Date/Time: Tue, 04 Nov 2025 12:43:35 +0000
Dis/RECon.
View Count: 1042
|   [2021-06-23 12:54:49]     |
| User664240 - Posts: 209 |
                I sent the Log...SC is disconnecting and reconnecting.
|   [2021-06-23 13:10:20]     |
                Guys any input would be appreciated. SC is basically useless while it continues to cycle through these disconnect reconnect cycles
|   [2021-06-23 14:29:58]     |
                I removed the MBO COLUMNS FROM THE DOM WHICH SEEMS TO HAVE STABILIZED SC I ALSO TURNED OFF THE SAVE MARKET DEPTH UNDER THE SYMBOL SETTINGS
|   [2021-06-23 14:49:20]     |
| John - SC Support - Posts: 42737 |
                We only see two disconnect messages in the log file you sent, which are the following: DTC Client socket (6) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
We think it may be related to what is described here in your case: Data and Trading Communications (DTC) Protocol Server: Troubleshooting Connection Problems to DTC Server We would really need to see the Message Log from one of the Sub-Instances to see if there is additional information in the Sub-Instance log. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-06-23 15:28:51]     |
                FIRST AND FOREMOST i SENT THE LOG ON THE FIRST DISCONNECT TO GIVE YOU A HEADS UP ...IT WAS CONTINUOUS.  SECOND THE SUBINSTANCE BELOW HAS BEEN EXITED AND RESTARTED SEVERAL TIMES.Reading Internal Order ID file. | 2021-06-23 09:34:10.439 Reading Trade Orders file. | 2021-06-23 09:34:10.454 Reading Trade Positions file. | 2021-06-23 09:34:10.454 Reading Trade Account Data files. | 2021-06-23 09:34:10.454 UDPListener (1120). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2021-06-23 09:34:10.470 Software version: 2276 64-bit | 2021-06-23 09:34:10.470 Safe Mode enabled | 2021-06-23 09:34:10.470 Primary Thread ID: 4112 | 2021-06-23 09:34:10.470 Usage end date: 2021-07-19 | 2021-06-23 09:34:10.470 Enabled for: Advanced Features 2. | 2021-06-23 09:34:10.470 Enabled for: Sierra Chart Historical Data Service. | 2021-06-23 09:34:10.470 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-23 09:34:10.470 Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-23 09:34:10.470 Enabled for exchange2: CME (Trading Account Required) | 2021-06-23 09:34:10.470 Enabled for exchange2: CBOT (Trading Account Required) | 2021-06-23 09:34:10.470 Enabled for exchange2: COMEX (Trading Account Required) | 2021-06-23 09:34:10.470 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-06-23 09:34:10.470 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-23 09:34:10.470 Current selected Data/Trading service: DTC - Sub Instance | 2021-06-23 09:34:10.470 Custom symbol settings values: enabled | 2021-06-23 09:34:10.470 Chart Update Interval: 100 | 2021-06-23 09:34:10.470 Intraday Data Storage Time Unit: 0 | 2021-06-23 09:34:10.470 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-06-23 09:34:10.470 2021-06-23 13:34:10 Local computer time in UTC | 2021-06-23 09:34:10.470 2021-06-23 09:34:10 Local computer time in SC Time Zone | 2021-06-23 09:34:10.470 2021-06-23 13:34:09 Server time in UTC | 2021-06-23 09:34:10.470 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-06-23 09:34:10.470 Program path: C:\SierraChart\SierraChartInstance_3\ | 2021-06-23 09:34:10.470 Data Files path: C:\SierraChart\SierraChartInstance_3\Data\ | 2021-06-23 09:34:10.470 OS Version Number: 6.1 | 2021-06-23 09:34:10.470 Locale Setting: C | 2021-06-23 09:34:10.470 DLLs: CrystalPalaceStudies_2217_64.dll, mboxhistogram_64.dll, Norvik_2151_64.dll, OFA Bars (by Zdislav)_2151_64.dll, Trade_Your_Plan_2151_64.dll, TradingriotSuite_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, zyp sierra free 2021_2151_64.dll, zyp sierra free_2151_64.dll | 2021-06-23 09:34:10.470 Allowed protected custom studies: zyp_app, zyp_download_free, zyp_download_free_2, zyp_mod_1 | 2021-06-23 09:34:10.470 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:34:10.486 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-06-23 09:34:10.579 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-06-23 09:34:10.579 Received 5 login tokens. | 2021-06-23 09:34:10.798 Requesting current DateTime from Sierra Chart server. | 2021-06-23 09:34:15.089 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-23 13:34:15.482. Round-trip delay: 00:00:00.195 | 2021-06-23 09:34:15.479 Computer time to server time difference: -00:00:00.002 | 2021-06-23 09:34:15.479 Successfully set the system Date-time to: 2021-06-23 13:34:15.482 UTC. | 2021-06-23 09:34:15.482 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:34:16.979 DTC Client socket (1) | Creating socket. | 2021-06-23 09:34:16.979 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:34:16.979 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Network connection to server complete. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Starting socket receive thread. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none | 2021-06-23 09:34:16.979 DTC - Sub Instance | Setting DTC encoding to Binary VLS | 2021-06-23 09:34:16.979 DTC - Sub Instance | Sending logon request message. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Received logon response. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Server Name: SC DTC Server. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 09:34:16.979 DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Trading is supported. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Order cancel and replace is supported. | 2021-06-23 09:34:16.979 DTC - Sub Instance | OCO Orders supported. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Bracket Orders supported. | 2021-06-23 09:34:16.979 DTC - Sub Instance | Connected to server complete. | 2021-06-23 09:34:16.979 Triggering next historical data download in queue. | 2021-06-23 09:34:16.979 Triggering next historical data download in queue. | 2021-06-23 09:34:16.979 Triggering next historical data download in queue. | 2021-06-23 09:34:16.979 Triggering next historical data download in queue. | 2021-06-23 09:34:16.979 No download requests in the queue to start downloads for. | 2021-06-23 09:34:16.979 No download requests in the queue to start downloads for. | 2021-06-23 09:34:16.979 No download requests in the queue to start downloads for. | 2021-06-23 09:34:16.979 No download requests in the queue to start downloads for. | 2021-06-23 09:34:16.979 NGN21-NYMEX 55 Min #1 | Reloading chart. | 2021-06-23 09:34:24.701 CLN21-NYMEX 55 Min #12 | Reloading chart. | 2021-06-23 09:34:24.701 ESU21-CME 240 Min #13 | Reloading chart. | 2021-06-23 09:34:24.717 ESU21-CME 30 Sec #3 | Reloading chart. | 2021-06-23 09:34:24.732 NGN21-NYMEX 30 Sec #8 | Reloading chart. | 2021-06-23 09:34:24.748 Loading market depth data. | 2021-06-23 09:34:24.795 ZSN21-CBOT 30 Sec #2 | Reloading chart. | 2021-06-23 09:34:24.842 Loading market depth data. | 2021-06-23 09:34:24.873 HGN21-COMEX 30 Sec #4 | Reloading chart. | 2021-06-23 09:34:24.888 NGN21-NYMEX 30 Min #5 | Reloading chart. | 2021-06-23 09:34:24.920 NGN21-NYMEX 5 Min #7 | Reloading chart. | 2021-06-23 09:34:24.951 Loaded depth data records for NGN21-NYMEX 2021-06-21 from 2021-06-21 14:30:00.000000 to 2021-06-21 19:59:59.976000. | 2021-06-23 09:34:24.966 Loading market depth data. | 2021-06-23 09:34:24.998 Loaded depth data records for HGN21-COMEX 2021-06-20 from 2021-06-20 18:07:00.849128 to 2021-06-20 19:59:54.315000. | 2021-06-23 09:34:25.013 ESU21-CME Point & Figure 1-12 #9 | Reloading chart. | 2021-06-23 09:34:25.013 Loading market depth data. | 2021-06-23 09:34:25.122 CLQ21-NYMEX 50 Volume #10 | Reloading chart. | 2021-06-23 09:34:25.232 SC Data - All Services | Starting real-time market data updates for: NGN21-NYMEX. ID: 1 | 2021-06-23 09:34:25.294 SC Data - All Services | Requesting security definition data for: NGN21-NYMEX. ID: 1 | 2021-06-23 09:34:25.294 Requesting market depth updates for: NGN21-NYMEX if supported. | 2021-06-23 09:34:25.294 SC Data - All Services | Starting market orders updates for: NGN21-NYMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:34:25.294 Starting DelayedDownloadMonitoringTimer | 2021-06-23 09:34:25.294 Starting HDTimeoutTimer | 2021-06-23 09:34:25.294 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 09:34:25.294 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 09:34:25.294 Triggering next historical data download in queue. | 2021-06-23 09:34:25.294 Delaying start of download for NGN21-NYMEX | 2021-06-23 09:34:25.294 SC Data - All Services | Starting real-time market data updates for: HGN21-COMEX. ID: 2 | 2021-06-23 09:34:25.325 SC Data - All Services | Requesting security definition data for: HGN21-COMEX. ID: 2 | 2021-06-23 09:34:25.325 Requesting market depth updates for: HGN21-COMEX if supported. | 2021-06-23 09:34:25.325 SC Data - All Services | Starting market orders updates for: HGN21-COMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:34:25.325 Added historical Intraday data request for HGN21-COMEX to the queue. | 2021-06-23 09:34:25.325 Intraday data recording state for symbol HGN21-COMEX is set to download 'Pending'. | 2021-06-23 09:34:25.325 Triggering next historical data download in queue. | 2021-06-23 09:34:25.325 Loaded depth data records for ESU21-CME 2021-06-21 from 2021-06-21 16:15:00.000000 to 2021-06-21 19:59:59.976000. | 2021-06-23 09:34:25.356 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 09:34:25.372 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\NGN21-NYMEX.2021-06-23.depth | 2021-06-23 09:34:25.403 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 09:34:25.403 SC Data - All Services | Starting real-time market data updates for: ESU21-CME. ID: 3 | 2021-06-23 09:34:25.403 SC Data - All Services | Requesting security definition data for: ESU21-CME. ID: 3 | 2021-06-23 09:34:25.403 Requesting market depth updates for: ESU21-CME if supported. | 2021-06-23 09:34:25.403 SC Data - All Services | Starting market orders updates for: ESU21-CME. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:34:25.403 Added historical Intraday data request for ESU21-CME to the queue. | 2021-06-23 09:34:25.403 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-06-23 09:34:25.403 Triggering next historical data download in queue. | 2021-06-23 09:34:25.403 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 09:34:25.403 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\HGN21-COMEX.2021-06-23.depth | 2021-06-23 09:34:25.403 SC Data - All Services | Starting real-time market data updates for: CLN21-NYMEX. ID: 4 | 2021-06-23 09:34:25.403 SC Data - All Services | Requesting security definition data for: CLN21-NYMEX. ID: 4 | 2021-06-23 09:34:25.403 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-23 09:34:25.403 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-23 09:34:25.403 Triggering next historical data download in queue. | 2021-06-23 09:34:25.403 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 09:34:25.403 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 09:34:25.419 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 09:34:25.434 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\ESU21-CME.2021-06-23.depth | 2021-06-23 09:34:25.434 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 09:34:25.434 SC Data - All Services | Starting real-time market data updates for: ZSN21-CBOT. ID: 5 | 2021-06-23 09:34:25.434 SC Data - All Services | Requesting security definition data for: ZSN21-CBOT. ID: 5 | 2021-06-23 09:34:25.434 Requesting market depth updates for: ZSN21-CBOT if supported. | 2021-06-23 09:34:25.434 SC Data - All Services | Starting market orders updates for: ZSN21-CBOT. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:34:25.434 Added historical Intraday data request for ZSN21-CBOT to the queue. | 2021-06-23 09:34:25.434 Intraday data recording state for symbol ZSN21-CBOT is set to download 'Pending'. | 2021-06-23 09:34:25.434 Triggering next historical data download in queue. | 2021-06-23 09:34:25.434 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 09:34:25.434 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 09:34:25.434 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\ZSN21-CBOT.2021-06-23.depth | 2021-06-23 09:34:25.434 SC Data - All Services | Starting real-time market data updates for: CLQ21-NYMEX. ID: 6 | 2021-06-23 09:34:25.450 SC Data - All Services | Requesting security definition data for: CLQ21-NYMEX. ID: 6 | 2021-06-23 09:34:25.450 Requesting market depth updates for: CLQ21-NYMEX if supported. | 2021-06-23 09:34:25.450 SC Data - All Services | Starting market orders updates for: CLQ21-NYMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:34:25.450 Added historical Intraday data request for CLQ21-NYMEX to the queue. | 2021-06-23 09:34:25.450 Intraday data recording state for symbol CLQ21-NYMEX is set to download 'Pending'. | 2021-06-23 09:34:25.450 Triggering next historical data download in queue. | 2021-06-23 09:34:25.450 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 09:34:25.450 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 09:34:25.450 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\CLQ21-NYMEX.2021-06-23.depth | 2021-06-23 09:34:25.450 Loading market depth data. | 2021-06-23 09:34:25.590 Loaded depth data records for CLQ21-NYMEX 2021-06-20 from 2021-06-20 18:07:01.031130 to 2021-06-20 19:59:59.098000. | 2021-06-23 09:34:25.684 Loading market depth data. | 2021-06-23 09:34:25.762 NGN21-NYMEX 30 Min #5 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:25.887 Loaded depth data records for ESU21-CME 2021-06-21 from 2021-06-21 16:15:00.000000 to 2021-06-21 19:59:59.976000. | 2021-06-23 09:34:25.965 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 09:34:26.214 SC Data - All Services | Real-time data for symbol CLN21-NYMEX has been restored. | 2021-06-23 09:34:26.214 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 09:34:26.214 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 09:34:26.214 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 09:34:26.214 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 09:34:26.214 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 09:34:26.214 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 09:34:26.214 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 09:34:26.214 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 09:34:26.214 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 09:34:26.214 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 09:34:26.370 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 09:34:26.370 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 09:34:26.370 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 09:34:26.433 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 09:34:26.433 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 09:34:26.433 Loaded depth data records for ZSN21-CBOT 2021-06-22 from 2021-06-21 20:00:00.048000 to 2021-06-22 14:19:59.963000. | 2021-06-23 09:34:26.542 Loaded depth data records for NGN21-NYMEX 2021-06-22 from 2021-06-21 20:00:00.016000 to 2021-06-22 19:59:59.822000. | 2021-06-23 09:34:26.542 Loaded depth data records for ZSN21-CBOT 2021-06-23 from 2021-06-22 20:00:00.053000 to 2021-06-23 09:33:08.395000. | 2021-06-23 09:34:26.963 ZSN21-CBOT 30 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:26.963 ZSN21-CBOT 30 Sec #2 | Reloading chart. | 2021-06-23 09:34:27.026 Loading market depth data. | 2021-06-23 09:34:27.026 Loaded depth data records for HGN21-COMEX 2021-06-21 from 2021-06-20 20:00:00.194000 to 2021-06-21 19:59:59.846000. | 2021-06-23 09:34:27.041 Loaded depth data records for NGN21-NYMEX 2021-06-23 from 2021-06-22 20:00:00.057000 to 2021-06-23 09:33:08.211000. | 2021-06-23 09:34:27.088 NGN21-NYMEX 30 Sec #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:27.088 NGN21-NYMEX 30 Sec #8 | Reloading chart. | 2021-06-23 09:34:27.150 Loading market depth data. | 2021-06-23 09:34:27.166 Loaded depth data records for NGN21-NYMEX 2021-06-21 from 2021-06-21 14:30:00.000000 to 2021-06-21 19:59:59.976000. | 2021-06-23 09:34:27.322 Loaded depth data records for ZSN21-CBOT 2021-06-22 from 2021-06-21 20:00:00.048000 to 2021-06-22 14:19:59.963000. | 2021-06-23 09:34:28.336 Loaded depth data records for NGN21-NYMEX 2021-06-22 from 2021-06-21 20:00:00.016000 to 2021-06-22 19:59:59.822000. | 2021-06-23 09:34:28.523 Loaded depth data records for ZSN21-CBOT 2021-06-23 from 2021-06-22 20:00:00.053000 to 2021-06-23 09:33:08.395000. | 2021-06-23 09:34:28.679 ZSN21-CBOT 30 Sec #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:28.679 Loaded depth data records for HGN21-COMEX 2021-06-22 from 2021-06-21 20:00:00.228000 to 2021-06-22 19:59:59.959000. | 2021-06-23 09:34:28.851 Loaded depth data records for NGN21-NYMEX 2021-06-23 from 2021-06-22 20:00:00.057000 to 2021-06-23 09:33:08.211000. | 2021-06-23 09:34:29.007 NGN21-NYMEX 30 Sec #8 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:29.007 Loaded depth data records for HGN21-COMEX 2021-06-23 from 2021-06-22 20:00:00.005000 to 2021-06-23 09:33:10.111000. | 2021-06-23 09:34:29.568 HGN21-COMEX 30 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:29.568 Chart #4 has tagged chart #5 for full recalculation. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 09:34:29.568 HGN21-COMEX 30 Sec #4 | Reloading chart. | 2021-06-23 09:34:29.584 Loading market depth data. | 2021-06-23 09:34:29.631 Loaded depth data records for HGN21-COMEX 2021-06-20 from 2021-06-20 18:07:00.849128 to 2021-06-20 19:59:54.315000. | 2021-06-23 09:34:29.662 HD Request # 1 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 09:34:30.364 HD Request # 1 | Download start date-time: 2021-06-23 09:33:08.000000. File last date-time: 2021-06-23 09:33:08.211001 | 2021-06-23 09:34:30.364 HD Request # 1 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 09:34:30.364 Socket (2) | Creating socket. | 2021-06-23 09:34:30.364 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 09:34:30.364 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-23 09:34:30.364 HD Request # 1 | Setting DTC encoding to Binary VLS | 2021-06-23 09:34:30.426 HD Request # 1 | Sending historical data logon request message. | 2021-06-23 09:34:30.426 HD Request # 1 | Requesting Intraday data. Start date-time: 2021-06-23 09:33:08. Record interval: 0. Symbol: NGN21 | 2021-06-23 09:34:30.926 HD Request # 1 | Decompressing data. | 2021-06-23 09:34:30.957 HD Request # 1 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 09:33:08.211000 | 2021-06-23 09:34:30.957 Socket (2) | CloseSocket call. | 2021-06-23 09:34:30.957 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:34:30.957 Historical data download thread signaled to stop. | 2021-06-23 09:34:30.957 HD Request # 1 | Timestamp of first Intraday data file record written: 2021-06-23 09:33:15.456000 | 2021-06-23 09:34:30.957 HD Request # 1 | Received 139 records from 2021-06-23 09:33:08.211000 to 2021-06-23 09:34:24.840000 (76.6 seconds) and wrote 137 records for NGN21-NYMEX | 2021-06-23 09:34:30.957 HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:34:24.840000 | 2021-06-23 09:34:30.957 HD Request # 1 | Completion time: 0s | 2021-06-23 09:34:30.957 HD Request # 1 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 1 | 2021-06-23 09:34:30.957 Removing historical data download ID 1. | 2021-06-23 09:34:30.957 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 09:34:30.957 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 09:34:30.957 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:34:30.957 Triggering next historical data download in queue. | 2021-06-23 09:34:30.957 HD Request # 2 | Downloading Intraday chart data for HGN21-COMEX to the file HGN21-COMEX.scid. Service: comex | 2021-06-23 09:34:30.957 HD Request # 2 | Download start date-time: 2021-06-23 09:33:10.000000. File last date-time: 2021-06-23 09:33:10.111000 | 2021-06-23 09:34:30.957 HD Request # 2 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 09:34:30.957 Socket (3) | Creating socket. | 2021-06-23 09:34:30.957 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 09:34:30.957 Socket (3) | Connecting to IP: 216.1.90.129. | 2021-06-23 09:34:30.957 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 09:34:30.988 Socket (2) | Closed. | 2021-06-23 09:34:30.988 HD Request # 2 | Setting DTC encoding to Binary VLS | 2021-06-23 09:34:31.019 HD Request # 2 | Sending historical data logon request message. | 2021-06-23 09:34:31.019 Loaded depth data records for HGN21-COMEX 2021-06-21 from 2021-06-20 20:00:00.194000 to 2021-06-21 19:59:59.846000. | 2021-06-23 09:34:31.050 Loaded depth data records for ESU21-CME 2021-06-22 from 2021-06-21 20:00:00.002000 to 2021-06-22 19:59:59.988000. | 2021-06-23 09:34:31.284 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-06-23 09:33:10. Record interval: 0. Symbol: HGN21 | 2021-06-23 09:34:31.518 HD Request # 2 | Decompressing data. | 2021-06-23 09:34:31.550 HD Request # 2 | Receiving Intraday data for HGN21-COMEX starting at 2021-06-23 09:33:10.110000 | 2021-06-23 09:34:31.550 Socket (3) | CloseSocket call. | 2021-06-23 09:34:31.550 Historical data download thread signaled to stop. | 2021-06-23 09:34:31.550 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:34:31.550 HD Request # 2 | Timestamp of first Intraday data file record written: 2021-06-23 09:33:11.045000 | 2021-06-23 09:34:31.550 HD Request # 2 | Received 318 records from 2021-06-23 09:33:10.110000 to 2021-06-23 09:34:30.077000 (80.0 seconds) and wrote 316 records for HGN21-COMEX | 2021-06-23 09:34:31.550 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:34:30.077000 | 2021-06-23 09:34:31.550 HD Request # 2 | Completion time: 1s | 2021-06-23 09:34:31.550 HD Request # 2 | Intraday data download complete for HGN21-COMEX. Unique request ID: 2 | 2021-06-23 09:34:31.550 Removing historical data download ID 2. | 2021-06-23 09:34:31.550 Real-time Intraday chart data file updates started for HGN21-COMEX | 2021-06-23 09:34:31.550 Intraday chart data file opened for HGN21-COMEX | 2021-06-23 09:34:31.550 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:34:31.550 Triggering next historical data download in queue. | 2021-06-23 09:34:31.550 HD Request # 3 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-06-23 09:34:31.550 HD Request # 3 | Download start date-time: 2021-06-23 09:33:10.000000. File last date-time: 2021-06-23 09:33:10.123000 | 2021-06-23 09:34:31.550 HD Request # 3 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 09:34:31.550 Socket (2) | Creating socket. | 2021-06-23 09:34:31.550 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 09:34:31.550 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-23 09:34:31.550 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 09:34:31.581 Socket (3) | Closed. | 2021-06-23 09:34:31.581 HD Request # 3 | Setting DTC encoding to Binary VLS | 2021-06-23 09:34:31.628 HD Request # 3 | Sending historical data logon request message. | 2021-06-23 09:34:31.628 HD Request # 3 | Requesting Intraday data. Start date-time: 2021-06-23 09:33:10. Record interval: 0. Symbol: ESU21 | 2021-06-23 09:34:31.659 HD Request # 3 | Decompressing data. | 2021-06-23 09:34:31.674 Loaded depth data records for ESU21-CME 2021-06-22 from 2021-06-21 20:00:00.002000 to 2021-06-22 19:59:59.988000. | 2021-06-23 09:34:31.737 HD Request # 3 | Receiving Intraday data for ESU21-CME starting at 2021-06-23 09:33:10.019000 | 2021-06-23 09:34:31.752 Socket (2) | CloseSocket call. | 2021-06-23 09:34:31.752 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:34:31.752 Historical data download thread signaled to stop. | 2021-06-23 09:34:31.752 HD Request # 3 | Timestamp of first Intraday data file record written: 2021-06-23 09:33:10.391000 | 2021-06-23 09:34:31.752 HD Request # 3 | Received 3413 records from 2021-06-23 09:33:10.019000 to 2021-06-23 09:34:28.791000 (78.8 seconds) and wrote 3373 records for ESU21-CME | 2021-06-23 09:34:31.752 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:34:28.791000 | 2021-06-23 09:34:31.752 Added 96 Time and Sales records to Intraday data file for ESU21-CME after download. | 2021-06-23 09:34:31.752 HD Request # 3 | Completion time: 0s | 2021-06-23 09:34:31.752 HD Request # 3 | Intraday data download complete for ESU21-CME. Unique request ID: 3 | 2021-06-23 09:34:31.752 Removing historical data download ID 3. | 2021-06-23 09:34:31.752 Real-time Intraday chart data file updates started for ESU21-CME | 2021-06-23 09:34:31.752 Intraday chart data file opened for ESU21-CME | 2021-06-23 09:34:31.752 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:34:31.752 Triggering next historical data download in queue. | 2021-06-23 09:34:31.752 HD Request # 4 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-23 09:34:31.752 HD Request # 4 | Download start date-time: 2021-06-22 14:29:46.000000. File last date-time: 2021-06-22 14:29:46.813000 | 2021-06-23 09:34:31.752 HD Request # 4 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 09:34:31.752 Socket (3) | Creating socket. | 2021-06-23 09:34:31.752 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 09:34:31.752 Socket (3) | Connecting to IP: 216.1.90.129. | 2021-06-23 09:34:31.752 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 09:34:31.784 Socket (2) | Closed. | 2021-06-23 09:34:31.784 HD Request # 4 | Setting DTC encoding to Binary VLS | 2021-06-23 09:34:31.815 HD Request # 4 | Sending historical data logon request message. | 2021-06-23 09:34:31.815 HD Request # 4 | Requesting Intraday data. Start date-time: 2021-06-22 14:29:46. Record interval: 0. Symbol: CLN21 | 2021-06-23 09:34:31.846 HD Request # 4 | Decompressing data. | 2021-06-23 09:34:31.877 HD Request # 4 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-22 14:29:46.813000 | 2021-06-23 09:34:31.877 Socket (3) | CloseSocket call. | 2021-06-23 09:34:31.877 Historical data download thread signaled to stop. | 2021-06-23 09:34:31.877 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:34:31.877 HD Request # 4 | Received 1 record from 2021-06-22 14:29:46.813000 to 2021-06-22 14:29:46.813000 (0.0 seconds) and wrote 0 records for CLN21-NYMEX | 2021-06-23 09:34:31.877 HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2021-06-22 18:29:46.813000 | 2021-06-23 09:34:31.877 HD Request # 4 | Completion time: 0s | 2021-06-23 09:34:31.877 HD Request # 4 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 4 | 2021-06-23 09:34:31.877 Removing historical data download ID 4. | 2021-06-23 09:34:31.877 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-23 09:34:31.877 Intraday chart data file opened for CLN21-NYMEX | 2021-06-23 09:34:31.877 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:34:31.877 Triggering next historical data download in queue. | 2021-06-23 09:34:31.877 HD Request # 5 | Downloading Intraday chart data for ZSN21-CBOT to the file ZSN21-CBOT.scid. Service: cbot | 2021-06-23 09:34:31.877 HD Request # 5 | Download start date-time: 2021-06-23 09:33:08.000000. File last date-time: 2021-06-23 09:33:08.395000 | 2021-06-23 09:34:31.877 HD Request # 5 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 09:34:31.877 Socket (2) | Creating socket. | 2021-06-23 09:34:31.877 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 09:34:31.877 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-23 09:34:31.877 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 09:34:31.908 Socket (3) | Closed. | 2021-06-23 09:34:31.908 HD Request # 5 | Setting DTC encoding to Binary VLS | 2021-06-23 09:34:31.955 HD Request # 5 | Sending historical data logon request message. | 2021-06-23 09:34:31.955 HD Request # 5 | Requesting Intraday data. Start date-time: 2021-06-23 09:33:08. Record interval: 0. Symbol: ZSN21 | 2021-06-23 09:34:31.971 HD Request # 5 | Decompressing data. | 2021-06-23 09:34:32.002 HD Request # 5 | Receiving Intraday data for ZSN21-CBOT starting at 2021-06-23 09:33:08.269000 | 2021-06-23 09:34:32.002 Socket (2) | CloseSocket call. | 2021-06-23 09:34:32.002 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:34:32.002 Historical data download thread signaled to stop. | 2021-06-23 09:34:32.002 HD Request # 5 | Timestamp of first Intraday data file record written: 2021-06-23 09:33:12.733000 | 2021-06-23 09:34:32.002 HD Request # 5 | Received 104 records from 2021-06-23 09:33:08.269000 to 2021-06-23 09:34:29.326002 (81.1 seconds) and wrote 102 records for ZSN21-CBOT | 2021-06-23 09:34:32.002 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:34:29.326002 | 2021-06-23 09:34:32.018 HD Request # 5 | Completion time: 1s | 2021-06-23 09:34:32.018 HD Request # 5 | Intraday data download complete for ZSN21-CBOT. Unique request ID: 5 | 2021-06-23 09:34:32.018 Removing historical data download ID 5. | 2021-06-23 09:34:32.018 Real-time Intraday chart data file updates started for ZSN21-CBOT | 2021-06-23 09:34:32.018 Intraday chart data file opened for ZSN21-CBOT | 2021-06-23 09:34:32.018 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:34:32.018 Triggering next historical data download in queue. | 2021-06-23 09:34:32.018 HD Request # 6 | Downloading Intraday chart data for CLQ21-NYMEX to the file CLQ21-NYMEX.scid. Service: nymex | 2021-06-23 09:34:32.018 HD Request # 6 | Download start date-time: 2021-06-23 09:33:09.000000. File last date-time: 2021-06-23 09:33:09.077000 | 2021-06-23 09:34:32.018 HD Request # 6 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 09:34:32.018 Socket (3) | Creating socket. | 2021-06-23 09:34:32.018 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 09:34:32.018 Socket (3) | Connecting to IP: 216.1.90.129. | 2021-06-23 09:34:32.018 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 09:34:32.049 Socket (2) | Closed. | 2021-06-23 09:34:32.049 HD Request # 6 | Setting DTC encoding to Binary VLS | 2021-06-23 09:34:32.080 HD Request # 6 | Sending historical data logon request message. | 2021-06-23 09:34:32.080 HD Request # 6 | Requesting Intraday data. Start date-time: 2021-06-23 09:33:09. Record interval: 0. Symbol: CLQ21 | 2021-06-23 09:34:32.111 HD Request # 6 | Decompressing data. | 2021-06-23 09:34:32.142 HD Request # 6 | Receiving Intraday data for CLQ21-NYMEX starting at 2021-06-23 09:33:09.077000 | 2021-06-23 09:34:32.142 Socket (3) | CloseSocket call. | 2021-06-23 09:34:32.142 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:34:32.142 Historical data download thread signaled to stop. | 2021-06-23 09:34:32.142 HD Request # 6 | Timestamp of first Intraday data file record written: 2021-06-23 09:33:12.809000 | 2021-06-23 09:34:32.142 HD Request # 6 | Received 760 records from 2021-06-23 09:33:09.077000 to 2021-06-23 09:34:26.915002 (77.8 seconds) and wrote 759 records for CLQ21-NYMEX | 2021-06-23 09:34:32.142 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:34:26.915002 | 2021-06-23 09:34:32.142 Added 27 Time and Sales records to Intraday data file for CLQ21-NYMEX after download. | 2021-06-23 09:34:32.142 HD Request # 6 | Completion time: 0s | 2021-06-23 09:34:32.158 HD Request # 6 | Intraday data download complete for CLQ21-NYMEX. Unique request ID: 6 | 2021-06-23 09:34:32.158 Removing historical data download ID 6. | 2021-06-23 09:34:32.158 Real-time Intraday chart data file updates started for CLQ21-NYMEX | 2021-06-23 09:34:32.158 Intraday chart data file opened for CLQ21-NYMEX | 2021-06-23 09:34:32.158 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:34:32.158 Triggering next historical data download in queue. | 2021-06-23 09:34:32.158 No download requests in the queue to start downloads for. | 2021-06-23 09:34:32.158 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 09:34:32.174 Socket (3) | Closed. | 2021-06-23 09:34:32.174 Loaded depth data records for HGN21-COMEX 2021-06-22 from 2021-06-21 20:00:00.228000 to 2021-06-22 19:59:59.959000. | 2021-06-23 09:34:32.205 Loaded depth data records for ESU21-CME 2021-06-23 from 2021-06-22 20:00:00.003000 to 2021-06-23 09:33:10.123000. | 2021-06-23 09:34:32.408 Loaded depth data records for CLQ21-NYMEX 2021-06-21 from 2021-06-20 20:00:00.090000 to 2021-06-21 19:59:59.848000. | 2021-06-23 09:34:32.517 Loaded depth data records for HGN21-COMEX 2021-06-23 from 2021-06-22 20:00:00.005000 to 2021-06-23 09:33:10.111000. | 2021-06-23 09:34:32.782 HGN21-COMEX 30 Sec #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:32.782 Loaded depth data records for ESU21-CME 2021-06-23 from 2021-06-22 20:00:00.003000 to 2021-06-23 09:33:10.123000. | 2021-06-23 09:34:32.876 ESU21-CME 30 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:32.876 ESU21-CME 30 Sec #3 | Reloading chart. | 2021-06-23 09:34:32.922 Loading market depth data. | 2021-06-23 09:34:33.172 Loaded depth data records for ESU21-CME 2021-06-21 from 2021-06-21 16:15:00.000000 to 2021-06-21 19:59:59.976000. | 2021-06-23 09:34:33.266 Loaded depth data records for CLQ21-NYMEX 2021-06-22 from 2021-06-21 20:00:00.016000 to 2021-06-22 19:59:59.959000. | 2021-06-23 09:34:34.233 Loaded depth data records for CLQ21-NYMEX 2021-06-23 from 2021-06-22 20:00:00.003000 to 2021-06-23 09:33:09.077000. | 2021-06-23 09:34:34.841 CLQ21-NYMEX 50 Volume #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:34.841 CLQ21-NYMEX 50 Volume #10 | Reloading chart. | 2021-06-23 09:34:34.950 Loading market depth data. | 2021-06-23 09:34:35.138 Loaded depth data records for CLQ21-NYMEX 2021-06-20 from 2021-06-20 18:07:01.031130 to 2021-06-20 19:59:59.098000. | 2021-06-23 09:34:35.153 Loaded depth data records for ESU21-CME 2021-06-22 from 2021-06-21 20:00:00.002000 to 2021-06-22 19:59:59.988000. | 2021-06-23 09:34:35.543 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\NGN21-NYMEX.scid. Thread ID: 5936 | 2021-06-23 09:34:35.824 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\HGN21-COMEX.scid. Thread ID: 5936 | 2021-06-23 09:34:35.824 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\ESU21-CME.scid. Thread ID: 5936 | 2021-06-23 09:34:35.824 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\ZSN21-CBOT.scid. Thread ID: 5936 | 2021-06-23 09:34:35.824 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\CLQ21-NYMEX.scid. Thread ID: 5936 | 2021-06-23 09:34:35.824 Loaded depth data records for ESU21-CME 2021-06-23 from 2021-06-22 20:00:00.003000 to 2021-06-23 09:34:31.305000. | 2021-06-23 09:34:36.183 ESU21-CME 30 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:36.183 Loaded depth data records for CLQ21-NYMEX 2021-06-21 from 2021-06-20 20:00:00.090000 to 2021-06-21 19:59:59.848000. | 2021-06-23 09:34:36.776 Loaded depth data records for CLQ21-NYMEX 2021-06-22 from 2021-06-21 20:00:00.016000 to 2021-06-22 19:59:59.959000. | 2021-06-23 09:34:38.055 Loaded depth data records for CLQ21-NYMEX 2021-06-23 from 2021-06-22 20:00:00.003000 to 2021-06-23 09:34:31.095000. | 2021-06-23 09:34:38.554 CLQ21-NYMEX 50 Volume #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 09:34:38.554 NGN21-NYMEX 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 09:34:38.570 SC Data - All Services | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-23 09:43:11.722 SC Data - All Services | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-23 09:43:11.722 SC Data - All Services | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-23 09:43:11.738 SC Data - All Services | Real-time data for symbol CLN21-NYMEX is currently unavailable. | 2021-06-23 09:43:11.738 SC Data - All Services | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-23 09:43:11.738 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-23 09:43:11.754 SC Data - All Services | Market data feed reported to be lost. | 2021-06-23 09:43:11.754 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-23 09:43:11.769 DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:11.769 Connection to the external service has been lost. | 2021-06-23 09:43:11.769 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 09:43:11.769 DTC Client socket (1) | Closed. | 2021-06-23 09:43:11.769 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-23 09:43:11.785 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:11.785 SC Data - All Services | Disconnected. | 2021-06-23 09:43:11.816 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:11.816 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:14.827 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:14.827 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:14.827 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:14.827 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:15.841 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:15.841 DTC Client socket (1) | Closed. | 2021-06-23 09:43:15.841 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:15.841 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:15.841 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:15.856 SC Data - All Services | Disconnected. | 2021-06-23 09:43:15.856 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:15.856 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:18.867 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:18.867 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:18.867 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:18.867 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:19.897 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:19.897 DTC Client socket (1) | Closed. | 2021-06-23 09:43:19.897 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:19.897 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:19.897 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:19.912 SC Data - All Services | Disconnected. | 2021-06-23 09:43:19.912 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:19.912 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:22.923 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:22.923 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:22.923 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:22.923 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:23.937 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:23.937 DTC Client socket (1) | Closed. | 2021-06-23 09:43:23.937 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:23.937 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:23.937 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:23.953 SC Data - All Services | Disconnected. | 2021-06-23 09:43:23.953 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:23.953 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:26.964 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:26.964 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:26.964 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:26.964 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:27.993 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:27.993 DTC Client socket (1) | Closed. | 2021-06-23 09:43:27.993 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:27.993 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:27.993 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:28.009 SC Data - All Services | Disconnected. | 2021-06-23 09:43:28.009 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:28.009 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:31.020 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:31.020 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:31.020 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:31.020 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:32.034 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:32.034 DTC Client socket (1) | Closed. | 2021-06-23 09:43:32.034 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:32.034 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:32.034 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:32.049 SC Data - All Services | Disconnected. | 2021-06-23 09:43:32.049 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:32.049 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:35.060 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:35.060 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:35.060 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:35.060 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:36.074 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:36.074 DTC Client socket (1) | Closed. | 2021-06-23 09:43:36.074 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:36.074 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:36.074 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:36.090 SC Data - All Services | Disconnected. | 2021-06-23 09:43:36.090 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:36.090 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:39.100 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:39.100 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:39.100 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:39.100 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:40.114 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:40.114 DTC Client socket (1) | Closed. | 2021-06-23 09:43:40.114 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:40.114 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:40.114 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:40.130 SC Data - All Services | Disconnected. | 2021-06-23 09:43:40.130 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:40.130 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:43.141 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:43.141 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:43.141 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:43.141 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:44.155 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:44.155 DTC Client socket (1) | Closed. | 2021-06-23 09:43:44.155 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:44.155 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:44.155 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:44.170 SC Data - All Services | Disconnected. | 2021-06-23 09:43:44.170 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:44.170 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:47.181 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:47.181 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:47.181 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:47.181 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:48.211 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:48.211 DTC Client socket (1) | Closed. | 2021-06-23 09:43:48.211 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:48.211 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:48.211 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:48.226 SC Data - All Services | Disconnected. | 2021-06-23 09:43:48.226 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:48.226 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:51.237 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:51.237 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:51.237 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:51.237 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:52.267 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:52.267 DTC Client socket (1) | Closed. | 2021-06-23 09:43:52.267 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:52.267 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:52.267 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:52.282 SC Data - All Services | Disconnected. | 2021-06-23 09:43:52.282 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:52.282 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:55.293 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:55.293 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:55.293 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:55.293 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:43:56.292 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:43:56.292 DTC Client socket (1) | Closed. | 2021-06-23 09:43:56.292 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:43:56.292 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:56.292 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:43:56.307 SC Data - All Services | Disconnected. | 2021-06-23 09:43:56.307 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:43:56.307 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:43:59.318 DTC Client socket (1) | Creating socket. | 2021-06-23 09:43:59.318 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:43:59.318 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:43:59.318 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:00.348 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:00.348 DTC Client socket (1) | Closed. | 2021-06-23 09:44:00.348 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:00.348 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:00.348 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:00.363 SC Data - All Services | Disconnected. | 2021-06-23 09:44:00.363 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:00.363 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:03.374 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:03.374 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:03.374 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:03.374 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:04.373 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:04.373 DTC Client socket (1) | Closed. | 2021-06-23 09:44:04.373 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:04.373 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:04.373 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:04.388 SC Data - All Services | Disconnected. | 2021-06-23 09:44:04.388 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:04.388 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:07.399 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:07.399 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:07.399 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:07.399 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:08.429 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:08.429 DTC Client socket (1) | Closed. | 2021-06-23 09:44:08.429 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:08.429 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:08.429 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:08.444 SC Data - All Services | Disconnected. | 2021-06-23 09:44:08.444 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:08.444 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:11.455 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:11.455 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:11.455 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:11.455 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:12.453 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:12.453 DTC Client socket (1) | Closed. | 2021-06-23 09:44:12.453 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:12.453 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:12.453 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:12.469 SC Data - All Services | Disconnected. | 2021-06-23 09:44:12.469 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:12.469 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:15.480 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:15.480 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:15.480 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:15.480 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:16.509 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:16.509 DTC Client socket (1) | Closed. | 2021-06-23 09:44:16.509 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:16.509 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:16.509 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:16.525 SC Data - All Services | Disconnected. | 2021-06-23 09:44:16.525 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:16.525 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:19.536 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:19.536 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:19.536 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:19.536 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:20.550 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:20.550 DTC Client socket (1) | Closed. | 2021-06-23 09:44:20.550 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:20.550 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:20.550 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:20.565 SC Data - All Services | Disconnected. | 2021-06-23 09:44:20.565 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:20.565 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:23.576 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:23.576 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:23.576 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:23.576 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:24.606 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:24.606 DTC Client socket (1) | Closed. | 2021-06-23 09:44:24.606 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:24.606 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:24.606 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:24.621 SC Data - All Services | Disconnected. | 2021-06-23 09:44:24.621 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:24.621 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:27.632 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:27.632 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:27.632 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:27.632 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:28.646 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:28.646 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:28.646 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:28.646 DTC Client socket (1) | Closed. | 2021-06-23 09:44:28.646 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:28.662 SC Data - All Services | Disconnected. | 2021-06-23 09:44:28.662 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:28.662 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:31.673 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:31.673 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:31.673 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:31.673 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:32.687 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:32.687 DTC Client socket (1) | Closed. | 2021-06-23 09:44:32.687 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:32.687 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:32.687 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:32.702 SC Data - All Services | Disconnected. | 2021-06-23 09:44:32.702 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:32.702 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:35.713 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:35.713 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:35.713 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:35.713 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:36.727 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:36.727 DTC Client socket (1) | Closed. | 2021-06-23 09:44:36.727 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:36.727 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:36.727 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:36.743 SC Data - All Services | Disconnected. | 2021-06-23 09:44:36.743 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:36.743 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:39.753 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:39.753 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:39.753 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:39.753 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:40.783 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:40.783 DTC Client socket (1) | Closed. | 2021-06-23 09:44:40.783 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:40.783 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:40.783 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:40.799 SC Data - All Services | Disconnected. | 2021-06-23 09:44:40.799 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:40.799 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:43.809 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:43.809 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:43.809 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:43.809 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 09:44:44.839 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 09:44:44.839 DTC Client socket (1) | Closed. | 2021-06-23 09:44:44.839 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 09:44:44.839 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:44.839 DTC Client socket (0) | CloseSocket call. | 2021-06-23 09:44:44.855 SC Data - All Services | Disconnected. | 2021-06-23 09:44:44.855 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 09:44:44.855 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 09:44:47.865 DTC Client socket (1) | Creating socket. | 2021-06-23 09:44:47.865 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 09:44:47.865 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 09:44:47.865 SC Data - All Services | Network connection to server complete. | 2021-06-23 09:44:47.865 SC Data - All Services | Starting socket receive thread. | 2021-06-23 09:44:47.865 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: none | 2021-06-23 09:44:47.865 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-23 09:44:47.865 SC Data - All Services | Sending logon request message. | 2021-06-23 09:44:47.865 SC Data - All Services | Message from server: Connecting to primary Data/Trading service. | 2021-06-23 09:44:47.865 SC Data - All Services | Received logon response. | 2021-06-23 09:44:47.865 SC Data - All Services | Server Name: SC DTC Server. | 2021-06-23 09:44:47.865 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 09:44:47.865 SC Data - All Services | Successfully connected. Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices. | 2021-06-23 09:44:47.865 SC Data - All Services | Trading is supported. | 2021-06-23 09:44:47.865 SC Data - All Services | Order cancel and replace is supported. | 2021-06-23 09:44:47.865 SC Data - All Services | OCO Orders supported. | 2021-06-23 09:44:47.865 SC Data - All Services | Bracket Orders supported. | 2021-06-23 09:44:47.865 SC Data - All Services | Connected to server complete. | 2021-06-23 09:44:47.865 Triggering next historical data download in queue. | 2021-06-23 09:44:47.865 Triggering next historical data download in queue. | 2021-06-23 09:44:47.865 Triggering next historical data download in queue. | 2021-06-23 09:44:47.865 Triggering next historical data download in queue. | 2021-06-23 09:44:47.865 No download requests in the queue to start downloads for. | 2021-06-23 09:44:47.865 No download requests in the queue to start downloads for. | 2021-06-23 09:44:47.865 No download requests in the queue to start downloads for. | 2021-06-23 09:44:47.865 No download requests in the queue to start downloads for. | 2021-06-23 09:44:47.865 SC Data - All Services | Starting real-time market data updates for: NGN21-NYMEX. ID: 1 | 2021-06-23 09:44:47.912 SC Data - All Services | Requesting security definition data for: NGN21-NYMEX. ID: 1 | 2021-06-23 09:44:47.912 Requesting market depth updates for: NGN21-NYMEX if supported. | 2021-06-23 09:44:47.912 SC Data - All Services | Starting market orders updates for: NGN21-NYMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:44:47.912 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 09:44:47.912 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 09:44:47.912 Triggering next historical data download in queue. | 2021-06-23 09:44:47.912 Delaying start of download for NGN21-NYMEX | 2021-06-23 09:44:47.912 SC Data - All Services | Starting real-time market data updates for: CLN21-NYMEX. ID: 2 | 2021-06-23 09:44:47.912 SC Data - All Services | Requesting security definition data for: CLN21-NYMEX. ID: 2 | 2021-06-23 09:44:47.912 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-23 09:44:47.912 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-23 09:44:47.912 Triggering next historical data download in queue. | 2021-06-23 09:44:47.912 SC Data - All Services | Starting real-time market data updates for: HGN21-COMEX. ID: 3 | 2021-06-23 09:44:47.912 SC Data - All Services | Requesting security definition data for: HGN21-COMEX. ID: 3 | 2021-06-23 09:44:47.912 Requesting market depth updates for: HGN21-COMEX if supported. | 2021-06-23 09:44:47.912 SC Data - All Services | Starting market orders updates for: HGN21-COMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:44:47.912 Added historical Intraday data request for HGN21-COMEX to the queue. | 2021-06-23 09:44:47.912 Intraday data recording state for symbol HGN21-COMEX is set to download 'Pending'. | 2021-06-23 09:44:47.912 Triggering next historical data download in queue. | 2021-06-23 09:44:47.912 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 09:44:47.912 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\NGN21-NYMEX.2021-06-23.depth | 2021-06-23 09:44:47.912 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 09:44:47.912 SC Data - All Services | Starting real-time market data updates for: ESU21-CME. ID: 4 | 2021-06-23 09:44:47.912 SC Data - All Services | Requesting security definition data for: ESU21-CME. ID: 4 | 2021-06-23 09:44:47.912 Added historical Intraday data request for ESU21-CME to the queue. | 2021-06-23 09:44:47.912 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-06-23 09:44:47.912 Triggering next historical data download in queue. | 2021-06-23 09:44:47.912 Requesting market depth updates for: ESU21-CME if supported. | 2021-06-23 09:44:47.912 SC Data - All Services | Starting market orders updates for: ESU21-CME. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:44:47.912 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 09:44:47.912 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 09:44:47.912 SC Data - All Services | Starting real-time market data updates for: ZSN21-CBOT. ID: 5 | 2021-06-23 09:44:47.912 SC Data - All Services | Requesting security definition data for: ZSN21-CBOT. ID: 5 | 2021-06-23 09:44:47.912 Requesting market depth updates for: ZSN21-CBOT if supported. | 2021-06-23 09:44:47.912 SC Data - All Services | Starting market orders updates for: ZSN21-CBOT. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:44:47.912 Added historical Intraday data request for ZSN21-CBOT to the queue. | 2021-06-23 09:44:47.912 Intraday data recording state for symbol ZSN21-CBOT is set to download 'Pending'. | 2021-06-23 09:44:47.912 Triggering next historical data download in queue. | 2021-06-23 09:44:47.912 SC Data - All Services | Starting real-time market data updates for: CLQ21-NYMEX. ID: 6 | 2021-06-23 09:44:47.943 SC Data - All Services | Requesting security definition data for: CLQ21-NYMEX. ID: 6 | 2021-06-23 09:44:47.943 Requesting market depth updates for: CLQ21-NYMEX if supported. | 2021-06-23 09:44:47.943 SC Data - All Services | Starting market orders updates for: CLQ21-NYMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 09:44:47.943 Added historical Intraday data request for CLQ21-NYMEX to the queue. | 2021-06-23 09:44:47.943 Intraday data recording state for symbol CLQ21-NYMEX is set to download 'Pending'. | 2021-06-23 09:44:47.943 Triggering next historical data download in queue. | 2021-06-23 09:44:47.943 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 09:44:47.990 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\HGN21-COMEX.2021-06-23.depth | 2021-06-23 09:44:47.990 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 09:44:47.990 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\ESU21-CME.2021-06-23.depth | 2021-06-23 09:44:47.990 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 09:44:47.990 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 09:44:47.990 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\ZSN21-CBOT.2021-06-23.depth | 2021-06-23 09:44:47.990 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 09:44:47.990 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 09:44:47.990 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\CLQ21-NYMEX.2021-06-23.depth | 2021-06-23 09:44:47.990 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 09:44:47.990 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 09:44:48.770 SC Data - All Services | Real-time data for symbol CLN21-NYMEX has been restored. | 2021-06-23 09:44:48.770 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 09:44:48.770 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 09:44:48.770 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 09:44:48.770 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 09:44:48.770 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 09:44:48.770 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 09:44:48.770 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 09:44:48.770 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 09:44:48.770 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 09:44:48.770 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 09:44:48.942 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 09:44:48.942 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 09:44:48.942 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 09:44:48.942 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 09:44:48.942 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 09:44:48.942 SC Data - All Services | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-23 09:44:49.971 SC Data - All Services | Real-time data for symbol CLN21-NYMEX is currently unavailable. | 2021-06-23 09:44:49.971 SC Data - All Services | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-23 09:44:49.971 SC Data - All Services | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-23 09:44:49.971 SC Data - All Services | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-23 09:44:49.971 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-23 09:44:49.971 SC Data - All Services | Market data feed reported to be lost. | 2021-06-23 09:44:49.971 HD Request # 7 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 09:44:52.957 HD Request # 7 | Download start date-time: 2021-06-23 09:43:07.000000. File last date-time: 2021-06-23 09:43:07.005000 | 2021-06-23 09:44:52.957 HD Request # 7 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 09:44:52.957 Socket (2) | Creating socket. | 2021-06-23 09:44:52.957 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 09:44:52.957 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-23 09:44:52.957 SC Data - All Services | Market data feed reported to be restored. | 2021-06-23 09:44:52.973 HD Request # 7 | Setting DTC encoding to Binary VLS | 2021-06-23 09:44:53.020 HD Request # 7 | Sending historical data logon request message. | 2021-06-23 09:44:53.020 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 09:44:53.223 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 09:44:53.223 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 09:44:53.223 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 09:44:53.223 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 09:44:53.223 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 09:44:53.223 SC Data - All Services | Real-time data for symbol CLN21-NYMEX has been restored. | 2021-06-23 09:44:53.223 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 09:44:53.223 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 09:44:53.223 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 09:44:53.223 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 09:44:53.223 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 09:44:53.285 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 09:44:53.285 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 09:44:53.285 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 09:44:53.285 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 09:44:53.285 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 09:44:53.285 HD Request # 7 | Requesting Intraday data. Start date-time: 2021-06-23 09:43:07. Record interval: 0. Symbol: NGN21 | 2021-06-23 09:44:53.519 HD Request # 7 | Decompressing data. | 2021-06-23 09:44:53.550 HD Request # 7 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 09:43:07.005000 | 2021-06-23 09:44:53.550 Socket (2) | CloseSocket call. | 2021-06-23 09:44:53.550 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:44:53.550 Historical data download thread signaled to stop. | 2021-06-23 09:44:53.550 HD Request # 7 | Timestamp of first Intraday data file record written: 2021-06-23 09:43:13.706000 | 2021-06-23 09:44:53.550 HD Request # 7 | Received 102 records from 2021-06-23 09:43:07.005000 to 2021-06-23 09:44:47.816000 (100.8 seconds) and wrote 101 records for NGN21-NYMEX | 2021-06-23 09:44:53.550 HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:44:47.816000 | 2021-06-23 09:44:53.550 HD Request # 7 | Completion time: 1s | 2021-06-23 09:44:53.550 HD Request # 7 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 7 | 2021-06-23 09:44:53.550 Removing historical data download ID 7. | 2021-06-23 09:44:53.550 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 09:44:53.550 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 09:44:53.550 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:44:53.550 Triggering next historical data download in queue. | 2021-06-23 09:44:53.550 HD Request # 8 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-23 09:44:53.550 HD Request # 8 | Download start date-time: 2021-06-22 14:29:46.000000. File last date-time: 2021-06-22 14:29:46.813000 | 2021-06-23 09:44:53.550 HD Request # 8 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 09:44:53.550 Socket (3) | Creating socket. | 2021-06-23 09:44:53.550 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 09:44:53.550 Socket (3) | Connecting to IP: 216.1.90.129. | 2021-06-23 09:44:53.550 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 09:44:53.581 Socket (2) | Closed. | 2021-06-23 09:44:53.581 HD Request # 8 | Setting DTC encoding to Binary VLS | 2021-06-23 09:44:53.628 HD Request # 8 | Sending historical data logon request message. | 2021-06-23 09:44:53.628 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 09:44:54.049 SC Data - All Services | Real-time data for symbol CLN21-NYMEX has been restored. | 2021-06-23 09:44:54.049 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 09:44:54.049 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 09:44:54.049 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 09:44:54.049 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 09:44:54.065 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 09:44:54.065 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 09:44:54.065 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 09:44:54.065 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 09:44:54.065 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 09:44:54.065 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 09:44:54.065 Triggering next historical data download in queue. | 2021-06-23 09:44:54.065 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 09:44:54.065 HD Request # 8 | Requesting Intraday data. Start date-time: 2021-06-22 14:29:46. Record interval: 0. Symbol: CLN21 | 2021-06-23 09:44:54.112 HD Request # 8 | Decompressing data. | 2021-06-23 09:44:54.143 HD Request # 8 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-22 14:29:46.813000 | 2021-06-23 09:44:54.143 Socket (3) | CloseSocket call. | 2021-06-23 09:44:54.143 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:44:54.143 Historical data download thread signaled to stop. | 2021-06-23 09:44:54.143 HD Request # 8 | Received 1 record from 2021-06-22 14:29:46.813000 to 2021-06-22 14:29:46.813000 (0.0 seconds) and wrote 0 records for CLN21-NYMEX | 2021-06-23 09:44:54.143 HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2021-06-22 18:29:46.813000 | 2021-06-23 09:44:54.143 HD Request # 8 | Completion time: 1s | 2021-06-23 09:44:54.143 HD Request # 8 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 8 | 2021-06-23 09:44:54.143 Removing historical data download ID 8. | 2021-06-23 09:44:54.143 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-23 09:44:54.143 Intraday chart data file opened for CLN21-NYMEX | 2021-06-23 09:44:54.143 HD Request # 8 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:44:54.143 Triggering next historical data download in queue. | 2021-06-23 09:44:54.143 HD Request # 9 | Downloading Intraday chart data for HGN21-COMEX to the file HGN21-COMEX.scid. Service: comex | 2021-06-23 09:44:54.143 HD Request # 9 | Download start date-time: 2021-06-23 09:43:11.000000. File last date-time: 2021-06-23 09:43:11.146000 | 2021-06-23 09:44:54.143 HD Request # 9 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 09:44:54.143 Socket (2) | Creating socket. | 2021-06-23 09:44:54.143 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 09:44:54.143 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-23 09:44:54.143 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 09:44:54.174 Socket (3) | Closed. | 2021-06-23 09:44:54.174 HD Request # 9 | Setting DTC encoding to Binary VLS | 2021-06-23 09:44:54.221 HD Request # 9 | Sending historical data logon request message. | 2021-06-23 09:44:54.221 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 09:44:54.237 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 09:44:54.237 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 09:44:54.237 HD Request # 9 | Requesting Intraday data. Start date-time: 2021-06-23 09:43:11. Record interval: 0. Symbol: HGN21 | 2021-06-23 09:44:54.252 HD Request # 9 | Decompressing data. | 2021-06-23 09:44:54.268 HD Request # 9 | Receiving Intraday data for HGN21-COMEX starting at 2021-06-23 09:43:11.145000 | 2021-06-23 09:44:54.268 Socket (2) | CloseSocket call. | 2021-06-23 09:44:54.283 Historical data download thread signaled to stop. | 2021-06-23 09:44:54.283 HD Request # 9 | Timestamp of first Intraday data file record written: 2021-06-23 09:43:12.066000 | 2021-06-23 09:44:54.283 HD Request # 9 | Received 167 records from 2021-06-23 09:43:11.145000 to 2021-06-23 09:44:51.492001 (100.3 seconds) and wrote 165 records for HGN21-COMEX | 2021-06-23 09:44:54.283 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:44:54.283 HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:44:51.492001 | 2021-06-23 09:44:54.283 HD Request # 9 | Completion time: 0s | 2021-06-23 09:44:54.283 HD Request # 9 | Intraday data download complete for HGN21-COMEX. Unique request ID: 9 | 2021-06-23 09:44:54.283 Removing historical data download ID 9. | 2021-06-23 09:44:54.283 Real-time Intraday chart data file updates started for HGN21-COMEX | 2021-06-23 09:44:54.283 Intraday chart data file opened for HGN21-COMEX | 2021-06-23 09:44:54.283 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:44:54.283 Triggering next historical data download in queue. | 2021-06-23 09:44:54.283 HD Request # 10 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-06-23 09:44:54.283 HD Request # 10 | Download start date-time: 2021-06-23 09:43:11.000000. File last date-time: 2021-06-23 09:43:11.053000 | 2021-06-23 09:44:54.283 HD Request # 10 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 09:44:54.283 Socket (3) | Creating socket. | 2021-06-23 09:44:54.283 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 09:44:54.283 Socket (3) | Connecting to IP: 216.1.90.129. | 2021-06-23 09:44:54.283 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 09:44:54.299 Socket (2) | Closed. | 2021-06-23 09:44:54.299 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 09:44:54.315 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 09:44:54.315 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 09:44:54.315 Chart #4 has tagged chart #5 for full recalculation. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 09:44:54.346 HD Request # 10 | Setting DTC encoding to Binary VLS | 2021-06-23 09:44:54.346 HD Request # 10 | Sending historical data logon request message. | 2021-06-23 09:44:54.346 HD Request # 10 | Requesting Intraday data. Start date-time: 2021-06-23 09:43:11. Record interval: 0. Symbol: ESU21 | 2021-06-23 09:44:54.377 HD Request # 10 | Decompressing data. | 2021-06-23 09:44:54.408 HD Request # 10 | Receiving Intraday data for ESU21-CME starting at 2021-06-23 09:43:11.053000 | 2021-06-23 09:44:54.439 Socket (3) | CloseSocket call. | 2021-06-23 09:44:54.439 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:44:54.439 Historical data download thread signaled to stop. | 2021-06-23 09:44:54.439 HD Request # 10 | Timestamp of first Intraday data file record written: 2021-06-23 09:43:11.485000 | 2021-06-23 09:44:54.439 HD Request # 10 | Received 2013 records from 2021-06-23 09:43:11.053000 to 2021-06-23 09:44:52.163000 (101.1 seconds) and wrote 2012 records for ESU21-CME | 2021-06-23 09:44:54.439 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:44:52.163000 | 2021-06-23 09:44:54.439 HD Request # 10 | Completion time: 0s | 2021-06-23 09:44:54.439 HD Request # 10 | Intraday data download complete for ESU21-CME. Unique request ID: 10 | 2021-06-23 09:44:54.439 Removing historical data download ID 10. | 2021-06-23 09:44:54.439 Real-time Intraday chart data file updates started for ESU21-CME | 2021-06-23 09:44:54.439 Intraday chart data file opened for ESU21-CME | 2021-06-23 09:44:54.439 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:44:54.439 Triggering next historical data download in queue. | 2021-06-23 09:44:54.439 HD Request # 11 | Downloading Intraday chart data for ZSN21-CBOT to the file ZSN21-CBOT.scid. Service: cbot | 2021-06-23 09:44:54.439 HD Request # 11 | Download start date-time: 2021-06-23 09:43:08.000000. File last date-time: 2021-06-23 09:43:08.431000 | 2021-06-23 09:44:54.439 HD Request # 11 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 09:44:54.439 Socket (2) | Creating socket. | 2021-06-23 09:44:54.439 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 09:44:54.439 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-23 09:44:54.439 NGN21-NYMEX 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 09:44:54.455 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 09:44:54.471 Socket (3) | Closed. | 2021-06-23 09:44:54.471 HD Request # 11 | Setting DTC encoding to Binary VLS | 2021-06-23 09:44:54.517 HD Request # 11 | Sending historical data logon request message. | 2021-06-23 09:44:54.517 HD Request # 11 | Requesting Intraday data. Start date-time: 2021-06-23 09:43:08. Record interval: 0. Symbol: ZSN21 | 2021-06-23 09:44:54.549 HD Request # 11 | Decompressing data. | 2021-06-23 09:44:54.580 HD Request # 11 | Receiving Intraday data for ZSN21-CBOT starting at 2021-06-23 09:43:08.431000 | 2021-06-23 09:44:54.580 Socket (2) | CloseSocket call. | 2021-06-23 09:44:54.580 Historical data download thread signaled to stop. | 2021-06-23 09:44:54.580 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:44:54.580 HD Request # 11 | Timestamp of first Intraday data file record written: 2021-06-23 09:43:12.166000 | 2021-06-23 09:44:54.580 HD Request # 11 | Received 185 records from 2021-06-23 09:43:08.431000 to 2021-06-23 09:44:51.012000 (102.6 seconds) and wrote 184 records for ZSN21-CBOT | 2021-06-23 09:44:54.580 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:44:51.012000 | 2021-06-23 09:44:54.580 HD Request # 11 | Completion time: 0s | 2021-06-23 09:44:54.580 HD Request # 11 | Intraday data download complete for ZSN21-CBOT. Unique request ID: 11 | 2021-06-23 09:44:54.580 Removing historical data download ID 11. | 2021-06-23 09:44:54.580 Real-time Intraday chart data file updates started for ZSN21-CBOT | 2021-06-23 09:44:54.580 Intraday chart data file opened for ZSN21-CBOT | 2021-06-23 09:44:54.580 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:44:54.580 Triggering next historical data download in queue. | 2021-06-23 09:44:54.580 HD Request # 12 | Downloading Intraday chart data for CLQ21-NYMEX to the file CLQ21-NYMEX.scid. Service: nymex | 2021-06-23 09:44:54.580 HD Request # 12 | Download start date-time: 2021-06-23 09:43:11.000000. File last date-time: 2021-06-23 09:43:11.137000 | 2021-06-23 09:44:54.580 HD Request # 12 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 09:44:54.580 Socket (3) | Creating socket. | 2021-06-23 09:44:54.580 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 09:44:54.580 Socket (3) | Connecting to IP: 216.1.90.129. | 2021-06-23 09:44:54.580 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 09:44:54.611 Socket (2) | Closed. | 2021-06-23 09:44:54.611 HD Request # 12 | Setting DTC encoding to Binary VLS | 2021-06-23 09:44:54.642 HD Request # 12 | Sending historical data logon request message. | 2021-06-23 09:44:54.642 HD Request # 12 | Requesting Intraday data. Start date-time: 2021-06-23 09:43:11. Record interval: 0. Symbol: CLQ21 | 2021-06-23 09:44:54.673 HD Request # 12 | Decompressing data. | 2021-06-23 09:44:54.705 HD Request # 12 | Receiving Intraday data for CLQ21-NYMEX starting at 2021-06-23 09:43:11.137000 | 2021-06-23 09:44:54.705 Socket (3) | CloseSocket call. | 2021-06-23 09:44:54.705 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:44:54.705 Historical data download thread signaled to stop. | 2021-06-23 09:44:54.705 HD Request # 12 | Timestamp of first Intraday data file record written: 2021-06-23 09:43:11.422000 | 2021-06-23 09:44:54.705 HD Request # 12 | Received 566 records from 2021-06-23 09:43:11.137000 to 2021-06-23 09:44:51.750000 (100.6 seconds) and wrote 565 records for CLQ21-NYMEX | 2021-06-23 09:44:54.705 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:44:51.750000 | 2021-06-23 09:44:54.720 Added 1 Time and Sales records to Intraday data file for CLQ21-NYMEX after download. | 2021-06-23 09:44:54.720 HD Request # 12 | Completion time: 0s | 2021-06-23 09:44:54.720 HD Request # 12 | Intraday data download complete for CLQ21-NYMEX. Unique request ID: 12 | 2021-06-23 09:44:54.720 Removing historical data download ID 12. | 2021-06-23 09:44:54.720 Real-time Intraday chart data file updates started for CLQ21-NYMEX | 2021-06-23 09:44:54.720 Intraday chart data file opened for CLQ21-NYMEX | 2021-06-23 09:44:54.720 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:44:54.720 Triggering next historical data download in queue. | 2021-06-23 09:44:54.720 HD Request # 13 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 09:44:54.720 HD Request # 13 | Download start date-time: 2021-06-23 09:44:47.000000. File last date-time: 2021-06-23 09:44:47.816000 | 2021-06-23 09:44:54.720 HD Request # 13 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 09:44:54.720 Socket (2) | Creating socket. | 2021-06-23 09:44:54.720 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 09:44:54.720 Socket (2) | Connecting to IP: 216.1.90.130. | 2021-06-23 09:44:54.720 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 09:44:54.736 Socket (3) | Closed. | 2021-06-23 09:44:54.736 HD Request # 13 | Setting DTC encoding to Binary VLS | 2021-06-23 09:44:54.783 HD Request # 13 | Sending historical data logon request message. | 2021-06-23 09:44:54.783 HD Request # 13 | Requesting Intraday data. Start date-time: 2021-06-23 09:44:47. Record interval: 0. Symbol: NGN21 | 2021-06-23 09:44:54.814 HD Request # 13 | Decompressing data. | 2021-06-23 09:44:54.845 HD Request # 13 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 09:44:47.762000 | 2021-06-23 09:44:54.845 Socket (2) | CloseSocket call. | 2021-06-23 09:44:54.845 Historical data download thread signaled to stop. | 2021-06-23 09:44:54.845 HD Request # 13 | Received 4 records from 2021-06-23 09:44:47.762000 to 2021-06-23 09:44:47.816000 (0.1 seconds) and wrote 0 records for NGN21-NYMEX | 2021-06-23 09:44:54.845 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 09:44:54.845 HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2021-06-23 13:44:47.816000 | 2021-06-23 09:44:54.845 HD Request # 13 | Completion time: 0s | 2021-06-23 09:44:54.845 HD Request # 13 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 13 | 2021-06-23 09:44:54.845 Removing historical data download ID 13. | 2021-06-23 09:44:54.845 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 09:44:54.845 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 09:44:54.845 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2021-06-23 09:44:54.845 Triggering next historical data download in queue. | 2021-06-23 09:44:54.845 No download requests in the queue to start downloads for. | 2021-06-23 09:44:54.845 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 09:44:54.861 Socket (2) | Closed. | 2021-06-23 09:44:54.861 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\NGN21-NYMEX.scid. Thread ID: 5936 | 2021-06-23 09:44:58.807 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\HGN21-COMEX.scid. Thread ID: 5936 | 2021-06-23 09:44:58.807 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\ESU21-CME.scid. Thread ID: 5936 | 2021-06-23 09:44:58.807 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\ZSN21-CBOT.scid. Thread ID: 5936 | 2021-06-23 09:44:58.807 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\CLQ21-NYMEX.scid. Thread ID: 5936 | 2021-06-23 09:44:58.807 SC Data - All Services | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-23 10:19:11.342 SC Data - All Services | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-23 10:19:11.342 SC Data - All Services | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-23 10:19:11.342 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-23 10:19:11.342 SC Data - All Services | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-23 10:19:11.342 SC Data - All Services | Real-time data for symbol CLN21-NYMEX is currently unavailable. | 2021-06-23 10:19:11.342 SC Data - All Services | Market data feed reported to be lost. | 2021-06-23 10:19:11.358 DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:19:11.358 DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:11.358 Connection to the external service has been lost. | 2021-06-23 10:19:11.358 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 10:19:11.358 DTC Client socket (1) | Closed. | 2021-06-23 10:19:11.358 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-23 10:19:11.373 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:11.373 SC Data - All Services | Disconnected. | 2021-06-23 10:19:11.405 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:11.405 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:14.415 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:14.415 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:14.415 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:14.415 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:15.445 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:15.445 DTC Client socket (1) | Closed. | 2021-06-23 10:19:15.445 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:15.445 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:15.445 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:15.461 SC Data - All Services | Disconnected. | 2021-06-23 10:19:15.461 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:15.461 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:18.471 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:18.471 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:18.471 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:18.471 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:19.485 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:19.485 DTC Client socket (1) | Closed. | 2021-06-23 10:19:19.485 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:19.485 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:19.485 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:19.501 SC Data - All Services | Disconnected. | 2021-06-23 10:19:19.501 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:19.501 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:22.512 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:22.512 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:22.512 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:22.512 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:23.526 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:23.526 DTC Client socket (1) | Closed. | 2021-06-23 10:19:23.526 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:23.526 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:23.526 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:23.541 SC Data - All Services | Disconnected. | 2021-06-23 10:19:23.541 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:23.541 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:26.552 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:26.552 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:26.552 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:26.552 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:27.551 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:27.551 DTC Client socket (1) | Closed. | 2021-06-23 10:19:27.551 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:27.551 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:27.551 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:27.566 SC Data - All Services | Disconnected. | 2021-06-23 10:19:27.566 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:27.566 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:30.577 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:30.577 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:30.577 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:30.577 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:31.607 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:31.607 DTC Client socket (1) | Closed. | 2021-06-23 10:19:31.607 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:31.607 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:31.607 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:31.622 SC Data - All Services | Disconnected. | 2021-06-23 10:19:31.622 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:31.622 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:34.633 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:34.633 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:34.633 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:34.633 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:35.647 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:35.647 DTC Client socket (1) | Closed. | 2021-06-23 10:19:35.647 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:35.647 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:35.647 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:35.663 SC Data - All Services | Disconnected. | 2021-06-23 10:19:35.663 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:35.663 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:38.673 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:38.673 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:38.673 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:38.673 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:39.687 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:39.687 DTC Client socket (1) | Closed. | 2021-06-23 10:19:39.687 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:39.687 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:39.687 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:39.703 SC Data - All Services | Disconnected. | 2021-06-23 10:19:39.703 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:39.703 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:42.714 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:42.714 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:42.714 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:42.714 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:43.712 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:43.712 DTC Client socket (1) | Closed. | 2021-06-23 10:19:43.712 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:43.712 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:43.712 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:43.728 SC Data - All Services | Disconnected. | 2021-06-23 10:19:43.728 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:43.728 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:46.739 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:46.739 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:46.739 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:46.739 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:47.753 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:47.753 DTC Client socket (1) | Closed. | 2021-06-23 10:19:47.753 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:47.753 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:47.753 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:47.768 SC Data - All Services | Disconnected. | 2021-06-23 10:19:47.768 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:47.768 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:50.779 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:50.779 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:50.779 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:50.779 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:51.793 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:51.793 DTC Client socket (1) | Closed. | 2021-06-23 10:19:51.793 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:51.793 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:51.793 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:51.809 SC Data - All Services | Disconnected. | 2021-06-23 10:19:51.809 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:51.809 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:54.819 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:54.819 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:54.819 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:54.819 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:55.849 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:55.849 DTC Client socket (1) | Closed. | 2021-06-23 10:19:55.849 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:55.849 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:55.849 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:55.865 SC Data - All Services | Disconnected. | 2021-06-23 10:19:55.865 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:55.865 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:19:58.875 DTC Client socket (1) | Creating socket. | 2021-06-23 10:19:58.875 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:19:58.875 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:19:58.875 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:19:59.905 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:19:59.905 DTC Client socket (1) | Closed. | 2021-06-23 10:19:59.905 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:19:59.905 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:59.905 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:19:59.921 SC Data - All Services | Disconnected. | 2021-06-23 10:19:59.921 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:19:59.921 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:20:02.931 DTC Client socket (1) | Creating socket. | 2021-06-23 10:20:02.931 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:02.931 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:20:02.931 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:20:03.945 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:20:03.945 DTC Client socket (1) | Closed. | 2021-06-23 10:20:03.945 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:20:03.945 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:20:03.945 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:20:03.961 SC Data - All Services | Disconnected. | 2021-06-23 10:20:03.961 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:20:03.961 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:20:06.972 DTC Client socket (1) | Creating socket. | 2021-06-23 10:20:06.972 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:06.972 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:20:06.972 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 10:20:07.986 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 10:20:07.986 DTC Client socket (1) | Closed. | 2021-06-23 10:20:07.986 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 10:20:07.986 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:20:07.986 DTC Client socket (0) | CloseSocket call. | 2021-06-23 10:20:08.001 SC Data - All Services | Disconnected. | 2021-06-23 10:20:08.001 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 10:20:08.001 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 10:20:11.012 DTC Client socket (2) | Creating socket. | 2021-06-23 10:20:11.012 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-23 10:20:11.012 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2021-06-23 10:20:11.012 SC Data - All Services | Network connection to server complete. | 2021-06-23 10:20:11.012 SC Data - All Services | Starting socket receive thread. | 2021-06-23 10:20:11.012 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: none | 2021-06-23 10:20:11.012 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:11.012 SC Data - All Services | Sending logon request message. | 2021-06-23 10:20:11.012 SC Data - All Services | Message from server: Connecting to primary Data/Trading service. | 2021-06-23 10:20:11.012 SC Data - All Services | Received logon response. | 2021-06-23 10:20:11.012 SC Data - All Services | Server Name: SC DTC Server. | 2021-06-23 10:20:11.012 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 10:20:11.012 SC Data - All Services | Successfully connected. Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices. | 2021-06-23 10:20:11.012 SC Data - All Services | Trading is supported. | 2021-06-23 10:20:11.012 SC Data - All Services | Order cancel and replace is supported. | 2021-06-23 10:20:11.012 SC Data - All Services | OCO Orders supported. | 2021-06-23 10:20:11.012 SC Data - All Services | Bracket Orders supported. | 2021-06-23 10:20:11.012 SC Data - All Services | Connected to server complete. | 2021-06-23 10:20:11.012 Triggering next historical data download in queue. | 2021-06-23 10:20:11.012 Triggering next historical data download in queue. | 2021-06-23 10:20:11.012 Triggering next historical data download in queue. | 2021-06-23 10:20:11.012 Triggering next historical data download in queue. | 2021-06-23 10:20:11.012 No download requests in the queue to start downloads for. | 2021-06-23 10:20:11.012 No download requests in the queue to start downloads for. | 2021-06-23 10:20:11.012 No download requests in the queue to start downloads for. | 2021-06-23 10:20:11.012 No download requests in the queue to start downloads for. | 2021-06-23 10:20:11.012 SC Data - All Services | Starting real-time market data updates for: NGN21-NYMEX. ID: 1 | 2021-06-23 10:20:11.121 SC Data - All Services | Requesting security definition data for: NGN21-NYMEX. ID: 1 | 2021-06-23 10:20:11.121 Requesting market depth updates for: NGN21-NYMEX if supported. | 2021-06-23 10:20:11.121 SC Data - All Services | Starting market orders updates for: NGN21-NYMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 10:20:11.121 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 10:20:11.121 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:11.121 Triggering next historical data download in queue. | 2021-06-23 10:20:11.121 Delaying start of download for NGN21-NYMEX | 2021-06-23 10:20:11.121 SC Data - All Services | Starting real-time market data updates for: CLN21-NYMEX. ID: 2 | 2021-06-23 10:20:11.121 SC Data - All Services | Requesting security definition data for: CLN21-NYMEX. ID: 2 | 2021-06-23 10:20:11.121 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-23 10:20:11.121 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:11.121 Triggering next historical data download in queue. | 2021-06-23 10:20:11.121 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 10:20:11.121 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\NGN21-NYMEX.2021-06-23.depth | 2021-06-23 10:20:11.121 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 10:20:11.121 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 10:20:11.121 SC Data - All Services | Starting real-time market data updates for: HGN21-COMEX. ID: 3 | 2021-06-23 10:20:11.121 SC Data - All Services | Requesting security definition data for: HGN21-COMEX. ID: 3 | 2021-06-23 10:20:11.121 Requesting market depth updates for: HGN21-COMEX if supported. | 2021-06-23 10:20:11.121 SC Data - All Services | Starting market orders updates for: HGN21-COMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 10:20:11.121 Added historical Intraday data request for HGN21-COMEX to the queue. | 2021-06-23 10:20:11.121 Intraday data recording state for symbol HGN21-COMEX is set to download 'Pending'. | 2021-06-23 10:20:11.121 Triggering next historical data download in queue. | 2021-06-23 10:20:11.121 SC Data - All Services | Starting real-time market data updates for: ESU21-CME. ID: 4 | 2021-06-23 10:20:11.121 SC Data - All Services | Requesting security definition data for: ESU21-CME. ID: 4 | 2021-06-23 10:20:11.121 Added historical Intraday data request for ESU21-CME to the queue. | 2021-06-23 10:20:11.121 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-06-23 10:20:11.121 Triggering next historical data download in queue. | 2021-06-23 10:20:11.121 Requesting market depth updates for: ESU21-CME if supported. | 2021-06-23 10:20:11.121 SC Data - All Services | Starting market orders updates for: ESU21-CME. MinimumMarketByOrderQuantity: 0 | 2021-06-23 10:20:11.121 SC Data - All Services | Starting real-time market data updates for: ZSN21-CBOT. ID: 5 | 2021-06-23 10:20:11.121 SC Data - All Services | Requesting security definition data for: ZSN21-CBOT. ID: 5 | 2021-06-23 10:20:11.121 Requesting market depth updates for: ZSN21-CBOT if supported. | 2021-06-23 10:20:11.121 SC Data - All Services | Starting market orders updates for: ZSN21-CBOT. MinimumMarketByOrderQuantity: 0 | 2021-06-23 10:20:11.121 Added historical Intraday data request for ZSN21-CBOT to the queue. | 2021-06-23 10:20:11.121 Intraday data recording state for symbol ZSN21-CBOT is set to download 'Pending'. | 2021-06-23 10:20:11.121 Triggering next historical data download in queue. | 2021-06-23 10:20:11.121 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 10:20:11.121 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 10:20:11.121 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\HGN21-COMEX.2021-06-23.depth | 2021-06-23 10:20:11.121 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 10:20:11.121 SC Data - All Services | Starting real-time market data updates for: CLQ21-NYMEX. ID: 6 | 2021-06-23 10:20:11.121 SC Data - All Services | Requesting security definition data for: CLQ21-NYMEX. ID: 6 | 2021-06-23 10:20:11.121 Requesting market depth updates for: CLQ21-NYMEX if supported. | 2021-06-23 10:20:11.121 SC Data - All Services | Starting market orders updates for: CLQ21-NYMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 10:20:11.121 Added historical Intraday data request for CLQ21-NYMEX to the queue. | 2021-06-23 10:20:11.121 Intraday data recording state for symbol CLQ21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:11.121 Triggering next historical data download in queue. | 2021-06-23 10:20:11.121 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 10:20:11.199 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\ESU21-CME.2021-06-23.depth | 2021-06-23 10:20:11.199 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 10:20:11.199 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\ZSN21-CBOT.2021-06-23.depth | 2021-06-23 10:20:11.199 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 10:20:11.199 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 10:20:11.199 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\CLQ21-NYMEX.2021-06-23.depth | 2021-06-23 10:20:11.199 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 10:20:11.199 SC Data - All Services | Real-time data for symbol CLN21-NYMEX is currently unavailable. | 2021-06-23 10:20:11.309 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-23 10:20:11.309 SC Data - All Services | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-23 10:20:11.309 SC Data - All Services | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-23 10:20:11.309 SC Data - All Services | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-23 10:20:11.309 SC Data - All Services | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-23 10:20:11.309 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 10:20:14.694 SC Data - All Services | Real-time data for symbol CLN21-NYMEX has been restored. | 2021-06-23 10:20:14.694 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 10:20:14.694 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 10:20:14.694 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 10:20:14.694 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 10:20:14.694 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 10:20:14.694 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 10:20:14.694 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 10:20:14.694 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 10:20:14.694 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 10:20:14.694 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 10:20:14.865 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 10:20:14.865 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 10:20:14.865 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 10:20:14.865 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 10:20:14.943 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 10:20:14.943 SC Data - All Services | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-23 10:20:15.614 SC Data - All Services | Real-time data for symbol CLN21-NYMEX is currently unavailable. | 2021-06-23 10:20:15.614 SC Data - All Services | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-23 10:20:15.614 SC Data - All Services | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-23 10:20:15.614 SC Data - All Services | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-23 10:20:15.614 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-23 10:20:15.614 SC Data - All Services | Market data feed reported to be lost. | 2021-06-23 10:20:15.614 HD Request # 14 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:16.292 HD Request # 14 | Download start date-time: 2021-06-23 10:19:06.000000. File last date-time: 2021-06-23 10:19:06.150000 | 2021-06-23 10:20:16.292 HD Request # 14 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:16.292 Socket (1) | Creating socket. | 2021-06-23 10:20:16.292 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:16.292 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:16.292 HD Request # 14 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:16.355 HD Request # 14 | Sending historical data logon request message. | 2021-06-23 10:20:16.355 HD Request # 14 | Requesting Intraday data. Start date-time: 2021-06-23 10:19:06. Record interval: 0. Symbol: NGN21 | 2021-06-23 10:20:16.854 HD Request # 14 | Decompressing data. | 2021-06-23 10:20:16.869 HD Request # 14 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 10:19:06.150000 | 2021-06-23 10:20:16.885 Socket (1) | CloseSocket call. | 2021-06-23 10:20:16.885 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:16.885 Historical data download thread signaled to stop. | 2021-06-23 10:20:16.885 HD Request # 14 | Timestamp of first Intraday data file record written: 2021-06-23 10:19:13.838000 | 2021-06-23 10:20:16.885 HD Request # 14 | Received 51 records from 2021-06-23 10:19:06.150000 to 2021-06-23 10:19:56.573002 (50.4 seconds) and wrote 50 records for NGN21-NYMEX | 2021-06-23 10:20:16.885 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:19:56.573002 | 2021-06-23 10:20:16.885 HD Request # 14 | Completion time: 0s | 2021-06-23 10:20:16.885 HD Request # 14 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 14 | 2021-06-23 10:20:16.885 Removing historical data download ID 14. | 2021-06-23 10:20:16.885 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 10:20:16.885 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 10:20:16.885 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:16.885 Triggering next historical data download in queue. | 2021-06-23 10:20:16.885 HD Request # 15 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:16.885 HD Request # 15 | Download start date-time: 2021-06-22 14:29:46.000000. File last date-time: 2021-06-22 14:29:46.813000 | 2021-06-23 10:20:16.885 HD Request # 15 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:16.885 Socket (3) | Creating socket. | 2021-06-23 10:20:16.885 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:16.885 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:16.885 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:16.901 Socket (1) | Closed. | 2021-06-23 10:20:16.901 HD Request # 15 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:16.947 HD Request # 15 | Sending historical data logon request message. | 2021-06-23 10:20:16.947 HD Request # 15 | Requesting Intraday data. Start date-time: 2021-06-22 14:29:46. Record interval: 0. Symbol: CLN21 | 2021-06-23 10:20:17.431 HD Request # 15 | Decompressing data. | 2021-06-23 10:20:17.462 HD Request # 15 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-22 14:29:46.813000 | 2021-06-23 10:20:17.462 Socket (3) | CloseSocket call. | 2021-06-23 10:20:17.462 Historical data download thread signaled to stop. | 2021-06-23 10:20:17.462 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:17.462 HD Request # 15 | Received 1 record from 2021-06-22 14:29:46.813000 to 2021-06-22 14:29:46.813000 (0.0 seconds) and wrote 0 records for CLN21-NYMEX | 2021-06-23 10:20:17.462 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2021-06-22 18:29:46.813000 | 2021-06-23 10:20:17.462 HD Request # 15 | Completion time: 1s | 2021-06-23 10:20:17.462 HD Request # 15 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 15 | 2021-06-23 10:20:17.462 Removing historical data download ID 15. | 2021-06-23 10:20:17.462 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-23 10:20:17.462 Intraday chart data file opened for CLN21-NYMEX | 2021-06-23 10:20:17.462 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:17.462 Triggering next historical data download in queue. | 2021-06-23 10:20:17.462 HD Request # 16 | Downloading Intraday chart data for HGN21-COMEX to the file HGN21-COMEX.scid. Service: comex | 2021-06-23 10:20:17.462 HD Request # 16 | Download start date-time: 2021-06-23 10:19:10.000000. File last date-time: 2021-06-23 10:19:10.892000 | 2021-06-23 10:20:17.462 HD Request # 16 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:17.462 Socket (1) | Creating socket. | 2021-06-23 10:20:17.462 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:17.462 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:17.462 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:17.493 Socket (3) | Closed. | 2021-06-23 10:20:17.493 HD Request # 16 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:17.525 HD Request # 16 | Sending historical data logon request message. | 2021-06-23 10:20:17.525 HD Request # 16 | Requesting Intraday data. Start date-time: 2021-06-23 10:19:10. Record interval: 0. Symbol: HGN21 | 2021-06-23 10:20:17.556 HD Request # 16 | Decompressing data. | 2021-06-23 10:20:17.571 HD Request # 16 | Receiving Intraday data for HGN21-COMEX starting at 2021-06-23 10:19:10.066000 | 2021-06-23 10:20:17.571 Socket (1) | CloseSocket call. | 2021-06-23 10:20:17.571 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:17.571 Historical data download thread signaled to stop. | 2021-06-23 10:20:17.571 HD Request # 16 | Timestamp of first Intraday data file record written: 2021-06-23 10:19:11.060000 | 2021-06-23 10:20:17.571 HD Request # 16 | Received 144 records from 2021-06-23 10:19:10.066000 to 2021-06-23 10:20:13.696005 (63.6 seconds) and wrote 135 records for HGN21-COMEX | 2021-06-23 10:20:17.571 HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:13.696005 | 2021-06-23 10:20:17.587 Added 8 Time and Sales records to Intraday data file for HGN21-COMEX after download. | 2021-06-23 10:20:17.587 HD Request # 16 | Completion time: 0s | 2021-06-23 10:20:17.587 HD Request # 16 | Intraday data download complete for HGN21-COMEX. Unique request ID: 16 | 2021-06-23 10:20:17.587 Removing historical data download ID 16. | 2021-06-23 10:20:17.587 Real-time Intraday chart data file updates started for HGN21-COMEX | 2021-06-23 10:20:17.587 Intraday chart data file opened for HGN21-COMEX | 2021-06-23 10:20:17.587 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:17.587 Triggering next historical data download in queue. | 2021-06-23 10:20:17.587 HD Request # 17 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-06-23 10:20:17.587 HD Request # 17 | Download start date-time: 2021-06-23 10:19:10.000000. File last date-time: 2021-06-23 10:19:10.606000 | 2021-06-23 10:20:17.587 HD Request # 17 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:17.587 Socket (3) | Creating socket. | 2021-06-23 10:20:17.587 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:17.587 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:17.587 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:17.603 Socket (1) | Closed. | 2021-06-23 10:20:17.603 HD Request # 17 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:17.649 HD Request # 17 | Sending historical data logon request message. | 2021-06-23 10:20:17.649 Chart #4 has tagged chart #5 for full recalculation. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 10:20:17.681 HD Request # 17 | Requesting Intraday data. Start date-time: 2021-06-23 10:19:10. Record interval: 0. Symbol: ESU21 | 2021-06-23 10:20:17.681 HD Request # 17 | Decompressing data. | 2021-06-23 10:20:17.712 HD Request # 17 | Receiving Intraday data for ESU21-CME starting at 2021-06-23 10:19:10.345000 | 2021-06-23 10:20:17.712 Socket (3) | CloseSocket call. | 2021-06-23 10:20:17.712 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:17.712 Historical data download thread signaled to stop. | 2021-06-23 10:20:17.712 HD Request # 17 | Timestamp of first Intraday data file record written: 2021-06-23 10:19:11.136000 | 2021-06-23 10:20:17.712 HD Request # 17 | Received 1235 records from 2021-06-23 10:19:10.345000 to 2021-06-23 10:20:14.613000 (64.3 seconds) and wrote 1233 records for ESU21-CME | 2021-06-23 10:20:17.712 HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:14.613000 | 2021-06-23 10:20:17.712 Added 127 Time and Sales records to Intraday data file for ESU21-CME after download. | 2021-06-23 10:20:17.712 HD Request # 17 | Completion time: 0s | 2021-06-23 10:20:17.712 HD Request # 17 | Intraday data download complete for ESU21-CME. Unique request ID: 17 | 2021-06-23 10:20:17.712 Removing historical data download ID 17. | 2021-06-23 10:20:17.712 Real-time Intraday chart data file updates started for ESU21-CME | 2021-06-23 10:20:17.712 Intraday chart data file opened for ESU21-CME | 2021-06-23 10:20:17.712 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:17.712 Triggering next historical data download in queue. | 2021-06-23 10:20:17.712 HD Request # 18 | Downloading Intraday chart data for ZSN21-CBOT to the file ZSN21-CBOT.scid. Service: cbot | 2021-06-23 10:20:17.712 HD Request # 18 | Download start date-time: 2021-06-23 10:19:10.000000. File last date-time: 2021-06-23 10:19:10.937007 | 2021-06-23 10:20:17.727 HD Request # 18 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:17.727 Socket (1) | Creating socket. | 2021-06-23 10:20:17.727 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:17.727 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:17.727 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:17.743 Socket (3) | Closed. | 2021-06-23 10:20:17.743 NGN21-NYMEX 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 10:20:17.790 HD Request # 18 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:17.790 HD Request # 18 | Sending historical data logon request message. | 2021-06-23 10:20:17.790 HD Request # 18 | Requesting Intraday data. Start date-time: 2021-06-23 10:19:10. Record interval: 0. Symbol: ZSN21 | 2021-06-23 10:20:17.821 HD Request # 18 | Decompressing data. | 2021-06-23 10:20:17.837 HD Request # 18 | Receiving Intraday data for ZSN21-CBOT starting at 2021-06-23 10:19:10.857000 | 2021-06-23 10:20:17.837 Socket (1) | CloseSocket call. | 2021-06-23 10:20:17.837 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:17.837 Historical data download thread signaled to stop. | 2021-06-23 10:20:17.837 HD Request # 18 | Timestamp of first Intraday data file record written: 2021-06-23 10:19:10.939000 | 2021-06-23 10:20:17.837 HD Request # 18 | Received 87 records from 2021-06-23 10:19:10.857000 to 2021-06-23 10:20:13.931000 (63.1 seconds) and wrote 75 records for ZSN21-CBOT | 2021-06-23 10:20:17.837 HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:13.931000 | 2021-06-23 10:20:17.852 HD Request # 18 | Completion time: 0s | 2021-06-23 10:20:17.852 HD Request # 18 | Intraday data download complete for ZSN21-CBOT. Unique request ID: 18 | 2021-06-23 10:20:17.852 Removing historical data download ID 18. | 2021-06-23 10:20:17.852 Real-time Intraday chart data file updates started for ZSN21-CBOT | 2021-06-23 10:20:17.852 Intraday chart data file opened for ZSN21-CBOT | 2021-06-23 10:20:17.852 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:17.852 Triggering next historical data download in queue. | 2021-06-23 10:20:17.852 HD Request # 19 | Downloading Intraday chart data for CLQ21-NYMEX to the file CLQ21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:17.852 HD Request # 19 | Download start date-time: 2021-06-23 10:19:09.000000. File last date-time: 2021-06-23 10:19:09.418000 | 2021-06-23 10:20:17.852 HD Request # 19 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:17.852 Socket (3) | Creating socket. | 2021-06-23 10:20:17.852 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:17.852 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:17.852 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:17.868 Socket (1) | Closed. | 2021-06-23 10:20:17.868 HD Request # 19 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:17.915 HD Request # 19 | Sending historical data logon request message. | 2021-06-23 10:20:17.915 HD Request # 19 | Requesting Intraday data. Start date-time: 2021-06-23 10:19:09. Record interval: 0. Symbol: CLQ21 | 2021-06-23 10:20:17.946 HD Request # 19 | Decompressing data. | 2021-06-23 10:20:17.977 HD Request # 19 | Receiving Intraday data for CLQ21-NYMEX starting at 2021-06-23 10:19:09.418000 | 2021-06-23 10:20:17.977 Socket (3) | CloseSocket call. | 2021-06-23 10:20:17.977 Historical data download thread signaled to stop. | 2021-06-23 10:20:17.977 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:17.977 HD Request # 19 | Timestamp of first Intraday data file record written: 2021-06-23 10:19:11.165000 | 2021-06-23 10:20:17.977 HD Request # 19 | Received 248 records from 2021-06-23 10:19:09.418000 to 2021-06-23 10:20:08.857003 (59.4 seconds) and wrote 247 records for CLQ21-NYMEX | 2021-06-23 10:20:17.977 HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:08.857003 | 2021-06-23 10:20:17.977 Added 2 Time and Sales records to Intraday data file for CLQ21-NYMEX after download. | 2021-06-23 10:20:17.977 HD Request # 19 | Completion time: 0s | 2021-06-23 10:20:17.977 HD Request # 19 | Intraday data download complete for CLQ21-NYMEX. Unique request ID: 19 | 2021-06-23 10:20:17.977 Removing historical data download ID 19. | 2021-06-23 10:20:17.977 Real-time Intraday chart data file updates started for CLQ21-NYMEX | 2021-06-23 10:20:17.977 Intraday chart data file opened for CLQ21-NYMEX | 2021-06-23 10:20:17.977 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:17.977 Triggering next historical data download in queue. | 2021-06-23 10:20:17.977 No download requests in the queue to start downloads for. | 2021-06-23 10:20:17.977 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:18.008 Socket (3) | Closed. | 2021-06-23 10:20:18.008 SC Data - All Services | Market data feed reported to be restored. | 2021-06-23 10:20:18.632 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 10:20:18.632 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:18.632 Triggering next historical data download in queue. | 2021-06-23 10:20:18.632 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-23 10:20:18.632 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:18.632 Added historical Intraday data request for HGN21-COMEX to the queue. | 2021-06-23 10:20:18.632 Intraday data recording state for symbol HGN21-COMEX is set to download 'Pending'. | 2021-06-23 10:20:18.632 Added historical Intraday data request for ESU21-CME to the queue. | 2021-06-23 10:20:18.632 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-06-23 10:20:18.632 Added historical Intraday data request for ZSN21-CBOT to the queue. | 2021-06-23 10:20:18.632 Intraday data recording state for symbol ZSN21-CBOT is set to download 'Pending'. | 2021-06-23 10:20:18.632 Added historical Intraday data request for CLQ21-NYMEX to the queue. | 2021-06-23 10:20:18.632 Intraday data recording state for symbol CLQ21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:18.632 HD Request # 20 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:18.632 HD Request # 20 | Download start date-time: 2021-06-23 10:19:56.000000. File last date-time: 2021-06-23 10:19:56.573002 | 2021-06-23 10:20:18.632 HD Request # 20 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:18.632 Socket (1) | Creating socket. | 2021-06-23 10:20:18.632 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:18.632 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:18.632 HD Request # 20 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:18.695 HD Request # 20 | Sending historical data logon request message. | 2021-06-23 10:20:18.695 HD Request # 20 | Requesting Intraday data. Start date-time: 2021-06-23 10:19:56. Record interval: 0. Symbol: NGN21 | 2021-06-23 10:20:18.710 HD Request # 20 | Decompressing data. | 2021-06-23 10:20:18.741 HD Request # 20 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 10:19:56.572000 | 2021-06-23 10:20:18.741 Socket (1) | CloseSocket call. | 2021-06-23 10:20:18.741 Historical data download thread signaled to stop. | 2021-06-23 10:20:18.741 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:18.741 HD Request # 20 | Received 4 records from 2021-06-23 10:19:56.572000 to 2021-06-23 10:19:56.573002 (0.0 seconds) and wrote 0 records for NGN21-NYMEX | 2021-06-23 10:20:18.741 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:19:56.573002 | 2021-06-23 10:20:18.741 HD Request # 20 | Completion time: 0s | 2021-06-23 10:20:18.741 HD Request # 20 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 20 | 2021-06-23 10:20:18.741 Removing historical data download ID 20. | 2021-06-23 10:20:18.741 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 10:20:18.741 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 10:20:18.741 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:18.741 Triggering next historical data download in queue. | 2021-06-23 10:20:18.741 HD Request # 21 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:18.741 HD Request # 21 | Download start date-time: 2021-06-22 14:29:46.000000. File last date-time: 2021-06-22 14:29:46.813000 | 2021-06-23 10:20:18.741 HD Request # 21 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:18.741 Socket (3) | Creating socket. | 2021-06-23 10:20:18.741 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:18.741 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:18.741 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:18.773 Socket (1) | Closed. | 2021-06-23 10:20:18.773 HD Request # 21 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:18.819 HD Request # 21 | Sending historical data logon request message. | 2021-06-23 10:20:18.819 HD Request # 21 | Requesting Intraday data. Start date-time: 2021-06-22 14:29:46. Record interval: 0. Symbol: CLN21 | 2021-06-23 10:20:18.835 HD Request # 21 | Decompressing data. | 2021-06-23 10:20:18.866 HD Request # 21 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-22 14:29:46.813000 | 2021-06-23 10:20:18.866 Socket (3) | CloseSocket call. | 2021-06-23 10:20:18.866 Historical data download thread signaled to stop. | 2021-06-23 10:20:18.866 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:18.866 HD Request # 21 | Received 1 record from 2021-06-22 14:29:46.813000 to 2021-06-22 14:29:46.813000 (0.0 seconds) and wrote 0 records for CLN21-NYMEX | 2021-06-23 10:20:18.866 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2021-06-22 18:29:46.813000 | 2021-06-23 10:20:18.866 HD Request # 21 | Completion time: 0s | 2021-06-23 10:20:18.866 HD Request # 21 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 21 | 2021-06-23 10:20:18.866 Removing historical data download ID 21. | 2021-06-23 10:20:18.866 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-23 10:20:18.866 Intraday chart data file opened for CLN21-NYMEX | 2021-06-23 10:20:18.866 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:18.866 Triggering next historical data download in queue. | 2021-06-23 10:20:18.866 HD Request # 22 | Downloading Intraday chart data for HGN21-COMEX to the file HGN21-COMEX.scid. Service: comex | 2021-06-23 10:20:18.866 HD Request # 22 | Download start date-time: 2021-06-23 10:20:15.000000. File last date-time: 2021-06-23 10:20:15.131000 | 2021-06-23 10:20:18.866 HD Request # 22 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:18.866 Socket (1) | Creating socket. | 2021-06-23 10:20:18.866 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:18.866 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:18.866 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 10:20:18.882 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 10:20:18.882 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:18.882 Triggering next historical data download in queue. | 2021-06-23 10:20:18.882 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 10:20:18.882 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 10:20:18.882 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 10:20:18.882 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 10:20:18.882 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 10:20:18.882 SC Data - All Services | Real-time data for symbol CLN21-NYMEX has been restored. | 2021-06-23 10:20:18.882 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-23 10:20:18.882 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:18.882 Triggering next historical data download in queue. | 2021-06-23 10:20:18.882 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 10:20:18.882 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 10:20:18.882 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 10:20:18.882 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 10:20:18.882 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 10:20:18.882 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 10:20:18.882 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 10:20:18.882 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 10:20:18.882 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 10:20:18.882 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 10:20:18.882 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:18.897 Socket (3) | Closed. | 2021-06-23 10:20:18.897 HD Request # 22 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:18.929 HD Request # 22 | Sending historical data logon request message. | 2021-06-23 10:20:18.929 HD Request # 22 | Requesting Intraday data. Start date-time: 2021-06-23 10:20:15. Record interval: 0. Symbol: HGN21 | 2021-06-23 10:20:18.960 HD Request # 22 | Decompressing data. | 2021-06-23 10:20:18.991 HD Request # 22 | Receiving Intraday data for HGN21-COMEX starting at 2021-06-23 10:20:15.130000 | 2021-06-23 10:20:18.991 Socket (1) | CloseSocket call. | 2021-06-23 10:20:18.991 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:18.991 Historical data download thread signaled to stop. | 2021-06-23 10:20:18.991 HD Request # 22 | Timestamp of first Intraday data file record written: 2021-06-23 10:20:15.455000 | 2021-06-23 10:20:18.991 HD Request # 22 | Received 11 records from 2021-06-23 10:20:15.130000 to 2021-06-23 10:20:16.842000 (1.7 seconds) and wrote 3 records for HGN21-COMEX | 2021-06-23 10:20:18.991 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:16.842000 | 2021-06-23 10:20:18.991 HD Request # 22 | Completion time: 0s | 2021-06-23 10:20:18.991 HD Request # 22 | Intraday data download complete for HGN21-COMEX. Unique request ID: 22 | 2021-06-23 10:20:18.991 Removing historical data download ID 22. | 2021-06-23 10:20:18.991 Real-time Intraday chart data file updates started for HGN21-COMEX | 2021-06-23 10:20:18.991 Intraday chart data file opened for HGN21-COMEX | 2021-06-23 10:20:18.991 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:18.991 Triggering next historical data download in queue. | 2021-06-23 10:20:18.991 HD Request # 23 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-06-23 10:20:18.991 HD Request # 23 | Download start date-time: 2021-06-23 10:20:15.000000. File last date-time: 2021-06-23 10:20:15.216003 | 2021-06-23 10:20:18.991 HD Request # 23 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:18.991 Socket (3) | Creating socket. | 2021-06-23 10:20:18.991 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:18.991 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:18.991 Chart #4 has tagged chart #5 for full recalculation. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 10:20:18.991 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:19.022 Socket (1) | Closed. | 2021-06-23 10:20:19.022 HD Request # 23 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:19.069 HD Request # 23 | Sending historical data logon request message. | 2021-06-23 10:20:19.069 HD Request # 23 | Requesting Intraday data. Start date-time: 2021-06-23 10:20:15. Record interval: 0. Symbol: ESU21 | 2021-06-23 10:20:19.085 NGN21-NYMEX 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 10:20:19.100 HD Request # 23 | Decompressing data. | 2021-06-23 10:20:19.116 HD Request # 23 | Receiving Intraday data for ESU21-CME starting at 2021-06-23 10:20:15.096000 | 2021-06-23 10:20:19.116 Socket (3) | CloseSocket call. | 2021-06-23 10:20:19.116 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:19.116 Historical data download thread signaled to stop. | 2021-06-23 10:20:19.116 HD Request # 23 | Timestamp of first Intraday data file record written: 2021-06-23 10:20:16.529000 | 2021-06-23 10:20:19.116 HD Request # 23 | Received 111 records from 2021-06-23 10:20:15.096000 to 2021-06-23 10:20:18.633001 (3.5 seconds) and wrote 19 records for ESU21-CME | 2021-06-23 10:20:19.116 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:18.633001 | 2021-06-23 10:20:19.131 HD Request # 23 | Completion time: 1s | 2021-06-23 10:20:19.131 HD Request # 23 | Intraday data download complete for ESU21-CME. Unique request ID: 23 | 2021-06-23 10:20:19.131 Removing historical data download ID 23. | 2021-06-23 10:20:19.131 Real-time Intraday chart data file updates started for ESU21-CME | 2021-06-23 10:20:19.131 Intraday chart data file opened for ESU21-CME | 2021-06-23 10:20:19.131 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:19.131 Triggering next historical data download in queue. | 2021-06-23 10:20:19.131 HD Request # 24 | Downloading Intraday chart data for ZSN21-CBOT to the file ZSN21-CBOT.scid. Service: cbot | 2021-06-23 10:20:19.131 HD Request # 24 | Download start date-time: 2021-06-23 10:20:13.000000. File last date-time: 2021-06-23 10:20:13.931000 | 2021-06-23 10:20:19.131 HD Request # 24 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:19.131 Socket (1) | Creating socket. | 2021-06-23 10:20:19.131 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:19.131 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:19.131 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:19.147 Socket (3) | Closed. | 2021-06-23 10:20:19.147 HD Request # 24 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:19.194 HD Request # 24 | Sending historical data logon request message. | 2021-06-23 10:20:19.194 HD Request # 24 | Requesting Intraday data. Start date-time: 2021-06-23 10:20:13. Record interval: 0. Symbol: ZSN21 | 2021-06-23 10:20:19.225 HD Request # 24 | Decompressing data. | 2021-06-23 10:20:19.256 HD Request # 24 | Receiving Intraday data for ZSN21-CBOT starting at 2021-06-23 10:20:13.931000 | 2021-06-23 10:20:19.256 Socket (1) | CloseSocket call. | 2021-06-23 10:20:19.256 Historical data download thread signaled to stop. | 2021-06-23 10:20:19.256 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:19.256 HD Request # 24 | Received 1 record from 2021-06-23 10:20:13.931000 to 2021-06-23 10:20:13.931000 (0.0 seconds) and wrote 0 records for ZSN21-CBOT | 2021-06-23 10:20:19.256 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:13.931000 | 2021-06-23 10:20:19.256 HD Request # 24 | Completion time: 0s | 2021-06-23 10:20:19.256 HD Request # 24 | Intraday data download complete for ZSN21-CBOT. Unique request ID: 24 | 2021-06-23 10:20:19.256 Removing historical data download ID 24. | 2021-06-23 10:20:19.256 Real-time Intraday chart data file updates started for ZSN21-CBOT | 2021-06-23 10:20:19.256 Intraday chart data file opened for ZSN21-CBOT | 2021-06-23 10:20:19.256 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:19.256 Triggering next historical data download in queue. | 2021-06-23 10:20:19.256 HD Request # 25 | Downloading Intraday chart data for CLQ21-NYMEX to the file CLQ21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:19.256 HD Request # 25 | Download start date-time: 2021-06-23 10:20:15.000000. File last date-time: 2021-06-23 10:20:15.126001 | 2021-06-23 10:20:19.256 HD Request # 25 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:19.256 Socket (3) | Creating socket. | 2021-06-23 10:20:19.256 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:19.256 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:19.256 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:19.287 Socket (1) | Closed. | 2021-06-23 10:20:19.287 HD Request # 25 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:19.319 HD Request # 25 | Sending historical data logon request message. | 2021-06-23 10:20:19.319 HD Request # 25 | Requesting Intraday data. Start date-time: 2021-06-23 10:20:15. Record interval: 0. Symbol: CLQ21 | 2021-06-23 10:20:19.350 HD Request # 25 | Decompressing data. | 2021-06-23 10:20:19.381 HD Request # 25 | Receiving Intraday data for CLQ21-NYMEX starting at 2021-06-23 10:20:15.126000 | 2021-06-23 10:20:19.381 Socket (3) | CloseSocket call. | 2021-06-23 10:20:19.381 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:19.381 Historical data download thread signaled to stop. | 2021-06-23 10:20:19.381 HD Request # 25 | Timestamp of first Intraday data file record written: 2021-06-23 10:20:17.111000 | 2021-06-23 10:20:19.381 HD Request # 25 | Received 9 records from 2021-06-23 10:20:15.126000 to 2021-06-23 10:20:17.216003 (2.1 seconds) and wrote 7 records for CLQ21-NYMEX | 2021-06-23 10:20:19.381 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:17.216003 | 2021-06-23 10:20:19.381 HD Request # 25 | Completion time: 0s | 2021-06-23 10:20:19.381 HD Request # 25 | Intraday data download complete for CLQ21-NYMEX. Unique request ID: 25 | 2021-06-23 10:20:19.381 Removing historical data download ID 25. | 2021-06-23 10:20:19.381 Real-time Intraday chart data file updates started for CLQ21-NYMEX | 2021-06-23 10:20:19.381 Intraday chart data file opened for CLQ21-NYMEX | 2021-06-23 10:20:19.381 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:19.381 Triggering next historical data download in queue. | 2021-06-23 10:20:19.381 HD Request # 26 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:19.381 HD Request # 26 | Download start date-time: 2021-06-23 10:19:56.000000. File last date-time: 2021-06-23 10:19:56.573002 | 2021-06-23 10:20:19.381 HD Request # 26 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:19.381 Socket (1) | Creating socket. | 2021-06-23 10:20:19.381 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:19.381 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:19.381 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:19.412 Socket (3) | Closed. | 2021-06-23 10:20:19.412 HD Request # 26 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:19.459 HD Request # 26 | Sending historical data logon request message. | 2021-06-23 10:20:19.459 HD Request # 26 | Requesting Intraday data. Start date-time: 2021-06-23 10:19:56. Record interval: 0. Symbol: NGN21 | 2021-06-23 10:20:19.490 HD Request # 26 | Decompressing data. | 2021-06-23 10:20:19.521 HD Request # 26 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 10:19:56.572000 | 2021-06-23 10:20:19.521 Socket (1) | CloseSocket call. | 2021-06-23 10:20:19.521 Historical data download thread signaled to stop. | 2021-06-23 10:20:19.521 HD Request # 26 | Received 4 records from 2021-06-23 10:19:56.572000 to 2021-06-23 10:19:56.573002 (0.0 seconds) and wrote 0 records for NGN21-NYMEX | 2021-06-23 10:20:19.521 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:19.521 HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:19:56.573002 | 2021-06-23 10:20:19.521 HD Request # 26 | Completion time: 0s | 2021-06-23 10:20:19.521 HD Request # 26 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 26 | 2021-06-23 10:20:19.521 Removing historical data download ID 26. | 2021-06-23 10:20:19.521 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 10:20:19.521 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 10:20:19.521 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:19.521 Triggering next historical data download in queue. | 2021-06-23 10:20:19.521 HD Request # 27 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:19.521 HD Request # 27 | Download start date-time: 2021-06-22 14:29:46.000000. File last date-time: 2021-06-22 14:29:46.813000 | 2021-06-23 10:20:19.521 HD Request # 27 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:19.521 Socket (3) | Creating socket. | 2021-06-23 10:20:19.521 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:19.521 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:19.521 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:19.553 Socket (1) | Closed. | 2021-06-23 10:20:19.553 HD Request # 27 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:19.584 HD Request # 27 | Sending historical data logon request message. | 2021-06-23 10:20:19.584 HD Request # 27 | Requesting Intraday data. Start date-time: 2021-06-22 14:29:46. Record interval: 0. Symbol: CLN21 | 2021-06-23 10:20:19.615 HD Request # 27 | Decompressing data. | 2021-06-23 10:20:19.646 HD Request # 27 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-22 14:29:46.813000 | 2021-06-23 10:20:19.646 Socket (3) | CloseSocket call. | 2021-06-23 10:20:19.646 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:19.646 Historical data download thread signaled to stop. | 2021-06-23 10:20:19.646 HD Request # 27 | Received 1 record from 2021-06-22 14:29:46.813000 to 2021-06-22 14:29:46.813000 (0.0 seconds) and wrote 0 records for CLN21-NYMEX | 2021-06-23 10:20:19.646 HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2021-06-22 18:29:46.813000 | 2021-06-23 10:20:19.646 HD Request # 27 | Completion time: 0s | 2021-06-23 10:20:19.646 HD Request # 27 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 27 | 2021-06-23 10:20:19.646 Removing historical data download ID 27. | 2021-06-23 10:20:19.646 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-23 10:20:19.646 Intraday chart data file opened for CLN21-NYMEX | 2021-06-23 10:20:19.646 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:19.646 Triggering next historical data download in queue. | 2021-06-23 10:20:19.646 No download requests in the queue to start downloads for. | 2021-06-23 10:20:19.646 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:19.662 Socket (3) | Closed. | 2021-06-23 10:20:19.662 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 10:20:19.740 SC Data - All Services | Real-time data for symbol CLN21-NYMEX has been restored. | 2021-06-23 10:20:19.740 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-23 10:20:19.740 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:19.740 Triggering next historical data download in queue. | 2021-06-23 10:20:19.740 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 10:20:19.740 Added historical Intraday data request for CLQ21-NYMEX to the queue. | 2021-06-23 10:20:19.740 Intraday data recording state for symbol CLQ21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:19.740 HD Request # 28 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:19.740 HD Request # 28 | Download start date-time: 2021-06-22 14:29:46.000000. File last date-time: 2021-06-22 14:29:46.813000 | 2021-06-23 10:20:19.740 HD Request # 28 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:19.740 Socket (1) | Creating socket. | 2021-06-23 10:20:19.740 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:19.740 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:19.740 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 10:20:19.740 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 10:20:19.740 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 10:20:19.740 Added historical Intraday data request for ESU21-CME to the queue. | 2021-06-23 10:20:19.740 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-06-23 10:20:19.740 Triggering next historical data download in queue. | 2021-06-23 10:20:19.740 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 10:20:19.740 Added historical Intraday data request for HGN21-COMEX to the queue. | 2021-06-23 10:20:19.740 Intraday data recording state for symbol HGN21-COMEX is set to download 'Pending'. | 2021-06-23 10:20:19.740 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 10:20:19.740 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 10:20:19.740 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 10:20:19.740 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 10:20:19.740 Triggering next historical data download in queue. | 2021-06-23 10:20:19.740 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 10:20:19.740 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 10:20:19.755 Added historical Intraday data request for ZSN21-CBOT to the queue. | 2021-06-23 10:20:19.755 Intraday data recording state for symbol ZSN21-CBOT is set to download 'Pending'. | 2021-06-23 10:20:19.755 Triggering next historical data download in queue. | 2021-06-23 10:20:19.755 HD Request # 28 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:19.802 HD Request # 28 | Sending historical data logon request message. | 2021-06-23 10:20:19.802 HD Request # 28 | Requesting Intraday data. Start date-time: 2021-06-22 14:29:46. Record interval: 0. Symbol: CLN21 | 2021-06-23 10:20:19.833 HD Request # 28 | Decompressing data. | 2021-06-23 10:20:19.865 HD Request # 28 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-22 14:29:46.813000 | 2021-06-23 10:20:19.865 Socket (1) | CloseSocket call. | 2021-06-23 10:20:19.865 Historical data download thread signaled to stop. | 2021-06-23 10:20:19.865 HD Request # 28 | Received 1 record from 2021-06-22 14:29:46.813000 to 2021-06-22 14:29:46.813000 (0.0 seconds) and wrote 0 records for CLN21-NYMEX | 2021-06-23 10:20:19.865 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:19.865 HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2021-06-22 18:29:46.813000 | 2021-06-23 10:20:19.865 HD Request # 28 | Completion time: 0s | 2021-06-23 10:20:19.865 HD Request # 28 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 28 | 2021-06-23 10:20:19.865 Removing historical data download ID 28. | 2021-06-23 10:20:19.865 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-23 10:20:19.865 Intraday chart data file opened for CLN21-NYMEX | 2021-06-23 10:20:19.865 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:19.865 Triggering next historical data download in queue. | 2021-06-23 10:20:19.865 HD Request # 29 | Downloading Intraday chart data for CLQ21-NYMEX to the file CLQ21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:19.865 HD Request # 29 | Download start date-time: 2021-06-23 10:20:17.000000. File last date-time: 2021-06-23 10:20:17.216003 | 2021-06-23 10:20:19.865 HD Request # 29 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:19.865 Socket (3) | Creating socket. | 2021-06-23 10:20:19.865 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:19.865 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:19.865 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:19.896 Socket (1) | Closed. | 2021-06-23 10:20:19.896 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 10:20:19.927 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 10:20:19.927 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 10:20:19.927 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 10:20:19.927 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 10:20:19.927 HD Request # 29 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:19.927 HD Request # 29 | Sending historical data logon request message. | 2021-06-23 10:20:19.927 HD Request # 29 | Requesting Intraday data. Start date-time: 2021-06-23 10:20:17. Record interval: 0. Symbol: CLQ21 | 2021-06-23 10:20:19.958 HD Request # 29 | Decompressing data. | 2021-06-23 10:20:19.989 HD Request # 29 | Receiving Intraday data for CLQ21-NYMEX starting at 2021-06-23 10:20:17.111000 | 2021-06-23 10:20:19.989 Socket (3) | CloseSocket call. | 2021-06-23 10:20:19.989 Historical data download thread signaled to stop. | 2021-06-23 10:20:19.989 HD Request # 29 | Received 7 records from 2021-06-23 10:20:17.111000 to 2021-06-23 10:20:17.216003 (0.1 seconds) and wrote 0 records for CLQ21-NYMEX | 2021-06-23 10:20:19.989 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:19.989 HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:17.216003 | 2021-06-23 10:20:19.989 HD Request # 29 | Completion time: 0s | 2021-06-23 10:20:19.989 HD Request # 29 | Intraday data download complete for CLQ21-NYMEX. Unique request ID: 29 | 2021-06-23 10:20:19.989 Removing historical data download ID 29. | 2021-06-23 10:20:19.989 Real-time Intraday chart data file updates started for CLQ21-NYMEX | 2021-06-23 10:20:19.989 Intraday chart data file opened for CLQ21-NYMEX | 2021-06-23 10:20:19.989 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:19.989 Triggering next historical data download in queue. | 2021-06-23 10:20:19.989 HD Request # 30 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-06-23 10:20:19.989 HD Request # 30 | Download start date-time: 2021-06-23 10:20:18.000000. File last date-time: 2021-06-23 10:20:18.633001 | 2021-06-23 10:20:19.989 HD Request # 30 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:19.989 Socket (1) | Creating socket. | 2021-06-23 10:20:19.989 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:19.989 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:19.989 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 10:20:20.005 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:20.021 Socket (3) | Closed. | 2021-06-23 10:20:20.021 HD Request # 30 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:20.052 HD Request # 30 | Sending historical data logon request message. | 2021-06-23 10:20:20.052 HD Request # 30 | Requesting Intraday data. Start date-time: 2021-06-23 10:20:18. Record interval: 0. Symbol: ESU21 | 2021-06-23 10:20:20.067 HD Request # 30 | Decompressing data. | 2021-06-23 10:20:20.099 HD Request # 30 | Receiving Intraday data for ESU21-CME starting at 2021-06-23 10:20:18.633000 | 2021-06-23 10:20:20.099 Socket (1) | CloseSocket call. | 2021-06-23 10:20:20.099 Historical data download thread signaled to stop. | 2021-06-23 10:20:20.099 HD Request # 30 | Received 2 records from 2021-06-23 10:20:18.633000 to 2021-06-23 10:20:18.633001 (0.0 seconds) and wrote 0 records for ESU21-CME | 2021-06-23 10:20:20.099 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:20.099 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:18.633001 | 2021-06-23 10:20:20.099 HD Request # 30 | Completion time: 1s | 2021-06-23 10:20:20.099 HD Request # 30 | Intraday data download complete for ESU21-CME. Unique request ID: 30 | 2021-06-23 10:20:20.099 Removing historical data download ID 30. | 2021-06-23 10:20:20.099 Real-time Intraday chart data file updates started for ESU21-CME | 2021-06-23 10:20:20.099 Intraday chart data file opened for ESU21-CME | 2021-06-23 10:20:20.099 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:20.099 Triggering next historical data download in queue. | 2021-06-23 10:20:20.099 HD Request # 31 | Downloading Intraday chart data for HGN21-COMEX to the file HGN21-COMEX.scid. Service: comex | 2021-06-23 10:20:20.099 HD Request # 31 | Download start date-time: 2021-06-23 10:20:16.000000. File last date-time: 2021-06-23 10:20:16.842000 | 2021-06-23 10:20:20.099 HD Request # 31 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:20.099 Socket (3) | Creating socket. | 2021-06-23 10:20:20.099 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:20.099 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:20.099 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:20.130 Socket (1) | Closed. | 2021-06-23 10:20:20.130 HD Request # 31 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:20.177 HD Request # 31 | Sending historical data logon request message. | 2021-06-23 10:20:20.177 HD Request # 31 | Requesting Intraday data. Start date-time: 2021-06-23 10:20:16. Record interval: 0. Symbol: HGN21 | 2021-06-23 10:20:20.192 HD Request # 31 | Decompressing data. | 2021-06-23 10:20:20.223 HD Request # 31 | Receiving Intraday data for HGN21-COMEX starting at 2021-06-23 10:20:16.471000 | 2021-06-23 10:20:20.223 Socket (3) | CloseSocket call. | 2021-06-23 10:20:20.223 Historical data download thread signaled to stop. | 2021-06-23 10:20:20.223 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:20.223 HD Request # 31 | Received 2 records from 2021-06-23 10:20:16.471000 to 2021-06-23 10:20:16.842000 (0.4 seconds) and wrote 0 records for HGN21-COMEX | 2021-06-23 10:20:20.223 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:16.842000 | 2021-06-23 10:20:20.223 HD Request # 31 | Completion time: 0s | 2021-06-23 10:20:20.223 HD Request # 31 | Intraday data download complete for HGN21-COMEX. Unique request ID: 31 | 2021-06-23 10:20:20.223 Removing historical data download ID 31. | 2021-06-23 10:20:20.223 Real-time Intraday chart data file updates started for HGN21-COMEX | 2021-06-23 10:20:20.223 Intraday chart data file opened for HGN21-COMEX | 2021-06-23 10:20:20.223 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:20.223 Triggering next historical data download in queue. | 2021-06-23 10:20:20.223 HD Request # 32 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 10:20:20.223 HD Request # 32 | Download start date-time: 2021-06-23 10:19:56.000000. File last date-time: 2021-06-23 10:19:56.573002 | 2021-06-23 10:20:20.223 HD Request # 32 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 10:20:20.223 Socket (1) | Creating socket. | 2021-06-23 10:20:20.223 Socket (1) | New receive buffer size: 5242880 | 2021-06-23 10:20:20.223 Socket (1) | Connecting to IP: 216.1.90.129. | 2021-06-23 10:20:20.223 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:20.255 Socket (3) | Closed. | 2021-06-23 10:20:20.255 HD Request # 32 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:20.286 HD Request # 32 | Sending historical data logon request message. | 2021-06-23 10:20:20.286 Chart #4 has tagged chart #5 for full recalculation. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 10:20:20.301 HD Request # 32 | Requesting Intraday data. Start date-time: 2021-06-23 10:19:56. Record interval: 0. Symbol: NGN21 | 2021-06-23 10:20:20.317 HD Request # 32 | Decompressing data. | 2021-06-23 10:20:20.348 HD Request # 32 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 10:19:56.572000 | 2021-06-23 10:20:20.348 Socket (1) | CloseSocket call. | 2021-06-23 10:20:20.348 Historical data download thread signaled to stop. | 2021-06-23 10:20:20.348 HD Request # 32 | Received 4 records from 2021-06-23 10:19:56.572000 to 2021-06-23 10:19:56.573002 (0.0 seconds) and wrote 0 records for NGN21-NYMEX | 2021-06-23 10:20:20.348 Socket (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:20.348 HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:19:56.573002 | 2021-06-23 10:20:20.348 HD Request # 32 | Completion time: 0s | 2021-06-23 10:20:20.348 HD Request # 32 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 32 | 2021-06-23 10:20:20.348 Removing historical data download ID 32. | 2021-06-23 10:20:20.348 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 10:20:20.348 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 10:20:20.348 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:20.348 Triggering next historical data download in queue. | 2021-06-23 10:20:20.348 HD Request # 33 | Downloading Intraday chart data for ZSN21-CBOT to the file ZSN21-CBOT.scid. Service: cbot | 2021-06-23 10:20:20.348 HD Request # 33 | Download start date-time: 2021-06-23 10:20:13.000000. File last date-time: 2021-06-23 10:20:13.931000 | 2021-06-23 10:20:20.348 HD Request # 33 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 10:20:20.348 Socket (3) | Creating socket. | 2021-06-23 10:20:20.348 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 10:20:20.348 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 10:20:20.348 Socket (1) | Socket gracefully closed by remote side. | 2021-06-23 10:20:20.364 Socket (1) | Closed. | 2021-06-23 10:20:20.364 NGN21-NYMEX 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 10:20:20.411 HD Request # 33 | Setting DTC encoding to Binary VLS | 2021-06-23 10:20:20.411 HD Request # 33 | Sending historical data logon request message. | 2021-06-23 10:20:20.411 HD Request # 33 | Requesting Intraday data. Start date-time: 2021-06-23 10:20:13. Record interval: 0. Symbol: ZSN21 | 2021-06-23 10:20:20.442 HD Request # 33 | Decompressing data. | 2021-06-23 10:20:20.473 HD Request # 33 | Receiving Intraday data for ZSN21-CBOT starting at 2021-06-23 10:20:13.931000 | 2021-06-23 10:20:20.473 Socket (3) | CloseSocket call. | 2021-06-23 10:20:20.473 Historical data download thread signaled to stop. | 2021-06-23 10:20:20.473 HD Request # 33 | Received 1 record from 2021-06-23 10:20:13.931000 to 2021-06-23 10:20:13.931000 (0.0 seconds) and wrote 0 records for ZSN21-CBOT | 2021-06-23 10:20:20.473 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 10:20:20.473 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2021-06-23 14:20:13.931000 | 2021-06-23 10:20:20.473 HD Request # 33 | Completion time: 0s | 2021-06-23 10:20:20.473 HD Request # 33 | Intraday data download complete for ZSN21-CBOT. Unique request ID: 33 | 2021-06-23 10:20:20.473 Removing historical data download ID 33. | 2021-06-23 10:20:20.473 Real-time Intraday chart data file updates started for ZSN21-CBOT | 2021-06-23 10:20:20.473 Intraday chart data file opened for ZSN21-CBOT | 2021-06-23 10:20:20.473 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2021-06-23 10:20:20.473 Triggering next historical data download in queue. | 2021-06-23 10:20:20.473 No download requests in the queue to start downloads for. | 2021-06-23 10:20:20.473 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 10:20:20.489 Socket (3) | Closed. | 2021-06-23 10:20:20.489 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\CLQ21-NYMEX.scid. Thread ID: 5936 | 2021-06-23 10:20:20.988 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\NGN21-NYMEX.scid. Thread ID: 5936 | 2021-06-23 10:20:26.058 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\HGN21-COMEX.scid. Thread ID: 5936 | 2021-06-23 10:20:26.058 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\ESU21-CME.scid. Thread ID: 5936 | 2021-06-23 10:20:26.058 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\ZSN21-CBOT.scid. Thread ID: 5936 | 2021-06-23 10:20:26.058 Requesting current DateTime from Sierra Chart server. | 2021-06-23 10:34:15.066 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-23 14:34:15.466. Round-trip delay: 00:00:00.202 | 2021-06-23 10:34:15.472 Computer time to server time difference: 00:00:00.005 | 2021-06-23 10:34:15.472 Successfully set the system Date-time to: 2021-06-23 14:34:15.466 UTC. | 2021-06-23 10:34:15.466 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-23 11:14:54.326 SC Data - All Services | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-23 11:14:54.326 SC Data - All Services | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-23 11:14:54.326 SC Data - All Services | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-23 11:14:54.326 SC Data - All Services | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-23 11:14:54.326 SC Data - All Services | Real-time data for symbol CLN21-NYMEX is currently unavailable. | 2021-06-23 11:14:54.326 SC Data - All Services | Market data feed reported to be lost. | 2021-06-23 11:14:54.342 DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-23 11:14:54.342 DTC Client socket (2) | CloseSocket call. | 2021-06-23 11:14:54.342 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 11:14:54.342 DTC Client socket (2) | Closed. | 2021-06-23 11:14:54.342 Connection to the external service has been lost. | 2021-06-23 11:14:54.342 SC Data - All Services | Waiting for socket receive thread to end | 2021-06-23 11:14:54.357 DTC Client socket (0) | CloseSocket call. | 2021-06-23 11:14:54.357 SC Data - All Services | Disconnected. | 2021-06-23 11:14:54.389 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:14:54.389 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 11:14:57.399 DTC Client socket (1) | Creating socket. | 2021-06-23 11:14:57.399 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 11:14:57.399 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 11:14:57.399 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 11:14:58.418 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 11:14:58.418 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 11:14:58.418 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:14:58.418 DTC Client socket (1) | Closed. | 2021-06-23 11:14:58.418 DTC Client socket (0) | CloseSocket call. | 2021-06-23 11:14:58.428 SC Data - All Services | Disconnected. | 2021-06-23 11:14:58.428 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:14:58.428 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 11:15:01.433 DTC Client socket (1) | Creating socket. | 2021-06-23 11:15:01.433 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 11:15:01.433 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 11:15:01.433 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 11:15:02.462 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 11:15:02.462 DTC Client socket (1) | Closed. | 2021-06-23 11:15:02.462 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 11:15:02.462 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:15:02.462 DTC Client socket (0) | CloseSocket call. | 2021-06-23 11:15:02.478 SC Data - All Services | Disconnected. | 2021-06-23 11:15:02.478 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:15:02.478 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 11:15:05.489 DTC Client socket (1) | Creating socket. | 2021-06-23 11:15:05.489 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 11:15:05.489 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 11:15:05.489 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 11:15:06.518 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 11:15:06.518 DTC Client socket (1) | Closed. | 2021-06-23 11:15:06.518 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 11:15:06.518 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:15:06.518 DTC Client socket (0) | CloseSocket call. | 2021-06-23 11:15:06.534 SC Data - All Services | Disconnected. | 2021-06-23 11:15:06.534 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:15:06.534 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 11:15:09.557 DTC Client socket (1) | Creating socket. | 2021-06-23 11:15:09.557 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 11:15:09.557 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 11:15:09.557 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 11:15:10.586 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 11:15:10.586 DTC Client socket (1) | Closed. | 2021-06-23 11:15:10.586 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 11:15:10.586 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:15:10.586 DTC Client socket (0) | CloseSocket call. | 2021-06-23 11:15:10.602 SC Data - All Services | Disconnected. | 2021-06-23 11:15:10.602 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:15:10.602 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 11:15:13.613 DTC Client socket (1) | Creating socket. | 2021-06-23 11:15:13.613 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 11:15:13.613 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 11:15:13.613 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-23 11:15:14.642 * DTC Client socket (1) | CloseSocket call. | 2021-06-23 11:15:14.642 DTC Client socket (1) | Closed. | 2021-06-23 11:15:14.642 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-23 11:15:14.642 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:15:14.642 DTC Client socket (0) | CloseSocket call. | 2021-06-23 11:15:14.658 SC Data - All Services | Disconnected. | 2021-06-23 11:15:14.658 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-23 11:15:14.658 SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-23 11:15:17.669 DTC Client socket (1) | Creating socket. | 2021-06-23 11:15:17.669 DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-23 11:15:17.669 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-23 11:15:17.669 SC Data - All Services | Network connection to server complete. | 2021-06-23 11:15:17.669 SC Data - All Services | Starting socket receive thread. | 2021-06-23 11:15:17.669 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: none | 2021-06-23 11:15:17.669 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-23 11:15:17.669 SC Data - All Services | Sending logon request message. | 2021-06-23 11:15:17.669 SC Data - All Services | Message from server: Connecting to primary Data/Trading service. | 2021-06-23 11:15:17.669 SC Data - All Services | Received logon response. | 2021-06-23 11:15:17.669 SC Data - All Services | Server Name: SC DTC Server. | 2021-06-23 11:15:17.669 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 11:15:17.669 SC Data - All Services | Successfully connected. Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices. | 2021-06-23 11:15:17.669 SC Data - All Services | Trading is supported. | 2021-06-23 11:15:17.669 SC Data - All Services | Order cancel and replace is supported. | 2021-06-23 11:15:17.669 SC Data - All Services | OCO Orders supported. | 2021-06-23 11:15:17.669 SC Data - All Services | Bracket Orders supported. | 2021-06-23 11:15:17.669 SC Data - All Services | Connected to server complete. | 2021-06-23 11:15:17.669 Triggering next historical data download in queue. | 2021-06-23 11:15:17.669 Triggering next historical data download in queue. | 2021-06-23 11:15:17.669 Triggering next historical data download in queue. | 2021-06-23 11:15:17.669 Triggering next historical data download in queue. | 2021-06-23 11:15:17.669 No download requests in the queue to start downloads for. | 2021-06-23 11:15:17.669 No download requests in the queue to start downloads for. | 2021-06-23 11:15:17.669 No download requests in the queue to start downloads for. | 2021-06-23 11:15:17.669 No download requests in the queue to start downloads for. | 2021-06-23 11:15:17.669 SC Data - All Services | Starting real-time market data updates for: ESU21-CME. ID: 1 | 2021-06-23 11:15:17.700 SC Data - All Services | Requesting security definition data for: ESU21-CME. ID: 1 | 2021-06-23 11:15:17.700 Added historical Intraday data request for ESU21-CME to the queue. | 2021-06-23 11:15:17.700 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-06-23 11:15:17.700 Triggering next historical data download in queue. | 2021-06-23 11:15:17.700 Delaying start of download for ESU21-CME | 2021-06-23 11:15:17.700 Requesting market depth updates for: ESU21-CME if supported. | 2021-06-23 11:15:17.700 SC Data - All Services | Starting market orders updates for: ESU21-CME. MinimumMarketByOrderQuantity: 0 | 2021-06-23 11:15:17.700 SC Data - All Services | Starting real-time market data updates for: ZSN21-CBOT. ID: 2 | 2021-06-23 11:15:17.700 SC Data - All Services | Requesting security definition data for: ZSN21-CBOT. ID: 2 | 2021-06-23 11:15:17.700 Requesting market depth updates for: ZSN21-CBOT if supported. | 2021-06-23 11:15:17.700 SC Data - All Services | Starting market orders updates for: ZSN21-CBOT. MinimumMarketByOrderQuantity: 0 | 2021-06-23 11:15:17.700 Added historical Intraday data request for ZSN21-CBOT to the queue. | 2021-06-23 11:15:17.700 Intraday data recording state for symbol ZSN21-CBOT is set to download 'Pending'. | 2021-06-23 11:15:17.700 Triggering next historical data download in queue. | 2021-06-23 11:15:17.700 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 11:15:17.700 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\ESU21-CME.2021-06-23.depth | 2021-06-23 11:15:17.700 SC Data - All Services | Starting real-time market data updates for: NGN21-NYMEX. ID: 3 | 2021-06-23 11:15:17.700 SC Data - All Services | Requesting security definition data for: NGN21-NYMEX. ID: 3 | 2021-06-23 11:15:17.700 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 11:15:17.700 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 11:15:17.700 Triggering next historical data download in queue. | 2021-06-23 11:15:17.700 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 11:15:17.700 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 11:15:17.700 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\ZSN21-CBOT.2021-06-23.depth | 2021-06-23 11:15:17.700 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 11:15:17.700 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\NGN21-NYMEX.2021-06-23.depth | 2021-06-23 11:15:17.700 SC Data - All Services | Starting real-time market data updates for: CLQ21-NYMEX. ID: 4 | 2021-06-23 11:15:17.700 SC Data - All Services | Requesting security definition data for: CLQ21-NYMEX. ID: 4 | 2021-06-23 11:15:17.700 Requesting market depth updates for: CLQ21-NYMEX if supported. | 2021-06-23 11:15:17.700 SC Data - All Services | Starting market orders updates for: CLQ21-NYMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 11:15:17.700 Added historical Intraday data request for CLQ21-NYMEX to the queue. | 2021-06-23 11:15:17.700 Intraday data recording state for symbol CLQ21-NYMEX is set to download 'Pending'. | 2021-06-23 11:15:17.700 Triggering next historical data download in queue. | 2021-06-23 11:15:17.700 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 11:15:17.700 Requesting market depth updates for: NGN21-NYMEX if supported. | 2021-06-23 11:15:17.700 SC Data - All Services | Starting market orders updates for: NGN21-NYMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 11:15:17.700 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 11:15:17.715 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 11:15:17.715 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\CLQ21-NYMEX.2021-06-23.depth | 2021-06-23 11:15:17.715 SC Data - All Services | Starting real-time market data updates for: CLN21-NYMEX. ID: 5 | 2021-06-23 11:15:17.715 SC Data - All Services | Requesting security definition data for: CLN21-NYMEX. ID: 5 | 2021-06-23 11:15:17.715 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-23 11:15:17.715 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-23 11:15:17.715 Triggering next historical data download in queue. | 2021-06-23 11:15:17.715 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 11:15:17.715 SC Data - All Services | Starting real-time market data updates for: HGN21-COMEX. ID: 6 | 2021-06-23 11:15:17.715 SC Data - All Services | Requesting security definition data for: HGN21-COMEX. ID: 6 | 2021-06-23 11:15:17.715 Requesting market depth updates for: HGN21-COMEX if supported. | 2021-06-23 11:15:17.715 SC Data - All Services | Starting market orders updates for: HGN21-COMEX. MinimumMarketByOrderQuantity: 0 | 2021-06-23 11:15:17.715 Added historical Intraday data request for HGN21-COMEX to the queue. | 2021-06-23 11:15:17.715 Intraday data recording state for symbol HGN21-COMEX is set to download 'Pending'. | 2021-06-23 11:15:17.715 Triggering next historical data download in queue. | 2021-06-23 11:15:17.715 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 11:15:17.715 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 11:15:17.715 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 11:15:17.793 Opened cached Depth file: C:\SierraChart\SierraChartInstance_3\Data\MarketDepthData\HGN21-COMEX.2021-06-23.depth | 2021-06-23 11:15:17.793 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 11:15:18.542 SC Data - All Services | Real-time data for symbol CLN21-NYMEX has been restored. | 2021-06-23 11:15:18.542 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 11:15:18.542 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 11:15:18.542 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 11:15:18.542 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 11:15:18.542 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 11:15:18.542 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 11:15:18.542 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 11:15:18.542 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 11:15:18.542 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 11:15:18.542 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 11:15:18.698 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 11:15:18.698 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 11:15:18.698 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 11:15:18.761 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 11:15:18.761 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 11:15:18.761 HD Request # 34 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-06-23 11:15:22.099 HD Request # 34 | Download start date-time: 2021-06-23 11:14:53.000000. File last date-time: 2021-06-23 11:14:53.737002 | 2021-06-23 11:15:22.099 HD Request # 34 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 11:15:22.099 Socket (2) | Creating socket. | 2021-06-23 11:15:22.099 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 11:15:22.099 Socket (2) | Connecting to IP: 216.1.90.129. | 2021-06-23 11:15:22.099 HD Request # 34 | Setting DTC encoding to Binary VLS | 2021-06-23 11:15:22.146 HD Request # 34 | Sending historical data logon request message. | 2021-06-23 11:15:22.146 HD Request # 34 | Requesting Intraday data. Start date-time: 2021-06-23 11:14:53. Record interval: 0. Symbol: ESU21 | 2021-06-23 11:15:22.624 HD Request # 34 | Decompressing data. | 2021-06-23 11:15:22.655 HD Request # 34 | Receiving Intraday data for ESU21-CME starting at 2021-06-23 11:14:53.737000 | 2021-06-23 11:15:22.655 Socket (2) | CloseSocket call. | 2021-06-23 11:15:22.655 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:15:22.655 Historical data download thread signaled to stop. | 2021-06-23 11:15:22.655 HD Request # 34 | Timestamp of first Intraday data file record written: 2021-06-23 11:14:54.181000 | 2021-06-23 11:15:22.655 HD Request # 34 | Received 354 records from 2021-06-23 11:14:53.737000 to 2021-06-23 11:15:19.412000 (25.7 seconds) and wrote 351 records for ESU21-CME | 2021-06-23 11:15:22.655 HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2021-06-23 15:15:19.412000 | 2021-06-23 11:15:22.655 Added 41 Time and Sales records to Intraday data file for ESU21-CME after download. | 2021-06-23 11:15:22.655 HD Request # 34 | Completion time: 0s | 2021-06-23 11:15:22.655 HD Request # 34 | Intraday data download complete for ESU21-CME. Unique request ID: 34 | 2021-06-23 11:15:22.655 Removing historical data download ID 34. | 2021-06-23 11:15:22.655 Real-time Intraday chart data file updates started for ESU21-CME | 2021-06-23 11:15:22.655 Intraday chart data file opened for ESU21-CME | 2021-06-23 11:15:22.655 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2021-06-23 11:15:22.655 Triggering next historical data download in queue. | 2021-06-23 11:15:22.655 HD Request # 35 | Downloading Intraday chart data for ZSN21-CBOT to the file ZSN21-CBOT.scid. Service: cbot | 2021-06-23 11:15:22.655 HD Request # 35 | Download start date-time: 2021-06-23 11:14:52.000000. File last date-time: 2021-06-23 11:14:52.360000 | 2021-06-23 11:15:22.671 HD Request # 35 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 11:15:22.671 Socket (3) | Creating socket. | 2021-06-23 11:15:22.671 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 11:15:22.671 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 11:15:22.671 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 11:15:22.686 Socket (2) | Closed. | 2021-06-23 11:15:22.686 HD Request # 35 | Setting DTC encoding to Binary VLS | 2021-06-23 11:15:22.733 HD Request # 35 | Sending historical data logon request message. | 2021-06-23 11:15:22.733 HD Request # 35 | Requesting Intraday data. Start date-time: 2021-06-23 11:14:52. Record interval: 0. Symbol: ZSN21 | 2021-06-23 11:15:23.217 HD Request # 35 | Decompressing data. | 2021-06-23 11:15:23.248 HD Request # 35 | Receiving Intraday data for ZSN21-CBOT starting at 2021-06-23 11:14:52.360000 | 2021-06-23 11:15:23.248 Socket (3) | CloseSocket call. | 2021-06-23 11:15:23.248 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:15:23.248 Historical data download thread signaled to stop. | 2021-06-23 11:15:23.248 HD Request # 35 | Timestamp of first Intraday data file record written: 2021-06-23 11:14:56.341000 | 2021-06-23 11:15:23.248 HD Request # 35 | Received 36 records from 2021-06-23 11:14:52.360000 to 2021-06-23 11:15:19.622000 (27.3 seconds) and wrote 35 records for ZSN21-CBOT | 2021-06-23 11:15:23.248 HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2021-06-23 15:15:19.622000 | 2021-06-23 11:15:23.248 Added 3 Time and Sales records to Intraday data file for ZSN21-CBOT after download. | 2021-06-23 11:15:23.248 HD Request # 35 | Completion time: 1s | 2021-06-23 11:15:23.248 HD Request # 35 | Intraday data download complete for ZSN21-CBOT. Unique request ID: 35 | 2021-06-23 11:15:23.248 Removing historical data download ID 35. | 2021-06-23 11:15:23.248 Real-time Intraday chart data file updates started for ZSN21-CBOT | 2021-06-23 11:15:23.248 Intraday chart data file opened for ZSN21-CBOT | 2021-06-23 11:15:23.248 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2021-06-23 11:15:23.248 Triggering next historical data download in queue. | 2021-06-23 11:15:23.248 HD Request # 36 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 11:15:23.248 HD Request # 36 | Download start date-time: 2021-06-23 11:14:49.000000. File last date-time: 2021-06-23 11:14:49.824000 | 2021-06-23 11:15:23.248 HD Request # 36 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 11:15:23.248 Socket (2) | Creating socket. | 2021-06-23 11:15:23.248 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 11:15:23.248 Socket (2) | Connecting to IP: 216.1.90.129. | 2021-06-23 11:15:23.248 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 11:15:23.279 Socket (3) | Closed. | 2021-06-23 11:15:23.279 HD Request # 36 | Setting DTC encoding to Binary VLS | 2021-06-23 11:15:23.310 HD Request # 36 | Sending historical data logon request message. | 2021-06-23 11:15:23.310 HD Request # 36 | Requesting Intraday data. Start date-time: 2021-06-23 11:14:49. Record interval: 0. Symbol: NGN21 | 2021-06-23 11:15:23.342 HD Request # 36 | Decompressing data. | 2021-06-23 11:15:23.373 HD Request # 36 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 11:14:49.824000 | 2021-06-23 11:15:23.373 Socket (2) | CloseSocket call. | 2021-06-23 11:15:23.373 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:15:23.373 Historical data download thread signaled to stop. | 2021-06-23 11:15:23.373 HD Request # 36 | Timestamp of first Intraday data file record written: 2021-06-23 11:14:57.434000 | 2021-06-23 11:15:23.373 HD Request # 36 | Received 25 records from 2021-06-23 11:14:49.824000 to 2021-06-23 11:15:19.229000 (29.4 seconds) and wrote 24 records for NGN21-NYMEX | 2021-06-23 11:15:23.373 HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2021-06-23 15:15:19.229000 | 2021-06-23 11:15:23.373 HD Request # 36 | Completion time: 0s | 2021-06-23 11:15:23.373 HD Request # 36 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 36 | 2021-06-23 11:15:23.373 Removing historical data download ID 36. | 2021-06-23 11:15:23.373 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 11:15:23.373 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 11:15:23.373 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2021-06-23 11:15:23.373 Triggering next historical data download in queue. | 2021-06-23 11:15:23.373 HD Request # 37 | Downloading Intraday chart data for CLQ21-NYMEX to the file CLQ21-NYMEX.scid. Service: nymex | 2021-06-23 11:15:23.373 HD Request # 37 | Download start date-time: 2021-06-23 11:14:53.000000. File last date-time: 2021-06-23 11:14:53.248000 | 2021-06-23 11:15:23.373 HD Request # 37 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 11:15:23.373 Socket (3) | Creating socket. | 2021-06-23 11:15:23.373 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 11:15:23.373 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 11:15:23.373 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 11:15:23.388 Socket (2) | Closed. | 2021-06-23 11:15:23.388 HD Request # 37 | Setting DTC encoding to Binary VLS | 2021-06-23 11:15:23.451 HD Request # 37 | Sending historical data logon request message. | 2021-06-23 11:15:23.451 HD Request # 37 | Requesting Intraday data. Start date-time: 2021-06-23 11:14:53. Record interval: 0. Symbol: CLQ21 | 2021-06-23 11:15:23.466 HD Request # 37 | Decompressing data. | 2021-06-23 11:15:23.498 HD Request # 37 | Receiving Intraday data for CLQ21-NYMEX starting at 2021-06-23 11:14:53.221000 | 2021-06-23 11:15:23.498 Socket (3) | CloseSocket call. | 2021-06-23 11:15:23.498 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:15:23.498 Historical data download thread signaled to stop. | 2021-06-23 11:15:23.498 HD Request # 37 | Timestamp of first Intraday data file record written: 2021-06-23 11:14:54.462000 | 2021-06-23 11:15:23.498 HD Request # 37 | Received 409 records from 2021-06-23 11:14:53.221000 to 2021-06-23 11:15:23.116000 (29.9 seconds) and wrote 355 records for CLQ21-NYMEX | 2021-06-23 11:15:23.498 HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2021-06-23 15:15:23.116000 | 2021-06-23 11:15:23.513 Added 2 Time and Sales records to Intraday data file for CLQ21-NYMEX after download. | 2021-06-23 11:15:23.513 HD Request # 37 | Completion time: 0s | 2021-06-23 11:15:23.513 HD Request # 37 | Intraday data download complete for CLQ21-NYMEX. Unique request ID: 37 | 2021-06-23 11:15:23.513 Removing historical data download ID 37. | 2021-06-23 11:15:23.513 Real-time Intraday chart data file updates started for CLQ21-NYMEX | 2021-06-23 11:15:23.513 Intraday chart data file opened for CLQ21-NYMEX | 2021-06-23 11:15:23.513 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2021-06-23 11:15:23.513 Triggering next historical data download in queue. | 2021-06-23 11:15:23.513 HD Request # 38 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-23 11:15:23.513 HD Request # 38 | Download start date-time: 2021-06-22 14:29:46.000000. File last date-time: 2021-06-22 14:29:46.813000 | 2021-06-23 11:15:23.513 HD Request # 38 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 11:15:23.513 Socket (2) | Creating socket. | 2021-06-23 11:15:23.513 Socket (2) | New receive buffer size: 5242880 | 2021-06-23 11:15:23.513 Socket (2) | Connecting to IP: 216.1.90.129. | 2021-06-23 11:15:23.513 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 11:15:23.529 Socket (3) | Closed. | 2021-06-23 11:15:23.529 HD Request # 38 | Setting DTC encoding to Binary VLS | 2021-06-23 11:15:23.576 HD Request # 38 | Sending historical data logon request message. | 2021-06-23 11:15:23.576 HD Request # 38 | Requesting Intraday data. Start date-time: 2021-06-22 14:29:46. Record interval: 0. Symbol: CLN21 | 2021-06-23 11:15:23.607 HD Request # 38 | Decompressing data. | 2021-06-23 11:15:23.622 HD Request # 38 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-22 14:29:46.813000 | 2021-06-23 11:15:23.622 Socket (2) | CloseSocket call. | 2021-06-23 11:15:23.622 Historical data download thread signaled to stop. | 2021-06-23 11:15:23.622 Socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:15:23.622 HD Request # 38 | Received 1 record from 2021-06-22 14:29:46.813000 to 2021-06-22 14:29:46.813000 (0.0 seconds) and wrote 0 records for CLN21-NYMEX | 2021-06-23 11:15:23.622 HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2021-06-22 18:29:46.813000 | 2021-06-23 11:15:23.622 HD Request # 38 | Completion time: 0s | 2021-06-23 11:15:23.622 HD Request # 38 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 38 | 2021-06-23 11:15:23.622 Removing historical data download ID 38. | 2021-06-23 11:15:23.622 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-23 11:15:23.622 Intraday chart data file opened for CLN21-NYMEX | 2021-06-23 11:15:23.622 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2021-06-23 11:15:23.622 Triggering next historical data download in queue. | 2021-06-23 11:15:23.622 HD Request # 39 | Downloading Intraday chart data for HGN21-COMEX to the file HGN21-COMEX.scid. Service: comex | 2021-06-23 11:15:23.622 HD Request # 39 | Download start date-time: 2021-06-23 11:14:52.000000. File last date-time: 2021-06-23 11:14:52.730002 | 2021-06-23 11:15:23.622 HD Request # 39 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 11:15:23.622 Socket (3) | Creating socket. | 2021-06-23 11:15:23.622 Socket (3) | New receive buffer size: 5242880 | 2021-06-23 11:15:23.622 Socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 11:15:23.622 Socket (2) | Socket gracefully closed by remote side. | 2021-06-23 11:15:23.654 Socket (2) | Closed. | 2021-06-23 11:15:23.654 HD Request # 39 | Setting DTC encoding to Binary VLS | 2021-06-23 11:15:23.685 HD Request # 39 | Sending historical data logon request message. | 2021-06-23 11:15:23.685 HD Request # 39 | Requesting Intraday data. Start date-time: 2021-06-23 11:14:52. Record interval: 0. Symbol: HGN21 | 2021-06-23 11:15:23.716 HD Request # 39 | Decompressing data. | 2021-06-23 11:15:23.747 HD Request # 39 | Receiving Intraday data for HGN21-COMEX starting at 2021-06-23 11:14:52.730000 | 2021-06-23 11:15:23.747 Socket (3) | CloseSocket call. | 2021-06-23 11:15:23.747 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:15:23.747 Historical data download thread signaled to stop. | 2021-06-23 11:15:23.747 HD Request # 39 | Timestamp of first Intraday data file record written: 2021-06-23 11:14:54.792000 | 2021-06-23 11:15:23.747 HD Request # 39 | Received 35 records from 2021-06-23 11:14:52.730000 to 2021-06-23 11:15:19.215001 (26.5 seconds) and wrote 32 records for HGN21-COMEX | 2021-06-23 11:15:23.747 HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2021-06-23 15:15:19.215001 | 2021-06-23 11:15:23.747 HD Request # 39 | Completion time: 0s | 2021-06-23 11:15:23.747 HD Request # 39 | Intraday data download complete for HGN21-COMEX. Unique request ID: 39 | 2021-06-23 11:15:23.747 Removing historical data download ID 39. | 2021-06-23 11:15:23.747 Real-time Intraday chart data file updates started for HGN21-COMEX | 2021-06-23 11:15:23.747 Intraday chart data file opened for HGN21-COMEX | 2021-06-23 11:15:23.747 HD Request # 39 | Enabling Intraday chart updating for symbol. | 2021-06-23 11:15:23.747 Triggering next historical data download in queue. | 2021-06-23 11:15:23.747 No download requests in the queue to start downloads for. | 2021-06-23 11:15:23.747 Socket (3) | Socket gracefully closed by remote side. | 2021-06-23 11:15:23.778 Socket (3) | Closed. | 2021-06-23 11:15:23.778 Chart #4 has tagged chart #5 for full recalculation. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 11:15:23.794 NGN21-NYMEX 30 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: WK_Heatmap_Tic_04_2021.Cht | 2021-06-23 11:15:23.903 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\ESU21-CME.scid. Thread ID: 5936 | 2021-06-23 11:15:26.508 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\ZSN21-CBOT.scid. Thread ID: 5936 | 2021-06-23 11:15:26.508 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\CLQ21-NYMEX.scid. Thread ID: 5936 | 2021-06-23 11:15:26.508 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\HGN21-COMEX.scid. Thread ID: 5936 | 2021-06-23 11:15:31.578 Opened cached Intraday file: C:\SierraChart\SierraChartInstance_3\Data\NGN21-NYMEX.scid. Thread ID: 5936 | 2021-06-23 11:16:02.358  |
|   [2021-06-23 18:41:22]     |
| Sierra_Chart Engineering - Posts: 21299 |
                This  is a very unusual problem to be having: SC Data - All Services | Market data feed reported to be lost. | 2021-06-23 11:14:54.342
DTC Client socket (2) | Socket gracefully closed by remote side. | 2021-06-23 11:14:54.342 DTC Client socket (2) | CloseSocket call. | 2021-06-23 11:14:54.342 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 11:14:54.342 DTC Client socket (2) | Closed. | 2021-06-23 11:14:54.342 Connection to the external service has been lost. | 2021-06-23 11:14:54.342 We have never seen this before. No one else is having any issue like this. We need to see the Message Log from the main instance of Sierra Chart at the time this happens. First clear the log though: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log And then when the disconnection occurs provide the Message Log from the main instance of Sierra Chart. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-23 18:41:53
|   [2021-06-23 19:03:06]     |
| User664240 - Posts: 209 |
                Are you saying wait until SC disconnects, In other words the problem I had this morning? If not here's the cleared Log from the Main instance. And so were clear the Dis/Rec issue from this Morning stopped and SC stabilized when I removed the MBO columns from the DOM. Could be coincidental? Software version: 2276 64-bit | 2021-06-23 14:58:13.171 Safe Mode enabled | 2021-06-23 14:58:13.171 Primary Thread ID: 5044 | 2021-06-23 14:58:13.171 Usage end date: 2021-07-19 | 2021-06-23 14:58:13.171 Enabled for: Advanced Features 2. | 2021-06-23 14:58:13.171 Enabled for: Sierra Chart Historical Data Service. | 2021-06-23 14:58:13.171 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-23 14:58:13.171 Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-23 14:58:13.171 Enabled for exchange2: CME (Trading Account Required) | 2021-06-23 14:58:13.171 Enabled for exchange2: CBOT (Trading Account Required) | 2021-06-23 14:58:13.171 Enabled for exchange2: COMEX (Trading Account Required) | 2021-06-23 14:58:13.171 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-06-23 14:58:13.171 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-23 14:58:13.171 Current selected Data/Trading service: SC Data - All Services | 2021-06-23 14:58:13.171 Custom symbol settings values: disabled | 2021-06-23 14:58:13.171 Chart Update Interval: 100 | 2021-06-23 14:58:13.171 Intraday Data Storage Time Unit: 0 | 2021-06-23 14:58:13.171 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-06-23 14:58:13.171 2021-06-23 18:58:13 Local computer time in UTC | 2021-06-23 14:58:13.171 2021-06-23 14:58:13 Local computer time in SC Time Zone | 2021-06-23 14:58:13.171 2021-06-23 15:15:16 Server time in UTC | 2021-06-23 14:58:13.171 Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-06-23 14:58:13.171 Program path: C:\SierraChart\ | 2021-06-23 14:58:13.171 Data Files path: C:\SierraChart\Data\ | 2021-06-23 14:58:13.171 OS Version Number: 6.1 | 2021-06-23 14:58:13.171 Locale Setting: C | 2021-06-23 14:58:13.171 DLLs: CrystalPalaceStudies_2217_64.dll, mboxhistogram_64.dll, Norvik_2151_64.dll, OFA Bars (by Zdislav)_2151_64.dll, Trade_Your_Plan_2151_64.dll, TradingriotSuite_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, zyp sierra free 2021_2151_64.dll, zyp sierra free_2151_64.dll | 2021-06-23 14:58:13.171 Allowed protected custom studies: zyp_app, zyp_download_free, zyp_download_free_2, zyp_mod_1 | 2021-06-23 14:58:13.171  |
|   [2021-06-23 19:07:13]     |
                You might have a tendency to look to the custom studies as causing the issue But I can say with certainty that this morning I switched to safe mode and the problem persisted.
