Date/Time: Fri, 14 Mar 2025 19:06:43 +0000
new laptop not able to run new instance SC cqg while desktop Den
View Count: 578
[2022-06-24 17:43:10]
User475862 - Posts: 31
HI got a new laptop and i am not able to run new instance SC cqg while desktop running separate instance using denali/ib. it worked on old laptop. the ONLY way to get data on new laptop is to close ALL desktop so it is not an antivirus issue. if i exit from new laptop and connect one instance CQG on old laptop and on desktop denali/ib all work fine.
hope you can help me fix this puzzle!
thanks
[2022-06-24 20:08:03]
John - SC Support - Posts: 38669
Keep in mind that with version 2394 and higher, we are not allowing CQG data for the CME Group and EUREX into Sierra Chart.
Our guess is that your old laptop was running a version before 2394 and your new one is a more recent version.
Therefore, you have three options:
1) Downgrade the new laptop to version 2393 and connect it to CQG.
or
2) Use the Denali Exchange Data Feed, but only connect to the data from one system or the other at a time. To do this, just set your second system to have the option for Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds to Yes.
or
3) Use the Denali Exchange Data Feed and pay for two connections (twice the exchange fees) so you can use both systems at the same time. Refer to the information here:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
[2022-06-27 14:53:13]
Hi John,
i did option 1
still not working.
also old laptop has version 2398 and it works!
both have the same data feed settings
not sure why one works but not the other!
[2022-06-27 15:08:27]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. We only need to know about one symbol.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-06-27 22:56:00]
Software version: 2393 64-bit | 2022-06-27 22:49:30.419
Primary Thread ID: 23544 | 2022-06-27 22:49:30.419
Usage end date: 2022-09-22 | 2022-06-27 22:49:30.419
Enabled for: Advanced Features 2. | 2022-06-27 22:49:30.419
Enabled for: Sierra Chart Historical Data Service. | 2022-06-27 22:49:30.419
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2022-06-27 22:49:30.419
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-06-27 22:49:30.419
Enabled for: Delayed Denali Exchange Data Feed. | 2022-06-27 22:49:30.420
Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX) | 2022-06-27 22:49:30.420
Enabled for exchange: Euronext Equities Delayed | 2022-06-27 22:49:30.420
Enabled for exchange2: CME (Trading Account Required) | 2022-06-27 22:49:30.420
Enabled for exchange2: CBOT (Trading Account Required) | 2022-06-27 22:49:30.420
Enabled for exchange2: COMEX (Trading Account Required) | 2022-06-27 22:49:30.420
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-06-27 22:49:30.420
Enabled for exchange2: fairx_exchange.data | 2022-06-27 22:49:30.420
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-06-27 22:49:30.420
Current selected Data/Trading service: CQG WebAPI | 2022-06-27 22:49:30.420
Custom symbol settings values: enabled | 2022-06-27 22:49:30.420
Chart Update Interval: 500 | 2022-06-27 22:49:30.420
Intraday Data Storage Time Unit: 0 | 2022-06-27 22:49:30.420
Time Zone: +00:00:00 (UTC+00) | 2022-06-27 22:49:30.420
2022-06-27 22:49:30 Local computer time in UTC | 2022-06-27 22:49:30.420
2022-06-27 22:49:30 Local computer time in SC Time Zone | 2022-06-27 22:49:30.420
2022-06-27 22:46:58 Server time in UTC | 2022-06-27 22:49:30.420
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-06-27 22:49:30.420
Program path: C:\SierraChart\ | 2022-06-27 22:49:30.420
Data Files path: C:\SierraChart\Data\ | 2022-06-27 22:49:30.420
OS Version Number: 10.0 | 2022-06-27 22:49:30.420
Locale Setting: C | 2022-06-27 22:49:30.420
DLLs: sst_FreeBundle_64.dll, UserContributedStudies_64.dll | 2022-06-27 22:49:30.420
Allowed protected custom studies: SST_FreeBundle | 2022-06-27 22:49:30.420
Crash reporter started: true | 2022-06-27 22:49:30.420
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2022-06-27 22:49:31.219
DTC Client socket (2) | Creating socket. | 2022-06-27 22:49:31.220
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-06-27 22:49:31.220
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-06-27 22:49:31.220
SC Data - All Services | Network connection to server complete. | 2022-06-27 22:49:31.265
SC Data - All Services | Starting socket receive thread. | 2022-06-27 22:49:31.265
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-27 22:49:31.266
