Date/Time: Sat, 19 Apr 2025 09:45:12 +0000
[Locked] - Connect to Gain Capital
View Count: 1046
[2021-10-28 20:32:50]
User312718 - Posts: 26
I am unable to connect to Gain Capital
[2021-10-29 00:19:56]
John - SC Support - Posts: 39362
We do not give any support for Gain Capital connectivity.
[2021-10-29 02:40:13]
Is sierra capable of using Gains data feed?
[2021-10-29 07:45:32]
It is considered a legacy service. However, it is currently supported.
And also we really cannot help with connectivity problems to that service. It is just not within our control. This is the main issue. Especially being we cannot even tell what the reason for the connection failure is. Since there is no descriptive message usually given.
This is the service we instead recommend using:
Date Time Of Last Edit: 2021-10-29 07:47:02
[2021-10-29 19:09:40]
I am currently subsribed to Denali Data feed. How do I proceed to receive real time data?
[2021-10-29 20:24:01]
You really have to get a connection to the trading service so we will try to help you with a connection to gain capital since that is where your account is.
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2021-10-29 20:24:13
[2021-10-29 22:12:49]
Software version: 2323 64-bit | 2021-10-29 19:00:09.844
Primary Thread ID: 23648 | 2021-10-29 19:00:09.844
Usage end date: 2021-12-02 | 2021-10-29 19:00:09.844
Enabled for: Sierra Chart Historical Data Service. | 2021-10-29 19:00:09.844
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-10-29 19:00:09.844
Enabled for: Delayed Denali Exchange Data Feed. | 2021-10-29 19:00:09.844
Enabled for exchange2: CME | 2021-10-29 19:00:09.844
Enabled for exchange2: fairx_exchange.data | 2021-10-29 19:00:09.844
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-10-29 19:00:09.844
Current selected Data/Trading service: GAIN Capital/OEC | 2021-10-29 19:00:09.844
Custom symbol settings values: enabled | 2021-10-29 19:00:09.844
Chart Update Interval: 500 | 2021-10-29 19:00:09.844
Intraday Data Storage Time Unit: 1 | 2021-10-29 19:00:09.844
Time Zone: +00:00:00 (UTC+00) | 2021-10-29 19:00:09.844
2021-10-29 19:00:09 Local computer time in UTC | 2021-10-29 19:00:09.844
2021-10-29 19:00:09 Local computer time in SC Time Zone | 2021-10-29 19:00:09.844
2021-10-28 23:07:30 Server time in UTC | 2021-10-29 19:00:09.844
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-10-29 19:00:09.844
Program path: C:\SierraChart\Data\ | 2021-10-29 19:00:09.844
Data Files path: C:\SierraChart\Data\Data\ | 2021-10-29 19:00:09.844
OS Version Number: 10.0 | 2021-10-29 19:00:09.844
Locale Setting: C | 2021-10-29 19:00:09.844
DLLs: SierraChartStudies_64.dll, UserContributedStudies_64.dll | 2021-10-29 19:00:09.844
Allowed protected custom studies: | 2021-10-29 19:00:09.845
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:12.238
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:12.238
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:12.238
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:12.238
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:12.281
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:12.485
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:1256=MBastiani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| 2021-10-29 19:00:12.708
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:12.708
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:12.708
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:12.709
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:12.709
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:12.709
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:1256=MBastiani351258=SoftwareNotPermitted10=001 | 2021-10-29 19:00:12.718
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:12.718
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:12.718
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:12.71858=Received Logout message.10=152 | 2021-10-29 19:00:12.718
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:12.718
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:12.718
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:12.718
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:12.718
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:12.719
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:12.738
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:12.738
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:12.738
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:12.738
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:12.738
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:12.738
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:12.757
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:12.757
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:12.757
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:12.757
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:15.734
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:15.735
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:15.735
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:15.735
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:15.776
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:15.974
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:1556=MBastiani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| 2021-10-29 19:00:16.196
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:16.196
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:16.196
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:16.196
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:16.196
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:16.196
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:1556=MBastiani351258=SoftwareNotPermitted10=004 | 2021-10-29 19:00:16.214
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:16.214
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:16.214
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:16.21558=Received Logout message.10=148 | 2021-10-29 19:00:16.214
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:16.214
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:16.214
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:16.214
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:16.214
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:16.215
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:16.220
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:16.220
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:16.220
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:16.220
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:16.220
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:16.220
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:16.252
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:16.252
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:16.252
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:16.252
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:19.214
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:19.215
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:19.215
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:19.215
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:19.260
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:19.456
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:1956=MBastiani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| 2021-10-29 19:00:19.699
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:19.699
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:19.699
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:19.699
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:19.699
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:19.699
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:1956=MBastiani351258=SoftwareNotPermitted10=008 | 2021-10-29 19:00:19.739
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:19.739
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:19.739
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:19.73958=Received Logout message.10=162 | 2021-10-29 19:00:19.739
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:19.739
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:19.739
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:19.739
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:19.739
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:19.741
GAIN Capital FAST Data: Sent the Hello message. | 2021-10-29 19:00:19.742
GAIN Capital FAST Data: Sent a Logout message. | 2021-10-29 19:00:19.752
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:19.753
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:19.753
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:19.780
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:19.780
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:19.780
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:19.781
GAIN Capital FAST Data: Sent the Logon message. | 2021-10-29 19:00:19.781
GAIN Capital FAST Data socket (3) | Socket gracefully closed by remote side. | 2021-10-29 19:00:19.799
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:19.799
GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2021-10-29 19:00:19.799
GAIN Capital FAST Data socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:19.799
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:19.799
GAIN Capital FAST Data socket (3) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:19.814
GAIN Capital FAST Data socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:19.814
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:19.815
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:22.750
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:22.751
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:22.751
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:22.751
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:22.793
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:22.996
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:2256=MBastiani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| 2021-10-29 19:00:23.227
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:23.227
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:23.227
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:23.227
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:23.227
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:23.227
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:2256=MBastiani351258=SoftwareNotPermitted10=002 | 2021-10-29 19:00:23.243
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:23.243
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:23.243
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:23.24458=Received Logout message.10=148 | 2021-10-29 19:00:23.243
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:23.243
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:23.243
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:23.243
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:23.243
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:23.245
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:23.255
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:23.255
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:23.255
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:23.255
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:23.256
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:23.256
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:23.282
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:23.282
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:23.282
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:23.282
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:26.253
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:26.253
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:26.253
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:26.253
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:26.301
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:26.496
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:2656=MBastiani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| 2021-10-29 19:00:26.727
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:26.727
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:26.727
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:26.727
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:26.727
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:26.727
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:2656=MBastiani351258=SoftwareNotPermitted10=006 | 2021-10-29 19:00:26.737
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:26.737
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:26.737
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:26.73858=Received Logout message.10=159 | 2021-10-29 19:00:26.737
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:26.737
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:26.737
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:26.737
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:26.737
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:26.738
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:26.756
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:26.756
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:26.756
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:26.756
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:26.756
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:26.756
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:26.779
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:26.779
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:26.779
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:26.779
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:29.752
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:29.809
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:29.810
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:29.810
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:29.849
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:30.044
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:2956=MBastiani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| 2021-10-29 19:00:30.261
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:30.261
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:30.261
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:30.261
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:30.262
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:30.262
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:2956=MBastiani351258=SoftwareNotPermitted10=009 | 2021-10-29 19:00:30.271
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:30.271
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:30.271
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:30.27258=Received Logout message.10=147 | 2021-10-29 19:00:30.271
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:30.272
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:30.272
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:30.272
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:30.272
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:30.273
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:30.277
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:30.277
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:30.277
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:30.277
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:30.277
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:30.277
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:30.309
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:30.309
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:30.309
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:30.309
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:33.278
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:33.279
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:33.279
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:33.279
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:33.322
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:33.518
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:3356=MBastiani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| 2021-10-29 19:00:33.745
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:33.745
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:33.745
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:33.746
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:33.746
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:33.746
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:3356=MBastiani351258=SoftwareNotPermitted10=004 | 2021-10-29 19:00:33.758
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:33.758
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:33.758
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:33.75958=Received Logout message.10=160 | 2021-10-29 19:00:33.758
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:33.758
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:33.758
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:33.758
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:33.758
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:33.759
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:33.763
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:33.763
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:33.763
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:33.763
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:33.764
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:33.764
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:33.795
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:33.795
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:33.795
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:33.795
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:36.762
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:36.762
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:36.762
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:36.762
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:36.806
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:37.003
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:3656=MBastiani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| 2021-10-29 19:00:37.235
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:37.235
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:37.235
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:37.235
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:37.235
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:37.235
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:3656=MBastiani351258=SoftwareNotPermitted10=007 | 2021-10-29 19:00:37.245
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:37.245
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:37.245
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:37.24658=Received Logout message.10=155 | 2021-10-29 19:00:37.245
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:37.245
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:37.246
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:37.246
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:37.246
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:37.247
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:37.263
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:37.263
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:37.263
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:37.264
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:37.264
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:37.264
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:37.285
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:37.285
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:37.285
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:37.285
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:40.267
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:40.267
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:40.267
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:40.267
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:40.308
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:40.501
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:4056=MBastiani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| 2021-10-29 19:00:40.752
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:40.753
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:40.753
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:40.753
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:40.753
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:40.753
