Date/Time: Wed, 19 Mar 2025 19:56:39 +0000
connecting to rithmic
View Count: 852
[2022-07-08 00:48:41]
SSGill - Posts: 36
hi, i tried to connect to rithmic from apex trader funding;
the instructions say to choose "rithmic direct - dtc [trading]"
but the instructions say I should be able to choose from the server list;
RIT5HMIC 01 CHICAGO AREA NON AGGREGATED
the pull down menu is blank; and I cannot proceed
please see screenshot attached
imagesc setting up rithmic.PNG / V - Attached On 2022-07-07 20:01:15 UTC - Size: 17.37 KB - 158 views
imagesc setting up rithmic.PNG / V - Attached On 2022-07-07 20:04:35 UTC - Size: 17.37 KB - 132 views
[2022-07-08 04:41:50]
Tony - Posts: 555
Rithmic Trading Platform Service: Setup Instructions
No,9 and No,10 explained.
[2022-07-08 05:32:11]
Yes go through the detailed instructions here:
[2022-10-28 15:27:27]
SSGill - Posts: 36
Hello;
as of last monday; 10-24, Apex Trader Funding has made a change to their Rithmic feed. If I load Rithmic on my computer, one of the changes I make is I choose "APEX" instead of "papertrading", then I can log in successfully.
As of last monday, I am unable to log into rithmic. I checked with Apex, and they say the issue is on your end.
Have you heard of anything different that needs to be done on the sierra charts side?? I am getting the "connection error message from service - Rithmic direct"
Any suggestions, or questions for Apex would be greatly appreciated.
[2022-10-28 16:33:47]
Sierra_Chart Engineering - Posts: 18844
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
[2022-10-28 17:43:17]
SSGill - Posts: 36
here is the copy of the log;
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2022-10-24 06:38:32.750
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 32768 | 2022-10-24 06:38:32.750
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 38.79.0.89. | 2022-10-24 06:38:32.750
Reading Internal Order ID file. | 2022-10-24 06:38:32.823
Reading Trade Orders file. | 2022-10-24 06:38:32.875
Reading Trade Positions file. | 2022-10-24 06:38:32.898
Reading Trade Account Data files. | 2022-10-24 06:38:32.905
Software version: 2394 64-bit | 2022-10-24 06:38:32.937
Primary Thread ID: 18004 | 2022-10-24 06:38:32.937
Usage end date: 2022-10-29 | 2022-10-24 06:38:32.937
Enabled for: Sierra Chart Historical Data Service. | 2022-10-24 06:38:32.937
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-10-24 06:38:32.937
Enabled for: Delayed Denali Exchange Data Feed. | 2022-10-24 06:38:32.937
Enabled for exchange2: CME (Trading Account Required) | 2022-10-24 06:38:32.937
Enabled for exchange2: CBOT (Trading Account Required) | 2022-10-24 06:38:32.937
Enabled for exchange2: COMEX (Trading Account Required) | 2022-10-24 06:38:32.937
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-10-24 06:38:32.937
Enabled for exchange2: fairx_exchange.data | 2022-10-24 06:38:32.937
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-10-24 06:38:32.937
Current selected Data/Trading service: Rithmic Direct - DTC | 2022-10-24 06:38:32.937
Custom symbol settings values: enabled | 2022-10-24 06:38:32.937
Chart Update Interval: 500 | 2022-10-24 06:38:32.937
Intraday Data Storage Time Unit: 1 | 2022-10-24 06:38:32.937
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-10-24 06:38:32.937
2022-10-24 10:38:32 Local computer time in UTC | 2022-10-24 06:38:32.937
2022-10-24 06:38:32 Local computer time in SC Time Zone | 2022-10-24 06:38:32.937
2022-10-24 10:38:31 Server time in UTC | 2022-10-24 06:38:32.937
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-10-24 06:38:32.938
Program path: C:\SierraChart\ | 2022-10-24 06:38:32.938
Data Files path: C:\SierraChart\Data\ | 2022-10-24 06:38:32.938
OS Version Number: 10.0 | 2022-10-24 06:38:32.938
Locale Setting: C | 2022-10-24 06:38:32.938
DLLs: sst_FreeBundle_2273_64.dll, sst_FreeBundle_64.dll, UserContributedStudies_64.dll | 2022-10-24 06:38:32.938
Allowed protected custom studies: SST_FreeBundle | 2022-10-24 06:38:32.938
Crash reporter started: true | 2022-10-24 06:38:32.938
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1. | 2022-10-24 06:38:32.951
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:32.979
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-10-24 06:38:33.116
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-10-24 06:38:33.116
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2022-10-24 06:38:33.155
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | CloseSocket call. | 2022-10-24 06:38:33.156
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:38:33.156
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (4) | Closed. | 2022-10-24 06:38:33.156
Received 5 login tokens. | 2022-10-24 06:38:33.428
Symbol settings MD5 received. Request ID: 1. | 2022-10-24 06:38:34.694
Symbol settings are up-to-date for rithmic_v2.trading. | 2022-10-24 06:38:34.694
Files to Open on Startup | Opening file: APEX.Cht | 2022-10-24 06:38:37.707
MESZ2.CME 1 Min #1 | Reloading chart. | 2022-10-24 06:38:37.918
ESZ2.CME 1 Min #2 | Reloading chart. | 2022-10-24 06:38:38.053
NQU2.CME 1 Min #3 | Reloading chart. | 2022-10-24 06:38:38.597
TICK-NYSE 1 Min #4 | Reloading chart. | 2022-10-24 06:38:39.280
TICK-NYSEMKT 1 Min #5 | Reloading chart. | 2022-10-24 06:38:40.560
NVOL24H-NYSEMKT 1 Min #6 | Reloading chart. | 2022-10-24 06:38:41.391
ESz2.CME 60 Min #7 | Reloading chart. | 2022-10-24 06:38:42.760
MESZ2.CME 1 Min #1 | StartDateTimeForLoadingOrderFills: 2022-09-25 18:00:00 | 2022-10-24 06:38:42.917
ESZ2.CME 1 Min #2 | StartDateTimeForLoadingOrderFills: 2022-09-25 18:00:00 | 2022-10-24 06:38:42.944
Mapping MESZ2.CME to MESZ22. Service code: cme | 2022-10-24 06:38:43.328
Using symbol data fast lookup vector | 2022-10-24 06:38:43.328
Starting DelayedDownloadMonitoringTimer | 2022-10-24 06:38:43.328
Starting HDTimeoutTimer | 2022-10-24 06:38:43.328
Added historical Intraday data request for MESZ2.CME to the queue. | 2022-10-24 06:38:43.328
Intraday data recording state for symbol MESZ2.CME is set to download 'Pending'. | 2022-10-24 06:38:43.328
Triggering next historical data download in queue. | 2022-10-24 06:38:43.328
HD Request # 1 | Downloading Intraday chart data for MESZ2.CME to the file MESZ2.CME.scid. Service: cme | 2022-10-24 06:38:43.330
HD Request # 1 | Download start date-time: 2022-10-24 05:39:14.000000. File last date-time: 2022-10-24 05:39:14.151000 | 2022-10-24 06:38:43.331
HD Request # 1 | Using server: ds26.sierracharts.com port 10150 | 2022-10-24 06:38:43.331
Mapping ESZ2.CME to ESZ22. Service code: cme | 2022-10-24 06:38:43.355
Added historical Intraday data request for ESZ2.CME to the queue. | 2022-10-24 06:38:43.355
Intraday data recording state for symbol ESZ2.CME is set to download 'Pending'. | 2022-10-24 06:38:43.355
Triggering next historical data download in queue. | 2022-10-24 06:38:43.355
Mapping NQU2.CME to NQU22. Service code: cme | 2022-10-24 06:38:43.363
Added historical Intraday data request for NQU2.CME to the queue. | 2022-10-24 06:38:43.363
Intraday data recording state for symbol NQU2.CME is set to download 'Pending'. | 2022-10-24 06:38:43.363
Triggering next historical data download in queue. | 2022-10-24 06:38:43.363
Added historical Intraday data request for TICK-NYSE to the queue. | 2022-10-24 06:38:43.365
Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2022-10-24 06:38:43.365
Triggering next historical data download in queue. | 2022-10-24 06:38:43.365
Socket (1) | Creating socket. | 2022-10-24 06:38:43.369
Socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:38:43.369
Socket (1) | Connecting to IP: 142.215.18.107. | 2022-10-24 06:38:43.370
Added historical Intraday data request for TICK-NYSEMKT to the queue. | 2022-10-24 06:38:43.372
Intraday data recording state for symbol TICK-NYSEMKT is set to download 'Pending'. | 2022-10-24 06:38:43.372
Triggering next historical data download in queue. | 2022-10-24 06:38:43.372
Added historical Intraday data request for NVOL24H-NYSEMKT to the queue. | 2022-10-24 06:38:43.383
Intraday data recording state for symbol NVOL24H-NYSEMKT is set to download 'Pending'. | 2022-10-24 06:38:43.383
Triggering next historical data download in queue. | 2022-10-24 06:38:43.385
HD Request # 1 | Setting DTC encoding to Binary VLS | 2022-10-24 06:38:43.452
HD Request # 1 | Sending historical data logon request message. | 2022-10-24 06:38:43.452
Chart #6 has tagged chart #4 for full recalculation. Chartbook: APEX.Cht | 2022-10-24 06:38:43.469
TICK-NYSE[M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: APEX.Cht | 2022-10-24 06:38:43.774
HD Request # 1 | Requesting Intraday data. Start date-time: 2022-10-24 05:39:14. Record interval: 1. Symbol: MESZ22 | 2022-10-24 06:38:44.006
HD Request # 1 | Decompressing data. | 2022-10-24 06:38:44.054
HD Request # 1 | Receiving Intraday data for MESZ2.CME starting at 2022-10-24 05:39:14.151000 | 2022-10-24 06:38:44.103
Socket (1) | CloseSocket call. | 2022-10-24 06:38:44.106
Socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:44.106
Historical data download thread signaled to stop. | 2022-10-24 06:38:44.106
HD Request # 1 | Timestamp of first Intraday data file record written: 2022-10-24 05:39:14.151000. | 2022-10-24 06:38:44.107
HD Request # 1 | Received 2818 Intraday data records from 2022-10-24 05:39:14.151000 to 2022-10-24 06:38:41.085000 (59.4 minutes) and wrote 2818 records for MESZ2.CME | 2022-10-24 06:38:44.107
HD Request # 1 | Completion time: 1s. | 2022-10-24 06:38:44.107
HD Request # 1 | Intraday data download complete for MESZ2.CME. Unique request ID: 1 | 2022-10-24 06:38:44.107
Removing historical data download ID 1. | 2022-10-24 06:38:44.107
HD Request # 1 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:38:44.107
Triggering next historical data download in queue. | 2022-10-24 06:38:44.107
Historical data for MESZ2.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:38:44.107
HD Request # 2 | Downloading Intraday chart data for ESZ2.CME to the file ESZ2.CME.scid. Service: cme | 2022-10-24 06:38:44.107
HD Request # 2 | Download start date-time: 2022-10-24 05:39:16.000000. File last date-time: 2022-10-24 05:39:16.207000 | 2022-10-24 06:38:44.108
HD Request # 2 | Using server: ds21.sierracharts.com port 10149 | 2022-10-24 06:38:44.108
Socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:38:44.144
Socket (1) | Closed. | 2022-10-24 06:38:44.144
Socket (3) | Creating socket. | 2022-10-24 06:38:44.145
Socket (3) | New receive buffer size: 5242880 | 2022-10-24 06:38:44.145
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-10-24 06:38:44.145
HD Request # 2 | Setting DTC encoding to Binary VLS | 2022-10-24 06:38:44.227
HD Request # 2 | Sending historical data logon request message. | 2022-10-24 06:38:44.227
HD Request # 2 | Requesting Intraday data. Start date-time: 2022-10-24 05:39:16. Record interval: 1. Symbol: ESZ22 | 2022-10-24 06:38:44.717
HD Request # 2 | Decompressing data. | 2022-10-24 06:38:44.760
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-24 06:38:44.779
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-24 06:38:44.781
HD Request # 2 | Receiving Intraday data for ESZ2.CME starting at 2022-10-24 05:39:16.207000 | 2022-10-24 06:38:44.812
Socket (3) | CloseSocket call. | 2022-10-24 06:38:44.813
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:44.813
Historical data download thread signaled to stop. | 2022-10-24 06:38:44.813
HD Request # 2 | Timestamp of first Intraday data file record written: 2022-10-24 05:39:16.207000. | 2022-10-24 06:38:44.813
HD Request # 2 | Received 2649 Intraday data records from 2022-10-24 05:39:16.207000 to 2022-10-24 06:38:41.085000 (59.4 minutes) and wrote 2649 records for ESZ2.CME | 2022-10-24 06:38:44.814
HD Request # 2 | Completion time: 0s. | 2022-10-24 06:38:44.814
HD Request # 2 | Intraday data download complete for ESZ2.CME. Unique request ID: 2 | 2022-10-24 06:38:44.814
Removing historical data download ID 2. | 2022-10-24 06:38:44.814
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:38:44.814
Triggering next historical data download in queue. | 2022-10-24 06:38:44.814
Historical data for ESZ2.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:38:44.814
HD Request # 3 | Downloading Intraday chart data for NQU2.CME to the file NQU2.CME.scid. Service: cme | 2022-10-24 06:38:44.814
HD Request # 3 | Download start date-time: 2022-09-16 09:29:59.000000. File last date-time: 2022-09-16 09:29:59.046000 | 2022-10-24 06:38:44.814
HD Request # 3 | Using server: ds26.sierracharts.com port 10150 | 2022-10-24 06:38:44.814
Socket (2) | Creating socket. | 2022-10-24 06:38:44.814
Socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:38:44.814
Socket (2) | Connecting to IP: 142.215.18.107. | 2022-10-24 06:38:44.814
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-24 06:38:44.819
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:38:44.819
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-24 06:38:44.819
Socket (3) | Socket gracefully closed by remote side. | 2022-10-24 06:38:44.853
Socket (3) | Closed. | 2022-10-24 06:38:44.853
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-24 06:38:44.860
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-24 06:38:44.860
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-24 06:38:44.860
Rithmic Direct - DTC | Sending logon request message. | 2022-10-24 06:38:44.860
HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-10-24 06:38:44.900
HD Request # 3 | Sending historical data logon request message. | 2022-10-24 06:38:44.900
HD Request # 3 | Requesting Intraday data. Start date-time: 2022-09-16 09:29:59. Record interval: 1. Symbol: NQU22 | 2022-10-24 06:38:44.946
HD Request # 3 | Decompressing data. | 2022-10-24 06:38:44.984
HD Request # 3 | Receiving Intraday data for NQU2.CME starting at 2022-09-16 09:29:59.046000 | 2022-10-24 06:38:44.985
Socket (2) | CloseSocket call. | 2022-10-24 06:38:44.985
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:44.986
Historical data download thread signaled to stop. | 2022-10-24 06:38:44.986
HD Request # 3 | Timestamp of first Intraday data file record written: 2022-09-16 09:29:59.046000. | 2022-10-24 06:38:44.986
HD Request # 3 | Received 1 Intraday data record from 2022-09-16 09:29:59.046000 to 2022-09-16 09:29:59.046000 (0.0 seconds) and wrote 1 record for NQU2.CME | 2022-10-24 06:38:44.986
HD Request # 3 | Completion time: 0s. | 2022-10-24 06:38:44.986
HD Request # 3 | Intraday data download complete for NQU2.CME. Unique request ID: 3 | 2022-10-24 06:38:44.986
Removing historical data download ID 3. | 2022-10-24 06:38:44.986
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:38:44.986
Triggering next historical data download in queue. | 2022-10-24 06:38:44.986
Historical data for NQU2.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:38:44.986
HD Request # 4 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2022-10-24 06:38:44.986
HD Request # 4 | Download start date-time: 2022-10-24 05:39:17.000000. File last date-time: 2022-10-24 05:39:17.000000 | 2022-10-24 06:38:44.986
HD Request # 4 | Using server: ds12.sierracharts.com port 10149 | 2022-10-24 06:38:44.986
Rithmic Direct - DTC | Received logon response. | 2022-10-24 06:38:44.993
Rithmic Direct - DTC | Server Name: . | 2022-10-24 06:38:44.993
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-24 06:38:44.993
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-24 06:38:44.993
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:38:44.993
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:38:44.993
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-24 06:38:45.015
DTC Client socket (1) | CloseSocket call. | 2022-10-24 06:38:45.016
Rithmic Direct - DTC | Disconnected. | 2022-10-24 06:38:45.016
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:38:45.016
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:45.016
Socket (3) | Creating socket. | 2022-10-24 06:38:45.018
Socket (3) | New receive buffer size: 5242880 | 2022-10-24 06:38:45.018
Socket (3) | Connecting to IP: 142.215.18.104. | 2022-10-24 06:38:45.018
Socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:38:45.026
Socket (2) | Closed. | 2022-10-24 06:38:45.026
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:38:45.057
DTC Client socket (1) | Closed. | 2022-10-24 06:38:45.057
Chart #2 has tagged chart #4 for full recalculation. Chartbook: APEX.Cht | 2022-10-24 06:38:45.058
HD Request # 4 | Setting DTC encoding to Binary VLS | 2022-10-24 06:38:45.120
HD Request # 4 | Sending historical data logon request message. | 2022-10-24 06:38:45.120
TICK-NYSE[M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: APEX.Cht | 2022-10-24 06:38:45.275
HD Request # 4 | Requesting Intraday data. Start date-time: 2022-10-24 05:39:17. Record interval: 1. Symbol: TICK-NYSE | 2022-10-24 06:38:45.671
HD Request # 4 | Decompressing data. | 2022-10-24 06:38:45.711
HD Request # 4 | Receiving Intraday data for TICK-NYSE starting at 2022-10-24 05:39:17.000000 | 2022-10-24 06:38:45.809
Socket (3) | CloseSocket call. | 2022-10-24 06:38:45.813
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:45.813
Historical data download thread signaled to stop. | 2022-10-24 06:38:45.813
HD Request # 4 | Timestamp of first Intraday data file record written: 2022-10-24 05:39:17.000000. | 2022-10-24 06:38:45.813
HD Request # 4 | Received 3530 Intraday data records from 2022-10-24 05:39:17.000000 to 2022-10-24 06:38:45.000000 (59.5 minutes) and wrote 3530 records for TICK-NYSE | 2022-10-24 06:38:45.813
HD Request # 4 | Completion time: 1s. | 2022-10-24 06:38:45.813
HD Request # 4 | Intraday data download complete for TICK-NYSE. Unique request ID: 4 | 2022-10-24 06:38:45.813
Removing historical data download ID 4. | 2022-10-24 06:38:45.813
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:38:45.813
Triggering next historical data download in queue. | 2022-10-24 06:38:45.813
Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:38:45.813
HD Request # 5 | Downloading Intraday chart data for TICK-NYSEMKT to the file TICK-NYSEMKT.scid. Service: statscalc | 2022-10-24 06:38:45.813
HD Request # 5 | Download start date-time: 2022-10-24 05:39:19.000000. File last date-time: 2022-10-24 05:39:19.000000 | 2022-10-24 06:38:45.813
HD Request # 5 | Using server: ds13-3.sierracharts.com port 10150 | 2022-10-24 06:38:45.813
Socket (1) | Creating socket. | 2022-10-24 06:38:45.847
Socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:38:45.847
Socket (1) | Connecting to IP: 162.251.232.235. | 2022-10-24 06:38:45.847
Socket (3) | Socket gracefully closed by remote side. | 2022-10-24 06:38:45.856
Socket (3) | Closed. | 2022-10-24 06:38:45.857
HD Request # 5 | Setting DTC encoding to Binary VLS | 2022-10-24 06:38:46.031
HD Request # 5 | Sending historical data logon request message. | 2022-10-24 06:38:46.031
HD Request # 5 | Requesting Intraday data. Start date-time: 2022-10-24 05:39:19. Record interval: 1. Symbol: TICK-NYSEMKT | 2022-10-24 06:38:46.752
HD Request # 5 | Decompressing data. | 2022-10-24 06:38:46.840
HD Request # 5 | Receiving Intraday data for TICK-NYSEMKT starting at 2022-10-24 05:39:19.000000 | 2022-10-24 06:38:47.027
Socket (1) | CloseSocket call. | 2022-10-24 06:38:47.031
Socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:47.031
Historical data download thread signaled to stop. | 2022-10-24 06:38:47.031
HD Request # 5 | Timestamp of first Intraday data file record written: 2022-10-24 05:39:19.000000. | 2022-10-24 06:38:47.032
HD Request # 5 | Received 3530 Intraday data records from 2022-10-24 05:39:19.000000 to 2022-10-24 06:38:47.000000 (59.5 minutes) and wrote 3530 records for TICK-NYSEMKT | 2022-10-24 06:38:47.032
HD Request # 5 | Completion time: 2s. | 2022-10-24 06:38:47.032
HD Request # 5 | Intraday data download complete for TICK-NYSEMKT. Unique request ID: 5 | 2022-10-24 06:38:47.032
Removing historical data download ID 5. | 2022-10-24 06:38:47.032
HD Request # 5 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:38:47.032
Triggering next historical data download in queue. | 2022-10-24 06:38:47.032
Historical data for TICK-NYSEMKT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:38:47.032
HD Request # 6 | Downloading Intraday chart data for NVOL24H-NYSEMKT to the file NVOL24H-NYSEMKT.scid. Service: statscalc | 2022-10-24 06:38:47.032
HD Request # 6 | Download start date-time: 2022-10-24 05:39:19.000000. File last date-time: 2022-10-24 05:39:19.000000 | 2022-10-24 06:38:47.033
HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2022-10-24 06:38:47.033
Socket (2) | Creating socket. | 2022-10-24 06:38:47.068
Socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:38:47.068
Socket (2) | Connecting to IP: 142.215.18.105. | 2022-10-24 06:38:47.068
Socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:38:47.117
Socket (1) | Closed. | 2022-10-24 06:38:47.117
HD Request # 6 | Setting DTC encoding to Binary VLS | 2022-10-24 06:38:47.157
HD Request # 6 | Sending historical data logon request message. | 2022-10-24 06:38:47.157
HD Request # 6 | Requesting Intraday data. Start date-time: 2022-10-24 05:39:19. Record interval: 1. Symbol: NVOL24H-NYSEMKT | 2022-10-24 06:38:47.705
HD Request # 6 | Decompressing data. | 2022-10-24 06:38:47.802
HD Request # 6 | Receiving Intraday data for NVOL24H-NYSEMKT starting at 2022-10-24 05:39:19.000000 | 2022-10-24 06:38:47.885
Socket (2) | CloseSocket call. | 2022-10-24 06:38:47.888
Historical data download thread signaled to stop. | 2022-10-24 06:38:47.888
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:47.888
HD Request # 6 | Timestamp of first Intraday data file record written: 2022-10-24 05:39:19.000000. | 2022-10-24 06:38:47.889
HD Request # 6 | Received 3530 Intraday data records from 2022-10-24 05:39:19.000000 to 2022-10-24 06:38:47.000000 (59.5 minutes) and wrote 3530 records for NVOL24H-NYSEMKT | 2022-10-24 06:38:47.889
HD Request # 6 | Completion time: 0s. | 2022-10-24 06:38:47.889
HD Request # 6 | Intraday data download complete for NVOL24H-NYSEMKT. Unique request ID: 6 | 2022-10-24 06:38:47.889
Removing historical data download ID 6. | 2022-10-24 06:38:47.889
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:38:47.889
Triggering next historical data download in queue. | 2022-10-24 06:38:47.889
Historical data for NVOL24H-NYSEMKT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:38:47.889
No download requests in the queue to start downloads for. | 2022-10-24 06:38:47.889
Socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:38:47.928
Socket (2) | Closed. | 2022-10-24 06:38:47.928
Chart #6 has tagged chart #4 for full recalculation. Chartbook: APEX.Cht | 2022-10-24 06:38:48.383
TICK-NYSE[M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: APEX.Cht | 2022-10-24 06:38:48.771
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-24 06:38:49.007
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-24 06:38:49.010
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-24 06:38:49.011
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:38:49.011
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-24 06:38:49.012
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-24 06:38:49.054
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-24 06:38:49.054
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-24 06:38:49.055
Rithmic Direct - DTC | Sending logon request message. | 2022-10-24 06:38:49.055
Rithmic Direct - DTC | Received logon response. | 2022-10-24 06:38:49.188
Rithmic Direct - DTC | Server Name: . | 2022-10-24 06:38:49.188
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-24 06:38:49.188
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-24 06:38:49.188
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:38:49.188
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:38:49.188
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-24 06:38:49.212
DTC Client socket (1) | CloseSocket call. | 2022-10-24 06:38:49.212
Rithmic Direct - DTC | Disconnected. | 2022-10-24 06:38:49.212
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:38:49.212
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:49.212
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:38:49.253
DTC Client socket (1) | Closed. | 2022-10-24 06:38:49.253
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-24 06:38:53.216
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-24 06:38:53.219
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-24 06:38:53.220
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:38:53.220
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-24 06:38:53.220
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-24 06:38:53.266
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-24 06:38:53.266
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-24 06:38:53.266
Rithmic Direct - DTC | Sending logon request message. | 2022-10-24 06:38:53.266
Rithmic Direct - DTC | Received logon response. | 2022-10-24 06:38:53.399
Rithmic Direct - DTC | Server Name: . | 2022-10-24 06:38:53.399
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-24 06:38:53.399
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-24 06:38:53.399
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:38:53.399
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:38:53.399
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-24 06:38:53.418
DTC Client socket (1) | CloseSocket call. | 2022-10-24 06:38:53.419
Rithmic Direct - DTC | Disconnected. | 2022-10-24 06:38:53.419
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:38:53.419
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:53.419
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:38:53.459
DTC Client socket (1) | Closed. | 2022-10-24 06:38:53.459
NVOL24H-NYSEMKT 1 Min #4 | Reloading chart. | 2022-10-24 06:38:55.126
NVOL24H-NYSE_NASDAQ_NYSEMKT 1 Min #5 | Reloading chart. | 2022-10-24 06:38:55.242
TICK-NYSEMKT 1 Min #6 | Reloading chart. | 2022-10-24 06:38:55.344
ESU22_FUT_CME 60 Min #1 | Reloading chart. | 2022-10-24 06:38:55.594
MESU22_FUT_CME 1 Min #2 | Reloading chart. | 2022-10-24 06:38:56.011
ESU22_FUT_CME 5 Min #3 | Reloading chart. | 2022-10-24 06:38:56.794
Chart #4 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:38:57.645
Added historical Intraday data request for NVOL24H-NYSE_NASDAQ_NYSEMKT to the queue. | 2022-10-24 06:38:57.675
Intraday data recording state for symbol NVOL24H-NYSE_NASDAQ_NYSEMKT is set to download 'Pending'. | 2022-10-24 06:38:57.675
Triggering next historical data download in queue. | 2022-10-24 06:38:57.675
HD Request # 7 | Downloading Intraday chart data for NVOL24H-NYSE_NASDAQ_NYSEMKT to the file NVOL24H-NYSE_NASDAQ_NYSEMKT.scid. Service: statscalc | 2022-10-24 06:38:57.676
HD Request # 7 | Download start date-time: 2022-09-13 18:23:14.000000. File last date-time: 2022-09-13 18:23:14.000000 | 2022-10-24 06:38:57.676
HD Request # 7 | Using server: ds12.sierracharts.com port 10150 | 2022-10-24 06:38:57.676
Socket (1) | Creating socket. | 2022-10-24 06:38:57.676
Socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:38:57.677
Socket (1) | Connecting to IP: 142.215.18.104. | 2022-10-24 06:38:57.677
MESU22_FUT_CME 1 Min #2 | StartDateTimeForLoadingOrderFills: 2022-08-14 18:00:00 | 2022-10-24 06:38:57.699
HD Request # 7 | Setting DTC encoding to Binary VLS | 2022-10-24 06:38:57.764
HD Request # 7 | Sending historical data logon request message. | 2022-10-24 06:38:57.764
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:38:57.805
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-24 06:38:57.868
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-24 06:38:57.869
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-24 06:38:57.870
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:38:57.870
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-24 06:38:57.870
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-24 06:38:57.904
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-24 06:38:57.911
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-24 06:38:57.911
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-24 06:38:57.911
Rithmic Direct - DTC | Sending logon request message. | 2022-10-24 06:38:57.911
Rithmic Direct - DTC | Received logon response. | 2022-10-24 06:38:58.045
Rithmic Direct - DTC | Server Name: . | 2022-10-24 06:38:58.045
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-24 06:38:58.045
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-24 06:38:58.045
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:38:58.045
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:38:58.045
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-24 06:38:58.068
DTC Client socket (2) | CloseSocket call. | 2022-10-24 06:38:58.068
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:38:58.069
Rithmic Direct - DTC | Disconnected. | 2022-10-24 06:38:58.069
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:38:58.069
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:38:58.107
DTC Client socket (2) | Closed. | 2022-10-24 06:38:58.108
HD Request # 7 | Requesting Intraday data. Start date-time: 2022-09-13 18:23:14. Record interval: 1. Symbol: NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-24 06:38:58.317
HD Request # 7 | Decompressing data. | 2022-10-24 06:38:58.356
HD Request # 7 | Receiving Intraday data for NVOL24H-NYSE_NASDAQ_NYSEMKT starting at 2022-09-13 18:23:14.000000 | 2022-10-24 06:38:58.543
HD Request # 7 | Timestamp of first Intraday data file record written: 2022-09-13 18:23:14.000000. | 2022-10-24 06:38:58.747
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-24 06:39:02.069
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-24 06:39:02.070
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-24 06:39:02.070
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:39:02.070
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-24 06:39:02.070
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-24 06:39:02.113
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-24 06:39:02.113
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-24 06:39:02.114
Rithmic Direct - DTC | Sending logon request message. | 2022-10-24 06:39:02.114
Rithmic Direct - DTC | Received logon response. | 2022-10-24 06:39:02.255
Rithmic Direct - DTC | Server Name: . | 2022-10-24 06:39:02.255
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-24 06:39:02.255
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-24 06:39:02.255
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:39:02.255
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:39:02.255
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-24 06:39:02.290
DTC Client socket (2) | CloseSocket call. | 2022-10-24 06:39:02.290
Rithmic Direct - DTC | Disconnected. | 2022-10-24 06:39:02.290
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:39:02.290
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:39:02.290
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:39:02.331
DTC Client socket (2) | Closed. | 2022-10-24 06:39:02.331
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-24 06:39:06.287
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-24 06:39:06.288
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-24 06:39:06.288
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:39:06.288
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-24 06:39:06.288
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-24 06:39:06.327
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-24 06:39:06.327
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-24 06:39:06.328
Rithmic Direct - DTC | Sending logon request message. | 2022-10-24 06:39:06.328
Rithmic Direct - DTC | Received logon response. | 2022-10-24 06:39:06.466
Rithmic Direct - DTC | Server Name: . | 2022-10-24 06:39:06.466
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-24 06:39:06.466
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-24 06:39:06.466
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:39:06.466
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:39:06.466
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-24 06:39:06.500
DTC Client socket (2) | CloseSocket call. | 2022-10-24 06:39:06.500
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:39:06.501
Rithmic Direct - DTC | Disconnected. | 2022-10-24 06:39:06.501
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:39:06.501
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:39:06.545
DTC Client socket (2) | Closed. | 2022-10-24 06:39:06.545
Socket (1) | CloseSocket call. | 2022-10-24 06:39:07.562
Historical data download thread signaled to stop. | 2022-10-24 06:39:07.562
Socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:39:07.563
Socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:39:07.601
Socket (1) | Closed. | 2022-10-24 06:39:07.602
HD Request # 7 | Received 1608480 Intraday data records from 2022-09-13 18:23:14.000000 to 2022-10-24 06:38:59.000000 (40.5 days) and wrote 1608480 records for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-24 06:39:07.782
HD Request # 7 | Completion time: 10s. | 2022-10-24 06:39:07.942
HD Request # 7 | Intraday data download complete for NVOL24H-NYSE_NASDAQ_NYSEMKT. Unique request ID: 7 | 2022-10-24 06:39:07.942
Removing historical data download ID 7. | 2022-10-24 06:39:07.942
HD Request # 7 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:39:07.942
Triggering next historical data download in queue. | 2022-10-24 06:39:07.942
Historical data for NVOL24H-NYSE_NASDAQ_NYSEMKT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:39:07.942
No download requests in the queue to start downloads for. | 2022-10-24 06:39:07.942
File >> Disconnect selected. | 2022-10-24 06:39:10.009
DTC Client socket (0) | CloseSocket call. | 2022-10-24 06:39:10.009
Rithmic Direct - DTC | Disconnected. | 2022-10-24 06:39:10.009
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2022-10-24 06:39:36.295
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2022-10-24 06:39:36.295
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 38.79.0.89. | 2022-10-24 06:39:36.295
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2022-10-24 06:39:36.539
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call. | 2022-10-24 06:39:36.541
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:39:36.542
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed. | 2022-10-24 06:39:36.542
Symbol settings could not be loaded because there are no applicable files to load. | 2022-10-24 06:42:22.351
Requested symbol settings for service code oec. Request ID: 2. | 2022-10-24 06:42:22.351
Current selected Data/Trading service: GAIN Capital/OEC | 2022-10-24 06:42:22.354
Symbol settings received. Request ID: 2. | 2022-10-24 06:42:25.045
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:32.539
Enabling compression for file: C:\SierraChart\Data\ESZ22.scid. This may take a while. | 2022-10-24 06:42:32.615
File compression enabled. C:\SierraChart\Data\ESZ22.scid. CompressionState=0 | 2022-10-24 06:42:32.615
ESZ22[M] 1 Min #2 | Reloading chart. | 2022-10-24 06:42:32.617
ESZ22[M] 1 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ22.scid | 2022-10-24 06:42:32.619
Enabling compression for file: C:\SierraChart\Data\NQU22.scid. This may take a while. | 2022-10-24 06:42:32.619
File compression enabled. C:\SierraChart\Data\NQU22.scid. CompressionState=0 | 2022-10-24 06:42:32.619
NQU22[M] 1 Min #3 | Reloading chart. | 2022-10-24 06:42:32.620
Enabling compression for file: C:\SierraChart\Data\ESU22.scid. This may take a while. | 2022-10-24 06:42:32.623
File compression enabled. C:\SierraChart\Data\ESU22.scid. CompressionState=0 | 2022-10-24 06:42:32.623
ESU22 60 Min #1 | Reloading chart. | 2022-10-24 06:42:32.624
NQU22[M] 1 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\NQU22.scid | 2022-10-24 06:42:32.628
ESU22 60 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU22.scid | 2022-10-24 06:42:32.629
Chart #4 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:42:32.630
ESZ22[M] 60 Min #7 | Reloading chart. | 2022-10-24 06:42:32.764
ESZ22[M] 60 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ22.scid | 2022-10-24 06:42:32.766
ESU22 5 Min #3 | Reloading chart. | 2022-10-24 06:42:32.787
ESU22 5 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESU22.scid | 2022-10-24 06:42:32.790
Chart #6 has tagged chart #4 for full recalculation. Chartbook: APEX.Cht | 2022-10-24 06:42:32.888
Enabling compression for file: C:\SierraChart\Data\MESZ22.scid. This may take a while. | 2022-10-24 06:42:32.934
File compression enabled. C:\SierraChart\Data\MESZ22.scid. CompressionState=0 | 2022-10-24 06:42:32.934
MESZ22[M] 1 Min #1 | Reloading chart. | 2022-10-24 06:42:32.935
MESZ22[M] 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESZ22.scid | 2022-10-24 06:42:32.936
Enabling compression for file: C:\SierraChart\Data\MESU22.scid. This may take a while. | 2022-10-24 06:42:33.007
File compression enabled. C:\SierraChart\Data\MESU22.scid. CompressionState=0 | 2022-10-24 06:42:33.007
MESU22 1 Min #2 | Reloading chart. | 2022-10-24 06:42:33.008
MESU22 1 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESU22.scid | 2022-10-24 06:42:33.012
Mapping ESU22 to ESU22. Service code: cme | 2022-10-24 06:42:33.115
Added historical Intraday data request for ESU22 to the queue. | 2022-10-24 06:42:33.115
Intraday data recording state for symbol ESU22 is set to download 'Pending'. | 2022-10-24 06:42:33.115
Triggering next historical data download in queue. | 2022-10-24 06:42:33.115
HD Request # 8 | Downloading Intraday chart data for ESU22 to the file ESU22.scid. Service: cme | 2022-10-24 06:42:33.116
HD Request # 8 | Download start date-time: 2022-03-28 19:59:59.000000. File last date-time: 00:00:00.000000 | 2022-10-24 06:42:33.116
HD Request # 8 | Using server: ds21.sierracharts.com port 10149 | 2022-10-24 06:42:33.116
Socket (1) | Creating socket. | 2022-10-24 06:42:33.116
Socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:42:33.116
Socket (1) | Connecting to IP: 216.1.90.129. | 2022-10-24 06:42:33.116
Mapping NQU22 to NQU22. Service code: cme | 2022-10-24 06:42:33.117
Added historical Intraday data request for NQU22 to the queue. | 2022-10-24 06:42:33.117
Intraday data recording state for symbol NQU22 is set to download 'Pending'. | 2022-10-24 06:42:33.117
Triggering next historical data download in queue. | 2022-10-24 06:42:33.117
Mapping ESZ22 to ESZ22. Service code: cme | 2022-10-24 06:42:33.117
Added historical Intraday data request for ESZ22 to the queue. | 2022-10-24 06:42:33.117
Intraday data recording state for symbol ESZ22 is set to download 'Pending'. | 2022-10-24 06:42:33.117
HD Request # 8 | Setting DTC encoding to Binary VLS | 2022-10-24 06:42:33.205
HD Request # 8 | Sending historical data logon request message. | 2022-10-24 06:42:33.205
TICK-NYSE[M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: APEX.Cht | 2022-10-24 06:42:33.270
Mapping MESZ22 to MESZ22. Service code: cme | 2022-10-24 06:42:33.429
Added historical Intraday data request for MESZ22 to the queue. | 2022-10-24 06:42:33.429
Intraday data recording state for symbol MESZ22 is set to download 'Pending'. | 2022-10-24 06:42:33.429
Triggering next historical data download in queue. | 2022-10-24 06:42:33.429
Mapping MESU22 to MESU22. Service code: cme | 2022-10-24 06:42:33.506
Added historical Intraday data request for MESU22 to the queue. | 2022-10-24 06:42:33.506
Intraday data recording state for symbol MESU22 is set to download 'Pending'. | 2022-10-24 06:42:33.506
Triggering next historical data download in queue. | 2022-10-24 06:42:33.506
HD Request # 8 | Requesting Intraday data. Start date-time: 2022-03-28 19:59:59. Record interval: 1. Symbol: ESU22 | 2022-10-24 06:42:33.727
HD Request # 8 | Decompressing data. | 2022-10-24 06:42:33.769
HD Request # 8 | Receiving Intraday data for ESU22 starting at 2022-03-28 20:02:06.212000 | 2022-10-24 06:42:33.875
HD Request # 8 | Timestamp of first Intraday data file record written: 2022-03-28 20:02:06.212000. | 2022-10-24 06:42:34.039
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:42:35.653
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:42:35.749
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:42:35.749
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:42:35.749
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:42:35.827
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:42:36.026
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:42:36.069
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:42:36.069
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:42:36.069
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:42:36.069
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:36.069
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:42:36.069
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:42:36.069
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:42:36.069
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:42:36.092
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:42:36.093
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:36.093
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:42:39.090
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:42:39.091
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:42:39.091
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:42:39.091
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:42:39.132
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:42:39.337
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:42:39.376
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:42:39.376
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:42:39.376
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:42:39.376
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:39.376
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:42:39.376
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:42:39.376
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:42:39.376
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:42:39.378
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:42:39.378
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:39.378
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:42:42.380
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:42:42.381
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:42:42.381
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:42:42.381
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:42:42.423
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:42:42.612
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:42:42.651
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:42:42.651
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:42:42.651
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:42:42.651
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:42.651
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:42:42.651
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:42:42.651
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:42:42.651
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:42:42.661
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:42:42.661
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:42.661
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:42:45.660
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:42:45.660
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:42:45.660
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:42:45.660
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:42:45.700
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:42:45.894
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:42:45.933
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:42:45.933
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:42:45.933
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:42:45.933
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:45.933
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:42:45.933
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:42:45.933
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:42:45.933
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:42:45.940
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:42:45.940
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:45.940
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:42:48.998
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:42:49.000
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:42:49.000
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:42:49.000
