Date/Time: Sun, 20 Sep 2026 02:56:36 +0000
Rithmic live data issue
View Count: 2407
[2022-10-10 07:20:16]
Pedro7 - Posts: 39
Today i have an issue with Rithmic live data. In the Rithmic app everything works fine but in Sierrachart i get historical data but not the live quotes. Has been working for months fine.
Can you please help ?
Peter
[2022-10-10 08:27:13]
Sierra_Chart Engineering - Posts: 24894
We do not provide support for Rithmic data:
Rithmic Trading Platform Service: Rithmic Support Policy
You can easily resolve the problem by using the Denali Exchange Data Feed. You just need to complete the agreements here and activate the exchanges that you need:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME
Date Time Of Last Edit: 2022-10-10 08:27:21
[2022-10-10 11:13:05]
madness99 - Posts: 35
I am having the same problem with connecting to Rithmic. My other friends that trades are having the same issue. We havent changed anything. If it was one user i can see this is an user error but it seems like multiple users are having t he same issue. You guys can't just punt and say you don't support Rithmic data connection issue.
Regards,
Jerome
[2022-10-10 11:23:56]
tunesirodolfo - Posts: 5
I do have the same problem with all of my rithmic account on sierra chart, i do use juigsaw with rithmic too and my account it's working on it. so the problem it's coming from sierra chart.
[2022-10-10 11:34:46]
User199865 - Posts: 23
Yep - in the same boat- just happened this morning when I renewed my package. IS it because we now have to have package 11 and it doesn't support package 5 anymore?
Anyone have an update on this? If this is the case can I get a refund on the $36 I just spent on the normal package 5 as missed this info? or payt the difference to get package 11
Date Time Of Last Edit: 2022-10-10 11:42:58
[2022-10-10 11:43:26]
It sounds like Rithmic is having a problem.
We will determine what the problem is.
Follow the instructions below:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
You do need to have Service Package 10 or higher to use Rithmic. However, everyone in this thread does.
You only need to change your Service Package but we see you are on Service Package 11 now.
Date Time Of Last Edit: 2022-10-10 11:44:52
[2022-10-10 11:48:26]
where is support for your customer base sierra?
Most likely this is going to be a Rithmic issue.
And we have asked for information at post #6. So at this point we are waiting for a log from someone. We do not know what the problem is at this point in time.
Date Time Of Last Edit: 2022-10-10 11:48:46
[2022-10-10 11:51:44]
Have sent the log to you as requested, sierra
[2022-10-10 11:52:18]
User475292 - Posts: 5
here is a log i have sierra
Software version: 2390 64-bit | 2022-10-10 06:50:19.770
Primary Thread ID: 32688 | 2022-10-10 06:50:19.770
Usage end date: 2022-10-10 | 2022-10-10 06:50:19.770
Enabled for: Advanced Features 2. | 2022-10-10 06:50:19.770
Enabled for: Sierra Chart Historical Data Service. | 2022-10-10 06:50:19.770
Enabled for: Delayed Denali Exchange Data Feed. | 2022-10-10 06:50:19.770
Enabled for exchange2: fairx_exchange.data | 2022-10-10 06:50:19.770
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-10-10 06:50:19.770
Current selected Data/Trading service: Rithmic Direct - DTC | 2022-10-10 06:50:19.770
Custom symbol settings values: enabled | 2022-10-10 06:50:19.770
Chart Update Interval: 500 | 2022-10-10 06:50:19.770
Intraday Data Storage Time Unit: 0 | 2022-10-10 06:50:19.770
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-10-10 06:50:19.770
2022-10-10 11:50:19 Local computer time in UTC | 2022-10-10 06:50:19.770
2022-10-10 06:50:19 Local computer time in SC Time Zone | 2022-10-10 06:50:19.770
2022-10-10 11:18:50 Server time in UTC | 2022-10-10 06:50:19.770
Local computer UTC time and Server UTC time difference: 3 seconds. | 2022-10-10 06:50:19.770
Program path: C:\SierraChart\ | 2022-10-10 06:50:19.770
Data Files path: C:\SierraChart\Data\ | 2022-10-10 06:50:19.770
OS Version Number: 10.0 | 2022-10-10 06:50:19.770
Locale Setting: C | 2022-10-10 06:50:19.770
DLLs: sst_FreeBundle_2273_64.dll, sst_FreeBundle_64.dll, UserContributedStudies_64.dll | 2022-10-10 06:50:19.770
Allowed protected custom studies: SST_FreeBundle | 2022-10-10 06:50:19.770
Crash reporter started: true | 2022-10-10 06:50:19.770
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:20.421
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:20.421
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:20.422
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:20.422
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:20.422
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:20.500
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:20.500
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:20.501
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:20.501
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:20.747
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:20.747
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:20.747
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:20.747
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:20.747
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:20.747
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:20.747
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:20.748
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:20.748
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:20.824
DTC Client socket (2) | Closed. | 2022-10-10 06:50:20.824
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:22.745
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:22.745
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:22.746
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:22.746
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:22.746
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:22.822
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:22.822
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:22.822
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:22.822
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:23.067
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:23.067
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:23.067
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:23.067
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:23.067
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:23.067
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:23.067
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:23.067
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:23.068
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:23.143
DTC Client socket (2) | Closed. | 2022-10-10 06:50:23.143
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:25.102
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:25.102
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:25.103
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:25.103
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:25.103
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:25.186
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:25.186
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:25.186
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:25.186
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:25.436
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:25.436
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:25.436
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:25.436
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:25.436
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:25.437
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:25.437
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:25.437
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:25.437
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:25.516
DTC Client socket (2) | Closed. | 2022-10-10 06:50:25.517
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:27.439
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:27.439
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:27.440
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:27.440
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:27.440
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:27.516
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:27.516
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:27.516
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:27.516
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:27.766
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:27.766
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:27.766
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:27.766
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:27.766
