Date/Time: Tue, 22 Apr 2025 06:45:59 +0000
No intraday historical data from CQG for the HKEX
View Count: 556
[2023-03-01 08:49:33] |
User288938 - Posts: 35 |
Hey! So I purchased HKEX data feed from AMP using CQG. I posted before and was told this was a viable solution however, with the feed active I am getting live data but my historical intraday data doesnt go back further than 2 days. I've tried changing all the settings and deleting the data and redownloading but it just doesnt seem to do anything. Is this a sierra chart problem or amp/cqg problem? Cheers! |
[2023-03-01 09:27:45] |
Sierra_Chart Engineering - Posts: 19293 |
Are you at least getting two days of historical data for that exchange? Or nothing at all. If you are getting some data then follow through the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-01 09:28:13
[2023-03-01 10:12:32] |
Yeah so im getting about 2 days worth. I did all the steps and nothing. The symbol is this: F.US.HSIH23. The only thing that ive changed is i canceled my CME denali feed because I wasnt using it anymore. Would that have an affect on HKEX though?
[2023-03-01 13:26:58] |
No that would not make any difference. Yeah so im getting about 2 days worth. I did all the steps and nothing. This would mean this is all the data that is available for that exchange.The only other thing we can recommend is set this particular setting to 1 Minute and try re-downloading the data again: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-01 13:28:44
[2023-03-01 13:58:04] |
Yeah same thing, no changes. Do you think this could be a CQG issue? |
[2023-03-01 14:25:01] |
The answer is yes as long as you have followed the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-01 23:58:18] |
i contacted both CQG and AMP and obviously theyre both saying it isnt there fault either. Im confident in the settings because they're the same settings I used when i used denali to trade on CME.
[2023-03-02 00:19:57] |
I noticed that when i switch my datafeed back to SC data - all services, the same issue is happening whereas a few days ago I had historical data loaded. Is this correlated somehow?
[2023-03-02 08:51:20] |
We definitively cannot help at all with CQG data. If you are having an issue with a particular symbol when using a Sierra Chart data feed, not CQG data, then first follow through the instructions here step-by-step and do not ignore any steps: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data And then follow the instructions here if you are still not getting enough historical data: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". Or, in the case of a Continuous Futures Contract chart, follow these instructions: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data After about a minute provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-02 08:52:16
[2023-03-02 10:06:12] |
This is the log, also I dont know if it helps but when I use CQG Desktrader, all the data i need is there. So I guess its something with sierra charts. Software version: 2484 64-bit | 2023-03-02 05:04:17.571 Primary Thread ID: 7068 | 2023-03-02 05:04:17.571 Usage end date: 2023-03-17 | 2023-03-02 05:04:17.571 Enabled for: Advanced Features 2. | 2023-03-02 05:04:17.571 Enabled for: Sierra Chart Historical Data Service. | 2023-03-02 05:04:17.571 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-03-02 05:04:17.571 Enabled for: Delayed Denali Exchange Data Feed. | 2023-03-02 05:04:17.571 Enabled for exchange2: fairx_exchange.data | 2023-03-02 05:04:17.571 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-03-02 05:04:17.571 Current selected Data/Trading service: CQG WebAPI | 2023-03-02 05:04:17.571 Custom symbol settings values: disabled | 2023-03-02 05:04:17.571 Chart Update Interval: 10 | 2023-03-02 05:04:17.571 Intraday Data Storage Time Unit: 0 | 2023-03-02 05:04:17.571 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-03-02 05:04:17.571 2023-03-02 10:04:17 Local computer time in UTC | 2023-03-02 05:04:17.571 2023-03-02 05:04:17 Local computer time in SC Time Zone | 2023-03-02 05:04:17.571 2023-03-02 09:59:53 Server time in UTC | 2023-03-02 05:04:17.571 Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-03-02 05:04:17.571 Program path: C:\SierraChart\ | 2023-03-02 05:04:17.571 Data Files path: C:\SierraChart\Data\ | 2023-03-02 05:04:17.571 OS Version Number: 10.0 | 2023-03-02 05:04:17.571 Locale Setting: C | 2023-03-02 05:04:17.571 DLLs: Sigmaspikev4_64.dll, UserContributedStudies_64.dll | 2023-03-02 05:04:17.572 Allowed protected custom studies: | 2023-03-02 05:04:17.572 Crash reporter started: true | 2023-03-02 05:04:17.572 CQG WebAPI | Using primary service for historical data for F.US.HSIM22 | 2023-03-02 05:04:29.121 Added historical Intraday data request for F.US.HSIM22 to the queue. | 2023-03-02 05:04:29.121 Intraday data recording state for symbol F.US.HSIM22 is set to download 'Pending'. | 2023-03-02 05:04:29.121 Triggering next historical data download in queue. | 2023-03-02 05:04:29.121 Reloading all charts with filename: F.US.HSIM22.scid | 2023-03-02 05:04:29.121 Added historical Daily data request for F.US.HSIM22 to the queue. | 2023-03-02 05:04:29.121 Triggering next historical data download in queue. | 2023-03-02 05:04:29.121 CQG WebAPI | Using primary service for historical data for F.US.HSIN22 | 2023-03-02 05:04:29.121 Added historical Intraday data request for F.US.HSIN22 to the queue. | 2023-03-02 05:04:29.121 Intraday data recording state for symbol F.US.HSIN22 is set to download 'Pending'. | 2023-03-02 05:04:29.121 Reloading all charts with filename: F.US.HSIN22.scid | 2023-03-02 05:04:29.121 Added historical Daily data request for F.US.HSIN22 to the queue. | 2023-03-02 05:04:29.121 CQG WebAPI | Using primary service for historical data for F.US.HSIQ22 | 2023-03-02 05:04:29.122 Added historical Intraday data request for F.US.HSIQ22 to the queue. | 2023-03-02 05:04:29.122 Intraday data recording state for symbol F.US.HSIQ22 is set to download 'Pending'. | 2023-03-02 05:04:29.122 Reloading all charts with filename: F.US.HSIQ22.scid | 2023-03-02 05:04:29.122 Added historical Daily data request for F.US.HSIQ22 to the queue. | 2023-03-02 05:04:29.122 CQG WebAPI | Using primary service for historical data for F.US.HSIU22 | 2023-03-02 05:04:29.122 Added historical Intraday data request for F.US.HSIU22 to