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:4056=MBastiani351258=SoftwareNotPermitted10=002 | 2021-10-29 19:00:40.767
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:40.767
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:40.767
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:40.76758=Received Logout message.10=157 | 2021-10-29 19:00:40.767
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:40.767
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:40.767
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:40.767
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:40.767
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:40.769
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:40.778
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:40.778
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:40.778
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:40.779
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:40.779
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:40.779
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:40.805
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:40.805
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:40.805
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:40.805
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:43.782
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:43.782
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:43.782
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:43.782
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:43.825
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:44.029
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:4356=MBastiani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| 2021-10-29 19:00:44.259
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:44.259
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:44.259
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:44.259
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:44.259
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:44.259
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:4356=MBastiani351258=SoftwareNotPermitted10=005 | 2021-10-29 19:00:44.272
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:44.272
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:44.272
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:44.27358=Received Logout message.10=153 | 2021-10-29 19:00:44.272
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:44.272
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:44.272
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:44.272
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:44.272
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:44.273
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:44.284
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:44.284
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:44.284
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:44.285
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:44.285
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:44.285
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:44.316
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:44.316
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:44.316
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:44.316
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:47.285
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:47.285
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:47.285
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:47.285
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:47.329
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:47.528
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:4756=MBastiani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| 2021-10-29 19:00:47.752
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:47.752
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:47.752
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:47.752
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:47.752
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:47.752
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:4756=MBastiani351258=SoftwareNotPermitted10=009 | 2021-10-29 19:00:47.764
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:47.764
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:47.764
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:47.76458=Received Logout message.10=161 | 2021-10-29 19:00:47.764
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:47.764
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:47.764
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:47.764
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:47.764
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:47.765
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:47.786
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:47.786
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:47.786
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:47.786
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:47.786
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:47.787
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:47.804
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:47.804
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:47.804
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:47.804
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:50.785
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:50.785
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:50.785
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:50.785
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:50.825
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:51.036
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:5056=MBastiani351298=0108=3012004=1FD4201027E796F679995B06B66BCA65938E0DC68A847FD29251B0C1C7BA900016D980CC42CEBD1FA8BB76A1AE5E25092CFE7A5A16E9E8D45BE5DBF039D60DFC4267F9386BEF8221D667AA4BA1432088C6AE67D3FA424CC673D5CD1538B081F7FA135A26104AD0F9CD3B598ADF84E69A73207160632C3AD484FDF12D19368E7A39CB8356C8CFA922BF91828447DA65572787F8277097E7FC7E31048A91B1E59BADA7B29E0082FAEFC640EE67F2F3D6C6BEF814E097023C698089974EBE1AF6902C32C3836703F10009AE8DB99DEFAAE41499BCAB119669ACD9C0E0B3A1F25C1F972297090E2C5477F60B8B6E6EC21227599243934F491573096D561CE1B11AAF10=175 | 2021-10-29 19:00:51.273
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:51.273
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:51.273
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:51.273
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:51.273
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:51.273
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:5056=MBastiani351258=SoftwareNotPermitted10=003 | 2021-10-29 19:00:51.288
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:51.288
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:51.288
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:51.28858=Received Logout message.10=157 | 2021-10-29 19:00:51.288
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:51.289
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:51.289
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:51.289
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:51.289
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:51.327
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:51.327
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:51.327
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:51.327
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:51.353
GAIN Capital FAST Data: Sent the Hello message. | 2021-10-29 19:00:51.353
GAIN Capital FAST Data: Sent a Logout message. | 2021-10-29 19:00:51.362
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:51.362
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:51.362
GAIN Capital FAST Data: Sent the Logon message. | 2021-10-29 19:00:51.390
GAIN Capital FAST Data socket (3) | Socket gracefully closed by remote side. | 2021-10-29 19:00:51.401
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:51.401
GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2021-10-29 19:00:51.401
GAIN Capital FAST Data socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:51.401
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:51.401
GAIN Capital FAST Data socket (3) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:51.433
GAIN Capital FAST Data socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:51.433
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:51.433
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:54.356
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:54.357
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:54.357
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:54.357
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:54.395
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:54.592
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:5456=MBastiani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| 2021-10-29 19:00:54.813
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:54.813
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:54.813
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:54.813
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:54.813
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:54.813
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:5456=MBastiani351258=SoftwareNotPermitted10=007 | 2021-10-29 19:00:54.822
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:54.822
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:54.822
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:54.82258=Received Logout message.10=154 | 2021-10-29 19:00:54.822
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:54.822
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:54.822
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:54.822
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:54.822
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:54.824
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:54.839
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:54.839
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:54.839
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:54.839
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:54.840
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:54.841
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:54.862
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:54.862
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:54.862
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:54.862
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:00:57.840
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:00:57.840
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:00:57.840
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:57.840
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:00:57.878
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:00:58.076
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:00:5756=MBastiani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| 2021-10-29 19:00:58.289
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:00:58.289
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:00:58.289
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:00:58.289
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:00:58.289
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:00:58.289
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:00:5756=MBastiani351258=SoftwareNotPermitted10=010 | 2021-10-29 19:00:58.299
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:00:58.299
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:00:58.299
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:00:58.29958=Received Logout message.10=166 | 2021-10-29 19:00:58.299
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:00:58.299
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:00:58.299
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:58.299
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:00:58.299
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:00:58.300
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:00:58.309
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:00:58.309
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:00:58.309
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:00:58.309
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:00:58.309
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:00:58.309
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:00:58.336
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:00:58.336
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:00:58.336
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:00:58.336
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:01.322
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:01.375
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:01.375
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:01.375
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:01.414
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:01.605
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:0156=MBastiani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| 2021-10-29 19:01:01.829
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:01.829
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:01.829
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:01.829
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:01.829
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:01.829
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:0156=MBastiani351258=SoftwareNotPermitted10=000 | 2021-10-29 19:01:01.839
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:01.839
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:01.839
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:01.83958=Received Logout message.10=155 | 2021-10-29 19:01:01.839
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:01.839
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:01.839
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:01.839
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:01.839
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:01.839
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:01.840
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:01.840
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:01.840
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:01.840
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:01.841
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:01.841
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:01.875
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:01.875
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:01.875
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:01.875
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:04.839
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:04.840
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:04.840
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:04.840
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:04.892
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:05.089
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:0456=MBastiani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| 2021-10-29 19:01:05.305
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:05.305
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:05.305
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:05.306
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:05.306
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:05.306
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:0456=MBastiani351258=SoftwareNotPermitted10=003 | 2021-10-29 19:01:05.316
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:05.316
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:05.316
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:05.31658=Received Logout message.10=149 | 2021-10-29 19:01:05.316
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:05.316
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:05.316
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:05.316
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:05.316
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:05.318
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:05.330
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:05.330
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:05.330
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:05.330
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:05.330
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:05.330
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:05.351
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:05.351
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:05.351
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:05.351
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:08.324
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:08.325
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:08.325
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:08.325
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:08.370
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:08.566
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:0856=MBastiani351298=0108=3012004=CF07CFD929A11C160D2695541C710EA94AA580AE29228A3DE4A3D41025ABD49DEDB43234E9A58DE0EDEA9C253F54D2E83CA98879F601B17057AD03BADBD3EDCC3EF149FF3007552AA8C1205C77D0720A7FC89D8C3E55593F96864AFEB7FC5697A3171EA76A8793899303A21CEA8F4CE76D38459062B5E83DCF089AFF2AA4CCD06F678E0C4078E2E8A89A0DEEDB84B29592A9C3FC2F211F8B835B77D522BF1492B1D93D518F4D873EB965AEC840F3F24E3C9F5662F8D4D2D9D813E119AFD25EDCA4E4BDC00AED26349EDB8611A3A97D2ED6AAB4B7ECEDB3E5894A46CFE8F3387415D83910EF05631646458670BCE49BF19CB3358B00B0F1E54DB8648B36006C9F10=186 | 2021-10-29 19:01:08.797
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:08.797
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:08.797
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:08.797
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:08.797
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:08.797
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:0856=MBastiani351258=SoftwareNotPermitted10=007 | 2021-10-29 19:01:08.807
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:08.807
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:08.807
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:08.80758=Received Logout message.10=157 | 2021-10-29 19:01:08.807
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:08.807
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:08.807
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:08.807
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:08.807
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:08.808
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:08.810
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:08.810
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:08.810
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:08.810
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:08.810
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:08.810
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:08.847
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:08.847
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:08.847
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:08.847
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:11.808
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:11.809
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:11.809
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:11.809
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:11.849
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:12.046
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:1156=MBastiani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| 2021-10-29 19:01:12.262
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:12.262
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:12.262
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:12.262
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:12.262
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:12.262
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:1156=MBastiani351258=SoftwareNotPermitted10=001 | 2021-10-29 19:01:12.271
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:12.271
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:12.271
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:12.27158=Received Logout message.10=147 | 2021-10-29 19:01:12.271
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:12.271