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:27.766
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:27.766
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:27.766
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:27.767
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:27.841
DTC Client socket (2) | Closed. | 2022-10-10 06:50:27.841
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:29.758
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:29.758
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:29.759
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:29.759
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:29.759
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:29.839
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:29.839
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:29.840
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:29.840
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:30.095
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:30.095
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:30.095
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:30.095
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:30.095
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:30.096
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:30.096
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:30.096
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:30.096
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:30.174
DTC Client socket (2) | Closed. | 2022-10-10 06:50:30.174
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:32.122
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:32.122
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:32.123
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:32.123
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:32.123
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:32.212
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:32.212
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:32.212
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:32.212
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:32.471
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:32.471
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:32.471
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:32.471
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:32.471
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:32.472
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:32.472
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:32.472
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:32.472
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:32.558
DTC Client socket (2) | Closed. | 2022-10-10 06:50:32.558
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:34.486
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:34.486
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:34.487
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:34.487
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:34.487
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:34.582
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:34.582
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:34.582
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:34.582
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:34.846
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:34.846
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:34.846
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:34.846
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:34.846
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:34.847
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:34.847
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:34.847
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:34.847
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:34.928
DTC Client socket (2) | Closed. | 2022-10-10 06:50:34.928
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:36.858
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:36.858
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:36.859
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:36.859
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:36.859
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:36.941
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:36.941
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:36.941
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:36.941
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:37.185
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:37.185
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:37.185
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:37.185
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:37.185
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:37.186
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:37.186
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:37.186
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:37.186
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:37.256
DTC Client socket (2) | Closed. | 2022-10-10 06:50:37.256
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:39.180
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:39.180
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:39.181
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:39.181
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:39.181
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:39.257
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:39.257
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:39.257
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:39.257
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:39.495
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:39.495
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:39.495
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:39.495
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:39.495
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:39.496
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:39.496
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:39.496
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:39.496
File >> Disconnect selected. | 2022-10-10 06:50:39.530
DTC Client socket (0) | CloseSocket call. | 2022-10-10 06:50:39.530
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:39.530
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:39.542
DTC Client socket (1) | CloseSocket call. | 2022-10-10 06:50:39.542
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:39.543
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-10-10 06:50:39.543
DTC Client socket (3) | CloseSocket call. | 2022-10-10 06:50:39.543
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:39.544
SC DTC Data with Market Depth | Disconnected from the server. | 2022-10-10 06:50:39.544
Rithmic Direct - DTC | Disconnected. | 2022-10-10 06:50:39.544
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:39.575
DTC Client socket (2) | Closed. | 2022-10-10 06:50:39.575
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-10 06:50:39.626
DTC Client socket (1) | Closed. | 2022-10-10 06:50:39.626
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:51.268
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-10 06:50:51.271
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:51.271
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-10 06:50:51.271
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:51.272
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:51.355
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:51.355
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:51.355
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:51.355
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:51.608
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:51.608
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:51.608
Rithmic Direct - DTC | Successfully connected. | 2022-10-10 06:50:51.608
Rithmic Direct - DTC | Trading is supported. | 2022-10-10 06:50:51.608
Rithmic Direct - DTC | Order cancel and replace is supported. | 2022-10-10 06:50:51.608
Rithmic Direct - DTC | OCO Orders supported. | 2022-10-10 06:50:51.608
Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2022-10-10 06:50:51.608
Rithmic Direct - DTC | Connected to server complete. | 2022-10-10 06:50:51.608
Triggering next historical data download in queue. | 2022-10-10 06:50:51.610
No download requests in the queue to start downloads for. | 2022-10-10 06:50:51.627
Using symbol data fast lookup vector | 2022-10-10 06:50:51.627
Rithmic Direct - DTC | Starting real-time market data updates for: NQZ2.CME. ID: 1 Service code: rithmic.trading | 2022-10-10 06:50:51.628
