Date/Time: Tue, 04 Nov 2025 09:04:21 +0000
[User Discussion] - RT Data with CQG
View Count: 571
| [2021-09-28 17:12:31] |
| User397996 - Posts: 18 |
I have an account with AMP and i'm trying to use SC for both charting and trading. When i log in using CQG credentials, my sub-instance of SC, which i use to follow NQ and RTY, stops updating despite being connected on top left corner. If i have Pack 10 w/ Denali, shouldn't i be able to follow all the markets included? Thanks. |
| [2021-09-28 17:42:25] |
| John - SC Support - Posts: 42737 |
Yes, you should be getting the data into a sub-instance without any issues. Are you able to get the data correctly in the main instance? Also, when you say you are using a Sub-Instance, are you starting that Sub-Instance by selecting File >> New Instance, or is this a completely separate installation of Sierra Chart? Also, get us the Message Log from the Sub-Instance by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-09-29 09:43:16] |
Good morning. My 2nd instance is a sub-instance of SC, which starts automatically with the first one. The chart I opened is NQZ21. I posted below the message log. I think I know what's happening: in the main instance, as I switch from SC data to CQG data, it asks me if I want to change the symbol from ESZ21 to F.US.ESZ21, which is the equivalent for CQG. That doesn't happen on the sub-instance, i wonder why. I manually switched the symbols for the CQG equivalent - does SC have an option to do this for all charts at once? Thanks **************** Software version: 2299 64-bit | 2021-09-29 04:22:26.993 Safe Mode enabled | 2021-09-29 04:22:26.993 Primary Thread ID: 13272 | 2021-09-29 04:22:26.993 Usage end date: 2022-03-27 | 2021-09-29 04:22:26.993 Enabled for: Sierra Chart Historical Data Service. | 2021-09-29 04:22:26.993 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-09-29 04:22:26.993 Enabled for: Delayed Denali Exchange Data Feed. | 2021-09-29 04:22:26.993 Enabled for exchange2: CME (Trading Account Required) | 2021-09-29 04:22:26.993 Enabled for exchange2: CBOT (Trading Account Required) | 2021-09-29 04:22:26.993 Enabled for exchange2: COMEX (Trading Account Required) | 2021-09-29 04:22:26.993 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-09-29 04:22:26.993 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-09-29 04:22:26.993 Current selected Data/Trading service: DTC - Sub Instance | 2021-09-29 04:22:26.993 Custom symbol settings values: disabled | 2021-09-29 04:22:26.993 Chart Update Interval: 40 | 2021-09-29 04:22:26.993 Intraday Data Storage Time Unit: 0 | 2021-09-29 04:22:26.993 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-09-29 04:22:26.993 2021-09-29 09:22:26 Local computer time in UTC | 2021-09-29 04:22:26.993 2021-09-29 04:22:26 Local computer time in SC Time Zone | 2021-09-29 04:22:26.993 2021-09-29 09:18:54 Server time in UTC | 2021-09-29 04:22:26.993 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-09-29 04:22:26.993 Program path: C:\SierraChart\SierraChartTransActMA\SierraChartInstance_2\ | 2021-09-29 04:22:26.993 Data Files path: C:\SierraChart\SierraChartTransActMA\SierraChartInstance_2\Data\ | 2021-09-29 04:22:26.993 OS Version Number: 10.0 | 2021-09-29 04:22:26.994 Locale Setting: C | 2021-09-29 04:22:26.994 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2021-09-29 04:22:26.994 Allowed protected custom studies: | 2021-09-29 04:22:26.994 NQZ21-CME [C] 5 Min #9 | Reloading chart. | 2021-09-29 04:22:36.744 NQZ21-CME [C] 5 Min #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2021-09-29 04:22:36.744 NQZ21-CME [C] 5 Min #9 | There are no continuous futures contract symbols. Loading data normally. | 2021-09-29 04:22:36.744 NQZ21-CME [C-D] 5 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-09-29 04:22:38.281 File >> Disconnect selected. | 2021-09-29 04:22:55.133 CQG WebAPI | Waiting for socket receive thread to end | 2021-09-29 04:22:55.135 DTC Client socket (2) | CloseSocket call. | 2021-09-29 04:22:55.135 CQG WebAPI | Disconnected. | 2021-09-29 04:22:55.135 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2021-09-29 04:22:55.135 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-09-29 04:22:55.144 DTC Client socket (2) | Closed. | 