|   [2021-06-23 19:16:17]     |
                I added back the MBO columns in the DOM hoping to recreate the issue but nothing yet But I can say the MBO filter for ES is set to 20 under the symbol settings TAB and yet I'm seeing 4 and above
|   [2021-06-23 19:21:36]     |
| John - SC Support - Posts: 42737 |
Are you using a Trade and Current Quote Symbol without the option enabled for Use as Trade Symbol Only? If so, then keep in mind that the depth data is from the defined Trade and Current Quote Symbol and you would need to change the symbol settings for that symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-06-23 20:35:40]     |
                Nothing of the sort....I haven't change ant settings WRT to the MBO only remove the columns and than added them back hoping to recreate the Dis/Recon issue. This Morning the MBO columns were populated with => 4 order size See Scrn Shts Date Time Of Last Edit: 2021-06-23 20:40:07
|   [2021-06-23 20:41:39]     |
                Did you uncheck the option for Global Settings >> Symbol Settings >> Use Custom Symbol Settings Values?
|   [2021-06-23 20:47:17]     |
                yes...AH  so those settings I changed are no longer in use HMM so we can't figure out why symbols are automatically changing to gibberish "UTES" so we uncheck "use custom settings" and now we can't filter the MBO...frustrating.
|   [2021-06-23 20:48:37]     |
                I'm still running the main instance in safe mode FWIW
|   [2021-06-23 21:13:16]     |
                Ok, good. Let us know when you have the issue and post your logs.
|   [2021-06-23 22:42:22]     |
                Ok to summarize I checked the "Use custom symbol" to  Filter the MBO in the Main instance but unchecked in the Sub Instances where I don't trade from. And if and when the issue arises I'll send you the Log of the Main and sub instance.
|   [2021-06-25 17:46:16]     |
                HERE GO JUST POP UP ... Created the DTC Protocol server. | 2021-06-23 16:49:24.279 DTC Protocol Server listening on port 11099. | 2021-06-23 16:49:24.279 Reading Internal Order ID file. | 2021-06-23 16:49:24.279 Reading Trade Orders file. | 2021-06-23 16:49:24.309 Reading Trade Positions file. | 2021-06-23 16:49:24.309 Reading Trade Account Data files. | 2021-06-23 16:49:24.309 UDPListener (1120). Port 22904 | Listening on UDP port 22904. | 2021-06-23 16:49:24.319 Software version: 2276 64-bit | 2021-06-23 16:49:24.319 Safe Mode enabled | 2021-06-23 16:49:24.319 Primary Thread ID: 2064 | 2021-06-23 16:49:24.319 Usage end date: 2021-07-19 | 2021-06-23 16:49:24.319 Enabled for: Advanced Features 2. | 2021-06-23 16:49:24.319 Enabled for: Sierra Chart Historical Data Service. | 2021-06-23 16:49:24.319 Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-23 16:49:24.319 Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-23 16:49:24.319 Enabled for exchange2: CME (Trading Account Required) | 2021-06-23 16:49:24.319 Enabled for exchange2: CBOT (Trading Account Required) | 2021-06-23 16:49:24.319 Enabled for exchange2: COMEX (Trading Account Required) | 2021-06-23 16:49:24.319 Enabled for exchange2: NYMEX (Trading Account Required) | 2021-06-23 16:49:24.319 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-23 16:49:24.319 Current selected Data/Trading service: SC Data - All Services | 2021-06-23 16:49:24.319 Custom symbol settings values: enabled | 2021-06-23 16:49:24.319 Chart Update Interval: 100 | 2021-06-23 16:49:24.319 Intraday Data Storage Time Unit: 0 | 2021-06-23 16:49:24.319 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-06-23 16:49:24.319 2021-06-23 20:49:24 Local computer time in UTC | 2021-06-23 16:49:24.319 2021-06-23 16:49:24 Local computer time in SC Time Zone | 2021-06-23 16:49:24.319 2021-06-23 20:49:23 Server time in UTC | 2021-06-23 16:49:24.319 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-06-23 16:49:24.319 Program path: C:\SierraChart\ | 2021-06-23 16:49:24.319 Data Files path: C:\SierraChart\Data\ | 2021-06-23 16:49:24.319 OS Version Number: 6.1 | 2021-06-23 16:49:24.319 Locale Setting: C | 2021-06-23 16:49:24.319 DLLs: CrystalPalaceStudies_2217_64.dll, mboxhistogram_64.dll, Norvik_2151_64.dll, OFA Bars (by Zdislav)_2151_64.dll, Trade_Your_Plan_2151_64.dll, TradingriotSuite_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, zyp sierra free 2021_2151_64.dll, zyp sierra free_2151_64.dll | 2021-06-23 16:49:24.319 Allowed protected custom studies: zyp_app, zyp_download_free, zyp_download_free_2, zyp_mod_1 | 2021-06-23 16:49:24.319 Created the DTC Protocol historical data server. | 2021-06-23 16:49:24.339 HD Server Manager | Listening on port 11098. | 2021-06-23 16:49:24.339 Checking for new symbol settings. Requested symbol settings MD5 for service code scdataallservices. Request ID: 1. | 2021-06-23 16:49:24.339 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:49:24.369 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-06-23 16:49:24.469 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-06-23 16:49:24.469 DTC Protocol server | Incoming connection from 127.0.0.1. | 2021-06-23 16:49:24.669 DTC client #1. 127.0.0.1 (1) | Creating socket. | 2021-06-23 16:49:24.669 DTC client #1. 127.0.0.1 (1) | New receive buffer size: 262144 | 2021-06-23 16:49:24.669 DTC client #1. 127.0.0.1 (1) | Allocated send buffers: 32 of 131072 bytes. | 2021-06-23 16:49:24.669 DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS | 2021-06-23 16:49:24.669 DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20 | 2021-06-23 16:49:24.669 DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request. | 2021-06-23 16:49:24.669 DTC client #1. Sierra Chart. 127.0.0.1 | Connecting to primary Data/Trading service. | 2021-06-23 16:49:24.669 SC Data - All Services | Connected to server complete. | 2021-06-23 16:49:24.679 Triggering next historical data download in queue. | 2021-06-23 16:49:24.679 Triggering next historical data download in queue. | 2021-06-23 16:49:24.679 Triggering next historical data download in queue. | 2021-06-23 16:49:24.679 Triggering next historical data download in queue. | 2021-06-23 16:49:24.679 DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: SPRDTRDR. Result text: Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices | 2021-06-23 16:49:24.679 Received 5 login tokens. | 2021-06-23 16:49:24.679 DTC Protocol server | Incoming connection from 127.0.0.1. | 2021-06-23 16:49:24.679 No download requests in the queue to start downloads for. | 2021-06-23 16:49:24.679 No download requests in the queue to start downloads for. | 2021-06-23 16:49:24.679 No download requests in the queue to start downloads for. | 2021-06-23 16:49:24.679 No download requests in the queue to start downloads for. | 2021-06-23 16:49:24.679 DTC client #2. 127.0.0.1 (5) | Creating socket. | 2021-06-23 16:49:24.679 DTC client #2. 127.0.0.1 (5) | New receive buffer size: 262144 | 2021-06-23 16:49:24.679 DTC client #2. 127.0.0.1 (5) | Allocated send buffers: 32 of 131072 bytes. | 2021-06-23 16:49:24.679 DTC client #2. 127.0.0.1 | Set DTC encoding to Binary VLS | 2021-06-23 16:49:24.679 DTC client #2. 127.0.0.1 | Requested heartbeat interval: 20 | 2021-06-23 16:49:24.679 DTC client #2. Sierra Chart. 127.0.0.1 | Received logon request. | 2021-06-23 16:49:24.679 DTC client #2. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: SPRDTRDR. Result text: Connected to SC DTC Protocol server. Service=scdataallservices|SymbolSettings=scdataallservices | 2021-06-23 16:49:24.679 Mapping ESU21-CME to ESU21. Service code: cme | 2021-06-23 16:49:24.769 SC Data - All Services | Starting real-time market data updates for: ESU21-CME (ESU21). ID: 1 Service code: cme | 2021-06-23 16:49:24.769 SC Data - All Services | Connecting to the server ds12-2.sierracharts.com. Port 443 | 2021-06-23 16:49:24.769 SC Data - All Services | Requesting security definition data for: ESU21-CME (ESU21). ID: 1 | 2021-06-23 16:49:24.769 Mapping CLQ21-NYMEX to CLQ21. Service code: nymex | 2021-06-23 16:49:24.769 SC Data - All Services | Starting real-time market data updates for: CLQ21-NYMEX (CLQ21). ID: 2 Service code: nymex | 2021-06-23 16:49:24.769 SC Data - All Services | Requesting security definition data for: CLQ21-NYMEX (CLQ21). ID: 2 | 2021-06-23 16:49:24.769 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol CLQ21-NYMEX | 2021-06-23 16:49:24.769 Requesting market depth updates for: CLQ21-NYMEX if supported. | 2021-06-23 16:49:24.769 Separate subscription for market depth updates not supported. CLQ21-NYMEX | 2021-06-23 16:49:24.769 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market orders for symbol CLQ21-NYMEX | 2021-06-23 16:49:24.769 Mapping NGN21-NYMEX to NGN21. Service code: nymex | 2021-06-23 16:49:24.769 SC Data - All Services | Starting real-time market data updates for: NGN21-NYMEX (NGN21). ID: 3 Service code: nymex | 2021-06-23 16:49:24.769 SC Data - All Services | Requesting security definition data for: NGN21-NYMEX (NGN21). ID: 3 | 2021-06-23 16:49:24.769 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol ESU21-CME | 2021-06-23 16:49:24.769 Requesting market depth updates for: ESU21-CME if supported. | 2021-06-23 16:49:24.769 Separate subscription for market depth updates not supported. ESU21-CME | 2021-06-23 16:49:24.769 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market orders for symbol ESU21-CME | 2021-06-23 16:49:24.769 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol NGN21-NYMEX | 2021-06-23 16:49:24.769 Requesting market depth updates for: NGN21-NYMEX if supported. | 2021-06-23 16:49:24.769 Separate subscription for market depth updates not supported. NGN21-NYMEX | 2021-06-23 16:49:24.769 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market orders for symbol NGN21-NYMEX | 2021-06-23 16:49:24.769 Mapping NGN21-NGQ21.FUT_SPREAD.NYMEX to NGN21-NGQ21.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:24.769 SC Data - All Services | Starting real-time market data updates for: NGN21-NGQ21.FUT_SPREAD.NYMEX (NGN21-NGQ21.FUT_SPREAD.NYMEX). ID: 4 Service code: nymex | 2021-06-23 16:49:24.769 SC Data - All Services | Requesting security definition data for: NGN21-NGQ21.FUT_SPREAD.NYMEX (NGN21-NGQ21.FUT_SPREAD.NYMEX). ID: 4 | 2021-06-23 16:49:24.769 Mapping NGN21-NGU21.FUT_SPREAD.NYMEX to NGN21-NGU21.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:24.779 SC Data - All Services | Starting real-time market data updates for: NGN21-NGU21.FUT_SPREAD.NYMEX (NGN21-NGU21.FUT_SPREAD.NYMEX). ID: 5 Service code: nymex | 2021-06-23 16:49:24.779 SC Data - All Services | Requesting security definition data for: NGN21-NGU21.FUT_SPREAD.NYMEX (NGN21-NGU21.FUT_SPREAD.NYMEX). ID: 5 | 2021-06-23 16:49:24.779 Mapping CLN21-NYMEX to CLN21. Service code: nymex | 2021-06-23 16:49:24.779 DTC Client socket (6) | Creating socket. | 2021-06-23 16:49:24.779 DTC Client socket (6) | New receive buffer size: 5242880 | 2021-06-23 16:49:24.779 SC Data - All Services | Starting real-time market data updates for: CLN21-NYMEX (CLN21). ID: 6 Service code: nymex | 2021-06-23 16:49:24.779 SC Data - All Services | Requesting security definition data for: CLN21-NYMEX (CLN21). ID: 6 | 2021-06-23 16:49:24.779 DTC Client socket (6) | Connecting to IP: 204.15.197.13. | 2021-06-23 16:49:24.779 Mapping NGN21-NGV21.FUT_SPREAD.NYMEX to NGN21-NGV21.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:24.779 SC Data - All Services | Starting real-time market data updates for: NGN21-NGV21.FUT_SPREAD.NYMEX (NGN21-NGV21.FUT_SPREAD.NYMEX). ID: 7 Service code: nymex | 2021-06-23 16:49:24.779 SC Data - All Services | Requesting security definition data for: NGN21-NGV21.FUT_SPREAD.NYMEX (NGN21-NGV21.FUT_SPREAD.NYMEX). ID: 7 | 2021-06-23 16:49:24.779 Mapping ZSN21-CBOT to ZSN21. Service code: cbot | 2021-06-23 16:49:24.779 SC Data - All Services | Starting real-time market data updates for: ZSN21-CBOT (ZSN21). ID: 8 Service code: cbot | 2021-06-23 16:49:24.779 SC Data - All Services | Requesting security definition data for: ZSN21-CBOT (ZSN21). ID: 8 | 2021-06-23 16:49:24.779 Mapping ZWN21-CBOT to ZWN21. Service code: cbot | 2021-06-23 16:49:24.779 SC Data - All Services | Starting real-time market data updates for: ZWN21-CBOT (ZWN21). ID: 9 Service code: cbot | 2021-06-23 16:49:24.779 SC Data - All Services | Requesting security definition data for: ZWN21-CBOT (ZWN21). ID: 9 | 2021-06-23 16:49:24.779 Mapping HGN21-COMEX to HGN21. Service code: comex | 2021-06-23 16:49:24.779 SC Data - All Services | Starting real-time market data updates for: HGN21-COMEX (HGN21). ID: 10 Service code: comex | 2021-06-23 16:49:24.779 SC Data - All Services | Requesting security definition data for: HGN21-COMEX (HGN21). ID: 10 | 2021-06-23 16:49:24.779 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol HGN21-COMEX | 2021-06-23 16:49:24.779 Requesting market depth updates for: HGN21-COMEX if supported. | 2021-06-23 16:49:24.779 Separate subscription for market depth updates not supported. HGN21-COMEX | 2021-06-23 16:49:24.779 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market orders for symbol HGN21-COMEX | 2021-06-23 16:49:24.779 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol ZSN21-CBOT | 2021-06-23 16:49:24.779 Requesting market depth updates for: ZSN21-CBOT if supported. | 2021-06-23 16:49:24.779 Separate subscription for market depth updates not supported. ZSN21-CBOT | 2021-06-23 16:49:24.779 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market orders for symbol ZSN21-CBOT | 2021-06-23 16:49:24.779 SC Data - All Services | Network connection to server complete. | 2021-06-23 16:49:24.809 SC Data - All Services | Starting socket receive thread. | 2021-06-23 16:49:24.809 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-23 16:49:24.809 Mapping ZCN21-CBOT to ZCN21. Service code: cbot | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: ZCN21-CBOT (ZCN21). ID: 11 Service code: cbot | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: ZCN21-CBOT (ZCN21). ID: 11 | 2021-06-23 16:49:24.859 Mapping CLK21-NYMEX to CLK21. Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: CLK21-NYMEX (CLK21). ID: 12 Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: CLK21-NYMEX (CLK21). ID: 12 | 2021-06-23 16:49:24.859 Mapping HOQ21-NYMEX to HOQ21. Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: HOQ21-NYMEX (HOQ21). ID: 13 Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: HOQ21-NYMEX (HOQ21). ID: 13 | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: UTES. ID: 14 Service code: equities.us | 2021-06-23 16:49:24.859 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: UTES | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: UTES. ID: 14 | 2021-06-23 16:49:24.859 Mapping RBQ21-NYMEX to RBQ21. Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: RBQ21-NYMEX (RBQ21). ID: 15 Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: RBQ21-NYMEX (RBQ21). ID: 15 | 2021-06-23 16:49:24.859 Mapping VXN21-CFE to VXN21_FUT_CFE. Service code: cfe_exchange.data | 2021-06-23 16:49:24.859 SC DTC Delayed Exchange Data | Starting real-time market data updates for: VXN21-CFE (VXN21_FUT_CFE). ID: 16 Service code: cfe_exchange.data | 2021-06-23 16:49:24.859 SC DTC Delayed Exchange Data | Connecting to the server ds12-3.sierracharts.com. Port 10043 | 2021-06-23 16:49:24.859 SC DTC Delayed Exchange Data | Requesting security definition data for: VXN21-CFE (VXN21_FUT_CFE). ID: 16 | 2021-06-23 16:49:24.859 Mapping BTCM21-CME to BTCM21. Service code: cme | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: BTCM21-CME (BTCM21). ID: 17 Service code: cme | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: BTCM21-CME (BTCM21). ID: 17 | 2021-06-23 16:49:24.859 Mapping NGV20-NGF21.FUT_SPREAD.NYMEX to NGV20-NGF21.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: NGV20-NGF21.FUT_SPREAD.NYMEX (NGV20-NGF21.FUT_SPREAD.NYMEX). ID: 18 Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: NGV20-NGF21.FUT_SPREAD.NYMEX (NGV20-NGF21.FUT_SPREAD.NYMEX). ID: 18 | 2021-06-23 16:49:24.859 DTC Client socket (7) | Creating socket. | 2021-06-23 16:49:24.859 DTC Client socket (7) | New receive buffer size: 5242880 | 2021-06-23 16:49:24.859 DTC Client socket (7) | Connecting to IP: 204.15.197.12. | 2021-06-23 16:49:24.859 Mapping NG:SA 12M F22.FUT_SPREAD.NYMEX to NG:SA 12M F22.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: NG:SA 12M F22.FUT_SPREAD.NYMEX (NG:SA 12M F22.FUT_SPREAD.NYMEX). ID: 19 Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: NG:SA 12M F22.FUT_SPREAD.NYMEX (NG:SA 12M F22.FUT_SPREAD.NYMEX). ID: 19 | 2021-06-23 16:49:24.859 Mapping NGV21-NGF22.FUT_SPREAD.NYMEX to NGV21-NGF22.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: NGV21-NGF22.FUT_SPREAD.NYMEX (NGV21-NGF22.FUT_SPREAD.NYMEX). ID: 20 Service code: nymex | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: NGV21-NGF22.FUT_SPREAD.NYMEX (NGV21-NGF22.FUT_SPREAD.NYMEX). ID: 20 | 2021-06-23 16:49:24.859 Mapping 6EU21-CME to 6EU21. Service code: cme | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: 6EU21-CME (6EU21). ID: 21 Service code: cme | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: 6EU21-CME (6EU21). ID: 21 | 2021-06-23 16:49:24.859 Mapping ZLN21-CBOT to ZLN21. Service code: cbot | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: ZLN21-CBOT (ZLN21). ID: 22 Service code: cbot | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: ZLN21-CBOT (ZLN21). ID: 22 | 2021-06-23 16:49:24.859 Mapping GCQ21-COMEX to GCQ21. Service code: comex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: GCQ21-COMEX (GCQ21). ID: 23 Service code: comex | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: GCQ21-COMEX (GCQ21). ID: 23 | 2021-06-23 16:49:24.859 Mapping SIN21-COMEX to SIN21. Service code: comex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: SIN21-COMEX (SIN21). ID: 24 Service code: comex | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: SIN21-COMEX (SIN21). ID: 24 | 2021-06-23 16:49:24.859 Mapping ZBU21-CBOT to ZBU21. Service code: cbot | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: ZBU21-CBOT (ZBU21). ID: 25 Service code: cbot | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: ZBU21-CBOT (ZBU21). ID: 25 | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: DXU21-ICEUS. ID: 26 Service code: ice.us | 2021-06-23 16:49:24.859 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: DXU21-ICEUS | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: DXU21-ICEUS. ID: 26 | 2021-06-23 16:49:24.859 Using -BID_ASK_TRADE_SYNC recording mode for SOK21 C2750.FUT_OPT.COMEX | 2021-06-23 16:49:24.859 Mapping SOK21 C2750.FUT_OPT.COMEX to SOK21 C2750.FUT_OPT.COMEX. Service code: comex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: SOK21 C2750.FUT_OPT.COMEX (SOK21 C2750.FUT_OPT.COMEX). ID: 27 Service code: comex | 2021-06-23 16:49:24.859 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10045 | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: SOK21 C2750.FUT_OPT.COMEX (SOK21 C2750.FUT_OPT.COMEX). ID: 27 | 2021-06-23 16:49:24.859 Using -BID_ASK_TRADE_SYNC recording mode for SOH21 C2750.FUT_OPT.COMEX | 2021-06-23 16:49:24.859 DTC Client socket (8) | Creating socket. | 2021-06-23 16:49:24.859 DTC Client socket (8) | New receive buffer size: 5242880 | 2021-06-23 16:49:24.859 DTC Client socket (8) | Connecting to IP: 216.1.90.129. | 2021-06-23 16:49:24.859 Mapping SOH21 C2750.FUT_OPT.COMEX to SOH21 C2750.FUT_OPT.COMEX. Service code: comex | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: SOH21 C2750.FUT_OPT.COMEX (SOH21 C2750.FUT_OPT.COMEX). ID: 28 Service code: comex | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: SOH21 C2750.FUT_OPT.COMEX (SOH21 C2750.FUT_OPT.COMEX). ID: 28 | 2021-06-23 16:49:24.859 Mapping ZNM21-CBOT to ZNM21. Service code: cbot | 2021-06-23 16:49:24.859 SC Data - All Services | Starting real-time market data updates for: ZNM21-CBOT (ZNM21). ID: 29 Service code: cbot | 2021-06-23 16:49:24.859 SC Data - All Services | Requesting security definition data for: ZNM21-CBOT (ZNM21). ID: 29 | 2021-06-23 16:49:24.859 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:24.879 SC Data - All Services | Sending logon request message. | 2021-06-23 16:49:24.879 SC Data - All Services | Network connection to server complete. | 2021-06-23 16:49:24.889 SC Data - All Services | Starting socket receive thread. | 2021-06-23 16:49:24.889 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-23 16:49:24.889 SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-06-23 16:49:24.889 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-06-23 16:49:24.889 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-23 16:49:24.889 SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:24.919 SC Data - All Services | Sending logon request message. | 2021-06-23 16:49:24.919 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:24.949 SC DTC Delayed Exchange Data | Sending logon request message. | 2021-06-23 16:49:24.949 Symbol settings MD5 received. Request ID: 1. | 2021-06-23 16:49:25.159 Symbol settings are up-to-date for scdataallservices. | 2021-06-23 16:49:25.159 SC DTC Delayed Exchange Data | Received logon response. | 2021-06-23 16:49:25.609 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-06-23 16:49:25.609 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 16:49:25.609 SC DTC Delayed Exchange Data | Successfully connected. | 2021-06-23 16:49:25.609 SC DTC Delayed Exchange Data | Trading is not supported. | 2021-06-23 16:49:25.609 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: VXN21-CFE -> VXN21_FUT_CFE | 2021-06-23 16:49:25.609 SC Data - All Services | Received logon response. | 2021-06-23 16:49:25.609 SC Data - All Services | Server Name: SC Realtime Server. | 2021-06-23 16:49:25.609 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 16:49:25.609 SC Data - All Services | Successfully connected. | 2021-06-23 16:49:25.609 SC Data - All Services | Trading is not supported. | 2021-06-23 16:49:25.609 SC Data - All Services | Restarting real-time data updates for symbol: SOH21 C2750.FUT_OPT.COMEX -> SOH21 C2750.FUT_OPT.COMEX | 2021-06-23 16:49:25.609 SC Data - All Services | Restarting real-time data updates for symbol: SOK21 C2750.FUT_OPT.COMEX -> SOK21 C2750.FUT_OPT.COMEX | 2021-06-23 16:49:25.609 SC Data - All Services | Received logon response. | 2021-06-23 16:49:25.719 SC Data - All Services | Server Name: SC Realtime Server. | 2021-06-23 16:49:25.719 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 16:49:25.719 SC Data - All Services | Successfully connected. | 2021-06-23 16:49:25.719 SC Data - All Services | Trading is not supported. | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: 6EU21-CME -> 6EU21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: BTCM21-CME -> BTCM21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: CLK21-NYMEX -> CLK21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: CLN21-NYMEX -> CLN21 | 2021-06-23 16:49:25.719 SC Data - All Services (Market Orders Data) | Connecting to the server ds12-2.sierracharts.com. Port 10060 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: CLQ21-NYMEX -> CLQ21. Market Depth data restarted. | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: ESU21-CME -> ESU21. Market Depth data restarted. | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: GCQ21-COMEX -> GCQ21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: HGN21-COMEX -> HGN21. Market Depth data restarted. | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: HOQ21-NYMEX -> HOQ21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: NG:SA 12M F22.FUT_SPREAD.NYMEX -> NG:SA 12M F22.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: NGN21-NGQ21.FUT_SPREAD.NYMEX -> NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: NGN21-NGU21.FUT_SPREAD.NYMEX -> NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: NGN21-NGV21.FUT_SPREAD.NYMEX -> NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: NGN21-NYMEX -> NGN21. Market Depth data restarted. | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: NGV20-NGF21.FUT_SPREAD.NYMEX -> NGV20-NGF21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: NGV21-NGF22.FUT_SPREAD.NYMEX -> NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: RBQ21-NYMEX -> RBQ21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: SIN21-COMEX -> SIN21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: ZBU21-CBOT -> ZBU21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: ZCN21-CBOT -> ZCN21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: ZLN21-CBOT -> ZLN21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: ZNM21-CBOT -> ZNM21 | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: ZSN21-CBOT -> ZSN21. Market Depth data restarted. | 2021-06-23 16:49:25.719 SC Data - All Services | Restarting real-time data updates for symbol: ZWN21-CBOT -> ZWN21 | 2021-06-23 16:49:25.719 DTC Client socket (2) | Creating socket. | 2021-06-23 16:49:25.719 DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-23 16:49:25.719 DTC Client socket (2) | Connecting to IP: 204.15.197.13. | 2021-06-23 16:49:25.719 SC DTC Delayed Exchange Data | Received security definition for symbol VXN21-CFE | 2021-06-23 16:49:25.729 SC Data - All Services | Real-time data for symbol SOH21 C2750.FUT_OPT.COMEX is currently unavailable. | 2021-06-23 16:49:25.739 SC Data - All Services | Received security definition for symbol SOH21 C2750.FUT_OPT.COMEX | 2021-06-23 16:49:25.739 SC Data - All Services | Real-time data for symbol SOK21 C2750.FUT_OPT.COMEX is currently unavailable. | 2021-06-23 16:49:25.739 SC Data - All Services | Received security definition for symbol SOK21 C2750.FUT_OPT.COMEX | 2021-06-23 16:49:25.739 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2021-06-23 16:49:25.759 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2021-06-23 16:49:25.759 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-23 16:49:25.759 SC Data - All Services (Market Orders Data) | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:25.799 SC Data - All Services (Market Orders Data) | Sending logon request message. | 2021-06-23 16:49:25.799 SC Data - All Services | Received security definition for symbol 6EU21-CME | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol BTCM21-CME | 2021-06-23 16:49:25.909 SC Data - All Services | Real-time data for symbol CLK21-NYMEX is currently unavailable. | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol CLK21-NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 16:49:25.909 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESU21-CME.2021-06-23.depth | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 16:49:25.909 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol GCQ21-COMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 16:49:25.909 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGN21-NYMEX.2021-06-23.depth | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol HOQ21-NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol NG:SA 12M F22.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 16:49:25.909 SC Data - All Services | Real-time data for symbol NGV20-NGF21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol NGV20-NGF21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol RBQ21-NYMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol SIN21-COMEX | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol ZBU21-CBOT | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol ZCN21-CBOT | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol ZLN21-CBOT | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol ZNM21-CBOT | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 16:49:25.909 SC Data - All Services | Received security definition for symbol ZWN21-CBOT | 2021-06-23 16:49:25.909 SC Data - All Services (Market Orders Data) | Received logon response. | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Server Name: SC Realtime Server. | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Successfully connected. | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Trading is not supported. | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Starting market orders updates for: CLQ21. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: CLQ21-NYMEX -> CLQ21 | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESU21. MinimumMarketByOrderQuantity: 20. Service code: cme | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ESU21-CME -> ESU21 | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Starting market orders updates for: HGN21. MinimumMarketByOrderQuantity: 0. Service code: comex | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: HGN21-COMEX -> HGN21 | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGN21. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: NGN21-NYMEX -> NGN21 | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZSN21. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2021-06-23 16:49:26.639 SC Data - All Services (Market Orders Data) | Restarting market orders data for symbol: ZSN21-CBOT -> ZSN21 | 2021-06-23 16:49:26.639 Files to Open on Startup | Opening file: CNDL_5x15x60.cht | 2021-06-23 16:49:28.849 NGN21-NYMEX 5 Min #14 | Reloading chart. | 2021-06-23 16:49:28.849 NGN21-NYMEX 15 Min #9 | Reloading chart. | 2021-06-23 16:49:28.859 NGN21-NYMEX 60 Min #8 | Reloading chart. | 2021-06-23 16:49:28.869 ESU21-CME 5 Min #3 | Reloading chart. | 2021-06-23 16:49:28.879 ESU21-CME 15 Min #24 | Reloading chart. | 2021-06-23 16:49:28.879 ESU21-CME 60 Min #23 | Reloading chart. | 2021-06-23 16:49:28.889 NGN21-NYMEX 60 Min #6 | Reloading chart. | 2021-06-23 16:49:28.899 NGN21-NYMEX 60 Min #11 | Reloading chart. | 2021-06-23 16:49:29.109 ESZ20-CME [C] Daily #2 | Reloading chart. | 2021-06-23 16:49:29.249 ESZ20-CME [C] Daily #2 | Performing historical Daily data download for symbol ESZ20-CME starting at last date in file. | 2021-06-23 16:49:29.753 Starting DelayedDownloadMonitoringTimer | 2021-06-23 16:49:29.753 Starting HDTimeoutTimer | 2021-06-23 16:49:29.753 Added historical Daily data request for ESZ20-CME to the queue. | 2021-06-23 16:49:29.753 Triggering next historical data download in queue. | 2021-06-23 16:49:29.753 ESZ20-CME [C] Daily #2 | Waiting for historical downloads to complete with the IDs: 1, | 2021-06-23 16:49:29.923 NGN21-NYMEX [C] 330 Min #4 | Reloading chart. | 2021-06-23 16:49:29.933 Starting DelayedDownloadMonitoringTimer | 2021-06-23 16:49:29.943 Starting HDTimeoutTimer | 2021-06-23 16:49:29.943 Added historical Intraday data request for NGM21-NYMEX to the queue. | 2021-06-23 16:49:29.943 Triggering next historical data download in queue. | 2021-06-23 16:49:29.943 NGN21-NYMEX [C] 330 Min #4 | Waiting for historical downloads to complete with the IDs: 2, | 2021-06-23 16:49:29.943 NGN21-NYMEX 60 Min #5 | Reloading chart. | 2021-06-23 16:49:29.953 NGN21-NGU21.FUT_SPREAD.NYMEX #1 | Reloading chart. | 2021-06-23 16:49:29.963 NGN21-NGU21.FUT_SPREAD.NYMEX #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:49:29.963 Cannot import symbols. File does not exist: C:\SierraChart\Data\Positions.SymbolList.SymbolList | 2021-06-23 16:49:29.973 * Mapping NGQ21-NYMEX to NGQ21. Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Starting real-time market data updates for: NGQ21-NYMEX (NGQ21). ID: 30 Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Requesting security definition data for: NGQ21-NYMEX (NGQ21). ID: 30 | 2021-06-23 16:49:29.973 Mapping NGU21-NYMEX to NGU21. Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Starting real-time market data updates for: NGU21-NYMEX (NGU21). ID: 31 Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Requesting security definition data for: NGU21-NYMEX (NGU21). ID: 31 | 2021-06-23 16:49:29.973 Mapping NGV21-NYMEX to NGV21. Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Starting real-time market data updates for: NGV21-NYMEX (NGV21). ID: 32 Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Requesting security definition data for: NGV21-NYMEX (NGV21). ID: 32 | 2021-06-23 16:49:29.973 Mapping NGN21-NGH22.FUT_SPREAD.NYMEX to NGN21-NGH22.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Starting real-time market data updates for: NGN21-NGH22.FUT_SPREAD.NYMEX (NGN21-NGH22.FUT_SPREAD.NYMEX). ID: 33 Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Requesting security definition data for: NGN21-NGH22.FUT_SPREAD.NYMEX (NGN21-NGH22.FUT_SPREAD.NYMEX). ID: 33 | 2021-06-23 16:49:29.973 Mapping NGJ22-NGV22.FUT_SPREAD.NYMEX to NGJ22-NGV22.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Starting real-time market data updates for: NGJ22-NGV22.FUT_SPREAD.NYMEX (NGJ22-NGV22.FUT_SPREAD.NYMEX). ID: 34 Service code: nymex | 2021-06-23 16:49:29.973 SC Data - All Services | Requesting security definition data for: NGJ22-NGV22.FUT_SPREAD.NYMEX (NGJ22-NGV22.FUT_SPREAD.NYMEX). ID: 34 | 2021-06-23 16:49:29.973 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSDT_PERP_BINANCE. ID: 35 Service code: binance_cryptocurrency.exchange.data | 2021-06-23 16:49:29.973 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2021-06-23 16:49:29.973 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSDT_PERP_BINANCE. ID: 35 | 2021-06-23 16:49:29.973 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 36 Service code: bitmex | 2021-06-23 16:49:29.973 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 36 | 2021-06-23 16:49:29.973 DTC Client socket (3) | Creating socket. | 2021-06-23 16:49:29.973 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-23 16:49:29.973 DTC Client socket (3) | Connecting to IP: 204.15.197.14. | 2021-06-23 16:49:29.973 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 37 Service code: bitmex | 2021-06-23 16:49:29.973 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 37 | 2021-06-23 16:49:29.973 Mapping NG:SA 07M J22.FUT_SPREAD.NYMEX to NG:SA 07M J22.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:29.983 SC Data - All Services | Starting real-time market data updates for: NG:SA 07M J22.FUT_SPREAD.NYMEX (NG:SA 07M J22.FUT_SPREAD.NYMEX). ID: 38 Service code: nymex | 2021-06-23 16:49:29.983 SC Data - All Services | Requesting security definition data for: NG:SA 07M J22.FUT_SPREAD.NYMEX (NG:SA 07M J22.FUT_SPREAD.NYMEX). ID: 38 | 2021-06-23 16:49:29.983 Mapping NGH22-NGJ22.FUT_SPREAD.NYMEX to NGH22-NGJ22.FUT_SPREAD.NYMEX. Service code: nymex | 2021-06-23 16:49:29.983 SC Data - All Services | Starting real-time market data updates for: NGH22-NGJ22.FUT_SPREAD.NYMEX (NGH22-NGJ22.FUT_SPREAD.NYMEX). ID: 39 Service code: nymex | 2021-06-23 16:49:29.983 SC Data - All Services | Requesting security definition data for: NGH22-NGJ22.FUT_SPREAD.NYMEX (NGH22-NGJ22.FUT_SPREAD.NYMEX). ID: 39 | 2021-06-23 16:49:29.983 Mapping ZWU21-CBOT to ZWU21. Service code: cbot | 2021-06-23 16:49:29.983 SC Data - All Services | Starting real-time market data updates for: ZWU21-CBOT (ZWU21). ID: 40 Service code: cbot | 2021-06-23 16:49:29.983 SC Data - All Services | Requesting security definition data for: ZWU21-CBOT (ZWU21). ID: 40 | 2021-06-23 16:49:29.983 Files to Open on Startup | Opening file: Daily NG Flows.Cht | 2021-06-23 16:49:29.993 NGN21-NYMEX 5 Min #4 | Reloading chart. | 2021-06-23 16:49:30.013 NGN21-NYMEX #10 | Reloading chart. | 2021-06-23 16:49:30.103 Loading market depth data. | 2021-06-23 16:49:30.113 NGN21-NYMEX [C] 330 Min #13 | Reloading chart. | 2021-06-23 16:49:30.133 Added historical Intraday data request for NGZ20-NYMEX to the queue. | 2021-06-23 16:49:30.173 NGN21-NYMEX [C] 330 Min #13 | Waiting for historical downloads to complete with the IDs: 2, 3, | 2021-06-23 16:49:30.213 NGN21-NYMEX #11 | Reloading chart. | 2021-06-23 16:49:30.243 NGN21-NYMEX #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:49:30.243 NGN21-NYMEX Point & Figure 1-10 #2 | Reloading chart. | 2021-06-23 16:49:30.253 NGN21-NYMEX Point & Figure 1-10 #1 | Reloading chart. | 2021-06-23 16:49:30.273 NGN21-NYMEX #9 | Reloading chart. | 2021-06-23 16:49:30.283 NGN21-NYMEX #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:49:30.283 Files to Open on Startup | File does not exist: C:\SierraChart\Data\TPObook1.Cht | 2021-06-23 16:49:30.323 Files to Open on Startup | Opening file: Daily ES Flows.Cht | 2021-06-23 16:49:30.323 ESU21-CME Point & Figure 1-12 #6 | Reloading chart. | 2021-06-23 16:49:30.350 ESU21-CME #3 | Reloading chart. | 2021-06-23 16:49:30.364 ESU21-CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:49:30.364 Loaded depth data records for NGN21-NYMEX 2021-06-14 from 2021-06-14 09:00:00.000000 to 2021-06-14 14:29:59.997000. | 2021-06-23 16:49:30.377 ESU21-CME #1 | Reloading chart. | 2021-06-23 16:49:30.394 ESU21-CME #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:49:30.395 Files to Open on Startup | Opening file: Wychoff.Cht | 2021-06-23 16:49:30.395 ESU21-CME Point & Figure 8-2 #1 | Reloading chart. | 2021-06-23 16:49:30.445 NGN21-NYMEX Point & Figure 5-3 #3 | Reloading chart. | 2021-06-23 16:49:30.475 DTC client #2. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol ESU21-CME | 2021-06-23 16:49:30.606 DTC client #2. Sierra Chart. 127.0.0.1 | Received subscribe to market orders for symbol ESU21-CME | 2021-06-23 16:49:30.606 DTC client #2. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol NGN21-NYMEX | 2021-06-23 16:49:30.606 DTC client #2. Sierra Chart. 127.0.0.1 | Received subscribe to market orders for symbol NGN21-NYMEX | 2021-06-23 16:49:30.606 Mapping ESZ20-CME to ESZ20. Service code: cme | 2021-06-23 16:49:30.606 HD Request # 1 | Downloading Historical Daily chart data for ESZ20-CME. Starting date: 2020-12-16. Service: scdataallservices | 2021-06-23 16:49:30.608 Mapping NGM21-NYMEX to NGM21. Service code: nymex | 2021-06-23 16:49:30.608 HD Request # 2 | Downloading Intraday chart data for NGM21-NYMEX to the file NGM21-NYMEX.scid. Service: nymex | 2021-06-23 16:49:30.608 HD Request # 2 | Download start date-time: 2021-05-26 14:28:52.000000. File last date-time: 2021-05-26 14:28:52.699000 | 2021-06-23 16:49:30.608 HD Request # 2 | Using server: ds23.sierracharts.com port 10149 | 2021-06-23 16:49:30.608 SC DTC Data with Market Depth | Network connection to server complete. | 2021-06-23 16:49:30.652 SC DTC Data with Market Depth | Starting socket receive thread. | 2021-06-23 16:49:30.652 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-23 16:49:30.652 NGN21-NYMEX #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:49:30.653 Socket (9) | Creating socket. | 2021-06-23 16:49:30.657 Socket (9) | New receive buffer size: 5242880 | 2021-06-23 16:49:30.657 Socket (9) | Connecting to IP: 216.1.90.130. | 2021-06-23 16:49:30.657 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:30.713 SC DTC Data with Market Depth | Sending logon request message. | 2021-06-23 16:49:30.713 HD Request # 2 | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:30.726 HD Request # 2 | Sending historical data logon request message. | 2021-06-23 16:49:30.726 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGQ21-NYMEX.2021-06-23.depth | 2021-06-23 16:49:30.727 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGU21-NYMEX.2021-06-23.depth | 2021-06-23 16:49:30.728 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGV21-NYMEX.2021-06-23.depth | 2021-06-23 16:49:30.730 SC Data - All Services | Received security definition for symbol NGQ21-NYMEX | 2021-06-23 16:49:30.734 SC Data - All Services | Received security definition for symbol NGU21-NYMEX | 2021-06-23 16:49:30.734 SC Data - All Services | Received security definition for symbol NGV21-NYMEX | 2021-06-23 16:49:30.734 SC Data - All Services | Received security definition for symbol NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 16:49:30.734 SC Data - All Services | Received security definition for symbol NGJ22-NGV22.FUT_SPREAD.NYMEX | 2021-06-23 16:49:30.734 SC Data - All Services | Received security definition for symbol NG:SA 07M J22.FUT_SPREAD.NYMEX | 2021-06-23 16:49:30.734 SC Data - All Services | Received security definition for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 16:49:30.734 SC Data - All Services | Received security definition for symbol ZWU21-CBOT | 2021-06-23 16:49:30.734 Requesting current DateTime from Sierra Chart server. | 2021-06-23 16:49:30.736 Loaded depth data records for NGN21-NYMEX 2021-06-15 from 2021-06-15 09:00:00.000000 to 2021-06-15 14:29:59.998000. | 2021-06-23 16:49:30.773 SC Data - All Services | Starting real-time market data updates for: ESZ20-CME (ESZ20). ID: 41 Service code: cme | 2021-06-23 16:49:30.801 SC Data - All Services | Requesting security definition data for: ESZ20-CME (ESZ20). ID: 41 | 2021-06-23 16:49:30.801 Requesting market depth updates for: ESZ20-CME if supported. | 2021-06-23 16:49:30.802 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ESZ20. MinimumMarketByOrderQuantity: 20. Service code: cme | 2021-06-23 16:49:30.802 SC Data - All Services | Starting real-time market data updates for: NGM21-NYMEX (NGM21). ID: 42 Service code: nymex | 2021-06-23 16:49:30.802 SC Data - All Services | Requesting security definition data for: NGM21-NYMEX (NGM21). ID: 42 | 2021-06-23 16:49:30.802 Requesting market depth updates for: NGM21-NYMEX if supported. | 2021-06-23 16:49:30.802 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGM21. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2021-06-23 16:49:30.802 Requesting market depth updates for: NGN21-NGU21.FUT_SPREAD.NYMEX if supported. | 2021-06-23 16:49:30.802 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGN21-NGU21.FUT_SPREAD.NYMEX. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2021-06-23 16:49:30.802 Requesting market depth updates for: NGQ21-NYMEX if supported. | 2021-06-23 16:49:30.802 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGQ21. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2021-06-23 16:49:30.802 Requesting market depth updates for: NGU21-NYMEX if supported. | 2021-06-23 16:49:30.802 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGU21. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2021-06-23 16:49:30.802 Requesting market depth updates for: NGV21-NYMEX if supported. | 2021-06-23 16:49:30.802 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGV21. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2021-06-23 16:49:30.802 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 16:49:30.819 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 16:49:30.819 Triggering next historical data download in queue. | 2021-06-23 16:49:30.819 Added historical Intraday data request for ESU21-CME to the queue. | 2021-06-23 16:49:30.823 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-06-23 16:49:30.823 Triggering next historical data download in queue. | 2021-06-23 16:49:30.823 Added historical Intraday data request for NGN21-NGU21.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 16:49:30.897 Intraday data recording state for symbol NGN21-NGU21.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 16:49:30.897 Triggering next historical data download in queue. | 2021-06-23 16:49:30.897 SC Data - All Services (Market Orders Data) | Real-time data for symbol ESZ20-CME is currently unavailable. | 2021-06-23 16:49:30.927 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGM21-NYMEX is currently unavailable. | 2021-06-23 16:49:30.927 SC Data - All Services | Clearing market depth for ESZ20-CME | 2021-06-23 16:49:30.937 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESZ20-CME.2021-06-23.depth | 2021-06-23 16:49:30.937 SC Data - All Services | Real-time data for symbol ESZ20-CME is currently unavailable. | 2021-06-23 16:49:30.937 SC Data - All Services | Received security definition for symbol ESZ20-CME | 2021-06-23 16:49:30.937 SC Data - All Services | Clearing market depth for NGM21-NYMEX | 2021-06-23 16:49:30.937 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGM21-NYMEX.2021-06-23.depth | 2021-06-23 16:49:30.937 SC Data - All Services | Clearing market depth for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:30.937 SC Data - All Services | Real-time data for symbol NGM21-NYMEX is currently unavailable. | 2021-06-23 16:49:30.937 SC Data - All Services | Received security definition for symbol NGM21-NYMEX | 2021-06-23 16:49:30.937 SC Data - All Services | Clearing market depth for NGQ21-NYMEX | 2021-06-23 16:49:30.937 SC Data - All Services | Clearing market depth for NGU21-NYMEX | 2021-06-23 16:49:30.937 SC Data - All Services | Clearing market depth for NGV21-NYMEX | 2021-06-23 16:49:30.937 Loaded depth data records for NGN21-NYMEX 2021-06-16 from 2021-06-16 09:00:00.000000 to 2021-06-16 14:29:59.870000. | 2021-06-23 16:49:31.057 HD Request # 1 | Requesting historical Daily data for ESZ20 starting at 2020-12-15. SC External HD service. | 2021-06-23 16:49:31.117 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-23 20:49:31.163. Round-trip delay: 00:00:00.210 | 2021-06-23 16:49:31.157 Computer time to server time difference: -00:00:00.006 | 2021-06-23 16:49:31.157 Successfully set the system Date-time to: 2021-06-23 20:49:31.163 UTC. | 2021-06-23 16:49:31.163 HD Request # 2 | Requesting Intraday data. Start date-time: 2021-05-26 14:28:52. Record interval: 0. Symbol: NGM21 | 2021-06-23 16:49:31.223 HD Request # 2 | Decompressing data. | 2021-06-23 16:49:31.253 HD Request # 2 | Receiving Intraday data for NGM21-NYMEX starting at 2021-05-26 14:28:52.699000 | 2021-06-23 16:49:31.263 Socket (9) | CloseSocket call. | 2021-06-23 16:49:31.263 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:49:31.263 Historical data download thread signaled to stop. | 2021-06-23 16:49:31.263 HD Request # 2 | Received 1 record from 2021-05-26 14:28:52.699000 to 2021-05-26 14:28:52.699000 (0.0 seconds) and wrote 0 records for NGM21-NYMEX | 2021-06-23 16:49:31.263 HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2021-05-26 18:28:52.699000 | 2021-06-23 16:49:31.263 HD Request # 2 | Completion time: 1s | 2021-06-23 16:49:31.263 HD Request # 2 | Intraday data download complete for NGM21-NYMEX. Unique request ID: 2 | 2021-06-23 16:49:31.263 Removing historical data download ID 2. | 2021-06-23 16:49:31.263 Real-time Intraday chart data file updates started for NGM21-NYMEX | 2021-06-23 16:49:31.263 Intraday chart data file opened for NGM21-NYMEX | 2021-06-23 16:49:31.263 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:49:31.263 Triggering next historical data download in queue. | 2021-06-23 16:49:31.263 Mapping NGZ20-NYMEX to NGZ20. Service code: nymex | 2021-06-23 16:49:31.263 HD Request # 3 | Downloading Intraday chart data for NGZ20-NYMEX to the file NGZ20-NYMEX.scid. Service: nymex | 2021-06-23 16:49:31.263 HD Request # 3 | Download start date-time: 2020-11-25 14:28:03.000000. File last date-time: 2020-11-25 14:28:03.727000 | 2021-06-23 16:49:31.263 HD Request # 3 | Using server: ds21.sierracharts.com port 10150 | 2021-06-23 16:49:31.263 NGN21-NYMEX [C] 330 Min #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-06-23 16:49:31.263 Socket (12) | Creating socket. | 2021-06-23 16:49:31.263 Socket (12) | New receive buffer size: 5242880 | 2021-06-23 16:49:31.263 Socket (12) | Connecting to IP: 216.1.90.129. | 2021-06-23 16:49:31.263 NGN21-NYMEX [C] 330 Min #4 | Reloading chart. | 2021-06-23 16:49:31.263 Socket (9) | Socket gracefully closed by remote side. | 2021-06-23 16:49:31.303 Socket (9) | Closed. | 2021-06-23 16:49:31.303 HD Request # 1 | Receiving historical Daily data for ESZ20-CME starting at 2020-12-16 | 2021-06-23 16:49:31.333 HD Request # 1 | Writing historical Daily data to the file ESZ20-CME.dly | 2021-06-23 16:49:31.333 HD Request # 1 | Bytes received: 240 | 2021-06-23 16:49:31.333 HD Request # 1 | Received 4 records from 2020-12-16 00:00:00 to 2020-12-18 00:00:00 (3.0 days) and wrote 3 records for ESZ20-CME | 2021-06-23 16:49:31.333 HD Request # 1 | Completion time: 1s | 2021-06-23 16:49:31.353 HD Request # 1 | Daily data download complete for ESZ20-CME. Unique request ID: 1 | 2021-06-23 16:49:31.353 Removing historical data download ID 1. | 2021-06-23 16:49:31.353 Triggering next historical data download in queue. | 2021-06-23 16:49:31.353 No download requests in the queue to start downloads for. | 2021-06-23 16:49:31.353 ESZ20-CME [C] Daily #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-06-23 16:49:31.353 ESZ20-CME [C] Daily #2 | Reloading chart. | 2021-06-23 16:49:31.353 HD Request # 3 | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:31.353 HD Request # 3 | Sending historical data logon request message. | 2021-06-23 16:49:31.353 NGN21-NYMEX [C] 330 Min #4 | Reloading chart. | 2021-06-23 16:49:31.373 Loaded depth data records for NGN21-NYMEX 2021-06-17 from 2021-06-17 09:00:00.000000 to 2021-06-17 14:29:59.869000. | 2021-06-23 16:49:31.411 SC DTC Data with Market Depth | Received logon response. | 2021-06-23 16:49:31.435 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-06-23 16:49:31.435 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 16:49:31.435 SC DTC Data with Market Depth | Successfully connected. | 2021-06-23 16:49:31.435 SC DTC Data with Market Depth | Trading is not supported. | 2021-06-23 16:49:31.435 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSDT_PERP_BINANCE | 2021-06-23 16:49:31.435 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2021-06-23 16:49:31.435 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2021-06-23 16:49:31.435 ESZ20-CME [C] Daily #2 | Reloading chart. | 2021-06-23 16:49:31.455 Loaded depth data records for NGN21-NYMEX 2021-06-18 from 2021-06-18 09:00:00.000000 to 2021-06-18 14:29:59.999000. | 2021-06-23 16:49:31.677 Loaded depth data records for NGN21-NYMEX 2021-06-19 from 00:00:00.000000 to 00:00:00.000000. | 2021-06-23 16:49:31.687 Loaded depth data records for NGN21-NYMEX 2021-06-20 from 2021-06-20 12:07:43.896007 to 2021-06-20 12:07:43.896007. | 2021-06-23 16:49:31.707 SC DTC Data with Market Depth | Received security definition for symbol BTCUSDT_PERP_BINANCE | 2021-06-23 16:49:31.717 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2021-06-23 16:49:31.717 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2021-06-23 16:49:31.717 + Loading additional symbol data. | 2021-06-23 16:49:31.767 HD Request # 3 | Requesting Intraday data. Start date-time: 2020-11-25 14:28:03. Record interval: 0. Symbol: NGZ20 | 2021-06-23 16:49:31.847 HD Request # 3 | Decompressing data. | 2021-06-23 16:49:31.867 HD Request # 3 | Receiving Intraday data for NGZ20-NYMEX starting at 2020-11-25 14:28:03.727000 | 2021-06-23 16:49:31.887 Socket (12) | CloseSocket call. | 2021-06-23 16:49:31.887 Socket (12) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:49:31.887 Historical data download thread signaled to stop. | 2021-06-23 16:49:31.887 HD Request # 3 | Received 1 record from 2020-11-25 14:28:03.727000 to 2020-11-25 14:28:03.727000 (0.0 seconds) and wrote 0 records for NGZ20-NYMEX | 2021-06-23 16:49:31.887 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2020-11-25 19:28:03.727000 | 2021-06-23 16:49:31.887 HD Request # 3 | Completion time: 0s | 2021-06-23 16:49:31.887 HD Request # 3 | Intraday data download complete for NGZ20-NYMEX. Unique request ID: 3 | 2021-06-23 16:49:31.887 Removing historical data download ID 3. | 2021-06-23 16:49:31.887 Real-time Intraday chart data file updates started for NGZ20-NYMEX | 2021-06-23 16:49:31.887 Intraday chart data file opened for NGZ20-NYMEX | 2021-06-23 16:49:31.887 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:49:31.887 Triggering next historical data download in queue. | 2021-06-23 16:49:31.887 HD Request # 4 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 16:49:31.887 HD Request # 4 | Download start date-time: 2021-06-23 16:47:47.000000. File last date-time: 2021-06-23 16:47:47.825001 | 2021-06-23 16:49:31.897 HD Request # 4 | Using server: ds23.sierracharts.com port 10149 | 2021-06-23 16:49:31.897 Socket (4) | Creating socket. | 2021-06-23 16:49:31.897 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 16:49:31.897 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-23 16:49:31.897 NGN21-NYMEX [C] 330 Min #13 | Download is complete for all contract months in chart. Proceeding with data load. | 2021-06-23 16:49:31.907 NGN21-NYMEX [C] 330 Min #13 | Reloading chart. | 2021-06-23 16:49:31.907 Socket (12) | Socket gracefully closed by remote side. | 2021-06-23 16:49:31.917 Socket (12) | Closed. | 2021-06-23 16:49:31.917 Loaded depth data records for NGN21-NYMEX 2021-06-21 from 2021-06-21 09:00:00.000000 to 2021-06-21 14:29:59.945000. | 2021-06-23 16:49:31.927 HD Request # 4 | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:31.957 HD Request # 4 | Sending historical data logon request message. | 2021-06-23 16:49:31.957 HD Request # 4 | Requesting Intraday data. Start date-time: 2021-06-23 16:47:47. Record interval: 0. Symbol: NGN21 | 2021-06-23 16:49:31.997 NGN21-NYMEX [C] 330 Min #13 | Reloading chart. | 2021-06-23 16:49:32.017 HD Request # 4 | Decompressing data. | 2021-06-23 16:49:32.027 HD Request # 4 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 16:47:47.825000 | 2021-06-23 16:49:32.057 Socket (4) | CloseSocket call. | 2021-06-23 16:49:32.077 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:49:32.077 Historical data download thread signaled to stop. | 2021-06-23 16:49:32.077 HD Request # 4 | Timestamp of first Intraday data file record written: 2021-06-23 16:48:12.560000 | 2021-06-23 16:49:32.077 HD Request # 4 | Received 7 records from 2021-06-23 16:47:47.825000 to 2021-06-23 16:49:21.903000 (94.1 seconds) and wrote 5 records for NGN21-NYMEX | 2021-06-23 16:49:32.077 HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:49:21.903000 | 2021-06-23 16:49:32.087 Loaded depth data records for NGN21-NYMEX 2021-06-22 from 2021-06-22 09:00:00.000000 to 2021-06-22 14:29:59.967000. | 2021-06-23 16:49:32.097 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 16:49:32.107 Socket (4) | Closed. | 2021-06-23 16:49:32.107 HD Request # 4 | Completion time: 1s | 2021-06-23 16:49:32.117 HD Request # 4 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 4 | 2021-06-23 16:49:32.117 Removing historical data download ID 4. | 2021-06-23 16:49:32.117 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 16:49:32.117 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 16:49:32.117 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:49:32.117 Triggering next historical data download in queue. | 2021-06-23 16:49:32.127 ESU21-CME[M] Point & Figure 1-12 #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:49:32.127 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE_NASDAQ_NYSEMKT. ID: 44 Service code: statscalc | 2021-06-23 16:49:32.127 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE_NASDAQ_NYSEMKT. ID: 44 | 2021-06-23 16:49:32.127 Added historical Intraday data request for TICK-NYSE_NASDAQ_NYSEMKT to the queue. | 2021-06-23 16:49:32.127 Intraday data recording state for symbol TICK-NYSE_NASDAQ_NYSEMKT is set to download 'Pending'. | 2021-06-23 16:49:32.127 ESU21-CME[M] Point & Figure 1-12 #6 | Started historical data download for additional symbol TICK-NYSE_NASDAQ_NYSEMKT. Download ID: 7 | 2021-06-23 16:49:32.177 HD Request # 5 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-06-23 16:49:32.177 HD Request # 5 | Download start date-time: 2021-06-23 16:47:51.000000. File last date-time: 2021-06-23 16:47:51.251000 | 2021-06-23 16:49:32.177 HD Request # 5 | Using server: ds21.sierracharts.com port 10150 | 2021-06-23 16:49:32.177 Socket (4) | Creating socket. | 2021-06-23 16:49:32.177 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 16:49:32.177 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-23 16:49:32.177 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-23 16:49:32.217 HD Request # 5 | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:32.247 HD Request # 5 | Sending historical data logon request message. | 2021-06-23 16:49:32.247 HD Request # 5 | Requesting Intraday data. Start date-time: 2021-06-23 16:47:51. Record interval: 0. Symbol: ESU21 | 2021-06-23 16:49:32.267 Loaded depth data records for NGN21-NYMEX 2021-06-23 from 2021-06-23 09:00:00.000000 to 2021-06-23 14:29:59.807000. | 2021-06-23 16:49:32.287 HD Request # 5 | Decompressing data. | 2021-06-23 16:49:32.297 HD Request # 5 | Receiving Intraday data for ESU21-CME starting at 2021-06-23 16:47:51.250000 | 2021-06-23 16:49:32.297 Socket (4) | CloseSocket call. | 2021-06-23 16:49:32.297 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:49:32.297 Historical data download thread signaled to stop. | 2021-06-23 16:49:32.297 HD Request # 5 | Timestamp of first Intraday data file record written: 2021-06-23 16:47:55.140000 | 2021-06-23 16:49:32.297 HD Request # 5 | Received 101 records from 2021-06-23 16:47:51.250000 to 2021-06-23 16:49:30.310001 (99.1 seconds) and wrote 99 records for ESU21-CME | 2021-06-23 16:49:32.297 HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:49:30.310001 | 2021-06-23 16:49:32.307 HD Request # 5 | Completion time: 0s | 2021-06-23 16:49:32.307 HD Request # 5 | Intraday data download complete for ESU21-CME. Unique request ID: 5 | 2021-06-23 16:49:32.307 Removing historical data download ID 5. | 2021-06-23 16:49:32.307 Real-time Intraday chart data file updates started for ESU21-CME | 2021-06-23 16:49:32.307 Intraday chart data file opened for ESU21-CME | 2021-06-23 16:49:32.307 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:49:32.307 Triggering next historical data download in queue. | 2021-06-23 16:49:32.307 HD Request # 6 | Downloading Intraday chart data for NGN21-NGU21.FUT_SPREAD.NYMEX to the file NGN21-NGU21.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 16:49:32.307 HD Request # 6 | Download start date-time: 2021-06-23 16:47:20.000000. File last date-time: 2021-06-23 16:47:20.512000 | 2021-06-23 16:49:32.307 HD Request # 6 | Using server: ds23.sierracharts.com port 10149 | 2021-06-23 16:49:32.307 Socket (9) | Creating socket. | 2021-06-23 16:49:32.307 Socket (9) | New receive buffer size: 5242880 | 2021-06-23 16:49:32.307 Socket (9) | Connecting to IP: 216.1.90.130. | 2021-06-23 16:49:32.307 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 16:49:32.327 Socket (4) | Closed. | 2021-06-23 16:49:32.327 HD Request # 6 | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:32.397 HD Request # 6 | Sending historical data logon request message. | 2021-06-23 16:49:32.397 HD Request # 6 | Requesting Intraday data. Start date-time: 2021-06-23 16:47:20. Record interval: 0. Symbol: NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:32.427 HD Request # 6 | Decompressing data. | 2021-06-23 16:49:32.447 HD Request # 6 | Receiving Intraday data for NGN21-NGU21.FUT_SPREAD.NYMEX starting at 2021-06-23 16:47:20.502000 | 2021-06-23 16:49:32.487 Socket (9) | CloseSocket call. | 2021-06-23 16:49:32.517 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:49:32.517 Historical data download thread signaled to stop. | 2021-06-23 16:49:32.517 HD Request # 6 | Timestamp of first Intraday data file record written: 2021-06-23 16:48:12.560000 | 2021-06-23 16:49:32.517 HD Request # 6 | Received 5 records from 2021-06-23 16:47:20.502000 to 2021-06-23 16:48:12.560001 (52.1 seconds) and wrote 2 records for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:32.517 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:48:12.560001 | 2021-06-23 16:49:32.517 Socket (9) | Socket gracefully closed by remote side. | 2021-06-23 16:49:32.537 Socket (9) | Closed. | 2021-06-23 16:49:32.537 HD Request # 6 | Completion time: 0s | 2021-06-23 16:49:32.547 HD Request # 6 | Intraday data download complete for NGN21-NGU21.FUT_SPREAD.NYMEX. Unique request ID: 6 | 2021-06-23 16:49:32.547 Removing historical data download ID 6. | 2021-06-23 16:49:32.547 Real-time Intraday chart data file updates started for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:32.547 Intraday chart data file opened for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 16:49:32.547 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:49:32.547 Triggering next historical data download in queue. | 2021-06-23 16:49:32.547 Delaying start of download for TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-23 16:49:32.547 Error opening C:\SierraChart\SierraChartInstance_2\SierraChartStudies_64.dll. Windows error code 32: The process cannot access the file because it is being used by another process. | 2021-06-23 16:49:34.707 * Error opening C:\SierraChart\SierraChartInstance_2\SierraChart_64.exe. Windows error code 32: The process cannot access the file because it is being used by another process. | 2021-06-23 16:49:34.927 * Error opening C:\SierraChart\SierraChartInstance_2\Data\CrystalPalaceStudies_2217_64.dll. Windows error code 32: The process cannot access the file because it is being used by another process. | 2021-06-23 16:49:34.997 * Error opening C:\SierraChart\SierraChartInstance_2\Data\OFA Bars (by Zdislav)_2151_64.dll. Windows error code 32: The process cannot access the file because it is being used by another process. | 2021-06-23 16:49:34.997 * Error opening C:\SierraChart\SierraChartInstance_2\Data\Trade_Your_Plan_2151_64.dll. Windows error code 32: The process cannot access the file because it is being used by another process. | 2021-06-23 16:49:34.997 * Error opening C:\SierraChart\SierraChartInstance_2\Data\zyp sierra free 2021_2151_64.dll. Windows error code 32: The process cannot access the file because it is being used by another process. | 2021-06-23 16:49:35.207 * Created process C:\SierraChart\SierraChartInstance_2\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_2 | 2021-06-23 16:49:35.417 Error opening C:\SierraChart\SierraChartInstance_3\SierraChartStudies_64.dll. Windows error code 32: The process cannot access the file because it is being used by another process. | 2021-06-23 16:49:35.467 * Error opening C:\SierraChart\SierraChartInstance_3\SierraChart_64.exe. Windows error code 32: The process cannot access the file because it is being used by another process. | 2021-06-23 16:49:35.677 * Created process C:\SierraChart\SierraChartInstance_3\SierraChart_64.exe. Current folder: C:\SierraChart\SierraChartInstance_3 | 2021-06-23 16:49:36.167 SC Data - All Services | Starting real-time market data updates for: NGZ20-NYMEX (NGZ20). ID: 43 Service code: nymex | 2021-06-23 16:49:36.167 SC Data - All Services | Requesting security definition data for: NGZ20-NYMEX (NGZ20). ID: 43 | 2021-06-23 16:49:36.167 Requesting market depth updates for: NGZ20-NYMEX if supported. | 2021-06-23 16:49:36.167 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGZ20. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2021-06-23 16:49:36.167 SC Data - All Services | Clearing market depth for NGZ20-NYMEX | 2021-06-23 16:49:36.307 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGZ20-NYMEX.2021-06-23.depth | 2021-06-23 16:49:36.307 SC Data - All Services | Real-time data for symbol NGZ20-NYMEX is currently unavailable. | 2021-06-23 16:49:36.307 SC Data - All Services | Received security definition for symbol NGZ20-NYMEX | 2021-06-23 16:49:36.307 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGZ20-NYMEX is currently unavailable. | 2021-06-23 16:49:36.307 HD Request # 7 | Downloading Intraday chart data for TICK-NYSE_NASDAQ_NYSEMKT to the file TICK-NYSE_NASDAQ_NYSEMKT.scid. Service: statscalc | 2021-06-23 16:49:37.037 HD Request # 7 | Download start date-time: 2021-06-23 16:47:54.000000. File last date-time: 2021-06-23 16:47:54.956000 | 2021-06-23 16:49:37.037 HD Request # 7 | Using server: ds12.sierracharts.com port 10150 | 2021-06-23 16:49:37.037 Socket (4) | Creating socket. | 2021-06-23 16:49:37.037 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 16:49:37.037 Socket (4) | Connecting to IP: 204.15.197.14. | 2021-06-23 16:49:37.037 HD Request # 7 | Setting DTC encoding to Binary VLS | 2021-06-23 16:49:37.127 HD Request # 7 | Sending historical data logon request message. | 2021-06-23 16:49:37.127 HD Request # 7 | Requesting Intraday data. Start date-time: 2021-06-23 16:47:54. Record interval: 0. Symbol: TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-23 16:49:37.697 HD Request # 7 | Decompressing data. | 2021-06-23 16:49:37.727 HD Request # 7 | Receiving Intraday data for TICK-NYSE_NASDAQ_NYSEMKT starting at 2021-06-23 16:47:54.000000 | 2021-06-23 16:49:37.727 Socket (4) | CloseSocket call. | 2021-06-23 16:49:37.727 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:49:37.727 Historical data download thread signaled to stop. | 2021-06-23 16:49:37.727 HD Request # 7 | Timestamp of first Intraday data file record written: 2021-06-23 16:47:55.000000 | 2021-06-23 16:49:37.727 HD Request # 7 | Received 102 records from 2021-06-23 16:47:54.000000 to 2021-06-23 16:49:35.000000 (101.0 seconds) and wrote 101 records for TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-23 16:49:37.727 HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:49:35.000000 | 2021-06-23 16:49:37.737 Added 15 Time and Sales records to Intraday data file for TICK-NYSE_NASDAQ_NYSEMKT after download. | 2021-06-23 16:49:37.737 HD Request # 7 | Completion time: 0s | 2021-06-23 16:49:37.737 HD Request # 7 | Intraday data download complete for TICK-NYSE_NASDAQ_NYSEMKT. Unique request ID: 7 | 2021-06-23 16:49:37.737 Removing historical data download ID 7. | 2021-06-23 16:49:37.737 Real-time Intraday chart data file updates started for TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-23 16:49:37.737 Intraday chart data file opened for TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-23 16:49:37.737 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:49:37.737 ESU21-CME[M] Point & Figure 1-12 #6 | Historical data download for additional symbol TICK-NYSE_NASDAQ_NYSEMKT with ID 7 has completed. | 2021-06-23 16:49:37.737 Triggering next historical data download in queue. | 2021-06-23 16:49:37.737 No download requests in the queue to start downloads for. | 2021-06-23 16:49:37.737 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 16:49:37.777 Socket (4) | Closed. | 2021-06-23 16:49:37.777 Opened cached Intraday file: C:\SierraChart\Data\ESU21-CME.scid. Thread ID: 5644 | 2021-06-23 16:49:39.377 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE_NASDAQ_NYSEMKT.scid. Thread ID: 5644 | 2021-06-23 16:49:39.377 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NYMEX.scid. Thread ID: 5644 | 2021-06-23 16:49:44.377 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGU21.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-23 16:51:14.377 NGH22-NGJ22.FUT_SPREAD.NYMEX #1 | Reloading chart. | 2021-06-23 16:52:03.037 ESU21-CME #2 | Reloading chart. | 2021-06-23 16:52:03.047 NGN21-NYMEX #3 | Reloading chart. | 2021-06-23 16:52:03.057 Added historical Intraday data request for NGH22-NGJ22.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 16:52:03.247 Intraday data recording state for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 16:52:03.247 Triggering next historical data download in queue. | 2021-06-23 16:52:03.247 HD Request # 8 | Downloading Intraday chart data for NGH22-NGJ22.FUT_SPREAD.NYMEX to the file NGH22-NGJ22.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 16:52:03.247 HD Request # 8 | Download start date-time: 2021-06-23 16:47:20.000000. File last date-time: 2021-06-23 16:47:20.594000 | 2021-06-23 16:52:03.247 HD Request # 8 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 16:52:03.247 Socket (4) | Creating socket. | 2021-06-23 16:52:03.247 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 16:52:03.247 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-23 16:52:03.247 HD Request # 8 | Setting DTC encoding to Binary VLS | 2021-06-23 16:52:03.307 HD Request # 8 | Sending historical data logon request message. | 2021-06-23 16:52:03.307 HD Request # 8 | Requesting Intraday data. Start date-time: 2021-06-23 16:47:20. Record interval: 0. Symbol: NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 16:52:03.787 HD Request # 8 | Decompressing data. | 2021-06-23 16:52:03.817 HD Request # 8 | Receiving Intraday data for NGH22-NGJ22.FUT_SPREAD.NYMEX starting at 2021-06-23 16:47:20.591000 | 2021-06-23 16:52:03.817 Socket (4) | CloseSocket call. | 2021-06-23 16:52:03.817 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:52:03.817 Historical data download thread signaled to stop. | 2021-06-23 16:52:03.817 HD Request # 8 | Timestamp of first Intraday data file record written: 2021-06-23 16:49:03.085000 | 2021-06-23 16:52:03.817 HD Request # 8 | Received 22 records from 2021-06-23 16:47:20.591000 to 2021-06-23 16:51:53.828000 (4.6 minutes) and wrote 20 records for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 16:52:03.817 HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:51:53.828000 | 2021-06-23 16:52:03.817 HD Request # 8 | Completion time: 0s | 2021-06-23 16:52:03.817 HD Request # 8 | Intraday data download complete for NGH22-NGJ22.FUT_SPREAD.NYMEX. Unique request ID: 8 | 2021-06-23 16:52:03.817 Removing historical data download ID 8. | 2021-06-23 16:52:03.817 Real-time Intraday chart data file updates started for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 16:52:03.817 Intraday chart data file opened for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 16:52:03.817 HD Request # 8 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:52:03.817 Triggering next historical data download in queue. | 2021-06-23 16:52:03.817 No download requests in the queue to start downloads for. | 2021-06-23 16:52:03.817 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 16:52:03.847 Socket (4) | Closed. | 2021-06-23 16:52:03.847 Opened cached Intraday file: C:\SierraChart\Data\NGH22-NGJ22.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-23 16:52:44.377 NGN21-NGQ21.FUT_SPREAD.NYMEX 330 Min #1 | Reloading chart. | 2021-06-23 16:54:11.697 NGN21-NGQ21.FUT_SPREAD.NYMEX 5 Min #4 | Reloading chart. | 2021-06-23 16:54:11.727 NGN21-NGQ21.FUT_SPREAD.NYMEX Daily #6 | Reloading chart. | 2021-06-23 16:54:11.787 NGN21-NGQ21.FUT_SPREAD.NYMEX 15 Min #3 | Reloading chart. | 2021-06-23 16:54:11.797 NGN21-NGQ21.FUT_SPREAD.NYMEX #2 | Reloading chart. | 2021-06-23 16:54:11.797 NGN21-NGQ21.FUT_SPREAD.NYMEX #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:54:11.797 Added historical Intraday data request for NGN21-NGQ21.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 16:54:11.917 Intraday data recording state for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 16:54:11.917 Triggering next historical data download in queue. | 2021-06-23 16:54:11.917 HD Request # 9 | Downloading Intraday chart data for NGN21-NGQ21.FUT_SPREAD.NYMEX to the file NGN21-NGQ21.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 16:54:11.917 HD Request # 9 | Download start date-time: 2021-06-23 09:07:19.000000. File last date-time: 2021-06-23 09:07:19.085000 | 2021-06-23 16:54:11.917 HD Request # 9 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 16:54:11.917 Socket (4) | Creating socket. | 2021-06-23 16:54:11.917 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 16:54:11.917 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-23 16:54:11.917 HD Request # 9 | Setting DTC encoding to Binary VLS | 2021-06-23 16:54:11.987 HD Request # 9 | Sending historical data logon request message. | 2021-06-23 16:54:11.987 Added historical Daily data request for NGN21-NGQ21.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 16:54:12.007 Triggering next historical data download in queue. | 2021-06-23 16:54:12.007 HD Request # 9 | Requesting Intraday data. Start date-time: 2021-06-23 09:07:19. Record interval: 0. Symbol: NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 16:54:12.467 HD Request # 9 | Decompressing data. | 2021-06-23 16:54:12.497 HD Request # 9 | Receiving Intraday data for NGN21-NGQ21.FUT_SPREAD.NYMEX starting at 2021-06-23 09:07:19.085000 | 2021-06-23 16:54:12.567 Socket (4) | CloseSocket call. | 2021-06-23 16:54:12.567 Historical data download thread signaled to stop. | 2021-06-23 16:54:12.567 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:54:12.567 HD Request # 9 | Timestamp of first Intraday data file record written: 2021-06-23 09:07:28.905000 | 2021-06-23 16:54:12.567 HD Request # 9 | Received 4546 records from 2021-06-23 09:07:19.085000 to 2021-06-23 16:52:53.822002 (7.8 hours) and wrote 4545 records for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 16:54:12.567 HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:52:53.822002 | 2021-06-23 16:54:12.567 HD Request # 9 | Completion time: 1s | 2021-06-23 16:54:12.567 HD Request # 9 | Intraday data download complete for NGN21-NGQ21.FUT_SPREAD.NYMEX. Unique request ID: 9 | 2021-06-23 16:54:12.567 Removing historical data download ID 9. | 2021-06-23 16:54:12.567 Real-time Intraday chart data file updates started for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 16:54:12.567 Intraday chart data file opened for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 16:54:12.567 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:54:12.567 Triggering next historical data download in queue. | 2021-06-23 16:54:12.567 HD Request # 10 | Downloading Historical Daily chart data for NGN21-NGQ21.FUT_SPREAD.NYMEX. Starting date: 2021-06-16. Service: nymex | 2021-06-23 16:54:12.567 HD Request # 10 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 16:54:12.567 Socket (9) | Creating socket. | 2021-06-23 16:54:12.567 Socket (9) | New receive buffer size: 5242880 | 2021-06-23 16:54:12.567 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-23 16:54:12.567 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 16:54:12.607 Socket (4) | Closed. | 2021-06-23 16:54:12.607 HD Request # 10 | Setting DTC encoding to Binary VLS | 2021-06-23 16:54:12.627 HD Request # 10 | Sending historical data logon request message. | 2021-06-23 16:54:12.627 HD Request # 10 | Requesting historical Daily data starting at 2021-06-16. | 2021-06-23 16:54:13.117 HD Request # 10 | Decompressing data. | 2021-06-23 16:54:13.137 HD Request # 10 | Receiving historical Daily data for NGN21-NGQ21.FUT_SPREAD.NYMEX starting at 2021-06-16 | 2021-06-23 16:54:13.147 HD Request # 10 | Writing historical Daily data to the file NGN21-NGQ21.FUT_SPREAD.NYMEX.dly | 2021-06-23 16:54:13.147 Socket (9) | CloseSocket call. | 2021-06-23 16:54:13.147 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:54:13.147 Historical data download thread signaled to stop. | 2021-06-23 16:54:13.157 HD Request # 10 | Received 5 records from 2021-06-16 00:00:00 to 2021-06-22 00:00:00 (7.0 days) and wrote 5 records for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 16:54:13.157 HD Request # 10 | Completion time: 1s | 2021-06-23 16:54:13.157 HD Request # 10 | Daily data download complete for NGN21-NGQ21.FUT_SPREAD.NYMEX. Unique request ID: 10 | 2021-06-23 16:54:13.157 Removing historical data download ID 10. | 2021-06-23 16:54:13.157 Triggering next historical data download in queue. | 2021-06-23 16:54:13.157 No download requests in the queue to start downloads for. | 2021-06-23 16:54:13.157 Socket (9) | Socket gracefully closed by remote side. | 2021-06-23 16:54:13.177 Socket (9) | Closed. | 2021-06-23 16:54:13.177 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] Daily #6 | Reloading chart. | 2021-06-23 16:54:13.207 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGQ21.