the queue. | 2023-03-02 05:04:29.122 Intraday data recording state for symbol F.US.HSIU22 is set to download 'Pending'. | 2023-03-02 05:04:29.122 Reloading all charts with filename: F.US.HSIU22.scid | 2023-03-02 05:04:29.122 Added historical Daily data request for F.US.HSIU22 to the queue. | 2023-03-02 05:04:29.122 CQG WebAPI | Using primary service for historical data for F.US.HSIV22 | 2023-03-02 05:04:29.122 Added historical Intraday data request for F.US.HSIV22 to the queue. | 2023-03-02 05:04:29.122 Intraday data recording state for symbol F.US.HSIV22 is set to download 'Pending'. | 2023-03-02 05:04:29.122 Reloading all charts with filename: F.US.HSIV22.scid | 2023-03-02 05:04:29.122 Added historical Daily data request for F.US.HSIV22 to the queue. | 2023-03-02 05:04:29.122 CQG WebAPI | Using primary service for historical data for F.US.HSIX22 | 2023-03-02 05:04:29.122 Added historical Intraday data request for F.US.HSIX22 to the queue. | 2023-03-02 05:04:29.122 Intraday data recording state for symbol F.US.HSIX22 is set to download 'Pending'. | 2023-03-02 05:04:29.122 Reloading all charts with filename: F.US.HSIX22.scid | 2023-03-02 05:04:29.123 Added historical Daily data request for F.US.HSIX22 to the queue. | 2023-03-02 05:04:29.123 CQG WebAPI | Using primary service for historical data for F.US.HSIZ22 | 2023-03-02 05:04:29.123 Added historical Intraday data request for F.US.HSIZ22 to the queue. | 2023-03-02 05:04:29.123 Intraday data recording state for symbol F.US.HSIZ22 is set to download 'Pending'. | 2023-03-02 05:04:29.123 Reloading all charts with filename: F.US.HSIZ22.scid | 2023-03-02 05:04:29.123 Added historical Daily data request for F.US.HSIZ22 to the queue. | 2023-03-02 05:04:29.123 CQG WebAPI | Using primary service for historical data for F.US.HSIF23 | 2023-03-02 05:04:29.123 Added historical Intraday data request for F.US.HSIF23 to the queue. | 2023-03-02 05:04:29.123 Intraday data recording state for symbol F.US.HSIF23 is set to download 'Pending'. | 2023-03-02 05:04:29.123 Reloading all charts with filename: F.US.HSIF23.scid | 2023-03-02 05:04:29.123 Added historical Daily data request for F.US.HSIF23 to the queue. | 2023-03-02 05:04:29.123 CQG WebAPI | Using primary service for historical data for F.US.HSIG23 | 2023-03-02 05:04:29.123 Added historical Intraday data request for F.US.HSIG23 to the queue. | 2023-03-02 05:04:29.123 Intraday data recording state for symbol F.US.HSIG23 is set to download 'Pending'. | 2023-03-02 05:04:29.123 Reloading all charts with filename: F.US.HSIG23.scid | 2023-03-02 05:04:29.123 Added historical Daily data request for F.US.HSIG23 to the queue. | 2023-03-02 05:04:29.123 CQG WebAPI | Using primary service for historical data for F.US.HSIH23 | 2023-03-02 05:04:29.124 Added historical Intraday data request for F.US.HSIH23 to the queue. | 2023-03-02 05:04:29.124 Intraday data recording state for symbol F.US.HSIH23 is set to download 'Pending'. | 2023-03-02 05:04:29.124 Added historical Daily data request for F.US.HSIH23 to the queue. | 2023-03-02 05:04:29.124 HD Request # 50 | Downloading Intraday chart data for F.US.HSIM22 to the file F.US.HSIM22.scid. Service: cqg | 2023-03-02 05:04:29.124 HD Request # 50 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.124 HD Request # 50 | Download start date-time: 2022-05-20 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.124 HD Request # 50 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.124 HD Request # 50 | Error downloading historical Intraday data for F.US.HSIM22. The symbol is unknown to the server. | 2023-03-02 05:04:29.124 HD Request # 50 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIM22 | 2023-03-02 05:04:29.124 HD Request # 50 | Completion time: 0s. | 2023-03-02 05:04:29.124 HD Request # 50 | Intraday data download complete for F.US.HSIM22. Unique request ID: 32 | 2023-03-02 05:04:29.124 Added historical Intraday data request for F.US.HSIM22 to the queue. | 2023-03-02 05:04:29.124 Triggering next historical data download in queue. | 2023-03-02 05:04:29.124 HD Request # 51 | Downloading Historical Daily chart data for F.US.HSIM22. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:29.124 HD Request # 52 | Downloading Intraday chart data for F.US.HSIM22 to the file F.US.HSIM22.scid. Service: cqg | 2023-03-02 05:04:29.124 HD Request # 52 | Download start date-time: 2022-05-20 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.125 HD Request # 52 | Error downloading historical Intraday data for F.US.HSIM22. The symbol is unknown to the server. | 2023-03-02 05:04:29.125 HD Request # 52 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIM22 | 2023-03-02 05:04:29.125 HD Request # 52 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-03-02 05:04:29.125 HD Request # 52 | Completion time: 0s. | 2023-03-02 05:04:29.125 HD Request # 52 | Intraday data download complete for F.US.HSIM22. Unique request ID: 32 | 2023-03-02 05:04:29.125 Removing historical data download ID 32. | 2023-03-02 05:04:29.125 Real-time Intraday chart data file updates started for F.US.HSIM22 | 2023-03-02 05:04:29.125 Intraday chart data file opened for F.US.HSIM22 | 2023-03-02 05:04:29.125 HD Request # 52 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.125 Triggering next historical data download in queue. | 2023-03-02 05:04:29.125 HD Request # 53 | Downloading Intraday chart data for F.US.HSIN22 to the file F.US.HSIN22.scid. Service: cqg | 2023-03-02 05:04:29.125 HD Request # 53 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.125 HD Request # 53 | Download start date-time: 2022-06-19 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.125 HD Request # 53 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.125 HD Request # 53 | Error downloading historical Intraday data for F.US.HSIN22. The symbol is unknown to the server. | 2023-03-02 05:04:29.125 HD Request # 53 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIN22 | 2023-03-02 05:04:29.125 HD Request # 53 | Completion time: 0s. | 2023-03-02 05:04:29.125 HD Request # 53 | Intraday data download complete for F.US.HSIN22. Unique request ID: 34 | 2023-03-02 05:04:29.125 Added historical Intraday data request for F.US.HSIN22 to the queue. | 2023-03-02 05:04:29.125 Triggering next historical data download in queue. | 2023-03-02 05:04:29.125 HD Request # 54 | Downloading Intraday