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:42:49.039
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:42:49.239
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:42:49.277
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:42:49.277
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:42:49.277
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:42:49.277
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:49.277
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:42:49.278
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:42:49.278
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:42:49.278
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:42:49.289
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:42:49.290
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:49.290
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:42:52.288
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:42:52.289
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:42:52.289
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:42:52.289
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:42:52.329
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:42:52.520
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:42:52.559
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:42:52.559
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:42:52.559
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:42:52.559
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:52.559
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:42:52.559
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:42:52.559
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:42:52.560
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:42:52.567
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:42:52.567
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:52.567
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:42:55.572
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:42:55.573
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:42:55.574
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:42:55.574
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:42:55.612
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:42:55.821
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:42:55.863
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:42:55.863
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:42:55.863
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:42:55.863
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:55.863
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:42:55.863
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:42:55.863
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:42:55.863
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:42:55.883
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:42:55.884
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:55.884
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:42:58.879
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:42:58.879
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:42:58.879
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:42:58.879
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:42:58.922
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:42:59.125
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:42:59.164
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:42:59.165
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:42:59.165
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:42:59.165
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:59.165
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:42:59.165
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:42:59.165
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:42:59.165
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:42:59.178
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:42:59.178
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:42:59.178
Socket (1) | CloseSocket call. | 2022-10-24 06:42:59.976
Historical data download thread signaled to stop. | 2022-10-24 06:42:59.976
Socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:42:59.976
HD Request # 8 | Received 3398424 Intraday data records from 2022-03-28 20:02:06.212000 to 2022-09-16 09:29:59.317000 (171.6 days) and wrote 3398424 records for ESU22 | 2022-10-24 06:42:59.976
HD Request # 8 | Completion time: 26s. | 2022-10-24 06:42:59.976
HD Request # 8 | Intraday data download complete for ESU22. Unique request ID: 8 | 2022-10-24 06:42:59.976
Removing historical data download ID 8. | 2022-10-24 06:42:59.976
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:42:59.976
Triggering next historical data download in queue. | 2022-10-24 06:42:59.976
Historical data for ESU22 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:42:59.976
HD Request # 9 | Downloading Intraday chart data for NQU22 to the file NQU22.scid. Service: cme | 2022-10-24 06:42:59.976
HD Request # 9 | Download start date-time: 2022-03-28 19:59:59.000000. File last date-time: 00:00:00.000000 | 2022-10-24 06:42:59.977
HD Request # 9 | Using server: ds26.sierracharts.com port 10150 | 2022-10-24 06:42:59.977
Socket (2) | Creating socket. | 2022-10-24 06:42:59.977
Socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:42:59.977
Socket (2) | Connecting to IP: 142.215.18.107. | 2022-10-24 06:42:59.977
Socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:00.018
Socket (1) | Closed. | 2022-10-24 06:43:00.018
HD Request # 9 | Setting DTC encoding to Binary VLS | 2022-10-24 06:43:00.059
HD Request # 9 | Sending historical data logon request message. | 2022-10-24 06:43:00.059
HD Request # 9 | Requesting Intraday data. Start date-time: 2022-03-28 19:59:59. Record interval: 1. Symbol: NQU22 | 2022-10-24 06:43:00.619
HD Request # 9 | Decompressing data. | 2022-10-24 06:43:00.662
HD Request # 9 | Receiving Intraday data for NQU22 starting at 2022-03-28 20:10:31.691000 | 2022-10-24 06:43:00.801
HD Request # 9 | Timestamp of first Intraday data file record written: 2022-03-28 20:10:31.691000. | 2022-10-24 06:43:00.981
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:02.181
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:02.181
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:02.181
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:02.181
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:02.221
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:02.413
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:02.451
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:02.452
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:02.452
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:02.452
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:02.452
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:02.452
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:02.452
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:02.452
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:02.462
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:02.463
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:02.463
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:05.460
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:05.553
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:05.553
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:05.553
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:05.591
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:05.790
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:05.830
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:05.830
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:05.830
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:05.830
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:05.830
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:05.830
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:05.830
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:05.830
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:05.836
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:05.836
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:05.836
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:08.839
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:08.840
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:08.840
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:08.840
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:08.877
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:09.073
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:09.115
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:09.115
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:09.115
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:09.115
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:09.115
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:09.115
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:09.115
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:09.115
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:09.135
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:09.135
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:09.135
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:12.130
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:12.131
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:12.131
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:12.131
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:12.169
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:12.363
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:12.404
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:12.404
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:12.404
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:12.404
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:12.404
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:12.404
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:12.404
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:12.404
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:12.411
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:12.411
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:12.411
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:15.416
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:15.416
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:15.417
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:15.417
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:15.457
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:15.664
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:15.709
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:15.709
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:15.709
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:15.709
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:15.709
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:15.709
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:15.709
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:15.709
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:15.725
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:15.726
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:15.726
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:18.726
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:18.727
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:18.727
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:18.727
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:18.765
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:18.960
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:19.000
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:19.000
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:19.000
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:19.000
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:19.000
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:19.000
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:19.000
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:19.000
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:19.010
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:19.010
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:19.010
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:22.008
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:22.009
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:22.009
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:22.009
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:22.047
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:22.238
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:22.276
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:22.276
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:22.276
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:22.276
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:22.276
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:22.276
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:22.276
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:22.276
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:22.288
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:22.288
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:22.288
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:25.287
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:25.287
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:25.287
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:25.287
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:25.326
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:25.520
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:25.561
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:25.561
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:25.561
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:25.561
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:25.561
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:25.561
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:25.561
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:25.561
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:25.570
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:25.570
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:25.570
Socket (2) | CloseSocket call. | 2022-10-24 06:43:27.220
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:43:27.220
Historical data download thread signaled to stop. | 2022-10-24 06:43:27.220
HD Request # 9 | Received 3458347 Intraday data records from 2022-03-28 20:10:31.691000 to 2022-09-16 09:29:59.046000 (171.6 days) and wrote 3458347 records for NQU22 | 2022-10-24 06:43:27.221
HD Request # 9 | Completion time: 28s. | 2022-10-24 06:43:27.221
HD Request # 9 | Intraday data download complete for NQU22. Unique request ID: 9 | 2022-10-24 06:43:27.221
Removing historical data download ID 9. | 2022-10-24 06:43:27.221
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:43:27.221
Triggering next historical data download in queue. | 2022-10-24 06:43:27.221
Historical data for NQU22 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:43:27.221
HD Request # 10 | Downloading Intraday chart data for ESZ22 to the file ESZ22.scid. Service: cme | 2022-10-24 06:43:27.221
HD Request # 10 | Download start date-time: 2022-04-21 06:43:27.000000. File last date-time: 00:00:00.000000 | 2022-10-24 06:43:27.221
HD Request # 10 | Using server: ds21.sierracharts.com port 10149 | 2022-10-24 06:43:27.221
Socket (1) | Creating socket. | 2022-10-24 06:43:27.221
Socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:27.221
Socket (1) | Connecting to IP: 216.1.90.129. | 2022-10-24 06:43:27.221
Socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:43:27.258
Socket (2) | Closed. | 2022-10-24 06:43:27.258
HD Request # 10 | Setting DTC encoding to Binary VLS | 2022-10-24 06:43:27.320
HD Request # 10 | Sending historical data logon request message. | 2022-10-24 06:43:27.320
HD Request # 10 | Requesting Intraday data. Start date-time: 2022-04-21 06:43:27. Record interval: 1. Symbol: ESZ22 | 2022-10-24 06:43:27.846
HD Request # 10 | Decompressing data. | 2022-10-24 06:43:27.892
HD Request # 10 | Receiving Intraday data for ESZ22 starting at 2022-04-21 08:01:36.861000 | 2022-10-24 06:43:27.992
HD Request # 10 | Timestamp of first Intraday data file record written: 2022-04-21 08:01:36.861000. | 2022-10-24 06:43:28.212
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:28.572
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:43:28.572
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:43:28.572
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:28.572
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:28.611
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:28.805
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:43:28.843
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:43:28.843
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:28.843
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:28.843
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:28.843
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:28.843
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:28.843
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:43:28.843
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:28.855
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:28.856
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:28.856
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:31.856
GAIN Capital FIX Trading socket (3) | Creating socket. | 2022-10-24 06:43:31.857
GAIN Capital FIX Trading socket (3) | New receive buffer size: 5242880 | 2022-10-24 06:43:31.858
GAIN Capital FIX Trading socket (3) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:31.858
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:31.898
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:32.104
GAIN Capital FIX Trading socket (3) | Socket gracefully closed by remote side. | 2022-10-24 06:43:32.150
GAIN Capital FIX Trading socket (3) | CloseSocket call. | 2022-10-24 06:43:32.150
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:32.150
GAIN Capital FIX Trading socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:32.150
GAIN Capital FIX Trading socket (3) | Closed. | 2022-10-24 06:43:32.150
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:32.150
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:32.150
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:32.150
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:32.161
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:32.161
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:32.161
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:35.162
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:43:35.162
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:43:35.162
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:35.162
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:35.204
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:35.394
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:43:35.433
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:43:35.433
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:35.433
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:35.433
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:35.433
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:35.433
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:35.433
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:43:35.433
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:35.441
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:35.441
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:35.441
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:38.441
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:43:38.540
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:43:38.540
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:38.540
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:38.586
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:38.788
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:43:38.827
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:43:38.827
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:38.827
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:38.827
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:38.827
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:38.827
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:38.827
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:43:38.827
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:38.836
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:38.836
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:38.836
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:41.839
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:43:41.840
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:43:41.840
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:41.840
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:41.880
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:42.086
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:43:42.124
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:43:42.124
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:42.124
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:42.124
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:42.124
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:42.124
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:42.124
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:43:42.124
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:42.132
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:42.132
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:42.132
Socket (1) | CloseSocket call. | 2022-10-24 06:43:45.038
Historical data download thread signaled to stop. | 2022-10-24 06:43:45.038
Socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:43:45.038
HD Request # 10 | Received 1841787 Intraday data records from 2022-04-21 08:01:36.861000 to 2022-10-24 06:43:44.093000 (185.9 days) and wrote 1841787 records for ESZ22 | 2022-10-24 06:43:45.038
HD Request # 10 | Completion time: 18s. | 2022-10-24 06:43:45.038
HD Request # 10 | Intraday data download complete for ESZ22. Unique request ID: 10 | 2022-10-24 06:43:45.038
Removing historical data download ID 10. | 2022-10-24 06:43:45.038
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:43:45.038
Triggering next historical data download in queue. | 2022-10-24 06:43:45.038
Historical data for ESZ22 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:43:45.038
HD Request # 11 | Downloading Intraday chart data for MESZ22 to the file MESZ22.scid. Service: cme | 2022-10-24 06:43:45.038
HD Request # 11 | Download start date-time: 2022-04-21 06:43:45.000000. File last date-time: 00:00:00.000000 | 2022-10-24 06:43:45.038
HD Request # 11 | Using server: ds26.sierracharts.com port 10150 | 2022-10-24 06:43:45.038
Socket (2) | Creating socket. | 2022-10-24 06:43:45.038
Socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:43:45.038
Socket (2) | Connecting to IP: 142.215.18.107. | 2022-10-24 06:43:45.038
Socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:45.083
Socket (1) | Closed. | 2022-10-24 06:43:45.083
HD Request # 11 | Setting DTC encoding to Binary VLS | 2022-10-24 06:43:45.123
HD Request # 11 | Sending historical data logon request message. | 2022-10-24 06:43:45.123
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:45.142
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:45.143
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:45.143
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:45.143
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:45.184
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:45.378
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:45.416
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:45.416
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:45.416
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:45.416
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:45.416
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:45.416
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:45.416
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:45.416
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:45.426
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:45.426
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:45.426
HD Request # 11 | Requesting Intraday data. Start date-time: 2022-04-21 06:43:45. Record interval: 1. Symbol: MESZ22 | 2022-10-24 06:43:45.678
HD Request # 11 | Decompressing data. | 2022-10-24 06:43:45.720
HD Request # 11 | Receiving Intraday data for MESZ22 starting at 2022-04-21 07:52:49.023000 | 2022-10-24 06:43:45.852
HD Request # 11 | Timestamp of first Intraday data file record written: 2022-04-21 07:52:49.023000. | 2022-10-24 06:43:46.014
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:48.435
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:48.436
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:48.436
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:48.436
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:48.479
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:48.678
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:48.716
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:48.716
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:48.716
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:48.716
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:48.716
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:48.716
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:48.717
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:48.717
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:48.727
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:48.727
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:48.727
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:51.723
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:51.724
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:51.724
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:51.724
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:51.764
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:51.964
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:52.003
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:52.003
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:52.003
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:52.003
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:52.003
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:52.003
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:52.003
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:52.003
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:52.021
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:52.022
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:52.022
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:55.027
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:55.028
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:55.028
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:55.028
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:55.068
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:55.271
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:55.309
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:55.310
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:55.310
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:55.310
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:55.310
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:55.310
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:55.310
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:55.310
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:55.316
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:55.317
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:55.317
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:43:58.319
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:43:58.319
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:43:58.319
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:43:58.319
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:43:58.363
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:43:58.566
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:43:58.604
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:43:58.605
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:43:58.605
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:43:58.605
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:58.605
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:43:58.605
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:43:58.605
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:43:58.605
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:43:58.614
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:43:58.614
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:43:58.614
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:01.614
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:01.614
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:01.614
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:01.614
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:01.656
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:01.855
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:01.894
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:01.894
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:01.894
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:01.894
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:01.894
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:01.894
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:01.894
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:01.894
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:01.921
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:01.921
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:01.921
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:04.915
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:04.916
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:04.916
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:04.916
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:04.955
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:05.146
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:05.186
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:05.186
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:05.186
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:05.186
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:05.186
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:05.186
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:05.186
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:05.186
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:05.194
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:05.194
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:05.194
Socket (2) | CloseSocket call. | 2022-10-24 06:44:06.028
Historical data download thread signaled to stop. | 2022-10-24 06:44:06.028
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:44:06.028
HD Request # 11 | Received 1873869 Intraday data records from 2022-04-21 07:52:49.023000 to 2022-10-24 06:44:03.723000 (186.0 days) and wrote 1873869 records for MESZ22 | 2022-10-24 06:44:06.028
HD Request # 11 | Completion time: 21s. | 2022-10-24 06:44:06.028
HD Request # 11 | Intraday data download complete for MESZ22. Unique request ID: 11 | 2022-10-24 06:44:06.028
Removing historical data download ID 11. | 2022-10-24 06:44:06.028
HD Request # 11 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:44:06.028
Triggering next historical data download in queue. | 2022-10-24 06:44:06.028
Historical data for MESZ22 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:44:06.028
HD Request # 12 | Downloading Intraday chart data for MESU22 to the file MESU22.scid. Service: cme | 2022-10-24 06:44:06.028
HD Request # 12 | Download start date-time: 2022-03-28 19:59:59.000000. File last date-time: 00:00:00.000000 | 2022-10-24 06:44:06.029
HD Request # 12 | Using server: ds21.sierracharts.com port 10149 | 2022-10-24 06:44:06.029
Socket (1) | Creating socket. | 2022-10-24 06:44:06.029
Socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:06.029
Socket (1) | Connecting to IP: 216.1.90.129. | 2022-10-24 06:44:06.029
Socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:44:06.070
Socket (2) | Closed. | 2022-10-24 06:44:06.070
HD Request # 12 | Setting DTC encoding to Binary VLS | 2022-10-24 06:44:06.115
HD Request # 12 | Sending historical data logon request message. | 2022-10-24 06:44:06.115
HD Request # 12 | Requesting Intraday data. Start date-time: 2022-03-28 19:59:59. Record interval: 1. Symbol: MESU22 | 2022-10-24 06:44:06.641
HD Request # 12 | Decompressing data. | 2022-10-24 06:44:06.685
HD Request # 12 | Receiving Intraday data for MESU22 starting at 2022-03-28 20:04:55.889000 | 2022-10-24 06:44:06.781
HD Request # 12 | Timestamp of first Intraday data file record written: 2022-03-28 20:04:55.889000. | 2022-10-24 06:44:06.991
MESU22[M] 1 Min #2 | StartDateTimeForLoadingOrderFills: 2022-03-28 20:04:00 | 2022-10-24 06:44:07.040
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:44:07.049
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-24 06:44:07.342
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:08.192
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:44:08.192
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:44:08.192
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:08.192
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:08.234
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:08.425
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:44:08.467
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:44:08.467
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:08.467
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:08.467
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:08.467
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:08.467
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:08.467
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:44:08.467
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:08.473
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:08.473
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:08.473
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:11.485
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:44:11.576
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:44:11.576
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:11.576
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:11.615
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:11.822
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:44:11.861
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:44:11.861
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:11.861
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:11.861
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:11.861
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:11.861
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:11.861
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:44:11.861
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:11.873
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:11.873
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:11.873
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:14.872
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:44:14.872
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:44:14.872
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:14.872
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:14.916
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:15.120
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:44:15.164
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:44:15.164
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:15.164
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:15.164
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:15.164
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:15.164
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:15.164
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:44:15.164
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:15.185
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:15.185
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:15.185
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:18.189
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:44:18.189
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:44:18.189
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:18.189
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:18.227
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:18.436
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:44:18.476
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:44:18.477
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:18.477
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:18.477
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:18.477
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:18.477
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:18.477
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:44:18.477
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:18.488
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:18.489
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:18.489
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:21.494
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:44:21.495
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:44:21.495
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:21.495
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:21.696
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:21.906
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:44:21.944
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:44:21.944
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:21.944
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:21.944
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:21.944
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:21.944
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:21.945
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:44:21.945
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:21.958
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:21.958
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:21.958
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:24.961
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:44:24.961
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:44:24.961
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:24.961
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:25.000
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:25.204
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:44:25.242
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:44:25.242
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:25.242
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:25.242
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:25.242
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:25.242
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:25.242
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:44:25.242
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:25.261
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:25.261
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:25.261
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:28.258
GAIN Capital FIX Trading socket (2) | Creating socket. | 2022-10-24 06:44:28.258
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:44:28.258
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:28.258
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:28.301
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:28.507
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2022-10-24 06:44:28.545
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2022-10-24 06:44:28.545
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:28.545
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:28.545
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:28.545
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:28.545
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:28.545
GAIN Capital FIX Trading socket (2) | Closed. | 2022-10-24 06:44:28.545
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:28.556
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:28.556
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:28.556
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:31.552
GAIN Capital FIX Trading socket (3) | Creating socket. | 2022-10-24 06:44:31.553
GAIN Capital FIX Trading socket (3) | New receive buffer size: 5242880 | 2022-10-24 06:44:31.553
GAIN Capital FIX Trading socket (3) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:31.553
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:31.592
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:31.784
GAIN Capital FIX Trading socket (3) | Socket gracefully closed by remote side. | 2022-10-24 06:44:31.822
GAIN Capital FIX Trading socket (3) | CloseSocket call. | 2022-10-24 06:44:31.822
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:31.822
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:31.822
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:31.822
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:31.822
GAIN Capital FIX Trading socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:31.822
GAIN Capital FIX Trading socket (3) | Closed. | 2022-10-24 06:44:31.822
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:31.833
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:31.833
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:31.833
Socket (1) | CloseSocket call. | 2022-10-24 06:44:32.610
Socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:44:32.611
Historical data download thread signaled to stop. | 2022-10-24 06:44:32.613
HD Request # 12 | Received 3547163 Intraday data records from 2022-03-28 20:04:55.889000 to 2022-09-16 09:29:59.771000 (171.6 days) and wrote 3547163 records for MESU22 | 2022-10-24 06:44:32.613
HD Request # 12 | Completion time: 26s. | 2022-10-24 06:44:32.613
HD Request # 12 | Intraday data download complete for MESU22. Unique request ID: 12 | 2022-10-24 06:44:32.613
Removing historical data download ID 12. | 2022-10-24 06:44:32.613
HD Request # 12 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:44:32.613
Triggering next historical data download in queue. | 2022-10-24 06:44:32.613
Historical data for MESU22 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-10-24 06:44:32.613
No download requests in the queue to start downloads for. | 2022-10-24 06:44:32.613
Socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:32.649
Socket (1) | Closed. | 2022-10-24 06:44:32.649
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:44:33.025
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-24 06:44:33.334
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:34.839
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:34.839
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:34.839
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:34.839
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:34.878
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:35.071
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:35.114
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:35.114
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:35.114
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:35.114
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:35.114
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:35.114
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:35.114
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:35.114
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:35.135