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-23 16:54:14.377 Requesting market depth updates for: NGN21-NGQ21.FUT_SPREAD.NYMEX if supported. | 2021-06-23 16:54:15.127 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGN21-NGQ21.FUT_SPREAD.NYMEX. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2021-06-23 16:54:15.127 SC Data - All Services | Clearing market depth for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 16:54:15.237 NGN21-NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:56:14.547 ESU21-CME[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:56:28.107 GCQ21-COMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:56:42.877 Added historical Intraday data request for GCQ21-COMEX to the queue. | 2021-06-23 16:56:42.987 Intraday data recording state for symbol GCQ21-COMEX is set to download 'Pending'. | 2021-06-23 16:56:42.987 Triggering next historical data download in queue. | 2021-06-23 16:56:42.987 HD Request # 11 | Downloading Intraday chart data for GCQ21-COMEX to the file GCQ21-COMEX.scid. Service: comex | 2021-06-23 16:56:42.987 HD Request # 11 | Download start date-time: 2021-06-18 16:59:55.000000. File last date-time: 2021-06-18 16:59:55.064000 | 2021-06-23 16:56:42.987 HD Request # 11 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 16:56:42.987 Socket (4) | Creating socket. | 2021-06-23 16:56:42.987 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 16:56:42.987 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-23 16:56:42.987 HD Request # 11 | Setting DTC encoding to Binary VLS | 2021-06-23 16:56:43.047 HD Request # 11 | Sending historical data logon request message. | 2021-06-23 16:56:43.047 HD Request # 11 | Requesting Intraday data. Start date-time: 2021-06-18 16:59:55. Record interval: 0. Symbol: GCQ21 | 2021-06-23 16:56:43.537 HD Request # 11 | Decompressing data. | 2021-06-23 16:56:43.557 HD Request # 11 | Receiving Intraday data for GCQ21-COMEX starting at 2021-06-18 16:59:55.033000 | 2021-06-23 16:56:43.667 HD Request # 11 | Timestamp of first Intraday data file record written: 2021-06-20 18:00:00.000000 | 2021-06-23 16:56:43.807 Socket (4) | CloseSocket call. | 2021-06-23 16:56:44.707 Historical data download thread signaled to stop. | 2021-06-23 16:56:44.707 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:56:44.707 HD Request # 11 | Received 447827 records from 2021-06-18 16:59:55.033000 to 2021-06-23 16:56:37.833000 (5.0 days) and wrote 447825 records for GCQ21-COMEX | 2021-06-23 16:56:44.707 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:56:37.833000 | 2021-06-23 16:56:44.717 HD Request # 11 | Completion time: 2s | 2021-06-23 16:56:44.717 HD Request # 11 | Intraday data download complete for GCQ21-COMEX. Unique request ID: 11 | 2021-06-23 16:56:44.717 Removing historical data download ID 11. | 2021-06-23 16:56:44.717 Real-time Intraday chart data file updates started for GCQ21-COMEX | 2021-06-23 16:56:44.717 Intraday chart data file opened for GCQ21-COMEX | 2021-06-23 16:56:44.717 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:56:44.717 Triggering next historical data download in queue. | 2021-06-23 16:56:44.717 No download requests in the queue to start downloads for. | 2021-06-23 16:56:44.717 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 16:56:44.747 Socket (4) | Closed. | 2021-06-23 16:56:44.747 Opened cached Intraday file: C:\SierraChart\Data\GCQ21-COMEX.scid. Thread ID: 5644 | 2021-06-23 16:57:04.377 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:57:52.117 NGN21-NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:58:01.957 NGN21-NYMEX[M] #2 | Reloading chart. | 2021-06-23 16:58:01.987 NGN21-NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:58:01.987 Unsubscribed from market depth data for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 16:58:05.477 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: NGN21-NGQ21.FUT_SPREAD.NYMEX.. Service code: nymex | 2021-06-23 16:58:05.477 NGN21-NGH22.FUT_SPREAD.NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:58:24.597 Added historical Intraday data request for NGN21-NGH22.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 16:58:24.697 Intraday data recording state for symbol NGN21-NGH22.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 16:58:24.697 Triggering next historical data download in queue. | 2021-06-23 16:58:24.697 HD Request # 12 | Downloading Intraday chart data for NGN21-NGH22.FUT_SPREAD.NYMEX to the file NGN21-NGH22.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 16:58:24.697 HD Request # 12 | Download start date-time: 2021-06-23 09:06:30.000000. File last date-time: 2021-06-23 09:06:30.209000 | 2021-06-23 16:58:24.697 HD Request # 12 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 16:58:24.697 Socket (9) | Creating socket. | 2021-06-23 16:58:24.697 Socket (9) | New receive buffer size: 5242880 | 2021-06-23 16:58:24.697 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-23 16:58:24.697 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #2 | Reloading chart. | 2021-06-23 16:58:24.697 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:58:24.697 HD Request # 12 | Setting DTC encoding to Binary VLS | 2021-06-23 16:58:24.757 HD Request # 12 | Sending historical data logon request message. | 2021-06-23 16:58:24.757 NGN21-NGH22.FUT_SPREAD.NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:58:24.807 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #2 | Reloading chart. | 2021-06-23 16:58:24.917 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:58:24.917 HD Request # 12 | Requesting Intraday data. Start date-time: 2021-06-23 09:06:30. Record interval: 0. Symbol: NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 16:58:25.237 HD Request # 12 | Decompressing data. | 2021-06-23 16:58:25.257 HD Request # 12 | Receiving Intraday data for NGN21-NGH22.FUT_SPREAD.NYMEX starting at 2021-06-23 09:06:30.179000 | 2021-06-23 16:58:25.257 Socket (9) | CloseSocket call. | 2021-06-23 16:58:25.257 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:58:25.257 Historical data download thread signaled to stop. | 2021-06-23 16:58:25.257 HD Request # 12 | Timestamp of first Intraday data file record written: 2021-06-23 09:13:05.544000 | 2021-06-23 16:58:25.257 HD Request # 12 | Received 182 records from 2021-06-23 09:06:30.179000 to 2021-06-23 16:51:10.311000 (7.7 hours) and wrote 179 records for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 16:58:25.257 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:51:10.311000 | 2021-06-23 16:58:25.267 HD Request # 12 | Completion time: 1s | 2021-06-23 16:58:25.267 HD Request # 12 | Intraday data download complete for NGN21-NGH22.FUT_SPREAD.NYMEX. Unique request ID: 12 | 2021-06-23 16:58:25.267 Removing historical data download ID 12. | 2021-06-23 16:58:25.267 Real-time Intraday chart data file updates started for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 16:58:25.267 Intraday chart data file opened for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 16:58:25.267 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:58:25.267 Triggering next historical data download in queue. | 2021-06-23 16:58:25.267 No download requests in the queue to start downloads for. | 2021-06-23 16:58:25.267 Socket (9) | Socket gracefully closed by remote side. | 2021-06-23 16:58:25.287 Socket (9) | Closed. | 2021-06-23 16:58:25.287 Requesting market depth updates for: NGN21-NGH22.FUT_SPREAD.NYMEX if supported. | 2021-06-23 16:58:25.507 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGN21-NGH22.FUT_SPREAD.NYMEX. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2021-06-23 16:58:25.507 SC Data - All Services | Clearing market depth for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 16:58:25.637 NGN21-NGV21.FUT_SPREAD.NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:59:04.287 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #2 | Reloading chart. | 2021-06-23 16:59:04.337 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:59:04.337 Added historical Intraday data request for NGN21-NGV21.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 16:59:04.397 Intraday data recording state for symbol NGN21-NGV21.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 16:59:04.397 Triggering next historical data download in queue. | 2021-06-23 16:59:04.397 HD Request # 13 | Downloading Intraday chart data for NGN21-NGV21.FUT_SPREAD.NYMEX to the file NGN21-NGV21.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 16:59:04.397 HD Request # 13 | Download start date-time: 2021-06-18 16:59:38.000000. File last date-time: 2021-06-18 16:59:38.675000 | 2021-06-23 16:59:04.397 HD Request # 13 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 16:59:04.397 Socket (4) | Creating socket. | 2021-06-23 16:59:04.397 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 16:59:04.397 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-23 16:59:04.397 HD Request # 13 | Setting DTC encoding to Binary VLS | 2021-06-23 16:59:04.467 HD Request # 13 | Sending historical data logon request message. | 2021-06-23 16:59:04.467 NGN21-NGV21.FUT_SPREAD.NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:59:04.507 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #2 | Reloading chart. | 2021-06-23 16:59:04.557 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:59:04.557 HD Request # 13 | Requesting Intraday data. Start date-time: 2021-06-18 16:59:38. Record interval: 0. Symbol: NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 16:59:04.947 HD Request # 13 | Decompressing data. | 2021-06-23 16:59:04.977 HD Request # 13 | Receiving Intraday data for NGN21-NGV21.FUT_SPREAD.NYMEX starting at 2021-06-18 16:59:38.675000 | 2021-06-23 16:59:05.047 Socket (4) | CloseSocket call. | 2021-06-23 16:59:05.047 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:59:05.047 Historical data download thread signaled to stop. | 2021-06-23 16:59:05.047 HD Request # 13 | Timestamp of first Intraday data file record written: 2021-06-20 18:00:00.000000 | 2021-06-23 16:59:05.047 HD Request # 13 | Received 5186 records from 2021-06-18 16:59:38.675000 to 2021-06-23 16:56:06.933003 (5.0 days) and wrote 5185 records for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 16:59:05.047 HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:56:06.933003 | 2021-06-23 16:59:05.047 HD Request # 13 | Completion time: 1s | 2021-06-23 16:59:05.047 HD Request # 13 | Intraday data download complete for NGN21-NGV21.FUT_SPREAD.NYMEX. Unique request ID: 13 | 2021-06-23 16:59:05.047 Removing historical data download ID 13. | 2021-06-23 16:59:05.047 Real-time Intraday chart data file updates started for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 16:59:05.047 Intraday chart data file opened for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 16:59:05.047 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:59:05.047 Triggering next historical data download in queue. | 2021-06-23 16:59:05.047 No download requests in the queue to start downloads for. | 2021-06-23 16:59:05.047 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 16:59:05.077 Socket (4) | Closed. | 2021-06-23 16:59:05.077 Unsubscribed from market depth data for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 16:59:05.567 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: NGN21-NGH22.FUT_SPREAD.NYMEX.. Service code: nymex | 2021-06-23 16:59:05.567 Requesting market depth updates for: NGN21-NGV21.FUT_SPREAD.NYMEX if supported. | 2021-06-23 16:59:05.567 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGN21-NGV21.FUT_SPREAD.NYMEX. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2021-06-23 16:59:05.567 SC Data - All Services | Clearing market depth for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 16:59:05.677 NGV21-NGF22.FUT_SPREAD.NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:59:32.217 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #2 | Reloading chart. | 2021-06-23 16:59:32.297 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:59:32.297 Added historical Intraday data request for NGV21-NGF22.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 16:59:32.327 Intraday data recording state for symbol NGV21-NGF22.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 16:59:32.327 Triggering next historical data download in queue. | 2021-06-23 16:59:32.327 HD Request # 14 | Downloading Intraday chart data for NGV21-NGF22.FUT_SPREAD.NYMEX to the file NGV21-NGF22.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 16:59:32.327 HD Request # 14 | Download start date-time: 2021-06-23 09:07:15.000000. File last date-time: 2021-06-23 09:07:15.928000 | 2021-06-23 16:59:32.327 HD Request # 14 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 16:59:32.327 Socket (4) | Creating socket. | 2021-06-23 16:59:32.327 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 16:59:32.327 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-23 16:59:32.327 HD Request # 14 | Setting DTC encoding to Binary VLS | 2021-06-23 16:59:32.387 HD Request # 14 | Sending historical data logon request message. | 2021-06-23 16:59:32.387 NGV21-NGF22.FUT_SPREAD.NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 16:59:32.417 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #2 | Reloading chart. | 2021-06-23 16:59:32.507 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 16:59:32.507 HD Request # 14 | Requesting Intraday data. Start date-time: 2021-06-23 09:07:15. Record interval: 0. Symbol: NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 16:59:32.867 HD Request # 14 | Decompressing data. | 2021-06-23 16:59:32.897 HD Request # 14 | Receiving Intraday data for NGV21-NGF22.FUT_SPREAD.NYMEX starting at 2021-06-23 09:07:15.928000 | 2021-06-23 16:59:32.927 Socket (4) | CloseSocket call. | 2021-06-23 16:59:32.927 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 16:59:32.927 Historical data download thread signaled to stop. | 2021-06-23 16:59:32.927 HD Request # 14 | Timestamp of first Intraday data file record written: 2021-06-23 09:07:22.190000 | 2021-06-23 16:59:32.927 HD Request # 14 | Received 1791 records from 2021-06-23 09:07:15.928000 to 2021-06-23 16:56:06.932000 (7.8 hours) and wrote 1790 records for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 16:59:32.927 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:56:06.932000 | 2021-06-23 16:59:32.927 HD Request # 14 | Completion time: 0s | 2021-06-23 16:59:32.927 HD Request # 14 | Intraday data download complete for NGV21-NGF22.FUT_SPREAD.NYMEX. Unique request ID: 14 | 2021-06-23 16:59:32.927 Removing historical data download ID 14. | 2021-06-23 16:59:32.927 Real-time Intraday chart data file updates started for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 16:59:32.927 Intraday chart data file opened for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 16:59:32.927 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2021-06-23 16:59:32.927 Triggering next historical data download in queue. | 2021-06-23 16:59:32.927 No download requests in the queue to start downloads for. | 2021-06-23 16:59:32.927 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 16:59:32.947 Socket (4) | Closed. | 2021-06-23 16:59:32.947 Unsubscribed from market depth data for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 16:59:35.617 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: NGN21-NGV21.FUT_SPREAD.NYMEX.. Service code: nymex | 2021-06-23 16:59:35.617 Requesting market depth updates for: NGV21-NGF22.FUT_SPREAD.NYMEX if supported. | 2021-06-23 16:59:35.617 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGV21-NGF22.FUT_SPREAD.NYMEX. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2021-06-23 16:59:35.617 SC Data - All Services | Clearing market depth for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 16:59:35.667 SC Data - All Services | Sent symbols for underlying request to server. Underlying: NG | 2021-06-23 16:59:55.967 SC Data - All Services | Received symbols for underlying request from server. Underlying: NG. Count: 1754 | 2021-06-23 17:00:00.327 NGH22-NGJ22.FUT_SPREAD.NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 17:00:33.327 NGH22-NGJ22.FUT_SPREAD.NYMEX[M] #2 | Reloading chart. | 2021-06-23 17:00:33.337 NGH22-NGJ22.FUT_SPREAD.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 17:00:33.337 NGH22-NGJ22.FUT_SPREAD.NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-23 17:00:33.537 NGH22-NGJ22.FUT_SPREAD.NYMEX[M] #2 | Reloading chart. | 2021-06-23 17:00:33.557 NGH22-NGJ22.FUT_SPREAD.NYMEX[M] #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 17:00:33.557 Unsubscribed from market depth data for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 17:00:35.707 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: NGV21-NGF22.FUT_SPREAD.NYMEX.. Service code: nymex | 2021-06-23 17:00:35.707 Requesting market depth updates for: NGH22-NGJ22.FUT_SPREAD.NYMEX if supported. | 2021-06-23 17:00:35.707 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGH22-NGJ22.FUT_SPREAD.NYMEX. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2021-06-23 17:00:35.707 SC Data - All Services | Clearing market depth for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:00:35.827 Saved Chartbook: TyP_Practice.Cht. Time: 0.0022 seconds. | 2021-06-23 17:00:48.447 Unsubscribed from market depth data for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:00:50.727 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: NGH22-NGJ22.FUT_SPREAD.NYMEX.. Service code: nymex | 2021-06-23 17:00:50.727 NGN21-NGQ21.FUT_SPREAD.NYMEX 330 Min #1 | Reloading chart. | 2021-06-23 17:01:03.107 NGH22-NGJ22.FUT_SPREAD.NYMEX 5 Min #4 | Reloading chart. | 2021-06-23 17:01:03.117 NGN21-NGQ21.FUT_SPREAD.NYMEX Daily #6 | Reloading chart. | 2021-06-23 17:01:03.167 NGN21-NGQ21.FUT_SPREAD.NYMEX 15 Min #3 | Reloading chart. | 2021-06-23 17:01:03.167 NGH22-NGJ22.FUT_SPREAD.NYMEX #2 | Reloading chart. | 2021-06-23 17:01:03.177 NGH22-NGJ22.FUT_SPREAD.NYMEX #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-23 17:01:03.177 Requesting market depth updates for: NGH22-NGJ22.FUT_SPREAD.NYMEX if supported. | 2021-06-23 17:01:05.757 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGH22-NGJ22.FUT_SPREAD.NYMEX. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2021-06-23 17:01:05.757 SC Data - All Services | Clearing market depth for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:01:05.867 Saved Chartbook: TyP_Practice.Cht. Time: 0.0022 seconds. | 2021-06-23 17:02:39.798 Unsubscribed from market depth data for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:02:40.898 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: NGH22-NGJ22.FUT_SPREAD.NYMEX.. Service code: nymex | 2021-06-23 17:02:40.898 SC DTC Delayed Exchange Data | Real-time data for symbol VXN21-CFE is currently unavailable. | 2021-06-23 17:30:28.468 SC DTC Delayed Exchange Data | Received security definition for symbol VXN21-CFE | 2021-06-23 17:30:50.208 SC DTC Delayed Exchange Data | Real-time data for symbol VXN21-CFE has been restored. | 2021-06-23 17:30:50.208 SC Data - All Services | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-23 17:36:00.398 SC Data - All Services | Real-time data for symbol GCQ21-COMEX is currently unavailable. | 2021-06-23 17:36:00.398 SC Data - All Services | Real-time data for symbol SIN21-COMEX is currently unavailable. | 2021-06-23 17:36:00.398 SC Data - All Services (Market Orders Data) | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-23 17:36:00.398 SC Data - All Services | Real-time data for symbol NGU21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGV21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGQ21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGN21-NGU21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NG:SA 12M F22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGJ22-NGV22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NG:SA 07M J22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGN21-NGV21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGV21-NGF22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGN21-NGH22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol CLN21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol RBQ21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol HOQ21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGU21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGV21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGQ21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGU21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGV21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGV21-NGF22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGH22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services (Market Orders Data) | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-23 17:36:01.838 SC Data - All Services | Real-time data for symbol ZNM21-CBOT is currently unavailable. | 2021-06-23 17:36:03.398 SC Data - All Services | Real-time data for symbol ZBU21-CBOT is currently unavailable. | 2021-06-23 17:36:03.398 SC Data - All Services | Real-time data for symbol ZCN21-CBOT is currently unavailable. | 2021-06-23 17:36:03.398 SC Data - All Services | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-23 17:36:03.398 SC Data - All Services | Real-time data for symbol ZLN21-CBOT is currently unavailable. | 2021-06-23 17:36:03.398 SC Data - All Services | Real-time data for symbol ZWU21-CBOT is currently unavailable. | 2021-06-23 17:36:03.398 SC Data - All Services | Real-time data for symbol ZWN21-CBOT is currently unavailable. | 2021-06-23 17:36:03.398 SC Data - All Services (Market Orders Data) | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-23 17:36:03.398 SC Data - All Services | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-23 17:36:04.368 SC Data - All Services | Real-time data for symbol 6EU21-CME is currently unavailable. | 2021-06-23 17:36:04.368 SC Data - All Services | Real-time data for symbol BTCM21-CME is currently unavailable. | 2021-06-23 17:36:04.368 SC Data - All Services (Market Orders Data) | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-23 17:36:04.368 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-23 17:36:26.608 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 17:36:26.608 Added historical Intraday data request for ESU21-CME to the queue. | 2021-06-23 17:36:26.608 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-06-23 17:36:26.608 Triggering next historical data download in queue. | 2021-06-23 17:36:26.608 HD Request # 15 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-06-23 17:36:26.608 HD Request # 15 | Download start date-time: 2021-06-23 16:59:59.000000. File last date-time: 2021-06-23 16:59:59.283000 | 2021-06-23 17:36:26.608 HD Request # 15 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 17:36:26.608 SC Data - All Services (Market Orders Data) | Received security definition for symbol ESU21-CME | 2021-06-23 17:36:26.608 SC Data - All Services (Market Orders Data) | Real-time data for symbol ESU21-CME has been restored. | 2021-06-23 17:36:26.608 Socket (4) | Creating socket. | 2021-06-23 17:36:26.608 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 17:36:26.608 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-23 17:36:26.608 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-23 17:36:26.698 HD Request # 15 | Setting DTC encoding to Binary VLS | 2021-06-23 17:36:26.908 HD Request # 15 | Sending historical data logon request message. | 2021-06-23 17:36:26.908 SC Data - All Services | Received security definition for symbol 6EU21-CME | 2021-06-23 17:36:28.578 SC Data - All Services | Real-time data for symbol 6EU21-CME has been restored. | 2021-06-23 17:36:28.578 SC Data - All Services | Received security definition for symbol ZBU21-CBOT | 2021-06-23 17:36:31.638 SC Data - All Services | Real-time data for symbol ZBU21-CBOT has been restored. | 2021-06-23 17:36:31.638 HD Request # 15 | Requesting Intraday data. Start date-time: 2021-06-23 16:59:59. Record interval: 0. Symbol: ESU21 | 2021-06-23 17:36:32.558 HD Request # 15 | Decompressing data. | 2021-06-23 17:36:32.588 HD Request # 15 | Receiving Intraday data for ESU21-CME starting at 2021-06-23 16:59:59.283000 | 2021-06-23 17:36:32.588 Socket (4) | CloseSocket call. | 2021-06-23 17:36:32.588 Historical data download thread signaled to stop. | 2021-06-23 17:36:32.588 HD Request # 15 | Received 1 record from 2021-06-23 16:59:59.283000 to 2021-06-23 16:59:59.283000 (0.0 seconds) and wrote 0 records for ESU21-CME | 2021-06-23 17:36:32.588 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 17:36:32.588 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:59:59.283000 | 2021-06-23 17:36:32.588 HD Request # 15 | Completion time: 6s | 2021-06-23 17:36:32.588 HD Request # 15 | Intraday data download complete for ESU21-CME. Unique request ID: 15 | 2021-06-23 17:36:32.588 Removing historical data download ID 15. | 2021-06-23 17:36:32.588 Real-time Intraday chart data file updates started for ESU21-CME | 2021-06-23 17:36:32.588 Intraday chart data file opened for ESU21-CME | 2021-06-23 17:36:32.588 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2021-06-23 17:36:32.588 Triggering next historical data download in queue. | 2021-06-23 17:36:32.588 No download requests in the queue to start downloads for. | 2021-06-23 17:36:32.588 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 17:36:32.618 Socket (4) | Closed. | 2021-06-23 17:36:32.618 SC Data - All Services | Received security definition for symbol NGU21-NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services | Real-time data for symbol NGU21-NYMEX has been restored. | 2021-06-23 17:36:40.848 SC Data - All Services | Received security definition for symbol NGV21-NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services | Real-time data for symbol NGV21-NYMEX has been restored. | 2021-06-23 17:36:40.848 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 17:36:40.848 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-23 17:36:40.848 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-23 17:36:40.848 Triggering next historical data download in queue. | 2021-06-23 17:36:40.848 SC Data - All Services | Received security definition for symbol NGQ21-NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services | Real-time data for symbol NGQ21-NYMEX has been restored. | 2021-06-23 17:36:40.848 SC Data - All Services | Received security definition for symbol NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services | Real-time data for symbol NGN21-NGU21.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.848 Added historical Intraday data request for NGN21-NGU21.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 17:36:40.848 Intraday data recording state for symbol NGN21-NGU21.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 17:36:40.848 SC Data - All Services | Received security definition for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services | Real-time data for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.848 Added historical Intraday data request for NGH22-NGJ22.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 17:36:40.848 Intraday data recording state for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 17:36:40.848 SC Data - All Services | Received security definition for symbol NG:SA 12M F22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services | Real-time data for symbol NG:SA 12M F22.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.848 HD Request # 16 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-23 17:36:40.848 HD Request # 16 | Download start date-time: 2021-06-23 16:59:59.000000. File last date-time: 2021-06-23 16:59:59.154000 | 2021-06-23 17:36:40.848 HD Request # 16 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGU21-NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGU21-NYMEX has been restored. | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGV21-NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGV21-NYMEX has been restored. | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGQ21-NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGQ21-NYMEX has been restored. | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGU21.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.848 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.848 Socket (4) | Creating socket. | 2021-06-23 17:36:40.848 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 17:36:40.848 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-23 17:36:40.848 HD Request # 16 | Setting DTC encoding to Binary VLS | 2021-06-23 17:36:40.908 HD Request # 16 | Sending historical data logon request message. | 2021-06-23 17:36:40.908 HD Request # 16 | Requesting Intraday data. Start date-time: 2021-06-23 16:59:59. Record interval: 0. Symbol: NGN21 | 2021-06-23 17:36:40.938 SC Data - All Services | Received security definition for symbol NGJ22-NGV22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.948 SC Data - All Services | Real-time data for symbol NGJ22-NGV22.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.948 SC Data - All Services | Received security definition for symbol NG:SA 07M J22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.948 SC Data - All Services | Real-time data for symbol NG:SA 07M J22.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.948 SC Data - All Services | Received security definition for symbol NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.948 SC Data - All Services | Real-time data for symbol NGN21-NGV21.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.948 Added historical Intraday data request for NGN21-NGV21.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 17:36:40.948 Intraday data recording state for symbol NGN21-NGV21.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 17:36:40.948 Triggering next historical data download in queue. | 2021-06-23 17:36:40.948 SC Data - All Services | Received security definition for symbol NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.948 SC Data - All Services | Real-time data for symbol NGV21-NGF22.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.948 Added historical Intraday data request for NGV21-NGF22.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 17:36:40.948 Intraday data recording state for symbol NGV21-NGF22.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 17:36:40.948 SC Data - All Services | Received security definition for symbol NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:40.948 SC Data - All Services | Real-time data for symbol NGN21-NGH22.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:40.948 Added historical Intraday data request for NGN21-NGH22.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 17:36:40.948 Intraday data recording state for symbol NGN21-NGH22.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 17:36:40.948 HD Request # 16 | Decompressing data. | 2021-06-23 17:36:40.958 HD Request # 16 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-23 16:59:59.154000 | 2021-06-23 17:36:40.958 Socket (4) | CloseSocket call. | 2021-06-23 17:36:40.958 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 17:36:40.958 Historical data download thread signaled to stop. | 2021-06-23 17:36:40.958 HD Request # 16 | Received 1 record from 2021-06-23 16:59:59.154000 to 2021-06-23 16:59:59.154000 (0.0 seconds) and wrote 0 records for NGN21-NYMEX | 2021-06-23 17:36:40.958 HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:59:59.154000 | 2021-06-23 17:36:40.958 HD Request # 16 | Completion time: 0s | 2021-06-23 17:36:40.958 HD Request # 16 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 16 | 2021-06-23 17:36:40.958 Removing historical data download ID 16. | 2021-06-23 17:36:40.958 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-23 17:36:40.958 Intraday chart data file opened for NGN21-NYMEX | 2021-06-23 17:36:40.958 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2021-06-23 17:36:40.958 Triggering next historical data download in queue. | 2021-06-23 17:36:40.958 HD Request # 17 | Downloading Intraday chart data for NGN21-NGU21.FUT_SPREAD.NYMEX to the file NGN21-NGU21.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 17:36:40.958 HD Request # 17 | Download start date-time: 2021-06-23 16:59:54.000000. File last date-time: 2021-06-23 16:59:54.704000 | 2021-06-23 17:36:40.958 HD Request # 17 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 17:36:40.958 Socket (9) | Creating socket. | 2021-06-23 17:36:40.958 Socket (9) | New receive buffer size: 5242880 | 2021-06-23 17:36:40.958 Socket (9) | Connecting to IP: 216.1.90.130. | 2021-06-23 17:36:40.958 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 17:36:40.988 Socket (4) | Closed. | 2021-06-23 17:36:40.988 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.008 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGV21.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:41.008 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.008 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGV21-NGF22.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:41.008 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.008 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGH22.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:41.008 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.008 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:41.008 Added historical Intraday data request for NGN21-NGQ21.FUT_SPREAD.NYMEX to the queue. | 2021-06-23 17:36:41.008 Intraday data recording state for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-23 17:36:41.008 Triggering next historical data download in queue. | 2021-06-23 17:36:41.008 SC Data - All Services | Clearing market depth for NGU21-NYMEX | 2021-06-23 17:36:41.038 SC Data - All Services | Clearing market depth for NGV21-NYMEX | 2021-06-23 17:36:41.038 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-23 17:36:41.038 SC Data - All Services | Clearing market depth for NGQ21-NYMEX | 2021-06-23 17:36:41.038 SC Data - All Services | Clearing market depth for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.038 SC Data - All Services | Received security definition for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.038 SC Data - All Services | Real-time data for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX has been restored. | 2021-06-23 17:36:41.038 HD Request # 17 | Setting DTC encoding to Binary VLS | 2021-06-23 17:36:41.058 HD Request # 17 | Sending historical data logon request message. | 2021-06-23 17:36:41.058 HD Request # 17 | Requesting Intraday data. Start date-time: 2021-06-23 16:59:54. Record interval: 0. Symbol: NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.088 HD Request # 17 | Decompressing data. | 2021-06-23 17:36:41.108 HD Request # 17 | Receiving Intraday data for NGN21-NGU21.FUT_SPREAD.NYMEX starting at 2021-06-23 16:59:54.704000 | 2021-06-23 17:36:41.108 Socket (9) | CloseSocket call. | 2021-06-23 17:36:41.108 Historical data download thread signaled to stop. | 2021-06-23 17:36:41.108 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-23 17:36:41.108 HD Request # 17 | Received 1 record from 2021-06-23 16:59:54.704000 to 2021-06-23 16:59:54.704000 (0.0 seconds) and wrote 0 records for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.108 HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:59:54.704000 | 2021-06-23 17:36:41.108 HD Request # 17 | Completion time: 1s | 2021-06-23 17:36:41.108 HD Request # 17 | Intraday data download complete for NGN21-NGU21.FUT_SPREAD.NYMEX. Unique request ID: 17 | 2021-06-23 17:36:41.108 Removing historical data download ID 17. | 2021-06-23 17:36:41.108 Real-time Intraday chart data file updates started for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.108 Intraday chart data file opened for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.108 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2021-06-23 17:36:41.108 Triggering next historical data download in queue. | 2021-06-23 17:36:41.108 HD Request # 18 | Downloading Intraday chart data for NGH22-NGJ22.FUT_SPREAD.NYMEX to the file NGH22-NGJ22.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 17:36:41.108 HD Request # 18 | Download start date-time: 2021-06-23 16:54:07.000000. File last date-time: 2021-06-23 16:54:07.131000 | 2021-06-23 17:36:41.108 HD Request # 18 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 17:36:41.108 Socket (4) | Creating socket. | 2021-06-23 17:36:41.108 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 17:36:41.108 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-23 17:36:41.108 Socket (9) | Socket gracefully closed by remote side. | 2021-06-23 17:36:41.138 Socket (9) | Closed. | 2021-06-23 17:36:41.138 HD Request # 18 | Setting DTC encoding to Binary VLS | 2021-06-23 17:36:41.168 HD Request # 18 | Sending historical data logon request message. | 2021-06-23 17:36:41.168 HD Request # 18 | Requesting Intraday data. Start date-time: 2021-06-23 16:54:07. Record interval: 0. Symbol: NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.188 HD Request # 18 | Decompressing data. | 2021-06-23 17:36:41.218 HD Request # 18 | Receiving Intraday data for NGH22-NGJ22.FUT_SPREAD.NYMEX starting at 2021-06-23 16:54:07.131000 | 2021-06-23 17:36:41.218 Socket (4) | CloseSocket call. | 2021-06-23 17:36:41.218 Historical data download thread signaled to stop. | 2021-06-23 17:36:41.218 HD Request # 18 | Received 1 record from 2021-06-23 16:54:07.131000 to 2021-06-23 16:54:07.131000 (0.0 seconds) and wrote 0 records for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.218 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 17:36:41.218 HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:54:07.131000 | 2021-06-23 17:36:41.218 HD Request # 18 | Completion time: 0s | 2021-06-23 17:36:41.218 HD Request # 18 | Intraday data download complete for NGH22-NGJ22.FUT_SPREAD.NYMEX. Unique request ID: 18 | 2021-06-23 17:36:41.218 Removing historical data download ID 18. | 2021-06-23 17:36:41.218 Real-time Intraday chart data file updates started for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.218 Intraday chart data file opened for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.218 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2021-06-23 17:36:41.218 Triggering next historical data download in queue. | 2021-06-23 17:36:41.218 HD Request # 19 | Downloading Intraday chart data for NGN21-NGV21.FUT_SPREAD.NYMEX to the file NGN21-NGV21.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 17:36:41.218 HD Request # 19 | Download start date-time: 2021-06-23 16:56:06.000000. File last date-time: 2021-06-23 16:56:06.933003 | 2021-06-23 17:36:41.218 HD Request # 19 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 17:36:41.218 Socket (9) | Creating socket. | 2021-06-23 17:36:41.218 Socket (9) | New receive buffer size: 5242880 | 2021-06-23 17:36:41.218 Socket (9) | Connecting to IP: 216.1.90.130. | 2021-06-23 17:36:41.218 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 17:36:41.248 Socket (4) | Closed. | 2021-06-23 17:36:41.248 HD Request # 19 | Setting DTC encoding to Binary VLS | 2021-06-23 17:36:41.278 HD Request # 19 | Sending historical data logon request message. | 2021-06-23 17:36:41.278 HD Request # 19 | Requesting Intraday data. Start date-time: 2021-06-23 16:56:06. Record interval: 0. Symbol: NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.308 HD Request # 19 | Decompressing data. | 2021-06-23 17:36:41.338 HD Request # 19 | Receiving Intraday data for NGN21-NGV21.FUT_SPREAD.NYMEX starting at 2021-06-23 16:56:06.933000 | 2021-06-23 17:36:41.338 Socket (9) | CloseSocket call. | 2021-06-23 17:36:41.338 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-23 17:36:41.338 Historical data download thread signaled to stop. | 2021-06-23 17:36:41.338 HD Request # 19 | Received 4 records from 2021-06-23 16:56:06.933000 to 2021-06-23 16:56:06.933003 (0.0 seconds) and wrote 0 records for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.338 HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:56:06.933003 | 2021-06-23 17:36:41.338 HD Request # 19 | Completion time: 0s | 2021-06-23 17:36:41.338 HD Request # 19 | Intraday data download complete for NGN21-NGV21.FUT_SPREAD.NYMEX. Unique request ID: 19 | 2021-06-23 17:36:41.338 Removing historical data download ID 19. | 2021-06-23 17:36:41.338 Real-time Intraday chart data file updates started for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.338 Intraday chart data file opened for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.338 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2021-06-23 17:36:41.338 Triggering next historical data download in queue. | 2021-06-23 17:36:41.338 HD Request # 20 | Downloading Intraday chart data for NGV21-NGF22.FUT_SPREAD.NYMEX to the file NGV21-NGF22.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 17:36:41.338 HD Request # 20 | Download start date-time: 2021-06-23 16:56:06.000000. File last date-time: 2021-06-23 16:56:06.932000 | 2021-06-23 17:36:41.338 HD Request # 20 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 17:36:41.338 Socket (4) | Creating socket. | 2021-06-23 17:36:41.338 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 17:36:41.338 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-23 17:36:41.338 Socket (9) | Socket gracefully closed by remote side. | 2021-06-23 17:36:41.358 Socket (9) | Closed. | 2021-06-23 17:36:41.358 HD Request # 20 | Setting DTC encoding to Binary VLS | 2021-06-23 17:36:41.398 HD Request # 20 | Sending historical data logon request message. | 2021-06-23 17:36:41.398 HD Request # 20 | Requesting Intraday data. Start date-time: 2021-06-23 16:56:06. Record interval: 0. Symbol: NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.418 HD Request # 20 | Decompressing data. | 2021-06-23 17:36:41.448 HD Request # 20 | Receiving Intraday data for NGV21-NGF22.FUT_SPREAD.NYMEX starting at 2021-06-23 16:56:06.932000 | 2021-06-23 17:36:41.448 Socket (4) | CloseSocket call. | 2021-06-23 17:36:41.448 Historical data download thread signaled to stop. | 2021-06-23 17:36:41.448 HD Request # 20 | Received 1 record from 2021-06-23 16:56:06.932000 to 2021-06-23 16:56:06.932000 (0.0 seconds) and wrote 0 records for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.448 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 17:36:41.448 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:56:06.932000 | 2021-06-23 17:36:41.448 HD Request # 20 | Completion time: 0s | 2021-06-23 17:36:41.448 HD Request # 20 | Intraday data download complete for NGV21-NGF22.FUT_SPREAD.NYMEX. Unique request ID: 20 | 2021-06-23 17:36:41.448 Removing historical data download ID 20. | 2021-06-23 17:36:41.448 Real-time Intraday chart data file updates started for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.448 Intraday chart data file opened for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.448 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2021-06-23 17:36:41.448 Triggering next historical data download in queue. | 2021-06-23 17:36:41.448 HD Request # 21 | Downloading Intraday chart data for NGN21-NGH22.FUT_SPREAD.NYMEX to the file NGN21-NGH22.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 17:36:41.448 HD Request # 21 | Download start date-time: 2021-06-23 16:51:10.000000. File last date-time: 2021-06-23 16:51:10.311000 | 2021-06-23 17:36:41.448 HD Request # 21 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 17:36:41.448 Socket (9) | Creating socket. | 2021-06-23 17:36:41.448 Socket (9) | New receive buffer size: 5242880 | 2021-06-23 17:36:41.448 Socket (9) | Connecting to IP: 216.1.90.130. | 2021-06-23 17:36:41.448 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 17:36:41.478 Socket (4) | Closed. | 2021-06-23 17:36:41.478 HD Request # 21 | Setting DTC encoding to Binary VLS | 2021-06-23 17:36:41.518 HD Request # 21 | Sending historical data logon request message. | 2021-06-23 17:36:41.518 HD Request # 21 | Requesting Intraday data. Start date-time: 2021-06-23 16:51:10. Record interval: 0. Symbol: NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.538 HD Request # 21 | Decompressing data. | 2021-06-23 17:36:41.568 HD Request # 21 | Receiving Intraday data for NGN21-NGH22.FUT_SPREAD.NYMEX starting at 2021-06-23 16:51:10.107000 | 2021-06-23 17:36:41.568 Socket (9) | CloseSocket call. | 2021-06-23 17:36:41.568 Historical data download thread signaled to stop. | 2021-06-23 17:36:41.568 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-23 17:36:41.568 HD Request # 21 | Received 5 records from 2021-06-23 16:51:10.107000 to 2021-06-23 16:51:10.311000 (0.2 seconds) and wrote 0 records for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.568 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:51:10.311000 | 2021-06-23 17:36:41.568 HD Request # 21 | Completion time: 0s | 2021-06-23 17:36:41.568 HD Request # 21 | Intraday data download complete for NGN21-NGH22.FUT_SPREAD.NYMEX. Unique request ID: 21 | 2021-06-23 17:36:41.568 Removing historical data download ID 21. | 2021-06-23 17:36:41.568 Real-time Intraday chart data file updates started for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.568 Intraday chart data file opened for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.568 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2021-06-23 17:36:41.568 Triggering next historical data download in queue. | 2021-06-23 17:36:41.568 HD Request # 22 | Downloading Intraday chart data for NGN21-NGQ21.FUT_SPREAD.NYMEX to the file NGN21-NGQ21.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-23 17:36:41.568 HD Request # 22 | Download start date-time: 2021-06-23 16:59:59.000000. File last date-time: 2021-06-23 16:59:59.512000 | 2021-06-23 17:36:41.568 HD Request # 22 | Using server: ds21.sierracharts.com port 10149 | 2021-06-23 17:36:41.568 Socket (4) | Creating socket. | 2021-06-23 17:36:41.568 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 17:36:41.568 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-23 17:36:41.568 Socket (9) | Socket gracefully closed by remote side. | 2021-06-23 17:36:41.598 Socket (9) | Closed. | 2021-06-23 17:36:41.598 HD Request # 22 | Setting DTC encoding to Binary VLS | 2021-06-23 17:36:41.628 HD Request # 22 | Sending historical data logon request message. | 2021-06-23 17:36:41.628 HD Request # 22 | Requesting Intraday data. Start date-time: 2021-06-23 16:59:59. Record interval: 0. Symbol: NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.658 HD Request # 22 | Decompressing data. | 2021-06-23 17:36:41.678 HD Request # 22 | Receiving Intraday data for NGN21-NGQ21.FUT_SPREAD.NYMEX starting at 2021-06-23 16:59:59.512000 | 2021-06-23 17:36:41.678 Socket (4) | CloseSocket call. | 2021-06-23 17:36:41.678 Historical data download thread signaled to stop. | 2021-06-23 17:36:41.678 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 17:36:41.678 HD Request # 22 | Received 1 record from 2021-06-23 16:59:59.512000 to 2021-06-23 16:59:59.512000 (0.0 seconds) and wrote 0 records for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.678 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:59:59.512000 | 2021-06-23 17:36:41.678 HD Request # 22 | Completion time: 0s | 2021-06-23 17:36:41.678 HD Request # 22 | Intraday data download complete for NGN21-NGQ21.FUT_SPREAD.NYMEX. Unique request ID: 22 | 2021-06-23 17:36:41.678 Removing historical data download ID 22. | 2021-06-23 17:36:41.678 Real-time Intraday chart data file updates started for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.678 Intraday chart data file opened for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-23 17:36:41.678 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2021-06-23 17:36:41.678 Triggering next historical data download in queue. | 2021-06-23 17:36:41.678 No download requests in the queue to start downloads for. | 2021-06-23 17:36:41.678 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 17:36:41.708 Socket (4) | Closed. | 2021-06-23 17:36:41.708 SC Data - All Services | Received security definition for symbol ZCN21-CBOT | 2021-06-23 17:36:43.598 SC Data - All Services | Real-time data for symbol ZCN21-CBOT has been restored. | 2021-06-23 17:36:43.598 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-23 17:36:43.598 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 17:36:43.598 SC Data - All Services | Received security definition for symbol ZLN21-CBOT | 2021-06-23 17:36:43.598 SC Data - All Services | Real-time data for symbol ZLN21-CBOT has been restored. | 2021-06-23 17:36:43.598 SC Data - All Services | Received security definition for symbol ZWU21-CBOT | 2021-06-23 17:36:43.598 SC Data - All Services | Real-time data for symbol ZWU21-CBOT has been restored. | 2021-06-23 17:36:43.598 SC Data - All Services | Received security definition for symbol ZWN21-CBOT | 2021-06-23 17:36:43.598 SC Data - All Services | Real-time data for symbol ZWN21-CBOT has been restored. | 2021-06-23 17:36:43.598 SC Data - All Services (Market Orders Data) | Received security definition for symbol ZSN21-CBOT | 2021-06-23 17:36:43.628 SC Data - All Services (Market Orders Data) | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-23 17:36:43.628 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-23 17:36:43.698 SC Data - All Services (Market Orders Data) | Received security definition for symbol HGN21-COMEX | 2021-06-23 17:36:44.508 SC Data - All Services (Market Orders Data) | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 17:36:44.508 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-23 17:36:44.508 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-23 17:36:44.508 SC Data - All Services | Received security definition for symbol GCQ21-COMEX | 2021-06-23 17:36:44.508 SC Data - All Services | Real-time data for symbol GCQ21-COMEX has been restored. | 2021-06-23 17:36:44.508 Added historical Intraday data request for GCQ21-COMEX to the queue. | 2021-06-23 17:36:44.508 Intraday data recording state for symbol GCQ21-COMEX is set to download 'Pending'. | 2021-06-23 17:36:44.508 Triggering next historical data download in queue. | 2021-06-23 17:36:44.508 SC Data - All Services | Received security definition for symbol SIN21-COMEX | 2021-06-23 17:36:44.508 SC Data - All Services | Real-time data for symbol SIN21-COMEX has been restored. | 2021-06-23 17:36:44.508 HD Request # 23 | Downloading Intraday chart data for GCQ21-COMEX to the file GCQ21-COMEX.scid. Service: comex | 2021-06-23 17:36:44.508 HD Request # 23 | Download start date-time: 2021-06-23 16:59:55.000000. File last date-time: 2021-06-23 16:59:55.957000 | 2021-06-23 17:36:44.518 HD Request # 23 | Using server: ds23.sierracharts.com port 10150 | 2021-06-23 17:36:44.518 Socket (4) | Creating socket. | 2021-06-23 17:36:44.518 Socket (4) | New receive buffer size: 5242880 | 2021-06-23 17:36:44.518 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-23 17:36:44.518 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-23 17:36:44.598 HD Request # 23 | Setting DTC encoding to Binary VLS | 2021-06-23 17:36:44.688 HD Request # 23 | Sending historical data logon request message. | 2021-06-23 17:36:44.688 HD Request # 23 | Requesting Intraday data. Start date-time: 2021-06-23 16:59:55. Record interval: 0. Symbol: GCQ21 | 2021-06-23 17:36:44.798 HD Request # 23 | Decompressing data. | 2021-06-23 17:36:44.878 HD Request # 23 | Receiving Intraday data for GCQ21-COMEX starting at 2021-06-23 16:59:55.102000 | 2021-06-23 17:36:44.878 Socket (4) | CloseSocket call. | 2021-06-23 17:36:44.878 Historical data download thread signaled to stop. | 2021-06-23 17:36:44.878 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 17:36:44.878 HD Request # 23 | Received 2 records from 2021-06-23 16:59:55.102000 to 2021-06-23 16:59:55.957000 (0.9 seconds) and wrote 0 records for GCQ21-COMEX | 2021-06-23 17:36:44.878 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2021-06-23 20:59:55.957000 | 2021-06-23 17:36:44.878 HD Request # 23 | Completion time: 0s | 2021-06-23 17:36:44.878 HD Request # 23 | Intraday data download complete for GCQ21-COMEX. Unique request ID: 23 | 2021-06-23 17:36:44.878 Removing historical data download ID 23. | 2021-06-23 17:36:44.878 Real-time Intraday chart data file updates started for GCQ21-COMEX | 2021-06-23 17:36:44.878 Intraday chart data file opened for GCQ21-COMEX | 2021-06-23 17:36:44.878 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2021-06-23 17:36:44.878 Triggering next historical data download in queue. | 2021-06-23 17:36:44.878 No download requests in the queue to start downloads for. | 2021-06-23 17:36:44.878 Socket (4) | Socket gracefully closed by remote side. | 2021-06-23 17:36:45.058 Socket (4) | Closed. | 2021-06-23 17:36:45.058 SC Data - All Services | Received security definition for symbol CLN21-NYMEX | 2021-06-23 17:36:46.888 SC Data - All Services | Real-time data for symbol CLN21-NYMEX has been restored. | 2021-06-23 17:36:46.888 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 17:36:46.888 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 17:36:46.888 SC Data - All Services | Received security definition for symbol RBQ21-NYMEX | 2021-06-23 17:36:46.888 SC Data - All Services | Real-time data for symbol RBQ21-NYMEX has been restored. | 2021-06-23 17:36:46.888 SC Data - All Services | Received security definition for symbol HOQ21-NYMEX | 2021-06-23 17:36:46.888 SC Data - All Services | Real-time data for symbol HOQ21-NYMEX has been restored. | 2021-06-23 17:36:46.888 SC Data - All Services (Market Orders Data) | Received security definition for symbol CLQ21-NYMEX | 2021-06-23 17:36:46.918 SC Data - All Services (Market Orders Data) | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-23 17:36:46.918 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-23 17:36:47.358 SC Data - All Services | Received security definition for symbol BTCM21-CME | 2021-06-23 17:36:50.638 SC Data - All Services | Real-time data for symbol BTCM21-CME has been restored. | 2021-06-23 17:36:50.638 SC DTC Delayed Exchange Data | Real-time data for symbol VXN21-CFE has been restored. | 2021-06-23 17:40:50.378 Requesting current DateTime from Sierra Chart server. | 2021-06-23 17:49:30.709 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-23 21:49:31.100. Round-trip delay: 00:00:00.200 | 2021-06-23 17:49:31.109 Computer time to server time difference: 00:00:00.009 | 2021-06-23 17:49:31.109 Successfully set the system Date-time to: 2021-06-23 21:49:31.100 UTC. | 2021-06-23 17:49:31.100 Opened cached Intraday file: C:\SierraChart\Data\ESU21-CME.scid. Thread ID: 5644 | 2021-06-23 18:00:04.360 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NYMEX.scid. Thread ID: 5644 | 2021-06-23 18:00:04.360 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGQ21.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-23 18:00:04.360 Opened cached Intraday file: C:\SierraChart\Data\GCQ21-COMEX.scid. Thread ID: 5644 | 2021-06-23 18:00:04.360 Opened cached Intraday file: C:\SierraChart\Data\NGH22-NGJ22.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-23 18:00:04.360 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 18:00:32.620 HD Server Manager | Started new historical data server. Count=1 | 2021-06-23 18:00:32.620 HD Server | Thread:5664 (4) | Creating socket. | 2021-06-23 18:00:32.630 HD Server | Thread:5664 (4) | New receive buffer size: 262144 | 2021-06-23 18:00:32.630 HD Server | Thread:5664 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-23 18:00:32.630 HD Server | Setting DTC encoding to Binary VLS | Thread:5664 | 2021-06-23 18:00:32.630 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:5664 | 2021-06-23 18:00:32.630 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:5664 | 2021-06-23 18:00:32.630 HD Server | HD Request #93 | Socket: 4 | Symbol: NGN21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-17 00:00:00 | ClientReqID: 93 | Username: SPRDTRDR. | Thread:5664 | 2021-06-23 18:00:32.630 Added historical Daily data request for NGN21-NYMEX to the queue. | 2021-06-23 18:00:32.630 Triggering next historical data download in queue. | 2021-06-23 18:00:32.630 HD Request # 24 | Downloading Historical Daily chart data for NGN21-NYMEX. Starting date: 2021-06-17. Service: scdataallservices | 2021-06-23 18:00:32.630 HD Request # 24 | Requesting historical Daily data for NGN21 starting at 2021-06-16. SC External HD service. | 2021-06-23 18:00:33.120 HD Request # 24 | Receiving historical Daily data for NGN21-NYMEX starting at 2021-06-17 | 2021-06-23 18:00:33.370 HD Request # 24 | Writing historical Daily data to the file NGN21-NYMEX.dly | 2021-06-23 18:00:33.370 HD Request # 24 | Bytes received: 322 | 2021-06-23 18:00:33.380 HD Request # 24 | Received 6 records from 2021-06-17 00:00:00 to 2021-06-23 00:00:00 (7.0 days) and wrote 5 records for NGN21-NYMEX | 2021-06-23 18:00:33.380 HD Request # 24 | Completion time: 1s | 2021-06-23 18:00:33.390 HD Request # 24 | Daily data download complete for NGN21-NYMEX. Unique request ID: 24 | 2021-06-23 18:00:33.390 Removing historical data download ID 24. | 2021-06-23 18:00:33.390 Triggering next historical data download in queue. | 2021-06-23 18:00:33.390 No download requests in the queue to start downloads for. | 2021-06-23 18:00:33.390 HD Server | HD Request | Socket: 4 | Symbol: NGN21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 5 | ClientReqID: 93 | Username: SPRDTRDR. | Thread:5664 | 2021-06-23 18:00:33.650 HD Server | Thread:5664 (4) | Socket gracefully closed by remote side. | 2021-06-23 18:00:33.670 HD Server | Thread:5664 (4) | CloseSocket call. | 2021-06-23 18:00:33.670 HD Server | Thread:5664 (0) | CloseSocket call. | 2021-06-23 18:00:33.670 HD Server | Thread:5664 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 18:00:33.670 HD Server | Thread:5664 (4) | Closed. | 2021-06-23 18:00:33.670 HD Server | Thread:5664 (0) | CloseSocket call. | 2021-06-23 18:00:33.670 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 18:00:33.690 HD Server Manager | Started new historical data server. Count=2 | 2021-06-23 18:00:33.690 HD Server | Thread:4868 (4) | Creating socket. | 2021-06-23 18:00:33.700 HD Server | Thread:4868 (4) | New receive buffer size: 262144 | 2021-06-23 18:00:33.700 HD Server | Thread:4868 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-23 18:00:33.700 HD Server | Setting DTC encoding to Binary VLS | Thread:4868 | 2021-06-23 18:00:33.700 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4868 | 2021-06-23 18:00:33.700 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4868 | 2021-06-23 18:00:33.700 HD Server | HD Request #94 | Socket: 4 | Symbol: ZBU21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 94 | Username: SPRDTRDR. | Thread:4868 | 2021-06-23 18:00:33.700 Added historical Daily data request for ZBU21-CBOT to the queue. | 2021-06-23 18:00:33.700 Triggering next historical data download in queue. | 2021-06-23 18:00:33.700 HD Request # 25 | Downloading Historical Daily chart data for ZBU21-CBOT. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-23 18:00:33.710 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:5664 | 2021-06-23 18:00:33.910 HD Server Manager | Current server count=1 | 2021-06-23 18:00:33.910 HD Request # 25 | Requesting historical Daily data for ZBU21 starting at 2021-06-20. SC External HD service. | 2021-06-23 18:00:34.200 HD Request # 25 | Receiving historical Daily data for ZBU21-CBOT starting at 2021-06-21 | 2021-06-23 18:00:34.330 HD Request # 25 | Writing historical Daily data to the file ZBU21-CBOT.dly | 2021-06-23 18:00:34.330 HD Request # 25 | Bytes received: 196 | 2021-06-23 18:00:34.330 HD Request # 25 | Received 3 records from 2021-06-21 00:00:00 to 2021-06-23 00:00:00 (3.0 days) and wrote 3 records for ZBU21-CBOT | 2021-06-23 18:00:34.330 HD Request # 25 | Completion time: 1s | 2021-06-23 18:00:34.340 HD Request # 25 | Daily data download complete for ZBU21-CBOT. Unique request ID: 25 | 2021-06-23 18:00:34.340 Removing historical data download ID 25. | 2021-06-23 18:00:34.340 Triggering next historical data download in queue. | 2021-06-23 18:00:34.340 No download requests in the queue to start downloads for. | 2021-06-23 18:00:34.340 HD Server | HD Request | Socket: 4 | Symbol: ZBU21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 94 | Username: SPRDTRDR. | Thread:4868 | 2021-06-23 18:00:34.720 HD Server | Thread:4868 (4) | Socket gracefully closed by remote side. | 2021-06-23 18:00:34.720 HD Server | Thread:4868 (4) | CloseSocket call. | 2021-06-23 18:00:34.720 HD Server | Thread:4868 (0) | CloseSocket call. | 2021-06-23 18:00:34.720 HD Server | Thread:4868 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 18:00:34.720 HD Server | Thread:4868 (4) | Closed. | 2021-06-23 18:00:34.720 HD Server | Thread:4868 (0) | CloseSocket call. | 2021-06-23 18:00:34.720 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4868 | 2021-06-23 18:00:34.950 HD Server Manager | Current server count=0 | 2021-06-23 18:00:34.950 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 18:01:01.020 HD Server Manager | Started new historical data server. Count=1 | 2021-06-23 18:01:01.020 HD Server | Thread:6476 (4) | Creating socket. | 2021-06-23 18:01:01.020 HD Server | Thread:6476 (4) | New receive buffer size: 262144 | 2021-06-23 18:01:01.020 HD Server | Thread:6476 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-23 18:01:01.020 HD Server | Setting DTC encoding to Binary VLS | Thread:6476 | 2021-06-23 18:01:01.020 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6476 | 2021-06-23 18:01:01.020 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6476 | 2021-06-23 18:01:01.020 HD Server | HD Request #95 | Socket: 4 | Symbol: HGN21-COMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 95 | Username: SPRDTRDR. | Thread:6476 | 2021-06-23 18:01:01.020 Added historical Daily data request for HGN21-COMEX to the queue. | 2021-06-23 18:01:01.030 Triggering next historical data download in queue. | 2021-06-23 18:01:01.030 HD Request # 26 | Downloading Historical Daily chart data for HGN21-COMEX. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-23 18:01:01.040 HD Request # 26 | Requesting historical Daily data for HGN21 starting at 2021-06-20. SC External HD service. | 2021-06-23 18:01:01.520 HD Request # 26 | Receiving historical Daily data for HGN21-COMEX starting at 2021-06-21 | 2021-06-23 18:01:01.660 HD Request # 26 | Writing historical Daily data to the file HGN21-COMEX.dly | 2021-06-23 18:01:01.660 HD Request # 26 | Bytes received: 163 | 2021-06-23 18:01:01.660 HD Request # 26 | Received 3 records from 2021-06-21 00:00:00 to 2021-06-23 00:00:00 (3.0 days) and wrote 3 records for HGN21-COMEX | 2021-06-23 18:01:01.660 HD Request # 26 | Completion time: 0s | 2021-06-23 18:01:01.670 HD Request # 26 | Daily data download complete for HGN21-COMEX. Unique request ID: 26 | 2021-06-23 18:01:01.670 Removing historical data download ID 26. | 2021-06-23 18:01:01.670 Triggering next historical data download in queue. | 2021-06-23 18:01:01.670 No download requests in the queue to start downloads for. | 2021-06-23 18:01:01.670 HD Server | HD Request | Socket: 4 | Symbol: HGN21-COMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 95 | Username: SPRDTRDR. | Thread:6476 | 2021-06-23 18:01:02.050 HD Server | Thread:6476 (4) | Socket gracefully closed by remote side. | 2021-06-23 18:01:02.060 HD Server | Thread:6476 (4) | CloseSocket call. | 2021-06-23 18:01:02.060 HD Server | Thread:6476 (0) | CloseSocket call. | 2021-06-23 18:01:02.060 HD Server | Thread:6476 (0) | CloseSocket call. | 2021-06-23 18:01:02.060 HD Server | Thread:6476 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 18:01:02.060 HD Server | Thread:6476 (4) | Closed. | 2021-06-23 18:01:02.060 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6476 | 2021-06-23 18:01:02.240 HD Server Manager | Current server count=0 | 2021-06-23 18:01:02.240 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGU21.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-23 18:02:34.361 Opened cached Intraday file: C:\SierraChart\Data\NGV21-NGF22.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-23 18:09:59.361 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 18:13:56.132 HD Server Manager | Started new historical data server. Count=1 | 2021-06-23 18:13:56.132 HD Server | Thread:6016 (4) | Creating socket. | 2021-06-23 18:13:56.132 HD Server | Thread:6016 (4) | New receive buffer size: 262144 | 2021-06-23 18:13:56.132 HD Server | Thread:6016 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-23 18:13:56.132 HD Server | Setting DTC encoding to Binary VLS | Thread:6016 | 2021-06-23 18:13:56.132 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6016 | 2021-06-23 18:13:56.132 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6016 | 2021-06-23 18:13:56.132 HD Server | HD Request #96 | Socket: 4 | Symbol: RBQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 96 | Username: SPRDTRDR. | Thread:6016 | 2021-06-23 18:13:56.132 Added historical Daily data request for RBQ21-NYMEX to the queue. | 2021-06-23 18:13:56.132 Triggering next historical data download in queue. | 2021-06-23 18:13:56.132 HD Request # 27 | Downloading Historical Daily chart data for RBQ21-NYMEX. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-23 18:13:56.142 HD Request # 27 | Requesting historical Daily data for RBQ21 starting at 2021-06-20. SC External HD service. | 2021-06-23 18:13:56.632 HD Request # 27 | Receiving historical Daily data for RBQ21-NYMEX starting at 2021-06-21 | 2021-06-23 18:13:56.772 HD Request # 27 | Writing historical Daily data to the file RBQ21-NYMEX.dly | 2021-06-23 18:13:56.772 HD Request # 27 | Bytes received: 169 | 2021-06-23 18:13:56.782 HD Request # 27 | Received 3 records from 2021-06-21 00:00:00 to 2021-06-23 00:00:00 (3.0 days) and wrote 3 records for RBQ21-NYMEX | 2021-06-23 18:13:56.782 HD Request # 27 | Completion time: 0s | 2021-06-23 18:13:56.792 HD Request # 27 | Daily data download complete for RBQ21-NYMEX. Unique request ID: 27 | 2021-06-23 18:13:56.792 Removing historical data download ID 27. | 2021-06-23 18:13:56.792 Triggering next historical data download in queue. | 2021-06-23 18:13:56.792 No download requests in the queue to start downloads for. | 2021-06-23 18:13:56.792 HD Server | HD Request | Socket: 4 | Symbol: RBQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 96 | Username: SPRDTRDR. | Thread:6016 | 2021-06-23 18:13:57.142 HD Server | Thread:6016 (4) | Socket gracefully closed by remote side. | 2021-06-23 18:13:57.152 HD Server | Thread:6016 (4) | CloseSocket call. | 2021-06-23 18:13:57.152 HD Server | Thread:6016 (0) | CloseSocket call. | 2021-06-23 18:13:57.152 HD Server | Thread:6016 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 18:13:57.152 HD Server | Thread:6016 (4) | Closed. | 2021-06-23 18:13:57.152 HD Server | Thread:6016 (0) | CloseSocket call. | 2021-06-23 18:13:57.152 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6016 | 2021-06-23 18:13:57.172 HD Server Manager | Current server count=0 | 2021-06-23 18:13:57.172 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 18:38:57.834 HD Server Manager | Started new historical data server. Count=1 | 2021-06-23 18:38:57.834 HD Server | Thread:7076 (4) | Creating socket. | 2021-06-23 18:38:57.844 HD Server | Thread:7076 (4) | New receive buffer size: 262144 | 2021-06-23 18:38:57.844 HD Server | Thread:7076 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-23 18:38:57.844 HD Server | Setting DTC encoding to Binary VLS | Thread:7076 | 2021-06-23 18:38:57.844 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:7076 | 2021-06-23 18:38:57.844 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:7076 | 2021-06-23 18:38:57.844 HD Server | HD Request #97 | Socket: 4 | Symbol: ESZ20 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2020-11-12 00:00:00 | ClientReqID: 97 | Username: SPRDTRDR. | Thread:7076 | 2021-06-23 18:38:57.844 HD Server | HD Request | Socket: 4 | Symbol: ESZ20 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 97 | Username: SPRDTRDR. | Thread:7076 | 2021-06-23 18:38:57.864 HD Server | Thread:7076 (4) | Socket gracefully closed by remote side. | 2021-06-23 18:38:57.864 HD Server | Thread:7076 (4) | CloseSocket call. | 2021-06-23 18:38:57.864 HD Server | Thread:7076 (0) | CloseSocket call. | 2021-06-23 18:38:57.864 HD Server | Thread:7076 (0) | CloseSocket call. | 2021-06-23 18:38:57.864 HD Server | Thread:7076 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 18:38:57.864 HD Server | Thread:7076 (4) | Closed. | 2021-06-23 18:38:57.864 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:7076 | 2021-06-23 18:38:57.894 HD Server Manager | Current server count=0 | 2021-06-23 18:38:57.894 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 18:47:05.028 HD Server Manager | Started new historical data server. Count=1 | 2021-06-23 18:47:05.028 HD Server | Thread:5636 (4) | Creating socket. | 2021-06-23 18:47:05.028 HD Server | Thread:5636 (4) | New receive buffer size: 262144 | 2021-06-23 18:47:05.028 HD Server | Thread:5636 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-23 18:47:05.028 HD Server | Setting DTC encoding to Binary VLS | Thread:5636 | 2021-06-23 18:47:05.028 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:5636 | 2021-06-23 18:47:05.028 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:5636 | 2021-06-23 18:47:05.028 HD Server | HD Request #98 | Socket: 4 | Symbol: NGN21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 98 | Username: SPRDTRDR. | Thread:5636 | 2021-06-23 18:47:05.044 HD Server | HD Request | Socket: 4 | Symbol: NGN21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 98 | Username: SPRDTRDR. | Thread:5636 | 2021-06-23 18:47:05.044 HD Server | Thread:5636 (4) | Socket gracefully closed by remote side. | 2021-06-23 18:47:05.075 HD Server | Thread:5636 (4) | CloseSocket call. | 2021-06-23 18:47:05.075 HD Server | Thread:5636 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 18:47:05.075 HD Server | Thread:5636 (4) | Closed. | 2021-06-23 18:47:05.075 HD Server | Thread:5636 (0) | CloseSocket call. | 2021-06-23 18:47:05.075 HD Server | Thread:5636 (0) | CloseSocket call. | 2021-06-23 18:47:05.075 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:5636 | 2021-06-23 18:47:05.325 HD Server Manager | Current server count=0 | 2021-06-23 18:47:05.325 Requesting current DateTime from Sierra Chart server. | 2021-06-23 18:49:30.686 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-23 22:49:31.068. Round-trip delay: 00:00:00.195 | 2021-06-23 18:49:31.076 Computer time to server time difference: 00:00:00.008 | 2021-06-23 18:49:31.076 Successfully set the system Date-time to: 2021-06-23 22:49:31.068 UTC. | 2021-06-23 18:49:31.068 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGV21.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-23 19:02:30.835 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX is currently unavailable. | 2021-06-23 19:03:00.381 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX is currently unavailable. | 2021-06-23 19:03:00.381 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2021-06-23 19:03:12.783 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX has been restored. | 2021-06-23 19:03:12.783 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2021-06-23 19:03:13.220 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX has been restored. | 2021-06-23 19:03:13.220 Requesting current DateTime from Sierra Chart server. | 2021-06-23 19:49:30.642 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-23 23:49:31.027. Round-trip delay: 00:00:00.195 | 2021-06-23 19:49:31.032 Computer time to server time difference: 00:00:00.005 | 2021-06-23 19:49:31.032 Successfully set the system Date-time to: 2021-06-23 23:49:31.027 UTC. | 2021-06-23 19:49:31.027 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGN21-NYMEX.2021-06-24.depth | 2021-06-23 20:00:00.227 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESU21-CME.2021-06-24.depth | 2021-06-23 20:00:00.237 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\NGN21-NYMEX.2021-06-24.depth. This may take a while. | 2021-06-23 20:00:00.247 File compression enabled. C:\SierraChart\Data\MarketDepthData\NGN21-NYMEX.2021-06-24.depth. CompressionState=0 | 2021-06-23 20:00:00.247 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGQ21-NYMEX.2021-06-24.depth | 2021-06-23 20:00:00.317 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGU21-NYMEX.2021-06-24.depth | 2021-06-23 20:00:00.327 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGV21-NYMEX.2021-06-24.depth | 2021-06-23 20:00:00.327 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 20:00:00.477 HD Server Manager | Started new historical data server. Count=1 | 2021-06-23 20:00:00.477 HD Server | Thread:4432 (4) | Creating socket. | 2021-06-23 20:00:00.487 HD Server | Thread:4432 (4) | New receive buffer size: 262144 | 2021-06-23 20:00:00.487 HD Server | Thread:4432 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-23 20:00:00.487 HD Server | Setting DTC encoding to Binary VLS | Thread:4432 | 2021-06-23 20:00:00.487 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4432 | 2021-06-23 20:00:00.487 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4432 | 2021-06-23 20:00:00.487 HD Server | HD Request #99 | Socket: 4 | Symbol: ZLN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-18 00:00:00 | ClientReqID: 99 | Username: SPRDTRDR. | Thread:4432 | 2021-06-23 20:00:00.487 HD Server | HD Request | Socket: 4 | Symbol: ZLN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 99 | Username: SPRDTRDR. | Thread:4432 | 2021-06-23 20:00:00.497 HD Server | Thread:4432 (4) | Socket gracefully closed by remote side. | 2021-06-23 20:00:00.507 HD Server | Thread:4432 (4) | CloseSocket call. | 2021-06-23 20:00:00.507 HD Server | Thread:4432 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 20:00:00.507 HD Server | Thread:4432 (4) | Closed. | 2021-06-23 20:00:00.507 HD Server | Thread:4432 (0) | CloseSocket call. | 2021-06-23 20:00:00.507 HD Server | Thread:4432 (0) | CloseSocket call. | 2021-06-23 20:00:00.507 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 20:00:00.527 HD Server Manager | Started new historical data server. Count=2 | 2021-06-23 20:00:00.527 HD Server | Thread:6968 (4) | Creating socket. | 2021-06-23 20:00:00.527 HD Server | Thread:6968 (4) | New receive buffer size: 262144 | 2021-06-23 20:00:00.527 HD Server | Setting DTC encoding to Binary VLS | Thread:6968 | 2021-06-23 20:00:00.527 HD Server | Thread:6968 (4) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-23 20:00:00.527 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6968 | 2021-06-23 20:00:00.527 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6968 | 2021-06-23 20:00:00.527 HD Server | HD Request #100 | Socket: 4 | Symbol: ZSN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 100 | Username: SPRDTRDR. | Thread:6968 | 2021-06-23 20:00:00.537 Added historical Daily data request for ZSN21-CBOT to the queue. | 2021-06-23 20:00:00.537 Triggering next historical data download in queue. | 2021-06-23 20:00:00.537 HD Request # 28 | Downloading Historical Daily chart data for ZSN21-CBOT. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-23 20:00:00.547 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4432 | 2021-06-23 20:00:00.647 HD Server Manager | Current server count=1 | 2021-06-23 20:00:00.647 HD Request # 28 | Requesting historical Daily data for ZSN21 starting at 2021-06-20. SC External HD service. | 2021-06-23 20:00:01.027 HD Request # 28 | Receiving historical Daily data for ZSN21-CBOT starting at 2021-06-21 | 2021-06-23 20:00:01.367 HD Request # 28 | Writing historical Daily data to the file ZSN21-CBOT.dly | 2021-06-23 20:00:01.367 HD Request # 28 | Bytes received: 162 | 2021-06-23 20:00:01.367 HD Request # 28 | Received 3 records from 2021-06-21 00:00:00 to 2021-06-23 00:00:00 (3.0 days) and wrote 3 records for ZSN21-CBOT | 2021-06-23 20:00:01.367 HD Request # 28 | Completion time: 1s | 2021-06-23 20:00:01.377 HD Request # 28 | Daily data download complete for ZSN21-CBOT. Unique request ID: 28 | 2021-06-23 20:00:01.377 Removing historical data download ID 28. | 2021-06-23 20:00:01.377 Triggering next historical data download in queue. | 2021-06-23 20:00:01.377 No download requests in the queue to start downloads for. | 2021-06-23 20:00:01.377 HD Server | HD Request | Socket: 4 | Symbol: ZSN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 100 | Username: SPRDTRDR. | Thread:6968 | 2021-06-23 20:00:01.547 HD Server | Thread:6968 (4) | Socket gracefully closed by remote side. | 2021-06-23 20:00:01.557 HD Server | Thread:6968 (4) | CloseSocket call. | 2021-06-23 20:00:01.557 HD Server | Thread:6968 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 20:00:01.557 HD Server | Thread:6968 (4) | Closed. | 2021-06-23 20:00:01.557 HD Server | Thread:6968 (0) | CloseSocket call. | 2021-06-23 20:00:01.557 HD Server | Thread:6968 (0) | CloseSocket call. | 2021-06-23 20:00:01.557 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 20:00:01.587 HD Server Manager | Started new historical data server. Count=2 | 2021-06-23 20:00:01.587 HD Server | Thread:3620 (4) | Creating socket. | 2021-06-23 20:00:01.587 HD Server | Thread:3620 (4) | New receive buffer size: 262144 | 2021-06-23 20:00:01.587 HD Server | Thread:3620 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-23 20:00:01.587 HD Server | Setting DTC encoding to Binary VLS | Thread:3620 | 2021-06-23 20:00:01.587 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:3620 | 2021-06-23 20:00:01.587 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:3620 | 2021-06-23 20:00:01.587 HD Server | HD Request #101 | Socket: 4 | Symbol: ZWN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-15 00:00:00 | ClientReqID: 101 | Username: SPRDTRDR. | Thread:3620 | 2021-06-23 20:00:01.587 HD Server | HD Request | Socket: 4 | Symbol: ZWN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 101 | Username: SPRDTRDR. | Thread:3620 | 2021-06-23 20:00:01.607 HD Server | Thread:3620 (4) | Socket gracefully closed by remote side. | 2021-06-23 20:00:01.607 HD Server | Thread:3620 (4) | CloseSocket call. | 2021-06-23 20:00:01.607 HD Server | Thread:3620 (0) | CloseSocket call. | 2021-06-23 20:00:01.607 HD Server | Thread:3620 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 20:00:01.607 HD Server | Thread:3620 (4) | Closed. | 2021-06-23 20:00:01.607 HD Server | Thread:3620 (0) | CloseSocket call. | 2021-06-23 20:00:01.607 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-23 20:00:01.637 HD Server Manager | Started new historical data server. Count=3 | 2021-06-23 20:00:01.637 HD Server | Thread:4808 (4) | Creating socket. | 2021-06-23 20:00:01.637 HD Server | Thread:4808 (4) | New receive buffer size: 262144 | 2021-06-23 20:00:01.637 HD Server | Thread:4808 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-23 20:00:01.637 HD Server | Setting DTC encoding to Binary VLS | Thread:4808 | 2021-06-23 20:00:01.637 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4808 | 2021-06-23 20:00:01.637 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4808 | 2021-06-23 20:00:01.637 HD Server | HD Request #102 | Socket: 4 | Symbol: ZCN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 102 | Username: SPRDTRDR. | Thread:4808 | 2021-06-23 20:00:01.637 Added historical Daily data request for ZCN21-CBOT to the queue. | 2021-06-23 20:00:01.637 Triggering next historical data download in queue. | 2021-06-23 20:00:01.637 HD Request # 29 | Downloading Historical Daily chart data for ZCN21-CBOT. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-23 20:00:01.647 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:3620 | 2021-06-23 20:00:01.687 HD Server Manager | Current server count=2 | 2021-06-23 20:00:01.687 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6968 | 2021-06-23 20:00:01.687 HD Server Manager | Current server count=1 | 2021-06-23 20:00:01.687 HD Request # 29 | Requesting historical Daily data for ZCN21 starting at 2021-06-20. SC External HD service. | 2021-06-23 20:00:02.127 HD Request # 29 | Receiving historical Daily data for ZCN21-CBOT starting at 2021-06-21 | 2021-06-23 20:00:02.257 HD Request # 29 | Writing historical Daily data to the file ZCN21-CBOT.dly | 2021-06-23 20:00:02.257 HD Request # 29 | Bytes received: 165 | 2021-06-23 20:00:02.267 HD Request # 29 | Received 3 records from 2021-06-21 00:00:00 to 2021-06-23 00:00:00 (3.0 days) and wrote 3 records for ZCN21-CBOT | 2021-06-23 20:00:02.267 HD Request # 29 | Completion time: 1s | 2021-06-23 20:00:02.277 HD Request # 29 | Daily data download complete for ZCN21-CBOT. Unique request ID: 29 | 2021-06-23 20:00:02.277 Removing historical data download ID 29. | 2021-06-23 20:00:02.277 Triggering next historical data download in queue. | 2021-06-23 20:00:02.277 No download requests in the queue to start downloads for. | 2021-06-23 20:00:02.277 HD Server | HD Request | Socket: 4 | Symbol: ZCN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 102 | Username: SPRDTRDR. | Thread:4808 | 2021-06-23 20:00:02.647 HD Server | Thread:4808 (4) | Socket gracefully closed by remote side. | 2021-06-23 20:00:02.657 HD Server | Thread:4808 (4) | CloseSocket call. | 2021-06-23 20:00:02.657 HD Server | Thread:4808 (0) | CloseSocket call. | 2021-06-23 20:00:02.657 HD Server | Thread:4808 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-23 20:00:02.657 HD Server | Thread:4808 (4) | Closed. | 2021-06-23 20:00:02.657 HD Server | Thread:4808 (0) | CloseSocket call. | 2021-06-23 20:00:02.657 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4808 | 2021-06-23 20:00:02.737 HD Server Manager | Current server count=0 | 2021-06-23 20:00:02.737 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX is currently unavailable. | 2021-06-23 20:11:05.508 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX is currently unavailable. | 2021-06-23 20:11:05.508 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2021-06-23 20:11:34.548 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX has been restored. | 2021-06-23 20:11:34.548 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2021-06-23 20:11:35.298 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX has been restored. | 2021-06-23 20:11:35.298 SC DTC Data with Market Depth | Real-time data for symbol BTCUSDT_PERP_BINANCE is currently unavailable. | 2021-06-23 20:25:36.985 SC DTC Data with Market Depth | Received security definition for symbol BTCUSDT_PERP_BINANCE | 2021-06-23 20:26:05.715 SC DTC Data with Market Depth | Real-time data for symbol BTCUSDT_PERP_BINANCE has been restored. | 2021-06-23 20:26:05.715 SC DTC Data with Market Depth | Real-time data for symbol BTCUSDT_PERP_BINANCE is currently unavailable. | 2021-06-23 20:41:00.967 SC DTC Data with Market Depth | Received security definition for symbol BTCUSDT_PERP_BINANCE | 2021-06-23 20:41:11.517 SC DTC Data with Market Depth | Real-time data for symbol BTCUSDT_PERP_BINANCE has been restored. | 2021-06-23 20:41:11.517 Requesting current DateTime from Sierra Chart server. | 2021-06-23 20:49:30.618 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 00:49:31.007. Round-trip delay: 00:00:00.200 | 2021-06-23 20:49:31.018 Computer time to server time difference: 00:00:00.011 | 2021-06-23 20:49:31.018 Successfully set the system Date-time to: 2021-06-24 00:49:31.007 UTC. | 2021-06-23 20:49:31.007 Requesting current DateTime from Sierra Chart server. | 2021-06-23 21:49:30.577 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 01:49:30.979. Round-trip delay: 00:00:00.205 | 2021-06-23 21:49:30.987 Computer time to server time difference: 00:00:00.008 | 2021-06-23 21:49:30.987 Successfully set the system Date-time to: 2021-06-24 01:49:30.979 UTC. | 2021-06-23 21:49:30.979 Requesting current DateTime from Sierra Chart server. | 2021-06-23 22:49:30.564 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 02:49:30.944. Round-trip delay: 00:00:00.195 | 2021-06-23 22:49:30.954 Computer time to server time difference: 00:00:00.010 | 2021-06-23 22:49:30.954 Successfully set the system Date-time to: 2021-06-24 02:49:30.944 UTC. | 2021-06-23 22:49:30.944 Requesting current DateTime from Sierra Chart server. | 2021-06-23 23:49:30.522 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 03:49:30.906. Round-trip delay: 00:00:00.195 | 2021-06-23 23:49:30.912 Computer time to server time difference: 00:00:00.006 | 2021-06-23 23:49:30.912 Successfully set the system Date-time to: 2021-06-24 03:49:30.906 UTC. | 2021-06-23 23:49:30.906 Requesting current DateTime from Sierra Chart server. | 2021-06-24 00:49:30.489 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 04:49:30.869. Round-trip delay: 00:00:00.195 | 2021-06-24 00:49:30.879 Computer time to server time difference: 00:00:00.010 | 2021-06-24 00:49:30.879 Successfully set the system Date-time to: 2021-06-24 04:49:30.869 UTC. | 2021-06-24 00:49:30.869 Requesting current DateTime from Sierra Chart server. | 2021-06-24 01:49:30.451 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 05:49:30.833. Round-trip delay: 00:00:00.195 | 2021-06-24 01:49:30.841 Computer time to server time difference: 00:00:00.008 | 2021-06-24 01:49:30.841 Successfully set the system Date-time to: 2021-06-24 05:49:30.833 UTC. | 2021-06-24 01:49:30.833 Requesting current DateTime from Sierra Chart server. | 2021-06-24 02:49:30.421 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 06:49:30.802. Round-trip delay: 00:00:00.195 | 2021-06-24 02:49:30.811 Computer time to server time difference: 00:00:00.009 | 2021-06-24 02:49:30.811 Successfully set the system Date-time to: 2021-06-24 06:49:30.802 UTC. | 2021-06-24 02:49:30.802 Requesting current DateTime from Sierra Chart server. | 2021-06-24 03:49:30.385 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 07:49:30.768. Round-trip delay: 00:00:00.195 | 2021-06-24 03:49:30.775 Computer time to server time difference: 00:00:00.007 | 2021-06-24 03:49:30.775 Successfully set the system Date-time to: 2021-06-24 07:49:30.768 UTC. | 2021-06-24 03:49:30.768 Requesting current DateTime from Sierra Chart server. | 2021-06-24 04:49:30.350 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 08:49:30.735. Round-trip delay: 00:00:00.195 | 2021-06-24 04:49:30.740 Computer time to server time difference: 00:00:00.005 | 2021-06-24 04:49:30.740 Successfully set the system Date-time to: 2021-06-24 08:49:30.735 UTC. | 2021-06-24 04:49:30.735 Requesting current DateTime from Sierra Chart server. | 2021-06-24 05:49:30.314 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 09:49:30.698. Round-trip delay: 00:00:00.195 | 2021-06-24 05:49:30.704 Computer time to server time difference: 00:00:00.006 | 2021-06-24 05:49:30.704 Successfully set the system Date-time to: 2021-06-24 09:49:30.698 UTC. | 2021-06-24 05:49:30.698 Requesting current DateTime from Sierra Chart server. | 2021-06-24 06:49:30.283 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 10:49:30.667. Round-trip delay: 00:00:00.195 | 2021-06-24 06:49:30.673 Computer time to server time difference: 00:00:00.006 | 2021-06-24 06:49:30.673 Successfully set the system Date-time to: 2021-06-24 10:49:30.667 UTC. | 2021-06-24 06:49:30.667 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGH22.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-24 07:22:15.487 Requesting current DateTime from Sierra Chart server. | 2021-06-24 07:49:30.253 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 11:49:30.636. Round-trip delay: 00:00:00.195 | 2021-06-24 07:49:30.643 Computer time to server time difference: 00:00:00.007 | 2021-06-24 07:49:30.643 Successfully set the system Date-time to: 2021-06-24 11:49:30.636 UTC. | 2021-06-24 07:49:30.636 Requesting current DateTime from Sierra Chart server. | 2021-06-24 08:49:30.213 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 12:49:30.601. Round-trip delay: 00:00:00.200 | 2021-06-24 08:49:30.613 Computer time to server time difference: 00:00:00.012 | 2021-06-24 08:49:30.613 Successfully set the system Date-time to: 2021-06-24 12:49:30.601 UTC. | 2021-06-24 08:49:30.601 ESU21-CME[M] Point & Figure 1-12 #6 | Reloading chart. | 2021-06-24 08:49:36.981 + Loading additional symbol data. | 2021-06-24 08:49:38.021 ESU21-CME[M] Point & Figure 1-12 #6 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 08:49:38.311 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:02.761 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:02.761 NGU21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:02.801 NGU21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:02.801 Added historical Intraday data request for NGU21-NYMEX to the queue. | 2021-06-24 09:00:02.911 Intraday data recording state for symbol NGU21-NYMEX is set to download 'Pending'. | 2021-06-24 09:00:02.911 Triggering next historical data download in queue. | 2021-06-24 09:00:02.911 HD Request # 30 | Downloading Intraday chart data for NGU21-NYMEX to the file NGU21-NYMEX.scid. Service: nymex | 2021-06-24 09:00:02.911 HD Request # 30 | Download start date-time: 2021-06-23 09:07:20.000000. File last date-time: 2021-06-23 09:07:20.724000 | 2021-06-24 09:00:02.911 HD Request # 30 | Using server: ds21.sierracharts.com port 10149 | 2021-06-24 09:00:02.911 Socket (4) | Creating socket. | 2021-06-24 09:00:02.911 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:00:02.911 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-24 09:00:02.911 HD Request # 30 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:02.971 HD Request # 30 | Sending historical data logon request message. | 2021-06-24 09:00:02.971 NGV21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:03.221 NGV21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:03.221 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:03.271 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:03.271 Using -BID_ASK_TRADE_SYNC recording mode for LNEN21 C3350.FUT_OPT.NYMEX | 2021-06-24 09:00:03.381 Mapping LNEN21 C3350.FUT_OPT.NYMEX to LNEN21 C3350.FUT_OPT.NYMEX. Service code: nymex | 2021-06-24 09:00:03.381 SC Data - All Services | Starting real-time market data updates for: LNEN21 C3350.FUT_OPT.NYMEX (LNEN21 C3350.FUT_OPT.NYMEX). ID: 45 Service code: nymex | 2021-06-24 09:00:03.381 SC Data - All Services | Requesting security definition data for: LNEN21 C3350.FUT_OPT.NYMEX (LNEN21 C3350.FUT_OPT.NYMEX). ID: 45 | 2021-06-24 09:00:03.381 Added historical Intraday data request for LNEN21 C3350.FUT_OPT.NYMEX to the queue. | 2021-06-24 09:00:03.381 Intraday data recording state for symbol LNEN21 C3350.FUT_OPT.NYMEX is set to download 'Pending'. | 2021-06-24 09:00:03.381 Triggering next historical data download in queue. | 2021-06-24 09:00:03.381 HD Request # 30 | Requesting Intraday data. Start date-time: 2021-06-23 09:07:20. Record interval: 0. Symbol: NGU21 | 2021-06-24 09:00:03.461 HD Request # 30 | Decompressing data. | 2021-06-24 09:00:03.481 SC Data - All Services | Received security definition for symbol LNEN21 C3350.FUT_OPT.NYMEX | 2021-06-24 09:00:03.481 HD Request # 30 | Receiving Intraday data for NGU21-NYMEX starting at 2021-06-23 09:07:20.724000 | 2021-06-24 09:00:03.571 Socket (4) | CloseSocket call. | 2021-06-24 09:00:03.571 Historical data download thread signaled to stop. | 2021-06-24 09:00:03.571 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:03.571 HD Request # 30 | Timestamp of first Intraday data file record written: 2021-06-23 09:07:22.645000 | 2021-06-24 09:00:03.571 HD Request # 30 | Received 8818 records from 2021-06-23 09:07:20.724000 to 2021-06-24 09:00:02.326000 (23.9 hours) and wrote 8817 records for NGU21-NYMEX | 2021-06-24 09:00:03.571 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2021-06-24 13:00:02.326000 | 2021-06-24 09:00:03.581 HD Request # 30 | Completion time: 1s | 2021-06-24 09:00:03.581 HD Request # 30 | Intraday data download complete for NGU21-NYMEX. Unique request ID: 30 | 2021-06-24 09:00:03.581 Removing historical data download ID 30. | 2021-06-24 09:00:03.581 Real-time Intraday chart data file updates started for NGU21-NYMEX | 2021-06-24 09:00:03.581 Intraday chart data file opened for NGU21-NYMEX | 2021-06-24 09:00:03.581 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:03.581 Triggering next historical data download in queue. | 2021-06-24 09:00:03.581 Delaying start of download for LNEN21 C3350.FUT_OPT.NYMEX | 2021-06-24 09:00:03.581 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:00:03.601 Socket (4) | Closed. | 2021-06-24 09:00:03.601 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:03.601 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:03.601 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:03.941 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:03.941 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:04.161 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:04.161 NGN21-NGU21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:04.431 NGN21-NGU21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:04.431 NGN21-NGU21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:04.641 NGN21-NGU21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:04.641 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:05.061 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:05.061 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:05.291 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:05.291 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:05.531 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:05.531 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:05.751 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:05.751 NGTN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:06.021 NGTN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:06.021 Mapping NGTN21-NYMEX to NGTN21. Service code: nymex | 2021-06-24 09:00:06.121 SC Data - All Services | Starting real-time market data updates for: NGTN21-NYMEX (NGTN21). ID: 46 Service code: nymex | 2021-06-24 09:00:06.121 SC Data - All Services | Requesting security definition data for: NGTN21-NYMEX (NGTN21). ID: 46 | 2021-06-24 09:00:06.121 Added historical Intraday data request for NGTN21-NYMEX to the queue. | 2021-06-24 09:00:06.121 Intraday data recording state for symbol NGTN21-NYMEX is set to download 'Pending'. | 2021-06-24 09:00:06.121 Triggering next historical data download in queue. | 2021-06-24 09:00:06.121 SC Data - All Services | Received security definition for symbol NGTN21-NYMEX | 2021-06-24 09:00:06.221 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:06.551 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:06.551 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:06.761 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:06.761 SIN21-COMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:07.031 SIN21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:07.031 Added historical Intraday data request for SIN21-COMEX to the queue. | 2021-06-24 09:00:07.141 Intraday data recording state for symbol SIN21-COMEX is set to download 'Pending'. | 2021-06-24 09:00:07.141 Triggering next historical data download in queue. | 2021-06-24 09:00:07.141 ZSN21-CBOT[M] #9 | Reloading chart. | 2021-06-24 09:00:07.401 ZSN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:07.401 Added historical Intraday data request for ZSN21-CBOT to the queue. | 2021-06-24 09:00:07.511 Intraday data recording state for symbol ZSN21-CBOT is set to download 'Pending'. | 2021-06-24 09:00:07.511 Triggering next historical data download in queue. | 2021-06-24 09:00:07.511 ZCN21-CBOT[M] #9 | Reloading chart. | 2021-06-24 09:00:07.971 ZCN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:07.971 Requesting market depth updates for: ZCN21-CBOT if supported. | 2021-06-24 09:00:07.971 SC Data - All Services (Market Orders Data) | Starting market orders updates for: ZCN21. MinimumMarketByOrderQuantity: 0. Service code: cbot | 2021-06-24 09:00:07.971 Added historical Intraday data request for ZCN21-CBOT to the queue. | 2021-06-24 09:00:08.071 Intraday data recording state for symbol ZCN21-CBOT is set to download 'Pending'. | 2021-06-24 09:00:08.071 Triggering next historical data download in queue. | 2021-06-24 09:00:08.071 SC Data - All Services | Clearing market depth for ZCN21-CBOT | 2021-06-24 09:00:08.091 HD Request # 31 | Downloading Intraday chart data for LNEN21 C3350.FUT_OPT.NYMEX to the file LNEN21 C3350.FUT_OPT.NYMEX.scid. Service: nymex | 2021-06-24 09:00:08.151 HD Request # 31 | Download start date-time: 2021-06-23 10:18:56.000000. File last date-time: 2021-06-23 10:18:56.057000 | 2021-06-24 09:00:08.151 HD Request # 31 | Using server: ds22.sierracharts.com port 10150 | 2021-06-24 09:00:08.151 Socket (4) | Creating socket. | 2021-06-24 09:00:08.171 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:00:08.171 Socket (4) | Connecting to IP: 208.185.224.129. | 2021-06-24 09:00:08.171 HD Request # 31 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:08.221 HD Request # 31 | Sending historical data logon request message. | 2021-06-24 09:00:08.221 ZWN21-CBOT[M] #9 | Reloading chart. | 2021-06-24 09:00:08.501 ZWN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:08.501 Added historical Intraday data request for ZWN21-CBOT to the queue. | 2021-06-24 09:00:08.601 Intraday data recording state for symbol ZWN21-CBOT is set to download 'Pending'. | 2021-06-24 09:00:08.601 Triggering next historical data download in queue. | 2021-06-24 09:00:08.601 ESU21-CME[M] #9 | Reloading chart. | 2021-06-24 09:00:09.201 ESU21-CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:09.211 HD Request # 31 | Requesting Intraday data. Start date-time: 2021-06-23 10:18:56. Record interval: 0. Symbol: LNEN21 C3350.FUT_OPT.NYMEX | 2021-06-24 09:00:09.331 Opened cached Intraday file: C:\SierraChart\Data\NGU21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 09:00:09.341 HD Request # 31 | Decompressing data. | 2021-06-24 09:00:09.351 HD Request # 31 | Receiving Intraday data for LNEN21 C3350.FUT_OPT.NYMEX starting at 2021-06-23 10:27:28.828000 | 2021-06-24 09:00:09.361 Socket (4) | CloseSocket call. | 2021-06-24 09:00:09.361 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:09.361 Historical data download thread signaled to stop. | 2021-06-24 09:00:09.361 HD Request # 31 | Timestamp of first Intraday data file record written: 2021-06-23 10:27:28.828000 | 2021-06-24 09:00:09.361 HD Request # 31 | Received 14 records from 2021-06-23 10:27:28.828000 to 2021-06-24 08:40:08.686000 (22.2 hours) and wrote 14 records for LNEN21 C3350.FUT_OPT.NYMEX | 2021-06-24 09:00:09.361 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2021-06-24 12:40:08.686000 | 2021-06-24 09:00:09.361 Added 2 Time and Sales records to Intraday data file for LNEN21 C3350.FUT_OPT.NYMEX after download. | 2021-06-24 09:00:09.361 HD Request # 31 | Completion time: 1s | 2021-06-24 09:00:09.371 HD Request # 31 | Intraday data download complete for LNEN21 C3350.FUT_OPT.NYMEX. Unique request ID: 31 | 2021-06-24 09:00:09.371 Removing historical data download ID 31. | 2021-06-24 09:00:09.371 Real-time Intraday chart data file updates started for LNEN21 C3350.FUT_OPT.NYMEX | 2021-06-24 09:00:09.371 Intraday chart data file opened for LNEN21 C3350.FUT_OPT.NYMEX | 2021-06-24 09:00:09.371 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:09.371 Triggering next historical data download in queue. | 2021-06-24 09:00:09.371 Delaying start of download for NGTN21-NYMEX | 2021-06-24 09:00:09.371 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:00:09.381 Socket (4) | Closed. | 2021-06-24 09:00:09.381 CLN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:10.451 CLN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:10.451 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-24 09:00:10.551 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-24 09:00:10.551 Triggering next historical data download in queue. | 2021-06-24 09:00:10.551 CLQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:10.911 CLQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:10.911 Added historical Intraday data request for CLQ21-NYMEX to the queue. | 2021-06-24 09:00:11.021 Intraday data recording state for symbol CLQ21-NYMEX is set to download 'Pending'. | 2021-06-24 09:00:11.021 Triggering next historical data download in queue. | 2021-06-24 09:00:11.021 HD Request # 32 | Downloading Intraday chart data for NGTN21-NYMEX to the file NGTN21-NYMEX.scid. Service: nymex | 2021-06-24 09:00:11.191 HD Request # 32 | Download start date-time: 2021-06-23 09:03:04.000000. File last date-time: 2021-06-23 09:03:04.773000 | 2021-06-24 09:00:11.191 HD Request # 32 | Using server: ds21.sierracharts.com port 10149 | 2021-06-24 09:00:11.191 Socket (4) | Creating socket. | 2021-06-24 09:00:11.191 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:00:11.191 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-24 09:00:11.191 HD Request # 32 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:11.251 HD Request # 32 | Sending historical data logon request message. | 2021-06-24 09:00:11.251 HD Request # 32 | Requesting Intraday data. Start date-time: 2021-06-23 09:03:04. Record interval: 0. Symbol: NGTN21 | 2021-06-24 09:00:11.271 HD Request # 32 | Decompressing data. | 2021-06-24 09:00:11.301 HD Request # 32 | Receiving Intraday data for NGTN21-NYMEX starting at 2021-06-23 09:03:04.773000 | 2021-06-24 09:00:11.301 Socket (4) | CloseSocket call. | 2021-06-24 09:00:11.301 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:11.301 Historical data download thread signaled to stop. | 2021-06-24 09:00:11.301 HD Request # 32 | Timestamp of first Intraday data file record written: 2021-06-23 12:10:05.250000 | 2021-06-24 09:00:11.301 HD Request # 32 | Received 54 records from 2021-06-23 09:03:04.773000 to 2021-06-24 05:38:48.704001 (20.6 hours) and wrote 53 records for NGTN21-NYMEX | 2021-06-24 09:00:11.301 HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2021-06-24 09:38:48.704001 | 2021-06-24 09:00:11.301 HD Request # 32 | Completion time: 0s | 2021-06-24 09:00:11.301 HD Request # 32 | Intraday data download complete for NGTN21-NYMEX. Unique request ID: 32 | 2021-06-24 09:00:11.301 Removing historical data download ID 32. | 2021-06-24 09:00:11.301 Real-time Intraday chart data file updates started for NGTN21-NYMEX | 2021-06-24 09:00:11.301 Intraday chart data file opened for NGTN21-NYMEX | 2021-06-24 09:00:11.301 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:11.301 Triggering next historical data download in queue. | 2021-06-24 09:00:11.301 HD Request # 33 | Downloading Intraday chart data for SIN21-COMEX to the file SIN21-COMEX.scid. Service: comex | 2021-06-24 09:00:11.301 HD Request # 33 | Download start date-time: 2021-06-23 09:07:21.000000. File last date-time: 2021-06-23 09:07:21.404000 | 2021-06-24 09:00:11.301 HD Request # 33 | Using server: ds23.sierracharts.com port 10150 | 2021-06-24 09:00:11.301 Socket (9) | Creating socket. | 2021-06-24 09:00:11.301 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 09:00:11.301 Socket (9) | Connecting to IP: 216.1.90.130. | 2021-06-24 09:00:11.301 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:00:11.331 Socket (4) | Closed. | 2021-06-24 09:00:11.331 HD Request # 33 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:11.371 HD Request # 33 | Sending historical data logon request message. | 2021-06-24 09:00:11.371 CLTN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:11.521 CLTN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:11.521 RBN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:11.601 RBN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:11.601 Mapping RBN21-NYMEX to RBN21. Service code: nymex | 2021-06-24 09:00:11.711 SC Data - All Services | Starting real-time market data updates for: RBN21-NYMEX (RBN21). ID: 47 Service code: nymex | 2021-06-24 09:00:11.711 SC Data - All Services | Requesting security definition data for: RBN21-NYMEX (RBN21). ID: 47 | 2021-06-24 09:00:11.711 Added historical Intraday data request for RBN21-NYMEX to the queue. | 2021-06-24 09:00:11.711 Intraday data recording state for symbol RBN21-NYMEX is set to download 'Pending'. | 2021-06-24 09:00:11.711 Triggering next historical data download in queue. | 2021-06-24 09:00:11.711 SC Data - All Services | Received security definition for symbol RBN21-NYMEX | 2021-06-24 09:00:11.741 HD Request # 33 | Requesting Intraday data. Start date-time: 2021-06-23 09:07:21. Record interval: 0. Symbol: SIN21 | 2021-06-24 09:00:11.861 HD Request # 33 | Decompressing data. | 2021-06-24 09:00:11.881 HD Request # 33 | Receiving Intraday data for SIN21-COMEX starting at 2021-06-23 09:07:21.404000 | 2021-06-24 09:00:11.951 HD Request # 33 | Timestamp of first Intraday data file record written: 2021-06-23 09:07:21.780000 | 2021-06-24 09:00:12.041 Socket (9) | CloseSocket call. | 2021-06-24 09:00:12.041 Historical data download thread signaled to stop. | 2021-06-24 09:00:12.041 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:12.041 HD Request # 33 | Received 39316 records from 2021-06-23 09:07:21.404000 to 2021-06-24 09:00:11.313004 (23.9 hours) and wrote 39315 records for SIN21-COMEX | 2021-06-24 09:00:12.041 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2021-06-24 13:00:11.313004 | 2021-06-24 09:00:12.051 HD Request # 33 | Completion time: 1s | 2021-06-24 09:00:12.051 HD Request # 33 | Intraday data download complete for SIN21-COMEX. Unique request ID: 33 | 2021-06-24 09:00:12.051 Removing historical data download ID 33. | 2021-06-24 09:00:12.051 Real-time Intraday chart data file updates started for SIN21-COMEX | 2021-06-24 09:00:12.051 Intraday chart data file opened for SIN21-COMEX | 2021-06-24 09:00:12.051 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:12.051 Triggering next historical data download in queue. | 2021-06-24 09:00:12.051 HD Request # 34 | Downloading Intraday chart data for ZSN21-CBOT to the file ZSN21-CBOT.scid. Service: cbot | 2021-06-24 09:00:12.051 HD Request # 34 | Download start date-time: 2021-06-23 08:44:51.000000. File last date-time: 2021-06-23 08:44:51.014000 | 2021-06-24 09:00:12.051 HD Request # 34 | Using server: ds21.sierracharts.com port 10149 | 2021-06-24 09:00:12.051 Socket (4) | Creating socket. | 2021-06-24 09:00:12.051 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:00:12.051 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-24 09:00:12.051 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 09:00:12.071 Socket (9) | Closed. | 2021-06-24 09:00:12.071 HD Request # 34 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:12.111 HD Request # 34 | Sending historical data logon request message. | 2021-06-24 09:00:12.111 HD Request # 34 | Requesting Intraday data. Start date-time: 2021-06-23 08:44:51. Record interval: 0. Symbol: ZSN21 | 2021-06-24 09:00:12.131 HD Request # 34 | Decompressing data. | 2021-06-24 09:00:12.161 HGN21-COMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:12.181 HGN21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:12.181 HD Request # 34 | Receiving Intraday data for ZSN21-CBOT starting at 2021-06-23 08:44:51.014000 | 2021-06-24 09:00:12.221 Added historical Intraday data request for HGN21-COMEX to the queue. | 2021-06-24 09:00:12.271 Intraday data recording state for symbol HGN21-COMEX is set to download 'Pending'. | 2021-06-24 09:00:12.271 Triggering next historical data download in queue. | 2021-06-24 09:00:12.271 Socket (4) | CloseSocket call. | 2021-06-24 09:00:12.271 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:12.271 Historical data download thread signaled to stop. | 2021-06-24 09:00:12.271 HD Request # 34 | Timestamp of first Intraday data file record written: 2021-06-23 09:30:00.000000 | 2021-06-24 09:00:12.271 HD Request # 34 | Received 20589 records from 2021-06-23 08:44:51.014000 to 2021-06-24 08:44:59.145001 (24.0 hours) and wrote 20588 records for ZSN21-CBOT | 2021-06-24 09:00:12.271 HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2021-06-24 12:44:59.145001 | 2021-06-24 09:00:12.281 HD Request # 34 | Completion time: 0s | 2021-06-24 09:00:12.281 HD Request # 34 | Intraday data download complete for ZSN21-CBOT. Unique request ID: 34 | 2021-06-24 09:00:12.281 Removing historical data download ID 34. | 2021-06-24 09:00:12.281 Real-time Intraday chart data file updates started for ZSN21-CBOT | 2021-06-24 09:00:12.281 Intraday chart data file opened for ZSN21-CBOT | 2021-06-24 09:00:12.281 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:12.281 Triggering next historical data download in queue. | 2021-06-24 09:00:12.281 HD Request # 35 | Downloading Intraday chart data for ZCN21-CBOT to the file ZCN21-CBOT.scid. Service: cbot | 2021-06-24 09:00:12.281 HD Request # 35 | Download start date-time: 2021-06-23 08:44:58.000000. File last date-time: 2021-06-23 08:44:58.316000 | 2021-06-24 09:00:12.281 HD Request # 35 | Using server: ds23.sierracharts.com port 10150 | 2021-06-24 09:00:12.281 Socket (9) | Creating socket. | 2021-06-24 09:00:12.281 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 09:00:12.281 Socket (9) | Connecting to IP: 216.1.90.130. | 2021-06-24 09:00:12.281 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:00:12.301 Socket (4) | Closed. | 2021-06-24 09:00:12.301 HD Request # 35 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:12.341 HD Request # 35 | Sending historical data logon request message. | 2021-06-24 09:00:12.341 HD Request # 35 | Requesting Intraday data. Start date-time: 2021-06-23 08:44:58. Record interval: 0. Symbol: ZCN21 | 2021-06-24 09:00:12.371 HD Request # 35 | Decompressing data. | 2021-06-24 09:00:12.401 HD Request # 35 | Receiving Intraday data for ZCN21-CBOT starting at 2021-06-23 08:44:58.316000 | 2021-06-24 09:00:12.471 Socket (9) | CloseSocket call. | 2021-06-24 09:00:12.551 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:12.551 Historical data download thread signaled to stop. | 2021-06-24 09:00:12.551 HD Request # 35 | Timestamp of first Intraday data file record written: 2021-06-23 09:30:00.000000 | 2021-06-24 09:00:12.551 HD Request # 35 | Received 25349 records from 2021-06-23 08:44:58.316000 to 2021-06-24 08:44:58.373000 (24.0 hours) and wrote 25348 records for ZCN21-CBOT | 2021-06-24 09:00:12.551 HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2021-06-24 12:44:58.373000 | 2021-06-24 09:00:12.551 HD Request # 35 | Completion time: 0s | 2021-06-24 09:00:12.551 HD Request # 35 | Intraday data download complete for ZCN21-CBOT. Unique request ID: 35 | 2021-06-24 09:00:12.551 Removing historical data download ID 35. | 2021-06-24 09:00:12.551 Real-time Intraday chart data file updates started for ZCN21-CBOT | 2021-06-24 09:00:12.551 Intraday chart data file opened for ZCN21-CBOT | 2021-06-24 09:00:12.551 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:12.551 Triggering next historical data download in queue. | 2021-06-24 09:00:12.551 HD Request # 36 | Downloading Intraday chart data for ZWN21-CBOT to the file ZWN21-CBOT.scid. Service: cbot | 2021-06-24 09:00:12.551 HD Request # 36 | Download start date-time: 2021-06-18 14:19:59.000000. File last date-time: 2021-06-18 14:19:59.961000 | 2021-06-24 09:00:12.551 HD Request # 36 | Using server: ds21.sierracharts.com port 10149 | 2021-06-24 09:00:12.551 Socket (4) | Creating socket. | 2021-06-24 09:00:12.551 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:00:12.551 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-24 09:00:12.551 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 09:00:12.581 Socket (9) | Closed. | 2021-06-24 09:00:12.581 HD Request # 36 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:12.611 HD Request # 36 | Sending historical data logon request message. | 2021-06-24 09:00:12.611 HD Request # 36 | Requesting Intraday data. Start date-time: 2021-06-18 14:19:59. Record interval: 0. Symbol: ZWN21 | 2021-06-24 09:00:12.641 HD Request # 36 | Decompressing data. | 2021-06-24 09:00:12.671 HD Request # 36 | Receiving Intraday data for ZWN21-CBOT starting at 2021-06-18 14:19:59.961000 | 2021-06-24 09:00:12.751 GCQ21-COMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:12.791 GCQ21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:12.791 Socket (4) | CloseSocket call. | 2021-06-24 09:00:12.811 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:12.811 Historical data download thread signaled to stop. | 2021-06-24 09:00:12.811 HD Request # 36 | Timestamp of first Intraday data file record written: 2021-06-20 20:00:00.000000 | 2021-06-24 09:00:12.811 HD Request # 36 | Received 30764 records from 2021-06-18 14:19:59.961000 to 2021-06-24 08:43:28.745000 (5.8 days) and wrote 30763 records for ZWN21-CBOT | 2021-06-24 09:00:12.811 HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2021-06-24 12:43:28.745000 | 2021-06-24 09:00:12.811 HD Request # 36 | Completion time: 0s | 2021-06-24 09:00:12.811 HD Request # 36 | Intraday data download complete for ZWN21-CBOT. Unique request ID: 36 | 2021-06-24 09:00:12.811 Removing historical data download ID 36. | 2021-06-24 09:00:12.811 Real-time Intraday chart data file updates started for ZWN21-CBOT | 2021-06-24 09:00:12.811 Intraday chart data file opened for ZWN21-CBOT | 2021-06-24 09:00:12.811 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:12.811 Triggering next historical data download in queue. | 2021-06-24 09:00:12.811 HD Request # 37 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-24 09:00:12.811 HD Request # 37 | Download start date-time: 2021-06-22 14:29:46.000000. File last date-time: 2021-06-22 14:29:46.813000 | 2021-06-24 09:00:12.811 HD Request # 37 | Using server: ds23.sierracharts.com port 10150 | 2021-06-24 09:00:12.811 Socket (9) | Creating socket. | 2021-06-24 09:00:12.811 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 09:00:12.811 Socket (9) | Connecting to IP: 216.1.90.130. | 2021-06-24 09:00:12.811 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:00:12.831 Socket (4) | Closed. | 2021-06-24 09:00:12.831 HD Request # 37 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:12.881 HD Request # 37 | Sending historical data logon request message. | 2021-06-24 09:00:12.881 HD Request # 37 | Requesting Intraday data. Start date-time: 2021-06-22 14:29:46. Record interval: 0. Symbol: CLN21 | 2021-06-24 09:00:12.901 HD Request # 37 | Decompressing data. | 2021-06-24 09:00:12.931 HD Request # 37 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-22 14:29:46.813000 | 2021-06-24 09:00:12.931 Socket (9) | CloseSocket call. | 2021-06-24 09:00:12.931 Historical data download thread signaled to stop. | 2021-06-24 09:00:12.931 HD Request # 37 | Received 1 record from 2021-06-22 14:29:46.813000 to 2021-06-22 14:29:46.813000 (0.0 seconds) and wrote 0 records for CLN21-NYMEX | 2021-06-24 09:00:12.931 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:12.931 HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2021-06-22 18:29:46.813000 | 2021-06-24 09:00:12.931 HD Request # 37 | Completion time: 0s | 2021-06-24 09:00:12.931 HD Request # 37 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 37 | 2021-06-24 09:00:12.931 Removing historical data download ID 37. | 2021-06-24 09:00:12.931 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-24 09:00:12.931 Intraday chart data file opened for CLN21-NYMEX | 2021-06-24 09:00:12.931 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:12.931 Triggering next historical data download in queue. | 2021-06-24 09:00:12.931 HD Request # 38 | Downloading Intraday chart data for CLQ21-NYMEX to the file CLQ21-NYMEX.scid. Service: nymex | 2021-06-24 09:00:12.931 HD Request # 38 | Download start date-time: 2021-06-23 09:43:11.000000. File last date-time: 2021-06-23 09:43:11.137000 | 2021-06-24 09:00:12.931 HD Request # 38 | Using server: ds21.sierracharts.com port 10149 | 2021-06-24 09:00:12.931 Socket (4) | Creating socket. | 2021-06-24 09:00:12.931 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:00:12.931 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-24 09:00:12.931 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 09:00:12.961 Socket (9) | Closed. | 2021-06-24 09:00:12.961 Unsubscribed from market depth data for ZCN21-CBOT | 2021-06-24 09:00:12.971 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: ZCN21.. Service code: cbot | 2021-06-24 09:00:12.971 Requesting market depth updates for: GCQ21-COMEX if supported. | 2021-06-24 09:00:12.971 SC Data - All Services (Market Orders Data) | Starting market orders updates for: GCQ21. MinimumMarketByOrderQuantity: 0. Service code: comex | 2021-06-24 09:00:12.971 HD Request # 38 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:12.991 HD Request # 38 | Sending historical data logon request message. | 2021-06-24 09:00:12.991 HD Request # 38 | Requesting Intraday data. Start date-time: 2021-06-23 09:43:11. Record interval: 0. Symbol: CLQ21 | 2021-06-24 09:00:13.021 HD Request # 38 | Decompressing data. | 2021-06-24 09:00:13.051 SC Data - All Services | Clearing market depth for GCQ21-COMEX | 2021-06-24 09:00:13.061 HD Request # 38 | Receiving Intraday data for CLQ21-NYMEX starting at 2021-06-23 09:43:11.137000 | 2021-06-24 09:00:13.111 HD Request # 38 | Timestamp of first Intraday data file record written: 2021-06-23 09:43:11.422000 | 2021-06-24 09:00:13.231 BTCM21-CME[M] #9 | Reloading chart. | 2021-06-24 09:00:13.381 BTCM21-CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:13.381 Added historical Intraday data request for BTCM21-CME to the queue. | 2021-06-24 09:00:13.491 Intraday data recording state for symbol BTCM21-CME is set to download 'Pending'. | 2021-06-24 09:00:13.491 Triggering next historical data download in queue. | 2021-06-24 09:00:13.491 BTCUSDT_PERP_BINANCE[M] #9 | Reloading chart. | 2021-06-24 09:00:13.951 BTCUSDT_PERP_BINANCE[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:13.951 Added historical Intraday data request for BTCUSDT_PERP_BINANCE to the queue. | 2021-06-24 09:00:14.051 Intraday data recording state for symbol BTCUSDT_PERP_BINANCE is set to download 'Pending'. | 2021-06-24 09:00:14.051 Triggering next historical data download in queue. | 2021-06-24 09:00:14.051 Socket (4) | CloseSocket call. | 2021-06-24 09:00:14.231 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:14.231 Historical data download thread signaled to stop. | 2021-06-24 09:00:14.231 HD Request # 38 | Received 199949 records from 2021-06-23 09:43:11.137000 to 2021-06-24 09:00:09.783000 (23.3 hours) and wrote 199948 records for CLQ21-NYMEX | 2021-06-24 09:00:14.231 HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2021-06-24 13:00:09.783000 | 2021-06-24 09:00:14.231 Added 16 Time and Sales records to Intraday data file for CLQ21-NYMEX after download. | 2021-06-24 09:00:14.231 HD Request # 38 | Completion time: 2s | 2021-06-24 09:00:14.231 HD Request # 38 | Intraday data download complete for CLQ21-NYMEX. Unique request ID: 38 | 2021-06-24 09:00:14.231 Removing historical data download ID 38. | 2021-06-24 09:00:14.231 Real-time Intraday chart data file updates started for CLQ21-NYMEX | 2021-06-24 09:00:14.231 Intraday chart data file opened for CLQ21-NYMEX | 2021-06-24 09:00:14.231 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:14.231 Triggering next historical data download in queue. | 2021-06-24 09:00:14.231 Delaying start of download for RBN21-NYMEX | 2021-06-24 09:00:14.231 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:00:14.251 Socket (4) | Closed. | 2021-06-24 09:00:14.251 Opened cached Intraday file: C:\SierraChart\Data\SIN21-COMEX.scid. Thread ID: 5644 | 2021-06-24 09:00:14.341 BTCM21-CME[M] #9 | Reloading chart. | 2021-06-24 09:00:15.111 BTCM21-CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.111 GCQ21-COMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:15.131 GCQ21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.131 HGN21-COMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:15.141 HGN21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.141 RBN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:15.181 RBN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.181 CLTN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:15.241 CLTN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.241 Mapping CLTN21-NYMEX to CLTN21. Service code: nymex | 2021-06-24 09:00:15.341 SC Data - All Services | Starting real-time market data updates for: CLTN21-NYMEX (CLTN21). ID: 48 Service code: nymex | 2021-06-24 09:00:15.341 SC Data - All Services | Requesting security definition data for: CLTN21-NYMEX (CLTN21). ID: 48 | 2021-06-24 09:00:15.341 Added historical Intraday data request for CLTN21-NYMEX to the queue. | 2021-06-24 09:00:15.341 Intraday data recording state for symbol CLTN21-NYMEX is set to download 'Pending'. | 2021-06-24 09:00:15.341 Triggering next historical data download in queue. | 2021-06-24 09:00:15.341 SC Data - All Services | Real-time data for symbol CLTN21-NYMEX is currently unavailable. | 2021-06-24 09:00:15.401 SC Data - All Services | Received security definition for symbol CLTN21-NYMEX | 2021-06-24 09:00:15.401 CLQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:15.571 CLQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.571 CLN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:15.591 CLN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.591 ESU21-CME[M] #9 | Reloading chart. | 2021-06-24 09:00:15.611 ESU21-CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.611 ZWN21-CBOT[M] #9 | Reloading chart. | 2021-06-24 09:00:15.641 ZWN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.641 ZCN21-CBOT[M] #9 | Reloading chart. | 2021-06-24 09:00:15.971 ZCN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.971 ZSN21-CBOT[M] #9 | Reloading chart. | 2021-06-24 09:00:15.991 ZSN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:15.991 SIN21-COMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:16.011 SIN21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:16.011 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:16.031 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:16.031 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:16.251 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:16.251 HD Request # 39 | Downloading Intraday chart data for RBN21-NYMEX to the file RBN21-NYMEX.scid. Service: nymex | 2021-06-24 09:00:16.261 HD Request # 39 | Download start date-time: 2021-06-18 16:58:04.000000. File last date-time: 2021-06-18 16:58:04.614000 | 2021-06-24 09:00:16.261 HD Request # 39 | Using server: ds23.sierracharts.com port 10150 | 2021-06-24 09:00:16.261 Socket (4) | Creating socket. | 2021-06-24 09:00:16.261 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:00:16.261 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 09:00:16.261 HD Request # 39 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:16.321 HD Request # 39 | Sending historical data logon request message. | 2021-06-24 09:00:16.321 HD Request # 39 | Requesting Intraday data. Start date-time: 2021-06-18 16:58:04. Record interval: 0. Symbol: RBN21 | 2021-06-24 09:00:16.351 HD Request # 39 | Decompressing data. | 2021-06-24 09:00:16.381 HD Request # 39 | Receiving Intraday data for RBN21-NYMEX starting at 2021-06-18 16:58:04.614000 | 2021-06-24 09:00:16.481 Socket (4) | CloseSocket call. | 2021-06-24 09:00:16.531 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:16.531 Historical data download thread signaled to stop. | 2021-06-24 09:00:16.531 HD Request # 39 | Timestamp of first Intraday data file record written: 2021-06-20 18:00:00.000000 | 2021-06-24 09:00:16.531 HD Request # 39 | Received 14908 records from 2021-06-18 16:58:04.614000 to 2021-06-24 09:00:04.233000 (5.7 days) and wrote 14907 records for RBN21-NYMEX | 2021-06-24 09:00:16.531 HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2021-06-24 13:00:04.233000 | 2021-06-24 09:00:16.541 HD Request # 39 | Completion time: 0s | 2021-06-24 09:00:16.541 HD Request # 39 | Intraday data download complete for RBN21-NYMEX. Unique request ID: 39 | 2021-06-24 09:00:16.541 Removing historical data download ID 39. | 2021-06-24 09:00:16.541 Real-time Intraday chart data file updates started for RBN21-NYMEX | 2021-06-24 09:00:16.541 Intraday chart data file opened for RBN21-NYMEX | 2021-06-24 09:00:16.541 HD Request # 39 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:16.541 Triggering next historical data download in queue. | 2021-06-24 09:00:16.541 HD Request # 40 | Downloading Intraday chart data for HGN21-COMEX to the file HGN21-COMEX.scid. Service: comex | 2021-06-24 09:00:16.541 HD Request # 40 | Download start date-time: 2021-06-17 09:39:52.000000. File last date-time: 2021-06-17 09:39:52.932000 | 2021-06-24 09:00:16.541 HD Request # 40 | Using server: ds21.sierracharts.com port 10149 | 2021-06-24 09:00:16.541 Socket (9) | Creating socket. | 2021-06-24 09:00:16.541 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 09:00:16.541 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-24 09:00:16.541 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:00:16.561 Socket (4) | Closed. | 2021-06-24 09:00:16.561 HD Request # 40 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:16.591 HD Request # 40 | Sending historical data logon request message. | 2021-06-24 09:00:16.591 HD Request # 40 | Requesting Intraday data. Start date-time: 2021-06-17 09:39:52. Record interval: 0. Symbol: HGN21 | 2021-06-24 09:00:16.621 HD Request # 40 | Decompressing data. | 2021-06-24 09:00:16.651 HD Request # 40 | Receiving Intraday data for HGN21-COMEX starting at 2021-06-17 09:39:52.171000 | 2021-06-24 09:00:16.711 HD Request # 40 | Timestamp of first Intraday data file record written: 2021-06-17 09:39:54.902000 | 2021-06-24 09:00:16.831 Socket (9) | CloseSocket call. | 2021-06-24 09:00:17.251 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:17.251 Historical data download thread signaled to stop. | 2021-06-24 09:00:17.261 HD Request # 40 | Received 307899 records from 2021-06-17 09:39:52.171000 to 2021-06-24 09:00:13.082000 (7.0 days) and wrote 307896 records for HGN21-COMEX | 2021-06-24 09:00:17.261 HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2021-06-24 13:00:13.082000 | 2021-06-24 09:00:17.261 Added 19 Time and Sales records to Intraday data file for HGN21-COMEX after download. | 2021-06-24 09:00:17.261 HD Request # 40 | Completion time: 1s | 2021-06-24 09:00:17.271 HD Request # 40 | Intraday data download complete for HGN21-COMEX. Unique request ID: 40 | 2021-06-24 09:00:17.271 Removing historical data download ID 40. | 2021-06-24 09:00:17.271 Real-time Intraday chart data file updates started for HGN21-COMEX | 2021-06-24 09:00:17.271 Intraday chart data file opened for HGN21-COMEX | 2021-06-24 09:00:17.271 HD Request # 40 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:17.271 Triggering next historical data download in queue. | 2021-06-24 09:00:17.271 HD Request # 41 | Downloading Intraday chart data for BTCM21-CME to the file BTCM21-CME.scid. Service: cme | 2021-06-24 09:00:17.271 HD Request # 41 | Download start date-time: 2021-06-18 16:59:59.000000. File last date-time: 2021-06-18 16:59:59.147002 | 2021-06-24 09:00:17.271 HD Request # 41 | Using server: ds23.sierracharts.com port 10150 | 2021-06-24 09:00:17.271 Socket (4) | Creating socket. | 2021-06-24 09:00:17.271 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:00:17.271 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 09:00:17.271 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 09:00:17.281 Socket (9) | Closed. | 2021-06-24 09:00:17.281 HD Request # 41 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:17.331 HD Request # 41 | Sending historical data logon request message. | 2021-06-24 09:00:17.331 HD Request # 41 | Requesting Intraday data. Start date-time: 2021-06-18 16:59:59. Record interval: 0. Symbol: BTCM21 | 2021-06-24 09:00:17.361 HD Request # 41 | Decompressing data. | 2021-06-24 09:00:17.391 HD Request # 41 | Receiving Intraday data for BTCM21-CME starting at 2021-06-18 16:59:59.147000 | 2021-06-24 09:00:17.491 Socket (4) | CloseSocket call. | 2021-06-24 09:00:17.551 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:17.551 Historical data download thread signaled to stop. | 2021-06-24 09:00:17.551 HD Request # 41 | Timestamp of first Intraday data file record written: 2021-06-20 18:00:15.124000 | 2021-06-24 09:00:17.551 HD Request # 41 | Received 26287 records from 2021-06-18 16:59:59.147000 to 2021-06-24 08:59:53.606000 (5.7 days) and wrote 26284 records for BTCM21-CME | 2021-06-24 09:00:17.551 HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2021-06-24 12:59:53.606000 | 2021-06-24 09:00:17.551 HD Request # 41 | Completion time: 0s | 2021-06-24 09:00:17.551 HD Request # 41 | Intraday data download complete for BTCM21-CME. Unique request ID: 41 | 2021-06-24 09:00:17.551 Removing historical data download ID 41. | 2021-06-24 09:00:17.551 Real-time Intraday chart data file updates started for BTCM21-CME | 2021-06-24 09:00:17.551 Intraday chart data file opened for BTCM21-CME | 2021-06-24 09:00:17.551 HD Request # 41 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:17.551 Triggering next historical data download in queue. | 2021-06-24 09:00:17.551 HD Request # 42 | Downloading Intraday chart data for BTCUSDT_PERP_BINANCE to the file BTCUSDT_PERP_BINANCE.scid. Service: binance_cryptocurrency.exchange.data | 2021-06-24 09:00:17.551 HD Request # 42 | Download start date-time: 2021-06-15 08:15:24.000000. File last date-time: 2021-06-15 08:15:24.747003 | 2021-06-24 09:00:17.551 HD Request # 42 | Using server: ds4.sierracharts.com port 10149 | 2021-06-24 09:00:17.551 Socket (9) | Creating socket. | 2021-06-24 09:00:17.551 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 09:00:17.551 Socket (9) | Connecting to IP: 192.81.56.146. | 2021-06-24 09:00:17.551 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:00:17.581 Socket (4) | Closed. | 2021-06-24 09:00:17.581 HD Request # 42 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:17.631 HD Request # 42 | Sending historical data logon request message. | 2021-06-24 09:00:17.631 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:00:17.941 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:00:17.941 Unsubscribed from market depth data for GCQ21-COMEX | 2021-06-24 09:00:17.981 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: GCQ21.. Service code: comex | 2021-06-24 09:00:17.981 HD Request # 42 | Requesting Intraday data. Start date-time: 2021-06-15 08:15:24. Record interval: 0. Symbol: BTCUSDT_PERP_BINANCE | 2021-06-24 09:00:18.201 HD Request # 42 | Decompressing data. | 2021-06-24 09:00:18.231 HD Request # 42 | Receiving Intraday data for BTCUSDT_PERP_BINANCE starting at 2021-06-15 08:15:24.000000 | 2021-06-24 09:00:18.391 HD Request # 42 | Timestamp of first Intraday data file record written: 2021-06-15 08:15:25.000000 | 2021-06-24 09:00:18.531 Opened cached Intraday file: C:\SierraChart\Data\CLQ21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 09:00:19.341 Opened cached Intraday file: C:\SierraChart\Data\HGN21-COMEX.scid. Thread ID: 5644 | 2021-06-24 09:00:19.341 Opened cached Intraday file: C:\SierraChart\Data\LNEN21 C3350.FUT_OPT.NYMEX.scid. Thread ID: 5644 | 2021-06-24 09:00:19.341 Opened cached Intraday file: C:\SierraChart\Data\RBN21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 09:00:24.341 Socket (9) | CloseSocket call. | 2021-06-24 09:00:24.951 Historical data download thread signaled to stop. | 2021-06-24 09:00:24.951 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:24.951 HD Request # 42 | Received 779491 records from 2021-06-15 08:15:24.000000 to 2021-06-24 09:00:21.000000 (9.0 days) and wrote 779489 records for BTCUSDT_PERP_BINANCE | 2021-06-24 09:00:24.951 HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2021-06-24 13:00:21.000000 | 2021-06-24 09:00:24.951 Added 572 Time and Sales records to Intraday data file for BTCUSDT_PERP_BINANCE after download. | 2021-06-24 09:00:24.951 HD Request # 42 | Completion time: 7s | 2021-06-24 09:00:24.951 HD Request # 42 | Intraday data download complete for BTCUSDT_PERP_BINANCE. Unique request ID: 42 | 2021-06-24 09:00:24.951 Removing historical data download ID 42. | 2021-06-24 09:00:24.951 Real-time Intraday chart data file updates started for BTCUSDT_PERP_BINANCE | 2021-06-24 09:00:24.951 Intraday chart data file opened for BTCUSDT_PERP_BINANCE | 2021-06-24 09:00:24.951 HD Request # 42 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:24.951 Triggering next historical data download in queue. | 2021-06-24 09:00:24.951 HD Request # 43 | Downloading Intraday chart data for CLTN21-NYMEX to the file CLTN21-NYMEX.scid. Service: nymex | 2021-06-24 09:00:24.951 HD Request # 43 | Download start date-time: 2021-06-18 14:29:55.000000. File last date-time: 2021-06-18 14:29:55.537000 | 2021-06-24 09:00:24.951 HD Request # 43 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 09:00:24.951 Socket (4) | Creating socket. | 2021-06-24 09:00:24.951 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:00:24.951 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-24 09:00:24.951 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 09:00:24.981 Socket (9) | Closed. | 2021-06-24 09:00:24.981 HD Request # 43 | Setting DTC encoding to Binary VLS | 2021-06-24 09:00:25.011 HD Request # 43 | Sending historical data logon request message. | 2021-06-24 09:00:25.011 HD Request # 43 | Requesting Intraday data. Start date-time: 2021-06-18 14:29:55. Record interval: 0. Symbol: CLTN21 | 2021-06-24 09:00:25.491 HD Request # 43 | Decompressing data. | 2021-06-24 09:00:25.521 HD Request # 43 | Receiving Intraday data for CLTN21-NYMEX starting at 2021-06-18 14:29:55.503000 | 2021-06-24 09:00:25.521 Socket (4) | CloseSocket call. | 2021-06-24 09:00:25.521 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:00:25.521 Historical data download thread signaled to stop. | 2021-06-24 09:00:25.521 HD Request # 43 | Timestamp of first Intraday data file record written: 2021-06-20 18:00:00.000000 | 2021-06-24 09:00:25.521 HD Request # 43 | Received 356 records from 2021-06-18 14:29:55.503000 to 2021-06-21 14:29:59.286000 (3.0 days) and wrote 326 records for CLTN21-NYMEX | 2021-06-24 09:00:25.521 HD Request # 43 | Add time&sales data | Remembered last file record date-time: 2021-06-21 18:29:59.286000 | 2021-06-24 09:00:25.531 HD Request # 43 | Completion time: 1s | 2021-06-24 09:00:25.531 HD Request # 43 | Intraday data download complete for CLTN21-NYMEX. Unique request ID: 43 | 2021-06-24 09:00:25.531 Removing historical data download ID 43. | 2021-06-24 09:00:25.531 Real-time Intraday chart data file updates started for CLTN21-NYMEX | 2021-06-24 09:00:25.531 Intraday chart data file opened for CLTN21-NYMEX | 2021-06-24 09:00:25.531 HD Request # 43 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:00:25.531 Triggering next historical data download in queue. | 2021-06-24 09:00:25.531 No download requests in the queue to start downloads for. | 2021-06-24 09:00:25.531 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:00:25.551 Socket (4) | Closed. | 2021-06-24 09:00:25.551 Opened cached Intraday file: C:\SierraChart\Data\BTCUSDT_PERP_BINANCE.scid. Thread ID: 5644 | 2021-06-24 09:00:29.341 NGN21-NYMEX[M] Point & Figure 1-10 #1 | Reloading chart. | 2021-06-24 09:00:32.301 Opened cached Intraday file: C:\SierraChart\Data\BTCM21-CME.scid. Thread ID: 5644 | 2021-06-24 09:00:44.341 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:15:51.388 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:15:51.388 Added historical Intraday data request for NGQ21-NYMEX to the queue. | 2021-06-24 09:15:51.498 Intraday data recording state for symbol NGQ21-NYMEX is set to download 'Pending'. | 2021-06-24 09:15:51.498 Triggering next historical data download in queue. | 2021-06-24 09:15:51.498 HD Request # 44 | Downloading Intraday chart data for NGQ21-NYMEX to the file NGQ21-NYMEX.scid. Service: nymex | 2021-06-24 09:15:51.498 HD Request # 44 | Download start date-time: 2021-06-23 16:47:50.000000. File last date-time: 2021-06-23 16:47:50.101000 | 2021-06-24 09:15:51.498 HD Request # 44 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 09:15:51.498 Socket (4) | Creating socket. | 2021-06-24 09:15:51.498 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 09:15:51.498 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 09:15:51.498 HD Request # 44 | Setting DTC encoding to Binary VLS | 2021-06-24 09:15:51.578 HD Request # 44 | Sending historical data logon request message. | 2021-06-24 09:15:51.578 HD Request # 44 | Requesting Intraday data. Start date-time: 2021-06-23 16:47:50. Record interval: 0. Symbol: NGQ21 | 2021-06-24 09:15:52.068 HD Request # 44 | Decompressing data. | 2021-06-24 09:15:52.098 HD Request # 44 | Receiving Intraday data for NGQ21-NYMEX starting at 2021-06-23 16:47:50.101000 | 2021-06-24 09:15:52.178 Socket (4) | CloseSocket call. | 2021-06-24 09:15:52.208 Historical data download thread signaled to stop. | 2021-06-24 09:15:52.208 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 09:15:52.208 HD Request # 44 | Timestamp of first Intraday data file record written: 2021-06-23 16:48:12.560000 | 2021-06-24 09:15:52.208 HD Request # 44 | Received 14323 records from 2021-06-23 16:47:50.101000 to 2021-06-24 09:15:49.619002 (16.5 hours) and wrote 14322 records for NGQ21-NYMEX | 2021-06-24 09:15:52.208 HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2021-06-24 13:15:49.619002 | 2021-06-24 09:15:52.208 HD Request # 44 | Completion time: 1s | 2021-06-24 09:15:52.208 HD Request # 44 | Intraday data download complete for NGQ21-NYMEX. Unique request ID: 44 | 2021-06-24 09:15:52.208 Removing historical data download ID 44. | 2021-06-24 09:15:52.208 Real-time Intraday chart data file updates started for NGQ21-NYMEX | 2021-06-24 09:15:52.208 Intraday chart data file opened for NGQ21-NYMEX | 2021-06-24 09:15:52.208 HD Request # 44 | Enabling Intraday chart updating for symbol. | 2021-06-24 09:15:52.208 Triggering next historical data download in queue. | 2021-06-24 09:15:52.208 No download requests in the queue to start downloads for. | 2021-06-24 09:15:52.208 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 09:15:52.238 Socket (4) | Closed. | 2021-06-24 09:15:52.238 Opened cached Intraday file: C:\SierraChart\Data\NGQ21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 09:15:59.338 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 09:16:05.068 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 09:16:05.068 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol NGQ21-NYMEX | 2021-06-24 09:17:04.438 DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market orders for symbol NGQ21-NYMEX | 2021-06-24 09:17:04.438 Opened cached Intraday file: C:\SierraChart\Data\ZSN21-CBOT.scid. Thread ID: 5644 | 2021-06-24 09:30:04.339 Opened cached Intraday file: C:\SierraChart\Data\ZWN21-CBOT.scid. Thread ID: 5644 | 2021-06-24 09:30:04.339 Opened cached Intraday file: C:\SierraChart\Data\ZCN21-CBOT.scid. Thread ID: 5644 | 2021-06-24 09:30:04.339 Requesting current DateTime from Sierra Chart server. | 2021-06-24 09:49:30.187 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 13:49:30.577. Round-trip delay: 00:00:00.200 | 2021-06-24 09:49:30.587 Computer time to server time difference: 00:00:00.010 | 2021-06-24 09:49:30.587 Successfully set the system Date-time to: 2021-06-24 13:49:30.577 UTC. | 2021-06-24 09:49:30.577 NGQ21-NYMEX[M] Point & Figure 1-10 #1 | Reloading chart. | 2021-06-24 10:32:06.240 Requesting current DateTime from Sierra Chart server. | 2021-06-24 10:49:30.150 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 14:49:30.542. Round-trip delay: 00:00:00.200 | 2021-06-24 10:49:30.550 Computer time to server time difference: 00:00:00.008 | 2021-06-24 10:49:30.550 Successfully set the system Date-time to: 2021-06-24 14:49:30.542 UTC. | 2021-06-24 10:49:30.542 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 11:15:40.112 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 11:15:40.112 HD Server | Thread:1788 (4) | Creating socket. | 2021-06-24 11:15:40.112 HD Server | Thread:1788 (4) | New receive buffer size: 262144 | 2021-06-24 11:15:40.112 HD Server | Setting DTC encoding to Binary VLS | Thread:1788 | 2021-06-24 11:15:40.122 HD Server | Thread:1788 (4) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-24 11:15:40.122 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:1788 | 2021-06-24 11:15:40.122 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:1788 | 2021-06-24 11:15:40.122 HD Server | HD Request #103 | Socket: 4 | Symbol: VXN21-CFE | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-18 00:00:00 | ClientReqID: 103 | Username: SPRDTRDR. | Thread:1788 | 2021-06-24 11:15:40.122 Added historical Daily data request for VXN21-CFE to the queue. | 2021-06-24 11:15:40.122 Triggering next historical data download in queue. | 2021-06-24 11:15:40.122 HD Request # 45 | Downloading Historical Daily chart data for VXN21-CFE. Starting date: 2021-06-18. Service: cfefut | 2021-06-24 11:15:40.122 HD Request # 45 | Requesting historical Daily data for VIN21 starting at 2021-06-17. SC External HD service. | 2021-06-24 11:15:40.632 HD Request # 45 | Receiving historical Daily data for VXN21-CFE starting at 2021-06-18 | 2021-06-24 11:15:40.882 HD Request # 45 | Writing historical Daily data to the file VXN21-CFE.dly | 2021-06-24 11:15:40.882 HD Request # 45 | Bytes received: 273 | 2021-06-24 11:15:40.882 HD Request # 45 | Received 5 records from 2021-06-18 00:00:00 to 2021-06-23 00:00:00 (6.0 days) and wrote 4 records for VXN21-CFE | 2021-06-24 11:15:40.882 HD Request # 45 | Completion time: 0s | 2021-06-24 11:15:40.892 HD Request # 45 | Daily data download complete for VXN21-CFE. Unique request ID: 45 | 2021-06-24 11:15:40.892 Removing historical data download ID 45. | 2021-06-24 11:15:40.892 Triggering next historical data download in queue. | 2021-06-24 11:15:40.892 No download requests in the queue to start downloads for. | 2021-06-24 11:15:40.892 HD Server | HD Request | Socket: 4 | Symbol: VXN21-CFE | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 103 | Username: SPRDTRDR. | Thread:1788 | 2021-06-24 11:15:41.142 HD Server | Thread:1788 (4) | Socket gracefully closed by remote side. | 2021-06-24 11:15:41.142 HD Server | Thread:1788 (4) | CloseSocket call. | 2021-06-24 11:15:41.142 HD Server | Thread:1788 (0) | CloseSocket call. | 2021-06-24 11:15:41.142 HD Server | Thread:1788 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 11:15:41.142 HD Server | Thread:1788 (4) | Closed. | 2021-06-24 11:15:41.142 HD Server | Thread:1788 (0) | CloseSocket call. | 2021-06-24 11:15:41.142 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:1788 | 2021-06-24 11:15:41.282 HD Server Manager | Current server count=0 | 2021-06-24 11:15:41.282 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 11:15:41.512 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 11:15:41.512 HD Server | Thread:4696 (4) | Creating socket. | 2021-06-24 11:15:41.522 HD Server | Thread:4696 (4) | New receive buffer size: 262144 | 2021-06-24 11:15:41.522 HD Server | Thread:4696 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 11:15:41.522 HD Server | Setting DTC encoding to Binary VLS | Thread:4696 | 2021-06-24 11:15:41.522 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 11:15:41.522 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 11:15:41.522 HD Server | HD Request #104 | Socket: 4 | Symbol: VIF21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-01-12 00:00:00 | ClientReqID: 104 | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 11:15:41.522 HD Server | HD Request | Socket: 4 | Symbol: VIF21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 104 | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 11:15:41.532 HD Server | Thread:4696 (4) | Socket gracefully closed by remote side. | 2021-06-24 11:15:41.532 HD Server | Thread:4696 (4) | CloseSocket call. | 2021-06-24 11:15:41.532 HD Server | Thread:4696 (0) | CloseSocket call. | 2021-06-24 11:15:41.532 HD Server | Thread:4696 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 11:15:41.532 HD Server | Thread:4696 (4) | Closed. | 2021-06-24 11:15:41.532 HD Server | Thread:4696 (0) | CloseSocket call. | 2021-06-24 11:15:41.532 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 11:15:41.542 HD Server Manager | Started new historical data server. Count=2 | 2021-06-24 11:15:41.542 HD Server | Thread:4660 (4) | Creating socket. | 2021-06-24 11:15:41.542 HD Server | Thread:4660 (4) | New receive buffer size: 262144 | 2021-06-24 11:15:41.542 HD Server | Thread:4660 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 11:15:41.542 HD Server | Setting DTC encoding to Binary VLS | Thread:4660 | 2021-06-24 11:15:41.542 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4660 | 2021-06-24 11:15:41.542 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4660 | 2021-06-24 11:15:41.542 HD Server | HD Request #105 | Socket: 4 | Symbol: VIJ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-04-13 00:00:00 | ClientReqID: 105 | Username: SPRDTRDR. | Thread:4660 | 2021-06-24 11:15:41.542 HD Server | HD Request | Socket: 4 | Symbol: VIJ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 105 | Username: SPRDTRDR. | Thread:4660 | 2021-06-24 11:15:41.552 HD Server | Thread:4660 (4) | Socket gracefully closed by remote side. | 2021-06-24 11:15:41.562 HD Server | Thread:4660 (4) | CloseSocket call. | 2021-06-24 11:15:41.562 HD Server | Thread:4660 (0) | CloseSocket call. | 2021-06-24 11:15:41.562 HD Server | Thread:4660 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 11:15:41.562 HD Server | Thread:4660 (4) | Closed. | 2021-06-24 11:15:41.562 HD Server | Thread:4660 (0) | CloseSocket call. | 2021-06-24 11:15:41.562 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 11:15:41.562 HD Server Manager | Started new historical data server. Count=3 | 2021-06-24 11:15:41.572 HD Server | Thread:6324 (4) | Creating socket. | 2021-06-24 11:15:41.572 HD Server | Thread:6324 (4) | New receive buffer size: 262144 | 2021-06-24 11:15:41.572 HD Server | Thread:6324 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 11:15:41.572 HD Server | Setting DTC encoding to Binary VLS | Thread:6324 | 2021-06-24 11:15:41.572 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6324 | 2021-06-24 11:15:41.572 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6324 | 2021-06-24 11:15:41.572 HD Server | HD Request #106 | Socket: 4 | Symbol: VIK21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-05-11 00:00:00 | ClientReqID: 106 | Username: SPRDTRDR. | Thread:6324 | 2021-06-24 11:15:41.572 HD Server | HD Request | Socket: 4 | Symbol: VIK21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 106 | Username: SPRDTRDR. | Thread:6324 | 2021-06-24 11:15:41.582 HD Server | Thread:6324 (4) | Socket gracefully closed by remote side. | 2021-06-24 11:15:41.592 HD Server | Thread:6324 (4) | CloseSocket call. | 2021-06-24 11:15:41.592 HD Server | Thread:6324 (0) | CloseSocket call. | 2021-06-24 11:15:41.592 HD Server | Thread:6324 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 11:15:41.592 HD Server | Thread:6324 (4) | Closed. | 2021-06-24 11:15:41.592 HD Server | Thread:6324 (0) | CloseSocket call. | 2021-06-24 11:15:41.592 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6324 | 2021-06-24 11:15:41.792 HD Server Manager | Current server count=2 | 2021-06-24 11:15:41.792 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4660 | 2021-06-24 11:15:41.792 HD Server Manager | Current server count=1 | 2021-06-24 11:15:41.792 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 11:15:41.792 HD Server Manager | Current server count=0 | 2021-06-24 11:15:41.792 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 11:15:45.032 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 11:15:45.032 HD Server | Thread:6212 (4) | Creating socket. | 2021-06-24 11:15:45.042 HD Server | Thread:6212 (4) | New receive buffer size: 262144 | 2021-06-24 11:15:45.042 HD Server | Thread:6212 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 11:15:45.042 HD Server | Setting DTC encoding to Binary VLS | Thread:6212 | 2021-06-24 11:15:45.042 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6212 | 2021-06-24 11:15:45.042 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6212 | 2021-06-24 11:15:45.042 HD Server | HD Request #107 | Socket: 4 | Symbol: CLK21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-04-13 00:00:00 | ClientReqID: 107 | Username: SPRDTRDR. | Thread:6212 | 2021-06-24 11:15:45.042 HD Server | HD Request | Socket: 4 | Symbol: CLK21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 107 | Username: SPRDTRDR. | Thread:6212 | 2021-06-24 11:15:45.062 HD Server | Thread:6212 (4) | Socket gracefully closed by remote side. | 2021-06-24 11:15:45.072 HD Server | Thread:6212 (4) | CloseSocket call. | 2021-06-24 11:15:45.072 HD Server | Thread:6212 (0) | CloseSocket call. | 2021-06-24 11:15:45.072 HD Server | Thread:6212 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 11:15:45.072 HD Server | Thread:6212 (4) | Closed. | 2021-06-24 11:15:45.072 HD Server | Thread:6212 (0) | CloseSocket call. | 2021-06-24 11:15:45.072 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6212 | 2021-06-24 11:15:45.182 HD Server Manager | Current server count=0 | 2021-06-24 11:15:45.182 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 11:15:47.162 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 11:15:47.162 HD Server | Thread:5804 (4) | Creating socket. | 2021-06-24 11:15:47.172 HD Server | Thread:5804 (4) | New receive buffer size: 262144 | 2021-06-24 11:15:47.172 HD Server | Thread:5804 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 11:15:47.172 HD Server | Setting DTC encoding to Binary VLS | Thread:5804 | 2021-06-24 11:15:47.172 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:5804 | 2021-06-24 11:15:47.172 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:5804 | 2021-06-24 11:15:47.172 HD Server | HD Request #108 | Socket: 4 | Symbol: CLM20 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2011-11-29 00:00:00 | ClientReqID: 108 | Username: SPRDTRDR. | Thread:5804 | 2021-06-24 11:15:47.172 HD Server | HD Request | Socket: 4 | Symbol: CLM20 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 108 | Username: SPRDTRDR. | Thread:5804 | 2021-06-24 11:15:47.172 HD Server | Thread:5804 (4) | Socket gracefully closed by remote side. | 2021-06-24 11:15:47.172 HD Server | Thread:5804 (4) | CloseSocket call. | 2021-06-24 11:15:47.172 HD Server | Thread:5804 (0) | CloseSocket call. | 2021-06-24 11:15:47.172 HD Server | Thread:5804 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 11:15:47.172 HD Server | Thread:5804 (4) | Closed. | 2021-06-24 11:15:47.172 HD Server | Thread:5804 (0) | CloseSocket call. | 2021-06-24 11:15:47.172 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:5804 | 2021-06-24 11:15:47.252 HD Server Manager | Current server count=0 | 2021-06-24 11:15:47.252 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 11:15:59.112 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 11:15:59.112 HD Server | Thread:1312 (4) | Creating socket. | 2021-06-24 11:15:59.112 HD Server | Thread:1312 (4) | New receive buffer size: 262144 | 2021-06-24 11:15:59.112 HD Server | Setting DTC encoding to Binary VLS | Thread:1312 | 2021-06-24 11:15:59.112 HD Server | Thread:1312 (4) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-24 11:15:59.112 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:1312 | 2021-06-24 11:15:59.112 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:1312 | 2021-06-24 11:15:59.112 HD Server | HD Request #109 | Socket: 4 | Symbol: 6EU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 109 | Username: SPRDTRDR. | Thread:1312 | 2021-06-24 11:15:59.112 Added historical Daily data request for 6EU21-CME to the queue. | 2021-06-24 11:15:59.122 Triggering next historical data download in queue. | 2021-06-24 11:15:59.122 HD Request # 46 | Downloading Historical Daily chart data for 6EU21-CME. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-24 11:15:59.132 HD Request # 46 | Requesting historical Daily data for E6U21 starting at 2021-06-20. SC External HD service. | 2021-06-24 11:15:59.612 HD Request # 46 | Receiving historical Daily data for 6EU21-CME starting at 2021-06-21 | 2021-06-24 11:15:59.762 HD Request # 46 | Writing historical Daily data to the file 6EU21-CME.dly | 2021-06-24 11:15:59.762 HD Request # 46 | Bytes received: 242 | 2021-06-24 11:15:59.772 HD Request # 46 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for 6EU21-CME | 2021-06-24 11:15:59.772 HD Request # 46 | Completion time: 0s | 2021-06-24 11:15:59.782 HD Request # 46 | Daily data download complete for 6EU21-CME. Unique request ID: 46 | 2021-06-24 11:15:59.782 Removing historical data download ID 46. | 2021-06-24 11:15:59.782 Triggering next historical data download in queue. | 2021-06-24 11:15:59.782 No download requests in the queue to start downloads for. | 2021-06-24 11:15:59.782 HD Server | HD Request | Socket: 4 | Symbol: 6EU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 109 | Username: SPRDTRDR. | Thread:1312 | 2021-06-24 11:16:00.142 HD Server | Thread:1312 (4) | Socket gracefully closed by remote side. | 2021-06-24 11:16:00.152 HD Server | Thread:1312 (4) | CloseSocket call. | 2021-06-24 11:16:00.152 HD Server | Thread:1312 (0) | CloseSocket call. | 2021-06-24 11:16:00.152 HD Server | Thread:1312 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 11:16:00.152 HD Server | Thread:1312 (4) | Closed. | 2021-06-24 11:16:00.152 HD Server | Thread:1312 (0) | CloseSocket call. | 2021-06-24 11:16:00.152 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 11:16:00.172 HD Server Manager | Started new historical data server. Count=2 | 2021-06-24 11:16:00.172 HD Server | Thread:7056 (4) | Creating socket. | 2021-06-24 11:16:00.182 HD Server | Thread:7056 (4) | New receive buffer size: 262144 | 2021-06-24 11:16:00.182 HD Server | Thread:7056 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 11:16:00.182 HD Server | Setting DTC encoding to Binary VLS | Thread:7056 | 2021-06-24 11:16:00.182 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:7056 | 2021-06-24 11:16:00.182 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:7056 | 2021-06-24 11:16:00.182 HD Server | HD Request #110 | Socket: 4 | Symbol: DXU21-ICEUS | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 110 | Username: SPRDTRDR. | Thread:7056 | 2021-06-24 11:16:00.182 Added historical Daily data request for DXU21-ICEUS to the queue. | 2021-06-24 11:16:00.182 Triggering next historical data download in queue. | 2021-06-24 11:16:00.182 HD Request # 47 | Downloading Historical Daily chart data for DXU21-ICEUS. Starting date: 2021-06-21. Service: ice.us | 2021-06-24 11:16:00.192 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:1312 | 2021-06-24 11:16:00.252 HD Server Manager | Current server count=1 | 2021-06-24 11:16:00.252 HD Request # 47 | Requesting historical Daily data for DXU21 starting at 2021-06-20. SC External HD service. | 2021-06-24 11:16:00.682 HD Request # 47 | Receiving historical Daily data for DXU21-ICEUS starting at 2021-06-21 | 2021-06-24 11:16:00.812 HD Request # 47 | Writing historical Daily data to the file DXU21-ICEUS.dly | 2021-06-24 11:16:00.812 HD Request # 47 | Bytes received: 226 | 2021-06-24 11:16:00.812 HD Request # 47 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for DXU21-ICEUS | 2021-06-24 11:16:00.812 HD Request # 47 | Completion time: 0s | 2021-06-24 11:16:00.812 HD Request # 47 | Daily data download complete for DXU21-ICEUS. Unique request ID: 47 | 2021-06-24 11:16:00.812 Removing historical data download ID 47. | 2021-06-24 11:16:00.812 Triggering next historical data download in queue. | 2021-06-24 11:16:00.812 No download requests in the queue to start downloads for. | 2021-06-24 11:16:00.812 HD Server | HD Request | Socket: 4 | Symbol: DXU21-ICEUS | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 110 | Username: SPRDTRDR. | Thread:7056 | 2021-06-24 11:16:01.202 HD Server | Thread:7056 (4) | Socket gracefully closed by remote side. | 2021-06-24 11:16:01.202 HD Server | Thread:7056 (4) | CloseSocket call. | 2021-06-24 11:16:01.202 HD Server | Thread:7056 (0) | CloseSocket call. | 2021-06-24 11:16:01.202 HD Server | Thread:7056 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 11:16:01.202 HD Server | Thread:7056 (4) | Closed. | 2021-06-24 11:16:01.202 HD Server | Thread:7056 (0) | CloseSocket call. | 2021-06-24 11:16:01.202 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 11:16:01.222 HD Server Manager | Started new historical data server. Count=2 | 2021-06-24 11:16:01.222 HD Server | Thread:4744 (4) | Creating socket. | 2021-06-24 11:16:01.222 HD Server | Thread:4744 (4) | New receive buffer size: 262144 | 2021-06-24 11:16:01.222 HD Server | Thread:4744 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 11:16:01.222 HD Server | Setting DTC encoding to Binary VLS | Thread:4744 | 2021-06-24 11:16:01.222 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4744 | 2021-06-24 11:16:01.232 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4744 | 2021-06-24 11:16:01.232 HD Server | HD Request #111 | Socket: 4 | Symbol: ESU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 111 | Username: SPRDTRDR. | Thread:4744 | 2021-06-24 11:16:01.232 Added historical Daily data request for ESU21-CME to the queue. | 2021-06-24 11:16:01.232 Triggering next historical data download in queue. | 2021-06-24 11:16:01.232 HD Request # 48 | Downloading Historical Daily chart data for ESU21-CME. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-24 11:16:01.242 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:7056 | 2021-06-24 11:16:01.292 HD Server Manager | Current server count=1 | 2021-06-24 11:16:01.292 HD Request # 48 | Requesting historical Daily data for ESU21 starting at 2021-06-20. SC External HD service. | 2021-06-24 11:16:01.732 HD Request # 48 | Receiving historical Daily data for ESU21-CME starting at 2021-06-21 | 2021-06-24 11:16:01.852 HD Request # 48 | Writing historical Daily data to the file ESU21-CME.dly | 2021-06-24 11:16:01.852 HD Request # 48 | Bytes received: 250 | 2021-06-24 11:16:01.862 HD Request # 48 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for ESU21-CME | 2021-06-24 11:16:01.862 HD Request # 48 | Completion time: 0s | 2021-06-24 11:16:01.862 HD Request # 48 | Daily data download complete for ESU21-CME. Unique request ID: 48 | 2021-06-24 11:16:01.862 Removing historical data download ID 48. | 2021-06-24 11:16:01.862 Triggering next historical data download in queue. | 2021-06-24 11:16:01.862 No download requests in the queue to start downloads for. | 2021-06-24 11:16:01.862 HD Server | HD Request | Socket: 4 | Symbol: ESU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 111 | Username: SPRDTRDR. | Thread:4744 | 2021-06-24 11:16:02.242 HD Server | Thread:4744 (4) | Socket gracefully closed by remote side. | 2021-06-24 11:16:02.242 HD Server | Thread:4744 (4) | CloseSocket call. | 2021-06-24 11:16:02.242 HD Server | Thread:4744 (0) | CloseSocket call. | 2021-06-24 11:16:02.242 HD Server | Thread:4744 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 11:16:02.242 HD Server | Thread:4744 (4) | Closed. | 2021-06-24 11:16:02.242 HD Server | Thread:4744 (0) | CloseSocket call. | 2021-06-24 11:16:02.242 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4744 | 2021-06-24 11:16:02.322 HD Server Manager | Current server count=0 | 2021-06-24 11:16:02.322 Opened cached Intraday file: C:\SierraChart\Data\NGTN21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 11:34:54.281 Requesting current DateTime from Sierra Chart server. | 2021-06-24 11:49:30.122 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 15:49:30.511. Round-trip delay: 00:00:00.200 | 2021-06-24 11:49:30.522 Computer time to server time difference: 00:00:00.011 | 2021-06-24 11:49:30.522 Successfully set the system Date-time to: 2021-06-24 15:49:30.511 UTC. | 2021-06-24 11:49:30.511 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 12:00:38.171 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 12:00:38.171 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 12:00:44.401 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 12:00:44.401 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 12:12:03.982 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 12:12:03.982 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 12:14:45.403 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 12:14:45.403 Requesting current DateTime from Sierra Chart server. | 2021-06-24 12:49:30.090 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 16:49:30.482. Round-trip delay: 00:00:00.200 | 2021-06-24 12:49:30.490 Computer time to server time difference: 00:00:00.008 | 2021-06-24 12:49:30.490 Successfully set the system Date-time to: 2021-06-24 16:49:30.482 UTC. | 2021-06-24 12:49:30.482 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 12:55:47.342 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 12:55:47.342 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 13:13:23.484 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 13:13:23.484 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 13:17:58.202 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 13:17:58.202 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 13:20:36.492 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 13:20:36.492 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 13:31:47.593 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 13:31:47.593 NGQ21-NYMEX[M] 5 Min #14 | Reloading chart. | 2021-06-24 13:33:51.513 NGQ21-NYMEX[M] 15 Min #9 | Reloading chart. | 2021-06-24 13:33:51.573 NGQ21-NYMEX[M] 60 Min #8 | Reloading chart. | 2021-06-24 13:33:51.573 NGQ21-NYMEX[M] 60 Min #6 | Reloading chart. | 2021-06-24 13:33:51.593 NGQ21-NYMEX[M] 60 Min #11 | Reloading chart. | 2021-06-24 13:33:51.593 NGQ21-NYMEX [C][M] 330 Min #4 | Reloading chart. | 2021-06-24 13:33:51.623 NGQ21-NYMEX[M] 60 Min #5 | Reloading chart. | 2021-06-24 13:33:51.643 NGQ21-NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-24 13:33:51.653 NGQ21-NYMEX[M] #10 | Reloading chart. | 2021-06-24 13:33:51.693 NGQ21-NYMEX [C][M] 330 Min #13 | Reloading chart. | 2021-06-24 13:33:51.693 Loading market depth data. | 2021-06-24 13:33:51.743 NGQ21-NYMEX[M] #11 | Reloading chart. | 2021-06-24 13:33:51.793 NGQ21-NYMEX[M] #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 13:33:51.793 NGQ21-NYMEX[M] Point & Figure 1-10 #2 | Reloading chart. | 2021-06-24 13:33:51.793 NGQ21-NYMEX[M] #3 | Reloading chart. | 2021-06-24 13:33:51.813 NGQ21-NYMEX[M] Point & Figure 5-3 #3 | Reloading chart. | 2021-06-24 13:33:51.903 NGQ21-NYMEX[M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 13:33:51.973 Loaded depth data records for NGQ21-NYMEX 2021-06-15 from 2021-06-15 09:00:00.000000 to 2021-06-15 14:29:59.867000. | 2021-06-24 13:33:51.993 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\NGQ21-NYMEX.2021-06-16.depth. This may take a while. | 2021-06-24 13:33:52.003 File compression enabled. C:\SierraChart\Data\MarketDepthData\NGQ21-NYMEX.2021-06-16.depth. CompressionState=0 | 2021-06-24 13:33:52.003 Loaded depth data records for NGQ21-NYMEX 2021-06-16 from 2021-06-16 09:00:00.000000 to 2021-06-16 14:29:59.870000. | 2021-06-24 13:33:52.513 Loaded depth data records for NGQ21-NYMEX 2021-06-17 from 2021-06-17 09:00:00.000000 to 2021-06-17 14:29:59.915000. | 2021-06-24 13:33:52.743 Loaded depth data records for NGQ21-NYMEX 2021-06-18 from 2021-06-18 09:00:00.000000 to 2021-06-18 14:29:59.999000. | 2021-06-24 13:33:52.943 Loaded depth data records for NGQ21-NYMEX 2021-06-19 from 00:00:00.000000 to 00:00:00.000000. | 2021-06-24 13:33:52.943 Loaded depth data records for NGQ21-NYMEX 2021-06-20 from 2021-06-20 12:07:43.896007 to 2021-06-20 12:07:46.735212. | 2021-06-24 13:33:52.963 Loaded depth data records for NGQ21-NYMEX 2021-06-21 from 2021-06-21 09:00:00.000000 to 2021-06-21 14:29:59.842000. | 2021-06-24 13:33:53.123 Loaded depth data records for NGQ21-NYMEX 2021-06-23 from 2021-06-23 09:35:16.046000 to 2021-06-23 09:43:11.754124. | 2021-06-24 13:33:53.133 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\NGQ21-NYMEX.2021-06-24.depth. This may take a while. | 2021-06-24 13:33:53.143 File compression enabled. C:\SierraChart\Data\MarketDepthData\NGQ21-NYMEX.2021-06-24.depth. CompressionState=0 | 2021-06-24 13:33:53.143 Loaded depth data records for NGQ21-NYMEX 2021-06-24 from 2021-06-24 09:00:00.000000 to 2021-06-24 13:33:47.222000. | 2021-06-24 13:33:53.643 NGQ21-NYMEX[M] 5 Min #14 | Reloading chart. | 2021-06-24 13:34:09.893 NGQ21-NYMEX[M] 15 Min #9 | Reloading chart. | 2021-06-24 13:34:09.903 NGQ21-NYMEX[M] 60 Min #8 | Reloading chart. | 2021-06-24 13:34:09.903 NGQ21-NYMEX[M] 60 Min #6 | Reloading chart. | 2021-06-24 13:34:09.903 NGQ21-NYMEX[M] 60 Min #11 | Reloading chart. | 2021-06-24 13:34:09.903 NGQ21-NYMEX [C][M] 330 Min #4 | Reloading chart. | 2021-06-24 13:34:09.913 NGQ21-NYMEX[M] 60 Min #5 | Reloading chart. | 2021-06-24 13:34:09.933 NGQ21-NYMEX[M] 5 Min #4 | Reloading chart. | 2021-06-24 13:34:10.023 NGQ21-NYMEX[M] #10 | Reloading chart. | 2021-06-24 13:34:10.023 NGQ21-NYMEX [C][M] 330 Min #13 | Reloading chart. | 2021-06-24 13:34:10.073 NGQ21-NYMEX[M] #11 | Reloading chart. | 2021-06-24 13:34:10.083 NGQ21-NYMEX[M] #11 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 13:34:10.083 NGQ21-NYMEX[M] Point & Figure 1-10 #2 | Reloading chart. | 2021-06-24 13:34:10.083 Loading market depth data. | 2021-06-24 13:34:10.083 NGQ21-NYMEX[M] Point & Figure 1-10 #1 | Reloading chart. | 2021-06-24 13:34:10.113 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 13:34:10.143 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 13:34:10.143 NGQ21-NYMEX[M] #3 | Reloading chart. | 2021-06-24 13:34:10.143 NGQ21-NYMEX[M] Point & Figure 5-3 #3 | Reloading chart. | 2021-06-24 13:34:10.153 NGQ21-NYMEX[M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 13:34:10.249 Loaded depth data records for NGQ21-NYMEX 2021-06-15 from 2021-06-15 09:00:00.000000 to 2021-06-15 14:29:59.867000. | 2021-06-24 13:34:10.293 Loaded depth data records for NGQ21-NYMEX 2021-06-16 from 2021-06-16 09:00:00.000000 to 2021-06-16 14:29:59.870000. | 2021-06-24 13:34:10.443 Loaded depth data records for NGQ21-NYMEX 2021-06-17 from 2021-06-17 09:00:00.000000 to 2021-06-17 14:29:59.915000. | 2021-06-24 13:34:10.643 Loaded depth data records for NGQ21-NYMEX 2021-06-18 from 2021-06-18 09:00:00.000000 to 2021-06-18 14:29:59.999000. | 2021-06-24 13:34:10.823 Loaded depth data records for NGQ21-NYMEX 2021-06-19 from 00:00:00.000000 to 00:00:00.000000. | 2021-06-24 13:34:10.823 Loaded depth data records for NGQ21-NYMEX 2021-06-20 from 2021-06-20 12:07:43.896007 to 2021-06-20 12:07:46.735212. | 2021-06-24 13:34:10.823 Loaded depth data records for NGQ21-NYMEX 2021-06-21 from 2021-06-21 09:00:00.000000 to 2021-06-21 14:29:59.842000. | 2021-06-24 13:34:10.983 Loaded depth data records for NGQ21-NYMEX 2021-06-23 from 2021-06-23 09:35:16.046000 to 2021-06-23 09:43:11.754124. | 2021-06-24 13:34:10.983 Loaded depth data records for NGQ21-NYMEX 2021-06-24 from 2021-06-24 09:00:00.000000 to 2021-06-24 13:33:55.040000. | 2021-06-24 13:34:11.173 Requesting current DateTime from Sierra Chart server. | 2021-06-24 13:49:30.060 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 17:49:30.448. Round-trip delay: 00:00:00.200 | 2021-06-24 13:49:30.460 Computer time to server time difference: 00:00:00.012 | 2021-06-24 13:49:30.460 Successfully set the system Date-time to: 2021-06-24 17:49:30.448 UTC. | 2021-06-24 13:49:30.448 ESU21-CME[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 14:08:26.599 ESU21-CME[M] #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 14:08:27.239 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 14:26:12.976 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 14:26:12.976 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-24 14:26:21.086 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-24 14:26:21.086 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 14:36:50.419 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 14:36:50.429 HD Server | Thread:5128 (4) | Creating socket. | 2021-06-24 14:36:50.429 HD Server | Thread:5128 (4) | New receive buffer size: 262144 | 2021-06-24 14:36:50.429 HD Server | Thread:5128 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 14:36:50.429 HD Server | Setting DTC encoding to Binary VLS | Thread:5128 | 2021-06-24 14:36:50.429 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:5128 | 2021-06-24 14:36:50.439 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:5128 | 2021-06-24 14:36:50.439 HD Server | HD Request #114 | Socket: 4 | Symbol: NGN21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 114 | Username: SPRDTRDR. | Thread:5128 | 2021-06-24 14:36:50.439 Added historical Daily data request for NGN21-NYMEX to the queue. | 2021-06-24 14:36:50.439 Triggering next historical data download in queue. | 2021-06-24 14:36:50.439 HD Request # 49 | Downloading Historical Daily chart data for NGN21-NYMEX. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-24 14:36:50.449 HD Request # 49 | Requesting historical Daily data for NGN21 starting at 2021-06-20. SC External HD service. | 2021-06-24 14:36:50.949 HD Request # 49 | Receiving historical Daily data for NGN21-NYMEX starting at 2021-06-21 | 2021-06-24 14:36:51.169 HD Request # 49 | Writing historical Daily data to the file NGN21-NYMEX.dly | 2021-06-24 14:36:51.169 HD Request # 49 | Bytes received: 212 | 2021-06-24 14:36:51.179 HD Request # 49 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for NGN21-NYMEX | 2021-06-24 14:36:51.179 HD Request # 49 | Completion time: 1s | 2021-06-24 14:36:51.189 HD Request # 49 | Daily data download complete for NGN21-NYMEX. Unique request ID: 49 | 2021-06-24 14:36:51.189 Removing historical data download ID 49. | 2021-06-24 14:36:51.189 Triggering next historical data download in queue. | 2021-06-24 14:36:51.189 No download requests in the queue to start downloads for. | 2021-06-24 14:36:51.189 HD Server | HD Request | Socket: 4 | Symbol: NGN21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 114 | Username: SPRDTRDR. | Thread:5128 | 2021-06-24 14:36:51.469 HD Server | Thread:5128 (4) | Socket gracefully closed by remote side. | 2021-06-24 14:36:51.489 HD Server | Thread:5128 (4) | CloseSocket call. | 2021-06-24 14:36:51.489 HD Server | Thread:5128 (0) | CloseSocket call. | 2021-06-24 14:36:51.489 HD Server | Thread:5128 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 14:36:51.489 HD Server | Thread:5128 (4) | Closed. | 2021-06-24 14:36:51.489 HD Server | Thread:5128 (0) | CloseSocket call. | 2021-06-24 14:36:51.489 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:5128 | 2021-06-24 14:36:51.529 HD Server Manager | Current server count=0 | 2021-06-24 14:36:51.529 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 14:38:00.241 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 14:38:00.241 HD Server | Thread:4424 (4) | Creating socket. | 2021-06-24 14:38:00.241 HD Server | Thread:4424 (4) | New receive buffer size: 262144 | 2021-06-24 14:38:00.241 HD Server | Thread:4424 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 14:38:00.241 HD Server | Setting DTC encoding to Binary VLS | Thread:4424 | 2021-06-24 14:38:00.241 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4424 | 2021-06-24 14:38:00.251 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4424 | 2021-06-24 14:38:00.251 HD Server | HD Request #117 | Socket: 4 | Symbol: NGQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 1971-06-25 06:38:00 | ClientReqID: 117 | Username: SPRDTRDR. | Thread:4424 | 2021-06-24 14:38:00.251 Added historical Daily data request for NGQ21-NYMEX to the queue. | 2021-06-24 14:38:00.251 Triggering next historical data download in queue. | 2021-06-24 14:38:00.251 HD Request # 50 | Downloading Historical Daily chart data for NGQ21-NYMEX. Starting date: 1971-06-25. Service: scdataallservices | 2021-06-24 14:38:00.251 HD Request # 50 | Requesting historical Daily data for NGQ21 starting at 1971-06-24. SC External HD service. | 2021-06-24 14:38:00.761 HD Request # 50 | Receiving historical Daily data for NGQ21-NYMEX starting at 2008-11-25 | 2021-06-24 14:38:00.941 HD Request # 50 | Writing historical Daily data to the file NGQ21-NYMEX.dly | 2021-06-24 14:38:00.941 HD Request # 50 | Bytes received: 147907 | 2021-06-24 14:38:00.981 HD Request # 50 | Received 3169 records from 2008-11-25 00:00:00 to 2021-06-24 00:00:00 (12.6years) and wrote 3169 records for NGQ21-NYMEX | 2021-06-24 14:38:00.981 HD Request # 50 | Completion time: 0s | 2021-06-24 14:38:00.991 HD Request # 50 | Daily data download complete for NGQ21-NYMEX. Unique request ID: 50 | 2021-06-24 14:38:00.991 Removing historical data download ID 50. | 2021-06-24 14:38:00.991 Triggering next historical data download in queue. | 2021-06-24 14:38:00.991 No download requests in the queue to start downloads for. | 2021-06-24 14:38:00.991 HD Server | HD Request | Socket: 4 | Symbol: NGQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3169 | ClientReqID: 117 | Username: SPRDTRDR. | Thread:4424 | 2021-06-24 14:38:01.291 HD Server | Thread:4424 (4) | Socket gracefully closed by remote side. | 2021-06-24 14:38:01.311 HD Server | Thread:4424 (4) | CloseSocket call. | 2021-06-24 14:38:01.311 HD Server | Thread:4424 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 14:38:01.311 HD Server | Thread:4424 (4) | Closed. | 2021-06-24 14:38:01.311 HD Server | Thread:4424 (0) | CloseSocket call. | 2021-06-24 14:38:01.311 HD Server | Thread:4424 (0) | CloseSocket call. | 2021-06-24 14:38:01.311 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4424 | 2021-06-24 14:38:01.471 HD Server Manager | Current server count=0 | 2021-06-24 14:38:01.471 Requesting current DateTime from Sierra Chart server. | 2021-06-24 14:49:30.022 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 18:49:30.413. Round-trip delay: 00:00:00.200 | 2021-06-24 14:49:30.422 Computer time to server time difference: 00:00:00.009 | 2021-06-24 14:49:30.422 Successfully set the system Date-time to: 2021-06-24 18:49:30.413 UTC. | 2021-06-24 14:49:30.413 Requesting current DateTime from Sierra Chart server. | 2021-06-24 15:49:30.001 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 19:49:30.380. Round-trip delay: 00:00:00.195 | 2021-06-24 15:49:30.391 Computer time to server time difference: 00:00:00.011 | 2021-06-24 15:49:30.391 Successfully set the system Date-time to: 2021-06-24 19:49:30.380 UTC. | 2021-06-24 15:49:30.380 NGQ21-NYMEX[M] Point & Figure 1-10 #1 | Reloading chart. | 2021-06-24 16:00:15.768 SC Data - All Services | Starting real-time market data updates for: ��U21-CM�. ID: 49 | 2021-06-24 16:15:34.720 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ��U21-CM� | 2021-06-24 16:15:34.720 SC Data - All Services | Requesting security definition data for: ��U21-CM�. ID: 49 | 2021-06-24 16:15:34.720 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 16:15:39.852 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 16:15:39.852 HD Server | Thread:6988 (4) | Creating socket. | 2021-06-24 16:15:39.852 HD Server | Thread:6988 (4) | New receive buffer size: 262144 | 2021-06-24 16:15:39.852 HD Server | Thread:6988 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 16:15:39.852 HD Server | Setting DTC encoding to Binary VLS | Thread:6988 | 2021-06-24 16:15:39.852 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6988 | 2021-06-24 16:15:39.852 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6988 | 2021-06-24 16:15:39.852 HD Server | HD Request #119 | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2020-02-10 20:15:39 | ClientReqID: 119 | Username: SPRDTRDR. | Thread:6988 | 2021-06-24 16:15:39.852 No historical data client is currently set to download historical Intraday data for ��U21-CM�. | 2021-06-24 16:15:39.852 Real-time Intraday chart data file updates started for ��U21-CM� | 2021-06-24 16:15:39.852 Intraday chart data file opened for ��U21-CM� | 2021-06-24 16:15:39.852 HD Server | HD Request | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 0 | Records Served: 0 | Error: Historical data file data not available for symbol. C:\SierraChart\Data\��U21-CM�.scid | ClientReqID: 119 | Username: SPRDTRDR. | Thread:6988 | 2021-06-24 16:15:40.866 HD Server | Thread:6988 (4) | Socket gracefully closed by remote side. | 2021-06-24 16:15:40.866 HD Server | Thread:6988 (4) | CloseSocket call. | 2021-06-24 16:15:40.866 HD Server | Thread:6988 (0) | CloseSocket call. | 2021-06-24 16:15:40.866 HD Server | Thread:6988 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 16:15:40.866 HD Server | Thread:6988 (4) | Closed. | 2021-06-24 16:15:40.866 HD Server | Thread:6988 (0) | CloseSocket call. | 2021-06-24 16:15:40.866 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6988 | 2021-06-24 16:15:40.866 HD Server Manager | Current server count=0 | 2021-06-24 16:15:40.866 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 16:15:40.866 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 16:15:40.866 HD Server | Thread:6968 (4) | Creating socket. | 2021-06-24 16:15:40.866 HD Server | Thread:6968 (4) | New receive buffer size: 262144 | 2021-06-24 16:15:40.866 HD Server | Thread:6968 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 16:15:40.866 HD Server | Setting DTC encoding to Binary VLS | Thread:6968 | 2021-06-24 16:15:40.866 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6968 | 2021-06-24 16:15:40.866 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6968 | 2021-06-24 16:15:40.866 HD Server | HD Request #120 | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 1971-06-25 08:15:40 | ClientReqID: 120 | Username: SPRDTRDR. | Thread:6968 | 2021-06-24 16:15:40.866 Added historical Daily data request for ��U21-CM� to the queue. | 2021-06-24 16:15:40.866 Triggering next historical data download in queue. | 2021-06-24 16:15:40.866 HD Request # 51 | Downloading Historical Daily chart data for ��U21-CM�. Starting date: 1971-06-25. Service: scdataallservices | 2021-06-24 16:15:40.866 HD Request # 51 | Requesting historical Daily data for ��U21-CM� starting at 1971-06-24. SC External HD service. | 2021-06-24 16:15:41.365 HD Request # 51 | Error downloading historical Daily data for ��U21-CM�. Error executing query: Invalid symbol | 2021-06-24 16:15:41.646 HD Request # 51 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ��U21-CM� | 2021-06-24 16:15:41.646 HD Request # 51 | Completion time: 1s | 2021-06-24 16:15:41.646 HD Request # 51 | Daily data download complete for ��U21-CM�. Unique request ID: 51 | 2021-06-24 16:15:41.646 Removing historical data download ID 51. | 2021-06-24 16:15:41.646 Triggering next historical data download in queue. | 2021-06-24 16:15:41.646 No download requests in the queue to start downloads for. | 2021-06-24 16:15:41.646 HD Server | HD Request | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 0 | Error: Historical data file data not available for symbol. C:\SierraChart\Data\��U21-CM�.dly | ClientReqID: 120 | Username: SPRDTRDR. | Thread:6968 | 2021-06-24 16:15:41.880 HD Server | Thread:6968 (4) | Socket gracefully closed by remote side. | 2021-06-24 16:15:41.880 HD Server | Thread:6968 (4) | CloseSocket call. | 2021-06-24 16:15:41.880 HD Server | Thread:6968 (0) | CloseSocket call. | 2021-06-24 16:15:41.880 HD Server | Thread:6968 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 16:15:41.880 HD Server | Thread:6968 (4) | Closed. | 2021-06-24 16:15:41.880 HD Server | Thread:6968 (0) | CloseSocket call. | 2021-06-24 16:15:41.880 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6968 | 2021-06-24 16:15:41.911 HD Server Manager | Current server count=0 | 2021-06-24 16:15:41.911 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:52.240 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:52.320 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:52.425 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:52.535 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:52.645 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:52.765 ESU21-CME[M] #1 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:52.770 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:52.865 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:52.975 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:53.080 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:53.190 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:53.305 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:53.410 ESU21-CME[M] Point & Figure 1-12 #6 | BitBlt error. Windows error code 6: The handle is invalid. | 2021-06-24 16:17:53.520 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 16:18:59.520 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 16:18:59.520 HD Server | Thread:4184 (4) | Creating socket. | 2021-06-24 16:18:59.520 HD Server | Thread:4184 (4) | New receive buffer size: 262144 | 2021-06-24 16:18:59.520 HD Server | Setting DTC encoding to Binary VLS | Thread:4184 | 2021-06-24 16:18:59.520 HD Server | Thread:4184 (4) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-24 16:18:59.520 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4184 | 2021-06-24 16:18:59.520 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4184 | 2021-06-24 16:18:59.520 HD Server | HD Request #121 | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 1971-06-25 08:18:59 | ClientReqID: 121 | Username: SPRDTRDR. | Thread:4184 | 2021-06-24 16:18:59.520 Added historical Daily data request for ��U21-CM� to the queue. | 2021-06-24 16:18:59.520 Triggering next historical data download in queue. | 2021-06-24 16:18:59.520 HD Request # 52 | Downloading Historical Daily chart data for ��U21-CM�. Starting date: 1971-06-25. Service: scdataallservices | 2021-06-24 16:18:59.520 HD Request # 52 | Requesting historical Daily data for ��U21-CM� starting at 1971-06-24. SC External HD service. | 2021-06-24 16:19:00.019 HD Request # 52 | Error downloading historical Daily data for ��U21-CM�. Error executing query: Invalid symbol | 2021-06-24 16:19:00.144 HD Request # 52 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ��U21-CM� | 2021-06-24 16:19:00.144 HD Request # 52 | Completion time: 1s | 2021-06-24 16:19:00.144 HD Request # 52 | Daily data download complete for ��U21-CM�. Unique request ID: 52 | 2021-06-24 16:19:00.144 Removing historical data download ID 52. | 2021-06-24 16:19:00.144 Triggering next historical data download in queue. | 2021-06-24 16:19:00.144 No download requests in the queue to start downloads for. | 2021-06-24 16:19:00.144 HD Server | HD Request | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 0 | Error: Historical data file data not available for symbol. C:\SierraChart\Data\��U21-CM�.dly | ClientReqID: 121 | Username: SPRDTRDR. | Thread:4184 | 2021-06-24 16:19:00.534 HD Server | Thread:4184 (4) | Socket gracefully closed by remote side. | 2021-06-24 16:19:00.534 HD Server | Thread:4184 (4) | CloseSocket call. | 2021-06-24 16:19:00.534 HD Server | Thread:4184 (0) | CloseSocket call. | 2021-06-24 16:19:00.534 HD Server | Thread:4184 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 16:19:00.534 HD Server | Thread:4184 (4) | Closed. | 2021-06-24 16:19:00.534 HD Server | Thread:4184 (0) | CloseSocket call. | 2021-06-24 16:19:00.534 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4184 | 2021-06-24 16:19:00.565 HD Server Manager | Current server count=0 | 2021-06-24 16:19:00.565 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 16:20:55.203 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 16:20:55.203 HD Server | Thread:4412 (4) | Creating socket. | 2021-06-24 16:20:55.203 HD Server | Thread:4412 (4) | New receive buffer size: 262144 | 2021-06-24 16:20:55.203 HD Server | Thread:4412 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 16:20:55.203 HD Server | Setting DTC encoding to Binary VLS | Thread:4412 | 2021-06-24 16:20:55.203 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4412 | 2021-06-24 16:20:55.203 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4412 | 2021-06-24 16:20:55.203 HD Server | HD Request #122 | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 1971-06-25 08:20:55 | ClientReqID: 122 | Username: SPRDTRDR. | Thread:4412 | 2021-06-24 16:20:55.203 Added historical Daily data request for ��U21-CM� to the queue. | 2021-06-24 16:20:55.203 Triggering next historical data download in queue. | 2021-06-24 16:20:55.203 HD Request # 53 | Downloading Historical Daily chart data for ��U21-CM�. Starting date: 1971-06-25. Service: scdataallservices | 2021-06-24 16:20:55.203 HD Request # 53 | Requesting historical Daily data for ��U21-CM� starting at 1971-06-24. SC External HD service. | 2021-06-24 16:20:55.687 HD Request # 53 | Error downloading historical Daily data for ��U21-CM�. Error executing query: Invalid symbol | 2021-06-24 16:20:55.827 HD Request # 53 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ��U21-CM� | 2021-06-24 16:20:55.827 HD Request # 53 | Completion time: 0s | 2021-06-24 16:20:55.827 HD Request # 53 | Daily data download complete for ��U21-CM�. Unique request ID: 53 | 2021-06-24 16:20:55.827 Removing historical data download ID 53. | 2021-06-24 16:20:55.827 Triggering next historical data download in queue. | 2021-06-24 16:20:55.827 No download requests in the queue to start downloads for. | 2021-06-24 16:20:55.827 HD Server | HD Request | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 0 | Error: Historical data file data not available for symbol. C:\SierraChart\Data\��U21-CM�.dly | ClientReqID: 122 | Username: SPRDTRDR. | Thread:4412 | 2021-06-24 16:20:56.217 HD Server | Thread:4412 (4) | Socket gracefully closed by remote side. | 2021-06-24 16:20:56.217 HD Server | Thread:4412 (4) | CloseSocket call. | 2021-06-24 16:20:56.217 HD Server | Thread:4412 (0) | CloseSocket call. | 2021-06-24 16:20:56.217 HD Server | Thread:4412 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 16:20:56.217 HD Server | Thread:4412 (4) | Closed. | 2021-06-24 16:20:56.217 HD Server | Thread:4412 (0) | CloseSocket call. | 2021-06-24 16:20:56.217 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4412 | 2021-06-24 16:20:56.264 HD Server Manager | Current server count=0 | 2021-06-24 16:20:56.264 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 16:43:20.471 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 16:43:20.471 HD Server | Thread:3980 (4) | Creating socket. | 2021-06-24 16:43:20.471 HD Server | Thread:3980 (4) | New receive buffer size: 262144 | 2021-06-24 16:43:20.471 HD Server | Setting DTC encoding to Binary VLS | Thread:3980 | 2021-06-24 16:43:20.471 HD Server | Thread:3980 (4) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-24 16:43:20.471 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:3980 | 2021-06-24 16:43:20.471 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:3980 | 2021-06-24 16:43:20.471 HD Server | HD Request #123 | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 1971-06-25 08:43:20 | ClientReqID: 123 | Username: SPRDTRDR. | Thread:3980 | 2021-06-24 16:43:20.471 Added historical Daily data request for ��U21-CM� to the queue. | 2021-06-24 16:43:20.471 Triggering next historical data download in queue. | 2021-06-24 16:43:20.471 HD Request # 54 | Downloading Historical Daily chart data for ��U21-CM�. Starting date: 1971-06-25. Service: scdataallservices | 2021-06-24 16:43:20.471 HD Request # 54 | Requesting historical Daily data for ��U21-CM� starting at 1971-06-24. SC External HD service. | 2021-06-24 16:43:20.961 HD Request # 54 | Error downloading historical Daily data for ��U21-CM�. Error executing query: Invalid symbol | 2021-06-24 16:43:21.171 HD Request # 54 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ��U21-CM� | 2021-06-24 16:43:21.171 HD Request # 54 | Completion time: 1s | 2021-06-24 16:43:21.171 HD Request # 54 | Daily data download complete for ��U21-CM�. Unique request ID: 54 | 2021-06-24 16:43:21.171 Removing historical data download ID 54. | 2021-06-24 16:43:21.171 Triggering next historical data download in queue. | 2021-06-24 16:43:21.171 No download requests in the queue to start downloads for. | 2021-06-24 16:43:21.171 HD Server | HD Request | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 0 | Error: Historical data file data not available for symbol. C:\SierraChart\Data\��U21-CM�.dly | ClientReqID: 123 | Username: SPRDTRDR. | Thread:3980 | 2021-06-24 16:43:21.481 HD Server | Thread:3980 (4) | Socket gracefully closed by remote side. | 2021-06-24 16:43:21.481 HD Server | Thread:3980 (4) | CloseSocket call. | 2021-06-24 16:43:21.481 HD Server | Thread:3980 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 16:43:21.481 HD Server | Thread:3980 (4) | Closed. | 2021-06-24 16:43:21.481 HD Server | Thread:3980 (0) | CloseSocket call. | 2021-06-24 16:43:21.481 HD Server | Thread:3980 (0) | CloseSocket call. | 2021-06-24 16:43:21.481 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:3980 | 2021-06-24 16:43:21.591 HD Server Manager | Current server count=0 | 2021-06-24 16:43:21.591 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 16:44:09.531 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 16:44:09.531 HD Server | Thread:2320 (4) | Creating socket. | 2021-06-24 16:44:09.531 HD Server | Thread:2320 (4) | New receive buffer size: 262144 | 2021-06-24 16:44:09.531 HD Server | Thread:2320 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 16:44:09.531 HD Server | Setting DTC encoding to Binary VLS | Thread:2320 | 2021-06-24 16:44:09.531 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:2320 | 2021-06-24 16:44:09.531 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:2320 | 2021-06-24 16:44:09.531 HD Server | HD Request #124 | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 1971-06-25 08:44:09 | ClientReqID: 124 | Username: SPRDTRDR. | Thread:2320 | 2021-06-24 16:44:09.531 Added historical Daily data request for ��U21-CM� to the queue. | 2021-06-24 16:44:09.531 Triggering next historical data download in queue. | 2021-06-24 16:44:09.531 HD Request # 55 | Downloading Historical Daily chart data for ��U21-CM�. Starting date: 1971-06-25. Service: scdataallservices | 2021-06-24 16:44:09.531 HD Request # 55 | Requesting historical Daily data for ��U21-CM� starting at 1971-06-24. SC External HD service. | 2021-06-24 16:44:10.031 HD Request # 55 | Error downloading historical Daily data for ��U21-CM�. Error executing query: Invalid symbol | 2021-06-24 16:44:11.981 HD Request # 55 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ��U21-CM� | 2021-06-24 16:44:11.981 HD Request # 55 | Completion time: 2s | 2021-06-24 16:44:11.981 HD Request # 55 | Daily data download complete for ��U21-CM�. Unique request ID: 55 | 2021-06-24 16:44:11.981 Removing historical data download ID 55. | 2021-06-24 16:44:11.981 Triggering next historical data download in queue. | 2021-06-24 16:44:11.981 No download requests in the queue to start downloads for. | 2021-06-24 16:44:11.981 HD Server | HD Request | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 0 | Error: Historical data file data not available for symbol. C:\SierraChart\Data\��U21-CM�.dly | ClientReqID: 124 | Username: SPRDTRDR. | Thread:2320 | 2021-06-24 16:44:12.571 HD Server | Thread:2320 (4) | Socket gracefully closed by remote side. | 2021-06-24 16:44:12.571 HD Server | Thread:2320 (4) | CloseSocket call. | 2021-06-24 16:44:12.571 HD Server | Thread:2320 (0) | CloseSocket call. | 2021-06-24 16:44:12.571 HD Server | Thread:2320 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 16:44:12.571 HD Server | Thread:2320 (4) | Closed. | 2021-06-24 16:44:12.571 HD Server | Thread:2320 (0) | CloseSocket call. | 2021-06-24 16:44:12.571 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:2320 | 2021-06-24 16:44:12.811 HD Server Manager | Current server count=0 | 2021-06-24 16:44:12.811 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 16:44:42.397 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 16:44:42.397 HD Server | Thread:6840 (4) | Creating socket. | 2021-06-24 16:44:42.397 HD Server | Thread:6840 (4) | New receive buffer size: 262144 | 2021-06-24 16:44:42.397 HD Server | Thread:6840 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 16:44:42.397 HD Server | Setting DTC encoding to Binary VLS | Thread:6840 | 2021-06-24 16:44:42.397 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6840 | 2021-06-24 16:44:42.397 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6840 | 2021-06-24 16:44:42.397 HD Server | HD Request #125 | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 1971-06-25 08:44:42 | ClientReqID: 125 | Username: SPRDTRDR. | Thread:6840 | 2021-06-24 16:44:42.397 Added historical Daily data request for ��U21-CM� to the queue. | 2021-06-24 16:44:42.397 Triggering next historical data download in queue. | 2021-06-24 16:44:42.397 HD Request # 56 | Downloading Historical Daily chart data for ��U21-CM�. Starting date: 1971-06-25. Service: scdataallservices | 2021-06-24 16:44:42.397 HD Request # 56 | Requesting historical Daily data for ��U21-CM� starting at 1971-06-24. SC External HD service. | 2021-06-24 16:44:42.877 HD Request # 56 | Error downloading historical Daily data for ��U21-CM�. Error executing query: Invalid symbol | 2021-06-24 16:44:43.047 HD Request # 56 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ��U21-CM� | 2021-06-24 16:44:43.047 HD Request # 56 | Completion time: 1s | 2021-06-24 16:44:43.047 HD Request # 56 | Daily data download complete for ��U21-CM�. Unique request ID: 56 | 2021-06-24 16:44:43.047 Removing historical data download ID 56. | 2021-06-24 16:44:43.047 Triggering next historical data download in queue. | 2021-06-24 16:44:43.047 No download requests in the queue to start downloads for. | 2021-06-24 16:44:43.047 HD Server | HD Request | Socket: 4 | Symbol: ��U21-CM� | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 0 | Error: Historical data file data not available for symbol. C:\SierraChart\Data\��U21-CM�.dly | ClientReqID: 125 | Username: SPRDTRDR. | Thread:6840 | 2021-06-24 16:44:43.417 HD Server | Thread:6840 (4) | Socket gracefully closed by remote side. | 2021-06-24 16:44:43.417 HD Server | Thread:6840 (4) | CloseSocket call. | 2021-06-24 16:44:43.417 HD Server | Thread:6840 (0) | CloseSocket call. | 2021-06-24 16:44:43.417 HD Server | Thread:6840 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 16:44:43.417 HD Server | Thread:6840 (4) | Closed. | 2021-06-24 16:44:43.417 HD Server | Thread:6840 (0) | CloseSocket call. | 2021-06-24 16:44:43.417 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6840 | 2021-06-24 16:44:43.477 HD Server Manager | Current server count=0 | 2021-06-24 16:44:43.477 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 16:48:12.027 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 16:48:12.027 HD Server | Thread:5660 (4) | Creating socket. | 2021-06-24 16:48:12.027 HD Server | Thread:5660 (4) | New receive buffer size: 262144 | 2021-06-24 16:48:12.027 HD Server | Setting DTC encoding to Binary VLS | Thread:5660 | 2021-06-24 16:48:12.027 HD Server | Thread:5660 (4) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-24 16:48:12.027 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:5660 | 2021-06-24 16:48:12.027 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:5660 | 2021-06-24 16:48:12.027 HD Server | HD Request #126 | Socket: 4 | Symbol: ZNM21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-05-26 00:00:00 | ClientReqID: 126 | Username: SPRDTRDR. | Thread:5660 | 2021-06-24 16:48:12.027 HD Server | HD Request | Socket: 4 | Symbol: ZNM21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 126 | Username: SPRDTRDR. | Thread:5660 | 2021-06-24 16:48:12.037 HD Server | Thread:5660 (4) | Socket gracefully closed by remote side. | 2021-06-24 16:48:12.037 HD Server | Thread:5660 (4) | CloseSocket call. | 2021-06-24 16:48:12.037 HD Server | Thread:5660 (0) | CloseSocket call. | 2021-06-24 16:48:12.037 HD Server | Thread:5660 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 16:48:12.037 HD Server | Thread:5660 (4) | Closed. | 2021-06-24 16:48:12.037 HD Server | Thread:5660 (0) | CloseSocket call. | 2021-06-24 16:48:12.037 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:5660 | 2021-06-24 16:48:12.257 HD Server Manager | Current server count=0 | 2021-06-24 16:48:12.257 Added historical Daily data request for ESZ20-CME to the queue. | 2021-06-24 16:49:29.019 Triggering next historical data download in queue. | 2021-06-24 16:49:29.019 HD Request # 57 | Downloading Historical Daily chart data for ESZ20-CME. Starting date: 2020-12-16. Service: scdataallservices | 2021-06-24 16:49:29.029 HD Request # 57 | Requesting historical Daily data for ESZ20 starting at 2020-12-15. SC External HD service. | 2021-06-24 16:49:29.539 HD Request # 57 | Receiving historical Daily data for ESZ20-CME starting at 2020-12-16 | 2021-06-24 16:49:29.709 HD Request # 57 | Writing historical Daily data to the file ESZ20-CME.dly | 2021-06-24 16:49:29.709 HD Request # 57 | Bytes received: 240 | 2021-06-24 16:49:29.709 HD Request # 57 | Received 4 records from 2020-12-16 00:00:00 to 2020-12-18 00:00:00 (3.0 days) and wrote 3 records for ESZ20-CME | 2021-06-24 16:49:29.709 HD Request # 57 | Completion time: 0s | 2021-06-24 16:49:29.709 HD Request # 57 | Daily data download complete for ESZ20-CME. Unique request ID: 57 | 2021-06-24 16:49:29.709 Removing historical data download ID 57. | 2021-06-24 16:49:29.709 Triggering next historical data download in queue. | 2021-06-24 16:49:29.709 No download requests in the queue to start downloads for. | 2021-06-24 16:49:29.709 ESZ20-CME [C][M] Daily #2 | Reloading chart. | 2021-06-24 16:49:29.799 Requesting current DateTime from Sierra Chart server. | 2021-06-24 16:49:30.159 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 20:49:30.560. Round-trip delay: 00:00:00.205 | 2021-06-24 16:49:30.569 Computer time to server time difference: 00:00:00.009 | 2021-06-24 16:49:30.569 Successfully set the system Date-time to: 2021-06-24 20:49:30.560 UTC. | 2021-06-24 16:49:30.560 SC Data - All Services | Message from server: Authorization data verified. | 2021-06-24 16:49:33.140 SC DTC Delayed Exchange Data | Message from server: Authorization data verified. | 2021-06-24 16:49:33.420 SC Data - All Services | Message from server: Authorization data verified. | 2021-06-24 16:49:33.550 SC Data - All Services (Market Orders Data) | Message from server: Authorization data verified. | 2021-06-24 16:49:34.450 SC DTC Data with Market Depth | Message from server: Authorization data verified. | 2021-06-24 16:49:39.180 SC DTC Delayed Exchange Data | Real-time data for symbol VXN21-CFE is currently unavailable. | 2021-06-24 17:30:36.636 SC DTC Delayed Exchange Data | Received security definition for symbol VXN21-CFE | 2021-06-24 17:30:58.196 SC DTC Delayed Exchange Data | Real-time data for symbol VXN21-CFE has been restored. | 2021-06-24 17:30:58.196 SC Data - All Services | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-24 17:36:08.361 SC Data - All Services | Real-time data for symbol GCQ21-COMEX is currently unavailable. | 2021-06-24 17:36:08.361 SC Data - All Services | Real-time data for symbol SIN21-COMEX is currently unavailable. | 2021-06-24 17:36:08.361 SC Data - All Services (Market Orders Data) | Real-time data for symbol HGN21-COMEX is currently unavailable. | 2021-06-24 17:36:08.361 SC Data - All Services (Market Orders Data) | Real-time data for symbol GCQ21-COMEX is currently unavailable. | 2021-06-24 17:36:08.361 SC Data - All Services | Real-time data for symbol NGU21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGV21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGTN21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGQ21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGN21-NGU21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NG:SA 12M F22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGJ22-NGV22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NG:SA 07M J22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGN21-NGV21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGV21-NGF22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGN21-NGH22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol CLN21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol RBN21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol RBQ21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services | Real-time data for symbol HOQ21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGU21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGV21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGQ21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGU21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGV21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGV21-NGF22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGH22.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol CLQ21-NYMEX is currently unavailable. | 2021-06-24 17:36:10.511 SC Data - All Services (Market Orders Data) | Real-time data for symbol ZCN21-CBOT is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services (Market Orders Data) | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services (Market Orders Data) | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services | Real-time data for symbol ZBU21-CBOT is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services | Real-time data for symbol ZCN21-CBOT is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services | Real-time data for symbol ZSN21-CBOT is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services | Real-time data for symbol ZLN21-CBOT is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services | Real-time data for symbol ZWU21-CBOT is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services | Real-time data for symbol ZWN21-CBOT is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services | Real-time data for symbol ESU21-CME is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services | Real-time data for symbol 6EU21-CME is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services | Real-time data for symbol BTCM21-CME is currently unavailable. | 2021-06-24 17:36:11.421 SC Data - All Services (Market Orders Data) | Received security definition for symbol ESU21-CME | 2021-06-24 17:36:33.701 SC Data - All Services (Market Orders Data) | Real-time data for symbol ESU21-CME has been restored. | 2021-06-24 17:36:33.701 Added historical Intraday data request for ESU21-CME to the queue. | 2021-06-24 17:36:33.701 Intraday data recording state for symbol ESU21-CME is set to download 'Pending'. | 2021-06-24 17:36:33.701 Triggering next historical data download in queue. | 2021-06-24 17:36:33.701 HD Request # 58 | Downloading Intraday chart data for ESU21-CME to the file ESU21-CME.scid. Service: cme | 2021-06-24 17:36:33.701 SC Data - All Services | Clearing market depth for ESU21-CME | 2021-06-24 17:36:33.701 HD Request # 58 | Download start date-time: 2021-06-24 16:59:59.000000. File last date-time: 2021-06-24 16:59:59.765000 | 2021-06-24 17:36:33.701 HD Request # 58 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:33.711 SC Data - All Services | Received security definition for symbol ESU21-CME | 2021-06-24 17:36:33.711 SC Data - All Services | Real-time data for symbol ESU21-CME has been restored. | 2021-06-24 17:36:33.711 Socket (4) | Creating socket. | 2021-06-24 17:36:33.721 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:33.721 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:33.721 HD Request # 58 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:33.871 HD Request # 58 | Sending historical data logon request message. | 2021-06-24 17:36:33.871 SC Data - All Services | Received security definition for symbol 6EU21-CME | 2021-06-24 17:36:35.701 SC Data - All Services | Real-time data for symbol 6EU21-CME has been restored. | 2021-06-24 17:36:35.701 HD Request # 58 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:59. Record interval: 0. Symbol: ESU21 | 2021-06-24 17:36:36.391 HD Request # 58 | Decompressing data. | 2021-06-24 17:36:36.421 HD Request # 58 | Receiving Intraday data for ESU21-CME starting at 2021-06-24 16:59:59.407000 | 2021-06-24 17:36:36.421 Socket (4) | CloseSocket call. | 2021-06-24 17:36:36.421 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:36.421 Historical data download thread signaled to stop. | 2021-06-24 17:36:36.431 HD Request # 58 | Received 6 records from 2021-06-24 16:59:59.407000 to 2021-06-24 16:59:59.765000 (0.4 seconds) and wrote 0 records for ESU21-CME | 2021-06-24 17:36:36.431 HD Request # 58 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:59.765000 | 2021-06-24 17:36:36.431 HD Request # 58 | Completion time: 3s | 2021-06-24 17:36:36.431 HD Request # 58 | Intraday data download complete for ESU21-CME. Unique request ID: 58 | 2021-06-24 17:36:36.431 Removing historical data download ID 58. | 2021-06-24 17:36:36.431 Real-time Intraday chart data file updates started for ESU21-CME | 2021-06-24 17:36:36.431 Intraday chart data file opened for ESU21-CME | 2021-06-24 17:36:36.431 HD Request # 58 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:36.431 Triggering next historical data download in queue. | 2021-06-24 17:36:36.431 No download requests in the queue to start downloads for. | 2021-06-24 17:36:36.431 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:36.441 Socket (4) | Closed. | 2021-06-24 17:36:36.441 SC Data - All Services | Received security definition for symbol ZBU21-CBOT | 2021-06-24 17:36:37.581 SC Data - All Services | Real-time data for symbol ZBU21-CBOT has been restored. | 2021-06-24 17:36:37.581 SC Data - All Services (Market Orders Data) | Received security definition for symbol ZCN21-CBOT | 2021-06-24 17:36:41.611 SC Data - All Services (Market Orders Data) | Real-time data for symbol ZCN21-CBOT has been restored. | 2021-06-24 17:36:41.611 Added historical Intraday data request for ZCN21-CBOT to the queue. | 2021-06-24 17:36:41.621 Intraday data recording state for symbol ZCN21-CBOT is set to download 'Pending'. | 2021-06-24 17:36:41.621 Triggering next historical data download in queue. | 2021-06-24 17:36:41.621 SC Data - All Services (Market Orders Data) | Received security definition for symbol ZSN21-CBOT | 2021-06-24 17:36:41.621 SC Data - All Services (Market Orders Data) | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-24 17:36:41.621 Added historical Intraday data request for ZSN21-CBOT to the queue. | 2021-06-24 17:36:41.621 Intraday data recording state for symbol ZSN21-CBOT is set to download 'Pending'. | 2021-06-24 17:36:41.621 HD Request # 59 | Downloading Intraday chart data for ZCN21-CBOT to the file ZCN21-CBOT.scid. Service: cbot | 2021-06-24 17:36:41.621 HD Request # 59 | Download start date-time: 2021-06-24 14:19:59.000000. File last date-time: 2021-06-24 14:19:59.018002 | 2021-06-24 17:36:41.621 HD Request # 59 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:41.621 SC Data - All Services | Received security definition for symbol ZCN21-CBOT | 2021-06-24 17:36:41.621 SC Data - All Services | Real-time data for symbol ZCN21-CBOT has been restored. | 2021-06-24 17:36:41.621 SC Data - All Services | Received security definition for symbol ZSN21-CBOT | 2021-06-24 17:36:41.621 SC Data - All Services | Real-time data for symbol ZSN21-CBOT has been restored. | 2021-06-24 17:36:41.621 SC Data - All Services | Received security definition for symbol ZLN21-CBOT | 2021-06-24 17:36:41.621 SC Data - All Services | Real-time data for symbol ZLN21-CBOT has been restored. | 2021-06-24 17:36:41.621 SC Data - All Services | Received security definition for symbol ZWU21-CBOT | 2021-06-24 17:36:41.621 SC Data - All Services | Real-time data for symbol ZWU21-CBOT has been restored. | 2021-06-24 17:36:41.621 SC Data - All Services | Received security definition for symbol ZWN21-CBOT | 2021-06-24 17:36:41.621 SC Data - All Services | Real-time data for symbol ZWN21-CBOT has been restored. | 2021-06-24 17:36:41.621 Socket (4) | Creating socket. | 2021-06-24 17:36:41.621 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:41.621 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:41.621 Added historical Intraday data request for ZWN21-CBOT to the queue. | 2021-06-24 17:36:41.631 Intraday data recording state for symbol ZWN21-CBOT is set to download 'Pending'. | 2021-06-24 17:36:41.631 Triggering next historical data download in queue. | 2021-06-24 17:36:41.631 HD Request # 59 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:41.711 HD Request # 59 | Sending historical data logon request message. | 2021-06-24 17:36:41.711 SC Data - All Services | Clearing market depth for ZSN21-CBOT | 2021-06-24 17:36:41.771 SC Data - All Services (Market Orders Data) | Received security definition for symbol CLQ21-NYMEX | 2021-06-24 17:36:51.651 SC Data - All Services (Market Orders Data) | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-24 17:36:51.651 Added historical Intraday data request for CLQ21-NYMEX to the queue. | 2021-06-24 17:36:51.661 Intraday data recording state for symbol CLQ21-NYMEX is set to download 'Pending'. | 2021-06-24 17:36:51.661 Triggering next historical data download in queue. | 2021-06-24 17:36:51.661 SC Data - All Services | Received security definition for symbol RBN21-NYMEX | 2021-06-24 17:36:51.661 SC Data - All Services | Real-time data for symbol RBN21-NYMEX has been restored. | 2021-06-24 17:36:51.661 Added historical Intraday data request for RBN21-NYMEX to the queue. | 2021-06-24 17:36:51.671 Intraday data recording state for symbol RBN21-NYMEX is set to download 'Pending'. | 2021-06-24 17:36:51.671 Triggering next historical data download in queue. | 2021-06-24 17:36:51.671 SC Data - All Services | Received security definition for symbol CLQ21-NYMEX | 2021-06-24 17:36:51.671 SC Data - All Services | Real-time data for symbol CLQ21-NYMEX has been restored. | 2021-06-24 17:36:51.671 SC Data - All Services | Received security definition for symbol RBQ21-NYMEX | 2021-06-24 17:36:51.671 SC Data - All Services | Real-time data for symbol RBQ21-NYMEX has been restored. | 2021-06-24 17:36:51.671 SC Data - All Services | Received security definition for symbol HOQ21-NYMEX | 2021-06-24 17:36:51.671 SC Data - All Services | Real-time data for symbol HOQ21-NYMEX has been restored. | 2021-06-24 17:36:51.671 SC Data - All Services | Received security definition for symbol NGU21-NYMEX | 2021-06-24 17:36:52.131 SC Data - All Services | Real-time data for symbol NGU21-NYMEX has been restored. | 2021-06-24 17:36:52.131 Added historical Intraday data request for NGU21-NYMEX to the queue. | 2021-06-24 17:36:52.141 Intraday data recording state for symbol NGU21-NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.141 Triggering next historical data download in queue. | 2021-06-24 17:36:52.141 SC Data - All Services | Received security definition for symbol NGV21-NYMEX | 2021-06-24 17:36:52.141 SC Data - All Services | Real-time data for symbol NGV21-NYMEX has been restored. | 2021-06-24 17:36:52.141 SC Data - All Services | Received security definition for symbol NGTN21-NYMEX | 2021-06-24 17:36:52.141 SC Data - All Services | Real-time data for symbol NGTN21-NYMEX has been restored. | 2021-06-24 17:36:52.141 Added historical Intraday data request for NGTN21-NYMEX to the queue. | 2021-06-24 17:36:52.141 Intraday data recording state for symbol NGTN21-NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.141 SC Data - All Services | Received security definition for symbol NGN21-NYMEX | 2021-06-24 17:36:52.141 SC Data - All Services | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-24 17:36:52.141 Added historical Intraday data request for NGN21-NYMEX to the queue. | 2021-06-24 17:36:52.151 Intraday data recording state for symbol NGN21-NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.151 SC Data - All Services | Received security definition for symbol NGQ21-NYMEX | 2021-06-24 17:36:52.151 SC Data - All Services | Real-time data for symbol NGQ21-NYMEX has been restored. | 2021-06-24 17:36:52.151 Added historical Intraday data request for NGQ21-NYMEX to the queue. | 2021-06-24 17:36:52.151 Intraday data recording state for symbol NGQ21-NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.151 SC Data - All Services | Received security definition for symbol NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.151 SC Data - All Services | Real-time data for symbol NGN21-NGU21.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.151 Added historical Intraday data request for NGN21-NGU21.FUT_SPREAD.NYMEX to the queue. | 2021-06-24 17:36:52.151 Intraday data recording state for symbol NGN21-NGU21.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.151 SC Data - All Services | Received security definition for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.151 SC Data - All Services | Real-time data for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.151 Added historical Intraday data request for NGH22-NGJ22.FUT_SPREAD.NYMEX to the queue. | 2021-06-24 17:36:52.151 Intraday data recording state for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGU21-NYMEX | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGU21-NYMEX has been restored. | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGV21-NYMEX | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGV21-NYMEX has been restored. | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NYMEX | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NYMEX has been restored. | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGQ21-NYMEX | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGQ21-NYMEX has been restored. | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGU21.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.151 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGH22-NGJ22.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.151 SC Data - All Services | Received security definition for symbol NG:SA 12M F22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.221 SC Data - All Services | Real-time data for symbol NG:SA 12M F22.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.221 SC Data - All Services | Received security definition for symbol NGJ22-NGV22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.221 SC Data - All Services | Real-time data for symbol NGJ22-NGV22.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.221 SC Data - All Services | Received security definition for symbol NG:SA 07M J22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.221 SC Data - All Services | Real-time data for symbol NG:SA 07M J22.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.221 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.311 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGV21.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.311 Added historical Intraday data request for NGN21-NGV21.FUT_SPREAD.NYMEX to the queue. | 2021-06-24 17:36:52.321 Intraday data recording state for symbol NGN21-NGV21.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.321 Triggering next historical data download in queue. | 2021-06-24 17:36:52.321 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.321 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGV21-NGF22.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.321 Added historical Intraday data request for NGV21-NGF22.FUT_SPREAD.NYMEX to the queue. | 2021-06-24 17:36:52.331 Intraday data recording state for symbol NGV21-NGF22.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.331 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.331 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGH22.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.331 Added historical Intraday data request for NGN21-NGH22.FUT_SPREAD.NYMEX to the queue. | 2021-06-24 17:36:52.331 Intraday data recording state for symbol NGN21-NGH22.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.331 SC Data - All Services (Market Orders Data) | Received security definition for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.331 SC Data - All Services (Market Orders Data) | Real-time data for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.331 Added historical Intraday data request for NGN21-NGQ21.FUT_SPREAD.NYMEX to the queue. | 2021-06-24 17:36:52.341 Intraday data recording state for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX is set to download 'Pending'. | 2021-06-24 17:36:52.341 SC Data - All Services | Received security definition for symbol NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Real-time data for symbol NGN21-NGV21.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.341 SC Data - All Services | Received security definition for symbol NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Real-time data for symbol NGV21-NGF22.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.341 SC Data - All Services | Received security definition for symbol NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Real-time data for symbol NGN21-NGH22.