Date/Time: Fri, 18 Sep 2026 09:48:11 +0000
Data not loading, blank date range field; only historical data loading
View Count: 1165
[2022-02-13 12:19:12]
User283743 - Posts: 38
Random symbol:
XLE-NQTV
Loaded from Find symbol; open intraday chart.
Chart is blank.
In chart settings, the date range field is blank.
Changing chart data type to Historical Chart.
Chart populates.
Changing Chart data type back to intraday chart.
Chart goes blank again.
Trying different random symbol.
AMRN-NQTV
Chart opens and shows bars from 3 to 4 PM. (Session times in chart settings are 9:30 to 16)
Here the date range in File is not blank.
When I change date range to 2022-02-07, dialogue opens:
Do you want to re-download intraday data for the symbol to try to get more data to match the new Date Range in File>> From setting?
Click yes.
Chart populates correctly.
Changing chart symbol to XLE-NQTV.
Chart settings "Date range in File" is blank again.
XLE isn't the only symbol where the intraday data will not load.
This was seen on my sub instance No.3.
When I change to main instance, XLE intraday data loads correctly.
Although I did have similar issues in the past here and there where
intraday data did not load in main instance either.
Please advise.
Just in case have copied log below:
(Log removed)
Date Time Of Last Edit: 2022-02-14 10:10:31
[2022-02-14 10:18:27]
Random symbol:
XLE-NQTV
Chart is blank.
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
AMRN-NQTV
Refer to the information here regarding missing historical Intraday data:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Missing or Incomplete Intraday Chart Data
This might be a Session Times/Time Zone issue.
Date Time Of Last Edit: 2022-02-14 10:19:37
[2022-02-20 12:05:22]
Software version: 2351 64-bit | 2022-02-20 07:03:39.271
Primary Thread ID: 35876 | 2022-02-20 07:03:39.271
Usage end date: 2022-03-10 | 2022-02-20 07:03:39.271
Enabled for: Advanced Features 2. | 2022-02-20 07:03:39.271
Enabled for: Sierra Chart Historical Data Service. | 2022-02-20 07:03:39.271
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-20 07:03:39.271
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-20 07:03:39.271
Enabled for exchange2: CME | 2022-02-20 07:03:39.271
Enabled for exchange2: fairx_exchange.data | 2022-02-20 07:03:39.271
Enabled for exchange2: NASDAQ US stock data | 2022-02-20 07:03:39.271
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-20 07:03:39.271
Current selected Data/Trading service: DTC - Sub Instance | 2022-02-20 07:03:39.271
Custom symbol settings values: enabled | 2022-02-20 07:03:39.271
Chart Update Interval: 1500 | 2022-02-20 07:03:39.271
Intraday Data Storage Time Unit: 0 | 2022-02-20 07:03:39.271
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-02-20 07:03:39.271
2022-02-20 12:03:39 Local computer time in UTC | 2022-02-20 07:03:39.271
2022-02-20 07:03:39 Local computer time in SC Time Zone | 2022-02-20 07:03:39.271
2022-02-20 12:00:06 Server time in UTC | 2022-02-20 07:03:39.271
Local computer UTC time and Server UTC time difference: 5 seconds. | 2022-02-20 07:03:39.271
Notice: Your computer's clock is off by 5 seconds. For help with this, press the 'Send for Analysis' button. | 2022-02-20 07:03:39.271
Program path: E:\SierraChart\SierraChartInstance_3\ | 2022-02-20 07:03:39.271
Data Files path: E:\SierraChart\SierraChartInstance_3\Data\ | 2022-02-20 07:03:39.271
OS Version Number: 10.0 | 2022-02-20 07:03:39.271
Locale Setting: C | 2022-02-20 07:03:39.271
DLLs: GomMPPro.dll, GomMPPro_64.dll, GomOrderFlowPro.dll, GomOrderFlowPro_64.dll, OFA Bars (by Zdislav)_64.dll, TicinoMathV3.0.dll, TicinoMathV3.0_64.dll, tradeinpool.dll, tradingpoolV4_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, WMOv4.dll, WMOv4_64.dll, VolumeTickerComparison_64.dll, VolumeComparison_64.dll, TickStatistics_64.dll, StatisticsBubbles_64.dll, ReconstructedTape_64.dll, ProfileValue_64.dll, ProfilePeriods_64.dll, PriceTickDivergence_64.dll, PrevReferences_64.dll, PivotLine_64.dll | 2022-02-20 07:03:39.272
Allowed protected custom studies: Wem's Orderflow, Wem's Orderflow Analysis, zyp_app, zyp_download_free | 2022-02-20 07:03:39.272
