Date/Time: Sun, 27 Sep 2026 06:38:47 +0000
Support Package does not support this function or account is..
View Count: 1132
[2022-02-03 15:08:16]
User68313 - Posts: 10
I just updated my Sierra Chart software and now I cannot log in to my account.
It says "Support Package does not support this function or account is expired". My account expire on April the 20th, I renew it every 6 months.
What is going on?
Thank you for your help
[2022-02-03 15:54:05]
John - SC Support - Posts: 48028
Follow the instructions at the following link to login using the Forced Login option:
Sierra Chart - Software Login Instructions: Forced Login
[2022-02-03 16:13:19]
Unfortunately, it didn't do the trick: I still cannot login into my account.
I do not get any HTTP communication error, it just says the exact same thing as before:
I closed and re-run Sierra Chart several times but still nothing...
[2022-02-03 17:05:48]
Can you please get us your message log by following these instructions:
Reconnect to the data feed:
[2022-02-03 17:12:31]
Software version: 2351 64-bit | 2022-02-03 11:09:02.273
Primary Thread ID: 1492 | 2022-02-03 11:09:02.273
Usage end date: 2022-04-20 | 2022-02-03 11:09:02.273
Enabled for: Sierra Chart Historical Data Service. | 2022-02-03 11:09:02.273
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-03 11:09:02.273
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-03 11:09:02.273
Current selected Data/Trading service: Rithmic Direct - DTC | 2022-02-03 11:09:02.273
Custom symbol settings values: disabled | 2022-02-03 11:09:02.274
Chart Update Interval: 500 | 2022-02-03 11:09:02.274
Intraday Data Storage Time Unit: 1 | 2022-02-03 11:09:02.274
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-02-03 11:09:02.274
2022-02-03 17:09:02 Local computer time in UTC | 2022-02-03 11:09:02.274
2022-02-03 11:09:02 Local computer time in SC Time Zone | 2022-02-03 11:09:02.274
2022-02-03 17:08:09 Server time in UTC | 2022-02-03 11:09:02.274
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-02-03 11:09:02.274
Program path: C:\SierraChart\ | 2022-02-03 11:09:02.274
Data Files path: C:\SierraChart\Data\ | 2022-02-03 11:09:02.274
OS Version Number: 10.0 | 2022-02-03 11:09:02.276
Locale Setting: C | 2022-02-03 11:09:02.276
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2022-02-03 11:09:02.279
Allowed protected custom studies: | 2022-02-03 11:09:02.279
Connect to Data Feed | Service Package does not support this function or account is expired. Select 'Help >> Account Control Panel' for account management. | 2022-02-03 11:09:45.154 *
[2022-02-03 17:40:33]
You are connecting to Rithmic and to do this you need to be on Package 10, 11, or 12.
We have set your account to evaluate Package 12 for the next 30 days, so you should be able to connect now. Just keep in mind that before the 30 are up, you will need to change your package to 10, 11, or 12 (since you are on package 3 now, package 10 would be the equivalent).
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
[2022-02-03 17:53:39]
I am sorry but it still won't connect, it keeps on "waiting to reconnect". I read Rithmic Direct DTC now but it won't connect..
Ok, I will change the package accordingly then, once I am able to log back in.
[2022-02-03 17:57:24]
To use Rithmic it requires Service Package 10 or higher.