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:12.271
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:12.271
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:12.271
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:12.271
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:12.282
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:12.282
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:12.282
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:12.282
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:12.282
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:12.282
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:12.309
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:12.309
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:12.309
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:12.309
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:15.281
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:15.282
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:15.282
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:15.282
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:15.320
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:15.513
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:1556=MBastiani351298=0108=3012004=2D3B7B1B005CA5A84A95D02606FE0C35078211393AD3AA9DDD81028E909F794706410A9181406EBD34E5280BF329E908C22F9A31C0B2DED854BFB8500179C87B9E76F159E2FC389E58EF03CDB22CEA4BC2033CCDF5BC3DC8F3A68FCAEE978FA7FD5EBF6F2F01E40BD2027EEB97A5DB1CD943498B9BFEF89C1BD1B1D77DDF6D7C06E24843D7CEF43DC2F852C9F02A26001F06616CBB49A90A59CD776590A2C9EAA3BEEC3F5F8C7B647D20254B2E6D3D79CB52EEBCE45032381CFA38720144D2E3B049B6F48075DC71D4DDB727C8901AE6685DA6241398BEC510151D35712B7F18713447438235525A1C258323B91EDBB794A5B3CCB8BC5AC246B9DA839EFE9DD910=104 | 2021-10-29 19:01:15.727
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:15.727
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:15.727
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:15.728
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:15.728
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:15.728
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:1556=MBastiani351258=SoftwareNotPermitted10=005 | 2021-10-29 19:01:15.737
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:15.737
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:15.737
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:15.73758=Received Logout message.10=157 | 2021-10-29 19:01:15.737
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:15.737
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:15.737
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:15.737
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:15.737
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:15.737
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:15.745
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:15.745
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:15.745
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:15.745
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:15.745
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:15.746
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:15.779
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:15.779
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:15.779
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:15.779
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:18.747
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:18.748
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:18.748
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:18.748
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:18.792
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:18.981
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:1856=MBastiani351298=0108=3012004=385C9123137152311FB35D4494EF91DAE33C9F7DAE85822BC8D7CA6A5285295BD39B36E8A8C9B9C184130DCCCF73054779C30485958858C17C4AA2ED2A5444185299934D6D0F6DE513FEC748D5C3B364FF73977366ACE9F6C95D45B26CB33D2560135FB43990CFA8AF5BF2F699B4BA2FB0669C50C873078691B7F7919417F90C82165307714310C5997600EAFC0F30B2F4FB9E3EBCC3765BB286292FEFE995572E2D1E32B74D32B9142441860E40A7B47549DCAC76F14DD4C354D9FC0F3FCD7FA491322702B63C803054BEAC0DEA93B21F9A5F189FE64780ECC965281B6BB522A60B2AA5EDC3AF9AC3D38C53F5D1043734B504A5EAD8357F51D9E5E4A7DD0A8210=119 | 2021-10-29 19:01:19.254
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:19.254
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:19.254
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:19.254
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:19.254
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:19.254
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:1856=MBastiani351258=SoftwareNotPermitted10=008 | 2021-10-29 19:01:19.264
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:19.264
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:19.264
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:19.26558=Received Logout message.10=157 | 2021-10-29 19:01:19.264
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:19.264
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:19.264
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:19.264
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:19.264
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:19.265
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:19.282
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:19.282
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:19.282
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:19.282
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:19.282
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:19.282
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:19.299
GAIN Capital FIX Trading socket (2) | Shutdown started. Waiting for graceful close. | 2021-10-29 19:01:19.299
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:19.302
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:19.302
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:22.284
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:22.284
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:22.284
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:22.284
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:22.326
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:22.527
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:2256=MBastiani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| 2021-10-29 19:01:22.754
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:22.754
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:22.754
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:22.755
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:22.755
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:22.755
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:2256=MBastiani351258=SoftwareNotPermitted10=003 | 2021-10-29 19:01:22.765
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:22.765
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:22.765
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:22.76558=Received Logout message.10=156 | 2021-10-29 19:01:22.765
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:22.765
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:22.765
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:22.765
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:22.765
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:22.766
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:22.778
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:22.778
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:22.778
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:22.778
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:22.778
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:22.778
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:22.805
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:22.805
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:22.805
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:22.805
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:25.781
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:25.782
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:25.782
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:25.782
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:25.822
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:26.015
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:2556=MBastiani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| 2021-10-29 19:01:26.235
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:26.235
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:26.235
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:26.235
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:26.235
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:26.235
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:2556=MBastiani351258=SoftwareNotPermitted10=006 | 2021-10-29 19:01:26.251
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:26.251
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:26.251
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:26.25258=Received Logout message.10=151 | 2021-10-29 19:01:26.251
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:26.251
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:26.251
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:26.251
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:26.251
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:26.252
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:26.262
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:26.262
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:26.262
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:26.262
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:26.263
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:26.263
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:26.289
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:26.289
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:26.289
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:26.289
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:29.270
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:29.270
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:29.270
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:29.270
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:29.317
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:29.511
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:2956=MBastiani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| 2021-10-29 19:01:29.734
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:29.735
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:29.735
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:29.735
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:29.735
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:29.735
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:2956=MBastiani351258=SoftwareNotPermitted10=010 | 2021-10-29 19:01:29.743
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:29.743
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:29.743
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:29.74458=Received Logout message.10=160 | 2021-10-29 19:01:29.743
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:29.743
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:29.743
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:29.743
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:29.744
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:29.745
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:29.757
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:29.757
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:29.757
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:29.757
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:29.758
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:29.758
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:29.783
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:29.783
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:29.783
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:29.783
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:32.746
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:32.800
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:32.800
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:32.800
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:32.842
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:33.044
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:3256=MBastiani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| 2021-10-29 19:01:33.272
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:33.272
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:33.272
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:33.273
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:33.273
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:33.273
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:3256=MBastiani351258=SoftwareNotPermitted10=004 | 2021-10-29 19:01:33.284
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:33.284
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:33.284
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:33.28558=Received Logout message.10=155 | 2021-10-29 19:01:33.284
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:33.284
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:33.284
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:33.284
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:33.284
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:33.285
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:33.297
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:33.297
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:33.297
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:33.297
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:33.297
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:33.297
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:33.326
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:33.326
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:33.326
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:33.326
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:36.301
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:36.302
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:36.302
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:36.302
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:36.345
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:36.550
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:3656=MBastiani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| 2021-10-29 19:01:36.777
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:36.777
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:36.777
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:36.777
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:36.777
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:36.777
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:3656=MBastiani351258=SoftwareNotPermitted10=008 | 2021-10-29 19:01:36.788
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:36.788
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:36.788
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:36.78858=Received Logout message.10=166 | 2021-10-29 19:01:36.788
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:36.788
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:36.788
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:36.788
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:36.788
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:36.790
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:36.802
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:36.802
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:36.802
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:36.802
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:36.802
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:36.802
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:36.833
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:36.833
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:36.833
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:36.833
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:39.801
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:39.801
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:39.801
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:39.801
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:39.853
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:40.047
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:3956=MBastiani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| 2021-10-29 19:01:40.274
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:40.274
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:40.274
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:40.275
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:40.275
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:40.275
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:3956=MBastiani351258=SoftwareNotPermitted10=011 | 2021-10-29 19:01:40.283
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:40.283
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:40.283
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:40.28358=Received Logout message.10=151 | 2021-10-29 19:01:40.283
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:40.283
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:40.283
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:40.283
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:40.283
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:40.284
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:40.304
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:40.304
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:40.304
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:40.304
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:40.304
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:40.304
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:40.320
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:40.320
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:40.320
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:40.320
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:43.299
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:43.299
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:43.299
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:43.299
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:43.340
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:43.543
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:4356=MBastiani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| 2021-10-29 19:01:43.763
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:43.763
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:43.763
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:43.764
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:43.764
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:43.764
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:4356=MBastiani351258=SoftwareNotPermitted10=006 | 2021-10-29 19:01:43.774
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:43.774
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:43.774
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:43.77558=Received Logout message.10=160 | 2021-10-29 19:01:43.774
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:43.774
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:43.774
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:43.774
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:43.774
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:43.775
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:43.783
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:43.783
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:43.783
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:43.783
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:43.783
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:43.783
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:43.809
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:43.809
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:43.809
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:43.809
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:46.779
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:46.779
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:46.779
