Date/Time: Mon, 28 Sep 2026 00:19:01 +0000
data freezing on screen
View Count: 767
| [2022-01-13 16:46:54] |
| User181801 - Posts: 46 |
Hello and thank you for your assistance. My SC front end has been quite laggy in general but today I get complete freeze of everything on my screen. Also, many of the charts (NQH22, ADR-NASDAQ(M), GCG22 for instance) are stuck in the waiting to dowload historical data condition. I would also like to ask advice for the following. What setting should I choose for days to look back in continuous contract and data feed delay given that my connection is usually 50MBPs. Thanks for your help Panos |
| [2022-01-13 17:07:37] |
| John - SC Support - Posts: 48028 |
First, get us your Message Log for us to take a look at what might be happening by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) In terms of your other questions, it is really up to you as to how many days you want to load. Once the historical data is downloaded, it only needs to be updated when you are disconnected from the data feed (like overnight), so although the initial download may take some time, it would not be that long each time afterwards. We are not sure what you are referring to in terms of "data feed delay". If you are asking about the Chart Update Interval, then we always recommend leaving that at 500 milliseconds for a typical chart. The only time we really suggest lowering the value is when using a Trading DOM and you want to see the market depth information update more frequently. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-01-13 17:15:47] |
Thank you for your answers, bellow you will find my message log. Reading Internal Order ID file. | 2022-01-13 16:33:12.320 Reading Trade Orders file. | 2022-01-13 16:33:12.418 Reading Trade Positions file. | 2022-01-13 16:33:12.419 Reading Trade Account Data files. | 2022-01-13 16:33:12.420 Software version: 2333 64-bit | 2022-01-13 16:33:12.444 Primary Thread ID: 11800 | 2022-01-13 16:33:12.444 Usage end date: 2022-02-10 | 2022-01-13 16:33:12.444 Enabled for: Advanced Features 2. | 2022-01-13 16:33:12.444 Enabled for: Sierra Chart Historical Data Service. | 2022-01-13 16:33:12.444 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-01-13 16:33:12.444 Enabled for: Delayed Denali Exchange Data Feed. | 2022-01-13 16:33:12.444 Enabled for exchange2: CME (Trading Account Required) | 2022-01-13 16:33:12.444 Enabled for exchange2: CBOT (Trading Account Required) | 2022-01-13 16:33:12.444 Enabled for exchange2: COMEX (Trading Account Required) | 2022-01-13 16:33:12.444 Enabled for exchange2: NYMEX (Trading Account Required) | 2022-01-13 16:33:12.444 Enabled for exchange2: fairx_exchange.data | 2022-01-13 16:33:12.444 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-01-13 16:33:12.444 Current selected Data/Trading service: Trading Evaluator | 2022-01-13 16:33:12.444 Custom symbol settings values: enabled | 2022-01-13 16:33:12.444 Chart Update Interval: 250 | 2022-01-13 16:33:12.444 Intraday Data Storage Time Unit: 0 | 2022-01-13 16:33:12.444 Time Zone: +00:00:00 (UTC+00) | 2022-01-13 16:33:12.444 2022-01-13 16:33:12 Local computer time in UTC | 2022-01-13 16:33:12.444 2022-01-13 16:33:12 Local computer time in SC Time Zone | 2022-01-13 16:33:12.444 2022-01-13 16:33:10 Server time in UTC | 2022-01-13 16:33:12.444 Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-01-13 16:33:12.444 Program path: C:\SierraChart\ | 2022-01-13 16:33:12.444 Data Files path: C:\SierraChart\Data\ | 2022-01-13 16:33:12.444 OS Version Number: 10.0 | 2022-01-13 16:33:12.444 Locale Setting: C | 2022-01-13 16:33:12.444 DLLs: UserContributedStudies_64.dll | 2022-01-13 16:33:12.445 Allowed protected custom studies: | 2022-01-13 16:33:12.445 Checking for new symbol settings. Requested symbol settings MD5 for service code tradesimulation.dtctrading. Request ID: 1. | 2022-01-13 16:33:12.475 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:33:12.553 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-01-13 16:33:12.639 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-01-13 16:33:12.639 Received 5 login tokens. | 2022-01-13 16:33:12.768 Symbol settings MD5 received. Request ID: 1. | 2022-01-13 16:33:13.865 Symbol settings are up-to-date for tradesimulation.dtctrading. | 2022-01-13 16:33:13.865 Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2022-01-13 16:33:18.915 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-01-13 16:33:18.916 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:33:18.916 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:33:18.916 Trading Evaluator | Network connection to server complete. | 2022-01-13 16:33:19.215 Trading Evaluator | Starting socket receive thread. | 2022-01-13 16:33:19.215 Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2022-01-13 16:33:19.215 Trading Evaluator | Setting DTC encoding to Binary VLS | 2022-01-13 16:33:20.243 Trading Evaluator | Sending logon request message. | 2022-01-13 16:33:20.243 Trading Evaluator | Received logon response. | 2022-01-13 16:33:20.986 Trading Evaluator | Server Name: SC DTC Server. Build=40463. | 2022-01-13 16:33:20.986 Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:33:20.986 Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2022-01-13 16:33:20.986 Trading Evaluator | Trading is supported. | 2022-01-13 16:33:20.986 Trading Evaluator | Order cancel and replace is supported. | 2022-01-13 16:33:20.986 Trading Evaluator | OCO Orders supported. | 2022-01-13 16:33:20.986 Trading Evaluator | Bracket Orders supported. | 2022-01-13 16:33:20.986 Trading Evaluator | Connected to server complete. | 2022-01-13 16:33:20.987 Triggering next historical data download in queue. | 2022-01-13 16:33:20.988 Triggering next historical data download in queue. | 2022-01-13 16:33:20.988 Triggering next historical data download in queue. | 2022-01-13 16:33:20.988 Triggering next historical data download in queue. | 2022-01-13 16:33:20.988 No download requests in the queue to start downloads for. | 2022-01-13 16:33:20.995 No download requests in the queue to start downloads for. | 2022-01-13 16:33:20.995 No download requests in the queue to start downloads for. | 2022-01-13 16:33:20.995 No download requests in the queue to start downloads for. | 2022-01-13 16:33:20.995 TRIN-NYSE 5 Min #14 | Reloading chart. | 2022-01-13 16:33:38.672 ADV-NYSE 5 Min #15 | Reloading chart. | 2022-01-13 16:33:38.716 TRIN-SP 5 Min #2 | Reloading chart. | 2022-01-13 16:33:38.747 ADR-NASDAQ 5 Min #13 | Reloading chart. | 2022-01-13 16:33:38.794 NQH22 [CV] #9 | Reloading chart. | 2022-01-13 16:33:38.828 NQH22 [CV] #9 | Performing continuous chart historical Daily data download for symbol NQH22 starting at last date in file. | 2022-01-13 16:33:38.886 Starting DelayedDownloadMonitoringTimer | 2022-01-13 16:33:38.886 Starting HDTimeoutTimer | 2022-01-13 16:33:38.886 Added historical Daily data request for NQH22 to the queue. | 2022-01-13 16:33:38.886 Triggering next historical data download in queue. | 2022-01-13 16:33:38.886 NQH22 [CV] #9 | Waiting for historical downloads to complete with the IDs: 1, | 2022-01-13 16:33:38.951 ESH22 [CV] #8 | Reloading chart. | 2022-01-13 16:33:39.085 ESH22 [CV] #8 | Performing continuous chart historical Daily data download for symbol ESH22 starting at last date in file. | 2022-01-13 16:33:39.172 Added historical Daily data request for ESH22 to the queue. | 2022-01-13 16:33:39.172 ESH22 [CV] #8 | Waiting for historical downloads to complete with the IDs: 2, | 2022-01-13 16:33:39.231 ESH22 #12 | Reloading chart. | 2022-01-13 16:33:39.406 ESH22 #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:39.406 CLG22 #1 | Reloading chart. | 2022-01-13 16:33:39.564 CLG22 #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:39.564 NQH22 #4 | Reloading chart. | 2022-01-13 16:33:39.725 NQH22 #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:39.725 GCG22 #5 | Reloading chart. | 2022-01-13 16:33:39.892 GCG22 #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:39.892 6EH22 #16 | Reloading chart. | 2022-01-13 16:33:40.063 6EH22 #16 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:40.063 6BH22 #17 | Reloading chart. | 2022-01-13 16:33:40.245 6BH22 #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:40.245 6CH22 #20 | Reloading chart. | 2022-01-13 16:33:40.479 6CH22 #20 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:40.479 6JH22 #21 | Reloading chart. | 2022-01-13 16:33:40.707 6JH22 #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:40.707 6AH22 #22 | Reloading chart. | 2022-01-13 16:33:40.915 6AH22 #22 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:40.915 RBG22 #23 | Reloading chart. | 2022-01-13 16:33:41.143 RBG22 #23 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:41.143 NGG22 #26 | Reloading chart. | 2022-01-13 16:33:41.342 NGG22 #26 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:41.343 ZBH22 #28 | Reloading chart. | 2022-01-13 16:33:41.531 ZBH22 #28 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:41.532 YMH22 #29 | Reloading chart. | 2022-01-13 16:33:41.732 YMH22 #29 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:41.732 ZNH22 #27 | Reloading chart. | 2022-01-13 16:33:41.921 ZNH22 #27 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:41.921 TNH22 #6 | Reloading chart. | 2022-01-13 16:33:42.125 TNH22 #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:42.125 ZFH22 #30 | Reloading chart. | 2022-01-13 16:33:42.324 ZFH22 #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:33:42.325 YMH22 [CV] #31 | Reloading chart. | 2022-01-13 16:33:42.363 YMH22 [CV] #31 | Performing continuous chart historical Daily data download for symbol YMH22 starting at last date in file. | 2022-01-13 16:33:42.385 Added historical Daily data request for YMH22 to the queue. | 2022-01-13 16:33:42.385 YMH22 [CV] #31 | Waiting for historical downloads to complete with the IDs: 3, | 2022-01-13 16:33:42.435 CLG22 [CV] #11 | Reloading chart. | 2022-01-13 16:33:42.447 CLG22 [CV] #11 | Performing continuous chart historical Daily data download for symbol CLG22 starting at last date in file. | 2022-01-13 16:33:42.503 Added historical Daily data request for CLG22 to the queue. | 2022-01-13 16:33:42.503 CLG22 [CV] #11 | Waiting for historical downloads to complete with the IDs: 4, | 2022-01-13 16:33:42.554 RBG22 [CV] #32 | Reloading chart. | 2022-01-13 16:33:42.562 RBG22 [CV] #32 | Performing continuous chart historical Daily data download for symbol RBG22 starting at last date in file. | 2022-01-13 16:33:42.600 Added historical Daily data request for RBG22 to the queue. | 2022-01-13 16:33:42.600 RBG22 [CV] #32 | Waiting for historical downloads to complete with the IDs: 5, | 2022-01-13 16:33:42.652 GCG22 [CV] #7 | Reloading chart. | 2022-01-13 16:33:42.668 GCG22 [CV] #7 | Performing continuous chart historical Daily data download for symbol GCG22 starting at last date in file. | 2022-01-13 16:33:42.687 Added historical Daily data request for GCG22 to the queue. | 2022-01-13 16:33:42.687 GCG22 [CV] #7 | Waiting for historical downloads to complete with the IDs: 6, | 2022-01-13 16:33:42.735 ESH22 [CV] 5 Min #3 | Reloading chart. | 2022-01-13 16:33:42.775 ESH22 [CV] 5 Min #3 | Waiting for historical downloads to complete with the IDs: 2, | 2022-01-13 16:33:42.818 CLG22 [CV] 5 Min #18 | Reloading chart. | 2022-01-13 16:33:42.878 CLG22 [CV] 5 Min #18 | Waiting for historical downloads to complete with the IDs: 4, | 2022-01-13 16:33:42.905 NQH22 [CV] 5 Min #19 | Reloading chart. | 2022-01-13 16:33:42.947 NQH22 [CV] 5 Min #19 | Waiting for historical downloads to complete with the IDs: 1, | 2022-01-13 16:33:42.993 GCG22 [CV] 5 Min #24 | Reloading chart. | 2022-01-13 16:33:43.049 GCG22 [CV] 5 Min #24 | Waiting for historical downloads to complete with the IDs: 6, | 2022-01-13 16:33:43.081 BTCF22 [CV] #10 | Reloading chart. | 2022-01-13 16:33:43.123 Starting DelayedDownloadMonitoringTimer | 2022-01-13 16:33:43.131 Starting HDTimeoutTimer | 2022-01-13 16:33:43.131 Added historical Intraday data request for BTCU21 to the queue. | 2022-01-13 16:33:43.131 Triggering next historical data download in queue. | 2022-01-13 16:33:43.131 BTCF22 [CV] #10 | Performing continuous chart historical Daily data download for symbol BTCU21 starting at last date in file. | 2022-01-13 16:33:43.133 Added historical Daily data request for BTCU21 to the queue. | 2022-01-13 16:33:43.133 BTCF22 [CV] #10 | Performing continuous chart historical Daily data download for symbol BTCF22 starting at last date in file. | 2022-01-13 16:33:43.147 Added historical Daily data request for BTCF22 to the queue. | 2022-01-13 16:33:43.147 BTCF22 [CV] #10 | Waiting for historical downloads to complete with the IDs: 7, 8, 9, | 2022-01-13 16:33:43.193 Mapping ESH22 to ESH22. Service code: cme | 2022-01-13 16:33:43.224 SC Data - All Services | Starting real-time market data updates for: ESH22 (ESH22). ID: 1 Service code: cme | 2022-01-13 16:33:43.224 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-01-13 16:33:43.224 SC Data - All Services | Requesting security definition data for: ESH22 (ESH22). ID: 1 | 2022-01-13 16:33:43.224 Mapping NQH22 to NQH22. Service code: cme | 2022-01-13 16:33:43.224 SC Data - All Services | Starting real-time market data updates for: NQH22 (NQH22). ID: 2 Service code: cme | 2022-01-13 16:33:43.224 SC Data - All Services | Requesting security definition data for: NQH22 (NQH22). ID: 2 | 2022-01-13 16:33:43.224 Mapping RTYH22 to RTYH22. Service code: cme | 2022-01-13 16:33:43.225 SC Data - All Services | Starting real-time market data updates for: RTYH22 (RTYH22). ID: 3 Service code: cme | 2022-01-13 16:33:43.225 SC Data - All Services | Requesting security definition data for: RTYH22 (RTYH22). ID: 3 | 2022-01-13 16:33:43.225 DTC Client socket (2) | Creating socket. | 2022-01-13 16:33:43.225 Mapping YMH22 to YMH22. Service code: cbot | 2022-01-13 16:33:43.225 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-01-13 16:33:43.225 SC Data - All Services | Starting real-time market data updates for: YMH22 (YMH22). ID: 4 Service code: cbot | 2022-01-13 16:33:43.225 DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:33:43.225 SC Data - All Services | Requesting security definition data for: YMH22 (YMH22). ID: 4 | 2022-01-13 16:33:43.225 Mapping NKDH22 to NKDH22. Service code: cme | 2022-01-13 16:33:43.225 SC Data - All Services | Starting real-time market data updates for: NKDH22 (NKDH22). ID: 5 Service code: cme | 2022-01-13 16:33:43.225 SC Data - All Services | Requesting security definition data for: NKDH22 (NKDH22). ID: 5 | 2022-01-13 16:33:43.225 Mapping ZBH22 to ZBH22. Service code: cbot | 2022-01-13 16:33:43.225 SC Data - All Services | Starting real-time market data updates for: ZBH22 (ZBH22). ID: 6 Service code: cbot | 2022-01-13 16:33:43.225 SC Data - All Services | Requesting security definition data for: ZBH22 (ZBH22). ID: 6 | 2022-01-13 16:33:43.225 Mapping ZNH22 to ZNH22. Service code: cbot | 2022-01-13 16:33:43.225 SC Data - All Services | Starting real-time market data updates for: ZNH22 (ZNH22). ID: 7 Service code: cbot | 2022-01-13 16:33:43.225 SC Data - All Services | Requesting security definition data for: ZNH22 (ZNH22). ID: 7 | 2022-01-13 16:33:43.225 Mapping ZTH22 to ZTH22. Service code: cbot | 2022-01-13 16:33:43.226 SC Data - All Services | Starting real-time market data updates for: ZTH22 (ZTH22). ID: 8 Service code: cbot | 2022-01-13 16:33:43.226 SC Data - All Services | Requesting security definition data for: ZTH22 (ZTH22). ID: 8 | 2022-01-13 16:33:43.226 Trading Evaluator | Starting real-time market data updates for: FBTPH22. ID: 9 Service code: eurex | 2022-01-13 16:33:43.226 Trading Evaluator | Requesting security definition data for: FBTPH22. ID: 9 | 2022-01-13 16:33:43.226 Trading Evaluator | Starting real-time market data updates for: FGBLH22. ID: 10 Service code: eurex | 2022-01-13 16:33:43.226 Trading Evaluator | Requesting security definition data for: FGBLH22. ID: 10 | 2022-01-13 16:33:43.226 Trading Evaluator | Starting real-time market data updates for: FGBMH22. ID: 11 Service code: eurex | 2022-01-13 16:33:43.226 Trading Evaluator | Requesting security definition data for: FGBMH22. ID: 11 | 2022-01-13 16:33:43.226 Mapping CLG22 to CLG22. Service code: nymex | 2022-01-13 16:33:43.226 SC Data - All Services | Starting real-time market data updates for: CLG22 (CLG22). ID: 12 Service code: nymex | 2022-01-13 16:33:43.226 SC Data - All Services | Requesting security definition data for: CLG22 (CLG22). ID: 12 | 2022-01-13 16:33:43.226 Mapping BBH22 to BBH22. Service code: nymex | 2022-01-13 16:33:43.226 SC Data - All Services | Starting real-time market data updates for: BBH22 (BBH22). ID: 13 Service code: nymex | 2022-01-13 16:33:43.227 SC Data - All Services | Requesting security definition data for: BBH22 (BBH22). ID: 13 | 2022-01-13 16:33:43.227 Mapping HOG22 to HOG22. Service code: nymex | 2022-01-13 16:33:43.227 SC Data - All Services | Starting real-time market data updates for: HOG22 (HOG22). ID: 14 Service code: nymex | 2022-01-13 16:33:43.227 SC Data - All Services | Requesting security definition data for: HOG22 (HOG22). ID: 14 | 2022-01-13 16:33:43.227 Mapping RBG22 to RBG22. Service code: nymex | 2022-01-13 16:33:43.227 SC Data - All Services | Starting real-time market data updates for: RBG22 (RBG22). ID: 15 Service code: nymex | 2022-01-13 16:33:43.227 SC Data - All Services | Requesting security definition data for: RBG22 (RBG22). ID: 15 | 2022-01-13 16:33:43.227 Mapping NGG22 to NGG22. Service code: nymex | 2022-01-13 16:33:43.227 SC Data - All Services | Starting real-time market data updates for: NGG22 (NGG22). ID: 16 Service code: nymex | 2022-01-13 16:33:43.227 SC Data - All Services | Requesting security definition data for: NGG22 (NGG22). ID: 16 | 2022-01-13 16:33:43.227 Mapping GCG22 to GCG22. Service code: comex | 2022-01-13 16:33:43.227 SC Data - All Services | Starting real-time market data updates for: GCG22 (GCG22). ID: 17 Service code: comex | 2022-01-13 16:33:43.227 SC Data - All Services | Requesting security definition data for: GCG22 (GCG22). ID: 17 | 2022-01-13 16:33:43.227 Mapping SIH22 to SIH22. Service code: comex | 2022-01-13 16:33:43.227 SC Data - All Services | Starting real-time market data updates for: SIH22 (SIH22). ID: 18 Service code: comex | 2022-01-13 16:33:43.227 SC Data - All Services | Requesting security definition data for: SIH22 (SIH22). ID: 18 | 2022-01-13 16:33:43.227 Mapping 6EH22 to 6EH22. Service code: cme | 2022-01-13 16:33:43.227 SC Data - All Services | Starting real-time market data updates for: 6EH22 (6EH22). ID: 19 Service code: cme | 2022-01-13 16:33:43.227 SC Data - All Services | Requesting security definition data for: 6EH22 (6EH22). ID: 19 | 2022-01-13 16:33:43.227 Mapping 6BH22 to 6BH22. Service code: cme | 2022-01-13 16:33:43.227 SC Data - All Services | Starting real-time market data updates for: 6BH22 (6BH22). ID: 20 Service code: cme | 2022-01-13 16:33:43.228 SC Data - All Services | Requesting security definition data for: 6BH22 (6BH22). ID: 20 | 2022-01-13 16:33:43.228 Mapping 6JH22 to 6JH22. Service code: cme | 2022-01-13 16:33:43.228 SC Data - All Services | Starting real-time market data updates for: 6JH22 (6JH22). ID: 21 Service code: cme | 2022-01-13 16:33:43.228 SC Data - All Services | Requesting security definition data for: 6JH22 (6JH22). ID: 21 | 2022-01-13 16:33:43.228 Mapping 6CH22 to 6CH22. Service code: cme | 2022-01-13 16:33:43.228 SC Data - All Services | Starting real-time market data updates for: 6CH22 (6CH22). ID: 22 Service code: cme | 2022-01-13 16:33:43.228 SC Data - All Services | Requesting security definition data for: 6CH22 (6CH22). ID: 22 | 2022-01-13 16:33:43.228 Mapping 6AH22 to 6AH22. Service code: cme | 2022-01-13 16:33:43.228 SC Data - All Services | Starting real-time market data updates for: 6AH22 (6AH22). ID: 23 Service code: cme | 2022-01-13 16:33:43.228 SC Data - All Services | Requesting security definition data for: 6AH22 (6AH22). ID: 23 | 2022-01-13 16:33:43.228 Mapping 6SH22 to 6SH22. Service code: cme | 2022-01-13 16:33:43.228 SC Data - All Services | Starting real-time market data updates for: 6SH22 (6SH22). ID: 24 Service code: cme | 2022-01-13 16:33:43.228 SC Data - All Services | Requesting security definition data for: 6SH22 (6SH22). ID: 24 | 2022-01-13 16:33:43.228 Mapping 6MH22 to 6MH22. Service code: cme | 2022-01-13 16:33:43.229 SC Data - All Services | Starting real-time market data updates for: 6MH22 (6MH22). ID: 25 Service code: cme | 2022-01-13 16:33:43.229 SC Data - All Services | Requesting security definition data for: 6MH22 (6MH22). ID: 25 | 2022-01-13 16:33:43.229 Mapping BTCF22 to BTCF22. Service code: cme | 2022-01-13 16:33:43.229 SC Data - All Services | Starting real-time market data updates for: BTCF22 (BTCF22). ID: 26 Service code: cme | 2022-01-13 16:33:43.229 SC Data - All Services | Requesting security definition data for: BTCF22 (BTCF22). ID: 26 | 2022-01-13 16:33:43.229 HD Request # 1 | Downloading Historical Daily chart data for NQH22. Starting date: 2022-01-10. Service: tradingevaluator.dtctrading | 2022-01-13 16:33:43.250 Mapping BTCU21 to BTCU21. Service code: cme | 2022-01-13 16:33:43.319 HD Request # 2 | Downloading Intraday chart data for BTCU21 to the file BTCU21.scid. Service: cme | 2022-01-13 16:33:43.320 HD Request # 2 | Download start date-time: 2021-09-24 14:57:02.000000. File last date-time: 2021-09-24 14:57:02.492000 | 2022-01-13 16:33:43.320 HD Request # 2 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:33:43.320 Socket (4) | Creating socket. | 2022-01-13 16:33:43.320 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:33:43.320 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:33:43.321 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH22 | 2022-01-13 16:33:43.518 Trading Evaluator | Received security definition for symbol ESH22 | 2022-01-13 16:33:43.518 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH22 | 2022-01-13 16:33:43.518 Trading Evaluator | Received security definition for symbol NQH22 | 2022-01-13 16:33:43.518 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH22 | 2022-01-13 16:33:43.518 Trading Evaluator | Received security definition for symbol RTYH22 | 2022-01-13 16:33:43.518 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 28 Service code: statscalc | 2022-01-13 16:33:43.543 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-01-13 16:33:43.543 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 28 | 2022-01-13 16:33:43.543 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:33:43.543 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2022-01-13 16:33:43.543 Triggering next historical data download in queue. | 2022-01-13 16:33:43.543 DTC Client socket (5) | Creating socket. | 2022-01-13 16:33:43.544 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:33:43.544 DTC Client socket (5) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:33:43.544 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-NYSE. ID: 29 Service code: statscalc | 2022-01-13 16:33:43.547 SC DTC Data with Market Depth | Requesting security definition data for: ADV-NYSE. ID: 29 | 2022-01-13 16:33:43.547 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:33:43.547 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:33:43.547 Triggering next historical data download in queue. | 2022-01-13 16:33:43.547 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-SP. ID: 30 Service code: statscalc | 2022-01-13 16:33:43.552 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-SP. ID: 30 | 2022-01-13 16:33:43.552 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:33:43.552 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2022-01-13 16:33:43.552 Triggering next historical data download in queue. | 2022-01-13 16:33:43.552 SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NASDAQ. ID: 31 Service code: statscalc | 2022-01-13 16:33:43.555 SC DTC Data with Market Depth | Requesting security definition data for: ADR-NASDAQ. ID: 31 | 2022-01-13 16:33:43.555 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:33:43.555 Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2022-01-13 16:33:43.555 Triggering next historical data download in queue. | 2022-01-13 16:33:43.555 Added historical Intraday data request for ESH22 to the queue. | 2022-01-13 16:33:43.585 Intraday data recording state for symbol ESH22 is set to download 'Pending'. | 2022-01-13 16:33:43.585 Triggering next historical data download in queue. | 2022-01-13 16:33:43.586 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH22 | 2022-01-13 16:33:43.593 Trading Evaluator | Received security definition for symbol YMH22 | 2022-01-13 16:33:43.593 Added historical Intraday data request for CLG22 to the queue. | 2022-01-13 16:33:43.622 Intraday data recording state for symbol CLG22 is set to download 'Pending'. | 2022-01-13 16:33:43.622 Triggering next historical data download in queue. | 2022-01-13 16:33:43.622 Added historical Intraday data request for NQH22 to the queue. | 2022-01-13 16:33:43.653 Intraday data recording state for symbol NQH22 is set to download 'Pending'. | 2022-01-13 16:33:43.653 Triggering next historical data download in queue. | 2022-01-13 16:33:43.653 Added historical Intraday data request for GCG22 to the queue. | 2022-01-13 16:33:43.694 Intraday data recording state for symbol GCG22 is set to download 'Pending'. | 2022-01-13 16:33:43.694 Triggering next historical data download in queue. | 2022-01-13 16:33:43.694 Added historical Intraday data request for 6EH22 to the queue. | 2022-01-13 16:33:43.708 Intraday data recording state for symbol 6EH22 is set to download 'Pending'. | 2022-01-13 16:33:43.708 Triggering next historical data download in queue. | 2022-01-13 16:33:43.708 HD Request # 1 | Requesting historical Daily data for NQH22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:33:43.710 Added historical Intraday data request for 6BH22 to the queue. | 2022-01-13 16:33:43.746 Intraday data recording state for symbol 6BH22 is set to download 'Pending'. | 2022-01-13 16:33:43.746 Triggering next historical data download in queue. | 2022-01-13 16:33:43.746 Added historical Intraday data request for 6CH22 to the queue. | 2022-01-13 16:33:43.773 Intraday data recording state for symbol 6CH22 is set to download 'Pending'. | 2022-01-13 16:33:43.773 Triggering next historical data download in queue. | 2022-01-13 16:33:43.773 Added historical Intraday data request for 6JH22 to the queue. | 2022-01-13 16:33:43.798 Intraday data recording state for symbol 6JH22 is set to download 'Pending'. | 2022-01-13 16:33:43.798 Triggering next historical data download in queue. | 2022-01-13 16:33:43.798 Requesting market depth updates for: 6AH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. 6AH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: 6BH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. 6BH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: 6CH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. 6CH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: 6EH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. 6EH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: 6JH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. 6JH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: CLG22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. CLG22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: ESH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. ESH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: GCG22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. GCG22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: NGG22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. NGG22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: NQH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. NQH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: RBG22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. RBG22 | 2022-01-13 16:33:43.815 Mapping TNH22 to TNH22. Service code: cbot | 2022-01-13 16:33:43.815 SC Data - All Services | Starting real-time market data updates for: TNH22 (TNH22). ID: 32 Service code: cbot | 2022-01-13 16:33:43.815 SC Data - All Services | Requesting security definition data for: TNH22 (TNH22). ID: 32 | 2022-01-13 16:33:43.815 Requesting market depth updates for: TNH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. TNH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: YMH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. YMH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: ZBH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. ZBH22 | 2022-01-13 16:33:43.815 Mapping ZFH22 to ZFH22. Service code: cbot | 2022-01-13 16:33:43.815 SC Data - All Services | Starting real-time market data updates for: ZFH22 (ZFH22). ID: 33 Service code: cbot | 2022-01-13 16:33:43.815 SC Data - All Services | Requesting security definition data for: ZFH22 (ZFH22). ID: 33 | 2022-01-13 16:33:43.815 Requesting market depth updates for: ZFH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. ZFH22 | 2022-01-13 16:33:43.815 Requesting market depth updates for: ZNH22 if supported. | 2022-01-13 16:33:43.815 Separate subscription for market depth updates not supported. ZNH22 | 2022-01-13 16:33:43.815 Added historical Intraday data request for 6AH22 to the queue. | 2022-01-13 16:33:43.823 Intraday data recording state for symbol 6AH22 is set to download 'Pending'. | 2022-01-13 16:33:43.823 Triggering next historical data download in queue. | 2022-01-13 16:33:43.823 Added historical Intraday data request for RBG22 to the queue. | 2022-01-13 16:33:43.850 Intraday data recording state for symbol RBG22 is set to download 'Pending'. | 2022-01-13 16:33:43.850 Triggering next historical data download in queue. | 2022-01-13 16:33:43.850 Added historical Intraday data request for NGG22 to the queue. | 2022-01-13 16:33:43.880 Intraday data recording state for symbol NGG22 is set to download 'Pending'. | 2022-01-13 16:33:43.880 Triggering next historical data download in queue. | 2022-01-13 16:33:43.880 Added historical Intraday data request for ZBH22 to the queue. | 2022-01-13 16:33:43.903 Intraday data recording state for symbol ZBH22 is set to download 'Pending'. | 2022-01-13 16:33:43.903 Triggering next historical data download in queue. | 2022-01-13 16:33:43.903 Added historical Intraday data request for YMH22 to the queue. | 2022-01-13 16:33:43.928 Intraday data recording state for symbol YMH22 is set to download 'Pending'. | 2022-01-13 16:33:43.928 Triggering next historical data download in queue. | 2022-01-13 16:33:43.928 HD Request # 2 | Setting DTC encoding to Binary VLS | 2022-01-13 16:33:43.930 HD Request # 2 | Sending historical data logon request message. | 2022-01-13 16:33:43.930 Added historical Intraday data request for ZNH22 to the queue. | 2022-01-13 16:33:43.947 Intraday data recording state for symbol ZNH22 is set to download 'Pending'. | 2022-01-13 16:33:43.947 Triggering next historical data download in queue. | 2022-01-13 16:33:43.947 Added historical Intraday data request for TNH22 to the queue. | 2022-01-13 16:33:43.971 Intraday data recording state for symbol TNH22 is set to download 'Pending'. | 2022-01-13 16:33:43.971 Triggering next historical data download in queue. | 2022-01-13 16:33:43.971 Added historical Intraday data request for ZFH22 to the queue. | 2022-01-13 16:33:43.993 Intraday data recording state for symbol ZFH22 is set to download 'Pending'. | 2022-01-13 16:33:43.993 Triggering next historical data download in queue. | 2022-01-13 16:33:43.993 HD Request # 1 | Receiving historical Daily data for NQH22 starting at 2022-01-10 | 2022-01-13 16:33:44.322 HD Request # 1 | Writing historical Daily data to the file NQH22.dly | 2022-01-13 16:33:44.323 HD Request # 1 | Bytes received: 180 | 2022-01-13 16:33:44.330 HD Request # 1 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for NQH22 | 2022-01-13 16:33:44.330 HD Request # 1 | Completion time: 1s | 2022-01-13 16:33:44.331 HD Request # 1 | Daily data download complete for NQH22. Unique request ID: 1 | 2022-01-13 16:33:44.331 Removing historical data download ID 1. | 2022-01-13 16:33:44.331 Triggering next historical data download in queue. | 2022-01-13 16:33:44.331 HD Request # 3 | Downloading Historical Daily chart data for ESH22. Starting date: 2022-01-10. Service: tradingevaluator.dtctrading | 2022-01-13 16:33:44.336 NQH22 [CV] #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:44.340 NQH22 [CV] #9 | Reloading chart. | 2022-01-13 16:33:44.341 NQH22 [CV] 5 Min #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:44.447 NQH22 [CV] 5 Min #19 | Reloading chart. | 2022-01-13 16:33:44.448 NQH22 [CV] #9 | Reloading chart. | 2022-01-13 16:33:44.598 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-09-24 14:57:02. Record interval: 0. Symbol: BTCU21 | 2022-01-13 16:33:44.684 NQH22 [CV] 5 Min #19 | Reloading chart. | 2022-01-13 16:33:44.710 HD Request # 3 | Requesting historical Daily data for ESH22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:33:44.758 HD Request # 3 | Receiving historical Daily data for ESH22 starting at 2022-01-10 | 2022-01-13 16:33:45.084 HD Request # 3 | Writing historical Daily data to the file ESH22.dly | 2022-01-13 16:33:45.085 HD Request # 3 | Bytes received: 183 | 2022-01-13 16:33:45.090 HD Request # 3 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for ESH22 | 2022-01-13 16:33:45.090 HD Request # 3 | Completion time: 1s | 2022-01-13 16:33:45.090 HD Request # 3 | Daily data download complete for ESH22. Unique request ID: 2 | 2022-01-13 16:33:45.090 Removing historical data download ID 2. | 2022-01-13 16:33:45.090 Triggering next historical data download in queue. | 2022-01-13 16:33:45.090 HD Request # 4 | Downloading Historical Daily chart data for YMH22. Starting date: 2022-01-10. Service: tradingevaluator.dtctrading | 2022-01-13 16:33:45.094 ESH22 [CV] #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:45.120 ESH22 [CV] #8 | Reloading chart. | 2022-01-13 16:33:45.120 ESH22 [CV] 5 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:45.320 ESH22 [CV] 5 Min #3 | Reloading chart. | 2022-01-13 16:33:45.321 ESH22 [CV] #8 | Reloading chart. | 2022-01-13 16:33:45.396 HD Request # 4 | Requesting historical Daily data for YMH22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:33:45.545 ESH22 [CV] 5 Min #3 | Reloading chart. | 2022-01-13 16:33:45.576 HD Request # 2 | Decompressing data. | 2022-01-13 16:33:45.660 HD Request # 2 | Receiving Intraday data for BTCU21 starting at 2021-09-24 14:57:02.492000 | 2022-01-13 16:33:45.684 Socket (4) | CloseSocket call. | 2022-01-13 16:33:45.684 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:33:45.684 Historical data download thread signaled to stop. | 2022-01-13 16:33:45.684 HD Request # 2 | Received 1 Intraday data record from 2021-09-24 14:57:02.492000 to 2021-09-24 14:57:02.492000 (0.0 seconds) and wrote 0 records for BTCU21 | 2022-01-13 16:33:45.684 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2021-09-24 14:57:02.492000 | 2022-01-13 16:33:45.685 HD Request # 2 | Completion time: 2s | 2022-01-13 16:33:45.685 HD Request # 2 | Intraday data download complete for BTCU21. Unique request ID: 7 | 2022-01-13 16:33:45.685 Removing historical data download ID 7. | 2022-01-13 16:33:45.685 Real-time Intraday chart data file updates started for BTCU21 | 2022-01-13 16:33:45.685 Intraday chart data file opened for BTCU21 | 2022-01-13 16:33:45.685 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:33:45.685 Triggering next historical data download in queue. | 2022-01-13 16:33:45.685 Delaying start of download for TRIN-NYSE | 2022-01-13 16:33:45.685 HD Request # 4 | Receiving historical Daily data for YMH22 starting at 2022-01-10 | 2022-01-13 16:33:45.722 HD Request # 4 | Writing historical Daily data to the file YMH22.dly | 2022-01-13 16:33:45.723 HD Request # 4 | Bytes received: 162 | 2022-01-13 16:33:45.725 HD Request # 4 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for YMH22 | 2022-01-13 16:33:45.725 HD Request # 4 | Completion time: 0s | 2022-01-13 16:33:45.725 HD Request # 4 | Daily data download complete for YMH22. Unique request ID: 3 | 2022-01-13 16:33:45.725 Removing historical data download ID 3. | 2022-01-13 16:33:45.725 Triggering next historical data download in queue. | 2022-01-13 16:33:45.725 HD Request # 5 | Downloading Historical Daily chart data for CLG22. Starting date: 2022-01-10. Service: tradingevaluator.dtctrading | 2022-01-13 16:33:45.727 YMH22 [CV] #31 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:45.873 YMH22 [CV] #31 | Reloading chart. | 2022-01-13 16:33:45.873 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:33:45.980 Socket (4) | Closed. | 2022-01-13 16:33:45.980 YMH22 [CV] #31 | Reloading chart. | 2022-01-13 16:33:46.124 HD Request # 5 | Requesting historical Daily data for CLG22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:33:46.203 HD Request # 5 | Receiving historical Daily data for CLG22 starting at 2022-01-10 | 2022-01-13 16:33:46.388 HD Request # 5 | Writing historical Daily data to the file CLG22.dly | 2022-01-13 16:33:46.388 HD Request # 5 | Bytes received: 169 | 2022-01-13 16:33:46.403 HD Request # 5 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for CLG22 | 2022-01-13 16:33:46.403 HD Request # 5 | Completion time: 1s | 2022-01-13 16:33:46.403 HD Request # 5 | Daily data download complete for CLG22. Unique request ID: 4 | 2022-01-13 16:33:46.403 Removing historical data download ID 4. | 2022-01-13 16:33:46.403 Triggering next historical data download in queue. | 2022-01-13 16:33:46.403 HD Request # 6 | Downloading Historical Daily chart data for RBG22. Starting date: 2022-01-10. Service: tradingevaluator.dtctrading | 2022-01-13 16:33:46.405 CLG22 [CV] 5 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:46.413 CLG22 [CV] 5 Min #18 | Reloading chart. | 2022-01-13 16:33:46.414 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NKDH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol NKDH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol ZBH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol ZNH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZTH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol ZTH22 | 2022-01-13 16:33:46.491 Symbol Error - FBTPH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol FBTPH22 | 2022-01-13 16:33:46.491 Symbol Error - FGBLH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol FGBLH22 | 2022-01-13 16:33:46.491 Symbol Error - FGBMH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol FGBMH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol CLG22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol BBH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: HOG22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol HOG22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RBG22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol RBG22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NGG22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol NGG22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol GCG22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: SIH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol SIH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol 6EH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol 6BH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6JH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol 6JH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6CH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol 6CH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6AH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol 6AH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6SH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol 6SH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6MH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol 6MH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BTCF22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol BTCF22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: TNH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol TNH22 | 2022-01-13 16:33:46.491 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZFH22 | 2022-01-13 16:33:46.491 Trading Evaluator | Received security definition for symbol ZFH22 | 2022-01-13 16:33:46.491 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:33:46.537 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:33:46.537 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:33:46.537 CLG22 [CV] #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:46.538 CLG22 [CV] #11 | Reloading chart. | 2022-01-13 16:33:46.538 HD Request # 6 | Requesting historical Daily data for RBG22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:33:46.856 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:33:46.856 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:33:46.856 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:33:46.856 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:33:46.869 SC Data - All Services | Sending logon request message. | 2022-01-13 16:33:46.869 CLG22 [CV] 5 Min #18 | Reloading chart. | 2022-01-13 16:33:46.897 HD Request # 6 | Receiving historical Daily data for RBG22 starting at 2022-01-10 | 2022-01-13 16:33:47.065 HD Request # 6 | Writing historical Daily data to the file RBG22.dly | 2022-01-13 16:33:47.065 HD Request # 6 | Bytes received: 175 | 2022-01-13 16:33:47.077 HD Request # 6 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for RBG22 | 2022-01-13 16:33:47.077 HD Request # 6 | Completion time: 1s | 2022-01-13 16:33:47.077 HD Request # 6 | Daily data download complete for RBG22. Unique request ID: 5 | 2022-01-13 16:33:47.077 Removing historical data download ID 5. | 2022-01-13 16:33:47.078 Triggering next historical data download in queue. | 2022-01-13 16:33:47.087 HD Request # 7 | Downloading Historical Daily chart data for GCG22. Starting date: 2022-01-10. Service: tradingevaluator.dtctrading | 2022-01-13 16:33:47.090 CLG22 [CV] #11 | Reloading chart. | 2022-01-13 16:33:47.092 RBG22 [CV] #32 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:47.500 RBG22 [CV] #32 | Reloading chart. | 2022-01-13 16:33:47.500 RBG22 [CV] #32 | Reloading chart. | 2022-01-13 16:33:47.836 HD Request # 7 | Requesting historical Daily data for GCG22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:33:48.156 SC Data - All Services | Received logon response. | 2022-01-13 16:33:48.158 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:33:48.158 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:33:48.158 SC Data - All Services | Successfully connected. | 2022-01-13 16:33:48.158 SC Data - All Services | Trading is not supported. | 2022-01-13 16:33:48.158 SC Data - All Services (Market Orders Data) | Connecting to the server ds21.sierracharts.com. Port 10060 | 2022-01-13 16:33:48.160 SC Data - All Services | Restarting real-time data updates for symbol: 6AH22 -> 6AH22. Market Depth data restarted. | 2022-01-13 16:33:48.160 SC Data - All Services | Restarting real-time data updates for symbol: 6BH22 -> 6BH22. Market Depth data restarted. | 2022-01-13 16:33:48.160 SC Data - All Services | Restarting real-time data updates for symbol: 6CH22 -> 6CH22. Market Depth data restarted. | 2022-01-13 16:33:48.160 SC Data - All Services | Restarting real-time data updates for symbol: 6EH22 -> 6EH22. Market Depth data restarted. | 2022-01-13 16:33:48.160 SC Data - All Services | Restarting real-time data updates for symbol: 6JH22 -> 6JH22. Market Depth data restarted. | 2022-01-13 16:33:48.160 SC Data - All Services | Restarting real-time data updates for symbol: 6MH22 -> 6MH22 | 2022-01-13 16:33:48.160 SC Data - All Services | Restarting real-time data updates for symbol: 6SH22 -> 6SH22 | 2022-01-13 16:33:48.160 SC Data - All Services | Restarting real-time data updates for symbol: BBH22 -> BBH22 | 2022-01-13 16:33:48.160 SC Data - All Services | Restarting real-time data updates for symbol: BTCF22 -> BTCF22 | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: CLG22 -> CLG22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: GCG22 -> GCG22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: HOG22 -> HOG22 | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: NGG22 -> NGG22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: NKDH22 -> NKDH22 | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: NQH22 -> NQH22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: RBG22 -> RBG22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: RTYH22 -> RTYH22 | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: SIH22 -> SIH22 | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: TNH22 -> TNH22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: YMH22 -> YMH22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: ZBH22 -> ZBH22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: ZFH22 -> ZFH22. Market Depth data restarted. | 2022-01-13 16:33:48.161 DTC Client socket (6) | Creating socket. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: ZNH22 -> ZNH22. Market Depth data restarted. | 2022-01-13 16:33:48.161 SC Data - All Services | Restarting real-time data updates for symbol: ZTH22 -> ZTH22 | 2022-01-13 16:33:48.161 DTC Client socket (6) | New receive buffer size: 5242880 | 2022-01-13 16:33:48.161 DTC Client socket (6) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:33:48.161 HD Request # 7 | Receiving historical Daily data for GCG22 starting at 2022-01-10 | 2022-01-13 16:33:48.332 HD Request # 7 | Writing historical Daily data to the file GCG22.dly | 2022-01-13 16:33:48.332 HD Request # 7 | Bytes received: 175 | 2022-01-13 16:33:48.340 HD Request # 7 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for GCG22 | 2022-01-13 16:33:48.340 HD Request # 7 | Completion time: 1s | 2022-01-13 16:33:48.340 HD Request # 7 | Daily data download complete for GCG22. Unique request ID: 6 | 2022-01-13 16:33:48.340 Removing historical data download ID 6. | 2022-01-13 16:33:48.340 Triggering next historical data download in queue. | 2022-01-13 16:33:48.340 HD Request # 8 | Downloading Historical Daily chart data for BTCU21. Starting date: 2021-09-22. Service: tradingevaluator.dtctrading | 2022-01-13 16:33:48.343 GCG22 [CV] #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:48.435 GCG22 [CV] #7 | Reloading chart. | 2022-01-13 16:33:48.436 GCG22 [CV] 5 Min #24 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:48.564 GCG22 [CV] 5 Min #24 | Reloading chart. | 2022-01-13 16:33:48.596 GCG22 [CV] #7 | Reloading chart. | 2022-01-13 16:33:48.745 HD Request # 8 | Requesting historical Daily data for BTU21 starting at 2021-09-21. SC External HD service. | 2022-01-13 16:33:49.049 GCG22 [CV] 5 Min #24 | Reloading chart. | 2022-01-13 16:33:49.064 HD Request # 8 | Receiving historical Daily data for BTCU21 starting at 2021-09-22 | 2022-01-13 16:33:49.255 HD Request # 8 | Writing historical Daily data to the file BTCU21.dly | 2022-01-13 16:33:49.256 HD Request # 8 | Bytes received: 208 | 2022-01-13 16:33:49.257 HD Request # 8 | Received 4 Daily data records from 2021-09-22 00:00:00 to 2021-09-24 00:00:00 (3.0 days) and wrote 3 records for BTCU21 | 2022-01-13 16:33:49.257 HD Request # 8 | Completion time: 1s | 2022-01-13 16:33:49.257 HD Request # 8 | Daily data download complete for BTCU21. Unique request ID: 8 | 2022-01-13 16:33:49.257 Removing historical data download ID 8. | 2022-01-13 16:33:49.257 Triggering next historical data download in queue. | 2022-01-13 16:33:49.257 HD Request # 9 | Downloading Historical Daily chart data for BTCF22. Starting date: 2022-01-10. Service: tradingevaluator.dtctrading | 2022-01-13 16:33:49.260 HD Request # 9 | Requesting historical Daily data for BTF22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:33:49.722 HD Request # 9 | Receiving historical Daily data for BTCF22 starting at 2022-01-10 | 2022-01-13 16:33:50.048 HD Request # 9 | Writing historical Daily data to the file BTCF22.dly | 2022-01-13 16:33:50.048 HD Request # 9 | Bytes received: 156 | 2022-01-13 16:33:50.050 HD Request # 9 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for BTCF22 | 2022-01-13 16:33:50.050 HD Request # 9 | Completion time: 1s | 2022-01-13 16:33:50.050 HD Request # 9 | Daily data download complete for BTCF22. Unique request ID: 9 | 2022-01-13 16:33:50.050 Removing historical data download ID 9. | 2022-01-13 16:33:50.050 Triggering next historical data download in queue. | 2022-01-13 16:33:50.065 No download requests in the queue to start downloads for. | 2022-01-13 16:33:50.065 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:33:50.219 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:33:50.219 BTCF22 [CV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:33:50.252 BTCF22 [CV] #10 | Reloading chart. | 2022-01-13 16:33:50.253 BTCF22 [CV] #10 | Reloading chart. | 2022-01-13 16:33:50.529 Added historical Intraday data request for BTCF22 to the queue. | 2022-01-13 16:33:51.063 Intraday data recording state for symbol BTCF22 is set to download 'Pending'. | 2022-01-13 16:33:51.063 Triggering next historical data download in queue. | 2022-01-13 16:33:51.063 SC Data - All Services | Clearing market depth for 6AH22 | 2022-01-13 16:33:51.609 SC Data - All Services | Clearing market depth for 6BH22 | 2022-01-13 16:33:51.609 SC Data - All Services | Received security definition for symbol 6AH22 | 2022-01-13 16:33:51.610 SC Data - All Services | Received security definition for symbol 6BH22 | 2022-01-13 16:33:51.610 SC Data - All Services | Clearing market depth for 6CH22 | 2022-01-13 16:33:55.156 SC Data - All Services | Clearing market depth for 6EH22 | 2022-01-13 16:33:55.156 SC Data - All Services | Clearing market depth for 6JH22 | 2022-01-13 16:33:55.156 SC Data - All Services | Clearing market depth for CLG22 | 2022-01-13 16:33:55.157 SC Data - All Services | Clearing market depth for ESH22 | 2022-01-13 16:33:55.157 SC Data - All Services | Clearing market depth for GCG22 | 2022-01-13 16:33:55.157 SC Data - All Services | Clearing market depth for NGG22 | 2022-01-13 16:33:55.157 SC Data - All Services | Clearing market depth for NQH22 | 2022-01-13 16:33:55.157 SC Data - All Services | Clearing market depth for RBG22 | 2022-01-13 16:33:55.157 SC Data - All Services | Received security definition for symbol 6CH22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol 6EH22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol 6JH22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol 6MH22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol 6SH22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol BBH22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol BTCF22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol CLG22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol ESH22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol GCG22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol HOG22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol NGG22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol NKDH22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol NQH22 | 2022-01-13 16:33:55.159 SC Data - All Services | Received security definition for symbol RBG22 | 2022-01-13 16:33:55.159 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:33:57.942 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:33:57.942 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:33:57.942 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:33:57.942 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:33:57.942 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:33:57.942 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:33:57.942 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:33:57.942 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:33:57.942 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:33:58.270 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:33:58.270 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:33:58.270 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:33:58.270 HD Request # 10 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2022-01-13 16:34:03.167 HD Request # 10 | Download start date-time: 2022-01-13 16:28:10.000000. File last date-time: 2022-01-13 16:28:10.960001 | 2022-01-13 16:34:03.168 HD Request # 10 | Using server: ds12.sierracharts.com port 10149 | 2022-01-13 16:34:03.168 Socket (3) | Creating socket. | 2022-01-13 16:34:03.168 Socket (3) | New receive buffer size: 5242880 | 2022-01-13 16:34:03.168 Socket (3) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:34:03.168 SC Data - All Services | Clearing market depth for TNH22 | 2022-01-13 16:34:08.101 SC Data - All Services | Clearing market depth for YMH22 | 2022-01-13 16:34:08.101 SC Data - All Services | Clearing market depth for ZBH22 | 2022-01-13 16:34:08.101 SC Data - All Services | Clearing market depth for ZFH22 | 2022-01-13 16:34:08.101 SC Data - All Services | Clearing market depth for ZNH22 | 2022-01-13 16:34:08.101 SC Data - All Services | Received security definition for symbol RTYH22 | 2022-01-13 16:34:08.102 SC Data - All Services | Received security definition for symbol SIH22 | 2022-01-13 16:34:08.102 SC Data - All Services | Received security definition for symbol TNH22 | 2022-01-13 16:34:08.102 SC Data - All Services | Received security definition for symbol YMH22 | 2022-01-13 16:34:08.102 SC Data - All Services | Received security definition for symbol ZBH22 | 2022-01-13 16:34:08.102 SC Data - All Services | Received security definition for symbol ZFH22 | 2022-01-13 16:34:08.102 SC Data - All Services | Received security definition for symbol ZNH22 | 2022-01-13 16:34:08.102 SC Data - All Services | Received security definition for symbol ZTH22 | 2022-01-13 16:34:08.102 DTC Client socket (6) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2022-01-13 16:34:09.197 * DTC Client socket (6) | CloseSocket call. | 2022-01-13 16:34:09.197 DTC Client socket (6) | Closed. | 2022-01-13 16:34:09.197 DTC Client socket (0) | CloseSocket call. | 2022-01-13 16:34:09.197 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:34:09.197 SC Data - All Services (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 16:34:09.197 SC Data - All Services (Market Orders Data) | Connecting to the server ds26.sierracharts.com. Port 10060 | 2022-01-13 16:34:11.207 DTC Client socket (4) | Creating socket. | 2022-01-13 16:34:11.265 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:34:11.265 DTC Client socket (4) | Connecting to IP: 38.89.235.129. | 2022-01-13 16:34:11.265 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:34:11.436 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:34:11.436 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:34:11.436 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:34:11.620 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:34:11.620 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:34:12.560 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:34:12.560 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:34:12.560 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 25. Service code: nymex | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLG22 -> CLG22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 15. Service code: comex | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: GCG22 -> GCG22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGG22 -> NGG22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 15. Service code: cme | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NQH22 -> NQH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: RBG22 -> RBG22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: TNH22 -> TNH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 20. Service code: cbot | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: YMH22 -> YMH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 200. Service code: cbot | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 1500. Service code: cbot | 2022-01-13 16:34:12.561 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:34:12.561 Socket (3) | CloseSocket call. | 2022-01-13 16:34:23.165 Socket (3) | Closed. | 2022-01-13 16:34:23.165 HD Request # 10 | Error downloading historical Intraday data for TRIN-NYSE. Timeout error connecting to server. | 2022-01-13 16:34:23.165 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:34:23.166 Triggering next historical data download in queue. | 2022-01-13 16:34:23.166 Historical data download thread signaled to stop. | 2022-01-13 16:34:23.166 HD Request # 10 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for TRIN-NYSE | 2022-01-13 16:34:23.166 HD Request # 10 | Completion time: 20s | 2022-01-13 16:34:23.166 HD Request # 11 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2022-01-13 16:34:23.166 HD Request # 11 | Download start date-time: 2022-01-13 16:28:10.000000. File last date-time: 2022-01-13 16:28:10.960001 | 2022-01-13 16:34:23.167 HD Request # 11 | Using server: ds13-3.sierracharts.com port 10150 | 2022-01-13 16:34:23.167 Socket (3) | Creating socket. | 2022-01-13 16:34:23.167 Socket (3) | New receive buffer size: 5242880 | 2022-01-13 16:34:23.168 Socket (3) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:34:23.168 HD Request # 11 | Setting DTC encoding to Binary VLS | 2022-01-13 16:34:23.860 HD Request # 11 | Sending historical data logon request message. | 2022-01-13 16:34:23.860 HD Request # 11 | Requesting Intraday data. Start date-time: 2022-01-13 16:28:10. Record interval: 0. Symbol: TRIN-NYSE | 2022-01-13 16:34:25.730 HD Request # 11 | Decompressing data. | 2022-01-13 16:34:33.799 HD Request # 11 | Receiving Intraday data for TRIN-NYSE starting at 2022-01-13 16:28:10.000000 | 2022-01-13 16:34:33.799 Socket (3) | CloseSocket call. | 2022-01-13 16:34:39.288 Historical data download thread signaled to stop. | 2022-01-13 16:34:39.289 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:34:39.289 HD Request # 11 | Timestamp of first Intraday data file record written: 2022-01-13 16:28:11.000000 | 2022-01-13 16:34:39.289 HD Request # 11 | Received 373 Intraday data records from 2022-01-13 16:28:10.000000 to 2022-01-13 16:34:22.000000 (6.2 minutes) and wrote 372 records for TRIN-NYSE | 2022-01-13 16:34:39.289 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:34:22.000000 | 2022-01-13 16:34:39.300 Added 158 Time and Sales records to Intraday data file for TRIN-NYSE after download. | 2022-01-13 16:34:39.300 HD Request # 11 | Completion time: 16s | 2022-01-13 16:34:39.300 HD Request # 11 | Intraday data download complete for TRIN-NYSE. Unique request ID: 10 | 2022-01-13 16:34:39.300 Removing historical data download ID 10. | 2022-01-13 16:34:39.300 Real-time Intraday chart data file updates started for TRIN-NYSE | 2022-01-13 16:34:39.300 Intraday chart data file opened for TRIN-NYSE | 2022-01-13 16:34:39.300 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:34:39.300 Triggering next historical data download in queue. | 2022-01-13 16:34:39.300 HD Request # 12 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 16:34:39.301 HD Request # 12 | Download start date-time: 2022-01-13 16:28:10.000000. File last date-time: 2022-01-13 16:28:10.960000 | 2022-01-13 16:34:39.301 HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2022-01-13 16:34:39.301 Socket (6) | Creating socket. | 2022-01-13 16:34:39.302 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 16:34:39.302 Socket (6) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:34:39.302 Socket (3) | Socket gracefully closed by remote side. | 2022-01-13 16:34:39.633 Socket (3) | Closed. | 2022-01-13 16:34:39.634 HD Request # 12 | Setting DTC encoding to Binary VLS | 2022-01-13 16:34:39.883 HD Request # 12 | Sending historical data logon request message. | 2022-01-13 16:34:39.883 HD Request # 12 | Requesting Intraday data. Start date-time: 2022-01-13 16:28:10. Record interval: 0. Symbol: ADV-NYSE | 2022-01-13 16:34:41.462 HD Request # 12 | Decompressing data. | 2022-01-13 16:34:41.743 HD Request # 12 | Receiving Intraday data for ADV-NYSE starting at 2022-01-13 16:28:10.000000 | 2022-01-13 16:34:41.745 Socket (6) | CloseSocket call. | 2022-01-13 16:34:42.033 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:34:42.033 Historical data download thread signaled to stop. | 2022-01-13 16:34:42.035 HD Request # 12 | Timestamp of first Intraday data file record written: 2022-01-13 16:28:11.000000 | 2022-01-13 16:34:42.035 HD Request # 12 | Received 389 Intraday data records from 2022-01-13 16:28:10.000000 to 2022-01-13 16:34:38.000000 (6.5 minutes) and wrote 388 records for ADV-NYSE | 2022-01-13 16:34:42.035 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:34:38.000000 | 2022-01-13 16:34:42.045 Added 10 Time and Sales records to Intraday data file for ADV-NYSE after download. | 2022-01-13 16:34:42.045 HD Request # 12 | Completion time: 3s | 2022-01-13 16:34:42.045 HD Request # 12 | Intraday data download complete for ADV-NYSE. Unique request ID: 11 | 2022-01-13 16:34:42.045 Removing historical data download ID 11. | 2022-01-13 16:34:42.045 Real-time Intraday chart data file updates started for ADV-NYSE | 2022-01-13 16:34:42.045 Intraday chart data file opened for ADV-NYSE | 2022-01-13 16:34:42.045 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:34:42.045 Triggering next historical data download in queue. | 2022-01-13 16:34:42.045 HD Request # 13 | Downloading Intraday chart data for TRIN-SP to the file TRIN-SP.scid. Service: statscalc | 2022-01-13 16:34:42.045 HD Request # 13 | Download start date-time: 2022-01-13 16:28:10.000000. File last date-time: 2022-01-13 16:28:10.960002 | 2022-01-13 16:34:42.046 HD Request # 13 | Using server: ds12.sierracharts.com port 10150 | 2022-01-13 16:34:42.046 Socket (3) | Creating socket. | 2022-01-13 16:34:42.046 Socket (3) | New receive buffer size: 5242880 | 2022-01-13 16:34:42.046 Socket (3) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:34:42.046 HD Request # 13 | Setting DTC encoding to Binary VLS | 2022-01-13 16:34:42.687 HD Request # 13 | Sending historical data logon request message. | 2022-01-13 16:34:42.687 Opened cached Intraday file: C:\SierraChart\Data\TRIN-NYSE.scid. Thread ID: 11608 | 2022-01-13 16:34:43.082 Opened cached Intraday file: C:\SierraChart\Data\ADV-NYSE.scid. Thread ID: 11608 | 2022-01-13 16:34:43.083 HD Request # 13 | Requesting Intraday data. Start date-time: 2022-01-13 16:28:10. Record interval: 0. Symbol: TRIN-SP | 2022-01-13 16:34:43.527 HD Request # 13 | Decompressing data. | 2022-01-13 16:34:43.816 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 16:34:43.968 Socket (6) | Closed. | 2022-01-13 16:34:43.969 Canceling queued historical data download request for ADR-NASDAQ Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 13. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for ESH22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 14. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for CLG22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 15. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for NQH22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 16. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for GCG22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 17. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for 6EH22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 18. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for 6BH22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 19. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for 6CH22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 20. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for 6JH22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 21. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for 6AH22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 22. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for RBG22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 23. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for NGG22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 24. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for ZBH22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 25. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for YMH22 Intraday data. | 2022-01-13 16:34:44.800 Removing historical data download ID 26. | 2022-01-13 16:34:44.800 Canceling queued historical data download request for ZNH22 Intraday data. | 2022-01-13 16:34:44.801 Removing historical data download ID 27. | 2022-01-13 16:34:44.801 Canceling queued historical data download request for TNH22 Intraday data. | 2022-01-13 16:34:44.801 Removing historical data download ID 28. | 2022-01-13 16:34:44.801 Canceling queued historical data download request for ZFH22 Intraday data. | 2022-01-13 16:34:44.801 Removing historical data download ID 29. | 2022-01-13 16:34:44.801 Canceling queued historical data download request for BTCF22 Intraday data. | 2022-01-13 16:34:44.801 Removing historical data download ID 30. | 2022-01-13 16:34:44.801 HD Request # 13 | Active download canceled. | 2022-01-13 16:34:44.801 Historical data download thread signaled to stop. | 2022-01-13 16:34:44.801 Socket (3) | CloseSocket call. | 2022-01-13 16:34:44.801 HD Request # 13 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for TRIN-SP | 2022-01-13 16:34:44.801 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:34:44.801 HD Request # 13 | Completion time: 2s | 2022-01-13 16:34:44.801 HD Request # 13 | Intraday data download complete for TRIN-SP. Unique request ID: 12 | 2022-01-13 16:34:44.801 Removing historical data download ID 12. | 2022-01-13 16:34:44.801 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:34:44.801 Triggering next historical data download in queue. | 2022-01-13 16:34:44.801 Trading Evaluator | Waiting for socket receive thread to end | 2022-01-13 16:34:44.833 DTC Client socket (1) | CloseSocket call. | 2022-01-13 16:34:44.834 DTC Client socket (1) | Max send buffers used during socket life: 4 | 2022-01-13 16:34:44.834 DTC Client socket (1) | Max send buffer size during socket life: 927 | 2022-01-13 16:34:44.834 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:34:44.834 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 16:34:44.834 DTC Client socket (4) | CloseSocket call. | 2022-01-13 16:34:44.835 DTC Client socket (4) | Max send buffers used during socket life: 4 | 2022-01-13 16:34:44.835 DTC Client socket (4) | Max send buffer size during socket life: 1242 | 2022-01-13 16:34:44.835 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:34:44.835 WSACleanup called. | 2022-01-13 16:34:44.835 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:34:44.835 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 16:34:44.835 DTC Client socket (2) | CloseSocket call. | 2022-01-13 16:34:44.835 DTC Client socket (2) | Max send buffers used during socket life: 4 | 2022-01-13 16:34:44.835 DTC Client socket (2) | Max send buffer size during socket life: 2367 | 2022-01-13 16:34:44.835 SC Data - All Services | Disconnected from the server. | 2022-01-13 16:34:44.835 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:34:44.835 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:34:44.835 DTC Client socket (5) | CloseSocket call. | 2022-01-13 16:34:44.836 DTC Client socket (5) | Max send buffers used during socket life: 3 | 2022-01-13 16:34:44.836 DTC Client socket (5) | Max send buffer size during socket life: 348 | 2022-01-13 16:34:44.836 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:34:44.836 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:34:44.836 Trading Evaluator | Disconnected. | 2022-01-13 16:34:44.836 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-01-13 16:34:44.837 No download requests in the queue to start downloads for. | 2022-01-13 16:34:44.837 DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:34:45.005 DTC Client socket (4) | Closed. | 2022-01-13 16:34:45.005 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:34:45.126 DTC Client socket (1) | Closed. | 2022-01-13 16:34:45.126 Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2022-01-13 16:34:46.904 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-01-13 16:34:46.905 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:34:46.905 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:34:46.905 Trading Evaluator | Network connection to server complete. | 2022-01-13 16:34:50.208 Trading Evaluator | Starting socket receive thread. | 2022-01-13 16:34:50.208 Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2022-01-13 16:34:50.208 Trading Evaluator | Setting DTC encoding to Binary VLS | 2022-01-13 16:34:51.101 Trading Evaluator | Sending logon request message. | 2022-01-13 16:34:51.102 Trading Evaluator | Received logon response. | 2022-01-13 16:34:53.830 Trading Evaluator | Server Name: SC DTC Server. Build=40463. | 2022-01-13 16:34:53.830 Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:34:53.830 Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2022-01-13 16:34:53.830 Trading Evaluator | Trading is supported. | 2022-01-13 16:34:53.830 Trading Evaluator | Order cancel and replace is supported. | 2022-01-13 16:34:53.830 Trading Evaluator | OCO Orders supported. | 2022-01-13 16:34:53.830 Trading Evaluator | Bracket Orders supported. | 2022-01-13 16:34:53.830 Trading Evaluator | Connected to server complete. | 2022-01-13 16:34:53.830 Triggering next historical data download in queue. | 2022-01-13 16:34:53.832 Triggering next historical data download in queue. | 2022-01-13 16:34:53.832 Triggering next historical data download in queue. | 2022-01-13 16:34:53.832 Triggering next historical data download in queue. | 2022-01-13 16:34:53.832 No download requests in the queue to start downloads for. | 2022-01-13 16:34:53.883 No download requests in the queue to start downloads for. | 2022-01-13 16:34:53.883 No download requests in the queue to start downloads for. | 2022-01-13 16:34:53.883 No download requests in the queue to start downloads for. | 2022-01-13 16:34:53.883 Mapping ESH22 to ESH22. Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: ESH22 (ESH22). ID: 1 Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: ESH22 (ESH22). ID: 1 | 2022-01-13 16:34:53.884 Mapping NQH22 to NQH22. Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: NQH22 (NQH22). ID: 2 Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: NQH22 (NQH22). ID: 2 | 2022-01-13 16:34:53.884 Mapping RTYH22 to RTYH22. Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: RTYH22 (RTYH22). ID: 3 Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: RTYH22 (RTYH22). ID: 3 | 2022-01-13 16:34:53.884 Mapping YMH22 to YMH22. Service code: cbot | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: YMH22 (YMH22). ID: 4 Service code: cbot | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: YMH22 (YMH22). ID: 4 | 2022-01-13 16:34:53.884 Mapping NKDH22 to NKDH22. Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: NKDH22 (NKDH22). ID: 5 Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: NKDH22 (NKDH22). ID: 5 | 2022-01-13 16:34:53.884 Mapping ZBH22 to ZBH22. Service code: cbot | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: ZBH22 (ZBH22). ID: 6 Service code: cbot | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: ZBH22 (ZBH22). ID: 6 | 2022-01-13 16:34:53.884 Mapping ZNH22 to ZNH22. Service code: cbot | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: ZNH22 (ZNH22). ID: 7 Service code: cbot | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: ZNH22 (ZNH22). ID: 7 | 2022-01-13 16:34:53.884 Mapping ZTH22 to ZTH22. Service code: cbot | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: ZTH22 (ZTH22). ID: 8 Service code: cbot | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: ZTH22 (ZTH22). ID: 8 | 2022-01-13 16:34:53.884 Trading Evaluator | Starting real-time market data updates for: FBTPH22. ID: 9 Service code: eurex | 2022-01-13 16:34:53.884 Trading Evaluator | Requesting security definition data for: FBTPH22. ID: 9 | 2022-01-13 16:34:53.884 Trading Evaluator | Starting real-time market data updates for: FGBLH22. ID: 10 Service code: eurex | 2022-01-13 16:34:53.884 Trading Evaluator | Requesting security definition data for: FGBLH22. ID: 10 | 2022-01-13 16:34:53.884 Trading Evaluator | Starting real-time market data updates for: FGBMH22. ID: 11 Service code: eurex | 2022-01-13 16:34:53.884 Trading Evaluator | Requesting security definition data for: FGBMH22. ID: 11 | 2022-01-13 16:34:53.884 Mapping CLG22 to CLG22. Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: CLG22 (CLG22). ID: 12 Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: CLG22 (CLG22). ID: 12 | 2022-01-13 16:34:53.884 Mapping BBH22 to BBH22. Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: BBH22 (BBH22). ID: 13 Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: BBH22 (BBH22). ID: 13 | 2022-01-13 16:34:53.884 Mapping HOG22 to HOG22. Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: HOG22 (HOG22). ID: 14 Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: HOG22 (HOG22). ID: 14 | 2022-01-13 16:34:53.884 Mapping RBG22 to RBG22. Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: RBG22 (RBG22). ID: 15 Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: RBG22 (RBG22). ID: 15 | 2022-01-13 16:34:53.884 Mapping NGG22 to NGG22. Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: NGG22 (NGG22). ID: 16 Service code: nymex | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: NGG22 (NGG22). ID: 16 | 2022-01-13 16:34:53.884 Mapping GCG22 to GCG22. Service code: comex | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: GCG22 (GCG22). ID: 17 Service code: comex | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: GCG22 (GCG22). ID: 17 | 2022-01-13 16:34:53.884 Mapping SIH22 to SIH22. Service code: comex | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: SIH22 (SIH22). ID: 18 Service code: comex | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: SIH22 (SIH22). ID: 18 | 2022-01-13 16:34:53.884 Mapping 6EH22 to 6EH22. Service code: cme | 2022-01-13 16:34:53.884 DTC Client socket (4) | Creating socket. | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: 6EH22 (6EH22). ID: 19 Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: 6EH22 (6EH22). ID: 19 | 2022-01-13 16:34:53.884 Mapping 6BH22 to 6BH22. Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: 6BH22 (6BH22). ID: 20 Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: 6BH22 (6BH22). ID: 20 | 2022-01-13 16:34:53.884 Mapping 6JH22 to 6JH22. Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: 6JH22 (6JH22). ID: 21 Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: 6JH22 (6JH22). ID: 21 | 2022-01-13 16:34:53.884 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:34:53.884 Mapping 6CH22 to 6CH22. Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: 6CH22 (6CH22). ID: 22 Service code: cme | 2022-01-13 16:34:53.884 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: 6CH22 (6CH22). ID: 22 | 2022-01-13 16:34:53.884 Mapping 6AH22 to 6AH22. Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Starting real-time market data updates for: 6AH22 (6AH22). ID: 23 Service code: cme | 2022-01-13 16:34:53.884 SC Data - All Services | Requesting security definition data for: 6AH22 (6AH22). ID: 23 | 2022-01-13 16:34:53.884 Mapping 6SH22 to 6SH22. Service code: cme | 2022-01-13 16:34:53.885 SC Data - All Services | Starting real-time market data updates for: 6SH22 (6SH22). ID: 24 Service code: cme | 2022-01-13 16:34:53.885 SC Data - All Services | Requesting security definition data for: 6SH22 (6SH22). ID: 24 | 2022-01-13 16:34:53.885 Mapping 6MH22 to 6MH22. Service code: cme | 2022-01-13 16:34:53.885 SC Data - All Services | Starting real-time market data updates for: 6MH22 (6MH22). ID: 25 Service code: cme | 2022-01-13 16:34:53.885 SC Data - All Services | Requesting security definition data for: 6MH22 (6MH22). ID: 25 | 2022-01-13 16:34:53.885 Mapping BTCF22 to BTCF22. Service code: cme | 2022-01-13 16:34:53.885 SC Data - All Services | Starting real-time market data updates for: BTCF22 (BTCF22). ID: 26 Service code: cme | 2022-01-13 16:34:53.885 SC Data - All Services | Requesting security definition data for: BTCF22 (BTCF22). ID: 26 | 2022-01-13 16:34:53.885 Added historical Intraday data request for ESH22 to the queue. | 2022-01-13 16:34:53.979 Intraday data recording state for symbol ESH22 is set to download 'Pending'. | 2022-01-13 16:34:53.979 Triggering next historical data download in queue. | 2022-01-13 16:34:53.979 Delaying start of download for ESH22 | 2022-01-13 16:34:54.004 Added historical Intraday data request for RBG22 to the queue. | 2022-01-13 16:34:54.034 Intraday data recording state for symbol RBG22 is set to download 'Pending'. | 2022-01-13 16:34:54.034 Triggering next historical data download in queue. | 2022-01-13 16:34:54.034 Added historical Intraday data request for GCG22 to the queue. | 2022-01-13 16:34:54.081 Intraday data recording state for symbol GCG22 is set to download 'Pending'. | 2022-01-13 16:34:54.082 Triggering next historical data download in queue. | 2022-01-13 16:34:54.082 SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NASDAQ. ID: 27 Service code: statscalc | 2022-01-13 16:34:54.113 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 443 | 2022-01-13 16:34:54.113 SC DTC Data with Market Depth | Requesting security definition data for: ADR-NASDAQ. ID: 27 | 2022-01-13 16:34:54.114 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:34:54.114 Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2022-01-13 16:34:54.114 Triggering next historical data download in queue. | 2022-01-13 16:34:54.114 DTC Client socket (6) | Creating socket. | 2022-01-13 16:34:54.114 DTC Client socket (6) | New receive buffer size: 5242880 | 2022-01-13 16:34:54.114 DTC Client socket (6) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:34:54.114 Added historical Intraday data request for CLG22 to the queue. | 2022-01-13 16:34:54.119 Intraday data recording state for symbol CLG22 is set to download 'Pending'. | 2022-01-13 16:34:54.119 Triggering next historical data download in queue. | 2022-01-13 16:34:54.119 Added historical Intraday data request for 6EH22 to the queue. | 2022-01-13 16:34:54.147 Intraday data recording state for symbol 6EH22 is set to download 'Pending'. | 2022-01-13 16:34:54.147 Triggering next historical data download in queue. | 2022-01-13 16:34:54.147 Added historical Intraday data request for ZBH22 to the queue. | 2022-01-13 16:34:54.149 Intraday data recording state for symbol ZBH22 is set to download 'Pending'. | 2022-01-13 16:34:54.150 Triggering next historical data download in queue. | 2022-01-13 16:34:54.150 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 28 Service code: statscalc | 2022-01-13 16:34:54.205 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 28 | 2022-01-13 16:34:54.205 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:34:54.205 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2022-01-13 16:34:54.205 Triggering next historical data download in queue. | 2022-01-13 16:34:54.205 Added historical Intraday data request for 6AH22 to the queue. | 2022-01-13 16:34:54.207 Intraday data recording state for symbol 6AH22 is set to download 'Pending'. | 2022-01-13 16:34:54.208 Triggering next historical data download in queue. | 2022-01-13 16:34:54.208 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH22 | 2022-01-13 16:34:54.211 Trading Evaluator | Received security definition for symbol ESH22 | 2022-01-13 16:34:54.211 Added historical Intraday data request for ZNH22 to the queue. | 2022-01-13 16:34:54.225 Intraday data recording state for symbol ZNH22 is set to download 'Pending'. | 2022-01-13 16:34:54.225 Triggering next historical data download in queue. | 2022-01-13 16:34:54.225 Mapping ZFH22 to ZFH22. Service code: cbot | 2022-01-13 16:34:54.226 SC Data - All Services | Starting real-time market data updates for: ZFH22 (ZFH22). ID: 29 Service code: cbot | 2022-01-13 16:34:54.226 SC Data - All Services | Requesting security definition data for: ZFH22 (ZFH22). ID: 29 | 2022-01-13 16:34:54.226 Added historical Intraday data request for ZFH22 to the queue. | 2022-01-13 16:34:54.226 Intraday data recording state for symbol ZFH22 is set to download 'Pending'. | 2022-01-13 16:34:54.226 Triggering next historical data download in queue. | 2022-01-13 16:34:54.226 Added historical Intraday data request for NGG22 to the queue. | 2022-01-13 16:34:54.227 Intraday data recording state for symbol NGG22 is set to download 'Pending'. | 2022-01-13 16:34:54.227 Triggering next historical data download in queue. | 2022-01-13 16:34:54.227 Mapping TNH22 to TNH22. Service code: cbot | 2022-01-13 16:34:54.230 SC Data - All Services | Starting real-time market data updates for: TNH22 (TNH22). ID: 30 Service code: cbot | 2022-01-13 16:34:54.230 SC Data - All Services | Requesting security definition data for: TNH22 (TNH22). ID: 30 | 2022-01-13 16:34:54.230 Added historical Intraday data request for TNH22 to the queue. | 2022-01-13 16:34:54.230 Intraday data recording state for symbol TNH22 is set to download 'Pending'. | 2022-01-13 16:34:54.230 Triggering next historical data download in queue. | 2022-01-13 16:34:54.230 Added historical Intraday data request for YMH22 to the queue. | 2022-01-13 16:34:54.231 Intraday data recording state for symbol YMH22 is set to download 'Pending'. | 2022-01-13 16:34:54.231 Triggering next historical data download in queue. | 2022-01-13 16:34:54.231 Added historical Intraday data request for NQH22 to the queue. | 2022-01-13 16:34:54.254 Intraday data recording state for symbol NQH22 is set to download 'Pending'. | 2022-01-13 16:34:54.254 Triggering next historical data download in queue. | 2022-01-13 16:34:54.254 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:34:54.290 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:34:54.290 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:34:54.290 Added historical Intraday data request for 6JH22 to the queue. | 2022-01-13 16:34:54.432 Intraday data recording state for symbol 6JH22 is set to download 'Pending'. | 2022-01-13 16:34:54.432 Triggering next historical data download in queue. | 2022-01-13 16:34:54.432 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-NYSE. ID: 31 Service code: statscalc | 2022-01-13 16:34:54.435 SC DTC Data with Market Depth | Requesting security definition data for: ADV-NYSE. ID: 31 | 2022-01-13 16:34:54.435 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:34:54.435 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:34:54.435 Triggering next historical data download in queue. | 2022-01-13 16:34:54.435 Added historical Intraday data request for 6CH22 to the queue. | 2022-01-13 16:34:54.441 Intraday data recording state for symbol 6CH22 is set to download 'Pending'. | 2022-01-13 16:34:54.441 Triggering next historical data download in queue. | 2022-01-13 16:34:54.441 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-SP. ID: 32 Service code: statscalc | 2022-01-13 16:34:54.457 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-SP. ID: 32 | 2022-01-13 16:34:54.457 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:34:54.457 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2022-01-13 16:34:54.457 Triggering next historical data download in queue. | 2022-01-13 16:34:54.457 Added historical Intraday data request for 6BH22 to the queue. | 2022-01-13 16:34:54.459 Intraday data recording state for symbol 6BH22 is set to download 'Pending'. | 2022-01-13 16:34:54.459 Triggering next historical data download in queue. | 2022-01-13 16:34:54.459 Added historical Intraday data request for BTCF22 to the queue. | 2022-01-13 16:34:54.461 Intraday data recording state for symbol BTCF22 is set to download 'Pending'. | 2022-01-13 16:34:54.461 Triggering next historical data download in queue. | 2022-01-13 16:34:54.461 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH22 | 2022-01-13 16:34:55.411 Trading Evaluator | Received security definition for symbol NQH22 | 2022-01-13 16:34:55.411 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH22 | 2022-01-13 16:34:55.411 Trading Evaluator | Received security definition for symbol RTYH22 | 2022-01-13 16:34:55.411 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH22 | 2022-01-13 16:34:55.411 Trading Evaluator | Received security definition for symbol YMH22 | 2022-01-13 16:34:55.411 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NKDH22 | 2022-01-13 16:34:55.411 Trading Evaluator | Received security definition for symbol NKDH22 | 2022-01-13 16:34:55.411 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:34:55.812 SC Data - All Services | Sending logon request message. | 2022-01-13 16:34:55.812 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBH22 | 2022-01-13 16:34:56.669 Trading Evaluator | Received security definition for symbol ZBH22 | 2022-01-13 16:34:56.669 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNH22 | 2022-01-13 16:34:56.669 Trading Evaluator | Received security definition for symbol ZNH22 | 2022-01-13 16:34:56.669 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZTH22 | 2022-01-13 16:34:56.669 Trading Evaluator | Received security definition for symbol ZTH22 | 2022-01-13 16:34:56.669 Symbol Error - FBTPH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:34:56.669 Trading Evaluator | Received security definition for symbol FBTPH22 | 2022-01-13 16:34:56.669 Symbol Error - FGBLH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:34:56.669 Trading Evaluator | Received security definition for symbol FGBLH22 | 2022-01-13 16:34:56.669 Symbol Error - FGBMH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:34:56.669 Trading Evaluator | Received security definition for symbol FGBMH22 | 2022-01-13 16:34:56.669 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG22 | 2022-01-13 16:34:56.669 Trading Evaluator | Received security definition for symbol CLG22 | 2022-01-13 16:34:56.669 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBH22 | 2022-01-13 16:34:56.669 Trading Evaluator | Received security definition for symbol BBH22 | 2022-01-13 16:34:56.669 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: HOG22 | 2022-01-13 16:34:56.669 Trading Evaluator | Received security definition for symbol HOG22 | 2022-01-13 16:34:56.669 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RBG22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol RBG22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NGG22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol NGG22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol GCG22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: SIH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol SIH22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol 6EH22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol 6BH22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6JH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol 6JH22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6CH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol 6CH22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6AH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol 6AH22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6SH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol 6SH22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6MH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol 6MH22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BTCF22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol BTCF22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZFH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol ZFH22 | 2022-01-13 16:34:56.670 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: TNH22 | 2022-01-13 16:34:56.670 Trading Evaluator | Received security definition for symbol TNH22 | 2022-01-13 16:34:56.670 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:34:57.453 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:34:57.453 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:34:57.453 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:34:57.835 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:34:57.835 SC Data - All Services | Received logon response. | 2022-01-13 16:34:58.109 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:34:58.109 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:34:58.109 SC Data - All Services | Successfully connected. | 2022-01-13 16:34:58.109 SC Data - All Services | Trading is not supported. | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: 6MH22 -> 6MH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: 6SH22 -> 6SH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: BBH22 -> BBH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: BTCF22 -> BTCF22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: CLG22 -> CLG22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: GCG22 -> GCG22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: HOG22 -> HOG22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: NGG22 -> NGG22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: NKDH22 -> NKDH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: NQH22 -> NQH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: RBG22 -> RBG22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: RTYH22 -> RTYH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: SIH22 -> SIH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: TNH22 -> TNH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: YMH22 -> YMH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Restarting real-time data updates for symbol: ZTH22 -> ZTH22 | 2022-01-13 16:34:58.109 SC Data - All Services | Received security definition for symbol 6AH22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol 6BH22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol 6CH22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol 6EH22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol 6JH22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol 6MH22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol 6SH22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol BBH22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol BTCF22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol CLG22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol ESH22 | 2022-01-13 16:34:58.823 SC Data - All Services | Received security definition for symbol GCG22 | 2022-01-13 16:34:58.823 Requesting market depth updates for: 6AH22 if supported. | 2022-01-13 16:34:58.827 SC Data - All Services (Market Orders Data) | Connecting to the server ds22.sierracharts.com. Port 10060 | 2022-01-13 16:34:58.833 Requesting market depth updates for: 6BH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: 6CH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: 6EH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: 6JH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: CLG22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: ESH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: GCG22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: NGG22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: NQH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: RBG22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: TNH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: YMH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: ZBH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: ZFH22 if supported. | 2022-01-13 16:34:58.833 Requesting market depth updates for: ZNH22 if supported. | 2022-01-13 16:34:58.833 DTC Client socket (7) | Creating socket. | 2022-01-13 16:34:58.834 DTC Client socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:34:58.834 DTC Client socket (7) | Connecting to IP: 208.185.224.129. | 2022-01-13 16:34:58.834 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:34:58.856 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:34:58.856 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:34:58.856 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:34:58.856 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:34:58.856 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:34:58.856 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:34:58.856 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:34:58.856 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:34:58.856 SC Data - All Services | Received security definition for symbol HOG22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol NGG22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol NKDH22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol NQH22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol RBG22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol RTYH22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol SIH22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol TNH22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol YMH22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol ZBH22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol ZFH22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol ZNH22 | 2022-01-13 16:34:59.148 SC Data - All Services | Received security definition for symbol ZTH22 | 2022-01-13 16:34:59.148 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:34:59.158 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:34:59.158 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:34:59.158 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:34:59.246 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:34:59.246 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:34:59.246 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:34:59.246 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:35:00.508 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:35:00.508 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 25. Service code: nymex | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLG22 -> CLG22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 15. Service code: comex | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: GCG22 -> GCG22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGG22 -> NGG22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 15. Service code: cme | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NQH22 -> NQH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: RBG22 -> RBG22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: TNH22 -> TNH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 20. Service code: cbot | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: YMH22 -> YMH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 200. Service code: cbot | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 1500. Service code: cbot | 2022-01-13 16:35:01.796 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:35:01.796 HD Request # 14 | Downloading Intraday chart data for ESH22 to the file ESH22.scid. Service: cme | 2022-01-13 16:35:03.203 HD Request # 14 | Download start date-time: 2022-01-13 16:25:29.000000. File last date-time: 2022-01-13 16:25:29.457007 | 2022-01-13 16:35:03.204 HD Request # 14 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:35:03.204 Socket (8) | Creating socket. | 2022-01-13 16:35:03.204 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:35:03.204 Socket (8) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:35:03.204 HD Request # 14 | Setting DTC encoding to Binary VLS | 2022-01-13 16:35:12.804 HD Request # 14 | Sending historical data logon request message. | 2022-01-13 16:35:12.804 HD Request # 14 | Requesting Intraday data. Start date-time: 2022-01-13 16:25:29. Record interval: 0. Symbol: ESH22 | 2022-01-13 16:35:13.571 HD Request # 14 | Decompressing data. | 2022-01-13 16:35:17.118 HD Request # 14 | Receiving Intraday data for ESH22 starting at 2022-01-13 16:25:29.457000 | 2022-01-13 16:35:17.118 SC Data - All Services | Clearing market depth for 6AH22 | 2022-01-13 16:35:21.739 SC Data - All Services | Clearing market depth for 6BH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for 6CH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for 6EH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for 6JH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for CLG22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for ESH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for GCG22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for NGG22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for NQH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for RBG22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for TNH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for YMH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for ZBH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for ZFH22 | 2022-01-13 16:35:21.740 SC Data - All Services | Clearing market depth for ZNH22 | 2022-01-13 16:35:21.740 Socket (8) | CloseSocket call. | 2022-01-13 16:35:43.134 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:35:43.135 Historical data download thread signaled to stop. | 2022-01-13 16:35:43.135 HD Request # 14 | Timestamp of first Intraday data file record written: 2022-01-13 16:25:29.877000 | 2022-01-13 16:35:43.136 HD Request # 14 | Received 18351 Intraday data records from 2022-01-13 16:25:29.457000 to 2022-01-13 16:35:11.932001 (9.7 minutes) and wrote 18343 records for ESH22 | 2022-01-13 16:35:43.136 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:35:11.932001 | 2022-01-13 16:35:43.146 HD Request # 14 | Completion time: 40s | 2022-01-13 16:35:43.146 HD Request # 14 | Intraday data download complete for ESH22. Unique request ID: 31 | 2022-01-13 16:35:43.146 Removing historical data download ID 31. | 2022-01-13 16:35:43.146 Real-time Intraday chart data file updates started for ESH22 | 2022-01-13 16:35:43.146 Intraday chart data file opened for ESH22 | 2022-01-13 16:35:43.146 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:35:43.146 Triggering next historical data download in queue. | 2022-01-13 16:35:43.146 HD Request # 15 | Downloading Intraday chart data for RBG22 to the file RBG22.scid. Service: nymex | 2022-01-13 16:35:43.146 HD Request # 15 | Download start date-time: 2022-01-13 16:26:12.000000. File last date-time: 2022-01-13 16:26:12.839000 | 2022-01-13 16:35:43.147 HD Request # 15 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:35:43.147 Socket (9) | Creating socket. | 2022-01-13 16:35:43.147 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:35:43.148 Socket (9) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:35:43.148 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:35:43.811 Socket (8) | Closed. | 2022-01-13 16:35:43.811 HD Request # 15 | Setting DTC encoding to Binary VLS | 2022-01-13 16:35:46.766 HD Request # 15 | Sending historical data logon request message. | 2022-01-13 16:35:46.766 HD Request # 15 | Requesting Intraday data. Start date-time: 2022-01-13 16:26:12. Record interval: 0. Symbol: RBG22 | 2022-01-13 16:35:47.522 HD Request # 15 | Decompressing data. | 2022-01-13 16:35:50.133 HD Request # 15 | Receiving Intraday data for RBG22 starting at 2022-01-13 16:26:12.816000 | 2022-01-13 16:35:50.133 Socket (9) | CloseSocket call. | 2022-01-13 16:35:53.126 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:35:53.126 Historical data download thread signaled to stop. | 2022-01-13 16:35:53.129 HD Request # 15 | Timestamp of first Intraday data file record written: 2022-01-13 16:26:39.296000 | 2022-01-13 16:35:53.130 HD Request # 15 | Received 609 Intraday data records from 2022-01-13 16:26:12.816000 to 2022-01-13 16:35:45.374000 (9.5 minutes) and wrote 607 records for RBG22 | 2022-01-13 16:35:53.130 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:35:45.374000 | 2022-01-13 16:35:53.142 HD Request # 15 | Completion time: 10s | 2022-01-13 16:35:53.142 HD Request # 15 | Intraday data download complete for RBG22. Unique request ID: 32 | 2022-01-13 16:35:53.142 Removing historical data download ID 32. | 2022-01-13 16:35:53.142 Real-time Intraday chart data file updates started for RBG22 | 2022-01-13 16:35:53.142 Intraday chart data file opened for RBG22 | 2022-01-13 16:35:53.142 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:35:53.142 Triggering next historical data download in queue. | 2022-01-13 16:35:53.142 HD Request # 16 | Downloading Intraday chart data for GCG22 to the file GCG22.scid. Service: comex | 2022-01-13 16:35:53.142 HD Request # 16 | Download start date-time: 2022-01-13 16:25:27.000000. File last date-time: 2022-01-13 16:25:27.284001 | 2022-01-13 16:35:53.143 HD Request # 16 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:35:53.143 Socket (8) | Creating socket. | 2022-01-13 16:35:53.143 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:35:53.143 Socket (8) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:35:53.143 Opened cached Intraday file: C:\SierraChart\Data\ESH22.scid. Thread ID: 11608 | 2022-01-13 16:35:53.540 HD Request # 16 | Setting DTC encoding to Binary VLS | 2022-01-13 16:35:56.387 HD Request # 16 | Sending historical data logon request message. | 2022-01-13 16:35:56.387 HD Request # 16 | Requesting Intraday data. Start date-time: 2022-01-13 16:25:27. Record interval: 0. Symbol: GCG22 | 2022-01-13 16:35:57.134 HD Request # 16 | Decompressing data. | 2022-01-13 16:35:57.425 HD Request # 16 | Receiving Intraday data for GCG22 starting at 2022-01-13 16:25:27.284000 | 2022-01-13 16:35:58.228 Opened cached Intraday file: C:\SierraChart\Data\RBG22.scid. Thread ID: 11608 | 2022-01-13 16:35:58.576 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:35:58.727 Socket (9) | Closed. | 2022-01-13 16:35:58.727 Socket (8) | CloseSocket call. | 2022-01-13 16:35:59.905 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:35:59.905 Historical data download thread signaled to stop. | 2022-01-13 16:35:59.905 HD Request # 16 | Timestamp of first Intraday data file record written: 2022-01-13 16:25:31.476000 | 2022-01-13 16:35:59.906 HD Request # 16 | Received 1410 Intraday data records from 2022-01-13 16:25:27.284000 to 2022-01-13 16:35:53.204001 (10.4 minutes) and wrote 1408 records for GCG22 | 2022-01-13 16:35:59.906 HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:35:53.204001 | 2022-01-13 16:35:59.917 HD Request # 16 | Completion time: 6s | 2022-01-13 16:35:59.917 HD Request # 16 | Intraday data download complete for GCG22. Unique request ID: 33 | 2022-01-13 16:35:59.917 Removing historical data download ID 33. | 2022-01-13 16:35:59.917 Real-time Intraday chart data file updates started for GCG22 | 2022-01-13 16:35:59.917 Intraday chart data file opened for GCG22 | 2022-01-13 16:35:59.917 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:35:59.917 Triggering next historical data download in queue. | 2022-01-13 16:35:59.917 HD Request # 17 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc | 2022-01-13 16:35:59.917 HD Request # 17 | Download start date-time: 2022-01-13 16:28:10.000000. File last date-time: 2022-01-13 16:28:10.960000 | 2022-01-13 16:35:59.918 HD Request # 17 | Using server: ds13-3.sierracharts.com port 10150 | 2022-01-13 16:35:59.918 Socket (9) | Creating socket. | 2022-01-13 16:35:59.918 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:35:59.918 Socket (9) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:35:59.918 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:36:01.884 Socket (8) | Closed. | 2022-01-13 16:36:01.884 HD Request # 17 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:09.616 HD Request # 17 | Sending historical data logon request message. | 2022-01-13 16:36:09.616 HD Request # 17 | Requesting Intraday data. Start date-time: 2022-01-13 16:28:10. Record interval: 0. Symbol: ADR-NASDAQ | 2022-01-13 16:36:10.588 HD Request # 17 | Decompressing data. | 2022-01-13 16:36:13.926 HD Request # 17 | Receiving Intraday data for ADR-NASDAQ starting at 2022-01-13 16:28:10.000000 | 2022-01-13 16:36:13.926 Socket (9) | CloseSocket call. | 2022-01-13 16:36:13.928 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:13.928 Historical data download thread signaled to stop. | 2022-01-13 16:36:13.931 HD Request # 17 | Timestamp of first Intraday data file record written: 2022-01-13 16:28:11.000000 | 2022-01-13 16:36:13.932 HD Request # 17 | Received 478 Intraday data records from 2022-01-13 16:28:10.000000 to 2022-01-13 16:36:07.000000 (8.0 minutes) and wrote 477 records for ADR-NASDAQ | 2022-01-13 16:36:13.932 HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:36:07.000000 | 2022-01-13 16:36:13.942 HD Request # 17 | Completion time: 14s | 2022-01-13 16:36:13.942 HD Request # 17 | Intraday data download complete for ADR-NASDAQ. Unique request ID: 34 | 2022-01-13 16:36:13.942 Removing historical data download ID 34. | 2022-01-13 16:36:13.942 Real-time Intraday chart data file updates started for ADR-NASDAQ | 2022-01-13 16:36:13.942 Intraday chart data file opened for ADR-NASDAQ | 2022-01-13 16:36:13.942 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:13.942 Triggering next historical data download in queue. | 2022-01-13 16:36:13.942 HD Request # 18 | Downloading Intraday chart data for CLG22 to the file CLG22.scid. Service: nymex | 2022-01-13 16:36:13.943 HD Request # 18 | Download start date-time: 2022-01-13 16:26:27.000000. File last date-time: 2022-01-13 16:26:27.430000 | 2022-01-13 16:36:13.943 HD Request # 18 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:36:13.943 Socket (8) | Creating socket. | 2022-01-13 16:36:13.943 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:36:13.944 Socket (8) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:36:13.944 HD Request # 18 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:14.556 HD Request # 18 | Sending historical data logon request message. | 2022-01-13 16:36:14.556 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:36:15.051 Socket (9) | Closed. | 2022-01-13 16:36:15.051 HD Request # 18 | Requesting Intraday data. Start date-time: 2022-01-13 16:26:27. Record interval: 0. Symbol: CLG22 | 2022-01-13 16:36:15.303 HD Request # 18 | Decompressing data. | 2022-01-13 16:36:15.671 HD Request # 18 | Receiving Intraday data for CLG22 starting at 2022-01-13 16:26:27.430000 | 2022-01-13 16:36:16.273 Socket (8) | CloseSocket call. | 2022-01-13 16:36:16.282 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:16.282 Historical data download thread signaled to stop. | 2022-01-13 16:36:16.286 HD Request # 18 | Timestamp of first Intraday data file record written: 2022-01-13 16:26:28.034000 | 2022-01-13 16:36:16.286 HD Request # 18 | Received 3712 Intraday data records from 2022-01-13 16:26:27.430000 to 2022-01-13 16:36:09.779000 (9.7 minutes) and wrote 3711 records for CLG22 | 2022-01-13 16:36:16.286 HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:36:09.779000 | 2022-01-13 16:36:16.296 HD Request # 18 | Completion time: 3s | 2022-01-13 16:36:16.296 HD Request # 18 | Intraday data download complete for CLG22. Unique request ID: 35 | 2022-01-13 16:36:16.296 Removing historical data download ID 35. | 2022-01-13 16:36:16.296 Real-time Intraday chart data file updates started for CLG22 | 2022-01-13 16:36:16.296 Intraday chart data file opened for CLG22 | 2022-01-13 16:36:16.296 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:16.296 Triggering next historical data download in queue. | 2022-01-13 16:36:16.296 HD Request # 19 | Downloading Intraday chart data for 6EH22 to the file 6EH22.scid. Service: cme | 2022-01-13 16:36:16.296 HD Request # 19 | Download start date-time: 2022-01-13 16:28:07.000000. File last date-time: 2022-01-13 16:28:07.370000 | 2022-01-13 16:36:16.297 HD Request # 19 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:36:16.297 Socket (9) | Creating socket. | 2022-01-13 16:36:16.297 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:36:16.297 Socket (9) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:36:16.297 HD Request # 19 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:16.895 HD Request # 19 | Sending historical data logon request message. | 2022-01-13 16:36:16.895 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:36:17.062 Socket (8) | Closed. | 2022-01-13 16:36:17.062 HD Request # 19 | Requesting Intraday data. Start date-time: 2022-01-13 16:28:07. Record interval: 0. Symbol: 6EH22 | 2022-01-13 16:36:17.689 Opened cached Intraday file: C:\SierraChart\Data\GCG22.scid. Thread ID: 11608 | 2022-01-13 16:36:18.695 HD Request # 19 | Decompressing data. | 2022-01-13 16:36:18.719 HD Request # 19 | Receiving Intraday data for 6EH22 starting at 2022-01-13 16:28:07.370000 | 2022-01-13 16:36:18.719 Socket (9) | CloseSocket call. | 2022-01-13 16:36:19.100 Historical data download thread signaled to stop. | 2022-01-13 16:36:19.101 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:19.101 HD Request # 19 | Timestamp of first Intraday data file record written: 2022-01-13 16:28:12.348000 | 2022-01-13 16:36:19.101 HD Request # 19 | Received 451 Intraday data records from 2022-01-13 16:28:07.370000 to 2022-01-13 16:36:03.646000 (7.9 minutes) and wrote 450 records for 6EH22 | 2022-01-13 16:36:19.101 HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:36:03.646000 | 2022-01-13 16:36:19.111 HD Request # 19 | Completion time: 3s | 2022-01-13 16:36:19.111 HD Request # 19 | Intraday data download complete for 6EH22. Unique request ID: 36 | 2022-01-13 16:36:19.111 Removing historical data download ID 36. | 2022-01-13 16:36:19.111 Real-time Intraday chart data file updates started for 6EH22 | 2022-01-13 16:36:19.111 Intraday chart data file opened for 6EH22 | 2022-01-13 16:36:19.111 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:19.111 Triggering next historical data download in queue. | 2022-01-13 16:36:19.111 HD Request # 20 | Downloading Intraday chart data for ZBH22 to the file ZBH22.scid. Service: cbot | 2022-01-13 16:36:19.112 HD Request # 20 | Download start date-time: 2022-01-13 16:26:36.000000. File last date-time: 2022-01-13 16:26:36.154000 | 2022-01-13 16:36:19.112 HD Request # 20 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:36:19.112 Socket (8) | Creating socket. | 2022-01-13 16:36:19.113 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:36:19.113 Socket (8) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:36:19.113 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:36:19.432 Socket (9) | Closed. | 2022-01-13 16:36:19.433 HD Request # 20 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:20.703 HD Request # 20 | Sending historical data logon request message. | 2022-01-13 16:36:20.703 HD Request # 20 | Requesting Intraday data. Start date-time: 2022-01-13 16:26:36. Record interval: 0. Symbol: ZBH22 | 2022-01-13 16:36:20.994 HD Request # 20 | Decompressing data. | 2022-01-13 16:36:21.303 HD Request # 20 | Receiving Intraday data for ZBH22 starting at 2022-01-13 16:26:36.153000 | 2022-01-13 16:36:23.009 Socket (8) | CloseSocket call. | 2022-01-13 16:36:23.013 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:23.013 Historical data download thread signaled to stop. | 2022-01-13 16:36:23.013 HD Request # 20 | Timestamp of first Intraday data file record written: 2022-01-13 16:27:36.323000 | 2022-01-13 16:36:23.014 HD Request # 20 | Received 1288 Intraday data records from 2022-01-13 16:26:36.153000 to 2022-01-13 16:36:15.631000 (9.7 minutes) and wrote 1285 records for ZBH22 | 2022-01-13 16:36:23.014 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:36:15.631000 | 2022-01-13 16:36:23.025 HD Request # 20 | Completion time: 4s | 2022-01-13 16:36:23.025 HD Request # 20 | Intraday data download complete for ZBH22. Unique request ID: 37 | 2022-01-13 16:36:23.025 Removing historical data download ID 37. | 2022-01-13 16:36:23.025 Real-time Intraday chart data file updates started for ZBH22 | 2022-01-13 16:36:23.025 Intraday chart data file opened for ZBH22 | 2022-01-13 16:36:23.025 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:23.025 Triggering next historical data download in queue. | 2022-01-13 16:36:23.025 HD Request # 21 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2022-01-13 16:36:23.025 HD Request # 21 | Download start date-time: 2022-01-13 16:34:42.000000. File last date-time: 2022-01-13 16:34:42.963001 | 2022-01-13 16:36:23.026 HD Request # 21 | Using server: ds4.sierracharts.com port 10150 | 2022-01-13 16:36:23.026 Socket (9) | Creating socket. | 2022-01-13 16:36:23.026 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:36:23.026 Socket (9) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:36:23.026 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:36:23.303 Socket (8) | Closed. | 2022-01-13 16:36:23.303 HD Request # 21 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:23.614 HD Request # 21 | Sending historical data logon request message. | 2022-01-13 16:36:23.614 Opened cached Intraday file: C:\SierraChart\Data\CLG22.scid. Thread ID: 11608 | 2022-01-13 16:36:23.728 Opened cached Intraday file: C:\SierraChart\Data\6EH22.scid. Thread ID: 11608 | 2022-01-13 16:36:23.729 HD Request # 21 | Requesting Intraday data. Start date-time: 2022-01-13 16:34:42. Record interval: 0. Symbol: TRIN-NYSE | 2022-01-13 16:36:25.219 HD Request # 21 | Decompressing data. | 2022-01-13 16:36:25.504 HD Request # 21 | Receiving Intraday data for TRIN-NYSE starting at 2022-01-13 16:34:42.000000 | 2022-01-13 16:36:25.505 Socket (9) | CloseSocket call. | 2022-01-13 16:36:26.464 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:26.464 Historical data download thread signaled to stop. | 2022-01-13 16:36:26.464 HD Request # 21 | Timestamp of first Intraday data file record written: 2022-01-13 16:34:43.000000 | 2022-01-13 16:36:26.464 HD Request # 21 | Received 102 Intraday data records from 2022-01-13 16:34:42.000000 to 2022-01-13 16:36:23.000000 (101.0 seconds) and wrote 101 records for TRIN-NYSE | 2022-01-13 16:36:26.464 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:36:23.000000 | 2022-01-13 16:36:26.474 HD Request # 21 | Completion time: 3s | 2022-01-13 16:36:26.474 HD Request # 21 | Intraday data download complete for TRIN-NYSE. Unique request ID: 38 | 2022-01-13 16:36:26.474 Removing historical data download ID 38. | 2022-01-13 16:36:26.474 Real-time Intraday chart data file updates started for TRIN-NYSE | 2022-01-13 16:36:26.474 Intraday chart data file opened for TRIN-NYSE | 2022-01-13 16:36:26.474 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:26.474 Triggering next historical data download in queue. | 2022-01-13 16:36:26.474 HD Request # 22 | Downloading Intraday chart data for 6AH22 to the file 6AH22.scid. Service: cme | 2022-01-13 16:36:26.474 HD Request # 22 | Download start date-time: 2022-01-13 16:28:07.000000. File last date-time: 2022-01-13 16:28:07.370004 | 2022-01-13 16:36:26.475 HD Request # 22 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:36:26.475 Socket (8) | Creating socket. | 2022-01-13 16:36:26.475 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:36:26.476 Socket (8) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:36:26.476 HD Request # 22 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:27.067 HD Request # 22 | Sending historical data logon request message. | 2022-01-13 16:36:27.067 HD Request # 22 | Requesting Intraday data. Start date-time: 2022-01-13 16:28:07. Record interval: 0. Symbol: 6AH22 | 2022-01-13 16:36:27.853 HD Request # 22 | Decompressing data. | 2022-01-13 16:36:28.215 HD Request # 22 | Receiving Intraday data for 6AH22 starting at 2022-01-13 16:28:07.370000 | 2022-01-13 16:36:28.217 Socket (8) | CloseSocket call. | 2022-01-13 16:36:28.217 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:28.217 Historical data download thread signaled to stop. | 2022-01-13 16:36:28.217 HD Request # 22 | Timestamp of first Intraday data file record written: 2022-01-13 16:28:11.974000 | 2022-01-13 16:36:28.217 HD Request # 22 | Received 181 Intraday data records from 2022-01-13 16:28:07.370000 to 2022-01-13 16:36:20.833000 (8.2 minutes) and wrote 176 records for 6AH22 | 2022-01-13 16:36:28.218 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:36:20.833000 | 2022-01-13 16:36:28.226 HD Request # 22 | Completion time: 2s | 2022-01-13 16:36:28.226 HD Request # 22 | Intraday data download complete for 6AH22. Unique request ID: 39 | 2022-01-13 16:36:28.226 Removing historical data download ID 39. | 2022-01-13 16:36:28.226 Real-time Intraday chart data file updates started for 6AH22 | 2022-01-13 16:36:28.226 Intraday chart data file opened for 6AH22 | 2022-01-13 16:36:28.226 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:28.226 Triggering next historical data download in queue. | 2022-01-13 16:36:28.227 HD Request # 23 | Downloading Intraday chart data for ZNH22 to the file ZNH22.scid. Service: cbot | 2022-01-13 16:36:28.227 HD Request # 23 | Download start date-time: 2022-01-13 16:25:23.000000. File last date-time: 2022-01-13 16:25:23.947001 | 2022-01-13 16:36:28.227 HD Request # 23 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:36:28.227 Socket (10) | Creating socket. | 2022-01-13 16:36:28.227 Socket (10) | New receive buffer size: 5242880 | 2022-01-13 16:36:28.227 Socket (10) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:36:28.227 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:36:28.615 Socket (9) | Closed. | 2022-01-13 16:36:28.615 Opened cached Intraday file: C:\SierraChart\Data\ZBH22.scid. Thread ID: 11608 | 2022-01-13 16:36:28.772 HD Request # 23 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:28.831 HD Request # 23 | Sending historical data logon request message. | 2022-01-13 16:36:28.831 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:36:29.132 Socket (8) | Closed. | 2022-01-13 16:36:29.132 HD Request # 23 | Requesting Intraday data. Start date-time: 2022-01-13 16:25:23. Record interval: 0. Symbol: ZNH22 | 2022-01-13 16:36:29.618 HD Request # 23 | Decompressing data. | 2022-01-13 16:36:29.908 HD Request # 23 | Receiving Intraday data for ZNH22 starting at 2022-01-13 16:25:23.947000 | 2022-01-13 16:36:32.604 Socket (10) | CloseSocket call. | 2022-01-13 16:36:33.025 Socket (10) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:33.025 Historical data download thread signaled to stop. | 2022-01-13 16:36:33.025 HD Request # 23 | Timestamp of first Intraday data file record written: 2022-01-13 16:25:40.001000 | 2022-01-13 16:36:33.026 HD Request # 23 | Received 3069 Intraday data records from 2022-01-13 16:25:23.947000 to 2022-01-13 16:35:38.929000 (10.2 minutes) and wrote 3067 records for ZNH22 | 2022-01-13 16:36:33.026 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:35:38.929000 | 2022-01-13 16:36:33.037 HD Request # 23 | Completion time: 5s | 2022-01-13 16:36:33.037 HD Request # 23 | Intraday data download complete for ZNH22. Unique request ID: 40 | 2022-01-13 16:36:33.037 Removing historical data download ID 40. | 2022-01-13 16:36:33.037 Real-time Intraday chart data file updates started for ZNH22 | 2022-01-13 16:36:33.037 Intraday chart data file opened for ZNH22 | 2022-01-13 16:36:33.037 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:33.037 Triggering next historical data download in queue. | 2022-01-13 16:36:33.037 HD Request # 24 | Downloading Intraday chart data for ZFH22 to the file ZFH22.scid. Service: cbot | 2022-01-13 16:36:33.037 HD Request # 24 | Download start date-time: 2022-01-13 16:25:17.000000. File last date-time: 2022-01-13 16:25:17.919000 | 2022-01-13 16:36:33.037 HD Request # 24 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:36:33.038 Socket (8) | Creating socket. | 2022-01-13 16:36:33.038 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:36:33.038 Socket (8) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:36:33.038 Socket (10) | Socket gracefully closed by remote side. | 2022-01-13 16:36:33.317 Socket (10) | Closed. | 2022-01-13 16:36:33.317 HD Request # 24 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:33.638 HD Request # 24 | Sending historical data logon request message. | 2022-01-13 16:36:33.638 HD Request # 24 | Requesting Intraday data. Start date-time: 2022-01-13 16:25:17. Record interval: 0. Symbol: ZFH22 | 2022-01-13 16:36:33.931 HD Request # 24 | Decompressing data. | 2022-01-13 16:36:34.220 HD Request # 24 | Receiving Intraday data for ZFH22 starting at 2022-01-13 16:25:17.097000 | 2022-01-13 16:36:34.733 Socket (8) | CloseSocket call. | 2022-01-13 16:36:40.179 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:40.179 Historical data download thread signaled to stop. | 2022-01-13 16:36:40.180 HD Request # 24 | Timestamp of first Intraday data file record written: 2022-01-13 16:25:33.034000 | 2022-01-13 16:36:40.180 HD Request # 24 | Received 2114 Intraday data records from 2022-01-13 16:25:17.097000 to 2022-01-13 16:36:00.872001 (10.7 minutes) and wrote 2110 records for ZFH22 | 2022-01-13 16:36:40.180 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:36:00.872001 | 2022-01-13 16:36:40.191 HD Request # 24 | Completion time: 7s | 2022-01-13 16:36:40.191 HD Request # 24 | Intraday data download complete for ZFH22. Unique request ID: 41 | 2022-01-13 16:36:40.191 Removing historical data download ID 41. | 2022-01-13 16:36:40.191 Real-time Intraday chart data file updates started for ZFH22 | 2022-01-13 16:36:40.191 Intraday chart data file opened for ZFH22 | 2022-01-13 16:36:40.191 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:40.191 Triggering next historical data download in queue. | 2022-01-13 16:36:40.192 HD Request # 25 | Downloading Intraday chart data for NGG22 to the file NGG22.scid. Service: nymex | 2022-01-13 16:36:40.192 HD Request # 25 | Download start date-time: 2022-01-13 16:25:29.000000. File last date-time: 2022-01-13 16:25:29.046004 | 2022-01-13 16:36:40.192 HD Request # 25 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:36:40.192 Socket (9) | Creating socket. | 2022-01-13 16:36:40.193 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:36:40.193 Socket (9) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:36:40.193 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:36:40.472 Socket (8) | Closed. | 2022-01-13 16:36:40.472 HD Request # 25 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:40.791 HD Request # 25 | Sending historical data logon request message. | 2022-01-13 16:36:40.791 HD Request # 25 | Requesting Intraday data. Start date-time: 2022-01-13 16:25:29. Record interval: 0. Symbol: NGG22 | 2022-01-13 16:36:41.084 HD Request # 25 | Decompressing data. | 2022-01-13 16:36:41.409 HD Request # 25 | Receiving Intraday data for NGG22 starting at 2022-01-13 16:25:29.015000 | 2022-01-13 16:36:42.230 Socket (9) | CloseSocket call. | 2022-01-13 16:36:42.571 Historical data download thread signaled to stop. | 2022-01-13 16:36:42.571 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:42.571 HD Request # 25 | Timestamp of first Intraday data file record written: 2022-01-13 16:25:29.683000 | 2022-01-13 16:36:42.571 HD Request # 25 | Received 2354 Intraday data records from 2022-01-13 16:25:29.015000 to 2022-01-13 16:36:37.117000 (11.1 minutes) and wrote 2348 records for NGG22 | 2022-01-13 16:36:42.571 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:36:37.117000 | 2022-01-13 16:36:42.582 HD Request # 25 | Completion time: 2s | 2022-01-13 16:36:42.582 HD Request # 25 | Intraday data download complete for NGG22. Unique request ID: 42 | 2022-01-13 16:36:42.582 Removing historical data download ID 42. | 2022-01-13 16:36:42.582 Real-time Intraday chart data file updates started for NGG22 | 2022-01-13 16:36:42.582 Intraday chart data file opened for NGG22 | 2022-01-13 16:36:42.582 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:42.582 Triggering next historical data download in queue. | 2022-01-13 16:36:42.582 HD Request # 26 | Downloading Intraday chart data for TNH22 to the file TNH22.scid. Service: cbot | 2022-01-13 16:36:42.582 HD Request # 26 | Download start date-time: 2022-01-13 16:26:39.000000. File last date-time: 2022-01-13 16:26:39.224000 | 2022-01-13 16:36:42.583 HD Request # 26 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:36:42.583 Socket (8) | Creating socket. | 2022-01-13 16:36:42.583 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:36:42.583 Socket (8) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:36:42.583 HD Request # 26 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:43.184 HD Request # 26 | Sending historical data logon request message. | 2022-01-13 16:36:43.184 HD Request # 26 | Requesting Intraday data. Start date-time: 2022-01-13 16:26:39. Record interval: 0. Symbol: TNH22 | 2022-01-13 16:36:43.488 Opened cached Intraday file: C:\SierraChart\Data\6AH22.scid. Thread ID: 11608 | 2022-01-13 16:36:43.903 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:36:44.397 Socket (9) | Closed. | 2022-01-13 16:36:44.397 HD Request # 26 | Decompressing data. | 2022-01-13 16:36:45.764 HD Request # 26 | Receiving Intraday data for TNH22 starting at 2022-01-13 16:26:39.221000 | 2022-01-13 16:36:45.765 ESH22 [CV][M] #10 | Reloading chart. | 2022-01-13 16:36:47.967 Socket (8) | CloseSocket call. | 2022-01-13 16:36:48.145 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:36:48.145 Historical data download thread signaled to stop. | 2022-01-13 16:36:48.145 HD Request # 26 | Timestamp of first Intraday data file record written: 2022-01-13 16:26:46.459000 | 2022-01-13 16:36:48.146 HD Request # 26 | Received 1032 Intraday data records from 2022-01-13 16:26:39.221000 to 2022-01-13 16:36:33.546000 (9.9 minutes) and wrote 1026 records for TNH22 | 2022-01-13 16:36:48.146 HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:36:33.546000 | 2022-01-13 16:36:48.151 HD Request # 26 | Completion time: 6s | 2022-01-13 16:36:48.151 HD Request # 26 | Intraday data download complete for TNH22. Unique request ID: 43 | 2022-01-13 16:36:48.151 Removing historical data download ID 43. | 2022-01-13 16:36:48.151 Real-time Intraday chart data file updates started for TNH22 | 2022-01-13 16:36:48.151 Intraday chart data file opened for TNH22 | 2022-01-13 16:36:48.151 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:36:48.151 Triggering next historical data download in queue. | 2022-01-13 16:36:48.151 HD Request # 27 | Downloading Intraday chart data for YMH22 to the file YMH22.scid. Service: cbot | 2022-01-13 16:36:48.151 HD Request # 27 | Download start date-time: 2022-01-13 16:26:49.000000. File last date-time: 2022-01-13 16:26:49.561000 | 2022-01-13 16:36:48.151 HD Request # 27 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:36:48.151 Socket (9) | Creating socket. | 2022-01-13 16:36:48.151 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:36:48.152 Socket (9) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:36:48.152 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:36:48.430 Socket (8) | Closed. | 2022-01-13 16:36:48.430 HD Request # 27 | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:48.754 HD Request # 27 | Sending historical data logon request message. | 2022-01-13 16:36:48.754 Opened cached Intraday file: C:\SierraChart\Data\ZNH22.scid. Thread ID: 11608 | 2022-01-13 16:36:48.940 Opened cached Intraday file: C:\SierraChart\Data\NGG22.scid. Thread ID: 11608 | 2022-01-13 16:36:48.940 Opened cached Intraday file: C:\SierraChart\Data\ZFH22.scid. Thread ID: 11608 | 2022-01-13 16:36:48.941 Opened cached Intraday file: C:\SierraChart\Data\TNH22.scid. Thread ID: 11608 | 2022-01-13 16:36:48.941 HD Request # 27 | Requesting Intraday data. Start date-time: 2022-01-13 16:26:49. Record interval: 0. Symbol: YMH22 | 2022-01-13 16:36:49.833 SC DTC Data with Market Depth | There has been no activity on the network socket for 47s. Will reconnect. | 2022-01-13 16:36:54.168 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:36:54.168 DTC Client socket (6) | CloseSocket call. | 2022-01-13 16:36:54.169 DTC Client socket (6) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:36:54.169 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:36:54.169 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 16:36:54.169 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2022-01-13 16:36:56.173 DTC Client socket (8) | Creating socket. | 2022-01-13 16:36:56.173 DTC Client socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:36:56.174 DTC Client socket (8) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:36:56.174 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:36:56.463 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:36:56.463 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:36:56.463 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:36:56.768 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:36:56.768 HD Request # 27 | Decompressing data. | 2022-01-13 16:36:57.306 HD Request # 27 | Receiving Intraday data for YMH22 starting at 2022-01-13 16:26:49.463000 | 2022-01-13 16:36:57.306 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:36:57.620 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:36:57.620 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:36:57.620 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:36:57.620 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:36:57.620 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:36:57.620 Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2022-01-13 16:36:57.620 Triggering next historical data download in queue. | 2022-01-13 16:36:57.620 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:36:57.620 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:36:57.620 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:36:57.620 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2022-01-13 16:36:57.620 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:36:57.620 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:36:57.620 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:36:57.931 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:36:57.931 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:36:57.931 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:36:57.931 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:37:06.079 DTC Client socket (2) | Closed. | 2022-01-13 16:37:06.079 Socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:37:06.079 Socket (3) | Closed. | 2022-01-13 16:37:06.079 DTC Client socket (5) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:37:06.079 DTC Client socket (5) | Closed. | 2022-01-13 16:37:06.079 File >> Disconnect selected. | 2022-01-13 16:37:35.527 Canceling queued historical data download request for NQH22 Intraday data. | 2022-01-13 16:37:35.527 Removing historical data download ID 45. | 2022-01-13 16:37:35.527 Canceling queued historical data download request for 6JH22 Intraday data. | 2022-01-13 16:37:35.527 Removing historical data download ID 46. | 2022-01-13 16:37:35.527 Canceling queued historical data download request for ADV-NYSE Intraday data. | 2022-01-13 16:37:35.527 Removing historical data download ID 47. | 2022-01-13 16:37:35.527 Canceling queued historical data download request for 6CH22 Intraday data. | 2022-01-13 16:37:35.527 Removing historical data download ID 48. | 2022-01-13 16:37:35.527 Canceling queued historical data download request for TRIN-SP Intraday data. | 2022-01-13 16:37:35.527 Removing historical data download ID 49. | 2022-01-13 16:37:35.527 Canceling queued historical data download request for 6BH22 Intraday data. | 2022-01-13 16:37:35.527 Removing historical data download ID 50. | 2022-01-13 16:37:35.527 Canceling queued historical data download request for BTCF22 Intraday data. | 2022-01-13 16:37:35.527 Removing historical data download ID 51. | 2022-01-13 16:37:35.527 Canceling queued historical data download request for ADR-NASDAQ Intraday data. | 2022-01-13 16:37:35.527 Removing historical data download ID 52. | 2022-01-13 16:37:35.527 Canceling queued historical data download request for TRIN-NYSE Intraday data. | 2022-01-13 16:37:35.527 Removing historical data download ID 53. | 2022-01-13 16:37:35.527 HD Request # 27 | Active download canceled. | 2022-01-13 16:37:35.527 Historical data download thread signaled to stop. | 2022-01-13 16:37:35.527 Socket (9) | CloseSocket call. | 2022-01-13 16:37:35.527 Socket (9) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:37:35.527 HD Request # 27 | Timestamp of first Intraday data file record written: 2022-01-13 16:26:50.622000 | 2022-01-13 16:37:35.527 HD Request # 27 | Received 191 Intraday data records from 2022-01-13 16:26:49.463000 to 2022-01-13 16:27:44.979000 (55.5 seconds) and wrote 186 records for YMH22 | 2022-01-13 16:37:35.527 HD Request # 27 | Completion time: 47s | 2022-01-13 16:37:35.527 HD Request # 27 | Intraday data download complete for YMH22. Unique request ID: 44 | 2022-01-13 16:37:35.527 Removing historical data download ID 44. | 2022-01-13 16:37:35.527 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:37:35.527 Triggering next historical data download in queue. | 2022-01-13 16:37:35.527 Trading Evaluator | Waiting for socket receive thread to end | 2022-01-13 16:37:35.559 DTC Client socket (1) | CloseSocket call. | 2022-01-13 16:37:35.560 DTC Client socket (1) | Max send buffers used during socket life: 4 | 2022-01-13 16:37:35.560 DTC Client socket (1) | Max send buffer size during socket life: 1095 | 2022-01-13 16:37:35.560 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:37:35.560 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 16:37:35.560 DTC Client socket (7) | CloseSocket call. | 2022-01-13 16:37:35.561 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:37:35.561 WSACleanup called. | 2022-01-13 16:37:35.561 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:37:35.561 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 16:37:35.561 DTC Client socket (4) | CloseSocket call. | 2022-01-13 16:37:35.561 DTC Client socket (4) | Max send buffers used during socket life: 4 | 2022-01-13 16:37:35.561 DTC Client socket (4) | Max send buffer size during socket life: 1746 | 2022-01-13 16:37:35.561 SC Data - All Services | Disconnected from the server. | 2022-01-13 16:37:35.561 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:37:35.561 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:37:35.561 DTC Client socket (8) | CloseSocket call. | 2022-01-13 16:37:35.562 DTC Client socket (8) | Max send buffers used during socket life: 3 | 2022-01-13 16:37:35.562 DTC Client socket (8) | Max send buffer size during socket life: 348 | 2022-01-13 16:37:35.562 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:37:35.562 DTC Client socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:37:35.562 Trading Evaluator | Disconnected. | 2022-01-13 16:37:35.562 No download requests in the queue to start downloads for. | 2022-01-13 16:37:35.562 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:37:35.853 DTC Client socket (1) | Closed. | 2022-01-13 16:37:35.853 DTC Client socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:37:35.856 DTC Client socket (7) | Closed. | 2022-01-13 16:37:35.856 DTC Client socket (2) | Deleting network socket now after delay. | 2022-01-13 16:37:36.084 Socket (3) | Deleting network socket now after delay. | 2022-01-13 16:37:36.084 DTC Client socket (5) | Deleting network socket now after delay. | 2022-01-13 16:37:36.084 Socket (9) | Write has completed. Shutdown being performed. | 2022-01-13 16:37:36.719 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:37:36.719 DTC Client socket (6) | Write has completed. Shutdown being performed. | 2022-01-13 16:37:45.830 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:37:45.830 DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-13 16:37:45.830 * DTC Client socket (6) | Socket gracefully closed by remote side. | 2022-01-13 16:37:45.830 DTC Client socket (6) | Closed. | 2022-01-13 16:37:45.830 WSACleanup called. | 2022-01-13 16:37:46.911 Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 2. | 2022-01-13 16:37:46.914 Current selected Data/Trading service: CQG WebAPI | 2022-01-13 16:37:46.914 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-01-13 16:37:48.240 F.US.EPH22 [CV][M] #10 | Reloading chart. | 2022-01-13 16:37:48.275 Added historical Intraday data request for F.US.EPZ21 to the queue. | 2022-01-13 16:37:48.280 Triggering next historical data download in queue. | 2022-01-13 16:37:48.280 F.US.EPH22 [CV][M] #10 | Performing continuous chart historical Daily data download for symbol F.US.EPH22 starting at last date in file. | 2022-01-13 16:37:48.286 Added historical Daily data request for F.US.EPH22 to the queue. | 2022-01-13 16:37:48.286 Triggering next historical data download in queue. | 2022-01-13 16:37:48.286 F.US.EPH22 [CV][M] #10 | Waiting for historical downloads to complete with the IDs: 54, 55, | 2022-01-13 16:37:48.334 Mapping F.US.EPZ21 to ESZ21. Service code: cme | 2022-01-13 16:37:48.335 HD Request # 28 | Downloading Intraday chart data for F.US.EPZ21 to the file F.US.EPZ21.scid. Service: cme | 2022-01-13 16:37:48.335 HD Request # 28 | Download start date-time: 2021-09-28 06:04:27.000000. File last date-time: 2021-09-28 06:04:27.159004 | 2022-01-13 16:37:48.335 HD Request # 28 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:37:48.335 Mapping F.US.EPH22 to ESH22. Service code: cme | 2022-01-13 16:37:48.335 Socket (2) | Creating socket. | 2022-01-13 16:37:48.336 Socket (2) | New receive buffer size: 5242880 | 2022-01-13 16:37:48.336 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:37:48.336 HD Request # 29 | Downloading Historical Daily chart data for F.US.EPH22. Starting date: 2022-01-10. Service: cqg | 2022-01-13 16:37:48.337 F.US.JY6H22[M] #21 | Reloading chart. | 2022-01-13 16:37:48.339 F.US.JY6H22[M] #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.339 F.US.ENQH22[M] #4 | Reloading chart. | 2022-01-13 16:37:48.357 F.US.ENQH22[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.358 F.US.CA6H22[M] #20 | Reloading chart. | 2022-01-13 16:37:48.366 F.US.CA6H22[M] #20 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.367 F.US.YMH22[M] #29 | Reloading chart. | 2022-01-13 16:37:48.370 F.US.YMH22[M] #29 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.370 F.US.GCEG22 [CV][M] #7 | Reloading chart. | 2022-01-13 16:37:48.375 Added historical Intraday data request for F.US.GCEZ21 to the queue. | 2022-01-13 16:37:48.379 Triggering next historical data download in queue. | 2022-01-13 16:37:48.379 F.US.GCEG22 [CV][M] #7 | Performing continuous chart historical Daily data download for symbol F.US.GCEG22 starting at last date in file. | 2022-01-13 16:37:48.385 Added historical Daily data request for F.US.GCEG22 to the queue. | 2022-01-13 16:37:48.385 Triggering next historical data download in queue. | 2022-01-13 16:37:48.385 F.US.GCEG22 [CV][M] #7 | Waiting for historical downloads to complete with the IDs: 56, 57, | 2022-01-13 16:37:48.436 F.US.BP6H22[M] #17 | Reloading chart. | 2022-01-13 16:37:48.446 F.US.BP6H22[M] #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.447 F.US.EPH22 [CV][M] 5 Min #3 | Reloading chart. | 2022-01-13 16:37:48.455 F.US.EPH22 [CV][M] 5 Min #3 | Waiting for historical downloads to complete with the IDs: 54, 55, | 2022-01-13 16:37:48.491 F.US.RBEG22 [CV][M] #32 | Reloading chart. | 2022-01-13 16:37:48.498 Added historical Intraday data request for F.US.RBEQ21 to the queue. | 2022-01-13 16:37:48.500 Triggering next historical data download in queue. | 2022-01-13 16:37:48.500 Added historical Intraday data request for F.US.RBEU21 to the queue. | 2022-01-13 16:37:48.504 Added historical Intraday data request for F.US.RBEV21 to the queue. | 2022-01-13 16:37:48.510 Added historical Intraday data request for F.US.RBEX21 to the queue. | 2022-01-13 16:37:48.517 Added historical Intraday data request for F.US.RBEZ21 to the queue. | 2022-01-13 16:37:48.520 Added historical Intraday data request for F.US.RBEF22 to the queue. | 2022-01-13 16:37:48.524 Added historical Intraday data request for F.US.RBEG22 to the queue. | 2022-01-13 16:37:48.529 F.US.RBEG22 [CV][M] #32 | Performing continuous chart historical Daily data download for symbol F.US.RBEG22 starting at last date in file. | 2022-01-13 16:37:48.532 Added historical Daily data request for F.US.RBEG22 to the queue. | 2022-01-13 16:37:48.532 Triggering next historical data download in queue. | 2022-01-13 16:37:48.532 F.US.RBEG22 [CV][M] #32 | Waiting for historical downloads to complete with the IDs: 58, 59, 60, 61, 62, 63, 64, 65, | 2022-01-13 16:37:48.589 Symbol settings MD5 received. Request ID: 2. | 2022-01-13 16:37:48.595 Requested symbol settings for service code cqg. Request ID: 3. | 2022-01-13 16:37:48.596 F.US.GCEG22 [CV][M] 5 Min #24 | Reloading chart. | 2022-01-13 16:37:48.598 F.US.GCEG22 [CV][M] 5 Min #24 | Waiting for historical downloads to complete with the IDs: 56, 57, | 2022-01-13 16:37:48.630 F.US.CLEG22[M] #1 | Reloading chart. | 2022-01-13 16:37:48.637 F.US.CLEG22[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.637 F.US.EU6H22[M] #16 | Reloading chart. | 2022-01-13 16:37:48.642 F.US.EU6H22[M] #16 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.642 F.US.USAH22[M] #28 | Reloading chart. | 2022-01-13 16:37:48.647 F.US.USAH22[M] #28 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.647 F.US.CLEG22 [CV][M] #11 | Reloading chart. | 2022-01-13 16:37:48.652 Added historical Intraday data request for F.US.CLEU21 to the queue. | 2022-01-13 16:37:48.660 Triggering next historical data download in queue. | 2022-01-13 16:37:48.660 Added historical Intraday data request for F.US.CLEV21 to the queue. | 2022-01-13 16:37:48.667 Added historical Intraday data request for F.US.CLEF22 to the queue. | 2022-01-13 16:37:48.684 Added historical Intraday data request for F.US.CLEG22 to the queue. | 2022-01-13 16:37:48.690 F.US.CLEG22 [CV][M] #11 | Performing continuous chart historical Daily data download for symbol F.US.CLEG22 starting at last date in file. | 2022-01-13 16:37:48.695 Added historical Daily data request for F.US.CLEG22 to the queue. | 2022-01-13 16:37:48.695 Triggering next historical data download in queue. | 2022-01-13 16:37:48.695 F.US.CLEG22 [CV][M] #11 | Waiting for historical downloads to complete with the IDs: 66, 67, 68, 69, 70, | 2022-01-13 16:37:48.749 F.US.CLEG22 [CV][M] 5 Min #18 | Reloading chart. | 2022-01-13 16:37:48.761 F.US.CLEG22 [CV][M] 5 Min #18 | Waiting for historical downloads to complete with the IDs: 68, 69, 70, | 2022-01-13 16:37:48.781 F.US.EPH22 [CV][M] #8 | Reloading chart. | 2022-01-13 16:37:48.789 F.US.EPH22 [CV][M] #8 | Waiting for historical downloads to complete with the IDs: 54, 55, | 2022-01-13 16:37:48.832 HD Request # 29 | Requesting historical Daily data for ESH22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:37:48.833 F.US.DA6H22[M] #22 | Reloading chart. | 2022-01-13 16:37:48.838 F.US.DA6H22[M] #22 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.839 F.US.EPH22[M] #12 | Reloading chart. | 2022-01-13 16:37:48.846 F.US.EPH22[M] #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.847 F.US.GCEG22[M] #5 | Reloading chart. | 2022-01-13 16:37:48.854 F.US.GCEG22[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.855 F.US.RBEG22[M] #23 | Reloading chart. | 2022-01-13 16:37:48.861 F.US.RBEG22[M] #23 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.862 F.US.TYAH22[M] #27 | Reloading chart. | 2022-01-13 16:37:48.871 F.US.TYAH22[M] #27 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.871 F.US.FVAH22[M] #30 | Reloading chart. | 2022-01-13 16:37:48.873 F.US.FVAH22[M] #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.873 F.US.NGEG22[M] #26 | Reloading chart. | 2022-01-13 16:37:48.875 F.US.NGEG22[M] #26 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.875 F.US.TNAH22[M] #6 | Reloading chart. | 2022-01-13 16:37:48.878 F.US.TNAH22[M] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:48.878 F.US.YMH22 [CV][M] #31 | Reloading chart. | 2022-01-13 16:37:48.884 Added historical Intraday data request for F.US.YMZ21 to the queue. | 2022-01-13 16:37:48.886 Triggering next historical data download in queue. | 2022-01-13 16:37:48.886 Added historical Intraday data request for F.US.YMH22 to the queue. | 2022-01-13 16:37:48.889 F.US.YMH22 [CV][M] #31 | Performing continuous chart historical Daily data download for symbol F.US.YMH22 starting at last date in file. | 2022-01-13 16:37:48.891 Added historical Daily data request for F.US.YMH22 to the queue. | 2022-01-13 16:37:48.891 Triggering next historical data download in queue. | 2022-01-13 16:37:48.891 F.US.YMH22 [CV][M] #31 | Waiting for historical downloads to complete with the IDs: 71, 72, 73, | 2022-01-13 16:37:48.937 F.US.ENQH22 [CV][M] #9 | Reloading chart. | 2022-01-13 16:37:48.949 Added historical Intraday data request for F.US.ENQZ21 to the queue. | 2022-01-13 16:37:48.952 Triggering next historical data download in queue. | 2022-01-13 16:37:48.952 F.US.ENQH22 [CV][M] #9 | Performing continuous chart historical Daily data download for symbol F.US.ENQH22 starting at last date in file. | 2022-01-13 16:37:48.956 Added historical Daily data request for F.US.ENQH22 to the queue. | 2022-01-13 16:37:48.956 Triggering next historical data download in queue. | 2022-01-13 16:37:48.956 F.US.ENQH22 [CV][M] #9 | Waiting for historical downloads to complete with the IDs: 74, 75, | 2022-01-13 16:37:48.998 F.US.ENQH22 [CV][M] 5 Min #19 | Reloading chart. | 2022-01-13 16:37:49.006 F.US.ENQH22 [CV][M] 5 Min #19 | Waiting for historical downloads to complete with the IDs: 74, 75, | 2022-01-13 16:37:49.048 Mapping F.US.ENQH22 to NQH22. Service code: cme | 2022-01-13 16:37:49.070 Mapping F.US.RTYH22 to RTYH22. Service code: cme | 2022-01-13 16:37:49.071 Mapping F.US.YMH22 to YMH22. Service code: cbot | 2022-01-13 16:37:49.071 Mapping F.US.NKDH22 to NKDH22. Service code: cme | 2022-01-13 16:37:49.071 Mapping F.US.USAH22 to ZBH22. Service code: cbot | 2022-01-13 16:37:49.071 Mapping F.US.TYAH22 to ZNH22. Service code: cbot | 2022-01-13 16:37:49.071 Mapping F.US.TUAH22 to ZTH22. Service code: cbot | 2022-01-13 16:37:49.071 Mapping F.US.CLEG22 to CLG22. Service code: nymex | 2022-01-13 16:37:49.072 Mapping F.US.HOEG22 to HOG22. Service code: nymex | 2022-01-13 16:37:49.073 Mapping F.US.RBEG22 to RBG22. Service code: nymex | 2022-01-13 16:37:49.073 Mapping F.US.NGEG22 to NGG22. Service code: nymex | 2022-01-13 16:37:49.073 Mapping F.US.GCEG22 to GCG22. Service code: comex | 2022-01-13 16:37:49.073 Mapping F.US.SIEH22 to SIH22. Service code: comex | 2022-01-13 16:37:49.073 Mapping F.US.EU6H22 to 6EH22. Service code: cme | 2022-01-13 16:37:49.074 Mapping F.US.BP6H22 to 6BH22. Service code: cme | 2022-01-13 16:37:49.074 Mapping F.US.JY6H22 to 6JH22. Service code: cme | 2022-01-13 16:37:49.074 Mapping F.US.CA6H22 to 6CH22. Service code: cme | 2022-01-13 16:37:49.074 Mapping F.US.DA6H22 to 6AH22. Service code: cme | 2022-01-13 16:37:49.074 Mapping F.US.SF6H22 to 6SH22. Service code: cme | 2022-01-13 16:37:49.075 Mapping F.US.MX6H22 to 6MH22. Service code: cme | 2022-01-13 16:37:49.075 Mapping F.US.BTCF22 to BTCF22. Service code: cme | 2022-01-13 16:37:49.075 Added historical Intraday data request for F.US.JY6H22 to the queue. | 2022-01-13 16:37:49.097 Intraday data recording state for symbol F.US.JY6H22 is set to download 'Pending'. | 2022-01-13 16:37:49.097 Triggering next historical data download in queue. | 2022-01-13 16:37:49.097 Added historical Intraday data request for F.US.CA6H22 to the queue. | 2022-01-13 16:37:49.101 Intraday data recording state for symbol F.US.CA6H22 is set to download 'Pending'. | 2022-01-13 16:37:49.101 Triggering next historical data download in queue. | 2022-01-13 16:37:49.101 Added historical Intraday data request for F.US.ENQH22 to the queue. | 2022-01-13 16:37:49.104 Intraday data recording state for symbol F.US.ENQH22 is set to download 'Pending'. | 2022-01-13 16:37:49.104 Triggering next historical data download in queue. | 2022-01-13 16:37:49.104 Added historical Intraday data request for F.US.BP6H22 to the queue. | 2022-01-13 16:37:49.126 Intraday data recording state for symbol F.US.BP6H22 is set to download 'Pending'. | 2022-01-13 16:37:49.126 Triggering next historical data download in queue. | 2022-01-13 16:37:49.126 Added historical Intraday data request for F.US.USAH22 to the queue. | 2022-01-13 16:37:49.129 Intraday data recording state for symbol F.US.USAH22 is set to download 'Pending'. | 2022-01-13 16:37:49.129 Triggering next historical data download in queue. | 2022-01-13 16:37:49.129 Added historical Intraday data request for F.US.EU6H22 to the queue. | 2022-01-13 16:37:49.131 Intraday data recording state for symbol F.US.EU6H22 is set to download 'Pending'. | 2022-01-13 16:37:49.131 Triggering next historical data download in queue. | 2022-01-13 16:37:49.131 Added historical Intraday data request for F.US.EPH22 to the queue. | 2022-01-13 16:37:49.138 Intraday data recording state for symbol F.US.EPH22 is set to download 'Pending'. | 2022-01-13 16:37:49.138 Triggering next historical data download in queue. | 2022-01-13 16:37:49.138 Added historical Intraday data request for F.US.DA6H22 to the queue. | 2022-01-13 16:37:49.154 Intraday data recording state for symbol F.US.DA6H22 is set to download 'Pending'. | 2022-01-13 16:37:49.154 Triggering next historical data download in queue. | 2022-01-13 16:37:49.154 Added historical Intraday data request for F.US.GCEG22 to the queue. | 2022-01-13 16:37:49.163 Intraday data recording state for symbol F.US.GCEG22 is set to download 'Pending'. | 2022-01-13 16:37:49.163 Triggering next historical data download in queue. | 2022-01-13 16:37:49.163 Mapping F.US.TNAH22 to TNH22. Service code: cbot | 2022-01-13 16:37:49.170 Added historical Intraday data request for F.US.TNAH22 to the queue. | 2022-01-13 16:37:49.170 Intraday data recording state for symbol F.US.TNAH22 is set to download 'Pending'. | 2022-01-13 16:37:49.170 Triggering next historical data download in queue. | 2022-01-13 16:37:49.170 Added historical Intraday data request for F.US.NGEG22 to the queue. | 2022-01-13 16:37:49.172 Intraday data recording state for symbol F.US.NGEG22 is set to download 'Pending'. | 2022-01-13 16:37:49.172 Triggering next historical data download in queue. | 2022-01-13 16:37:49.172 Mapping F.US.FVAH22 to ZFH22. Service code: cbot | 2022-01-13 16:37:49.174 Added historical Intraday data request for F.US.FVAH22 to the queue. | 2022-01-13 16:37:49.174 Intraday data recording state for symbol F.US.FVAH22 is set to download 'Pending'. | 2022-01-13 16:37:49.174 Triggering next historical data download in queue. | 2022-01-13 16:37:49.174 Added historical Intraday data request for F.US.TYAH22 to the queue. | 2022-01-13 16:37:49.175 Intraday data recording state for symbol F.US.TYAH22 is set to download 'Pending'. | 2022-01-13 16:37:49.175 Triggering next historical data download in queue. | 2022-01-13 16:37:49.175 HD Request # 29 | Receiving historical Daily data for F.US.EPH22 starting at 2022-01-10 | 2022-01-13 16:37:49.195 HD Request # 29 | Writing historical Daily data to the file F.US.EPH22.dly | 2022-01-13 16:37:49.195 HD Request # 29 | Bytes received: 183 | 2022-01-13 16:37:49.201 HD Request # 29 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for F.US.EPH22 | 2022-01-13 16:37:49.201 HD Request # 29 | Completion time: 1s | 2022-01-13 16:37:49.201 HD Request # 29 | Daily data download complete for F.US.EPH22. Unique request ID: 55 | 2022-01-13 16:37:49.201 Removing historical data download ID 55. | 2022-01-13 16:37:49.201 Triggering next historical data download in queue. | 2022-01-13 16:37:49.201 HD Request # 30 | Downloading Historical Daily chart data for F.US.GCEG22. Starting date: 2022-01-10. Service: cqg | 2022-01-13 16:37:49.205 HD Request # 30 | Requesting historical Daily data for GCG22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:37:49.654 HD Request # 30 | Receiving historical Daily data for F.US.GCEG22 starting at 2022-01-10 | 2022-01-13 16:37:49.967 HD Request # 30 | Writing historical Daily data to the file F.US.GCEG22.dly | 2022-01-13 16:37:49.968 HD Request # 30 | Bytes received: 175 | 2022-01-13 16:37:49.980 HD Request # 30 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for F.US.GCEG22 | 2022-01-13 16:37:49.980 HD Request # 30 | Completion time: 0s | 2022-01-13 16:37:49.980 HD Request # 30 | Daily data download complete for F.US.GCEG22. Unique request ID: 57 | 2022-01-13 16:37:49.980 Removing historical data download ID 57. | 2022-01-13 16:37:49.980 Triggering next historical data download in queue. | 2022-01-13 16:37:49.980 HD Request # 31 | Downloading Historical Daily chart data for F.US.RBEG22. Starting date: 2022-01-10. Service: cqg | 2022-01-13 16:37:49.985 CQG WebAPI | Connecting to server api.cqg.com | 2022-01-13 16:37:50.238 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-01-13 16:37:50.238 CQG WebSocket socket (6) | Creating socket. Using TLS 1.2. | 2022-01-13 16:37:50.397 CQG WebSocket socket (6) | New receive buffer size: 5242880 | 2022-01-13 16:37:50.398 CQG WebSocket socket (6) | Connecting to IP: 195.166.124.165. | 2022-01-13 16:37:50.398 HD Request # 31 | Requesting historical Daily data for RBG22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:37:50.411 CQG WebSocket | Opening WebSocket. | 2022-01-13 16:37:50.471 CQG WebSocket | Sending WebSocket handshake. | 2022-01-13 16:37:50.471 Symbol settings received. Request ID: 3. | 2022-01-13 16:37:50.597 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-01-13 16:37:50.695 CQG WebSocket | Server header | Connection: upgrade | 2022-01-13 16:37:50.695 CQG WebSocket | Server header | Sec-WebSocket-Accept: CstdcTOk/Z17EWbbb0qL7UjnTgU= | 2022-01-13 16:37:50.695 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-01-13 16:37:50.695 CQG WebSocket | Server header | Upgrade: websocket | 2022-01-13 16:37:50.695 CQG WebSocket | Server header | | 2022-01-13 16:37:50.695 CQG WebSocket | Web socket state is now open. | 2022-01-13 16:37:50.695 CQG WebAPI | WebSocket connected. | 2022-01-13 16:37:50.695 CQG WebAPI | Sending market data logon message. | 2022-01-13 16:37:50.695 HD Request # 31 | Receiving historical Daily data for F.US.RBEG22 starting at 2022-01-10 | 2022-01-13 16:37:50.728 HD Request # 31 | Writing historical Daily data to the file F.US.RBEG22.dly | 2022-01-13 16:37:50.728 HD Request # 31 | Bytes received: 175 | 2022-01-13 16:37:50.737 HD Request # 31 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for F.US.RBEG22 | 2022-01-13 16:37:50.737 HD Request # 31 | Completion time: 1s | 2022-01-13 16:37:50.737 HD Request # 31 | Daily data download complete for F.US.RBEG22. Unique request ID: 65 | 2022-01-13 16:37:50.737 Removing historical data download ID 65. | 2022-01-13 16:37:50.737 Triggering next historical data download in queue. | 2022-01-13 16:37:50.737 HD Request # 32 | Downloading Historical Daily chart data for F.US.CLEG22. Starting date: 2022-01-10. Service: cqg | 2022-01-13 16:37:50.738 HD Request # 32 | Requesting historical Daily data for CLG22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:37:51.214 CQG WebAPI | Base Time: 2022-01-09T00:38:55. 2022-01-09 00:38:55 | 2022-01-13 16:37:51.328 CQG WebAPI | Logon successful. Session Token = 46avsAxJgGQiuWR/Wxn/r5uV2ys7LLJcyMlNSrB+z/ofa/PgVepM83tWqzK6m5xtSGRRVdPG8EJ | 2022-01-13 16:37:51.328 CQG WebAPI | Connected to server complete. | 2022-01-13 16:37:51.328 Triggering next historical data download in queue. | 2022-01-13 16:37:51.330 Triggering next historical data download in queue. | 2022-01-13 16:37:51.330 Triggering next historical data download in queue. | 2022-01-13 16:37:51.330 Triggering next historical data download in queue. | 2022-01-13 16:37:51.330 Updated verified funded futures trading account ending date to: 2022-02-12 16:37:51 | 2022-01-13 16:37:51.330 CQG WebAPI | Sending Trade Accounts request message. | 2022-01-13 16:37:51.331 No download requests in the queue to start downloads for. | 2022-01-13 16:37:51.331 No download requests in the queue to start downloads for. | 2022-01-13 16:37:51.331 Mapping F.US.JY6H22 to 6JH22. Service code: cme | 2022-01-13 16:37:51.338 SC Data - All Services | Starting real-time market data updates for: F.US.JY6H22 (6JH22). ID: 1 Service code: cme | 2022-01-13 16:37:51.338 SC Data - All Services | Connecting to the server ds6-2.sierracharts.com. Port 443 | 2022-01-13 16:37:51.338 CQG WebAPI | Sending symbol resolution request for F.US.JY6H22. ID: 816042 | 2022-01-13 16:37:51.338 SC Data - All Services | Requesting security definition data for: F.US.JY6H22 (6JH22). ID: 1 | 2022-01-13 16:37:51.338 DTC Client socket (3) | Creating socket. | 2022-01-13 16:37:51.339 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-01-13 16:37:51.339 DTC Client socket (3) | Connecting to IP: 51.195.180.15. | 2022-01-13 16:37:51.339 Mapping F.US.EPH22 to ESH22. Service code: cme | 2022-01-13 16:37:51.345 SC Data - All Services | Starting real-time market data updates for: F.US.EPH22 (ESH22). ID: 2 Service code: cme | 2022-01-13 16:37:51.345 CQG WebAPI | Sending symbol resolution request for F.US.EPH22. ID: 816043 | 2022-01-13 16:37:51.345 SC Data - All Services | Requesting security definition data for: F.US.EPH22 (ESH22). ID: 2 | 2022-01-13 16:37:51.345 Mapping F.US.DA6H22 to 6AH22. Service code: cme | 2022-01-13 16:37:51.352 SC Data - All Services | Starting real-time market data updates for: F.US.DA6H22 (6AH22). ID: 3 Service code: cme | 2022-01-13 16:37:51.352 CQG WebAPI | Sending symbol resolution request for F.US.DA6H22. ID: 816044 | 2022-01-13 16:37:51.352 SC Data - All Services | Requesting security definition data for: F.US.DA6H22 (6AH22). ID: 3 | 2022-01-13 16:37:51.352 Mapping F.US.ENQH22 to NQH22. Service code: cme | 2022-01-13 16:37:51.368 SC Data - All Services | Starting real-time market data updates for: F.US.ENQH22 (NQH22). ID: 4 Service code: cme | 2022-01-13 16:37:51.368 CQG WebAPI | Sending symbol resolution request for F.US.ENQH22. ID: 816045 | 2022-01-13 16:37:51.368 SC Data - All Services | Requesting security definition data for: F.US.ENQH22 (NQH22). ID: 4 | 2022-01-13 16:37:51.368 Mapping F.US.RBEG22 to RBG22. Service code: nymex | 2022-01-13 16:37:51.375 SC Data - All Services | Starting real-time market data updates for: F.US.RBEG22 (RBG22). ID: 5 Service code: nymex | 2022-01-13 16:37:51.375 CQG WebAPI | Sending symbol resolution request for F.US.RBEG22. ID: 816046 | 2022-01-13 16:37:51.375 SC Data - All Services | Requesting security definition data for: F.US.RBEG22 (RBG22). ID: 5 | 2022-01-13 16:37:51.375 Mapping F.US.GCEG22 to GCG22. Service code: comex | 2022-01-13 16:37:51.381 SC Data - All Services | Starting real-time market data updates for: F.US.GCEG22 (GCG22). ID: 6 Service code: comex | 2022-01-13 16:37:51.381 CQG WebAPI | Sending symbol resolution request for F.US.GCEG22. ID: 816047 | 2022-01-13 16:37:51.381 SC Data - All Services | Requesting security definition data for: F.US.GCEG22 (GCG22). ID: 6 | 2022-01-13 16:37:51.381 Mapping F.US.CA6H22 to 6CH22. Service code: cme | 2022-01-13 16:37:51.387 SC Data - All Services | Starting real-time market data updates for: F.US.CA6H22 (6CH22). ID: 7 Service code: cme | 2022-01-13 16:37:51.387 CQG WebAPI | Sending symbol resolution request for F.US.CA6H22. ID: 816048 | 2022-01-13 16:37:51.387 SC Data - All Services | Requesting security definition data for: F.US.CA6H22 (6CH22). ID: 7 | 2022-01-13 16:37:51.387 HD Request # 32 | Receiving historical Daily data for F.US.CLEG22 starting at 2022-01-10 | 2022-01-13 16:37:51.392 HD Request # 32 | Writing historical Daily data to the file F.US.CLEG22.dly | 2022-01-13 16:37:51.393 HD Request # 32 | Bytes received: 169 | 2022-01-13 16:37:51.419 HD Request # 32 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for F.US.CLEG22 | 2022-01-13 16:37:51.419 HD Request # 32 | Completion time: 1s | 2022-01-13 16:37:51.419 HD Request # 32 | Daily data download complete for F.US.CLEG22. Unique request ID: 70 | 2022-01-13 16:37:51.419 Removing historical data download ID 70. | 2022-01-13 16:37:51.419 Triggering next historical data download in queue. | 2022-01-13 16:37:51.419 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:37:51.420 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:37:51.420 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:37:51.420 Mapping F.US.YMH22 to YMH22. Service code: cbot | 2022-01-13 16:37:51.420 HD Request # 33 | Downloading Historical Daily chart data for F.US.YMH22. Starting date: 2022-01-10. Service: cqg | 2022-01-13 16:37:51.426 CQG WebAPI | Received symbol resolution report for symbol F.US.JY6H22. Search Symbol: F.US.JY6H22. Request ID: 816042. Contract ID: 1. | 2022-01-13 16:37:51.426 CQG WebAPI | Brokerage name: AMP. Account Name: 146043 | 2022-01-13 16:37:51.426 Updated verified funded futures trading account ending date to: 2022-02-12 16:37:51 | 2022-01-13 16:37:51.426 CQG WebAPI | Sending collateral subscribe request. | 2022-01-13 16:37:51.426 CQG WebAPI | Received symbol resolution report for symbol F.US.EPH22. Search Symbol: F.US.EPH22. Request ID: 816043. Contract ID: 2. | 2022-01-13 16:37:51.427 F.US.TNAH22[M] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.429 Mapping F.US.TNAH22 to TNH22. Service code: cbot | 2022-01-13 16:37:51.429 SC Data - All Services | Starting real-time market data updates for: F.US.TNAH22 (TNH22). ID: 9 Service code: cbot | 2022-01-13 16:37:51.429 CQG WebAPI | Sending symbol resolution request for F.US.TNAH22. ID: 816050 | 2022-01-13 16:37:51.429 SC Data - All Services | Requesting security definition data for: F.US.TNAH22 (TNH22). ID: 9 | 2022-01-13 16:37:51.429 F.US.NGEG22[M] #26 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.433 Mapping F.US.NGEG22 to NGG22. Service code: nymex | 2022-01-13 16:37:51.433 SC Data - All Services | Starting real-time market data updates for: F.US.NGEG22 (NGG22). ID: 10 Service code: nymex | 2022-01-13 16:37:51.433 CQG WebAPI | Sending symbol resolution request for F.US.NGEG22. ID: 816051 | 2022-01-13 16:37:51.433 SC Data - All Services | Requesting security definition data for: F.US.NGEG22 (NGG22). ID: 10 | 2022-01-13 16:37:51.434 F.US.FVAH22[M] #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.442 Mapping F.US.FVAH22 to ZFH22. Service code: cbot | 2022-01-13 16:37:51.442 SC Data - All Services | Starting real-time market data updates for: F.US.FVAH22 (ZFH22). ID: 11 Service code: cbot | 2022-01-13 16:37:51.442 CQG WebAPI | Sending symbol resolution request for F.US.FVAH22. ID: 816052 | 2022-01-13 16:37:51.442 SC Data - All Services | Requesting security definition data for: F.US.FVAH22 (ZFH22). ID: 11 | 2022-01-13 16:37:51.442 F.US.TYAH22[M] #27 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.445 Mapping F.US.TYAH22 to ZNH22. Service code: cbot | 2022-01-13 16:37:51.446 SC Data - All Services | Starting real-time market data updates for: F.US.TYAH22 (ZNH22). ID: 12 Service code: cbot | 2022-01-13 16:37:51.446 CQG WebAPI | Sending symbol resolution request for F.US.TYAH22. ID: 816053 | 2022-01-13 16:37:51.446 SC Data - All Services | Requesting security definition data for: F.US.TYAH22 (ZNH22). ID: 12 | 2022-01-13 16:37:51.446 F.US.YMH22[M] #29 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.453 SC Data - All Services | Starting real-time market data updates for: F.US.YMH22 (YMH22). ID: 8 Service code: cbot | 2022-01-13 16:37:51.453 CQG WebAPI | Sending symbol resolution request for F.US.YMH22. ID: 816054 | 2022-01-13 16:37:51.453 SC Data - All Services | Requesting security definition data for: F.US.YMH22 (YMH22). ID: 8 | 2022-01-13 16:37:51.453 F.US.USAH22[M] #28 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.457 Mapping F.US.USAH22 to ZBH22. Service code: cbot | 2022-01-13 16:37:51.457 SC Data - All Services | Starting real-time market data updates for: F.US.USAH22 (ZBH22). ID: 13 Service code: cbot | 2022-01-13 16:37:51.457 CQG WebAPI | Sending symbol resolution request for F.US.USAH22. ID: 816055 | 2022-01-13 16:37:51.457 SC Data - All Services | Requesting security definition data for: F.US.USAH22 (ZBH22). ID: 13 | 2022-01-13 16:37:51.457 F.US.EU6H22[M] #16 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.460 Mapping F.US.EU6H22 to 6EH22. Service code: cme | 2022-01-13 16:37:51.460 SC Data - All Services | Starting real-time market data updates for: F.US.EU6H22 (6EH22). ID: 14 Service code: cme | 2022-01-13 16:37:51.460 CQG WebAPI | Sending symbol resolution request for F.US.EU6H22. ID: 816056 | 2022-01-13 16:37:51.460 SC Data - All Services | Requesting security definition data for: F.US.EU6H22 (6EH22). ID: 14 | 2022-01-13 16:37:51.460 F.US.CLEG22[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.466 Mapping F.US.CLEG22 to CLG22. Service code: nymex | 2022-01-13 16:37:51.467 SC Data - All Services | Starting real-time market data updates for: F.US.CLEG22 (CLG22). ID: 15 Service code: nymex | 2022-01-13 16:37:51.467 CQG WebAPI | Sending symbol resolution request for F.US.CLEG22. ID: 816057 | 2022-01-13 16:37:51.467 SC Data - All Services | Requesting security definition data for: F.US.CLEG22 (CLG22). ID: 15 | 2022-01-13 16:37:51.467 Mapping F.US.RTYH22 to RTYH22. Service code: cme | 2022-01-13 16:37:51.470 SC Data - All Services | Starting real-time market data updates for: F.US.RTYH22 (RTYH22). ID: 16 Service code: cme | 2022-01-13 16:37:51.470 CQG WebAPI | Sending symbol resolution request for F.US.RTYH22. ID: 816058 | 2022-01-13 16:37:51.470 SC Data - All Services | Requesting security definition data for: F.US.RTYH22 (RTYH22). ID: 16 | 2022-01-13 16:37:51.470 Mapping F.US.NKDH22 to NKDH22. Service code: cme | 2022-01-13 16:37:51.470 SC Data - All Services | Starting real-time market data updates for: F.US.NKDH22 (NKDH22). ID: 17 Service code: cme | 2022-01-13 16:37:51.470 CQG WebAPI | Sending symbol resolution request for F.US.NKDH22. ID: 816059 | 2022-01-13 16:37:51.470 SC Data - All Services | Requesting security definition data for: F.US.NKDH22 (NKDH22). ID: 17 | 2022-01-13 16:37:51.470 Mapping F.US.TUAH22 to ZTH22. Service code: cbot | 2022-01-13 16:37:51.471 SC Data - All Services | Starting real-time market data updates for: F.US.TUAH22 (ZTH22). ID: 18 Service code: cbot | 2022-01-13 16:37:51.471 CQG WebAPI | Sending symbol resolution request for F.US.TUAH22. ID: 816060 | 2022-01-13 16:37:51.471 SC Data - All Services | Requesting security definition data for: F.US.TUAH22 (ZTH22). ID: 18 | 2022-01-13 16:37:51.471 CQG WebAPI | Starting real-time market data updates for: F.US.FBTPH22. ID: 19 Service code: cqg | 2022-01-13 16:37:51.471 CQG WebAPI | Sending symbol resolution request for F.US.FBTPH22. ID: 816061 | 2022-01-13 16:37:51.471 CQG WebAPI | Requesting security definition data for: F.US.FBTPH22. ID: 19 | 2022-01-13 16:37:51.471 CQG WebAPI | Starting real-time market data updates for: F.US.DBH22. ID: 20 Service code: cqg | 2022-01-13 16:37:51.471 CQG WebAPI | Sending symbol resolution request for F.US.DBH22. ID: 816062 | 2022-01-13 16:37:51.471 CQG WebAPI | Requesting security definition data for: F.US.DBH22. ID: 20 | 2022-01-13 16:37:51.471 CQG WebAPI | Starting real-time market data updates for: F.US.DLH22. ID: 21 Service code: cqg | 2022-01-13 16:37:51.471 CQG WebAPI | Sending symbol resolution request for F.US.DLH22. ID: 816063 | 2022-01-13 16:37:51.471 CQG WebAPI | Requesting security definition data for: F.US.DLH22. ID: 21 | 2022-01-13 16:37:51.471 CQG WebAPI | Starting real-time market data updates for: BBH22. ID: 22 | 2022-01-13 16:37:51.471 CQG WebAPI | Sending symbol resolution request for BBH22. ID: 816064 | 2022-01-13 16:37:51.471 CQG WebAPI | Requesting security definition data for: BBH22. ID: 22 | 2022-01-13 16:37:51.471 Mapping F.US.HOEG22 to HOG22. Service code: nymex | 2022-01-13 16:37:51.471 SC Data - All Services | Starting real-time market data updates for: F.US.HOEG22 (HOG22). ID: 23 Service code: nymex | 2022-01-13 16:37:51.471 CQG WebAPI | Sending symbol resolution request for F.US.HOEG22. ID: 816065 | 2022-01-13 16:37:51.471 SC Data - All Services | Requesting security definition data for: F.US.HOEG22 (HOG22). ID: 23 | 2022-01-13 16:37:51.471 Mapping F.US.SIEH22 to SIH22. Service code: comex | 2022-01-13 16:37:51.472 SC Data - All Services | Starting real-time market data updates for: F.US.SIEH22 (SIH22). ID: 24 Service code: comex | 2022-01-13 16:37:51.472 CQG WebAPI | Sending symbol resolution request for F.US.SIEH22. ID: 816066 | 2022-01-13 16:37:51.472 SC Data - All Services | Requesting security definition data for: F.US.SIEH22 (SIH22). ID: 24 | 2022-01-13 16:37:51.472 Mapping F.US.BP6H22 to 6BH22. Service code: cme | 2022-01-13 16:37:51.472 SC Data - All Services | Starting real-time market data updates for: F.US.BP6H22 (6BH22). ID: 25 Service code: cme | 2022-01-13 16:37:51.472 CQG WebAPI | Sending symbol resolution request for F.US.BP6H22. ID: 816067 | 2022-01-13 16:37:51.472 SC Data - All Services | Requesting security definition data for: F.US.BP6H22 (6BH22). ID: 25 | 2022-01-13 16:37:51.472 Mapping F.US.SF6H22 to 6SH22. Service code: cme | 2022-01-13 16:37:51.472 SC Data - All Services | Starting real-time market data updates for: F.US.SF6H22 (6SH22). ID: 26 Service code: cme | 2022-01-13 16:37:51.472 CQG WebAPI | Sending symbol resolution request for F.US.SF6H22. ID: 816068 | 2022-01-13 16:37:51.472 SC Data - All Services | Requesting security definition data for: F.US.SF6H22 (6SH22). ID: 26 | 2022-01-13 16:37:51.472 Mapping F.US.MX6H22 to 6MH22. Service code: cme | 2022-01-13 16:37:51.472 SC Data - All Services | Starting real-time market data updates for: F.US.MX6H22 (6MH22). ID: 27 Service code: cme | 2022-01-13 16:37:51.472 CQG WebAPI | Sending symbol resolution request for F.US.MX6H22. ID: 816069 | 2022-01-13 16:37:51.472 SC Data - All Services | Requesting security definition data for: F.US.MX6H22 (6MH22). ID: 27 | 2022-01-13 16:37:51.472 Mapping F.US.BTCF22 to BTCF22. Service code: cme | 2022-01-13 16:37:51.472 SC Data - All Services | Starting real-time market data updates for: F.US.BTCF22 (BTCF22). ID: 28 Service code: cme | 2022-01-13 16:37:51.472 CQG WebAPI | Sending symbol resolution request for F.US.BTCF22. ID: 816070 | 2022-01-13 16:37:51.472 SC Data - All Services | Requesting security definition data for: F.US.BTCF22 (BTCF22). ID: 28 | 2022-01-13 16:37:51.472 F.US.BP6H22[M] #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.483 CQG WebAPI | Received symbol resolution report for symbol F.US.DA6H22. Search Symbol: F.US.DA6H22. Request ID: 816044. Contract ID: 3. | 2022-01-13 16:37:51.491 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQH22. Search Symbol: F.US.ENQH22. Request ID: 816045. Contract ID: 4. | 2022-01-13 16:37:51.491 CQG WebAPI | Received symbol resolution report for symbol F.US.RBEG22. Search Symbol: F.US.RBEG22. Request ID: 816046. Contract ID: 5. | 2022-01-13 16:37:51.496 CQG WebAPI | Received symbol resolution report for symbol F.US.GCEG22. Search Symbol: F.US.GCEG22. Request ID: 816047. Contract ID: 6. | 2022-01-13 16:37:51.496 CQG WebAPI | Received symbol resolution report for symbol F.US.CA6H22. Search Symbol: F.US.CA6H22. Request ID: 816048. Contract ID: 7. | 2022-01-13 16:37:51.496 CQG WebAPI | Received symbol resolution report for symbol F.US.TNAH22. Search Symbol: F.US.TNAH22. Request ID: 816050. Contract ID: 8. | 2022-01-13 16:37:51.506 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:37:51.506 SC Data - All Services | Sending logon request message. | 2022-01-13 16:37:51.506 CQG WebAPI | Received symbol resolution report for symbol F.US.NGEG22. Search Symbol: F.US.NGEG22. Request ID: 816051. Contract ID: 9. | 2022-01-13 16:37:51.506 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-NYSE. ID: 29 Service code: statscalc | 2022-01-13 16:37:51.521 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2022-01-13 16:37:51.521 SC DTC Data with Market Depth | Requesting security definition data for: ADV-NYSE. ID: 29 | 2022-01-13 16:37:51.521 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:37:51.521 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:37:51.521 Triggering next historical data download in queue. | 2022-01-13 16:37:51.521 DTC Client socket (10) | Creating socket. | 2022-01-13 16:37:51.521 DTC Client socket (10) | New receive buffer size: 5242880 | 2022-01-13 16:37:51.521 DTC Client socket (10) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:37:51.521 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-SP. ID: 30 Service code: statscalc | 2022-01-13 16:37:51.530 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-SP. ID: 30 | 2022-01-13 16:37:51.530 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:37:51.530 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2022-01-13 16:37:51.530 Triggering next historical data download in queue. | 2022-01-13 16:37:51.530 SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NASDAQ. ID: 31 Service code: statscalc | 2022-01-13 16:37:51.533 SC DTC Data with Market Depth | Requesting security definition data for: ADR-NASDAQ. ID: 31 | 2022-01-13 16:37:51.533 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:37:51.533 Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2022-01-13 16:37:51.533 Triggering next historical data download in queue. | 2022-01-13 16:37:51.533 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 32 Service code: statscalc | 2022-01-13 16:37:51.539 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 32 | 2022-01-13 16:37:51.539 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:37:51.539 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2022-01-13 16:37:51.539 Triggering next historical data download in queue. | 2022-01-13 16:37:51.539 CQG WebAPI | Received symbol resolution report for symbol F.US.FVAH22. Search Symbol: F.US.FVAH22. Request ID: 816052. Contract ID: 10. | 2022-01-13 16:37:51.575 CQG WebAPI | Received symbol resolution report for symbol F.US.TYAH22. Search Symbol: F.US.TYAH22. Request ID: 816053. Contract ID: 11. | 2022-01-13 16:37:51.575 CQG WebAPI | Received symbol resolution report for symbol F.US.YMH22. Search Symbol: F.US.YMH22. Request ID: 816054. Contract ID: 12. | 2022-01-13 16:37:51.580 CQG WebAPI | Received symbol resolution report for symbol F.US.USAH22. Search Symbol: F.US.USAH22. Request ID: 816055. Contract ID: 13. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.EU6H22. Search Symbol: F.US.EU6H22. Request ID: 816056. Contract ID: 14. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG22. Search Symbol: F.US.CLEG22. Request ID: 816057. Contract ID: 15. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYH22. Search Symbol: F.US.RTYH22. Request ID: 816058. Contract ID: 16. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.NKDH22. Search Symbol: F.US.NKDH22. Request ID: 816059. Contract ID: 17. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.TUAH22. Search Symbol: F.US.TUAH22. Request ID: 816060. Contract ID: 18. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.FBTPH22. Search Symbol: F.US.FBTPH22. Request ID: 816061. Contract ID: 19. | 2022-01-13 16:37:51.584 CQG WebAPI | Requesting market data for F.US.FBTPH22 | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.DBH22. Search Symbol: F.US.DBH22. Request ID: 816062. Contract ID: 20. | 2022-01-13 16:37:51.584 CQG WebAPI | Requesting market data for F.US.DBH22 | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.DLH22. Search Symbol: F.US.DLH22. Request ID: 816063. Contract ID: 21. | 2022-01-13 16:37:51.584 CQG WebAPI | Requesting market data for F.US.DLH22 | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.HOEG22. Search Symbol: F.US.HOEG22. Request ID: 816065. Contract ID: 22. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.SIEH22. Search Symbol: F.US.SIEH22. Request ID: 816066. Contract ID: 23. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.BP6H22. Search Symbol: F.US.BP6H22. Request ID: 816067. Contract ID: 24. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.SF6H22. Search Symbol: F.US.SF6H22. Request ID: 816068. Contract ID: 25. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.MX6H22. Search Symbol: F.US.MX6H22. Request ID: 816069. Contract ID: 26. | 2022-01-13 16:37:51.584 CQG WebAPI | Received symbol resolution report for symbol F.US.BTCF22. Search Symbol: F.US.BTCF22. Request ID: 816070. Contract ID: 27. | 2022-01-13 16:37:51.584 F.US.JY6H22[M] #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.590 F.US.EPH22[M] #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.597 F.US.DA6H22[M] #22 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.603 F.US.ENQH22[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.616 F.US.RBEG22[M] #23 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.624 F.US.GCEG22[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.640 F.US.CA6H22[M] #20 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:37:51.654 CQG WebAPI | Received symbol resolution report for symbol F.CN.BBH22. Search Symbol: BBH22. Request ID: 816064. Contract ID: 28. | 2022-01-13 16:37:51.658 Symbol Error - BBH22 is unknown, unavailable, or improperly formatted. Exact match not found for symbol BBH22 | 2022-01-13 16:37:51.658 CQG WebAPI | Market data subscription for F.US.FBTPH22 was unsuccessful. Text: Real-time data subscription for instrument F.US.FBTP (corresponding to ID = 19) is not enabled. | 2022-01-13 16:37:51.661 Symbol Error - F.US.FBTPH22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.FBTP (corresponding to ID = 19) is not enabled. | 2022-01-13 16:37:51.661 CQG WebAPI | Market data subscription for F.US.DBH22 was unsuccessful. Text: Real-time data subscription for instrument F.US.DB (corresponding to ID = 20) is not enabled. | 2022-01-13 16:37:51.661 Symbol Error - F.US.DBH22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.DB (corresponding to ID = 20) is not enabled. | 2022-01-13 16:37:51.661 CQG WebAPI | Market data subscription for F.US.DLH22 was unsuccessful. Text: Real-time data subscription for instrument F.US.DL (corresponding to ID = 21) is not enabled. | 2022-01-13 16:37:51.661 Symbol Error - F.US.DLH22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.DL (corresponding to ID = 21) is not enabled. | 2022-01-13 16:37:51.661 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:37:51.808 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:37:51.808 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:37:51.808 HD Request # 33 | Requesting historical Daily data for YMH22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:37:51.910 HD Request # 28 | Setting DTC encoding to Binary VLS | 2022-01-13 16:37:51.926 HD Request # 28 | Sending historical data logon request message. | 2022-01-13 16:37:51.926 SC Data - All Services | Received logon response. | 2022-01-13 16:37:52.007 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:37:52.007 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:37:52.007 SC Data - All Services | Successfully connected. | 2022-01-13 16:37:52.007 SC Data - All Services | Trading is not supported. | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6H22 -> 6BH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.BTCF22 -> BTCF22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6H22 -> 6CH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEG22 -> CLG22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6H22 -> 6AH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.ENQH22 -> NQH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPH22 -> ESH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6H22 -> 6EH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAH22 -> ZFH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEG22 -> GCG22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEG22 -> HOG22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6H22 -> 6JH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.MX6H22 -> 6MH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEG22 -> NGG22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.NKDH22 -> NKDH22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEG22 -> RBG22 | 2022-01-13 16:37:52.007 SC Data - All Services | Restarting real-time data updates for symbol: F.US.RTYH22 -> RTYH22 | 2022-01-13 16:37:52.008 SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6H22 -> 6SH22 | 2022-01-13 16:37:52.008 SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEH22 -> SIH22 | 2022-01-13 16:37:52.008 SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAH22 -> TNH22 | 2022-01-13 16:37:52.008 SC Data - All Services | Restarting real-time data updates for symbol: F.US.TUAH22 -> ZTH22 | 2022-01-13 16:37:52.008 SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAH22 -> ZNH22 | 2022-01-13 16:37:52.008 SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAH22 -> ZBH22 | 2022-01-13 16:37:52.008 SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMH22 -> YMH22 | 2022-01-13 16:37:52.008 SC Data - All Services | Received security definition for symbol F.US.BP6H22 | 2022-01-13 16:37:52.101 SC Data - All Services | Received security definition for symbol F.US.BTCF22 | 2022-01-13 16:37:52.101 SC Data - All Services | Received security definition for symbol F.US.CA6H22 | 2022-01-13 16:37:52.101 SC Data - All Services | Received security definition for symbol F.US.CLEG22 | 2022-01-13 16:37:52.101 SC Data - All Services | Received security definition for symbol F.US.DA6H22 | 2022-01-13 16:37:52.101 SC Data - All Services | Received security definition for symbol F.US.ENQH22 | 2022-01-13 16:37:52.101 SC Data - All Services | Received security definition for symbol F.US.EPH22 | 2022-01-13 16:37:52.101 SC Data - All Services | Received security definition for symbol F.US.EU6H22 | 2022-01-13 16:37:52.101 SC Data - All Services | Received security definition for symbol F.US.FVAH22 | 2022-01-13 16:37:52.101 SC Data - All Services | Received security definition for symbol F.US.GCEG22 | 2022-01-13 16:37:52.101 HD Request # 33 | Receiving historical Daily data for F.US.YMH22 starting at 2022-01-10 | 2022-01-13 16:37:52.105 HD Request # 33 | Writing historical Daily data to the file F.US.YMH22.dly | 2022-01-13 16:37:52.106 HD Request # 33 | Bytes received: 162 | 2022-01-13 16:37:52.112 HD Request # 33 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for F.US.YMH22 | 2022-01-13 16:37:52.112 HD Request # 33 | Completion time: 1s | 2022-01-13 16:37:52.112 HD Request # 33 | Daily data download complete for F.US.YMH22. Unique request ID: 73 | 2022-01-13 16:37:52.112 Removing historical data download ID 73. | 2022-01-13 16:37:52.112 Triggering next historical data download in queue. | 2022-01-13 16:37:52.112 HD Request # 34 | Downloading Historical Daily chart data for F.US.ENQH22. Starting date: 2022-01-10. Service: cqg | 2022-01-13 16:37:52.118 SC Data - All Services | Received security definition for symbol F.US.HOEG22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.JY6H22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.MX6H22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.NGEG22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.NKDH22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.RBEG22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.RTYH22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.SF6H22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.SIEH22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.TNAH22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.TUAH22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.TYAH22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.USAH22 | 2022-01-13 16:37:52.166 SC Data - All Services | Received security definition for symbol F.US.YMH22 | 2022-01-13 16:37:52.166 HD Request # 34 | Requesting historical Daily data for NQH22 starting at 2022-01-09. SC External HD service. | 2022-01-13 16:37:52.563 HD Request # 28 | Requesting Intraday data. Start date-time: 2021-09-28 06:04:27. Record interval: 0. Symbol: ESZ21 | 2022-01-13 16:37:52.728 HD Request # 34 | Receiving historical Daily data for F.US.ENQH22 starting at 2022-01-10 | 2022-01-13 16:37:52.756 HD Request # 34 | Writing historical Daily data to the file F.US.ENQH22.dly | 2022-01-13 16:37:52.757 HD Request # 34 | Bytes received: 180 | 2022-01-13 16:37:52.764 HD Request # 34 | Received 3 Daily data records from 2022-01-10 00:00:00 to 2022-01-12 00:00:00 (3.0 days) and wrote 3 records for F.US.ENQH22 | 2022-01-13 16:37:52.764 HD Request # 34 | Completion time: 0s | 2022-01-13 16:37:52.764 HD Request # 34 | Daily data download complete for F.US.ENQH22. Unique request ID: 75 | 2022-01-13 16:37:52.764 Removing historical data download ID 75. | 2022-01-13 16:37:52.764 Triggering next historical data download in queue. | 2022-01-13 16:37:52.764 No download requests in the queue to start downloads for. | 2022-01-13 16:37:52.764 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:37:53.023 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:37:53.023 HD Request # 28 | Decompressing data. | 2022-01-13 16:37:54.240 HD Request # 28 | Receiving Intraday data for F.US.EPZ21 starting at 2021-09-28 06:04:27.159000 | 2022-01-13 16:37:54.244 CQG WebAPI | Sending positions subscribe request. RequestID: 816071 | 2022-01-13 16:37:54.332 CQG WebAPI | Sending orders subscribe request. RequestID: 816072 | 2022-01-13 16:37:54.332 Requesting market depth updates for: F.US.BP6H22 if supported. | 2022-01-13 16:37:56.336 SC Data - All Services (Market Orders Data) | Connecting to the server ds6-2.sierracharts.com. Port 10060 | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.CA6H22 if supported. | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.CLEG22 if supported. | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.DA6H22 if supported. | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.ENQH22 if supported. | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.EPH22 if supported. | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.EU6H22 if supported. | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.FVAH22 if supported. | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.GCEG22 if supported. | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.JY6H22 if supported. | 2022-01-13 16:37:56.341 Requesting market depth updates for: F.US.NGEG22 if supported. | 2022-01-13 16:37:56.342 Requesting market depth updates for: F.US.RBEG22 if supported. | 2022-01-13 16:37:56.342 Requesting market depth updates for: F.US.TNAH22 if supported. | 2022-01-13 16:37:56.342 Requesting market depth updates for: F.US.TYAH22 if supported. | 2022-01-13 16:37:56.342 Requesting market depth updates for: F.US.USAH22 if supported. | 2022-01-13 16:37:56.342 Requesting market depth updates for: F.US.YMH22 if supported. | 2022-01-13 16:37:56.342 DTC Client socket (1) | Creating socket. | 2022-01-13 16:37:56.342 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:37:56.342 DTC Client socket (1) | Connecting to IP: 51.195.180.15. | 2022-01-13 16:37:56.342 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:37:56.408 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:37:56.408 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:37:56.408 SC Data - All Services | Clearing market depth for F.US.BP6H22 | 2022-01-13 16:37:56.431 SC Data - All Services | Clearing market depth for F.US.CA6H22 | 2022-01-13 16:37:56.432 SC Data - All Services | Clearing market depth for F.US.CLEG22 | 2022-01-13 16:37:56.432 SC Data - All Services | Clearing market depth for F.US.DA6H22 | 2022-01-13 16:37:56.432 SC Data - All Services | Clearing market depth for F.US.ENQH22 | 2022-01-13 16:37:56.432 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:37:56.506 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:37:56.506 SC Data - All Services | Clearing market depth for F.US.EPH22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.EU6H22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.FVAH22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.GCEG22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.JY6H22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.NGEG22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.RBEG22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.TNAH22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.TYAH22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.USAH22 | 2022-01-13 16:37:56.525 SC Data - All Services | Clearing market depth for F.US.YMH22 | 2022-01-13 16:37:56.525 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.BP6H22 -> 6BH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.CA6H22 -> 6CH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.CLEG22 -> CLG22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.DA6H22 -> 6AH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.ENQH22 -> NQH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.EPH22 -> ESH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.EU6H22 -> 6EH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.FVAH22 -> ZFH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 0. Service code: comex | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.GCEG22 -> GCG22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.JY6H22 -> 6JH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.NGEG22 -> NGG22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.RBEG22 -> RBG22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.TNAH22 -> TNH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.TYAH22 -> ZNH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.USAH22 -> ZBH22 | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:37:57.009 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.YMH22 -> YMH22 | 2022-01-13 16:37:57.009 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:38:00.896 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:38:00.896 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:38:00.896 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:38:00.896 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:38:00.896 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:38:00.896 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:38:00.896 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:38:00.897 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:38:00.897 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:38:01.212 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:38:01.212 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:38:01.212 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:38:01.212 HD Request # 28 | Timestamp of first Intraday data file record written: 2021-09-28 06:04:27.159005 | 2022-01-13 16:39:06.496 DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:39:36.121 DTC Client socket (4) | Closed. | 2022-01-13 16:39:36.122 DTC Client socket (8) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:39:36.122 DTC Client socket (8) | Closed. | 2022-01-13 16:39:36.122 Socket (9) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-13 16:39:43.738 * SC DTC Data with Market Depth | There has been no activity on the network socket for 43s. Will reconnect. | 2022-01-13 16:39:51.515 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:39:51.515 DTC Client socket (10) | CloseSocket call. | 2022-01-13 16:39:51.516 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:39:51.516 DTC Client socket (10) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:39:51.516 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 16:39:51.516 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 443 | 2022-01-13 16:39:53.513 DTC Client socket (5) | Creating socket. | 2022-01-13 16:39:53.514 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:39:53.514 DTC Client socket (5) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:39:53.514 DTC Client socket (4) | Deleting network socket now after delay. | 2022-01-13 16:40:06.126 DTC Client socket (8) | Deleting network socket now after delay. | 2022-01-13 16:40:06.126 Socket (9) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:40:06.126 Socket (9) | Closed. | 2022-01-13 16:40:06.126 File >> Disconnect selected. | 2022-01-13 16:40:08.397 Canceling queued historical data download request for F.US.GCEZ21 Intraday data. | 2022-01-13 16:40:08.397 Removing historical data download ID 56. | 2022-01-13 16:40:08.397 Mapping F.US.GCEZ21 to GCZ21. Service code: comex | 2022-01-13 16:40:08.397 Canceling queued historical data download request for F.US.RBEQ21 Intraday data. | 2022-01-13 16:40:08.397 Removing historical data download ID 58. | 2022-01-13 16:40:08.397 Mapping F.US.RBEQ21 to RBQ21. Service code: nymex | 2022-01-13 16:40:08.397 Canceling queued historical data download request for F.US.RBEU21 Intraday data. | 2022-01-13 16:40:08.397 Removing historical data download ID 59. | 2022-01-13 16:40:08.397 Mapping F.US.RBEU21 to RBU21. Service code: nymex | 2022-01-13 16:40:08.397 Canceling queued historical data download request for F.US.RBEV21 Intraday data. | 2022-01-13 16:40:08.397 Removing historical data download ID 60. | 2022-01-13 16:40:08.397 Mapping F.US.RBEV21 to RBV21. Service code: nymex | 2022-01-13 16:40:08.397 Canceling queued historical data download request for F.US.RBEX21 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 61. | 2022-01-13 16:40:08.398 Mapping F.US.RBEX21 to RBX21. Service code: nymex | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.RBEZ21 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 62. | 2022-01-13 16:40:08.398 Mapping F.US.RBEZ21 to RBZ21. Service code: nymex | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.RBEF22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 63. | 2022-01-13 16:40:08.398 Mapping F.US.RBEF22 to RBF22. Service code: nymex | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.RBEG22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 64. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.CLEU21 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 66. | 2022-01-13 16:40:08.398 Mapping F.US.CLEU21 to CLU21. Service code: nymex | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.CLEV21 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 67. | 2022-01-13 16:40:08.398 Mapping F.US.CLEV21 to CLV21. Service code: nymex | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.CLEF22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 68. | 2022-01-13 16:40:08.398 Mapping F.US.CLEF22 to CLF22. Service code: nymex | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.CLEG22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 69. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.YMZ21 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 71. | 2022-01-13 16:40:08.398 Mapping F.US.YMZ21 to YMZ21. Service code: cbot | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.YMH22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 72. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.ENQZ21 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 74. | 2022-01-13 16:40:08.398 Mapping F.US.ENQZ21 to NQZ21. Service code: cme | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.JY6H22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 76. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.CA6H22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 77. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.ENQH22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 78. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.BP6H22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 79. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.USAH22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 80. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.EU6H22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 81. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.EPH22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 82. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.DA6H22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 83. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.GCEG22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 84. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.TNAH22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 85. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.NGEG22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 86. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.FVAH22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 87. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for F.US.TYAH22 Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 88. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for ADV-NYSE Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 89. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for TRIN-SP Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 90. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for ADR-NASDAQ Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 91. | 2022-01-13 16:40:08.398 Canceling queued historical data download request for TRIN-NYSE Intraday data. | 2022-01-13 16:40:08.398 Removing historical data download ID 92. | 2022-01-13 16:40:08.398 HD Request # 28 | Active download canceled. | 2022-01-13 16:40:08.398 Historical data download thread signaled to stop. | 2022-01-13 16:40:08.398 Socket (2) | CloseSocket call. | 2022-01-13 16:40:08.398 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:08.398 HD Request # 28 | Received 49540 Intraday data records from 2021-09-28 06:04:27.159000 to 2021-09-28 07:51:05.552000 (106.6 minutes) and wrote 49535 records for F.US.EPZ21 | 2022-01-13 16:40:08.399 HD Request # 28 | Completion time: 2m 20s | 2022-01-13 16:40:08.399 HD Request # 28 | Intraday data download complete for F.US.EPZ21. Unique request ID: 54 | 2022-01-13 16:40:08.399 Removing historical data download ID 54. | 2022-01-13 16:40:08.399 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:40:08.399 Triggering next historical data download in queue. | 2022-01-13 16:40:08.399 CQG WebAPI | Sending Web API Logoff message. | 2022-01-13 16:40:08.400 CQG WebSocket socket (6) | CloseSocket call. | 2022-01-13 16:40:08.400 CQG WebSocket socket (6) | Max send buffers used during socket life: 4 | 2022-01-13 16:40:08.400 CQG WebSocket socket (6) | Max send buffer size during socket life: 826 | 2022-01-13 16:40:08.400 CQG WebSocket | WebSocket closed. | 2022-01-13 16:40:08.400 CQG WebAPI | WebSocket closed. | 2022-01-13 16:40:08.400 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 16:40:08.400 CQG WebSocket socket (6) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:40:08.400 DTC Client socket (1) | CloseSocket call. | 2022-01-13 16:40:08.401 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-01-13 16:40:08.401 DTC Client socket (1) | Max send buffer size during socket life: 1242 | 2022-01-13 16:40:08.401 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:40:08.401 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:08.401 WSACleanup called. | 2022-01-13 16:40:08.401 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 16:40:08.401 DTC Client socket (3) | CloseSocket call. | 2022-01-13 16:40:08.401 DTC Client socket (3) | Max send buffers used during socket life: 4 | 2022-01-13 16:40:08.402 DTC Client socket (3) | Max send buffer size during socket life: 1674 | 2022-01-13 16:40:08.402 SC Data - All Services | Disconnected from the server. | 2022-01-13 16:40:08.402 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:08.402 DTC Client socket (5) | CloseSocket call. | 2022-01-13 16:40:08.402 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:40:08.402 CQG WebAPI | Disconnected. | 2022-01-13 16:40:08.402 DTC Client socket (5) | Closed. | 2022-01-13 16:40:08.402 No download requests in the queue to start downloads for. | 2022-01-13 16:40:08.402 CQG WebSocket socket (6) | Write has completed. Shutdown being performed. | 2022-01-13 16:40:08.469 CQG WebSocket socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:08.469 F.US.CLEG22 [CV][M] #11 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:08.491 F.US.CLEG22 [CV][M] #11 | Reloading chart. | 2022-01-13 16:40:08.491 F.US.ENQH22 [CV][M] #9 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:08.664 F.US.ENQH22 [CV][M] #9 | Reloading chart. | 2022-01-13 16:40:08.664 F.US.EPH22 [CV][M] 5 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:08.699 F.US.EPH22 [CV][M] 5 Min #3 | Reloading chart. | 2022-01-13 16:40:08.748 F.US.ENQH22 [CV][M] 5 Min #19 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:08.780 F.US.ENQH22 [CV][M] 5 Min #19 | Reloading chart. | 2022-01-13 16:40:08.792 F.US.RBEG22 [CV][M] #32 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:08.836 F.US.RBEG22 [CV][M] #32 | Reloading chart. | 2022-01-13 16:40:08.841 F.US.CLEG22 [CV][M] 5 Min #18 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:09.021 F.US.CLEG22 [CV][M] 5 Min #18 | Reloading chart. | 2022-01-13 16:40:09.022 F.US.CLEG22 [CV][M] 5 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.CLEG22.scid | 2022-01-13 16:40:09.107 F.US.EPH22 [CV][M] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:09.110 F.US.EPH22 [CV][M] #10 | Reloading chart. | 2022-01-13 16:40:09.110 F.US.EPH22 [CV][M] #8 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:09.126 F.US.EPH22 [CV][M] #8 | Reloading chart. | 2022-01-13 16:40:09.136 F.US.GCEG22 [CV][M] 5 Min #24 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:09.182 F.US.GCEG22 [CV][M] 5 Min #24 | Reloading chart. | 2022-01-13 16:40:09.183 F.US.RBEG22 [CV][M] #32 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.RBEG22.scid | 2022-01-13 16:40:09.306 F.US.YMH22 [CV][M] #31 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:09.502 F.US.YMH22 [CV][M] #31 | Reloading chart. | 2022-01-13 16:40:09.523 F.US.GCEG22 [CV][M] #7 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-01-13 16:40:09.566 F.US.GCEG22 [CV][M] #7 | Reloading chart. | 2022-01-13 16:40:09.573 F.US.YMH22 [CV][M] #31 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.YMH22.scid | 2022-01-13 16:40:09.631 F.US.CLEG22 [CV][M] #11 | Reloading chart. | 2022-01-13 16:40:09.679 F.US.ENQH22 [CV][M] #9 | Reloading chart. | 2022-01-13 16:40:10.176 F.US.EPH22 [CV][M] 5 Min #3 | Reloading chart. | 2022-01-13 16:40:10.317 F.US.ENQH22 [CV][M] 5 Min #19 | Reloading chart. | 2022-01-13 16:40:10.373 F.US.RBEG22 [CV][M] #32 | Reloading chart. | 2022-01-13 16:40:10.433 F.US.CLEG22 [CV][M] 5 Min #18 | Reloading chart. | 2022-01-13 16:40:10.813 F.US.EPH22 [CV][M] #10 | Reloading chart. | 2022-01-13 16:40:10.936 F.US.CLEG22 [CV][M] 5 Min #18 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.CLEG22.scid | 2022-01-13 16:40:11.014 F.US.RBEG22 [CV][M] #32 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.RBEG22.scid | 2022-01-13 16:40:11.017 F.US.EPH22 [CV][M] #8 | Reloading chart. | 2022-01-13 16:40:11.021 F.US.GCEG22 [CV][M] 5 Min #24 | Reloading chart. | 2022-01-13 16:40:11.100 F.US.YMH22 [CV][M] #31 | Reloading chart. | 2022-01-13 16:40:11.190 F.US.YMH22 [CV][M] #31 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.YMH22.scid | 2022-01-13 16:40:11.324 F.US.GCEG22 [CV][M] #7 | Reloading chart. | 2022-01-13 16:40:11.326 CQG WebAPI | Connecting to server api.cqg.com | 2022-01-13 16:40:11.444 CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-01-13 16:40:11.444 CQG WebSocket socket (4) | Creating socket. Using TLS 1.2. | 2022-01-13 16:40:11.445 CQG WebSocket socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:40:11.445 CQG WebSocket socket (4) | Connecting to IP: 195.166.124.165. | 2022-01-13 16:40:11.445 CQG WebSocket | Opening WebSocket. | 2022-01-13 16:40:11.546 CQG WebSocket | Sending WebSocket handshake. | 2022-01-13 16:40:11.546 CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-01-13 16:40:11.765 CQG WebSocket | Server header | Connection: upgrade | 2022-01-13 16:40:11.765 CQG WebSocket | Server header | Sec-WebSocket-Accept: G29FzbiyQFMnjloJquS5lhihZ4M= | 2022-01-13 16:40:11.765 CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-01-13 16:40:11.765 CQG WebSocket | Server header | Upgrade: websocket | 2022-01-13 16:40:11.765 CQG WebSocket | Server header | | 2022-01-13 16:40:11.765 CQG WebSocket | Web socket state is now open. | 2022-01-13 16:40:11.765 CQG WebAPI | WebSocket connected. | 2022-01-13 16:40:11.765 CQG WebAPI | Sending market data logon message. | 2022-01-13 16:40:11.765 CQG WebAPI | Base Time: 2022-01-09T00:38:55. 2022-01-09 00:38:55 | 2022-01-13 16:40:12.419 CQG WebAPI | Logon successful. Session Token = I+vFI276+0+C8GVlO1CFfeEQVqyEQ093+wYcSXue/xkUIM18MXtfEC2nl/8PxJ5/UuFoniZ6WJC | 2022-01-13 16:40:12.419 CQG WebAPI | Connected to server complete. | 2022-01-13 16:40:12.419 Triggering next historical data download in queue. | 2022-01-13 16:40:12.426 Triggering next historical data download in queue. | 2022-01-13 16:40:12.426 Triggering next historical data download in queue. | 2022-01-13 16:40:12.426 Triggering next historical data download in queue. | 2022-01-13 16:40:12.426 Updated verified funded futures trading account ending date to: 2022-02-12 16:40:12 | 2022-01-13 16:40:12.426 CQG WebAPI | Sending Trade Accounts request message. | 2022-01-13 16:40:12.428 No download requests in the queue to start downloads for. | 2022-01-13 16:40:12.428 No download requests in the queue to start downloads for. | 2022-01-13 16:40:12.428 No download requests in the queue to start downloads for. | 2022-01-13 16:40:12.428 No download requests in the queue to start downloads for. | 2022-01-13 16:40:12.428 Mapping F.US.RBEG22 to RBG22. Service code: nymex | 2022-01-13 16:40:12.443 SC Data - All Services | Starting real-time market data updates for: F.US.RBEG22 (RBG22). ID: 1 Service code: nymex | 2022-01-13 16:40:12.443 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-01-13 16:40:12.443 CQG WebAPI | Sending symbol resolution request for F.US.RBEG22. ID: 816074 | 2022-01-13 16:40:12.443 SC Data - All Services | Requesting security definition data for: F.US.RBEG22 (RBG22). ID: 1 | 2022-01-13 16:40:12.443 Added historical Intraday data request for F.US.RBEG22 to the queue. | 2022-01-13 16:40:12.443 Intraday data recording state for symbol F.US.RBEG22 is set to download 'Pending'. | 2022-01-13 16:40:12.443 Triggering next historical data download in queue. | 2022-01-13 16:40:12.443 DTC Client socket (7) | Creating socket. | 2022-01-13 16:40:12.444 DTC Client socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:40:12.444 DTC Client socket (7) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:40:12.444 Delaying start of download for F.US.RBEG22 | 2022-01-13 16:40:12.445 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-NYSE. ID: 2 Service code: statscalc | 2022-01-13 16:40:12.448 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2022-01-13 16:40:12.448 SC DTC Data with Market Depth | Requesting security definition data for: ADV-NYSE. ID: 2 | 2022-01-13 16:40:12.448 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:40:12.448 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:40:12.448 Triggering next historical data download in queue. | 2022-01-13 16:40:12.448 DTC Client socket (8) | Creating socket. | 2022-01-13 16:40:12.449 DTC Client socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:40:12.449 DTC Client socket (8) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:40:12.449 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-SP. ID: 3 Service code: statscalc | 2022-01-13 16:40:12.454 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-SP. ID: 3 | 2022-01-13 16:40:12.454 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:40:12.454 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2022-01-13 16:40:12.454 Triggering next historical data download in queue. | 2022-01-13 16:40:12.454 SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NASDAQ. ID: 4 Service code: statscalc | 2022-01-13 16:40:12.457 SC DTC Data with Market Depth | Requesting security definition data for: ADR-NASDAQ. ID: 4 | 2022-01-13 16:40:12.457 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:40:12.457 Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2022-01-13 16:40:12.457 Triggering next historical data download in queue. | 2022-01-13 16:40:12.457 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 5 Service code: statscalc | 2022-01-13 16:40:12.463 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 5 | 2022-01-13 16:40:12.463 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:40:12.463 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2022-01-13 16:40:12.463 Triggering next historical data download in queue. | 2022-01-13 16:40:12.463 Mapping F.US.JY6H22 to 6JH22. Service code: cme | 2022-01-13 16:40:12.468 SC Data - All Services | Starting real-time market data updates for: F.US.JY6H22 (6JH22). ID: 6 Service code: cme | 2022-01-13 16:40:12.468 CQG WebAPI | Sending symbol resolution request for F.US.JY6H22. ID: 816075 | 2022-01-13 16:40:12.468 SC Data - All Services | Requesting security definition data for: F.US.JY6H22 (6JH22). ID: 6 | 2022-01-13 16:40:12.468 Added historical Intraday data request for F.US.JY6H22 to the queue. | 2022-01-13 16:40:12.469 Intraday data recording state for symbol F.US.JY6H22 is set to download 'Pending'. | 2022-01-13 16:40:12.469 Triggering next historical data download in queue. | 2022-01-13 16:40:12.469 Mapping F.US.EPH22 to ESH22. Service code: cme | 2022-01-13 16:40:12.472 SC Data - All Services | Starting real-time market data updates for: F.US.EPH22 (ESH22). ID: 7 Service code: cme | 2022-01-13 16:40:12.472 CQG WebAPI | Sending symbol resolution request for F.US.EPH22. ID: 816076 | 2022-01-13 16:40:12.472 SC Data - All Services | Requesting security definition data for: F.US.EPH22 (ESH22). ID: 7 | 2022-01-13 16:40:12.472 Added historical Intraday data request for F.US.EPH22 to the queue. | 2022-01-13 16:40:12.472 Intraday data recording state for symbol F.US.EPH22 is set to download 'Pending'. | 2022-01-13 16:40:12.472 Triggering next historical data download in queue. | 2022-01-13 16:40:12.472 Mapping F.US.YMH22 to YMH22. Service code: cbot | 2022-01-13 16:40:12.489 SC Data - All Services | Starting real-time market data updates for: F.US.YMH22 (YMH22). ID: 8 Service code: cbot | 2022-01-13 16:40:12.489 CQG WebAPI | Sending symbol resolution request for F.US.YMH22. ID: 816077 | 2022-01-13 16:40:12.489 SC Data - All Services | Requesting security definition data for: F.US.YMH22 (YMH22). ID: 8 | 2022-01-13 16:40:12.489 Added historical Intraday data request for F.US.YMH22 to the queue. | 2022-01-13 16:40:12.489 Intraday data recording state for symbol F.US.YMH22 is set to download 'Pending'. | 2022-01-13 16:40:12.489 Triggering next historical data download in queue. | 2022-01-13 16:40:12.489 Mapping F.US.DA6H22 to 6AH22. Service code: cme | 2022-01-13 16:40:12.498 SC Data - All Services | Starting real-time market data updates for: F.US.DA6H22 (6AH22). ID: 9 Service code: cme | 2022-01-13 16:40:12.498 CQG WebAPI | Sending symbol resolution request for F.US.DA6H22. ID: 816078 | 2022-01-13 16:40:12.498 SC Data - All Services | Requesting security definition data for: F.US.DA6H22 (6AH22). ID: 9 | 2022-01-13 16:40:12.498 Added historical Intraday data request for F.US.DA6H22 to the queue. | 2022-01-13 16:40:12.498 Intraday data recording state for symbol F.US.DA6H22 is set to download 'Pending'. | 2022-01-13 16:40:12.498 Triggering next historical data download in queue. | 2022-01-13 16:40:12.498 Mapping F.US.ENQH22 to NQH22. Service code: cme | 2022-01-13 16:40:12.501 SC Data - All Services | Starting real-time market data updates for: F.US.ENQH22 (NQH22). ID: 10 Service code: cme | 2022-01-13 16:40:12.501 CQG WebAPI | Sending symbol resolution request for F.US.ENQH22. ID: 816079 | 2022-01-13 16:40:12.501 SC Data - All Services | Requesting security definition data for: F.US.ENQH22 (NQH22). ID: 10 | 2022-01-13 16:40:12.501 Added historical Intraday data request for F.US.ENQH22 to the queue. | 2022-01-13 16:40:12.501 Intraday data recording state for symbol F.US.ENQH22 is set to download 'Pending'. | 2022-01-13 16:40:12.501 Triggering next historical data download in queue. | 2022-01-13 16:40:12.501 CQG WebAPI | Received symbol resolution report for symbol F.US.RBEG22. Search Symbol: F.US.RBEG22. Request ID: 816074. Contract ID: 1. | 2022-01-13 16:40:12.534 CQG WebAPI | Brokerage name: AMP. Account Name: 146043 | 2022-01-13 16:40:12.534 Updated verified funded futures trading account ending date to: 2022-02-12 16:40:12 | 2022-01-13 16:40:12.534 CQG WebAPI | Sending collateral subscribe request. | 2022-01-13 16:40:12.534 CQG WebAPI | Received symbol resolution report for symbol F.US.JY6H22. Search Symbol: F.US.JY6H22. Request ID: 816075. Contract ID: 2. | 2022-01-13 16:40:12.569 Mapping F.US.GCEG22 to GCG22. Service code: comex | 2022-01-13 16:40:12.571 SC Data - All Services | Starting real-time market data updates for: F.US.GCEG22 (GCG22). ID: 11 Service code: comex | 2022-01-13 16:40:12.571 CQG WebAPI | Sending symbol resolution request for F.US.GCEG22. ID: 816081 | 2022-01-13 16:40:12.571 SC Data - All Services | Requesting security definition data for: F.US.GCEG22 (GCG22). ID: 11 | 2022-01-13 16:40:12.571 Added historical Intraday data request for F.US.GCEG22 to the queue. | 2022-01-13 16:40:12.571 Intraday data recording state for symbol F.US.GCEG22 is set to download 'Pending'. | 2022-01-13 16:40:12.571 Triggering next historical data download in queue. | 2022-01-13 16:40:12.571 CQG WebAPI | Received symbol resolution report for symbol F.US.EPH22. Search Symbol: F.US.EPH22. Request ID: 816076. Contract ID: 3. | 2022-01-13 16:40:12.591 CQG WebAPI | Received symbol resolution report for symbol F.US.YMH22. Search Symbol: F.US.YMH22. Request ID: 816077. Contract ID: 4. | 2022-01-13 16:40:12.591 CQG WebAPI | Received symbol resolution report for symbol F.US.DA6H22. Search Symbol: F.US.DA6H22. Request ID: 816078. Contract ID: 5. | 2022-01-13 16:40:12.591 CQG WebAPI | Received symbol resolution report for symbol F.US.ENQH22. Search Symbol: F.US.ENQH22. Request ID: 816079. Contract ID: 6. | 2022-01-13 16:40:12.591 Mapping F.US.CA6H22 to 6CH22. Service code: cme | 2022-01-13 16:40:12.591 SC Data - All Services | Starting real-time market data updates for: F.US.CA6H22 (6CH22). ID: 12 Service code: cme | 2022-01-13 16:40:12.591 CQG WebAPI | Sending symbol resolution request for F.US.CA6H22. ID: 816082 | 2022-01-13 16:40:12.592 SC Data - All Services | Requesting security definition data for: F.US.CA6H22 (6CH22). ID: 12 | 2022-01-13 16:40:12.592 Added historical Intraday data request for F.US.CA6H22 to the queue. | 2022-01-13 16:40:12.592 Intraday data recording state for symbol F.US.CA6H22 is set to download 'Pending'. | 2022-01-13 16:40:12.592 Triggering next historical data download in queue. | 2022-01-13 16:40:12.592 Mapping F.US.TNAH22 to TNH22. Service code: cbot | 2022-01-13 16:40:12.594 SC Data - All Services | Starting real-time market data updates for: F.US.TNAH22 (TNH22). ID: 13 Service code: cbot | 2022-01-13 16:40:12.594 CQG WebAPI | Sending symbol resolution request for F.US.TNAH22. ID: 816083 | 2022-01-13 16:40:12.594 SC Data - All Services | Requesting security definition data for: F.US.TNAH22 (TNH22). ID: 13 | 2022-01-13 16:40:12.594 Added historical Intraday data request for F.US.TNAH22 to the queue. | 2022-01-13 16:40:12.594 Intraday data recording state for symbol F.US.TNAH22 is set to download 'Pending'. | 2022-01-13 16:40:12.594 Triggering next historical data download in queue. | 2022-01-13 16:40:12.594 Mapping F.US.NGEG22 to NGG22. Service code: nymex | 2022-01-13 16:40:12.596 SC Data - All Services | Starting real-time market data updates for: F.US.NGEG22 (NGG22). ID: 14 Service code: nymex | 2022-01-13 16:40:12.596 CQG WebAPI | Sending symbol resolution request for F.US.NGEG22. ID: 816084 | 2022-01-13 16:40:12.596 SC Data - All Services | Requesting security definition data for: F.US.NGEG22 (NGG22). ID: 14 | 2022-01-13 16:40:12.596 Added historical Intraday data request for F.US.NGEG22 to the queue. | 2022-01-13 16:40:12.596 Intraday data recording state for symbol F.US.NGEG22 is set to download 'Pending'. | 2022-01-13 16:40:12.596 Triggering next historical data download in queue. | 2022-01-13 16:40:12.596 Mapping F.US.FVAH22 to ZFH22. Service code: cbot | 2022-01-13 16:40:12.599 SC Data - All Services | Starting real-time market data updates for: F.US.FVAH22 (ZFH22). ID: 15 Service code: cbot | 2022-01-13 16:40:12.599 CQG WebAPI | Sending symbol resolution request for F.US.FVAH22. ID: 816085 | 2022-01-13 16:40:12.599 SC Data - All Services | Requesting security definition data for: F.US.FVAH22 (ZFH22). ID: 15 | 2022-01-13 16:40:12.599 Added historical Intraday data request for F.US.FVAH22 to the queue. | 2022-01-13 16:40:12.599 Intraday data recording state for symbol F.US.FVAH22 is set to download 'Pending'. | 2022-01-13 16:40:12.599 Triggering next historical data download in queue. | 2022-01-13 16:40:12.599 Mapping F.US.TYAH22 to ZNH22. Service code: cbot | 2022-01-13 16:40:12.601 SC Data - All Services | Starting real-time market data updates for: F.US.TYAH22 (ZNH22). ID: 16 Service code: cbot | 2022-01-13 16:40:12.601 CQG WebAPI | Sending symbol resolution request for F.US.TYAH22. ID: 816086 | 2022-01-13 16:40:12.601 SC Data - All Services | Requesting security definition data for: F.US.TYAH22 (ZNH22). ID: 16 | 2022-01-13 16:40:12.601 Added historical Intraday data request for F.US.TYAH22 to the queue. | 2022-01-13 16:40:12.601 Intraday data recording state for symbol F.US.TYAH22 is set to download 'Pending'. | 2022-01-13 16:40:12.601 Triggering next historical data download in queue. | 2022-01-13 16:40:12.601 Mapping F.US.USAH22 to ZBH22. Service code: cbot | 2022-01-13 16:40:12.604 SC Data - All Services | Starting real-time market data updates for: F.US.USAH22 (ZBH22). ID: 17 Service code: cbot | 2022-01-13 16:40:12.604 CQG WebAPI | Sending symbol resolution request for F.US.USAH22. ID: 816087 | 2022-01-13 16:40:12.604 SC Data - All Services | Requesting security definition data for: F.US.USAH22 (ZBH22). ID: 17 | 2022-01-13 16:40:12.604 Added historical Intraday data request for F.US.USAH22 to the queue. | 2022-01-13 16:40:12.604 Intraday data recording state for symbol F.US.USAH22 is set to download 'Pending'. | 2022-01-13 16:40:12.604 Triggering next historical data download in queue. | 2022-01-13 16:40:12.604 Mapping F.US.EU6H22 to 6EH22. Service code: cme | 2022-01-13 16:40:12.605 SC Data - All Services | Starting real-time market data updates for: F.US.EU6H22 (6EH22). ID: 18 Service code: cme | 2022-01-13 16:40:12.605 CQG WebAPI | Sending symbol resolution request for F.US.EU6H22. ID: 816088 | 2022-01-13 16:40:12.605 SC Data - All Services | Requesting security definition data for: F.US.EU6H22 (6EH22). ID: 18 | 2022-01-13 16:40:12.605 Added historical Intraday data request for F.US.EU6H22 to the queue. | 2022-01-13 16:40:12.605 Intraday data recording state for symbol F.US.EU6H22 is set to download 'Pending'. | 2022-01-13 16:40:12.605 Triggering next historical data download in queue. | 2022-01-13 16:40:12.605 Mapping F.US.CLEG22 to CLG22. Service code: nymex | 2022-01-13 16:40:12.607 SC Data - All Services | Starting real-time market data updates for: F.US.CLEG22 (CLG22). ID: 19 Service code: nymex | 2022-01-13 16:40:12.607 CQG WebAPI | Sending symbol resolution request for F.US.CLEG22. ID: 816089 | 2022-01-13 16:40:12.607 SC Data - All Services | Requesting security definition data for: F.US.CLEG22 (CLG22). ID: 19 | 2022-01-13 16:40:12.607 Added historical Intraday data request for F.US.CLEG22 to the queue. | 2022-01-13 16:40:12.607 Intraday data recording state for symbol F.US.CLEG22 is set to download 'Pending'. | 2022-01-13 16:40:12.607 Triggering next historical data download in queue. | 2022-01-13 16:40:12.607 Mapping F.US.BP6H22 to 6BH22. Service code: cme | 2022-01-13 16:40:12.613 SC Data - All Services | Starting real-time market data updates for: F.US.BP6H22 (6BH22). ID: 20 Service code: cme | 2022-01-13 16:40:12.613 CQG WebAPI | Sending symbol resolution request for F.US.BP6H22. ID: 816090 | 2022-01-13 16:40:12.613 SC Data - All Services | Requesting security definition data for: F.US.BP6H22 (6BH22). ID: 20 | 2022-01-13 16:40:12.613 Added historical Intraday data request for F.US.BP6H22 to the queue. | 2022-01-13 16:40:12.613 Intraday data recording state for symbol F.US.BP6H22 is set to download 'Pending'. | 2022-01-13 16:40:12.613 Triggering next historical data download in queue. | 2022-01-13 16:40:12.613 CQG WebAPI | Received symbol resolution report for symbol F.US.GCEG22. Search Symbol: F.US.GCEG22. Request ID: 816081. Contract ID: 7. | 2022-01-13 16:40:12.647 CQG WebAPI | Received symbol resolution report for symbol F.US.CA6H22. Search Symbol: F.US.CA6H22. Request ID: 816082. Contract ID: 8. | 2022-01-13 16:40:12.674 CQG WebAPI | Received symbol resolution report for symbol F.US.TNAH22. Search Symbol: F.US.TNAH22. Request ID: 816083. Contract ID: 9. | 2022-01-13 16:40:12.713 CQG WebAPI | Received symbol resolution report for symbol F.US.NGEG22. Search Symbol: F.US.NGEG22. Request ID: 816084. Contract ID: 10. | 2022-01-13 16:40:12.713 CQG WebAPI | Received symbol resolution report for symbol F.US.FVAH22. Search Symbol: F.US.FVAH22. Request ID: 816085. Contract ID: 11. | 2022-01-13 16:40:12.713 CQG WebAPI | Received symbol resolution report for symbol F.US.TYAH22. Search Symbol: F.US.TYAH22. Request ID: 816086. Contract ID: 12. | 2022-01-13 16:40:12.713 CQG WebAPI | Received symbol resolution report for symbol F.US.USAH22. Search Symbol: F.US.USAH22. Request ID: 816087. Contract ID: 13. | 2022-01-13 16:40:12.713 CQG WebAPI | Received symbol resolution report for symbol F.US.EU6H22. Search Symbol: F.US.EU6H22. Request ID: 816088. Contract ID: 14. | 2022-01-13 16:40:12.713 CQG WebAPI | Received symbol resolution report for symbol F.US.CLEG22. Search Symbol: F.US.CLEG22. Request ID: 816089. Contract ID: 15. | 2022-01-13 16:40:12.713 CQG WebAPI | Received symbol resolution report for symbol F.US.BP6H22. Search Symbol: F.US.BP6H22. Request ID: 816090. Contract ID: 16. | 2022-01-13 16:40:12.713 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:40:12.736 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:40:12.736 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:40:12.736 Mapping F.US.RTYH22 to RTYH22. Service code: cme | 2022-01-13 16:40:12.822 SC Data - All Services | Starting real-time market data updates for: F.US.RTYH22 (RTYH22). ID: 21 Service code: cme | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.RTYH22. ID: 816091 | 2022-01-13 16:40:12.822 SC Data - All Services | Requesting security definition data for: F.US.RTYH22 (RTYH22). ID: 21 | 2022-01-13 16:40:12.822 Mapping F.US.NKDH22 to NKDH22. Service code: cme | 2022-01-13 16:40:12.822 SC Data - All Services | Starting real-time market data updates for: F.US.NKDH22 (NKDH22). ID: 22 Service code: cme | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.NKDH22. ID: 816092 | 2022-01-13 16:40:12.822 SC Data - All Services | Requesting security definition data for: F.US.NKDH22 (NKDH22). ID: 22 | 2022-01-13 16:40:12.822 Mapping F.US.TUAH22 to ZTH22. Service code: cbot | 2022-01-13 16:40:12.822 SC Data - All Services | Starting real-time market data updates for: F.US.TUAH22 (ZTH22). ID: 23 Service code: cbot | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.TUAH22. ID: 816093 | 2022-01-13 16:40:12.822 SC Data - All Services | Requesting security definition data for: F.US.TUAH22 (ZTH22). ID: 23 | 2022-01-13 16:40:12.822 CQG WebAPI | Starting real-time market data updates for: F.US.FBTPH22. ID: 24 Service code: cqg | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.FBTPH22. ID: 816094 | 2022-01-13 16:40:12.822 CQG WebAPI | Requesting security definition data for: F.US.FBTPH22. ID: 24 | 2022-01-13 16:40:12.822 CQG WebAPI | Starting real-time market data updates for: F.US.DBH22. ID: 25 Service code: cqg | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.DBH22. ID: 816095 | 2022-01-13 16:40:12.822 CQG WebAPI | Requesting security definition data for: F.US.DBH22. ID: 25 | 2022-01-13 16:40:12.822 CQG WebAPI | Starting real-time market data updates for: F.US.DLH22. ID: 26 Service code: cqg | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.DLH22. ID: 816096 | 2022-01-13 16:40:12.822 CQG WebAPI | Requesting security definition data for: F.US.DLH22. ID: 26 | 2022-01-13 16:40:12.822 CQG WebAPI | Starting real-time market data updates for: BBH22. ID: 27 | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for BBH22. ID: 816097 | 2022-01-13 16:40:12.822 CQG WebAPI | Requesting security definition data for: BBH22. ID: 27 | 2022-01-13 16:40:12.822 Mapping F.US.HOEG22 to HOG22. Service code: nymex | 2022-01-13 16:40:12.822 SC Data - All Services | Starting real-time market data updates for: F.US.HOEG22 (HOG22). ID: 28 Service code: nymex | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.HOEG22. ID: 816098 | 2022-01-13 16:40:12.822 SC Data - All Services | Requesting security definition data for: F.US.HOEG22 (HOG22). ID: 28 | 2022-01-13 16:40:12.822 Mapping F.US.SIEH22 to SIH22. Service code: comex | 2022-01-13 16:40:12.822 SC Data - All Services | Starting real-time market data updates for: F.US.SIEH22 (SIH22). ID: 29 Service code: comex | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.SIEH22. ID: 816099 | 2022-01-13 16:40:12.822 SC Data - All Services | Requesting security definition data for: F.US.SIEH22 (SIH22). ID: 29 | 2022-01-13 16:40:12.822 Mapping F.US.SF6H22 to 6SH22. Service code: cme | 2022-01-13 16:40:12.822 SC Data - All Services | Starting real-time market data updates for: F.US.SF6H22 (6SH22). ID: 30 Service code: cme | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.SF6H22. ID: 816100 | 2022-01-13 16:40:12.822 SC Data - All Services | Requesting security definition data for: F.US.SF6H22 (6SH22). ID: 30 | 2022-01-13 16:40:12.822 Mapping F.US.MX6H22 to 6MH22. Service code: cme | 2022-01-13 16:40:12.822 SC Data - All Services | Starting real-time market data updates for: F.US.MX6H22 (6MH22). ID: 31 Service code: cme | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.MX6H22. ID: 816101 | 2022-01-13 16:40:12.822 SC Data - All Services | Requesting security definition data for: F.US.MX6H22 (6MH22). ID: 31 | 2022-01-13 16:40:12.822 Mapping F.US.BTCF22 to BTCF22. Service code: cme | 2022-01-13 16:40:12.822 SC Data - All Services | Starting real-time market data updates for: F.US.BTCF22 (BTCF22). ID: 32 Service code: cme | 2022-01-13 16:40:12.822 CQG WebAPI | Sending symbol resolution request for F.US.BTCF22. ID: 816102 | 2022-01-13 16:40:12.822 SC Data - All Services | Requesting security definition data for: F.US.BTCF22 (BTCF22). ID: 32 | 2022-01-13 16:40:12.822 CQG WebAPI | Received symbol resolution report for symbol F.US.RTYH22. Search Symbol: F.US.RTYH22. Request ID: 816091. Contract ID: 17. | 2022-01-13 16:40:12.893 CQG WebAPI | Received symbol resolution report for symbol F.US.NKDH22. Search Symbol: F.US.NKDH22. Request ID: 816092. Contract ID: 18. | 2022-01-13 16:40:12.893 CQG WebAPI | Received symbol resolution report for symbol F.US.TUAH22. Search Symbol: F.US.TUAH22. Request ID: 816093. Contract ID: 19. | 2022-01-13 16:40:12.893 CQG WebAPI | Received symbol resolution report for symbol F.US.FBTPH22. Search Symbol: F.US.FBTPH22. Request ID: 816094. Contract ID: 20. | 2022-01-13 16:40:12.962 CQG WebAPI | Requesting market data for F.US.FBTPH22 | 2022-01-13 16:40:12.962 CQG WebAPI | Received symbol resolution report for symbol F.US.DBH22. Search Symbol: F.US.DBH22. Request ID: 816095. Contract ID: 21. | 2022-01-13 16:40:12.962 CQG WebAPI | Requesting market data for F.US.DBH22 | 2022-01-13 16:40:12.962 CQG WebAPI | Received symbol resolution report for symbol F.US.DLH22. Search Symbol: F.US.DLH22. Request ID: 816096. Contract ID: 22. | 2022-01-13 16:40:12.962 CQG WebAPI | Requesting market data for F.US.DLH22 | 2022-01-13 16:40:12.962 CQG WebAPI | Received symbol resolution report for symbol F.CN.BBH22. Search Symbol: BBH22. Request ID: 816097. Contract ID: 23. | 2022-01-13 16:40:12.962 Symbol Error - BBH22 is unknown, unavailable, or improperly formatted. Exact match not found for symbol BBH22 | 2022-01-13 16:40:12.962 CQG WebAPI | Received symbol resolution report for symbol F.US.HOEG22. Search Symbol: F.US.HOEG22. Request ID: 816098. Contract ID: 24. | 2022-01-13 16:40:12.962 CQG WebAPI | Received symbol resolution report for symbol F.US.SIEH22. Search Symbol: F.US.SIEH22. Request ID: 816099. Contract ID: 25. | 2022-01-13 16:40:12.962 CQG WebAPI | Received symbol resolution report for symbol F.US.SF6H22. Search Symbol: F.US.SF6H22. Request ID: 816100. Contract ID: 26. | 2022-01-13 16:40:12.962 CQG WebAPI | Received symbol resolution report for symbol F.US.MX6H22. Search Symbol: F.US.MX6H22. Request ID: 816101. Contract ID: 27. | 2022-01-13 16:40:12.962 CQG WebAPI | Received symbol resolution report for symbol F.US.BTCF22. Search Symbol: F.US.BTCF22. Request ID: 816102. Contract ID: 28. | 2022-01-13 16:40:12.962 CQG WebAPI | Market data subscription for F.US.FBTPH22 was unsuccessful. Text: Real-time data subscription for instrument F.US.FBTP (corresponding to ID = 20) is not enabled. | 2022-01-13 16:40:13.032 Symbol Error - F.US.FBTPH22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.FBTP (corresponding to ID = 20) is not enabled. | 2022-01-13 16:40:13.032 CQG WebAPI | Market data subscription for F.US.DBH22 was unsuccessful. Text: Real-time data subscription for instrument F.US.DB (corresponding to ID = 21) is not enabled. | 2022-01-13 16:40:13.032 Symbol Error - F.US.DBH22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.DB (corresponding to ID = 21) is not enabled. | 2022-01-13 16:40:13.032 CQG WebAPI | Market data subscription for F.US.DLH22 was unsuccessful. Text: Real-time data subscription for instrument F.US.DL (corresponding to ID = 22) is not enabled. | 2022-01-13 16:40:13.032 Symbol Error - F.US.DLH22 is unknown, unavailable, or improperly formatted. Real-time data subscription for instrument F.US.DL (corresponding to ID = 22) is not enabled. | 2022-01-13 16:40:13.032 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:13.049 SC Data - All Services | Sending logon request message. | 2022-01-13 16:40:13.049 SC Data - All Services | Received logon response. | 2022-01-13 16:40:14.048 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:40:14.048 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:40:14.048 SC Data - All Services | Successfully connected. | 2022-01-13 16:40:14.048 SC Data - All Services | Trading is not supported. | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.BP6H22 -> 6BH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.BTCF22 -> BTCF22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.CA6H22 -> 6CH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.CLEG22 -> CLG22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.DA6H22 -> 6AH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.ENQH22 -> NQH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPH22 -> ESH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6H22 -> 6EH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.FVAH22 -> ZFH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.GCEG22 -> GCG22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.HOEG22 -> HOG22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.JY6H22 -> 6JH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.MX6H22 -> 6MH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.NGEG22 -> NGG22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.NKDH22 -> NKDH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.RBEG22 -> RBG22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.RTYH22 -> RTYH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.SF6H22 -> 6SH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.SIEH22 -> SIH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.TNAH22 -> TNH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.TUAH22 -> ZTH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAH22 -> ZNH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.USAH22 -> ZBH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Restarting real-time data updates for symbol: F.US.YMH22 -> YMH22 | 2022-01-13 16:40:14.048 SC Data - All Services | Received security definition for symbol F.US.BP6H22 | 2022-01-13 16:40:14.444 SC Data - All Services | Received security definition for symbol F.US.BTCF22 | 2022-01-13 16:40:14.444 SC Data - All Services | Received security definition for symbol F.US.CA6H22 | 2022-01-13 16:40:14.444 SC Data - All Services | Received security definition for symbol F.US.CLEG22 | 2022-01-13 16:40:14.444 SC Data - All Services | Received security definition for symbol F.US.DA6H22 | 2022-01-13 16:40:14.444 SC Data - All Services | Received security definition for symbol F.US.ENQH22 | 2022-01-13 16:40:14.444 SC Data - All Services | Received security definition for symbol F.US.EPH22 | 2022-01-13 16:40:14.444 SC Data - All Services | Received security definition for symbol F.US.EU6H22 | 2022-01-13 16:40:14.444 SC Data - All Services | Received security definition for symbol F.US.FVAH22 | 2022-01-13 16:40:14.444 SC Data - All Services | Received security definition for symbol F.US.GCEG22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.HOEG22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.JY6H22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.MX6H22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.NGEG22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.NKDH22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.RBEG22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.RTYH22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.SF6H22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.SIEH22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.TNAH22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.TUAH22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.TYAH22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.USAH22 | 2022-01-13 16:40:14.445 SC Data - All Services | Received security definition for symbol F.US.YMH22 | 2022-01-13 16:40:14.445 CQG WebAPI | Sending positions subscribe request. RequestID: 816103 | 2022-01-13 16:40:15.419 CQG WebAPI | Sending orders subscribe request. RequestID: 816104 | 2022-01-13 16:40:15.419 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:40:15.774 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:40:15.774 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:40:15.774 F.US.CLEG22 [CV][M] #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.CLEG22.scid | 2022-01-13 16:40:15.774 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:16.076 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:40:16.076 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:40:17.303 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:40:17.303 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:40:17.303 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:40:17.303 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:40:17.303 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:40:17.303 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:40:17.303 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:40:17.303 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:40:17.303 Requesting market depth updates for: F.US.BP6H22 if supported. | 2022-01-13 16:40:17.415 SC Data - All Services (Market Orders Data) | Connecting to the server ds23.sierracharts.com. Port 10060 | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.CA6H22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.CLEG22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.DA6H22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.ENQH22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.EPH22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.EU6H22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.FVAH22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.GCEG22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.JY6H22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.NGEG22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.RBEG22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.TNAH22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.TYAH22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.USAH22 if supported. | 2022-01-13 16:40:17.421 Requesting market depth updates for: F.US.YMH22 if supported. | 2022-01-13 16:40:17.421 DTC Client socket (5) | Creating socket. | 2022-01-13 16:40:17.422 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:40:17.422 DTC Client socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:40:17.422 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:40:17.644 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:40:17.644 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:40:17.644 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:40:17.644 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:40:17.719 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:40:17.719 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:40:17.719 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:18.029 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:40:18.029 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.BP6H22 -> 6BH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.CA6H22 -> 6CH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.CLEG22 -> CLG22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.DA6H22 -> 6AH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.ENQH22 -> NQH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.EPH22 -> ESH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.EU6H22 -> 6EH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.FVAH22 -> ZFH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 0. Service code: comex | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.GCEG22 -> GCG22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 0. Service code: cme | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.JY6H22 -> 6JH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.NGEG22 -> NGG22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.RBEG22 -> RBG22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.TNAH22 -> TNH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.TYAH22 -> ZNH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.USAH22 -> ZBH22 | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2022-01-13 16:40:19.037 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: F.US.YMH22 -> YMH22 | 2022-01-13 16:40:19.037 HD Request # 35 | Downloading Intraday chart data for F.US.RBEG22 to the file F.US.RBEG22.scid. Service: nymex | 2022-01-13 16:40:19.453 HD Request # 35 | Download start date-time: 2021-07-11 16:40:19.000000. File last date-time: 00:00:00.000000 | 2022-01-13 16:40:19.453 HD Request # 35 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:40:19.454 Socket (11) | Creating socket. | 2022-01-13 16:40:19.454 Socket (11) | New receive buffer size: 5242880 | 2022-01-13 16:40:19.454 Socket (11) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:40:19.454 HD Request # 35 | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:23.399 HD Request # 35 | Sending historical data logon request message. | 2022-01-13 16:40:23.399 HD Request # 35 | Requesting Intraday data. Start date-time: 2021-07-11 16:40:19. Record interval: 0. Symbol: RBG22 | 2022-01-13 16:40:24.155 Canceling queued historical data download request for ADV-NYSE Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 94. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for TRIN-SP Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 95. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for ADR-NASDAQ Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 96. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for TRIN-NYSE Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 97. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.JY6H22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 98. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.EPH22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 99. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.YMH22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 100. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.DA6H22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 101. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.ENQH22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 102. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.GCEG22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 103. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.CA6H22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 104. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.TNAH22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 105. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.NGEG22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 106. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.FVAH22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 107. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.TYAH22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 108. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.USAH22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 109. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.EU6H22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 110. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.CLEG22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 111. | 2022-01-13 16:40:24.877 Canceling queued historical data download request for F.US.BP6H22 Intraday data. | 2022-01-13 16:40:24.877 Removing historical data download ID 112. | 2022-01-13 16:40:24.877 HD Request # 35 | Active download canceled. | 2022-01-13 16:40:24.877 Historical data download thread signaled to stop. | 2022-01-13 16:40:24.877 Socket (11) | CloseSocket call. | 2022-01-13 16:40:24.877 HD Request # 35 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.RBEG22 | 2022-01-13 16:40:24.877 Socket (11) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:40:24.877 HD Request # 35 | Completion time: 5s | 2022-01-13 16:40:24.877 HD Request # 35 | Intraday data download complete for F.US.RBEG22. Unique request ID: 93 | 2022-01-13 16:40:24.877 Removing historical data download ID 93. | 2022-01-13 16:40:24.877 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:40:24.877 Triggering next historical data download in queue. | 2022-01-13 16:40:24.877 CQG WebAPI | Sending Web API Logoff message. | 2022-01-13 16:40:24.880 CQG WebSocket socket (4) | CloseSocket call. | 2022-01-13 16:40:24.880 CQG WebSocket socket (4) | Max send buffers used during socket life: 3 | 2022-01-13 16:40:24.880 CQG WebSocket socket (4) | Max send buffer size during socket life: 404 | 2022-01-13 16:40:24.880 CQG WebSocket | WebSocket closed. | 2022-01-13 16:40:24.880 CQG WebAPI | WebSocket closed. | 2022-01-13 16:40:24.880 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 16:40:24.880 CQG WebSocket socket (4) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:40:24.880 DTC Client socket (5) | CloseSocket call. | 2022-01-13 16:40:24.880 DTC Client socket (5) | Max send buffers used during socket life: 4 | 2022-01-13 16:40:24.880 DTC Client socket (5) | Max send buffer size during socket life: 1242 | 2022-01-13 16:40:24.880 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:40:24.880 WSACleanup called. | 2022-01-13 16:40:24.880 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:24.881 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 16:40:24.881 DTC Client socket (7) | CloseSocket call. | 2022-01-13 16:40:24.882 DTC Client socket (7) | Max send buffers used during socket life: 4 | 2022-01-13 16:40:24.882 DTC Client socket (7) | Max send buffer size during socket life: 1674 | 2022-01-13 16:40:24.882 SC Data - All Services | Disconnected from the server. | 2022-01-13 16:40:24.882 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:40:24.882 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:24.882 DTC Client socket (8) | CloseSocket call. | 2022-01-13 16:40:24.882 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:40:24.882 CQG WebAPI | Disconnected. | 2022-01-13 16:40:24.882 DTC Client socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:24.882 CQG WebSocket socket (0) | CloseSocket call. | 2022-01-13 16:40:24.916 CQG WebSocket socket (0) | CloseSocket call. | 2022-01-13 16:40:24.916 CQG WebSocket socket (0) | CloseSocket call. | 2022-01-13 16:40:24.916 Checking for new symbol settings. Requested symbol settings MD5 for service code tradesimulation.dtctrading. Request ID: 4. | 2022-01-13 16:40:24.919 Current selected Data/Trading service: Trading Evaluator | 2022-01-13 16:40:24.919 CQG WebSocket socket (4) | Write has completed. Shutdown being performed. | 2022-01-13 16:40:24.948 CQG WebSocket socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:24.948 No download requests in the queue to start downloads for. | 2022-01-13 16:40:24.985 Socket (11) | Write has completed. Shutdown being performed. | 2022-01-13 16:40:25.118 Socket (11) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:25.118 Symbol settings MD5 received. Request ID: 4. | 2022-01-13 16:40:26.372 Requested symbol settings for service code tradesimulation.dtctrading. Request ID: 5. | 2022-01-13 16:40:26.372 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-01-13 16:40:26.692 CLG22 [CV][M] #11 | Reloading chart. | 2022-01-13 16:40:26.702 NQH22 [CV][M] #9 | Reloading chart. | 2022-01-13 16:40:26.917 RBG22 [CV][M] #32 | Reloading chart. | 2022-01-13 16:40:27.000 6JH22[M] #21 | Reloading chart. | 2022-01-13 16:40:27.193 6JH22[M] #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.194 ESH22 [CV][M] #10 | Reloading chart. | 2022-01-13 16:40:27.198 YMH22 [CV][M] #31 | Reloading chart. | 2022-01-13 16:40:27.286 ESH22[M] #12 | Reloading chart. | 2022-01-13 16:40:27.369 ESH22[M] #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.370 6AH22[M] #22 | Reloading chart. | 2022-01-13 16:40:27.374 6AH22[M] #22 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.374 NQH22[M] #4 | Reloading chart. | 2022-01-13 16:40:27.378 NQH22[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.379 RBG22[M] #23 | Reloading chart. | 2022-01-13 16:40:27.384 RBG22[M] #23 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.385 GCG22[M] #5 | Reloading chart. | 2022-01-13 16:40:27.388 GCG22[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.388 6CH22[M] #20 | Reloading chart. | 2022-01-13 16:40:27.394 6CH22[M] #20 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.394 TNH22[M] #6 | Reloading chart. | 2022-01-13 16:40:27.401 TNH22[M] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.402 NGG22[M] #26 | Reloading chart. | 2022-01-13 16:40:27.403 NGG22[M] #26 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.404 ZFH22[M] #30 | Reloading chart. | 2022-01-13 16:40:27.408 ZFH22[M] #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.408 ZNH22[M] #27 | Reloading chart. | 2022-01-13 16:40:27.411 ZNH22[M] #27 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.411 YMH22[M] #29 | Reloading chart. | 2022-01-13 16:40:27.413 YMH22[M] #29 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.413 ZBH22[M] #28 | Reloading chart. | 2022-01-13 16:40:27.418 ZBH22[M] #28 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.418 6EH22[M] #16 | Reloading chart. | 2022-01-13 16:40:27.420 6EH22[M] #16 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.420 CLG22[M] #1 | Reloading chart. | 2022-01-13 16:40:27.426 CLG22[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.426 6BH22[M] #17 | Reloading chart. | 2022-01-13 16:40:27.431 6BH22[M] #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:27.431 ESH22 [CV][M] #8 | Reloading chart. | 2022-01-13 16:40:27.439 CLG22 [CV][M] 5 Min #18 | Reloading chart. | 2022-01-13 16:40:27.535 GCG22 [CV][M] #7 | Reloading chart. | 2022-01-13 16:40:27.636 ESH22 [CV][M] 5 Min #3 | Reloading chart. | 2022-01-13 16:40:27.755 GCG22 [CV][M] 5 Min #24 | Reloading chart. | 2022-01-13 16:40:27.808 NQH22 [CV][M] 5 Min #19 | Reloading chart. | 2022-01-13 16:40:27.912 Mapping CLG22 to CLG22. Service code: nymex | 2022-01-13 16:40:27.967 Added historical Intraday data request for CLG22 to the queue. | 2022-01-13 16:40:27.967 Intraday data recording state for symbol CLG22 is set to download 'Pending'. | 2022-01-13 16:40:27.967 Triggering next historical data download in queue. | 2022-01-13 16:40:27.967 HD Request # 36 | Downloading Intraday chart data for CLG22 to the file CLG22.scid. Service: nymex | 2022-01-13 16:40:27.967 HD Request # 36 | Download start date-time: 2022-01-13 16:35:20.000000. File last date-time: 2022-01-13 16:35:20.347000 | 2022-01-13 16:40:27.968 HD Request # 36 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:40:27.968 Socket (12) | Creating socket. | 2022-01-13 16:40:27.968 Socket (12) | New receive buffer size: 5242880 | 2022-01-13 16:40:27.968 Socket (12) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:40:27.968 Mapping ESH22 to ESH22. Service code: cme | 2022-01-13 16:40:27.975 Mapping NQH22 to NQH22. Service code: cme | 2022-01-13 16:40:27.975 Mapping RTYH22 to RTYH22. Service code: cme | 2022-01-13 16:40:27.975 Mapping YMH22 to YMH22. Service code: cbot | 2022-01-13 16:40:27.975 Mapping NKDH22 to NKDH22. Service code: cme | 2022-01-13 16:40:27.976 Mapping ZBH22 to ZBH22. Service code: cbot | 2022-01-13 16:40:27.976 Mapping ZNH22 to ZNH22. Service code: cbot | 2022-01-13 16:40:27.976 Mapping ZTH22 to ZTH22. Service code: cbot | 2022-01-13 16:40:27.976 Mapping HOG22 to HOG22. Service code: nymex | 2022-01-13 16:40:27.976 Mapping RBG22 to RBG22. Service code: nymex | 2022-01-13 16:40:27.976 Mapping NGG22 to NGG22. Service code: nymex | 2022-01-13 16:40:27.976 Mapping GCG22 to GCG22. Service code: comex | 2022-01-13 16:40:27.976 Mapping SIH22 to SIH22. Service code: comex | 2022-01-13 16:40:27.976 Mapping 6EH22 to 6EH22. Service code: cme | 2022-01-13 16:40:27.976 Mapping 6BH22 to 6BH22. Service code: cme | 2022-01-13 16:40:27.976 Mapping 6JH22 to 6JH22. Service code: cme | 2022-01-13 16:40:27.976 Mapping 6CH22 to 6CH22. Service code: cme | 2022-01-13 16:40:27.976 Mapping 6AH22 to 6AH22. Service code: cme | 2022-01-13 16:40:27.976 Mapping 6SH22 to 6SH22. Service code: cme | 2022-01-13 16:40:27.976 Mapping 6MH22 to 6MH22. Service code: cme | 2022-01-13 16:40:27.976 Mapping BTCF22 to BTCF22. Service code: cme | 2022-01-13 16:40:27.976 Added historical Intraday data request for NQH22 to the queue. | 2022-01-13 16:40:28.068 Intraday data recording state for symbol NQH22 is set to download 'Pending'. | 2022-01-13 16:40:28.068 Triggering next historical data download in queue. | 2022-01-13 16:40:28.068 Added historical Intraday data request for RBG22 to the queue. | 2022-01-13 16:40:28.076 Intraday data recording state for symbol RBG22 is set to download 'Pending'. | 2022-01-13 16:40:28.076 Triggering next historical data download in queue. | 2022-01-13 16:40:28.076 Added historical Intraday data request for 6JH22 to the queue. | 2022-01-13 16:40:28.080 Intraday data recording state for symbol 6JH22 is set to download 'Pending'. | 2022-01-13 16:40:28.080 Triggering next historical data download in queue. | 2022-01-13 16:40:28.080 Added historical Intraday data request for ESH22 to the queue. | 2022-01-13 16:40:28.110 Intraday data recording state for symbol ESH22 is set to download 'Pending'. | 2022-01-13 16:40:28.110 Triggering next historical data download in queue. | 2022-01-13 16:40:28.110 Added historical Intraday data request for YMH22 to the queue. | 2022-01-13 16:40:28.119 Intraday data recording state for symbol YMH22 is set to download 'Pending'. | 2022-01-13 16:40:28.119 Triggering next historical data download in queue. | 2022-01-13 16:40:28.119 Added historical Intraday data request for 6AH22 to the queue. | 2022-01-13 16:40:28.126 Intraday data recording state for symbol 6AH22 is set to download 'Pending'. | 2022-01-13 16:40:28.126 Triggering next historical data download in queue. | 2022-01-13 16:40:28.126 Symbol settings received. Request ID: 5. | 2022-01-13 16:40:28.135 Added historical Intraday data request for 6CH22 to the queue. | 2022-01-13 16:40:28.289 Intraday data recording state for symbol 6CH22 is set to download 'Pending'. | 2022-01-13 16:40:28.289 Triggering next historical data download in queue. | 2022-01-13 16:40:28.289 Added historical Intraday data request for GCG22 to the queue. | 2022-01-13 16:40:28.293 Intraday data recording state for symbol GCG22 is set to download 'Pending'. | 2022-01-13 16:40:28.293 Triggering next historical data download in queue. | 2022-01-13 16:40:28.293 Added historical Intraday data request for ZNH22 to the queue. | 2022-01-13 16:40:28.304 Intraday data recording state for symbol ZNH22 is set to download 'Pending'. | 2022-01-13 16:40:28.304 Triggering next historical data download in queue. | 2022-01-13 16:40:28.304 Mapping ZFH22 to ZFH22. Service code: cbot | 2022-01-13 16:40:28.305 Added historical Intraday data request for ZFH22 to the queue. | 2022-01-13 16:40:28.305 Intraday data recording state for symbol ZFH22 is set to download 'Pending'. | 2022-01-13 16:40:28.305 Triggering next historical data download in queue. | 2022-01-13 16:40:28.305 Added historical Intraday data request for NGG22 to the queue. | 2022-01-13 16:40:28.307 Intraday data recording state for symbol NGG22 is set to download 'Pending'. | 2022-01-13 16:40:28.307 Triggering next historical data download in queue. | 2022-01-13 16:40:28.307 Mapping TNH22 to TNH22. Service code: cbot | 2022-01-13 16:40:28.309 Added historical Intraday data request for TNH22 to the queue. | 2022-01-13 16:40:28.309 Intraday data recording state for symbol TNH22 is set to download 'Pending'. | 2022-01-13 16:40:28.309 Triggering next historical data download in queue. | 2022-01-13 16:40:28.309 Added historical Intraday data request for 6EH22 to the queue. | 2022-01-13 16:40:28.314 Intraday data recording state for symbol 6EH22 is set to download 'Pending'. | 2022-01-13 16:40:28.314 Triggering next historical data download in queue. | 2022-01-13 16:40:28.314 Added historical Intraday data request for ZBH22 to the queue. | 2022-01-13 16:40:28.316 Intraday data recording state for symbol ZBH22 is set to download 'Pending'. | 2022-01-13 16:40:28.316 Triggering next historical data download in queue. | 2022-01-13 16:40:28.316 Added historical Intraday data request for 6BH22 to the queue. | 2022-01-13 16:40:28.317 Intraday data recording state for symbol 6BH22 is set to download 'Pending'. | 2022-01-13 16:40:28.317 Triggering next historical data download in queue. | 2022-01-13 16:40:28.317 DTC Client socket (10) | Write has completed. Shutdown being performed. | 2022-01-13 16:40:28.461 DTC Client socket (10) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:28.461 DTC Client socket (10) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-13 16:40:28.461 * DTC Client socket (10) | Socket gracefully closed by remote side. | 2022-01-13 16:40:28.461 DTC Client socket (10) | Closed. | 2022-01-13 16:40:28.461 Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2022-01-13 16:40:28.941 DTC Client socket (10) | Creating socket. Using TLS 1.2. | 2022-01-13 16:40:28.941 DTC Client socket (10) | New receive buffer size: 5242880 | 2022-01-13 16:40:28.941 DTC Client socket (10) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:40:28.941 Trading Evaluator | Network connection to server complete. | 2022-01-13 16:40:29.492 Trading Evaluator | Starting socket receive thread. | 2022-01-13 16:40:29.492 Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2022-01-13 16:40:29.492 Trading Evaluator | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:30.397 Trading Evaluator | Sending logon request message. | 2022-01-13 16:40:30.397 Trading Evaluator | Received logon response. | 2022-01-13 16:40:31.157 Trading Evaluator | Server Name: SC DTC Server. Build=40463. | 2022-01-13 16:40:31.157 Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:40:31.157 Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2022-01-13 16:40:31.157 Trading Evaluator | Trading is supported. | 2022-01-13 16:40:31.157 Trading Evaluator | Order cancel and replace is supported. | 2022-01-13 16:40:31.157 Trading Evaluator | OCO Orders supported. | 2022-01-13 16:40:31.157 Trading Evaluator | Bracket Orders supported. | 2022-01-13 16:40:31.157 Trading Evaluator | Connected to server complete. | 2022-01-13 16:40:31.157 Triggering next historical data download in queue. | 2022-01-13 16:40:31.157 Triggering next historical data download in queue. | 2022-01-13 16:40:31.157 Triggering next historical data download in queue. | 2022-01-13 16:40:31.157 Triggering next historical data download in queue. | 2022-01-13 16:40:31.157 No download requests in the queue to start downloads for. | 2022-01-13 16:40:31.192 No download requests in the queue to start downloads for. | 2022-01-13 16:40:31.192 No download requests in the queue to start downloads for. | 2022-01-13 16:40:31.192 Mapping YMH22 to YMH22. Service code: cbot | 2022-01-13 16:40:31.192 SC Data - All Services | Starting real-time market data updates for: YMH22 (YMH22). ID: 1 Service code: cbot | 2022-01-13 16:40:31.192 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-01-13 16:40:31.192 SC Data - All Services | Requesting security definition data for: YMH22 (YMH22). ID: 1 | 2022-01-13 16:40:31.192 DTC Client socket (13) | Creating socket. | 2022-01-13 16:40:31.193 DTC Client socket (13) | New receive buffer size: 5242880 | 2022-01-13 16:40:31.193 DTC Client socket (13) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:40:31.193 Mapping ZNH22 to ZNH22. Service code: cbot | 2022-01-13 16:40:31.197 SC Data - All Services | Starting real-time market data updates for: ZNH22 (ZNH22). ID: 2 Service code: cbot | 2022-01-13 16:40:31.197 SC Data - All Services | Requesting security definition data for: ZNH22 (ZNH22). ID: 2 | 2022-01-13 16:40:31.197 Mapping ZFH22 to ZFH22. Service code: cbot | 2022-01-13 16:40:31.372 SC Data - All Services | Starting real-time market data updates for: ZFH22 (ZFH22). ID: 3 Service code: cbot | 2022-01-13 16:40:31.372 SC Data - All Services | Requesting security definition data for: ZFH22 (ZFH22). ID: 3 | 2022-01-13 16:40:31.372 Mapping NGG22 to NGG22. Service code: nymex | 2022-01-13 16:40:31.374 SC Data - All Services | Starting real-time market data updates for: NGG22 (NGG22). ID: 4 Service code: nymex | 2022-01-13 16:40:31.374 SC Data - All Services | Requesting security definition data for: NGG22 (NGG22). ID: 4 | 2022-01-13 16:40:31.374 Mapping TNH22 to TNH22. Service code: cbot | 2022-01-13 16:40:31.376 SC Data - All Services | Starting real-time market data updates for: TNH22 (TNH22). ID: 5 Service code: cbot | 2022-01-13 16:40:31.376 SC Data - All Services | Requesting security definition data for: TNH22 (TNH22). ID: 5 | 2022-01-13 16:40:31.376 Mapping NQH22 to NQH22. Service code: cme | 2022-01-13 16:40:31.379 SC Data - All Services | Starting real-time market data updates for: NQH22 (NQH22). ID: 6 Service code: cme | 2022-01-13 16:40:31.379 SC Data - All Services | Requesting security definition data for: NQH22 (NQH22). ID: 6 | 2022-01-13 16:40:31.379 Mapping CLG22 to CLG22. Service code: nymex | 2022-01-13 16:40:31.380 SC Data - All Services | Starting real-time market data updates for: CLG22 (CLG22). ID: 7 Service code: nymex | 2022-01-13 16:40:31.380 SC Data - All Services | Requesting security definition data for: CLG22 (CLG22). ID: 7 | 2022-01-13 16:40:31.380 Mapping 6EH22 to 6EH22. Service code: cme | 2022-01-13 16:40:31.382 SC Data - All Services | Starting real-time market data updates for: 6EH22 (6EH22). ID: 8 Service code: cme | 2022-01-13 16:40:31.382 SC Data - All Services | Requesting security definition data for: 6EH22 (6EH22). ID: 8 | 2022-01-13 16:40:31.382 Mapping ZBH22 to ZBH22. Service code: cbot | 2022-01-13 16:40:31.386 SC Data - All Services | Starting real-time market data updates for: ZBH22 (ZBH22). ID: 9 Service code: cbot | 2022-01-13 16:40:31.386 SC Data - All Services | Requesting security definition data for: ZBH22 (ZBH22). ID: 9 | 2022-01-13 16:40:31.386 Mapping ESH22 to ESH22. Service code: cme | 2022-01-13 16:40:31.387 SC Data - All Services | Starting real-time market data updates for: ESH22 (ESH22). ID: 10 Service code: cme | 2022-01-13 16:40:31.387 SC Data - All Services | Requesting security definition data for: ESH22 (ESH22). ID: 10 | 2022-01-13 16:40:31.387 Mapping 6BH22 to 6BH22. Service code: cme | 2022-01-13 16:40:31.387 SC Data - All Services | Starting real-time market data updates for: 6BH22 (6BH22). ID: 11 Service code: cme | 2022-01-13 16:40:31.387 SC Data - All Services | Requesting security definition data for: 6BH22 (6BH22). ID: 11 | 2022-01-13 16:40:31.387 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-NYSE. ID: 12 Service code: statscalc | 2022-01-13 16:40:31.390 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2022-01-13 16:40:31.390 SC DTC Data with Market Depth | Requesting security definition data for: ADV-NYSE. ID: 12 | 2022-01-13 16:40:31.390 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:40:31.390 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:40:31.390 Triggering next historical data download in queue. | 2022-01-13 16:40:31.390 DTC Client socket (14) | Creating socket. | 2022-01-13 16:40:31.390 DTC Client socket (14) | New receive buffer size: 5242880 | 2022-01-13 16:40:31.390 DTC Client socket (14) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:40:31.390 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-SP. ID: 13 Service code: statscalc | 2022-01-13 16:40:31.396 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-SP. ID: 13 | 2022-01-13 16:40:31.396 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:40:31.396 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2022-01-13 16:40:31.396 Triggering next historical data download in queue. | 2022-01-13 16:40:31.396 Mapping 6JH22 to 6JH22. Service code: cme | 2022-01-13 16:40:31.399 SC Data - All Services | Starting real-time market data updates for: 6JH22 (6JH22). ID: 14 Service code: cme | 2022-01-13 16:40:31.399 SC Data - All Services | Requesting security definition data for: 6JH22 (6JH22). ID: 14 | 2022-01-13 16:40:31.399 SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NASDAQ. ID: 15 Service code: statscalc | 2022-01-13 16:40:31.402 SC DTC Data with Market Depth | Requesting security definition data for: ADR-NASDAQ. ID: 15 | 2022-01-13 16:40:31.402 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:40:31.402 Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2022-01-13 16:40:31.402 Triggering next historical data download in queue. | 2022-01-13 16:40:31.402 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 16 Service code: statscalc | 2022-01-13 16:40:31.408 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 16 | 2022-01-13 16:40:31.408 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:40:31.408 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2022-01-13 16:40:31.408 Triggering next historical data download in queue. | 2022-01-13 16:40:31.408 Mapping RBG22 to RBG22. Service code: nymex | 2022-01-13 16:40:31.414 SC Data - All Services | Starting real-time market data updates for: RBG22 (RBG22). ID: 17 Service code: nymex | 2022-01-13 16:40:31.414 SC Data - All Services | Requesting security definition data for: RBG22 (RBG22). ID: 17 | 2022-01-13 16:40:31.414 Mapping GCG22 to GCG22. Service code: comex | 2022-01-13 16:40:31.458 SC Data - All Services | Starting real-time market data updates for: GCG22 (GCG22). ID: 18 Service code: comex | 2022-01-13 16:40:31.458 SC Data - All Services | Requesting security definition data for: GCG22 (GCG22). ID: 18 | 2022-01-13 16:40:31.458 Mapping 6AH22 to 6AH22. Service code: cme | 2022-01-13 16:40:31.470 SC Data - All Services | Starting real-time market data updates for: 6AH22 (6AH22). ID: 19 Service code: cme | 2022-01-13 16:40:31.470 SC Data - All Services | Requesting security definition data for: 6AH22 (6AH22). ID: 19 | 2022-01-13 16:40:31.470 Mapping 6CH22 to 6CH22. Service code: cme | 2022-01-13 16:40:31.475 SC Data - All Services | Starting real-time market data updates for: 6CH22 (6CH22). ID: 20 Service code: cme | 2022-01-13 16:40:31.475 SC Data - All Services | Requesting security definition data for: 6CH22 (6CH22). ID: 20 | 2022-01-13 16:40:31.475 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:40:31.501 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:40:31.501 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:40:31.501 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH22 | 2022-01-13 16:40:31.502 Trading Evaluator | Received security definition for symbol YMH22 | 2022-01-13 16:40:31.502 YMH22[M] #29 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.512 ZNH22[M] #27 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.515 ZFH22[M] #30 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.517 NGG22[M] #26 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.519 TNH22[M] #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.523 CLG22[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.525 6EH22[M] #16 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.529 ZBH22[M] #28 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.532 6BH22[M] #17 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.535 6JH22[M] #21 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.546 Mapping RTYH22 to RTYH22. Service code: cme | 2022-01-13 16:40:31.608 SC Data - All Services | Starting real-time market data updates for: RTYH22 (RTYH22). ID: 21 Service code: cme | 2022-01-13 16:40:31.608 SC Data - All Services | Requesting security definition data for: RTYH22 (RTYH22). ID: 21 | 2022-01-13 16:40:31.608 Mapping NKDH22 to NKDH22. Service code: cme | 2022-01-13 16:40:31.608 SC Data - All Services | Starting real-time market data updates for: NKDH22 (NKDH22). ID: 22 Service code: cme | 2022-01-13 16:40:31.608 SC Data - All Services | Requesting security definition data for: NKDH22 (NKDH22). ID: 22 | 2022-01-13 16:40:31.608 Mapping ZTH22 to ZTH22. Service code: cbot | 2022-01-13 16:40:31.608 SC Data - All Services | Starting real-time market data updates for: ZTH22 (ZTH22). ID: 23 Service code: cbot | 2022-01-13 16:40:31.608 SC Data - All Services | Requesting security definition data for: ZTH22 (ZTH22). ID: 23 | 2022-01-13 16:40:31.608 Trading Evaluator | Starting real-time market data updates for: FBTPH22. ID: 24 Service code: eurex | 2022-01-13 16:40:31.608 Trading Evaluator | Requesting security definition data for: FBTPH22. ID: 24 | 2022-01-13 16:40:31.608 Trading Evaluator | Starting real-time market data updates for: FGBLH22. ID: 25 Service code: eurex | 2022-01-13 16:40:31.608 Trading Evaluator | Requesting security definition data for: FGBLH22. ID: 25 | 2022-01-13 16:40:31.608 Trading Evaluator | Starting real-time market data updates for: FGBMH22. ID: 26 Service code: eurex | 2022-01-13 16:40:31.608 Trading Evaluator | Requesting security definition data for: FGBMH22. ID: 26 | 2022-01-13 16:40:31.608 Mapping BBH22 to BBH22. Service code: nymex | 2022-01-13 16:40:31.608 SC Data - All Services | Starting real-time market data updates for: BBH22 (BBH22). ID: 27 Service code: nymex | 2022-01-13 16:40:31.608 SC Data - All Services | Requesting security definition data for: BBH22 (BBH22). ID: 27 | 2022-01-13 16:40:31.608 Mapping HOG22 to HOG22. Service code: nymex | 2022-01-13 16:40:31.609 SC Data - All Services | Starting real-time market data updates for: HOG22 (HOG22). ID: 28 Service code: nymex | 2022-01-13 16:40:31.609 SC Data - All Services | Requesting security definition data for: HOG22 (HOG22). ID: 28 | 2022-01-13 16:40:31.609 Mapping SIH22 to SIH22. Service code: comex | 2022-01-13 16:40:31.609 SC Data - All Services | Starting real-time market data updates for: SIH22 (SIH22). ID: 29 Service code: comex | 2022-01-13 16:40:31.609 SC Data - All Services | Requesting security definition data for: SIH22 (SIH22). ID: 29 | 2022-01-13 16:40:31.609 Mapping 6SH22 to 6SH22. Service code: cme | 2022-01-13 16:40:31.609 SC Data - All Services | Starting real-time market data updates for: 6SH22 (6SH22). ID: 30 Service code: cme | 2022-01-13 16:40:31.609 SC Data - All Services | Requesting security definition data for: 6SH22 (6SH22). ID: 30 | 2022-01-13 16:40:31.609 Mapping 6MH22 to 6MH22. Service code: cme | 2022-01-13 16:40:31.609 SC Data - All Services | Starting real-time market data updates for: 6MH22 (6MH22). ID: 31 Service code: cme | 2022-01-13 16:40:31.609 SC Data - All Services | Requesting security definition data for: 6MH22 (6MH22). ID: 31 | 2022-01-13 16:40:31.609 Mapping BTCF22 to BTCF22. Service code: cme | 2022-01-13 16:40:31.609 SC Data - All Services | Starting real-time market data updates for: BTCF22 (BTCF22). ID: 32 Service code: cme | 2022-01-13 16:40:31.609 SC Data - All Services | Requesting security definition data for: BTCF22 (BTCF22). ID: 32 | 2022-01-13 16:40:31.609 NQH22[M] #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.656 6AH22[M] #22 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.659 ESH22[M] #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.663 6CH22[M] #20 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.666 GCG22[M] #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.669 RBG22[M] #23 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-01-13 16:40:31.672 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:31.819 SC Data - All Services | Sending logon request message. | 2022-01-13 16:40:31.819 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNH22 | 2022-01-13 16:40:32.351 Trading Evaluator | Received security definition for symbol ZNH22 | 2022-01-13 16:40:32.351 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZFH22 | 2022-01-13 16:40:32.351 Trading Evaluator | Received security definition for symbol ZFH22 | 2022-01-13 16:40:32.351 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NGG22 | 2022-01-13 16:40:32.351 Trading Evaluator | Received security definition for symbol NGG22 | 2022-01-13 16:40:32.351 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: TNH22 | 2022-01-13 16:40:32.351 Trading Evaluator | Received security definition for symbol TNH22 | 2022-01-13 16:40:32.351 SC Data - All Services | Received logon response. | 2022-01-13 16:40:34.469 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:40:34.469 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:40:34.469 SC Data - All Services | Successfully connected. | 2022-01-13 16:40:34.469 SC Data - All Services | Trading is not supported. | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: 6MH22 -> 6MH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: 6SH22 -> 6SH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: BBH22 -> BBH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: BTCF22 -> BTCF22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: CLG22 -> CLG22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: GCG22 -> GCG22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: HOG22 -> HOG22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: NGG22 -> NGG22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: NKDH22 -> NKDH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: NQH22 -> NQH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: RBG22 -> RBG22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: RTYH22 -> RTYH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: SIH22 -> SIH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: TNH22 -> TNH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: YMH22 -> YMH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:40:34.469 SC Data - All Services | Restarting real-time data updates for symbol: ZTH22 -> ZTH22 | 2022-01-13 16:40:34.469 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol NQH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol CLG22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol 6EH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol ZBH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol ESH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol 6BH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6JH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol 6JH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RBG22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol RBG22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol GCG22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6AH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol 6AH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6CH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol 6CH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol RTYH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NKDH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol NKDH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZTH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol ZTH22 | 2022-01-13 16:40:34.470 Symbol Error - FBTPH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol FBTPH22 | 2022-01-13 16:40:34.470 Symbol Error - FGBLH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol FGBLH22 | 2022-01-13 16:40:34.470 Symbol Error - FGBMH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol FGBMH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol BBH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: HOG22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol HOG22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: SIH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol SIH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6SH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol 6SH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6MH22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol 6MH22 | 2022-01-13 16:40:34.470 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BTCF22 | 2022-01-13 16:40:34.470 Trading Evaluator | Received security definition for symbol BTCF22 | 2022-01-13 16:40:34.470 Socket (9) | Deleting network socket now after delay. | 2022-01-13 16:40:36.141 Requesting market depth updates for: 6AH22 if supported. | 2022-01-13 16:40:36.157 SC Data - All Services (Market Orders Data) | Connecting to the server ds21.sierracharts.com. Port 10060 | 2022-01-13 16:40:36.159 Requesting market depth updates for: 6BH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: 6CH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: 6EH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: 6JH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: CLG22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: ESH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: GCG22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: NGG22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: NQH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: RBG22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: TNH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: YMH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: ZBH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: ZFH22 if supported. | 2022-01-13 16:40:36.159 Requesting market depth updates for: ZNH22 if supported. | 2022-01-13 16:40:36.159 DTC Client socket (9) | Creating socket. | 2022-01-13 16:40:36.159 DTC Client socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:40:36.159 DTC Client socket (9) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:40:36.159 SC Data - All Services | Received security definition for symbol 6AH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol 6BH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol 6CH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol 6EH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol 6JH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol 6MH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol 6SH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol BBH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol BTCF22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol CLG22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol ESH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol GCG22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol HOG22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol NGG22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol NKDH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol NQH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol RBG22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol RTYH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol SIH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol TNH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol YMH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol ZBH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol ZFH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol ZNH22 | 2022-01-13 16:40:36.457 SC Data - All Services | Received security definition for symbol ZTH22 | 2022-01-13 16:40:36.457 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:40:36.460 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:40:36.460 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:40:36.460 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:36.772 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:40:36.772 HD Request # 36 | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:37.593 HD Request # 36 | Sending historical data logon request message. | 2022-01-13 16:40:37.593 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:40:37.916 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:40:37.916 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:40:37.916 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:40:37.916 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:40:37.916 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 25. Service code: nymex | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLG22 -> CLG22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 15. Service code: comex | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: GCG22 -> GCG22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGG22 -> NGG22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 15. Service code: cme | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NQH22 -> NQH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: RBG22 -> RBG22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: TNH22 -> TNH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 20. Service code: cbot | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: YMH22 -> YMH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 200. Service code: cbot | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 1500. Service code: cbot | 2022-01-13 16:40:37.917 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:40:37.917 HD Request # 36 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:20. Record interval: 0. Symbol: CLG22 | 2022-01-13 16:40:38.351 HD Request # 36 | Decompressing data. | 2022-01-13 16:40:38.647 HD Request # 36 | Receiving Intraday data for CLG22 starting at 2022-01-13 16:35:20.170000 | 2022-01-13 16:40:38.949 Socket (12) | CloseSocket call. | 2022-01-13 16:40:38.951 Socket (12) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:38.951 Historical data download thread signaled to stop. | 2022-01-13 16:40:38.951 HD Request # 36 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:22.797000 | 2022-01-13 16:40:38.951 HD Request # 36 | Received 1457 Intraday data records from 2022-01-13 16:35:20.170000 to 2022-01-13 16:40:31.593000 (5.2 minutes) and wrote 1447 records for CLG22 | 2022-01-13 16:40:38.952 HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:40:31.593000 | 2022-01-13 16:40:38.955 HD Request # 36 | Completion time: 11s | 2022-01-13 16:40:38.955 HD Request # 36 | Intraday data download complete for CLG22. Unique request ID: 113 | 2022-01-13 16:40:38.955 Removing historical data download ID 113. | 2022-01-13 16:40:38.955 Real-time Intraday chart data file updates started for CLG22 | 2022-01-13 16:40:38.955 Intraday chart data file opened for CLG22 | 2022-01-13 16:40:38.955 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:40:38.955 Triggering next historical data download in queue. | 2022-01-13 16:40:38.955 Initiating new historical data download for CLG22 to get the latest data since the download was started while not connected to primary service. | 2022-01-13 16:40:38.955 Added historical Intraday data request for CLG22 to the queue. | 2022-01-13 16:40:38.955 Intraday data recording state for symbol CLG22 is set to download 'Pending'. | 2022-01-13 16:40:38.956 Delaying start of download for CLG22 | 2022-01-13 16:40:38.956 Socket (12) | Socket gracefully closed by remote side. | 2022-01-13 16:40:39.244 Socket (12) | Closed. | 2022-01-13 16:40:39.244 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:40:40.703 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:40:40.703 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:40:40.703 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:41.048 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:40:41.048 HD Request # 37 | Downloading Intraday chart data for CLG22 to the file CLG22.scid. Service: nymex | 2022-01-13 16:40:41.431 HD Request # 37 | Download start date-time: 2022-01-13 16:40:31.000000. File last date-time: 2022-01-13 16:40:31.593000 | 2022-01-13 16:40:41.431 HD Request # 37 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:40:41.431 Socket (12) | Creating socket. | 2022-01-13 16:40:41.431 Socket (12) | New receive buffer size: 5242880 | 2022-01-13 16:40:41.431 Socket (12) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:40:41.431 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:40:44.084 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:40:44.084 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:40:44.084 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:40:44.084 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:40:44.084 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:40:44.084 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:40:44.084 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:40:44.084 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:40:44.084 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:40:44.426 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:40:44.426 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:40:44.426 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:40:44.426 HD Request # 37 | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:45.051 HD Request # 37 | Sending historical data logon request message. | 2022-01-13 16:40:45.051 HD Request # 37 | Requesting Intraday data. Start date-time: 2022-01-13 16:40:31. Record interval: 0. Symbol: CLG22 | 2022-01-13 16:40:45.348 HD Request # 37 | Decompressing data. | 2022-01-13 16:40:45.642 HD Request # 37 | Receiving Intraday data for CLG22 starting at 2022-01-13 16:40:31.405000 | 2022-01-13 16:40:45.643 Socket (12) | CloseSocket call. | 2022-01-13 16:40:45.644 Socket (12) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:40:45.644 Historical data download thread signaled to stop. | 2022-01-13 16:40:45.644 HD Request # 37 | Timestamp of first Intraday data file record written: 2022-01-13 16:40:34.306000 | 2022-01-13 16:40:45.645 HD Request # 37 | Received 92 Intraday data records from 2022-01-13 16:40:31.405000 to 2022-01-13 16:40:39.416002 (8.0 seconds) and wrote 71 records for CLG22 | 2022-01-13 16:40:45.645 HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:40:39.416002 | 2022-01-13 16:40:45.653 HD Request # 37 | Completion time: 4s | 2022-01-13 16:40:45.653 HD Request # 37 | Intraday data download complete for CLG22. Unique request ID: 133 | 2022-01-13 16:40:45.653 Removing historical data download ID 133. | 2022-01-13 16:40:45.653 Real-time Intraday chart data file updates started for CLG22 | 2022-01-13 16:40:45.653 Intraday chart data file opened for CLG22 | 2022-01-13 16:40:45.653 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:40:45.653 Triggering next historical data download in queue. | 2022-01-13 16:40:45.653 HD Request # 38 | Downloading Intraday chart data for NQH22 to the file NQH22.scid. Service: cme | 2022-01-13 16:40:45.653 HD Request # 38 | Download start date-time: 2022-01-13 16:26:41.000000. File last date-time: 2022-01-13 16:26:41.600000 | 2022-01-13 16:40:45.653 HD Request # 38 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:40:45.653 Socket (15) | Creating socket. | 2022-01-13 16:40:45.653 Socket (15) | New receive buffer size: 5242880 | 2022-01-13 16:40:45.653 Socket (15) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:40:45.653 Socket (12) | Socket gracefully closed by remote side. | 2022-01-13 16:40:46.681 Socket (12) | Closed. | 2022-01-13 16:40:46.681 HD Request # 38 | Setting DTC encoding to Binary VLS | 2022-01-13 16:40:47.196 HD Request # 38 | Sending historical data logon request message. | 2022-01-13 16:40:47.196 HD Request # 38 | Requesting Intraday data. Start date-time: 2022-01-13 16:26:41. Record interval: 0. Symbol: NQH22 | 2022-01-13 16:40:47.494 HD Request # 38 | Decompressing data. | 2022-01-13 16:40:47.794 SC Data - All Services | Clearing market depth for 6AH22 | 2022-01-13 16:40:52.171 SC Data - All Services | Clearing market depth for 6BH22 | 2022-01-13 16:40:52.171 SC Data - All Services | Clearing market depth for 6CH22 | 2022-01-13 16:40:52.171 SC Data - All Services | Clearing market depth for 6EH22 | 2022-01-13 16:40:52.171 SC Data - All Services | Clearing market depth for 6JH22 | 2022-01-13 16:40:52.171 SC Data - All Services | Clearing market depth for CLG22 | 2022-01-13 16:40:52.171 SC Data - All Services | Clearing market depth for ESH22 | 2022-01-13 16:40:52.171 SC Data - All Services | Clearing market depth for GCG22 | 2022-01-13 16:40:52.172 SC Data - All Services | Clearing market depth for NGG22 | 2022-01-13 16:40:52.172 SC Data - All Services | Clearing market depth for NQH22 | 2022-01-13 16:40:52.172 SC Data - All Services | Clearing market depth for RBG22 | 2022-01-13 16:40:52.172 SC Data - All Services | Clearing market depth for TNH22 | 2022-01-13 16:40:52.172 SC Data - All Services | Clearing market depth for YMH22 | 2022-01-13 16:40:52.172 SC Data - All Services | Clearing market depth for ZBH22 | 2022-01-13 16:40:52.172 SC Data - All Services | Clearing market depth for ZFH22 | 2022-01-13 16:40:52.172 SC Data - All Services | Clearing market depth for ZNH22 | 2022-01-13 16:40:52.172 HD Request # 38 | Receiving Intraday data for NQH22 starting at 2022-01-13 16:26:41.030000 | 2022-01-13 16:40:53.515 Opened cached Intraday file: C:\SierraChart\Data\CLG22.scid. Thread ID: 11608 | 2022-01-13 16:40:55.793 Socket (15) | CloseSocket call. | 2022-01-13 16:41:32.741 Socket (15) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:41:32.741 Historical data download thread signaled to stop. | 2022-01-13 16:41:32.743 HD Request # 38 | Timestamp of first Intraday data file record written: 2022-01-13 16:26:41.943000 | 2022-01-13 16:41:32.743 HD Request # 38 | Received 14814 Intraday data records from 2022-01-13 16:26:41.030000 to 2022-01-13 16:40:45.445000 (14.1 minutes) and wrote 14809 records for NQH22 | 2022-01-13 16:41:32.744 HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:40:45.445000 | 2022-01-13 16:41:32.752 Added 22 Time and Sales records to Intraday data file for NQH22 after download. | 2022-01-13 16:41:32.752 HD Request # 38 | Completion time: 47s | 2022-01-13 16:41:32.752 HD Request # 38 | Intraday data download complete for NQH22. Unique request ID: 114 | 2022-01-13 16:41:32.752 Removing historical data download ID 114. | 2022-01-13 16:41:32.752 Real-time Intraday chart data file updates started for NQH22 | 2022-01-13 16:41:32.752 Intraday chart data file opened for NQH22 | 2022-01-13 16:41:32.752 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:41:32.752 Triggering next historical data download in queue. | 2022-01-13 16:41:32.752 HD Request # 39 | Downloading Intraday chart data for RBG22 to the file RBG22.scid. Service: nymex | 2022-01-13 16:41:32.752 HD Request # 39 | Download start date-time: 2022-01-13 16:35:20.000000. File last date-time: 2022-01-13 16:35:20.167001 | 2022-01-13 16:41:32.753 HD Request # 39 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:41:32.753 Socket (12) | Creating socket. | 2022-01-13 16:41:32.753 Socket (12) | New receive buffer size: 5242880 | 2022-01-13 16:41:32.753 Socket (12) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:41:32.753 Socket (15) | Socket gracefully closed by remote side. | 2022-01-13 16:41:33.046 Socket (15) | Closed. | 2022-01-13 16:41:33.046 HD Request # 39 | Setting DTC encoding to Binary VLS | 2022-01-13 16:41:33.360 HD Request # 39 | Sending historical data logon request message. | 2022-01-13 16:41:33.360 HD Request # 39 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:20. Record interval: 0. Symbol: RBG22 | 2022-01-13 16:41:34.894 Opened cached Intraday file: C:\SierraChart\Data\NQH22.scid. Thread ID: 11608 | 2022-01-13 16:41:36.094 HD Request # 39 | Decompressing data. | 2022-01-13 16:41:37.454 HD Request # 39 | Receiving Intraday data for RBG22 starting at 2022-01-13 16:35:20.117000 | 2022-01-13 16:41:37.455 Socket (12) | CloseSocket call. | 2022-01-13 16:41:44.562 Socket (12) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:41:44.562 Historical data download thread signaled to stop. | 2022-01-13 16:41:44.563 HD Request # 39 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:34.147000 | 2022-01-13 16:41:44.563 HD Request # 39 | Received 307 Intraday data records from 2022-01-13 16:35:20.117000 to 2022-01-13 16:41:26.186001 (6.1 minutes) and wrote 303 records for RBG22 | 2022-01-13 16:41:44.563 HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:41:26.186001 | 2022-01-13 16:41:44.572 HD Request # 39 | Completion time: 12s | 2022-01-13 16:41:44.572 HD Request # 39 | Intraday data download complete for RBG22. Unique request ID: 115 | 2022-01-13 16:41:44.572 Removing historical data download ID 115. | 2022-01-13 16:41:44.572 Real-time Intraday chart data file updates started for RBG22 | 2022-01-13 16:41:44.572 Intraday chart data file opened for RBG22 | 2022-01-13 16:41:44.572 HD Request # 39 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:41:44.572 Triggering next historical data download in queue. | 2022-01-13 16:41:44.572 HD Request # 40 | Downloading Intraday chart data for 6JH22 to the file 6JH22.scid. Service: cme | 2022-01-13 16:41:44.572 HD Request # 40 | Download start date-time: 2022-01-13 16:25:46.000000. File last date-time: 2022-01-13 16:25:46.499000 | 2022-01-13 16:41:44.573 HD Request # 40 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:41:44.573 Socket (15) | Creating socket. | 2022-01-13 16:41:44.573 Socket (15) | New receive buffer size: 5242880 | 2022-01-13 16:41:44.573 Socket (15) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:41:44.573 Socket (12) | Socket gracefully closed by remote side. | 2022-01-13 16:41:44.852 Socket (12) | Closed. | 2022-01-13 16:41:44.852 HD Request # 40 | Setting DTC encoding to Binary VLS | 2022-01-13 16:41:47.867 HD Request # 40 | Sending historical data logon request message. | 2022-01-13 16:41:47.867 HD Request # 40 | Requesting Intraday data. Start date-time: 2022-01-13 16:25:46. Record interval: 0. Symbol: 6JH22 | 2022-01-13 16:41:48.634 HD Request # 40 | Decompressing data. | 2022-01-13 16:41:48.948 HD Request # 40 | Receiving Intraday data for 6JH22 starting at 2022-01-13 16:25:46.445000 | 2022-01-13 16:41:48.949 Socket (15) | CloseSocket call. | 2022-01-13 16:41:49.251 Socket (15) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:41:49.251 Historical data download thread signaled to stop. | 2022-01-13 16:41:49.252 HD Request # 40 | Timestamp of first Intraday data file record written: 2022-01-13 16:26:07.684000 | 2022-01-13 16:41:49.252 HD Request # 40 | Received 501 Intraday data records from 2022-01-13 16:25:46.445000 to 2022-01-13 16:41:45.334000 (16.0 minutes) and wrote 495 records for 6JH22 | 2022-01-13 16:41:49.253 HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:41:45.334000 | 2022-01-13 16:41:49.263 HD Request # 40 | Completion time: 5s | 2022-01-13 16:41:49.264 HD Request # 40 | Intraday data download complete for 6JH22. Unique request ID: 116 | 2022-01-13 16:41:49.264 Removing historical data download ID 116. | 2022-01-13 16:41:49.264 Real-time Intraday chart data file updates started for 6JH22 | 2022-01-13 16:41:49.264 Intraday chart data file opened for 6JH22 | 2022-01-13 16:41:49.264 HD Request # 40 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:41:49.264 Triggering next historical data download in queue. | 2022-01-13 16:41:49.264 HD Request # 41 | Downloading Intraday chart data for ESH22 to the file ESH22.scid. Service: cme | 2022-01-13 16:41:49.264 HD Request # 41 | Download start date-time: 2022-01-13 16:35:20.000000. File last date-time: 2022-01-13 16:35:20.809002 | 2022-01-13 16:41:49.264 HD Request # 41 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:41:49.265 Socket (12) | Creating socket. | 2022-01-13 16:41:49.265 Socket (12) | New receive buffer size: 5242880 | 2022-01-13 16:41:49.265 Socket (12) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:41:49.265 Socket (15) | Socket gracefully closed by remote side. | 2022-01-13 16:41:49.550 Socket (15) | Closed. | 2022-01-13 16:41:49.550 HD Request # 41 | Setting DTC encoding to Binary VLS | 2022-01-13 16:41:49.866 HD Request # 41 | Sending historical data logon request message. | 2022-01-13 16:41:49.866 HD Request # 41 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:20. Record interval: 0. Symbol: ESH22 | 2022-01-13 16:41:50.941 HD Request # 41 | Decompressing data. | 2022-01-13 16:41:51.246 HD Request # 41 | Receiving Intraday data for ESH22 starting at 2022-01-13 16:35:20.364000 | 2022-01-13 16:41:52.847 Socket (12) | CloseSocket call. | 2022-01-13 16:42:06.179 Socket (12) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:42:06.179 Historical data download thread signaled to stop. | 2022-01-13 16:42:06.179 HD Request # 41 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:21.325000 | 2022-01-13 16:42:06.180 HD Request # 41 | Received 10180 Intraday data records from 2022-01-13 16:35:20.364000 to 2022-01-13 16:41:47.202010 (6.4 minutes) and wrote 10149 records for ESH22 | 2022-01-13 16:42:06.180 HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:41:47.202010 | 2022-01-13 16:42:06.190 HD Request # 41 | Completion time: 17s | 2022-01-13 16:42:06.190 HD Request # 41 | Intraday data download complete for ESH22. Unique request ID: 117 | 2022-01-13 16:42:06.190 Removing historical data download ID 117. | 2022-01-13 16:42:06.190 Real-time Intraday chart data file updates started for ESH22 | 2022-01-13 16:42:06.190 Intraday chart data file opened for ESH22 | 2022-01-13 16:42:06.190 HD Request # 41 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:42:06.190 Triggering next historical data download in queue. | 2022-01-13 16:42:06.190 HD Request # 42 | Downloading Intraday chart data for YMH22 to the file YMH22.scid. Service: cbot | 2022-01-13 16:42:06.190 HD Request # 42 | Download start date-time: 2022-01-13 16:27:44.000000. File last date-time: 2022-01-13 16:27:44.979000 | 2022-01-13 16:42:06.191 HD Request # 42 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:42:06.191 Socket (15) | Creating socket. | 2022-01-13 16:42:06.191 Socket (15) | New receive buffer size: 5242880 | 2022-01-13 16:42:06.192 Socket (15) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:42:06.192 HD Request # 42 | Setting DTC encoding to Binary VLS | 2022-01-13 16:42:06.786 HD Request # 42 | Sending historical data logon request message. | 2022-01-13 16:42:06.786 HD Request # 42 | Requesting Intraday data. Start date-time: 2022-01-13 16:27:44. Record interval: 0. Symbol: YMH22 | 2022-01-13 16:42:07.109 Socket (12) | Socket gracefully closed by remote side. | 2022-01-13 16:42:07.127 Socket (12) | Closed. | 2022-01-13 16:42:07.127 HD Request # 42 | Decompressing data. | 2022-01-13 16:42:08.115 HD Request # 42 | Receiving Intraday data for YMH22 starting at 2022-01-13 16:27:44.024000 | 2022-01-13 16:42:08.115 Socket (15) | CloseSocket call. | 2022-01-13 16:42:15.457 Socket (15) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:42:15.457 Historical data download thread signaled to stop. | 2022-01-13 16:42:15.458 HD Request # 42 | Timestamp of first Intraday data file record written: 2022-01-13 16:27:44.999000 | 2022-01-13 16:42:15.458 HD Request # 42 | Received 4197 Intraday data records from 2022-01-13 16:27:44.024000 to 2022-01-13 16:42:02.955001 (14.3 minutes) and wrote 4174 records for YMH22 | 2022-01-13 16:42:15.458 HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:42:02.955001 | 2022-01-13 16:42:15.462 HD Request # 42 | Completion time: 9s | 2022-01-13 16:42:15.462 HD Request # 42 | Intraday data download complete for YMH22. Unique request ID: 118 | 2022-01-13 16:42:15.462 Removing historical data download ID 118. | 2022-01-13 16:42:15.462 Real-time Intraday chart data file updates started for YMH22 | 2022-01-13 16:42:15.462 Intraday chart data file opened for YMH22 | 2022-01-13 16:42:15.462 HD Request # 42 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:42:15.462 Triggering next historical data download in queue. | 2022-01-13 16:42:15.462 HD Request # 43 | Downloading Intraday chart data for 6AH22 to the file 6AH22.scid. Service: cme | 2022-01-13 16:42:15.462 HD Request # 43 | Download start date-time: 2022-01-13 16:35:20.000000. File last date-time: 2022-01-13 16:35:20.994000 | 2022-01-13 16:42:15.463 HD Request # 43 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:42:15.463 Socket (12) | Creating socket. | 2022-01-13 16:42:15.463 Socket (12) | New receive buffer size: 5242880 | 2022-01-13 16:42:15.463 Socket (12) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:42:15.463 HD Request # 43 | Setting DTC encoding to Binary VLS | 2022-01-13 16:42:18.987 HD Request # 43 | Sending historical data logon request message. | 2022-01-13 16:42:18.987 HD Request # 43 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:20. Record interval: 0. Symbol: 6AH22 | 2022-01-13 16:42:19.748 HD Request # 43 | Decompressing data. | 2022-01-13 16:42:20.877 HD Request # 43 | Receiving Intraday data for 6AH22 starting at 2022-01-13 16:35:20.994000 | 2022-01-13 16:42:20.877 Socket (12) | CloseSocket call. | 2022-01-13 16:42:22.056 Socket (12) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:42:22.056 Historical data download thread signaled to stop. | 2022-01-13 16:42:22.059 HD Request # 43 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:21.487000 | 2022-01-13 16:42:22.059 HD Request # 43 | Received 207 Intraday data records from 2022-01-13 16:35:20.994000 to 2022-01-13 16:42:13.998001 (6.9 minutes) and wrote 206 records for 6AH22 | 2022-01-13 16:42:22.059 HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:42:13.998001 | 2022-01-13 16:42:22.063 HD Request # 43 | Completion time: 7s | 2022-01-13 16:42:22.063 HD Request # 43 | Intraday data download complete for 6AH22. Unique request ID: 119 | 2022-01-13 16:42:22.063 Removing historical data download ID 119. | 2022-01-13 16:42:22.063 Real-time Intraday chart data file updates started for 6AH22 | 2022-01-13 16:42:22.063 Intraday chart data file opened for 6AH22 | 2022-01-13 16:42:22.063 HD Request # 43 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:42:22.063 Triggering next historical data download in queue. | 2022-01-13 16:42:22.063 HD Request # 44 | Downloading Intraday chart data for 6CH22 to the file 6CH22.scid. Service: cme | 2022-01-13 16:42:22.063 HD Request # 44 | Download start date-time: 2022-01-13 16:28:09.000000. File last date-time: 2022-01-13 16:28:09.689002 | 2022-01-13 16:42:22.063 HD Request # 44 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:42:22.064 Socket (16) | Creating socket. | 2022-01-13 16:42:22.064 Socket (16) | New receive buffer size: 5242880 | 2022-01-13 16:42:22.064 Socket (16) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:42:22.064 Socket (12) | Socket gracefully closed by remote side. | 2022-01-13 16:42:22.342 Socket (12) | Closed. | 2022-01-13 16:42:22.342 HD Request # 44 | Setting DTC encoding to Binary VLS | 2022-01-13 16:42:22.671 HD Request # 44 | Sending historical data logon request message. | 2022-01-13 16:42:22.671 HD Request # 44 | Requesting Intraday data. Start date-time: 2022-01-13 16:28:09. Record interval: 0. Symbol: 6CH22 | 2022-01-13 16:42:23.433 HD Request # 44 | Decompressing data. | 2022-01-13 16:42:23.733 HD Request # 44 | Receiving Intraday data for 6CH22 starting at 2022-01-13 16:28:09.689000 | 2022-01-13 16:42:23.738 Socket (16) | CloseSocket call. | 2022-01-13 16:42:23.739 Socket (16) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:42:23.739 Historical data download thread signaled to stop. | 2022-01-13 16:42:23.739 HD Request # 44 | Timestamp of first Intraday data file record written: 2022-01-13 16:28:13.295000 | 2022-01-13 16:42:23.739 HD Request # 44 | Received 580 Intraday data records from 2022-01-13 16:28:09.689000 to 2022-01-13 16:42:08.156000 (14.0 minutes) and wrote 577 records for 6CH22 | 2022-01-13 16:42:23.739 HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:42:08.156000 | 2022-01-13 16:42:23.746 HD Request # 44 | Completion time: 1s | 2022-01-13 16:42:23.746 HD Request # 44 | Intraday data download complete for 6CH22. Unique request ID: 120 | 2022-01-13 16:42:23.746 Removing historical data download ID 120. | 2022-01-13 16:42:23.746 Real-time Intraday chart data file updates started for 6CH22 | 2022-01-13 16:42:23.746 Intraday chart data file opened for 6CH22 | 2022-01-13 16:42:23.746 HD Request # 44 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:42:23.746 Triggering next historical data download in queue. | 2022-01-13 16:42:23.746 HD Request # 45 | Downloading Intraday chart data for GCG22 to the file GCG22.scid. Service: comex | 2022-01-13 16:42:23.746 HD Request # 45 | Download start date-time: 2022-01-13 16:35:19.000000. File last date-time: 2022-01-13 16:35:19.589000 | 2022-01-13 16:42:23.746 HD Request # 45 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:42:23.746 Socket (12) | Creating socket. | 2022-01-13 16:42:23.746 Socket (12) | New receive buffer size: 5242880 | 2022-01-13 16:42:23.746 Socket (12) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:42:23.746 Socket (16) | Socket gracefully closed by remote side. | 2022-01-13 16:42:24.037 Socket (16) | Closed. | 2022-01-13 16:42:24.037 HD Request # 45 | Setting DTC encoding to Binary VLS | 2022-01-13 16:42:25.252 HD Request # 45 | Sending historical data logon request message. | 2022-01-13 16:42:25.252 HD Request # 45 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:19. Record interval: 0. Symbol: GCG22 | 2022-01-13 16:42:25.545 HD Request # 45 | Decompressing data. | 2022-01-13 16:42:25.848 HD Request # 45 | Receiving Intraday data for GCG22 starting at 2022-01-13 16:35:19.068000 | 2022-01-13 16:42:28.569 Socket (12) | CloseSocket call. | 2022-01-13 16:42:28.571 Socket (12) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:42:28.571 Historical data download thread signaled to stop. | 2022-01-13 16:42:28.573 HD Request # 45 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:22.104000 | 2022-01-13 16:42:28.573 HD Request # 45 | Received 561 Intraday data records from 2022-01-13 16:35:19.068000 to 2022-01-13 16:42:18.277002 (7.0 minutes) and wrote 552 records for GCG22 | 2022-01-13 16:42:28.573 HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:42:18.277002 | 2022-01-13 16:42:28.580 HD Request # 45 | Completion time: 5s | 2022-01-13 16:42:28.580 HD Request # 45 | Intraday data download complete for GCG22. Unique request ID: 121 | 2022-01-13 16:42:28.580 Removing historical data download ID 121. | 2022-01-13 16:42:28.580 Real-time Intraday chart data file updates started for GCG22 | 2022-01-13 16:42:28.580 Intraday chart data file opened for GCG22 | 2022-01-13 16:42:28.580 HD Request # 45 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:42:28.580 Triggering next historical data download in queue. | 2022-01-13 16:42:28.580 HD Request # 46 | Downloading Intraday chart data for ZNH22 to the file ZNH22.scid. Service: cbot | 2022-01-13 16:42:28.580 HD Request # 46 | Download start date-time: 2022-01-13 16:35:19.000000. File last date-time: 2022-01-13 16:35:19.804000 | 2022-01-13 16:42:28.581 HD Request # 46 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:42:28.581 Socket (16) | Creating socket. | 2022-01-13 16:42:28.581 Socket (16) | New receive buffer size: 5242880 | 2022-01-13 16:42:28.581 Socket (16) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:42:28.581 Socket (12) | Socket gracefully closed by remote side. | 2022-01-13 16:42:28.872 Socket (12) | Closed. | 2022-01-13 16:42:28.872 HD Request # 46 | Setting DTC encoding to Binary VLS | 2022-01-13 16:42:30.207 HD Request # 46 | Sending historical data logon request message. | 2022-01-13 16:42:30.207 HD Request # 46 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:19. Record interval: 0. Symbol: ZNH22 | 2022-01-13 16:42:30.509 HD Request # 46 | Decompressing data. | 2022-01-13 16:42:30.875 HD Request # 46 | Receiving Intraday data for ZNH22 starting at 2022-01-13 16:35:19.364000 | 2022-01-13 16:42:30.878 Socket (16) | CloseSocket call. | 2022-01-13 16:42:30.879 Socket (16) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:42:30.879 Historical data download thread signaled to stop. | 2022-01-13 16:42:30.879 HD Request # 46 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:26.172000 | 2022-01-13 16:42:30.880 HD Request # 46 | Received 482 Intraday data records from 2022-01-13 16:35:19.364000 to 2022-01-13 16:42:21.108000 (7.0 minutes) and wrote 362 records for ZNH22 | 2022-01-13 16:42:30.880 HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:42:21.108000 | 2022-01-13 16:42:30.888 HD Request # 46 | Completion time: 2s | 2022-01-13 16:42:30.888 HD Request # 46 | Intraday data download complete for ZNH22. Unique request ID: 122 | 2022-01-13 16:42:30.888 Removing historical data download ID 122. | 2022-01-13 16:42:30.888 Real-time Intraday chart data file updates started for ZNH22 | 2022-01-13 16:42:30.888 Intraday chart data file opened for ZNH22 | 2022-01-13 16:42:30.888 HD Request # 46 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:42:30.888 Triggering next historical data download in queue. | 2022-01-13 16:42:30.888 HD Request # 47 | Downloading Intraday chart data for ZFH22 to the file ZFH22.scid. Service: cbot | 2022-01-13 16:42:30.888 HD Request # 47 | Download start date-time: 2022-01-13 16:35:18.000000. File last date-time: 2022-01-13 16:35:18.140001 | 2022-01-13 16:42:30.889 HD Request # 47 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:42:30.889 Socket (12) | Creating socket. | 2022-01-13 16:42:30.889 Socket (12) | New receive buffer size: 5242880 | 2022-01-13 16:42:30.889 Socket (12) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:42:30.889 Socket (16) | Socket gracefully closed by remote side. | 2022-01-13 16:42:31.172 Socket (16) | Closed. | 2022-01-13 16:42:31.172 HD Request # 47 | Setting DTC encoding to Binary VLS | 2022-01-13 16:42:31.506 HD Request # 47 | Sending historical data logon request message. | 2022-01-13 16:42:31.506 Socket (11) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-13 16:42:35.788 * DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:42:36.179 DTC Client socket (1) | Closed. | 2022-01-13 16:42:36.179 Socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:42:36.179 Socket (2) | Closed. | 2022-01-13 16:42:36.179 DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:42:36.179 DTC Client socket (3) | Closed. | 2022-01-13 16:42:36.179 CQG WebSocket socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:42:36.179 CQG WebSocket socket (4) | Closed. | 2022-01-13 16:42:36.179 DTC Client socket (5) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:42:36.179 DTC Client socket (5) | Closed. | 2022-01-13 16:42:36.180 CQG WebSocket socket (6) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:42:36.180 CQG WebSocket socket (6) | Closed. | 2022-01-13 16:42:36.180 DTC Client socket (7) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:42:36.180 DTC Client socket (7) | Closed. | 2022-01-13 16:42:36.180 DTC Client socket (8) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:42:36.180 DTC Client socket (8) | Closed. | 2022-01-13 16:42:36.180 Socket (11) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:42:36.180 Socket (11) | Closed. | 2022-01-13 16:42:36.180 Socket (2) | Socket gracefully closed by remote side. | 2022-01-13 16:42:36.180 HD Request # 47 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:18. Record interval: 0. Symbol: ZFH22 | 2022-01-13 16:42:36.978 HD Request # 47 | Decompressing data. | 2022-01-13 16:42:37.281 HD Request # 47 | Receiving Intraday data for ZFH22 starting at 2022-01-13 16:35:18.120000 | 2022-01-13 16:42:37.786 Socket (12) | CloseSocket call. | 2022-01-13 16:42:38.636 Socket (12) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:42:38.636 Historical data download thread signaled to stop. | 2022-01-13 16:42:38.636 HD Request # 47 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:26.036000 | 2022-01-13 16:42:38.637 HD Request # 47 | Received 777 Intraday data records from 2022-01-13 16:35:18.120000 to 2022-01-13 16:42:21.969000 (7.1 minutes) and wrote 681 records for ZFH22 | 2022-01-13 16:42:38.637 HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:42:21.969000 | 2022-01-13 16:42:38.645 HD Request # 47 | Completion time: 8s | 2022-01-13 16:42:38.645 HD Request # 47 | Intraday data download complete for ZFH22. Unique request ID: 123 | 2022-01-13 16:42:38.645 Removing historical data download ID 123. | 2022-01-13 16:42:38.645 Real-time Intraday chart data file updates started for ZFH22 | 2022-01-13 16:42:38.645 Intraday chart data file opened for ZFH22 | 2022-01-13 16:42:38.645 HD Request # 47 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:42:38.645 Triggering next historical data download in queue. | 2022-01-13 16:42:38.645 HD Request # 48 | Downloading Intraday chart data for NGG22 to the file NGG22.scid. Service: nymex | 2022-01-13 16:42:38.646 HD Request # 48 | Download start date-time: 2022-01-13 16:35:20.000000. File last date-time: 2022-01-13 16:35:20.700000 | 2022-01-13 16:42:38.646 HD Request # 48 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:42:38.646 Socket (16) | Creating socket. | 2022-01-13 16:42:38.646 Socket (16) | New receive buffer size: 5242880 | 2022-01-13 16:42:38.647 Socket (16) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:42:38.647 Socket (12) | Socket gracefully closed by remote side. | 2022-01-13 16:42:38.927 Socket (12) | Closed. | 2022-01-13 16:42:38.927 HD Request # 48 | Setting DTC encoding to Binary VLS | 2022-01-13 16:42:46.199 HD Request # 48 | Sending historical data logon request message. | 2022-01-13 16:42:46.199 HD Request # 48 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:20. Record interval: 0. Symbol: NGG22 | 2022-01-13 16:42:46.497 HD Request # 48 | Decompressing data. | 2022-01-13 16:42:46.790 HD Request # 48 | Receiving Intraday data for NGG22 starting at 2022-01-13 16:35:20.153000 | 2022-01-13 16:42:47.897 Socket (16) | CloseSocket call. | 2022-01-13 16:42:48.632 Socket (16) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:42:48.632 Historical data download thread signaled to stop. | 2022-01-13 16:42:48.632 HD Request # 48 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:21.911000 | 2022-01-13 16:42:48.632 HD Request # 48 | Received 1592 Intraday data records from 2022-01-13 16:35:20.153000 to 2022-01-13 16:42:42.224000 (7.4 minutes) and wrote 1586 records for NGG22 | 2022-01-13 16:42:48.632 HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:42:42.224000 | 2022-01-13 16:42:48.636 HD Request # 48 | Completion time: 10s | 2022-01-13 16:42:48.636 HD Request # 48 | Intraday data download complete for NGG22. Unique request ID: 124 | 2022-01-13 16:42:48.636 Removing historical data download ID 124. | 2022-01-13 16:42:48.636 Real-time Intraday chart data file updates started for NGG22 | 2022-01-13 16:42:48.636 Intraday chart data file opened for NGG22 | 2022-01-13 16:42:48.636 HD Request # 48 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:42:48.636 Triggering next historical data download in queue. | 2022-01-13 16:42:48.636 HD Request # 49 | Downloading Intraday chart data for TNH22 to the file TNH22.scid. Service: cbot | 2022-01-13 16:42:48.636 HD Request # 49 | Download start date-time: 2022-01-13 16:35:19.000000. File last date-time: 2022-01-13 16:35:19.508001 | 2022-01-13 16:42:48.637 HD Request # 49 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:42:48.637 Socket (12) | Creating socket. | 2022-01-13 16:42:48.637 Socket (12) | New receive buffer size: 5242880 | 2022-01-13 16:42:48.637 Socket (12) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:42:48.637 Socket (16) | Socket gracefully closed by remote side. | 2022-01-13 16:42:48.930 Socket (16) | Closed. | 2022-01-13 16:42:48.930 HD Request # 49 | Setting DTC encoding to Binary VLS | 2022-01-13 16:42:51.854 HD Request # 49 | Sending historical data logon request message. | 2022-01-13 16:42:51.855 HD Request # 49 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:19. Record interval: 0. Symbol: TNH22 | 2022-01-13 16:42:52.619 HD Request # 49 | Decompressing data. | 2022-01-13 16:42:53.696 HD Request # 49 | Receiving Intraday data for TNH22 starting at 2022-01-13 16:35:19.363000 | 2022-01-13 16:42:53.697 Socket (12) | CloseSocket call. | 2022-01-13 16:42:54.034 Socket (12) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:42:54.034 Historical data download thread signaled to stop. | 2022-01-13 16:42:54.034 HD Request # 49 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:41.242000 | 2022-01-13 16:42:54.035 HD Request # 49 | Received 339 Intraday data records from 2022-01-13 16:35:19.363000 to 2022-01-13 16:42:44.652014 (7.4 minutes) and wrote 311 records for TNH22 | 2022-01-13 16:42:54.035 HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:42:44.652014 | 2022-01-13 16:42:54.040 HD Request # 49 | Completion time: 6s | 2022-01-13 16:42:54.040 HD Request # 49 | Intraday data download complete for TNH22. Unique request ID: 125 | 2022-01-13 16:42:54.040 Removing historical data download ID 125. | 2022-01-13 16:42:54.040 Real-time Intraday chart data file updates started for TNH22 | 2022-01-13 16:42:54.040 Intraday chart data file opened for TNH22 | 2022-01-13 16:42:54.040 HD Request # 49 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:42:54.040 Triggering next historical data download in queue. | 2022-01-13 16:42:54.040 HD Request # 50 | Downloading Intraday chart data for 6EH22 to the file 6EH22.scid. Service: cme | 2022-01-13 16:42:54.040 HD Request # 50 | Download start date-time: 2022-01-13 16:35:20.000000. File last date-time: 2022-01-13 16:35:20.848001 | 2022-01-13 16:42:54.041 HD Request # 50 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:42:54.041 Socket (16) | Creating socket. | 2022-01-13 16:42:54.041 Socket (16) | New receive buffer size: 5242880 | 2022-01-13 16:42:54.041 Socket (16) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:42:54.041 Socket (12) | Socket gracefully closed by remote side. | 2022-01-13 16:42:54.336 Socket (12) | Closed. | 2022-01-13 16:42:54.336 DTC Client socket (1) | Deleting network socket now after delay. | 2022-01-13 16:43:06.194 Socket (2) | Deleting network socket now after delay. | 2022-01-13 16:43:06.194 DTC Client socket (3) | Deleting network socket now after delay. | 2022-01-13 16:43:06.194 CQG WebSocket socket (4) | Deleting network socket now after delay. | 2022-01-13 16:43:06.194 DTC Client socket (5) | Deleting network socket now after delay. | 2022-01-13 16:43:06.194 CQG WebSocket socket (6) | Deleting network socket now after delay. | 2022-01-13 16:43:06.194 DTC Client socket (7) | Deleting network socket now after delay. | 2022-01-13 16:43:06.194 DTC Client socket (8) | Deleting network socket now after delay. | 2022-01-13 16:43:06.194 Socket (11) | Deleting network socket now after delay. | 2022-01-13 16:43:06.194 Socket (15) | Socket gracefully closed by remote side. | 2022-01-13 16:43:08.680 Socket (15) | Closed. | 2022-01-13 16:43:08.680 SC Data - All Services | There has been no activity on the network socket for 1m 2s. Will reconnect. | 2022-01-13 16:43:11.181 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 16:43:11.181 DTC Client socket (9) | CloseSocket call. | 2022-01-13 16:43:11.182 DTC Client socket (9) | Max send buffers used during socket life: 4 | 2022-01-13 16:43:11.182 DTC Client socket (9) | Max send buffer size during socket life: 1242 | 2022-01-13 16:43:11.182 DTC Client socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:43:11.182 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:43:11.182 WSACleanup called. | 2022-01-13 16:43:11.182 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 16:43:11.183 DTC Client socket (13) | CloseSocket call. | 2022-01-13 16:43:11.183 DTC Client socket (13) | Max send buffers used during socket life: 4 | 2022-01-13 16:43:11.183 DTC Client socket (13) | Max send buffer size during socket life: 1746 | 2022-01-13 16:43:11.183 SC Data - All Services | Disconnected from the server. | 2022-01-13 16:43:11.183 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 16:43:11.183 DTC Client socket (13) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:43:11.183 DTC Client socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:43:11.469 DTC Client socket (9) | Closed. | 2022-01-13 16:43:11.469 SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 443 | 2022-01-13 16:43:13.204 DTC Client socket (1) | Creating socket. | 2022-01-13 16:43:13.204 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:43:13.204 DTC Client socket (1) | Connecting to IP: 38.89.235.129. | 2022-01-13 16:43:13.204 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:43:13.360 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:43:13.360 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:43:13.360 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:43:13.547 SC Data - All Services | Sending logon request message. | 2022-01-13 16:43:13.547 Socket (16) | CloseSocket call. | 2022-01-13 16:43:14.051 Socket (16) | Closed. | 2022-01-13 16:43:14.051 HD Request # 50 | Error downloading historical Intraday data for 6EH22. Timeout error connecting to server. | 2022-01-13 16:43:14.051 Added historical Intraday data request for 6EH22 to the queue. | 2022-01-13 16:43:14.051 Triggering next historical data download in queue. | 2022-01-13 16:43:14.051 Historical data download thread signaled to stop. | 2022-01-13 16:43:14.051 HD Request # 50 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for 6EH22 | 2022-01-13 16:43:14.051 HD Request # 50 | Completion time: 20s | 2022-01-13 16:43:14.051 HD Request # 51 | Downloading Intraday chart data for 6EH22 to the file 6EH22.scid. Service: cme | 2022-01-13 16:43:14.051 HD Request # 51 | Download start date-time: 2022-01-13 16:35:20.000000. File last date-time: 2022-01-13 16:35:20.848001 | 2022-01-13 16:43:14.052 HD Request # 51 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:43:14.052 Socket (2) | Creating socket. | 2022-01-13 16:43:14.052 Socket (2) | New receive buffer size: 5242880 | 2022-01-13 16:43:14.052 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:43:14.052 SC Data - All Services | Received logon response. | 2022-01-13 16:43:14.443 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:43:14.443 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:43:14.443 SC Data - All Services | Successfully connected. | 2022-01-13 16:43:14.443 SC Data - All Services | Trading is not supported. | 2022-01-13 16:43:14.443 SC Data - All Services (Market Orders Data) | Connecting to the server ds26.sierracharts.com. Port 10060 | 2022-01-13 16:43:14.448 Added historical Intraday data request for 6AH22 to the queue. | 2022-01-13 16:43:14.448 Intraday data recording state for symbol 6AH22 is set to download 'Pending'. | 2022-01-13 16:43:14.448 Triggering next historical data download in queue. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: 6AH22 -> 6AH22. Market Depth data restarted. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: 6BH22 -> 6BH22. Market Depth data restarted. | 2022-01-13 16:43:14.449 Added historical Intraday data request for 6CH22 to the queue. | 2022-01-13 16:43:14.449 Intraday data recording state for symbol 6CH22 is set to download 'Pending'. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: 6CH22 -> 6CH22. Market Depth data restarted. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: 6EH22 -> 6EH22. Market Depth data restarted. | 2022-01-13 16:43:14.449 Added historical Intraday data request for 6JH22 to the queue. | 2022-01-13 16:43:14.449 Intraday data recording state for symbol 6JH22 is set to download 'Pending'. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: 6JH22 -> 6JH22. Market Depth data restarted. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: 6MH22 -> 6MH22 | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: 6SH22 -> 6SH22 | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: BBH22 -> BBH22 | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: BTCF22 -> BTCF22 | 2022-01-13 16:43:14.449 DTC Client socket (3) | Creating socket. | 2022-01-13 16:43:14.449 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-01-13 16:43:14.449 DTC Client socket (3) | Connecting to IP: 38.89.235.129. | 2022-01-13 16:43:14.449 Added historical Intraday data request for CLG22 to the queue. | 2022-01-13 16:43:14.449 Intraday data recording state for symbol CLG22 is set to download 'Pending'. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: CLG22 -> CLG22. Market Depth data restarted. | 2022-01-13 16:43:14.449 Added historical Intraday data request for ESH22 to the queue. | 2022-01-13 16:43:14.449 Intraday data recording state for symbol ESH22 is set to download 'Pending'. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22. Market Depth data restarted. | 2022-01-13 16:43:14.449 Added historical Intraday data request for GCG22 to the queue. | 2022-01-13 16:43:14.449 Intraday data recording state for symbol GCG22 is set to download 'Pending'. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: GCG22 -> GCG22. Market Depth data restarted. | 2022-01-13 16:43:14.449 SC Data - All Services | Restarting real-time data updates for symbol: HOG22 -> HOG22 | 2022-01-13 16:43:14.449 Added historical Intraday data request for NGG22 to the queue. | 2022-01-13 16:43:14.449 Intraday data recording state for symbol NGG22 is set to download 'Pending'. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: NGG22 -> NGG22. Market Depth data restarted. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: NKDH22 -> NKDH22 | 2022-01-13 16:43:14.450 Added historical Intraday data request for NQH22 to the queue. | 2022-01-13 16:43:14.450 Intraday data recording state for symbol NQH22 is set to download 'Pending'. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: NQH22 -> NQH22. Market Depth data restarted. | 2022-01-13 16:43:14.450 Added historical Intraday data request for RBG22 to the queue. | 2022-01-13 16:43:14.450 Intraday data recording state for symbol RBG22 is set to download 'Pending'. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: RBG22 -> RBG22. Market Depth data restarted. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: RTYH22 -> RTYH22 | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: SIH22 -> SIH22 | 2022-01-13 16:43:14.450 Added historical Intraday data request for TNH22 to the queue. | 2022-01-13 16:43:14.450 Intraday data recording state for symbol TNH22 is set to download 'Pending'. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: TNH22 -> TNH22. Market Depth data restarted. | 2022-01-13 16:43:14.450 Added historical Intraday data request for YMH22 to the queue. | 2022-01-13 16:43:14.450 Intraday data recording state for symbol YMH22 is set to download 'Pending'. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: YMH22 -> YMH22. Market Depth data restarted. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: ZBH22 -> ZBH22. Market Depth data restarted. | 2022-01-13 16:43:14.450 Added historical Intraday data request for ZFH22 to the queue. | 2022-01-13 16:43:14.450 Intraday data recording state for symbol ZFH22 is set to download 'Pending'. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: ZFH22 -> ZFH22. Market Depth data restarted. | 2022-01-13 16:43:14.450 Added historical Intraday data request for ZNH22 to the queue. | 2022-01-13 16:43:14.450 Intraday data recording state for symbol ZNH22 is set to download 'Pending'. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: ZNH22 -> ZNH22. Market Depth data restarted. | 2022-01-13 16:43:14.450 SC Data - All Services | Restarting real-time data updates for symbol: ZTH22 -> ZTH22 | 2022-01-13 16:43:14.450 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:43:14.603 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:43:14.603 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:43:14.603 SC Data - All Services | Clearing market depth for 6AH22 | 2022-01-13 16:43:14.666 SC Data - All Services | Clearing market depth for 6BH22 | 2022-01-13 16:43:14.666 SC Data - All Services | Clearing market depth for 6CH22 | 2022-01-13 16:43:14.666 SC Data - All Services | Received security definition for symbol 6AH22 | 2022-01-13 16:43:14.673 SC Data - All Services | Received security definition for symbol 6BH22 | 2022-01-13 16:43:14.673 SC Data - All Services | Received security definition for symbol 6CH22 | 2022-01-13 16:43:14.673 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:43:14.781 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:43:14.781 SC Data - All Services | Clearing market depth for 6EH22 | 2022-01-13 16:43:14.781 SC Data - All Services | Clearing market depth for 6JH22 | 2022-01-13 16:43:14.781 SC Data - All Services | Clearing market depth for CLG22 | 2022-01-13 16:43:14.781 SC Data - All Services | Clearing market depth for ESH22 | 2022-01-13 16:43:14.781 SC Data - All Services | Clearing market depth for GCG22 | 2022-01-13 16:43:14.781 SC Data - All Services | Clearing market depth for NGG22 | 2022-01-13 16:43:14.781 SC Data - All Services | Clearing market depth for NQH22 | 2022-01-13 16:43:14.781 SC Data - All Services | Clearing market depth for RBG22 | 2022-01-13 16:43:14.782 SC Data - All Services | Clearing market depth for TNH22 | 2022-01-13 16:43:14.782 SC Data - All Services | Clearing market depth for YMH22 | 2022-01-13 16:43:14.782 SC Data - All Services | Clearing market depth for ZBH22 | 2022-01-13 16:43:14.782 SC Data - All Services | Clearing market depth for ZFH22 | 2022-01-13 16:43:14.782 SC Data - All Services | Clearing market depth for ZNH22 | 2022-01-13 16:43:14.782 SC Data - All Services | Received security definition for symbol 6EH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol 6JH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol 6MH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol 6SH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol BBH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol BTCF22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol CLG22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol ESH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol GCG22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol HOG22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol NGG22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol NKDH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol NQH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol RBG22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol RTYH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol SIH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol TNH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol YMH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol ZBH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol ZFH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol ZNH22 | 2022-01-13 16:43:14.783 SC Data - All Services | Received security definition for symbol ZTH22 | 2022-01-13 16:43:14.783 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 25. Service code: nymex | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLG22 -> CLG22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 15. Service code: comex | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: GCG22 -> GCG22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGG22 -> NGG22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 15. Service code: cme | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NQH22 -> NQH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: RBG22 -> RBG22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: TNH22 -> TNH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 20. Service code: cbot | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: YMH22 -> YMH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 200. Service code: cbot | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 1500. Service code: cbot | 2022-01-13 16:43:15.687 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:43:15.687 HD Request # 51 | Setting DTC encoding to Binary VLS | 2022-01-13 16:43:17.646 HD Request # 51 | Sending historical data logon request message. | 2022-01-13 16:43:17.646 HD Request # 51 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:20. Record interval: 0. Symbol: 6EH22 | 2022-01-13 16:43:17.941 HD Request # 51 | Decompressing data. | 2022-01-13 16:43:18.253 HD Request # 51 | Receiving Intraday data for 6EH22 starting at 2022-01-13 16:35:20.848000 | 2022-01-13 16:43:18.257 Socket (2) | CloseSocket call. | 2022-01-13 16:43:18.259 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:43:18.259 Historical data download thread signaled to stop. | 2022-01-13 16:43:18.280 HD Request # 51 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:21.334000 | 2022-01-13 16:43:18.280 HD Request # 51 | Received 454 Intraday data records from 2022-01-13 16:35:20.848000 to 2022-01-13 16:43:16.051000 (7.9 minutes) and wrote 452 records for 6EH22 | 2022-01-13 16:43:18.280 HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:43:16.051000 | 2022-01-13 16:43:18.290 HD Request # 51 | Completion time: 4s | 2022-01-13 16:43:18.290 HD Request # 51 | Intraday data download complete for 6EH22. Unique request ID: 126 | 2022-01-13 16:43:18.290 Removing historical data download ID 126. | 2022-01-13 16:43:18.290 Real-time Intraday chart data file updates started for 6EH22 | 2022-01-13 16:43:18.290 Intraday chart data file opened for 6EH22 | 2022-01-13 16:43:18.290 HD Request # 51 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:43:18.290 Triggering next historical data download in queue. | 2022-01-13 16:43:18.290 HD Request # 52 | Downloading Intraday chart data for ZBH22 to the file ZBH22.scid. Service: cbot | 2022-01-13 16:43:18.290 HD Request # 52 | Download start date-time: 2022-01-13 16:35:14.000000. File last date-time: 2022-01-13 16:35:14.276002 | 2022-01-13 16:43:18.290 HD Request # 52 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 16:43:18.290 Socket (4) | Creating socket. | 2022-01-13 16:43:18.290 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:43:18.291 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:43:18.291 Socket (2) | Socket gracefully closed by remote side. | 2022-01-13 16:43:19.248 Socket (2) | Closed. | 2022-01-13 16:43:19.248 HD Request # 52 | Setting DTC encoding to Binary VLS | 2022-01-13 16:43:19.826 HD Request # 52 | Sending historical data logon request message. | 2022-01-13 16:43:19.826 HD Request # 52 | Requesting Intraday data. Start date-time: 2022-01-13 16:35:14. Record interval: 0. Symbol: ZBH22 | 2022-01-13 16:43:20.573 HD Request # 52 | Decompressing data. | 2022-01-13 16:43:20.860 HD Request # 52 | Receiving Intraday data for ZBH22 starting at 2022-01-13 16:35:14.101000 | 2022-01-13 16:43:21.660 Socket (4) | CloseSocket call. | 2022-01-13 16:43:22.048 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:43:22.048 Historical data download thread signaled to stop. | 2022-01-13 16:43:22.049 HD Request # 52 | Timestamp of first Intraday data file record written: 2022-01-13 16:35:24.758000 | 2022-01-13 16:43:22.049 HD Request # 52 | Received 853 Intraday data records from 2022-01-13 16:35:14.101000 to 2022-01-13 16:43:12.808004 (8.0 minutes) and wrote 810 records for ZBH22 | 2022-01-13 16:43:22.049 HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:43:12.808004 | 2022-01-13 16:43:22.058 HD Request # 52 | Completion time: 4s | 2022-01-13 16:43:22.058 HD Request # 52 | Intraday data download complete for ZBH22. Unique request ID: 127 | 2022-01-13 16:43:22.058 Removing historical data download ID 127. | 2022-01-13 16:43:22.058 Real-time Intraday chart data file updates started for ZBH22 | 2022-01-13 16:43:22.058 Intraday chart data file opened for ZBH22 | 2022-01-13 16:43:22.058 HD Request # 52 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:43:22.058 Triggering next historical data download in queue. | 2022-01-13 16:43:22.058 HD Request # 53 | Downloading Intraday chart data for 6BH22 to the file 6BH22.scid. Service: cme | 2022-01-13 16:43:22.058 HD Request # 53 | Download start date-time: 2022-01-13 16:28:07.000000. File last date-time: 2022-01-13 16:28:07.256000 | 2022-01-13 16:43:22.058 HD Request # 53 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:43:22.059 Socket (2) | Creating socket. | 2022-01-13 16:43:22.059 Socket (2) | New receive buffer size: 5242880 | 2022-01-13 16:43:22.059 Socket (2) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:43:22.059 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:43:22.344 Socket (4) | Closed. | 2022-01-13 16:43:22.344 Opened cached Intraday file: C:\SierraChart\Data\6EH22.scid. Thread ID: 11608 | 2022-01-13 16:43:26.923 HD Request # 53 | Setting DTC encoding to Binary VLS | 2022-01-13 16:43:31.684 HD Request # 53 | Sending historical data logon request message. | 2022-01-13 16:43:31.684 Opened cached Intraday file: C:\SierraChart\Data\ZBH22.scid. Thread ID: 11608 | 2022-01-13 16:43:31.972 HD Request # 53 | Requesting Intraday data. Start date-time: 2022-01-13 16:28:07. Record interval: 0. Symbol: 6BH22 | 2022-01-13 16:43:32.441 HD Request # 53 | Decompressing data. | 2022-01-13 16:43:43.963 HD Request # 53 | Receiving Intraday data for 6BH22 starting at 2022-01-13 16:28:07.253000 | 2022-01-13 16:43:43.964 Socket (2) | CloseSocket call. | 2022-01-13 16:43:44.314 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:43:44.314 Historical data download thread signaled to stop. | 2022-01-13 16:43:44.358 HD Request # 53 | Timestamp of first Intraday data file record written: 2022-01-13 16:28:27.347000 | 2022-01-13 16:43:44.358 HD Request # 53 | Received 399 Intraday data records from 2022-01-13 16:28:07.253000 to 2022-01-13 16:43:27.766002 (15.3 minutes) and wrote 387 records for 6BH22 | 2022-01-13 16:43:44.359 HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:43:27.766002 | 2022-01-13 16:43:44.366 Added 2 Time and Sales records to Intraday data file for 6BH22 after download. | 2022-01-13 16:43:44.366 HD Request # 53 | Completion time: 22s | 2022-01-13 16:43:44.366 HD Request # 53 | Intraday data download complete for 6BH22. Unique request ID: 128 | 2022-01-13 16:43:44.366 Removing historical data download ID 128. | 2022-01-13 16:43:44.366 Real-time Intraday chart data file updates started for 6BH22 | 2022-01-13 16:43:44.366 Intraday chart data file opened for 6BH22 | 2022-01-13 16:43:44.366 HD Request # 53 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:43:44.366 Triggering next historical data download in queue. | 2022-01-13 16:43:44.366 HD Request # 54 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 16:43:44.366 HD Request # 54 | Download start date-time: 2022-01-13 16:34:42.000000. File last date-time: 2022-01-13 16:34:42.963000 | 2022-01-13 16:43:44.367 HD Request # 54 | Using server: ds12.sierracharts.com port 10149 | 2022-01-13 16:43:44.367 Socket (4) | Creating socket. | 2022-01-13 16:43:44.367 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:43:44.367 Socket (4) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:43:44.367 Socket (2) | Socket gracefully closed by remote side. | 2022-01-13 16:43:44.618 Socket (2) | Closed. | 2022-01-13 16:43:44.618 HD Request # 54 | Setting DTC encoding to Binary VLS | 2022-01-13 16:43:45.866 HD Request # 54 | Sending historical data logon request message. | 2022-01-13 16:43:45.866 Trading Evaluator | There has been no activity on the network socket for 1m 14s. Will reconnect. | 2022-01-13 16:43:49.051 Connection to the external service has been lost. | 2022-01-13 16:43:49.051 Trading Evaluator | Waiting for socket receive thread to end | 2022-01-13 16:43:49.089 DTC Client socket (10) | CloseSocket call. | 2022-01-13 16:43:49.090 DTC Client socket (10) | Max send buffers used during socket life: 5 | 2022-01-13 16:43:49.090 DTC Client socket (10) | Max send buffer size during socket life: 1124 | 2022-01-13 16:43:49.090 DTC Client socket (10) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:43:49.090 Trading Evaluator | Disconnected. | 2022-01-13 16:43:49.090 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-01-13 16:43:49.090 Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2022-01-13 16:43:51.389 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-01-13 16:43:51.390 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-01-13 16:43:51.390 DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:43:51.390 Trading Evaluator | Network connection to server complete. | 2022-01-13 16:43:54.719 Trading Evaluator | Starting socket receive thread. | 2022-01-13 16:43:54.719 Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2022-01-13 16:43:54.719 Trading Evaluator | Setting DTC encoding to Binary VLS | 2022-01-13 16:44:04.355 Trading Evaluator | Sending logon request message. | 2022-01-13 16:44:04.355 HD Request # 54 | Requesting Intraday data. Start date-time: 2022-01-13 16:34:42. Record interval: 0. Symbol: ADV-NYSE | 2022-01-13 16:44:04.789 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:44:05.082 Socket (4) | CloseSocket call. | 2022-01-13 16:44:05.082 Socket (0) | CloseSocket call. | 2022-01-13 16:44:05.082 Socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-01-13 16:44:05.082 Socket (4) | Closed. | 2022-01-13 16:44:05.082 HD Request # 54 | Error downloading historical Intraday data for ADV-NYSE. The network socket has been closed. Retrying download. | 2022-01-13 16:44:05.085 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:44:05.085 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:44:05.085 Triggering next historical data download in queue. | 2022-01-13 16:44:05.085 Historical data download thread signaled to stop. | 2022-01-13 16:44:05.085 HD Request # 54 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ADV-NYSE | 2022-01-13 16:44:05.085 HD Request # 54 | Completion time: 21s | 2022-01-13 16:44:05.085 HD Request # 55 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 16:44:05.085 HD Request # 55 | Download start date-time: 2022-01-13 16:34:42.000000. File last date-time: 2022-01-13 16:34:42.963000 | 2022-01-13 16:44:05.086 HD Request # 55 | Using server: ds13-3.sierracharts.com port 10150 | 2022-01-13 16:44:05.086 Socket (4) | Creating socket. | 2022-01-13 16:44:05.086 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:44:05.086 Socket (4) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:44:05.086 Trading Evaluator | Received logon response. | 2022-01-13 16:44:05.200 Trading Evaluator | Server Name: SC DTC Server. Build=40463. | 2022-01-13 16:44:05.200 Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:44:05.200 Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2022-01-13 16:44:05.200 Trading Evaluator | Trading is supported. | 2022-01-13 16:44:05.200 Trading Evaluator | Order cancel and replace is supported. | 2022-01-13 16:44:05.200 Trading Evaluator | OCO Orders supported. | 2022-01-13 16:44:05.200 Trading Evaluator | Bracket Orders supported. | 2022-01-13 16:44:05.200 Trading Evaluator | Connected to server complete. | 2022-01-13 16:44:05.200 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 16:44:05.200 DTC Client socket (3) | CloseSocket call. | 2022-01-13 16:44:05.201 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:44:05.201 WSACleanup called. | 2022-01-13 16:44:05.201 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:44:05.201 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 16:44:05.201 DTC Client socket (1) | CloseSocket call. | 2022-01-13 16:44:05.202 DTC Client socket (1) | Max send buffers used during socket life: 4 | 2022-01-13 16:44:05.202 DTC Client socket (1) | Max send buffer size during socket life: 2367 | 2022-01-13 16:44:05.202 SC Data - All Services | Disconnected from the server. | 2022-01-13 16:44:05.202 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:44:05.202 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:44:05.202 DTC Client socket (14) | CloseSocket call. | 2022-01-13 16:44:05.202 DTC Client socket (14) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:44:05.202 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:44:05.202 Triggering next historical data download in queue. | 2022-01-13 16:44:05.204 Triggering next historical data download in queue. | 2022-01-13 16:44:05.204 Triggering next historical data download in queue. | 2022-01-13 16:44:05.204 Triggering next historical data download in queue. | 2022-01-13 16:44:05.204 No download requests in the queue to start downloads for. | 2022-01-13 16:44:05.246 No download requests in the queue to start downloads for. | 2022-01-13 16:44:05.246 No download requests in the queue to start downloads for. | 2022-01-13 16:44:05.246 Mapping RBG22 to RBG22. Service code: nymex | 2022-01-13 16:44:05.246 SC Data - All Services | Starting real-time market data updates for: RBG22 (RBG22). ID: 1 Service code: nymex | 2022-01-13 16:44:05.247 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-01-13 16:44:05.247 SC Data - All Services | Requesting security definition data for: RBG22 (RBG22). ID: 1 | 2022-01-13 16:44:05.247 Mapping CLG22 to CLG22. Service code: nymex | 2022-01-13 16:44:05.269 SC Data - All Services | Starting real-time market data updates for: CLG22 (CLG22). ID: 2 Service code: nymex | 2022-01-13 16:44:05.269 SC Data - All Services | Requesting security definition data for: CLG22 (CLG22). ID: 2 | 2022-01-13 16:44:05.269 Mapping YMH22 to YMH22. Service code: cbot | 2022-01-13 16:44:05.277 SC Data - All Services | Starting real-time market data updates for: YMH22 (YMH22). ID: 3 Service code: cbot | 2022-01-13 16:44:05.277 SC Data - All Services | Requesting security definition data for: YMH22 (YMH22). ID: 3 | 2022-01-13 16:44:05.277 Mapping GCG22 to GCG22. Service code: comex | 2022-01-13 16:44:05.308 SC Data - All Services | Starting real-time market data updates for: GCG22 (GCG22). ID: 4 Service code: comex | 2022-01-13 16:44:05.308 SC Data - All Services | Requesting security definition data for: GCG22 (GCG22). ID: 4 | 2022-01-13 16:44:05.308 Mapping NQH22 to NQH22. Service code: cme | 2022-01-13 16:44:05.317 SC Data - All Services | Starting real-time market data updates for: NQH22 (NQH22). ID: 5 Service code: cme | 2022-01-13 16:44:05.317 SC Data - All Services | Requesting security definition data for: NQH22 (NQH22). ID: 5 | 2022-01-13 16:44:05.317 Mapping 6AH22 to 6AH22. Service code: cme | 2022-01-13 16:44:05.323 SC Data - All Services | Starting real-time market data updates for: 6AH22 (6AH22). ID: 6 Service code: cme | 2022-01-13 16:44:05.323 SC Data - All Services | Requesting security definition data for: 6AH22 (6AH22). ID: 6 | 2022-01-13 16:44:05.323 Mapping ESH22 to ESH22. Service code: cme | 2022-01-13 16:44:05.327 SC Data - All Services | Starting real-time market data updates for: ESH22 (ESH22). ID: 7 Service code: cme | 2022-01-13 16:44:05.327 SC Data - All Services | Requesting security definition data for: ESH22 (ESH22). ID: 7 | 2022-01-13 16:44:05.327 Mapping 6CH22 to 6CH22. Service code: cme | 2022-01-13 16:44:05.332 SC Data - All Services | Starting real-time market data updates for: 6CH22 (6CH22). ID: 8 Service code: cme | 2022-01-13 16:44:05.332 SC Data - All Services | Requesting security definition data for: 6CH22 (6CH22). ID: 8 | 2022-01-13 16:44:05.332 DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-01-13 16:44:05.347 DTC Client socket (3) | Closed. | 2022-01-13 16:44:05.347 DTC Client socket (5) | Creating socket. | 2022-01-13 16:44:05.357 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:44:05.357 DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2022-01-13 16:44:05.357 Mapping ZNH22 to ZNH22. Service code: cbot | 2022-01-13 16:44:05.374 SC Data - All Services | Starting real-time market data updates for: ZNH22 (ZNH22). ID: 9 Service code: cbot | 2022-01-13 16:44:05.374 SC Data - All Services | Requesting security definition data for: ZNH22 (ZNH22). ID: 9 | 2022-01-13 16:44:05.374 Mapping ZFH22 to ZFH22. Service code: cbot | 2022-01-13 16:44:05.377 SC Data - All Services | Starting real-time market data updates for: ZFH22 (ZFH22). ID: 10 Service code: cbot | 2022-01-13 16:44:05.377 SC Data - All Services | Requesting security definition data for: ZFH22 (ZFH22). ID: 10 | 2022-01-13 16:44:05.377 Mapping NGG22 to NGG22. Service code: nymex | 2022-01-13 16:44:05.380 SC Data - All Services | Starting real-time market data updates for: NGG22 (NGG22). ID: 11 Service code: nymex | 2022-01-13 16:44:05.380 SC Data - All Services | Requesting security definition data for: NGG22 (NGG22). ID: 11 | 2022-01-13 16:44:05.380 Mapping TNH22 to TNH22. Service code: cbot | 2022-01-13 16:44:05.384 SC Data - All Services | Starting real-time market data updates for: TNH22 (TNH22). ID: 12 Service code: cbot | 2022-01-13 16:44:05.384 SC Data - All Services | Requesting security definition data for: TNH22 (TNH22). ID: 12 | 2022-01-13 16:44:05.384 Mapping 6EH22 to 6EH22. Service code: cme | 2022-01-13 16:44:05.461 SC Data - All Services | Starting real-time market data updates for: 6EH22 (6EH22). ID: 13 Service code: cme | 2022-01-13 16:44:05.461 SC Data - All Services | Requesting security definition data for: 6EH22 (6EH22). ID: 13 | 2022-01-13 16:44:05.461 Added historical Intraday data request for 6EH22 to the queue. | 2022-01-13 16:44:05.461 Intraday data recording state for symbol 6EH22 is set to download 'Pending'. | 2022-01-13 16:44:05.461 Triggering next historical data download in queue. | 2022-01-13 16:44:05.461 Mapping ZBH22 to ZBH22. Service code: cbot | 2022-01-13 16:44:05.463 SC Data - All Services | Starting real-time market data updates for: ZBH22 (ZBH22). ID: 14 Service code: cbot | 2022-01-13 16:44:05.463 SC Data - All Services | Requesting security definition data for: ZBH22 (ZBH22). ID: 14 | 2022-01-13 16:44:05.463 Added historical Intraday data request for ZBH22 to the queue. | 2022-01-13 16:44:05.463 Intraday data recording state for symbol ZBH22 is set to download 'Pending'. | 2022-01-13 16:44:05.463 Triggering next historical data download in queue. | 2022-01-13 16:44:05.463 Mapping RTYH22 to RTYH22. Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: RTYH22 (RTYH22). ID: 15 Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: RTYH22 (RTYH22). ID: 15 | 2022-01-13 16:44:05.477 Mapping NKDH22 to NKDH22. Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: NKDH22 (NKDH22). ID: 16 Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: NKDH22 (NKDH22). ID: 16 | 2022-01-13 16:44:05.477 Mapping ZTH22 to ZTH22. Service code: cbot | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: ZTH22 (ZTH22). ID: 17 Service code: cbot | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: ZTH22 (ZTH22). ID: 17 | 2022-01-13 16:44:05.477 Trading Evaluator | Starting real-time market data updates for: FBTPH22. ID: 18 Service code: eurex | 2022-01-13 16:44:05.477 Trading Evaluator | Requesting security definition data for: FBTPH22. ID: 18 | 2022-01-13 16:44:05.477 Trading Evaluator | Starting real-time market data updates for: FGBLH22. ID: 19 Service code: eurex | 2022-01-13 16:44:05.477 Trading Evaluator | Requesting security definition data for: FGBLH22. ID: 19 | 2022-01-13 16:44:05.477 Trading Evaluator | Starting real-time market data updates for: FGBMH22. ID: 20 Service code: eurex | 2022-01-13 16:44:05.477 Trading Evaluator | Requesting security definition data for: FGBMH22. ID: 20 | 2022-01-13 16:44:05.477 Mapping BBH22 to BBH22. Service code: nymex | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: BBH22 (BBH22). ID: 21 Service code: nymex | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: BBH22 (BBH22). ID: 21 | 2022-01-13 16:44:05.477 Mapping HOG22 to HOG22. Service code: nymex | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: HOG22 (HOG22). ID: 22 Service code: nymex | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: HOG22 (HOG22). ID: 22 | 2022-01-13 16:44:05.477 Mapping SIH22 to SIH22. Service code: comex | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: SIH22 (SIH22). ID: 23 Service code: comex | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: SIH22 (SIH22). ID: 23 | 2022-01-13 16:44:05.477 Mapping 6BH22 to 6BH22. Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: 6BH22 (6BH22). ID: 24 Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: 6BH22 (6BH22). ID: 24 | 2022-01-13 16:44:05.477 Mapping 6JH22 to 6JH22. Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: 6JH22 (6JH22). ID: 25 Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: 6JH22 (6JH22). ID: 25 | 2022-01-13 16:44:05.477 Mapping 6SH22 to 6SH22. Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: 6SH22 (6SH22). ID: 26 Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: 6SH22 (6SH22). ID: 26 | 2022-01-13 16:44:05.477 Mapping 6MH22 to 6MH22. Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: 6MH22 (6MH22). ID: 27 Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: 6MH22 (6MH22). ID: 27 | 2022-01-13 16:44:05.477 Mapping BTCF22 to BTCF22. Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Starting real-time market data updates for: BTCF22 (BTCF22). ID: 28 Service code: cme | 2022-01-13 16:44:05.477 SC Data - All Services | Requesting security definition data for: BTCF22 (BTCF22). ID: 28 | 2022-01-13 16:44:05.477 Added historical Intraday data request for 6BH22 to the queue. | 2022-01-13 16:44:05.490 Intraday data recording state for symbol 6BH22 is set to download 'Pending'. | 2022-01-13 16:44:05.490 Triggering next historical data download in queue. | 2022-01-13 16:44:05.490 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-NYSE. ID: 29 Service code: statscalc | 2022-01-13 16:44:05.492 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 443 | 2022-01-13 16:44:05.492 SC DTC Data with Market Depth | Requesting security definition data for: ADV-NYSE. ID: 29 | 2022-01-13 16:44:05.493 DTC Client socket (3) | Creating socket. | 2022-01-13 16:44:05.493 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-01-13 16:44:05.493 DTC Client socket (3) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:44:05.493 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-SP. ID: 30 Service code: statscalc | 2022-01-13 16:44:05.497 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-SP. ID: 30 | 2022-01-13 16:44:05.497 SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NASDAQ. ID: 31 Service code: statscalc | 2022-01-13 16:44:05.502 SC DTC Data with Market Depth | Requesting security definition data for: ADR-NASDAQ. ID: 31 | 2022-01-13 16:44:05.502 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 32 Service code: statscalc | 2022-01-13 16:44:05.508 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 32 | 2022-01-13 16:44:05.508 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RBG22 | 2022-01-13 16:44:05.588 Trading Evaluator | Received security definition for symbol RBG22 | 2022-01-13 16:44:05.588 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:44:05.658 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:44:05.658 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:44:05.658 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:44:05.971 SC Data - All Services | Sending logon request message. | 2022-01-13 16:44:05.971 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol CLG22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol YMH22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol GCG22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol NQH22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6AH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol 6AH22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol ESH22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6CH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol 6CH22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol ZNH22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZFH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol ZFH22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NGG22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol NGG22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: TNH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol TNH22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol 6EH22 | 2022-01-13 16:44:06.595 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBH22 | 2022-01-13 16:44:06.595 Trading Evaluator | Received security definition for symbol ZBH22 | 2022-01-13 16:44:06.595 SC Data - All Services | Received logon response. | 2022-01-13 16:44:07.143 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:44:07.143 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:44:07.143 SC Data - All Services | Successfully connected. | 2022-01-13 16:44:07.143 SC Data - All Services | Trading is not supported. | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: 6MH22 -> 6MH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: 6SH22 -> 6SH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: BBH22 -> BBH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: BTCF22 -> BTCF22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: CLG22 -> CLG22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: GCG22 -> GCG22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: HOG22 -> HOG22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: NGG22 -> NGG22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: NKDH22 -> NKDH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: NQH22 -> NQH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: RBG22 -> RBG22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: RTYH22 -> RTYH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: SIH22 -> SIH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: TNH22 -> TNH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: YMH22 -> YMH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:44:07.143 SC Data - All Services | Restarting real-time data updates for symbol: ZTH22 -> ZTH22 | 2022-01-13 16:44:07.143 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol RTYH22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NKDH22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol NKDH22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZTH22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol ZTH22 | 2022-01-13 16:44:07.182 Symbol Error - FBTPH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol FBTPH22 | 2022-01-13 16:44:07.182 Symbol Error - FGBLH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol FGBLH22 | 2022-01-13 16:44:07.182 Symbol Error - FGBMH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol FGBMH22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBH22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol BBH22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: HOG22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol HOG22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: SIH22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol SIH22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BH22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol 6BH22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6JH22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol 6JH22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6SH22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol 6SH22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6MH22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol 6MH22 | 2022-01-13 16:44:07.182 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BTCF22 | 2022-01-13 16:44:07.182 Trading Evaluator | Received security definition for symbol BTCF22 | 2022-01-13 16:44:07.182 SC Data - All Services | Received security definition for symbol 6AH22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol 6BH22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol 6CH22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol 6EH22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol 6JH22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol 6MH22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol 6SH22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol BBH22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol BTCF22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol CLG22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol ESH22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol GCG22 | 2022-01-13 16:44:07.783 SC Data - All Services | Received security definition for symbol HOG22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol NGG22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol NKDH22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol NQH22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol RBG22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol RTYH22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol SIH22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol TNH22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol YMH22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol ZBH22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol ZFH22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol ZNH22 | 2022-01-13 16:44:07.839 SC Data - All Services | Received security definition for symbol ZTH22 | 2022-01-13 16:44:07.839 HD Request # 55 | Setting DTC encoding to Binary VLS | 2022-01-13 16:44:08.787 HD Request # 55 | Sending historical data logon request message. | 2022-01-13 16:44:08.787 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:44:08.850 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:44:08.850 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:44:08.850 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:44:09.229 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:44:09.229 HD Request # 55 | Requesting Intraday data. Start date-time: 2022-01-13 16:34:42. Record interval: 0. Symbol: ADV-NYSE | 2022-01-13 16:44:09.763 Requesting market depth updates for: 6AH22 if supported. | 2022-01-13 16:44:10.205 SC Data - All Services (Market Orders Data) | Connecting to the server ds22.sierracharts.com. Port 10060 | 2022-01-13 16:44:10.210 Requesting market depth updates for: 6BH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: 6CH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: 6EH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: 6JH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: CLG22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: ESH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: GCG22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: NGG22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: NQH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: RBG22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: TNH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: YMH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: ZBH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: ZFH22 if supported. | 2022-01-13 16:44:10.211 Requesting market depth updates for: ZNH22 if supported. | 2022-01-13 16:44:10.211 DTC Client socket (6) | Creating socket. | 2022-01-13 16:44:10.211 DTC Client socket (6) | New receive buffer size: 5242880 | 2022-01-13 16:44:10.211 DTC Client socket (6) | Connecting to IP: 208.185.224.129. | 2022-01-13 16:44:10.211 HD Request # 55 | Decompressing data. | 2022-01-13 16:44:12.928 HD Request # 55 | Receiving Intraday data for ADV-NYSE starting at 2022-01-13 16:34:42.000000 | 2022-01-13 16:44:12.928 Socket (4) | CloseSocket call. | 2022-01-13 16:44:14.648 Historical data download thread signaled to stop. | 2022-01-13 16:44:14.648 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:44:14.648 HD Request # 55 | Timestamp of first Intraday data file record written: 2022-01-13 16:34:43.000000 | 2022-01-13 16:44:14.648 HD Request # 55 | Received 566 Intraday data records from 2022-01-13 16:34:42.000000 to 2022-01-13 16:44:07.000000 (9.4 minutes) and wrote 565 records for ADV-NYSE | 2022-01-13 16:44:14.648 HD Request # 55 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:44:07.000000 | 2022-01-13 16:44:14.657 HD Request # 55 | Completion time: 9s | 2022-01-13 16:44:14.657 HD Request # 55 | Intraday data download complete for ADV-NYSE. Unique request ID: 129 | 2022-01-13 16:44:14.657 Removing historical data download ID 129. | 2022-01-13 16:44:14.657 Real-time Intraday chart data file updates started for ADV-NYSE | 2022-01-13 16:44:14.657 Intraday chart data file opened for ADV-NYSE | 2022-01-13 16:44:14.657 HD Request # 55 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:44:14.657 Triggering next historical data download in queue. | 2022-01-13 16:44:14.657 Initiating new historical data download for ADV-NYSE to get the latest data since the download was started while not connected to primary service. | 2022-01-13 16:44:14.657 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:44:14.657 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:44:14.657 Delaying start of download for ADV-NYSE | 2022-01-13 16:44:14.657 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:44:16.615 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:44:16.615 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:44:16.615 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:44:16.615 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:44:16.615 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:44:16.615 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:44:16.615 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:44:16.615 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:44:16.615 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:44:17.010 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:44:17.010 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:44:17.010 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:44:17.010 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:44:17.744 Socket (4) | Closed. | 2022-01-13 16:44:17.745 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:44:19.519 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:44:19.519 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:44:19.519 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:44:19.840 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:44:19.840 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 25. Service code: nymex | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLG22 -> CLG22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 15. Service code: comex | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: GCG22 -> GCG22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGG22 -> NGG22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 15. Service code: cme | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NQH22 -> NQH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: RBG22 -> RBG22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: TNH22 -> TNH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 20. Service code: cbot | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: YMH22 -> YMH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 200. Service code: cbot | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 1500. Service code: cbot | 2022-01-13 16:44:21.697 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:44:21.697 HD Request # 56 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 16:44:22.697 HD Request # 56 | Download start date-time: 2022-01-13 16:44:07.000000. File last date-time: 2022-01-13 16:44:07.000000 | 2022-01-13 16:44:22.697 HD Request # 56 | Using server: ds4.sierracharts.com port 10149 | 2022-01-13 16:44:22.698 Socket (4) | Creating socket. | 2022-01-13 16:44:22.698 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:44:22.698 Socket (4) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:44:22.698 SC Data - All Services | Clearing market depth for 6AH22 | 2022-01-13 16:44:22.980 SC Data - All Services | Clearing market depth for 6BH22 | 2022-01-13 16:44:22.980 SC Data - All Services | Clearing market depth for 6CH22 | 2022-01-13 16:44:22.980 SC Data - All Services | Clearing market depth for 6EH22 | 2022-01-13 16:44:22.980 SC Data - All Services | Clearing market depth for 6JH22 | 2022-01-13 16:44:22.980 SC Data - All Services | Clearing market depth for CLG22 | 2022-01-13 16:44:22.980 SC Data - All Services | Clearing market depth for ESH22 | 2022-01-13 16:44:22.980 SC Data - All Services | Clearing market depth for GCG22 | 2022-01-13 16:44:25.677 SC Data - All Services | Clearing market depth for NGG22 | 2022-01-13 16:44:25.677 SC Data - All Services | Clearing market depth for NQH22 | 2022-01-13 16:44:25.678 SC Data - All Services | Clearing market depth for RBG22 | 2022-01-13 16:44:25.678 SC Data - All Services | Clearing market depth for TNH22 | 2022-01-13 16:44:25.678 SC Data - All Services | Clearing market depth for YMH22 | 2022-01-13 16:44:25.678 SC Data - All Services | Clearing market depth for ZBH22 | 2022-01-13 16:44:25.678 SC Data - All Services | Clearing market depth for ZFH22 | 2022-01-13 16:44:25.678 SC Data - All Services | Clearing market depth for ZNH22 | 2022-01-13 16:44:25.678 HD Request # 56 | Setting DTC encoding to Binary VLS | 2022-01-13 16:44:32.314 HD Request # 56 | Sending historical data logon request message. | 2022-01-13 16:44:32.314 HD Request # 56 | Requesting Intraday data. Start date-time: 2022-01-13 16:44:07. Record interval: 0. Symbol: ADV-NYSE | 2022-01-13 16:44:33.148 HD Request # 56 | Decompressing data. | 2022-01-13 16:44:35.754 HD Request # 56 | Receiving Intraday data for ADV-NYSE starting at 2022-01-13 16:44:07.000000 | 2022-01-13 16:44:35.754 Socket (4) | CloseSocket call. | 2022-01-13 16:44:35.755 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:44:35.755 Historical data download thread signaled to stop. | 2022-01-13 16:44:35.755 HD Request # 56 | Timestamp of first Intraday data file record written: 2022-01-13 16:44:08.000000 | 2022-01-13 16:44:35.755 HD Request # 56 | Received 24 Intraday data records from 2022-01-13 16:44:07.000000 to 2022-01-13 16:44:30.000000 (23.0 seconds) and wrote 23 records for ADV-NYSE | 2022-01-13 16:44:35.755 HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:44:30.000000 | 2022-01-13 16:44:35.764 Added 19 Time and Sales records to Intraday data file for ADV-NYSE after download. | 2022-01-13 16:44:35.764 HD Request # 56 | Completion time: 13s | 2022-01-13 16:44:35.764 HD Request # 56 | Intraday data download complete for ADV-NYSE. Unique request ID: 150 | 2022-01-13 16:44:35.764 Removing historical data download ID 150. | 2022-01-13 16:44:35.764 Real-time Intraday chart data file updates started for ADV-NYSE | 2022-01-13 16:44:35.764 Intraday chart data file opened for ADV-NYSE | 2022-01-13 16:44:35.764 HD Request # 56 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:44:35.764 Triggering next historical data download in queue. | 2022-01-13 16:44:35.764 HD Request # 57 | Downloading Intraday chart data for TRIN-SP to the file TRIN-SP.scid. Service: statscalc | 2022-01-13 16:44:35.764 HD Request # 57 | Download start date-time: 2022-01-13 16:28:10.000000. File last date-time: 2022-01-13 16:28:10.960002 | 2022-01-13 16:44:35.765 HD Request # 57 | Using server: ds12.sierracharts.com port 10150 | 2022-01-13 16:44:35.765 Socket (7) | Creating socket. | 2022-01-13 16:44:35.765 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:44:35.766 Socket (7) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:44:35.766 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:44:36.054 Socket (4) | Closed. | 2022-01-13 16:44:36.054 Opened cached Intraday file: C:\SierraChart\Data\ADV-NYSE.scid. Thread ID: 11608 | 2022-01-13 16:44:37.514 HD Request # 57 | Setting DTC encoding to Binary VLS | 2022-01-13 16:44:48.407 HD Request # 57 | Sending historical data logon request message. | 2022-01-13 16:44:48.407 DTC Client socket (13) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:45:36.250 DTC Client socket (13) | Closed. | 2022-01-13 16:45:36.250 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:46:06.254 DTC Client socket (1) | Closed. | 2022-01-13 16:46:06.254 DTC Client socket (10) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:46:06.254 DTC Client socket (10) | Closed. | 2022-01-13 16:46:06.254 DTC Client socket (13) | Deleting network socket now after delay. | 2022-01-13 16:46:06.254 DTC Client socket (14) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:46:06.254 DTC Client socket (14) | Closed. | 2022-01-13 16:46:06.254 HD Request # 57 | Error downloading historical Intraday data for TRIN-SP. The download timed out. | 2022-01-13 16:46:19.592 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:46:19.593 Triggering next historical data download in queue. | 2022-01-13 16:46:19.593 Historical data download thread signaled to stop. | 2022-01-13 16:46:19.593 Socket (7) | CloseSocket call. | 2022-01-13 16:46:19.593 HD Request # 57 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for TRIN-SP | 2022-01-13 16:46:19.593 Socket (7) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:46:19.593 HD Request # 57 | Completion time: 1m 44s | 2022-01-13 16:46:19.593 HD Request # 58 | Downloading Intraday chart data for TRIN-SP to the file TRIN-SP.scid. Service: statscalc | 2022-01-13 16:46:19.593 HD Request # 58 | Download start date-time: 2022-01-13 16:28:10.000000. File last date-time: 2022-01-13 16:28:10.960002 | 2022-01-13 16:46:19.594 HD Request # 58 | Using server: ds13-3.sierracharts.com port 10149 | 2022-01-13 16:46:19.594 Socket (4) | Creating socket. | 2022-01-13 16:46:19.594 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:46:19.595 Socket (4) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:46:19.595 HD Request # 58 | Setting DTC encoding to Binary VLS | 2022-01-13 16:46:20.296 HD Request # 58 | Sending historical data logon request message. | 2022-01-13 16:46:20.296 HD Request # 58 | Requesting Intraday data. Start date-time: 2022-01-13 16:28:10. Record interval: 0. Symbol: TRIN-SP | 2022-01-13 16:46:21.312 HD Request # 58 | Decompressing data. | 2022-01-13 16:46:21.685 HD Request # 58 | Receiving Intraday data for TRIN-SP starting at 2022-01-13 16:28:10.000000 | 2022-01-13 16:46:22.552 Socket (4) | CloseSocket call. | 2022-01-13 16:46:24.002 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:46:24.002 Historical data download thread signaled to stop. | 2022-01-13 16:46:24.002 HD Request # 58 | Timestamp of first Intraday data file record written: 2022-01-13 16:28:11.000000 | 2022-01-13 16:46:24.002 HD Request # 58 | Received 1089 Intraday data records from 2022-01-13 16:28:10.000000 to 2022-01-13 16:46:18.000000 (18.1 minutes) and wrote 1088 records for TRIN-SP | 2022-01-13 16:46:24.002 HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:46:18.000000 | 2022-01-13 16:46:24.013 Added 36 Time and Sales records to Intraday data file for TRIN-SP after download. | 2022-01-13 16:46:24.013 HD Request # 58 | Completion time: 5s | 2022-01-13 16:46:24.013 HD Request # 58 | Intraday data download complete for TRIN-SP. Unique request ID: 130 | 2022-01-13 16:46:24.013 Removing historical data download ID 130. | 2022-01-13 16:46:24.013 Real-time Intraday chart data file updates started for TRIN-SP | 2022-01-13 16:46:24.013 Intraday chart data file opened for TRIN-SP | 2022-01-13 16:46:24.013 HD Request # 58 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:46:24.013 Triggering next historical data download in queue. | 2022-01-13 16:46:24.013 HD Request # 59 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc | 2022-01-13 16:46:24.014 HD Request # 59 | Download start date-time: 2022-01-13 16:36:07.000000. File last date-time: 2022-01-13 16:36:07.000000 | 2022-01-13 16:46:24.014 HD Request # 59 | Using server: ds4.sierracharts.com port 10150 | 2022-01-13 16:46:24.015 Socket (8) | Creating socket. | 2022-01-13 16:46:24.015 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:46:24.015 Socket (8) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:46:24.015 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:46:24.351 Socket (4) | Closed. | 2022-01-13 16:46:24.351 HD Request # 59 | Setting DTC encoding to Binary VLS | 2022-01-13 16:46:27.797 HD Request # 59 | Sending historical data logon request message. | 2022-01-13 16:46:27.797 Opened cached Intraday file: C:\SierraChart\Data\TRIN-SP.scid. Thread ID: 11608 | 2022-01-13 16:46:28.306 HD Request # 59 | Requesting Intraday data. Start date-time: 2022-01-13 16:36:07. Record interval: 0. Symbol: ADR-NASDAQ | 2022-01-13 16:46:28.775 HD Request # 59 | Decompressing data. | 2022-01-13 16:46:29.241 HD Request # 59 | Receiving Intraday data for ADR-NASDAQ starting at 2022-01-13 16:36:07.000000 | 2022-01-13 16:46:29.753 Socket (8) | CloseSocket call. | 2022-01-13 16:46:32.170 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:46:32.170 Historical data download thread signaled to stop. | 2022-01-13 16:46:32.170 HD Request # 59 | Timestamp of first Intraday data file record written: 2022-01-13 16:36:08.000000 | 2022-01-13 16:46:32.171 HD Request # 59 | Received 620 Intraday data records from 2022-01-13 16:36:07.000000 to 2022-01-13 16:46:26.000000 (10.3 minutes) and wrote 619 records for ADR-NASDAQ | 2022-01-13 16:46:32.171 HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:46:26.000000 | 2022-01-13 16:46:32.180 Added 27 Time and Sales records to Intraday data file for ADR-NASDAQ after download. | 2022-01-13 16:46:32.180 HD Request # 59 | Completion time: 8s | 2022-01-13 16:46:32.180 HD Request # 59 | Intraday data download complete for ADR-NASDAQ. Unique request ID: 131 | 2022-01-13 16:46:32.180 Removing historical data download ID 131. | 2022-01-13 16:46:32.180 Real-time Intraday chart data file updates started for ADR-NASDAQ | 2022-01-13 16:46:32.180 Intraday chart data file opened for ADR-NASDAQ | 2022-01-13 16:46:32.180 HD Request # 59 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:46:32.180 Triggering next historical data download in queue. | 2022-01-13 16:46:32.180 HD Request # 60 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2022-01-13 16:46:32.180 HD Request # 60 | Download start date-time: 2022-01-13 16:36:23.000000. File last date-time: 2022-01-13 16:36:23.000000 | 2022-01-13 16:46:32.181 HD Request # 60 | Using server: ds12.sierracharts.com port 10149 | 2022-01-13 16:46:32.181 Socket (4) | Creating socket. | 2022-01-13 16:46:32.181 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:46:32.181 Socket (4) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:46:32.181 Opened cached Intraday file: C:\SierraChart\Data\ADR-NASDAQ.scid. Thread ID: 11608 | 2022-01-13 16:46:33.338 HD Request # 60 | Setting DTC encoding to Binary VLS | 2022-01-13 16:46:35.801 HD Request # 60 | Sending historical data logon request message. | 2022-01-13 16:46:35.801 DTC Client socket (1) | Deleting network socket now after delay. | 2022-01-13 16:46:36.259 DTC Client socket (10) | Deleting network socket now after delay. | 2022-01-13 16:46:36.259 DTC Client socket (14) | Deleting network socket now after delay. | 2022-01-13 16:46:36.259 HD Request # 60 | Requesting Intraday data. Start date-time: 2022-01-13 16:36:23. Record interval: 0. Symbol: TRIN-NYSE | 2022-01-13 16:46:36.647 HD Request # 60 | Decompressing data. | 2022-01-13 16:46:36.944 HD Request # 60 | Receiving Intraday data for TRIN-NYSE starting at 2022-01-13 16:36:23.000000 | 2022-01-13 16:46:37.246 Socket (4) | CloseSocket call. | 2022-01-13 16:46:37.248 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:46:37.248 Historical data download thread signaled to stop. | 2022-01-13 16:46:37.248 HD Request # 60 | Timestamp of first Intraday data file record written: 2022-01-13 16:36:24.000000 | 2022-01-13 16:46:37.248 HD Request # 60 | Received 611 Intraday data records from 2022-01-13 16:36:23.000000 to 2022-01-13 16:46:33.000000 (10.2 minutes) and wrote 610 records for TRIN-NYSE | 2022-01-13 16:46:37.249 HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:46:33.000000 | 2022-01-13 16:46:37.258 Added 27 Time and Sales records to Intraday data file for TRIN-NYSE after download. | 2022-01-13 16:46:37.258 HD Request # 60 | Completion time: 5s | 2022-01-13 16:46:37.258 HD Request # 60 | Intraday data download complete for TRIN-NYSE. Unique request ID: 132 | 2022-01-13 16:46:37.258 Removing historical data download ID 132. | 2022-01-13 16:46:37.258 Real-time Intraday chart data file updates started for TRIN-NYSE | 2022-01-13 16:46:37.258 Intraday chart data file opened for TRIN-NYSE | 2022-01-13 16:46:37.258 HD Request # 60 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:46:37.258 Triggering next historical data download in queue. | 2022-01-13 16:46:37.258 HD Request # 61 | Downloading Intraday chart data for 6AH22 to the file 6AH22.scid. Service: cme | 2022-01-13 16:46:37.258 HD Request # 61 | Download start date-time: 2022-01-13 16:42:13.000000. File last date-time: 2022-01-13 16:42:13.998001 | 2022-01-13 16:46:37.259 HD Request # 61 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:46:37.259 Socket (1) | Creating socket. | 2022-01-13 16:46:37.259 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:46:37.259 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:46:37.259 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:46:37.546 Socket (4) | Closed. | 2022-01-13 16:46:37.546 HD Request # 61 | Setting DTC encoding to Binary VLS | 2022-01-13 16:46:37.877 HD Request # 61 | Sending historical data logon request message. | 2022-01-13 16:46:37.877 Opened cached Intraday file: C:\SierraChart\Data\TRIN-NYSE.scid. Thread ID: 11608 | 2022-01-13 16:46:38.367 HD Request # 61 | Requesting Intraday data. Start date-time: 2022-01-13 16:42:13. Record interval: 0. Symbol: 6AH22 | 2022-01-13 16:46:38.633 HD Request # 61 | Decompressing data. | 2022-01-13 16:46:38.930 HD Request # 61 | Receiving Intraday data for 6AH22 starting at 2022-01-13 16:42:13.998000 | 2022-01-13 16:46:38.931 Socket (1) | CloseSocket call. | 2022-01-13 16:46:38.931 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:46:38.932 Historical data download thread signaled to stop. | 2022-01-13 16:46:38.932 HD Request # 61 | Timestamp of first Intraday data file record written: 2022-01-13 16:42:27.154000 | 2022-01-13 16:46:38.932 HD Request # 61 | Received 93 Intraday data records from 2022-01-13 16:42:13.998000 to 2022-01-13 16:46:23.501000 (4.2 minutes) and wrote 91 records for 6AH22 | 2022-01-13 16:46:38.932 HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:46:23.501000 | 2022-01-13 16:46:38.941 HD Request # 61 | Completion time: 1s | 2022-01-13 16:46:38.941 HD Request # 61 | Intraday data download complete for 6AH22. Unique request ID: 134 | 2022-01-13 16:46:38.941 Removing historical data download ID 134. | 2022-01-13 16:46:38.941 Real-time Intraday chart data file updates started for 6AH22 | 2022-01-13 16:46:38.941 Intraday chart data file opened for 6AH22 | 2022-01-13 16:46:38.941 HD Request # 61 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:46:38.941 Triggering next historical data download in queue. | 2022-01-13 16:46:38.941 HD Request # 62 | Downloading Intraday chart data for 6CH22 to the file 6CH22.scid. Service: cme | 2022-01-13 16:46:38.941 HD Request # 62 | Download start date-time: 2022-01-13 16:42:08.000000. File last date-time: 2022-01-13 16:42:08.156000 | 2022-01-13 16:46:38.942 HD Request # 62 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:46:38.942 Socket (4) | Creating socket. | 2022-01-13 16:46:38.942 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:46:38.942 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:46:38.942 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:46:39.234 Socket (1) | Closed. | 2022-01-13 16:46:39.234 HD Request # 62 | Setting DTC encoding to Binary VLS | 2022-01-13 16:46:39.576 HD Request # 62 | Sending historical data logon request message. | 2022-01-13 16:46:39.576 HD Request # 62 | Requesting Intraday data. Start date-time: 2022-01-13 16:42:08. Record interval: 0. Symbol: 6CH22 | 2022-01-13 16:46:40.334 HD Request # 62 | Decompressing data. | 2022-01-13 16:46:41.342 HD Request # 62 | Receiving Intraday data for 6CH22 starting at 2022-01-13 16:42:08.156000 | 2022-01-13 16:46:41.342 Socket (4) | CloseSocket call. | 2022-01-13 16:46:41.343 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:46:41.343 Historical data download thread signaled to stop. | 2022-01-13 16:46:41.401 HD Request # 62 | Timestamp of first Intraday data file record written: 2022-01-13 16:42:27.153000 | 2022-01-13 16:46:41.401 HD Request # 62 | Received 177 Intraday data records from 2022-01-13 16:42:08.156000 to 2022-01-13 16:46:32.197000 (4.4 minutes) and wrote 176 records for 6CH22 | 2022-01-13 16:46:41.401 HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:46:32.197000 | 2022-01-13 16:46:41.410 HD Request # 62 | Completion time: 3s | 2022-01-13 16:46:41.410 HD Request # 62 | Intraday data download complete for 6CH22. Unique request ID: 135 | 2022-01-13 16:46:41.410 Removing historical data download ID 135. | 2022-01-13 16:46:41.410 Real-time Intraday chart data file updates started for 6CH22 | 2022-01-13 16:46:41.410 Intraday chart data file opened for 6CH22 | 2022-01-13 16:46:41.410 HD Request # 62 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:46:41.410 Triggering next historical data download in queue. | 2022-01-13 16:46:41.410 HD Request # 63 | Downloading Intraday chart data for 6JH22 to the file 6JH22.scid. Service: cme | 2022-01-13 16:46:41.411 HD Request # 63 | Download start date-time: 2022-01-13 16:41:45.000000. File last date-time: 2022-01-13 16:41:45.334000 | 2022-01-13 16:46:41.411 HD Request # 63 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:46:41.412 Socket (1) | Creating socket. | 2022-01-13 16:46:41.412 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:46:41.412 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:46:41.412 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:46:41.922 Socket (8) | Closed. | 2022-01-13 16:46:41.922 HD Request # 63 | Setting DTC encoding to Binary VLS | 2022-01-13 16:46:42.018 HD Request # 63 | Sending historical data logon request message. | 2022-01-13 16:46:42.018 HD Request # 63 | Requesting Intraday data. Start date-time: 2022-01-13 16:41:45. Record interval: 0. Symbol: 6JH22 | 2022-01-13 16:46:42.317 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:46:42.357 Socket (4) | Closed. | 2022-01-13 16:46:42.357 HD Request # 63 | Decompressing data. | 2022-01-13 16:46:42.617 HD Request # 63 | Receiving Intraday data for 6JH22 starting at 2022-01-13 16:41:45.007000 | 2022-01-13 16:46:42.618 Socket (1) | CloseSocket call. | 2022-01-13 16:46:42.620 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:46:42.620 Historical data download thread signaled to stop. | 2022-01-13 16:46:42.620 HD Request # 63 | Timestamp of first Intraday data file record written: 2022-01-13 16:41:47.512000 | 2022-01-13 16:46:42.620 HD Request # 63 | Received 236 Intraday data records from 2022-01-13 16:41:45.007000 to 2022-01-13 16:46:20.675002 (4.6 minutes) and wrote 211 records for 6JH22 | 2022-01-13 16:46:42.621 HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:46:20.675002 | 2022-01-13 16:46:42.630 HD Request # 63 | Completion time: 1s | 2022-01-13 16:46:42.630 HD Request # 63 | Intraday data download complete for 6JH22. Unique request ID: 136 | 2022-01-13 16:46:42.630 Removing historical data download ID 136. | 2022-01-13 16:46:42.630 Real-time Intraday chart data file updates started for 6JH22 | 2022-01-13 16:46:42.630 Intraday chart data file opened for 6JH22 | 2022-01-13 16:46:42.630 HD Request # 63 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:46:42.630 Triggering next historical data download in queue. | 2022-01-13 16:46:42.630 HD Request # 64 | Downloading Intraday chart data for CLG22 to the file CLG22.scid. Service: nymex | 2022-01-13 16:46:42.631 HD Request # 64 | Download start date-time: 2022-01-13 16:41:00.000000. File last date-time: 2022-01-13 16:41:00.008000 | 2022-01-13 16:46:42.631 HD Request # 64 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:46:42.631 Socket (4) | Creating socket. | 2022-01-13 16:46:42.632 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:46:42.632 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:46:42.632 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:46:43.528 Socket (1) | Closed. | 2022-01-13 16:46:43.528 Socket (7) | Write has completed. Shutdown being performed. | 2022-01-13 16:46:45.741 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:46:45.741 Socket (7) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-13 16:46:45.741 * Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:46:45.741 Socket (7) | Closed. | 2022-01-13 16:46:45.741 HD Request # 64 | Setting DTC encoding to Binary VLS | 2022-01-13 16:46:52.275 HD Request # 64 | Sending historical data logon request message. | 2022-01-13 16:46:52.275 HD Request # 64 | Requesting Intraday data. Start date-time: 2022-01-13 16:41:00. Record interval: 0. Symbol: CLG22 | 2022-01-13 16:46:52.571 Opened cached Intraday file: C:\SierraChart\Data\6JH22.scid. Thread ID: 11608 | 2022-01-13 16:46:53.459 HD Request # 64 | Decompressing data. | 2022-01-13 16:46:53.680 HD Request # 64 | Receiving Intraday data for CLG22 starting at 2022-01-13 16:41:00.008000 | 2022-01-13 16:46:53.681 Socket (4) | CloseSocket call. | 2022-01-13 16:46:53.981 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:46:53.981 Historical data download thread signaled to stop. | 2022-01-13 16:46:53.981 HD Request # 64 | Timestamp of first Intraday data file record written: 2022-01-13 16:41:01.966000 | 2022-01-13 16:46:53.981 HD Request # 64 | Received 2244 Intraday data records from 2022-01-13 16:41:00.008000 to 2022-01-13 16:46:47.089005 (5.8 minutes) and wrote 2243 records for CLG22 | 2022-01-13 16:46:53.981 HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:46:47.089005 | 2022-01-13 16:46:53.989 HD Request # 64 | Completion time: 11s | 2022-01-13 16:46:53.989 HD Request # 64 | Intraday data download complete for CLG22. Unique request ID: 137 | 2022-01-13 16:46:53.989 Removing historical data download ID 137. | 2022-01-13 16:46:53.989 Real-time Intraday chart data file updates started for CLG22 | 2022-01-13 16:46:53.989 Intraday chart data file opened for CLG22 | 2022-01-13 16:46:53.989 HD Request # 64 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:46:53.989 Triggering next historical data download in queue. | 2022-01-13 16:46:53.989 HD Request # 65 | Downloading Intraday chart data for ESH22 to the file ESH22.scid. Service: cme | 2022-01-13 16:46:53.989 HD Request # 65 | Download start date-time: 2022-01-13 16:41:47.000000. File last date-time: 2022-01-13 16:41:47.202010 | 2022-01-13 16:46:53.990 HD Request # 65 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:46:53.990 Socket (1) | Creating socket. | 2022-01-13 16:46:53.990 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:46:53.990 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:46:53.990 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:46:54.282 Socket (4) | Closed. | 2022-01-13 16:46:54.282 HD Request # 65 | Setting DTC encoding to Binary VLS | 2022-01-13 16:46:55.206 HD Request # 65 | Sending historical data logon request message. | 2022-01-13 16:46:55.206 HD Request # 65 | Requesting Intraday data. Start date-time: 2022-01-13 16:41:47. Record interval: 0. Symbol: ESH22 | 2022-01-13 16:46:55.509 HD Request # 65 | Decompressing data. | 2022-01-13 16:46:55.801 HD Request # 65 | Receiving Intraday data for ESH22 starting at 2022-01-13 16:41:47.201000 | 2022-01-13 16:46:56.670 Opened cached Intraday file: C:\SierraChart\Data\CLG22.scid. Thread ID: 11608 | 2022-01-13 16:47:03.521 Socket (1) | CloseSocket call. | 2022-01-13 16:47:03.799 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:47:03.799 Historical data download thread signaled to stop. | 2022-01-13 16:47:03.801 HD Request # 65 | Timestamp of first Intraday data file record written: 2022-01-13 16:41:48.049000 | 2022-01-13 16:47:03.801 HD Request # 65 | Received 5708 Intraday data records from 2022-01-13 16:41:47.201000 to 2022-01-13 16:46:50.789006 (5.1 minutes) and wrote 5693 records for ESH22 | 2022-01-13 16:47:03.802 HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:46:50.789006 | 2022-01-13 16:47:03.810 HD Request # 65 | Completion time: 10s | 2022-01-13 16:47:03.810 HD Request # 65 | Intraday data download complete for ESH22. Unique request ID: 138 | 2022-01-13 16:47:03.810 Removing historical data download ID 138. | 2022-01-13 16:47:03.810 Real-time Intraday chart data file updates started for ESH22 | 2022-01-13 16:47:03.810 Intraday chart data file opened for ESH22 | 2022-01-13 16:47:03.810 HD Request # 65 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:47:03.810 Triggering next historical data download in queue. | 2022-01-13 16:47:03.810 HD Request # 66 | Downloading Intraday chart data for GCG22 to the file GCG22.scid. Service: comex | 2022-01-13 16:47:03.811 HD Request # 66 | Download start date-time: 2022-01-13 16:42:18.000000. File last date-time: 2022-01-13 16:42:18.277002 | 2022-01-13 16:47:03.811 HD Request # 66 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:47:03.811 Socket (4) | Creating socket. | 2022-01-13 16:47:03.811 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:47:03.812 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:47:03.812 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:47:04.101 Socket (1) | Closed. | 2022-01-13 16:47:04.101 HD Request # 66 | Setting DTC encoding to Binary VLS | 2022-01-13 16:47:07.421 HD Request # 66 | Sending historical data logon request message. | 2022-01-13 16:47:07.421 Opened cached Intraday file: C:\SierraChart\Data\ESH22.scid. Thread ID: 11608 | 2022-01-13 16:47:08.563 HD Request # 66 | Requesting Intraday data. Start date-time: 2022-01-13 16:42:18. Record interval: 0. Symbol: GCG22 | 2022-01-13 16:47:08.692 HD Request # 66 | Decompressing data. | 2022-01-13 16:47:08.980 HD Request # 66 | Receiving Intraday data for GCG22 starting at 2022-01-13 16:42:18.277000 | 2022-01-13 16:47:09.489 Socket (4) | CloseSocket call. | 2022-01-13 16:47:11.622 Historical data download thread signaled to stop. | 2022-01-13 16:47:11.622 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:47:11.622 HD Request # 66 | Timestamp of first Intraday data file record written: 2022-01-13 16:42:22.501000 | 2022-01-13 16:47:11.622 HD Request # 66 | Received 411 Intraday data records from 2022-01-13 16:42:18.277000 to 2022-01-13 16:47:03.590000 (4.8 minutes) and wrote 408 records for GCG22 | 2022-01-13 16:47:11.622 HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:47:03.590000 | 2022-01-13 16:47:11.633 HD Request # 66 | Completion time: 8s | 2022-01-13 16:47:11.633 HD Request # 66 | Intraday data download complete for GCG22. Unique request ID: 139 | 2022-01-13 16:47:11.633 Removing historical data download ID 139. | 2022-01-13 16:47:11.633 Real-time Intraday chart data file updates started for GCG22 | 2022-01-13 16:47:11.633 Intraday chart data file opened for GCG22 | 2022-01-13 16:47:11.633 HD Request # 66 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:47:11.633 Triggering next historical data download in queue. | 2022-01-13 16:47:11.633 HD Request # 67 | Downloading Intraday chart data for NGG22 to the file NGG22.scid. Service: nymex | 2022-01-13 16:47:11.633 HD Request # 67 | Download start date-time: 2022-01-13 16:42:42.000000. File last date-time: 2022-01-13 16:42:42.224000 | 2022-01-13 16:47:11.634 HD Request # 67 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:47:11.634 Socket (1) | Creating socket. | 2022-01-13 16:47:11.634 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:47:11.634 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:47:11.634 HD Request # 67 | Setting DTC encoding to Binary VLS | 2022-01-13 16:47:12.245 HD Request # 67 | Sending historical data logon request message. | 2022-01-13 16:47:12.245 HD Request # 67 | Requesting Intraday data. Start date-time: 2022-01-13 16:42:42. Record interval: 0. Symbol: NGG22 | 2022-01-13 16:47:13.794 HD Request # 67 | Decompressing data. | 2022-01-13 16:47:14.095 HD Request # 67 | Receiving Intraday data for NGG22 starting at 2022-01-13 16:42:42.215000 | 2022-01-13 16:47:14.909 Socket (1) | CloseSocket call. | 2022-01-13 16:47:16.789 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:47:16.789 Historical data download thread signaled to stop. | 2022-01-13 16:47:16.789 HD Request # 67 | Timestamp of first Intraday data file record written: 2022-01-13 16:42:43.779000 | 2022-01-13 16:47:16.790 HD Request # 67 | Received 885 Intraday data records from 2022-01-13 16:42:42.215000 to 2022-01-13 16:47:10.020000 (4.5 minutes) and wrote 882 records for NGG22 | 2022-01-13 16:47:16.790 HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:47:10.020000 | 2022-01-13 16:47:16.799 HD Request # 67 | Completion time: 5s | 2022-01-13 16:47:16.799 HD Request # 67 | Intraday data download complete for NGG22. Unique request ID: 140 | 2022-01-13 16:47:16.799 Removing historical data download ID 140. | 2022-01-13 16:47:16.799 Real-time Intraday chart data file updates started for NGG22 | 2022-01-13 16:47:16.799 Intraday chart data file opened for NGG22 | 2022-01-13 16:47:16.799 HD Request # 67 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:47:16.799 Triggering next historical data download in queue. | 2022-01-13 16:47:16.799 HD Request # 68 | Downloading Intraday chart data for NQH22 to the file NQH22.scid. Service: cme | 2022-01-13 16:47:16.799 HD Request # 68 | Download start date-time: 2022-01-13 16:41:00.000000. File last date-time: 2022-01-13 16:41:00.640000 | 2022-01-13 16:47:16.800 HD Request # 68 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:47:16.800 Socket (7) | Creating socket. | 2022-01-13 16:47:16.800 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:47:16.800 Socket (7) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:47:16.800 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:47:17.089 Socket (1) | Closed. | 2022-01-13 16:47:17.089 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:47:17.312 Socket (4) | Closed. | 2022-01-13 16:47:17.312 HD Request # 68 | Setting DTC encoding to Binary VLS | 2022-01-13 16:47:23.434 HD Request # 68 | Sending historical data logon request message. | 2022-01-13 16:47:23.435 HD Request # 68 | Requesting Intraday data. Start date-time: 2022-01-13 16:41:00. Record interval: 0. Symbol: NQH22 | 2022-01-13 16:47:24.201 HD Request # 68 | Decompressing data. | 2022-01-13 16:47:24.496 HD Request # 68 | Receiving Intraday data for NQH22 starting at 2022-01-13 16:41:00.006000 | 2022-01-13 16:47:25.626 Socket (7) | CloseSocket call. | 2022-01-13 16:47:38.138 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:47:38.138 Historical data download thread signaled to stop. | 2022-01-13 16:47:38.138 HD Request # 68 | Timestamp of first Intraday data file record written: 2022-01-13 16:41:00.996000 | 2022-01-13 16:47:38.139 HD Request # 68 | Received 5241 Intraday data records from 2022-01-13 16:41:00.006000 to 2022-01-13 16:47:22.673000 (6.4 minutes) and wrote 5235 records for NQH22 | 2022-01-13 16:47:38.139 HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:47:22.673000 | 2022-01-13 16:47:38.149 HD Request # 68 | Completion time: 22s | 2022-01-13 16:47:38.149 HD Request # 68 | Intraday data download complete for NQH22. Unique request ID: 141 | 2022-01-13 16:47:38.149 Removing historical data download ID 141. | 2022-01-13 16:47:38.149 Real-time Intraday chart data file updates started for NQH22 | 2022-01-13 16:47:38.149 Intraday chart data file opened for NQH22 | 2022-01-13 16:47:38.149 HD Request # 68 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:47:38.149 Triggering next historical data download in queue. | 2022-01-13 16:47:38.149 HD Request # 69 | Downloading Intraday chart data for RBG22 to the file RBG22.scid. Service: nymex | 2022-01-13 16:47:38.149 HD Request # 69 | Download start date-time: 2022-01-13 16:41:26.000000. File last date-time: 2022-01-13 16:41:26.186001 | 2022-01-13 16:47:38.150 HD Request # 69 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:47:38.150 Socket (1) | Creating socket. | 2022-01-13 16:47:38.150 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:47:38.151 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:47:38.151 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:47:38.455 Socket (7) | Closed. | 2022-01-13 16:47:38.455 HD Request # 69 | Setting DTC encoding to Binary VLS | 2022-01-13 16:47:38.773 HD Request # 69 | Sending historical data logon request message. | 2022-01-13 16:47:38.773 HD Request # 69 | Requesting Intraday data. Start date-time: 2022-01-13 16:41:26. Record interval: 0. Symbol: RBG22 | 2022-01-13 16:47:39.876 HD Request # 69 | Decompressing data. | 2022-01-13 16:47:40.171 HD Request # 69 | Receiving Intraday data for RBG22 starting at 2022-01-13 16:41:26.155000 | 2022-01-13 16:47:40.172 Socket (1) | CloseSocket call. | 2022-01-13 16:47:40.471 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:47:40.471 Historical data download thread signaled to stop. | 2022-01-13 16:47:40.471 HD Request # 69 | Timestamp of first Intraday data file record written: 2022-01-13 16:41:37.389000 | 2022-01-13 16:47:40.471 HD Request # 69 | Received 254 Intraday data records from 2022-01-13 16:41:26.155000 to 2022-01-13 16:47:37.050000 (6.2 minutes) and wrote 243 records for RBG22 | 2022-01-13 16:47:40.472 HD Request # 69 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:47:37.050000 | 2022-01-13 16:47:40.482 HD Request # 69 | Completion time: 2s | 2022-01-13 16:47:40.483 HD Request # 69 | Intraday data download complete for RBG22. Unique request ID: 142 | 2022-01-13 16:47:40.483 Removing historical data download ID 142. | 2022-01-13 16:47:40.483 Real-time Intraday chart data file updates started for RBG22 | 2022-01-13 16:47:40.483 Intraday chart data file opened for RBG22 | 2022-01-13 16:47:40.483 HD Request # 69 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:47:40.483 Triggering next historical data download in queue. | 2022-01-13 16:47:40.483 HD Request # 70 | Downloading Intraday chart data for TNH22 to the file TNH22.scid. Service: cbot | 2022-01-13 16:47:40.483 HD Request # 70 | Download start date-time: 2022-01-13 16:42:44.000000. File last date-time: 2022-01-13 16:42:44.652014 | 2022-01-13 16:47:40.484 HD Request # 70 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:47:40.484 Socket (4) | Creating socket. | 2022-01-13 16:47:40.484 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:47:40.484 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:47:40.484 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:47:40.780 Socket (1) | Closed. | 2022-01-13 16:47:40.780 HD Request # 70 | Setting DTC encoding to Binary VLS | 2022-01-13 16:47:41.099 HD Request # 70 | Sending historical data logon request message. | 2022-01-13 16:47:41.099 HD Request # 70 | Requesting Intraday data. Start date-time: 2022-01-13 16:42:44. Record interval: 0. Symbol: TNH22 | 2022-01-13 16:47:41.413 HD Request # 70 | Decompressing data. | 2022-01-13 16:47:42.424 HD Request # 70 | Receiving Intraday data for TNH22 starting at 2022-01-13 16:42:44.652000 | 2022-01-13 16:47:42.425 Socket (4) | CloseSocket call. | 2022-01-13 16:47:44.794 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:47:44.794 Historical data download thread signaled to stop. | 2022-01-13 16:47:44.798 HD Request # 70 | Timestamp of first Intraday data file record written: 2022-01-13 16:43:02.088000 | 2022-01-13 16:47:44.798 HD Request # 70 | Received 451 Intraday data records from 2022-01-13 16:42:44.652000 to 2022-01-13 16:47:36.429002 (4.9 minutes) and wrote 436 records for TNH22 | 2022-01-13 16:47:44.798 HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:47:36.429002 | 2022-01-13 16:47:44.808 HD Request # 70 | Completion time: 4s | 2022-01-13 16:47:44.808 HD Request # 70 | Intraday data download complete for TNH22. Unique request ID: 143 | 2022-01-13 16:47:44.808 Removing historical data download ID 143. | 2022-01-13 16:47:44.808 Real-time Intraday chart data file updates started for TNH22 | 2022-01-13 16:47:44.808 Intraday chart data file opened for TNH22 | 2022-01-13 16:47:44.808 HD Request # 70 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:47:44.808 Triggering next historical data download in queue. | 2022-01-13 16:47:44.808 HD Request # 71 | Downloading Intraday chart data for YMH22 to the file YMH22.scid. Service: cbot | 2022-01-13 16:47:44.809 HD Request # 71 | Download start date-time: 2022-01-13 16:42:02.000000. File last date-time: 2022-01-13 16:42:02.955001 | 2022-01-13 16:47:44.809 HD Request # 71 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:47:44.809 Socket (1) | Creating socket. | 2022-01-13 16:47:44.810 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:47:44.810 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:47:44.810 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:47:45.087 Socket (4) | Closed. | 2022-01-13 16:47:45.087 HD Request # 71 | Setting DTC encoding to Binary VLS | 2022-01-13 16:47:45.433 HD Request # 71 | Sending historical data logon request message. | 2022-01-13 16:47:45.433 HD Request # 71 | Requesting Intraday data. Start date-time: 2022-01-13 16:42:02. Record interval: 0. Symbol: YMH22 | 2022-01-13 16:47:47.009 HD Request # 71 | Decompressing data. | 2022-01-13 16:47:47.314 HD Request # 71 | Receiving Intraday data for YMH22 starting at 2022-01-13 16:42:02.276000 | 2022-01-13 16:47:48.920 Socket (1) | CloseSocket call. | 2022-01-13 16:47:51.158 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:47:51.158 Historical data download thread signaled to stop. | 2022-01-13 16:47:51.166 HD Request # 71 | Timestamp of first Intraday data file record written: 2022-01-13 16:42:03.200000 | 2022-01-13 16:47:51.166 HD Request # 71 | Received 1180 Intraday data records from 2022-01-13 16:42:02.276000 to 2022-01-13 16:47:44.352000 (5.7 minutes) and wrote 1176 records for YMH22 | 2022-01-13 16:47:51.167 HD Request # 71 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:47:44.352000 | 2022-01-13 16:47:51.176 HD Request # 71 | Completion time: 7s | 2022-01-13 16:47:51.176 HD Request # 71 | Intraday data download complete for YMH22. Unique request ID: 144 | 2022-01-13 16:47:51.176 Removing historical data download ID 144. | 2022-01-13 16:47:51.176 Real-time Intraday chart data file updates started for YMH22 | 2022-01-13 16:47:51.176 Intraday chart data file opened for YMH22 | 2022-01-13 16:47:51.176 HD Request # 71 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:47:51.176 Triggering next historical data download in queue. | 2022-01-13 16:47:51.176 HD Request # 72 | Downloading Intraday chart data for ZFH22 to the file ZFH22.scid. Service: cbot | 2022-01-13 16:47:51.176 HD Request # 72 | Download start date-time: 2022-01-13 16:42:21.000000. File last date-time: 2022-01-13 16:42:21.969000 | 2022-01-13 16:47:51.177 HD Request # 72 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:47:51.177 Socket (4) | Creating socket. | 2022-01-13 16:47:51.177 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:47:51.177 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:47:51.177 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:47:51.458 Socket (1) | Closed. | 2022-01-13 16:47:51.458 HD Request # 72 | Setting DTC encoding to Binary VLS | 2022-01-13 16:48:03.805 HD Request # 72 | Sending historical data logon request message. | 2022-01-13 16:48:03.805 HD Request # 72 | Requesting Intraday data. Start date-time: 2022-01-13 16:42:21. Record interval: 0. Symbol: ZFH22 | 2022-01-13 16:48:04.562 HD Request # 72 | Decompressing data. | 2022-01-13 16:48:04.867 SC Data - All Services | There has been no activity on the network socket for 59s. Will reconnect. | 2022-01-13 16:48:05.266 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 16:48:05.266 DTC Client socket (6) | CloseSocket call. | 2022-01-13 16:48:05.267 DTC Client socket (6) | Max send buffers used during socket life: 4 | 2022-01-13 16:48:05.267 DTC Client socket (6) | Max send buffer size during socket life: 1242 | 2022-01-13 16:48:05.267 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:48:05.267 WSACleanup called. | 2022-01-13 16:48:05.267 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:48:05.267 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 16:48:05.267 DTC Client socket (5) | CloseSocket call. | 2022-01-13 16:48:05.268 DTC Client socket (5) | Max send buffers used during socket life: 4 | 2022-01-13 16:48:05.268 DTC Client socket (5) | Max send buffer size during socket life: 1746 | 2022-01-13 16:48:05.268 SC Data - All Services | Disconnected from the server. | 2022-01-13 16:48:05.268 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 16:48:05.268 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:48:05.268 DTC Client socket (6) | Socket gracefully closed by remote side. | 2022-01-13 16:48:05.570 DTC Client socket (6) | Closed. | 2022-01-13 16:48:05.570 HD Request # 72 | Receiving Intraday data for ZFH22 starting at 2022-01-13 16:42:21.969000 | 2022-01-13 16:48:06.432 Socket (4) | CloseSocket call. | 2022-01-13 16:48:06.434 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:48:06.434 Historical data download thread signaled to stop. | 2022-01-13 16:48:06.434 HD Request # 72 | Timestamp of first Intraday data file record written: 2022-01-13 16:43:07.400000 | 2022-01-13 16:48:06.435 HD Request # 72 | Received 658 Intraday data records from 2022-01-13 16:42:21.969000 to 2022-01-13 16:47:50.187000 (5.5 minutes) and wrote 657 records for ZFH22 | 2022-01-13 16:48:06.435 HD Request # 72 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:47:50.187000 | 2022-01-13 16:48:06.444 HD Request # 72 | Completion time: 15s | 2022-01-13 16:48:06.445 HD Request # 72 | Intraday data download complete for ZFH22. Unique request ID: 145 | 2022-01-13 16:48:06.445 Removing historical data download ID 145. | 2022-01-13 16:48:06.445 Real-time Intraday chart data file updates started for ZFH22 | 2022-01-13 16:48:06.445 Intraday chart data file opened for ZFH22 | 2022-01-13 16:48:06.445 HD Request # 72 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:48:06.445 Triggering next historical data download in queue. | 2022-01-13 16:48:06.445 HD Request # 73 | Downloading Intraday chart data for ZNH22 to the file ZNH22.scid. Service: cbot | 2022-01-13 16:48:06.445 HD Request # 73 | Download start date-time: 2022-01-13 16:42:21.000000. File last date-time: 2022-01-13 16:42:21.108000 | 2022-01-13 16:48:06.445 HD Request # 73 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:48:06.446 Socket (1) | Creating socket. | 2022-01-13 16:48:06.446 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:48:06.446 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:48:06.446 SC Data - All Services | Connecting to the server ds6-2.sierracharts.com. Port 10048 | 2022-01-13 16:48:07.265 DTC Client socket (6) | Creating socket. | 2022-01-13 16:48:07.272 DTC Client socket (6) | New receive buffer size: 5242880 | 2022-01-13 16:48:07.272 DTC Client socket (6) | Connecting to IP: 51.195.180.15. | 2022-01-13 16:48:07.272 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:48:07.337 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:48:07.337 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:48:07.338 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:48:07.421 SC Data - All Services | Sending logon request message. | 2022-01-13 16:48:07.421 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:48:07.485 Socket (4) | Closed. | 2022-01-13 16:48:07.485 SC Data - All Services | Received logon response. | 2022-01-13 16:48:07.891 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:48:07.891 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:48:07.891 SC Data - All Services | Successfully connected. | 2022-01-13 16:48:07.891 SC Data - All Services | Trading is not supported. | 2022-01-13 16:48:07.891 SC Data - All Services (Market Orders Data) | Connecting to the server ds6-2.sierracharts.com. Port 10060 | 2022-01-13 16:48:07.897 Added historical Intraday data request for 6AH22 to the queue. | 2022-01-13 16:48:07.897 Intraday data recording state for symbol 6AH22 is set to download 'Pending'. | 2022-01-13 16:48:07.897 Triggering next historical data download in queue. | 2022-01-13 16:48:07.897 SC Data - All Services | Restarting real-time data updates for symbol: 6AH22 -> 6AH22. Market Depth data restarted. | 2022-01-13 16:48:07.897 SC Data - All Services | Restarting real-time data updates for symbol: 6BH22 -> 6BH22. Market Depth data restarted. | 2022-01-13 16:48:07.897 Added historical Intraday data request for 6CH22 to the queue. | 2022-01-13 16:48:07.897 Intraday data recording state for symbol 6CH22 is set to download 'Pending'. | 2022-01-13 16:48:07.897 SC Data - All Services | Restarting real-time data updates for symbol: 6CH22 -> 6CH22. Market Depth data restarted. | 2022-01-13 16:48:07.897 SC Data - All Services | Restarting real-time data updates for symbol: 6EH22 -> 6EH22. Market Depth data restarted. | 2022-01-13 16:48:07.897 DTC Client socket (4) | Creating socket. | 2022-01-13 16:48:07.897 Added historical Intraday data request for 6JH22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol 6JH22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: 6JH22 -> 6JH22. Market Depth data restarted. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: 6MH22 -> 6MH22 | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: 6SH22 -> 6SH22 | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: BBH22 -> BBH22 | 2022-01-13 16:48:07.898 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: BTCF22 -> BTCF22 | 2022-01-13 16:48:07.898 DTC Client socket (4) | Connecting to IP: 51.195.180.15. | 2022-01-13 16:48:07.898 Added historical Intraday data request for CLG22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol CLG22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: CLG22 -> CLG22. Market Depth data restarted. | 2022-01-13 16:48:07.898 Added historical Intraday data request for ESH22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol ESH22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22. Market Depth data restarted. | 2022-01-13 16:48:07.898 Added historical Intraday data request for GCG22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol GCG22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: GCG22 -> GCG22. Market Depth data restarted. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: HOG22 -> HOG22 | 2022-01-13 16:48:07.898 Added historical Intraday data request for NGG22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol NGG22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: NGG22 -> NGG22. Market Depth data restarted. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: NKDH22 -> NKDH22 | 2022-01-13 16:48:07.898 Added historical Intraday data request for NQH22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol NQH22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: NQH22 -> NQH22. Market Depth data restarted. | 2022-01-13 16:48:07.898 Added historical Intraday data request for RBG22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol RBG22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: RBG22 -> RBG22. Market Depth data restarted. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: RTYH22 -> RTYH22 | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: SIH22 -> SIH22 | 2022-01-13 16:48:07.898 Added historical Intraday data request for TNH22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol TNH22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: TNH22 -> TNH22. Market Depth data restarted. | 2022-01-13 16:48:07.898 Added historical Intraday data request for YMH22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol YMH22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: YMH22 -> YMH22. Market Depth data restarted. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: ZBH22 -> ZBH22. Market Depth data restarted. | 2022-01-13 16:48:07.898 Added historical Intraday data request for ZFH22 to the queue. | 2022-01-13 16:48:07.898 Intraday data recording state for symbol ZFH22 is set to download 'Pending'. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: ZFH22 -> ZFH22. Market Depth data restarted. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: ZNH22 -> ZNH22. Market Depth data restarted. | 2022-01-13 16:48:07.898 SC Data - All Services | Restarting real-time data updates for symbol: ZTH22 -> ZTH22 | 2022-01-13 16:48:07.898 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:48:07.989 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:48:07.989 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:48:07.989 SC Data - All Services | Clearing market depth for 6AH22 | 2022-01-13 16:48:07.989 SC Data - All Services | Clearing market depth for 6BH22 | 2022-01-13 16:48:07.989 SC Data - All Services | Clearing market depth for 6CH22 | 2022-01-13 16:48:07.989 SC Data - All Services | Received security definition for symbol 6AH22 | 2022-01-13 16:48:08.002 SC Data - All Services | Received security definition for symbol 6BH22 | 2022-01-13 16:48:08.002 SC Data - All Services | Received security definition for symbol 6CH22 | 2022-01-13 16:48:08.002 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:48:08.101 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:48:08.101 SC Data - All Services | Clearing market depth for 6EH22 | 2022-01-13 16:48:08.101 SC Data - All Services | Clearing market depth for 6JH22 | 2022-01-13 16:48:08.101 SC Data - All Services | Received security definition for symbol 6EH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol 6JH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for CLG22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol 6MH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol 6SH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol BBH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol BTCF22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol CLG22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for ESH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol ESH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for GCG22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol GCG22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for NGG22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol HOG22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol NGG22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for NQH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for RBG22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for TNH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for YMH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for ZBH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for ZFH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Clearing market depth for ZNH22 | 2022-01-13 16:48:08.102 SC Data - All Services | Received security definition for symbol NKDH22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol NQH22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol RBG22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol RTYH22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol SIH22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol TNH22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol YMH22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol ZBH22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol ZFH22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol ZNH22 | 2022-01-13 16:48:08.121 SC Data - All Services | Received security definition for symbol ZTH22 | 2022-01-13 16:48:08.121 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:48:08.639 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 25. Service code: nymex | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLG22 -> CLG22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 15. Service code: comex | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: GCG22 -> GCG22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGG22 -> NGG22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 15. Service code: cme | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NQH22 -> NQH22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: RBG22 -> RBG22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: TNH22 -> TNH22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 20. Service code: cbot | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: YMH22 -> YMH22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 200. Service code: cbot | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 1500. Service code: cbot | 2022-01-13 16:48:08.640 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:48:08.640 HD Request # 73 | Setting DTC encoding to Binary VLS | 2022-01-13 16:48:10.056 HD Request # 73 | Sending historical data logon request message. | 2022-01-13 16:48:10.056 HD Request # 73 | Requesting Intraday data. Start date-time: 2022-01-13 16:42:21. Record interval: 0. Symbol: ZNH22 | 2022-01-13 16:48:11.272 HD Request # 73 | Decompressing data. | 2022-01-13 16:48:50.725 HD Request # 73 | Receiving Intraday data for ZNH22 starting at 2022-01-13 16:42:21.108000 | 2022-01-13 16:48:50.726 Socket (1) | CloseSocket call. | 2022-01-13 16:48:51.357 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:48:51.357 Historical data download thread signaled to stop. | 2022-01-13 16:48:51.381 HD Request # 73 | Timestamp of first Intraday data file record written: 2022-01-13 16:42:29.026000 | 2022-01-13 16:48:51.381 HD Request # 73 | Received 914 Intraday data records from 2022-01-13 16:42:21.108000 to 2022-01-13 16:48:06.009001 (5.7 minutes) and wrote 913 records for ZNH22 | 2022-01-13 16:48:51.381 HD Request # 73 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:48:06.009001 | 2022-01-13 16:48:51.389 Added 103 Time and Sales records to Intraday data file for ZNH22 after download. | 2022-01-13 16:48:51.389 HD Request # 73 | Completion time: 45s | 2022-01-13 16:48:51.390 HD Request # 73 | Intraday data download complete for ZNH22. Unique request ID: 146 | 2022-01-13 16:48:51.390 Removing historical data download ID 146. | 2022-01-13 16:48:51.390 Real-time Intraday chart data file updates started for ZNH22 | 2022-01-13 16:48:51.390 Intraday chart data file opened for ZNH22 | 2022-01-13 16:48:51.390 HD Request # 73 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:48:51.390 Triggering next historical data download in queue. | 2022-01-13 16:48:51.390 HD Request # 74 | Downloading Intraday chart data for 6EH22 to the file 6EH22.scid. Service: cme | 2022-01-13 16:48:51.390 HD Request # 74 | Download start date-time: 2022-01-13 16:43:43.000000. File last date-time: 2022-01-13 16:43:43.900002 | 2022-01-13 16:48:51.391 HD Request # 74 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:48:51.391 Socket (7) | Creating socket. | 2022-01-13 16:48:51.391 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:48:51.391 Socket (7) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:48:51.391 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:48:52.316 Socket (1) | Closed. | 2022-01-13 16:48:52.316 HD Request # 74 | Setting DTC encoding to Binary VLS | 2022-01-13 16:48:52.898 HD Request # 74 | Sending historical data logon request message. | 2022-01-13 16:48:52.898 Opened cached Intraday file: C:\SierraChart\Data\ZNH22.scid. Thread ID: 11608 | 2022-01-13 16:48:54.405 HD Request # 74 | Requesting Intraday data. Start date-time: 2022-01-13 16:43:43. Record interval: 0. Symbol: 6EH22 | 2022-01-13 16:48:56.236 HD Request # 74 | Decompressing data. | 2022-01-13 16:48:56.530 HD Request # 74 | Receiving Intraday data for 6EH22 starting at 2022-01-13 16:43:43.900000 | 2022-01-13 16:48:57.036 Socket (7) | CloseSocket call. | 2022-01-13 16:49:01.891 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:49:01.891 Historical data download thread signaled to stop. | 2022-01-13 16:49:01.933 HD Request # 74 | Timestamp of first Intraday data file record written: 2022-01-13 16:43:48.209000 | 2022-01-13 16:49:01.933 HD Request # 74 | Received 486 Intraday data records from 2022-01-13 16:43:43.900000 to 2022-01-13 16:48:50.969000 (5.1 minutes) and wrote 483 records for 6EH22 | 2022-01-13 16:49:01.933 HD Request # 74 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:48:50.969000 | 2022-01-13 16:49:01.941 Added 5 Time and Sales records to Intraday data file for 6EH22 after download. | 2022-01-13 16:49:01.941 HD Request # 74 | Completion time: 10s | 2022-01-13 16:49:01.941 HD Request # 74 | Intraday data download complete for 6EH22. Unique request ID: 147 | 2022-01-13 16:49:01.941 Removing historical data download ID 147. | 2022-01-13 16:49:01.941 Real-time Intraday chart data file updates started for 6EH22 | 2022-01-13 16:49:01.941 Intraday chart data file opened for 6EH22 | 2022-01-13 16:49:01.941 HD Request # 74 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:49:01.941 Triggering next historical data download in queue. | 2022-01-13 16:49:01.941 HD Request # 75 | Downloading Intraday chart data for ZBH22 to the file ZBH22.scid. Service: cbot | 2022-01-13 16:49:01.941 HD Request # 75 | Download start date-time: 2022-01-13 16:43:33.000000. File last date-time: 2022-01-13 16:43:33.958004 | 2022-01-13 16:49:01.942 HD Request # 75 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:49:01.942 Socket (1) | Creating socket. | 2022-01-13 16:49:01.942 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:49:01.942 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:49:01.942 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:49:02.182 Socket (7) | Closed. | 2022-01-13 16:49:02.182 Opened cached Intraday file: C:\SierraChart\Data\6EH22.scid. Thread ID: 11608 | 2022-01-13 16:49:04.490 HD Request # 75 | Setting DTC encoding to Binary VLS | 2022-01-13 16:49:05.537 HD Request # 75 | Sending historical data logon request message. | 2022-01-13 16:49:05.537 HD Request # 75 | Requesting Intraday data. Start date-time: 2022-01-13 16:43:33. Record interval: 0. Symbol: ZBH22 | 2022-01-13 16:49:08.895 HD Request # 75 | Decompressing data. | 2022-01-13 16:49:09.196 HD Request # 75 | Receiving Intraday data for ZBH22 starting at 2022-01-13 16:43:33.958000 | 2022-01-13 16:49:09.197 Socket (1) | CloseSocket call. | 2022-01-13 16:49:10.637 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:49:10.637 Historical data download thread signaled to stop. | 2022-01-13 16:49:10.652 HD Request # 75 | Timestamp of first Intraday data file record written: 2022-01-13 16:43:52.769000 | 2022-01-13 16:49:10.652 HD Request # 75 | Received 674 Intraday data records from 2022-01-13 16:43:33.958000 to 2022-01-13 16:49:02.577000 (5.5 minutes) and wrote 669 records for ZBH22 | 2022-01-13 16:49:10.652 HD Request # 75 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:49:02.577000 | 2022-01-13 16:49:10.660 Added 78 Time and Sales records to Intraday data file for ZBH22 after download. | 2022-01-13 16:49:10.660 HD Request # 75 | Completion time: 9s | 2022-01-13 16:49:10.660 HD Request # 75 | Intraday data download complete for ZBH22. Unique request ID: 148 | 2022-01-13 16:49:10.660 Removing historical data download ID 148. | 2022-01-13 16:49:10.660 Real-time Intraday chart data file updates started for ZBH22 | 2022-01-13 16:49:10.660 Intraday chart data file opened for ZBH22 | 2022-01-13 16:49:10.660 HD Request # 75 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:49:10.660 Triggering next historical data download in queue. | 2022-01-13 16:49:10.660 HD Request # 76 | Downloading Intraday chart data for 6BH22 to the file 6BH22.scid. Service: cme | 2022-01-13 16:49:10.660 HD Request # 76 | Download start date-time: 2022-01-13 16:43:37.000000. File last date-time: 2022-01-13 16:43:37.297000 | 2022-01-13 16:49:10.661 HD Request # 76 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:49:10.661 Socket (7) | Creating socket. | 2022-01-13 16:49:10.661 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:49:10.661 Socket (7) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:49:10.661 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:49:13.207 Socket (1) | Closed. | 2022-01-13 16:49:13.207 HD Request # 76 | Setting DTC encoding to Binary VLS | 2022-01-13 16:49:13.899 HD Request # 76 | Sending historical data logon request message. | 2022-01-13 16:49:13.899 HD Request # 76 | Requesting Intraday data. Start date-time: 2022-01-13 16:43:37. Record interval: 0. Symbol: 6BH22 | 2022-01-13 16:49:14.195 HD Request # 76 | Decompressing data. | 2022-01-13 16:49:14.507 HD Request # 76 | Receiving Intraday data for 6BH22 starting at 2022-01-13 16:43:37.297000 | 2022-01-13 16:49:14.803 Socket (7) | CloseSocket call. | 2022-01-13 16:49:14.804 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:49:14.804 Historical data download thread signaled to stop. | 2022-01-13 16:49:14.836 HD Request # 76 | Timestamp of first Intraday data file record written: 2022-01-13 16:43:49.928000 | 2022-01-13 16:49:14.836 HD Request # 76 | Received 234 Intraday data records from 2022-01-13 16:43:37.297000 to 2022-01-13 16:49:05.722000 (5.5 minutes) and wrote 233 records for 6BH22 | 2022-01-13 16:49:14.836 HD Request # 76 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:49:05.722000 | 2022-01-13 16:49:14.845 HD Request # 76 | Completion time: 4s | 2022-01-13 16:49:14.845 HD Request # 76 | Intraday data download complete for 6BH22. Unique request ID: 149 | 2022-01-13 16:49:14.845 Removing historical data download ID 149. | 2022-01-13 16:49:14.845 Real-time Intraday chart data file updates started for 6BH22 | 2022-01-13 16:49:14.845 Intraday chart data file opened for 6BH22 | 2022-01-13 16:49:14.845 HD Request # 76 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:49:14.845 Triggering next historical data download in queue. | 2022-01-13 16:49:14.845 HD Request # 77 | Downloading Intraday chart data for 6AH22 to the file 6AH22.scid. Service: cme | 2022-01-13 16:49:14.845 HD Request # 77 | Download start date-time: 2022-01-13 16:46:23.000000. File last date-time: 2022-01-13 16:46:23.501000 | 2022-01-13 16:49:14.845 HD Request # 77 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:49:14.845 Socket (1) | Creating socket. | 2022-01-13 16:49:14.845 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:49:14.845 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:49:14.845 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:49:15.099 Socket (7) | Closed. | 2022-01-13 16:49:15.099 HD Request # 77 | Setting DTC encoding to Binary VLS | 2022-01-13 16:49:21.458 HD Request # 77 | Sending historical data logon request message. | 2022-01-13 16:49:21.459 HD Request # 77 | Requesting Intraday data. Start date-time: 2022-01-13 16:46:23. Record interval: 0. Symbol: 6AH22 | 2022-01-13 16:49:21.747 HD Request # 77 | Decompressing data. | 2022-01-13 16:49:22.049 HD Request # 77 | Receiving Intraday data for 6AH22 starting at 2022-01-13 16:46:23.500000 | 2022-01-13 16:49:22.050 Socket (1) | CloseSocket call. | 2022-01-13 16:49:22.050 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:49:22.050 Historical data download thread signaled to stop. | 2022-01-13 16:49:22.054 HD Request # 77 | Timestamp of first Intraday data file record written: 2022-01-13 16:46:37.297000 | 2022-01-13 16:49:22.055 HD Request # 77 | Received 90 Intraday data records from 2022-01-13 16:46:23.500000 to 2022-01-13 16:49:08.223001 (2.7 minutes) and wrote 88 records for 6AH22 | 2022-01-13 16:49:22.055 HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:49:08.223001 | 2022-01-13 16:49:22.062 HD Request # 77 | Completion time: 8s | 2022-01-13 16:49:22.062 HD Request # 77 | Intraday