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:35.135
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:35.135
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:38.139
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:38.140
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:38.141
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:38.141
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:38.187
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:38.386
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:38.426
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:38.426
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:38.426
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:38.426
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:38.426
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:38.426
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:38.426
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:38.426
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:38.446
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:38.447
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:38.447
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:41.443
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:41.448
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:41.448
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:41.448
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:41.488
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:41.695
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:41.737
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:41.738
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:41.738
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:41.738
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:41.738
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:41.738
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:41.738
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:41.738
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:41.755
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:41.756
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:41.756
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:44.755
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:44.848
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:44.848
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:44.848
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:44.887
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:45.082
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:45.122
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:45.122
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:45.122
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:45.122
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:45.122
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:45.122
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:45.123
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:45.123
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:45.129
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:45.130
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:45.130
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:48.139
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:48.140
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:48.140
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:48.140
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:48.179
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:48.389
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:48.429
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:48.429
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:48.429
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:48.429
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:48.429
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:48.429
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:48.429
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:48.429
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:48.451
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:48.451
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:48.451
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:51.441
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:51.442
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:51.442
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:51.442
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:51.481
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:51.675
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:51.716
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:51.716
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:51.716
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:51.716
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:51.716
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:51.716
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:51.716
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:51.716
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:51.722
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:51.722
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:51.723
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:54.724
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:54.724
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:54.724
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:54.724
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:54.765
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:54.957
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:54.996
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:54.996
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:54.996
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:54.996
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:54.996
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:54.996
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:54.996
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:54.996
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:55.004
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:55.005
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:55.005
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:44:58.003
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:44:58.004
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:44:58.004
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:44:58.004
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:44:58.042
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:44:58.239
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:44:58.279
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:44:58.279
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:44:58.279
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:44:58.279
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:44:58.279
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:44:58.280
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:58.280
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:44:58.280
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:44:58.285
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:44:58.285
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:44:58.285
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:45:01.296
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:45:01.297
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:45:01.297
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:45:01.298
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:45:01.342
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:45:01.540
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:45:01.577
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:45:01.577
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:45:01.577
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:45:01.577
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:45:01.577
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:45:01.577
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:45:01.577
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:45:01.577
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:45:01.586
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:45:01.587
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:45:01.587
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:45:04.595
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:45:04.596
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:45:04.596
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:45:04.596
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:45:04.639
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:45:04.839
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:45:04.878
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:45:04.878
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:45:04.878
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:45:04.878
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:45:04.878
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:45:04.878
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:45:04.878
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:45:04.878
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:45:04.905
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:45:04.905
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:45:04.905
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:45:07.903
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:45:07.904
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:45:07.904
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:45:07.904
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:45:07.947
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:45:08.145
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:45:08.183
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:45:08.183
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:45:08.183
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:45:08.183
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:45:08.183
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:45:08.183
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:45:08.183
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:45:08.184
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:45:08.195
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:45:08.195
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:45:08.195
GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2022-10-24 06:45:11.192
GAIN Capital FIX Trading socket (1) | Creating socket. | 2022-10-24 06:45:11.193
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:45:11.193
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2022-10-24 06:45:11.193
GAIN Capital FIX Trading: Connected to FIX server. | 2022-10-24 06:45:11.234
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=. | 2022-10-24 06:45:11.426
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2022-10-24 06:45:11.465
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2022-10-24 06:45:11.465
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2022-10-24 06:45:11.465
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-24 06:45:11.465
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:45:11.465
GAIN Capital/OEC | Disconnected from the trading server. | 2022-10-24 06:45:11.465
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-24 06:45:11.465
GAIN Capital FIX Trading socket (1) | Closed. | 2022-10-24 06:45:11.465
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:45:11.475
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:45:11.475
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:45:11.475
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:45:11.815
GAIN Capital/OEC | Disconnected. | 2022-10-24 06:45:11.815
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2022-10-24 06:45:11.892
WSACleanup called. | 2022-10-24 06:45:11.892
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 3. | 2022-10-24 06:45:11.893
Current selected Data/Trading service: Teton CME Order Routing | 2022-10-24 06:45:11.894
Symbol settings MD5 received. Request ID: 3. | 2022-10-24 06:45:14.044
Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 4. | 2022-10-24 06:45:14.044
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-24 06:45:15.652
ESU22_FUT_CME[M] 5 Min #3 | Reloading chart. | 2022-10-24 06:45:15.793
MESU22_FUT_CME[M] 1 Min #2 | Reloading chart. | 2022-10-24 06:45:16.016
ESU22_FUT_CME[M] 60 Min #1 | Reloading chart. | 2022-10-24 06:45:16.131
Chart #4 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:45:16.133
MESU22_FUT_CME[M] 1 Min #2 | StartDateTimeForLoadingOrderFills: 2022-08-14 18:00:00 | 2022-10-24 06:45:16.266
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:45:16.279
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-24 06:45:16.332
Symbol settings received. Request ID: 4. | 2022-10-24 06:45:16.745
Teton CME Order Routing | Clearing firm: IronBeam | 2022-10-24 06:45:17.653
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11085 | 2022-10-24 06:45:17.653
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-24 06:45:17.687
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-24 06:45:17.688
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-10-24 06:45:17.688
Teton CME Order Routing | Network connection to server complete. | 2022-10-24 06:45:17.731
Teton CME Order Routing | Starting socket receive thread. | 2022-10-24 06:45:17.731
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-10-24 06:45:17.731
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-10-24 06:45:17.872
Teton CME Order Routing | Sending logon request message. | 2022-10-24 06:45:17.872
Teton CME Order Routing | Received logon response. | 2022-10-24 06:45:18.414
Teton CME Order Routing | Server Name: SC DTC Server. Build=43909M. | 2022-10-24 06:45:18.414
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-10-24 06:45:18.414
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-10-24 06:45:18.414
Teton CME Order Routing | Trading is supported. | 2022-10-24 06:45:18.414
Teton CME Order Routing | Order cancel and replace is supported. | 2022-10-24 06:45:18.414
Teton CME Order Routing | OCO Orders supported. | 2022-10-24 06:45:18.414
Teton CME Order Routing | Bracket Orders supported. | 2022-10-24 06:45:18.414
Teton CME Order Routing | Connected to server complete. | 2022-10-24 06:45:18.414
Triggering next historical data download in queue. | 2022-10-24 06:45:18.416
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-10-24 06:45:18.443
No download requests in the queue to start downloads for. | 2022-10-24 06:45:18.443
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-10-20 18:12:04.054402 | 2022-10-24 06:45:18.445
Updated verified funded futures trading account ending date to: 2022-11-23 10:45:18 | 2022-10-24 06:45:18.486
Mapping MESU22_FUT_CME to MESU22. Service code: cme | 2022-10-24 06:45:18.521
Using symbol data fast lookup vector | 2022-10-24 06:45:18.521
SC Data - All Services | Starting real-time market data updates for: MESU22_FUT_CME (MESU22). ID: 1 Service code: cme | 2022-10-24 06:45:18.521
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-10-24 06:45:18.521
SC Data - All Services | Requesting security definition data for: MESU22_FUT_CME (MESU22). ID: 1 | 2022-10-24 06:45:18.521
Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-10-24 06:45:18.521
Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-10-24 06:45:18.521
Triggering next historical data download in queue. | 2022-10-24 06:45:18.521
DTC Client socket (2) | Creating socket. | 2022-10-24 06:45:18.523
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-24 06:45:18.523
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-10-24 06:45:18.523
Delaying start of download for MESU22_FUT_CME. | 2022-10-24 06:45:18.529
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=23051269 | 2022-10-24 06:45:18.548
SC Data - All Services | Network connection to server complete. | 2022-10-24 06:45:18.577
SC Data - All Services | Starting socket receive thread. | 2022-10-24 06:45:18.577
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-24 06:45:18.577
Mapping ESU22_FUT_CME to ESU22. Service code: cme | 2022-10-24 06:45:18.630
SC Data - All Services | Starting real-time market data updates for: ESU22_FUT_CME (ESU22). ID: 2 Service code: cme | 2022-10-24 06:45:18.630
SC Data - All Services | Requesting security definition data for: ESU22_FUT_CME (ESU22). ID: 2 | 2022-10-24 06:45:18.630
Added historical Intraday data request for ESU22_FUT_CME to the queue. | 2022-10-24 06:45:18.630
Intraday data recording state for symbol ESU22_FUT_CME is set to download 'Pending'. | 2022-10-24 06:45:18.630
Triggering next historical data download in queue. | 2022-10-24 06:45:18.630
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-24 06:45:18.636
SC Data - All Services | Sending logon request message. | 2022-10-24 06:45:18.636
SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL24H-NYSEMKT. ID: 3 Service code: statscalc | 2022-10-24 06:45:18.636
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2022-10-24 06:45:18.636
SC DTC Data with Market Depth | Requesting security definition data for: NVOL24H-NYSEMKT. ID: 3 | 2022-10-24 06:45:18.637
Added historical Intraday data request for NVOL24H-NYSEMKT to the queue. | 2022-10-24 06:45:18.637
Intraday data recording state for symbol NVOL24H-NYSEMKT is set to download 'Pending'. | 2022-10-24 06:45:18.637
Triggering next historical data download in queue. | 2022-10-24 06:45:18.637
DTC Client socket (3) | Creating socket. | 2022-10-24 06:45:18.637
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-10-24 06:45:18.637
DTC Client socket (3) | Connecting to IP: 142.215.18.104. | 2022-10-24 06:45:18.637
Teton CME Order Routing | Received security definition for symbol MESU22_FUT_CME | 2022-10-24 06:45:18.649
Teton CME Order Routing | Received security definition for symbol ESU22_FUT_CME | 2022-10-24 06:45:18.672
SC DTC Data with Market Depth | Network connection to server complete. | 2022-10-24 06:45:18.679
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-10-24 06:45:18.679
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-24 06:45:18.679
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-10-24 06:45:18.737
SC DTC Data with Market Depth | Sending logon request message. | 2022-10-24 06:45:18.737
SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL24H-NYSE_NASDAQ_NYSEMKT. ID: 4 Service code: statscalc | 2022-10-24 06:45:18.770
SC DTC Data with Market Depth | Requesting security definition data for: NVOL24H-NYSE_NASDAQ_NYSEMKT. ID: 4 | 2022-10-24 06:45:18.770
Added historical Intraday data request for NVOL24H-NYSE_NASDAQ_NYSEMKT to the queue. | 2022-10-24 06:45:18.770
Intraday data recording state for symbol NVOL24H-NYSE_NASDAQ_NYSEMKT is set to download 'Pending'. | 2022-10-24 06:45:18.770
Triggering next historical data download in queue. | 2022-10-24 06:45:18.770
SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSEMKT. ID: 5 Service code: statscalc | 2022-10-24 06:45:18.832
SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSEMKT. ID: 5 | 2022-10-24 06:45:18.832
Added historical Intraday data request for TICK-NYSEMKT to the queue. | 2022-10-24 06:45:18.832
Intraday data recording state for symbol TICK-NYSEMKT is set to download 'Pending'. | 2022-10-24 06:45:18.832
Triggering next historical data download in queue. | 2022-10-24 06:45:18.832
SC Data - All Services | Received logon response. | 2022-10-24 06:45:19.353
SC Data - All Services | Server Name: SC Realtime Server. | 2022-10-24 06:45:19.353
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-24 06:45:19.353
SC Data - All Services | Successfully connected. | 2022-10-24 06:45:19.353
SC Data - All Services | Trading is not supported. | 2022-10-24 06:45:19.353
SC Data - All Services | Restarting real-time data updates for symbol: ESU22_FUT_CME -> ESU22 | 2022-10-24 06:45:19.353
SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-10-24 06:45:19.353
SC DTC Data with Market Depth | Received logon response. | 2022-10-24 06:45:19.393
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-10-24 06:45:19.393
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-10-24 06:45:19.393
SC DTC Data with Market Depth | Successfully connected. | 2022-10-24 06:45:19.393
SC DTC Data with Market Depth | Trading is not supported. | 2022-10-24 06:45:19.393
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-24 06:45:19.393
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL24H-NYSEMKT | 2022-10-24 06:45:19.393
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSEMKT | 2022-10-24 06:45:19.393
SC Data - All Services | Real-time data for symbol ESU22_FUT_CME is currently unavailable. | 2022-10-24 06:45:19.479
SC Data - All Services | Received security definition for symbol ESU22_FUT_CME | 2022-10-24 06:45:19.479
SC Data - All Services | Real-time data for symbol MESU22_FUT_CME is currently unavailable. | 2022-10-24 06:45:19.479
SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-10-24 06:45:19.479
SC DTC Data with Market Depth | Received security definition for symbol NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-24 06:45:19.519
SC DTC Data with Market Depth | Received security definition for symbol NVOL24H-NYSEMKT | 2022-10-24 06:45:19.519
SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSEMKT | 2022-10-24 06:45:19.519
HD Request # 13 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-10-24 06:45:24.322
HD Request # 13 | Download start date-time: 2022-09-13 18:23:12.000000. File last date-time: 2022-09-13 18:23:12.000000 | 2022-10-24 06:45:24.323
HD Request # 13 | Using server: ds26.sierracharts.com port 10150 | 2022-10-24 06:45:24.323
Socket (4) | Creating socket. | 2022-10-24 06:45:24.323
Socket (4) | New receive buffer size: 5242880 | 2022-10-24 06:45:24.324
Socket (4) | Connecting to IP: 142.215.18.107. | 2022-10-24 06:45:24.324
HD Request # 13 | Setting DTC encoding to Binary VLS | 2022-10-24 06:45:24.406
HD Request # 13 | Sending historical data logon request message. | 2022-10-24 06:45:24.406
HD Request # 13 | Requesting Intraday data. Start date-time: 2022-09-13 18:23:12. Record interval: 1. Symbol: MESU22 | 2022-10-24 06:45:24.958
HD Request # 13 | Decompressing data. | 2022-10-24 06:45:25.007
HD Request # 13 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-09-13 18:23:12.106000 | 2022-10-24 06:45:25.110
HD Request # 13 | Timestamp of first Intraday data file record written: 2022-09-13 18:23:12.106000. | 2022-10-24 06:45:25.265
Socket (4) | CloseSocket call. | 2022-10-24 06:45:25.337
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:45:25.337
Historical data download thread signaled to stop. | 2022-10-24 06:45:25.337
HD Request # 13 | Received 73292 Intraday data records from 2022-09-13 18:23:12.106000 to 2022-09-16 09:29:59.771000 (2.6 days) and wrote 73292 records for MESU22_FUT_CME | 2022-10-24 06:45:25.338
HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2022-09-16 13:29:59.771000 | 2022-10-24 06:45:25.338
HD Request # 13 | Completion time: 1s. | 2022-10-24 06:45:25.338
HD Request # 13 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 13 | 2022-10-24 06:45:25.338
Removing historical data download ID 13. | 2022-10-24 06:45:25.338
Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-10-24 06:45:25.338
Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 18004 | 2022-10-24 06:45:25.338
Intraday chart data file opened for MESU22_FUT_CME | 2022-10-24 06:45:25.338
HD Request # 13 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:45:25.338
Triggering next historical data download in queue. | 2022-10-24 06:45:25.338
HD Request # 14 | Downloading Intraday chart data for ESU22_FUT_CME to the file ESU22_FUT_CME.scid. Service: cme | 2022-10-24 06:45:25.338
HD Request # 14 | Download start date-time: 2022-09-13 18:22:59.000000. File last date-time: 2022-09-13 18:22:59.000000 | 2022-10-24 06:45:25.338
HD Request # 14 | Using server: ds21.sierracharts.com port 10149 | 2022-10-24 06:45:25.338
Socket (5) | Creating socket. | 2022-10-24 06:45:25.338
Socket (5) | New receive buffer size: 5242880 | 2022-10-24 06:45:25.338
Socket (5) | Connecting to IP: 216.1.90.129. | 2022-10-24 06:45:25.338
Socket (4) | Socket gracefully closed by remote side. | 2022-10-24 06:45:25.382
Socket (4) | Closed. | 2022-10-24 06:45:25.382
HD Request # 14 | Setting DTC encoding to Binary VLS | 2022-10-24 06:45:25.425
HD Request # 14 | Sending historical data logon request message. | 2022-10-24 06:45:25.425
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:45:25.571
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-24 06:45:25.835
HD Request # 14 | Requesting Intraday data. Start date-time: 2022-09-13 18:22:59. Record interval: 1. Symbol: ESU22 | 2022-10-24 06:45:25.981
HD Request # 14 | Decompressing data. | 2022-10-24 06:45:26.021
HD Request # 14 | Receiving Intraday data for ESU22_FUT_CME starting at 2022-09-13 18:22:59.307000 | 2022-10-24 06:45:26.126
HD Request # 14 | Timestamp of first Intraday data file record written: 2022-09-13 18:22:59.307000. | 2022-10-24 06:45:26.294
Socket (5) | CloseSocket call. | 2022-10-24 06:45:26.392
Historical data download thread signaled to stop. | 2022-10-24 06:45:26.392
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:45:26.392
HD Request # 14 | Received 74712 Intraday data records from 2022-09-13 18:22:59.307000 to 2022-09-16 09:29:59.317000 (2.6 days) and wrote 74712 records for ESU22_FUT_CME | 2022-10-24 06:45:26.392
HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2022-09-16 13:29:59.317000 | 2022-10-24 06:45:26.393
HD Request # 14 | Completion time: 1s. | 2022-10-24 06:45:26.393
HD Request # 14 | Intraday data download complete for ESU22_FUT_CME. Unique request ID: 14 | 2022-10-24 06:45:26.393
Removing historical data download ID 14. | 2022-10-24 06:45:26.393
Real-time Intraday chart data file updates started for ESU22_FUT_CME | 2022-10-24 06:45:26.393
Opened cached Intraday file: C:\SierraChart\Data\ESU22_FUT_CME.scid. Thread ID: 18004 | 2022-10-24 06:45:26.393
Intraday chart data file opened for ESU22_FUT_CME | 2022-10-24 06:45:26.393
HD Request # 14 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:45:26.393
Triggering next historical data download in queue. | 2022-10-24 06:45:26.393
HD Request # 15 | Downloading Intraday chart data for NVOL24H-NYSEMKT to the file NVOL24H-NYSEMKT.scid. Service: statscalc | 2022-10-24 06:45:26.393
HD Request # 15 | Download start date-time: 2022-10-24 06:38:47.000000. File last date-time: 2022-10-24 06:38:47.000000 | 2022-10-24 06:45:26.393
HD Request # 15 | Using server: ds13-3.sierracharts.com port 10150 | 2022-10-24 06:45:26.393
Socket (4) | Creating socket. | 2022-10-24 06:45:26.393
Socket (4) | New receive buffer size: 5242880 | 2022-10-24 06:45:26.393
Socket (4) | Connecting to IP: 162.251.232.235. | 2022-10-24 06:45:26.393
Socket (5) | Socket gracefully closed by remote side. | 2022-10-24 06:45:26.431
Socket (5) | Closed. | 2022-10-24 06:45:26.431
HD Request # 15 | Setting DTC encoding to Binary VLS | 2022-10-24 06:45:26.582
HD Request # 15 | Sending historical data logon request message. | 2022-10-24 06:45:26.582
HD Request # 15 | Requesting Intraday data. Start date-time: 2022-10-24 06:38:47. Record interval: 1. Symbol: NVOL24H-NYSEMKT | 2022-10-24 06:45:27.318
HD Request # 15 | Decompressing data. | 2022-10-24 06:45:27.407
HD Request # 15 | Receiving Intraday data for NVOL24H-NYSEMKT starting at 2022-10-24 06:38:47.000000 | 2022-10-24 06:45:27.408
Socket (4) | CloseSocket call. | 2022-10-24 06:45:27.409
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:45:27.409
Historical data download thread signaled to stop. | 2022-10-24 06:45:27.409
HD Request # 15 | Timestamp of first Intraday data file record written: 2022-10-24 06:38:47.000000. | 2022-10-24 06:45:27.409
HD Request # 15 | Received 400 Intraday data records from 2022-10-24 06:38:47.000000 to 2022-10-24 06:45:27.000000 (6.7 minutes) and wrote 400 records for NVOL24H-NYSEMKT | 2022-10-24 06:45:27.409
HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2022-10-24 10:45:27.000000 | 2022-10-24 06:45:27.410
Added 1 Time and Sales records to Intraday data file for NVOL24H-NYSEMKT after download. | 2022-10-24 06:45:27.410
HD Request # 15 | Completion time: 1s. | 2022-10-24 06:45:27.410
HD Request # 15 | Intraday data download complete for NVOL24H-NYSEMKT. Unique request ID: 15 | 2022-10-24 06:45:27.410
Removing historical data download ID 15. | 2022-10-24 06:45:27.410
Real-time Intraday chart data file updates started for NVOL24H-NYSEMKT | 2022-10-24 06:45:27.410
Opened cached Intraday file: C:\SierraChart\Data\NVOL24H-NYSEMKT.scid. Thread ID: 18004 | 2022-10-24 06:45:27.410
Intraday chart data file opened for NVOL24H-NYSEMKT | 2022-10-24 06:45:27.410
HD Request # 15 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:45:27.410
Triggering next historical data download in queue. | 2022-10-24 06:45:27.410
HD Request # 16 | Downloading Intraday chart data for NVOL24H-NYSE_NASDAQ_NYSEMKT to the file NVOL24H-NYSE_NASDAQ_NYSEMKT.scid. Service: statscalc | 2022-10-24 06:45:27.410
HD Request # 16 | Download start date-time: 2022-10-24 06:38:59.000000. File last date-time: 2022-10-24 06:38:59.000000 | 2022-10-24 06:45:27.411
HD Request # 16 | Using server: ds4.sierracharts.com port 10149 | 2022-10-24 06:45:27.411
Socket (5) | Creating socket. | 2022-10-24 06:45:27.411
Socket (5) | New receive buffer size: 5242880 | 2022-10-24 06:45:27.411
Socket (5) | Connecting to IP: 142.215.18.105. | 2022-10-24 06:45:27.411
Socket (4) | Socket gracefully closed by remote side. | 2022-10-24 06:45:27.499
Socket (4) | Closed. | 2022-10-24 06:45:27.499
HD Request # 16 | Setting DTC encoding to Binary VLS | 2022-10-24 06:45:27.505
HD Request # 16 | Sending historical data logon request message. | 2022-10-24 06:45:27.505
Chart #4 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:45:27.637
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-24 06:45:27.838
HD Request # 16 | Requesting Intraday data. Start date-time: 2022-10-24 06:38:59. Record interval: 1. Symbol: NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-24 06:45:28.055
HD Request # 16 | Decompressing data. | 2022-10-24 06:45:28.125
HD Request # 16 | Receiving Intraday data for NVOL24H-NYSE_NASDAQ_NYSEMKT starting at 2022-10-24 06:38:59.000000 | 2022-10-24 06:45:28.127
Socket (5) | CloseSocket call. | 2022-10-24 06:45:28.128
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:45:28.128
Historical data download thread signaled to stop. | 2022-10-24 06:45:28.128
HD Request # 16 | Timestamp of first Intraday data file record written: 2022-10-24 06:38:59.000000. | 2022-10-24 06:45:28.128
HD Request # 16 | Received 388 Intraday data records from 2022-10-24 06:38:59.000000 to 2022-10-24 06:45:27.000000 (6.5 minutes) and wrote 388 records for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-24 06:45:28.128
HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2022-10-24 10:45:27.000000 | 2022-10-24 06:45:28.128
Added 2 Time and Sales records to Intraday data file for NVOL24H-NYSE_NASDAQ_NYSEMKT after download. | 2022-10-24 06:45:28.128
HD Request # 16 | Completion time: 1s. | 2022-10-24 06:45:28.129
HD Request # 16 | Intraday data download complete for NVOL24H-NYSE_NASDAQ_NYSEMKT. Unique request ID: 16 | 2022-10-24 06:45:28.129
Removing historical data download ID 16. | 2022-10-24 06:45:28.129
Real-time Intraday chart data file updates started for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-24 06:45:28.129
Opened cached Intraday file: C:\SierraChart\Data\NVOL24H-NYSE_NASDAQ_NYSEMKT.scid. Thread ID: 18004 | 2022-10-24 06:45:28.129
Intraday chart data file opened for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-24 06:45:28.129
HD Request # 16 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:45:28.129
Triggering next historical data download in queue. | 2022-10-24 06:45:28.129
HD Request # 17 | Downloading Intraday chart data for TICK-NYSEMKT to the file TICK-NYSEMKT.scid. Service: statscalc | 2022-10-24 06:45:28.129
HD Request # 17 | Download start date-time: 2022-10-24 06:38:47.000000. File last date-time: 2022-10-24 06:38:47.000000 | 2022-10-24 06:45:28.129
HD Request # 17 | Using server: ds12.sierracharts.com port 10150 | 2022-10-24 06:45:28.130
Socket (4) | Creating socket. | 2022-10-24 06:45:28.130
Socket (4) | New receive buffer size: 5242880 | 2022-10-24 06:45:28.130
Socket (4) | Connecting to IP: 142.215.18.104. | 2022-10-24 06:45:28.130
Socket (5) | Socket gracefully closed by remote side. | 2022-10-24 06:45:28.169
Socket (5) | Closed. | 2022-10-24 06:45:28.169
HD Request # 17 | Setting DTC encoding to Binary VLS | 2022-10-24 06:45:28.223
HD Request # 17 | Sending historical data logon request message. | 2022-10-24 06:45:28.223
HD Request # 17 | Requesting Intraday data. Start date-time: 2022-10-24 06:38:47. Record interval: 1. Symbol: TICK-NYSEMKT | 2022-10-24 06:45:28.774
HD Request # 17 | Decompressing data. | 2022-10-24 06:45:28.814
HD Request # 17 | Receiving Intraday data for TICK-NYSEMKT starting at 2022-10-24 06:38:47.000000 | 2022-10-24 06:45:28.815
Socket (4) | CloseSocket call. | 2022-10-24 06:45:28.816
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:45:28.816
Historical data download thread signaled to stop. | 2022-10-24 06:45:28.816
HD Request # 17 | Timestamp of first Intraday data file record written: 2022-10-24 06:38:47.000000. | 2022-10-24 06:45:28.816
HD Request # 17 | Received 401 Intraday data records from 2022-10-24 06:38:47.000000 to 2022-10-24 06:45:28.000000 (6.7 minutes) and wrote 401 records for TICK-NYSEMKT | 2022-10-24 06:45:28.816
HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2022-10-24 10:45:28.000000 | 2022-10-24 06:45:28.817
Added 1 Time and Sales records to Intraday data file for TICK-NYSEMKT after download. | 2022-10-24 06:45:28.817
HD Request # 17 | Completion time: 0s. | 2022-10-24 06:45:28.817
HD Request # 17 | Intraday data download complete for TICK-NYSEMKT. Unique request ID: 17 | 2022-10-24 06:45:28.817
Removing historical data download ID 17. | 2022-10-24 06:45:28.817
Real-time Intraday chart data file updates started for TICK-NYSEMKT | 2022-10-24 06:45:28.817
Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSEMKT.scid. Thread ID: 18004 | 2022-10-24 06:45:28.817
Intraday chart data file opened for TICK-NYSEMKT | 2022-10-24 06:45:28.817
HD Request # 17 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:45:28.817
Triggering next historical data download in queue. | 2022-10-24 06:45:28.817
No download requests in the queue to start downloads for. | 2022-10-24 06:45:28.817
Socket (4) | Socket gracefully closed by remote side. | 2022-10-24 06:45:28.857
Socket (4) | Closed. | 2022-10-24 06:45:28.857
Enabling compression for file: C:\SierraChart\Data\MESZ22_FUT_CME.scid. This may take a while. | 2022-10-24 06:45:56.945
File compression enabled. C:\SierraChart\Data\MESZ22_FUT_CME.scid. CompressionState=0 | 2022-10-24 06:45:56.945
MESZ22_FUT_CME[M] 1 Min #2 | Reloading chart. | 2022-10-24 06:45:56.947
MESZ22_FUT_CME[M] 1 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\MESZ22_FUT_CME.scid | 2022-10-24 06:45:56.950
Mapping MESZ22_FUT_CME to MESZ22. Service code: cme | 2022-10-24 06:45:57.444
SC Data - All Services | Starting real-time market data updates for: MESZ22_FUT_CME (MESZ22). ID: 6 Service code: cme | 2022-10-24 06:45:57.444
SC Data - All Services | Requesting security definition data for: MESZ22_FUT_CME (MESZ22). ID: 6 | 2022-10-24 06:45:57.444
Added historical Intraday data request for MESZ22_FUT_CME to the queue. | 2022-10-24 06:45:57.445
Intraday data recording state for symbol MESZ22_FUT_CME is set to download 'Pending'. | 2022-10-24 06:45:57.445
Triggering next historical data download in queue. | 2022-10-24 06:45:57.445
Delaying start of download for MESZ22_FUT_CME. | 2022-10-24 06:45:57.445
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-24 06:45:57.496
SC Data - All Services | Received security definition for symbol MESZ22_FUT_CME | 2022-10-24 06:45:57.576
HD Request # 18 | Downloading Intraday chart data for MESZ22_FUT_CME to the file MESZ22_FUT_CME.scid. Service: cme | 2022-10-24 06:46:02.326
HD Request # 18 | Download start date-time: 2022-04-21 06:46:02.000000. File last date-time: 00:00:00.000000 | 2022-10-24 06:46:02.326
HD Request # 18 | Using server: ds26.sierracharts.com port 10149 | 2022-10-24 06:46:02.326
Socket (4) | Creating socket. | 2022-10-24 06:46:02.327
Socket (4) | New receive buffer size: 5242880 | 2022-10-24 06:46:02.327
Socket (4) | Connecting to IP: 142.215.18.107. | 2022-10-24 06:46:02.327
HD Request # 18 | Setting DTC encoding to Binary VLS | 2022-10-24 06:46:02.412
HD Request # 18 | Sending historical data logon request message. | 2022-10-24 06:46:02.412
HD Request # 18 | Requesting Intraday data. Start date-time: 2022-04-21 06:46:02. Record interval: 1. Symbol: MESZ22 | 2022-10-24 06:46:02.965
HD Request # 18 | Decompressing data. | 2022-10-24 06:46:03.010
HD Request # 18 | Receiving Intraday data for MESZ22_FUT_CME starting at 2022-04-21 07:52:49.023000 | 2022-10-24 06:46:03.105
HD Request # 18 | Timestamp of first Intraday data file record written: 2022-04-21 07:52:49.023000. | 2022-10-24 06:46:03.252
MESZ22_FUT_CME[M] 1 Min #2 | StartDateTimeForLoadingOrderFills: 2022-04-21 07:52:00 | 2022-10-24 06:46:03.505
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:46:03.521
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-24 06:46:03.837
Socket (4) | CloseSocket call. | 2022-10-24 06:46:14.362
Historical data download thread signaled to stop. | 2022-10-24 06:46:14.362
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:46:14.362
HD Request # 18 | Received 1873969 Intraday data records from 2022-04-21 07:52:49.023000 to 2022-10-24 06:46:12.079000 (186.0 days) and wrote 1873969 records for MESZ22_FUT_CME | 2022-10-24 06:46:14.362
HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2022-10-24 10:46:12.079000 | 2022-10-24 06:46:14.362
Added 2 Time and Sales records to Intraday data file for MESZ22_FUT_CME after download. | 2022-10-24 06:46:14.362
HD Request # 18 | Completion time: 12s. | 2022-10-24 06:46:14.362
HD Request # 18 | Intraday data download complete for MESZ22_FUT_CME. Unique request ID: 18 | 2022-10-24 06:46:14.362
Removing historical data download ID 18. | 2022-10-24 06:46:14.362
Real-time Intraday chart data file updates started for MESZ22_FUT_CME | 2022-10-24 06:46:14.362
Opened cached Intraday file: C:\SierraChart\Data\MESZ22_FUT_CME.scid. Thread ID: 18004 | 2022-10-24 06:46:14.362
Intraday chart data file opened for MESZ22_FUT_CME | 2022-10-24 06:46:14.362
HD Request # 18 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:46:14.362
Triggering next historical data download in queue. | 2022-10-24 06:46:14.362
No download requests in the queue to start downloads for. | 2022-10-24 06:46:14.362
Socket (4) | Socket gracefully closed by remote side. | 2022-10-24 06:46:14.404
Socket (4) | Closed. | 2022-10-24 06:46:14.404
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-24 06:46:14.467
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-24 06:46:14.832
Enabling compression for file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. This may take a while. | 2022-10-24 06:48:30.135
File compression enabled. C:\SierraChart\Data\ESZ22_FUT_CME.scid. CompressionState=0 | 2022-10-24 06:48:30.135
ESZ22_FUT_CME[M] 60 Min #1 | Reloading chart. | 2022-10-24 06:48:30.136
ESZ22_FUT_CME[M] 60 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ22_FUT_CME.scid | 2022-10-24 06:48:30.150
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-10-24 06:48:30.638
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 7 Service code: cme | 2022-10-24 06:48:30.638
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 7 | 2022-10-24 06:48:30.638
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-10-24 06:48:30.638
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-10-24 06:48:30.638
Triggering next historical data download in queue. | 2022-10-24 06:48:30.638
Delaying start of download for ESZ22_FUT_CME. | 2022-10-24 06:48:30.638
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-24 06:48:30.688
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-10-24 06:48:30.734
HD Request # 19 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-10-24 06:48:35.318
HD Request # 19 | Download start date-time: 2022-04-21 06:48:35.000000. File last date-time: 00:00:00.000000 | 2022-10-24 06:48:35.318
HD Request # 19 | Using server: ds21.sierracharts.com port 10150 | 2022-10-24 06:48:35.319
Socket (4) | Creating socket. | 2022-10-24 06:48:35.319
Socket (4) | New receive buffer size: 5242880 | 2022-10-24 06:48:35.319
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-10-24 06:48:35.319
HD Request # 19 | Setting DTC encoding to Binary VLS | 2022-10-24 06:48:35.402
HD Request # 19 | Sending historical data logon request message. | 2022-10-24 06:48:35.402
HD Request # 19 | Requesting Intraday data. Start date-time: 2022-04-21 06:48:35. Record interval: 1. Symbol: ESZ22 | 2022-10-24 06:48:35.902
HD Request # 19 | Decompressing data. | 2022-10-24 06:48:35.944
HD Request # 19 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-04-21 08:01:36.861000 | 2022-10-24 06:48:36.049
HD Request # 19 | Timestamp of first Intraday data file record written: 2022-04-21 08:01:36.861000. | 2022-10-24 06:48:36.197
Socket (4) | CloseSocket call. | 2022-10-24 06:48:54.319
Historical data download thread signaled to stop. | 2022-10-24 06:48:54.319
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-24 06:48:54.319
HD Request # 19 | Received 1841995 Intraday data records from 2022-04-21 08:01:36.861000 to 2022-10-24 06:48:53.980000 (185.9 days) and wrote 1841995 records for ESZ22_FUT_CME | 2022-10-24 06:48:54.319
HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2022-10-24 10:48:53.980000 | 2022-10-24 06:48:54.319
Added 1 Time and Sales records to Intraday data file for ESZ22_FUT_CME after download. | 2022-10-24 06:48:54.319
HD Request # 19 | Completion time: 19s. | 2022-10-24 06:48:54.320
HD Request # 19 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 19 | 2022-10-24 06:48:54.320
Removing historical data download ID 19. | 2022-10-24 06:48:54.320
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-10-24 06:48:54.320
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 18004 | 2022-10-24 06:48:54.320
Intraday chart data file opened for ESZ22_FUT_CME | 2022-10-24 06:48:54.320
HD Request # 19 | Enabling Intraday chart updating for symbol. | 2022-10-24 06:48:54.320
Triggering next historical data download in queue. | 2022-10-24 06:48:54.320
No download requests in the queue to start downloads for. | 2022-10-24 06:48:54.320
Socket (4) | Socket gracefully closed by remote side. | 2022-10-24 06:48:54.356
Socket (4) | Closed. | 2022-10-24 06:48:54.356
ESZ22_FUT_CME[M] 5 Min #3 | Reloading chart. | 2022-10-24 06:55:19.680
Saved Chartbook: IB Internals.Cht. Time: 0.0018 seconds. | 2022-10-24 06:55:29.484
ESZ22_FUT_CME[M] 60 Min #3 | Reloading chart. | 2022-10-24 06:55:35.384
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-24 17:19:30.200
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-24 17:20:02.212
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-24 17:26:04.679
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-24 17:26:38.685
SC Data - All Services | Message from server: Authorization data verified. | 2022-10-25 06:45:27.992
SC DTC Data with Market Depth | Message from server: Authorization data verified. | 2022-10-25 06:45:28.542
SC Data - All Services | Message from server: Authorization data verified. | 2022-10-26 06:45:35.445
SC DTC Data with Market Depth | Message from server: Authorization data verified. | 2022-10-26 06:45:36.338
SC Data - All Services | Message from server: Authorization data verified. | 2022-10-27 06:45:42.804
SC DTC Data with Market Depth | Message from server: Authorization data verified. | 2022-10-27 06:45:44.337
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-27 16:03:43.454
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-27 16:03:43.454
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-27 17:03:47.268
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-27 17:03:47.269
