Date/Time: Thu, 06 Mar 2025 13:03:40 +0000
Sierra connection
View Count: 636
[2022-02-02 15:23:43]
User112741 - Posts: 4
I am having a problem getting my data to connect not sure what is going on but need some clarification as to what the issue is. It is saying I am not enabled to use sierra chart data but I do currently have a balance available.
[2022-02-02 15:38:20]
We see you are using CQG. Refer to the different connection errors here:
CQG Trading Platform Service: Common Error Messages
For now:
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
[2022-02-02 23:30:56]
Sierra Chart - Max - Posts: 5796
From User:
I am getting a connection error message from CQG WEBAPI
Reading Internal Order ID file. | 2022-02-02 11:18:30.152
Reading Trade Orders file. | 2022-02-02 11:18:30.217
Reading Trade Positions file. | 2022-02-02 11:18:30.218
Reading Trade Account Data files. | 2022-02-02 11:18:30.218
Software version: 2351 64-bit | 2022-02-02 11:18:30.230
OpenGL enabled (NVIDIA Corporation/NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2) | 2022-02-02 11:18:30.230
Primary Thread ID: 10576 | 2022-02-02 11:18:30.230
Usage end date: 2022-08-08 | 2022-02-02 11:18:30.230
Enabled for: Advanced Features 2. | 2022-02-02 11:18:30.230
Enabled for: Sierra Chart Historical Data Service. | 2022-02-02 11:18:30.230
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-02 11:18:30.230
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-02 11:18:30.230
Enabled for exchange2: fairx_exchange.data | 2022-02-02 11:18:30.230
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-02 11:18:30.230
Current selected Data/Trading service: SC Data - All Services | 2022-02-02 11:18:30.230
Custom symbol settings values: enabled | 2022-02-02 11:18:30.230
Chart Update Interval: 100 | 2022-02-02 11:18:30.230
Intraday Data Storage Time Unit: 0 | 2022-02-02 11:18:30.230
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-02-02 11:18:30.230
2022-02-02 17:18:30 Local computer time in UTC | 2022-02-02 11:18:30.230
2022-02-02 11:18:30 Local computer time in SC Time Zone | 2022-02-02 11:18:30.230
2022-02-02 17:18:29 Server time in UTC | 2022-02-02 11:18:30.230
Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-02-02 11:18:30.230
Program path: C:\SierraChart\ | 2022-02-02 11:18:30.230
Data Files path: C:\SierraChart\Data\ | 2022-02-02 11:18:30.230
OS Version Number: 10.0 | 2022-02-02 11:18:30.230
Locale Setting: C | 2022-02-02 11:18:30.230
DLLs: OrderFlowLabs.com.beta_64.dll, OrderFlowLabs.com_64.dll, UserContributedStudies_64.dll | 2022-02-02 11:18:30.232
Allowed protected custom studies: OrderFlowLabs.com, OrderFlowLabs.com Beta | 2022-02-02 11:18:30.232
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2022-02-02 11:18:30.244
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-02-02 11:18:30.265
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-02-02 11:18:30.421
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-02-02 11:18:30.421
Received 5 login tokens. | 2022-02-02 11:18:30.731
Symbol settings MD5 received. Request ID: 1. | 2022-02-02 11:18:32.363
Symbol settings are up-to-date for scdataallservices. | 2022-02-02 11:18:32.363
SC Data - All Services | Connected to server complete. | 2022-02-02 11:18:36.965
Triggering next historical data download in queue. | 2022-02-02 11:18:36.965
No download requests in the queue to start downloads for. | 2022-02-02 11:18:36.974
SC Data - All Services | Disconnected. | 2022-02-02 11:19:12.925
SC Data - All Services | Disconnected. | 2022-02-02 11:19:12.968
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 2. | 2022-02-02 11:19:12.970
Current selected Data/Trading service: CQG WebAPI | 2022-02-02 11:19:12.970
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-02-02 11:19:12.982
Symbol settings MD5 received. Request ID: 2. | 2022-02-02 11:19:14.829
Requested symbol settings for service code cqg. Request ID: 3. | 2022-02-02 11:19:14.829
CQG WebAPI | Connecting to server api.cqg.com | 2022-02-02 11:19:14.975
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-02-02 11:19:14.975
CQG WebSocket socket (3) | Creating socket. Using TLS 1.2. | 2022-02-02 11:19:15.060
CQG WebSocket socket (3) | New receive buffer size: 5242880 | 2022-02-02 11:19:15.060
CQG WebSocket socket (3) | Connecting to IP: 208.48.16.35. | 2022-02-02 11:19:15.060
CQG WebSocket | Opening WebSocket. | 2022-02-02 11:19:15.093
CQG WebSocket | Sending WebSocket handshake. | 2022-02-02 11:19:15.093
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-02 11:19:15.217
CQG WebSocket | Server header | Connection: upgrade | 2022-02-02 11:19:15.217
CQG WebSocket | Server header | Sec-WebSocket-Accept: 2TalTBMDUbt8VZqaU5uwpfAJCCY= | 2022-02-02 11:19:15.218
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-02-02 11:19:15.218
CQG WebSocket | Server header | Upgrade: websocket | 2022-02-02 11:19:15.218
CQG WebSocket | Server header | | 2022-02-02 11:19:15.218
CQG WebSocket | Web socket state is now open. | 2022-02-02 11:19:15.218
CQG WebAPI | WebSocket connected. | 2022-02-02 11:19:15.218
CQG WebAPI | Sending market data logon message. | 2022-02-02 11:19:15.218
CQG WebAPI | Logon unsuccessful. Server message: Trader is not enabled to use SierraChartData - SierraChart. Contact your FCM. | 2022-02-02 11:19:15.356
CQG WebSocket socket (3) | CloseSocket call. | 2022-02-02 11:19:15.369
CQG WebAPI | Disconnected. | 2022-02-02 11:19:15.369
CQG WebAPI | Not reconnecting due to connection error condition. | 2022-02-02 11:19:15.369
CQG WebSocket | WebSocket closed. | 2022-02-02 11:19:15.369
CQG WebAPI | WebSocket closed. | 2022-02-02 11:19:15.369
CQG WebSocket socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-02-02 11:19:15.370
CQG WebSocket socket (3) | Write has completed. Shutdown being performed. | 2022-02-02 11:19:15.404
CQG WebSocket socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-02 11:19:15.404
Symbol settings received. Request ID: 3. | 2022-02-02 11:19:17.254
CQG WebSocket socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-02-02 11:21:23.506
CQG WebSocket socket (3) | Closed. | 2022-02-02 11:21:23.506
CQG WebSocket socket (3) | Deleting network socket now after delay. | 2022-02-02 11:21:53.506
Sierra Chart Support
[2022-02-03 00:44:19]
I'm still not understanding why CQG would not connect to the chart is their something on my end I am not doing?
[2022-02-03 02:10:24]
This is the relevant message:
We see you are using CQG. Refer to the different connection errors here to locate this specific one and what action to take:
For now:
Press "OK"
Date Time Of Last Edit: 2022-02-03 02:10:40
[2022-02-03 19:12:46]
I reached out to tradeovate as it appears to be their issue. One question about SC all data, is it delayed at all?
[2022-02-03 19:27:27]
John - SC Support - Posts: 38425
Since you are not setup to get real-time data from us, when you change to "SC Data - All Services", the data from the CME Group and EUREX will be the delayed streaming data, so it will be 10-15 minutes behind the market. Refer to the information here:
Delayed Exchange Data Feed