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:46.779
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:46.825
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:47.036
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:4656=MBastiani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| 2021-10-29 19:01:47.260
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:47.260
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:47.260
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:47.260
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:47.260
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:47.260
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:4656=MBastiani351258=SoftwareNotPermitted10=009 | 2021-10-29 19:01:47.272
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:47.273
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:47.273
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:47.27358=Received Logout message.10=157 | 2021-10-29 19:01:47.273
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:47.273
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:47.273
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:47.273
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:47.273
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:47.273
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:47.278
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:47.278
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:47.278
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:47.278
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:47.278
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:47.278
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:47.309
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:47.309
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:47.309
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:47.309
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:50.289
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:50.289
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:50.289
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:50.289
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:50.338
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:50.533
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:5056=MBastiani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| 2021-10-29 19:01:50.770
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:50.770
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:50.770
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:50.770
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:50.770
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:50.770
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:5056=MBastiani351258=SoftwareNotPermitted10=004 | 2021-10-29 19:01:50.785
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:50.785
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:50.785
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:50.78658=Received Logout message.10=160 | 2021-10-29 19:01:50.785
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:50.786
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:50.786
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:50.786
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:50.786
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:50.788
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:50.793
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:50.793
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:50.793
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:50.793
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:50.793
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:50.793
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:50.822
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:50.822
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:50.822
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:50.822
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:53.805
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:53.805
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:53.805
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:53.805
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:53.851
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:54.046
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:5356=MBastiani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| 2021-10-29 19:01:54.269
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:54.269
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:54.269
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:54.269
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:54.270
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:54.270
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:5356=MBastiani351258=SoftwareNotPermitted10=007 | 2021-10-29 19:01:54.285
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:54.285
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:54.285
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:54.28658=Received Logout message.10=159 | 2021-10-29 19:01:54.285
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:54.285
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:54.285
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:54.285
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:54.286
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:54.286
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:54.294
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:54.294
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:54.294
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:54.294
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:54.294
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:54.294
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:54.324
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:54.324
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:54.324
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:54.324
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:01:57.292
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:01:57.293
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:01:57.293
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:57.293
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:01:57.333
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:01:57.536
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:01:5756=MBastiani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| 2021-10-29 19:01:57.780
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:01:57.780
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:01:57.780
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:01:57.781
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:01:57.781
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:01:57.781
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:01:5756=MBastiani351258=SoftwareNotPermitted10=011 | 2021-10-29 19:01:57.795
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:01:57.795
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:01:57.795
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:01:57.79658=Received Logout message.10=168 | 2021-10-29 19:01:57.795
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:01:57.796
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:01:57.796
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:57.796
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:01:57.796
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:01:57.797
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:01:57.816
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:01:57.816
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:01:57.816
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:01:57.817
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:01:57.817
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:01:57.817
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:01:57.837
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:01:57.837
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:01:57.837
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:01:57.837
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:00.809
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:00.810
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:00.810
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:00.810
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:00.854
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:01.053
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:0056=MBastiani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| 2021-10-29 19:02:01.286
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:01.286
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:01.286
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:01.287
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:01.287
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:01.287
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:0056=MBastiani351258=SoftwareNotPermitted10=000 | 2021-10-29 19:02:01.300
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:01.300
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:01.300
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:01.30058=Received Logout message.10=139 | 2021-10-29 19:02:01.300
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:01.300
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:01.300
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:01.300
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:01.300
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:01.301
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:01.315
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:01.315
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:01.315
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:01.315
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:01.315
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:01.315
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:01.340
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:01.340
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:01.340
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:01.340
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:04.311
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:04.339
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:04.339
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:04.339
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:04.379
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:04.576
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:0456=MBastiani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| 2021-10-29 19:02:04.807
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:04.807
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:04.807
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:04.807
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:04.807
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:04.807
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:0456=MBastiani351258=SoftwareNotPermitted10=004 | 2021-10-29 19:02:04.829
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:04.829
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:04.829
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:04.83058=Received Logout message.10=150 | 2021-10-29 19:02:04.829
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:04.830
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:04.830
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:04.830
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:04.830
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:04.833
GAIN Capital FAST Data: Sent the Hello message. | 2021-10-29 19:02:04.847
GAIN Capital FAST Data: Sent a Logout message. | 2021-10-29 19:02:04.849
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:04.850
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:04.851
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:04.866
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:04.866
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:04.866
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:04.866
GAIN Capital FAST Data socket (3) | Socket gracefully closed by remote side. | 2021-10-29 19:02:04.896
GAIN Capital FAST Data: Sent the Logon message. | 2021-10-29 19:02:04.896
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:04.897
GAIN Capital FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2021-10-29 19:02:04.897
GAIN Capital FAST Data socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:04.897
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:04.897
GAIN Capital FAST Data socket (3) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:04.931
GAIN Capital FAST Data socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:04.931
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:04.931
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:07.853
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:07.853
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:07.853
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:07.853
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:07.898
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:08.207
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:0756=MBastiani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| 2021-10-29 19:02:08.439
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:08.439
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:08.439
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:08.439
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:08.439
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:08.439
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:0756=MBastiani351258=SoftwareNotPermitted10=007 | 2021-10-29 19:02:08.451
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:08.451
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:08.451
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:08.45158=Received Logout message.10=153 | 2021-10-29 19:02:08.451
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:08.451
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:08.451
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:08.451
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:08.451
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:08.453
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:08.470
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:08.470
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:08.470
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:08.470
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:08.470
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:08.470
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:08.491
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:08.491
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:08.491
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:08.491
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:11.469
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:11.469
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:11.470
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:11.470
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:11.511
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:11.704
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:1156=MBastiani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| 2021-10-29 19:02:11.923
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:11.923
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:11.923
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:11.924
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:11.924
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:11.924
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:1156=MBastiani351258=SoftwareNotPermitted10=002 | 2021-10-29 19:02:11.933
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:11.933
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:11.933
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:11.93458=Received Logout message.10=153 | 2021-10-29 19:02:11.933
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:11.933
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:11.933
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:11.933
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:11.933
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:11.934
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:11.952
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:11.952
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:11.952
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:11.952
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:11.953
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:11.953
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:11.973
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:11.973
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:11.973
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:11.973
GAIN Capital FIX Trading socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-10-29 19:02:13.661
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 19:02:13.661
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:14.951
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:14.951
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:14.951
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:14.951
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:14.995
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:15.185
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:1456=MBastiani351298=0108=3012004=7CEA82EB38A2954D6D0DEB2B94FBE87AED6899B083CA7082BE750DFBA8602484368AF8B041709EC1B1001A03A5F9FDEAF9DEF5AB41FBF4A68D34D148F1169A8815888DBDAE99118A251D44A3B119FBC72400C467CF53CD3B59F85FA5EBBA5DF99523E3D5BDD4995DB1FFC0BA686338CB236F3FF8B7136BD38D5F6950A1B3A2C3CE8CD7F21D3C309749BA9734476AE2F8192DAB76BD76367438BB51408A806A6317D268885A14ADE1B16E1F4600CCED5D71E08B5B9DCAE017DDA150001121134E4B8955F644B4E01B38A9E327A4266776B1733DA83FCE86BF2B3B48905C039852B8302B2A635386972E484CA7CCCAC174ECF82AE37A7D23CF5FFDD4A9F9EB8E3410=107 | 2021-10-29 19:02:15.417
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:15.417
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:15.417
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:15.417
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:15.417
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:15.417
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:1456=MBastiani351258=SoftwareNotPermitted10=005 | 2021-10-29 19:02:15.431
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:15.431
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:15.431
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:15.43258=Received Logout message.10=150 | 2021-10-29 19:02:15.431
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:15.431
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:15.431
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:15.431
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:15.431
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:15.433
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:15.437
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:15.437
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:15.437
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:15.437
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:15.437
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:15.437
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:15.505
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:15.505
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:15.505
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:15.505
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:18.443
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:18.443
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:18.443
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:18.443
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:18.485
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:18.685
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:1856=MBastiani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| 2021-10-29 19:02:18.915
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:18.915
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:18.915
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:18.915
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:18.915
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:18.915
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:1856=MBastiani351258=SoftwareNotPermitted10=009 | 2021-10-29 19:02:18.927
