Date/Time: Sun, 27 Sep 2026 14:18:15 +0000
CQG Setup
View Count: 690
[2022-06-28 17:17:34]
Pak Leung - Posts: 3
I am setup for data through CQG from AMP. I was able to log in under package 11 but there was an error when it was trying to download data. So I figure I would try going into my SC account and activated the Denali data feed and activated the CME bundle. Now I'm able to get live data but I'm having two issues:
1. Can't route any order. Getting message "CQG Order Update. Status: REJECTED......" I contacted AMP they reset the routing but it's still not working. Is this because I have both Denali and CQG activated? (Not the "CQG Denali Feed - Order Routing Only")
2. I'm only able to load about 8 days of data and the settings are exactly the same as when I was testing the demo account. Is the historical feed supposed to be from Denali or CQG?
Please advise what's going on here and what I need to do to get setup.
thank you
[2022-06-28 18:11:05]
John - SC Support - Posts: 48028
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2022-06-28 18:27:58]
I'm having issues on the ES. Symbol F.US.EPU22. I've copied the message and the service log. See below.
Thank you.
MESSAGE LOG
Software version: 2403 64-bit | 2022-06-28 18:23:28.868
Primary Thread ID: 9008 | 2022-06-28 18:23:28.868
Usage end date: 2022-09-27 | 2022-06-28 18:23:28.868
Enabled for: Advanced Features 2. | 2022-06-28 18:23:28.868
Enabled for: Sierra Chart Historical Data Service. | 2022-06-28 18:23:28.868
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-06-28 18:23:28.868
Enabled for: Delayed Denali Exchange Data Feed. | 2022-06-28 18:23:28.868
Enabled for exchange2: CME (Trading Account Required) | 2022-06-28 18:23:28.868
Enabled for exchange2: CBOT (Trading Account Required) | 2022-06-28 18:23:28.868
Enabled for exchange2: COMEX (Trading Account Required) | 2022-06-28 18:23:28.868
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-06-28 18:23:28.868
Enabled for exchange2: fairx_exchange.data | 2022-06-28 18:23:28.868
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-06-28 18:23:28.868
Current selected Data/Trading service: CQG WebAPI | 2022-06-28 18:23:28.868
Custom symbol settings values: enabled | 2022-06-28 18:23:28.868
Chart Update Interval: 500 | 2022-06-28 18:23:28.868
Intraday Data Storage Time Unit: 1 | 2022-06-28 18:23:28.868
Time Zone: +00:00:00 (UTC+00) | 2022-06-28 18:23:28.868
2022-06-28 18:23:28 Local computer time in UTC | 2022-06-28 18:23:28.868
2022-06-28 18:23:28 Local computer time in SC Time Zone | 2022-06-28 18:23:28.868
Program path: C:\SierraChart\ | 2022-06-28 18:23:28.868
Data Files path: C:\SierraChart\Data\ | 2022-06-28 18:23:28.868
OS Version Number: 10.0 | 2022-06-28 18:23:28.868
Locale Setting: C | 2022-06-28 18:23:28.868
DLLs: UserContributedStudies_64.dll | 2022-06-28 18:23:28.868
Allowed protected custom studies: | 2022-06-28 18:23:28.868
Crash reporter started: true | 2022-06-28 18:23:28.868
Sierra Chart account data changed. Requesting updated account information. | 2022-06-28 18:24:45.543
Successfully processed Sierra Chart account data. | 2022-06-28 18:24:47.187
File >> Disconnect selected. | 2022-06-28 18:24:56.362
CQG WebAPI | Sending Web API Logoff message. | 2022-06-28 18:24:56.363
CQG WebSocket socket (1) | CloseSocket call. | 2022-06-28 18:24:56.363
CQG WebSocket | WebSocket closed. | 2022-06-28 18:24:56.363
CQG WebAPI | WebSocket closed. | 2022-06-28 18:24:56.363
CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-06-28 18:24:56.364
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-28 18:24:56.364
DTC Client socket (2) | CloseSocket call. | 2022-06-28 18:24:56.364
SC Data - All Services | Disconnected from the server. | 2022-06-28 18:24:56.364
CQG WebAPI | Disconnected. | 2022-06-28 18:24:56.364
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-28 18:24:56.364
CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2022-06-28 18:24:56.442
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2022-06-28 18:24:56.442
CQG WebAPI | Connecting to server api.cqg.com | 2022-06-28 18:25:07.774
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-06-28 18:25:07.774
CQG WebSocket socket (3) | Creating socket. Using TLS 1.2. | 2022-06-28 18:25:07.775
CQG WebSocket socket (3) | New receive buffer size: 5242880 | 2022-06-28 18:25:07.776
CQG WebSocket socket (3) | Connecting to IP: 208.48.16.35. | 2022-06-28 18:25:07.776