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-27 18:10:23.441
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-27 18:10:23.441
SC Data - All Services | Message from server: Authorization data verified. | 2022-10-28 06:45:50.320
SC DTC Data with Market Depth | Message from server: Authorization data verified. | 2022-10-28 06:45:52.211
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-10-28 08:13:21.437
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:13:21.437
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-10-28 08:13:21.437
DTC Client socket (1) | Max send buffer size during socket life: 235 | 2022-10-28 08:13:21.437
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:21.437
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-28 08:13:21.438
DTC Client socket (2) | CloseSocket call. | 2022-10-28 08:13:21.438
SC Data - All Services | Disconnected from the server. | 2022-10-28 08:13:21.438
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-10-28 08:13:21.438
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:21.438
DTC Client socket (3) | CloseSocket call. | 2022-10-28 08:13:21.438
SC DTC Data with Market Depth | Disconnected from the server. | 2022-10-28 08:13:21.438
Teton CME Order Routing | Disconnected. | 2022-10-28 08:13:21.438
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:21.438
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:21.493
DTC Client socket (1) | Closed. | 2022-10-28 08:13:21.493
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 5. | 2022-10-28 08:13:21.505
Current selected Data/Trading service: Rithmic Direct - DTC | 2022-10-28 08:13:21.505
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:13:22.187
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2022-10-28 08:13:22.187
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Connecting to IP: 38.79.0.89. | 2022-10-28 08:13:22.187
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:22.568
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | CloseSocket call. | 2022-10-28 08:13:22.570
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 08:13:22.570
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Closed. | 2022-10-28 08:13:22.570
Symbol settings MD5 received. Request ID: 5. | 2022-10-28 08:13:23.346
Requested symbol settings for service code rithmic_v2.trading. Request ID: 6. | 2022-10-28 08:13:23.346
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:25.727
Symbol settings received. Request ID: 6. | 2022-10-28 08:13:25.888
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:13:29.728
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:13:29.731
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:13:29.778
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:13:29.779
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:13:29.779
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:13:29.820
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:13:29.820
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:13:29.820
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:13:29.820
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:13:29.959
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:13:29.959
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:13:29.959
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:13:29.959
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:13:29.959
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:29.959
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:13:29.995
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:13:29.995
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:29.995
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:13:29.996
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:29.996
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:30.034
DTC Client socket (1) | Closed. | 2022-10-28 08:13:30.034
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:13:34.005
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:13:34.011
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:13:34.012
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:13:34.013
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:13:34.013
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:13:34.054
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:13:34.054
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:13:34.054
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:13:34.054
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:13:34.189
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:13:34.189
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:13:34.189
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:13:34.189
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:13:34.189
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:34.189
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:13:34.207
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:13:34.208
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:13:34.208
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:34.208
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:34.208
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:34.253
DTC Client socket (1) | Closed. | 2022-10-28 08:13:34.253
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:13:38.202
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:13:38.208
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:13:38.209
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:13:38.209
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:13:38.209
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:13:38.250
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:13:38.250
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:13:38.250
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:13:38.250
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:13:38.380
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:13:38.380
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:13:38.380
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:13:38.380
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:13:38.380
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:38.380
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:13:38.395
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:13:38.396
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:13:38.396
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:38.396
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:38.396
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:38.437
DTC Client socket (1) | Closed. | 2022-10-28 08:13:38.437
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:13:42.390
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:13:42.393
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:13:42.394
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:13:42.394
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:13:42.394
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:13:42.436
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:13:42.436
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:13:42.436
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:13:42.436
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:13:42.573
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:13:42.573
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:13:42.573
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:13:42.573
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:13:42.573
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:42.573
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:13:42.587
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:13:42.588
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:13:42.588
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:42.588
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:42.588
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:42.627
DTC Client socket (1) | Closed. | 2022-10-28 08:13:42.627
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:13:46.606
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:13:46.610
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:13:46.611
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:13:46.611
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:13:46.611
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:13:46.653
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:13:46.653
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:13:46.654
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:13:46.654
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:13:46.785
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:13:46.785
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:13:46.785
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:13:46.785
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:13:46.785
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:46.785
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:13:46.803
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:13:46.803
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:13:46.803
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:46.803
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:46.803
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:46.843
DTC Client socket (1) | Closed. | 2022-10-28 08:13:46.843
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:13:50.795
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:13:50.800
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:13:50.801
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:13:50.801
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:13:50.801
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:13:50.843
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:13:50.843
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:13:50.844
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:13:50.844
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:13:50.982
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:13:50.982
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:13:50.982
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:13:50.982
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:13:50.982
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:50.982
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:13:51.004
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:13:51.005
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:13:51.005
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:51.005
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:51.005
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:51.044
DTC Client socket (1) | Closed. | 2022-10-28 08:13:51.044
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:13:54.999
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:13:55.003
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:13:55.004
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:13:55.004
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:13:55.004
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:13:55.044
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:13:55.044
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:13:55.044
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:13:55.044
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:13:55.178
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:13:55.178
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:13:55.178
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:13:55.178
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:13:55.178
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:55.178
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:13:55.188
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:13:55.189
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:13:55.189
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:55.189
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:55.189
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:55.228
DTC Client socket (1) | Closed. | 2022-10-28 08:13:55.228
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:13:59.187
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:13:59.188
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:13:59.188
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:13:59.188
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:13:59.188
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:13:59.227
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:13:59.227
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:13:59.227
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:13:59.227
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:13:59.359
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:13:59.359
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:13:59.359
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:13:59.359
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:13:59.359
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:59.359
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:13:59.378
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:13:59.380
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:13:59.380
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:13:59.380
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:13:59.380
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:13:59.418
DTC Client socket (1) | Closed. | 2022-10-28 08:13:59.419
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:03.377
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:03.378
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:03.378
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:14:03.378
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:03.378
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:03.416
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:03.416
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:03.417
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:03.417
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:03.547
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:03.547
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:03.547
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:03.547
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:03.547
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:03.547
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:03.565
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:14:03.567
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:03.567
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:03.568
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:03.568
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:14:03.606
DTC Client socket (1) | Closed. | 2022-10-28 08:14:03.606
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:07.564
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:07.567
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:07.568
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:14:07.569
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:07.569
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:07.613
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:07.613
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:07.613
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:07.613
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:07.750
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:07.750
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:07.750
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:07.750
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:07.750
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:07.750
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:07.764
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:14:07.765
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:07.765
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:07.766
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:07.766
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:14:07.804
DTC Client socket (1) | Closed. | 2022-10-28 08:14:07.805
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:11.776
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:11.779
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:11.781
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:14:11.781
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:11.781
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:11.820
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:11.820
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:11.820
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:11.820
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:11.959
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:11.959
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:11.959
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:11.959
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:11.959
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:11.959
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:11.972
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:14:11.973
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:11.973
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:11.973
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:11.973
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:14:12.013
DTC Client socket (1) | Closed. | 2022-10-28 08:14:12.013
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:15.971
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:15.972
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:15.972
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:14:15.972
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:15.972
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:16.014
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:16.014
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:16.014
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:16.014
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:16.152
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:16.152
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:16.152
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:16.152
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:16.152
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:16.152
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:16.170
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:14:16.172
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:16.172
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:16.173
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:16.173
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:14:16.214
DTC Client socket (1) | Closed. | 2022-10-28 08:14:16.214
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:20.182
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:20.183
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:20.184
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:14:20.184
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:20.184
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:20.223
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:20.223
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:20.223
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:20.223
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:20.354
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:20.354
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:20.354
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:20.354
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:20.354
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:20.354
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:20.358
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:14:20.358
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:20.358
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:20.358
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:20.358
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:14:20.397
DTC Client socket (1) | Closed. | 2022-10-28 08:14:20.398
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:24.364
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:24.367
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:24.368
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:14:24.368
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:24.368
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:24.412
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:24.412
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:24.412
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:24.412
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:24.548
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:24.548
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:24.548
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:24.548
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:24.548
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:24.548
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:24.561
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:14:24.563
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:24.563
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:24.563
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:24.563
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:14:24.602
DTC Client socket (1) | Closed. | 2022-10-28 08:14:24.603
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:28.562
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:28.565
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:28.566
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:14:28.566
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:28.566
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:28.608
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:28.608
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:28.609
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:28.609
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:28.740
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:28.740
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:28.740
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:28.740
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:28.740
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:28.740
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:28.749
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:14:28.750
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:28.750
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:28.750
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:28.750
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:14:28.790
DTC Client socket (1) | Closed. | 2022-10-28 08:14:28.790
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:32.754
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:32.757
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:32.758
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:14:32.758
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:32.758
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:32.798
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:32.798
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:32.798
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:32.798
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:32.928
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:32.928
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:32.928
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:32.928
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:32.928
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:32.928
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:32.939
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:14:32.940
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:32.940
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:32.940
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:32.941
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:14:32.980
DTC Client socket (1) | Closed. | 2022-10-28 08:14:32.980
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:36.936
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:36.940
DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:36.941
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-10-28 08:14:36.941
DTC Client socket (4) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:36.941
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:36.982
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:36.982
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:36.983
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:36.983
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:37.118
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:37.118
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:37.118
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:37.118
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:37.118
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:37.118
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:37.131
DTC Client socket (4) | CloseSocket call. | 2022-10-28 08:14:37.132
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:37.133
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:37.133
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:37.133
DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-10-28 08:14:37.172
DTC Client socket (4) | Closed. | 2022-10-28 08:14:37.173
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 08:14:41.122
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 08:14:41.126
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:14:41.127
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 08:14:41.128
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 08:14:41.128
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 08:14:41.167
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 08:14:41.167
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 08:14:41.167
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 08:14:41.167
Rithmic Direct - DTC | Received logon response. | 2022-10-28 08:14:41.302
Rithmic Direct - DTC | Server Name: . | 2022-10-28 08:14:41.302
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 08:14:41.302
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 08:14:41.302
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 08:14:41.302
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:41.302
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 08:14:41.318
DTC Client socket (1) | CloseSocket call. | 2022-10-28 08:14:41.319
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:41.320
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 08:14:41.320
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 08:14:41.320
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 08:14:41.366
DTC Client socket (1) | Closed. | 2022-10-28 08:14:41.366
File >> Disconnect selected. | 2022-10-28 08:14:44.836
DTC Client socket (0) | CloseSocket call. | 2022-10-28 08:14:44.836
Rithmic Direct - DTC | Disconnected. | 2022-10-28 08:14:44.836
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2022-10-28 08:15:11.145
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2022-10-28 08:15:11.145
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 38.79.0.89. | 2022-10-28 08:15:11.145
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2022-10-28 08:15:11.390
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call. | 2022-10-28 08:15:11.390
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 08:15:11.391
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed. | 2022-10-28 08:15:11.391
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-10-28 08:15:27.761
DTC Client socket (2) | Closed. | 2022-10-28 08:15:27.762
DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-10-28 08:15:27.762
DTC Client socket (3) | Closed. | 2022-10-28 08:15:27.762
DTC Client socket (2) | Deleting network socket now after delay. | 2022-10-28 08:15:57.767
DTC Client socket (3) | Deleting network socket now after delay. | 2022-10-28 08:15:57.767
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:15.565
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:15.569
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:15.570
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:11:15.570
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:15.570
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:15.613
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:15.613
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:15.613
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:15.613
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:15.748
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:15.748
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:15.748
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:15.748
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:15.748
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:15.748
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:15.782
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:11:15.782
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:15.782
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:15.782
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:15.782
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:11:15.824
DTC Client socket (1) | Closed. | 2022-10-28 09:11:15.824
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:19.785
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:19.786
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:19.787
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:11:19.787
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:19.787
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:19.828
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:19.828
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:19.828
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:19.828
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:19.962
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:19.962
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:19.962
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:19.962
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:19.962
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:19.962
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:19.970
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:11:19.970
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:19.970
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:19.970
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:19.970
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:11:20.016
DTC Client socket (1) | Closed. | 2022-10-28 09:11:20.016
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:23.983
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:23.986
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:23.987
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:11:23.988
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:23.988
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:24.031
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:24.031
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:24.031
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:24.031
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:24.165
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:24.165
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:24.165
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:24.165
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:24.165
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:24.165
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:24.172
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:11:24.173
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:24.174
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:24.174
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:24.174
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:11:24.213
DTC Client socket (1) | Closed. | 2022-10-28 09:11:24.213
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:28.174
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:28.178
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:28.179
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:11:28.180
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:28.180
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:28.221
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:28.221
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:28.221
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:28.221
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:28.352
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:28.352
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:28.352
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:28.352
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:28.352
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:28.352
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:28.359
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:11:28.359
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:28.359
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:28.360
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:28.360
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:11:28.399
DTC Client socket (1) | Closed. | 2022-10-28 09:11:28.399
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:32.362
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:32.365
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:32.366
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:11:32.366
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:32.366
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:32.407
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:32.407
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:32.407
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:32.407
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:32.532
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:32.532
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:32.532
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:32.532
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:32.532
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:32.532
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:32.550
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:11:32.550
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:32.550
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:32.550
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:32.550
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:11:32.590
DTC Client socket (1) | Closed. | 2022-10-28 09:11:32.590
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:36.559
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:36.563
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:36.565
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-28 09:11:36.565
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:36.565
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:36.609
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:36.609
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:36.609
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:36.609
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:36.756
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:36.756
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:36.756
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:36.756
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:36.756
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:36.756
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:36.765
DTC Client socket (2) | CloseSocket call. | 2022-10-28 09:11:36.766
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:36.766
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:36.766
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:36.766
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-28 09:11:36.806
DTC Client socket (2) | Closed. | 2022-10-28 09:11:36.807
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:40.774
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:40.777
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:40.778
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:11:40.778
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:40.778
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:40.821
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:40.821
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:40.821
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:40.821
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:40.964
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:40.964
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:40.964
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:40.964
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:40.964
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:40.964
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:40.997
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:11:40.997
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:40.997
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:40.997
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:40.997
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:11:41.040
DTC Client socket (1) | Closed. | 2022-10-28 09:11:41.040
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:45.012
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:45.016
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:45.017
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:11:45.017
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:45.017
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:45.057
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:45.057
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:45.057
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:45.057
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:45.193
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:45.193
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:45.193
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:45.193
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:45.193
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:45.193
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:45.209
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:11:45.210
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:45.210
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:45.211
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:45.211
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:11:45.249
DTC Client socket (1) | Closed. | 2022-10-28 09:11:45.249
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:49.210
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:49.213
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:49.214
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:11:49.214
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:49.214
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:49.254
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:49.255
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:49.255
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:49.255
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:49.387
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:49.387
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:49.387
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:49.387
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:49.387
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:49.387
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:49.407
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:11:49.408
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:49.408
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:49.409
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:49.409
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:11:49.453
DTC Client socket (1) | Closed. | 2022-10-28 09:11:49.453
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:11:53.411
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:11:53.413
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:11:53.414
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:11:53.415
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:11:53.415
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:11:53.456
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:11:53.456
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:11:53.456
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:11:53.456
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:11:53.588
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:11:53.588
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:11:53.588
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:11:53.588
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:11:53.588
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:53.588
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:11:53.596
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:11:53.597
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:53.597
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:11:53.597
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:11:53.597
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:11:53.635
DTC Client socket (1) | Closed. | 2022-10-28 09:11:53.636
File >> Disconnect selected. | 2022-10-28 09:11:57.083
DTC Client socket (0) | CloseSocket call. | 2022-10-28 09:11:57.083
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:11:57.084
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:12:23.412
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | New receive buffer size: 32768 | 2022-10-28 09:12:23.412
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Connecting to IP: 38.79.0.89. | 2022-10-28 09:12:23.412
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. | 2022-10-28 09:12:23.648
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | CloseSocket call. | 2022-10-28 09:12:23.650
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 09:12:23.651
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Closed. | 2022-10-28 09:12:23.651
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 7. | 2022-10-28 09:13:52.551
Current selected Data/Trading service: Teton CME Order Routing | 2022-10-28 09:13:52.551
Symbol settings MD5 received. Request ID: 7. | 2022-10-28 09:13:54.374
Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 8. | 2022-10-28 09:13:54.375
Symbol settings received. Request ID: 8. | 2022-10-28 09:13:57.080
Teton CME Order Routing | Clearing firm: IronBeam | 2022-10-28 09:14:18.060
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11085 | 2022-10-28 09:14:18.060
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:14:18.107
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:14:18.107
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-10-28 09:14:18.107
Teton CME Order Routing | Network connection to server complete. | 2022-10-28 09:14:18.159
Teton CME Order Routing | Starting socket receive thread. | 2022-10-28 09:14:18.159
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-10-28 09:14:18.159
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-10-28 09:14:18.309
Teton CME Order Routing | Sending logon request message. | 2022-10-28 09:14:18.309
Teton CME Order Routing | Received logon response. | 2022-10-28 09:14:18.836
Teton CME Order Routing | Server Name: SC DTC Server. Build=43909M. | 2022-10-28 09:14:18.836
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:14:18.836
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-10-28 09:14:18.836
Teton CME Order Routing | Trading is supported. | 2022-10-28 09:14:18.836
Teton CME Order Routing | Order cancel and replace is supported. | 2022-10-28 09:14:18.836
Teton CME Order Routing | OCO Orders supported. | 2022-10-28 09:14:18.836
Teton CME Order Routing | Bracket Orders supported. | 2022-10-28 09:14:18.836
Teton CME Order Routing | Connected to server complete. | 2022-10-28 09:14:18.836