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-27 22:49:31.334
SC Data - All Services | Sending logon request message. | 2022-06-27 22:49:31.334
SC Data - All Services | Received logon response. | 2022-06-27 22:49:31.974
SC Data - All Services | Server Name: RealTime Server. | 2022-06-27 22:49:31.974
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-27 22:49:31.974
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-06-27 22:49:31.974
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-27 22:49:31.974
DTC Client socket (2) | CloseSocket call. | 2022-06-27 22:49:31.975
SC Data - All Services | Disconnected from the server. | 2022-06-27 22:49:31.975
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-06-27 22:49:31.975
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:49:31.975
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-06-27 22:49:32.008
DTC Client socket (2) | Closed. | 2022-06-27 22:49:32.008
SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 10048 | 2022-06-27 22:50:01.981
DTC Client socket (2) | Creating socket. | 2022-06-27 22:50:01.983
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-06-27 22:50:01.983
DTC Client socket (2) | Connecting to IP: 38.89.235.129. | 2022-06-27 22:50:01.983
SC Data - All Services | Network connection to server complete. | 2022-06-27 22:50:02.034
SC Data - All Services | Starting socket receive thread. | 2022-06-27 22:50:02.034
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-27 22:50:02.034
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-27 22:50:02.088
SC Data - All Services | Sending logon request message. | 2022-06-27 22:50:02.088
SC Data - All Services | Received logon response. | 2022-06-27 22:50:02.785
SC Data - All Services | Server Name: RealTime Server. | 2022-06-27 22:50:02.785
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-27 22:50:02.785
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-06-27 22:50:02.785
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-27 22:50:02.785
DTC Client socket (2) | CloseSocket call. | 2022-06-27 22:50:02.786
SC Data - All Services | Disconnected from the server. | 2022-06-27 22:50:02.786
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-06-27 22:50:02.786
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:50:02.786
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-06-27 22:50:02.862
DTC Client socket (2) | Closed. | 2022-06-27 22:50:02.863
F.US.EPU22 1 Min #1 | Reloading chart. | 2022-06-27 22:50:29.310
Mapping F.US.EPU22 to ESU22. Service code: cme | 2022-06-27 22:50:29.808
SC Data - All Services | Starting real-time market data updates for: F.US.EPU22 (ESU22). ID: 2 Service code: cme | 2022-06-27 22:50:29.809
CQG WebAPI | Sending symbol resolution request for F.US.EPU22. ID: 249962 | 2022-06-27 22:50:29.809
SC Data - All Services | Requesting security definition data for: F.US.EPU22 (ESU22). ID: 2 | 2022-06-27 22:50:29.809
Added historical Intraday data request for F.US.EPU22 to the queue. | 2022-06-27 22:50:29.809
Intraday data recording state for symbol F.US.EPU22 is set to download 'Pending'. | 2022-06-27 22:50:29.809
Triggering next historical data download in queue. | 2022-06-27 22:50:29.809
Delaying start of download for F.US.EPU22. | 2022-06-27 22:50:29.818
CQG WebAPI | Received symbol resolution report for symbol F.US.EPU22. Search Symbol: F.US.EPU22. Request ID: 249962. Contract ID: 2. | 2022-06-27 22:50:29.848
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-06-27 22:50:32.794
DTC Client socket (2) | Creating socket. | 2022-06-27 22:50:32.796
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-06-27 22:50:32.796
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-06-27 22:50:32.796
SC Data - All Services | Network connection to server complete. | 2022-06-27 22:50:32.840
SC Data - All Services | Starting socket receive thread. | 2022-06-27 22:50:32.840
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-27 22:50:32.840
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-27 22:50:32.886
SC Data - All Services | Sending logon request message. | 2022-06-27 22:50:32.886
SC Data - All Services | Received logon response. | 2022-06-27 22:50:33.575
SC Data - All Services | Server Name: RealTime Server. | 2022-06-27 22:50:33.575
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-27 22:50:33.575
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-06-27 22:50:33.575
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-27 22:50:33.576