CQG WebSocket | Opening WebSocket. | 2022-06-28 18:25:07.823
CQG WebSocket | Sending WebSocket handshake. | 2022-06-28 18:25:07.823
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-06-28 18:25:08.176
CQG WebSocket | Server header | Connection: upgrade | 2022-06-28 18:25:08.176
CQG WebSocket | Server header | Sec-WebSocket-Accept: bXzaLOEcQXRaKhDGKAODJqbEflk= | 2022-06-28 18:25:08.176
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-06-28 18:25:08.176
CQG WebSocket | Server header | Upgrade: websocket | 2022-06-28 18:25:08.176
CQG WebSocket | Server header | | 2022-06-28 18:25:08.176
CQG WebSocket | Web socket state is now open. | 2022-06-28 18:25:08.176
CQG WebAPI | WebSocket connected. | 2022-06-28 18:25:08.176
CQG WebAPI | Sending market data logon message. | 2022-06-28 18:25:08.176
CQG WebAPI | Base Time: 2022-06-18T06:53:03. 2022-06-18 06:53:03 | 2022-06-28 18:25:08.429
CQG WebAPI | Logon successful. Session Token = FCQsqCSPgw1YvwcBppoqK4LNu/FIt1SHLw52IC9C08QMn8KeUzLHfqZuA92DNwgw4PlyAyzCrXu | 2022-06-28 18:25:08.429
CQG WebAPI | Connected to server complete. | 2022-06-28 18:25:08.429
Triggering next historical data download in queue. | 2022-06-28 18:25:08.430
Updated verified funded futures trading account ending date to: 2022-07-28 18:25:08 | 2022-06-28 18:25:08.430
CQG WebAPI | Sending Trade Accounts request message. | 2022-06-28 18:25:08.433
No download requests in the queue to start downloads for. | 2022-06-28 18:25:08.433
No download requests in the queue to start downloads for. | 2022-06-28 18:25:08.434
CQG WebAPI | Brokerage name: AMP. Account Name: 150764 | 2022-06-28 18:25:08.579
Updated verified funded futures trading account ending date to: 2022-07-28 18:25:08 | 2022-06-28 18:25:08.579
CQG WebAPI | Sending collateral subscribe request. | 2022-06-28 18:25:08.579
Mapping F.US.EPU22 to ESU22. Service code: cme | 2022-06-28 18:25:08.619
Using symbol data fast lookup vector | 2022-06-28 18:25:08.619
SC Data - All Services | Starting real-time market data updates for: F.US.EPU22 (ESU22). ID: 1 Service code: cme | 2022-06-28 18:25:08.619
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-06-28 18:25:08.619
CQG WebAPI | Sending symbol resolution request for F.US.EPU22. ID: 387095 | 2022-06-28 18:25:08.619
SC Data - All Services | Requesting security definition data for: F.US.EPU22 (ESU22). ID: 1 | 2022-06-28 18:25:08.619
Added historical Intraday data request for F.US.EPU22 to the queue. | 2022-06-28 18:25:08.620
Intraday data recording state for symbol F.US.EPU22 is set to download 'Pending'. | 2022-06-28 18:25:08.620
Triggering next historical data download in queue. | 2022-06-28 18:25:08.620
DTC Client socket (4) | Creating socket. | 2022-06-28 18:25:08.620
DTC Client socket (4) | New receive buffer size: 5242880 | 2022-06-28 18:25:08.621
DTC Client socket (4) | Connecting to IP: 216.1.90.130. | 2022-06-28 18:25:08.621
Delaying start of download for F.US.EPU22. | 2022-06-28 18:25:08.630
SC Data - All Services | Network connection to server complete. | 2022-06-28 18:25:08.772
SC Data - All Services | Starting socket receive thread. | 2022-06-28 18:25:08.772
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-28 18:25:08.772
CQG WebAPI | Received symbol resolution report for symbol F.US.EPU22. Search Symbol: F.US.EPU22. Request ID: 387095. Contract ID: 1. | 2022-06-28 18:25:08.773
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-28 18:25:08.997
SC Data - All Services | Sending logon request message. | 2022-06-28 18:25:08.997
SC Data - All Services | Received logon response. | 2022-06-28 18:25:09.834
SC Data - All Services | Server Name: SC Realtime Server. | 2022-06-28 18:25:09.834
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-28 18:25:09.834
SC Data - All Services | Successfully connected. | 2022-06-28 18:25:09.834
SC Data - All Services | Trading is not supported. | 2022-06-28 18:25:09.834
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPU22 -> ESU22 | 2022-06-28 18:25:09.834
SC Data - All Services | Received security definition for symbol F.US.EPU22 | 2022-06-28 18:25:10.054
CQG WebAPI | Sending positions subscribe request. RequestID: 387096 | 2022-06-28 18:25:11.443
CQG WebAPI | Sending orders subscribe request. RequestID: 387097 | 2022-06-28 18:25:11.443
HD Request # 3 | Downloading Intraday chart data for F.US.EPU22 to the file F.US.EPU22.scid. Service: cme | 2022-06-28 18:25:15.879
