Date/Time: Thu, 03 Apr 2025 20:32:38 +0000
Volume In Volume Profile Not Correct
View Count: 465
[2022-12-29 19:02:19]
Stav - Posts: 104
Hi SC,
Not sure why the total volume traded per price is not always correct on my footprint(Please see attached image)
I have the following setting:-
Column 2 Numbers Bar Text : Volume
Column 2 Background Type: Volume Profile
Column 2 Background Coloring Method Type: Based On Dominant AskVolBidVol - Actual
Column 2 Text Coloring Method: None
E.g., 65 bid Vol + 62 ask vol = 127 not 128, 68 bid vol + 98 ask vol = 166 not 170, 99 bid vol + 77 ask vol = 176 not 172.
Not sure why this is.
Kind Regards
Stephen
imageESH23-CME[M] Renko 5t #9 2022-12-29 13_41_46.113.png / V - Attached On 2022-12-29 18:43:51 UTC - Size: 88.62 KB - 96 views
[2022-12-29 20:17:16]
John - SC Support - Posts: 39148
Check to make sure you do not have any volume filtering setup for the chart. Refer to the following:
Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu)
If there is no filtering, then we would like for you to delete all the data and redownload it by selecting Edit >> Delete All Data and Download.
Let us know if redownloading the data does not fix this.
[2022-12-29 20:44:21]
Stav - Posts: 104
Hi John,
Exclude >= set to 0
Exclude <= set to 0
Filter Trade Completely set to No
I have deleted all data and download but still problem persists.
Kind Regards
Stephen
[2022-12-29 20:45:41]
Stav - Posts: 104
Hi John,
Latest screen shot of footprint.
Stephen
imageESH23-CME[M] Renko 5t #9 2022-12-29 15_43_07.599.png / V - Attached On 2022-12-29 20:45:29 UTC - Size: 86.13 KB - 93 views
[2022-12-29 21:12:00]
Please get us a copy of your chart by following these instructions:
[2022-12-30 12:17:53]
Stav - Posts: 104
Hi John,
Please see attached chartbook - Chartbook5 with just one study, the footprint highlighting the total
volume sums error.
Thank you most kindly for your help.
Kind Regards
Stephen
attachmentChartbook5.Cht - Attached On 2022-12-30 12:17:39 UTC - Size: 4.84 KB - 141 views
[2022-12-30 16:12:21]
We are not able to see any issue when we open your Chartbook.
Check your setting for Global Settings >> Data/Trade Service Settings >> Common Settings >> Intraday Data Storage Time Unit. This needs to be set to 1 Tick in order to ensure that the data in the Numbers Bars is correct.
If this is not already 1 tick, then change it to be 1 Tick and then you will need to redownload the data for the symbols in your charts by selecting Edit >> Delete All Data and Download. You just need to do the redownload once for each symbol, not for each chart.
[2022-12-30 19:31:05]
Stav - Posts: 104
Hi John,
Thank you very much.
Did as instructed and all bid/ask volumes total correct.
Much appreciated.
Kind Regards
Stephen
[2022-12-30 19:32:51]
Very good.