2021-09-29 04:22:55.144 CQG WebAPI | Connecting to the server 127.0.0.1. Port 11099 | 2021-09-29 04:23:08.689 DTC Client socket (1) | Creating socket. | 2021-09-29 04:23:08.689 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-09-29 04:23:08.689 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-09-29 04:23:08.689 CQG WebAPI | Network connection to server complete. | 2021-09-29 04:23:08.691 CQG WebAPI | Starting socket receive thread. | 2021-09-29 04:23:08.691 CQG WebAPI | Sending encoding request to server: Binary VLS. Compression: none | 2021-09-29 04:23:08.692 CQG WebAPI | Setting DTC encoding to Binary VLS | 2021-09-29 04:23:08.704 CQG WebAPI | Sending logon request message. | 2021-09-29 04:23:08.704 CQG WebAPI | Received logon response. | 2021-09-29 04:23:08.711 CQG WebAPI | Server Name: SC DTC Server. Build=38697M. | 2021-09-29 04:23:08.711 CQG WebAPI | Server protocol version: 8. Client protocol version: 8 | 2021-09-29 04:23:08.711 CQG WebAPI | Successfully connected. Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg. | 2021-09-29 04:23:08.711 CQG WebAPI | Trading is supported. | 2021-09-29 04:23:08.711 CQG WebAPI | Order cancel and replace is supported. | 2021-09-29 04:23:08.711 CQG WebAPI | OCO Orders supported. | 2021-09-29 04:23:08.711 CQG WebAPI | Bracket Orders supported. | 2021-09-29 04:23:08.711 CQG WebAPI | Connected to server complete. | 2021-09-29 04:23:08.711 Triggering next historical data download in queue. | 2021-09-29 04:23:08.712 Triggering next historical data download in queue. | 2021-09-29 04:23:08.712 Triggering next historical data download in queue. | 2021-09-29 04:23:08.712 Triggering next historical data download in queue. | 2021-09-29 04:23:08.712 No download requests in the queue to start downloads for. | 2021-09-29 04:23:08.713 No download requests in the queue to start downloads for. | 2021-09-29 04:23:08.713 No download requests in the queue to start downloads for. | 2021-09-29 04:23:08.713 No download requests in the queue to start downloads for. | 2021-09-29 04:23:08.713 CQG WebAPI | Starting real-time market data updates for: M2KZ21-CME. ID: 1 | 2021-09-29 04:23:08.714 CQG WebAPI | Requesting security definition data for: M2KZ21-CME. ID: 1 | 2021-09-29 04:23:08.714 Added historical Intraday data request for M2KZ21-CME to the queue. | 2021-09-29 04:23:08.714 Intraday data recording state for symbol M2KZ21-CME is set to download 'Pending'. | 2021-09-29 04:23:08.714 Triggering next historical data download in queue. | 2021-09-29 04:23:08.714 Delaying start of download for M2KZ21-CME | 2021-09-29 04:23:08.714 CQG WebAPI | Received security definition for symbol M2KZ21-CME | 2021-09-29 04:23:08.742 CQG WebAPI | Starting real-time market data updates for: NQZ21-CME. ID: 2 | 2021-09-29 04:23:08.742 CQG WebAPI | Requesting security definition data for: NQZ21-CME. ID: 2 | 2021-09-29 04:23:08.742 Added historical Intraday data request for NQZ21-CME to the queue. | 2021-09-29 04:23:08.742 Intraday data recording state for symbol NQZ21-CME is set to download 'Pending'. | 2021-09-29 04:23:08.742 Triggering next historical data download in queue. | 2021-09-29 04:23:08.742 CQG WebAPI | Received security definition for symbol NQZ21-CME | 2021-09-29 04:23:08.768 HD Request # 4 | Downloading Intraday chart data for M2KZ21-CME to the file M2KZ21-CME.scid. Service: DTCSubInstance | 2021-09-29 04:23:13.576 HD Request # 4 | Download start date-time: 2021-09-28 07:39:10.000000. File last date-time: 2021-09-28 07:39:10.293001 | 2021-09-29 04:23:13.577 HD Request # 4 | Using server: 127.0.0.1 port 11098 | 2021-09-29 04:23:13.577 Socket (2) | Creating socket. | 2021-09-29 04:23:13.577 Socket (2) | New receive buffer size: 5242880 | 2021-09-29 04:23:13.577 Socket (2) | Connecting to IP: 127.0.0.1. | 2021-09-29 04:23:13.577 HD Request # 4 | Setting DTC encoding to Binary VLS | 2021-09-29 04:23:13.585 HD Request # 4 | Sending historical data logon request message. | 2021-09-29 04:23:13.585 HD Request # 4 | Requesting Intraday data. Start date-time: 2021-09-28 07:39:10. Record interval: 0. Symbol: M2KZ21-CME | 2021-09-29 04:23:13.586 HD Request # 4 | Decompressing data. | 2021-09-29 04:23:13.588 HD Request # 4 | Receiving Intraday data for M2KZ21-CME