DTC Client socket (2) | CloseSocket call. | 2022-06-27 22:50:33.577
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:50:33.578
SC Data - All Services | Disconnected from the server. | 2022-06-27 22:50:33.578
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-06-27 22:50:33.579
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-06-27 22:50:33.630
DTC Client socket (2) | Closed. | 2022-06-27 22:50:33.630
HD Request # 2 | Downloading Intraday chart data for F.US.EPU22 to the file F.US.EPU22.scid. Service: cme | 2022-06-27 22:51:00.579
HD Request # 2 | Download start date-time: 2022-06-27 02:48:14.000000. File last date-time: 2022-06-27 02:48:14.791000 | 2022-06-27 22:51:00.579
HD Request # 2 | Using server: ds21.sierracharts.com port 10150 | 2022-06-27 22:51:00.579
Socket (3) | Creating socket. | 2022-06-27 22:51:00.579
Socket (3) | New receive buffer size: 5242880 | 2022-06-27 22:51:00.580
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-06-27 22:51:00.580
HD Request # 2 | Setting DTC encoding to Binary VLS | 2022-06-27 22:51:00.667
HD Request # 2 | Sending historical data logon request message. | 2022-06-27 22:51:00.667
HD Request # 2 | Requesting Intraday data. Start date-time: 2022-06-27 02:48:14. Record interval: 0. Symbol: ESU22 | 2022-06-27 22:51:01.163
HD Request # 2 | Decompressing data. | 2022-06-27 22:51:01.201
HD Request # 2 | Receiving Intraday data for F.US.EPU22 starting at 2022-06-27 02:48:14.124000 | 2022-06-27 22:51:01.275
HD Request # 2 | Timestamp of first Intraday data file record written: 2022-06-27 02:48:17.998000. | 2022-06-27 22:51:01.501
Socket (3) | CloseSocket call. | 2022-06-27 22:51:03.050
Historical data download thread signaled to stop. | 2022-06-27 22:51:03.050
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:51:03.050
HD Request # 2 | Received 1040422 Intraday data records from 2022-06-27 02:48:14.124000 to 2022-06-27 22:51:00.161000 (20.0 hours) and wrote 1040407 records for F.US.EPU22 | 2022-06-27 22:51:03.050
HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2022-06-27 22:51:00.161000 | 2022-06-27 22:51:03.058
HD Request # 2 | Completion time: 3s. | 2022-06-27 22:51:03.058
HD Request # 2 | Intraday data download complete for F.US.EPU22. Unique request ID: 2 | 2022-06-27 22:51:03.058
Removing historical data download ID 2. | 2022-06-27 22:51:03.058
Real-time Intraday chart data file updates started for F.US.EPU22 | 2022-06-27 22:51:03.058
Intraday chart data file opened for F.US.EPU22 | 2022-06-27 22:51:03.058
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2022-06-27 22:51:03.058
Triggering next historical data download in queue. | 2022-06-27 22:51:03.058
No download requests in the queue to start downloads for. | 2022-06-27 22:51:03.058
Socket (3) | Socket gracefully closed by remote side. | 2022-06-27 22:51:03.084
Socket (3) | Closed. | 2022-06-27 22:51:03.084
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-06-27 22:51:03.579
DTC Client socket (2) | Creating socket. | 2022-06-27 22:51:03.580
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-06-27 22:51:03.580
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-06-27 22:51:03.580
SC Data - All Services | Network connection to server complete. | 2022-06-27 22:51:03.626
SC Data - All Services | Starting socket receive thread. | 2022-06-27 22:51:03.626
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-27 22:51:03.626
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-27 22:51:03.673
SC Data - All Services | Sending logon request message. | 2022-06-27 22:51:03.673
SC Data - All Services | Received logon response. | 2022-06-27 22:51:04.328
SC Data - All Services | Server Name: RealTime Server. | 2022-06-27 22:51:04.328
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-27 22:51:04.328
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-06-27 22:51:04.328
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-27 22:51:04.328
DTC Client socket (2) | CloseSocket call. | 2022-06-27 22:51:04.329
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:51:04.330
SC Data - All Services | Disconnected from the server. | 2022-06-27 22:51:04.330
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-06-27 22:51:04.330
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-06-27 22:51:04.366
DTC Client socket (2) | Closed. | 2022-06-27 22:51:04.366
SC Data - All Services | Connecting to the server ds27.sierracharts.com. Port 10048 | 2022-06-27 22:51:34.330