chart data for F.US.HSIN22 to the file F.US.HSIN22.scid. Service: cqg | 2023-03-02 05:04:29.125 HD Request # 54 | Download start date-time: 2022-06-19 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.126 HD Request # 54 | Error downloading historical Intraday data for F.US.HSIN22. The symbol is unknown to the server. | 2023-03-02 05:04:29.126 HD Request # 54 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIN22 | 2023-03-02 05:04:29.126 HD Request # 54 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-03-02 05:04:29.126 HD Request # 54 | Completion time: 0s. | 2023-03-02 05:04:29.126 HD Request # 54 | Intraday data download complete for F.US.HSIN22. Unique request ID: 34 | 2023-03-02 05:04:29.126 Removing historical data download ID 34. | 2023-03-02 05:04:29.126 Real-time Intraday chart data file updates started for F.US.HSIN22 | 2023-03-02 05:04:29.126 Intraday chart data file opened for F.US.HSIN22 | 2023-03-02 05:04:29.126 HD Request # 54 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.126 Triggering next historical data download in queue. | 2023-03-02 05:04:29.126 HD Request # 55 | Downloading Intraday chart data for F.US.HSIQ22 to the file F.US.HSIQ22.scid. Service: cqg | 2023-03-02 05:04:29.126 HD Request # 55 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.126 HD Request # 55 | Download start date-time: 2022-07-18 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.126 HD Request # 55 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.126 HD Request # 55 | Error downloading historical Intraday data for F.US.HSIQ22. The symbol is unknown to the server. | 2023-03-02 05:04:29.126 HD Request # 55 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIQ22 | 2023-03-02 05:04:29.126 HD Request # 55 | Completion time: 0s. | 2023-03-02 05:04:29.126 HD Request # 55 | Intraday data download complete for F.US.HSIQ22. Unique request ID: 36 | 2023-03-02 05:04:29.126 Added historical Intraday data request for F.US.HSIQ22 to the queue. | 2023-03-02 05:04:29.126 Triggering next historical data download in queue. | 2023-03-02 05:04:29.126 HD Request # 56 | Downloading Intraday chart data for F.US.HSIQ22 to the file F.US.HSIQ22.scid. Service: cqg | 2023-03-02 05:04:29.126 HD Request # 56 | Download start date-time: 2022-07-18 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.126 HD Request # 56 | Error downloading historical Intraday data for F.US.HSIQ22. The symbol is unknown to the server. | 2023-03-02 05:04:29.127 HD Request # 56 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIQ22 | 2023-03-02 05:04:29.127 HD Request # 56 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-03-02 05:04:29.127 HD Request # 56 | Completion time: 0s. | 2023-03-02 05:04:29.127 HD Request # 56 | Intraday data download complete for F.US.HSIQ22. Unique request ID: 36 | 2023-03-02 05:04:29.127 Removing historical data download ID 36. | 2023-03-02 05:04:29.127 Real-time Intraday chart data file updates started for F.US.HSIQ22 | 2023-03-02 05:04:29.127 Intraday chart data file opened for F.US.HSIQ22 | 2023-03-02 05:04:29.127 HD Request # 56 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.127 Triggering next historical data download in queue. | 2023-03-02 05:04:29.127 HD Request # 57 | Downloading Intraday chart data for F.US.HSIU22 to the file F.US.HSIU22.scid. Service: cqg | 2023-03-02 05:04:29.127 HD Request # 57 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.127 HD Request # 57 | Download start date-time: 2022-08-20 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.127 HD Request # 57 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.127 HD Request # 57 | Error downloading historical Intraday data for F.US.HSIU22. The symbol is unknown to the server. | 2023-03-02 05:04:29.127 HD Request # 57 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIU22 | 2023-03-02 05:04:29.127 HD Request # 57 | Completion time: 0s. | 2023-03-02 05:04:29.127 HD Request # 57 | Intraday data download complete for F.US.HSIU22. Unique request ID: 38 | 2023-03-02 05:04:29.127 Added historical Intraday data request for F.US.HSIU22 to the queue. | 2023-03-02 05:04:29.127 Triggering next historical data download in queue. | 2023-03-02 05:04:29.127 HD Request # 58 | Downloading Intraday chart data for F.US.HSIU22 to the file F.US.HSIU22.scid. Service: cqg | 2023-03-02 05:04:29.127 HD Request # 58 | Download start date-time: 2022-08-20 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.127 HD Request # 58 | Error downloading historical Intraday data for F.US.HSIU22. The symbol is unknown to the server. | 2023-03-02 05:04:29.127 HD Request # 58 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIU22 | 2023-03-02 05:04:29.127 HD Request # 58 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-03-02 05:04:29.128 HD Request # 58 | Completion time: 0s. | 2023-03-02 05:04:29.128 HD Request # 58 | Intraday data download complete for F.US.HSIU22. Unique request ID: 38 | 2023-03-02 05:04:29.128 Removing historical data download ID 38. | 2023-03-02 05:04:29.128 Real-time Intraday chart data file updates started for F.US.HSIU22 | 2023-03-02 05:04:29.128 Intraday chart data file opened for F.US.HSIU22 | 2023-03-02 05:04:29.128 HD Request # 58 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.128 Triggering next historical data download in queue. | 2023-03-02 05:04:29.128 HD Request # 59 | Downloading Intraday chart data for F.US.HSIV22 to the file F.US.HSIV22.scid. Service: cqg | 2023-03-02 05:04:29.128 HD Request # 59 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.128 HD Request # 59 | Download start date-time: 2022-09-19 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.128 HD Request # 59 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.128 HD Request # 59 | Error downloading historical Intraday data for F.US.HSIV22. The symbol is unknown to the server. | 2023-03-02 05:04:29.128 HD Request # 59 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIV22 | 2023-03-02 05:04:29.128 HD Request # 59 | Completion time: 0s. | 2023-03-02 05:04:29.128 HD Request # 59 | Intraday data download complete for F.US.HSIV22. Unique request ID: 40 | 2023-03-02 05:04:29.128 Added historical Intraday data request for F.US.HSIV22 to the queue. | 2023-03-02 05:04:29.128 Triggering next historical data download in queue. | 2023-03-02 05:04:29.128 HD