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:51.628
Rithmic Direct - DTC | Requesting security definition data for: NQZ2.CME. ID: 1 | 2022-10-10 06:50:51.628
Added historical Intraday data request for NQZ2.CME to the queue. | 2022-10-10 06:50:51.628
Intraday data recording state for symbol NQZ2.CME is set to download 'Pending'. | 2022-10-10 06:50:51.628
Triggering next historical data download in queue. | 2022-10-10 06:50:51.628
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:51.629
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:51.629
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:51.629
Delaying start of download for NQZ2.CME | 2022-10-10 06:50:51.650
Using Bid/Ask average for last trade price for NAS100 | 2022-10-10 06:50:51.658
SC DTC Data with Market Depth | Starting real-time market data updates for: NAS100. ID: 2 Service code: fxcm | 2022-10-10 06:50:51.658
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2022-10-10 06:50:51.658
SC DTC Data with Market Depth | Requesting security definition data for: NAS100. ID: 2 | 2022-10-10 06:50:51.658
Added historical Intraday data request for NAS100 to the queue. | 2022-10-10 06:50:51.658
Intraday data recording state for symbol NAS100 is set to download 'Pending'. | 2022-10-10 06:50:51.658
Triggering next historical data download in queue. | 2022-10-10 06:50:51.658
DTC Client socket (4) | Creating socket. | 2022-10-10 06:50:51.659
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-10-10 06:50:51.659
DTC Client socket (4) | Connecting to IP: 142.215.18.104. | 2022-10-10 06:50:51.659
Rithmic Direct - DTC | Starting real-time market data updates for: MNQZ2.CME. ID: 3 Service code: rithmic.trading | 2022-10-10 06:50:51.675
Rithmic Direct - DTC | Requesting security definition data for: MNQZ2.CME. ID: 3 | 2022-10-10 06:50:51.675
Added historical Intraday data request for MNQZ2.CME to the queue. | 2022-10-10 06:50:51.675
Intraday data recording state for symbol MNQZ2.CME is set to download 'Pending'. | 2022-10-10 06:50:51.675
Triggering next historical data download in queue. | 2022-10-10 06:50:51.675
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:51.727
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:51.727
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:51.727
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:51.727
SC DTC Data with Market Depth | Network connection to server complete. | 2022-10-10 06:50:51.727
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-10-10 06:50:51.727
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-10 06:50:51.727
Rithmic Direct - DTC | Starting real-time market data updates for: MNQM2.CME. ID: 4 Service code: rithmic.trading | 2022-10-10 06:50:51.734
Rithmic Direct - DTC | Requesting security definition data for: MNQM2.CME. ID: 4 | 2022-10-10 06:50:51.734
Added historical Intraday data request for MNQM2.CME to the queue. | 2022-10-10 06:50:51.734
Intraday data recording state for symbol MNQM2.CME is set to download 'Pending'. | 2022-10-10 06:50:51.734
Triggering next historical data download in queue. | 2022-10-10 06:50:51.734
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-10-10 06:50:51.814
SC DTC Data with Market Depth | Sending logon request message. | 2022-10-10 06:50:51.814
Using Bid/Ask average for last trade price for SPX500 | 2022-10-10 06:50:51.916
SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 5 Service code: fxcm | 2022-10-10 06:50:51.916
SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 5 | 2022-10-10 06:50:51.916
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:51.962
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:51.962
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:51.962
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:51.962
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:51.962
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:51.963
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:51.963
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:51.963
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:51.963
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:52.042
DTC Client socket (2) | Closed. | 2022-10-10 06:50:52.042
SC DTC Data with Market Depth | Received logon response. | 2022-10-10 06:50:52.501
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-10-10 06:50:52.501
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:52.501
SC DTC Data with Market Depth | Successfully connected. | 2022-10-10 06:50:52.501
SC DTC Data with Market Depth | Trading is not supported. | 2022-10-10 06:50:52.501
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NAS100 | 2022-10-10 06:50:52.501
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-10-10 06:50:52.501
SC DTC Data with Market Depth | Received security definition for symbol NAS100 | 2022-10-10 06:50:52.680
SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-10-10 06:50:52.680
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:53.983
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:53.984
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:53.984
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:53.985
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:53.985
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:54.072
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:54.072
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:54.072
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:54.072
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:54.335
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:54.335
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:54.335
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:54.335
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:54.335
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:54.336
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:54.336
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:54.336
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:54.336
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:54.421
DTC Client socket (2) | Closed. | 2022-10-10 06:50:54.421
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:56.340
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:56.340
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:56.341
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:56.341
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:56.341
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:56.437
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:56.437
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:56.438
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:56.438
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:56.680
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:56.680
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:56.680
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:56.680
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:56.680
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:56.680
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:56.680
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:56.680
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:56.681
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:56.758
DTC Client socket (2) | Closed. | 2022-10-10 06:50:56.758
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:50:58.691
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:50:58.691
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:50:58.692
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:50:58.692
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:50:58.692
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:50:58.778
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:50:58.778
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:50:58.778
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:50:58.778
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:50:59.012
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:50:59.012
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:50:59.012
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:50:59.012
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:50:59.012
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:50:59.013
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:50:59.013
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:50:59.013
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:50:59.013
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:50:59.088
DTC Client socket (2) | Closed. | 2022-10-10 06:50:59.088
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:01.026
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:01.026
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:01.027
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:01.027