Triggering next historical data download in queue. | 2022-10-28 09:14:18.838
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-10-28 09:14:18.841
No download requests in the queue to start downloads for. | 2022-10-28 09:14:18.841
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-10-20 18:12:04.054402 | 2022-10-28 09:14:18.851
Updated verified funded futures trading account ending date to: 2022-11-27 13:14:18 | 2022-10-28 09:14:18.885
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=23051269 | 2022-10-28 09:14:18.899
Using symbol data fast lookup vector | 2022-10-28 09:14:18.984
SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSEMKT. ID: 1 Service code: statscalc | 2022-10-28 09:14:18.984
SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 443 | 2022-10-28 09:14:18.984
SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSEMKT. ID: 1 | 2022-10-28 09:14:18.984
Added historical Intraday data request for TICK-NYSEMKT to the queue. | 2022-10-28 09:14:18.984
Intraday data recording state for symbol TICK-NYSEMKT is set to download 'Pending'. | 2022-10-28 09:14:18.985
Triggering next historical data download in queue. | 2022-10-28 09:14:18.985
Delaying start of download for TICK-NYSEMKT. | 2022-10-28 09:14:19.002
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-10-28 09:14:19.002
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 2 Service code: cme | 2022-10-28 09:14:19.002
SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 10048 | 2022-10-28 09:14:19.002
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 2 | 2022-10-28 09:14:19.002
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-10-28 09:14:19.002
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-10-28 09:14:19.002
Triggering next historical data download in queue. | 2022-10-28 09:14:19.002
SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL24H-NYSEMKT. ID: 3 Service code: statscalc | 2022-10-28 09:14:19.006
SC DTC Data with Market Depth | Requesting security definition data for: NVOL24H-NYSEMKT. ID: 3 | 2022-10-28 09:14:19.006
Added historical Intraday data request for NVOL24H-NYSEMKT to the queue. | 2022-10-28 09:14:19.006
Intraday data recording state for symbol NVOL24H-NYSEMKT is set to download 'Pending'. | 2022-10-28 09:14:19.006
Triggering next historical data download in queue. | 2022-10-28 09:14:19.006
SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL24H-NYSE_NASDAQ_NYSEMKT. ID: 4 Service code: statscalc | 2022-10-28 09:14:19.007
SC DTC Data with Market Depth | Requesting security definition data for: NVOL24H-NYSE_NASDAQ_NYSEMKT. ID: 4 | 2022-10-28 09:14:19.007
Added historical Intraday data request for NVOL24H-NYSE_NASDAQ_NYSEMKT to the queue. | 2022-10-28 09:14:19.007
Intraday data recording state for symbol NVOL24H-NYSE_NASDAQ_NYSEMKT is set to download 'Pending'. | 2022-10-28 09:14:19.007
Triggering next historical data download in queue. | 2022-10-28 09:14:19.007
Mapping MESZ22_FUT_CME to MESZ22. Service code: cme | 2022-10-28 09:14:19.008
SC Data - All Services | Starting real-time market data updates for: MESZ22_FUT_CME (MESZ22). ID: 5 Service code: cme | 2022-10-28 09:14:19.008
SC Data - All Services | Requesting security definition data for: MESZ22_FUT_CME (MESZ22). ID: 5 | 2022-10-28 09:14:19.008
Added historical Intraday data request for MESZ22_FUT_CME to the queue. | 2022-10-28 09:14:19.008
Intraday data recording state for symbol MESZ22_FUT_CME is set to download 'Pending'. | 2022-10-28 09:14:19.008
Triggering next historical data download in queue. | 2022-10-28 09:14:19.008
DTC Client socket (2) | Creating socket. | 2022-10-28 09:14:19.024
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-28 09:14:19.024
DTC Client socket (2) | Connecting to IP: 162.251.232.235. | 2022-10-28 09:14:19.024
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-28 09:14:19.046
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-28 09:14:19.051
DTC Client socket (3) | Creating socket. | 2022-10-28 09:14:19.068
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-10-28 09:14:19.068
DTC Client socket (3) | Connecting to IP: 142.215.18.107. | 2022-10-28 09:14:19.068
SC Data - All Services | Network connection to server complete. | 2022-10-28 09:14:19.108
SC Data - All Services | Starting socket receive thread. | 2022-10-28 09:14:19.108
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-28 09:14:19.108
SC DTC Data with Market Depth | Network connection to server complete. | 2022-10-28 09:14:19.112
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-10-28 09:14:19.112
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-28 09:14:19.112
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-28 09:14:19.158
SC Data - All Services | Sending logon request message. | 2022-10-28 09:14:19.158
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-10-28 09:14:19.232
SC DTC Data with Market Depth | Sending logon request message. | 2022-10-28 09:14:19.232
SC Data - All Services | Received logon response. | 2022-10-28 09:14:19.909
SC Data - All Services | Server Name: SC Realtime Server. | 2022-10-28 09:14:19.909
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:14:19.909
SC Data - All Services | Successfully connected. | 2022-10-28 09:14:19.909
SC Data - All Services | Trading is not supported. | 2022-10-28 09:14:19.909
SC Data - All Services | Restarting real-time data updates for symbol: ESZ22_FUT_CME -> ESZ22 | 2022-10-28 09:14:19.909
SC Data - All Services | Restarting real-time data updates for symbol: MESZ22_FUT_CME -> MESZ22 | 2022-10-28 09:14:19.909
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-10-28 09:14:20.032
SC Data - All Services | Received security definition for symbol MESZ22_FUT_CME | 2022-10-28 09:14:20.032
SC DTC Data with Market Depth | Received logon response. | 2022-10-28 09:14:20.061
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-10-28 09:14:20.061
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:14:20.061
SC DTC Data with Market Depth | Successfully connected. | 2022-10-28 09:14:20.061
SC DTC Data with Market Depth | Trading is not supported. | 2022-10-28 09:14:20.061
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 09:14:20.061
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL24H-NYSEMKT | 2022-10-28 09:14:20.061
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSEMKT | 2022-10-28 09:14:20.061
SC DTC Data with Market Depth | Received security definition for symbol NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 09:14:20.249
SC DTC Data with Market Depth | Received security definition for symbol NVOL24H-NYSEMKT | 2022-10-28 09:14:20.249
SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSEMKT | 2022-10-28 09:14:20.249
HD Request # 20 | Downloading Intraday chart data for TICK-NYSEMKT to the file TICK-NYSEMKT.scid. Service: statscalc | 2022-10-28 09:14:25.166
HD Request # 20 | Download start date-time: 2022-10-28 08:13:20.000000. File last date-time: 2022-10-28 08:13:20.000000 | 2022-10-28 09:14:25.167
HD Request # 20 | Using server: ds13-3.sierracharts.com port 10149 | 2022-10-28 09:14:25.167
Socket (4) | Creating socket. | 2022-10-28 09:14:25.167
Socket (4) | New receive buffer size: 5242880 | 2022-10-28 09:14:25.168
Socket (4) | Connecting to IP: 162.251.232.235. | 2022-10-28 09:14:25.168
HD Request # 20 | Setting DTC encoding to Binary VLS | 2022-10-28 09:14:25.353
HD Request # 20 | Sending historical data logon request message. | 2022-10-28 09:14:25.353
HD Request # 20 | Requesting Intraday data. Start date-time: 2022-10-28 08:13:20. Record interval: 1. Symbol: TICK-NYSEMKT | 2022-10-28 09:14:26.098
HD Request # 20 | Decompressing data. | 2022-10-28 09:14:26.186
HD Request # 20 | Receiving Intraday data for TICK-NYSEMKT starting at 2022-10-28 08:13:20.000000 | 2022-10-28 09:14:26.451
Socket (4) | CloseSocket call. | 2022-10-28 09:14:26.455
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:14:26.455
Historical data download thread signaled to stop. | 2022-10-28 09:14:26.456
HD Request # 20 | Timestamp of first Intraday data file record written: 2022-10-28 08:13:20.000000. | 2022-10-28 09:14:26.457
HD Request # 20 | Received 3666 Intraday data records from 2022-10-28 08:13:20.000000 to 2022-10-28 09:14:25.000000 (61.1 minutes) and wrote 3666 records for TICK-NYSEMKT | 2022-10-28 09:14:26.457
HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2022-10-28 13:14:25.000000 | 2022-10-28 09:14:26.458
HD Request # 20 | Completion time: 1s. | 2022-10-28 09:14:26.458
HD Request # 20 | Intraday data download complete for TICK-NYSEMKT. Unique request ID: 20 | 2022-10-28 09:14:26.458
Removing historical data download ID 20. | 2022-10-28 09:14:26.458
Real-time Intraday chart data file updates started for TICK-NYSEMKT | 2022-10-28 09:14:26.458
Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSEMKT.scid. Thread ID: 18004 | 2022-10-28 09:14:26.458
Intraday chart data file opened for TICK-NYSEMKT | 2022-10-28 09:14:26.458
HD Request # 20 | Enabling Intraday chart updating for symbol. | 2022-10-28 09:14:26.458
Triggering next historical data download in queue. | 2022-10-28 09:14:26.459
HD Request # 21 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-10-28 09:14:26.459
HD Request # 21 | Download start date-time: 2022-10-28 08:13:20.000000. File last date-time: 2022-10-28 08:13:20.000000 | 2022-10-28 09:14:26.459
HD Request # 21 | Using server: ds26.sierracharts.com port 10150 | 2022-10-28 09:14:26.459
Socket (5) | Creating socket. | 2022-10-28 09:14:26.460
Socket (5) | New receive buffer size: 5242880 | 2022-10-28 09:14:26.460
Socket (5) | Connecting to IP: 142.215.18.107. | 2022-10-28 09:14:26.460
Socket (4) | Socket gracefully closed by remote side. | 2022-10-28 09:14:26.540
Socket (4) | Closed. | 2022-10-28 09:14:26.541
HD Request # 21 | Setting DTC encoding to Binary VLS | 2022-10-28 09:14:26.541
HD Request # 21 | Sending historical data logon request message. | 2022-10-28 09:14:26.541
HD Request # 21 | Requesting Intraday data. Start date-time: 2022-10-28 08:13:20. Record interval: 1. Symbol: ESZ22 | 2022-10-28 09:14:27.096
HD Request # 21 | Decompressing data. | 2022-10-28 09:14:27.136
HD Request # 21 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-10-28 08:13:20.510000 | 2022-10-28 09:14:27.280
Socket (5) | CloseSocket call. | 2022-10-28 09:14:27.281
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:14:27.281
Historical data download thread signaled to stop. | 2022-10-28 09:14:27.281
HD Request # 21 | Timestamp of first Intraday data file record written: 2022-10-28 08:13:20.510000. | 2022-10-28 09:14:27.281
HD Request # 21 | Received 3266 Intraday data records from 2022-10-28 08:13:20.510000 to 2022-10-28 09:14:25.693000 (61.1 minutes) and wrote 3266 records for ESZ22_FUT_CME | 2022-10-28 09:14:27.281
HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2022-10-28 13:14:25.693000 | 2022-10-28 09:14:27.281
HD Request # 21 | Completion time: 1s. | 2022-10-28 09:14:27.281
HD Request # 21 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 21 | 2022-10-28 09:14:27.282
Removing historical data download ID 21. | 2022-10-28 09:14:27.282
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-10-28 09:14:27.282
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 18004 | 2022-10-28 09:14:27.282
Intraday chart data file opened for ESZ22_FUT_CME | 2022-10-28 09:14:27.282
HD Request # 21 | Enabling Intraday chart updating for symbol. | 2022-10-28 09:14:27.282
Triggering next historical data download in queue. | 2022-10-28 09:14:27.282
HD Request # 22 | Downloading Intraday chart data for NVOL24H-NYSEMKT to the file NVOL24H-NYSEMKT.scid. Service: statscalc | 2022-10-28 09:14:27.282
HD Request # 22 | Download start date-time: 2022-10-28 08:13:20.000000. File last date-time: 2022-10-28 08:13:20.000000 | 2022-10-28 09:14:27.282
HD Request # 22 | Using server: ds4.sierracharts.com port 10149 | 2022-10-28 09:14:27.282
Socket (4) | Creating socket. | 2022-10-28 09:14:27.320
Socket (4) | New receive buffer size: 5242880 | 2022-10-28 09:14:27.320
Socket (4) | Connecting to IP: 142.215.18.105. | 2022-10-28 09:14:27.320
Socket (5) | Socket gracefully closed by remote side. | 2022-10-28 09:14:27.321
Socket (5) | Closed. | 2022-10-28 09:14:27.322
HD Request # 22 | Setting DTC encoding to Binary VLS | 2022-10-28 09:14:27.414
HD Request # 22 | Sending historical data logon request message. | 2022-10-28 09:14:27.414
HD Request # 22 | Requesting Intraday data. Start date-time: 2022-10-28 08:13:20. Record interval: 1. Symbol: NVOL24H-NYSEMKT | 2022-10-28 09:14:27.964
HD Request # 22 | Decompressing data. | 2022-10-28 09:14:28.062
HD Request # 22 | Receiving Intraday data for NVOL24H-NYSEMKT starting at 2022-10-28 08:13:20.000000 | 2022-10-28 09:14:28.182
Socket (4) | CloseSocket call. | 2022-10-28 09:14:28.186
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:14:28.186
Historical data download thread signaled to stop. | 2022-10-28 09:14:28.186
HD Request # 22 | Timestamp of first Intraday data file record written: 2022-10-28 08:13:20.000000. | 2022-10-28 09:14:28.186
HD Request # 22 | Received 3667 Intraday data records from 2022-10-28 08:13:20.000000 to 2022-10-28 09:14:26.000000 (61.1 minutes) and wrote 3667 records for NVOL24H-NYSEMKT | 2022-10-28 09:14:28.186
HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2022-10-28 13:14:26.000000 | 2022-10-28 09:14:28.186
Added 1 Time and Sales records to Intraday data file for NVOL24H-NYSEMKT after download. | 2022-10-28 09:14:28.186
HD Request # 22 | Completion time: 1s. | 2022-10-28 09:14:28.186
HD Request # 22 | Intraday data download complete for NVOL24H-NYSEMKT. Unique request ID: 22 | 2022-10-28 09:14:28.186
Removing historical data download ID 22. | 2022-10-28 09:14:28.186
Real-time Intraday chart data file updates started for NVOL24H-NYSEMKT | 2022-10-28 09:14:28.186
Opened cached Intraday file: C:\SierraChart\Data\NVOL24H-NYSEMKT.scid. Thread ID: 18004 | 2022-10-28 09:14:28.186
Intraday chart data file opened for NVOL24H-NYSEMKT | 2022-10-28 09:14:28.186
HD Request # 22 | Enabling Intraday chart updating for symbol. | 2022-10-28 09:14:28.186
Triggering next historical data download in queue. | 2022-10-28 09:14:28.186
HD Request # 23 | Downloading Intraday chart data for NVOL24H-NYSE_NASDAQ_NYSEMKT to the file NVOL24H-NYSE_NASDAQ_NYSEMKT.scid. Service: statscalc | 2022-10-28 09:14:28.186
HD Request # 23 | Download start date-time: 2022-10-28 08:13:20.000000. File last date-time: 2022-10-28 08:13:20.000000 | 2022-10-28 09:14:28.186
HD Request # 23 | Using server: ds12.sierracharts.com port 10150 | 2022-10-28 09:14:28.187
Socket (4) | Socket gracefully closed by remote side. | 2022-10-28 09:14:28.228
Socket (4) | Closed. | 2022-10-28 09:14:28.229
Socket (5) | Creating socket. | 2022-10-28 09:14:28.239
Socket (5) | New receive buffer size: 5242880 | 2022-10-28 09:14:28.239
Socket (5) | Connecting to IP: 142.215.18.104. | 2022-10-28 09:14:28.239
HD Request # 23 | Setting DTC encoding to Binary VLS | 2022-10-28 09:14:28.330
HD Request # 23 | Sending historical data logon request message. | 2022-10-28 09:14:28.330
Chart #4 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 09:14:28.494
HD Request # 23 | Requesting Intraday data. Start date-time: 2022-10-28 08:13:20. Record interval: 1. Symbol: NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 09:14:28.893
HD Request # 23 | Decompressing data. | 2022-10-28 09:14:28.937
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 09:14:28.996
HD Request # 23 | Receiving Intraday data for NVOL24H-NYSE_NASDAQ_NYSEMKT starting at 2022-10-28 08:13:20.000000 | 2022-10-28 09:14:29.076
Socket (5) | CloseSocket call. | 2022-10-28 09:14:29.077
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:14:29.077
Historical data download thread signaled to stop. | 2022-10-28 09:14:29.078
HD Request # 23 | Timestamp of first Intraday data file record written: 2022-10-28 08:13:20.000000. | 2022-10-28 09:14:29.078
HD Request # 23 | Received 3668 Intraday data records from 2022-10-28 08:13:20.000000 to 2022-10-28 09:14:27.000000 (61.1 minutes) and wrote 3668 records for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 09:14:29.078
HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2022-10-28 13:14:27.000000 | 2022-10-28 09:14:29.078
Added 1 Time and Sales records to Intraday data file for NVOL24H-NYSE_NASDAQ_NYSEMKT after download. | 2022-10-28 09:14:29.078
HD Request # 23 | Completion time: 1s. | 2022-10-28 09:14:29.078
HD Request # 23 | Intraday data download complete for NVOL24H-NYSE_NASDAQ_NYSEMKT. Unique request ID: 23 | 2022-10-28 09:14:29.078
Removing historical data download ID 23. | 2022-10-28 09:14:29.078
Real-time Intraday chart data file updates started for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 09:14:29.078
Opened cached Intraday file: C:\SierraChart\Data\NVOL24H-NYSE_NASDAQ_NYSEMKT.scid. Thread ID: 18004 | 2022-10-28 09:14:29.078
Intraday chart data file opened for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 09:14:29.078
HD Request # 23 | Enabling Intraday chart updating for symbol. | 2022-10-28 09:14:29.078
Triggering next historical data download in queue. | 2022-10-28 09:14:29.078
HD Request # 24 | Downloading Intraday chart data for MESZ22_FUT_CME to the file MESZ22_FUT_CME.scid. Service: cme | 2022-10-28 09:14:29.078
HD Request # 24 | Download start date-time: 2022-10-28 08:13:19.000000. File last date-time: 2022-10-28 08:13:19.000000 | 2022-10-28 09:14:29.079
HD Request # 24 | Using server: ds21.sierracharts.com port 10149 | 2022-10-28 09:14:29.079
Socket (4) | Creating socket. | 2022-10-28 09:14:29.110
Socket (4) | New receive buffer size: 5242880 | 2022-10-28 09:14:29.111
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-10-28 09:14:29.111
Socket (5) | Socket gracefully closed by remote side. | 2022-10-28 09:14:29.117
Socket (5) | Closed. | 2022-10-28 09:14:29.117
HD Request # 24 | Setting DTC encoding to Binary VLS | 2022-10-28 09:14:29.201
HD Request # 24 | Sending historical data logon request message. | 2022-10-28 09:14:29.201
HD Request # 24 | Requesting Intraday data. Start date-time: 2022-10-28 08:13:19. Record interval: 1. Symbol: MESZ22 | 2022-10-28 09:14:29.718
HD Request # 24 | Decompressing data. | 2022-10-28 09:14:29.763
HD Request # 24 | Receiving Intraday data for MESZ22_FUT_CME starting at 2022-10-28 08:13:19.443000 | 2022-10-28 09:14:29.865
Socket (4) | CloseSocket call. | 2022-10-28 09:14:29.867
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:14:29.868
Historical data download thread signaled to stop. | 2022-10-28 09:14:29.868
HD Request # 24 | Timestamp of first Intraday data file record written: 2022-10-28 08:13:19.443000. | 2022-10-28 09:14:29.868
HD Request # 24 | Received 3425 Intraday data records from 2022-10-28 08:13:19.443000 to 2022-10-28 09:14:29.040000 (61.2 minutes) and wrote 3425 records for MESZ22_FUT_CME | 2022-10-28 09:14:29.868
HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2022-10-28 13:14:29.040000 | 2022-10-28 09:14:29.868
HD Request # 24 | Completion time: 0s. | 2022-10-28 09:14:29.868
HD Request # 24 | Intraday data download complete for MESZ22_FUT_CME. Unique request ID: 24 | 2022-10-28 09:14:29.868
Removing historical data download ID 24. | 2022-10-28 09:14:29.868
Real-time Intraday chart data file updates started for MESZ22_FUT_CME | 2022-10-28 09:14:29.868
Opened cached Intraday file: C:\SierraChart\Data\MESZ22_FUT_CME.scid. Thread ID: 18004 | 2022-10-28 09:14:29.868
Intraday chart data file opened for MESZ22_FUT_CME | 2022-10-28 09:14:29.868
HD Request # 24 | Enabling Intraday chart updating for symbol. | 2022-10-28 09:14:29.868
Triggering next historical data download in queue. | 2022-10-28 09:14:29.868
No download requests in the queue to start downloads for. | 2022-10-28 09:14:29.868
Socket (4) | Socket gracefully closed by remote side. | 2022-10-28 09:14:29.905
Socket (4) | Closed. | 2022-10-28 09:14:29.905
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 09:14:30.009
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 09:14:30.503
Saved Chartbook: IB Internals.Cht. Time: 0.0016 seconds. | 2022-10-28 09:20:23.248
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-10-28 09:40:22.938
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:40:22.938
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:22.938
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-28 09:40:22.941
DTC Client socket (3) | CloseSocket call. | 2022-10-28 09:40:22.941
SC Data - All Services | Disconnected from the server. | 2022-10-28 09:40:22.941
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-10-28 09:40:22.941
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:22.942
DTC Client socket (2) | CloseSocket call. | 2022-10-28 09:40:22.942
SC DTC Data with Market Depth | Disconnected from the server. | 2022-10-28 09:40:22.942
Teton CME Order Routing | Disconnected. | 2022-10-28 09:40:22.942
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:22.942
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:40:22.982
DTC Client socket (1) | Closed. | 2022-10-28 09:40:22.982
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 9. | 2022-10-28 09:40:22.982
Current selected Data/Trading service: Rithmic Direct - DTC | 2022-10-28 09:40:22.982
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:40:23.077
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2022-10-28 09:40:23.077
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Connecting to IP: 38.79.0.89. | 2022-10-28 09:40:23.077
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:23.221
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-10-28 09:40:23.442
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | CloseSocket call. | 2022-10-28 09:40:23.445
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 09:40:23.445
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Closed. | 2022-10-28 09:40:23.445
Symbol settings MD5 received. Request ID: 9. | 2022-10-28 09:40:24.981
Requested symbol settings for service code rithmic_v2.trading. Request ID: 10. | 2022-10-28 09:40:24.982
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:40:27.214
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:40:27.216
Symbol settings received. Request ID: 10. | 2022-10-28 09:40:27.656
DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-10-28 09:40:28.310
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-10-28 09:40:28.311
DTC Client socket (4) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:40:28.311
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:40:28.354
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:40:28.354
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:40:28.354
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:40:28.355
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:40:28.492
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:40:28.492
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:40:28.492
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:40:28.492
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:40:28.492
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:28.492
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:40:28.514
DTC Client socket (4) | CloseSocket call. | 2022-10-28 09:40:28.514
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:40:28.514
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:28.514
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:28.514
DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-10-28 09:40:28.558
DTC Client socket (4) | Closed. | 2022-10-28 09:40:28.558
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:40:32.514
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:40:32.519
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:40:32.520
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:40:32.520
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:40:32.520
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:40:32.563
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:40:32.563
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:40:32.563
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:40:32.563
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:40:32.700
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:40:32.700
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:40:32.700
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:40:32.700
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:40:32.700
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:32.700
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:40:32.715
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:40:32.716
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:40:32.716
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:32.716
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:32.716
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:40:32.756
DTC Client socket (1) | Closed. | 2022-10-28 09:40:32.757
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:40:36.724
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:40:36.725
DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-10-28 09:40:36.726
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-10-28 09:40:36.726
DTC Client socket (4) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:40:36.726
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:40:36.766
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:40:36.766
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:40:36.766
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:40:36.766
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:40:36.897
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:40:36.897
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:40:36.897
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:40:36.897
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:40:36.897
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:36.897
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:40:36.909
DTC Client socket (4) | CloseSocket call. | 2022-10-28 09:40:36.910
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:36.911
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:40:36.911
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:36.911
DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-10-28 09:40:36.950
DTC Client socket (4) | Closed. | 2022-10-28 09:40:36.950
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:40:40.904
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:40:40.907
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:40:40.908
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:40:40.909
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:40:40.909
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:40:40.951
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:40:40.951
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:40:40.951
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:40:40.951
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:40:41.090
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:40:41.090
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:40:41.090
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:40:41.090
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:40:41.090
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:41.090
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:40:41.108
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:40:41.109
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:40:41.109
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:41.109
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:41.109
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:40:41.148
DTC Client socket (1) | Closed. | 2022-10-28 09:40:41.148
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:40:45.108
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:40:45.109
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:40:45.110
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:40:45.110
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:40:45.110
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:40:45.149
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:40:45.149
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:40:45.149
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:40:45.149
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:40:45.297
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:40:45.297
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:40:45.297
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:40:45.297
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:40:45.297
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:45.297
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:40:45.335
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:40:45.335
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:40:45.335
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:45.335
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:45.335
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:40:45.373
DTC Client socket (1) | Closed. | 2022-10-28 09:40:45.373
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:40:49.332
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:40:49.338
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:40:49.339
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:40:49.339
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:40:49.339
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:40:49.381
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:40:49.381
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:40:49.382
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:40:49.382
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:40:49.515
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:40:49.515
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:40:49.515
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:40:49.515
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:40:49.515
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:49.515
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:40:49.530
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:40:49.531
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:49.531
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:40:49.531
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:49.531
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:40:49.570
DTC Client socket (1) | Closed. | 2022-10-28 09:40:49.570
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 09:40:53.530
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 09:40:53.536
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:40:53.537
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 09:40:53.537
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 09:40:53.537
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 09:40:53.583
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 09:40:53.583
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 09:40:53.583
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 09:40:53.583
Rithmic Direct - DTC | Received logon response. | 2022-10-28 09:40:53.738
Rithmic Direct - DTC | Server Name: . | 2022-10-28 09:40:53.738
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 09:40:53.738
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 09:40:53.738
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 09:40:53.738
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:53.738
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 09:40:53.753
DTC Client socket (1) | CloseSocket call. | 2022-10-28 09:40:53.753
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:40:53.753
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 09:40:53.753
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 09:40:53.753
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 09:40:53.799
DTC Client socket (1) | Closed. | 2022-10-28 09:40:53.799
File >> Disconnect selected. | 2022-10-28 09:40:53.931
DTC Client socket (0) | CloseSocket call. | 2022-10-28 09:40:53.931
Rithmic Direct - DTC | Disconnected. | 2022-10-28 09:40:53.931
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2022-10-28 09:41:23.531
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2022-10-28 09:41:23.531
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 38.79.0.89. | 2022-10-28 09:41:23.531
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2022-10-28 09:41:23.771
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call. | 2022-10-28 09:41:23.772
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 09:41:23.772
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed. | 2022-10-28 09:41:23.772
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-10-28 09:42:29.118
DTC Client socket (2) | Closed. | 2022-10-28 09:42:29.118
DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-10-28 09:42:29.118
DTC Client socket (3) | Closed. | 2022-10-28 09:42:29.118
DTC Client socket (2) | Deleting network socket now after delay. | 2022-10-28 09:42:59.119
DTC Client socket (3) | Deleting network socket now after delay. | 2022-10-28 09:42:59.119
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 11. | 2022-10-28 11:10:57.796
Current selected Data/Trading service: Teton CME Order Routing | 2022-10-28 11:10:57.796
Symbol settings MD5 received. Request ID: 11. | 2022-10-28 11:10:59.616
Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 12. | 2022-10-28 11:10:59.616
Symbol settings received. Request ID: 12. | 2022-10-28 11:11:02.213
File >> Disconnect selected. | 2022-10-28 11:11:03.429
Teton CME Order Routing | Clearing firm: IronBeam | 2022-10-28 11:11:22.667
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11085 | 2022-10-28 11:11:22.667
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:11:22.697
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:11:22.697
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-10-28 11:11:22.697
Teton CME Order Routing | Network connection to server complete. | 2022-10-28 11:11:22.746
Teton CME Order Routing | Starting socket receive thread. | 2022-10-28 11:11:22.746
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-10-28 11:11:22.746
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-10-28 11:11:22.893
Teton CME Order Routing | Sending logon request message. | 2022-10-28 11:11:22.893
Teton CME Order Routing | Received logon response. | 2022-10-28 11:11:23.405
Teton CME Order Routing | Server Name: SC DTC Server. Build=43909M. | 2022-10-28 11:11:23.405
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:11:23.405
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-10-28 11:11:23.405
Teton CME Order Routing | Trading is supported. | 2022-10-28 11:11:23.405
Teton CME Order Routing | Order cancel and replace is supported. | 2022-10-28 11:11:23.405
Teton CME Order Routing | OCO Orders supported. | 2022-10-28 11:11:23.405
Teton CME Order Routing | Bracket Orders supported. | 2022-10-28 11:11:23.405
Teton CME Order Routing | Connected to server complete. | 2022-10-28 11:11:23.405
Triggering next historical data download in queue. | 2022-10-28 11:11:23.406
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-10-28 11:11:23.406
No download requests in the queue to start downloads for. | 2022-10-28 11:11:23.406
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-10-20 18:12:04.054402 | 2022-10-28 11:11:23.408
Updated verified funded futures trading account ending date to: 2022-11-27 15:11:23 | 2022-10-28 11:11:23.451
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=23051269 | 2022-10-28 11:11:23.460
NVOL24H-NYSEMKT 1 Min #4 | Reloading chart. | 2022-10-28 11:11:28.883
NVOL24H-NYSE_NASDAQ_NYSEMKT 1 Min #5 | Reloading chart. | 2022-10-28 11:11:28.965
TICK-NYSEMKT 1 Min #6 | Reloading chart. | 2022-10-28 11:11:29.135
ESZ22_FUT_CME 60 Min #1 | Reloading chart. | 2022-10-28 11:11:29.326
MESZ22_FUT_CME 1 Min #2 | Reloading chart. | 2022-10-28 11:11:29.721
ESZ22_FUT_CME 60 Min #3 | Reloading chart. | 2022-10-28 11:11:29.763
Chart #4 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:11:29.919
Using symbol data fast lookup vector | 2022-10-28 11:11:29.943
SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL24H-NYSEMKT. ID: 1 Service code: statscalc | 2022-10-28 11:11:29.943
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2022-10-28 11:11:29.943
SC DTC Data with Market Depth | Requesting security definition data for: NVOL24H-NYSEMKT. ID: 1 | 2022-10-28 11:11:29.943
Added historical Intraday data request for NVOL24H-NYSEMKT to the queue. | 2022-10-28 11:11:29.943
Intraday data recording state for symbol NVOL24H-NYSEMKT is set to download 'Pending'. | 2022-10-28 11:11:29.943
Triggering next historical data download in queue. | 2022-10-28 11:11:29.943
DTC Client socket (2) | Creating socket. | 2022-10-28 11:11:29.944
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-28 11:11:29.944
DTC Client socket (2) | Connecting to IP: 142.215.18.105. | 2022-10-28 11:11:29.944
Delaying start of download for NVOL24H-NYSEMKT. | 2022-10-28 11:11:29.944
SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL24H-NYSE_NASDAQ_NYSEMKT. ID: 2 Service code: statscalc | 2022-10-28 11:11:29.944
SC DTC Data with Market Depth | Requesting security definition data for: NVOL24H-NYSE_NASDAQ_NYSEMKT. ID: 2 | 2022-10-28 11:11:29.944
Added historical Intraday data request for NVOL24H-NYSE_NASDAQ_NYSEMKT to the queue. | 2022-10-28 11:11:29.944
Intraday data recording state for symbol NVOL24H-NYSE_NASDAQ_NYSEMKT is set to download 'Pending'. | 2022-10-28 11:11:29.944
Triggering next historical data download in queue. | 2022-10-28 11:11:29.944
SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSEMKT. ID: 3 Service code: statscalc | 2022-10-28 11:11:29.977
SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSEMKT. ID: 3 | 2022-10-28 11:11:29.977
Added historical Intraday data request for TICK-NYSEMKT to the queue. | 2022-10-28 11:11:29.977
Intraday data recording state for symbol TICK-NYSEMKT is set to download 'Pending'. | 2022-10-28 11:11:29.977
Triggering next historical data download in queue. | 2022-10-28 11:11:29.977
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-10-28 11:11:29.982
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 4 Service code: cme | 2022-10-28 11:11:29.982
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-10-28 11:11:29.982
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 4 | 2022-10-28 11:11:29.982
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-10-28 11:11:29.982
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-10-28 11:11:29.982
Triggering next historical data download in queue. | 2022-10-28 11:11:29.982
DTC Client socket (3) | Creating socket. | 2022-10-28 11:11:29.982
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-10-28 11:11:29.982
DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2022-10-28 11:11:29.982
SC DTC Data with Market Depth | Network connection to server complete. | 2022-10-28 11:11:29.984
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-10-28 11:11:29.984
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-28 11:11:29.984
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-28 11:11:30.025
SC Data - All Services | Network connection to server complete. | 2022-10-28 11:11:30.033
SC Data - All Services | Starting socket receive thread. | 2022-10-28 11:11:30.033
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-28 11:11:30.033
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-10-28 11:11:30.046
SC DTC Data with Market Depth | Sending logon request message. | 2022-10-28 11:11:30.046
MESZ22_FUT_CME 1 Min #2 | StartDateTimeForLoadingOrderFills: 2022-09-28 16:05:00 | 2022-10-28 11:11:30.066
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:11:30.172
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-28 11:11:30.196
SC Data - All Services | Sending logon request message. | 2022-10-28 11:11:30.196
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:11:30.235
Mapping MESZ22_FUT_CME to MESZ22. Service code: cme | 2022-10-28 11:11:30.240
SC Data - All Services | Starting real-time market data updates for: MESZ22_FUT_CME (MESZ22). ID: 5 Service code: cme | 2022-10-28 11:11:30.240
SC Data - All Services | Requesting security definition data for: MESZ22_FUT_CME (MESZ22). ID: 5 | 2022-10-28 11:11:30.240
Added historical Intraday data request for MESZ22_FUT_CME to the queue. | 2022-10-28 11:11:30.240
Intraday data recording state for symbol MESZ22_FUT_CME is set to download 'Pending'. | 2022-10-28 11:11:30.240
Triggering next historical data download in queue. | 2022-10-28 11:11:30.240
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-28 11:11:30.286
SC DTC Data with Market Depth | Received logon response. | 2022-10-28 11:11:30.702
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-10-28 11:11:30.702
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:11:30.702
SC DTC Data with Market Depth | Successfully connected. | 2022-10-28 11:11:30.702
SC DTC Data with Market Depth | Trading is not supported. | 2022-10-28 11:11:30.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:11:30.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL24H-NYSEMKT | 2022-10-28 11:11:30.702
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSEMKT | 2022-10-28 11:11:30.702
SC DTC Data with Market Depth | Received security definition for symbol NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:11:30.830
SC DTC Data with Market Depth | Received security definition for symbol NVOL24H-NYSEMKT | 2022-10-28 11:11:30.830
SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSEMKT | 2022-10-28 11:11:30.830
SC Data - All Services | Received logon response. | 2022-10-28 11:11:31.028
SC Data - All Services | Server Name: SC Realtime Server. | 2022-10-28 11:11:31.028
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:11:31.028
SC Data - All Services | Successfully connected. | 2022-10-28 11:11:31.028
SC Data - All Services | Trading is not supported. | 2022-10-28 11:11:31.028
SC Data - All Services | Restarting real-time data updates for symbol: ESZ22_FUT_CME -> ESZ22 | 2022-10-28 11:11:31.028
SC Data - All Services | Restarting real-time data updates for symbol: MESZ22_FUT_CME -> MESZ22 | 2022-10-28 11:11:31.028
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-10-28 11:11:31.176
SC Data - All Services | Received security definition for symbol MESZ22_FUT_CME | 2022-10-28 11:11:31.176
HD Request # 25 | Downloading Intraday chart data for NVOL24H-NYSEMKT to the file NVOL24H-NYSEMKT.scid. Service: statscalc | 2022-10-28 11:11:35.596
HD Request # 25 | Download start date-time: 2022-10-28 09:40:22.000000. File last date-time: 2022-10-28 09:40:22.000000 | 2022-10-28 11:11:35.596
HD Request # 25 | Using server: ds13-3.sierracharts.com port 10150 | 2022-10-28 11:11:35.596
Socket (4) | Creating socket. | 2022-10-28 11:11:35.597
Socket (4) | New receive buffer size: 5242880 | 2022-10-28 11:11:35.597
Socket (4) | Connecting to IP: 162.251.232.235. | 2022-10-28 11:11:35.597
HD Request # 25 | Setting DTC encoding to Binary VLS | 2022-10-28 11:11:35.783
HD Request # 25 | Sending historical data logon request message. | 2022-10-28 11:11:35.783
HD Request # 25 | Requesting Intraday data. Start date-time: 2022-10-28 09:40:22. Record interval: 1. Symbol: NVOL24H-NYSEMKT | 2022-10-28 11:11:36.527
HD Request # 25 | Decompressing data. | 2022-10-28 11:11:36.618
HD Request # 25 | Receiving Intraday data for NVOL24H-NYSEMKT starting at 2022-10-28 09:40:22.000000 | 2022-10-28 11:11:36.978
Socket (4) | CloseSocket call. | 2022-10-28 11:11:36.979
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:11:36.979
Historical data download thread signaled to stop. | 2022-10-28 11:11:36.979
HD Request # 25 | Timestamp of first Intraday data file record written: 2022-10-28 09:40:22.000000. | 2022-10-28 11:11:36.979
HD Request # 25 | Received 5474 Intraday data records from 2022-10-28 09:40:22.000000 to 2022-10-28 11:11:35.000000 (91.2 minutes) and wrote 5474 records for NVOL24H-NYSEMKT | 2022-10-28 11:11:36.979
HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:11:35.000000 | 2022-10-28 11:11:36.980
Added 1 Time and Sales records to Intraday data file for NVOL24H-NYSEMKT after download. | 2022-10-28 11:11:36.980
HD Request # 25 | Completion time: 1s. | 2022-10-28 11:11:36.980
HD Request # 25 | Intraday data download complete for NVOL24H-NYSEMKT. Unique request ID: 25 | 2022-10-28 11:11:36.980
Removing historical data download ID 25. | 2022-10-28 11:11:36.980