DTC Client socket (2) | Creating socket. | 2022-06-27 22:51:34.331
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-06-27 22:51:34.332
DTC Client socket (2) | Connecting to IP: 208.185.224.128. | 2022-06-27 22:51:34.332
SC Data - All Services | Network connection to server complete. | 2022-06-27 22:51:34.373
SC Data - All Services | Starting socket receive thread. | 2022-06-27 22:51:34.373
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-27 22:51:34.373
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-27 22:51:34.431
SC Data - All Services | Sending logon request message. | 2022-06-27 22:51:34.431
SC Data - All Services | Received logon response. | 2022-06-27 22:51:35.095
SC Data - All Services | Server Name: RealTime Server. | 2022-06-27 22:51:35.095
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-27 22:51:35.095
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-06-27 22:51:35.095
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-27 22:51:35.095
DTC Client socket (2) | CloseSocket call. | 2022-06-27 22:51:35.096
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:51:35.097
SC Data - All Services | Disconnected from the server. | 2022-06-27 22:51:35.097
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-06-27 22:51:35.097
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-06-27 22:51:35.143
DTC Client socket (2) | Closed. | 2022-06-27 22:51:35.144
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2022-06-27 22:52:05.097
DTC Client socket (2) | Creating socket. | 2022-06-27 22:52:05.099
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-06-27 22:52:05.099
DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2022-06-27 22:52:05.099
SC Data - All Services | Network connection to server complete. | 2022-06-27 22:52:05.143
SC Data - All Services | Starting socket receive thread. | 2022-06-27 22:52:05.143
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-27 22:52:05.143
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-27 22:52:05.186
SC Data - All Services | Sending logon request message. | 2022-06-27 22:52:05.186
SC Data - All Services | Received logon response. | 2022-06-27 22:52:05.866
SC Data - All Services | Server Name: RealTime Server. | 2022-06-27 22:52:05.866
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-27 22:52:05.866
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-06-27 22:52:05.866
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-27 22:52:05.866
DTC Client socket (2) | CloseSocket call. | 2022-06-27 22:52:05.869
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:52:05.870
SC Data - All Services | Disconnected from the server. | 2022-06-27 22:52:05.870
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-06-27 22:52:05.871
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-06-27 22:52:05.907
DTC Client socket (2) | Closed. | 2022-06-27 22:52:05.908
SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 443 | 2022-06-27 22:52:35.871
DTC Client socket (2) | Creating socket. | 2022-06-27 22:52:35.872
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-06-27 22:52:35.873
DTC Client socket (2) | Connecting to IP: 38.89.235.129. | 2022-06-27 22:52:35.873
SC Data - All Services | Network connection to server complete. | 2022-06-27 22:52:35.913
SC Data - All Services | Starting socket receive thread. | 2022-06-27 22:52:35.913
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-27 22:52:35.914
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-27 22:52:35.978
SC Data - All Services | Sending logon request message. | 2022-06-27 22:52:35.978
SC Data - All Services | Received logon response. | 2022-06-27 22:52:36.665
SC Data - All Services | Server Name: RealTime Server. | 2022-06-27 22:52:36.665
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-27 22:52:36.665
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-06-27 22:52:36.665
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-27 22:52:36.665
DTC Client socket (2) | CloseSocket call. | 2022-06-27 22:52:36.666
SC Data - All Services | Disconnected from the server. | 2022-06-27 22:52:36.666
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-06-27 22:52:36.666
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:52:36.666
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-06-27 22:52:36.707
DTC Client socket (2) | Closed. | 2022-06-27 22:52:36.707
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2022-06-27 22:52:56.374