Request # 60 | Downloading Intraday chart data for F.US.HSIV22 to the file F.US.HSIV22.scid. Service: cqg | 2023-03-02 05:04:29.128 HD Request # 60 | Download start date-time: 2022-09-19 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.128 HD Request # 60 | Error downloading historical Intraday data for F.US.HSIV22. The symbol is unknown to the server. | 2023-03-02 05:04:29.128 HD Request # 60 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIV22 | 2023-03-02 05:04:29.128 HD Request # 60 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-03-02 05:04:29.129 HD Request # 60 | Completion time: 0s. | 2023-03-02 05:04:29.129 HD Request # 60 | Intraday data download complete for F.US.HSIV22. Unique request ID: 40 | 2023-03-02 05:04:29.129 Removing historical data download ID 40. | 2023-03-02 05:04:29.129 Real-time Intraday chart data file updates started for F.US.HSIV22 | 2023-03-02 05:04:29.129 Intraday chart data file opened for F.US.HSIV22 | 2023-03-02 05:04:29.129 HD Request # 60 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.129 Triggering next historical data download in queue. | 2023-03-02 05:04:29.129 HD Request # 61 | Downloading Intraday chart data for F.US.HSIX22 to the file F.US.HSIX22.scid. Service: cqg | 2023-03-02 05:04:29.129 HD Request # 61 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.129 HD Request # 61 | Download start date-time: 2022-10-18 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.129 HD Request # 61 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.129 HD Request # 61 | Error downloading historical Intraday data for F.US.HSIX22. The symbol is unknown to the server. | 2023-03-02 05:04:29.129 HD Request # 61 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIX22 | 2023-03-02 05:04:29.129 HD Request # 61 | Completion time: 0s. | 2023-03-02 05:04:29.129 HD Request # 61 | Intraday data download complete for F.US.HSIX22. Unique request ID: 42 | 2023-03-02 05:04:29.129 Added historical Intraday data request for F.US.HSIX22 to the queue. | 2023-03-02 05:04:29.129 Triggering next historical data download in queue. | 2023-03-02 05:04:29.129 HD Request # 62 | Downloading Intraday chart data for F.US.HSIX22 to the file F.US.HSIX22.scid. Service: cqg | 2023-03-02 05:04:29.129 HD Request # 62 | Download start date-time: 2022-10-18 20:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.129 HD Request # 62 | Error downloading historical Intraday data for F.US.HSIX22. The symbol is unknown to the server. | 2023-03-02 05:04:29.129 HD Request # 62 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIX22 | 2023-03-02 05:04:29.129 HD Request # 62 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-03-02 05:04:29.129 HD Request # 62 | Completion time: 0s. | 2023-03-02 05:04:29.129 HD Request # 62 | Intraday data download complete for F.US.HSIX22. Unique request ID: 42 | 2023-03-02 05:04:29.129 Removing historical data download ID 42. | 2023-03-02 05:04:29.130 Real-time Intraday chart data file updates started for F.US.HSIX22 | 2023-03-02 05:04:29.130 Intraday chart data file opened for F.US.HSIX22 | 2023-03-02 05:04:29.130 HD Request # 62 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.130 Triggering next historical data download in queue. | 2023-03-02 05:04:29.130 HD Request # 63 | Downloading Intraday chart data for F.US.HSIZ22 to the file F.US.HSIZ22.scid. Service: cqg | 2023-03-02 05:04:29.130 HD Request # 63 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.130 HD Request # 63 | Download start date-time: 2022-11-19 19:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.130 HD Request # 63 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.130 HD Request # 63 | Error downloading historical Intraday data for F.US.HSIZ22. The symbol is unknown to the server. | 2023-03-02 05:04:29.130 HD Request # 63 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIZ22 | 2023-03-02 05:04:29.130 HD Request # 63 | Completion time: 0s. | 2023-03-02 05:04:29.130 HD Request # 63 | Intraday data download complete for F.US.HSIZ22. Unique request ID: 44 | 2023-03-02 05:04:29.130 Added historical Intraday data request for F.US.HSIZ22 to the queue. | 2023-03-02 05:04:29.130 Triggering next historical data download in queue. | 2023-03-02 05:04:29.130 HD Request # 64 | Downloading Intraday chart data for F.US.HSIZ22 to the file F.US.HSIZ22.scid. Service: cqg | 2023-03-02 05:04:29.130 HD Request # 64 | Download start date-time: 2022-11-19 19:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.130 HD Request # 64 | Error downloading historical Intraday data for F.US.HSIZ22. The symbol is unknown to the server. | 2023-03-02 05:04:29.130 HD Request # 64 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIZ22 | 2023-03-02 05:04:29.130 HD Request # 64 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-03-02 05:04:29.130 HD Request # 64 | Completion time: 0s. | 2023-03-02 05:04:29.130 HD Request # 64 | Intraday data download complete for F.US.HSIZ22. Unique request ID: 44 | 2023-03-02 05:04:29.130 Removing historical data download ID 44. | 2023-03-02 05:04:29.130 Real-time Intraday chart data file updates started for F.US.HSIZ22 | 2023-03-02 05:04:29.130 Intraday chart data file opened for F.US.HSIZ22 | 2023-03-02 05:04:29.130 HD Request # 64 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.130 Triggering next historical data download in queue. | 2023-03-02 05:04:29.130 HD Request # 65 | Downloading Intraday chart data for F.US.HSIF23 to the file F.US.HSIF23.scid. Service: cqg | 2023-03-02 05:04:29.131 HD Request # 65 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.131 HD Request # 65 | Download start date-time: 2022-12-19 19:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.131 HD Request # 65 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.131 HD Request # 65 | Requesting historical Minute data. | 2023-03-02 05:04:29.131 HD Request # 65 | Error downloading historical Intraday data for F.US.HSIF23. Historical data unavailable for this instrument. | 2023-03-02 05:04:29.207 HD Request # 65 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIF23 | 2023-03-02 05:04:29.207 HD Request # 65 | Completion time: 0s. | 2023-03-02 05:04:29.207 HD Request # 65 | Intraday data download complete for F.US.HSIF23. Unique request ID: 46 | 2023-03-02 05:04:29.207 Added historical Intraday data request for