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:18.927
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:18.927
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:18.92758=Received Logout message.10=162 | 2021-10-29 19:02:18.927
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:18.927
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:18.927
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:18.927
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:18.927
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:18.928
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:18.937
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:18.937
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:18.937
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:18.937
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:18.938
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:18.938
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:18.964
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:18.964
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:18.964
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:18.964
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:21.937
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:21.938
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:21.938
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:21.938
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:21.978
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:22.169
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:2156=MBastiani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| 2021-10-29 19:02:22.387
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:22.387
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:22.387
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:22.387
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:22.387
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:22.387
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:2156=MBastiani351258=SoftwareNotPermitted10=003 | 2021-10-29 19:02:22.399
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:22.399
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:22.399
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:22.40058=Received Logout message.10=143 | 2021-10-29 19:02:22.399
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:22.399
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:22.399
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:22.399
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:22.399
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:22.400
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:22.403
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:22.403
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:22.403
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:22.403
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:22.403
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:22.403
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:22.437
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:22.437
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:22.437
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:22.437
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:25.403
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:25.403
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:25.403
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:25.403
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:25.446
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:25.641
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:2556=MBastiani351298=0108=3012004=34C53B072EB88E04566BF479D9A4969B1662A9417E6AFBD0F9ABD100100E4DAF284B7E9339B4D24ED1FD6A5CEB787906365FB9D528DBB142DB3BD03782BD770F812ED67197098F2CC2D26404D215F2318A9D713151C044715354C07EEC9846F1A94CF3869D9CD03FF3B2D424146BA9CF3F2F81732EAA951C644CBC883045F6DCA6D3F1BEBA541D89A7CD54B686FDF109C618A1AA570DDB9F5143D13D746E70B4964F9FE1E9BF85B76EB747759C03380FFFBEC6066AF98B48B1653E3DA41D40EE41E5DE79BC6F1B51E5C86EF7AF4DF108DA2AFDE541FEC86A45568C846B444D412DCE011FC99DA0281CFEB2A83209A9127BF0F4AB033F1E632C9BD7578104144E10=065 | 2021-10-29 19:02:25.863
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:25.863
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:25.863
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:25.864
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:25.864
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:25.864
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:2556=MBastiani351258=SoftwareNotPermitted10=007 | 2021-10-29 19:02:25.873
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:25.873
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:25.873
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:25.87458=Received Logout message.10=161 | 2021-10-29 19:02:25.873
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:25.873
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:25.873
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:25.873
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:25.873
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:25.875
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:25.892
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:25.892
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:25.892
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:25.892
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:25.892
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:25.892
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:25.912
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:25.912
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:25.912
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:25.912
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:28.887
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:28.887
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:28.887
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:28.887
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:28.933
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:29.120
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:2856=MBastiani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| 2021-10-29 19:02:29.338
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:29.338
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:29.338
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:29.339
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:29.339
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:29.339
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:2856=MBastiani351258=SoftwareNotPermitted10=010 | 2021-10-29 19:02:29.349
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:29.349
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:29.349
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:29.34958=Received Logout message.10=162 | 2021-10-29 19:02:29.349
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:29.349
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:29.349
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:29.349
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:29.349
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:29.349
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:29.359
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:29.359
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:29.359
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:29.359
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:29.359
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:29.359
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:29.383
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:29.383
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:29.384
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:29.384
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:32.364
GAIN Capital FIX Trading socket (3) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:32.364
GAIN Capital FIX Trading socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:32.364
GAIN Capital FIX Trading socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:32.364
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:32.406
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:32.609
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:3256=MBastiani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| 2021-10-29 19:02:32.831
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:32.831
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:32.831
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:3256=MBastiani351258=SoftwareNotPermitted10=005 | 2021-10-29 19:02:32.864
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:32.864
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:32.864
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:32.86458=Received Logout message.10=158 | 2021-10-29 19:02:32.864
GAIN Capital FIX Trading socket (3) | CloseSocket call. | 2021-10-29 19:02:32.864
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:32.864
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:32.864
GAIN Capital FIX Trading socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:32.864
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:32.864
GAIN Capital FAST Data socket (2) | CloseSocket call. | 2021-10-29 19:02:32.878
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:32.878
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:32.878
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:32.878
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:32.878
GAIN Capital FIX Trading socket (3) | Socket gracefully closed by remote side. | 2021-10-29 19:02:32.901
GAIN Capital FIX Trading socket (3) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:32.901
GAIN Capital FIX Trading socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:32.901
GAIN Capital FIX Trading socket (3) | Closed. | 2021-10-29 19:02:32.901
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:35.876
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:35.876
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:35.876
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:35.876
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:35.921
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:36.121
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:3556=MBastiani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| 2021-10-29 19:02:36.356
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:36.356
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:36.356
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:36.357
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:36.357
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:36.357
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:3556=MBastiani351258=SoftwareNotPermitted10=008 | 2021-10-29 19:02:36.368
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:36.368
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:36.368
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:36.36858=Received Logout message.10=161 | 2021-10-29 19:02:36.368
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:36.368
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:36.368
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:36.368
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:36.368
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:36.368
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:36.381
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:36.381
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:36.381
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:36.381
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:36.382
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:36.383
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:36.406
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:36.406
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:36.406
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:36.406
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:39.371
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:39.371
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:39.371
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:39.371
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:39.422
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:39.628
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:3956=MBastiani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| 2021-10-29 19:02:39.847
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:39.847
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:39.847
GAIN Capital FAST Data socket (3) | Creating socket. | 2021-10-29 19:02:39.847
GAIN Capital FAST Data socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:39.847
GAIN Capital FAST Data socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:39.847
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:3956=MBastiani351258=SoftwareNotPermitted10=012 | 2021-10-29 19:02:39.857
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:39.857
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:39.857
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:39.85758=Received Logout message.10=167 | 2021-10-29 19:02:39.857
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 19:02:39.857
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:39.857
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:39.857
GAIN Capital FIX Trading socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:39.857
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:39.858
GAIN Capital FAST Data socket (3) | CloseSocket call. | 2021-10-29 19:02:39.881
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:39.881
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:39.881
GAIN Capital FAST Data socket (3) | Closed. | 2021-10-29 19:02:39.882
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:39.882
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:39.882
GAIN Capital FIX Trading socket (2) | Socket gracefully closed by remote side. | 2021-10-29 19:02:39.893
GAIN Capital FIX Trading socket (2) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:39.893
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:39.893
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 19:02:39.893
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:42.884
GAIN Capital FIX Trading socket (3) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:42.884
GAIN Capital FIX Trading socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:02:42.884
GAIN Capital FIX Trading socket (3) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:42.884
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:42.925
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:43.127
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:4256=MBastiani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| 2021-10-29 19:02:43.347
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:43.347
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:43.347
GAIN Capital FAST Data socket (2) | Creating socket. | 2021-10-29 19:02:43.347
GAIN Capital FAST Data socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:43.347
GAIN Capital FAST Data socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:43.347
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:4256=MBastiani351258=SoftwareNotPermitted10=006 | 2021-10-29 19:02:43.360
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:43.360
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:43.360
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:43.36158=Received Logout message.10=152 | 2021-10-29 19:02:43.360
GAIN Capital FIX Trading socket (3) | CloseSocket call. | 2021-10-29 19:02:43.361
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:43.361
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:43.361
GAIN Capital FIX Trading socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:43.361
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:43.362
GAIN Capital FAST Data socket (2) | CloseSocket call. | 2021-10-29 19:02:43.378
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:43.378
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:43.378
GAIN Capital FAST Data socket (2) | Closed. | 2021-10-29 19:02:43.378
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:43.378
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:43.378
GAIN Capital FIX Trading socket (3) | Socket gracefully closed by remote side. | 2021-10-29 19:02:43.399
GAIN Capital FIX Trading socket (3) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:43.399
GAIN Capital FIX Trading socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:43.399
GAIN Capital FIX Trading socket (3) | Closed. | 2021-10-29 19:02:43.399
GAIN Capital FIX Trading socket (1) | Deleting network socket now after delay. | 2021-10-29 19:02:43.670
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:46.379
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:46.380
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 19:02:46.380
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:46.380
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:46.417
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:46.607
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:4656=MBastiani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| 2021-10-29 19:02:46.826
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:46.826
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:46.826
GAIN Capital FAST Data socket (2) | Creating socket. | 2021-10-29 19:02:46.826
GAIN Capital FAST Data socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:46.826
GAIN Capital FAST Data socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:46.826
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:4656=MBastiani351258=SoftwareNotPermitted10=010 | 2021-10-29 19:02:46.836
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:46.836
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:46.836
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:46.83658=Received Logout message.10=162 | 2021-10-29 19:02:46.836
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 19:02:46.836
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:46.836
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:46.836
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:46.836
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:46.838
GAIN Capital FAST Data socket (2) | CloseSocket call. | 2021-10-29 19:02:46.850
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:46.850
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:46.850
GAIN Capital FAST Data socket (2) | Closed. | 2021-10-29 19:02:46.850
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:46.851
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:46.851
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2021-10-29 19:02:46.874
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:46.874
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:46.874
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 19:02:46.874
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 19:02:49.850
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 19:02:49.850
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 19:02:49.850
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:49.850
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 19:02:49.895
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 19:02:50.092
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=58635=A34=149=OEC52=20211029-19:02:4956=MBastiani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| 2021-10-29 19:02:50.321
GAIN Capital FIX Trading | Connected to trading server. | 2021-10-29 19:02:50.321
GAIN Capital/OEC | Connecting to market data server prod.gainfutures.com:9301. | 2021-10-29 19:02:50.321
GAIN Capital FAST Data socket (2) | Creating socket. | 2021-10-29 19:02:50.322
GAIN Capital FAST Data socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:02:50.322
GAIN Capital FAST Data socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 19:02:50.322
GAIN Capital FIX Trading: (Recv) >> 8=FIX.4.49=7935=534=249=OEC52=20211029-19:02:4956=MBastiani351258=SoftwareNotPermitted10=013 | 2021-10-29 19:02:50.335
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted | 2021-10-29 19:02:50.335
GAIN Capital FIX Trading: Sending a Logout message. Text = Received Logout message. | 2021-10-29 19:02:50.335
GAIN Capital FIX Trading: (Send) << 8=FIX.4.49=8735=549=MBastiani351256=OEC34=252=20211029-19:02:50.33658=Received Logout message.10=152 | 2021-10-29 19:02:50.335
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 19:02:50.335
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 19:02:50.335