Real-time Intraday chart data file updates started for NVOL24H-NYSEMKT | 2022-10-28 11:11:36.980
Opened cached Intraday file: C:\SierraChart\Data\NVOL24H-NYSEMKT.scid. Thread ID: 18004 | 2022-10-28 11:11:36.980
Intraday chart data file opened for NVOL24H-NYSEMKT | 2022-10-28 11:11:36.980
HD Request # 25 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:11:36.980
Triggering next historical data download in queue. | 2022-10-28 11:11:36.980
HD Request # 26 | Downloading Intraday chart data for NVOL24H-NYSE_NASDAQ_NYSEMKT to the file NVOL24H-NYSE_NASDAQ_NYSEMKT.scid. Service: statscalc | 2022-10-28 11:11:36.980
HD Request # 26 | Download start date-time: 2022-10-28 09:40:22.000000. File last date-time: 2022-10-28 09:40:22.000000 | 2022-10-28 11:11:36.980
HD Request # 26 | Using server: ds4.sierracharts.com port 10149 | 2022-10-28 11:11:36.980
Socket (6) | Creating socket. | 2022-10-28 11:11:36.980
Socket (6) | New receive buffer size: 5242880 | 2022-10-28 11:11:36.980
Socket (6) | Connecting to IP: 142.215.18.105. | 2022-10-28 11:11:36.980
Socket (4) | Socket gracefully closed by remote side. | 2022-10-28 11:11:37.066
Socket (4) | Closed. | 2022-10-28 11:11:37.066
HD Request # 26 | Setting DTC encoding to Binary VLS | 2022-10-28 11:11:37.069
HD Request # 26 | Sending historical data logon request message. | 2022-10-28 11:11:37.070
Chart #4 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:11:37.377
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:11:37.621
HD Request # 26 | Requesting Intraday data. Start date-time: 2022-10-28 09:40:22. Record interval: 1. Symbol: NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:11:37.624
HD Request # 26 | Decompressing data. | 2022-10-28 11:11:37.679
HD Request # 26 | Receiving Intraday data for NVOL24H-NYSE_NASDAQ_NYSEMKT starting at 2022-10-28 09:40:22.000000 | 2022-10-28 11:11:37.853
Socket (6) | CloseSocket call. | 2022-10-28 11:11:37.854
Socket (6) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:11:37.854
Historical data download thread signaled to stop. | 2022-10-28 11:11:37.854
HD Request # 26 | Timestamp of first Intraday data file record written: 2022-10-28 09:40:22.000000. | 2022-10-28 11:11:37.855
HD Request # 26 | Received 5474 Intraday data records from 2022-10-28 09:40:22.000000 to 2022-10-28 11:11:35.000000 (91.2 minutes) and wrote 5474 records for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:11:37.855
HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:11:35.000000 | 2022-10-28 11:11:37.855
Added 2 Time and Sales records to Intraday data file for NVOL24H-NYSE_NASDAQ_NYSEMKT after download. | 2022-10-28 11:11:37.855
HD Request # 26 | Completion time: 1s. | 2022-10-28 11:11:37.855
HD Request # 26 | Intraday data download complete for NVOL24H-NYSE_NASDAQ_NYSEMKT. Unique request ID: 26 | 2022-10-28 11:11:37.855
Removing historical data download ID 26. | 2022-10-28 11:11:37.855
Real-time Intraday chart data file updates started for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:11:37.855
Opened cached Intraday file: C:\SierraChart\Data\NVOL24H-NYSE_NASDAQ_NYSEMKT.scid. Thread ID: 18004 | 2022-10-28 11:11:37.855
Intraday chart data file opened for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:11:37.855
HD Request # 26 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:11:37.855
Triggering next historical data download in queue. | 2022-10-28 11:11:37.855
HD Request # 27 | Downloading Intraday chart data for TICK-NYSEMKT to the file TICK-NYSEMKT.scid. Service: statscalc | 2022-10-28 11:11:37.855
HD Request # 27 | Download start date-time: 2022-10-28 09:40:22.000000. File last date-time: 2022-10-28 09:40:22.000000 | 2022-10-28 11:11:37.855
HD Request # 27 | Using server: ds12.sierracharts.com port 10150 | 2022-10-28 11:11:37.855
Socket (4) | Creating socket. | 2022-10-28 11:11:37.856
Socket (4) | New receive buffer size: 5242880 | 2022-10-28 11:11:37.856
Socket (4) | Connecting to IP: 142.215.18.104. | 2022-10-28 11:11:37.856
Socket (6) | Socket gracefully closed by remote side. | 2022-10-28 11:11:37.892
Socket (6) | Closed. | 2022-10-28 11:11:37.892
HD Request # 27 | Setting DTC encoding to Binary VLS | 2022-10-28 11:11:37.955
HD Request # 27 | Sending historical data logon request message. | 2022-10-28 11:11:37.955
HD Request # 27 | Requesting Intraday data. Start date-time: 2022-10-28 09:40:22. Record interval: 1. Symbol: TICK-NYSEMKT | 2022-10-28 11:11:38.511
HD Request # 27 | Decompressing data. | 2022-10-28 11:11:38.551
HD Request # 27 | Receiving Intraday data for TICK-NYSEMKT starting at 2022-10-28 09:40:22.000000 | 2022-10-28 11:11:38.725
Socket (4) | CloseSocket call. | 2022-10-28 11:11:38.726
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:11:38.726
Historical data download thread signaled to stop. | 2022-10-28 11:11:38.726
HD Request # 27 | Timestamp of first Intraday data file record written: 2022-10-28 09:40:22.000000. | 2022-10-28 11:11:38.726
HD Request # 27 | Received 5476 Intraday data records from 2022-10-28 09:40:22.000000 to 2022-10-28 11:11:37.000000 (91.3 minutes) and wrote 5476 records for TICK-NYSEMKT | 2022-10-28 11:11:38.726
HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:11:37.000000 | 2022-10-28 11:11:38.727
Added 1 Time and Sales records to Intraday data file for TICK-NYSEMKT after download. | 2022-10-28 11:11:38.727
HD Request # 27 | Completion time: 1s. | 2022-10-28 11:11:38.727
HD Request # 27 | Intraday data download complete for TICK-NYSEMKT. Unique request ID: 27 | 2022-10-28 11:11:38.727
Removing historical data download ID 27. | 2022-10-28 11:11:38.727
Real-time Intraday chart data file updates started for TICK-NYSEMKT | 2022-10-28 11:11:38.727
Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSEMKT.scid. Thread ID: 18004 | 2022-10-28 11:11:38.727
Intraday chart data file opened for TICK-NYSEMKT | 2022-10-28 11:11:38.727
HD Request # 27 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:11:38.727
Triggering next historical data download in queue. | 2022-10-28 11:11:38.727
HD Request # 28 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-10-28 11:11:38.727
HD Request # 28 | Download start date-time: 2022-10-28 09:40:22.000000. File last date-time: 2022-10-28 09:40:22.000000 | 2022-10-28 11:11:38.727
HD Request # 28 | Using server: ds26.sierracharts.com port 10149 | 2022-10-28 11:11:38.727
Socket (4) | Socket gracefully closed by remote side. | 2022-10-28 11:11:38.767
Socket (4) | Closed. | 2022-10-28 11:11:38.767
Socket (5) | Creating socket. | 2022-10-28 11:11:38.770
Socket (5) | New receive buffer size: 5242880 | 2022-10-28 11:11:38.770
Socket (5) | Connecting to IP: 142.215.18.107. | 2022-10-28 11:11:38.770
HD Request # 28 | Setting DTC encoding to Binary VLS | 2022-10-28 11:11:38.853
HD Request # 28 | Sending historical data logon request message. | 2022-10-28 11:11:38.853
HD Request # 28 | Requesting Intraday data. Start date-time: 2022-10-28 09:40:22. Record interval: 1. Symbol: ESZ22 | 2022-10-28 11:11:39.407
HD Request # 28 | Decompressing data. | 2022-10-28 11:11:39.451
HD Request # 28 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-10-28 09:40:22.000000 | 2022-10-28 11:11:39.639
Socket (5) | CloseSocket call. | 2022-10-28 11:11:39.641
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:11:39.641
Historical data download thread signaled to stop. | 2022-10-28 11:11:39.643
HD Request # 28 | Timestamp of first Intraday data file record written: 2022-10-28 09:40:22.000000. | 2022-10-28 11:11:39.643
HD Request # 28 | Received 5461 Intraday data records from 2022-10-28 09:40:22.000000 to 2022-10-28 11:11:36.045000 (91.2 minutes) and wrote 5461 records for ESZ22_FUT_CME | 2022-10-28 11:11:39.643
HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:11:36.045000 | 2022-10-28 11:11:39.643
Added 2 Time and Sales records to Intraday data file for ESZ22_FUT_CME after download. | 2022-10-28 11:11:39.643
HD Request # 28 | Completion time: 1s. | 2022-10-28 11:11:39.643
HD Request # 28 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 28 | 2022-10-28 11:11:39.643
Removing historical data download ID 28. | 2022-10-28 11:11:39.643
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-10-28 11:11:39.643
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 18004 | 2022-10-28 11:11:39.644
Intraday chart data file opened for ESZ22_FUT_CME | 2022-10-28 11:11:39.644
HD Request # 28 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:11:39.644
Triggering next historical data download in queue. | 2022-10-28 11:11:39.644
HD Request # 29 | Downloading Intraday chart data for MESZ22_FUT_CME to the file MESZ22_FUT_CME.scid. Service: cme | 2022-10-28 11:11:39.644
HD Request # 29 | Download start date-time: 2022-10-28 09:40:22.000000. File last date-time: 2022-10-28 09:40:22.000000 | 2022-10-28 11:11:39.644
HD Request # 29 | Using server: ds21.sierracharts.com port 10150 | 2022-10-28 11:11:39.644
Socket (4) | Creating socket. | 2022-10-28 11:11:39.644
Socket (4) | New receive buffer size: 5242880 | 2022-10-28 11:11:39.644
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-10-28 11:11:39.644
Socket (5) | Socket gracefully closed by remote side. | 2022-10-28 11:11:39.684
Socket (5) | Closed. | 2022-10-28 11:11:39.684
HD Request # 29 | Setting DTC encoding to Binary VLS | 2022-10-28 11:11:39.733
HD Request # 29 | Sending historical data logon request message. | 2022-10-28 11:11:39.733
HD Request # 29 | Requesting Intraday data. Start date-time: 2022-10-28 09:40:22. Record interval: 1. Symbol: MESZ22 | 2022-10-28 11:11:40.264
HD Request # 29 | Decompressing data. | 2022-10-28 11:11:40.307
HD Request # 29 | Receiving Intraday data for MESZ22_FUT_CME starting at 2022-10-28 09:40:22.002000 | 2022-10-28 11:11:40.474
Socket (4) | CloseSocket call. | 2022-10-28 11:11:40.475
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:11:40.475
Historical data download thread signaled to stop. | 2022-10-28 11:11:40.475
HD Request # 29 | Timestamp of first Intraday data file record written: 2022-10-28 09:40:22.002000. | 2022-10-28 11:11:40.476
HD Request # 29 | Received 5469 Intraday data records from 2022-10-28 09:40:22.002000 to 2022-10-28 11:11:37.061000 (91.3 minutes) and wrote 5469 records for MESZ22_FUT_CME | 2022-10-28 11:11:40.476
HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:11:37.061000 | 2022-10-28 11:11:40.476
Added 3 Time and Sales records to Intraday data file for MESZ22_FUT_CME after download. | 2022-10-28 11:11:40.476
HD Request # 29 | Completion time: 1s. | 2022-10-28 11:11:40.476
HD Request # 29 | Intraday data download complete for MESZ22_FUT_CME. Unique request ID: 29 | 2022-10-28 11:11:40.476
Removing historical data download ID 29. | 2022-10-28 11:11:40.476
Real-time Intraday chart data file updates started for MESZ22_FUT_CME | 2022-10-28 11:11:40.476
Opened cached Intraday file: C:\SierraChart\Data\MESZ22_FUT_CME.scid. Thread ID: 18004 | 2022-10-28 11:11:40.476
Intraday chart data file opened for MESZ22_FUT_CME | 2022-10-28 11:11:40.476
HD Request # 29 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:11:40.476
Triggering next historical data download in queue. | 2022-10-28 11:11:40.476
No download requests in the queue to start downloads for. | 2022-10-28 11:11:40.476
Socket (4) | Socket gracefully closed by remote side. | 2022-10-28 11:11:40.516
Socket (4) | Closed. | 2022-10-28 11:11:40.516
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:11:40.718
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:11:41.141
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:13:32.229
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:13:32.300
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:13:39.533
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:13:39.735
File >> Disconnect selected. | 2022-10-28 11:22:32.705
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-10-28 11:22:32.706
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:22:32.706
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-10-28 11:22:32.706
DTC Client socket (1) | Max send buffer size during socket life: 235 | 2022-10-28 11:22:32.706
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:22:32.706
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-28 11:22:32.706
DTC Client socket (3) | CloseSocket call. | 2022-10-28 11:22:32.706
SC Data - All Services | Disconnected from the server. | 2022-10-28 11:22:32.706
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-10-28 11:22:32.706
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:22:32.706
DTC Client socket (2) | CloseSocket call. | 2022-10-28 11:22:32.706
SC DTC Data with Market Depth | Disconnected from the server. | 2022-10-28 11:22:32.706
Teton CME Order Routing | Disconnected. | 2022-10-28 11:22:32.707
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:22:32.707
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:22:32.749
DTC Client socket (1) | Closed. | 2022-10-28 11:22:32.749
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-10-28 11:25:00.753
DTC Client socket (2) | Closed. | 2022-10-28 11:25:00.753
DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-10-28 11:25:00.753
DTC Client socket (3) | Closed. | 2022-10-28 11:25:00.753
DTC Client socket (2) | Deleting network socket now after delay. | 2022-10-28 11:25:30.762
DTC Client socket (3) | Deleting network socket now after delay. | 2022-10-28 11:25:30.762
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 13. | 2022-10-28 11:25:36.407
Current selected Data/Trading service: Rithmic Direct - DTC | 2022-10-28 11:25:36.407
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2022-10-28 11:25:36.978
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | New receive buffer size: 32768 | 2022-10-28 11:25:36.978
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Connecting to IP: 38.79.0.89. | 2022-10-28 11:25:36.978
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2022-10-28 11:25:37.211
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | CloseSocket call. | 2022-10-28 11:25:37.213
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 11:25:37.214
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (2) | Closed. | 2022-10-28 11:25:37.214
Symbol settings MD5 received. Request ID: 13. | 2022-10-28 11:25:38.193
Requested symbol settings for service code rithmic_v2.trading. Request ID: 14. | 2022-10-28 11:25:38.193
Symbol settings received. Request ID: 14. | 2022-10-28 11:25:40.814
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:09.310
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:09.313
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:09.419
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:09.420
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:09.420
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:09.467
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:09.467
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:09.467
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:09.467
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:09.606
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:09.606
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:09.606
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:09.606
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:09.606
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:09.606
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:09.638
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:09.638
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:09.638
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:09.638
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:09.638
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:09.678
DTC Client socket (1) | Closed. | 2022-10-28 11:26:09.678
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:13.639
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:13.644
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:13.645
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:13.645
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:13.645
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:13.686
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:13.686
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:13.686
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:13.686
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:13.825
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:13.825
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:13.825
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:13.825
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:13.825
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:13.825
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:13.842
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:13.843
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:13.843
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:13.843
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:13.843
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:13.888
DTC Client socket (1) | Closed. | 2022-10-28 11:26:13.888
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:17.840
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:17.844
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:17.845
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:17.845
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:17.845
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:17.883
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:17.883
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:17.883
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:17.883
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:18.026
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:18.026
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:18.026
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:18.026
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:18.026
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:18.026
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:18.053
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:18.054
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:18.054
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:18.054
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:18.054
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:18.099
DTC Client socket (1) | Closed. | 2022-10-28 11:26:18.100
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:22.044
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:22.044
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:22.045
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:22.045
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:22.045
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:22.087
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:22.087
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:22.087
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:22.087
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:22.220
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:22.220
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:22.220
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:22.220
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:22.220
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:22.220
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:22.231
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:22.232
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:22.232
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:22.233
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:22.233
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:22.272
DTC Client socket (1) | Closed. | 2022-10-28 11:26:22.272
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:26.231
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:26.234
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:26.235
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:26.235
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:26.235
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:26.277
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:26.277
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:26.277
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:26.277
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:26.409
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:26.409
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:26.409
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:26.409
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:26.409
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:26.409
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:26.418
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:26.419
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:26.419
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:26.420
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:26.420
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:26.459
DTC Client socket (1) | Closed. | 2022-10-28 11:26:26.460
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:30.418
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:30.422
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:30.422
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:30.423
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:30.423
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:30.467
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:30.467
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:30.467
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:30.467
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:30.606
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:30.606
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:30.606
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:30.606
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:30.606
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:30.606
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:30.627
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:30.628
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:30.628
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:30.628
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:30.628
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:30.666
DTC Client socket (1) | Closed. | 2022-10-28 11:26:30.667
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:34.624
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:34.627
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:34.628
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:34.628
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:34.628
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:34.671
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:34.671
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:34.671
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:34.671
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:34.805
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:34.805
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:34.805
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:34.805
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:34.805
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:34.805
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:34.812
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:34.813
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:34.813
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:34.813
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:34.813
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:34.853
DTC Client socket (1) | Closed. | 2022-10-28 11:26:34.853
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:38.821
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:38.822
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:38.822
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:38.822
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:38.822
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:38.866
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:38.866
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:38.867
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:38.867
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:39.012
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:39.012
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:39.012
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:39.012
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:39.012
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:39.012
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:39.039
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:39.040
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:39.040
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:39.040
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:39.040
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:39.081
DTC Client socket (1) | Closed. | 2022-10-28 11:26:39.081
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:43.030
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:43.033
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:43.034
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:43.034
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:43.034
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:43.077
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:43.077
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:43.077
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:43.077
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:43.208
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:43.208
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:43.208
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:43.208
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:43.208
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:43.208
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:43.217
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:43.218
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:43.218
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:43.218
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:43.218
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:43.258
DTC Client socket (1) | Closed. | 2022-10-28 11:26:43.258
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:47.225
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:47.227
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:47.228
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:47.228
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:47.229
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:47.279
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:47.279
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:47.279
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:47.279
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:47.407
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:47.407
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:47.407
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:47.407
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:47.407
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:47.407
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:47.418
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:47.420
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:47.420
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:47.420
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:47.420
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:47.459
DTC Client socket (1) | Closed. | 2022-10-28 11:26:47.460
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:51.427
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:51.428
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:51.428
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:51.428
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:51.428
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:51.467
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:51.467
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:51.467
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:51.467
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:51.601
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:51.601
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:51.601
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:51.601
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:51.601
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:51.601
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:51.615
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:51.616
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:51.617
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:51.617
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:51.618
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:51.656
DTC Client socket (1) | Closed. | 2022-10-28 11:26:51.656
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:55.613
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:55.617
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:55.618
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:55.618
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:55.618
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:55.657
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:55.657
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:55.657
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:55.657
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:55.793
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:55.793
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:55.793
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:55.793
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:55.793
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:55.793
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:26:55.819
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:26:55.819
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:26:55.819
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:55.819
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:26:55.819
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:26:55.858
DTC Client socket (1) | Closed. | 2022-10-28 11:26:55.858
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:26:59.815
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:26:59.817
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:26:59.818
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:26:59.819
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:26:59.819
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:26:59.861
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:26:59.861
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:26:59.861
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:26:59.861
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:26:59.995
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:26:59.995
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:26:59.995
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:26:59.995
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:26:59.995
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:26:59.995
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:00.017
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:00.017
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:00.017
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:00.017
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:00.017
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:00.056
DTC Client socket (1) | Closed. | 2022-10-28 11:27:00.056
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:04.019
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:04.022
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:04.023
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:04.023
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:04.023
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:04.063
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:04.063
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:04.064
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:04.064
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:04.194
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:04.194
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:04.194
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:04.194
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:04.194
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:04.194
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:04.213
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:04.214
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:04.214
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:04.214
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:04.215
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:04.254
DTC Client socket (1) | Closed. | 2022-10-28 11:27:04.254
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:08.226
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:08.228
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:08.229
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:08.229
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:08.229
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:08.271
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:08.271
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:08.271
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:08.271
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:08.416
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:08.416
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:08.416
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:08.416
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:08.416
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:08.416
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:08.428
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:08.429
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:08.429
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:08.429
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:08.430
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:08.468
DTC Client socket (1) | Closed. | 2022-10-28 11:27:08.469
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:12.428
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:12.430
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:12.432
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:12.432
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:12.432
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:12.474
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:12.474
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:12.474
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:12.474
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:12.612
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:12.612
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:12.612
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:12.612
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:12.612
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:12.612
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:12.631
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:12.631
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:12.631
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:12.631
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:12.631
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:12.674
DTC Client socket (1) | Closed. | 2022-10-28 11:27:12.674
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:16.626
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:16.629
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:16.630
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:16.630
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:16.630
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:16.670
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:16.670
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:16.670
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:16.670
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:16.800
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:16.800
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:16.800
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:16.800
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:16.800
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:16.800
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:16.820
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:16.820
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:16.820
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:16.820
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:16.820
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:16.860
DTC Client socket (1) | Closed. | 2022-10-28 11:27:16.860
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:20.811
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:20.813
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:20.814
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:20.814
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:20.814
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:20.856
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:20.856
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:20.857
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:20.857
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:20.989
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:20.989
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:20.989
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:20.989
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:20.989
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:20.989
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:20.999
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:21.000
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:21.000
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:21.000
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:21.000
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:21.039
DTC Client socket (1) | Closed. | 2022-10-28 11:27:21.039
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:25.009
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:25.011
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:25.012
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:25.012
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:25.012
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:25.052
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:25.052
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:25.052
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:25.052
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:25.185
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:25.185
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:25.185
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:25.185
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:25.185
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:25.185
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:25.198
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:25.199
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:25.199
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:25.199
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:25.199
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:25.239
DTC Client socket (1) | Closed. | 2022-10-28 11:27:25.239
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:29.202
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:29.202
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:29.203
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:29.203
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:29.203
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:29.244
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:29.244
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:29.244
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:29.244
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:29.373
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:29.373
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:29.373
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:29.373
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:29.373
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:29.373
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:29.396
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:29.398
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:29.398
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:29.399
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:29.399
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:29.439
DTC Client socket (1) | Closed. | 2022-10-28 11:27:29.439
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:33.399
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:33.402
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:33.403
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:33.403
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:33.403
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:33.447
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:33.447
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:33.447
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:33.447
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:33.578
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:33.578
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:33.578
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:33.579
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:33.579
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:33.579
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:33.597
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:33.598
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:33.598
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:33.599
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:33.599
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:33.639
DTC Client socket (1) | Closed. | 2022-10-28 11:27:33.639
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:37.594
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:37.594
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:37.594
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:37.594
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:37.594
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:37.634
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:37.634
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:37.634
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:37.634
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:37.766
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:37.766
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:37.766
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:37.766
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:37.766
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:37.766
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:37.780
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:37.781
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:37.781
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:37.781
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:37.781
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:37.820
DTC Client socket (1) | Closed. | 2022-10-28 11:27:37.820
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:41.780
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:41.781
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:41.782
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:41.782
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:41.782
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:41.822
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:41.822
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:41.822
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:41.822
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:41.958
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:41.958
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:41.958