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:01.027
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:01.107
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:01.107
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:01.107
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:01.107
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:01.358
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:01.358
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:01.358
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:01.358
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:01.358
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:01.359
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:01.359
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:01.359
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:01.359
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:01.446
DTC Client socket (2) | Closed. | 2022-10-10 06:51:01.446
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:03.352
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:03.352
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:03.353
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:03.353
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:03.353
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:03.432
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:03.432
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:03.432
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:03.432
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:03.681
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:03.681
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:03.681
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:03.681
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:03.682
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:03.682
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:03.682
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:03.682
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:03.683
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:03.763
DTC Client socket (2) | Closed. | 2022-10-10 06:51:03.763
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:05.703
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:05.703
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:05.704
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:05.704
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:05.704
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:05.805
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:05.805
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:05.806
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:05.806
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:06.043
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:06.043
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:06.043
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:06.043
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:06.043
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:06.044
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:06.044
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:06.044
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:06.044
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:06.122
DTC Client socket (2) | Closed. | 2022-10-10 06:51:06.123
HD Request # 18 | Downloading Intraday chart data for NQZ2.CME to the file NQZ2.CME.scid. Service: rithmic.trading | 2022-10-10 06:51:07.752
HD Request # 18 | Download start date-time: 2022-10-10 06:47:45.000000. File last date-time: 2022-10-10 06:47:45.583000 | 2022-10-10 06:51:07.753
HD Request # 18 | Using server: rsc.rithmic.com port 50502. Use encryption. | 2022-10-10 06:51:07.753
Socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:07.753
Socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:07.753
Socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:07.753
HD Request # 18 | Sending historical data logon request message. | 2022-10-10 06:51:07.833
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:08.040
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:08.040
DTC Client socket (5) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:08.041
DTC Client socket (5) | New receive buffer size: 5242880 | 2022-10-10 06:51:08.041
DTC Client socket (5) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:08.041
HD Request # 18 | Requesting Intraday data. Start date-time: 2022-10-10 06:47:45. Record interval: 0. Symbol: NQZ2.CME | 2022-10-10 06:51:08.082
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:08.123
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:08.123
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:08.123
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:08.123
HD Request # 18 | Receiving Intraday data for NQZ2.CME starting at 2022-10-10 06:47:45.270000 | 2022-10-10 06:51:08.165
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:08.362
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:08.362
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:08.362
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:08.362
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:08.362
DTC Client socket (5) | CloseSocket call. | 2022-10-10 06:51:08.362
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:08.362
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:08.362
DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:08.362
Socket (2) | CloseSocket call. | 2022-10-10 06:51:08.411
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:08.412
Historical data download thread signaled to stop. | 2022-10-10 06:51:08.412
HD Request # 18 | Timestamp of first Intraday data file record written: 2022-10-10 06:47:48.070000 | 2022-10-10 06:51:08.412
HD Request # 18 | Received 417 Intraday data records from 2022-10-10 06:47:45.270000 to 2022-10-10 06:51:05.522000 (3.3 minutes) and wrote 409 records for NQZ2.CME | 2022-10-10 06:51:08.412
HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2022-10-10 11:51:05.522000 | 2022-10-10 06:51:08.421
HD Request # 18 | Completion time: 1s | 2022-10-10 06:51:08.421
HD Request # 18 | Intraday data download complete for NQZ2.CME. Unique request ID: 18 | 2022-10-10 06:51:08.421
Removing historical data download ID 18. | 2022-10-10 06:51:08.421
Real-time Intraday chart data file updates started for NQZ2.CME | 2022-10-10 06:51:08.421
Intraday chart data file opened for NQZ2.CME | 2022-10-10 06:51:08.421
HD Request # 18 | Enabling Intraday chart updating for symbol. | 2022-10-10 06:51:08.421
Triggering next historical data download in queue. | 2022-10-10 06:51:08.421
HD Request # 19 | Downloading Intraday chart data for NAS100 to the file NAS100.scid. Service: fxcm | 2022-10-10 06:51:08.421
HD Request # 19 | Download start date-time: 2022-10-10 06:50:36.000000. File last date-time: 2022-10-10 06:50:36.996000 | 2022-10-10 06:51:08.421
HD Request # 19 | Using server: ds12.sierracharts.com port 10149 | 2022-10-10 06:51:08.422
Socket (6) | Creating socket. | 2022-10-10 06:51:08.422
Socket (6) | New receive buffer size: 5242880 | 2022-10-10 06:51:08.422
Socket (6) | Connecting to IP: 142.215.18.104. | 2022-10-10 06:51:08.422
DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-10-10 06:51:08.441
DTC Client socket (5) | Closed. | 2022-10-10 06:51:08.441
Socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:08.486
Socket (2) | Closed. | 2022-10-10 06:51:08.486
HD Request # 19 | Setting DTC encoding to Binary VLS | 2022-10-10 06:51:08.569
HD Request # 19 | Sending historical data logon request message. | 2022-10-10 06:51:08.569
Chart #8 has tagged chart #3 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:08.799
Chart #8 has tagged chart #4 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:08.800
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:08.800
Chart #8 has tagged chart #7 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:08.800
Chart #8 has tagged chart #9 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:08.800
NQZ2.CME 3 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:08.833
MNQZ2.CME 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:08.841
MNQZ2.CME 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:08.864
NQZ2.CME #4 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:09.054
MNQM2.CME #3 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:09.058
HD Request # 19 | Requesting Intraday data. Start date-time: 2022-10-10 06:50:36. Record interval: 0. Symbol: NAS100 | 2022-10-10 06:51:09.145
HD Request # 19 | Decompressing data. | 2022-10-10 06:51:09.210
HD Request # 19 | Receiving Intraday data for NAS100 starting at 2022-10-10 06:50:36.114000 | 2022-10-10 06:51:09.212
Socket (6) | CloseSocket call. | 2022-10-10 06:51:09.212
Historical data download thread signaled to stop. | 2022-10-10 06:51:09.213