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:50.335
GAIN Capital FIX Trading socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 19:02:50.335
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 19:02:50.336
GAIN Capital FAST Data socket (2) | CloseSocket call. | 2021-10-29 19:02:50.339
GAIN Capital FAST Data: Socket connection was closed without any logout messages sent or received. | 2021-10-29 19:02:50.339
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:02:50.339
GAIN Capital FAST Data socket (2) | Closed. | 2021-10-29 19:02:50.339
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:02:50.339
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:02:50.339
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2021-10-29 19:02:50.378
GAIN Capital FIX Trading socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 19:02:50.378
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 19:02:50.378
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 19:02:50.378
The message log has been sent to support. | 2021-10-29 19:03:50.851 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2021-10-29 19:03:50.851
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2021-10-29 19:03:50.851
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 95.216.233.104. | 2021-10-29 19:03:50.851
Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\Data\MessageLogAnalysis.htm | 2021-10-29 19:03:52.033
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2021-10-29 19:03:52.287
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-10-29 19:03:52.287
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-10-29 19:03:52.400
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-10-29 19:03:52.400
File >> Disconnect selected. | 2021-10-29 19:04:12.179
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:04:12.179
GAIN Capital/OEC | Disconnected. | 2021-10-29 19:04:12.179
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 19:11:21.315
WSACleanup called. | 2021-10-29 19:11:21.316
Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 4. | 2021-10-29 19:11:21.324
Current selected Data/Trading service: SC Data - All Services | 2021-10-29 19:11:21.324
Symbol settings MD5 received. Request ID: 4. | 2021-10-29 19:11:22.185
Requested symbol settings for service code scdataallservices. Request ID: 5. | 2021-10-29 19:11:22.185
SC Data - All Services | Disconnected. | 2021-10-29 19:11:23.130
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 19:11:23.130
Symbol settings received. Request ID: 5. | 2021-10-29 19:11:23.857
SC Data - All Services | Connected to server complete. | 2021-10-29 19:11:25.128
Triggering next historical data download in queue. | 2021-10-29 19:11:25.129
Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2021-10-29 19:11:25.129
No download requests in the queue to start downloads for. | 2021-10-29 19:11:25.129
Using Bid/Ask average for last trade price for EURUSD | 2021-10-29 19:11:25.255
SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 1 Service code: fxcm | 2021-10-29 19:11:25.255
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2021-10-29 19:11:25.255
SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 1 | 2021-10-29 19:11:25.255
DTC Client socket (1) | Creating socket. | 2021-10-29 19:11:25.421
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 19:11:25.421
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2021-10-29 19:11:25.421
SC DTC Data with Market Depth | Network connection to server complete. | 2021-10-29 19:11:25.453
SC DTC Data with Market Depth | Starting socket receive thread. | 2021-10-29 19:11:25.453
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-10-29 19:11:25.453
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-10-29 19:11:25.494
SC DTC Data with Market Depth | Sending logon request message. | 2021-10-29 19:11:25.494
SC DTC Data with Market Depth | Received logon response. | 2021-10-29 19:11:26.090
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-10-29 19:11:26.090
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-10-29 19:11:26.090
SC DTC Data with Market Depth | Successfully connected. | 2021-10-29 19:11:26.090
SC DTC Data with Market Depth | Trading is not supported. | 2021-10-29 19:11:26.090
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2021-10-29 19:11:26.090
SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2021-10-29 19:11:26.210
Enabling compression for file: C:\SierraChart\Data\Data\ESZ21-CME.scid. This may take a while. | 2021-10-29 19:14:00.385
File compression enabled. C:\SierraChart\Data\Data\ESZ21-CME.scid. CompressionState=0 | 2021-10-29 19:14:00.385
ESZ21-CME 1 Min #2 | Reloading chart. | 2021-10-29 19:14:00.388
ESZ21-CME 1 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Data\ESZ21-CME.scid | 2021-10-29 19:14:00.399
Mapping ESZ21-CME to ESZ21. Service code: cme | 2021-10-29 19:14:00.876
SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESZ21-CME (ESZ21). ID: 2 Service code: cme | 2021-10-29 19:14:00.876
SC DTC Delayed Exchange Data | Connecting to the server ds21.sierracharts.com. Port 10043 | 2021-10-29 19:14:00.876
SC DTC Delayed Exchange Data | Requesting security definition data for: ESZ21-CME (ESZ21). ID: 2 | 2021-10-29 19:14:00.877
Added historical Intraday data request for ESZ21-CME to the queue. | 2021-10-29 19:14:00.877
Intraday data recording state for symbol ESZ21-CME is set to download 'Pending'. | 2021-10-29 19:14:00.877
Triggering next historical data download in queue. | 2021-10-29 19:14:00.877
Delaying start of download for ESZ21-CME | 2021-10-29 19:14:00.883
DTC Client socket (2) | Creating socket. | 2021-10-29 19:14:01.044
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-10-29 19:14:01.044
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2021-10-29 19:14:01.044
SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-10-29 19:14:01.081
SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-10-29 19:14:01.081
SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-10-29 19:14:01.081
SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-10-29 19:14:01.131
SC DTC Delayed Exchange Data | Sending logon request message. | 2021-10-29 19:14:01.131
SC DTC Delayed Exchange Data | Received logon response. | 2021-10-29 19:14:01.729
SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-10-29 19:14:01.729
SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-10-29 19:14:01.729
SC DTC Delayed Exchange Data | Successfully connected. | 2021-10-29 19:14:01.729
SC DTC Delayed Exchange Data | Trading is not supported. | 2021-10-29 19:14:01.729
SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ESZ21-CME -> ESZ21 | 2021-10-29 19:14:01.729
SC DTC Delayed Exchange Data | Received security definition for symbol ESZ21-CME | 2021-10-29 19:14:01.850
ESZ21-CME 1 Min #3 | Reloading chart. | 2021-10-29 19:14:05.749
ESZ21-CME 1 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Data\ESZ21-CME.scid | 2021-10-29 19:14:05.760
ESZ21-CME 1 Min #4 | Reloading chart. | 2021-10-29 19:14:06.601
ESZ21-CME 1 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Data\ESZ21-CME.scid | 2021-10-29 19:14:06.612
HD Request # 2 | Downloading Intraday chart data for ESZ21-CME to the file ESZ21-CME.scid. Service: cme | 2021-10-29 19:14:06.761
HD Request # 2 | Download start date-time: 2021-04-26 19:14:06.000000. File last date-time: 00:00:00.000000 | 2021-10-29 19:14:06.762
HD Request # 2 | Using server: ds21.sierracharts.com port 10150 | 2021-10-29 19:14:06.763
Socket (3) | Creating socket. | 2021-10-29 19:14:06.763
Socket (3) | New receive buffer size: 5242880 | 2021-10-29 19:14:06.764
Socket (3) | Connecting to IP: 216.1.90.129. | 2021-10-29 19:14:06.764
HD Request # 2 | Setting DTC encoding to Binary VLS | 2021-10-29 19:14:06.843
HD Request # 2 | Sending historical data logon request message. | 2021-10-29 19:14:06.843
HD Request # 2 | Requesting Intraday data. Start date-time: 2021-04-26 19:14:06. Record interval: 1. Symbol: ESZ21 | 2021-10-29 19:14:07.330
HD Request # 2 | Decompressing data. | 2021-10-29 19:14:07.361
HD Request # 2 | Receiving Intraday data for ESZ21-CME starting at 2021-04-27 05:32:20.840000 | 2021-10-29 19:14:07.498
HD Request # 2 | Timestamp of first Intraday data file record written: 2021-04-27 05:32:20.840000 | 2021-10-29 19:14:07.668
Socket (3) | CloseSocket call. | 2021-10-29 19:14:17.511
Socket (3) | Shutdown started. Waiting for graceful close. | 2021-10-29 19:14:17.511
Historical data download thread signaled to stop. | 2021-10-29 19:14:17.512
HD Request # 2 | Received 1647602 Intraday data records from 2021-04-27 05:32:20.840000 to 2021-10-29 19:04:14.888000 (185.6 days) and wrote 1647602 records for ESZ21-CME | 2021-10-29 19:14:17.512
HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2021-10-29 19:04:14.888000 | 2021-10-29 19:14:17.516
HD Request # 2 | Completion time: 11s | 2021-10-29 19:14:17.516
HD Request # 2 | Intraday data download complete for ESZ21-CME. Unique request ID: 2 | 2021-10-29 19:14:17.516
Removing historical data download ID 2. | 2021-10-29 19:14:17.516
Real-time Intraday chart data file updates started for ESZ21-CME | 2021-10-29 19:14:17.516
Opened cached Intraday file: C:\SierraChart\Data\Data\ESZ21-CME.scid. Thread ID: 23648 | 2021-10-29 19:14:17.517
Intraday chart data file opened for ESZ21-CME | 2021-10-29 19:14:17.517
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-10-29 19:14:17.517
Triggering next historical data download in queue. | 2021-10-29 19:14:17.517
No download requests in the queue to start downloads for. | 2021-10-29 19:14:17.517
Socket (3) | Socket gracefully closed by remote side. | 2021-10-29 19:14:17.544
Socket (3) | Closed. | 2021-10-29 19:14:17.544
ESZ21-CME 1 Min #5 | Reloading chart. | 2021-10-29 19:14:37.112
File >> Disconnect selected. | 2021-10-29 19:17:42.885
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-10-29 19:17:42.885
DTC Client socket (1) | CloseSocket call. | 2021-10-29 19:17:42.886
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2021-10-29 19:17:42.886
SC DTC Data with Market Depth | Disconnected from the server. | 2021-10-29 19:17:42.886
SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2021-10-29 19:17:42.886
DTC Client socket (2) | CloseSocket call. | 2021-10-29 19:17:42.886
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-10-29 19:17:42.886
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-10-29 19:17:42.886
SC Data - All Services | Disconnected. | 2021-10-29 19:17:42.886
DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-10-29 19:19:43.885
DTC Client socket (1) | Closed. | 2021-10-29 19:19:43.885
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-10-29 19:19:43.885
DTC Client socket (2) | Closed. | 2021-10-29 19:19:43.885
DTC Client socket (1) | Deleting network socket now after delay. | 2021-10-29 19:20:13.889
DTC Client socket (2) | Deleting network socket now after delay. | 2021-10-29 19:20:13.889
SC Data - All Services | Disconnected. | 2021-10-29 22:11:03.292
SC Data - All Services | Disconnected. | 2021-10-29 22:11:03.326
Checking for new symbol settings. Requested symbol settings MD5 for service code oec. Request ID: 6. | 2021-10-29 22:11:03.335
Current selected Data/Trading service: GAIN Capital/OEC | 2021-10-29 22:11:03.335
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:05.275
Enabling compression for file: C:\SierraChart\Data\Data\ESZ21.scid. This may take a while. | 2021-10-29 22:11:05.563
File compression enabled. C:\SierraChart\Data\Data\ESZ21.scid. CompressionState=0 | 2021-10-29 22:11:05.563
ESZ21[M] 1 Min #4 | Reloading chart. | 2021-10-29 22:11:05.564
ESZ21[M] 1 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Data\ESZ21.scid | 2021-10-29 22:11:05.574
ESZ21[M] 1 Min #5 | Reloading chart. | 2021-10-29 22:11:05.577
ESZ21[M] 1 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Data\ESZ21.scid | 2021-10-29 22:11:05.587
ESZ21[M] 1 Min #3 | Reloading chart. | 2021-10-29 22:11:05.590
ESZ21[M] 1 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Data\ESZ21.scid | 2021-10-29 22:11:05.600
ESZ21[M] 1 Min #2 | Reloading chart. | 2021-10-29 22:11:05.607
ESZ21[M] 1 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\Data\ESZ21.scid | 2021-10-29 22:11:05.616
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:08.267
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:08.349
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 22:11:08.349
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:08.349
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:08.405
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:08.608
GAIN Capital FIX Trading socket (2) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:08.848
GAIN Capital FIX Trading socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:08.848 *
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 22:11:08.848
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:08.848
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:08.848
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:08.848
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:08.848
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:08.848
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 22:11:08.848
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:08.859
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:08.859
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:08.859
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:11.856
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:11.857
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 22:11:11.857
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:11.857
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:11.913
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:12.106
GAIN Capital FIX Trading socket (2) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:12.355
GAIN Capital FIX Trading socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:12.355 *
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 22:11:12.355
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:12.355
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:12.355
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 22:11:12.355
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:12.355
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:12.355
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:12.355
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:12.379
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:12.379
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:12.380
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:15.386
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:15.386
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 22:11:15.386
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:15.386
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:15.441
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:15.639
GAIN Capital FIX Trading socket (2) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:15.877
GAIN Capital FIX Trading socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:15.877 *
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 22:11:15.877
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:15.877
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:15.877
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 22:11:15.877
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:15.877
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:15.877
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:15.878
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:15.895
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:15.896
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:15.896
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:18.887
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:18.887
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 22:11:18.887
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:18.887
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:18.943
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:19.138
GAIN Capital FIX Trading socket (2) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:19.376
GAIN Capital FIX Trading socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:19.376 *
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 22:11:19.376
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:19.376
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:19.376
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 22:11:19.376
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:19.376
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:19.376
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:19.376
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:19.387
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:19.387
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:19.387
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:22.388
GAIN Capital FIX Trading socket (2) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:22.389
GAIN Capital FIX Trading socket (2) | New receive buffer size: 5242880 | 2021-10-29 22:11:22.389
GAIN Capital FIX Trading socket (2) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:22.389
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:22.443
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:22.640
GAIN Capital FIX Trading socket (2) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:22.881
GAIN Capital FIX Trading socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:22.881 *
GAIN Capital FIX Trading socket (2) | CloseSocket call. | 2021-10-29 22:11:22.881
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:22.881
GAIN Capital FIX Trading socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:22.881
GAIN Capital FIX Trading socket (2) | Closed. | 2021-10-29 22:11:22.881
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:22.881
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:22.881
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:22.881
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:22.895
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:22.895
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:22.895
Symbol settings MD5 received. Request ID: 6. | 2021-10-29 22:11:23.417
Requested symbol settings for service code oec. Request ID: 7. | 2021-10-29 22:11:23.417
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:25.889
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:25.890
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:25.890
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:25.890
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:25.946
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:26.143
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:26.383
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:26.383 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:26.383
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:26.383
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:26.383
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:26.384
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:26.384
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:26.384
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:26.384
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:26.392
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:26.392
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:26.392
Symbol settings received. Request ID: 7. | 2021-10-29 22:11:28.440
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:29.416
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:29.416
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:29.416
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:29.416
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:29.472
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:29.670
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:29.918
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:29.918 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:29.918
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:29.918
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:29.918
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:29.918
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:29.918
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:29.918
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:29.918
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:29.948
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:29.948
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:29.948
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:32.940
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:32.941
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:32.941
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:32.941
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:32.996
