Date/Time: Tue, 04 Nov 2025 10:47:10 +0000
alert
View Count: 502
|   [2021-07-14 15:59:23]     |
| User144295 - Posts: 74 |
                Hi Sierra Team, Alert on the dark orange line (pic 1) is setup as on the picture (pic 2). Desired behavior is that Alert goes ON only when Crossing or Equal from bottom or from top. But this logic is not considered and alert goes ON anytime. I tried also other options like Cross from Below or Above but no success. Would you please know what I setup incorrectly? Thank you very much  |
|   [2021-07-14 16:28:14]     |
| John - SC Support - Posts: 42737 |
                From what you show, the Alert should NOT be going off "all the time". So that has us confused.  But, for what you want, it sounds like you would really want to use the Last rather than the Entire Bar. That way, when the Last Price touches or crosses the line, the Alert will sound. Try this setup and see if it works more the way you expect. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