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.341 SC Data - All Services | Clearing market depth for CLQ21-NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Clearing market depth for NGU21-NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Clearing market depth for NGV21-NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Clearing market depth for NGN21-NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Clearing market depth for NGQ21-NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Clearing market depth for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Received security definition for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:52.341 SC Data - All Services | Real-time data for symbol NGN21-NGQ21.FUT_SPREAD.NYMEX has been restored. | 2021-06-24 17:36:52.341 HD Request # 59 | Requesting Intraday data. Start date-time: 2021-06-24 14:19:59. Record interval: 0. Symbol: ZCN21 | 2021-06-24 17:36:52.851 HD Request # 59 | Decompressing data. | 2021-06-24 17:36:52.871 HD Request # 59 | Receiving Intraday data for ZCN21-CBOT starting at 2021-06-24 14:19:59.018000 | 2021-06-24 17:36:52.871 Socket (4) | CloseSocket call. | 2021-06-24 17:36:52.871 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:52.871 Historical data download thread signaled to stop. | 2021-06-24 17:36:52.871 HD Request # 59 | Received 3 records from 2021-06-24 14:19:59.018000 to 2021-06-24 14:19:59.018002 (0.0 seconds) and wrote 0 records for ZCN21-CBOT | 2021-06-24 17:36:52.871 HD Request # 59 | Add time&sales data | Remembered last file record date-time: 2021-06-24 18:19:59.018002 | 2021-06-24 17:36:52.871 HD Request # 59 | Completion time: 11s | 2021-06-24 17:36:52.871 HD Request # 59 | Intraday data download complete for ZCN21-CBOT. Unique request ID: 59 | 2021-06-24 17:36:52.871 Removing historical data download ID 59. | 2021-06-24 17:36:52.871 Real-time Intraday chart data file updates started for ZCN21-CBOT | 2021-06-24 17:36:52.871 Intraday chart data file opened for ZCN21-CBOT | 2021-06-24 17:36:52.871 HD Request # 59 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:52.871 Triggering next historical data download in queue. | 2021-06-24 17:36:52.871 HD Request # 60 | Downloading Intraday chart data for ZSN21-CBOT to the file ZSN21-CBOT.scid. Service: cbot | 2021-06-24 17:36:52.871 HD Request # 60 | Download start date-time: 2021-06-24 14:19:58.000000. File last date-time: 2021-06-24 14:19:58.782000 | 2021-06-24 17:36:52.871 HD Request # 60 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:52.871 Socket (9) | Creating socket. | 2021-06-24 17:36:52.871 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 17:36:52.881 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:52.881 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:52.901 Socket (4) | Closed. | 2021-06-24 17:36:52.901 HD Request # 60 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:52.931 HD Request # 60 | Sending historical data logon request message. | 2021-06-24 17:36:52.931 HD Request # 60 | Requesting Intraday data. Start date-time: 2021-06-24 14:19:58. Record interval: 0. Symbol: ZSN21 | 2021-06-24 17:36:52.961 HD Request # 60 | Decompressing data. | 2021-06-24 17:36:52.981 HD Request # 60 | Receiving Intraday data for ZSN21-CBOT starting at 2021-06-24 14:19:58.021000 | 2021-06-24 17:36:52.981 Socket (9) | CloseSocket call. | 2021-06-24 17:36:52.981 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:52.981 Historical data download thread signaled to stop. | 2021-06-24 17:36:52.981 HD Request # 60 | Received 3 records from 2021-06-24 14:19:58.021000 to 2021-06-24 14:19:58.782000 (0.8 seconds) and wrote 0 records for ZSN21-CBOT | 2021-06-24 17:36:52.981 HD Request # 60 | Add time&sales data | Remembered last file record date-time: 2021-06-24 18:19:58.782000 | 2021-06-24 17:36:52.981 HD Request # 60 | Completion time: 0s | 2021-06-24 17:36:52.981 HD Request # 60 | Intraday data download complete for ZSN21-CBOT. Unique request ID: 60 | 2021-06-24 17:36:52.981 Removing historical data download ID 60. | 2021-06-24 17:36:52.981 Real-time Intraday chart data file updates started for ZSN21-CBOT | 2021-06-24 17:36:52.981 Intraday chart data file opened for ZSN21-CBOT | 2021-06-24 17:36:52.981 HD Request # 60 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:52.981 Triggering next historical data download in queue. | 2021-06-24 17:36:52.981 HD Request # 61 | Downloading Intraday chart data for ZWN21-CBOT to the file ZWN21-CBOT.scid. Service: cbot | 2021-06-24 17:36:52.981 HD Request # 61 | Download start date-time: 2021-06-24 14:19:59.000000. File last date-time: 2021-06-24 14:19:59.257000 | 2021-06-24 17:36:52.991 HD Request # 61 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:52.991 Socket (4) | Creating socket. | 2021-06-24 17:36:52.991 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:52.991 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:52.991 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 17:36:53.011 Socket (9) | Closed. | 2021-06-24 17:36:53.011 HD Request # 61 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:53.061 HD Request # 61 | Sending historical data logon request message. | 2021-06-24 17:36:53.061 HD Request # 61 | Requesting Intraday data. Start date-time: 2021-06-24 14:19:59. Record interval: 0. Symbol: ZWN21 | 2021-06-24 17:36:53.091 HD Request # 61 | Decompressing data. | 2021-06-24 17:36:53.121 HD Request # 61 | Receiving Intraday data for ZWN21-CBOT starting at 2021-06-24 14:19:59.252000 | 2021-06-24 17:36:53.121 Socket (4) | CloseSocket call. | 2021-06-24 17:36:53.121 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:53.121 Historical data download thread signaled to stop. | 2021-06-24 17:36:53.121 HD Request # 61 | Received 2 records from 2021-06-24 14:19:59.252000 to 2021-06-24 14:19:59.257000 (0.0 seconds) and wrote 0 records for ZWN21-CBOT | 2021-06-24 17:36:53.121 HD Request # 61 | Add time&sales data | Remembered last file record date-time: 2021-06-24 18:19:59.257000 | 2021-06-24 17:36:53.121 HD Request # 61 | Completion time: 1s | 2021-06-24 17:36:53.121 HD Request # 61 | Intraday data download complete for ZWN21-CBOT. Unique request ID: 61 | 2021-06-24 17:36:53.121 Removing historical data download ID 61. | 2021-06-24 17:36:53.121 Real-time Intraday chart data file updates started for ZWN21-CBOT | 2021-06-24 17:36:53.121 Intraday chart data file opened for ZWN21-CBOT | 2021-06-24 17:36:53.121 HD Request # 61 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:53.121 Triggering next historical data download in queue. | 2021-06-24 17:36:53.121 HD Request # 62 | Downloading Intraday chart data for CLQ21-NYMEX to the file CLQ21-NYMEX.scid. Service: nymex | 2021-06-24 17:36:53.121 HD Request # 62 | Download start date-time: 2021-06-24 16:59:59.000000. File last date-time: 2021-06-24 16:59:59.024002 | 2021-06-24 17:36:53.121 HD Request # 62 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:53.121 Socket (9) | Creating socket. | 2021-06-24 17:36:53.121 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 17:36:53.121 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:53.121 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:53.151 Socket (4) | Closed. | 2021-06-24 17:36:53.151 HD Request # 62 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:53.191 HD Request # 62 | Sending historical data logon request message. | 2021-06-24 17:36:53.191 HD Request # 62 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:59. Record interval: 0. Symbol: CLQ21 | 2021-06-24 17:36:53.221 HD Request # 62 | Decompressing data. | 2021-06-24 17:36:53.241 HD Request # 62 | Receiving Intraday data for CLQ21-NYMEX starting at 2021-06-24 16:59:59.024000 | 2021-06-24 17:36:53.251 Socket (9) | CloseSocket call. | 2021-06-24 17:36:53.251 Historical data download thread signaled to stop. | 2021-06-24 17:36:53.251 HD Request # 62 | Received 3 records from 2021-06-24 16:59:59.024000 to 2021-06-24 16:59:59.024002 (0.0 seconds) and wrote 0 records for CLQ21-NYMEX | 2021-06-24 17:36:53.251 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:53.251 HD Request # 62 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:59.024002 | 2021-06-24 17:36:53.251 HD Request # 62 | Completion time: 0s | 2021-06-24 17:36:53.251 HD Request # 62 | Intraday data download complete for CLQ21-NYMEX. Unique request ID: 62 | 2021-06-24 17:36:53.251 Removing historical data download ID 62. | 2021-06-24 17:36:53.251 Real-time Intraday chart data file updates started for CLQ21-NYMEX | 2021-06-24 17:36:53.251 Intraday chart data file opened for CLQ21-NYMEX | 2021-06-24 17:36:53.251 HD Request # 62 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:53.251 Triggering next historical data download in queue. | 2021-06-24 17:36:53.251 HD Request # 63 | Downloading Intraday chart data for RBN21-NYMEX to the file RBN21-NYMEX.scid. Service: nymex | 2021-06-24 17:36:53.251 HD Request # 63 | Download start date-time: 2021-06-24 16:58:42.000000. File last date-time: 2021-06-24 16:58:42.120000 | 2021-06-24 17:36:53.251 HD Request # 63 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:53.251 Socket (4) | Creating socket. | 2021-06-24 17:36:53.251 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:53.251 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:53.251 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 17:36:53.271 Socket (9) | Closed. | 2021-06-24 17:36:53.271 HD Request # 63 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:53.311 HD Request # 63 | Sending historical data logon request message. | 2021-06-24 17:36:53.311 HD Request # 63 | Requesting Intraday data. Start date-time: 2021-06-24 16:58:42. Record interval: 0. Symbol: RBN21 | 2021-06-24 17:36:53.341 HD Request # 63 | Decompressing data. | 2021-06-24 17:36:53.381 HD Request # 63 | Receiving Intraday data for RBN21-NYMEX starting at 2021-06-24 16:58:42.120000 | 2021-06-24 17:36:53.381 Socket (4) | CloseSocket call. | 2021-06-24 17:36:53.381 Historical data download thread signaled to stop. | 2021-06-24 17:36:53.381 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:53.381 HD Request # 63 | Received 1 record from 2021-06-24 16:58:42.120000 to 2021-06-24 16:58:42.120000 (0.0 seconds) and wrote 0 records for RBN21-NYMEX | 2021-06-24 17:36:53.381 HD Request # 63 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:58:42.120000 | 2021-06-24 17:36:53.381 HD Request # 63 | Completion time: 0s | 2021-06-24 17:36:53.381 HD Request # 63 | Intraday data download complete for RBN21-NYMEX. Unique request ID: 63 | 2021-06-24 17:36:53.381 Removing historical data download ID 63. | 2021-06-24 17:36:53.381 Real-time Intraday chart data file updates started for RBN21-NYMEX | 2021-06-24 17:36:53.381 Intraday chart data file opened for RBN21-NYMEX | 2021-06-24 17:36:53.381 HD Request # 63 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:53.381 Triggering next historical data download in queue. | 2021-06-24 17:36:53.381 HD Request # 64 | Downloading Intraday chart data for NGU21-NYMEX to the file NGU21-NYMEX.scid. Service: nymex | 2021-06-24 17:36:53.381 HD Request # 64 | Download start date-time: 2021-06-24 16:59:36.000000. File last date-time: 2021-06-24 16:59:36.259000 | 2021-06-24 17:36:53.381 HD Request # 64 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:53.381 Socket (9) | Creating socket. | 2021-06-24 17:36:53.381 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 17:36:53.381 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:53.381 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:53.411 Socket (4) | Closed. | 2021-06-24 17:36:53.411 HD Request # 64 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:53.441 HD Request # 64 | Sending historical data logon request message. | 2021-06-24 17:36:53.441 HD Request # 64 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:36. Record interval: 0. Symbol: NGU21 | 2021-06-24 17:36:53.471 HD Request # 64 | Decompressing data. | 2021-06-24 17:36:53.501 HD Request # 64 | Receiving Intraday data for NGU21-NYMEX starting at 2021-06-24 16:59:36.259000 | 2021-06-24 17:36:53.501 Socket (9) | CloseSocket call. | 2021-06-24 17:36:53.501 Historical data download thread signaled to stop. | 2021-06-24 17:36:53.501 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:53.501 HD Request # 64 | Received 1 record from 2021-06-24 16:59:36.259000 to 2021-06-24 16:59:36.259000 (0.0 seconds) and wrote 0 records for NGU21-NYMEX | 2021-06-24 17:36:53.501 HD Request # 64 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:36.259000 | 2021-06-24 17:36:53.501 HD Request # 64 | Completion time: 0s | 2021-06-24 17:36:53.501 HD Request # 64 | Intraday data download complete for NGU21-NYMEX. Unique request ID: 64 | 2021-06-24 17:36:53.501 Removing historical data download ID 64. | 2021-06-24 17:36:53.501 Real-time Intraday chart data file updates started for NGU21-NYMEX | 2021-06-24 17:36:53.501 Intraday chart data file opened for NGU21-NYMEX | 2021-06-24 17:36:53.501 HD Request # 64 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:53.501 Triggering next historical data download in queue. | 2021-06-24 17:36:53.501 HD Request # 65 | Downloading Intraday chart data for NGTN21-NYMEX to the file NGTN21-NYMEX.scid. Service: nymex | 2021-06-24 17:36:53.501 HD Request # 65 | Download start date-time: 2021-06-24 14:29:48.000000. File last date-time: 2021-06-24 14:29:48.599000 | 2021-06-24 17:36:53.501 HD Request # 65 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:53.501 Socket (4) | Creating socket. | 2021-06-24 17:36:53.501 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:53.501 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:53.501 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 17:36:53.521 Socket (9) | Closed. | 2021-06-24 17:36:53.521 HD Request # 65 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:53.571 HD Request # 65 | Sending historical data logon request message. | 2021-06-24 17:36:53.571 HD Request # 65 | Requesting Intraday data. Start date-time: 2021-06-24 14:29:48. Record interval: 0. Symbol: NGTN21 | 2021-06-24 17:36:53.591 HD Request # 65 | Decompressing data. | 2021-06-24 17:36:53.621 HD Request # 65 | Receiving Intraday data for NGTN21-NYMEX starting at 2021-06-24 14:29:48.599000 | 2021-06-24 17:36:53.621 Socket (4) | CloseSocket call. | 2021-06-24 17:36:53.621 Historical data download thread signaled to stop. | 2021-06-24 17:36:53.621 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:53.621 HD Request # 65 | Received 1 record from 2021-06-24 14:29:48.599000 to 2021-06-24 14:29:48.599000 (0.0 seconds) and wrote 0 records for NGTN21-NYMEX | 2021-06-24 17:36:53.621 HD Request # 65 | Add time&sales data | Remembered last file record date-time: 2021-06-24 18:29:48.599000 | 2021-06-24 17:36:53.621 HD Request # 65 | Completion time: 0s | 2021-06-24 17:36:53.621 HD Request # 65 | Intraday data download complete for NGTN21-NYMEX. Unique request ID: 65 | 2021-06-24 17:36:53.621 Removing historical data download ID 65. | 2021-06-24 17:36:53.621 Real-time Intraday chart data file updates started for NGTN21-NYMEX | 2021-06-24 17:36:53.621 Intraday chart data file opened for NGTN21-NYMEX | 2021-06-24 17:36:53.621 HD Request # 65 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:53.621 Triggering next historical data download in queue. | 2021-06-24 17:36:53.621 HD Request # 66 | Downloading Intraday chart data for NGN21-NYMEX to the file NGN21-NYMEX.scid. Service: nymex | 2021-06-24 17:36:53.621 HD Request # 66 | Download start date-time: 2021-06-24 16:59:36.000000. File last date-time: 2021-06-24 16:59:36.259000 | 2021-06-24 17:36:53.621 HD Request # 66 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:53.621 Socket (9) | Creating socket. | 2021-06-24 17:36:53.621 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 17:36:53.621 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:53.621 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:53.651 Socket (4) | Closed. | 2021-06-24 17:36:53.651 HD Request # 66 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:53.681 HD Request # 66 | Sending historical data logon request message. | 2021-06-24 17:36:53.681 HD Request # 66 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:36. Record interval: 0. Symbol: NGN21 | 2021-06-24 17:36:53.711 HD Request # 66 | Decompressing data. | 2021-06-24 17:36:53.731 HD Request # 66 | Receiving Intraday data for NGN21-NYMEX starting at 2021-06-24 16:59:36.259000 | 2021-06-24 17:36:53.731 Socket (9) | CloseSocket call. | 2021-06-24 17:36:53.731 Historical data download thread signaled to stop. | 2021-06-24 17:36:53.731 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:53.731 HD Request # 66 | Received 1 record from 2021-06-24 16:59:36.259000 to 2021-06-24 16:59:36.259000 (0.0 seconds) and wrote 0 records for NGN21-NYMEX | 2021-06-24 17:36:53.741 HD Request # 66 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:36.259000 | 2021-06-24 17:36:53.741 HD Request # 66 | Completion time: 0s | 2021-06-24 17:36:53.741 HD Request # 66 | Intraday data download complete for NGN21-NYMEX. Unique request ID: 66 | 2021-06-24 17:36:53.741 Removing historical data download ID 66. | 2021-06-24 17:36:53.741 Real-time Intraday chart data file updates started for NGN21-NYMEX | 2021-06-24 17:36:53.741 Intraday chart data file opened for NGN21-NYMEX | 2021-06-24 17:36:53.741 HD Request # 66 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:53.741 Triggering next historical data download in queue. | 2021-06-24 17:36:53.741 HD Request # 67 | Downloading Intraday chart data for NGQ21-NYMEX to the file NGQ21-NYMEX.scid. Service: nymex | 2021-06-24 17:36:53.741 HD Request # 67 | Download start date-time: 2021-06-24 16:59:58.000000. File last date-time: 2021-06-24 16:59:58.124000 | 2021-06-24 17:36:53.741 HD Request # 67 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:53.741 Socket (4) | Creating socket. | 2021-06-24 17:36:53.741 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:53.741 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:53.741 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 17:36:53.761 Socket (9) | Closed. | 2021-06-24 17:36:53.761 HD Request # 67 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:53.801 HD Request # 67 | Sending historical data logon request message. | 2021-06-24 17:36:53.801 HD Request # 67 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:58. Record interval: 0. Symbol: NGQ21 | 2021-06-24 17:36:53.831 HD Request # 67 | Decompressing data. | 2021-06-24 17:36:53.861 HD Request # 67 | Receiving Intraday data for NGQ21-NYMEX starting at 2021-06-24 16:59:58.124000 | 2021-06-24 17:36:53.861 Socket (4) | CloseSocket call. | 2021-06-24 17:36:53.861 Historical data download thread signaled to stop. | 2021-06-24 17:36:53.861 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:53.861 HD Request # 67 | Received 1 record from 2021-06-24 16:59:58.124000 to 2021-06-24 16:59:58.124000 (0.0 seconds) and wrote 0 records for NGQ21-NYMEX | 2021-06-24 17:36:53.861 HD Request # 67 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:58.124000 | 2021-06-24 17:36:53.861 HD Request # 67 | Completion time: 0s | 2021-06-24 17:36:53.861 HD Request # 67 | Intraday data download complete for NGQ21-NYMEX. Unique request ID: 67 | 2021-06-24 17:36:53.861 Removing historical data download ID 67. | 2021-06-24 17:36:53.861 Real-time Intraday chart data file updates started for NGQ21-NYMEX | 2021-06-24 17:36:53.861 Intraday chart data file opened for NGQ21-NYMEX | 2021-06-24 17:36:53.861 HD Request # 67 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:53.861 Triggering next historical data download in queue. | 2021-06-24 17:36:53.861 HD Request # 68 | Downloading Intraday chart data for NGN21-NGU21.FUT_SPREAD.NYMEX to the file NGN21-NGU21.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-24 17:36:53.861 HD Request # 68 | Download start date-time: 2021-06-24 16:59:36.000000. File last date-time: 2021-06-24 16:59:36.259000 | 2021-06-24 17:36:53.861 HD Request # 68 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:53.861 Socket (9) | Creating socket. | 2021-06-24 17:36:53.861 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 17:36:53.861 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:53.861 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:53.881 Socket (4) | Closed. | 2021-06-24 17:36:53.881 HD Request # 68 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:53.911 HD Request # 68 | Sending historical data logon request message. | 2021-06-24 17:36:53.911 HD Request # 68 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:36. Record interval: 0. Symbol: NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:53.941 HD Request # 68 | Decompressing data. | 2021-06-24 17:36:53.971 HD Request # 68 | Receiving Intraday data for NGN21-NGU21.FUT_SPREAD.NYMEX starting at 2021-06-24 16:59:36.259000 | 2021-06-24 17:36:53.971 Socket (9) | CloseSocket call. | 2021-06-24 17:36:53.971 Historical data download thread signaled to stop. | 2021-06-24 17:36:53.971 HD Request # 68 | Received 1 record from 2021-06-24 16:59:36.259000 to 2021-06-24 16:59:36.259000 (0.0 seconds) and wrote 0 records for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:53.971 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:53.971 HD Request # 68 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:36.259000 | 2021-06-24 17:36:53.971 HD Request # 68 | Completion time: 0s | 2021-06-24 17:36:53.971 HD Request # 68 | Intraday data download complete for NGN21-NGU21.FUT_SPREAD.NYMEX. Unique request ID: 68 | 2021-06-24 17:36:53.971 Removing historical data download ID 68. | 2021-06-24 17:36:53.971 Real-time Intraday chart data file updates started for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:53.971 Intraday chart data file opened for NGN21-NGU21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:53.971 HD Request # 68 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:53.971 Triggering next historical data download in queue. | 2021-06-24 17:36:53.971 HD Request # 69 | Downloading Intraday chart data for NGH22-NGJ22.FUT_SPREAD.NYMEX to the file NGH22-NGJ22.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-24 17:36:53.971 HD Request # 69 | Download start date-time: 2021-06-24 16:55:57.000000. File last date-time: 2021-06-24 16:55:57.747000 | 2021-06-24 17:36:53.971 HD Request # 69 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:53.971 Socket (4) | Creating socket. | 2021-06-24 17:36:53.971 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:53.971 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:53.971 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 17:36:53.991 Socket (9) | Closed. | 2021-06-24 17:36:53.991 HD Request # 69 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:54.041 HD Request # 69 | Sending historical data logon request message. | 2021-06-24 17:36:54.041 HD Request # 69 | Requesting Intraday data. Start date-time: 2021-06-24 16:55:57. Record interval: 0. Symbol: NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.071 HD Request # 69 | Decompressing data. | 2021-06-24 17:36:54.101 HD Request # 69 | Receiving Intraday data for NGH22-NGJ22.FUT_SPREAD.NYMEX starting at 2021-06-24 16:55:57.246000 | 2021-06-24 17:36:54.101 Socket (4) | CloseSocket call. | 2021-06-24 17:36:54.101 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:54.101 Historical data download thread signaled to stop. | 2021-06-24 17:36:54.101 HD Request # 69 | Received 2 records from 2021-06-24 16:55:57.246000 to 2021-06-24 16:55:57.747000 (0.5 seconds) and wrote 0 records for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.101 HD Request # 69 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:55:57.747000 | 2021-06-24 17:36:54.101 HD Request # 69 | Completion time: 1s | 2021-06-24 17:36:54.101 HD Request # 69 | Intraday data download complete for NGH22-NGJ22.FUT_SPREAD.NYMEX. Unique request ID: 69 | 2021-06-24 17:36:54.101 Removing historical data download ID 69. | 2021-06-24 17:36:54.101 Real-time Intraday chart data file updates started for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.101 Intraday chart data file opened for NGH22-NGJ22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.101 HD Request # 69 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:54.101 Triggering next historical data download in queue. | 2021-06-24 17:36:54.101 HD Request # 70 | Downloading Intraday chart data for NGN21-NGV21.FUT_SPREAD.NYMEX to the file NGN21-NGV21.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-24 17:36:54.101 HD Request # 70 | Download start date-time: 2021-06-24 16:44:26.000000. File last date-time: 2021-06-24 16:44:26.088000 | 2021-06-24 17:36:54.101 HD Request # 70 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:54.101 Socket (9) | Creating socket. | 2021-06-24 17:36:54.101 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 17:36:54.101 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:54.101 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:54.131 Socket (4) | Closed. | 2021-06-24 17:36:54.131 HD Request # 70 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:54.171 HD Request # 70 | Sending historical data logon request message. | 2021-06-24 17:36:54.171 HD Request # 70 | Requesting Intraday data. Start date-time: 2021-06-24 16:44:26. Record interval: 0. Symbol: NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.201 HD Request # 70 | Decompressing data. | 2021-06-24 17:36:54.231 HD Request # 70 | Receiving Intraday data for NGN21-NGV21.FUT_SPREAD.NYMEX starting at 2021-06-24 16:44:26.088000 | 2021-06-24 17:36:54.231 Socket (9) | CloseSocket call. | 2021-06-24 17:36:54.231 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:54.231 Historical data download thread signaled to stop. | 2021-06-24 17:36:54.231 HD Request # 70 | Received 1 record from 2021-06-24 16:44:26.088000 to 2021-06-24 16:44:26.088000 (0.0 seconds) and wrote 0 records for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.231 HD Request # 70 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:44:26.088000 | 2021-06-24 17:36:54.231 HD Request # 70 | Completion time: 0s | 2021-06-24 17:36:54.231 HD Request # 70 | Intraday data download complete for NGN21-NGV21.FUT_SPREAD.NYMEX. Unique request ID: 70 | 2021-06-24 17:36:54.231 Removing historical data download ID 70. | 2021-06-24 17:36:54.231 Real-time Intraday chart data file updates started for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.231 Intraday chart data file opened for NGN21-NGV21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.231 HD Request # 70 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:54.231 Triggering next historical data download in queue. | 2021-06-24 17:36:54.231 HD Request # 71 | Downloading Intraday chart data for NGV21-NGF22.FUT_SPREAD.NYMEX to the file NGV21-NGF22.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-24 17:36:54.231 HD Request # 71 | Download start date-time: 2021-06-24 16:57:34.000000. File last date-time: 2021-06-24 16:57:34.577001 | 2021-06-24 17:36:54.231 HD Request # 71 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:54.231 Socket (4) | Creating socket. | 2021-06-24 17:36:54.231 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:54.231 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:54.231 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 17:36:54.261 Socket (9) | Closed. | 2021-06-24 17:36:54.261 HD Request # 71 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:54.301 HD Request # 71 | Sending historical data logon request message. | 2021-06-24 17:36:54.301 HD Request # 71 | Requesting Intraday data. Start date-time: 2021-06-24 16:57:34. Record interval: 0. Symbol: NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.321 HD Request # 71 | Decompressing data. | 2021-06-24 17:36:54.351 HD Request # 71 | Receiving Intraday data for NGV21-NGF22.FUT_SPREAD.NYMEX starting at 2021-06-24 16:57:34.577000 | 2021-06-24 17:36:54.351 Socket (4) | CloseSocket call. | 2021-06-24 17:36:54.351 Historical data download thread signaled to stop. | 2021-06-24 17:36:54.351 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:54.351 HD Request # 71 | Received 2 records from 2021-06-24 16:57:34.577000 to 2021-06-24 16:57:34.577001 (0.0 seconds) and wrote 0 records for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.351 HD Request # 71 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:57:34.577001 | 2021-06-24 17:36:54.351 HD Request # 71 | Completion time: 0s | 2021-06-24 17:36:54.351 HD Request # 71 | Intraday data download complete for NGV21-NGF22.FUT_SPREAD.NYMEX. Unique request ID: 71 | 2021-06-24 17:36:54.351 Removing historical data download ID 71. | 2021-06-24 17:36:54.351 Real-time Intraday chart data file updates started for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.351 Intraday chart data file opened for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.351 HD Request # 71 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:54.351 Triggering next historical data download in queue. | 2021-06-24 17:36:54.351 HD Request # 72 | Downloading Intraday chart data for NGN21-NGH22.FUT_SPREAD.NYMEX to the file NGN21-NGH22.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-24 17:36:54.351 HD Request # 72 | Download start date-time: 2021-06-24 16:37:34.000000. File last date-time: 2021-06-24 16:37:34.074000 | 2021-06-24 17:36:54.351 HD Request # 72 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:54.351 Socket (9) | Creating socket. | 2021-06-24 17:36:54.351 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 17:36:54.351 Socket (9) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:54.351 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:54.381 Socket (4) | Closed. | 2021-06-24 17:36:54.381 HD Request # 72 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:54.411 HD Request # 72 | Sending historical data logon request message. | 2021-06-24 17:36:54.411 HD Request # 72 | Requesting Intraday data. Start date-time: 2021-06-24 16:37:34. Record interval: 0. Symbol: NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.441 HD Request # 72 | Decompressing data. | 2021-06-24 17:36:54.471 HD Request # 72 | Receiving Intraday data for NGN21-NGH22.FUT_SPREAD.NYMEX starting at 2021-06-24 16:37:34.074000 | 2021-06-24 17:36:54.471 Socket (9) | CloseSocket call. | 2021-06-24 17:36:54.471 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:54.471 Historical data download thread signaled to stop. | 2021-06-24 17:36:54.471 HD Request # 72 | Received 1 record from 2021-06-24 16:37:34.074000 to 2021-06-24 16:37:34.074000 (0.0 seconds) and wrote 0 records for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.471 HD Request # 72 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:37:34.074000 | 2021-06-24 17:36:54.471 HD Request # 72 | Completion time: 0s | 2021-06-24 17:36:54.471 HD Request # 72 | Intraday data download complete for NGN21-NGH22.FUT_SPREAD.NYMEX. Unique request ID: 72 | 2021-06-24 17:36:54.471 Removing historical data download ID 72. | 2021-06-24 17:36:54.471 Real-time Intraday chart data file updates started for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.471 Intraday chart data file opened for NGN21-NGH22.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.471 HD Request # 72 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:54.471 Triggering next historical data download in queue. | 2021-06-24 17:36:54.471 HD Request # 73 | Downloading Intraday chart data for NGN21-NGQ21.FUT_SPREAD.NYMEX to the file NGN21-NGQ21.FUT_SPREAD.NYMEX.scid. Service: nymex | 2021-06-24 17:36:54.471 HD Request # 73 | Download start date-time: 2021-06-24 16:59:14.000000. File last date-time: 2021-06-24 16:59:14.907000 | 2021-06-24 17:36:54.471 HD Request # 73 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:54.471 Socket (4) | Creating socket. | 2021-06-24 17:36:54.471 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:54.471 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:54.471 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 17:36:54.491 Socket (9) | Closed. | 2021-06-24 17:36:54.491 HD Request # 73 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:54.531 HD Request # 73 | Sending historical data logon request message. | 2021-06-24 17:36:54.531 HD Request # 73 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:14. Record interval: 0. Symbol: NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.571 HD Request # 73 | Decompressing data. | 2021-06-24 17:36:54.601 HD Request # 73 | Receiving Intraday data for NGN21-NGQ21.FUT_SPREAD.NYMEX starting at 2021-06-24 16:59:14.888000 | 2021-06-24 17:36:54.601 Socket (4) | CloseSocket call. | 2021-06-24 17:36:54.601 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:54.601 Historical data download thread signaled to stop. | 2021-06-24 17:36:54.601 HD Request # 73 | Received 2 records from 2021-06-24 16:59:14.888000 to 2021-06-24 16:59:14.907000 (0.0 seconds) and wrote 0 records for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.601 HD Request # 73 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:14.907000 | 2021-06-24 17:36:54.601 HD Request # 73 | Completion time: 0s | 2021-06-24 17:36:54.601 HD Request # 73 | Intraday data download complete for NGN21-NGQ21.FUT_SPREAD.NYMEX. Unique request ID: 73 | 2021-06-24 17:36:54.601 Removing historical data download ID 73. | 2021-06-24 17:36:54.601 Real-time Intraday chart data file updates started for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.601 Intraday chart data file opened for NGN21-NGQ21.FUT_SPREAD.NYMEX | 2021-06-24 17:36:54.601 HD Request # 73 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:54.601 Triggering next historical data download in queue. | 2021-06-24 17:36:54.601 No download requests in the queue to start downloads for. | 2021-06-24 17:36:54.601 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:54.631 Socket (4) | Closed. | 2021-06-24 17:36:54.631 SC Data - All Services (Market Orders Data) | Received security definition for symbol HGN21-COMEX | 2021-06-24 17:36:58.571 SC Data - All Services (Market Orders Data) | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-24 17:36:58.571 Added historical Intraday data request for HGN21-COMEX to the queue. | 2021-06-24 17:36:58.581 Intraday data recording state for symbol HGN21-COMEX is set to download 'Pending'. | 2021-06-24 17:36:58.581 Triggering next historical data download in queue. | 2021-06-24 17:36:58.581 SC Data - All Services (Market Orders Data) | Received security definition for symbol GCQ21-COMEX | 2021-06-24 17:36:58.581 SC Data - All Services (Market Orders Data) | Real-time data for symbol GCQ21-COMEX has been restored. | 2021-06-24 17:36:58.581 Added historical Intraday data request for GCQ21-COMEX to the queue. | 2021-06-24 17:36:58.591 Intraday data recording state for symbol GCQ21-COMEX is set to download 'Pending'. | 2021-06-24 17:36:58.591 SC Data - All Services | Clearing market depth for HGN21-COMEX | 2021-06-24 17:36:58.591 HD Request # 74 | Downloading Intraday chart data for HGN21-COMEX to the file HGN21-COMEX.scid. Service: comex | 2021-06-24 17:36:58.591 HD Request # 74 | Download start date-time: 2021-06-24 16:59:59.000000. File last date-time: 2021-06-24 16:59:59.017000 | 2021-06-24 17:36:58.591 HD Request # 74 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:58.591 SC Data - All Services | Received security definition for symbol HGN21-COMEX | 2021-06-24 17:36:58.591 SC Data - All Services | Real-time data for symbol HGN21-COMEX has been restored. | 2021-06-24 17:36:58.591 SC Data - All Services | Received security definition for symbol GCQ21-COMEX | 2021-06-24 17:36:58.591 SC Data - All Services | Real-time data for symbol GCQ21-COMEX has been restored. | 2021-06-24 17:36:58.591 SC Data - All Services | Received security definition for symbol SIN21-COMEX | 2021-06-24 17:36:58.591 SC Data - All Services | Real-time data for symbol SIN21-COMEX has been restored. | 2021-06-24 17:36:58.591 Socket (4) | Creating socket. | 2021-06-24 17:36:58.591 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:58.591 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:58.591 Added historical Intraday data request for SIN21-COMEX to the queue. | 2021-06-24 17:36:58.591 Intraday data recording state for symbol SIN21-COMEX is set to download 'Pending'. | 2021-06-24 17:36:58.591 Triggering next historical data download in queue. | 2021-06-24 17:36:58.591 HD Request # 74 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:58.701 HD Request # 74 | Sending historical data logon request message. | 2021-06-24 17:36:58.701 HD Request # 74 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:59. Record interval: 0. Symbol: HGN21 | 2021-06-24 17:36:58.761 HD Request # 74 | Decompressing data. | 2021-06-24 17:36:58.801 HD Request # 74 | Receiving Intraday data for HGN21-COMEX starting at 2021-06-24 16:59:59.017000 | 2021-06-24 17:36:58.801 Socket (4) | CloseSocket call. | 2021-06-24 17:36:58.801 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:58.801 Historical data download thread signaled to stop. | 2021-06-24 17:36:58.801 HD Request # 74 | Received 1 record from 2021-06-24 16:59:59.017000 to 2021-06-24 16:59:59.017000 (0.0 seconds) and wrote 0 records for HGN21-COMEX | 2021-06-24 17:36:58.801 HD Request # 74 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:59.017000 | 2021-06-24 17:36:58.801 HD Request # 74 | Completion time: 0s | 2021-06-24 17:36:58.801 HD Request # 74 | Intraday data download complete for HGN21-COMEX. Unique request ID: 74 | 2021-06-24 17:36:58.801 Removing historical data download ID 74. | 2021-06-24 17:36:58.801 Real-time Intraday chart data file updates started for HGN21-COMEX | 2021-06-24 17:36:58.801 Intraday chart data file opened for HGN21-COMEX | 2021-06-24 17:36:58.801 HD Request # 74 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:58.801 Triggering next historical data download in queue. | 2021-06-24 17:36:58.801 HD Request # 75 | Downloading Intraday chart data for GCQ21-COMEX to the file GCQ21-COMEX.scid. Service: comex | 2021-06-24 17:36:58.801 HD Request # 75 | Download start date-time: 2021-06-24 16:59:59.000000. File last date-time: 2021-06-24 16:59:59.525000 | 2021-06-24 17:36:58.801 HD Request # 75 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:58.801 Socket (9) | Creating socket. | 2021-06-24 17:36:58.801 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 17:36:58.801 Socket (9) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:58.801 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:58.831 Socket (4) | Closed. | 2021-06-24 17:36:58.831 HD Request # 75 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:59.551 HD Request # 75 | Sending historical data logon request message. | 2021-06-24 17:36:59.551 HD Request # 75 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:59. Record interval: 0. Symbol: GCQ21 | 2021-06-24 17:36:59.581 HD Request # 75 | Decompressing data. | 2021-06-24 17:36:59.611 HD Request # 75 | Receiving Intraday data for GCQ21-COMEX starting at 2021-06-24 16:59:59.525000 | 2021-06-24 17:36:59.611 Socket (9) | CloseSocket call. | 2021-06-24 17:36:59.611 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:59.611 Historical data download thread signaled to stop. | 2021-06-24 17:36:59.611 HD Request # 75 | Received 1 record from 2021-06-24 16:59:59.525000 to 2021-06-24 16:59:59.525000 (0.0 seconds) and wrote 0 records for GCQ21-COMEX | 2021-06-24 17:36:59.611 HD Request # 75 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:59.525000 | 2021-06-24 17:36:59.611 HD Request # 75 | Completion time: 1s | 2021-06-24 17:36:59.611 HD Request # 75 | Intraday data download complete for GCQ21-COMEX. Unique request ID: 75 | 2021-06-24 17:36:59.611 Removing historical data download ID 75. | 2021-06-24 17:36:59.611 Real-time Intraday chart data file updates started for GCQ21-COMEX | 2021-06-24 17:36:59.611 Intraday chart data file opened for GCQ21-COMEX | 2021-06-24 17:36:59.611 HD Request # 75 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:59.611 Triggering next historical data download in queue. | 2021-06-24 17:36:59.611 HD Request # 76 | Downloading Intraday chart data for SIN21-COMEX to the file SIN21-COMEX.scid. Service: comex | 2021-06-24 17:36:59.611 HD Request # 76 | Download start date-time: 2021-06-24 16:59:54.000000. File last date-time: 2021-06-24 16:59:54.538000 | 2021-06-24 17:36:59.611 HD Request # 76 | Using server: ds21.sierracharts.com port 10150 | 2021-06-24 17:36:59.611 Socket (4) | Creating socket. | 2021-06-24 17:36:59.611 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:59.611 Socket (4) | Connecting to IP: 216.1.90.129. | 2021-06-24 17:36:59.611 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 17:36:59.651 Socket (9) | Closed. | 2021-06-24 17:36:59.651 HD Request # 76 | Setting DTC encoding to Binary VLS | 2021-06-24 17:36:59.681 HD Request # 76 | Sending historical data logon request message. | 2021-06-24 17:36:59.681 HD Request # 76 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:54. Record interval: 0. Symbol: SIN21 | 2021-06-24 17:36:59.711 HD Request # 76 | Decompressing data. | 2021-06-24 17:36:59.741 HD Request # 76 | Receiving Intraday data for SIN21-COMEX starting at 2021-06-24 16:59:54.538000 | 2021-06-24 17:36:59.741 Socket (4) | CloseSocket call. | 2021-06-24 17:36:59.741 Historical data download thread signaled to stop. | 2021-06-24 17:36:59.741 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:36:59.741 HD Request # 76 | Received 1 record from 2021-06-24 16:59:54.538000 to 2021-06-24 16:59:54.538000 (0.0 seconds) and wrote 0 records for SIN21-COMEX | 2021-06-24 17:36:59.741 HD Request # 76 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:54.538000 | 2021-06-24 17:36:59.741 HD Request # 76 | Completion time: 0s | 2021-06-24 17:36:59.741 HD Request # 76 | Intraday data download complete for SIN21-COMEX. Unique request ID: 76 | 2021-06-24 17:36:59.741 Removing historical data download ID 76. | 2021-06-24 17:36:59.741 Real-time Intraday chart data file updates started for SIN21-COMEX | 2021-06-24 17:36:59.741 Intraday chart data file opened for SIN21-COMEX | 2021-06-24 17:36:59.741 HD Request # 76 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:36:59.741 Triggering next historical data download in queue. | 2021-06-24 17:36:59.741 No download requests in the queue to start downloads for. | 2021-06-24 17:36:59.741 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:36:59.761 Socket (4) | Closed. | 2021-06-24 17:36:59.761 SC Data - All Services | Received security definition for symbol BTCM21-CME | 2021-06-24 17:36:59.791 SC Data - All Services | Real-time data for symbol BTCM21-CME has been restored. | 2021-06-24 17:36:59.791 Added historical Intraday data request for BTCM21-CME to the queue. | 2021-06-24 17:36:59.801 Intraday data recording state for symbol BTCM21-CME is set to download 'Pending'. | 2021-06-24 17:36:59.801 Triggering next historical data download in queue. | 2021-06-24 17:36:59.801 HD Request # 77 | Downloading Intraday chart data for BTCM21-CME to the file BTCM21-CME.scid. Service: cme | 2021-06-24 17:36:59.801 HD Request # 77 | Download start date-time: 2021-06-24 16:59:51.000000. File last date-time: 2021-06-24 16:59:51.788000 | 2021-06-24 17:36:59.801 HD Request # 77 | Using server: ds23.sierracharts.com port 10149 | 2021-06-24 17:36:59.801 Socket (4) | Creating socket. | 2021-06-24 17:36:59.801 Socket (4) | New receive buffer size: 5242880 | 2021-06-24 17:36:59.801 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-06-24 17:36:59.801 HD Request # 77 | Setting DTC encoding to Binary VLS | 2021-06-24 17:37:00.431 HD Request # 77 | Sending historical data logon request message. | 2021-06-24 17:37:00.431 HD Request # 77 | Requesting Intraday data. Start date-time: 2021-06-24 16:59:51. Record interval: 0. Symbol: BTCM21 | 2021-06-24 17:37:01.471 HD Request # 77 | Decompressing data. | 2021-06-24 17:37:01.531 HD Request # 77 | Receiving Intraday data for BTCM21-CME starting at 2021-06-24 16:59:51.788000 | 2021-06-24 17:37:01.531 Socket (4) | CloseSocket call. | 2021-06-24 17:37:01.531 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-24 17:37:01.531 Historical data download thread signaled to stop. | 2021-06-24 17:37:01.531 HD Request # 77 | Received 1 record from 2021-06-24 16:59:51.788000 to 2021-06-24 16:59:51.788000 (0.0 seconds) and wrote 0 records for BTCM21-CME | 2021-06-24 17:37:01.531 HD Request # 77 | Add time&sales data | Remembered last file record date-time: 2021-06-24 20:59:51.788000 | 2021-06-24 17:37:01.531 HD Request # 77 | Completion time: 2s | 2021-06-24 17:37:01.531 HD Request # 77 | Intraday data download complete for BTCM21-CME. Unique request ID: 77 | 2021-06-24 17:37:01.531 Removing historical data download ID 77. | 2021-06-24 17:37:01.531 Real-time Intraday chart data file updates started for BTCM21-CME | 2021-06-24 17:37:01.531 Intraday chart data file opened for BTCM21-CME | 2021-06-24 17:37:01.531 HD Request # 77 | Enabling Intraday chart updating for symbol. | 2021-06-24 17:37:01.531 Triggering next historical data download in queue. | 2021-06-24 17:37:01.531 No download requests in the queue to start downloads for. | 2021-06-24 17:37:01.531 Socket (4) | Socket gracefully closed by remote side. | 2021-06-24 17:37:01.791 Socket (4) | Closed. | 2021-06-24 17:37:01.791 SC DTC Delayed Exchange Data | Real-time data for symbol VXN21-CFE has been restored. | 2021-06-24 17:40:58.401 Requesting current DateTime from Sierra Chart server. | 2021-06-24 17:49:29.920 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 21:49:30.302. Round-trip delay: 00:00:00.195 | 2021-06-24 17:49:30.310 Computer time to server time difference: 00:00:00.008 | 2021-06-24 17:49:30.310 Successfully set the system Date-time to: 2021-06-24 21:49:30.302 UTC. | 2021-06-24 17:49:30.302 Opened cached Intraday file: C:\SierraChart\Data\ESU21-CME.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 Opened cached Intraday file: C:\SierraChart\Data\CLQ21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGQ21.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 Opened cached Intraday file: C:\SierraChart\Data\HGN21-COMEX.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 Opened cached Intraday file: C:\SierraChart\Data\GCQ21-COMEX.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 Opened cached Intraday file: C:\SierraChart\Data\SIN21-COMEX.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 Opened cached Intraday file: C:\SierraChart\Data\NGQ21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 Opened cached Intraday file: C:\SierraChart\Data\NGU21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 Opened cached Intraday file: C:\SierraChart\Data\NGTN21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 18:00:01.342 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 18:00:32.102 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 18:00:32.102 HD Server | Thread:4512 (4) | Creating socket. | 2021-06-24 18:00:32.112 HD Server | Thread:4512 (4) | New receive buffer size: 262144 | 2021-06-24 18:00:32.112 HD Server | Setting DTC encoding to Binary VLS | Thread:4512 | 2021-06-24 18:00:32.112 HD Server | Thread:4512 (4) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-24 18:00:32.112 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4512 | 2021-06-24 18:00:32.112 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4512 | 2021-06-24 18:00:32.112 HD Server | HD Request #142 | Socket: 4 | Symbol: ZBU21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 142 | Username: SPRDTRDR. | Thread:4512 | 2021-06-24 18:00:32.112 Added historical Daily data request for ZBU21-CBOT to the queue. | 2021-06-24 18:00:32.122 Triggering next historical data download in queue. | 2021-06-24 18:00:32.122 HD Request # 78 | Downloading Historical Daily chart data for ZBU21-CBOT. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-24 18:00:32.132 HD Request # 78 | Requesting historical Daily data for ZBU21 starting at 2021-06-20. SC External HD service. | 2021-06-24 18:00:32.622 HD Request # 78 | Receiving historical Daily data for ZBU21-CBOT starting at 2021-06-21 | 2021-06-24 18:00:32.822 HD Request # 78 | Writing historical Daily data to the file ZBU21-CBOT.dly | 2021-06-24 18:00:32.822 HD Request # 78 | Bytes received: 261 | 2021-06-24 18:00:32.822 HD Request # 78 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for ZBU21-CBOT | 2021-06-24 18:00:32.822 HD Request # 78 | Completion time: 0s | 2021-06-24 18:00:32.832 HD Request # 78 | Daily data download complete for ZBU21-CBOT. Unique request ID: 78 | 2021-06-24 18:00:32.832 Removing historical data download ID 78. | 2021-06-24 18:00:32.832 Triggering next historical data download in queue. | 2021-06-24 18:00:32.832 No download requests in the queue to start downloads for. | 2021-06-24 18:00:32.832 HD Server | HD Request | Socket: 4 | Symbol: ZBU21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 142 | Username: SPRDTRDR. | Thread:4512 | 2021-06-24 18:00:33.142 HD Server | Thread:4512 (4) | Socket gracefully closed by remote side. | 2021-06-24 18:00:33.142 HD Server | Thread:4512 (4) | CloseSocket call. | 2021-06-24 18:00:33.142 HD Server | Thread:4512 (0) | CloseSocket call. | 2021-06-24 18:00:33.142 HD Server | Thread:4512 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 18:00:33.142 HD Server | Thread:4512 (4) | Closed. | 2021-06-24 18:00:33.142 HD Server | Thread:4512 (0) | CloseSocket call. | 2021-06-24 18:00:33.142 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4512 | 2021-06-24 18:00:33.322 HD Server Manager | Current server count=0 | 2021-06-24 18:00:33.322 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 18:00:35.592 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 18:00:35.592 HD Server | Thread:4696 (4) | Creating socket. | 2021-06-24 18:00:35.602 HD Server | Thread:4696 (4) | New receive buffer size: 262144 | 2021-06-24 18:00:35.602 HD Server | Thread:4696 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 18:00:35.602 HD Server | Setting DTC encoding to Binary VLS | Thread:4696 | 2021-06-24 18:00:35.602 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 18:00:35.602 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 18:00:35.602 HD Server | HD Request #143 | Socket: 4 | Symbol: HGN21-COMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 143 | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 18:00:35.602 Added historical Daily data request for HGN21-COMEX to the queue. | 2021-06-24 18:00:35.602 Triggering next historical data download in queue. | 2021-06-24 18:00:35.602 HD Request # 79 | Downloading Historical Daily chart data for HGN21-COMEX. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-24 18:00:35.612 HD Request # 79 | Requesting historical Daily data for HGN21 starting at 2021-06-20. SC External HD service. | 2021-06-24 18:00:36.102 HD Request # 79 | Receiving historical Daily data for HGN21-COMEX starting at 2021-06-21 | 2021-06-24 18:00:36.252 HD Request # 79 | Writing historical Daily data to the file HGN21-COMEX.dly | 2021-06-24 18:00:36.252 HD Request # 79 | Bytes received: 216 | 2021-06-24 18:00:36.262 HD Request # 79 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for HGN21-COMEX | 2021-06-24 18:00:36.262 HD Request # 79 | Completion time: 1s | 2021-06-24 18:00:36.272 HD Request # 79 | Daily data download complete for HGN21-COMEX. Unique request ID: 79 | 2021-06-24 18:00:36.272 Removing historical data download ID 79. | 2021-06-24 18:00:36.272 Triggering next historical data download in queue. | 2021-06-24 18:00:36.272 No download requests in the queue to start downloads for. | 2021-06-24 18:00:36.272 HD Server | HD Request | Socket: 4 | Symbol: HGN21-COMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 143 | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 18:00:36.622 HD Server | Thread:4696 (4) | Socket gracefully closed by remote side. | 2021-06-24 18:00:36.632 HD Server | Thread:4696 (4) | CloseSocket call. | 2021-06-24 18:00:36.632 HD Server | Thread:4696 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 18:00:36.632 HD Server | Thread:4696 (4) | Closed. | 2021-06-24 18:00:36.632 HD Server | Thread:4696 (0) | CloseSocket call. | 2021-06-24 18:00:36.632 HD Server | Thread:4696 (0) | CloseSocket call. | 2021-06-24 18:00:36.632 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4696 | 2021-06-24 18:00:36.712 HD Server Manager | Current server count=0 | 2021-06-24 18:00:36.712 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 18:00:36.872 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 18:00:36.872 HD Server | Thread:6792 (4) | Creating socket. | 2021-06-24 18:00:36.872 HD Server | Thread:6792 (4) | New receive buffer size: 262144 | 2021-06-24 18:00:36.872 HD Server | Thread:6792 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 18:00:36.872 HD Server | Setting DTC encoding to Binary VLS | Thread:6792 | 2021-06-24 18:00:36.872 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6792 | 2021-06-24 18:00:36.872 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6792 | 2021-06-24 18:00:36.872 HD Server | HD Request #144 | Socket: 4 | Symbol: HGZ20 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2020-11-12 00:00:00 | ClientReqID: 144 | Username: SPRDTRDR. | Thread:6792 | 2021-06-24 18:00:36.882 HD Server | HD Request | Socket: 4 | Symbol: HGZ20 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 144 | Username: SPRDTRDR. | Thread:6792 | 2021-06-24 18:00:36.902 HD Server | Thread:6792 (4) | Socket gracefully closed by remote side. | 2021-06-24 18:00:36.912 HD Server | Thread:6792 (4) | CloseSocket call. | 2021-06-24 18:00:36.912 HD Server | Thread:6792 (0) | CloseSocket call. | 2021-06-24 18:00:36.912 HD Server | Thread:6792 (0) | CloseSocket call. | 2021-06-24 18:00:36.912 HD Server | Thread:6792 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 18:00:36.912 HD Server | Thread:6792 (4) | Closed. | 2021-06-24 18:00:36.912 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6792 | 2021-06-24 18:00:36.972 HD Server Manager | Current server count=0 | 2021-06-24 18:00:36.972 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 18:00:46.412 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 18:00:46.412 HD Server | Thread:3012 (4) | Creating socket. | 2021-06-24 18:00:46.412 HD Server | Thread:3012 (4) | New receive buffer size: 262144 | 2021-06-24 18:00:46.412 HD Server | Thread:3012 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 18:00:46.412 HD Server | Setting DTC encoding to Binary VLS | Thread:3012 | 2021-06-24 18:00:46.412 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:3012 | 2021-06-24 18:00:46.412 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:3012 | 2021-06-24 18:00:46.412 HD Server | HD Request #145 | Socket: 4 | Symbol: RBQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 145 | Username: SPRDTRDR. | Thread:3012 | 2021-06-24 18:00:46.412 Added historical Daily data request for RBQ21-NYMEX to the queue. | 2021-06-24 18:00:46.412 Triggering next historical data download in queue. | 2021-06-24 18:00:46.412 HD Request # 80 | Downloading Historical Daily chart data for RBQ21-NYMEX. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-24 18:00:46.422 HD Request # 80 | Requesting historical Daily data for RBQ21 starting at 2021-06-20. SC External HD service. | 2021-06-24 18:00:46.902 HD Request # 80 | Receiving historical Daily data for RBQ21-NYMEX starting at 2021-06-21 | 2021-06-24 18:00:47.032 HD Request # 80 | Writing historical Daily data to the file RBQ21-NYMEX.dly | 2021-06-24 18:00:47.032 HD Request # 80 | Bytes received: 228 | 2021-06-24 18:00:47.042 HD Request # 80 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for RBQ21-NYMEX | 2021-06-24 18:00:47.042 HD Request # 80 | Completion time: 1s | 2021-06-24 18:00:47.052 HD Request # 80 | Daily data download complete for RBQ21-NYMEX. Unique request ID: 80 | 2021-06-24 18:00:47.052 Removing historical data download ID 80. | 2021-06-24 18:00:47.052 Triggering next historical data download in queue. | 2021-06-24 18:00:47.052 No download requests in the queue to start downloads for. | 2021-06-24 18:00:47.052 HD Server | HD Request | Socket: 4 | Symbol: RBQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 145 | Username: SPRDTRDR. | Thread:3012 | 2021-06-24 18:00:47.432 HD Server | Thread:3012 (4) | Socket gracefully closed by remote side. | 2021-06-24 18:00:47.442 HD Server | Thread:3012 (4) | CloseSocket call. | 2021-06-24 18:00:47.442 HD Server | Thread:3012 (0) | CloseSocket call. | 2021-06-24 18:00:47.442 HD Server | Thread:3012 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 18:00:47.442 HD Server | Thread:3012 (4) | Closed. | 2021-06-24 18:00:47.442 HD Server | Thread:3012 (0) | CloseSocket call. | 2021-06-24 18:00:47.442 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:3012 | 2021-06-24 18:00:47.632 HD Server Manager | Current server count=0 | 2021-06-24 18:00:47.632 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 18:00:55.792 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 18:00:55.792 HD Server | Thread:4852 (4) | Creating socket. | 2021-06-24 18:00:55.792 HD Server | Thread:4852 (4) | New receive buffer size: 262144 | 2021-06-24 18:00:55.792 HD Server | Thread:4852 (4) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 18:00:55.792 HD Server | Setting DTC encoding to Binary VLS | Thread:4852 | 2021-06-24 18:00:55.792 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4852 | 2021-06-24 18:00:55.802 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4852 | 2021-06-24 18:00:55.802 HD Server | HD Request #146 | Socket: 4 | Symbol: NGQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-22 00:00:00 | ClientReqID: 146 | Username: SPRDTRDR. | Thread:4852 | 2021-06-24 18:00:55.802 Added historical Daily data request for NGQ21-NYMEX to the queue. | 2021-06-24 18:00:55.802 Triggering next historical data download in queue. | 2021-06-24 18:00:55.802 HD Request # 81 | Downloading Historical Daily chart data for NGQ21-NYMEX. Starting date: 2021-06-22. Service: scdataallservices | 2021-06-24 18:00:55.812 HD Request # 81 | Requesting historical Daily data for NGQ21 starting at 2021-06-21. SC External HD service. | 2021-06-24 18:00:56.292 HD Request # 81 | Receiving historical Daily data for NGQ21-NYMEX starting at 2021-06-22 | 2021-06-24 18:00:56.412 HD Request # 81 | Writing historical Daily data to the file NGQ21-NYMEX.dly | 2021-06-24 18:00:56.412 HD Request # 81 | Bytes received: 216 | 2021-06-24 18:00:56.432 HD Request # 81 | Received 4 records from 2021-06-22 00:00:00 to 2021-06-24 00:00:00 (3.0 days) and wrote 3 records for NGQ21-NYMEX | 2021-06-24 18:00:56.432 HD Request # 81 | Completion time: 1s | 2021-06-24 18:00:56.432 HD Request # 81 | Daily data download complete for NGQ21-NYMEX. Unique request ID: 81 | 2021-06-24 18:00:56.432 Removing historical data download ID 81. | 2021-06-24 18:00:56.432 Triggering next historical data download in queue. | 2021-06-24 18:00:56.432 No download requests in the queue to start downloads for. | 2021-06-24 18:00:56.432 HD Server | HD Request | Socket: 4 | Symbol: NGQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 146 | Username: SPRDTRDR. | Thread:4852 | 2021-06-24 18:00:56.832 HD Server | Thread:4852 (4) | Socket gracefully closed by remote side. | 2021-06-24 18:00:56.852 HD Server | Thread:4852 (4) | CloseSocket call. | 2021-06-24 18:00:56.852 HD Server | Thread:4852 (0) | CloseSocket call. | 2021-06-24 18:00:56.852 HD Server | Thread:4852 (0) | CloseSocket call. | 2021-06-24 18:00:56.852 HD Server | Thread:4852 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 18:00:56.852 HD Server | Thread:4852 (4) | Closed. | 2021-06-24 18:00:56.852 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4852 | 2021-06-24 18:00:56.992 HD Server Manager | Current server count=0 | 2021-06-24 18:00:56.992 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGV21.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-24 18:02:31.343 SC DTC Data with Market Depth | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2021-06-24 18:02:41.403 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-06-24 18:02:41.403 DTC Client socket (3) | CloseSocket call. | 2021-06-24 18:02:41.403 SC DTC Data with Market Depth | Disconnected from the server. | 2021-06-24 18:02:41.403 DTC Client socket (3) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-06-24 18:02:41.403 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-24 18:02:41.403 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2021-06-24 18:02:43.413 DTC Client socket (4) | Creating socket. | 2021-06-24 18:02:43.443 DTC Client socket (4) | New receive buffer size: 5242880 | 2021-06-24 18:02:43.443 DTC Client socket (4) | Connecting to IP: 192.81.56.146. | 2021-06-24 18:02:43.443 SC DTC Data with Market Depth | Network connection to server complete. | 2021-06-24 18:02:43.483 SC DTC Data with Market Depth | Starting socket receive thread. | 2021-06-24 18:02:43.483 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-24 18:02:43.483 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-06-24 18:02:43.533 SC DTC Data with Market Depth | Sending logon request message. | 2021-06-24 18:02:43.533 SC DTC Data with Market Depth | Received logon response. | 2021-06-24 18:02:44.193 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-06-24 18:02:44.193 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-06-24 18:02:44.193 SC DTC Data with Market Depth | Successfully connected. | 2021-06-24 18:02:44.193 SC DTC Data with Market Depth | Trading is not supported. | 2021-06-24 18:02:44.193 Added historical Intraday data request for BTCUSDT_PERP_BINANCE to the queue. | 2021-06-24 18:02:44.203 Intraday data recording state for symbol BTCUSDT_PERP_BINANCE is set to download 'Pending'. | 2021-06-24 18:02:44.203 Triggering next historical data download in queue. | 2021-06-24 18:02:44.203 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSDT_PERP_BINANCE | 2021-06-24 18:02:44.203 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2021-06-24 18:02:44.203 Added historical Intraday data request for TICK-NYSE_NASDAQ_NYSEMKT to the queue. | 2021-06-24 18:02:44.203 Intraday data recording state for symbol TICK-NYSE_NASDAQ_NYSEMKT is set to download 'Pending'. | 2021-06-24 18:02:44.203 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-24 18:02:44.203 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2021-06-24 18:02:44.203 HD Request # 82 | Downloading Intraday chart data for BTCUSDT_PERP_BINANCE to the file BTCUSDT_PERP_BINANCE.scid. Service: binance_cryptocurrency.exchange.data | 2021-06-24 18:02:44.203 HD Request # 82 | Download start date-time: 2021-06-24 18:01:47.000000. File last date-time: 2021-06-24 18:01:47.551000 | 2021-06-24 18:02:44.203 HD Request # 82 | Using server: ds12.sierracharts.com port 10150 | 2021-06-24 18:02:44.203 Socket (10) | Creating socket. | 2021-06-24 18:02:44.223 Socket (10) | New receive buffer size: 5242880 | 2021-06-24 18:02:44.223 Socket (10) | Connecting to IP: 204.15.197.14. | 2021-06-24 18:02:44.223 SC DTC Data with Market Depth | Received security definition for symbol BTCUSDT_PERP_BINANCE | 2021-06-24 18:02:44.313 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2021-06-24 18:02:44.313 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-24 18:02:44.313 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2021-06-24 18:02:44.313 HD Request # 82 | Setting DTC encoding to Binary VLS | 2021-06-24 18:02:44.323 HD Request # 82 | Sending historical data logon request message. | 2021-06-24 18:02:44.323 HD Request # 82 | Requesting Intraday data. Start date-time: 2021-06-24 18:01:47. Record interval: 0. Symbol: BTCUSDT_PERP_BINANCE | 2021-06-24 18:02:44.893 HD Request # 82 | Decompressing data. | 2021-06-24 18:02:44.933 HD Request # 82 | Receiving Intraday data for BTCUSDT_PERP_BINANCE starting at 2021-06-24 18:01:47.000000 | 2021-06-24 18:02:44.933 Socket (10) | CloseSocket call. | 2021-06-24 18:02:44.933 Socket (10) | Shutdown started. Waiting for graceful close. | 2021-06-24 18:02:44.933 Historical data download thread signaled to stop. | 2021-06-24 18:02:44.933 HD Request # 82 | Timestamp of first Intraday data file record written: 2021-06-24 18:01:48.000000 | 2021-06-24 18:02:44.933 HD Request # 82 | Received 55 records from 2021-06-24 18:01:47.000000 to 2021-06-24 18:02:41.000000 (54.0 seconds) and wrote 54 records for BTCUSDT_PERP_BINANCE | 2021-06-24 18:02:44.933 HD Request # 82 | Add time&sales data | Remembered last file record date-time: 2021-06-24 22:02:41.000000 | 2021-06-24 18:02:44.933 Added 54 Time and Sales records to Intraday data file for BTCUSDT_PERP_BINANCE after download. | 2021-06-24 18:02:44.933 HD Request # 82 | Completion time: 0s | 2021-06-24 18:02:44.933 HD Request # 82 | Intraday data download complete for BTCUSDT_PERP_BINANCE. Unique request ID: 82 | 2021-06-24 18:02:44.933 Removing historical data download ID 82. | 2021-06-24 18:02:44.933 Real-time Intraday chart data file updates started for BTCUSDT_PERP_BINANCE | 2021-06-24 18:02:44.933 Intraday chart data file opened for BTCUSDT_PERP_BINANCE | 2021-06-24 18:02:44.933 HD Request # 82 | Enabling Intraday chart updating for symbol. | 2021-06-24 18:02:44.933 Triggering next historical data download in queue. | 2021-06-24 18:02:44.933 HD Request # 83 | Downloading Intraday chart data for TICK-NYSE_NASDAQ_NYSEMKT to the file TICK-NYSE_NASDAQ_NYSEMKT.scid. Service: statscalc | 2021-06-24 18:02:44.933 HD Request # 83 | Download start date-time: 2021-06-24 18:01:47.000000. File last date-time: 2021-06-24 18:01:47.715000 | 2021-06-24 18:02:44.933 HD Request # 83 | Using server: ds4.sierracharts.com port 10149 | 2021-06-24 18:02:44.933 Socket (9) | Creating socket. | 2021-06-24 18:02:44.933 Socket (9) | New receive buffer size: 5242880 | 2021-06-24 18:02:44.933 Socket (9) | Connecting to IP: 192.81.56.146. | 2021-06-24 18:02:44.933 Socket (10) | Socket gracefully closed by remote side. | 2021-06-24 18:02:44.973 Socket (10) | Closed. | 2021-06-24 18:02:44.973 HD Request # 83 | Setting DTC encoding to Binary VLS | 2021-06-24 18:02:45.023 HD Request # 83 | Sending historical data logon request message. | 2021-06-24 18:02:45.023 HD Request # 83 | Requesting Intraday data. Start date-time: 2021-06-24 18:01:47. Record interval: 0. Symbol: TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-24 18:02:45.593 HD Request # 83 | Decompressing data. | 2021-06-24 18:02:45.623 HD Request # 83 | Receiving Intraday data for TICK-NYSE_NASDAQ_NYSEMKT starting at 2021-06-24 18:01:47.000000 | 2021-06-24 18:02:45.623 Socket (9) | CloseSocket call. | 2021-06-24 18:02:45.633 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-24 18:02:45.633 Historical data download thread signaled to stop. | 2021-06-24 18:02:45.633 HD Request # 83 | Timestamp of first Intraday data file record written: 2021-06-24 18:01:48.000000 | 2021-06-24 18:02:45.633 HD Request # 83 | Received 57 records from 2021-06-24 18:01:47.000000 to 2021-06-24 18:02:43.000000 (56.0 seconds) and wrote 56 records for TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-24 18:02:45.633 HD Request # 83 | Add time&sales data | Remembered last file record date-time: 2021-06-24 22:02:43.000000 | 2021-06-24 18:02:45.633 Added 3 Time and Sales records to Intraday data file for TICK-NYSE_NASDAQ_NYSEMKT after download. | 2021-06-24 18:02:45.633 HD Request # 83 | Completion time: 1s | 2021-06-24 18:02:45.633 HD Request # 83 | Intraday data download complete for TICK-NYSE_NASDAQ_NYSEMKT. Unique request ID: 83 | 2021-06-24 18:02:45.633 Removing historical data download ID 83. | 2021-06-24 18:02:45.633 Real-time Intraday chart data file updates started for TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-24 18:02:45.633 Intraday chart data file opened for TICK-NYSE_NASDAQ_NYSEMKT | 2021-06-24 18:02:45.633 HD Request # 83 | Enabling Intraday chart updating for symbol. | 2021-06-24 18:02:45.633 Triggering next historical data download in queue. | 2021-06-24 18:02:45.633 No download requests in the queue to start downloads for. | 2021-06-24 18:02:45.633 Socket (9) | Socket gracefully closed by remote side. | 2021-06-24 18:02:45.663 Socket (9) | Closed. | 2021-06-24 18:02:45.663 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGU21.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-24 18:02:46.343 Opened cached Intraday file: C:\SierraChart\Data\BTCUSDT_PERP_BINANCE.scid. Thread ID: 5644 | 2021-06-24 18:02:46.343 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE_NASDAQ_NYSEMKT.scid. Thread ID: 5644 | 2021-06-24 18:02:46.343 DTC Client socket (3) | Write has completed. Shutdown being performed. | 2021-06-24 18:02:48.273 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-24 18:02:48.273 DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-06-24 18:02:48.273 * DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-06-24 18:02:48.273 DTC Client socket (3) | Closed. | 2021-06-24 18:02:48.273 Opened cached Intraday file: C:\SierraChart\Data\BTCM21-CME.scid. Thread ID: 5644 | 2021-06-24 18:07:31.343 Opened cached Intraday file: C:\SierraChart\Data\RBN21-NYMEX.scid. Thread ID: 5644 | 2021-06-24 18:13:46.344 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX is currently unavailable. | 2021-06-24 18:40:00.437 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX is currently unavailable. | 2021-06-24 18:40:00.437 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2021-06-24 18:40:14.517 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX has been restored. | 2021-06-24 18:40:14.517 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2021-06-24 18:40:15.927 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX has been restored. | 2021-06-24 18:40:15.927 Requesting current DateTime from Sierra Chart server. | 2021-06-24 18:49:29.892 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 22:49:30.276. Round-trip delay: 00:00:00.195 | 2021-06-24 18:49:30.282 Computer time to server time difference: 00:00:00.006 | 2021-06-24 18:49:30.282 Successfully set the system Date-time to: 2021-06-24 22:49:30.276 UTC. | 2021-06-24 18:49:30.276 Opened cached Intraday file: C:\SierraChart\Data\NGH22-NGJ22.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-24 19:46:51.306 Requesting current DateTime from Sierra Chart server. | 2021-06-24 19:49:29.866 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-24 23:49:30.257. Round-trip delay: 00:00:00.200 | 2021-06-24 19:49:30.266 Computer time to server time difference: 00:00:00.009 | 2021-06-24 19:49:30.266 Successfully set the system Date-time to: 2021-06-24 23:49:30.257 UTC. | 2021-06-24 19:49:30.257 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 20:00:00.067 HD Server Manager | Started new historical data server. Count=1 | 2021-06-24 20:00:00.067 HD Server | Thread:6976 (3) | Creating socket. | 2021-06-24 20:00:00.067 HD Server | Thread:6976 (3) | New receive buffer size: 262144 | 2021-06-24 20:00:00.067 HD Server | Setting DTC encoding to Binary VLS | Thread:6976 | 2021-06-24 20:00:00.067 HD Server | Thread:6976 (3) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-24 20:00:00.067 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6976 | 2021-06-24 20:00:00.067 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6976 | 2021-06-24 20:00:00.067 HD Server | HD Request #147 | Socket: 3 | Symbol: ZWN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-15 00:00:00 | ClientReqID: 147 | Username: SPRDTRDR. | Thread:6976 | 2021-06-24 20:00:00.067 HD Server | HD Request | Socket: 3 | Symbol: ZWN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 147 | Username: SPRDTRDR. | Thread:6976 | 2021-06-24 20:00:00.087 HD Server | Thread:6976 (3) | Socket gracefully closed by remote side. | 2021-06-24 20:00:00.087 HD Server | Thread:6976 (3) | CloseSocket call. | 2021-06-24 20:00:00.087 HD Server | Thread:6976 (0) | CloseSocket call. | 2021-06-24 20:00:00.087 HD Server | Thread:6976 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 20:00:00.087 HD Server | Thread:6976 (3) | Closed. | 2021-06-24 20:00:00.087 HD Server | Thread:6976 (0) | CloseSocket call. | 2021-06-24 20:00:00.087 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 20:00:00.117 HD Server Manager | Started new historical data server. Count=2 | 2021-06-24 20:00:00.117 HD Server | Thread:5772 (3) | Creating socket. | 2021-06-24 20:00:00.117 HD Server | Thread:5772 (3) | New receive buffer size: 262144 | 2021-06-24 20:00:00.117 HD Server | Thread:5772 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 20:00:00.117 HD Server | Setting DTC encoding to Binary VLS | Thread:5772 | 2021-06-24 20:00:00.117 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:5772 | 2021-06-24 20:00:00.117 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:5772 | 2021-06-24 20:00:00.117 HD Server | HD Request #148 | Socket: 3 | Symbol: ZCN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 148 | Username: SPRDTRDR. | Thread:5772 | 2021-06-24 20:00:00.117 Added historical Daily data request for ZCN21-CBOT to the queue. | 2021-06-24 20:00:00.117 Triggering next historical data download in queue. | 2021-06-24 20:00:00.117 HD Request # 84 | Downloading Historical Daily chart data for ZCN21-CBOT. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-24 20:00:00.127 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6976 | 2021-06-24 20:00:00.187 HD Server Manager | Current server count=1 | 2021-06-24 20:00:00.187 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ESU21-CME.2021-06-25.depth | 2021-06-24 20:00:00.297 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGN21-NYMEX.2021-06-25.depth | 2021-06-24 20:00:00.307 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGQ21-NYMEX.2021-06-25.depth | 2021-06-24 20:00:00.307 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\NGQ21-NYMEX.2021-06-25.depth. This may take a while. | 2021-06-24 20:00:00.367 File compression enabled. C:\SierraChart\Data\MarketDepthData\NGQ21-NYMEX.2021-06-25.depth. CompressionState=0 | 2021-06-24 20:00:00.367 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGU21-NYMEX.2021-06-25.depth | 2021-06-24 20:00:00.487 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\NGV21-NYMEX.2021-06-25.depth | 2021-06-24 20:00:00.487 HD Request # 84 | Requesting historical Daily data for ZCN21 starting at 2021-06-20. SC External HD service. | 2021-06-24 20:00:00.607 HD Request # 84 | Receiving historical Daily data for ZCN21-CBOT starting at 2021-06-21 | 2021-06-24 20:00:00.997 HD Request # 84 | Writing historical Daily data to the file ZCN21-CBOT.dly | 2021-06-24 20:00:00.997 HD Request # 84 | Bytes received: 219 | 2021-06-24 20:00:01.007 HD Request # 84 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for ZCN21-CBOT | 2021-06-24 20:00:01.007 HD Request # 84 | Completion time: 1s | 2021-06-24 20:00:01.017 HD Request # 84 | Daily data download complete for ZCN21-CBOT. Unique request ID: 84 | 2021-06-24 20:00:01.017 Removing historical data download ID 84. | 2021-06-24 20:00:01.017 Triggering next historical data download in queue. | 2021-06-24 20:00:01.017 No download requests in the queue to start downloads for. | 2021-06-24 20:00:01.017 HD Server | HD Request | Socket: 3 | Symbol: ZCN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 148 | Username: SPRDTRDR. | Thread:5772 | 2021-06-24 20:00:01.127 HD Server | Thread:5772 (3) | Socket gracefully closed by remote side. | 2021-06-24 20:00:01.137 HD Server | Thread:5772 (3) | CloseSocket call. | 2021-06-24 20:00:01.137 HD Server | Thread:5772 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 20:00:01.137 HD Server | Thread:5772 (3) | Closed. | 2021-06-24 20:00:01.137 HD Server | Thread:5772 (0) | CloseSocket call. | 2021-06-24 20:00:01.137 HD Server | Thread:5772 (0) | CloseSocket call. | 2021-06-24 20:00:01.137 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 20:00:01.167 HD Server Manager | Started new historical data server. Count=2 | 2021-06-24 20:00:01.167 HD Server | Thread:4964 (3) | Creating socket. | 2021-06-24 20:00:01.177 HD Server | Thread:4964 (3) | New receive buffer size: 262144 | 2021-06-24 20:00:01.177 HD Server | Thread:4964 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 20:00:01.177 HD Server | Setting DTC encoding to Binary VLS | Thread:4964 | 2021-06-24 20:00:01.177 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4964 | 2021-06-24 20:00:01.177 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4964 | 2021-06-24 20:00:01.177 HD Server | HD Request #149 | Socket: 3 | Symbol: ZSN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 149 | Username: SPRDTRDR. | Thread:4964 | 2021-06-24 20:00:01.177 Added historical Daily data request for ZSN21-CBOT to the queue. | 2021-06-24 20:00:01.177 Triggering next historical data download in queue. | 2021-06-24 20:00:01.177 HD Request # 85 | Downloading Historical Daily chart data for ZSN21-CBOT. Starting date: 2021-06-21. Service: scdataallservices | 2021-06-24 20:00:01.187 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:5772 | 2021-06-24 20:00:01.217 HD Server Manager | Current server count=1 | 2021-06-24 20:00:01.217 Opened cached Intraday file: C:\SierraChart\Data\ZSN21-CBOT.scid. Thread ID: 5644 | 2021-06-24 20:00:01.297 Opened cached Intraday file: C:\SierraChart\Data\ZWN21-CBOT.scid. Thread ID: 5644 | 2021-06-24 20:00:01.297 Opened cached Intraday file: C:\SierraChart\Data\ZCN21-CBOT.scid. Thread ID: 5644 | 2021-06-24 20:00:01.297 HD Request # 85 | Requesting historical Daily data for ZSN21 starting at 2021-06-20. SC External HD service. | 2021-06-24 20:00:01.667 HD Request # 85 | Receiving historical Daily data for ZSN21-CBOT starting at 2021-06-21 | 2021-06-24 20:00:01.817 HD Request # 85 | Writing historical Daily data to the file ZSN21-CBOT.dly | 2021-06-24 20:00:01.817 HD Request # 85 | Bytes received: 220 | 2021-06-24 20:00:01.817 HD Request # 85 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for ZSN21-CBOT | 2021-06-24 20:00:01.817 HD Request # 85 | Completion time: 0s | 2021-06-24 20:00:01.827 HD Request # 85 | Daily data download complete for ZSN21-CBOT. Unique request ID: 85 | 2021-06-24 20:00:01.827 Removing historical data download ID 85. | 2021-06-24 20:00:01.827 Triggering next historical data download in queue. | 2021-06-24 20:00:01.827 No download requests in the queue to start downloads for. | 2021-06-24 20:00:01.827 HD Server | HD Request | Socket: 3 | Symbol: ZSN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 149 | Username: SPRDTRDR. | Thread:4964 | 2021-06-24 20:00:02.187 HD Server | Thread:4964 (3) | Socket gracefully closed by remote side. | 2021-06-24 20:00:02.197 HD Server | Thread:4964 (3) | CloseSocket call. | 2021-06-24 20:00:02.197 HD Server | Thread:4964 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 20:00:02.197 HD Server | Thread:4964 (3) | Closed. | 2021-06-24 20:00:02.197 HD Server | Thread:4964 (0) | CloseSocket call. | 2021-06-24 20:00:02.197 HD Server | Thread:4964 (0) | CloseSocket call. | 2021-06-24 20:00:02.197 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-24 20:00:02.217 HD Server Manager | Started new historical data server. Count=2 | 2021-06-24 20:00:02.217 HD Server | Thread:1164 (3) | Creating socket. | 2021-06-24 20:00:02.217 HD Server | Thread:1164 (3) | New receive buffer size: 262144 | 2021-06-24 20:00:02.217 HD Server | Thread:1164 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-24 20:00:02.217 HD Server | Setting DTC encoding to Binary VLS | Thread:1164 | 2021-06-24 20:00:02.217 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:1164 | 2021-06-24 20:00:02.227 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:1164 | 2021-06-24 20:00:02.227 HD Server | HD Request #150 | Socket: 3 | Symbol: ZLN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-18 00:00:00 | ClientReqID: 150 | Username: SPRDTRDR. | Thread:1164 | 2021-06-24 20:00:02.227 HD Server | HD Request | Socket: 3 | Symbol: ZLN21-CBOT | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 150 | Username: SPRDTRDR. | Thread:1164 | 2021-06-24 20:00:02.237 HD Server | Thread:1164 (3) | Socket gracefully closed by remote side. | 2021-06-24 20:00:02.247 HD Server | Thread:1164 (3) | CloseSocket call. | 2021-06-24 20:00:02.247 HD Server | Thread:1164 (0) | CloseSocket call. | 2021-06-24 20:00:02.247 HD Server | Thread:1164 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-24 20:00:02.247 HD Server | Thread:1164 (3) | Closed. | 2021-06-24 20:00:02.247 HD Server | Thread:1164 (0) | CloseSocket call. | 2021-06-24 20:00:02.247 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:1164 | 2021-06-24 20:00:02.267 HD Server Manager | Current server count=1 | 2021-06-24 20:00:02.267 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4964 | 2021-06-24 20:00:02.267 HD Server Manager | Current server count=0 | 2021-06-24 20:00:02.267 Opened cached Intraday file: C:\SierraChart\Data\NGV21-NGF22.