Date/Time: Sat, 15 Mar 2025 02:37:18 +0000
Out of order timestamps although imported scid file correct
View Count: 443
[2022-07-11 07:02:39] |
User102394 - Posts: 9 |
Hi, I have been successfully importing a self-generated scid file since December last year, however, I now started getting an "out of order timestamp" issue. The message is: DAX-LONGSHORT 1 Min #1 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-07-11 08:53:00. Next Bar Date Time: 2022-07-11 08:46:00. Filename: DAX-LONGSHORT.scid | 2022-07-11 08:53:40.074 It seems that the "Next Bar Date Time" is never incrementing. How can I solve this problem? Thank you very much in advance! |
[2022-07-11 11:02:33] |
The only possibility here, is that the timestamps are actually out of order in the Intraday data file. Export the data and check this: Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-11 11:29:59] |
Thank you for your prompt reply! I have already checked the scid file and it is correct. However, when I perform manual re-calculation the out-of-order timestamp (as visualized by the out-of-order timestamp study) disappear except for the latest bar. This is an excerpt of the exported bar data: 2022/7/11, 13:17:00, 0.29, 0.29, 0.29, 0.29, 1, 1, 1, 1 2022/7/11, 13:18:00, 0.29, 0.29, 0.29, 0.29, 1, 1, 1, 1 2022/7/11, 13:19:00, 0.29, 0.29, 0.29, 0.29, 1, 1, 1, 1 2022/7/11, 13:20:00, 0.29, 0.29, 0.29, 0.29, 1, 1, 1, 1 2022/7/11, 13:19:00, 0.29, 0.29, 0.29, 0.29, 1, 1, 1, 1 At 13:18, I did a recalculation and the "13:19:00" timestamp will continue repeating from then on. FYI, I have a Intraday Data Storage Time Unit of 10 sec and I use the SC data feed. As I wrote earlier, I did not have the problem earlier. The only thing I changed was the Intraday Data Storage Time Unit (from tick based to 10 sec). Thank you for your help!! Date Time Of Last Edit: 2022-07-11 11:47:17
[2022-07-11 14:50:04] |
Where is the real-time data coming from? The timestamps of that sounds like they are not correct.
[2022-07-11 15:05:09] |
The data is generated using a python script I wrote, which creates an entry every minute based on some scraped data. The entries are generated exactly as explained here: Intraday Data File Format As I said, after a recalculation of the chart, all "out-of-order timestamps" disappear. Also, when I try to spot these timestamps using "Edit -> Edit Intraday Data" they are all correct, which proves that the generated scid file is correct. It is only the real-time updating of the chart in SC that does not work properly. |
[2022-07-12 08:49:29] |
Sierra_Chart Engineering - Posts: 18789 |
There must be something you are doing wrong on your side. This is definitively not a problem on the Sierra Chart side.
[2022-07-12 10:11:11] |
Dear SC support, Your reply is not really of great help to me. I am not saying that there is a problem with SC. But as I said already a couple of times, my scid file is correct. Probably, there are one or two configurations that are not correct but I don't know where to look and check. I was hoping that you can give me at least some hints on what to check. IMO, if you provide the feature of importing your own scid file in real-time in SC (which is a wonderful feature BTW!) then a customer can expect some degree of support for this feature that goes beyond just repeating that "something is wrong on my side". Please give me some hints what I need to check that could help solving the problem. For instance, I changed the intraday data storage unit recently from 1tick to 10 sec. Could this create the problem? Thanks |
[2022-07-13 11:10:53] |
Based upon what you are saying, are the timestamps of written records in the Intraday data file changing? The Date-Time value of a record must not change after it has been written. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-13 11:10:58