data download complete for 6AH22. Unique request ID: 151 | 2022-01-13 16:49:22.062 Removing historical data download ID 151. | 2022-01-13 16:49:22.062 Real-time Intraday chart data file updates started for 6AH22 | 2022-01-13 16:49:22.062 Intraday chart data file opened for 6AH22 | 2022-01-13 16:49:22.062 HD Request # 77 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:49:22.062 Triggering next historical data download in queue. | 2022-01-13 16:49:22.062 HD Request # 78 | Downloading Intraday chart data for 6CH22 to the file 6CH22.scid. Service: cme | 2022-01-13 16:49:22.062 HD Request # 78 | Download start date-time: 2022-01-13 16:46:32.000000. File last date-time: 2022-01-13 16:46:32.197000 | 2022-01-13 16:49:22.062 HD Request # 78 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:49:22.063 Socket (7) | Creating socket. | 2022-01-13 16:49:22.063 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:49:22.063 Socket (7) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:49:22.063 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:49:23.136 Socket (1) | Closed. | 2022-01-13 16:49:23.136 Opened cached Intraday file: C:\SierraChart\Data\6BH22.scid. Thread ID: 11608 | 2022-01-13 16:49:24.662 HD Request # 78 | Setting DTC encoding to Binary VLS | 2022-01-13 16:49:25.674 HD Request # 78 | Sending historical data logon request message. | 2022-01-13 16:49:25.674 HD Request # 78 | Requesting Intraday data. Start date-time: 2022-01-13 16:46:32. Record interval: 0. Symbol: 6CH22 | 2022-01-13 16:49:26.430 HD Request # 78 | Decompressing data. | 2022-01-13 16:49:26.735 HD Request # 78 | Receiving Intraday data for 6CH22 starting at 2022-01-13 16:46:32.197000 | 2022-01-13 16:49:26.735 Socket (7) | CloseSocket call. | 2022-01-13 16:49:26.736 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:49:26.736 Historical data download thread signaled to stop. | 2022-01-13 16:49:26.759 HD Request # 78 | Timestamp of first Intraday data file record written: 2022-01-13 16:46:53.597000 | 2022-01-13 16:49:26.759 HD Request # 78 | Received 124 Intraday data records from 2022-01-13 16:46:32.197000 to 2022-01-13 16:49:23.381001 (2.9 minutes) and wrote 123 records for 6CH22 | 2022-01-13 16:49:26.760 HD Request # 78 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:49:23.381001 | 2022-01-13 16:49:26.768 HD Request # 78 | Completion time: 4s | 2022-01-13 16:49:26.768 HD Request # 78 | Intraday data download complete for 6CH22. Unique request ID: 152 | 2022-01-13 16:49:26.768 Removing historical data download ID 152. | 2022-01-13 16:49:26.768 Real-time Intraday chart data file updates started for 6CH22 | 2022-01-13 16:49:26.768 Intraday chart data file opened for 6CH22 | 2022-01-13 16:49:26.768 HD Request # 78 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:49:26.768 Triggering next historical data download in queue. | 2022-01-13 16:49:26.768 HD Request # 79 | Downloading Intraday chart data for 6JH22 to the file 6JH22.scid. Service: cme | 2022-01-13 16:49:26.769 HD Request # 79 | Download start date-time: 2022-01-13 16:45:17.000000. File last date-time: 2022-01-13 16:45:17.020000 | 2022-01-13 16:49:26.769 HD Request # 79 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:49:26.769 Socket (1) | Creating socket. | 2022-01-13 16:49:26.769 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:49:26.769 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:49:26.769 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:49:27.027 Socket (7) | Closed. | 2022-01-13 16:49:27.027 Opened cached Intraday file: C:\SierraChart\Data\6AH22.scid. Thread ID: 11608 | 2022-01-13 16:49:34.738 Opened cached Intraday file: C:\SierraChart\Data\6CH22.scid. Thread ID: 11608 | 2022-01-13 16:49:34.739 HD Request # 79 | Setting DTC encoding to Binary VLS | 2022-01-13 16:49:36.387 HD Request # 79 | Sending historical data logon request message. | 2022-01-13 16:49:36.387 HD Request # 79 | Requesting Intraday data. Start date-time: 2022-01-13 16:45:17. Record interval: 0. Symbol: 6JH22 | 2022-01-13 16:49:37.147 HD Request # 79 | Decompressing data. | 2022-01-13 16:49:37.445 HD Request # 79 | Receiving Intraday data for 6JH22 starting at 2022-01-13 16:45:17.020000 | 2022-01-13 16:49:37.447 Socket (1) | CloseSocket call. | 2022-01-13 16:49:37.448 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:49:37.448 Historical data download thread signaled to stop. | 2022-01-13 16:49:37.449 HD Request # 79 | Timestamp of first Intraday data file record written: 2022-01-13 16:45:24.255000 | 2022-01-13 16:49:37.449 HD Request # 79 | Received 287 Intraday data records from 2022-01-13 16:45:17.020000 to 2022-01-13 16:49:23.311000 (4.1 minutes) and wrote 286 records for 6JH22 | 2022-01-13 16:49:37.449 HD Request # 79 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:49:23.311000 | 2022-01-13 16:49:37.457 Added 1 Time and Sales records to Intraday data file for 6JH22 after download. | 2022-01-13 16:49:37.457 HD Request # 79 | Completion time: 11s | 2022-01-13 16:49:37.457 HD Request # 79 | Intraday data download complete for 6JH22. Unique request ID: 153 | 2022-01-13 16:49:37.457 Removing historical data download ID 153. | 2022-01-13 16:49:37.457 Real-time Intraday chart data file updates started for 6JH22 | 2022-01-13 16:49:37.457 Intraday chart data file opened for 6JH22 | 2022-01-13 16:49:37.457 HD Request # 79 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:49:37.457 Triggering next historical data download in queue. | 2022-01-13 16:49:37.457 HD Request # 80 | Downloading Intraday chart data for CLG22 to the file CLG22.scid. Service: nymex | 2022-01-13 16:49:37.457 HD Request # 80 | Download start date-time: 2022-01-13 16:45:21.000000. File last date-time: 2022-01-13 16:45:21.181002 | 2022-01-13 16:49:37.457 HD Request # 80 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:49:37.458 Socket (7) | Creating socket. | 2022-01-13 16:49:37.458 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:49:37.458 Socket (7) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:49:37.458 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:49:37.746 Socket (1) | Closed. | 2022-01-13 16:49:37.747 HD Request # 80 | Setting DTC encoding to Binary VLS | 2022-01-13 16:49:38.060 HD Request # 80 | Sending historical data logon request message. | 2022-01-13 16:49:38.060 HD Request # 80 | Requesting Intraday data. Start date-time: 2022-01-13 16:45:21. Record interval: 0. Symbol: CLG22 | 2022-01-13 16:49:39.127 HD Request # 80 | Decompressing data. | 2022-01-13 16:49:39.419 HD Request # 80 | Receiving Intraday data for CLG22 starting at 2022-01-13 16:45:21.181000 | 2022-01-13 16:49:39.928 Opened cached Intraday file: C:\SierraChart\Data\ZBH22.scid. Thread ID: 11608 | 2022-01-13 16:49:44.830 Opened cached Intraday file: C:\SierraChart\Data\6JH22.scid. Thread ID: 11608 | 2022-01-13 16:49:44.830 Saved Chartbook: daytradepanos.Cht. Time: 0.0631 seconds. | 2022-01-13 16:49:51.691 DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-13 16:50:05.562 * DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:50:05.562 DTC Client socket (5) | Closed. | 2022-01-13 16:50:05.562 Socket (7) | CloseSocket call. | 2022-01-13 16:50:27.402 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:50:27.402 Historical data download thread signaled to stop. | 2022-01-13 16:50:27.404 HD Request # 80 | Timestamp of first Intraday data file record written: 2022-01-13 16:45:22.633000 | 2022-01-13 16:50:27.404 HD Request # 80 | Received 901 Intraday data records from 2022-01-13 16:45:21.181000 to 2022-01-13 16:49:35.226004 (4.2 minutes) and wrote 898 records for CLG22 | 2022-01-13 16:50:27.404 HD Request # 80 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:49:35.226004 | 2022-01-13 16:50:27.409 Added 72 Time and Sales records to Intraday data file for CLG22 after download. | 2022-01-13 16:50:27.409 HD Request # 80 | Completion time: 50s | 2022-01-13 16:50:27.409 HD Request # 80 | Intraday data download complete for CLG22. Unique request ID: 154 | 2022-01-13 16:50:27.409 Removing historical data download ID 154. | 2022-01-13 16:50:27.409 Real-time Intraday chart data file updates started for CLG22 | 2022-01-13 16:50:27.409 Intraday chart data file opened for CLG22 | 2022-01-13 16:50:27.409 HD Request # 80 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:50:27.409 Triggering next historical data download in queue. | 2022-01-13 16:50:27.409 HD Request # 81 | Downloading Intraday chart data for ESH22 to the file ESH22.scid. Service: cme | 2022-01-13 16:50:27.410 HD Request # 81 | Download start date-time: 2022-01-13 16:45:22.000000. File last date-time: 2022-01-13 16:45:22.255000 | 2022-01-13 16:50:27.410 HD Request # 81 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:50:27.410 Socket (1) | Creating socket. | 2022-01-13 16:50:27.410 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:50:27.410 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:50:27.410 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:50:27.712 Socket (7) | Closed. | 2022-01-13 16:50:27.712 HD Request # 81 | Setting DTC encoding to Binary VLS | 2022-01-13 16:50:29.000 HD Request # 81 | Sending historical data logon request message. | 2022-01-13 16:50:29.000 HD Request # 81 | Requesting Intraday data. Start date-time: 2022-01-13 16:45:22. Record interval: 0. Symbol: ESH22 | 2022-01-13 16:50:29.851 HD Request # 81 | Decompressing data. | 2022-01-13 16:50:30.151 Opened cached Intraday file: C:\SierraChart\Data\CLG22.scid. Thread ID: 11608 | 2022-01-13 16:50:30.195 HD Request # 81 | Receiving Intraday data for ESH22 starting at 2022-01-13 16:45:22.255000 | 2022-01-13 16:50:30.665 Socket (1) | CloseSocket call. | 2022-01-13 16:50:37.240 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:50:37.240 Historical data download thread signaled to stop. | 2022-01-13 16:50:37.248 HD Request # 81 | Timestamp of first Intraday data file record written: 2022-01-13 16:45:22.470000 | 2022-01-13 16:50:37.248 HD Request # 81 | Received 6307 Intraday data records from 2022-01-13 16:45:22.255000 to 2022-01-13 16:50:28.217000 (5.1 minutes) and wrote 6306 records for ESH22 | 2022-01-13 16:50:37.249 HD Request # 81 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:50:28.217000 | 2022-01-13 16:50:37.257 Added 103 Time and Sales records to Intraday data file for ESH22 after download. | 2022-01-13 16:50:37.257 HD Request # 81 | Completion time: 10s | 2022-01-13 16:50:37.257 HD Request # 81 | Intraday data download complete for ESH22. Unique request ID: 155 | 2022-01-13 16:50:37.257 Removing historical data download ID 155. | 2022-01-13 16:50:37.257 Real-time Intraday chart data file updates started for ESH22 | 2022-01-13 16:50:37.257 Intraday chart data file opened for ESH22 | 2022-01-13 16:50:37.257 HD Request # 81 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:50:37.257 Triggering next historical data download in queue. | 2022-01-13 16:50:37.257 HD Request # 82 | Downloading Intraday chart data for GCG22 to the file GCG22.scid. Service: comex | 2022-01-13 16:50:37.257 HD Request # 82 | Download start date-time: 2022-01-13 16:47:03.000000. File last date-time: 2022-01-13 16:47:03.590000 | 2022-01-13 16:50:37.257 HD Request # 82 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:50:37.257 Socket (5) | Creating socket. | 2022-01-13 16:50:37.258 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:50:37.258 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:50:37.258 Opened cached Intraday file: C:\SierraChart\Data\ESH22.scid. Thread ID: 11608 | 2022-01-13 16:50:40.285 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:50:40.332 Socket (1) | Closed. | 2022-01-13 16:50:40.332 HD Request # 82 | Setting DTC encoding to Binary VLS | 2022-01-13 16:50:40.561 HD Request # 82 | Sending historical data logon request message. | 2022-01-13 16:50:40.561 SC DTC Data with Market Depth | There has been no activity on the network socket for 1m 9s. Will reconnect. | 2022-01-13 16:50:45.719 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:50:45.719 DTC Client socket (3) | CloseSocket call. | 2022-01-13 16:50:45.719 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:50:45.719 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 16:50:45.719 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:50:45.720 HD Request # 82 | Requesting Intraday data. Start date-time: 2022-01-13 16:47:03. Record interval: 0. Symbol: GCG22 | 2022-01-13 16:50:47.507 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2022-01-13 16:50:47.945 DTC Client socket (1) | Creating socket. | 2022-01-13 16:50:47.946 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:50:47.946 DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:50:47.946 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:50:51.254 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:50:51.254 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:50:51.254 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:50:51.647 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:50:51.647 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:50:52.528 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:50:52.528 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:50:52.528 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:50:52.528 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:50:52.528 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:50:52.528 Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2022-01-13 16:50:52.528 Triggering next historical data download in queue. | 2022-01-13 16:50:52.528 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:50:52.528 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:50:52.528 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:50:52.528 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:50:52.528 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:50:52.528 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2022-01-13 16:50:52.528 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:50:52.528 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:50:52.528 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2022-01-13 16:50:52.528 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:50:52.528 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:50:53.696 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:50:53.696 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:50:53.696 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:50:53.696 HD Request # 82 | Decompressing data. | 2022-01-13 16:51:43.169 HD Request # 82 | Receiving Intraday data for GCG22 starting at 2022-01-13 16:47:03.590000 | 2022-01-13 16:51:43.169 Socket (5) | CloseSocket call. | 2022-01-13 16:51:43.810 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:51:43.810 Historical data download thread signaled to stop. | 2022-01-13 16:51:43.812 HD Request # 82 | Timestamp of first Intraday data file record written: 2022-01-13 16:47:04.304000 | 2022-01-13 16:51:43.812 HD Request # 82 | Received 734 Intraday data records from 2022-01-13 16:47:03.590000 to 2022-01-13 16:50:43.771000 (3.7 minutes) and wrote 733 records for GCG22 | 2022-01-13 16:51:43.812 HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:50:43.771000 | 2022-01-13 16:51:43.820 Added 105 Time and Sales records to Intraday data file for GCG22 after download. | 2022-01-13 16:51:43.820 HD Request # 82 | Completion time: 1m 6s | 2022-01-13 16:51:43.820 HD Request # 82 | Intraday data download complete for GCG22. Unique request ID: 156 | 2022-01-13 16:51:43.820 Removing historical data download ID 156. | 2022-01-13 16:51:43.820 Real-time Intraday chart data file updates started for GCG22 | 2022-01-13 16:51:43.820 Intraday chart data file opened for GCG22 | 2022-01-13 16:51:43.820 HD Request # 82 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:51:43.820 Triggering next historical data download in queue. | 2022-01-13 16:51:43.820 HD Request # 83 | Downloading Intraday chart data for NGG22 to the file NGG22.scid. Service: nymex | 2022-01-13 16:51:43.821 HD Request # 83 | Download start date-time: 2022-01-13 16:47:10.000000. File last date-time: 2022-01-13 16:47:10.020000 | 2022-01-13 16:51:43.821 HD Request # 83 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:51:43.821 Socket (7) | Creating socket. | 2022-01-13 16:51:43.821 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:51:43.821 Socket (7) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:51:43.821 HD Request # 83 | Setting DTC encoding to Binary VLS | 2022-01-13 16:51:44.406 HD Request # 83 | Sending historical data logon request message. | 2022-01-13 16:51:44.406 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:51:44.796 Socket (5) | Closed. | 2022-01-13 16:51:44.796 HD Request # 83 | Requesting Intraday data. Start date-time: 2022-01-13 16:47:10. Record interval: 0. Symbol: NGG22 | 2022-01-13 16:51:45.907 HD Request # 83 | Decompressing data. | 2022-01-13 16:51:46.199 HD Request # 83 | Receiving Intraday data for NGG22 starting at 2022-01-13 16:47:10.020000 | 2022-01-13 16:51:46.199 Socket (7) | CloseSocket call. | 2022-01-13 16:51:46.785 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:51:46.785 Historical data download thread signaled to stop. | 2022-01-13 16:51:46.806 HD Request # 83 | Timestamp of first Intraday data file record written: 2022-01-13 16:47:11.567000 | 2022-01-13 16:51:46.806 HD Request # 83 | Received 689 Intraday data records from 2022-01-13 16:47:10.020000 to 2022-01-13 16:51:40.726001 (4.5 minutes) and wrote 688 records for NGG22 | 2022-01-13 16:51:46.806 HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:51:40.726001 | 2022-01-13 16:51:46.814 Added 39 Time and Sales records to Intraday data file for NGG22 after download. | 2022-01-13 16:51:46.814 HD Request # 83 | Completion time: 3s | 2022-01-13 16:51:46.815 HD Request # 83 | Intraday data download complete for NGG22. Unique request ID: 157 | 2022-01-13 16:51:46.815 Removing historical data download ID 157. | 2022-01-13 16:51:46.815 Real-time Intraday chart data file updates started for NGG22 | 2022-01-13 16:51:46.815 Intraday chart data file opened for NGG22 | 2022-01-13 16:51:46.815 HD Request # 83 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:51:46.815 Triggering next historical data download in queue. | 2022-01-13 16:51:46.815 HD Request # 84 | Downloading Intraday chart data for NQH22 to the file NQH22.scid. Service: cme | 2022-01-13 16:51:46.815 HD Request # 84 | Download start date-time: 2022-01-13 16:47:22.000000. File last date-time: 2022-01-13 16:47:22.673000 | 2022-01-13 16:51:46.815 HD Request # 84 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:51:46.815 Socket (5) | Creating socket. | 2022-01-13 16:51:46.815 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:51:46.815 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:51:46.815 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:51:47.077 Socket (7) | Closed. | 2022-01-13 16:51:47.077 HD Request # 84 | Setting DTC encoding to Binary VLS | 2022-01-13 16:51:47.415 HD Request # 84 | Sending historical data logon request message. | 2022-01-13 16:51:47.415 HD Request # 84 | Requesting Intraday data. Start date-time: 2022-01-13 16:47:22. Record interval: 0. Symbol: NQH22 | 2022-01-13 16:51:48.158 HD Request # 84 | Decompressing data. | 2022-01-13 16:51:49.645 HD Request # 84 | Receiving Intraday data for NQH22 starting at 2022-01-13 16:47:22.371000 | 2022-01-13 16:51:49.647 Socket (5) | CloseSocket call. | 2022-01-13 16:51:49.657 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:51:49.657 Historical data download thread signaled to stop. | 2022-01-13 16:51:49.693 HD Request # 84 | Timestamp of first Intraday data file record written: 2022-01-13 16:47:22.940000 | 2022-01-13 16:51:49.693 HD Request # 84 | Received 4457 Intraday data records from 2022-01-13 16:47:22.371000 to 2022-01-13 16:51:45.017006 (4.4 minutes) and wrote 4451 records for NQH22 | 2022-01-13 16:51:49.693 HD Request # 84 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:51:45.017006 | 2022-01-13 16:51:49.701 Added 35 Time and Sales records to Intraday data file for NQH22 after download. | 2022-01-13 16:51:49.701 HD Request # 84 | Completion time: 3s | 2022-01-13 16:51:49.701 HD Request # 84 | Intraday data download complete for NQH22. Unique request ID: 158 | 2022-01-13 16:51:49.701 Removing historical data download ID 158. | 2022-01-13 16:51:49.701 Real-time Intraday chart data file updates started for NQH22 | 2022-01-13 16:51:49.701 Intraday chart data file opened for NQH22 | 2022-01-13 16:51:49.701 HD Request # 84 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:51:49.701 Triggering next historical data download in queue. | 2022-01-13 16:51:49.701 HD Request # 85 | Downloading Intraday chart data for RBG22 to the file RBG22.scid. Service: nymex | 2022-01-13 16:51:49.701 HD Request # 85 | Download start date-time: 2022-01-13 16:47:37.000000. File last date-time: 2022-01-13 16:47:37.050000 | 2022-01-13 16:51:49.702 HD Request # 85 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:51:49.702 Socket (7) | Creating socket. | 2022-01-13 16:51:49.702 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:51:49.702 Socket (7) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:51:49.703 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:51:49.952 Socket (5) | Closed. | 2022-01-13 16:51:49.952 Opened cached Intraday file: C:\SierraChart\Data\GCG22.scid. Thread ID: 11608 | 2022-01-13 16:51:50.863 Opened cached Intraday file: C:\SierraChart\Data\NQH22.scid. Thread ID: 11608 | 2022-01-13 16:51:50.864 Opened cached Intraday file: C:\SierraChart\Data\NGG22.scid. Thread ID: 11608 | 2022-01-13 16:51:50.864 HD Request # 85 | Setting DTC encoding to Binary VLS | 2022-01-13 16:51:52.888 HD Request # 85 | Sending historical data logon request message. | 2022-01-13 16:51:52.888 HD Request # 85 | Requesting Intraday data. Start date-time: 2022-01-13 16:47:37. Record interval: 0. Symbol: RBG22 | 2022-01-13 16:51:53.183 HD Request # 85 | Decompressing data. | 2022-01-13 16:51:53.477 HD Request # 85 | Receiving Intraday data for RBG22 starting at 2022-01-13 16:47:37.050000 | 2022-01-13 16:51:53.478 Socket (7) | CloseSocket call. | 2022-01-13 16:51:53.479 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:51:53.479 Historical data download thread signaled to stop. | 2022-01-13 16:51:53.479 HD Request # 85 | Timestamp of first Intraday data file record written: 2022-01-13 16:47:41.827000 | 2022-01-13 16:51:53.479 HD Request # 85 | Received 101 Intraday data records from 2022-01-13 16:47:37.050000 to 2022-01-13 16:51:48.302001 (4.2 minutes) and wrote 100 records for RBG22 | 2022-01-13 16:51:53.479 HD Request # 85 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:51:48.302001 | 2022-01-13 16:51:53.484 HD Request # 85 | Completion time: 4s | 2022-01-13 16:51:53.484 HD Request # 85 | Intraday data download complete for RBG22. Unique request ID: 159 | 2022-01-13 16:51:53.484 Removing historical data download ID 159. | 2022-01-13 16:51:53.484 Real-time Intraday chart data file updates started for RBG22 | 2022-01-13 16:51:53.484 Intraday chart data file opened for RBG22 | 2022-01-13 16:51:53.484 HD Request # 85 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:51:53.484 Triggering next historical data download in queue. | 2022-01-13 16:51:53.484 HD Request # 86 | Downloading Intraday chart data for TNH22 to the file TNH22.scid. Service: cbot | 2022-01-13 16:51:53.484 HD Request # 86 | Download start date-time: 2022-01-13 16:47:36.000000. File last date-time: 2022-01-13 16:47:36.429002 | 2022-01-13 16:51:53.484 HD Request # 86 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:51:53.484 Socket (5) | Creating socket. | 2022-01-13 16:51:53.484 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:51:53.484 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:51:53.484 HD Request # 86 | Setting DTC encoding to Binary VLS | 2022-01-13 16:51:54.088 HD Request # 86 | Sending historical data logon request message. | 2022-01-13 16:51:54.088 HD Request # 86 | Requesting Intraday data. Start date-time: 2022-01-13 16:47:36. Record interval: 0. Symbol: TNH22 | 2022-01-13 16:51:54.386 HD Request # 86 | Decompressing data. | 2022-01-13 16:51:54.681 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:51:55.699 Socket (7) | Closed. | 2022-01-13 16:51:55.699 HD Request # 86 | Receiving Intraday data for TNH22 starting at 2022-01-13 16:47:36.383000 | 2022-01-13 16:51:56.016 Socket (5) | CloseSocket call. | 2022-01-13 16:51:56.018 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:51:56.018 Historical data download thread signaled to stop. | 2022-01-13 16:51:56.023 HD Request # 86 | Timestamp of first Intraday data file record written: 2022-01-13 16:47:54.831000 | 2022-01-13 16:51:56.023 HD Request # 86 | Received 561 Intraday data records from 2022-01-13 16:47:36.383000 to 2022-01-13 16:51:48.783001 (4.2 minutes) and wrote 516 records for TNH22 | 2022-01-13 16:51:56.023 HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:51:48.783001 | 2022-01-13 16:51:56.031 Added 27 Time and Sales records to Intraday data file for TNH22 after download. | 2022-01-13 16:51:56.031 HD Request # 86 | Completion time: 3s | 2022-01-13 16:51:56.031 HD Request # 86 | Intraday data download complete for TNH22. Unique request ID: 160 | 2022-01-13 16:51:56.031 Removing historical data download ID 160. | 2022-01-13 16:51:56.031 Real-time Intraday chart data file updates started for TNH22 | 2022-01-13 16:51:56.031 Intraday chart data file opened for TNH22 | 2022-01-13 16:51:56.031 HD Request # 86 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:51:56.031 Triggering next historical data download in queue. | 2022-01-13 16:51:56.031 HD Request # 87 | Downloading Intraday chart data for YMH22 to the file YMH22.scid. Service: cbot | 2022-01-13 16:51:56.031 HD Request # 87 | Download start date-time: 2022-01-13 16:47:44.000000. File last date-time: 2022-01-13 16:47:44.352000 | 2022-01-13 16:51:56.032 HD Request # 87 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:51:56.032 Socket (7) | Creating socket. | 2022-01-13 16:51:56.032 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:51:56.032 Socket (7) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:51:56.032 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:51:56.314 Socket (5) | Closed. | 2022-01-13 16:51:56.314 HD Request # 87 | Setting DTC encoding to Binary VLS | 2022-01-13 16:51:56.626 HD Request # 87 | Sending historical data logon request message. | 2022-01-13 16:51:56.626 HD Request # 87 | Requesting Intraday data. Start date-time: 2022-01-13 16:47:44. Record interval: 0. Symbol: YMH22 | 2022-01-13 16:51:56.915 HD Request # 87 | Decompressing data. | 2022-01-13 16:51:57.218 HD Request # 87 | Receiving Intraday data for YMH22 starting at 2022-01-13 16:47:44.352000 | 2022-01-13 16:51:58.319 Socket (7) | CloseSocket call. | 2022-01-13 16:51:59.787 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:51:59.787 Historical data download thread signaled to stop. | 2022-01-13 16:51:59.793 HD Request # 87 | Timestamp of first Intraday data file record written: 2022-01-13 16:47:45.310000 | 2022-01-13 16:51:59.793 HD Request # 87 | Received 1198 Intraday data records from 2022-01-13 16:47:44.352000 to 2022-01-13 16:51:53.446001 (4.2 minutes) and wrote 1197 records for YMH22 | 2022-01-13 16:51:59.794 HD Request # 87 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:51:53.446001 | 2022-01-13 16:51:59.798 Added 29 Time and Sales records to Intraday data file for YMH22 after download. | 2022-01-13 16:51:59.798 HD Request # 87 | Completion time: 3s | 2022-01-13 16:51:59.798 HD Request # 87 | Intraday data download complete for YMH22. Unique request ID: 161 | 2022-01-13 16:51:59.798 Removing historical data download ID 161. | 2022-01-13 16:51:59.798 Real-time Intraday chart data file updates started for YMH22 | 2022-01-13 16:51:59.798 Intraday chart data file opened for YMH22 | 2022-01-13 16:51:59.798 HD Request # 87 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:51:59.798 Triggering next historical data download in queue. | 2022-01-13 16:51:59.798 HD Request # 88 | Downloading Intraday chart data for ZFH22 to the file ZFH22.scid. Service: cbot | 2022-01-13 16:51:59.798 HD Request # 88 | Download start date-time: 2022-01-13 16:47:50.000000. File last date-time: 2022-01-13 16:47:50.187000 | 2022-01-13 16:51:59.798 HD Request # 88 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:51:59.798 Socket (5) | Creating socket. | 2022-01-13 16:51:59.798 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:51:59.799 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:51:59.799 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:52:00.117 Socket (7) | Closed. | 2022-01-13 16:52:00.118 Opened cached Intraday file: C:\SierraChart\Data\RBG22.scid. Thread ID: 11608 | 2022-01-13 16:52:00.969 Opened cached Intraday file: C:\SierraChart\Data\YMH22.scid. Thread ID: 11608 | 2022-01-13 16:52:00.970 HD Request # 88 | Setting DTC encoding to Binary VLS | 2022-01-13 16:52:09.451 HD Request # 88 | Sending historical data logon request message. | 2022-01-13 16:52:09.451 HD Request # 88 | Requesting Intraday data. Start date-time: 2022-01-13 16:47:50. Record interval: 0. Symbol: ZFH22 | 2022-01-13 16:52:09.748 HD Request # 88 | Decompressing data. | 2022-01-13 16:52:10.049 HD Request # 88 | Receiving Intraday data for ZFH22 starting at 2022-01-13 16:47:50.076000 | 2022-01-13 16:52:11.974 Opened cached Intraday file: C:\SierraChart\Data\TNH22.scid. Thread ID: 11608 | 2022-01-13 16:52:16.063 Socket (5) | CloseSocket call. | 2022-01-13 16:52:21.145 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:52:21.145 Historical data download thread signaled to stop. | 2022-01-13 16:52:21.149 HD Request # 88 | Timestamp of first Intraday data file record written: 2022-01-13 16:48:04.253000 | 2022-01-13 16:52:21.149 HD Request # 88 | Received 1169 Intraday data records from 2022-01-13 16:47:50.076000 to 2022-01-13 16:51:54.928000 (4.1 minutes) and wrote 1052 records for ZFH22 | 2022-01-13 16:52:21.149 HD Request # 88 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:51:54.928000 | 2022-01-13 16:52:21.158 HD Request # 88 | Completion time: 22s | 2022-01-13 16:52:21.158 HD Request # 88 | Intraday data download complete for ZFH22. Unique request ID: 162 | 2022-01-13 16:52:21.158 Removing historical data download ID 162. | 2022-01-13 16:52:21.158 Real-time Intraday chart data file updates started for ZFH22 | 2022-01-13 16:52:21.158 Intraday chart data file opened for ZFH22 | 2022-01-13 16:52:21.158 HD Request # 88 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:52:21.158 Triggering next historical data download in queue. | 2022-01-13 16:52:21.158 HD Request # 89 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc | 2022-01-13 16:52:21.158 HD Request # 89 | Download start date-time: 2022-01-13 16:49:20.000000. File last date-time: 2022-01-13 16:49:20.957000 | 2022-01-13 16:52:21.159 HD Request # 89 | Using server: ds13-3.sierracharts.com port 10150 | 2022-01-13 16:52:21.159 Socket (7) | Creating socket. | 2022-01-13 16:52:21.159 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:52:21.159 Socket (7) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:52:21.159 HD Request # 89 | Setting DTC encoding to Binary VLS | 2022-01-13 16:52:21.863 HD Request # 89 | Sending historical data logon request message. | 2022-01-13 16:52:21.863 HD Request # 89 | Requesting Intraday data. Start date-time: 2022-01-13 16:49:20. Record interval: 0. Symbol: ADR-NASDAQ | 2022-01-13 16:52:23.740 HD Request # 89 | Decompressing data. | 2022-01-13 16:52:24.082 HD Request # 89 | Receiving Intraday data for ADR-NASDAQ starting at 2022-01-13 16:49:20.000000 | 2022-01-13 16:52:24.426 Socket (7) | CloseSocket call. | 2022-01-13 16:52:24.426 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:52:24.426 Historical data download thread signaled to stop. | 2022-01-13 16:52:24.429 HD Request # 89 | Timestamp of first Intraday data file record written: 2022-01-13 16:49:21.000000 | 2022-01-13 16:52:24.429 HD Request # 89 | Received 181 Intraday data records from 2022-01-13 16:49:20.000000 to 2022-01-13 16:52:20.000000 (3.0 minutes) and wrote 180 records for ADR-NASDAQ | 2022-01-13 16:52:24.429 HD Request # 89 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:52:20.000000 | 2022-01-13 16:52:24.437 Added 13 Time and Sales records to Intraday data file for ADR-NASDAQ after download. | 2022-01-13 16:52:24.437 HD Request # 89 | Completion time: 3s | 2022-01-13 16:52:24.437 HD Request # 89 | Intraday data download complete for ADR-NASDAQ. Unique request ID: 163 | 2022-01-13 16:52:24.437 Removing historical data download ID 163. | 2022-01-13 16:52:24.437 Real-time Intraday chart data file updates started for ADR-NASDAQ | 2022-01-13 16:52:24.437 Intraday chart data file opened for ADR-NASDAQ | 2022-01-13 16:52:24.437 HD Request # 89 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:52:24.437 Triggering next historical data download in queue. | 2022-01-13 16:52:24.437 HD Request # 90 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 16:52:24.437 HD Request # 90 | Download start date-time: 2022-01-13 16:49:20.000000. File last date-time: 2022-01-13 16:49:20.957000 | 2022-01-13 16:52:24.437 HD Request # 90 | Using server: ds4.sierracharts.com port 10149 | 2022-01-13 16:52:24.437 Socket (8) | Creating socket. | 2022-01-13 16:52:24.438 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:52:24.438 Socket (8) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:52:24.438 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:52:24.782 Socket (7) | Closed. | 2022-01-13 16:52:24.782 Opened cached Intraday file: C:\SierraChart\Data\ADR-NASDAQ.scid. Thread ID: 11608 | 2022-01-13 16:52:26.143 Opened cached Intraday file: C:\SierraChart\Data\ZFH22.scid. Thread ID: 11608 | 2022-01-13 16:52:41.235 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:52:42.257 Socket (5) | Closed. | 2022-01-13 16:52:42.257 Socket (8) | CloseSocket call. | 2022-01-13 16:52:44.435 Socket (8) | Closed. | 2022-01-13 16:52:44.435 HD Request # 90 | Error downloading historical Intraday data for ADV-NYSE. Timeout error connecting to server. | 2022-01-13 16:52:44.439 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:52:44.439 Triggering next historical data download in queue. | 2022-01-13 16:52:44.440 Historical data download thread signaled to stop. | 2022-01-13 16:52:44.440 HD Request # 90 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ADV-NYSE | 2022-01-13 16:52:44.440 HD Request # 90 | Completion time: 20s | 2022-01-13 16:52:44.440 HD Request # 91 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 16:52:44.440 HD Request # 91 | Download start date-time: 2022-01-13 16:49:20.000000. File last date-time: 2022-01-13 16:49:20.957000 | 2022-01-13 16:52:44.440 HD Request # 91 | Using server: ds12.sierracharts.com port 10150 | 2022-01-13 16:52:44.441 Socket (5) | Creating socket. | 2022-01-13 16:52:44.441 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:52:44.441 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:52:44.441 HD Request # 91 | Setting DTC encoding to Binary VLS | 2022-01-13 16:52:45.075 HD Request # 91 | Sending historical data logon request message. | 2022-01-13 16:52:45.075 HD Request # 91 | Requesting Intraday data. Start date-time: 2022-01-13 16:49:20. Record interval: 0. Symbol: ADV-NYSE | 2022-01-13 16:52:45.920 HD Request # 91 | Decompressing data. | 2022-01-13 16:52:46.245 HD Request # 91 | Receiving Intraday data for ADV-NYSE starting at 2022-01-13 16:49:20.000000 | 2022-01-13 16:52:46.248 Socket (5) | CloseSocket call. | 2022-01-13 16:52:46.249 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:52:46.249 Historical data download thread signaled to stop. | 2022-01-13 16:52:46.253 HD Request # 91 | Timestamp of first Intraday data file record written: 2022-01-13 16:49:21.000000 | 2022-01-13 16:52:46.253 HD Request # 91 | Received 204 Intraday data records from 2022-01-13 16:49:20.000000 to 2022-01-13 16:52:43.000000 (3.4 minutes) and wrote 203 records for ADV-NYSE | 2022-01-13 16:52:46.253 HD Request # 91 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:52:43.000000 | 2022-01-13 16:52:46.258 Added 6 Time and Sales records to Intraday data file for ADV-NYSE after download. | 2022-01-13 16:52:46.258 HD Request # 91 | Completion time: 2s | 2022-01-13 16:52:46.258 HD Request # 91 | Intraday data download complete for ADV-NYSE. Unique request ID: 164 | 2022-01-13 16:52:46.258 Removing historical data download ID 164. | 2022-01-13 16:52:46.258 Real-time Intraday chart data file updates started for ADV-NYSE | 2022-01-13 16:52:46.258 Intraday chart data file opened for ADV-NYSE | 2022-01-13 16:52:46.258 HD Request # 91 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:52:46.258 Triggering next historical data download in queue. | 2022-01-13 16:52:46.258 HD Request # 92 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2022-01-13 16:52:46.258 HD Request # 92 | Download start date-time: 2022-01-13 16:49:20.000000. File last date-time: 2022-01-13 16:49:20.957001 | 2022-01-13 16:52:46.258 HD Request # 92 | Using server: ds13-3.sierracharts.com port 10149 | 2022-01-13 16:52:46.259 Socket (7) | Creating socket. | 2022-01-13 16:52:46.259 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:52:46.259 Socket (7) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:52:46.259 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:52:46.544 Socket (5) | Closed. | 2022-01-13 16:52:46.544 Opened cached Intraday file: C:\SierraChart\Data\ADV-NYSE.scid. Thread ID: 11608 | 2022-01-13 16:52:51.328 Socket (7) | CloseSocket call. | 2022-01-13 16:53:06.251 Socket (7) | Closed. | 2022-01-13 16:53:06.252 HD Request # 92 | Error downloading historical Intraday data for TRIN-NYSE. Timeout error connecting to server. | 2022-01-13 16:53:06.263 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:53:06.263 Triggering next historical data download in queue. | 2022-01-13 16:53:06.263 Historical data download thread signaled to stop. | 2022-01-13 16:53:06.263 HD Request # 92 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for TRIN-NYSE | 2022-01-13 16:53:06.263 HD Request # 92 | Completion time: 20s | 2022-01-13 16:53:06.263 HD Request # 93 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2022-01-13 16:53:06.263 HD Request # 93 | Download start date-time: 2022-01-13 16:49:20.000000. File last date-time: 2022-01-13 16:49:20.957001 | 2022-01-13 16:53:06.264 HD Request # 93 | Using server: ds4.sierracharts.com port 10150 | 2022-01-13 16:53:06.264 Socket (5) | Creating socket. | 2022-01-13 16:53:06.264 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:53:06.264 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:53:06.264 DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:53:06.364 DTC Client socket (3) | Closed. | 2022-01-13 16:53:06.364 HD Request # 93 | Setting DTC encoding to Binary VLS | 2022-01-13 16:53:06.851 HD Request # 93 | Sending historical data logon request message. | 2022-01-13 16:53:06.851 HD Request # 93 | Requesting Intraday data. Start date-time: 2022-01-13 16:49:20. Record interval: 0. Symbol: TRIN-NYSE | 2022-01-13 16:53:07.692 HD Request # 93 | Decompressing data. | 2022-01-13 16:53:07.984 HD Request # 93 | Receiving Intraday data for TRIN-NYSE starting at 2022-01-13 16:49:20.000000 | 2022-01-13 16:53:09.474 Socket (5) | CloseSocket call. | 2022-01-13 16:53:10.303 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:53:10.303 Historical data download thread signaled to stop. | 2022-01-13 16:53:10.305 HD Request # 93 | Timestamp of first Intraday data file record written: 2022-01-13 16:49:21.000000 | 2022-01-13 16:53:10.305 HD Request # 93 | Received 226 Intraday data records from 2022-01-13 16:49:20.000000 to 2022-01-13 16:53:05.000000 (3.8 minutes) and wrote 225 records for TRIN-NYSE | 2022-01-13 16:53:10.305 HD Request # 93 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:53:05.000000 | 2022-01-13 16:53:10.314 Added 30 Time and Sales records to Intraday data file for TRIN-NYSE after download. | 2022-01-13 16:53:10.314 HD Request # 93 | Completion time: 4s | 2022-01-13 16:53:10.314 HD Request # 93 | Intraday data download complete for TRIN-NYSE. Unique request ID: 165 | 2022-01-13 16:53:10.314 Removing historical data download ID 165. | 2022-01-13 16:53:10.314 Real-time Intraday chart data file updates started for TRIN-NYSE | 2022-01-13 16:53:10.314 Intraday chart data file opened for TRIN-NYSE | 2022-01-13 16:53:10.314 HD Request # 93 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:53:10.314 Triggering next historical data download in queue. | 2022-01-13 16:53:10.314 HD Request # 94 | Downloading Intraday chart data for TRIN-SP to the file TRIN-SP.scid. Service: statscalc | 2022-01-13 16:53:10.314 HD Request # 94 | Download start date-time: 2022-01-13 16:49:20.000000. File last date-time: 2022-01-13 16:49:20.957002 | 2022-01-13 16:53:10.314 HD Request # 94 | Using server: ds12.sierracharts.com port 10149 | 2022-01-13 16:53:10.314 Socket (7) | Creating socket. | 2022-01-13 16:53:10.315 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:53:10.315 Socket (7) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:53:10.315 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:53:10.594 Socket (5) | Closed. | 2022-01-13 16:53:10.594 HD Request # 94 | Setting DTC encoding to Binary VLS | 2022-01-13 16:53:10.927 HD Request # 94 | Sending historical data logon request message. | 2022-01-13 16:53:10.927 Opened cached Intraday file: C:\SierraChart\Data\TRIN-NYSE.scid. Thread ID: 11608 | 2022-01-13 16:53:11.504 HD Request # 94 | Requesting Intraday data. Start date-time: 2022-01-13 16:49:20. Record interval: 0. Symbol: TRIN-SP | 2022-01-13 16:53:11.767 HD Request # 94 | Decompressing data. | 2022-01-13 16:53:12.059 HD Request # 94 | Receiving Intraday data for TRIN-SP starting at 2022-01-13 16:49:20.000000 | 2022-01-13 16:53:12.060 Socket (7) | CloseSocket call. | 2022-01-13 16:53:12.060 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:53:12.060 Historical data download thread signaled to stop. | 2022-01-13 16:53:12.063 HD Request # 94 | Timestamp of first Intraday data file record written: 2022-01-13 16:49:21.000000 | 2022-01-13 16:53:12.063 HD Request # 94 | Received 230 Intraday data records from 2022-01-13 16:49:20.000000 to 2022-01-13 16:53:09.000000 (3.8 minutes) and wrote 229 records for TRIN-SP | 2022-01-13 16:53:12.063 HD Request # 94 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:53:09.000000 | 2022-01-13 16:53:12.077 Added 15 Time and Sales records to Intraday data file for TRIN-SP after download. | 2022-01-13 16:53:12.077 HD Request # 94 | Completion time: 2s | 2022-01-13 16:53:12.077 HD Request # 94 | Intraday data download complete for TRIN-SP. Unique request ID: 166 | 2022-01-13 16:53:12.077 Removing historical data download ID 166. | 2022-01-13 16:53:12.077 Real-time Intraday chart data file updates started for TRIN-SP | 2022-01-13 16:53:12.077 Intraday chart data file opened for TRIN-SP | 2022-01-13 16:53:12.077 HD Request # 94 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:53:12.077 Triggering next historical data download in queue. | 2022-01-13 16:53:12.077 No download requests in the queue to start downloads for. | 2022-01-13 16:53:12.077 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 16:53:12.348 Socket (7) | Closed. | 2022-01-13 16:53:12.348 Opened cached Intraday file: C:\SierraChart\Data\TRIN-SP.scid. Thread ID: 11608 | 2022-01-13 16:53:16.544 DTC Client socket (3) | Deleting network socket now after delay. | 2022-01-13 16:53:36.371 Trading Evaluator | There has been no activity on the network socket for 1m 17s. Will reconnect. | 2022-01-13 16:54:31.459 Connection to the external service has been lost. | 2022-01-13 16:54:31.459 Trading Evaluator | Waiting for socket receive thread to end | 2022-01-13 16:54:31.766 DTC Client socket (2) | CloseSocket call. | 2022-01-13 16:54:31.767 DTC Client socket (2) | Max send buffers used during socket life: 5 | 2022-01-13 16:54:31.767 DTC Client socket (2) | Max send buffer size during socket life: 1124 | 2022-01-13 16:54:31.767 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:54:31.767 Trading Evaluator | Disconnected. | 2022-01-13 16:54:31.771 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-01-13 16:54:31.771 Trading Evaluator | Connecting to the server tradesimulation2.sierracharts.com. Port 11096 | 2022-01-13 16:54:33.946 DTC Client socket (3) | Creating socket. Using TLS 1.2. | 2022-01-13 16:54:33.947 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-01-13 16:54:33.947 DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:54:33.947 Trading Evaluator | Network connection to server complete. | 2022-01-13 16:54:34.251 Trading Evaluator | Starting socket receive thread. | 2022-01-13 16:54:34.251 Trading Evaluator | Sending encoding request to server: Binary VLS. Compression: none | 2022-01-13 16:54:34.251 Trading Evaluator | Setting DTC encoding to Binary VLS | 2022-01-13 16:54:42.428 Trading Evaluator | Sending logon request message. | 2022-01-13 16:54:42.428 Trading Evaluator | Received logon response. | 2022-01-13 16:54:43.209 Trading Evaluator | Server Name: SC DTC Server. Build=40463. | 2022-01-13 16:54:43.209 Trading Evaluator | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:54:43.209 Trading Evaluator | Successfully connected. Connected to SC DTC Protocol server. Service=tradesimulation.dtctrading|SymbolSettings=tradesimulation.dtctrading. | 2022-01-13 16:54:43.209 Trading Evaluator | Trading is supported. | 2022-01-13 16:54:43.209 Trading Evaluator | Order cancel and replace is supported. | 2022-01-13 16:54:43.209 Trading Evaluator | OCO Orders supported. | 2022-01-13 16:54:43.209 Trading Evaluator | Bracket Orders supported. | 2022-01-13 16:54:43.209 Trading Evaluator | Connected to server complete. | 2022-01-13 16:54:43.209 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 16:54:43.209 DTC Client socket (4) | CloseSocket call. | 2022-01-13 16:54:43.210 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2022-01-13 16:54:43.210 DTC Client socket (4) | Max send buffer size during socket life: 1242 | 2022-01-13 16:54:43.210 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:54:43.210 WSACleanup called. | 2022-01-13 16:54:43.210 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:54:43.210 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 16:54:43.210 DTC Client socket (6) | CloseSocket call. | 2022-01-13 16:54:43.211 DTC Client socket (6) | Max send buffers used during socket life: 3 | 2022-01-13 16:54:43.211 DTC Client socket (6) | Max send buffer size during socket life: 2367 | 2022-01-13 16:54:43.211 SC Data - All Services | Disconnected from the server. | 2022-01-13 16:54:43.211 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:54:43.211 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:54:43.211 DTC Client socket (1) | CloseSocket call. | 2022-01-13 16:54:43.211 DTC Client socket (1) | Max send buffers used during socket life: 4 | 2022-01-13 16:54:43.211 DTC Client socket (1) | Max send buffer size during socket life: 348 | 2022-01-13 16:54:43.211 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:54:43.211 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:54:43.211 Triggering next historical data download in queue. | 2022-01-13 16:54:43.212 Triggering next historical data download in queue. | 2022-01-13 16:54:43.212 Triggering next historical data download in queue. | 2022-01-13 16:54:43.212 Triggering next historical data download in queue. | 2022-01-13 16:54:43.212 No download requests in the queue to start downloads for. | 2022-01-13 16:54:43.241 No download requests in the queue to start downloads for. | 2022-01-13 16:54:43.241 No download requests in the queue to start downloads for. | 2022-01-13 16:54:43.241 No download requests in the queue to start downloads for. | 2022-01-13 16:54:43.241 Mapping NQH22 to NQH22. Service code: cme | 2022-01-13 16:54:43.242 SC Data - All Services | Starting real-time market data updates for: NQH22 (NQH22). ID: 1 Service code: cme | 2022-01-13 16:54:43.242 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-01-13 16:54:43.242 SC Data - All Services | Requesting security definition data for: NQH22 (NQH22). ID: 1 | 2022-01-13 16:54:43.242 Added historical Intraday data request for NQH22 to the queue. | 2022-01-13 16:54:43.242 Intraday data recording state for symbol NQH22 is set to download 'Pending'. | 2022-01-13 16:54:43.242 Triggering next historical data download in queue. | 2022-01-13 16:54:43.242 DTC Client socket (5) | Creating socket. | 2022-01-13 16:54:43.242 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:54:43.242 DTC Client socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:54:43.242 Delaying start of download for NQH22 | 2022-01-13 16:54:43.244 DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-01-13 16:54:43.274 DTC Client socket (4) | Closed. | 2022-01-13 16:54:43.274 Mapping 6AH22 to 6AH22. Service code: cme | 2022-01-13 16:54:43.285 SC Data - All Services | Starting real-time market data updates for: 6AH22 (6AH22). ID: 2 Service code: cme | 2022-01-13 16:54:43.285 SC Data - All Services | Requesting security definition data for: 6AH22 (6AH22). ID: 2 | 2022-01-13 16:54:43.285 Added historical Intraday data request for 6AH22 to the queue. | 2022-01-13 16:54:43.285 Intraday data recording state for symbol 6AH22 is set to download 'Pending'. | 2022-01-13 16:54:43.285 Triggering next historical data download in queue. | 2022-01-13 16:54:43.285 Mapping ESH22 to ESH22. Service code: cme | 2022-01-13 16:54:43.287 SC Data - All Services | Starting real-time market data updates for: ESH22 (ESH22). ID: 3 Service code: cme | 2022-01-13 16:54:43.287 SC Data - All Services | Requesting security definition data for: ESH22 (ESH22). ID: 3 | 2022-01-13 16:54:43.287 Added historical Intraday data request for ESH22 to the queue. | 2022-01-13 16:54:43.287 Intraday data recording state for symbol ESH22 is set to download 'Pending'. | 2022-01-13 16:54:43.287 Triggering next historical data download in queue. | 2022-01-13 16:54:43.287 Mapping 6CH22 to 6CH22. Service code: cme | 2022-01-13 16:54:43.349 SC Data - All Services | Starting real-time market data updates for: 6CH22 (6CH22). ID: 4 Service code: cme | 2022-01-13 16:54:43.350 SC Data - All Services | Requesting security definition data for: 6CH22 (6CH22). ID: 4 | 2022-01-13 16:54:43.350 Added historical Intraday data request for 6CH22 to the queue. | 2022-01-13 16:54:43.350 Intraday data recording state for symbol 6CH22 is set to download 'Pending'. | 2022-01-13 16:54:43.350 Triggering next historical data download in queue. | 2022-01-13 16:54:43.350 Mapping GCG22 to GCG22. Service code: comex | 2022-01-13 16:54:43.352 SC Data - All Services | Starting real-time market data updates for: GCG22 (GCG22). ID: 5 Service code: comex | 2022-01-13 16:54:43.352 SC Data - All Services | Requesting security definition data for: GCG22 (GCG22). ID: 5 | 2022-01-13 16:54:43.352 Added historical Intraday data request for GCG22 to the queue. | 2022-01-13 16:54:43.352 Intraday data recording state for symbol GCG22 is set to download 'Pending'. | 2022-01-13 16:54:43.352 Triggering next historical data download in queue. | 2022-01-13 16:54:43.352 Mapping RBG22 to RBG22. Service code: nymex | 2022-01-13 16:54:43.370 SC Data - All Services | Starting real-time market data updates for: RBG22 (RBG22). ID: 6 Service code: nymex | 2022-01-13 16:54:43.370 SC Data - All Services | Requesting security definition data for: RBG22 (RBG22). ID: 6 | 2022-01-13 16:54:43.370 Added historical Intraday data request for RBG22 to the queue. | 2022-01-13 16:54:43.370 Intraday data recording state for symbol RBG22 is set to download 'Pending'. | 2022-01-13 16:54:43.370 Triggering next historical data download in queue. | 2022-01-13 16:54:43.370 Mapping YMH22 to YMH22. Service code: cbot | 2022-01-13 16:54:43.398 SC Data - All Services | Starting real-time market data updates for: YMH22 (YMH22). ID: 7 Service code: cbot | 2022-01-13 16:54:43.398 SC Data - All Services | Requesting security definition data for: YMH22 (YMH22). ID: 7 | 2022-01-13 16:54:43.398 Added historical Intraday data request for YMH22 to the queue. | 2022-01-13 16:54:43.398 Intraday data recording state for symbol YMH22 is set to download 'Pending'. | 2022-01-13 16:54:43.398 Triggering next historical data download in queue. | 2022-01-13 16:54:43.398 Mapping ZNH22 to ZNH22. Service code: cbot | 2022-01-13 16:54:43.408 SC Data - All Services | Starting real-time market data updates for: ZNH22 (ZNH22). ID: 8 Service code: cbot | 2022-01-13 16:54:43.408 SC Data - All Services | Requesting security definition data for: ZNH22 (ZNH22). ID: 8 | 2022-01-13 16:54:43.408 Added historical Intraday data request for ZNH22 to the queue. | 2022-01-13 16:54:43.408 Intraday data recording state for symbol ZNH22 is set to download 'Pending'. | 2022-01-13 16:54:43.408 Triggering next historical data download in queue. | 2022-01-13 16:54:43.408 Mapping ZFH22 to ZFH22. Service code: cbot | 2022-01-13 16:54:43.409 SC Data - All Services | Starting real-time market data updates for: ZFH22 (ZFH22). ID: 9 Service code: cbot | 2022-01-13 16:54:43.409 SC Data - All Services | Requesting security definition data for: ZFH22 (ZFH22). ID: 9 | 2022-01-13 16:54:43.409 Added historical Intraday data request for ZFH22 to the queue. | 2022-01-13 16:54:43.409 Intraday data recording state for symbol ZFH22 is set to download 'Pending'. | 2022-01-13 16:54:43.409 Triggering next historical data download in queue. | 2022-01-13 16:54:43.409 Mapping NGG22 to NGG22. Service code: nymex | 2022-01-13 16:54:43.410 SC Data - All Services | Starting real-time market data updates for: NGG22 (NGG22). ID: 10 Service code: nymex | 2022-01-13 16:54:43.410 SC Data - All Services | Requesting security definition data for: NGG22 (NGG22). ID: 10 | 2022-01-13 16:54:43.410 Added historical Intraday data request for NGG22 to the queue. | 2022-01-13 16:54:43.410 Intraday data recording state for symbol NGG22 is set to download 'Pending'. | 2022-01-13 16:54:43.410 Triggering next historical data download in queue. | 2022-01-13 16:54:43.410 Mapping TNH22 to TNH22. Service code: cbot | 2022-01-13 16:54:43.412 SC Data - All Services | Starting real-time market data updates for: TNH22 (TNH22). ID: 11 Service code: cbot | 2022-01-13 16:54:43.412 SC Data - All Services | Requesting security definition data for: TNH22 (TNH22). ID: 11 | 2022-01-13 16:54:43.412 Added historical Intraday data request for TNH22 to the queue. | 2022-01-13 16:54:43.412 Intraday data recording state for symbol TNH22 is set to download 'Pending'. | 2022-01-13 16:54:43.412 Triggering next historical data download in queue. | 2022-01-13 16:54:43.412 Mapping RTYH22 to RTYH22. Service code: cme | 2022-01-13 16:54:43.430 SC Data - All Services | Starting real-time market data updates for: RTYH22 (RTYH22). ID: 12 Service code: cme | 2022-01-13 16:54:43.430 SC Data - All Services | Requesting security definition data for: RTYH22 (RTYH22). ID: 12 | 2022-01-13 16:54:43.430 Mapping NKDH22 to NKDH22. Service code: cme | 2022-01-13 16:54:43.430 SC Data - All Services | Starting real-time market data updates for: NKDH22 (NKDH22). ID: 13 Service code: cme | 2022-01-13 16:54:43.430 SC Data - All Services | Requesting security definition data for: NKDH22 (NKDH22). ID: 13 | 2022-01-13 16:54:43.430 Mapping ZBH22 to ZBH22. Service code: cbot | 2022-01-13 16:54:43.430 SC Data - All Services | Starting real-time market data updates for: ZBH22 (ZBH22). ID: 14 Service code: cbot | 2022-01-13 16:54:43.430 SC Data - All Services | Requesting security definition data for: ZBH22 (ZBH22). ID: 14 | 2022-01-13 16:54:43.430 Mapping ZTH22 to ZTH22. Service code: cbot | 2022-01-13 16:54:43.430 SC Data - All Services | Starting real-time market data updates for: ZTH22 (ZTH22). ID: 15 Service code: cbot | 2022-01-13 16:54:43.430 SC Data - All Services | Requesting security definition data for: ZTH22 (ZTH22). ID: 15 | 2022-01-13 16:54:43.430 Trading Evaluator | Starting real-time market data updates for: FBTPH22. ID: 16 Service code: eurex | 2022-01-13 16:54:43.430 Trading Evaluator | Requesting security definition data for: FBTPH22. ID: 16 | 2022-01-13 16:54:43.430 Trading Evaluator | Starting real-time market data updates for: FGBLH22. ID: 17 Service code: eurex | 2022-01-13 16:54:43.430 Trading Evaluator | Requesting security definition data for: FGBLH22. ID: 17 | 2022-01-13 16:54:43.430 Trading Evaluator | Starting real-time market data updates for: FGBMH22. ID: 18 Service code: eurex | 2022-01-13 16:54:43.431 Trading Evaluator | Requesting security definition data for: FGBMH22. ID: 18 | 2022-01-13 16:54:43.431 Mapping CLG22 to CLG22. Service code: nymex | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: CLG22 (CLG22). ID: 19 Service code: nymex | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: CLG22 (CLG22). ID: 19 | 2022-01-13 16:54:43.431 Mapping BBH22 to BBH22. Service code: nymex | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: BBH22 (BBH22). ID: 20 Service code: nymex | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: BBH22 (BBH22). ID: 20 | 2022-01-13 16:54:43.431 Mapping HOG22 to HOG22. Service code: nymex | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: HOG22 (HOG22). ID: 21 Service code: nymex | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: HOG22 (HOG22). ID: 21 | 2022-01-13 16:54:43.431 Mapping SIH22 to SIH22. Service code: comex | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: SIH22 (SIH22). ID: 22 Service code: comex | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: SIH22 (SIH22). ID: 22 | 2022-01-13 16:54:43.431 Mapping 6EH22 to 6EH22. Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: 6EH22 (6EH22). ID: 23 Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: 6EH22 (6EH22). ID: 23 | 2022-01-13 16:54:43.431 Mapping 6BH22 to 6BH22. Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: 6BH22 (6BH22). ID: 24 Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: 6BH22 (6BH22). ID: 24 | 2022-01-13 16:54:43.431 Mapping 6JH22 to 6JH22. Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: 6JH22 (6JH22). ID: 25 Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: 6JH22 (6JH22). ID: 25 | 2022-01-13 16:54:43.431 Mapping 6SH22 to 6SH22. Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: 6SH22 (6SH22). ID: 26 Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: 6SH22 (6SH22). ID: 26 | 2022-01-13 16:54:43.431 Mapping 6MH22 to 6MH22. Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: 6MH22 (6MH22). ID: 27 Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: 6MH22 (6MH22). ID: 27 | 2022-01-13 16:54:43.431 Mapping BTCF22 to BTCF22. Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Starting real-time market data updates for: BTCF22 (BTCF22). ID: 28 Service code: cme | 2022-01-13 16:54:43.431 SC Data - All Services | Requesting security definition data for: BTCF22 (BTCF22). ID: 28 | 2022-01-13 16:54:43.431 Added historical Intraday data request for CLG22 to the queue. | 2022-01-13 16:54:43.475 Intraday data recording state for symbol CLG22 is set to download 'Pending'. | 2022-01-13 16:54:43.475 Triggering next historical data download in queue. | 2022-01-13 16:54:43.475 Added historical Intraday data request for 6EH22 to the queue. | 2022-01-13 16:54:43.505 Intraday data recording state for symbol 6EH22 is set to download 'Pending'. | 2022-01-13 16:54:43.505 Triggering next historical data download in queue. | 2022-01-13 16:54:43.505 Added historical Intraday data request for ZBH22 to the queue. | 2022-01-13 16:54:43.507 Intraday data recording state for symbol ZBH22 is set to download 'Pending'. | 2022-01-13 16:54:43.507 Triggering next historical data download in queue. | 2022-01-13 16:54:43.507 Added historical Intraday data request for 6BH22 to the queue. | 2022-01-13 16:54:43.520 Intraday data recording state for symbol 6BH22 is set to download 'Pending'. | 2022-01-13 16:54:43.520 Triggering next historical data download in queue. | 2022-01-13 16:54:43.520 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-NYSE. ID: 29 Service code: statscalc | 2022-01-13 16:54:43.522 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2022-01-13 16:54:43.522 SC DTC Data with Market Depth | Requesting security definition data for: ADV-NYSE. ID: 29 | 2022-01-13 16:54:43.522 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:54:43.522 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:54:43.522 Triggering next historical data download in queue. | 2022-01-13 16:54:43.522 DTC Client socket (4) | Creating socket. | 2022-01-13 16:54:43.523 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:54:43.523 DTC Client socket (4) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:54:43.523 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-SP. ID: 30 Service code: statscalc | 2022-01-13 16:54:43.526 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-SP. ID: 30 | 2022-01-13 16:54:43.526 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:54:43.526 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2022-01-13 16:54:43.526 Triggering next historical data download in queue. | 2022-01-13 16:54:43.526 Added historical Intraday data request for 6JH22 to the queue. | 2022-01-13 16:54:43.528 Intraday data recording state for symbol 6JH22 is set to download 'Pending'. | 2022-01-13 16:54:43.528 Triggering next historical data download in queue. | 2022-01-13 16:54:43.528 SC DTC Data with Market Depth | Starting real-time market data updates for: ADR-NASDAQ. ID: 31 Service code: statscalc | 2022-01-13 16:54:43.530 SC DTC Data with Market Depth | Requesting security definition data for: ADR-NASDAQ. ID: 31 | 2022-01-13 16:54:43.530 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:54:43.530 Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2022-01-13 16:54:43.530 Triggering next historical data download in queue. | 2022-01-13 16:54:43.530 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 32 Service code: statscalc | 2022-01-13 16:54:43.534 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 32 | 2022-01-13 16:54:43.534 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:54:43.534 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2022-01-13 16:54:43.534 Triggering next historical data download in queue. | 2022-01-13 16:54:43.534 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:54:43.558 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:54:43.558 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:54:43.558 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH22 | 2022-01-13 16:54:43.623 Trading Evaluator | Received security definition for symbol NQH22 | 2022-01-13 16:54:43.623 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6AH22 | 2022-01-13 16:54:43.623 Trading Evaluator | Received security definition for symbol 6AH22 | 2022-01-13 16:54:43.623 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:54:43.805 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:54:43.805 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:54:43.805 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:54:43.867 SC Data - All Services | Sending logon request message. | 2022-01-13 16:54:43.867 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:54:44.129 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:54:44.129 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol ESH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6CH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol 6CH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol GCG22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RBG22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol RBG22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol YMH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZNH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol ZNH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZFH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol ZFH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NGG22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol NGG22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: TNH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol TNH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: RTYH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol RTYH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NKDH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol NKDH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZBH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol ZBH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ZTH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol ZTH22 | 2022-01-13 16:54:44.828 Symbol Error - FBTPH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol FBTPH22 | 2022-01-13 16:54:44.828 Symbol Error - FGBLH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol FGBLH22 | 2022-01-13 16:54:44.828 Symbol Error - FGBMH22 is unknown, unavailable, or improperly formatted. Market data requests not allowed | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol FGBMH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol CLG22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BBH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol BBH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: HOG22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol HOG22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: SIH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol SIH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6EH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol 6EH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6BH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol 6BH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6JH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol 6JH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6SH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol 6SH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: 6MH22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol 6MH22 | 2022-01-13 16:54:44.828 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: BTCF22 | 2022-01-13 16:54:44.828 Trading Evaluator | Received security definition for symbol BTCF22 | 2022-01-13 16:54:44.828 SC Data - All Services | Received logon response. | 2022-01-13 16:54:44.853 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:54:44.853 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:54:44.853 SC Data - All Services | Successfully connected. | 2022-01-13 16:54:44.853 SC Data - All Services | Trading is not supported. | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: 6MH22 -> 6MH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: 6SH22 -> 6SH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: BBH22 -> BBH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: BTCF22 -> BTCF22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: CLG22 -> CLG22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: GCG22 -> GCG22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: HOG22 -> HOG22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: NGG22 -> NGG22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: NKDH22 -> NKDH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: NQH22 -> NQH22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: RBG22 -> RBG22 | 2022-01-13 16:54:44.853 SC Data - All Services | Restarting real-time data updates for symbol: RTYH22 -> RTYH22 | 2022-01-13 16:54:44.854 SC Data - All Services | Restarting real-time data updates for symbol: SIH22 -> SIH22 | 2022-01-13 16:54:44.854 SC Data - All Services | Restarting real-time data updates for symbol: TNH22 -> TNH22 | 2022-01-13 16:54:44.854 SC Data - All Services | Restarting real-time data updates for symbol: YMH22 -> YMH22 | 2022-01-13 16:54:44.854 SC Data - All Services | Restarting real-time data updates for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:54:44.854 SC Data - All Services | Restarting real-time data updates for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:54:44.854 SC Data - All Services | Restarting real-time data updates for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:54:44.854 SC Data - All Services | Restarting real-time data updates for symbol: ZTH22 -> ZTH22 | 2022-01-13 16:54:44.854 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:54:45.061 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:54:45.061 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:54:45.061 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:54:45.061 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:54:45.061 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:54:45.061 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:54:45.061 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:54:45.061 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:54:45.061 SC Data - All Services | Received security definition for symbol 6AH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol 6BH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol 6CH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol 6EH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol 6JH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol 6MH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol 6SH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol BBH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol BTCF22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol CLG22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol ESH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol GCG22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol HOG22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol NGG22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol NKDH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol NQH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol RBG22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol RTYH22 | 2022-01-13 16:54:45.174 SC Data - All Services | Received security definition for symbol SIH22 | 2022-01-13 16:54:46.101 SC Data - All Services | Received security definition for symbol TNH22 | 2022-01-13 16:54:46.101 SC Data - All Services | Received security definition for symbol YMH22 | 2022-01-13 16:54:46.101 SC Data - All Services | Received security definition for symbol ZBH22 | 2022-01-13 16:54:46.101 SC Data - All Services | Received security definition for symbol ZFH22 | 2022-01-13 16:54:46.101 SC Data - All Services | Received security definition for symbol ZNH22 | 2022-01-13 16:54:46.101 SC Data - All Services | Received security definition for symbol ZTH22 | 2022-01-13 16:54:46.101 Requesting market depth updates for: 6AH22 if supported. | 2022-01-13 16:54:48.196 SC Data - All Services (Market Orders Data) | Connecting to the server ds23.sierracharts.com. Port 10060 | 2022-01-13 16:54:48.202 Requesting market depth updates for: 6BH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: 6CH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: 6EH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: 6JH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: CLG22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: ESH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: GCG22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: NGG22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: NQH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: RBG22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: TNH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: YMH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: ZBH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: ZFH22 if supported. | 2022-01-13 16:54:48.202 Requesting market depth updates for: ZNH22 if supported. | 2022-01-13 16:54:48.202 DTC Client socket (7) | Creating socket. | 2022-01-13 16:54:48.202 DTC Client socket (7) | New receive buffer size: 5242880 | 2022-01-13 16:54:48.202 DTC Client socket (7) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:54:48.202 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:54:48.517 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:54:48.517 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:54:48.517 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:54:48.838 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:54:48.838 SC Data - All Services | Clearing market depth for 6AH22 | 2022-01-13 16:54:49.423 SC Data - All Services | Clearing market depth for 6BH22 | 2022-01-13 16:54:49.423 SC Data - All Services | Clearing market depth for 6CH22 | 2022-01-13 16:54:49.423 SC Data - All Services | Clearing market depth for 6EH22 | 2022-01-13 16:54:49.423 SC Data - All Services | Clearing market depth for 6JH22 | 2022-01-13 16:54:49.423 SC Data - All Services | Clearing market depth for CLG22 | 2022-01-13 16:54:49.423 SC Data - All Services | Clearing market depth for ESH22 | 2022-01-13 16:54:49.423 SC Data - All Services | Clearing market depth for GCG22 | 2022-01-13 16:54:49.427 SC Data - All Services | Clearing market depth for NGG22 | 2022-01-13 16:54:49.427 SC Data - All Services | Clearing market depth for NQH22 | 2022-01-13 16:54:49.427 SC Data - All Services | Clearing market depth for RBG22 | 2022-01-13 16:54:49.427 SC Data - All Services | Clearing market depth for TNH22 | 2022-01-13 16:54:49.427 SC Data - All Services | Clearing market depth for YMH22 | 2022-01-13 16:54:49.427 SC Data - All Services | Clearing market depth for ZBH22 | 2022-01-13 16:54:49.427 SC Data - All Services | Clearing market depth for ZFH22 | 2022-01-13 16:54:49.427 SC Data - All Services | Clearing market depth for ZNH22 | 2022-01-13 16:54:49.427 HD Request # 95 | Downloading Intraday chart data for NQH22 to the file NQH22.scid. Service: cme | 2022-01-13 16:54:50.197 HD Request # 95 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.030000 | 2022-01-13 16:54:50.198 HD Request # 95 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:54:50.198 Socket (8) | Creating socket. | 2022-01-13 16:54:50.198 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:54:50.198 Socket (8) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:54:50.198 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 25. Service code: nymex | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLG22 -> CLG22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 15. Service code: comex | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: GCG22 -> GCG22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGG22 -> NGG22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 15. Service code: cme | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NQH22 -> NQH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: RBG22 -> RBG22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: TNH22 -> TNH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 20. Service code: cbot | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: YMH22 -> YMH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 200. Service code: cbot | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 1500. Service code: cbot | 2022-01-13 16:54:50.584 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:54:50.584 HD Request # 95 | Setting DTC encoding to Binary VLS | 2022-01-13 16:54:50.783 HD Request # 95 | Sending historical data logon request message. | 2022-01-13 16:54:50.783 HD Request # 95 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:30. Record interval: 0. Symbol: NQH22 | 2022-01-13 16:54:51.540 HD Request # 95 | Decompressing data. | 2022-01-13 16:54:51.840 HD Request # 95 | Receiving Intraday data for NQH22 starting at 2022-01-13 16:54:30.030000 | 2022-01-13 16:54:51.841 Socket (8) | CloseSocket call. | 2022-01-13 16:54:51.842 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:54:51.842 Historical data download thread signaled to stop. | 2022-01-13 16:54:51.842 HD Request # 95 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:30.610000 | 2022-01-13 16:54:51.843 HD Request # 95 | Received 453 Intraday data records from 2022-01-13 16:54:30.030000 to 2022-01-13 16:54:49.339000 (19.3 seconds) and wrote 452 records for NQH22 | 2022-01-13 16:54:51.843 HD Request # 95 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:54:49.339000 | 2022-01-13 16:54:51.851 HD Request # 95 | Completion time: 1s | 2022-01-13 16:54:51.851 HD Request # 95 | Intraday data download complete for NQH22. Unique request ID: 167 | 2022-01-13 16:54:51.851 Removing historical data download ID 167. | 2022-01-13 16:54:51.851 Real-time Intraday chart data file updates started for NQH22 | 2022-01-13 16:54:51.851 Intraday chart data file opened for NQH22 | 2022-01-13 16:54:51.851 HD Request # 95 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:54:51.851 Triggering next historical data download in queue. | 2022-01-13 16:54:51.851 HD Request # 96 | Downloading Intraday chart data for 6AH22 to the file 6AH22.scid. Service: cme | 2022-01-13 16:54:51.851 HD Request # 96 | Download start date-time: 2022-01-13 16:54:27.000000. File last date-time: 2022-01-13 16:54:27.961004 | 2022-01-13 16:54:51.852 HD Request # 96 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:54:51.852 Socket (9) | Creating socket. | 2022-01-13 16:54:51.852 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:54:51.853 Socket (9) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:54:51.853 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:54:52.130 Socket (8) | Closed. | 2022-01-13 16:54:52.130 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:54:52.169 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:54:52.169 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:54:52.169 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:54:52.169 Opened cached Intraday file: C:\SierraChart\Data\NQH22.scid. Thread ID: 11608 | 2022-01-13 16:54:52.325 HD Request # 96 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:01.476 HD Request # 96 | Sending historical data logon request message. | 2022-01-13 16:55:01.476 HD Request # 96 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:27. Record interval: 0. Symbol: 6AH22 | 2022-01-13 16:55:02.244 HD Request # 96 | Decompressing data. | 2022-01-13 16:55:02.540 HD Request # 96 | Receiving Intraday data for 6AH22 starting at 2022-01-13 16:54:27.961000 | 2022-01-13 16:55:02.540 Socket (9) | CloseSocket call. | 2022-01-13 16:55:02.541 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:02.541 Historical data download thread signaled to stop. | 2022-01-13 16:55:02.541 HD Request # 96 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:34.545000 | 2022-01-13 16:55:02.541 HD Request # 96 | Received 6 Intraday data records from 2022-01-13 16:54:27.961000 to 2022-01-13 16:54:34.545000 (6.6 seconds) and wrote 1 record for 6AH22 | 2022-01-13 16:55:02.541 HD Request # 96 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:54:34.545000 | 2022-01-13 16:55:02.552 HD Request # 96 | Completion time: 11s | 2022-01-13 16:55:02.552 HD Request # 96 | Intraday data download complete for 6AH22. Unique request ID: 168 | 2022-01-13 16:55:02.552 Removing historical data download ID 168. | 2022-01-13 16:55:02.552 Real-time Intraday chart data file updates started for 6AH22 | 2022-01-13 16:55:02.552 Intraday chart data file opened for 6AH22 | 2022-01-13 16:55:02.552 HD Request # 96 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:02.552 Triggering next historical data download in queue. | 2022-01-13 16:55:02.552 HD Request # 97 | Downloading Intraday chart data for ESH22 to the file ESH22.scid. Service: cme | 2022-01-13 16:55:02.552 HD Request # 97 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.138000 | 2022-01-13 16:55:02.553 HD Request # 97 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:55:02.553 Socket (8) | Creating socket. | 2022-01-13 16:55:02.553 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:55:02.553 Socket (8) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:55:02.553 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:55:02.857 Socket (9) | Closed. | 2022-01-13 16:55:02.857 HD Request # 97 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:03.166 HD Request # 97 | Sending historical data logon request message. | 2022-01-13 16:55:03.166 HD Request # 97 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:30. Record interval: 0. Symbol: ESH22 | 2022-01-13 16:55:03.460 HD Request # 97 | Decompressing data. | 2022-01-13 16:55:03.763 HD Request # 97 | Receiving Intraday data for ESH22 starting at 2022-01-13 16:54:30.009000 | 2022-01-13 16:55:03.764 Socket (8) | CloseSocket call. | 2022-01-13 16:55:03.767 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:03.767 Historical data download thread signaled to stop. | 2022-01-13 16:55:03.767 HD Request # 97 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:31.254000 | 2022-01-13 16:55:03.767 HD Request # 97 | Received 624 Intraday data records from 2022-01-13 16:54:30.009000 to 2022-01-13 16:55:01.374023 (31.4 seconds) and wrote 622 records for ESH22 | 2022-01-13 16:55:03.767 HD Request # 97 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:01.374023 | 2022-01-13 16:55:03.777 HD Request # 97 | Completion time: 1s | 2022-01-13 16:55:03.777 HD Request # 97 | Intraday data download complete for ESH22. Unique request ID: 169 | 2022-01-13 16:55:03.777 Removing historical data download ID 169. | 2022-01-13 16:55:03.777 Real-time Intraday chart data file updates started for ESH22 | 2022-01-13 16:55:03.777 Intraday chart data file opened for ESH22 | 2022-01-13 16:55:03.777 HD Request # 97 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:03.777 Triggering next historical data download in queue. | 2022-01-13 16:55:03.777 HD Request # 98 | Downloading Intraday chart data for 6CH22 to the file 6CH22.scid. Service: cme | 2022-01-13 16:55:03.777 HD Request # 98 | Download start date-time: 2022-01-13 16:54:21.000000. File last date-time: 2022-01-13 16:54:21.747003 | 2022-01-13 16:55:03.778 HD Request # 98 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:55:03.778 Socket (9) | Creating socket. | 2022-01-13 16:55:03.778 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:55:03.778 Socket (9) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:55:03.778 HD Request # 98 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:10.433 HD Request # 98 | Sending historical data logon request message. | 2022-01-13 16:55:10.434 HD Request # 98 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:21. Record interval: 0. Symbol: 6CH22 | 2022-01-13 16:55:10.724 HD Request # 98 | Decompressing data. | 2022-01-13 16:55:11.960 HD Request # 98 | Receiving Intraday data for 6CH22 starting at 2022-01-13 16:54:21.129000 | 2022-01-13 16:55:11.960 Socket (9) | CloseSocket call. | 2022-01-13 16:55:11.961 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:11.961 Historical data download thread signaled to stop. | 2022-01-13 16:55:11.962 HD Request # 98 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:44.108000 | 2022-01-13 16:55:11.962 HD Request # 98 | Received 20 Intraday data records from 2022-01-13 16:54:21.129000 to 2022-01-13 16:55:06.931000 (45.8 seconds) and wrote 15 records for 6CH22 | 2022-01-13 16:55:11.962 HD Request # 98 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:06.931000 | 2022-01-13 16:55:11.972 HD Request # 98 | Completion time: 8s | 2022-01-13 16:55:11.972 HD Request # 98 | Intraday data download complete for 6CH22. Unique request ID: 170 | 2022-01-13 16:55:11.972 Removing historical data download ID 170. | 2022-01-13 16:55:11.972 Real-time Intraday chart data file updates started for 6CH22 | 2022-01-13 16:55:11.972 Intraday chart data file opened for 6CH22 | 2022-01-13 16:55:11.972 HD Request # 98 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:11.972 Triggering next historical data download in queue. | 2022-01-13 16:55:11.972 HD Request # 99 | Downloading Intraday chart data for GCG22 to the file GCG22.scid. Service: comex | 2022-01-13 16:55:11.973 HD Request # 99 | Download start date-time: 2022-01-13 16:54:29.000000. File last date-time: 2022-01-13 16:54:29.635000 | 2022-01-13 16:55:11.973 HD Request # 99 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:55:11.973 Socket (11) | Creating socket. | 2022-01-13 16:55:11.974 Socket (11) | New receive buffer size: 5242880 | 2022-01-13 16:55:11.974 Socket (11) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:55:11.974 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:55:12.249 Socket (8) | Closed. | 2022-01-13 16:55:12.249 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:55:12.260 Socket (9) | Closed. | 2022-01-13 16:55:12.260 HD Request # 99 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:15.580 HD Request # 99 | Sending historical data logon request message. | 2022-01-13 16:55:15.580 HD Request # 99 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:29. Record interval: 0. Symbol: GCG22 | 2022-01-13 16:55:15.870 HD Request # 99 | Decompressing data. | 2022-01-13 16:55:16.161 HD Request # 99 | Receiving Intraday data for GCG22 starting at 2022-01-13 16:54:29.635000 | 2022-01-13 16:55:16.162 Socket (11) | CloseSocket call. | 2022-01-13 16:55:16.163 Socket (11) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:16.163 Historical data download thread signaled to stop. | 2022-01-13 16:55:16.164 HD Request # 99 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:31.259000 | 2022-01-13 16:55:16.164 HD Request # 99 | Received 60 Intraday data records from 2022-01-13 16:54:29.635000 to 2022-01-13 16:55:11.311000 (41.7 seconds) and wrote 59 records for GCG22 | 2022-01-13 16:55:16.164 HD Request # 99 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:11.311000 | 2022-01-13 16:55:16.174 HD Request # 99 | Completion time: 5s | 2022-01-13 16:55:16.174 HD Request # 99 | Intraday data download complete for GCG22. Unique request ID: 171 | 2022-01-13 16:55:16.174 Removing historical data download ID 171. | 2022-01-13 16:55:16.174 Real-time Intraday chart data file updates started for GCG22 | 2022-01-13 16:55:16.174 Intraday chart data file opened for GCG22 | 2022-01-13 16:55:16.174 HD Request # 99 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:16.174 Triggering next historical data download in queue. | 2022-01-13 16:55:16.175 HD Request # 100 | Downloading Intraday chart data for RBG22 to the file RBG22.scid. Service: nymex | 2022-01-13 16:55:16.175 HD Request # 100 | Download start date-time: 2022-01-13 16:54:11.000000. File last date-time: 2022-01-13 16:54:11.240000 | 2022-01-13 16:55:16.175 HD Request # 100 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:55:16.175 Socket (8) | Creating socket. | 2022-01-13 16:55:16.176 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:55:16.176 Socket (8) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:55:16.176 Socket (11) | Socket gracefully closed by remote side. | 2022-01-13 16:55:16.454 Socket (11) | Closed. | 2022-01-13 16:55:16.454 HD Request # 100 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:16.786 HD Request # 100 | Sending historical data logon request message. | 2022-01-13 16:55:16.786 HD Request # 100 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:11. Record interval: 0. Symbol: RBG22 | 2022-01-13 16:55:17.097 HD Request # 100 | Decompressing data. | 2022-01-13 16:55:17.387 HD Request # 100 | Receiving Intraday data for RBG22 starting at 2022-01-13 16:54:11.240000 | 2022-01-13 16:55:17.388 Socket (8) | CloseSocket call. | 2022-01-13 16:55:17.388 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:17.389 Historical data download thread signaled to stop. | 2022-01-13 16:55:17.389 HD Request # 100 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:39.007000 | 2022-01-13 16:55:17.389 HD Request # 100 | Received 9 Intraday data records from 2022-01-13 16:54:11.240000 to 2022-01-13 16:55:08.980000 (57.7 seconds) and wrote 8 records for RBG22 | 2022-01-13 16:55:17.390 HD Request # 100 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:08.980000 | 2022-01-13 16:55:17.400 HD Request # 100 | Completion time: 1s | 2022-01-13 16:55:17.400 HD Request # 100 | Intraday data download complete for RBG22. Unique request ID: 172 | 2022-01-13 16:55:17.400 Removing historical data download ID 172. | 2022-01-13 16:55:17.400 Real-time Intraday chart data file updates started for RBG22 | 2022-01-13 16:55:17.400 Intraday chart data file opened for RBG22 | 2022-01-13 16:55:17.400 HD Request # 100 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:17.400 Triggering next historical data download in queue. | 2022-01-13 16:55:17.400 HD Request # 101 | Downloading Intraday chart data for YMH22 to the file YMH22.scid. Service: cbot | 2022-01-13 16:55:17.400 HD Request # 101 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.197000 | 2022-01-13 16:55:17.401 HD Request # 101 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:55:17.401 Socket (9) | Creating socket. | 2022-01-13 16:55:17.401 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:55:17.401 Socket (9) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:55:17.401 Opened cached Intraday file: C:\SierraChart\Data\ESH22.scid. Thread ID: 11608 | 2022-01-13 16:55:17.546 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:55:17.677 Socket (8) | Closed. | 2022-01-13 16:55:17.677 HD Request # 101 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:17.992 HD Request # 101 | Sending historical data logon request message. | 2022-01-13 16:55:17.992 HD Request # 101 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:30. Record interval: 0. Symbol: YMH22 | 2022-01-13 16:55:18.287 HD Request # 101 | Decompressing data. | 2022-01-13 16:55:19.251 HD Request # 101 | Receiving Intraday data for YMH22 starting at 2022-01-13 16:54:30.072000 | 2022-01-13 16:55:19.251 Socket (9) | CloseSocket call. | 2022-01-13 16:55:19.252 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:19.252 Historical data download thread signaled to stop. | 2022-01-13 16:55:19.252 HD Request # 101 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:32.384000 | 2022-01-13 16:55:19.252 HD Request # 101 | Received 154 Intraday data records from 2022-01-13 16:54:30.072000 to 2022-01-13 16:55:13.465000 (43.4 seconds) and wrote 150 records for YMH22 | 2022-01-13 16:55:19.253 HD Request # 101 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:13.465000 | 2022-01-13 16:55:19.262 HD Request # 101 | Completion time: 2s | 2022-01-13 16:55:19.263 HD Request # 101 | Intraday data download complete for YMH22. Unique request ID: 173 | 2022-01-13 16:55:19.263 Removing historical data download ID 173. | 2022-01-13 16:55:19.263 Real-time Intraday chart data file updates started for YMH22 | 2022-01-13 16:55:19.263 Intraday chart data file opened for YMH22 | 2022-01-13 16:55:19.263 HD Request # 101 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:19.263 Triggering next historical data download in queue. | 2022-01-13 16:55:19.263 HD Request # 102 | Downloading Intraday chart data for ZNH22 to the file ZNH22.scid. Service: cbot | 2022-01-13 16:55:19.263 HD Request # 102 | Download start date-time: 2022-01-13 16:54:28.000000. File last date-time: 2022-01-13 16:54:28.312003 | 2022-01-13 16:55:19.263 HD Request # 102 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:55:19.264 Socket (8) | Creating socket. | 2022-01-13 16:55:19.264 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:55:19.264 Socket (8) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:55:19.264 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:55:19.541 Socket (9) | Closed. | 2022-01-13 16:55:19.541 HD Request # 102 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:19.868 HD Request # 102 | Sending historical data logon request message. | 2022-01-13 16:55:19.868 HD Request # 102 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:28. Record interval: 0. Symbol: ZNH22 | 2022-01-13 16:55:20.161 HD Request # 102 | Decompressing data. | 2022-01-13 16:55:24.795 HD Request # 102 | Receiving Intraday data for ZNH22 starting at 2022-01-13 16:54:28.312000 | 2022-01-13 16:55:24.795 Socket (8) | CloseSocket call. | 2022-01-13 16:55:25.131 Historical data download thread signaled to stop. | 2022-01-13 16:55:25.132 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:25.132 HD Request # 102 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:40.360000 | 2022-01-13 16:55:25.132 HD Request # 102 | Received 252 Intraday data records from 2022-01-13 16:54:28.312000 to 2022-01-13 16:55:14.018000 (45.7 seconds) and wrote 248 records for ZNH22 | 2022-01-13 16:55:25.132 HD Request # 102 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:14.018000 | 2022-01-13 16:55:25.142 HD Request # 102 | Completion time: 6s | 2022-01-13 16:55:25.142 HD Request # 102 | Intraday data download complete for ZNH22. Unique request ID: 174 | 2022-01-13 16:55:25.142 Removing historical data download ID 174. | 2022-01-13 16:55:25.142 Real-time Intraday chart data file updates started for ZNH22 | 2022-01-13 16:55:25.142 Intraday chart data file opened for ZNH22 | 2022-01-13 16:55:25.142 HD Request # 102 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:25.142 Triggering next historical data download in queue. | 2022-01-13 16:55:25.142 HD Request # 103 | Downloading Intraday chart data for ZFH22 to the file ZFH22.scid. Service: cbot | 2022-01-13 16:55:25.143 HD Request # 103 | Download start date-time: 2022-01-13 16:54:15.000000. File last date-time: 2022-01-13 16:54:15.585000 | 2022-01-13 16:55:25.143 HD Request # 103 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:55:25.143 Socket (9) | Creating socket. | 2022-01-13 16:55:25.144 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:55:25.144 Socket (9) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:55:25.144 HD Request # 103 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:25.742 HD Request # 103 | Sending historical data logon request message. | 2022-01-13 16:55:25.742 HD Request # 103 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:15. Record interval: 0. Symbol: ZFH22 | 2022-01-13 16:55:26.518 HD Request # 103 | Decompressing data. | 2022-01-13 16:55:26.809 HD Request # 103 | Receiving Intraday data for ZFH22 starting at 2022-01-13 16:54:15.091000 | 2022-01-13 16:55:26.810 Socket (9) | CloseSocket call. | 2022-01-13 16:55:26.811 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:26.812 Historical data download thread signaled to stop. | 2022-01-13 16:55:26.812 HD Request # 103 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:34.680000 | 2022-01-13 16:55:26.812 HD Request # 103 | Received 216 Intraday data records from 2022-01-13 16:54:15.091000 to 2022-01-13 16:55:21.011000 (65.9 seconds) and wrote 206 records for ZFH22 | 2022-01-13 16:55:26.812 HD Request # 103 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:21.011000 | 2022-01-13 16:55:26.822 HD Request # 103 | Completion time: 1s | 2022-01-13 16:55:26.822 HD Request # 103 | Intraday data download complete for ZFH22. Unique request ID: 175 | 2022-01-13 16:55:26.822 Removing historical data download ID 175. | 2022-01-13 16:55:26.822 Real-time Intraday chart data file updates started for ZFH22 | 2022-01-13 16:55:26.822 Intraday chart data file opened for ZFH22 | 2022-01-13 16:55:26.822 HD Request # 103 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:26.822 Triggering next historical data download in queue. | 2022-01-13 16:55:26.822 HD Request # 104 | Downloading Intraday chart data for NGG22 to the file NGG22.scid. Service: nymex | 2022-01-13 16:55:26.822 HD Request # 104 | Download start date-time: 2022-01-13 16:54:27.000000. File last date-time: 2022-01-13 16:54:27.155000 | 2022-01-13 16:55:26.823 HD Request # 104 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:55:26.823 Socket (10) | Creating socket. | 2022-01-13 16:55:26.823 Socket (10) | New receive buffer size: 5242880 | 2022-01-13 16:55:26.823 Socket (10) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:55:26.823 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:55:27.104 Socket (9) | Closed. | 2022-01-13 16:55:27.104 HD Request # 104 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:33.460 HD Request # 104 | Sending historical data logon request message. | 2022-01-13 16:55:33.460 HD Request # 104 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:27. Record interval: 0. Symbol: NGG22 | 2022-01-13 16:55:34.247 HD Request # 104 | Decompressing data. | 2022-01-13 16:55:37.195 HD Request # 104 | Receiving Intraday data for NGG22 starting at 2022-01-13 16:54:27.155000 | 2022-01-13 16:55:37.195 Socket (10) | CloseSocket call. | 2022-01-13 16:55:37.196 Socket (10) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:37.196 Historical data download thread signaled to stop. | 2022-01-13 16:55:37.197 HD Request # 104 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:30.899000 | 2022-01-13 16:55:37.197 HD Request # 104 | Received 63 Intraday data records from 2022-01-13 16:54:27.155000 to 2022-01-13 16:55:26.029000 (58.9 seconds) and wrote 62 records for NGG22 | 2022-01-13 16:55:37.197 HD Request # 104 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:26.029000 | 2022-01-13 16:55:37.207 HD Request # 104 | Completion time: 11s | 2022-01-13 16:55:37.207 HD Request # 104 | Intraday data download complete for NGG22. Unique request ID: 176 | 2022-01-13 16:55:37.207 Removing historical data download ID 176. | 2022-01-13 16:55:37.207 Real-time Intraday chart data file updates started for NGG22 | 2022-01-13 16:55:37.207 Intraday chart data file opened for NGG22 | 2022-01-13 16:55:37.207 HD Request # 104 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:37.207 Triggering next historical data download in queue. | 2022-01-13 16:55:37.207 HD Request # 105 | Downloading Intraday chart data for TNH22 to the file TNH22.scid. Service: cbot | 2022-01-13 16:55:37.207 HD Request # 105 | Download start date-time: 2022-01-13 16:54:21.000000. File last date-time: 2022-01-13 16:54:21.359004 | 2022-01-13 16:55:37.208 HD Request # 105 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:55:37.208 Socket (9) | Creating socket. | 2022-01-13 16:55:37.209 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:55:37.209 Socket (9) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:55:37.209 HD Request # 105 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:40.812 HD Request # 105 | Sending historical data logon request message. | 2022-01-13 16:55:40.812 HD Request # 105 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:21. Record interval: 0. Symbol: TNH22 | 2022-01-13 16:55:41.105 HD Request # 105 | Decompressing data. | 2022-01-13 16:55:41.412 HD Request # 105 | Receiving Intraday data for TNH22 starting at 2022-01-13 16:54:21.357000 | 2022-01-13 16:55:41.413 Socket (9) | CloseSocket call. | 2022-01-13 16:55:41.414 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:41.415 Historical data download thread signaled to stop. | 2022-01-13 16:55:41.415 HD Request # 105 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:44.661000 | 2022-01-13 16:55:41.415 HD Request # 105 | Received 96 Intraday data records from 2022-01-13 16:54:21.357000 to 2022-01-13 16:55:36.729001 (75.4 seconds) and wrote 90 records for TNH22 | 2022-01-13 16:55:41.415 HD Request # 105 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:36.729001 | 2022-01-13 16:55:41.425 HD Request # 105 | Completion time: 4s | 2022-01-13 16:55:41.425 HD Request # 105 | Intraday data download complete for TNH22. Unique request ID: 177 | 2022-01-13 16:55:41.425 Removing historical data download ID 177. | 2022-01-13 16:55:41.425 Real-time Intraday chart data file updates started for TNH22 | 2022-01-13 16:55:41.425 Intraday chart data file opened for TNH22 | 2022-01-13 16:55:41.425 HD Request # 105 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:41.425 Triggering next historical data download in queue. | 2022-01-13 16:55:41.425 HD Request # 106 | Downloading Intraday chart data for CLG22 to the file CLG22.scid. Service: nymex | 2022-01-13 16:55:41.425 HD Request # 106 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.075000 | 2022-01-13 16:55:41.426 HD Request # 106 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:55:41.426 Socket (11) | Creating socket. | 2022-01-13 16:55:41.426 Socket (11) | New receive buffer size: 5242880 | 2022-01-13 16:55:41.426 Socket (11) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:55:41.426 HD Request # 106 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:42.032 HD Request # 106 | Sending historical data logon request message. | 2022-01-13 16:55:42.032 HD Request # 106 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:30. Record interval: 0. Symbol: CLG22 | 2022-01-13 16:55:42.325 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:55:42.397 Socket (9) | Closed. | 2022-01-13 16:55:42.398 Opened cached Intraday file: C:\SierraChart\Data\YMH22.scid. Thread ID: 11608 | 2022-01-13 16:55:42.765 HD Request # 106 | Decompressing data. | 2022-01-13 16:55:43.291 HD Request # 106 | Receiving Intraday data for CLG22 starting at 2022-01-13 16:54:30.016000 | 2022-01-13 16:55:43.291 Socket (11) | CloseSocket call. | 2022-01-13 16:55:43.292 Socket (11) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:43.292 Historical data download thread signaled to stop. | 2022-01-13 16:55:43.297 HD Request # 106 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:30.616000 | 2022-01-13 16:55:43.297 HD Request # 106 | Received 159 Intraday data records from 2022-01-13 16:54:30.016000 to 2022-01-13 16:55:35.739000 (65.7 seconds) and wrote 156 records for CLG22 | 2022-01-13 16:55:43.298 HD Request # 106 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:35.739000 | 2022-01-13 16:55:43.306 HD Request # 106 | Completion time: 2s | 2022-01-13 16:55:43.306 HD Request # 106 | Intraday data download complete for CLG22. Unique request ID: 178 | 2022-01-13 16:55:43.306 Removing historical data download ID 178. | 2022-01-13 16:55:43.306 Real-time Intraday chart data file updates started for CLG22 | 2022-01-13 16:55:43.306 Intraday chart data file opened for CLG22 | 2022-01-13 16:55:43.306 HD Request # 106 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:43.306 Triggering next historical data download in queue. | 2022-01-13 16:55:43.306 HD Request # 107 | Downloading Intraday chart data for 6EH22 to the file 6EH22.scid. Service: cme | 2022-01-13 16:55:43.306 HD Request # 107 | Download start date-time: 2022-01-13 16:54:24.000000. File last date-time: 2022-01-13 16:54:24.848001 | 2022-01-13 16:55:43.307 HD Request # 107 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:55:43.307 Socket (9) | Creating socket. | 2022-01-13 16:55:43.307 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:55:43.307 Socket (9) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:55:43.308 Socket (10) | Socket gracefully closed by remote side. | 2022-01-13 16:55:43.558 Socket (10) | Closed. | 2022-01-13 16:55:43.559 Socket (11) | Socket gracefully closed by remote side. | 2022-01-13 16:55:45.467 Socket (11) | Closed. | 2022-01-13 16:55:45.467 HD Request # 107 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:46.912 HD Request # 107 | Sending historical data logon request message. | 2022-01-13 16:55:46.912 HD Request # 107 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:24. Record interval: 0. Symbol: 6EH22 | 2022-01-13 16:55:47.205 Opened cached Intraday file: C:\SierraChart\Data\GCG22.scid. Thread ID: 11608 | 2022-01-13 16:55:47.782 Opened cached Intraday file: C:\SierraChart\Data\NGG22.scid. Thread ID: 11608 | 2022-01-13 16:55:47.782 HD Request # 107 | Decompressing data. | 2022-01-13 16:55:48.283 HD Request # 107 | Receiving Intraday data for 6EH22 starting at 2022-01-13 16:54:24.827000 | 2022-01-13 16:55:48.284 Socket (9) | CloseSocket call. | 2022-01-13 16:55:48.284 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:48.285 Historical data download thread signaled to stop. | 2022-01-13 16:55:48.285 HD Request # 107 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:44.662000 | 2022-01-13 16:55:48.285 HD Request # 107 | Received 46 Intraday data records from 2022-01-13 16:54:24.827000 to 2022-01-13 16:55:40.175000 (75.3 seconds) and wrote 35 records for 6EH22 | 2022-01-13 16:55:48.285 HD Request # 107 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:40.175000 | 2022-01-13 16:55:48.295 HD Request # 107 | Completion time: 5s | 2022-01-13 16:55:48.295 HD Request # 107 | Intraday data download complete for 6EH22. Unique request ID: 179 | 2022-01-13 16:55:48.295 Removing historical data download ID 179. | 2022-01-13 16:55:48.295 Real-time Intraday chart data file updates started for 6EH22 | 2022-01-13 16:55:48.295 Intraday chart data file opened for 6EH22 | 2022-01-13 16:55:48.295 HD Request # 107 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:48.295 Triggering next historical data download in queue. | 2022-01-13 16:55:48.295 HD Request # 108 | Downloading Intraday chart data for ZBH22 to the file ZBH22.scid. Service: cbot | 2022-01-13 16:55:48.295 HD Request # 108 | Download start date-time: 2022-01-13 16:54:24.000000. File last date-time: 2022-01-13 16:54:24.828000 | 2022-01-13 16:55:48.296 HD Request # 108 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:55:48.296 Socket (10) | Creating socket. | 2022-01-13 16:55:48.296 Socket (10) | New receive buffer size: 5242880 | 2022-01-13 16:55:48.297 Socket (10) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:55:48.297 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:55:48.574 Socket (9) | Closed. | 2022-01-13 16:55:48.574 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:55:53.087 Socket (8) | Closed. | 2022-01-13 16:55:53.087 HD Request # 108 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:54.927 HD Request # 108 | Sending historical data logon request message. | 2022-01-13 16:55:54.927 HD Request # 108 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:24. Record interval: 0. Symbol: ZBH22 | 2022-01-13 16:55:55.223 HD Request # 108 | Decompressing data. | 2022-01-13 16:55:55.514 HD Request # 108 | Receiving Intraday data for ZBH22 starting at 2022-01-13 16:54:24.413000 | 2022-01-13 16:55:55.516 Socket (10) | CloseSocket call. | 2022-01-13 16:55:55.517 Socket (10) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:55.517 Historical data download thread signaled to stop. | 2022-01-13 16:55:55.517 HD Request # 108 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:03.565000 | 2022-01-13 16:55:55.517 HD Request # 108 | Received 79 Intraday data records from 2022-01-13 16:54:24.413000 to 2022-01-13 16:55:50.428023 (86.0 seconds) and wrote 76 records for ZBH22 | 2022-01-13 16:55:55.518 HD Request # 108 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:50.428023 | 2022-01-13 16:55:55.528 HD Request # 108 | Completion time: 7s | 2022-01-13 16:55:55.528 HD Request # 108 | Intraday data download complete for ZBH22. Unique request ID: 180 | 2022-01-13 16:55:55.528 Removing historical data download ID 180. | 2022-01-13 16:55:55.528 Real-time Intraday chart data file updates started for ZBH22 | 2022-01-13 16:55:55.528 Intraday chart data file opened for ZBH22 | 2022-01-13 16:55:55.528 HD Request # 108 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:55.528 Triggering next historical data download in queue. | 2022-01-13 16:55:55.528 HD Request # 109 | Downloading Intraday chart data for 6BH22 to the file 6BH22.scid. Service: cme | 2022-01-13 16:55:55.528 HD Request # 109 | Download start date-time: 2022-01-13 16:54:25.000000. File last date-time: 2022-01-13 16:54:25.009000 | 2022-01-13 16:55:55.529 HD Request # 109 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:55:55.529 Socket (8) | Creating socket. | 2022-01-13 16:55:55.529 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:55:55.530 Socket (8) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:55:55.530 HD Request # 109 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:56.123 HD Request # 109 | Sending historical data logon request message. | 2022-01-13 16:55:56.123 Socket (10) | Socket gracefully closed by remote side. | 2022-01-13 16:55:56.627 Socket (10) | Closed. | 2022-01-13 16:55:56.627 HD Request # 109 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:25. Record interval: 0. Symbol: 6BH22 | 2022-01-13 16:55:56.895 HD Request # 109 | Decompressing data. | 2022-01-13 16:55:57.193 HD Request # 109 | Receiving Intraday data for 6BH22 starting at 2022-01-13 16:54:25.009000 | 2022-01-13 16:55:57.194 Socket (8) | CloseSocket call. | 2022-01-13 16:55:57.195 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:55:57.195 Historical data download thread signaled to stop. | 2022-01-13 16:55:57.195 HD Request # 109 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:34.164000 | 2022-01-13 16:55:57.195 HD Request # 109 | Received 38 Intraday data records from 2022-01-13 16:54:25.009000 to 2022-01-13 16:55:49.952000 (84.9 seconds) and wrote 37 records for 6BH22 | 2022-01-13 16:55:57.195 HD Request # 109 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:49.952000 | 2022-01-13 16:55:57.205 HD Request # 109 | Completion time: 2s | 2022-01-13 16:55:57.205 HD Request # 109 | Intraday data download complete for 6BH22. Unique request ID: 181 | 2022-01-13 16:55:57.205 Removing historical data download ID 181. | 2022-01-13 16:55:57.205 Real-time Intraday chart data file updates started for 6BH22 | 2022-01-13 16:55:57.205 Intraday chart data file opened for 6BH22 | 2022-01-13 16:55:57.205 HD Request # 109 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:55:57.205 Triggering next historical data download in queue. | 2022-01-13 16:55:57.205 HD Request # 110 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 16:55:57.205 HD Request # 110 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.215000 | 2022-01-13 16:55:57.206 HD Request # 110 | Using server: ds13-3.sierracharts.com port 10149 | 2022-01-13 16:55:57.206 Socket (9) | Creating socket. | 2022-01-13 16:55:57.207 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:55:57.207 Socket (9) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:55:57.207 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:55:57.494 Socket (8) | Closed. | 2022-01-13 16:55:57.495 HD Request # 110 | Setting DTC encoding to Binary VLS | 2022-01-13 16:55:57.898 HD Request # 110 | Sending historical data logon request message. | 2022-01-13 16:55:57.898 HD Request # 110 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:30. Record interval: 0. Symbol: ADV-NYSE | 2022-01-13 16:55:59.767 HD Request # 110 | Decompressing data. | 2022-01-13 16:56:00.136 HD Request # 110 | Receiving Intraday data for ADV-NYSE starting at 2022-01-13 16:54:30.000000 | 2022-01-13 16:56:00.137 Socket (9) | CloseSocket call. | 2022-01-13 16:56:00.137 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:56:00.138 Historical data download thread signaled to stop. | 2022-01-13 16:56:00.140 HD Request # 110 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:31.000000 | 2022-01-13 16:56:00.140 HD Request # 110 | Received 87 Intraday data records from 2022-01-13 16:54:30.000000 to 2022-01-13 16:55:56.000000 (86.0 seconds) and wrote 86 records for ADV-NYSE | 2022-01-13 16:56:00.140 HD Request # 110 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:55:56.000000 | 2022-01-13 16:56:00.150 HD Request # 110 | Completion time: 3s | 2022-01-13 16:56:00.150 HD Request # 110 | Intraday data download complete for ADV-NYSE. Unique request ID: 182 | 2022-01-13 16:56:00.150 Removing historical data download ID 182. | 2022-01-13 16:56:00.150 Real-time Intraday chart data file updates started for ADV-NYSE | 2022-01-13 16:56:00.150 Intraday chart data file opened for ADV-NYSE | 2022-01-13 16:56:00.150 HD Request # 110 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:56:00.150 Triggering next historical data download in queue. | 2022-01-13 16:56:00.150 HD Request # 111 | Downloading Intraday chart data for TRIN-SP to the file TRIN-SP.scid. Service: statscalc | 2022-01-13 16:56:00.150 HD Request # 111 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.215002 | 2022-01-13 16:56:00.151 HD Request # 111 | Using server: ds4.sierracharts.com port 10150 | 2022-01-13 16:56:00.151 Socket (8) | Creating socket. | 2022-01-13 16:56:00.151 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:56:00.151 Socket (8) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:56:00.151 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:56:00.489 Socket (9) | Closed. | 2022-01-13 16:56:00.489 Socket (8) | CloseSocket call. | 2022-01-13 16:56:20.150 Socket (8) | Closed. | 2022-01-13 16:56:20.151 HD Request # 111 | Error downloading historical Intraday data for TRIN-SP. Timeout error connecting to server. | 2022-01-13 16:56:20.151 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:56:20.151 Triggering next historical data download in queue. | 2022-01-13 16:56:20.151 Historical data download thread signaled to stop. | 2022-01-13 16:56:20.151 HD Request # 111 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for TRIN-SP | 2022-01-13 16:56:20.151 HD Request # 111 | Completion time: 20s | 2022-01-13 16:56:20.151 HD Request # 112 | Downloading Intraday chart data for TRIN-SP to the file TRIN-SP.scid. Service: statscalc | 2022-01-13 16:56:20.151 HD Request # 112 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.215002 | 2022-01-13 16:56:20.152 HD Request # 112 | Using server: ds12.sierracharts.com port 10149 | 2022-01-13 16:56:20.152 Socket (8) | Creating socket. | 2022-01-13 16:56:20.152 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:56:20.152 Socket (8) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:56:20.152 HD Request # 112 | Setting DTC encoding to Binary VLS | 2022-01-13 16:56:20.759 HD Request # 112 | Sending historical data logon request message. | 2022-01-13 16:56:20.759 HD Request # 112 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:30. Record interval: 0. Symbol: TRIN-SP | 2022-01-13 16:56:21.596 HD Request # 112 | Decompressing data. | 2022-01-13 16:56:21.889 HD Request # 112 | Receiving Intraday data for TRIN-SP starting at 2022-01-13 16:54:30.000000 | 2022-01-13 16:56:21.891 Socket (8) | CloseSocket call. | 2022-01-13 16:56:21.892 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:56:21.893 Historical data download thread signaled to stop. | 2022-01-13 16:56:21.893 HD Request # 112 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:31.000000 | 2022-01-13 16:56:21.893 HD Request # 112 | Received 109 Intraday data records from 2022-01-13 16:54:30.000000 to 2022-01-13 16:56:18.000000 (108.0 seconds) and wrote 108 records for TRIN-SP | 2022-01-13 16:56:21.893 HD Request # 112 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:56:18.000000 | 2022-01-13 16:56:21.908 HD Request # 112 | Completion time: 1s | 2022-01-13 16:56:21.908 HD Request # 112 | Intraday data download complete for TRIN-SP. Unique request ID: 183 | 2022-01-13 16:56:21.908 Removing historical data download ID 183. | 2022-01-13 16:56:21.908 Real-time Intraday chart data file updates started for TRIN-SP | 2022-01-13 16:56:21.908 Intraday chart data file opened for TRIN-SP | 2022-01-13 16:56:21.908 HD Request # 112 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:56:21.908 Triggering next historical data download in queue. | 2022-01-13 16:56:21.908 HD Request # 113 | Downloading Intraday chart data for 6JH22 to the file 6JH22.scid. Service: cme | 2022-01-13 16:56:21.908 HD Request # 113 | Download start date-time: 2022-01-13 16:54:29.000000. File last date-time: 2022-01-13 16:54:29.634000 | 2022-01-13 16:56:21.909 HD Request # 113 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 16:56:21.909 Socket (9) | Creating socket. | 2022-01-13 16:56:21.909 Socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:56:21.909 Socket (9) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:56:21.909 HD Request # 113 | Setting DTC encoding to Binary VLS | 2022-01-13 16:56:22.513 HD Request # 113 | Sending historical data logon request message. | 2022-01-13 16:56:22.513 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:56:22.769 Socket (8) | Closed. | 2022-01-13 16:56:22.769 HD Request # 113 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:29. Record interval: 0. Symbol: 6JH22 | 2022-01-13 16:56:23.303 HD Request # 113 | Decompressing data. | 2022-01-13 16:56:23.597 HD Request # 113 | Receiving Intraday data for 6JH22 starting at 2022-01-13 16:54:29.633000 | 2022-01-13 16:56:23.598 Socket (9) | CloseSocket call. | 2022-01-13 16:56:23.599 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:56:23.600 Historical data download thread signaled to stop. | 2022-01-13 16:56:23.600 HD Request # 113 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:32.340000 | 2022-01-13 16:56:23.600 HD Request # 113 | Received 167 Intraday data records from 2022-01-13 16:54:29.633000 to 2022-01-13 16:56:10.607001 (101.0 seconds) and wrote 152 records for 6JH22 | 2022-01-13 16:56:23.600 HD Request # 113 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:56:10.607001 | 2022-01-13 16:56:23.612 HD Request # 113 | Completion time: 2s | 2022-01-13 16:56:23.612 HD Request # 113 | Intraday data download complete for 6JH22. Unique request ID: 184 | 2022-01-13 16:56:23.612 Removing historical data download ID 184. | 2022-01-13 16:56:23.612 Real-time Intraday chart data file updates started for 6JH22 | 2022-01-13 16:56:23.612 Intraday chart data file opened for 6JH22 | 2022-01-13 16:56:23.612 HD Request # 113 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:56:23.612 Triggering next historical data download in queue. | 2022-01-13 16:56:23.612 HD Request # 114 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc | 2022-01-13 16:56:23.612 HD Request # 114 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.215000 | 2022-01-13 16:56:23.613 HD Request # 114 | Using server: ds13-3.sierracharts.com port 10149 | 2022-01-13 16:56:23.613 Socket (8) | Creating socket. | 2022-01-13 16:56:23.613 Socket (8) | New receive buffer size: 5242880 | 2022-01-13 16:56:23.614 Socket (8) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:56:23.614 Socket (9) | Socket gracefully closed by remote side. | 2022-01-13 16:56:23.890 Socket (9) | Closed. | 2022-01-13 16:56:23.890 HD Request # 114 | Setting DTC encoding to Binary VLS | 2022-01-13 16:56:25.372 HD Request # 114 | Sending historical data logon request message. | 2022-01-13 16:56:25.372 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:56:36.392 DTC Client socket (2) | Closed. | 2022-01-13 16:56:36.392 SC Data - All Services | There has been no activity on the network socket for 57s. Will reconnect. | 2022-01-13 16:56:43.240 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 16:56:43.240 DTC Client socket (7) | CloseSocket call. | 2022-01-13 16:56:43.241 DTC Client socket (7) | Max send buffers used during socket life: 4 | 2022-01-13 16:56:43.241 DTC Client socket (7) | Max send buffer size during socket life: 1242 | 2022-01-13 16:56:43.241 DTC Client socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:56:43.241 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 16:56:43.241 WSACleanup called. | 2022-01-13 16:56:43.241 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 16:56:43.242 DTC Client socket (5) | CloseSocket call. | 2022-01-13 16:56:43.242 DTC Client socket (5) | Max send buffers used during socket life: 4 | 2022-01-13 16:56:43.242 DTC Client socket (5) | Max send buffer size during socket life: 1746 | 2022-01-13 16:56:43.242 SC Data - All Services | Disconnected from the server. | 2022-01-13 16:56:43.242 DTC Client socket (5) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:56:43.242 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 16:56:43.243 SC DTC Data with Market Depth | There has been no activity on the network socket for 1m 20s. Will reconnect. | 2022-01-13 16:56:43.509 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:56:43.509 DTC Client socket (4) | CloseSocket call. | 2022-01-13 16:56:43.510 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:56:43.510 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:56:43.510 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 16:56:43.510 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2022-01-13 16:56:45.241 DTC Client socket (9) | Creating socket. | 2022-01-13 16:56:45.241 DTC Client socket (9) | New receive buffer size: 5242880 | 2022-01-13 16:56:45.242 DTC Client socket (9) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:56:45.242 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 443 | 2022-01-13 16:56:45.524 DTC Client socket (10) | Creating socket. | 2022-01-13 16:56:45.586 DTC Client socket (10) | New receive buffer size: 5242880 | 2022-01-13 16:56:45.586 DTC Client socket (10) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:56:45.586 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:56:45.935 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:56:45.935 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:56:45.935 HD Request # 114 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:30. Record interval: 0. Symbol: ADR-NASDAQ | 2022-01-13 16:56:47.169 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:56:47.386 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:56:47.386 SC Data - All Services | Network connection to server complete. | 2022-01-13 16:56:48.531 SC Data - All Services | Starting socket receive thread. | 2022-01-13 16:56:48.531 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:56:48.531 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 16:56:48.854 SC Data - All Services | Sending logon request message. | 2022-01-13 16:56:48.854 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:56:49.348 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:56:49.348 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:56:49.348 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:56:49.348 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:56:49.348 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:56:49.348 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:56:49.348 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:56:49.348 Triggering next historical data download in queue. | 2022-01-13 16:56:49.348 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:56:49.348 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:56:49.348 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:56:49.348 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2022-01-13 16:56:49.348 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:56:49.348 SC Data - All Services | Received logon response. | 2022-01-13 16:56:49.845 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 16:56:49.845 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:56:49.845 SC Data - All Services | Successfully connected. | 2022-01-13 16:56:49.845 SC Data - All Services | Trading is not supported. | 2022-01-13 16:56:49.845 SC Data - All Services (Market Orders Data) | Connecting to the server ds21.sierracharts.com. Port 10060 | 2022-01-13 16:56:49.851 Added historical Intraday data request for 6AH22 to the queue. | 2022-01-13 16:56:49.851 Intraday data recording state for symbol 6AH22 is set to download 'Pending'. | 2022-01-13 16:56:49.851 Triggering next historical data download in queue. | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: 6AH22 -> 6AH22. Market Depth data restarted. | 2022-01-13 16:56:49.851 Added historical Intraday data request for 6BH22 to the queue. | 2022-01-13 16:56:49.851 Intraday data recording state for symbol 6BH22 is set to download 'Pending'. | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: 6BH22 -> 6BH22. Market Depth data restarted. | 2022-01-13 16:56:49.851 Added historical Intraday data request for 6CH22 to the queue. | 2022-01-13 16:56:49.851 Intraday data recording state for symbol 6CH22 is set to download 'Pending'. | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: 6CH22 -> 6CH22. Market Depth data restarted. | 2022-01-13 16:56:49.851 Added historical Intraday data request for 6EH22 to the queue. | 2022-01-13 16:56:49.851 Intraday data recording state for symbol 6EH22 is set to download 'Pending'. | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: 6EH22 -> 6EH22. Market Depth data restarted. | 2022-01-13 16:56:49.851 Added historical Intraday data request for 6JH22 to the queue. | 2022-01-13 16:56:49.851 Intraday data recording state for symbol 6JH22 is set to download 'Pending'. | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: 6JH22 -> 6JH22. Market Depth data restarted. | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: 6MH22 -> 6MH22 | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: 6SH22 -> 6SH22 | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: BBH22 -> BBH22 | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: BTCF22 -> BTCF22 | 2022-01-13 16:56:49.851 Added historical Intraday data request for CLG22 to the queue. | 2022-01-13 16:56:49.851 Intraday data recording state for symbol CLG22 is set to download 'Pending'. | 2022-01-13 16:56:49.851 SC Data - All Services | Restarting real-time data updates for symbol: CLG22 -> CLG22. Market Depth data restarted. | 2022-01-13 16:56:49.851 DTC Client socket (11) | Creating socket. | 2022-01-13 16:56:49.852 Added historical Intraday data request for ESH22 to the queue. | 2022-01-13 16:56:49.852 Intraday data recording state for symbol ESH22 is set to download 'Pending'. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22. Market Depth data restarted. | 2022-01-13 16:56:49.852 DTC Client socket (11) | New receive buffer size: 5242880 | 2022-01-13 16:56:49.852 DTC Client socket (11) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:56:49.852 Added historical Intraday data request for GCG22 to the queue. | 2022-01-13 16:56:49.852 Intraday data recording state for symbol GCG22 is set to download 'Pending'. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: GCG22 -> GCG22. Market Depth data restarted. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: HOG22 -> HOG22 | 2022-01-13 16:56:49.852 Added historical Intraday data request for NGG22 to the queue. | 2022-01-13 16:56:49.852 Intraday data recording state for symbol NGG22 is set to download 'Pending'. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: NGG22 -> NGG22. Market Depth data restarted. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: NKDH22 -> NKDH22 | 2022-01-13 16:56:49.852 Added historical Intraday data request for NQH22 to the queue. | 2022-01-13 16:56:49.852 Intraday data recording state for symbol NQH22 is set to download 'Pending'. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: NQH22 -> NQH22. Market Depth data restarted. | 2022-01-13 16:56:49.852 Added historical Intraday data request for RBG22 to the queue. | 2022-01-13 16:56:49.852 Intraday data recording state for symbol RBG22 is set to download 'Pending'. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: RBG22 -> RBG22. Market Depth data restarted. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: RTYH22 -> RTYH22 | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: SIH22 -> SIH22 | 2022-01-13 16:56:49.852 Added historical Intraday data request for TNH22 to the queue. | 2022-01-13 16:56:49.852 Intraday data recording state for symbol TNH22 is set to download 'Pending'. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: TNH22 -> TNH22. Market Depth data restarted. | 2022-01-13 16:56:49.852 Added historical Intraday data request for YMH22 to the queue. | 2022-01-13 16:56:49.852 Intraday data recording state for symbol YMH22 is set to download 'Pending'. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: YMH22 -> YMH22. Market Depth data restarted. | 2022-01-13 16:56:49.852 Added historical Intraday data request for ZBH22 to the queue. | 2022-01-13 16:56:49.852 Intraday data recording state for symbol ZBH22 is set to download 'Pending'. | 2022-01-13 16:56:49.852 SC Data - All Services | Restarting real-time data updates for symbol: ZBH22 -> ZBH22. Market Depth data restarted. | 2022-01-13 16:56:49.852 Added historical Intraday data request for ZFH22 to the queue. | 2022-01-13 16:56:49.853 Intraday data recording state for symbol ZFH22 is set to download 'Pending'. | 2022-01-13 16:56:49.853 SC Data - All Services | Restarting real-time data updates for symbol: ZFH22 -> ZFH22. Market Depth data restarted. | 2022-01-13 16:56:49.853 Added historical Intraday data request for ZNH22 to the queue. | 2022-01-13 16:56:49.853 Intraday data recording state for symbol ZNH22 is set to download 'Pending'. | 2022-01-13 16:56:49.853 SC Data - All Services | Restarting real-time data updates for symbol: ZNH22 -> ZNH22. Market Depth data restarted. | 2022-01-13 16:56:49.853 SC Data - All Services | Restarting real-time data updates for symbol: ZTH22 -> ZTH22 | 2022-01-13 16:56:49.853 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 16:56:50.152 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 16:56:50.152 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:56:50.152 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 16:56:50.474 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 16:56:50.474 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6AH22 -> 6AH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6BH22 -> 6BH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6CH22 -> 6CH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6EH22 -> 6EH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6JH22 -> 6JH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 25. Service code: nymex | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLG22 -> CLG22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 15. Service code: comex | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: GCG22 -> GCG22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGG22 -> NGG22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 15. Service code: cme | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NQH22 -> NQH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: RBG22 -> RBG22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: TNH22 -> TNH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 20. Service code: cbot | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: YMH22 -> YMH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 200. Service code: cbot | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZBH22 -> ZBH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZFH22 -> ZFH22 | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 1500. Service code: cbot | 2022-01-13 16:56:51.596 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZNH22 -> ZNH22 | 2022-01-13 16:56:51.596 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:56:52.500 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:56:52.500 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:56:52.500 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:56:52.500 SC Data - All Services | Clearing market depth for 6AH22 | 2022-01-13 16:56:53.138 SC Data - All Services | Clearing market depth for 6BH22 | 2022-01-13 16:56:53.138 SC Data - All Services | Clearing market depth for 6CH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for 6EH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for 6JH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for CLG22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for ESH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for GCG22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for NGG22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for NQH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for RBG22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for TNH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for YMH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for ZBH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for ZFH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Clearing market depth for ZNH22 | 2022-01-13 16:56:53.139 SC Data - All Services | Received security definition for symbol 6AH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol 6BH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol 6CH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol 6EH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol 6JH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol 6MH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol 6SH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol BBH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol BTCF22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol CLG22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol ESH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol GCG22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol HOG22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol NGG22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol NKDH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol NQH22 | 2022-01-13 16:56:53.142 SC Data - All Services | Received security definition for symbol RBG22 | 2022-01-13 16:56:53.143 SC Data - All Services | Received security definition for symbol RTYH22 | 2022-01-13 16:56:53.143 SC Data - All Services | Received security definition for symbol SIH22 | 2022-01-13 16:56:53.143 SC Data - All Services | Received security definition for symbol TNH22 | 2022-01-13 16:56:53.143 SC Data - All Services | Received security definition for symbol YMH22 | 2022-01-13 16:56:53.143 SC Data - All Services | Received security definition for symbol ZBH22 | 2022-01-13 16:56:53.143 SC Data - All Services | Received security definition for symbol ZFH22 | 2022-01-13 16:56:53.143 SC Data - All Services | Received security definition for symbol ZNH22 | 2022-01-13 16:56:53.143 SC Data - All Services | Received security definition for symbol ZTH22 | 2022-01-13 16:56:53.143 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:57:06.398 DTC Client socket (1) | Closed. | 2022-01-13 16:57:06.398 DTC Client socket (2) | Deleting network socket now after delay. | 2022-01-13 16:57:06.398 DTC Client socket (6) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:57:06.398 DTC Client socket (6) | Closed. | 2022-01-13 16:57:06.398 DTC Client socket (1) | Deleting network socket now after delay. | 2022-01-13 16:57:36.408 DTC Client socket (6) | Deleting network socket now after delay. | 2022-01-13 16:57:36.408 DTC Client socket (5) | Timed out waiting for final send. Canceling I/O. | 2022-01-13 16:58:06.408 DTC Client socket (5) | Write has completed. Shutdown being performed. | 2022-01-13 16:58:06.408 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:58:06.408 DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:58:06.408 DTC Client socket (5) | Closed. | 2022-01-13 16:58:06.408 HD Request # 114 | Error downloading historical Intraday data for ADR-NASDAQ. The download timed out. | 2022-01-13 16:58:19.979 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:58:19.979 Triggering next historical data download in queue. | 2022-01-13 16:58:19.979 Historical data download thread signaled to stop. | 2022-01-13 16:58:19.979 Socket (8) | CloseSocket call. | 2022-01-13 16:58:19.979 Socket (8) | Max send buffers used during socket life: 3 | 2022-01-13 16:58:19.979 Socket (8) | Max send buffer size during socket life: 186 | 2022-01-13 16:58:19.979 HD Request # 114 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ADR-NASDAQ | 2022-01-13 16:58:19.979 HD Request # 114 | Completion time: 1m 56s | 2022-01-13 16:58:19.980 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:58:19.980 HD Request # 115 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc | 2022-01-13 16:58:19.980 HD Request # 115 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.215000 | 2022-01-13 16:58:19.980 HD Request # 115 | Using server: ds4.sierracharts.com port 10150 | 2022-01-13 16:58:19.981 Socket (1) | Creating socket. | 2022-01-13 16:58:19.981 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:58:19.981 Socket (1) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:58:19.981 HD Request # 115 | Sending historical data logon request message. | 2022-01-13 16:58:33.303 DTC Client socket (4) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:59:06.425 DTC Client socket (4) | Closed. | 2022-01-13 16:59:06.425 DTC Client socket (7) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-01-13 16:59:06.425 DTC Client socket (7) | Closed. | 2022-01-13 16:59:06.425 HD Request # 115 | Setting DTC encoding to Binary VLS | 2022-01-13 16:59:08.628 HD Request # 115 | Sending historical data logon request message. | 2022-01-13 16:59:08.628 Socket (1) | CloseSocket call. | 2022-01-13 16:59:08.629 HD Request # 115 | Error downloading historical Intraday data for ADR-NASDAQ. Historical data logon error: Unsupported protocol version | 2022-01-13 16:59:08.629 Socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:59:08.629 Historical data download thread signaled to stop. | 2022-01-13 16:59:08.629 HD Request # 115 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ADR-NASDAQ | 2022-01-13 16:59:08.629 HD Request # 115 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:54:30.215000 | 2022-01-13 16:59:08.630 HD Request # 115 | Receiving Intraday data for ADR-NASDAQ starting at 2022-01-13 16:54:30.465000 | 2022-01-13 16:59:08.630 Added 773 Time and Sales records to Intraday data file for ADR-NASDAQ after download. | 2022-01-13 16:59:08.631 HD Request # 115 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:30.465000 | 2022-01-13 16:59:08.631 HD Request # 115 | Completion time: 49s | 2022-01-13 16:59:08.631 HD Request # 115 | Intraday data download complete for ADR-NASDAQ. Unique request ID: 185 | 2022-01-13 16:59:08.631 Removing historical data download ID 185. | 2022-01-13 16:59:08.631 Real-time Intraday chart data file updates started for ADR-NASDAQ | 2022-01-13 16:59:08.631 Intraday chart data file opened for ADR-NASDAQ | 2022-01-13 16:59:08.631 HD Request # 115 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:59:08.631 Triggering next historical data download in queue. | 2022-01-13 16:59:08.631 HD Request # 116 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2022-01-13 16:59:08.632 HD Request # 116 | Download start date-time: 2022-01-13 16:54:30.000000. File last date-time: 2022-01-13 16:54:30.215002 | 2022-01-13 16:59:08.632 HD Request # 116 | Using server: ds12.sierracharts.com port 10149 | 2022-01-13 16:59:08.632 Socket (2) | Creating socket. | 2022-01-13 16:59:08.632 Socket (2) | New receive buffer size: 5242880 | 2022-01-13 16:59:08.633 Socket (2) | Connecting to IP: 204.15.197.14. | 2022-01-13 16:59:08.633 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:59:08.922 Socket (1) | Write has completed. Shutdown being performed. | 2022-01-13 16:59:08.922 Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-01-13 16:59:08.922 Socket (1) | Closed. | 2022-01-13 16:59:08.922 HD Request # 116 | Setting DTC encoding to Binary VLS | 2022-01-13 16:59:09.270 HD Request # 116 | Sending historical data logon request message. | 2022-01-13 16:59:09.270 HD Request # 116 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:30. Record interval: 0. Symbol: TRIN-NYSE | 2022-01-13 16:59:10.111 HD Request # 116 | Decompressing data. | 2022-01-13 16:59:11.097 HD Request # 116 | Receiving Intraday data for TRIN-NYSE starting at 2022-01-13 16:54:30.000000 | 2022-01-13 16:59:11.097 Socket (2) | CloseSocket call. | 2022-01-13 16:59:15.400 Historical data download thread signaled to stop. | 2022-01-13 16:59:15.400 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:59:15.400 HD Request # 116 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:31.000000 | 2022-01-13 16:59:15.400 HD Request # 116 | Received 279 Intraday data records from 2022-01-13 16:54:30.000000 to 2022-01-13 16:59:08.000000 (4.6 minutes) and wrote 278 records for TRIN-NYSE | 2022-01-13 16:59:15.400 HD Request # 116 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:59:08.000000 | 2022-01-13 16:59:15.410 HD Request # 116 | Completion time: 7s | 2022-01-13 16:59:15.410 HD Request # 116 | Intraday data download complete for TRIN-NYSE. Unique request ID: 186 | 2022-01-13 16:59:15.410 Removing historical data download ID 186. | 2022-01-13 16:59:15.410 Real-time Intraday chart data file updates started for TRIN-NYSE | 2022-01-13 16:59:15.410 Intraday chart data file opened for TRIN-NYSE | 2022-01-13 16:59:15.410 HD Request # 116 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:59:15.410 Triggering next historical data download in queue. | 2022-01-13 16:59:15.410 HD Request # 117 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 16:59:15.411 HD Request # 117 | Download start date-time: 2022-01-13 16:55:56.000000. File last date-time: 2022-01-13 16:55:56.000000 | 2022-01-13 16:59:15.411 HD Request # 117 | Using server: ds13-3.sierracharts.com port 10150 | 2022-01-13 16:59:15.411 Socket (1) | Creating socket. | 2022-01-13 16:59:15.412 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:59:15.412 Socket (1) | Connecting to IP: 64.38.174.180. | 2022-01-13 16:59:15.412 Socket (2) | Socket gracefully closed by remote side. | 2022-01-13 16:59:15.698 Socket (2) | Closed. | 2022-01-13 16:59:15.698 SC DTC Data with Market Depth | There has been no activity on the network socket for 1m 3s. Will reconnect. | 2022-01-13 16:59:25.526 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-01-13 16:59:25.526 DTC Client socket (10) | CloseSocket call. | 2022-01-13 16:59:25.527 DTC Client socket (10) | Max send buffers used during socket life: 3 | 2022-01-13 16:59:25.527 DTC Client socket (10) | Max send buffer size during socket life: 348 | 2022-01-13 16:59:25.527 SC DTC Data with Market Depth | Disconnected from the server. | 2022-01-13 16:59:25.528 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 16:59:25.528 DTC Client socket (10) | Write in progress. Shutdown being delayed. PendingSize=0 | 2022-01-13 16:59:25.528 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2022-01-13 16:59:27.529 DTC Client socket (2) | Creating socket. | 2022-01-13 16:59:27.530 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-01-13 16:59:27.530 DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:59:27.530 SC DTC Data with Market Depth | Network connection to server complete. | 2022-01-13 16:59:27.826 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-01-13 16:59:27.826 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 16:59:27.826 HD Request # 117 | Setting DTC encoding to Binary VLS | 2022-01-13 16:59:28.121 HD Request # 117 | Sending historical data logon request message. | 2022-01-13 16:59:28.121 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-01-13 16:59:29.065 SC DTC Data with Market Depth | Sending logon request message. | 2022-01-13 16:59:29.065 HD Request # 117 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:56. Record interval: 0. Symbol: ADV-NYSE | 2022-01-13 16:59:29.095 HD Request # 117 | Decompressing data. | 2022-01-13 16:59:29.447 HD Request # 117 | Receiving Intraday data for ADV-NYSE starting at 2022-01-13 16:55:56.000000 | 2022-01-13 16:59:29.449 Socket (1) | CloseSocket call. | 2022-01-13 16:59:29.801 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:59:29.801 Historical data download thread signaled to stop. | 2022-01-13 16:59:29.801 HD Request # 117 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:57.000000 | 2022-01-13 16:59:29.801 HD Request # 117 | Received 211 Intraday data records from 2022-01-13 16:55:56.000000 to 2022-01-13 16:59:26.000000 (3.5 minutes) and wrote 210 records for ADV-NYSE | 2022-01-13 16:59:29.802 HD Request # 117 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:59:26.000000 | 2022-01-13 16:59:29.812 HD Request # 117 | Completion time: 14s | 2022-01-13 16:59:29.812 HD Request # 117 | Intraday data download complete for ADV-NYSE. Unique request ID: 187 | 2022-01-13 16:59:29.812 Removing historical data download ID 187. | 2022-01-13 16:59:29.812 Real-time Intraday chart data file updates started for ADV-NYSE | 2022-01-13 16:59:29.812 Intraday chart data file opened for ADV-NYSE | 2022-01-13 16:59:29.812 HD Request # 117 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:59:29.812 Triggering next historical data download in queue. | 2022-01-13 16:59:29.812 HD Request # 118 | Downloading Intraday chart data for TRIN-SP to the file TRIN-SP.scid. Service: statscalc | 2022-01-13 16:59:29.812 HD Request # 118 | Download start date-time: 2022-01-13 16:56:18.000000. File last date-time: 2022-01-13 16:56:18.000000 | 2022-01-13 16:59:29.813 HD Request # 118 | Using server: ds4.sierracharts.com port 10149 | 2022-01-13 16:59:29.813 Socket (5) | Creating socket. | 2022-01-13 16:59:29.813 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:59:29.813 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-01-13 16:59:29.813 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:59:30.148 Socket (1) | Closed. | 2022-01-13 16:59:30.148 HD Request # 118 | Setting DTC encoding to Binary VLS | 2022-01-13 16:59:30.414 HD Request # 118 | Sending historical data logon request message. | 2022-01-13 16:59:30.414 HD Request # 118 | Requesting Intraday data. Start date-time: 2022-01-13 16:56:18. Record interval: 0. Symbol: TRIN-SP | 2022-01-13 16:59:31.261 HD Request # 118 | Decompressing data. | 2022-01-13 16:59:31.554 HD Request # 118 | Receiving Intraday data for TRIN-SP starting at 2022-01-13 16:56:18.000000 | 2022-01-13 16:59:31.558 Socket (5) | CloseSocket call. | 2022-01-13 16:59:31.559 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:59:31.559 Historical data download thread signaled to stop. | 2022-01-13 16:59:31.559 HD Request # 118 | Timestamp of first Intraday data file record written: 2022-01-13 16:56:19.000000 | 2022-01-13 16:59:31.559 HD Request # 118 | Received 192 Intraday data records from 2022-01-13 16:56:18.000000 to 2022-01-13 16:59:29.000000 (3.2 minutes) and wrote 191 records for TRIN-SP | 2022-01-13 16:59:31.560 HD Request # 118 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:59:29.000000 | 2022-01-13 16:59:31.570 HD Request # 118 | Completion time: 2s | 2022-01-13 16:59:31.570 HD Request # 118 | Intraday data download complete for TRIN-SP. Unique request ID: 188 | 2022-01-13 16:59:31.570 Removing historical data download ID 188. | 2022-01-13 16:59:31.570 Real-time Intraday chart data file updates started for TRIN-SP | 2022-01-13 16:59:31.570 Intraday chart data file opened for TRIN-SP | 2022-01-13 16:59:31.570 HD Request # 118 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:59:31.570 Triggering next historical data download in queue. | 2022-01-13 16:59:31.570 HD Request # 119 | Downloading Intraday chart data for 6AH22 to the file 6AH22.scid. Service: cme | 2022-01-13 16:59:31.570 HD Request # 119 | Download start date-time: 2022-01-13 16:54:34.000000. File last date-time: 2022-01-13 16:54:34.545000 | 2022-01-13 16:59:31.571 HD Request # 119 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:59:31.571 Socket (1) | Creating socket. | 2022-01-13 16:59:31.571 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:59:31.571 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:59:31.571 SC DTC Data with Market Depth | Received logon response. | 2022-01-13 16:59:32.007 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-01-13 16:59:32.007 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 16:59:32.007 SC DTC Data with Market Depth | Successfully connected. | 2022-01-13 16:59:32.007 SC DTC Data with Market Depth | Trading is not supported. | 2022-01-13 16:59:32.007 Added historical Intraday data request for ADR-NASDAQ to the queue. | 2022-01-13 16:59:32.007 Intraday data recording state for symbol ADR-NASDAQ is set to download 'Pending'. | 2022-01-13 16:59:32.007 Triggering next historical data download in queue. | 2022-01-13 16:59:32.007 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADR-NASDAQ | 2022-01-13 16:59:32.007 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 16:59:32.007 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2022-01-13 16:59:32.007 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ADV-NYSE | 2022-01-13 16:59:32.007 Added historical Intraday data request for TRIN-NYSE to the queue. | 2022-01-13 16:59:32.007 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2022-01-13 16:59:32.007 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-NYSE | 2022-01-13 16:59:32.007 Added historical Intraday data request for TRIN-SP to the queue. | 2022-01-13 16:59:32.007 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2022-01-13 16:59:32.007 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRIN-SP | 2022-01-13 16:59:32.007 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:59:32.453 Socket (5) | Closed. | 2022-01-13 16:59:32.453 HD Request # 119 | Setting DTC encoding to Binary VLS | 2022-01-13 16:59:33.094 HD Request # 119 | Sending historical data logon request message. | 2022-01-13 16:59:33.094 SC DTC Data with Market Depth | Received security definition for symbol ADR-NASDAQ | 2022-01-13 16:59:33.097 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2022-01-13 16:59:33.098 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2022-01-13 16:59:33.098 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2022-01-13 16:59:33.098 Socket (8) | Socket gracefully closed by remote side. | 2022-01-13 16:59:33.434 Socket (8) | Closed. | 2022-01-13 16:59:33.434 HD Request # 119 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:34. Record interval: 0. Symbol: 6AH22 | 2022-01-13 16:59:33.866 HD Request # 119 | Decompressing data. | 2022-01-13 16:59:34.257 HD Request # 119 | Receiving Intraday data for 6AH22 starting at 2022-01-13 16:54:34.545000 | 2022-01-13 16:59:34.258 Socket (1) | CloseSocket call. | 2022-01-13 16:59:34.259 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:59:34.260 Historical data download thread signaled to stop. | 2022-01-13 16:59:34.260 HD Request # 119 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:01.666000 | 2022-01-13 16:59:34.260 HD Request # 119 | Received 87 Intraday data records from 2022-01-13 16:54:34.545000 to 2022-01-13 16:59:29.623000 (4.9 minutes) and wrote 86 records for 6AH22 | 2022-01-13 16:59:34.260 HD Request # 119 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:59:29.623000 | 2022-01-13 16:59:34.270 HD Request # 119 | Completion time: 3s | 2022-01-13 16:59:34.270 HD Request # 119 | Intraday data download complete for 6AH22. Unique request ID: 189 | 2022-01-13 16:59:34.270 Removing historical data download ID 189. | 2022-01-13 16:59:34.270 Real-time Intraday chart data file updates started for 6AH22 | 2022-01-13 16:59:34.270 Intraday chart data file opened for 6AH22 | 2022-01-13 16:59:34.270 HD Request # 119 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:59:34.270 Triggering next historical data download in queue. | 2022-01-13 16:59:34.270 HD Request # 120 | Downloading Intraday chart data for 6BH22 to the file 6BH22.scid. Service: cme | 2022-01-13 16:59:34.270 HD Request # 120 | Download start date-time: 2022-01-13 16:55:49.000000. File last date-time: 2022-01-13 16:55:49.952000 | 2022-01-13 16:59:34.271 HD Request # 120 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:59:34.271 Socket (5) | Creating socket. | 2022-01-13 16:59:34.271 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 16:59:34.272 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:59:34.272 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:59:34.566 Socket (1) | Closed. | 2022-01-13 16:59:34.566 HD Request # 120 | Setting DTC encoding to Binary VLS | 2022-01-13 16:59:34.888 HD Request # 120 | Sending historical data logon request message. | 2022-01-13 16:59:34.888 HD Request # 120 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:49. Record interval: 0. Symbol: 6BH22 | 2022-01-13 16:59:35.653 DTC Client socket (4) | Deleting network socket now after delay. | 2022-01-13 16:59:36.433 DTC Client socket (7) | Deleting network socket now after delay. | 2022-01-13 16:59:36.433 HD Request # 120 | Decompressing data. | 2022-01-13 16:59:36.659 HD Request # 120 | Receiving Intraday data for 6BH22 starting at 2022-01-13 16:55:49.694000 | 2022-01-13 16:59:36.660 Socket (5) | CloseSocket call. | 2022-01-13 16:59:36.661 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:59:36.661 Historical data download thread signaled to stop. | 2022-01-13 16:59:36.661 HD Request # 120 | Timestamp of first Intraday data file record written: 2022-01-13 16:56:02.584000 | 2022-01-13 16:59:36.661 HD Request # 120 | Received 152 Intraday data records from 2022-01-13 16:55:49.694000 to 2022-01-13 16:59:24.687000 (3.6 minutes) and wrote 147 records for 6BH22 | 2022-01-13 16:59:36.661 HD Request # 120 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:59:24.687000 | 2022-01-13 16:59:36.672 HD Request # 120 | Completion time: 2s | 2022-01-13 16:59:36.672 HD Request # 120 | Intraday data download complete for 6BH22. Unique request ID: 190 | 2022-01-13 16:59:36.672 Removing historical data download ID 190. | 2022-01-13 16:59:36.672 Real-time Intraday chart data file updates started for 6BH22 | 2022-01-13 16:59:36.672 Intraday chart data file opened for 6BH22 | 2022-01-13 16:59:36.672 HD Request # 120 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:59:36.672 Triggering next historical data download in queue. | 2022-01-13 16:59:36.672 HD Request # 121 | Downloading Intraday chart data for 6CH22 to the file 6CH22.scid. Service: cme | 2022-01-13 16:59:36.672 HD Request # 121 | Download start date-time: 2022-01-13 16:55:06.000000. File last date-time: 2022-01-13 16:55:06.931000 | 2022-01-13 16:59:36.673 HD Request # 121 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 16:59:36.673 Socket (1) | Creating socket. | 2022-01-13 16:59:36.673 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 16:59:36.673 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 16:59:36.673 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 16:59:36.963 Socket (5) | Closed. | 2022-01-13 16:59:36.963 HD Request # 121 | Setting DTC encoding to Binary VLS | 2022-01-13 16:59:38.218 HD Request # 121 | Sending historical data logon request message. | 2022-01-13 16:59:38.218 HD Request # 121 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:06. Record interval: 0. Symbol: 6CH22 | 2022-01-13 16:59:38.520 HD Request # 121 | Decompressing data. | 2022-01-13 16:59:38.816 HD Request # 121 | Receiving Intraday data for 6CH22 starting at 2022-01-13 16:55:06.931000 | 2022-01-13 16:59:38.817 Socket (1) | CloseSocket call. | 2022-01-13 16:59:39.101 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:59:39.102 Historical data download thread signaled to stop. | 2022-01-13 16:59:39.102 HD Request # 121 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:19.536000 | 2022-01-13 16:59:39.102 HD Request # 121 | Received 249 Intraday data records from 2022-01-13 16:55:06.931000 to 2022-01-13 16:59:27.037001 (4.3 minutes) and wrote 248 records for 6CH22 | 2022-01-13 16:59:39.102 HD Request # 121 | Add time&sales data | Remembered last file record date-time: 2022-01-13 16:59:27.037001 | 2022-01-13 16:59:39.113 HD Request # 121 | Completion time: 3s | 2022-01-13 16:59:39.113 HD Request # 121 | Intraday data download complete for 6CH22. Unique request ID: 191 | 2022-01-13 16:59:39.113 Removing historical data download ID 191. | 2022-01-13 16:59:39.113 Real-time Intraday chart data file updates started for 6CH22 | 2022-01-13 16:59:39.113 Intraday chart data file opened for 6CH22 | 2022-01-13 16:59:39.113 HD Request # 121 | Enabling Intraday chart updating for symbol. | 2022-01-13 16:59:39.113 Triggering next historical data download in queue. | 2022-01-13 16:59:39.113 HD Request # 122 | Downloading Intraday chart data for 6EH22 to the file 6EH22.scid. Service: cme | 2022-01-13 16:59:39.113 HD Request # 122 | Download start date-time: 2022-01-13 16:55:40.000000. File last date-time: 2022-01-13 16:55:40.175000 | 2022-01-13 16:59:39.114 HD Request # 122 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 16:59:39.114 Socket (4) | Creating socket. | 2022-01-13 16:59:39.114 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 16:59:39.115 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 16:59:39.115 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 16:59:39.397 Socket (1) | Closed. | 2022-01-13 16:59:39.397 HD Request # 122 | Setting DTC encoding to Binary VLS | 2022-01-13 16:59:39.717 HD Request # 122 | Sending historical data logon request message. | 2022-01-13 16:59:39.717 Opened cached Intraday file: C:\SierraChart\Data\6AH22.scid. Thread ID: 11608 | 2022-01-13 16:59:44.694 Opened cached Intraday file: C:\SierraChart\Data\6BH22.scid. Thread ID: 11608 | 2022-01-13 16:59:49.724 Opened cached Intraday file: C:\SierraChart\Data\6CH22.scid. Thread ID: 11608 | 2022-01-13 16:59:54.755 DTC Client socket (10) | Write has completed. Shutdown being performed. | 2022-01-13 16:59:58.353 DTC Client socket (10) | Shutdown started. Waiting for graceful close. | 2022-01-13 16:59:58.353 DTC Client socket (10) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-13 16:59:58.353 * DTC Client socket (10) | Socket gracefully closed by remote side. | 2022-01-13 16:59:58.353 DTC Client socket (10) | Closed. | 2022-01-13 16:59:58.353 HD Request # 122 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:40. Record interval: 0. Symbol: 6EH22 | 2022-01-13 16:59:58.955 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:00:38.424 Socket (4) | CloseSocket call. | 2022-01-13 17:00:38.424 Socket (0) | CloseSocket call. | 2022-01-13 17:00:38.424 Socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-01-13 17:00:38.424 Socket (4) | Closed. | 2022-01-13 17:00:38.424 HD Request # 122 | Error downloading historical Intraday data for 6EH22. The network socket has been closed. Retrying download. | 2022-01-13 17:00:38.425 Added historical Intraday data request for 6EH22 to the queue. | 2022-01-13 17:00:38.425 Triggering next historical data download in queue. | 2022-01-13 17:00:38.425 Historical data download thread signaled to stop. | 2022-01-13 17:00:38.425 HD Request # 122 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for 6EH22 | 2022-01-13 17:00:38.425 HD Request # 122 | Completion time: 59s | 2022-01-13 17:00:38.425 HD Request # 123 | Downloading Intraday chart data for 6EH22 to the file 6EH22.scid. Service: cme | 2022-01-13 17:00:38.425 HD Request # 123 | Download start date-time: 2022-01-13 16:55:40.000000. File last date-time: 2022-01-13 16:55:40.175000 | 2022-01-13 17:00:38.426 HD Request # 123 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 17:00:38.426 Socket (1) | Creating socket. | 2022-01-13 17:00:38.426 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 17:00:38.426 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:00:38.426 HD Request # 123 | Setting DTC encoding to Binary VLS | 2022-01-13 17:00:40.038 HD Request # 123 | Sending historical data logon request message. | 2022-01-13 17:00:40.038 HD Request # 123 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:40. Record interval: 0. Symbol: 6EH22 | 2022-01-13 17:00:43.641 HD Request # 123 | Decompressing data. | 2022-01-13 17:00:43.950 HD Request # 123 | Receiving Intraday data for 6EH22 starting at 2022-01-13 16:55:40.173000 | 2022-01-13 17:00:44.248 Socket (1) | CloseSocket call. | 2022-01-13 17:00:44.249 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:00:44.249 Historical data download thread signaled to stop. | 2022-01-13 17:00:44.249 HD Request # 123 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:47.471000 | 2022-01-13 17:00:44.249 HD Request # 123 | Received 245 Intraday data records from 2022-01-13 16:55:40.173000 to 2022-01-13 17:00:39.061000 (5.0 minutes) and wrote 239 records for 6EH22 | 2022-01-13 17:00:44.249 HD Request # 123 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:00:39.061000 | 2022-01-13 17:00:44.258 HD Request # 123 | Completion time: 6s | 2022-01-13 17:00:44.258 HD Request # 123 | Intraday data download complete for 6EH22. Unique request ID: 192 | 2022-01-13 17:00:44.258 Removing historical data download ID 192. | 2022-01-13 17:00:44.258 Real-time Intraday chart data file updates started for 6EH22 | 2022-01-13 17:00:44.258 Intraday chart data file opened for 6EH22 | 2022-01-13 17:00:44.258 HD Request # 123 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:00:44.258 Triggering next historical data download in queue. | 2022-01-13 17:00:44.258 HD Request # 124 | Downloading Intraday chart data for 6JH22 to the file 6JH22.scid. Service: cme | 2022-01-13 17:00:44.259 HD Request # 124 | Download start date-time: 2022-01-13 16:56:10.000000. File last date-time: 2022-01-13 16:56:10.607001 | 2022-01-13 17:00:44.259 HD Request # 124 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 17:00:44.259 Socket (4) | Creating socket. | 2022-01-13 17:00:44.260 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:00:44.260 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:00:44.260 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 17:00:44.551 Socket (1) | Closed. | 2022-01-13 17:00:44.551 HD Request # 124 | Setting DTC encoding to Binary VLS | 2022-01-13 17:00:45.785 HD Request # 124 | Sending historical data logon request message. | 2022-01-13 17:00:45.785 HD Request # 124 | Requesting Intraday data. Start date-time: 2022-01-13 16:56:10. Record interval: 0. Symbol: 6JH22 | 2022-01-13 17:00:46.563 HD Request # 124 | Decompressing data. | 2022-01-13 17:00:52.269 HD Request # 124 | Receiving Intraday data for 6JH22 starting at 2022-01-13 16:56:10.607000 | 2022-01-13 17:00:52.269 Socket (4) | CloseSocket call. | 2022-01-13 17:00:52.270 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:00:52.270 Historical data download thread signaled to stop. | 2022-01-13 17:00:52.273 HD Request # 124 | Timestamp of first Intraday data file record written: 2022-01-13 16:56:35.215000 | 2022-01-13 17:00:52.273 HD Request # 124 | Received 87 Intraday data records from 2022-01-13 16:56:10.607000 to 2022-01-13 17:00:29.694001 (4.3 minutes) and wrote 85 records for 6JH22 | 2022-01-13 17:00:52.273 HD Request # 124 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:00:29.694001 | 2022-01-13 17:00:52.282 HD Request # 124 | Completion time: 8s | 2022-01-13 17:00:52.282 HD Request # 124 | Intraday data download complete for 6JH22. Unique request ID: 193 | 2022-01-13 17:00:52.282 Removing historical data download ID 193. | 2022-01-13 17:00:52.282 Real-time Intraday chart data file updates started for 6JH22 | 2022-01-13 17:00:52.282 Intraday chart data file opened for 6JH22 | 2022-01-13 17:00:52.282 HD Request # 124 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:00:52.282 Triggering next historical data download in queue. | 2022-01-13 17:00:52.282 HD Request # 125 | Downloading Intraday chart data for CLG22 to the file CLG22.scid. Service: nymex | 2022-01-13 17:00:52.282 HD Request # 125 | Download start date-time: 2022-01-13 16:55:35.000000. File last date-time: 2022-01-13 16:55:35.739000 | 2022-01-13 17:00:52.283 HD Request # 125 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 17:00:52.283 Socket (1) | Creating socket. | 2022-01-13 17:00:52.283 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 17:00:52.283 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:00:52.283 HD Request # 125 | Setting DTC encoding to Binary VLS | 2022-01-13 17:00:55.893 HD Request # 125 | Sending historical data logon request message. | 2022-01-13 17:00:55.893 HD Request # 125 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:35. Record interval: 0. Symbol: CLG22 | 2022-01-13 17:00:56.193 HD Request # 125 | Decompressing data. | 2022-01-13 17:00:56.496 HD Request # 125 | Receiving Intraday data for CLG22 starting at 2022-01-13 16:55:35.016000 | 2022-01-13 17:00:56.499 Socket (1) | CloseSocket call. | 2022-01-13 17:00:56.502 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:00:56.502 Historical data download thread signaled to stop. | 2022-01-13 17:00:56.502 HD Request # 125 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:40.023000 | 2022-01-13 17:00:56.502 HD Request # 125 | Received 1001 Intraday data records from 2022-01-13 16:55:35.016000 to 2022-01-13 17:00:51.372000 (5.3 minutes) and wrote 982 records for CLG22 | 2022-01-13 17:00:56.502 HD Request # 125 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:00:51.372000 | 2022-01-13 17:00:56.516 HD Request # 125 | Completion time: 4s | 2022-01-13 17:00:56.516 HD Request # 125 | Intraday data download complete for CLG22. Unique request ID: 194 | 2022-01-13 17:00:56.516 Removing historical data download ID 194. | 2022-01-13 17:00:56.516 Real-time Intraday chart data file updates started for CLG22 | 2022-01-13 17:00:56.516 Intraday chart data file opened for CLG22 | 2022-01-13 17:00:56.516 HD Request # 125 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:00:56.516 Triggering next historical data download in queue. | 2022-01-13 17:00:56.516 HD Request # 126 | Downloading Intraday chart data for ESH22 to the file ESH22.scid. Service: cme | 2022-01-13 17:00:56.516 HD Request # 126 | Download start date-time: 2022-01-13 16:54:54.000000. File last date-time: 2022-01-13 16:54:54.840000 | 2022-01-13 17:00:56.517 HD Request # 126 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 17:00:56.517 Socket (5) | Creating socket. | 2022-01-13 17:00:56.517 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 17:00:56.517 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:00:56.517 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 17:00:56.798 Socket (1) | Closed. | 2022-01-13 17:00:56.798 HD Request # 126 | Setting DTC encoding to Binary VLS | 2022-01-13 17:00:57.135 HD Request # 126 | Sending historical data logon request message. | 2022-01-13 17:00:57.135 HD Request # 126 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:54. Record interval: 0. Symbol: ESH22 | 2022-01-13 17:00:57.440 HD Request # 126 | Decompressing data. | 2022-01-13 17:00:59.149 HD Request # 126 | Receiving Intraday data for ESH22 starting at 2022-01-13 16:54:54.197000 | 2022-01-13 17:00:59.150 Socket (5) | CloseSocket call. | 2022-01-13 17:01:00.097 Historical data download thread signaled to stop. | 2022-01-13 17:01:00.098 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:00.098 HD Request # 126 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:55.016000 | 2022-01-13 17:01:00.098 HD Request # 126 | Received 6618 Intraday data records from 2022-01-13 16:54:54.197000 to 2022-01-13 17:00:54.645001 (6.0 minutes) and wrote 6597 records for ESH22 | 2022-01-13 17:01:00.098 HD Request # 126 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:00:54.645001 | 2022-01-13 17:01:00.104 HD Request # 126 | Completion time: 4s | 2022-01-13 17:01:00.104 HD Request # 126 | Intraday data download complete for ESH22. Unique request ID: 195 | 2022-01-13 17:01:00.104 Removing historical data download ID 195. | 2022-01-13 17:01:00.104 Real-time Intraday chart data file updates started for ESH22 | 2022-01-13 17:01:00.104 Intraday chart data file opened for ESH22 | 2022-01-13 17:01:00.104 HD Request # 126 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:00.104 Triggering next historical data download in queue. | 2022-01-13 17:01:00.104 HD Request # 127 | Downloading Intraday chart data for GCG22 to the file GCG22.scid. Service: comex | 2022-01-13 17:01:00.104 HD Request # 127 | Download start date-time: 2022-01-13 16:54:54.000000. File last date-time: 2022-01-13 16:54:54.570000 | 2022-01-13 17:01:00.105 HD Request # 127 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 17:01:00.105 Socket (1) | Creating socket. | 2022-01-13 17:01:00.105 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 17:01:00.105 Socket (1) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:01:00.105 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 17:01:00.403 Socket (5) | Closed. | 2022-01-13 17:01:00.404 HD Request # 127 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:00.714 HD Request # 127 | Sending historical data logon request message. | 2022-01-13 17:01:00.714 HD Request # 127 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:54. Record interval: 0. Symbol: GCG22 | 2022-01-13 17:01:01.015 HD Request # 127 | Decompressing data. | 2022-01-13 17:01:01.318 HD Request # 127 | Receiving Intraday data for GCG22 starting at 2022-01-13 16:54:54.570000 | 2022-01-13 17:01:03.343 Socket (1) | CloseSocket call. | 2022-01-13 17:01:03.345 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:03.345 Historical data download thread signaled to stop. | 2022-01-13 17:01:03.347 HD Request # 127 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:55.672000 | 2022-01-13 17:01:03.347 HD Request # 127 | Received 762 Intraday data records from 2022-01-13 16:54:54.570000 to 2022-01-13 17:00:57.120000 (6.0 minutes) and wrote 761 records for GCG22 | 2022-01-13 17:01:03.348 HD Request # 127 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:00:57.120000 | 2022-01-13 17:01:03.357 HD Request # 127 | Completion time: 3s | 2022-01-13 17:01:03.357 HD Request # 127 | Intraday data download complete for GCG22. Unique request ID: 196 | 2022-01-13 17:01:03.357 Removing historical data download ID 196. | 2022-01-13 17:01:03.357 Real-time Intraday chart data file updates started for GCG22 | 2022-01-13 17:01:03.357 Intraday chart data file opened for GCG22 | 2022-01-13 17:01:03.357 HD Request # 127 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:03.357 Triggering next historical data download in queue. | 2022-01-13 17:01:03.357 HD Request # 128 | Downloading Intraday chart data for NGG22 to the file NGG22.scid. Service: nymex | 2022-01-13 17:01:03.357 HD Request # 128 | Download start date-time: 2022-01-13 16:54:54.000000. File last date-time: 2022-01-13 16:54:54.944001 | 2022-01-13 17:01:03.358 HD Request # 128 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 17:01:03.358 Socket (5) | Creating socket. | 2022-01-13 17:01:03.358 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 17:01:03.358 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:01:03.358 HD Request # 128 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:03.984 HD Request # 128 | Sending historical data logon request message. | 2022-01-13 17:01:03.984 HD Request # 128 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:54. Record interval: 0. Symbol: NGG22 | 2022-01-13 17:01:04.302 HD Request # 128 | Decompressing data. | 2022-01-13 17:01:04.669 HD Request # 128 | Receiving Intraday data for NGG22 starting at 2022-01-13 16:54:54.944000 | 2022-01-13 17:01:04.670 Socket (5) | CloseSocket call. | 2022-01-13 17:01:05.013 Historical data download thread signaled to stop. | 2022-01-13 17:01:05.013 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:05.013 HD Request # 128 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:58.586000 | 2022-01-13 17:01:05.013 HD Request # 128 | Received 1213 Intraday data records from 2022-01-13 16:54:54.944000 to 2022-01-13 17:01:02.252001 (6.1 minutes) and wrote 1211 records for NGG22 | 2022-01-13 17:01:05.013 HD Request # 128 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:01:02.252001 | 2022-01-13 17:01:05.023 HD Request # 128 | Completion time: 2s | 2022-01-13 17:01:05.023 HD Request # 128 | Intraday data download complete for NGG22. Unique request ID: 197 | 2022-01-13 17:01:05.023 Removing historical data download ID 197. | 2022-01-13 17:01:05.023 Real-time Intraday chart data file updates started for NGG22 | 2022-01-13 17:01:05.023 Intraday chart data file opened for NGG22 | 2022-01-13 17:01:05.023 HD Request # 128 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:05.023 Triggering next historical data download in queue. | 2022-01-13 17:01:05.023 HD Request # 129 | Downloading Intraday chart data for NQH22 to the file NQH22.scid. Service: cme | 2022-01-13 17:01:05.024 HD Request # 129 | Download start date-time: 2022-01-13 16:54:54.000000. File last date-time: 2022-01-13 16:54:54.919000 | 2022-01-13 17:01:05.024 HD Request # 129 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 17:01:05.024 Socket (6) | Creating socket. | 2022-01-13 17:01:05.025 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 17:01:05.025 Socket (6) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:01:05.025 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 17:01:05.352 Socket (5) | Closed. | 2022-01-13 17:01:05.352 HD Request # 129 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:06.332 HD Request # 129 | Sending historical data logon request message. | 2022-01-13 17:01:06.332 HD Request # 129 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:54. Record interval: 0. Symbol: NQH22 | 2022-01-13 17:01:06.632 HD Request # 129 | Decompressing data. | 2022-01-13 17:01:06.932 HD Request # 129 | Receiving Intraday data for NQH22 starting at 2022-01-13 16:54:54.015000 | 2022-01-13 17:01:07.450 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 17:01:07.538 Socket (1) | Closed. | 2022-01-13 17:01:07.538 Socket (6) | CloseSocket call. | 2022-01-13 17:01:08.492 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:08.492 Historical data download thread signaled to stop. | 2022-01-13 17:01:08.492 HD Request # 129 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:55.008000 | 2022-01-13 17:01:08.493 HD Request # 129 | Received 5396 Intraday data records from 2022-01-13 16:54:54.015000 to 2022-01-13 17:01:03.279000 (6.2 minutes) and wrote 5382 records for NQH22 | 2022-01-13 17:01:08.493 HD Request # 129 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:01:03.279000 | 2022-01-13 17:01:08.503 HD Request # 129 | Completion time: 3s | 2022-01-13 17:01:08.503 HD Request # 129 | Intraday data download complete for NQH22. Unique request ID: 198 | 2022-01-13 17:01:08.503 Removing historical data download ID 198. | 2022-01-13 17:01:08.503 Real-time Intraday chart data file updates started for NQH22 | 2022-01-13 17:01:08.503 Intraday chart data file opened for NQH22 | 2022-01-13 17:01:08.503 HD Request # 129 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:08.503 Triggering next historical data download in queue. | 2022-01-13 17:01:08.503 HD Request # 130 | Downloading Intraday chart data for RBG22 to the file RBG22.scid. Service: nymex | 2022-01-13 17:01:08.503 HD Request # 130 | Download start date-time: 2022-01-13 16:55:08.000000. File last date-time: 2022-01-13 16:55:08.980000 | 2022-01-13 17:01:08.504 HD Request # 130 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 17:01:08.504 Socket (1) | Creating socket. | 2022-01-13 17:01:08.504 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 17:01:08.504 Socket (1) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:01:08.504 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 17:01:09.350 Socket (6) | Closed. | 2022-01-13 17:01:09.350 HD Request # 130 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:18.124 HD Request # 130 | Sending historical data logon request message. | 2022-01-13 17:01:18.124 HD Request # 130 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:08. Record interval: 0. Symbol: RBG22 | 2022-01-13 17:01:18.888 HD Request # 130 | Decompressing data. | 2022-01-13 17:01:21.480 HD Request # 130 | Receiving Intraday data for RBG22 starting at 2022-01-13 16:55:08.966000 | 2022-01-13 17:01:21.481 Socket (1) | CloseSocket call. | 2022-01-13 17:01:21.481 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:21.481 Historical data download thread signaled to stop. | 2022-01-13 17:01:21.481 HD Request # 130 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:21.664000 | 2022-01-13 17:01:21.481 HD Request # 130 | Received 356 Intraday data records from 2022-01-13 16:55:08.966000 to 2022-01-13 17:01:10.892002 (6.0 minutes) and wrote 351 records for RBG22 | 2022-01-13 17:01:21.482 HD Request # 130 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:01:10.892002 | 2022-01-13 17:01:21.491 HD Request # 130 | Completion time: 13s | 2022-01-13 17:01:21.491 HD Request # 130 | Intraday data download complete for RBG22. Unique request ID: 199 | 2022-01-13 17:01:21.491 Removing historical data download ID 199. | 2022-01-13 17:01:21.491 Real-time Intraday chart data file updates started for RBG22 | 2022-01-13 17:01:21.491 Intraday chart data file opened for RBG22 | 2022-01-13 17:01:21.491 HD Request # 130 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:21.491 Triggering next historical data download in queue. | 2022-01-13 17:01:21.491 HD Request # 131 | Downloading Intraday chart data for TNH22 to the file TNH22.scid. Service: cbot | 2022-01-13 17:01:21.491 HD Request # 131 | Download start date-time: 2022-01-13 16:55:36.000000. File last date-time: 2022-01-13 16:55:36.729001 | 2022-01-13 17:01:21.492 HD Request # 131 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 17:01:21.492 Socket (5) | Creating socket. | 2022-01-13 17:01:21.492 Socket (5) | New receive buffer size: 5242880 | 2022-01-13 17:01:21.492 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:01:21.492 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 17:01:21.779 Socket (1) | Closed. | 2022-01-13 17:01:21.779 HD Request # 131 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:23.029 HD Request # 131 | Sending historical data logon request message. | 2022-01-13 17:01:23.029 HD Request # 131 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:36. Record interval: 0. Symbol: TNH22 | 2022-01-13 17:01:23.821 HD Request # 131 | Decompressing data. | 2022-01-13 17:01:26.391 HD Request # 131 | Receiving Intraday data for TNH22 starting at 2022-01-13 16:55:36.727000 | 2022-01-13 17:01:26.392 Socket (5) | CloseSocket call. | 2022-01-13 17:01:26.393 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:26.393 Historical data download thread signaled to stop. | 2022-01-13 17:01:26.393 HD Request # 131 | Timestamp of first Intraday data file record written: 2022-01-13 16:56:40.400000 | 2022-01-13 17:01:26.393 HD Request # 131 | Received 125 Intraday data records from 2022-01-13 16:55:36.727000 to 2022-01-13 17:00:50.140002 (5.2 minutes) and wrote 104 records for TNH22 | 2022-01-13 17:01:26.393 HD Request # 131 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:00:50.140002 | 2022-01-13 17:01:26.402 HD Request # 131 | Completion time: 5s | 2022-01-13 17:01:26.403 HD Request # 131 | Intraday data download complete for TNH22. Unique request ID: 200 | 2022-01-13 17:01:26.403 Removing historical data download ID 200. | 2022-01-13 17:01:26.403 Real-time Intraday chart data file updates started for TNH22 | 2022-01-13 17:01:26.403 Intraday chart data file opened for TNH22 | 2022-01-13 17:01:26.403 HD Request # 131 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:26.403 Triggering next historical data download in queue. | 2022-01-13 17:01:26.403 HD Request # 132 | Downloading Intraday chart data for YMH22 to the file YMH22.scid. Service: cbot | 2022-01-13 17:01:26.403 HD Request # 132 | Download start date-time: 2022-01-13 16:54:54.000000. File last date-time: 2022-01-13 16:54:54.333000 | 2022-01-13 17:01:26.403 HD Request # 132 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 17:01:26.404 Socket (1) | Creating socket. | 2022-01-13 17:01:26.404 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 17:01:26.404 Socket (1) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:01:26.404 Socket (5) | Socket gracefully closed by remote side. | 2022-01-13 17:01:26.689 Socket (5) | Closed. | 2022-01-13 17:01:26.689 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:01:26.961 Socket (4) | Closed. | 2022-01-13 17:01:26.961 HD Request # 132 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:39.079 HD Request # 132 | Sending historical data logon request message. | 2022-01-13 17:01:39.079 HD Request # 132 | Requesting Intraday data. Start date-time: 2022-01-13 16:54:54. Record interval: 0. Symbol: YMH22 | 2022-01-13 17:01:39.375 HD Request # 132 | Decompressing data. | 2022-01-13 17:01:39.670 HD Request # 132 | Receiving Intraday data for YMH22 starting at 2022-01-13 16:54:54.333000 | 2022-01-13 17:01:40.267 Socket (1) | CloseSocket call. | 2022-01-13 17:01:40.272 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:40.273 Historical data download thread signaled to stop. | 2022-01-13 17:01:40.274 HD Request # 132 | Timestamp of first Intraday data file record written: 2022-01-13 16:54:55.308000 | 2022-01-13 17:01:40.275 HD Request # 132 | Received 1353 Intraday data records from 2022-01-13 16:54:54.333000 to 2022-01-13 17:01:36.610000 (6.7 minutes) and wrote 1352 records for YMH22 | 2022-01-13 17:01:40.275 HD Request # 132 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:01:36.610000 | 2022-01-13 17:01:40.285 HD Request # 132 | Completion time: 14s | 2022-01-13 17:01:40.285 HD Request # 132 | Intraday data download complete for YMH22. Unique request ID: 201 | 2022-01-13 17:01:40.285 Removing historical data download ID 201. | 2022-01-13 17:01:40.285 Real-time Intraday chart data file updates started for YMH22 | 2022-01-13 17:01:40.285 Intraday chart data file opened for YMH22 | 2022-01-13 17:01:40.285 HD Request # 132 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:40.285 Triggering next historical data download in queue. | 2022-01-13 17:01:40.285 HD Request # 133 | Downloading Intraday chart data for ZBH22 to the file ZBH22.scid. Service: cbot | 2022-01-13 17:01:40.285 HD Request # 133 | Download start date-time: 2022-01-13 16:55:50.000000. File last date-time: 2022-01-13 16:55:50.428023 | 2022-01-13 17:01:40.286 HD Request # 133 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 17:01:40.286 Socket (4) | Creating socket. | 2022-01-13 17:01:40.286 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:01:40.286 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:01:40.286 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 17:01:40.574 Socket (1) | Closed. | 2022-01-13 17:01:40.574 HD Request # 133 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:40.899 HD Request # 133 | Sending historical data logon request message. | 2022-01-13 17:01:40.899 HD Request # 133 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:50. Record interval: 0. Symbol: ZBH22 | 2022-01-13 17:01:41.190 HD Request # 133 | Decompressing data. | 2022-01-13 17:01:41.493 HD Request # 133 | Receiving Intraday data for ZBH22 starting at 2022-01-13 16:55:50.428000 | 2022-01-13 17:01:41.495 Socket (4) | CloseSocket call. | 2022-01-13 17:01:41.496 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:41.496 Historical data download thread signaled to stop. | 2022-01-13 17:01:41.499 HD Request # 133 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:57.011000 | 2022-01-13 17:01:41.499 HD Request # 133 | Received 484 Intraday data records from 2022-01-13 16:55:50.428000 to 2022-01-13 17:01:23.905000 (5.6 minutes) and wrote 460 records for ZBH22 | 2022-01-13 17:01:41.499 HD Request # 133 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:01:23.905000 | 2022-01-13 17:01:41.508 HD Request # 133 | Completion time: 1s | 2022-01-13 17:01:41.508 HD Request # 133 | Intraday data download complete for ZBH22. Unique request ID: 202 | 2022-01-13 17:01:41.508 Removing historical data download ID 202. | 2022-01-13 17:01:41.508 Real-time Intraday chart data file updates started for ZBH22 | 2022-01-13 17:01:41.508 Intraday chart data file opened for ZBH22 | 2022-01-13 17:01:41.508 HD Request # 133 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:41.508 Triggering next historical data download in queue. | 2022-01-13 17:01:41.508 HD Request # 134 | Downloading Intraday chart data for ZFH22 to the file ZFH22.scid. Service: cbot | 2022-01-13 17:01:41.508 HD Request # 134 | Download start date-time: 2022-01-13 16:55:21.000000. File last date-time: 2022-01-13 16:55:21.011000 | 2022-01-13 17:01:41.508 HD Request # 134 | Using server: ds23.sierracharts.com port 10149 | 2022-01-13 17:01:41.509 Socket (1) | Creating socket. | 2022-01-13 17:01:41.509 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 17:01:41.509 Socket (1) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:01:41.509 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:01:41.796 Socket (4) | Closed. | 2022-01-13 17:01:41.796 HD Request # 134 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:42.127 HD Request # 134 | Sending historical data logon request message. | 2022-01-13 17:01:42.127 HD Request # 134 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:21. Record interval: 0. Symbol: ZFH22 | 2022-01-13 17:01:42.425 HD Request # 134 | Decompressing data. | 2022-01-13 17:01:43.427 HD Request # 134 | Receiving Intraday data for ZFH22 starting at 2022-01-13 16:55:21.011000 | 2022-01-13 17:01:43.427 Socket (1) | CloseSocket call. | 2022-01-13 17:01:43.428 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:43.429 Historical data download thread signaled to stop. | 2022-01-13 17:01:43.429 HD Request # 134 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:30.009000 | 2022-01-13 17:01:43.429 HD Request # 134 | Received 428 Intraday data records from 2022-01-13 16:55:21.011000 to 2022-01-13 17:01:38.296000 (6.3 minutes) and wrote 427 records for ZFH22 | 2022-01-13 17:01:43.429 HD Request # 134 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:01:38.296000 | 2022-01-13 17:01:43.438 HD Request # 134 | Completion time: 2s | 2022-01-13 17:01:43.438 HD Request # 134 | Intraday data download complete for ZFH22. Unique request ID: 203 | 2022-01-13 17:01:43.438 Removing historical data download ID 203. | 2022-01-13 17:01:43.438 Real-time Intraday chart data file updates started for ZFH22 | 2022-01-13 17:01:43.438 Intraday chart data file opened for ZFH22 | 2022-01-13 17:01:43.438 HD Request # 134 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:43.438 Triggering next historical data download in queue. | 2022-01-13 17:01:43.438 HD Request # 135 | Downloading Intraday chart data for ZNH22 to the file ZNH22.scid. Service: cbot | 2022-01-13 17:01:43.438 HD Request # 135 | Download start date-time: 2022-01-13 16:55:14.000000. File last date-time: 2022-01-13 16:55:14.018000 | 2022-01-13 17:01:43.439 HD Request # 135 | Using server: ds21.sierracharts.com port 10150 | 2022-01-13 17:01:43.439 Socket (4) | Creating socket. | 2022-01-13 17:01:43.439 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:01:43.439 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:01:43.439 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 17:01:44.429 Socket (1) | Closed. | 2022-01-13 17:01:44.429 HD Request # 135 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:45.060 HD Request # 135 | Sending historical data logon request message. | 2022-01-13 17:01:45.060 HD Request # 135 | Requesting Intraday data. Start date-time: 2022-01-13 16:55:14. Record interval: 0. Symbol: ZNH22 | 2022-01-13 17:01:45.367 HD Request # 135 | Decompressing data. | 2022-01-13 17:01:45.677 HD Request # 135 | Receiving Intraday data for ZNH22 starting at 2022-01-13 16:55:14.018000 | 2022-01-13 17:01:46.485 Socket (4) | CloseSocket call. | 2022-01-13 17:01:48.057 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:48.057 Historical data download thread signaled to stop. | 2022-01-13 17:01:48.058 HD Request # 135 | Timestamp of first Intraday data file record written: 2022-01-13 16:55:27.009000 | 2022-01-13 17:01:48.058 HD Request # 135 | Received 1005 Intraday data records from 2022-01-13 16:55:14.018000 to 2022-01-13 17:01:11.013000 (5.9 minutes) and wrote 1004 records for ZNH22 | 2022-01-13 17:01:48.059 HD Request # 135 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:01:11.013000 | 2022-01-13 17:01:48.068 HD Request # 135 | Completion time: 5s | 2022-01-13 17:01:48.068 HD Request # 135 | Intraday data download complete for ZNH22. Unique request ID: 204 | 2022-01-13 17:01:48.068 Removing historical data download ID 204. | 2022-01-13 17:01:48.068 Real-time Intraday chart data file updates started for ZNH22 | 2022-01-13 17:01:48.068 Intraday chart data file opened for ZNH22 | 2022-01-13 17:01:48.068 HD Request # 135 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:48.068 Triggering next historical data download in queue. | 2022-01-13 17:01:48.068 HD Request # 136 | Downloading Intraday chart data for ADR-NASDAQ to the file ADR-NASDAQ.scid. Service: statscalc | 2022-01-13 17:01:48.068 HD Request # 136 | Download start date-time: 2022-01-13 16:58:21.000000. File last date-time: 2022-01-13 16:58:21.209000 | 2022-01-13 17:01:48.069 HD Request # 136 | Using server: ds12.sierracharts.com port 10149 | 2022-01-13 17:01:48.069 Socket (1) | Creating socket. | 2022-01-13 17:01:48.069 Socket (1) | New receive buffer size: 5242880 | 2022-01-13 17:01:48.069 Socket (1) | Connecting to IP: 204.15.197.14. | 2022-01-13 17:01:48.069 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:01:48.363 Socket (4) | Closed. | 2022-01-13 17:01:48.363 HD Request # 136 | Setting DTC encoding to Binary VLS | 2022-01-13 17:01:51.673 HD Request # 136 | Sending historical data logon request message. | 2022-01-13 17:01:51.673 HD Request # 136 | Requesting Intraday data. Start date-time: 2022-01-13 16:58:21. Record interval: 0. Symbol: ADR-NASDAQ | 2022-01-13 17:01:53.470 HD Request # 136 | Decompressing data. | 2022-01-13 17:01:53.767 HD Request # 136 | Receiving Intraday data for ADR-NASDAQ starting at 2022-01-13 16:58:21.000000 | 2022-01-13 17:01:54.276 Socket (1) | CloseSocket call. | 2022-01-13 17:01:55.220 Historical data download thread signaled to stop. | 2022-01-13 17:01:55.220 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:01:55.220 HD Request # 136 | Timestamp of first Intraday data file record written: 2022-01-13 16:58:22.000000 | 2022-01-13 17:01:55.220 HD Request # 136 | Received 211 Intraday data records from 2022-01-13 16:58:21.000000 to 2022-01-13 17:01:51.000000 (3.5 minutes) and wrote 210 records for ADR-NASDAQ | 2022-01-13 17:01:55.220 HD Request # 136 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:01:51.000000 | 2022-01-13 17:01:55.229 Added 13 Time and Sales records to Intraday data file for ADR-NASDAQ after download. | 2022-01-13 17:01:55.229 HD Request # 136 | Completion time: 7s | 2022-01-13 17:01:55.229 HD Request # 136 | Intraday data download complete for ADR-NASDAQ. Unique request ID: 205 | 2022-01-13 17:01:55.229 Removing historical data download ID 205. | 2022-01-13 17:01:55.229 Real-time Intraday chart data file updates started for ADR-NASDAQ | 2022-01-13 17:01:55.229 Intraday chart data file opened for ADR-NASDAQ | 2022-01-13 17:01:55.229 HD Request # 136 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:01:55.229 Triggering next historical data download in queue. | 2022-01-13 17:01:55.229 HD Request # 137 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 17:01:55.229 HD Request # 137 | Download start date-time: 2022-01-13 16:59:26.000000. File last date-time: 2022-01-13 16:59:26.000000 | 2022-01-13 17:01:55.230 HD Request # 137 | Using server: ds13-3.sierracharts.com port 10150 | 2022-01-13 17:01:55.230 Socket (4) | Creating socket. | 2022-01-13 17:01:55.230 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:01:55.230 Socket (4) | Connecting to IP: 64.38.174.180. | 2022-01-13 17:01:55.230 Socket (1) | Socket gracefully closed by remote side. | 2022-01-13 17:01:55.516 Socket (1) | Closed. | 2022-01-13 17:01:55.516 Opened cached Intraday file: C:\SierraChart\Data\ADR-NASDAQ.scid. Thread ID: 11608 | 2022-01-13 17:01:55.597 HD Request # 137 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:02.947 HD Request # 137 | Sending historical data logon request message. | 2022-01-13 17:02:02.947 SC Data - All Services | There has been no activity on the network socket for 1m 14s. Will reconnect. | 2022-01-13 17:02:05.263 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2022-01-13 17:02:05.263 DTC Client socket (11) | CloseSocket call. | 2022-01-13 17:02:05.263 DTC Client socket (11) | Max send buffers used during socket life: 4 | 2022-01-13 17:02:05.263 DTC Client socket (11) | Max send buffer size during socket life: 1242 | 2022-01-13 17:02:05.263 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2022-01-13 17:02:05.263 WSACleanup called. | 2022-01-13 17:02:05.263 DTC Client socket (11) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:05.264 SC Data - All Services | Waiting for socket receive thread to end | 2022-01-13 17:02:05.264 DTC Client socket (9) | CloseSocket call. | 2022-01-13 17:02:05.264 DTC Client socket (9) | Max send buffers used during socket life: 4 | 2022-01-13 17:02:05.264 DTC Client socket (9) | Max send buffer size during socket life: 2367 | 2022-01-13 17:02:05.264 SC Data - All Services | Disconnected from the server. | 2022-01-13 17:02:05.264 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-01-13 17:02:05.264 DTC Client socket (9) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:05.264 DTC Client socket (11) | Socket gracefully closed by remote side. | 2022-01-13 17:02:05.552 DTC Client socket (11) | Closed. | 2022-01-13 17:02:05.552 SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 10048 | 2022-01-13 17:02:07.263 DTC Client socket (1) | Creating socket. | 2022-01-13 17:02:07.264 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-01-13 17:02:07.264 DTC Client socket (1) | Connecting to IP: 38.89.235.129. | 2022-01-13 17:02:07.264 SC Data - All Services | Network connection to server complete. | 2022-01-13 17:02:07.419 SC Data - All Services | Starting socket receive thread. | 2022-01-13 17:02:07.419 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 17:02:07.419 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:07.588 SC Data - All Services | Sending logon request message. | 2022-01-13 17:02:07.588 SC Data - All Services | Received logon response. | 2022-01-13 17:02:08.498 SC Data - All Services | Server Name: SC Realtime Server. | 2022-01-13 17:02:08.498 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 17:02:08.498 SC Data - All Services | Successfully connected. | 2022-01-13 17:02:08.498 SC Data - All Services | Trading is not supported. | 2022-01-13 17:02:08.498 SC Data - All Services (Market Orders Data) | Connecting to the server ds26.sierracharts.com. Port 10060 | 2022-01-13 17:02:08.500 Added historical Intraday data request for 6AH22 to the queue. | 2022-01-13 17:02:08.500 Intraday data recording state for symbol 6AH22 is set to download 'Pending'. | 2022-01-13 17:02:08.500 Triggering next historical data download in queue. | 2022-01-13 17:02:08.500 SC Data - All Services | Restarting real-time data updates for symbol: 6AH22 -> 6AH22. Market Depth data restarted. | 2022-01-13 17:02:08.500 Added historical Intraday data request for 6BH22 to the queue. | 2022-01-13 17:02:08.500 Intraday data recording state for symbol 6BH22 is set to download 'Pending'. | 2022-01-13 17:02:08.500 SC Data - All Services | Restarting real-time data updates for symbol: 6BH22 -> 6BH22. Market Depth data restarted. | 2022-01-13 17:02:08.500 Added historical Intraday data request for 6CH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol 6CH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: 6CH22 -> 6CH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 Added historical Intraday data request for 6EH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol 6EH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: 6EH22 -> 6EH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 Added historical Intraday data request for 6JH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol 6JH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: 6JH22 -> 6JH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: 6MH22 -> 6MH22 | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: 6SH22 -> 6SH22 | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: BBH22 -> BBH22 | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: BTCF22 -> BTCF22 | 2022-01-13 17:02:08.501 Added historical Intraday data request for CLG22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol CLG22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: CLG22 -> CLG22. Market Depth data restarted. | 2022-01-13 17:02:08.501 Added historical Intraday data request for ESH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol ESH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: ESH22 -> ESH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 Added historical Intraday data request for GCG22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol GCG22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: GCG22 -> GCG22. Market Depth data restarted. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: HOG22 -> HOG22 | 2022-01-13 17:02:08.501 Added historical Intraday data request for NGG22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol NGG22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: NGG22 -> NGG22. Market Depth data restarted. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: NKDH22 -> NKDH22 | 2022-01-13 17:02:08.501 Added historical Intraday data request for NQH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol NQH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: NQH22 -> NQH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 Added historical Intraday data request for RBG22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol RBG22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: RBG22 -> RBG22. Market Depth data restarted. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: RTYH22 -> RTYH22 | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: SIH22 -> SIH22 | 2022-01-13 17:02:08.501 Added historical Intraday data request for TNH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol TNH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: TNH22 -> TNH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 Added historical Intraday data request for YMH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol YMH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: YMH22 -> YMH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 Added historical Intraday data request for ZBH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol ZBH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: ZBH22 -> ZBH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 DTC Client socket (5) | Creating socket. | 2022-01-13 17:02:08.501 Added historical Intraday data request for ZFH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol ZFH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: ZFH22 -> ZFH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 Added historical Intraday data request for ZNH22 to the queue. | 2022-01-13 17:02:08.501 Intraday data recording state for symbol ZNH22 is set to download 'Pending'. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: ZNH22 -> ZNH22. Market Depth data restarted. | 2022-01-13 17:02:08.501 SC Data - All Services | Restarting real-time data updates for symbol: ZTH22 -> ZTH22 | 2022-01-13 17:02:08.501 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-01-13 17:02:08.501 DTC Client socket (5) | Connecting to IP: 38.89.235.129. | 2022-01-13 17:02:08.501 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2022-01-13 17:02:08.671 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2022-01-13 17:02:08.671 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2022-01-13 17:02:08.671 SC Data - All Services | Clearing market depth for 6AH22 | 2022-01-13 17:02:08.696 SC Data - All Services | Clearing market depth for 6BH22 | 2022-01-13 17:02:08.696 SC Data - All Services | Clearing market depth for 6CH22 | 2022-01-13 17:02:08.696 SC Data - All Services | Received security definition for symbol 6AH22 | 2022-01-13 17:02:08.703 SC Data - All Services | Received security definition for symbol 6BH22 | 2022-01-13 17:02:08.703 SC Data - All Services | Received security definition for symbol 6CH22 | 2022-01-13 17:02:08.703 SC Data - All Services | Clearing market depth for 6EH22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for 6JH22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for CLG22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for ESH22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for GCG22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for NGG22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for NQH22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for RBG22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for TNH22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for YMH22 | 2022-01-13 17:02:08.829 SC Data - All Services | Clearing market depth for ZBH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Clearing market depth for ZFH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Clearing market depth for ZNH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol 6EH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol 6JH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol 6MH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol 6SH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol BBH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol BTCF22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol CLG22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol ESH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol GCG22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol HOG22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol NGG22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol NKDH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol NQH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol RBG22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol RTYH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol SIH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol TNH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol YMH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol ZBH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol ZFH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol ZNH22 | 2022-01-13 17:02:08.830 SC Data - All Services | Received security definition for symbol ZTH22 | 2022-01-13 17:02:08.830 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:08.833 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2022-01-13 17:02:08.833 SC Data - All Services (Market Orders Data) | Received logon response. | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Successfully connected. | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6AH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6AH22 -> 6AH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6BH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6BH22 -> 6BH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6CH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6CH22 -> 6CH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6EH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6EH22 -> 6EH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: 6JH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: 6JH22 -> 6JH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLG22. MinimumMarketByOrderQuantity: 25. Service code: nymex | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLG22 -> CLG22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESH22. MinimumMarketByOrderQuantity: 50. Service code: cme | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESH22 -> ESH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCG22. MinimumMarketByOrderQuantity: 15. Service code: comex | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: GCG22 -> GCG22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGG22. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGG22 -> NGG22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NQH22. MinimumMarketByOrderQuantity: 15. Service code: cme | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NQH22 -> NQH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: RBG22. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: RBG22 -> RBG22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: TNH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: TNH22 -> TNH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: YMH22. MinimumMarketByOrderQuantity: 20. Service code: cbot | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: YMH22 -> YMH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZBH22. MinimumMarketByOrderQuantity: 200. Service code: cbot | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZBH22 -> ZBH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZFH22. MinimumMarketByOrderQuantity: 750. Service code: cbot | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZFH22 -> ZFH22 | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZNH22. MinimumMarketByOrderQuantity: 1500. Service code: cbot | 2022-01-13 17:02:09.729 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZNH22 -> ZNH22 | 2022-01-13 17:02:09.729 HD Request # 137 | Requesting Intraday data. Start date-time: 2022-01-13 16:59:26. Record interval: 0. Symbol: ADV-NYSE | 2022-01-13 17:02:18.835 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:02:19.187 Socket (4) | CloseSocket call. | 2022-01-13 17:02:19.187 Socket (0) | CloseSocket call. | 2022-01-13 17:02:19.187 Socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-01-13 17:02:19.187 Socket (4) | Closed. | 2022-01-13 17:02:19.187 HD Request # 137 | Error downloading historical Intraday data for ADV-NYSE. The network socket has been closed. Retrying download. | 2022-01-13 17:02:19.188 Added historical Intraday data request for ADV-NYSE to the queue. | 2022-01-13 17:02:19.188 Triggering next historical data download in queue. | 2022-01-13 17:02:19.188 Historical data download thread signaled to stop. | 2022-01-13 17:02:19.188 HD Request # 137 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ADV-NYSE | 2022-01-13 17:02:19.188 HD Request # 137 | Completion time: 24s | 2022-01-13 17:02:19.188 HD Request # 138 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2022-01-13 17:02:19.188 HD Request # 138 | Download start date-time: 2022-01-13 16:59:26.000000. File last date-time: 2022-01-13 16:59:26.000000 | 2022-01-13 17:02:19.189 HD Request # 138 | Using server: ds4.sierracharts.com port 10149 | 2022-01-13 17:02:19.189 Socket (4) | Creating socket. | 2022-01-13 17:02:19.189 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:02:19.189 Socket (4) | Connecting to IP: 192.81.56.146. | 2022-01-13 17:02:19.189 HD Request # 138 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:19.780 HD Request # 138 | Sending historical data logon request message. | 2022-01-13 17:02:19.780 HD Request # 138 | Requesting Intraday data. Start date-time: 2022-01-13 16:59:26. Record interval: 0. Symbol: ADV-NYSE | 2022-01-13 17:02:20.620 HD Request # 138 | Decompressing data. | 2022-01-13 17:02:20.914 HD Request # 138 | Receiving Intraday data for ADV-NYSE starting at 2022-01-13 16:59:26.000000 | 2022-01-13 17:02:20.915 Socket (4) | CloseSocket call. | 2022-01-13 17:02:20.916 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:20.916 Historical data download thread signaled to stop. | 2022-01-13 17:02:20.943 HD Request # 138 | Timestamp of first Intraday data file record written: 2022-01-13 16:59:27.000000 | 2022-01-13 17:02:20.943 HD Request # 138 | Received 173 Intraday data records from 2022-01-13 16:59:26.000000 to 2022-01-13 17:02:18.000000 (2.9 minutes) and wrote 172 records for ADV-NYSE | 2022-01-13 17:02:20.943 HD Request # 138 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:18.000000 | 2022-01-13 17:02:20.951 Added 5 Time and Sales records to Intraday data file for ADV-NYSE after download. | 2022-01-13 17:02:20.951 HD Request # 138 | Completion time: 1s | 2022-01-13 17:02:20.951 HD Request # 138 | Intraday data download complete for ADV-NYSE. Unique request ID: 206 | 2022-01-13 17:02:20.951 Removing historical data download ID 206. | 2022-01-13 17:02:20.951 Real-time Intraday chart data file updates started for ADV-NYSE | 2022-01-13 17:02:20.951 Intraday chart data file opened for ADV-NYSE | 2022-01-13 17:02:20.951 HD Request # 138 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:02:20.951 Triggering next historical data download in queue. | 2022-01-13 17:02:20.951 HD Request # 139 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2022-01-13 17:02:20.952 HD Request # 139 | Download start date-time: 2022-01-13 16:59:08.000000. File last date-time: 2022-01-13 16:59:08.000000 | 2022-01-13 17:02:20.952 HD Request # 139 | Using server: ds12.sierracharts.com port 10150 | 2022-01-13 17:02:20.952 Socket (6) | Creating socket. | 2022-01-13 17:02:20.952 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 17:02:20.952 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-01-13 17:02:20.952 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:02:21.210 Socket (4) | Closed. | 2022-01-13 17:02:21.210 HD Request # 139 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:22.508 HD Request # 139 | Sending historical data logon request message. | 2022-01-13 17:02:22.508 Opened cached Intraday file: C:\SierraChart\Data\ADV-NYSE.scid. Thread ID: 11608 | 2022-01-13 17:02:25.844 HD Request # 139 | Requesting Intraday data. Start date-time: 2022-01-13 16:59:08. Record interval: 0. Symbol: TRIN-NYSE | 2022-01-13 17:02:26.034 HD Request # 139 | Decompressing data. | 2022-01-13 17:02:26.333 HD Request # 139 | Receiving Intraday data for TRIN-NYSE starting at 2022-01-13 16:59:08.000000 | 2022-01-13 17:02:26.635 Socket (6) | CloseSocket call. | 2022-01-13 17:02:26.636 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:26.636 Historical data download thread signaled to stop. | 2022-01-13 17:02:26.639 HD Request # 139 | Timestamp of first Intraday data file record written: 2022-01-13 16:59:09.000000 | 2022-01-13 17:02:26.639 HD Request # 139 | Received 197 Intraday data records from 2022-01-13 16:59:08.000000 to 2022-01-13 17:02:24.000000 (3.3 minutes) and wrote 196 records for TRIN-NYSE | 2022-01-13 17:02:26.639 HD Request # 139 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:24.000000 | 2022-01-13 17:02:26.647 Added 11 Time and Sales records to Intraday data file for TRIN-NYSE after download. | 2022-01-13 17:02:26.647 HD Request # 139 | Completion time: 6s | 2022-01-13 17:02:26.647 HD Request # 139 | Intraday data download complete for TRIN-NYSE. Unique request ID: 207 | 2022-01-13 17:02:26.647 Removing historical data download ID 207. | 2022-01-13 17:02:26.647 Real-time Intraday chart data file updates started for TRIN-NYSE | 2022-01-13 17:02:26.647 Intraday chart data file opened for TRIN-NYSE | 2022-01-13 17:02:26.647 HD Request # 139 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:02:26.647 Triggering next historical data download in queue. | 2022-01-13 17:02:26.647 HD Request # 140 | Downloading Intraday chart data for TRIN-SP to the file TRIN-SP.scid. Service: statscalc | 2022-01-13 17:02:26.647 HD Request # 140 | Download start date-time: 2022-01-13 16:59:29.000000. File last date-time: 2022-01-13 16:59:29.000000 | 2022-01-13 17:02:26.647 HD Request # 140 | Using server: ds13-3.sierracharts.com port 10149 | 2022-01-13 17:02:26.647 Socket (4) | Creating socket. | 2022-01-13 17:02:26.647 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:02:26.647 Socket (4) | Connecting to IP: 64.38.174.180. | 2022-01-13 17:02:26.647 HD Request # 140 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:27.352 HD Request # 140 | Sending historical data logon request message. | 2022-01-13 17:02:27.352 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 17:02:27.615 Socket (6) | Closed. | 2022-01-13 17:02:27.615 HD Request # 140 | Requesting Intraday data. Start date-time: 2022-01-13 16:59:29. Record interval: 0. Symbol: TRIN-SP | 2022-01-13 17:02:29.256 HD Request # 140 | Decompressing data. | 2022-01-13 17:02:29.621 HD Request # 140 | Receiving Intraday data for TRIN-SP starting at 2022-01-13 16:59:29.000000 | 2022-01-13 17:02:30.124 Socket (4) | CloseSocket call. | 2022-01-13 17:02:30.758 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:30.758 Historical data download thread signaled to stop. | 2022-01-13 17:02:30.766 HD Request # 140 | Timestamp of first Intraday data file record written: 2022-01-13 16:59:30.000000 | 2022-01-13 17:02:30.766 HD Request # 140 | Received 179 Intraday data records from 2022-01-13 16:59:29.000000 to 2022-01-13 17:02:27.000000 (3.0 minutes) and wrote 178 records for TRIN-SP | 2022-01-13 17:02:30.767 HD Request # 140 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:27.000000 | 2022-01-13 17:02:30.775 Added 10 Time and Sales records to Intraday data file for TRIN-SP after download. | 2022-01-13 17:02:30.775 HD Request # 140 | Completion time: 4s | 2022-01-13 17:02:30.775 HD Request # 140 | Intraday data download complete for TRIN-SP. Unique request ID: 208 | 2022-01-13 17:02:30.775 Removing historical data download ID 208. | 2022-01-13 17:02:30.775 Real-time Intraday chart data file updates started for TRIN-SP | 2022-01-13 17:02:30.775 Intraday chart data file opened for TRIN-SP | 2022-01-13 17:02:30.775 HD Request # 140 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:02:30.775 Triggering next historical data download in queue. | 2022-01-13 17:02:30.775 HD Request # 141 | Downloading Intraday chart data for 6AH22 to the file 6AH22.scid. Service: cme | 2022-01-13 17:02:30.775 HD Request # 141 | Download start date-time: 2022-01-13 16:58:05.000000. File last date-time: 2022-01-13 16:58:05.305001 | 2022-01-13 17:02:30.775 HD Request # 141 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 17:02:30.775 Socket (6) | Creating socket. | 2022-01-13 17:02:30.775 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 17:02:30.775 Socket (6) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:02:30.775 Opened cached Intraday file: C:\SierraChart\Data\TRIN-NYSE.scid. Thread ID: 11608 | 2022-01-13 17:02:30.894 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:02:31.105 Socket (4) | Closed. | 2022-01-13 17:02:31.105 HD Request # 141 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:31.398 HD Request # 141 | Sending historical data logon request message. | 2022-01-13 17:02:31.398 HD Request # 141 | Requesting Intraday data. Start date-time: 2022-01-13 16:58:05. Record interval: 0. Symbol: 6AH22 | 2022-01-13 17:02:32.156 HD Request # 141 | Decompressing data. | 2022-01-13 17:02:33.197 HD Request # 141 | Receiving Intraday data for 6AH22 starting at 2022-01-13 16:58:05.305000 | 2022-01-13 17:02:33.197 Socket (6) | CloseSocket call. | 2022-01-13 17:02:33.198 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:33.198 Historical data download thread signaled to stop. | 2022-01-13 17:02:33.207 HD Request # 141 | Timestamp of first Intraday data file record written: 2022-01-13 16:58:12.082000 | 2022-01-13 17:02:33.207 HD Request # 141 | Received 137 Intraday data records from 2022-01-13 16:58:05.305000 to 2022-01-13 17:02:24.703005 (4.3 minutes) and wrote 135 records for 6AH22 | 2022-01-13 17:02:33.207 HD Request # 141 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:24.703005 | 2022-01-13 17:02:33.214 HD Request # 141 | Completion time: 3s | 2022-01-13 17:02:33.214 HD Request # 141 | Intraday data download complete for 6AH22. Unique request ID: 209 | 2022-01-13 17:02:33.214 Removing historical data download ID 209. | 2022-01-13 17:02:33.214 Real-time Intraday chart data file updates started for 6AH22 | 2022-01-13 17:02:33.214 Intraday chart data file opened for 6AH22 | 2022-01-13 17:02:33.214 HD Request # 141 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:02:33.214 Triggering next historical data download in queue. | 2022-01-13 17:02:33.214 HD Request # 142 | Downloading Intraday chart data for 6BH22 to the file 6BH22.scid. Service: cme | 2022-01-13 17:02:33.214 HD Request # 142 | Download start date-time: 2022-01-13 16:58:05.000000. File last date-time: 2022-01-13 16:58:05.304000 | 2022-01-13 17:02:33.214 HD Request # 142 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 17:02:33.214 Socket (4) | Creating socket. | 2022-01-13 17:02:33.215 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:02:33.215 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:02:33.215 HD Request # 142 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:33.820 HD Request # 142 | Sending historical data logon request message. | 2022-01-13 17:02:33.820 HD Request # 142 | Requesting Intraday data. Start date-time: 2022-01-13 16:58:05. Record interval: 0. Symbol: 6BH22 | 2022-01-13 17:02:34.596 HD Request # 142 | Decompressing data. | 2022-01-13 17:02:34.895 HD Request # 142 | Receiving Intraday data for 6BH22 starting at 2022-01-13 16:58:05.293000 | 2022-01-13 17:02:34.896 Socket (4) | CloseSocket call. | 2022-01-13 17:02:34.897 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:34.898 Historical data download thread signaled to stop. | 2022-01-13 17:02:34.899 HD Request # 142 | Timestamp of first Intraday data file record written: 2022-01-13 16:58:08.899000 | 2022-01-13 17:02:34.900 HD Request # 142 | Received 156 Intraday data records from 2022-01-13 16:58:05.293000 to 2022-01-13 17:02:26.193001 (4.3 minutes) and wrote 151 records for 6BH22 | 2022-01-13 17:02:34.900 HD Request # 142 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:26.193001 | 2022-01-13 17:02:34.907 HD Request # 142 | Completion time: 1s | 2022-01-13 17:02:34.907 HD Request # 142 | Intraday data download complete for 6BH22. Unique request ID: 210 | 2022-01-13 17:02:34.907 Removing historical data download ID 210. | 2022-01-13 17:02:34.907 Real-time Intraday chart data file updates started for 6BH22 | 2022-01-13 17:02:34.907 Intraday chart data file opened for 6BH22 | 2022-01-13 17:02:34.907 HD Request # 142 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:02:34.907 Triggering next historical data download in queue. | 2022-01-13 17:02:34.908 HD Request # 143 | Downloading Intraday chart data for 6CH22 to the file 6CH22.scid. Service: cme | 2022-01-13 17:02:34.908 HD Request # 143 | Download start date-time: 2022-01-13 16:58:05.000000. File last date-time: 2022-01-13 16:58:05.441000 | 2022-01-13 17:02:34.908 HD Request # 143 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 17:02:34.908 Socket (7) | Creating socket. | 2022-01-13 17:02:34.908 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 17:02:34.908 Socket (7) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:02:34.908 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 17:02:35.511 Socket (6) | Closed. | 2022-01-13 17:02:35.511 HD Request # 143 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:35.524 HD Request # 143 | Sending historical data logon request message. | 2022-01-13 17:02:35.524 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:02:35.808 Socket (4) | Closed. | 2022-01-13 17:02:35.808 HD Request # 143 | Requesting Intraday data. Start date-time: 2022-01-13 16:58:05. Record interval: 0. Symbol: 6CH22 | 2022-01-13 17:02:35.819 Opened cached Intraday file: C:\SierraChart\Data\6BH22.scid. Thread ID: 11608 | 2022-01-13 17:02:35.921 Opened cached Intraday file: C:\SierraChart\Data\TRIN-SP.scid. Thread ID: 11608 | 2022-01-13 17:02:35.922 HD Request # 143 | Decompressing data. | 2022-01-13 17:02:36.121 HD Request # 143 | Receiving Intraday data for 6CH22 starting at 2022-01-13 16:58:05.305000 | 2022-01-13 17:02:36.122 Socket (7) | CloseSocket call. | 2022-01-13 17:02:36.123 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:36.123 Historical data download thread signaled to stop. | 2022-01-13 17:02:36.152 HD Request # 143 | Timestamp of first Intraday data file record written: 2022-01-13 16:58:17.029000 | 2022-01-13 17:02:36.152 HD Request # 143 | Received 162 Intraday data records from 2022-01-13 16:58:05.305000 to 2022-01-13 17:02:25.414000 (4.3 minutes) and wrote 157 records for 6CH22 | 2022-01-13 17:02:36.152 HD Request # 143 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:25.414000 | 2022-01-13 17:02:36.162 HD Request # 143 | Completion time: 2s | 2022-01-13 17:02:36.162 HD Request # 143 | Intraday data download complete for 6CH22. Unique request ID: 211 | 2022-01-13 17:02:36.162 Removing historical data download ID 211. | 2022-01-13 17:02:36.162 Real-time Intraday chart data file updates started for 6CH22 | 2022-01-13 17:02:36.162 Intraday chart data file opened for 6CH22 | 2022-01-13 17:02:36.162 HD Request # 143 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:02:36.162 Triggering next historical data download in queue. | 2022-01-13 17:02:36.162 HD Request # 144 | Downloading Intraday chart data for 6EH22 to the file 6EH22.scid. Service: cme | 2022-01-13 17:02:36.162 HD Request # 144 | Download start date-time: 2022-01-13 17:00:39.000000. File last date-time: 2022-01-13 17:00:39.061000 | 2022-01-13 17:02:36.162 HD Request # 144 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 17:02:36.164 Socket (4) | Creating socket. | 2022-01-13 17:02:36.164 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:02:36.164 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:02:36.164 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 17:02:37.018 Socket (7) | Closed. | 2022-01-13 17:02:37.018 HD Request # 144 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:39.769 HD Request # 144 | Sending historical data logon request message. | 2022-01-13 17:02:39.769 Opened cached Intraday file: C:\SierraChart\Data\6AH22.scid. Thread ID: 11608 | 2022-01-13 17:02:40.964 HD Request # 144 | Requesting Intraday data. Start date-time: 2022-01-13 17:00:39. Record interval: 0. Symbol: 6EH22 | 2022-01-13 17:02:42.752 HD Request # 144 | Decompressing data. | 2022-01-13 17:02:43.052 HD Request # 144 | Receiving Intraday data for 6EH22 starting at 2022-01-13 17:00:39.043000 | 2022-01-13 17:02:43.052 Socket (4) | CloseSocket call. | 2022-01-13 17:02:43.053 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:43.053 Historical data download thread signaled to stop. | 2022-01-13 17:02:43.068 HD Request # 144 | Timestamp of first Intraday data file record written: 2022-01-13 17:00:40.448000 | 2022-01-13 17:02:43.068 HD Request # 144 | Received 91 Intraday data records from 2022-01-13 17:00:39.043000 to 2022-01-13 17:02:36.788000 (117.7 seconds) and wrote 65 records for 6EH22 | 2022-01-13 17:02:43.068 HD Request # 144 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:36.788000 | 2022-01-13 17:02:43.076 HD Request # 144 | Completion time: 7s | 2022-01-13 17:02:43.076 HD Request # 144 | Intraday data download complete for 6EH22. Unique request ID: 212 | 2022-01-13 17:02:43.076 Removing historical data download ID 212. | 2022-01-13 17:02:43.076 Real-time Intraday chart data file updates started for 6EH22 | 2022-01-13 17:02:43.076 Intraday chart data file opened for 6EH22 | 2022-01-13 17:02:43.076 HD Request # 144 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:02:43.076 Triggering next historical data download in queue. | 2022-01-13 17:02:43.076 HD Request # 145 | Downloading Intraday chart data for 6JH22 to the file 6JH22.scid. Service: cme | 2022-01-13 17:02:43.077 HD Request # 145 | Download start date-time: 2022-01-13 17:00:29.000000. File last date-time: 2022-01-13 17:00:29.694001 | 2022-01-13 17:02:43.077 HD Request # 145 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 17:02:43.078 Socket (6) | Creating socket. | 2022-01-13 17:02:43.078 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 17:02:43.078 Socket (6) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:02:43.078 HD Request # 145 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:43.692 HD Request # 145 | Sending historical data logon request message. | 2022-01-13 17:02:43.693 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:02:44.131 Socket (4) | Closed. | 2022-01-13 17:02:44.131 HD Request # 145 | Requesting Intraday data. Start date-time: 2022-01-13 17:00:29. Record interval: 0. Symbol: 6JH22 | 2022-01-13 17:02:46.231 HD Request # 145 | Decompressing data. | 2022-01-13 17:02:46.530 HD Request # 145 | Receiving Intraday data for 6JH22 starting at 2022-01-13 17:00:29.694000 | 2022-01-13 17:02:46.531 Socket (6) | CloseSocket call. | 2022-01-13 17:02:46.532 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:46.532 Historical data download thread signaled to stop. | 2022-01-13 17:02:46.539 HD Request # 145 | Timestamp of first Intraday data file record written: 2022-01-13 17:00:45.146000 | 2022-01-13 17:02:46.539 HD Request # 145 | Received 55 Intraday data records from 2022-01-13 17:00:29.694000 to 2022-01-13 17:02:35.322001 (2.1 minutes) and wrote 53 records for 6JH22 | 2022-01-13 17:02:46.539 HD Request # 145 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:35.322001 | 2022-01-13 17:02:46.547 HD Request # 145 | Completion time: 3s | 2022-01-13 17:02:46.547 HD Request # 145 | Intraday data download complete for 6JH22. Unique request ID: 213 | 2022-01-13 17:02:46.547 Removing historical data download ID 213. | 2022-01-13 17:02:46.547 Real-time Intraday chart data file updates started for 6JH22 | 2022-01-13 17:02:46.547 Intraday chart data file opened for 6JH22 | 2022-01-13 17:02:46.547 HD Request # 145 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:02:46.547 Triggering next historical data download in queue. | 2022-01-13 17:02:46.547 HD Request # 146 | Downloading Intraday chart data for CLG22 to the file CLG22.scid. Service: nymex | 2022-01-13 17:02:46.547 HD Request # 146 | Download start date-time: 2022-01-13 17:00:51.000000. File last date-time: 2022-01-13 17:00:51.372000 | 2022-01-13 17:02:46.548 HD Request # 146 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 17:02:46.548 Socket (4) | Creating socket. | 2022-01-13 17:02:46.548 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:02:46.548 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:02:46.548 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 17:02:46.829 Socket (6) | Closed. | 2022-01-13 17:02:46.829 HD Request # 146 | Setting DTC encoding to Binary VLS | 2022-01-13 17:02:50.161 HD Request # 146 | Sending historical data logon request message. | 2022-01-13 17:02:50.162 HD Request # 146 | Requesting Intraday data. Start date-time: 2022-01-13 17:00:51. Record interval: 0. Symbol: CLG22 | 2022-01-13 17:02:50.460 Opened cached Intraday file: C:\SierraChart\Data\6EH22.scid. Thread ID: 11608 | 2022-01-13 17:02:51.063 HD Request # 146 | Decompressing data. | 2022-01-13 17:02:51.408 HD Request # 146 | Receiving Intraday data for CLG22 starting at 2022-01-13 17:00:51.372000 | 2022-01-13 17:02:53.384 Socket (4) | CloseSocket call. | 2022-01-13 17:02:53.385 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:02:53.385 Historical data download thread signaled to stop. | 2022-01-13 17:02:53.396 HD Request # 146 | Timestamp of first Intraday data file record written: 2022-01-13 17:00:52.782000 | 2022-01-13 17:02:53.396 HD Request # 146 | Received 488 Intraday data records from 2022-01-13 17:00:51.372000 to 2022-01-13 17:02:48.835000 (117.5 seconds) and wrote 487 records for CLG22 | 2022-01-13 17:02:53.396 HD Request # 146 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:48.835000 | 2022-01-13 17:02:53.403 Added 3 Time and Sales records to Intraday data file for CLG22 after download. | 2022-01-13 17:02:53.403 HD Request # 146 | Completion time: 7s | 2022-01-13 17:02:53.404 HD Request # 146 | Intraday data download complete for CLG22. Unique request ID: 214 | 2022-01-13 17:02:53.404 Removing historical data download ID 214. | 2022-01-13 17:02:53.404 Real-time Intraday chart data file updates started for CLG22 | 2022-01-13 17:02:53.404 Intraday chart data file opened for CLG22 | 2022-01-13 17:02:53.404 HD Request # 146 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:02:53.404 Triggering next historical data download in queue. | 2022-01-13 17:02:53.404 HD Request # 147 | Downloading Intraday chart data for ESH22 to the file ESH22.scid. Service: cme | 2022-01-13 17:02:53.404 HD Request # 147 | Download start date-time: 2022-01-13 17:00:54.000000. File last date-time: 2022-01-13 17:00:54.645001 | 2022-01-13 17:02:53.405 HD Request # 147 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 17:02:53.405 Socket (6) | Creating socket. | 2022-01-13 17:02:53.405 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 17:02:53.405 Socket (6) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:02:53.405 Opened cached Intraday file: C:\SierraChart\Data\6CH22.scid. Thread ID: 11608 | 2022-01-13 17:02:56.096 Opened cached Intraday file: C:\SierraChart\Data\CLG22.scid. Thread ID: 11608 | 2022-01-13 17:02:56.097 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:02:57.431 Socket (4) | Closed. | 2022-01-13 17:02:57.431 HD Request # 147 | Setting DTC encoding to Binary VLS | 2022-01-13 17:03:00.051 HD Request # 147 | Sending historical data logon request message. | 2022-01-13 17:03:00.051 HD Request # 147 | Requesting Intraday data. Start date-time: 2022-01-13 17:00:54. Record interval: 0. Symbol: ESH22 | 2022-01-13 17:03:01.007 HD Request # 147 | Decompressing data. | 2022-01-13 17:03:02.801 HD Request # 147 | Receiving Intraday data for ESH22 starting at 2022-01-13 17:00:54.373000 | 2022-01-13 17:03:02.801 Socket (6) | CloseSocket call. | 2022-01-13 17:03:03.219 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:03:03.219 Historical data download thread signaled to stop. | 2022-01-13 17:03:03.221 HD Request # 147 | Timestamp of first Intraday data file record written: 2022-01-13 17:00:55.130000 | 2022-01-13 17:03:03.222 HD Request # 147 | Received 3442 Intraday data records from 2022-01-13 17:00:54.373000 to 2022-01-13 17:02:55.970000 (2.0 minutes) and wrote 3418 records for ESH22 | 2022-01-13 17:03:03.222 HD Request # 147 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:55.970000 | 2022-01-13 17:03:03.230 Added 139 Time and Sales records to Intraday data file for ESH22 after download. | 2022-01-13 17:03:03.230 HD Request # 147 | Completion time: 10s | 2022-01-13 17:03:03.230 HD Request # 147 | Intraday data download complete for ESH22. Unique request ID: 215 | 2022-01-13 17:03:03.230 Removing historical data download ID 215. | 2022-01-13 17:03:03.230 Real-time Intraday chart data file updates started for ESH22 | 2022-01-13 17:03:03.230 Intraday chart data file opened for ESH22 | 2022-01-13 17:03:03.230 HD Request # 147 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:03:03.230 Triggering next historical data download in queue. | 2022-01-13 17:03:03.230 HD Request # 148 | Downloading Intraday chart data for GCG22 to the file GCG22.scid. Service: comex | 2022-01-13 17:03:03.230 HD Request # 148 | Download start date-time: 2022-01-13 17:00:57.000000. File last date-time: 2022-01-13 17:00:57.120000 | 2022-01-13 17:03:03.230 HD Request # 148 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 17:03:03.230 Socket (4) | Creating socket. | 2022-01-13 17:03:03.230 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:03:03.230 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:03:03.230 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 17:03:03.521 Socket (6) | Closed. | 2022-01-13 17:03:03.521 HD Request # 148 | Setting DTC encoding to Binary VLS | 2022-01-13 17:03:03.829 HD Request # 148 | Sending historical data logon request message. | 2022-01-13 17:03:03.829 HD Request # 148 | Requesting Intraday data. Start date-time: 2022-01-13 17:00:57. Record interval: 0. Symbol: GCG22 | 2022-01-13 17:03:04.928 Opened cached Intraday file: C:\SierraChart\Data\ESH22.scid. Thread ID: 11608 | 2022-01-13 17:03:06.195 HD Request # 148 | Decompressing data. | 2022-01-13 17:03:12.618 HD Request # 148 | Receiving Intraday data for GCG22 starting at 2022-01-13 17:00:57.120000 | 2022-01-13 17:03:12.618 Socket (4) | CloseSocket call. | 2022-01-13 17:03:12.619 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:03:12.619 Historical data download thread signaled to stop. | 2022-01-13 17:03:12.625 HD Request # 148 | Timestamp of first Intraday data file record written: 2022-01-13 17:00:59.296000 | 2022-01-13 17:03:12.625 HD Request # 148 | Received 131 Intraday data records from 2022-01-13 17:00:57.120000 to 2022-01-13 17:02:57.369000 (2.0 minutes) and wrote 130 records for GCG22 | 2022-01-13 17:03:12.625 HD Request # 148 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:02:57.369000 | 2022-01-13 17:03:12.634 Added 1 Time and Sales records to Intraday data file for GCG22 after download. | 2022-01-13 17:03:12.634 HD Request # 148 | Completion time: 9s | 2022-01-13 17:03:12.634 HD Request # 148 | Intraday data download complete for GCG22. Unique request ID: 216 | 2022-01-13 17:03:12.634 Removing historical data download ID 216. | 2022-01-13 17:03:12.634 Real-time Intraday chart data file updates started for GCG22 | 2022-01-13 17:03:12.634 Intraday chart data file opened for GCG22 | 2022-01-13 17:03:12.634 HD Request # 148 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:03:12.634 Triggering next historical data download in queue. | 2022-01-13 17:03:12.634 HD Request # 149 | Downloading Intraday chart data for NGG22 to the file NGG22.scid. Service: nymex | 2022-01-13 17:03:12.634 HD Request # 149 | Download start date-time: 2022-01-13 17:01:02.000000. File last date-time: 2022-01-13 17:01:02.252001 | 2022-01-13 17:03:12.635 HD Request # 149 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 17:03:12.635 Socket (7) | Creating socket. | 2022-01-13 17:03:12.635 Socket (7) | New receive buffer size: 5242880 | 2022-01-13 17:03:12.635 Socket (7) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:03:12.635 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:03:12.923 Socket (4) | Closed. | 2022-01-13 17:03:12.923 HD Request # 149 | Setting DTC encoding to Binary VLS | 2022-01-13 17:03:16.073 HD Request # 149 | Sending historical data logon request message. | 2022-01-13 17:03:16.073 HD Request # 149 | Requesting Intraday data. Start date-time: 2022-01-13 17:01:02. Record interval: 0. Symbol: NGG22 | 2022-01-13 17:03:16.846 HD Request # 149 | Decompressing data. | 2022-01-13 17:03:17.984 HD Request # 149 | Receiving Intraday data for NGG22 starting at 2022-01-13 17:01:02.248000 | 2022-01-13 17:03:17.984 Opened cached Intraday file: C:\SierraChart\Data\GCG22.scid. Thread ID: 11608 | 2022-01-13 17:03:21.271 Opened cached Intraday file: C:\SierraChart\Data\6JH22.scid. Thread ID: 11608 | 2022-01-13 17:03:21.272 Socket (7) | CloseSocket call. | 2022-01-13 17:03:25.376 Socket (7) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:03:25.376 Historical data download thread signaled to stop. | 2022-01-13 17:03:25.401 HD Request # 149 | Timestamp of first Intraday data file record written: 2022-01-13 17:01:03.814000 | 2022-01-13 17:03:25.401 HD Request # 149 | Received 299 Intraday data records from 2022-01-13 17:01:02.248000 to 2022-01-13 17:03:11.775000 (2.2 minutes) and wrote 293 records for NGG22 | 2022-01-13 17:03:25.401 HD Request # 149 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:03:11.775000 | 2022-01-13 17:03:25.409 Added 42 Time and Sales records to Intraday data file for NGG22 after download. | 2022-01-13 17:03:25.409 HD Request # 149 | Completion time: 13s | 2022-01-13 17:03:25.410 HD Request # 149 | Intraday data download complete for NGG22. Unique request ID: 217 | 2022-01-13 17:03:25.410 Removing historical data download ID 217. | 2022-01-13 17:03:25.410 Real-time Intraday chart data file updates started for NGG22 | 2022-01-13 17:03:25.410 Intraday chart data file opened for NGG22 | 2022-01-13 17:03:25.410 HD Request # 149 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:03:25.410 Triggering next historical data download in queue. | 2022-01-13 17:03:25.410 HD Request # 150 | Downloading Intraday chart data for NQH22 to the file NQH22.scid. Service: cme | 2022-01-13 17:03:25.410 HD Request # 150 | Download start date-time: 2022-01-13 17:01:03.000000. File last date-time: 2022-01-13 17:01:03.279000 | 2022-01-13 17:03:25.410 HD Request # 150 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 17:03:25.411 Socket (4) | Creating socket. | 2022-01-13 17:03:25.411 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:03:25.411 Socket (4) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:03:25.411 Socket (7) | Socket gracefully closed by remote side. | 2022-01-13 17:03:25.677 Socket (7) | Closed. | 2022-01-13 17:03:25.677 Opened cached Intraday file: C:\SierraChart\Data\NGG22.scid. Thread ID: 11608 | 2022-01-13 17:03:26.334 HD Request # 150 | Setting DTC encoding to Binary VLS | 2022-01-13 17:03:28.701 HD Request # 150 | Sending historical data logon request message. | 2022-01-13 17:03:28.701 HD Request # 150 | Requesting Intraday data. Start date-time: 2022-01-13 17:01:03. Record interval: 0. Symbol: NQH22 | 2022-01-13 17:03:47.900 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:03:48.189 Socket (4) | CloseSocket call. | 2022-01-13 17:03:48.189 Socket (0) | CloseSocket call. | 2022-01-13 17:03:48.189 Socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-01-13 17:03:48.189 Socket (4) | Closed. | 2022-01-13 17:03:48.189 HD Request # 150 | Error downloading historical Intraday data for NQH22. The network socket has been closed. Retrying download. | 2022-01-13 17:03:48.190 Added historical Intraday data request for NQH22 to the queue. | 2022-01-13 17:03:48.190 Triggering next historical data download in queue. | 2022-01-13 17:03:48.190 Historical data download thread signaled to stop. | 2022-01-13 17:03:48.190 HD Request # 150 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for NQH22 | 2022-01-13 17:03:48.190 HD Request # 150 | Completion time: 23s | 2022-01-13 17:03:48.190 HD Request # 151 | Downloading Intraday chart data for NQH22 to the file NQH22.scid. Service: cme | 2022-01-13 17:03:48.190 HD Request # 151 | Download start date-time: 2022-01-13 17:01:03.000000. File last date-time: 2022-01-13 17:01:03.279000 | 2022-01-13 17:03:48.191 HD Request # 151 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 17:03:48.191 Socket (4) | Creating socket. | 2022-01-13 17:03:48.191 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:03:48.191 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:03:48.191 HD Request # 151 | Setting DTC encoding to Binary VLS | 2022-01-13 17:03:48.808 HD Request # 151 | Sending historical data logon request message. | 2022-01-13 17:03:48.808 HD Request # 151 | Requesting Intraday data. Start date-time: 2022-01-13 17:01:03. Record interval: 0. Symbol: NQH22 | 2022-01-13 17:03:49.576 HD Request # 151 | Decompressing data. | 2022-01-13 17:03:49.870 HD Request # 151 | Receiving Intraday data for NQH22 starting at 2022-01-13 17:01:03.072000 | 2022-01-13 17:03:50.392 Socket (4) | CloseSocket call. | 2022-01-13 17:03:54.436 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:03:54.436 Historical data download thread signaled to stop. | 2022-01-13 17:03:54.493 HD Request # 151 | Timestamp of first Intraday data file record written: 2022-01-13 17:01:03.281000 | 2022-01-13 17:03:54.494 HD Request # 151 | Received 2602 Intraday data records from 2022-01-13 17:01:03.072000 to 2022-01-13 17:03:44.581000 (2.7 minutes) and wrote 2546 records for NQH22 | 2022-01-13 17:03:54.494 HD Request # 151 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:03:44.581000 | 2022-01-13 17:03:54.501 Added 57 Time and Sales records to Intraday data file for NQH22 after download. | 2022-01-13 17:03:54.501 HD Request # 151 | Completion time: 6s | 2022-01-13 17:03:54.501 HD Request # 151 | Intraday data download complete for NQH22. Unique request ID: 218 | 2022-01-13 17:03:54.501 Removing historical data download ID 218. | 2022-01-13 17:03:54.501 Real-time Intraday chart data file updates started for NQH22 | 2022-01-13 17:03:54.501 Intraday chart data file opened for NQH22 | 2022-01-13 17:03:54.501 HD Request # 151 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:03:54.501 Triggering next historical data download in queue. | 2022-01-13 17:03:54.501 HD Request # 152 | Downloading Intraday chart data for RBG22 to the file RBG22.scid. Service: nymex | 2022-01-13 17:03:54.502 HD Request # 152 | Download start date-time: 2022-01-13 17:01:10.000000. File last date-time: 2022-01-13 17:01:10.892002 | 2022-01-13 17:03:54.502 HD Request # 152 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 17:03:54.503 Socket (6) | Creating socket. | 2022-01-13 17:03:54.503 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 17:03:54.503 Socket (6) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:03:54.503 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:03:54.741 Socket (4) | Closed. | 2022-01-13 17:03:54.741 HD Request # 152 | Setting DTC encoding to Binary VLS | 2022-01-13 17:03:55.106 HD Request # 152 | Sending historical data logon request message. | 2022-01-13 17:03:55.106 HD Request # 152 | Requesting Intraday data. Start date-time: 2022-01-13 17:01:10. Record interval: 0. Symbol: RBG22 | 2022-01-13 17:03:55.404 HD Request # 152 | Decompressing data. | 2022-01-13 17:03:55.701 HD Request # 152 | Receiving Intraday data for RBG22 starting at 2022-01-13 17:01:10.121000 | 2022-01-13 17:03:55.702 Socket (6) | CloseSocket call. | 2022-01-13 17:03:55.702 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:03:55.703 Historical data download thread signaled to stop. | 2022-01-13 17:03:55.703 HD Request # 152 | Timestamp of first Intraday data file record written: 2022-01-13 17:01:17.174000 | 2022-01-13 17:03:55.703 HD Request # 152 | Received 82 Intraday data records from 2022-01-13 17:01:10.121000 to 2022-01-13 17:03:36.958000 (2.4 minutes) and wrote 73 records for RBG22 | 2022-01-13 17:03:55.703 HD Request # 152 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:03:36.958000 | 2022-01-13 17:03:55.712 HD Request # 152 | Completion time: 1s | 2022-01-13 17:03:55.712 HD Request # 152 | Intraday data download complete for RBG22. Unique request ID: 219 | 2022-01-13 17:03:55.712 Removing historical data download ID 219. | 2022-01-13 17:03:55.712 Real-time Intraday chart data file updates started for RBG22 | 2022-01-13 17:03:55.712 Intraday chart data file opened for RBG22 | 2022-01-13 17:03:55.712 HD Request # 152 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:03:55.712 Triggering next historical data download in queue. | 2022-01-13 17:03:55.712 HD Request # 153 | Downloading Intraday chart data for TNH22 to the file TNH22.scid. Service: cbot | 2022-01-13 17:03:55.712 HD Request # 153 | Download start date-time: 2022-01-13 17:00:50.000000. File last date-time: 2022-01-13 17:00:50.140002 | 2022-01-13 17:03:55.712 HD Request # 153 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 17:03:55.712 Socket (4) | Creating socket. | 2022-01-13 17:03:55.712 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:03:55.712 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:03:55.712 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 17:03:56.000 Socket (6) | Closed. | 2022-01-13 17:03:56.000 Opened cached Intraday file: C:\SierraChart\Data\NQH22.scid. Thread ID: 11608 | 2022-01-13 17:03:56.615 Opened cached Intraday file: C:\SierraChart\Data\RBG22.scid. Thread ID: 11608 | 2022-01-13 17:04:01.659 HD Request # 153 | Setting DTC encoding to Binary VLS | 2022-01-13 17:04:02.350 HD Request # 153 | Sending historical data logon request message. | 2022-01-13 17:04:02.350 HD Request # 153 | Requesting Intraday data. Start date-time: 2022-01-13 17:00:50. Record interval: 0. Symbol: TNH22 | 2022-01-13 17:04:02.651 HD Request # 153 | Decompressing data. | 2022-01-13 17:04:02.953 HD Request # 153 | Receiving Intraday data for TNH22 starting at 2022-01-13 17:00:50.140000 | 2022-01-13 17:04:02.954 Socket (4) | CloseSocket call. | 2022-01-13 17:04:02.954 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:04:02.954 Historical data download thread signaled to stop. | 2022-01-13 17:04:02.989 HD Request # 153 | Timestamp of first Intraday data file record written: 2022-01-13 17:01:32.588000 | 2022-01-13 17:04:02.990 HD Request # 153 | Received 55 Intraday data records from 2022-01-13 17:00:50.140000 to 2022-01-13 17:03:46.311002 (2.9 minutes) and wrote 52 records for TNH22 | 2022-01-13 17:04:02.990 HD Request # 153 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:03:46.311002 | 2022-01-13 17:04:02.997 HD Request # 153 | Completion time: 7s | 2022-01-13 17:04:02.997 HD Request # 153 | Intraday data download complete for TNH22. Unique request ID: 220 | 2022-01-13 17:04:02.997 Removing historical data download ID 220. | 2022-01-13 17:04:02.997 Real-time Intraday chart data file updates started for TNH22 | 2022-01-13 17:04:02.997 Intraday chart data file opened for TNH22 | 2022-01-13 17:04:02.997 HD Request # 153 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:04:02.997 Triggering next historical data download in queue. | 2022-01-13 17:04:02.997 HD Request # 154 | Downloading Intraday chart data for YMH22 to the file YMH22.scid. Service: cbot | 2022-01-13 17:04:02.997 HD Request # 154 | Download start date-time: 2022-01-13 17:01:36.000000. File last date-time: 2022-01-13 17:01:36.610000 | 2022-01-13 17:04:02.997 HD Request # 154 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 17:04:03.000 Socket (6) | Creating socket. | 2022-01-13 17:04:03.000 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 17:04:03.000 Socket (6) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:04:03.000 HD Request # 154 | Setting DTC encoding to Binary VLS | 2022-01-13 17:04:03.599 HD Request # 154 | Sending historical data logon request message. | 2022-01-13 17:04:03.599 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:04:03.988 Socket (4) | Closed. | 2022-01-13 17:04:03.988 DTC Client socket (9) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-13 17:04:05.571 * DTC Client socket (9) | Socket gracefully closed by remote side. | 2022-01-13 17:04:05.571 DTC Client socket (9) | Closed. | 2022-01-13 17:04:05.571 HD Request # 154 | Requesting Intraday data. Start date-time: 2022-01-13 17:01:36. Record interval: 0. Symbol: YMH22 | 2022-01-13 17:04:06.562 HD Request # 154 | Decompressing data. | 2022-01-13 17:04:06.860 HD Request # 154 | Receiving Intraday data for YMH22 starting at 2022-01-13 17:01:36.303000 | 2022-01-13 17:04:07.459 Socket (6) | CloseSocket call. | 2022-01-13 17:04:07.459 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:04:07.460 Historical data download thread signaled to stop. | 2022-01-13 17:04:07.493 HD Request # 154 | Timestamp of first Intraday data file record written: 2022-01-13 17:01:36.786000 | 2022-01-13 17:04:07.493 HD Request # 154 | Received 712 Intraday data records from 2022-01-13 17:01:36.303000 to 2022-01-13 17:04:05.110000 (2.5 minutes) and wrote 705 records for YMH22 | 2022-01-13 17:04:07.494 HD Request # 154 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:04:05.110000 | 2022-01-13 17:04:07.502 Added 3 Time and Sales records to Intraday data file for YMH22 after download. | 2022-01-13 17:04:07.502 HD Request # 154 | Completion time: 5s | 2022-01-13 17:04:07.502 HD Request # 154 | Intraday data download complete for YMH22. Unique request ID: 221 | 2022-01-13 17:04:07.502 Removing historical data download ID 221. | 2022-01-13 17:04:07.502 Real-time Intraday chart data file updates started for YMH22 | 2022-01-13 17:04:07.502 Intraday chart data file opened for YMH22 | 2022-01-13 17:04:07.502 HD Request # 154 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:04:07.502 Triggering next historical data download in queue. | 2022-01-13 17:04:07.502 HD Request # 155 | Downloading Intraday chart data for ZBH22 to the file ZBH22.scid. Service: cbot | 2022-01-13 17:04:07.502 HD Request # 155 | Download start date-time: 2022-01-13 17:01:23.000000. File last date-time: 2022-01-13 17:01:23.905000 | 2022-01-13 17:04:07.503 HD Request # 155 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 17:04:07.503 Socket (4) | Creating socket. | 2022-01-13 17:04:07.503 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:04:07.503 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:04:07.503 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 17:04:07.755 Socket (6) | Closed. | 2022-01-13 17:04:07.755 HD Request # 155 | Setting DTC encoding to Binary VLS | 2022-01-13 17:04:11.120 HD Request # 155 | Sending historical data logon request message. | 2022-01-13 17:04:11.120 Opened cached Intraday file: C:\SierraChart\Data\YMH22.scid. Thread ID: 11608 | 2022-01-13 17:04:11.736 HD Request # 155 | Requesting Intraday data. Start date-time: 2022-01-13 17:01:23. Record interval: 0. Symbol: ZBH22 | 2022-01-13 17:04:12.347 HD Request # 155 | Decompressing data. | 2022-01-13 17:04:15.321 HD Request # 155 | Receiving Intraday data for ZBH22 starting at 2022-01-13 17:01:23.904000 | 2022-01-13 17:04:15.321 Socket (4) | CloseSocket call. | 2022-01-13 17:04:15.322 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:04:15.322 Historical data download thread signaled to stop. | 2022-01-13 17:04:15.339 HD Request # 155 | Timestamp of first Intraday data file record written: 2022-01-13 17:01:37.700000 | 2022-01-13 17:04:15.339 HD Request # 155 | Received 151 Intraday data records from 2022-01-13 17:01:23.904000 to 2022-01-13 17:04:01.826000 (2.6 minutes) and wrote 149 records for ZBH22 | 2022-01-13 17:04:15.339 HD Request # 155 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:04:01.826000 | 2022-01-13 17:04:15.348 Added 1 Time and Sales records to Intraday data file for ZBH22 after download. | 2022-01-13 17:04:15.348 HD Request # 155 | Completion time: 8s | 2022-01-13 17:04:15.348 HD Request # 155 | Intraday data download complete for ZBH22. Unique request ID: 222 | 2022-01-13 17:04:15.348 Removing historical data download ID 222. | 2022-01-13 17:04:15.348 Real-time Intraday chart data file updates started for ZBH22 | 2022-01-13 17:04:15.348 Intraday chart data file opened for ZBH22 | 2022-01-13 17:04:15.348 HD Request # 155 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:04:15.348 Triggering next historical data download in queue. | 2022-01-13 17:04:15.348 HD Request # 156 | Downloading Intraday chart data for ZFH22 to the file ZFH22.scid. Service: cbot | 2022-01-13 17:04:15.348 HD Request # 156 | Download start date-time: 2022-01-13 17:01:38.000000. File last date-time: 2022-01-13 17:01:38.296000 | 2022-01-13 17:04:15.349 HD Request # 156 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 17:04:15.349 Socket (6) | Creating socket. | 2022-01-13 17:04:15.349 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 17:04:15.349 Socket (6) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:04:15.349 Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:04:16.514 Socket (4) | Closed. | 2022-01-13 17:04:16.515 HD Request # 156 | Setting DTC encoding to Binary VLS | 2022-01-13 17:04:18.631 HD Request # 156 | Sending historical data logon request message. | 2022-01-13 17:04:18.631 HD Request # 156 | Requesting Intraday data. Start date-time: 2022-01-13 17:01:38. Record interval: 0. Symbol: ZFH22 | 2022-01-13 17:04:18.948 HD Request # 156 | Decompressing data. | 2022-01-13 17:04:20.083 HD Request # 156 | Receiving Intraday data for ZFH22 starting at 2022-01-13 17:01:38.296000 | 2022-01-13 17:04:20.083 Socket (6) | CloseSocket call. | 2022-01-13 17:04:20.448 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:04:20.448 Historical data download thread signaled to stop. | 2022-01-13 17:04:20.451 HD Request # 156 | Timestamp of first Intraday data file record written: 2022-01-13 17:01:53.880000 | 2022-01-13 17:04:20.451 HD Request # 156 | Received 269 Intraday data records from 2022-01-13 17:01:38.296000 to 2022-01-13 17:04:15.008001 (2.6 minutes) and wrote 268 records for ZFH22 | 2022-01-13 17:04:20.451 HD Request # 156 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:04:15.008001 | 2022-01-13 17:04:20.459 HD Request # 156 | Completion time: 5s | 2022-01-13 17:04:20.459 HD Request # 156 | Intraday data download complete for ZFH22. Unique request ID: 223 | 2022-01-13 17:04:20.459 Removing historical data download ID 223. | 2022-01-13 17:04:20.459 Real-time Intraday chart data file updates started for ZFH22 | 2022-01-13 17:04:20.459 Intraday chart data file opened for ZFH22 | 2022-01-13 17:04:20.459 HD Request # 156 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:04:20.459 Triggering next historical data download in queue. | 2022-01-13 17:04:20.459 HD Request # 157 | Downloading Intraday chart data for ZNH22 to the file ZNH22.scid. Service: cbot | 2022-01-13 17:04:20.460 HD Request # 157 | Download start date-time: 2022-01-13 17:01:11.000000. File last date-time: 2022-01-13 17:01:11.013000 | 2022-01-13 17:04:20.460 HD Request # 157 | Using server: ds23.sierracharts.com port 10150 | 2022-01-13 17:04:20.460 Socket (4) | Creating socket. | 2022-01-13 17:04:20.460 Socket (4) | New receive buffer size: 5242880 | 2022-01-13 17:04:20.460 Socket (4) | Connecting to IP: 216.1.90.130. | 2022-01-13 17:04:20.460 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 17:04:20.748 Socket (6) | Closed. | 2022-01-13 17:04:20.748 Opened cached Intraday file: C:\SierraChart\Data\TNH22.scid. Thread ID: 11608 | 2022-01-13 17:04:21.804 HD Request # 157 | Setting DTC encoding to Binary VLS | 2022-01-13 17:04:23.880 HD Request # 157 | Sending historical data logon request message. | 2022-01-13 17:04:23.880 Opened cached Intraday file: C:\SierraChart\Data\ZFH22.scid. Thread ID: 11608 | 2022-01-13 17:04:31.919 Opened cached Intraday file: C:\SierraChart\Data\ZBH22.scid. Thread ID: 11608 | 2022-01-13 17:04:36.939 HD Request # 157 | Error downloading historical Intraday data for ZNH22. The download timed out. | 2022-01-13 17:05:53.408 Added historical Intraday data request for ZNH22 to the queue. | 2022-01-13 17:05:53.408 Triggering next historical data download in queue. | 2022-01-13 17:05:53.408 Historical data download thread signaled to stop. | 2022-01-13 17:05:53.408 Socket (4) | CloseSocket call. | 2022-01-13 17:05:53.408 HD Request # 157 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ZNH22 | 2022-01-13 17:05:53.408 HD Request # 157 | Completion time: 1m 33s | 2022-01-13 17:05:53.408 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:05:53.408 HD Request # 158 | Downloading Intraday chart data for ZNH22 to the file ZNH22.scid. Service: cbot | 2022-01-13 17:05:53.408 HD Request # 158 | Download start date-time: 2022-01-13 17:01:11.000000. File last date-time: 2022-01-13 17:01:11.013000 | 2022-01-13 17:05:53.409 HD Request # 158 | Using server: ds21.sierracharts.com port 10149 | 2022-01-13 17:05:53.409 Socket (6) | Creating socket. | 2022-01-13 17:05:53.409 Socket (6) | New receive buffer size: 5242880 | 2022-01-13 17:05:53.409 Socket (6) | Connecting to IP: 216.1.90.129. | 2022-01-13 17:05:53.409 HD Request # 158 | Setting DTC encoding to Binary VLS | 2022-01-13 17:05:57.021 HD Request # 158 | Sending historical data logon request message. | 2022-01-13 17:05:57.021 HD Request # 158 | Requesting Intraday data. Start date-time: 2022-01-13 17:01:11. Record interval: 0. Symbol: ZNH22 | 2022-01-13 17:05:57.787 HD Request # 158 | Decompressing data. | 2022-01-13 17:05:58.084 HD Request # 158 | Receiving Intraday data for ZNH22 starting at 2022-01-13 17:01:11.013000 | 2022-01-13 17:05:58.086 Socket (6) | CloseSocket call. | 2022-01-13 17:05:58.088 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-01-13 17:05:58.088 Historical data download thread signaled to stop. | 2022-01-13 17:05:58.110 HD Request # 158 | Timestamp of first Intraday data file record written: 2022-01-13 17:01:45.932000 | 2022-01-13 17:05:58.110 HD Request # 158 | Received 614 Intraday data records from 2022-01-13 17:01:11.013000 to 2022-01-13 17:05:49.059000 (4.6 minutes) and wrote 613 records for ZNH22 | 2022-01-13 17:05:58.111 HD Request # 158 | Add time&sales data | Remembered last file record date-time: 2022-01-13 17:05:49.059000 | 2022-01-13 17:05:58.115 HD Request # 158 | Completion time: 5s | 2022-01-13 17:05:58.115 HD Request # 158 | Intraday data download complete for ZNH22. Unique request ID: 224 | 2022-01-13 17:05:58.115 Removing historical data download ID 224. | 2022-01-13 17:05:58.115 Real-time Intraday chart data file updates started for ZNH22 | 2022-01-13 17:05:58.115 Intraday chart data file opened for ZNH22 | 2022-01-13 17:05:58.115 HD Request # 158 | Enabling Intraday chart updating for symbol. | 2022-01-13 17:05:58.115 Triggering next historical data download in queue. | 2022-01-13 17:05:58.115 No download requests in the queue to start downloads for. | 2022-01-13 17:05:58.115 Socket (6) | Socket gracefully closed by remote side. | 2022-01-13 17:05:58.386 Socket (6) | Closed. | 2022-01-13 17:05:58.386 Opened cached Intraday file: C:\SierraChart\Data\ZNH22.scid. Thread ID: 11608 | 2022-01-13 17:06:07.664 Socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-01-13 17:07:53.726 * Socket (4) | Socket gracefully closed by remote side. | 2022-01-13 17:07:53.726 Socket (4) | Closed. | 2022-01-13 17:07:53.726 |
| [2022-01-13 18:46:57] |
| John - SC Support - Posts: 48028 |
We do see about a total of 10 of these errors: DTC Client socket (6) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. These are stating that you are having network connectivity issues. Refer to the information here: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem -- We also see a few attempts to get data for EUREX symbols, but you are not setup to get EUREX through us or from CQG, so you may not get any data for these, or at best it would be delayed. If you want to get real-time EUREX data, then we recommend using our Denali EUREX data. You will find the Setup Instructions for this here: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_EUREX For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
