Date/Time: Sun, 09 Mar 2025 00:52:32 +0000
Cannot interact with chart - Charts freezing
View Count: 738
[2022-02-24 15:43:20] |
Alex Q - Posts: 109 |
So I use Sierra on OSX. I have been using crossover to accomplish this. It was been working wonderfully since I started with it 6 months ago, or so. However, I am recently having a problem: The charts seem to freeze as far as there interactive function. I can scroll, or click on a window to have it "in focus", however, I cannot use my hot-keys, I cannot draw/click/drag/place orders with the mouse. Sierra becomes unusable, and I am forced to restart it. It has been happening frequently, and so far about 3 times in the first hour of trade today. Any idea what could be causing this all of a sudden? |
[2022-02-24 16:59:23] |
John - SC Support - Posts: 38516 |
Refer to the following for general information on issues related to lagging/freezing: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often In particular, start with this section on that page: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart But, it could be that the issue you are having is with Crossover, which would be something that we can not help with. There are several users of Sierra Chart that run it on Crossover that might be able to give you some insight if they have had issues and found solutions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-24 19:23:23] |
See if updating Sierra Chart also helps. We have made performance improvements related to the Chart/Trade DOM. Instructions: Software Download: Fast Update This may or may not help in your case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-24 19:23:35
[2022-02-25 21:39:41] |
Just wanted to reach out and say thank you! I put the time in yesterday, and read up on the articles you sent me. Quite the learning curve with Sierra, but I can say I am continually impressed with it's functionality, and in the way you can really get under the hood and fine tune things. I am not running at significantly less CPU, with a FASTER refresh rate on one the charts that matter (my trade DOM and corresponding tape). If anyone is interested I've done as follows: - Changed Global Chart Update Interval to 1000ms. On my 5m, 1hr, 1D charts, this is way more that sufficient. This has freed me up to change my Trade DOM to 100ms, allowing for a more fluid reading of the tape and DOM. So far this has worked well, but if need by I will raise it. - Under "Chart Settings" I have changed days to load to the necessary amount for each time frame, and I have set market depth to load 0 days worth of data on all charts except for my intraday chart, and Trade DOM. They have both been set to load only the current day. This works well with my "Market Depth Historical Graph" which is used to plot only large orders (size depending on product) for the current day. I have also Adjusted all volume profiles/TPO's on higher time frames to aggregate ticks into points. For the NQ I have found that my Daily Chart volume bars can be summed in units of 5 points, and the hourly chart by single points. This frees up the necessary power to represent my intraday execution chart by single ticks for both the Volume by Price, and Delta by Price study. With these changes my CPU runs at about 1/3 of what it was running at before these adjustments. Silky smooth, with no freeze ups, and now the benefit of a more fluid DOM/tape. Again, thank you for your help. Hopefully this breakdown can help others. |