Socket (6) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:09.213
HD Request # 19 | Timestamp of first Intraday data file record written: 2022-10-10 06:50:37.613000 | 2022-10-10 06:51:09.213
HD Request # 19 | Received 195 Intraday data records from 2022-10-10 06:50:36.114000 to 2022-10-10 06:51:07.172000 (31.1 seconds) and wrote 182 records for NAS100 | 2022-10-10 06:51:09.213
HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2022-10-10 11:51:07.172000 | 2022-10-10 06:51:09.221
HD Request # 19 | Completion time: 1s | 2022-10-10 06:51:09.221
HD Request # 19 | Intraday data download complete for NAS100. Unique request ID: 19 | 2022-10-10 06:51:09.221
Removing historical data download ID 19. | 2022-10-10 06:51:09.221
Real-time Intraday chart data file updates started for NAS100 | 2022-10-10 06:51:09.222
Intraday chart data file opened for NAS100 | 2022-10-10 06:51:09.222
HD Request # 19 | Enabling Intraday chart updating for symbol. | 2022-10-10 06:51:09.222
Triggering next historical data download in queue. | 2022-10-10 06:51:09.222
HD Request # 20 | Downloading Intraday chart data for MNQZ2.CME to the file MNQZ2.CME.scid. Service: rithmic.trading | 2022-10-10 06:51:09.222
HD Request # 20 | Download start date-time: 2022-10-10 06:47:49.000000. File last date-time: 2022-10-10 06:47:49.709000 | 2022-10-10 06:51:09.222
HD Request # 20 | Using server: rsc.rithmic.com port 50502. Use encryption. | 2022-10-10 06:51:09.222
Socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:09.223
Socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:09.223
Socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:09.223
Socket (6) | Socket gracefully closed by remote side. | 2022-10-10 06:51:09.277
Socket (6) | Closed. | 2022-10-10 06:51:09.277
HD Request # 20 | Sending historical data logon request message. | 2022-10-10 06:51:09.308
HD Request # 20 | Requesting Intraday data. Start date-time: 2022-10-10 06:47:49. Record interval: 0. Symbol: MNQZ2.CME | 2022-10-10 06:51:09.588
HD Request # 20 | Receiving Intraday data for MNQZ2.CME starting at 2022-10-10 06:47:49.231000 | 2022-10-10 06:51:09.680
Socket (2) | CloseSocket call. | 2022-10-10 06:51:10.269
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:10.269
Historical data download thread signaled to stop. | 2022-10-10 06:51:10.269
HD Request # 20 | Timestamp of first Intraday data file record written: 2022-10-10 06:47:51.030000 | 2022-10-10 06:51:10.270
HD Request # 20 | Received 1073 Intraday data records from 2022-10-10 06:47:49.231000 to 2022-10-10 06:51:07.058000 (3.3 minutes) and wrote 1070 records for MNQZ2.CME | 2022-10-10 06:51:10.270
HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2022-10-10 11:51:07.058000 | 2022-10-10 06:51:10.279
HD Request # 20 | Completion time: 1s | 2022-10-10 06:51:10.280
HD Request # 20 | Intraday data download complete for MNQZ2.CME. Unique request ID: 20 | 2022-10-10 06:51:10.280
Removing historical data download ID 20. | 2022-10-10 06:51:10.280
Real-time Intraday chart data file updates started for MNQZ2.CME | 2022-10-10 06:51:10.280
Intraday chart data file opened for MNQZ2.CME | 2022-10-10 06:51:10.280
HD Request # 20 | Enabling Intraday chart updating for symbol. | 2022-10-10 06:51:10.280
Triggering next historical data download in queue. | 2022-10-10 06:51:10.280
HD Request # 21 | Downloading Intraday chart data for MNQM2.CME to the file MNQM2.CME.scid. Service: rithmic.trading | 2022-10-10 06:51:10.280
HD Request # 21 | Download start date-time: 2022-06-17 08:29:59.000000. File last date-time: 2022-06-17 08:29:59.827000 | 2022-10-10 06:51:10.280
HD Request # 21 | Using server: rsc.rithmic.com port 50502. Use encryption. | 2022-10-10 06:51:10.280
Socket (5) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:10.280
Socket (5) | New receive buffer size: 5242880 | 2022-10-10 06:51:10.281
Socket (5) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:10.281
Chart #11 has tagged chart #3 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.352
Chart #11 has tagged chart #4 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.352
Chart #11 has tagged chart #8 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.352
Socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:10.354
Socket (2) | Closed. | 2022-10-10 06:51:10.354
Chart #10 has tagged chart #3 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.361
Chart #10 has tagged chart #4 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.361
Chart #10 has tagged chart #6 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.361
Chart #10 has tagged chart #7 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.361
Chart #10 has tagged chart #8 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.361
Chart #10 has tagged chart #9 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.361
HD Request # 21 | Sending historical data logon request message. | 2022-10-10 06:51:10.368
MNQZ2.CME 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:10.375
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:10.564
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:10.564
NQZ2.CME #4 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:10.564
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:10.564
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:10.564
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:10.564
MNQM2.CME #3 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:10.566
HD Request # 21 | Requesting Intraday data. Start date-time: 2022-06-17 08:29:59. Record interval: 0. Symbol: MNQM2.CME | 2022-10-10 06:51:10.612
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:10.648
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:10.648
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:10.648
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:10.648
HD Request # 21 | Receiving Intraday data for MNQM2.CME starting at 2022-06-17 08:29:59.827000 | 2022-10-10 06:51:10.691
Socket (5) | CloseSocket call. | 2022-10-10 06:51:10.691
Historical data download thread signaled to stop. | 2022-10-10 06:51:10.692
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:10.692
HD Request # 21 | Received 1 Intraday data record from 2022-06-17 08:29:59.827000 to 2022-06-17 08:29:59.827000 (0.0 seconds) and wrote 0 records for MNQM2.CME | 2022-10-10 06:51:10.692
HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2022-06-17 13:29:59.827000 | 2022-10-10 06:51:10.693
HD Request # 21 | Completion time: 0s | 2022-10-10 06:51:10.693
HD Request # 21 | Intraday data download complete for MNQM2.CME. Unique request ID: 21 | 2022-10-10 06:51:10.693
Removing historical data download ID 21. | 2022-10-10 06:51:10.693
Real-time Intraday chart data file updates started for MNQM2.CME | 2022-10-10 06:51:10.693
Intraday chart data file opened for MNQM2.CME | 2022-10-10 06:51:10.693
HD Request # 21 | Enabling Intraday chart updating for symbol. | 2022-10-10 06:51:10.693
Triggering next historical data download in queue. | 2022-10-10 06:51:10.693
No download requests in the queue to start downloads for. | 2022-10-10 06:51:10.693
Socket (5) | Socket gracefully closed by remote side. | 2022-10-10 06:51:10.768
Socket (5) | Closed. | 2022-10-10 06:51:10.768
NQZ2.CME 3 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:10.806
Chart #8 has tagged chart #3 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.821
Chart #8 has tagged chart #4 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.821
Chart #8 has tagged chart #6 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.821
Chart #8 has tagged chart #7 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.821
Chart #8 has tagged chart #9 for full recalculation. Chartbook: Axia.Cht | 2022-10-10 06:51:10.821
NQZ2.CME 3 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:10.842
MNQZ2.CME 3 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:10.851
MNQZ2.CME 30 Sec #6 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:10.870
NQZ2.CME #4 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:11.056
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:11.059
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:11.059
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:11.059
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:11.059
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:11.060
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:11.060
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:11.060
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:11.060
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:11.060
MNQM2.CME #3 | Performing a full recalculation because it has been tagged. Chartbook: Axia.Cht | 2022-10-10 06:51:11.062
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:11.138
DTC Client socket (2) | Closed. | 2022-10-10 06:51:11.138