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:33.199
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:33.441
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:33.441 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:33.441
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:33.441
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:33.441
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:33.441
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:33.441
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:33.441
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:33.441
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:33.462
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:33.462
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:33.462
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:36.451
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:36.451
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:36.451
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:36.451
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:36.509
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:36.712
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:36.951
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:36.951 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:36.951
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:36.951
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:36.951
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:36.951
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:36.951
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:36.951
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:36.952
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:36.965
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:36.965
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:36.965
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:39.965
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:40.026
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:40.026
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:40.026
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:40.082
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:40.281
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:40.521
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:40.521 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:40.521
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:40.521
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:40.521
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:40.521
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:40.521
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:40.521
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:40.521
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:40.531
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:40.532
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:40.532
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:43.531
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:43.531
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:43.531
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:43.531
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:43.586
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:43.781
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:44.024
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:44.024 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:44.024
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:44.024
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:44.024
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:44.024
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:44.024
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:44.024
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:44.024
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:44.032
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:44.032
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:44.032
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:47.031
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:47.031
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:47.031
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:47.031
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:47.087
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:47.281
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:47.526
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:47.526 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:47.526
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:47.526
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:47.526
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:47.526
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:47.526
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:47.526
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:47.526
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:47.531
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:47.531
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:47.531
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:50.527
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:50.527
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:50.527
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:50.527
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:50.589
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:50.782
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:51.029
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:51.029 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:51.029
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:51.029
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:51.029
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:51.029
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:51.029
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:51.029
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:51.029
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:51.048
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:51.048
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:51.048
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:54.047
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:54.048
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:54.048
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:54.048
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:54.103
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:54.293
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:54.538
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:54.538 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:54.538
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:54.538
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:54.538
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:54.538
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:54.538
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:54.538
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:54.538
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:54.547
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:54.548
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:54.548
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:11:57.547
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:11:57.547
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:11:57.547
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:11:57.547
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:11:57.602
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:11:57.797
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:11:58.039
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:11:58.039 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:11:58.039
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:11:58.039
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:11:58.039
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:11:58.039
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:11:58.039
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:58.039
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:11:58.039
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:11:58.045
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:11:58.046
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:11:58.046
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:12:01.044
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:12:01.045
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:12:01.045
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:12:01.045
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:12:01.102
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:12:01.298
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:12:01.538
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:12:01.538 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:12:01.538
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:12:01.538
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:12:01.538
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:12:01.538
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:12:01.538
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:01.538
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:12:01.538
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:12:01.544
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:12:01.544
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:01.544
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:12:04.544
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:12:04.544
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:12:04.544
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:12:04.544
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:12:04.606
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:12:04.810
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:12:05.048
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:12:05.048 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:12:05.048
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:12:05.048
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:12:05.048
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:12:05.048
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:12:05.048
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:05.048
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:12:05.048
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:12:05.059
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:12:05.059
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:05.059
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:12:08.063
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:12:08.097
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:12:08.097
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:12:08.097
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:12:08.161
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:12:08.357
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:12:08.599
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:12:08.599 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:12:08.599
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:12:08.599
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:12:08.599
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:12:08.599
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:12:08.599
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:08.599
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:12:08.599
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:12:08.614
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:12:08.614
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:08.614
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:12:11.608
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:12:11.666
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:12:11.666
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:12:11.666
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:12:11.722
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:12:11.918
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:12:12.155 *
GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2021-10-29 22:12:12.155
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:12:12.155
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:12:12.155
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:12:12.155
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:12:12.155
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:12:12.155
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:12.156
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:12:12.156
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:12:12.168
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:12:12.168
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:12.168
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:12:15.170
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:12:15.171
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:12:15.171
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:12:15.171
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:12:15.232
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:12:15.435
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:12:15.677
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:12:15.677 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:12:15.677
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:12:15.677
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:12:15.677
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:12:15.677
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:12:15.677
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:15.677
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:12:15.677
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:12:15.685
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:12:15.685
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:15.685
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:12:18.696
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:12:18.696
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:12:18.696
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:12:18.696
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:12:18.752
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:12:18.958
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:12:19.201
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:12:19.201 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:12:19.201
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:12:19.201
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:12:19.201
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:12:19.201
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:12:19.201
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:19.201
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:12:19.201
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:12:19.218
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:12:19.219
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:19.219
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:12:22.214
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:12:22.215
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:12:22.215
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:12:22.215
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:12:22.270
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:12:22.466
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:12:22.713
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:12:22.713 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:12:22.713
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:12:22.713
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:12:22.713
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:12:22.713
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:12:22.713
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:22.713
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:12:22.713
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:12:22.717
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:12:22.718
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:22.718
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:12:25.716
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:12:25.716
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:12:25.716
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:12:25.716
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:12:25.774
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:12:25.964
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:12:26.204
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:12:26.204 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:12:26.204
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:12:26.204
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:12:26.204
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:12:26.204
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:12:26.204
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:26.204
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:12:26.204
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:12:26.223
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:12:26.223
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:26.223
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2021-10-29 22:12:29.214
GAIN Capital FIX Trading socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 22:12:29.214
GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-10-29 22:12:29.214
GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.30. | 2021-10-29 22:12:29.214
GAIN Capital FIX Trading: Connected to FIX server. | 2021-10-29 22:12:29.276
GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=MBastiani3512. | 2021-10-29 22:12:29.472
GAIN Capital FIX Trading socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-10-29 22:12:29.726
GAIN Capital FIX Trading socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-10-29 22:12:29.726 *
GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-10-29 22:12:29.726
GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-10-29 22:12:29.726
GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 22:12:29.726
GAIN Capital FIX Trading socket (1) | Closed. | 2021-10-29 22:12:29.726
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 22:12:29.726
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:29.726
GAIN Capital/OEC | Disconnected from the trading server. | 2021-10-29 22:12:29.726
GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-10-29 22:12:29.730
GAIN Capital/OEC | Disconnected. | 2021-10-29 22:12:29.730
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 22:12:29.730
[2021-10-29 22:16:06]
User312718 - Posts: 26
This is the message log while trying to connect to SC-All Services (data)
Software version: 2323 64-bit | 2021-10-29 22:14:18.697
Primary Thread ID: 23648 | 2021-10-29 22:14:18.697
Usage end date: 2021-12-02 | 2021-10-29 22:14:18.697
Enabled for: Sierra Chart Historical Data Service. | 2021-10-29 22:14:18.697
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-10-29 22:14:18.697
Enabled for: Delayed Denali Exchange Data Feed. | 2021-10-29 22:14:18.697
Enabled for exchange2: CME | 2021-10-29 22:14:18.697
Enabled for exchange2: fairx_exchange.data | 2021-10-29 22:14:18.697
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-10-29 22:14:18.697
Current selected Data/Trading service: SC Data - All Services | 2021-10-29 22:14:18.697
Custom symbol settings values: enabled | 2021-10-29 22:14:18.697
Chart Update Interval: 500 | 2021-10-29 22:14:18.697
Intraday Data Storage Time Unit: 1 | 2021-10-29 22:14:18.697
Time Zone: +00:00:00 (UTC+00) | 2021-10-29 22:14:18.697
2021-10-29 22:14:18 Local computer time in UTC | 2021-10-29 22:14:18.697
2021-10-29 22:14:18 Local computer time in SC Time Zone | 2021-10-29 22:14:18.697
2021-10-28 23:07:30 Server time in UTC | 2021-10-29 22:14:18.697
Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-10-29 22:14:18.697
Program path: C:\SierraChart\Data\ | 2021-10-29 22:14:18.697
Data Files path: C:\SierraChart\Data\Data\ | 2021-10-29 22:14:18.697
OS Version Number: 10.0 | 2021-10-29 22:14:18.698
Locale Setting: C | 2021-10-29 22:14:18.698
DLLs: SierraChartStudies_64.dll, UserContributedStudies_64.dll | 2021-10-29 22:14:18.698
Allowed protected custom studies: | 2021-10-29 22:14:18.698
[2021-10-31 16:00:49]
John - SC Support - Posts: 39362
This is the relevant message:
GAIN Capital FIX Trading: Received a Logout message. Text = SoftwareNotPermitted
You need to ask Gain to allow Sierra Chart.