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:41.958
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:41.958
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:41.958
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:41.968
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:41.969
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:41.969
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:41.969
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:41.969
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:42.010
DTC Client socket (1) | Closed. | 2022-10-28 11:27:42.010
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:45.975
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:45.978
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:45.979
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:45.979
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:45.979
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:46.021
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:46.021
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:46.021
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:46.021
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:46.160
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:46.160
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:46.160
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:46.160
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:46.160
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:46.160
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:46.179
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:46.179
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:46.179
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:46.179
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:46.179
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:46.219
DTC Client socket (1) | Closed. | 2022-10-28 11:27:46.220
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:50.172
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:50.175
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:50.176
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:50.176
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:50.176
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:50.220
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:50.220
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:50.221
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:50.221
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:50.353
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:50.353
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:50.353
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:50.353
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:50.353
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:50.353
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:50.359
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:50.359
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:50.360
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:50.360
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:50.360
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:50.402
DTC Client socket (1) | Closed. | 2022-10-28 11:27:50.402
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:54.366
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:54.369
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:54.370
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:54.370
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:54.370
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:54.413
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:54.413
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:54.413
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:54.413
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:54.558
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:54.558
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:54.558
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:54.558
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:54.558
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:54.558
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:54.577
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:54.578
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:54.579
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:54.579
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:54.579
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:54.618
DTC Client socket (1) | Closed. | 2022-10-28 11:27:54.618
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:27:58.575
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:27:58.577
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:27:58.578
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:27:58.578
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:27:58.578
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:27:58.620
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:27:58.620
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:27:58.620
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:27:58.620
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:27:58.754
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:27:58.754
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:27:58.754
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:27:58.754
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:27:58.754
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:58.754
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:27:58.766
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:27:58.768
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:27:58.768
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:27:58.769
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:27:58.769
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:27:58.807
DTC Client socket (1) | Closed. | 2022-10-28 11:27:58.807
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:02.767
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:02.770
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:02.771
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:02.772
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:02.772
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:02.814
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:02.814
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:02.814
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:02.814
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:02.955
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:02.955
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:02.955
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:02.955
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:02.955
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:02.955
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:02.974
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:02.975
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:02.976
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:02.976
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:02.976
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:03.020
DTC Client socket (1) | Closed. | 2022-10-28 11:28:03.020
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:06.979
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:06.983
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:06.984
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:06.984
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:06.985
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:07.028
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:07.028
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:07.028
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:07.028
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:07.159
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:07.159
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:07.159
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:07.159
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:07.159
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:07.159
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:07.170
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:07.171
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:07.171
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:07.171
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:07.171
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:07.210
DTC Client socket (1) | Closed. | 2022-10-28 11:28:07.211
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:11.178
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:11.181
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:11.182
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:11.183
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:11.183
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:11.223
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:11.223
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:11.223
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:11.223
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:11.361
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:11.361
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:11.361
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:11.361
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:11.361
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:11.361
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:11.376
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:11.376
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:11.376
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:11.376
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:11.376
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:11.416
DTC Client socket (1) | Closed. | 2022-10-28 11:28:11.416
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:15.370
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:15.373
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:15.374
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:15.374
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:15.374
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:15.418
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:15.418
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:15.418
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:15.418
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:15.552
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:15.552
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:15.552
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:15.552
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:15.552
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:15.552
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:15.565
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:15.567
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:15.567
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:15.567
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:15.567
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:15.606
DTC Client socket (1) | Closed. | 2022-10-28 11:28:15.606
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:19.567
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:19.569
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:19.570
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:19.570
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:19.570
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:19.614
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:19.614
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:19.614
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:19.614
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:19.755
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:19.755
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:19.755
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:19.755
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:19.755
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:19.755
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:19.769
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:19.770
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:19.770
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:19.770
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:19.770
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:19.811
DTC Client socket (1) | Closed. | 2022-10-28 11:28:19.811
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:23.761
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:23.762
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:23.762
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:23.762
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:23.762
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:23.803
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:23.803
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:23.803
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:23.803
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:23.937
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:23.937
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:23.937
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:23.937
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:23.937
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:23.937
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:23.960
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:23.961
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:23.961
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:23.962
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:23.962
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:24.004
DTC Client socket (1) | Closed. | 2022-10-28 11:28:24.004
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:27.962
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:27.964
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:27.965
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:27.965
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:27.965
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:28.008
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:28.008
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:28.008
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:28.008
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:28.147
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:28.147
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:28.147
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:28.147
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:28.147
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:28.147
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:28.152
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:28.153
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:28.153
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:28.154
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:28.154
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:28.201
DTC Client socket (1) | Closed. | 2022-10-28 11:28:28.201
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:32.151
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:32.153
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:32.153
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:32.153
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:32.153
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:32.196
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:32.196
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:32.196
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:32.196
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:32.334
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:32.334
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:32.334
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:32.334
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:32.334
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:32.334
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:32.353
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:32.353
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:32.353
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:32.354
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:32.354
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:32.394
DTC Client socket (1) | Closed. | 2022-10-28 11:28:32.394
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:36.345
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:36.348
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:36.349
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:36.349
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:36.349
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:36.390
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:36.390
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:36.390
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:36.390
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:36.532
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:36.532
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:36.532
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:36.532
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:36.532
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:36.532
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:36.547
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:36.548
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:36.548
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:36.548
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:36.548
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:36.594
DTC Client socket (1) | Closed. | 2022-10-28 11:28:36.595
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:40.544
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:40.546
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:40.547
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:40.547
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:40.547
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:40.589
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:40.589
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:40.589
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:40.589
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:48.847
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:48.847
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:48.847
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:48.847
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:48.847
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:48.847
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:48.861
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:48.861
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:48.861
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:48.861
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:48.861
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:48.898
DTC Client socket (1) | Closed. | 2022-10-28 11:28:48.898
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:52.862
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:52.866
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:52.867
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:52.867
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:52.867
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:52.906
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:52.906
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:52.906
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:52.906
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:53.041
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:53.041
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:53.041
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:53.041
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:53.041
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:53.041
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:53.050
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:53.050
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:53.051
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:53.051
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:53.051
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:53.088
DTC Client socket (1) | Closed. | 2022-10-28 11:28:53.089
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:28:57.050
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:28:57.052
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:28:57.052
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:28:57.052
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:28:57.052
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:28:57.093
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:28:57.093
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:28:57.093
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:28:57.093
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:28:57.228
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:28:57.228
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:28:57.228
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:28:57.228
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:28:57.228
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:57.228
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:28:57.238
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:28:57.239
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:28:57.239
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:28:57.239
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:28:57.239
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:28:57.278
DTC Client socket (1) | Closed. | 2022-10-28 11:28:57.279
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:01.245
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:01.246
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:01.246
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:01.246
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:01.246
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:01.286
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:01.286
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:01.286
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:01.286
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:01.420
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:01.420
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:01.420
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:01.420
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:01.420
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:01.420
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:01.443
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:01.443
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:01.443
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:01.443
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:01.443
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:01.481
DTC Client socket (1) | Closed. | 2022-10-28 11:29:01.481
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:05.445
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:05.446
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:05.446
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:05.446
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:05.446
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:05.483
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:05.483
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:05.483
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:05.483
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:05.621
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:05.621
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:05.621
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:05.621
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:05.621
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:05.621
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:05.646
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:05.648
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:05.648
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:05.650
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:05.650
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:05.693
DTC Client socket (1) | Closed. | 2022-10-28 11:29:05.693
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:09.642
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:09.643
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:09.644
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:09.644
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:09.644
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:09.685
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:09.685
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:09.685
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:09.685
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:09.822
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:09.822
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:09.822
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:09.822
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:09.822
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:09.822
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:09.828
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:09.829
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:09.829
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:09.829
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:09.829
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:09.868
DTC Client socket (1) | Closed. | 2022-10-28 11:29:09.869
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:13.828
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:13.830
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:13.831
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:13.831
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:13.831
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:13.874
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:13.874
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:13.874
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:13.874
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:14.006
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:14.006
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:14.006
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:14.006
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:14.006
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:14.006
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:14.013
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:14.014
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:14.014
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:14.014
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:14.014
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:14.059
DTC Client socket (1) | Closed. | 2022-10-28 11:29:14.059
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:18.016
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:18.020
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:18.021
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:18.021
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:18.021
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:18.064
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:18.064
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:18.064
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:18.064
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:18.202
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:18.202
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:18.202
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:18.202
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:18.202
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:18.202
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:18.215
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:18.216
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:18.216
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:18.216
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:18.216
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:18.257
DTC Client socket (1) | Closed. | 2022-10-28 11:29:18.257
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:22.223
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:22.229
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:22.230
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:22.231
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:22.231
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:22.276
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:22.276
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:22.276
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:22.276
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:22.415
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:22.415
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:22.415
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:22.415
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:22.415
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:22.415
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:22.427
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:22.428
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:22.428
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:22.428
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:22.428
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:22.467
DTC Client socket (1) | Closed. | 2022-10-28 11:29:22.467
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:26.426
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:26.429
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:26.430
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:26.430
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:26.430
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:26.471
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:26.471
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:26.471
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:26.471
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:26.609
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:26.609
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:26.609
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:26.609
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:26.609
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:26.609
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:26.624
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:26.625
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:26.625
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:26.625
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:26.625
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:26.662
DTC Client socket (1) | Closed. | 2022-10-28 11:29:26.662
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:30.628
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:30.633
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:30.634
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:30.634
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:30.634
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:30.675
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:30.675
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:30.675
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:30.675
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:30.812
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:30.812
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:30.812
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:30.812
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:30.812
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:30.812
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:30.833
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:30.833
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:30.833
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:30.833
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:30.833
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:30.874
DTC Client socket (1) | Closed. | 2022-10-28 11:29:30.874
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:34.828
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:34.831
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:34.832
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:34.832
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:34.832
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:34.873
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:34.873
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:34.873
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:34.873
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:35.005
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:35.005
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:35.005
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:35.005
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:35.005
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:35.005
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:35.017
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:35.018
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:35.018
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:35.018
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:35.018
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:35.059
DTC Client socket (1) | Closed. | 2022-10-28 11:29:35.060
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:39.020
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:39.024
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:39.025
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:39.025
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:39.025
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:39.064
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:39.064
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:39.064
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:39.064
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:39.194
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:39.194
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:39.194
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:39.194
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:39.194
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:39.194
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:39.203
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:39.203
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:39.203
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:39.203
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:39.203
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:39.243
DTC Client socket (1) | Closed. | 2022-10-28 11:29:39.243
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:29:43.202
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:29:43.204
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:29:43.205
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:29:43.206
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:29:43.206
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:29:43.245
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:29:43.245
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:29:43.246
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:29:43.246
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:29:43.375
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:29:43.375
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:29:43.375
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:29:43.375
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:29:43.375
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:43.375
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:29:43.399
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:29:43.400
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:29:43.400
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:29:43.401
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:29:43.401
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:29:43.442
DTC Client socket (1) | Closed. | 2022-10-28 11:29:43.442
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:30:13.200
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2022-10-28 11:30:13.200
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 38.79.0.89. | 2022-10-28 11:30:13.200
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 65536 | 2022-10-28 11:30:13.417
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2022-10-28 11:30:13.458
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call. | 2022-10-28 11:30:13.460
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 11:30:13.460
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed. | 2022-10-28 11:30:13.460
File >> Disconnect selected. | 2022-10-28 11:31:28.081
DTC Client socket (0) | CloseSocket call. | 2022-10-28 11:31:28.081
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:31:28.081
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:31:31.769
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:31:31.771
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:31:31.772
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:31:31.773
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:31:31.773
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:31:31.815
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:31:31.815
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:31:31.815
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:31:31.815
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:31:31.958
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:31:31.958
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:31:31.958
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:31:31.958
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:31:31.958
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:31:31.958
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:31:31.979
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:31:31.979
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:31:31.979
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:31:31.980
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:31:31.980
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:31:32.016
DTC Client socket (1) | Closed. | 2022-10-28 11:31:32.016
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:31:35.981
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:31:35.981
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:31:35.982
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:31:35.982
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:31:35.982
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:31:36.025
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:31:36.025
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:31:36.025
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:31:36.025
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:31:36.159
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:31:36.159
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:31:36.159
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:31:36.159
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:31:36.159
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:31:36.159
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:31:36.176
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:31:36.177
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:31:36.177
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:31:36.177
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:31:36.177
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:31:36.214
DTC Client socket (1) | Closed. | 2022-10-28 11:31:36.214
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:31:40.170
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:31:40.176
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:31:40.177
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:31:40.177
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:31:40.177
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:31:40.220
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:31:40.220
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:31:40.220
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:31:40.220
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:31:40.358
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:31:40.358
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:31:40.358
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:31:40.358
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:31:40.358
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:31:40.358
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:31:40.379
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:31:40.380
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:31:40.380
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:31:40.380
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:31:40.380
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:31:40.422
DTC Client socket (1) | Closed. | 2022-10-28 11:31:40.422
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 11:31:44.380
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 11:31:44.382
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:31:44.382
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:31:44.383
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 11:31:44.383
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 11:31:44.423
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 11:31:44.423
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 11:31:44.423
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 11:31:44.423
Rithmic Direct - DTC | Received logon response. | 2022-10-28 11:31:44.569
Rithmic Direct - DTC | Server Name: . | 2022-10-28 11:31:44.569
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:31:44.569
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 11:31:44.569
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 11:31:44.569
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:31:44.569
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 11:31:44.583
DTC Client socket (1) | CloseSocket call. | 2022-10-28 11:31:44.584
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:31:44.584
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 11:31:44.584
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:31:44.584
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 11:31:44.625
DTC Client socket (1) | Closed. | 2022-10-28 11:31:44.625
File >> Disconnect selected. | 2022-10-28 11:31:47.332
DTC Client socket (0) | CloseSocket call. | 2022-10-28 11:31:47.332
Rithmic Direct - DTC | Disconnected. | 2022-10-28 11:31:47.332
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:32:14.373
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | New receive buffer size: 32768 | 2022-10-28 11:32:14.374
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Connecting to IP: 38.79.0.89. | 2022-10-28 11:32:14.374
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Socket gracefully closed by remote side. | 2022-10-28 11:32:14.611
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | CloseSocket call. | 2022-10-28 11:32:14.613
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 11:32:14.614
HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (1) | Closed. | 2022-10-28 11:32:14.614
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 15. | 2022-10-28 11:32:30.028
Current selected Data/Trading service: Teton CME Order Routing | 2022-10-28 11:32:30.028
Symbol settings MD5 received. Request ID: 15. | 2022-10-28 11:32:31.860
Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 16. | 2022-10-28 11:32:31.860
Symbol settings received. Request ID: 16. | 2022-10-28 11:32:34.581
Teton CME Order Routing | Clearing firm: IronBeam | 2022-10-28 11:32:38.433
Teton CME Order Routing | Connecting to the server futurestrading2.sierracharts.com. Port 11085 | 2022-10-28 11:32:38.433
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 11:32:38.471
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 11:32:38.471
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-10-28 11:32:38.472
Teton CME Order Routing | Network connection to server complete. | 2022-10-28 11:32:38.519
Teton CME Order Routing | Starting socket receive thread. | 2022-10-28 11:32:38.519
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-10-28 11:32:38.520
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-10-28 11:32:38.675
Teton CME Order Routing | Sending logon request message. | 2022-10-28 11:32:38.675
Teton CME Order Routing | Received logon response. | 2022-10-28 11:32:39.188
Teton CME Order Routing | Server Name: SC DTC Server. Build=43909M. | 2022-10-28 11:32:39.188
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:32:39.188
Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-10-28 11:32:39.188
Teton CME Order Routing | Trading is supported. | 2022-10-28 11:32:39.188
Teton CME Order Routing | Order cancel and replace is supported. | 2022-10-28 11:32:39.188
Teton CME Order Routing | OCO Orders supported. | 2022-10-28 11:32:39.188
Teton CME Order Routing | Bracket Orders supported. | 2022-10-28 11:32:39.188
Teton CME Order Routing | Connected to server complete. | 2022-10-28 11:32:39.188
Triggering next historical data download in queue. | 2022-10-28 11:32:39.189
Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-10-28 11:32:39.189
No download requests in the queue to start downloads for. | 2022-10-28 11:32:39.189
Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2022-10-20 18:12:04.054402 | 2022-10-28 11:32:39.194
Updated verified funded futures trading account ending date to: 2022-11-27 15:32:39 | 2022-10-28 11:32:39.234
Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=23051269 | 2022-10-28 11:32:39.244
NVOL24H-NYSEMKT 1 Min #4 | Reloading chart. | 2022-10-28 11:32:43.848
NVOL24H-NYSE_NASDAQ_NYSEMKT 1 Min #5 | Reloading chart. | 2022-10-28 11:32:43.912
TICK-NYSEMKT 1 Min #6 | Reloading chart. | 2022-10-28 11:32:43.966
ESZ22_FUT_CME 60 Min #1 | Reloading chart. | 2022-10-28 11:32:44.015
MESZ22_FUT_CME 1 Min #2 | Reloading chart. | 2022-10-28 11:32:44.149
ESZ22_FUT_CME 60 Min #3 | Reloading chart. | 2022-10-28 11:32:44.193
Chart #4 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:32:44.326
Using symbol data fast lookup vector | 2022-10-28 11:32:44.388
SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL24H-NYSEMKT. ID: 1 Service code: statscalc | 2022-10-28 11:32:44.388
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-10-28 11:32:44.388
SC DTC Data with Market Depth | Requesting security definition data for: NVOL24H-NYSEMKT. ID: 1 | 2022-10-28 11:32:44.388
Added historical Intraday data request for NVOL24H-NYSEMKT to the queue. | 2022-10-28 11:32:44.388
Intraday data recording state for symbol NVOL24H-NYSEMKT is set to download 'Pending'. | 2022-10-28 11:32:44.388
Triggering next historical data download in queue. | 2022-10-28 11:32:44.388
DTC Client socket (2) | Creating socket. | 2022-10-28 11:32:44.389
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-28 11:32:44.389
DTC Client socket (2) | Connecting to IP: 142.215.18.104. | 2022-10-28 11:32:44.389
Delaying start of download for NVOL24H-NYSEMKT. | 2022-10-28 11:32:44.389
SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL24H-NYSE_NASDAQ_NYSEMKT. ID: 2 Service code: statscalc | 2022-10-28 11:32:44.403
SC DTC Data with Market Depth | Requesting security definition data for: NVOL24H-NYSE_NASDAQ_NYSEMKT. ID: 2 | 2022-10-28 11:32:44.403
Added historical Intraday data request for NVOL24H-NYSE_NASDAQ_NYSEMKT to the queue. | 2022-10-28 11:32:44.403
Intraday data recording state for symbol NVOL24H-NYSE_NASDAQ_NYSEMKT is set to download 'Pending'. | 2022-10-28 11:32:44.403
Triggering next historical data download in queue. | 2022-10-28 11:32:44.403
SC DTC Data with Market Depth | Network connection to server complete. | 2022-10-28 11:32:44.437
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-10-28 11:32:44.437
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-28 11:32:44.437
SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSEMKT. ID: 3 Service code: statscalc | 2022-10-28 11:32:44.465
SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSEMKT. ID: 3 | 2022-10-28 11:32:44.465
Added historical Intraday data request for TICK-NYSEMKT to the queue. | 2022-10-28 11:32:44.465
Intraday data recording state for symbol TICK-NYSEMKT is set to download 'Pending'. | 2022-10-28 11:32:44.465
Triggering next historical data download in queue. | 2022-10-28 11:32:44.465
MESZ22_FUT_CME 1 Min #2 | StartDateTimeForLoadingOrderFills: 2022-09-28 16:05:00 | 2022-10-28 11:32:44.477
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:32:44.581
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-10-28 11:32:44.606
SC DTC Data with Market Depth | Sending logon request message. | 2022-10-28 11:32:44.606
Mapping ESZ22_FUT_CME to ESZ22. Service code: cme | 2022-10-28 11:32:44.645
SC Data - All Services | Starting real-time market data updates for: ESZ22_FUT_CME (ESZ22). ID: 4 Service code: cme | 2022-10-28 11:32:44.645
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2022-10-28 11:32:44.645
SC Data - All Services | Requesting security definition data for: ESZ22_FUT_CME (ESZ22). ID: 4 | 2022-10-28 11:32:44.645
Added historical Intraday data request for ESZ22_FUT_CME to the queue. | 2022-10-28 11:32:44.645
Intraday data recording state for symbol ESZ22_FUT_CME is set to download 'Pending'. | 2022-10-28 11:32:44.645
Triggering next historical data download in queue. | 2022-10-28 11:32:44.645
DTC Client socket (3) | Creating socket. | 2022-10-28 11:32:44.647
DTC Client socket (3) | New receive buffer size: 5242880 | 2022-10-28 11:32:44.647
DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2022-10-28 11:32:44.647
Mapping MESZ22_FUT_CME to MESZ22. Service code: cme | 2022-10-28 11:32:44.650
SC Data - All Services | Starting real-time market data updates for: MESZ22_FUT_CME (MESZ22). ID: 5 Service code: cme | 2022-10-28 11:32:44.650
SC Data - All Services | Requesting security definition data for: MESZ22_FUT_CME (MESZ22). ID: 5 | 2022-10-28 11:32:44.650
Added historical Intraday data request for MESZ22_FUT_CME to the queue. | 2022-10-28 11:32:44.650
Intraday data recording state for symbol MESZ22_FUT_CME is set to download 'Pending'. | 2022-10-28 11:32:44.650
Triggering next historical data download in queue. | 2022-10-28 11:32:44.650
Teton CME Order Routing | Received security definition for symbol ESZ22_FUT_CME | 2022-10-28 11:32:44.688
Teton CME Order Routing | Received security definition for symbol MESZ22_FUT_CME | 2022-10-28 11:32:44.693
SC Data - All Services | Network connection to server complete. | 2022-10-28 11:32:44.693
SC Data - All Services | Starting socket receive thread. | 2022-10-28 11:32:44.693
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-10-28 11:32:44.693
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-10-28 11:32:44.751
SC Data - All Services | Sending logon request message. | 2022-10-28 11:32:44.751
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:32:44.969
SC DTC Data with Market Depth | Received logon response. | 2022-10-28 11:32:45.270
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-10-28 11:32:45.270
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:32:45.270
SC DTC Data with Market Depth | Successfully connected. | 2022-10-28 11:32:45.270
SC DTC Data with Market Depth | Trading is not supported. | 2022-10-28 11:32:45.270
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:32:45.270
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NVOL24H-NYSEMKT | 2022-10-28 11:32:45.270
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSEMKT | 2022-10-28 11:32:45.270
SC DTC Data with Market Depth | Received security definition for symbol NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:32:45.397
SC DTC Data with Market Depth | Received security definition for symbol NVOL24H-NYSEMKT | 2022-10-28 11:32:45.397
SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSEMKT | 2022-10-28 11:32:45.397
SC Data - All Services | Received logon response. | 2022-10-28 11:32:45.474
SC Data - All Services | Server Name: SC Realtime Server. | 2022-10-28 11:32:45.474
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 11:32:45.474
SC Data - All Services | Successfully connected. | 2022-10-28 11:32:45.474
SC Data - All Services | Trading is not supported. | 2022-10-28 11:32:45.474
SC Data - All Services | Restarting real-time data updates for symbol: ESZ22_FUT_CME -> ESZ22 | 2022-10-28 11:32:45.474
SC Data - All Services | Restarting real-time data updates for symbol: MESZ22_FUT_CME -> MESZ22 | 2022-10-28 11:32:45.474
SC Data - All Services | Received security definition for symbol ESZ22_FUT_CME | 2022-10-28 11:32:45.599
SC Data - All Services | Received security definition for symbol MESZ22_FUT_CME | 2022-10-28 11:32:45.599
HD Request # 30 | Downloading Intraday chart data for NVOL24H-NYSEMKT to the file NVOL24H-NYSEMKT.scid. Service: statscalc | 2022-10-28 11:32:50.196
HD Request # 30 | Download start date-time: 2022-10-28 11:22:32.000000. File last date-time: 2022-10-28 11:22:32.000000 | 2022-10-28 11:32:50.196
HD Request # 30 | Using server: ds13-3.sierracharts.com port 10149 | 2022-10-28 11:32:50.196
Socket (4) | Creating socket. | 2022-10-28 11:32:50.197
Socket (4) | New receive buffer size: 5242880 | 2022-10-28 11:32:50.197
Socket (4) | Connecting to IP: 162.251.232.235. | 2022-10-28 11:32:50.197
HD Request # 30 | Setting DTC encoding to Binary VLS | 2022-10-28 11:32:50.381
HD Request # 30 | Sending historical data logon request message. | 2022-10-28 11:32:50.381
HD Request # 30 | Requesting Intraday data. Start date-time: 2022-10-28 11:22:32. Record interval: 1. Symbol: NVOL24H-NYSEMKT | 2022-10-28 11:32:51.131
HD Request # 30 | Decompressing data. | 2022-10-28 11:32:51.221
HD Request # 30 | Receiving Intraday data for NVOL24H-NYSEMKT starting at 2022-10-28 11:22:32.000000 | 2022-10-28 11:32:51.317
Socket (4) | CloseSocket call. | 2022-10-28 11:32:51.318
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:32:51.318
Socket (4) | Socket gracefully closed by remote side. | 2022-10-28 11:32:51.406
Socket (4) | Closed. | 2022-10-28 11:32:51.406
Historical data download thread signaled to stop. | 2022-10-28 11:32:51.430
HD Request # 30 | Timestamp of first Intraday data file record written: 2022-10-28 11:22:32.000000. | 2022-10-28 11:32:51.431
HD Request # 30 | Received 618 Intraday data records from 2022-10-28 11:22:32.000000 to 2022-10-28 11:32:49.000000 (10.3 minutes) and wrote 618 records for NVOL24H-NYSEMKT | 2022-10-28 11:32:51.431
HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:32:49.000000 | 2022-10-28 11:32:51.431
Added 1 Time and Sales records to Intraday data file for NVOL24H-NYSEMKT after download. | 2022-10-28 11:32:51.431
HD Request # 30 | Completion time: 1s. | 2022-10-28 11:32:51.431
HD Request # 30 | Intraday data download complete for NVOL24H-NYSEMKT. Unique request ID: 30 | 2022-10-28 11:32:51.431
Removing historical data download ID 30. | 2022-10-28 11:32:51.431
Real-time Intraday chart data file updates started for NVOL24H-NYSEMKT | 2022-10-28 11:32:51.431
Opened cached Intraday file: C:\SierraChart\Data\NVOL24H-NYSEMKT.scid. Thread ID: 18004 | 2022-10-28 11:32:51.431
Intraday chart data file opened for NVOL24H-NYSEMKT | 2022-10-28 11:32:51.431
HD Request # 30 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:32:51.431
Triggering next historical data download in queue. | 2022-10-28 11:32:51.431
HD Request # 31 | Downloading Intraday chart data for NVOL24H-NYSE_NASDAQ_NYSEMKT to the file NVOL24H-NYSE_NASDAQ_NYSEMKT.scid. Service: statscalc | 2022-10-28 11:32:51.431
HD Request # 31 | Download start date-time: 2022-10-28 11:22:32.000000. File last date-time: 2022-10-28 11:22:32.000000 | 2022-10-28 11:32:51.431
HD Request # 31 | Using server: ds4.sierracharts.com port 10150 | 2022-10-28 11:32:51.432
Socket (4) | Creating socket. | 2022-10-28 11:32:51.432
Socket (4) | New receive buffer size: 5242880 | 2022-10-28 11:32:51.432
Socket (4) | Connecting to IP: 142.215.18.105. | 2022-10-28 11:32:51.432
Chart #4 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:32:51.461
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:32:51.477
HD Request # 31 | Setting DTC encoding to Binary VLS | 2022-10-28 11:32:51.517
HD Request # 31 | Sending historical data logon request message. | 2022-10-28 11:32:51.517
HD Request # 31 | Requesting Intraday data. Start date-time: 2022-10-28 11:22:32. Record interval: 1. Symbol: NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:32:52.068
HD Request # 31 | Decompressing data. | 2022-10-28 11:32:52.109
HD Request # 31 | Receiving Intraday data for NVOL24H-NYSE_NASDAQ_NYSEMKT starting at 2022-10-28 11:22:32.000000 | 2022-10-28 11:32:52.110
Socket (4) | CloseSocket call. | 2022-10-28 11:32:52.151
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:32:52.151
Historical data download thread signaled to stop. | 2022-10-28 11:32:52.151
HD Request # 31 | Timestamp of first Intraday data file record written: 2022-10-28 11:22:32.000000. | 2022-10-28 11:32:52.151
HD Request # 31 | Received 619 Intraday data records from 2022-10-28 11:22:32.000000 to 2022-10-28 11:32:50.000000 (10.3 minutes) and wrote 619 records for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:32:52.152
HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:32:50.000000 | 2022-10-28 11:32:52.152
Added 1 Time and Sales records to Intraday data file for NVOL24H-NYSE_NASDAQ_NYSEMKT after download. | 2022-10-28 11:32:52.153
HD Request # 31 | Completion time: 1s. | 2022-10-28 11:32:52.153
HD Request # 31 | Intraday data download complete for NVOL24H-NYSE_NASDAQ_NYSEMKT. Unique request ID: 31 | 2022-10-28 11:32:52.153
Removing historical data download ID 31. | 2022-10-28 11:32:52.153
Real-time Intraday chart data file updates started for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:32:52.153
Opened cached Intraday file: C:\SierraChart\Data\NVOL24H-NYSE_NASDAQ_NYSEMKT.scid. Thread ID: 18004 | 2022-10-28 11:32:52.153
Intraday chart data file opened for NVOL24H-NYSE_NASDAQ_NYSEMKT | 2022-10-28 11:32:52.153
HD Request # 31 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:32:52.153
Triggering next historical data download in queue. | 2022-10-28 11:32:52.153
HD Request # 32 | Downloading Intraday chart data for TICK-NYSEMKT to the file TICK-NYSEMKT.scid. Service: statscalc | 2022-10-28 11:32:52.153
HD Request # 32 | Download start date-time: 2022-10-28 11:22:32.000000. File last date-time: 2022-10-28 11:22:32.000000 | 2022-10-28 11:32:52.154
HD Request # 32 | Using server: ds12.sierracharts.com port 10149 | 2022-10-28 11:32:52.154
Socket (5) | Creating socket. | 2022-10-28 11:32:52.154
Socket (5) | New receive buffer size: 5242880 | 2022-10-28 11:32:52.155
Socket (5) | Connecting to IP: 142.215.18.104. | 2022-10-28 11:32:52.155
Socket (4) | Socket gracefully closed by remote side. | 2022-10-28 11:32:52.193
Socket (4) | Closed. | 2022-10-28 11:32:52.193
HD Request # 32 | Setting DTC encoding to Binary VLS | 2022-10-28 11:32:52.257
HD Request # 32 | Sending historical data logon request message. | 2022-10-28 11:32:52.257
HD Request # 32 | Requesting Intraday data. Start date-time: 2022-10-28 11:22:32. Record interval: 1. Symbol: TICK-NYSEMKT | 2022-10-28 11:32:52.813
HD Request # 32 | Decompressing data. | 2022-10-28 11:32:52.853
HD Request # 32 | Receiving Intraday data for TICK-NYSEMKT starting at 2022-10-28 11:22:32.000000 | 2022-10-28 11:32:52.897
Socket (5) | CloseSocket call. | 2022-10-28 11:32:52.898
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:32:52.898
Historical data download thread signaled to stop. | 2022-10-28 11:32:52.898
HD Request # 32 | Timestamp of first Intraday data file record written: 2022-10-28 11:22:32.000000. | 2022-10-28 11:32:52.899
HD Request # 32 | Received 621 Intraday data records from 2022-10-28 11:22:32.000000 to 2022-10-28 11:32:52.000000 (10.3 minutes) and wrote 621 records for TICK-NYSEMKT | 2022-10-28 11:32:52.899
HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:32:52.000000 | 2022-10-28 11:32:52.900
HD Request # 32 | Completion time: 0s. | 2022-10-28 11:32:52.900
HD Request # 32 | Intraday data download complete for TICK-NYSEMKT. Unique request ID: 32 | 2022-10-28 11:32:52.900
Removing historical data download ID 32. | 2022-10-28 11:32:52.900
Real-time Intraday chart data file updates started for TICK-NYSEMKT | 2022-10-28 11:32:52.900
Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSEMKT.scid. Thread ID: 18004 | 2022-10-28 11:32:52.900
Intraday chart data file opened for TICK-NYSEMKT | 2022-10-28 11:32:52.900
HD Request # 32 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:32:52.900
Triggering next historical data download in queue. | 2022-10-28 11:32:52.900
HD Request # 33 | Downloading Intraday chart data for ESZ22_FUT_CME to the file ESZ22_FUT_CME.scid. Service: cme | 2022-10-28 11:32:52.901
HD Request # 33 | Download start date-time: 2022-10-28 11:22:32.000000. File last date-time: 2022-10-28 11:22:32.000000 | 2022-10-28 11:32:52.901
HD Request # 33 | Using server: ds26.sierracharts.com port 10150 | 2022-10-28 11:32:52.901
Socket (4) | Creating socket. | 2022-10-28 11:32:52.902
Socket (4) | New receive buffer size: 5242880 | 2022-10-28 11:32:52.903
Socket (4) | Connecting to IP: 142.215.18.107. | 2022-10-28 11:32:52.903
Socket (5) | Socket gracefully closed by remote side. | 2022-10-28 11:32:52.940
Socket (5) | Closed. | 2022-10-28 11:32:52.940
HD Request # 33 | Setting DTC encoding to Binary VLS | 2022-10-28 11:32:52.988
HD Request # 33 | Sending historical data logon request message. | 2022-10-28 11:32:52.988
HD Request # 33 | Requesting Intraday data. Start date-time: 2022-10-28 11:22:32. Record interval: 1. Symbol: ESZ22 | 2022-10-28 11:32:53.540
HD Request # 33 | Decompressing data. | 2022-10-28 11:32:53.578
HD Request # 33 | Receiving Intraday data for ESZ22_FUT_CME starting at 2022-10-28 11:22:32.292000 | 2022-10-28 11:32:53.586
Socket (4) | CloseSocket call. | 2022-10-28 11:32:53.587
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:32:53.587
Historical data download thread signaled to stop. | 2022-10-28 11:32:53.587
HD Request # 33 | Timestamp of first Intraday data file record written: 2022-10-28 11:22:32.292000. | 2022-10-28 11:32:53.587
HD Request # 33 | Received 607 Intraday data records from 2022-10-28 11:22:32.292000 to 2022-10-28 11:32:50.111000 (10.3 minutes) and wrote 607 records for ESZ22_FUT_CME | 2022-10-28 11:32:53.587
HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:32:50.111000 | 2022-10-28 11:32:53.588
Added 3 Time and Sales records to Intraday data file for ESZ22_FUT_CME after download. | 2022-10-28 11:32:53.588
HD Request # 33 | Completion time: 1s. | 2022-10-28 11:32:53.588
HD Request # 33 | Intraday data download complete for ESZ22_FUT_CME. Unique request ID: 33 | 2022-10-28 11:32:53.588
Removing historical data download ID 33. | 2022-10-28 11:32:53.588
Real-time Intraday chart data file updates started for ESZ22_FUT_CME | 2022-10-28 11:32:53.588
Opened cached Intraday file: C:\SierraChart\Data\ESZ22_FUT_CME.scid. Thread ID: 18004 | 2022-10-28 11:32:53.588
Intraday chart data file opened for ESZ22_FUT_CME | 2022-10-28 11:32:53.588
HD Request # 33 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:32:53.588
Triggering next historical data download in queue. | 2022-10-28 11:32:53.588
HD Request # 34 | Downloading Intraday chart data for MESZ22_FUT_CME to the file MESZ22_FUT_CME.scid. Service: cme | 2022-10-28 11:32:53.588
HD Request # 34 | Download start date-time: 2022-10-28 11:22:32.000000. File last date-time: 2022-10-28 11:22:32.000000 | 2022-10-28 11:32:53.588
HD Request # 34 | Using server: ds21.sierracharts.com port 10149 | 2022-10-28 11:32:53.588
Socket (5) | Creating socket. | 2022-10-28 11:32:53.589
Socket (5) | New receive buffer size: 5242880 | 2022-10-28 11:32:53.589
Socket (5) | Connecting to IP: 216.1.90.129. | 2022-10-28 11:32:53.589
Socket (4) | Socket gracefully closed by remote side. | 2022-10-28 11:32:53.627
Socket (4) | Closed. | 2022-10-28 11:32:53.628
HD Request # 34 | Setting DTC encoding to Binary VLS | 2022-10-28 11:32:53.672
HD Request # 34 | Sending historical data logon request message. | 2022-10-28 11:32:53.672
HD Request # 34 | Requesting Intraday data. Start date-time: 2022-10-28 11:22:32. Record interval: 1. Symbol: MESZ22 | 2022-10-28 11:32:54.197
HD Request # 34 | Decompressing data. | 2022-10-28 11:32:54.240
HD Request # 34 | Receiving Intraday data for MESZ22_FUT_CME starting at 2022-10-28 11:22:32.008000 | 2022-10-28 11:32:54.247
Socket (5) | CloseSocket call. | 2022-10-28 11:32:54.248
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-10-28 11:32:54.248
Historical data download thread signaled to stop. | 2022-10-28 11:32:54.248
HD Request # 34 | Timestamp of first Intraday data file record written: 2022-10-28 11:22:32.008000. | 2022-10-28 11:32:54.249
HD Request # 34 | Received 608 Intraday data records from 2022-10-28 11:22:32.008000 to 2022-10-28 11:32:50.247000 (10.3 minutes) and wrote 608 records for MESZ22_FUT_CME | 2022-10-28 11:32:54.249
HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2022-10-28 15:32:50.247000 | 2022-10-28 11:32:54.250
Added 3 Time and Sales records to Intraday data file for MESZ22_FUT_CME after download. | 2022-10-28 11:32:54.250
HD Request # 34 | Completion time: 1s. | 2022-10-28 11:32:54.250
HD Request # 34 | Intraday data download complete for MESZ22_FUT_CME. Unique request ID: 34 | 2022-10-28 11:32:54.250
Removing historical data download ID 34. | 2022-10-28 11:32:54.250
Real-time Intraday chart data file updates started for MESZ22_FUT_CME | 2022-10-28 11:32:54.250
Opened cached Intraday file: C:\SierraChart\Data\MESZ22_FUT_CME.scid. Thread ID: 18004 | 2022-10-28 11:32:54.251
Intraday chart data file opened for MESZ22_FUT_CME | 2022-10-28 11:32:54.251
HD Request # 34 | Enabling Intraday chart updating for symbol. | 2022-10-28 11:32:54.251
Triggering next historical data download in queue. | 2022-10-28 11:32:54.251
No download requests in the queue to start downloads for. | 2022-10-28 11:32:54.251
Socket (5) | Socket gracefully closed by remote side. | 2022-10-28 11:32:54.284
Socket (5) | Closed. | 2022-10-28 11:32:54.284
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:32:54.658
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:32:54.991
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:44:05.009
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:44:05.075
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:44:11.609
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:44:12.044
Chart #2 has tagged chart #6 for full recalculation. Chartbook: IB Internals.Cht | 2022-10-28 11:44:14.967
TICK-NYSEMKT[M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IB Internals.Cht | 2022-10-28 11:44:15.049
Saved Chartbook: IB Internals.Cht. Time: 0.0015 seconds. | 2022-10-28 11:44:21.426
File >> Disconnect selected. | 2022-10-28 13:30:18.168
Teton CME Order Routing | Waiting for socket receive thread to end | 2022-10-28 13:30:18.170
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:30:18.170
DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-10-28 13:30:18.170
DTC Client socket (1) | Max send buffer size during socket life: 443 | 2022-10-28 13:30:18.170
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:30:18.170
SC Data - All Services | Waiting for socket receive thread to end | 2022-10-28 13:30:18.170
DTC Client socket (3) | CloseSocket call. | 2022-10-28 13:30:18.170
SC Data - All Services | Disconnected from the server. | 2022-10-28 13:30:18.170
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-10-28 13:30:18.170
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:30:18.170
DTC Client socket (2) | CloseSocket call. | 2022-10-28 13:30:18.171
SC DTC Data with Market Depth | Disconnected from the server. | 2022-10-28 13:30:18.171
Teton CME Order Routing | Disconnected. | 2022-10-28 13:30:18.171
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:30:18.171
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:30:18.213
DTC Client socket (1) | Closed. | 2022-10-28 13:30:18.213
Saved Chartbook: IB Internals.Cht. Time: 0.0017 seconds. | 2022-10-28 13:30:29.754
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-10-28 13:32:32.676
DTC Client socket (2) | Closed. | 2022-10-28 13:32:32.676
DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-10-28 13:32:32.676
DTC Client socket (3) | Closed. | 2022-10-28 13:32:32.676
DTC Client socket (2) | Deleting network socket now after delay. | 2022-10-28 13:33:02.690
DTC Client socket (3) | Deleting network socket now after delay. | 2022-10-28 13:33:02.690
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 17. | 2022-10-28 13:38:59.933
Current selected Data/Trading service: Rithmic Direct - DTC | 2022-10-28 13:38:59.933
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:38:59.999
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2022-10-28 13:38:59.999
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Connecting to IP: 38.79.0.89. | 2022-10-28 13:38:59.999
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-10-28 13:39:00.354
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | CloseSocket call. | 2022-10-28 13:39:00.354
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 13:39:00.354
HTTPS connection ID:1 to www.rithmic.com:443 for request ID:1 (1) | Closed. | 2022-10-28 13:39:00.354
Symbol settings MD5 received. Request ID: 17. | 2022-10-28 13:39:01.730
Requested symbol settings for service code rithmic_v2.trading. Request ID: 18. | 2022-10-28 13:39:01.730
Symbol settings received. Request ID: 18. | 2022-10-28 13:39:04.133
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:39:37.065
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:39:37.066
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-10-28 13:39:37.604
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-10-28 13:39:37.604
DTC Client socket (2) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:39:37.604
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:39:37.645
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:39:37.645
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:39:37.646
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:39:37.646
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:39:37.790
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:39:37.790
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:39:37.790
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:39:37.790
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:39:37.790
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:37.790
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:39:37.839
DTC Client socket (2) | CloseSocket call. | 2022-10-28 13:39:37.839
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:39:37.839
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:39:37.839
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:37.839
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-10-28 13:39:37.881
DTC Client socket (2) | Closed. | 2022-10-28 13:39:37.881
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:39:41.840
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:39:41.840
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:39:41.841
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:39:41.841
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:39:41.841
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:39:41.881
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:39:41.881
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:39:41.881
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:39:41.881
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:39:42.014
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:39:42.014
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:39:42.014
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:39:42.014
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:39:42.014
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:42.014
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:39:42.033
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:39:42.034
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:39:42.034
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:39:42.034
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:42.034
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:39:42.073
DTC Client socket (1) | Closed. | 2022-10-28 13:39:42.073
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:39:46.044
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:39:46.048
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:39:46.049
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:39:46.049
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:39:46.049
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:39:46.090
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:39:46.090
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:39:46.090
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:39:46.090
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:39:46.221
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:39:46.221
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:39:46.221
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:39:46.221
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:39:46.221
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:46.221
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:39:46.239
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:39:46.240
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:39:46.240
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:39:46.240
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:46.240
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:39:46.278
DTC Client socket (1) | Closed. | 2022-10-28 13:39:46.278
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:39:50.233
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:39:50.238
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:39:50.239
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:39:50.240
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:39:50.240
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:39:50.283
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:39:50.283
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:39:50.283
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:39:50.283
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:39:50.426
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:39:50.426
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:39:50.426
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:39:50.426
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:39:50.426
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:50.426
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:39:50.444
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:39:50.444
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:39:50.444
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:50.444
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:39:50.444
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:39:50.488
DTC Client socket (1) | Closed. | 2022-10-28 13:39:50.488
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:39:54.434
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:39:54.439
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:39:54.440
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:39:54.441
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:39:54.441
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:39:54.482
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:39:54.482
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:39:54.483
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:39:54.483
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:39:54.613
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:39:54.613
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:39:54.613
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:39:54.613
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:39:54.613
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:54.613
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:39:54.629
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:39:54.630
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:39:54.631
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:39:54.631
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:54.631
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:39:54.670
DTC Client socket (1) | Closed. | 2022-10-28 13:39:54.670
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:39:58.622
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:39:58.627
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:39:58.628
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:39:58.628
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:39:58.629
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:39:58.669
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:39:58.669
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:39:58.669
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:39:58.669
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:39:58.801
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:39:58.801
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:39:58.801
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:39:58.801
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:39:58.801
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:58.801
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:39:58.810
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:39:58.811
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:39:58.811
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:39:58.811
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:39:58.811
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:39:58.851
DTC Client socket (1) | Closed. | 2022-10-28 13:39:58.851
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:40:02.826
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:40:02.832
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:40:02.832
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:40:02.832
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:40:02.832
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:40:02.871
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:40:02.871
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:40:02.871
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:40:02.871
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:40:03.005
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:40:03.005
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:40:03.005
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:40:03.005
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:40:03.005
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:03.005
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:40:03.013
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:40:03.015
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:40:03.015
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:40:03.015
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:03.015
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:40:03.056
DTC Client socket (1) | Closed. | 2022-10-28 13:40:03.056
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:40:07.015
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:40:07.017
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:40:07.017
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:40:07.017
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:40:07.017
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:40:07.064
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:40:07.064
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:40:07.064
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:40:07.064
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:40:07.195
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:40:07.195
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:40:07.195
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:40:07.195
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:40:07.195
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:07.195
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:40:07.199
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:40:07.200
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:40:07.200
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:40:07.200
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:07.200
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:40:07.240
DTC Client socket (1) | Closed. | 2022-10-28 13:40:07.240
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:40:11.217
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:40:11.219
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:40:11.220
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:40:11.220
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:40:11.220
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:40:11.260
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:40:11.260
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:40:11.260
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:40:11.260
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:40:11.392
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:40:11.392
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:40:11.392
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:40:11.392
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:40:11.392
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:11.392
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:40:11.404
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:40:11.404
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:40:11.405
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:11.405
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:40:11.405
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:40:11.444
DTC Client socket (1) | Closed. | 2022-10-28 13:40:11.444
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:40:15.405
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:40:15.408
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:40:15.409
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:40:15.409
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:40:15.409
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:40:15.450
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:40:15.450
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:40:15.450
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:40:15.450
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:40:15.581
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:40:15.581
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:40:15.581
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:40:15.581
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:40:15.581
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:15.581
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:40:15.597
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:40:15.597
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:40:15.597
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:15.597
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:40:15.597
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:40:15.639
DTC Client socket (1) | Closed. | 2022-10-28 13:40:15.639
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:40:19.599
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:40:19.605
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:40:19.606
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:40:19.606
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:40:19.606
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:40:19.648
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:40:19.649
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:40:19.649
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:40:19.649
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:40:19.785
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:40:19.785
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:40:19.785
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:40:19.785
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:40:19.785
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:19.785
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:40:19.795
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:40:19.795
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:40:19.795
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:40:19.795
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:19.795
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:40:19.835
DTC Client socket (1) | Closed. | 2022-10-28 13:40:19.835
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-10-28 13:40:23.813
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-10-28 13:40:23.817
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:40:23.818
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-10-28 13:40:23.818
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-10-28 13:40:23.818
Rithmic Direct - DTC | Network connection to server complete. | 2022-10-28 13:40:23.857
Rithmic Direct - DTC | Starting socket receive thread. | 2022-10-28 13:40:23.857
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-10-28 13:40:23.857
Rithmic Direct - DTC | Sending logon request message. | 2022-10-28 13:40:23.857
Rithmic Direct - DTC | Received logon response. | 2022-10-28 13:40:23.992
Rithmic Direct - DTC | Server Name: . | 2022-10-28 13:40:23.992
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-10-28 13:40:23.992
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-10-28 13:40:23.992
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-10-28 13:40:23.992
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:23.992
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-10-28 13:40:23.999
DTC Client socket (1) | CloseSocket call. | 2022-10-28 13:40:24.000
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:40:24.000
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-10-28 13:40:24.000
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-10-28 13:40:24.000
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-10-28 13:40:24.039
DTC Client socket (1) | Closed. | 2022-10-28 13:40:24.039
File >> Disconnect selected. | 2022-10-28 13:40:27.118
DTC Client socket (0) | CloseSocket call. | 2022-10-28 13:40:27.118
Rithmic Direct - DTC | Disconnected. | 2022-10-28 13:40:27.118
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2022-10-28 13:40:53.809
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2022-10-28 13:40:53.809
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Connecting to IP: 38.79.0.89. | 2022-10-28 13:40:53.810
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2022-10-28 13:40:54.049
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | CloseSocket call. | 2022-10-28 13:40:54.052
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-10-28 13:40:54.052
HTTPS connection ID:2 to www.rithmic.com:443 for request ID:2 (1) | Closed. | 2022-10-28 13:40:54.052
[2022-10-28 20:39:10]
John - SC Support - Posts: 38806
We are really sorry, but the issue is the following:
There is nothing we can do about this, it is not our issue. Refer to the information we have on this at the following link:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
[2022-10-29 10:05:50]
SSGill - Posts: 36
Hi John;
Can you tell me if it is necessary to have Rithmic loaded before I start Sierra Charts on my PC?
When I load SC, I also always right click and run as administrator.
But for the last 3 months, before Apex got it's own Rithmic connection on 10-24, I was always ONLY running SC WITHOUT loading rithmic first.
[2022-10-30 07:28:19]
Sierra_Chart Engineering - Posts: 18844
No, it is not necessary to run the Rithmic software to use Sierra Chart with Rithmic.