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-24 20:41:21.275 Requesting current DateTime from Sierra Chart server. | 2021-06-24 20:49:29.831 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 00:49:30.220. Round-trip delay: 00:00:00.200 | 2021-06-24 20:49:30.231 Computer time to server time difference: 00:00:00.011 | 2021-06-24 20:49:30.231 Successfully set the system Date-time to: 2021-06-25 00:49:30.220 UTC. | 2021-06-24 20:49:30.220 Opened cached Intraday file: C:\SierraChart\Data\NGN21-NGH22.FUT_SPREAD.NYMEX.scid. Thread ID: 5644 | 2021-06-24 21:48:11.294 Requesting current DateTime from Sierra Chart server. | 2021-06-24 21:49:29.804 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 01:49:30.203. Round-trip delay: 00:00:00.205 | 2021-06-24 21:49:30.214 Computer time to server time difference: 00:00:00.011 | 2021-06-24 21:49:30.214 Successfully set the system Date-time to: 2021-06-25 01:49:30.203 UTC. | 2021-06-24 21:49:30.203 Requesting current DateTime from Sierra Chart server. | 2021-06-24 22:49:29.769 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 02:49:30.158. Round-trip delay: 00:00:00.200 | 2021-06-24 22:49:30.169 Computer time to server time difference: 00:00:00.011 | 2021-06-24 22:49:30.169 Successfully set the system Date-time to: 2021-06-25 02:49:30.158 UTC. | 2021-06-24 22:49:30.158 Requesting current DateTime from Sierra Chart server. | 2021-06-24 23:49:29.728 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 03:49:30.113. Round-trip delay: 00:00:00.195 | 2021-06-24 23:49:30.118 Computer time to server time difference: 00:00:00.005 | 2021-06-24 23:49:30.118 Successfully set the system Date-time to: 2021-06-25 03:49:30.113 UTC. | 2021-06-24 23:49:30.113 Requesting current DateTime from Sierra Chart server. | 2021-06-25 00:49:29.701 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 04:49:30.083. Round-trip delay: 00:00:00.195 | 2021-06-25 00:49:30.091 Computer time to server time difference: 00:00:00.008 | 2021-06-25 00:49:30.091 Successfully set the system Date-time to: 2021-06-25 04:49:30.083 UTC. | 2021-06-25 00:49:30.083 Requesting current DateTime from Sierra Chart server. | 2021-06-25 01:49:29.666 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 05:49:30.058. Round-trip delay: 00:00:00.200 | 2021-06-25 01:49:30.066 Computer time to server time difference: 00:00:00.008 | 2021-06-25 01:49:30.066 Successfully set the system Date-time to: 2021-06-25 05:49:30.058 UTC. | 2021-06-25 01:49:30.058 SC DTC Data with Market Depth | Real-time data for symbol BTCUSDT_PERP_BINANCE is currently unavailable. | 2021-06-25 01:58:59.308 SC DTC Data with Market Depth | Received security definition for symbol BTCUSDT_PERP_BINANCE | 2021-06-25 01:59:12.558 SC DTC Data with Market Depth | Real-time data for symbol BTCUSDT_PERP_BINANCE has been restored. | 2021-06-25 01:59:12.558 Added historical Intraday data request for BTCUSDT_PERP_BINANCE to the queue. | 2021-06-25 01:59:12.568 Intraday data recording state for symbol BTCUSDT_PERP_BINANCE is set to download 'Pending'. | 2021-06-25 01:59:12.568 Triggering next historical data download in queue. | 2021-06-25 01:59:12.568 HD Request # 86 | Downloading Intraday chart data for BTCUSDT_PERP_BINANCE to the file BTCUSDT_PERP_BINANCE.scid. Service: binance_cryptocurrency.exchange.data | 2021-06-25 01:59:12.568 HD Request # 86 | Download start date-time: 2021-06-25 01:59:12.000000. File last date-time: 2021-06-25 01:59:12.246004 | 2021-06-25 01:59:12.568 HD Request # 86 | Using server: ds12.sierracharts.com port 10150 | 2021-06-25 01:59:12.568 Socket (3) | Creating socket. | 2021-06-25 01:59:12.568 Socket (3) | New receive buffer size: 5242880 | 2021-06-25 01:59:12.568 Socket (3) | Connecting to IP: 204.15.197.14. | 2021-06-25 01:59:12.568 HD Request # 86 | Setting DTC encoding to Binary VLS | 2021-06-25 01:59:12.668 HD Request # 86 | Sending historical data logon request message. | 2021-06-25 01:59:12.668 HD Request # 86 | Requesting Intraday data. Start date-time: 2021-06-25 01:59:12. Record interval: 0. Symbol: BTCUSDT_PERP_BINANCE | 2021-06-25 01:59:13.238 HD Request # 86 | Decompressing data. | 2021-06-25 01:59:13.278 HD Request # 86 | Receiving Intraday data for BTCUSDT_PERP_BINANCE starting at 2021-06-25 01:59:12.000000 | 2021-06-25 01:59:13.278 Socket (3) | CloseSocket call. | 2021-06-25 01:59:13.278 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-25 01:59:13.278 Historical data download thread signaled to stop. | 2021-06-25 01:59:13.278 HD Request # 86 | Received 1 record from 2021-06-25 01:59:12.000000 to 2021-06-25 01:59:12.000000 (0.0 seconds) and wrote 0 records for BTCUSDT_PERP_BINANCE | 2021-06-25 01:59:13.278 HD Request # 86 | Add time&sales data | Remembered last file record date-time: 2021-06-25 05:59:12.246004 | 2021-06-25 01:59:13.278 Added 15 Time and Sales records to Intraday data file for BTCUSDT_PERP_BINANCE after download. | 2021-06-25 01:59:13.278 HD Request # 86 | Timestamp of first Intraday data file record written: 2021-06-25 01:59:12.277000 | 2021-06-25 01:59:13.278 HD Request # 86 | Completion time: 1s | 2021-06-25 01:59:13.288 HD Request # 86 | Intraday data download complete for BTCUSDT_PERP_BINANCE. Unique request ID: 86 | 2021-06-25 01:59:13.288 Removing historical data download ID 86. | 2021-06-25 01:59:13.288 Real-time Intraday chart data file updates started for BTCUSDT_PERP_BINANCE | 2021-06-25 01:59:13.288 Intraday chart data file opened for BTCUSDT_PERP_BINANCE | 2021-06-25 01:59:13.288 HD Request # 86 | Enabling Intraday chart updating for symbol. | 2021-06-25 01:59:13.288 Triggering next historical data download in queue. | 2021-06-25 01:59:13.288 No download requests in the queue to start downloads for. | 2021-06-25 01:59:13.288 Socket (3) | Socket gracefully closed by remote side. | 2021-06-25 01:59:13.318 Socket (3) | Closed. | 2021-06-25 01:59:13.318 Opened cached Intraday file: C:\SierraChart\Data\BTCUSDT_PERP_BINANCE.scid. Thread ID: 5644 | 2021-06-25 01:59:16.318 Requesting current DateTime from Sierra Chart server. | 2021-06-25 02:49:29.636 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 06:49:30.017. Round-trip delay: 00:00:00.195 | 2021-06-25 02:49:30.026 Computer time to server time difference: 00:00:00.009 | 2021-06-25 02:49:30.026 Successfully set the system Date-time to: 2021-06-25 06:49:30.017 UTC. | 2021-06-25 02:49:30.017 SC DTC Data with Market Depth | Real-time data for symbol BTCUSDT_PERP_BINANCE is currently unavailable. | 2021-06-25 03:47:47.698 SC DTC Data with Market Depth | Received security definition for symbol BTCUSDT_PERP_BINANCE | 2021-06-25 03:48:03.478 SC DTC Data with Market Depth | Real-time data for symbol BTCUSDT_PERP_BINANCE has been restored. | 2021-06-25 03:48:03.478 Added historical Intraday data request for BTCUSDT_PERP_BINANCE to the queue. | 2021-06-25 03:48:03.478 Intraday data recording state for symbol BTCUSDT_PERP_BINANCE is set to download 'Pending'. | 2021-06-25 03:48:03.478 Triggering next historical data download in queue. | 2021-06-25 03:48:03.478 HD Request # 87 | Downloading Intraday chart data for BTCUSDT_PERP_BINANCE to the file BTCUSDT_PERP_BINANCE.scid. Service: binance_cryptocurrency.exchange.data | 2021-06-25 03:48:03.478 HD Request # 87 | Download start date-time: 2021-06-25 03:48:03.000000. File last date-time: 2021-06-25 03:48:03.169000 | 2021-06-25 03:48:03.478 HD Request # 87 | Using server: ds4.sierracharts.com port 10149 | 2021-06-25 03:48:03.478 Socket (3) | Creating socket. | 2021-06-25 03:48:03.478 Socket (3) | New receive buffer size: 5242880 | 2021-06-25 03:48:03.478 Socket (3) | Connecting to IP: 192.81.56.146. | 2021-06-25 03:48:03.478 HD Request # 87 | Setting DTC encoding to Binary VLS | 2021-06-25 03:48:03.558 HD Request # 87 | Sending historical data logon request message. | 2021-06-25 03:48:03.558 HD Request # 87 | Requesting Intraday data. Start date-time: 2021-06-25 03:48:03. Record interval: 0. Symbol: BTCUSDT_PERP_BINANCE | 2021-06-25 03:48:04.118 HD Request # 87 | Decompressing data. | 2021-06-25 03:48:04.158 HD Request # 87 | Receiving Intraday data for BTCUSDT_PERP_BINANCE starting at 2021-06-25 03:48:03.055000 | 2021-06-25 03:48:04.158 Socket (3) | CloseSocket call. | 2021-06-25 03:48:04.158 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-25 03:48:04.158 Historical data download thread signaled to stop. | 2021-06-25 03:48:04.158 HD Request # 87 | Received 1 record from 2021-06-25 03:48:03.055000 to 2021-06-25 03:48:03.055000 (0.0 seconds) and wrote 0 records for BTCUSDT_PERP_BINANCE | 2021-06-25 03:48:04.158 HD Request # 87 | Add time&sales data | Remembered last file record date-time: 2021-06-25 07:48:03.169000 | 2021-06-25 03:48:04.158 Added 25 Time and Sales records to Intraday data file for BTCUSDT_PERP_BINANCE after download. | 2021-06-25 03:48:04.158 HD Request # 87 | Timestamp of first Intraday data file record written: 2021-06-25 03:48:03.184000 | 2021-06-25 03:48:04.158 HD Request # 87 | Completion time: 1s | 2021-06-25 03:48:04.158 HD Request # 87 | Intraday data download complete for BTCUSDT_PERP_BINANCE. Unique request ID: 87 | 2021-06-25 03:48:04.158 Removing historical data download ID 87. | 2021-06-25 03:48:04.158 Real-time Intraday chart data file updates started for BTCUSDT_PERP_BINANCE | 2021-06-25 03:48:04.158 Intraday chart data file opened for BTCUSDT_PERP_BINANCE | 2021-06-25 03:48:04.158 HD Request # 87 | Enabling Intraday chart updating for symbol. | 2021-06-25 03:48:04.158 Triggering next historical data download in queue. | 2021-06-25 03:48:04.158 No download requests in the queue to start downloads for. | 2021-06-25 03:48:04.158 Socket (3) | Socket gracefully closed by remote side. | 2021-06-25 03:48:04.188 Socket (3) | Closed. | 2021-06-25 03:48:04.188 Opened cached Intraday file: C:\SierraChart\Data\BTCUSDT_PERP_BINANCE.scid. Thread ID: 5644 | 2021-06-25 03:48:06.278 Requesting current DateTime from Sierra Chart server. | 2021-06-25 03:49:29.598 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 07:49:29.978. Round-trip delay: 00:00:00.195 | 2021-06-25 03:49:29.988 Computer time to server time difference: 00:00:00.010 | 2021-06-25 03:49:29.988 Successfully set the system Date-time to: 2021-06-25 07:49:29.978 UTC. | 2021-06-25 03:49:29.978 Requesting current DateTime from Sierra Chart server. | 2021-06-25 04:49:29.566 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 08:49:29.956. Round-trip delay: 00:00:00.200 | 2021-06-25 04:49:29.966 Computer time to server time difference: 00:00:00.010 | 2021-06-25 04:49:29.966 Successfully set the system Date-time to: 2021-06-25 08:49:29.956 UTC. | 2021-06-25 04:49:29.956 Requesting current DateTime from Sierra Chart server. | 2021-06-25 05:49:29.527 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 09:49:29.910. Round-trip delay: 00:00:00.195 | 2021-06-25 05:49:29.917 Computer time to server time difference: 00:00:00.007 | 2021-06-25 05:49:29.917 Successfully set the system Date-time to: 2021-06-25 09:49:29.910 UTC. | 2021-06-25 05:49:29.910 Requesting current DateTime from Sierra Chart server. | 2021-06-25 06:49:29.495 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 10:49:29.878. Round-trip delay: 00:00:00.195 | 2021-06-25 06:49:29.885 Computer time to server time difference: 00:00:00.007 | 2021-06-25 06:49:29.885 Successfully set the system Date-time to: 2021-06-25 10:49:29.878 UTC. | 2021-06-25 06:49:29.878 Requesting current DateTime from Sierra Chart server. | 2021-06-25 07:49:29.460 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 11:49:29.843. Round-trip delay: 00:00:00.195 | 2021-06-25 07:49:29.850 Computer time to server time difference: 00:00:00.007 | 2021-06-25 07:49:29.850 Successfully set the system Date-time to: 2021-06-25 11:49:29.843 UTC. | 2021-06-25 07:49:29.843 Requesting current DateTime from Sierra Chart server. | 2021-06-25 08:49:29.442 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 12:49:29.824. Round-trip delay: 00:00:00.195 | 2021-06-25 08:49:29.832 Computer time to server time difference: 00:00:00.008 | 2021-06-25 08:49:29.832 Successfully set the system Date-time to: 2021-06-25 12:49:29.824 UTC. | 2021-06-25 08:49:29.824 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:51.547 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:51.547 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:52.140 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:52.140 NGU21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:52.187 NGU21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:52.187 NGV21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:52.436 NGV21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:52.436 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:52.452 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:52.452 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:52.467 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:52.467 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:52.686 NGN21-NGQ21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:52.686 NGN21-NGU21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:52.889 NGN21-NGU21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:52.889 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:52.935 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:52.935 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:53.154 NGN21-NGH22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:53.154 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:53.201 NGN21-NGV21.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:53.201 NGTN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:53.232 NGTN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:53.232 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:53.575 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:53.575 SIN21-COMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:53.606 SIN21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:53.606 Requesting market depth updates for: SIN21-COMEX if supported. | 2021-06-25 08:59:53.793 SC Data - All Services (Market Orders Data) | Starting market orders updates for: SIN21. MinimumMarketByOrderQuantity: 0. Service code: comex | 2021-06-25 08:59:53.793 ZSN21-CBOT[M] #9 | Reloading chart. | 2021-06-25 08:59:53.918 ZSN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:53.918 SC Data - All Services | Clearing market depth for SIN21-COMEX | 2021-06-25 08:59:53.918 ZCN21-CBOT[M] #9 | Reloading chart. | 2021-06-25 08:59:53.949 ZCN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:53.949 ZWN21-CBOT[M] #9 | Reloading chart. | 2021-06-25 08:59:54.293 ZWN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:54.293 ESU21-CME[M] #9 | Reloading chart. | 2021-06-25 08:59:54.636 ESU21-CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:54.636 CLN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:54.698 CLN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:54.698 CLQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:54.979 CLQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:54.979 CLTN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:55.041 CLTN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:55.041 RBN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:55.369 RBN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:55.369 HGN21-COMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:55.385 HGN21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:55.385 GCQ21-COMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:55.728 GCQ21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:55.728 BTCM21-CME[M] #9 | Reloading chart. | 2021-06-25 08:59:56.149 BTCM21-CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:56.149 BTCUSDT_PERP_BINANCE[M] #9 | Reloading chart. | 2021-06-25 08:59:56.180 BTCUSDT_PERP_BINANCE[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:56.180 BTCM21-CME[M] #9 | Reloading chart. | 2021-06-25 08:59:57.132 BTCM21-CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.132 GCQ21-COMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:57.132 GCQ21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.132 HGN21-COMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:57.132 HGN21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.132 RBN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:57.147 RBN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.147 CLTN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:57.381 CLTN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.381 CLQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:57.397 CLQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.397 CLN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:57.428 CLN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.428 ESU21-CME[M] #9 | Reloading chart. | 2021-06-25 08:59:57.428 ESU21-CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.428 ZWN21-CBOT[M] #9 | Reloading chart. | 2021-06-25 08:59:57.459 ZWN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.459 ZCN21-CBOT[M] #9 | Reloading chart. | 2021-06-25 08:59:57.756 ZCN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.756 ZSN21-CBOT[M] #9 | Reloading chart. | 2021-06-25 08:59:57.771 ZSN21-CBOT[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.771 SIN21-COMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:57.787 SIN21-COMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.787 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:57.849 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:57.849 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | Reloading chart. | 2021-06-25 08:59:58.068 NGV21-NGF22.FUT_SPREAD.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 08:59:58.068 Unsubscribed from market depth data for SIN21-COMEX | 2021-06-25 08:59:58.801 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: SIN21.. Service code: comex | 2021-06-25 08:59:58.801 Requesting market depth updates for: NGV21-NGF22.FUT_SPREAD.NYMEX if supported. | 2021-06-25 08:59:58.801 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGV21-NGF22.FUT_SPREAD.NYMEX. MinimumMarketByOrderQuantity: 0. Service code: nymex | 2021-06-25 08:59:58.801 SC Data - All Services | Clearing market depth for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-25 08:59:58.895 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 09:00:00.158 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 09:00:00.158 Unsubscribed from market depth data for NGV21-NGF22.FUT_SPREAD.NYMEX | 2021-06-25 09:00:03.809 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: NGV21-NGF22.FUT_SPREAD.NYMEX.. Service code: nymex | 2021-06-25 09:00:03.809 NGQ21-NYMEX[M] Point & Figure 1-10 #1 | Reloading chart. | 2021-06-25 09:00:38.363 NGQ21-NYMEX[M] Point & Figure 1-10 #1 | Reloading chart. | 2021-06-25 09:01:07.706 NGQ21-NYMEX[M] Point & Figure 1-10 #1 | Reloading chart. | 2021-06-25 09:02:27.220 NGQ21-NYMEX[M] Point & Figure 1-10 #1 | Reloading chart. | 2021-06-25 09:02:40.339 NGQ21-NYMEX[M] Point & Figure 1-10 #1 | Reloading chart. | 2021-06-25 09:02:42.305 Requesting current DateTime from Sierra Chart server. | 2021-06-25 09:49:29.406 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 13:49:29.797. Round-trip delay: 00:00:00.202 | 2021-06-25 09:49:29.811 Computer time to server time difference: 00:00:00.013 | 2021-06-25 09:49:29.811 Successfully set the system Date-time to: 2021-06-25 13:49:29.797 UTC. | 2021-06-25 09:49:29.797 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 09:53:51.955 HD Server Manager | Started new historical data server. Count=1 | 2021-06-25 09:53:51.955 HD Server | Thread:508 (3) | Creating socket. | 2021-06-25 09:53:51.971 HD Server | Thread:508 (3) | New receive buffer size: 262144 | 2021-06-25 09:53:51.971 HD Server | Setting DTC encoding to Binary VLS | Thread:508 | 2021-06-25 09:53:51.971 HD Server | Thread:508 (3) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-25 09:53:51.971 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:508 | 2021-06-25 09:53:51.971 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:508 | 2021-06-25 09:53:51.971 HD Server | HD Request #151 | Socket: 3 | Symbol: NGN21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 1971-06-26 01:53:51 | ClientReqID: 151 | Username: SPRDTRDR. | Thread:508 | 2021-06-25 09:53:51.971 Added historical Daily data request for NGN21 to the queue. | 2021-06-25 09:53:51.971 Triggering next historical data download in queue. | 2021-06-25 09:53:51.971 Mapping NGN21 to NGN21. Service code: nymex | 2021-06-25 09:53:51.971 HD Request # 88 | Downloading Historical Daily chart data for NGN21. Starting date: 2021-06-16. Service: scdataallservices | 2021-06-25 09:53:51.986 HD Request # 88 | Requesting historical Daily data for NGN21 starting at 2021-06-15. SC External HD service. | 2021-06-25 09:53:52.470 HD Request # 88 | Receiving historical Daily data for NGN21 starting at 2021-06-16 | 2021-06-25 09:53:52.735 HD Request # 88 | Writing historical Daily data to the file NGN21.dly | 2021-06-25 09:53:52.735 HD Request # 88 | Bytes received: 481 | 2021-06-25 09:53:52.751 HD Request # 88 | Received 9 records from 2021-06-16 00:00:00 to 2021-06-25 00:00:00 (10.0 days) and wrote 8 records for NGN21 | 2021-06-25 09:53:52.751 HD Request # 88 | Completion time: 1s | 2021-06-25 09:53:52.766 HD Request # 88 | Daily data download complete for NGN21. Unique request ID: 88 | 2021-06-25 09:53:52.766 Removing historical data download ID 88. | 2021-06-25 09:53:52.766 Triggering next historical data download in queue. | 2021-06-25 09:53:52.766 No download requests in the queue to start downloads for. | 2021-06-25 09:53:52.766 HD Server | HD Request | Socket: 3 | Symbol: NGN21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3170 | ClientReqID: 151 | Username: SPRDTRDR. | Thread:508 | 2021-06-25 09:53:53.000 HD Server | Thread:508 (3) | Socket gracefully closed by remote side. | 2021-06-25 09:53:53.016 HD Server | Thread:508 (3) | CloseSocket call. | 2021-06-25 09:53:53.016 HD Server | Thread:508 (0) | CloseSocket call. | 2021-06-25 09:53:53.016 HD Server | Thread:508 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 09:53:53.016 HD Server | Thread:508 (3) | Closed. | 2021-06-25 09:53:53.016 HD Server | Thread:508 (0) | CloseSocket call. | 2021-06-25 09:53:53.016 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:508 | 2021-06-25 09:53:53.063 HD Server Manager | Current server count=0 | 2021-06-25 09:53:53.063 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 09:53:53.468 HD Server Manager | Started new historical data server. Count=1 | 2021-06-25 09:53:53.468 HD Server | Thread:2844 (3) | Creating socket. | 2021-06-25 09:53:53.468 HD Server | Thread:2844 (3) | New receive buffer size: 262144 | 2021-06-25 09:53:53.468 HD Server | Setting DTC encoding to Binary VLS | Thread:2844 | 2021-06-25 09:53:53.468 HD Server | Thread:2844 (3) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-25 09:53:53.468 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:2844 | 2021-06-25 09:53:53.468 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:2844 | 2021-06-25 09:53:53.468 HD Server | HD Request #152 | Socket: 3 | Symbol: NGQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-22 00:00:00 | ClientReqID: 152 | Username: SPRDTRDR. | Thread:2844 | 2021-06-25 09:53:53.468 Added historical Daily data request for NGQ21-NYMEX to the queue. | 2021-06-25 09:53:53.468 Triggering next historical data download in queue. | 2021-06-25 09:53:53.468 HD Request # 89 | Downloading Historical Daily chart data for NGQ21-NYMEX. Starting date: 2021-06-22. Service: scdataallservices | 2021-06-25 09:53:53.484 SC Data - All Services | Starting real-time market data updates for: NGN21 (NGN21). ID: 50 Service code: nymex | 2021-06-25 09:53:53.687 SC Data - All Services | Requesting security definition data for: NGN21 (NGN21). ID: 50 | 2021-06-25 09:53:53.687 Requesting market depth updates for: NGN21 if supported. | 2021-06-25 09:53:53.687 SC Data - All Services (Market Orders Data) | Starting market orders updates for: NGN21. MinimumMarketByOrderQuantity: 10. Service code: nymex | 2021-06-25 09:53:53.687 Symbol Error - NGN21 is unknown, unavailable, or improperly formatted. Already subscribed to symbol. New subscription rejected. | 2021-06-25 09:53:53.749 SC Data - All Services | Received security definition for symbol NGN21 | 2021-06-25 09:53:53.749 SC Data - All Services | Market Depth data has been rejected for symbol: NGN21. Already subscribed to market depth for symbol NGN21 for service code nymex. Rejecting new subscription. | 2021-06-25 09:53:53.749 Symbol Error - NGN21 is unknown, unavailable, or improperly formatted. Already subscribed to symbol. New subscription rejected. | 2021-06-25 09:53:53.811 SC Data - All Services (Market Orders Data) | Market Orders data has been rejected for symbol: NGN21. Already subscribed to market orders for symbol NGN21 for service code nymex. Rejecting new subscription. | 2021-06-25 09:53:53.811 HD Request # 89 | Requesting historical Daily data for NGQ21 starting at 2021-06-21. SC External HD service. | 2021-06-25 09:53:53.967 HD Request # 89 | Receiving historical Daily data for NGQ21-NYMEX starting at 2021-06-22 | 2021-06-25 09:53:54.123 HD Request # 89 | Writing historical Daily data to the file NGQ21-NYMEX.dly | 2021-06-25 09:53:54.123 HD Request # 89 | Bytes received: 268 | 2021-06-25 09:53:54.139 HD Request # 89 | Received 5 records from 2021-06-22 00:00:00 to 2021-06-25 00:00:00 (4.0 days) and wrote 4 records for NGQ21-NYMEX | 2021-06-25 09:53:54.139 HD Request # 89 | Completion time: 1s | 2021-06-25 09:53:54.139 HD Request # 89 | Daily data download complete for NGQ21-NYMEX. Unique request ID: 89 | 2021-06-25 09:53:54.139 Removing historical data download ID 89. | 2021-06-25 09:53:54.139 Triggering next historical data download in queue. | 2021-06-25 09:53:54.139 No download requests in the queue to start downloads for. | 2021-06-25 09:53:54.139 HD Server | HD Request | Socket: 3 | Symbol: NGQ21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 152 | Username: SPRDTRDR. | Thread:2844 | 2021-06-25 09:53:54.498 HD Server | Thread:2844 (3) | Socket gracefully closed by remote side. | 2021-06-25 09:53:54.513 HD Server | Thread:2844 (3) | CloseSocket call. | 2021-06-25 09:53:54.513 HD Server | Thread:2844 (0) | CloseSocket call. | 2021-06-25 09:53:54.513 HD Server | Thread:2844 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 09:53:54.513 HD Server | Thread:2844 (3) | Closed. | 2021-06-25 09:53:54.513 HD Server | Thread:2844 (0) | CloseSocket call. | 2021-06-25 09:53:54.513 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:2844 | 2021-06-25 09:53:54.623 HD Server Manager | Current server count=0 | 2021-06-25 09:53:54.623 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 10:43:29.513 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 10:43:29.528 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 10:43:44.785 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 10:43:44.785 Requesting current DateTime from Sierra Chart server. | 2021-06-25 10:49:29.374 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 14:49:29.753. Round-trip delay: 00:00:00.195 | 2021-06-25 10:49:29.764 Computer time to server time difference: 00:00:00.011 | 2021-06-25 10:49:29.764 Successfully set the system Date-time to: 2021-06-25 14:49:29.753 UTC. | 2021-06-25 10:49:29.753 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 10:51:12.697 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 10:51:12.697 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 10:52:16.688 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 10:52:16.688 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 10:57:45.287 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 10:57:45.287 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:10:09.409 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:10:09.409 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:11:12.838 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:11:12.838 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:13:01.633 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:13:01.633 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:13:29.885 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:13:29.885 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 11:15:40.088 HD Server Manager | Started new historical data server. Count=1 | 2021-06-25 11:15:40.088 HD Server | Thread:2724 (3) | Creating socket. | 2021-06-25 11:15:40.104 HD Server | Thread:2724 (3) | New receive buffer size: 262144 | 2021-06-25 11:15:40.104 HD Server | Thread:2724 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-25 11:15:40.104 HD Server | Setting DTC encoding to Binary VLS | Thread:2724 | 2021-06-25 11:15:40.104 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:2724 | 2021-06-25 11:15:40.104 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:2724 | 2021-06-25 11:15:40.104 HD Server | HD Request #153 | Socket: 3 | Symbol: VXN21-CFE | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-21 00:00:00 | ClientReqID: 153 | Username: SPRDTRDR. | Thread:2724 | 2021-06-25 11:15:40.104 Added historical Daily data request for VXN21-CFE to the queue. | 2021-06-25 11:15:40.104 Triggering next historical data download in queue. | 2021-06-25 11:15:40.104 HD Request # 90 | Downloading Historical Daily chart data for VXN21-CFE. Starting date: 2021-06-21. Service: cfefut | 2021-06-25 11:15:40.104 HD Request # 90 | Requesting historical Daily data for VIN21 starting at 2021-06-20. SC External HD service. | 2021-06-25 11:15:40.587 HD Request # 90 | Receiving historical Daily data for VXN21-CFE starting at 2021-06-21 | 2021-06-25 11:15:40.853 HD Request # 90 | Writing historical Daily data to the file VXN21-CFE.dly | 2021-06-25 11:15:40.853 HD Request # 90 | Bytes received: 216 | 2021-06-25 11:15:40.853 HD Request # 90 | Received 4 records from 2021-06-21 00:00:00 to 2021-06-24 00:00:00 (4.0 days) and wrote 4 records for VXN21-CFE | 2021-06-25 11:15:40.853 HD Request # 90 | Completion time: 0s | 2021-06-25 11:15:40.853 HD Request # 90 | Daily data download complete for VXN21-CFE. Unique request ID: 90 | 2021-06-25 11:15:40.853 Removing historical data download ID 90. | 2021-06-25 11:15:40.853 Triggering next historical data download in queue. | 2021-06-25 11:15:40.853 No download requests in the queue to start downloads for. | 2021-06-25 11:15:40.853 HD Server | HD Request | Socket: 3 | Symbol: VXN21-CFE | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 153 | Username: SPRDTRDR. | Thread:2724 | 2021-06-25 11:15:41.118 HD Server | Thread:2724 (3) | Socket gracefully closed by remote side. | 2021-06-25 11:15:41.118 HD Server | Thread:2724 (3) | CloseSocket call. | 2021-06-25 11:15:41.118 HD Server | Thread:2724 (0) | CloseSocket call. | 2021-06-25 11:15:41.118 HD Server | Thread:2724 (0) | CloseSocket call. | 2021-06-25 11:15:41.118 HD Server | Thread:2724 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 11:15:41.118 HD Server | Thread:2724 (3) | Closed. | 2021-06-25 11:15:41.118 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:2724 | 2021-06-25 11:15:41.289 HD Server Manager | Current server count=0 | 2021-06-25 11:15:41.289 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 11:15:41.477 HD Server Manager | Started new historical data server. Count=1 | 2021-06-25 11:15:41.477 HD Server | Thread:4128 (3) | Creating socket. | 2021-06-25 11:15:41.477 HD Server | Thread:4128 (3) | New receive buffer size: 262144 | 2021-06-25 11:15:41.477 HD Server | Thread:4128 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-25 11:15:41.477 HD Server | Setting DTC encoding to Binary VLS | Thread:4128 | 2021-06-25 11:15:41.477 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:4128 | 2021-06-25 11:15:41.477 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:4128 | 2021-06-25 11:15:41.477 HD Server | HD Request #154 | Socket: 3 | Symbol: VIF21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-01-12 00:00:00 | ClientReqID: 154 | Username: SPRDTRDR. | Thread:4128 | 2021-06-25 11:15:41.477 HD Server | HD Request | Socket: 3 | Symbol: VIF21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 154 | Username: SPRDTRDR. | Thread:4128 | 2021-06-25 11:15:41.492 HD Server | Thread:4128 (3) | Socket gracefully closed by remote side. | 2021-06-25 11:15:41.492 HD Server | Thread:4128 (3) | CloseSocket call. | 2021-06-25 11:15:41.492 HD Server | Thread:4128 (0) | CloseSocket call. | 2021-06-25 11:15:41.492 HD Server | Thread:4128 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 11:15:41.492 HD Server | Thread:4128 (3) | Closed. | 2021-06-25 11:15:41.492 HD Server | Thread:4128 (0) | CloseSocket call. | 2021-06-25 11:15:41.492 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 11:15:41.508 HD Server Manager | Started new historical data server. Count=2 | 2021-06-25 11:15:41.508 HD Server | Thread:5500 (3) | Creating socket. | 2021-06-25 11:15:41.508 HD Server | Thread:5500 (3) | New receive buffer size: 262144 | 2021-06-25 11:15:41.508 HD Server | Thread:5500 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-25 11:15:41.508 HD Server | Setting DTC encoding to Binary VLS | Thread:5500 | 2021-06-25 11:15:41.508 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:5500 | 2021-06-25 11:15:41.508 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:5500 | 2021-06-25 11:15:41.508 HD Server | HD Request #155 | Socket: 3 | Symbol: VIJ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-04-13 00:00:00 | ClientReqID: 155 | Username: SPRDTRDR. | Thread:5500 | 2021-06-25 11:15:41.508 HD Server | HD Request | Socket: 3 | Symbol: VIJ21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 155 | Username: SPRDTRDR. | Thread:5500 | 2021-06-25 11:15:41.523 HD Server | Thread:5500 (3) | Socket gracefully closed by remote side. | 2021-06-25 11:15:41.523 HD Server | Thread:5500 (3) | CloseSocket call. | 2021-06-25 11:15:41.523 HD Server | Thread:5500 (0) | CloseSocket call. | 2021-06-25 11:15:41.523 HD Server | Thread:5500 (0) | CloseSocket call. | 2021-06-25 11:15:41.523 HD Server | Thread:5500 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 11:15:41.523 HD Server | Thread:5500 (3) | Closed. | 2021-06-25 11:15:41.523 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 11:15:41.523 HD Server Manager | Started new historical data server. Count=3 | 2021-06-25 11:15:41.523 HD Server | Thread:7100 (3) | Creating socket. | 2021-06-25 11:15:41.539 HD Server | Thread:7100 (3) | New receive buffer size: 262144 | 2021-06-25 11:15:41.539 HD Server | Thread:7100 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-25 11:15:41.539 HD Server | Setting DTC encoding to Binary VLS | Thread:7100 | 2021-06-25 11:15:41.539 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:7100 | 2021-06-25 11:15:41.539 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:7100 | 2021-06-25 11:15:41.539 HD Server | HD Request #156 | Socket: 3 | Symbol: VIK21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-05-11 00:00:00 | ClientReqID: 156 | Username: SPRDTRDR. | Thread:7100 | 2021-06-25 11:15:41.539 HD Server | HD Request | Socket: 3 | Symbol: VIK21 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 156 | Username: SPRDTRDR. | Thread:7100 | 2021-06-25 11:15:41.539 HD Server | Thread:7100 (3) | Socket gracefully closed by remote side. | 2021-06-25 11:15:41.539 HD Server | Thread:7100 (3) | CloseSocket call. | 2021-06-25 11:15:41.539 HD Server | Thread:7100 (0) | CloseSocket call. | 2021-06-25 11:15:41.539 HD Server | Thread:7100 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 11:15:41.539 HD Server | Thread:7100 (3) | Closed. | 2021-06-25 11:15:41.539 HD Server | Thread:7100 (0) | CloseSocket call. | 2021-06-25 11:15:41.539 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:7100 | 2021-06-25 11:15:41.555 HD Server Manager | Current server count=2 | 2021-06-25 11:15:41.555 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:5500 | 2021-06-25 11:15:41.555 HD Server Manager | Current server count=1 | 2021-06-25 11:15:41.555 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:4128 | 2021-06-25 11:15:41.555 HD Server Manager | Current server count=0 | 2021-06-25 11:15:41.555 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 11:15:45.111 HD Server Manager | Started new historical data server. Count=1 | 2021-06-25 11:15:45.111 HD Server | Thread:7068 (3) | Creating socket. | 2021-06-25 11:15:45.111 HD Server | Thread:7068 (3) | New receive buffer size: 262144 | 2021-06-25 11:15:45.111 HD Server | Thread:7068 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-25 11:15:45.111 HD Server | Setting DTC encoding to Binary VLS | Thread:7068 | 2021-06-25 11:15:45.111 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:7068 | 2021-06-25 11:15:45.111 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:7068 | 2021-06-25 11:15:45.111 HD Server | HD Request #157 | Socket: 3 | Symbol: CLK21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-04-13 00:00:00 | ClientReqID: 157 | Username: SPRDTRDR. | Thread:7068 | 2021-06-25 11:15:45.111 HD Server | HD Request | Socket: 3 | Symbol: CLK21-NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 157 | Username: SPRDTRDR. | Thread:7068 | 2021-06-25 11:15:45.127 HD Server | Thread:7068 (3) | Socket gracefully closed by remote side. | 2021-06-25 11:15:45.143 HD Server | Thread:7068 (3) | CloseSocket call. | 2021-06-25 11:15:45.143 HD Server | Thread:7068 (0) | CloseSocket call. | 2021-06-25 11:15:45.143 HD Server | Thread:7068 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 11:15:45.143 HD Server | Thread:7068 (3) | Closed. | 2021-06-25 11:15:45.143 HD Server | Thread:7068 (0) | CloseSocket call. | 2021-06-25 11:15:45.143 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:7068 | 2021-06-25 11:15:45.189 HD Server Manager | Current server count=0 | 2021-06-25 11:15:45.189 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 11:15:47.249 HD Server Manager | Started new historical data server. Count=1 | 2021-06-25 11:15:47.249 HD Server | Thread:2840 (3) | Creating socket. | 2021-06-25 11:15:47.249 HD Server | Thread:2840 (3) | New receive buffer size: 262144 | 2021-06-25 11:15:47.249 HD Server | Thread:2840 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-25 11:15:47.249 HD Server | Setting DTC encoding to Binary VLS | Thread:2840 | 2021-06-25 11:15:47.249 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:2840 | 2021-06-25 11:15:47.249 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:2840 | 2021-06-25 11:15:47.249 HD Server | HD Request #158 | Socket: 3 | Symbol: CLM20 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2011-11-29 00:00:00 | ClientReqID: 158 | Username: SPRDTRDR. | Thread:2840 | 2021-06-25 11:15:47.249 HD Server | HD Request | Socket: 3 | Symbol: CLM20 | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 3 | ClientReqID: 158 | Username: SPRDTRDR. | Thread:2840 | 2021-06-25 11:15:47.264 HD Server | Thread:2840 (3) | Socket gracefully closed by remote side. | 2021-06-25 11:15:47.264 HD Server | Thread:2840 (3) | CloseSocket call. | 2021-06-25 11:15:47.264 HD Server | Thread:2840 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 11:15:47.264 HD Server | Thread:2840 (3) | Closed. | 2021-06-25 11:15:47.264 HD Server | Thread:2840 (0) | CloseSocket call. | 2021-06-25 11:15:47.264 HD Server | Thread:2840 (0) | CloseSocket call. | 2021-06-25 11:15:47.264 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:2840 | 2021-06-25 11:15:47.280 HD Server Manager | Current server count=0 | 2021-06-25 11:15:47.280 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 11:15:59.073 HD Server Manager | Started new historical data server. Count=1 | 2021-06-25 11:15:59.073 HD Server | Thread:6104 (3) | Creating socket. | 2021-06-25 11:15:59.089 HD Server | Thread:6104 (3) | New receive buffer size: 262144 | 2021-06-25 11:15:59.089 HD Server | Thread:6104 (3) | Allocated send buffers: 32 of 4096 bytes. | 2021-06-25 11:15:59.089 HD Server | Setting DTC encoding to Binary VLS | Thread:6104 | 2021-06-25 11:15:59.089 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6104 | 2021-06-25 11:15:59.089 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6104 | 2021-06-25 11:15:59.089 HD Server | HD Request #159 | Socket: 3 | Symbol: DXU21-ICEUS | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-22 00:00:00 | ClientReqID: 159 | Username: SPRDTRDR. | Thread:6104 | 2021-06-25 11:15:59.089 Added historical Daily data request for DXU21-ICEUS to the queue. | 2021-06-25 11:15:59.089 Triggering next historical data download in queue. | 2021-06-25 11:15:59.089 HD Request # 91 | Downloading Historical Daily chart data for DXU21-ICEUS. Starting date: 2021-06-22. Service: ice.us | 2021-06-25 11:15:59.089 HD Request # 91 | Requesting historical Daily data for DXU21 starting at 2021-06-21. SC External HD service. | 2021-06-25 11:15:59.588 HD Request # 91 | Receiving historical Daily data for DXU21-ICEUS starting at 2021-06-22 | 2021-06-25 11:15:59.744 HD Request # 91 | Writing historical Daily data to the file DXU21-ICEUS.dly | 2021-06-25 11:15:59.744 HD Request # 91 | Bytes received: 283 | 2021-06-25 11:15:59.744 HD Request # 91 | Received 5 records from 2021-06-22 00:00:00 to 2021-06-25 00:00:00 (4.0 days) and wrote 4 records for DXU21-ICEUS | 2021-06-25 11:15:59.744 HD Request # 91 | Completion time: 0s | 2021-06-25 11:15:59.744 HD Request # 91 | Daily data download complete for DXU21-ICEUS. Unique request ID: 91 | 2021-06-25 11:15:59.744 Removing historical data download ID 91. | 2021-06-25 11:15:59.744 Triggering next historical data download in queue. | 2021-06-25 11:15:59.744 No download requests in the queue to start downloads for. | 2021-06-25 11:15:59.744 HD Server | HD Request | Socket: 3 | Symbol: DXU21-ICEUS | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 159 | Username: SPRDTRDR. | Thread:6104 | 2021-06-25 11:16:00.103 HD Server | Thread:6104 (3) | Socket gracefully closed by remote side. | 2021-06-25 11:16:00.103 HD Server | Thread:6104 (3) | CloseSocket call. | 2021-06-25 11:16:00.103 HD Server | Thread:6104 (0) | CloseSocket call. | 2021-06-25 11:16:00.103 HD Server | Thread:6104 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 11:16:00.103 HD Server | Thread:6104 (3) | Closed. | 2021-06-25 11:16:00.103 HD Server | Thread:6104 (0) | CloseSocket call. | 2021-06-25 11:16:00.103 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6104 | 2021-06-25 11:16:00.275 HD Server Manager | Current server count=0 | 2021-06-25 11:16:00.275 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 11:16:01.413 HD Server Manager | Started new historical data server. Count=1 | 2021-06-25 11:16:01.413 HD Server | Thread:6600 (3) | Creating socket. | 2021-06-25 11:16:01.413 HD Server | Thread:6600 (3) | New receive buffer size: 262144 | 2021-06-25 11:16:01.413 HD Server | Setting DTC encoding to Binary VLS | Thread:6600 | 2021-06-25 11:16:01.413 HD Server | Thread:6600 (3) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-25 11:16:01.413 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6600 | 2021-06-25 11:16:01.413 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6600 | 2021-06-25 11:16:01.413 HD Server | HD Request #162 | Socket: 3 | Symbol: ESU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-22 00:00:00 | ClientReqID: 162 | Username: SPRDTRDR. | Thread:6600 | 2021-06-25 11:16:01.413 Added historical Daily data request for ESU21-CME to the queue. | 2021-06-25 11:16:01.413 Triggering next historical data download in queue. | 2021-06-25 11:16:01.413 HD Request # 92 | Downloading Historical Daily chart data for ESU21-CME. Starting date: 2021-06-22. Service: scdataallservices | 2021-06-25 11:16:01.429 HD Request # 92 | Requesting historical Daily data for ESU21 starting at 2021-06-21. SC External HD service. | 2021-06-25 11:16:01.913 HD Request # 92 | Receiving historical Daily data for ESU21-CME starting at 2021-06-22 | 2021-06-25 11:16:02.053 HD Request # 92 | Writing historical Daily data to the file ESU21-CME.dly | 2021-06-25 11:16:02.053 HD Request # 92 | Bytes received: 305 | 2021-06-25 11:16:02.053 HD Request # 92 | Received 5 records from 2021-06-22 00:00:00 to 2021-06-25 00:00:00 (4.0 days) and wrote 4 records for ESU21-CME | 2021-06-25 11:16:02.053 HD Request # 92 | Completion time: 1s | 2021-06-25 11:16:02.053 HD Request # 92 | Daily data download complete for ESU21-CME. Unique request ID: 92 | 2021-06-25 11:16:02.053 Removing historical data download ID 92. | 2021-06-25 11:16:02.053 Triggering next historical data download in queue. | 2021-06-25 11:16:02.053 No download requests in the queue to start downloads for. | 2021-06-25 11:16:02.053 HD Server | Thread:6600 (3) | Socket gracefully closed by remote side. | 2021-06-25 11:16:02.427 HD Server | HD Request | Socket: 3 | Symbol: ESU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 162 | Username: SPRDTRDR. | Thread:6600 | 2021-06-25 11:16:02.427 HD Server | Thread:6600 (3) | CloseSocket call. | 2021-06-25 11:16:02.427 HD Server | Thread:6600 (0) | CloseSocket call. | 2021-06-25 11:16:02.427 HD Server | Thread:6600 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 11:16:02.427 HD Server | Thread:6600 (3) | Closed. | 2021-06-25 11:16:02.427 HD Server | Thread:6600 (0) | CloseSocket call. | 2021-06-25 11:16:02.427 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-06-25 11:16:02.443 HD Server Manager | Started new historical data server. Count=2 | 2021-06-25 11:16:02.443 HD Server | Thread:6920 (3) | Creating socket. | 2021-06-25 11:16:02.443 HD Server | Thread:6920 (3) | New receive buffer size: 262144 | 2021-06-25 11:16:02.443 HD Server | Setting DTC encoding to Binary VLS | Thread:6920 | 2021-06-25 11:16:02.443 HD Server | Thread:6920 (3) | Allocated send buffers: 31 of 4096 bytes. | 2021-06-25 11:16:02.443 HD Server | Received login. Requesting authorization. | Username: SPRDTRDR. | Thread:6920 | 2021-06-25 11:16:02.459 HD Server | Login has been authorized. | Username: SPRDTRDR. | Thread:6920 | 2021-06-25 11:16:02.459 HD Server | HD Request #163 | Socket: 3 | Symbol: 6EU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | MaximumDaysRequested: 0 | Start date-time: 2021-06-22 00:00:00 | ClientReqID: 163 | Username: SPRDTRDR. | Thread:6920 | 2021-06-25 11:16:02.459 Added historical Daily data request for 6EU21-CME to the queue. | 2021-06-25 11:16:02.459 Triggering next historical data download in queue. | 2021-06-25 11:16:02.459 HD Request # 93 | Downloading Historical Daily chart data for 6EU21-CME. Starting date: 2021-06-22. Service: scdataallservices | 2021-06-25 11:16:02.474 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6600 | 2021-06-25 11:16:02.615 HD Server Manager | Current server count=1 | 2021-06-25 11:16:02.615 HD Request # 93 | Requesting historical Daily data for E6U21 starting at 2021-06-21. SC External HD service. | 2021-06-25 11:16:02.958 HD Request # 93 | Receiving historical Daily data for 6EU21-CME starting at 2021-06-22 | 2021-06-25 11:16:03.083 HD Request # 93 | Writing historical Daily data to the file 6EU21-CME.dly | 2021-06-25 11:16:03.083 HD Request # 93 | Bytes received: 302 | 2021-06-25 11:16:03.098 HD Request # 93 | Received 5 records from 2021-06-22 00:00:00 to 2021-06-25 00:00:00 (4.0 days) and wrote 4 records for 6EU21-CME | 2021-06-25 11:16:03.098 HD Request # 93 | Completion time: 1s | 2021-06-25 11:16:03.098 HD Request # 93 | Daily data download complete for 6EU21-CME. Unique request ID: 93 | 2021-06-25 11:16:03.098 Removing historical data download ID 93. | 2021-06-25 11:16:03.098 Triggering next historical data download in queue. | 2021-06-25 11:16:03.098 No download requests in the queue to start downloads for. | 2021-06-25 11:16:03.098 HD Server | HD Request | Socket: 3 | Symbol: 6EU21-CME | ServiceCode: DTCSubInstance | RecordInterval: 86400 | Records Served: 4 | ClientReqID: 163 | Username: SPRDTRDR. | Thread:6920 | 2021-06-25 11:16:03.473 HD Server | Thread:6920 (3) | Socket gracefully closed by remote side. | 2021-06-25 11:16:03.473 HD Server | Thread:6920 (3) | CloseSocket call. | 2021-06-25 11:16:03.473 HD Server | Thread:6920 (0) | CloseSocket call. | 2021-06-25 11:16:03.473 HD Server | Thread:6920 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 11:16:03.473 HD Server | Thread:6920 (3) | Closed. | 2021-06-25 11:16:03.488 HD Server | Thread:6920 (0) | CloseSocket call. | 2021-06-25 11:16:03.488 HD Server | Server thread ending. Closing socket. | Username: SPRDTRDR. | Thread:6920 | 2021-06-25 11:16:03.644 HD Server Manager | Current server count=0 | 2021-06-25 11:16:03.644 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:22:10.604 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:22:10.604 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:28:04.896 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:28:04.896 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:28:10.169 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:28:10.169 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:28:53.646 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:28:53.646 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:40:12.872 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:40:12.872 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 11:41:40.419 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 11:41:40.419 Requesting current DateTime from Sierra Chart server. | 2021-06-25 11:49:29.340 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 15:49:29.726. Round-trip delay: 00:00:00.195 | 2021-06-25 11:49:29.730 Computer time to server time difference: 00:00:00.004 | 2021-06-25 11:49:29.730 Successfully set the system Date-time to: 2021-06-25 15:49:29.726 UTC. | 2021-06-25 11:49:29.726 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 12:00:19.810 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 12:00:19.810 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 12:12:30.234 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 12:12:30.234 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 12:14:47.811 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 12:14:47.811 Requesting current DateTime from Sierra Chart server. | 2021-06-25 12:49:29.311 Received Date-time from server. Delay adjusted UTC Date-time: 2021-06-25 16:49:29.689. Round-trip delay: 00:00:00.195 | 2021-06-25 12:49:29.701 Computer time to server time difference: 00:00:00.012 | 2021-06-25 12:49:29.701 Successfully set the system Date-time to: 2021-06-25 16:49:29.689 UTC. | 2021-06-25 12:49:29.689 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 13:02:22.935 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:02:22.935 Enabling compression for file: C:\SierraChart\Data\BTCN21-CME.scid. This may take a while. | 2021-06-25 13:39:17.502 File compression enabled. C:\SierraChart\Data\BTCN21-CME.scid. CompressionState=0 | 2021-06-25 13:39:17.502 BTCN21-CME[M] #9 | Reloading chart. | 2021-06-25 13:39:17.502 BTCN21-CME[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:39:17.502 Mapping BTCN21-CME to BTCN21. Service code: cme | 2021-06-25 13:39:17.612 SC Data - All Services | Starting real-time market data updates for: BTCN21-CME (BTCN21). ID: 51 Service code: cme | 2021-06-25 13:39:17.612 SC Data - All Services | Requesting security definition data for: BTCN21-CME (BTCN21). ID: 51 | 2021-06-25 13:39:17.612 Added historical Intraday data request for BTCN21-CME to the queue. | 2021-06-25 13:39:17.612 Intraday data recording state for symbol BTCN21-CME is set to download 'Pending'. | 2021-06-25 13:39:17.612 Triggering next historical data download in queue. | 2021-06-25 13:39:17.612 Delaying start of download for BTCN21-CME | 2021-06-25 13:39:17.612 SC Data - All Services | Received security definition for symbol BTCN21-CME | 2021-06-25 13:39:17.643 Requesting market depth updates for: BTCN21-CME if supported. | 2021-06-25 13:39:19.172 SC Data - All Services (Market Orders Data) | Starting market orders updates for: BTCN21. MinimumMarketByOrderQuantity: 0. Service code: cme | 2021-06-25 13:39:19.172 SC Data - All Services | Clearing market depth for BTCN21-CME | 2021-06-25 13:39:19.296 HD Request # 94 | Downloading Intraday chart data for BTCN21-CME to the file BTCN21-CME.scid. Service: cme | 2021-06-25 13:39:22.089 HD Request # 94 | Download start date-time: 2020-02-11 12:39:22.000000. File last date-time: 00:00:00.000000 | 2021-06-25 13:39:22.089 HD Request # 94 | Using server: ds21.sierracharts.com port 10150 | 2021-06-25 13:39:22.089 Socket (3) | Creating socket. | 2021-06-25 13:39:22.089 Socket (3) | New receive buffer size: 5242880 | 2021-06-25 13:39:22.089 Socket (3) | Connecting to IP: 216.1.90.129. | 2021-06-25 13:39:22.089 HD Request # 94 | Setting DTC encoding to Binary VLS | 2021-06-25 13:39:22.151 HD Request # 94 | Sending historical data logon request message. | 2021-06-25 13:39:22.151 HD Request # 94 | Requesting Intraday data. Start date-time: 2020-02-11 12:39:22. Record interval: 0. Symbol: BTCN21 | 2021-06-25 13:39:22.635 HD Request # 94 | Decompressing data. | 2021-06-25 13:39:22.666 HD Request # 94 | Receiving Intraday data for BTCN21-CME starting at 2021-02-11 11:31:44.451000 | 2021-06-25 13:39:22.760 Socket (3) | CloseSocket call. | 2021-06-25 13:39:22.806 Historical data download thread signaled to stop. | 2021-06-25 13:39:22.806 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-25 13:39:22.806 HD Request # 94 | Timestamp of first Intraday data file record written: 2021-02-11 11:31:44.451000 | 2021-06-25 13:39:22.806 HD Request # 94 | Received 24947 records from 2021-02-11 11:31:44.451000 to 2021-06-25 13:39:17.421000 (134.0 days) and wrote 24947 records for BTCN21-CME | 2021-06-25 13:39:22.806 HD Request # 94 | Add time&sales data | Remembered last file record date-time: 2021-06-25 17:39:17.421000 | 2021-06-25 13:39:22.806 HD Request # 94 | Completion time: 0s | 2021-06-25 13:39:22.806 HD Request # 94 | Intraday data download complete for BTCN21-CME. Unique request ID: 94 | 2021-06-25 13:39:22.806 Removing historical data download ID 94. | 2021-06-25 13:39:22.806 Real-time Intraday chart data file updates started for BTCN21-CME | 2021-06-25 13:39:22.806 Intraday chart data file opened for BTCN21-CME | 2021-06-25 13:39:22.806 HD Request # 94 | Enabling Intraday chart updating for symbol. | 2021-06-25 13:39:22.822 Triggering next historical data download in queue. | 2021-06-25 13:39:22.822 No download requests in the queue to start downloads for. | 2021-06-25 13:39:22.822 Socket (3) | Socket gracefully closed by remote side. | 2021-06-25 13:39:22.838 Socket (3) | Closed. | 2021-06-25 13:39:22.838 Opened cached Intraday file: C:\SierraChart\Data\BTCN21-CME.scid. Thread ID: 5644 | 2021-06-25 13:39:31.152 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 13:39:37.564 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:39:37.564 Unsubscribed from market depth data for BTCN21-CME | 2021-06-25 13:39:39.202 SC Data - All Services (Market Orders Data) | Stopping market orders updates for: BTCN21.. Service code: cme | 2021-06-25 13:39:39.202 ETHUSD-BMEX[M] #9 | Reloading chart. | 2021-06-25 13:39:44.428 ETHUSD-BMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:39:44.428 Added historical Intraday data request for ETHUSD-BMEX to the queue. | 2021-06-25 13:39:44.537 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2021-06-25 13:39:44.537 Triggering next historical data download in queue. | 2021-06-25 13:39:44.537 HD Request # 95 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2021-06-25 13:39:44.537 HD Request # 95 | Download start date-time: 2021-06-17 09:39:50.000000. File last date-time: 2021-06-17 09:39:50.995000 | 2021-06-25 13:39:44.537 HD Request # 95 | Using server: ds12.sierracharts.com port 10149 | 2021-06-25 13:39:44.537 Socket (3) | Creating socket. | 2021-06-25 13:39:44.537 Socket (3) | New receive buffer size: 5242880 | 2021-06-25 13:39:44.537 Socket (3) | Connecting to IP: 204.15.197.14. | 2021-06-25 13:39:44.537 HD Request # 95 | Setting DTC encoding to Binary VLS | 2021-06-25 13:39:44.631 HD Request # 95 | Sending historical data logon request message. | 2021-06-25 13:39:44.631 HD Request # 95 | Requesting Intraday data. Start date-time: 2021-06-17 09:39:50. Record interval: 0. Symbol: ETHUSD-BMEX | 2021-06-25 13:39:45.192 HD Request # 95 | Decompressing data. | 2021-06-25 13:39:45.224 HD Request # 95 | Receiving Intraday data for ETHUSD-BMEX starting at 2021-06-17 09:39:50.000000 | 2021-06-25 13:39:45.395 HD Request # 95 | Timestamp of first Intraday data file record written: 2021-06-17 09:39:56.000000 | 2021-06-25 13:39:45.473 Socket (3) | CloseSocket call. | 2021-06-25 13:39:46.206 Historical data download thread signaled to stop. | 2021-06-25 13:39:46.206 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-25 13:39:46.206 HD Request # 95 | Received 189698 records from 2021-06-17 09:39:50.000000 to 2021-06-25 13:39:34.000000 (8.2 days) and wrote 189697 records for ETHUSD-BMEX | 2021-06-25 13:39:46.206 HD Request # 95 | Add time&sales data | Remembered last file record date-time: 2021-06-25 17:39:34.000000 | 2021-06-25 13:39:46.222 Added 1 Time and Sales records to Intraday data file for ETHUSD-BMEX after download. | 2021-06-25 13:39:46.222 HD Request # 95 | Completion time: 2s | 2021-06-25 13:39:46.222 HD Request # 95 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 95 | 2021-06-25 13:39:46.222 Removing historical data download ID 95. | 2021-06-25 13:39:46.222 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2021-06-25 13:39:46.222 Intraday chart data file opened for ETHUSD-BMEX | 2021-06-25 13:39:46.222 HD Request # 95 | Enabling Intraday chart updating for symbol. | 2021-06-25 13:39:46.222 Triggering next historical data download in queue. | 2021-06-25 13:39:46.222 No download requests in the queue to start downloads for. | 2021-06-25 13:39:46.222 Socket (3) | Socket gracefully closed by remote side. | 2021-06-25 13:39:46.253 Socket (3) | Closed. | 2021-06-25 13:39:46.253 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2021-06-25 13:39:49.217 SC DTC Data with Market Depth | Starting market orders updates for: ETHUSD-BMEX. MinimumMarketByOrderQuantity: 0. Service code: bitmex | 2021-06-25 13:39:49.217 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX | 2021-06-25 13:39:49.326 SC DTC Data with Market Depth | Market Orders data has been rejected for symbol: ETHUSD-BMEX. Market orders request not authorized. | 2021-06-25 13:39:49.326 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid. Thread ID: 5644 | 2021-06-25 13:39:51.432 XBTUSD-BMEX[M] #9 | Reloading chart. | 2021-06-25 13:40:04.646 XBTUSD-BMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:40:04.646 Added historical Intraday data request for XBTUSD-BMEX to the queue. | 2021-06-25 13:40:04.755 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2021-06-25 13:40:04.755 Triggering next historical data download in queue. | 2021-06-25 13:40:04.755 HD Request # 96 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2021-06-25 13:40:04.755 HD Request # 96 | Download start date-time: 2021-06-23 11:14:53.000000. File last date-time: 2021-06-23 11:14:53.851000 | 2021-06-25 13:40:04.755 HD Request # 96 | Using server: ds4.sierracharts.com port 10150 | 2021-06-25 13:40:04.755 Socket (3) | Creating socket. | 2021-06-25 13:40:04.755 Socket (3) | New receive buffer size: 5242880 | 2021-06-25 13:40:04.755 Socket (3) | Connecting to IP: 192.81.56.146. | 2021-06-25 13:40:04.755 HD Request # 96 | Setting DTC encoding to Binary VLS | 2021-06-25 13:40:04.833 HD Request # 96 | Sending historical data logon request message. | 2021-06-25 13:40:04.833 HD Request # 96 | Requesting Intraday data. Start date-time: 2021-06-23 11:14:53. Record interval: 0. Symbol: XBTUSD-BMEX | 2021-06-25 13:40:05.395 HD Request # 96 | Decompressing data. | 2021-06-25 13:40:05.426 HD Request # 96 | Receiving Intraday data for XBTUSD-BMEX starting at 2021-06-23 11:14:53.000000 | 2021-06-25 13:40:05.582 HD Request # 96 | Timestamp of first Intraday data file record written: 2021-06-23 11:14:55.000000 | 2021-06-25 13:40:05.691 Socket (3) | CloseSocket call. | 2021-06-25 13:40:05.753 Historical data download thread signaled to stop. | 2021-06-25 13:40:05.753 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-25 13:40:05.753 HD Request # 96 | Received 60385 records from 2021-06-23 11:14:53.000000 to 2021-06-25 13:40:03.000000 (2.1 days) and wrote 60384 records for XBTUSD-BMEX | 2021-06-25 13:40:05.753 HD Request # 96 | Add time&sales data | Remembered last file record date-time: 2021-06-25 17:40:03.000000 | 2021-06-25 13:40:05.753 Added 6 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2021-06-25 13:40:05.753 HD Request # 96 | Completion time: 1s | 2021-06-25 13:40:05.753 HD Request # 96 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 96 | 2021-06-25 13:40:05.753 Removing historical data download ID 96. | 2021-06-25 13:40:05.753 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2021-06-25 13:40:05.753 Intraday chart data file opened for XBTUSD-BMEX | 2021-06-25 13:40:05.753 HD Request # 96 | Enabling Intraday chart updating for symbol. | 2021-06-25 13:40:05.753 Triggering next historical data download in queue. | 2021-06-25 13:40:05.753 No download requests in the queue to start downloads for. | 2021-06-25 13:40:05.753 Socket (3) | Socket gracefully closed by remote side. | 2021-06-25 13:40:05.785 Socket (3) | Closed. | 2021-06-25 13:40:05.785 Unsubscribed from market depth data for ETHUSD-BMEX | 2021-06-25 13:40:09.248 SC DTC Data with Market Depth | Unsubscribing market orders updates for: ETHUSD-BMEX.. Service code: bitmex | 2021-06-25 13:40:09.248 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2021-06-25 13:40:09.248 SC DTC Data with Market Depth | Starting market orders updates for: XBTUSD-BMEX. MinimumMarketByOrderQuantity: 0. Service code: bitmex | 2021-06-25 13:40:09.248 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX | 2021-06-25 13:40:09.341 SC DTC Data with Market Depth | Market Orders data has been rejected for symbol: XBTUSD-BMEX. Market orders request not authorized. | 2021-06-25 13:40:09.341 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid. Thread ID: 5644 | 2021-06-25 13:40:11.713 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 13:40:42.725 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:40:42.741 Unsubscribed from market depth data for XBTUSD-BMEX | 2021-06-25 13:40:44.301 SC DTC Data with Market Depth | Unsubscribing market orders updates for: XBTUSD-BMEX.. Service code: bitmex | 2021-06-25 13:40:44.301 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 13:40:46.079 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:40:46.079 SC Data - All Services | Sent symbols for underlying request to server. Underlying: NG | 2021-06-25 13:41:33.784 SC Data - All Services | Received symbols for underlying request from server. Underlying: NG. Count: 1754 | 2021-06-25 13:41:38.121 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | Reloading chart. | 2021-06-25 13:42:48.696 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:42:48.696 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | Reloading chart. | 2021-06-25 13:42:48.914 LNEN21 C3350.FUT_OPT.NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:42:48.914 Requesting market depth updates for: LNEN21 C3350.FUT_OPT.NYMEX if supported. | 2021-06-25 13:42:49.491 SC Data - All Services (Market Orders Data) | Connecting to the server ds21.sierracharts.com. Port 80 | 2021-06-25 13:42:49.491 DTC Client socket (3) | Creating socket. | 2021-06-25 13:42:49.491 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-25 13:42:49.491 DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2021-06-25 13:42:49.491 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2021-06-25 13:42:49.522 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2021-06-25 13:42:49.522 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-25 13:42:49.522 SC Data - All Services | Clearing market depth for LNEN21 C3350.FUT_OPT.NYMEX | 2021-06-25 13:42:49.616 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-06-25 13:43:00.567 DTC Client socket (3) | CloseSocket call. | 2021-06-25 13:43:00.567 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2021-06-25 13:43:00.567 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 13:43:00.567 DTC Client socket (3) | Closed. | 2021-06-25 13:43:00.567 DTC Client socket (0) | CloseSocket call. | 2021-06-25 13:43:00.567 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2021-06-25 13:43:00.567 SC Data - All Services (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-25 13:43:00.567 SC Data - All Services (Market Orders Data) | Connecting to the server ds22.sierracharts.com. Port 80 | 2021-06-25 13:43:02.580 DTC Client socket (3) | Creating socket. | 2021-06-25 13:43:02.580 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-25 13:43:02.580 DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2021-06-25 13:43:02.580 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX is currently unavailable. | 2021-06-25 13:43:16.167 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX is currently unavailable. | 2021-06-25 13:43:16.167 NGN21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 13:43:18.445 NGN21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:43:18.445 Unsubscribed from market depth data for LNEN21 C3350.FUT_OPT.NYMEX | 2021-06-25 13:43:19.537 NGQ21-NYMEX[M] #9 | Reloading chart. | 2021-06-25 13:43:21.580 NGQ21-NYMEX[M] #9 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2021-06-25 13:43:21.596 DTC Client socket (3) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-06-25 13:43:23.608 * DTC Client socket (3) | CloseSocket call. | 2021-06-25 13:43:23.608 DTC Client socket (3) | Closed. | 2021-06-25 13:43:23.608 DTC Client socket (0) | CloseSocket call. | 2021-06-25 13:43:23.608 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2021-06-25 13:43:23.608 SC Data - All Services (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-25 13:43:23.608 SC Data - All Services (Market Orders Data) | Connecting to the server ds23.sierracharts.com. Port 80 | 2021-06-25 13:43:25.621 DTC Client socket (3) | Creating socket. | 2021-06-25 13:43:25.621 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-25 13:43:25.621 DTC Client socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-25 13:43:25.621 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2021-06-25 13:43:25.652 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2021-06-25 13:43:25.652 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-25 13:43:25.652 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2021-06-25 13:43:31.564 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX has been restored. | 2021-06-25 13:43:31.564 Added historical Intraday data request for XBTUSD-BMEX to the queue. | 2021-06-25 13:43:31.564 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2021-06-25 13:43:31.564 Triggering next historical data download in queue. | 2021-06-25 13:43:31.564 HD Request # 97 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2021-06-25 13:43:31.564 HD Request # 97 | Download start date-time: 2021-06-25 13:43:11.000000. File last date-time: 2021-06-25 13:43:11.916000 | 2021-06-25 13:43:31.564 HD Request # 97 | Using server: ds12.sierracharts.com port 10149 | 2021-06-25 13:43:31.564 Socket (9) | Creating socket. | 2021-06-25 13:43:31.564 Socket (9) | New receive buffer size: 5242880 | 2021-06-25 13:43:31.564 Socket (9) | Connecting to IP: 204.15.197.14. | 2021-06-25 13:43:31.564 HD Request # 97 | Setting DTC encoding to Binary VLS | 2021-06-25 13:43:31.674 HD Request # 97 | Sending historical data logon request message. | 2021-06-25 13:43:31.674 HD Request # 97 | Requesting Intraday data. Start date-time: 2021-06-25 13:43:11. Record interval: 0. Symbol: XBTUSD-BMEX | 2021-06-25 13:43:32.703 HD Request # 97 | Decompressing data. | 2021-06-25 13:43:32.750 HD Request # 97 | Receiving Intraday data for XBTUSD-BMEX starting at 2021-06-25 13:43:11.000000 | 2021-06-25 13:43:32.750 Socket (9) | CloseSocket call. | 2021-06-25 13:43:32.750 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-25 13:43:32.750 Historical data download thread signaled to stop. | 2021-06-25 13:43:32.750 HD Request # 97 | Timestamp of first Intraday data file record written: 2021-06-25 13:43:16.000000 | 2021-06-25 13:43:32.750 HD Request # 97 | Received 11 records from 2021-06-25 13:43:11.000000 to 2021-06-25 13:43:30.000000 (19.0 seconds) and wrote 10 records for XBTUSD-BMEX | 2021-06-25 13:43:32.750 HD Request # 97 | Add time&sales data | Remembered last file record date-time: 2021-06-25 17:43:30.000000 | 2021-06-25 13:43:32.750 HD Request # 97 | Completion time: 1s | 2021-06-25 13:43:32.750 HD Request # 97 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 97 | 2021-06-25 13:43:32.750 Removing historical data download ID 97. | 2021-06-25 13:43:32.750 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2021-06-25 13:43:32.750 Intraday chart data file opened for XBTUSD-BMEX | 2021-06-25 13:43:32.750 HD Request # 97 | Enabling Intraday chart updating for symbol. | 2021-06-25 13:43:32.750 Triggering next historical data download in queue. | 2021-06-25 13:43:32.750 No download requests in the queue to start downloads for. | 2021-06-25 13:43:32.750 Socket (9) | Socket gracefully closed by remote side. | 2021-06-25 13:43:32.906 Socket (9) | Closed. | 2021-06-25 13:43:32.906 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2021-06-25 13:43:33.249 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX has been restored. | 2021-06-25 13:43:33.249 Added historical Intraday data request for ETHUSD-BMEX to the queue. | 2021-06-25 13:43:33.249 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2021-06-25 13:43:33.249 Triggering next historical data download in queue. | 2021-06-25 13:43:33.249 HD Request # 98 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2021-06-25 13:43:33.249 HD Request # 98 | Download start date-time: 2021-06-25 13:43:11.000000. File last date-time: 2021-06-25 13:43:11.216000 | 2021-06-25 13:43:33.249 HD Request # 98 | Using server: ds4.sierracharts.com port 10150 | 2021-06-25 13:43:33.249 Socket (9) | Creating socket. | 2021-06-25 13:43:33.249 Socket (9) | New receive buffer size: 5242880 | 2021-06-25 13:43:33.249 Socket (9) | Connecting to IP: 192.81.56.146. | 2021-06-25 13:43:33.249 HD Request # 98 | Setting DTC encoding to Binary VLS | 2021-06-25 13:43:33.327 HD Request # 98 | Sending historical data logon request message. | 2021-06-25 13:43:33.327 HD Request # 98 | Requesting Intraday data. Start date-time: 2021-06-25 13:43:11. Record interval: 0. Symbol: ETHUSD-BMEX | 2021-06-25 13:43:33.904 HD Request # 98 | Decompressing data. | 2021-06-25 13:43:33.936 HD Request # 98 | Receiving Intraday data for ETHUSD-BMEX starting at 2021-06-25 13:43:11.000000 | 2021-06-25 13:43:33.936 Socket (9) | CloseSocket call. | 2021-06-25 13:43:33.936 Socket (9) | Shutdown started. Waiting for graceful close. | 2021-06-25 13:43:33.936 Historical data download thread signaled to stop. | 2021-06-25 13:43:33.936 HD Request # 98 | Timestamp of first Intraday data file record written: 2021-06-25 13:43:18.000000 | 2021-06-25 13:43:33.936 HD Request # 98 | Received 8 records from 2021-06-25 13:43:11.000000 to 2021-06-25 13:43:31.463000 (20.5 seconds) and wrote 7 records for ETHUSD-BMEX | 2021-06-25 13:43:33.936 HD Request # 98 | Add time&sales data | Remembered last file record date-time: 2021-06-25 17:43:31.463000 | 2021-06-25 13:43:33.936 HD Request # 98 | Completion time: 0s | 2021-06-25 13:43:33.936 HD Request # 98 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 98 | 2021-06-25 13:43:33.936 Removing historical data download ID 98. | 2021-06-25 13:43:33.936 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2021-06-25 13:43:33.936 Intraday chart data file opened for ETHUSD-BMEX | 2021-06-25 13:43:33.936 HD Request # 98 | Enabling Intraday chart updating for symbol. | 2021-06-25 13:43:33.936 Triggering next historical data download in queue. | 2021-06-25 13:43:33.936 No download requests in the queue to start downloads for. | 2021-06-25 13:43:33.936 Socket (9) | Socket gracefully closed by remote side. | 2021-06-25 13:43:33.982 Socket (9) | Closed. | 2021-06-25 13:43:33.982 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid. Thread ID: 5644 | 2021-06-25 13:43:34.513 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-06-25 13:43:36.650 DTC Client socket (3) | CloseSocket call. | 2021-06-25 13:43:36.650 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2021-06-25 13:43:36.650 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 13:43:36.650 DTC Client socket (3) | Closed. | 2021-06-25 13:43:36.650 DTC Client socket (0) | CloseSocket call. | 2021-06-25 13:43:36.650 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2021-06-25 13:43:36.650 SC Data - All Services (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-25 13:43:36.650 SC Data - All Services (Market Orders Data) | Connecting to the server ds21.sierracharts.com. Port 80 | 2021-06-25 13:43:38.662 DTC Client socket (3) | Creating socket. | 2021-06-25 13:43:38.662 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-25 13:43:38.662 DTC Client socket (3) | Connecting to IP: 216.1.90.129. | 2021-06-25 13:43:38.662 SC Data - All Services (Market Orders Data) | Network connection to server complete. | 2021-06-25 13:43:38.678 SC Data - All Services (Market Orders Data) | Starting socket receive thread. | 2021-06-25 13:43:38.678 SC Data - All Services (Market Orders Data) | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-25 13:43:38.678 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid. Thread ID: 5644 | 2021-06-25 13:43:39.583 DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-06-25 13:43:49.692 DTC Client socket (3) | CloseSocket call. | 2021-06-25 13:43:49.692 SC Data - All Services (Market Orders Data) | Waiting for socket receive thread to end | 2021-06-25 13:43:49.692 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-06-25 13:43:49.692 DTC Client socket (3) | Closed. | 2021-06-25 13:43:49.692 DTC Client socket (0) | CloseSocket call. | 2021-06-25 13:43:49.692 SC Data - All Services (Market Orders Data) | Disconnected from the server. | 2021-06-25 13:43:49.692 SC Data - All Services (Market Orders Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2021-06-25 13:43:49.692 SC Data - All Services (Market Orders Data) | Connecting to the server ds22.sierracharts.com. Port 80 | 2021-06-25 13:43:51.704 DTC Client socket (3) | Creating socket. | 2021-06-25 13:43:51.704 DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-25 13:43:51.704 DTC Client socket (3) | Connecting to IP: 208.185.224.129. | 2021-06-25 13:43:51.704  |
|   [2021-06-25 17:51:03]     |
| User664240 - Posts: 209 |
                EXITED AND UNCHECKED OPEN FILES ON START UP.  SO I'M STILL IN SAFE MODE WITH A BLANK SCREEN IN THE MAIN INSTANCE AND NOW 3M GONE BY AND NO DIS/REC.
|   [2021-06-25 22:59:38]     |
                This will be resolved in the next release we are putting out this evening.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