[2023-12-13 15:44:57]
I put a trade on and my internet went down. There was a stop and target in place. When my internet came back the position is gone but my trade log is just showing the entry and no exit. I called stonex and they said the target was hit and the position was closed. I'm still just seeing an open position in my trade log. I just want to make sure everything is squared away. Everything on sierra dom's are showing I'm flat but the trade log is only showing the entry for a sell short and no buy to cover. Trade log below: Thank you
TradeActivity files query time: 0.130359 seconds. Entries: 0. Current queries: 2 | 2023-12-13 10:13:08.612
TradeActivity files query time: 0.000251 seconds. Entries: 1. Current queries: 1 | 2023-12-13 10:13:08.613
SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-12-13 10:13:22.441
SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2023-12-13 10:13:22.441
TradeActivity files query time: 0.025173 seconds. Entries: 11. Current queries: 1 | 2023-12-13 10:13:44.911
TradeActivity files query time: 0.018490 seconds. Entries: 11. Current queries: 2 | 2023-12-13 10:13:44.973
TradeActivity files query time: 0.019321 seconds. Entries: 11. Current queries: 3 | 2023-12-13 10:13:45.078
TradeActivity files query time: 0.017893 seconds. Entries: 11. Current queries: 4 | 2023-12-13 10:13:45.113
TradeActivity files query time: 0.019391 seconds. Entries: 12. Current queries: 5 | 2023-12-13 10:13:45.152
TradeActivity files query time: 0.011652 seconds. Entries: 11. Current queries: 8 | 2023-12-13 10:13:45.179
TradeActivity files query time: 0.011673 seconds. Entries: 12. Current queries: 8 | 2023-12-13 10:13:45.190
TradeActivity files query time: 0.018399 seconds. Entries: 11. Current queries: 8 | 2023-12-13 10:13:45.209
TradeActivity files query time: 0.015536 seconds. Entries: 11. Current queries: 2 | 2023-12-13 10:13:45.669
TradeActivity files query time: 0.016701 seconds. Entries: 11. Current queries: 1 | 2023-12-13 10:13:45.685
TradeActivity files query time: 0.017295 seconds. Entries: 11. Current queries: 1 | 2023-12-13 10:13:46.902
TradeActivity files query time: 0.016529 seconds. Entries: 11. Current queries: 1 | 2023-12-13 10:13:48.926
TradeActivity files query time: 0.014863 seconds. Entries: 11. Current queries: 1 | 2023-12-13 10:13:49.885
TradeActivity files query time: 0.019989 seconds. Entries: 11. Current queries: 1 | 2023-12-13 10:13:50.045
TradeActivity files query time: 0.015218 seconds. Entries: 12. Current queries: 1 | 2023-12-13 10:13:50.229
TradeActivity files query time: 0.015016 seconds. Entries: 11. Current queries: 2 | 2023-12-13 10:13:50.283
TradeActivity files query time: 0.019503 seconds. Entries: 11. Current queries: 1 | 2023-12-13 10:13:50.372
SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-12-13 10:19:46.302
SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2023-12-13 10:19:46.302
SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-12-13 10:19:51.675
SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 2 | 2023-12-13 10:19:51.675
TradeActivity files query time: 0.004419 seconds. Entries: 1. Current queries: 1 | 2023-12-13 10:20:52.966
TradeActivity files query time: 0.000418 seconds. Entries: 1. Current queries: 1 | 2023-12-13 10:20:53.473
SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-12-13 10:21:42.010
SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2023-12-13 10:21:42.010
SC Data - All Services | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 1 | 2023-12-13 10:22:39.123
SC Data - All Services | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 1 | 2023-12-13 10:22:39.123
TradeActivity files query time: 0.004347 seconds. Entries: 1. Current queries: 1 | 2023-12-13 10:32:39.414
TradeActivity files query time: 0.000373 seconds. Entries: 1. Current queries: 1 | 2023-12-13 10:32:39.906
TradeActivity files query time: 0.000355 seconds. Entries: 1. Current queries: 1 | 2023-12-13 10:32:45.909
TradeActivity files query time: 0.000370 seconds. Entries: 1. Current queries: 1 | 2023-12-13 10:32:45.945
TradeActivity files query time: 0.000371 seconds. Entries: 1. Current queries: 1 | 2023-12-13 10:32:49.528
TradeActivity files query time: 0.000321 seconds. Entries: 1. Current queries: 1 | 2023-12-13 10:32:49.572
[2023-12-13 17:18:16]
You would need to enter the missing fill, as it was not picked up from your trading service. Refer to the following:
Trade Activity Log: Manually Inserting Missing Order Fills
[2025-03-19 19:38:21]
Attached is the error message I'm getting. For some reason I'm not getting the correct price and data.
2025-03-19 19:34:52.855 | Trade activity files set size: 49
2025-03-19 19:34:52.996 | Created the DTC Protocol server.
2025-03-19 19:34:52.997 | DTC Protocol Server listening on port 11099.
2025-03-19 19:34:52.997 | Reading Internal Order ID file.
2025-03-19 19:34:52.998 | Reading Trade Orders file.
2025-03-19 19:34:52.999 | Reading Trade Positions file.
2025-03-19 19:34:52.999 | Reading Trade Account Data files.
2025-03-19 19:34:53.000 | Software version: 2744 64-bit
2025-03-19 19:34:53.000 | Primary Thread ID: 26656
2025-03-19 19:34:53.000 | Usage end date: 2025-04-11
2025-03-19 19:34:53.000 | Enabled for: Advanced Features 2.
2025-03-19 19:34:53.000 | Enabled for: Sierra Chart Historical Data Service.
2025-03-19 19:34:53.000 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-03-19 19:34:53.000 | Enabled for: Delayed Denali Exchange Data Feed.
2025-03-19 19:34:53.000 | Enabled for exchange2: CME (Trading Account Required)
2025-03-19 19:34:53.000 | Enabled for exchange2: CBOT (Trading Account Required)
2025-03-19 19:34:53.000 | Enabled for exchange2: COMEX (Trading Account Required)
2025-03-19 19:34:53.000 | Enabled for exchange2: NYMEX (Trading Account Required)
2025-03-19 19:34:53.000 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-03-19 19:34:53.000 | Current selected Data/Trading service: SC Data
2025-03-19 19:34:53.000 | Custom symbol settings values: disabled
2025-03-19 19:34:53.000 | Chart Update Interval: 400
2025-03-19 19:34:53.000 | Intraday Data Storage Time Unit: 0
2025-03-19 19:34:53.000 | Time Zone: +00:00:00 (UTC+00)
2025-03-19 19:34:53.000 | 2025-03-19 19:34:53 Local computer time in UTC
2025-03-19 19:34:53.000 | 2025-03-19 19:34:53 Local computer time in SC Time Zone
2025-03-19 19:34:53.000 | 2025-03-19 19:34:52 Server time in UTC
2025-03-19 19:34:53.000 | Local computer UTC time and Server UTC time difference: 0 seconds.
2025-03-19 19:34:53.000 | Program path: C:\SierraChart\
2025-03-19 19:34:53.000 | Data Files path: C:\SierraChart\Data\
2025-03-19 19:34:53.000 | OS Version Number: 10.0
2025-03-19 19:34:53.000 | Locale Setting: C
2025-03-19 19:34:53.000 | DLLs: UserContributedStudies_64.dll
2025-03-19 19:34:53.000 | Allowed protected custom studies:
2025-03-19 19:34:53.000 | Crash reporter started: true
2025-03-19 19:34:53.014 | Created the DTC Protocol historical data server.
2025-03-19 19:34:53.015 | HD Server Manager | Listening on port 11098.
2025-03-19 19:34:53.015 | Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1.
2025-03-19 19:34:53.038 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-03-19 19:34:53.064 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-03-19 19:34:53.064 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-03-19 19:34:53.129 | Received 5 login tokens.
2025-03-19 19:34:53.578 | Symbol settings MD5 received. Request ID: 1.
2025-03-19 19:34:53.578 | Requested symbol settings for service code scdataallservices. Request ID: 2.
2025-03-19 19:35:53.079 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:35:53.079 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\MESH25-CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:35:53.079 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:35:53.079 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:35:58.086 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:35:58.086 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\MESH25-CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:35:58.086 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:35:58.086 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:36:03.099 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:36:03.099 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\MESH25-CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:36:03.099 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:36:03.099 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:36:08.108 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:36:08.108 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\MESH25-CME.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:36:08.108 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\TICK-NYSE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
2025-03-19 19:36:08.108 | Error writing to cached Intraday data file. Error writing record to the file C:\SierraChart\Data\BTCUSD_PERP_BINANCE.scid. Error: File error: Windows error code 112: There is not enough space on the disk.
Date Time Of Last Edit: 2025-03-19 21:13:29
[2025-03-19 20:18:41]
User312718:
This last post is completely unrelated to the original posting topic. Next time, be sure you open a new thread for the particular issue you are having. Do not continue to add to an existing thread that is not related.
As to the issue you are having, we see the following in your log:
Error writing historical Intraday data. Error writing record to the file C:\SierraChart\Data\XAUUSD.scid. Error: File error: Windows error code 112: There is not enough space on the disk. *
You are out of drive space. You need to either get a larger drive, or clean up space on your drive. For cleaning up Sierra Chart files, refer to the following:
Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency
