Date/Time: Tue, 04 Mar 2025 21:31:38 +0000
Lockup while in Configure Control Bar 1 >> Set Custom Tool
View Count: 586
[2022-01-04 21:51:45]
User180397 - Posts: 16
I have successfully configured a number of buttons in Customize Control Bar 1. Recently, attempting to add and configure another button, I was able to add a Custom Drawing Tool and then set its "Properties" without difficulty. I am also able to use the "Move Up" and "Move Down" buttons, and the "Add Separator" and "Add Blank" buttons. I can also "Remove" Control Bar commands. There are about 3 inches of blank space to the right of the last button on the Control Bar, suggesting I might be able to add at least another button in Control Bar 1. However, as I click on "Set Custom Tool" the entire SC program locks up. If I attempt to click on anything on the main screen I get an audible soft chime or "bling" sound - as if I need to first select something to proceed, but there are no options offered, and that was not the functionality I remembered during prior configurations. At that point, my only option is to close the program through Task Master. After restarting SC, I then selected an existing functioning button and clicked on the "Set Custom Tool" button and the program immediately locked up again. I've repeated this sequence a number of times.
I recently changed some of the existing button tool configurations, under Global Settings>>Tool Config. That shouldn't disallow opening "Set Custom Tools" but..........? Any suggestions or thoughts?
[2022-01-04 22:22:21]
John - SC Support - Posts: 38369
Usually when you have this specific issue, in particular the "ding" when you try to select something else, it implies that the window is opening for the input you are trying to do, but it is opening off the screen so you can not see it, or access it.
To fix this, select Window >> Reset Windows. Then try again and see if you get the proper window showing up. For information on the Reset Windows command, refer to the following:
Window, CB and CW Menus: Reset Windows (Window)
[2022-01-05 02:02:29]
We need you to update Sierra Chart to the latest version. The issue is what is described here:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.40 - Dialog Windows Do Not Display
Update instructions:
We have updated that interface to be a completely new one that does not use a Microsoft dialog.
Tell us if updating resolve the problem. And also select Window >> Reset Windows after updating to be sure it is not offscreen.
Date Time Of Last Edit: 2022-01-05 02:05:59
[2022-01-05 02:06:03]
Prior post has been updated.