starting at 2021-09-28 06:38:01.000000 | 2021-09-29 04:23:13.588 Socket (2) | CloseSocket call. | 2021-09-29 04:23:13.588 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-09-29 04:23:13.588 Historical data download thread signaled to stop. | 2021-09-29 04:23:13.588 HD Request # 4 | Received 61 Intraday data records from 2021-09-28 06:38:01.000000 to 2021-09-28 07:38:00.000000 (60.0 minutes) and wrote 0 records for M2KZ21-CME | 2021-09-29 04:23:13.588 Socket (2) | Socket gracefully closed by remote side. | 2021-09-29 04:23:13.589 Socket (2) | Closed. | 2021-09-29 04:23:13.589 HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2021-09-28 12:39:10.293001 | 2021-09-29 04:23:13.589 HD Request # 4 | Completion time: 0s | 2021-09-29 04:23:13.589 HD Request # 4 | Intraday data download complete for M2KZ21-CME. Unique request ID: 3 | 2021-09-29 04:23:13.589 Removing historical data download ID 3. | 2021-09-29 04:23:13.589 Real-time Intraday chart data file updates started for M2KZ21-CME | 2021-09-29 04:23:13.589 Intraday chart data file opened for M2KZ21-CME | 2021-09-29 04:23:13.589 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2021-09-29 04:23:13.589 Triggering next historical data download in queue. | 2021-09-29 04:23:13.589 HD Request # 5 | Downloading Intraday chart data for NQZ21-CME to the file NQZ21-CME.scid. Service: DTCSubInstance | 2021-09-29 04:23:13.589 HD Request # 5 | Download start date-time: 2021-09-28 07:39:12.000000. File last date-time: 2021-09-28 07:39:12.494000 | 2021-09-29 04:23:13.590 HD Request # 5 | Using server: 127.0.0.1 port 11098 | 2021-09-29 04:23:13.590 Socket (2) | Creating socket. | 2021-09-29 04:23:13.590 Socket (2) | New receive buffer size: 5242880 | 2021-09-29 04:23:13.590 Socket (2) | Connecting to IP: 127.0.0.1. | 2021-09-29 04:23:13.590 HD Request # 5 | Setting DTC encoding to Binary VLS | 2021-09-29 04:23:13.599 HD Request # 5 | Sending historical data logon request message. | 2021-09-29 04:23:13.599 HD Request # 5 | Requesting Intraday data. Start date-time: 2021-09-28 07:39:12. Record interval: 0. Symbol: NQZ21-CME | 2021-09-29 04:23:13.599 HD Request # 5 | Decompressing data. | 2021-09-29 04:23:13.601 HD Request # 5 | Receiving Intraday data for NQZ21-CME starting at 2021-09-28 06:38:00.000000 | 2021-09-29 04:23:13.601 Socket (2) | CloseSocket call. | 2021-09-29 04:23:13.601 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-09-29 04:23:13.601 Socket (2) | Socket gracefully closed by remote side. | 2021-09-29 04:23:13.601 Socket (2) | Closed. | 2021-09-29 04:23:13.601 Historical data download thread signaled to stop. | 2021-09-29 04:23:13.605 HD Request # 5 | Received 61 Intraday data records from 2021-09-28 06:38:00.000000 to 2021-09-28 07:38:00.000000 (60.0 minutes) and wrote 0 records for NQZ21-CME | 2021-09-29 04:23:13.605 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2021-09-28 12:39:12.494000 | 2021-09-29 04:23:13.605 HD Request # 5 | Completion time: 0s | 2021-09-29 04:23:13.605 HD Request # 5 | Intraday data download complete for NQZ21-CME. Unique request ID: 4 | 2021-09-29 04:23:13.605 Removing historical data download ID 4. | 2021-09-29 04:23:13.605 Real-time Intraday chart data file updates started for NQZ21-CME | 2021-09-29 04:23:13.605 Intraday chart data file opened for NQZ21-CME | 2021-09-29 04:23:13.605 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2021-09-29 04:23:13.605 Triggering next historical data download in queue. | 2021-09-29 04:23:13.605 No download requests in the queue to start downloads for. | 2021-09-29 04:23:13.605 |
| [2021-09-29 14:31:37] |
Yes, your analysis is correct. When you are switching services and you close the Data/Trade Service Settings window, it gives you the option to update the symbols, which it sounds like you are doing. But you are correct, this does not flow to the Sub-Instance, as these are completely separate. Therefore, you would need to change the symbols in the sub-instance "manually" after you make the change in the main instance. To do this in the sub-instance, open your chartbooks and select Edit >> Translate Symbols to Current Service. That will update the symbols in all of the charts at once. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