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
Date Time Of Last Edit: 2022-02-03 17:58:27
[2022-02-03 18:01:03]
Software version: 2351 64-bit | 2022-02-03 11:59:39.414
Primary Thread ID: 13532 | 2022-02-03 11:59:39.414
Usage end date: 2022-04-20 | 2022-02-03 11:59:39.414
Enabled for: Advanced Features 2. | 2022-02-03 11:59:39.414
Enabled for: Sierra Chart Historical Data Service. | 2022-02-03 11:59:39.414
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-03 11:59:39.414
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-03 11:59:39.414
Enabled for exchange2: fairx_exchange.data | 2022-02-03 11:59:39.414
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-03 11:59:39.414
Current selected Data/Trading service: Rithmic Direct - DTC | 2022-02-03 11:59:39.414
Custom symbol settings values: disabled | 2022-02-03 11:59:39.414
Chart Update Interval: 500 | 2022-02-03 11:59:39.414
Intraday Data Storage Time Unit: 1 | 2022-02-03 11:59:39.414
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-02-03 11:59:39.414
2022-02-03 17:59:39 Local computer time in UTC | 2022-02-03 11:59:39.414
2022-02-03 11:59:39 Local computer time in SC Time Zone | 2022-02-03 11:59:39.414
2022-02-03 17:46:20 Server time in UTC | 2022-02-03 11:59:39.414
Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-02-03 11:59:39.414
Program path: C:\SierraChart\ | 2022-02-03 11:59:39.414
Data Files path: C:\SierraChart\Data\ | 2022-02-03 11:59:39.414
OS Version Number: 10.0 | 2022-02-03 11:59:39.416
Locale Setting: C | 2022-02-03 11:59:39.416
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2022-02-03 11:59:39.418
Allowed protected custom studies: | 2022-02-03 11:59:39.419
Rithmic Direct - DTC | Using server connection: | 2022-02-03 11:59:52.515
Rithmic Direct - DTC | Remote address is not set. | 2022-02-03 11:59:52.515
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 11:59:52.515
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 11:59:52.515
DTC Client socket (0) | CloseSocket call. | 2022-02-03 11:59:52.519
Rithmic Direct - DTC | Disconnected. | 2022-02-03 11:59:52.520
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 11:59:52.520
Rithmic Direct - DTC | Using server connection: | 2022-02-03 11:59:56.521
Rithmic Direct - DTC | Remote address is not set. | 2022-02-03 11:59:56.521
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 11:59:56.521
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 11:59:56.521
DTC Client socket (0) | CloseSocket call. | 2022-02-03 11:59:56.537
Rithmic Direct - DTC | Disconnected. | 2022-02-03 11:59:56.537
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 11:59:56.537
Rithmic Direct - DTC | Using server connection: | 2022-02-03 12:00:00.525
Rithmic Direct - DTC | Remote address is not set. | 2022-02-03 12:00:00.525
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 12:00:00.525
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 12:00:00.525
DTC Client socket (0) | CloseSocket call. | 2022-02-03 12:00:00.540
Rithmic Direct - DTC | Disconnected. | 2022-02-03 12:00:00.540
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 12:00:00.541
Rithmic Direct - DTC | Using server connection: | 2022-02-03 12:00:04.545
Rithmic Direct - DTC | Remote address is not set. | 2022-02-03 12:00:04.545
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 12:00:04.545
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 12:00:04.545
DTC Client socket (0) | CloseSocket call. | 2022-02-03 12:00:04.567
Rithmic Direct - DTC | Disconnected. | 2022-02-03 12:00:04.570
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 12:00:04.571
Rithmic Direct - DTC | Using server connection: | 2022-02-03 12:00:08.565
Rithmic Direct - DTC | Remote address is not set. | 2022-02-03 12:00:08.565
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-02-03 12:00:08.566
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 12:00:08.566
DTC Client socket (0) | CloseSocket call. | 2022-02-03 12:00:08.580
Rithmic Direct - DTC | Disconnected. | 2022-02-03 12:00:08.580
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-03 12:00:08.580
File >> Disconnect selected. | 2022-02-03 12:00:09.385
DTC Client socket (0) | CloseSocket call. | 2022-02-03 12:00:09.385
Rithmic Direct - DTC | Disconnected. | 2022-02-03 12:00:09.385
[2022-02-04 11:59:36]
Hi there,
Any clues as to what the problem might be?
I am currently on a Evaluate Package 12 courtesy of John but I still cannot log in.
I think the Rithmic server settings were reset with the update. I would like to be up and running before the Chicago "open" in about 2 hours.
Regards
[2022-02-04 12:33:07]
You need to configure the Rithmic settings as explained here:
Rithmic Trading Platform Service: Setup Instructions
[2022-02-04 13:04:05]
Guys,
I am ever so thankful to you all: it's all good and running and so glad I decided back then to choose you.
Thank you all again very much!
Regards