F.US.HSIF23 to the queue. | 2023-03-02 05:04:29.207 Triggering next historical data download in queue. | 2023-03-02 05:04:29.207 HD Request # 66 | Downloading Intraday chart data for F.US.HSIF23 to the file F.US.HSIF23.scid. Service: cqg | 2023-03-02 05:04:29.207 HD Request # 66 | Download start date-time: 2022-12-19 19:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.207 HD Request # 66 | Requesting historical Tick data. | 2023-03-02 05:04:29.207 HD Request # 66 | Error downloading historical Intraday data for F.US.HSIF23. Historical data unavailable for this instrument. Result=104. Num Quotes=0 | 2023-03-02 05:04:29.293 HD Request # 66 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIF23 | 2023-03-02 05:04:29.293 HD Request # 66 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-03-02 05:04:29.293 HD Request # 66 | Completion time: 0s. | 2023-03-02 05:04:29.293 HD Request # 66 | Intraday data download complete for F.US.HSIF23. Unique request ID: 46 | 2023-03-02 05:04:29.293 Removing historical data download ID 46. | 2023-03-02 05:04:29.293 Real-time Intraday chart data file updates started for F.US.HSIF23 | 2023-03-02 05:04:29.293 Intraday chart data file opened for F.US.HSIF23 | 2023-03-02 05:04:29.293 HD Request # 66 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.293 Triggering next historical data download in queue. | 2023-03-02 05:04:29.293 HD Request # 67 | Downloading Intraday chart data for F.US.HSIG23 to the file F.US.HSIG23.scid. Service: cqg | 2023-03-02 05:04:29.293 HD Request # 67 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.293 HD Request # 67 | Download start date-time: 2023-01-20 19:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.294 HD Request # 67 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.294 HD Request # 67 | Requesting historical Minute data. | 2023-03-02 05:04:29.294 HD Request # 67 | Error downloading historical Intraday data for F.US.HSIG23. Historical data unavailable for this instrument. | 2023-03-02 05:04:29.369 HD Request # 67 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIG23 | 2023-03-02 05:04:29.369 HD Request # 67 | Completion time: 0s. | 2023-03-02 05:04:29.369 HD Request # 67 | Intraday data download complete for F.US.HSIG23. Unique request ID: 48 | 2023-03-02 05:04:29.369 Added historical Intraday data request for F.US.HSIG23 to the queue. | 2023-03-02 05:04:29.369 Triggering next historical data download in queue. | 2023-03-02 05:04:29.369 HD Request # 68 | Downloading Intraday chart data for F.US.HSIG23 to the file F.US.HSIG23.scid. Service: cqg | 2023-03-02 05:04:29.369 HD Request # 68 | Download start date-time: 2023-01-20 19:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.369 HD Request # 68 | Requesting historical Tick data. | 2023-03-02 05:04:29.369 HD Request # 68 | Error downloading historical Intraday data for F.US.HSIG23. Historical data unavailable for this instrument. Result=104. Num Quotes=0 | 2023-03-02 05:04:29.445 HD Request # 68 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.HSIG23 | 2023-03-02 05:04:29.445 HD Request # 68 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-03-02 05:04:29.445 HD Request # 68 | Completion time: 0s. | 2023-03-02 05:04:29.445 HD Request # 68 | Intraday data download complete for F.US.HSIG23. Unique request ID: 48 | 2023-03-02 05:04:29.445 Removing historical data download ID 48. | 2023-03-02 05:04:29.445 Real-time Intraday chart data file updates started for F.US.HSIG23 | 2023-03-02 05:04:29.445 Intraday chart data file opened for F.US.HSIG23 | 2023-03-02 05:04:29.445 HD Request # 68 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.445 Triggering next historical data download in queue. | 2023-03-02 05:04:29.445 HD Request # 69 | Downloading Intraday chart data for F.US.HSIH23 to the file F.US.HSIH23.scid. Service: cqg | 2023-03-02 05:04:29.445 Reloading all charts with filename: F.US.HSIH23.scid | 2023-03-02 05:04:29.450 HD Request # 69 | Performing multistage download. Downloading Minute data first. | 2023-03-02 05:04:29.456 HD Request # 69 | Download start date-time: 2023-02-17 19:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.456 HD Request # 69 | Disabling Intraday chart updating for symbol. | 2023-03-02 05:04:29.456 HD Request # 69 | Requesting historical Minute data. | 2023-03-02 05:04:29.456 F.US.HSIH23 [CB] 30 Sec #9 | Reloading chart. | 2023-03-02 05:04:29.608 F.US.HSIH23 [CB] 30 Sec #9 | Waiting for historical downloads to complete with the IDs: 49, 50, 51, | 2023-03-02 05:04:29.619 F.US.HSIH23 [CBV] 480 Min #2 | Reloading chart. | 2023-03-02 05:04:29.621 F.US.HSIH23 [CBV] 480 Min #2 | Waiting for historical downloads to complete with the IDs: 33, 35, 37, 39, 41, 43, 45, 47, 49, 50, 51, | 2023-03-02 05:04:29.696 HD Request # 69 | Receiving Intraday data for F.US.HSIH23 starting at 2023-02-19 20:15:00.000000 | 2023-03-02 05:04:29.699 HD Request # 69 | Timestamp of first Intraday data file record written: 2023-02-19 20:15:00.000000. | 2023-03-02 05:04:29.701 HD Request # 69 | Received 8105 Intraday data records from 2023-02-19 20:15:00.000000 to 2023-03-02 05:04:00.000000 (10.4 days) and wrote 8105 records for F.US.HSIH23 | 2023-03-02 05:04:29.701 HD Request # 69 | Completion time: 0s. | 2023-03-02 05:04:29.701 HD Request # 69 | Intraday data download complete for F.US.HSIH23. Unique request ID: 50 | 2023-03-02 05:04:29.701 Added historical Intraday data request for F.US.HSIH23 to the queue. | 2023-03-02 05:04:29.701 Triggering next historical data download in queue. | 2023-03-02 05:04:29.701 HD Request # 70 | Downloading Intraday chart data for F.US.HSIH23 to the file F.US.HSIH23.scid. Service: cqg | 2023-03-02 05:04:29.701 Reloading all charts with filename: F.US.HSIH23.scid | 2023-03-02 05:04:29.711 HD Request # 70 | Download start date-time: 2023-02-17 19:00:00.000000. File last date-time: 00:00:00.000000 | 2023-03-02 05:04:29.713 HD Request # 70 | Requesting historical Tick data. | 2023-03-02 05:04:29.713 HD Request # 51 | Requesting historical Daily data for HSM22 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:29.781 F.US.HSIH23 [CBV] 1 Day #1 | Reloading chart. | 2023-03-02 05:04:29.858 F.US.HSIH23 [CBV] 1 Day #1 | Waiting for historical downloads to complete with the IDs: 45, 47, 49, 50, 51, | 2023-03-02 05:04:29.886 HD Request # 51 | Receiving historical Daily data for F.US.HSIM22 starting at 2021-10-29. | 2023-03-02 05:04:29.888 HD Request # 51 | Writing historical Daily data to the file F.US.HSIM22.dly. | 2023-03-02 05:04:29.888 HD Request # 51 | Bytes received: 8532 | 2023-03-02 05:04:29.890 HD Request # 51 | Received 169 Daily data records from 2021-10-29 00:00:00 to 2022-06-29 00:00:00 (244.0 days) and wrote 169 records for F.US.HSIM22 | 2023-03-02 05:04:29.890 HD Request # 51 | Completion time: 0s. | 2023-03-02 05:04:29.890 HD Request # 51 | Daily data download complete for F.US.HSIM22. Unique request ID: 33 | 2023-03-02 05:04:29.890 Removing historical data download ID 33. | 2023-03-02 05:04:29.890 Triggering next historical data download in queue. | 2023-03-02 05:04:29.890 HD Request # 71 | Downloading Historical Daily chart data for F.US.HSIN22. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:29.890 F.US.HSIH23 [CBV] 120 Min #3 | Reloading chart. | 2023-03-02 05:04:29.891 F.US.HSIH23 [CBV] 120 Min #3 | Waiting for historical downloads to complete with the IDs: 43, 45, 47, 49, 50, 51, | 2023-03-02 05:04:29.926 F.US.HSIH23 [CBV] 30 Min #4 | Reloading chart. | 2023-03-02 05:04:29.928 F.US.HSIH23 [CBV] 30 Min #4 | Waiting for historical downloads to complete with the IDs: 45, 47, 49, 50, 51, | 2023-03-02 05:04:29.954 F.US.HSIH23 [CB] 3 Min #5 | Reloading chart. | 2023-03-02 05:04:29.960 F.US.HSIH23 [CB] 3 Min #5 | Waiting for historical downloads to complete with the IDs: 49, 50, 51, | 2023-03-02 05:04:29.970 F.US.HSIH23 [CBV] #6 | Reloading chart. | 2023-03-02 05:04:29.976 F.US.HSIH23 [CBV] #6 | Waiting for historical downloads to complete with the IDs: 45, 47, 49, 50, 51, | 2023-03-02 05:04:30.007 F.US.HSIH23 [CBV] #7 | Reloading chart. | 2023-03-02 05:04:30.010 F.US.HSIH23 [CBV] #7 | Waiting for historical downloads to complete with the IDs: 47, 49, 50, 51, | 2023-03-02 05:04:30.030 F.US.HSIH23 [CB] 30 Sec #8 | Reloading chart. | 2023-03-02 05:04:30.033 F.US.HSIH23 [CB] 30 Sec #8 | Waiting for historical downloads to complete with the IDs: 49, 50, 51, | 2023-03-02 05:04:30.043 F.US.HSIH23 [CB] 30 Sec #10 | Reloading chart. | 2023-03-02 05:04:30.045 F.US.HSIH23 [CB] 30 Sec #10 | Waiting for historical downloads to complete with the IDs: 49, 50, 51, | 2023-03-02 05:04:30.056 F.US.HSIH23 [CB] 30 Sec #9 | Reloading chart. | 2023-03-02 05:04:30.071 F.US.HSIH23 [CB] 30 Sec #9 | Waiting for historical downloads to complete with the IDs: 49, 50, 51, | 2023-03-02 05:04:30.082 F.US.HSIH23 [CBV] 480 Min #2 | Reloading chart. | 2023-03-02 05:04:30.084 F.US.HSIH23 [CBV] 480 Min #2 | Waiting for historical downloads to complete with the IDs: 35, 37, 39, 41, 43, 45, 47, 49, 50, 51, | 2023-03-02 05:04:30.159 HD Request # 71 | Requesting historical Daily data for HSN22 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:30.493 HD Request # 71 | Receiving historical Daily data for F.US.HSIN22 starting at 2022-05-31. | 2023-03-02 05:04:30.607 HD Request # 71 | Writing historical Daily data to the file F.US.HSIN22.dly. | 2023-03-02 05:04:30.608 HD Request # 71 | Bytes received: 2212 | 2023-03-02 05:04:30.608 HD Request # 71 | Received 42 Daily data records from 2022-05-31 00:00:00 to 2022-07-28 00:00:00 (59.0 days) and wrote 42 records for F.US.HSIN22 | 2023-03-02 05:04:30.608 HD Request # 71 | Completion time: 1s. | 2023-03-02 05:04:30.609 HD Request # 71 | Daily data download complete for F.US.HSIN22. Unique request ID: 35 | 2023-03-02 05:04:30.609 Removing historical data download ID 35. | 2023-03-02 05:04:30.609 Triggering next historical data download in queue. | 2023-03-02 05:04:30.609 HD Request # 72 | Downloading Historical Daily chart data for F.US.HSIQ22. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:30.609 HD Request # 72 | Requesting historical Daily data for HSQ22 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:31.196 HD Request # 72 | Receiving historical Daily data for F.US.HSIQ22 starting at 2022-06-13. | 2023-03-02 05:04:31.308 HD Request # 72 | Writing historical Daily data to the file F.US.HSIQ22.dly. | 2023-03-02 05:04:31.309 HD Request # 72 | Bytes received: 2920 | 2023-03-02 05:04:31.309 HD Request # 72 | Received 57 Daily data records from 2022-06-13 00:00:00 to 2022-08-30 00:00:00 (79.0 days) and wrote 57 records for F.US.HSIQ22 | 2023-03-02 05:04:31.309 HD Request # 72 | Completion time: 1s. | 2023-03-02 05:04:31.309 HD Request # 72 | Daily data download complete for F.US.HSIQ22. Unique request ID: 37 | 2023-03-02 05:04:31.309 Removing historical data download ID 37. | 2023-03-02 05:04:31.309 Triggering next historical data download in queue. | 2023-03-02 05:04:31.309 HD Request # 73 | Downloading Historical Daily chart data for F.US.HSIU22. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:31.309 HD Request # 73 | Requesting historical Daily data for HSU22 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:31.888 HD Request # 73 | Receiving historical Daily data for F.US.HSIU22 starting at 2022-01-31. | 2023-03-02 05:04:31.976 HD Request # 73 | Writing historical Daily data to the file F.US.HSIU22.dly. | 2023-03-02 05:04:31.977 HD Request # 73 | Bytes received: 8647 | 2023-03-02 05:04:31.979 HD Request # 73 | Received 170 Daily data records from 2022-01-31 00:00:00 to 2022-09-29 00:00:00 (242.0 days) and wrote 170 records for F.US.HSIU22 | 2023-03-02 05:04:31.979 HD Request # 73 | Completion time: 0s. | 2023-03-02 05:04:31.979 HD Request # 73 | Daily data download complete for F.US.HSIU22. Unique request ID: 39 | 2023-03-02 05:04:31.979 Removing historical data download ID 39. | 2023-03-02 05:04:31.979 Triggering next historical data download in queue. | 2023-03-02 05:04:31.979 HD Request # 74 | Downloading Historical Daily chart data for F.US.HSIV22. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:31.979 HD Request # 74 | Requesting historical Daily data for HSV22 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:32.561 HD Request # 74 | Receiving historical Daily data for F.US.HSIV22 starting at 2022-06-30. | 2023-03-02 05:04:32.640 HD Request # 74 | Writing historical Daily data to the file F.US.HSIV22.dly. | 2023-03-02 05:04:32.641 HD Request # 74 | Bytes received: 4222 | 2023-03-02 05:04:32.641 HD Request # 74 | Received 86 Daily data records from 2022-06-30 00:00:00 to 2022-10-28 00:00:00 (121.0 days) and wrote 86 records for F.US.HSIV22 | 2023-03-02 05:04:32.642 HD Request # 74 | Completion time: 1s. | 2023-03-02 05:04:32.642 HD Request # 74 | Daily data download complete for F.US.HSIV22. Unique request ID: 41 | 2023-03-02 05:04:32.642 Removing historical data download ID 41. | 2023-03-02 05:04:32.642 Triggering next historical data download in queue. | 2023-03-02 05:04:32.642 HD Request # 75 | Downloading Historical Daily chart data for F.US.HSIX22. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:32.642 HD Request # 75 | Requesting historical Daily data for HSX22 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:33.220 HD Request # 75 | Receiving historical Daily data for F.US.HSIX22 starting at 2022-07-29. | 2023-03-02 05:04:33.317 HD Request # 75 | Writing historical Daily data to the file F.US.HSIX22.dly. | 2023-03-02 05:04:33.317 HD Request # 75 | Bytes received: 4323 | 2023-03-02 05:04:33.318 HD Request # 75 | Received 88 Daily data records from 2022-07-29 00:00:00 to 2022-11-29 00:00:00 (124.0 days) and wrote 88 records for F.US.HSIX22 | 2023-03-02 05:04:33.318 HD Request # 75 | Completion time: 1s. | 2023-03-02 05:04:33.318 HD Request # 75 | Daily data download complete for F.US.HSIX22. Unique request ID: 43 | 2023-03-02 05:04:33.318 Removing historical data download ID 43. | 2023-03-02 05:04:33.318 Triggering next historical data download in queue. | 2023-03-02 05:04:33.318 HD Request # 76 | Downloading Historical Daily chart data for F.US.HSIZ22. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:33.318 HD Request # 76 | Requesting historical Daily data for HSZ22 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:33.898 HD Request # 76 | Receiving historical Daily data for F.US.HSIZ22 starting at 2018-03-05. | 2023-03-02 05:04:33.978 HD Request # 76 | Writing historical Daily data to the file F.US.HSIZ22.dly. | 2023-03-02 05:04:33.978 HD Request # 76 | Bytes received: 56017 | 2023-03-02 05:04:33.985 HD Request # 76 | Received 1199 Daily data records from 2018-03-05 00:00:00 to 2022-12-29 00:00:00 (4.8years) and wrote 1199 records for F.US.HSIZ22 | 2023-03-02 05:04:33.985 HD Request # 76 | Completion time: 0s. | 2023-03-02 05:04:33.986 HD Request # 76 | Daily data download complete for F.US.HSIZ22. Unique request ID: 45 | 2023-03-02 05:04:33.986 Removing historical data download ID 45. | 2023-03-02 05:04:33.986 Triggering next historical data download in queue. | 2023-03-02 05:04:33.986 HD Request # 77 | Downloading Historical Daily chart data for F.US.HSIF23. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:33.986 HD Request # 77 | Requesting historical Daily data for HSF23 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:34.568 HD Request # 77 | Receiving historical Daily data for F.US.HSIF23 starting at 2022-09-30. | 2023-03-02 05:04:34.646 HD Request # 77 | Writing historical Daily data to the file F.US.HSIF23.dly. | 2023-03-02 05:04:34.647 HD Request # 77 | Bytes received: 4232 | 2023-03-02 05:04:34.648 HD Request # 77 | Received 86 Daily data records from 2022-09-30 00:00:00 to 2023-01-30 00:00:00 (123.0 days) and wrote 86 records for F.US.HSIF23 | 2023-03-02 05:04:34.648 HD Request # 77 | Completion time: 1s. | 2023-03-02 05:04:34.648 HD Request # 77 | Daily data download complete for F.US.HSIF23. Unique request ID: 47 | 2023-03-02 05:04:34.648 Removing historical data download ID 47. | 2023-03-02 05:04:34.648 Triggering next historical data download in queue. | 2023-03-02 05:04:34.648 HD Request # 78 | Downloading Historical Daily chart data for F.US.HSIG23. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:34.648 HD Request # 78 | Requesting historical Daily data for HSG23 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:35.223 HD Request # 78 | Receiving historical Daily data for F.US.HSIG23 starting at 2022-10-31. | 2023-03-02 05:04:35.297 HD Request # 78 | Writing historical Daily data to the file F.US.HSIG23.dly. | 2023-03-02 05:04:35.298 HD Request # 78 | Bytes received: 4209 | 2023-03-02 05:04:35.298 HD Request # 78 | Received 85 Daily data records from 2022-10-31 00:00:00 to 2023-02-27 00:00:00 (120.0 days) and wrote 85 records for F.US.HSIG23 | 2023-03-02 05:04:35.298 HD Request # 78 | Completion time: 1s. | 2023-03-02 05:04:35.298 HD Request # 78 | Daily data download complete for F.US.HSIG23. Unique request ID: 49 | 2023-03-02 05:04:35.298 Removing historical data download ID 49. | 2023-03-02 05:04:35.298 Triggering next historical data download in queue. | 2023-03-02 05:04:35.298 HD Request # 79 | Downloading Historical Daily chart data for F.US.HSIH23. Starting date: 1973-03-01. Service: cqg | 2023-03-02 05:04:35.298 HD Request # 79 | Requesting historical Daily data for HSH23 starting at 1973-02-28. SC External HD service. | 2023-03-02 05:04:35.891 HD Request # 79 | Receiving historical Daily data for F.US.HSIH23 starting at 2022-06-13. | 2023-03-02 05:04:35.963 HD Request # 79 | Writing historical Daily data to the file F.US.HSIH23.dly. | 2023-03-02 05:04:35.963 HD Request # 79 | Bytes received: 9123 | 2023-03-02 05:04:35.964 HD Request # 79 | Received 187 Daily data records from 2022-06-13 00:00:00 to 2023-03-01 00:00:00 (262.0 days) and wrote 187 records for F.US.HSIH23 | 2023-03-02 05:04:35.964 HD Request # 79 | Completion time: 0s. | 2023-03-02 05:04:35.964 HD Request # 79 | Daily data download complete for F.US.HSIH23. Unique request ID: 51 | 2023-03-02 05:04:35.964 Removing historical data download ID 51. | 2023-03-02 05:04:35.964 Triggering next historical data download in queue. | 2023-03-02 05:04:35.965 No download requests in the queue to start downloads for. | 2023-03-02 05:04:35.965 HD Request # 70 | Receiving Intraday data for F.US.HSIH23 starting at 2023-02-26 20:14:00.136000 | 2023-03-02 05:04:39.182 HD Request # 70 | Timestamp of first Intraday data file record written: 2023-02-26 20:14:00.136000. | 2023-03-02 05:04:39.185 HD Request # 70 | Received 454068 Intraday data records from 2023-02-26 20:14:00.136000 to 2023-03-02 05:04:27.924000 (3.4 days) and wrote 454068 records for F.US.HSIH23 | 2023-03-02 05:04:39.219 HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2023-03-02 10:04:27.924000 | 2023-03-02 05:04:39.227 Added 6 Time and Sales records to Intraday data file for F.US.HSIH23 after download. | 2023-03-02 05:04:39.227 HD Request # 70 | Completion time: 10s. | 2023-03-02 05:04:39.228 HD Request # 70 | Intraday data download complete for F.US.HSIH23. Unique request ID: 50 | 2023-03-02 05:04:39.228 Removing historical data download ID 50. | 2023-03-02 05:04:39.228 Real-time Intraday chart data file updates started for F.US.HSIH23 | 2023-03-02 05:04:39.228 Intraday chart data file opened for F.US.HSIH23 | 2023-03-02 05:04:39.228 HD Request # 70 | Enabling Intraday chart updating for symbol. | 2023-03-02 05:04:39.228 Triggering next historical data download in queue. | 2023-03-02 05:04:39.228 No download requests in the queue to start downloads for. | 2023-03-02 05:04:39.228 F.US.HSIH23 [CBV] 480 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:39.239 F.US.HSIH23 [CBV] 480 Min #2 | Reloading chart. | 2023-03-02 05:04:39.240 F.US.HSIH23 [CBV] 1 Day #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:39.358 F.US.HSIH23 [CBV] 1 Day #1 | Reloading chart. | 2023-03-02 05:04:39.360 F.US.HSIH23 [CBV] 120 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:39.438 F.US.HSIH23 [CBV] 120 Min #3 | Reloading chart. | 2023-03-02 05:04:39.440 F.US.HSIH23 [CBV] 30 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:39.549 F.US.HSIH23 [CBV] 30 Min #4 | Reloading chart. | 2023-03-02 05:04:39.552 F.US.HSIH23 [CB] 3 Min #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:39.653 F.US.HSIH23 [CB] 3 Min #5 | Reloading chart. | 2023-03-02 05:04:39.654 F.US.HSIH23 [CBV] #6 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:39.745 F.US.HSIH23 [CBV] #6 | Reloading chart. | 2023-03-02 05:04:39.746 F.US.HSIH23 [CBV] #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:39.847 F.US.HSIH23 [CBV] #7 | Reloading chart. | 2023-03-02 05:04:39.849 F.US.HSIH23 [CB] 3 Min #5 | StartDateTimeForLoadingOrderFills: 2023-02-16 05:04:38 | 2023-03-02 05:04:39.951 F.US.HSIH23 [CB] 30 Sec #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:40.010 F.US.HSIH23 [CB] 30 Sec #8 | Reloading chart. | 2023-03-02 05:04:40.011 F.US.HSIH23 [CB] 30 Sec #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:40.019 F.US.HSIH23 [CB] 30 Sec #10 | Reloading chart. | 2023-03-02 05:04:40.020 F.US.HSIH23 [CB] 30 Sec #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2023-03-02 05:04:40.054 F.US.HSIH23 [CB] 30 Sec #9 | Reloading chart. | 2023-03-02 05:04:40.054 F.US.HSIH23 [CBV] 480 Min #2 | Reloading chart. | 2023-03-02 05:04:40.355 F.US.HSIH23 [CB] 30 Sec #8 | StartDateTimeForLoadingOrderFills: 2023-02-16 05:04:38 | 2023-03-02 05:04:40.574 F.US.HSIH23 [CB] 30 Sec #10 | StartDateTimeForLoadingOrderFills: 2023-02-16 03:29:59 | 2023-03-02 05:04:40.621 F.US.HSIH23 [CB] 30 Sec #9 | StartDateTimeForLoadingOrderFills: 2023-02-16 05:04:38 | 2023-03-02 05:04:40.815 F.US.HSIH23 [CBV] 1 Day #1 | Reloading chart. | 2023-03-02 05:04:41.390 F.US.HSIH23 [CBV] 120 Min #3 | Reloading chart. | 2023-03-02 05:04:41.478 F.US.HSIH23 [CBV] 30 Min #4 | Reloading chart. | 2023-03-02 05:04:41.614 F.US.HSIH23 [CB] 3 Min #5 | Reloading chart. | 2023-03-02 05:04:41.734 F.US.HSIH23 [CBV] #6 | Reloading chart. | 2023-03-02 05:04:41.763 F.US.HSIH23 [CBV] #7 | Reloading chart. | 2023-03-02 05:04:41.953 F.US.HSIH23 [CB] 3 Min #5 | StartDateTimeForLoadingOrderFills: 2023-02-16 05:04:38 | 2023-03-02 05:04:42.023 F.US.HSIH23 [CB] 30 Sec #8 | Reloading chart. | 2023-03-02 05:04:42.077 F.US.HSIH23 [CB] 30 Sec #10 | Reloading chart. | 2023-03-02 05:04:42.099 F.US.HSIH23 [CB] 30 Sec #9 | Reloading chart. | 2023-03-02 05:04:42.387 F.US.HSIH23 [CB] 30 Sec #8 | StartDateTimeForLoadingOrderFills: 2023-02-16 05:04:38 | 2023-03-02 05:04:42.635 F.US.HSIH23 [CB] 30 Sec #10 | StartDateTimeForLoadingOrderFills: 2023-02-16 03:29:59 | 2023-03-02 05:04:42.739 F.US.HSIH23 [CB] 30 Sec #9 | StartDateTimeForLoadingOrderFills: 2023-02-16 05:04:38 | 2023-03-02 05:04:43.055 Opened cached Intraday file: C:\SierraChart\Data\F.US.HSIH23.scid. Thread ID: 6636 | 2023-03-02 05:04:48.219 |
[2023-03-02 23:22:08] |
Just a follow up question: When I switch my data connection to SC Data, Im also not getting anymore than 2 days of data - whereas before I was getting all the historical intraday data - is this right? Sorry I know you guys hate CQG, I appreciate you guys trying to help with this!
[2023-03-03 11:23:23] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You cannot use the continuous futures feature with HKFE with CQG since they do not provide data for historical futures contracts. And we have also removed support for Sierra Chart historical data when using CQG for this exchange. You must set this setting to None: Chart >> Chart Settings >> Symbol >> Continuous Contract Set this to 1 Minute: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) Try the download again to get as much data as you can. That is as best as we can offer . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-03 12:00:48] |
We discovered another issue related to this and we will solve that in the next release.
[2023-03-03 12:01:36] |
Okay, thanks for the support. Im guessing Ill have to go the route of purchasing the data from you guys and not CQG. Will the data I purchase from SC be complete?
[2023-03-03 12:06:45] |
Oh, will this issue possibly resolve my issue with CQG? |
[2023-03-03 12:25:43] |
Yes it definitely will we think, but when we said to use 1 Minute Historical Intraday Data Time Unit, you should be getting the full amount of historical data available.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-03 12:26:00
[2023-03-03 12:43:08] |
Yeah, getting the data now, obviously without the tick data but better than nothing. Really appreciate the help! Do you have an eta on the release? haha
[2023-03-03 14:27:15] |
Update to prerelease version 2485 following these instructions: Software Download: Fast Update After that: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-04 01:38:31] |
Thanks! So I updated and am getting more tick data now! It still about 18 days, if thats right. When I set the data storage to 1min, I get all the days I need minus the tick data obviously, so is it possible to merge the longer non-tick data with the more recent tick data? Because some of my charts are set to 250 days. Thanks! |
[2023-03-04 09:22:13] |
The CQG Web API from what we understand only delivers 30 days of tick Data. And Sierra Chart does limit it due to the awful delivery method and how it is processed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-04 09:22:28