File compression not supported on file system. E:\SierraChart\SierraChartInstance_3\Data\XLE-NQTV.scid. Windows error code 1: Incorrect function. | 2022-02-20 07:03:48.433
Added historical Intraday data request for XLE-NQTV to the queue. | 2022-02-20 07:03:48.433
Intraday data recording state for symbol XLE-NQTV is set to download 'Pending'. | 2022-02-20 07:03:48.433
Triggering next historical data download in queue. | 2022-02-20 07:03:48.433
Reloading all charts with filename: XLE-NQTV.scid | 2022-02-20 07:03:48.433
HD Request # 28 | Downloading Intraday chart data for XLE-NQTV to the file XLE-NQTV.scid. Service: nasdaq_exchange.data | 2022-02-20 07:03:48.433
HD Request # 28 | Download start date-time: 2022-02-19 07:03:48.000000. File last date-time: 00:00:00.000000 | 2022-02-20 07:03:48.433
HD Request # 28 | Using server: ds25.sierracharts.com port 10149 | 2022-02-20 07:03:48.434
Socket (3) | Creating socket. | 2022-02-20 07:03:48.434
Socket (3) | New receive buffer size: 5242880 | 2022-02-20 07:03:48.434
Socket (3) | Connecting to IP: 38.65.8.115. | 2022-02-20 07:03:48.434
HD Request # 28 | Setting DTC encoding to Binary VLS | 2022-02-20 07:03:48.598
HD Request # 28 | Sending historical data logon request message. | 2022-02-20 07:03:48.598
HD Request # 28 | Requesting Intraday data. Start date-time: 2022-02-19 07:03:48. Record interval: 0. Symbol: XLE-NQTV | 2022-02-20 07:03:49.128
HD Request # 28 | Decompressing data. | 2022-02-20 07:03:49.209
Socket (3) | CloseSocket call. | 2022-02-20 07:03:49.210
Historical data download thread signaled to stop. | 2022-02-20 07:03:49.210
HD Request # 28 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for XLE-NQTV | 2022-02-20 07:03:49.210
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-20 07:03:49.210
File compression not supported on file system. E:\SierraChart\SierraChartInstance_3\Data\XLE-NQTV.scid. Windows error code 1: Incorrect function. | 2022-02-20 07:03:49.210
HD Request # 28 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2022-02-20 07:03:49.211
HD Request # 28 | Completion time: 1s | 2022-02-20 07:03:49.211
HD Request # 28 | Intraday data download complete for XLE-NQTV. Unique request ID: 29 | 2022-02-20 07:03:49.211
Removing historical data download ID 29. | 2022-02-20 07:03:49.211
Real-time Intraday chart data file updates started for XLE-NQTV | 2022-02-20 07:03:49.211
Intraday chart data file opened for XLE-NQTV | 2022-02-20 07:03:49.211
HD Request # 28 | Enabling Intraday chart updating for symbol. | 2022-02-20 07:03:49.211
Triggering next historical data download in queue. | 2022-02-20 07:03:49.211
No download requests in the queue to start downloads for. | 2022-02-20 07:03:49.212
Socket (3) | Socket gracefully closed by remote side. | 2022-02-20 07:03:49.290
Socket (3) | Closed. | 2022-02-20 07:03:49.290
File compression not supported on file system. E:\SierraChart\SierraChartInstance_3\Data\xle-nqtv.scid. Windows error code 1: Incorrect function. | 2022-02-20 07:03:49.717
XLE-NQTV 5 Min #7 | Reloading chart. | 2022-02-20 07:03:49.718
File compression not supported on file system. E:\SierraChart\SierraChartInstance_3\Data\xle-nqtv.scid. Windows error code 1: Incorrect function. | 2022-02-20 07:03:49.736
File compression not supported on file system. E:\SierraChart\SierraChartInstance_3\Data\xle-nqtv.scid. Windows error code 1: Incorrect function. | 2022-02-20 07:03:49.738
XLE-NQTV 5 Min #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: E:\SierraChart\SierraChartInstance_3\Data\xle-nqtv.scid | 2022-02-20 07:03:49.745
File compression not supported on file system. E:\SierraChart\SierraChartInstance_3\Data\xle-nqtv.scid. Windows error code 1: Incorrect function. | 2022-02-20 07:03:51.220
Socket (2) | Deleting network socket now after delay. | 2022-02-20 07:04:35.634
[2022-02-21 15:50:41]
John - SC Support - Posts: 47930
Your Message Log is not showing any issue, as you were trying to access data over the weekend. Now that the market is open again, let us know if you are having an issue. If so, then we need to see your Message Log again by following the same instructions.