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:13.075
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:13.075
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:13.076
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:13.076
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:13.076
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:13.163
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:13.163
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:13.163
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:13.163
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:13.409
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:13.409
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:13.409
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:13.409
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:13.409
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:13.409
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:13.409
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:13.409
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:13.409
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:13.493
DTC Client socket (2) | Closed. | 2022-10-10 06:51:13.493
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:15.420
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:15.420
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:15.421
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:15.421
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:15.421
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:15.499
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:15.499
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:15.499
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:15.499
Opened cached Intraday file: C:\SierraChart\Data\NAS100.scid. Thread ID: 23956 | 2022-10-10 06:51:15.595
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:15.738
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:15.738
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:15.738
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:15.738
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:15.738
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:15.739
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:15.739
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:15.739
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:15.739
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:15.819
DTC Client socket (2) | Closed. | 2022-10-10 06:51:15.819
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:17.766
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:17.766
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:17.767
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:17.767
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:17.767
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:17.865
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:17.865
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:17.865
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:17.865
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:18.116
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:18.116
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:18.116
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:18.116
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:18.116
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:18.116
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:18.116
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:18.116
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:18.117
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:18.202
DTC Client socket (2) | Closed. | 2022-10-10 06:51:18.202
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:20.120
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:20.120
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:20.121
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:20.121
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:20.121
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:20.201
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:20.201
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:20.202
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:20.202
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:20.442
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:20.442
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:20.442
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:20.442
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:20.442
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:20.443
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:20.443
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:20.443
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:20.443
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:20.537
DTC Client socket (2) | Closed. | 2022-10-10 06:51:20.537
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:21.276
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | New receive buffer size: 32768 | 2022-10-10 06:51:21.276
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Connecting to IP: 38.79.0.89. | 2022-10-10 06:51:21.276
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:21.895
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | CloseSocket call. | 2022-10-10 06:51:21.897
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-10 06:51:21.897
HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Closed. | 2022-10-10 06:51:21.897
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:22.446
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:22.446
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:22.447
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:22.447
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:22.447
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:22.527
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:22.527
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:22.528
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:22.528
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:22.771
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:22.771
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:22.771
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:22.771
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:22.771
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:22.772
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:22.772
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:22.772
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:22.772
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:22.856
DTC Client socket (2) | Closed. | 2022-10-10 06:51:22.856
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:24.782
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:24.782
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:24.783
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:24.783
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:24.783
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:24.868
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:24.868
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:24.868
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:24.868
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:25.132
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:25.132
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:25.132
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:25.132
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:25.132
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:25.132
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:25.133
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:25.133
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:25.133
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:25.221
DTC Client socket (2) | Closed. | 2022-10-10 06:51:25.222
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:27.136
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:27.136
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:27.137
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:27.137
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:27.137
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:27.212
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:27.212
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:27.212
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:27.212
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:27.457
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:27.457
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:27.457
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:27.457
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:27.457
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:27.457
