Date/Time: Tue, 04 Nov 2025 14:40:53 +0000
How to use Trade Management Study & Parabolic SAR only for 2nd quantity of attached order?
View Count: 884
|   [2021-08-24 13:58:43]     |
| BenjaminR - Posts: 176 |
                Using attached orders "2TargetsWith BE Stop"... we want to use the fixed offset stop upon order entry, but after the 1st target is reached, using the Trade Management Study & the Parabolic study, for the 2nd quantity's stop order to only begin moving when the Parabolic "catches up" to it.  In other words, to just use the TMS & the Parabolic, often the entry will place the OCO attached stop just too far away. So the idea is that once the position is moving in our direction, not to risk more than if the position immediately moved against us... but trail as far as possible until stopped out by the attached order following the Parabolic SAR. But ONLY after the PSAR has caught up to the initial stop position. Please advise. Thank you! Date Time Of Last Edit: 2021-08-24 13:59:26
|   [2021-08-24 14:56:17]     |
                We will have to modify  the trade management study to support specifying an OCO Group number.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-08-24 15:26:56]     |
                That would be really great!!  I know you've got a long list, but please do! I have no doubt this is a feature that many users would appreciate!
|   [2021-08-25 06:44:54]     |
| User90125 - Posts: 715 |
                +1 Please set as a [Feature Request].  |
|   [2021-08-26 14:26:22]     |
                We should be able to have this out next week.