The message log has been sent to support. | 2022-06-27 22:52:56.374 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 32768 | 2022-06-27 22:52:56.374
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 95.216.233.104. | 2022-06-27 22:52:56.374
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2022-06-27 22:52:57.138
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | CloseSocket call. | 2022-06-27 22:52:57.377
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:52:57.377
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Socket gracefully closed by remote side. | 2022-06-27 22:52:57.503
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (2) | Closed. | 2022-06-27 22:52:57.503
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-06-27 22:53:06.656
DTC Client socket (2) | Creating socket. | 2022-06-27 22:53:06.656
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-06-27 22:53:06.656
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-06-27 22:53:06.656
SC Data - All Services | Network connection to server complete. | 2022-06-27 22:53:06.695
SC Data - All Services | Starting socket receive thread. | 2022-06-27 22:53:06.695
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-27 22:53:06.695
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-27 22:53:06.784
SC Data - All Services | Sending logon request message. | 2022-06-27 22:53:06.784
SC Data - All Services | Received logon response. | 2022-06-27 22:53:07.428
SC Data - All Services | Server Name: RealTime Server. | 2022-06-27 22:53:07.428
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-27 22:53:07.428
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-06-27 22:53:07.428
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-27 22:53:07.428
DTC Client socket (2) | CloseSocket call. | 2022-06-27 22:53:07.430
SC Data - All Services | Disconnected from the server. | 2022-06-27 22:53:07.430
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-06-27 22:53:07.430
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:53:07.430
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-06-27 22:53:07.466
DTC Client socket (2) | Closed. | 2022-06-27 22:53:07.466
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-06-27 22:53:37.434
DTC Client socket (2) | Creating socket. | 2022-06-27 22:53:37.436
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-06-27 22:53:37.436
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-06-27 22:53:37.436
SC Data - All Services | Network connection to server complete. | 2022-06-27 22:53:37.506
SC Data - All Services | Starting socket receive thread. | 2022-06-27 22:53:37.506
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-06-27 22:53:37.507
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-06-27 22:53:37.575
SC Data - All Services | Sending logon request message. | 2022-06-27 22:53:37.575
SC Data - All Services | Received logon response. | 2022-06-27 22:53:38.243
SC Data - All Services | Server Name: RealTime Server. | 2022-06-27 22:53:38.243
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-06-27 22:53:38.243
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-06-27 22:53:38.243
SC Data - All Services | Waiting for socket receive thread to end | 2022-06-27 22:53:38.243
DTC Client socket (2) | CloseSocket call. | 2022-06-27 22:53:38.245
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-06-27 22:53:38.245
SC Data - All Services | Disconnected from the server. | 2022-06-27 22:53:38.245
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-06-27 22:53:38.246
DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-06-27 22:53:38.309
DTC Client socket (2) | Closed. | 2022-06-27 22:53:38.309
[2022-06-28 10:25:05]
This is the issue:
Refer to:
Denali Exchange Data Feed: Connections
[2022-06-28 13:02:12]
Noted but the laptop connection is thru CQG not Denali
[2022-06-28 13:28:08]
According to the Message Log you provided, that system is trying to get data from our Denali Data Feed, as we see the following:
If you want to get data from CQG on that system, then go to Global Settings >> Data/Trade Service Settings >> Common Settings and set the option for Allow Support For Sierra Chart Data Feeds to No. Then OK to close that window and then select File >> Disconnect followed by File >> Connect to Data Feed and your data will then be coming from CQG.
Just keep in mind that in order to get the data from CQG, you have to be on version 2393 or lower. Refer to the following for more information:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394