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:27.457
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:27.457
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:27.457
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:27.534
DTC Client socket (2) | Closed. | 2022-10-10 06:51:27.534
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:29.462
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:29.462
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:29.463
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:29.463
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:29.463
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:29.543
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:29.543
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:29.543
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:29.543
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:29.787
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:29.787
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:29.787
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:29.787
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:29.787
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:29.787
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:29.787
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:29.787
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:29.788
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:29.878
DTC Client socket (2) | Closed. | 2022-10-10 06:51:29.878
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:31.804
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:31.804
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:31.805
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:31.805
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:31.805
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:31.903
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:31.903
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:31.903
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:31.903
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:32.156
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:32.156
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:32.156
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:32.156
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:32.156
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:32.157
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:32.157
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:32.157
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:32.157
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:32.246
DTC Client socket (2) | Closed. | 2022-10-10 06:51:32.246
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:34.167
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:34.167
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:34.168
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:34.168
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:34.168
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:34.252
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:34.252
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:34.252
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:34.252
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:34.505
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:34.505
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:34.505
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:34.505
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:34.505
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:34.506
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:34.506
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:34.506
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:34.506
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:34.585
DTC Client socket (2) | Closed. | 2022-10-10 06:51:34.586
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:36.508
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:36.508
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:36.509
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:36.509
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:36.509
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:36.589
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:36.589
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:36.589
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:36.589
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:36.830
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:36.830
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:36.830
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:36.830
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:36.830
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:36.830
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:36.830
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:36.830
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:36.830
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:36.906
DTC Client socket (2) | Closed. | 2022-10-10 06:51:36.906
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:38.820
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:38.820
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:38.821
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:38.821
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:38.821
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:38.912
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:38.912
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:38.912
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:38.912
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:39.158
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:39.158
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:39.158
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:39.158
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:39.158
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:39.159
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:39.159
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:39.159
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:39.159
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:39.250
DTC Client socket (2) | Closed. | 2022-10-10 06:51:39.250
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:41.166
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:41.166
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:41.167
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:41.167
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:41.167
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:41.247
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:41.247
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:41.247
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:41.247
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:41.512
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:41.512
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:41.512
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:41.512
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:41.512
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:41.512
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:41.512
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:41.512
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:41.513
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:41.599
DTC Client socket (2) | Closed. | 2022-10-10 06:51:41.599
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:43.512
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:43.512
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:43.513
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:43.513
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:43.513
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:43.595
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:43.595
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:43.595
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:43.595
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:43.841
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:43.841
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:43.841
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:43.841
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:43.841
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:43.842
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:43.842
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:43.842
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:43.842
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:43.920
DTC Client socket (2) | Closed. | 2022-10-10 06:51:43.920
