Data\MarketDepthData\NQM3.CME.2023-04-21.depth | 2023-04-21 10:10:45.990
Denali Data Feed | Received security definition for symbol NQM3.CME | 2023-04-21 10:10:45.990
Requesting market depth updates for: NQM3.CME if supported. | 2023-04-21 10:10:49.413
Denali Data Feed | Clearing market depth for NQM3.CME | 2023-04-21 10:10:49.489
HD Request # 9 | Downloading Intraday chart data for NQM3.CME to the file NQM3.CME.scid. Service: cme | 2023-04-21 10:10:50.464
HD Request # 9 | Download start date-time: 2023-04-21 10:10:32.000000. File last date-time: 2023-04-21 10:10:32.553006 | 2023-04-21 10:10:50.465
HD Request # 9 | Using server: ds23.sierracharts.com port 10149 | 2023-04-21 10:10:50.465
Socket (4) | Creating socket. | 2023-04-21 10:10:50.465
Socket (4) | New receive buffer size: 5242880 | 2023-04-21 10:10:50.465
Socket (4) | Connecting to IP: 142.215.17.190. | 2023-04-21 10:10:50.465
HD Request # 9 | Setting DTC encoding to Binary VLS | 2023-04-21 10:10:50.569
HD Request # 9 | Sending historical data logon request message. | 2023-04-21 10:10:50.569
HD Request # 9 | Requesting Intraday data. Start date-time: 2023-04-21 10:10:32. Record interval: 0. Symbol: NQM23 | 2023-04-21 10:10:51.146
HD Request # 9 | Decompressing data. | 2023-04-21 10:10:51.182
HD Request # 9 | Receiving Intraday data for NQM3.CME starting at 2023-04-21 10:10:32.082000 | 2023-04-21 10:10:51.186
Socket (4) | CloseSocket call. | 2023-04-21 10:10:51.186
Socket (4) | Shutdown started. Waiting for graceful close. | 2023-04-21 10:10:51.186
Historical data download thread signaled to stop. | 2023-04-21 10:10:51.186
HD Request # 9 | Timestamp of first Intraday data file record written: 2023-04-21 10:10:32.660000. | 2023-04-21 10:10:51.186
HD Request # 9 | Received 779 Intraday data records from 2023-04-21 10:10:32.082000 to 2023-04-21 10:10:46.407000 (14.3 seconds. Delay: 4.8 seconds) and wrote 752 records for NQM3.CME | 2023-04-21 10:10:51.186
HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2023-04-21 14:10:46.407000 | 2023-04-21 10:10:51.187
Added 101 Time and Sales records to Intraday data file for NQM3.CME after download. | 2023-04-21 10:10:51.187
HD Request # 9 | Completion time: 1s. | 2023-04-21 10:10:51.187
HD Request # 9 | Intraday data download complete for NQM3.CME. Unique request ID: 9 | 2023-04-21 10:10:51.187
Removing historical data download ID 9. | 2023-04-21 10:10:51.187
Real-time Intraday chart data file updates started for NQM3.CME | 2023-04-21 10:10:51.187
Intraday chart data file opened for NQM3.CME | 2023-04-21 10:10:51.187
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2023-04-21 10:10:51.187
Triggering next historical data download in queue. | 2023-04-21 10:10:51.187
No download requests in the queue to start downloads for. | 2023-04-21 10:10:51.187
Socket (4) | Socket gracefully closed by remote side. | 2023-04-21 10:10:51.227
Socket (4) | Closed. | 2023-04-21 10:10:51.227
Opened cached Intraday file: C:\SierraChart rith\Data\NQM3.CME.scid. Thread ID: 17848 | 2023-04-21 10:10:54.127
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Creating socket. Using TLS 1.2. | 2023-04-21 10:11:04.242
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | New receive buffer size: 32768 | 2023-04-21 10:11:04.242
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Connecting to IP: 38.79.0.89. | 2023-04-21 10:11:04.242
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Socket gracefully closed by remote side. | 2023-04-21 10:11:04.390
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | CloseSocket call. | 2023-04-21 10:11:04.391
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-04-21 10:11:04.391
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (4) | Closed. | 2023-04-21 10:11:04.391