HD Request # 3 | Download start date-time: 2022-06-28 18:24:55.000000. File last date-time: 2022-06-28 18:24:55.000000 | 2022-06-28 18:25:15.879
HD Request # 3 | Using server: ds21.sierracharts.com port 10150 | 2022-06-28 18:25:15.879
Socket (5) | Creating socket. | 2022-06-28 18:25:15.937
Socket (5) | New receive buffer size: 5242880 | 2022-06-28 18:25:15.937
Socket (5) | Connecting to IP: 216.1.90.129. | 2022-06-28 18:25:15.937
HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-06-28 18:25:16.190
HD Request # 3 | Sending historical data logon request message. | 2022-06-28 18:25:16.190
HD Request # 3 | Requesting Intraday data. Start date-time: 2022-06-28 18:24:55. Record interval: 1. Symbol: ESU22 | 2022-06-28 18:25:16.799
HD Request # 3 | Decompressing data. | 2022-06-28 18:25:16.930
HD Request # 3 | Receiving Intraday data for F.US.EPU22 starting at 2022-06-28 18:24:55.053000 | 2022-06-28 18:25:16.939
Socket (5) | CloseSocket call. | 2022-06-28 18:25:16.940
Historical data download thread signaled to stop. | 2022-06-28 18:25:16.940
Socket (5) | Shutdown started. Waiting for graceful close. | 2022-06-28 18:25:16.940
HD Request # 3 | Timestamp of first Intraday data file record written: 2022-06-28 18:24:55.053000. | 2022-06-28 18:25:16.940
HD Request # 3 | Received 18 Intraday data records from 2022-06-28 18:24:55.053000 to 2022-06-28 18:25:14.120000 (19.1 seconds) and wrote 18 records for F.US.EPU22 | 2022-06-28 18:25:16.940
HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2022-06-28 18:25:14.120000 | 2022-06-28 18:25:16.950
Added 1 Time and Sales records to Intraday data file for F.US.EPU22 after download. | 2022-06-28 18:25:16.950
HD Request # 3 | Completion time: 1s. | 2022-06-28 18:25:16.950
HD Request # 3 | Intraday data download complete for F.US.EPU22. Unique request ID: 3 | 2022-06-28 18:25:16.950
Removing historical data download ID 3. | 2022-06-28 18:25:16.950
Real-time Intraday chart data file updates started for F.US.EPU22 | 2022-06-28 18:25:16.950
Opened cached Intraday file: C:\SierraChart\Data\F.US.EPU22.scid. Thread ID: 9008 | 2022-06-28 18:25:16.959
Intraday chart data file opened for F.US.EPU22 | 2022-06-28 18:25:16.959
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-06-28 18:25:16.959
Triggering next historical data download in queue. | 2022-06-28 18:25:16.959
No download requests in the queue to start downloads for. | 2022-06-28 18:25:16.959
Socket (5) | Socket gracefully closed by remote side. | 2022-06-28 18:25:17.065
Socket (5) | Closed. | 2022-06-28 18:25:17.066
TRADE SERVICE LOG
TradeActivity files query time: 0.011314 seconds. Entries: 0. Current queries: 2 | 2022-06-28 18:21:45.214
TradeActivity files query time: 0.003721 seconds. Entries: 48. Current queries: 2 | 2022-06-28 18:21:45.218
TradeActivity files query time: 0.004538 seconds. Entries: 0. Current queries: 1 | 2022-06-28 18:22:19.423
SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2022-06-28 18:22:21.651
SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2022-06-28 18:22:21.651
SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2022-06-28 18:25:09.834
SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2022-06-28 18:25:09.834
Trade Order Error - CQG order update. Status: REJECTED. Text: Cannot route the order at this time. Internal Order ID: 740. Service Order ID: 1354980136. Symbol: F.US.EPU22. Account: 150764 | 2022-06-28 18:26:01.555 *
Trade Order Error - CQG order update. Status: REJECTED. Text: Cannot route the order at this time. Internal Order ID: 743. Service Order ID: 1354970517. Symbol: F.US.EPU22. Account: 150764 | 2022-06-28 18:26:01.740 *
[2022-06-28 18:48:47]
There is no specific reason why you would not be getting more data into your chart, particularly since you are on the current contract for the symbol. Refer to the following information for how to get more data into an Intraday chart:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
With regards to the order not going through, we see the following in your Trade Service Log:
There is no reason why you should be getting this error, as the market is open. But you will have to ask your broker about why you are getting this. The message is coming from CQG and we are just reporting it. Your broker will have to find out why you are getting this specific error.