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:45.838
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:45.838
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:45.839
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:45.839
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:45.839
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:45.925
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:45.925
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:45.925
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:45.925
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:46.171
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:46.171
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:46.171
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:46.171
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:46.171
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:46.172
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:46.172
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:46.172
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:46.172
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:46.250
DTC Client socket (2) | Closed. | 2022-10-10 06:51:46.250
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:48.162
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:48.162
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:48.163
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:48.163
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:48.163
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:48.243
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:48.243
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:48.243
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:48.243
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:48.489
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:48.489
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:48.489
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:48.489
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:48.489
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:48.490
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:48.490
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:48.490
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:48.490
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:48.572
DTC Client socket (2) | Closed. | 2022-10-10 06:51:48.572
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:50.496
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:50.497
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:50.497
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:50.498
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:50.498
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:50.573
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:50.573
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:50.573
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:50.573
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:50.821
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:50.821
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:50.821
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:50.821
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:50.821
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:50.821
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:50.821
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:50.821
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:50.822
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:50.900
DTC Client socket (2) | Closed. | 2022-10-10 06:51:50.900
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:52.820
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:52.820
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:52.821
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-10 06:51:52.821
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:52.821
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:52.903
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:52.903
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:52.903
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:52.903
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:53.146
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:53.146
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:53.146
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:53.146
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:53.146
DTC Client socket (2) | CloseSocket call. | 2022-10-10 06:51:53.147
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:53.147
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:53.147
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:53.147
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-10 06:51:53.226
DTC Client socket (2) | Closed. | 2022-10-10 06:51:53.226
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Aggregated | 2022-10-10 06:51:55.158
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50507 | 2022-10-10 06:51:55.158
DTC Client socket (5) | Creating socket. Using TLS 1.2. | 2022-10-10 06:51:55.159
DTC Client socket (5) | New receive buffer size: 5242880 | 2022-10-10 06:51:55.159
DTC Client socket (5) | Connecting to IP: 216.57.156.163. | 2022-10-10 06:51:55.159
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-10 06:51:55.243
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-10 06:51:55.243
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-10 06:51:55.243
Rithmic Direct - DTC | Sending logon request message. | 2022-10-10 06:51:55.243
Rithmic Direct - DTC | Received logon response. | 2022-10-10 06:51:55.488
Rithmic Direct - DTC | Server Name: . | 2022-10-10 06:51:55.488
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-10 06:51:55.488
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-10 06:51:55.488
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-10 06:51:55.488
DTC Client socket (5) | CloseSocket call. | 2022-10-10 06:51:55.489
Rithmic Direct - DTC | Disconnected from the server. | 2022-10-10 06:51:55.489
Rithmic Direct - DTC | Data feed disconnected. Will reconnect in 2 seconds. | 2022-10-10 06:51:55.489
DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-10 06:51:55.489
DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-10-10 06:51:55.572
DTC Client socket (5) | Closed. | 2022-10-10 06:51:55.572
[2022-10-10 11:54:13]
User475292 - Posts: 5
also if you would like to remote in. Im not going to leave this thread until this issue has a resoultion
[2022-10-10 11:59:59]
Sierra_Chart Engineering - Posts: 24894
We have had several reports today of users getting this:
Rithmic Direct - DTC (Data) | Logon error received from server: permission denied | 2022-10-10 07:50:14.175
And now the two logs that we see in this thread, also getting the same error. We are going to contact Rithmic about this, if you do not know why this is happening. This is a Rithmic issue. Not Sierra Chart. It may be affecting Sierra Chart users only, but it is an issue on the Rithmic side.
[2022-10-10 12:02:27]
We have contacted Rithmic about this. We have indicated it is a priority.
Date Time Of Last Edit: 2022-10-10 12:02:38
[2022-10-10 12:03:45]
Thank you sierra for asking to get the logs from us, Thank you for investigating, will you continue to update this thread with this issue, if it adds anything thing. I'm on two different machines with two different firms LEELOO, APEX, they are creating similar logs, "logon error" but it is correct, and shows the connection established.
[2022-10-10 12:17:21]
One other thing we want to make clear is that Rithmic uses two connections. One for trading which is considered the primary connection and which the status box of Sierra Chart, the one that is green and red, indicates the status of.
And the other one is for market data.
If you have a connection to the trading server but you are getting an error connecting to the Data server:
Rithmic Direct - DTC (Data) | Logon error received from server: permission denied | 2022-10-10 07:50:06.921
Then this means there is a problem with the market data connection only. If are using the Denali Data Feed, you do you will not have this issue. However, there are complications using this data feed if you are using one of these trading evaluator services related to CME exchange fees.
Date Time Of Last Edit: 2022-10-10 12:18:24
[2022-10-10 12:38:50]
User199865 - Posts: 23
I HAVE LIFT OFFF - working
[2022-10-10 12:39:32]
Its working again. THank you sooo very much. SIERRA. this is the one time i have needed you guys. and you saved the day.
[2022-10-10 12:55:18]
This is what Rithmic said:
We believe the live data issue is fixed for Sierra Charts. Please check and confirm.
[2022-10-10 13:21:12]
madness99 - Posts: 35
Can you tell us what was the problem?
Jerome
[2022-10-10 13:37:45]
No Rithmic did not tell us that.
